[Swift-devel] Re: hanging workflow
Mihael Hategan hategan at mcs.anl.gov
Mon Apr 30 10:21:23 CDT 2007
Consistently or intermittently?
On Mon, 2007-04-30 at 15:00 +0000, Ben Clifford wrote:
> On Mon, 30 Apr 2007, Ben Clifford wrote:
> > any idea why this:
> > http://www.ci.uchicago.edu/~benc/fmri-tutorial/4-combine-img-hdr-type.swift
> > hangs for me after running all four reslice commands?
> looks like JVM uses a bunch of CPU time while it sits hung, too.
> This is the end of output run with -debug. I can send the lot if desired.
> This happened with the same code last week or so, too, but I've only got
> round to playing with it in more depth today:
> Task(type=4, identity=urn:0-2-1-1-1177944701983) setting status to Active
> Completed
> Task(type=4, identity=urn:0-0-1-2-1177944701986) setting status to Active
> Completed
> reslice completed
> Task(type=2, identity=urn:0-3-1-1-1177944701937) setting status to
> Completed
> Staged out 4-combine-img-hdr-type-412bm8vq69yl0/shared//slice4.img to
> slice4.img from localhost
> Task(type=4, identity=urn:0-3-1-1-1177944701989) setting status to Active
> Completed
> Task(type=2, identity=urn:0-1-1-1-1177944701963) setting status to
> Completed
> reslice completed
> Staged out 4-combine-img-hdr-type-412bm8vq69yl0/shared//slice2.img to
> slice2.img from localhost
> Task(type=4, identity=urn:0-1-1-1-1177944701992) setting status to Active
> Completed
> Task(type=2, identity=urn:0-0-1-1-1177944701975) setting status to
> Completed
> reslice completed
> Staged out 4-combine-img-hdr-type-412bm8vq69yl0/shared//slice1.img to
> slice1.img from localhost
> Task(type=4, identity=urn:0-0-1-1-1177944701995) setting status to Active
> Completed
> reslice completed
