[Swift-devel] swift in SVN is broken
    Ben Clifford
    benc at hawaga.org.uk
    Mon Apr 30 06:21:53 CDT 2007
On Fri, 27 Apr 2007, Veronika  V. Nefedova wrote:
> Hi,
> I tried to use swift from svn trunk and the build has failed with these
> errors. Please fix! Its a blocker for me...
What machine were you building this on, btw? I thought you were usually
using terminable, which should be giving you:
$ java -version
java version "1.5.0_06"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_06-b05)
Java HotSpot(TM) Client VM (build 1.5.0_06-b05, mixed mode, sharing)
