[Swift-devel] swift in SVN is broken
    Veronika  V. Nefedova
    nefedova at mcs.anl.gov
    Fri Apr 27 13:56:37 CDT 2007
Even though the compilation was successful, the execution was not. Swift
failed with Karajan exceptions:
RunID: z8onnx8li6qo1
Execution failed:
         Karajan exception: Ambiguous element: getfield. Possible choices:
         vdl:getfield
         java:getfield
[1]    Exit 2                        swift MolDyn.dtm
[302] wiggum /sandbox/ydeng/alamines >
So it still needs to be fixed.
Thanks!
Nika
At 01:45 PM 4/27/2007, Veronika  V. Nefedova wrote:
>I followed Mihael's advise and was able to compile with java 1.5
>Nika
>At 01:25 PM 4/27/2007, Mihael Hategan wrote:
>>Note: that constructor has only been added in java 1.5. It's not
>>available in 1.4.
>>On Fri, 2007-04-27 at 13:23 -0500, Veronika V. Nefedova wrote:
>> > Hi,
>> > I tried to use swift from svn trunk and the build has failed with these
>> > errors. Please fix! Its a blocker for me...
>> > Thanks!
>> > Nika
>> > compile:
>> >       [echo] [vdsk]: COMPILE
>> >      [mkdir] Created dir: /sandbox/nefedova/SWIFT/cog/modules/vdsk/build
>> >      [javac] Compiling 165 source files to
>> >      [javac]
>> /sandbox/nefedova/SWIFT/cog/modules/vdsk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java:35:
>> > cannot resolve symbol
>> >      [javac] symbol  : constructor IllegalArgumentException
>> > (java.lang.String,org.griphyn.vdl.mapping.InvalidMapperException)
>> >      [javac] location: class java.lang.IllegalArgumentException
>> >      [javac]                     throw new
>> > IllegalArgumentException(e.getMessage(), e);
>> >      [javac]                               ^
>> >      [javac]
>> /sandbox/nefedova/SWIFT/cog/modules/vdsk/src/org/griphyn/vdl/mapping/RootDataNode.java:38:
>> >      [javac]                     throw new
>> > IllegalArgumentException(e.getMessage(),e);
>> >      [javac]                               ^
>> >      [javac] 2 errors
>> > BUILD FAILED
>> > /sandbox/nefedova/SWIFT/cog/modules/vdsk/build.xml:69: The following error
>> > occurred while executing this line:
>> > /sandbox/nefedova/SWIFT/cog/mbuild.xml:463: The following error occurred
>> > /sandbox/nefedova/SWIFT/cog/mbuild.xml:227: Compile failed; see the
>> > compiler error output for details.
>> > _______________________________________________
>> > Swift-devel mailing list
>> > Swift-devel at ci.uchicago.edu
>> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
