[Swift-devel] file declaration inside foreach
Veronika V. Nefedova
nefedova at mcs.anl.gov
Wed Apr 25 12:55:54 CDT 2007
I tried what Mihael has suggested, but I am not sure that i got all the
syntax correct since it doesn't compile (complete dtm file is in
/home/nefedova/LQCD/fermi_bench/lqcd-genU.dtm on terminable)
file original[];
original[0]="test.in";
file lattice[];
lattice[0]="lattice.1";
foreach i in range {
file lattice[i] <single_file_mapper;file=@strcat("lattice.",i)>;
lattice[i] = lqcd_exec(original[i-1],lattice[i-1]);
file original[i] <"test.in">;
original[i]=mode_test_in(original[i-1],i);
When I try to compile it, it complains about this line:
[nefedova at terminable fermi_bench]$ swift lqcd-genU.dtm
Could not compile SwiftScript source: line 22:13: unexpected token: [
Please let me know what I did wrong here,
Nika
At 03:47 PM 4/24/2007, Mihael Hategan wrote:
>Because the jobs are independent. You are creating iteratiion-local
>variables between which there is no dependency.
>What you want is something like this:
>file[] lattice <...>;
>lattice[0] = initialLattice;
>for i in 1...2 {
> lattice[i] = app(lattice[i-1]);
>On Tue, 2007-04-24 at 15:37 -0500, Veronika V. Nefedova wrote:
> > Fortunately, Ti was able to fix my env on terminable (some faulty softenv
> > key thats not working in tcsh) so I was able to try the run there.
> > The compilation was fine, no problems. Then it submitted the workflow.
> > The main problem: it submitted 2 jobs at once (foreach loop is for i=1,2).
> > And since the jobs were supposed to run one after another - they all
> failed
> > (application failure)
> > Nika
> > At 03:17 PM 4/24/2007, Ben Clifford wrote:
> > >GCJ! that isn't normal java. is that what you normally use? it used to be
> > >lame, though i have no idea now. also evitable is unsupported. try
> > >terminable.
> > >On Tue, 24 Apr 2007, Veronika V. Nefedova wrote:
> > > > You right! here is the output:
> > > > [nefedova at evitable fermi_bench]$ swift -debug lqcd-genU.dtm
> > > > lqcd-genU.dtm: source file is new. Recompiling.
> > > > Detailed exception:
> > > > java.lang.RuntimeException: Failed to convert .xml to .kml for
> > > lqcd-genU.dtm
> > > > at org.griphyn.vdl.karajan.Loader.compile(java.lang.String) (Unknown
> > > > Source)
> > > > at org.griphyn.vdl.karajan.Loader.main(java.lang.String[]) (Unknown
> > > Source)
> > > > at gnu.java.lang.MainThread.call_main() (/usr/lib/libgcj.so.6.0.0)
> > > > at gnu.java.lang.MainThread.run() (/usr/lib/libgcj.so.6.0.0)
> > > > Caused by: java.lang.NullPointerException
> > > > at
> > > org.apache.xmlbeans.impl.schema.SchemaTypeLoaderBase.parse(java.io.File,
> > > > org.apache.xmlbeans.SchemaType, org.apache.xmlbeans.XmlOptions)
> (Unknown
> > > > Source)
> > > > at org.griphyn.vdl.model.ProgramDocument$Factory.parse(java.io.File)
> > > > (Unknown Source)
> > > > at org.griphyn.vdl.engine.Karajan.main(java.lang.String[]) (Unknown
> > > Source)
> > > > Source)
> > > > ...3 more
> > > > Could not start execution.
> > > > Failed to convert .xml to .kml for lqcd-genU.dtm
> > > > Nika
> > > > At 03:11 PM 4/24/2007, Ben Clifford wrote:
> > > > > run with -debug and you should get a much longer output.
> > > > > > I did some modifications to the dtm file, and now i get something
> > > > > different:
> > > > > > [nefedova at evitable fermi_bench]$ swift lqcd-genU.dtm
> > > > > > [nefedova at evitable fermi_bench]$ pwd
> > > > > > /autonfs/home/nefedova/LQCD/fermi_bench
> > > > > > Any idea what the problem could be?
> > > > > > Thanks,
> > > > > > Nika
> > > > > > At 01:39 PM 4/24/2007, Mihael Hategan wrote:
> > > > > > > On Tue, 2007-04-24 at 13:32 -0500, Mihael Hategan wrote:
> > > > > > > > Posting the kml file would be useful.
> > > > > > > Riiight. The nonexistent kml file. Nevermind me.
> > > > > > > > Mihael
> > > > > > > > On Tue, 2007-04-24 at 13:23 -0500, Veronika V. Nefedova wrote:
> > > > > > > > > Hi,
> > > > > > > > > I am wondering why this is not working?
> > > > > > > > > file in <simple_mapper;file=@strcat("lattice.",i);
> > > > > > > > > file out <simple_mapper;file=@strcat("lattice.",i+1);
> > > > > > > > > out=lqcd_exec(original,in);
> > > > > > > > > Swift complains about file declarations (mappers) inside
> foreach
> > > > > > > statement:
> > > > > > > > > Could not compile SwiftScript source: line 11:1: unexpected
> > > token:
> > > > > file
> > > > > > > > > Please let me know how to make it working (-;
> > > > > > > > > Thanks!
> > > > > > > > > Nika
> > > > > > > > > _______________________________________________
> > > > > > > > > Swift-devel mailing list
> > > > > > > > > Swift-devel at ci.uchicago.edu
> > > > > > > > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
