[Swift-devel] Interesting observation when running Swift
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Apr 10 13:19:49 CDT 2007
On Tue, 2007-04-10 at 13:08 -0500, Yong Zhao wrote:
> something Mike has been calling collectors for a long time: which does
> pattern matching (or other operations) on the remote execution directory
> and collect the outputs etc.
Yes, and it makes sense. Note that the difference between the existing()
function of the mappers and the above would be the ability to work on a
supplied file tree: existing(stuff), assuming that we don't want to
clutter "collectors" with knowledge of the implementation of the remote
file system access method.
> On Tue, 10 Apr 2007, Mihael Hategan wrote:
> > Remote mappers?
> > On Tue, 2007-04-10 at 13:01 -0500, Yong Zhao wrote:
> > > aren't these already addressed by remote mappers?
> > > Yong.
> > > > On Tue, 2007-04-10 at 12:12 -0500, Veronika V. Nefedova wrote:
> > > > > I think that something like that would be useful:
> > > > > outputsStage1[]=stage1()
> > > > > outputsStage2[]=stage2(outputsStage1[])
> > > > > if you didn't have to specify the number or specific filenames for the
> > > > > outputs. Basically it would be good for the Workflow engine to understand
> > > > > this: "get all the produced files from stage 1 and use them as an input for
> > > > > Stage 2"
> > > > Some applications are known to produce extra temporary files. Mappers
> > > > are supposed to be able to extract arrays from a cluttered file system
> > > > (assuming that there are no ambiguities in naming patterns). So yes, it
> > > > would be useful, and I think one of the planned features, and I see no
> > > > obvious problems besides the possible naming conflicts (which would
> > > > apply to a local file system anyway, so not a new problem).
> > > > > Nika
> > > > > At 11:57 AM 4/10/2007, Tiberiu Stef-Praun wrote:
> > > > > >Interesting.
> > > > > >Does anyone else think that monitoring the filesystem could be a useful idea ?
> > > > > >For instance it could help with file-driven dependencies, in scenarios
> > > > > >where we want to have continuous workflows, or compose independent
> > > > > >wokflows. The filesystem would act as the publish-subscribe mechanism
> > > > > >for some workflow cases.
> > > > > >Tibi
> > > > > >On 4/10/07, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > > > > >>Swift doesn't monitor the file system.
> > > > > >>Data driven doesn't mean that it does magic in the background. It means
> > > > > >>that you have to express data dependencies in the code.
> > > > > >>On Tue, 2007-04-10 at 11:47 -0500, Tiberiu Stef-Praun wrote:
> > > > > >> > I have a workflow along these lines:
> > > > > >> > // this one generates outputsStage1[]
> > > > > >> > stage1()
> > > > > >> > // this one merges the stage1 outputs
> > > > > >> > note that it is not outputsStage1=stage1()
> > > > > >> > Since the outputsStage1 files were not generated yet, I expected that
> > > > > >> > Karajan waited for them to be created before running stage2, but that
> > > > > >> > was not the case: stage2 was executed when the workflow started (and
> > > > > >> > it failed) and caused the workflow to fail.
> > > > > >> > I know how to fix the workflow, that is not the issue. The issue is
> > > > > >> > that I expected the workflow to be data-driven, but it seems to be
> > > > > >> > code driven. Explanation: it attempted to execute a section even if
> > > > > >> > its input files were not available.
> > > > > >> > Correct me if I am wrong.
> > > > > >> > Tibi
> > > > > >Tiberiu (Tibi) Stef-Praun, PhD
> > > > > >Research Staff, Computation Institute
> > > > > >5640 S. Ellis Ave, #405
> > > > > >University of Chicago
> > > > > >http://www-unix.mcs.anl.gov/~tiberius/
> > > > > >_______________________________________________
> > > > > >Swift-devel mailing list
> > > > > >Swift-devel at ci.uchicago.edu
> > > > > >http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
