[Swift-devel] Swift Question/Request
Tiberiu Stef-Praun
tiberius at ci.uchicago.edu
Tue Apr 3 10:52:08 CDT 2007
I'm not sure that the workflow below will wok as intended.
The uncertainty I have is after the submission to execution of the
moralhazard_problem procedure.
I have not tested it completely (I only ran it up to the
moralhazard_problem invocation), I'm still working on the
mergeSolutions script
Tibi
type file{}
//define the linear solver
(file solutions) moralhazard_solver (file scriptfile, int batch_size,
int batch_no,
file init_iteration, file init_param, file init_limits, file
init_surplus){
app{
moralhazard @filename(scriptfile) batch_size batch_no;
//(file solutions[]) moralhazard_problem (file inputfiles[]){
file script<"scripts/moralhazard-param.m">;
file iteration<"iteration.mat">;
file param<"param.mat">;
file limits<"limits.mat">;
file surplus<"Surplus.mat">;
// the limit of 36 needs to be adjusted
// the batch_size can change, together with the limit
// batch_size x batch_limit = gridsize(26x26)/2
int batch_limit=36;
int batch_size=10;
int batch_range=[0:35];
foreach i in batch_range {
int position=i*batch_size;
file solution<simple_mapper; prefix="hazard", suffix=position>;
solution=moralhazard_solver(script,batch_size,position,iteration,param,limits,surplus);
file problems[] <filesys_mapper; prefix="moral_hazard_4.31_1", suffix=".gz">;
file results[];
moralhazard_problem (problems);
file solutions[] <filesys_mapper; prefix="hazard">;
file solution <"mergedSolution.txt">;
file solution combineSolutions(file solverSolutions[]){
app{
mergeSolutions @filenames(solverSolutions)
stdout=@filename(solution);
combineSolutions(solutions);
On 4/3/07, Yong Zhao <yongzh at cs.uchicago.edu> wrote:
> Can you be more specific about why it can't figure out the number of
> outputs correctly? The sequential order should already be defined in your
> example as there is explicit data dependency.
> Yong.
> On Tue, 3 Apr 2007, Tiberiu Stef-Praun wrote:
> > Sometimes i find myself in the position of wanting to do one step of
> > the swift script only after the previous phase has finished. The case
> > is the following (not really swift script):
> > seq{
> > file stageOneOutputs[] = processStageOne();
> > file combine = combine(stageOneOutputs);
> > In my case the problem seems to be the fact that swift cannot dream up
> > how many stageOneOutput files will exist (unless we extend the
> > language -probably the input mapper which I use in this case- to
> > support this feature), so it could decide to start the combine stage
> > prematurely.
> > Supposedly one solution is to create a dummy output file at the end of
> > stage one, and pass it tot stage two.
> > Any suggestions ?
> > I'm thinking that having an example in the user guide would help others as well.
> > Maybe we should have a "Patterns in Swift" document.
> > Thanks
> > Tibi
> > Tiberiu (Tibi) Stef-Praun, PhD
> > Research Staff, Computation Institute
> > 5640 S. Ellis Ave, #405
> > University of Chicago
> > http://www-unix.mcs.anl.gov/~tiberius/
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
