[Swift-commit] r8456 - SwiftApps/subjobs
ketan at ci.uchicago.edu
Fri May 8 10:07:35 CDT 2015
Author: ketan
Date: 2015-05-08 10:07:34 -0500 (Fri, 08 May 2015)
New Revision: 8456
Added:
SwiftApps/subjobs/vaspbg.sh
Modified:
SwiftApps/subjobs/bg.sh
Log:
adding vasp related script
Modified: SwiftApps/subjobs/bg.sh
--- SwiftApps/subjobs/bg.sh 2015-05-07 22:39:23 UTC (rev 8455)
+++ SwiftApps/subjobs/bg.sh 2015-05-08 15:07:34 UTC (rev 8456)
@@ -89,11 +89,11 @@
#processedargs=$(echo "$@" | cut -d" " -f 1)
echo "$0": running BLOCK="$COBALT_PARTNAME" SLOT="$SWIFT_JOB_SLOT"
echo "$0": running cmd: "$0" args: "$@"
- echo "$0": runjob --block "$COBALT_PARTNAME" --corner "$CORNER" --shape "$SHAPE" -p 1 : "$@"
+ echo "$0": runjob --block "$COBALT_PARTNAME" --corner "$CORNER" --shape "$SHAPE" -p 16 --np "$((16*$SUBBLOCK_SIZE))" : "$@"
#without timeout
#runjob --strace none --block "$COBALT_PARTNAME" --corner "$CORNER" --shape "$SHAPE" -p 16 --np "$((16*$SUBBLOCK_SIZE))" : "$@"
- runjob --block "$COBALT_PARTNAME" --corner "$CORNER" --shape "$SHAPE" -p 1 : "$@"
+ runjob --block "$COBALT_PARTNAME" --corner "$CORNER" --shape "$SHAPE" -p 16 --np "$((16*$SUBBLOCK_SIZE))" : "$@"
echo "Runjob finished."
fi
Added: SwiftApps/subjobs/vaspbg.sh
--- SwiftApps/subjobs/vaspbg.sh (rev 0)
+++ SwiftApps/subjobs/vaspbg.sh 2015-05-08 15:07:34 UTC (rev 8456)
@@ -0,0 +1,124 @@
+#!/bin/bash
+#set -x
+mname=$(hostname)
+incarfile=$2
+poscarfile=$3
+potcarfile=$4
+kpointsfile=$5
+outcarfile=$6
+contcarfile=$7
+cp $incarfile .
+cp $poscarfile .
+cp $potcarfile .
+cp $kpointsfile .
+# vesta and mira has different path than cetus
+if [[ $mname == *vesta* || $mname == *mira* ]]
+then
+ export PATH=/soft/cobalt/bgq_hardware_mapper:$PATH
+else
+ export PATH=/soft/cobalt/cetus/bgq_hardware_mapper:$PATH
+fi
+#Run the preprocessing script
+#/bin/bash $preproc "$@"
+#export SUBBLOCK_SIZE=16
+# Prepare shape based on subblock size
+# provided by user in sites environment
+case "$SUBBLOCK_SIZE" in
+1) SHAPE="1x1x1x1x1"
+8) SHAPE="1x2x2x2x1"
+16) SHAPE="2x2x2x2x1"
+32) SHAPE="2x2x2x2x2"
+64) SHAPE="2x2x4x2x2"
+128) SHAPE="2x4x4x2x2"
+256) SHAPE="2x4x4x4x2"
+512) SHAPE="4x4x4x4x2"
+*) echo "SUBBLOCK_SIZE not set or incorrectly set: will not use subblock jobs"
+esac
+# If subblock size is provided, do subblock business
+if [ "$SUBBLOCK_SIZE"_ != "_" ]
+then
+ # sub-block size larger than 512 nodes, currently untested
+ if [ "$SUBBLOCK_SIZE" -gt 512 ]
+ then
+ export SWIFT_SUBBLOCKS=$(get-bootable-blocks --size $SUBBLOCK_SIZE $COBALT_PARTNAME)
+ export SWIFT_SUBBLOCK_ARRAY=($SWIFT_SUBBLOCKS)
+ if [ "_$SWIFT_SUBBLOCKS" = _ ]; then
+ echo ERROR: "$0": SWIFT_SUBBLOCKS is null.
+ exit 1
+ fi
+ BLOCK=${SWIFT_SUBBLOCK_ARRAY[$SWIFT_JOB_SLOT]}
+ #Some logging
+ echo "$0": running BLOCK="$BLOCK" SLOT="$SWIFT_JOB_SLOT"
+ echo "$0": running cmd: "$0" args: "$@"
+ echo "$0": running runjob --block "$BLOCK" : "$@"
+ boot-block --block $BLOCK
+ runjob --block $BLOCK : "$@"
+ boot-block --block $BLOCK --free
+ echo "Runjob finished"
+ else
+ export SWIFT_SUBBLOCKS=$(get-corners.py "$COBALT_PARTNAME" $SHAPE)
+ exit 1
+ fi
+ nsb=${#SWIFT_SUBBLOCK_ARRAY[@]}
+ CORNER=${SWIFT_SUBBLOCK_ARRAY[$SWIFT_JOB_SLOT]}
+ #Some logging
+ #processedargs=$(echo "$@" | cut -d" " -f 1)
+ echo "$0": running BLOCK="$COBALT_PARTNAME" SLOT="$SWIFT_JOB_SLOT"
+ echo "$0": runjob --block "$COBALT_PARTNAME" --corner "$CORNER" --shape "$SHAPE" -p 8 --np "$((8*$SUBBLOCK_SIZE))" : "$@"
+ #without timeout
+ #runjob --strace none --block "$COBALT_PARTNAME" --corner "$CORNER" --shape "$SHAPE" -p 16 --np "$((16*$SUBBLOCK_SIZE))" : "$@"
+ runjob --block "$COBALT_PARTNAME" --corner "$CORNER" --shape "$SHAPE" -p 8 --np "$((8*$SUBBLOCK_SIZE))" : $1
+ echo "Runjob finished."
+ fi
+else
+ # run w/o subblocks if no subblock size provided
+ echo "Running in nonsubblock mode."
+ echo "$0": running runjob -p 16 --block $COBALT_PARTNAME : "$@"
+ #strace -o "$HOME/strace.runjob.out" runjob --strace none -p 16 --block $COBALT_PARTNAME : "$@"
+ runjob -p 16 --block $COBALT_PARTNAME : "$@"
+ echo "Finished Running in nonsubblock mode."
+fi
+#Run the postprocessing script
+#/bin/bash $postproc "$@"
+mv OUTCAR $outcarfile
+mv CONTCAR $contcarfile
+exit 0
Property changes on: SwiftApps/subjobs/vaspbg.sh
___________________________________________________________________
Added: svn:executable
More information about the Swift-commit
