[Swift-commit] r8401 - SwiftApps/subjobs/gridpack
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Thu Mar 19 16:19:53 CDT 2015
Author: ketan
Date: 2015-03-19 16:19:53 -0500 (Thu, 19 Mar 2015)
New Revision: 8401
Removed:
   SwiftApps/subjobs/gridpack/bgsh-cagfy8zl-ca.2.stderr
Log:
cleanup
Deleted: SwiftApps/subjobs/gridpack/bgsh-cagfy8zl-ca.2.stderr
--- SwiftApps/subjobs/gridpack/bgsh-cagfy8zl-ca.2.stderr	2015-03-19 21:09:07 UTC (rev 8400)
+++ SwiftApps/subjobs/gridpack/bgsh-cagfy8zl-ca.2.stderr	2015-03-19 21:19:53 UTC (rev 8401)
@@ -1,598 +0,0 @@
-2014-10-23 20:38:23.702 (INFO ) [0xfff7ec1bdd0] ibm.runjob.AbstractOptions: using properties file /bgsys/local/etc/bg.properties
-2014-10-23 20:38:23.703 (INFO ) [0xfff7ec1bdd0] ibm.runjob.AbstractOptions: max open file descriptors: 65536
-2014-10-23 20:38:23.703 (INFO ) [0xfff7ec1bdd0] ibm.runjob.AbstractOptions: core file limit: 18446744073709551615
-2014-10-23 20:38:23.704 (INFO ) [0xfff7ec1bdd0] 24459:tatu.runjob.client: scheduler job id is 222728
-2014-10-23 20:38:23.709 (INFO ) [0xfff8fba34d0] 24459:tatu.runjob.monitor: monitor started
-2014-10-23 20:38:27.397 (INFO ) [0xfff8fba34d0] 24459:tatu.runjob.monitor: task record 787265 created
-2014-10-23 20:38:27.398 (INFO ) [0xfff7ec1bdd0] VST-20020-31331-64:24459:ibm.runjob.client.options.Parser: set local socket to runjob_mux from properties file
-2014-10-23 20:38:30.678 (INFO ) [0xfff7ec1bdd0] VST-20020-31331-64:985588:ibm.runjob.client.Job: job 985588 started
-(I) sc_uname[0.0:1]: name=0x1fbfffb8d0
-(I) sc_brk[0]: brk_val=r3=0x00000000
-(I) sc_brk[0]: brk_val=0x00000000, returning 0x1f83200000.
-(I) sc_brk[0]: brk_val=r3=0x1f83216ad0
-(I) sc_brk[0]: brk_val=0x1f83216ad0, returning 0x1f83216ad0.
-(I) sc_set_tid_address[ 0]: Entry: tid_addr=0x1f832000d0. Returning PID=1.
-(I) sc_futex[0]: op(129)=WAKE, uaddr=1fbfffb9b0, val=1 timeout=0 *uaddr=0 uaddr2=0x00000000 val3=0x00000000.
-(I) sc_futex[0]: op(393)=Other, uaddr=1fbfffb9b0, val=1 timeout=0 *uaddr=0 uaddr2=0x00000000 val3=0x00000000.
-(I) sc_rt_sigaction[0]: sig=32, act=0x1fbfffb7b0, oldact=0x00000000, sigsetsize=8.
-(I) sc_rt_sigaction[0]: act{ sa_handler:2ee6460, flags=4 }
-(I) sc_rt_sigaction[0]: sig=33, act=0x1fbfffb7b0, oldact=0x00000000, sigsetsize=8.
-(I) sc_rt_sigaction[0]: act{ sa_handler:2ee6430, flags=10000004 }
-(I) sc_rt_sigprocmask[0]: how=1 set=1fbfffb9d8 oldset=0
-(I) sc_ugetrlimit[0]: resource=3, rlp=0x0000001fbfffb9c0
-(I) sc_brk[0]: brk_val=r3=0x1f83237ad0
-(I) sc_brk[0]: brk_val=0x1f83237ad0, returning 0x1f83237ad0.
-(I) sc_brk[0]: brk_val=r3=0x1f83238000
-(I) sc_brk[0]: brk_val=0x1f83238000, returning 0x1f83238000.
-(I) sc_GET_PERSONALITY[0]: dst=0x000000000302f638, size=176.
-(I) sc_statfs[0.0:1]: pathname="/dev/shm/", buf=0x1fbfffabd8
-(I) sc_futex[0]: op(129)=WAKE, uaddr=3061f30, val=2147483647 timeout=0 *uaddr=2 uaddr2=0x00000000 val3=0x00000000.
-(I) sc_open[0.0:1]: pathname="/dev/shm/job0-pami-global-shmem", flags=0x000880c2 mode=(I) sc_fcntl[0.0:1]: fd=3, cmd=1, parm3=0x0
-(I) sc_ftruncate[0.0:1]: fd=3, len=389256
-(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x0005f088, prot=0x00000003(RW--), flags=0x00000001=(Shared ), filedes=0x00000003, off=0x00000000, MMap_Start=0x0000000000000000, MMap_End=0x0000000000000000.
-(I) sc_mmap[0]: Returning 0x31c1000000 for len=0x0005f088 fd=0x3.
-(I) sc_close[0.0:1]: fd=3
-(I) sc_open[0.0:1]: pathname="/dev/shm/job0-pami-global-shmem-a", flags=0x000880c2 mode=(I) sc_ftruncate[0.0:1]: fd=3, len=217984
-(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00035380, prot=0x00000003(RW--), flags=0x00000001=(Shared ), filedes=0x00000003, off=0x00000000, MMap_Start=0x0000000000000000, MMap_End=0x0000000000000000.
-(I) sc_mmap[0]: Returning 0x31c3010000 for len=0x00035380 fd=0x3.
-(I) sc_open[0.0:1]: pathname="/dev/shm/unique-comm-agent-shmem-file", flags=0x00088042 mode=(I) sc_ioctl[0.0:1]: fd=3, cmd=3221529856
-(I) sc_ftruncate[0.0:1]: fd=3, len=65536
-(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00010000, prot=0x00000003(RW--), flags=0x00000001=(Shared ), filedes=0x00000003, off=0x00000000, MMap_Start=0x0000000000000000, MMap_End=0x0000000000000000.
-(I) sc_mmap[0]: Returning 0x31c3000000 for len=0x00010000 fd=0x3.
-(I) sc_open[0.0:1]: pathname="/dev/shm/job0-L2AtomicFactory-shared", flags=0x000880c2 mode=(I) sc_ioctl[0.0:1]: fd=4, cmd=3221529856
-(I) sc_ftruncate[0.0:1]: fd=4, len=98440
-(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00018088, prot=0x00000003(RW--), flags=0x00000001=(Shared ), filedes=0x00000004, off=0x00000000, MMap_Start=0x0000000000000000, MMap_End=0x0000000000000000.
-(I) sc_mmap[0]: Returning 0x31c3045380 for len=0x00018088 fd=0x4.
-(I) sc_close[0.0:1]: fd=4
-(I) sc_open[0.0:1]: pathname="/dev/shm/job0-unique-pami-globalRM-shmem-file", flags=0x000880c2 mode=(I) sc_ftruncate[0.0:1]: fd=4, len=657988
-(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x000a0a44, prot=0x00000003(RW--), flags=0x00000001=(Shared ), filedes=0x00000004, off=0x00000000, MMap_Start=0x0000000000000000, MMap_End=0x0000000000000000.
-(I) sc_mmap[0]: Returning 0x31c1060000 for len=0x000a0a44 fd=0x4.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=64, nfifos=1fbfffb1b0, fifoids=1fbfffb1e0.
-(I) sc_ALLOCATE_INJ_FIFOS[0]: subgrpid=64, sg_ptr=1f832207c0, nfifos=1, fifoids=1fbfffb1e0, fifoAttrs=1f83220720.
-(I) sc_brk[0]: brk_val=r3=0x1f83271000
-(I) sc_brk[0]: brk_val=0x1f83271000, returning 0x1f83271000.
-(I) sc_ALLOCATE_INJ_FIFOS[0]: subgrpid=64, sg_ptr=31c1060080, nfifos=6, fifoids=1fbfffb1e0, fifoAttrs=1f83220300.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=65, nfifos=1fbfffb1b0, fifoids=1fbfffb1e0.
-(I) sc_ALLOCATE_INJ_FIFOS[0]: subgrpid=65, sg_ptr=31c1060350, nfifos=4, fifoids=1fbfffb1e0, fifoAttrs=1f83220300.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=64, nbatids=1fbfffb330, batids=1fbfffb358.
-(I) sc_ALLOCATE_BASE_ADDRESS_TABLE[0]: subgrpid=64, sg_ptr=31c1100680, nbatids=7, batids=1fbfffb358, system=0.
-(I) sc_CFG_REC_FIFO_THRESH[0]: threshold=21845.
-(I) sc_futex[0]: op(129)=WAKE, uaddr=3066fe4, val=2147483647 timeout=0 *uaddr=2 uaddr2=0x029d93e8 val3=0x029d93d8.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=0, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=0, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=0, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=1, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=1, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=1, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=2, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=2, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=2, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=3, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=3, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=3, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=4, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=4, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=4, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=5, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=5, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=5, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=6, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=6, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=6, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=7, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=7, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=7, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=8, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=8, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=8, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=9, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=9, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=9, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=10, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=10, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=10, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=11, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=11, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=11, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=12, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=12, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=12, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=13, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=13, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=13, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=14, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=14, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=14, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=15, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=15, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=15, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=16, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=16, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=16, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=17, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=17, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=17, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=18, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=18, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=18, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=19, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=19, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=19, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=20, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=20, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=20, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=21, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=21, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=21, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=22, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=22, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=22, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=23, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=23, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=23, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=24, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=24, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=24, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=25, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=25, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=25, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=26, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=26, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=26, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=27, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=27, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=27, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=28, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=28, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=28, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=29, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=29, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=29, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=30, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=30, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=30, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=31, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=31, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=31, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=32, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=32, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=32, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=33, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=33, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=33, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=34, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=34, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=34, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=35, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=35, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=35, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=36, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=36, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=36, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=37, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=37, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=37, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=38, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=38, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=38, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=39, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=39, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=39, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=40, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=40, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=40, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=41, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=41, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=41, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=42, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=42, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=42, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=43, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=43, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=43, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=44, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=44, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=44, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=45, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=45, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=45, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=46, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=46, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=46, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=47, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=47, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=47, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=48, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=48, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=48, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=49, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=49, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=49, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=50, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=50, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=50, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=51, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=51, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=51, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=52, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=52, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=52, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=53, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=53, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=53, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=54, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=54, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=54, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=55, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=55, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=55, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=56, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=56, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=56, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=57, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=57, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=57, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=58, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=58, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=58, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=59, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=59, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=59, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=60, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=60, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=60, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=61, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=61, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=61, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=62, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=62, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=62, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=63, nfifos=1fbfffb440, fifoids=1fbfffb460.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=63, nfifos=1fbfffb440, fifoids=1fbfffb450.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=63, nbatids=1fbfffb440, batids=1fbfffb480.
-(I) sc_open[0.0:1]: pathname="/dev/shm/job0-pami-client-MPI", flags=0x000880c2 mode=(I) sc_ftruncate[0.0:1]: fd=4, len=4194440
-(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00400088, prot=0x00000003(RW--), flags=0x00000001=(Shared ), filedes=0x00000004, off=0x00000000, MMap_Start=0x0000000000000000, MMap_End=0x0000000000000000.
-(I) sc_mmap[0]: Returning 0x31c305e000 for len=0x00400088 fd=0x4.
-(I) sc_brk[0]: brk_val=r3=0x1f832a4000
-(I) sc_brk[0]: brk_val=0x1f832a4000, returning 0x1f832a4000.
-(I) sc_brk[0]: brk_val=r3=0x1f832c5000
-(I) sc_brk[0]: brk_val=0x1f832c5000, returning 0x1f832c5000.
-(I) sc_brk[0]: brk_val=r3=0x1f832f5000
-(I) sc_brk[0]: brk_val=0x1f832f5000, returning 0x1f832f5000.
-(I) sc_brk[0]: brk_val=r3=0x1f83325000
-(I) sc_brk[0]: brk_val=0x1f83325000, returning 0x1f83325000.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=0, nfifos=1fbfffa8f0, fifoids=1fbfffa920.
-(I) sc_ALLOCATE_INJ_FIFOS[0]: subgrpid=0, sg_ptr=1f83283f20, nfifos=8, fifoids=1fbfffa920, fifoAttrs=1f83324e00.
-(I) sc_CFG_INJ_FIFO_INTS[0]: sg_ptr=1f83283f20, nfifos=8, fifoids=1fbfffa920, fifoInterrupts=1f83324e00.
-(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=1, nfifos=1fbfffa8f0, fifoids=1fbfffa920.
-(I) sc_ALLOCATE_INJ_FIFOS[0]: subgrpid=1, sg_ptr=1f832841f0, nfifos=2, fifoids=1fbfffa920, fifoAttrs=1f83314d20.
-(I) sc_CFG_INJ_FIFO_INTS[0]: sg_ptr=1f832841f0, nfifos=2, fifoids=1fbfffa920, fifoInterrupts=1f83314d20.
-(I) sc_brk[0]: brk_val=r3=0x1f83348000
-(I) sc_brk[0]: brk_val=0x1f83348000, returning 0x1f83348000.
-(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00101000, prot=0x00000003(RW--), flags=0x00000022=(Private Anonymous ), filedes=0xffffffffffffffff, off=0x00000000, MMap_Start=0x0000000000000000, MMap_End=0x0000000000000000.
-(I) sc_mmap[0]: Brk: 0x1f83200000 - 0x1f833fffff. MMap: 0x1f83400000 - 0x1fbfb00000.
-(I) sc_mmap[0]: Returning 0x1f83400000 for len=0x00101000.
-(I) sc_QUERY_REC_FIFOS[0]: subgrpid=0, nfifos=1fbfffa910, fifoids=1fbfffa928.
-(I) sc_ALLOCATE_REC_FIFOS[0]: subgrpid=0, sg_ptr=1f83324e00, nfifos=1, fifoids=1fbfffa928, fifoAttrs=1f832b4ba0.
-(I) sc_CFG_REC_FIFO_INTS[0]: sg_ptr=1f83324e00, nfifos=1, fifoids=1fbfffa928, fifoInterrupts=1f832b4ba0.
-(I) sc_REC_FIFO_ENABLE[0]: groupid=0, enableBitsr=0000000000008000.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=0, nbatids=1fbfffab40, batids=1fbfffab68.
-(I) sc_ALLOCATE_BASE_ADDRESS_TABLE[0]: subgrpid=0, sg_ptr=1f833274a0, nbatids=8, batids=1fbfffab68, system=0.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=1, nbatids=1fbfffab40, batids=1fbfffab68.
-(I) sc_ALLOCATE_BASE_ADDRESS_TABLE[0]: subgrpid=1, sg_ptr=1f833274f0, nbatids=8, batids=1fbfffab68, system=0.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=2, nbatids=1fbfffab40, batids=1fbfffab68.
-(I) sc_ALLOCATE_BASE_ADDRESS_TABLE[0]: subgrpid=2, sg_ptr=1f83327540, nbatids=8, batids=1fbfffab68, system=0.
-(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=3, nbatids=1fbfffab40, batids=1fbfffab68.
-(I) sc_ALLOCATE_BASE_ADDRESS_TABLE[0]: subgrpid=3, sg_ptr=1f83327590, nbatids=8, batids=1fbfffab68, system=0.
-(I) sc_brk[0]: brk_val=r3=0x1f83388000
-(I) sc_brk[0]: brk_val=0x1f83388000, returning 0x1f83388000.
-(I) sc_brk[0]: brk_val=r3=0x1f833c8000
-(I) sc_brk[0]: brk_val=0x1f833c8000, returning 0x1f833c8000.
-(I) sc_brk[0]: brk_val=r3=0x1f83408000
-(I) sc_brk[0]: brk_val=0x1f83408000, returning 0x1f833c8000.
-(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00800000, prot=0x00000003(RW--), flags=0x00000022=(Private Anonymous ), filedes=0xffffffffffffffff, off=0x00000000, MMap_Start=0x0000001f83400000, MMap_End=0x0000001fbfb00000.
-(I) sc_mmap[0]: Returning 0x1f83501000 for len=0x00800000.
-(I) sc_open[0.0:1]: pathname="/dev/shm/job0-pami-clt0-ctx-mm", flags=0x000880c2 mode=(I) sc_ftruncate[0.0:1]: fd=4, len=138376
-(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00021c88, prot=0x00000003(RW--), flags=0x00000001=(Shared ), filedes=0x00000004, off=0x00000000, MMap_Start=0x0000001f83400000, MMap_End=0x0000001fbfb00000.
-(I) sc_mmap[0]: Returning 0x31c1101000 for len=0x00021c88 fd=0x4.
-(I) sc_getuid[0]: returning 5222.
-(I) sc_time[0]: buf=0x0000000000000000
-(I) sc_open[0.0:1]: pathname="/etc/mtab", flags=0x00000000 mode=(I) sc_futex[0]: op(129)=WAKE, uaddr=307c318, val=2147483647 timeout=0 *uaddr=2 uaddr2=0x00000000 val3=0x00000000.
-(I) sc_fstat[0.0:1]: fd=4, buf=0x1fbfffacf0
-(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00010000, prot=0x00000003(RW--), flags=0x00000022=(Private Anonymous ), filedes=0xffffffffffffffff, off=0x00000000, MMap_Start=0x0000001f83400000, MMap_End=0x0000001fbfb00000.
-(I) sc_mmap[0]: Returning 0x1f83d01000 for len=0x00010000.
-(I) sc_read[0.0:1]: fd=4, buf=0x1f83d01000, cnt=65536
-(I) sc_statfs[0.0:1]: pathname="/gpfs/vesta-fs0", buf=0x1fbfffb4b0
-(I) sc_statfs[0.0:1]: pathname="/gpfs/vesta-home", buf=0x1fbfffb4b0
-(I) sc_munmap[0]: start=0x1f83d01000, len=0x00010000.
-(I) sc_open[0.0:1]: pathname="/etc/mtab", flags=0x00000000 mode=(I) sc_fstat[0.0:1]: fd=4, buf=0x1fbfffacf0
-(I) sc_statfs[0.0:1]: pathname="/", buf=0x1fbfffb4b0
-(I) sc_statfs[0.0:1]: pathname="/bgsys", buf=0x1fbfffb4b0
-(I) sc_uname[0.0:1]: name=0x1fbfffb370
-(I) sc_open[0.0:1]: pathname="/etc/localtime", flags=0x00000000 mode=(I) sc_fstat[0.0:1]: fd=4, buf=0x1fbfffb128
-(I) sc_fstat[0.0:1]: fd=4, buf=0x1fbfffad50
-(I) sc_lseek[0.0:1]: fd=4, offset=18446744073709551554, whence=1
-(I) sc_open[0.0:1]: pathname="", flags=0x00000000 mode=(I) sc_open[0.0:1]: pathname=".petscrc", flags=0x00000000 mode=(I) sc_open[0.0:1]: pathname="petscrc", flags=0x00000000 mode=(I) sc_uname[0.0:1]: name=0x1fbfff6cf0
-(I) sc_rt_sigaction[0]: sig=7, act=0x1fbfff6ef0, oldact=0x1fbfff6f88, sigsetsize=8.
-(I) sc_rt_sigaction[0]: act{ sa_handler:2e71978, flags=10000000 }
-(I) sc_rt_sigaction[0]: sig=8, act=0x1fbfff6ef0, oldact=0x1fbfff6f88, sigsetsize=8.
-(I) sc_rt_sigaction[0]: sig=1, act=0x1fbfff6ef0, oldact=0x1fbfff6f88, sigsetsize=8.
-(I) sc_rt_sigaction[0]: sig=4, act=0x1fbfff6ef0, oldact=0x1fbfff6f88, sigsetsize=8.
-(I) sc_rt_sigaction[0]: sig=13, act=0x1fbfff6ef0, oldact=0x1fbfff6f88, sigsetsize=8.
-(I) sc_rt_sigaction[0]: sig=3, act=0x1fbfff6ef0, oldact=0x1fbfff6f88, sigsetsize=8.
-(I) sc_rt_sigaction[0]: sig=11, act=0x1fbfff6ef0, oldact=0x1fbfff6f88, sigsetsize=8.
-(I) sc_rt_sigaction[0]: sig=31, act=0x1fbfff6ef0, oldact=0x1fbfff6f88, sigsetsize=8.
-(I) sc_rt_sigaction[0]: sig=15, act=0x1fbfff6ef0, oldact=0x1fbfff6f88, sigsetsize=8.
-(I) sc_rt_sigaction[0]: sig=5, act=0x1fbfff6ef0, oldact=0x1fbfff6f88, sigsetsize=8.
-(I) sc_rt_sigaction[0]: sig=23, act=0x1fbfff6ef0, oldact=0x1fbfff6f88, sigsetsize=8.
-(I) sc_gettimeofday[0]: tv=0x0000000002f71d88, tz=0x0000000000000000
-(I) sc_gettimeofday[0]: tv=0x0000000002f6ff08, tz=0x0000000000000000
-(I) sc_uname[0.0:1]: name=0x1fbfffb430
-(I) sc_open[0.0:1]: pathname="gridpack.petscrc", flags=0x00000000 mode=(I) sc_fstat[0.0:1]: fd=1, buf=0x1fbfffae70
-(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=1
-(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=48
-(I) sc_uname[0.0:1]: name=0x1fbfffb410
-(I) sc_rt_sigaction[0]: sig=17, act=0x1fbfffb310, oldact=0x1fbfffb3a8, sigsetsize=8.
-(I) sc_rt_sigaction[0]: act{ sa_handler:2e68438, flags=10000000 }
-(I) sc_rt_sigaction[0]: sig=1, act=0x1fbfffb310, oldact=0x1fbfffb3a8, sigsetsize=8.
-(I) sc_rt_sigaction[0]: act{ sa_handler:2e685d0, flags=10000000 }
-(I) sc_rt_sigaction[0]: sig=7, act=0x1fbfffb310, oldact=0x1fbfffb3a8, sigsetsize=8.
-(I) sc_rt_sigaction[0]: act{ sa_handler:2e68498, flags=10000000 }
-(I) sc_rt_sigaction[0]: sig=8, act=0x1fbfffb310, oldact=0x1fbfffb3a8, sigsetsize=8.
-(I) sc_rt_sigaction[0]: act{ sa_handler:2e684c8, flags=10000000 }
-(I) sc_rt_sigaction[0]: sig=4, act=0x1fbfffb310, oldact=0x1fbfffb3a8, sigsetsize=8.
-(I) sc_rt_sigaction[0]: act{ sa_handler:2e684f8, flags=10000000 }
-(I) sc_rt_sigaction[0]: sig=11, act=0x1fbfffb310, oldact=0x1fbfffb3a8, sigsetsize=8.
-(I) sc_rt_sigaction[0]: act{ sa_handler:2e68528, flags=10000000 }
-(I) sc_rt_sigaction[0]: sig=5, act=0x1fbfffb310, oldact=0x1fbfffb3a8, sigsetsize=8.
-(I) sc_rt_sigaction[0]: act{ sa_handler:2e685a0, flags=10000000 }
-(I) sc_rt_sigaction[0]: sig=2, act=0x1fbfffb310, oldact=0x1fbfffb3a8, sigsetsize=8.
-(I) sc_rt_sigaction[0]: act{ sa_handler:2e68408, flags=10000000 }
-(I) sc_rt_sigaction[0]: sig=15, act=0x1fbfffb310, oldact=0x1fbfffb3a8, sigsetsize=8.
-(I) sc_rt_sigaction[0]: act{ sa_handler:2e68618, flags=10000000 }
-(I) sc_rt_sigaction[0]: act{ sa_handler:2e683c0, flags=10000000 }
-(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x02001000, prot=0x00000003(RW--), flags=0x00000022=(Private Anonymous ), filedes=0xffffffffffffffff, off=0x00000000, MMap_Start=0x0000001f83400000, MMap_End=0x0000001fbfb00000.
-(I) sc_mmap[0]: Returning 0x1f83d11000 for len=0x02001000.
-(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x01681000, prot=0x00000003(RW--), flags=0x00000022=(Private Anonymous ), filedes=0xffffffffffffffff, off=0x00000000, MMap_Start=0x0000001f83400000, MMap_End=0x0000001fbfb00000.
-(I) sc_mmap[0]: Returning 0x1f85d12000 for len=0x01681000.
-(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x0030e000, prot=0x00000003(RW--), flags=0x00000022=(Private Anonymous ), filedes=0xffffffffffffffff, off=0x00000000, MMap_Start=0x0000001f83400000, MMap_End=0x0000001fbfb00000.
-(I) sc_mmap[0]: Returning 0x1f87393000 for len=0x0030e000.
-(I) sc_open[0.0:1]: pathname="infiles/input3.xml", flags=0x00000000 mode=(I) sc_getcwd[0.0:1]: buf=0x1f83a3dc80, len=4096
-(I) sc_lseek[0.0:1]: fd=4, offset=0, whence=2
-(I) sc_lseek[0.0:1]: fd=4, offset=0, whence=1
-(I) sc_lseek[0.0:1]: fd=4, offset=0, whence=0
-(I) sc_read[0.0:1]: fd=4, buf=0x1f83a3dc80, cnt=8191
-(I) sc_open[0.0:1]: pathname="contingencies.xml", flags=0x00000000 mode=(I) sc_getcwd[0.0:1]: buf=0x1f83a3df20, len=4096
-(I) sc_read[0.0:1]: fd=4, buf=0x1f83a3df20, cnt=8191
-(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=11
-(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=37
-(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=38
-(I) sc_open[0.0:1]: pathname="infiles/input3.xml", flags=0x00000000 mode=(I) sc_getcwd[0.0:1]: buf=0x1f83a3e2c0, len=4096
-(I) sc_read[0.0:1]: fd=4, buf=0x1f83a45ce0, cnt=8191
-(I) sc_open[0.0:1]: pathname="IEEE14_ca.raw", flags=0x00000000 mode=(I) sc_getcwd[0.0:1]: buf=0x1f83a45ce0, len=4096
-(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=30
-(I) sc_open[0.0:1]: pathname="CTG1.out", flags=0x00000241 mode=(I) sc_getcwd[0.0:1]: buf=0x1f83a7b8e0, len=4096
-(I) sc_open[0.0:1]: pathname="/dev/urandom", flags=0x00000000 mode=(I) sc_read[0.0:1]: fd=5, buf=0x1fbfff9a28, cnt=4
-(I) sc_read[0.0:1]: fd=5, buf=0x1fbfff9a28, cnt=4
-(I) sc_close[0.0:1]: fd=5
-(I) sc_rt_sigaction[0]: sig=6, act=0x1fbfff7cf0, oldact=0x1fbfff7d88, sigsetsize=8.
-(I) sc_rt_sigaction[0]: act{ sa_handler:2e8f450, flags=10000000 }
-(I) sc_rt_sigaction[0]: sig=15, act=0x1fbfff7cf0, oldact=0x1fbfff7d88, sigsetsize=8.
-(I) sc_rt_sigaction[0]: act{ sa_handler:0, flags=10000000 }
-(I) sc_futex[0]: op(129)=WAKE, uaddr=2dd4a8c, val=2147483647 timeout=0 *uaddr=2 uaddr2=0x7f7f7f7f7f7f7f7f val3=0x00008080.
-(I) sc_write[0.0:1]: fd=2, buf=0x1f83a5ccd8, cnt=52
-0: PETSc KSP converged after 1 iterations, reason: 3(I) sc_write[0.0:1]: fd=2, buf=0x2e1b32b, cnt=1
-(I) sc_write[0.0:1]: fd=2, buf=0x1f83a56a78, cnt=52
-0: PETSc KSP converged after 0 iterations, reason: 3(I) sc_write[0.0:1]: fd=2, buf=0x2e1b32b, cnt=1
-(I) sc_write[0.0:1]: fd=4, buf=0x1f83a7b8e0, cnt=352
-(I) sc_open[0.0:1]: pathname="CTG2.out", flags=0x00000241 mode=(I) sc_getcwd[0.0:1]: buf=0x1f838eb540, len=4096
-(I) sc_write[0.0:1]: fd=2, buf=0x1f83a54598, cnt=52
-(I) sc_write[0.0:1]: fd=2, buf=0x1f838ec638, cnt=52
-(I) sc_write[0.0:1]: fd=4, buf=0x1f83a7b8e0, cnt=383
-(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=32
-(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=44
-(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=41
-(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=40
-(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=35
-(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=42
-(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=51
-(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=49
-(I) sc_munmap[0]: start=0x1f85d12000, len=0x01681000.
-(I) sc_rt_sigaction[0]: sig=17, act=0x1fbfffb190, oldact=0x1fbfffb228, sigsetsize=8.
-(I) sc_rt_sigaction[0]: sig=15, act=0x1fbfffb190, oldact=0x1fbfffb228, sigsetsize=8.
-(I) sc_rt_sigaction[0]: sig=2, act=0x1fbfffb190, oldact=0x1fbfffb228, sigsetsize=8.
-(I) sc_rt_sigaction[0]: sig=11, act=0x1fbfffb190, oldact=0x1fbfffb228, sigsetsize=8.
-(I) sc_rt_sigaction[0]: sig=1, act=0x1fbfffb190, oldact=0x1fbfffb228, sigsetsize=8.
-(I) sc_rt_sigaction[0]: sig=7, act=0x1fbfff7330, oldact=0x1fbfff73c8, sigsetsize=8.
-(I) sc_rt_sigaction[0]: sig=8, act=0x1fbfff7330, oldact=0x1fbfff73c8, sigsetsize=8.
-(I) sc_rt_sigaction[0]: sig=1, act=0x1fbfff7330, oldact=0x1fbfff73c8, sigsetsize=8.
-(I) sc_rt_sigaction[0]: sig=4, act=0x1fbfff7330, oldact=0x1fbfff73c8, sigsetsize=8.
-(I) sc_rt_sigaction[0]: sig=13, act=0x1fbfff7330, oldact=0x1fbfff73c8, sigsetsize=8.
-(I) sc_rt_sigaction[0]: sig=3, act=0x1fbfff7330, oldact=0x1fbfff73c8, sigsetsize=8.
-(I) sc_rt_sigaction[0]: sig=11, act=0x1fbfff7330, oldact=0x1fbfff73c8, sigsetsize=8.
-(I) sc_rt_sigaction[0]: sig=31, act=0x1fbfff7330, oldact=0x1fbfff73c8, sigsetsize=8.
-(I) sc_rt_sigaction[0]: sig=15, act=0x1fbfff7330, oldact=0x1fbfff73c8, sigsetsize=8.
-(I) sc_rt_sigaction[0]: sig=5, act=0x1fbfff7330, oldact=0x1fbfff73c8, sigsetsize=8.
-(I) sc_rt_sigaction[0]: sig=23, act=0x1fbfff7330, oldact=0x1fbfff73c8, sigsetsize=8.
-(I) sc_stat[0.0:1]: path="/etc/localtime", buf=0x1fbfffaee8
-(I) sc_geteuid[0]: returning 5222.
-(I) sc_socketcall[0.0:1]: operation=1 sockfd=1
-(I) sc_socketcall[0.0:1]: operation=3 sockfd=4
-(I) sc_socketcall[0.0:1]: operation=9 sockfd=4
-(I) sc_poll[0.0:1]: nfds=1, timeout=5000
-(I) sc_socketcall[0.0:1]: operation=17 sockfd=4
-(I) sc_close[0.0:1]: fd=-1
-(I) sc_read[0.0:1]: fd=4, buf=0x1fbfffaa94, cnt=36
-(I) sc_read[0.0:1]: fd=4, buf=0x1fbfffade8, cnt=64
-(I) sc_uname[0.0:1]: name=0x1fbfffb050
-(I) sc_open[0.0:1]: pathname="/proc/meminfo", flags=0x00000000 mode=(I) sc_fstat[0.0:1]: fd=4, buf=0x1fbfff49b0
-(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00001000, prot=0x00000003(RW--), flags=0x00000022=(Private Anonymous ), filedes=0xffffffffffffffff, off=0x00000000, MMap_Start=0x0000001f83400000, MMap_End=0x0000001fbfb00000.
-(I) sc_mmap[0]: Returning 0x1f85d12000 for len=0x00001000.
-(I) sc_read[0.0:1]: fd=4, buf=0x1f85d12000, cnt=1024
-(I) sc_munmap[0]: start=0x1f85d12000, len=0x00001000.
-(I) sc_open[0.0:1]: pathname="/etc/romio-hints", flags=0x00000000 mode=(I) sc_statfs[0.0:1]: pathname="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74310-11943461529772078178.darshan_partial", buf=0x1fbfffaea0
-(I) sc_lstat[0.0:1]: path="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74310-11943461529772078178.darshan_partial", buf=0x1fbfffaf20
-(I) sc_statfs[0.0:1]: pathname="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23", buf=0x1fbfffaea0
-(I) sc_GET_PERSONALITY[0]: dst=0x0000001fbfffac80, size=176.
-(I) sc_umask[0.0:1]: newmask=0x00000012
-(I) sc_open[0.0:1]: pathname="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74310-11943461529772078178.darshan_partial", flags=0x000000c1 mode=(I) sc_stat[0.0:1]: path="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74310-11943461529772078178.darshan_partial", buf=0x1fbfffad20
-(I) sc_statfs[0.0:1]: pathname="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74310-11943461529772078178.darshan_partial", buf=0x1fbfffaca0
-(I) sc_open[0.0:1]: pathname="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74310-11943461529772078178.darshan_partial", flags=0x00000002 mode=(I) sc_stat[0.0:1]: path="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74310-11943461529772078178.darshan_partial", buf=0x1fbfffad20
-(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x01001000, prot=0x00000003(RW--), flags=0x00000022=(Private Anonymous ), filedes=0xffffffffffffffff, off=0x00000000, MMap_Start=0x0000001f83400000, MMap_End=0x0000001fbfb00000.
-(I) sc_mmap[0]: Returning 0x1f85d12000 for len=0x01001000.
-(I) sc_fcntl[0.0:1]: fd=4, cmd=7, parm3=0x1fbfffa9c0
-(I) sc_write[0.0:1]: fd=4, buf=0x1f85d120b8, cnt=978
-(I) sc_fcntl[0.0:1]: fd=4, cmd=6, parm3=0x1fbfffa9c0
-(I) sc_munmap[0]: start=0x1f85d12000, len=0x01001000.
-(I) sc_rename[0.0:1]: old="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74310-11943461529772078178.darshan_partial", new="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74310-11943461529772078178_1.darshan.gz"
-(I) sc_chmod[0.0:1]: path="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74310-11943461529772078178_1.darshan.gz", mode=0x00000120
-(I) sc_exit_group[ 0:0]: status = 0.
-2014-10-23 20:38:32.533 (INFO ) [0xfff7ec1bdd0] VST-20020-31331-64:985588:ibm.runjob.client.Job: exited with status 0
-2014-10-23 20:38:32.533 (INFO ) [0xfff7ec1bdd0] tatu.runjob.client: task exited with status 0
