[Swift-commit] r8397 - SwiftApps/subjobs
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Thu Mar 19 11:47:58 CDT 2015
Author: ketan
Date: 2015-03-19 11:47:56 -0500 (Thu, 19 Mar 2015)
New Revision: 8397
Added:
   SwiftApps/subjobs/README.95.txt
Modified:
   SwiftApps/subjobs/README.txt
Log:
README for Swift95
Added: SwiftApps/subjobs/README.95.txt
--- SwiftApps/subjobs/README.95.txt	                        (rev 0)
+++ SwiftApps/subjobs/README.95.txt	2015-03-19 16:47:56 UTC (rev 8397)
@@ -0,0 +1,268 @@
+Running Sub-block jobs via Swift
+Introduction
+Argonne Leadership Computing Facility (ALCF) hosts a leadership class (among
+the most powerful in the world) supercomputer, \textit{Mira}, which is a
+50K-node IBM Blue Gene/Q (BG/Q) with peak performance of 10 PetaFLOPS.
+Many applications are originally developed with small- and medium- size
+execution on regular clusters  in mind. Some of these applications are later
+used at large-scale in a workflow and/or many-task computing (MTC) style.  (MTC
+is an emerging computation style wherein the computation consists of a large
+number of medium-sized, semi-dependent tasks implemented as ordinary programs.)
+The BG/Q resource manager, Cobalt, provides a mechanism
+to run multiple small jobs (sub-block jobs) repeatedly over a larger outer
+block, but in order to run an application in this mode, the user has to
+manually determine the optimal geometry (i.e., select a subset of the nodes based on
+their interconnection, allowing for best internode communication) and related
+low-level parameters of the system. The subjob technique addresses this
+challenge and enables MTC application to be run on the BG/Q.
+This document describes the subjob approach to run multiple jobs over a single
+large block of compute nodes on Blue Gene/Q systems. The technique lets users
+submit multiple, independent, repeated jobs within a single larger Cobalt
+block.
+The Swift-subjob package provides tools, scripts and example use-cases to run
+Swift applications in subjob mode over the ALCF BG/Q resources: +Vesta+,
++Cetus+ and +Mira+. The framework is flexible in that the same Swift script and
+configuration can be used to run subjob or non-subjob mode depending on the
+scale and size of a run. Users can run multiple 'waves' of jobs asynchronously
+and in parallel.
+Swift subjobs
+To download the package, checkout the directory as follows:
+svn co https://svn.ci.uchicago.edu/svn/vdl2/SwiftApps/subjobs
+followed by:
+cd  subjobs
+To set up the environment:
+source setup
+To run an example application
+./runswift.sh
+How To
+To convert an ordinary Swift application run in sub-block mode, the following changes are required:
+First, Add bg.sh as the application invoker in place of +sh+ or any other invoker. For example, if the app definition is as follows:
+sh @exe @i @o arg("s","1") stdout=@sout stderr=@serr;
+Replace the shell invocation with the bg.sh invocations like so:
+bg.sh @exe @i @o arg("s","1") stdout=@sout stderr=@serr;
+Second, add the +SUBBLOCK_SIZE+ environment variable to the sites file. For example:
+<profile key="SUBBLOCK_SIZE" namespace="env">16</profile>
+NOTE: The value of +SUBBLOCK_SIZE+ variable must be a power of 2 greater than 8 and less than the +maxnodes+ value.
+A complete example sites file for a sub-block job run on ALCF +Vesta+ is shown below:
+<?xml version="1.0" encoding="UTF-8"?>
+<config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
+<pool handle="cluster">
+<execution provider="coaster" jobmanager="local:cobalt" />
+<!-- "slots" determine the number of Cobalt jobs -->
+<profile namespace="globus" key="slots">1</profile>
+<profile namespace="globus" key="mode">script</profile>
+<profile namespace="karajan" key="jobThrottle">2.99</profile>
+<profile namespace="karajan" key="initialScore">10000</profile>
+<profile namespace="globus" key="maxwalltime">00:40:00</profile>
+<profile namespace="globus" key="walltime">2050</profile>
+<profile namespace="globus" key="maxnodes">256</profile>
+<profile namespace="globus" key="nodegranularity">256</profile>
+<!-- required for sub-block jobs, remove for non-sub-block jobs -->
+<profile namespace="globus" key="jobsPerNode">16</profile>
+<workdirectory>/tmp/swiftwork</workdirectory>
+<filesystem provider="local"/>
+</pool>
+</config>
+Of note are the +SUBBLOCK_SIZE+ and the +mode+ properties which must be present
+in the sites definition. The former defines the size of the subblock needed and
+the latter specifies that the "mode" to run the outer cobalt job would be
++script+ mode. In this particular example, we have the outer block size to be
+256 nodes whereas the subblock size is 16 nodes. This results in a total of 16
+subblocks resulting in +jobsPerNode+ value to be 16.
+NOTE: Swift installation for sub-block jobs on Vesta and Mira machines can be
+found at +/home/ketan/swift-0.95/cog/modules/swift/dist/swift-svn/bin/swift+
+Use-Case Applications
+This section discusses some of the real-world use-case applications that are set up
+with this package. These applications are tested with subblock and non-subblock
+runs on ALCF Vesta, a 2-rack (2048 nodes) BlueGene/Q system.
+NAMD
++NAMD+ is a molecular dynamics simulation code developed at
+http://www.ks.uiuc.edu/Research/namd[uiuc]. The Swift source and configuration
+files along with application inputs can be found in the +namd+ directory in the
+subjobs pacjage. To run NAMD example:
+cd namd #change to the package's namd directory
+./runvesta.sh #run on vesta
+./runmira.sh  #run on mira
+To run NAMD with a different input dataset, change the input files in the
++input_files+ directory and reflect the changes in the +namd.swift+ source code,
+especially the data definitions part:
+file psf <"input_files/h0_solvion.psf">;
+file pdb <"input_files/h0_solvion.pdb">;
+file coord_restart <"input_files/h0_eq.0.restart.coor">;
+file velocity_restart <"input_files/h0_eq.0.restart.vel">;
+file system_restart <"input_files/h0_eq.0.restart.xsc">;
+file namd_config <"input_files/h0_eq.conf">;
+file charmm_parameters <"input_files/par_all22_prot.inp">;
+Similarly, in order to change the scale and size of runs, make changes to the
+parameters in the sites file as described in section 1 above.
+ToDo: Visualize NAMD results with VMD.
+Rosetta
++Rosetta+ is a molecular http://rosie.rosettacommons.org/docking[docking]
+toolkit with many related programs used by many large-scale HPC science
+applications. This implementation shows how to run +FlexPeptide Docking+ on
+ALCF systems. The Swift scripts, configuration and application specific inputs
+are found in the +rosetta+ directory. To run the example:
+cd rosetta
+To change scale, size and/or inputs of the run, change the location of input
+files in the Swift source file (+rosetta.swift+) like so:
+file pdb_files[] <filesys_mapper; location="hlac_complex", suffix=".pdb">;
+In the above line all +.pdb+ files in the directory +hlac_complex+ will be
+processed in parallel. Change the +location+ from +hlac_complex+ to where you
+have your input files.
+To change the number of generated +structs+ by Flexpep Docking program, change
+the struct argument in the call to the rosetta application like so:
+(scorefile, rosetta_output, rosetta_error) = rosetta(pdb, 2);
+In the above line, the number +2+ indicates the number of +structs+ to be
+generated by the docking. Change this value to the desired size to change the
+desired number of +structs+. To make changes to other parameters, make changes
+to the commandline as invoked in the +app+ definition in the Swift script like
+so:
+bgsh "/home/ketan/openmp-gnu-july16-mini/build/src/debug/linux/2.6/64/ppc64/xlc/static-mpi/FlexPepDocking.staticmpi.linuxxlcdebug" "-database" "/home/ketan/minirosetta_database" "-pep_refine" "-s" @pdb_file "-ex1" "-ex2aro" "-use_input_sc" "-nstruct" nstruct "-overwrite" "-scorefile" @_scorefile stdout=@out stderr=@err;
+Dock
+Dock is another molecular docking
+http://dock.compbio.ucsf.edu/DOCK_6/dock6_manual.htm[program] used by many
+applications. The Swift source, configuration and application related inputs
+can be found in the +dock+ directory. To run the Dock example:
+cd dock
+GridPack
+GridPack is a simulation package designed for powergrid design application.
+HALO
+HALO is a astrophysics application.
+Internals
+The key driver of the Swift sub-block jobs is a script called +bg.sh+ that does
+the sub-block jobs calculations and othe chores for the users. The script looks
+as follows:
+include::bg.sh[]
+Sub-block limitations
+There are currently the following two limitations with sub-block jobs:
+. The maximum size of the outer Cobalt job must not exceed 512 nodes, ie. half
+of a hardware rack.
+. The successive subjobs must be submitted with a gap of at least 3 seconds in
+between. This means for a large number of shorter than 5 seconds jobs, the
+system will be underutilized. Consequently, subblocks are suitable for
+tasks which are more than a couple of minutes in duration.
+Further Information
+. More information about Swift can be found http://swift-lang.org/main[here].
+. More about ALCF can be found http://www.alcf.anl.gov[here].
+. More about IBM BlueGene sub-block jobs can be found http://www.alcf.anl.gov/files/ensemble_jobs_0.pdf[here] (warning: pdf).
Modified: SwiftApps/subjobs/README.txt
--- SwiftApps/subjobs/README.txt	2015-03-16 20:45:44 UTC (rev 8396)
+++ SwiftApps/subjobs/README.txt	2015-03-19 16:47:56 UTC (rev 8397)
@@ -3,31 +3,42 @@
 Introduction
-This document describes an approach to run multiple jobs over a single large
-block of compute nodes on BlueGene/Q systems.
-The technique, called sub-block jobs lets users submit multiple, independent,
-repeated jobs within a single larger Cobalt block. Sub-block jobs is a mode of
-running jobs on BlueGene/Q systems wherein one can allocate a larger "outer"
-block of compute nodes and repeatedly submit jobs of smaller sized sub-blocks
-to this block.
+the most powerful in the world) supercomputer, +Mira+, which is a
-The current package provides tools, scripts and example use-cases to run Swift
-applications in sub-block mode over the ALCF BlueGene/Q resources: +Vesta+,
-+Cetus+ and +Mira+. The benefit of this approach is that the user does not have
-to invoke the sub-block specific routines involving the details of the
-underlying node interconnect hardware. Additionally, with the same Swift script
-and configuration, user gets a flexibility to run jobs in sub-block or
-non-sub-block mode depending on the scale and size of a run. The approach
-transparently allows user to run jobs directly via Swift. Users can run
-multiple 'waves' of jobs asynchronously and in parallel without restarting the
-outer block.
-Swift sub-block jobs
+The BG/Q resource manager, Cobalt, provides a mechanism to run multiple small
+jobs (sub-block jobs) repeatedly over a larger outer block. In order to run an
+application in this mode, the user has to manually determine the optimal
+geometry (i.e., select a subset of the nodes based on their interconnection,
+allowing for best internode communication) and related low-level parameters of
+the system. The subjob technique addresses this challenge and enables MTC
+application to be run on the BG/Q.
-To download the package, checkout the directory as follows:
+block.
+Swift applications in subjob mode over the ALCF BG/Q resources: +Cetus+ (for
+small-scale testing) and +Mira+. The framework is flexible in that the same
+and in parallel.
+Quickstart
+To download the package, SVN checkout the directory as follows:
@@ -44,7 +55,7 @@
 source setup
-To run an example application
+To run an example application (mpicatnap, described in section x.y)
 ./runswift.sh
@@ -53,28 +64,31 @@
 How To
-To convert an ordinary Swift application run in sub-block mode, the following changes are required:
+To configure a Swift application to run in subjob mode, the following
+changes are required:
-First, Add bg.sh as the application invoker in place of +sh+ or any other invoker. For example, if the app definition is as follows:
+First, add +bg.sh+ as the application invoker in place of +sh+ or any other
+invoker. For example, if the app definition is as follows:
-Replace the shell invocation with the bg.sh invocations like so:
+Replace the invocation with the +bg.sh+ invocations like so:
-Second, add the +SUBBLOCK_SIZE+ environment variable to the sites file. For example:
+Second, export the +SUBBLOCK_SIZE+ environment variable. For example:
-<profile key="SUBBLOCK_SIZE" namespace="env">16</profile>
+export SUBBLOCK_SIZE=16
-NOTE: The value of +SUBBLOCK_SIZE+ variable must be a power of 2 greater than 8 and less than the +maxnodes+ value.
+NOTE: The value of +SUBBLOCK_SIZE+ variable must be a power of 2 greater than 8 and less than 512.
@@ -113,14 +127,17 @@
-NOTE: Swift installation for sub-block jobs on Vesta and Mira machines can be found at +/home/ketan/swift-0.95/cog/modules/swift/dist/swift-svn/bin/swift+
+found at +/home/ketan/x/y/dist/swift-svn/bin/swift+
-This section discusses some of the real-world use-case applications that are set up
-with this package. These applications are tested with subblock and non-subblock
-runs on ALCF Vesta, a 2-rack (2048 nodes) BlueGene/Q system.
+This section discusses some of the real-world use-cases that are set up as demo
+applications with this package. These applications are tested with subblock as
+well as non-subblock runs on BG/Q system.
 NAMD
@@ -153,8 +170,6 @@
-ToDo: Visualize NAMD results with VMD.
 Rosetta
@@ -166,7 +181,6 @@
 cd rosetta
-./runvesta.sh #run on vesta
@@ -188,10 +202,19 @@
-In the above line, the number +2+ indicates the number of +structs+ to be generated by the docking. Change this value to the desired size to change the desired number of +structs+. To make changes to other parameters, make changes to the commandline as invoked in the +app+ definition in the Swift script like so:
+so:
-bgsh "/home/ketan/openmp-gnu-july16-mini/build/src/debug/linux/2.6/64/ppc64/xlc/static-mpi/FlexPepDocking.staticmpi.linuxxlcdebug" "-database" "/home/ketan/minirosetta_database" "-pep_refine" "-s" @pdb_file "-ex1" "-ex2aro" "-use_input_sc" "-nstruct" nstruct "-overwrite" "-scorefile" @_scorefile stdout=@out stderr=@err;
+bgsh \
+"/home/ketan/openmp-gnu-july16-mini/build/src/debug/linux/2.6/64/ppc64/xlc/static-mpi/FlexPepDocking.staticmpi.linuxxlcdebug" \
+"-database" "/home/ketan/minirosetta_database" \
+"-pep_refine" "-s" @pdb_file "-ex1" "-ex2aro" \
+"-use_input_sc" "-nstruct" nstruct "-overwrite" \
+"-scorefile" @_scorefile stdout=@out stderr=@err;
 Dock
@@ -219,12 +242,15 @@
 Internals
-The key driver of the Swift sub-block jobs is a script called +bg.sh+ that does the sub-block jobs calculations and othe chores for the users. The script looks as follows:
+as follows:
 include::bg.sh[]
@@ -237,6 +263,7 @@
 Further Information
