[Swift-commit] r8469 - www/Swift-T
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Thu Jul 23 16:57:35 CDT 2015
Author: wozniak
Date: 2015-07-23 16:57:35 -0500 (Thu, 23 Jul 2015)
New Revision: 8469
Modified:
   www/Swift-T/turbine-sites.html
Log:
Fix Beagle
Modified: www/Swift-T/turbine-sites.html
--- www/Swift-T/turbine-sites.html	2015-07-23 21:53:25 UTC (rev 8468)
+++ www/Swift-T/turbine-sites.html	2015-07-23 21:57:35 UTC (rev 8469)
@@ -1855,8 +1855,8 @@
 <div class="content">
 <pre><code>./configure --prefix=/path/to/lb --with-c-utils=/path/to/c-utils
 CC=gcc
-CFLAGS=-I/opt/cray/mpt/default/gni/mpich2-gnu/49/include
-LDFLAGS="-L/opt/cray/mpt/default/gni/mpich2-gnu/49/lib -lmpich"
+CFLAGS=-I/opt/cray/mpt/default/gni/mpich2-gnu/47/include
+LDFLAGS="-L/opt/cray/mpt/default/gni/mpich2-gnu/47/lib -lmpich"
 --enable-mpi-2</code></pre>
 </div></div>
 </li>
@@ -1866,7 +1866,7 @@
 </p>
 <div class="listingblock">
-<pre><code>--enable-custom-mpi --with-mpi=/opt/cray/mpt/default/gni/mpich2-gnu/49</code></pre>
+<pre><code>--enable-custom-mpi --with-mpi=/opt/cray/mpt/default/gni/mpich2-gnu/47</code></pre>
 </div></div>
 </li>
 </ul></div>
@@ -2191,11 +2191,9 @@
 </p>
-<pre><code>./configure --prefix=/path/to/lb --with-c-utils=/path/to/c-utils
-CC=gcc
-CFLAGS=-I/opt/cray/mpt/default/gni/mpich2-gnu/47/include
-LDFLAGS="-L/opt/cray/mpt/default/gni/mpich2-gnu/47/lib -lmpich"
---enable-mpi-2</code></pre>
+<pre><code>$ export CFLAGS=-I/opt/cray/mpt/default/gni/mpich2-gnu/49/include
+$ export LDFLAGS="-L/opt/cray/mpt/default/gni/mpich2-gnu/49/lib -lmpich"
+$ ./configure --prefix=/path/to/lb --with-c-utils=/path/to/c-utils CC=gcc --enable-mpi-2</code></pre>
 </div></div>
 </li>
 <li>
@@ -2204,7 +2202,7 @@
 </p>
-<pre><code>--enable-custom-mpi --with-mpi=/opt/cray/mpt/default/gni/mpich2-gnu/47</code></pre>
+<pre><code>--enable-custom-mpi --with-mpi=/opt/cray/mpt/default/gni/mpich2-gnu/49</code></pre>
 </div></div>
 </li>
 </ul></div>
@@ -2698,7 +2696,7 @@
 <div id="footer">
 <div id="footer-text">
 Version 0.8.0<br />
-Last updated 2015-07-23 16:49:34 CDT
+Last updated 2015-07-23 16:57:11 CDT
 </div>
 </div>
 </body>
