[Swift-commit] r8441 - www/Swift-T
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Wed Apr 29 14:52:28 CDT 2015
Author: wozniak
Date: 2015-04-29 14:52:28 -0500 (Wed, 29 Apr 2015)
New Revision: 8441
Modified:
   www/Swift-T/turbine-sites.html
Log:
Fix location
Modified: www/Swift-T/turbine-sites.html
--- www/Swift-T/turbine-sites.html	2015-04-29 19:47:52 UTC (rev 8440)
+++ www/Swift-T/turbine-sites.html	2015-04-29 19:52:28 UTC (rev 8441)
@@ -763,9 +763,11 @@
 <div class="paragraph"><p>For each machine, a <strong>public installation</strong> and/or a <strong>build procedure</strong> will
 be provided.  The user need only follow one set of directions.</p></div>
 <div class="paragraph" id="login_node"><p>A <strong>login node installation</strong> may be available on certain systems.  This
-will run Swift/T on the login node of that system.  This only acceptable for
-short debugging runs of 1 minute or less.  It will affect other users
-so please be cautious when using this mode for debugging.</p></div>
+will run Swift/T on the login node of that system.  This only
+acceptable for short debugging runs of 1 minute or less.  If you do
+this, you should run <code>swift-t</code> or <code>turbine</code> under the <code>nice</code> command.
+It will affect other users so please be cautious when using this mode
+for debugging.</p></div>
 <div class="sect2">
 <h3 id="_public_installations">Public installations</h3>
 <div class="paragraph"><p>These are maintained by the Swift/T team.  Because they may become out
@@ -2185,7 +2187,7 @@
 <div class="paragraph"><p>Swan is a Cray XC40 at Cray.</p></div>
 <div class="sect3">
 <h4 id="_public_installation_9">Public installation</h4>
-<div class="paragraph"><p>A public installation may be run at: <code>~/Public/sfw/swift-t/stc/bin/swift-t</code></p></div>
+<div class="paragraph"><p>A public installation may be run at: <code>~p01951/Public/sfw/swift-t/stc/bin/swift-t</code></p></div>
 <div class="paragraph"><p>Run with, e.g.:</p></div>
 <div class="listingblock">
 <div class="content">
@@ -2430,7 +2432,7 @@
 <div id="footer">
 <div id="footer-text">
 Version 0.8.0<br />
-Last updated 2015-04-29 14:47:33 CDT
+Last updated 2015-04-29 14:52:39 CDT
 </div>
 </div>
 </body>
