[Swift-commit] r8439 - www/Swift-T
    wozniak at ci.uchicago.edu
    Wed Apr 29 14:45:28 CDT 2015
Author: wozniak
Date: 2015-04-29 14:45:28 -0500 (Wed, 29 Apr 2015)
New Revision: 8439
Modified:
   www/Swift-T/turbine-sites.html
Log:
Document Swan
Modified: www/Swift-T/turbine-sites.html
--- www/Swift-T/turbine-sites.html	2015-04-22 21:01:02 UTC (rev 8438)
+++ www/Swift-T/turbine-sites.html	2015-04-29 19:45:28 UTC (rev 8439)
@@ -1911,6 +1911,8 @@
 <div class="content">
 <pre><code>QUEUE=normal BLUE_WATERS=true PPN=32 turbine-aprun-run.zsh -n 32 helloworld.tcl</code></pre>
 </div></div>
+<div class="paragraph"><p>(The <code>BLUE_WATERS=true</code> setting was renamed to <code>CRAY_PPN=true</code> on
+April 29, 2015.)</p></div>
 </div>
 <div class="sect3">
 <h4 id="_installing_from_source">Installing from source</h4>
@@ -2179,10 +2181,60 @@
 </div>
 </div>
 <div class="sect2">
+<h3 id="_swan">Swan</h3>
+<div class="paragraph"><p>Swan is a Cray XC40 at Cray.</p></div>
+<div class="sect3">
+<h4 id="_build_procedure_11">Build procedure</h4>
+<div class="ulist"><ul>
+<li>
+<p>
+Configure c-utils as usual with <code>gcc</code>.
+</p>
+</li>
+<li>
+<p>
+Configure ADLB with:
+</p>
+<div class="listingblock">
+<div class="content">
+<pre><code>CC=gcc
+CFLAGS=-I/opt/cray/mpt/default/gni/mpich2-gnu/48/include
+LDFLAGS="-L/opt/cray/mpt/default/gni/mpich2-gnu/48/lib -lmpich"
+./configure --prefix=/path/to/lb --with-c-utils=/path/to/c-utils</code></pre>
+</div></div>
+</li>
+<li>
+<p>
+Configure Turbine with:
+</p>
+<pre><code>./configure --prefix=/path/to/turbine CC=gcc
+--enable-custom-mpi
+--with-mpi-include=/opt/cray/mpt/default/gni/mpich2-gnu/48/include
+--with-mpi-lib-dir=/opt/cray/mpt/default/gni/mpich2-gnu/48/lib
+--with-tcl=/home/users/p01951/Public/sfw/tcl-8.6.2</code></pre>
+</div></div>
+</li>
+<li>
+<p>
+Compile STC as usual.
+</p>
+</li>
+</ul></div>
+<div class="paragraph"><p>Run with, e.g.:</p></div>
+<pre><code>export CRAY_PPN=true
+swift-t -m cray -n 4 program.swift</code></pre>
+</div></div>
+</div>
+</div>
+<div class="sect2">
 <h3 id="_raven">Raven</h3>
 <div class="paragraph"><p>Raven is a Cray XE6/XK7 at Cray.</p></div>
 <div class="sect3">
-<h4 id="_build_procedure_11">Build procedure</h4>
+<h4 id="_build_procedure_12">Build procedure</h4>
 <li>
 <p>
@@ -2374,7 +2426,7 @@
 <div id="footer">
 <div id="footer-text">
 Version 0.8.0<br />
-Last updated 2015-04-21 14:59:10 CDT
+Last updated 2015-04-29 14:40:19 CDT
 </div>
 </div>
 </body>
More information about the Swift-commit
