[Swift-commit] r8422 - in SwiftApps/subjobs: . simanalyze/part05	vasp
    ketan at ci.uchicago.edu
    Sat Apr  4 12:21:19 CDT 2015
Author: ketan
Date: 2015-04-04 12:21:19 -0500 (Sat, 04 Apr 2015)
New Revision: 8422
Added:
   SwiftApps/subjobs/simanalyze/part05/mira.conf
   SwiftApps/subjobs/vasp/
   SwiftApps/subjobs/vasp/INCAR
   SwiftApps/subjobs/vasp/KPOINTS
   SwiftApps/subjobs/vasp/POSCAR
   SwiftApps/subjobs/vasp/POTCAR
   SwiftApps/subjobs/vasp/cetus.conf
   SwiftApps/subjobs/vasp/cobaltvasp.sh
   SwiftApps/subjobs/vasp/job.sh
   SwiftApps/subjobs/vasp/runcetus.sh
   SwiftApps/subjobs/vasp/runvasp.sh
   SwiftApps/subjobs/vasp/vasp.swift
   SwiftApps/subjobs/vasp/vaspostproc.sh
   SwiftApps/subjobs/vasp/vaspreproc.sh
Modified:
   SwiftApps/subjobs/bg.sh
Log:
add vasp app
Modified: SwiftApps/subjobs/bg.sh
--- SwiftApps/subjobs/bg.sh	2015-04-01 00:01:17 UTC (rev 8421)
+++ SwiftApps/subjobs/bg.sh	2015-04-04 17:21:19 UTC (rev 8422)
@@ -19,7 +19,7 @@
 fi
 #Run the preprocessing script
-./$preproc
+/bin/bash $preproc "$@"
 #export SUBBLOCK_SIZE=16
@@ -86,13 +86,14 @@
         CORNER=${SWIFT_SUBBLOCK_ARRAY[$SWIFT_JOB_SLOT]}
         #Some logging
+        processedargs=$(echo "$@" | cut -d" " -f 1)
         echo "$0": running BLOCK="$COBALT_PARTNAME" SLOT="$SWIFT_JOB_SLOT"
         echo "$0": running cmd: "$0" args: "$@"
-        echo "$0": running runjob --strace none --block "$COBALT_PARTNAME" --corner "$CORNER" --shape "$SHAPE" -p 16 --np "$((16*$SUBBLOCK_SIZE))" : "$@"
+        echo "$0": runjob --block "$COBALT_PARTNAME" --corner "$CORNER" --shape "$SHAPE" -p 1 : "$processedargs"
         #without timeout
         #runjob --strace none --block "$COBALT_PARTNAME" --corner "$CORNER" --shape "$SHAPE" -p 16 --np "$((16*$SUBBLOCK_SIZE))" : "$@"
-        runjob --block "$COBALT_PARTNAME" --corner "$CORNER" --shape "$SHAPE" -p 16 --np "$((16*$SUBBLOCK_SIZE))" : "$@"
+        runjob --block "$COBALT_PARTNAME" --corner "$CORNER" --shape "$SHAPE" -p 1 : "$processedargs"
         echo "Runjob finished."
     fi
@@ -108,7 +109,7 @@
 fi
 #Run the postprocessing script
-./$postproc
+/bin/bash $postproc "$@"
 exit 0
Added: SwiftApps/subjobs/simanalyze/part05/mira.conf
--- SwiftApps/subjobs/simanalyze/part05/mira.conf	                        (rev 0)
+++ SwiftApps/subjobs/simanalyze/part05/mira.conf	2015-04-04 17:21:19 UTC (rev 8422)
@@ -0,0 +1 @@
+link ../../conf/mira.conf
\ No newline at end of file
Property changes on: SwiftApps/subjobs/simanalyze/part05/mira.conf
___________________________________________________________________
Added: svn:special
Added: SwiftApps/subjobs/vasp/INCAR
--- SwiftApps/subjobs/vasp/INCAR	                        (rev 0)
+++ SwiftApps/subjobs/vasp/INCAR	2015-04-04 17:21:19 UTC (rev 8422)
@@ -0,0 +1,18 @@
+ SYSTEM =   Fe4N 5  atoms Pm-3m
+ Electronic Relaxation 1
+   ENCUT  = 3200 eV
+   NELM   = 50
+   EDIFF  = 5E-05   stopping-criterion for ELM
+ Ionic Relaxation
+   NSW    = 400          number of steps for ionic relaxation
+   IBRION = 1           quasi-Newtonian
+   ISIF   = 4           forces, relax ions, compute forces
+   EDIFFG = 5E-04       convergence criterion for ir
+ Magnetic stuff
+   ISPIN  = 3
+   MAGMOM = 4*5 1*0
+   RWIGS  = 4*1.35 1*1.0
Added: SwiftApps/subjobs/vasp/KPOINTS
--- SwiftApps/subjobs/vasp/KPOINTS	                        (rev 0)
+++ SwiftApps/subjobs/vasp/KPOINTS	2015-04-04 17:21:19 UTC (rev 8422)
@@ -0,0 +1,6 @@
+Automatic mesh
+0
+Monkhorst Pack
+ 1  1  1
+ 0. 0. 0.
Added: SwiftApps/subjobs/vasp/POSCAR
--- SwiftApps/subjobs/vasp/POSCAR	                        (rev 0)
+++ SwiftApps/subjobs/vasp/POSCAR	2015-04-04 17:21:19 UTC (rev 8422)
@@ -0,0 +1,13 @@
+   gamma-Fe4N Cubic
+    0.997298612
+     3.7900000000000000    0.0000000000000000    0.0000000000000000
+     0.0000000000000000    3.7900000000000000    0.0000000000000000
+     0.0000000000000000    0.0000000000000000    3.7900000000000000
+   Fe   N
+     4     1
+Direct
+    0.0    0.0   0.0
+  0.0    0.5   0.5
+  0.5    0.5   0.0
+  0.5    0.0   0.5
+  0.5    0.5   0.5
Added: SwiftApps/subjobs/vasp/POTCAR
--- SwiftApps/subjobs/vasp/POTCAR	                        (rev 0)
+++ SwiftApps/subjobs/vasp/POTCAR	2015-04-04 17:21:19 UTC (rev 8422)
@@ -0,0 +1,3678 @@
+ PAW_PBE Fe_pv 06Sep2000
+ 14.0000000000000000
+ parameters from PSCTR are:
+   VRHFIN =Fe:  3pd7s1
+   LEXCH  = PE
+   EATOM  =  2456.8974 eV,  180.5769 Ry
+   TITEL  = PAW_PBE Fe_pv 06Sep2000
+   LULTRA =        F    use ultrasoft PP ?
+   IUNSCR =        1    unscreen: 0-lin 1-nonlin 2-no
+   RPACOR =    1.750    partial core radius
+   POMASS =   55.847; ZVAL   =   14.000    mass and valenz
+   RCORE  =    2.200    outmost cutoff radius
+   RWIGS  =    2.200; RWIGS  =    1.164    wigner-seitz radius (au A)
+   ENMAX  =  293.238; ENMIN  =  219.929 eV
+   RCLOC  =    1.701    cutoff for local pot
+   LCOR   =        T    correct aug charges
+   LPAW   =        T    paw PP
+   EAUG   =  578.342
+   DEXC   =    -.002
+   RMAX   =    2.693    core radius for proj-oper
+   RAUG   =    1.300    factor for augmentation sphere
+   RDEP   =    2.296    radius for radial grids
+   QCUT   =   -4.642; QGAM   =    9.285    optimization parameters
+   Description
+     l     E      TYP  RCUT    TYP  RCUT
+     1   .000     23  2.000
+     1  -.400     23  2.000
+     2   .000     23  2.200
+     2   .000     23  2.200
+     0   .000     23  2.000
+     0  2.000     23  2.000
+     3   .000      7   .000
+   Error from kinetic energy argument (eV)
+   NDATA  =      100
+   STEP   =   20.000   1.050
+  199.      197.      196.      193.      192.      189.      187.      185.
+  182.      179.      177.      173.      170.      166.      162.      157.
+  153.      148.      144.      137.      132.      127.      120.      115.
+  110.      103.      95.3      90.5      83.4      76.6      70.0      63.6
+  57.6      51.8      46.4      41.3      35.1      30.8      25.7      22.3
+  18.2      14.7      11.7      9.21      7.12      5.42      4.06      2.74
+  1.96      1.25      .765      .504      .292      .170      .975E-01  .731E-01
+  .649E-01  .632E-01  .619E-01  .576E-01  .500E-01  .404E-01  .306E-01  .205E-01
+  .141E-01  .927E-02  .689E-02  .608E-02  .597E-02  .588E-02  .539E-02  .448E-02
+  .339E-02  .239E-02  .161E-02  .125E-02  .113E-02  .112E-02  .107E-02  .928E-03
+  .710E-03  .503E-03  .369E-03  .311E-03  .302E-03  .288E-03  .247E-03  .185E-03
+  .134E-03  .110E-03  .103E-03  .974E-04  .809E-04  .618E-04  .477E-04  .423E-04
+  .392E-04  .339E-04  .262E-04  .213E-04
+END of PSCTR-controll parameters
+ local part
+ 85.0376694860515556
+   .14031159E+03   .14028744E+03   .14021498E+03   .14009432E+03   .13992560E+03
+   .13970903E+03   .13944487E+03   .13913343E+03   .13877509E+03   .13837027E+03
+   .13791944E+03   .13742312E+03   .13688187E+03   .13629632E+03   .13566713E+03
+   .13499499E+03   .13428067E+03   .13352493E+03   .13272863E+03   .13189264E+03
+   .13101786E+03   .13010526E+03   .12915583E+03   .12817059E+03   .12715061E+03
+   .12609699E+03   .12501084E+03   .12389332E+03   .12274562E+03   .12156893E+03
+   .12036448E+03   .11913351E+03   .11787728E+03   .11659707E+03   .11529416E+03
+   .11396985E+03   .11262544E+03   .11126224E+03   .10988159E+03   .10848478E+03
+   .10707316E+03   .10564803E+03   .10421072E+03   .10276255E+03   .10130481E+03
+   .99838814E+02   .98365840E+02   .96887168E+02   .95404057E+02   .93917752E+02
+   .92429478E+02   .90940443E+02   .89451833E+02   .87964810E+02   .86480513E+02
+   .85000059E+02   .83524533E+02   .82054998E+02   .80592485E+02   .79137996E+02
+   .77692504E+02   .76256950E+02   .74832239E+02   .73419248E+02   .72018816E+02
+   .70631748E+02   .69258814E+02   .67900747E+02   .66558245E+02   .65231969E+02
+   .63922542E+02   .62630550E+02   .61356543E+02   .60101033E+02   .58864496E+02
+   .57647368E+02   .56450051E+02   .55272909E+02   .54116269E+02   .52980423E+02
+   .51865627E+02   .50772099E+02   .49700025E+02   .48649555E+02   .47620805E+02
+   .46613860E+02   .45628769E+02   .44665551E+02   .43724196E+02   .42804661E+02
+   .41906875E+02   .41030739E+02   .40176128E+02   .39342888E+02   .38530842E+02
+   .37739789E+02   .36969502E+02   .36219736E+02   .35490221E+02   .34780670E+02
+   .34090776E+02   .33420213E+02   .32768642E+02   .32135704E+02   .31521031E+02
+   .30924238E+02   .30344930E+02   .29782702E+02   .29237139E+02   .28707817E+02
+   .28194306E+02   .27696170E+02   .27212968E+02   .26744255E+02   .26289582E+02
+   .25848502E+02   .25420563E+02   .25005316E+02   .24602314E+02   .24211110E+02
+   .23831262E+02   .23462330E+02   .23103883E+02   .22755492E+02   .22416737E+02
+   .22087204E+02   .21766488E+02   .21454193E+02   .21149932E+02   .20853328E+02
+   .20564014E+02   .20281634E+02   .20005845E+02   .19736314E+02   .19472721E+02
+   .19214758E+02   .18962130E+02   .18714555E+02   .18471765E+02   .18233504E+02
+   .17999530E+02   .17769615E+02   .17543542E+02   .17321112E+02   .17102134E+02
+   .16886433E+02   .16673849E+02   .16464229E+02   .16257439E+02   .16053352E+02
+   .15851856E+02   .15652850E+02   .15456243E+02   .15261956E+02   .15069920E+02
+   .14880076E+02   .14692375E+02   .14506777E+02   .14323249E+02   .14141767E+02
+   .13962316E+02   .13784886E+02   .13609473E+02   .13436081E+02   .13264718E+02
+   .13095395E+02   .12928131E+02   .12762944E+02   .12599859E+02   .12438901E+02
+   .12280098E+02   .12123480E+02   .11969076E+02   .11816917E+02   .11667035E+02
+   .11519460E+02   .11374220E+02   .11231345E+02   .11090861E+02   .10952793E+02
+   .10817163E+02   .10683991E+02   .10553292E+02   .10425082E+02   .10299369E+02
+   .10176161E+02   .10055459E+02   .99372639E+01   .98215693E+01   .97083665E+01
+   .95976421E+01   .94893787E+01   .93835550E+01   .92801453E+01   .91791201E+01
+   .90804458E+01   .89840851E+01   .88899968E+01   .87981362E+01   .87084553E+01
+   .86209027E+01   .85354241E+01   .84519624E+01   .83704579E+01   .82908487E+01
+   .82130708E+01   .81370586E+01   .80627447E+01   .79900609E+01   .79189379E+01
+   .78493056E+01   .77810937E+01   .77142318E+01   .76486498E+01   .75842779E+01
+   .75210470E+01   .74588891E+01   .73977375E+01   .73375269E+01   .72781937E+01
+   .72196765E+01   .71619158E+01   .71048545E+01   .70484383E+01   .69926152E+01
+   .69373365E+01   .68825562E+01   .68282312E+01   .67743220E+01   .67207920E+01
+   .66676080E+01   .66147400E+01   .65621615E+01   .65098490E+01   .64577828E+01
+   .64059459E+01   .63543251E+01   .63029099E+01   .62516932E+01   .62006706E+01
+   .61498407E+01   .60992051E+01   .60487675E+01   .59985344E+01   .59485145E+01
+   .58987185E+01   .58491593E+01   .57998513E+01   .57508105E+01   .57020544E+01
+   .56536014E+01   .56054712E+01   .55576842E+01   .55102612E+01   .54632237E+01
+   .54165931E+01   .53703911E+01   .53246391E+01   .52793583E+01   .52345691E+01
+   .51902916E+01   .51465448E+01   .51033469E+01   .50607147E+01   .50186641E+01
+   .49772094E+01   .49363636E+01   .48961381E+01   .48565426E+01   .48175852E+01
+   .47792724E+01   .47416086E+01   .47045968E+01   .46682379E+01   .46325312E+01
+   .45974740E+01   .45630619E+01   .45292890E+01   .44961472E+01   .44636272E+01
+   .44317178E+01   .44004064E+01   .43696791E+01   .43395203E+01   .43099135E+01
+   .42808409E+01   .42522837E+01   .42242221E+01   .41966358E+01   .41695035E+01
+   .41428036E+01   .41165139E+01   .40906120E+01   .40650754E+01   .40398813E+01
+   .40150074E+01   .39904311E+01   .39661304E+01   .39420838E+01   .39182701E+01
+   .38946688E+01   .38712603E+01   .38480256E+01   .38249469E+01   .38020070E+01
+   .37791903E+01   .37564819E+01   .37338682E+01   .37113370E+01   .36888772E+01
+   .36664791E+01   .36441342E+01   .36218354E+01   .35995770E+01   .35773544E+01
+   .35551645E+01   .35330055E+01   .35108766E+01   .34887786E+01   .34667133E+01
+   .34446836E+01   .34226934E+01   .34007480E+01   .33788531E+01   .33570159E+01
+   .33352438E+01   .33135454E+01   .32919295E+01   .32704059E+01   .32489846E+01
+   .32276759E+01   .32064904E+01   .31854392E+01   .31645331E+01   .31437832E+01
+   .31232003E+01   .31027952E+01   .30825785E+01   .30625603E+01   .30427507E+01
+   .30231588E+01   .30037937E+01   .29846635E+01   .29657759E+01   .29471379E+01
+   .29287556E+01   .29106344E+01   .28927789E+01   .28751927E+01   .28578787E+01
+   .28408388E+01   .28240740E+01   .28075845E+01   .27913696E+01   .27754275E+01
+   .27597556E+01   .27443507E+01   .27292085E+01   .27143239E+01   .26996911E+01
+   .26853036E+01   .26711541E+01   .26572346E+01   .26435368E+01   .26300515E+01
+   .26167691E+01   .26036798E+01   .25907732E+01   .25780386E+01   .25654652E+01
+   .25530420E+01   .25407578E+01   .25286014E+01   .25165617E+01   .25046276E+01
+   .24927883E+01   .24810329E+01   .24693511E+01   .24577327E+01   .24461680E+01
+   .24346476E+01   .24231626E+01   .24117048E+01   .24002662E+01   .23888398E+01
+   .23774188E+01   .23659975E+01   .23545705E+01   .23431334E+01   .23316822E+01
+   .23202139E+01   .23087260E+01   .22972170E+01   .22856858E+01   .22741322E+01
+   .22625567E+01   .22509605E+01   .22393452E+01   .22277134E+01   .22160680E+01
+   .22044127E+01   .21927517E+01   .21810896E+01   .21694316E+01   .21577833E+01
+   .21461506E+01   .21345398E+01   .21229576E+01   .21114107E+01   .20999062E+01
+   .20884513E+01   .20770532E+01   .20657191E+01   .20544564E+01   .20432723E+01
+   .20321739E+01   .20211681E+01   .20102616E+01   .19994611E+01   .19887726E+01
+   .19782022E+01   .19677553E+01   .19574372E+01   .19472525E+01   .19372057E+01
+   .19273003E+01   .19175399E+01   .19079271E+01   .18984641E+01   .18891528E+01
+   .18799941E+01   .18709887E+01   .18621365E+01   .18534371E+01   .18448892E+01
+   .18364913E+01   .18282411E+01   .18201360E+01   .18121727E+01   .18043475E+01
+   .17966564E+01   .17890948E+01   .17816576E+01   .17743396E+01   .17671350E+01
+   .17600380E+01   .17530421E+01   .17461410E+01   .17393278E+01   .17325959E+01
+   .17259382E+01   .17193477E+01   .17128173E+01   .17063400E+01   .16999088E+01
+   .16935168E+01   .16871572E+01   .16808233E+01   .16745087E+01   .16682073E+01
+   .16619130E+01   .16556203E+01   .16493237E+01   .16430183E+01   .16366995E+01
+   .16303630E+01   .16240050E+01   .16176222E+01   .16112116E+01   .16047708E+01
+   .15982977E+01   .15917908E+01   .15852491E+01   .15786721E+01   .15720595E+01
+   .15654118E+01   .15587297E+01   .15520146E+01   .15452682E+01   .15384925E+01
+   .15316900E+01   .15248637E+01   .15180168E+01   .15111529E+01   .15042758E+01
+   .14973898E+01   .14904993E+01   .14836088E+01   .14767233E+01   .14698477E+01
+   .14629873E+01   .14561471E+01   .14493324E+01   .14425485E+01   .14358008E+01
+   .14290944E+01   .14224344E+01   .14158259E+01   .14092738E+01   .14027828E+01
+   .13963575E+01   .13900021E+01   .13837207E+01   .13775171E+01   .13713948E+01
+   .13653568E+01   .13594062E+01   .13535453E+01   .13477763E+01   .13421009E+01
+   .13365204E+01   .13310358E+01   .13256477E+01   .13203562E+01   .13151610E+01
+   .13100615E+01   .13050567E+01   .13001452E+01   .12953251E+01   .12905944E+01
+   .12859505E+01   .12813907E+01   .12769117E+01   .12725102E+01   .12681826E+01
+   .12639247E+01   .12597326E+01   .12556018E+01   .12515278E+01   .12475059E+01
+   .12435313E+01   .12395991E+01   .12357043E+01   .12318421E+01   .12280073E+01
+   .12241952E+01   .12204007E+01   .12166192E+01   .12128459E+01   .12090763E+01
+   .12053060E+01   .12015308E+01   .11977468E+01   .11939502E+01   .11901375E+01
+   .11863056E+01   .11824514E+01   .11785724E+01   .11746662E+01   .11707309E+01
+   .11667647E+01   .11627665E+01   .11587352E+01   .11546702E+01   .11505714E+01
+   .11464387E+01   .11422727E+01   .11380740E+01   .11338439E+01   .11295837E+01
+   .11252952E+01   .11209803E+01   .11166414E+01   .11122810E+01   .11079018E+01
+   .11035070E+01   .10990997E+01   .10946834E+01   .10902615E+01   .10858378E+01
+   .10814160E+01   .10770001E+01   .10725940E+01   .10682016E+01   .10638269E+01
+   .10594739E+01   .10551465E+01   .10508484E+01   .10465835E+01   .10423554E+01
+   .10381674E+01   .10340230E+01   .10299253E+01   .10258772E+01   .10218815E+01
+   .10179405E+01   .10140567E+01   .10102319E+01   .10064680E+01   .10027662E+01
+   .99912787E+00   .99555373E+00   .99204436E+00   .98860003E+00   .98522067E+00
+   .98190593E+00   .97865518E+00   .97546747E+00   .97234160E+00   .96927608E+00
+   .96626916E+00   .96331887E+00   .96042296E+00   .95757901E+00   .95478436E+00
+   .95203618E+00   .94933147E+00   .94666708E+00   .94403974E+00   .94144604E+00
+   .93888252E+00   .93634564E+00   .93383180E+00   .93133740E+00   .92885885E+00
+   .92639256E+00   .92393501E+00   .92148274E+00   .91903237E+00   .91658065E+00
+   .91412445E+00   .91166076E+00   .90918677E+00   .90669982E+00   .90419745E+00
+   .90167740E+00   .89913764E+00   .89657634E+00   .89399192E+00   .89138304E+00
+   .88874862E+00   .88608782E+00   .88340007E+00   .88068505E+00   .87794270E+00
+   .87517321E+00   .87237705E+00   .86955489E+00   .86670768E+00   .86383657E+00
+   .86094293E+00   .85802837E+00   .85509465E+00   .85214374E+00   .84917777E+00
+   .84619902E+00   .84320990E+00   .84021295E+00   .83721082E+00   .83420623E+00
+   .83120198E+00   .82820090E+00   .82520588E+00   .82221980E+00   .81924553E+00
+   .81628591E+00   .81334376E+00   .81042179E+00   .80752267E+00   .80464895E+00
+   .80180306E+00   .79898732E+00   .79620390E+00   .79345481E+00   .79074190E+00
+   .78806685E+00   .78543114E+00   .78283607E+00   .78028274E+00   .77777205E+00
+   .77530466E+00   .77288106E+00   .77050149E+00   .76816600E+00   .76587440E+00
+   .76362630E+00   .76142111E+00   .75925802E+00   .75713605E+00   .75505401E+00
+   .75301054E+00   .75100412E+00   .74903306E+00   .74709553E+00   .74518959E+00
+   .74331315E+00   .74146403E+00   .73963996E+00   .73783859E+00   .73605751E+00
+   .73429426E+00   .73254634E+00   .73081125E+00   .72908649E+00   .72736956E+00
+   .72565799E+00   .72394939E+00   .72224138E+00   .72053171E+00   .71881819E+00
+   .71709872E+00   .71537135E+00   .71363422E+00   .71188562E+00   .71012399E+00
+   .70834792E+00   .70655612E+00   .70474752E+00   .70292118E+00   .70107634E+00
+   .69921243E+00   .69732903E+00   .69542593E+00   .69350307E+00   .69156058E+00
+   .68959877E+00   .68761812E+00   .68561927E+00   .68360301E+00   .68157030E+00
+   .67952223E+00   .67746004E+00   .67538509E+00   .67329885E+00   .67120288E+00
+   .66909887E+00   .66698855E+00   .66487376E+00   .66275637E+00   .66063829E+00
+   .65852150E+00   .65640796E+00   .65429967E+00   .65219860E+00   .65010671E+00
+   .64802595E+00   .64595820E+00   .64390531E+00   .64186903E+00   .63985105E+00
+   .63785300E+00   .63587636E+00   .63392255E+00   .63199284E+00   .63008840E+00
+   .62821028E+00   .62635939E+00   .62453649E+00   .62274222E+00   .62097707E+00
+   .61924139E+00   .61753539E+00   .61585912E+00   .61421249E+00   .61259527E+00
+   .61100709E+00   .60944743E+00   .60791564E+00   .60641095E+00   .60493245E+00
+   .60347913E+00   .60204986E+00   .60064342E+00   .59925849E+00   .59789367E+00
+   .59654748E+00   .59521839E+00   .59390481E+00   .59260510E+00   .59131760E+00
+   .59004062E+00   .58877245E+00   .58751139E+00   .58625572E+00   .58500378E+00
+   .58375390E+00   .58250447E+00   .58125392E+00   .58000073E+00   .57874346E+00
+   .57748074E+00   .57621129E+00   .57493390E+00   .57364748E+00   .57235102E+00
+   .57104365E+00   .56972457E+00   .56839313E+00   .56704877E+00   .56569105E+00
+   .56431968E+00   .56293446E+00   .56153532E+00   .56012231E+00   .55869560E+00
+   .55725549E+00   .55580237E+00   .55433677E+00   .55285930E+00   .55137069E+00
+   .54987176E+00   .54836342E+00   .54684666E+00   .54532257E+00   .54379226E+00
+   .54225695E+00   .54071788E+00   .53917634E+00   .53763366E+00   .53609119E+00
+   .53455030E+00   .53301238E+00   .53147881E+00   .52995095E+00   .52843017E+00
+   .52691781E+00   .52541516E+00   .52392348E+00   .52244400E+00   .52097785E+00
+   .51952614E+00   .51808988E+00   .51667002E+00   .51526741E+00   .51388284E+00
+   .51251698E+00   .51117042E+00   .50984366E+00   .50853708E+00   .50725098E+00
+   .50598555E+00   .50474087E+00   .50351694E+00   .50231363E+00   .50113072E+00
+   .49996791E+00   .49882479E+00   .49770084E+00   .49659546E+00   .49550799E+00
+   .49443764E+00   .49338359E+00   .49234493E+00   .49132067E+00   .49030979E+00
+   .48931122E+00   .48832382E+00   .48734645E+00   .48637792E+00   .48541703E+00
+   .48446256E+00   .48351328E+00   .48256798E+00   .48162544E+00   .48068447E+00
+   .47974389E+00   .47880256E+00   .47785937E+00   .47691326E+00   .47596322E+00
+   .47500828E+00   .47404757E+00   .47308025E+00   .47210556E+00   .47112284E+00
+   .47013149E+00   .46913099E+00   .46812091E+00   .46710093E+00   .46607077E+00
+   .46503029E+00   .46397940E+00   .46291812E+00   .46184656E+00   .46076489E+00
+   .45967339E+00   .45857241E+00   .45746240E+00   .45634387E+00   .45521741E+00
+   .45408366E+00   .45294336E+00   .45179729E+00   .45064627E+00   .44949120E+00
+   .44833300E+00   .44717263E+00   .44601107E+00   .44484933E+00   .44368845E+00
+   .44252944E+00   .44137335E+00   .44022120E+00   .43907402E+00   .43793280E+00
+   .43679852E+00   .43567213E+00   .43455455E+00   .43344666E+00   .43234927E+00
+   .43126317E+00   .43018907E+00   .42912764E+00   .42807946E+00   .42704506E+00
+   .42602488E+00   .42501931E+00   .42402864E+00   .42305310E+00   .42209282E+00
+   .42114788E+00   .42021827E+00   .41930388E+00   .41840455E+00   .41752005E+00
+   .41665006E+00   .41579419E+00   .41495198E+00   .41412292E+00   .41330642E+00
+   .41250185E+00   .41170850E+00   .41092563E+00   .41015246E+00   .40938816E+00
+   .40863186E+00   .40788268E+00   .40713972E+00   .40640204E+00   .40566872E+00
+   .40493882E+00   .40421141E+00   .40348557E+00   .40276039E+00   .40203497E+00
+   .40130847E+00   .40058004E+00   .39984888E+00   .39911423E+00   .39837539E+00
+   .39763167E+00   .39688247E+00   .39612723E+00   .39536546E+00   .39459672E+00
+   .39382064E+00   .39303693E+00   .39224535E+00   .39144574E+00   .39063801E+00
+   .38982214E+00   .38899819E+00   .38816625E+00   .38732653E+00   .38647926E+00
+   .38562476E+00   .38476339E+00   .38389559E+00   .38302184E+00   .38214268E+00
+   .38125868E+00   .38037048E+00   .37947875E+00   .37858418E+00   .37768750E+00
+   .37678948E+00   .37589089E+00   .37499252E+00   .37409517E+00   .37319964E+00
+   .37230673E+00   .37141723E+00   .37053192E+00   .36965156E+00   .36877689E+00
+   .36790861E+00   .36704741E+00   .36619394E+00   .36534880E+00   .36451255E+00
+   .36368572E+00   .36286877E+00   .36206212E+00   .36126613E+00   .36048111E+00
+   .35970730E+00   .35894489E+00   .35819399E+00   .35745468E+00   .35672695E+00
+   .35601073E+00   .35530591E+00   .35461231E+00   .35392969E+00   .35325776E+00
+   .35259616E+00   .35194452E+00   .35130238E+00   .35066926E+00   .35004462E+00
+ gradient corrections used for XC
+ 5
+ core charge-density (partial)
+   .71600890E+00   .71575195E+00   .71498162E+00   .71369952E+00   .71190828E+00
+   .70961159E+00   .70681419E+00   .70352181E+00   .69974119E+00   .69548005E+00
+   .69074704E+00   .68555174E+00   .67990461E+00   .67381698E+00   .66730095E+00
+   .66036944E+00   .65303607E+00   .64531515E+00   .63722163E+00   .62877107E+00
+   .61997955E+00   .61086363E+00   .60144034E+00   .59172709E+00   .58174161E+00
+   .57150192E+00   .56102627E+00   .55033309E+00   .53944094E+00   .52836842E+00
+   .51713420E+00   .50575688E+00   .49425501E+00   .48264700E+00   .47095109E+00
+   .45918531E+00   .44736744E+00   .43551494E+00   .42364496E+00   .41177426E+00
+   .39991919E+00   .38809566E+00   .37631912E+00   .36460451E+00   .35296627E+00
+   .34141826E+00   .32997380E+00   .31864562E+00   .30744584E+00   .29638599E+00
+   .28547694E+00   .27472897E+00   .26415169E+00   .25375408E+00   .24354449E+00
+   .23353058E+00   .22371943E+00   .21411743E+00   .20473036E+00   .19556337E+00
+   .18662101E+00   .17790719E+00   .16942527E+00   .16117799E+00   .15316755E+00
+   .14539560E+00   .13786324E+00   .13057108E+00   .12351922E+00   .11670727E+00
+   .11013442E+00   .10379938E+00   .97700483E-01   .91835646E-01   .86202420E-01
+   .80798003E-01   .75619266E-01   .70662774E-01   .65924802E-01   .61401368E-01
+   .57088241E-01   .52980974E-01   .49074917E-01   .45365243E-01   .41846963E-01
+   .38514949E-01   .35363955E-01   .32388628E-01   .29583536E-01   .26943177E-01
+   .24462002E-01   .22134426E-01   .19954849E-01   .17917664E-01   .16017277E-01
+   .14248118E-01   .12604654E-01   .11081400E-01   .96729297E-02   .83738895E-02
+   .71790041E-02   .60830875E-02   .50810509E-02   .41679104E-02   .33387935E-02
+   .25889459E-02   .19137364E-02   .13086623E-02   .76935350E-03   .29157596E-03
+  -.12876487E-03  -.49562176E-03  -.81280368E-03  -.10839744E-02  -.13126514E-02
+  -.15022057E-02  -.16558615E-02  -.17766968E-02  -.18676442E-02  -.19314922E-02
+  -.19708864E-02  -.19883317E-02  -.19861946E-02  -.19667052E-02  -.19319605E-02
+  -.18839269E-02  -.18244439E-02  -.17552267E-02  -.16778707E-02  -.15938546E-02
+  -.15045443E-02  -.14111971E-02  -.13149654E-02  -.12169010E-02  -.11179595E-02
+  -.10190040E-02  -.92080970E-03  -.82406807E-03  -.72939103E-03  -.63731519E-03
+  -.54830603E-03  -.46276206E-03  -.38101890E-03  -.30335326E-03  -.22998693E-03
+  -.16109063E-03  -.96787770E-04  -.37158102E-04   .17758681E-04   .67959515E-04
+   .11347462E-03   .15436429E-03   .19071581E-03   .22264045E-03   .25027070E-03
+   .27375751E-03   .29326775E-03   .30898175E-03   .32109102E-03   .32979610E-03
+   .33530447E-03   .33782868E-03   .33758460E-03   .33478973E-03   .32966171E-03
+   .32241692E-03   .31326919E-03   .30242868E-03   .29010079E-03   .27648527E-03
+   .26177536E-03   .24615710E-03   .22980866E-03   .21289986E-03   .19559167E-03
+   .17803591E-03   .16037494E-03   .14274148E-03   .12525844E-03   .10803891E-03
+   .91186141E-04   .74793579E-04   .58945012E-04   .43714711E-04   .29167638E-04
+   .15359692E-04   .23379917E-05  -.98588160E-05  -.21200210E-04  -.31663433E-04
+  -.41233102E-04  -.49900807E-04  -.57664694E-04  -.64529036E-04  -.70503799E-04
+  -.75604201E-04  -.79850271E-04  -.83266407E-04  -.85880939E-04  -.87725696E-04
+  -.88835581E-04  -.89248153E-04  -.89003222E-04  -.88142458E-04  -.86709011E-04
+  -.84747147E-04  -.82301900E-04  -.79418740E-04  -.76143266E-04  -.72520905E-04
+  -.68596640E-04  -.64414757E-04  -.60018603E-04  -.55450376E-04  -.50750925E-04
+  -.45959576E-04  -.41113972E-04  -.36249939E-04  -.31401366E-04  -.26600103E-04
+  -.21875883E-04  -.17256254E-04  -.12766533E-04  -.84297743E-05  -.42667509E-05
+  -.29595558E-06   .34663882E-05   .70063016E-05   .10312013E-04   .13373911E-04
+   .16184483E-04   .18738252E-04   .21031696E-04   .23063165E-04   .24832794E-04
+   .26342402E-04   .27595392E-04   .28596649E-04   .29352425E-04   .29870234E-04
+   .30158735E-04   .30227622E-04   .30087505E-04   .29749801E-04   .29226619E-04
+   .28530649E-04   .27675054E-04   .26673366E-04   .25539377E-04   .24287048E-04
+   .22930405E-04   .21483458E-04   .19960105E-04   .18374058E-04   .16738762E-04
+   .15067329E-04   .13372469E-04   .11666431E-04   .99609515E-05   .82672027E-05
+   .65957528E-05   .49565277E-05   .33587805E-05   .18110654E-05   .32121769E-06
+  -.11036610E-05  -.24572128E-05  -.37338285E-05  -.49286472E-05  -.60375524E-05
+  -.70571632E-05  -.79848212E-05  -.88185745E-05  -.95571574E-05  -.10199967E-04
+  -.10747038E-04  -.11199013E-04  -.11557110E-04  -.11823091E-04  -.11999229E-04
+  -.12088265E-04  -.12093375E-04  -.12018133E-04  -.11866465E-04  -.11642615E-04
+  -.11351102E-04  -.10996681E-04  -.10584305E-04  -.10119081E-04  -.96062361E-05
+  -.90510796E-05  -.84589646E-05  -.78352541E-05  -.71852876E-05  -.65143485E-05
+  -.58276337E-05  -.51302255E-05  -.44270644E-05  -.37229245E-05  -.30223909E-05
+  -.23298390E-05  -.16494159E-05  -.98502427E-06  -.34030788E-06   .28136034E-06
+   .87688824E-06   .14434723E-05   .19786035E-05   .24800708E-05   .29459635E-05
+   .33746703E-05   .37648783E-05   .41155688E-05   .44260123E-05   .46957615E-05
+   .49246432E-05   .51127486E-05   .52604227E-05   .53682520E-05   .54370519E-05
+   .54678526E-05   .54618849E-05   .54205643E-05   .53454761E-05   .52383582E-05
+   .51010854E-05   .49356522E-05   .47441561E-05   .45287807E-05   .42917792E-05
+   .40354578E-05   .37621594E-05   .34742476E-05   .31740918E-05   .28640521E-05
+   .25464648E-05   .22236291E-05   .18977946E-05   .15711482E-05   .12458040E-05
+   .92379193E-06   .60704886E-06   .29740962E-06  -.34005756E-08  -.29377288E-06
+  -.57222067E-06  -.83738436E-06  -.10880354E-05  -.13230790E-05  -.15415568E-05
+  -.17426472E-05  -.19256664E-05  -.20900673E-05  -.22354387E-05  -.23615026E-05
+  -.24681116E-05  -.25552453E-05  -.26230060E-05  -.26716143E-05  -.27014030E-05
+  -.27128117E-05  -.27063805E-05  -.26827430E-05  -.26426197E-05  -.25868101E-05
+  -.25161853E-05  -.24316807E-05  -.23342874E-05  -.22250445E-05  -.21050314E-05
+  -.19753593E-05  -.18371638E-05  -.16915966E-05  -.15398183E-05  -.13829907E-05
+  -.12222695E-05  -.10587979E-05  -.89369922E-06  -.72807107E-06  -.56297934E-06
+  -.39945255E-06  -.23847680E-06  -.80990924E-07   .72117690E-07   .22001701E-06
+   .36193371E-06   .49715612E-06   .62503663E-06   .74499373E-06   .85651348E-06
+   .95915061E-06   .10525291E-05   .11363424E-05   .12103531E-05   .12743922E-05
+   .13283584E-05   .13722162E-05   .14059942E-05   .14297834E-05   .14437339E-05
+   .14480532E-05   .14430022E-05   .14288928E-05   .14060839E-05   .13749779E-05
+   .13360169E-05   .12896792E-05   .12364746E-05   .11769406E-05   .11116385E-05
+   .10411490E-05   .96606792E-06   .88700244E-06   .80456672E-06   .71937804E-06
+   .63205286E-06   .54320310E-06   .45343242E-06   .36333283E-06   .27348127E-06
+   .18443661E-06   .96736622E-07   .10895329E-07  -.72599497E-07  -.15328859E-06
+  -.23074322E-06  -.30456694E-06  -.37439713E-06  -.43990627E-06  -.50080298E-06
+  -.55683278E-06  -.60777861E-06  -.65346116E-06  -.69373887E-06  -.72850777E-06
+  -.75770109E-06  -.78128862E-06  -.79927588E-06  -.81170308E-06  -.81864398E-06
+  -.82020444E-06  -.81652092E-06  -.80775881E-06  -.79411058E-06  -.77579390E-06
+  -.75304959E-06  -.72613952E-06  -.69534441E-06  -.66096159E-06  -.62330276E-06
+  -.58269161E-06  -.53946159E-06  -.49395352E-06  -.44651333E-06  -.39748980E-06
+  -.34723230E-06  -.29608866E-06  -.24440305E-06  -.19251395E-06  -.14075221E-06
+  -.89439250E-07  -.38885286E-07   .10612272E-07   .58770318E-07   .10532142E-06
+   .15001507E-06   .19261878E-06   .23291902E-06   .27072212E-06   .30585488E-06
+   .33816511E-06   .36752209E-06   .39381678E-06   .41696193E-06   .43689209E-06
+   .45356344E-06   .46695351E-06   .47706082E-06   .48390428E-06   .48752263E-06
+   .48797365E-06   .48533339E-06   .47969516E-06   .47116860E-06   .45987856E-06
+   .44596394E-06   .42957652E-06   .41087968E-06   .39004712E-06   .36726154E-06
+   .34271325E-06   .31659889E-06   .28911997E-06   .26048159E-06   .23089104E-06
+   .20055650E-06   .16968570E-06   .13848469E-06   .10715659E-06   .75900416E-07
+   .44909940E-07   .14372645E-07  -.15531292E-07  -.44629931E-07  -.72760435E-07
+  -.99769850E-07  -.12551582E-06  -.14986719E-06  -.17270458E-06  -.19392082E-06
+  -.21342133E-06  -.23112439E-06  -.24696135E-06  -.26087678E-06  -.27282843E-06
+  -.28278724E-06  -.29073718E-06  -.29667507E-06  -.30061029E-06  -.30256440E-06
+  -.30257078E-06  -.30067411E-06  -.29692985E-06  -.29140365E-06  -.28417071E-06
+  -.27531508E-06  -.26492897E-06  -.25311197E-06  -.23997030E-06  -.22561597E-06
+  -.21016597E-06  -.19374143E-06  -.17646682E-06  -.15846904E-06  -.13987665E-06
+  -.12081900E-06  -.10142543E-06  -.81824461E-07  -.62143040E-07  -.42505786E-07
+  -.23034269E-07  -.38463369E-08   .14944533E-07   .33229835E-07   .50906589E-07
+   .67877858E-07   .84053211E-07   .99349132E-07   .11368939E-06   .12700534E-06
+   .13923619E-06   .15032919E-06   .16023980E-06   .16893177E-06   .17637719E-06
+   .18255647E-06   .18745831E-06   .19107955E-06   .19342504E-06   .19450745E-06
+   .19434698E-06   .19297112E-06   .19041429E-06   .18671751E-06   .18192797E-06
+   .17609864E-06   .16928783E-06   .16155868E-06   .15297866E-06   .14361915E-06
+   .13355480E-06   .12286309E-06   .11162376E-06   .99918262E-07   .87829244E-07
+   .75440003E-07   .62833960E-07   .50094149E-07   .37302705E-07   .24540386E-07
+   .11886098E-07  -.58355004E-09  -.12794672E-07  -.24676503E-07  -.36161768E-07
+  -.47187031E-07  -.57693001E-07  -.67624813E-07  -.76932280E-07  -.85570102E-07
+  -.93498045E-07  -.10068109E-06  -.10708954E-06  -.11269909E-06  -.11749089E-06
+  -.12145151E-06  -.12457295E-06  -.12685258E-06  -.12829301E-06  -.12890200E-06
+  -.12869233E-06  -.12768157E-06  -.12589189E-06  -.12334987E-06  -.12008621E-06
+  -.11613547E-06  -.11153578E-06  -.10632853E-06  -.10055806E-06  -.94271339E-07
+  -.87517587E-07  -.80347964E-07  -.72815198E-07  -.64973237E-07  -.56876891E-07
+  -.48581476E-07  -.40142463E-07  -.31615139E-07  -.23054264E-07  -.14513744E-07
+  -.60463209E-08   .22967348E-08   .10465910E-07   .18413718E-07   .26094957E-07
+   .33466938E-07   .40489705E-07   .47126227E-07   .53342569E-07   .59108042E-07
+   .64395333E-07   .69180605E-07   .73443582E-07   .77167602E-07   .80339654E-07
+   .82950389E-07   .84994108E-07   .86468728E-07   .87375727E-07   .87720069E-07
+   .87510106E-07   .86757464E-07   .85476914E-07   .83686214E-07   .81405953E-07
+   .78659366E-07   .75472141E-07   .71872221E-07   .67889585E-07   .63556027E-07
+   .58904927E-07   .53971017E-07   .48790141E-07   .43399014E-07   .37834981E-07
+   .32135773E-07   .26339270E-07   .20483264E-07   .14605227E-07   .87420886E-08
+   .29300151E-08  -.27957973E-08  -.84013221E-08  -.13853891E-07  -.19122372E-07
+  -.24177330E-07  -.28991182E-07  -.33538329E-07  -.37795282E-07  -.41740768E-07
+  -.45355819E-07  -.48623851E-07  -.51530720E-07  -.54064770E-07  -.56216856E-07
+  -.57980360E-07  -.59351184E-07  -.60327732E-07  -.60910873E-07  -.61103898E-07
+  -.60912449E-07  -.60344452E-07  -.59410019E-07  -.58121354E-07  -.56492638E-07
+  -.54539907E-07  -.52280924E-07  -.49735035E-07  -.46923024E-07  -.43866963E-07
+  -.40590049E-07  -.37116443E-07  -.33471107E-07  -.29679632E-07  -.25768076E-07
+  -.21762786E-07  -.17690241E-07  -.13576880E-07  -.94489393E-08  -.53323003E-08
+  -.12523303E-08   .27662621E-08   .66995690E-08   .10524616E-07   .14219490E-07
+   .17763451E-07   .21137047E-07   .24322208E-07   .27302332E-07   .30062367E-07
+   .32588875E-07   .34870089E-07   .36895954E-07   .38658165E-07   .40150185E-07
+   .41367259E-07   .42306409E-07   .42966426E-07   .43347850E-07   .43452932E-07
+   .43285594E-07   .42851380E-07   .42157390E-07   .41212215E-07   .40025857E-07
+   .38609643E-07   .36976136E-07   .35139038E-07   .33113082E-07   .30913928E-07
+   .28558051E-07   .26062627E-07   .23445413E-07   .20724630E-07   .17918843E-07
+   .15046841E-07   .12127516E-07   .91797487E-08   .62222885E-08   .32736421E-08
+   .35196302E-09  -.25250548E-08  -.53402782E-08  -.80772316E-08  -.10720188E-07
+  -.13254253E-07  -.15665445E-07  -.17940764E-07  -.20068260E-07  -.22037085E-07
+  -.23837547E-07  -.25461147E-07  -.26900615E-07  -.28149935E-07  -.29204362E-07
+  -.30060431E-07  -.30715957E-07  -.31170031E-07  -.31423002E-07  -.31476457E-07
+  -.31333194E-07  -.30997179E-07  -.30473510E-07  -.29768366E-07  -.28888950E-07
+  -.27843430E-07  -.26640874E-07  -.25291179E-07  -.23804999E-07  -.22193665E-07
+  -.20469106E-07  -.18643767E-07  -.16730524E-07  -.14742596E-07  -.12693461E-07
+  -.10596768E-07  -.84662488E-08  -.63156341E-08  -.41585681E-08  -.20085260E-08
+   .12126692E-09   .22179125E-08   .42689143E-08   .62622486E-08   .81864311E-08
+   .10030580E-07   .11784472E-07   .13438598E-07   .14984210E-07   .16413362E-07
+   .17718949E-07   .18894734E-07   .19935381E-07   .20836466E-07   .21594494E-07
+   .22206911E-07   .22672095E-07   .22989364E-07   .23158956E-07   .23182022E-07
+   .23060599E-07   .22797587E-07   .22396719E-07   .21862524E-07   .21200288E-07
+   .20416010E-07   .19516355E-07   .18508601E-07   .17400589E-07   .16200662E-07
+   .14917610E-07   .13560605E-07   .12139144E-07   .10662983E-07   .91420700E-08
+   .75864872E-08   .60063826E-08   .44119074E-08   .28131540E-08   .12200940E-08
+  -.35748113E-09  -.19100177E-08  -.34282557E-08  -.49032808E-08  -.63265753E-08
+  -.76900639E-08  -.89861577E-08  -.10207794E-07  -.11348471E-07  -.12402282E-07
+  -.13363941E-07  -.14228808E-07  -.14992908E-07  -.15652945E-07  -.16206313E-07
+  -.16651102E-07  -.16986103E-07  -.17210800E-07  -.17325367E-07  -.17330655E-07
+  -.17228180E-07  -.17020102E-07  -.16709202E-07  -.16298858E-07  -.15793016E-07
+  -.15196154E-07  -.14513251E-07  -.13749747E-07  -.12911504E-07  -.12004764E-07
+  -.11036104E-07  -.10012391E-07  -.89407384E-08  -.78284540E-08  -.66829961E-08
+  -.55119235E-08  -.43228484E-08  -.31233881E-08  -.19211184E-08  -.72352741E-09
+   .46202952E-09   .16283732E-08   .27685423E-08   .38758337E-08   .49438394E-08
+   .59664828E-08   .69380511E-08   .78532257E-08   .87071095E-08   .94952512E-08
+   .10213667E-07   .10858857E-07   .11427825E-07   .11918083E-07   .12327665E-07
+   .12655131E-07   .12899566E-07   .13060582E-07   .13138312E-07   .13133400E-07
+   .13046995E-07   .12880731E-07   .12636715E-07   .12317506E-07   .11926092E-07
+   .11465868E-07   .10940609E-07   .10354440E-07   .97118083E-08   .90174489E-08
+   .82763544E-08   .74937389E-08   .66750035E-08   .58257008E-08   .49514977E-08
+   .40581401E-08   .31514157E-08   .22371178E-08   .13210099E-08   .40879021E-09
+  -.49394241E-09  -.13817218E-08  -.22492462E-08  -.30914091E-08  -.39033278E-08
+  -.46803710E-08  -.54181833E-08  -.61127094E-08  -.67602142E-08  -.73573023E-08
+  -.79009342E-08  -.83884405E-08  -.88175333E-08  -.91863156E-08  -.94932876E-08
+  -.97373511E-08  -.99178109E-08  -.10034374E-07  -.10087145E-07  -.10076622E-07
+  -.10003689E-07  -.98696018E-08  -.96759797E-08  -.94247882E-08  -.91183232E-08
+  -.87591928E-08  -.83502969E-08  -.78948055E-08  -.73961362E-08  -.68579292E-08
+  -.62840228E-08  -.56784265E-08  -.50452945E-08  -.43888983E-08  -.37135986E-08
+  -.30238172E-08  -.23240096E-08  -.16186362E-08  -.91213563E-09  -.20889690E-09
+   .48676651E-09   .11706425E-08   .18386451E-08   .24868379E-08   .31114564E-08
+   .37089293E-08   .42758979E-08   .48092342E-08   .53060572E-08   .57637476E-08
+   .61799608E-08   .65526378E-08   .68800140E-08   .71606273E-08   .73933222E-08
+   .75772540E-08   .77118897E-08   .77970075E-08   .78326943E-08   .78193414E-08
+   .77576381E-08   .76485641E-08   .74933794E-08   .72936137E-08   .70510530E-08
+   .67677257E-08   .64458873E-08   .60880032E-08   .56967316E-08   .52749040E-08
+   .48255061E-08   .43516576E-08   .38565907E-08   .33436296E-08   .28161681E-08
+   .22776484E-08   .17315391E-08   .11813134E-08   .63042781E-09   .82300788E-10
+  -.45970763E-09  -.99231595E-09  -.15123405E-08  -.20167139E-08  -.25025024E-08
+  -.29669226E-08  -.34073568E-08  -.38213667E-08  -.42067069E-08  -.45613359E-08
+  -.48834267E-08  -.51713751E-08  -.54238070E-08  -.56395844E-08  -.58178091E-08
+  -.59578260E-08  -.60592235E-08  -.61218338E-08  -.61457305E-08  -.61312258E-08
+ atomic pseudo charge-density
+   .14000000E+02   .13988361E+02   .13953614E+02   .13896261E+02   .13817117E+02
+   .13717270E+02   .13598041E+02   .13460933E+02   .13307570E+02   .13139653E+02
+   .12958900E+02   .12767006E+02   .12565606E+02   .12356241E+02   .12140339E+02
+   .11919203E+02   .11693998E+02   .11465757E+02   .11235382E+02   .11003649E+02
+   .10771221E+02   .10538658E+02   .10306428E+02   .10074919E+02   .98444513E+01
+   .96152882E+01   .93876445E+01   .91616958E+01   .89375859E+01   .87154336E+01
+   .84953376E+01   .82773813E+01   .80616367E+01   .78481672E+01   .76370299E+01
+   .74282778E+01   .72219608E+01   .70181271E+01   .68168237E+01   .66180971E+01
+   .64219934E+01   .62285587E+01   .60378389E+01   .58498798E+01   .56647267E+01
+   .54824246E+01   .53030177E+01   .51265492E+01   .49530612E+01   .47825943E+01
+   .46151873E+01   .44508771E+01   .42896986E+01   .41316839E+01   .39768631E+01
+   .38252630E+01   .36769080E+01   .35318192E+01   .33900147E+01   .32515094E+01
+   .31163149E+01   .29844396E+01   .28558886E+01   .27306634E+01   .26087624E+01
+   .24901808E+01   .23749102E+01   .22629393E+01   .21542534E+01   .20488347E+01
+   .19466626E+01   .18477133E+01   .17519602E+01   .16593739E+01   .15699225E+01
+   .14835713E+01   .14002832E+01   .13200188E+01   .12427365E+01   .11683924E+01
+   .10969407E+01   .10283337E+01   .96252186E+00   .89945401E+00   .83907740E+00
+   .78133786E+00   .72617991E+00   .67354683E+00   .62338085E+00   .57562319E+00
+   .53021421E+00   .48709353E+00   .44620010E+00   .40747234E+00   .37084824E+00
+   .33626544E+00   .30366135E+00   .27297328E+00   .24413845E+00   .21709417E+00
+   .19177790E+00   .16812731E+00   .14608041E+00   .12557562E+00   .10655184E+00
+   .88948521E-01   .72705769E-01   .57764391E-01   .44065971E-01   .31552937E-01
+   .20168620E-01   .98573152E-02   .56433654E-03  -.77639311E-02  -.15179983E-01
+  -.21735148E-01  -.27479548E-01  -.32462057E-01  -.36730268E-01  -.40330456E-01
+  -.43307556E-01  -.45705130E-01  -.47565352E-01  -.48928982E-01  -.49835356E-01
+  -.50322369E-01  -.50426469E-01  -.50182648E-01  -.49624441E-01  -.48783924E-01
+  -.47691719E-01  -.46376996E-01  -.44867484E-01  -.43189483E-01  -.41367873E-01
+  -.39426137E-01  -.37386373E-01  -.35269317E-01  -.33094371E-01  -.30879619E-01
+  -.28641864E-01  -.26396649E-01  -.24158293E-01  -.21939921E-01  -.19753500E-01
+  -.17609873E-01  -.15518795E-01  -.13488972E-01  -.11528102E-01  -.96429104E-02
+  -.78391927E-02  -.61218563E-02  -.44949611E-02  -.29617621E-02  -.15247513E-02
+  -.18570028E-03   .10542972E-02   .21947831E-02   .32358928E-02   .41783132E-02
+   .50232416E-02   .57723446E-02   .64277181E-02   .69918475E-02   .74675694E-02
+   .78580335E-02   .81666659E-02   .83971337E-02   .85533097E-02   .86392396E-02
+   .86591096E-02   .86172153E-02   .85179326E-02   .83656895E-02   .81649389E-02
+   .79201339E-02   .76357040E-02   .73160323E-02   .69654355E-02   .65881438E-02
+   .61882841E-02   .57698628E-02   .53367520E-02   .48926756E-02   .44411979E-02
+   .39857132E-02   .35294370E-02   .30753983E-02   .26264337E-02   .21851824E-02
+   .17540827E-02   .13353697E-02   .93107419E-03   .54302230E-03   .17283683E-03
+  -.17806085E-03  -.50844785E-03  -.81729586E-03  -.11037665E-02  -.13672058E-02
+  -.16071383E-02  -.18232598E-02  -.20154305E-02  -.21836668E-02  -.23281332E-02
+  -.24491335E-02  -.25471016E-02  -.26225926E-02  -.26762732E-02  -.27089119E-02
+  -.27213693E-02  -.27145886E-02  -.26895857E-02  -.26474395E-02  -.25892824E-02
+  -.25162912E-02  -.24296772E-02  -.23306780E-02  -.22205484E-02  -.21005523E-02
+  -.19719543E-02  -.18360126E-02  -.16939713E-02  -.15470537E-02  -.13964559E-02
+  -.12433409E-02  -.10888331E-02  -.93401318E-03  -.77991360E-03  -.62751460E-03
+  -.47774060E-03  -.33145709E-03  -.18946801E-03  -.52513674E-04   .78730957E-04
+   .20365746E-03   .32172472E-03   .43245929E-03   .53545530E-03   .63037399E-03
+   .71694288E-03   .79495457E-03   .86426520E-03   .92479261E-03   .97651420E-03
+   .10194645E-02   .10537327E-02   .10794596E-02   .10968345E-02   .11060922E-02
+   .11075098E-02   .11014027E-02   .10881216E-02   .10680484E-02   .10415930E-02
+   .10091894E-02   .97129178E-03   .92837133E-03   .88091230E-03   .82940855E-03
+   .77436010E-03   .71626974E-03   .65563980E-03   .59296902E-03   .52874955E-03
+   .46346419E-03   .39758367E-03   .33156422E-03   .26584524E-03   .20084722E-03
+   .13696983E-03   .74590187E-04   .14061373E-04  -.44288876E-04  -.10015926E-03
+  -.15327584E-03  -.20339267E-03  -.25029237E-03  -.29378636E-03  -.33371503E-03
+  -.36994761E-03  -.40238200E-03  -.43094429E-03  -.45558824E-03  -.47629452E-03
+  -.49306989E-03  -.50594618E-03  -.51497919E-03  -.52024748E-03  -.52185105E-03
+  -.51990994E-03  -.51456275E-03  -.50596512E-03  -.49428812E-03  -.47971664E-03
+  -.46244771E-03  -.44268887E-03  -.42065643E-03  -.39657384E-03  -.37067003E-03
+  -.34317771E-03  -.31433184E-03  -.28436802E-03  -.25352098E-03  -.22202313E-03
+  -.19010316E-03  -.15798473E-03  -.12588520E-03  -.94014464E-04  -.62573903E-04
+  -.31755356E-04  -.17402396E-05   .27301258E-04   .55210886E-04   .81842937E-04
+   .10706476E-03   .13075716E-03   .15281474E-03   .17314609E-03   .19167392E-03
+   .20833511E-03   .22308059E-03   .23587530E-03   .24669784E-03   .25554027E-03
+   .26240766E-03   .26731767E-03   .27030003E-03   .27139596E-03   .27065757E-03
+   .26814714E-03   .26393644E-03   .25810596E-03   .25074412E-03   .24194647E-03
+   .23181486E-03   .22045657E-03   .20798350E-03   .19451130E-03   .18015850E-03
+   .16504567E-03   .14929463E-03   .13302759E-03   .11636637E-03   .99431681E-04
+   .82342314E-04   .65214506E-04   .48161249E-04   .31291674E-04   .14710473E-04
+  -.14826342E-05  -.17193387E-04  -.32333421E-04  -.46820657E-04  -.60579633E-04
+  -.73541796E-04  -.85645727E-04  -.96837331E-04  -.10706996E-03  -.11630450E-03
+  -.12450938E-03  -.13166060E-03  -.13774162E-03  -.14274324E-03  -.14666353E-03
+  -.14950752E-03  -.15128706E-03  -.15202051E-03  -.15173244E-03  -.15045331E-03
+  -.14821908E-03  -.14507087E-03  -.14105453E-03  -.13622022E-03  -.13062195E-03
+  -.12431717E-03  -.11736627E-03  -.10983215E-03  -.10177970E-03  -.93275403E-04
+  -.84386808E-04  -.75182100E-04  -.65729641E-04  -.56097536E-04  -.46353202E-04
+  -.36562964E-04  -.26791655E-04  -.17102252E-04  -.75555228E-05   .17903019E-05
+   .10879829E-04   .19660779E-04   .28084238E-04   .36104875E-04   .43681137E-04
+   .50775415E-04   .57354178E-04   .63388076E-04   .68852022E-04   .73725237E-04
+   .77991271E-04   .81637995E-04   .84657566E-04   .87046367E-04   .88804922E-04
+   .89937783E-04   .90453403E-04   .90363981E-04   .89685286E-04   .88436475E-04
+   .86639874E-04   .84320768E-04   .81507160E-04   .78229524E-04   .74520556E-04
+   .70414904E-04   .65948906E-04   .61160315E-04   .56088021E-04   .50771784E-04
+   .45251954E-04   .39569202E-04   .33764257E-04   .27877644E-04   .21949429E-04
+   .16018983E-04   .10124742E-04   .43039909E-05  -.14073486E-05  -.69749119E-05
+  -.12366073E-04  -.17550108E-04  -.22498349E-04  -.27184313E-04  -.31583820E-04
+  -.35675094E-04  -.39438840E-04  -.42858316E-04  -.45919369E-04  -.48610476E-04
+  -.50922748E-04  -.52849929E-04  -.54388373E-04  -.55537008E-04  -.56297287E-04
+  -.56673114E-04  -.56670770E-04  -.56298815E-04  -.55567984E-04  -.54491070E-04
+  -.53082793E-04  -.51359669E-04  -.49339859E-04  -.47043022E-04  -.44490152E-04
+  -.41703420E-04  -.38706003E-04  -.35521918E-04  -.32175849E-04  -.28692975E-04
+  -.25098802E-04  -.21418991E-04  -.17679194E-04  -.13904890E-04  -.10121228E-04
+  -.63528718E-05  -.26238578E-05   .10425472E-05   .46239762E-05   .80990852E-05
+   .11447667E-04   .14650754E-04   .17690715E-04   .20551337E-04   .23217901E-04
+   .25677239E-04   .27917790E-04   .29929638E-04   .31704543E-04   .33235954E-04
+   .34519018E-04   .35550579E-04   .36329157E-04   .36854927E-04   .37129683E-04
+   .37156794E-04   .36941149E-04   .36489095E-04   .35808369E-04   .34908018E-04
+   .33798317E-04   .32490678E-04   .30997552E-04   .29332335E-04   .27509258E-04
+   .25543280E-04   .23449983E-04   .21245454E-04   .18946177E-04   .16568918E-04
+   .14130614E-04   .11648259E-04   .91387969E-05   .66190127E-05   .41054300E-05
+   .16142095E-05  -.83894683E-06  -.32388870E-05  -.55710953E-05  -.78217726E-05
+  -.99779111E-05  -.12027362E-04  -.13958896E-04  -.15762259E-04  -.17428217E-04
+  -.18948600E-04  -.20316327E-04  -.21525439E-04  -.22571108E-04  -.23449652E-04
+  -.24158535E-04  -.24696364E-04  -.25062871E-04  -.25258900E-04  -.25286378E-04
+  -.25148281E-04  -.24848600E-04  -.24392291E-04  -.23785231E-04  -.23034159E-04
+  -.22146619E-04  -.21130896E-04  -.19995951E-04  -.18751349E-04  -.17407188E-04
+  -.15974025E-04  -.14462797E-04  -.12884748E-04  -.11251347E-04  -.95742153E-05
+  -.78650434E-05  -.61355195E-05  -.43972516E-05  -.26616955E-05  -.94008363E-06
+   .75664339E-06   .24179016E-05   .40335258E-05   .55938270E-05   .70896468E-05
+   .85124069E-05   .98541536E-05   .11107599E-04   .12266154E-04   .13323963E-04
+   .14275923E-04   .15117707E-04   .15845778E-04   .16457398E-04   .16950629E-04
+   .17324336E-04   .17578178E-04   .17712594E-04   .17728794E-04   .17628730E-04
+   .17415074E-04   .17091189E-04   .16661095E-04   .16129429E-04   .15501412E-04
+   .14782794E-04   .13979818E-04   .13099167E-04   .12147912E-04   .11133463E-04
+   .10063513E-04   .89459836E-05   .77889719E-05   .66006930E-05   .53894257E-05
+   .41634583E-05   .29310340E-05   .17002992E-05   .47925176E-06  -.72430798E-06
+  -.19028243E-05  -.30490312E-05  -.41559941E-05  -.52171499E-05  -.62263425E-05
+  -.71778567E-05  -.80664472E-05  -.88873654E-05  -.96363813E-05  -.10309803E-04
+  -.10904491E-04  -.11417870E-04  -.11847937E-04  -.12193262E-04  -.12452992E-04
+  -.12626844E-04  -.12715098E-04  -.12718587E-04  -.12638682E-04  -.12477274E-04
+  -.12236753E-04  -.11919985E-04  -.11530288E-04  -.11071397E-04  -.10547438E-04
+  -.99628939E-05  -.93225692E-05  -.86315531E-05  -.78951827E-05  -.71190036E-05
+  -.63087313E-05  -.54702108E-05  -.46093767E-05  -.37322130E-05  -.28447141E-05
+  -.19528447E-05  -.10625024E-05  -.17948014E-06   .69056996E-06   .15421708E-05
+   .23700531E-05   .31691864E-05   .39348081E-05   .46624498E-05   .53479618E-05
+   .59875350E-05   .65777202E-05   .71154451E-05   .75980277E-05   .80231879E-05
+   .83890560E-05   .86941783E-05   .89375199E-05   .91184647E-05   .92368130E-05
+   .92927764E-05   .92869694E-05   .92203995E-05   .90944543E-05   .89108868E-05
+   .86717977E-05   .83796168E-05   .80370819E-05   .76472161E-05   .72133038E-05
+   .67388651E-05   .62276295E-05   .56835082E-05   .51105660E-05   .45129922E-05
+   .38950717E-05   .32611557E-05   .26156320E-05   .19628965E-05   .13073238E-05
+   .65323983E-06   .48938824E-08  -.63356752E-06  -.12581261E-05  -.18649159E-05
+  -.24502461E-05  -.30106223E-05  -.35427663E-05  -.40436340E-05  -.45104316E-05
+  -.49406297E-05  -.53319762E-05  -.56825063E-05  -.59905510E-05  -.62547432E-05
+  -.64740223E-05  -.66476363E-05  -.67751420E-05  -.68564029E-05  -.68915858E-05
+  -.68811549E-05  -.68258643E-05  -.67267486E-05  -.65851124E-05  -.64025168E-05
+  -.61807664E-05  -.59218932E-05  -.56281404E-05  -.53019442E-05  -.49459156E-05
+  -.45628205E-05  -.41555592E-05  -.37271463E-05  -.32806885E-05  -.28193639E-05
+  -.23463998E-05  -.18650511E-05  -.13785788E-05  -.89022909E-06  -.40321199E-06
+   .79318595E-07   .55428454E-06   .10187024E-05   .14697011E-05   .19045394E-05
+   .23206211E-05   .27155101E-05   .30869437E-05   .34328449E-05   .37513326E-05
+   .40407316E-05   .42995799E-05   .45266351E-05   .47208795E-05   .48815230E-05
+   .50080055E-05   .50999963E-05   .51573936E-05   .51803215E-05   .51691262E-05
+   .51243699E-05   .50468247E-05   .49374643E-05   .47974547E-05   .46281440E-05
+   .44310509E-05   .42078525E-05   .39603712E-05   .36905608E-05   .34004919E-05
+   .30923370E-05   .27683549E-05   .24308745E-05   .20822796E-05   .17249918E-05
+   .13614549E-05   .99411858E-06   .62542245E-06   .25778052E-06  -.10643403E-06
+  -.46490365E-06  -.81538053E-06  -.11557002E-05  -.14837943E-05  -.17977024E-05
+  -.20955836E-05  -.23757261E-05  -.26365569E-05  -.28766499E-05  -.30947327E-05
+  -.32896934E-05  -.34605847E-05  -.36066282E-05  -.37272169E-05  -.38219169E-05
+  -.38904675E-05  -.39327808E-05  -.39489397E-05  -.39391950E-05  -.39039615E-05
+  -.38438130E-05  -.37594768E-05  -.36518263E-05  -.35218738E-05  -.33707621E-05
+  -.31997550E-05  -.30102278E-05  -.28036572E-05  -.25816097E-05  -.23457310E-05
+  -.20977338E-05  -.18393863E-05  -.15725000E-05  -.12989171E-05  -.10204985E-05
+  -.73911187E-06  -.45661893E-06  -.17486400E-06   .10433781E-06   .37921183E-06
+   .64803475E-06   .90914502E-06   .11609527E-05   .14019487E-05   .16307136E-05
+   .18459254E-05   .20463669E-05   .22309318E-05   .23986311E-05   .25485971E-05
+   .26800879E-05   .27924904E-05   .28853226E-05   .29582350E-05   .30110109E-05
+   .30435666E-05   .30559496E-05   .30483372E-05   .30210331E-05   .29744644E-05
+   .29091767E-05   .28258298E-05   .27251911E-05   .26081302E-05   .24756113E-05
+   .23286864E-05   .21684867E-05   .19962152E-05   .18131373E-05   .16205724E-05
+   .14198845E-05   .12124730E-05   .99976313E-06   .78319652E-06   .56422183E-06
+   .34428531E-06   .12482148E-06  -.92755848E-07  -.30706247E-06  -.51675228E-06
+  -.72052542E-06  -.91713613E-06  -.11054000E-05  -.12842010E-05  -.14524975E-05
+  -.16093283E-05  -.17538180E-05  -.18851811E-05  -.20027263E-05  -.21058598E-05
+  -.21940878E-05  -.22670185E-05  -.23243636E-05  -.23659387E-05  -.23916632E-05
+  -.24015599E-05  -.23957532E-05  -.23744674E-05  -.23380241E-05  -.22868387E-05
+  -.22214169E-05  -.21423503E-05  -.20503115E-05  -.19460489E-05  -.18303810E-05
+  -.17041904E-05  -.15684172E-05  -.14240522E-05  -.12721305E-05  -.11137236E-05
+  -.94993250E-06  -.78188017E-06  -.61070410E-06  -.43754878E-06  -.26355826E-06
+  -.89868782E-07   .82398432E-07   .25214423E-06   .41829836E-06   .57982602E-06
+   .73573413E-06   .88507725E-06   .10269631E-05   .11605578E-05   .12850904E-05
+   .13998572E-05   .15042258E-05   .15976379E-05   .16796124E-05   .17497474E-05
+   .18077222E-05   .18532983E-05   .18863196E-05   .19067135E-05   .19144894E-05
+   .19097382E-05   .18926309E-05   .18634165E-05   .18224193E-05   .17700363E-05
+   .17067339E-05   .16330437E-05   .15495587E-05   .14569288E-05   .13558558E-05
+   .12470885E-05   .11314173E-05   .10096684E-05   .88269853E-06   .75138875E-06
+   .61663863E-06   .47936020E-06   .34047194E-06   .20089277E-06   .61536143E-07
+  -.76695861E-07  -.21291819E-06  -.34626838E-06  -.47591190E-06  -.60104721E-06
+  -.72091065E-06  -.83478091E-06  -.94198330E-06  -.10418936E-05  -.11339416E-05
+  -.12176140E-05  -.12924575E-05  -.13580809E-05  -.14141568E-05  -.14604234E-05
+  -.14966852E-05  -.15228137E-05  -.15387476E-05  -.15444924E-05  -.15401193E-05
+  -.15257650E-05  -.15016289E-05  -.14679723E-05  -.14251151E-05  -.13734338E-05
+  -.13133580E-05  -.12453675E-05  -.11699882E-05  -.10877885E-05  -.99937506E-06
+  -.90538854E-06  -.80649903E-06  -.70340142E-06  -.59681064E-06  -.48745679E-06
+  -.37608030E-06  -.26342695E-06  -.15024306E-06  -.37270564E-07   .74757695E-07
+   .18512265E-06   .29312355E-06   .39808225E-06   .49934746E-06   .59629864E-06
+   .68834972E-06   .77495255E-06   .85560008E-06   .92982920E-06   .99722333E-06
+   .10574146E-05   .11100858E-05   .11549720E-05   .11918613E-05   .12205962E-05
+   .12410741E-05   .12532466E-05   .12571204E-05   .12527557E-05   .12402660E-05
+   .12198162E-05   .11916215E-05   .11559453E-05   .11130969E-05   .10634292E-05
+   .10073359E-05   .94524827E-06   .87763252E-06   .80498589E-06   .72783333E-06
+   .64672375E-06   .56222627E-06   .47492620E-06   .38542116E-06   .29431703E-06
+   .20222391E-06   .10975213E-06   .17508247E-07  -.73908835E-07  -.16391170E-06
+  -.25192813E-06  -.33740468E-06  -.41981005E-06  -.49863838E-06  -.57341223E-06
+  -.64368543E-06  -.70904565E-06  -.76911673E-06  -.82356081E-06  -.87208005E-06
+  -.91441825E-06  -.95036205E-06  -.97974188E-06  -.10024326E-05  -.10183540E-05
+  -.10274706E-05  -.10297917E-05  -.10253708E-05  -.10143045E-05  -.99673193E-06
+  -.97283317E-06  -.94282758E-06  -.90697211E-06  -.86555921E-06  -.81891458E-06
+ 17.0075338972103118 T
+ Non local Part
+ 1 2 1.42483014276140318
+ -19.3116750135285180 1.15651569312746694 1.15651569312746694 8.35437929212855046
+ Reciprocal Space Part
+   .00000000E+00   .38789916E+00   .77278352E+00   .11516723E+01   .15216520E+01
+   .18799094E+01   .22237623E+01   .25506890E+01   .28583554E+01   .31446398E+01
+   .34076542E+01   .36457627E+01   .38575971E+01   .40420679E+01   .41983719E+01
+   .43259968E+01   .44247210E+01   .44946102E+01   .45360103E+01   .45495370E+01
+   .45360619E+01   .44966959E+01   .44327696E+01   .43458116E+01   .42375249E+01
+   .41097612E+01   .39644947E+01   .38037946E+01   .36297972E+01   .34446785E+01
+   .32506266E+01   .30498155E+01   .28443794E+01   .26363894E+01   .24278309E+01
+   .22205837E+01   .20164047E+01   .18169119E+01   .16235721E+01   .14376909E+01
+   .12604048E+01   .10926769E+01   .93529495E+00   .78887142E+00   .65384689E+00
+   .53049506E+00   .41893015E+00   .31911612E+00   .23087746E+00   .15391152E+00
+   .87801776E-01   .32032112E-01  -.13998415E-01  -.50960458E-01  -.79579222E-01
+  -.10061950E+00  -.11487114E+00  -.12313514E+00  -.12621063E+00  -.12488274E+00
+  -.11991175E+00  -.11202335E+00  -.10190032E+00  -.90175585E-01  -.77426635E-01
+  -.64171397E-01  -.50865480E-01  -.37900749E-01  -.25605165E-01  -.14243794E-01
+  -.40208810E-02   .49171299E-02   .12477766E-01   .18618017E-01   .23339287E-01
+   .26681954E-01   .28719679E-01   .29553585E-01   .29306454E-01   .28117039E-01
+   .26134621E-01   .23513883E-01   .20410198E-01   .16975391E-01   .13354022E-01
+   .96802379E-02   .60751988E-02   .26450975E-02  -.52023974E-03  -.33481913E-02
+  -.57836450E-02  -.77888132E-02  -.93426034E-02  -.10439602E-01  -.11088731E-01
+  -.11311635E-01  -.11140877E-01  -.10617986E-01  -.97914374E-02  -.87146183E-02
+ Real Space Part
+   .00000000E+00   .45673033E+00   .91064621E+00   .13589852E+01   .17990870E+01
+   .22284409E+01   .26447279E+01   .30458573E+01   .34299960E+01   .37955901E+01
+   .41413782E+01   .44663954E+01   .47699699E+01   .50517100E+01   .53114849E+01
+   .55493982E+01   .57657556E+01   .59610294E+01   .61358195E+01   .62908132E+01
+   .64267461E+01   .65443634E+01   .66443861E+01   .67274795E+01   .67942293E+01
+   .68451220E+01   .68805333E+01   .69007228E+01   .69058362E+01   .68959141E+01
+   .68709067E+01   .68306947E+01   .67751137E+01   .67039831E+01   .66171365E+01
+   .65144526E+01   .63958870E+01   .62615008E+01   .61114873E+01   .59461945E+01
+   .57661423E+01   .55720350E+01   .53647667E+01   .51454217E+01   .49152669E+01
+   .46757398E+01   .44284293E+01   .41750524E+01   .39174260E+01   .36574355E+01
+   .33970009E+01   .31380419E+01   .28824422E+01   .26320150E+01   .23884708E+01
+   .21533871E+01   .19281828E+01   .17140956E+01   .15121660E+01   .13232245E+01
+   .11478857E+01   .98654689E+00   .83939192E+00   .70639989E+00   .58735825E+00
+   .48187944E+00   .38942075E+00   .30930646E+00   .24075156E+00   .18288630E+00
+   .13478083E+00   .95469249E-01   .63972383E-01   .39318853E-01   .20563887E-01
+   .68056008E-02  -.28015057E-02  -.90359546E-02  -.12601621E-01  -.14122910E-01
+  -.14142618E-01  -.13122245E-01  -.11444468E-01  -.94174442E-02  -.72805785E-02
+  -.52113969E-02  -.33331538E-02  -.17228286E-02  -.41919140E-03   .56934410E-03
+   .12573193E-02   .16754723E-02   .18647625E-02   .18712718E-02   .17420256E-02
+   .15217364E-02   .12504354E-02   .96192351E-03   .68295233E-03   .43302721E-03
+   .00000000E+00   .65364562E+00   .12969722E+01   .19198370E+01   .25124463E+01
+   .30655218E+01   .35704575E+01   .40194634E+01   .44056950E+01   .47233640E+01
+   .49678306E+01   .51356737E+01   .52247392E+01   .52341650E+01   .51643830E+01
+   .50170974E+01   .47952404E+01   .45029069E+01   .41452690E+01   .37284716E+01
+   .32595131E+01   .27461118E+01   .21965616E+01   .16195803E+01   .10241519E+01
+   .41936828E+00  -.18572905E+00  -.78230248E+00  -.13618651E+01  -.19164177E+01
+  -.24385742E+01  -.29216723E+01  -.33598691E+01  -.37482181E+01  -.40827291E+01
+  -.43604079E+01  -.45792773E+01  -.47383783E+01  -.48377529E+01  -.48784086E+01
+  -.48622664E+01  -.47920935E+01  -.46714225E+01  -.45044590E+01  -.42959801E+01
+  -.40512261E+01  -.37757867E+01  -.34754862E+01  -.31562674E+01  -.28240794E+01
+  -.24847687E+01  -.21439777E+01  -.18070511E+01  -.14789521E+01  -.11641904E+01
+  -.86676193E+00  -.59010159E+00  -.33704928E+00  -.10982961E+00   .89955253E-01
+   .26131985E+00   .40387753E+00   .51781136E+00   .60383491E+00   .66314432E+00
+   .69736298E+00   .70848047E+00   .69878731E+00   .67080706E+00   .62722759E+00
+   .57083277E+00   .50443634E+00   .43081914E+00   .35267092E+00   .27253787E+00
+   .19277660E+00   .11551543E+00   .42623258E-01  -.24313511E-01  -.84006098E-01
+  -.13547048E+00  -.17802695E+00  -.21129244E+00  -.23516637E+00  -.24981058E+00
+  -.25562432E+00  -.25321511E+00  -.24336646E+00  -.22700350E+00  -.20515735E+00
+  -.17892935E+00  -.14945593E+00  -.11787510E+00  -.85295132E-01  -.52766306E-01
+  -.21256074E-01   .83718013E-02   .35373901E-01   .59139393E-01   .79197828E-01
+ Real Space Part
+   .00000000E+00  -.33518861E-01  -.82007980E-01  -.15994967E+00  -.28086467E+00
+  -.45686677E+00  -.69825860E+00  -.10131806E+01  -.14073233E+01  -.18837109E+01
+  -.24425632E+01  -.30812386E+01  -.37942607E+01  -.45734268E+01  -.54079955E+01
+  -.62849471E+01  -.71893095E+01  -.81045401E+01  -.90129522E+01  -.98961739E+01
+  -.10735626E+02  -.11513006E+02  -.12210765E+02  -.12812560E+02  -.13303679E+02
+  -.13671414E+02  -.13905389E+02  -.13997814E+02  -.13943680E+02  -.13740879E+02
+  -.13390242E+02  -.12895514E+02  -.12263247E+02  -.11502628E+02  -.10625246E+02
+  -.96448068E+01  -.85767908E+01  -.74380895E+01  -.62466077E+01  -.50208548E+01
+  -.37795322E+01  -.25411292E+01  -.13235367E+01  -.14368755E+00   .98276611E+00
+   .20417343E+01   .30209215E+01   .39100079E+01   .47007751E+01   .53871779E+01
+   .59653606E+01   .64336215E+01   .67923296E+01   .70437960E+01   .71921083E+01
+   .72429326E+01   .72032909E+01   .70813209E+01   .68860252E+01   .66270177E+01
+   .63142734E+01   .59578876E+01   .55678516E+01   .51538468E+01   .47250644E+01
+   .42900512E+01   .38565837E+01   .34315734E+01   .30210001E+01   .26298759E+01
+   .22622352E+01   .19211513E+01   .16087742E+01   .13263884E+01   .10744862E+01
+   .85285349E+00   .66066389E+00   .49657786E+00   .35884371E+00   .24539710E+00
+   .15395648E+00   .82112238E-01   .27407464E-01  -.12590780E-01  -.40230835E-01
+  -.57726864E-01  -.67120432E-01  -.70252943E-01  -.68748343E-01  -.64005207E-01
+  -.57197134E-01  -.49280236E-01  -.41006414E-01  -.32941091E-01  -.25484100E-01
+  -.18892485E-01  -.13304091E-01  -.87609469E-02  -.52315912E-02  -.26316815E-02
+ Non local Part
+ 2 2 1.42483014276140318
+ 20.6836375656163405 -6.93368929790366639 -6.93368929790366639 2.14679055333156876
+   .00000000E+00   .15399685E-01   .61350034E-01   .13710935E+00   .24145615E+00
+   .37271082E+00   .52876543E+00   .70712092E+00   .90493119E+00   .11190529E+01
+   .13461004E+01   .15825044E+01   .18245732E+01   .20685559E+01   .23107054E+01
+   .25473411E+01   .27749092E+01   .29900402E+01   .31896015E+01   .33707464E+01
+   .35309554E+01   .36680723E+01   .37803324E+01   .38663831E+01   .39252977E+01
+   .39565796E+01   .39601604E+01   .39363893E+01   .38860159E+01   .38101660E+01
+   .37103114E+01   .35882346E+01   .34459887E+01   .32858540E+01   .31102918E+01
+   .29218966E+01   .27233473E+01   .25173592E+01   .23066370E+01   .20938295E+01
+   .18814876E+01   .16720255E+01   .14676868E+01   .12705143E+01   .10823257E+01
+   .90469417E+00   .73893488E+00   .58609664E+00   .44695927E+00   .32203610E+00
+   .21158147E+00   .11560276E+00   .33876548E-01  -.34031778E-01  -.88745356E-01
+  -.13105092E+00  -.16187219E+00  -.18224219E+00  -.19327526E+00  -.19613922E+00
+  -.19202836E+00  -.18213784E+00  -.16763983E+00  -.14966186E+00  -.12926781E+00
+  -.10744167E+00  -.85074195E-01  -.62952832E-01  -.41754585E-01  -.22042026E-01
+  -.42622096E-02   .11251656E-01   .24276027E-01   .34690613E-01   .42470053E-01
+   .47674018E-01   .50436120E-01   .50951964E-01   .49466730E-01   .46262625E-01
+   .41646534E-01   .35938178E-01   .29459036E-01   .22522274E-01   .15423858E-01
+   .84349960E-02   .17960096E-02  -.42883178E-02  -.96519052E-02  -.14169084E-01
+  -.17754926E-01  -.20364289E-01  -.21989718E-01  -.22658352E-01  -.22428013E-01
+  -.21382649E-01  -.19627338E-01  -.17283022E-01  -.14481161E-01  -.11358478E-01
+ Real Space Part
+   .00000000E+00   .13126126E-01   .52262490E-01   .11669055E+00   .20523746E+00
+   .31631225E+00   .44795452E+00   .59789397E+00   .76361861E+00   .94244901E+00
+   .11316161E+01   .13283397E+01   .15299047E+01   .17337326E+01   .19374457E+01
+   .21389223E+01   .23363396E+01   .25282052E+01   .27133744E+01   .28910540E+01
+   .30607926E+01   .32224578E+01   .33762022E+01   .35224188E+01   .36616887E+01
+   .37947230E+01   .39223012E+01   .40452086E+01   .41641760E+01   .42798228E+01
+   .43926068E+01   .45027824E+01   .46103681E+01   .47151258E+01   .48165514E+01
+   .49138774E+01   .50060877E+01   .50919431E+01   .51700177E+01   .52387432E+01
+   .52964610E+01   .53414779E+01   .53721267E+01   .53868254E+01   .53841359E+01
+   .53628188E+01   .53218826E+01   .52606254E+01   .51786678E+01   .50759761E+01
+   .49528753E+01   .48100505E+01   .46485383E+01   .44697072E+01   .42752292E+01
+   .40670426E+01   .38473076E+01   .36183563E+01   .33826399E+01   .31426722E+01
+   .29009745E+01   .26600203E+01   .24221847E+01   .21896965E+01   .19645977E+01
+   .17487083E+01   .15435993E+01   .13505731E+01   .11706517E+01   .10045736E+01
+   .85279746E+00   .71551249E+00   .59265588E+00   .48393472E+00   .38885240E+00
+   .30673808E+00   .23677819E+00   .17804877E+00   .12954767E+00   .90225712E-01
+   .59015812E-01   .34859548E-01   .16730495E-01   .36539832E-02  -.52769560E-02
+  -.10889549E-01  -.13923074E-01  -.15024304E-01  -.14746312E-01  -.13550239E-01
+  -.11809605E-01  -.98166598E-02  -.77902805E-02  -.58849218E-02  -.42001442E-02
+  -.27902867E-02  -.16739033E-02  -.84264500E-03  -.26933262E-03   .84961019E-04
+   .00000000E+00   .55925549E-01   .22258126E+00   .49661653E+00   .87248795E+00
+   .13425210E+01   .18969969E+01   .25242657E+01   .32108854E+01   .39417882E+01
+   .47004735E+01   .54692280E+01   .62293727E+01   .69615348E+01   .76459431E+01
+   .82627447E+01   .87923399E+01   .92157305E+01   .95148763E+01   .96730555E+01
+   .96752217E+01   .95083494E+01   .91617629E+01   .86274383E+01   .79002730E+01
+   .69783126E+01   .58629302E+01   .45589494E+01   .30747066E+01   .14220461E+01
+  -.38375320E+00  -.23241243E+01  -.43774299E+01  -.65192516E+01  -.87227470E+01
+  -.10959069E+02  -.13197843E+02  -.15407689E+02  -.17556786E+02  -.19613459E+02
+  -.21546780E+02  -.23327177E+02  -.24927022E+02  -.26321198E+02  -.27487624E+02
+  -.28407728E+02  -.29066860E+02  -.29454616E+02  -.29565096E+02  -.29397054E+02
+  -.28953964E+02  -.28243974E+02  -.27279769E+02  -.26078333E+02  -.24660620E+02
+  -.23051129E+02  -.21277416E+02  -.19369525E+02  -.17359377E+02  -.15280113E+02
+  -.13165417E+02  -.11048824E+02  -.89630474E+01  -.69393222E+01  -.50067901E+01
+  -.31919399E+01  -.15181146E+01  -.50968653E-02   .13312178E+01   .24790530E+01
+   .34308846E+01   .41834724E+01   .47377922E+01   .50988704E+01   .52755273E+01
+   .52800373E+01   .51277167E+01   .48364490E+01   .44261632E+01   .39182783E+01
+   .33351287E+01   .26993870E+01   .20334971E+01   .13591337E+01   .69670152E+00
+   .64884415E-01  -.51974272E+00  -.10430328E+01  -.14935088E+01  -.18625256E+01
+  -.21443499E+01  -.23361582E+01  -.24379564E+01  -.24524249E+01  -.23846975E+01
+  -.22420813E+01  -.20337278E+01  -.17702676E+01  -.14634183E+01  -.11255794E+01
+ Real Space Part
+   .00000000E+00   .11261026E+00   .43864459E+00   .94323010E+00   .15699464E+01
+   .22433072E+01   .28720966E+01   .33534299E+01   .35773783E+01   .34319760E+01
+   .28084138E+01   .16062121E+01  -.26182811E+00  -.28650941E+01  -.62512297E+01
+  -.10442960E+02  -.15435800E+02  -.21196751E+02  -.27664023E+02  -.34747832E+02
+  -.42332217E+02  -.50277855E+02  -.58425739E+02  -.66601632E+02  -.74621107E+02
+  -.82295014E+02  -.89435190E+02  -.95860190E+02  -.10140087E+03  -.10590558E+03
+  -.10924491E+03  -.11131562E+03  -.11204387E+03  -.11138746E+03  -.10933715E+03
+  -.10591686E+03  -.10118296E+03  -.95222559E+02  -.88150835E+02  -.80107655E+02
+  -.71253455E+02  -.61764613E+02  -.51828461E+02  -.41638084E+02  -.31387102E+02
+  -.21264581E+02  -.11450243E+02  -.21101052E+01   .66073153E+01   .14574153E+02
+   .21685611E+02   .27861606E+02   .33047623E+02   .37214793E+02   .40359219E+02
+   .42500622E+02   .43680371E+02   .43959006E+02   .43413355E+02   .42133359E+02
+   .40218720E+02   .37775504E+02   .34912790E+02   .31739483E+02   .28361379E+02
+   .24878552E+02   .21383128E+02   .17957493E+02   .14672942E+02   .11588804E+02
+   .87520014E+01   .61970480E+01   .39464261E+01   .20113094E+01   .39256701E+00
+  -.91800834E+00  -.19363146E+01  -.26844594E+01  -.31892457E+01  -.34806806E+01
+  -.35905585E+01  -.35511599E+01  -.33941003E+01  -.31493548E+01  -.28444719E+01
+  -.25039842E+01  -.21490139E+01  -.17970623E+01  -.14619700E+01  -.11540241E+01
+  -.88018996E+00  -.64444121E+00  -.44815891E+00  -.29057488E+00  -.16923275E+00
+  -.80444450E-01  -.19722350E-01   .17828687E-01   .37171280E-01   .43055280E-01
+ Non local Part
+ 0 2 1.42483014276140318
+ 3.03008364309744893 -0.307063262319207553 -0.307063262319207553 0.389068896570595249E-01
+   .23582123E+02   .23532940E+02   .23385878E+02   .23142396E+02   .22804898E+02
+   .22376705E+02   .21862012E+02   .21265823E+02   .20593889E+02   .19852631E+02
+   .19049049E+02   .18190636E+02   .17285272E+02   .16341129E+02   .15366561E+02
+   .14370001E+02   .13359858E+02   .12344411E+02   .11331716E+02   .10329508E+02
+   .93451224E+01   .83854115E+01   .74566786E+01   .65646184E+01   .57142687E+01
+   .49099731E+01   .41553544E+01   .34533000E+01   .28059580E+01   .22147442E+01
+   .16803596E+01   .12028178E+01   .78148091E+00   .41510394E+00   .10188609E+00
+  -.16047222E+00  -.37470743E+00  -.54392750E+00  -.67154430E+00  -.76120491E+00
+  -.81672310E+00  -.84201218E+00  -.84102011E+00  -.81766806E+00  -.77579316E+00
+  -.71909632E+00  -.65109565E+00  -.57508606E+00  -.49410538E+00  -.41090722E+00
+  -.32794070E+00  -.24733693E+00  -.17090218E+00  -.10011733E+00  -.36143310E-01
+   .20168018E-01   .68258089E-01   .10784160E+00   .13888290E+00   .16156949E+00
+   .17628340E+00   .18357115E+00   .18411299E+00   .17869209E+00   .16816443E+00
+   .15342980E+00   .13540454E+00   .11499650E+00   .93082508E-01   .70488683E-01
+   .47973830E-01   .26215999E-01   .58023059E-02  -.12778054E-01  -.29137656E-01
+  -.42991755E-01  -.54156449E-01  -.62544376E-01  -.68158248E-01  -.71082560E-01
+  -.71473833E-01  -.69549741E-01  -.65577520E-01  -.59861988E-01  -.52733539E-01
+  -.44536415E-01  -.35617561E-01  -.26316304E-01  -.16955075E-01  -.78313447E-02
+   .78909458E-03   .86774251E-02   .15645631E-01   .21548865E-01   .26286385E-01
+   .29801158E-01   .32078209E-01   .33141886E-01   .33052163E-01   .31900175E-01
+ Real Space Part
+   .14462297E+02   .14461028E+02   .14457120E+02   .14450274E+02   .14440008E+02
+   .14425680E+02   .14406515E+02   .14381645E+02   .14350150E+02   .14311097E+02
+   .14263594E+02   .14206824E+02   .14140092E+02   .14062859E+02   .13974771E+02
+   .13875682E+02   .13765663E+02   .13645009E+02   .13514230E+02   .13374034E+02
+   .13225303E+02   .13069057E+02   .12906419E+02   .12738562E+02   .12566666E+02
+   .12391867E+02   .12215206E+02   .12037587E+02   .11859730E+02   .11682140E+02
+   .11505081E+02   .11328558E+02   .11152308E+02   .10975806E+02   .10798282E+02
+   .10618737E+02   .10435987E+02   .10248699E+02   .10055442E+02   .98547432E+01
+   .96451411E+01   .94252480E+01   .91938053E+01   .89497385E+01   .86922062E+01
+   .84206424E+01   .81347907E+01   .78347290E+01   .75208837E+01   .71940330E+01
+   .68552996E+01   .65061327E+01   .61482798E+01   .57837501E+01   .54147694E+01
+   .50437301E+01   .46731353E+01   .43055417E+01   .39435006E+01   .35895004E+01
+   .32459122E+01   .29149391E+01   .25985716E+01   .22985504E+01   .20163359E+01
+   .17530871E+01   .15096489E+01   .12865476E+01   .10839955E+01   .90190315E+00
+   .73989797E+00   .59735010E+00   .47340241E+00   .36700462E+00   .27694992E+00
+   .20191279E+00   .14048699E+00   .91222384E-01   .52659739E-01   .23362538E-01
+   .19451437E-02  -.12903226E-01  -.22399050E-01  -.27649737E-01  -.29643536E-01
+  -.29243945E-01  -.27188308E-01  -.24090180E-01  -.20444938E-01  -.16638077E-01
+  -.12955563E-01  -.95956507E-02  -.66815486E-02  -.42743830E-02  -.23859561E-02
+  -.99086469E-03  -.37629791E-04   .54143186E-03   .82177312E-03   .87971618E-03
+   .27883343E+02   .27954021E+02   .28164465E+02   .28509941E+02   .28982659E+02
+   .29571926E+02   .30264355E+02   .31044122E+02   .31893273E+02   .32792073E+02
+   .33719384E+02   .34653074E+02   .35570440E+02   .36448644E+02   .37265146E+02
+   .37998131E+02   .38626925E+02   .39132377E+02   .39497218E+02   .39706379E+02
+   .39747264E+02   .39609977E+02   .39287493E+02   .38775774E+02   .38073831E+02
+   .37183725E+02   .36110510E+02   .34862124E+02   .33449228E+02   .31884990E+02
+   .30184837E+02   .28366156E+02   .26447973E+02   .24450607E+02   .22395299E+02
+   .20303839E+02   .18198185E+02   .16100094E+02   .14030754E+02   .12010446E+02
+   .10058225E+02   .81916310E+01   .64264414E+01   .47764551E+01   .32533245E+01
+   .18664306E+01   .62280391E+00  -.47290897E+00  -.14184326E+01  -.22138071E+01
+  -.28612911E+01  -.33652267E+01  -.37318710E+01  -.39691981E+01  -.40866766E+01
+  -.40950285E+01  -.40059743E+01  -.38319710E+01  -.35859474E+01  -.32810426E+01
+  -.29303540E+01  -.25466974E+01  -.21423860E+01  -.17290297E+01  -.13173599E+01
+  -.91708164E+00  -.53675370E+00  -.18370016E+00   .13604832E+00   .41778252E+00
+   .65811346E+00   .85494319E+00   .10074099E+01   .11158098E+01   .11814987E+01
+   .12067766E+01   .11947589E+01   .11492378E+01   .10745373E+01   .97536631E+00
+   .85667226E+00   .72349936E+00   .58085432E+00   .43358220E+00   .28625478E+00
+   .14307341E+00   .77876865E-02  -.11636880E+00  -.22672537E+00  -.32120354E+00
+  -.39832904E+00  -.45722742E+00  -.49760426E+00  -.51971149E+00  -.52430150E+00
+  -.51257100E+00  -.48609662E+00  -.44676467E+00  -.39669691E+00  -.33817488E+00
+ Real Space Part
+   .15138964E+03   .15112740E+03   .15034594E+03   .14906092E+03   .14729789E+03
+   .14509147E+03   .14248432E+03   .13952573E+03   .13627019E+03   .13277562E+03
+   .12910170E+03   .12530801E+03   .12145233E+03   .11758892E+03   .11376706E+03
+   .11002967E+03   .10641224E+03   .10294204E+03   .99637558E+02   .96508307E+02
+   .93554916E+02   .90769522E+02   .88136447E+02   .85633127E+02   .83231259E+02
+   .80898114E+02   .78597986E+02   .76293699E+02   .73948137E+02   .71525747E+02
+   .68993940E+02   .66324373E+02   .63494050E+02   .60486222E+02   .57291047E+02
+   .53906007E+02   .50336060E+02   .46593541E+02   .42697814E+02   .38674693E+02
+   .34555664E+02   .30376934E+02   .26178339E+02   .22002170E+02   .17891932E+02
+   .13891104E+02   .10041916E+02   .63842095E+01   .29543879E+01  -.21549073E+00
+  -.30984686E+01  -.56732664E+01  -.79246751E+01  -.98437578E+01  -.11427863E+02
+  -.12680456E+02  -.13610789E+02  -.14233416E+02  -.14567590E+02  -.14636558E+02
+  -.14466785E+02  -.14087132E+02  -.13528024E+02  -.12820624E+02  -.11996047E+02
+  -.11084625E+02  -.10115261E+02  -.91148600E+01  -.81078691E+01  -.71159260E+01
+  -.61576138E+01  -.52483269E+01  -.44002389E+01  -.36223666E+01  -.29207169E+01
+  -.22985065E+01  -.17564384E+01  -.12930212E+01  -.90491611E+00  -.58729815E+00
+  -.33421656E+00  -.13894381E+00   .56978801E-02   .10704081E+00   .17231330E+00
+   .20842261E+00   .22178177E+00   .21818045E+00   .20269872E+00   .17966073E+00
+   .15262440E+00   .12440210E+00   .97106795E-01   .72217946E-01   .50661264E-01
+   .32896719E-01   .19009710E-01   .88008308E-02   .18704504E-02  -.23048780E-02
+ PAW radial sets
+ 333 0.950033776649352624
+(5E20.12)
+ augmentation charges (non sperical)
+   .733505396324E+00  -.555083358825E+00   .607622380246E+00  -.144722249601E+00  -.155901199920E+00
+   .333092622850E-01  -.555083358825E+00   .375689312757E+00  -.426370429086E+00   .967291105417E-01
+   .776140634772E-01  -.236718805671E-01   .607622380246E+00  -.426370429086E+00   .602806359533E+00
+  -.139611383856E+00  -.964349173433E-01   .277700174514E-01  -.144722249601E+00   .967291105417E-01
+  -.139611383856E+00   .319334656696E-01   .187691608083E-01  -.608645693819E-02  -.155901199920E+00
+   .776140634772E-01  -.964349173433E-01   .187691608083E-01  -.237974438990E-02  -.622670703202E-02
+   .333092622850E-01  -.236718805671E-01   .277700174514E-01  -.608645693819E-02  -.622670703202E-02
+   .126553954909E-02
+ uccopancies in atom
+   .199999999977E+01   .000000000000E+00   .000000000000E+00   .000000000000E+00   .000000000000E+00
+   .000000000000E+00   .000000000000E+00   .000000000000E+00   .000000000000E+00   .000000000000E+00
+   .000000000000E+00   .000000000000E+00   .000000000000E+00   .000000000000E+00   .139999997296E+01
+   .000000000000E+00   .000000000000E+00   .000000000000E+00   .999999999276E+00   .000000000000E+00
+   .000000000000E+00
+ grid
+   .444792170761E-04   .458690812442E-04   .473023751876E-04   .487804559781E-04   .503047230926E-04
+   .518766197380E-04   .534976342178E-04   .551693013416E-04   .568932038775E-04   .586709740514E-04
+   .605042950921E-04   .623949028251E-04   .643445873161E-04   .663551945659E-04   .684286282582E-04
+   .705668515620E-04   .727718889904E-04   .750458283175E-04   .773908225552E-04   .798090919916E-04
+   .823029262930E-04   .848746866723E-04   .875268081245E-04   .902618017317E-04   .930822570414E-04
+   .959908445177E-04   .989903180702E-04   .102083517661E-03   .105273371995E-03   .108562901290E-03
+   .111955220139E-03   .115453540459E-03   .119061174529E-03   .122781538132E-03   .126618153782E-03
+   .130574654066E-03   .134654785077E-03   .138862409966E-03   .143201512599E-03   .147676201325E-03
+   .152290712869E-03   .157049416346E-03   .161956817392E-03   .167017562433E-03   .172236443086E-03
+   .177618400693E-03   .183168531000E-03   .188892088982E-03   .194794493821E-03   .200881334033E-03
+   .207158372762E-03   .213631553235E-03   .220307004390E-03   .227191046680E-03   .234290198055E-03
+   .241611180136E-03   .249160924578E-03   .256946579630E-03   .264975516909E-03   .273255338376E-03
+   .281793883533E-03   .290599236847E-03   .299679735406E-03   .309043976810E-03   .318700827311E-03
+   .328659430212E-03   .338929214520E-03   .349519903874E-03   .360441525754E-03   .371704420972E-03
+   .383319253467E-03   .395297020396E-03   .407649062552E-03   .420387075099E-03   .433523118644E-03
+   .447069630661E-03   .461039437262E-03   .475445765341E-03   .490302255103E-03   .505622972973E-03
+   .521422424916E-03   .537715570175E-03   .554517835429E-03   .571845129403E-03   .589713857930E-03
+   .608140939485E-03   .627143821201E-03   .646740495392E-03   .666949516586E-03   .687790019094E-03
+   .709281735125E-03   .731445013472E-03   .754300838775E-03   .777870851394E-03   .802177367893E-03
+   .827243402175E-03   .853092687269E-03   .879749697802E-03   .907239673170E-03   .935588641441E-03
+   .964823443991E-03   .994971760923E-03   .102606213728E-02   .105812401005E-02   .109118773606E-02
+   .112528462074E-02   .116044694769E-02   .119670800931E-02   .123410213833E-02   .127266474025E-02
+   .131243232692E-02   .135344255112E-02   .139573424213E-02   .143934744261E-02   .148432344640E-02
+   .153070483770E-02   .157853553135E-02   .162786081442E-02   .167872738909E-02   .173118341686E-02
+   .178527856416E-02   .184106404937E-02   .189859269132E-02   .195791895929E-02   .201909902459E-02
+   .208219081376E-02   .214725406337E-02   .221435037663E-02   .228354328168E-02   .235489829178E-02
+   .242848296728E-02   .250436697965E-02   .258262217742E-02   .266332265418E-02   .274654481879E-02
+   .283236746767E-02   .292087185944E-02   .301214179187E-02   .310626368117E-02   .320332664385E-02
+   .330342258109E-02   .340664626575E-02   .351309543210E-02   .362287086839E-02   .373607651220E-02
+   .385281954895E-02   .397321051329E-02   .409736339384E-02   .422539574106E-02   .435742877856E-02
+   .449358751791E-02   .463400087695E-02   .477880180190E-02   .492812739321E-02   .508211903537E-02
+   .524092253078E-02   .540468823783E-02   .557357121318E-02   .574773135867E-02   .592733357266E-02
+   .611254790615E-02   .630354972382E-02   .650051987007E-02   .670364484023E-02   .691311695713E-02
+   .712913455321E-02   .735190215831E-02   .758163069331E-02   .781853766985E-02   .806284739624E-02
+   .831479118989E-02   .857460759628E-02   .884254261485E-02   .911884993190E-02   .940379116081E-02
+   .969763608969E-02   .100006629369E-01   .103131586143E-01   .106354189993E-01   .109677492144E-01
+   .113104639167E-01   .116638875953E-01   .120283548790E-01   .124042108528E-01   .127918113847E-01
+   .131915234628E-01   .136037255425E-01   .140288079052E-01   .144671730273E-01   .149192359620E-01
+   .153854247315E-01   .158661807329E-01   .163619591556E-01   .168732294127E-01   .174004755852E-01
+   .179441968805E-01   .185049081050E-01   .190831401513E-01   .196794405013E-01   .202943737442E-01
+   .209285221114E-01   .215824860272E-01   .222568846781E-01   .229523565982E-01   .236695602746E-01
+   .244091747701E-01   .251719003668E-01   .259584592287E-01   .267695960857E-01   .276060789386E-01
+   .284686997862E-01   .293582753756E-01   .302756479748E-01   .312216861709E-01   .321972856919E-01
+   .332033702553E-01   .342408924423E-01   .353108345999E-01   .364142097711E-01   .375520626538E-01
+   .387254705901E-01   .399355445865E-01   .411834303656E-01   .424703094508E-01   .437974002854E-01
+   .451659593859E-01   .465772825317E-01   .480327059922E-01   .495336077918E-01   .510814090147E-01
+   .526775751505E-01   .543236174816E-01   .560210945143E-01   .577716134541E-01   .595768317279E-01
+   .614384585530E-01   .633582565552E-01   .653380434383E-01   .673796937046E-01   .694851404298E-01
+   .716563770937E-01   .738954594671E-01   .762045075584E-01   .785857076214E-01   .810413142243E-01
+   .835736523853E-01   .861851197734E-01   .888781889790E-01   .916554098543E-01   .945194119286E-01
+   .974729068968E-01   .100518691188E+00   .103659648612E+00   .106898753092E+00   .110239071477E+00
+   .113683766447E+00   .117236099511E+00   .120899434089E+00   .124677238700E+00   .128573090247E+00
+   .132590677400E+00   .136733804093E+00   .141006393122E+00   .145412489860E+00   .149956266089E+00
+   .154642023949E+00   .159474200010E+00   .164457369474E+00   .169596250507E+00   .174895708706E+00
+   .180360761705E+00   .185996583927E+00   .191808511483E+00   .197802047223E+00   .203982865949E+00
+   .210356819784E+00   .216929943718E+00   .223708461317E+00   .230698790620E+00   .237907550211E+00
+   .245341565490E+00   .253007875134E+00   .260913737759E+00   .269066638797E+00   .277474297579E+00
+   .286144674648E+00   .295085979291E+00   .304306677318E+00   .313815499071E+00   .323621447696E+00
+   .333733807664E+00   .344162153563E+00   .354916359160E+00   .366006606756E+00   .377443396822E+00
+   .389237557943E+00   .401400257069E+00   .413943010089E+00   .426877692738E+00   .440216551834E+00
+   .453972216880E+00   .468157712017E+00   .482786468360E+00   .497872336712E+00   .513429600678E+00
+   .529472990191E+00   .546017695458E+00   .563079381341E+00   .580674202188E+00   .598818817134E+00
+   .617530405867E+00   .636826684899E+00   .656725924337E+00   .677246965184E+00   .698409237178E+00
+   .720232777186E+00   .742738248179E+00   .765946958792E+00   .789880883502E+00   .814562683434E+00
+   .840015727817E+00   .866264116108E+00   .893332700813E+00   .921247111018E+00   .950033776649E+00
+   .979719953507E+00   .101033374906E+01   .104190414908E+01   .107446104506E+01   .110803526252E+01
+   .114265859021E+01   .117836381020E+01   .121518472892E+01
+ aepotential
+   .142553756966E+05   .143731819423E+05   .144684844170E+05   .145405631657E+05   .145888729387E+05
+   .146130223194E+05   .146127847456E+05   .145881001495E+05   .145390776393E+05   .144659985891E+05
+   .143693095026E+05   .142496175816E+05   .141076863982E+05   .139444230440E+05   .137608635621E+05
+   .135581691874E+05   .133376013258E+05   .131005095745E+05   .128483160684E+05   .125824971486E+05
+   .123045661606E+05   .120160546359E+05   .117184994454E+05   .114134236157E+05   .111023235250E+05
+   .107866547725E+05   .104678203519E+05   .101471605279E+05   .982594312873E+04   .950535734271E+04
+   .918650738971E+04   .887040889537E+04   .855798638137E+04   .825007197296E+04   .794740587585E+04
+   .765063764440E+04   .736032861185E+04   .707695502454E+04   .680091229308E+04   .653251921115E+04
+   .627202315207E+04   .601960524677E+04   .577538585227E+04   .553943007162E+04   .531175325220E+04
+   .509232638211E+04   .488108131642E+04   .467791577973E+04   .448269810279E+04   .429527166145E+04
+   .411545899819E+04   .394306561477E+04   .377788343433E+04   .361969391144E+04   .346827085998E+04
+   .332338291858E+04   .318479575683E+04   .305227398644E+04   .292558281390E+04   .280448944367E+04
+   .268876429919E+04   .257818196970E+04   .247252208038E+04   .237156990007E+04   .227511688064E+04
+   .218296102463E+04   .209490718434E+04   .201076723618E+04   .193036016753E+04   .185351214292E+04
+   .178005644655E+04   .170983343321E+04   .164269039296E+04   .157848144612E+04   .151706729129E+04
+   .145831514804E+04   .140209838473E+04   .134829644319E+04   .129679454671E+04   .124748345727E+04
+   .120025931054E+04   .115502333748E+04   .111168163754E+04   .107014497623E+04   .103032854776E+04
+   .992151800682E+03   .955538187353E+03   .920414983479E+03   .886713096677E+03   .854366905652E+03
+   .823314032287E+03   .793495212032E+03   .764854138792E+03   .737337282700E+03   .710893758851E+03
+   .685475190364E+03   .661035579929E+03   .637531164989E+03   .614920321543E+03   .593163440290E+03
+   .572222820482E+03   .552062567382E+03   .532648504486E+03   .513948070414E+03   .495930245792E+03
+   .478565461519E+03   .461825530790E+03   .445683569413E+03   .430113929775E+03   .415092140481E+03
+   .400594834709E+03   .386599702485E+03   .373085429800E+03   .360031648742E+03   .347418887062E+03
+   .335228522275E+03   .323442740843E+03   .312044488422E+03   .301017438658E+03   .290345950222E+03
+   .280015037395E+03   .270010330627E+03   .260318044781E+03   .250924956668E+03   .241818365475E+03
+   .232986074806E+03   .224416362187E+03   .216097955386E+03   .208020010940E+03   .200172089176E+03
+   .192544136933E+03   .185126465159E+03   .177909729816E+03   .170884915711E+03   .164043318505E+03
+   .157376527597E+03   .150876412821E+03   .144535106920E+03   .138344994214E+03   .132298695258E+03
+   .126389055466E+03   .120609131953E+03   .114952182871E+03   .109411655705E+03   .103981177500E+03
+   .986545442779E+02   .934257122151E+02   .882887878606E+02   .832380204053E+02   .782677929949E+02
+   .733726153902E+02   .685471164332E+02   .637860375137E+02   .590842258166E+02   .544366284750E+02
+   .498382868957E+02   .452843313274E+02   .407699764250E+02   .362905162530E+02   .318413207678E+02
+   .274178320918E+02   .230155607157E+02   .186300839293E+02   .142570426543E+02   .989213969965E+01
+   .553113915142E+01   .116986457503E+01  -.319580008457E+01  -.756991110389E+01  -.119564634681E+02
+  -.163593894080E+02  -.207825561216E+02  -.252297626938E+02  -.297047362855E+02  -.342111277445E+02
+  -.387525055667E+02  -.433323502078E+02  -.479540457869E+02  -.526208722794E+02  -.573359954604E+02
+  -.621024560237E+02  -.669231574342E+02  -.718008523518E+02  -.767381271108E+02  -.817373853811E+02
+  -.868008293209E+02  -.919304391967E+02  -.971279511247E+02  -.102394832502E+03  -.107732255238E+03
+  -.113141066900E+03  -.118621759080E+03  -.124174433691E+03  -.129798766528E+03  -.135493968664E+03
+  -.141258745538E+03  -.147091254337E+03  -.152989059970E+03  -.158949090600E+03  -.164967593785E+03
+  -.171040094747E+03  -.177161358881E+03  -.183325361083E+03  -.189525265278E+03  -.195753418224E+03
+  -.202001362382E+03  -.208259873405E+03  -.214519028076E+03  -.220768308500E+03  -.226996747524E+03
+  -.233193117914E+03  -.239346164109E+03  -.245444868297E+03  -.251478732832E+03  -.257438046745E+03
+  -.263314085923E+03  -.269099174956E+03  -.274786516856E+03  -.280369681006E+03  -.285841641358E+03
+  -.291193291528E+03  -.296411451424E+03  -.301476528904E+03  -.306360255149E+03  -.311024015628E+03
+  -.315418725246E+03  -.319486831489E+03  -.323166946883E+03  -.326400836024E+03  -.329141749447E+03
+  -.331362506591E+03  -.333061600927E+03  -.334265968583E+03  -.335029723525E+03  -.335428881188E+03
+  -.335552823902E+03  -.335494061841E+03  -.335338505921E+03  -.335158469893E+03  -.335009646406E+03
+  -.334931791500E+03  -.334951689128E+03  -.335086721259E+03  -.335347890242E+03  -.335741881505E+03
+  -.336272287319E+03  -.336940312523E+03  -.337745242307E+03  -.338684833216E+03  -.339755674582E+03
+  -.340953510451E+03  -.342273495278E+03  -.343710362044E+03  -.345258496513E+03  -.346911921854E+03
+  -.348664203427E+03  -.350508286273E+03  -.352436277151E+03  -.354439183004E+03  -.356506621097E+03
+  -.358626521289E+03  -.360784853710E+03  -.362965432102E+03  -.365149866562E+03  -.367317763517E+03
+  -.369447289559E+03  -.371516209938E+03  -.373503459319E+03  -.375391160661E+03  -.377166727490E+03
+  -.378824215163E+03  -.380363433912E+03  -.381784718050E+03  -.383077363574E+03  -.384201991413E+03
+  -.385072617338E+03  -.385551445716E+03  -.385472223736E+03  -.384698098847E+03  -.383196604071E+03
+  -.381085398814E+03  -.378595841905E+03  -.375959611341E+03  -.373308613739E+03  -.370663295919E+03
+  -.367984290440E+03  -.365223364316E+03  -.362346872375E+03  -.359338632626E+03  -.356194647582E+03
+  -.352916799645E+03  -.349508241476E+03  -.345971015578E+03  -.342305475257E+03  -.338510759887E+03
+  -.334585656545E+03  -.330529422841E+03  -.326342383480E+03  -.322026269699E+03  -.317584341019E+03
+  -.313021355948E+03  -.308343443277E+03  -.303557919294E+03  -.298673077926E+03  -.293697972987E+03
+  -.288642205159E+03  -.283515719271E+03  -.278328622513E+03  -.273091017836E+03  -.267812870463E+03
+  -.262503896464E+03  -.257173482424E+03  -.251830631996E+03  -.246483949691E+03  -.241141621709E+03
+  -.235811227395E+03  -.230497606044E+03  -.225211104602E+03  -.219958466920E+03  -.214746106759E+03
+  -.209580059946E+03  -.204465953398E+03  -.199408963353E+03  -.194413780574E+03  -.189484597230E+03
+  -.184625125581E+03  -.179838652785E+03  -.175128125015E+03  -.170496243661E+03  -.165945550963E+03
+  -.161478482532E+03  -.157097373617E+03  -.152804420925E+03
+ core charge-density
+   .706305344741E-03   .750191563067E-03   .796801204316E-03   .846302941862E-03   .898875864319E-03
+   .954710115716E-03   .101400757474E-02   .107698257540E-02   .114386267164E-02   .121488944851E-02
+   .129031938269E-02   .137042475542E-02   .145549462082E-02   .154583583311E-02   .164177413609E-02
+   .174365531870E-02   .185184644059E-02   .196673713185E-02   .208874097126E-02   .221829694795E-02
+   .235587101108E-02   .250195771305E-02   .265708195162E-02   .282180081679E-02   .299670554873E-02
+   .318242361305E-02   .337962090061E-02   .358900405888E-02   .381132296275E-02   .404737333279E-02
+   .429799950960E-02   .456409739335E-02   .484661755799E-02   .514656855029E-02   .546502038437E-02
+   .580310824286E-02   .616203639671E-02   .654308235593E-02   .694760126463E-02   .737703055408E-02
+   .783289486843E-02   .831681127859E-02   .883049480026E-02   .937576423333E-02   .995454834053E-02
+   .105688923841E-01   .112209650402E-01   .119130657128E-01   .126476322666E-01   .134272492052E-01
+   .142546563161E-01   .151327578079E-01   .160646319685E-01   .170535413685E-01   .181029436425E-01
+   .192165028757E-01   .203981016294E-01   .216518536381E-01   .229821172124E-01   .243935093855E-01
+   .258909208385E-01   .274795316469E-01   .291648278864E-01   .309526191431E-01   .328490569707E-01
+   .348606543413E-01   .369943061379E-01   .392573107370E-01   .416573927340E-01   .442027268616E-01
+   .469019631592E-01   .497642534458E-01   .527992791566E-01   .560172806017E-01   .594290877065E-01
+   .630461522978E-01   .668805819973E-01   .709451757863E-01   .752534613091E-01   .798197339780E-01
+   .846590979484E-01   .897875090292E-01   .952218195960E-01   .100979825572E+00   .107080315541E+00
+   .113543122063E+00   .120389175236E+00   .127640558595E+00   .135320567369E+00   .143453769173E+00
+   .152066067182E+00   .161184765815E+00   .170838638980E+00   .181058000906E+00   .191874779578E+00
+   .203322592795E+00   .215436826840E+00   .228254717758E+00   .241815435211E+00   .256160168870E+00
+   .271332217272E+00   .287377079075E+00   .304342546599E+00   .322278801517E+00   .341238512550E+00
+   .361276934972E+00   .382452011704E+00   .404824475731E+00   .428457953557E+00   .453419069339E+00
+   .479777549309E+00   .507606326047E+00   .536981642094E+00   .567983152332E+00   .600694024521E+00
+   .635201037262E+00   .671594674614E+00   .709969216507E+00   .750422823976E+00   .793057618182E+00
+   .837979752051E+00   .885299473288E+00   .935131177370E+00   .987593449043E+00   .104280909068E+01
+   .110090513577E+01   .116201284560E+01   .122626768717E+01   .129380929007E+01   .136478138000E+01
+   .143933168652E+01   .151761182220E+01   .159977713058E+01   .168598649970E+01   .177640213834E+01
+   .187118931137E+01   .197051603106E+01   .207455270053E+01   .218347170571E+01   .229744695197E+01
+   .241665334144E+01   .254126618701E+01   .267146055886E+01   .280741055954E+01   .294928852337E+01
+   .309726413615E+01   .325150347129E+01   .341216793845E+01   .357941314130E+01   .375338764087E+01
+   .393423162184E+01   .412207545913E+01   .431703818291E+01   .451922584096E+01   .472872975764E+01
+   .494562469017E+01   .516996688358E+01   .540179202702E+01   .564111311550E+01   .588791822254E+01
+   .614216819103E+01   .640379425125E+01   .667269557732E+01   .694873679540E+01   .723174545929E+01
+   .752150951205E+01   .781777475465E+01   .812024234576E+01   .842856636002E+01   .874235143516E+01
+   .906115054186E+01   .938446291350E+01   .971173217650E+01   .100423447255E+02   .103756283905E+02
+   .107108514473E+02   .110472220241E+02   .113838879615E+02   .117199371840E+02   .120543986437E+02
+   .123862438980E+02   .127143893832E+02   .130376994457E+02   .133549901903E+02   .136650342048E+02
+   .139665662112E+02   .142582896951E+02   .145388845510E+02   .148070157769E+02   .150613432392E+02
+   .153005325162E+02   .155232668132E+02   .157282599267E+02   .159142702134E+02   .160801155024E+02
+   .162246888603E+02   .163469750998E+02   .164460678896E+02   .165211872992E+02   .165716975815E+02
+   .165971249655E+02   .165971752022E+02   .165717505785E+02   .165209660837E+02   .164451643904E+02
+   .163449292871E+02   .162210971835E+02   .160747662949E+02   .159073031069E+02   .157203457221E+02
+   .155158037005E+02   .152958540223E+02   .150629328354E+02   .148197226857E+02   .145691349832E+02
+   .143142875219E+02   .140584769436E+02   .138051461263E+02   .135578465726E+02   .133201959794E+02
+   .130958312836E+02   .128883575935E+02   .127012935371E+02   .125380136639E+02   .124016887094E+02
+   .122952245241E+02   .122212007314E+02   .121818101788E+02   .121788003886E+02   .122134182994E+02
+   .122863596629E+02   .123977245059E+02   .125469800777E+02   .127329326724E+02   .129537096338E+02
+   .132067527135E+02   .134888237586E+02   .137960234530E+02   .141238235579E+02   .144671128079E+02
+   .148202563481E+02   .151771683281E+02   .155313969993E+02   .158762213539E+02   .162047580237E+02
+   .165100768143E+02   .167853229211E+02   .170238435745E+02   .172193166018E+02   .173658781891E+02
+   .174582469790E+02   .174918415572E+02   .174628883621E+02   .173685171107E+02   .172068409601E+02
+   .169770188385E+02   .166792976640E+02   .163150325422E+02   .158866834791E+02   .153977876668E+02
+   .148529069901E+02   .142575510465E+02   .136180766710E+02   .129415656846E+02   .122356833272E+02
+   .115085205691E+02   .107684241908E+02   .100238191293E+02   .928302807485E+01   .855409360110E+01
+   .784460815343E+01   .716155695284E+01   .651117828851E+01   .589884471176E+01   .532896745709E+01
+   .480492573774E+01   .432902208878E+01   .390246536042E+01   .352538477051E+01   .319687817462E+01
+   .291509611021E+01   .267735825265E+01   .248029250163E+01   .231998346941E+01   .219212029629E+01
+   .209214020959E+01   .201536767483E+01   .195714816012E+01   .191297356905E+01   .187859546407E+01
+   .185012240440E+01   .182409850947E+01   .179756136592E+01   .176807845638E+01   .173376232645E+01
+   .169326565343E+01   .164575818807E+01   .159088817098E+01   .152873126283E+01   .145973026820E+01
+   .138462898494E+01   .130440339974E+01   .122019319391E+01   .113323616095E+01   .104480769719E+01
+   .956167043705E+00   .868511452013E+00   .782939006259E+00   .700420360497E+00   .621779128291E+00
+   .547680629737E+00   .478628144210E+00   .414965752320E+00   .356886694653E+00   .304446106273E+00
+   .257576973440E+00   .216108157774E+00   .179783475427E+00   .148281116558E+00   .121232285922E+00
+   .982385248944E-01   .788872671502E-01   .627653027620E-01   .494699713178E-01   .386180354775E-01
+   .298522975008E-01   .228461100937E-01   .173059985746E-01   .129726545569E-01   .962058397975E-02
+   .705669707387E-02   .511811779566E-02   .366946860873E-02
+ pspotential
+  -.402379368488E+03  -.402382277428E+03  -.402385098218E+03  -.402387833529E+03  -.402390485951E+03
+  -.402393057994E+03  -.402395552094E+03  -.402397970611E+03  -.402400315836E+03  -.402402589988E+03
+  -.402404795221E+03  -.402406933621E+03  -.402409007214E+03  -.402411017962E+03  -.402412967768E+03
+  -.402414858479E+03  -.402416691883E+03  -.402418469717E+03  -.402420193663E+03  -.402421865353E+03
+  -.402423486368E+03  -.402425058243E+03  -.402426582466E+03  -.402428060478E+03  -.402429493680E+03
+  -.402430883426E+03  -.402432231031E+03  -.402433537772E+03  -.402434804882E+03  -.402436033563E+03
+  -.402437224975E+03  -.402438380244E+03  -.402439500466E+03  -.402440586697E+03  -.402441639965E+03
+  -.402442661266E+03  -.402443651565E+03  -.402444611798E+03  -.402445542873E+03  -.402446445667E+03
+  -.402447321036E+03  -.402448169803E+03  -.402448992772E+03  -.402449790719E+03  -.402450564396E+03
+  -.402451314533E+03  -.402452041836E+03  -.402452746993E+03  -.402453430665E+03  -.402454093498E+03
+  -.402454736114E+03  -.402455359118E+03  -.402455963095E+03  -.402456548613E+03  -.402457116219E+03
+  -.402457666447E+03  -.402458199812E+03  -.402458716812E+03  -.402459217930E+03  -.402459703635E+03
+  -.402460174377E+03  -.402460630596E+03  -.402461072714E+03  -.402461501142E+03  -.402461916276E+03
+  -.402462318498E+03  -.402462708179E+03  -.402463085676E+03  -.402463451334E+03  -.402463805488E+03
+  -.402464148458E+03  -.402464480554E+03  -.402464802076E+03  -.402465113312E+03  -.402465414538E+03
+  -.402465706022E+03  -.402465988019E+03  -.402466260775E+03  -.402466524526E+03  -.402466779498E+03
+  -.402467025908E+03  -.402467263960E+03  -.402467493853E+03  -.402467715773E+03  -.402467929898E+03
+  -.402468136395E+03  -.402468335425E+03  -.402468527136E+03  -.402468711669E+03  -.402468889153E+03
+  -.402469059711E+03  -.402469223453E+03  -.402469380482E+03  -.402469530889E+03  -.402469674758E+03
+  -.402469812160E+03  -.402469943159E+03  -.402470067804E+03  -.402470186139E+03  -.402470298192E+03
+  -.402470403984E+03  -.402470503522E+03  -.402470596803E+03  -.402470683810E+03  -.402470764513E+03
+  -.402470838873E+03  -.402470906833E+03  -.402470968324E+03  -.402471023263E+03  -.402471071550E+03
+  -.402471113070E+03  -.402471147691E+03  -.402471175266E+03  -.402471195625E+03  -.402471208584E+03
+  -.402471213936E+03  -.402471211453E+03  -.402471200887E+03  -.402471181963E+03  -.402471154384E+03
+  -.402471117828E+03  -.402471071943E+03  -.402471016349E+03  -.402470950636E+03  -.402470874361E+03
+  -.402470787049E+03  -.402470688186E+03  -.402470577220E+03  -.402470453561E+03  -.402470316574E+03
+  -.402470165580E+03  -.402469999849E+03  -.402469818603E+03  -.402469621008E+03  -.402469406174E+03
+  -.402469173149E+03  -.402468920916E+03  -.402468648391E+03  -.402468354414E+03  -.402468037750E+03
+  -.402467697082E+03  -.402467331004E+03  -.402466938019E+03  -.402466516529E+03  -.402466064835E+03
+  -.402465581122E+03  -.402465063462E+03  -.402464509796E+03  -.402463917937E+03  -.402463285552E+03
+  -.402462610160E+03  -.402461889117E+03  -.402461119611E+03  -.402460298648E+03  -.402459423041E+03
+  -.402458489401E+03  -.402457494117E+03  -.402456433352E+03  -.402455303018E+03  -.402454098770E+03
+  -.402452815983E+03  -.402451449736E+03  -.402449994795E+03  -.402448445592E+03  -.402446796205E+03
+  -.402445040331E+03  -.402443171269E+03  -.402441181889E+03  -.402439064609E+03  -.402436811362E+03
+  -.402434413571E+03  -.402431862111E+03  -.402429147277E+03  -.402426258748E+03  -.402423185547E+03
+  -.402419915999E+03  -.402416437687E+03  -.402412737407E+03  -.402408801116E+03  -.402404613877E+03
+  -.402400159810E+03  -.402395422022E+03  -.402390382551E+03  -.402385022295E+03  -.402379320941E+03
+  -.402373256885E+03  -.402366807157E+03  -.402359947329E+03  -.402352651422E+03  -.402344891816E+03
+  -.402336639136E+03  -.402327862148E+03  -.402318527639E+03  -.402308600293E+03  -.402298042558E+03
+  -.402286814505E+03  -.402274873675E+03  -.402262174927E+03  -.402248670259E+03  -.402234308637E+03
+  -.402219035798E+03  -.402202794049E+03  -.402185522051E+03  -.402167154589E+03  -.402147622330E+03
+  -.402126851563E+03  -.402104763925E+03  -.402081276108E+03  -.402056299550E+03  -.402029740107E+03
+  -.402001497701E+03  -.401971465953E+03  -.401939531786E+03  -.401905575007E+03  -.401869467868E+03
+  -.401831074590E+03  -.401790250869E+03  -.401746843343E+03  -.401700689033E+03  -.401651614744E+03
+  -.401599436440E+03  -.401543958571E+03  -.401484973362E+03  -.401422260069E+03  -.401355584178E+03
+  -.401284696563E+03  -.401209332598E+03  -.401129211209E+03  -.401044033881E+03  -.400953483597E+03
+  -.400857223727E+03  -.400754896844E+03  -.400646123484E+03  -.400530500825E+03  -.400407601307E+03
+  -.400276971162E+03  -.400138128875E+03  -.399990563559E+03  -.399833733246E+03  -.399667063086E+03
+  -.399489943458E+03  -.399301727987E+03  -.399101731458E+03  -.398889227634E+03  -.398663446972E+03
+  -.398423574235E+03  -.398168745994E+03  -.397898048026E+03  -.397610512609E+03  -.397305115702E+03
+  -.396980774029E+03  -.396636342051E+03  -.396270608847E+03  -.395882294899E+03  -.395470048785E+03
+  -.395032443801E+03  -.394567974513E+03  -.394075053255E+03  -.393552006589E+03  -.392997071752E+03
+  -.392408393107E+03  -.391784018623E+03  -.391121896437E+03  -.390419871501E+03  -.389675682393E+03
+  -.388886958323E+03  -.388051216392E+03  -.387165859181E+03  -.386228172735E+03  -.385235325035E+03
+  -.384184365046E+03  -.383072222460E+03  -.381895708242E+03  -.380651516131E+03  -.379336225227E+03
+  -.377946303848E+03  -.376478114828E+03  -.374927922464E+03  -.373291901331E+03  -.371566147200E+03
+  -.369746690322E+03  -.367829511358E+03  -.365810560243E+03  -.363685778314E+03  -.361451124020E+03
+  -.359102602575E+03  -.356636299906E+03  -.354048421268E+03  -.351335334908E+03  -.348493621137E+03
+  -.345520127192E+03  -.342412028233E+03  -.339166894815E+03  -.335782767130E+03  -.332258236284E+03
+  -.328592532820E+03  -.324785622642E+03  -.320838310401E+03  -.316752350342E+03  -.312530564456E+03
+  -.308176967643E+03  -.303696899340E+03  -.299097160651E+03  -.294386155273E+03  -.289574031115E+03
+  -.284672816722E+03  -.279696541165E+03  -.274661315337E+03  -.269585331843E+03  -.264488701972E+03
+  -.259392980094E+03  -.254320118406E+03  -.249290461780E+03  -.244319328647E+03  -.239412006233E+03
+  -.234558111025E+03  -.229728097966E+03  -.224876895734E+03  -.219971482590E+03  -.215013126242E+03
+  -.210070867172E+03  -.205255402617E+03  -.200511466353E+03  -.195313615990E+03  -.189203618402E+03
+  -.184328594739E+03  -.179616448923E+03  -.174978074563E+03  -.170409615690E+03  -.165916075380E+03
+  -.161482100382E+03  -.157097524808E+03  -.152804420925E+03
+ core charge-density (pseudized)
+   .859127508394E-08   .913657532397E-08   .971648653226E-08   .103332055153E-07   .109890685139E-07
+   .116865600535E-07   .124283223556E-07   .132171653473E-07   .140560773056E-07   .149482361778E-07
+   .158970216198E-07   .169060277990E-07   .179790770094E-07   .191202341517E-07   .203338221312E-07
+   .216244382342E-07   .229969715429E-07   .244566214566E-07   .260089173875E-07   .276597397075E-07
+   .294153420235E-07   .312823748678E-07   .332679108911E-07   .353794716550E-07   .376250561250E-07
+   .400131709722E-07   .425528627975E-07   .452537524023E-07   .481260712336E-07   .511807001422E-07
+   .544292106017E-07   .578839085428E-07   .615578809708E-07   .654650455410E-07   .696202032813E-07
+   .740390946613E-07   .787384592196E-07   .837360989762E-07   .890509458695E-07   .947031334738E-07
+   .100714073269E-06   .107106535749E-06   .113904736685E-06   .121134428854E-06   .128822999594E-06
+   .136999574559E-06   .145695128044E-06   .154942600325E-06   .164777022440E-06   .175235648895E-06
+   .186358098788E-06   .198186505893E-06   .210765678272E-06   .224143268010E-06   .238369951736E-06
+   .253499622585E-06   .269589594365E-06   .286700818659E-06   .304898115729E-06   .324250420059E-06
+   .344831041492E-06   .366717942939E-06   .389994035713E-06   .414747493609E-06   .441072086924E-06
+   .469067537664E-06   .498839897315E-06   .530501948572E-06   .564173632584E-06   .599982503300E-06
+   .638064210665E-06   .678563014478E-06   .721632330868E-06   .767435313451E-06   .816145471379E-06
+   .867947326612E-06   .923037112906E-06   .981623519170E-06   .104392848001E-05   .111018801641E-05
+   .118065312985E-05   .125559075308E-05   .133528476132E-05   .142003704756E-05   .151016866618E-05
+   .160602104914E-05   .170795729931E-05   .181636356596E-05   .193165050747E-05   .205425484695E-05
+   .218464102655E-05   .232330296678E-05   .247076593749E-05   .262758854756E-05   .279436486095E-05
+   .297172664696E-05   .316034577337E-05   .336093675143E-05   .357425944241E-05   .380112193583E-05
+   .404238361049E-05   .429895838966E-05   .457181820291E-05   .486199666763E-05   .517059300418E-05
+   .549877619956E-05   .584778943521E-05   .621895479593E-05   .661367827754E-05   .703345511241E-05
+   .747987543284E-05   .795463029396E-05   .845951807876E-05   .899645130955E-05   .956746389172E-05
+   .101747188171E-04   .108205163562E-04   .115073027702E-04   .122376795757E-04   .130144133977E-04
+   .138404464471E-04   .147189076637E-04   .156531245655E-04   .166466358505E-04   .177032047973E-04
+   .188268335164E-04   .200217781058E-04   .212925647669E-04   .226440069443E-04   .240812235516E-04
+   .256096583541E-04   .272351005806E-04   .289637068423E-04   .308020244428E-04   .327570161652E-04
+   .348360866321E-04   .370471103372E-04   .393984614537E-04   .418990455332E-04   .445583332151E-04
+   .473863960715E-04   .503939447266E-04   .535923693903E-04   .569937829626E-04   .606110668696E-04
+   .644579198033E-04   .685489095514E-04   .728995281098E-04   .775262502873E-04   .824465960225E-04
+   .876791966475E-04   .932438653489E-04   .991616720887E-04   .105455023270E-03   .112147746447E-03
+   .119265180389E-03   .126834270855E-03   .134883672419E-03   .143443856735E-03   .152547227658E-03
+   .162228243632E-03   .172523547822E-03   .183472106466E-03   .195115355965E-03   .207497359269E-03
+   .220664972129E-03   .234668019845E-03   .249559485165E-03   .265395708036E-03   .282236597942E-03
+   .300145859624E-03   .319191233021E-03   .339444748307E-03   .360982996983E-03   .383887420010E-03
+   .408244614055E-03   .434146656961E-03   .461691453661E-03   .490983103767E-03   .522132292213E-03
+   .555256704346E-03   .590481466994E-03   .627939617100E-03   .667772599615E-03   .710130796455E-03
+   .755174088411E-03   .803072452021E-03   .854006593550E-03   .908168622306E-03   .965762765692E-03
+   .102700612850E-02   .109212949912E-02   .116137820542E-02   .123501302340E-02   .131331114151E-02
+   .139656718424E-02   .148509429813E-02   .157922530417E-02   .167931392019E-02   .178573605745E-02
+   .189889119563E-02   .201920384072E-02   .214712507044E-02   .228313417216E-02   .242774037842E-02
+   .258148470547E-02   .274494190038E-02   .291872250257E-02   .310347502588E-02   .329988826739E-02
+   .350869374962E-02   .373066830283E-02   .396663679433E-02   .421747501198E-02   .448411270919E-02
+   .476753681899E-02   .506879484449E-02   .538899843373E-02   .572932714630E-02   .609103241966E-02
+   .647544174249E-02   .688396304267E-02   .731808929697E-02   .777940336913E-02   .826958308280E-02
+   .879040653476E-02   .934375765338E-02   .993163200606E-02   .105561428582E-01   .112195274850E-01
+   .119241537346E-01   .126725268408E-01   .134672964792E-01   .143112640584E-01   .152073902346E-01
+   .161588026337E-01   .171688037605E-01   .182408790677E-01   .193787051551E-01   .205861580560E-01
+   .218673215667E-01   .232264955591E-01   .246682042106E-01   .261972040711E-01   .278184918721E-01
+   .295373119709E-01   .313591633021E-01   .332898056893E-01   .353352653503E-01   .375018394003E-01
+   .397960991337E-01   .422248918317E-01   .447953408097E-01   .475148433793E-01   .503910663607E-01
+   .534319387302E-01   .566456409413E-01   .600405904008E-01   .636254225192E-01   .674089666927E-01
+   .714002165012E-01   .756082933329E-01   .800424025649E-01   .847117813462E-01   .896256369406E-01
+   .947930744970E-01   .100223013022E+00   .105924088239E+00   .111904540927E+00   .118172089252E+00
+   .124733783526E+00   .131595841768E+00   .138763464409E+00   .146240626456E+00   .154029845456E+00
+   .162131923677E+00   .170545663021E+00   .179267551413E+00   .188291419650E+00   .197608068133E+00
+   .207204863360E+00   .217065304806E+00   .227168563586E+00   .237488995441E+00   .247995631828E+00
+   .258651654545E+00   .269413861186E+00   .280232131010E+00   .291048903438E+00   .301798684482E+00
+   .312407599876E+00   .322793017663E+00   .332863267347E+00   .342517487495E+00   .351645638768E+00
+   .360128724628E+00   .367839267268E+00   .374642091288E+00   .380395472059E+00   .384952708957E+00
+   .388164185136E+00   .389879974478E+00   .389953051772E+00   .388243152833E+00   .384621315861E+00
+   .378975112113E+00   .371214541258E+00   .361278522599E+00   .349141855800E+00   .334822452023E+00
+   .318388547106E+00   .299965501904E+00   .279741671615E+00   .257972688241E+00   .234983352872E+00
+   .211166185635E+00   .186975543331E+00   .162916106377E+00   .139524482302E+00   .117342705289E+00
+   .968825705608E-01   .785800771672E-01   .627398177320E-01   .494700066772E-01   .386180354775E-01
+ pseudo wavefunction
+   .108716378895E-07   .115616759463E-07   .122955116832E-07   .130759249999E-07   .139058722406E-07
+   .147884973926E-07   .157271439965E-07   .167253678121E-07   .177869502882E-07   .189159128875E-07
+   .201165323205E-07   .213933567464E-07   .227512230025E-07   .241952749269E-07   .257309828442E-07
+   .273641642882E-07   .291010060396E-07   .309480875627E-07   .329124059296E-07   .350014023262E-07
+   .372229902409E-07   .395855854422E-07   .420981378591E-07   .447701654849E-07   .476117904333E-07
+   .506337772827E-07   .538475738539E-07   .572653545769E-07   .609000666098E-07   .647654788845E-07
+   .688762342662E-07   .732479050228E-07   .778970518158E-07   .828412864346E-07   .880993385132E-07
+   .936911264812E-07   .996378330183E-07   .105961985298E-06   .112687540325E-06   .119839975687E-06
+   .127446386070E-06   .135535585896E-06   .144138218479E-06   .153286872103E-06   .163016203478E-06
+   .173363069022E-06   .184366664478E-06   .196068673397E-06   .208513425043E-06   .221748062315E-06
+   .235822720337E-06   .250790716377E-06   .266708751820E-06   .283637126965E-06   .301639969451E-06
+   .320785477182E-06   .341146176674E-06   .362799197798E-06   .385826565956E-06   .410315512812E-06
+   .436358806737E-06   .464055104228E-06   .493509323640E-06   .524833042628E-06   .558144920826E-06
+   .593571149341E-06   .631245928792E-06   .671311977675E-06   .713921073010E-06   .759234625288E-06
+   .807424289920E-06   .858672617495E-06   .913173745304E-06   .971134132762E-06   .103277334350E-05
+   .109832487712E-05   .116803705369E-05   .124217395444E-05   .132101642213E-05   .140486312491E-05
+   .149403168771E-05   .158885989545E-05   .168970697262E-05   .179695494401E-05   .191101008193E-05
+   .203230444515E-05   .216129751562E-05   .229847793901E-05   .244436537575E-05   .259951246954E-05
+   .276450694079E-05   .293997381300E-05   .312657778029E-05   .332502572541E-05   .353606939733E-05
+   .376050825899E-05   .399919251562E-05   .425302633536E-05   .452297127425E-05   .481004991860E-05
+   .511534975852E-05   .544002730734E-05   .578531248236E-05   .615251326381E-05   .654302064929E-05
+   .695831392283E-05   .739996625820E-05   .786965067795E-05   .836914639057E-05   .890034552984E-05
+   .946526032193E-05   .100660307072E-04   .107049324461E-04   .113843857386E-04   .121069643919E-04
+   .128754055687E-04   .136926201551E-04   .145617037854E-04   .154859485677E-04   .164688555523E-04
+   .175141479925E-04   .186257854463E-04   .198079787725E-04   .210652060793E-04   .224022296841E-04
+   .238241141499E-04   .253362454658E-04   .269443514444E-04   .286545234141E-04   .304732392867E-04
+   .324073880890E-04   .344642960507E-04   .366517543474E-04   .389780486034E-04   .414519902661E-04
+   .440829499708E-04   .468808930216E-04   .498564171228E-04   .530207925040E-04   .563860045895E-04
+   .599647993739E-04   .637707316760E-04   .678182164514E-04   .721225833600E-04   .767001347933E-04
+   .815682075797E-04   .867452386034E-04   .922508345820E-04   .981058462673E-04   .104332447350E-03
+   .110954218363E-03   .117996235907E-03   .125485167520E-03   .133449372573E-03   .141919009538E-03
+   .150926150070E-03   .160504900299E-03   .170691529818E-03   .181524608819E-03   .193045153932E-03
+   .205296783279E-03   .218325881349E-03   .232181774304E-03   .246916916374E-03   .262587088042E-03
+   .279251606759E-03   .296973550989E-03   .315819998402E-03   .335862279125E-03   .357176244993E-03
+   .379842555794E-03   .403946983596E-03   .429580736266E-03   .456840801414E-03   .485830312006E-03
+   .516658935044E-03   .549443284715E-03   .584307361574E-03   .621383019362E-03   .660810461193E-03
+   .702738766937E-03   .747326453747E-03   .794742071779E-03   .845164837295E-03   .898785305466E-03
+   .955806085333E-03   .101644259952E-02   .108092389149E-02   .114949348318E-02   .122241028630E-02
+   .129994957030E-02   .138240399076E-02   .147008468172E-02   .156332241581E-02   .166246883649E-02
+   .176789776648E-02   .188000659724E-02   .199921776422E-02   .212598031296E-02   .226077156165E-02
+   .240409886567E-02   .255650149028E-02   .271855259769E-02   .289086135530E-02   .307407517208E-02
+   .326888207053E-02   .347601320195E-02   .369624551323E-02   .393040457364E-02   .417936757070E-02
+   .444406648429E-02   .472549144907E-02   .502469431519E-02   .534279241799E-02   .568097256784E-02
+   .604049527146E-02   .642269919670E-02   .682900589303E-02   .726092478028E-02   .772005841881E-02
+   .820810807423E-02   .872687959023E-02   .927828958331E-02   .986437197329E-02   .104872848634E-01
+   .111493177837E-01   .118528993120E-01   .126006050847E-01   .133951662115E-01   .142394781045E-01
+   .151366097346E-01   .160898133239E-01   .171025344831E-01   .181784227999E-01   .193213428834E-01
+   .205353858646E-01   .218248813531E-01   .231944098416E-01   .246488155495E-01   .261932196892E-01
+   .278330341318E-01   .295739754426E-01   .314220792486E-01   .333837148884E-01   .354656002849E-01
+   .376748169675E-01   .400188251560E-01   .425054788006E-01   .451430404529E-01   .479401958218E-01
+   .509060678417E-01   .540502300536E-01   .573827190665E-01   .609140458326E-01   .646552054280E-01
+   .686176849877E-01   .728134693919E-01   .772550442482E-01   .819553956505E-01   .869280061283E-01
+   .921868461274E-01   .977463602790E-01   .103621447627E+00   .109827434885E+00   .116380041690E+00
+   .123295336709E+00   .130589683330E+00   .138279673542E+00   .146382048481E+00   .154913603963E+00
+   .163891079202E+00   .173331026734E+00   .183249661465E+00   .193662686575E+00   .204585093905E+00
+   .216030936334E+00   .228013069557E+00   .240542860597E+00   .253629860399E+00   .267281437844E+00
+   .281502372676E+00   .296294404981E+00   .311655739218E+00   .327580501200E+00   .344058147068E+00
+   .361072824101E+00   .378602684232E+00   .396619152510E+00   .415086154330E+00   .433959307321E+00
+   .453185086163E+00   .472699971531E+00   .492429597755E+00   .512287917726E+00   .532176408146E+00
+   .551983343325E+00   .571583171476E+00   .590836033678E+00   .609587472453E+00   .627668383838E+00
+   .644895274026E+00   .661070888408E+00   .675985287105E+00   .689417445931E+00   .701137464680E+00
+   .710909464576E+00   .718495252612E+00   .723658820977E+00   .726171733150E+00   .725819422892E+00
+   .722408396233E+00   .715774277727E+00   .705790578807E+00   .692377986389E+00   .675513873057E+00
+   .655241616055E+00   .631679182652E+00   .605026297828E+00   .575569363423E+00   .543683156358E+00
+   .509828212598E+00   .474542724062E+00   .438427764764E+00   .402124753916E+00   .366284297012E+00
+   .331525965080E+00   .298389222229E+00   .267276632420E+00   .238391910135E+00   .211733674988E+00
+   .187244705198E+00   .164855993212E+00   .144486517875E+00
+ ae wavefunction
+  -.415304344296E-05  -.439032636189E-05  -.464028940439E-05  -.490366166687E-05  -.518121220642E-05
+  -.547375238681E-05  -.578213835931E-05  -.610727368579E-05  -.645011211208E-05  -.681166050423E-05
+  -.719298195126E-05  -.759519905200E-05  -.801949739131E-05  -.846712922075E-05  -.893941735427E-05
+  -.943775929396E-05  -.996363159783E-05  -.105185945051E-04  -.111042968358E-04  -.117224811807E-04
+  -.123749893973E-04  -.130637684340E-04  -.137908765006E-04  -.145584896049E-04  -.153689084808E-04
+  -.162245659289E-04  -.171280345967E-04  -.180820352237E-04  -.190894453806E-04  -.201533087326E-04
+  -.212768448591E-04  -.224634596622E-04  -.237167564026E-04  -.250405473985E-04  -.264388664296E-04
+  -.279159818894E-04  -.294764107303E-04  -.311249332513E-04  -.328666087791E-04  -.347067922976E-04
+  -.366511520834E-04  -.387056884094E-04  -.408767533812E-04  -.431710719766E-04  -.455957643602E-04
+  -.481583695527E-04  -.508668705367E-04  -.537297208867E-04  -.567558730170E-04  -.599548081457E-04
+  -.633365680797E-04  -.669117889315E-04  -.706917368850E-04  -.746883461369E-04  -.789142591428E-04
+  -.833828693109E-04  -.881083662907E-04  -.931057840128E-04  -.983910516495E-04  -.103981047669E-03
+  -.109893657175E-03  -.116147832721E-03  -.122763658824E-03  -.129762420386E-03  -.137166675257E-03
+  -.145000331209E-03  -.153288727559E-03  -.162058721737E-03  -.171338781081E-03  -.181159080191E-03
+  -.191551604149E-03  -.202550257968E-03  -.214190982640E-03  -.226511878165E-03  -.239553333982E-03
+  -.253358167233E-03  -.267971769327E-03  -.283442261276E-03  -.299820658347E-03  -.317161044532E-03
+  -.335520757450E-03  -.354960584254E-03  -.375544969207E-03  -.397342233580E-03  -.420424808594E-03
+  -.444869482154E-03  -.470757660158E-03  -.498175643227E-03  -.527214919709E-03  -.557972475907E-03
+  -.590551124479E-03  -.625059852050E-03  -.661614187094E-03  -.700336589236E-03  -.741356861142E-03
+  -.784812584266E-03  -.830849579737E-03  -.879622395802E-03  -.931294823219E-03  -.986040440161E-03
+  -.104404318818E-02  -.110549798093E-02  -.117061134730E-02  -.123960211097E-02  -.131270210799E-02
+  -.139015694470E-02  -.147222679779E-02  -.155918725883E-02  -.165133022548E-02  -.174896484164E-02
+  -.185241848915E-02  -.196203783341E-02  -.207818992567E-02  -.220126336460E-02  -.233166952014E-02
+  -.246984382237E-02  -.261624711851E-02  -.277136710119E-02  -.293571981113E-02  -.310985121754E-02
+  -.329433887965E-02  -.348979369280E-02  -.369686172265E-02  -.391622613104E-02  -.414860919727E-02
+  -.439477443836E-02  -.465552883221E-02  -.493172514719E-02  -.522426438213E-02  -.553409832036E-02
+  -.586223220152E-02  -.620972751477E-02  -.657770491707E-02  -.696734727984E-02  -.737990286746E-02
+  -.781668865056E-02  -.827909375711E-02  -.876858306390E-02  -.928670093062E-02  -.983507507853E-02
+  -.104154206151E-01  -.110295442056E-01  -.116793483918E-01  -.123668360581E-01  -.130941150426E-01
+  -.138634028929E-01  -.146770317622E-01  -.155374534424E-01  -.164472445291E-01  -.174091117111E-01
+  -.184258971767E-01  -.195005841279E-01  -.206363023884E-01  -.218363340953E-01  -.231041194548E-01
+  -.244432625467E-01  -.258575371549E-01  -.273508926005E-01  -.289274595509E-01  -.305915557730E-01
+  -.323476917990E-01  -.342005764630E-01  -.361551222687E-01  -.382164505402E-01  -.403898963027E-01
+  -.426810128367E-01  -.450955758414E-01  -.476395871391E-01  -.503192778433E-01  -.531411109076E-01
+  -.561117829670E-01  -.592382253713E-01  -.625276043063E-01  -.659873198876E-01  -.696250041034E-01
+  -.734485174747E-01  -.774659442893E-01  -.816855862586E-01  -.861159544343E-01  -.907657592135E-01
+  -.956438982474E-01  -.100759442061E+00  -.106121617182E+00  -.111739786557E+00  -.117623427038E+00
+  -.123782103705E+00  -.130225440766E+00  -.136963088807E+00  -.144004688106E+00  -.151359827761E+00
+  -.159038000351E+00  -.167048551862E+00  -.175400626591E+00  -.184103106756E+00  -.193164546538E+00
+  -.202593100293E+00  -.212396444659E+00  -.222581694331E+00  -.233155311269E+00  -.244123007130E+00
+  -.255489638751E+00  -.267259096541E+00  -.279434185666E+00  -.292016499973E+00  -.305006288651E+00
+  -.318402315675E+00  -.332201712152E+00  -.346399821795E+00  -.360990039782E+00  -.375963645423E+00
+  -.391309629117E+00  -.407014514235E+00  -.423062174692E+00  -.439433649136E+00  -.456106952820E+00
+  -.473056888442E+00  -.490254857383E+00  -.507668672978E+00  -.525262377608E+00  -.542996065523E+00
+  -.560825713365E+00  -.578703020307E+00  -.596575259585E+00  -.614385142904E+00  -.632070698899E+00
+  -.649565166561E+00  -.666796904505E+00  -.683689317444E+00  -.700160802200E+00  -.716124717294E+00
+  -.731489382124E+00  -.746158113731E+00  -.760029310635E+00  -.772996593770E+00  -.784949013902E+00
+  -.795771333027E+00  -.805344384263E+00  -.813545511260E+00  -.820249085255E+00  -.825327096385E+00
+  -.828649816104E+00  -.830086528909E+00  -.829506332953E+00  -.826779009766E+00  -.821775962962E+00
+  -.814371224794E+00  -.804442528099E+00  -.791872439988E+00  -.776549552450E+00  -.758369724145E+00
+  -.737237366608E+00  -.713066767051E+00  -.685783438768E+00  -.655325488769E+00  -.621644990764E+00
+  -.584709349980E+00  -.544502644536E+00  -.501026926255E+00  -.454303462005E+00  -.404373894823E+00
+  -.351301302590E+00  -.295171130672E+00  -.236091974275E+00  -.174196186086E+00  -.109640285441E+00
+  -.426051465605E-01   .267040548723E-01   .980581561070E-01   .171204601874E+00   .245868340576E+00
+   .321753048826E+00   .398542717113E+00   .475903629235E+00   .553486746056E+00   .630930437616E+00
+   .707863380292E+00   .783907273448E+00   .858678940163E+00   .931791535144E+00   .100285511358E+01
+   .107147757323E+01   .113726739201E+01   .119983891266E+01   .125881934136E+01   .131385562207E+01
+   .136461991649E+01   .141081364383E+01   .145217065969E+01   .148846007425E+01   .151948890873E+01
+   .154510456121E+01   .156519693997E+01   .157970009897E+01   .158859323855E+01   .159190099047E+01
+   .158969296355E+01   .158208257272E+01   .156922520510E+01   .155131579528E+01   .152858589084E+01
+   .150130029246E+01   .146975335397E+01   .143426502492E+01   .139517671545E+01   .135284705803E+01
+   .130764763503E+01   .125995873488E+01   .121016519206E+01   .115865236032E+01   .110580226149E+01
+   .105198994661E+01   .997580101337E+00   .942923923385E+00   .888356293250E+00   .834193274555E+00
+   .780729923891E+00   .728238408756E+00   .676966404555E+00   .627136179777E+00   .578943896568E+00
+   .532559215314E+00   .488125233471E+00   .445758738955E+00   .405550754363E+00   .367567346489E+00
+   .331850675258E+00   .298420256946E+00   .267274417314E+00   .238391910135E+00   .211733674988E+00
+  -.432535886704E-08  -.459989544102E-08  -.489185723498E-08  -.520235025197E-08  -.553255069458E-08
+  -.588370942064E-08  -.625715668165E-08  -.665430716201E-08  -.707666533816E-08  -.752583117769E-08
+  -.800350620042E-08  -.851149992396E-08  -.905173671852E-08  -.962626309680E-08  -.102372554665E-07
+  -.108870283748E-07  -.115780432767E-07  -.123129178589E-07  -.130944359564E-07  -.139255580980E-07
+  -.148094327216E-07  -.157494081005E-07  -.167490450277E-07  -.178121303047E-07  -.189426910865E-07
+  -.201450101371E-07  -.214236420536E-07  -.227834305195E-07  -.242295266536E-07  -.257674085234E-07
+  -.274029018968E-07  -.291422023112E-07  -.309918985433E-07  -.329589975685E-07  -.350509511044E-07
+  -.372756838395E-07  -.396416234529E-07  -.421577325401E-07  -.448335425647E-07  -.476791899653E-07
+  -.507054545539E-07  -.539238003517E-07  -.573464190172E-07  -.609862760293E-07  -.648571598038E-07
+  -.689737339253E-07  -.733515926962E-07  -.780073202096E-07  -.829585531733E-07  -.882240477203E-07
+  -.938237504599E-07  -.997788740391E-07  -.106111977499E-06  -.112847051734E-06  -.120009610370E-06
+  -.127626786415E-06  -.135727435046E-06  -.144342242914E-06  -.153503844392E-06  -.163246945194E-06
+  -.173608453853E-06  -.184627621532E-06  -.196346190712E-06  -.208808553322E-06  -.222061918898E-06
+  -.236156493426E-06  -.251145669523E-06  -.267086228698E-06  -.284038556448E-06  -.302066871008E-06
+  -.321239466618E-06  -.341628972225E-06  -.363312626619E-06  -.386372571017E-06  -.410896160226E-06
+  -.436976293552E-06  -.464711766717E-06  -.494207646100E-06  -.525575666747E-06  -.558934655630E-06
+  -.594410981776E-06  -.632139034964E-06  -.672261734806E-06  -.714931072133E-06  -.760308684752E-06
+  -.808566469738E-06  -.859887234589E-06  -.914465389712E-06  -.972507684853E-06  -.103423399228E-05
+  -.109987813965E-05  -.116968879576E-05  -.124393041252E-05  -.132288422667E-05  -.140684932509E-05
+  -.149614377777E-05  -.159110584262E-05  -.169209524676E-05  -.179949454917E-05  -.191371058976E-05
+  -.203517603043E-05  -.216435099398E-05  -.230172480694E-05  -.244781785308E-05  -.260318354452E-05
+  -.276841041794E-05  -.294412436382E-05  -.313099099712E-05  -.332971817849E-05  -.354105869534E-05
+  -.376581311323E-05  -.400483280799E-05  -.425902319046E-05  -.452934713574E-05  -.481682863006E-05
+  -.512255664909E-05  -.544768928235E-05  -.579345811928E-05  -.616117291369E-05  -.655222654408E-05
+  -.696810028878E-05  -.741036943572E-05  -.788070924815E-05  -.838090130888E-05  -.891284026694E-05
+  -.947854101234E-05  -.100801463060E-04  -.107199348935E-04  -.114003301339E-04  -.121239091757E-04
+  -.128934127146E-04  -.137117553708E-04  -.145820367238E-04  -.155075530473E-04  -.164918097889E-04
+  -.175385348399E-04  -.186516926482E-04  -.198354992247E-04  -.210944381017E-04  -.224332773034E-04
+  -.238570873920E-04  -.253712606573E-04  -.269815315233E-04  -.286939982482E-04  -.305151459991E-04
+  -.324518713892E-04  -.345115085701E-04  -.367018569763E-04  -.390312108285E-04  -.415083905041E-04
+  -.441427758963E-04  -.469443418837E-04  -.499236960471E-04  -.530921187728E-04  -.564616058953E-04
+  -.600449140374E-04  -.638556088195E-04  -.679081161185E-04  -.722177765681E-04  -.768009035055E-04
+  -.816748445807E-04  -.868580472595E-04  -.923701284647E-04  -.982319486166E-04  -.104465690347E-03
+  -.111094942183E-03  -.118144787509E-03  -.125641899146E-03  -.133614639881E-03  -.142093169347E-03
+  -.151109557626E-03  -.160697906006E-03  -.170894475339E-03  -.181737822471E-03  -.193268945247E-03
+  -.205531436627E-03  -.218571648472E-03  -.232438865610E-03  -.247185490810E-03  -.262867241341E-03
+  -.279543357835E-03  -.297276826202E-03  -.316134613414E-03  -.336187917992E-03  -.357512436117E-03
+  -.380188644292E-03  -.404302099592E-03  -.429943758546E-03  -.457210315799E-03  -.486204563732E-03
+  -.517035774311E-03  -.549820104496E-03  -.584681026611E-03  -.621749785167E-03  -.661165881699E-03
+  -.703077589271E-03  -.747642498377E-03  -.795028096084E-03  -.845412380327E-03  -.898984511381E-03
+  -.955945502648E-03  -.101650895296E-02  -.108090182275E-02  -.114936525655E-02  -.122215545433E-02
+  -.129954459434E-02  -.138182181033E-02  -.146929422589E-02  -.156228804902E-02  -.166114973002E-02
+  -.176624718586E-02  -.187797109444E-02  -.199673626203E-02  -.212298306752E-02  -.225717898692E-02
+  -.239982020179E-02  -.255143329528E-02  -.271257703936E-02  -.288384427708E-02  -.306586390328E-02
+  -.325930294744E-02  -.346486876208E-02  -.368331131984E-02  -.391542562249E-02  -.416205422424E-02
+  -.442408987203E-02  -.470247826432E-02  -.499822092980E-02  -.531237822647E-02  -.564607246068E-02
+  -.600049112482E-02  -.637689025099E-02  -.677659787650E-02  -.720101761556E-02  -.765163232925E-02
+  -.813000788376E-02  -.863779698419E-02  -.917674306792E-02  -.974868423830E-02  -.103555572149E-01
+  -.109994012726E-01  -.116823621347E-01  -.124066957825E-01  -.131747721318E-01  -.139890785238E-01
+  -.148522229660E-01  -.157669370484E-01  -.167360784500E-01  -.177626329375E-01  -.188497157413E-01
+  -.200005721803E-01  -.212185773858E-01  -.225072349556E-01  -.238701743454E-01  -.253111467784E-01
+  -.268340194251E-01  -.284427675741E-01  -.301414644763E-01  -.319342685084E-01  -.338254072565E-01
+  -.358191580713E-01  -.379198245975E-01  -.401317087178E-01  -.424590772938E-01  -.449061230159E-01
+  -.474769186008E-01  -.501753634999E-01  -.530051221957E-01  -.559695530764E-01  -.590716267875E-01
+  -.623138328620E-01  -.656980733342E-01  -.692255419443E-01  -.728965874417E-01  -.767105594058E-01
+  -.806656349137E-01  -.847586243160E-01  -.889847543195E-01  -.933374265500E-01  -.978079497612E-01
+  -.102385243901E+00  -.107055514332E+00  -.111801894673E+00  -.116604056952E+00  -.121437788107E+00
+  -.126274532333E+00  -.131080899378E+00  -.135818139633E+00  -.140441587883E+00  -.144900078740E+00
+  -.149135338282E+00  -.153081358166E+00  -.156663760604E+00  -.159799165064E+00  -.162394570441E+00
+  -.164346769747E+00  -.165541818117E+00  -.165854579121E+00  -.165148378970E+00  -.163274803170E+00
+  -.160073675390E+00  -.155373263668E+00  -.148990764309E+00  -.140733118685E+00  -.130398222215E+00
+  -.117776587582E+00  -.102653525067E+00  -.848119010372E-01  -.640355300359E-01  -.401132456369E-01
+  -.128436788316E-01   .179592510551E-01   .524601605999E-01   .907954123377E-01   .133065835904E+00
+   .179329152672E+00   .229592376320E+00   .283804554101E+00   .341850316194E+00   .403544809697E+00
+   .468630703139E+00   .536778047603E+00   .607587858668E+00   .680600322122E+00   .755308504399E+00
+   .831178340094E+00   .907675444812E+00   .984298931650E+00   .106062279114E+01   .113643841516E+01
+   .121181907091E+01   .128689186917E+01   .136181211116E+01
+ ae wavefunction
+   .326550037042E-05   .345207399818E-05   .364861789906E-05   .385570535605E-05   .407394107286E-05
+   .430396301869E-05   .454644437875E-05   .480209561690E-05   .507166665626E-05   .535594918798E-05
+   .565577911095E-05   .597203911615E-05   .630566142006E-05   .665763065869E-05   .702898695076E-05
+   .742082914175E-05   .783431823824E-05   .827068104473E-05   .873121401635E-05   .921728733925E-05
+   .973034925260E-05   .102719306277E-04   .108436498198E-04   .114472178081E-04   .120844436431E-04
+   .127572402184E-04   .134676303882E-04   .142177534506E-04   .150098720189E-04   .158463793056E-04
+   .167298068430E-04   .176628326683E-04   .186482900000E-04   .196891764373E-04   .207886637132E-04
+   .219501080359E-04   .231770610539E-04   .244732814836E-04   .258427474388E-04   .272896695070E-04
+   .288185046154E-04   .304339707380E-04   .321410624927E-04   .339450676841E-04   .358515848499E-04
+   .378665418718E-04   .399962157156E-04   .422472533707E-04   .446266940611E-04   .471419928059E-04
+   .498010454114E-04   .526122149825E-04   .555843600457E-04   .587268643811E-04   .620496686685E-04
+   .655633040567E-04   .692789277740E-04   .732083609012E-04   .773641284418E-04   .817595018246E-04
+   .864085439881E-04   .913261572014E-04   .965281337875E-04   .102031209922E-03   .107853122695E-03
+   .114012670627E-03   .120529777855E-03   .127425562193E-03   .134722407321E-03   .142444039319E-03
+   .150615607840E-03   .159263772164E-03   .168416792442E-03   .178104626441E-03   .188359032093E-03
+   .199213676213E-03   .210704249740E-03   .222868589881E-03   .235746809565E-03   .249381434638E-03
+   .263817549238E-03   .279102949844E-03   .295288308485E-03   .312427345644E-03   .330577013417E-03
+   .349797689515E-03   .370153382731E-03   .391711950525E-03   .414545329408E-03   .438729778872E-03
+   .464346139604E-03   .491480106804E-03   .520222519450E-03   .550669666391E-03   .582923610213E-03
+   .617092529854E-03   .653291082993E-03   .691640789309E-03   .732270435727E-03   .775316504861E-03
+   .820923627878E-03   .869245063108E-03   .920443201759E-03   .974690102168E-03   .103216805407E-02
+   .109307017450E-02   .115760103682E-02   .122597733482E-02   .129842858333E-02   .137519785753E-02
+   .145654257261E-02   .154273530592E-02   .163406466361E-02   .173083619398E-02   .183337334964E-02
+   .194201850094E-02   .205713400285E-02   .217910331795E-02   .230833219785E-02   .244524992574E-02
+   .259031062277E-02   .274399462077E-02   .290680990441E-02   .307929362524E-02   .326201369090E-02
+   .345557043197E-02   .366059834985E-02   .387776794818E-02   .410778765114E-02   .435140581128E-02
+   .460941280998E-02   .488264325334E-02   .517197826627E-02   .547834788757E-02   .580273356852E-02
+   .614617077745E-02   .650975171254E-02   .689462812492E-02   .730201425382E-02   .773318987527E-02
+   .818950346543E-02   .867237547937E-02   .918330174540E-02   .972385697482E-02   .102956983861E-01
+   .109005694418E-01   .115403036964E-01   .122168287509E-01   .129321703111E-01   .136884563431E-01
+   .144879213214E-01   .153329105596E-01   .162258846159E-01   .171694237629E-01   .181662325077E-01
+   .192191441497E-01   .203311253570E-01   .215052807461E-01   .227448574392E-01   .240532495792E-01
+   .254340027721E-01   .268908184290E-01   .284275579720E-01   .300482468687E-01   .317570784527E-01
+   .335584174848E-01   .354568034056E-01   .374569532235E-01   .395637639792E-01   .417823147203E-01
+   .441178679154E-01   .465758702304E-01   .491619525819E-01   .518819293799E-01   .547417968591E-01
+   .577477303966E-01   .609060807027E-01   .642233687632E-01   .677062794079E-01   .713616533661E-01
+   .751964776660E-01   .792178742238E-01   .834330864618E-01   .878494637852E-01   .924744437397E-01
+   .973155316644E-01   .102380277646E+00   .107676250574E+00   .113211009095E+00   .118992069244E+00
+   .125026868550E+00   .131322726391E+00   .137886800366E+00   .144726038495E+00   .151847126994E+00
+   .159256433436E+00   .166959945083E+00   .174963202196E+00   .183271226142E+00   .191888442128E+00
+   .200818596430E+00   .210064667992E+00   .219628774312E+00   .229512071557E+00   .239714648920E+00
+   .250235417232E+00   .261071991943E+00   .272220570623E+00   .283675805210E+00   .295430669309E+00
+   .307476320950E+00   .319801961273E+00   .332394689773E+00   .345239356813E+00   .358318414258E+00
+   .371611765243E+00   .385096614205E+00   .398747318478E+00   .412535242856E+00   .426428618657E+00
+   .440392408830E+00   .454388180660E+00   .468373987460E+00   .482304260472E+00   .496129711925E+00
+   .509797250004E+00   .523249906493E+00   .536426778180E+00   .549262983974E+00   .561689640934E+00
+   .573633864053E+00   .585018796142E+00   .595763675380E+00   .605783948486E+00   .614991437011E+00
+   .623294562732E+00   .630598635818E+00   .636806206722E+00   .641817480452E+00   .645530790755E+00
+   .647843131895E+00   .648650746821E+00   .647849771588E+00   .645336936396E+00   .641010323363E+00
+   .634770180344E+00   .626519789072E+00   .616166384950E+00   .603622124932E+00   .588805099147E+00
+   .571640381146E+00   .552061110770E+00   .530009602695E+00   .505438472581E+00   .478311771543E+00
+   .448606118289E+00   .416311816854E+00   .381433946329E+00   .343993407492E+00   .304027909754E+00
+   .261592880525E+00   .216762278027E+00   .169629287889E+00   .120306883700E+00   .689282320738E-01
+   .156469237328E-01  -.393629866804E-01  -.959071483747E-01  -.153771306191E+00  -.212721934844E+00
+  -.272507138342E+00  -.332857842103E+00  -.393489304749E+00  -.454102958160E+00  -.514388530249E+00
+  -.574026302989E+00  -.632689230357E+00  -.690044574252E+00  -.745754850217E+00  -.799478302796E+00
+  -.850869729989E+00  -.899582784769E+00  -.945274326851E+00  -.987610134151E+00  -.102627050506E+01
+  -.106095475678E+01  -.109138460017E+01  -.111730685683E+01  -.113849591162E+01  -.115475605037E+01
+  -.116592365227E+01  -.117186911920E+01  -.117249840815E+01  -.116775405761E+01  -.115761564443E+01
+  -.114209965312E+01  -.112125877580E+01  -.109518068518E+01  -.106398633634E+01  -.102782786003E+01
+  -.986886111843E+00  -.941367941887E+00  -.891503247083E+00  -.837541864981E+00  -.779750363815E+00
+  -.718408778345E+00  -.653807335952E+00  -.586243211627E+00  -.516017345701E+00  -.443431353449E+00
+  -.368784551652E+00  -.292371124370E+00  -.214477447477E+00  -.135379588339E+00  -.553410014518E-01
+   .253895819347E-01   .106580040188E+00   .188016494307E+00   .269504761240E+00   .350871612034E+00
+   .431965848573E+00   .512659211827E+00   .592847135615E+00   .672449365763E+00   .751410459177E+00
+   .829700177600E+00   .907313792964E+00   .984272330514E+00   .106062279114E+01   .113643841516E+01
+   .532130737371E-12   .583588959248E-12   .640023305236E-12   .701914977566E-12   .769791711786E-12
+   .844232276646E-12   .925871409112E-12   .101540522662E-11   .111359716272E-11   .122128447664E-11
+   .133938539247E-11   .146890692859E-11   .161095348427E-11   .176673625665E-11   .193758356832E-11
+   .212495219360E-11   .233043978011E-11   .255579847152E-11   .280294984769E-11   .307400130951E-11
+   .337126404817E-11   .369727275218E-11   .405480722004E-11   .444691606291E-11   .487694269939E-11
+   .534855386404E-11   .586577087279E-11   .643300391168E-11   .705508964149E-11   .773733243881E-11
+   .848554962514E-11   .930612106983E-11   .102060435897E-10   .111929906091E-10   .122753775896E-10
+   .134624337864E-10   .147642809441E-10   .161920196021E-10   .177578237468E-10   .194750446155E-10
+   .213583245399E-10   .234237217972E-10   .256888475354E-10   .281730159393E-10   .308974089178E-10
+   .338852567170E-10   .371620359986E-10   .407556870736E-10   .446968521425E-10   .490191365733E-10
+   .537593954472E-10   .589580478120E-10   .646594213260E-10   .709121302291E-10   .777694898640E-10
+   .852899712834E-10   .935376998183E-10   .102583001859E-09   .112503004509E-09   .123382293233E-09
+   .135313633091E-09   .148398759726E-09   .162749246837E-09   .178487457542E-09   .195747587736E-09
+   .214676810342E-09   .235436530224E-09   .258203760443E-09   .283172631596E-09   .310556047128E-09
+   .340587498697E-09   .373523057099E-09   .409643555719E-09   .449256985120E-09   .492701119201E-09
+   .540346395304E-09   .592599072834E-09   .649904697324E-09   .712751899481E-09   .781676561607E-09
+   .857266386922E-09   .940165910744E-09   .103108199626E-08   .113078986176E-08   .124013969067E-08
+   .136006388088E-08   .149158499496E-08   .163582447931E-08   .179401222636E-08   .196749706150E-08
+   .215775824410E-08   .236641808073E-08   .259525575800E-08   .284622251315E-08   .312145827160E-08
+   .342330989341E-08   .375435118415E-08   .411740484085E-08   .451556652015E-08   .495223123388E-08
+   .543112229710E-08   .595632307537E-08   .653231180211E-08   .716399976270E-08   .785677317112E-08
+   .861653909591E-08   .944977582733E-08   .103635881149E-07   .113657677464E-07   .124648599851E-07
+   .136702364309E-07   .149921749275E-07   .164419471965E-07   .180319149456E-07   .197756352701E-07
+   .216879762465E-07   .237852437046E-07   .260853202572E-07   .286078177740E-07   .313742445997E-07
+   .344081889410E-07   .377355199868E-07   .413846084762E-07   .453865685942E-07   .497755232576E-07
+   .545888950534E-07   .598677253083E-07   .656570240118E-07   .720061535733E-07   .789692496869E-07
+   .866056828903E-07   .949805647527E-07   .104165303007E-06   .114238210358E-06   .125285172156E-06
+   .137400378627E-06   .150687127904E-06   .165258706696E-06   .181239356108E-06   .198765330846E-06
+   .217986060827E-06   .239065425093E-06   .262183148901E-06   .287536335873E-06   .315341148282E-06
+   .345834649782E-06   .379276826285E-06   .415952802208E-06   .456175270975E-06   .500287160473E-06
+   .548664556178E-06   .601719906856E-06   .659905540138E-06   .723717517926E-06   .793699864454E-06
+   .870449203038E-06   .954619840974E-06   .104692934592E-05   .114816466119E-05   .125918881213E-05
+   .138094826052E-05   .151448096978E-05   .166092524945E-05   .182152945441E-05   .199766262119E-05
+   .219082613202E-05   .240266650575E-05   .263498942452E-05   .288977511547E-05   .316919521817E-05
+   .347563128139E-05   .381169504631E-05   .418025068850E-05   .458443920787E-05   .502770517358E-05
+   .551382605126E-05   .604694436132E-05   .663160294162E-05   .727278361360E-05   .797594957989E-05
+   .874709191313E-05   .959278053002E-05   .105202200827E-04   .115373112411E-04   .126527178848E-04
+   .138759407737E-04   .152173983208E-04   .166885151495E-04   .183018191851E-04   .200710480995E-04
+   .220112660086E-04   .241389914067E-04   .264723374170E-04   .290311655386E-04   .318372541866E-04
+   .349144834412E-04   .382890375593E-04   .419896269494E-04   .460477314717E-04   .504978671021E-04
+   .553778781930E-04   .607292577733E-04   .665974985637E-04   .730324776330E-04   .800888778997E-04
+   .878266499827E-04   .963115182341E-04   .105615535150E-03   .115817688739E-03   .127004567873E-03
+   .139271091083E-03   .152721304811E-03   .167469257642E-03   .183639957684E-03   .201370420885E-03
+   .220810818827E-03   .242125735293E-03   .265495541759E-03   .291117902882E-03   .319209424064E-03
+   .350007454234E-03   .383772058207E-03   .420788174200E-03   .461367973515E-03   .505853440859E-03
+   .554619195399E-03   .608075574372E-03   .666672002964E-03   .730900676167E-03   .801300580500E-03
+   .878461885801E-03   .963030739774E-03   .105571450065E-02   .115728744609E-02   .126859699961E-02
+   .139057051878E-02   .152422269301E-02   .167066360224E-02   .183110749139E-02   .200688231964E-02
+   .219944014734E-02   .241036842756E-02   .264140227368E-02   .289443777849E-02   .317154646473E-02
+   .347499095116E-02   .380724192242E-02   .417099649460E-02   .456919807233E-02   .500505779584E-02
+   .548207767908E-02   .600407554123E-02   .657521183458E-02   .720001847052E-02   .788342974270E-02
+   .863081544150E-02   .944801624631E-02   .103413814717E-01   .113178092289E-01   .123847890445E-01
+   .135504469556E-01   .148235930674E-01   .162137715235E-01   .177313127914E-01   .193873881078E-01
+   .211940658628E-01   .231643696166E-01   .253123373476E-01   .276530814153E-01   .302028485860E-01
+   .329790793144E-01   .360004652887E-01   .392870040407E-01   .428600491781E-01   .467423545236E-01
+   .509581101325E-01   .555329678109E-01   .604940533623E-01   .658699623557E-01   .716907357267E-01
+   .779878109994E-01   .847939443514E-01   .921430981371E-01   .100070287856E+00   .108611381892E+00
+   .117802846704E+00   .127681429489E+00   .138283769765E+00   .149645930807E+00   .161802841458E+00
+   .174787638699E+00   .188630901364E+00   .203359765854E+00   .218996915541E+00   .235559437000E+00
+   .253057538386E+00   .271493128284E+00   .290858257492E+00   .311133431533E+00   .332285808498E+00
+   .354267305310E+00   .377012645768E+00   .400437396067E+00   .424436047836E+00   .448880225193E+00
+   .473617110680E+00   .498468204830E+00   .523228554987E+00   .547666609753E+00   .571524874772E+00
+   .594521561399E+00   .616353429614E+00   .636700026959E+00   .655229512189E+00   .671606220816E+00
+   .685500074200E+00   .696597848160E+00   .704616195033E+00   .709316148978E+00   .710518633960E+00
+   .708120235669E+00   .702108196066E+00   .692573251963E+00   .679718586782E+00   .663862829116E+00
+   .645434760298E+00   .624957251248E+00   .603018020672E+00   .580225195128E+00   .557146472407E+00
+   .534232062253E+00   .511723727271E+00   .489649347251E+00
+ ae wavefunction
+   .290743485819E-09   .317143897068E-09   .345696513897E-09   .376596061706E-09   .410053503810E-09
+   .446297517345E-09   .485576095754E-09   .528158289436E-09   .574336097020E-09   .624426521812E-09
+   .678773807256E-09   .737751869207E-09   .801766941832E-09   .871260457267E-09   .946712179993E-09
+   .102864361949E-08   .111762174616E-08   .121426303817E-08   .131923788978E-08   .143327541376E-08
+   .155716867362E-08   .169178038538E-08   .183804913156E-08   .199699613382E-08   .216973263581E-08
+   .235746795173E-08   .256151824163E-08   .278331608008E-08   .302442089063E-08   .328653032604E-08
+   .357149268056E-08   .388132042945E-08   .421820499937E-08   .458453288277E-08   .498290322035E-08
+   .541614698692E-08   .588734792837E-08   .639986541203E-08   .695735936673E-08   .756381750643E-08
+   .822358504830E-08   .894139715713E-08   .972241436815E-08   .105722612654E-07   .114970687172E-07
+   .125035200004E-07   .135989011741E-07   .147911560987E-07   .160889465331E-07   .175017177831E-07
+   .190397704183E-07   .207143386243E-07   .225376758091E-07   .245231481412E-07   .266853367605E-07
+   .290401494739E-07   .316049428207E-07   .343986554795E-07   .374419540785E-07   .407573925695E-07
+   .443695864372E-07   .483054031335E-07   .525941702583E-07   .572679031501E-07   .623615537075E-07
+   .679132824331E-07   .739647558784E-07   .805614718751E-07   .877531151595E-07   .955939462441E-07
+   .104143226658E-06   .113465683974E-06   .123632020348E-06   .134719468679E-06   .146812400837E-06
+   .160002992860E-06   .174391952486E-06   .190089314837E-06   .207215312697E-06   .225901328354E-06
+   .246290934683E-06   .268541033841E-06   .292823102738E-06   .319324555301E-06   .348250232482E-06
+   .379824032003E-06   .414290690940E-06   .451917735459E-06   .492997613377E-06   .537850026679E-06
+   .586824482702E-06   .640303084465E-06   .698703582493E-06   .762482712633E-06   .832139846545E-06
+   .908220984106E-06   .991323119623E-06   .108209901678E-05   .118126243036E-05   .128959381644E-05
+   .140794657652E-05   .153725388526E-05   .167853615607E-05   .183290920390E-05   .200159316982E-05
+   .218592227816E-05   .238735550324E-05   .260748823000E-05   .284806500036E-05   .311099344562E-05
+   .339835951445E-05   .371244411562E-05   .405574130608E-05   .443097816617E-05   .484113651706E-05
+   .528947664929E-05   .577956324666E-05   .631529370613E-05   .690092907261E-05   .754112782698E-05
+   .824098278699E-05   .900606140408E-05   .984244976391E-05   .107568006262E-04   .117563858685E-04
+   .128491537319E-04   .140437913000E-04   .153497926816E-04   .167775334086E-04   .183383516044E-04
+   .200446365268E-04   .219099251426E-04   .239490074451E-04   .261780412903E-04   .286146775910E-04
+   .312781967811E-04   .341896575397E-04   .373720588469E-04   .408505165352E-04   .446524555957E-04
+   .488078196053E-04   .533492987520E-04   .583125780574E-04   .637366075292E-04   .696638961115E-04
+   .761408314579E-04   .832180277112E-04   .909507036473E-04   .993990937307E-04   .108628894825E-03
+   .118711751517E-03   .129725783243E-03   .141756156651E-03   .154895706876E-03   .169245611725E-03
+   .184916122999E-03   .202027359557E-03   .220710167019E-03   .241107049363E-03   .263373178060E-03
+   .287677484765E-03   .314203844005E-03   .343152352743E-03   .374740714148E-03   .409205733387E-03
+   .446804933753E-03   .487818301955E-03   .532550171967E-03   .581331257351E-03   .634520842600E-03
+   .692509144588E-03   .755719855875E-03   .824612882200E-03   .899687287136E-03   .981484457526E-03
+   .107059150392E-02   .116764491093E-02   .127333445284E-02   .138840739083E-02   .151367296803E-02
+   .165000722004E-02   .179835811811E-02   .195975106338E-02   .213529475035E-02   .232618741831E-02
+   .253372350955E-02   .275930075293E-02   .300442769177E-02   .327073167412E-02   .355996732338E-02
+   .387402550635E-02   .421494281475E-02   .458491157517E-02   .498629040056E-02   .542161529468E-02
+   .589361131832E-02   .640520482362E-02   .695953625921E-02   .755997354550E-02   .821012601470E-02
+   .891385890548E-02   .967530839642E-02   .104988971560E-01   .113893503798E-01   .123517122780E-01
+   .133913629666E-01   .145140357074E-01   .157258344298E-01   .170332514579E-01   .184431853516E-01
+   .199629587596E-01   .216003361669E-01   .233635414050E-01   .252612747781E-01   .273027296432E-01
+   .294976082666E-01   .318561367616E-01   .343890788983E-01   .371077485559E-01   .400240205661E-01
+   .431503396707E-01   .464997272749E-01   .500857856277E-01   .539226989877E-01   .580252312402E-01
+   .624087193290E-01   .670890617600E-01   .720827013619E-01   .774066014717E-01   .830782147809E-01
+   .891154442440E-01   .955365956824E-01   .102360321993E+00   .109605559121E+00   .117291454119E+00
+   .125437285657E+00   .134062377145E+00   .143186002351E+00   .152827282935E+00   .163005077066E+00
+   .173737858217E+00   .185043583407E+00   .196939550508E+00   .209442244520E+00   .222567172946E+00
+   .236328690508E+00   .250739813497E+00   .265812024137E+00   .281555065455E+00   .297976727368E+00
+   .315082624926E+00   .332875969998E+00   .351357338011E+00   .370524431759E+00   .390371844702E+00
+   .410890826577E+00   .432069054598E+00   .453890413872E+00   .476334791012E+00   .499377885186E+00
+   .522991040910E+00   .547141106879E+00   .571790324880E+00   .596896252515E+00   .622411723141E+00
+   .648284846420E+00   .674459053632E+00   .700873193916E+00   .727461691493E+00   .754154779677E+00
+   .780878833872E+00   .807556828724E+00   .834108935642E+00   .860453241997E+00   .886506498342E+00
+   .912184686644E+00   .937403096565E+00   .962075607669E+00   .986113129009E+00   .100942167305E+01
+   .103190111914E+01   .105344583503E+01   .107394748658E+01   .109329897818E+01   .111139787717E+01
+   .112814845292E+01   .114346256216E+01   .115726003097E+01   .116946900803E+01   .118002646526E+01
+   .118887883071E+01   .119598265524E+01   .120130520305E+01   .120482487873E+01   .120653144211E+01
+   .120642599701E+01   .120452076569E+01   .120083867497E+01   .119541278593E+01   .118828559996E+01
+   .117950827172E+01   .116913975771E+01   .115724592526E+01   .114389864413E+01   .112917487960E+01
+   .111315580232E+01   .109592592756E+01   .107757229220E+01   .105818367577E+01   .103784986853E+01
+   .101666098759E+01   .994706840706E+00   .972076336857E+00   .948856942356E+00   .925134183565E+00
+   .900991194335E+00   .876508243864E+00   .851762198539E+00   .826826466725E+00   .801770802990E+00
+   .776661134097E+00   .751559437481E+00   .726523663051E+00   .701607692403E+00   .676861325222E+00
+   .652330285754E+00   .628056245620E+00   .604076865344E+00   .580425862344E+00   .557133116999E+00
+   .534224828349E+00   .511723727271E+00   .489649347251E+00
+  -.115024817686E-12  -.126147972514E-12  -.138346761064E-12  -.151725199501E-12  -.166397362583E-12
+  -.182488356349E-12  -.200135384869E-12  -.219488920152E-12  -.240713985181E-12  -.263991561027E-12
+  -.289520130034E-12  -.317517368226E-12  -.348222001378E-12  -.381895840580E-12  -.418826014631E-12
+  -.459327418321E-12  -.503745397463E-12  -.552458693572E-12  -.605882673307E-12  -.664472870201E-12
+  -.728728868887E-12  -.799198564935E-12  -.876482836627E-12  -.961240668506E-12  -.105419477037E-11
+  -.115613773966E-11  -.126793881972E-11  -.139055131167E-11  -.152502070293E-11  -.167249358188E-11
+  -.183422741450E-11  -.201160126653E-11  -.220612756238E-11  -.241946498124E-11  -.265343260025E-11
+  -.291002540528E-11  -.319143130175E-11  -.350004977033E-11  -.383851232675E-11  -.420970496008E-11
+  -.461679274090E-11  -.506324680901E-11  -.555287397107E-11  -.608984916029E-11  -.667875103504E-11
+  -.732460101997E-11  -.803290612249E-11  -.880970588962E-11  -.966162390577E-11  -.105959242704E-10
+  -.116205735372E-10  -.127443086428E-10  -.139767114049E-10  -.153282902233E-10  -.168105696831E-10
+  -.184361888218E-10  -.202190088987E-10  -.221742315872E-10  -.243185285949E-10  -.266701838194E-10
+  -.292492492504E-10  -.320777159478E-10  -.351797015540E-10  -.385816559385E-10  -.423125867296E-10
+  -.464043066543E-10  -.508917047976E-10  -.558130440921E-10  -.612102875766E-10  -.671294562027E-10
+  -.736210212441E-10  -.807403346510E-10  -.885481010212E-10  -.971108952116E-10  -.106501730004E-09
+  -.116800678662E-09  -.128095557700E-09  -.140482675660E-09  -.154067654316E-09  -.168966329272E-09
+  -.185305737667E-09  -.203225201373E-09  -.222877514961E-09  -.244430248524E-09  -.268067176501E-09
+  -.293989844664E-09  -.322419288632E-09  -.353597918571E-09  -.387791586146E-09  -.425291851348E-09
+  -.466418468530E-09  -.511522112835E-09  -.560987370284E-09  -.615236016997E-09  -.674730615526E-09
+  -.739978458947E-09  -.811535896356E-09  -.890013076630E-09  -.976079150923E-09  -.107046797824E-08
+  -.117398438272E-08  -.128751101605E-08  -.141201588341E-08  -.154856059719E-08  -.169830942887E-08
+  -.186253923618E-08  -.204265035018E-08  -.224017851518E-08  -.245680798315E-08  -.269438587439E-08
+  -.295493792683E-08  -.324068576823E-08  -.355406585863E-08  -.389775026436E-08  -.427466944097E-08
+  -.468803721905E-08  -.514137820620E-08  -.563855783857E-08  -.618381533829E-08  -.678179985765E-08
+  -.743761011835E-08  -.815683788344E-08  -.894561563284E-08  -.981066884872E-08  -.107593733564E-07
+  -.117998182097E-07  -.129408746568E-07  -.141922717740E-07  -.155646794131E-07  -.170697991684E-07
+  -.187204641394E-07  -.205307483385E-07  -.225160866779E-07  -.246934065569E-07  -.270812721711E-07
+  -.297000427748E-07  -.325720462432E-07  -.357217694156E-07  -.391760668399E-07  -.429643896985E-07
+  -.471190368653E-07  -.516754302330E-07  -.566724166578E-07  -.621525990919E-07  -.681626997262E-07
+  -.747539582371E-07  -.819825685281E-07  -.899101576875E-07  -.986043112420E-07  -.108139149178E-06
+  -.118595957636E-06  -.130063881660E-06  -.142640684899E-06  -.156433582720E-06  -.171560155842E-06
+  -.188149352256E-06  -.206342585953E-06  -.226294941825E-06  -.248176496985E-06  -.272173769741E-06
+  -.298491308559E-06  -.327353434527E-06  -.359006152135E-06  -.393719244620E-06  -.431788571691E-06
+  -.473538589157E-06  -.519325111873E-06  -.569538343480E-06  -.624606198666E-06  -.684997946162E-06
+  -.751228203410E-06  -.823861316786E-06  -.903516164566E-06  -.990871423355E-06  -.108667134264E-05
+  -.119173207641E-05  -.130694862551E-05  -.143330244947E-05  -.157186981235E-05  -.172383093308E-05
+  -.189048001783E-05  -.207323625911E-05  -.227365589463E-05  -.249344542759E-05  -.273447612010E-05
+  -.299879988193E-05  -.328866668840E-05  -.360654367409E-05  -.395513606315E-05  -.433741011199E-05
+  -.475661825708E-05  -.521632667896E-05  -.572044551339E-05  -.627326196261E-05  -.687947658362E-05
+  -.754424305661E-05  -.827321176515E-05  -.907257755121E-05  -.994913204215E-05  -.109103209842E-04
+  -.119643070573E-04  -.131200386919E-04  -.143873254547E-04  -.157769206255E-04  -.173006116437E-04
+  -.189713191662E-04  -.208032055473E-04  -.228117936253E-04  -.250140967825E-04  -.274287613336E-04
+  -.300762223919E-04  -.329788744710E-04  -.361612581885E-04  -.396502645652E-04  -.434753585441E-04
+  -.476688235002E-04  -.522660286667E-04  -.573057215736E-04  -.628303477782E-04  -.688864003618E-04
+  -.755248018823E-04  -.828013216993E-04  -.907770318344E-04  -.995188047931E-04  -.109099857056E-03
+  -.119600342251E-03  -.131107998331E-03  -.143718853439E-03  -.157537995485E-03  -.172680410852E-03
+  -.189271898050E-03  -.207450062557E-03  -.227365399519E-03  -.249182471450E-03  -.273081188516E-03
+  -.299258199503E-03  -.327928402002E-03  -.359326580881E-03  -.393709184535E-03  -.431356248901E-03
+  -.472573479626E-03  -.517694503164E-03  -.567083297909E-03  -.621136816689E-03  -.680287812094E-03
+  -.745007876110E-03  -.815810705319E-03  -.893255602580E-03  -.977951225406E-03  -.107055959029E-02
+  -.117180034084E-02  -.128245528581E-02  -.140337321050E-02  -.153547496226E-02  -.167975880643E-02
+  -.183730604491E-02  -.200928688277E-02  -.219696652183E-02  -.240171145092E-02  -.262499589203E-02
+  -.286840834930E-02  -.313365819231E-02  -.342258218807E-02  -.373715087498E-02  -.407947464775E-02
+  -.445180939425E-02  -.485656149206E-02  -.529629193474E-02  -.577371931430E-02  -.629172133609E-02
+  -.685333448561E-02  -.746175140207E-02  -.812031544059E-02  -.883251182304E-02  -.960195468639E-02
+  -.104323692360E-01  -.113275681005E-01  -.122914208620E-01  -.133278156070E-01  -.144406111995E-01
+  -.156335788330E-01  -.169103312636E-01  -.182742379703E-01  -.197283243365E-01  -.212751527996E-01
+  -.229166837848E-01  -.246541141334E-01  -.264876906654E-01  -.284164964990E-01  -.304382077973E-01
+  -.325488187558E-01  -.347423328977E-01  -.370104191424E-01  -.393420316919E-01  -.417229935617E-01
+  -.441355446255E-01  -.465578563703E-01  -.489635172149E-01  -.513209942727E-01  -.535930798516E-01
+  -.557363338093E-01  -.577005361042E-01  -.594281674639E-01  -.608539399648E-01  -.619044033251E-01
+  -.624976566740E-01  -.625431991573E-01  -.619419555915E-01  -.605865149428E-01  -.583616190453E-01
+  -.551449358758E-01  -.508081449632E-01  -.452183511122E-01  -.382398255350E-01  -.297360497715E-01
+  -.195720067557E-01  -.761662489501E-02   .625476423899E-02   .221581440620E-01   .401989474129E-01
+   .604708933112E-01   .830558427613E-01   .108024992762E+00   .135441684220E+00   .165365988074E+00
+   .197861028819E+00   .233000678054E+00   .270877776313E+00   .311611400169E+00   .355350880102E+00
+   .402273317153E+00   .452572056849E+00   .506475668526E+00
+ ae wavefunction
+  -.793425873260E-10  -.865471479238E-10  -.943390360067E-10  -.102771391331E-09  -.111901784912E-09
+  -.121792621793E-09  -.132511578357E-09  -.144132077341E-09  -.156733803962E-09  -.170403267110E-09
+  -.185234409396E-09  -.201329270910E-09  -.218798711279E-09  -.237763195512E-09  -.258353649360E-09
+  -.280712390615E-09  -.304994143172E-09  -.331367141393E-09  -.360014333132E-09  -.391134690282E-09
+  -.424944636644E-09  -.461679603910E-09  -.501595727438E-09  -.544971694479E-09  -.592110758930E-09
+  -.643342937762E-09  -.699027405748E-09  -.759555106735E-09  -.825351601160E-09  -.896880171670E-09
+  -.974645210393E-09  -.105919591381E-08  -.115113031357E-08  -.125109967399E-08  -.135981329030E-08
+  -.147804372437E-08  -.160663251831E-08  -.174649643029E-08  -.189863424056E-08  -.206413418069E-08
+  -.224418204351E-08  -.244007003710E-08  -.265320645152E-08  -.288512621399E-08  -.313750241483E-08
+  -.341215889459E-08  -.371108399080E-08  -.403644555254E-08  -.439060734073E-08  -.477614694328E-08
+  -.519587534649E-08  -.565285831697E-08  -.615043976336E-08  -.669226726252E-08  -.728231995262E-08
+  -.792493901427E-08  -.862486098190E-08  -.938725414994E-08  -.102177583640E-07  -.111225285133E-07
+  -.121082820719E-07  -.131823510676E-07  -.143527388935E-07  -.156281824168E-07  -.170182198814E-07
+  -.185332651474E-07  -.201846888631E-07  -.219849072189E-07  -.239474789966E-07  -.260872116906E-07
+  -.284202775546E-07  -.309643405053E-07  -.337386949024E-07  -.367644173208E-07  -.400645325344E-07
+  -.436641950472E-07  -.475908876317E-07  -.518746384701E-07  -.565482586491E-07  -.616476019138E-07
+  -.672118487760E-07  -.732838172594E-07  -.799103027837E-07  -.871424499212E-07  -.950361590146E-07
+  -.103652530929E-06  -.113058353508E-06  -.123326633657E-06  -.134537179300E-06  -.146777235924E-06
+  -.160142182782E-06  -.174736294361E-06  -.190673573217E-06  -.208078660848E-06  -.227087833900E-06
+  -.247850093671E-06  -.270528357641E-06  -.295300762527E-06  -.322362089272E-06  -.351925321330E-06
+  -.384223348660E-06  -.419510830983E-06  -.458066235113E-06  -.500194062537E-06  -.546227284892E-06
+  -.596530006640E-06  -.651500375966E-06  -.711573766904E-06  -.777226257754E-06  -.848978433161E-06
+  -.927399539739E-06  -.101311202780E-05  -.110679651477E-05  -.120919720899E-05  -.132112783633E-05
+  -.144347811553E-05  -.157722083265E-05  -.172341956943E-05  -.188323714515E-05  -.205794483718E-05
+  -.224893245095E-05  -.245771931669E-05  -.268596629680E-05  -.293548889557E-05  -.320827157073E-05
+  -.350648335520E-05  -.383249490714E-05  -.418889711642E-05  -.457852140704E-05  -.500446188727E-05
+  -.547009951214E-05  -.597912843751E-05  -.653558476023E-05  -.714387785553E-05  -.780882454104E-05
+  -.853568631627E-05  -.933020994738E-05  -.101986716901E-04  -.111479254681E-04  -.121854553504E-04
+  -.133194327011E-04  -.145587784031E-04  -.159132305948E-04  -.173934183887E-04  -.190109420857E-04
+  -.207784604344E-04  -.227097855329E-04  -.248199860161E-04  -.271254992228E-04  -.296442530920E-04
+  -.323957985956E-04  -.354014535762E-04  -.386844589277E-04  -.422701481236E-04  -.461861311778E-04
+  -.504624941989E-04  -.551320157878E-04  -.602304016163E-04  -.657965386221E-04  -.718727703574E-04
+  -.785051951327E-04  -.857439887140E-04  -.936437534481E-04  -.102263895816E-03  -.111669034543E-03
+  -.121929441540E-03  -.133121518071E-03  -.145328308720E-03  -.158640055856E-03  -.173154797466E-03
+  -.188979011387E-03  -.206228309132E-03  -.225028182677E-03  -.245514807736E-03  -.267835907242E-03
+  -.292151678903E-03  -.318635790890E-03  -.347476449864E-03  -.378877545726E-03  -.413059877605E-03
+  -.450262465761E-03  -.490743954206E-03  -.534784108930E-03  -.582685416752E-03  -.634774789838E-03
+  -.691405380995E-03  -.752958514826E-03  -.819845739801E-03  -.892511006202E-03  -.971432974765E-03
+  -.105712746062E-02  -.115015001685E-02  -.125109866171E-02  -.136061675292E-02  -.147939601211E-02
+  -.160817970176E-02  -.174776595612E-02  -.189901126681E-02  -.206283412270E-02  -.224021880246E-02
+  -.243221931678E-02  -.263996349572E-02  -.286465721484E-02  -.310758875184E-02  -.337013326325E-02
+  -.365375736811E-02  -.396002382319E-02  -.429059627106E-02  -.464724403941E-02  -.503184696634E-02
+  -.544640022279E-02  -.589301909952E-02  -.637394372157E-02  -.689154364948E-02  -.744832232159E-02
+  -.804692128790E-02  -.869012418099E-02  -.938086036513E-02  -.101222081993E-01  -.109173978436E-01
+  -.117698135315E-01  -.126829952184E-01  -.136606395034E-01  -.147065997006E-01  -.158248849119E-01
+  -.170196579228E-01  -.182952317151E-01  -.196560643713E-01  -.211067521363E-01  -.226520204261E-01
+  -.242967126117E-01  -.260457764751E-01  -.279042483036E-01  -.298772346602E-01  -.319698919109E-01
+  -.341874035956E-01  -.365349556857E-01  -.390177096769E-01  -.416407733564E-01  -.444091690028E-01
+  -.473277987596E-01  -.504014069732E-01  -.536345393756E-01  -.570314990740E-01  -.605962993673E-01
+  -.643326134413E-01  -.682437210063E-01  -.723324519661E-01  -.766011272360E-01  -.810514968867E-01
+  -.856846758554E-01  -.905010775570E-01  -.955003458199E-01  -.100681285679E+00  -.106041793667E+00
+  -.111578788369E+00  -.117288142102E+00  -.123164614704E+00  -.129201790505E+00  -.135392019612E+00
+  -.141726364675E+00  -.148194554291E+00  -.154784944129E+00  -.161484486785E+00  -.168278711279E+00
+  -.175151713115E+00  -.182086156000E+00  -.189063286903E+00  -.196062967129E+00  -.203063723654E+00
+  -.210042826631E+00  -.216976399744E+00  -.223839567594E+00  -.230606634889E+00  -.237251271923E+00
+  -.243746651182E+00  -.250065451183E+00  -.256179648389E+00  -.262060086160E+00  -.267675950268E+00
+  -.272994432823E+00  -.277980892975E+00  -.282599596502E+00  -.286814748291E+00  -.290591379954E+00
+  -.293895865125E+00  -.296696126843E+00  -.298961710112E+00  -.300663844074E+00  -.301775538747E+00
+  -.302271710613E+00  -.302129310013E+00  -.301327420640E+00  -.299847307998E+00  -.297672403982E+00
+  -.294788224056E+00  -.291182220151E+00  -.286843575994E+00  -.281762952982E+00  -.275932194803E+00
+  -.269343998208E+00  -.261991556747E+00  -.253868182995E+00  -.244966913986E+00  -.235280103403E+00
+  -.224799002988E+00  -.213513334624E+00  -.201410853345E+00  -.188476900630E+00  -.174693946475E+00
+  -.160041117947E+00  -.144493711493E+00  -.128022685923E+00  -.110594132690E+00  -.921687201889E-01
+  -.727011079426E-01  -.521393220615E-01  -.304240892160E-01  -.748815996157E-02   .167444424032E-01
+   .423592401365E-01   .694521929757E-01   .981306776901E-01   .128514568402E+00   .160737432060E+00
+   .194947854059E+00   .231310910554E+00   .270009807749E+00   .311247715232E+00   .355249830896E+00
+   .402265728751E+00   .452572056849E+00   .506475668526E+00
+   .625772735697E-05   .645326567785E-05   .665491408254E-05   .686286349594E-05   .707731080888E-05
+   .729845906456E-05   .752651765076E-05   .776170249814E-05   .800423628464E-05   .825434864636E-05
+   .851227639495E-05   .877826374187E-05   .905256252956E-05   .933543246996E-05   .962714139035E-05
+   .992796548698E-05   .102381895866E-04   .105581074159E-04   .108880218803E-04   .112282453497E-04
+   .115790999552E-04   .119409178936E-04   .123140417421E-04   .126988247827E-04   .130956313364E-04
+   .135048371085E-04   .139268295443E-04   .143620081958E-04   .148107851001E-04   .152735851693E-04
+   .157508465933E-04   .162430212543E-04   .167505751549E-04   .172739888591E-04   .178137579474E-04
+   .183703934864E-04   .189444225121E-04   .195363885292E-04   .201468520261E-04   .207763910049E-04
+   .214256015291E-04   .220950982882E-04   .227855151792E-04   .234975059071E-04   .242317446040E-04
+   .249889264672E-04   .257697684176E-04   .265750097786E-04   .274054129758E-04   .282617642595E-04
+   .291448744488E-04   .300555796994E-04   .309947422955E-04   .319632514663E-04   .329620242280E-04
+   .339920062521E-04   .350541727610E-04   .361495294513E-04   .372791134464E-04   .384439942785E-04
+   .396452749014E-04   .408840927348E-04   .421616207419E-04   .434790685398E-04   .448376835451E-04
+   .462387521554E-04   .476836009672E-04   .491735980329E-04   .507101541557E-04   .522947242264E-04
+   .539288086007E-04   .556139545209E-04   .573517575809E-04   .591438632374E-04   .609919683690E-04
+   .628978228828E-04   .648632313724E-04   .668900548272E-04   .689802123955E-04   .711356832020E-04
+   .733585082232E-04   .756507922207E-04   .780147057355E-04   .804524871442E-04   .829664447801E-04
+   .855589591204E-04   .882324850415E-04   .909895541458E-04   .938327771607E-04   .967648464124E-04
+   .997885383786E-04   .102906716319E-03   .106122332991E-03   .109438433447E-03   .112858157922E-03
+   .116384744812E-03   .120021533743E-03   .123771968741E-03   .127639601493E-03   .131628094721E-03
+   .135741225654E-03   .139982889612E-03   .144357103702E-03   .148868010631E-03   .153519882635E-03
+   .158317125539E-03   .163264282935E-03   .168366040501E-03   .173627230448E-03   .179052836111E-03
+   .184647996685E-03   .190418012109E-03   .196368348100E-03   .202504641357E-03   .208832704913E-03
+   .215358533675E-03   .222088310120E-03   .229028410183E-03   .236185409333E-03   .243566088830E-03
+   .251177442189E-03   .259026681851E-03   .267121246057E-03   .275468805946E-03   .284077272883E-03
+   .292954806009E-03   .302109820042E-03   .311550993325E-03   .321287276125E-03   .331327899207E-03
+   .341682382675E-03   .352360545103E-03   .363372512956E-03   .374728730316E-03   .386439968922E-03
+   .398517338532E-03   .410972297629E-03   .423816664465E-03   .437062628472E-03   .450722762040E-03
+   .464810032688E-03   .479337815626E-03   .494319906740E-03   .509770535995E-03   .525704381295E-03
+   .542136582792E-03   .559082757684E-03   .576559015498E-03   .594581973896E-03   .613168775014E-03
+   .632337102351E-03   .652105198239E-03   .672491881913E-03   .693516568201E-03   .715199286862E-03
+   .737560702606E-03   .760622135803E-03   .784405583942E-03   .808933743834E-03   .834230034628E-03
+   .860318621647E-03   .887224441095E-03   .914973225669E-03   .943591531123E-03   .973106763821E-03
+   .100354720932E-02   .103494206207E-02   .106732145620E-02   .110071649756E-02   .113515929699E-02
+   .117068300491E-02   .120732184730E-02   .124511116316E-02   .128408744347E-02   .132428837183E-02
+   .136575286679E-02   .140852112593E-02   .145263467200E-02   .149813640093E-02   .154507063211E-02
+   .159348316083E-02   .164342131327E-02   .169493400394E-02   .174807179591E-02   .180288696392E-02
+   .185943356061E-02   .191776748599E-02   .197794656049E-02   .204003060177E-02   .210408150546E-02
+   .217016333033E-02   .223834238796E-02   .230868733740E-02   .238126928511E-02   .245616189060E-02
+   .253344147815E-02   .261318715518E-02   .269548093758E-02   .278040788276E-02   .286805623092E-02
+   .295851755505E-02   .305188692069E-02   .314826305588E-02   .324774853234E-02   .335044995873E-02
+   .345647818699E-02   .356594853279E-02   .367898101141E-02   .379570059017E-02   .391623745893E-02
+   .404072732016E-02   .416931170024E-02   .430213828382E-02   .443936127327E-02   .458114177536E-02
+   .472764821751E-02   .487905679631E-02   .503555196100E-02   .519732693519E-02   .536458427994E-02
+   .553753650208E-02   .571640671181E-02   .590142933372E-02   .609285087632E-02   .629093076510E-02
+   .649594224493E-02   .670817335797E-02   .692792800381E-02   .715552708950E-02   .739130977715E-02
+   .763563483824E-02   .788888212406E-02   .815145416278E-02   .842377789447E-02   .870630655655E-02
+   .899952173314E-02   .930393558286E-02   .962009326133E-02   .994857555532E-02   .102900017478E-01
+   .106450327341E-01   .110143744114E-01   .113987813659E-01   .117990608833E-01   .122160773114E-01
+   .126507568049E-01   .131040924858E-01   .135771500545E-01   .140710738912E-01   .145870936874E-01
+   .151265316539E-01   .156908103509E-01   .162814611940E-01   .169001336887E-01   .175486054538E-01
+   .182287930948E-01   .189427639942E-01   .196927490897E-01   .204811567131E-01   .213105875692E-01
+   .221838509373E-01   .231039821785E-01   .240742616403E-01   .250982350482E-01   .261797354786E-01
+   .273229070081E-01   .285322301340E-01   .298125490600E-01   .311691009400E-01   .326075471638E-01
+   .341340067677E-01   .357550920368E-01   .374779463548E-01   .393102843411E-01   .412604342871E-01
+   .433373828783E-01   .455508221532E-01   .479111986014E-01   .504297642563E-01   .531186295663E-01
+   .559908177567E-01   .590603202985E-01   .623421529954E-01   .658524120695E-01   .696083294813E-01
+   .736283265435E-01   .779320646933E-01   .825404920560E-01   .874758841736E-01   .927618769764E-01
+   .984234897415E-01   .104487135408E+00   .110980615202E+00   .117933094068E+00   .125375052899E+00
+   .133338213009E+00   .141855427725E+00   .150960535346E+00   .160688167090E+00   .171073503010E+00
+   .182151968232E+00   .193958861263E+00   .206528905622E+00   .219895715629E+00   .234091166967E+00
+   .249144662640E+00   .265082285310E+00   .281925827730E+00   .299691694348E+00   .318389669129E+00
+   .338021547516E+00   .358579634352E+00   .380045114679E+00   .402386310933E+00   .425556848283E+00
+   .449493760001E+00   .474115576936E+00   .499320459646E+00   .524984448450E+00   .550959925690E+00
+   .577074405542E+00   .603129789335E+00   .628902247863E+00   .654142915249E+00   .678579600126E+00
+   .701919736667E+00   .723854807596E+00   .744066469725E+00   .762228534470E+00   .778123726362E+00
+   .791684451361E+00   .802878609667E+00   .811684745620E+00
+ ae wavefunction
+  -.899198353841E-03  -.926712521187E-03  -.955066450255E-03  -.984285638958E-03  -.101439635132E-02
+  -.104542563998E-02  -.107740136938E-02  -.111035223955E-02  -.114430781055E-02  -.117929852763E-02
+  -.121535574704E-02  -.125251176256E-02  -.129079983278E-02  -.133025420905E-02  -.137091016429E-02
+  -.141280402248E-02  -.145597318897E-02  -.150045618161E-02  -.154629266272E-02  -.159352347183E-02
+  -.164219065935E-02  -.169233752109E-02  -.174400863366E-02  -.179724989080E-02  -.185210854063E-02
+  -.190863322383E-02  -.196687401281E-02  -.202688245183E-02  -.208871159815E-02  -.215241606412E-02
+  -.221805206039E-02  -.228567744012E-02  -.235535174418E-02  -.242713624757E-02  -.250109400678E-02
+  -.257728990833E-02  -.265579071839E-02  -.273666513352E-02  -.281998383256E-02  -.290581952963E-02
+  -.299424702829E-02  -.308534327685E-02  -.317918742486E-02  -.327586088067E-02  -.337544737027E-02
+  -.347803299720E-02  -.358370630361E-02  -.369255833253E-02  -.380468269119E-02  -.392017561554E-02
+  -.403913603582E-02  -.416166564322E-02  -.428786895766E-02  -.441785339653E-02  -.455172934446E-02
+  -.468961022412E-02  -.483161256783E-02  -.497785609014E-02  -.512846376124E-02  -.528356188103E-02
+  -.544328015406E-02  -.560775176491E-02  -.577711345430E-02  -.595150559549E-02  -.613107227119E-02
+  -.631596135059E-02  -.650632456660E-02  -.670231759308E-02  -.690410012192E-02  -.711183593981E-02
+  -.732569300460E-02  -.754584352100E-02  -.777246401539E-02  -.800573540968E-02  -.824584309382E-02
+  -.849297699682E-02  -.874733165594E-02  -.900910628387E-02  -.927850483344E-02  -.955573605970E-02
+  -.984101357881E-02  -.101345559236E-01  -.104365865952E-01  -.107473341103E-01  -.110670320437E-01
+  -.113959190656E-01  -.117342389731E-01  -.120822407151E-01  -.124401784105E-01  -.128083113584E-01
+  -.131869040403E-01  -.135762261130E-01  -.139765523913E-01  -.143881628210E-01  -.148113424389E-01
+  -.152463813215E-01  -.156935745191E-01  -.161532219760E-01  -.166256284347E-01  -.171111033226E-01
+  -.176099606218E-01  -.181225187176E-01  -.186491002274E-01  -.191900318064E-01  -.197456439295E-01
+  -.203162706469E-01  -.209022493132E-01  -.215039202859E-01  -.221216265937E-01  -.227557135704E-01
+  -.234065284540E-01  -.240744199475E-01  -.247597377397E-01  -.254628319830E-01  -.261840527262E-01
+  -.269237492988E-01  -.276822696445E-01  -.284599596010E-01  -.292571621217E-01  -.300742164383E-01
+  -.309114571583E-01  -.317692132962E-01  -.326478072329E-01  -.335475536006E-01  -.344687580886E-01
+  -.354117161665E-01  -.363767117199E-01  -.373640155947E-01  -.383738840454E-01  -.394065570825E-01
+  -.404622567149E-01  -.415411850820E-01  -.426435224698E-01  -.437694252084E-01  -.449190234428E-01
+  -.460924187738E-01  -.472896817634E-01  -.485108492991E-01  -.497559218126E-01  -.510248603468E-01
+  -.523175834670E-01  -.536339640107E-01  -.549738256715E-01  -.563369394121E-01  -.577230197024E-01
+  -.591317205784E-01  -.605626315184E-01  -.620152731321E-01  -.634890926619E-01  -.649834592915E-01
+  -.664976592625E-01  -.680308907969E-01  -.695822588252E-01  -.711507695225E-01  -.727353246532E-01
+  -.743347157283E-01  -.759476179799E-01  -.775725841588E-01  -.792080381632E-01  -.808522685079E-01
+  -.825034216460E-01  -.841594951571E-01  -.858183308173E-01  -.874776075715E-01  -.891348344283E-01
+  -.907873433036E-01  -.924322818408E-01  -.940666062386E-01  -.956870741239E-01  -.972902375081E-01
+  -.988724358728E-01  -.100429789432E+00  -.101958192628E+00  -.103453307915E+00  -.104910559905E+00
+  -.106325129937E+00  -.107691951151E+00  -.109005704157E+00  -.110260813372E+00  -.111451444148E+00
+  -.112571500771E+00  -.113614625463E+00  -.114574198488E+00  -.115443339510E+00  -.116214910326E+00
+  -.116881519111E+00  -.117435526347E+00  -.117869052568E+00  -.118173988109E+00  -.118342005016E+00
+  -.118364571301E+00  -.118232967726E+00  -.117938307303E+00  -.117471557703E+00  -.116823566767E+00
+  -.115985091322E+00  -.114946829481E+00  -.113699456641E+00  -.112233665352E+00  -.110540209243E+00
+  -.108609951173E+00  -.106433915777E+00  -.104003346530E+00  -.101309767468E+00  -.983450496627E-01
+  -.951014825035E-01  -.915718498506E-01  -.877495110385E-01  -.836284866986E-01  -.792035493055E-01
+  -.744703183056E-01  -.694253596226E-01  -.640662892686E-01  -.583918807179E-01  -.524021756178E-01
+  -.460985973220E-01  -.394840666358E-01  -.325631190565E-01  -.253420226800E-01  -.178288958309E-01
+  -.100338233555E-01  -.196897041846E-02   .635130744433E-02   .149103593094E-01   .236891401895E-01
+   .326661199705E-01   .418172011875E-01   .511156468463E-01   .605320195557E-01   .700341334354E-01
+   .795870206160E-01   .891529146265E-01   .986912534872E-01   .108158705783E+00   .117509223245E+00
+   .126694123353E+00   .135662205068E+00   .144359900124E+00   .152731461502E+00   .160719189968E+00
+   .168263699159E+00   .175304219540E+00   .181778941558E+00   .187625398180E+00   .192780886798E+00
+   .197182929987E+00   .200769774111E+00   .203480924170E+00   .205257712737E+00   .206043900277E+00
+   .205786303570E+00   .204435448392E+00   .201946241992E+00   .198278660211E+00   .193398443402E+00
+   .187277794549E+00   .179896072185E+00   .171240469898E+00   .161306673423E+00   .150099485504E+00
+   .137633408003E+00   .123933170145E+00   .109034191331E+00   .929829668192E-01   .758373646553E-01
+   .576668227067E-01   .385524353540E-01   .185869202081E-01  -.212554413693E-02  -.234696182120E-01
+  -.453192492185E-01  -.675382767194E-01  -.899812070739E-01  -.112494161913E+00  -.134915989271E+00
+  -.157079492842E+00  -.178812690457E+00  -.199939984140E+00  -.220283157880E+00  -.239662251068E+00
+  -.257896552174E+00  -.274806070475E+00  -.290213681412E+00  -.303947738052E+00  -.315844675777E+00
+  -.325751270780E+00  -.333526519703E+00  -.339043268157E+00  -.342189698293E+00  -.342870710681E+00
+  -.341009178987E+00  -.336547029506E+00  -.329446094635E+00  -.319688700478E+00  -.307277966505E+00
+  -.292237812734E+00  -.274612683925E+00  -.254467009937E+00  -.231884427155E+00  -.206966789220E+00
+  -.179832996494E+00  -.150617674278E+00  -.119469728937E+00  -.865508100911E-01  -.520337052407E-01
+  -.161006912205E-01   .210581352729E-01   .592465279993E-01   .982637441706E-01   .137906163704E+00
+   .177968859678E+00   .218247106128E+00   .258537810450E+00   .298640858779E+00   .338360364663E+00
+   .377505812321E+00   .415893058901E+00   .453345157081E+00   .489693249528E+00   .524777291749E+00
+   .558446658714E+00   .590560659113E+00   .620988954824E+00   .649611890536E+00   .676320732406E+00
+   .701017815151E+00   .723616599449E+00   .744041647225E+00   .762228534470E+00   .778123726362E+00
+ pseudo wavefunction
+   .332758200799E-05   .343156061717E-05   .353878829783E-05   .364936657534E-05   .376340014751E-05
+   .388099698366E-05   .400226842691E-05   .412732929958E-05   .425629801189E-05   .438929667409E-05
+   .452645121207E-05   .466789148661E-05   .481375141630E-05   .496416910438E-05   .511928696945E-05
+   .527925188036E-05   .544421529525E-05   .561433340495E-05   .578976728087E-05   .597068302753E-05
+   .615725193979E-05   .634965066505E-05   .654806137055E-05   .675267191578E-05   .696367603039E-05
+   .718127349764E-05   .740567034351E-05   .763707903181E-05   .787571866534E-05   .812181519332E-05
+   .837560162537E-05   .863731825210E-05   .890721287263E-05   .918554102923E-05   .947256624926E-05
+   .976856029470E-05   .100738034195E-04   .103885846348E-04   .107132019827E-04   .110479628186E-04
+   .113931841018E-04   .117491926962E-04   .121163256790E-04   .124949306607E-04   .128853661138E-04
+   .132880017122E-04   .137032186813E-04   .141314101590E-04   .145729815680E-04   .150283509995E-04
+   .154979496093E-04   .159822220258E-04   .164816267714E-04   .169966366960E-04   .175277394256E-04
+   .180754378234E-04   .186402504659E-04   .192227121345E-04   .198233743215E-04   .204428057523E-04
+   .210815929239E-04   .217403406606E-04   .224196726865E-04   .231202322159E-04   .238426825627E-04
+   .245877077686E-04   .253560132505E-04   .261483264688E-04   .269653976161E-04   .278080003278E-04
+   .286769324146E-04   .295730166180E-04   .304971013896E-04   .314500616944E-04   .324327998398E-04
+   .334462463297E-04   .344913607460E-04   .355691326573E-04   .366805825563E-04   .378267628260E-04
+   .390087587371E-04   .402276894749E-04   .414847092006E-04   .427810081434E-04   .441178137288E-04
+   .454963917407E-04   .469180475208E-04   .483841272050E-04   .498960189987E-04   .514551544922E-04
+   .530630100164E-04   .547211080424E-04   .564310186232E-04   .581943608821E-04   .600128045463E-04
+   .618880715299E-04   .638219375650E-04   .658162338852E-04   .678728489610E-04   .699937302898E-04
+   .721808862420E-04   .744363879649E-04   .767623713465E-04   .791610390403E-04   .816346625542E-04
+   .841855844046E-04   .868162203379E-04   .895290616222E-04   .923266774100E-04   .952117171767E-04
+   .981869132334E-04   .101255083321E-03   .104419133283E-03   .107682059826E-03   .111046953364E-03
+   .114517000952E-03   .118095489315E-03   .121785807968E-03   .125591452439E-03   .129516027589E-03
+   .133563251041E-03   .137736956712E-03   .142041098462E-03   .146479753854E-03   .151057128037E-03
+   .155777557744E-03   .160645515428E-03   .165665613517E-03   .170842608816E-03   .176181407035E-03
+   .181687067473E-03   .187364807847E-03   .193220009266E-03   .199258221382E-03   .205485167684E-03
+   .211906750980E-03   .218529059038E-03   .225358370423E-03   .232401160507E-03   .239664107683E-03
+   .247154099774E-03   .254878240646E-03   .262843857043E-03   .271058505635E-03   .279529980297E-03
+   .288266319630E-03   .297275814716E-03   .306567017139E-03   .316148747256E-03   .326030102756E-03
+   .336220467481E-03   .346729520555E-03   .357567245809E-03   .368743941522E-03   .380270230481E-03
+   .392157070389E-03   .404415764616E-03   .417057973314E-03   .430095724916E-03   .443541428020E-03
+   .457407883685E-03   .471708298150E-03   .486456296000E-03   .501665933781E-03   .517351714102E-03
+   .533528600235E-03   .550212031229E-03   .567417937576E-03   .585162757432E-03   .603463453437E-03
+   .622337530147E-03   .641803052120E-03   .661878662665E-03   .682583603310E-03   .703937734006E-03
+   .725961554105E-03   .748676224163E-03   .772103588586E-03   .796266199186E-03   .821187339682E-03
+   .846891051191E-03   .873402158776E-03   .900746299091E-03   .928949949206E-03   .958040456654E-03
+   .988046070785E-03   .101899597550E-02   .105092032345E-02   .108385027176E-02   .111781801943E-02
+   .115285684646E-02   .118900115481E-02   .122628651137E-02   .126474969299E-02   .130442873378E-02
+   .134536297475E-02   .138759311603E-02   .143116127179E-02   .147611102808E-02   .152248750375E-02
+   .157033741472E-02   .161970914182E-02   .167065280241E-02   .172322032616E-02   .177746553522E-02
+   .183344422905E-02   .189121427445E-02   .195083570102E-02   .201237080242E-02   .207588424416E-02
+   .214144317802E-02   .220911736401E-02   .227897930013E-02   .235110436081E-02   .242557094452E-02
+   .250246063140E-02   .258185835163E-02   .266385256546E-02   .274853545575E-02   .283600313417E-02
+   .292635586193E-02   .301969828644E-02   .311613969498E-02   .321579428689E-02   .331878146562E-02
+   .342522615237E-02   .353525912283E-02   .364901736906E-02   .376664448829E-02   .388829110081E-02
+   .401411529919E-02   .414428313121E-02   .427896911900E-02   .441835681710E-02   .456263941230E-02
+   .471202036819E-02   .486671411767E-02   .502694680657E-02   .519295709190E-02   .536499699817E-02
+   .554333283550E-02   .572824618302E-02   .592003494139E-02   .611901445807E-02   .632551872878E-02
+   .653990167868E-02   .676253852617E-02   .699382723214E-02   .723419003681E-02   .748407508535E-02
+   .774395814300E-02   .801434439871E-02   .829577035513E-02   .858880580073E-02   .889405585751E-02
+   .921216309496E-02   .954380969737E-02   .988971966759E-02   .102506610449E-01   .106274481092E-01
+   .110209435358E-01   .114320604572E-01   .118617643781E-01   .123110748763E-01   .127810670117E-01
+   .132728723445E-01   .137876794477E-01   .143267337757E-01   .148913367229E-01   .154828436778E-01
+   .161026608417E-01   .167522405392E-01   .174330747029E-01   .181466861584E-01   .188946172744E-01
+   .196784154721E-01   .204996150078E-01   .213597143480E-01   .222601483587E-01   .232022544067E-01
+   .241872313469E-01   .252160902189E-01   .262895953169E-01   .274081941188E-01   .285719343643E-01
+   .297803663603E-01   .310324283664E-01   .323263126676E-01   .336593096918E-01   .350276272678E-01
+   .364261818572E-01   .378483583402E-01   .392857346991E-01   .407277677387E-01   .421614358347E-01
+   .435708346222E-01   .449367215714E-01   .462360055703E-01   .474411780000E-01   .485196823962E-01
+   .494332207119E-01   .501369955023E-01   .505788891426E-01   .506985835564E-01   .504266270020E-01
+   .496834583590E-01   .483784042193E-01   .464086700540E-01   .436583539488E-01   .399975200001E-01
+   .352813785507E-01   .293496320737E-01   .220260586882E-01   .131184198804E-01   .241879477531E-02
+  -.102955402139E-01  -.252605510262E-01  -.427230540644E-01  -.629373289210E-01  -.861605631798E-01
+  -.112646954928E+00  -.142640306730E+00  -.176364966679E+00  -.214015012180E+00  -.255741635362E+00
+  -.301638780848E+00  -.351727212482E+00  -.405937350300E+00  -.464084251523E+00  -.525932864509E+00
+  -.591208917696E+00  -.659547216885E+00  -.730460902614E+00
+ ae wavefunction
+   .129467076207E-03   .133428583235E-03   .137510999937E-03   .141717997541E-03   .146053357577E-03
+   .150520975130E-03   .155124862163E-03   .159869150952E-03   .164758097605E-03   .169796085680E-03
+   .174987629904E-03   .180337379995E-03   .185850124583E-03   .191530795246E-03   .197384470645E-03
+   .203416380780E-03   .209631911350E-03   .216036608238E-03   .222636182110E-03   .229436513133E-03
+   .236443655822E-03   .243663844012E-03   .251103495952E-03   .258769219538E-03   .266667817679E-03
+   .274806293789E-03   .283191857434E-03   .291831930103E-03   .300734151135E-03   .309906383785E-03
+   .319356721438E-03   .329093493979E-03   .339125274305E-03   .349460885000E-03   .360109405165E-03
+   .371080177400E-03   .382382814956E-03   .394027209035E-03   .406023536266E-03   .418382266337E-03
+   .431114169795E-03   .444230326009E-03   .457742131302E-03   .471661307250E-03   .485999909145E-03
+   .500770334628E-03   .515985332481E-03   .531658011597E-03   .547801850096E-03   .564430704619E-03
+   .581558819769E-03   .599200837718E-03   .617371807959E-03   .636087197215E-03   .655362899488E-03
+   .675215246247E-03   .695661016757E-03   .716717448522E-03   .738402247861E-03   .760733600588E-03
+   .783730182792E-03   .807411171710E-03   .831796256681E-03   .856905650164E-03   .882760098807E-03
+   .909380894557E-03   .936789885784E-03   .965009488411E-03   .994062697023E-03   .102397309593E-02
+   .105476487018E-02   .108646281646E-02   .111909235389E-02   .115267953468E-02   .118725105455E-02
+   .122283426303E-02   .125945717339E-02   .129714847237E-02   .133593752949E-02   .137585440604E-02
+   .141692986357E-02   .145919537192E-02   .150268311667E-02   .154742600602E-02   .159345767691E-02
+   .164081250045E-02   .168952558649E-02   .173963278725E-02   .179117070001E-02   .184417666860E-02
+   .189868878381E-02   .195474588238E-02   .201238754467E-02   .207165409073E-02   .213258657475E-02
+   .219522677760E-02   .225961719763E-02   .232580103911E-02   .239382219865E-02   .246372524901E-02
+   .253555542041E-02   .260935857894E-02   .268518120203E-02   .276307035067E-02   .284307363817E-02
+   .292523919518E-02   .300961563090E-02   .309625198993E-02   .318519770467E-02   .327650254302E-02
+   .337021655082E-02   .346638998905E-02   .356507326507E-02   .366631685792E-02   .377017123699E-02
+   .387668677384E-02   .398591364674E-02   .409790173740E-02   .421270051964E-02   .433035893927E-02
+   .445092528491E-02   .457444704918E-02   .470097077965E-02   .483054191913E-02   .496320463466E-02
+   .509900163465E-02   .523797397346E-02   .538016084306E-02   .552559935078E-02   .567432428273E-02
+   .582636785225E-02   .598175943242E-02   .614052527229E-02   .630268819583E-02   .646826728301E-02
+   .663727753232E-02   .680972950381E-02   .698562894216E-02   .716497637882E-02   .734776671266E-02
+   .753398876832E-02   .772362483156E-02   .791665016099E-02   .811303247550E-02   .831273141670E-02
+   .851569798594E-02   .872187395529E-02   .893119125200E-02   .914357131614E-02   .935892443105E-02
+   .957714902637E-02   .979813095367E-02   .100217427345E-01   .102478427812E-01   .104762745907E-01
+   .107068659118E-01   .109394278868E-01   .111737541678E-01   .114096200099E-01   .116467813410E-01
+   .118849738123E-01   .121239118289E-01   .123632875645E-01   .126027699631E-01   .128420037289E-01
+   .130806083109E-01   .133181768834E-01   .135542753287E-01   .137884412271E-01   .140201828583E-01
+   .142489782229E-01   .144742740888E-01   .146954850714E-01   .149119927566E-01   .151231448732E-01
+   .153282545287E-01   .155265995154E-01   .157174217021E-01   .158999265212E-01   .160732825675E-01
+   .162366213215E-01   .163890370136E-01   .165295866466E-01   .166572901935E-01   .167711309892E-01
+   .168700563374E-01   .169529783520E-01   .170187750554E-01   .170662917573E-01   .170943427368E-01
+   .171017132517E-01   .170871619020E-01   .170494233716E-01   .169872115746E-01   .168992232329E-01
+   .167841419118E-01   .166406425379E-01   .164673964269E-01   .162630768448E-01   .160263651262E-01
+   .157559573721E-01   .154505717467E-01   .151089563902E-01   .147298979639E-01   .143122308358E-01
+   .138548469164E-01   .133567061437E-01   .128168476166E-01   .122344013658E-01   .116086007458E-01
+   .109387954244E-01   .102244649366E-01   .946523276252E-02   .866088087554E-02   .781136469954E-02
+   .691682839863E-02   .597762041201E-02   .499430913101E-02   .396769860106E-02   .289884411583E-02
+   .178906755599E-02   .639972311630E-03  -.546542382426E-03  -.176826787415E-02  -.302267345929E-02
+  -.430689485117E-02  -.561772391221E-02  -.695159979709E-02  -.830460166077E-02  -.967244310702E-02
+  -.110504685968E-01  -.124336520983E-01  -.138165983277E-01  -.151935469897E-01  -.165583804577E-01
+  -.179046353254E-01  -.192255181988E-01  -.205139259982E-01  -.217624709109E-01  -.229635100310E-01
+  -.241091796495E-01  -.251914341322E-01  -.262020893120E-01  -.271328703033E-01  -.279754636043E-01
+  -.287215732897E-01  -.293629810166E-01  -.298916094897E-01  -.302995889509E-01  -.305793261928E-01
+  -.307235755198E-01  -.307255110204E-01  -.305787994394E-01  -.302776728758E-01  -.298170004582E-01
+  -.291923580824E-01  -.284000952307E-01  -.274373978241E-01  -.263023460098E-01  -.249939657333E-01
+  -.235122729198E-01  -.218583090782E-01  -.200341671656E-01  -.180430066110E-01  -.158890565087E-01
+  -.135776061524E-01  -.111149822919E-01  -.850851273348E-02  -.576647613306E-02  -.289803799079E-02
+   .868271008447E-04   .317742698748E-02   .636245733779E-02   .963012050375E-02   .129682556736E-01
+   .163644740595E-01   .198062866325E-01   .232812064380E-01   .267768090194E-01   .302807492650E-01
+   .337807596243E-01   .372646755965E-01   .407205212938E-01   .441366371868E-01   .475017902611E-01
+   .508052161010E-01   .540365814686E-01   .571858810087E-01   .602432831776E-01   .631989321856E-01
+   .660427052515E-01   .687639202596E-01   .713509877236E-01   .737910018668E-01   .760692678938E-01
+   .781687651807E-01   .800695486385E-01   .817480926280E-01   .831765835639E-01   .843221689026E-01
+   .851461715846E-01   .856032805383E-01   .856407293072E-01   .851974765745E-01   .842034041498E-01
+   .825785499752E-01   .802323959449E-01   .770632327454E-01   .729576267103E-01   .677900167541E-01
+   .614224728949E-01   .537046517788E-01   .444739889225E-01   .335561720662E-01   .207659451252E-01
+   .590829718095E-02  -.112199070159E-01  -.308277630007E-01  -.531276210327E-01  -.783316948937E-01
+  -.106647977832E+00  -.138275362190E+00  -.173397902213E+00  -.212178158210E+00  -.254749569528E+00
+  -.301207818949E+00  -.351601173439E+00  -.405919818242E+00  -.464084251523E+00  -.525932864509E+00
+ End of Dataset
+ PAW_PBE N_h 13Feb2001
+ 5.00000000000000000
+ parameters from PSCTR are:
+   VRHFIN =N: s2p3
+   LEXCH  = PE
+   EATOM  =   264.5486 eV,   19.4438 Ry
+   TITEL  = PAW_PBE N_h 13Feb2001
+   LULTRA =        F    use ultrasoft PP ?
+   IUNSCR =        0    unscreen: 0-lin 1-nonlin 2-no
+   RPACOR =     .000    partial core radius
+   POMASS =   14.001; ZVAL   =    5.000    mass and valenz
+   RCORE  =    1.100    outmost cutoff radius
+   RWIGS  =    1.480; RWIGS  =     .783    wigner-seitz radius (au A)
+   ENMAX  =  755.582; ENMIN  =  566.687 eV
+   ICORE  =        2    local potential
+   LCOR   =        T    correct aug charges
+   LPAW   =        T    paw PP
+   EAUG   =  904.640
+   DEXC   =     .000
+   RMAX   =    1.677    core radius for proj-oper
+   RAUG   =    1.300    factor for augmentation sphere
+   RDEP   =    1.115    radius for radial grids
+   QCUT   =   -7.452; QGAM   =   14.904    optimization parameters
+   Description
+     l     E      TYP  RCUT    TYP  RCUT
+     0   .000     23  1.100
+     0   .000     23  1.100
+     1   .000     23  1.100
+     1   .000     23  1.100
+     2   .000      7  1.100
+   Error from kinetic energy argument (eV)
+   NDATA  =      100
+   STEP   =   20.000   1.050
+  133.      130.      129.      126.      125.      122.      119.      118.
+  115.      112.      111.      108.      105.      103.      99.9      97.2
+  94.5      91.8      89.2      85.3      82.8      80.3      76.7      74.3
+  72.0      68.6      65.4      63.3      60.2      57.3      54.4      51.7
+  49.1      46.6      44.2      41.9      39.0      36.9      34.2      32.4
+  30.0      27.8      25.7      23.7      21.9      20.2      18.6      16.7
+  15.3      13.7      12.3      11.2      9.96      8.84      7.64      6.74
+  5.93      5.06      4.30      3.64      3.06      2.56      2.13      1.71
+  1.40      1.10      .859      .662      .484      .363      .257      .178
+  .121      .800E-01  .493E-01  .317E-01  .197E-01  .130E-01  .957E-02  .842E-02
+  .812E-02  .811E-02  .795E-02  .744E-02  .658E-02  .551E-02  .437E-02  .323E-02
+  .231E-02  .165E-02  .122E-02  .103E-02  .961E-03  .952E-03  .933E-03  .867E-03
+  .745E-03  .605E-03  .452E-03  .343E-03
+END of PSCTR-controll parameters
+ local part
+ 170.075338972103111
+   .14499253E+02   .14499335E+02   .14496325E+02   .14491312E+02   .14484300E+02
+   .14475293E+02   .14464299E+02   .14451322E+02   .14436368E+02   .14419440E+02
+   .14400541E+02   .14379672E+02   .14356831E+02   .14332016E+02   .14305223E+02
+   .14276445E+02   .14245675E+02   .14212906E+02   .14178127E+02   .14141327E+02
+   .14102494E+02   .14061613E+02   .14018669E+02   .13973642E+02   .13926512E+02
+   .13877254E+02   .13825842E+02   .13772248E+02   .13716439E+02   .13658381E+02
+   .13598038E+02   .13535372E+02   .13470341E+02   .13402903E+02   .13333014E+02
+   .13260629E+02   .13185702E+02   .13108184E+02   .13028028E+02   .12945184E+02
+   .12859605E+02   .12771242E+02   .12680048E+02   .12585978E+02   .12488988E+02
+   .12389035E+02   .12286083E+02   .12180096E+02   .12071042E+02   .11958895E+02
+   .11843632E+02   .11725237E+02   .11603699E+02   .11479013E+02   .11351182E+02
+   .11220213E+02   .11086125E+02   .10948942E+02   .10808697E+02   .10665433E+02
+   .10519199E+02   .10370057E+02   .10218075E+02   .10063333E+02   .99059189E+01
+   .97459316E+01   .95834785E+01   .94186773E+01   .92516550E+01   .90825478E+01
+   .89115013E+01   .87386700E+01   .85642167E+01   .83883126E+01   .82111365E+01
+   .80328747E+01   .78537199E+01   .76738711E+01   .74935326E+01   .73129139E+01
+   .71322283E+01   .69516928E+01   .67715268E+01   .65919519E+01   .64131907E+01
+   .62354658E+01   .60589996E+01   .58840129E+01   .57107241E+01   .55393486E+01
+   .53700978E+01   .52031782E+01   .50387905E+01   .48771292E+01   .47183814E+01
+   .45627263E+01   .44103346E+01   .42613674E+01   .41159759E+01   .39743009E+01
+   .38364719E+01   .37026069E+01   .35728118E+01   .34471803E+01   .33257931E+01
+   .32087181E+01   .30960100E+01   .29877103E+01   .28838471E+01   .27844351E+01
+   .26894759E+01   .25989579E+01   .25128567E+01   .24311348E+01   .23537429E+01
+   .22806193E+01   .22116909E+01   .21468733E+01   .20860719E+01   .20291818E+01
+   .19760890E+01   .19266707E+01   .18807960E+01   .18383270E+01   .17991192E+01
+   .17630223E+01   .17298811E+01   .16995363E+01   .16718252E+01   .16465826E+01
+   .16236417E+01   .16028347E+01   .15839938E+01   .15669519E+01   .15515433E+01
+   .15376046E+01   .15249752E+01   .15134983E+01   .15030211E+01   .14933959E+01
+   .14844803E+01   .14761378E+01   .14682384E+01   .14606589E+01   .14532833E+01
+   .14460033E+01   .14387183E+01   .14313358E+01   .14237717E+01   .14159501E+01
+   .14078035E+01   .13992731E+01   .13903081E+01   .13808664E+01   .13709139E+01
+   .13604245E+01   .13493799E+01   .13377695E+01   .13255897E+01   .13128438E+01
+   .12995419E+01   .12856999E+01   .12713395E+01   .12564879E+01   .12411767E+01
+   .12254421E+01   .12093240E+01   .11928655E+01   .11761128E+01   .11591140E+01
+   .11419195E+01   .11245804E+01   .11071491E+01   .10896782E+01   .10722201E+01
+   .10548266E+01   .10375487E+01   .10204358E+01   .10035356E+01   .98689383E+00
+   .97055350E+00   .95455509E+00   .93893603E+00   .92373056E+00   .90896952E+00
+   .89468021E+00   .88088624E+00   .86760746E+00   .85485990E+00   .84265572E+00
+   .83100326E+00   .81990704E+00   .80936784E+00   .79938281E+00   .78994555E+00
+   .78104633E+00   .77267221E+00   .76480723E+00   .75743267E+00   .75052723E+00
+   .74406729E+00   .73802718E+00   .73237941E+00   .72709495E+00   .72214354E+00
+   .71749390E+00   .71311408E+00   .70897169E+00   .70503420E+00   .70126918E+00
+   .69764459E+00   .69412901E+00   .69069188E+00   .68730371E+00   .68393630E+00
+   .68056291E+00   .67715846E+00   .67369966E+00   .67016514E+00   .66653558E+00
+   .66279382E+00   .65892488E+00   .65491608E+00   .65075702E+00   .64643963E+00
+   .64195813E+00   .63730905E+00   .63249111E+00   .62750523E+00   .62235439E+00
+   .61704359E+00   .61157968E+00   .60597127E+00   .60022862E+00   .59436344E+00
+   .58838878E+00   .58231884E+00   .57616884E+00   .56995481E+00   .56369344E+00
+   .55740188E+00   .55109761E+00   .54479821E+00   .53852124E+00   .53228405E+00
+   .52610362E+00   .51999644E+00   .51397833E+00   .50806434E+00   .50226861E+00
+   .49660427E+00   .49108335E+00   .48571665E+00   .48051372E+00   .47548276E+00
+   .47063061E+00   .46596268E+00   .46148293E+00   .45719392E+00   .45309675E+00
+   .44919111E+00   .44547534E+00   .44194642E+00   .43860005E+00   .43543074E+00
+   .43243185E+00   .42959567E+00   .42691354E+00   .42437592E+00   .42197251E+00
+   .41969236E+00   .41752395E+00   .41545535E+00   .41347431E+00   .41156837E+00
+   .40972501E+00   .40793172E+00   .40617612E+00   .40444609E+00   .40272986E+00
+   .40101608E+00   .39929394E+00   .39755325E+00   .39578451E+00   .39397899E+00
+   .39212875E+00   .39022676E+00   .38826688E+00   .38624393E+00   .38415371E+00
+   .38199298E+00   .37975952E+00   .37745206E+00   .37507033E+00   .37261499E+00
+   .37008762E+00   .36749070E+00   .36482752E+00   .36210217E+00   .35931947E+00
+   .35648490E+00   .35360454E+00   .35068499E+00   .34773329E+00   .34475686E+00
+   .34176341E+00   .33876086E+00   .33575723E+00   .33276061E+00   .32977906E+00
+   .32682052E+00   .32389273E+00   .32100321E+00   .31815912E+00   .31536727E+00
+   .31263399E+00   .30996513E+00   .30736599E+00   .30484129E+00   .30239509E+00
+   .30003084E+00   .29775130E+00   .29555853E+00   .29345391E+00   .29143811E+00
+   .28951112E+00   .28767224E+00   .28592012E+00   .28425274E+00   .28266749E+00
+   .28116119E+00   .27973011E+00   .27837002E+00   .27707624E+00   .27584371E+00
+   .27466700E+00   .27354043E+00   .27245804E+00   .27141376E+00   .27040135E+00
+   .26941456E+00   .26844714E+00   .26749287E+00   .26654569E+00   .26559969E+00
+   .26464919E+00   .26368877E+00   .26271335E+00   .26171819E+00   .26069895E+00
+   .25965172E+00   .25857305E+00   .25745998E+00   .25631003E+00   .25512123E+00
+   .25389216E+00   .25262189E+00   .25131003E+00   .24995669E+00   .24856250E+00
+   .24712857E+00   .24565647E+00   .24414822E+00   .24260627E+00   .24103344E+00
+   .23943291E+00   .23780815E+00   .23616294E+00   .23450127E+00   .23282732E+00
+   .23114541E+00   .22945996E+00   .22777545E+00   .22609637E+00   .22442718E+00
+   .22277225E+00   .22113585E+00   .21952208E+00   .21793485E+00   .21637785E+00
+   .21485449E+00   .21336790E+00   .21192088E+00   .21051590E+00   .20915506E+00
+   .20784010E+00   .20657236E+00   .20535279E+00   .20418195E+00   .20305999E+00
+   .20198668E+00   .20096140E+00   .19998316E+00   .19905060E+00   .19816202E+00
+   .19731541E+00   .19650846E+00   .19573857E+00   .19500290E+00   .19429843E+00
+   .19362191E+00   .19296999E+00   .19233916E+00   .19172586E+00   .19112649E+00
+   .19053742E+00   .18995506E+00   .18937585E+00   .18879635E+00   .18821323E+00
+   .18762330E+00   .18702356E+00   .18641120E+00   .18578366E+00   .18513861E+00
+   .18447400E+00   .18378803E+00   .18307924E+00   .18234645E+00   .18158877E+00
+   .18080565E+00   .17999684E+00   .17916241E+00   .17830272E+00   .17741843E+00
+   .17651049E+00   .17558012E+00   .17462879E+00   .17365821E+00   .17267031E+00
+   .17166722E+00   .17065122E+00   .16962476E+00   .16859038E+00   .16755075E+00
+   .16650856E+00   .16546658E+00   .16442755E+00   .16339424E+00   .16236933E+00
+   .16135546E+00   .16035517E+00   .15937088E+00   .15840488E+00   .15745927E+00
+   .15653600E+00   .15563682E+00   .15476326E+00   .15391662E+00   .15309798E+00
+   .15230817E+00   .15154779E+00   .15081718E+00   .15011643E+00   .14944539E+00
+   .14880366E+00   .14819062E+00   .14760539E+00   .14704692E+00   .14651391E+00
+   .14600490E+00   .14551825E+00   .14505217E+00   .14460472E+00   .14417385E+00
+   .14375744E+00   .14335327E+00   .14295908E+00   .14257257E+00   .14219146E+00
+   .14181345E+00   .14143631E+00   .14105784E+00   .14067594E+00   .14028860E+00
+   .13989390E+00   .13949010E+00   .13907557E+00   .13864885E+00   .13820866E+00
+   .13775390E+00   .13728365E+00   .13679720E+00   .13629403E+00   .13577383E+00
+   .13523649E+00   .13468209E+00   .13411092E+00   .13352347E+00   .13292039E+00
+   .13230254E+00   .13167090E+00   .13102666E+00   .13037109E+00   .12970564E+00
+   .12903183E+00   .12835130E+00   .12766574E+00   .12697692E+00   .12628663E+00
+   .12559671E+00   .12490897E+00   .12422524E+00   .12354728E+00   .12287684E+00
+   .12221559E+00   .12156511E+00   .12092690E+00   .12030233E+00   .11969267E+00
+   .11909904E+00   .11852244E+00   .11796368E+00   .11742346E+00   .11690229E+00
+   .11640051E+00   .11591831E+00   .11545572E+00   .11501257E+00   .11458858E+00
+   .11418326E+00   .11379601E+00   .11342605E+00   .11307250E+00   .11273432E+00
+   .11241039E+00   .11209946E+00   .11180021E+00   .11151123E+00   .11123108E+00
+   .11095824E+00   .11069118E+00   .11042834E+00   .11016818E+00   .10990915E+00
+   .10964975E+00   .10938850E+00   .10912400E+00   .10885491E+00   .10857997E+00
+   .10829800E+00   .10800796E+00   .10770889E+00   .10739997E+00   .10708048E+00
+   .10674987E+00   .10640769E+00   .10605365E+00   .10568759E+00   .10530950E+00
+   .10491948E+00   .10451781E+00   .10410486E+00   .10368115E+00   .10324731E+00
+   .10280408E+00   .10235231E+00   .10189294E+00   .10142699E+00   .10095557E+00
+   .10047983E+00   .10000096E+00   .99520223E-01   .99038870E-01   .98558179E-01
+   .98079425E-01   .97603865E-01   .97132735E-01   .96667229E-01   .96208495E-01
+   .95757616E-01   .95315608E-01   .94883404E-01   .94461851E-01   .94051698E-01
+   .93653591E-01   .93268072E-01   .92895566E-01   .92536388E-01   .92190735E-01
+   .91858686E-01   .91540202E-01   .91235131E-01   .90943205E-01   .90664046E-01
+   .90397174E-01   .90142004E-01   .89897863E-01   .89663988E-01   .89439543E-01
+   .89223621E-01   .89015257E-01   .88813438E-01   .88617113E-01   .88425202E-01
+   .88236608E-01   .88050228E-01   .87864961E-01   .87679722E-01   .87493451E-01
+   .87305121E-01   .87113751E-01   .86918413E-01   .86718242E-01   .86512444E-01
+   .86300299E-01   .86081175E-01   .85854524E-01   .85619893E-01   .85376925E-01
+   .85125361E-01   .84865041E-01   .84595907E-01   .84317998E-01   .84031454E-01
+   .83736512E-01   .83433499E-01   .83122833E-01   .82805017E-01   .82480630E-01
+   .82150325E-01   .81814816E-01   .81474875E-01   .81131324E-01   .80785021E-01
+   .80436856E-01   .80087743E-01   .79738605E-01   .79390371E-01   .79043965E-01
+   .78700293E-01   .78360243E-01   .78024667E-01   .77694377E-01   .77370140E-01
+   .77052665E-01   .76742601E-01   .76440526E-01   .76146950E-01   .75862303E-01
+   .75586936E-01   .75321116E-01   .75065025E-01   .74818762E-01   .74582336E-01
+   .74355673E-01   .74138614E-01   .73930918E-01   .73732264E-01   .73542257E-01
+   .73360429E-01   .73186249E-01   .73019122E-01   .72858405E-01   .72703404E-01
+   .72553387E-01   .72407592E-01   .72265229E-01   .72125496E-01   .71987579E-01
+   .71850663E-01   .71713943E-01   .71576627E-01   .71437944E-01   .71297154E-01
+   .71153555E-01   .71006487E-01   .70855339E-01   .70699557E-01   .70538645E-01
+   .70372173E-01   .70199777E-01   .70021165E-01   .69836116E-01   .69644484E-01
+   .69446197E-01   .69241257E-01   .69029742E-01   .68811800E-01   .68587653E-01
+   .68357588E-01   .68121958E-01   .67881176E-01   .67635711E-01   .67386082E-01
+   .67132855E-01   .66876630E-01   .66618044E-01   .66357758E-01   .66096450E-01
+   .65834815E-01   .65573549E-01   .65313349E-01   .65054904E-01   .64798888E-01
+   .64545953E-01   .64296724E-01   .64051793E-01   .63811710E-01   .63576982E-01
+   .63348067E-01   .63125369E-01   .62909234E-01   .62699951E-01   .62497745E-01
+   .62302777E-01   .62115144E-01   .61934879E-01   .61761949E-01   .61596255E-01
+   .61437638E-01   .61285876E-01   .61140690E-01   .61001743E-01   .60868651E-01
+   .60740977E-01   .60618247E-01   .60499945E-01   .60385526E-01   .60274418E-01
+   .60166027E-01   .60059745E-01   .59954955E-01   .59851038E-01   .59747378E-01
+   .59643366E-01   .59538411E-01   .59431939E-01   .59323404E-01   .59212293E-01
+   .59098126E-01   .58980466E-01   .58858920E-01   .58733141E-01   .58602837E-01
+   .58467766E-01   .58327743E-01   .58182636E-01   .58032375E-01   .57876943E-01
+   .57716382E-01   .57550790E-01   .57380320E-01   .57205178E-01   .57025621E-01
+   .56841952E-01   .56654521E-01   .56463716E-01   .56269962E-01   .56073716E-01
+   .55875460E-01   .55675699E-01   .55474955E-01   .55273759E-01   .55072651E-01
+   .54872169E-01   .54672848E-01   .54475215E-01   .54279778E-01   .54087030E-01
+   .53897435E-01   .53711432E-01   .53529424E-01   .53351777E-01   .53178817E-01
+   .53010828E-01   .52848046E-01   .52690662E-01   .52538814E-01   .52392595E-01
+   .52252043E-01   .52117149E-01   .51987851E-01   .51864039E-01   .51745555E-01
+   .51632195E-01   .51523710E-01   .51419810E-01   .51320168E-01   .51224422E-01
+   .51132179E-01   .51043021E-01   .50956506E-01   .50872176E-01   .50789560E-01
+   .50708177E-01   .50627545E-01   .50547182E-01   .50466609E-01   .50385360E-01
+   .50302984E-01   .50219047E-01   .50133140E-01   .50044879E-01   .49953915E-01
+   .49859928E-01   .49762640E-01   .49661807E-01   .49557231E-01   .49448755E-01
+   .49336265E-01   .49219693E-01   .49099016E-01   .48974255E-01   .48845476E-01
+   .48712788E-01   .48576343E-01   .48436334E-01   .48292991E-01   .48146581E-01
+   .47997401E-01   .47845782E-01   .47692077E-01   .47536662E-01   .47379933E-01
+   .47222299E-01   .47064177E-01   .46905993E-01   .46748175E-01   .46591145E-01
+   .46435323E-01   .46281115E-01   .46128914E-01   .45979096E-01   .45832011E-01
+   .45687988E-01   .45547325E-01   .45410288E-01   .45277110E-01   .45147990E-01
+   .45023086E-01   .44902520E-01   .44786374E-01   .44674690E-01   .44567468E-01
+   .44464670E-01   .44366219E-01   .44271998E-01   .44181853E-01   .44095594E-01
+   .44013000E-01   .43933817E-01   .43857762E-01   .43784528E-01   .43713788E-01
+   .43645192E-01   .43578380E-01   .43512976E-01   .43448600E-01   .43384867E-01
+   .43321391E-01   .43257791E-01   .43193691E-01   .43128728E-01   .43062552E-01
+   .42994832E-01   .42925256E-01   .42853538E-01   .42779417E-01   .42702663E-01
+   .42623076E-01   .42540488E-01   .42454765E-01   .42365811E-01   .42273562E-01
+   .42177992E-01   .42079112E-01   .41976965E-01   .41871634E-01   .41763232E-01
+   .41651908E-01   .41537841E-01   .41421238E-01   .41302336E-01   .41181394E-01
+   .41058692E-01   .40934532E-01   .40809228E-01   .40683107E-01   .40556506E-01
+   .40429767E-01   .40303233E-01   .40177247E-01   .40052149E-01   .39928269E-01
+   .39805927E-01   .39685428E-01   .39567062E-01   .39451097E-01   .39337779E-01
+   .39227329E-01   .39119942E-01   .39015784E-01   .38914990E-01   .38817665E-01
+   .38723881E-01   .38633679E-01   .38547067E-01   .38464021E-01   .38384482E-01
+   .38308364E-01   .38235548E-01   .38165887E-01   .38099204E-01   .38035300E-01
+   .37973950E-01   .37914909E-01   .37857913E-01   .37802683E-01   .37748927E-01
+   .37696342E-01   .37644620E-01   .37593449E-01   .37542515E-01   .37491507E-01
+   .37440118E-01   .37388052E-01   .37335022E-01   .37280754E-01   .37224992E-01
+   .37167499E-01   .37108058E-01   .37046478E-01   .36982589E-01   .36916251E-01
+   .36847351E-01   .36775803E-01   .36701551E-01   .36624568E-01   .36544858E-01
+   .36462451E-01   .36377411E-01   .36289824E-01   .36199808E-01   .36107505E-01
+   .36013080E-01   .35916723E-01   .35818643E-01   .35719068E-01   .35618240E-01
+   .35516417E-01   .35413864E-01   .35310857E-01   .35207676E-01   .35104601E-01
+   .35001916E-01   .34899899E-01   .34798822E-01   .34698951E-01   .34600537E-01
+   .34503822E-01   .34409028E-01   .34316363E-01   .34226010E-01   .34138135E-01
+   .34052877E-01   .33970353E-01   .33890652E-01   .33813840E-01   .33739954E-01
+   .33669005E-01   .33600978E-01   .33535830E-01   .33473492E-01   .33413872E-01
+   .33356853E-01   .33302292E-01   .33250029E-01   .33199882E-01   .33151650E-01
+   .33105120E-01   .33060062E-01   .33016236E-01   .32973395E-01   .32931284E-01
+   .32889646E-01   .32848222E-01   .32806755E-01   .32764990E-01   .32722680E-01
+   .32679587E-01   .32635484E-01   .32590156E-01   .32543403E-01   .32495045E-01
+   .32444918E-01   .32392881E-01   .32338813E-01   .32282617E-01   .32224218E-01
+   .32163566E-01   .32100636E-01   .32035427E-01   .31967962E-01   .31898287E-01
+   .31826474E-01   .31752616E-01   .31676827E-01   .31599243E-01   .31520018E-01
+ gradient corrections used for XC
+ 5
+ atomic pseudo charge-density
+   .50000000E+01   .49824973E+01   .49305443E+01   .48457626E+01   .47307126E+01
+   .45887034E+01   .44235660E+01   .42394185E+01   .40404481E+01   .38307260E+01
+   .36140656E+01   .33939246E+01   .31733481E+01   .29549456E+01   .27408938E+01
+   .25329582E+01   .23325260E+01   .21406454E+01   .19580677E+01   .17852883E+01
+   .16225862E+01   .14700601E+01   .13276612E+01   .11952216E+01   .10724796E+01
+   .95910164E+00   .85470029E+00   .75885018E+00   .67110101E+00   .59098837E+00
+   .51804260E+00   .45179603E+00   .39178861E+00   .33757240E+00   .28871501E+00
+   .24480200E+00   .20543872E+00   .17025136E+00   .13888759E+00   .11101675E+00
+   .86329727E-01   .64538512E-01   .45375645E-01   .28593443E-01   .13963148E-01
+   .12739955E-02  -.96677615E-02  -.19039848E-01  -.27004967E-01  -.33711786E-01
+  -.39295904E-01  -.43880783E-01  -.47578647E-01  -.50491335E-01  -.52711111E-01
+  -.54321432E-01  -.55397665E-01  -.56007760E-01  -.56212879E-01  -.56067982E-01
+  -.55622364E-01  -.54920166E-01  -.54000829E-01  -.52899532E-01  -.51647578E-01
+  -.50272762E-01  -.48799699E-01  -.47250134E-01  -.45643214E-01  -.43995750E-01
+  -.42322445E-01  -.40636107E-01  -.38947846E-01  -.37267244E-01  -.35602521E-01
+  -.33960677E-01  -.32347622E-01  -.30768302E-01  -.29226798E-01  -.27726433E-01
+  -.26269852E-01  -.24859107E-01  -.23495727E-01  -.22180781E-01  -.20914937E-01
+  -.19698517E-01  -.18531538E-01  -.17413756E-01  -.16344705E-01  -.15323730E-01
+  -.14350011E-01  -.13422598E-01  -.12540427E-01  -.11702343E-01  -.10907121E-01
+  -.10153478E-01  -.94400863E-02  -.87655913E-02  -.81286171E-02  -.75277779E-02
+  -.69616857E-02  -.64289570E-02  -.59282192E-02  -.54581156E-02  -.50173093E-02
+  -.46044870E-02  -.42183623E-02  -.38576776E-02  -.35212065E-02  -.32077552E-02
+  -.29161638E-02  -.26453068E-02  -.23940946E-02  -.21614727E-02  -.19464231E-02
+  -.17479632E-02  -.15651466E-02  -.13970623E-02  -.12428343E-02  -.11016217E-02
+  -.97261737E-03  -.85504816E-03  -.74817373E-03  -.65128608E-03  -.56370886E-03
+  -.48479658E-03  -.41393395E-03  -.35053504E-03  -.29404260E-03  -.24392723E-03
+  -.19968663E-03  -.16084484E-03  -.12695147E-03  -.97580916E-04  -.72331611E-04
+  -.50825264E-04  -.32706104E-04  -.17640136E-04  -.53143962E-05   .45637845E-05
+   .12267509E-04   .18051039E-04   .22150512E-04   .24784654E-04   .26155484E-04
+   .26449012E-04   .25835929E-04   .24472295E-04   .22500212E-04   .20048498E-04
+   .17233343E-04   .14158968E-04   .10918264E-04   .75934261E-05   .42565826E-05
+   .97040369E-06  -.22112949E-05  -.52429620E-05  -.80867341E-05  -.10711872E-04
+  -.13094210E-04  -.15215623E-04  -.17063508E-04  -.18630279E-04  -.19912884E-04
+  -.20912333E-04  -.21633253E-04  -.22083452E-04  -.22273508E-04  -.22216376E-04
+  -.21927016E-04  -.21422038E-04  -.20719370E-04  -.19837948E-04  -.18797422E-04
+  -.17617887E-04  -.16319632E-04  -.14922913E-04  -.13447739E-04  -.11913689E-04
+  -.10339737E-04  -.87441074E-05  -.71441386E-05  -.55561736E-05  -.39954637E-05
+  -.24760902E-05  -.10109033E-05   .38852469E-06   .17119300E-05   .29503749E-05
+   .40962519E-05   .51432754E-05   .60864622E-05   .69221015E-05   .76477155E-05
+   .82620112E-05   .87648249E-05   .91570596E-05   .94406171E-05   .96183249E-05
+   .96938593E-05   .96716652E-05   .95568740E-05   .93552199E-05   .90729552E-05
+   .87167663E-05   .82936901E-05   .78110314E-05   .72762836E-05   .66970501E-05
+   .60809709E-05   .54356508E-05   .47685928E-05   .40871355E-05   .33983947E-05
+   .27092107E-05   .20260995E-05   .13552101E-05   .70228720E-06   .72638387E-07
+  -.52889249E-06  -.10979469E-05  -.16306681E-05  -.21237121E-05  -.25742538E-05
+  -.29799884E-05  -.33391284E-05  -.36503953E-05  -.39130084E-05  -.41266692E-05
+  -.42915420E-05  -.44082321E-05  -.44777601E-05  -.45015351E-05  -.44813242E-05
+  -.44192212E-05  -.43176132E-05  -.41791471E-05  -.40066938E-05  -.38033131E-05
+  -.35722183E-05  -.33167404E-05  -.30402933E-05  -.27463399E-05  -.24383586E-05
+  -.21198112E-05  -.17941133E-05  -.14646043E-05  -.11345217E-05  -.80697522E-06
+  -.48492473E-06  -.17115932E-06   .13172074E-06   .42131977E-06   .69546008E-06
+   .95219280E-06   .11898064E-05   .14068325E-05   .16020499E-05   .17744854E-05
+   .19234130E-05   .20483511E-05   .21490569E-05   .22255199E-05   .22779524E-05
+   .23067795E-05   .23126270E-05   .22963083E-05   .22588095E-05   .22012745E-05
+   .21249883E-05   .20313604E-05   .19219075E-05   .17982353E-05   .16620212E-05
+   .15149965E-05   .13589282E-05   .11956023E-05   .10268068E-05   .85431528E-06
+   .67987135E-06   .50517417E-06   .33186448E-06   .16151184E-06  -.43970453E-08
+  -.16446888E-06  -.31741311E-06  -.46205003E-06  -.59731758E-06  -.72227693E-06
+  -.83611665E-06  -.93815573E-06  -.10278452E-05  -.11047688E-05  -.11686417E-05
+  -.12193094E-05  -.12567438E-05  -.12810402E-05  -.12924112E-05  -.12911817E-05
+  -.12777818E-05  -.12527394E-05  -.12166723E-05  -.11702793E-05  -.11143317E-05
+  -.10496634E-05  -.97716162E-06  -.89775676E-06  -.81241286E-06  -.72211759E-06
+  -.62787247E-06  -.53068337E-06  -.43155119E-06  -.33146291E-06  -.23138305E-06
+  -.13224556E-06  -.34946343E-07   .59663766E-07   .15078532E-06   .23767594E-06
+   .31965531E-06   .39610945E-06   .46649428E-06   .53033841E-06   .58724521E-06
+   .63689416E-06   .67904143E-06   .71351981E-06   .74023789E-06   .75917861E-06
+   .77039721E-06   .77401851E-06   .77023378E-06   .75929692E-06   .74152037E-06
+   .71727047E-06   .68696258E-06   .65105582E-06   .61004760E-06   .56446797E-06
+   .51487386E-06   .46184315E-06   .40596886E-06   .34785327E-06   .28810213E-06
+   .22731906E-06   .16610011E-06   .10502848E-06   .44669594E-07  -.14433589E-07
+  -.71764883E-07  -.12683886E-06  -.17920442E-06  -.22844797E-06  -.27419616E-06
+  -.31611817E-06  -.35392760E-06  -.38738383E-06  -.41629301E-06  -.44050852E-06
+  -.45993106E-06  -.47450824E-06  -.48423385E-06  -.48914661E-06  -.48932869E-06
+  -.48490371E-06  -.47603457E-06  -.46292091E-06  -.44579629E-06  -.42492517E-06
+  -.40059967E-06  -.37313620E-06  -.34287192E-06  -.31016108E-06  -.27537140E-06
+  -.23888029E-06  -.20107120E-06  -.16232993E-06  -.12304104E-06  -.83584377E-07
+  -.44331695E-07  -.56434806E-08   .32134073E-07   .68671870E-07   .10366050E-06
+   .13681257E-06   .16786479E-06   .19657979E-06   .22274762E-06   .24618705E-06
+   .26674646E-06   .28430455E-06   .29877067E-06   .31008493E-06   .31821800E-06
+   .32317060E-06   .32497283E-06   .32368312E-06   .31938708E-06   .31219601E-06
+   .30224529E-06   .28969260E-06   .27471588E-06   .25751130E-06   .23829096E-06
+   .21728062E-06   .19471732E-06   .17084691E-06   .14592161E-06   .12019758E-06
+   .93932432E-07   .67382874E-07   .40802372E-07   .14438895E-07  -.11467220E-07
+  -.36685306E-07  -.60996253E-07  -.84194256E-07  -.10608840E-06  -.12650408E-06
+  -.14528422E-06  -.16229035E-06  -.17740342E-06  -.19052449E-06  -.20157520E-06
+  -.21049800E-06  -.21725624E-06  -.22183406E-06  -.22423607E-06  -.22448684E-06
+  -.22263029E-06  -.21872882E-06  -.21286239E-06  -.20512736E-06  -.19563530E-06
+  -.18451160E-06  -.17189408E-06  -.15793142E-06  -.14278157E-06  -.12661015E-06
+  -.10958873E-06  -.91893127E-07  -.73701757E-07  -.55193895E-07  -.36548042E-07
+  -.17940294E-07   .45721566E-09   .18477814E-07   .35961706E-07   .52757295E-07
+   .68722407E-07   .83725401E-07   .97646165E-07   .11037698E-06   .12182327E-06
+   .13190419E-06   .14055310E-06   .14771790E-06   .15336121E-06   .15746043E-06
+   .16000764E-06   .16100941E-06   .16048644E-06   .15847309E-06   .15501682E-06
+   .15017749E-06   .14402656E-06   .13664623E-06   .12812847E-06   .11857400E-06
+   .10809117E-06   .96794889E-07   .84805362E-07   .72246949E-07   .59246922E-07
+   .45934250E-07   .32438381E-07   .18888049E-07   .54101066E-08  -.78716033E-08
+  -.20837329E-07  -.33372431E-07  -.45368342E-07  -.56723446E-07  -.67343890E-07
+  -.77144299E-07  -.86048410E-07  -.93989599E-07  -.10091133E-06  -.10676748E-06
+  -.11152259E-06  -.11515198E-06  -.11764181E-06  -.11898900E-06  -.11920106E-06
+  -.11829587E-06  -.11630128E-06  -.11325473E-06  -.10920271E-06  -.10420021E-06
+  -.98310013E-07  -.91602046E-07  -.84152575E-07  -.76043412E-07  -.67361068E-07
+  -.58195880E-07  -.48641114E-07  -.38792064E-07  -.28745140E-07  -.18596965E-07
+  -.84434852E-08   .16208991E-08   .11504177E-07   .21117528E-07   .30376091E-07
+   .39199672E-07   .47513409E-07   .55248370E-07   .62342090E-07   .68739039E-07
+   .74391022E-07   .79257503E-07   .83305851E-07   .86511519E-07   .88858135E-07
+   .90337525E-07   .90949658E-07   .90702518E-07   .89611901E-07   .87701153E-07
+   .85000831E-07   .81548316E-07   .77387357E-07   .72567575E-07   .67143915E-07
+   .61176057E-07   .54727799E-07   .47866402E-07   .40661924E-07   .33186531E-07
+   .25513803E-07   .17718034E-07   .98735406E-08   .20539754E-08  -.56683371E-08
+  -.13223048E-07  -.20542401E-07  -.27561818E-07  -.34220446E-07  -.40461662E-07
+  -.46233533E-07  -.51489225E-07  -.56187359E-07  -.60292317E-07  -.63774481E-07
+  -.66610423E-07  -.68783032E-07  -.70281580E-07  -.71101733E-07  -.71245497E-07
+  -.70721109E-07  -.69542879E-07  -.67730968E-07  -.65311122E-07  -.62314357E-07
+  -.58776601E-07  -.54738292E-07  -.50243946E-07  -.45341690E-07  -.40082766E-07
+  -.34521021E-07  -.28712371E-07  -.22714259E-07  -.16585104E-07  -.10383749E-07
+  -.41689142E-08   .20013443E-08   .80701614E-08   .13982371E-07   .19684992E-07
+   .25127689E-07   .30263202E-07   .35047741E-07   .39441345E-07   .43408202E-07
+   .46916924E-07   .49940778E-07   .52457878E-07   .54451319E-07   .55909272E-07
+   .56825027E-07   .57196991E-07   .57028638E-07   .56328410E-07   .55109581E-07
+   .53390070E-07   .51192218E-07   .48542527E-07   .45471365E-07   .42012634E-07
+   .38203415E-07   .34083589E-07   .29695426E-07   .25083174E-07   .20292619E-07
+   .15370646E-07   .10364794E-07   .53228012E-08   .29216880E-09  -.46802806E-08
+  -.95488269E-08  -.14269262E-07  -.18799284E-07  -.23098861E-07  -.27130581E-07
+  -.30859964E-07  -.34255748E-07  -.37290143E-07  -.39939042E-07  -.42182212E-07
+  -.44003425E-07  -.45390572E-07  -.46335722E-07  -.46835150E-07  -.46889323E-07
+  -.46502848E-07  -.45684384E-07  -.44446511E-07  -.42805575E-07  -.40781491E-07
+  -.38397518E-07  -.35680007E-07  -.32658122E-07  -.29363538E-07  -.25830118E-07
+  -.22093576E-07  -.18191128E-07  -.14161122E-07  -.10042679E-07  -.58753140E-08
+  -.16985704E-08   .24483520E-08   .65269548E-08   .10499792E-07   .14330808E-07
+   .17985654E-07   .21431994E-07   .24639780E-07   .27581511E-07   .30232458E-07
+   .32570869E-07   .34578137E-07   .36238942E-07   .37541361E-07   .38476939E-07
+   .39040739E-07   .39231345E-07   .39050846E-07   .38504773E-07   .37602021E-07
+   .36354724E-07   .34778118E-07   .32890358E-07   .30712328E-07   .28267414E-07
+   .25581264E-07   .22681524E-07   .19597562E-07   .16360176E-07   .13001295E-07
+   .95536671E-08   .60505469E-08   .25253816E-08  -.98850406E-09  -.44582175E-08
+  -.78516009E-08  -.11137524E-07  -.14286166E-07  -.17269280E-07  -.20060440E-07
+  -.22635276E-07  -.24971676E-07  -.27049974E-07  -.28853110E-07  -.30366764E-07
+  -.31579467E-07  -.32482676E-07  -.33070833E-07  -.33341383E-07  -.33294777E-07
+  -.32934432E-07  -.32266678E-07  -.31300670E-07  -.30048275E-07  -.28523940E-07
+  -.26744529E-07  -.24729148E-07  -.22498940E-07  -.20076877E-07  -.17487520E-07
+  -.14756782E-07  -.11911668E-07  -.89800161E-08  -.59902277E-08  -.29709967E-08
+   .48962085E-10   .30411815E-08   .59777073E-08   .88313552E-08   .11575959E-07
+   .14186609E-07   .16639872E-07   .18913998E-07   .20989114E-07   .22847390E-07
+   .24473192E-07   .25853205E-07   .26976545E-07   .27834836E-07   .28422267E-07
+   .28735629E-07   .28774319E-07   .28540325E-07   .28038188E-07   .27274932E-07
+   .26259985E-07   .25005065E-07   .23524052E-07   .21832842E-07   .19949178E-07
+   .17892468E-07   .15683591E-07   .13344690E-07   .10898949E-07   .83703687E-08
+   .57835358E-08   .31633844E-08   .53496079E-09  -.20768142E-08  -.46473783E-08
+  -.71527561E-08  -.95697803E-08  -.11876303E-07  -.14051395E-07  -.16075536E-07
+  -.17930785E-07  -.19600937E-07  -.21071664E-07  -.22330633E-07  -.23367607E-07
+  -.24174529E-07  -.24745575E-07  -.25077197E-07  -.25168135E-07  -.25019416E-07
+  -.24634321E-07  -.24018343E-07  -.23179114E-07  -.22126319E-07  -.20871587E-07
+  -.19428371E-07  -.17811802E-07  -.16038537E-07  -.14126588E-07  -.12095145E-07
+  -.99643844E-08  -.77552685E-08  -.54893456E-08  -.31885399E-08  -.87494259E-09
+   .14293985E-08   .37026874E-08   .59235836E-08   .80714010E-08   .10126298E-07
+   .12069459E-07   .13883266E-07   .15551453E-07   .17059256E-07   .18393537E-07
+   .19542898E-07   .20497775E-07   .21250519E-07   .21795450E-07   .22128901E-07
+   .22249236E-07   .22156852E-07   .21854159E-07   .21345546E-07   .20637323E-07
+   .19737650E-07   .18656447E-07   .17405284E-07   .15997265E-07   .14446889E-07
+   .12769907E-07   .10983161E-07   .91044200E-08   .71522017E-08   .51455943E-08
+   .31040708E-08   .10473023E-08  -.10050297E-08  -.30334204E-08  -.50187256E-08
+  -.69423414E-08  -.87863764E-08  -.10533817E-07  -.12168682E-07  -.13676169E-07
+  -.15042786E-07  -.16256471E-07  -.17306699E-07  -.18184570E-07  -.18882881E-07
+  -.19396187E-07  -.19720837E-07  -.19855004E-07  -.19798682E-07  -.19553679E-07
+  -.19123589E-07  -.18513742E-07  -.17731144E-07  -.16784400E-07  -.15683625E-07
+  -.14440331E-07  -.13067315E-07  -.11578524E-07  -.99889194E-08  -.83143240E-08
+  -.65712706E-08  -.47768376E-08  -.29484831E-08  -.11038762E-08   .73927193E-09
+   .25633767E-08   .43511461E-08   .60857437E-08   .77509464E-08   .93312955E-08
+   .10812239E-07   .12180263E-07   .13423015E-07   .14529415E-07   .15489751E-07
+   .16295766E-07   .16940725E-07   .17419474E-07   .17728474E-07   .17865829E-07
+   .17831292E-07   .17626259E-07   .17253743E-07   .16718342E-07   .16026179E-07
+   .15184836E-07   .14203274E-07   .13091740E-07   .11861660E-07   .10525524E-07
+   .90967615E-08   .75896058E-08   .60189536E-08   .44002190E-08   .27491839E-08
+   .10818456E-08  -.58573710E-09  -.22375988E-08  -.38580192E-08  -.54316723E-08
+  -.69437698E-08  -.83801989E-08  -.97276528E-08  -.10973753E-07  -.12107165E-07
+  -.13117697E-07  -.13996393E-07  -.14735613E-07  -.15329091E-07  -.15771995E-07
+  -.16060960E-07  -.16194115E-07  -.16171090E-07  -.15993014E-07  -.15662492E-07
+  -.15183573E-07  -.14561705E-07  -.13803671E-07  -.12917520E-07  -.11912484E-07
+  -.10798881E-07  -.95880102E-08  -.82920377E-08  -.69238763E-08  -.54970579E-08
+  -.40256017E-08  -.25238768E-08  -.10064626E-08   .51199289E-09   .20169133E-08
+   .34939332E-08   .49290337E-08   .63086740E-08   .76199191E-08   .88505607E-08
+   .99892309E-08   .11025507E-07   .11950005E-07   .12754466E-07   .13431823E-07
+   .13976271E-07   .14383307E-07   .14649775E-07   .14773884E-07   .14755221E-07
+   .14594743E-07   .14294764E-07   .13858923E-07   .13292145E-07   .12600584E-07
+   .11791563E-07   .10873492E-07   .98557839E-08   .87487558E-08   .75635285E-08
+   .63119145E-08   .50063017E-08   .36595325E-08   .22847768E-08   .89540360E-09
+  -.49514886E-09  -.18735024E-08  -.32264660E-08  -.45411610E-08  -.58051424E-08
+  -.70065170E-08  -.81340553E-08  -.91772964E-08  -.10126645E-07  -.10973457E-07
+  -.11710118E-07  -.12330110E-07  -.12828072E-07  -.13199840E-07  -.13442488E-07
+  -.13554347E-07  -.13535013E-07  -.13385347E-07  -.13107458E-07  -.12704675E-07
+  -.12181513E-07  -.11543624E-07  -.10797735E-07  -.99515801E-08  -.90138176E-08
+  -.79939443E-08  -.69021985E-08  -.57494591E-08  -.45471388E-08  -.33070717E-08
+  -.20413977E-08  -.76244263E-09   .51740162E-09   .17857971E-08   .30305774E-08
+   .42398632E-08   .54021744E-08   .65065387E-08   .75425959E-08   .85006951E-08
+   .93719851E-08   .10148495E-07   .10823207E-07   .11390115E-07   .11844281E-07
+   .12181878E-07   .12400218E-07   .12497781E-07   .12474214E-07   .12330338E-07
+   .12068125E-07   .11690681E-07   .11202202E-07   .10607937E-07   .99141297E-08
+   .91279545E-08   .82574431E-08   .73114015E-08   .62993212E-08   .52312840E-08
+   .41178627E-08   .29700187E-08   .17989945E-08   .61620490E-09  -.56687514E-09
+  -.17388223E-08  -.28883752E-08  -.40045424E-08  -.50767057E-08  -.60947199E-08
+ 34.2040403932785111 T
+ Non local Part
+ 0 2 0.887630909308563698
+ 10.5461618117312579 -0.686088657688400244E-01 -0.686088657688400244E-01 -0.493676121990704127E-04
+ Reciprocal Space Part
+   .40918416E+01   .40810480E+01   .40487894E+01   .39954305E+01   .39215730E+01
+   .38280463E+01   .37158951E+01   .35863632E+01   .34408749E+01   .32810137E+01
+   .31084988E+01   .29251594E+01   .27329086E+01   .25337153E+01   .23295769E+01
+   .21224910E+01   .19144285E+01   .17073073E+01   .15029673E+01   .13031481E+01
+   .11094677E+01   .92340443E+00   .74628166E+00   .57925497E+00   .42330281E+00
+   .27922006E+00   .14761484E+00   .28908392E-01  -.76662076E-01  -.16903766E+00
+  -.24832944E+00  -.31480776E+00  -.36888938E+00  -.41112296E+00  -.44217296E+00
+  -.46280253E+00  -.47385567E+00  -.47623897E+00  -.47090340E+00  -.45882631E+00
+  -.44099419E+00  -.41838620E+00  -.39195901E+00  -.36263290E+00  -.33127957E+00
+  -.29871153E+00  -.26567343E+00  -.23283513E+00  -.20078679E+00  -.17003569E+00
+  -.14100495E+00  -.11403393E+00  -.89380158E-01  -.67222743E-01  -.47667037E-01
+  -.30750345E-01  -.16448518E-01  -.46832123E-02   .46703985E-02   .11775645E-01
+   .16826323E-01   .20038774E-01   .21644240E-01   .21881659E-01   .20991006E-01
+   .19207307E-01   .16755380E-01   .13845392E-01   .10669236E-01   .73977572E-02
+   .41788116E-02   .11361305E-02  -.16310617E-02  -.40477350E-02  -.60621220E-02
+  -.76442521E-02  -.87840427E-02  -.94890412E-02  -.97819144E-02  -.96977806E-02
+  -.92814722E-02  -.85848156E-02  -.76640037E-02  -.65771271E-02  -.53819226E-02
+  -.41337828E-02  -.28840605E-02  -.16786914E-02  -.55714419E-03   .44830034E-03
+   .13129518E-02   .20198124E-02   .25594051E-02   .29293596E-02   .31337929E-02
+   .31825249E-02   .30901699E-02   .28751469E-02   .25586485E-02   .21636082E-02
+ Real Space Part
+  -.89852328E+01  -.89351603E+01  -.87853324E+01  -.85369186E+01  -.81918690E+01
+  -.77529143E+01  -.72235654E+01  -.66081105E+01  -.59116078E+01  -.51398741E+01
+  -.42994648E+01  -.33976468E+01  -.24423601E+01  -.14421684E+01  -.40619723E+00
+   .65594082E+00   .17342346E+01   .28183752E+01   .38978693E+01   .49621629E+01
+   .60007743E+01   .70034334E+01   .79602247E+01   .88617318E+01   .96991790E+01
+   .10464567E+02   .11150799E+02   .11751797E+02   .12262596E+02   .12679430E+02
+   .12999784E+02   .13222437E+02   .13347470E+02   .13376253E+02   .13311415E+02
+   .13156773E+02   .12917257E+02   .12598799E+02   .12208215E+02   .11753062E+02
+   .11241493E+02   .10682095E+02   .10083727E+02   .94553555E+01   .88058962E+01
+   .81440588E+01   .74782043E+01   .68162150E+01   .61653813E+01   .55323049E+01
+   .49228231E+01   .43419525E+01   .37938540E+01   .32818180E+01   .28082701E+01
+   .23747943E+01   .19821736E+01   .16304455E+01   .13189689E+01   .10465023E+01
+   .81128721E+00   .61113767E+00   .44353042E+00   .30569490E+00   .19469996E+00
+   .10753568E+00   .41188315E-01  -.72927707E-02  -.40737456E-01  -.61806956E-01
+  -.72956061E-01  -.76405466E-01  -.74123863E-01  -.67819191E-01  -.58938214E-01
+  -.48673441E-01  -.37976249E-01  -.27575017E-01  -.17997039E-01  -.95930207E-02
+  -.25629908E-02   .30174056E-02   .71711827E-02   .99956443E-02   .11640013E-01
+   .12285534E-01   .12128389E-01   .11365569E-01   .10183764E-01   .87511649E-02
+   .72119904E-02   .56834614E-02   .42548962E-02   .29885528E-02   .19218335E-02
+   .10704690E-02   .43232016E-03  -.85335592E-05  -.27770489E-03  -.40664440E-03
+  -.47591268E+02  -.47002038E+02  -.45244157E+02  -.42346860E+02  -.38358263E+02
+  -.33344445E+02  -.27388211E+02  -.20587530E+02  -.13053707E+02  -.49093048E+01
+   .37141235E+01   .12678452E+02   .21841504E+02   .31059614E+02   .40190197E+02
+   .49094251E+02   .57638765E+02   .65698967E+02   .73160387E+02   .79920676E+02
+   .85891173E+02   .90998166E+02   .95183856E+02   .98406981E+02   .10064312E+03
+   .10188468E+03   .10214050E+03   .10143527E+03   .99808519E+02   .97313459E+02
+   .94015549E+02   .89990881E+02   .85324409E+02   .80108077E+02   .74438868E+02
+   .68416830E+02   .62143123E+02   .55718111E+02   .49239557E+02   .42800940E+02
+   .36489933E+02   .30387059E+02   .24564559E+02   .19085473E+02   .14002957E+02
+   .93598315E+01   .51883606E+01   .15102651E+01  -.16630524E+01  -.43300792E+01
+  -.64985830E+01  -.81848425E+01  -.94127437E+01  -.10212769E+02  -.10620907E+02
+  -.10677511E+02  -.10426141E+02  -.99124006E+01  -.91828183E+01  -.82837741E+01
+  -.72605091E+01  -.61562278E+01  -.50113116E+01  -.38626538E+01  -.27431251E+01
+  -.16811724E+01  -.70055335E+00   .17979663E+00   .94577109E+00   .15879806E+01
+   .21015339E+01   .24857243E+01   .27436372E+01   .28816930E+01   .29091429E+01
+   .28375332E+01   .26801554E+01   .24514970E+01   .21667068E+01   .18410903E+01
+   .14896434E+01   .11266371E+01   .76525835E+00   .41731438E+00   .93002722E-01
+  -.19925114E+00  -.45288940E+00  -.66325333E+00  -.82755458E+00  -.94479199E+00
+  -.10156207E+01  -.10421813E+01  -.10278969E+01  -.97724777E+00  -.89553096E+00
+  -.78861428E+00  -.66269256E+00  -.52405342E+00  -.37885937E+00  -.23295165E+00
+ Real Space Part
+   .23125182E+04   .23138226E+04   .23176301E+04   .23236269E+04   .23313008E+04
+   .23399582E+04   .23487452E+04   .23566759E+04   .23626628E+04   .23655522E+04
+   .23641613E+04   .23573157E+04   .23438879E+04   .23228337E+04   .22932270E+04
+   .22542908E+04   .22054239E+04   .21462226E+04   .20764972E+04   .19962821E+04
+   .19058392E+04   .18056555E+04   .16964345E+04   .15790816E+04   .14546838E+04
+   .13244850E+04   .11898578E+04   .10522713E+04   .91325778E+03   .77437736E+03
+   .63718337E+03   .50318807E+03   .37383039E+03   .25044616E+03   .13424185E+03
+   .26272148E+02  -.72577923E+02  -.16160614E+03  -.24030126E+03  -.30834624E+03
+  -.36561656E+03  -.41217402E+03  -.44825622E+03  -.47426240E+03  -.49073608E+03
+  -.49834517E+03  -.49786021E+03  -.49013145E+03  -.47606549E+03  -.45660202E+03
+  -.43269145E+03  -.40527375E+03  -.37525928E+03  -.34351168E+03  -.31083343E+03
+  -.27795399E+03  -.24552084E+03  -.21409344E+03  -.18413983E+03  -.15603596E+03
+  -.13006746E+03  -.10643346E+03  -.85252384E+02  -.66569116E+02  -.50363402E+02
+  -.36558998E+02  -.25033261E+02  -.15626846E+02  -.81532182E+01  -.24077011E+01
+   .18241426E+01   .47589879E+01   .66092016E+01   .75773610E+01   .78518715E+01
+   .76036824E+01   .69840590E+01   .61233392E+01   .51305795E+01   .40939733E+01
+   .30819140E+01   .21445693E+01   .13158301E+01   .61550692E+00   .51649049E-01
+  -.37711851E+00  -.67933615E+00  -.86860399E+00  -.96168860E+00  -.97688296E+00
+  -.93264404E+00  -.84651624E+00  -.73433581E+00  -.60969931E+00  -.48367061E+00
+  -.36469378E+00  -.25867573E+00  -.16919993E+00  -.97833616E-01  -.44492146E-01
+ Non local Part
+ 1 2 0.887630909308563698
+ -2.36278393853791124 0.156423412382481003 0.156423412382481003 0.180558482747100561E-01
+   .00000000E+00   .15782231E+00   .31448783E+00   .46885407E+00   .61980695E+00
+   .76627438E+00   .90723915E+00   .10417509E+01   .11689371E+01   .12880125E+01
+   .13982874E+01   .14991742E+01   .15901924E+01   .16709722E+01   .17412556E+01
+   .18008967E+01   .18498599E+01   .18882164E+01   .19161396E+01   .19338985E+01
+   .19418510E+01   .19404349E+01   .19301586E+01   .19115916E+01   .18853536E+01
+   .18521040E+01   .18125308E+01   .17673405E+01   .17172474E+01   .16629637E+01
+   .16051903E+01   .15446085E+01   .14818722E+01   .14176013E+01   .13523764E+01
+   .12867338E+01   .12211623E+01   .11561012E+01   .10919383E+01   .10290104E+01
+   .96760317E+00   .90795340E+00   .85025074E+00   .79464083E+00   .74122867E+00
+   .69008247E+00   .64123778E+00   .59470180E+00   .55045774E+00   .50846910E+00
+   .46868385E+00   .43103837E+00   .39546101E+00   .36187540E+00   .33020325E+00
+   .30036676E+00   .27229052E+00   .24590302E+00   .22113763E+00   .19793324E+00
+   .17623439E+00   .15599117E+00   .13715875E+00   .11969664E+00   .10356783E+00
+   .88737744E-01   .75173132E-01   .62840952E-01   .51707283E-01   .41736319E-01
+   .32889482E-01   .25124702E-01   .18395863E-01   .12652459E-01   .78394571E-02
+   .38973649E-02   .76250732E-03  -.16325102E-02  -.33581673E-02  -.44872488E-02
+  -.50939484E-02  -.52528877E-02  -.50380846E-02  -.45219058E-02  -.37740357E-02
+  -.28604968E-02  -.18427480E-02  -.77688953E-03   .28700429E-03   .13054078E-02
+   .22417085E-02   .30664077E-02   .37571545E-02   .42986170E-02   .46821986E-02
+   .49056124E-02   .49723299E-02   .48909230E-02   .46743223E-02   .43390146E-02
+ Real Space Part
+   .00000000E+00   .46183593E+01   .91839852E+01   .13645085E+02   .17951723E+02
+   .22056700E+02   .25916361E+02   .29491332E+02   .32747150E+02   .35654789E+02
+   .38191063E+02   .40338901E+02   .42087487E+02   .43432275E+02   .44374865E+02
+   .44922760E+02   .45089013E+02   .44891766E+02   .44353696E+02   .43501406E+02
+   .42364738E+02   .40976069E+02   .39369572E+02   .37580491E+02   .35644419E+02
+   .33596619E+02   .31471387E+02   .29301475E+02   .27117590E+02   .24947963E+02
+   .22818010E+02   .20750072E+02   .18763254E+02   .16873334E+02   .15092769E+02
+   .13430768E+02   .11893433E+02   .10483962E+02   .92028986E+01   .80484223E+01
+   .70166631E+01   .61020353E+01   .52975766E+01   .45952840E+01   .39864373E+01
+   .34619032E+01   .30124126E+01   .26288075E+01   .23022521E+01   .20244080E+01
+   .17875703E+01   .15847674E+01   .14098241E+01   .12573917E+01   .11229479E+01
+   .10027707E+01   .89389006E+00   .79402302E+00   .70149556E+00   .61515664E+00
+   .53428835E+00   .45851593E+00   .38772108E+00   .32196144E+00   .26139832E+00
+   .20623437E+00   .15666210E+00   .11282381E+00   .74782699E-01   .42504703E-01
+   .15850135E-01  -.54260761E-02  -.21666964E-01  -.33300429E-01  -.40822048E-01
+  -.44775309E-01  -.45730725E-01  -.44265091E-01  -.40942010E-01  -.36294564E-01
+  -.30810790E-01  -.24922406E-01  -.18996986E-01  -.13333606E-01  -.81617858E-02
+  -.36434159E-02   .12275098E-03   .30945578E-02   .52783894E-02   .67201682E-02
+   .74959356E-02   .77025124E-02   .74486691E-02   .68471570E-02   .60078640E-02
+   .50322718E-02   .40092984E-02   .30125341E-02   .20988009E-02   .13079097E-02
+   .00000000E+00  -.30963878E+01  -.61180283E+01  -.89916665E+01  -.11647000E+02
+  -.14018078E+02  -.16044607E+02  -.17673142E+02  -.18858126E+02  -.19562772E+02
+  -.19759764E+02  -.19431749E+02  -.18571640E+02  -.17182696E+02  -.15278403E+02
+  -.12882132E+02  -.10026623E+02  -.67532642E+01  -.31112167E+01   .84361130E+00
+   .50497128E+01   .94412281E+01   .13949260E+02   .18503230E+02   .23032249E+02
+   .27466466E+02   .31738376E+02   .35784060E+02   .39544316E+02   .42965689E+02
+   .46001351E+02   .48611836E+02   .50765606E+02   .52439450E+02   .53618701E+02
+   .54297283E+02   .54477580E+02   .54170142E+02   .53393238E+02   .52172270E+02
+   .50539059E+02   .48531031E+02   .46190318E+02   .43562798E+02   .40697093E+02
+   .37643554E+02   .34453250E+02   .31176986E+02   .27864361E+02   .24562904E+02
+   .21317280E+02   .18168596E+02   .15153814E+02   .12305274E+02   .96503390E+01
+   .72111613E+01   .50045695E+01   .30420718E+01   .13299714E+01  -.13041481E+00
+  -.13424450E+01  -.23137598E+01  -.30558220E+01  -.35834032E+01  -.39140306E+01
+  -.40674104E+01  -.40648419E+01  -.39286362E+01  -.36815523E+01  -.33462647E+01
+  -.29448698E+01  -.24984439E+01  -.20266567E+01  -.15474488E+01  -.10767741E+01
+  -.62841090E+00  -.21384087E+00   .15780646E+00   .47974600E+00   .74747148E+00
+   .95863782E+00   .11128982E+01   .12117036E+01   .12580726E+01   .12563402E+01
+   .12118936E+01   .11309030E+01   .10200557E+01   .88629967E+00   .73660327E+00
+   .57773694E+00   .41608046E+00   .25745971E+00   .10701503E+00  -.30897617E-01
+  -.15277234E+00  -.25598689E+00  -.33880546E+00  -.40035346E+00  -.44056705E+00
+ Real Space Part
+   .00000000E+00   .15119748E+03   .30090828E+03   .44766338E+03   .59002898E+03
+   .72662360E+03   .85613466E+03   .97733434E+03   .10890945E+04   .11904003E+04
+   .12803631E+04   .13582310E+04   .14233984E+04   .14754134E+04   .15139834E+04
+   .15389783E+04   .15504320E+04   .15485409E+04   .15336604E+04   .15062994E+04
+   .14671116E+04   .14168857E+04   .13565323E+04   .12870697E+04   .12096077E+04
+   .11253301E+04   .10354756E+04   .94131834E+03   .84414811E+03   .74524979E+03
+   .64588378E+03   .54726679E+03   .45055379E+03   .35682140E+03   .26705302E+03
+   .18212600E+03   .10280109E+03   .29714404E+02  -.36628057E+02  -.95853212E+02
+  -.14772102E+03  -.19212201E+03  -.22907233E+03  -.25870651E+03  -.28126812E+03
+  -.29709876E+03  -.30662543E+03  -.31034691E+03  -.30881937E+03  -.30264153E+03
+  -.29243985E+03  -.27885407E+03  -.26252336E+03  -.24407345E+03  -.22410498E+03
+  -.20318325E+03  -.18182959E+03  -.16051439E+03  -.13965191E+03  -.11959685E+03
+  -.10064263E+03  -.83021355E+02  -.66905186E+02  -.52409174E+02  -.39595178E+02
+  -.28476770E+02  -.19024858E+02  -.11173835E+02  -.48280034E+01   .13190512E+00
+   .38423330E+01   .64507843E+01   .81101500E+01   .89735923E+01   .91900800E+01
+   .89006397E+01   .82353529E+01   .73111084E+01   .62300878E+01   .50789431E+01
+   .39286056E+01   .28346501E+01   .18381286E+01   .96678067E+00   .23652637E+00
+  -.34685338E+00  -.78593624E+00  -.10898598E+01  -.12725764E+01  -.13512207E+01
+  -.13446385E+01  -.12721114E+01  -.11522979E+01  -.10024030E+01  -.83757360E+00
+  -.67050965E+00  -.51127257E+00  -.36726631E+00  -.24336230E+00  -.14213737E+00
+ PAW radial sets
+ 327 0.590240404345511394
+(5E20.12)
+ augmentation charges (non sperical)
+  -.937646889450E-01  -.774518202843E-03  -.573275050987E-01   .299876319582E-03  -.774518202843E-03
+  -.112730604537E-04   .562997646001E-05   .740352939618E-06  -.573275050987E-01   .562997646001E-05
+   .353661472789E-01   .156923926472E-02   .299876319582E-03   .740352939618E-06   .156923926472E-02
+   .130747060367E-04
+ uccopancies in atom
+   .200000000000E+01   .000000000000E+00   .000000000000E+00   .000000000000E+00   .000000000000E+00
+   .000000000000E+00   .000000000000E+00   .000000000000E+00   .000000000000E+00   .000000000000E+00
+   .999999999728E+00   .000000000000E+00   .000000000000E+00   .000000000000E+00   .000000000000E+00
+   .000000000000E+00
+ grid
+   .280527516333E-04   .289225357721E-04   .298192878340E-04   .307438439676E-04   .316970662468E-04
+   .326798434741E-04   .336930920097E-04   .347377566259E-04   .358148113878E-04   .369252605618E-04
+   .380701395518E-04   .392505158649E-04   .404674901063E-04   .417221970061E-04   .430158064768E-04
+   .443495247045E-04   .457245952736E-04   .471423003259E-04   .486039617567E-04   .501109424469E-04
+   .516646475341E-04   .532665257223E-04   .549180706334E-04   .566208221993E-04   .583763680979E-04
+   .601863452337E-04   .620524412639E-04   .639763961718E-04   .659600038897E-04   .680051139712E-04
+   .701136333158E-04   .722875279473E-04   .745288248462E-04   .768396138405E-04   .792220495539E-04
+   .816783534148E-04   .842108157277E-04   .868217978087E-04   .895137341871E-04   .922891348757E-04
+   .951505877110E-04   .981007607661E-04   .101142404838E-03   .104278356015E-03   .107511538316E-03
+   .110844966423E-03   .114281748487E-03   .117825089030E-03   .121478291928E-03   .125244763500E-03
+   .129128015674E-03   .133131669268E-03   .137259457366E-03   .141515228795E-03   .145902951719E-03
+   .150426717332E-03   .155090743682E-03   .159899379594E-03   .164857108732E-03   .169968553777E-03
+   .175238480738E-03   .180671803396E-03   .186273587883E-03   .192049057411E-03   .198003597136E-03
+   .204142759186E-03   .210472267831E-03   .216998024827E-03   .223726114913E-03   .230662811488E-03
+   .237814582461E-03   .245188096279E-03   .252790228147E-03   .260628066437E-03   .268708919298E-03
+   .277040321473E-03   .285630041319E-03   .294486088053E-03   .303616719224E-03   .313030448405E-03
+   .322736053137E-03   .332742583110E-03   .343059368603E-03   .353696029184E-03   .364662482677E-03
+   .375968954412E-03   .387625986760E-03   .399644448959E-03   .412035547251E-03   .424810835334E-03
+   .437982225128E-03   .451561997889E-03   .465562815655E-03   .479997733055E-03   .494880209481E-03
+   .510224121638E-03   .526043776481E-03   .542353924558E-03   .559169773761E-03   .576507003509E-03
+   .594381779364E-03   .612810768108E-03   .631811153281E-03   .651400651203E-03   .671597527497E-03
+   .692420614113E-03   .713889326894E-03   .736023683677E-03   .758844322957E-03   .782372523134E-03
+   .806630222348E-03   .831640038941E-03   .857425292542E-03   .884010025812E-03   .911419026863E-03
+   .939677852369E-03   .968812851398E-03   .998851189976E-03   .102982087642E-02   .106175078746E-02
+   .109467069516E-02   .112861129465E-02   .116360423281E-02   .119968213770E-02   .123687864907E-02
+   .127522844964E-02   .131476729750E-02   .135553205942E-02   .139756074525E-02   .144089254332E-02
+   .148556785704E-02   .153162834252E-02   .157911694742E-02   .162807795104E-02   .167855700554E-02
+   .173060117855E-02   .178425899706E-02   .183958049263E-02   .189661724807E-02   .195542244556E-02
+   .201605091616E-02   .207855919103E-02   .214300555407E-02   .220945009629E-02   .227795477185E-02
+   .234858345582E-02   .242140200372E-02   .249647831295E-02   .257388238610E-02   .265368639620E-02
+   .273596475402E-02   .282079417747E-02   .290825376313E-02   .299842505997E-02   .309139214544E-02
+   .318724170380E-02   .328606310702E-02   .338794849805E-02   .349299287677E-02   .360129418856E-02
+   .371295341562E-02   .382807467115E-02   .394676529639E-02   .406913596075E-02   .419530076495E-02
+   .432537734748E-02   .445948699420E-02   .459775475151E-02   .474030954290E-02   .488728428917E-02
+   .503881603237E-02   .519504606359E-02   .535612005467E-02   .552218819408E-02   .569340532692E-02
+   .586993109928E-02   .605193010718E-02   .623957204995E-02   .643303188850E-02   .663249000848E-02
+   .683813238844E-02   .705015077324E-02   .726874285286E-02   .749411244673E-02   .772646969374E-02
+   .796603124822E-02   .821302048191E-02   .846766769229E-02   .873021031726E-02   .900089315657E-02
+   .927996860004E-02   .956769686293E-02   .986434622857E-02   .101701932985E-01   .104855232502E-01
+   .108106301035E-01   .111458169942E-01   .114913964569E-01   .118476907164E-01   .122150319883E-01
+   .125937627887E-01   .129842362533E-01   .133868164670E-01   .138018788033E-01   .142298102742E-01
+   .146710098911E-01   .151258890370E-01   .155948718499E-01   .160783956182E-01   .165769111888E-01
+   .170908833870E-01   .176207914503E-01   .181671294750E-01   .187304068773E-01   .193111488675E-01
+   .199098969406E-01   .205272093808E-01   .211636617819E-01   .218198475842E-01   .224963786278E-01
+   .231938857233E-01   .239130192394E-01   .246544497100E-01   .254188684590E-01   .262069882449E-01
+   .270195439257E-01   .278572931437E-01   .287210170323E-01   .296115209441E-01   .305296352018E-01
+   .314762158727E-01   .324521455667E-01   .334583342591E-01   .344957201394E-01   .355652704861E-01
+   .366679825681E-01   .378048845754E-01   .389770365768E-01   .401855315093E-01   .414314961966E-01
+   .427160923999E-01   .440405179010E-01   .454060076197E-01   .468138347644E-01   .482653120201E-01
+   .497617927717E-01   .513046723665E-01   .528953894146E-01   .545354271311E-01   .562263147182E-01
+   .579696287918E-01   .597669948511E-01   .616200887945E-01   .635306384819E-01   .655004253464E-01
+   .675312860547E-01   .696251142200E-01   .717838621675E-01   .740095427550E-01   .763042312493E-01
+   .786700672619E-01   .811092567431E-01   .836240740397E-01   .862168640153E-01   .888900442366E-01
+   .916461072276E-01   .944876227942E-01   .974172404194E-01   .100437691734E+00   .103551793066E+00
+   .106762448061E+00   .110072650395E+00   .113485486565E+00   .117004138763E+00   .120631887848E+00
+   .124372116402E+00   .128228311886E+00   .132204069889E+00   .136303097485E+00   .140529216684E+00
+   .144886368000E+00   .149378614125E+00   .154010143714E+00   .158785275294E+00   .163708461288E+00
+   .168784292168E+00   .174017500736E+00   .179412966535E+00   .184975720401E+00   .190710949150E+00
+   .196624000420E+00   .202720387652E+00   .209005795233E+00   .215486083798E+00   .222167295690E+00
+   .229055660599E+00   .236157601368E+00   .243479739980E+00   .251028903739E+00   .258812131627E+00
+   .266836680875E+00   .275110033725E+00   .283639904409E+00   .292434246341E+00   .301501259532E+00
+   .310849398238E+00   .320487378843E+00   .330424187982E+00   .340669090926E+00   .351231640216E+00
+   .362121684576E+00   .373349378090E+00   .384925189674E+00   .396859912833E+00   .409164675732E+00
+   .421850951565E+00   .434930569259E+00   .448415724497E+00   .462318991095E+00   .476653332723E+00
+   .491432114994E+00   .506669117928E+00   .522378548794E+00   .538575055366E+00   .555273739575E+00
+   .572490171592E+00   .590240404346E+00
+ aepotential
+   .363639741525E+05   .353486988431E+05   .343218421719E+05   .332873506987E+05   .322493425013E+05
+   .312116817821E+05   .301779824554E+05   .291515900552E+05   .281355719873E+05   .271327122522E+05
+   .261455097070E+05   .251761801616E+05   .242266612837E+05   .232986206673E+05   .223934661094E+05
+   .215123579591E+05   .206562230842E+05   .198257700763E+05   .190215053474E+05   .182437497397E+05
+   .174926553864E+05   .167682225150E+05   .160703159665E+05   .153986812261E+05   .147529597911E+05
+   .141327037385E+05   .135373894181E+05   .129664301650E+05   .124191880122E+05   .118949843633E+05
+   .113931096827E+05   .109128321163E+05   .104534052295E+05   .100140747189E+05   .959408436168E+04
+   .919268105970E+04   .880911918884E+04   .844266424842E+04   .809259589992E+04   .775821039989E+04
+   .743882261121E+04   .713376751399E+04   .684240134668E+04   .656410242701E+04   .629827164939E+04
+   .604433276833E+04   .580173243593E+04   .556994011018E+04   .534844775879E+04   .513676946601E+04
+   .493444100413E+04   .474101918523E+04   .455608133122E+04   .437922451875E+04   .421006498213E+04
+   .404823730666E+04   .389339377076E+04   .374520359187E+04   .360335219401E+04   .346754051519E+04
+   .333748429799E+04   .321291338902E+04   .309357108986E+04   .297921350116E+04   .286960890600E+04
+   .276453716092E+04   .266378912080E+04   .256716609088E+04   .247447928324E+04   .238554932784E+04
+   .230020577148E+04   .221828663647E+04   .213963796492E+04   .206411341185E+04   .199157384772E+04
+   .192188698360E+04   .185492700868E+04   .179057426100E+04   .172871489759E+04   .166924060140E+04
+   .161204828066E+04   .155703980758E+04   .150412175443E+04   .145320515704E+04   .140420526364E+04
+   .135704135019E+04   .131163647545E+04   .126791731834E+04   .122581396868E+04   .118525976774E+04
+   .114619113374E+04   .110854740959E+04   .107227071448E+04   .103730579901E+04   .100359991984E+04
+   .971102708549E+03   .939766055312E+03   .909543996388E+03   .880392605856E+03   .852269898434E+03
+   .825135730040E+03   .798951711238E+03   .773681119698E+03   .749288819036E+03   .725741183375E+03
+   .703006024362E+03   .681052521465E+03   .659851157598E+03   .639373657217E+03   .619592927130E+03
+   .600483001830E+03   .582018989710E+03   .564177023819E+03   .546934214176E+03   .530268602534E+03
+   .514159120016E+03   .498585546066E+03   .483528470409E+03   .468969255931E+03   .454890004293E+03
+   .441273522745E+03   .428103292723E+03   .415363439803E+03   .403038705661E+03   .391114420680E+03
+   .379576478711E+03   .368411312191E+03   .357605868845E+03   .347147590092E+03   .337024389275E+03
+   .327224631997E+03   .317737116800E+03   .308551056886E+03   .299656062835E+03   .291042125975E+03
+   .282699602499E+03   .274619198521E+03   .266791955511E+03   .259209236639E+03   .251862713713E+03
+   .244744354458E+03   .237846410836E+03   .231161407375E+03   .224682130329E+03   .218401617250E+03
+   .212313147000E+03   .206410230161E+03   .200686599981E+03   .195136203508E+03   .189753193401E+03
+   .184531919758E+03   .179466922520E+03   .174552924136E+03   .169784822509E+03   .165157684250E+03
+   .160666738222E+03   .156307369361E+03   .152075112703E+03   .147965647713E+03   .143974792800E+03
+   .140098500097E+03   .136332850405E+03   .132674048320E+03   .129118417754E+03   .125662397229E+03
+   .122302535831E+03   .119035488956E+03   .115858014436E+03   .112766968678E+03   .109759303081E+03
+   .106832060482E+03   .103982371805E+03   .101207452823E+03   .985046010377E+02   .958711926753E+02
+   .933046798103E+02   .908025876049E+02   .883625116361E+02   .859821153174E+02   .836591274767E+02
+   .813913399403E+02   .791766052946E+02   .770128346760E+02   .748979956694E+02   .728301103007E+02
+   .708072530777E+02   .688275491452E+02   .668891724779E+02   .649903441822E+02   .631293308353E+02
+   .613044429175E+02   .595140333034E+02   .577564958085E+02   .560302638159E+02   .543338089527E+02
+   .526656398285E+02   .510243008416E+02   .494083710310E+02   .478164629940E+02   .462472218524E+02
+   .446993242848E+02   .431714775948E+02   .416624188544E+02   .401709140744E+02   .386957574524E+02
+   .372357706445E+02   .357898021135E+02   .343567265021E+02   .329354440718E+02   .315248801825E+02
+   .301239848158E+02   .287317321592E+02   .273471202133E+02   .259691704701E+02   .245969276151E+02
+   .232294592857E+02   .218658558680E+02   .205052303380E+02   .191467181433E+02   .177894771268E+02
+   .164326874903E+02   .150755517980E+02   .137172950157E+02   .123571645916E+02   .109944305686E+02
+   .962838573530E+01   .825834580743E+01   .688364964536E+01   .550365950006E+01   .411776129127E+01
+   .272536491297E+01   .132590456771E+01  -.811608726201E-01  -.149634748076E+01  -.292014586199E+01
+  -.435302071851E+01  -.579541038874E+01  -.724772636160E+01  -.871035276612E+01  -.101836458321E+02
+  -.116679333222E+02  -.131635139298E+02  -.146706566387E+02  -.161896000369E+02  -.177205515777E+02
+  -.192636867748E+02  -.208191483196E+02  -.223870451014E+02  -.239674511108E+02  -.255604041983E+02
+  -.271659046567E+02  -.287839135878E+02  -.304143510061E+02  -.320570936226E+02  -.337119722409E+02
+  -.353787686852E+02  -.370572121637E+02  -.387469749575E+02  -.404476673028E+02  -.421588313190E+02
+  -.438799338088E+02  -.456103577416E+02  -.473493922075E+02  -.490962206156E+02  -.508499069039E+02
+  -.526093795307E+02  -.543734130444E+02  -.561406070829E+02  -.579093627492E+02  -.596778564634E+02
+  -.614440116193E+02  -.632054686969E+02  -.649595549163E+02  -.667032550900E+02  -.684331860342E+02
+  -.701455777437E+02  -.718362654769E+02  -.735006978979E+02  -.751339673772E+02  -.767308693647E+02
+  -.782859982940E+02  -.797938876916E+02  -.812492020575E+02  -.826469878511E+02  -.839829910573E+02
+  -.852540490827E+02  -.864585671912E+02  -.875970892780E+02  -.886729693113E+02  -.896931274595E+02
+  -.906688133867E+02  -.916161615546E+02  -.925560698026E+02  -.935125585017E+02  -.945084003335E+02
+  -.955568564711E+02  -.966495565018E+02  -.977435752368E+02  -.987548956466E+02  -.995673584555E+02
+  -.100061379620E+03  -.100154992533E+03  -.998385173631E+02  -.991826926026E+02  -.983122581877E+02
+  -.973581436293E+02  -.964160582281E+02  -.955317704410E+02  -.947111132488E+02  -.939390886823E+02
+  -.931953467187E+02  -.924622718412E+02  -.917274076175E+02  -.909830054766E+02  -.902246341771E+02
+  -.894498046272E+02  -.886569511579E+02  -.878448120816E+02  -.870121334636E+02  -.861575898467E+02
+  -.852798259845E+02  -.843775489340E+02  -.834496263823E+02  -.824951684779E+02  -.815135848938E+02
+  -.805046170962E+02  -.794683496812E+02
+ core charge-density
+   .378166384757E-05   .401938221399E-05   .427204066085E-05   .454057784405E-05   .482599136570E-05
+   .512934147321E-05   .545175499020E-05   .579442949387E-05   .615863775415E-05   .654573245093E-05
+   .695715118702E-05   .739442181501E-05   .785916809796E-05   .835311572453E-05   .887809870087E-05
+   .943606614281E-05   .100290894932E-04   .106593701912E-04   .113292478214E-04   .120412087736E-04
+   .127978954431E-04   .136021160083E-04   .144568548188E-04   .153652834335E-04   .163307723491E-04
+   .173569034617E-04   .184474833077E-04   .196065571320E-04   .208384238353E-04   .221476518555E-04
+   .235390960405E-04   .250179155760E-04   .265895930308E-04   .282599545926E-04   .300351915660E-04
+   .319218832115E-04   .339270210099E-04   .360580344392E-04   .383228183591E-04   .407297621019E-04
+   .432877803764E-04   .460063460970E-04   .488955252567E-04   .519660139717E-04   .552291778313E-04
+   .586970936959E-04   .623825940948E-04   .662993143841E-04   .704617428360E-04   .748852738393E-04
+   .795862644046E-04   .845820941769E-04   .898912291720E-04   .955332894673E-04   .101529121088E-03
+   .107900872352E-03   .114672074936E-03   .121867729970E-03   .129514399458E-03   .137640303344E-03
+   .146275422593E-03   .155451608631E-03   .165202699543E-03   .175564643455E-03   .186575629507E-03
+   .198276226915E-03   .210709532591E-03   .223921327859E-03   .237960244800E-03   .252877942839E-03
+   .268729296164E-03   .285572592666E-03   .303469745067E-03   .322486515002E-03   .342692750813E-03
+   .364162639902E-03   .386974976500E-03   .411213445807E-03   .436966925455E-03   .464329805358E-03
+   .493402327040E-03   .524290943604E-03   .557108701578E-03   .591975645945E-03   .629019249726E-03
+   .668374869583E-03   .710186228981E-03   .754605930542E-03   .801795999301E-03   .851928458704E-03
+   .905185941259E-03   .961762335868E-03   .102186347400E-02   .108570785696E-02   .115352742663E-02
+   .122556838226E-02   .130209204591E-02   .138337577935E-02   .146971395547E-02   .156141898719E-02
+   .165882241729E-02   .176227607249E-02   .187215328560E-02   .198885018939E-02   .211278708638E-02
+   .224440989875E-02   .238419170285E-02   .253263435297E-02   .269027019941E-02   .285766390598E-02
+   .303541437236E-02   .322415676715E-02   .342456467750E-02   .363735238163E-02   .386327725094E-02
+   .410314228842E-02   .435779881085E-02   .462814928203E-02   .491515030523E-02   .521981578291E-02
+   .554322025240E-02   .588650240652E-02   .625086880843E-02   .663759781052E-02   .704804368736E-02
+   .748364099335E-02   .794590915589E-02   .843645731536E-02   .895698942371E-02   .950930961369E-02
+   .100953278512E-01   .107170658839E-01   .113766634985E-01   .120763851020E-01   .128186266388E-01
+   .136059228594E-01   .144409549552E-01   .153265585731E-01   .162657322265E-01   .172616461172E-01
+   .183176513830E-01   .194372897880E-01   .206243038695E-01   .218826475581E-01   .232164972855E-01
+   .246302635953E-01   .261286032715E-01   .277164319986E-01   .293989375669E-01   .311815936358E-01
+   .330701740666E-01   .350707678356E-01   .371897945364E-01   .394340204794E-01   .418105753938E-01
+   .443269697359E-01   .469911126043E-01   .498113302613E-01   .527963852542E-01   .559554961287E-01
+   .592983577222E-01   .628351620189E-01   .665766195451E-01   .705339812770E-01   .747190610268E-01
+   .791442582658E-01   .838225813376E-01   .887676710020E-01   .939938242464E-01   .995160182871E-01
+   .105349934674E+00   .111511983402E+00   .118019326912E+00   .124889903864E+00   .132142452534E+00
+   .139796533688E+00   .147872552742E+00   .156391781033E+00   .165376375983E+00   .174849399906E+00
+   .184834837227E+00   .195357609811E+00   .206443590098E+00   .218119611727E+00   .230413477255E+00
+   .243353962607E+00   .256970817822E+00   .271294763636E+00   .286357483419E+00   .302191609933E+00
+   .318830706372E+00   .336309241058E+00   .354662555192E+00   .373926822969E+00   .394139003372E+00
+   .415336782889E+00   .437558508392E+00   .460843109360E+00   .485230008624E+00   .510759020751E+00
+   .537470237197E+00   .565403897303E+00   .594600244233E+00   .625099364900E+00   .656941012977E+00
+   .690164414050E+00   .724808052028E+00   .760909435932E+00   .798504846243E+00   .837629060032E+00
+   .878315054192E+00   .920593686163E+00   .964493351671E+00   .101003961913E+01   .105725484051E+01
+   .110615773869E+01   .115676297144E+01   .120908067261E+01   .126311597105E+01   .131886848851E+01
+   .137633181772E+01   .143549298248E+01   .149633188186E+01   .155882072117E+01   .162292343267E+01
+   .168859508975E+01   .175578131859E+01   .182441771210E+01   .189442925138E+01   .196572974067E+01
+   .203822126243E+01   .211179365968E+01   .218632405344E+01   .226167640400E+01   .233770112491E+01
+   .241423475950E+01   .249109973027E+01   .256810417178E+01   .264504185819E+01   .272169223696E+01
+   .279782058021E+01   .287317826544E+01   .294750319715E+01   .302052038044E+01   .309194265750E+01
+   .316147161666E+01   .322879868312E+01   .329360639899E+01   .335556989863E+01   .341435858370E+01
+   .346963799983E+01   .352107191457E+01   .356832459326E+01   .361106326663E+01   .364896078013E+01
+   .368169841153E+01   .370896883948E+01   .373047924128E+01   .374595449408E+01   .375514044920E+01
+   .375780724509E+01   .375375261983E+01   .374280518040E+01   .372482758171E+01   .369971956525E+01
+   .366742080426E+01   .362791350021E+01   .358122467382E+01   .352742809355E+01   .346664578522E+01
+   .339904906800E+01   .332485906545E+01   .324434664489E+01   .315783174432E+01   .306568205413E+01
+   .296831102995E+01   .286617522395E+01   .275977093447E+01   .264963018743E+01   .253631607809E+01
+   .242041751766E+01   .230254344544E+01   .218331658354E+01   .206336682733E+01   .194332437785E+01
+   .182381274100E+01   .170544171472E+01   .158880050993E+01   .147445114069E+01   .136292222279E+01
+   .125470331188E+01   .115023989871E+01   .104992915545E+01   .954116492060E+00   .863092930985E+00
+   .777093246588E+00   .696294757090E+00   .620816638218E+00   .550719698696E+00   .486006745643E+00
+   .426623916802E+00   .372463504183E+00   .323368663209E+00   .279139964416E+00   .239543195086E+00
+   .204317468497E+00   .173182769327E+00   .145846494262E+00   .122009020820E+00   .101368570213E+00
+   .836255977702E-01   .684868026748E-01   .556687339940E-01   .449009229172E-01   .359284740988E-01
+   .285140746905E-01   .224394102278E-01   .175060040292E-01   .135355187265E-01   .103695748506E-01
+   .786915260934E-02   .591364975020E-02   .439967123087E-02   .323962578827E-02   .236020085325E-02
+   .170078111056E-02   .121186792537E-02
+ kinetic energy-density
+   .532955807213E-01   .540205706616E-01   .547722478392E-01   .555517135887E-01   .563601491850E-01
+   .571988017377E-01   .580689880635E-01   .589720973273E-01   .599095940565E-01   .608830213004E-01
+   .618940040930E-01   .629442529804E-01   .640355679050E-01   .651698423542E-01   .663490677411E-01
+   .675753381164E-01   .688508552289E-01   .701779339175E-01   .715590078974E-01   .729966359175E-01
+   .744935083777E-01   .760524543607E-01   .776764491609E-01   .793686222735E-01   .811322659457E-01
+   .829708442599E-01   .848880027939E-01   .868875788931E-01   .889736126049E-01   .911503582530E-01
+   .934222967647E-01   .957941487592E-01   .982708883705E-01   .100857758005E+00   .103560283916E+00
+   .106384292764E+00   .109335929155E+00   .112421674248E+00   .115648365476E+00   .119023217450E+00
+   .122553844137E+00   .126248282351E+00   .130115016669E+00   .134163005840E+00   .138401710779E+00
+   .142841124290E+00   .147491802475E+00   .152364898191E+00   .157472196329E+00   .162826151454E+00
+   .168439927448E+00   .174327439850E+00   .180503400465E+00   .186983364828E+00   .193783782582E+00
+   .200922050681E+00   .208416570161E+00   .216286805914E+00   .224553350521E+00   .233237991550E+00
+   .242363783296E+00   .251955122523E+00   .262037829078E+00   .272639231179E+00   .283788255980E+00
+   .295515525606E+00   .307853458954E+00   .320836379704E+00   .334500630828E+00   .348884696090E+00
+   .364029328800E+00   .379977688433E+00   .396775485459E+00   .414471134974E+00   .433115919557E+00
+   .452764161922E+00   .473473408160E+00   .495304621791E+00   .518322389680E+00   .542595140329E+00
+   .568195375209E+00   .595199914122E+00   .623690155173E+00   .653752350630E+00   .685477898834E+00
+   .718963654119E+00   .754312254945E+00   .791632471980E+00   .831039576244E+00   .872655730526E+00
+   .916610402562E+00   .963040804090E+00   .101209235531E+01   .106391917711E+01   .111868461243E+01
+   .117656177861E+01   .123773415216E+01   .130239618820E+01   .137075397625E+01   .144302593472E+01
+   .151944354598E+01   .160025213461E+01   .168571169098E+01   .177609774301E+01   .187170227860E+01
+   .197283472144E+01   .207982296365E+01   .219301445770E+01   .231277737157E+01   .243950180997E+01
+   .257360110572E+01   .271551318482E+01   .286570200926E+01   .302465910161E+01   .319290515605E+01
+   .337099173998E+01   .355950309131E+01   .375905801630E+01   .397031189301E+01   .419395878612E+01
+   .443073367828E+01   .468141482455E+01   .494682623529E+01   .522784029453E+01   .552538052014E+01
+   .584042447259E+01   .617400681977E+01   .652722256462E+01   .690123044424E+01   .729725650680E+01
+   .771659787607E+01   .816062671058E+01   .863079436651E+01   .912863577327E+01   .965577403014E+01
+   .102139252338E+02   .108049035457E+02   .114306265083E+02   .120931206211E+02   .127945271843E+02
+   .135371084210E+02   .143232538877E+02   .151554871811E+02   .160364729531E+02   .169690242410E+02
+   .179561101239E+02   .190008637122E+02   .201065904795E+02   .212767769455E+02   .225150997148E+02
+   .238254348796E+02   .252118677913E+02   .266787032057E+02   .282304758039E+02   .298719610918E+02
+   .316081866777E+02   .334444439258E+02   .353862999836E+02   .374396101739E+02   .396105307455E+02
+   .419055319696E+02   .443314115657E+02   .468953084409E+02   .496047167162E+02   .524675000169E+02
+   .554919059887E+02   .586865810095E+02   .620605850458E+02   .656234066089E+02   .693849777495E+02
+   .733556890302E+02   .775464043971E+02   .819684758736E+02   .866337579780E+02   .915546217685E+02
+   .967439683954E+02   .102215242038E+03   .107982442083E+03   .114060134397E+03   .120463461516E+03
+   .127208151572E+03   .134310525764E+03   .141787504137E+03   .149656609450E+03   .157935968866E+03
+   .166644313191E+03   .175800973371E+03   .185425873917E+03   .195539522925E+03   .206162998326E+03
+   .217317929985E+03   .229026477228E+03   .241311301375E+03   .254195532823E+03   .267702732198E+03
+   .281856845083E+03   .296682149797E+03   .312203197701E+03   .328444745462E+03   .345431678732E+03
+   .363188926639E+03   .381741366540E+03   .401113718424E+03   .421330428409E+03   .442415540748E+03
+   .464392557808E+03   .487284287484E+03   .511112677568E+03   .535898636616E+03   .561661840940E+03
+   .588420527387E+03   .616191271692E+03   .644988752230E+03   .674825499185E+03   .705711629200E+03
+   .737654565797E+03   .770658745967E+03   .804725313553E+03   .839851800254E+03   .876031795293E+03
+   .913254605067E+03   .951504904362E+03   .990762381008E+03   .103100137618E+04   .107219052287E+04
+   .111429238545E+04   .115726310350E+04   .120105204370E+04   .124560146359E+04   .129084619189E+04
+   .133671332989E+04   .138312197938E+04   .142998300250E+04   .147719881949E+04   .152466325047E+04
+   .157226140789E+04   .161986964607E+04   .166735557495E+04   .171457814473E+04   .176138780835E+04
+   .180762676863E+04   .185312931642E+04   .189772226607E+04   .194122549371E+04   .198345258349E+04
+   .202421158569E+04   .206330589018E+04   .210053521700E+04   .213569672495E+04   .216858623732E+04
+   .219899958226E+04   .222673404372E+04   .225158991653E+04   .227337215748E+04   .229189212179E+04
+   .230696937243E+04   .231843354711E+04   .232612626573E+04   .232990305882E+04   .232963529517E+04
+   .232521208521E+04   .231654213438E+04   .230355551986E+04   .228620536203E+04   .226446936184E+04
+   .223835117417E+04   .220788158781E+04   .217311948251E+04   .213415253506E+04   .209109764743E+04
+   .204410107233E+04   .199333821376E+04   .193901308358E+04   .188135739848E+04   .182062930602E+04
+   .175711173286E+04   .169111035384E+04   .162295118589E+04   .155297781738E+04   .148154829067E+04
+   .140903166324E+04   .133580428167E+04   .126224581224E+04   .118873507723E+04   .111564580054E+04
+   .104334219459E+04   .972174747616E+03   .902475983529E+03   .834556504451E+03   .768701335191E+03
+   .705166689134E+03   .644177277570E+03   .585924312584E+03   .530564394027E+03   .478219504178E+03
+   .428978305256E+03   .382898750697E+03   .340011596025E+03   .300323789355E+03   .263820298345E+03
+   .230463266369E+03   .200188731532E+03   .172902844909E+03   .148480362653E+03   .126767390522E+03
+   .107588271142E+03   .907544509077E+02   .760726014073E+02   .633504173410E+02   .524001100015E+02
+   .430404409556E+02   .350980932873E+02   .284087987970E+02   .228183342126E+02   .181833598131E+02
+   .143720450906E+02   .112644434187E+02   .875260471254E+01   .674043770626E+01   .514334865856E+01
+   .388769191001E+01   .291007156436E+01   .215653420246E+01   .158169104272E+01   .114780500860E+01
+   .823874180193E+00   .584738414580E+00
+ pspotential
+  -.108020752148E+03  -.108024751819E+03  -.108028631273E+03  -.108032394088E+03  -.108036043772E+03
+  -.108039583731E+03  -.108043017266E+03  -.108046347579E+03  -.108049577777E+03  -.108052710874E+03
+  -.108055749789E+03  -.108058697361E+03  -.108061556337E+03  -.108064329386E+03  -.108067019095E+03
+  -.108069627972E+03  -.108072158454E+03  -.108074612901E+03  -.108076993603E+03  -.108079302782E+03
+  -.108081542594E+03  -.108083715131E+03  -.108085822421E+03  -.108087866430E+03  -.108089849067E+03
+  -.108091772184E+03  -.108093637579E+03  -.108095446993E+03  -.108097202119E+03  -.108098904596E+03
+  -.108100556016E+03  -.108102157922E+03  -.108103711814E+03  -.108105219146E+03  -.108106681330E+03
+  -.108108099732E+03  -.108109475683E+03  -.108110810471E+03  -.108112105351E+03  -.108113361532E+03
+  -.108114580198E+03  -.108115762491E+03  -.108116909522E+03  -.108118022373E+03  -.108119102090E+03
+  -.108120149688E+03  -.108121166157E+03  -.108122152458E+03  -.108123109522E+03  -.108124038257E+03
+  -.108124939539E+03  -.108125814226E+03  -.108126663152E+03  -.108127487123E+03  -.108128286927E+03
+  -.108129063329E+03  -.108129817073E+03  -.108130548886E+03  -.108131259470E+03  -.108131949517E+03
+  -.108132619694E+03  -.108133270657E+03  -.108133903039E+03  -.108134517464E+03  -.108135114539E+03
+  -.108135694855E+03  -.108136258993E+03  -.108136807519E+03  -.108137340988E+03  -.108137859943E+03
+  -.108138364916E+03  -.108138856433E+03  -.108139335002E+03  -.108139801134E+03  -.108140255324E+03
+  -.108140698059E+03  -.108141129825E+03  -.108141551099E+03  -.108141962353E+03  -.108142364055E+03
+  -.108142756670E+03  -.108143140661E+03  -.108143516487E+03  -.108143884604E+03  -.108144245473E+03
+  -.108144599551E+03  -.108144947299E+03  -.108145289178E+03  -.108145625654E+03  -.108145957197E+03
+  -.108146284281E+03  -.108146607389E+03  -.108146927007E+03  -.108147243632E+03  -.108147557773E+03
+  -.108147869945E+03  -.108148180679E+03  -.108148490520E+03  -.108148800023E+03  -.108149109767E+03
+  -.108149420344E+03  -.108149732367E+03  -.108150046473E+03  -.108150363320E+03  -.108150683591E+03
+  -.108151008000E+03  -.108151337288E+03  -.108151672227E+03  -.108152013631E+03  -.108152362339E+03
+  -.108152719241E+03  -.108153085263E+03  -.108153461380E+03  -.108153848615E+03  -.108154248045E+03
+  -.108154660800E+03  -.108155088073E+03  -.108155531122E+03  -.108155991269E+03  -.108156469912E+03
+  -.108156968526E+03  -.108157488670E+03  -.108158031989E+03  -.108158600227E+03  -.108159195223E+03
+  -.108159818924E+03  -.108160473392E+03  -.108161160810E+03  -.108161883491E+03  -.108162643879E+03
+  -.108163444570E+03  -.108164288313E+03  -.108165178016E+03  -.108166116773E+03  -.108167107851E+03
+  -.108168154724E+03  -.108169261070E+03  -.108170430791E+03  -.108171668027E+03  -.108172977166E+03
+  -.108174362864E+03  -.108175830058E+03  -.108177383987E+03  -.108179030206E+03  -.108180774605E+03
+  -.108182623438E+03  -.108184583332E+03  -.108186661316E+03  -.108188864847E+03  -.108191201833E+03
+  -.108193680659E+03  -.108196310211E+03  -.108199099916E+03  -.108202059765E+03  -.108205200346E+03
+  -.108208532882E+03  -.108212069264E+03  -.108215822093E+03  -.108219804710E+03  -.108224031253E+03
+  -.108228516685E+03  -.108233276848E+03  -.108238328511E+03  -.108243689413E+03  -.108249378320E+03
+  -.108255415077E+03  -.108261820660E+03  -.108268617241E+03  -.108275828236E+03  -.108283478375E+03
+  -.108291593759E+03  -.108300201927E+03  -.108309331919E+03  -.108319014341E+03  -.108329281432E+03
+  -.108340167133E+03  -.108351707153E+03  -.108363939031E+03  -.108376902206E+03  -.108390638077E+03
+  -.108405190062E+03  -.108420603659E+03  -.108436926492E+03  -.108454208361E+03  -.108472501280E+03
+  -.108491859505E+03  -.108512339556E+03  -.108534000222E+03  -.108556902556E+03  -.108581109854E+03
+  -.108606687608E+03  -.108633703438E+03  -.108662227011E+03  -.108692329914E+03  -.108724085509E+03
+  -.108757568742E+03  -.108792855916E+03  -.108830024422E+03  -.108869152411E+03  -.108910318426E+03
+  -.108953600951E+03  -.108999077924E+03  -.109046826153E+03  -.109096920672E+03  -.109149434008E+03
+  -.109204435362E+03  -.109261989699E+03  -.109322156743E+03  -.109384989865E+03  -.109450534880E+03
+  -.109518828727E+03  -.109589898055E+03  -.109663757696E+03  -.109740409045E+03  -.109819838343E+03
+  -.109902014874E+03  -.109986889095E+03  -.110074390695E+03  -.110164426624E+03  -.110256879097E+03
+  -.110351603617E+03  -.110448427026E+03  -.110547145635E+03  -.110647523478E+03  -.110749290701E+03
+  -.110852142183E+03  -.110955736381E+03  -.111059694503E+03  -.111163600016E+03  -.111266998578E+03
+  -.111369398409E+03  -.111470271172E+03  -.111569053395E+03  -.111665148460E+03  -.111757929182E+03
+  -.111846741009E+03  -.111930905812E+03  -.112009726265E+03  -.112082490781E+03  -.112148478954E+03
+  -.112206967441E+03  -.112257236189E+03  -.112298574941E+03  -.112330289873E+03  -.112351710269E+03
+  -.112362195084E+03  -.112361139271E+03  -.112347979741E+03  -.112322200813E+03  -.112283339050E+03
+  -.112230987368E+03  -.112164798324E+03  -.112084486534E+03  -.111989830183E+03  -.111880671603E+03
+  -.111756916973E+03  -.111618535180E+03  -.111465555939E+03  -.111298067306E+03  -.111116212724E+03
+  -.110920187795E+03  -.110710236960E+03  -.110486650317E+03  -.110249760783E+03  -.109999941802E+03
+  -.109737605823E+03  -.109463203699E+03  -.109177225157E+03  -.108880200440E+03  -.108572703154E+03
+  -.108255354298E+03  -.107928827399E+03  -.107593854553E+03  -.107251233130E+03  -.106901832767E+03
+  -.106546602207E+03  -.106186575394E+03  -.105822876146E+03  -.105456720568E+03  -.105089416236E+03
+  -.104722357032E+03  -.104357012277E+03  -.103994908702E+03  -.103637603516E+03  -.103286646747E+03
+  -.102943530903E+03  -.102609626094E+03  -.102286099095E+03  -.101973815614E+03  -.101673226425E+03
+  -.101384240240E+03  -.101106089425E+03  -.100837198887E+03  -.100575073471E+03  -.100316224293E+03
+  -.100056158413E+03  -.997894572049E+02  -.995099646826E+02  -.992110959561E+02  -.988862574927E+02
+  -.985293467158E+02  -.981352736140E+02  -.977004287357E+02  -.972230178772E+02  -.967031987166E+02
+  -.961429875773E+02  -.955459477070E+02  -.949167118535E+02  -.942604196205E+02  -.935821572286E+02
+  -.928864742980E+02  -.921770258150E+02  -.914563569788E+02  -.907258224779E+02  -.899856146998E+02
+  -.892348682563E+02  -.884718090090E+02  -.876939212781E+02  -.868981140628E+02  -.860808737861E+02
+  -.852383963895E+02  -.843666957950E+02  -.834616900833E+02  -.825192734740E+02  -.815353947375E+02
+  -.805166722764E+02  -.794860047315E+02
+ core charge-density (pseudized)
+ pseudo wavefunction
+   .112936833579E-03   .116438474611E-03   .120048685092E-03   .123770831251E-03   .127608383688E-03
+   .131564920610E-03   .135644131167E-03   .139849818891E-03   .144185905248E-03   .148656433284E-03
+   .153265571406E-03   .158017617262E-03   .162917001749E-03   .167968293146E-03   .173176201373E-03
+   .178545582383E-03   .184081442687E-03   .189788944028E-03   .195673408186E-03   .201740321949E-03
+   .207995342221E-03   .214444301301E-03   .221093212321E-03   .227948274852E-03   .235015880682E-03
+   .242302619781E-03   .249815286442E-03   .257560885617E-03   .265546639449E-03   .273779994004E-03
+   .282268626219E-03   .291020451052E-03   .300043628870E-03   .309346573053E-03   .318937957842E-03
+   .328826726422E-03   .339022099267E-03   .349533582733E-03   .360370977924E-03   .371544389829E-03
+   .383064236745E-03   .394941259993E-03   .407186533929E-03   .419811476274E-03   .432827858758E-03
+   .446247818097E-03   .460083867308E-03   .474348907378E-03   .489056239293E-03   .504219576439E-03
+   .519853057388E-03   .535971259084E-03   .552589210431E-03   .569722406308E-03   .587386822017E-03
+   .605598928177E-03   .624375706083E-03   .643734663538E-03   .663693851181E-03   .684271879310E-03
+   .705487935242E-03   .727361801202E-03   .749913872764E-03   .773165177871E-03   .797137396441E-03
+   .821852880583E-03   .847334675436E-03   .873606540655E-03   .900692972569E-03   .928619227017E-03
+   .957411342900E-03   .987096166457E-03   .101770137630E-02   .104925550920E-02   .108178798675E-02
+   .111532914273E-02   .114991025143E-02   .118556355679E-02   .122232230250E-02   .126022076293E-02
+   .129929427517E-02   .133957927190E-02   .138111331540E-02   .142393513257E-02   .146808465104E-02
+   .151360303637E-02   .156053273046E-02   .160891749112E-02   .165880243285E-02   .171023406891E-02
+   .176326035469E-02   .181793073243E-02   .187429617728E-02   .193240924487E-02   .199232412030E-02
+   .205409666863E-02   .211778448699E-02   .218344695827E-02   .225114530648E-02   .232094265383E-02
+   .239290407958E-02   .246709668072E-02   .254358963451E-02   .262245426296E-02   .270376409935E-02
+   .278759495676E-02   .287402499875E-02   .296313481222E-02   .305500748255E-02   .314972867101E-02
+   .324738669467E-02   .334807260868E-02   .345188029115E-02   .355890653069E-02   .366925111659E-02
+   .378301693183E-02   .390031004902E-02   .402123982920E-02   .414591902380E-02   .427446387975E-02
+   .440699424775E-02   .454363369403E-02   .468450961544E-02   .482975335823E-02   .497950034040E-02
+   .513389017788E-02   .529306681466E-02   .545717865684E-02   .562637871097E-02   .580082472654E-02
+   .598067934295E-02   .616611024102E-02   .635729029917E-02   .655439775444E-02   .675761636851E-02
+   .696713559880E-02   .718315077491E-02   .740586328049E-02   .763548074077E-02   .787221721578E-02
+   .811629339967E-02   .836793682612E-02   .862738208007E-02   .889487101602E-02   .917065298309E-02
+   .945498505693E-02   .974813227893E-02   .100503679026E-01   .103619736479E-01   .106832399628E-01
+   .110144662935E-01   .113559613628E-01   .117080434568E-01   .120710407206E-01   .124452914631E-01
+   .128311444712E-01   .132289593335E-01   .136391067739E-01   .140619689957E-01   .144979400363E-01
+   .149474261317E-01   .154108460942E-01   .158886316992E-01   .163812280861E-01   .168890941695E-01
+   .174127030646E-01   .179525425240E-01   .185091153891E-01   .190829400543E-01   .196745509459E-01
+   .202844990148E-01   .209133522451E-01   .215616961769E-01   .222301344458E-01   .229192893381E-01
+   .236298023627E-01   .243623348406E-01   .251175685114E-01   .258962061583E-01   .266989722513E-01
+   .275266136099E-01   .283799000855E-01   .292596252632E-01   .301666071847E-01   .311016890927E-01
+   .320657401964E-01   .330596564593E-01   .340843614106E-01   .351408069785E-01   .362299743490E-01
+   .373528748478E-01   .385105508480E-01   .397040767030E-01   .409345597060E-01   .422031410750E-01
+   .435109969663E-01   .448593395148E-01   .462494179028E-01   .476825194573E-01   .491599707765E-01
+   .506831388862E-01   .522534324250E-01   .538723028617E-01   .555412457411E-01   .572618019630E-01
+   .590355590904E-01   .608641526900E-01   .627492677043E-01   .646926398539E-01   .666960570727E-01
+   .687613609727E-01   .708904483404E-01   .730852726635E-01   .753478456872E-01   .776802389994E-01
+   .800845856442E-01   .825630817624E-01   .851179882572E-01   .877516324843E-01   .904664099642E-01
+   .932647861139E-01   .961492979963E-01   .991225560844E-01   .102187246037E+00   .105346130479E+00
+   .108602050791E+00   .111957928890E+00   .115416769009E+00   .118981659462E+00   .122655774384E+00
+   .126442375454E+00   .130344813569E+00   .134366530488E+00   .138511060405E+00   .142782031463E+00
+   .147183167189E+00   .151718287827E+00   .156391311567E+00   .161206255645E+00   .166167237292E+00
+   .171278474518E+00   .176544286708E+00   .181969094989E+00   .187557422366E+00   .193313893575E+00
+   .199243234620E+00   .205350271978E+00   .211639931400E+00   .218117236293E+00   .224787305615E+00
+   .231655351242E+00   .238726674738E+00   .246006663483E+00   .253500786070E+00   .261214586915E+00
+   .269153679993E+00   .277323741610E+00   .285730502123E+00   .294379736511E+00   .303277253668E+00
+   .312428884334E+00   .321840467502E+00   .331517835193E+00   .341466795442E+00   .351693113337E+00
+   .362202489962E+00   .373000539047E+00   .384092761157E+00   .395484515213E+00   .407180987151E+00
+   .419187155479E+00   .431507753531E+00   .444147228167E+00   .457109694679E+00   .470398887655E+00
+   .484018107539E+00   .497970162644E+00   .512257306339E+00   .526881169174E+00   .541842685686E+00
+   .557142015651E+00   .572778459563E+00   .588750368150E+00   .605055045757E+00   .621688647464E+00
+   .638646069887E+00   .655920835606E+00   .673504971314E+00   .691388879787E+00   .709561205926E+00
+   .728008697221E+00   .746716059078E+00   .765665805650E+00   .784838106918E+00   .804210632955E+00
+   .823758396493E+00   .843453595084E+00   .863265454340E+00   .883160073931E+00   .903100278175E+00
+   .923045473217E+00   .942951512883E+00   .962770575356E+00   .982451052772E+00   .100193745570E+01
+   .102117033415E+01   .104008621638E+01   .105861756585E+01   .107669275605E+01   .109423606130E+01
+   .111116766016E+01   .112740364596E+01   .114285603632E+01   .115743277066E+01   .117103768082E+01
+   .118357041626E+01   .119492630044E+01   .120499609048E+01   .121366560723E+01   .122081519839E+01
+   .122631899339E+01   .123004390639E+01   .123184834333E+01   .123158057227E+01   .122907672349E+01
+   .122415839999E+01   .121661099761E+01
+ ae wavefunction
+  -.597520737029E-03  -.616014834872E-03  -.635081121050E-03  -.654737284352E-03  -.675001559522E-03
+  -.695892744057E-03  -.717430215506E-03  -.739633949310E-03  -.762524537174E-03  -.786123206011E-03
+  -.810451837452E-03  -.835532987960E-03  -.861389909552E-03  -.888046571153E-03  -.915527680598E-03
+  -.943858707309E-03  -.973065905652E-03  -.100317633901E-02  -.103421790460E-02  -.106621935899E-02
+  -.109921034448E-02  -.113322141619E-02  -.116828407002E-02  -.120443077147E-02  -.124169498526E-02
+  -.128011120594E-02  -.131971498934E-02  -.136054298500E-02  -.140263296964E-02  -.144602388151E-02
+  -.149075585586E-02  -.153687026151E-02  -.158440973839E-02  -.163341823634E-02  -.168394105501E-02
+  -.173602488491E-02  -.178971784981E-02  -.184506955030E-02  -.190213110868E-02  -.196095521519E-02
+  -.202159617565E-02  -.208410996044E-02  -.214855425501E-02  -.221498851184E-02  -.228347400396E-02
+  -.235407388005E-02  -.242685322113E-02  -.250187909902E-02  -.257922063635E-02  -.265894906854E-02
+  -.274113780742E-02  -.282586250679E-02  -.291320112992E-02  -.300323401895E-02  -.309604396638E-02
+  -.319171628853E-02  -.329033890128E-02  -.339200239787E-02  -.349680012897E-02  -.360482828512E-02
+  -.371618598146E-02  -.383097534491E-02  -.394930160383E-02  -.407127318028E-02  -.419700178481E-02
+  -.432660251403E-02  -.446019395083E-02  -.459789826753E-02  -.473984133181E-02  -.488615281566E-02
+  -.503696630737E-02  -.519241942658E-02  -.535265394253E-02  -.551781589555E-02  -.568805572191E-02
+  -.586352838201E-02  -.604439349209E-02  -.623081545952E-02  -.642296362162E-02  -.662101238832E-02
+  -.682514138853E-02  -.703553562035E-02  -.725238560533E-02  -.747588754666E-02  -.770624349147E-02
+  -.794366149740E-02  -.818835580325E-02  -.844054700419E-02  -.870046223115E-02  -.896833533485E-02
+  -.924440707431E-02  -.952892531003E-02  -.982214520178E-02  -.101243294112E-01  -.104357483093E-01
+  -.107566801887E-01  -.110874114808E-01  -.114282369781E-01  -.117794600613E-01  -.121413929319E-01
+  -.125143568493E-01  -.128986823738E-01  -.132947096139E-01  -.137027884795E-01  -.141232789401E-01
+  -.145565512880E-01  -.150029864066E-01  -.154629760445E-01  -.159369230941E-01  -.164252418753E-01
+  -.169283584247E-01  -.174467107893E-01  -.179807493252E-01  -.185309370012E-01  -.190977497066E-01
+  -.196816765642E-01  -.202832202471E-01  -.209028972994E-01  -.215412384616E-01  -.221987889989E-01
+  -.228761090336E-01  -.235737738797E-01  -.242923743814E-01  -.250325172529E-01  -.257948254211E-01
+  -.265799383690E-01  -.273885124812E-01  -.282212213885E-01  -.290787563142E-01  -.299618264178E-01
+  -.308711591389E-01  -.318075005381E-01  -.327716156348E-01  -.337642887420E-01  -.347863237951E-01
+  -.358385446760E-01  -.369217955294E-01  -.380369410714E-01  -.391848668884E-01  -.403664797251E-01
+  -.415827077607E-01  -.428345008702E-01  -.441228308711E-01  -.454486917519E-01  -.468130998811E-01
+  -.482170941953E-01  -.496617363628E-01  -.511481109214E-01  -.526773253869E-01  -.542505103313E-01
+  -.558688194249E-01  -.575334294425E-01  -.592455402279E-01  -.610063746141E-01  -.628171782964E-01
+  -.646792196524E-01  -.665937895071E-01  -.685622008361E-01  -.705857884052E-01  -.726659083384E-01
+  -.748039376113E-01  -.770012734632E-01  -.792593327228E-01  -.815795510400E-01  -.839633820196E-01
+  -.864122962467E-01  -.889277802005E-01  -.915113350453E-01  -.941644752932E-01  -.968887273285E-01
+  -.996856277863E-01  -.102556721775E+00  -.105503560933E+00  -.108527701313E+00  -.111630701071E+00
+  -.114814117975E+00  -.118079506685E+00  -.121428415828E+00  -.124862384832E+00  -.128382940516E+00
+  -.131991593419E+00  -.135689833858E+00  -.139479127696E+00  -.143360911804E+00  -.147336589214E+00
+  -.151407523923E+00  -.155575035361E+00  -.159840392479E+00  -.164204807465E+00  -.168669429044E+00
+  -.173235335369E+00  -.177903526470E+00  -.182674916242E+00  -.187550323970E+00  -.192530465345E+00
+  -.197615942984E+00  -.202807236404E+00  -.208104691461E+00  -.213508509213E+00  -.219018734201E+00
+  -.224635242131E+00  -.230357726938E+00  -.236185687210E+00  -.242118411975E+00  -.248154965819E+00
+  -.254294173335E+00  -.260534602895E+00  -.266874549721E+00  -.273312018268E+00  -.279844703909E+00
+  -.286469973921E+00  -.293184847772E+00  -.299985976721E+00  -.306869622745E+00  -.313831636798E+00
+  -.320867436428E+00  -.327971982785E+00  -.335139757031E+00  -.342364736213E+00  -.349640368627E+00
+  -.356959548737E+00  -.364314591695E+00  -.371697207546E+00  -.379098475184E+00  -.386508816155E+00
+  -.393917968397E+00  -.401314960036E+00  -.408688083349E+00  -.416024869035E+00  -.423312060933E+00
+  -.430535591355E+00  -.437680557200E+00  -.444731197039E+00  -.451670869384E+00  -.458482032335E+00
+  -.465146224877E+00  -.471644050039E+00  -.477955160211E+00  -.484058244892E+00  -.489931021166E+00
+  -.495550227230E+00  -.500891619310E+00  -.505929972305E+00  -.510639084533E+00  -.514991786958E+00
+  -.518959957286E+00  -.522514539352E+00  -.525625568199E+00  -.528262201296E+00  -.530392756321E+00
+  -.531984755958E+00  -.533004980157E+00  -.533419526305E+00  -.533193877757E+00  -.532292981162E+00
+  -.530681333023E+00  -.528323075905E+00  -.525182104684E+00  -.521222183211E+00  -.516407071726E+00
+  -.510700665319E+00  -.504067143693E+00  -.496471132405E+00  -.487877875730E+00  -.478253421166E+00
+  -.467564815560E+00  -.455780312685E+00  -.442869592018E+00  -.428803988313E+00  -.413556731446E+00
+  -.397103195830E+00  -.379421158553E+00  -.360491065208E+00  -.340296302214E+00  -.318823474239E+00
+  -.296062685183E+00  -.272007821000E+00  -.246656832508E+00  -.220012016240E+00  -.192080291270E+00
+  -.162873469927E+00  -.132408520268E+00  -.100707818152E+00  -.677993867027E-01  -.337171208218E-01
+   .149900587593E-02   .378027548766E-01   .751414614371E-01   .113455903761E+00   .152680210710E+00
+   .192741819571E+00   .233561500197E+00   .275053467550E+00   .317125609833E+00   .359679859700E+00
+   .402612723554E+00   .445815947236E+00   .489177227382E+00   .532580786825E+00   .575907566566E+00
+   .619034824821E+00   .661835133970E+00   .704175088578E+00   .745914315462E+00   .786905395754E+00
+   .826994971469E+00   .866025783091E+00   .903839034545E+00   .940276532166E+00   .975182362464E+00
+   .100840416780E+01   .103979419983E+01   .106921031168E+01   .109651698096E+01   .112158639312E+01
+   .114429957418E+01   .116454754177E+01   .118223243614E+01   .119726859418E+01   .120958353433E+01
+   .121911882731E+01   .122583083392E+01   .122969129705E+01   .123068777947E+01   .122882394266E+01
+   .122411966470E+01   .121661099761E+01
+   .196520024109E-05   .202613187455E-05   .208895271186E-05   .215372132836E-05   .222049811553E-05
+   .228934533731E-05   .236032718815E-05   .243350985287E-05   .250896156836E-05   .258675268723E-05
+   .266695574337E-05   .274964551964E-05   .283489911753E-05   .292279602910E-05   .301341821108E-05
+   .310685016129E-05   .320317899744E-05   .330249453834E-05   .340488938765E-05   .351045902025E-05
+   .361930187123E-05   .373151942769E-05   .384721632339E-05   .396650043624E-05   .408948298898E-05
+   .421627865281E-05   .434700565436E-05   .448178588590E-05   .462074501900E-05   .476401262171E-05
+   .491172227937E-05   .506401171918E-05   .522102293858E-05   .538290233770E-05   .554980085583E-05
+   .572187411217E-05   .589928255094E-05   .608219159094E-05   .627077177984E-05   .646519895319E-05
+   .666565439832E-05   .687232502345E-05   .708540353191E-05   .730508860182E-05   .753158507138E-05
+   .776510412981E-05   .800586351431E-05   .825408771303E-05   .851000817445E-05   .877386352310E-05
+   .904589978211E-05   .932637060261E-05   .961553750019E-05   .991367009874E-05   .102210463819E-04
+   .105379529522E-04   .108646852983E-04   .112015480704E-04   .115488553646E-04   .119069310154E-04
+   .122761088978E-04   .126567332385E-04   .130491589372E-04   .134537518970E-04   .138708893658E-04
+   .143009602882E-04   .147443656677E-04   .152015189411E-04   .156728463636E-04   .161587874062E-04
+   .166597951660E-04   .171763367877E-04   .177088939001E-04   .182579630644E-04   .188240562376E-04
+   .194077012498E-04   .200094422959E-04   .206298404434E-04   .212694741554E-04   .219289398297E-04
+   .226088523551E-04   .233098456843E-04   .240325734255E-04   .247777094509E-04   .255459485257E-04
+   .263380069555E-04   .271546232539E-04   .279965588312E-04   .288645987041E-04   .297595522277E-04
+   .306822538495E-04   .316335638877E-04   .326143693331E-04   .336255846756E-04   .346681527569E-04
+   .357430456494E-04   .368512655619E-04   .379938457741E-04   .391718515995E-04   .403863813782E-04
+   .416385675008E-04   .429295774636E-04   .442606149566E-04   .456329209853E-04   .470477750273E-04
+   .485064962243E-04   .500104446115E-04   .515610223849E-04   .531596752075E-04   .548078935565E-04
+   .565072141117E-04   .582592211872E-04   .600655482073E-04   .619278792278E-04   .638479505048E-04
+   .658275521116E-04   .678685296059E-04   .699727857488E-04   .721422822758E-04   .743790417239E-04
+   .766851493146E-04   .790627548948E-04   .815140749380E-04   .840413946069E-04   .866470698808E-04
+   .893335297468E-04   .921032784603E-04   .949588978744E-04   .979030498412E-04   .100938478687E-03
+   .104068013765E-03   .107294572083E-03   .110621161019E-03   .114050881111E-03   .117586928941E-03
+   .121232600103E-03   .124991292262E-03   .128866508313E-03   .132861859626E-03   .136981069401E-03
+   .141227976121E-03   .145606537111E-03   .150120832204E-03   .154775067528E-03   .159573579393E-03
+   .164520838313E-03   .169621453140E-03   .174880175328E-03   .180301903326E-03   .185891687104E-03
+   .191654732815E-03   .197596407606E-03   .203722244562E-03   .210037947807E-03   .216549397763E-03
+   .223262656554E-03   .230183973588E-03   .237319791295E-03   .244676751038E-03   .252261699210E-03
+   .260081693499E-03   .268144009349E-03   .276456146606E-03   .285025836367E-03   .293861048023E-03
+   .302969996514E-03   .312361149795E-03   .322043236515E-03   .332025253925E-03   .342316476011E-03
+   .352926461857E-03   .363865064254E-03   .375142438549E-03   .386769051743E-03   .398755691846E-03
+   .411113477493E-03   .423853867822E-03   .436988672629E-03   .450530062792E-03   .464490580981E-03
+   .478883152649E-03   .493721097318E-03   .509018140150E-03   .524788423825E-03   .541046520711E-03
+   .557807445348E-03   .575086667222E-03   .592900123863E-03   .611264234242E-03   .630195912478E-03
+   .649712581854E-03   .669832189139E-03   .690573219213E-03   .711954709992E-03   .733996267649E-03
+   .756718082113E-03   .780140942859E-03   .804286254952E-03   .829176055354E-03   .854833029465E-03
+   .881280527886E-03   .908542583375E-03   .936643927987E-03   .965610010348E-03   .995467013053E-03
+   .102624187013E-02   .105796228453E-02   .109065674566E-02   .112435454672E-02   .115908580207E-02
+   .119488146428E-02   .123177334096E-02   .126979411120E-02   .130897734158E-02   .134935750160E-02
+   .139096997842E-02   .143385109083E-02   .147803810215E-02   .152356923212E-02   .157048366740E-02
+   .161882157057E-02   .166862408741E-02   .171993335215E-02   .177279249050E-02   .182724562004E-02
+   .188333784779E-02   .194111526442E-02   .200062493482E-02   .206191488443E-02   .212503408104E-02
+   .219003241128E-02   .225696065135E-02   .232587043120E-02   .239681419147E-02   .246984513247E-02
+   .254501715401E-02   .262238478540E-02   .270200310434E-02   .278392764350E-02   .286821428351E-02
+   .295491913086E-02   .304409837905E-02   .313580815127E-02   .323010432261E-02   .332704231962E-02
+   .342667689483E-02   .352906187360E-02   .363424987047E-02   .374229197165E-02   .385323738030E-02
+   .396713302064E-02   .408402309656E-02   .420394860015E-02   .432694676486E-02   .445305045752E-02
+   .458228750304E-02   .471467993471E-02   .485024316247E-02   .498898505066E-02   .513090489593E-02
+   .527599229493E-02   .542422589057E-02   .557557198402E-02   .572998299891E-02   .588739578223E-02
+   .604772972504E-02   .621088468453E-02   .637673868670E-02   .654514538693E-02   .671593126354E-02
+   .688889251645E-02   .706379164051E-02   .724035363973E-02   .741826184522E-02   .759715329573E-02
+   .777661363559E-02   .795617148009E-02   .813529219336E-02   .831337101822E-02   .848972549140E-02
+   .866358707103E-02   .883409189602E-02   .900027058936E-02   .916103700897E-02   .931517584087E-02
+   .946132891992E-02   .959798015356E-02   .972343891321E-02   .983582174753E-02   .993303226053E-02
+   .100127389866E-01   .100723510839E-01   .101089916575E-01   .101194685154E-01   .101002421524E-01
+   .100473907548E-01   .995657201663E-02   .982298156377E-02   .964130779401E-02   .940568296118E-02
+   .910963036355E-02   .874600754254E-02   .830694546239E-02   .778378372777E-02   .716700201089E-02
+   .644614800815E-02   .560976243544E-02   .464530181044E-02   .353906006825E-02   .227609042441E-02
+   .840129349639E-03  -.786474934831E-03  -.262282637765E-02  -.468953359234E-02  -.700874616928E-02
+  -.960416897976E-02  -.125010474170E-01  -.157261151205E-01  -.193074941602E-01  -.232745359319E-01
+  -.276575891459E-01  -.324876793357E-01  -.377960823217E-01  -.436137721479E-01  -.499707222934E-01
+  -.568950376424E-01  -.643833519108E-01
+ ae wavefunction
+  -.352599561891E-05  -.363513004996E-05  -.374764098276E-05  -.386363279915E-05  -.398321310262E-05
+  -.410649281746E-05  -.423358629085E-05  -.436461139807E-05  -.449968965100E-05  -.463894630982E-05
+  -.478251049819E-05  -.493051532192E-05  -.508309799126E-05  -.524039994688E-05  -.540256698973E-05
+  -.556974941485E-05  -.574210214915E-05  -.591978489354E-05  -.610296226923E-05  -.629180396854E-05
+  -.648648491029E-05  -.668718539983E-05  -.689409129399E-05  -.710739417099E-05  -.732729150551E-05
+  -.755398684897E-05  -.778769001537E-05  -.802861727265E-05  -.827699153983E-05  -.853304259014E-05
+  -.879700726017E-05  -.906912966538E-05  -.934966142207E-05  -.963886187597E-05  -.993699833770E-05
+  -.102443463253E-04  -.105611898140E-04  -.108878214934E-04  -.112245430324E-04  -.115716653520E-04
+  -.119295089061E-04  -.122984039709E-04  -.126786909427E-04  -.130707206445E-04  -.134748546416E-04
+  -.138914655670E-04  -.143209374559E-04  -.147636660901E-04  -.152200593526E-04  -.156905375931E-04
+  -.161755340033E-04  -.166754950035E-04  -.171908806414E-04  -.177221650009E-04  -.182698366240E-04
+  -.188343989447E-04  -.194163707349E-04  -.200162865642E-04  -.206346972719E-04  -.212721704529E-04
+  -.219292909585E-04  -.226066614096E-04  -.233049027263E-04  -.240246546718E-04  -.247665764115E-04
+  -.255313470886E-04  -.263196664150E-04  -.271322552801E-04  -.279698563748E-04  -.288332348350E-04
+  -.297231789010E-04  -.306405005968E-04  -.315860364270E-04  -.325606480933E-04  -.335652232303E-04
+  -.346006761620E-04  -.356679486779E-04  -.367680108302E-04  -.379018617530E-04  -.390705305027E-04
+  -.402750769208E-04  -.415165925193E-04  -.427962013899E-04  -.441150611361E-04  -.454743638294E-04
+  -.468753369909E-04  -.483192445969E-04  -.498073881105E-04  -.513411075386E-04  -.529217825156E-04
+  -.545508334134E-04  -.562297224788E-04  -.579599549982E-04  -.597430804899E-04  -.615806939250E-04
+  -.634744369762E-04  -.654259992961E-04  -.674371198241E-04  -.695095881227E-04  -.716452457433E-04
+  -.738459876218E-04  -.761137635039E-04  -.784505794007E-04  -.808584990738E-04  -.833396455504E-04
+  -.858962026691E-04  -.885304166541E-04  -.912445977204E-04  -.940411217074E-04  -.969224317415E-04
+  -.998910399280E-04  -.102949529070E-03  -.106100554414E-03  -.109346845426E-03  -.112691207587E-03
+  -.116136524220E-03  -.119685758333E-03  -.123341954492E-03  -.127108240710E-03  -.130987830356E-03
+  -.134984024082E-03  -.139100211764E-03  -.143339874458E-03  -.147706586366E-03  -.152204016808E-03
+  -.156835932200E-03  -.161606198035E-03  -.166518780858E-03  -.171577750241E-03  -.176787280741E-03
+  -.182151653849E-03  -.187675259911E-03  -.193362600035E-03  -.199218287955E-03  -.205247051865E-03
+  -.211453736202E-03  -.217843303382E-03  -.224420835472E-03  -.231191535791E-03  -.238160730439E-03
+  -.245333869728E-03  -.252716529518E-03  -.260314412444E-03  -.268133349011E-03  -.276179298556E-03
+  -.284458350059E-03  -.292976722781E-03  -.301740766722E-03  -.310756962873E-03  -.320031923249E-03
+  -.329572390678E-03  -.339385238330E-03  -.349477468952E-03  -.359856213798E-03  -.370528731217E-03
+  -.381502404875E-03  -.392784741585E-03  -.404383368697E-03  -.416306031038E-03  -.428560587346E-03
+  -.441155006166E-03  -.454097361171E-03  -.467395825858E-03  -.481058667575E-03  -.495094240836E-03
+  -.509510979859E-03  -.524317390281E-03  -.539522039995E-03  -.555133549035E-03  -.571160578454E-03
+  -.587611818120E-03  -.604495973359E-03  -.621821750369E-03  -.639597840316E-03  -.657832902035E-03
+  -.676535543237E-03  -.695714300135E-03  -.715377615376E-03  -.735533814180E-03  -.756191078575E-03
+  -.777357419604E-03  -.799040647390E-03  -.821248338914E-03  -.843987803384E-03  -.867266045052E-03
+  -.891089723312E-03  -.915465109947E-03  -.940398043346E-03  -.965893879522E-03  -.991957439765E-03
+  -.101859295473E-02  -.104580400477E-02  -.107359345633E-02  -.110196339422E-02  -.113091504939E-02
+  -.116044872232E-02  -.119056370138E-02  -.122125817629E-02  -.125252914625E-02  -.128437232246E-02
+  -.131678202495E-02  -.134975107331E-02  -.138327067114E-02  -.141733028393E-02  -.145191751005E-02
+  -.148701794477E-02  -.152261503680E-02  -.155868993728E-02  -.159522134086E-02  -.163218531869E-02
+  -.166955514302E-02  -.170730110320E-02  -.174539031293E-02  -.178378650839E-02  -.182244983738E-02
+  -.186133663898E-02  -.190039921386E-02  -.193958558510E-02  -.197883924941E-02  -.201809891895E-02
+  -.205729825355E-02  -.209636558381E-02  -.213522362495E-02  -.217378918202E-02  -.221197284665E-02
+  -.224967868588E-02  -.228680392384E-02  -.232323861682E-02  -.235886532279E-02  -.239355876633E-02
+  -.242718550038E-02  -.245960356609E-02  -.249066215252E-02  -.252020125822E-02  -.254805135673E-02
+  -.257403306862E-02  -.259795684285E-02  -.261962265071E-02  -.263881969580E-02  -.265532614425E-02
+  -.266890887948E-02  -.267932328670E-02  -.268631307246E-02  -.268961012561E-02  -.268893442638E-02
+  -.268399401106E-02  -.267448500055E-02  -.266009170183E-02  -.264048679225E-02  -.261533159756E-02
+  -.258427647535E-02  -.254696131697E-02  -.250301618172E-02  -.245206207865E-02  -.239371191212E-02
+  -.232757160902E-02  -.225324144639E-02  -.217031760006E-02  -.207839393582E-02  -.197706406661E-02
+  -.186592370026E-02  -.174457330394E-02  -.161262111298E-02  -.146968651318E-02  -.131540382677E-02
+  -.114942653401E-02  -.971431963222E-03  -.781126483296E-03  -.578251233687E-03  -.362588427702E-03
+  -.133968265497E-03   .107723506316E-03   .362537351334E-03   .630450979094E-03   .911359622815E-03
+   .120506552245E-02   .151126657690E-02   .182954412998E-02   .215934985602E-02   .249999171231E-02
+   .285061892808E-02   .321020600284E-02   .357753569177E-02   .395118096285E-02   .432948592061E-02
+   .471054570570E-02   .509218539982E-02   .547193799319E-02   .584702150864E-02   .621431542505E-02
+   .657033660231E-02   .691121497656E-02   .723266935112E-02   .752998361615E-02   .779798361229E-02
+   .803101449814E-02   .822291778535E-02   .836700621061E-02   .845603372069E-02   .848215790746E-02
+   .843689416684E-02   .831106469808E-02   .809474955718E-02   .777724852803E-02   .734705955910E-02
+   .679187279623E-02   .609857294563E-02   .525324122853E-02   .424115189109E-02   .304676327228E-02
+   .165370620904E-02   .447725764738E-04  -.179809454140E-02  -.389380888251E-02  -.626214794681E-02
+  -.892375999988E-02  -.119001724745E-01  -.152138031563E-01  -.188879755598E-01  -.229469399462E-01
+  -.274159015330E-01  -.323210576170E-01  -.376896455613E-01  -.435500038975E-01  -.499316491437E-01
+  -.568653713563E-01  -.643833519108E-01
+   .119548626449E-07   .127076835378E-07   .135079110225E-07   .143585303841E-07   .152627148967E-07
+   .162238376618E-07   .172454841914E-07   .183314657845E-07   .194858337445E-07   .207128944937E-07
+   .220172256378E-07   .234036930434E-07   .248774689901E-07   .264440514658E-07   .281092846776E-07
+   .298793808534E-07   .317609434172E-07   .337609916235E-07   .358869867426E-07   .381468598956E-07
+   .405490416414E-07   .431024934279E-07   .458167410223E-07   .487019100479E-07   .517687637580E-07
+   .550287431889E-07   .584940098409E-07   .621774910475E-07   .660929282011E-07   .702549280164E-07
+   .746790170209E-07   .793816994775E-07   .843805189543E-07   .896941237715E-07   .953423365702E-07
+   .101346228261E-06   .107728196630E-06   .114512049896E-06   .121723095526E-06   .129388234647E-06
+   .137536062401E-06   .146196974622E-06   .155403281226E-06   .165189326749E-06   .175591618465E-06
+   .186648962583E-06   .198402609011E-06   .210896405243E-06   .224176959933E-06   .238293816772E-06
+   .253299639308E-06   .269250407414E-06   .286205626122E-06   .304228547608E-06   .323386407154E-06
+   .343750673978E-06   .365397317846E-06   .388407092483E-06   .412865836827E-06   .438864795254E-06
+   .466500957968E-06   .495877422825E-06   .527103779943E-06   .560296520534E-06   .595579471472E-06
+   .633084257238E-06   .672950790946E-06   .715327796291E-06   .760373362370E-06   .808255533431E-06
+   .859152935773E-06   .913255444107E-06   .970764889893E-06   .103189581427E-05   .109687626841E-05
+   .116594866426E-05   .123937067887E-05   .131741621565E-05   .140037642616E-05   .148856079627E-05
+   .158229830071E-05   .168193863026E-05   .178785349631E-05   .190043801750E-05   .202011219372E-05
+   .214732247293E-05   .228254341657E-05   .242627946996E-05   .257906684406E-05   .274147551585E-05
+   .291411135453E-05   .309761838177E-05   .329268117412E-05   .350002741683E-05   .372043061845E-05
+   .395471299628E-05   .420374854366E-05   .446846629026E-05   .474985376780E-05   .504896069389E-05
+   .536690288790E-05   .570486643336E-05   .606411210255E-05   .644598005955E-05   .685189485955E-05
+   .728337076291E-05   .774201738383E-05   .822954569468E-05   .874777440844E-05   .929863676294E-05
+   .988418773241E-05   .105066116929E-04   .111682305707E-04   .118715125031E-04   .126190810455E-04
+   .134137249575E-04   .142584086051E-04   .151562830181E-04   .161106976441E-04   .171252128414E-04
+   .182036131597E-04   .193499214561E-04   .205684139001E-04   .218636359233E-04   .232404191732E-04
+   .247038995345E-04   .262595362845E-04   .279131324548E-04   .296708564744E-04   .315392651762E-04
+   .335253282502E-04   .356364542374E-04   .378805181593E-04   .402658908864E-04   .428014703559E-04
+   .454967147532E-04   .483616777832E-04   .514070461602E-04   .546441794583E-04   .580851524688E-04
+   .617428002239E-04   .656307658535E-04   .697635514527E-04   .741565721512E-04   .788262135837E-04
+   .837898929768E-04   .890661240783E-04   .946745861719E-04   .100636197433E-03   .106973192897E-03
+   .113709207337E-03   .120869363343E-03   .128480364954E-03   .136570597166E-03   .145170231702E-03
+   .154311339433E-03   .164028009859E-03   .174356478111E-03   .185335259922E-03   .197005295092E-03
+   .209410099957E-03   .222595929445E-03   .236611949303E-03   .251510419148E-03   .267346887007E-03
+   .284180396074E-03   .302073704444E-03   .321093518633E-03   .341310741760E-03   .362800737284E-03
+   .385643609290E-03   .409924500347E-03   .435733908033E-03   .463168021296E-03   .492329077882E-03
+   .523325744151E-03   .556273518666E-03   .591295161036E-03   .628521147583E-03   .668090155500E-03
+   .710149577270E-03   .754856067208E-03   .802376122137E-03   .852886698288E-03   .906575866680E-03
+   .963643509333E-03   .102430205886E-02   .108877728407E-02   .115730912444E-02   .123015257647E-02
+   .130757863501E-02   .138987529302E-02   .147734860330E-02   .157032380593E-02   .166914652545E-02
+   .177418404195E-02   .188582664064E-02   .200448904455E-02   .213061193530E-02   .226466356745E-02
+   .240714148171E-02   .255857432315E-02   .271952377045E-02   .289058658294E-02   .307239677212E-02
+   .326562790518E-02   .347099554798E-02   .368925985574E-02   .392122831990E-02   .416775867999E-02
+   .442976200994E-02   .470820598878E-02   .500411836577E-02   .531859063104E-02   .565278190279E-02
+   .600792304298E-02   .638532101367E-02   .678636348693E-02   .721252372138E-02   .766536571948E-02
+   .814654967940E-02   .865783775658E-02   .920110014991E-02   .977832152814E-02   .103916078125E-01
+   .110431933315E-01   .117354483651E-01   .124708870934E-01   .132521759688E-01   .140821425251E-01
+   .149637846432E-01   .159002802874E-01   .168949977276E-01   .179515062632E-01   .190735874616E-01
+   .202652469232E-01   .215307265832E-01   .228745175599E-01   .243013735524E-01   .258163247925E-01
+   .274246925490E-01   .291321041766E-01   .309445087009E-01   .328681929207E-01   .349097980024E-01
+   .370763365352E-01   .393752100029E-01   .418142266196E-01   .444016194617E-01   .471460648165E-01
+   .500567006485E-01   .531431450672E-01   .564155146591E-01   .598844425217E-01   .635610958094E-01
+   .674571925739E-01   .715850176439E-01   .759574372530E-01   .805879120817E-01   .854905083333E-01
+   .906799064099E-01   .961714066993E-01   .101980931919E+00   .108125025396E+00   .114620844589E+00
+   .121486149068E+00   .128739282099E+00   .136399144861E+00   .144485162254E+00   .153017239126E+00
+   .162015705650E+00   .171501250470E+00   .181494840124E+00   .192017623117E+00   .203090816937E+00
+   .214735576173E+00   .226972839823E+00   .239823155780E+00   .253306480441E+00   .267441951357E+00
+   .282247630847E+00   .297740218575E+00   .313934731195E+00   .330844147412E+00   .348479017071E+00
+   .366847033327E+00   .385952567516E+00   .405796167034E+00   .426374017491E+00   .447677371491E+00
+   .469691947805E+00   .492397306341E+00   .515766206280E+00   .539763957058E+00   .564347774484E+00
+   .589466157328E+00   .615058303014E+00   .641053584763E+00   .667371116462E+00   .693919435630E+00
+   .720596339034E+00   .747288909493E+00   .773873775956E+00   .800217651740E+00   .826178197315E+00
+   .851605253765E+00   .876342490170E+00   .900229502030E+00   .923104387203E+00   .944806809883E+00
+   .965181540373E+00   .984082427784E+00   .100137672298E+01   .101694961907E+01   .103070881580E+01
+   .104258884232E+01   .105255479041E+01   .106060502044E+01   .106677230743E+01   .107112280292E+01
+   .107375210738E+01   .107477769194E+01   .107432689351E+01   .107251975572E+01   .106944612557E+01
+   .106513667140E+01   .105951590919E+01
+ ae wavefunction
+   .638386667376E-07   .677120719962E-07   .717878148162E-07   .760781692450E-07   .805960852755E-07
+   .853552309281E-07   .903700368932E-07   .956557437996E-07   .101228452275E-06   .107105175975E-06
+   .113303897768E-06   .119843629279E-06   .126744473999E-06   .134027694187E-06   .141715781809E-06
+   .149832533758E-06   .158403131636E-06   .167454226371E-06   .177014027992E-06   .187112400866E-06
+   .197780964760E-06   .209053202074E-06   .220964571654E-06   .233552629579E-06   .246857157378E-06
+   .260920298125E-06   .275786700924E-06   .291503674301E-06   .308121349062E-06   .325692851214E-06
+   .344274485579E-06   .363925930776E-06   .384710446267E-06   .406695092253E-06   .429950963189E-06
+   .454553435806E-06   .480582432520E-06   .508122701213E-06   .537264112393E-06   .568101974841E-06
+   .600737370883E-06   .635277512523E-06   .671836119748E-06   .710533822382E-06   .751498586969E-06
+   .794866170246E-06   .840780600873E-06   .889394691184E-06   .940870580833E-06   .995380314344E-06
+   .105310645465E-05   .111424273492E-05   .117899475101E-05   .124758069715E-05   .132023214744E-05
+   .139719488621E-05   .147872979008E-05   .156511376512E-05   .165664074249E-05   .175362273610E-05
+   .185639096640E-05   .196529705422E-05   .208071428910E-05   .220303897678E-05   .233269187073E-05
+   .247011969307E-05   .261579675027E-05   .277022664977E-05   .293394412359E-05   .310751696575E-05
+   .329154809048E-05   .348667771889E-05   .369358570193E-05   .391299398818E-05   .414566924562E-05
+   .439242564673E-05   .465412782724E-05   .493169402933E-05   .522609944062E-05   .553837974126E-05
+   .586963487198E-05   .622103303687E-05   .659381495531E-05   .698929837885E-05   .740888288904E-05
+   .785405499401E-05   .832639354216E-05   .882757547256E-05   .935938192307E-05   .992370471820E-05
+   .105225532603E-04   .111580618490E-04   .118324974554E-04   .125482679788E-04   .133079310169E-04
+   .141142031792E-04   .149699699792E-04   .158782963398E-04   .168424377503E-04   .178658521140E-04
+   .189522123315E-04   .201054196616E-04   .213296179102E-04   .226292084970E-04   .240088664536E-04
+   .254735574115E-04   .270285556389E-04   .286794631912E-04   .304322302449E-04   .322931766840E-04
+   .342690150189E-04   .363668747166E-04   .385943280294E-04   .409594174132E-04   .434706846320E-04
+   .461372016512E-04   .489686034280E-04   .519751227146E-04   .551676269955E-04   .585576576880E-04
+   .621574717438E-04   .659800857943E-04   .700393229956E-04   .743498627336E-04   .789272933620E-04
+   .837881681551E-04   .889500646678E-04   .944316477064E-04   .100252736127E-03   .106434373689E-03
+   .112998904200E-03   .119970051221E-03   .127373002584E-03   .135234500022E-03   .143582934202E-03
+   .152448445488E-03   .161863030762E-03   .171860656675E-03   .182477379676E-03   .193751473245E-03
+   .205723562729E-03   .218436768227E-03   .231936856004E-03   .246272398895E-03   .261494946258E-03
+   .277659203982E-03   .294823225160E-03   .313048612011E-03   .332400729706E-03   .352948932759E-03
+   .374766804705E-03   .397932411798E-03   .422528571522E-03   .448643136741E-03   .476369296349E-03
+   .505805893338E-03   .537057761236E-03   .570236079922E-03   .605458751875E-03   .642850799952E-03
+   .682544787871E-03   .724681264595E-03   .769409233900E-03   .816886650448E-03   .867280943766E-03
+   .920769571575E-03   .977540603989E-03   .103779334017E-02   .110173895909E-02   .116960120612E-02
+   .124161711723E-02   .131803778267E-02   .139912915210E-02   .148517288306E-02   .157646723507E-02
+   .167332801131E-02   .177608955018E-02   .188510576920E-02   .200075126331E-02   .212342246037E-02
+   .225353883612E-02   .239154419130E-02   .253790799365E-02   .269312678730E-02   .285772567255E-02
+   .303225985866E-02   .321731629273E-02   .341351536733E-02   .362151270999E-02   .384200105741E-02
+   .407571221735E-02   .432341912122E-02   .458593797008E-02   .486413047725E-02   .515890621002E-02
+   .547122503343E-02   .580209965875E-02   .615259829894E-02   .652384743386E-02   .691703468697E-02
+   .733341181578E-02   .777429781760E-02   .824108215208E-02   .873522808145E-02   .925827612928E-02
+   .981184765789E-02   .103976485641E-01   .110174730928E-01   .116732077659E-01   .123668354262E-01
+   .131004393914E-01   .138762077157E-01   .146964375537E-01   .155635396211E-01   .164800427450E-01
+   .174485984965E-01   .184719858945E-01   .195531161717E-01   .206950375890E-01   .219009402849E-01
+   .231741611430E-01   .245181886607E-01   .259366677978E-01   .274334047841E-01   .290123718602E-01
+   .306777119238E-01   .324337430530E-01   .342849628725E-01   .362360527272E-01   .382918816234E-01
+   .404575098967E-01   .427381925586E-01   .451393822735E-01   .476667319122E-01   .503260966243E-01
+   .531235353679E-01   .560653118313E-01   .591578946758E-01   .624079570260E-01   .658223751276E-01
+   .694082260906E-01   .731727846277E-01   .771235186983E-01   .812680839588E-01   .856143169185E-01
+   .901702266971E-01   .949439852730E-01   .999439161104E-01   .105178481049E+00   .110656265340E+00
+   .116385960702E+00   .122376346281E+00   .128636267393E+00   .135174611916E+00   .142000284232E+00
+   .149122176577E+00   .156549137709E+00   .164289938775E+00   .172353236286E+00   .180747532104E+00
+   .189481130385E+00   .198562091398E+00   .207998182192E+00   .217796824093E+00   .227965037026E+00
+   .238509380698E+00   .249435892702E+00   .260750023621E+00   .272456569271E+00   .284559600216E+00
+   .297062388746E+00   .309967333537E+00   .323275882213E+00   .336988452081E+00   .351104349291E+00
+   .365621686691E+00   .380537300641E+00   .395846667028E+00   .411543816721E+00   .427621250673E+00
+   .444069854932E+00   .460878815830E+00   .478035535801E+00   .495525550466E+00   .513332448110E+00
+   .531437793276E+00   .549821057247E+00   .568459559656E+00   .587328427601E+00   .606400581552E+00
+   .625646761242E+00   .645035609268E+00   .664533834316E+00   .684106476974E+00   .703717293083E+00
+   .723329243608E+00   .742905026222E+00   .762407502025E+00   .781799786725E+00   .801044752505E+00
+   .820103803160E+00   .838935065448E+00   .857491485850E+00   .875719528735E+00   .893559046860E+00
+   .910944422795E+00   .927806518361E+00   .944074703498E+00   .959678416184E+00   .974548104615E+00
+   .988615703182E+00   .100181487992E+01   .101408123971E+01   .102535257998E+01   .103556922786E+01
+   .104467444950E+01   .105261490576E+01   .105934112503E+01   .106480796684E+01   .106897505609E+01
+   .107180717351E+01   .107327459381E+01   .107335336666E+01   .107202553894E+01   .106927931812E+01
+   .106510917804E+01   .105951590919E+01
+   .239377382215E-09   .254451440250E-09   .270474740944E-09   .287507059946E-09   .305611937093E-09
+   .324856913447E-09   .345313783265E-09   .367058861824E-09   .390173270121E-09   .414743237502E-09
+   .440860423338E-09   .468622258970E-09   .498132311177E-09   .529500668538E-09   .562844352123E-09
+   .598287752043E-09   .635963091495E-09   .676010920024E-09   .718580637853E-09   .763831053221E-09
+   .811930974829E-09   .863059841586E-09   .917408392014E-09   .975179375805E-09   .103658831019E-08
+   .110186428393E-08   .117125081194E-08   .124500674375E-08   .132340722912E-08   .140674474453E-08
+   .149533018426E-08   .158949402019E-08   .168958753464E-08   .179598413086E-08   .190908072600E-08
+   .202929923184E-08   .215708812874E-08   .229292413871E-08   .243731400386E-08   .259079637679E-08
+   .275394383009E-08   .292736499228E-08   .311170681840E-08   .330765700343E-08   .351594654779E-08
+   .373735248436E-08   .397270077723E-08   .422286940294E-08   .448879162586E-08   .477145947972E-08
+   .507192746844E-08   .539131649996E-08   .573081806782E-08   .609169869609E-08   .647530466410E-08
+   .688306702882E-08   .731650696343E-08   .777724143206E-08   .826698922193E-08   .878757735529E-08
+   .934094790513E-08   .992916524016E-08   .105544237259E-07   .112190559107E-07   .119255412276E-07
+   .126765152434E-07   .134747794912E-07   .143233119208E-07   .152252780085E-07   .161840425657E-07
+   .172031822913E-07   .182864991140E-07   .194380343763E-07   .206620839096E-07   .219632140603E-07
+   .233462787239E-07   .248164374529E-07   .263791747034E-07   .280403202952E-07   .298060711593E-07
+   .316830144551E-07   .336781521436E-07   .357989271069E-07   .380532509140E-07   .404495333335E-07
+   .429967137056E-07   .457042942893E-07   .485823757087E-07   .516416946327E-07   .548936638261E-07
+   .583504147229E-07   .620248426805E-07   .659306550834E-07   .700824224755E-07   .744956329125E-07
+   .791867497358E-07   .841732729851E-07   .894738046770E-07   .951081181945E-07   .101097232045E-06
+   .107463488262E-06   .114230635745E-06   .121423918844E-06   .129070171522E-06   .137197917451E-06
+   .145837476399E-06   .155021077328E-06   .164782978601E-06   .175159595768E-06   .186189637386E-06
+   .197914249396E-06   .210377168590E-06   .223624885736E-06   .237706818972E-06   .252675498119E-06
+   .268586760592E-06   .285499959645E-06   .303478185729E-06   .322588501773E-06   .342902193286E-06
+   .364495034192E-06   .387447569400E-06   .411845415163E-06   .437779578328E-06   .465346795693E-06
+   .494649894707E-06   .525798176875E-06   .558907825289E-06   .594102337798E-06   .631512987440E-06
+   .671279311831E-06   .713549633357E-06   .758481612081E-06   .806242833432E-06   .857011432865E-06
+   .910976759803E-06   .968340083344E-06   .102931534234E-05   .109412994264E-05   .116302560448E-05
+   .123625926311E-05   .131410402608E-05   .139685019066E-05   .148480632526E-05   .157830041871E-05
+   .167768110185E-05   .178331894582E-05   .189560784191E-05   .201496646805E-05   .214183984746E-05
+   .227670100502E-05   .242005272777E-05   .257242943581E-05   .273439917056E-05   .290656570783E-05
+   .308957080336E-05   .328409657914E-05   .349086805936E-05   .371065586526E-05   .394427907871E-05
+   .419260828526E-05   .445656880761E-05   .473714414136E-05   .503537960585E-05   .535238622310E-05
+   .568934483928E-05   .604751050358E-05   .642821712054E-05   .683288239266E-05   .726301307126E-05
+   .772021053462E-05   .820617671354E-05   .872272038581E-05   .927176386205E-05   .985535008716E-05
+   .104756501827E-04   .111349714571E-04   .118357659126E-04   .125806392785E-04   .133723606036E-04
+   .142138724408E-04   .151083016601E-04   .160589709283E-04   .170694108949E-04   .181433731261E-04
+   .192848438333E-04   .204980584410E-04   .217875170464E-04   .231580008210E-04   .246145894114E-04
+   .261626793969E-04   .278080038652E-04   .295566531716E-04   .314150969497E-04   .333902074441E-04
+   .354892842421E-04   .377200804816E-04   .400908306176E-04   .426102798360E-04   .452877152015E-04
+   .481329986371E-04   .511566018314E-04   .543696431769E-04   .577839268453E-04   .614119841096E-04
+   .652671170275E-04   .693634446031E-04   .737159515479E-04   .783405397658E-04   .832540826867E-04
+   .884744825804E-04   .940207309790E-04   .999129723402E-04   .106172571083E-03   .112822182124E-03
+   .119885825047E-03   .127388962024E-03   .135358579611E-03   .143823274527E-03   .152813343519E-03
+   .162360877398E-03   .172499859324E-03   .183266267384E-03   .194698181505E-03   .206835894684E-03
+   .219722028512E-03   .233401652918E-03   .247922409999E-03   .263334641757E-03   .279691521500E-03
+   .297049188572E-03   .315466886009E-03   .335007100577E-03   .355735704575E-03   .377722098607E-03
+   .401039354378E-03   .425764356413E-03   .451977941328E-03   .479765033120E-03   .509214772598E-03
+   .540420638815E-03   .573480559986E-03   .608497010986E-03   .645577094058E-03   .684832598858E-03
+   .726380037394E-03   .770340648726E-03   .816840367610E-03   .866009750408E-03   .917983850663E-03
+   .972902035709E-03   .103090773453E-02   .109214810573E-02   .115677361315E-02   .122493749486E-02
+   .129679510967E-02   .137250314320E-02   .145221865335E-02   .153609793256E-02   .162429516182E-02
+   .171696082797E-02   .181423987313E-02   .191626954126E-02   .202317688311E-02   .213507587679E-02
+   .225206411650E-02   .237421901737E-02   .250159347911E-02   .263421094570E-02   .277205979278E-02
+   .291508696803E-02   .306319080398E-02   .321621291610E-02   .337392909247E-02   .353603907516E-02
+   .370215512708E-02   .387178927211E-02   .404433909132E-02   .421907195334E-02   .439510755395E-02
+   .457139863802E-02   .474670977725E-02   .491959407972E-02   .508836771312E-02   .525108213254E-02
+   .540549391748E-02   .554903214131E-02   .567876322066E-02   .579135322336E-02   .588302765155E-02
+   .594952876283E-02   .598607054689E-02   .598729153832E-02   .594720571849E-02   .585915183945E-02
+   .571574159030E-02   .550880711926E-02   .522934851945E-02   .486748198028E-02   .441238939296E-02
+   .385227027155E-02   .317429690197E-02   .236457364971E-02   .140810133210E-02   .288747479407E-03
+  -.101077684091E-02  -.250893319225E-02  -.422536480211E-02  -.618089873957E-02  -.839754200033E-02
+  -.108984728001E-01  -.137080289153E-01  -.168516953652E-01  -.203560939745E-01  -.242489771966E-01
+  -.285592277681E-01  -.333168639390E-01  -.385530467629E-01  -.443000806568E-01  -.505913905300E-01
+  -.574614474741E-01  -.649455995569E-01  -.730797439223E-01  -.818997506488E-01  -.914405174681E-01
+  -.101734498007E+00  -.112792147163E+00
+ ae wavefunction
+   .206416732725E-08   .218941337504E-08   .232120192911E-08   .245992987326E-08   .260601594813E-08
+   .275990211196E-08   .292205498413E-08   .309296737358E-08   .327315989763E-08   .346318269663E-08
+   .366361725084E-08   .387507830569E-08   .409821591257E-08   .433371759218E-08   .458231062827E-08
+   .484476450010E-08   .512189346206E-08   .541455928004E-08   .572367413422E-08   .605020369873E-08
+   .639517040945E-08   .675965693167E-08   .714480984011E-08   .755184352486E-08   .798204433724E-08
+   .843677499063E-08   .891747923250E-08   .942568680445E-08   .996301870835E-08   .105311927979E-07
+   .111320297162E-07   .117674592000E-07   .124395267755E-07   .131504008683E-07   .139023803547E-07
+   .146979025814E-07   .155395518834E-07   .164300686304E-07   .173723588365E-07   .183695043664E-07
+   .194247737767E-07   .205416338319E-07   .217237617376E-07   .229750581340E-07   .242996609002E-07
+   .257019598175E-07   .271866121462E-07   .287585591740E-07   .304230437952E-07   .321856291856E-07
+   .340522186429E-07   .360290766633E-07   .381228513327E-07   .403405981153E-07   .426898051255E-07
+   .451784199758E-07   .478148783013E-07   .506081340623E-07   .535676917382E-07   .567036405302E-07
+   .600266906983E-07   .635482121646E-07   .672802755271E-07   .712356956302E-07   .754280778562E-07
+   .798718673029E-07   .845824010309E-07   .895759635695E-07   .948698458854E-07   .100482408030E-06
+   .106433145693E-06   .112742760911E-06   .119433237178E-06   .126527919247E-06   .134051597903E-06
+   .142030600022E-06   .150492884244E-06   .159468142608E-06   .168987908521E-06   .179085671453E-06
+   .189796998781E-06   .201159665214E-06   .213213790288E-06   .226001984411E-06   .239569504010E-06
+   .253964416324E-06   .269237774457E-06   .285443803317E-06   .302640097122E-06   .320887829184E-06
+   .340251974730E-06   .360801547581E-06   .382609851517E-06   .405754747271E-06   .430318936085E-06
+   .456390260877E-06   .484062026082E-06   .513433337340E-06   .544609462239E-06   .577702213417E-06
+   .612830355397E-06   .650120036614E-06   .689705248187E-06   .731728311073E-06   .776340393348E-06
+   .823702059460E-06   .873983853422E-06   .927366918011E-06   .984043652184E-06   .104421840904E-05
+   .110810823683E-05   .117594366559E-05   .124796954220E-05   .132444591690E-05   .140564898424E-05
+   .149187208187E-05   .158342675069E-05   .168064385999E-05   .178387480170E-05   .189349275763E-05
+   .200989404444E-05   .213349954078E-05   .226475620168E-05   .240413866540E-05   .255215095828E-05
+   .270932830348E-05   .287623903983E-05   .305348665740E-05   .324171195666E-05   .344159533874E-05
+   .365385923440E-05   .387927068016E-05   .411864405008E-05   .437284395258E-05   .464278830187E-05
+   .492945157442E-05   .523386826119E-05   .555713652723E-05   .590042209059E-05   .626496233353E-05
+   .665207065932E-05   .706314110906E-05   .749965325335E-05   .796317737483E-05   .845537995818E-05
+   .897802950525E-05   .953300269379E-05   .101222908994E-04   .107480071012E-04   .114123931932E-04
+   .121178277232E-04   .128668340848E-04   .136620891861E-04   .145064326225E-04   .154028763812E-04
+   .163546151070E-04   .173650369587E-04   .184377350905E-04   .195765197901E-04   .207854313099E-04
+   .220687534279E-04   .234310277775E-04   .248770689865E-04   .264119806666E-04   .280411723005E-04
+   .297703770688E-04   .316056706686E-04   .335534911714E-04   .356206599742E-04   .378144038963E-04
+   .401423784807E-04   .426126925565E-04   .452339341237E-04   .480151976243E-04   .509661126627E-04
+   .540968742448E-04   .574182746032E-04   .609417366800E-04   .646793493423E-04   .686439044018E-04
+   .728489355189E-04   .773087590675E-04   .820385170405E-04   .870542220782E-04   .923728046992E-04
+   .980121628192E-04   .103991213639E-03   .110329947983E-03   .117049487178E-03   .124172142540E-03
+   .131721477567E-03   .139722372900E-03   .148201094133E-03   .157185362552E-03   .166704428853E-03
+   .176789149916E-03   .187472068677E-03   .198787497162E-03   .210771602701E-03   .223462497360E-03
+   .236900330614E-03   .251127385242E-03   .266188176444E-03   .282129554144E-03   .299000808417E-03
+   .316853777976E-03   .335742961603E-03   .355725632393E-03   .376861954652E-03   .399215103242E-03
+   .422851385126E-03   .447840362836E-03   .474254979518E-03   .502171685165E-03   .531670563586E-03
+   .562835459593E-03   .595754105821E-03   .630518248491E-03   .667223771392E-03   .705970817192E-03
+   .746863905152E-03   .790012044160E-03   .835528839893E-03   .883532594796E-03   .934146399386E-03
+   .987498213282E-03   .104372093415E-02   .110295245257E-02   .116533569074E-02   .123101862247E-02
+   .130015427198E-02   .137290068866E-02   .144942089456E-02   .152988280120E-02   .161445909222E-02
+   .170332706746E-02   .179666844445E-02   .189466911234E-02   .199751883319E-02   .210541088512E-02
+   .221854164121E-02   .233711007776E-02   .246131720494E-02   .259136541225E-02   .272745772087E-02
+   .286979693414E-02   .301858467706E-02   .317402031475E-02   .333629973953E-02   .350561401525E-02
+   .368214786686E-02   .386607800271E-02   .405757125589E-02   .425678253048E-02   .446385253772E-02
+   .467890530608E-02   .490204544867E-02   .513335517065E-02   .537289099802E-02   .562068020913E-02
+   .587671694881E-02   .614095800462E-02   .641331822405E-02   .669366555050E-02   .698181565573E-02
+   .727752614536E-02   .758049031393E-02   .789033042503E-02   .820659049205E-02   .852872853402E-02
+   .885610828095E-02   .918799030225E-02   .952352253120E-02   .986173015767E-02   .102015048605E-01
+   .105415933497E-01   .108805851881E-01   .112168998603E-01   .115487730574E-01   .118742421443E-01
+   .121911307789E-01   .124970326548E-01   .127892943441E-01   .130649972262E-01   .133209385017E-01
+   .135536113115E-01   .137591840043E-01   .139334786359E-01   .140719488248E-01   .141696571442E-01
+   .142212522891E-01   .142209463039E-01   .141624921585E-01   .140391618496E-01   .138437248694E-01
+   .135684261962E-01   .132049618901E-01   .127444491624E-01   .121773872355E-01   .114936066179E-01
+   .106822083844E-01   .973150068030E-02   .862894374668E-02   .736111363291E-02   .591368743634E-02
+   .427144299678E-02   .241826008033E-02   .337112309779E-03  -.198995328238E-02  -.458184568092E-02
+  -.745846300845E-02  -.106407256240E-01  -.141506078546E-01  -.180111686718E-01  -.222465823596E-01
+  -.268821703250E-01  -.319444350043E-01  -.374610965145E-01  -.434611324081E-01  -.499748206697E-01
+  -.570337859509E-01  -.646710489749E-01  -.729210790263E-01  -.818198494607E-01  -.914048962011E-01
+  -.101715379233E+00  -.112792147163E+00
+ End of Dataset
Added: SwiftApps/subjobs/vasp/cetus.conf
--- SwiftApps/subjobs/vasp/cetus.conf	                        (rev 0)
+++ SwiftApps/subjobs/vasp/cetus.conf	2015-04-04 17:21:19 UTC (rev 8422)
@@ -0,0 +1,34 @@
+sites : cluster
+site.cluster {
+    execution {
+        type: "coaster"
+        URL: "localhost"
+        jobManager: "local:cobalt"
+        options {
+            maxNodesPerJob: 512
+            maxJobs: 1
+            tasksPerNode: 64
+            nodeGranularity: 512
+            maxJobTime = "00:60:00"
+    filesystem {
+        type: "local"
+        URL: "localhost"
+    staging : swift
+    workDirectory: "/home/"${env.USER}"/swift.work"
+    maxParallelTasks: 64
+    initialParallelTasks: 63
+    app.bgsh {
+        executable: "/home/ketan/SwiftApps/subjobs/bg.sh"
+        maxWallTime: "00:15:00"
+        env.SUBBLOCK_SIZE="8"
+executionRetries: 0
+keepSiteDir: true
+providerStagingPinSwiftFiles: false
+alwaysTransferWrapperLog: true
Added: SwiftApps/subjobs/vasp/cobaltvasp.sh
--- SwiftApps/subjobs/vasp/cobaltvasp.sh	                        (rev 0)
+++ SwiftApps/subjobs/vasp/cobaltvasp.sh	2015-04-04 17:21:19 UTC (rev 8422)
@@ -0,0 +1,3 @@
+#!/bin/bash
+runjob -p 1 --block $COBALT_PARTNAME : /home/naromero/vasp.5.3.3.bgq.power_elpa_sep2013/vasp.bgq.ibm.real
Property changes on: SwiftApps/subjobs/vasp/cobaltvasp.sh
___________________________________________________________________
Added: svn:executable
Added: SwiftApps/subjobs/vasp/job.sh
--- SwiftApps/subjobs/vasp/job.sh	                        (rev 0)
+++ SwiftApps/subjobs/vasp/job.sh	2015-04-04 17:21:19 UTC (rev 8422)
@@ -0,0 +1,3 @@
+#!/bin/bash
+qsub -A ExM -t 10 -n 1 --mode script cobaltvasp.sh
Property changes on: SwiftApps/subjobs/vasp/job.sh
Added: SwiftApps/subjobs/vasp/runcetus.sh
--- SwiftApps/subjobs/vasp/runcetus.sh	                        (rev 0)
+++ SwiftApps/subjobs/vasp/runcetus.sh	2015-04-04 17:21:19 UTC (rev 8422)
@@ -0,0 +1,4 @@
+#! /bin/sh
+/home/ketan/swift-k/dist/swift-svn/bin/swift -config cetus.conf -reducedLogging -minimalLogging vasp.swift
Property changes on: SwiftApps/subjobs/vasp/runcetus.sh
Added: SwiftApps/subjobs/vasp/runvasp.sh
--- SwiftApps/subjobs/vasp/runvasp.sh	                        (rev 0)
+++ SwiftApps/subjobs/vasp/runvasp.sh	2015-04-04 17:21:19 UTC (rev 8422)
@@ -0,0 +1,18 @@
+#!/bin/bash
+incar=$1
+poscar=$2
+potcar=$3
+kpoints=$4
+latt_factor=$5
+echo Command line arguments: $@
+echo
+sed -i "2s/.*/$latt_factor/" $poscar
+/home/naromero/vasp.5.3.3.bgq.power_elpa_sep2013/vasp.bgq.ibm
+cp OUTCAR output/vasp-outcar-${latt_factor}
+cp CONTCAR output/vasp-contcar-${latt_factor}
Property changes on: SwiftApps/subjobs/vasp/runvasp.sh
Added: SwiftApps/subjobs/vasp/vasp.swift
--- SwiftApps/subjobs/vasp/vasp.swift	                        (rev 0)
+++ SwiftApps/subjobs/vasp/vasp.swift	2015-04-04 17:21:19 UTC (rev 8422)
@@ -0,0 +1,23 @@
+type file;
+app (file _o, file _e, file _outcar, file _contcar) runvasp (file _vaspreproc, file _vaspostproc, file _vasp_incar, file _vasp_poscar, file _vasp_potcar, file _vasp_kpoints, int _latt_factor) {
+  #bgsh @_vasprun @_vasp_incar @_vasp_poscar @_vasp_potcar @_vasp_kpoints _latt_factor stdout=@_o stderr=@_e;
+  bgsh "/home/naromero/vasp.5.3.3.bgq.power_elpa_sep2013/vasp.bgq.ibm.real" @_vaspreproc @_vaspostproc _latt_factor stdout=@_o stderr=@_e;
+# Files
+file vaspreproc <"vaspreproc.sh">;
+file vaspostproc <"vaspostproc.sh">;
+file incar <"INCAR">;
+file poscar <"POSCAR">;
+file potcar <"POTCAR">;
+file kpoints <"KPOINTS">;
+foreach fact in [1:300]{
+  file output <single_file_mapper; file=strcat("logs/vasp-", fact, ".out.txt")>;
+  file error  <single_file_mapper; file=strcat("logs/vasp-", fact, ".err.txt")>;
+  file outcar <single_file_mapper; file=strcat("output/vasp-outcar-", fact)>;
+  file contcar <single_file_mapper; file=strcat("output/vasp-contcar-", fact)>;
+  (output, error, outcar, contcar) = runvasp(vaspreproc, vaspostproc, incar, poscar, potcar, kpoints, fact);
Added: SwiftApps/subjobs/vasp/vaspostproc.sh
--- SwiftApps/subjobs/vasp/vaspostproc.sh	                        (rev 0)
+++ SwiftApps/subjobs/vasp/vaspostproc.sh	2015-04-04 17:21:19 UTC (rev 8422)
@@ -0,0 +1,9 @@
+#!/bin/bash
+latt_factor=$4
Property changes on: SwiftApps/subjobs/vasp/vaspostproc.sh
Added: SwiftApps/subjobs/vasp/vaspreproc.sh
--- SwiftApps/subjobs/vasp/vaspreproc.sh	                        (rev 0)
+++ SwiftApps/subjobs/vasp/vaspreproc.sh	2015-04-04 17:21:19 UTC (rev 8422)
@@ -0,0 +1,9 @@
+#!/bin/bash
+latt_factor=$4
+echo
+#sed -i "2s/.*/$latt_factor/" POSCAR
Property changes on: SwiftApps/subjobs/vasp/vaspreproc.sh
More information about the Swift-commit
