[Swift-commit] r8292 - SwiftApps/subjobs
ketan at ci.uchicago.edu
Wed Oct 22 15:39:53 CDT 2014
Author: ketan
Date: 2014-10-22 15:39:53 -0500 (Wed, 22 Oct 2014)
New Revision: 8292
Modified:
SwiftApps/subjobs/README.txt
SwiftApps/subjobs/bg.sh
SwiftApps/subjobs/docbuild
Log:
document bg.sh
Modified: SwiftApps/subjobs/README.txt
--- SwiftApps/subjobs/README.txt 2014-10-22 20:30:26 UTC (rev 8291)
+++ SwiftApps/subjobs/README.txt 2014-10-22 20:39:53 UTC (rev 8292)
@@ -210,7 +210,6 @@
The key driver of the Swift sub-block jobs is a script called +bg.sh+ that does the sub-block jobs calculations and othe chores for the users. The script looks as follows:
-[source]
include::bg.sh[]
Modified: SwiftApps/subjobs/bg.sh
--- SwiftApps/subjobs/bg.sh 2014-10-22 20:30:26 UTC (rev 8291)
+++ SwiftApps/subjobs/bg.sh 2014-10-22 20:39:53 UTC (rev 8292)
@@ -1,11 +1,8 @@
#! /bin/bash
-# Note: This path is for Cetus only
-#export PATH=/soft/cobalt/cetus/bgq_hardware_mapper:$PATH
-# Note: This path is for Mira or Vesta
mname=$(hostname)
+# vesta and mira has different path than cetus
if [[ $mname == *vesta* || $mname == *mira* ]]
then
export PATH=/soft/cobalt/bgq_hardware_mapper:$PATH
@@ -13,7 +10,8 @@
fi
+# Prepare shape based on subblock size
+# provided by user in sites environment
case "$SUBBLOCK_SIZE" in
8) SHAPE="1x2x2x2x1"
@@ -33,7 +31,7 @@
esac
+# If subblock size is provided, do subblock business
if [ "$SUBBLOCK_SIZE"_ != "_" ]
then
export SWIFT_SUBBLOCKS=$(get-corners.py "$COBALT_PARTNAME" $SHAPE)
@@ -50,6 +48,7 @@
CORNER=${SWIFT_SUBBLOCK_ARRAY[$SWIFT_JOB_SLOT]}
+ #Some logging
echo "$0": running BLOCK="$COBALT_PARTNAME" SLOT="$SWIFT_JOB_SLOT"
echo "$0": running cmd: "$0" args: "$@"
echo "$0": running runjob --block "$COBALT_PARTNAME" --corner "$CORNER" --shape "$SHAPE" --ranks-per-node 1 : "$REMAINING_ARGS"
@@ -59,6 +58,7 @@
echo "Runjob finished."
else
+ # run w/o subblocks if no subblock size provided
echo "Running in nonsubblock mode."
runjob --strace 0 --block "$COBALT_PARTNAME" -p 16 : "$@"
fi
Modified: SwiftApps/subjobs/docbuild
--- SwiftApps/subjobs/docbuild 2014-10-22 20:30:26 UTC (rev 8291)
+++ SwiftApps/subjobs/docbuild 2014-10-22 20:39:53 UTC (rev 8292)
@@ -2,7 +2,7 @@
if [ -z $1 ] ; then
- asciidoc -a toc -a toclevels=2 -a max-width=750px -a textwidth=80 -o /home/$(whoami)/public_html/subjobs.html README.txt
+ asciidoc -a toc -a numbered -a toclevels=2 -a max-width=750px -a textwidth=80 -o /home/$(whoami)/public_html/subjobs.html README.txt
else
- asciidoc -a toc -a toclevels=2 -a max-width=750px -a textwidth=80 -o "$1" README.txt
+ asciidoc -a toc -a numbered -a toclevels=2 -a max-width=750px -a textwidth=80 -o "$1" README.txt
fi
More information about the Swift-commit
