[Swift-commit] r8282 - in SwiftApps/subjobs: . haloapp
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Tue Oct 21 17:30:38 CDT 2014
Author: ketan
Date: 2014-10-21 17:30:38 -0500 (Tue, 21 Oct 2014)
New Revision: 8282
Added:
   SwiftApps/subjobs/haloapp/
   SwiftApps/subjobs/haloapp/apps
   SwiftApps/subjobs/haloapp/cf
   SwiftApps/subjobs/haloapp/cobalt.mira.xml
   SwiftApps/subjobs/haloapp/halo.swift
   SwiftApps/subjobs/haloapp/map_file.txt
   SwiftApps/subjobs/haloapp/mmps
   SwiftApps/subjobs/haloapp/run.sh
   SwiftApps/subjobs/haloapp/runswift.sh
Log:
Adding the halo app
Added: SwiftApps/subjobs/haloapp/apps
--- SwiftApps/subjobs/haloapp/apps	                        (rev 0)
+++ SwiftApps/subjobs/haloapp/apps	2014-10-21 22:30:38 UTC (rev 8282)
@@ -0,0 +1,4 @@
+localhost cat /bin/cat null null null
+cluster bgsh /home/ketan/SwiftApps/subjobs/bg.sh null null null
+cluster2 bgsh /home/ketan/SwiftApps/subjobs/bg.sh null null null
Added: SwiftApps/subjobs/haloapp/cf
--- SwiftApps/subjobs/haloapp/cf	                        (rev 0)
+++ SwiftApps/subjobs/haloapp/cf	2014-10-21 22:30:38 UTC (rev 8282)
@@ -0,0 +1,6 @@
+use.provider.staging=false
+wrapperlog.always.transfer=false
+execution.retries=0
+provider.staging.pin.swiftfiles=false
+sitedir.keep=false
+use.wrapper.staging=false
Added: SwiftApps/subjobs/haloapp/cobalt.mira.xml
--- SwiftApps/subjobs/haloapp/cobalt.mira.xml	                        (rev 0)
+++ SwiftApps/subjobs/haloapp/cobalt.mira.xml	2014-10-21 22:30:38 UTC (rev 8282)
@@ -0,0 +1,57 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
+<pool handle="cluster">
+<execution provider="coaster" jobmanager="local:cobalt" />
+<profile namespace="globus" key="slots">2</profile>
+<profile namespace="globus" key="mode">script</profile>
+<profile namespace="karajan" key="jobThrottle">2.99</profile>
+<profile namespace="karajan" key="initialScore">10000</profile>
+<profile namespace="globus" key="maxwalltime">00:40:00</profile>
+<profile namespace="globus" key="walltime">2050</profile>
+<profile namespace="globus" key="maxnodes">64</profile>
+<profile namespace="globus" key="nodegranularity">64</profile>
+<profile key="SUBBLOCK_SIZE" namespace="env">8</profile>
+<profile key="WORKER_LOGGING_LEVEL" namespace="env">DEBUG</profile>
+<profile key="ENABLE_WORKER_LOGGING" namespace="env">TRUE</profile>
+<profile key="ENABLE_WORKER_LOGGING" namespace="env">ON</profile>
+<profile key="WORKER_LOG_DIR" namespace="env">/home/ketan/workerlogs</profile>
+<profile namespace="globus" key="workerLoggingLevel">DEBUG</profile>
+<profile namespace="globus" key="workerLoggingDirectory">/home/ketan/workerlogs</profile>
+<profile namespace="globus" key="jobsPerNode">8</profile>
+<workdirectory>/home/ketan/swiftwork</workdirectory>
+<filesystem provider="local"/>
+</pool>
+<pool handle="cluster2">
+</pool>
+</config>
Added: SwiftApps/subjobs/haloapp/halo.swift
--- SwiftApps/subjobs/haloapp/halo.swift	                        (rev 0)
+++ SwiftApps/subjobs/haloapp/halo.swift	2014-10-21 22:30:38 UTC (rev 8282)
@@ -0,0 +1,15 @@
+type file;
+app (file _out, file _err) haloapp (string _exec_path, file _map_file)
+   bgsh _exec_path @_map_file stdout=@_out stderr=@_err;
+string exec_path="/home/ketan/SwiftApps/subjobs/HALO/mmps";
+file map_file <"map_file.txt">;
+file out <"halo.out">;
+file err <"halo.err">;
+(out, err) = haloapp( exec_path, map_file);
Added: SwiftApps/subjobs/haloapp/map_file.txt
--- SwiftApps/subjobs/haloapp/map_file.txt	                        (rev 0)
+++ SwiftApps/subjobs/haloapp/map_file.txt	2014-10-21 22:30:38 UTC (rev 8282)
@@ -0,0 +1,4 @@
+0 0 0 0 0 0
+0 0 0 0 1 0
+0 0 0 1 0 0
+0 0 0 1 1 0
Added: SwiftApps/subjobs/haloapp/mmps
(Binary files differ)
Property changes on: SwiftApps/subjobs/haloapp/mmps
___________________________________________________________________
Added: svn:executable
Added: svn:mime-type
   + application/octet-stream
Added: SwiftApps/subjobs/haloapp/run.sh
--- SwiftApps/subjobs/haloapp/run.sh	                        (rev 0)
+++ SwiftApps/subjobs/haloapp/run.sh	2014-10-21 22:30:38 UTC (rev 8282)
@@ -0,0 +1,9 @@
+#!/bin/bash
+NCORES=4
+TIME=30
+EXEC=./mmps
+MAP_FILE=./map_file.txt
+qsub -n $NCORES -t $TIME --env RUNJOB_MAPPING=$MAP_FILE $EXEC
\ No newline at end of file
Property changes on: SwiftApps/subjobs/haloapp/run.sh
Added: SwiftApps/subjobs/haloapp/runswift.sh
--- SwiftApps/subjobs/haloapp/runswift.sh	                        (rev 0)
+++ SwiftApps/subjobs/haloapp/runswift.sh	2014-10-21 22:30:38 UTC (rev 8282)
@@ -0,0 +1,10 @@
+#! /bin/sh
+#Old method
+#qsub -A ATPESC2014 -n 512 -t 15 --mode script runswift_script.sh -config cf -tc.file apps -sites.file localcoast.xml "$@"
+#New method
+/home/ketan/swift-0.95/cog/modules/swift/dist/swift-svn/bin/swift -sites.file cobalt.mira.xml -config cf -tc.file apps halo.swift
+#A testblock run
+#qsub -A ATPESC2013 -n 32 -t 5 -q low --mode c16 --mode script testblock.sh # --disable_preboot
Property changes on: SwiftApps/subjobs/haloapp/runswift.sh
