[Swift-commit] r7752 - SwiftApps/swift-galaxy/swift
ketan at ci.uchicago.edu
Fri Mar 28 13:10:54 CDT 2014
Author: ketan
Date: 2014-03-28 13:10:53 -0500 (Fri, 28 Mar 2014)
New Revision: 7752
Modified:
SwiftApps/swift-galaxy/swift/swiftforeach.xml
SwiftApps/swift-galaxy/swift/swiftforeachlist.sh
SwiftApps/swift-galaxy/swift/swiftforeachrange.sh
Log:
Option to call Swift/T, not tested yet
Modified: SwiftApps/swift-galaxy/swift/swiftforeach.xml
--- SwiftApps/swift-galaxy/swift/swiftforeach.xml 2014-03-28 03:40:26 UTC (rev 7751)
+++ SwiftApps/swift-galaxy/swift/swiftforeach.xml 2014-03-28 18:10:53 UTC (rev 7752)
@@ -14,6 +14,7 @@
#if $rangeorlist.rl == "rng"
+ "${k_or_t}"
"${site}"
"${swiftargs}"
"${interpret}"
@@ -31,6 +32,7 @@
#end for
#elif $rangeorlist.rl == "lst"
swiftforeachlist.sh
+ "${k_or_t}"
"${site}"
"${swiftargs}"
"${interpret}"
@@ -46,6 +48,7 @@
#end for
#else
swiftforeachtest.sh
+ "${k_or_t}"
"${site}"
"${swiftargs}"
"${interpret}"
@@ -72,6 +75,11 @@
#end if
<inputs>
+ <param name="k_or_t" type="select" display="radio" label="choose target execution engine">
+ <option value="swiftK" selected="true">Swift/K</option>
+ <option value="swiftT" >Swift/T</option>
+ </param>
<param name="site" type="select" multiple="true" label="Execution Location" help="Multi-select list - hold the appropriate key while clicking to select multiple items">
<option value="localhost" selected="true">Localhost</option>
<option value="midway">Midway</option>
@@ -80,7 +88,6 @@
<option value="tukey">Tukey</option>
</param>
<param name="interpret" type="select" label="Execution interpreter">
<option value="sh">sh</option>
<option value="python">python</option>
Modified: SwiftApps/swift-galaxy/swift/swiftforeachlist.sh
--- SwiftApps/swift-galaxy/swift/swiftforeachlist.sh 2014-03-28 03:40:26 UTC (rev 7751)
+++ SwiftApps/swift-galaxy/swift/swiftforeachlist.sh 2014-03-28 18:10:53 UTC (rev 7752)
@@ -2,7 +2,8 @@
wdir=$(mktemp -d /tmp/swift-gal.XXXX)
-# numeric range
+k_or_t=$1
+shift
sites=$1 # comma separated list of sites
shift
swiftargs=$1
@@ -105,11 +106,13 @@
done
touch None # Create a "None" file in case user does not specify any stdin file
+if [ "$k_or_t" = "swiftK" ] ; then
+ $swift -sites.file $wdir/sites.xml -tc.file $wdir/tc -config $wdir/cf $wdir/script.swift "${swiftargs}" 2>$logfile
+ EXITCODE=$?
+else
+ echo "stc + turbine; not implemented yet" > /tmp/swiftT.txt
+fi
-#invoke swift
-$swift -sites.file $wdir/sites.xml -tc.file $wdir/tc -config $wdir/cf $wdir/script.swift "${swiftargs}" 2>$logfile
-EXITCODE=$?
`for i in \`find $outloc -type f\`; do echo "\`basename $i\` $i"; done`
cat << EOF > $outlistfile
Modified: SwiftApps/swift-galaxy/swift/swiftforeachrange.sh
--- SwiftApps/swift-galaxy/swift/swiftforeachrange.sh 2014-03-28 03:40:26 UTC (rev 7751)
+++ SwiftApps/swift-galaxy/swift/swiftforeachrange.sh 2014-03-28 18:10:53 UTC (rev 7752)
@@ -3,7 +3,8 @@
echo $@ > /tmp/args.txt
-# numeric range
+k_or_t=$1
+shift
shift
swiftargs=$1
@@ -113,8 +114,12 @@
done
-EXITCODE=$?
+ EXITCODE=$?
+else
+fi
#`for i in \`find $HOME/swift-sandbox -type f\`; do echo "\`basename $i\` $i"; done`
#Populate output file
More information about the Swift-commit
