[Swift-commit] r7748 - in trunk: libexec src/org/griphyn/vdl/karajan/lib src/org/griphyn/vdl/mapping src/org/griphyn/vdl/mapping/file src/org/griphyn/vdl/type src/org/griphyn/vdl/type/impl
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Thu Mar 27 20:51:51 CDT 2014
Author: hategan
Date: 2014-03-27 20:51:51 -0500 (Thu, 27 Mar 2014)
New Revision: 7748
Added:
   trunk/src/org/griphyn/vdl/karajan/lib/ProcessStageouts.java
   trunk/src/org/griphyn/vdl/karajan/lib/ReadCollectList.java
   trunk/src/org/griphyn/vdl/mapping/FileSystemLister.java
   trunk/src/org/griphyn/vdl/mapping/file/AbstractFileNameElementMapper.java
Modified:
   trunk/libexec/_swiftwrap
   trunk/libexec/_swiftwrap.staging
   trunk/libexec/swift-int-staging.k
   trunk/libexec/swift-int.k
   trunk/libexec/swift-lib.k
   trunk/libexec/swift.k
   trunk/src/org/griphyn/vdl/karajan/lib/AppStageouts.java
   trunk/src/org/griphyn/vdl/karajan/lib/GetStagingInfo.java
   trunk/src/org/griphyn/vdl/karajan/lib/IsDone.java
   trunk/src/org/griphyn/vdl/karajan/lib/IsLogged.java
   trunk/src/org/griphyn/vdl/karajan/lib/PathUtils.java
   trunk/src/org/griphyn/vdl/karajan/lib/RemoteFileNames.java
   trunk/src/org/griphyn/vdl/mapping/AbsFile.java
   trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
   trunk/src/org/griphyn/vdl/mapping/AbstractMapper.java
   trunk/src/org/griphyn/vdl/mapping/ArrayDataNode.java
   trunk/src/org/griphyn/vdl/mapping/Mapper.java
   trunk/src/org/griphyn/vdl/mapping/MapperFactory.java
   trunk/src/org/griphyn/vdl/mapping/NullMapper.java
   trunk/src/org/griphyn/vdl/mapping/RootDataNode.java
   trunk/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java
   trunk/src/org/griphyn/vdl/mapping/file/AirsnFileNameElementMapper.java
   trunk/src/org/griphyn/vdl/mapping/file/ArrayFileMapper.java
   trunk/src/org/griphyn/vdl/mapping/file/CSVMapper.java
   trunk/src/org/griphyn/vdl/mapping/file/ConcurrentElementMapper.java
   trunk/src/org/griphyn/vdl/mapping/file/DefaultFileNameElementMapper.java
   trunk/src/org/griphyn/vdl/mapping/file/ExternalMapper.java
   trunk/src/org/griphyn/vdl/mapping/file/FileNameElementMapper.java
   trunk/src/org/griphyn/vdl/mapping/file/FileSystemArrayMapper.java
   trunk/src/org/griphyn/vdl/mapping/file/FixedArrayFileMapper.java
   trunk/src/org/griphyn/vdl/mapping/file/ROIFileNameElementMapper.java
   trunk/src/org/griphyn/vdl/mapping/file/RegularExpressionMapper.java
   trunk/src/org/griphyn/vdl/mapping/file/SingleFileMapper.java
   trunk/src/org/griphyn/vdl/mapping/file/StructuredRegularExpressionMapper.java
   trunk/src/org/griphyn/vdl/mapping/file/TestMapper.java
   trunk/src/org/griphyn/vdl/type/Type.java
   trunk/src/org/griphyn/vdl/type/impl/TypeImpl.java
   trunk/src/org/griphyn/vdl/type/impl/UnresolvedType.java
Log:
support for dynamic array (and other structures) stageouts
Modified: trunk/libexec/_swiftwrap
--- trunk/libexec/_swiftwrap	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/libexec/_swiftwrap	2014-03-28 01:51:51 UTC (rev 7748)
@@ -305,6 +305,10 @@
 OUTF=$VALUE
 shift $SHIFTCOUNT
+getarg "-cf" "$@"
+COLLECT=$VALUE
+shift $SHIFTCOUNT
 getarg "-cdmfile" "$@"
 CDM_FILE=
 if [ "X$VALUE" != "X" ]; then
@@ -384,7 +388,7 @@
 log "DIRS=$DIRS"
 log "INF=$INF"
 log "OUTF=$OUTF"
-log "KICKSTART=$KICKSTART"
+log "COLLECT=$COLLECT"
 log "CDM_FILE=$CDM_FILE"
 log "ARGS=$@"
 log "ARGC=$#"
@@ -543,6 +547,21 @@
 	fi
 fi
+if [ "$COLLECT" != "" ]; then
+	logstate "COLLECT"
+	log "Collect list is $COLLECT"
+	exec 4<> "$WFDIR/shared/${ID}-collect"
+	for O in "$COLLECT" ; do
+		log "Collecting $O"
+		ls -1 $O >&4
+		for OO in $O ; do
+			DIR=`dirname "$OO"`
+			mv $OO "$WFDIR/shared/$DIR" 2>&1 >& "$INFO"
+		done
+	done
+	exec 4>&-
+fi
 log "Moving back to workflow directory $WFDIR"
 cd $WFDIR
 if [ $? != 0 ]; then
Modified: trunk/libexec/_swiftwrap.staging
--- trunk/libexec/_swiftwrap.staging	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/libexec/_swiftwrap.staging	2014-03-28 01:51:51 UTC (rev 7748)
@@ -185,8 +185,8 @@
 OUTF=$VALUE
 shift $SHIFTCOUNT
-getarg "-k" "$@"
-KICKSTART=$VALUE
+getarg "-cf" "$@"
+COLLECT=$VALUE
 shift $SHIFTCOUNT
@@ -248,7 +248,7 @@
 log "DIRS=$DIRS"
 log "INF=$INF"
 log "OUTF=$OUTF"
 log "ARGS=$@"
 log "ARGC=$#"
@@ -302,6 +302,18 @@
 fi
 checkError $? "Application $EXEC failed with an exit code of $?" <$STDERR
+	exec 4<> "_collect"
+		ls -1 $O >&4
+	done
+	exec 4>&-
+fi
 logstate "EXECUTE_DONE"
 log "Job ran successfully"
Modified: trunk/libexec/swift-int-staging.k
--- trunk/libexec/swift-int-staging.k	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/libexec/swift-int-staging.k	2014-03-28 01:51:51 UTC (rev 7748)
@@ -78,7 +78,7 @@
 				tmpdir := dircat("{wfdir}/jobs/{jobdir}", jobid)
 				cdmfile := cdm:file(),
-				(localFileDirs, remoteFileDirs, inFiles, outFiles) := getStagingInfo(stagein, stageout)
+				(fileDirs, inFiles, outFiles, outCollect) := getStagingInfo(stagein, stageout)
 				try {
 					log(LOG:DEBUG, "JOB_START jobid={jobid} tr={tr}", if (arguments != null, (" arguments=", arguments)),
@@ -96,10 +96,10 @@
 							"-out", if(stdout == null, "stdout.txt", getFieldValue(stdout)),
 							"-err", if(stderr == null, "stderr.txt", getFieldValue(stderr)),
 							"-i", if (stdin != null, getFieldValue(stdin)),
-							"-d", str:join(remoteFileDirs, "|"),
+							"-d", str:join(fileDirs, "|"),
 							"-if", str:join(remoteFileNames(inFiles), "|"),
 							"-of", str:join(remoteFileNames(outFiles), "|"),
-							"-k",
+							"-cf", str:join(remoteFileNames(outCollect), "|"),
 							"-cdmfile", cdmfile,
 							"-status", "provider"
 							"-a", if (arguments != null, each(arguments))
@@ -139,7 +139,7 @@
 						else {
 							stageOut("{stdout}", "{stagingMethod}://localhost/{ddir}/{stdout}",
-								mode = STAGING_MODE:ALWAYS + STAGING_MODE:IF_PRESENT)
+								mode = STAGING_MODE:IF_PRESENT)
 						if (stderr == null) {
 							stageOut("stderr.txt", "{stagingMethod}://localhost/{ddir}/{jobid}.stderr",
@@ -147,11 +147,15 @@
 						else {
 							stageOut("{stderr}", "{stagingMethod}://localhost/{ddir}/{stderr}",
 						stageOut("wrapper.error", "{stagingMethod}://localhost/{ddir}/{jobid}.error",
-						appStageouts(jobid, outFiles, stagingMethod)
+						appStageouts(jobid, outFiles, outCollect, stagingMethod)
+						if (!isEmpty(outCollect)) {
+							stageOut("_collect", "{stagingMethod}://localhost/{ddir}/{jobid}.collect",
+								mode = STAGING_MODE:ALWAYS)
 						if (CLEANUP_ENABLED) {
 							task:cleanUp(".")
@@ -159,7 +163,13 @@
-					doRestartLog(stageout)
+						readCollectList("{ddir}/{jobid}.collect")
+					else {
 					log(LOG:DEBUG, "JOB_END jobid={jobid}")
 				else catch(prev) {
Modified: trunk/libexec/swift-int.k
--- trunk/libexec/swift-int.k	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/libexec/swift-int.k	2014-03-28 01:51:51 UTC (rev 7748)
@@ -117,9 +117,12 @@
 		 * to be created and (eventually) exploiting the concurrency in that.
 		log(LOG:INFO, "START jobid={jobid} host={host} - Initializing directory structure")
-		for(u, dirs) {
-			cache(list(u, destdir, host)) {
-				createdirs(u, destdir, host)
+		for(path, dirs) {
+			cache(list(path, destdir, host)) {
+				dc := dircat(destdir, path)
+				log(LOG:INFO, "START path={path} dir={destdir} - Creating directory structure")
+				dir:make(dc, host=host)
 		log(LOG:INFO, "END jobid={jobid} - Done initializing directory structure")
@@ -158,12 +161,8 @@
 	stageWrapperParams := function(jobid, jobdir, wrapfile, dir, host) {
-		log(LOG:INFO, "START jobid={jobid} - staging in wrapper params")
-		provider := provider(wrapfile)
-		srchost := hostname(wrapfile)
-		srcdir := swift:dirname(wrapfile)
-		destdir := dircat(dir, "/parameters/{jobdir}/")
-		filename := basename(wrapfile)
+		log(LOG:INFO, "START jobid={jobid} - staging in wrapper params"),
+		(provider, srchost, destdir, filename, srcdir) := splitFileURL(wrapfile, dir, destdir="parameters/{jobdir}")
 		cache(list(destdir, host)) {
 			dir:make(destdir, host=host, provider=provider)
@@ -274,6 +273,15 @@
 		log(LOG:INFO, "END jobid={jobid} - Staging out finished")
+	doStageoutCollect := function(jobid, dir, host, outFiles) {
+		fileList := "{jobid}-collect"
+		task:transfer(fileList, srchost=host, srcdir=dir)
+		collectList := readCollectList(fileList)
+		doStageout(jobid, dir, host,
+			list:join(outFiles, collectList))
+		collectList
 	fileSizes := function(files) {
 		math:sum(
@@ -359,7 +367,7 @@
 				stdout := if (stdout == null, "stdout.txt", getFieldValue(stdout))
 				stderr := if (stderr == null, "stderr.txt", getFieldValue(stderr)),
 				os := siteProfile(rhost, "SYSINFO:OS")
@@ -370,9 +378,10 @@
 						"\n-out ", stdout,
 						"\n-err ", stderr,
 						"\n-i ", if (stdin != null, getFieldValue(stdin)),
-						"\n-d ", str:join(remoteFileDirs, "|"),
+						"\n-d ", str:join(fileDirs, "|"),
 						"\n-if ", str:join(remoteFileNames(inFiles), "|"),
 						"\n-of ", str:join(remoteFileNames(outFiles), "|"),
+						"\n-cf ", str:join(remoteFileNames(outCollect), "|"),
 						"\n-cdmfile ", cdm:file(),
 						"\n-status ", statusMode,
 						for(a, arguments) {
@@ -385,7 +394,7 @@
 				try {
-					createDirSet(jobid, sharedDir, rhost, localFileDirs)
+					createDirSet(jobid, sharedDir, rhost, fileDirs)
 					doStagein(jobid, sharedDir, rhost, inFiles)
 					if(wrapperMode == "files") {
 						stageWrapperParams(jobid, jobdir, wrapfile, wfdir, rhost)
@@ -427,9 +436,10 @@
 								"-out", stdout,
 								"-err", stderr,
 								"-cdmfile", cdm:file(),
 								"-status", statusMode,
@@ -461,8 +471,13 @@
 					setProgress(progress, "Stage out")
-					doStageout(jobid, sharedDir, rhost, outFiles)
+					if (isEmpty(outCollect)) {
+						doStageout(jobid, sharedDir, rhost, outFiles)
+						[] // empty collect list
+					else {
+						doStageoutCollect(jobid, sharedDir, rhost, outFiles)
 					if (configProperty("wrapperlog.always.transfer") == "true") {
 						discard(transferWrapperLog(rhost, wfdir, jobid, jobdir))
Modified: trunk/libexec/swift-lib.k
--- trunk/libexec/swift-lib.k	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/libexec/swift-lib.k	2014-03-28 01:51:51 UTC (rev 7748)
@@ -131,6 +131,8 @@
 	export(mark, def("org.griphyn.vdl.karajan.lib.Mark"))
 	export(parameterlog, def("org.griphyn.vdl.karajan.lib.Parameterlog"))
 	export(getStagingInfo, def("org.griphyn.vdl.karajan.lib.GetStagingInfo"))
+	export(readCollectList, def("org.griphyn.vdl.karajan.lib.ReadCollectList"))
+	export(processStageouts, def("org.griphyn.vdl.karajan.lib.ProcessStageouts"))
 	export(doRestartLog, def("org.griphyn.vdl.karajan.lib.DoRestartLog"))
 	export(unwrapClosedList, def("org.griphyn.vdl.karajan.lib.UnwrapClosedList"))
Modified: trunk/libexec/swift.k
--- trunk/libexec/swift.k	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/libexec/swift.k	2014-03-28 01:51:51 UTC (rev 7748)
@@ -191,7 +191,7 @@
 					try {
 						throttled {
 							setProgress(progress, "Selecting site")
-							restartOnError(number(swift:configProperty("execution.retries"))) {
+							collectList := restartOnError(number(swift:configProperty("execution.retries"))) {
 								if (swift:configProperty("replication.enabled") == "true") {
 									replicationChannel := channel:new()
 									//trigger the first job
@@ -235,8 +235,7 @@
-							setDatasetValues(stageout)
-							mark(stageout, false, mapping=false)
+							processStageouts(stageout, collectList)
 							log(LOG:INFO, "END_SUCCESS thread=", currentThread(), " tr={tr}")
 							setProgress(progress, "Finished successfully")
Modified: trunk/src/org/griphyn/vdl/karajan/lib/AppStageouts.java
--- trunk/src/org/griphyn/vdl/karajan/lib/AppStageouts.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/karajan/lib/AppStageouts.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -38,6 +38,7 @@
 public class AppStageouts extends InternalFunction {
     private ArgRef<String> jobid;
     private ArgRef<List<AbsFile>> files;
+    private ArgRef<List<AbsFile>> outCollect;
     private ArgRef<String> stagingMethod;
     private ChannelRef<List<String>> cr_stageout;
@@ -47,7 +48,8 @@
     @Override
     protected Signature getSignature() {
-        return new Signature(params("jobid", "files", "stagingMethod"), returns(channel("stageout")));
+        return new Signature(params("jobid", "files", "outCollect", "stagingMethod"),
+            returns(channel("stageout")));
     @Override
@@ -60,27 +62,33 @@
         try {
             Stack stack = thr.getStack();
             List<AbsFile> files = this.files.getValue(stack);
+            List<AbsFile> outCollect = this.outCollect.getValue(stack);
             String stagingMethod = this.stagingMethod.getValue(stack);
             String cwd = this.cwd.getValue(stack);
-            for (AbsFile file : files) {
-                String protocol = file.getProtocol();
-                if (protocol.equals("file")) {
-                    protocol = stagingMethod;
-                String path = file.getDirectory() == null ? file.getName() : file.getDirectory()
-                        + "/" + file.getName();
-                String relpath = PathUtils.remotePathName(path);
-                cr_stageout.append(stack,
-                    makeList(relpath,
-                        AppStageins.localPath(cwd, protocol, path, file)));
+            process(stack, files, stagingMethod, cwd);
+            process(stack, outCollect, stagingMethod, cwd);
         catch (Exception e) {
             throw new ExecutionException(this, e);
+    private void process(Stack stack, List<AbsFile> files, String stagingMethod, String cwd) {
+        for (AbsFile file : files) {
+            String protocol = file.getProtocol();
+            if (protocol.equals("file")) {
+                protocol = stagingMethod;
+            String path = file.getDirectory() == null ? file.getName() : file.getDirectory()
+                    + "/" + file.getName();
+            String relpath = PathUtils.remotePathName(path);
+            cr_stageout.append(stack,
+                makeList(relpath,
+                    AppStageins.localPath(cwd, protocol, path, file)));
     private List<String> makeList(String s1, String s2) {
         return new Pair<String>(s1, s2);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/GetStagingInfo.java
--- trunk/src/org/griphyn/vdl/karajan/lib/GetStagingInfo.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/karajan/lib/GetStagingInfo.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -22,6 +22,7 @@
 import java.util.ArrayList;
 import java.util.Collection;
+import java.util.Collections;
 import java.util.HashSet;
 import java.util.List;
 import java.util.Set;
@@ -36,7 +37,9 @@
 import org.griphyn.vdl.mapping.AbsFile;
 import org.griphyn.vdl.mapping.DSHandle;
 import org.griphyn.vdl.mapping.HandleOpenException;
+import org.griphyn.vdl.mapping.Mapper;
 import org.griphyn.vdl.type.Type;
+import org.griphyn.vdl.type.Types;
 public class GetStagingInfo extends SwiftFunction {
@@ -46,51 +49,97 @@
     @Override
-        return new Signature(params("stageins", "stageouts"), returns(channel("...", 4)));
+        return new Signature(params("stageins", "stageouts"), returns(channel("...", 5)));
+    private static class Info {
+        Set<String> remoteDirNames = Collections.emptySet();
+        List<AbsFile> inFiles = Collections.emptyList();
+        List<AbsFile> outFiles = Collections.emptyList();
+        List<AbsFile> collectPatterns = Collections.emptyList();
     @Override
     public Object function(Stack stack) {
         Collection<DSHandle> fi = stageins.getValue(stack);
         Collection<DSHandle> fo = stageouts.getValue(stack);
         Channel<Object> ret = cr_vargs.get(stack);
-        Set<String> localDirNames = new HashSet<String>();
-        Set<String> remoteDirNames = new HashSet<String>();
-        List<AbsFile> inFiles = new ArrayList<AbsFile>();
-        List<AbsFile> outFiles = new ArrayList<AbsFile>();
+        Info info = new Info();
         try {
-            addPaths(localDirNames, remoteDirNames, inFiles, fi);
-            addPaths(localDirNames, remoteDirNames, outFiles, fo);
+            addPaths(info, fi, false);
+            addPaths(info, fo, true);
         catch (HandleOpenException e) {
         	throw new ExecutionException(e.getMessage(), e);
-        ret.add(localDirNames);
-        ret.add(remoteDirNames);
-        ret.add(inFiles);
-        ret.add(outFiles);
+        ret.add(info.remoteDirNames);
+        ret.add(info.inFiles);
+        ret.add(info.outFiles);
+        ret.add(info.collectPatterns);
         return null;
-    private void addPaths(Set<String> ldirs, Set<String> rdirs, List<AbsFile> files, Collection<DSHandle> vars) throws HandleOpenException {
-    	for (DSHandle file : vars) {
-            for (DSHandle leaf : file.getLeaves()) {
-            	Type t = leaf.getType();
-                String fname = SwiftFunction.argList(SwiftFunction.filename(leaf), true);
-                AbsFile f = new AbsFile(fname);
-                String dir = f.getDirectory();
-                if (dir != null) {
-                    ldirs.add(dir);
-                    rdirs.add(remoteDir(f, dir));
-                files.add(f);
+    private void addPaths(Info info, Collection<DSHandle> vars, boolean out) throws HandleOpenException {
+    	for (DSHandle var : vars) {
+    	    Mapper m = getMapper(var);
+    	    if (out && !m.isStatic() && var.getType().hasArrayComponents()) {
+    	        Collection<AbsFile> patterns = m.getPattern(var.getPathFromRoot(), var.getType());
+    	        for (AbsFile f : patterns) {
+    	            info.collectPatterns = addOne(f, info, info.collectPatterns);
+    	    else {
+    	        addAllStatic(var, m, info, out);
+    private void addAllStatic(DSHandle var, Mapper m, Info info, boolean out) throws HandleOpenException {
+        for (DSHandle leaf : var.getLeaves()) {
+            Type t = leaf.getType();
+            if (t.equals(Types.EXTERNAL)) {
+                continue;
+            if (out) {
+                info.outFiles = addOne((AbsFile) m.map(leaf.getPathFromRoot()), info, info.outFiles);
+            else {
+                info.inFiles = addOne((AbsFile) m.map(leaf.getPathFromRoot()), info, info.inFiles);
+    private List<AbsFile> addOne(AbsFile f, Info info, List<AbsFile> files) {
+        String dir = f.getDirectory();
+        if (dir != null) {
+            if (info.remoteDirNames.isEmpty()) {
+                info.remoteDirNames = new HashSet<String>();
+            info.remoteDirNames.add(remoteDir(f, dir));
+        if (files.isEmpty()) {
+            files = new ArrayList<AbsFile>();
+        files.add(f);
+        return files;
+    private Mapper getMapper(DSHandle var) {
+        Mapper m = var.getMapper();
+        if (m == null) {
+            throw new ExecutionException("No mapper found for  " + var);
+        return m;
     private String remoteDir(AbsFile f, String dir) {
         if ("file".equals(f.getProtocol())) {
             return PathUtils.remotePathName(dir);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/IsDone.java
--- trunk/src/org/griphyn/vdl/karajan/lib/IsDone.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/karajan/lib/IsDone.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -48,22 +48,37 @@
     @Override
+    	Context ctx = context.getValue(stack);
         Iterable<DSHandle> files = stageout.getValue(stack);
         for (DSHandle file : files) {
-            if (file.isRestartable()) {
-                try {
-                        if (!IsLogged.isLogged(context.getValue(stack), leaf)) {
-                            return Boolean.FALSE;
+        	if (file.isRestartable()) {
+        		if (file.getMapper().isStatic()) {
+                    try {
+                        for (DSHandle leaf : file.getLeaves()) {
+                            if (!IsLogged.isLogged(ctx, leaf)) {
+                                return Boolean.FALSE;
-                catch (HandleOpenException e) {
-                    if (logger.isDebugEnabled()) {
-                        logger.debug("Handle open caught in isDone for " + file + ". Assuming false.");
+                    catch (HandleOpenException e) {
+                        if (logger.isDebugEnabled()) {
+                            logger.debug("Handle open caught in isDone for " + file + ". Assuming false.");
+        		else {
+        			 * Checking if data with a dynamic mapper is done cannot involve
+        			 * iterating over the data items, since the items are not known
+        			 * until after the app runs. In such cases revert to logging
+        			 * and checking the entire variable rather than its items
+        			if (!IsLogged.isLogged(ctx, file)) {
         if (!files.iterator().hasNext()) {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/IsLogged.java
--- trunk/src/org/griphyn/vdl/karajan/lib/IsLogged.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/karajan/lib/IsLogged.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -29,6 +29,7 @@
 import org.globus.cog.karajan.analyzer.ArgRef;
 import org.globus.cog.karajan.analyzer.Scope;
 import org.globus.cog.karajan.analyzer.Signature;
+import org.globus.cog.karajan.analyzer.Var;
 import org.globus.cog.karajan.analyzer.VarRef;
 import org.globus.cog.karajan.compiled.nodes.restartLog.LogEntry;
 import org.globus.cog.karajan.compiled.nodes.restartLog.RestartLog;
@@ -65,6 +66,11 @@
 		    return false;
+		 * One cannot use the file name to check if external data is logged
+		 * since there is no explicit file name known to swift for external
+		 * data.
 		if (var.getType().equals(Types.EXTERNAL)) {
 		    return isLogged(logData, LogVar.getLogId(var));
Modified: trunk/src/org/griphyn/vdl/karajan/lib/PathUtils.java
--- trunk/src/org/griphyn/vdl/karajan/lib/PathUtils.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/karajan/lib/PathUtils.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -339,11 +339,12 @@
     public static class SplitFileURL extends SwiftFunction {
        private ArgRef<AbsFile> file;
        private ArgRef<String> dir;
+       private ArgRef<String> destdir;
        private ChannelRef<Object> cr_vargs;
         @Override
-            return new Signature(params("file", "dir"), returns(channel("...", DYNAMIC)));
+            return new Signature(params("file", "dir", optional("destdir", null)), returns(channel("...", DYNAMIC)));
@@ -357,12 +358,18 @@
             AbsFile f = this.file.getValue(stack);
             String dir = this.dir.getValue(stack);
+            String destdir = this.destdir.getValue(stack);
             ret.add(f.getProtocol());
             ret.add(f.getHost());
             String fdir = f.getDirectory();
-            ret.add(DirCat.function(dir, RelDirName.function(fdir), false));
+            if (destdir == null) {
+                ret.add(DirCat.function(dir, RelDirName.function(fdir), false));
+            else {
+                ret.add(DirCat.function(dir, destdir, false));
             ret.add(f.getName());
             ret.add(fdir == null ? "" : fdir);
Added: trunk/src/org/griphyn/vdl/karajan/lib/ProcessStageouts.java
--- trunk/src/org/griphyn/vdl/karajan/lib/ProcessStageouts.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/karajan/lib/ProcessStageouts.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -0,0 +1,114 @@
+ * Copyright 2012 University of Chicago
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * http://www.apache.org/licenses/LICENSE-2.0
+ * Unless required by applicable law or agreed to in writing, software
+ * distributed under the License is distributed on an "AS IS" BASIS,
+ * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+ * See the License for the specific language governing permissions and
+ * limitations under the License.
+ * Created on Jul 18, 2010
+package org.griphyn.vdl.karajan.lib;
+import java.util.Collection;
+import k.rt.Channel;
+import k.rt.ExecutionException;
+import k.rt.Stack;
+import org.apache.log4j.Logger;
+import org.globus.cog.karajan.analyzer.ArgRef;
+import org.globus.cog.karajan.analyzer.ChannelRef;
+import org.globus.cog.karajan.analyzer.Signature;
+import org.griphyn.vdl.mapping.AbsFile;
+import org.griphyn.vdl.mapping.AbstractDataNode;
+import org.griphyn.vdl.mapping.DSHandle;
+import org.griphyn.vdl.mapping.FileSystemLister;
+import org.griphyn.vdl.mapping.Path;
+import org.griphyn.vdl.mapping.RootDataNode;
+public class ProcessStageouts extends SwiftFunction {
+    public static final Logger logger = Logger.getLogger(ProcessStageouts.class);
+	private ArgRef<Collection<DSHandle>> stageouts;
+	private ArgRef<Collection<AbsFile>> collectList;
+    private ChannelRef<Object> cr_restartLog;
+    @Override
+    protected Signature getSignature() {
+        return new Signature(params("stageouts", "collectList"),
+            returns(channel("restartLog", DYNAMIC)));
+    @Override
+    public Object function(Stack stack) {
+        Collection<DSHandle> stageouts = this.stageouts.getValue(stack);
+        Collection<AbsFile> collectList = this.collectList.getValue(stack);
+        if (logger.isInfoEnabled()) {
+            logger.info("Collect list: " + collectList);
+        Channel<Object> log = cr_restartLog.get(stack);
+         * This basically does what setDatasetValues(), mark() and log() used to do.
+         * Specifically, discover all data in the collectList (similar to what
+         * Root*Data nodes do when initialized), set all file objects to some
+         * dummy FILE_VALUE, deep close everything, then send everything to the
+         * restart log
+        process(stageouts, collectList, log);
+        return null;
+    private void process(Collection<DSHandle> vars, Collection<AbsFile> collectList, Channel<Object> log) {
+            if (!m.isStatic() && var.getType().hasArrayComponents()) {
+                Collection<Path> found = m.existing(new FileSystemLister.FileList(collectList));
+                RootDataNode.addExisting(found, m, var.getRoot(), var);
+                logOnly(var, log);
+            else {
+                processStatic(var, log);
+    private void processStatic(DSHandle var, Channel<Object> log) {
+        try {
+                leaf.setValue(AbstractDataNode.FILE_VALUE);
+                leaf.closeShallow();
+                LogVar.logVar(log, leaf);
+        catch (Exception e) {
+            throw new ExecutionException("Exception caught closing stageouts", e);
+    private void logOnly(DSHandle var, Channel<Object> log) {
+        try {
Added: trunk/src/org/griphyn/vdl/karajan/lib/ReadCollectList.java
--- trunk/src/org/griphyn/vdl/karajan/lib/ReadCollectList.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/karajan/lib/ReadCollectList.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -0,0 +1,79 @@
+import java.io.BufferedReader;
+import java.io.File;
+import java.io.FileReader;
+import java.io.IOException;
+import java.util.ArrayList;
+import java.util.List;
+import k.rt.Stack;
+import org.globus.cog.karajan.analyzer.Param;
+import org.globus.cog.karajan.compiled.nodes.functions.AbstractSingleValuedFunction;
+public class ReadCollectList extends AbstractSingleValuedFunction {
+    private ArgRef<String> file;
+    @Override
+    protected Param[] getParams() {
+        return params("file");
+    @Override
+        String fileName = this.file.getValue(stack);
+        try {
+            return readFile(fileName);
+        catch (IOException e) {
+            throw new ExecutionException("Could not read collect file", e);
+    private List<AbsFile> readFile(String fileName) throws IOException {
+        BufferedReader br = new BufferedReader(new FileReader(fileName));
+        List<AbsFile> l = new ArrayList<AbsFile>();
+        String line = br.readLine();
+        while (line != null) {
+            AbsFile f = new AbsFile(remoteToLocal(line));
+            l.add(f);
+            line = br.readLine();
+        br.close();
+        new File(fileName).delete();
+        return l;
+     * Must do the reverse of PathUtils.remotePathName since the collect list
+     * is built remotely by _swiftwrap
+    private String remoteToLocal(String s) {
+        return s.replace("__root__/", "/").replace("__parent__", "..");
Modified: trunk/src/org/griphyn/vdl/karajan/lib/RemoteFileNames.java
--- trunk/src/org/griphyn/vdl/karajan/lib/RemoteFileNames.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/karajan/lib/RemoteFileNames.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -21,6 +21,7 @@
 import k.rt.Stack;
@@ -30,7 +31,7 @@
 public class RemoteFileNames extends SwiftFunction {
-    private ArgRef<List<AbsFile>> files;
+    private ArgRef<Collection<AbsFile>> files;
     @Override
@@ -39,7 +40,7 @@
     @Override
-        List<AbsFile> files = this.files.getValue(stack);
+        Collection<AbsFile> files = this.files.getValue(stack);
         List<String> ret = new ArrayList<String>();
         for (AbsFile f : files) {
             String path = null;
Modified: trunk/src/org/griphyn/vdl/mapping/AbsFile.java
--- trunk/src/org/griphyn/vdl/mapping/AbsFile.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/mapping/AbsFile.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -36,6 +36,10 @@
 public class AbsFile extends RemoteFile implements GeneralizedFileFormat {
+    public AbsFile(AbsFile dir, String name) {
+        super(dir, name);
 	public AbsFile(String url) {
 	    super(url);
Modified: trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -45,7 +45,11 @@
 public abstract class AbstractDataNode implements DSHandle, FutureValue {
-    public static final Object FILE_VALUE = new Object();
+    public static final Object FILE_VALUE = new Object() {
+        public String toString() {
+            return "<FILE>";
     static final String DATASET_URI_PREFIX = "dataset:";
Modified: trunk/src/org/griphyn/vdl/mapping/AbstractMapper.java
--- trunk/src/org/griphyn/vdl/mapping/AbstractMapper.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/mapping/AbstractMapper.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -17,12 +17,14 @@
 package org.griphyn.vdl.mapping;
 import java.util.Map;
 import org.griphyn.vdl.mapping.file.FileGarbageCollector;
+import org.griphyn.vdl.type.Type;
 /** AbstractMapper provides an implementation of the Mapper interface to be
     used as a base class for writing other mappers. It provides handling
@@ -150,4 +152,14 @@
         sb.append('>');
         return sb.toString();
+    @Override
+    public Collection<AbsFile> getPattern(Path path, Type type) {
+        if (isStatic()) {
+            return null;
+        else {
+            throw new UnsupportedOperationException(this.getClass().getName() + ".getPattern()");
Modified: trunk/src/org/griphyn/vdl/mapping/ArrayDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/ArrayDataNode.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/mapping/ArrayDataNode.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -21,6 +21,7 @@
@@ -58,6 +59,21 @@
+	 * Get leaves and make sure they are sorted based on the indices
+	public void getLeaves(List<DSHandle> list) throws HandleOpenException {
+        checkMappingException();
+        if (!isClosed()) {
+            throw new HandleOpenException(this);
+        Map<Comparable<?>, DSHandle> handles = getHandles();
+        Collection<DSHandle> values = handles.values();
+        for (DSHandle child : values) {
+            ((AbstractDataNode) child).getLeaves(list);
 	/** Recursively closes arrays through a tree of arrays and complex
         types. */
     public void closeDeep() {
Added: trunk/src/org/griphyn/vdl/mapping/FileSystemLister.java
--- trunk/src/org/griphyn/vdl/mapping/FileSystemLister.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/mapping/FileSystemLister.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -0,0 +1,180 @@
+//This code is developed as part of the Java CoG Kit project
+//The terms of the license can be found at http://www.cogkit.org/license
+//This message may not be removed or altered.
+ * Created on Mar 24, 2014
+package org.griphyn.vdl.mapping;
+import java.io.FilenameFilter;
+import java.util.LinkedList;
+import java.util.StringTokenizer;
+public interface FileSystemLister {
+    List<AbsFile> listFiles(AbsFile dir, FilenameFilter filter);
+    FileSystemLister DEFAULT = new Default();
+    public static class Default implements FileSystemLister {
+        @Override
+        public List<AbsFile> listFiles(AbsFile dir, FilenameFilter filter) {
+            return dir.listFiles(filter);
+    public static class FileList implements FileSystemLister {
+        private FSTree tree;
+        public FileList(Collection<AbsFile> l) {
+            tree = buildTree(l);
+        private FSTree buildTree(Collection<AbsFile> l) {
+            FSTree tree = new FSTree(null);
+            FSTree root = tree.getDir("absolute");
+            root.setParent(root);
+            for (AbsFile f : l) {
+                String path = f.getPath();
+                boolean absolute = path.startsWith("/");
+                FSTree crt = absolute ? tree.getDir("absolute") : tree.getDir("relative");
+                StringTokenizer st = new StringTokenizer(path, "/", false);
+                while (st.hasMoreTokens()) {
+                    String token = st.nextToken();
+                    if (!st.hasMoreTokens()) {
+                        // file
+                        crt.addFile(token);
+                    else if (token.equals("..")) {
+                        crt = crt.getParent();
+                    else if (token.equals(".")) {
+                        // skip
+                    else {
+                        crt = crt.getDir(token);
+            return tree;
+        @Override
+            String path = dir.getPath();
+            while (st.hasMoreTokens() && crt != null) {
+                if (token.equals("..")) {
+                    // skip
+                else {
+                    crt = crt.findDir(token);
+            if (crt == null) {
+                throw new RuntimeException("No such directory: " + path);
+            for (String name : crt.listFiles()) {
+                if (filter.accept(null, name)) {
+                    l.add(new AbsFile(dir, name));
+            return l;
+    public static class FSTree {
+        private List<String> files;
+        private List<FSTreeDirEntry> dirs;
+        private FSTree parent;
+        public FSTree(FSTree parent) {
+            this.parent = parent;
+        public List<String> listFiles() {
+            if (files == null) {
+                return Collections.emptyList();
+            else {
+                return files;
+        public FSTree getParent() {
+            if (parent == null) {
+                parent = findDir("..");
+            return parent;
+        public void setParent(FSTree parent) {
+        public void addFile(String name) {
+                files = new ArrayList<String>();
+            files.add(name);
+        public FSTree getDir(String name) {
+            FSTree d = findDir(name);
+            if (d == null) {
+                if (dirs == null) {
+                    dirs = new LinkedList<FSTreeDirEntry>();
+                d = new FSTree(this);
+                dirs.add(new FSTreeDirEntry(name, d));
+            return d;
+        public FSTree findDir(String name) {
+                return null;
+            for (FSTreeDirEntry e : dirs) {
+                if (e.name.equals(name)) {
+                    return e.files;
+            return null;
+    public static class FSTreeDirEntry {
+        public final String name;
+        public final FSTree files;
+        public FSTreeDirEntry(String name, FSTree files) {
+            this.name = name;
+            this.files = files;
Modified: trunk/src/org/griphyn/vdl/mapping/Mapper.java
--- trunk/src/org/griphyn/vdl/mapping/Mapper.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/mapping/Mapper.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -21,6 +21,8 @@
 /** This interface must be implemented by a Java class that represents
     a Swift mapper between SwiftScript variables and external data
     sources. */
@@ -39,6 +41,8 @@
         do not necessarily have to exist.
     Collection<Path> existing();
+    Collection<Path> existing(FileSystemLister l);
      * Returns true if data mapped by this mapper cannot
@@ -88,4 +92,18 @@
     void setBaseDir(String baseDir);
     AbstractDataNode getFirstOpenParameter();
+     * For dynamic mappers, this returns a glob pattern that can
+     * be used to filter data that this mapper maps from a set of
+     * files.
+     * The type parameter specifies the swift type of the data
+     * with the specified path. This is necessary in order to build
+     * a sufficiently restrictive pattern in the case when multiple
+     * levels of dynamic mappings exist (e.g. file[][]).
+     * Static mappers should return null.
+    Collection<AbsFile> getPattern(Path path, Type type);
Modified: trunk/src/org/griphyn/vdl/mapping/MapperFactory.java
--- trunk/src/org/griphyn/vdl/mapping/MapperFactory.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/mapping/MapperFactory.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -117,4 +117,18 @@
     public static Set<String> getValidParams(String type) {
         return validParams.get(type);
+    public static void main(String[] args) {
+        for (String name : mappers.keySet()) {
+            try {
+                Mapper m = getMapper(name);
+                if (!m.isStatic()) {
+                    System.out.println(name);
+            catch (InvalidMapperException e) {
+                e.printStackTrace();
Modified: trunk/src/org/griphyn/vdl/mapping/NullMapper.java
--- trunk/src/org/griphyn/vdl/mapping/NullMapper.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/mapping/NullMapper.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -14,7 +14,9 @@
 public class NullMapper implements Mapper {
     public NullMapper() {
@@ -34,7 +36,13 @@
     @Override
+    public Collection<Path> existing(FileSystemLister l) {
+        return null;
+    @Override
     public boolean isStatic() {
         return false;
@@ -80,4 +88,9 @@
     public AbstractDataNode getFirstOpenParameter() {
         return null;
+    @Override
+        return null;
Modified: trunk/src/org/griphyn/vdl/mapping/RootDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/RootDataNode.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/mapping/RootDataNode.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -20,6 +20,8 @@
 import k.rt.Future;
 import k.rt.FutureListener;
 import k.thr.LWThread;
@@ -156,7 +158,7 @@
 	static protected void checkInputs(RootHandle root, DuplicateMappingChecker dmc) {
 	    Mapper mapper = root.getActualMapper();
 		if (root.isInput()) {
-			addExisting(mapper, root);
+			addExisting(mapper.existing(), mapper, root, root);
 			checkConsistency(root, root, dmc);
 		else if (mapper.isStatic()) {
@@ -194,11 +196,11 @@
-	private static void addExisting(Mapper mapper, RootHandle root) {
+	public static void addExisting(Collection<Path> existing, Mapper mapper, RootHandle root, DSHandle var) {
 	    boolean any = false;
-		for (Path p : mapper.existing()) {
+		for (Path p : existing) {
             try {
-                DSHandle field = root.getField(p);
+                DSHandle field = var.getField(p);
                 field.setValue(FILE_VALUE);
                 if (variableTracer.isEnabled()) {
                     variableTracer.trace(root.getThread(), root.getLine(),
@@ -216,7 +218,7 @@
                     e.getDataNode().getType() + "'");
-        root.closeDeep();
+        var.closeDeep();
         if (!any && variableTracer.isEnabled()) {
                 root.getName() + " MAPPING no files found");
Modified: trunk/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -19,8 +19,6 @@
-import java.security.MessageDigest;
-import java.security.NoSuchAlgorithmException;
@@ -30,13 +28,16 @@
-import org.globus.cog.util.Base64;
 import org.griphyn.vdl.mapping.AbstractMapper;
 import org.griphyn.vdl.mapping.MappingParamSet;
 import org.griphyn.vdl.mapping.PhysicalFormat;
 import org.griphyn.vdl.mapping.RootHandle;
+import org.griphyn.vdl.type.Field;
 /** A base class to build mappers which map based on filename patterns.
   * It provides a large amount of default behaviour which can be
@@ -132,71 +133,51 @@
 	    AbstractFileMapperParams cp = getParams();
 	    return map(cp, path, cp.getPrefix());
+	protected PhysicalFormat map(AbstractFileMapperParams cp, Path path, String prefix) {
+	    return map(cp, path, prefix, getElementMapper());
-	protected PhysicalFormat map(AbstractFileMapperParams cp, Path path, String prefix) {
-		if(logger.isDebugEnabled())
-			logger.debug("mapper id="+this.hashCode()+" starting to map "+path);
-		StringBuffer sb = new StringBuffer();
+	protected PhysicalFormat map(AbstractFileMapperParams cp, Path path, String prefix, FileNameElementMapper em) {
+			logger.debug("mapper id=" + this.hashCode() + " starting to map " + path);
+		StringBuilder sb = new StringBuilder();
 		String location = cp.getLocation();
-		maybeAppend(sb, location);
-		if (location != null && !location.endsWith("/")) {
-			sb.append('/');
-		if (prefix != null) {
-			sb.append(prefix);
+        maybeAppend(sb, location);
+        if (location != null && !location.endsWith("/")) {
+            sb.append('/');
+        if (prefix != null) {
+            sb.append(prefix);
-		Iterator<Path.Entry> pi = path.iterator();
-		int level = 0, tokenCount = path.size();
-		while (pi.hasNext()) {
-			Path.Entry nextPathElement = pi.next();
-			if (nextPathElement.isIndex()) {
-			    Comparable<?> key = nextPathElement.getKey();
-			    String f, token;
-			    if (key instanceof Integer) {
-			        token = key.toString();
-			        f = getElementMapper().mapIndex(((Integer) key).intValue());
-			    else if (key instanceof Double) {
-			        token = Double.toHexString(((Double) key).doubleValue());
-			        f = getElementMapper().mapField(token);
-			    else {
-			        MessageDigest md = getDigest();
-			        byte[] buf = md.digest(key.toString().getBytes());
-			        token = encode(buf);
-    			    logger.debug("Mapping path component to " + token);
-    			sb.append(f);
-			else {
-			    String token = (String) nextPathElement.getKey();
-					logger.debug("Mapping path component field " + token);
-				String f = getElementMapper().mapField(token);
-					logger.debug("field is mapped to: " + f);
-				sb.append(f);
+        Iterator<Path.Entry> pi = path.iterator();
+        int level = 0, tokenCount = path.size();
+        while (pi.hasNext()) {
+            Path.Entry nextPathElement = pi.next();
+            if (nextPathElement.isIndex()) {
+                Comparable<?> key = nextPathElement.getKey();
+                String f = em.mapIndex(key, level);
+                sb.append(f);
+            else {
+                String token = (String) nextPathElement.getKey();
+                    logger.debug("Mapping path component field " + token);
+                String f = em.mapField(token);
+                    logger.debug("field is mapped to: " + f);
+                sb.append(f);
-			if (!pi.hasNext()) {
-				logger.debug("last element in name - not using a separator");
-			else if (level < tokenCount - 2) {
-				logger.debug("Adding mapper-specified separator");
-				sb.append(getElementMapper().getSeparator(level));
-			else {
-				logger.debug("Adding '.' instead of mapper-specified separator");
-				sb.append('.');
-			level++;
+            appendSeparator(sb, level, tokenCount, em);
+            level++;
 		String suffix = cp.getSuffix();
 		if (suffix != null) {
 			sb.append(suffix);
@@ -208,26 +189,33 @@
 		return new AbsFile(sb.toString());
-	private String encode(byte[] buf) {
-        buf = Base64.encode(buf);
-        char[] c = new char[buf.length];
-        for (int i = 0; i < buf.length; i++) {
-            c[i] = (char) buf[i];
+    protected void appendSeparator(StringBuilder sb, int level, int totalTokenCount, FileNameElementMapper em) {
+        if (level == totalTokenCount - 1) {
+                logger.debug("last element in name - not using a separator");
-        return String.copyValueOf(c);
-    private MessageDigest getDigest() {
-        try {
-            return MessageDigest.getInstance("SHA-1");
+        else if (level == totalTokenCount - 2) {
+                logger.debug("Adding mapper-specified separator");
+            sb.append(em.getSeparator(level));
-        catch (NoSuchAlgorithmException e) {
-            throw new Error("JVM error: SHA-1 not available");
+        else {
+                logger.debug("Adding '.' instead of mapper-specified separator");
+            sb.append('.');
     @Override
     public Collection<Path> existing() {
+        return existing(FileSystemLister.DEFAULT);
+    @Override
+    public Collection<Path> existing(FileSystemLister fsl) {
 			logger.debug("list existing paths for mapper id=" + this.hashCode());
@@ -246,7 +234,7 @@
 		logger.debug("Processing file list.");
 		String pattern = cp.getPattern();
-		List<AbsFile> files = glob(f, pattern);
+		List<AbsFile> files = glob(f, fsl, pattern);
 		if (files != null) {
@@ -273,7 +261,7 @@
 		return result;
-    protected List<AbsFile> glob(AbsFile f, String pattern) {
+    protected List<AbsFile> glob(AbsFile f, FileSystemLister fsl, String pattern) {
         if (pattern.length() == 0) {
             pattern = "*";
@@ -298,25 +286,25 @@
         else {
             tokens = Collections.singletonList(firstToken);
-        globRecursive(f, l, tokens, 0);
+        globRecursive(f, fsl, l, tokens, 0);
         return l;
-    private void globRecursive(AbsFile f, List<AbsFile> l, List<String> tokens, int pos) {
+    private void globRecursive(AbsFile f, FileSystemLister fsl, List<AbsFile> l, List<String> tokens, int pos) {
         String token = tokens.get(pos);
         if (pos == tokens.size() - 1) {
             if (token.equals("**")) {
                 throw new IllegalArgumentException("** cannot be the last path element in a path pattern");
             // at the file level
-            globFiles(f, l, token);
+            globFiles(f, fsl, l, token);
         else if (token.equals("**")) {
             // recursively go through all sub-directories and match the remaining pattern tokens
             DirectoryScanner ds = new DirectoryScanner(f);
             while (ds.hasNext()) {
                 AbsFile dir = ds.next();
-                globRecursive(dir, l, tokens, pos + 1);
+                globRecursive(dir, fsl, l, tokens, pos + 1);
         else {
@@ -329,14 +317,14 @@
             for (AbsFile dir : dirs) {
-    private void globFiles(AbsFile f, List<AbsFile> l, String token) {
+    private void globFiles(AbsFile f, FileSystemLister fsl, List<AbsFile> l, String token) {
         final String regex = replaceWildcards(token);
-        List<AbsFile> files = f.listFiles(new FilenameFilter() {
+        List<AbsFile> files = fsl.listFiles(f, new FilenameFilter() {
             @Override
             public boolean accept(File dir, String name) {
                 return name.matches(regex);
@@ -345,6 +333,7 @@
         l.addAll(files);
     /** Returns the SwiftScript path for a supplied filename.
 	  * Splits the filename into components using the separator
@@ -425,7 +414,7 @@
 	/** Appends the string representation of obj to the string buffer
 	    if obj is not null. */
-	private void maybeAppend(StringBuffer sb, Object obj) {
+	private void maybeAppend(StringBuilder sb, Object obj) {
 		if (obj != null) {
 			sb.append(obj.toString());
@@ -455,5 +444,129 @@
 		return false;
+    @Override
+        // it makes no sense to call this method without an array
+        if (!type.isArray()) {
+            throw new IllegalArgumentException("getPattern() must be called on an array");
+        AbstractFileMapperParams cp = getParams();
+         * figure out all possible paths to leaves, then map them but
+         * replace all array indices by wildcards
+        FileNameElementMapper m = new WildcardElementMapper(getElementMapper(), path.size());
+        Path cpath = path.addLast(getTemplateIndex(type.keyType()), true);
+        if (!type.itemType().isComposite()) {
+            AbsFile f = (AbsFile) this.map(cp, cpath, cp.getPrefix(), m);
+            return Collections.singletonList(f);
+        else {
+            // build all possible paths to leaves
+            List<Path> l = new ArrayList<Path>();
+            traverseTypes(l, cpath, type.itemType());
+            List<AbsFile> rl = new ArrayList<AbsFile>();
+            for (Path p : l) {
+            return rl;
+    private static class WildcardElementMapper implements FileNameElementMapper {
+        private FileNameElementMapper delegate;
+        private int fixed;
+        public WildcardElementMapper(FileNameElementMapper delegate, int fixed) {
+            this.delegate = delegate;
+            this.fixed = fixed;
+        @Override
+        public String mapField(String fieldName) {
+            return delegate.mapField(fieldName);
+        @Override
+        public String rmapField(String pathElement) {
+            return delegate.rmapField(pathElement);
+        @Override
+        public String mapIndex(int index, int pos) {
+            String s = delegate.mapIndex(index, pos);
+            if (pos > fixed) {
+                return nChars(s.length());
+            else {
+                return s;
+        @Override
+        public String mapIndex(Object index, int pos) {
+            if (pos >= fixed) {
+            else {
+                return s;
+        @Override
+        public int rmapIndex(String pathElement) {
+            return delegate.rmapIndex(pathElement);
+        @Override
+        public String getSeparator(int depth) {
+            return delegate.getSeparator(depth);
+        private String nChars(int length) {
+            char[] c = new char[length];
+            for (int i = 0; i < length; i++) {
+                c[i] = '?';
+            return new String(c);
+    private void traverseTypes(List<Path> l, Path path, Type t) {
+        if (!t.isComposite()) {
+            // done
+            l.add(path);
+        else if (t.isArray()) {
+            Path cpath = path.addLast(getTemplateIndex(t.keyType()), true);
+            traverseTypes(l, cpath, t.itemType());
+        else {
+            // struct
+            for (Field f : t.getFields()) {
+                Path cpath = path.addLast(f.getId());
+                traverseTypes(l, cpath, f.getType());
+    private Comparable<?> getTemplateIndex(Type keyType) {
+        if (keyType.equals(Types.INT)) {
+            return 1;
+        else if (keyType.equals(Types.FLOAT)) {
+            return 1.1;
+        else {
+            return "index";
Added: trunk/src/org/griphyn/vdl/mapping/file/AbstractFileNameElementMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/AbstractFileNameElementMapper.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/mapping/file/AbstractFileNameElementMapper.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -0,0 +1,63 @@
+ * Created on Mar 22, 2014
+package org.griphyn.vdl.mapping.file;
+import java.security.MessageDigest;
+import java.security.NoSuchAlgorithmException;
+import org.globus.cog.util.Base64;
+public abstract class AbstractFileNameElementMapper implements FileNameElementMapper {
+    public static final Logger logger = Logger.getLogger(AbstractFileNameElementMapper.class);
+    @Override
+    public String mapIndex(Object key, int pos) {
+        String token;
+        String f;
+        if (key instanceof Integer) {
+            token = key.toString();
+            f = mapIndex(((Integer) key).intValue(), pos);
+        else if (key instanceof Double) {
+            token = Double.toHexString(((Double) key).doubleValue());
+            f = mapField(token);
+        else {
+            MessageDigest md = getDigest();
+            byte[] buf = md.digest(key.toString().getBytes());
+            token = encode(buf);
+            logger.debug("Mapping path component to " + token);
+        return f;
+    private String encode(byte[] buf) {
+        buf = Base64.encode(buf);
+        char[] c = new char[buf.length];
+        for (int i = 0; i < buf.length; i++) {
+            c[i] = (char) buf[i];
+        return String.copyValueOf(c);
+    private MessageDigest getDigest() {
+        try {
+            return MessageDigest.getInstance("SHA-1");
+        catch (NoSuchAlgorithmException e) {
+            throw new Error("JVM error: SHA-1 not available");
Modified: trunk/src/org/griphyn/vdl/mapping/file/AirsnFileNameElementMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/AirsnFileNameElementMapper.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/mapping/file/AirsnFileNameElementMapper.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -21,7 +21,7 @@
-public class AirsnFileNameElementMapper implements FileNameElementMapper {
+public class AirsnFileNameElementMapper extends AbstractFileNameElementMapper {
 	public static final int INDEX_WIDTH = 4;
@@ -35,7 +35,7 @@
 		return pathElement;
-	public String mapIndex(int index) {
         sb.append('i');
 		String num = String.valueOf(index);
@@ -56,5 +56,4 @@
 		return "_";
Modified: trunk/src/org/griphyn/vdl/mapping/file/ArrayFileMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/ArrayFileMapper.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/mapping/file/ArrayFileMapper.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -11,6 +11,7 @@
 import org.griphyn.vdl.mapping.InvalidPathException;
@@ -48,6 +49,11 @@
 	@Override
+        throw new UnsupportedOperationException();
+    @Override
 	public PhysicalFormat map(Path path) {
 		if (path.isEmpty()) {
 			throw new IllegalArgumentException("Path cannot be empty");
Modified: trunk/src/org/griphyn/vdl/mapping/file/CSVMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/CSVMapper.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/mapping/file/CSVMapper.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -33,6 +33,7 @@
 import org.griphyn.vdl.mapping.GeneralizedFileFormat;
 import org.griphyn.vdl.mapping.InvalidMappingParameterException;
@@ -183,9 +184,14 @@
 		return l;
-	@Override
+	@Override
+    @Override
-		return false;
+		return true;
 	@Override
Modified: trunk/src/org/griphyn/vdl/mapping/file/ConcurrentElementMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/ConcurrentElementMapper.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/mapping/file/ConcurrentElementMapper.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -26,7 +26,7 @@
     the same from version to version.
-public class ConcurrentElementMapper implements FileNameElementMapper {
+public class ConcurrentElementMapper extends AbstractFileNameElementMapper {
 	/** determines how many directories and element files are permitted
 	    in each directory. There will be no more than
@@ -43,23 +43,24 @@
 		return pathElement;
 		sb.append("-array/");
 		sb.append(splitIndexByLoadFactor(index));
 		sb.append("/");
-		sb.append("elt-"+String.valueOf(index));
+		sb.append("elt-");
+		sb.append(String.valueOf(index));
-	String splitIndexByLoadFactor(int index)
-		if(index<=DIRECTORY_LOAD_FACTOR) {
+	String splitIndexByLoadFactor(int index) {
+		if (index <= DIRECTORY_LOAD_FACTOR) {
 			return "";
-		} else {
-			String prefix = "h"+String.valueOf(index % DIRECTORY_LOAD_FACTOR) +"/";
-			String suffix = splitIndexByLoadFactor(index/DIRECTORY_LOAD_FACTOR);
+		else {
+			String prefix = "h" + String.valueOf(index % DIRECTORY_LOAD_FACTOR) + "/";
+			String suffix = splitIndexByLoadFactor(index / DIRECTORY_LOAD_FACTOR);
 			return prefix + suffix;
Modified: trunk/src/org/griphyn/vdl/mapping/file/DefaultFileNameElementMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/DefaultFileNameElementMapper.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/mapping/file/DefaultFileNameElementMapper.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -30,7 +30,7 @@
   * </ul>
-public class DefaultFileNameElementMapper implements FileNameElementMapper {
+public class DefaultFileNameElementMapper extends AbstractFileNameElementMapper {
 	public static final int DEFAULT_INDEX_WIDTH = 4;
@@ -52,7 +52,7 @@
 		return pathElement;
 		StringBuilder sb = new StringBuilder(indexWidth);
 		for (int i = 0; i < indexWidth - num.length(); i++) {
Modified: trunk/src/org/griphyn/vdl/mapping/file/ExternalMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/ExternalMapper.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/mapping/file/ExternalMapper.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -32,6 +32,7 @@
@@ -140,7 +141,12 @@
 	@Override
 		return map.keySet();
+	@Override
 	public Path rmap(String name) {
 		if (name == null || name.equals("")) {
Modified: trunk/src/org/griphyn/vdl/mapping/file/FileNameElementMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/FileNameElementMapper.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/mapping/file/FileNameElementMapper.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -27,7 +27,9 @@
 	String mapField(String fieldName);
 	String rmapField(String pathElement);
-	String mapIndex(int index);
+	String mapIndex(int index, int pos);
+	String mapIndex(Object index, int pos);
 	int rmapIndex(String pathElement);
 	/** Returns a string which will be used as a separator string between
Modified: trunk/src/org/griphyn/vdl/mapping/file/FileSystemArrayMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/FileSystemArrayMapper.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/mapping/file/FileSystemArrayMapper.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -17,12 +17,15 @@
 import java.util.HashMap;
 public class FileSystemArrayMapper extends AbstractFileMapper {
     private Map<Object, String> filenames = new HashMap<Object, String>();
@@ -47,7 +50,7 @@
     @Override
-		if (path.size()!=1) {
+		if (path.size() != 1) {
 			return null;
 		if (!path.isArrayIndex(0)) {
@@ -68,5 +71,27 @@
 		return new AbsFile(filename);
+    @Override
+            throw new IllegalArgumentException("Cannot use a non-array type with the FilesysMapper");
+        String location = defaultValue(cp.getLocation(), "./");
+        String prefix = defaultValue(cp.getPrefix(), "");
+        String suffix = defaultValue(cp.getSuffix(), "");
+        String pattern = defaultValue(cp.getPattern(), null);
+        if (pattern != null) {
+            return Collections.singletonList(new AbsFile(location + "/" + pattern));
+        else {
+            return Collections.singletonList(new AbsFile(location + "/" + prefix + "*" + suffix));
+    private String defaultValue(String s, String d) {
+        return s == null ? d : s;
Modified: trunk/src/org/griphyn/vdl/mapping/file/FixedArrayFileMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/FixedArrayFileMapper.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/mapping/file/FixedArrayFileMapper.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -25,6 +25,7 @@
@@ -86,6 +87,11 @@
 		return l;
+	@Override
 	@Override
Modified: trunk/src/org/griphyn/vdl/mapping/file/ROIFileNameElementMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/ROIFileNameElementMapper.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/mapping/file/ROIFileNameElementMapper.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -20,7 +20,7 @@
-public class ROIFileNameElementMapper implements FileNameElementMapper {
+public class ROIFileNameElementMapper extends AbstractFileNameElementMapper {
 	private Map<Integer, String> basenames;
 	int index;
@@ -46,7 +46,7 @@
 		return pathElement;
 		return basenames.get(index);
Modified: trunk/src/org/griphyn/vdl/mapping/file/RegularExpressionMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/RegularExpressionMapper.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/mapping/file/RegularExpressionMapper.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -28,6 +28,7 @@
@@ -73,7 +74,12 @@
 		else {
+	@Override
 	    RegularExpressionMapperParams cp = getParams();
Modified: trunk/src/org/griphyn/vdl/mapping/file/SingleFileMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/SingleFileMapper.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/mapping/file/SingleFileMapper.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -23,6 +23,7 @@
@@ -61,6 +62,11 @@
+    @Override
     @Override
Modified: trunk/src/org/griphyn/vdl/mapping/file/StructuredRegularExpressionMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/StructuredRegularExpressionMapper.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/mapping/file/StructuredRegularExpressionMapper.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -29,6 +29,7 @@
@@ -84,7 +85,12 @@
 		return output;
+    @Override
 	@Override
Modified: trunk/src/org/griphyn/vdl/mapping/file/TestMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/TestMapper.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/mapping/file/TestMapper.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -23,6 +23,7 @@
@@ -103,9 +104,19 @@
         return Collections.singletonList(Path.EMPTY_PATH);
+    @Override
+        return Collections.singletonList(Path.EMPTY_PATH);
         TestMapperParams cp = getParams();
-        return cp.getStatic_();
+        if (cp != null) {
+            return cp.getStatic_();
+        else {
+            return false;
Modified: trunk/src/org/griphyn/vdl/type/Type.java
--- trunk/src/org/griphyn/vdl/type/Type.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/type/Type.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -187,5 +187,7 @@
-    public boolean hasNonPrimitiveComponents();
+    public boolean hasNonPrimitiveComponents();
+    public boolean hasArrayComponents();
Modified: trunk/src/org/griphyn/vdl/type/impl/TypeImpl.java
--- trunk/src/org/griphyn/vdl/type/impl/TypeImpl.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/type/impl/TypeImpl.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -32,7 +32,7 @@
 	private boolean primitive;
 	private Map<String, Field> fields;
 	private Type baseType;
-	private Boolean hasNonPrimitiveComponents;
+	private Boolean hasNonPrimitiveComponents, hasArrayComponents;
 	public TypeImpl() {
 		this((URI) null, null, false);
@@ -164,6 +164,27 @@
         return hasNonPrimitiveComponents;
+    public synchronized boolean hasArrayComponents() {
+        if (hasArrayComponents == null) {
+            if (isArray()) {
+                hasArrayComponents = true;
+            else if (isPrimitive()) {
+            else {
+                // struct
+                for (Field f : getFields()) {
+                    if (f.getType().hasArrayComponents()) {
+                        return hasArrayComponents = true;
+                hasArrayComponents = false;
+        return hasArrayComponents;
     public static class Array extends TypeImpl {
Modified: trunk/src/org/griphyn/vdl/type/impl/UnresolvedType.java
--- trunk/src/org/griphyn/vdl/type/impl/UnresolvedType.java	2014-03-22 20:28:48 UTC (rev 7747)
+++ trunk/src/org/griphyn/vdl/type/impl/UnresolvedType.java	2014-03-28 01:51:51 UTC (rev 7748)
@@ -88,6 +88,11 @@
     public boolean hasNonPrimitiveComponents() {
+	@Override
+    public boolean hasArrayComponents() {
     public String getName() {
 		return name;
