[Swift-commit] cog r3883
swift at ci.uchicago.edu swift at ci.uchicago.edu
Thu Mar 27 20:40:05 CDT 2014
r3883 | hategan | 2014-03-27 20:39:36 -0500 (Thu, 27 Mar 2014) | 1 line
added filtered list method to file resources
Index: modules/abstraction-common/src/org/globus/cog/abstraction/impl/file/FileResourceFileFilter.java
--- modules/abstraction-common/src/org/globus/cog/abstraction/impl/file/FileResourceFileFilter.java	(revision 0)
+++ modules/abstraction-common/src/org/globus/cog/abstraction/impl/file/FileResourceFileFilter.java	(revision 3883)
@@ -0,0 +1,16 @@
+//This code is developed as part of the Java CoG Kit project
+//The terms of the license can be found at http://www.cogkit.org/license
+//This message may not be removed or altered.
+ * Created on Mar 26, 2014
+package org.globus.cog.abstraction.impl.file;
+import org.globus.cog.abstraction.interfaces.GridFile;
+public interface FileResourceFileFilter {
+    boolean accept(GridFile f);
Index: modules/abstraction-common/src/org/globus/cog/abstraction/impl/file/AbstractFileResource.java
--- modules/abstraction-common/src/org/globus/cog/abstraction/impl/file/AbstractFileResource.java	(revision 3882)
+++ modules/abstraction-common/src/org/globus/cog/abstraction/impl/file/AbstractFileResource.java	(working copy)
@@ -13,9 +13,11 @@
 import java.io.InputStream;
 import java.io.OutputStream;
 import java.net.PasswordAuthentication;
+import java.util.ArrayList;
 import java.util.Collection;
 import java.util.HashMap;
 import java.util.Iterator;
+import java.util.List;
 import java.util.Map;
 import org.apache.log4j.Logger;
@@ -436,4 +438,24 @@
             throw new UnsupportedOperationException("The " + name + " provider does not support partial transfers");
+     * Convenience method to implement filtering. Providers should implement their
+     * own, more efficient, filtering
+     * @throws FileResourceException
+     * @throws DirectoryNotFoundException
+    @Override
+    public Collection<GridFile> list(String dir, FileResourceFileFilter filter)
+            throws DirectoryNotFoundException, FileResourceException {
+        List<GridFile> nl = new ArrayList<GridFile>();
+        Collection<GridFile> ol = list(dir);
+        for (GridFile f : ol) {
+            if (filter.accept(f)) {
+                nl.add(f);
+        return nl;
Index: modules/abstraction-common/src/org/globus/cog/abstraction/interfaces/FileResource.java
--- modules/abstraction-common/src/org/globus/cog/abstraction/interfaces/FileResource.java	(revision 3882)
+++ modules/abstraction-common/src/org/globus/cog/abstraction/interfaces/FileResource.java	(working copy)
@@ -10,12 +10,14 @@
 import org.globus.cog.abstraction.impl.common.task.IllegalSpecException;
 import org.globus.cog.abstraction.impl.common.task.InvalidSecurityContextException;
 import org.globus.cog.abstraction.impl.common.task.TaskSubmissionException;
 import org.globus.cog.abstraction.impl.file.DirectoryNotFoundException;
 import org.globus.cog.abstraction.impl.file.FileResourceException;
+import org.globus.cog.abstraction.impl.file.FileResourceFileFilter;
 import org.globus.cog.abstraction.impl.file.IllegalHostException;
@@ -132,6 +134,9 @@
     public Collection<GridFile> list(String directoryName)
             throws DirectoryNotFoundException, FileResourceException;
+            throws DirectoryNotFoundException, FileResourceException;
      * Creates a new directory with the given name
@@ -371,4 +376,5 @@
     void thirdPartyTransfer(FileResource sourceResource, FileFragment source, FileFragment destination)
             throws FileResourceException;
