[Swift-commit] r7719 - SwiftApps/cloud
ketan at ci.uchicago.edu
Mon Mar 17 12:38:25 CDT 2014
Author: ketan
Date: 2014-03-17 12:38:25 -0500 (Mon, 17 Mar 2014)
New Revision: 7719
Modified:
SwiftApps/cloud/README
SwiftApps/cloud/addnodes
Log:
document spot instances and add more info on addnodes
Modified: SwiftApps/cloud/README
--- SwiftApps/cloud/README 2014-03-17 16:49:25 UTC (rev 7718)
+++ SwiftApps/cloud/README 2014-03-17 17:38:25 UTC (rev 7719)
@@ -202,7 +202,18 @@
./addnodes -a "54.243.24.104 54.243.24.154"
+Add EC2 spot instances
+To add resources from the EC2 spot instances, use the `-p` option of the `addnodes` command. For example, the following commandline will add 2 EC2 spot instances with a bid of $ 0.08 :
+./addnodes -p 0.08 -n 2
+Note that there is no guarantee of the resources being available at this price.
+In case the resources are not available, the request will be silently ignored.
Remove EC2 compute instances
Modified: SwiftApps/cloud/addnodes
--- SwiftApps/cloud/addnodes 2014-03-17 16:49:25 UTC (rev 7718)
+++ SwiftApps/cloud/addnodes 2014-03-17 17:38:25 UTC (rev 7719)
@@ -53,7 +53,6 @@
addbynum (){
- echo "$1"
if [ -z "$SPOT_PRICE" ] ; then
#ec2-run-instances -k <key-name> -n 1 -g <groupname> --instance-type <type> <ami-id>
@@ -61,10 +60,10 @@
runinst=$(ec2-run-instances -k "$EC2KEYPAIR" -g "$EC2SECGRP" -n "$1" --instance-type t1.micro "$EC2AMI")
else
echo "spot price set to: $SPOT_PRICE"
- runinst=$(ec2-request-spot-instances -k "$EC2KEYPAIR" -g "$EC2SECGRP" -n "$1" --instance-type -p "$SPOT_PRICE" t1.micro "$EC2AMI")
+ runinst=$(ec2rsi -k "$EC2KEYPAIR" -g "$EC2SECGRP" -n "$1" --instance-type -p "$SPOT_PRICE" t1.micro "$EC2AMI")
fi
- echo "Waiting for instances to start"
+ echo "Waiting for $1 instance(s) to start"
sleep 60
for i in $(echo $runinst | grep -o '\bi-........\b'); do
ip=$(ec2din $i | grep 'running' | awk '{print $15}')
More information about the Swift-commit
