[Swift-commit] r7704 - in SwiftApps: EPlus/examples gocat swift-galaxy
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Thu Mar 13 10:57:00 CDT 2014
Author: ketan
Date: 2014-03-13 10:57:00 -0500 (Thu, 13 Mar 2014)
New Revision: 7704
Added:
   SwiftApps/EPlus/examples/in.imf
   SwiftApps/gocat/locatewrap.sh
Modified:
   SwiftApps/swift-galaxy/README
Log:
shuffle in readme
Added: SwiftApps/EPlus/examples/in.imf
--- SwiftApps/EPlus/examples/in.imf	                        (rev 0)
+++ SwiftApps/EPlus/examples/in.imf	2014-03-13 15:57:00 UTC (rev 7704)
@@ -0,0 +1,9361 @@
+##set1 ORIENTATION[] 20
+##set1 HEIGHT[] 1
+! DOE Commercial Reference Building
+! Large office, new construction 90.1-2004
+! Version 1.3_5.0
+! EnergyPlus Version 5.0
+! ASHRAE Standards 90.1-2004 and 62-1999
+! Description:  12 story plus basement, office building.
+! Form:         Area = 46,320 m2 (498,588 ft2); Number of Stories = 12; Shape = rectangle, Aspect ratio = 1.5
+! Envelope:     Envelope thermal properties vary with climate according to ASHRAE Standard 90.1-2004.
+!               Opaque constructions: mass walls; built-up flat roof (insulation above deck); slab-on-grade floor
+!               Windows: window-to-wall ratio = 38.0%, equal distribution of windows
+!               Infiltration in perimeter zones only
+!                            = 0.4 cfm/ft2 above grade wall area at 0.3 in wc (75 Pa) adjusted to 0.016 in wc (4 Pa).
+!                              25% of full value when ventilation system on.
+! HVAC:         2 water-cooled chillers, VAV with reheat and plenum zones
+!               Economizer per 90.1-2004
+! Int. gains:   lights = 10.76 W/m2 (1.0 W/ft2) (building area method);
+!               elec. plug loads = 10.76 W/m2 (1.0 W/ft2)
+!               gas plug load = 0 W/m2 (0 W/ft2)
+!               people = 2,397 total, 5.38/100 m2 (5.0/1000 ft2); basement 2.69/100 m2 (2.5/1000 ft2)
+!               elevators = 12 @ 25 HP each, 91% motor efficiency, motor heat exhausted directly
+! Detached Shading:               None
+! Daylight:                       None
+! Natural Ventilation:            None
+! Zonal Equipment:                None
+! Air Primary Loops:              VAV WITH REHEAT
+! Plant Loops:                    SHWSys1, HeatSys1, CoolSys1, TowerWaterSys
+! System Equipment Autosize:      Yes
+! Purchased Cooling:              None
+! Purchased Heating:              None
+! Coils:                          Coil:Cooling:Water; Coil:Heating:Water
+! Pumps:                          Yes
+! Boilers:                        Boiler:HotWater (gas-fired)
+! Chillers:                       Chiller:Electric:ReformulatedEIR (water-cooled)
+!***** NOTICE *****
+!***** The Reference Buildings were prepared as an account of work sponsored by an *****
+!***** agency of the United States government. Neither the United States *****
+!***** government nor any agency thereof, nor any of their employees, makes *****
+!***** any warranty, express or implied, or assumes any legal liability or *****
+!***** responsibility for the accuracy, completeness, or usefulness of any *****
+!***** information, apparatus, product, or process disclosed, or represents *****
+!***** that its use would not infringe privately owned rights. Reference *****
+!***** herein to any specific commercial product, process, or service by *****
+!***** trade name, trademark, manufacturer, or otherwise does not necessarily *****
+!***** constitute or imply its endorsement, recommendation, or favoring by *****
+!***** the United States government or any agency thereof. The views and *****
+!***** opinions of authors expressed herein do not necessarily state or *****
+!***** reflect those of the United States government or any agency thereof. *****
+!***** Access to and use of the Reference Buildings imposes the following obligations *****
+!***** on the user. The user agrees to credit DOE, NREL, PNNL, and LBNL in *****
+!***** any publication(s) that that result from the use of Reference Buildings. *****
+!***** However, the names of DOE/NREL/PNNL/LBNL may not be used in any *****
+!***** advertising or publicity that implies endorsement or promotion of any *****
+!***** products, services or commercial entities. *****
+! Reference citation for the Commercial Reference Buildings:
+! Deru, M.; Field, K.; Studer, D.; Benne, K.; Griffith, B.; Torcellini, P;
+! Halverson, M.; Winiarski, D.; Liu, B.; Rosenberg, M.; Huang, J.;
+! Yazdanian, M.; Crawley, D. (2010).
+! U.S. Department of Energy Commercial Reference Building Models of the National Building Stock.
+! Washington, DC: U.S. Department of Energy, Energy Efficiency and
+! Renewable Energy, Office of Building Technologies.
+! ***GENERAL SIMULATION PARAMETERS***
+! Number of Zones: 19
+  Version,8.0;
+  SimulationControl,
+    YES,                     !- Do Zone Sizing Calculation
+    YES,                     !- Do System Sizing Calculation
+    YES,                     !- Do Plant Sizing Calculation
+    NO,                      !- Run Simulation for Sizing Periods
+    YES;                     !- Run Simulation for Weather File Run Periods
+  Building,
+    Ref Bldg Large Office New2004_v1.3_5.0,  !- Name
+    ORIENTATION[],                  !- North Axis {deg}
+    City,                    !- Terrain
+    0.0400,                  !- Loads Convergence Tolerance Value
+    0.2000,                  !- Temperature Convergence Tolerance Value {deltaC}
+    FullInteriorAndExterior, !- Solar Distribution
+    25,                      !- Maximum Number of Warmup Days
+    6;                       !- Minimum Number of Warmup Days
+  RunPeriod,
+    ,                        !- Name
+    1,                       !- Begin Month
+    1,                       !- Begin Day of Month
+    12,                      !- End Month
+    31,                      !- End Day of Month
+    Sunday,                  !- Day of Week for Start Day
+    No,                      !- Use Weather File Holidays and Special Days
+    No,                      !- Use Weather File Daylight Saving Period
+    No,                      !- Apply Weekend Holiday Rule
+    Yes,                     !- Use Weather File Rain Indicators
+    Yes,                     !- Use Weather File Snow Indicators
+    1.0000;                  !- Number of Times Runperiod to be Repeated
+! ***HOLIDAYS & DAYLIGHT SAVINGS***
+  RunPeriodControl:DaylightSavingTime,
+    2nd Sunday in March,     !- Start Date
+    1st Sunday in November;  !- End Date
+  RunPeriodControl:SpecialDays,
+    New Years Day,           !- Name
+    January 1,               !- Start Date
+    1,                       !- Duration {days}
+    Holiday;                 !- Special Day Type
+    Veterans Day,            !- Name
+    November 11,             !- Start Date
+    Christmas,               !- Name
+    December 25,             !- Start Date
+    Independence Day,        !- Name
+    July 4,                  !- Start Date
+    MLK Day,                 !- Name
+    3rd Monday in January,   !- Start Date
+    Presidents Day,          !- Name
+    3rd Monday in February,  !- Start Date
+    Memorial Day,            !- Name
+    Last Monday in May,      !- Start Date
+    Labor Day,               !- Name
+    1st Monday in September, !- Start Date
+    Columbus Day,            !- Name
+    2nd Monday in October,   !- Start Date
+    Thanksgiving,            !- Name
+    4th Thursday in November,!- Start Date
+! ***SCHEDULE TYPES***
+  ScheduleTypeLimits,
+    Any Number;              !- Name
+    Fraction,                !- Name
+    0.0,                     !- Lower Limit Value
+    1.0,                     !- Upper Limit Value
+    CONTINUOUS;              !- Numeric Type
+    Temperature,             !- Name
+    -60,                     !- Lower Limit Value
+    200,                     !- Upper Limit Value
+    On/Off,                  !- Name
+    0,                       !- Lower Limit Value
+    1,                       !- Upper Limit Value
+    DISCRETE;                !- Numeric Type
+    Control Type,            !- Name
+    4,                       !- Upper Limit Value
+    Humidity,                !- Name
+    10,                      !- Lower Limit Value
+    90,                      !- Upper Limit Value
+    Number;                  !- Name
+! ***ALWAYS ON SCHEDULE***
+  Schedule:Compact,
+    ALWAYS_ON,               !- Name
+    On/Off,                  !- Schedule Type Limits Name
+    Through: 12/31,          !- Field 1
+    For: AllDays,            !- Field 2
+    Until: 24:00,1;          !- Field 3
+! ***MISC SIMULATION PARAMETERS***
+  SurfaceConvectionAlgorithm:Inside,TARP;
+  SurfaceConvectionAlgorithm:Outside,DOE-2;
+  HeatBalanceAlgorithm,ConductionTransferFunction,200.0000;
+  ZoneAirHeatBalanceAlgorithm,
+    AnalyticalSolution;      !- Algorithm
+  Sizing:Parameters,
+    1.33,                    !- Heating Sizing Factor
+    1.33,                    !- Cooling Sizing Factor
+    6;                       !- Timesteps in Averaging Window
+  ConvergenceLimits,
+    2,                       !- Minimum System Timestep {minutes}
+    25;                      !- Maximum HVAC Iterations
+  ShadowCalculation,
+    AverageOverDaysInFrequency,  !- Calculation Method
+    7,                       !- Calculation Frequency
+    15000;                   !- Maximum Figures in Shadow Overlap Calculations
+  Timestep,6;
+! WeatherFileName=USA_IL_Chicago-OHare_TMY2.epw
+  Site:Location,
+    USA IL-CHICAGO-OHARE,    !- Name
+    41.77,                   !- Latitude {deg}
+    -87.75,                  !- Longitude {deg}
+    -6.00,                   !- Time Zone {hr}
+    190;                     !- Elevation {m}
+! CHICAGO_IL_USA Annual Heating 99.6%, MaxDB=-20.6�C
+  SizingPeriod:DesignDay,
+    CHICAGO Ann Htg 99.6% Condns DB,  !- Name
+    1,                       !- Month
+    21,                      !- Day of Month
+    WinterDesignDay,         !- Day Type
+    -20.6,                   !- Maximum Dry-Bulb Temperature {C}
+    0.0,                     !- Daily Dry-Bulb Temperature Range {deltaC}
+    ,                        !- Dry-Bulb Temperature Range Modifier Type
+    ,                        !- Dry-Bulb Temperature Range Modifier Day Schedule Name
+    Wetbulb,                 !- Humidity Condition Type
+    -20.6,                   !- Wetbulb or DewPoint at Maximum Dry-Bulb {C}
+    ,                        !- Humidity Condition Day Schedule Name
+    ,                        !- Humidity Ratio at Maximum Dry-Bulb {kgWater/kgDryAir}
+    ,                        !- Enthalpy at Maximum Dry-Bulb {J/kg}
+    ,                        !- Daily Wet-Bulb Temperature Range {deltaC}
+    99063.,                  !- Barometric Pressure {Pa}
+    4.9,                     !- Wind Speed {m/s}
+    270,                     !- Wind Direction {deg}
+    No,                      !- Rain Indicator
+    No,                      !- Snow Indicator
+    No,                      !- Daylight Saving Time Indicator
+    ASHRAEClearSky,          !- Solar Model Indicator
+    ,                        !- Beam Solar Day Schedule Name
+    ,                        !- Diffuse Solar Day Schedule Name
+    ,                        !- ASHRAE Clear Sky Optical Depth for Beam Irradiance (taub) {dimensionless}
+    ,                        !- ASHRAE Clear Sky Optical Depth for Diffuse Irradiance (taud) {dimensionless}
+    0.00;                    !- Sky Clearness
+! CHICAGO_IL_USA Annual Cooling (WB=>MDB) .4%, MDB=31.2�C WB=25.5�C
+    CHICAGO Ann Clg .4% Condns WB=>MDB,  !- Name
+    7,                       !- Month
+    SummerDesignDay,         !- Day Type
+    31.2,                    !- Maximum Dry-Bulb Temperature {C}
+    10.7,                    !- Daily Dry-Bulb Temperature Range {deltaC}
+    25.5,                    !- Wetbulb or DewPoint at Maximum Dry-Bulb {C}
+    5.3,                     !- Wind Speed {m/s}
+    230,                     !- Wind Direction {deg}
+    1.00;                    !- Sky Clearness
+  Site:WaterMainsTemperature,
+    CORRELATION,             !- Calculation Method
+    ,                        !- Temperature Schedule Name
+    9.69,                    !- Annual Average Outdoor Air Temperature {C}
+    28.10;                   !- Maximum Difference In Monthly Average Outdoor Air Temperatures {deltaC}
+  Site:GroundTemperature:BuildingSurface,19.527,19.502,19.536,19.598,20.002,21.640,22.225,22.375,21.449,20.121,19.802,19.633;
+! ***OPAQUE CONSTRUCTIONS AND MATERIALS***
+! Exterior Walls
+  Construction,
+    Mass Non-res Ext Wall,   !- Name
+    1IN Stucco,              !- Outside Layer
+    8IN Concrete HW,         !- Layer 2
+    Mass NonRes Wall Insulation,  !- Layer 3
+    1/2IN Gypsum;            !- Layer 4
+  Material,
+    Mass NonRes Wall Insulation,  !- Name
+    MediumRough,             !- Roughness
+    0.0495494599433393,      !- Thickness {m}
+    0.049,                   !- Conductivity {W/m-K}
+    265.0000,                !- Density {kg/m3}
+    836.8000,                !- Specific Heat {J/kg-K}
+    0.9000,                  !- Thermal Absorptance
+    0.7000,                  !- Solar Absorptance
+    0.7000;                  !- Visible Absorptance
+! Roof
+  Construction,
+    IEAD Non-res Roof,       !- Name
+    Roof Membrane,           !- Outside Layer
+    IEAD NonRes Roof Insulation,  !- Layer 2
+    Metal Decking;           !- Layer 3
+  Material,
+    IEAD NonRes Roof Insulation,  !- Name
+    0.127338688569477,       !- Thickness {m}
+! Slab on grade, unheated
+  Construction,
+    ext-slab,                !- Name
+    HW CONCRETE,             !- Outside Layer
+    CP02 CARPET PAD;         !- Layer 2
+! Interior Walls
+  Construction,
+    int-walls,               !- Name
+    1/2IN Gypsum,            !- Outside Layer
+    1/2IN Gypsum;            !- Layer 2
+! Interior Floors
+  Construction,
+    INT-FLOOR-TOPSIDE,       !- Name
+    MAT-CC05 4 HW CONCRETE,  !- Outside Layer
+  Construction,
+    INT-FLOOR-UNDERSIDE,     !- Name
+    CP02 CARPET PAD,         !- Outside Layer
+    MAT-CC05 4 HW CONCRETE;  !- Layer 2
+  Construction,
+    Underground Wall Non-res,!- Name
+    8IN Concrete HW,         !- Outside Layer
+    UGWall NonRes Insulation;!- Layer 2
+  Material,
+    UGWall NonRes Insulation,!- Name
+    0.0001,                  !- Thickness {m}
+! ***WINDOW/DOOR CONSTRUCTIONS AND MATERIALS***
+  Construction,
+    Window Non-res Fixed,    !- Name
+    NonRes Fixed Assembly Window;  !- Outside Layer
+  WindowMaterial:SimpleGlazingSystem,
+    NonRes Fixed Assembly Window,  !- Name
+    3.23646,                 !- U-Factor {W/m2-K}
+    0.39,                    !- Solar Heat Gain Coefficient
+    ;                        !- Visible Transmittance
+! ***COMMON CONSTRUCTIONS AND MATERIALS***
+  Construction,
+    DropCeiling,             !- Name
+    Std AC02;                !- Outside Layer
+  Construction,
+    AIR-WALL,                !- Name
+    MAT-AIR-WALL;            !- Outside Layer
+  Construction,
+    InteriorFurnishings,     !- Name
+    Std Wood 6inch;          !- Outside Layer
+  Material,
+    Std Wood 6inch,          !- Name
+    MediumSmooth,            !- Roughness
+    0.15,                    !- Thickness {m}
+    0.12,                    !- Conductivity {W/m-K}
+    540.0000,                !- Density {kg/m3}
+    1210,                    !- Specific Heat {J/kg-K}
+    0.9000000,               !- Thermal Absorptance
+    0.7000000,               !- Solar Absorptance
+    0.7000000;               !- Visible Absorptance
+  Material,
+    Wood Siding,             !- Name
+    0.0100,                  !- Thickness {m}
+    0.1100,                  !- Conductivity {W/m-K}
+    544.6200,                !- Density {kg/m3}
+    1210.0000,               !- Specific Heat {J/kg-K}
+    0.7800,                  !- Solar Absorptance
+    0.7800;                  !- Visible Absorptance
+  Material,
+    1/2IN Gypsum,            !- Name
+    Smooth,                  !- Roughness
+    0.0127,                  !- Thickness {m}
+    0.1600,                  !- Conductivity {W/m-K}
+    784.9000,                !- Density {kg/m3}
+    830.0000,                !- Specific Heat {J/kg-K}
+    0.9200,                  !- Solar Absorptance
+    0.9200;                  !- Visible Absorptance
+  Material,
+    1IN Stucco,              !- Name
+    0.0253,                  !- Thickness {m}
+    0.6918,                  !- Conductivity {W/m-K}
+    1858.0000,               !- Density {kg/m3}
+    837.0000,                !- Specific Heat {J/kg-K}
+  Material,
+    8IN CONCRETE HW,         !- Name
+    Rough,                   !- Roughness
+    0.2032,                  !- Thickness {m}
+    1.3110,                  !- Conductivity {W/m-K}
+    2240.0000,               !- Density {kg/m3}
+  Material,
+    Metal Siding,            !- Name
+    0.0015,                  !- Thickness {m}
+    44.9600,                 !- Conductivity {W/m-K}
+    7688.8600,               !- Density {kg/m3}
+    410.0000,                !- Specific Heat {J/kg-K}
+    0.2000,                  !- Solar Absorptance
+    0.2000;                  !- Visible Absorptance
+  Material,
+    HW CONCRETE,             !- Name
+    0.1016,                  !- Thickness {m}
+  Material:NoMass,
+    CP02 CARPET PAD,         !- Name
+    VeryRough,               !- Roughness
+    0.2165,                  !- Thermal Resistance {m2-K/W}
+    0.8000;                  !- Visible Absorptance
+  Material,
+    Roof Membrane,           !- Name
+    0.0095,                  !- Thickness {m}
+    1121.2900,               !- Density {kg/m3}
+    1460.0000,               !- Specific Heat {J/kg-K}
+  Material,
+    Metal Decking,           !- Name
+    45.0060,                 !- Conductivity {W/m-K}
+    7680.0000,               !- Density {kg/m3}
+    418.4000,                !- Specific Heat {J/kg-K}
+    0.3000;                  !- Visible Absorptance
+  Material,
+    Metal Roofing,           !- Name
+  Material,
+    MAT-CC05 4 HW CONCRETE,  !- Name
+! Acoustic tile for drop ceiling
+  Material,
+    Std AC02,                !- Name
+    1.2700000E-02,           !- Thickness {m}
+    5.7000000E-02,           !- Conductivity {W/m-K}
+    288.0000,                !- Density {kg/m3}
+    1339.000,                !- Specific Heat {J/kg-K}
+    0.2000000;               !- Visible Absorptance
+  Material:NoMass,
+    MAT-AIR-WALL,            !- Name
+    0.2079491,               !- Thermal Resistance {m2-K/W}
+    0.9,                     !- Thermal Absorptance
+    0.7;                     !- Solar Absorptance
+! ZONE LIST:
+! Basement
+! Core_bottom
+! Core_mid (mult=10)
+! Core_top
+! GroundFloor_Plenum
+! MidFloor_Plenum (mult=10)
+! Perimeter_bot_ZN_1
+! Perimeter_bot_ZN_2
+! Perimeter_bot_ZN_3
+! Perimeter_bot_ZN_4
+! Perimeter_mid_ZN_1 (mult=10)
+! Perimeter_mid_ZN_2 (mult=10)
+! Perimeter_mid_ZN_3 (mult=10)
+! Perimeter_mid_ZN_4 (mult=10)
+! Perimeter_top_ZN_1
+! Perimeter_top_ZN_2
+! Perimeter_top_ZN_3
+! Perimeter_top_ZN_4
+! TopFloor_Plenum
+! ***ZONES***
+  Zone,
+    Basement,                !- Name
+    0.0000,                  !- Direction of Relative North {deg}
+    0.0000,                  !- X Origin {m}
+    0.0400,                  !- Y Origin {m}
+    0.2000,                  !- Z Origin {m}
+    1,                       !- Type
+    1,                       !- Multiplier
+    ,                        !- Ceiling Height {m}
+    ,                        !- Volume {m3}
+    autocalculate,           !- Floor Area {m2}
+    ,                        !- Zone Inside Convection Algorithm
+    ,                        !- Zone Outside Convection Algorithm
+    Yes;                     !- Part of Total Floor Area
+  Zone,
+    Core_bottom,             !- Name
+    0.0000,                  !- Y Origin {m}
+    0.0000,                  !- Z Origin {m}
+    1,                       !- Type
+    1,                       !- Multiplier
+    ,                        !- Volume {m3}
+  Zone,
+    Core_mid,                !- Name
+    1,                       !- Type
+    HEIGHT[],                 !- Multiplier
+    ,                        !- Volume {m3}
+  Zone,
+    Core_top,                !- Name
+    1,                       !- Type
+    1,                       !- Multiplier
+    ,                        !- Volume {m3}
+  Zone,
+    GroundFloor_Plenum,      !- Name
+    1,                       !- Type
+    1,                       !- Multiplier
+    ,                        !- Volume {m3}
+    No;                      !- Part of Total Floor Area
+  Zone,
+    MidFloor_Plenum,         !- Name
+    1,                       !- Type
+    ,                        !- Volume {m3}
+  Zone,
+    Perimeter_bot_ZN_1,      !- Name
+    1,                       !- Type
+    1,                       !- Multiplier
+    ,                        !- Volume {m3}
+  Zone,
+    Perimeter_bot_ZN_2,      !- Name
+    1,                       !- Type
+    1,                       !- Multiplier
+    ,                        !- Volume {m3}
+  Zone,
+    Perimeter_bot_ZN_3,      !- Name
+    1,                       !- Type
+    1,                       !- Multiplier
+    ,                        !- Volume {m3}
+  Zone,
+    Perimeter_bot_ZN_4,      !- Name
+    1,                       !- Type
+    1,                       !- Multiplier
+    ,                        !- Volume {m3}
+  Zone,
+    Perimeter_mid_ZN_1,      !- Name
+    1,                       !- Type
+    HEIGHT[],                 !- Multiplier HEIGHT[]
+    ,                        !- Volume {m3}
+  Zone,
+    Perimeter_mid_ZN_2,      !- Name
+    1,                       !- Type
+    ,                        !- Volume {m3}
+  Zone,
+    Perimeter_mid_ZN_3,      !- Name
+    1,                       !- Type
+    ,                        !- Volume {m3}
+  Zone,
+    Perimeter_mid_ZN_4,      !- Name
+    1,                       !- Type
+    ,                        !- Volume {m3}
+  Zone,
+    Perimeter_top_ZN_1,      !- Name
+    1,                       !- Type
+    1,                       !- Multiplier
+    ,                        !- Volume {m3}
+  Zone,
+    Perimeter_top_ZN_2,      !- Name
+    1,                       !- Type
+    1,                       !- Multiplier
+    ,                        !- Volume {m3}
+  Zone,
+    Perimeter_top_ZN_3,      !- Name
+    1,                       !- Type
+    1,                       !- Multiplier
+    ,                        !- Volume {m3}
+  Zone,
+    Perimeter_top_ZN_4,      !- Name
+    1,                       !- Type
+    1,                       !- Multiplier
+    ,                        !- Volume {m3}
+  Zone,
+    TopFloor_Plenum,         !- Name
+    1,                       !- Type
+    1,                       !- Multiplier
+    ,                        !- Volume {m3}
+! ***WALLS***
+  BuildingSurface:Detailed,
+    Basement_Ceiling_1,      !- Name
+    Ceiling,                 !- Surface Type
+    INT-FLOOR-UNDERSIDE,     !- Construction Name
+    Basement,                !- Zone Name
+    Surface,                 !- Outside Boundary Condition
+    Perimeter_bot_ZN_1_Floor,!- Outside Boundary Condition Object
+    NoSun,                   !- Sun Exposure
+    NoWind,                  !- Wind Exposure
+    AutoCalculate,           !- View Factor to Ground
+    4,                       !- Number of Vertices
+    4.5732,4.5732,0.0000,  !- X,Y,Z ==> Vertex 1 {m}
+    0.0000,0.0000,0.0000,  !- X,Y,Z ==> Vertex 2 {m}
+    73.1072,0.0000,0.0000,  !- X,Y,Z ==> Vertex 3 {m}
+    68.5340,4.5732,0.0000;  !- X,Y,Z ==> Vertex 4 {m}
+    Basement_Ceiling_2,      !- Name
+    Perimeter_bot_ZN_2_Floor,!- Outside Boundary Condition Object
+    68.5340,4.5732,0.0000,  !- X,Y,Z ==> Vertex 1 {m}
+    73.1072,0.0000,0.0000,  !- X,Y,Z ==> Vertex 2 {m}
+    73.1072,48.7381,0.0000,  !- X,Y,Z ==> Vertex 3 {m}
+    68.5340,44.1650,0.0000;  !- X,Y,Z ==> Vertex 4 {m}
+    Basement_Ceiling_3,      !- Name
+    Perimeter_bot_ZN_3_Floor,!- Outside Boundary Condition Object
+    68.5340,44.1650,0.0000,  !- X,Y,Z ==> Vertex 1 {m}
+    73.1072,48.7381,0.0000,  !- X,Y,Z ==> Vertex 2 {m}
+    0.0000,48.7381,0.0000,  !- X,Y,Z ==> Vertex 3 {m}
+    4.5732,44.1650,0.0000;  !- X,Y,Z ==> Vertex 4 {m}
+    Basement_Ceiling_4,      !- Name
+    Perimeter_bot_ZN_4_Floor,!- Outside Boundary Condition Object
+    4.5732,44.1650,0.0000,  !- X,Y,Z ==> Vertex 1 {m}
+    0.0000,48.7381,0.0000,  !- X,Y,Z ==> Vertex 2 {m}
+    0.0000,0.0000,0.0000,  !- X,Y,Z ==> Vertex 3 {m}
+    4.5732,4.5732,0.0000;  !- X,Y,Z ==> Vertex 4 {m}
+    Basement_Ceiling_5,      !- Name
+    Core_bot_ZN_5_Floor,     !- Outside Boundary Condition Object
+    4.5732,4.5732,0.0000,  !- X,Y,Z ==> Vertex 2 {m}
+    68.5340,4.5732,0.0000,  !- X,Y,Z ==> Vertex 3 {m}
+    Basement_Floor,          !- Name
+    Floor,                   !- Surface Type
+    ext-slab,                !- Construction Name
+    Ground,                  !- Outside Boundary Condition
+    ,                        !- Outside Boundary Condition Object
+    73.1072,48.7381,-2.4390,  !- X,Y,Z ==> Vertex 1 {m}
+    73.1072,0.0000,-2.4390,  !- X,Y,Z ==> Vertex 2 {m}
+    0.0000,0.0000,-2.4390,  !- X,Y,Z ==> Vertex 3 {m}
+    0.0000,48.7381,-2.4390;  !- X,Y,Z ==> Vertex 4 {m}
+    Basement_Wall_East,      !- Name
+    Wall,                    !- Surface Type
+    Underground Wall Non-res,!- Construction Name
+    73.1072,0.0000,0.0000,  !- X,Y,Z ==> Vertex 1 {m}
+    73.1072,48.7381,-2.4390,  !- X,Y,Z ==> Vertex 3 {m}
+    73.1072,48.7381,0.0000;  !- X,Y,Z ==> Vertex 4 {m}
+    Basement_Wall_North,     !- Name
+    73.1072,48.7381,0.0000,  !- X,Y,Z ==> Vertex 1 {m}
+    73.1072,48.7381,-2.4390,  !- X,Y,Z ==> Vertex 2 {m}
+    0.0000,48.7381,-2.4390,  !- X,Y,Z ==> Vertex 3 {m}
+    0.0000,48.7381,0.0000;  !- X,Y,Z ==> Vertex 4 {m}
+    Basement_Wall_South,     !- Name
+    0.0000,0.0000,0.0000,  !- X,Y,Z ==> Vertex 1 {m}
+    0.0000,0.0000,-2.4390,  !- X,Y,Z ==> Vertex 2 {m}
+    73.1072,0.0000,-2.4390,  !- X,Y,Z ==> Vertex 3 {m}
+    73.1072,0.0000,0.0000;  !- X,Y,Z ==> Vertex 4 {m}
+    Basement_Wall_West,      !- Name
+    0.0000,48.7381,0.0000,  !- X,Y,Z ==> Vertex 1 {m}
+    0.0000,48.7381,-2.4390,  !- X,Y,Z ==> Vertex 2 {m}
+    0.0000,0.0000,0.0000;  !- X,Y,Z ==> Vertex 4 {m}
+    Building_Roof,           !- Name
+    Roof,                    !- Surface Type
+    IEAD Non-res Roof,       !- Construction Name
+    TopFloor_Plenum,         !- Zone Name
+    Outdoors,                !- Outside Boundary Condition
+    SunExposed,              !- Sun Exposure
+    WindExposed,             !- Wind Exposure
+    73.1072,0.0000,47.5584,  !- X,Y,Z ==> Vertex 1 {m}
+    73.1072,48.7381,47.5584,  !- X,Y,Z ==> Vertex 2 {m}
+    0.0000,48.7381,47.5584,  !- X,Y,Z ==> Vertex 3 {m}
+    0.0000,0.0000,47.5584;  !- X,Y,Z ==> Vertex 4 {m}
+    Core_bot_ZN_5_Ceiling,   !- Name
+    DropCeiling,             !- Construction Name
+    Core_bottom,             !- Zone Name
+    GroundFloor_Plenum_Floor_5,  !- Outside Boundary Condition Object
+    4.5732,44.1650,2.7440,  !- X,Y,Z ==> Vertex 1 {m}
+    4.5732,4.5732,2.7440,  !- X,Y,Z ==> Vertex 2 {m}
+    68.5340,4.5732,2.7440,  !- X,Y,Z ==> Vertex 3 {m}
+    68.5340,44.1650,2.7440;  !- X,Y,Z ==> Vertex 4 {m}
+    Core_bot_ZN_5_Floor,     !- Name
+    INT-FLOOR-TOPSIDE,       !- Construction Name
+    Basement_Ceiling_5,      !- Outside Boundary Condition Object
+    68.5340,4.5732,0.0000,  !- X,Y,Z ==> Vertex 2 {m}
+    4.5732,4.5732,0.0000,  !- X,Y,Z ==> Vertex 3 {m}
+    Core_bot_ZN_5_Wall_East, !- Name
+    int-walls,               !- Construction Name
+    Perimeter_bot_ZN_2_Wall_West,  !- Outside Boundary Condition Object
+    68.5340,4.5732,2.7440,  !- X,Y,Z ==> Vertex 1 {m}
+    68.5340,44.1650,0.0000,  !- X,Y,Z ==> Vertex 3 {m}
+    Core_bot_ZN_5_Wall_North,!- Name
+    Perimeter_bot_ZN_3_Wall_South,  !- Outside Boundary Condition Object
+    68.5340,44.1650,2.7440,  !- X,Y,Z ==> Vertex 1 {m}
+    68.5340,44.1650,0.0000,  !- X,Y,Z ==> Vertex 2 {m}
+    4.5732,44.1650,0.0000,  !- X,Y,Z ==> Vertex 3 {m}
+    4.5732,44.1650,2.7440;  !- X,Y,Z ==> Vertex 4 {m}
+    Core_bot_ZN_5_Wall_South,!- Name
+    Perimeter_bot_ZN_1_Wall_North,  !- Outside Boundary Condition Object
+    4.5732,4.5732,2.7440,  !- X,Y,Z ==> Vertex 1 {m}
+    68.5340,4.5732,2.7440;  !- X,Y,Z ==> Vertex 4 {m}
+    Core_bot_ZN_5_Wall_West, !- Name
+    Perimeter_bot_ZN_4_Wall_East,  !- Outside Boundary Condition Object
+    4.5732,44.1650,0.0000,  !- X,Y,Z ==> Vertex 2 {m}
+    4.5732,4.5732,2.7440;  !- X,Y,Z ==> Vertex 4 {m}
+    Core_mid_ZN_5_Ceiling,   !- Name
+    Core_mid,                !- Zone Name
+    MidFloor_Plenum_Floor_5, !- Outside Boundary Condition Object
+    4.5732,44.1650,22.5600,  !- X,Y,Z ==> Vertex 1 {m}
+    4.5732,4.5732,22.5600,  !- X,Y,Z ==> Vertex 2 {m}
+    68.5340,4.5732,22.5600,  !- X,Y,Z ==> Vertex 3 {m}
+    68.5340,44.1650,22.5600;  !- X,Y,Z ==> Vertex 4 {m}
+    Core_mid_ZN_5_Floor,     !- Name
+    Core_mid_ZN_5_Floor,     !- Outside Boundary Condition Object
+    68.5340,44.1650,19.8160,  !- X,Y,Z ==> Vertex 1 {m}
+    68.5340,4.5732,19.8160,  !- X,Y,Z ==> Vertex 2 {m}
+    4.5732,4.5732,19.8160,  !- X,Y,Z ==> Vertex 3 {m}
+    4.5732,44.1650,19.8160;  !- X,Y,Z ==> Vertex 4 {m}
+    Core_mid_ZN_5_Wall_East, !- Name
+    Perimeter_mid_ZN_2_Wall_West,  !- Outside Boundary Condition Object
+    68.5340,4.5732,22.5600,  !- X,Y,Z ==> Vertex 1 {m}
+    68.5340,44.1650,19.8160,  !- X,Y,Z ==> Vertex 3 {m}
+    Core_mid_ZN_5_Wall_North,!- Name
+    Perimeter_mid_ZN_3_Wall_South,  !- Outside Boundary Condition Object
+    68.5340,44.1650,22.5600,  !- X,Y,Z ==> Vertex 1 {m}
+    68.5340,44.1650,19.8160,  !- X,Y,Z ==> Vertex 2 {m}
+    4.5732,44.1650,19.8160,  !- X,Y,Z ==> Vertex 3 {m}
+    4.5732,44.1650,22.5600;  !- X,Y,Z ==> Vertex 4 {m}
+    Core_mid_ZN_5_Wall_South,!- Name
+    Perimeter_mid_ZN_1_Wall_North,  !- Outside Boundary Condition Object
+    4.5732,4.5732,22.5600,  !- X,Y,Z ==> Vertex 1 {m}
+    4.5732,4.5732,19.8160,  !- X,Y,Z ==> Vertex 2 {m}
+    68.5340,4.5732,19.8160,  !- X,Y,Z ==> Vertex 3 {m}
+    68.5340,4.5732,22.5600;  !- X,Y,Z ==> Vertex 4 {m}
+    Core_mid_ZN_5_Wall_West, !- Name
+    Perimeter_mid_ZN_4_Wall_East,  !- Outside Boundary Condition Object
+    4.5732,44.1650,19.8160,  !- X,Y,Z ==> Vertex 2 {m}
+    4.5732,4.5732,22.5600;  !- X,Y,Z ==> Vertex 4 {m}
+    Core_top_ZN_5_Ceiling,   !- Name
+    Core_top,                !- Zone Name
+    TopFloor_Plenum_Floor_5, !- Outside Boundary Condition Object
+    4.5732,44.1650,46.3392,  !- X,Y,Z ==> Vertex 1 {m}
+    4.5732,4.5732,46.3392,  !- X,Y,Z ==> Vertex 2 {m}
+    68.5340,4.5732,46.3392,  !- X,Y,Z ==> Vertex 3 {m}
+    68.5340,44.1650,46.3392;  !- X,Y,Z ==> Vertex 4 {m}
+    Core_top_ZN_5_Floor,     !- Name
+    Core_top_ZN_5_Floor,     !- Outside Boundary Condition Object
+    68.5340,44.1650,43.5952,  !- X,Y,Z ==> Vertex 1 {m}
+    68.5340,4.5732,43.5952,  !- X,Y,Z ==> Vertex 2 {m}
+    4.5732,4.5732,43.5952,  !- X,Y,Z ==> Vertex 3 {m}
+    4.5732,44.1650,43.5952;  !- X,Y,Z ==> Vertex 4 {m}
+    Core_top_ZN_5_Wall_East, !- Name
+    Perimeter_top_ZN_2_Wall_West,  !- Outside Boundary Condition Object
+    68.5340,4.5732,46.3392,  !- X,Y,Z ==> Vertex 1 {m}
+    68.5340,44.1650,43.5952,  !- X,Y,Z ==> Vertex 3 {m}
+    Core_top_ZN_5_Wall_North,!- Name
+    Perimeter_top_ZN_3_Wall_South,  !- Outside Boundary Condition Object
+    68.5340,44.1650,46.3392,  !- X,Y,Z ==> Vertex 1 {m}
+    68.5340,44.1650,43.5952,  !- X,Y,Z ==> Vertex 2 {m}
+    4.5732,44.1650,43.5952,  !- X,Y,Z ==> Vertex 3 {m}
+    4.5732,44.1650,46.3392;  !- X,Y,Z ==> Vertex 4 {m}
+    Core_top_ZN_5_Wall_South,!- Name
+    Perimeter_top_ZN_1_Wall_North,  !- Outside Boundary Condition Object
+    4.5732,4.5732,46.3392,  !- X,Y,Z ==> Vertex 1 {m}
+    4.5732,4.5732,43.5952,  !- X,Y,Z ==> Vertex 2 {m}
+    68.5340,4.5732,43.5952,  !- X,Y,Z ==> Vertex 3 {m}
+    68.5340,4.5732,46.3392;  !- X,Y,Z ==> Vertex 4 {m}
+    Core_top_ZN_5_Wall_West, !- Name
+    Perimeter_top_ZN_4_Wall_East,  !- Outside Boundary Condition Object
+    4.5732,44.1650,43.5952,  !- X,Y,Z ==> Vertex 2 {m}
+    4.5732,4.5732,46.3392;  !- X,Y,Z ==> Vertex 4 {m}
+    GroundFloor_Plenum_Ceiling,  !- Name
+    GroundFloor_Plenum,      !- Zone Name
+    GroundFloor_Plenum_Ceiling,  !- Outside Boundary Condition Object
+    73.1072,0.0000,3.9632,  !- X,Y,Z ==> Vertex 1 {m}
+    73.1072,48.7381,3.9632,  !- X,Y,Z ==> Vertex 2 {m}
+    0.0000,48.7381,3.9632,  !- X,Y,Z ==> Vertex 3 {m}
+    0.0000,0.0000,3.9632;  !- X,Y,Z ==> Vertex 4 {m}
+    GroundFloor_Plenum_Floor_1,  !- Name
+    Perimeter_bot_ZN_1_Ceiling,  !- Outside Boundary Condition Object
+    68.5340,4.5732,2.7440,  !- X,Y,Z ==> Vertex 2 {m}
+    73.1072,0.0000,2.7440,  !- X,Y,Z ==> Vertex 3 {m}
+    0.0000,0.0000,2.7440;  !- X,Y,Z ==> Vertex 4 {m}
+    GroundFloor_Plenum_Floor_2,  !- Name
+    Perimeter_bot_ZN_2_Ceiling,  !- Outside Boundary Condition Object
+    73.1072,48.7381,2.7440,  !- X,Y,Z ==> Vertex 1 {m}
+    73.1072,0.0000,2.7440,  !- X,Y,Z ==> Vertex 2 {m}
+    GroundFloor_Plenum_Floor_3,  !- Name
+    Perimeter_bot_ZN_3_Ceiling,  !- Outside Boundary Condition Object
+    4.5732,44.1650,2.7440,  !- X,Y,Z ==> Vertex 2 {m}
+    0.0000,48.7381,2.7440,  !- X,Y,Z ==> Vertex 3 {m}
+    73.1072,48.7381,2.7440;  !- X,Y,Z ==> Vertex 4 {m}
+    GroundFloor_Plenum_Floor_4,  !- Name
+    Perimeter_bot_ZN_4_Ceiling,  !- Outside Boundary Condition Object
+    0.0000,0.0000,2.7440,  !- X,Y,Z ==> Vertex 3 {m}
+    0.0000,48.7381,2.7440;  !- X,Y,Z ==> Vertex 4 {m}
+    GroundFloor_Plenum_Floor_5,  !- Name
+    Core_bot_ZN_5_Ceiling,   !- Outside Boundary Condition Object
+    4.5732,44.1650,2.7440,  !- X,Y,Z ==> Vertex 3 {m}
+    GroundFloor_Plenum_Wall_East,  !- Name
+    Mass Non-res Ext Wall,   !- Construction Name
+    73.1072,48.7381,2.7440,  !- X,Y,Z ==> Vertex 3 {m}
+    73.1072,48.7381,3.9632;  !- X,Y,Z ==> Vertex 4 {m}
+    GroundFloor_Plenum_Wall_North,  !- Name
+    73.1072,48.7381,3.9632,  !- X,Y,Z ==> Vertex 1 {m}
+    73.1072,48.7381,2.7440,  !- X,Y,Z ==> Vertex 2 {m}
+    0.0000,48.7381,3.9632;  !- X,Y,Z ==> Vertex 4 {m}
+    GroundFloor_Plenum_Wall_South,  !- Name
+    0.0000,0.0000,3.9632,  !- X,Y,Z ==> Vertex 1 {m}
+    0.0000,0.0000,2.7440,  !- X,Y,Z ==> Vertex 2 {m}
+    73.1072,0.0000,3.9632;  !- X,Y,Z ==> Vertex 4 {m}
+    GroundFloor_Plenum_West, !- Name
+    0.0000,48.7381,3.9632,  !- X,Y,Z ==> Vertex 1 {m}
+    0.0000,48.7381,2.7440,  !- X,Y,Z ==> Vertex 2 {m}
+    MidFloor_Plenum_Ceiling, !- Name
+    MidFloor_Plenum,         !- Zone Name
+    MidFloor_Plenum_Ceiling, !- Outside Boundary Condition Object
+    73.1072,48.7381,23.7792,  !- X,Y,Z ==> Vertex 1 {m}
+    0.0000,48.7381,23.7792,  !- X,Y,Z ==> Vertex 2 {m}
+    0.0000,0.0000,23.7792,  !- X,Y,Z ==> Vertex 3 {m}
+    73.1072,0.0000,23.7792;  !- X,Y,Z ==> Vertex 4 {m}
+    MidFloor_Plenum_Floor_1, !- Name
+    Perimeter_mid_ZN_1_Ceiling,  !- Outside Boundary Condition Object
+    73.1072,0.0000,22.5600,  !- X,Y,Z ==> Vertex 1 {m}
+    0.0000,0.0000,22.5600,  !- X,Y,Z ==> Vertex 2 {m}
+    4.5732,4.5732,22.5600,  !- X,Y,Z ==> Vertex 3 {m}
+    MidFloor_Plenum_Floor_2, !- Name
+    Perimeter_mid_ZN_2_Ceiling,  !- Outside Boundary Condition Object
+    68.5340,4.5732,22.5600,  !- X,Y,Z ==> Vertex 2 {m}
+    68.5340,44.1650,22.5600,  !- X,Y,Z ==> Vertex 3 {m}
+    73.1072,48.7381,22.5600;  !- X,Y,Z ==> Vertex 4 {m}
+    MidFloor_Plenum_Floor_3, !- Name
+    Perimeter_mid_ZN_3_Ceiling,  !- Outside Boundary Condition Object
+    0.0000,48.7381,22.5600,  !- X,Y,Z ==> Vertex 1 {m}
+    73.1072,48.7381,22.5600,  !- X,Y,Z ==> Vertex 2 {m}
+    MidFloor_Plenum_Floor_4, !- Name
+    Perimeter_mid_ZN_4_Ceiling,  !- Outside Boundary Condition Object
+    0.0000,0.0000,22.5600,  !- X,Y,Z ==> Vertex 1 {m}
+    0.0000,48.7381,22.5600,  !- X,Y,Z ==> Vertex 2 {m}
+    4.5732,44.1650,22.5600,  !- X,Y,Z ==> Vertex 3 {m}
+    MidFloor_Plenum_Floor_5, !- Name
+    Core_mid_ZN_5_Ceiling,   !- Outside Boundary Condition Object
+    MidFloor_Plenum_Wall_East,  !- Name
+    73.1072,0.0000,23.7792,  !- X,Y,Z ==> Vertex 1 {m}
+    73.1072,0.0000,22.5600,  !- X,Y,Z ==> Vertex 2 {m}
+    73.1072,48.7381,22.5600,  !- X,Y,Z ==> Vertex 3 {m}
+    73.1072,48.7381,23.7792;  !- X,Y,Z ==> Vertex 4 {m}
+    MidFloor_Plenum_Wall_North,  !- Name
+    0.0000,48.7381,22.5600,  !- X,Y,Z ==> Vertex 3 {m}
+    0.0000,48.7381,23.7792;  !- X,Y,Z ==> Vertex 4 {m}
+    MidFloor_Plenum_Wall_South,  !- Name
+    0.0000,0.0000,23.7792,  !- X,Y,Z ==> Vertex 1 {m}
+    73.1072,0.0000,22.5600,  !- X,Y,Z ==> Vertex 3 {m}
+    MidFloor_Plenum_Wall_West,  !- Name
+    0.0000,48.7381,23.7792,  !- X,Y,Z ==> Vertex 1 {m}
+    0.0000,0.0000,22.5600,  !- X,Y,Z ==> Vertex 3 {m}
+    0.0000,0.0000,23.7792;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_bot_ZN_1_Ceiling,  !- Name
+    Perimeter_bot_ZN_1,      !- Zone Name
+    GroundFloor_Plenum_Floor_1,  !- Outside Boundary Condition Object
+    Perimeter_bot_ZN_1_Floor,!- Name
+    Basement_Ceiling_1,      !- Outside Boundary Condition Object
+    Perimeter_bot_ZN_1_Wall_East,  !- Name
+    Perimeter_bot_ZN_2_Wall_South,  !- Outside Boundary Condition Object
+    73.1072,0.0000,2.7440,  !- X,Y,Z ==> Vertex 1 {m}
+    Perimeter_bot_ZN_1_Wall_North,  !- Name
+    Core_bot_ZN_5_Wall_South,!- Outside Boundary Condition Object
+    Perimeter_bot_ZN_1_Wall_South,  !- Name
+    0.0000,0.0000,2.7440,  !- X,Y,Z ==> Vertex 1 {m}
+    73.1072,0.0000,2.7440;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_bot_ZN_1_Wall_West,  !- Name
+    Perimeter_bot_ZN_4_Wall_South,  !- Outside Boundary Condition Object
+    Perimeter_bot_ZN_2_Ceiling,  !- Name
+    Perimeter_bot_ZN_2,      !- Zone Name
+    GroundFloor_Plenum_Floor_2,  !- Outside Boundary Condition Object
+    Perimeter_bot_ZN_2_Floor,!- Name
+    Basement_Ceiling_2,      !- Outside Boundary Condition Object
+    Perimeter_bot_ZN_2_Wall_East,  !- Name
+    Perimeter_bot_ZN_2_Wall_North,  !- Name
+    Perimeter_bot_ZN_3_Wall_East,  !- Outside Boundary Condition Object
+    Perimeter_bot_ZN_2_Wall_South,  !- Name
+    Perimeter_bot_ZN_1_Wall_East,  !- Outside Boundary Condition Object
+    Perimeter_bot_ZN_2_Wall_West,  !- Name
+    Core_bot_ZN_5_Wall_East, !- Outside Boundary Condition Object
+    Perimeter_bot_ZN_3_Ceiling,  !- Name
+    Perimeter_bot_ZN_3,      !- Zone Name
+    GroundFloor_Plenum_Floor_3,  !- Outside Boundary Condition Object
+    Perimeter_bot_ZN_3_Floor,!- Name
+    Basement_Ceiling_3,      !- Outside Boundary Condition Object
+    Perimeter_bot_ZN_3_Wall_East,  !- Name
+    Perimeter_bot_ZN_2_Wall_North,  !- Outside Boundary Condition Object
+    Perimeter_bot_ZN_3_Wall_North,  !- Name
+    Perimeter_bot_ZN_3_Wall_South,  !- Name
+    Core_bot_ZN_5_Wall_North,!- Outside Boundary Condition Object
+    Perimeter_bot_ZN_3_Wall_West,  !- Name
+    Perimeter_bot_ZN_4_Wall_North,  !- Outside Boundary Condition Object
+    0.0000,48.7381,2.7440,  !- X,Y,Z ==> Vertex 1 {m}
+    Perimeter_bot_ZN_4_Ceiling,  !- Name
+    Perimeter_bot_ZN_4,      !- Zone Name
+    GroundFloor_Plenum_Floor_4,  !- Outside Boundary Condition Object
+    Perimeter_bot_ZN_4_Floor,!- Name
+    Basement_Ceiling_4,      !- Outside Boundary Condition Object
+    Perimeter_bot_ZN_4_Wall_East,  !- Name
+    Core_bot_ZN_5_Wall_West, !- Outside Boundary Condition Object
+    Perimeter_bot_ZN_4_Wall_North,  !- Name
+    Perimeter_bot_ZN_3_Wall_West,  !- Outside Boundary Condition Object
+    Perimeter_bot_ZN_4_Wall_South,  !- Name
+    Perimeter_bot_ZN_1_Wall_West,  !- Outside Boundary Condition Object
+    Perimeter_bot_ZN_4_Wall_West,  !- Name
+    Perimeter_mid_ZN_1_Ceiling,  !- Name
+    Perimeter_mid_ZN_1,      !- Zone Name
+    MidFloor_Plenum_Floor_1, !- Outside Boundary Condition Object
+    Perimeter_mid_ZN_1_Floor,!- Name
+    Perimeter_mid_ZN_1_Floor,!- Outside Boundary Condition Object
+    68.5340,4.5732,19.8160,  !- X,Y,Z ==> Vertex 1 {m}
+    73.1072,0.0000,19.8160,  !- X,Y,Z ==> Vertex 2 {m}
+    0.0000,0.0000,19.8160,  !- X,Y,Z ==> Vertex 3 {m}
+    4.5732,4.5732,19.8160;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_mid_ZN_1_Wall_East,  !- Name
+    Perimeter_mid_ZN_2_Wall_South,  !- Outside Boundary Condition Object
+    Perimeter_mid_ZN_1_Wall_North,  !- Name
+    Core_mid_ZN_5_Wall_South,!- Outside Boundary Condition Object
+    Perimeter_mid_ZN_1_Wall_South,  !- Name
+    0.0000,0.0000,19.8160,  !- X,Y,Z ==> Vertex 2 {m}
+    73.1072,0.0000,19.8160,  !- X,Y,Z ==> Vertex 3 {m}
+    73.1072,0.0000,22.5600;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_mid_ZN_1_Wall_West,  !- Name
+    Perimeter_mid_ZN_4_Wall_South,  !- Outside Boundary Condition Object
+    0.0000,0.0000,22.5600;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_mid_ZN_2_Ceiling,  !- Name
+    Perimeter_mid_ZN_2,      !- Zone Name
+    MidFloor_Plenum_Floor_2, !- Outside Boundary Condition Object
+    Perimeter_mid_ZN_2_Floor,!- Name
+    Perimeter_mid_ZN_2_Floor,!- Outside Boundary Condition Object
+    73.1072,48.7381,19.8160,  !- X,Y,Z ==> Vertex 2 {m}
+    68.5340,4.5732,19.8160;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_mid_ZN_2_Wall_East,  !- Name
+    73.1072,48.7381,19.8160,  !- X,Y,Z ==> Vertex 3 {m}
+    Perimeter_mid_ZN_2_Wall_North,  !- Name
+    Perimeter_mid_ZN_3_Wall_East,  !- Outside Boundary Condition Object
+    73.1072,48.7381,22.5600,  !- X,Y,Z ==> Vertex 1 {m}
+    Perimeter_mid_ZN_2_Wall_South,  !- Name
+    Perimeter_mid_ZN_1_Wall_East,  !- Outside Boundary Condition Object
+    Perimeter_mid_ZN_2_Wall_West,  !- Name
+    Core_mid_ZN_5_Wall_East, !- Outside Boundary Condition Object
+    Perimeter_mid_ZN_3_Ceiling,  !- Name
+    Perimeter_mid_ZN_3,      !- Zone Name
+    MidFloor_Plenum_Floor_3, !- Outside Boundary Condition Object
+    Perimeter_mid_ZN_3_Floor,!- Name
+    Perimeter_mid_ZN_3_Floor,!- Outside Boundary Condition Object
+    4.5732,44.1650,19.8160,  !- X,Y,Z ==> Vertex 1 {m}
+    0.0000,48.7381,19.8160,  !- X,Y,Z ==> Vertex 2 {m}
+    68.5340,44.1650,19.8160;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_mid_ZN_3_Wall_East,  !- Name
+    Perimeter_mid_ZN_2_Wall_North,  !- Outside Boundary Condition Object
+    Perimeter_mid_ZN_3_Wall_North,  !- Name
+    0.0000,48.7381,19.8160,  !- X,Y,Z ==> Vertex 3 {m}
+    0.0000,48.7381,22.5600;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_mid_ZN_3_Wall_South,  !- Name
+    Core_mid_ZN_5_Wall_North,!- Outside Boundary Condition Object
+    Perimeter_mid_ZN_3_Wall_West,  !- Name
+    Perimeter_mid_ZN_4_Wall_North,  !- Outside Boundary Condition Object
+    Perimeter_mid_ZN_4_Ceiling,  !- Name
+    Perimeter_mid_ZN_4,      !- Zone Name
+    MidFloor_Plenum_Floor_4, !- Outside Boundary Condition Object
+    Perimeter_mid_ZN_4_Floor,!- Name
+    Perimeter_mid_ZN_4_Floor,!- Outside Boundary Condition Object
+    4.5732,4.5732,19.8160,  !- X,Y,Z ==> Vertex 1 {m}
+    Perimeter_mid_ZN_4_Wall_East,  !- Name
+    Core_mid_ZN_5_Wall_West, !- Outside Boundary Condition Object
+    Perimeter_mid_ZN_4_Wall_North,  !- Name
+    Perimeter_mid_ZN_3_Wall_West,  !- Outside Boundary Condition Object
+    Perimeter_mid_ZN_4_Wall_South,  !- Name
+    Perimeter_mid_ZN_1_Wall_West,  !- Outside Boundary Condition Object
+    Perimeter_mid_ZN_4_Wall_West,  !- Name
+    Perimeter_top_ZN_1_Ceiling,  !- Name
+    Perimeter_top_ZN_1,      !- Zone Name
+    TopFloor_Plenum_Floor_1, !- Outside Boundary Condition Object
+    0.0000,0.0000,46.3392,  !- X,Y,Z ==> Vertex 2 {m}
+    73.1072,0.0000,46.3392,  !- X,Y,Z ==> Vertex 3 {m}
+    Perimeter_top_ZN_1_Floor,!- Name
+    Perimeter_top_ZN_1_Floor,!- Outside Boundary Condition Object
+    68.5340,4.5732,43.5952,  !- X,Y,Z ==> Vertex 1 {m}
+    73.1072,0.0000,43.5952,  !- X,Y,Z ==> Vertex 2 {m}
+    0.0000,0.0000,43.5952,  !- X,Y,Z ==> Vertex 3 {m}
+    4.5732,4.5732,43.5952;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_top_ZN_1_Wall_East,  !- Name
+    Perimeter_top_ZN_2_Wall_South,  !- Outside Boundary Condition Object
+    73.1072,0.0000,46.3392,  !- X,Y,Z ==> Vertex 1 {m}
+    Perimeter_top_ZN_1_Wall_North,  !- Name
+    Core_top_ZN_5_Wall_South,!- Outside Boundary Condition Object
+    Perimeter_top_ZN_1_Wall_South,  !- Name
+    0.0000,0.0000,46.3392,  !- X,Y,Z ==> Vertex 1 {m}
+    0.0000,0.0000,43.5952,  !- X,Y,Z ==> Vertex 2 {m}
+    73.1072,0.0000,43.5952,  !- X,Y,Z ==> Vertex 3 {m}
+    73.1072,0.0000,46.3392;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_top_ZN_1_Wall_West,  !- Name
+    Perimeter_top_ZN_4_Wall_South,  !- Outside Boundary Condition Object
+    0.0000,0.0000,46.3392;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_top_ZN_2_Ceiling,  !- Name
+    Perimeter_top_ZN_2,      !- Zone Name
+    TopFloor_Plenum_Floor_2, !- Outside Boundary Condition Object
+    73.1072,0.0000,46.3392,  !- X,Y,Z ==> Vertex 2 {m}
+    73.1072,48.7381,46.3392,  !- X,Y,Z ==> Vertex 3 {m}
+    Perimeter_top_ZN_2_Floor,!- Name
+    Perimeter_top_ZN_2_Floor,!- Outside Boundary Condition Object
+    73.1072,48.7381,43.5952,  !- X,Y,Z ==> Vertex 2 {m}
+    68.5340,4.5732,43.5952;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_top_ZN_2_Wall_East,  !- Name
+    73.1072,48.7381,43.5952,  !- X,Y,Z ==> Vertex 3 {m}
+    73.1072,48.7381,46.3392;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_top_ZN_2_Wall_North,  !- Name
+    Perimeter_top_ZN_3_Wall_East,  !- Outside Boundary Condition Object
+    73.1072,48.7381,46.3392,  !- X,Y,Z ==> Vertex 1 {m}
+    Perimeter_top_ZN_2_Wall_South,  !- Name
+    Perimeter_top_ZN_1_Wall_East,  !- Outside Boundary Condition Object
+    Perimeter_top_ZN_2_Wall_West,  !- Name
+    Core_top_ZN_5_Wall_East, !- Outside Boundary Condition Object
+    Perimeter_top_ZN_3_Ceiling,  !- Name
+    Perimeter_top_ZN_3,      !- Zone Name
+    TopFloor_Plenum_Floor_3, !- Outside Boundary Condition Object
+    73.1072,48.7381,46.3392,  !- X,Y,Z ==> Vertex 2 {m}
+    0.0000,48.7381,46.3392,  !- X,Y,Z ==> Vertex 3 {m}
+    Perimeter_top_ZN_3_Floor,!- Name
+    Perimeter_top_ZN_3_Floor,!- Outside Boundary Condition Object
+    4.5732,44.1650,43.5952,  !- X,Y,Z ==> Vertex 1 {m}
+    0.0000,48.7381,43.5952,  !- X,Y,Z ==> Vertex 2 {m}
+    68.5340,44.1650,43.5952;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_top_ZN_3_Wall_East,  !- Name
+    Perimeter_top_ZN_2_Wall_North,  !- Outside Boundary Condition Object
+    Perimeter_top_ZN_3_Wall_North,  !- Name
+    0.0000,48.7381,43.5952,  !- X,Y,Z ==> Vertex 3 {m}
+    0.0000,48.7381,46.3392;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_top_ZN_3_Wall_South,  !- Name
+    Core_top_ZN_5_Wall_North,!- Outside Boundary Condition Object
+    Perimeter_top_ZN_3_Wall_West,  !- Name
+    Perimeter_top_ZN_4_Wall_North,  !- Outside Boundary Condition Object
+    0.0000,48.7381,46.3392,  !- X,Y,Z ==> Vertex 1 {m}
+    Perimeter_top_ZN_4_Ceiling,  !- Name
+    Perimeter_top_ZN_4,      !- Zone Name
+    TopFloor_Plenum_Floor_4, !- Outside Boundary Condition Object
+    0.0000,48.7381,46.3392,  !- X,Y,Z ==> Vertex 2 {m}
+    0.0000,0.0000,46.3392,  !- X,Y,Z ==> Vertex 3 {m}
+    Perimeter_top_ZN_4_Floor,!- Name
+    Perimeter_top_ZN_4_Floor,!- Outside Boundary Condition Object
+    4.5732,4.5732,43.5952,  !- X,Y,Z ==> Vertex 1 {m}
+    Perimeter_top_ZN_4_Wall_East,  !- Name
+    Core_top_ZN_5_Wall_West, !- Outside Boundary Condition Object
+    Perimeter_top_ZN_4_Wall_North,  !- Name
+    Perimeter_top_ZN_3_Wall_West,  !- Outside Boundary Condition Object
+    Perimeter_top_ZN_4_Wall_South,  !- Name
+    Perimeter_top_ZN_1_Wall_West,  !- Outside Boundary Condition Object
+    Perimeter_top_ZN_4_Wall_West,  !- Name
+    TopFloor_Plenum_Floor_1, !- Name
+    Perimeter_top_ZN_1_Ceiling,  !- Outside Boundary Condition Object
+    4.5732,4.5732,46.3392,  !- X,Y,Z ==> Vertex 3 {m}
+    TopFloor_Plenum_Floor_2, !- Name
+    Perimeter_top_ZN_2_Ceiling,  !- Outside Boundary Condition Object
+    68.5340,4.5732,46.3392,  !- X,Y,Z ==> Vertex 2 {m}
+    68.5340,44.1650,46.3392,  !- X,Y,Z ==> Vertex 3 {m}
+    TopFloor_Plenum_Floor_3, !- Name
+    Perimeter_top_ZN_3_Ceiling,  !- Outside Boundary Condition Object
+    TopFloor_Plenum_Floor_4, !- Name
+    Perimeter_top_ZN_4_Ceiling,  !- Outside Boundary Condition Object
+    4.5732,44.1650,46.3392,  !- X,Y,Z ==> Vertex 3 {m}
+    TopFloor_Plenum_Floor_5, !- Name
+    Core_top_ZN_5_Ceiling,   !- Outside Boundary Condition Object
+    68.5340,44.1650,46.3392,  !- X,Y,Z ==> Vertex 2 {m}
+    TopFloor_Plenum_Wall_East,  !- Name
+    73.1072,48.7381,47.5584;  !- X,Y,Z ==> Vertex 4 {m}
+    TopFloor_Plenum_Wall_North,  !- Name
+    0.0000,0.0000,47.5584,  !- X,Y,Z ==> Vertex 1 {m}
+    73.1072,0.0000,47.5584;  !- X,Y,Z ==> Vertex 4 {m}
+    TopFloor_Plenum_Wall_South,  !- Name
+    73.1072,48.7381,47.5584,  !- X,Y,Z ==> Vertex 1 {m}
+    0.0000,48.7381,47.5584;  !- X,Y,Z ==> Vertex 4 {m}
+    TopFloor_Plenum_Wall_West,  !- Name
+    0.0000,48.7381,47.5584,  !- X,Y,Z ==> Vertex 1 {m}
+! ***WINDOWS***
+  FenestrationSurface:Detailed,
+    Perimeter_bot_ZN_1_Wall_South_Window,  !- Name
+    Window,                  !- Surface Type
+    Window Non-res Fixed,    !- Construction Name
+    Perimeter_bot_ZN_1_Wall_South,  !- Building Surface Name
+    ,                        !- Shading Control Name
+    ,                        !- Frame and Divider Name
+    1.0000,                  !- Multiplier
+    0.0000,0.0000,2.5000,  !- X,Y,Z ==> Vertex 1 {m}
+    0.0000,0.0000,0.9146,  !- X,Y,Z ==> Vertex 2 {m}
+    73.1070,0.0000,0.9146,  !- X,Y,Z ==> Vertex 3 {m}
+    73.1070,0.0000,2.5000;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_bot_ZN_2_Wall_East_Window,  !- Name
+    Perimeter_bot_ZN_2_Wall_East,  !- Building Surface Name
+    73.1072,0.0000,2.5000,  !- X,Y,Z ==> Vertex 1 {m}
+    73.1072,0.0000,0.9146,  !- X,Y,Z ==> Vertex 2 {m}
+    73.1072,48.7380,0.9146,  !- X,Y,Z ==> Vertex 3 {m}
+    73.1072,48.7380,2.5000;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_bot_ZN_3_Wall_North_Window,  !- Name
+    Perimeter_bot_ZN_3_Wall_North,  !- Building Surface Name
+    73.1070,48.7381,2.5000,  !- X,Y,Z ==> Vertex 1 {m}
+    73.1070,48.7381,0.9146,  !- X,Y,Z ==> Vertex 2 {m}
+    0.0000,48.7381,0.9146,  !- X,Y,Z ==> Vertex 3 {m}
+    0.0000,48.7381,2.5000;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_bot_ZN_4_Wall_West_Window,  !- Name
+    Perimeter_bot_ZN_4_Wall_West,  !- Building Surface Name
+    0.0000,48.7380,2.5000,  !- X,Y,Z ==> Vertex 1 {m}
+    0.0000,48.7380,0.9146,  !- X,Y,Z ==> Vertex 2 {m}
+    0.0000,0.0000,0.9146,  !- X,Y,Z ==> Vertex 3 {m}
+    0.0000,0.0000,2.5000;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_mid_ZN_1_Wall_South_Window,  !- Name
+    Perimeter_mid_ZN_1_Wall_South,  !- Building Surface Name
+    0.0000,0.0000,22.3160,  !- X,Y,Z ==> Vertex 1 {m}
+    0.0000,0.0000,20.7306,  !- X,Y,Z ==> Vertex 2 {m}
+    73.1070,0.0000,20.7306,  !- X,Y,Z ==> Vertex 3 {m}
+    73.1070,0.0000,22.3160;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_mid_ZN_2_Wall_East_Window,  !- Name
+    Perimeter_mid_ZN_2_Wall_East,  !- Building Surface Name
+    73.1072,0.0000,22.3160,  !- X,Y,Z ==> Vertex 1 {m}
+    73.1072,0.0000,20.7306,  !- X,Y,Z ==> Vertex 2 {m}
+    73.1072,48.7380,20.7306,  !- X,Y,Z ==> Vertex 3 {m}
+    73.1072,48.7380,22.3160;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_mid_ZN_3_Wall_North_Window,  !- Name
+    Perimeter_mid_ZN_3_Wall_North,  !- Building Surface Name
+    73.1070,48.7381,22.3160,  !- X,Y,Z ==> Vertex 1 {m}
+    73.1070,48.7381,20.7306,  !- X,Y,Z ==> Vertex 2 {m}
+    0.0000,48.7381,20.7306,  !- X,Y,Z ==> Vertex 3 {m}
+    0.0000,48.7381,22.3160;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_mid_ZN_4_Wall_West_Window,  !- Name
+    Perimeter_mid_ZN_4_Wall_West,  !- Building Surface Name
+    0.0000,48.7380,22.3160,  !- X,Y,Z ==> Vertex 1 {m}
+    0.0000,48.7380,20.7306,  !- X,Y,Z ==> Vertex 2 {m}
+    0.0000,0.0000,20.7306,  !- X,Y,Z ==> Vertex 3 {m}
+    0.0000,0.0000,22.3160;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_top_ZN_1_Wall_South_Window,  !- Name
+    Perimeter_top_ZN_1_Wall_South,  !- Building Surface Name
+    0.0000,0.0000,46.0952,  !- X,Y,Z ==> Vertex 1 {m}
+    0.0000,0.0000,44.5098,  !- X,Y,Z ==> Vertex 2 {m}
+    73.1070,0.0000,44.5098,  !- X,Y,Z ==> Vertex 3 {m}
+    73.1070,0.0000,46.0952;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_top_ZN_2_Wall_East_Window,  !- Name
+    Perimeter_top_ZN_2_Wall_East,  !- Building Surface Name
+    73.1072,0.0000,46.0952,  !- X,Y,Z ==> Vertex 1 {m}
+    73.1072,0.0000,44.5098,  !- X,Y,Z ==> Vertex 2 {m}
+    73.1072,48.7380,44.5098,  !- X,Y,Z ==> Vertex 3 {m}
+    73.1072,48.7380,46.0952;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_top_ZN_3_Wall_North_Window,  !- Name
+    Perimeter_top_ZN_3_Wall_North,  !- Building Surface Name
+    73.1070,48.7381,46.0952,  !- X,Y,Z ==> Vertex 1 {m}
+    73.1070,48.7381,44.5098,  !- X,Y,Z ==> Vertex 2 {m}
+    0.0000,48.7381,44.5098,  !- X,Y,Z ==> Vertex 3 {m}
+    0.0000,48.7381,46.0952;  !- X,Y,Z ==> Vertex 4 {m}
+    Perimeter_top_ZN_4_Wall_West_Window,  !- Name
+    Perimeter_top_ZN_4_Wall_West,  !- Building Surface Name
+    0.0000,48.7380,46.0952,  !- X,Y,Z ==> Vertex 1 {m}
+    0.0000,48.7380,44.5098,  !- X,Y,Z ==> Vertex 2 {m}
+    0.0000,0.0000,44.5098,  !- X,Y,Z ==> Vertex 3 {m}
+    0.0000,0.0000,46.0952;  !- X,Y,Z ==> Vertex 4 {m}
+! ***GEOMETRY RULES***
+  GlobalGeometryRules,
+    UpperLeftCorner,         !- Starting Vertex Position
+    Counterclockwise,        !- Vertex Entry Direction
+    Relative,                !- Coordinate System
+    Relative;                !- Daylighting Reference Point Coordinate System
+! ***PEOPLE***
+  People,
+    Basement People,         !- Name
+    Basement,                !- Zone or ZoneList Name
+    BLDG_OCC_SCH,            !- Number of People Schedule Name
+    Area/Person,             !- Number of People Calculation Method
+    ,                        !- Number of People
+    ,                        !- People per Zone Floor Area {person/m2}
+    37.16,                   !- Zone Floor Area per Person {m2/person}
+    0.3000,                  !- Fraction Radiant
+    AUTOCALCULATE,           !- Sensible Heat Fraction
+    ACTIVITY_SCH,            !- Activity Level Schedule Name
+    ,                        !- Carbon Dioxide Generation Rate {m3/s-W}
+    No,                      !- Enable ASHRAE 55 Comfort Warnings
+    ZoneAveraged,            !- Mean Radiant Temperature Calculation Type
+    ,                        !- Surface Name/Angle Factor List Name
+    WORK_EFF_SCH,            !- Work Efficiency Schedule Name
+    CLOTHING_SCH,            !- Clothing Insulation Schedule Name
+    AIR_VELO_SCH,            !- Air Velocity Schedule Name
+    FANGER;                  !- Thermal Comfort Model 1 Type
+  People,
+    Core_bottom People,      !- Name
+    Core_bottom,             !- Zone or ZoneList Name
+    18.58,                   !- Zone Floor Area per Person {m2/person}
+  People,
+    Core_mid People,         !- Name
+    Core_mid,                !- Zone or ZoneList Name
+  People,
+    Core_top People,         !- Name
+    Core_top,                !- Zone or ZoneList Name
+  People,
+    Perimeter_bot_ZN_1 People,  !- Name
+    Perimeter_bot_ZN_1,      !- Zone or ZoneList Name
+  People,
+    Perimeter_bot_ZN_2 People,  !- Name
+    Perimeter_bot_ZN_2,      !- Zone or ZoneList Name
+  People,
+    Perimeter_bot_ZN_3 People,  !- Name
+    Perimeter_bot_ZN_3,      !- Zone or ZoneList Name
+  People,
+    Perimeter_bot_ZN_4 People,  !- Name
+    Perimeter_bot_ZN_4,      !- Zone or ZoneList Name
+  People,
+    Perimeter_mid_ZN_1 People,  !- Name
+    Perimeter_mid_ZN_1,      !- Zone or ZoneList Name
+  People,
+    Perimeter_mid_ZN_2 People,  !- Name
+    Perimeter_mid_ZN_2,      !- Zone or ZoneList Name
+  People,
+    Perimeter_mid_ZN_3 People,  !- Name
+    Perimeter_mid_ZN_3,      !- Zone or ZoneList Name
+  People,
+    Perimeter_mid_ZN_4 People,  !- Name
+    Perimeter_mid_ZN_4,      !- Zone or ZoneList Name
+  People,
+    Perimeter_top_ZN_1 People,  !- Name
+    Perimeter_top_ZN_1,      !- Zone or ZoneList Name
+  People,
+    Perimeter_top_ZN_2 People,  !- Name
+    Perimeter_top_ZN_2,      !- Zone or ZoneList Name
+  People,
+    Perimeter_top_ZN_3 People,  !- Name
+    Perimeter_top_ZN_3,      !- Zone or ZoneList Name
+  People,
+    Perimeter_top_ZN_4 People,  !- Name
+    Perimeter_top_ZN_4,      !- Zone or ZoneList Name
+! ***LIGHTS***
+  Lights,
+    Basement_Lights,         !- Name
+    BLDG_LIGHT_SCH,          !- Schedule Name
+    Watts/Area,              !- Design Level Calculation Method
+    ,                        !- Lighting Level {W}
+    10.76,                   !- Watts per Zone Floor Area {W/m2}
+    ,                        !- Watts per Person {W/person}
+    0.0000,                  !- Return Air Fraction
+    0.7000,                  !- Fraction Radiant
+    0.2000,                  !- Fraction Visible
+    1.0000,                  !- Fraction Replaceable
+    General,                 !- End-Use Subcategory
+    No;                      !- Return Air Fraction Calculated from Plenum Temperature
+  Lights,
+    Core_bottom_Lights,      !- Name
+  Lights,
+    Core_mid_Lights,         !- Name
+  Lights,
+    Core_top_Lights,         !- Name
+  Lights,
+    Perimeter_bot_ZN_1_Lights,  !- Name
+  Lights,
+    Perimeter_bot_ZN_2_Lights,  !- Name
+  Lights,
+    Perimeter_bot_ZN_3_Lights,  !- Name
+  Lights,
+    Perimeter_bot_ZN_4_Lights,  !- Name
+  Lights,
+    Perimeter_mid_ZN_1_Lights,  !- Name
+  Lights,
+    Perimeter_mid_ZN_2_Lights,  !- Name
+  Lights,
+    Perimeter_mid_ZN_3_Lights,  !- Name
+  Lights,
+    Perimeter_mid_ZN_4_Lights,  !- Name
+  Lights,
+    Perimeter_top_ZN_1_Lights,  !- Name
+  Lights,
+    Perimeter_top_ZN_2_Lights,  !- Name
+  Lights,
+    Perimeter_top_ZN_3_Lights,  !- Name
+  Lights,
+    Perimeter_top_ZN_4_Lights,  !- Name
+! ***EQUIPMENT GAINS***
+  ElectricEquipment,
+    Basement_PlugMisc_Equip, !- Name
+    BLDG_EQUIP_SCH,          !- Schedule Name
+    ,                        !- Design Level {W}
+    0.0000,                  !- Fraction Latent
+    0.5000,                  !- Fraction Radiant
+    0.0000,                  !- Fraction Lost
+    General;                 !- End-Use Subcategory
+    Core_bottom_PlugMisc_Equip,  !- Name
+    Core_mid_PlugMisc_Equip, !- Name
+    Core_top_PlugMisc_Equip, !- Name
+    Perimeter_bot_ZN_1_PlugMisc_Equip,  !- Name
+    Perimeter_bot_ZN_2_PlugMisc_Equip,  !- Name
+    Perimeter_bot_ZN_3_PlugMisc_Equip,  !- Name
+    Perimeter_bot_ZN_4_PlugMisc_Equip,  !- Name
+    Perimeter_mid_ZN_1_PlugMisc_Equip,  !- Name
+    Perimeter_mid_ZN_2_PlugMisc_Equip,  !- Name
+    Perimeter_mid_ZN_3_PlugMisc_Equip,  !- Name
+    Perimeter_mid_ZN_4_PlugMisc_Equip,  !- Name
+    Perimeter_top_ZN_1_PlugMisc_Equip,  !- Name
+    Perimeter_top_ZN_2_PlugMisc_Equip,  !- Name
+    Perimeter_top_ZN_3_PlugMisc_Equip,  !- Name
+    Perimeter_top_ZN_4_PlugMisc_Equip,  !- Name
+! ***EXTERIOR LOADS***
+  Exterior:Lights,
+    Exterior Facade Lighting,!- Name
+    ALWAYS_ON,               !- Schedule Name
+    51262,                   !- Design Level {W}
+    AstronomicalClock,       !- Control Option
+    Exterior Facade Lighting;!- End-Use Subcategory
+  Exterior:FuelEquipment,
+    Elevators,               !- Name
+    Electricity,             !- Fuel Use Type
+    BLDG_ELEVATORS,          !- Schedule Name
+    244443.956043956,        !- Design Level {W}
+    Elevators;               !- End-Use Subcategory
+! ***INFILTRATION***
+  ZoneInfiltration:DesignFlowRate,
+    GroundFloor_Plenum_Infiltration,  !- Name
+    GroundFloor_Plenum,      !- Zone or ZoneList Name
+    INFIL_QUARTER_ON_SCH,    !- Schedule Name
+    Flow/ExteriorArea,       !- Design Flow Rate Calculation Method
+    ,                        !- Design Flow Rate {m3/s}
+    ,                        !- Flow per Zone Floor Area {m3/s-m2}
+    0.000302,                !- Flow per Exterior Surface Area {m3/s-m2}
+    ,                        !- Air Changes per Hour {1/hr}
+    1.0000,                  !- Constant Term Coefficient
+    0.0000,                  !- Temperature Term Coefficient
+    0.0000,                  !- Velocity Term Coefficient
+    0.0000;                  !- Velocity Squared Term Coefficient
+    MidFloor_Plenum_Infiltration,  !- Name
+    MidFloor_Plenum,         !- Zone or ZoneList Name
+    Perimeter_bot_ZN_1_Infiltration,  !- Name
+    Perimeter_bot_ZN_2_Infiltration,  !- Name
+    Perimeter_bot_ZN_3_Infiltration,  !- Name
+    Perimeter_bot_ZN_4_Infiltration,  !- Name
+    Perimeter_mid_ZN_1_Infiltration,  !- Name
+    Perimeter_mid_ZN_2_Infiltration,  !- Name
+    Perimeter_mid_ZN_3_Infiltration,  !- Name
+    Perimeter_mid_ZN_4_Infiltration,  !- Name
+    Perimeter_top_ZN_1_Infiltration,  !- Name
+    Perimeter_top_ZN_2_Infiltration,  !- Name
+    Perimeter_top_ZN_3_Infiltration,  !- Name
+    Perimeter_top_ZN_4_Infiltration,  !- Name
+    TopFloor_Plenum_Infiltration,  !- Name
+    TopFloor_Plenum,         !- Zone or ZoneList Name
+! ***INTERNAL MASS***
+  InternalMass,
+    Basement Internal Mass,  !- Name
+    InteriorFurnishings,     !- Construction Name
+    7126.2120;               !- Surface Area {m2}
+  InternalMass,
+    Core_bottom Internal Mass,  !- Name
+    5064.6464;               !- Surface Area {m2}
+  InternalMass,
+    Core_mid Internal Mass,  !- Name
+  InternalMass,
+    Core_top Internal Mass,  !- Name
+  InternalMass,
+    Perimeter_bot_ZN_1 Internal Mass,  !- Name
+    626.8394;                !- Surface Area {m2}
+  InternalMass,
+    Perimeter_bot_ZN_2 Internal Mass,  !- Name
+    403.9503;                !- Surface Area {m2}
+  InternalMass,
+    Perimeter_bot_ZN_3 Internal Mass,  !- Name
+    626.8257;                !- Surface Area {m2}
+  InternalMass,
+    Perimeter_bot_ZN_4 Internal Mass,  !- Name
+  InternalMass,
+    Perimeter_mid_ZN_1 Internal Mass,  !- Name
+  InternalMass,
+    Perimeter_mid_ZN_2 Internal Mass,  !- Name
+  InternalMass,
+    Perimeter_mid_ZN_3 Internal Mass,  !- Name
+  InternalMass,
+    Perimeter_mid_ZN_4 Internal Mass,  !- Name
+  InternalMass,
+    Perimeter_top_ZN_1 Internal Mass,  !- Name
+  InternalMass,
+    Perimeter_top_ZN_2 Internal Mass,  !- Name
+  InternalMass,
+    Perimeter_top_ZN_3 Internal Mass,  !- Name
+  InternalMass,
+    Perimeter_top_ZN_4 Internal Mass,  !- Name
+! ***INTERNAL GAINS SCHEDULES***
+  Schedule:Compact,
+    BLDG_ELEVATORS,          !- Name
+    Fraction,                !- Schedule Type Limits Name
+    Until: 04:00,0.05,       !- Field 3
+    Until: 05:00,0.10,       !- Field 5
+    Until: 06:00,0.20,       !- Field 7
+    Until: 07:00,0.40,       !- Field 9
+    Until: 09:00,0.50,       !- Field 11
+    Until: 10:00,0.35,       !- Field 13
+    Until: 16:00,0.15,       !- Field 15
+    Until: 17:00,0.35,       !- Field 17
+    Until: 19:00,0.50,       !- Field 19
+    Until: 21:00,0.40,       !- Field 21
+    Until: 22:00,0.30,       !- Field 23
+    Until: 23:00,0.20,       !- Field 25
+    Until: 24:00,0.10;       !- Field 27
+  Schedule:Compact,
+    INFIL_QUARTER_ON_SCH,    !- Name
+    For: Weekdays SummerDesignDay, !- Field 2
+    Until: 06:00,1.0,        !- Field 3
+    Until: 22:00,0.25,       !- Field 5
+    Until: 24:00,1.0,        !- Field 7
+    For: Saturday WinterDesignDay, !- Field 9
+    Until: 06:00,1.0,        !- Field 10
+    Until: 18:00,0.25,       !- Field 12
+    Until: 24:00,1.0,        !- Field 14
+    For: Sunday Holidays AllOtherDays, !- Field 16
+    Until: 24:00,1.0;        !- Field 17
+  Schedule:Compact,
+    BLDG_OCC_SCH,            !- Name
+    For: SummerDesignDay,    !- Field 2
+    Until: 06:00,0.0,        !- Field 3
+    Until: 22:00,1.0,        !- Field 5
+    Until: 24:00,0.05,       !- Field 7
+    For: Weekdays,           !- Field 9
+    Until: 06:00,0.0,        !- Field 10
+    Until: 07:00,0.1,        !- Field 12
+    Until: 08:00,0.2,        !- Field 14
+    Until: 12:00,0.95,       !- Field 16
+    Until: 13:00,0.5,        !- Field 18
+    Until: 17:00,0.95,       !- Field 20
+    Until: 18:00,0.7,        !- Field 22
+    Until: 20:00,0.4,        !- Field 24
+    Until: 22:00,0.1,        !- Field 26
+    Until: 24:00,0.05,       !- Field 28
+    For: Saturday,           !- Field 30
+    Until: 06:00,0.0,        !- Field 31
+    Until: 08:00,0.1,        !- Field 33
+    Until: 14:00,0.5,        !- Field 35
+    Until: 17:00,0.1,        !- Field 37
+    Until: 24:00,0.0,        !- Field 39
+    For: AllOtherDays,       !- Field 41
+    Until: 24:00,0.0;        !- Field 42
+  Schedule:Compact,
+    BLDG_LIGHT_SCH,          !- Name
+    For: Weekdays,           !- Field 2
+    Until: 05:00,0.05,       !- Field 3
+    Until: 07:00,0.1,        !- Field 5
+    Until: 08:00,0.3,        !- Field 7
+    Until: 17:00,0.9,        !- Field 9
+    Until: 18:00,0.7,        !- Field 11
+    Until: 20:00,0.5,        !- Field 13
+    Until: 22:00,0.3,        !- Field 15
+    Until: 23:00,0.1,        !- Field 17
+    Until: 24:00,0.05,       !- Field 19
+    For: Saturday,           !- Field 21
+    Until: 06:00,0.05,       !- Field 22
+    Until: 08:00,0.1,        !- Field 24
+    Until: 14:00,0.5,        !- Field 26
+    Until: 17:00,0.15,       !- Field 28
+    Until: 24:00,0.05,       !- Field 30
+    For: SummerDesignDay,    !- Field 32
+    Until: 24:00,1.0,        !- Field 33
+    For: WinterDesignDay,    !- Field 35
+    Until: 24:00,0.0,        !- Field 36
+    For: AllOtherDays,       !- Field 38
+    Until: 24:00,0.05;       !- Field 39
+  Schedule:Compact,
+    BLDG_EQUIP_SCH,          !- Name
+    Until: 08:00,0.40,       !- Field 3
+    Until: 12:00,0.90,       !- Field 5
+    Until: 13:00,0.80,       !- Field 7
+    Until: 17:00,0.90,       !- Field 9
+    Until: 18:00,0.80,       !- Field 11
+    Until: 20:00,0.60,       !- Field 13
+    Until: 22:00,0.50,       !- Field 15
+    Until: 24:00,0.40,       !- Field 17
+    For: Saturday,           !- Field 19
+    Until: 06:00,0.30,       !- Field 20
+    Until: 08:00,0.4,        !- Field 22
+    Until: 14:00,0.5,        !- Field 24
+    Until: 17:00,0.35,       !- Field 26
+    Until: 24:00,0.30,       !- Field 28
+    For: SummerDesignDay,    !- Field 30
+    Until: 24:00,1.0,        !- Field 31
+    For: WinterDesignDay,    !- Field 33
+    Until: 24:00,0.0,        !- Field 34
+    For: AllOtherDays,       !- Field 36
+    Until: 24:00,0.30;       !- Field 37
+  Schedule:Compact,
+    ACTIVITY_SCH,            !- Name
+    Any Number,              !- Schedule Type Limits Name
+    Until: 24:00,120;        !- Field 3
+  Schedule:Compact,
+    WORK_EFF_SCH,            !- Name
+    Until: 24:00,0.0;        !- Field 3
+  Schedule:Compact,
+    AIR_VELO_SCH,            !- Name
+    Until: 24:00,0.2;        !- Field 3
+  Schedule:Compact,
+    CLOTHING_SCH,            !- Name
+    Through: 04/30,          !- Field 1
+    Through: 09/30,          !- Field 5
+    For: AllDays,            !- Field 6
+    Until: 24:00,0.5,        !- Field 7
+    Through: 12/31,          !- Field 9
+    For: AllDays,            !- Field 10
+    Until: 24:00,1.0;        !- Field 11
+! ***HVAC EQUIPMENT***
+  Fan:VariableVolume,
+    VAV_1_Fan,               !- Name
+    HVACOperationSchd,       !- Availability Schedule Name
+    0.6045,                  !- Fan Efficiency
+    1017.592,                !- Pressure Rise {Pa}
+    AUTOSIZE,                !- Maximum Flow Rate {m3/s}
+    FixedFlowRate,           !- Fan Power Minimum Flow Rate Input Method
+    ,                        !- Fan Power Minimum Flow Fraction
+    0.0000,                  !- Fan Power Minimum Air Flow Rate {m3/s}
+    0.93,                    !- Motor Efficiency
+    1.0,                     !- Motor In Airstream Fraction
+    0.0407598940,            !- Fan Power Coefficient 1
+    0.08804497,              !- Fan Power Coefficient 2
+    -0.072926120,            !- Fan Power Coefficient 3
+    0.9437398230,            !- Fan Power Coefficient 4
+    0,                       !- Fan Power Coefficient 5
+    VAV_1_HeatC-VAV_1_FanNode,  !- Air Inlet Node Name
+    VAV_1 Supply Equipment Outlet Node,  !- Air Outlet Node Name
+    Fan Energy;              !- End-Use Subcategory
+    VAV_2_Fan,               !- Name
+    0.6175,                  !- Fan Efficiency
+    0.95,                    !- Motor Efficiency
+    VAV_2_HeatC-VAV_2_FanNode,  !- Air Inlet Node Name
+    VAV_2 Supply Equipment Outlet Node,  !- Air Outlet Node Name
+    VAV_3_Fan,               !- Name
+    VAV_3_HeatC-VAV_3_FanNode,  !- Air Inlet Node Name
+    VAV_3 Supply Equipment Outlet Node,  !- Air Outlet Node Name
+    VAV_5_Fan,               !- Name
+    0.5915,                  !- Fan Efficiency
+    1109.648,                !- Pressure Rise {Pa}
+    0.91,                    !- Motor Efficiency
+    VAV_5_HeatC-VAV_5_FanNode,  !- Air Inlet Node Name
+    VAV_5 Supply Equipment Outlet Node,  !- Air Outlet Node Name
+  Coil:Heating:Water,
+    Basement VAV Box Reheat Coil,  !- Name
+    ALWAYS_ON,               !- Availability Schedule Name
+    AUTOSIZE,                !- U-Factor Times Area Value {W/K}
+    AUTOSIZE,                !- Maximum Water Flow Rate {m3/s}
+    Basement VAV Box Reheat CoilDemand Inlet Node,  !- Water Inlet Node Name
+    Basement VAV Box Reheat CoilDemand Outlet Node,  !- Water Outlet Node Name
+    Basement VAV Box Damper Node,  !- Air Inlet Node Name
+    Basement VAV Box Outlet Node Name,  !- Air Outlet Node Name
+    UFactorTimesAreaAndDesignWaterFlowRate,  !- Performance Input Method
+    AUTOSIZE,                !- Rated Capacity {W}
+    82.2,                    !- Rated Inlet Water Temperature {C}
+    16.6,                    !- Rated Inlet Air Temperature {C}
+    71.1,                    !- Rated Outlet Water Temperature {C}
+    32.2,                    !- Rated Outlet Air Temperature {C}
+    ;                        !- Rated Ratio for Air and Water Convection
+    Core_bottom VAV Box Reheat Coil,  !- Name
+    Core_bottom VAV Box Reheat CoilDemand Inlet Node,  !- Water Inlet Node Name
+    Core_bottom VAV Box Reheat CoilDemand Outlet Node,  !- Water Outlet Node Name
+    Core_bottom VAV Box Damper Node,  !- Air Inlet Node Name
+    Core_bottom VAV Box Outlet Node Name,  !- Air Outlet Node Name
+    Core_mid VAV Box Reheat Coil,  !- Name
+    Core_mid VAV Box Reheat CoilDemand Inlet Node,  !- Water Inlet Node Name
+    Core_mid VAV Box Reheat CoilDemand Outlet Node,  !- Water Outlet Node Name
+    Core_mid VAV Box Damper Node,  !- Air Inlet Node Name
+    Core_mid VAV Box Outlet Node Name,  !- Air Outlet Node Name
+    Core_top VAV Box Reheat Coil,  !- Name
+    Core_top VAV Box Reheat CoilDemand Inlet Node,  !- Water Inlet Node Name
+    Core_top VAV Box Reheat CoilDemand Outlet Node,  !- Water Outlet Node Name
+    Core_top VAV Box Damper Node,  !- Air Inlet Node Name
+    Core_top VAV Box Outlet Node Name,  !- Air Outlet Node Name
+    Perimeter_bot_ZN_1 VAV Box Reheat Coil,  !- Name
+    Perimeter_bot_ZN_1 VAV Box Reheat CoilDemand Inlet Node,  !- Water Inlet Node Name
+    Perimeter_bot_ZN_1 VAV Box Reheat CoilDemand Outlet Node,  !- Water Outlet Node Name
+    Perimeter_bot_ZN_1 VAV Box Damper Node,  !- Air Inlet Node Name
+    Perimeter_bot_ZN_1 VAV Box Outlet Node Name,  !- Air Outlet Node Name
+    Perimeter_bot_ZN_2 VAV Box Reheat Coil,  !- Name
+    Perimeter_bot_ZN_2 VAV Box Reheat CoilDemand Inlet Node,  !- Water Inlet Node Name
+    Perimeter_bot_ZN_2 VAV Box Reheat CoilDemand Outlet Node,  !- Water Outlet Node Name
+    Perimeter_bot_ZN_2 VAV Box Damper Node,  !- Air Inlet Node Name
+    Perimeter_bot_ZN_2 VAV Box Outlet Node Name,  !- Air Outlet Node Name
+    Perimeter_bot_ZN_3 VAV Box Reheat Coil,  !- Name
+    Perimeter_bot_ZN_3 VAV Box Reheat CoilDemand Inlet Node,  !- Water Inlet Node Name
+    Perimeter_bot_ZN_3 VAV Box Reheat CoilDemand Outlet Node,  !- Water Outlet Node Name
+    Perimeter_bot_ZN_3 VAV Box Damper Node,  !- Air Inlet Node Name
+    Perimeter_bot_ZN_3 VAV Box Outlet Node Name,  !- Air Outlet Node Name
+    Perimeter_bot_ZN_4 VAV Box Reheat Coil,  !- Name
+    Perimeter_bot_ZN_4 VAV Box Reheat CoilDemand Inlet Node,  !- Water Inlet Node Name
+    Perimeter_bot_ZN_4 VAV Box Reheat CoilDemand Outlet Node,  !- Water Outlet Node Name
+    Perimeter_bot_ZN_4 VAV Box Damper Node,  !- Air Inlet Node Name
+    Perimeter_bot_ZN_4 VAV Box Outlet Node Name,  !- Air Outlet Node Name
+    Perimeter_mid_ZN_1 VAV Box Reheat Coil,  !- Name
+    Perimeter_mid_ZN_1 VAV Box Reheat CoilDemand Inlet Node,  !- Water Inlet Node Name
+    Perimeter_mid_ZN_1 VAV Box Reheat CoilDemand Outlet Node,  !- Water Outlet Node Name
+    Perimeter_mid_ZN_1 VAV Box Damper Node,  !- Air Inlet Node Name
+    Perimeter_mid_ZN_1 VAV Box Outlet Node Name,  !- Air Outlet Node Name
+    Perimeter_mid_ZN_2 VAV Box Reheat Coil,  !- Name
+    Perimeter_mid_ZN_2 VAV Box Reheat CoilDemand Inlet Node,  !- Water Inlet Node Name
+    Perimeter_mid_ZN_2 VAV Box Reheat CoilDemand Outlet Node,  !- Water Outlet Node Name
+    Perimeter_mid_ZN_2 VAV Box Damper Node,  !- Air Inlet Node Name
+    Perimeter_mid_ZN_2 VAV Box Outlet Node Name,  !- Air Outlet Node Name
+    Perimeter_mid_ZN_3 VAV Box Reheat Coil,  !- Name
+    Perimeter_mid_ZN_3 VAV Box Reheat CoilDemand Inlet Node,  !- Water Inlet Node Name
+    Perimeter_mid_ZN_3 VAV Box Reheat CoilDemand Outlet Node,  !- Water Outlet Node Name
+    Perimeter_mid_ZN_3 VAV Box Damper Node,  !- Air Inlet Node Name
+    Perimeter_mid_ZN_3 VAV Box Outlet Node Name,  !- Air Outlet Node Name
+    Perimeter_mid_ZN_4 VAV Box Reheat Coil,  !- Name
+    Perimeter_mid_ZN_4 VAV Box Reheat CoilDemand Inlet Node,  !- Water Inlet Node Name
+    Perimeter_mid_ZN_4 VAV Box Reheat CoilDemand Outlet Node,  !- Water Outlet Node Name
+    Perimeter_mid_ZN_4 VAV Box Damper Node,  !- Air Inlet Node Name
+    Perimeter_mid_ZN_4 VAV Box Outlet Node Name,  !- Air Outlet Node Name
+    Perimeter_top_ZN_1 VAV Box Reheat Coil,  !- Name
+    Perimeter_top_ZN_1 VAV Box Reheat CoilDemand Inlet Node,  !- Water Inlet Node Name
+    Perimeter_top_ZN_1 VAV Box Reheat CoilDemand Outlet Node,  !- Water Outlet Node Name
+    Perimeter_top_ZN_1 VAV Box Damper Node,  !- Air Inlet Node Name
+    Perimeter_top_ZN_1 VAV Box Outlet Node Name,  !- Air Outlet Node Name
+    Perimeter_top_ZN_2 VAV Box Reheat Coil,  !- Name
+    Perimeter_top_ZN_2 VAV Box Reheat CoilDemand Inlet Node,  !- Water Inlet Node Name
+    Perimeter_top_ZN_2 VAV Box Reheat CoilDemand Outlet Node,  !- Water Outlet Node Name
+    Perimeter_top_ZN_2 VAV Box Damper Node,  !- Air Inlet Node Name
+    Perimeter_top_ZN_2 VAV Box Outlet Node Name,  !- Air Outlet Node Name
+    Perimeter_top_ZN_3 VAV Box Reheat Coil,  !- Name
+    Perimeter_top_ZN_3 VAV Box Reheat CoilDemand Inlet Node,  !- Water Inlet Node Name
+    Perimeter_top_ZN_3 VAV Box Reheat CoilDemand Outlet Node,  !- Water Outlet Node Name
+    Perimeter_top_ZN_3 VAV Box Damper Node,  !- Air Inlet Node Name
+    Perimeter_top_ZN_3 VAV Box Outlet Node Name,  !- Air Outlet Node Name
+    Perimeter_top_ZN_4 VAV Box Reheat Coil,  !- Name
+    Perimeter_top_ZN_4 VAV Box Reheat CoilDemand Inlet Node,  !- Water Inlet Node Name
+    Perimeter_top_ZN_4 VAV Box Reheat CoilDemand Outlet Node,  !- Water Outlet Node Name
+    Perimeter_top_ZN_4 VAV Box Damper Node,  !- Air Inlet Node Name
+    Perimeter_top_ZN_4 VAV Box Outlet Node Name,  !- Air Outlet Node Name
+    VAV_1_HeatC,             !- Name
+    VAV_1_HeatCDemand Inlet Node,  !- Water Inlet Node Name
+    VAV_1_HeatCDemand Outlet Node,  !- Water Outlet Node Name
+    VAV_1_CoolC-VAV_1_HeatCNode,  !- Air Inlet Node Name
+    VAV_1_HeatC-VAV_1_FanNode,  !- Air Outlet Node Name
+    VAV_2_HeatC,             !- Name
+    VAV_2_HeatCDemand Inlet Node,  !- Water Inlet Node Name
+    VAV_2_HeatCDemand Outlet Node,  !- Water Outlet Node Name
+    VAV_2_CoolC-VAV_2_HeatCNode,  !- Air Inlet Node Name
+    VAV_2_HeatC-VAV_2_FanNode,  !- Air Outlet Node Name
+    VAV_3_HeatC,             !- Name
+    VAV_3_HeatCDemand Inlet Node,  !- Water Inlet Node Name
+    VAV_3_HeatCDemand Outlet Node,  !- Water Outlet Node Name
+    VAV_3_CoolC-VAV_3_HeatCNode,  !- Air Inlet Node Name
+    VAV_3_HeatC-VAV_3_FanNode,  !- Air Outlet Node Name
+    VAV_5_HeatC,             !- Name
+    VAV_5_HeatCDemand Inlet Node,  !- Water Inlet Node Name
+    VAV_5_HeatCDemand Outlet Node,  !- Water Outlet Node Name
+    VAV_5_CoolC-VAV_5_HeatCNode,  !- Air Inlet Node Name
+    VAV_5_HeatC-VAV_5_FanNode,  !- Air Outlet Node Name
+  Coil:Cooling:Water,
+    VAV_3_CoolC,             !- Name
+    AUTOSIZE,                !- Design Water Flow Rate {m3/s}
+    AUTOSIZE,                !- Design Air Flow Rate {m3/s}
+    AUTOSIZE,                !- Design Inlet Water Temperature {C}
+    AUTOSIZE,                !- Design Inlet Air Temperature {C}
+    AUTOSIZE,                !- Design Outlet Air Temperature {C}
+    AUTOSIZE,                !- Design Inlet Air Humidity Ratio {kgWater/kgDryAir}
+    AUTOSIZE,                !- Design Outlet Air Humidity Ratio {kgWater/kgDryAir}
+    VAV_3_CoolCDemand Inlet Node,  !- Water Inlet Node Name
+    VAV_3_CoolCDemand Outlet Node,  !- Water Outlet Node Name
+    VAV_3_OA-VAV_3_CoolCNode,!- Air Inlet Node Name
+    VAV_3_CoolC-VAV_3_HeatCNode,  !- Air Outlet Node Name
+    SimpleAnalysis,          !- Type of Analysis
+    CrossFlow;               !- Heat Exchanger Configuration
+    VAV_2_CoolC,             !- Name
+    VAV_2_CoolCDemand Inlet Node,  !- Water Inlet Node Name
+    VAV_2_CoolCDemand Outlet Node,  !- Water Outlet Node Name
+    VAV_2_OA-VAV_2_CoolCNode,!- Air Inlet Node Name
+    VAV_2_CoolC-VAV_2_HeatCNode,  !- Air Outlet Node Name
+    VAV_1_CoolC,             !- Name
+    VAV_1_CoolCDemand Inlet Node,  !- Water Inlet Node Name
+    VAV_1_CoolCDemand Outlet Node,  !- Water Outlet Node Name
+    VAV_1_OA-VAV_1_CoolCNode,!- Air Inlet Node Name
+    VAV_1_CoolC-VAV_1_HeatCNode,  !- Air Outlet Node Name
+    VAV_5_CoolC,             !- Name
+    VAV_5_CoolCDemand Inlet Node,  !- Water Inlet Node Name
+    VAV_5_CoolCDemand Outlet Node,  !- Water Outlet Node Name
+    VAV_5_OA-VAV_5_CoolCNode,!- Air Inlet Node Name
+    VAV_5_CoolC-VAV_5_HeatCNode,  !- Air Outlet Node Name
+  AirTerminal:SingleDuct:VAV:Reheat,
+    Basement VAV Box Component,  !- Name
+    Basement VAV Box Damper Node,  !- Damper Air Outlet Node Name
+    Basement VAV Box Inlet Node Name,  !- Air Inlet Node Name
+    AUTOSIZE,                !- Maximum Air Flow Rate {m3/s}
+    Constant,                !- Zone Minimum Air Flow Input Method
+    0.3,                     !- Constant Minimum Air Flow Fraction
+    ,                        !- Fixed Minimum Air Flow Rate {m3/s}
+    ,                        !- Minimum Air Flow Fraction Schedule Name
+    Coil:Heating:Water,      !- Reheat Coil Object Type
+    Basement VAV Box Reheat Coil,  !- Reheat Coil Name
+    AUTOSIZE,                !- Maximum Hot Water or Steam Flow Rate {m3/s}
+    0.0,                     !- Minimum Hot Water or Steam Flow Rate {m3/s}
+    0.001,                   !- Convergence Tolerance
+    NORMAL;                  !- Damper Heating Action
+    Core_bottom VAV Box Component,  !- Name
+    Core_bottom VAV Box Damper Node,  !- Damper Air Outlet Node Name
+    Core_bottom VAV Box Inlet Node Name,  !- Air Inlet Node Name
+    Core_bottom VAV Box Reheat Coil,  !- Reheat Coil Name
+    Core_mid VAV Box Component,  !- Name
+    Core_mid VAV Box Damper Node,  !- Damper Air Outlet Node Name
+    Core_mid VAV Box Inlet Node Name,  !- Air Inlet Node Name
+    Core_mid VAV Box Reheat Coil,  !- Reheat Coil Name
+    Core_top VAV Box Component,  !- Name
+    Core_top VAV Box Damper Node,  !- Damper Air Outlet Node Name
+    Core_top VAV Box Inlet Node Name,  !- Air Inlet Node Name
+    Core_top VAV Box Reheat Coil,  !- Reheat Coil Name
+    Perimeter_bot_ZN_1 VAV Box Component,  !- Name
+    Perimeter_bot_ZN_1 VAV Box Damper Node,  !- Damper Air Outlet Node Name
+    Perimeter_bot_ZN_1 VAV Box Inlet Node Name,  !- Air Inlet Node Name
+    Perimeter_bot_ZN_1 VAV Box Reheat Coil,  !- Reheat Coil Name
+    Perimeter_bot_ZN_2 VAV Box Component,  !- Name
+    Perimeter_bot_ZN_2 VAV Box Damper Node,  !- Damper Air Outlet Node Name
+    Perimeter_bot_ZN_2 VAV Box Inlet Node Name,  !- Air Inlet Node Name
+    Perimeter_bot_ZN_2 VAV Box Reheat Coil,  !- Reheat Coil Name
+    Perimeter_bot_ZN_3 VAV Box Component,  !- Name
+    Perimeter_bot_ZN_3 VAV Box Damper Node,  !- Damper Air Outlet Node Name
+    Perimeter_bot_ZN_3 VAV Box Inlet Node Name,  !- Air Inlet Node Name
+    Perimeter_bot_ZN_3 VAV Box Reheat Coil,  !- Reheat Coil Name
+    Perimeter_bot_ZN_4 VAV Box Component,  !- Name
+    Perimeter_bot_ZN_4 VAV Box Damper Node,  !- Damper Air Outlet Node Name
+    Perimeter_bot_ZN_4 VAV Box Inlet Node Name,  !- Air Inlet Node Name
+    Perimeter_bot_ZN_4 VAV Box Reheat Coil,  !- Reheat Coil Name
+    Perimeter_mid_ZN_1 VAV Box Component,  !- Name
+    Perimeter_mid_ZN_1 VAV Box Damper Node,  !- Damper Air Outlet Node Name
+    Perimeter_mid_ZN_1 VAV Box Inlet Node Name,  !- Air Inlet Node Name
+    Perimeter_mid_ZN_1 VAV Box Reheat Coil,  !- Reheat Coil Name
+    Perimeter_mid_ZN_2 VAV Box Component,  !- Name
+    Perimeter_mid_ZN_2 VAV Box Damper Node,  !- Damper Air Outlet Node Name
+    Perimeter_mid_ZN_2 VAV Box Inlet Node Name,  !- Air Inlet Node Name
+    Perimeter_mid_ZN_2 VAV Box Reheat Coil,  !- Reheat Coil Name
+    Perimeter_mid_ZN_3 VAV Box Component,  !- Name
+    Perimeter_mid_ZN_3 VAV Box Damper Node,  !- Damper Air Outlet Node Name
+    Perimeter_mid_ZN_3 VAV Box Inlet Node Name,  !- Air Inlet Node Name
+    Perimeter_mid_ZN_3 VAV Box Reheat Coil,  !- Reheat Coil Name
+    Perimeter_mid_ZN_4 VAV Box Component,  !- Name
+    Perimeter_mid_ZN_4 VAV Box Damper Node,  !- Damper Air Outlet Node Name
+    Perimeter_mid_ZN_4 VAV Box Inlet Node Name,  !- Air Inlet Node Name
+    Perimeter_mid_ZN_4 VAV Box Reheat Coil,  !- Reheat Coil Name
+    Perimeter_top_ZN_1 VAV Box Component,  !- Name
+    Perimeter_top_ZN_1 VAV Box Damper Node,  !- Damper Air Outlet Node Name
+    Perimeter_top_ZN_1 VAV Box Inlet Node Name,  !- Air Inlet Node Name
+    Perimeter_top_ZN_1 VAV Box Reheat Coil,  !- Reheat Coil Name
+    Perimeter_top_ZN_2 VAV Box Component,  !- Name
+    Perimeter_top_ZN_2 VAV Box Damper Node,  !- Damper Air Outlet Node Name
+    Perimeter_top_ZN_2 VAV Box Inlet Node Name,  !- Air Inlet Node Name
+    Perimeter_top_ZN_2 VAV Box Reheat Coil,  !- Reheat Coil Name
+    Perimeter_top_ZN_3 VAV Box Component,  !- Name
+    Perimeter_top_ZN_3 VAV Box Damper Node,  !- Damper Air Outlet Node Name
+    Perimeter_top_ZN_3 VAV Box Inlet Node Name,  !- Air Inlet Node Name
+    Perimeter_top_ZN_3 VAV Box Reheat Coil,  !- Reheat Coil Name
+    Perimeter_top_ZN_4 VAV Box Component,  !- Name
+    Perimeter_top_ZN_4 VAV Box Damper Node,  !- Damper Air Outlet Node Name
+    Perimeter_top_ZN_4 VAV Box Inlet Node Name,  !- Air Inlet Node Name
+    Perimeter_top_ZN_4 VAV Box Reheat Coil,  !- Reheat Coil Name
+  ZoneHVAC:EquipmentList,
+    Basement Equipment,      !- Name
+    ZoneHVAC:AirDistributionUnit,  !- Zone Equipment 1 Object Type
+    Basement VAV Box,        !- Zone Equipment 1 Name
+    1,                       !- Zone Equipment 1 Cooling Sequence
+    1;                       !- Zone Equipment 1 Heating or No-Load Sequence
+    Core_bottom Equipment,   !- Name
+    Core_bottom VAV Box,     !- Zone Equipment 1 Name
+    Core_mid Equipment,      !- Name
+    Core_mid VAV Box,        !- Zone Equipment 1 Name
+    Core_top Equipment,      !- Name
+    Core_top VAV Box,        !- Zone Equipment 1 Name
+    Perimeter_bot_ZN_1 Equipment,  !- Name
+    Perimeter_bot_ZN_1 VAV Box,  !- Zone Equipment 1 Name
+    Perimeter_bot_ZN_2 Equipment,  !- Name
+    Perimeter_bot_ZN_2 VAV Box,  !- Zone Equipment 1 Name
+    Perimeter_bot_ZN_3 Equipment,  !- Name
+    Perimeter_bot_ZN_3 VAV Box,  !- Zone Equipment 1 Name
+    Perimeter_bot_ZN_4 Equipment,  !- Name
+    Perimeter_bot_ZN_4 VAV Box,  !- Zone Equipment 1 Name
+    Perimeter_mid_ZN_1 Equipment,  !- Name
+    Perimeter_mid_ZN_1 VAV Box,  !- Zone Equipment 1 Name
+    Perimeter_mid_ZN_2 Equipment,  !- Name
+    Perimeter_mid_ZN_2 VAV Box,  !- Zone Equipment 1 Name
+    Perimeter_mid_ZN_3 Equipment,  !- Name
+    Perimeter_mid_ZN_3 VAV Box,  !- Zone Equipment 1 Name
+    Perimeter_mid_ZN_4 Equipment,  !- Name
+    Perimeter_mid_ZN_4 VAV Box,  !- Zone Equipment 1 Name
+    Perimeter_top_ZN_1 Equipment,  !- Name
+    Perimeter_top_ZN_1 VAV Box,  !- Zone Equipment 1 Name
+    Perimeter_top_ZN_2 Equipment,  !- Name
+    Perimeter_top_ZN_2 VAV Box,  !- Zone Equipment 1 Name
+    Perimeter_top_ZN_3 Equipment,  !- Name
+    Perimeter_top_ZN_3 VAV Box,  !- Zone Equipment 1 Name
+    Perimeter_top_ZN_4 Equipment,  !- Name
+    Perimeter_top_ZN_4 VAV Box,  !- Zone Equipment 1 Name
+! ***SIZING & CONTROLS***
+  Sizing:Zone,
+    SupplyAirTemperature,    !- Zone Cooling Design Supply Air Temperature Input Method
+    12.8000,                 !- Zone Cooling Design Supply Air Temperature {C}
+    ,                        !- Zone Cooling Design Supply Air Temperature Difference {deltaC}
+    SupplyAirTemperature,    !- Zone Heating Design Supply Air Temperature Input Method
+    50.0000,                 !- Zone Heating Design Supply Air Temperature {C}
+    ,                        !- Zone Heating Design Supply Air Temperature Difference {deltaC}
+    0.0085,                  !- Zone Cooling Design Supply Air Humidity Ratio {kgWater/kgDryAir}
+    0.0080,                  !- Zone Heating Design Supply Air Humidity Ratio {kgWater/kgDryAir}
+    SZ DSOA Basement,        !- Design Specification Outdoor Air Object Name
+    ,                        !- Zone Heating Sizing Factor
+    ,                        !- Zone Cooling Sizing Factor
+    DesignDay,               !- Cooling Design Air Flow Method
+    ,                        !- Cooling Design Air Flow Rate {m3/s}
+    ,                        !- Cooling Minimum Air Flow per Zone Floor Area {m3/s-m2}
+    ,                        !- Cooling Minimum Air Flow {m3/s}
+    ,                        !- Cooling Minimum Air Flow Fraction
+    DesignDay,               !- Heating Design Air Flow Method
+    ,                        !- Heating Design Air Flow Rate {m3/s}
+    ,                        !- Heating Maximum Air Flow per Zone Floor Area {m3/s-m2}
+    ,                        !- Heating Maximum Air Flow {m3/s}
+    ;                        !- Heating Maximum Air Flow Fraction
+  DesignSpecification:OutdoorAir,
+    SZ DSOA Basement,        !- Name
+    Flow/Person,             !- Outdoor Air Method
+    0.0125,                  !- Outdoor Air Flow per Person {m3/s-person}
+    ,                        !- Outdoor Air Flow per Zone Floor Area {m3/s-m2}
+    ;                        !- Outdoor Air Flow per Zone {m3/s}
+  Sizing:Zone,
+    SZ DSOA Core_bottom,     !- Design Specification Outdoor Air Object Name
+    SZ DSOA Core_bottom,     !- Name
+  Sizing:Zone,
+    SZ DSOA Core_mid,        !- Design Specification Outdoor Air Object Name
+    SZ DSOA Core_mid,        !- Name
+  Sizing:Zone,
+    SZ DSOA Core_top,        !- Design Specification Outdoor Air Object Name
+    SZ DSOA Core_top,        !- Name
+  Sizing:Zone,
+    SZ DSOA Perimeter_bot_ZN_1,  !- Design Specification Outdoor Air Object Name
+    SZ DSOA Perimeter_bot_ZN_1,  !- Name
+  Sizing:Zone,
+    SZ DSOA Perimeter_bot_ZN_2,  !- Design Specification Outdoor Air Object Name
+    SZ DSOA Perimeter_bot_ZN_2,  !- Name
+  Sizing:Zone,
+    SZ DSOA Perimeter_bot_ZN_3,  !- Design Specification Outdoor Air Object Name
+    SZ DSOA Perimeter_bot_ZN_3,  !- Name
+  Sizing:Zone,
+    SZ DSOA Perimeter_bot_ZN_4,  !- Design Specification Outdoor Air Object Name
+    SZ DSOA Perimeter_bot_ZN_4,  !- Name
+  Sizing:Zone,
+    SZ DSOA Perimeter_mid_ZN_1,  !- Design Specification Outdoor Air Object Name
+    SZ DSOA Perimeter_mid_ZN_1,  !- Name
+  Sizing:Zone,
+    SZ DSOA Perimeter_mid_ZN_2,  !- Design Specification Outdoor Air Object Name
+    SZ DSOA Perimeter_mid_ZN_2,  !- Name
+  Sizing:Zone,
+    SZ DSOA Perimeter_mid_ZN_3,  !- Design Specification Outdoor Air Object Name
+    SZ DSOA Perimeter_mid_ZN_3,  !- Name
+  Sizing:Zone,
+    SZ DSOA Perimeter_mid_ZN_4,  !- Design Specification Outdoor Air Object Name
+    SZ DSOA Perimeter_mid_ZN_4,  !- Name
+  Sizing:Zone,
+    SZ DSOA Perimeter_top_ZN_1,  !- Design Specification Outdoor Air Object Name
+    SZ DSOA Perimeter_top_ZN_1,  !- Name
+  Sizing:Zone,
+    SZ DSOA Perimeter_top_ZN_2,  !- Design Specification Outdoor Air Object Name
+    SZ DSOA Perimeter_top_ZN_2,  !- Name
+  Sizing:Zone,
+    SZ DSOA Perimeter_top_ZN_3,  !- Design Specification Outdoor Air Object Name
+    SZ DSOA Perimeter_top_ZN_3,  !- Name
+  Sizing:Zone,
+    SZ DSOA Perimeter_top_ZN_4,  !- Design Specification Outdoor Air Object Name
+    SZ DSOA Perimeter_top_ZN_4,  !- Name
+  ZoneControl:Thermostat,
+    Basement Thermostat,     !- Name
+    Dual Zone Control Type Sched,  !- Control Type Schedule Name
+    ThermostatSetpoint:DualSetpoint,  !- Control 1 Object Type
+    Basement DualSPSched;    !- Control 1 Name
+    Core_bottom Thermostat,  !- Name
+    Core_bottom DualSPSched; !- Control 1 Name
+    Core_mid Thermostat,     !- Name
+    Core_mid DualSPSched;    !- Control 1 Name
+    Core_top Thermostat,     !- Name
+    Core_top DualSPSched;    !- Control 1 Name
+    Perimeter_bot_ZN_1 Thermostat,  !- Name
+    Perimeter_bot_ZN_1 DualSPSched;  !- Control 1 Name
+    Perimeter_bot_ZN_2 Thermostat,  !- Name
+    Perimeter_bot_ZN_2 DualSPSched;  !- Control 1 Name
+    Perimeter_bot_ZN_3 Thermostat,  !- Name
+    Perimeter_bot_ZN_3 DualSPSched;  !- Control 1 Name
+    Perimeter_bot_ZN_4 Thermostat,  !- Name
+    Perimeter_bot_ZN_4 DualSPSched;  !- Control 1 Name
+    Perimeter_mid_ZN_1 Thermostat,  !- Name
+    Perimeter_mid_ZN_1 DualSPSched;  !- Control 1 Name
+    Perimeter_mid_ZN_2 Thermostat,  !- Name
+    Perimeter_mid_ZN_2 DualSPSched;  !- Control 1 Name
+    Perimeter_mid_ZN_3 Thermostat,  !- Name
+    Perimeter_mid_ZN_3 DualSPSched;  !- Control 1 Name
+    Perimeter_mid_ZN_4 Thermostat,  !- Name
+    Perimeter_mid_ZN_4 DualSPSched;  !- Control 1 Name
+    Perimeter_top_ZN_1 Thermostat,  !- Name
+    Perimeter_top_ZN_1 DualSPSched;  !- Control 1 Name
+    Perimeter_top_ZN_2 Thermostat,  !- Name
+    Perimeter_top_ZN_2 DualSPSched;  !- Control 1 Name
+    Perimeter_top_ZN_3 Thermostat,  !- Name
+    Perimeter_top_ZN_3 DualSPSched;  !- Control 1 Name
+    Perimeter_top_ZN_4 Thermostat,  !- Name
+    Perimeter_top_ZN_4 DualSPSched;  !- Control 1 Name
+    Basement DualSPSched,    !- Name
+    HTGSETP_SCH,             !- Heating Setpoint Temperature Schedule Name
+    CLGSETP_SCH;             !- Cooling Setpoint Temperature Schedule Name
+    Core_bottom DualSPSched, !- Name
+    Core_mid DualSPSched,    !- Name
+    Core_top DualSPSched,    !- Name
+    Perimeter_bot_ZN_1 DualSPSched,  !- Name
+    Perimeter_bot_ZN_2 DualSPSched,  !- Name
+    Perimeter_bot_ZN_3 DualSPSched,  !- Name
+    Perimeter_bot_ZN_4 DualSPSched,  !- Name
+    Perimeter_mid_ZN_1 DualSPSched,  !- Name
+    Perimeter_mid_ZN_2 DualSPSched,  !- Name
+    Perimeter_mid_ZN_3 DualSPSched,  !- Name
+    Perimeter_mid_ZN_4 DualSPSched,  !- Name
+    Perimeter_top_ZN_1 DualSPSched,  !- Name
+    Perimeter_top_ZN_2 DualSPSched,  !- Name
+    Perimeter_top_ZN_3 DualSPSched,  !- Name
+    Perimeter_top_ZN_4 DualSPSched,  !- Name
+  Sizing:System,
+    VAV_1,                   !- AirLoop Name
+    Sensible,                !- Type of Load to Size On
+    AUTOSIZE,                !- Design Outdoor Air Flow Rate {m3/s}
+    0.3,                     !- Minimum System Air Flow Ratio
+    7.0,                     !- Preheat Design Temperature {C}
+    0.008,                   !- Preheat Design Humidity Ratio {kgWater/kgDryAir}
+    12.8000,                 !- Precool Design Temperature {C}
+    0.008,                   !- Precool Design Humidity Ratio {kgWater/kgDryAir}
+    12.8000,                 !- Central Cooling Design Supply Air Temperature {C}
+    16.7000,                 !- Central Heating Design Supply Air Temperature {C}
+    NonCoincident,           !- Sizing Option
+    No,                      !- 100% Outdoor Air in Cooling
+    No,                      !- 100% Outdoor Air in Heating
+    0.0085,                  !- Central Cooling Design Supply Air Humidity Ratio {kgWater/kgDryAir}
+    0.0080,                  !- Central Heating Design Supply Air Humidity Ratio {kgWater/kgDryAir}
+    ZoneSum;                 !- System Outdoor Air Method
+  Sizing:System,
+    VAV_2,                   !- AirLoop Name
+  Sizing:System,
+    VAV_3,                   !- AirLoop Name
+  Sizing:System,
+    VAV_5,                   !- AirLoop Name
+  Controller:OutdoorAir,
+    VAV_1_OA_Controller,     !- Name
+    VAV_1_OARelief Node,     !- Relief Air Outlet Node Name
+    VAV_1 Supply Equipment Inlet Node,  !- Return Air Node Name
+    VAV_1_OA-VAV_1_CoolCNode,!- Mixed Air Node Name
+    VAV_1_OAInlet Node,      !- Actuator Node Name
+    AUTOSIZE,                !- Minimum Outdoor Air Flow Rate {m3/s}
+    AUTOSIZE,                !- Maximum Outdoor Air Flow Rate {m3/s}
+    DifferentialDryBulb,     !- Economizer Control Type
+    ModulateFlow,            !- Economizer Control Action Type
+    28.0,                    !- Economizer Maximum Limit Dry-Bulb Temperature {C}
+    64000.0,                 !- Economizer Maximum Limit Enthalpy {J/kg}
+    ,                        !- Economizer Maximum Limit Dewpoint Temperature {C}
+    ,                        !- Electronic Enthalpy Limit Curve Name
+    -100.0,                  !- Economizer Minimum Limit Dry-Bulb Temperature {C}
+    NoLockout,               !- Lockout Type
+    FixedMinimum,            !- Minimum Limit Type
+    MinOA_MotorizedDamper_Sched,  !- Minimum Outdoor Air Schedule Name
+    ,                        !- Minimum Fraction of Outdoor Air Schedule Name
+    ,                        !- Maximum Fraction of Outdoor Air Schedule Name
+    ;                        !- Mechanical Ventilation Controller Name
+    VAV_2_OA_Controller,     !- Name
+    VAV_2_OARelief Node,     !- Relief Air Outlet Node Name
+    VAV_2 Supply Equipment Inlet Node,  !- Return Air Node Name
+    VAV_2_OA-VAV_2_CoolCNode,!- Mixed Air Node Name
+    VAV_2_OAInlet Node,      !- Actuator Node Name
+    VAV_3_OA_Controller,     !- Name
+    VAV_3_OARelief Node,     !- Relief Air Outlet Node Name
+    VAV_3 Supply Equipment Inlet Node,  !- Return Air Node Name
+    VAV_3_OA-VAV_3_CoolCNode,!- Mixed Air Node Name
+    VAV_3_OAInlet Node,      !- Actuator Node Name
+    VAV_5_OA_Controller,     !- Name
+    VAV_5_OARelief Node,     !- Relief Air Outlet Node Name
+    VAV_5 Supply Equipment Inlet Node,  !- Return Air Node Name
+    VAV_5_OA-VAV_5_CoolCNode,!- Mixed Air Node Name
+    VAV_5_OAInlet Node,      !- Actuator Node Name
+  SetpointManager:Scheduled,
+    VAV_1 SAT setpoint,      !- Name
+    Temperature,             !- Control Variable
+    Seasonal-Reset-Supply-Air-Temp-Sch,  !- Schedule Name
+    VAV_1 Supply Equipment Outlet Node;  !- Setpoint Node or NodeList Name
+    VAV_2 SAT setpoint,      !- Name
+    VAV_2 Supply Equipment Outlet Node;  !- Setpoint Node or NodeList Name
+    VAV_3 SAT setpoint,      !- Name
+    VAV_3 Supply Equipment Outlet Node;  !- Setpoint Node or NodeList Name
+    VAV_5 SAT setpoint,      !- Name
+    VAV_5 Supply Equipment Outlet Node;  !- Setpoint Node or NodeList Name
+! ***AIR LOOPS***
+  AirLoopHVAC,
+    VAV_1,                   !- Name
+    VAV_1_Controllers,       !- Controller List Name
+    VAV_1 Availability Manager List,  !- Availability Manager List Name
+    AUTOSIZE,                !- Design Supply Air Flow Rate {m3/s}
+    VAV_1 Air Loop Branches, !- Branch List Name
+    ,                        !- Connector List Name
+    VAV_1 Supply Equipment Inlet Node,  !- Supply Side Inlet Node Name
+    VAV_1 Zone Equipment Outlet Node,  !- Demand Side Outlet Node Name
+    VAV_1 Zone Equipment Inlet Node,  !- Demand Side Inlet Node Names
+    VAV_1 Supply Equipment Outlet Node;  !- Supply Side Outlet Node Names
+  AirLoopHVAC,
+    VAV_2,                   !- Name
+    VAV_2_Controllers,       !- Controller List Name
+    VAV_2 Availability Manager List,  !- Availability Manager List Name
+    VAV_2 Air Loop Branches, !- Branch List Name
+    VAV_2 Supply Equipment Inlet Node,  !- Supply Side Inlet Node Name
+    VAV_2 Zone Equipment Outlet Node,  !- Demand Side Outlet Node Name
+    VAV_2 Zone Equipment Inlet Node,  !- Demand Side Inlet Node Names
+    VAV_2 Supply Equipment Outlet Node;  !- Supply Side Outlet Node Names
+  AirLoopHVAC,
+    VAV_3,                   !- Name
+    VAV_3_Controllers,       !- Controller List Name
+    VAV_3 Availability Manager List,  !- Availability Manager List Name
+    VAV_3 Air Loop Branches, !- Branch List Name
+    VAV_3 Supply Equipment Inlet Node,  !- Supply Side Inlet Node Name
+    VAV_3 Zone Equipment Outlet Node,  !- Demand Side Outlet Node Name
+    VAV_3 Zone Equipment Inlet Node,  !- Demand Side Inlet Node Names
+    VAV_3 Supply Equipment Outlet Node;  !- Supply Side Outlet Node Names
+  AirLoopHVAC,
+    VAV_5,                   !- Name
+    VAV_5_Controllers,       !- Controller List Name
+    VAV_5 Availability Manager List,  !- Availability Manager List Name
+    VAV_5 Air Loop Branches, !- Branch List Name
+    VAV_5 Supply Equipment Inlet Node,  !- Supply Side Inlet Node Name
+    VAV_5 Zone Equipment Outlet Node,  !- Demand Side Outlet Node Name
+    VAV_5 Zone Equipment Inlet Node,  !- Demand Side Inlet Node Names
+    VAV_5 Supply Equipment Outlet Node;  !- Supply Side Outlet Node Names
+! ***CONNECTIONS***
+  ZoneHVAC:EquipmentConnections,
+    Basement,                !- Zone Name
+    Basement Equipment,      !- Zone Conditioning Equipment List Name
+    Basement Inlet Nodes,    !- Zone Air Inlet Node or NodeList Name
+    ,                        !- Zone Air Exhaust Node or NodeList Name
+    Basement Air Node,       !- Zone Air Node Name
+    Basement Return Air Node Name;  !- Zone Return Air Node Name
+    Core_bottom,             !- Zone Name
+    Core_bottom Equipment,   !- Zone Conditioning Equipment List Name
+    Core_bottom Inlet Nodes, !- Zone Air Inlet Node or NodeList Name
+    Core_bottom Air Node,    !- Zone Air Node Name
+    Core_bottom Return Air Node Name;  !- Zone Return Air Node Name
+    Core_mid,                !- Zone Name
+    Core_mid Equipment,      !- Zone Conditioning Equipment List Name
+    Core_mid Inlet Nodes,    !- Zone Air Inlet Node or NodeList Name
+    Core_mid Air Node,       !- Zone Air Node Name
+    Core_mid Return Air Node Name;  !- Zone Return Air Node Name
+    Core_top Equipment,      !- Zone Conditioning Equipment List Name
+    Core_top Inlet Nodes,    !- Zone Air Inlet Node or NodeList Name
+    Core_top Air Node,       !- Zone Air Node Name
+    Core_top Return Air Node Name;  !- Zone Return Air Node Name
+    Perimeter_bot_ZN_1 Equipment,  !- Zone Conditioning Equipment List Name
+    Perimeter_bot_ZN_1 Inlet Nodes,  !- Zone Air Inlet Node or NodeList Name
+    Perimeter_bot_ZN_1 Air Node,  !- Zone Air Node Name
+    Perimeter_bot_ZN_1 Return Air Node Name;  !- Zone Return Air Node Name
+    Perimeter_bot_ZN_2 Equipment,  !- Zone Conditioning Equipment List Name
+    Perimeter_bot_ZN_2 Inlet Nodes,  !- Zone Air Inlet Node or NodeList Name
+    Perimeter_bot_ZN_2 Air Node,  !- Zone Air Node Name
+    Perimeter_bot_ZN_2 Return Air Node Name;  !- Zone Return Air Node Name
+    Perimeter_bot_ZN_3 Equipment,  !- Zone Conditioning Equipment List Name
+    Perimeter_bot_ZN_3 Inlet Nodes,  !- Zone Air Inlet Node or NodeList Name
+    Perimeter_bot_ZN_3 Air Node,  !- Zone Air Node Name
+    Perimeter_bot_ZN_3 Return Air Node Name;  !- Zone Return Air Node Name
+    Perimeter_bot_ZN_4 Equipment,  !- Zone Conditioning Equipment List Name
+    Perimeter_bot_ZN_4 Inlet Nodes,  !- Zone Air Inlet Node or NodeList Name
+    Perimeter_bot_ZN_4 Air Node,  !- Zone Air Node Name
+    Perimeter_bot_ZN_4 Return Air Node Name;  !- Zone Return Air Node Name
+    Perimeter_mid_ZN_1 Equipment,  !- Zone Conditioning Equipment List Name
+    Perimeter_mid_ZN_1 Inlet Nodes,  !- Zone Air Inlet Node or NodeList Name
+    Perimeter_mid_ZN_1 Air Node,  !- Zone Air Node Name
+    Perimeter_mid_ZN_1 Return Air Node Name;  !- Zone Return Air Node Name
+    Perimeter_mid_ZN_2 Equipment,  !- Zone Conditioning Equipment List Name
+    Perimeter_mid_ZN_2 Inlet Nodes,  !- Zone Air Inlet Node or NodeList Name
+    Perimeter_mid_ZN_2 Air Node,  !- Zone Air Node Name
+    Perimeter_mid_ZN_2 Return Air Node Name;  !- Zone Return Air Node Name
+    Perimeter_mid_ZN_3 Equipment,  !- Zone Conditioning Equipment List Name
+    Perimeter_mid_ZN_3 Inlet Nodes,  !- Zone Air Inlet Node or NodeList Name
+    Perimeter_mid_ZN_3 Air Node,  !- Zone Air Node Name
+    Perimeter_mid_ZN_3 Return Air Node Name;  !- Zone Return Air Node Name
+    Perimeter_mid_ZN_4 Equipment,  !- Zone Conditioning Equipment List Name
+    Perimeter_mid_ZN_4 Inlet Nodes,  !- Zone Air Inlet Node or NodeList Name
+    Perimeter_mid_ZN_4 Air Node,  !- Zone Air Node Name
+    Perimeter_mid_ZN_4 Return Air Node Name;  !- Zone Return Air Node Name
+    Perimeter_top_ZN_1 Equipment,  !- Zone Conditioning Equipment List Name
+    Perimeter_top_ZN_1 Inlet Nodes,  !- Zone Air Inlet Node or NodeList Name
+    Perimeter_top_ZN_1 Air Node,  !- Zone Air Node Name
+    Perimeter_top_ZN_1 Return Air Node Name;  !- Zone Return Air Node Name
+    Perimeter_top_ZN_2 Equipment,  !- Zone Conditioning Equipment List Name
+    Perimeter_top_ZN_2 Inlet Nodes,  !- Zone Air Inlet Node or NodeList Name
+    Perimeter_top_ZN_2 Air Node,  !- Zone Air Node Name
+    Perimeter_top_ZN_2 Return Air Node Name;  !- Zone Return Air Node Name
+    Perimeter_top_ZN_3 Equipment,  !- Zone Conditioning Equipment List Name
+    Perimeter_top_ZN_3 Inlet Nodes,  !- Zone Air Inlet Node or NodeList Name
+    Perimeter_top_ZN_3 Air Node,  !- Zone Air Node Name
+    Perimeter_top_ZN_3 Return Air Node Name;  !- Zone Return Air Node Name
+    Perimeter_top_ZN_4 Equipment,  !- Zone Conditioning Equipment List Name
+    Perimeter_top_ZN_4 Inlet Nodes,  !- Zone Air Inlet Node or NodeList Name
+    Perimeter_top_ZN_4 Air Node,  !- Zone Air Node Name
+    Perimeter_top_ZN_4 Return Air Node Name;  !- Zone Return Air Node Name
+    Basement VAV Box,        !- Name
+    Basement VAV Box Outlet Node Name,  !- Air Distribution Unit Outlet Node Name
+    AirTerminal:SingleDuct:VAV:Reheat,  !- Air Terminal Object Type
+    Basement VAV Box Component;  !- Air Terminal Name
+    Core_bottom VAV Box,     !- Name
+    Core_bottom VAV Box Outlet Node Name,  !- Air Distribution Unit Outlet Node Name
+    Core_bottom VAV Box Component;  !- Air Terminal Name
+    Core_mid VAV Box,        !- Name
+    Core_mid VAV Box Outlet Node Name,  !- Air Distribution Unit Outlet Node Name
+    Core_mid VAV Box Component;  !- Air Terminal Name
+    Core_top VAV Box,        !- Name
+    Core_top VAV Box Outlet Node Name,  !- Air Distribution Unit Outlet Node Name
+    Core_top VAV Box Component;  !- Air Terminal Name
+    Perimeter_bot_ZN_1 VAV Box,  !- Name
+    Perimeter_bot_ZN_1 VAV Box Outlet Node Name,  !- Air Distribution Unit Outlet Node Name
+    Perimeter_bot_ZN_1 VAV Box Component;  !- Air Terminal Name
+    Perimeter_bot_ZN_2 VAV Box,  !- Name
+    Perimeter_bot_ZN_2 VAV Box Outlet Node Name,  !- Air Distribution Unit Outlet Node Name
+    Perimeter_bot_ZN_2 VAV Box Component;  !- Air Terminal Name
+    Perimeter_bot_ZN_3 VAV Box,  !- Name
+    Perimeter_bot_ZN_3 VAV Box Outlet Node Name,  !- Air Distribution Unit Outlet Node Name
+    Perimeter_bot_ZN_3 VAV Box Component;  !- Air Terminal Name
+    Perimeter_bot_ZN_4 VAV Box,  !- Name
+    Perimeter_bot_ZN_4 VAV Box Outlet Node Name,  !- Air Distribution Unit Outlet Node Name
+    Perimeter_bot_ZN_4 VAV Box Component;  !- Air Terminal Name
+    Perimeter_mid_ZN_1 VAV Box,  !- Name
+    Perimeter_mid_ZN_1 VAV Box Outlet Node Name,  !- Air Distribution Unit Outlet Node Name
+    Perimeter_mid_ZN_1 VAV Box Component;  !- Air Terminal Name
+    Perimeter_mid_ZN_2 VAV Box,  !- Name
+    Perimeter_mid_ZN_2 VAV Box Outlet Node Name,  !- Air Distribution Unit Outlet Node Name
+    Perimeter_mid_ZN_2 VAV Box Component;  !- Air Terminal Name
+    Perimeter_mid_ZN_3 VAV Box,  !- Name
+    Perimeter_mid_ZN_3 VAV Box Outlet Node Name,  !- Air Distribution Unit Outlet Node Name
+    Perimeter_mid_ZN_3 VAV Box Component;  !- Air Terminal Name
+    Perimeter_mid_ZN_4 VAV Box,  !- Name
+    Perimeter_mid_ZN_4 VAV Box Outlet Node Name,  !- Air Distribution Unit Outlet Node Name
+    Perimeter_mid_ZN_4 VAV Box Component;  !- Air Terminal Name
+    Perimeter_top_ZN_1 VAV Box,  !- Name
+    Perimeter_top_ZN_1 VAV Box Outlet Node Name,  !- Air Distribution Unit Outlet Node Name
+    Perimeter_top_ZN_1 VAV Box Component;  !- Air Terminal Name
+    Perimeter_top_ZN_2 VAV Box,  !- Name
+    Perimeter_top_ZN_2 VAV Box Outlet Node Name,  !- Air Distribution Unit Outlet Node Name
+    Perimeter_top_ZN_2 VAV Box Component;  !- Air Terminal Name
+    Perimeter_top_ZN_3 VAV Box,  !- Name
+    Perimeter_top_ZN_3 VAV Box Outlet Node Name,  !- Air Distribution Unit Outlet Node Name
+    Perimeter_top_ZN_3 VAV Box Component;  !- Air Terminal Name
+    Perimeter_top_ZN_4 VAV Box,  !- Name
+    Perimeter_top_ZN_4 VAV Box Outlet Node Name,  !- Air Distribution Unit Outlet Node Name
+    Perimeter_top_ZN_4 VAV Box Component;  !- Air Terminal Name
+  NodeList,
+    Basement Inlet Nodes,    !- Name
+    Basement VAV Box Outlet Node Name;  !- Node 1 Name
+  NodeList,
+    Core_bottom Inlet Nodes, !- Name
+    Core_bottom VAV Box Outlet Node Name;  !- Node 1 Name
+  NodeList,
+    Core_mid Inlet Nodes,    !- Name
+    Core_mid VAV Box Outlet Node Name;  !- Node 1 Name
+  NodeList,
+    Core_top Inlet Nodes,    !- Name
+    Core_top VAV Box Outlet Node Name;  !- Node 1 Name
+  NodeList,
+    Perimeter_bot_ZN_1 Inlet Nodes,  !- Name
+    Perimeter_bot_ZN_1 VAV Box Outlet Node Name;  !- Node 1 Name
+  NodeList,
+    Perimeter_bot_ZN_2 Inlet Nodes,  !- Name
+    Perimeter_bot_ZN_2 VAV Box Outlet Node Name;  !- Node 1 Name
+  NodeList,
+    Perimeter_bot_ZN_3 Inlet Nodes,  !- Name
+    Perimeter_bot_ZN_3 VAV Box Outlet Node Name;  !- Node 1 Name
+  NodeList,
+    Perimeter_bot_ZN_4 Inlet Nodes,  !- Name
+    Perimeter_bot_ZN_4 VAV Box Outlet Node Name;  !- Node 1 Name
+  NodeList,
+    Perimeter_mid_ZN_1 Inlet Nodes,  !- Name
+    Perimeter_mid_ZN_1 VAV Box Outlet Node Name;  !- Node 1 Name
+  NodeList,
+    Perimeter_mid_ZN_2 Inlet Nodes,  !- Name
+    Perimeter_mid_ZN_2 VAV Box Outlet Node Name;  !- Node 1 Name
+  NodeList,
+    Perimeter_mid_ZN_3 Inlet Nodes,  !- Name
+    Perimeter_mid_ZN_3 VAV Box Outlet Node Name;  !- Node 1 Name
+  NodeList,
+    Perimeter_mid_ZN_4 Inlet Nodes,  !- Name
+    Perimeter_mid_ZN_4 VAV Box Outlet Node Name;  !- Node 1 Name
+  NodeList,
+    Perimeter_top_ZN_1 Inlet Nodes,  !- Name
+    Perimeter_top_ZN_1 VAV Box Outlet Node Name;  !- Node 1 Name
+  NodeList,
+    Perimeter_top_ZN_2 Inlet Nodes,  !- Name
+    Perimeter_top_ZN_2 VAV Box Outlet Node Name;  !- Node 1 Name
+  NodeList,
+    Perimeter_top_ZN_3 Inlet Nodes,  !- Name
+    Perimeter_top_ZN_3 VAV Box Outlet Node Name;  !- Node 1 Name
+  NodeList,
+    Perimeter_top_ZN_4 Inlet Nodes,  !- Name
+    Perimeter_top_ZN_4 VAV Box Outlet Node Name;  !- Node 1 Name
+  NodeList,
+    VAV_1_OANode List,       !- Name
+    VAV_1_OAInlet Node;      !- Node 1 Name
+  NodeList,
+    VAV_2_OANode List,       !- Name
+    VAV_2_OAInlet Node;      !- Node 1 Name
+  NodeList,
+    VAV_3_OANode List,       !- Name
+    VAV_3_OAInlet Node;      !- Node 1 Name
+  NodeList,
+    VAV_5_OANode List,       !- Name
+    VAV_5_OAInlet Node;      !- Node 1 Name
+  AvailabilityManagerAssignmentList,
+    VAV_1 Availability Manager List,  !- Name
+    AvailabilityManager:NightCycle,  !- Availability Manager 1 Object Type
+    VAV_1 Availability Manager;  !- Availability Manager 1 Name
+    VAV_2 Availability Manager List,  !- Name
+    VAV_2 Availability Manager;  !- Availability Manager 1 Name
+    VAV_3 Availability Manager List,  !- Name
+    VAV_3 Availability Manager;  !- Availability Manager 1 Name
+    VAV_5 Availability Manager List,  !- Name
+    VAV_5 Availability Manager;  !- Availability Manager 1 Name
+    VAV_1 Availability Manager,  !- Name
+    ALWAYS_ON,               !- Applicability Schedule Name
+    HVACOperationSchd,       !- Fan Schedule Name
+    CycleOnAny,              !- Control Type
+    1.0,                     !- Thermostat Tolerance {deltaC}
+    1800;                    !- Cycling Run Time {s}
+    VAV_2 Availability Manager,  !- Name
+    VAV_3 Availability Manager,  !- Name
+    VAV_5 Availability Manager,  !- Name
+  BranchList,
+    VAV_1 Air Loop Branches, !- Name
+    VAV_1 Air Loop Main Branch;  !- Branch 1 Name
+  BranchList,
+    VAV_2 Air Loop Branches, !- Name
+    VAV_2 Air Loop Main Branch;  !- Branch 1 Name
+  BranchList,
+    VAV_3 Air Loop Branches, !- Name
+    VAV_3 Air Loop Main Branch;  !- Branch 1 Name
+  BranchList,
+    VAV_5 Air Loop Branches, !- Name
+    VAV_5 Air Loop Main Branch;  !- Branch 1 Name
+  Branch,
+    VAV_1 Air Loop Main Branch,  !- Name
+    ,                        !- Pressure Drop Curve Name
+    AirLoopHVAC:OutdoorAirSystem,  !- Component 1 Object Type
+    VAV_1_OA,                !- Component 1 Name
+    VAV_1 Supply Equipment Inlet Node,  !- Component 1 Inlet Node Name
+    VAV_1_OA-VAV_1_CoolCNode,!- Component 1 Outlet Node Name
+    Passive,                 !- Component 1 Branch Control Type
+    Coil:Cooling:Water,      !- Component 2 Object Type
+    VAV_1_CoolC,             !- Component 2 Name
+    VAV_1_OA-VAV_1_CoolCNode,!- Component 2 Inlet Node Name
+    VAV_1_CoolC-VAV_1_HeatCNode,  !- Component 2 Outlet Node Name
+    Passive,                 !- Component 2 Branch Control Type
+    Coil:Heating:Water,      !- Component 3 Object Type
+    VAV_1_HeatC,             !- Component 3 Name
+    VAV_1_CoolC-VAV_1_HeatCNode,  !- Component 3 Inlet Node Name
+    VAV_1_HeatC-VAV_1_FanNode,  !- Component 3 Outlet Node Name
+    Passive,                 !- Component 3 Branch Control Type
+    Fan:VariableVolume,      !- Component 4 Object Type
+    VAV_1_Fan,               !- Component 4 Name
+    VAV_1_HeatC-VAV_1_FanNode,  !- Component 4 Inlet Node Name
+    VAV_1 Supply Equipment Outlet Node,  !- Component 4 Outlet Node Name
+    Active;                  !- Component 4 Branch Control Type
+  Branch,
+    VAV_2 Air Loop Main Branch,  !- Name
+    VAV_2_OA,                !- Component 1 Name
+    VAV_2 Supply Equipment Inlet Node,  !- Component 1 Inlet Node Name
+    VAV_2_OA-VAV_2_CoolCNode,!- Component 1 Outlet Node Name
+    VAV_2_CoolC,             !- Component 2 Name
+    VAV_2_OA-VAV_2_CoolCNode,!- Component 2 Inlet Node Name
+    VAV_2_CoolC-VAV_2_HeatCNode,  !- Component 2 Outlet Node Name
+    VAV_2_HeatC,             !- Component 3 Name
+    VAV_2_CoolC-VAV_2_HeatCNode,  !- Component 3 Inlet Node Name
+    VAV_2_HeatC-VAV_2_FanNode,  !- Component 3 Outlet Node Name
+    VAV_2_Fan,               !- Component 4 Name
+    VAV_2_HeatC-VAV_2_FanNode,  !- Component 4 Inlet Node Name
+    VAV_2 Supply Equipment Outlet Node,  !- Component 4 Outlet Node Name
+  Branch,
+    VAV_3 Air Loop Main Branch,  !- Name
+    VAV_3_OA,                !- Component 1 Name
+    VAV_3 Supply Equipment Inlet Node,  !- Component 1 Inlet Node Name
+    VAV_3_OA-VAV_3_CoolCNode,!- Component 1 Outlet Node Name
+    VAV_3_CoolC,             !- Component 2 Name
+    VAV_3_OA-VAV_3_CoolCNode,!- Component 2 Inlet Node Name
+    VAV_3_CoolC-VAV_3_HeatCNode,  !- Component 2 Outlet Node Name
+    VAV_3_HeatC,             !- Component 3 Name
+    VAV_3_CoolC-VAV_3_HeatCNode,  !- Component 3 Inlet Node Name
+    VAV_3_HeatC-VAV_3_FanNode,  !- Component 3 Outlet Node Name
+    VAV_3_Fan,               !- Component 4 Name
+    VAV_3_HeatC-VAV_3_FanNode,  !- Component 4 Inlet Node Name
+    VAV_3 Supply Equipment Outlet Node,  !- Component 4 Outlet Node Name
+  Branch,
+    VAV_5 Air Loop Main Branch,  !- Name
+    VAV_5_OA,                !- Component 1 Name
+    VAV_5 Supply Equipment Inlet Node,  !- Component 1 Inlet Node Name
+    VAV_5_OA-VAV_5_CoolCNode,!- Component 1 Outlet Node Name
+    VAV_5_CoolC,             !- Component 2 Name
+    VAV_5_OA-VAV_5_CoolCNode,!- Component 2 Inlet Node Name
+    VAV_5_CoolC-VAV_5_HeatCNode,  !- Component 2 Outlet Node Name
+    VAV_5_HeatC,             !- Component 3 Name
+    VAV_5_CoolC-VAV_5_HeatCNode,  !- Component 3 Inlet Node Name
+    VAV_5_HeatC-VAV_5_FanNode,  !- Component 3 Outlet Node Name
+    VAV_5_Fan,               !- Component 4 Name
+    VAV_5_HeatC-VAV_5_FanNode,  !- Component 4 Inlet Node Name
+    VAV_5 Supply Equipment Outlet Node,  !- Component 4 Outlet Node Name
+  AirLoopHVAC:ControllerList,
+    VAV_1_Controllers,       !- Name
+    Controller:WaterCoil,    !- Controller 1 Object Type
+    VAV_1_CoolC_Controller,  !- Controller 1 Name
+    Controller:WaterCoil,    !- Controller 2 Object Type
+    VAV_1_HeatC_Controller;  !- Controller 2 Name
+    VAV_1_OA_Controllers,    !- Name
+    Controller:OutdoorAir,   !- Controller 1 Object Type
+    VAV_1_OA_Controller;     !- Controller 1 Name
+    VAV_2_Controllers,       !- Name
+    VAV_2_CoolC_Controller,  !- Controller 1 Name
+    VAV_2_HeatC_Controller;  !- Controller 2 Name
+    VAV_2_OA_Controllers,    !- Name
+    VAV_2_OA_Controller;     !- Controller 1 Name
+    VAV_3_Controllers,       !- Name
+    VAV_3_CoolC_Controller,  !- Controller 1 Name
+    VAV_3_HeatC_Controller;  !- Controller 2 Name
+    VAV_3_OA_Controllers,    !- Name
+    VAV_3_OA_Controller;     !- Controller 1 Name
+    VAV_5_Controllers,       !- Name
+    VAV_5_CoolC_Controller,  !- Controller 1 Name
+    VAV_5_HeatC_Controller;  !- Controller 2 Name
+    VAV_5_OA_Controllers,    !- Name
+    VAV_5_OA_Controller;     !- Controller 1 Name
+  AirLoopHVAC:OutdoorAirSystem:EquipmentList,
+    VAV_1_OA_Equipment,      !- Name
+    OutdoorAir:Mixer,        !- Component 1 Object Type
+    VAV_1_OAMixing Box;      !- Component 1 Name
+    VAV_2_OA_Equipment,      !- Name
+    VAV_2_OAMixing Box;      !- Component 1 Name
+    VAV_3_OA_Equipment,      !- Name
+    VAV_3_OAMixing Box;      !- Component 1 Name
+    VAV_5_OA_Equipment,      !- Name
+    VAV_5_OAMixing Box;      !- Component 1 Name
+    VAV_1_OA,                !- Name
+    VAV_1_OA_Controllers,    !- Controller List Name
+    VAV_1_OA_Equipment,      !- Outdoor Air Equipment List Name
+    VAV_1 Availability Manager List;  !- Availability Manager List Name
+    VAV_2_OA,                !- Name
+    VAV_2_OA_Controllers,    !- Controller List Name
+    VAV_2_OA_Equipment,      !- Outdoor Air Equipment List Name
+    VAV_2 Availability Manager List;  !- Availability Manager List Name
+    VAV_3_OA,                !- Name
+    VAV_3_OA_Controllers,    !- Controller List Name
+    VAV_3_OA_Equipment,      !- Outdoor Air Equipment List Name
+    VAV_3 Availability Manager List;  !- Availability Manager List Name
+    VAV_5_OA,                !- Name
+    VAV_5_OA_Controllers,    !- Controller List Name
+    VAV_5_OA_Equipment,      !- Outdoor Air Equipment List Name
+    VAV_5 Availability Manager List;  !- Availability Manager List Name
+  OutdoorAir:NodeList,
+    VAV_1_OANode List;       !- Node or NodeList Name 1
+    VAV_2_OANode List;       !- Node or NodeList Name 1
+    VAV_3_OANode List;       !- Node or NodeList Name 1
+    VAV_5_OANode List;       !- Node or NodeList Name 1
+  OutdoorAir:Mixer,
+    VAV_1_OAMixing Box,      !- Name
+    VAV_1_OAInlet Node,      !- Outdoor Air Stream Node Name
+    VAV_1_OARelief Node,     !- Relief Air Stream Node Name
+    VAV_1 Supply Equipment Inlet Node;  !- Return Air Stream Node Name
+  OutdoorAir:Mixer,
+    VAV_2_OAMixing Box,      !- Name
+    VAV_2_OAInlet Node,      !- Outdoor Air Stream Node Name
+    VAV_2_OARelief Node,     !- Relief Air Stream Node Name
+    VAV_2 Supply Equipment Inlet Node;  !- Return Air Stream Node Name
+  OutdoorAir:Mixer,
+    VAV_3_OAMixing Box,      !- Name
+    VAV_3_OAInlet Node,      !- Outdoor Air Stream Node Name
+    VAV_3_OARelief Node,     !- Relief Air Stream Node Name
+    VAV_3 Supply Equipment Inlet Node;  !- Return Air Stream Node Name
+  OutdoorAir:Mixer,
+    VAV_5_OAMixing Box,      !- Name
+    VAV_5_OAInlet Node,      !- Outdoor Air Stream Node Name
+    VAV_5_OARelief Node,     !- Relief Air Stream Node Name
+    VAV_5 Supply Equipment Inlet Node;  !- Return Air Stream Node Name
+  SetpointManager:MixedAir,
+    VAV_1_CoolC SAT Manager, !- Name
+    VAV_1 Supply Equipment Outlet Node,  !- Reference Setpoint Node Name
+    VAV_1_HeatC-VAV_1_FanNode,  !- Fan Inlet Node Name
+    VAV_1 Supply Equipment Outlet Node,  !- Fan Outlet Node Name
+    VAV_1_CoolC-VAV_1_HeatCNode;  !- Setpoint Node or NodeList Name
+    VAV_1_HeatC SAT Manager, !- Name
+    VAV_1_HeatC-VAV_1_FanNode;  !- Setpoint Node or NodeList Name
+    VAV_1_OAMixed Air Temp Manager,  !- Name
+    VAV_1_OA-VAV_1_CoolCNode;!- Setpoint Node or NodeList Name
+    VAV_2_CoolC SAT Manager, !- Name
+    VAV_2 Supply Equipment Outlet Node,  !- Reference Setpoint Node Name
+    VAV_2_HeatC-VAV_2_FanNode,  !- Fan Inlet Node Name
+    VAV_2 Supply Equipment Outlet Node,  !- Fan Outlet Node Name
+    VAV_2_CoolC-VAV_2_HeatCNode;  !- Setpoint Node or NodeList Name
+    VAV_2_HeatC SAT Manager, !- Name
+    VAV_2_HeatC-VAV_2_FanNode;  !- Setpoint Node or NodeList Name
+    VAV_2_OAMixed Air Temp Manager,  !- Name
+    VAV_2_OA-VAV_2_CoolCNode;!- Setpoint Node or NodeList Name
+    VAV_3_CoolC SAT Manager, !- Name
+    VAV_3 Supply Equipment Outlet Node,  !- Reference Setpoint Node Name
+    VAV_3_HeatC-VAV_3_FanNode,  !- Fan Inlet Node Name
+    VAV_3 Supply Equipment Outlet Node,  !- Fan Outlet Node Name
+    VAV_3_CoolC-VAV_3_HeatCNode;  !- Setpoint Node or NodeList Name
+    VAV_3_HeatC SAT Manager, !- Name
+    VAV_3_HeatC-VAV_3_FanNode;  !- Setpoint Node or NodeList Name
+    VAV_3_OAMixed Air Temp Manager,  !- Name
+    VAV_3_OA-VAV_3_CoolCNode;!- Setpoint Node or NodeList Name
+    VAV_5_CoolC SAT Manager, !- Name
+    VAV_5 Supply Equipment Outlet Node,  !- Reference Setpoint Node Name
+    VAV_5_HeatC-VAV_5_FanNode,  !- Fan Inlet Node Name
+    VAV_5 Supply Equipment Outlet Node,  !- Fan Outlet Node Name
+    VAV_5_CoolC-VAV_5_HeatCNode;  !- Setpoint Node or NodeList Name
+    VAV_5_HeatC SAT Manager, !- Name
+    VAV_5_HeatC-VAV_5_FanNode;  !- Setpoint Node or NodeList Name
+    VAV_5_OAMixed Air Temp Manager,  !- Name
+    VAV_5_OA-VAV_5_CoolCNode;!- Setpoint Node or NodeList Name
+  AirLoopHVAC:SupplyPath,
+    VAV_1,                   !- Name
+    VAV_1 Zone Equipment Inlet Node,  !- Supply Air Path Inlet Node Name
+    AirLoopHVAC:ZoneSplitter,!- Component 1 Object Type
+    VAV_1 Supply Air Splitter;  !- Component 1 Name
+    VAV_2,                   !- Name
+    VAV_2 Zone Equipment Inlet Node,  !- Supply Air Path Inlet Node Name
+    VAV_2 Supply Air Splitter;  !- Component 1 Name
+    VAV_3,                   !- Name
+    VAV_3 Zone Equipment Inlet Node,  !- Supply Air Path Inlet Node Name
+    VAV_3 Supply Air Splitter;  !- Component 1 Name
+    VAV_5,                   !- Name
+    VAV_5 Zone Equipment Inlet Node,  !- Supply Air Path Inlet Node Name
+    VAV_5 Supply Air Splitter;  !- Component 1 Name
+    VAV_1 Supply Air Splitter,  !- Name
+    VAV_1 Zone Equipment Inlet Node,  !- Inlet Node Name
+    Core_bottom VAV Box Inlet Node Name,  !- Outlet 1 Node Name
+    Perimeter_bot_ZN_3 VAV Box Inlet Node Name,  !- Outlet 2 Node Name
+    Perimeter_bot_ZN_2 VAV Box Inlet Node Name,  !- Outlet 3 Node Name
+    Perimeter_bot_ZN_1 VAV Box Inlet Node Name,  !- Outlet 4 Node Name
+    Perimeter_bot_ZN_4 VAV Box Inlet Node Name;  !- Outlet 5 Node Name
+    VAV_2 Supply Air Splitter,  !- Name
+    VAV_2 Zone Equipment Inlet Node,  !- Inlet Node Name
+    Core_mid VAV Box Inlet Node Name,  !- Outlet 1 Node Name
+    Perimeter_mid_ZN_3 VAV Box Inlet Node Name,  !- Outlet 2 Node Name
+    Perimeter_mid_ZN_2 VAV Box Inlet Node Name,  !- Outlet 3 Node Name
+    Perimeter_mid_ZN_1 VAV Box Inlet Node Name,  !- Outlet 4 Node Name
+    Perimeter_mid_ZN_4 VAV Box Inlet Node Name;  !- Outlet 5 Node Name
+    VAV_3 Supply Air Splitter,  !- Name
+    VAV_3 Zone Equipment Inlet Node,  !- Inlet Node Name
+    Core_top VAV Box Inlet Node Name,  !- Outlet 1 Node Name
+    Perimeter_top_ZN_3 VAV Box Inlet Node Name,  !- Outlet 2 Node Name
+    Perimeter_top_ZN_2 VAV Box Inlet Node Name,  !- Outlet 3 Node Name
+    Perimeter_top_ZN_1 VAV Box Inlet Node Name,  !- Outlet 4 Node Name
+    Perimeter_top_ZN_4 VAV Box Inlet Node Name;  !- Outlet 5 Node Name
+    VAV_5 Supply Air Splitter,  !- Name
+    VAV_5 Zone Equipment Inlet Node,  !- Inlet Node Name
+    Basement VAV Box Inlet Node Name;  !- Outlet 1 Node Name
+  AirLoopHVAC:ReturnPath,
+    VAV_1 Return Air Path,   !- Name
+    VAV_1 Zone Equipment Outlet Node,  !- Return Air Path Outlet Node Name
+    AirLoopHVAC:ReturnPlenum,!- Component 1 Object Type
+    VAV_1 Return Plenum,     !- Component 1 Name
+    AirLoopHVAC:ZoneMixer,   !- Component 2 Object Type
+    VAV_1 Return Air Mixer;  !- Component 2 Name
+    VAV_2 Return Air Path,   !- Name
+    VAV_2 Zone Equipment Outlet Node,  !- Return Air Path Outlet Node Name
+    VAV_2 Return Plenum,     !- Component 1 Name
+    VAV_2 Return Air Mixer;  !- Component 2 Name
+    VAV_3 Return Air Path,   !- Name
+    VAV_3 Zone Equipment Outlet Node,  !- Return Air Path Outlet Node Name
+    VAV_3 Return Plenum,     !- Component 1 Name
+    VAV_3 Return Air Mixer;  !- Component 2 Name
+    VAV_5 Return Air Path,   !- Name
+    VAV_5 Zone Equipment Outlet Node,  !- Return Air Path Outlet Node Name
+    AirLoopHVAC:ZoneMixer,   !- Component 1 Object Type
+    VAV_5 Return Air Mixer;  !- Component 1 Name
+    VAV_2 Return Plenum,     !- Name
+    MidFloor_Plenum,         !- Zone Name
+    MIDFLOOR_PLENUMPlenumNode,  !- Zone Node Name
+    MIDFLOOR_PLENUMPlenumOutletNode,  !- Outlet Node Name
+    ,                        !- Induced Air Outlet Node or NodeList Name
+    Core_mid Return Air Node Name,  !- Inlet 1 Node Name
+    Perimeter_mid_ZN_3 Return Air Node Name,  !- Inlet 2 Node Name
+    Perimeter_mid_ZN_2 Return Air Node Name,  !- Inlet 3 Node Name
+    Perimeter_mid_ZN_1 Return Air Node Name,  !- Inlet 4 Node Name
+    Perimeter_mid_ZN_4 Return Air Node Name;  !- Inlet 5 Node Name
+    VAV_1 Return Plenum,     !- Name
+    GroundFloor_Plenum,      !- Zone Name
+    GROUNDFLOOR_PLENUMPlenumNode,  !- Zone Node Name
+    GROUNDFLOOR_PLENUMPlenumOutletNode,  !- Outlet Node Name
+    Core_bottom Return Air Node Name,  !- Inlet 1 Node Name
+    Perimeter_bot_ZN_3 Return Air Node Name,  !- Inlet 2 Node Name
+    Perimeter_bot_ZN_2 Return Air Node Name,  !- Inlet 3 Node Name
+    Perimeter_bot_ZN_1 Return Air Node Name,  !- Inlet 4 Node Name
+    Perimeter_bot_ZN_4 Return Air Node Name;  !- Inlet 5 Node Name
+    VAV_3 Return Plenum,     !- Name
+    TopFloor_Plenum,         !- Zone Name
+    TOPFLOOR_PLENUMPlenumNode,  !- Zone Node Name
+    TOPFLOOR_PLENUMPlenumOutletNode,  !- Outlet Node Name
+    Core_top Return Air Node Name,  !- Inlet 1 Node Name
+    Perimeter_top_ZN_3 Return Air Node Name,  !- Inlet 2 Node Name
+    Perimeter_top_ZN_2 Return Air Node Name,  !- Inlet 3 Node Name
+    Perimeter_top_ZN_1 Return Air Node Name,  !- Inlet 4 Node Name
+    Perimeter_top_ZN_4 Return Air Node Name;  !- Inlet 5 Node Name
+    VAV_1 Return Air Mixer,  !- Name
+    VAV_1 Zone Equipment Outlet Node,  !- Outlet Node Name
+    GROUNDFLOOR_PLENUMPlenumOutletNode;  !- Inlet 1 Node Name
+    VAV_2 Return Air Mixer,  !- Name
+    VAV_2 Zone Equipment Outlet Node,  !- Outlet Node Name
+    MIDFLOOR_PLENUMPlenumOutletNode;  !- Inlet 1 Node Name
+    VAV_3 Return Air Mixer,  !- Name
+    VAV_3 Zone Equipment Outlet Node,  !- Outlet Node Name
+    TOPFLOOR_PLENUMPlenumOutletNode;  !- Inlet 1 Node Name
+    VAV_5 Return Air Mixer,  !- Name
+    VAV_5 Zone Equipment Outlet Node,  !- Outlet Node Name
+    Basement Return Air Node Name;  !- Inlet 1 Node Name
+! ***SCHEDULES***
+  Schedule:Compact,
+    CLGSETP_SCH,             !- Name
+    Temperature,             !- Schedule Type Limits Name
+    Through: 12/31,          !- Field 1
+    Until: 06:00,26.7,       !- Field 3
+    Until: 22:00,24.0,       !- Field 5
+    Until: 24:00,26.7,       !- Field 7
+    For: Saturday,           !- Field 9
+    Until: 06:00,26.7,       !- Field 10
+    Until: 18:00,24.0,       !- Field 12
+    Until: 24:00,26.7,       !- Field 14
+    For WinterDesignDay,     !- Field 16
+    Until: 24:00,26.7,       !- Field 17
+    For: AllOtherDays,       !- Field 19
+    Until: 24:00,26.7;       !- Field 20
+  Schedule:Compact,
+    HTGSETP_SCH,             !- Name
+    Until: 06:00,15.6,       !- Field 3
+    Until: 22:00,21.0,       !- Field 5
+    Until: 24:00,15.6,       !- Field 7
+    For SummerDesignDay,     !- Field 9
+    Until: 24:00,15.6,       !- Field 10
+    For: Saturday,           !- Field 12
+    Until: 06:00,15.6,       !- Field 13
+    Until: 18:00,21.0,       !- Field 15
+    Until: 24:00,15.6,       !- Field 17
+    For: WinterDesignDay,    !- Field 19
+    Until: 24:00,21.0,       !- Field 20
+    For: AllOtherDays,       !- Field 22
+    Until: 24:00,15.6;       !- Field 23
+  Schedule:Compact,
+    Seasonal-Reset-Supply-Air-Temp-Sch,  !- Name
+    For: AllDays,            !- Field 2
+    Until: 24:00,12.8;       !- Field 3
+  Schedule:Compact,
+    MinOA_MotorizedDamper_Sched,  !- Name
+    Until: 07:00,0.0,        !- Field 3
+    Until: 24:00,0.0,        !- Field 7
+    Until: 07:00,0.0,        !- Field 10
+    Until: 18:00,1.0,        !- Field 12
+    Until: 24:00,0.0,        !- Field 14
+    For: AllOtherDays,       !- Field 16
+    Until: 24:00,0.0;        !- Field 17
+  Schedule:Compact,
+    Dual Zone Control Type Sched,  !- Name
+    Control Type,            !- Schedule Type Limits Name
+    Until: 24:00,4;          !- Field 3
+  Schedule:Compact,
+    HVACOperationSchd,       !- Name
+    On/Off,                  !- Schedule Type Limits Name
+! ***EQUIPMENT***
+ Output:PreprocessorMessage,Conversion 7.2 => 8.0,Warning,
+Boiler:HotWater="HeatSys1 Boiler",
+ defaults for this object have changed. Results may be different than previous. See ,
+InputOutputReference document for details.;
+  Boiler:HotWater,
+    HeatSys1 Boiler,         !- Name
+    NATURALGAS,              !- Fuel Type
+    AUTOSIZE,                !- Nominal Capacity {W}
+    0.78,                    !- Nominal Thermal Efficiency
+    LeavingBoiler,           !- Efficiency Curve Temperature Evaluation Variable
+    ,                        !- Normalized Boiler Efficiency Curve Name
+    82.2000,                 !- Design Water Outlet Temperature {C}
+    0.0,                     !- Minimum Part Load Ratio
+    1.2,                     !- Maximum Part Load Ratio
+    1.0,                     !- Optimum Part Load Ratio
+    HeatSys1 Pump-HeatSys1 BoilerNode,  !- Boiler Water Inlet Node Name
+    HeatSys1 Supply Equipment Outlet Node,  !- Boiler Water Outlet Node Name
+    95.0,                    !- Water Outlet Upper Temperature Limit {C}
+    LeavingSetpointModulated,!- Boiler Flow Mode
+    0.0000,                  !- Parasitic Electric Load {W}
+    1.0000;                  !- Sizing Factor
+    HeatSys1 Boiler Setpoint Manager,  !- Name
+    HW-Loop-Temp-Schedule,   !- Schedule Name
+    HeatSys1 Supply Equipment Outlet Node;  !- Setpoint Node or NodeList Name
+Chiller:Electric:ReformulatedEIR="CoolSys1 Chiller 1",
+ defaults for this object have changed. See InputOutputReference document for details.;
+  Chiller:Electric:ReformulatedEIR,
+    CoolSys1 Chiller 1,      !- Name
+    AUTOSIZE,                !- Reference Capacity {W}
+    5.5,                     !- Reference COP {W/W}
+    6.67,                    !- Reference Leaving Chilled Water Temperature {C}
+    35,                      !- Reference Leaving Condenser Water Temperature {C}
+    AutoSize,                !- Reference Chilled Water Flow Rate {m3/s}
+    AutoSize,                !- Reference Condenser Water Flow Rate {m3/s}
+    WC Screw Default 90.1-2004 Cap_fT,  !- Cooling Capacity Function of Temperature Curve Name
+    WC Screw Default 90.1-2004 EIR_fT,  !- Electric Input to Cooling Output Ratio Function of Temperature Curve Name
+    WC Screw GTE 300tons Default 90.1-2004 EIR_fPLR,  !- Electric Input to Cooling Output Ratio Function of Part Load Ratio Curve Name
+    0.1,                     !- Minimum Part Load Ratio
+    1,                       !- Maximum Part Load Ratio
+    1,                       !- Optimum Part Load Ratio
+    0.2,                     !- Minimum Unloading Ratio
+    CoolSys1 Pump-CoolSys1 ChillerNode 1,  !- Chilled Water Inlet Node Name
+    CoolSys1 Supply Equipment Outlet Node 1,  !- Chilled Water Outlet Node Name
+    CoolSys1 Chiller Water Inlet Node 1,  !- Condenser Inlet Node Name
+    CoolSys1 Chiller Water Outlet Node 1,  !- Condenser Outlet Node Name
+    1,                       !- Fraction of Compressor Electric Consumption Rejected by Condenser
+    2,                       !- Leaving Chilled Water Lower Temperature Limit {C}
+    LeavingSetpointModulated,!- Chiller Flow Mode Type
+    ,                        !- Design Heat Recovery Water Flow Rate {m3/s}
+    ,                        !- Heat Recovery Inlet Node Name
+    ,                        !- Heat Recovery Outlet Node Name
+    0.4;                     !- Sizing Factor
+    CoolSys1 Chiller 1 Setpoint Manager,  !- Name
+    CW-Loop-Temp-Schedule,   !- Schedule Name
+    CoolSys1 Supply Equipment Outlet Node 1;  !- Setpoint Node or NodeList Name
+Chiller:Electric:ReformulatedEIR="CoolSys1 Chiller 2",
+    CoolSys1 Chiller 2,      !- Name
+    CoolSys1 Pump-CoolSys1 ChillerNode 2,  !- Chilled Water Inlet Node Name
+    CoolSys1 Supply Equipment Outlet Node 2,  !- Chilled Water Outlet Node Name
+    CoolSys1 Chiller Water Inlet Node 2,  !- Condenser Inlet Node Name
+    CoolSys1 Chiller Water Outlet Node 2,  !- Condenser Outlet Node Name
+    CoolSys1 Chiller 2 Setpoint Manager,  !- Name
+    CoolSys1 Supply Equipment Outlet Node 2;  !- Setpoint Node or NodeList Name
+  CoolingTower:SingleSpeed,
+    TowerWaterSys CoolTower, !- Name
+    TowerWaterSys Pump-TowerWaterSys CoolTowerNode,  !- Water Inlet Node Name
+    TowerWaterSys Supply Equipment Outlet Node,  !- Water Outlet Node Name
+    AUTOSIZE,                !- Fan Power at Design Air Flow Rate {W}
+    AUTOSIZE,                !- U-Factor Times Area Value at Design Air Flow Rate {W/K}
+    AUTOSIZE,                !- Air Flow Rate in Free Convection Regime {m3/s}
+    AUTOSIZE,                !- U-Factor Times Area Value at Free Convection Air Flow Rate {W/K}
+    ,                        !- Nominal Capacity {W}
+    ,                        !- Free Convection Capacity {W}
+    ,                        !- Basin Heater Capacity {W/K}
+    ,                        !- Basin Heater Setpoint Temperature {C}
+    ,                        !- Basin Heater Operating Schedule Name
+    SaturatedExit,           !- Evaporation Loss Mode
+    ,                        !- Evaporation Loss Factor {percent/K}
+    0.0080,                  !- Drift Loss Percent {percent}
+    ConcentrationRatio,      !- Blowdown Calculation Mode
+    3.0000,                  !- Blowdown Concentration Ratio
+    ,                        !- Blowdown Makeup Water Usage Schedule Name
+    ,                        !- Supply Water Storage Tank Name
+    TowerWaterSys CoolTower OA ref Node,  !- Outdoor Air Inlet Node Name
+    FanCycling,              !- Capacity Control
+    ,                        !- Number of Cells
+    ,                        !- Cell Control
+    ,                        !- Cell Minimum  Water Flow Rate Fraction
+    ,                        !- Cell Maximum Water Flow Rate Fraction
+  Pump:VariableSpeed,
+    CoolSys1 Pump,           !- Name
+    CoolSys1 Supply Inlet Node,  !- Inlet Node Name
+    CoolSys1 Pump-CoolSys1 ChillerNodeviaConnector,  !- Outlet Node Name
+    AUTOSIZE,                !- Rated Flow Rate {m3/s}
+    179352,                  !- Rated Pump Head {Pa}
+    AUTOSIZE,                !- Rated Power Consumption {W}
+    0.9,                     !- Motor Efficiency
+    0.0,                     !- Fraction of Motor Inefficiencies to Fluid Stream
+    0,                       !- Coefficient 1 of the Part Load Performance Curve
+    1,                       !- Coefficient 2 of the Part Load Performance Curve
+    0,                       !- Coefficient 3 of the Part Load Performance Curve
+    0,                       !- Coefficient 4 of the Part Load Performance Curve
+    0.0,                     !- Minimum Flow Rate {m3/s}
+    Intermittent,            !- Pump Control Type
+    ;                        !- Pump Flow Rate Schedule Name
+    HeatSys1 Pump,           !- Name
+    HeatSys1 Supply Inlet Node,  !- Inlet Node Name
+    HeatSys1 Pump-HeatSys1 BoilerNodeviaConnector,  !- Outlet Node Name
+    0.875,                   !- Motor Efficiency
+  Pump:ConstantSpeed,
+    TowerWaterSys Pump,      !- Name
+    TowerWaterSys Supply Inlet Node,  !- Inlet Node Name
+    TowerWaterSys Pump-TowerWaterSys CoolTowerNodeviaConnector,  !- Outlet Node Name
+    0.87,                    !- Motor Efficiency
+  PlantEquipmentList,
+    CoolSys1 Equipment List, !- Name
+    Chiller:Electric:ReformulatedEIR,  !- Equipment 1 Object Type
+    CoolSys1 Chiller 1,      !- Equipment 1 Name
+    Chiller:Electric:ReformulatedEIR,  !- Equipment 2 Object Type
+    CoolSys1 Chiller 2;      !- Equipment 2 Name
+    HeatSys1 Equipment List, !- Name
+    Boiler:HotWater,         !- Equipment 1 Object Type
+    HeatSys1 Boiler;         !- Equipment 1 Name
+  CondenserEquipmentList,
+    TowerWaterSys Equipment List,  !- Name
+    CoolingTower:SingleSpeed,!- Equipment 1 Object Type
+    TowerWaterSys CoolTower; !- Equipment 1 Name
+  Sizing:Plant,
+    CoolSys1,                !- Plant or Condenser Loop Name
+    Cooling,                 !- Loop Type
+    6.67,                    !- Design Loop Exit Temperature {C}
+    6.67;                    !- Loop Design Temperature Difference {deltaC}
+  Sizing:Plant,
+    HeatSys1,                !- Plant or Condenser Loop Name
+    Heating,                 !- Loop Type
+    82.2,                    !- Design Loop Exit Temperature {C}
+    11.1;                    !- Loop Design Temperature Difference {deltaC}
+  Sizing:Plant,
+    TowerWaterSys,           !- Plant or Condenser Loop Name
+    CONDENSER,               !- Loop Type
+    29.4,                    !- Design Loop Exit Temperature {C}
+    5.6;                     !- Loop Design Temperature Difference {deltaC}
+    VAV_1_CoolC_Controller,  !- Name
+    Reverse,                 !- Action
+    Flow,                    !- Actuator Variable
+    VAV_1_CoolC-VAV_1_HeatCNode,  !- Sensor Node Name
+    VAV_1_CoolCDemand Inlet Node,  !- Actuator Node Name
+    ,                        !- Controller Convergence Tolerance {deltaC}
+    AUTOSIZE,                !- Maximum Actuated Flow {m3/s}
+    0.0;                     !- Minimum Actuated Flow {m3/s}
+    VAV_1_HeatC_Controller,  !- Name
+    Normal,                  !- Action
+    VAV_1_HeatC-VAV_1_FanNode,  !- Sensor Node Name
+    VAV_1_HeatCDemand Inlet Node,  !- Actuator Node Name
+    0.0001,                  !- Controller Convergence Tolerance {deltaC}
+    VAV_2_CoolC_Controller,  !- Name
+    VAV_2_CoolC-VAV_2_HeatCNode,  !- Sensor Node Name
+    VAV_2_CoolCDemand Inlet Node,  !- Actuator Node Name
+    VAV_2_HeatC_Controller,  !- Name
+    Normal,                  !- Action
+    VAV_2_HeatC-VAV_2_FanNode,  !- Sensor Node Name
+    VAV_2_HeatCDemand Inlet Node,  !- Actuator Node Name
+    VAV_3_CoolC_Controller,  !- Name
+    VAV_3_CoolC-VAV_3_HeatCNode,  !- Sensor Node Name
+    VAV_3_CoolCDemand Inlet Node,  !- Actuator Node Name
+    VAV_3_HeatC_Controller,  !- Name
+    Normal,                  !- Action
+    VAV_3_HeatC-VAV_3_FanNode,  !- Sensor Node Name
+    VAV_3_HeatCDemand Inlet Node,  !- Actuator Node Name
+    VAV_5_CoolC_Controller,  !- Name
+    VAV_5_CoolC-VAV_5_HeatCNode,  !- Sensor Node Name
+    VAV_5_CoolCDemand Inlet Node,  !- Actuator Node Name
+    VAV_5_HeatC_Controller,  !- Name
+    Normal,                  !- Action
+    VAV_5_HeatC-VAV_5_FanNode,  !- Sensor Node Name
+    VAV_5_HeatCDemand Inlet Node,  !- Actuator Node Name
+! Curve adapted by R. Lord for ANSI/ASHRAE/IESNA 90.1-2004 performance
+! for a water-cooled, screw/scroll chiller
+  Curve:Biquadratic,
+    WC Screw Default 90.1-2004 Cap_fT,  !- Name
+    0.9061150,               !- Coefficient1 Constant
+    0.0292277,               !- Coefficient2 x
+    -0.0003647,              !- Coefficient3 x**2
+    -0.0009709,              !- Coefficient4 y
+    -0.0000905,              !- Coefficient5 y**2
+    0.0002527,               !- Coefficient6 x*y
+    0.0,                     !- Minimum Value of x
+    20.0,                    !- Maximum Value of x
+    0.0,                     !- Minimum Value of y
+    50.0;                    !- Maximum Value of y
+    WC Screw Default 90.1-2004 EIR_fT,  !- Name
+    0.3617105,               !- Coefficient1 Constant
+    -0.0229833,              !- Coefficient2 x
+    -0.0009519,              !- Coefficient3 x**2
+    0.0131889,               !- Coefficient4 y
+    0.0003752,               !- Coefficient5 y**2
+    -0.0007059,              !- Coefficient6 x*y
+    CoolSys1 Loop Setpoint Manager,  !- Name
+    CoolSys1 Supply Outlet Node;  !- Setpoint Node or NodeList Name
+    HeatSys1 Loop Setpoint Manager,  !- Name
+    HeatSys1 Supply Outlet Node;  !- Setpoint Node or NodeList Name
+  PlantEquipmentOperationSchemes,
+    CoolSys1 Loop Operation Scheme List,  !- Name
+    PlantEquipmentOperation:CoolingLoad,  !- Control Scheme 1 Object Type
+    CoolSys1 Operation Scheme,  !- Control Scheme 1 Name
+    ALWAYS_ON;               !- Control Scheme 1 Schedule Name
+    HeatSys1 Loop Operation Scheme List,  !- Name
+    PlantEquipmentOperation:HeatingLoad,  !- Control Scheme 1 Object Type
+    HeatSys1 Operation Scheme,  !- Control Scheme 1 Name
+  CondenserEquipmentOperationSchemes,
+    TowerWaterSys Loop Operation Scheme List,  !- Name
+    TowerWaterSys Operation Scheme,  !- Control Scheme 1 Name
+    HeatSys1 Operation Scheme,  !- Name
+    0.0,                     !- Load Range 1 Lower Limit {W}
+    1000000000000000,        !- Load Range 1 Upper Limit {W}
+    HeatSys1 Equipment List; !- Range 1 Equipment List Name
+    CoolSys1 Operation Scheme,  !- Name
+    100000000000000,         !- Load Range 1 Upper Limit {W}
+    CoolSys1 Equipment List; !- Range 1 Equipment List Name
+    TowerWaterSys Operation Scheme,  !- Name
+    1000000000000,           !- Load Range 1 Upper Limit {W}
+    TowerWaterSys Equipment List;  !- Range 1 Equipment List Name
+! ***LOOPS***
+  PlantLoop,
+    CoolSys1,                !- Name
+    Water,                   !- Fluid Type
+    ,                        !- User Defined Fluid Type
+    CoolSys1 Loop Operation Scheme List,  !- Plant Equipment Operation Scheme Name
+    CoolSys1 Supply Outlet Node,  !- Loop Temperature Setpoint Node Name
+    98.0,                    !- Maximum Loop Temperature {C}
+    1.0,                     !- Minimum Loop Temperature {C}
+    AUTOSIZE,                !- Maximum Loop Flow Rate {m3/s}
+    0.0,                     !- Minimum Loop Flow Rate {m3/s}
+    AUTOSIZE,                !- Plant Loop Volume {m3}
+    CoolSys1 Supply Inlet Node,  !- Plant Side Inlet Node Name
+    CoolSys1 Supply Outlet Node,  !- Plant Side Outlet Node Name
+    CoolSys1 Supply Branches,!- Plant Side Branch List Name
+    CoolSys1 Supply Connectors,  !- Plant Side Connector List Name
+    CoolSys1 Demand Inlet Node,  !- Demand Side Inlet Node Name
+    CoolSys1 Demand Outlet Node,  !- Demand Side Outlet Node Name
+    CoolSys1 Demand Branches,!- Demand Side Branch List Name
+    CoolSys1 Demand Connectors,  !- Demand Side Connector List Name
+    Uniform;                 !- Load Distribution Scheme
+  PlantLoop,
+    HeatSys1,                !- Name
+    HeatSys1 Loop Operation Scheme List,  !- Plant Equipment Operation Scheme Name
+    HeatSys1 Supply Outlet Node,  !- Loop Temperature Setpoint Node Name
+    100.0,                   !- Maximum Loop Temperature {C}
+    10.0,                    !- Minimum Loop Temperature {C}
+    HeatSys1 Supply Inlet Node,  !- Plant Side Inlet Node Name
+    HeatSys1 Supply Outlet Node,  !- Plant Side Outlet Node Name
+    HeatSys1 Supply Branches,!- Plant Side Branch List Name
+    HeatSys1 Supply Connectors,  !- Plant Side Connector List Name
+    HeatSys1 Demand Inlet Node,  !- Demand Side Inlet Node Name
+    HeatSys1 Demand Outlet Node,  !- Demand Side Outlet Node Name
+    HeatSys1 Demand Branches,!- Demand Side Branch List Name
+    HeatSys1 Demand Connectors,  !- Demand Side Connector List Name
+    Optimal;                 !- Load Distribution Scheme
+  CondenserLoop,
+    TowerWaterSys,           !- Name
+    TowerWaterSys Loop Operation Scheme List,  !- Condenser Equipment Operation Scheme Name
+    TowerWaterSys Supply Outlet Node,  !- Condenser Loop Temperature Setpoint Node Name
+    80.0,                    !- Maximum Loop Temperature {C}
+    5.0,                     !- Minimum Loop Temperature {C}
+    AUTOSIZE,                !- Condenser Loop Volume {m3}
+    TowerWaterSys Supply Inlet Node,  !- Condenser Side Inlet Node Name
+    TowerWaterSys Supply Outlet Node,  !- Condenser Side Outlet Node Name
+    TowerWaterSys Supply Branches,  !- Condenser Side Branch List Name
+    TowerWaterSys Supply Connectors,  !- Condenser Side Connector List Name
+    TowerWaterSys Demand Inlet Node,  !- Demand Side Inlet Node Name
+    TowerWaterSys Demand Outlet Node,  !- Demand Side Outlet Node Name
+    TowerWaterSys Demand Branches,  !- Condenser Demand Side Branch List Name
+    TowerWaterSys Demand Connectors,  !- Condenser Demand Side Connector List Name
+    Sequential;              !- Load Distribution Scheme
+  SetpointManager:FollowOutdoorAirTemperature,
+    OutdoorAirWetBulb,       !- Reference Temperature Type
+    0,                       !- Offset Temperature Difference {deltaC}
+    80.0,                    !- Maximum Setpoint Temperature {C}
+    5.0,                     !- Minimum Setpoint Temperature {C}
+    TowerWaterSys Supply Outlet Node;  !- Setpoint Node or NodeList Name
+  BranchList,
+    CoolSys1 Demand Branches,!- Name
+    CoolSys1 Demand Inlet Branch,  !- Branch 1 Name
+    CoolSys1 Demand Load Branch 1,  !- Branch 2 Name
+    CoolSys1 Demand Load Branch 2,  !- Branch 3 Name
+    CoolSys1 Demand Load Branch 3,  !- Branch 4 Name
+    CoolSys1 Demand Load Branch 4,  !- Branch 5 Name
+    CoolSys1 Demand Bypass Branch,  !- Branch 6 Name
+    CoolSys1 Demand Outlet Branch;  !- Branch 7 Name
+  BranchList,
+    CoolSys1 Supply Branches,!- Name
+    CoolSys1 Supply Inlet Branch,  !- Branch 1 Name
+    CoolSys1 Supply Equipment Branch 1,  !- Branch 2 Name
+    CoolSys1 Supply Equipment Branch 2,  !- Branch 3 Name
+    CoolSys1 Supply Equipment Bypass Branch,  !- Branch 4 Name
+    CoolSys1 Supply Outlet Branch;  !- Branch 5 Name
+  BranchList,
+    HeatSys1 Demand Branches,!- Name
+    HeatSys1 Demand Inlet Branch,  !- Branch 1 Name
+    HeatSys1 Demand Load Branch 1,  !- Branch 2 Name
+    HeatSys1 Demand Load Branch 2,  !- Branch 3 Name
+    HeatSys1 Demand Load Branch 3,  !- Branch 4 Name
+    HeatSys1 Demand Load Branch 4,  !- Branch 5 Name
+    HeatSys1 Demand Load Branch 5,  !- Branch 6 Name
+    HeatSys1 Demand Load Branch 6,  !- Branch 7 Name
+    HeatSys1 Demand Load Branch 7,  !- Branch 8 Name
+    HeatSys1 Demand Load Branch 8,  !- Branch 9 Name
+    HeatSys1 Demand Load Branch 9,  !- Branch 10 Name
+    HeatSys1 Demand Load Branch 10,  !- Branch 11 Name
+    HeatSys1 Demand Load Branch 11,  !- Branch 12 Name
+    HeatSys1 Demand Load Branch 12,  !- Branch 13 Name
+    HeatSys1 Demand Load Branch 13,  !- Branch 14 Name
+    HeatSys1 Demand Load Branch 14,  !- Branch 15 Name
+    HeatSys1 Demand Load Branch 15,  !- Branch 16 Name
+    HeatSys1 Demand Load Branch 16,  !- Branch 17 Name
+    HeatSys1 Demand Load Branch 17,  !- Branch 18 Name
+    HeatSys1 Demand Load Branch 18,  !- Branch 19 Name
+    HeatSys1 Demand Load Branch 19,  !- Branch 20 Name
+    HeatSys1 Demand Load Branch 20,  !- Branch 21 Name
+    HeatSys1 Demand Bypass Branch,  !- Branch 22 Name
+    HeatSys1 Demand Outlet Branch;  !- Branch 23 Name
+  BranchList,
+    HeatSys1 Supply Branches,!- Name
+    HeatSys1 Supply Inlet Branch,  !- Branch 1 Name
+    HeatSys1 Supply Equipment Branch,  !- Branch 2 Name
+    HeatSys1 Supply Equipment Bypass Branch,  !- Branch 3 Name
+    HeatSys1 Supply Outlet Branch;  !- Branch 4 Name
+  BranchList,
+    TowerWaterSys Demand Branches,  !- Name
+    TowerWaterSys Demand Inlet Branch,  !- Branch 1 Name
+    TowerWaterSys Demand Load Branch 1,  !- Branch 2 Name
+    TowerWaterSys Demand Load Branch 2,  !- Branch 3 Name
+    TowerWaterSys Demand Bypass Branch,  !- Branch 4 Name
+    TowerWaterSys Demand Outlet Branch;  !- Branch 5 Name
+  BranchList,
+    TowerWaterSys Supply Branches,  !- Name
+    TowerWaterSys Supply Inlet Branch,  !- Branch 1 Name
+    TowerWaterSys Supply Equipment Branch,  !- Branch 2 Name
+    TowerWaterSys Supply Equipment Bypass Branch,  !- Branch 3 Name
+    TowerWaterSys Supply Outlet Branch;  !- Branch 4 Name
+  Branch,
+    CoolSys1 Demand Bypass Branch,  !- Name
+    ,                        !- Maximum Flow Rate {m3/s}
+    Pipe:Adiabatic,          !- Component 1 Object Type
+    CoolSys1 Demand Bypass Pipe,  !- Component 1 Name
+    CoolSys1 Demand Bypass Pipe Inlet Node,  !- Component 1 Inlet Node Name
+    CoolSys1 Demand Bypass Pipe Outlet Node,  !- Component 1 Outlet Node Name
+    Bypass;                  !- Component 1 Branch Control Type
+  Branch,
+    CoolSys1 Demand Inlet Branch,  !- Name
+    CoolSys1 Demand Inlet Pipe,  !- Component 1 Name
+    CoolSys1 Demand Inlet Node,  !- Component 1 Inlet Node Name
+    CoolSys1 Demand Inlet Pipe-CoolSys1 Demand Mixer,  !- Component 1 Outlet Node Name
+    Passive;                 !- Component 1 Branch Control Type
+  Branch,
+    CoolSys1 Demand Load Branch 1,  !- Name
+    Coil:Cooling:Water,      !- Component 1 Object Type
+    VAV_5_CoolC,             !- Component 1 Name
+    VAV_5_CoolCDemand Inlet Node,  !- Component 1 Inlet Node Name
+    VAV_5_CoolCDemand Outlet Node,  !- Component 1 Outlet Node Name
+    Active;                  !- Component 1 Branch Control Type
+  Branch,
+    CoolSys1 Demand Load Branch 2,  !- Name
+    VAV_1_CoolC,             !- Component 1 Name
+    VAV_1_CoolCDemand Inlet Node,  !- Component 1 Inlet Node Name
+    VAV_1_CoolCDemand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    CoolSys1 Demand Load Branch 3,  !- Name
+    VAV_2_CoolC,             !- Component 1 Name
+    VAV_2_CoolCDemand Inlet Node,  !- Component 1 Inlet Node Name
+    VAV_2_CoolCDemand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    CoolSys1 Demand Load Branch 4,  !- Name
+    VAV_3_CoolC,             !- Component 1 Name
+    VAV_3_CoolCDemand Inlet Node,  !- Component 1 Inlet Node Name
+    VAV_3_CoolCDemand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    CoolSys1 Demand Outlet Branch,  !- Name
+    CoolSys1 Demand Outlet Pipe,  !- Component 1 Name
+    CoolSys1 Demand Mixer-CoolSys1 Demand Outlet Pipe,  !- Component 1 Inlet Node Name
+    CoolSys1 Demand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    CoolSys1 Supply Equipment Branch 1,  !- Name
+    Chiller:Electric:ReformulatedEIR,  !- Component 1 Object Type
+    CoolSys1 Chiller 1,      !- Component 1 Name
+    CoolSys1 Pump-CoolSys1 ChillerNode 1,  !- Component 1 Inlet Node Name
+    CoolSys1 Supply Equipment Outlet Node 1,  !- Component 1 Outlet Node Name
+  Branch,
+    CoolSys1 Supply Equipment Branch 2,  !- Name
+    CoolSys1 Chiller 2,      !- Component 1 Name
+    CoolSys1 Pump-CoolSys1 ChillerNode 2,  !- Component 1 Inlet Node Name
+    CoolSys1 Supply Equipment Outlet Node 2,  !- Component 1 Outlet Node Name
+  Branch,
+    CoolSys1 Supply Equipment Bypass Branch,  !- Name
+    CoolSys1 Supply Equipment Bypass Pipe,  !- Component 1 Name
+    CoolSys1 Supply Equip Bypass Inlet Node,  !- Component 1 Inlet Node Name
+    CoolSys1 Supply Equip Bypass Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    CoolSys1 Supply Inlet Branch,  !- Name
+    Pump:VariableSpeed,      !- Component 1 Object Type
+    CoolSys1 Pump,           !- Component 1 Name
+    CoolSys1 Supply Inlet Node,  !- Component 1 Inlet Node Name
+    CoolSys1 Pump-CoolSys1 ChillerNodeviaConnector,  !- Component 1 Outlet Node Name
+  Branch,
+    CoolSys1 Supply Outlet Branch,  !- Name
+    CoolSys1 Supply Outlet Pipe,  !- Component 1 Name
+    CoolSys1 Supply Mixer-CoolSys1 Supply Outlet Pipe,  !- Component 1 Inlet Node Name
+    CoolSys1 Supply Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Demand Bypass Branch,  !- Name
+    HeatSys1 Demand Bypass Pipe,  !- Component 1 Name
+    HeatSys1 Demand Bypass Pipe Inlet Node,  !- Component 1 Inlet Node Name
+    HeatSys1 Demand Bypass Pipe Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Demand Inlet Branch,  !- Name
+    HeatSys1 Demand Inlet Pipe,  !- Component 1 Name
+    HeatSys1 Demand Inlet Node,  !- Component 1 Inlet Node Name
+    HeatSys1 Demand Inlet Pipe-HeatSys1 Demand Mixer,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Demand Load Branch 1,  !- Name
+    Coil:Heating:Water,      !- Component 1 Object Type
+    Basement VAV Box Reheat Coil,  !- Component 1 Name
+    Basement VAV Box Reheat CoilDemand Inlet Node,  !- Component 1 Inlet Node Name
+    Basement VAV Box Reheat CoilDemand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Demand Load Branch 10,  !- Name
+    Perimeter_mid_ZN_2 VAV Box Reheat Coil,  !- Component 1 Name
+    Perimeter_mid_ZN_2 VAV Box Reheat CoilDemand Inlet Node,  !- Component 1 Inlet Node Name
+    Perimeter_mid_ZN_2 VAV Box Reheat CoilDemand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Demand Load Branch 11,  !- Name
+    Perimeter_mid_ZN_1 VAV Box Reheat Coil,  !- Component 1 Name
+    Perimeter_mid_ZN_1 VAV Box Reheat CoilDemand Inlet Node,  !- Component 1 Inlet Node Name
+    Perimeter_mid_ZN_1 VAV Box Reheat CoilDemand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Demand Load Branch 12,  !- Name
+    Perimeter_mid_ZN_4 VAV Box Reheat Coil,  !- Component 1 Name
+    Perimeter_mid_ZN_4 VAV Box Reheat CoilDemand Inlet Node,  !- Component 1 Inlet Node Name
+    Perimeter_mid_ZN_4 VAV Box Reheat CoilDemand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Demand Load Branch 13,  !- Name
+    Perimeter_top_ZN_3 VAV Box Reheat Coil,  !- Component 1 Name
+    Perimeter_top_ZN_3 VAV Box Reheat CoilDemand Inlet Node,  !- Component 1 Inlet Node Name
+    Perimeter_top_ZN_3 VAV Box Reheat CoilDemand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Demand Load Branch 14,  !- Name
+    Perimeter_top_ZN_2 VAV Box Reheat Coil,  !- Component 1 Name
+    Perimeter_top_ZN_2 VAV Box Reheat CoilDemand Inlet Node,  !- Component 1 Inlet Node Name
+    Perimeter_top_ZN_2 VAV Box Reheat CoilDemand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Demand Load Branch 15,  !- Name
+    Perimeter_top_ZN_1 VAV Box Reheat Coil,  !- Component 1 Name
+    Perimeter_top_ZN_1 VAV Box Reheat CoilDemand Inlet Node,  !- Component 1 Inlet Node Name
+    Perimeter_top_ZN_1 VAV Box Reheat CoilDemand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Demand Load Branch 16,  !- Name
+    Perimeter_top_ZN_4 VAV Box Reheat Coil,  !- Component 1 Name
+    Perimeter_top_ZN_4 VAV Box Reheat CoilDemand Inlet Node,  !- Component 1 Inlet Node Name
+    Perimeter_top_ZN_4 VAV Box Reheat CoilDemand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Demand Load Branch 17,  !- Name
+    VAV_5_HeatC,             !- Component 1 Name
+    VAV_5_HeatCDemand Inlet Node,  !- Component 1 Inlet Node Name
+    VAV_5_HeatCDemand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Demand Load Branch 18,  !- Name
+    VAV_1_HeatC,             !- Component 1 Name
+    VAV_1_HeatCDemand Inlet Node,  !- Component 1 Inlet Node Name
+    VAV_1_HeatCDemand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Demand Load Branch 19,  !- Name
+    VAV_2_HeatC,             !- Component 1 Name
+    VAV_2_HeatCDemand Inlet Node,  !- Component 1 Inlet Node Name
+    VAV_2_HeatCDemand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Demand Load Branch 2,  !- Name
+    Core_bottom VAV Box Reheat Coil,  !- Component 1 Name
+    Core_bottom VAV Box Reheat CoilDemand Inlet Node,  !- Component 1 Inlet Node Name
+    Core_bottom VAV Box Reheat CoilDemand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Demand Load Branch 20,  !- Name
+    VAV_3_HeatC,             !- Component 1 Name
+    VAV_3_HeatCDemand Inlet Node,  !- Component 1 Inlet Node Name
+    VAV_3_HeatCDemand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Demand Load Branch 3,  !- Name
+    Core_mid VAV Box Reheat Coil,  !- Component 1 Name
+    Core_mid VAV Box Reheat CoilDemand Inlet Node,  !- Component 1 Inlet Node Name
+    Core_mid VAV Box Reheat CoilDemand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Demand Load Branch 4,  !- Name
+    Core_top VAV Box Reheat Coil,  !- Component 1 Name
+    Core_top VAV Box Reheat CoilDemand Inlet Node,  !- Component 1 Inlet Node Name
+    Core_top VAV Box Reheat CoilDemand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Demand Load Branch 5,  !- Name
+    Perimeter_bot_ZN_3 VAV Box Reheat Coil,  !- Component 1 Name
+    Perimeter_bot_ZN_3 VAV Box Reheat CoilDemand Inlet Node,  !- Component 1 Inlet Node Name
+    Perimeter_bot_ZN_3 VAV Box Reheat CoilDemand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Demand Load Branch 6,  !- Name
+    Perimeter_bot_ZN_2 VAV Box Reheat Coil,  !- Component 1 Name
+    Perimeter_bot_ZN_2 VAV Box Reheat CoilDemand Inlet Node,  !- Component 1 Inlet Node Name
+    Perimeter_bot_ZN_2 VAV Box Reheat CoilDemand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Demand Load Branch 7,  !- Name
+    Perimeter_bot_ZN_1 VAV Box Reheat Coil,  !- Component 1 Name
+    Perimeter_bot_ZN_1 VAV Box Reheat CoilDemand Inlet Node,  !- Component 1 Inlet Node Name
+    Perimeter_bot_ZN_1 VAV Box Reheat CoilDemand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Demand Load Branch 8,  !- Name
+    Perimeter_bot_ZN_4 VAV Box Reheat Coil,  !- Component 1 Name
+    Perimeter_bot_ZN_4 VAV Box Reheat CoilDemand Inlet Node,  !- Component 1 Inlet Node Name
+    Perimeter_bot_ZN_4 VAV Box Reheat CoilDemand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Demand Load Branch 9,  !- Name
+    Perimeter_mid_ZN_3 VAV Box Reheat Coil,  !- Component 1 Name
+    Perimeter_mid_ZN_3 VAV Box Reheat CoilDemand Inlet Node,  !- Component 1 Inlet Node Name
+    Perimeter_mid_ZN_3 VAV Box Reheat CoilDemand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Demand Outlet Branch,  !- Name
+    HeatSys1 Demand Outlet Pipe,  !- Component 1 Name
+    HeatSys1 Demand Mixer-HeatSys1 Demand Outlet Pipe,  !- Component 1 Inlet Node Name
+    HeatSys1 Demand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Supply Equipment Branch,  !- Name
+    Boiler:HotWater,         !- Component 1 Object Type
+    HeatSys1 Boiler,         !- Component 1 Name
+    HeatSys1 Pump-HeatSys1 BoilerNode,  !- Component 1 Inlet Node Name
+    HeatSys1 Supply Equipment Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Supply Equipment Bypass Branch,  !- Name
+    HeatSys1 Supply Equipment Bypass Pipe,  !- Component 1 Name
+    HeatSys1 Supply Equip Bypass Inlet Node,  !- Component 1 Inlet Node Name
+    HeatSys1 Supply Equip Bypass Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Supply Inlet Branch,  !- Name
+    HeatSys1 Pump,           !- Component 1 Name
+    HeatSys1 Supply Inlet Node,  !- Component 1 Inlet Node Name
+    HeatSys1 Pump-HeatSys1 BoilerNodeviaConnector,  !- Component 1 Outlet Node Name
+  Branch,
+    HeatSys1 Supply Outlet Branch,  !- Name
+    HeatSys1 Supply Outlet Pipe,  !- Component 1 Name
+    HeatSys1 Supply Mixer-HeatSys1 Supply Outlet Pipe,  !- Component 1 Inlet Node Name
+    HeatSys1 Supply Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    TowerWaterSys Demand Bypass Branch,  !- Name
+    TowerWaterSys Demand Bypass Pipe,  !- Component 1 Name
+    TowerWaterSys Demand Bypass Pipe Inlet Node,  !- Component 1 Inlet Node Name
+    TowerWaterSys Demand Bypass Pipe Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    TowerWaterSys Demand Inlet Branch,  !- Name
+    TowerWaterSys Demand Inlet Pipe,  !- Component 1 Name
+    TowerWaterSys Demand Inlet Node,  !- Component 1 Inlet Node Name
+    TowerWaterSys Demand Inlet Pipe-TowerWaterSys Demand Mixer,  !- Component 1 Outlet Node Name
+  Branch,
+    TowerWaterSys Demand Load Branch 1,  !- Name
+    CoolSys1 Chiller Water Inlet Node 1,  !- Component 1 Inlet Node Name
+    CoolSys1 Chiller Water Outlet Node 1,  !- Component 1 Outlet Node Name
+  Branch,
+    TowerWaterSys Demand Load Branch 2,  !- Name
+    CoolSys1 Chiller Water Inlet Node 2,  !- Component 1 Inlet Node Name
+    CoolSys1 Chiller Water Outlet Node 2,  !- Component 1 Outlet Node Name
+  Branch,
+    TowerWaterSys Demand Outlet Branch,  !- Name
+    TowerWaterSys Demand Outlet Pipe,  !- Component 1 Name
+    TowerWaterSys Demand Mixer-TowerWaterSys Demand Outlet Pipe,  !- Component 1 Inlet Node Name
+    TowerWaterSys Demand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    TowerWaterSys Supply Equipment Branch,  !- Name
+    CoolingTower:SingleSpeed,!- Component 1 Object Type
+    TowerWaterSys CoolTower, !- Component 1 Name
+    TowerWaterSys Pump-TowerWaterSys CoolTowerNode,  !- Component 1 Inlet Node Name
+    TowerWaterSys Supply Equipment Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    TowerWaterSys Supply Equipment Bypass Branch,  !- Name
+    TowerWaterSys Supply Equipment Bypass Pipe,  !- Component 1 Name
+    TowerWaterSys Supply Equip Bypass Inlet Node,  !- Component 1 Inlet Node Name
+    TowerWaterSys Supply Equip Bypass Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    TowerWaterSys Supply Inlet Branch,  !- Name
+    Pump:ConstantSpeed,      !- Component 1 Object Type
+    TowerWaterSys Pump,      !- Component 1 Name
+    TowerWaterSys Supply Inlet Node,  !- Component 1 Inlet Node Name
+    TowerWaterSys Pump-TowerWaterSys CoolTowerNodeviaConnector,  !- Component 1 Outlet Node Name
+  Branch,
+    TowerWaterSys Supply Outlet Branch,  !- Name
+    TowerWaterSys Supply Outlet Pipe,  !- Component 1 Name
+    TowerWaterSys Supply Mixer-TowerWaterSys Supply Outlet Pipe,  !- Component 1 Inlet Node Name
+    TowerWaterSys Supply Outlet Node,  !- Component 1 Outlet Node Name
+  OutdoorAir:Node,
+    TowerWaterSys CoolTower OA ref Node;  !- Name
+  ConnectorList,
+    CoolSys1 Demand Connectors,  !- Name
+    Connector:Splitter,      !- Connector 1 Object Type
+    CoolSys1 Demand Splitter,!- Connector 1 Name
+    Connector:Mixer,         !- Connector 2 Object Type
+    CoolSys1 Demand Mixer;   !- Connector 2 Name
+  ConnectorList,
+    CoolSys1 Supply Connectors,  !- Name
+    CoolSys1 Supply Splitter,!- Connector 1 Name
+    CoolSys1 Supply Mixer;   !- Connector 2 Name
+  ConnectorList,
+    HeatSys1 Demand Connectors,  !- Name
+    HeatSys1 Demand Splitter,!- Connector 1 Name
+    HeatSys1 Demand Mixer;   !- Connector 2 Name
+  ConnectorList,
+    HeatSys1 Supply Connectors,  !- Name
+    HeatSys1 Supply Splitter,!- Connector 1 Name
+    HeatSys1 Supply Mixer;   !- Connector 2 Name
+  ConnectorList,
+    TowerWaterSys Demand Connectors,  !- Name
+    TowerWaterSys Demand Splitter,  !- Connector 1 Name
+    TowerWaterSys Demand Mixer;  !- Connector 2 Name
+  ConnectorList,
+    TowerWaterSys Supply Connectors,  !- Name
+    TowerWaterSys Supply Splitter,  !- Connector 1 Name
+    TowerWaterSys Supply Mixer;  !- Connector 2 Name
+    CoolSys1 Demand Splitter,!- Name
+    CoolSys1 Demand Inlet Branch,  !- Inlet Branch Name
+    CoolSys1 Demand Load Branch 1,  !- Outlet Branch 1 Name
+    CoolSys1 Demand Load Branch 2,  !- Outlet Branch 2 Name
+    CoolSys1 Demand Load Branch 3,  !- Outlet Branch 3 Name
+    CoolSys1 Demand Load Branch 4,  !- Outlet Branch 4 Name
+    CoolSys1 Demand Bypass Branch;  !- Outlet Branch 5 Name
+    CoolSys1 Supply Splitter,!- Name
+    CoolSys1 Supply Inlet Branch,  !- Inlet Branch Name
+    CoolSys1 Supply Equipment Branch 1,  !- Outlet Branch 1 Name
+    CoolSys1 Supply Equipment Branch 2,  !- Outlet Branch 2 Name
+    CoolSys1 Supply Equipment Bypass Branch;  !- Outlet Branch 3 Name
+    HeatSys1 Demand Splitter,!- Name
+    HeatSys1 Demand Inlet Branch,  !- Inlet Branch Name
+    HeatSys1 Demand Load Branch 1,  !- Outlet Branch 1 Name
+    HeatSys1 Demand Load Branch 2,  !- Outlet Branch 2 Name
+    HeatSys1 Demand Load Branch 3,  !- Outlet Branch 3 Name
+    HeatSys1 Demand Load Branch 4,  !- Outlet Branch 4 Name
+    HeatSys1 Demand Load Branch 5,  !- Outlet Branch 5 Name
+    HeatSys1 Demand Load Branch 6,  !- Outlet Branch 6 Name
+    HeatSys1 Demand Load Branch 7,  !- Outlet Branch 7 Name
+    HeatSys1 Demand Load Branch 8,  !- Outlet Branch 8 Name
+    HeatSys1 Demand Load Branch 9,  !- Outlet Branch 9 Name
+    HeatSys1 Demand Load Branch 10,  !- Outlet Branch 10 Name
+    HeatSys1 Demand Load Branch 11,  !- Outlet Branch 11 Name
+    HeatSys1 Demand Load Branch 12,  !- Outlet Branch 12 Name
+    HeatSys1 Demand Load Branch 13,  !- Outlet Branch 13 Name
+    HeatSys1 Demand Load Branch 14,  !- Outlet Branch 14 Name
+    HeatSys1 Demand Load Branch 15,  !- Outlet Branch 15 Name
+    HeatSys1 Demand Load Branch 16,  !- Outlet Branch 16 Name
+    HeatSys1 Demand Load Branch 17,  !- Outlet Branch 17 Name
+    HeatSys1 Demand Load Branch 18,  !- Outlet Branch 18 Name
+    HeatSys1 Demand Load Branch 19,  !- Outlet Branch 19 Name
+    HeatSys1 Demand Load Branch 20,  !- Outlet Branch 20 Name
+    HeatSys1 Demand Bypass Branch;  !- Outlet Branch 21 Name
+    HeatSys1 Supply Splitter,!- Name
+    HeatSys1 Supply Inlet Branch,  !- Inlet Branch Name
+    HeatSys1 Supply Equipment Branch,  !- Outlet Branch 1 Name
+    HeatSys1 Supply Equipment Bypass Branch;  !- Outlet Branch 2 Name
+    TowerWaterSys Demand Splitter,  !- Name
+    TowerWaterSys Demand Inlet Branch,  !- Inlet Branch Name
+    TowerWaterSys Demand Load Branch 1,  !- Outlet Branch 1 Name
+    TowerWaterSys Demand Load Branch 2,  !- Outlet Branch 2 Name
+    TowerWaterSys Demand Bypass Branch;  !- Outlet Branch 3 Name
+    TowerWaterSys Supply Splitter,  !- Name
+    TowerWaterSys Supply Inlet Branch,  !- Inlet Branch Name
+    TowerWaterSys Supply Equipment Branch,  !- Outlet Branch 1 Name
+    TowerWaterSys Supply Equipment Bypass Branch;  !- Outlet Branch 2 Name
+  Connector:Mixer,
+    CoolSys1 Demand Mixer,   !- Name
+    CoolSys1 Demand Outlet Branch,  !- Outlet Branch Name
+    CoolSys1 Demand Load Branch 1,  !- Inlet Branch 1 Name
+    CoolSys1 Demand Load Branch 2,  !- Inlet Branch 2 Name
+    CoolSys1 Demand Load Branch 3,  !- Inlet Branch 3 Name
+    CoolSys1 Demand Load Branch 4,  !- Inlet Branch 4 Name
+    CoolSys1 Demand Bypass Branch;  !- Inlet Branch 5 Name
+  Connector:Mixer,
+    CoolSys1 Supply Mixer,   !- Name
+    CoolSys1 Supply Outlet Branch,  !- Outlet Branch Name
+    CoolSys1 Supply Equipment Branch 1,  !- Inlet Branch 1 Name
+    CoolSys1 Supply Equipment Branch 2,  !- Inlet Branch 2 Name
+    CoolSys1 Supply Equipment Bypass Branch;  !- Inlet Branch 3 Name
+  Connector:Mixer,
+    HeatSys1 Demand Mixer,   !- Name
+    HeatSys1 Demand Outlet Branch,  !- Outlet Branch Name
+    HeatSys1 Demand Load Branch 1,  !- Inlet Branch 1 Name
+    HeatSys1 Demand Load Branch 2,  !- Inlet Branch 2 Name
+    HeatSys1 Demand Load Branch 3,  !- Inlet Branch 3 Name
+    HeatSys1 Demand Load Branch 4,  !- Inlet Branch 4 Name
+    HeatSys1 Demand Load Branch 5,  !- Inlet Branch 5 Name
+    HeatSys1 Demand Load Branch 6,  !- Inlet Branch 6 Name
+    HeatSys1 Demand Load Branch 7,  !- Inlet Branch 7 Name
+    HeatSys1 Demand Load Branch 8,  !- Inlet Branch 8 Name
+    HeatSys1 Demand Load Branch 9,  !- Inlet Branch 9 Name
+    HeatSys1 Demand Load Branch 10,  !- Inlet Branch 10 Name
+    HeatSys1 Demand Load Branch 11,  !- Inlet Branch 11 Name
+    HeatSys1 Demand Load Branch 12,  !- Inlet Branch 12 Name
+    HeatSys1 Demand Load Branch 13,  !- Inlet Branch 13 Name
+    HeatSys1 Demand Load Branch 14,  !- Inlet Branch 14 Name
+    HeatSys1 Demand Load Branch 15,  !- Inlet Branch 15 Name
+    HeatSys1 Demand Load Branch 16,  !- Inlet Branch 16 Name
+    HeatSys1 Demand Load Branch 17,  !- Inlet Branch 17 Name
+    HeatSys1 Demand Load Branch 18,  !- Inlet Branch 18 Name
+    HeatSys1 Demand Load Branch 19,  !- Inlet Branch 19 Name
+    HeatSys1 Demand Load Branch 20,  !- Inlet Branch 20 Name
+    HeatSys1 Demand Bypass Branch;  !- Inlet Branch 21 Name
+  Connector:Mixer,
+    HeatSys1 Supply Mixer,   !- Name
+    HeatSys1 Supply Outlet Branch,  !- Outlet Branch Name
+    HeatSys1 Supply Equipment Branch,  !- Inlet Branch 1 Name
+    HeatSys1 Supply Equipment Bypass Branch;  !- Inlet Branch 2 Name
+  Connector:Mixer,
+    TowerWaterSys Demand Mixer,  !- Name
+    TowerWaterSys Demand Outlet Branch,  !- Outlet Branch Name
+    TowerWaterSys Demand Load Branch 1,  !- Inlet Branch 1 Name
+    TowerWaterSys Demand Load Branch 2,  !- Inlet Branch 2 Name
+    TowerWaterSys Demand Bypass Branch;  !- Inlet Branch 3 Name
+  Connector:Mixer,
+    TowerWaterSys Supply Mixer,  !- Name
+    TowerWaterSys Supply Outlet Branch,  !- Outlet Branch Name
+    TowerWaterSys Supply Equipment Branch,  !- Inlet Branch 1 Name
+    TowerWaterSys Supply Equipment Bypass Branch;  !- Inlet Branch 2 Name
+  Pipe:Adiabatic,
+    CoolSys1 Demand Bypass Pipe,  !- Name
+    CoolSys1 Demand Bypass Pipe Inlet Node,  !- Inlet Node Name
+    CoolSys1 Demand Bypass Pipe Outlet Node;  !- Outlet Node Name
+  Pipe:Adiabatic,
+    CoolSys1 Demand Inlet Pipe,  !- Name
+    CoolSys1 Demand Inlet Node,  !- Inlet Node Name
+    CoolSys1 Demand Inlet Pipe-CoolSys1 Demand Mixer;  !- Outlet Node Name
+  Pipe:Adiabatic,
+    CoolSys1 Demand Outlet Pipe,  !- Name
+    CoolSys1 Demand Mixer-CoolSys1 Demand Outlet Pipe,  !- Inlet Node Name
+    CoolSys1 Demand Outlet Node;  !- Outlet Node Name
+  Pipe:Adiabatic,
+    CoolSys1 Supply Equipment Bypass Pipe,  !- Name
+    CoolSys1 Supply Equip Bypass Inlet Node,  !- Inlet Node Name
+    CoolSys1 Supply Equip Bypass Outlet Node;  !- Outlet Node Name
+  Pipe:Adiabatic,
+    CoolSys1 Supply Outlet Pipe,  !- Name
+    CoolSys1 Supply Mixer-CoolSys1 Supply Outlet Pipe,  !- Inlet Node Name
+    CoolSys1 Supply Outlet Node;  !- Outlet Node Name
+  Pipe:Adiabatic,
+    HeatSys1 Demand Bypass Pipe,  !- Name
+    HeatSys1 Demand Bypass Pipe Inlet Node,  !- Inlet Node Name
+    HeatSys1 Demand Bypass Pipe Outlet Node;  !- Outlet Node Name
+  Pipe:Adiabatic,
+    HeatSys1 Demand Inlet Pipe,  !- Name
+    HeatSys1 Demand Inlet Node,  !- Inlet Node Name
+    HeatSys1 Demand Inlet Pipe-HeatSys1 Demand Mixer;  !- Outlet Node Name
+  Pipe:Adiabatic,
+    HeatSys1 Demand Outlet Pipe,  !- Name
+    HeatSys1 Demand Mixer-HeatSys1 Demand Outlet Pipe,  !- Inlet Node Name
+    HeatSys1 Demand Outlet Node;  !- Outlet Node Name
+  Pipe:Adiabatic,
+    HeatSys1 Supply Equipment Bypass Pipe,  !- Name
+    HeatSys1 Supply Equip Bypass Inlet Node,  !- Inlet Node Name
+    HeatSys1 Supply Equip Bypass Outlet Node;  !- Outlet Node Name
+  Pipe:Adiabatic,
+    HeatSys1 Supply Outlet Pipe,  !- Name
+    HeatSys1 Supply Mixer-HeatSys1 Supply Outlet Pipe,  !- Inlet Node Name
+    HeatSys1 Supply Outlet Node;  !- Outlet Node Name
+  Pipe:Adiabatic,
+    TowerWaterSys Demand Bypass Pipe,  !- Name
+    TowerWaterSys Demand Bypass Pipe Inlet Node,  !- Inlet Node Name
+    TowerWaterSys Demand Bypass Pipe Outlet Node;  !- Outlet Node Name
+  Pipe:Adiabatic,
+    TowerWaterSys Demand Inlet Pipe,  !- Name
+    TowerWaterSys Demand Inlet Node,  !- Inlet Node Name
+    TowerWaterSys Demand Inlet Pipe-TowerWaterSys Demand Mixer;  !- Outlet Node Name
+  Pipe:Adiabatic,
+    TowerWaterSys Demand Outlet Pipe,  !- Name
+    TowerWaterSys Demand Mixer-TowerWaterSys Demand Outlet Pipe,  !- Inlet Node Name
+    TowerWaterSys Demand Outlet Node;  !- Outlet Node Name
+  Pipe:Adiabatic,
+    TowerWaterSys Supply Equipment Bypass Pipe,  !- Name
+    TowerWaterSys Supply Equip Bypass Inlet Node,  !- Inlet Node Name
+    TowerWaterSys Supply Equip Bypass Outlet Node;  !- Outlet Node Name
+  Pipe:Adiabatic,
+    TowerWaterSys Supply Outlet Pipe,  !- Name
+    TowerWaterSys Supply Mixer-TowerWaterSys Supply Outlet Pipe,  !- Inlet Node Name
+    TowerWaterSys Supply Outlet Node;  !- Outlet Node Name
+! ***SCHEDULES***
+  Schedule:Compact,
+    CW-Loop-Temp-Schedule,   !- Name
+    Until: 24:00,6.7;        !- Field 3
+  Schedule:Compact,
+    HW-Loop-Temp-Schedule,   !- Name
+    Until: 24:00,82.2;       !- Field 3
+! ***SWH EQUIPMENT***
+  WaterHeater:Mixed,
+    SWHSys1 Water Heater,    !- Name
+    0.7571,                  !- Tank Volume {m3}
+    SWHSys1 Water Heater Setpoint Temperature Schedule Name,  !- Setpoint Temperature Schedule Name
+    2.0,                     !- Deadband Temperature Difference {deltaC}
+    82.2222,                 !- Maximum Temperature Limit {C}
+    Cycle,                   !- Heater Control Type
+    845000,                  !- Heater Maximum Capacity {W}
+    ,                        !- Heater Minimum Capacity {W}
+    ,                        !- Heater Ignition Minimum Flow Rate {m3/s}
+    ,                        !- Heater Ignition Delay {s}
+    NATURALGAS,              !- Heater Fuel Type
+    0.8,                     !- Heater Thermal Efficiency
+    ,                        !- Part Load Factor Curve Name
+    20,                      !- Off Cycle Parasitic Fuel Consumption Rate {W}
+    NATURALGAS,              !- Off Cycle Parasitic Fuel Type
+    0.8,                     !- Off Cycle Parasitic Heat Fraction to Tank
+    ,                        !- On Cycle Parasitic Fuel Consumption Rate {W}
+    NATURALGAS,              !- On Cycle Parasitic Fuel Type
+    ,                        !- On Cycle Parasitic Heat Fraction to Tank
+    SCHEDULE,                !- Ambient Temperature Indicator
+    SWHSys1 Water Heater Ambient Temperature Schedule Name,  !- Ambient Temperature Schedule Name
+    ,                        !- Ambient Temperature Zone Name
+    ,                        !- Ambient Temperature Outdoor Air Node Name
+    6.0,                     !- Off Cycle Loss Coefficient to Ambient Temperature {W/K}
+    ,                        !- Off Cycle Loss Fraction to Zone
+    6.0,                     !- On Cycle Loss Coefficient to Ambient Temperature {W/K}
+    ,                        !- On Cycle Loss Fraction to Zone
+    ,                        !- Peak Use Flow Rate {m3/s}
+    ,                        !- Use Flow Rate Fraction Schedule Name
+    ,                        !- Cold Water Supply Temperature Schedule Name
+    SWHSys1 Pump-SWHSys1 Water HeaterNode,  !- Use Side Inlet Node Name
+    SWHSys1 Supply Equipment Outlet Node,  !- Use Side Outlet Node Name
+    1.0,                     !- Use Side Effectiveness
+    ,                        !- Source Side Inlet Node Name
+    ,                        !- Source Side Outlet Node Name
+    1.0,                     !- Source Side Effectiveness
+    AUTOSIZE,                !- Use Side Design Flow Rate {m3/s}
+    AUTOSIZE,                !- Source Side Design Flow Rate {m3/s}
+    1.5;                     !- Indirect Water Heating Recovery Time {hr}
+  WaterUse:Equipment,
+    Core_bottom Water Equipment,  !- Name
+    ,                        !- End-Use Subcategory
+    2.24e-005,               !- Peak Flow Rate {m3/s}
+    BLDG_SWH_SCH,            !- Flow Rate Fraction Schedule Name
+    Water Equipment Temp Sched,  !- Target Temperature Schedule Name
+    Water Equipment Hot Supply Temp Sched,  !- Hot Water Supply Temperature Schedule Name
+    Core_bottom,             !- Zone Name
+    Water Equipment Sensible fract sched,  !- Sensible Fraction Schedule Name
+    Water Equipment Latent fract sched;  !- Latent Fraction Schedule Name
+    Core_mid Water Equipment,!- Name
+    Core_mid,                !- Zone Name
+    Core_top Water Equipment,!- Name
+    Core_top,                !- Zone Name
+    SWHSys1 Equipment List,  !- Name
+    WaterHeater:Mixed,       !- Equipment 1 Object Type
+    SWHSys1 Water Heater;    !- Equipment 1 Name
+    SWHSys1 Pump,            !- Name
+    SWHSys1 Supply Inlet Node,  !- Inlet Node Name
+    SWHSys1 Pump-SWHSys1 Water HeaterNodeviaConnector,  !- Outlet Node Name
+    0.85,                    !- Motor Efficiency
+! ***SWH SIZING & CONTROLS***
+  Sizing:Plant,
+    SWHSys1,                 !- Plant or Condenser Loop Name
+    60,                      !- Design Loop Exit Temperature {C}
+    5.0;                     !- Loop Design Temperature Difference {deltaC}
+  SetpointManager:Scheduled,
+    SWHSys1 Loop Setpoint Manager,  !- Name
+    Temperature,             !- Control Variable
+    SWHSys1-Loop-Temp-Schedule,  !- Schedule Name
+    SWHSys1 Supply Outlet Node;  !- Setpoint Node or NodeList Name
+    SWHSys1 Loop Operation Scheme List,  !- Name
+    SWHSys1 Operation Scheme,!- Control Scheme 1 Name
+    SWHSys1 Operation Scheme,!- Name
+    SWHSys1 Equipment List;  !- Range 1 Equipment List Name
+! ***SWH LOOP***
+  PlantLoop,
+    SWHSys1,                 !- Name
+    SWHSys1 Loop Operation Scheme List,  !- Plant Equipment Operation Scheme Name
+    SWHSys1 Supply Outlet Node,  !- Loop Temperature Setpoint Node Name
+    60.0,                    !- Maximum Loop Temperature {C}
+    SWHSys1 Supply Inlet Node,  !- Plant Side Inlet Node Name
+    SWHSys1 Supply Outlet Node,  !- Plant Side Outlet Node Name
+    SWHSys1 Supply Branches, !- Plant Side Branch List Name
+    SWHSys1 Supply Connectors,  !- Plant Side Connector List Name
+    SWHSys1 Demand Inlet Node,  !- Demand Side Inlet Node Name
+    SWHSys1 Demand Outlet Node,  !- Demand Side Outlet Node Name
+    SWHSys1 Demand Branches, !- Demand Side Branch List Name
+    SWHSys1 Demand Connectors,  !- Demand Side Connector List Name
+! ***SWH CONNECTIONS***
+  BranchList,
+    SWHSys1 Demand Branches, !- Name
+    SWHSys1 Demand Inlet Branch,  !- Branch 1 Name
+    SWHSys1 Demand Load Branch 1,  !- Branch 2 Name
+    SWHSys1 Demand Load Branch 2,  !- Branch 3 Name
+    SWHSys1 Demand Load Branch 3,  !- Branch 4 Name
+    SWHSys1 Demand Bypass Branch,  !- Branch 5 Name
+    SWHSys1 Demand Outlet Branch;  !- Branch 6 Name
+  BranchList,
+    SWHSys1 Supply Branches, !- Name
+    SWHSys1 Supply Inlet Branch,  !- Branch 1 Name
+    SWHSys1 Supply Equipment Branch,  !- Branch 2 Name
+    SWHSys1 Supply Equipment Bypass Branch,  !- Branch 3 Name
+    SWHSys1 Supply Outlet Branch;  !- Branch 4 Name
+  Branch,
+    SWHSys1 Demand Bypass Branch,  !- Name
+    SWHSys1 Demand Bypass Pipe,  !- Component 1 Name
+    SWHSys1 Demand Bypass Pipe Inlet Node,  !- Component 1 Inlet Node Name
+    SWHSys1 Demand Bypass Pipe Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    SWHSys1 Demand Inlet Branch,  !- Name
+    SWHSys1 Demand Inlet Pipe,  !- Component 1 Name
+    SWHSys1 Demand Inlet Node,  !- Component 1 Inlet Node Name
+    SWHSys1 Demand Inlet Pipe-SWHSys1 Demand Mixer,  !- Component 1 Outlet Node Name
+  Branch,
+    SWHSys1 Demand Load Branch 1,  !- Name
+    WaterUse:Connections,    !- Component 1 Object Type
+    Core_bottom Water Equipment,  !- Component 1 Name
+    Core_bottom Water Equipment Water Inlet Node,  !- Component 1 Inlet Node Name
+    Core_bottom Water Equipment Water Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    SWHSys1 Demand Load Branch 2,  !- Name
+    Core_mid Water Equipment,!- Component 1 Name
+    Core_mid Water Equipment Water Inlet Node,  !- Component 1 Inlet Node Name
+    Core_mid Water Equipment Water Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    SWHSys1 Demand Load Branch 3,  !- Name
+    Core_top Water Equipment,!- Component 1 Name
+    Core_top Water Equipment Water Inlet Node,  !- Component 1 Inlet Node Name
+    Core_top Water Equipment Water Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    SWHSys1 Demand Outlet Branch,  !- Name
+    SWHSys1 Demand Outlet Pipe,  !- Component 1 Name
+    SWHSys1 Demand Mixer-SWHSys1 Demand Outlet Pipe,  !- Component 1 Inlet Node Name
+    SWHSys1 Demand Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    SWHSys1 Supply Equipment Branch,  !- Name
+    WaterHeater:Mixed,       !- Component 1 Object Type
+    SWHSys1 Water Heater,    !- Component 1 Name
+    SWHSys1 Pump-SWHSys1 Water HeaterNode,  !- Component 1 Inlet Node Name
+    SWHSys1 Supply Equipment Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    SWHSys1 Supply Equipment Bypass Branch,  !- Name
+    ,                        !- Pressure Drop Curve Name
+    SWHSys1 Supply Equipment Bypass Pipe,  !- Component 1 Name
+    SWHSys1 Supply Equip Bypass Inlet Node,  !- Component 1 Inlet Node Name
+    SWHSys1 Supply Equip Bypass Outlet Node,  !- Component 1 Outlet Node Name
+  Branch,
+    SWHSys1 Supply Inlet Branch,  !- Name
+    SWHSys1 Pump,            !- Component 1 Name
+    SWHSys1 Supply Inlet Node,  !- Component 1 Inlet Node Name
+    SWHSys1 Pump-SWHSys1 Water HeaterNodeviaConnector,  !- Component 1 Outlet Node Name
+  Branch,
+    SWHSys1 Supply Outlet Branch,  !- Name
+    SWHSys1 Supply Outlet Pipe,  !- Component 1 Name
+    SWHSys1 Supply Mixer-SWHSys1 Supply Outlet Pipe,  !- Component 1 Inlet Node Name
+    SWHSys1 Supply Outlet Node,  !- Component 1 Outlet Node Name
+  ConnectorList,
+    SWHSys1 Demand Connectors,  !- Name
+    SWHSys1 Demand Splitter, !- Connector 1 Name
+    SWHSys1 Demand Mixer;    !- Connector 2 Name
+  ConnectorList,
+    SWHSys1 Supply Connectors,  !- Name
+    SWHSys1 Supply Splitter, !- Connector 1 Name
+    SWHSys1 Supply Mixer;    !- Connector 2 Name
+    Core_bottom Water Equipment Water Inlet Node,  !- Inlet Node Name
+    Core_bottom Water Equipment Water Outlet Node,  !- Outlet Node Name
+    ,                        !- Reclamation Water Storage Tank Name
+    ,                        !- Hot Water Supply Temperature Schedule Name
+    ,                        !- Drain Water Heat Exchanger Type
+    ,                        !- Drain Water Heat Exchanger Destination
+    ,                        !- Drain Water Heat Exchanger U-Factor Times Area {W/K}
+    Core_bottom Water Equipment;  !- Water Use Equipment 1 Name
+    Core_mid Water Equipment Water Inlet Node,  !- Inlet Node Name
+    Core_mid Water Equipment Water Outlet Node,  !- Outlet Node Name
+    Core_mid Water Equipment;!- Water Use Equipment 1 Name
+    Core_top Water Equipment Water Inlet Node,  !- Inlet Node Name
+    Core_top Water Equipment Water Outlet Node,  !- Outlet Node Name
+    Core_top Water Equipment;!- Water Use Equipment 1 Name
+    SWHSys1 Demand Splitter, !- Name
+    SWHSys1 Demand Inlet Branch,  !- Inlet Branch Name
+    SWHSys1 Demand Load Branch 1,  !- Outlet Branch 1 Name
+    SWHSys1 Demand Load Branch 2,  !- Outlet Branch 2 Name
+    SWHSys1 Demand Load Branch 3,  !- Outlet Branch 3 Name
+    SWHSys1 Demand Bypass Branch;  !- Outlet Branch 4 Name
+    SWHSys1 Supply Splitter, !- Name
+    SWHSys1 Supply Inlet Branch,  !- Inlet Branch Name
+    SWHSys1 Supply Equipment Branch,  !- Outlet Branch 1 Name
+    SWHSys1 Supply Equipment Bypass Branch;  !- Outlet Branch 2 Name
+  Connector:Mixer,
+    SWHSys1 Demand Mixer,    !- Name
+    SWHSys1 Demand Outlet Branch,  !- Outlet Branch Name
+    SWHSys1 Demand Load Branch 1,  !- Inlet Branch 1 Name
+    SWHSys1 Demand Load Branch 2,  !- Inlet Branch 2 Name
+    SWHSys1 Demand Load Branch 3,  !- Inlet Branch 3 Name
+    SWHSys1 Demand Bypass Branch;  !- Inlet Branch 4 Name
+  Connector:Mixer,
+    SWHSys1 Supply Mixer,    !- Name
+    SWHSys1 Supply Outlet Branch,  !- Outlet Branch Name
+    SWHSys1 Supply Equipment Branch,  !- Inlet Branch 1 Name
+    SWHSys1 Supply Equipment Bypass Branch;  !- Inlet Branch 2 Name
+  Pipe:Adiabatic,
+    SWHSys1 Demand Bypass Pipe,  !- Name
+    SWHSys1 Demand Bypass Pipe Inlet Node,  !- Inlet Node Name
+    SWHSys1 Demand Bypass Pipe Outlet Node;  !- Outlet Node Name
+  Pipe:Adiabatic,
+    SWHSys1 Demand Inlet Pipe,  !- Name
+    SWHSys1 Demand Inlet Node,  !- Inlet Node Name
+    SWHSys1 Demand Inlet Pipe-SWHSys1 Demand Mixer;  !- Outlet Node Name
+  Pipe:Adiabatic,
+    SWHSys1 Demand Outlet Pipe,  !- Name
+    SWHSys1 Demand Mixer-SWHSys1 Demand Outlet Pipe,  !- Inlet Node Name
+    SWHSys1 Demand Outlet Node;  !- Outlet Node Name
+  Pipe:Adiabatic,
+    SWHSys1 Supply Equipment Bypass Pipe,  !- Name
+    SWHSys1 Supply Equip Bypass Inlet Node,  !- Inlet Node Name
+    SWHSys1 Supply Equip Bypass Outlet Node;  !- Outlet Node Name
+  Pipe:Adiabatic,
+    SWHSys1 Supply Outlet Pipe,  !- Name
+    SWHSys1 Supply Mixer-SWHSys1 Supply Outlet Pipe,  !- Inlet Node Name
+    SWHSys1 Supply Outlet Node;  !- Outlet Node Name
+! ***SWH SCHEDULES***
+  Schedule:Compact,
+    BLDG_SWH_SCH,            !- Name
+    Fraction,                !- Schedule Type Limits Name
+    For: Weekdays SummerDesignDay, !- Field 2
+    Until: 05:00,0.05,       !- Field 3
+    Until: 06:00,0.08,       !- Field 5
+    Until: 07:00,0.07,       !- Field 7
+    Until: 08:00,0.19,       !- Field 9
+    Until: 09:00,0.35,       !- Field 11
+    Until: 10:00,0.38,       !- Field 13
+    Until: 11:00,0.39,       !- Field 15
+    Until: 12:00,0.47,       !- Field 17
+    Until: 13:00,0.57,       !- Field 19
+    Until: 14:00,0.54,       !- Field 21
+    Until: 15:00,0.34,       !- Field 23
+    Until: 16:00,0.33,       !- Field 25
+    Until: 17:00,0.44,       !- Field 27
+    Until: 18:00,0.26,       !- Field 29
+    Until: 19:00,0.21,       !- Field 31
+    Until: 20:00,0.15,       !- Field 33
+    Until: 21:00,0.17,       !- Field 35
+    Until: 22:00,0.08,       !- Field 37
+    Until: 24:00,0.05,       !- Field 39
+    For: Saturday WinterDesignDay, !- Field 41
+    Until: 05:00,0.05,       !- Field 42
+    Until: 06:00,0.08,       !- Field 44
+    Until: 07:00,0.07,       !- Field 46
+    Until: 08:00,0.11,       !- Field 48
+    Until: 09:00,0.15,       !- Field 50
+    Until: 10:00,0.21,       !- Field 52
+    Until: 11:00,0.19,       !- Field 54
+    Until: 12:00,0.23,       !- Field 56
+    Until: 13:00,0.20,       !- Field 58
+    Until: 14:00,0.19,       !- Field 60
+    Until: 15:00,0.15,       !- Field 62
+    Until: 16:00,0.13,       !- Field 64
+    Until: 17:00,0.14,       !- Field 66
+    Until: 21:00,0.07,       !- Field 68
+    Until: 22:00,0.09,       !- Field 70
+    Until: 24:00,0.05,       !- Field 72
+    For: AllOtherDays,       !- Field 74
+    Until: 05:00,0.04,       !- Field 75
+    Until: 06:00,0.07,       !- Field 77
+    Until: 11:00,0.04,       !- Field 79
+    Until: 13:00,0.06,       !- Field 81
+    Until: 14:00,0.09,       !- Field 83
+    Until: 15:00,0.06,       !- Field 85
+    Until: 21:00,0.04,       !- Field 87
+    Until: 22:00,0.07,       !- Field 89
+    Until: 24:00,0.04;       !- Field 91
+  Schedule:Compact,
+    Water Equipment Latent fract sched,  !- Name
+    Until: 24:00,0.05;       !- Field 3
+  Schedule:Compact,
+    Water Equipment Sensible fract sched,  !- Name
+    Until: 24:00,0.2;        !- Field 3
+  Schedule:Compact,
+    SWHSys1 Water Heater Ambient Temperature Schedule Name,  !- Name
+    Until: 24:00,22.0;       !- Field 3
+  Schedule:Compact,
+    Water Equipment Temp Sched,  !- Name
+    Until: 24:00,43.3;       !- Field 3
+  Schedule:Compact,
+    Water Equipment Hot Supply Temp Sched,  !- Name
+  Schedule:Compact,
+    SWHSys1 Water Heater Setpoint Temperature Schedule Name,  !- Name
+    Until: 24:00,60.0;       !- Field 3
+  Schedule:Compact,
+    SWHSys1-Loop-Temp-Schedule,  !- Name
+! ***ECONOMICS***
+!   IN_EIAMonthlyRateGas, Source EIA historical Nov2003 thru Oct2004
+! Indiana 1999 state average electricity emissions factors based on eGRID, 1065, AirData
+! PSI_CS_CommercialElectricService, source http://www.cinergypsi.com/pdfs/RateCS.pdf, effective 2004-05-24
+! PSI_LLF_LowLoadFactorService,source http://www.cinergypsi.com/pdfs/RATELLF.pdf, effective 2004-05-24
+  UtilityCost:Tariff,
+    PSI_LLF_LowLoadFactorService,  !- Name
+    Electricity:Facility,    !- Output Meter Name
+    kWh,                     !- Conversion Factor Choice
+    ,                        !- Energy Conversion Factor
+    ,                        !- Demand Conversion Factor
+    ,                        !- Time of Use Period Schedule Name
+    ,                        !- Season Schedule Name
+    ,                        !- Month Schedule Name
+    HalfHour,                !- Demand Window Length
+    15.00,                   !- Monthly Charge or Variable Name
+    ,                        !- Minimum Monthly Charge or Variable Name
+    ,                        !- Real Time Pricing Charge Schedule Name
+    ,                        !- Customer Baseline Load Schedule Name
+    Comm Elect;              !- Group Name
+  UtilityCost:Charge:Block,
+    AnnualEnergyCharge,      !- Name
+    PSI_LLF_LowLoadFactorService,  !- Tariff Name
+    totalEnergy,             !- Source Variable
+    Annual,                  !- Season
+    EnergyCharges,           !- Category Variable Name
+    ,                        !- Remaining Into Variable
+    ,                        !- Block Size Multiplier Value or Variable Name
+    300,                     !- Block Size 1 Value or Variable Name
+    0.108222,                !- Block 1 Cost per Unit Value or Variable Name
+    700,                     !- Block Size 2 Value or Variable Name
+    0.087021,                !- Block 2 Cost per Unit Value or Variable Name
+    1500,                    !- Block Size 3 Value or Variable Name
+    0.078420,                !- Block 3 Cost per Unit Value or Variable Name
+    remaining,               !- Block Size 4 Value or Variable Name
+    0.058320;                !- Block 4 Cost per Unit Value or Variable Name
+    AnnualDemandBaseCharge,  !- Name
+    Annual,                  !- Season
+    TotalDemand,             !- Block Size Multiplier Value or Variable Name
+    190,                     !- Block Size 1 Value or Variable Name
+    0.0,                     !- Block 1 Cost per Unit Value or Variable Name
+    110,                     !- Block Size 2 Value or Variable Name
+    0.051773,                !- Block 2 Cost per Unit Value or Variable Name
+    remaining,               !- Block Size 3 Value or Variable Name
+    0.046965;                !- Block 3 Cost per Unit Value or Variable Name
+  UtilityCost:Charge:Simple,
+    FuelCostAdjustEnergyCharge,  !- Name
+    Annual,                  !- Season
+    0.002028;                !- Cost per Unit Value or Variable Name
+    QualPollutionControlAdjustEnergyCharge,  !- Name
+    Annual,                  !- Season
+    0.000536;                !- Cost per Unit Value or Variable Name
+    SoxNoxRiderAdjustEnergyCharge,  !- Name
+    Annual,                  !- Season
+    0.001127;                !- Cost per Unit Value or Variable Name
+    DSMRiderAdjustEnergyCharge,  !- Name
+    Annual,                  !- Season
+    -0.000370;               !- Cost per Unit Value or Variable Name
+    PurchPowerTrackerAdjustEnergyCharge,  !- Name
+    Annual,                  !- Season
+    -0.000031;               !- Cost per Unit Value or Variable Name
+    MidwestISOAdjustEnergyCharge,  !- Name
+    Annual,                  !- Season
+    -0.000216;               !- Cost per Unit Value or Variable Name
+    CleanCoalRiderEnergyCharge,  !- Name
+    Annual,                  !- Season
+    0.000833;                !- Cost per Unit Value or Variable Name
+  UtilityCost:Qualify,
+    MinDemand75kw,           !- Name
+    TotalDemand,             !- Variable Name
+    Minimum,                 !- Qualify Type
+    75,                      !- Threshold Value or Variable Name
+    Annual,                  !- Season
+    Count,                   !- Threshold Test
+    12;                      !- Number of Months
+    TaxofeightPercent,       !- Name
+    SubTotal,                !- Source Variable
+    Annual,                  !- Season
+    Taxes,                   !- Category Variable Name
+    0.08;                    !- Cost per Unit Value or Variable Name
+!end  PSI_LLF_LowLoadFactorService
+    PSI_CS_CommercialElectricService,  !- Name
+    ,                        !- Demand Window Length
+    9.40,                    !- Monthly Charge or Variable Name
+    PSI_CS_CommercialElectricService,  !- Tariff Name
+    Annual,                  !- Season
+    0.082409,                !- Block 1 Cost per Unit Value or Variable Name
+    0.072873,                !- Block 2 Cost per Unit Value or Variable Name
+    0.061696,                !- Block 3 Cost per Unit Value or Variable Name
+    0.041179;                !- Block 4 Cost per Unit Value or Variable Name
+    Annual,                  !- Season
+    Annual,                  !- Season
+    Annual,                  !- Season
+    Annual,                  !- Season
+    0.000021;                !- Cost per Unit Value or Variable Name
+    Annual,                  !- Season
+    0.000034;                !- Cost per Unit Value or Variable Name
+    Annual,                  !- Season
+    -0.000203;               !- Cost per Unit Value or Variable Name
+    Annual,                  !- Season
+    0.000807;                !- Cost per Unit Value or Variable Name
+    MaxDemand75kw,           !- Name
+    Maximum,                 !- Qualify Type
+    Annual,                  !- Season
+    1;                       !- Number of Months
+    Annual,                  !- Season
+    IN_EIAMonthlyRateGas,    !- Name
+    Gas:Facility,            !- Output Meter Name
+    MCF,                     !- Conversion Factor Choice
+    0.0,                     !- Monthly Charge or Variable Name
+    Comm Gas;                !- Group Name
+    MonthlyRateGasCharge,    !- Name
+    IN_EIAMonthlyRateGas,    !- Tariff Name
+    Annual,                  !- Season
+    IN_MonthlyGasRates;      !- Cost per Unit Value or Variable Name
+  UtilityCost:Variable,
+    IN_MonthlyGasRates,      !- Name
+    Currency,                !- Variable Type
+    8.22,                    !- January Value
+    7.51,                    !- February Value
+    8.97,                    !- March Value
+    9.01,                    !- April Value
+    9.16,                    !- May Value
+    10.44,                   !- June Value
+    10.32,                   !- July Value
+    10.13,                   !- August Value
+    9.20,                    !- September Value
+    8.18,                    !- October Value
+    7.83,                    !- November Value
+    7.63;                    !- December Value
+    TaxofEightPercent,       !- Name
+    Annual,                  !- Season
+! ***GENERAL REPORTING***
+  OutputControl:ReportingTolerances,
+    0.556,                   !- Tolerance for Time Heating Setpoint Not Met {deltaC}
+    0.556;                   !- Tolerance for Time Cooling Setpoint Not Met {deltaC}
+  Output:SQLite,
+    SimpleAndTabular;        !- Option Type
+  EnvironmentalImpactFactors,
+    0.663,                   !- District Heating Efficiency
+    4.18,                    !- District Cooling COP {W/W}
+    0.585,                   !- Steam Conversion Efficiency
+    80.7272,                 !- Total Carbon Equivalent Emission Factor From N2O {kg/kg}
+    6.2727,                  !- Total Carbon Equivalent Emission Factor From CH4 {kg/kg}
+    0.2727;                  !- Total Carbon Equivalent Emission Factor From CO2 {kg/kg}
+! Indiana electricity source and emission factors based on Deru and Torcellini 2007
+  FuelFactors,
+    Electricity,             !- Existing Fuel Resource Name
+    kg,                      !- Units of Measure
+    ,                        !- Energy per Unit Factor
+    3.546,                   !- Source Energy Factor {J/J}
+    ,                        !- Source Energy Schedule Name
+    3.417E+02,               !- CO2 Emission Factor {g/MJ}
+    ,                        !- CO2 Emission Factor Schedule Name
+    1.186E-01,               !- CO Emission Factor {g/MJ}
+    ,                        !- CO Emission Factor Schedule Name
+    7.472E-01,               !- CH4 Emission Factor {g/MJ}
+    ,                        !- CH4 Emission Factor Schedule Name
+    6.222E-01,               !- NOx Emission Factor {g/MJ}
+    ,                        !- NOx Emission Factor Schedule Name
+    8.028E-03,               !- N2O Emission Factor {g/MJ}
+    ,                        !- N2O Emission Factor Schedule Name
+    1.872E+00,               !- SO2 Emission Factor {g/MJ}
+    ,                        !- SO2 Emission Factor Schedule Name
+    0.0,                     !- PM Emission Factor {g/MJ}
+    ,                        !- PM Emission Factor Schedule Name
+    1.739E-02,               !- PM10 Emission Factor {g/MJ}
+    ,                        !- PM10 Emission Factor Schedule Name
+    0.0,                     !- PM2.5 Emission Factor {g/MJ}
+    ,                        !- PM2.5 Emission Factor Schedule Name
+    0.0,                     !- NH3 Emission Factor {g/MJ}
+    ,                        !- NH3 Emission Factor Schedule Name
+    1.019E-02,               !- NMVOC Emission Factor {g/MJ}
+    ,                        !- NMVOC Emission Factor Schedule Name
+    5.639E-06,               !- Hg Emission Factor {g/MJ}
+    ,                        !- Hg Emission Factor Schedule Name
+    2.778E-05,               !- Pb Emission Factor {g/MJ}
+    ,                        !- Pb Emission Factor Schedule Name
+    0.4309556,               !- Water Emission Factor {L/MJ}
+    ,                        !- Water Emission Factor Schedule Name
+    0,                       !- Nuclear High Level Emission Factor {g/MJ}
+    ,                        !- Nuclear High Level Emission Factor Schedule Name
+    0;                       !- Nuclear Low Level Emission Factor {m3/MJ}
+! Deru and Torcellini 2007
+! Source Energy and Emission Factors for Energy Use in Buildings
+! NREL/TP-550-38617
+! source factor and Higher Heating Values from Table 5
+! post-combustion emission factors for boiler from Table 9 (with factor of 1000 correction for natural gas)
+  FuelFactors,
+    NaturalGas,              !- Existing Fuel Resource Name
+    m3,                      !- Units of Measure
+    37631000,                !- Energy per Unit Factor
+    1.092,                   !- Source Energy Factor {J/J}
+    5.21E+01,                !- CO2 Emission Factor {g/MJ}
+    3.99E-02,                !- CO Emission Factor {g/MJ}
+    1.06E-03,                !- CH4 Emission Factor {g/MJ}
+    4.73E-02,                !- NOx Emission Factor {g/MJ}
+    1.06E-03,                !- N2O Emission Factor {g/MJ}
+    2.68E-04,                !- SO2 Emission Factor {g/MJ}
+    3.59E-03,                !- PM10 Emission Factor {g/MJ}
+    0,                       !- NH3 Emission Factor {g/MJ}
+    2.61E-03,                !- NMVOC Emission Factor {g/MJ}
+    1.11E-07,                !- Hg Emission Factor {g/MJ}
+    2.13E-07,                !- Pb Emission Factor {g/MJ}
+    0,                       !- Water Emission Factor {L/MJ}
+  Curve:Bicubic,
+    WC Screw GTE 300tons Default 90.1-2004 EIR_fPLR,  !- Name
+    -2.737954E-01,           !- Coefficient1 Constant
+    2.822257E-02,            !- Coefficient2 x
+    -8.097657E-05,           !- Coefficient3 x**2
+    9.612284E-01,            !- Coefficient4 y
+    3.029741E-01,            !- Coefficient5 y**2
+    -2.421933E-02,           !- Coefficient6 x*y
+    0.000000E+00,            !- Coefficient7 x**3
+    -3.885224E-02,           !- Coefficient8 y**3
+    0.000000E+00,            !- Coefficient9 x**2*y
+    0.000000E+00,            !- Coefficient10 x*y**2
+    18.54,                   !- Minimum Value of x
+    31.63,                   !- Maximum Value of x
+    0.20,                    !- Minimum Value of y
+    1.02;                    !- Maximum Value of y
+  OutputControl:Table:Style,
+    XML;                    !- Column Separator
+  Output:Table:SummaryReports,
+    AllSummaryAndMonthly;              !- Report 1 Name
+  Output:Meter,Electricity:Facility,hourly;
+  Output:Meter,Heating:Electricity,hourly;
+  Output:Meter,Cooling:Electricity,hourly;
+  Output:Meter,InteriorLights:Electricity,hourly;
+  Output:Meter,ExteriorLights:Electricity,hourly;
+  Output:Meter,InteriorEquipment:Electricity,hourly;
+  Output:Meter,ExteriorEquipment:Electricity,hourly;
+  Output:Meter,Fans:Electricity,hourly;
+  Output:Meter,Pumps:Electricity,hourly;
+  Output:Meter,HeatRejection:Electricity,hourly;
+  Output:Meter,Humidifier:Electricity,hourly;
+  Output:Meter,Refrigeration:Electricity,hourly;
+  Output:Meter,WaterSystems:Electricity,hourly;
+  Output:Meter,Gas:Facility,hourly;
+  Output:Meter,Heating:Gas,hourly;
+  Output:Meter,InteriorEquipment:Gas,hourly;
+  Output:Meter,WaterSystems:Gas,hourly;
Added: SwiftApps/gocat/locatewrap.sh
--- SwiftApps/gocat/locatewrap.sh	                        (rev 0)
+++ SwiftApps/gocat/locatewrap.sh	2014-03-13 15:57:00 UTC (rev 7704)
@@ -0,0 +1,31 @@
+#!/bin/bash -x
+# Usage: $0 <dataset_name> <tagname> <tagname> ...
+#e.g. sh locatewrap.sh cofeemug color size material
+# Required: Env variable catloc pointing to the directory containing catalog.py
+if [ $# -le 1 ]
+then
+ echo "Usage: $0 <dataset_name> <tagnamei1> LIKE <value1> <tagname2> LIKE <valu2> ..."
+ exit 1
+fi
+dsetname=$1
+shift
+for tagvalpair in "$@"
+do
+  tagname=`echo $tagvalpair|awk -F= '{print $1}'`
+  tagval=`echo $tagvalpair|awk -F= '{print $2}'`
+  python $catloc/catalog.py -text query_datasets $catid name EQUAL $dsetname
+  exprstr="{\"name\":\"$dsetname\"}"
+  retstr=$(python $catloc/catalog.py create_dataset $catid $exprstr)
+  python $catloc/catalog.py create_annotation_def $catid "$tagname" 'text'
+  dsetid=`echo $retstr |awk -F, '{print $2}'`
+  python $catloc/catalog.py add_dataset_annotation $catid $dsetid "{\"$tagname\":\"$tagval\"}"
+done
Modified: SwiftApps/swift-galaxy/README
--- SwiftApps/swift-galaxy/README	2014-03-13 15:30:07 UTC (rev 7703)
+++ SwiftApps/swift-galaxy/README	2014-03-13 15:57:00 UTC (rev 7704)
@@ -14,6 +14,22 @@
 This document can be found http://www.mcs.anl.gov/~ketan/swiftgalaxy.html[here].
+Description of the Swift-Galaxy `foreach` tool
+There are two ways, the foreach Swift tool can be utilized. First, over a range
+of numbers. The tool is used to run a Swift foreach loop over a range of
+numbers for any arbitrary executable. The executable will run with number in
+range as commandline argument, one at a time. User can add arbitrary string
+arguments in addition to the number argument to the call to executable.
+The second version runs the foreach loop over a list of items. These items can
+be file references or simple strings. The tool will pass one item at a time to
+the executable as argument parameter and run them all in parallel. This is
+similar to the above described number range except that the iteration takes
+place over a list of items provided as a file.
 How To
@@ -42,39 +58,49 @@
 Screenshots
-The following screenshot shows overall look-and-feel of the Swift-Galaxy tool in the Galaxy web GUI.
+The following screenshot shows overall look-and-feel of the Swift-Galaxy tool
+in the Galaxy web GUI.
 image::./screenshots/overall.png["swift-galaxy screenshot", width=600, align="center"]
-The following screenshot shows execution location selector. User can select one or more execution locations from the list as their target execution site.
+The following screenshot shows execution location selector. User can select one
+or more execution locations from the list as their target execution site.
 image::./screenshots/execloc.png["execution location selector screenshot", width=200, align="center"]
-The following screenshot shows a dialog box to add Swift-level commandline arguments to be passed to the script.
+The following screenshot shows a dialog box to add Swift-level commandline
+arguments to be passed to the script.
 image::./screenshots/swift-level-args.png["swift-args screenshot", width=200, align="center"]
-The following screenshot shows a selection dropdown list to chose the execution interpreter from. The interpreters currently supported and tested are shell, java and python. Upcoming are R and matlab.
+The following screenshot shows a selection dropdown list to chose the execution
+interpreter from. The interpreters currently supported and tested are shell,
+java and python. Upcoming are R and matlab.
 image::./screenshots/execution-interpreter.png["interpreter screenshot", width=150, align="center"]
-The following screenshot shows the selection for an executable. User can upload an executable and select it from the list.
+The following screenshot shows the selection for an executable. User can upload
+an executable and select it from the list.
 image::./screenshots/executable.png["executable screenshot", width=200, align="center"]
-The following screenshot shows a selection for range of numbers or list of items to chose from. User can select one and the corresponding dialog box will appear below.
+The following screenshot shows a selection for range of numbers or list of
+items to chose from. User can select one and the corresponding dialog box will
+appear below.
 image::./screenshots/rangeorlist.png["select range or list screenshot", width=150, align="center"]
-The following screenshot shows a dialog for string or file type arguments. A user can add string and filetype arguments to their executable and the commandline will be built accordingly.
+The following screenshot shows a dialog for string or file type arguments. A
+user can add string and filetype arguments to their executable and the
+commandline will be built accordingly.
 image::./screenshots/string-or-fileargs.png["string or fileargs screenshot", width=250, align="center"]
-The following screenshot shows a dialog box to enter the directory location for results of execution. The Swift output files will be placed here:
+The following screenshot shows a dialog box to enter the directory location for
+results of execution. The Swift output files will be placed here:
 image::./screenshots/outlocation.png["output location screenshot", width=250, align="center"]
 An example
@@ -120,17 +146,3 @@
 Step 6. For examples of other Galaxy-Swift tools, look into the swift directoty.
-Description of the Swift-Galaxy `foreach` tool
-There are two ways, the foreach Swift tool can be utilized. First, over a range
-of numbers. The tool is used to run a Swift foreach loop over a range of
-numbers for any arbitrary executable. The executable will run with number in
-range as commandline argument, one at a time. User can add arbitrary string
-arguments in addition to the number argument to the call to executable.
-The second version runs the foreach loop over a list of items. These items can
-be file references or simple strings. The tool will pass one item at a time to
-the executable as argument parameter and run them all in parallel. This is
-similar to the above described number range except that the iteration takes
-place over a list of items provided as a file.
