[Swift-commit] r7646 - SwiftApps/cloud
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Fri Mar 7 18:53:34 CST 2014
Author: ketan
Date: 2014-03-07 18:53:34 -0600 (Fri, 07 Mar 2014)
New Revision: 7646
Modified:
   SwiftApps/cloud/rem
Log:
rem node testing
Modified: SwiftApps/cloud/rem
--- SwiftApps/cloud/rem	2014-03-08 00:04:31 UTC (rev 7645)
+++ SwiftApps/cloud/rem	2014-03-08 00:53:34 UTC (rev 7646)
@@ -1,4 +1,50 @@
-#!/usr/bin/env python
+#!/bin/bash
-# Add cloud resources to existing pool
+#set -x
+usage (){
+    printf "Usage: %s  -a \"<space separated ip addresses in quotes>\" | -n <nodecount> \n" "${0}"
+rem_instance() {
+      MACHINE=$1
+      #ec2din | grep 54.243.24.154 | awk '{print $2}'
+      instanceid=$(ec2din | grep $1 | awk '{print $2}')
+      ec2kill $instanceid
+      # Connect directly
+   return 0
+rembyip (){
+    echo "$@"
+    for i in "$@" ; do
+        rem_instance $i
+    done
+rembynum (){
+    #ec2-run-instance -k <key-name> -n 1 -g <groupname> --instance-type <type> <ami-id>
+    for i in $(seq 1 $1); do
+        ip=$(ec2din | grep running | head -1 | awk '{print $15}')
+        rem_instance "${ip}"
+        sleep 15
+    done
+#use getopts to check user options
+while getopts ":a:n:" o ; do
+    case $o in
+    a)
+        rembyip ${OPTARG}
+    n)
+        rembynum ${OPTARG}
+        usage
+    esac
+done
