[Swift-commit] r7641 - branches/release-0.94/bin
ketan at ci.uchicago.edu
Fri Mar 7 16:41:45 CST 2014
Author: ketan
Date: 2014-03-07 16:41:45 -0600 (Fri, 07 Mar 2014)
New Revision: 7641
Modified:
branches/release-0.94/bin/start-coaster-service
Log:
adding additional env var to conf
Modified: branches/release-0.94/bin/start-coaster-service
--- branches/release-0.94/bin/start-coaster-service 2014-03-07 22:26:53 UTC (rev 7640)
+++ branches/release-0.94/bin/start-coaster-service 2014-03-07 22:41:45 UTC (rev 7641)
@@ -86,6 +86,7 @@
esac
done
# Determine the location of needed files
export SWIFT_BIN="$( cd "$( dirname "$0" )" && pwd )"
if [ -z "$WORKER" ]; then
@@ -95,6 +96,7 @@
export PID_FILE="$HOME/.swift/.coaster-service-pids"
export COASTER_SERVICE="$SWIFT_BIN/coaster-service"
export LOG="start-coaster-service.log"
mkdir -p "$HOME/.swift" || crash "Unable to create $HOME/.swift"
# Import settings
@@ -106,6 +108,12 @@
crash "Cannot find coaster-service.conf!"
fi
+#clean up coaster conf
+sed -i '/export WORKERURL=/d' $CONFIG_FILE
+sed -i '/export PID_FILE=/d' $CONFIG_FILE
+sed -i '/export LOG=/d' $CONFIG_FILE
+sed -i '/export LOCAL_PORT=/d' $CONFIG_FILE
echo "Start-coaster-service..."
echo "Configuration: $CONFIG_FILE"
source $CONFIG_FILE
@@ -189,6 +197,14 @@
export EXECUTIONURL="http://$IPADDR:$SERVICE_PORT"
export WORKERURL="http://$IPADDR:$LOCAL_PORT"
+echo "export WORKERURL=\"http://$IPADDR:$LOCAL_PORT\"" >> $CONFIG_FILE
+echo "export PID_FILE=\"$HOME/.swift/.coaster-service-pids\"" >> $CONFIG_FILE
+echo "export LOG=\"start-coaster-service.log\"" >> $CONFIG_FILE
+echo "export LOCAL_PORT=\"$LOCAL_PORT\"" >> $CONFIG_FILE
echo Generating sites.xml
if [ -f "gensites.template" ]; then
gensites $( cat gensites.template ) -p $CONFIG_FILE > sites.xml
More information about the Swift-commit
