[Swift-commit] cog r3878
swift at ci.uchicago.edu
Wed Mar 5 15:10:03 CST 2014
r3878 | yadunand | 2014-03-05 15:05:14 -0600 (Wed, 05 Mar 2014) | 5 lines
Bug fix for coaster settings getting mangled.
String references used to set values in map, was getting overwritten.
Index: modules/provider-coaster-c-client/src/CoasterSWIG.cpp
--- modules/provider-coaster-c-client/src/CoasterSWIG.cpp (revision 3877)
+++ modules/provider-coaster-c-client/src/CoasterSWIG.cpp (working copy)
@@ -48,6 +48,7 @@
int CoasterSWIGClientSettings(CoasterClient *client, char *settings)
Settings s;
+ int kv_index = 0;
cout << "CoasterSWIGClientSettings(" << settings << ")" <<endl;
cout << "Client : [" << (void *) client << "]"<<endl;
@@ -55,21 +56,30 @@
// K1=V1, K2=V2 is the format of the settings string
std::vector<std::string> elems;
std::stringstream ss(settings);
- std::string item, key, value;
+ std::string item;
+ // Assumed to not have more than 50 coaster settings
+ std::string kv_pair[50][2];
while (std::getline(ss, item, ',')) {
elems.push_back(item);
std::stringstream kv(item);
std::string kv_item;
- std::getline(kv, kv_item, '=');
- key = kv_item;
- std::getline(kv, kv_item);
- value = kv_item;
- s.set(key, value);
- cout << "Key,Value : " << key <<", "<<value << endl;
+ std::getline(kv, kv_pair[kv_index][0], '=');
+ std::getline(kv, kv_pair[kv_index][1]);
+ s.set(kv_pair[kv_index][0], kv_pair[kv_index][1]);
+ cout << "Key,Value : " << kv_pair[kv_index][0] <<", "<< kv_pair[kv_index][1] << endl;
+ kv_index++;
client->setOptions(s);
+ /* ONLY FOR DEBUGGING
+ map<string*, const char*>::iterator i;
+ map<string *, const char*>* m = s.getSettings();
+ for (i = m->begin(); i != m->end(); i++) {
+ string ss;
+ cout << "Key, Value SET : " << *(i->first) << " : " << i->second << endl;
return 0;
More information about the Swift-commit
