[Swift-commit] r7994 - trunk/src/org/griphyn/vdl/karajan/lib
hategan at ci.uchicago.edu
Fri Jul 11 23:38:16 CDT 2014
Author: hategan
Date: 2014-07-11 23:38:16 -0500 (Fri, 11 Jul 2014)
New Revision: 7994
Modified:
trunk/src/org/griphyn/vdl/karajan/lib/Execute.java
Log:
fixed job logging
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Execute.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Execute.java 2014-07-12 04:36:23 UTC (rev 7993)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Execute.java 2014-07-12 04:38:16 UTC (rev 7994)
@@ -139,14 +139,14 @@
logger.debug(task);
logger.debug("Submitting task " + task);
- String jobid = this.jobid.getValue(stack);
if (logger.isInfoEnabled()) {
+ String jobid = this.jobid.getValue(stack);
JobSpecification spec = (JobSpecification) task.getSpecification();
- logger.info(buildTaskInfoString(task, spec));
+ logger.info(buildTaskInfoString(task, jobid, spec));
- private String buildTaskInfoString(Task task, JobSpecification spec) {
+ private String buildTaskInfoString(Task task, String jobid, JobSpecification spec) {
StringBuilder sb = new StringBuilder();
sb.append("JOB_TASK jobid=");
sb.append(jobid);
More information about the Swift-commit
