[Swift-commit] r7532 - SwiftApps/swift-galaxy/swift
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Thu Jan 30 20:03:11 CST 2014
Author: ketan
Date: 2014-01-30 20:03:11 -0600 (Thu, 30 Jan 2014)
New Revision: 7532
Added:
   SwiftApps/swift-galaxy/swift/swift-skeleton.sh
Modified:
   SwiftApps/swift-galaxy/swift/swiftforeachlist.sh
   SwiftApps/swift-galaxy/swift/swiftforeachlist.xml
   SwiftApps/swift-galaxy/swift/swiftforeachrange.sh
   SwiftApps/swift-galaxy/swift/swiftforeachrange.xml
Log:
user controlled outdir
Added: SwiftApps/swift-galaxy/swift/swift-skeleton.sh
--- SwiftApps/swift-galaxy/swift/swift-skeleton.sh	                        (rev 0)
+++ SwiftApps/swift-galaxy/swift/swift-skeleton.sh	2014-01-31 02:03:11 UTC (rev 7532)
@@ -0,0 +1,187 @@
+#!/bin/bash
+#set -x
+set -e
+site=$1
+data=$2
+n=$3
+outdir=$4
+logfile=$5
+htmlfile=$6
+mkdir -p $outdir
+swift=`which swift`
+# use "here" document for configs
+cat << EOF > /tmp/script.swift
+# Place your Swift script here
+# Make sure all data references are full-path
+EOF
+case "$site" in
+midway )
+cat << 'EOF' > /tmp/sites.xml
+<?xml version="1.0" encoding="UTF-8"?>
+<config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
+ <pool handle="midway">
+  <execution provider="coaster" url="swift.rcc.uchicago.edu" jobmanager="ssh-cl:slurm"/>
+  <profile namespace="globus" key="queue">sandyb</profile>
+  <profile namespace="globus" key="jobsPerNode">16</profile>
+  <profile namespace="globus" key="maxWalltime">02:00:00</profile>
+  <profile namespace="globus" key="maxTime">7500</profile>
+  <profile namespace="globus" key="highOverAllocation">100</profile>
+  <profile namespace="globus" key="lowOverAllocation">100</profile>
+  <profile namespace="globus" key="slots">2</profile>
+  <profile namespace="globus" key="maxNodes">1</profile>
+  <profile namespace="globus" key="nodeGranularity">1</profile>
+  <profile namespace="karajan" key="jobThrottle">.31</profile>
+  <profile namespace="karajan" key="initialScore">10000</profile>
+  <workdirectory>/tmp/swift.work</workdirectory>
+ </pool>
+</config>
+EOF
+uc3 )
+ <pool handle="uc3">
+   <execution provider="coaster" url="uc3-sub.uchicago.edu" jobmanager="ssh-cl:condor"/>
+   <!--<execution provider="coaster" jobmanager="local:condor"/>-->
+   <profile namespace="karajan" key="jobThrottle">.09</profile>
+   <profile namespace="karajan" key="initialScore">1000</profile>
+   <profile namespace="globus"  key="jobsPerNode">1</profile>
+   <profile namespace="globus"  key="maxWalltime">3600</profile>
+   <profile namespace="globus"  key="slots">1</profile>
+   <profile namespace="globus"  key="condor.Requirements">UidDomain == "osg-gk.mwt2.org"</profile>
+   <profile namespace="globus"  key="condor.+AccountingGroup">"group_friends.{env.USER}"</profile>
+   <profile namespace="globus"  key="jobType">nonshared</profile>
+   <filesystem provider="local" url="none" />
+   <!--<workdirectory>/home/maheshwari/test/catsn/swift.work</workdirectory>-->
+ </pool>
+</config>
+EOF
+stampede )
+<pool handle="stampede">
+  <execution provider="coaster" jobmanager="ssh-cl:slurm" url="stampede.tacc.utexas.edu"/>
+  <filesystem provider="local"/>
+  <profile namespace="globus" key="ppn">16</profile>
+  <profile namespace="globus" key="project">TG-STA110005S</profile>
+  <profile namespace="globus" key="queue">normal</profile>
+  <profile namespace="globus" key="slurm.mail-user">ketancmaheshwari at gmail.com</profile>
+  <profile namespace="globus" key="slurm.mail-type">ALL</profile>
+  <profile namespace="globus" key="maxTime">8000</profile>
+  <profile namespace="karajan" key="jobThrottle">.15</profile>
+</pool>
+</config>
+EOF
+localhost )
+<pool handle="localhost">
+  <execution provider="local" jobmanager="local:local"/>
+  <!--<workdirectory>/home/kcm92/powergridapps/swiftscripts/swift.work</workdirectory>-->
+  <profile namespace="karajan" key="jobThrottle">0.31</profile>
+</pool>
+</config>
+EOF
+echo "defaulting to localhost"
+</pool>
+</config>
+EOF
+esac
+cat << 'EOF' > /tmp/cf
+use.provider.staging=true
+wrapperlog.always.transfer=true
+execution.retries=1
+provider.staging.pin.swiftfiles=false
+sitedir.keep=true
+lazy.errors=false
+EOF
+cat << 'EOF' > /tmp/tc
+localhost echo echo
+localhost cat cat
+stampede echo echo
+stampede cat cat
+uc3 echo echo
+uc3 cat cat
+midway echo echo
+midway cat cat
+EOF
+$swift -sites.file /tmp/sites.xml -tc.file /tmp/tc -config /tmp/cf /tmp/catsn.swift -n=$n -data=$data 2> $logfile
+EXITCODE=$?
+#for i in `find $outdir`
+#do
+#  lastfile=$i
+#done
+#bname=`basename $lastfile`
+cat << EOF > $htmlfile
+<!DOCTYPE HTML>
+<html xmlns="http://www.w3.org/1999/xhtml">
+<head>
+  <title>Catsn output</title>
+</head>
+<body>
+<h2>Swift run trace plots</h2>
+<a href="activeplot.png" alt="active plot">active plot</a>
+<a href="cumulativeplot.png" alt="cumulative plot">cumulative plot</a>
+<h2>Browse output of catsn application</h2>
+`for i in \`find $outdir -type f\`; do echo "<a href=\`basename $i\`>Output: \`basename $i\`</a><br/>"; done`
+</body>
+</html>
+EOF
+if [ "$EXITCODE" -ne "0" ]; then
+       cat $logfile >&2
+fi
+exit $EXITCODE
Property changes on: SwiftApps/swift-galaxy/swift/swift-skeleton.sh
___________________________________________________________________
Added: svn:executable
Modified: SwiftApps/swift-galaxy/swift/swiftforeachlist.sh
--- SwiftApps/swift-galaxy/swift/swiftforeachlist.sh	2014-01-30 23:35:08 UTC (rev 7531)
+++ SwiftApps/swift-galaxy/swift/swiftforeachlist.sh	2014-01-31 02:03:11 UTC (rev 7532)
@@ -15,6 +15,8 @@
 shift
 listfile=$1
 shift
+outloc=$1
+shift
 logfile=$1
 shift
 outlistfile=$1
@@ -30,8 +32,8 @@
 file listfile<"$listfile">;
 string list[] = readData(listfile);
 foreach l, i in list{
-    file out <single_file_mapper; file=@strcat("$HOME/swift-sandbox/", l, ".", i, ".out")>;
-    file err <single_file_mapper; file=@strcat("$HOME/swift-sandbox/", l, ".", i, ".err")>;
+    file out <single_file_mapper; file=@strcat("$outloc", "/", l, ".", i, ".out")>;
+    file err <single_file_mapper; file=@strcat("$outloc", "/", l, ".", i, ".err")>;
     (out,err) = anapp(exec, l);
 EOF
Modified: SwiftApps/swift-galaxy/swift/swiftforeachlist.xml
--- SwiftApps/swift-galaxy/swift/swiftforeachlist.xml	2014-01-30 23:35:08 UTC (rev 7531)
+++ SwiftApps/swift-galaxy/swift/swiftforeachlist.xml	2014-01-31 02:03:11 UTC (rev 7532)
@@ -6,6 +6,7 @@
             $site
             $executable
             $listfile
+            $outloc
             $log_file
             $outlist
   </command>
@@ -20,6 +21,7 @@
     <param format="sh" name="executable" type="data" label="Executable"/>
     <param format="data" name="listfile" type="data" label="List file"/>
+    <param name="outloc" size="50" type="text" value="$HOME/swift-sandbox" label="location for output files" help="Swift will write output files here on disc"></param>
     <conditional name="configuration">
         <param name="mode" type="select" label="Swift configuration">
Modified: SwiftApps/swift-galaxy/swift/swiftforeachrange.sh
--- SwiftApps/swift-galaxy/swift/swiftforeachrange.sh	2014-01-30 23:35:08 UTC (rev 7531)
+++ SwiftApps/swift-galaxy/swift/swiftforeachrange.sh	2014-01-31 02:03:11 UTC (rev 7532)
@@ -32,8 +32,8 @@
 file exec<"$executable">;
 foreach i in [$rstart:$rend:$stepsize]{
-    file out <single_file_mapper; file=@strcat("$HOME/swift-sandbox/", i, ".out")>;
-    file err <single_file_mapper; file=@strcat("$HOME/swift-sandbox/", i, ".err")>;
     (out,err) = anapp(exec, i);
 EOF
Modified: SwiftApps/swift-galaxy/swift/swiftforeachrange.xml
--- SwiftApps/swift-galaxy/swift/swiftforeachrange.xml	2014-01-30 23:35:08 UTC (rev 7531)
+++ SwiftApps/swift-galaxy/swift/swiftforeachrange.xml	2014-01-31 02:03:11 UTC (rev 7532)
@@ -8,6 +8,7 @@
             $rstart
             $rend
             $stepsize
+            $outloc
             $logfile
             $outlist
   </command>
@@ -26,6 +27,8 @@
     <param name="rend" size="2" type="integer"  value="9" label="end"/>
     <param name="stepsize" size="2" type="integer"  value="1" label="stepsize"/>
           <option value="default">default configuration</option>
