[Swift-commit] r7463 - branches/release-0.95/docs/userguide
davidk at ci.uchicago.edu
Wed Jan 8 16:13:42 CST 2014
Author: davidk
Date: 2014-01-08 16:13:41 -0600 (Wed, 08 Jan 2014)
New Revision: 7463
Added:
branches/release-0.95/docs/userguide/configuration
branches/release-0.95/docs/userguide/debugging
branches/release-0.95/docs/userguide/gettingStarted
Removed:
branches/release-0.95/docs/userguide/app_procedures
branches/release-0.95/docs/userguide/build_options
branches/release-0.95/docs/userguide/clustering
branches/release-0.95/docs/userguide/commands
branches/release-0.95/docs/userguide/configuration_properties
branches/release-0.95/docs/userguide/howto_tips
branches/release-0.95/docs/userguide/images
branches/release-0.95/docs/userguide/kickstart
branches/release-0.95/docs/userguide/log-processing
branches/release-0.95/docs/userguide/mappers
branches/release-0.95/docs/userguide/reliability_mechanisms
branches/release-0.95/docs/userguide/site_catalog
branches/release-0.95/docs/userguide/transformation_catalog
Modified:
branches/release-0.95/docs/userguide/language
branches/release-0.95/docs/userguide/overview
branches/release-0.95/docs/userguide/userguide.txt
Log:
Updated userguide
Deleted: branches/release-0.95/docs/userguide/app_procedures
--- branches/release-0.95/docs/userguide/app_procedures 2014-01-08 22:04:50 UTC (rev 7462)
+++ branches/release-0.95/docs/userguide/app_procedures 2014-01-08 22:13:41 UTC (rev 7463)
@@ -1,568 +0,0 @@
-Executing app procedures
-This section describes how Swift executes app procedures, and
-requirements on the behaviour of application programs used in app
-procedures. These requirements are primarily to ensure that the Swift
-can run your application in different places and with the various fault
-tolerance mechanisms in place.
-Mapping of app semantics into unix process execution semantics
-This section describes how an app procedure invocation is translated
-into a (remote) unix process execution. It does not describe the
-mechanisms by which Swift performs that translation; that is described
-in the next section.
-In this section, this example Swift script is used for reference:
-type file;
-app (file o) count(file i) {
- wc @i stdout=@o;
-file q <"input.txt">;
-file r <"output.txt">;
-The executable for wc will be looked up in tc.data.
-This unix executable will then be executed in some application
-procedure workspace. This means:
-Each application procedure workspace will have an application workspace
-directory. (TODO: can collapse terms application procedure workspace
-and application workspace directory ?
-This application workspace directory will not be shared with any other
-application procedure execution attempt; all application procedure
-execution attempts will run with distinct application procedure
-workspaces. (for the avoidance of doubt: If a Swift script procedure
-invocation is subject to multiple application procedure execution
-attempts (due to Swift-level restarts, retries or replication) then each
-of those application procedure execution attempts will be made in a
-different application procedure workspace. )
-The application workspace directory will be a directory on a POSIX
-filesystem accessible throughout the application execution by the
-application executable.
-Before the application executable is executed:
- * The application workspace directory will exist.
- * The input files will exist inside the application workspace
- directory (but not necessarily as direct children; there may be
- subdirectories within the application workspace directory).
- * The input files will be those files mapped to input parameters
- of the application procedure invocation. (In the example, this
- means that the file input.txt will exist in the application
- workspace directory)
- * For each input file dataset, it will be the case that @filename
- or @filenames invoked with that dataset as a parameter will
- return the path relative to the application workspace directory
- for the file(s) that are associated with that dataset. (In the
- example, that means that @i will evaluate to the path input.txt)
- * For each file-bound parameter of the Swift procedure invocation,
- the associated files (determined by data type?) will always exist.
- * The input files must be treated as read only files. This may or
- may not be enforced by unix file system permissions. They may or
- may not be copies of the source file (conversely, they may be
- links to the actual source file).
-During/after the application executable execution, the following must
-be true:
- * If the application executable execution was successful (in the
- opinion of the application executable), then the application
- executable should exit with unix return code 0; if the
- application executable execution was unsuccessful (in the opinion
- of the application executable), then the application executable
- should exit with unix return code not equal to 0.
- * Each file mapped from an output parameter of the Swift script
- procedure call must exist. Files will be mapped in the same way as
- for input files.
- * The output subdirectories will be precreated
- before execution by Swift if defined within a Swift script such as the
- location attribute of a mapper. App executables expect to make them if
- they are referred to in the wrapper scripts.
- * Output produced by running the application executable on some
- inputs should be the same no matter how many times, when or where
- that application executable is run. 'The same' can vary depending
- on application (for example, in an application it might be
- acceptable for a PNG->JPEG conversion to produce different,
- similar looking, output jpegs depending on the environment)
-Things to not assume:
- * Anything about the path of the application workspace directory
- * That either the application workspace directory will be deleted or
- will continue to exist or will remain unmodified after execution
- has finished
- * That files can be passed between application procedure
- invocations through any mechanism except through files known to
- Swift through the mapping mechanism (there is some exception here
- for external datasets - there are a separate set of assertions
- that hold for external datasets)
- * That application executables will run on any particular site of
- those available, or than any combination of applications will run
- on the same or different sites.
-How Swift implements the site execution model
-This section describes the implementation of the semantics described in
-the previous section.
-Swift executes application procedures on one or more sites.
-Each site consists of:
- * worker nodes. There is some execution mechanism through which
- the Swift client side executable can execute its wrapper script
- on those worker nodes. This is commonly GRAM or Falkon or coasters.
- * a site-shared file system. This site shared filesystem is
- accessible through some file transfer mechanism from the Swift
- client side executable. This is commonly GridFTP or coasters. This
- site shared filesystem is also accessible through the posix file
- system on all worker nodes, mounted at the same location as seen
- through the file transfer mechanism. Swift is configured with the
- location of some site working directory on that site-shared file
- system.
-There is no assumption that the site shared file system for one site is
-accessible from another site.
-For each workflow run, on each site that is used by that run, a run
-directory is created in the site working directory, by the Swift client
-side.
-In that run directory are placed several subdirectories:
- * shared/ - site shared files cache
- * kickstart/ - when kickstart is used, kickstart record files for
- each job that has generated a kickstart record.
- * info/ - wrapper script log files
- * status/ - job status files
- * jobs/ - application workspace directories (optionally placed
- here - see below)
-Application execution looks like this:
-For each application procedure call:
-The Swift client side selects a site; copies the input files for that
-procedure call to the site shared file cache if they are not already in
-the cache, using the file transfer mechanism; and then invokes the
-wrapper script on that site using the execution mechanism.
-The wrapper script creates the application workspace directory; places
-the input files for that job into the application workspace directory
-using either cp or ln -s (depending on a configuration option);
-executes the application unix executable; copies output files from the
-application workspace directory to the site shared directory using cp;
-creates a status file under the status/ directory; and exits,
-returning control to the Swift client side. Logs created during the
-execution of the wrapper script are stored under the info/ directory.
-The Swift client side then checks for the presence of and deletes a
-status file indicating success; and copies files from the site shared
-directory to the appropriate client side location.
-The job directory is created (in the default mode) under the jobs/
-directory. However, it can be created under an arbitrary other path,
-which allows it to be created on a different file system (such as a
-worker node local file system in the case that the worker node has a
-local file system).
-image:swift-site-model.png[]
-Technical overview of the Swift architecture
-This section attempts to provide a technical overview of the Swift
-architecture.
-Execution layer
-The execution layer causes an application program (in the form of a unix
-executable) to be executed either locally or remotely.
-The two main choices are local unix execution and execution through
-GRAM. Other options are available, and user provided code can also be
-plugged in.
-The kickstart utility can be used to capture environmental
-information at execution time to aid in debugging and provenance capture.
-Swift script language compilation layer
-Step i: text to XML intermediate form parser/processor. parser written
-in ANTLR - see resources/VDL.g. The XML Schema Definition (XSD) for the
-intermediate language is in resources/XDTM.xsd.
-Step ii: XML intermediate form to Karajan workflow. Karajan.java - reads
-the XML intermediate form. compiles to karajan workflow language - for
-example, expressions are converted from Swift script syntax into Karajan
-syntax, and function invocations become karajan function invocations
-with various modifications to parameters to accomodate return parameters
-and dataset handling.
-Swift/karajan library layer
-Some Swift functionality is provided in the form of Karajan libraries
-that are used at runtime by the Karajan workflows that the Swift
-compiler generates.
-Ways in which Swift can be extended
-Swift is extensible in a number of ways. It is possible to add mappers
-to accomodate different filesystem arrangements, site selectors to
-change how Swift decides where to run each job, and job submission
-interfaces to submit jobs through different mechanisms.
-A number of mappers are provided as part of the Swift release and
-documented in the mappers section. New mappers can be
-implemented in Java by implementing the org.griphyn.vdl.mapping.Mapper
-interface. The Swift tutorial
-<http://www.ci.uchicago.edu/swift/guides/tutorial.php> contains a simple
-example of this.
-Swift provides a default site selector, the Adaptive Scheduler. New site
-selectors can be plugged in by implementing the
-org.globus.cog.karajan.scheduler.Scheduler interface and modifying
-libexec/scheduler.xml and etc/karajan.properties to refer to the new
-scheduler.
-Execution providers and filesystem providers, which allow to Swift to
-execute jobs and to stage files in and out through mechanisms such as
-GRAM and GridFTP can be implemented as Java CoG kit providers.
-Function reference
-This section details functions that are available for use in the
-Swift scripting language.
- at arg
-Takes a command line parameter name as a string parameter and an
-optional default value and returns the value of that string parameter
-from the command line. If no default value is specified and the command
-line parameter is missing, an error is generated. If a default value is
-specified and the command line parameter is missing, @arg will return
-the default value.
-Command line parameters recognized by @arg begin with exactly one
-hyphen and need to be positioned after the script name.
-For example:
-trace(@arg("myparam"));
-trace(@arg("optionalparam", "defaultvalue"));
-$ swift arg.swift -myparam=hello
-Swift v0.3-dev r1674 (modified locally)
-RunID: 20080220-1548-ylc4pmda
-Swift trace: defaultvalue
-Swift trace: hello
- at extractInt
- at extractInt(file) will read the specified file, parse an integer from
-the file contents and return that integer.
- at extractFloat
-Similar to @extractInt, @extractFloat(file) will read the specified file, parse a float from
-the file contents and return that float.
- at filename
- at filename(v) will return a string containing the filename(s) for the
-file(s) mapped to the variable v. When more than one filename is
-returned, the filenames will be space separated inside a single string
-return value.
- at filenames
- at filenames(v) will return multiple values (!) containing the
-filename(s) for the file(s) mapped to the variable v. (compare to
- at filename)
- at regexp
- at regexp(input,pattern,replacement) will apply regular expression
-substitution using the Java java.util.regexp API
-<http://java.sun.com/j2se/1.4.2/docs/api/java/util/regex/Pattern.html>.
-For example:
-string v = @regexp("abcdefghi", "c(def)g","monkey");
-will assign the value "abmonkeyhi" to the variable v.
- at sprintf
- at sprintf(spec, variable list) will generate a string based on the specified format.
-Example: string s = @sprintf("\t%s\n", "hello");
-Format specifiers
-[width="100%",frame="topbot"]
-|%%| % sign
-|%M| Filename output (waits for close)
-|%p| Format variable according to an internal format
-|%b| Boolean output
-|%f| Float output
-|%i| int output
-|%s| String output
-|%k| Variable sKipped, no output
-|%q| Array output
- at strcat
- at strcat(a,b,c,d,...) will return a string containing all of the
-strings passed as parameters joined into a single string. There may be
-any number of parameters.
-The + operator concatenates two strings: @strcat(a,b) is the same as
-a + b
- at strcut
- at strcut(input,pattern) will match the regular expression in the
-pattern parameter against the supplied input string and return the
-section that matches the first matching parenthesised group.
-For example:
-string t = "my name is John and i like puppies.";
-string name = @strcut(t, "my name is ([^ ]*) ");
-string out = @strcat("Your name is ",name);
-trace(out);
-This will output the message: Your name is John.
- at strjoin
- at strjoin(array, delimiter) will combine the elements of an array
-into a single string separated by a given delimiter. The array
-passed to @strjoin must be of a primitive type (string, int, float,
-or boolean). It will not join the contents of an array of files.
-Example:
-string test[] = ["this", "is", "a", "test" ];
-string mystring = @strjoin(test, " ");
-tracef("%s\n", mystring);
-This will print the string "this is a test".
- at strsplit
- at strsplit(input,pattern) will split the input string based on
-separators that match the given pattern and return a string array.
-Example:
-string words[] = @strsplit(t, "\\s");
-foreach word in words {
- trace(word);
-This will output one word of the sentence on each line (though not
-necessarily in order, due to the fact that foreach iterations execute in
-parallel).
- at toInt
- at toInt(input) will parse its input string into an integer. This can be
-used with @arg to pass input parameters to a Swift script as
-integers.
- at toFloat
- at toFloat(input) will parse its input string into a floating point number. This can be
-floating point numbers.
- at toString
- at toString(input) will parse its input into a string. Input can be an int, float, string,
-or boolean.
- at length
- at length(array) will return the length of an array in Swift. This function will wait for all elements in the array to be written before returning the length.
- at java
- at java(class_name, static_method, method_arg) will call a java static method of the class class_name.
-Built-in procedure reference
-This section details built-in procedures that are available for use in
-the Swift scripting language.
-readData
-readData will read data from a specified file and assign it to Swift variable. The format of the input file is
-controlled by the type of the return value. For scalar return types, such as
-int, the specified file should contain a single value of that type. For arrays
-of scalars, the specified file should contain one value per line. For complex types
-of scalars, the file should contain two rows. The first row should be structure
-member names separated by whitespace. The second row should be the
-corresponding values for each structure member, separated by whitespace, in the
-same order as the header row. For arrays of structs, the file should contain a
-heading row listing structure member names separated by whitespace. There
-should be one row for each element of the array, with structure member elements
-listed in the same order as the header row and separated by whitespace. The following example shows how readData() can be used to populate an array of Swift struct-like complex type:
-type Employee{
- string name;
- int id;
- string loc;
-Employee emps[] = readData("emps.txt");
-Where the contents of the "emps.txt" file are:
-name id loc
-Thomas 2222 Chicago
-Gina 3333 Boston
-Anne 4444 Houston
-This will result in the array "emps" with 3 members. This can be processed within a Swift script using the foreach construct as follows:
-foreach emp in emps{
- tracef("Employee %s lives in %s and has id %d", emp.name, emp.loc, emp.id);
-readStructured
-readStructured will read data from a specified file, like readdata, but
-using a different file format more closely related to that used by the
-ext mapper.
-Input files should list, one per line, a path into a Swift structure,
-and the value for that position in the structure:
-rows[0].columns[0] = 0
-rows[0].columns[1] = 2
-rows[0].columns[2] = 4
-rows[1].columns[0] = 1
-rows[1].columns[1] = 3
-rows[1].columns[2] = 5
-which can be read into a structure defined like this:
-type vector {
- int columns[];
-type matrix {
- vector rows[];
-matrix m;
-m = readStructured("readStructured.in");
-(since Swift 0.7, was readData2(deprecated))
-trace
-trace will log its parameters. By default these will appear on both
-stdout and in the run log file. Some formatting occurs to produce the
-log message. The particular output format should not be relied upon.
-tracef
-+tracef(_spec_, _variable list_)+ will log its parameters as formatted
-by the formatter _spec_. _spec_ must be a string. Checks the type of
-the specifiers arguments against the variable list and allows for
-certain escape characters.
-Example:
-int i = 3;
-tracef("%s: %i\n", "the value is", i);
-Specifiers:
-+%s+:: Format a string.
-+%b+:: Format a boolean.
-+%i+:: Format a number as an integer.
-+%f+:: Format a number as a floating point number.
-+%q+:: Format an array.
-+%M+:: Format a mapped variable's filename.
-+%k+:: Wait for the given variable but do not format it.
-+%p+:: Format variable according to an internal format.
-Escape sequences:
-+\n+:: Produce a newline.
-+\t+:: Produce a tab.
-Known issues: :: Swift does not correctly scan certain backslash
-sequences such as +\\+.
-writeData
-writeData will write out data structures in the format described for
-readData. The following example demonstrates how one can write a string "foo" into a file "writeDataPrimitive.out":
-include::../../tests/language-behaviour/IO/writeDataPrimitive.swift[]
Deleted: branches/release-0.95/docs/userguide/build_options
--- branches/release-0.95/docs/userguide/build_options 2014-01-08 22:04:50 UTC (rev 7462)
+++ branches/release-0.95/docs/userguide/build_options 2014-01-08 22:13:41 UTC (rev 7463)
@@ -1,24 +0,0 @@
-Build options
-See the Swift download page <http://www.ci.uchicago.edu/swift/downloads/> for
-instructions on downloading and building Swift from source. When building,
-various build options can be supplied on the ant commandline. These are
-summarised here:
-with-provider-condor - build with CoG condor provider
-with-provider-coaster - build with CoG coaster provider (see the section on
-coasters). Since 0.8, coasters are always built, and this option has no effect.
-no-supporting - produces a distribution without supporting commands such as
-grid-proxy-init. This is intended for when the Swift distribution will be used
-in an environment where those commands are already provided by other packages,
-where the Swift package should be providing only Swift commands, and where the
-presence of commands such as grid-proxy-init from the Swift distribution in the
-path will mask the presence of those commands from their true distribution
-package such as a Globus Toolkit package.
-$ ant -Dno-supporting=true redist
Deleted: branches/release-0.95/docs/userguide/clustering
--- branches/release-0.95/docs/userguide/clustering 2014-01-08 22:04:50 UTC (rev 7462)
+++ branches/release-0.95/docs/userguide/clustering 2014-01-08 22:13:41 UTC (rev 7463)
@@ -1,24 +0,0 @@
-Clustering
-Swift can group a number of short job submissions into a single larger job
-submission to minimize overhead involved in launching jobs (for example, caused
-by security negotiation and queuing delay). In general, coasters should be used
-in preference to the clustering mechanism documented in this section.
-By default, clustering is disabled. It can be activated by setting the
-clustering.enabled property to true.
-A job is eligible for clustering if the GLOBUS::maxwalltime profile is
-specified in the tc.data entry for that job, and its value is less than the
-value of the clustering.min.time property.
-Two or more jobs are considered compatible if they share the same site and do
-not have conflicting profiles (e.g. different values for the same environment
-variable).
-When a submitted job is eligible for clustering, it will be put in a clustering
-queue rather than being submitted to a remote site. The queue is processed at
-intervals specified by the clustering.queue.delay property. The processing of
-the clustering queue consists of selecting compatible jobs and grouping them
-into clusters whose maximum wall time does not exceed twice the value of the
-clustering.min.time property.
Deleted: branches/release-0.95/docs/userguide/commands
--- branches/release-0.95/docs/userguide/commands 2014-01-08 22:04:50 UTC (rev 7462)
+++ branches/release-0.95/docs/userguide/commands 2014-01-08 22:13:41 UTC (rev 7463)
@@ -1,213 +0,0 @@
-Commands
-The commands detailed in this section are available in the bin/
-directory of a Swift installation and can by run from the commandline if
-that directory is placed on the PATH.
-swift
-The swift command is the main command line tool for executing
-Swift scripts.
-Command-line Syntax
-The swift command is invoked as follows: swift [options]
-Swifti script [Swift-arguments]* with options taken from the
-following list, and Swift script arguments made available to the
-Swift script through the @arg function.
-Swift command-line options
--help or -h
- Display usage information
--typecheck
- Does a typecheck of a Swift script, instead of executing it.
--dryrun
- Runs the Swift script without submitting any jobs. This can be
- used to obtain an execution graph in conjunction with the +pgraph+
- options below.
--monitor
- Shows a graphical resource monitor
--resume file
- Resumes the execution using a resume-log file .rlog
--config file
- Indicates the Swift configuration file to be used for this run.
- Properties in this configuration file will override the default
- properties. If individual command line arguments are used for
- properties, they will override the contents of this file.
--verbose | -v
- Increases the level of output that Swift produces on the console to
- include more detail about the execution
--debug | -d
- include lots of detail about the execution
--logfile file
- Specifies a file where log messages should go to. By default Swift
- uses the name of the program being run and a numeric index (e.g.
- myworkflow.1.log)
--runid identifier
- Specifies the run identifier. This must be unique for every
- invocation and is used in several places to keep files from
- different executions cleanly separated. By default, a datestamp and
- random number are used to generate a run identifier. When using this
- parameter, care should be taken to ensure that the run ID remains
- unique with respect to all other run IDs that might be used,
- irrespective of (at least) expected execution sites, program or user.
--version
- Display Swift version and exit
--recompile
- Forces Swift to re-compile the invoked Swift script. While Swift
- is meant to detect when recompilation is necessary, in some
- special cases it fails to do so. This flag helps with those
- special cases.
--cdm.file
- Specifies a CDM policy file.
--reduced.logging
- Makes logging more terse by disabling provenance information and
- low-level task messages
--minimal.logging
- Makes logging much more terse: reports warnings only
--tui
- Displays an interactive text mode monitor during a run. (since Swift
- 0.9)
-In addition, the following Swift properties can be set on the command line:
- * caching.algorithm
- * clustering.enabled
- * clustering.min.time
- * clustering.queue.delay
- * ip.address
- * kickstart.always.transfer
- * kickstart.enabled
- * lazy.errors
- * pgraph
- * pgraph.graph.options
- * pgraph.node.options
- * sitedir.keep
- * sites.file
- * tc.file
- * tcp.port.range
-Return codes
-The swift command may exit with the following return codes:
-[options="header, autowidth"]
-|value|meaning
-|0|success
-|1|command line syntax error or missing project name
-|2|error during execution
-|3|error during compilation
-|4|input file does not exist
-Environment variables
-The swift is influenced by the following environment variables:
-GLOBUS_HOSTNAME, GLOBUS_TCP_PORT_RANGE
- Set in the environment before running Swift. These can be set to inform Swift
- of the configuration of your local firewall. More information can be found in
- the Globus firewall How-to <http://dev.globus.org/wiki/FirewallHowTo>.
-SWIFT_HEAP_MAX
- Sets the java heap size. Use this if Swift runs out of memory.
- Uses the format set by java -Xmx, which is how this is implemented.
- The default setting is 1024M.
-COG_OPTS
- Set in the environment before running Swift. Options set in
- this variable will be passed as parameters to the Java Virtual Machine
- which will run Swift. The parameters vary between virtual machine
- imlementations, but can usually be used to alter settings such as
- maximum heap size. Typing 'java -help' will sometimes give a list of
- commands.
-swift-osg-ress-site-catalog
-The swift-osg-ress-site-catalog command generates a site catalog based
-on OSG <http://www.opensciencegrid.org/>'s ReSS information system
-(since Swift 0.9)
-Usage: *swift-osg-ress-site-catalog [options]*
---help
- Show help message
---vo=[name]
- Set what VO to query ReSS for
---engage-verified
- Only retrieve sites verified by the Engagement VO site verification
- tests This can not be used together with |--vo|, as the query will
- only work for sites advertising support for the Engagement VO.
- This option means information will be retrieved from the Engagement
- collector instead of the top-level ReSS collector.
---out=[filename]
- Write to [filename] instead of stdout
---condor-g
- Generates sites files which will submit jobs using a local Condor-G
- installation rather than through direct GRAM2 submission. (since
- Swift 0.10)
-swift-plot-log
-swift-plot-log generates summaries of Swift run log files.
-Usage: swift-plot-log [logfile] [targets]
-When no targets are specified, swift-plog-log will generate an HTML
-report for the run. When targets are specified, only those named targets
-will be generated.
Added: branches/release-0.95/docs/userguide/configuration
--- branches/release-0.95/docs/userguide/configuration (rev 0)
+++ branches/release-0.95/docs/userguide/configuration 2014-01-08 22:13:41 UTC (rev 7463)
@@ -0,0 +1,513 @@
+Configuration
+Swift uses a single configuration file called swift.properties. The swift.properties
+file is responsible for:
+1. Defining how to interface with schedulers
+2. Defining app names and locations
+3. Defining various other swift settings and behavior
+Here is an example swift.properties file.
+# Define a site named sandyb
+site.sandyb {
+ tasksPerWorker=16
+ taskWalltime=00:05:00
+ jobManager=slurm
+ jobQueue=sandyb
+ maxJobs=1
+ workdir=/scratch/midway/$USER/work
+ filesystem=local
+# Define sandyb apps
+app.sandyb.echo=/bin/echo
+# Define other swift properties
+sitedir.keep=true
+wrapperlog.always.transfer=true
+# Select which site to run on
+site=sandyb
+The details of this file will be explained more later. Let's first look
+at an example of running Swift with this new file.
+Using the swift.properties file above, the new Swift command a user would run
+is:
+$ swift script.swift
+That is all that is needed. Everything Swift needs to know is defined in
+swift.properties.
+Location of swift.properties
+Swift searches for swift.properties files in multiple locations:
+1. The etc/swift.properties file included with the Swift distribution.
+2. $SWIFT_SITE_CONF/swift.properties - used for defining site templates.
+3. $HOME/.swift/swift.properties
+4. swift.properties in your current directory.
+5. Any property file you point to with the command line argument "-properties
+<file>"
+Settings get read in this order. Definitions in the later files will override
+any previous definitions. For example, if you have execution.retries=10 in
+$HOME/.swift/swift.properties, and execution.retries=0 in the swift.properties
+in your current directory, execution.retries will be set to 0.
+To verify what files are being read, and what values will be set, run:
+$ swift -listconfig
+Selecting a site
+There are two ways Swift knows where to run. The first is via
+swift.properties. The site command specified which site entries
+should be used for a particular run.
+site=sandyb
+Sites can also be selected on the command line by using the -site option.
+$ swift -site westmere script.swift
+The -site command line argument will override any sites selected in
+swift.properties.
+Selecting multiple sites
+To use multiple sites, use a list of site names separated by commas. In
+swift.properties:
+site=westmere,sandyb
+The same format can be used on the command line:
+$ swift -site westmere,sandyb script.swift
+NOTE: You can also use "sites=" in swift.properties, and "-sites x,y,z" on the
+command line.
+Run directories
+When you run Swift, you will see a run directory get created. The run
+directory has the name of runNNN, where NNN starts at 000 and increments for
+every run.
+The run directories can be useful for debugging. They contain:
+.Run directory contents
+|apps |An apps generated from swift.properties
+|cf |A configuration file generated from swift.properties
+|runNNN.log|The log file generated during the Swift run
+|scriptname-runNNN.d|Debug directory containing wrapper logs
+|scripts|Directory that contains scheduler scripts used for that run
+|sites.xml|A sites.xml generated from swift.properties
+|swift.out|The standard out and standard error generated by Swift
+Using site templates
+This new configuration mechanism should make it easier to use site templates.
+To use this, set the environment variable $SWIFT_SITE_CONF to a directory
+containing a swift.properties file. This swift.properties can contain multiple
+site definitions for the various queues available on the cluster you are using.
+Your local swift.properties then does not need to define the entire site. It
+may contain only differences you need to make that are specific to your
+application, like walltime.
+Backward compatability
+New users are encouraged to use the configuration mechanisms described in this documentation.
+However, if you are migrating from an older Swift release to 0.95, the older-style configurations
+using sites.xml and tc.data should still work. If you notice an instance where this is not true,
+please send an email to swift-support at ci.uchicago.edu.
+The swift.properties file format
+Site definitions
+Site definitions in the swift.properties files begin with "site".
+The second word is the name of the site you are defining. In these examples we
+will define a site called westmere.
+The third word is the property.
+For example:
+site.westmere.jobQueue=fast
+Before the site properties are listed, it's important to understand the
+terminology used.
+A *task*, or *app task* is an instance of a program as defined in
+a Swift app() function.
+A *worker* is the program that launches app tasks.
+A *job* is related to schedulers. It is the mechanism by which workers
+are launched.
+Below is the list of valid site properties with brief explanations of what
+they do, and an example swift.properties entry.
+.swift.properties site properties
+[options="header"]
+|Property|Description|Example
+|filesystem|
+Defines how files should be accessed
+|site.westmere.filesystem=local
+|jobGranularity|
+Specifies the granularity of a job, in nodes
+|site.westmere.jobGranularity=2
+|jobManager|
+Specifies how jobs will be launched. The supported job managers are
+"cobalt", "slurm", "condor", "pbs", "lsf", "local", and "sge".
+|site.westmere.jobManager=slurm
+|jobProject|
+Set the project name for the job scheduler
+|site.westmere.project=myproject
+|jobQueue|
+Set the name of the scheduler queue to use.
+|site.westmere.jobQueue=westmere
+|jobWalltime|
+The maximum number amount of time allocated in a scheduler job, in hh:mm:ss
+format.
+|site.westmere.jobWalltime=01:00:00
+|maxJobs|
+Maximum number of scheduler jobs to submit
+|site.westmere.maxJobs=20
+|maxNodesPerJob|
+The maximum number of nodes to request per scheduler job.
+|site.westmere.maxNodesPerJob=2
+|taskDir|
+Tasks will be run from this directory. In the absence of a taskDir definition,
+Swift will run the task from workdir.
+|site.westmere.taskDir=/scratch/local/$USER/work
+|tasksPerWorker|
+The number of tasks that each worker can run simultaneously.
+|site.westmere.tasksPernode=12
+|taskThrottle|
+The maximum number of active tasks across all workers.
+|site.westmere.taskThrottle=100
+|taskWalltime|
+The maximum amount of time a task may run, in hh:mm:ss.
+|site.westmere.taskWalltime=01:00:00
+|site |
+Name of site or sites to run on. This is the same as running with
+swift -site <sitename>
+|site=westmere
+|workdir |
+The workdirectory element specifies where on the site files can be stored.
+This directory must be available on all worker nodes that will be used for
+execution. A shared cluster filesystem is appropriate for this. Note that
+you need to specify absolute pathname for this field.
+|site.westmere.workdir=/scratch/midway/$USER/work
+Grouping site properties
+The example swift.properties in this document listed the following site
+related properties:
+site.westmere.provider=local:slurm
+site.westmere.jobsPerNode=12
+site.westmere.maxWalltime=00:05:00
+site.westmere.queue=westmere
+site.westmere.initialScore=10000
+site.westmere.filesystem=local
+site.westmere.workdir=/scratch/midway/davidkelly999
+However, it is also simplify this by grouping these properties together with
+curly brackets.
+site.westmere {
+ provider=local:slurm
+ jobsPerNode=12
+ maxWalltime=00:05:00
+ queue=westmere
+ initialScore=10000
+ filesystem=local
+App definitions
+In 0.95, applications wildcards will be used by default. This means that
+$PATH will be searched and pathnames to application do not have to be defined.
+In the case where you have multiple sites defined, and you want
+control over where things run, you will need to define the location of apps.
+In this scenario, you will can define apps in swift.properties with something
+like this:
+app.westmere.cat=/bin/cat
+When an app is defined in swift.properties for any site you are running on,
+wildcards will be disabled, and all apps you want to use must be defined.
+General Swift properties
+Various aspects of the behavior of Swift can be configured through general
+Swift properties. Below is a list of properties:
+[options="header"]
+|Name|Valid Values|Default Value|Description
+|execution.retries
+|Positive integer
+|2
+|The number of time a job will be retried if it fails (giving a
+ maximum of 1 + execution.retries attempts at execution)
+|foreach.max.threads
+|Positive integer
+|1024
+|Limits the number of concurrent iterations that each foreach
+ statement can have at one time. This conserves memory for swift
+ programs that have large numbers of iterations (which would
+ otherwise all be executed in parallel)
+|lazy.errors
+|true, false
+|false
+|Swift can report application errors in two modes, depending on the
+ value of this property. If set to false, Swift will report the
+ first error encountered and immediately stop execution. If set to
+ true, Swift will attempt to run as much as possible from a
+ Swift script before stopping execution and reporting all
+ errors encountered. When developing Swift scripts, using the default value of
+ false can make the program easier to debug. However in production
+ runs, using true will allow more of a Swift script to be
+ run before Swift aborts execution.
+|swift.home
+|String
+|Points to the Swift installation directory ($SWIFT_HOME). In general, this should
+ not be set as Swift can find its own installation directory, and incorrectly setting it may impair the
+ correct functionality of Swift.
+|pgraph
+|true, false
+|false
+|Swift can generate a Graphviz <http://www.graphviz.org/> file
+representing the structure of the Swift script it has run. If
+this property is set to true, Swift will save the provenance graph
+in a file named by concatenating the program name and the instance
+ID (e.g. helloworld-ht0adgi315l61.dot).
+If set to false, no provenance graph will be generated. If a file
+name is used, then the provenance graph will be saved in the
+specified file.
+The generated dot file can be rendered into a graphical form using
+Graphviz <http://www.graphviz.org/>, for example with a command-line
+such as:
+$ swift -pgraph graph1.dot q1.swift
+$ dot -ograph.png -Tpng graph1.dot
+|pgraph.graph.options
+|String
+|splines="compound", rankdir="TB"
+|This property specifies a Graphviz <http://www.graphviz.org>
+ specific set of parameters for the graph.
+|pgraph.node.options
+|String
+|color="seagreen", style="filled"
+|Used to specify a set of Graphviz <http://www.graphviz.org> specific
+ properties for the nodes in the graph.
+|provenance.log
+|true, false
+|false
+|This property controls whether the log file will contain provenance
+ information enabling this will increase the size of log files,
+ sometimes significantly.
+|sitedir.keep
+|true, false
+|false
+|Indicates whether the working directory on the remote site should be
+ left intact even when a run completes successfully. This can be used
+ to inspect the site working directory for debugging purposes.
+|status.mode
+|files, provider
+|files
+|Controls how Swift will communicate the result code of running user
+ programs from workers to the submit side. In files mode, a file
+ indicating success or failure will be created on the site shared
+ filesystem. In provider mode, the execution provider job status
+ will be used. provider mode requires the underlying job execution system to
+ correctly return exit codes.
+|tcp.port.range
+|none
+|<start>,<end> where start and end are integers
+|A TCP port range can be specified to restrict the ports on which
+ GRAM callback services are started. This is likely needed if your
+ submit host is behind a firewall, in which case the firewall should
+ be configured to allow incoming connections on ports in the range.
+|throttle.file.operations
+|<int>, off
+|8
+|Limits the total number of concurrent file operations that can
+ happen at any given time. File operations (like transfers) require
+ an exclusive connection to a site. These connections can be
+ expensive to establish. A large number of concurrent file operations
+ may cause Swift to attempt to establish many such expensive
+ connections to various sites. Limiting the number of concurrent file
+ operations causes Swift to use a small number of cached connections
+ and achieve better overall performance.
+|throttle.host.submit
+|<int>, off
+|2
+|Limits the number of concurrent submissions for any of the sites
+ Swift will try to send jobs to. In other words it guarantees that no
+ more than the value of this throttle jobs sent to any site will be
+ concurrently in a state of being submitted.
+|throttle.score.job.factor
+|<int>, off
+|4
+|The Swift scheduler has the ability to limit the number of
+concurrent jobs allowed on a site based on the performance history
+of that site. Each site is assigned a score (initially 1), which can
+increase or decrease based on whether the site yields successful or
+faulty job runs. The score for a site can take values in the (0.1,
+100) interval. The number of allowed jobs is calculated using the
+following formula:
+2 + score*throttle.score.job.factor
+This means a site will always be allowed at least two concurrent
+jobs and at most 2 + 100*throttle.score.job.factor. With a default
+of 4 this means at least 2 jobs and at most 402.
+This parameter can also be set per site using the jobThrottle
+profile key in a site catalog entry.
+|throttle.submit
+|<int>, off
+|4
+|Limits the number of concurrent submissions for a run. This throttle
+ only limits the number of concurrent tasks (jobs) that are being
+ sent to sites, not the total number of concurrent jobs that can be
+ run. The submission stage in GRAM is one of the most CPU expensive
+ stages (due mostly to the mutual authentication and delegation).
+ Having too many concurrent submissions can overload either or both
+ the submit host CPU and the remote host/head node causing degraded
+ performance.
+|throttle.transfers
+|<int>, off
+|4
+|Limits the total number of concurrent file transfers that can happen
+ at any given time. File transfers consume bandwidth. Too many
+ concurrent transfers can cause the network to be overloaded
+ preventing various other signaling traffic from flowing properly.
+|ticker.disable
+|true, false
+|false
+|When set to true, suppresses the output progress ticker that Swift
+ sends to the console every few seconds during a run
+|use.wrapper.staging
+|true, false
+|false
+|Determines if the Swift wrapper should do file staging.
+|wrapper.invocation.mode
+|absolute, relative
+|absolute
+|Determines if Swift remote wrappers will be executed by specifying
+ an absolute path, or a path relative to the job initial working
+ directory. In most cases, execution will be successful with either
+ option. However, some execution sites ignore the specified initial
+ working directory, and so absolute must be used. Conversely on
+ some sites, job directories appear in a different place on the
+ worker node file system than on the filesystem access node, with the
+ execution system handling translation of the job initial working
+ directory. In such cases, relative mode must be used.
+|wrapper.parameter.mode
+|args,files
+|args
+|Controls how Swift will supply parameters to the remote wrapper
+ script. args mode will pass parameters on the command line. Some
+ execution systems do not pass commandline parameters sufficiently
+ cleanly for Swift to operate correctly. files mode will pass
+ parameters through an additional input file. This
+ provides a cleaner communication channel for parameters, at the
+ expense of transferring an additional file for each job invocation.
+|wrapperlog.always.transfer
+|true, false
+|false
+|This property controls when output from the Swift remote wrapper is
+ transfered back to the submit site. When set to false, wrapper
+ logs are only transfered for jobs that fail. If set to true,
+ wrapper logs are transfered after every job is completed or failed.
+Using shell variables
+Any value in swift.properties may contain environment variables. For example:
+workdir=/scratch/midway/$USER/work
+Environment variables are expanded locally on the machine where you are running
+Swift.
+Swift will also define a variable called $RUNDIRECTORY that is the path to the
+run directory Swift creates. In a case where you'd like your work directory
+to be in the runNNN directory, you may do something like this:
+workdir=$RUNDIRECTORY
Deleted: branches/release-0.95/docs/userguide/configuration_properties
--- branches/release-0.95/docs/userguide/configuration_properties 2014-01-08 22:04:50 UTC (rev 7462)
+++ branches/release-0.95/docs/userguide/configuration_properties 2014-01-08 22:13:41 UTC (rev 7463)
@@ -1,493 +0,0 @@
-Swift configuration properties
-Various aspects of the behavior of Swift can be configured through properties.
-Swift recognizes a global, per installation properties file which can found in
-etc/swift.properties in the Swift installation directory and a user properties
-file which can be created by each user in ~/.swift/swift.properties.
-Swift will first load the global properties file. It will then try to load the
-user properties file. If a user properties file is found, individual properties
-explicitly set in that file will override the respective properties in the
-global properties file. Furthermore, some of the properties can be overridden
-directly using command line arguments to the *swift* command.
-Swift properties are specified in the following format:
-<name>=<value>
-The value can contain variables which will be expanded when the
-properties file is read. Expansion is performed when the name of the
-variable is used inside the standard shell dereference construct:
-${name}. The following variables can be used in the Swift
-configuration file:
-Swift Configuration Variables
-swift.home
- Points to the Swift installation directory ($SWIFT_HOME). In
- general, this should not be set as Swift can find its own
- installation directory, and incorrectly setting it may impair the
- correct functionality of Swift.
-user.name
- The name of the current logged in user.
-user.home
- The user's home directory.
-The following is a list of valid Swift properties:
-Swift Properties
-caching.algorithm
- Valid values: LRU
- Default value: LRU
- Swift caches files that are staged in on remote resources, and files
- that are produced remotely by applications, such that they can be
- re-used if needed without being transfered again. However, the
- amount of remote file system space to be used for caching can be
- limited using the swift:storagesize profile entry in the sites.xml file. Example:
-<pool handle="example" sysinfo="INTEL32::LINUX">
-<gridftp url="gsiftp://example.org" storage="/scratch/swift" major="2" minor="4" patch="3"/>
-<jobmanager universe="vanilla" url="example.org/jobmanager-pbs" major="2" minor="4" patch="3"/>
-<workdirectory>/scratch/swift</workdirectory>
-<profile namespace="SWIFT" key="storagesize">20000000</profile>
-</pool>
- The decision of which files to keep in the cache and which files to
- remove is made considering the value of the caching.algorithm
- property. Currently, the only available value for this property is
- LRU, which would cause the least recently used files to be deleted
- first.
-clustering.enabled
- Valid values: true, false
- Default value: false
- Enables clustering.
- Valid values: <int>
- Default value: 60
- Indicates the threshold wall time for clustering, in seconds. Jobs
- that have a wall time smaller than the value of this property will
- be considered for clustering.
-clustering.queue.delay
- Default value: 4
- This property indicates the interval, in seconds, at which the
- clustering queue is processed.
-execution.retries
- Valid values: positive integers
- Default value: 2
- The number of time a job will be retried if it fails (giving a
- maximum of 1 + execution.retries attempts at execution)
-foreach.max.threads
- Default value: 1024
- Limits the number of concurrent iterations that each foreach
- statement can have at one time. This conserves memory for swift
- programs that have large numbers of iterations (which would
- otherwise all be executed in parallel). (since Swift 0.9)
-ip.address
- Valid values: <ipaddress>
- Default value: N/A
- The Globus GRAM service uses a callback mechanism to send
- notifications about the status of submitted jobs. The callback
- mechanism requires that the Swift client be reachable from the hosts
- the GRAM services are running on. Normally, Swift can detect the
- correct IP address of the client machine. However, in certain cases
- (such as the client machine having more than one network interface)
- the automatic detection mechanism is not reliable. In such cases,
- the IP address of the Swift client machine can be specified using
- this property. The value of this property must be a numeric address
- without quotes.
- This option is deprecated and the hostname property should be used
- instead.
-kickstart.always.transfer
- This property controls when output from Kickstart is transfered back
- to the submit site, if Kickstart is enabled. When set to false,
- Kickstart output is only transfered for jobs that fail. If set to
- true, Kickstart output is transfered after every job is completed
- or failed.
-kickstart.enabled
- Valid values: true, false, maybe
- Default value: maybe
- This option allows controlling of when Swift uses Kickstart.
- A value of false disables the use of Kickstart,
- while a value of true enables the use of Kickstart, in which case
- sites specified in the sites.xml file must have valid
- gridlaunch attributes. The maybe value will enable the use of
- Kickstart only on sites that have the gridlaunch attribute
- specified.
-lazy.errors
- Swift can report application errors in two modes, depending on the
- value of this property. If set to false, Swift will report the
- first error encountered and immediately stop execution. If set to
- true, Swift will attempt to run as much as possible from a
- Swift script before stopping execution and reporting all
- errors encountered.
- When developing Swift scripts, using the default value of
- false can make the program easier to debug. However in production
- runs, using true will allow more of a Swift script to be
- run before Swift aborts execution.
-pgraph
- Valid values: true, false, <file>
- Swift can generate a Graphviz <http://www.graphviz.org/> file
- representing the structure of the Swift script it has run. If
- this property is set to true, Swift will save the provenance graph
- in a file named by concatenating the program name and the instance
- ID (e.g. helloworld-ht0adgi315l61.dot).
- If set to false, no provenance graph will be generated. If a file
- name is used, then the provenance graph will be saved in the
- specified file.
- The generated dot file can be rendered into a graphical form using
- Graphviz <http://www.graphviz.org/>, for example with a command-line
- such as:
-$ swift -pgraph graph1.dot q1.swift
-$ dot -ograph.png -Tpng graph1.dot
-pgraph.graph.options
- Valid values: <string>
- Default value: splines="compound", rankdir="TB"
- This property specifies a Graphviz <http://www.graphviz.org>
- specific set of parameters for the graph.
-pgraph.node.options
- Default value: color="seagreen", style="filled"
- Used to specify a set of Graphviz <http://www.graphviz.org> specific
- properties for the nodes in the graph.
-provenance.log
- This property controls whether the log file will contain provenance
- information enabling this will increase the size of log files,
- sometimes significantly.
-replication.enabled
- Enables/disables replication. Replication is used to deal with jobs
- sitting in batch queues for abnormally large amounts of time. If
- replication is enabled and certain conditions are met, Swift creates
- and submits replicas of jobs, and allows multiple instances of a job
- to compete.
-replication.limit
- Default value: 3
- The maximum number of replicas that Swift should attempt.
-sitedir.keep
- Indicates whether the working directory on the remote site should be
- left intact even when a run completes successfully. This can be used
- to inspect the site working directory for debugging purposes.
-sites.file
- Valid values: <file>
- Default value: ${swift.home}/etc/sites.xml
- Points to the location of the site catalog, which contains a list of
- all sites that Swift should use.
-status.mode
- Valid values: files, provider
- Default value: files
- Controls how Swift will communicate the result code of running user
- programs from workers to the submit side. In files mode, a file
- indicating success or failure will be created on the site shared
- filesystem. In provider mode, the execution provider job status
- will be used.
- provider mode requires the underlying job execution system to
- correctly return exit codes. In at least the cases of GRAM2, and
- clusters used with any provider, exit codes are not returned, and so
- files mode must be used in those cases. Otherwise, provider mode
- can be used to reduce the amount of filesystem access. (since Swift
- 0.8)
-tc.file
- Default value: ${swift.home}/etc/tc.data
- Points to the location of the transformation catalog file which
- contains information about installed applications. Details about the
- format of the transformation catalog can be found here
- <http://vds.uchicago.edu/vds/doc/userguide/html/H_TransformationCatalog.html>.
-tcp.port.range
- Valid values: <start>,<end> where start and end are integers
- Default value: none
- A TCP port range can be specified to restrict the ports on which
- GRAM callback services are started. This is likely needed if your
- submit host is behind a firewall, in which case the firewall should
- be configured to allow incoming connections on ports in the range.
-throttle.file.operations
- Valid values: <int>, off
- Default value: 8
- Limits the total number of concurrent file operations that can
- happen at any given time. File operations (like transfers) require
- an exclusive connection to a site. These connections can be
- expensive to establish. A large number of concurrent file operations
- may cause Swift to attempt to establish many such expensive
- connections to various sites. Limiting the number of concurrent file
- operations causes Swift to use a small number of cached connections
- and achieve better overall performance.
-throttle.host.submit
- Default value: 2
- Limits the number of concurrent submissions for any of the sites
- Swift will try to send jobs to. In other words it guarantees that no
- more than the value of this throttle jobs sent to any site will be
- concurrently in a state of being submitted.
-throttle.score.job.factor
- Default value: 4
- The Swift scheduler has the ability to limit the number of
- concurrent jobs allowed on a site based on the performance history
- of that site. Each site is assigned a score (initially 1), which can
- increase or decrease based on whether the site yields successful or
- faulty job runs. The score for a site can take values in the (0.1,
- 100) interval. The number of allowed jobs is calculated using the
- following formula:
- 2 + score*throttle.score.job.factor
- This means a site will always be allowed at least two concurrent
- jobs and at most 2 + 100*throttle.score.job.factor. With a default
- of 4 this means at least 2 jobs and at most 402.
- This parameter can also be set per site using the jobThrottle
- profile key in a site catalog entry.
-throttle.submit
- Default value: 4
- Limits the number of concurrent submissions for a run. This throttle
- only limits the number of concurrent tasks (jobs) that are being
- sent to sites, not the total number of concurrent jobs that can be
- run. The submission stage in GRAM is one of the most CPU expensive
- stages (due mostly to the mutual authentication and delegation).
- Having too many concurrent submissions can overload either or both
- the submit host CPU and the remote host/head node causing degraded
- performance.
-throttle.transfers
- Default value: 4
- Limits the total number of concurrent file transfers that can happen
- at any given time. File transfers consume bandwidth. Too many
- concurrent transfers can cause the network to be overloaded
- preventing various other signaling traffic from flowing properly.
-ticker.disable
- When set to true, suppresses the output progress ticker that Swift
- sends to the console every few seconds during a run (since Swift 0.9)
-wrapper.invocation.mode
- Valid values: absolute, relative
- Default value: absolute
- Determines if Swift remote wrappers will be executed by specifying
- an absolute path, or a path relative to the job initial working
- directory. In most cases, execution will be successful with either
- option. However, some execution sites ignore the specified initial
- working directory, and so absolute must be used. Conversely on
- some sites, job directories appear in a different place on the
- worker node file system than on the filesystem access node, with the
- execution system handling translation of the job initial working
- directory. In such cases, relative mode must be used. (since Swift
- 0.9)
-use.wrapper.staging
- Determines if the Swift wrapper should do file staging.
-wrapper.parameter.mode
- Controls how Swift will supply parameters to the remote wrapper
- script. args mode will pass parameters on the command line. Some
- execution systems do not pass commandline parameters sufficiently
- cleanly for Swift to operate correctly. files mode will pass
- parameters through an additional input file (since Swift 0.95). This
- provides a cleaner communication channel for parameters, at the
- expense of transferring an additional file for each job invocation.
-wrapperlog.always.transfer
- This property controls when output from the Swift remote wrapper is
- transfered back to the submit site. When set to false, wrapper
- logs are only transfered for jobs that fail. If set to true,
- wrapper logs are transfered after every job is completed or failed.
-Example:
-sites.file=${vds.home}/etc/sites.xml
-tc.file=${vds.home}/etc/tc.data
-ip.address=192.168.0.1
-Monitoring Swift
-A Swift run can be monitored for progress and resource usage. To monitor the resource usage, use the +-monitor+ option with the Swift commandline. For example:
-swift -tc.file tc -sites.file sites.xml -config cf modis04.swift -monitor
-This will produce a gui/X window consisting of the following quantities:
-* Allocated memory
-* Heap Size
-* Total Threads
-* Total Workers
-.Figure 4. Resource Monitor
-image:swift_monitor.png[]
-Figure 4 shows a snapshot of a Swift resource monitor.
-The progress of a Swift run can be monitored using the +-tui+ option. For example:
-swift -tc.file tc -sites.file sites.xml -config cf modis04.swift -tui
-This will produce a textual user interface with multiple tabs, each showing the following features of the current Swift run:
-* A summary view showing task status
-* An apps tab
-* A jobs tab
-* A transfer tab
-* A scheduler tab
-* A Tast statistics tab
-* A customized tab called 'Ben's View'
-Navigation between these tabs can be done using the function keys f2 through f8.
Added: branches/release-0.95/docs/userguide/debugging
--- branches/release-0.95/docs/userguide/debugging (rev 0)
+++ branches/release-0.95/docs/userguide/debugging 2014-01-08 22:13:41 UTC (rev 7463)
@@ -0,0 +1,137 @@
+Debugging
+Retries
+If an application procedure execution fails, Swift will attempt that
+execution again repeatedly until it succeeds, up until the limit defined
+in the execution.retries configuration property.
+Site selection will occur for retried jobs in the same way that it
+happens for new jobs. Retried jobs may run on the same site or may run
+on a different site.
+If the retry limit execution.retries is reached for an application
+procedure, then that application procedure will fail. This will cause
+the entire run to fail - either immediately (if the lazy.errors
+property is false) or after all other possible work has been attempted
+(if the lazy.errors property is true).
+With or without lazy errors, each app is re-tried <execution.retries>
+times before it is considered failed for good. An app that has failed
+but still has retries left will appear as "Failed but can retry".
+Without lazy errors, once the first (time-wise) app has run out of
+retries, the whole run is stopped and the error reported.
+With lazy errors, if an app fails after all retries, its outputs are
+marked as failed. All apps that depend on failed outputs will also fail
+and their outputs marked as failed. All apps that have non-failed
+outputs will continue to run normally until everything that can proceed
+completes.
+For example, if you have:
+foreach x in [1:1024] {
+ app(x);
+If the first started app fails, all the other ones can still
+continue, and if they don't otherwise fail, the run will only terminate
+when all 1023 of them will complete.
+So basically the idea behind lazy errors is to run EVERYTHING that can
+safely be run before stopping.
+Some types of errors (such as internal swift errors happening in an app
+thread) will still stop the run immediately even in lazy errors mode.
+But we all know there are no such things as internal swift errors :)
+Restarts
+If a run fails, Swift can resume the program from the point of failure.
+When a run fails, a restart log file will be left behind in the run directory
+called restart.log. This restart log can then be passed to a subsequent Swift
+invocation using the -resume parameter. Swift will resume execution, avoiding
+execution of invocations that have previously completed successfully. The Swift
+source file and input data files should not be modified between runs.
+Normally, if the run completes successfully, the restart log file is deleted.
+If however the workflow fails, swift can use the restart log file to continue
+execution from a point before the failure occurred. In order to restart from a
+restart log file, the -resume logfile argument can be used after the
+Swift script file name. Example:
+$ swift -resume runNNN/restart.log example.swift.
+Monitoring Swift
+A Swift run can be monitored for progress and resource usage. To monitor the resource usage, use the +-monitor+ option with the Swift commandline. For example:
+swift -tc.file tc -sites.file sites.xml -config cf modis04.swift -monitor
+This will produce a gui/X window consisting of the following quantities:
+* Allocated memory
+* Heap Size
+* Total Threads
+* Total Workers
+.Figure 4. Resource Monitor
+image:swift_monitor.png[]
+Figure 4 shows a snapshot of a Swift resource monitor.
+The progress of a Swift run can be monitored using the +-tui+ option. For example:
+swift -tc.file tc -sites.file sites.xml -config cf modis04.swift -tui
+This will produce a textual user interface with multiple tabs, each showing the following features of the current Swift run:
+* A summary view showing task status
+* An apps tab
+* A jobs tab
+* A transfer tab
+* A scheduler tab
+* A Tast statistics tab
+* A customized tab called 'Ben's View'
+Navigation between these tabs can be done using the function keys f2 through f8.
+Log analysis
+Swift logs can contain a lot of information. Swift includes a utility called "swiftlog" that
+analyzes the log and prints a nicely formatted summary of all tasks of a given run.
+.swiftlog usage
+$ swiftlog run027
+Task 1
+ App name = cat
+ Command line arguments = data.txt data2.txt
+ Host = westmere
+ Start time = 17:09:59,607+0000
+ Stop time = 17:10:22,962+0000
+ Work directory = catsn-run027/jobs/r/cat-r6pxt6kl
+ Staged in files = file://localhost/data.txt file://localhost/data2.txt
+ Staged out files = catsn.0004.outcatsn.0004.err
+Task 2
+ App name = cat
+ Host = westmere
+ Stop time = 17:10:22,965+0000
+ Work directory = catsn-run027/jobs/q/cat-q6pxt6kl
+ Staged out files = catsn.0010.outcatsn.0010.err
Added: branches/release-0.95/docs/userguide/gettingStarted
--- branches/release-0.95/docs/userguide/gettingStarted (rev 0)
+++ branches/release-0.95/docs/userguide/gettingStarted 2014-01-08 22:13:41 UTC (rev 7463)
@@ -0,0 +1,27 @@
+Getting Started
+This section will provide links and information to new
+Swift users about how to get started using Swift.
+Quickstart
+This section provides the basic steps for downloading and installing Swift.
+* Swift requires that a recent version of Oracle Java is installed. More information about installing Java can be found at http://www.oracle.com/technetwork/java.
+* Download Swift 0.95 at http://swiftlang.org/packages/swift-0.95.tar.gz.
+* Extract by running "tar xfz swift-0.95.tar.gz"
+* Add Swift to $PATH by running "export PATH=$PATH:/path/to/swift-0.95/bin"
+* Verify swift is working by running "swift -version"
+Tutorials
+There are a few tutorials available for specific clusters and
+supercomputers.
+http://swift-lang.org/tutorials/cloud/tutorial.html[Swift on Clouds and Ad Hoc collections of workstations]
+http://swift-lang.org/tutorials/osgconnect/tutorial.html[Swift on OSG Connect]
+http://swiftlang.org/tutorials/cray/tutorial.html[Swift on Crays]
+http://swiftlang.org/tutorials/midway/tutorial.html[Swift on RCC Midway Cluster at UChicago / Slurm]
Deleted: branches/release-0.95/docs/userguide/howto_tips
--- branches/release-0.95/docs/userguide/howto_tips 2014-01-08 22:04:50 UTC (rev 7462)
+++ branches/release-0.95/docs/userguide/howto_tips 2014-01-08 22:13:41 UTC (rev 7463)
@@ -1,160 +0,0 @@
-How-To Tips for Specific User Communities
-Saving Logs - for UChicago CI Users
-If you have a UChicago Computation Institute account, run this command
-in your submit directory after each run. It will copy all your logs and
-kickstart records into a directory at the CI for reporting, usage
-tracking, support and debugging.
-rsync --ignore-existing *.log *.d login.ci.uchicago.edu:/disks/ci-gpfs/swift/swift-logs/ --verbose
-Specifying TeraGrid allocations
-TeraGrid users with no default project or with several project
-allocations can specify a project allocation using a profile key in the
-site catalog entry for a TeraGrid site:
-<profile namespace="globus" key="project">TG-CCR080002N</profile>
-More information on the TeraGrid allocations process can be found here
-<http://www.teragrid.org/userinfo/access/allocations.php>.
-Launching MPI jobs from Swift
-There are several ways to run MPI jobs under Swift. Two will be discussed here -
-calling mpiexec from a wrapper script, and using the MPICH/coasters interface.
-Calling mpiexec
-In this example, a single MPI program will run across two nodes. For this to
-happen, sites.xml must be configured to allocate two nodes but only run a
-single job on them. A wrapper script must then be used to call mpiexec.
-sites.xml
-First, we need to make sure that Swift will allocate exactly two nodes. This
-can be done with the maxnodes and nodegranularity settings.
-<profile namespace="globus" key="nodeGranularity">2</profile>
-<profile namespace="globus" key="maxnodes">2</profile>
-Next, we want to make sure that the MPI program is called only once on those
-nodes. There are two settings we must set to get this behavior:
-<profile namespace="globus" key="jobsPerNode">1</profile>
-<profile namespace="globus" key="jobtype">single</profile>
-tc.data
-The app defined in tc.data should be a shell script wrapper to the actual
-program that is being called. Let's assume in this example that the MPI program
-we are using is called "mpitest", and the wrapper script will be called
-"mpitest.sh". The tc.data will look like this then:
-host mpitest /path/to/mpitest.sh
-Wrapper script
-The wrapper script in this example, mpitest.sh, will call mpiexec and launch
-the real MPI program. Here is an example:
-#!/bin/bash
-mpiexec /path/to/mpitest "$@"
-Swift then makes an invocation that does not look any different from any other
-invocation. In the code below, we pass one input file and get back one output
-file.
-type file;
-app (file output_file) mpitest (file input_file)
- mpitest @input_file @output_file;
-file input <"input.txt">;
-file output <"output.txt">;
-output = mpitest(input);
-==== MPICH/Coasters
-In this case, the user desires to launch many MPI jobs within a single
-Coasters allocation, reusing Coasters workers for variable-sized jobs.
-The reuse of the Coasters workers allows the user to launch many
-MPI jobs in rapid succession with minimal overhead.
-The user must access to MPICH compiled for sockets, with +mpiexec+ in
-the +PATH+ environment variable. Swift uses this MPICH installation
-to launch the user processes on the remote Coasters workers, which are
-able to connect back to +mpiexec+ and coordinate the job launch. The
-infrastructure must allow the user MPI processes to find each other
-and communicate over sockets.
-To configure the user MPI job, simply add +mpi.processes+ and
-+mpi.ppn+ to the profile in the +tc.file+:
-pbs_site my_program /path/to/program null null globus::mpi.processes=16;globus::mpi.ppn=8
-Coasters must be set with +jobsPerNode=1+.
-This runs +mpiexec+ locally, and allocates 2 Coasters workers (2
-nodes), each with 8 MPI processes. Thus, +MPI_COMM_WORLD+ has size
-16.
-Running on Windows
-Swift has the ability to run on a Windows machine, as well as the
-ability to submit jobs to a Windows site (provided that an appropriate
-provider is used).
-In order to launch Swift on Windows, use the provided batch file
-(swift.bat). In certain cases, when a large number of jar libraries are
-present in the Swift lib directory and depending on the exact location
-of the Swift installation, the classpath environment variable that the
-Swift batch launcher tries to create may be larger than what Windows can
-handle. In such a case, either install Swift in a directory closer to
-the root of the disk (say, c:\swift) or remove non-essential jar files
-from the Swift lib directory.
-Due to the large differences between Windows and Unix environments,
-Swift must use environment specific tools to achieve some of its goals.
-In particular, each Swift executable is launched using a wrapper script.
-This script is a Bourne Shell script. On Windows machines, which have no
-Bourne Shell interpreter installed by default, the Windows Scripting
-Host is used instead, and the wrapper script is written in VBScript.
-Similarly, when cleaning up after a run, the "/bin/rm" command available
-in typical Unix environments must be replaced by the "del" shell command.
-It is important to note that in order to select the proper set of tools
-to use, Swift must know when a site runs under Windows. To inform Swift
-of this, specify the "sysinfo" attribute for the "pool" element in the
-site catalog. For example:
-<pool handle="localhost" sysinfo="INTEL32::WINDOWS">
-</pool>
Deleted: branches/release-0.95/docs/userguide/images
--- branches/release-0.95/docs/userguide/images 2014-01-08 22:04:50 UTC (rev 7462)
+++ branches/release-0.95/docs/userguide/images 2014-01-08 22:13:41 UTC (rev 7463)
@@ -1 +0,0 @@
-link ../tutorial/images/
\ No newline at end of file
Deleted: branches/release-0.95/docs/userguide/kickstart
--- branches/release-0.95/docs/userguide/kickstart 2014-01-08 22:04:50 UTC (rev 7462)
+++ branches/release-0.95/docs/userguide/kickstart 2014-01-08 22:13:41 UTC (rev 7463)
@@ -1,31 +0,0 @@
-Kickstart
-Kickstart is a tool that can be used to gather various information about
-the remote execution environment for each job that Swift tries to run.
-For each job, Kickstart generates an XML invocation record. By default
-this record is staged back to the submit host if the job fails.
-Before it can be used it must be installed on the remote site and the
-sites file must be configured to point to kickstart.
-Kickstart can be downloaded as part of the Pegasus 'worker package'
-available from the worker packages section of the Pegasus download page
-<http://pegasus.isi.edu/code.php>.
-Untar the relevant worker package somewhere where it is visible to all
-of the worker nodes on the remote execution machine (such as in a shared
-application filesystem).
-Now configure the gridlaunch attribute of the sites catalog to point to
-that path, by adding a gridlaunch attribute to the pool element in
-the site catalog:
-<pool handle="example" gridlaunch="/usr/local/bin/kickstart" sysinfo="INTEL32::LINUX">
-</pool>
-There are various kickstart.* properties, which have sensible default
-values. These are documented in the properties section.
Modified: branches/release-0.95/docs/userguide/language
--- branches/release-0.95/docs/userguide/language 2014-01-08 22:04:50 UTC (rev 7462)
+++ branches/release-0.95/docs/userguide/language 2014-01-08 22:13:41 UTC (rev 7463)
@@ -1,7 +1,7 @@
-The Swift scripting Language
+The Swift Language
-Language basics
+Language Basics
A Swift script describes data, application components, invocations of
applications components, and the inter-relations (data flow) between
@@ -145,7 +145,6 @@
Arrays and Parallel Execution
Arrays of values can be declared using the [] suffix. Following is an example
of an array of strings:
@@ -184,7 +183,6 @@
Associative Arrays
By default, array keys are integers. However, other primitive types are also
allowed as array keys. The syntax for declaring an array with a key type different
than the default is:
@@ -302,7 +300,6 @@
Compound procedures
As with many other programming languages, procedures consisting of
Swift script can be defined. These differ from the previously
mentioned procedures declared with the app keyword, as they invoke
@@ -344,7 +341,6 @@
More about types
Each variable and procedure parameter in Swift script is strongly typed.
Types are used to structure data, to aid in debugging and checking
program correctness and to influence how Swift interacts with data.
@@ -432,3 +428,1390 @@
values in memory or as out-of-core files on disk. Language constructs
called mappers specify how each piece of data is stored.
+More technical details about Swift script
+The syntax of Swift script has a superficial resemblance to C and Java.
+For example, { and } characters are used to enclose blocks of statements.
+A Swift script consists of a number of statements. Statements may
+declare types, procedures and variables, assign values to variables, and
+express operations over arrays.
+Variables
+Variables in Swift scripts are declared to be of a specific type.
+Assignments to those variables must be data of that type. Swift script
+variables are single-assignment - a value may be assigned to a variable
+at most once. This assignment can happen at declaration time or later on
+in execution. When an attempt to read from a variable that has not yet
+been assigned is made, the code performing the read is suspended until
+that variable has been written to. This forms the basis for Swift's
+ability to parallelise execution - all code will execute in parallel
+unless there are variables shared between the code that cause sequencing.
+Variable Declarations
+Variable declaration statements declare new variables. They can
+optionally assign a value to them or map those variables to on-disk files.
+Declaration statements have the general form:
+typename variablename (<mapping> | = initialValue ) ;
+The format of the mapping expression is defined in the Mappers section.
+initialValue may be either an expression or a procedure call that
+returns a single value.
+Variables can also be declared in a multivalued-procedure statement,
+described in another section.
+Assignment Statements
+Assignment statements assign values to previously declared variables.
+Assignments may only be made to variables that have not already been
+assigned. Assignment statements have the general form:
+variable = value;
+where value can be either an expression or a procedure call that returns
+a single value.
+Variables can also be assigned in a multivalued-procedure statement,
+Procedures
+There are two kinds of procedure: An atomic procedure, which describes
+how an external program can be executed; and compound procedures which
+consist of a sequence of Swift script statements.
+A procedure declaration defines the name of a procedure and its input
+and output parameters. Swift script procedures can take multiple inputs
+and produce multiple outputs. Inputs are specified to the right of the
+function name, and outputs are specified to the left. For example:
+(type3 out1, type4 out2) myproc (type1 in1, type2 in2)
+The above example declares a procedure called myproc, which has two
+inputs in1 (of type type1) and in2 (of type type2) and two
+outputs out1 (of type type3) and out2 (of type type4).
+A procedure input parameter can be an optional parameter in which case
+it must be declared with a default value. When calling a procedure, both
+positional parameter and named parameter passings can be passed,
+provided that all optional parameters are declared after the required
+parameters and any optional parameter is bound using keyword parameter
+passing. For example, if myproc1 is defined as:
+(binaryfile bf) myproc1 (int i, string s="foo")
+Then that procedure can be called like this, omitting the optional
+parameter s:
+binaryfile mybf = myproc1(1);
+or like this supplying a value for the optional parameter s:
+binaryfile mybf = myproc1 (1, s="bar");
+Atomic procedures
+An atomic procedure specifies how to invoke an external executable
+program, and how logical data types are mapped to command line arguments.
+Atomic procedures are defined with the app keyword:
+app (binaryfile bf) myproc (int i, string s="foo") {
+ myapp i s @filename(bf);
+which specifies that myproc invokes an executable called myapp,
+passing the values of i, s and the filename of bf as command line
+arguments.
+Compound procedures
+A compound procedure contains a set of Swift script statements:
+(type2 b) foo_bar (type1 a) {
+ type3 c;
+ c = foo(a); // c holds the result of foo
+ b = bar(c); // c is an input to bar
+Control Constructs
+Swift script provides if, switch, foreach, and iterate
+constructs, with syntax and semantics similar to comparable constructs
+in other high-level languages.
+foreach
+The foreach construct is used to apply a block of statements to each
+element in an array. For example:
+check_order (file a[]) {
+ foreach f in a {
+ compute(f);
+foreach statements have the general form:
+foreach controlvariable (,index) in expression {
+ statements
+The block of statements is evaluated once for each element in
+expression which must be an array, with controlvariable set to the
+corresponding element and index (if specified) set to the integer
+position in the array that is being iterated over.
+if
+The if statement allows one of two blocks of statements to be
+executed, based on a boolean predicate. if statements generally have
+the form:
+if(predicate) {
+ statements
+} else {
+ statements
+where predicate is a boolean expression.
+switch
+switch expressions allow one of a selection of blocks to be chosen
+based on the value of a numerical control expression. switch
+statements take the general form:
+switch(controlExpression) {
+ case n1:
+ statements2
+ case n2:
+ statements2
+ default:
+ statements
+The control expression is evaluated, the resulting numerical value used
+to select a corresponding case, and the statements belonging to that
+case block are evaluated. If no case corresponds, then the statements
+belonging to the default block are evaluated.
+Unlike C or Java switch statements, execution does not fall through to
+subsequent case blocks, and no break statement is necessary at the
+end of each block.
+Following is an example of a switch expression in Swift:
+int score=60;
+switch (score){
+case 100:
+ tracef("%s\n", "Bravo!");
+case 90:
+ tracef("%s\n", "very good");
+case 80:
+ tracef("%s\n", "good");
+case 70:
+ tracef("%s\n", "fair");
+default:
+ tracef("%s\n", "unknown grade");
+iterate
+iterate expressions allow a block of code to be evaluated repeatedly,
+with an iteration variable being incremented after each iteration.
+The general form is:
+iterate var {
+ statements;
+} until (terminationExpression);
+Here _var_ is the iteration variable. Its initial value is 0. After each iteration,
+but before _terminationExpression_ is evaluated, the iteration variable is incremented.
+This means that if the termination expression is a function of only the iteration variable,
+the body will never be executed while the termination expression is true.
+Example:
+iterate i {
+ trace(i); // will print 0, 1, and 2
+} until (i == 3);
+Variables declared inside the body of _iterate_ can be used in the termination expression.
+However, their values will reflect the values calculated as part of the last invocation
+of the body, and may not reflect the incremented value of the iteration variable:
+iterate i {
+ trace(i);
+ int j = i; // will print 0, 1, 2, and 3
+} until (j == 3);
+Operators
+The following infix operators are available for use in Swift script
+expressions.
+[options="header, autowidth"]
+|operator|purpose
+|+|numeric addition; string concatenation
+|-|numeric subtraction
+|*|numeric multiplication
+|/|floating point division
+|%/|integer division
+|%%|integer remainder of division
+|== !=|comparison and not-equal-to
+|< > <= >=|numerical ordering
+|&& \|\||boolean and, or
+|!|boolean not
+Global constants
+At the top level of a Swift script program, the global modified may be
+added to a declaration so that it is visible throughout the program,
+rather than only at the top level of the program. This allows global
+constants (of any type) to be defined.
+Imports
+The import directive can be used to import definitions from another
+Swift file.
+For example, a Swift script might contain this:
+import "defs";
+file f;
+which would import the content of defs.swift:
+type file;
+Imported files are read from two places. They are either read from
+the path that is specified from the import command, such as:
+import "definitions/file/defs";
+or they are read from the environment variable SWIFT_LIB. This
+environment variable is used just like the PATH environment
+variable. For example, if the command below was issued to the bash
+shell:
+export SWIFT_LIB=${HOME}/Swift/defs:${HOME}/Swift/functions
+then the import command will check for the file defs.swift in both
+"$\{HOME}/Swift/defs" and "$\{HOME}/Swift/functions" first before trying
+the path that was specified in the import command.
+Other valid imports:
+import "../functions/func"
+import "/home/user/Swift/definitions/defs"
+There is no requirement that a module is imported only once. If a module
+is imported multiple times, for example in different files, then Swift
+will only process the imports once.
+Imports may contain anything that is valid in a Swift script,
+including the code that causes remote execution.
+Mappers
+Mappers provide a mechanism to specify the layout of mapped datasets on
+disk. This is needed when Swift must access files to transfer them to
+remote sites for execution or to pass to applications.
+Swift provides a number of mappers that are useful in common cases. This
+section details those mappers. For more complex cases, it is
+possible to write application-specific mappers in Java and use them
+within a Swift script.
+The Single File Mapper
+The single_file_mapper maps a single physical file to a dataset.
+|Swift variable|Filename
+|f|myfile
+|f [0]|INVALID
+|f.bar|INVALID
+|parameter|meaning
+|file|The location of the physical file including path and file name.
+Example:
+file f <single_file_mapper;file="plot_outfile_param">;
+There is a simplified syntax for this mapper:
+file f <"plot_outfile_param">;
+The Simple Mapper
+The simple_mapper maps a file or a list of files into an array by
+prefix, suffix, and pattern. If more than one file is matched, each of
+the file names will be mapped as a subelement of the dataset.
+|Parameter|Meaning
+|location|A directory that the files are located.
+|prefix|The prefix of the files
+|suffix|The suffix of the files, for instance: ".txt"
+|padding| The number of digits used to uniquely identify the mapped file. This is an optional parameter which defaults to 4.
+|pattern|A UNIX glob style pattern, for instance: "\*foo*" would match
+all file names that contain foo. When this mapper is used to specify
+output filenames, pattern is ignored.
+type file;
+file f <simple_mapper;prefix="foo", suffix=".txt">;
+The above maps all filenames that start with foo and have an extension
+.txt into file f.
+|f|foo.txt
+type messagefile;
+(messagefile t) greeting(string m) {.
+ app {
+ echo m stdout=@filename(t);
+messagefile outfile <simple_mapper;prefix="foo",suffix=".txt">;
+outfile = greeting("hi");
+This will output the string 'hi' to the file foo.txt.
+The simple_mapper can be used to map arrays. It will map the array
+index into the filename between the prefix and suffix.
+type messagefile;
+ app {
+messagefile outfile[] <simple_mapper;prefix="baz",suffix=".txt", padding=2>;
+outfile[0] = greeting("hello");
+outfile[1] = greeting("middle");
+outfile[2] = greeting("goodbye");
+|outfile[0]|baz00.txt
+|outfile[1]|baz01.txt
+|outfile[2]|baz02.txt
+simple_mapper can be used to map structures. It will map the name of
+the structure member into the filename, between the prefix and the suffix.
+type messagefile;
+type mystruct {
+ messagefile left;
+ messagefile right;
+ app {
+mystruct out <simple_mapper;prefix="qux",suffix=".txt">;
+out.left = greeting("hello");
+out.right = greeting("goodbye");
+This will output the string "hello" into the file qux.left.txt and the
+string "goodbye" into the file qux.right.txt.
+|out.left|quxleft.txt
+|out.right|quxright.txt
+Concurrent Mapper
+The concurrent_mapper is almost the same as the simple mapper, except that
+it is used to map an output file, and the filename generated will
+contain an extract sequence that is unique. This mapper is the default
+mapper for variables when no mapper is specified.
+|Parameter|Meaning
+pattern A UNIX glob style pattern, for instance: "\*foo*" would match
+Example:
+file f1;
+file f2 <concurrent_mapper;prefix="foo", suffix=".txt">;
+The above example would use concurrent mapper for f1 and f2, and
+generate f2 filename with prefix "foo" and extension ".txt"
+Filesystem Mapper
+The filesys_mapper is similar to the simple mapper, but maps a file or a
+list of files to an array. Each of the filename is mapped as an element
+in the array. The order of files in the resulting array is not defined.
+TODO: note on difference between location as a relative vs absolute path
+w.r.t. staging to remote location - as mihael said: It's because you
+specify that location in the mapper. Try location="." instead of
+location="/sandbox/..."
+|parameter|meaning
+|location|The directory where the files are located.
+Example:
+file texts[] <filesys_mapper;prefix="foo", suffix=".txt">;
+The above example would map all filenames that start with "foo" and
+have an extension ".txt" into the array texts. For example, if the
+specified directory contains files: foo1.txt, footest.txt,
+foo__1.txt, then the mapping might be:
+|texts[0]|footest.txt
+|texts[1]|foo1.txt
+|texts[2]|foo__1.txt
+Fixed Array Mapper
+The fixed_array_mapper maps from a string that contains a list of
+filenames into a file array.
+|parameter|Meaning
+|files|A string that contains a list of filenames, separated by space,
+comma or colon
+Example:
+file texts[] <fixed_array_mapper;files="file1.txt, fileB.txt, file3.txt">;
+would cause a mapping like this:
+|texts[0]|file1.txt
+|texts[1]|fileB.txt
+|texts[2]|file3.txt
+Array Mapper
+The array_mapper maps from an array of strings into a file
+|parameter|meaning
+|files|An array of strings containing one filename per element
+Example:
+string s[] = [ "a.txt", "b.txt", "c.txt" ];
+file f[] <array_mapper;files=s>;
+This will establish the mapping:
+|f[0]|a.txt
+|f[1]|b.txt
+|f[2]|c.txt
+Regular Expression Mapper
+The regexp_mapper transforms one file name to another using regular
+expression matching.
+|parameter|meaning
+|source|The source file name
+|match|Regular expression pattern to match, use |()| to match whatever
+regular expression is inside the parentheses, and indicate the start and
+end of a group; the contents of a group can be retrieved with the
+|\\number|special sequence (two backslashes are needed because the
+backslash is an escape sequence introducer)
+|transform|The pattern of the file name to transform to, use \number to
+reference the group matched.
+Example:
+file s <"picture.gif">;
+file f <regexp_mapper; source=s,
+ match="(.*)gif", transform="\\1jpg">;
+This example transforms a file ending gif into one ending jpg and
+maps that to a file.
+Structured Regular Expression Mapper
+The structured_regexp_mapper is similar to the regexp_mapper with the only
+difference that it can be applied to arrays while the regexp_mapper cannot.
+|parameter|meaning
+Example:
+file s[] <filesys_mapper; pattern="*.gif">;
+file f[] <structured_regexp_mapper; source=s,
+This example transforms all files in a list that end in gif to end in jpg and maps
+the list to those files.
+CSV Mapper
+The csv_mapper maps the content of a CSV (comma-separated value) file
+into an array of structures. The dataset type needs to be correctly
+defined to conform to the column names in the file. For instance, if the
+file contains columns: name age GPA then the type needs to have member
+elements like this:
+type student {
+ file name;
+ file age;
+ file GPA;
+If the file does not contain a header with column info, then the column
+names are assumed as column1, column2, etc.
+|Parameter|Meaning
+|file|The name of the CSV file to read mappings from.
+|header|Whether the file has a line describing header info; default is |true|
+|skip|The number of lines to skip at the beginning (after header line);
+default is 0.
+|hdelim|Header field delimiter; default is the value of the |delim| parameter
+|delim|Content field delimiters; defaults are space, tab and comma
+Example:
+student stus[] <csv_mapper;file="stu_list.txt">;
+The above example would read a list of student info from file
+"stu_list.txt" and map them into a student array. By default, the file
+should contain a header line specifying the names of the columns. If
+stu_list.txt contains the following:
+name,age,gpa
+101-name.txt, 101-age.txt, 101-gpa.txt
+name55.txt, age55.txt, age55.txt
+q, r, s
+then some of the mappings produced by this example would be:
+|stus[0].name|101-name.txt
+|stus[0].age|101-age.txt
+|stus[0].gpa|101-gpa.txt
+|stus[1].name|name55.txt
+|stus[1].age|age55.txt
+|stus[1].gpa|gpa55.txt
+|stus[2].name|q
+|stus[2].age|r
+|stus[2].gpa|s
+External Mapper
+The external mapper, ext maps based on the output of a supplied Unix
+executable.
+[option="header, autowidth"]
+|parameter|meaning
+|exec|The name of the executable (relative to the current directory, if
+an absolute path is not specified)
+|*|Other parameters are passed to the executable prefixed with a - symbol
+The output (stdout) of the executable should consist of two columns of data,
+separated by a space. The first column should be the path of the mapped
+variable, in Swift script syntax (for example [2] means the 2nd element of an
+array) or the symbol $ to represent the root of the mapped variable. The
+following table shows the symbols that should appear in the first column
+corresponding to the mapping of different types of swift constructs such as
+scalars, arrays and structs.
+|Swift construct|first column|second column
+|scalar|$|file_name
+|anarray[]|[]|file_name
+|2dimarray[][]|[][]|file_name
+|astruct.fld|fld|file_name
+|astructarray[].fldname|[].fldname|file_name
+Example: With the following in mapper.sh,
+#!/bin/bash
+echo "[2] qux"
+echo "[0] foo"
+echo "[1] bar"
+then a mapping statement:
+student stus[] <ext;exec="mapper.sh">;
+would map
+|stus[0]|foo
+|stus[1]|bar
+|stus[2]|qux
+Advanced Example: The following mapper.sh is an advanced example of an external
+mapper that maps a two-dimensional array to a directory of files. The files in
+the said directory are identified by their names appended by a number between
+000 and 099. The first index of the array maps to the first part of the
+filename while the second index of the array maps to the second part of the
+filename.
+#!/bin/sh
+#take care of the mapper args
+while [ $# -gt 0 ]; do
+ case $1 in
+ -location) location=$2;;
+ -padding) padding=$2;;
+ -prefix) prefix=$2;;
+ -suffix) suffix=$2;;
+ -mod_index) mod_index=$2;;
+ -outer_index) outer_index=$2;;
+ *) echo "$0: bad mapper args" 1>&2
+ exit 1;;
+ esac
+ shift 2
+done
+for i in `seq 0 ${outer_index}`
+do
+ for j in `seq -w 000 ${mod_index}`
+ do
+ fj=`echo ${j} | awk '{print $1 +0}'` #format j by removing leading zeros
+ echo "["${i}"]["${fj}"]" ${location}"/"${prefix}${j}${suffix}
+ done
+done
+The mapper definition is as follows:
+file_dat dat_files[][] < ext;
+ exec="mapper.sh",
+ padding=3,
+ location="output",
+ prefix=@strcat( str_root, "_" ),
+ suffix=".dat",
+ outer_index=pid,
+ mod_index=n >;
+Assuming there are 4 files with name aaa, bbb, ccc, ddd and a mod_index of 10,
+we will have 4x10=40 files mapped to a two-dimensional array in the following
+pattern:
+|stus[0][0]|output/aaa_000.dat
+|stus[0][1]|output/aaa_001.dat
+|stus[0][2]|output/aaa_002.dat
+|stus[0][3]|output/aaa_003.dat
+|stus[0][9]|output/aaa_009.dat
+|stus[1][0]|output/bbb_000.dat
+|stus[1][1]|output/bbb_001.dat
+|stus[3][9]|output/ddd_009.dat
+Executing app procedures
+This section describes how Swift executes app procedures, and
+requirements on the behaviour of application programs used in app
+procedures. These requirements are primarily to ensure that the Swift
+can run your application in different places and with the various fault
+tolerance mechanisms in place.
+Mapping of app semantics into unix process execution semantics
+This section describes how an app procedure invocation is translated
+into a (remote) unix process execution. It does not describe the
+mechanisms by which Swift performs that translation; that is described
+in the next section.
+In this section, this example Swift script is used for reference:
+type file;
+app (file o) count(file i) {
+ wc @i stdout=@o;
+file q <"input.txt">;
+file r <"output.txt">;
+The executable for wc will be looked up in tc.data.
+This unix executable will then be executed in some application
+procedure workspace. This means:
+Each application procedure workspace will have an application workspace
+directory. (TODO: can collapse terms application procedure workspace
+and application workspace directory ?
+This application workspace directory will not be shared with any other
+application procedure execution attempt; all application procedure
+execution attempts will run with distinct application procedure
+workspaces. (for the avoidance of doubt: If a Swift script procedure
+invocation is subject to multiple application procedure execution
+attempts (due to Swift-level restarts, retries or replication) then each
+of those application procedure execution attempts will be made in a
+different application procedure workspace. )
+The application workspace directory will be a directory on a POSIX
+filesystem accessible throughout the application execution by the
+application executable.
+Before the application executable is executed:
+ * The application workspace directory will exist.
+ * The input files will exist inside the application workspace
+ directory (but not necessarily as direct children; there may be
+ subdirectories within the application workspace directory).
+ * The input files will be those files mapped to input parameters
+ of the application procedure invocation. (In the example, this
+ means that the file input.txt will exist in the application
+ workspace directory)
+ * For each input file dataset, it will be the case that @filename
+ or @filenames invoked with that dataset as a parameter will
+ return the path relative to the application workspace directory
+ for the file(s) that are associated with that dataset. (In the
+ example, that means that @i will evaluate to the path input.txt)
+ * For each file-bound parameter of the Swift procedure invocation,
+ the associated files (determined by data type?) will always exist.
+ * The input files must be treated as read only files. This may or
+ may not be enforced by unix file system permissions. They may or
+ may not be copies of the source file (conversely, they may be
+ links to the actual source file).
+During/after the application executable execution, the following must
+be true:
+ * If the application executable execution was successful (in the
+ opinion of the application executable), then the application
+ executable should exit with unix return code 0; if the
+ application executable execution was unsuccessful (in the opinion
+ of the application executable), then the application executable
+ should exit with unix return code not equal to 0.
+ * Each file mapped from an output parameter of the Swift script
+ procedure call must exist. Files will be mapped in the same way as
+ for input files.
+ * The output subdirectories will be precreated
+ before execution by Swift if defined within a Swift script such as the
+ location attribute of a mapper. App executables expect to make them if
+ they are referred to in the wrapper scripts.
+ * Output produced by running the application executable on some
+ inputs should be the same no matter how many times, when or where
+ that application executable is run. 'The same' can vary depending
+ on application (for example, in an application it might be
+ acceptable for a PNG->JPEG conversion to produce different,
+ similar looking, output jpegs depending on the environment)
+Things to not assume:
+ * Anything about the path of the application workspace directory
+ * That either the application workspace directory will be deleted or
+ will continue to exist or will remain unmodified after execution
+ has finished
+ * That files can be passed between application procedure
+ invocations through any mechanism except through files known to
+ Swift through the mapping mechanism (there is some exception here
+ for external datasets - there are a separate set of assertions
+ that hold for external datasets)
+ * That application executables will run on any particular site of
+ those available, or than any combination of applications will run
+ on the same or different sites.
+How Swift implements the site execution model
+This section describes the implementation of the semantics described in
+the previous section.
+Swift executes application procedures on one or more sites.
+Each site consists of:
+ * worker nodes. There is some execution mechanism through which
+ the Swift client side executable can execute its wrapper script
+ on those worker nodes. This is commonly GRAM or Falkon or coasters.
+ * a site-shared file system. This site shared filesystem is
+ accessible through some file transfer mechanism from the Swift
+ client side executable. This is commonly GridFTP or coasters. This
+ site shared filesystem is also accessible through the posix file
+ system on all worker nodes, mounted at the same location as seen
+ through the file transfer mechanism. Swift is configured with the
+ location of some site working directory on that site-shared file
+ system.
+There is no assumption that the site shared file system for one site is
+accessible from another site.
+For each workflow run, on each site that is used by that run, a run
+directory is created in the site working directory, by the Swift client
+side.
+In that run directory are placed several subdirectories:
+ * shared/ - site shared files cache
+ * kickstart/ - when kickstart is used, kickstart record files for
+ each job that has generated a kickstart record.
+ * info/ - wrapper script log files
+ * status/ - job status files
+ * jobs/ - application workspace directories (optionally placed
+ here - see below)
+Application execution looks like this:
+For each application procedure call:
+The Swift client side selects a site; copies the input files for that
+procedure call to the site shared file cache if they are not already in
+the cache, using the file transfer mechanism; and then invokes the
+wrapper script on that site using the execution mechanism.
+The wrapper script creates the application workspace directory; places
+the input files for that job into the application workspace directory
+using either cp or ln -s (depending on a configuration option);
+executes the application unix executable; copies output files from the
+application workspace directory to the site shared directory using cp;
+creates a status file under the status/ directory; and exits,
+returning control to the Swift client side. Logs created during the
+execution of the wrapper script are stored under the info/ directory.
+The Swift client side then checks for the presence of and deletes a
+status file indicating success; and copies files from the site shared
+directory to the appropriate client side location.
+The job directory is created (in the default mode) under the jobs/
+directory. However, it can be created under an arbitrary other path,
+which allows it to be created on a different file system (such as a
+worker node local file system in the case that the worker node has a
+local file system).
+image:swift-site-model.png[]
+Technical overview of the Swift architecture
+This section attempts to provide a technical overview of the Swift
+architecture.
+Execution layer
+The execution layer causes an application program (in the form of a unix
+executable) to be executed either locally or remotely.
+The two main choices are local unix execution and execution through
+GRAM. Other options are available, and user provided code can also be
+plugged in.
+The kickstart utility can be used to capture environmental
+information at execution time to aid in debugging and provenance capture.
+Swift script language compilation layer
+Step i: text to XML intermediate form parser/processor. parser written
+in ANTLR - see resources/VDL.g. The XML Schema Definition (XSD) for the
+intermediate language is in resources/XDTM.xsd.
+Step ii: XML intermediate form to Karajan workflow. Karajan.java - reads
+the XML intermediate form. compiles to karajan workflow language - for
+example, expressions are converted from Swift script syntax into Karajan
+syntax, and function invocations become karajan function invocations
+with various modifications to parameters to accomodate return parameters
+and dataset handling.
+Swift/karajan library layer
+Some Swift functionality is provided in the form of Karajan libraries
+that are used at runtime by the Karajan workflows that the Swift
+compiler generates.
+Function reference
+This section details functions that are available for use in the
+Swift language.
+arg
+Takes a command line parameter name as a string parameter and an
+optional default value and returns the value of that string parameter
+from the command line. If no default value is specified and the command
+line parameter is missing, an error is generated. If a default value is
+specified and the command line parameter is missing, @arg will return
+the default value.
+Command line parameters recognized by @arg begin with exactly one
+hyphen and need to be positioned after the script name.
+For example:
+trace(arg("myparam"));
+trace(arg("optionalparam", "defaultvalue"));
+$ swift arg.swift -myparam=hello
+Swift v0.3-dev r1674 (modified locally)
+RunID: 20080220-1548-ylc4pmda
+Swift trace: defaultvalue
+Swift trace: hello
+extractInt
+extractInt(file) will read the specified file, parse an integer from
+the file contents and return that integer.
+extractFloat
+Similar to extractInt, extractFloat(file) will read the specified file, parse a float from
+the file contents and return that float.
+filename
+filename(v) will return a string containing the filename(s) for the
+file(s) mapped to the variable v. When more than one filename is
+returned, the filenames will be space separated inside a single string
+return value.
+filenames
+filenames(v) will return multiple values containing the
+filename(s) for the file(s) mapped to the variable v.
+length
+length(array) will return the length of an array in Swift. This function will wait for all
+elements in the array to be written before returning the length.
+readData
+readData will read data from a specified file and assign it to Swift variable. The format of the input file is
+controlled by the type of the return value. For scalar return types, such as
+int, the specified file should contain a single value of that type. For arrays
+of scalars, the specified file should contain one value per line. For complex types
+of scalars, the file should contain two rows. The first row should be structure
+member names separated by whitespace. The second row should be the
+corresponding values for each structure member, separated by whitespace, in the
+same order as the header row. For arrays of structs, the file should contain a
+heading row listing structure member names separated by whitespace. There
+should be one row for each element of the array, with structure member elements
+listed in the same order as the header row and separated by whitespace. The following example shows how readData() can be used to populate an array of Swift struct-like complex type:
+type Employee{
+ string name;
+ int id;
+ string loc;
+Employee emps[] = readData("emps.txt");
+Where the contents of the "emps.txt" file are:
+name id loc
+Thomas 2222 Chicago
+Gina 3333 Boston
+Anne 4444 Houston
+This will result in the array "emps" with 3 members. This can be processed within a Swift script using the foreach construct as follows:
+foreach emp in emps{
+ tracef("Employee %s lives in %s and has id %d", emp.name, emp.loc, emp.id);
+readStructured
+readStructured will read data from a specified file, like readdata, but
+using a different file format more closely related to that used by the
+ext mapper.
+Input files should list, one per line, a path into a Swift structure,
+and the value for that position in the structure:
+rows[0].columns[0] = 0
+rows[0].columns[1] = 2
+rows[0].columns[2] = 4
+rows[1].columns[0] = 1
+rows[1].columns[1] = 3
+rows[1].columns[2] = 5
+which can be read into a structure defined like this:
+type vector {
+ int columns[];
+type matrix {
+ vector rows[];
+matrix m;
+m = readStructured("readStructured.in");
+(since Swift 0.7, was readData2(deprecated))
+regexp
+regexp(input,pattern,replacement) will apply regular expression
+substitution using the Java java.util.regexp API
+<http://java.sun.com/j2se/1.4.2/docs/api/java/util/regex/Pattern.html>.
+For example:
+string v = regexp("abcdefghi", "c(def)g","monkey");
+will assign the value "abmonkeyhi" to the variable v.
+sprintf
+sprintf(spec, variable list) will generate a string based on the specified format.
+Example: string s = sprintf("\t%s\n", "hello");
+Format specifiers
+[width="100%",frame="topbot"]
+|%%| % sign
+|%M| Filename output (waits for close)
+|%p| Format variable according to an internal format
+|%b| Boolean output
+|%f| Float output
+|%i| int output
+|%s| String output
+|%k| Variable sKipped, no output
+|%q| Array output
+strcat
+strcat(a,b,c,d,...) will return a string containing all of the
+strings passed as parameters joined into a single string. There may be
+any number of parameters.
+The + operator concatenates two strings: strcat(a,b) is the same as
+a + b
+strcut
+strcut(input,pattern) will match the regular expression in the
+pattern parameter against the supplied input string and return the
+section that matches the first matching parenthesised group.
+For example:
+string t = "my name is John and i like puppies.";
+string name = strcut(t, "my name is ([^ ]*) ");
+string out = strcat("Your name is ",name);
+trace(out);
+This will output the message: Your name is John.
+strjoin
+strjoin(array, delimiter) will combine the elements of an array
+into a single string separated by a given delimiter. The array
+passed to strjoin must be of a primitive type (string, int, float,
+or boolean). It will not join the contents of an array of files.
+Example:
+string test[] = ["this", "is", "a", "test" ];
+string mystring = strjoin(test, " ");
+tracef("%s\n", mystring);
+This will print the string "this is a test".
+strsplit
+strsplit(input,pattern) will split the input string based on
+separators that match the given pattern and return a string array.
+Example:
+string words[] = strsplit(t, "\\s");
+foreach word in words {
+ trace(word);
+This will output one word of the sentence on each line (though not
+necessarily in order, due to the fact that foreach iterations execute in
+parallel).
+toInt
+toInt(input) will parse its input string into an integer. This can be
+used with arg() to pass input parameters to a Swift script as
+integers.
+toFloat
+toFloat(input) will parse its input string into a floating point number. This can be
+floating point numbers.
+toString
+toString(input) will parse its input into a string. Input can be an int, float, string,
+or boolean.
+trace
+trace will log its parameters. By default these will appear on both
+stdout and in the run log file. Some formatting occurs to produce the
+log message. The particular output format should not be relied upon.
+tracef
++tracef(_spec_, _variable list_)+ will log its parameters as formatted
+by the formatter _spec_. _spec_ must be a string. Checks the type of
+the specifiers arguments against the variable list and allows for
+certain escape characters.
+Example:
+int i = 3;
+tracef("%s: %i\n", "the value is", i);
+Specifiers:
++%s+:: Format a string.
++%b+:: Format a boolean.
++%i+:: Format a number as an integer.
++%f+:: Format a number as a floating point number.
++%q+:: Format an array.
++%M+:: Format a mapped variable's filename.
++%k+:: Wait for the given variable but do not format it.
++%p+:: Format variable according to an internal format.
+Escape sequences:
++\n+:: Produce a newline.
++\t+:: Produce a tab.
+Known issues: :: Swift does not correctly scan certain backslash
+sequences such as +\\+.
+java
+java(class_name, static_method, method_arg) will call a java static method of the class class_name.
+writeData
+writeData will write out data structures in the format described for
+readData. The following example demonstrates how one can write a string "foo" into a file "writeDataPrimitive.out":
+include::../../tests/language-behaviour/IO/writeDataPrimitive.swift[]
Deleted: branches/release-0.95/docs/userguide/log-processing
--- branches/release-0.95/docs/userguide/log-processing 2014-01-08 22:04:50 UTC (rev 7462)
+++ branches/release-0.95/docs/userguide/log-processing 2014-01-08 22:13:41 UTC (rev 7463)
@@ -1,154 +0,0 @@
-Log Processing
-To properly generate log plots, you must enable VDL/Karajan logging.
-This can be done by putting the following lines in log4j.properties file found in the /etc directory of Swift installation:
-log4j.logger.swift=DEBUG
-log4j.logger.org.globus.cog.abstraction.coaster.service.job.manager.Cpu=DEBUG
-log4j.logger.org.globus.cog.abstraction.coaster.service.job.manager.Block=DEBUG
-All the executables, zsh and perl scripts mentioned in the following steps are
-available in the libexec/log-processing directory of your Swift installation.
-Log plotting
-Normalize event times in the log to the run start time
-* Generate the normalized log, assuming the log is titled +swift-run.log+
-./normalize-log.pl file.contains.start.time swift-run.log > swift-run.norm
-TODO:In what format does the start time be in 'file.contains.start.time'
-Make a basic load plot from Coasters Cpu log lines
-. Normalize the log.
-. Build up a load data file:
-./cpu-job-load.pl < swift-run.norm > load.data
-. Plot with the JFreeChart-based plotter in usertools/plotter:
-swift_plotter.zsh -s load.cfg load.eps load.data
-Note: Th load.cfg is available from swift/libexec/log-processing/
-Make a basic job completion plot from Coasters Cpu log lines
-. Build up a completed data file:
-./cpu-job-completed.pl < swift-run.norm > completed.data
-swift_plotter.zsh -s completed.cfg completed.eps completed.data
-Make a basic Block allocation plot from Coasters Block log lines
-. Build up a block allocation data file:
-./block-level.pl < swift-run.norm > blocks.data
-swift_plotter.zsh -s blocks.{cfg,eps,data}
-Make a job runtime distribution plot from Coasters Cpu log lines
-. Build up a job runtime file:
-./extract-times.pl < swift-run.norm > times.data
-. Put the job runtimes into 1-second buckets:
-./ buckets.pl 1 times.data > buckets.data
-swift_plotter.zsh -s buckets.cfg buckets.eps buckets.data
-Meaning and interpretation of Swift log messages
-A Swift log file is typically a text file with the name of the Swift run and
-its timestamp in the filename and an extension ".log". In addition, a ".rlog"
-file is Swift's resume log which is used by Swift when a run is resumed using
-the "-resume" option. The .rlog file is only for Swift's internal purpose and
-not to be interpreted by the user.
-Each line in the log file typically consists of three parts. The first part
-is the timestamp, the second is the type of log message and the third is the
-message itself. The types of log messages follows the java log4j standard types
-of TRACE, DEBUG, INFO, WARN, ERROR and FATAL.
-This section lists the various Swift log messages and explains the meaning and
-likely interpretation of those messages. Note that the list is not
-comprehensive at this time. Also note that we will ignore the timestamps here.
-. _DEBUG Loader arguments: [-sites.file, sites.xml, -config, cf, -tc.file, tc, postproc-gridftp.swift]_
- Swift commandline arguments
-. _DEBUG Loader Max heap: 5592449024_
- The java runtime heap size
-. _DEBUG textfiles BEGIN_
- A dump of config and source files associated with this run
-. _DEBUG VDL2ExecutionContext Stack dump_
-. _INFO SetFieldValue Set_
-. _INFO get__site STARTCOMPOUND thread=0-8 name=get__site_
-. _INFO vdl:execute START thread=0-8-0 tr=_
-. _INFO GlobalSubmitQueue No global submit throttle set. Using default (1024)_
-. _DEBUG vdl:execute2 THREAD_ASSOCIATION jobid=getsite-ymj72ook thread=0-8-0-1 host=localhost replicationGroup=xmj72ook_
-. _DEBUG vdl:execute2 JOB_START jobid=getsite-ymj72ook tr=getsite arguments=[644] tmpdir=postproc-gridftp-20120319-0942-adf1o1u2/jobs/y/getsite-ymj72ook host=localhost_
-. _INFO GridExec TASK_DEFINITION_
-. _WARN RemoteConfiguration Find: http://140.221.8.62:38260_
-. _INFO AbstractStreamKarajanChannel$Multiplexer Multiplexer 0 started_
-. _INFO AbstractStreamKarajanChannel$Multiplexer (0) Scheduling SC-null for addition_
-. _INFO AbstractStreamKarajanChannel Channel configured_
-. _INFO MetaChannel MetaChannel: 651528505[1478354072: {}] -> null.bind -> SC-null_
-. _INFO ReadBuffer Will ask for 1 buffers for a size of 6070_
-. _INFO ThrottleManager O maxBuffers=512, crtBuffers=0, allowedTransfers=256, active=0, suspended=0_
-. _INFO ThrottleManager mem=113.54 MB, heap=482.88 MB, maxHeap=5.21 GB_
-. _INFO ThrottleManager I maxBuffers=512, crtBuffers=0, allowedTransfers=256, active=0, suspended=0_
-. _INFO PerformanceDiagnosticInputStream [MEM] Heap total: 482.88 MB, Heap used: 118.58 MB_
-Heap sizes for performance
-. _INFO vdl:execute END_SUCCESS thread=0-8-0 tr=getsite_
-The job ended successfully
-. _INFO WeightedHostScoreScheduler CONTACT_SELECTED host=localhost, score=99.854_
-. _
Deleted: branches/release-0.95/docs/userguide/mappers
--- branches/release-0.95/docs/userguide/mappers 2014-01-08 22:04:50 UTC (rev 7462)
+++ branches/release-0.95/docs/userguide/mappers 2014-01-08 22:13:41 UTC (rev 7463)
@@ -1,898 +0,0 @@
-Mappers
-When a DSHandle represents a data file (or container of datafiles), it
-is associated with a mapper. The mapper is used to identify which files
-belong to that DSHandle.
-A dataset's physical representation is declared by a mapping descriptor,
-which defines how each element in the dataset's logical schema is stored
-in, and fetched from, physical structures such as directories, files,
-and remote servers.
-Mappers are parameterized to take into account properties such as
-varying dataset location. In order to access a dataset, we need to know
-three things: its type, its mapping, and the value(s) of any
-parameter(s) associated with the mapping descriptor. For example, if we
-want to describe a dataset, of type imagefile, and whose physical
-representation is a file called "file1.bin" located at
-"/home/yongzh/data/", then the dataset might be declared as follows:
-imagefile f1<single_file_mapper;file="/home/yongzh/data/file1.bin">
-The above example declares a dataset called f1, which uses a single file
-mapper to map a file from a specific location.
-Swift has a simplified syntax for this case, since
-single_file_mapper is frequently used:
-binaryfile f1<"/home/yongzh/data/file1.bin">
-Swift comes with a number of mappers that handle common mapping
-patterns. These are documented in the mappers section of this
-guide.
-More technical details about Swift script
-The syntax of Swift script has a superficial resemblance to C and Java.
-For example, { and } characters are used to enclose blocks of statements.
-A Swift script consists of a number of statements. Statements may
-declare types, procedures and variables, assign values to variables, and
-express operations over arrays.
-Variables
-Variables in Swift scripts are declared to be of a specific type.
-Assignments to those variables must be data of that type. Swift script
-variables are single-assignment - a value may be assigned to a variable
-at most once. This assignment can happen at declaration time or later on
-in execution. When an attempt to read from a variable that has not yet
-been assigned is made, the code performing the read is suspended until
-that variable has been written to. This forms the basis for Swift's
-ability to parallelise execution - all code will execute in parallel
-unless there are variables shared between the code that cause sequencing.
-Variable Declarations
-Variable declaration statements declare new variables. They can
-optionally assign a value to them or map those variables to on-disk files.
-Declaration statements have the general form:
-typename variablename (<mapping> | = initialValue ) ;
-The format of the mapping expression is defined in the Mappers section.
-initialValue may be either an expression or a procedure call that
-returns a single value.
-Variables can also be declared in a multivalued-procedure statement,
-described in another section.
-Assignment Statements
-Assignment statements assign values to previously declared variables.
-Assignments may only be made to variables that have not already been
-assigned. Assignment statements have the general form:
-variable = value;
-where value can be either an expression or a procedure call that returns
-a single value.
-Variables can also be assigned in a multivalued-procedure statement,
-Procedures
-There are two kinds of procedure: An atomic procedure, which describes
-how an external program can be executed; and compound procedures which
-consist of a sequence of Swift script statements.
-A procedure declaration defines the name of a procedure and its input
-and output parameters. Swift script procedures can take multiple inputs
-and produce multiple outputs. Inputs are specified to the right of the
-function name, and outputs are specified to the left. For example:
-(type3 out1, type4 out2) myproc (type1 in1, type2 in2)
-The above example declares a procedure called myproc, which has two
-inputs in1 (of type type1) and in2 (of type type2) and two
-outputs out1 (of type type3) and out2 (of type type4).
-A procedure input parameter can be an optional parameter in which case
-it must be declared with a default value. When calling a procedure, both
-positional parameter and named parameter passings can be passed,
-provided that all optional parameters are declared after the required
-parameters and any optional parameter is bound using keyword parameter
-passing. For example, if myproc1 is defined as:
-(binaryfile bf) myproc1 (int i, string s="foo")
-Then that procedure can be called like this, omitting the optional
-parameter s:
-binaryfile mybf = myproc1(1);
-or like this supplying a value for the optional parameter s:
-binaryfile mybf = myproc1 (1, s="bar");
-Atomic procedures
-An atomic procedure specifies how to invoke an external executable
-program, and how logical data types are mapped to command line arguments.
-Atomic procedures are defined with the app keyword:
-app (binaryfile bf) myproc (int i, string s="foo") {
- myapp i s @filename(bf);
-which specifies that myproc invokes an executable called myapp,
-passing the values of i, s and the filename of bf as command line
-arguments.
-Compound procedures
-A compound procedure contains a set of Swift script statements:
-(type2 b) foo_bar (type1 a) {
- type3 c;
- c = foo(a); // c holds the result of foo
- b = bar(c); // c is an input to bar
-Control Constructs
-Swift script provides if, switch, foreach, and iterate
-constructs, with syntax and semantics similar to comparable constructs
-in other high-level languages.
-foreach
-The foreach construct is used to apply a block of statements to each
-element in an array. For example:
-check_order (file a[]) {
- foreach f in a {
- compute(f);
-foreach statements have the general form:
-foreach controlvariable (,index) in expression {
- statements
-The block of statements is evaluated once for each element in
-expression which must be an array, with controlvariable set to the
-corresponding element and index (if specified) set to the integer
-position in the array that is being iterated over.
-if
-The if statement allows one of two blocks of statements to be
-executed, based on a boolean predicate. if statements generally have
-the form:
-if(predicate) {
- statements
-} else {
- statements
-where predicate is a boolean expression.
-switch
-switch expressions allow one of a selection of blocks to be chosen
-based on the value of a numerical control expression. switch
-statements take the general form:
-switch(controlExpression) {
- case n1:
- statements2
- case n2:
- statements2
- default:
- statements
-The control expression is evaluated, the resulting numerical value used
-to select a corresponding case, and the statements belonging to that
-case block are evaluated. If no case corresponds, then the statements
-belonging to the default block are evaluated.
-Unlike C or Java switch statements, execution does not fall through to
-subsequent case blocks, and no break statement is necessary at the
-end of each block.
-Following is an example of a switch expression in Swift:
-int score=60;
-switch (score){
-case 100:
- tracef("%s\n", "Bravo!");
-case 90:
- tracef("%s\n", "very good");
-case 80:
- tracef("%s\n", "good");
-case 70:
- tracef("%s\n", "fair");
-default:
- tracef("%s\n", "unknown grade");
-iterate
-iterate expressions allow a block of code to be evaluated repeatedly,
-with an iteration variable being incremented after each iteration.
-The general form is:
-iterate var {
- statements;
-} until (terminationExpression);
-Here _var_ is the iteration variable. Its initial value is 0. After each iteration,
-but before _terminationExpression_ is evaluated, the iteration variable is incremented.
-This means that if the termination expression is a function of only the iteration variable,
-the body will never be executed while the termination expression is true.
-Example:
-iterate i {
- trace(i); // will print 0, 1, and 2
-} until (i == 3);
-Variables declared inside the body of _iterate_ can be used in the termination expression.
-However, their values will reflect the values calculated as part of the last invocation
-of the body, and may not reflect the incremented value of the iteration variable:
-iterate i {
- trace(i);
- int j = i; // will print 0, 1, 2, and 3
-} until (j == 3);
-Operators
-The following infix operators are available for use in Swift script
-expressions.
-[options="header, autowidth"]
-|operator|purpose
-|+|numeric addition; string concatenation
-|-|numeric subtraction
-|*|numeric multiplication
-|/|floating point division
-|%/|integer division
-|%%|integer remainder of division
-|== !=|comparison and not-equal-to
-|< > <= >=|numerical ordering
-|&& \|\||boolean and, or
-|!|boolean not
-Global constants
-At the top level of a Swift script program, the global modified may be
-added to a declaration so that it is visible throughout the program,
-rather than only at the top level of the program. This allows global
-constants (of any type) to be defined. (since Swift 0.10)
-Imports
-The import directive can be used to import definitions from another
-Swift file.
-For example, a Swift script might contain this:
-import "defs";
-file f;
-which would import the content of defs.swift:
-type file;
-Imported files are read from two places. They are either read from
-the path that is specified from the import command, such as:
-import "definitions/file/defs";
-or they are read from the environment variable SWIFT_LIB. This
-environment variable is used just like the PATH environment
-variable. For example, if the command below was issued to the bash
-shell:
-export SWIFT_LIB=${HOME}/Swift/defs:${HOME}/Swift/functions
-then the import command will check for the file defs.swift in both
-"$\{HOME}/Swift/defs" and "$\{HOME}/Swift/functions" first before trying
-the path that was specified in the import command.
-Other valid imports:
-import "../functions/func"
-import "/home/user/Swift/definitions/defs"
-There is no requirement that a module is imported only once. If a module
-is imported multiple times, for example in different files, then Swift
-will only process the imports once.
-Imports may contain anything that is valid in a Swift script,
-including the code that causes remote execution.
-Mappers
-Mappers provide a mechanism to specify the layout of mapped datasets on
-disk. This is needed when Swift must access files to transfer them to
-remote sites for execution or to pass to applications.
-Swift provides a number of mappers that are useful in common cases. This
-section details those mappers. For more complex cases, it is
-possible to write application-specific mappers in Java and use them
-within a Swift script.
-The single file mapper
-The single_file_mapper maps a single physical file to a dataset.
-|Swift variable|Filename
-|f|myfile
-|f [0]|INVALID
-|f.bar|INVALID
-|parameter|meaning
-|file|The location of the physical file including path and file name.
-Example:
-file f <single_file_mapper;file="plot_outfile_param">;
-There is a simplified syntax for this mapper:
-file f <"plot_outfile_param">;
-The simple mapper
-The simple_mapper maps a file or a list of files into an array by
-prefix, suffix, and pattern. If more than one file is matched, each of
-the file names will be mapped as a subelement of the dataset.
-|Parameter|Meaning
-|location|A directory that the files are located.
-|prefix|The prefix of the files
-|suffix|The suffix of the files, for instance: ".txt"
-|padding| The number of digits used to uniquely identify the mapped file. This is an optional parameter which defaults to 4.
-|pattern|A UNIX glob style pattern, for instance: "\*foo*" would match
-all file names that contain foo. When this mapper is used to specify
-output filenames, pattern is ignored.
-type file;
-file f <simple_mapper;prefix="foo", suffix=".txt">;
-The above maps all filenames that start with foo and have an extension
-.txt into file f.
-|f|foo.txt
-type messagefile;
-(messagefile t) greeting(string m) {.
- app {
- echo m stdout=@filename(t);
-messagefile outfile <simple_mapper;prefix="foo",suffix=".txt">;
-outfile = greeting("hi");
-This will output the string 'hi' to the file foo.txt.
-The simple_mapper can be used to map arrays. It will map the array
-index into the filename between the prefix and suffix.
-type messagefile;
- app {
-messagefile outfile[] <simple_mapper;prefix="baz",suffix=".txt", padding=2>;
-outfile[0] = greeting("hello");
-outfile[1] = greeting("middle");
-outfile[2] = greeting("goodbye");
-|outfile[0]|baz00.txt
-|outfile[1]|baz01.txt
-|outfile[2]|baz02.txt
-simple_mapper can be used to map structures. It will map the name of
-the structure member into the filename, between the prefix and the suffix.
-type messagefile;
-type mystruct {
- messagefile left;
- messagefile right;
- app {
-mystruct out <simple_mapper;prefix="qux",suffix=".txt">;
-out.left = greeting("hello");
-out.right = greeting("goodbye");
-This will output the string "hello" into the file qux.left.txt and the
-string "goodbye" into the file qux.right.txt.
-|out.left|quxleft.txt
-|out.right|quxright.txt
-concurrent mapper
-The concurrent_mapper is almost the same as the simple mapper, except that
-it is used to map an output file, and the filename generated will
-contain an extract sequence that is unique. This mapper is the default
-mapper for variables when no mapper is specified.
-|Parameter|Meaning
-pattern A UNIX glob style pattern, for instance: "\*foo*" would match
-Example:
-file f1;
-file f2 <concurrent_mapper;prefix="foo", suffix=".txt">;
-The above example would use concurrent mapper for f1 and f2, and
-generate f2 filename with prefix "foo" and extension ".txt"
-File system mapper
-The filesys_mapper is similar to the simple mapper, but maps a file or a
-list of files to an array. Each of the filename is mapped as an element
-in the array. The order of files in the resulting array is not defined.
-TODO: note on difference between location as a relative vs absolute path
-w.r.t. staging to remote location - as mihael said: It's because you
-specify that location in the mapper. Try location="." instead of
-location="/sandbox/..."
-|parameter|meaning
-|location|The directory where the files are located.
-Example:
-file texts[] <filesys_mapper;prefix="foo", suffix=".txt">;
-The above example would map all filenames that start with "foo" and
-have an extension ".txt" into the array texts. For example, if the
-specified directory contains files: foo1.txt, footest.txt,
-foo__1.txt, then the mapping might be:
-|texts[0]|footest.txt
-|texts[1]|foo1.txt
-|texts[2]|foo__1.txt
-fixed array mapper
-The fixed_array_mapper maps from a string that contains a list of
-filenames into a file array.
-|parameter|Meaning
-|files|A string that contains a list of filenames, separated by space,
-comma or colon
-Example:
-file texts[] <fixed_array_mapper;files="file1.txt, fileB.txt, file3.txt">;
-would cause a mapping like this:
-|texts[0]|file1.txt
-|texts[1]|fileB.txt
-|texts[2]|file3.txt
-array mapper
-The array_mapper maps from an array of strings into a file
-|parameter|meaning
-|files|An array of strings containing one filename per element
-Example:
-string s[] = [ "a.txt", "b.txt", "c.txt" ];
-file f[] <array_mapper;files=s>;
-This will establish the mapping:
-|f[0]|a.txt
-|f[1]|b.txt
-|f[2]|c.txt
-regular expression mapper
-The regexp_mapper transforms one file name to another using regular
-expression matching.
-|parameter|meaning
-|source|The source file name
-|match|Regular expression pattern to match, use |()| to match whatever
-regular expression is inside the parentheses, and indicate the start and
-end of a group; the contents of a group can be retrieved with the
-|\\number|special sequence (two backslashes are needed because the
-backslash is an escape sequence introducer)
-|transform|The pattern of the file name to transform to, use \number to
-reference the group matched.
-Example:
-file s <"picture.gif">;
-file f <regexp_mapper; source=s,
- match="(.*)gif", transform="\\1jpg">;
-This example transforms a file ending gif into one ending jpg and
-maps that to a file.
-structured regular expression mapper
-The structured_regexp_mapper is similar to the regexp_mapper with the only
-difference that it can be applied to arrays while the regexp_mapper cannot.
-|parameter|meaning
-Example:
-file s[] <filesys_mapper; pattern="*.gif">;
-file f[] <structured_regexp_mapper; source=s,
-This example transforms all files in a list that end in gif to end in jpg and maps
-the list to those files.
-csv mapper
-The csv_mapper maps the content of a CSV (comma-separated value) file
-into an array of structures. The dataset type needs to be correctly
-defined to conform to the column names in the file. For instance, if the
-file contains columns: name age GPA then the type needs to have member
-elements like this:
-type student {
- file name;
- file age;
- file GPA;
-If the file does not contain a header with column info, then the column
-names are assumed as column1, column2, etc.
-|Parameter|Meaning
-|file|The name of the CSV file to read mappings from.
-|header|Whether the file has a line describing header info; default is |true|
-|skip|The number of lines to skip at the beginning (after header line);
-default is 0.
-|hdelim|Header field delimiter; default is the value of the |delim| parameter
-|delim|Content field delimiters; defaults are space, tab and comma
-Example:
-student stus[] <csv_mapper;file="stu_list.txt">;
-The above example would read a list of student info from file
-"stu_list.txt" and map them into a student array. By default, the file
-should contain a header line specifying the names of the columns. If
-stu_list.txt contains the following:
-name,age,gpa
-101-name.txt, 101-age.txt, 101-gpa.txt
-name55.txt, age55.txt, age55.txt
-q, r, s
-then some of the mappings produced by this example would be:
-|stus[0].name|101-name.txt
-|stus[0].age|101-age.txt
-|stus[0].gpa|101-gpa.txt
-|stus[1].name|name55.txt
-|stus[1].age|age55.txt
-|stus[1].gpa|gpa55.txt
-|stus[2].name|q
-|stus[2].age|r
-|stus[2].gpa|s
-external mapper
-The external mapper, ext maps based on the output of a supplied Unix
-executable.
-[option="header, autowidth"]
-|parameter|meaning
-|exec|The name of the executable (relative to the current directory, if
-an absolute path is not specified)
-|*|Other parameters are passed to the executable prefixed with a - symbol
-The output (stdout) of the executable should consist of two columns of data,
-separated by a space. The first column should be the path of the mapped
-variable, in Swift script syntax (for example [2] means the 2nd element of an
-array) or the symbol $ to represent the root of the mapped variable. The
-following table shows the symbols that should appear in the first column
-corresponding to the mapping of different types of swift constructs such as
-scalars, arrays and structs.
-|Swift construct|first column|second column
-|scalar|$|file_name
-|anarray[]|[]|file_name
-|2dimarray[][]|[][]|file_name
-|astruct.fld|fld|file_name
-|astructarray[].fldname|[].fldname|file_name
-Example: With the following in mapper.sh,
-#!/bin/bash
-echo "[2] qux"
-echo "[0] foo"
-echo "[1] bar"
-then a mapping statement:
-student stus[] <ext;exec="mapper.sh">;
-would map
-|stus[0]|foo
-|stus[1]|bar
-|stus[2]|qux
-Advanced Example: The following mapper.sh is an advanced example of an external
-mapper that maps a two-dimensional array to a directory of files. The files in
-the said directory are identified by their names appended by a number between
-000 and 099. The first index of the array maps to the first part of the
-filename while the second index of the array maps to the second part of the
-filename.
-#!/bin/sh
-#take care of the mapper args
-while [ $# -gt 0 ]; do
- case $1 in
- -location) location=$2;;
- -padding) padding=$2;;
- -prefix) prefix=$2;;
- -suffix) suffix=$2;;
- -mod_index) mod_index=$2;;
- -outer_index) outer_index=$2;;
- *) echo "$0: bad mapper args" 1>&2
- exit 1;;
- esac
- shift 2
-done
-for i in `seq 0 ${outer_index}`
-do
- for j in `seq -w 000 ${mod_index}`
- do
- fj=`echo ${j} | awk '{print $1 +0}'` #format j by removing leading zeros
- echo "["${i}"]["${fj}"]" ${location}"/"${prefix}${j}${suffix}
- done
-done
-The mapper definition is as follows:
-file_dat dat_files[][] < ext;
- exec="mapper.sh",
- padding=3,
- location="output",
- prefix=@strcat( str_root, "_" ),
- suffix=".dat",
- outer_index=pid,
- mod_index=n >;
-Assuming there are 4 files with name aaa, bbb, ccc, ddd and a mod_index of 10,
-we will have 4x10=40 files mapped to a two-dimensional array in the following
-pattern:
-|stus[0][0]|output/aaa_000.dat
-|stus[0][1]|output/aaa_001.dat
-|stus[0][2]|output/aaa_002.dat
-|stus[0][3]|output/aaa_003.dat
-|stus[0][9]|output/aaa_009.dat
-|stus[1][0]|output/bbb_000.dat
-|stus[1][1]|output/bbb_001.dat
-|stus[3][9]|output/ddd_009.dat
Modified: branches/release-0.95/docs/userguide/overview
--- branches/release-0.95/docs/userguide/overview 2014-01-08 22:04:50 UTC (rev 7462)
+++ branches/release-0.95/docs/userguide/overview 2014-01-08 22:13:41 UTC (rev 7463)
@@ -1,10 +1,5 @@
Overview
-This manual provides reference material for Swift: the Swift
-language and the Swift runtime system. For introductory material,
-consult the
-http://www.ci.uchicago.edu/swift/guides/trunk/tutorial/tutorial.html[Swift tutorial].
Swift is a data-flow oriented coarse grained scripting language that supports
dataset typing and mapping, dataset iteration, conditional branching,
and procedural composition.
Deleted: branches/release-0.95/docs/userguide/reliability_mechanisms
--- branches/release-0.95/docs/userguide/reliability_mechanisms 2014-01-08 22:04:50 UTC (rev 7462)
+++ branches/release-0.95/docs/userguide/reliability_mechanisms 2014-01-08 22:13:41 UTC (rev 7463)
@@ -1,101 +0,0 @@
-Reliability mechanisms
-This section details reliabilty mechanisms in Swift: retries, restarts
-and replication.
-Retries
-If an application procedure execution fails, Swift will attempt that
-execution again repeatedly until it succeeds, up until the limit defined
-in the execution.retries configuration property.
-Site selection will occur for retried jobs in the same way that it
-happens for new jobs. Retried jobs may run on the same site or may run
-on a different site.
-If the retry limit execution.retries is reached for an application
-procedure, then that application procedure will fail. This will cause
-the entire run to fail - either immediately (if the lazy.errors
-property is false) or after all other possible work has been attempted
-(if the lazy.errors property is true).
-With or without lazy errors, each app is re-tried <execution.retries>
-times before it is considered failed for good. An app that has failed
-but still has retries left will appear as "Failed but can retry".
-Without lazy errors, once the first (time-wise) app has run out of
-retries, the whole run is stopped and the error reported.
-With lazy errors, if an app fails after all retries, its outputs are
-marked as failed. All apps that depend on failed outputs will also fail
-and their outputs marked as failed. All apps that have non-failed
-outputs will continue to run normally until everything that can proceed
-completes.
-For example, if you have:
-foreach x in [1:1024] {
- app(x);
-... and if the first started app fails, all the other ones can still
-continue, and if they don't otherwise fail, the run will only terminate
-when all 1023 of them will complete.
-So basically the idea behind lazy errors is to run EVERYTHING that can
-safely be run before stopping.
-Some types of errors (such as internal swift errors happening in an app
-thread) will still stop the run immediately even in lazy errors mode.
-But we all know there are no such things as internal swift errors :)
-Restarts
-If a run fails, Swift can resume the program from the point of failure.
-When a run fails, a restart log file will be left behind in a file named
-using the unique job ID and a .rlog extension. This restart log can
-then be passed to a subsequent Swift invocation using the -resume
-parameter. Swift will resume execution, avoiding execution of
-invocations that have previously completed successfully. The Swift
-source file and input data files should not be modified between runs.
-Every run creates a restart log file with a named composed of the file
-name of the workflow being executed, an invocation ID, a numeric ID, and
-the .rlog extension. For example, example.swift, when executed,
-could produce the following restart log file:
-example-ht0adgi315l61.0.rlog. Normally, if the run completes
-successfully, the restart log file is deleted. If however the workflow
-fails, swift can use the restart log file to continue execution from a
-point before the failure occurred. In order to restart from a restart
-log file, the -resume logfile argument can be used after the
-Swift script file name. Example:
-$ swift -resume example-ht0adgi315l61.0.rlog example.swift.
-Replication
-When an execution job has been waiting in a site queue for a certain
-period of time, Swift can resubmit replicas of that job (up to the limit
-defined in the replication.limit configuration property). When any of
-those jobs moves from queued to active state, all of the other replicas
-will be cancelled.
-This is intended to deal with situations where some sites have a
-substantially longer (sometimes effectively infinite) queue time than
-other sites. Selecting those slower sites can cause a very large delay
-in overall run time.
-Replication can be enabled by setting the replication.enabled
-configuration property to true. The maximum number of replicas that
-will be submitted for a job is controlled by the replication.limit
-configuration property.
-When replication is enabled, Swift will also enforce the maxwalltime
-profile setting for jobs as documented in the profiles section.
Deleted: branches/release-0.95/docs/userguide/site_catalog
--- branches/release-0.95/docs/userguide/site_catalog 2014-01-08 22:04:50 UTC (rev 7462)
+++ branches/release-0.95/docs/userguide/site_catalog 2014-01-08 22:13:41 UTC (rev 7463)
@@ -1,186 +0,0 @@
-The Site Catalog - sites.xml
-The site catalog lists details of each site that Swift can use. The
-default file contains one entry for local execution, and a large number
-of commented-out example entries for other sites.
-By default, the site catalog is stored in etc/sites.xml. This path can
-be overridden with the sites.file configuration property, either in
-the Swift configuration file or on the command line.
-The sites file is formatted as XML. It consists of <pool> elements,
-one for each site that Swift will use.
-Pool element
-Each pool element must have a handle attribute, giving a symbolic
-name for the site. This can be any name, but must correspond to entries
-for that site in the transformation catalog.
-Optionally, the gridlaunch attribute can be used to specify the path
-to kickstart on the site.
-Each pool must specify a file transfer method, an execution method and
-a remote working directory. Optionally, profile settings can
-be specified.
-File transfer method
-Transfer methods are specified with either the <gridftp> element or
-the <filesystem> element.
-To use gridftp or local filesystem copy, use the <gridftp> element:
-<gridftp url="gsiftp://evitable.ci.uchicago.edu" />
-The url attribute may specify a GridFTP server, using the gsiftp URI
-scheme; or it may specify that filesystem copying will be used (which
-assumes that the site has access to the same filesystem as the
-submitting machine) using the URI local://localhost.
-Filesystem access using scp (the SSH copy protocol) can be specified
-using the <filesystem> element:
-<filesystem url="www11.i2u2.org" provider="ssh"/>
-For additional ssh configuration information, see the ssh execution
-provider documentation below.
-Filesystem access using CoG coasters can be also be
-specified using the <filesystem> element. More detail about
-configuring that can be found in the CoG coasters section.
-Execution method
-Execution methods may be specified either with the <jobmanager> or
-<execution> element.
-The <jobmanager> element can be used to specify execution through
-GRAM2. For example,
-<jobmanager universe="vanilla" url="evitable.ci.uchicago.edu/jobmanager-fork" major="2" />
-The universe attribute should always be set to vanilla. The url
-attribute should specify the name of the GRAM2 gatekeeper host, and the
-name of the jobmanager to use. The major attribute should always be set
-to 2.
-The <execution> element can be used to specify execution through other
-execution providers:
-To use GRAM4, specify the gt4 provider. For example:
-<execution provider="gt4" jobmanager="PBS" url="tg-grid.uc.teragrid.org" />
-The url attribute should specify the GRAM4 submission site. The
-jobmanager attribute should specify which GRAM4 jobmanager will be used.
-For local execution, the local provider should be used, like this:
-<execution provider="local" url="none" />
-For PBS execution, the pbs provider should be used:
-<execution provider="pbs" url="none" />
-The GLOBUS::queue profile key can be used to
-specify which PBS queue jobs will be submitted to.
-For execution through a local Condor installation, the condor provider
-should be used. This provider can run jobs either in the default vanilla
-universe, or can use Condor-G to run jobs on remote sites.
-When running locally, only the <execution> element needs to be specified:
-<execution provider="condor" url="none" />
-When running with Condor-G, it is necessary to specify the Condor grid
-universe and the contact string for the remote site. For example:
- <execution provider="condor" />
- <profile namespace="globus" key="jobType">grid</profile>
- <profile namespace="globus" key="gridResource">gt2 belhaven-1.renci.org/jobmanager-fork</profile>
-For execution through SSH, the ssh provider should be used:
-<execution url="www11.i2u2.org" provider="ssh"/>
-with configuration made in ~/.ssh/auth.defaults with the string
-'www11.i2u2.org' changed to the appropriate host name:
-www11.i2u2.org.type=key
-www11.i2u2.org.username=hategan
-www11.i2u2.org.key=/home/mike/.ssh/i2u2portal
-www11.i2u2.org.passphrase=XXXX
-For execution using the CoG Coaster mechanism, the coaster
-provider should be used:
-<execution provider="coaster" url="tg-grid.uc.teragrid.org"
- jobmanager="gt2:gt2:pbs" />
-More details about configuration of coasters can be found in the section
-on coasters.
-Work directory
-The workdirectory element specifies where on the site files can be
-stored.
-<workdirectory>/tmp/swift.workdir</workdirectory>
-This directory must be accessible through the specified transfer mechanism and
-also mounted on all worker nodes that will be used for execution. A shared
-cluster scratch filesystem is appropriate for this. Note that you need to
-specify _absolute pathname_ for this field.
-Scratch
-The scratch element takes in a value of a directory on a shared filesystem. For example:
-<scratch>/work/01739/ketan/lab/swift/myscratch</scratch>
-The scratch element specifies that the underlying Swift wrapper will copy the
-input files into the scratch directory and the job will be run from that
-directory. In the absence of scratch tag, Swift will run the job from
-workdirectory by creating symlinks to input files in a shared directory.
-Profiles
-Profile keys can be specified using the <profile> element.
-For example:
-<profile namespace="globus" key="queue">fast</profile>
-The site catalog format is an evolution of the VDS site catalog format
-which is documented here
-<http://vds.uchicago.edu/vds/doc/userguide/html/H_SiteCatalog.html>.
Deleted: branches/release-0.95/docs/userguide/transformation_catalog
--- branches/release-0.95/docs/userguide/transformation_catalog 2014-01-08 22:04:50 UTC (rev 7462)
+++ branches/release-0.95/docs/userguide/transformation_catalog 2014-01-08 22:13:41 UTC (rev 7463)
@@ -1,55 +0,0 @@
-The Transformation Catalog - tc
-The transformation catalog lists where application executables are
-located on execution sites.
-By default, the site catalog is stored in etc/tc.data. This path can
-be overridden with the tc.file configuration property, either in the
-Swift configuration file or on the command line.
-The format is one line per executable per site, with fields separated by space or tab.
-Some example entries:
-localhost cat /bin/cat null null null
-localhost vasp /home/ketan/runvasp.sh null null null
-fusion echo /bin/echo INSTALLED INTEL32::LINUX null
-TGUC touch /usr/bin/touch INSTALLED INTEL32::LINUX GLOBUS::maxwalltime="0:1"
-The fields are: site, transformation name, executable path, installation
-status, platform, and profile entries.
-The site field should correspond to a site name listed in the sites catalog.
-The transformation name should correspond to the transformation name
-used in a Swift script app procedure.
-The executable path should specify where the executable is
-located on that site.
-The installation status and platform fields are not used. Set them to
-INSTALLED and INTEL32::LINUX respectively. Alternatively, they could be set to null.
-The profiles field should be set to null if no profile entries are to
-be specified.
-Setting Environment Variables
-It is often useful to set environment variables when running an application.
-This can be accomplished using *env* in the profile entry. For example,
-the following application sets an environment variable called R_LIBS to
-/home/user/R_libs.
-localhost R /usr/bin/R INSTALLED INTEL32::LINUX env::R_LIBS=/home/user/r_libs
-Setting Multiple Profiles
-Multiple profile entries can be added by using a semicolon. The example below
-sets two environment variables: R_LIBS and R_HOME.
-localhost R /usr/bin/R INSTALLED INTEL32::LINUX env::R_LIBS=/home/user/r_libs;env::R_HOME=/home/user/r
Modified: branches/release-0.95/docs/userguide/userguide.txt
--- branches/release-0.95/docs/userguide/userguide.txt 2014-01-08 22:04:50 UTC (rev 7462)
+++ branches/release-0.95/docs/userguide/userguide.txt 2014-01-08 22:13:41 UTC (rev 7463)
@@ -3,41 +3,16 @@
:toc:
:icons:
-:website: http://www.ci.uchicago.edu/swift/guides/userguide.php
:numbered:
include::overview[]
+include::gettingStarted[]
include::language[]
-include::mappers[]
+include::configuration[]
-include::commands[]
+include::debugging[]
-include::app_procedures[]
-include::configuration_properties[]
-include::profiles[]
-include::site_catalog[]
-include::transformation_catalog[]
-include::build_options[]
-include::kickstart[]
-include::reliability_mechanisms[]
-include::clustering[]
-include::coasters[]
-include::howto_tips[]
-include::cdm[]
-include::log-processing[]
-link:http://www.ci.uchicago.edu/swift/docs/index.php[home]
+link:http://swift-lang.org/docs/index.php[home]
More information about the Swift-commit
