[Swift-commit] r8230 - usertools/plotter/src/plotter
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Mon Aug 25 22:46:38 CDT 2014
Author: wozniak
Date: 2014-08-25 22:46:38 -0500 (Mon, 25 Aug 2014)
New Revision: 8230
Modified:
   usertools/plotter/src/plotter/Lines.java
Log:
Support date axes
Modified: usertools/plotter/src/plotter/Lines.java
--- usertools/plotter/src/plotter/Lines.java	2014-08-22 20:23:09 UTC (rev 8229)
+++ usertools/plotter/src/plotter/Lines.java	2014-08-26 03:46:38 UTC (rev 8230)
@@ -19,6 +19,7 @@
 import org.jfree.chart.ChartFactory;
 import org.jfree.chart.JFreeChart;
 import org.jfree.chart.annotations.XYTextAnnotation;
+import org.jfree.chart.axis.DateAxis;
 import org.jfree.chart.axis.LogAxis;
 import org.jfree.chart.axis.LogarithmicAxis;
 import org.jfree.chart.axis.NumberAxis;
@@ -120,16 +121,12 @@
       File file = new File(name);
       Util.verbose("open: " + file);
-      List<String> lines = null;
       double[][] array;
       try
-        lines = LineReader.read(file);
+        List<String> lines = LineReader.read(file);
         if (lines == null)
           System.err.println("Problem when reading: "+file);
         array = LineReader.array(lines);
       catch (FileNotFoundException e)
@@ -142,18 +139,24 @@
         (e.getMessage() + "\n" + "In file: " + file);
-      if (array.length == 0)
-        throw new UserInputException
-        ("file has no data: " + name);
-      if (array[0].length != 2)
-        ("file is not two-column: " + name);
+      checkRead(name, array);
       data.add(array);
       addLabel(name, labels);
       Util.verbose("array:\n" + toString(array));
+  static void checkRead(String name, double[][] array)
+  throws UserInputException
+	  if (array.length == 0)
+		  throw new UserInputException
+		  ("file has no data: " + name);
+	  if (array[0].length != 2)
+		  ("file is not two-column: " + name);
        Generate simple plot.
        @param collection The x,y data.
@@ -256,6 +259,7 @@
   private static void setupPlot(JFreeChart chart,
       XYSeriesCollection collection)
     XYPlot plot = chart.getXYPlot();
     XYLineAndShapeRenderer renderer = new XYLineAndShapeRenderer();
@@ -283,6 +287,7 @@
   static void setAxes(XYPlot plot)
     setAxisTypes(plot);
@@ -315,14 +320,20 @@
   private static void setAxisTypes(XYPlot plot)
     if (axis_x_type.equals("logarithmic"))
       NumberAxis domainAxis = new LogarithmicAxis(xlabel);
       plot.setDomainAxis(domainAxis);
+    else if (axis_x_type.equals("date"))
+    	DateAxis dateAxis = new DateAxis(xlabel);
+    	plot.setDomainAxis(dateAxis);
     else if (!axis_x_type.equals("normal"))
-      throw new RuntimeException
       ("Invalid axis.x type: " + axis_x_type);
     if (axis_y_type.equals("logarithmic"))
@@ -331,7 +342,7 @@
       plot.setRangeAxis(rangeAxis);
     else if (!axis_y_type.equals("normal"))
       ("Invalid axis.y type: " + axis_y_type);
