[Swift-commit] r8128 - SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/05-md
wozniak at ci.uchicago.edu
Wed Aug 13 11:02:28 CDT 2014
Author: wozniak
Date: 2014-08-13 11:02:28 -0500 (Wed, 13 Aug 2014)
New Revision: 8128
Added:
SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/05-md/main.c
SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/05-md/md.h
Modified:
SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/05-md/Makefile
SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/05-md/md.c
Log:
Working version - split out main.c
Modified: SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/05-md/Makefile
--- SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/05-md/Makefile 2014-08-13 15:55:17 UTC (rev 8127)
+++ SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/05-md/Makefile 2014-08-13 16:02:28 UTC (rev 8128)
@@ -1,12 +1,17 @@
bin = md
-src = md.c
CC = gcc
-#CFLAGS = -O3 -ffast-math
+CFLAGS = -O0 -g -fPIC
+# CFLAGS = -O3 -ffast-math -g -fPIC
-$(bin): $(src)
- $(CC) -o $@ $(bin).c -lm
+SRC = main.c md.c
+OBJ = $(patsubst %.c,%.o,$(SRC))
+all: $(bin)
+$(bin): $(OBJ)
+ $(CC) -o $(@) $(OBJ) -lm
.PHONY: clean
clean:
rm -f $(obj) $(bin)
Added: SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/05-md/main.c
--- SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/05-md/main.c (rev 0)
+++ SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/05-md/main.c 2014-08-13 16:02:28 UTC (rev 8128)
@@ -0,0 +1,298 @@
+ * main.c
+ * Created on: Aug 13, 2014
+ * Author: wozniak
+#include <stdio.h>
+#include <stdlib.h>
+#include "md.h"
+char *outfile = "md.dat";
+char *trjfile = "md.trj.tgz";
+int main ( int argc, char *argv[] )
+ Purpose:
+ MAIN is the main program for MD.
+ Discussion:
+ MD implements a simple molecular dynamics simulation.
+ The velocity Verlet time integration scheme is used.
+ The particles interact with a central pair potential.
+ Usage:
+ md nd np step_num print_step_num dt mass printinfo scale_factor scale_offset seed outFile trajectoryFile
+ where
+ * nd is the spatial dimension (2 or 3);
+ * np is the number of particles (500, for instance);
+ * step_num is the number of time steps (500, for instance);
+ * print_step_num is the number of snapshot prints (10 for instance);
+ * dt is size of timestep;
+ * mass is particle mass;
+ * printinfo is a string to append to each particle coord
+ * scale_offset and scale_factor are used to scale particle positions for logging/rendering (FIXME)
+ * seed sets the initial configuration
+ Licensing:
+ This code is distributed under the GNU LGPL license.
+ Modified:
+ 05 November 2010
+ Author:
+ Original FORTRAN90 version by Bill Magro.
+ C version by John Burkardt.
+ Parameters:
+ None
+ double *acc;
+ double *box;
+ double ctime;
+ double ctime1;
+ double ctime2;
+ double dt = 0.0001;
+ double e0;
+ double *force;
+ int i;
+ int id;
+ double kinetic;
+ double mass = 1.0 * .0001;
+ int nd;
+ int np;
+ double *pos;
+ double potential;
+ int seed = 123456789;
+ int step;
+ int step_num;
+ int step_print;
+ int step_print_index;
+ int step_print_num=10;
+ double *vel;
+ timestamp ( );
+ printf ( "\n" );
+ printf ( "MD\n" );
+ printf ( " C version\n" );
+ printf ( " A molecular dynamics program.\n" );
+ Get the spatial dimension.
+ if ( 1 < argc )
+ nd = atoi ( argv[1] );
+ else
+ printf ( "\n" );
+ printf ( " Enter ND, the spatial dimension (2 or 3).\n" );
+ scanf ( "%d", &nd );
+// Get the number of points.
+ if ( 2 < argc )
+ np = atoi ( argv[2] );
+ else
+ printf ( "\n" );
+ printf ( " Enter NP, the number of points (500, for instance).\n" );
+ scanf ( "%d", &np );
+// Get the number of time steps.
+ if ( 3 < argc )
+ step_num = atoi ( argv[3] );
+ else
+ printf ( "\n" );
+ printf ( " Enter ND, the number of time steps (500 or 1000, for instance).\n" );
+ scanf ( "%d", &step_num );
+ Get any additional args (command-line only)
+ md nd np step_num [ step__print_num dt mass printinfo scale_factor scale_offset randomseed outfile trjfile ]
+ if ( 4 < argc )
+ step_print_num = atoi ( argv[4] );
+ if ( 5 < argc )
+ dt = atof ( argv[5] );
+ if ( 6 < argc )
+ mass = atof ( argv[6] );
+ if ( 7 < argc )
+ printinfo = ( argv[7] );
+ if ( 8 < argc )
+ scale_factor = atof ( argv[8] );
+ if ( 9 < argc )
+ scale_offset = atof ( argv[9] );
+ if ( 10 < argc )
+ seed = atof ( argv[10] );
+ if ( 11 < argc )
+ outfile = argv[11];
+ if ( 12 < argc )
+ trjfile = argv[12];
+ Report.
+ printf ( "\n" );
+ printf ( " MD: Argument count: %d\n", argc );
+ printf ( " ND, the spatial dimension, is %d\n", nd );
+ printf ( " NP, the number of particles in the simulation, is %d\n", np );
+ printf ( " STEP_NUM, the number of time steps, is %d\n", step_num );
+ printf ( " STEP_PRINT_NUM, the number of snapshots to print, is %d\n", step_print_num );
+ printf ( " DT, the size of each time step, is %f\n", dt );
+ printf ( " MASS, the particle mass, is %f\n", mass );
+ printf ( " PRINTINFO, the pass-through info to c-ray, is %s\n", printinfo );
+ printf ( " SCALE_FACTOR, the particle position scaling factor, is %f\n", scale_factor );
+ printf ( " SCALE_OFFSET, the particle position scaling offset, is %f\n", scale_offset );
+ printf ( " SEED, the simulation randomization seed, is %d\n", seed );
+ Allocate memory.
+ acc = ( double * ) malloc ( nd * np * sizeof ( double ) );
+ box = ( double * ) malloc ( nd * sizeof ( double ) );
+ force = ( double * ) malloc ( nd * np * sizeof ( double ) );
+ pos = ( double * ) malloc ( nd * np * sizeof ( double ) );
+ vel = ( double * ) malloc ( nd * np * sizeof ( double ) );
+ Set the dimensions of the box.
+ for ( i = 0; i < nd; i++ )
+ box[i] = 10.0;
+ printf ( "\n" );
+ printf ( " Initializing positions, velocities, and accelerations.\n" );
+ Set initial positions, velocities, and accelerations.
+ initialize ( np, nd, box, &seed, pos, vel, acc );
+ Compute the forces and energies.
+ printf ( "\n" );
+ printf ( " Computing initial forces and energies.\n" );
+ compute ( np, nd, pos, vel, mass, force, &potential, &kinetic );
+ e0 = potential + kinetic;
+ This is the main time stepping loop:
+ Compute forces and energies,
+ Update positions, velocities, accelerations.
+ printf ( "\n" );
+ printf ( " At each step, we report the potential and kinetic energies.\n" );
+ printf ( " The sum of these energies should be a constant.\n" );
+ printf ( " As an accuracy check, we also print the relative error\n" );
+ printf ( " in the total energy.\n" );
+ printf ( "\n" );
+ printf ( " Step Potential Kinetic (P+K-E0)/E0\n" );
+ printf ( " Energy P Energy K Relative Energy Error\n" );
+ printf ( "\n" );
+ FILE *ofile = fopen(outfile,"w");
+ fprintf (ofile, " Step Potential Kinetic RelativeErr\n" );
+ step_print = 0;
+ step_print_index = 0;
+ step = 0;
+ printf ( " %8d %14f %14f %14e\n",
+ step, potential, kinetic, ( potential + kinetic - e0 ) / e0 );
+ fprintf ( ofile, " %8d %14f %14f %14e\n",
+ step_print_index = step_print_index + 1;
+ step_print = ( step_print_index * step_num ) / step_print_num;
+ ctime1 = cpu_time ( );
+ for ( step = 1; step <= step_num; step++ )
+ if ( step == step_print )
+ printf ( " %8d %14f %14f %14e\n", step, potential, kinetic,
+ ( potential + kinetic - e0 ) / e0 );
+ fprintf ( ofile, " %8d %14f %14f %14e\n", step, potential, kinetic,
+ snap ( np, nd, pos, vel, force, acc, mass, dt );
+ update ( np, nd, pos, vel, force, acc, mass, dt );
+ ctime2 = cpu_time ( );
+ ctime = ctime2 - ctime1;
+ printf ( "\n" );
+ printf ( " Elapsed cpu time for main computation:\n" );
+ printf ( " %f seconds.\n", ctime );
+ free ( acc );
+ free ( box );
+ free ( force );
+ free ( pos );
+ free ( vel );
+ char tarcmd[2000];
+ sprintf(tarcmd,"tar zcf %s md??.trj",trjfile);
+ system(tarcmd);
+ Terminate.
+ printf ( "\n" );
+ printf ( " Normal end of execution.\n" );
+ printf ( "\n" );
+ timestamp ( );
+ fclose(ofile);
+ return 0;
Modified: SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/05-md/md.c
--- SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/05-md/md.c 2014-08-13 15:55:17 UTC (rev 8127)
+++ SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/05-md/md.c 2014-08-13 16:02:28 UTC (rev 8128)
@@ -3,7 +3,8 @@
# include <time.h>
# include <math.h>
-int main ( int argc, char *argv[] );
+#include "md.h"
void compute ( int np, int nd, double pos[], double vel[],
double mass, double f[], double *pot, double *kin );
double cpu_time ( void );
@@ -19,293 +20,9 @@
double scale_factor = 2.5, scale_offset = -2.0;
char *printinfo = "0.05 1.0 0.2 0.05 50.0 0.1";
-char *outfile = "md.dat";
-char *trjfile = "md.trj.tgz";
- Purpose:
- MAIN is the main program for MD.
- Discussion:
- MD implements a simple molecular dynamics simulation.
- The velocity Verlet time integration scheme is used.
- The particles interact with a central pair potential.
- Usage:
- md nd np step_num print_step_num dt mass printinfo scale_factor scale_offset seed outFile trajectoryFile
- where
- * nd is the spatial dimension (2 or 3);
- * np is the number of particles (500, for instance);
- * step_num is the number of time steps (500, for instance);
- * print_step_num is the number of snapshot prints (10 for instance);
- * dt is size of timestep;
- * mass is particle mass;
- * printinfo is a string to append to each particle coord
- * scale_offset and scale_factor are used to scale particle positions for logging/rendering (FIXME)
- * seed sets the initial configuration
- Licensing:
- This code is distributed under the GNU LGPL license.
- Modified:
- 05 November 2010
- Author:
- Original FORTRAN90 version by Bill Magro.
- C version by John Burkardt.
- Parameters:
- None
- double *acc;
- double *box;
- double ctime;
- double ctime1;
- double ctime2;
- double dt = 0.0001;
- double e0;
- double *force;
- int i;
- int id;
- double kinetic;
- double mass = 1.0 * .0001;
- int nd;
- int np;
- double *pos;
- double potential;
- int seed = 123456789;
- int step;
- int step_num;
- int step_print;
- int step_print_index;
- int step_print_num=10;
- double *vel;
- timestamp ( );
- printf ( "\n" );
- printf ( "MD\n" );
- printf ( " C version\n" );
- printf ( " A molecular dynamics program.\n" );
- Get the spatial dimension.
- if ( 1 < argc )
- nd = atoi ( argv[1] );
- else
- printf ( "\n" );
- printf ( " Enter ND, the spatial dimension (2 or 3).\n" );
- scanf ( "%d", &nd );
-// Get the number of points.
- if ( 2 < argc )
- np = atoi ( argv[2] );
- else
- printf ( "\n" );
- printf ( " Enter NP, the number of points (500, for instance).\n" );
- scanf ( "%d", &np );
-// Get the number of time steps.
- if ( 3 < argc )
- step_num = atoi ( argv[3] );
- else
- printf ( "\n" );
- printf ( " Enter ND, the number of time steps (500 or 1000, for instance).\n" );
- scanf ( "%d", &step_num );
- Get any additional args (command-line only)
- md nd np step_num [ step__print_num dt mass printinfo scale_factor scale_offset randomseed outfile trjfile ]
- if ( 4 < argc )
- step_print_num = atoi ( argv[4] );
- if ( 5 < argc )
- dt = atof ( argv[5] );
- if ( 6 < argc )
- mass = atof ( argv[6] );
- if ( 7 < argc )
- printinfo = ( argv[7] );
- if ( 8 < argc )
- scale_factor = atof ( argv[8] );
- if ( 9 < argc )
- scale_offset = atof ( argv[9] );
- if ( 10 < argc )
- seed = atof ( argv[10] );
- if ( 11 < argc )
- outfile = argv[11];
- if ( 12 < argc )
- trjfile = argv[12];
- Report.
- printf ( "\n" );
- printf ( " MD: Argument count: %d\n", argc );
- printf ( " ND, the spatial dimension, is %d\n", nd );
- printf ( " NP, the number of particles in the simulation, is %d\n", np );
- printf ( " STEP_NUM, the number of time steps, is %d\n", step_num );
- printf ( " STEP_PRINT_NUM, the number of snapshots to print, is %d\n", step_print_num );
- printf ( " DT, the size of each time step, is %f\n", dt );
- printf ( " MASS, the particle mass, is %f\n", mass );
- printf ( " PRINTINFO, the pass-through info to c-ray, is %s\n", printinfo );
- printf ( " SCALE_FACTOR, the particle position scaling factor, is %f\n", scale_factor );
- printf ( " SCALE_OFFSET, the particle position scaling offset, is %f\n", scale_offset );
- printf ( " SEED, the simulation randomization seed, is %d\n", seed );
- Allocate memory.
- acc = ( double * ) malloc ( nd * np * sizeof ( double ) );
- box = ( double * ) malloc ( nd * sizeof ( double ) );
- force = ( double * ) malloc ( nd * np * sizeof ( double ) );
- pos = ( double * ) malloc ( nd * np * sizeof ( double ) );
- vel = ( double * ) malloc ( nd * np * sizeof ( double ) );
- Set the dimensions of the box.
- for ( i = 0; i < nd; i++ )
- box[i] = 10.0;
- printf ( "\n" );
- printf ( " Initializing positions, velocities, and accelerations.\n" );
- Set initial positions, velocities, and accelerations.
- initialize ( np, nd, box, &seed, pos, vel, acc );
- Compute the forces and energies.
- printf ( "\n" );
- printf ( " Computing initial forces and energies.\n" );
- compute ( np, nd, pos, vel, mass, force, &potential, &kinetic );
- e0 = potential + kinetic;
- This is the main time stepping loop:
- Compute forces and energies,
- Update positions, velocities, accelerations.
- printf ( "\n" );
- printf ( " At each step, we report the potential and kinetic energies.\n" );
- printf ( " The sum of these energies should be a constant.\n" );
- printf ( " As an accuracy check, we also print the relative error\n" );
- printf ( " in the total energy.\n" );
- printf ( "\n" );
- printf ( " Step Potential Kinetic (P+K-E0)/E0\n" );
- printf ( " Energy P Energy K Relative Energy Error\n" );
- printf ( "\n" );
- FILE *ofile = fopen(outfile,"w");
- fprintf (ofile, " Step Potential Kinetic RelativeErr\n" );
- step_print = 0;
- step_print_index = 0;
- step = 0;
- printf ( " %8d %14f %14f %14e\n",
- step, potential, kinetic, ( potential + kinetic - e0 ) / e0 );
- fprintf ( ofile, " %8d %14f %14f %14e\n",
- step_print_index = step_print_index + 1;
- step_print = ( step_print_index * step_num ) / step_print_num;
- ctime1 = cpu_time ( );
- for ( step = 1; step <= step_num; step++ )
- if ( step == step_print )
- printf ( " %8d %14f %14f %14e\n", step, potential, kinetic,
- ( potential + kinetic - e0 ) / e0 );
- fprintf ( ofile, " %8d %14f %14f %14e\n", step, potential, kinetic,
- snap ( np, nd, pos, vel, force, acc, mass, dt );
- update ( np, nd, pos, vel, force, acc, mass, dt );
- ctime2 = cpu_time ( );
- ctime = ctime2 - ctime1;
- printf ( "\n" );
- printf ( " Elapsed cpu time for main computation:\n" );
- printf ( " %f seconds.\n", ctime );
- free ( acc );
- free ( box );
- free ( force );
- free ( pos );
- free ( vel );
- char tarcmd[2000];
- sprintf(tarcmd,"tar zcf %s md??.trj",trjfile);
- system(tarcmd);
- Terminate.
- printf ( "\n" );
- printf ( " Normal end of execution.\n" );
- printf ( "\n" );
- timestamp ( );
- fclose(ofile);
- return 0;
Added: SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/05-md/md.h
--- SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/05-md/md.h (rev 0)
+++ SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/05-md/md.h 2014-08-13 16:02:28 UTC (rev 8128)
@@ -0,0 +1,14 @@
+ * md.h
+ * Author: wozniak
+#ifndef MD_H
+#define MD_H
+extern double scale_factor, scale_offset;
+extern char *printinfo;
+#endif
More information about the Swift-commit
