[Swift-commit] r8102 -	SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas
    wozniak at ci.uchicago.edu
    Tue Aug 12 11:35:09 CDT 2014
Author: wozniak
Date: 2014-08-12 11:35:09 -0500 (Tue, 12 Aug 2014)
New Revision: 8102
Added:
   SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/dot.swift
Removed:
   SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/test-blas.swift
Modified:
   SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/blas.swift
   SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/blas.tcl
   SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/run-local.sh
Log:
BLAS example works
Modified: SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/blas.swift
--- SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/blas.swift	2014-08-12 16:17:37 UTC (rev 8101)
+++ SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/blas.swift	2014-08-12 16:35:09 UTC (rev 8102)
@@ -6,4 +6,12 @@
   z = blas_ddot_blobs(N, x, y);
-(float z) blas_ddot_blobs(int n, blob x, blob y) "blas" "0.0.1" "ddot";
+// (float z) blas_ddot_blobs(int n, blob x, blob y) "blas" "0.0.1" "ddot";
+(float z) blas_ddot_blobs(int n, blob x, blob y)
+"blas" "0.0.1"
+  set <<z>> [ blas::ddot_impl <<n>> <<x>> <<y>> ]
Modified: SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/blas.tcl
--- SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/blas.tcl	2014-08-12 16:17:37 UTC (rev 8101)
+++ SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/blas.tcl	2014-08-12 16:35:09 UTC (rev 8102)
@@ -3,33 +3,40 @@
 namespace eval blas {
-    proc ddot { stack outputs inputs } {
+    # proc ddot { stack outputs inputs } {
-        turbine::rule "ddot-$outputs" $inputs $turbine::LOCAL \
-            "blas::ddot_body $outputs $inputs"
+    #     turbine::rule "ddot-$outputs" $inputs $turbine::LOCAL \
+    #         "blas::ddot_body $outputs $inputs"
-    proc ddot_body { z n x y } {
+    # proc ddot_body { z n x y } {
-        puts "$z,$n,$x,$y"
+    #     puts "$z,$n,$x,$y"
-        set N [ retrieve_integer $n ]
-        # Note: L = [ list pointer length ]
-        set LX [ adlb::blob_cache $x ]
-        set pointerX [ lindex $LX 0 ]
-        set lengthX  [ lindex $LX 1 ]
-        set LY [ adlb::blob_cache $y ]
-        set pointerY [ lindex $LY 0 ]
-        set lengthY  [ lindex $LY 1 ]
+    #     set N [ retrieve_integer $n ]
+    #     # Note: L = [ list pointer length ]
+    #     set LX [ adlb::blob_cache $x ]
+    #     set pointerX [ lindex $LX 0 ]
+    #     set lengthX  [ lindex $LX 1 ]
+    #     set LY [ adlb::blob_cache $y ]
+    #     set pointerY [ lindex $LY 0 ]
+    #     set lengthY  [ lindex $LY 1 ]
-        if { $lengthX != $lengthY } {
-            error "ddot: length(x) != length(y)"
+    #     if { $lengthX != $lengthY } {
+    #         error "ddot: length(x) != length(y)"
-        set result [ blas::c::ddot $N $pointerX $pointerY ]
-        puts "result: $result"
-        turbine::store_float $z $result
-        adlb::blob_free $x
-        adlb::blob_free $y
+    #     set result [ blas::c::ddot $N $pointerX $pointerY ]
+    #     puts "result: $result"
+    #     turbine::store_float $z $result
+    #     adlb::blob_free $x
+    #     adlb::blob_free $y
+    proc ddot_impl { n x y } {
+        set x_ptr [ lindex $x 0 ]
+        set y_ptr [ lindex $y 0 ]
+        set z [ blas::c::ddot $n $x_ptr $y_ptr ]
+        return $z
Copied: SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/dot.swift (from rev 8098, SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/test-blas.swift)
--- SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/dot.swift	                        (rev 0)
+++ SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/dot.swift	2014-08-12 16:35:09 UTC (rev 8102)
@@ -0,0 +1,35 @@
+   Example 3 - DOT.SWIFT
+// Swift/T libraries:
+import blob;
+import io;
+import matrix;
+// BLAS library for this example:
+import blas;
+main
+  // Swift floats are 64-bit
+  float A[];
+  float B[];
+  int N = 3;
+  foreach i in [0:N-1]
+    A[i] = itof(i);
+    B[i] = itof(i+1);
+  // Use => for output ordering
+  printf("A") =>
+    vector_print(A) =>
+    printf("\nB") =>
+    vector_print(B)
+    float z = blas_ddot(N, A, B);
+  printf("\nA*B=%0.1f", z);
Modified: SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/run-local.sh
--- SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/run-local.sh	2014-08-12 16:17:37 UTC (rev 8101)
+++ SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/run-local.sh	2014-08-12 16:35:09 UTC (rev 8102)
@@ -1,33 +1,9 @@
-#!/bin/bash
+#!/bin/bash -eu
-export TURBINE_USER_LIB=${PWD}
+source ../../cfg/setup-local.sh
-check()
-  if [[ ${?} != 0 ]]
-  then
-    MSG=$1
-    echo ${MSG}
-  fi
-STC=$( which stc )
-check
-echo "using stc: ${STC}"
-TURBINE=$( which turbine )
-check
-echo "using turbine: ${TURBINE}"
-STC_OUT=test-blas.tcl
-${STC} test-blas.swift ${STC_OUT}
-check
-echo "compiled to: ${STC_OUT}"
-export ADLB_EXHAUST_TIME=1
-${TURBINE} -l -n 3 ${STC_OUT}
-check
-exit 0
+PROGRAM=dot
+stc     ${PROGRAM}.swift
+turbine ${PROGRAM}.tcl
Deleted: SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/test-blas.swift
--- SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/test-blas.swift	2014-08-12 16:17:37 UTC (rev 8101)
+++ SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/test-blas.swift	2014-08-12 16:35:09 UTC (rev 8102)
@@ -1,19 +0,0 @@
-#include <builtins.swift>
-#include <io.swift>
-#include "blas.swift"
-main {
-  // Swift floats are 64-bit
-  float A[];
-  float B[];
-  int N = 3;
-  foreach i in [0:N-1]
-    A[i] = itof(i);
-    B[i] = itof(i+1);
-  float z = blas_ddot(N, A, B);
-  printf("A*B=%0.1f", z);
More information about the Swift-commit
