[Swift-commit] r7098 - trunk/src/org/griphyn/vdl/mapping
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Sat Sep 21 23:05:35 CDT 2013
Author: hategan
Date: 2013-09-21 23:05:35 -0500 (Sat, 21 Sep 2013)
New Revision: 7098
Modified:
   trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
   trunk/src/org/griphyn/vdl/mapping/ArrayDataNode.java
Log:
fixed self closing race condition and lockup
Modified: trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2013-09-22 04:05:10 UTC (rev 7097)
+++ trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2013-09-22 04:05:35 UTC (rev 7098)
@@ -732,16 +732,20 @@
     	boolean closed;
     	WaitingThreadsMonitor.addThread(l, this);
     	synchronized(this) {
-        	if (this.listeners == null) {
-        		this.listeners = new ArrayList<FutureListener>();
-        	this.listeners.add(l);
-        	closed = this.closed;
+    	    closed = addListener0(l);
     	if (closed) {
     		notifyListeners();
+    protected boolean addListener0(FutureListener l) {
+        if (this.listeners == null) {
+            this.listeners = new ArrayList<FutureListener>();
+        this.listeners.add(l);
+        return this.closed;
     protected void notifyListeners() {
     	List<FutureListener> l;
Modified: trunk/src/org/griphyn/vdl/mapping/ArrayDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/ArrayDataNode.java	2013-09-22 04:05:10 UTC (rev 7097)
+++ trunk/src/org/griphyn/vdl/mapping/ArrayDataNode.java	2013-09-22 04:05:35 UTC (rev 7098)
@@ -24,7 +24,10 @@
 import java.util.List;
 import java.util.Map;
+import k.rt.FutureListener;
 import org.globus.cog.karajan.futures.FutureNotYetAvailable;
+import org.griphyn.vdl.karajan.WaitingThreadsMonitor;
 import org.griphyn.vdl.type.Field;
 public class ArrayDataNode extends DataNode {
@@ -101,6 +104,21 @@
     @Override
+    public void addListener(FutureListener l) {
+        boolean shouldNotify;
+        WaitingThreadsMonitor.addThread(l, this);
+        synchronized(this) {
+            shouldNotify = addListener0(l);
+            if (keyList != null) {
+                shouldNotify = true;
+        if (shouldNotify) {
+            notifyListeners();
+    @Override
     public synchronized DSHandle createField(Comparable<?> key) throws NoSuchFieldException {
         DSHandle h = super.createField(key);
         addKey(key);
