[Swift-commit] r7079 - in trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi: . tui
hategan at ci.uchicago.edu
Tue Sep 17 02:27:16 CDT 2013
Author: hategan
Date: 2013-09-17 02:27:16 -0500 (Tue, 17 Sep 2013)
New Revision: 7079
Modified:
trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/SummaryPane.java
trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/LevelBars.java
Log:
use total number of jobs as range for summary bars instead of the maximum
Modified: trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/SummaryPane.java
--- trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/SummaryPane.java 2013-09-17 03:08:32 UTC (rev 7078)
+++ trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/SummaryPane.java 2013-09-17 07:27:16 UTC (rev 7079)
@@ -66,6 +66,7 @@
SummaryItem summary = (SummaryItem) state.getItemByID(SummaryItem.ID, StatefulItemClass.WORKFLOW);
if (summary != null) {
Map<String, Integer> counts = summary.getCounts(state);
+ bars.setRange(state.getTotal());
for (int i = 0; i < SummaryItem.STATES.length; i++) {
if (SummaryItem.STATES[i].isEnabled()) {
Integer v = counts.get(SummaryItem.STATES[i].getName());
Modified: trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/LevelBars.java
--- trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/LevelBars.java 2013-09-17 03:08:32 UTC (rev 7078)
+++ trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/LevelBars.java 2013-09-17 07:27:16 UTC (rev 7079)
@@ -34,14 +34,15 @@
public void setValue(int index, int v) {
values[index] = v;
+ int r = range;
for (int i = 0; i < values.length; i++) {
- if (values[i] > range) {
- range = values[i];
+ if (values[i] > r) {
+ r = values[i];
- if (range > 0) {
- getBar(i).setValue((float) values[i] / range);
+ if (r > 0) {
+ getBar(i).setValue((float) values[i] / r);
else {
getBar(i).setValue(0);
@@ -49,6 +50,10 @@
+ public void setRange(int range) {
+ this.range = range;
public void setOtherValue(int i, int ov) {
if (range != 0) {
getBar(i).setOtherValue((float) ov / range);
More information about the Swift-commit
