[Swift-commit] r7069 - in trunk/src/org/griphyn/vdl/karajan/monitor: . items monitors/ansi monitors/ansi/tui processors/swift
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Mon Sep 16 02:06:34 CDT 2013
Author: hategan
Date: 2013-09-16 02:06:34 -0500 (Mon, 16 Sep 2013)
New Revision: 7069
Modified:
   trunk/src/org/griphyn/vdl/karajan/monitor/SystemState.java
   trunk/src/org/griphyn/vdl/karajan/monitor/items/ApplicationState.java
   trunk/src/org/griphyn/vdl/karajan/monitor/items/SummaryItem.java
   trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/SummaryPane.java
   trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/LevelBar.java
   trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/LevelBars.java
   trunk/src/org/griphyn/vdl/karajan/monitor/processors/swift/SummaryProcessor.java
Log:
show "completed in previous run" jobs as part of "Finished successfully" using a different color bar; show elapsed and estimated times in minute precision to reduce the wildly fluctuating numbers; properly take finished in previous run jobs into account (i.e. ignore them instead of expecting all jobs to finish in a second) when estimating time left
Modified: trunk/src/org/griphyn/vdl/karajan/monitor/SystemState.java
--- trunk/src/org/griphyn/vdl/karajan/monitor/SystemState.java	2013-09-16 07:03:25 UTC (rev 7068)
+++ trunk/src/org/griphyn/vdl/karajan/monitor/SystemState.java	2013-09-16 07:06:34 UTC (rev 7069)
@@ -34,10 +34,12 @@
 import org.griphyn.vdl.karajan.monitor.items.SummaryItem;
 public class SystemState {
+    public static final boolean SHOW_SECONDS = false;
 	private Map<StatefulItemClass, StatefulItemClassSet<? extends StatefulItem>> classes;
     private Set<SystemStateListener> listeners;
     private Map<String, Stats> stats;
-    private int total, completed;
+    private int total, completed, completedPreviously;
     private long start, currentTime;
     private Stack stack;
     private String projectName;
@@ -146,6 +148,14 @@
         return completed;
+    public int getCompletedPreviously() {
+        return completedPreviously;
+    public void setCompletedPreviously(int completedPreviously) {
+        this.completedPreviously = completedPreviously;
     public long getStart() {
         return start;
@@ -175,12 +185,16 @@
     public String getEstimatedTimeLeftFormatted() {
-        if (completed == 0) {
+        // don't use previously completed jobs to estimate remaining time
+        // since they "finish" pretty quickly
+        int c = completed - completedPreviously;
+        int t = total - completedPreviously;
+        if (c == 0) {
             return "N/A";
         else {
             long time = System.currentTimeMillis() - start;
-            long et = (time * total / completed) - time;
+            long et = (time * t / c) - time;
             return format(et);
@@ -221,12 +235,14 @@
             sb.append('0');
         sb.append(m);
-        sb.append(':');
-        int s = (int) (v % 60);
-        if (s < 10) {
-            sb.append('0');
+        if (SHOW_SECONDS) {
+            sb.append(':');
+            int s = (int) (v % 60);
+            if (s < 10) {
+                sb.append('0');
+            sb.append(s);
-        sb.append(s);
         return sb.toString();
Modified: trunk/src/org/griphyn/vdl/karajan/monitor/items/ApplicationState.java
--- trunk/src/org/griphyn/vdl/karajan/monitor/items/ApplicationState.java	2013-09-16 07:03:25 UTC (rev 7068)
+++ trunk/src/org/griphyn/vdl/karajan/monitor/items/ApplicationState.java	2013-09-16 07:06:34 UTC (rev 7069)
@@ -9,21 +9,30 @@
 package org.griphyn.vdl.karajan.monitor.items;
+import java.util.ArrayList;
+import java.util.List;
 public enum ApplicationState {
     INITIALIZING("Initializing"), SELECTING_SITE("Selecting site", "Sel. site"), STAGE_IN("Stage in"),
     SUBMITTING("Submitting"), SUBMITTED("Submitted"), ACTIVE("Active"), STAGE_OUT("Stage out"),
-    FAILED("Failed"), REPLICATING("Replicating"), FINISHED_SUCCESSFULLY("Finished successfully", "Finished");
+    FAILED("Failed"), REPLICATING("Replicating"), FINISHED_IN_PREVIOUS_RUN("Finished in previous run", "Finished in prev. run", false),
+    FINISHED_SUCCESSFULLY("Finished successfully");
     private String name, shortName;
+    private boolean enabled;
     private ApplicationState(String name) {
-        this.name = name;
-        this.shortName = name;
+        this(name, name);
     private ApplicationState(String name, String shortName) {
+        this(name, name, true);
+    private ApplicationState(String name, String shortName, boolean enabled) {
         this.name = name;
         this.shortName = shortName;
+        this.enabled = enabled;
     public String getName() {
@@ -37,8 +46,29 @@
     public void setShortName(String shortName) {
+    public boolean isEnabled() {
+        return enabled;
     public String toString() {
         return name;
+    private static ApplicationState[] enabledValues;
+    public synchronized static ApplicationState[] enabledValues() {
+        if (enabledValues == null) {
+            List<ApplicationState> l = new ArrayList<ApplicationState>();
+            for (ApplicationState s : values()) {
+                if (s.isEnabled()) {
+                    l.add(s);
+            enabledValues = new ApplicationState[l.size()];
+            l.toArray(enabledValues);
+        return enabledValues;
\ No newline at end of file
Modified: trunk/src/org/griphyn/vdl/karajan/monitor/items/SummaryItem.java
--- trunk/src/org/griphyn/vdl/karajan/monitor/items/SummaryItem.java	2013-09-16 07:03:25 UTC (rev 7068)
+++ trunk/src/org/griphyn/vdl/karajan/monitor/items/SummaryItem.java	2013-09-16 07:06:34 UTC (rev 7069)
@@ -27,7 +27,7 @@
 import org.griphyn.vdl.karajan.monitor.SystemState;
 public class SummaryItem extends AbstractStatefulItem {
-    public static final ApplicationState[] STATES = ApplicationState.values();
+    public static final ApplicationState[] STATES = ApplicationState.enabledValues();
     public static ApplicationState getStateByKey(String key) {
         for (ApplicationState s : STATES) {
Modified: trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/SummaryPane.java
--- trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/SummaryPane.java	2013-09-16 07:03:25 UTC (rev 7068)
+++ trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/SummaryPane.java	2013-09-16 07:06:34 UTC (rev 7069)
@@ -22,6 +22,7 @@
 import org.griphyn.vdl.karajan.monitor.common.GlobalTimer;
+import org.griphyn.vdl.karajan.monitor.items.ApplicationState;
 import org.griphyn.vdl.karajan.monitor.items.StatefulItemClass;
 import org.griphyn.vdl.karajan.monitor.monitors.ansi.tui.ANSI;
@@ -66,15 +67,30 @@
             if (summary != null) {
                 Map<String, Integer> counts = summary.getCounts(state);
                 for (int i = 0; i < SummaryItem.STATES.length; i++) {
-                    Integer v = counts.get(SummaryItem.STATES[i].getName());
-                    if (v != null) {
-                        bars.setValue(i, v);
-                        bars.setText(i, v.toString());
+                    if (SummaryItem.STATES[i].isEnabled()) {
+                        Integer v = counts.get(SummaryItem.STATES[i].getName());
+                        int iv = 0, prev = 0;
+                        if (v != null) {
+                            iv = v.intValue();
+                        if (SummaryItem.STATES[i] == ApplicationState.FINISHED_SUCCESSFULLY) {
+                            v = counts.get(ApplicationState.FINISHED_IN_PREVIOUS_RUN.getName());
+                            if (v != null) {
+                                prev = v.intValue();
+                        if (prev == 0) {
+                            bars.setValue(i, iv);
+                            bars.setText(i, String.valueOf(iv));
+                        else {
+                            bars.setValue(i, iv + prev);
+                            bars.setOtherValue(i, prev);
+                            bars.setText(i, String.valueOf(iv + prev) + " (" + String.valueOf(prev) + ")");
-                    else {
-                        bars.setValue(i, 0);
-                        bars.setText(i, "0");
             // mem
Modified: trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/LevelBar.java
--- trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/LevelBar.java	2013-09-16 07:03:25 UTC (rev 7068)
+++ trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/LevelBar.java	2013-09-16 07:06:34 UTC (rev 7069)
@@ -20,14 +20,15 @@
 import java.io.IOException;
 public class LevelBar extends Component {
-    private float value;
+    private float value, other;
     private String text;
-    private int textColor;
+    private int textColor, otherColor;
     public LevelBar() {
         bgColor = ANSI.BLACK;
         fgColor = ANSI.RED;
         textColor = ANSI.WHITE;
+        otherColor = ANSI.MAGENTA;
     public float getValue() {
@@ -37,6 +38,10 @@
     public void setValue(float value) {
         this.value = value;
+    public void setOtherValue(float ov) {
+        this.other = ov;
     protected void draw(ANSIContext context) throws IOException {
         if (text == null) {
@@ -49,13 +54,19 @@
     private void drawWithoutText(ANSIContext context) throws IOException {
         context.moveTo(sx, sy);
-        context.bgColor(fgColor);
-        int c = (int) (value * width);
-        context.spaces(c);
-        context.bgColor(bgColor);
-        context.spaces(width - c);
+        int crt;
+        crt = spaces(context, 0, other * width, otherColor);
+        crt = spaces(context, crt, (value - other) * width, fgColor);
+        crt = spaces(context, crt, width, bgColor);
+    private int spaces(ANSIContext context, int pos, float count, int color) throws IOException {
+        int c = (int) count;
+        context.bgColor(color);
+        context.spaces(Math.min(c, width - pos));
+        return pos + c;
     private void drawWithText(ANSIContext context) throws IOException {
         int textPos = (width - text.length()) / 2;
         StringBuilder sb = new StringBuilder();
@@ -65,14 +76,23 @@
         String s = sb.toString();
         context.fgColor(textColor);
-        context.text(s.substring(0, c));
-        context.text(s.substring(c));
+        int crt;
+        crt = text(context, s, 0, other * width, otherColor);
+        crt = text(context, s, crt, (value - other) * width, fgColor);
+        crt = text(context, s, crt, width, bgColor);
+    private int text(ANSIContext context, String str, int pos, float count, int color) throws IOException {
+        for (int i = 0; i < c && pos + i < str.length(); i++) {
+            context.putChar(str.charAt(pos + i));
+        return pos + c;
      private void spaces(StringBuilder sb, int count) {
         for(int i = 0; i < count; i++) {
             sb.append(' ');
Modified: trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/LevelBars.java
--- trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/LevelBars.java	2013-09-16 07:03:25 UTC (rev 7068)
+++ trunk/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/LevelBars.java	2013-09-16 07:06:34 UTC (rev 7069)
@@ -40,10 +40,24 @@
         for (int i = 0; i < values.length; i++) {
-            getBar(i).setValue((float) values[i] / range);
+            if (range > 0) {
+                getBar(i).setValue((float) values[i] / range);
+            else {
+                getBar(i).setValue(0);
+    public void setOtherValue(int i, int ov) {
+        if (range != 0) {
+            getBar(i).setOtherValue((float) ov / range);
+        else {
+            getBar(i).setOtherValue(0);
     public void setText(int index, String text) {
         getBar(index).setText(text);
@@ -60,6 +74,4 @@
         super.validate();
Modified: trunk/src/org/griphyn/vdl/karajan/monitor/processors/swift/SummaryProcessor.java
--- trunk/src/org/griphyn/vdl/karajan/monitor/processors/swift/SummaryProcessor.java	2013-09-16 07:03:25 UTC (rev 7068)
+++ trunk/src/org/griphyn/vdl/karajan/monitor/processors/swift/SummaryProcessor.java	2013-09-16 07:06:34 UTC (rev 7069)
@@ -50,7 +50,12 @@
 		        continue;
 		    String[] v = pair.split(":");
-		    s.setCount(v[0].trim(), Integer.parseInt(v[1]));
+		    String key = v[0].trim();
+		    int value = Integer.parseInt(v[1]);
+		    if (key.equals(ApplicationState.FINISHED_IN_PREVIOUS_RUN.getName())) {
+		        state.setCompletedPreviously(value);
+		    s.setCount(key, value);
 		state.itemUpdated(s);
