[Swift-commit] r7066 - trunk/src/org/griphyn/vdl/mapping
hategan at ci.uchicago.edu
Mon Sep 16 02:01:04 CDT 2013
Author: hategan
Date: 2013-09-16 02:01:03 -0500 (Mon, 16 Sep 2013)
New Revision: 7066
Modified:
trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java
trunk/src/org/griphyn/vdl/mapping/RootDataNode.java
Log:
use a single tracer for VARIABLE traces in swift data and move the "all partial closes have happened" to a trace
Modified: trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java 2013-09-13 01:48:14 UTC (rev 7065)
+++ trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java 2013-09-16 07:01:03 UTC (rev 7066)
@@ -37,6 +37,7 @@
import org.globus.cog.karajan.futures.FutureNotYetAvailable;
import org.griphyn.vdl.karajan.Loader;
import org.griphyn.vdl.karajan.WaitingThreadsMonitor;
+import org.griphyn.vdl.karajan.lib.Tracer;
import org.griphyn.vdl.type.Field;
import org.griphyn.vdl.type.Type;
import org.griphyn.vdl.util.VDL2Config;
@@ -88,6 +89,8 @@
private int writeRefCount;
private List<FutureListener> listeners;
+ protected static final Tracer variableTracer = Tracer.getTracer("VARIABLE");
protected AbstractDataNode(Field field) {
this.field = field;
@@ -789,9 +792,8 @@
logger.debug(this + " writeRefCount " + this.writeRefCount);
if (this.writeRefCount == 0) {
- if(logger.isInfoEnabled()) {
- logger.info("All partial closes for " + this +
- " have happened. Closing fully.");
+ if (variableTracer.isEnabled()) {
+ variableTracer.trace(getThread(), getDeclarationLine(), getDisplayableName() + " CLOSE write ref count is zero");
closeDeep();
Modified: trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java 2013-09-13 01:48:14 UTC (rev 7065)
+++ trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java 2013-09-16 07:01:03 UTC (rev 7066)
@@ -34,9 +34,7 @@
private Mapper mapper;
private MappingParamSet params;
private AbstractDataNode waitingMapperParam;
- private DuplicateMappingChecker dmc;
- private static final Tracer tracer = Tracer.getTracer("VARIABLE");
+ private DuplicateMappingChecker dmc;
* Instantiate a root array data node with specified type.
@@ -68,8 +66,8 @@
waitingMapperParam = params.getFirstOpenParamValue();
if (waitingMapperParam != null) {
waitingMapperParam.addListener(this);
- if (tracer.isEnabled()) {
- tracer.trace(getThread(), getDeclarationLine(), getDisplayableName() + " WAIT "
+ variableTracer.trace(getThread(), getDeclarationLine(), getDisplayableName() + " WAIT "
+ Tracer.getVarName(waitingMapperParam));
return;
@@ -163,8 +161,8 @@
private synchronized void initialized() {
initialized = true;
waitingMapperParam = null;
- tracer.trace(getThread(), getDeclarationLine(), getDisplayableName() + " INITIALIZED " + params);
+ variableTracer.trace(getThread(), getDeclarationLine(), getDisplayableName() + " INITIALIZED " + params);
Modified: trunk/src/org/griphyn/vdl/mapping/RootDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/RootDataNode.java 2013-09-13 01:48:14 UTC (rev 7065)
+++ trunk/src/org/griphyn/vdl/mapping/RootDataNode.java 2013-09-16 07:01:03 UTC (rev 7066)
@@ -39,8 +39,6 @@
public RootDataNode(Type type, DuplicateMappingChecker dmc) {
super(Field.Factory.createField(null, type));
this.dmc = dmc;
@@ -73,8 +71,8 @@
return;
@@ -149,8 +147,8 @@
// Try to get the path in order to check that the
// path is valid - we'll get an exception if not
DSHandle h = root.getField(p);
- tracer.trace(root.getThread(), root.getDeclarationLine(),
+ variableTracer.trace(root.getThread(), root.getDeclarationLine(),
root.getDisplayableName() + " MAPPING " + p + ", " + mapper.map(p));
@@ -174,8 +172,8 @@
try {
DSHandle field = root.getField(p);
field.setValue(FILE_VALUE);
any = true;
@@ -191,8 +189,8 @@
root.closeDeep();
- if (!any && tracer.isEnabled()) {
+ if (!any && variableTracer.isEnabled()) {
root.getDisplayableName() + " MAPPING no files found");
@@ -288,8 +286,8 @@
initialized = true;
More information about the Swift-commit
