[Swift-commit] cog r3781
swift at ci.uchicago.edu
Sun Sep 15 21:15:03 CDT 2013
r3781 | hategan | 2013-09-15 21:10:26 -0500 (Sun, 15 Sep 2013) | 1 line
extend proxy numbering scheme to 2 digits to accomodate a possible increase in the number of proxies due to non-sharing and delete proxies on exit if not shared
Index: modules/provider-coaster/src/org/globus/cog/abstraction/impl/execution/coaster/AutoCA.java
--- modules/provider-coaster/src/org/globus/cog/abstraction/impl/execution/coaster/AutoCA.java (revision 3780)
+++ modules/provider-coaster/src/org/globus/cog/abstraction/impl/execution/coaster/AutoCA.java (working copy)
@@ -24,7 +24,9 @@
import java.security.cert.X509Certificate;
import java.util.Date;
import java.util.HashMap;
+import java.util.HashSet;
import java.util.Map;
+import java.util.Set;
import org.apache.log4j.Logger;
import org.bouncycastle.asn1.ASN1InputStream;
@@ -84,6 +86,8 @@
public static final long CA_CERT_LIFETIME = 2 * WEEK_IN_MS;
public static final long MIN_CA_CERT_LIFETIME_LEFT = WEEK_IN_MS;
+ public static final int MAX_PROXY_INDEX = 99;
public static final int ID_BYTES = 4;
private static AutoCA instance;
@@ -208,13 +212,18 @@
private int getIndex(File c) {
String name = c.getName();
int i2 = name.lastIndexOf('.');
- return Integer.parseInt(name.substring(i2 - 1, i2));
+ int i1 = name.lastIndexOf('.', i2 - 1);
+ return Integer.parseInt(name.substring(i1 + 1, i2));
private int discoverNextIndex() throws GeneralSecurityException {
- for (int i = 0; i < 10; i++) {
- File f = makeFile(PROXY_NAME_PREFIX, i);
- if (!f.exists()) {
+ File[] existing = discoverProxies();
+ Set<Integer> usedIndices = new HashSet<Integer>();
+ for (File e : existing) {
+ usedIndices.add(getIndex(e));
+ for (int i = 0; i < MAX_PROXY_INDEX; i++) {
+ if (!usedIndices.contains(i)) {
return i;
@@ -262,7 +271,11 @@
private void copySigningPolicy(int index) throws IOException {
- FileOutputStream fos = new FileOutputStream(CA_DIR + File.separator + CA_CRT_NAME_PREFIX + "." + index + ".signing_policy");
+ File f = new File(CA_DIR + File.separator + CA_CRT_NAME_PREFIX + "." + index + ".signing_policy");
+ if (!SHARED_PROXIES) {
+ f.deleteOnExit();
+ FileOutputStream fos = new FileOutputStream(f);
try {
InputStream is = AutoCA.class.getClassLoader().getResource(SIGNING_POLICY_RES_NAME).openStream();
try {
@@ -324,6 +337,9 @@
private void writeProxy(GlobusCredential proxy, File f) throws GeneralSecurityException {
try {
OutputStream fw = openStream(f);
+ f.deleteOnExit();
try {
proxy.save(fw);
@@ -349,6 +365,9 @@
private void writeCert(X509Certificate cert, File f) throws GeneralSecurityException {
try {
+ f.deleteOnExit();
CertUtil.writeCertificate(fw, cert);
catch (Exception e) {
@@ -387,6 +406,9 @@
private void writeKey(OpenSSLKey key, File f) throws GeneralSecurityException {
try {
OutputStream keyStream = openStream(f);
+ f.deleteOnExit();
try {
key.writeTo(keyStream);
More information about the Swift-commit
