[Swift-commit] r7061 - SwiftApps/tryswift
davidk at ci.uchicago.edu
Thu Sep 12 13:58:30 CDT 2013
Author: davidk
Date: 2013-09-12 13:58:30 -0500 (Thu, 12 Sep 2013)
New Revision: 7061
Modified:
SwiftApps/tryswift/tryswift.php
Log:
Recursive find and sort of swift output files
Disaply size of output files
Modified: SwiftApps/tryswift/tryswift.php
--- SwiftApps/tryswift/tryswift.php 2013-09-12 17:21:20 UTC (rev 7060)
+++ SwiftApps/tryswift/tryswift.php 2013-09-12 18:58:30 UTC (rev 7061)
@@ -9,13 +9,13 @@
function copy_file($src, $dst) {
if(!copy($src, $dst)) {
die("Failed to copy $src to $dst\n");
$source = $_POST['source'];
$web_directory = "/home/tryswift/tryswift";
$url = "http://54.212.60.65:8080";
-$cmd = "PATH=/usr/bin:/bin:$PATH /home/tryswift/swift-0.94.1-RC2/bin/swift -sites.file sites.xml -tc.file tc.data script.swift";
+$cmd = "PATH=/usr/bin:/bin:\$PATH /home/tryswift/swift-0.94.1-RC2/bin/swift -sites.file sites.xml -tc.file tc.data script.swift";
# Create directory structure
$unique = uniqid();
@@ -38,7 +38,7 @@
$descriptorspec = array(
0 => array("pipe", "r"), // stdin is a pipe that the child will read from
1 => array("pipe", "w"), // stdout is a pipe that the child will write to
- 2 => array("file", "$dirname/err.txt", "a") // stderr is a pipe that the child will write to
+ 2 => array("pipe", "w") // stderr is a pipe that the child will write to
echo "<pre>";
@@ -49,7 +49,7 @@
foreach(explode("\n", $_POST['source']) as $line) {
print "<tr style=\"background-color:#f6f6f6;\">" .
"<td style=\"text-align: center; width: 25px\">" . ++$count . "</td>" .
- "<td style=\"text-align: left; border-left: 1px solid black; padding-left: 10px;\">$line </td></tr>\n";
+ "<td style=\"text-align: left; border-left: 1px solid black; padding-left: 10px;\">" . htmlentities($line) . "</td></tr>\n";
print "</table>\n";
print "<table cellspacing=\"0\" title=\"Swift Results\">\n";
@@ -72,26 +72,32 @@
$filehtml = "";
$print_files=0;
-if ($handle = opendir("$web_directory/$unique")) {
- while (false !== ($entry = readdir($handle))) {
- if ( $entry != "." &&
- $entry != ".." &&
- $entry != "err.txt" &&
- $entry != "tc.data" &&
- $entry != "sites.xml" &&
- $entry != "script.swift" &&
- substr($entry, -2) != ".d" &&
- substr($entry, -4) != ".kml" &&
- substr($entry, -7) != ".swiftx" &&
- substr($entry, -4) != ".log"
- if($print_files == 0) { $print_files=1; }
- $filehtml .= "<tr style=\"background-color:#f6f6f6;\">" .
+# Sorted, recursive list of all files
+$iterator = new RecursiveIteratorIterator(new RecursiveDirectoryIterator("$web_directory/$unique"));
+$paths = array();
+while($iterator->valid()) {
+ if($iterator->isFile()) {
+ $paths[] = $iterator->getSubPathname();
+ $iterator->next();
+sort($paths);
+foreach ($paths as $file) {
+ if( $file != "err.txt" &&
+ $file != "tc.data" &&
+ $file != "sites.xml" &&
+ $file != "script.swift" &&
+ substr($file, -2) != ".d" &&
+ substr($file, -4) != ".kml" &&
+ substr($file, -7) != ".swiftx" &&
+ substr($file, -4) != ".log"
+ if($print_files == 0) { $print_files=1; }
+ $filehtml .= "<tr style=\"background-color:#f6f6f6;\">" .
"<td style=\"text-align: left; border-left: 0px solid black; padding-left: 10px;\">" .
- "<a href=\"$url/$unique/$entry\">$entry</a> </td></tr>\n";
- closedir($handle);
+ "<a href=\"$url/$unique/$file\">$file</a> [" . filesize($file) . " bytes]</td></tr>\n";
if($print_files) {
More information about the Swift-commit
