[Swift-commit] r7056 - branches/release-0.94/docs/siteguide
davidk at ci.uchicago.edu
Wed Sep 11 13:51:41 CDT 2013
Author: davidk
Date: 2013-09-11 13:51:41 -0500 (Wed, 11 Sep 2013)
New Revision: 7056
Added:
branches/release-0.94/docs/siteguide/ssh-cl
Modified:
branches/release-0.94/docs/siteguide/siteguide.txt
Log:
Start of ssh-cl site entry
Modified: branches/release-0.94/docs/siteguide/siteguide.txt
--- branches/release-0.94/docs/siteguide/siteguide.txt 2013-09-11 18:25:03 UTC (rev 7055)
+++ branches/release-0.94/docs/siteguide/siteguide.txt 2013-09-11 18:51:41 UTC (rev 7056)
@@ -28,6 +28,8 @@
include::ssh[]
+include::ssh-cl[]
include::stampede[]
include::uc3[]
Added: branches/release-0.94/docs/siteguide/ssh-cl
--- branches/release-0.94/docs/siteguide/ssh-cl (rev 0)
+++ branches/release-0.94/docs/siteguide/ssh-cl 2013-09-11 18:51:41 UTC (rev 7056)
@@ -0,0 +1,68 @@
+SSH-CL
+This section describes how to use the SSH command line provider (ssh-cl) to
+connect to remote sites.
+Verify you can connect to the remote site
+The first step of this process is to verify that you can connect to a remote
+site without being prompted for a password or passphrase.
+$ ssh my.site.com
+Typically to make this work you will need to add your SSH public key to the
+$HOME/.ssh/authorized_keys file on the remote system.
+This SSH connection must work without specifying a username on the command line.
+If your username differs on your local machine and the remote machine, you will
+need to add an entry like this to your local $HOME/.ssh/config:
+Host my.site.com
+ Hostname my.site.com
+ User myusername
+Create a sites.xml file
+Once you have verified that you can connect without prompt to the remote machine,
+you will need to create a sites.xml file that contains the host information. The
+example below will assume there is no scheduler on the remote system - it simply
+connects to the remote machine and runs work there.
+<config>
+ <pool handle="mysite">
+ <execution provider="coaster" jobmanager="ssh-cl:local" url="my.site.com"/>
+ <profile namespace="globus" key="jobsPerNode">1</profile>
+ <profile namespace="globus" key="lowOverAllocation">100</profile>
+ <profile namespace="globus" key="highOverAllocation">100</profile>
+ <profile namespace="karajan" key="jobThrottle">1</profile>
+ <profile namespace="karajan" key="initialScore">10000</profile>
+ <workdirectory>/home/username/work</workdirectory>
+ </pool>
+</config>
+NOTE: This requires that the remote site can connect back to the machine where
+you are running Swift. If a firewall is configured to block incoming connections,
+this will not work correctly.
+Enabling coaster provider staging
+If there is a shared filesystem between the two machines, you can set this as your
+work directory and skip this step. Otherwise, you will need to enable coaster provider
+staging.
+To do this, add the following line to your "cf" file:
+use.provider.staging=true
+To run swift, then:
+swift -sites.file sites.xml -tc.file tc.data -config cf script.swift
More information about the Swift-commit
