[Swift-commit] r7050 - branches/release-0.94/tests
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Tue Sep 10 10:35:44 CDT 2013
Author: davidk
Date: 2013-09-10 10:35:44 -0500 (Tue, 10 Sep 2013)
New Revision: 7050
Modified:
   branches/release-0.94/tests/suite.sh
Log:
Various fixes to the test suite script
The current suite.sh does not kill all processes correctly. When a swift script exceeds its time limit, the parent bash script gets a kill signal, but the children processes do not, which leaves many swift/java instances running after the suite is over. This should be fixed now.
Previously suite.sh would attempt to determine the IP address of the local machine via ifconfig and set GLOBUS_HOSTNAME. It's not easy to determine which IP address is the correct one to use. On macs it fails completely and sets it to "inet". It's probably better to let the user define it, either globally via .bashrc, or within the user environment script (-z user_env.sh).
Replace readlink command for determining directory structures - it failed on macs and caused the suite to not run. The test suite should be runnable on macs now.
The repeat file was not being read correctly. This should be working now for repeating tests.
Modified: branches/release-0.94/tests/suite.sh
--- branches/release-0.94/tests/suite.sh	2013-09-10 15:19:56 UTC (rev 7049)
+++ branches/release-0.94/tests/suite.sh	2013-09-10 15:35:44 UTC (rev 7050)
@@ -39,8 +39,8 @@
 INDIVIDUAL_TEST_TIME=0
 COLORIZE=0
 # The directory in which to start:
-TOPDIR=`readlink -f $PWD/../../../..`
-CRTDIR=`pwd`
+TOPDIR=$( cd ../../../.. && echo $PWD )
+CRTDIR=$PWD
 # Disable usage stats in test suite
 export SWIFT_USAGE_STATS=0
@@ -544,8 +544,15 @@
 process_trap() {
   PROCESS_INTERNAL_PID=$1
   echo "process_trap: killing: $PROCESS_INTERNAL_PID"
-  # ps -H
-  kill -TERM $PROCESS_INTERNAL_PID
+  ps -o "pid,ppid"|sed 1d | while read PROC
+  do
+     PROC_PID=$( echo $PROC | awk '{print $1}' )
+     PROC_PPID=$( echo $PROC | awk '{print $2}' )
+     if [ $PROC_PPID == $PROCESS_INTERNAL_PID ]
+     then
+        kill $PROC_PID
+     fi
+  done
 # Execute process in the background
@@ -633,7 +640,7 @@
   wait
   [ $? != 0 ] && verbose "monitor($V) cancelled" && return 0
-  if ps | grep $PID
+  if ps | grep $PID > /dev/null 2>&1
   then
     echo "monitor: killing test process $PID"
     touch killed_test
@@ -679,8 +686,11 @@
   # If the test was killed, monitor() may have work to do
   rm killed_test > /dev/null 2>&1 && sleep 5
-  verbose "killing monitor: $MONITOR_PID..."
-  kill $MONITOR_PID
+  if ps -p $MONITOR_PID > /dev/null 2>&1
+  then
+     verbose "killing monitor: $MONITOR_PID..."
+     kill $MONITOR_PID
+  fi
   INDIVIDUAL_TEST_TIME=$(( STOP-START ))
   TOTAL_TIME=$(( INDIVIDUAL_TEST_TIME+TOTAL_TIME ))
@@ -807,7 +817,6 @@
     cp "$GROUP/$SOURCESCRIPT" .
     source ./$SOURCESCRIPT
   fi
-  echo "GLOBUS_HOSTNAME : $GLOBUS_HOSTNAME"
   if [ -x "$GROUP/$SETUPSCRIPT" ]; then
     cp "$GROUP/$SETUPSCRIPT" .
@@ -972,17 +981,6 @@
   output_report package "swift-$DATE.tar.gz"
-# Setup coasters variables
-if which ifconfig > /dev/null 2>&1; then
-  IFCONFIG=ifconfig
-else
-  IFCONFIG=/sbin/ifconfig
-fi
-$IFCONFIG > /dev/null 2>&1 || crash "Cannot run ifconfig!"
-export GLOBUS_HOSTNAME=$( $IFCONFIG 2>/dev/null | grep inet | head -1 | cut -d ':' -f 2 | \
-                   awk '{print $1}' )
-[ $? != 0 ] && crash "Could not obtain GLOBUS_HOSTNAME!"
 # Generate sites.xml
 group_sites_xml() {
@@ -1105,12 +1103,12 @@
   for TEST in $SWIFTS; do
     (( SKIP_COUNTER++ < SKIP_TESTS )) && continue
-   # Use repeat.txt to determine number of test iterations
-    SCRIPT_BASENAME=`basename $TESTNAME .swift`
+   # Use scriptname.repeat to determine number of test iterations
+    SCRIPT_BASENAME=`basename $TEST .swift`
     TESTLINK="$TESTNAMEDIR/$TESTNAME"
+    GROUP_DIRNAME=$( dirname $GROUP )
     if [ -f "$GROUP/$SCRIPT_BASENAME.repeat" ]; then
-      ITERS_LOCAL=`cat $GROUP/$SCRIPT_BASENAME.repeat`
+       ITERS_LOCAL=$( cat $GROUP/$SCRIPT_BASENAME.repeat )
     else
        ITERS_LOCAL=1
     fi
