[Swift-commit] cog r3769
swift at ci.uchicago.edu
Mon Sep 2 03:30:05 CDT 2013
r3769 | hategan | 2013-09-02 03:27:46 -0500 (Mon, 02 Sep 2013) | 1 line
only use auto CA if no standard proxy is present (expired or not)
Index: modules/provider-coaster/src/org/globus/cog/abstraction/impl/execution/coaster/ServiceManager.java
--- modules/provider-coaster/src/org/globus/cog/abstraction/impl/execution/coaster/ServiceManager.java (revision 3768)
+++ modules/provider-coaster/src/org/globus/cog/abstraction/impl/execution/coaster/ServiceManager.java (working copy)
@@ -54,6 +54,7 @@
import org.globus.cog.karajan.workflow.service.channels.KarajanChannel;
import org.globus.cog.karajan.workflow.service.commands.Command;
import org.globus.cog.karajan.workflow.service.commands.Command.Callback;
+import org.globus.common.CoGProperties;
import org.ietf.jgss.GSSCredential;
public class ServiceManager implements StatusListener {
@@ -222,11 +223,27 @@
private void setupGSIProxy() throws IOException, GeneralSecurityException {
- AutoCA.Info result = AutoCA.getInstance().createProxy();
- System.setProperty("X509_USER_PROXY", result.proxyPath);
- System.setProperty("X509_CERT_DIR", result.caCertPath);
+ if (!checkStandardProxy()) {
+ * only do the automatic CA if a standard proxy file does not exist
+ * to allow using things like GridFTP from the coaster service through
+ * delegation (which won't work with the auto-generated proxy).
+ logger.info("No standard proxy found. Using AutoCA.");
+ AutoCA.Info result = AutoCA.getInstance().createProxy();
+ System.setProperty("X509_USER_PROXY", result.proxyPath);
+ System.setProperty("X509_CERT_DIR", result.caCertPath);
+ else {
+ logger.info("Standard proxy file found. Disabling AutoCA.");
+ private boolean checkStandardProxy() {
+ File proxy = new File(CoGProperties.getDefault().getProxyFile());
+ return proxy.exists();
private void setSecurityContext(Task t, SecurityContext sc, String provider)
throws InvalidProviderException, ProviderMethodException {
t.getService(0).setSecurityContext(AbstractionFactory.getSecurityContext(provider, t.getService(0).getServiceContact()));
More information about the Swift-commit
