[Swift-commit] cog r3827
swift at ci.uchicago.edu
Wed Oct 30 09:35:03 CDT 2013
r3827 | jmwozniak | 2013-10-30 09:30:38 -0500 (Wed, 30 Oct 2013) | 2 lines
Drop auto-generated files
Index: modules/provider-coaster-c-client/configure
--- modules/provider-coaster-c-client/configure (revision 3826)
+++ modules/provider-coaster-c-client/configure (working copy)
@@ -1,19284 +0,0 @@
-#! /bin/sh
-# Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.68 for coaster-c-client 1.0.
-# Copyright (C) 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001,
-# 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010 Free Software
-# Foundation, Inc.
-# This configure script is free software; the Free Software Foundation
-# gives unlimited permission to copy, distribute and modify it.
-## M4sh Initialization. ##
-# Be more Bourne compatible
-DUALCASE=1; export DUALCASE # for MKS sh
-if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then :
- emulate sh
- NULLCMD=:
- # Pre-4.2 versions of Zsh do word splitting on ${1+"$@"}, which
- # is contrary to our usage. Disable this feature.
- alias -g '${1+"$@"}'='"$@"'
- setopt NO_GLOB_SUBST
-else
- case `(set -o) 2>/dev/null` in #(
- *posix*) :
- set -o posix ;; #(
-esac
-fi
-as_nl='
-export as_nl
-# Printing a long string crashes Solaris 7 /usr/bin/printf.
-as_echo='\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'
-as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo
-as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo$as_echo
-# Prefer a ksh shell builtin over an external printf program on Solaris,
-# but without wasting forks for bash or zsh.
-if test -z "$BASH_VERSION$ZSH_VERSION" \
- && (test "X`print -r -- $as_echo`" = "X$as_echo") 2>/dev/null; then
- as_echo='print -r --'
- as_echo_n='print -rn --'
-elif (test "X`printf %s $as_echo`" = "X$as_echo") 2>/dev/null; then
- as_echo='printf %s\n'
- as_echo_n='printf %s'
-else
- if test "X`(/usr/ucb/echo -n -n $as_echo) 2>/dev/null`" = "X-n $as_echo"; then
- as_echo_body='eval /usr/ucb/echo -n "$1$as_nl"'
- as_echo_n='/usr/ucb/echo -n'
- else
- as_echo_body='eval expr "X$1" : "X\\(.*\\)"'
- as_echo_n_body='eval
- arg=$1;
- case $arg in #(
- *"$as_nl"*)
- expr "X$arg" : "X\\(.*\\)$as_nl";
- arg=`expr "X$arg" : ".*$as_nl\\(.*\\)"`;;
- esac;
- expr "X$arg" : "X\\(.*\\)" | tr -d "$as_nl"
- export as_echo_n_body
- as_echo_n='sh -c $as_echo_n_body as_echo'
- fi
- export as_echo_body
- as_echo='sh -c $as_echo_body as_echo'
-fi
-# The user is always right.
-if test "${PATH_SEPARATOR+set}" != set; then
- PATH_SEPARATOR=:
- (PATH='/bin;/bin'; FPATH=$PATH; sh -c :) >/dev/null 2>&1 && {
- (PATH='/bin:/bin'; FPATH=$PATH; sh -c :) >/dev/null 2>&1 ||
- PATH_SEPARATOR=';'
-fi
-# IFS
-# We need space, tab and new line, in precisely that order. Quoting is
-# there to prevent editors from complaining about space-tab.
-# (If _AS_PATH_WALK were called with IFS unset, it would disable word
-# splitting by setting IFS to empty value.)
-IFS=" "" $as_nl"
-# Find who we are. Look in the path if we contain no directory separator.
-as_myself=
-case $0 in #((
- *[\\/]* ) as_myself=$0 ;;
- *) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-for as_dir in $PATH
-do
- IFS=$as_save_IFS
- test -z "$as_dir" && as_dir=.
- test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
- done
-IFS=$as_save_IFS
-esac
-# We did not find ourselves, most probably we were run as `sh COMMAND'
-# in which case we are not to be found in the path.
-if test "x$as_myself" = x; then
- as_myself=$0
-fi
-if test ! -f "$as_myself"; then
- $as_echo "$as_myself: error: cannot find myself; rerun with an absolute file name" >&2
- exit 1
-fi
-# Unset variables that we do not need and which cause bugs (e.g. in
-# pre-3.0 UWIN ksh). But do not cause bugs in bash 2.01; the "|| exit 1"
-# suppresses any "Segmentation fault" message there. '((' could
-# trigger a bug in pdksh 5.2.14.
-for as_var in BASH_ENV ENV MAIL MAILPATH
-do eval test x\${$as_var+set} = xset \
- && ( (unset $as_var) || exit 1) >/dev/null 2>&1 && unset $as_var || :
-done
-PS1='$ '
-PS2='> '
-PS4='+ '
-# NLS nuisances.
-LC_ALL=C
-export LC_ALL
-LANGUAGE=C
-export LANGUAGE
-# CDPATH.
-(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
-if test "x$CONFIG_SHELL" = x; then
- as_bourne_compatible="if test -n \"\${ZSH_VERSION+set}\" && (emulate sh) >/dev/null 2>&1; then :
- emulate sh
- NULLCMD=:
- # Pre-4.2 versions of Zsh do word splitting on \${1+\"\$@\"}, which
- alias -g '\${1+\"\$@\"}'='\"\$@\"'
-else
- case \`(set -o) 2>/dev/null\` in #(
- *posix*) :
-esac
-fi
- as_required="as_fn_return () { (exit \$1); }
-as_fn_success () { as_fn_return 0; }
-as_fn_failure () { as_fn_return 1; }
-as_fn_ret_success () { return 0; }
-as_fn_ret_failure () { return 1; }
-exitcode=0
-as_fn_success || { exitcode=1; echo as_fn_success failed.; }
-as_fn_failure && { exitcode=1; echo as_fn_failure succeeded.; }
-as_fn_ret_success || { exitcode=1; echo as_fn_ret_success failed.; }
-as_fn_ret_failure && { exitcode=1; echo as_fn_ret_failure succeeded.; }
-if ( set x; as_fn_ret_success y && test x = \"\$1\" ); then :
-else
- exitcode=1; echo positional parameters were not saved.
-fi
-test x\$exitcode = x0 || exit 1"
- as_suggested=" as_lineno_1=";as_suggested=$as_suggested$LINENO;as_suggested=$as_suggested" as_lineno_1a=\$LINENO
- as_lineno_2=";as_suggested=$as_suggested$LINENO;as_suggested=$as_suggested" as_lineno_2a=\$LINENO
- eval 'test \"x\$as_lineno_1'\$as_run'\" != \"x\$as_lineno_2'\$as_run'\" &&
- test \"x\`expr \$as_lineno_1'\$as_run' + 1\`\" = \"x\$as_lineno_2'\$as_run'\"' || exit 1
- test -n \"\${ZSH_VERSION+set}\${BASH_VERSION+set}\" || (
- ECHO='\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'
- ECHO=\$ECHO\$ECHO\$ECHO\$ECHO\$ECHO
- ECHO=\$ECHO\$ECHO\$ECHO\$ECHO\$ECHO\$ECHO
- PATH=/empty FPATH=/empty; export PATH FPATH
- test \"X\`printf %s \$ECHO\`\" = \"X\$ECHO\" \\
- || test \"X\`print -r -- \$ECHO\`\" = \"X\$ECHO\" ) || exit 1
-test \$(( 1 + 1 )) = 2 || exit 1"
- if (eval "$as_required") 2>/dev/null; then :
- as_have_required=yes
-else
- as_have_required=no
-fi
- if test x$as_have_required = xyes && (eval "$as_suggested") 2>/dev/null; then :
-else
- as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-as_found=false
-for as_dir in /bin$PATH_SEPARATOR/usr/bin$PATH_SEPARATOR$PATH
-do
- IFS=$as_save_IFS
- as_found=:
- case $as_dir in #(
- for as_base in sh bash ksh sh5; do
- # Try only shells that exist, to save several forks.
- as_shell=$as_dir/$as_base
- if { test -f "$as_shell" || test -f "$as_shell.exe"; } &&
- { $as_echo "$as_bourne_compatible""$as_required" | as_run=a "$as_shell"; } 2>/dev/null; then :
- CONFIG_SHELL=$as_shell as_have_required=yes
- if { $as_echo "$as_bourne_compatible""$as_suggested" | as_run=a "$as_shell"; } 2>/dev/null; then :
- break 2
-fi
-fi
- done;;
- esac
- as_found=false
-done
-$as_found || { if { test -f "$SHELL" || test -f "$SHELL.exe"; } &&
- { $as_echo "$as_bourne_compatible""$as_required" | as_run=a "$SHELL"; } 2>/dev/null; then :
- CONFIG_SHELL=$SHELL as_have_required=yes
-fi; }
-IFS=$as_save_IFS
- if test "x$CONFIG_SHELL" != x; then :
- # We cannot yet assume a decent shell, so we have to provide a
- # neutralization value for shells without unset; and this also
- # works around shells that cannot unset nonexistent variables.
- # Preserve -v and -x to the replacement shell.
- BASH_ENV=/dev/null
- ENV=/dev/null
- (unset BASH_ENV) >/dev/null 2>&1 && unset BASH_ENV ENV
- export CONFIG_SHELL
- case $- in # ((((
- *v*x* | *x*v* ) as_opts=-vx ;;
- *v* ) as_opts=-v ;;
- *x* ) as_opts=-x ;;
- * ) as_opts= ;;
- esac
- exec "$CONFIG_SHELL" $as_opts "$as_myself" ${1+"$@"}
-fi
- if test x$as_have_required = xno; then :
- $as_echo "$0: This script requires a shell more modern than all"
- $as_echo "$0: the shells that I found on your system."
- if test x${ZSH_VERSION+set} = xset ; then
- $as_echo "$0: In particular, zsh $ZSH_VERSION has bugs and should"
- $as_echo "$0: be upgraded to zsh 4.3.4 or later."
- else
- $as_echo "$0: Please tell bug-autoconf at gnu.org about your system,
-$0: including any error possibly output before this
-$0: message. Then install a modern shell, or manually run
-$0: the script under such a shell if you do have one."
- fi
- exit 1
-fi
-fi
-fi
-SHELL=${CONFIG_SHELL-/bin/sh}
-export SHELL
-# Unset more variables known to interfere with behavior of common tools.
-CLICOLOR_FORCE= GREP_OPTIONS=
-unset CLICOLOR_FORCE GREP_OPTIONS
-## M4sh Shell Functions. ##
-# as_fn_unset VAR
-# Portably unset VAR.
-as_fn_unset ()
- { eval $1=; unset $1;}
-as_unset=as_fn_unset
-# as_fn_set_status STATUS
-# Set $? to STATUS, without forking.
-as_fn_set_status ()
- return $1
-} # as_fn_set_status
-# as_fn_exit STATUS
-# Exit the shell with STATUS, even in a "trap 0" or "set -e" context.
-as_fn_exit ()
- set +e
- as_fn_set_status $1
- exit $1
-} # as_fn_exit
-# as_fn_mkdir_p
-# Create "$as_dir" as a directory, including parents if necessary.
-as_fn_mkdir_p ()
- -*) as_dir=./$as_dir;;
- esac
- test -d "$as_dir" || eval $as_mkdir_p || {
- as_dirs=
- while :; do
- *\'*) as_qdir=`$as_echo "$as_dir" | sed "s/'/'\\\\\\\\''/g"`;; #'(
- *) as_qdir=$as_dir;;
- esac
- as_dirs="'$as_qdir' $as_dirs"
- as_dir=`$as_dirname -- "$as_dir" ||
-$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$as_dir" : 'X\(//\)[^/]' \| \
- X"$as_dir" : 'X\(//\)$' \| \
- X"$as_dir" : 'X\(/\)' \| . 2>/dev/null ||
-$as_echo X"$as_dir" |
- sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
- s//\1/
- q
- /^X\(\/\/\)[^/].*/{
- s//\1/
- q
- /^X\(\/\/\)$/{
- s//\1/
- q
- /^X\(\/\).*/{
- s//\1/
- q
- s/.*/./; q'`
- test -d "$as_dir" && break
- done
- test -z "$as_dirs" || eval "mkdir $as_dirs"
- } || test -d "$as_dir" || as_fn_error $? "cannot create directory $as_dir"
-} # as_fn_mkdir_p
-# as_fn_append VAR VALUE
-# Append the text in VALUE to the end of the definition contained in VAR. Take
-# advantage of any shell optimizations that allow amortized linear growth over
-# repeated appends, instead of the typical quadratic growth present in naive
-# implementations.
-if (eval "as_var=1; as_var+=2; test x\$as_var = x12") 2>/dev/null; then :
- eval 'as_fn_append ()
- eval $1+=\$2
-else
- as_fn_append ()
- eval $1=\$$1\$2
-fi # as_fn_append
-# as_fn_arith ARG...
-# Perform arithmetic evaluation on the ARGs, and store the result in the
-# global $as_val. Take advantage of shells that can avoid forks. The arguments
-# must be portable across $(()) and expr.
-if (eval "test \$(( 1 + 1 )) = 2") 2>/dev/null; then :
- eval 'as_fn_arith ()
- as_val=$(( $* ))
-else
- as_fn_arith ()
- as_val=`expr "$@" || test $? -eq 1`
-fi # as_fn_arith
-# as_fn_error STATUS ERROR [LINENO LOG_FD]
-# Output "`basename $0`: error: ERROR" to stderr. If LINENO and LOG_FD are
-# provided, also output the error to LOG_FD, referencing LINENO. Then exit the
-# script with STATUS, using 1 if that was 0.
-as_fn_error ()
- as_status=$1; test $as_status -eq 0 && as_status=1
- if test "$4"; then
- as_lineno=${as_lineno-"$3"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
- $as_echo "$as_me:${as_lineno-$LINENO}: error: $2" >&$4
- fi
- $as_echo "$as_me: error: $2" >&2
- as_fn_exit $as_status
-} # as_fn_error
-if expr a : '\(a\)' >/dev/null 2>&1 &&
- test "X`expr 00001 : '.*\(...\)'`" = X001; then
- as_expr=expr
-else
- as_expr=false
-fi
-if (basename -- /) >/dev/null 2>&1 && test "X`basename -- / 2>&1`" = "X/"; then
- as_basename=basename
-else
- as_basename=false
-fi
-if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
- as_dirname=dirname
-else
- as_dirname=false
-fi
-as_me=`$as_basename -- "$0" ||
-$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
- X"$0" : 'X\(//\)$' \| \
- X"$0" : 'X\(/\)' \| . 2>/dev/null ||
-$as_echo X/"$0" |
- sed '/^.*\/\([^/][^/]*\)\/*$/{
- s//\1/
- q
- /^X\/\(\/\/\)$/{
- s//\1/
- q
- /^X\/\(\/\).*/{
- s//\1/
- q
- s/.*/./; q'`
-# Avoid depending upon Character Ranges.
-as_cr_letters='abcdefghijklmnopqrstuvwxyz'
-as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
-as_cr_Letters=$as_cr_letters$as_cr_LETTERS
-as_cr_digits='0123456789'
-as_cr_alnum=$as_cr_Letters$as_cr_digits
- as_lineno_1=$LINENO as_lineno_1a=$LINENO
- as_lineno_2=$LINENO as_lineno_2a=$LINENO
- eval 'test "x$as_lineno_1'$as_run'" != "x$as_lineno_2'$as_run'" &&
- test "x`expr $as_lineno_1'$as_run' + 1`" = "x$as_lineno_2'$as_run'"' || {
- # Blame Lee E. McMahon (1931-1989) for sed's syntax. :-)
- sed -n '
- p
- /[$]LINENO/=
- ' <$as_myself |
- sed '
- s/[$]LINENO.*/&-/
- t lineno
- b
- :lineno
- N
- :loop
- s/[$]LINENO\([^'$as_cr_alnum'_].*\n\)\(.*\)/\2\1\2/
- t loop
- s/-\n.*//
- ' >$as_me.lineno &&
- chmod +x "$as_me.lineno" ||
- { $as_echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2; as_fn_exit 1; }
- # Don't try to exec as it changes $[0], causing all sort of problems
- # (the dirname of $[0] is not the place where we might find the
- # original and so on. Autoconf is especially sensitive to this).
- . "./$as_me.lineno"
- # Exit status is that of the last command.
- exit
-ECHO_C= ECHO_N= ECHO_T=
-case `echo -n x` in #(((((
--n*)
- case `echo 'xy\c'` in
- *c*) ECHO_T=' ';; # ECHO_T is single tab character.
- xy) ECHO_C='\c';;
- *) echo `echo ksh88 bug on AIX 6.1` > /dev/null
- ECHO_T=' ';;
- esac;;
- ECHO_N='-n';;
-esac
-rm -f conf$$ conf$$.exe conf$$.file
-if test -d conf$$.dir; then
- rm -f conf$$.dir/conf$$.file
-else
- rm -f conf$$.dir
- mkdir conf$$.dir 2>/dev/null
-fi
-if (echo >conf$$.file) 2>/dev/null; then
- if ln -s conf$$.file conf$$ 2>/dev/null; then
- as_ln_s='ln -s'
- # ... but there are two gotchas:
- # 1) On MSYS, both `ln -s file dir' and `ln file dir' fail.
- # 2) DJGPP < 2.04 has no symlinks; `ln -s' creates a wrapper executable.
- # In both cases, we have to default to `cp -p'.
- ln -s conf$$.file conf$$.dir 2>/dev/null && test ! -f conf$$.exe ||
- as_ln_s='cp -p'
- elif ln conf$$.file conf$$ 2>/dev/null; then
- as_ln_s=ln
- else
- as_ln_s='cp -p'
- fi
-else
- as_ln_s='cp -p'
-fi
-rm -f conf$$ conf$$.exe conf$$.dir/conf$$.file conf$$.file
-rmdir conf$$.dir 2>/dev/null
-if mkdir -p . 2>/dev/null; then
- as_mkdir_p='mkdir -p "$as_dir"'
-else
- test -d ./-p && rmdir ./-p
- as_mkdir_p=false
-fi
-if test -x / >/dev/null 2>&1; then
- as_test_x='test -x'
-else
- if ls -dL / >/dev/null 2>&1; then
- as_ls_L_option=L
- else
- as_ls_L_option=
- fi
- as_test_x='
- eval sh -c '\''
- if test -d "$1"; then
- test -d "$1/.";
- else
- case $1 in #(
- -*)set "./$1";;
- esac;
- case `ls -ld'$as_ls_L_option' "$1" 2>/dev/null` in #((
- ???[sx]*):;;*)false;;esac;fi
- '\'' sh
-fi
-as_executable_p=$as_test_x
-# Sed expression to map a string onto a valid CPP name.
-as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
-# Sed expression to map a string onto a valid variable name.
-as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
-test -n "$DJDIR" || exec 7<&0 </dev/null
-exec 6>&1
-# Name of the host.
-# hostname on some systems (SVR3.2, old GNU/Linux) returns a bogus exit status,
-# so uname gets run too.
-ac_hostname=`(hostname || uname -n) 2>/dev/null | sed 1q`
-# Initializations.
-ac_default_prefix=/usr/local
-ac_clean_files=
-ac_config_libobj_dir=.
-LIBOBJS=
-cross_compiling=no
-subdirs=
-MFLAGS=
-MAKEFLAGS=
-# Identity of this package.
-PACKAGE_NAME='coaster-c-client'
-PACKAGE_TARNAME='coaster-c-client'
-PACKAGE_VERSION='1.0'
-PACKAGE_STRING='coaster-c-client 1.0'
-PACKAGE_BUGREPORT=''
-PACKAGE_URL=''
-ac_unique_file="src/CoasterClient.cpp"
-# Factoring default headers for most tests.
-ac_includes_default="\
-#include <stdio.h>
-#ifdef HAVE_SYS_TYPES_H
-# include <sys/types.h>
-#endif
-#ifdef HAVE_SYS_STAT_H
-# include <sys/stat.h>
-#endif
-#ifdef STDC_HEADERS
-# include <stdlib.h>
-# include <stddef.h>
-#else
-# ifdef HAVE_STDLIB_H
-# endif
-#endif
-#ifdef HAVE_STRING_H
-# if !defined STDC_HEADERS && defined HAVE_MEMORY_H
-# include <memory.h>
-# endif
-# include <string.h>
-#endif
-#ifdef HAVE_STRINGS_H
-# include <strings.h>
-#endif
-#ifdef HAVE_INTTYPES_H
-# include <inttypes.h>
-#endif
-#ifdef HAVE_STDINT_H
-# include <stdint.h>
-#endif
-#ifdef HAVE_UNISTD_H
-# include <unistd.h>
-#endif"
-ac_subst_vars='am__EXEEXT_FALSE
-am__EXEEXT_TRUE
-LTLIBOBJS
-AM_CXXFLAGS
-SWIG_FALSE
-SWIG_TRUE
-LIBOBJS
-CXXCPP
-am__fastdepCXX_FALSE
-am__fastdepCXX_TRUE
-CXXDEPMODE
-ac_ct_CXX
-CXXFLAGS
-CXX
-CPP
-OTOOL64
-OTOOL
-LIPO
-NMEDIT
-DSYMUTIL
-MANIFEST_TOOL
-RANLIB
-ac_ct_AR
-AR
-DLLTOOL
-OBJDUMP
-LN_S
-NM
-ac_ct_DUMPBIN
-DUMPBIN
-LD
-FGREP
-EGREP
-GREP
-SED
-am__fastdepCC_FALSE
-am__fastdepCC_TRUE
-CCDEPMODE
-am__nodep
-AMDEPBACKSLASH
-AMDEP_FALSE
-AMDEP_TRUE
-am__quote
-am__include
-DEPDIR
-OBJEXT
-EXEEXT
-ac_ct_CC
-CPPFLAGS
-LDFLAGS
-CFLAGS
-CC
-host_os
-host_vendor
-host_cpu
-host
-build_os
-build_vendor
-build_cpu
-build
-LIBTOOL
-am__untar
-am__tar
-AMTAR
-am__leading_dot
-SET_MAKE
-AWK
-mkdir_p
-MKDIR_P
-INSTALL_STRIP_PROGRAM
-STRIP
-install_sh
-MAKEINFO
-AUTOHEADER
-AUTOMAKE
-AUTOCONF
-ACLOCAL
-VERSION
-PACKAGE
-CYGPATH_W
-am__isrc
-INSTALL_DATA
-INSTALL_SCRIPT
-INSTALL_PROGRAM
-target_alias
-host_alias
-build_alias
-LIBS
-ECHO_T
-ECHO_N
-ECHO_C
-DEFS
-mandir
-localedir
-libdir
-psdir
-pdfdir
-dvidir
-htmldir
-infodir
-docdir
-oldincludedir
-includedir
-localstatedir
-sharedstatedir
-sysconfdir
-datadir
-datarootdir
-libexecdir
-sbindir
-bindir
-program_transform_name
-prefix
-exec_prefix
-PACKAGE_URL
-PACKAGE_BUGREPORT
-PACKAGE_STRING
-PACKAGE_VERSION
-PACKAGE_TARNAME
-PACKAGE_NAME
-PATH_SEPARATOR
-SHELL'
-ac_subst_files=''
-ac_user_opts='
-enable_option_checking
-enable_shared
-enable_static
-with_pic
-enable_fast_install
-enable_dependency_tracking
-with_gnu_ld
-with_sysroot
-enable_libtool_lock
-enable_debug
-with_tcl
-with_tcl_version
-enable_swig
- ac_precious_vars='build_alias
-host_alias
-target_alias
-CC
-CFLAGS
-LDFLAGS
-LIBS
-CPPFLAGS
-CPP
-CXX
-CXXFLAGS
-CCC
-CXXCPP'
-# Initialize some variables set by options.
-ac_init_help=
-ac_init_version=false
-ac_unrecognized_opts=
-ac_unrecognized_sep=
-# The variables have the same names as the options, with
-# dashes changed to underlines.
-cache_file=/dev/null
-exec_prefix=NONE
-no_create=
-no_recursion=
-prefix=NONE
-program_prefix=NONE
-program_suffix=NONE
-program_transform_name=s,x,x,
-silent=
-site=
-srcdir=
-verbose=
-x_includes=NONE
-x_libraries=NONE
-# Installation directory options.
-# These are left unexpanded so users can "make install exec_prefix=/foo"
-# and all the variables that are supposed to be based on exec_prefix
-# by default will actually change.
-# Use braces instead of parens because sh, perl, etc. also accept them.
-# (The list follows the same order as the GNU Coding Standards.)
-bindir='${exec_prefix}/bin'
-sbindir='${exec_prefix}/sbin'
-libexecdir='${exec_prefix}/libexec'
-datarootdir='${prefix}/share'
-datadir='${datarootdir}'
-sysconfdir='${prefix}/etc'
-sharedstatedir='${prefix}/com'
-localstatedir='${prefix}/var'
-includedir='${prefix}/include'
-oldincludedir='/usr/include'
-docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
-infodir='${datarootdir}/info'
-htmldir='${docdir}'
-dvidir='${docdir}'
-pdfdir='${docdir}'
-psdir='${docdir}'
-libdir='${exec_prefix}/lib'
-localedir='${datarootdir}/locale'
-mandir='${datarootdir}/man'
-ac_prev=
-ac_dashdash=
-for ac_option
-do
- # If the previous option needs an argument, assign it.
- if test -n "$ac_prev"; then
- eval $ac_prev=\$ac_option
- ac_prev=
- continue
- fi
- case $ac_option in
- *=?*) ac_optarg=`expr "X$ac_option" : '[^=]*=\(.*\)'` ;;
- *=) ac_optarg= ;;
- *) ac_optarg=yes ;;
- esac
- # Accept the important Cygnus configure options, so we can diagnose typos.
- case $ac_dashdash$ac_option in
- ac_dashdash=yes ;;
- -bindir | --bindir | --bindi | --bind | --bin | --bi)
- ac_prev=bindir ;;
- -bindir=* | --bindir=* | --bindi=* | --bind=* | --bin=* | --bi=*)
- bindir=$ac_optarg ;;
- -build | --build | --buil | --bui | --bu)
- ac_prev=build_alias ;;
- -build=* | --build=* | --buil=* | --bui=* | --bu=*)
- build_alias=$ac_optarg ;;
- -cache-file | --cache-file | --cache-fil | --cache-fi \
- | --cache-f | --cache- | --cache | --cach | --cac | --ca | --c)
- ac_prev=cache_file ;;
- -cache-file=* | --cache-file=* | --cache-fil=* | --cache-fi=* \
- | --cache-f=* | --cache-=* | --cache=* | --cach=* | --cac=* | --ca=* | --c=*)
- cache_file=$ac_optarg ;;
- --config-cache | -C)
- cache_file=config.cache ;;
- -datadir | --datadir | --datadi | --datad)
- ac_prev=datadir ;;
- -datadir=* | --datadir=* | --datadi=* | --datad=*)
- datadir=$ac_optarg ;;
- -datarootdir | --datarootdir | --datarootdi | --datarootd | --dataroot \
- | --dataroo | --dataro | --datar)
- ac_prev=datarootdir ;;
- -datarootdir=* | --datarootdir=* | --datarootdi=* | --datarootd=* \
- | --dataroot=* | --dataroo=* | --dataro=* | --datar=*)
- datarootdir=$ac_optarg ;;
- -disable-* | --disable-*)
- ac_useropt=`expr "x$ac_option" : 'x-*disable-\(.*\)'`
- # Reject names that are not valid shell variable names.
- expr "x$ac_useropt" : ".*[^-+._$as_cr_alnum]" >/dev/null &&
- as_fn_error $? "invalid feature name: $ac_useropt"
- ac_useropt_orig=$ac_useropt
- ac_useropt=`$as_echo "$ac_useropt" | sed 's/[-+.]/_/g'`
- case $ac_user_opts in
-"enable_$ac_useropt"
- *) ac_unrecognized_opts="$ac_unrecognized_opts$ac_unrecognized_sep--disable-$ac_useropt_orig"
- ac_unrecognized_sep=', ';;
- esac
- eval enable_$ac_useropt=no ;;
- -docdir | --docdir | --docdi | --doc | --do)
- ac_prev=docdir ;;
- -docdir=* | --docdir=* | --docdi=* | --doc=* | --do=*)
- docdir=$ac_optarg ;;
- -dvidir | --dvidir | --dvidi | --dvid | --dvi | --dv)
- ac_prev=dvidir ;;
- -dvidir=* | --dvidir=* | --dvidi=* | --dvid=* | --dvi=* | --dv=*)
- dvidir=$ac_optarg ;;
- -enable-* | --enable-*)
- ac_useropt=`expr "x$ac_option" : 'x-*enable-\([^=]*\)'`
- *) ac_unrecognized_opts="$ac_unrecognized_opts$ac_unrecognized_sep--enable-$ac_useropt_orig"
- esac
- eval enable_$ac_useropt=\$ac_optarg ;;
- -exec-prefix | --exec_prefix | --exec-prefix | --exec-prefi \
- | --exec-pref | --exec-pre | --exec-pr | --exec-p | --exec- \
- | --exec | --exe | --ex)
- ac_prev=exec_prefix ;;
- -exec-prefix=* | --exec_prefix=* | --exec-prefix=* | --exec-prefi=* \
- | --exec-pref=* | --exec-pre=* | --exec-pr=* | --exec-p=* | --exec-=* \
- | --exec=* | --exe=* | --ex=*)
- exec_prefix=$ac_optarg ;;
- -gas | --gas | --ga | --g)
- # Obsolete; use --with-gas.
- with_gas=yes ;;
- -help | --help | --hel | --he | -h)
- ac_init_help=long ;;
- -help=r* | --help=r* | --hel=r* | --he=r* | -hr*)
- ac_init_help=recursive ;;
- -help=s* | --help=s* | --hel=s* | --he=s* | -hs*)
- ac_init_help=short ;;
- -host | --host | --hos | --ho)
- ac_prev=host_alias ;;
- -host=* | --host=* | --hos=* | --ho=*)
- host_alias=$ac_optarg ;;
- -htmldir | --htmldir | --htmldi | --htmld | --html | --htm | --ht)
- ac_prev=htmldir ;;
- -htmldir=* | --htmldir=* | --htmldi=* | --htmld=* | --html=* | --htm=* \
- | --ht=*)
- htmldir=$ac_optarg ;;
- -includedir | --includedir | --includedi | --included | --include \
- | --includ | --inclu | --incl | --inc)
- ac_prev=includedir ;;
- -includedir=* | --includedir=* | --includedi=* | --included=* | --include=* \
- | --includ=* | --inclu=* | --incl=* | --inc=*)
- includedir=$ac_optarg ;;
- -infodir | --infodir | --infodi | --infod | --info | --inf)
- ac_prev=infodir ;;
- -infodir=* | --infodir=* | --infodi=* | --infod=* | --info=* | --inf=*)
- infodir=$ac_optarg ;;
- -libdir | --libdir | --libdi | --libd)
- ac_prev=libdir ;;
- -libdir=* | --libdir=* | --libdi=* | --libd=*)
- libdir=$ac_optarg ;;
- -libexecdir | --libexecdir | --libexecdi | --libexecd | --libexec \
- | --libexe | --libex | --libe)
- ac_prev=libexecdir ;;
- -libexecdir=* | --libexecdir=* | --libexecdi=* | --libexecd=* | --libexec=* \
- | --libexe=* | --libex=* | --libe=*)
- libexecdir=$ac_optarg ;;
- -localedir | --localedir | --localedi | --localed | --locale)
- ac_prev=localedir ;;
- -localedir=* | --localedir=* | --localedi=* | --localed=* | --locale=*)
- localedir=$ac_optarg ;;
- -localstatedir | --localstatedir | --localstatedi | --localstated \
- | --localstate | --localstat | --localsta | --localst | --locals)
- ac_prev=localstatedir ;;
- -localstatedir=* | --localstatedir=* | --localstatedi=* | --localstated=* \
- | --localstate=* | --localstat=* | --localsta=* | --localst=* | --locals=*)
- localstatedir=$ac_optarg ;;
- -mandir | --mandir | --mandi | --mand | --man | --ma | --m)
- ac_prev=mandir ;;
- -mandir=* | --mandir=* | --mandi=* | --mand=* | --man=* | --ma=* | --m=*)
- mandir=$ac_optarg ;;
- -nfp | --nfp | --nf)
- # Obsolete; use --without-fp.
- with_fp=no ;;
- -no-create | --no-create | --no-creat | --no-crea | --no-cre \
- | --no-cr | --no-c | -n)
- no_create=yes ;;
- -no-recursion | --no-recursion | --no-recursio | --no-recursi \
- | --no-recurs | --no-recur | --no-recu | --no-rec | --no-re | --no-r)
- no_recursion=yes ;;
- -oldincludedir | --oldincludedir | --oldincludedi | --oldincluded \
- | --oldinclude | --oldinclud | --oldinclu | --oldincl | --oldinc \
- | --oldin | --oldi | --old | --ol | --o)
- ac_prev=oldincludedir ;;
- -oldincludedir=* | --oldincludedir=* | --oldincludedi=* | --oldincluded=* \
- | --oldinclude=* | --oldinclud=* | --oldinclu=* | --oldincl=* | --oldinc=* \
- | --oldin=* | --oldi=* | --old=* | --ol=* | --o=*)
- oldincludedir=$ac_optarg ;;
- -prefix | --prefix | --prefi | --pref | --pre | --pr | --p)
- ac_prev=prefix ;;
- -prefix=* | --prefix=* | --prefi=* | --pref=* | --pre=* | --pr=* | --p=*)
- prefix=$ac_optarg ;;
- -program-prefix | --program-prefix | --program-prefi | --program-pref \
- | --program-pre | --program-pr | --program-p)
- ac_prev=program_prefix ;;
- -program-prefix=* | --program-prefix=* | --program-prefi=* \
- | --program-pref=* | --program-pre=* | --program-pr=* | --program-p=*)
- program_prefix=$ac_optarg ;;
- -program-suffix | --program-suffix | --program-suffi | --program-suff \
- | --program-suf | --program-su | --program-s)
- ac_prev=program_suffix ;;
- -program-suffix=* | --program-suffix=* | --program-suffi=* \
- | --program-suff=* | --program-suf=* | --program-su=* | --program-s=*)
- program_suffix=$ac_optarg ;;
- -program-transform-name | --program-transform-name \
- | --program-transform-nam | --program-transform-na \
- | --program-transform-n | --program-transform- \
- | --program-transform | --program-transfor \
- | --program-transfo | --program-transf \
- | --program-trans | --program-tran \
- | --progr-tra | --program-tr | --program-t)
- ac_prev=program_transform_name ;;
- -program-transform-name=* | --program-transform-name=* \
- | --program-transform-nam=* | --program-transform-na=* \
- | --program-transform-n=* | --program-transform-=* \
- | --program-transform=* | --program-transfor=* \
- | --program-transfo=* | --program-transf=* \
- | --program-trans=* | --program-tran=* \
- | --progr-tra=* | --program-tr=* | --program-t=*)
- program_transform_name=$ac_optarg ;;
- -pdfdir | --pdfdir | --pdfdi | --pdfd | --pdf | --pd)
- ac_prev=pdfdir ;;
- -pdfdir=* | --pdfdir=* | --pdfdi=* | --pdfd=* | --pdf=* | --pd=*)
- pdfdir=$ac_optarg ;;
- -psdir | --psdir | --psdi | --psd | --ps)
- ac_prev=psdir ;;
- -psdir=* | --psdir=* | --psdi=* | --psd=* | --ps=*)
- psdir=$ac_optarg ;;
- -q | -quiet | --quiet | --quie | --qui | --qu | --q \
- | -silent | --silent | --silen | --sile | --sil)
- silent=yes ;;
- -sbindir | --sbindir | --sbindi | --sbind | --sbin | --sbi | --sb)
- ac_prev=sbindir ;;
- -sbindir=* | --sbindir=* | --sbindi=* | --sbind=* | --sbin=* \
- | --sbi=* | --sb=*)
- sbindir=$ac_optarg ;;
- -sharedstatedir | --sharedstatedir | --sharedstatedi \
- | --sharedstated | --sharedstate | --sharedstat | --sharedsta \
- | --sharedst | --shareds | --shared | --share | --shar \
- | --sha | --sh)
- ac_prev=sharedstatedir ;;
- -sharedstatedir=* | --sharedstatedir=* | --sharedstatedi=* \
- | --sharedstated=* | --sharedstate=* | --sharedstat=* | --sharedsta=* \
- | --sharedst=* | --shareds=* | --shared=* | --share=* | --shar=* \
- | --sha=* | --sh=*)
- sharedstatedir=$ac_optarg ;;
- -site | --site | --sit)
- ac_prev=site ;;
- -site=* | --site=* | --sit=*)
- site=$ac_optarg ;;
- -srcdir | --srcdir | --srcdi | --srcd | --src | --sr)
- ac_prev=srcdir ;;
- -srcdir=* | --srcdir=* | --srcdi=* | --srcd=* | --src=* | --sr=*)
- srcdir=$ac_optarg ;;
- -sysconfdir | --sysconfdir | --sysconfdi | --sysconfd | --sysconf \
- | --syscon | --sysco | --sysc | --sys | --sy)
- ac_prev=sysconfdir ;;
- -sysconfdir=* | --sysconfdir=* | --sysconfdi=* | --sysconfd=* | --sysconf=* \
- | --syscon=* | --sysco=* | --sysc=* | --sys=* | --sy=*)
- sysconfdir=$ac_optarg ;;
- -target | --target | --targe | --targ | --tar | --ta | --t)
- ac_prev=target_alias ;;
- -target=* | --target=* | --targe=* | --targ=* | --tar=* | --ta=* | --t=*)
- target_alias=$ac_optarg ;;
- -v | -verbose | --verbose | --verbos | --verbo | --verb)
- verbose=yes ;;
- -version | --version | --versio | --versi | --vers | -V)
- ac_init_version=: ;;
- -with-* | --with-*)
- ac_useropt=`expr "x$ac_option" : 'x-*with-\([^=]*\)'`
- as_fn_error $? "invalid package name: $ac_useropt"
-"with_$ac_useropt"
- *) ac_unrecognized_opts="$ac_unrecognized_opts$ac_unrecognized_sep--with-$ac_useropt_orig"
- esac
- eval with_$ac_useropt=\$ac_optarg ;;
- -without-* | --without-*)
- ac_useropt=`expr "x$ac_option" : 'x-*without-\(.*\)'`
-"with_$ac_useropt"
- *) ac_unrecognized_opts="$ac_unrecognized_opts$ac_unrecognized_sep--without-$ac_useropt_orig"
- esac
- eval with_$ac_useropt=no ;;
- --x)
- # Obsolete; use --with-x.
- with_x=yes ;;
- -x-includes | --x-includes | --x-include | --x-includ | --x-inclu \
- | --x-incl | --x-inc | --x-in | --x-i)
- ac_prev=x_includes ;;
- -x-includes=* | --x-includes=* | --x-include=* | --x-includ=* | --x-inclu=* \
- | --x-incl=* | --x-inc=* | --x-in=* | --x-i=*)
- x_includes=$ac_optarg ;;
- -x-libraries | --x-libraries | --x-librarie | --x-librari \
- | --x-librar | --x-libra | --x-libr | --x-lib | --x-li | --x-l)
- ac_prev=x_libraries ;;
- -x-libraries=* | --x-libraries=* | --x-librarie=* | --x-librari=* \
- | --x-librar=* | --x-libra=* | --x-libr=* | --x-lib=* | --x-li=* | --x-l=*)
- x_libraries=$ac_optarg ;;
- -*) as_fn_error $? "unrecognized option: \`$ac_option'
-Try \`$0 --help' for more information"
- ac_envvar=`expr "x$ac_option" : 'x\([^=]*\)='`
- case $ac_envvar in #(
- '' | [0-9]* | *[!_$as_cr_alnum]* )
- as_fn_error $? "invalid variable name: \`$ac_envvar'" ;;
- esac
- eval $ac_envvar=\$ac_optarg
- export $ac_envvar ;;
- # FIXME: should be removed in autoconf 3.0.
- $as_echo "$as_me: WARNING: you should use --build, --host, --target" >&2
- expr "x$ac_option" : ".*[^-._$as_cr_alnum]" >/dev/null &&
- $as_echo "$as_me: WARNING: invalid host type: $ac_option" >&2
- : "${build_alias=$ac_option} ${host_alias=$ac_option} ${target_alias=$ac_option}"
- esac
-done
-if test -n "$ac_prev"; then
- ac_option=--`echo $ac_prev | sed 's/_/-/g'`
- as_fn_error $? "missing argument to $ac_option"
-fi
-if test -n "$ac_unrecognized_opts"; then
- case $enable_option_checking in
- no) ;;
- fatal) as_fn_error $? "unrecognized options: $ac_unrecognized_opts" ;;
- *) $as_echo "$as_me: WARNING: unrecognized options: $ac_unrecognized_opts" >&2 ;;
- esac
-fi
-# Check all directory arguments for consistency.
-for ac_var in exec_prefix prefix bindir sbindir libexecdir datarootdir \
- datadir sysconfdir sharedstatedir localstatedir includedir \
- oldincludedir docdir infodir htmldir dvidir pdfdir psdir \
- libdir localedir mandir
-do
- eval ac_val=\$$ac_var
- # Remove trailing slashes.
- case $ac_val in
- ac_val=`expr "X$ac_val" : 'X\(.*[^/]\)' \| "X$ac_val" : 'X\(.*\)'`
- eval $ac_var=\$ac_val;;
- esac
- # Be sure to have absolute directory names.
- case $ac_val in
- [\\/$]* | ?:[\\/]* ) continue;;
- NONE | '' ) case $ac_var in *prefix ) continue;; esac;;
- esac
- as_fn_error $? "expected an absolute directory name for --$ac_var: $ac_val"
-done
-# There might be people who depend on the old broken behavior: `$host'
-# used to hold the argument of --host etc.
-# FIXME: To remove some day.
-build=$build_alias
-host=$host_alias
-target=$target_alias
-if test "x$host_alias" != x; then
- if test "x$build_alias" = x; then
- cross_compiling=maybe
- $as_echo "$as_me: WARNING: if you wanted to set the --build type, don't use --host.
- If a cross compiler is detected then cross compile mode will be used" >&2
- elif test "x$build_alias" != "x$host_alias"; then
- cross_compiling=yes
- fi
-fi
-ac_tool_prefix=
-test -n "$host_alias" && ac_tool_prefix=$host_alias-
-test "$silent" = yes && exec 6>/dev/null
-ac_pwd=`pwd` && test -n "$ac_pwd" &&
-ac_ls_di=`ls -di .` &&
-ac_pwd_ls_di=`cd "$ac_pwd" && ls -di .` ||
- as_fn_error $? "working directory cannot be determined"
-test "X$ac_ls_di" = "X$ac_pwd_ls_di" ||
- as_fn_error $? "pwd does not report name of working directory"
-# Find the source files, if location was not specified.
-if test -z "$srcdir"; then
- ac_srcdir_defaulted=yes
- # Try the directory containing this script, then the parent directory.
- ac_confdir=`$as_dirname -- "$as_myself" ||
-$as_expr X"$as_myself" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$as_myself" : 'X\(//\)[^/]' \| \
- X"$as_myself" : 'X\(//\)$' \| \
- X"$as_myself" : 'X\(/\)' \| . 2>/dev/null ||
-$as_echo X"$as_myself" |
- s//\1/
- q
- s//\1/
- q
- /^X\(\/\/\)$/{
- s//\1/
- q
- /^X\(\/\).*/{
- s//\1/
- q
- s/.*/./; q'`
- srcdir=$ac_confdir
- if test ! -r "$srcdir/$ac_unique_file"; then
- srcdir=..
- fi
-else
- ac_srcdir_defaulted=no
-fi
-if test ! -r "$srcdir/$ac_unique_file"; then
- test "$ac_srcdir_defaulted" = yes && srcdir="$ac_confdir or .."
- as_fn_error $? "cannot find sources ($ac_unique_file) in $srcdir"
-fi
-ac_msg="sources are in $srcdir, but \`cd $srcdir' does not work"
-ac_abs_confdir=`(
- cd "$srcdir" && test -r "./$ac_unique_file" || as_fn_error $? "$ac_msg"
- pwd)`
-# When building in place, set srcdir=.
-if test "$ac_abs_confdir" = "$ac_pwd"; then
- srcdir=.
-fi
-# Remove unnecessary trailing slashes from srcdir.
-# Double slashes in file names in object file debugging info
-# mess up M-x gdb in Emacs.
-case $srcdir in
-*/) srcdir=`expr "X$srcdir" : 'X\(.*[^/]\)' \| "X$srcdir" : 'X\(.*\)'`;;
-esac
-for ac_var in $ac_precious_vars; do
- eval ac_env_${ac_var}_set=\${${ac_var}+set}
- eval ac_env_${ac_var}_value=\$${ac_var}
- eval ac_cv_env_${ac_var}_set=\${${ac_var}+set}
- eval ac_cv_env_${ac_var}_value=\$${ac_var}
-done
-# Report the --help message.
-if test "$ac_init_help" = "long"; then
- # Omit some internal or obsolete options to make the list less imposing.
- # This message is too long to be a string in the A/UX 3.1 sh.
- cat <<_ACEOF
-\`configure' configures coaster-c-client 1.0 to adapt to many kinds of systems.
-Usage: $0 [OPTION]... [VAR=VALUE]...
-To assign environment variables (e.g., CC, CFLAGS...), specify them as
-VAR=VALUE. See below for descriptions of some of the useful variables.
-Defaults for the options are specified in brackets.
-Configuration:
- -h, --help display this help and exit
- --help=short display options specific to this package
- --help=recursive display the short help of all the included packages
- -V, --version display version information and exit
- -q, --quiet, --silent do not print \`checking ...' messages
- --cache-file=FILE cache test results in FILE [disabled]
- -C, --config-cache alias for \`--cache-file=config.cache'
- -n, --no-create do not create output files
- --srcdir=DIR find the sources in DIR [configure dir or \`..']
-Installation directories:
- --prefix=PREFIX install architecture-independent files in PREFIX
- [$ac_default_prefix]
- --exec-prefix=EPREFIX install architecture-dependent files in EPREFIX
- [PREFIX]
-By default, \`make install' will install all the files in
-\`$ac_default_prefix/bin', \`$ac_default_prefix/lib' etc. You can specify
-an installation prefix other than \`$ac_default_prefix' using \`--prefix',
-for instance \`--prefix=\$HOME'.
-For better control, use the options below.
-Fine tuning of the installation directories:
- --bindir=DIR user executables [EPREFIX/bin]
- --sbindir=DIR system admin executables [EPREFIX/sbin]
- --libexecdir=DIR program executables [EPREFIX/libexec]
- --sysconfdir=DIR read-only single-machine data [PREFIX/etc]
- --sharedstatedir=DIR modifiable architecture-independent data [PREFIX/com]
- --localstatedir=DIR modifiable single-machine data [PREFIX/var]
- --libdir=DIR object code libraries [EPREFIX/lib]
- --includedir=DIR C header files [PREFIX/include]
- --oldincludedir=DIR C header files for non-gcc [/usr/include]
- --datarootdir=DIR read-only arch.-independent data root [PREFIX/share]
- --datadir=DIR read-only architecture-independent data [DATAROOTDIR]
- --infodir=DIR info documentation [DATAROOTDIR/info]
- --localedir=DIR locale-dependent data [DATAROOTDIR/locale]
- --mandir=DIR man documentation [DATAROOTDIR/man]
- --docdir=DIR documentation root
- [DATAROOTDIR/doc/coaster-c-client]
- --htmldir=DIR html documentation [DOCDIR]
- --dvidir=DIR dvi documentation [DOCDIR]
- --pdfdir=DIR pdf documentation [DOCDIR]
- --psdir=DIR ps documentation [DOCDIR]
-_ACEOF
- cat <<\_ACEOF
-Program names:
- --program-prefix=PREFIX prepend PREFIX to installed program names
- --program-suffix=SUFFIX append SUFFIX to installed program names
- --program-transform-name=PROGRAM run sed PROGRAM on installed program names
-System types:
- --build=BUILD configure for building on BUILD [guessed]
- --host=HOST cross-compile to build programs to run on HOST [BUILD]
-_ACEOF
-fi
-if test -n "$ac_init_help"; then
- case $ac_init_help in
- short | recursive ) echo "Configuration of coaster-c-client 1.0:";;
- esac
- cat <<\_ACEOF
-Optional Features:
- --disable-option-checking ignore unrecognized --enable/--with options
- --disable-FEATURE do not include FEATURE (same as --enable-FEATURE=no)
- --enable-FEATURE[=ARG] include FEATURE [ARG=yes]
- --enable-shared[=PKGS] build shared libraries [default=yes]
- --enable-static[=PKGS] build static libraries [default=yes]
- --enable-fast-install[=PKGS]
- optimize for fast installation [default=yes]
- --disable-dependency-tracking speeds up one-time build
- --enable-dependency-tracking do not reject slow dependency extractors
- --disable-libtool-lock avoid locking (might break parallel builds)
- --enable-debug enable debugging symbols and disable compiler
- optimizations (def=no)
- --enable-swig enable use of SWIG and Tcl support
-Optional Packages:
- --with-PACKAGE[=ARG] use PACKAGE [ARG=yes]
- --without-PACKAGE do not use PACKAGE (same as --with-PACKAGE=no)
- --with-pic[=PKGS] try to use only PIC/non-PIC objects [default=use
- both]
- --with-gnu-ld assume the C compiler uses GNU ld [default=no]
- --with-sysroot=DIR Search for dependent libraries within DIR
- (or the compiler's sysroot if not specified).
- --with-tcl location of Tcl
- --with-tcl-version Tcl version: 8.5 or 8.6
-Some influential environment variables:
- CC C compiler command
- CFLAGS C compiler flags
- LDFLAGS linker flags, e.g. -L<lib dir> if you have libraries in a
- nonstandard directory <lib dir>
- LIBS libraries to pass to the linker, e.g. -l<library>
- CPPFLAGS (Objective) C/C++ preprocessor flags, e.g. -I<include dir> if
- you have headers in a nonstandard directory <include dir>
- CPP C preprocessor
- CXX C++ compiler command
- CXXFLAGS C++ compiler flags
- CXXCPP C++ preprocessor
-Use these variables to override the choices made by `configure' or to help
-it to find libraries and programs with nonstandard names/locations.
-Report bugs to the package provider.
-_ACEOF
-ac_status=$?
-fi
-if test "$ac_init_help" = "recursive"; then
- # If there are subdirs, report their specific --help.
- for ac_dir in : $ac_subdirs_all; do test "x$ac_dir" = x: && continue
- test -d "$ac_dir" ||
- { cd "$srcdir" && ac_pwd=`pwd` && srcdir=. && test -d "$ac_dir"; } ||
- continue
- ac_builddir=.
-case "$ac_dir" in
-.) ac_dir_suffix= ac_top_builddir_sub=. ac_top_build_prefix= ;;
- ac_dir_suffix=/`$as_echo "$ac_dir" | sed 's|^\.[\\/]||'`
- # A ".." for each directory in $ac_dir_suffix.
- ac_top_builddir_sub=`$as_echo "$ac_dir_suffix" | sed 's|/[^\\/]*|/..|g;s|/||'`
- case $ac_top_builddir_sub in
- "") ac_top_builddir_sub=. ac_top_build_prefix= ;;
- *) ac_top_build_prefix=$ac_top_builddir_sub/ ;;
- esac ;;
-esac
-ac_abs_top_builddir=$ac_pwd
-ac_abs_builddir=$ac_pwd$ac_dir_suffix
-# for backward compatibility:
-ac_top_builddir=$ac_top_build_prefix
-case $srcdir in
- .) # We are building in place.
- ac_srcdir=.
- ac_top_srcdir=$ac_top_builddir_sub
- ac_abs_top_srcdir=$ac_pwd ;;
- [\\/]* | ?:[\\/]* ) # Absolute name.
- ac_srcdir=$srcdir$ac_dir_suffix;
- ac_top_srcdir=$srcdir
- ac_abs_top_srcdir=$srcdir ;;
- *) # Relative name.
- ac_srcdir=$ac_top_build_prefix$srcdir$ac_dir_suffix
- ac_top_srcdir=$ac_top_build_prefix$srcdir
- ac_abs_top_srcdir=$ac_pwd/$srcdir ;;
-esac
-ac_abs_srcdir=$ac_abs_top_srcdir$ac_dir_suffix
- cd "$ac_dir" || { ac_status=$?; continue; }
- # Check for guested configure.
- if test -f "$ac_srcdir/configure.gnu"; then
- echo &&
- $SHELL "$ac_srcdir/configure.gnu" --help=recursive
- elif test -f "$ac_srcdir/configure"; then
- echo &&
- $SHELL "$ac_srcdir/configure" --help=recursive
- else
- $as_echo "$as_me: WARNING: no configuration information is in $ac_dir" >&2
- fi || ac_status=$?
- cd "$ac_pwd" || { ac_status=$?; break; }
- done
-fi
-test -n "$ac_init_help" && exit $ac_status
-if $ac_init_version; then
- cat <<\_ACEOF
-coaster-c-client configure 1.0
-generated by GNU Autoconf 2.68
-Copyright (C) 2010 Free Software Foundation, Inc.
-This configure script is free software; the Free Software Foundation
-gives unlimited permission to copy, distribute and modify it.
-_ACEOF
- exit
-fi
-## Autoconf initialization. ##
-# ac_fn_c_try_compile LINENO
-# Try to compile conftest.$ac_ext, and return whether this succeeded.
-ac_fn_c_try_compile ()
- as_lineno=${as_lineno-"$1"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
- rm -f conftest.$ac_objext
- if { { ac_try="$ac_compile"
-case "(($ac_try" in
- *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
- *) ac_try_echo=$ac_try;;
-esac
-eval ac_try_echo="\"\$as_me:${as_lineno-$LINENO}: $ac_try_echo\""
-$as_echo "$ac_try_echo"; } >&5
- (eval "$ac_compile") 2>conftest.err
- ac_status=$?
- if test -s conftest.err; then
- grep -v '^ *+' conftest.err >conftest.er1
- cat conftest.er1 >&5
- mv -f conftest.er1 conftest.err
- fi
- $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
- test $ac_status = 0; } && {
- test -z "$ac_c_werror_flag" ||
- test ! -s conftest.err
- } && test -s conftest.$ac_objext; then :
- ac_retval=0
-else
- $as_echo "$as_me: failed program was:" >&5
-sed 's/^/| /' conftest.$ac_ext >&5
- ac_retval=1
-fi
- eval $as_lineno_stack; ${as_lineno_stack:+:} unset as_lineno
- as_fn_set_status $ac_retval
-} # ac_fn_c_try_compile
-# ac_fn_c_try_link LINENO
-# Try to link conftest.$ac_ext, and return whether this succeeded.
-ac_fn_c_try_link ()
- rm -f conftest.$ac_objext conftest$ac_exeext
- if { { ac_try="$ac_link"
-esac
- (eval "$ac_link") 2>conftest.err
- ac_status=$?
- fi
- } && test -s conftest$ac_exeext && {
- test "$cross_compiling" = yes ||
- $as_test_x conftest$ac_exeext
- }; then :
- ac_retval=0
-else
- ac_retval=1
-fi
- # Delete the IPA/IPO (Inter Procedural Analysis/Optimization) information
- # created by the PGI compiler (conftest_ipa8_conftest.oo), as it would
- # interfere with the next link command; also delete a directory that is
- # left behind by Apple's compiler. We do this before executing the actions.
- rm -rf conftest.dSYM conftest_ipa8_conftest.oo
-} # ac_fn_c_try_link
-# ac_fn_c_check_header_compile LINENO HEADER VAR INCLUDES
-# Tests whether HEADER exists and can be compiled using the include files in
-# INCLUDES, setting the cache variable VAR accordingly.
-ac_fn_c_check_header_compile ()
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for $2" >&5
-$as_echo_n "checking for $2... " >&6; }
-if eval \${$3+:} false; then :
- $as_echo_n "(cached) " >&6
-else
- cat confdefs.h - <<_ACEOF >conftest.$ac_ext
-/* end confdefs.h. */
-$4
-#include <$2>
-_ACEOF
-if ac_fn_c_try_compile "$LINENO"; then :
- eval "$3=yes"
-else
- eval "$3=no"
-fi
-rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
-fi
-eval ac_res=\$$3
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_res" >&5
-$as_echo "$ac_res" >&6; }
-} # ac_fn_c_check_header_compile
-# ac_fn_c_try_cpp LINENO
-# Try to preprocess conftest.$ac_ext, and return whether this succeeded.
-ac_fn_c_try_cpp ()
- if { { ac_try="$ac_cpp conftest.$ac_ext"
-esac
- (eval "$ac_cpp conftest.$ac_ext") 2>conftest.err
- ac_status=$?
- fi
- test $ac_status = 0; } > conftest.i && {
- test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" ||
- }; then :
- ac_retval=0
-else
- ac_retval=1
-fi
-} # ac_fn_c_try_cpp
-# ac_fn_c_try_run LINENO
-# Try to link conftest.$ac_ext, and return whether this succeeded. Assumes
-# that executables *can* be run.
-ac_fn_c_try_run ()
-esac
- (eval "$ac_link") 2>&5
- ac_status=$?
- test $ac_status = 0; } && { ac_try='./conftest$ac_exeext'
- { { case "(($ac_try" in
-esac
- (eval "$ac_try") 2>&5
- ac_status=$?
- test $ac_status = 0; }; }; then :
- ac_retval=0
-else
- $as_echo "$as_me: program exited with status $ac_status" >&5
- ac_retval=$ac_status
-fi
-} # ac_fn_c_try_run
-# ac_fn_c_check_func LINENO FUNC VAR
-# Tests whether FUNC exists, setting the cache variable VAR accordingly
-ac_fn_c_check_func ()
-else
-/* Define $2 to an innocuous variant, in case <limits.h> declares $2.
- For example, HP-UX 11i <limits.h> declares gettimeofday. */
-#define $2 innocuous_$2
-/* System header to define __stub macros and hopefully few prototypes,
- which can conflict with char $2 (); below.
- Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
- <limits.h> exists even on freestanding compilers. */
-#ifdef __STDC__
-# include <limits.h>
-#else
-# include <assert.h>
-#endif
-#undef $2
-/* Override any GCC internal prototype to avoid an error.
- Use char because int might match the return type of a GCC
- builtin and then its argument prototype would still apply. */
-#ifdef __cplusplus
-extern "C"
-#endif
-char $2 ();
-/* The GNU C library defines this for functions which it implements
- to always fail with ENOSYS. Some functions are actually named
- something starting with __ and the normal name is an alias. */
-#if defined __stub_$2 || defined __stub___$2
-choke me
-#endif
-int
-main ()
-return $2 ();
- return 0;
-_ACEOF
-if ac_fn_c_try_link "$LINENO"; then :
- eval "$3=yes"
-else
- eval "$3=no"
-fi
-rm -f core conftest.err conftest.$ac_objext \
- conftest$ac_exeext conftest.$ac_ext
-fi
-eval ac_res=\$$3
-} # ac_fn_c_check_func
-# ac_fn_cxx_try_compile LINENO
-ac_fn_cxx_try_compile ()
-esac
- ac_status=$?
- fi
- test -z "$ac_cxx_werror_flag" ||
- ac_retval=0
-else
- ac_retval=1
-fi
-} # ac_fn_cxx_try_compile
-# ac_fn_cxx_try_cpp LINENO
-ac_fn_cxx_try_cpp ()
-esac
- ac_status=$?
- fi
- test -z "$ac_cxx_preproc_warn_flag$ac_cxx_werror_flag" ||
- }; then :
- ac_retval=0
-else
- ac_retval=1
-fi
-} # ac_fn_cxx_try_cpp
-# ac_fn_cxx_try_link LINENO
-ac_fn_cxx_try_link ()
-esac
- ac_status=$?
- fi
- }; then :
- ac_retval=0
-else
- ac_retval=1
-fi
-} # ac_fn_cxx_try_link
-# ac_fn_c_check_header_mongrel LINENO HEADER VAR INCLUDES
-# Tests whether HEADER exists, giving a warning if it cannot be compiled using
-# the include files in INCLUDES and setting the cache variable VAR
-# accordingly.
-ac_fn_c_check_header_mongrel ()
- if eval \${$3+:} false; then :
-fi
-eval ac_res=\$$3
-else
- # Is the header compilable?
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking $2 usability" >&5
-$as_echo_n "checking $2 usability... " >&6; }
-cat confdefs.h - <<_ACEOF >conftest.$ac_ext
-$4
-#include <$2>
-_ACEOF
- ac_header_compiler=yes
-else
- ac_header_compiler=no
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_header_compiler" >&5
-$as_echo "$ac_header_compiler" >&6; }
-# Is the header present?
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking $2 presence" >&5
-$as_echo_n "checking $2 presence... " >&6; }
-#include <$2>
-_ACEOF
-if ac_fn_c_try_cpp "$LINENO"; then :
- ac_header_preproc=yes
-else
- ac_header_preproc=no
-fi
-rm -f conftest.err conftest.i conftest.$ac_ext
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_header_preproc" >&5
-$as_echo "$ac_header_preproc" >&6; }
-# So? What about this header?
-case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in #((
- yes:no: )
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: accepted by the compiler, rejected by the preprocessor!" >&5
-$as_echo "$as_me: WARNING: $2: accepted by the compiler, rejected by the preprocessor!" >&2;}
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: proceeding with the compiler's result" >&5
-$as_echo "$as_me: WARNING: $2: proceeding with the compiler's result" >&2;}
- no:yes:* )
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: present but cannot be compiled" >&5
-$as_echo "$as_me: WARNING: $2: present but cannot be compiled" >&2;}
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: check for missing prerequisite headers?" >&5
-$as_echo "$as_me: WARNING: $2: check for missing prerequisite headers?" >&2;}
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: see the Autoconf documentation" >&5
-$as_echo "$as_me: WARNING: $2: see the Autoconf documentation" >&2;}
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: section \"Present But Cannot Be Compiled\"" >&5
-$as_echo "$as_me: WARNING: $2: section \"Present But Cannot Be Compiled\"" >&2;}
-esac
-else
- eval "$3=\$ac_header_compiler"
-fi
-eval ac_res=\$$3
-fi
-} # ac_fn_c_check_header_mongrel
-# ac_fn_c_check_type LINENO TYPE VAR INCLUDES
-# Tests whether TYPE exists after having included INCLUDES, setting cache
-# variable VAR accordingly.
-ac_fn_c_check_type ()
-else
- eval "$3=no"
-$4
-int
-main ()
-if (sizeof ($2))
- return 0;
- return 0;
-_ACEOF
-$4
-int
-main ()
-if (sizeof (($2)))
- return 0;
- return 0;
-_ACEOF
-else
- eval "$3=yes"
-fi
-fi
-fi
-eval ac_res=\$$3
-} # ac_fn_c_check_type
-cat >config.log <<_ACEOF
-This file contains any messages produced by compilers while
-running configure, to aid debugging if configure makes a mistake.
-It was created by coaster-c-client $as_me 1.0, which was
-generated by GNU Autoconf 2.68. Invocation command line was
- $ $0 $@
-_ACEOF
-exec 5>>config.log
-cat <<_ASUNAME
-## Platform. ##
-hostname = `(hostname || uname -n) 2>/dev/null | sed 1q`
-uname -m = `(uname -m) 2>/dev/null || echo unknown`
-uname -r = `(uname -r) 2>/dev/null || echo unknown`
-uname -s = `(uname -s) 2>/dev/null || echo unknown`
-uname -v = `(uname -v) 2>/dev/null || echo unknown`
-/usr/bin/uname -p = `(/usr/bin/uname -p) 2>/dev/null || echo unknown`
-/bin/uname -X = `(/bin/uname -X) 2>/dev/null || echo unknown`
-/bin/arch = `(/bin/arch) 2>/dev/null || echo unknown`
-/usr/bin/arch -k = `(/usr/bin/arch -k) 2>/dev/null || echo unknown`
-/usr/convex/getsysinfo = `(/usr/convex/getsysinfo) 2>/dev/null || echo unknown`
-/usr/bin/hostinfo = `(/usr/bin/hostinfo) 2>/dev/null || echo unknown`
-/bin/machine = `(/bin/machine) 2>/dev/null || echo unknown`
-/usr/bin/oslevel = `(/usr/bin/oslevel) 2>/dev/null || echo unknown`
-/bin/universe = `(/bin/universe) 2>/dev/null || echo unknown`
-_ASUNAME
-as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-do
- IFS=$as_save_IFS
- $as_echo "PATH: $as_dir"
- done
-IFS=$as_save_IFS
-} >&5
-cat >&5 <<_ACEOF
-## Core tests. ##
-_ACEOF
-# Keep a trace of the command line.
-# Strip out --no-create and --no-recursion so they do not pile up.
-# Strip out --silent because we don't want to record it for future runs.
-# Also quote any args containing shell meta-characters.
-# Make two passes to allow for proper duplicate-argument suppression.
-ac_configure_args=
-ac_configure_args0=
-ac_configure_args1=
-ac_must_keep_next=false
-for ac_pass in 1 2
-do
- for ac_arg
- do
- case $ac_arg in
- -no-create | --no-c* | -n | -no-recursion | --no-r*) continue ;;
- continue ;;
- ac_arg=`$as_echo "$ac_arg" | sed "s/'/'\\\\\\\\''/g"` ;;
- esac
- case $ac_pass in
- 1) as_fn_append ac_configure_args0 " '$ac_arg'" ;;
- 2)
- as_fn_append ac_configure_args1 " '$ac_arg'"
- if test $ac_must_keep_next = true; then
- ac_must_keep_next=false # Got value, back to normal.
- else
- case $ac_arg in
- *=* | --config-cache | -C | -disable-* | --disable-* \
- | -enable-* | --enable-* | -gas | --g* | -nfp | --nf* \
- | -q | -quiet | --q* | -silent | --sil* | -v | -verb* \
- | -with-* | --with-* | -without-* | --without-* | --x)
- case "$ac_configure_args0 " in
- "$ac_configure_args1"*" '$ac_arg' "* ) continue ;;
- esac
- -* ) ac_must_keep_next=true ;;
- esac
- fi
- as_fn_append ac_configure_args " '$ac_arg'"
- esac
- done
-done
-{ ac_configure_args0=; unset ac_configure_args0;}
-{ ac_configure_args1=; unset ac_configure_args1;}
-# When interrupted or exit'd, cleanup temporary files, and complete
-# config.log. We remove comments because anyway the quotes in there
-# would cause problems or look ugly.
-# WARNING: Use '\'' to represent an apostrophe within the trap.
-# WARNING: Do not start the trap code with a newline, due to a FreeBSD 4.0 bug.
-trap 'exit_status=$?
- # Save into config.log some information that might help in debugging.
- echo
- $as_echo "## ---------------- ##
-## Cache variables. ##
- echo
- # The following way of writing the cache mishandles newlines in values,
- for ac_var in `(set) 2>&1 | sed -n '\''s/^\([a-zA-Z_][a-zA-Z0-9_]*\)=.*/\1/p'\''`; do
- case $ac_val in #(
- *${as_nl}*)
- case $ac_var in #(
- *_cv_*) { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: cache variable $ac_var contains a newline" >&5
-$as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
- esac
- _ | IFS | as_nl) ;; #(
- BASH_ARGV | BASH_SOURCE) eval $ac_var= ;; #(
- *) { eval $ac_var=; unset $ac_var;} ;;
- esac ;;
- esac
- done
- (set) 2>&1 |
- case $as_nl`(ac_space='\'' '\''; set) 2>&1` in #(
- *${as_nl}ac_space=\ *)
- sed -n \
- "s/'\''/'\''\\\\'\'''\''/g;
- s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='\''\\2'\''/p"
- sed -n "/^[_$as_cr_alnum]*_cv_[_$as_cr_alnum]*=/p"
- esac |
- sort
- echo
- $as_echo "## ----------------- ##
-## Output variables. ##
- echo
- for ac_var in $ac_subst_vars
- do
- case $ac_val in
- *\'\''*) ac_val=`$as_echo "$ac_val" | sed "s/'\''/'\''\\\\\\\\'\'''\''/g"`;;
- esac
- $as_echo "$ac_var='\''$ac_val'\''"
- done | sort
- echo
- if test -n "$ac_subst_files"; then
- $as_echo "## ------------------- ##
-## File substitutions. ##
- echo
- for ac_var in $ac_subst_files
- do
- case $ac_val in
- esac
- done | sort
- echo
- fi
- if test -s confdefs.h; then
- $as_echo "## ----------- ##
-## confdefs.h. ##
- echo
- cat confdefs.h
- echo
- fi
- test "$ac_signal" != 0 &&
- $as_echo "$as_me: caught signal $ac_signal"
- $as_echo "$as_me: exit $exit_status"
- } >&5
- rm -f core *.core core.conftest.* &&
- rm -f -r conftest* confdefs* conf$$* $ac_clean_files &&
- exit $exit_status
-' 0
-for ac_signal in 1 2 13 15; do
- trap 'ac_signal='$ac_signal'; as_fn_exit 1' $ac_signal
-done
-ac_signal=0
-# confdefs.h avoids OS command line length limits that DEFS can exceed.
-rm -f -r conftest* confdefs.h
-$as_echo "/* confdefs.h */" > confdefs.h
-# Predefined preprocessor variables.
-cat >>confdefs.h <<_ACEOF
-#define PACKAGE_NAME "$PACKAGE_NAME"
-_ACEOF
-#define PACKAGE_TARNAME "$PACKAGE_TARNAME"
-_ACEOF
-#define PACKAGE_VERSION "$PACKAGE_VERSION"
-_ACEOF
-#define PACKAGE_STRING "$PACKAGE_STRING"
-_ACEOF
-#define PACKAGE_BUGREPORT "$PACKAGE_BUGREPORT"
-_ACEOF
-#define PACKAGE_URL "$PACKAGE_URL"
-_ACEOF
-# Let the site file select an alternate cache file if it wants to.
-# Prefer an explicitly selected file to automatically selected ones.
-ac_site_file1=NONE
-ac_site_file2=NONE
-if test -n "$CONFIG_SITE"; then
- # We do not want a PATH search for config.site.
- case $CONFIG_SITE in #((
- -*) ac_site_file1=./$CONFIG_SITE;;
- */*) ac_site_file1=$CONFIG_SITE;;
- *) ac_site_file1=./$CONFIG_SITE;;
- esac
-elif test "x$prefix" != xNONE; then
- ac_site_file1=$prefix/share/config.site
- ac_site_file2=$prefix/etc/config.site
-else
- ac_site_file1=$ac_default_prefix/share/config.site
- ac_site_file2=$ac_default_prefix/etc/config.site
-fi
-for ac_site_file in "$ac_site_file1" "$ac_site_file2"
-do
- test "x$ac_site_file" = xNONE && continue
- if test /dev/null != "$ac_site_file" && test -r "$ac_site_file"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: loading site script $ac_site_file" >&5
-$as_echo "$as_me: loading site script $ac_site_file" >&6;}
- sed 's/^/| /' "$ac_site_file" >&5
- . "$ac_site_file" \
- || { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
-$as_echo "$as_me: error: in \`$ac_pwd':" >&2;}
-as_fn_error $? "failed to load site script $ac_site_file
-See \`config.log' for more details" "$LINENO" 5; }
- fi
-done
-if test -r "$cache_file"; then
- # Some versions of bash will fail to source /dev/null (special files
- # actually), so we avoid doing that. DJGPP emulates it as a regular file.
- if test /dev/null != "$cache_file" && test -f "$cache_file"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: loading cache $cache_file" >&5
-$as_echo "$as_me: loading cache $cache_file" >&6;}
- case $cache_file in
- [\\/]* | ?:[\\/]* ) . "$cache_file";;
- *) . "./$cache_file";;
- esac
- fi
-else
- { $as_echo "$as_me:${as_lineno-$LINENO}: creating cache $cache_file" >&5
-$as_echo "$as_me: creating cache $cache_file" >&6;}
- >$cache_file
-fi
-# Check that the precious variables saved in the cache have kept the same
-# value.
-ac_cache_corrupted=false
- eval ac_old_set=\$ac_cv_env_${ac_var}_set
- eval ac_new_set=\$ac_env_${ac_var}_set
- eval ac_old_val=\$ac_cv_env_${ac_var}_value
- eval ac_new_val=\$ac_env_${ac_var}_value
- case $ac_old_set,$ac_new_set in
- set,)
- { $as_echo "$as_me:${as_lineno-$LINENO}: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&5
-$as_echo "$as_me: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&2;}
- ac_cache_corrupted=: ;;
- ,set)
- { $as_echo "$as_me:${as_lineno-$LINENO}: error: \`$ac_var' was not set in the previous run" >&5
-$as_echo "$as_me: error: \`$ac_var' was not set in the previous run" >&2;}
- if test "x$ac_old_val" != "x$ac_new_val"; then
- # differences in whitespace do not lead to failure.
- ac_old_val_w=`echo x $ac_old_val`
- ac_new_val_w=`echo x $ac_new_val`
- if test "$ac_old_val_w" != "$ac_new_val_w"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: error: \`$ac_var' has changed since the previous run:" >&5
-$as_echo "$as_me: error: \`$ac_var' has changed since the previous run:" >&2;}
- else
- { $as_echo "$as_me:${as_lineno-$LINENO}: warning: ignoring whitespace changes in \`$ac_var' since the previous run:" >&5
-$as_echo "$as_me: warning: ignoring whitespace changes in \`$ac_var' since the previous run:" >&2;}
- eval $ac_var=\$ac_old_val
- fi
- { $as_echo "$as_me:${as_lineno-$LINENO}: former value: \`$ac_old_val'" >&5
-$as_echo "$as_me: former value: \`$ac_old_val'" >&2;}
- { $as_echo "$as_me:${as_lineno-$LINENO}: current value: \`$ac_new_val'" >&5
-$as_echo "$as_me: current value: \`$ac_new_val'" >&2;}
- fi;;
- esac
- # Pass precious variables to config.status.
- if test "$ac_new_set" = set; then
- case $ac_new_val in
- *\'*) ac_arg=$ac_var=`$as_echo "$ac_new_val" | sed "s/'/'\\\\\\\\''/g"` ;;
- *) ac_arg=$ac_var=$ac_new_val ;;
- esac
- case " $ac_configure_args " in
- *" '$ac_arg' "*) ;; # Avoid dups. Use of quotes ensures accuracy.
- *) as_fn_append ac_configure_args " '$ac_arg'" ;;
- esac
- fi
-done
-if $ac_cache_corrupted; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
- { $as_echo "$as_me:${as_lineno-$LINENO}: error: changes in the environment can compromise the build" >&5
-$as_echo "$as_me: error: changes in the environment can compromise the build" >&2;}
- as_fn_error $? "run \`make distclean' and/or \`rm $cache_file' and start over" "$LINENO" 5
-fi
-## Main body of script. ##
-ac_ext=c
-ac_cpp='$CPP $CPPFLAGS'
-ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_c_compiler_gnu
-ac_aux_dir=
-for ac_dir in config "$srcdir"/config; do
- if test -f "$ac_dir/install-sh"; then
- ac_aux_dir=$ac_dir
- ac_install_sh="$ac_aux_dir/install-sh -c"
- break
- elif test -f "$ac_dir/install.sh"; then
- ac_install_sh="$ac_aux_dir/install.sh -c"
- break
- elif test -f "$ac_dir/shtool"; then
- ac_install_sh="$ac_aux_dir/shtool install -c"
- break
- fi
-done
-if test -z "$ac_aux_dir"; then
- as_fn_error $? "cannot find install-sh, install.sh, or shtool in config \"$srcdir\"/config" "$LINENO" 5
-fi
-# These three variables are undocumented and unsupported,
-# and are intended to be withdrawn in a future Autoconf release.
-# They can cause serious problems if a builder's source tree is in a directory
-# whose full name contains unusual characters.
-ac_config_guess="$SHELL $ac_aux_dir/config.guess" # Please don't use this var.
-ac_config_sub="$SHELL $ac_aux_dir/config.sub" # Please don't use this var.
-ac_configure="$SHELL $ac_aux_dir/configure" # Please don't use this var.
-#AC_CONFIG_HEADERS([config.h])
-am__api_version='1.11'
-# Find a good install program. We prefer a C program (faster),
-# so one script is as good as another. But avoid the broken or
-# incompatible versions:
-# SysV /etc/install, /usr/sbin/install
-# SunOS /usr/etc/install
-# IRIX /sbin/install
-# AIX /bin/install
-# AmigaOS /C/install, which installs bootblocks on floppy discs
-# AIX 4 /usr/bin/installbsd, which doesn't work without a -g flag
-# AFS /usr/afsws/bin/install, which mishandles nonexistent args
-# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
-# OS/2's system install, which has a completely different semantic
-# ./install, which can be erroneously created by make from ./install.sh.
-# Reject install programs that cannot install multiple files.
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for a BSD-compatible install" >&5
-$as_echo_n "checking for a BSD-compatible install... " >&6; }
-if test -z "$INSTALL"; then
-if ${ac_cv_path_install+:} false; then :
-else
-do
- IFS=$as_save_IFS
- # Account for people who put trailing slashes in PATH elements.
-case $as_dir/ in #((
- ./ | .// | /[cC]/* | \
- /etc/* | /usr/sbin/* | /usr/etc/* | /sbin/* | /usr/afsws/bin/* | \
- ?:[\\/]os2[\\/]install[\\/]* | ?:[\\/]OS2[\\/]INSTALL[\\/]* | \
- /usr/ucb/* ) ;;
- # OSF1 and SCO ODT 3.0 have their own names for install.
- # Don't use installbsd from OSF since it installs stuff as root
- # by default.
- for ac_prog in ginstall scoinst install; do
- for ac_exec_ext in '' $ac_executable_extensions; do
- if { test -f "$as_dir/$ac_prog$ac_exec_ext" && $as_test_x "$as_dir/$ac_prog$ac_exec_ext"; }; then
- if test $ac_prog = install &&
- grep dspmsg "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
- # AIX install. It has an incompatible calling convention.
- elif test $ac_prog = install &&
- grep pwplus "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
- # program-specific install script used by HP pwplus--don't use.
- else
- rm -rf conftest.one conftest.two conftest.dir
- echo one > conftest.one
- echo two > conftest.two
- mkdir conftest.dir
- if "$as_dir/$ac_prog$ac_exec_ext" -c conftest.one conftest.two "`pwd`/conftest.dir" &&
- test -s conftest.one && test -s conftest.two &&
- test -s conftest.dir/conftest.one &&
- test -s conftest.dir/conftest.two
- then
- ac_cv_path_install="$as_dir/$ac_prog$ac_exec_ext -c"
- break 3
- fi
- fi
- fi
- done
- done
-esac
- done
-IFS=$as_save_IFS
-rm -rf conftest.one conftest.two conftest.dir
-fi
- if test "${ac_cv_path_install+set}" = set; then
- INSTALL=$ac_cv_path_install
- else
- # As a last resort, use the slow shell script. Don't cache a
- # value for INSTALL within a source directory, because that will
- # break other packages using the cache if that directory is
- # removed, or if the value is a relative name.
- INSTALL=$ac_install_sh
- fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $INSTALL" >&5
-$as_echo "$INSTALL" >&6; }
-# Use test -z because SunOS4 sh mishandles braces in ${var-val}.
-# It thinks the first close brace ends the variable substitution.
-test -z "$INSTALL_PROGRAM" && INSTALL_PROGRAM='${INSTALL}'
-test -z "$INSTALL_SCRIPT" && INSTALL_SCRIPT='${INSTALL}'
-test -z "$INSTALL_DATA" && INSTALL_DATA='${INSTALL} -m 644'
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether build environment is sane" >&5
-$as_echo_n "checking whether build environment is sane... " >&6; }
-# Just in case
-sleep 1
-echo timestamp > conftest.file
-# Reject unsafe characters in $srcdir or the absolute working directory
-# name. Accept space and tab only in the latter.
-am_lf='
-case `pwd` in
- *[\\\"\#\$\&\'\`$am_lf]*)
- as_fn_error $? "unsafe absolute working directory name" "$LINENO" 5;;
-esac
-case $srcdir in
- *[\\\"\#\$\&\'\`$am_lf\ \ ]*)
- as_fn_error $? "unsafe srcdir value: \`$srcdir'" "$LINENO" 5;;
-esac
-# Do `set' in a subshell so we don't clobber the current shell's
-# arguments. Must try -L first in case configure is actually a
-# symlink; some systems play weird games with the mod time of symlinks
-# (eg FreeBSD returns the mod time of the symlink's containing
-# directory).
-if (
- set X `ls -Lt "$srcdir/configure" conftest.file 2> /dev/null`
- if test "$*" = "X"; then
- # -L didn't work.
- set X `ls -t "$srcdir/configure" conftest.file`
- fi
- rm -f conftest.file
- if test "$*" != "X $srcdir/configure conftest.file" \
- && test "$*" != "X conftest.file $srcdir/configure"; then
- # If neither matched, then we have a broken ls. This can happen
- # if, for instance, CONFIG_SHELL is bash and it inherits a
- # broken ls alias from the environment. This has actually
- # happened. Such a system could not be considered "sane".
- as_fn_error $? "ls -t appears to fail. Make sure there is not a broken
-alias in your environment" "$LINENO" 5
- fi
- test "$2" = conftest.file
-then
- # Ok.
-else
- as_fn_error $? "newly created file is older than distributed files!
-Check your system clock" "$LINENO" 5
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
-$as_echo "yes" >&6; }
-test "$program_prefix" != NONE &&
- program_transform_name="s&^&$program_prefix&;$program_transform_name"
-# Use a double $ so make ignores it.
-test "$program_suffix" != NONE &&
- program_transform_name="s&\$&$program_suffix&;$program_transform_name"
-# Double any \ or $.
-# By default was `s,x,x', remove it if useless.
-ac_script='s/[\\$]/&&/g;s/;s,x,x,$//'
-program_transform_name=`$as_echo "$program_transform_name" | sed "$ac_script"`
-# expand $ac_aux_dir to an absolute path
-am_aux_dir=`cd $ac_aux_dir && pwd`
-if test x"${MISSING+set}" != xset; then
- case $am_aux_dir in
- MISSING="\${SHELL} \"$am_aux_dir/missing\"" ;;
- MISSING="\${SHELL} $am_aux_dir/missing" ;;
- esac
-fi
-# Use eval to expand $SHELL
-if eval "$MISSING --run true"; then
- am_missing_run="$MISSING --run "
-else
- am_missing_run=
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: \`missing' script is too old or missing" >&5
-$as_echo "$as_me: WARNING: \`missing' script is too old or missing" >&2;}
-fi
-if test x"${install_sh}" != xset; then
- install_sh="\${SHELL} '$am_aux_dir/install-sh'" ;;
- install_sh="\${SHELL} $am_aux_dir/install-sh"
- esac
-fi
-# Installed binaries are usually stripped using `strip' when the user
-# run `make install-strip'. However `strip' might not be the right
-# tool to use in cross-compilation environments, therefore Automake
-# will honor the `STRIP' environment variable to overrule this program.
-if test "$cross_compiling" != no; then
- if test -n "$ac_tool_prefix"; then
- # Extract the first word of "${ac_tool_prefix}strip", so it can be a program name with args.
-set dummy ${ac_tool_prefix}strip; ac_word=$2
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $ac_word" >&5
-$as_echo_n "checking for $ac_word... " >&6; }
-if ${ac_cv_prog_STRIP+:} false; then :
-else
- if test -n "$STRIP"; then
- ac_cv_prog_STRIP="$STRIP" # Let the user override the test.
-else
-for as_dir in $PATH
-do
- IFS=$as_save_IFS
- test -z "$as_dir" && as_dir=.
- if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then
- ac_cv_prog_STRIP="${ac_tool_prefix}strip"
- $as_echo "$as_me:${as_lineno-$LINENO}: found $as_dir/$ac_word$ac_exec_ext" >&5
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-STRIP=$ac_cv_prog_STRIP
-if test -n "$STRIP"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $STRIP" >&5
-$as_echo "$STRIP" >&6; }
-else
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
-$as_echo "no" >&6; }
-fi
-fi
-if test -z "$ac_cv_prog_STRIP"; then
- ac_ct_STRIP=$STRIP
- # Extract the first word of "strip", so it can be a program name with args.
-set dummy strip; ac_word=$2
-if ${ac_cv_prog_ac_ct_STRIP+:} false; then :
-else
- if test -n "$ac_ct_STRIP"; then
- ac_cv_prog_ac_ct_STRIP="$ac_ct_STRIP" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_STRIP="strip"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-ac_ct_STRIP=$ac_cv_prog_ac_ct_STRIP
-if test -n "$ac_ct_STRIP"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_STRIP" >&5
-$as_echo "$ac_ct_STRIP" >&6; }
-else
-fi
- if test "x$ac_ct_STRIP" = x; then
- STRIP=":"
- else
- case $cross_compiling:$ac_tool_warned in
-yes:)
-{ $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: using cross tools not prefixed with host triplet" >&5
-$as_echo "$as_me: WARNING: using cross tools not prefixed with host triplet" >&2;}
-ac_tool_warned=yes ;;
-esac
- STRIP=$ac_ct_STRIP
- fi
-else
- STRIP="$ac_cv_prog_STRIP"
-fi
-fi
-INSTALL_STRIP_PROGRAM="\$(install_sh) -c -s"
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for a thread-safe mkdir -p" >&5
-$as_echo_n "checking for a thread-safe mkdir -p... " >&6; }
-if test -z "$MKDIR_P"; then
- if ${ac_cv_path_mkdir+:} false; then :
-else
- as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-for as_dir in $PATH$PATH_SEPARATOR/opt/sfw/bin
-do
- IFS=$as_save_IFS
- for ac_prog in mkdir gmkdir; do
- { test -f "$as_dir/$ac_prog$ac_exec_ext" && $as_test_x "$as_dir/$ac_prog$ac_exec_ext"; } || continue
- case `"$as_dir/$ac_prog$ac_exec_ext" --version 2>&1` in #(
- 'mkdir (GNU coreutils) '* | \
- 'mkdir (coreutils) '* | \
- 'mkdir (fileutils) '4.1*)
- ac_cv_path_mkdir=$as_dir/$ac_prog$ac_exec_ext
- break 3;;
- esac
- done
- done
- done
-IFS=$as_save_IFS
-fi
- test -d ./--version && rmdir ./--version
- if test "${ac_cv_path_mkdir+set}" = set; then
- MKDIR_P="$ac_cv_path_mkdir -p"
- else
- # value for MKDIR_P within a source directory, because that will
- MKDIR_P="$ac_install_sh -d"
- fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $MKDIR_P" >&5
-$as_echo "$MKDIR_P" >&6; }
-mkdir_p="$MKDIR_P"
-case $mkdir_p in
- */*) mkdir_p="\$(top_builddir)/$mkdir_p" ;;
-esac
-for ac_prog in gawk mawk nawk awk
-do
- # Extract the first word of "$ac_prog", so it can be a program name with args.
-set dummy $ac_prog; ac_word=$2
-if ${ac_cv_prog_AWK+:} false; then :
-else
- if test -n "$AWK"; then
- ac_cv_prog_AWK="$AWK" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_AWK="$ac_prog"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-AWK=$ac_cv_prog_AWK
-if test -n "$AWK"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $AWK" >&5
-$as_echo "$AWK" >&6; }
-else
-fi
- test -n "$AWK" && break
-done
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether ${MAKE-make} sets \$(MAKE)" >&5
-$as_echo_n "checking whether ${MAKE-make} sets \$(MAKE)... " >&6; }
-set x ${MAKE-make}
-ac_make=`$as_echo "$2" | sed 's/+/p/g; s/[^a-zA-Z0-9_]/_/g'`
-if eval \${ac_cv_prog_make_${ac_make}_set+:} false; then :
-else
- cat >conftest.make <<\_ACEOF
-SHELL = /bin/sh
-all:
- @echo '@@@%%%=$(MAKE)=@@@%%%'
-_ACEOF
-# GNU make sometimes prints "make[1]: Entering ...", which would confuse us.
-case `${MAKE-make} -f conftest.make 2>/dev/null` in
- eval ac_cv_prog_make_${ac_make}_set=yes;;
- eval ac_cv_prog_make_${ac_make}_set=no;;
-esac
-rm -f conftest.make
-fi
-if eval test \$ac_cv_prog_make_${ac_make}_set = yes; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
- SET_MAKE=
-else
- SET_MAKE="MAKE=${MAKE-make}"
-fi
-rm -rf .tst 2>/dev/null
-mkdir .tst 2>/dev/null
-if test -d .tst; then
- am__leading_dot=.
-else
- am__leading_dot=_
-fi
-rmdir .tst 2>/dev/null
-if test "`cd $srcdir && pwd`" != "`pwd`"; then
- # Use -I$(srcdir) only when $(srcdir) != ., so that make's output
- # is not polluted with repeated "-I."
- am__isrc=' -I$(srcdir)'
- # test to see if srcdir already configured
- if test -f $srcdir/config.status; then
- as_fn_error $? "source directory already configured; run \"make distclean\" there first" "$LINENO" 5
- fi
-fi
-# test whether we have cygpath
-if test -z "$CYGPATH_W"; then
- if (cygpath --version) >/dev/null 2>/dev/null; then
- CYGPATH_W='cygpath -w'
- else
- CYGPATH_W=echo
- fi
-fi
-# Define the identity of the package.
- PACKAGE='coaster-c-client'
- VERSION='1.0'
-#define PACKAGE "$PACKAGE"
-_ACEOF
-#define VERSION "$VERSION"
-_ACEOF
-# Some tools Automake needs.
-ACLOCAL=${ACLOCAL-"${am_missing_run}aclocal-${am__api_version}"}
-AUTOCONF=${AUTOCONF-"${am_missing_run}autoconf"}
-AUTOMAKE=${AUTOMAKE-"${am_missing_run}automake-${am__api_version}"}
-AUTOHEADER=${AUTOHEADER-"${am_missing_run}autoheader"}
-MAKEINFO=${MAKEINFO-"${am_missing_run}makeinfo"}
-# We need awk for the "check" target. The system "awk" is bad on
-# some platforms.
-# Always define AMTAR for backward compatibility. Yes, it's still used
-# in the wild :-( We should find a proper way to deprecate it ...
-AMTAR='$${TAR-tar}'
-am__tar='$${TAR-tar} chof - "$$tardir"' am__untar='$${TAR-tar} xf -'
-case `pwd` in
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: Libtool does not cope well with whitespace in \`pwd\`" >&5
-$as_echo "$as_me: WARNING: Libtool does not cope well with whitespace in \`pwd\`" >&2;} ;;
-esac
-macro_version='2.4.2'
-macro_revision='1.3337'
-ltmain="$ac_aux_dir/ltmain.sh"
-# Make sure we can run config.sub.
-$SHELL "$ac_aux_dir/config.sub" sun4 >/dev/null 2>&1 ||
- as_fn_error $? "cannot run $SHELL $ac_aux_dir/config.sub" "$LINENO" 5
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking build system type" >&5
-$as_echo_n "checking build system type... " >&6; }
-if ${ac_cv_build+:} false; then :
-else
- ac_build_alias=$build_alias
-test "x$ac_build_alias" = x &&
- ac_build_alias=`$SHELL "$ac_aux_dir/config.guess"`
- as_fn_error $? "cannot guess build type; you must specify one" "$LINENO" 5
-ac_cv_build=`$SHELL "$ac_aux_dir/config.sub" $ac_build_alias` ||
- as_fn_error $? "$SHELL $ac_aux_dir/config.sub $ac_build_alias failed" "$LINENO" 5
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_build" >&5
-$as_echo "$ac_cv_build" >&6; }
-case $ac_cv_build in
-*) as_fn_error $? "invalid value of canonical build" "$LINENO" 5;;
-esac
-build=$ac_cv_build
-ac_save_IFS=$IFS; IFS='-'
-set x $ac_cv_build
-shift
-build_cpu=$1
-build_vendor=$2
-shift; shift
-# Remember, the first character of IFS is used to create $*,
-# except with old shells:
-build_os=$*
-IFS=$ac_save_IFS
-case $build_os in *\ *) build_os=`echo "$build_os" | sed 's/ /-/g'`;; esac
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking host system type" >&5
-$as_echo_n "checking host system type... " >&6; }
-if ${ac_cv_host+:} false; then :
-else
- if test "x$host_alias" = x; then
- ac_cv_host=$ac_cv_build
-else
- ac_cv_host=`$SHELL "$ac_aux_dir/config.sub" $host_alias` ||
- as_fn_error $? "$SHELL $ac_aux_dir/config.sub $host_alias failed" "$LINENO" 5
-fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_host" >&5
-$as_echo "$ac_cv_host" >&6; }
-case $ac_cv_host in
-*) as_fn_error $? "invalid value of canonical host" "$LINENO" 5;;
-esac
-host=$ac_cv_host
-set x $ac_cv_host
-shift
-host_cpu=$1
-host_vendor=$2
-shift; shift
-host_os=$*
-IFS=$ac_save_IFS
-case $host_os in *\ *) host_os=`echo "$host_os" | sed 's/ /-/g'`;; esac
-# Backslashify metacharacters that are still active within
-# double-quoted strings.
-sed_quote_subst='s/\(["`$\\]\)/\\\1/g'
-# Same as above, but do not quote variable references.
-double_quote_subst='s/\(["`\\]\)/\\\1/g'
-# Sed substitution to delay expansion of an escaped shell variable in a
-# double_quote_subst'ed string.
-delay_variable_subst='s/\\\\\\\\\\\$/\\\\\\$/g'
-# Sed substitution to delay expansion of an escaped single quote.
-delay_single_quote_subst='s/'\''/'\'\\\\\\\'\''/g'
-# Sed substitution to avoid accidental globbing in evaled expressions
-no_glob_subst='s/\*/\\\*/g'
-ECHO='\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'
-ECHO=$ECHO$ECHO$ECHO$ECHO$ECHO
-ECHO=$ECHO$ECHO$ECHO$ECHO$ECHO$ECHO
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to print strings" >&5
-$as_echo_n "checking how to print strings... " >&6; }
-# Test print first, because it will be a builtin if present.
-if test "X`( print -r -- -n ) 2>/dev/null`" = X-n && \
- test "X`print -r -- $ECHO 2>/dev/null`" = "X$ECHO"; then
- ECHO='print -r --'
-elif test "X`printf %s $ECHO 2>/dev/null`" = "X$ECHO"; then
- ECHO='printf %s\n'
-else
- # Use this function as a fallback that always works.
- func_fallback_echo ()
- eval 'cat <<_LTECHO_EOF
-$1
-_LTECHO_EOF'
- ECHO='func_fallback_echo'
-fi
-# func_echo_all arg...
-# Invoke $ECHO with all args, space-separated.
-func_echo_all ()
- $ECHO ""
-case "$ECHO" in
- printf*) { $as_echo "$as_me:${as_lineno-$LINENO}: result: printf" >&5
-$as_echo "printf" >&6; } ;;
- print*) { $as_echo "$as_me:${as_lineno-$LINENO}: result: print -r" >&5
-$as_echo "print -r" >&6; } ;;
- *) { $as_echo "$as_me:${as_lineno-$LINENO}: result: cat" >&5
-$as_echo "cat" >&6; } ;;
-esac
-DEPDIR="${am__leading_dot}deps"
-ac_config_commands="$ac_config_commands depfiles"
-am_make=${MAKE-make}
-cat > confinc << 'END'
-am__doit:
- @echo this is the am__doit target
-.PHONY: am__doit
-END
-# If we don't find an include directive, just comment out the code.
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for style of include used by $am_make" >&5
-$as_echo_n "checking for style of include used by $am_make... " >&6; }
-am__include="#"
-am__quote=
-_am_result=none
-# First try GNU make style include.
-echo "include confinc" > confmf
-# Ignore all kinds of additional output from `make'.
-case `$am_make -s -f confmf 2> /dev/null` in #(
-*the\ am__doit\ target*)
- am__include=include
- am__quote=
- _am_result=GNU
-esac
-# Now try BSD make style include.
-if test "$am__include" = "#"; then
- echo '.include "confinc"' > confmf
- case `$am_make -s -f confmf 2> /dev/null` in #(
- *the\ am__doit\ target*)
- am__include=.include
- am__quote="\""
- _am_result=BSD
- esac
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $_am_result" >&5
-$as_echo "$_am_result" >&6; }
-rm -f confinc confmf
-# Check whether --enable-dependency-tracking was given.
-if test "${enable_dependency_tracking+set}" = set; then :
- enableval=$enable_dependency_tracking;
-fi
-if test "x$enable_dependency_tracking" != xno; then
- am_depcomp="$ac_aux_dir/depcomp"
- AMDEPBACKSLASH='\'
- am__nodep='_no'
-fi
- if test "x$enable_dependency_tracking" != xno; then
- AMDEP_TRUE=
- AMDEP_FALSE='#'
-else
- AMDEP_TRUE='#'
- AMDEP_FALSE=
-fi
-ac_ext=c
-if test -n "$ac_tool_prefix"; then
- # Extract the first word of "${ac_tool_prefix}gcc", so it can be a program name with args.
-set dummy ${ac_tool_prefix}gcc; ac_word=$2
-if ${ac_cv_prog_CC+:} false; then :
-else
- if test -n "$CC"; then
- ac_cv_prog_CC="$CC" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_CC="${ac_tool_prefix}gcc"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-CC=$ac_cv_prog_CC
-if test -n "$CC"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $CC" >&5
-$as_echo "$CC" >&6; }
-else
-fi
-fi
-if test -z "$ac_cv_prog_CC"; then
- ac_ct_CC=$CC
- # Extract the first word of "gcc", so it can be a program name with args.
-set dummy gcc; ac_word=$2
-if ${ac_cv_prog_ac_ct_CC+:} false; then :
-else
- if test -n "$ac_ct_CC"; then
- ac_cv_prog_ac_ct_CC="$ac_ct_CC" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_CC="gcc"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-ac_ct_CC=$ac_cv_prog_ac_ct_CC
-if test -n "$ac_ct_CC"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_CC" >&5
-$as_echo "$ac_ct_CC" >&6; }
-else
-fi
- if test "x$ac_ct_CC" = x; then
- CC=""
- else
-yes:)
-esac
- CC=$ac_ct_CC
- fi
-else
- CC="$ac_cv_prog_CC"
-fi
-if test -z "$CC"; then
- # Extract the first word of "${ac_tool_prefix}cc", so it can be a program name with args.
-set dummy ${ac_tool_prefix}cc; ac_word=$2
-else
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_CC="${ac_tool_prefix}cc"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-CC=$ac_cv_prog_CC
-else
-fi
- fi
-fi
- # Extract the first word of "cc", so it can be a program name with args.
-set dummy cc; ac_word=$2
-else
-else
- ac_prog_rejected=no
-do
- IFS=$as_save_IFS
- if test "$as_dir/$ac_word$ac_exec_ext" = "/usr/ucb/cc"; then
- ac_prog_rejected=yes
- continue
- fi
- ac_cv_prog_CC="cc"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-if test $ac_prog_rejected = yes; then
- # We found a bogon in the path, so make sure we never use it.
- set dummy $ac_cv_prog_CC
- shift
- if test $# != 0; then
- # We chose a different compiler from the bogus one.
- # However, it has the same basename, so the bogon will be chosen
- # first if we set CC to just the basename; use the full file name.
- shift
- ac_cv_prog_CC="$as_dir/$ac_word${1+' '}$@"
- fi
-fi
-fi
-fi
-CC=$ac_cv_prog_CC
-else
-fi
-fi
- for ac_prog in cl.exe
- do
- # Extract the first word of "$ac_tool_prefix$ac_prog", so it can be a program name with args.
-set dummy $ac_tool_prefix$ac_prog; ac_word=$2
-else
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_CC="$ac_tool_prefix$ac_prog"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-CC=$ac_cv_prog_CC
-else
-fi
- test -n "$CC" && break
- done
-fi
- ac_ct_CC=$CC
-do
-else
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_CC="$ac_prog"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-else
-fi
- test -n "$ac_ct_CC" && break
-done
- CC=""
- else
-yes:)
-esac
- CC=$ac_ct_CC
- fi
-fi
-fi
-test -z "$CC" && { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
-as_fn_error $? "no acceptable C compiler found in \$PATH
-# Provide some information about the compiler.
-$as_echo "$as_me:${as_lineno-$LINENO}: checking for C compiler version" >&5
-set X $ac_compile
-ac_compiler=$2
-for ac_option in --version -v -V -qversion; do
- { { ac_try="$ac_compiler $ac_option >&5"
-esac
- (eval "$ac_compiler $ac_option >&5") 2>conftest.err
- ac_status=$?
- sed '10a\
-... rest of stderr output deleted ...
- 10q' conftest.err >conftest.er1
- fi
- rm -f conftest.er1 conftest.err
-done
-int
-main ()
- return 0;
-_ACEOF
-ac_clean_files_save=$ac_clean_files
-ac_clean_files="$ac_clean_files a.out a.out.dSYM a.exe b.out"
-# Try to create an executable without -o first, disregard a.out.
-# It will help us diagnose broken compilers, and finding out an intuition
-# of exeext.
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the C compiler works" >&5
-$as_echo_n "checking whether the C compiler works... " >&6; }
-ac_link_default=`$as_echo "$ac_link" | sed 's/ -o *conftest[^ ]*//'`
-# The possible output files:
-ac_files="a.out conftest.exe conftest a.exe a_out.exe b.out conftest.*"
-ac_rmfiles=
-for ac_file in $ac_files
-do
- case $ac_file in
- *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.map | *.inf | *.dSYM | *.o | *.obj ) ;;
- * ) ac_rmfiles="$ac_rmfiles $ac_file";;
- esac
-done
-rm -f $ac_rmfiles
-if { { ac_try="$ac_link_default"
-esac
- (eval "$ac_link_default") 2>&5
- ac_status=$?
- test $ac_status = 0; }; then :
- # Autoconf-2.13 could set the ac_cv_exeext variable to `no'.
-# So ignore a value of `no', otherwise this would lead to `EXEEXT = no'
-# in a Makefile. We should not override ac_cv_exeext if it was cached,
-# so that the user can short-circuit this test for compilers unknown to
-# Autoconf.
-for ac_file in $ac_files ''
-do
- test -f "$ac_file" || continue
- case $ac_file in
- [ab].out )
- # We found the default executable, but exeext='' is most
- # certainly right.
- break;;
- if test "${ac_cv_exeext+set}" = set && test "$ac_cv_exeext" != no;
- then :; else
- ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
- fi
- # We set ac_cv_exeext here because the later test for it is not
- # safe: cross compilers may not add the suffix if given an `-o'
- # argument, so we may need to know it at that point already.
- # Even if this section looks crufty: it has the advantage of
- # actually working.
- break;;
- break;;
- esac
-done
-test "$ac_cv_exeext" = no && ac_cv_exeext=
-else
- ac_file=''
-fi
-if test -z "$ac_file"; then :
-$as_echo "$as_me: failed program was:" >&5
-{ { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
-as_fn_error 77 "C compiler cannot create executables
-else
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for C compiler default output file name" >&5
-$as_echo_n "checking for C compiler default output file name... " >&6; }
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_file" >&5
-$as_echo "$ac_file" >&6; }
-ac_exeext=$ac_cv_exeext
-rm -f -r a.out a.out.dSYM a.exe conftest$ac_cv_exeext b.out
-ac_clean_files=$ac_clean_files_save
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for suffix of executables" >&5
-$as_echo_n "checking for suffix of executables... " >&6; }
-if { { ac_try="$ac_link"
-esac
- ac_status=$?
- # If both `conftest.exe' and `conftest' are `present' (well, observable)
-# catch `conftest.exe'. For instance with Cygwin, `ls conftest' will
-# work properly (i.e., refer to `conftest.exe'), while it won't with
-# `rm'.
-for ac_file in conftest.exe conftest conftest.*; do
- case $ac_file in
- *.* ) ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
- break;;
- * ) break;;
- esac
-done
-else
- { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
-as_fn_error $? "cannot compute suffix of executables: cannot compile and link
-fi
-rm -f conftest conftest$ac_cv_exeext
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_exeext" >&5
-$as_echo "$ac_cv_exeext" >&6; }
-rm -f conftest.$ac_ext
-EXEEXT=$ac_cv_exeext
-ac_exeext=$EXEEXT
-#include <stdio.h>
-int
-main ()
-FILE *f = fopen ("conftest.out", "w");
- return ferror (f) || fclose (f) != 0;
- return 0;
-_ACEOF
-ac_clean_files="$ac_clean_files conftest.out"
-# Check that the compiler produces executables we can run. If not, either
-# the compiler is broken, or we cross compile.
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are cross compiling" >&5
-$as_echo_n "checking whether we are cross compiling... " >&6; }
-if test "$cross_compiling" != yes; then
- { { ac_try="$ac_link"
-esac
- ac_status=$?
- if { ac_try='./conftest$ac_cv_exeext'
-esac
- ac_status=$?
- cross_compiling=no
- else
- if test "$cross_compiling" = maybe; then
- else
-as_fn_error $? "cannot run C compiled programs.
-If you meant to cross compile, use \`--host'.
- fi
- fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $cross_compiling" >&5
-$as_echo "$cross_compiling" >&6; }
-rm -f conftest.$ac_ext conftest$ac_cv_exeext conftest.out
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for suffix of object files" >&5
-$as_echo_n "checking for suffix of object files... " >&6; }
-if ${ac_cv_objext+:} false; then :
-else
-int
-main ()
- return 0;
-_ACEOF
-rm -f conftest.o conftest.obj
-if { { ac_try="$ac_compile"
-esac
- (eval "$ac_compile") 2>&5
- ac_status=$?
- for ac_file in conftest.o conftest.obj conftest.*; do
- test -f "$ac_file" || continue;
- case $ac_file in
- *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.map | *.inf | *.dSYM ) ;;
- *) ac_cv_objext=`expr "$ac_file" : '.*\.\(.*\)'`
- break;;
- esac
-done
-else
-as_fn_error $? "cannot compute suffix of object files: cannot compile
-fi
-rm -f conftest.$ac_cv_objext conftest.$ac_ext
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_objext" >&5
-$as_echo "$ac_cv_objext" >&6; }
-OBJEXT=$ac_cv_objext
-ac_objext=$OBJEXT
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are using the GNU C compiler" >&5
-$as_echo_n "checking whether we are using the GNU C compiler... " >&6; }
-if ${ac_cv_c_compiler_gnu+:} false; then :
-else
-int
-main ()
-#ifndef __GNUC__
- choke me
-#endif
- return 0;
-_ACEOF
- ac_compiler_gnu=yes
-else
- ac_compiler_gnu=no
-fi
-ac_cv_c_compiler_gnu=$ac_compiler_gnu
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_c_compiler_gnu" >&5
-$as_echo "$ac_cv_c_compiler_gnu" >&6; }
-if test $ac_compiler_gnu = yes; then
- GCC=yes
-else
- GCC=
-fi
-ac_test_CFLAGS=${CFLAGS+set}
-ac_save_CFLAGS=$CFLAGS
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether $CC accepts -g" >&5
-$as_echo_n "checking whether $CC accepts -g... " >&6; }
-if ${ac_cv_prog_cc_g+:} false; then :
-else
- ac_save_c_werror_flag=$ac_c_werror_flag
- ac_c_werror_flag=yes
- ac_cv_prog_cc_g=no
- CFLAGS="-g"
-int
-main ()
- return 0;
-_ACEOF
- ac_cv_prog_cc_g=yes
-else
- CFLAGS=""
-int
-main ()
- return 0;
-_ACEOF
-else
- ac_c_werror_flag=$ac_save_c_werror_flag
- CFLAGS="-g"
-int
-main ()
- return 0;
-_ACEOF
-fi
-fi
-fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_cc_g" >&5
-$as_echo "$ac_cv_prog_cc_g" >&6; }
-if test "$ac_test_CFLAGS" = set; then
- CFLAGS=$ac_save_CFLAGS
-elif test $ac_cv_prog_cc_g = yes; then
- if test "$GCC" = yes; then
- CFLAGS="-g -O2"
- else
- CFLAGS="-g"
- fi
-else
- CFLAGS="-O2"
- else
- CFLAGS=
- fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $CC option to accept ISO C89" >&5
-$as_echo_n "checking for $CC option to accept ISO C89... " >&6; }
-if ${ac_cv_prog_cc_c89+:} false; then :
-else
- ac_cv_prog_cc_c89=no
-ac_save_CC=$CC
-#include <stdarg.h>
-#include <stdio.h>
-#include <sys/types.h>
-#include <sys/stat.h>
-/* Most of the following tests are stolen from RCS 5.7's src/conf.sh. */
-struct buf { int x; };
-FILE * (*rcsopen) (struct buf *, struct stat *, int);
-static char *e (p, i)
- char **p;
- int i;
- return p[i];
-static char *f (char * (*g) (char **, int), char **p, ...)
- char *s;
- va_list v;
- va_start (v,p);
- s = g (p, va_arg (v,int));
- va_end (v);
- return s;
-/* OSF 4.0 Compaq cc is some sort of almost-ANSI by default. It has
- function prototypes and stuff, but not '\xHH' hex character constants.
- These don't provoke an error unfortunately, instead are silently treated
- as 'x'. The following induces an error, until -std is added to get
- proper ANSI mode. Curiously '\x00'!='x' always comes out true, for an
- array size at least. It's necessary to write '\x00'==0 to get something
- that's true only with -std. */
-int osf4_cc_array ['\x00' == 0 ? 1 : -1];
-/* IBM C 6 for AIX is almost-ANSI by default, but it replaces macro parameters
- inside strings and character constants. */
-#define FOO(x) 'x'
-int xlc6_cc_array[FOO(a) == 'x' ? 1 : -1];
-int test (int i, double x);
-struct s1 {int (*f) (int a);};
-struct s2 {int (*f) (double a);};
-int pairnames (int, char **, FILE *(*)(struct buf *, struct stat *, int), int, int);
-int argc;
-char **argv;
-int
-main ()
-return f (e, argv, 0) != argv[0] || f (e, argv, 1) != argv[1];
- return 0;
-_ACEOF
-for ac_arg in '' -qlanglvl=extc89 -qlanglvl=ansi -std \
- -Ae "-Aa -D_HPUX_SOURCE" "-Xc -D__EXTENSIONS__"
-do
- CC="$ac_save_CC $ac_arg"
- if ac_fn_c_try_compile "$LINENO"; then :
- ac_cv_prog_cc_c89=$ac_arg
-fi
- test "x$ac_cv_prog_cc_c89" != "xno" && break
-done
-CC=$ac_save_CC
-fi
-# AC_CACHE_VAL
-case "x$ac_cv_prog_cc_c89" in
- x)
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: none needed" >&5
-$as_echo "none needed" >&6; } ;;
- xno)
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: unsupported" >&5
-$as_echo "unsupported" >&6; } ;;
- CC="$CC $ac_cv_prog_cc_c89"
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_cc_c89" >&5
-$as_echo "$ac_cv_prog_cc_c89" >&6; } ;;
-esac
-if test "x$ac_cv_prog_cc_c89" != xno; then :
-fi
-ac_ext=c
-depcc="$CC" am_compiler_list=
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking dependency style of $depcc" >&5
-$as_echo_n "checking dependency style of $depcc... " >&6; }
-if ${am_cv_CC_dependencies_compiler_type+:} false; then :
-else
- if test -z "$AMDEP_TRUE" && test -f "$am_depcomp"; then
- # We make a subdir and do the tests there. Otherwise we can end up
- # making bogus files that we don't know about and never remove. For
- # instance it was reported that on HP-UX the gcc test will end up
- # making a dummy file named `D' -- because `-MD' means `put the output
- # in D'.
- rm -rf conftest.dir
- # Copy depcomp to subdir because otherwise we won't find it if we're
- # using a relative directory.
- cp "$am_depcomp" conftest.dir
- cd conftest.dir
- # We will build objects and dependencies in a subdirectory because
- # it helps to detect inapplicable dependency modes. For instance
- # both Tru64's cc and ICC support -MD to output dependencies as a
- # side effect of compilation, but ICC will put the dependencies in
- # the current directory while Tru64 will put them in the object
- # directory.
- mkdir sub
- am_cv_CC_dependencies_compiler_type=none
- if test "$am_compiler_list" = ""; then
- am_compiler_list=`sed -n 's/^#*\([a-zA-Z0-9]*\))$/\1/p' < ./depcomp`
- fi
- am__universal=false
- case " $depcc " in #(
- *\ -arch\ *\ -arch\ *) am__universal=true ;;
- esac
- for depmode in $am_compiler_list; do
- # Setup a source with many dependencies, because some compilers
- # like to wrap large dependency lists on column 80 (with \), and
- # we should not choose a depcomp mode which is confused by this.
- # We need to recreate these files for each test, as the compiler may
- # overwrite some of them when testing with obscure command lines.
- # This happens at least with the AIX C compiler.
- : > sub/conftest.c
- for i in 1 2 3 4 5 6; do
- echo '#include "conftst'$i'.h"' >> sub/conftest.c
- # Using `: > sub/conftst$i.h' creates only sub/conftst1.h with
- # Solaris 8's {/usr,}/bin/sh.
- touch sub/conftst$i.h
- done
- echo "${am__include} ${am__quote}sub/conftest.Po${am__quote}" > confmf
- # We check with `-c' and `-o' for the sake of the "dashmstdout"
- # mode. It turns out that the SunPro C++ compiler does not properly
- # handle `-M -o', and we need to detect this. Also, some Intel
- # versions had trouble with output in subdirs
- am__obj=sub/conftest.${OBJEXT-o}
- am__minus_obj="-o $am__obj"
- case $depmode in
- gcc)
- # This depmode causes a compiler race in universal mode.
- test "$am__universal" = false || continue
- nosideeffect)
- # after this tag, mechanisms are not by side-effect, so they'll
- # only be used when explicitly requested
- if test "x$enable_dependency_tracking" = xyes; then
- continue
- else
- break
- fi
- msvc7 | msvc7msys | msvisualcpp | msvcmsys)
- # This compiler won't grok `-c -o', but also, the minuso test has
- # not run yet. These depmodes are late enough in the game, and
- # so weak that their functioning should not be impacted.
- am__obj=conftest.${OBJEXT-o}
- am__minus_obj=
- none) break ;;
- esac
- if depmode=$depmode \
- source=sub/conftest.c object=$am__obj \
- depfile=sub/conftest.Po tmpdepfile=sub/conftest.TPo \
- $SHELL ./depcomp $depcc -c $am__minus_obj sub/conftest.c \
- >/dev/null 2>conftest.err &&
- grep sub/conftst1.h sub/conftest.Po > /dev/null 2>&1 &&
- grep sub/conftst6.h sub/conftest.Po > /dev/null 2>&1 &&
- grep $am__obj sub/conftest.Po > /dev/null 2>&1 &&
- ${MAKE-make} -s -f confmf > /dev/null 2>&1; then
- # icc doesn't choke on unknown options, it will just issue warnings
- # or remarks (even with -Werror). So we grep stderr for any message
- # that says an option was ignored or not supported.
- # When given -MP, icc 7.0 and 7.1 complain thusly:
- # icc: Command line warning: ignoring option '-M'; no argument required
- # The diagnosis changed in icc 8.0:
- # icc: Command line remark: option '-MP' not supported
- if (grep 'ignoring option' conftest.err ||
- grep 'not supported' conftest.err) >/dev/null 2>&1; then :; else
- am_cv_CC_dependencies_compiler_type=$depmode
- break
- fi
- fi
- done
- cd ..
-else
-fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $am_cv_CC_dependencies_compiler_type" >&5
-$as_echo "$am_cv_CC_dependencies_compiler_type" >&6; }
-CCDEPMODE=depmode=$am_cv_CC_dependencies_compiler_type
- if
- test "x$enable_dependency_tracking" != xno \
- && test "$am_cv_CC_dependencies_compiler_type" = gcc3; then
- am__fastdepCC_TRUE=
- am__fastdepCC_FALSE='#'
-else
- am__fastdepCC_TRUE='#'
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for a sed that does not truncate output" >&5
-$as_echo_n "checking for a sed that does not truncate output... " >&6; }
-if ${ac_cv_path_SED+:} false; then :
-else
- ac_script=s/aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa/bbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbb/
- for ac_i in 1 2 3 4 5 6 7; do
- ac_script="$ac_script$as_nl$ac_script"
- done
- echo "$ac_script" 2>/dev/null | sed 99q >conftest.sed
- { ac_script=; unset ac_script;}
- if test -z "$SED"; then
- ac_path_SED_found=false
- # Loop through the user's path and test for each of PROGNAME-LIST
-do
- IFS=$as_save_IFS
- for ac_prog in sed gsed; do
- ac_path_SED="$as_dir/$ac_prog$ac_exec_ext"
- { test -f "$ac_path_SED" && $as_test_x "$ac_path_SED"; } || continue
-# Check for GNU ac_path_SED and select it if it is found.
- # Check for GNU $ac_path_SED
-case `"$ac_path_SED" --version 2>&1` in
-*GNU*)
- ac_cv_path_SED="$ac_path_SED" ac_path_SED_found=:;;
- ac_count=0
- $as_echo_n 0123456789 >"conftest.in"
- while :
- do
- cat "conftest.in" "conftest.in" >"conftest.tmp"
- mv "conftest.tmp" "conftest.in"
- cp "conftest.in" "conftest.nl"
- $as_echo '' >> "conftest.nl"
- "$ac_path_SED" -f conftest.sed < "conftest.nl" >"conftest.out" 2>/dev/null || break
- diff "conftest.out" "conftest.nl" >/dev/null 2>&1 || break
- as_fn_arith $ac_count + 1 && ac_count=$as_val
- if test $ac_count -gt ${ac_path_SED_max-0}; then
- # Best one so far, save it but keep looking for a better one
- ac_path_SED_max=$ac_count
- fi
- # 10*(2^10) chars as input seems more than enough
- test $ac_count -gt 10 && break
- done
- rm -f conftest.in conftest.tmp conftest.nl conftest.out;;
-esac
- $ac_path_SED_found && break 3
- done
- done
- done
-IFS=$as_save_IFS
- if test -z "$ac_cv_path_SED"; then
- as_fn_error $? "no acceptable sed could be found in \$PATH" "$LINENO" 5
- fi
-else
- ac_cv_path_SED=$SED
-fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_path_SED" >&5
-$as_echo "$ac_cv_path_SED" >&6; }
- SED="$ac_cv_path_SED"
- rm -f conftest.sed
-test -z "$SED" && SED=sed
-Xsed="$SED -e 1s/^X//"
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for grep that handles long lines and -e" >&5
-$as_echo_n "checking for grep that handles long lines and -e... " >&6; }
-if ${ac_cv_path_GREP+:} false; then :
-else
- if test -z "$GREP"; then
- ac_path_GREP_found=false
-for as_dir in $PATH$PATH_SEPARATOR/usr/xpg4/bin
-do
- IFS=$as_save_IFS
- for ac_prog in grep ggrep; do
- ac_path_GREP="$as_dir/$ac_prog$ac_exec_ext"
- { test -f "$ac_path_GREP" && $as_test_x "$ac_path_GREP"; } || continue
-# Check for GNU ac_path_GREP and select it if it is found.
- # Check for GNU $ac_path_GREP
-case `"$ac_path_GREP" --version 2>&1` in
-*GNU*)
- ac_cv_path_GREP="$ac_path_GREP" ac_path_GREP_found=:;;
- ac_count=0
- while :
- do
- $as_echo 'GREP' >> "conftest.nl"
- "$ac_path_GREP" -e 'GREP$' -e '-(cannot match)-' < "conftest.nl" >"conftest.out" 2>/dev/null || break
- if test $ac_count -gt ${ac_path_GREP_max-0}; then
- ac_path_GREP_max=$ac_count
- fi
- done
-esac
- $ac_path_GREP_found && break 3
- done
- done
- done
-IFS=$as_save_IFS
- if test -z "$ac_cv_path_GREP"; then
- as_fn_error $? "no acceptable grep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" "$LINENO" 5
- fi
-else
- ac_cv_path_GREP=$GREP
-fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_path_GREP" >&5
-$as_echo "$ac_cv_path_GREP" >&6; }
- GREP="$ac_cv_path_GREP"
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for egrep" >&5
-$as_echo_n "checking for egrep... " >&6; }
-if ${ac_cv_path_EGREP+:} false; then :
-else
- if echo a | $GREP -E '(a|b)' >/dev/null 2>&1
- then ac_cv_path_EGREP="$GREP -E"
- else
- if test -z "$EGREP"; then
- ac_path_EGREP_found=false
-do
- IFS=$as_save_IFS
- for ac_prog in egrep; do
- ac_path_EGREP="$as_dir/$ac_prog$ac_exec_ext"
- { test -f "$ac_path_EGREP" && $as_test_x "$ac_path_EGREP"; } || continue
-# Check for GNU ac_path_EGREP and select it if it is found.
- # Check for GNU $ac_path_EGREP
-case `"$ac_path_EGREP" --version 2>&1` in
-*GNU*)
- ac_cv_path_EGREP="$ac_path_EGREP" ac_path_EGREP_found=:;;
- ac_count=0
- while :
- do
- $as_echo 'EGREP' >> "conftest.nl"
- "$ac_path_EGREP" 'EGREP$' < "conftest.nl" >"conftest.out" 2>/dev/null || break
- if test $ac_count -gt ${ac_path_EGREP_max-0}; then
- ac_path_EGREP_max=$ac_count
- fi
- done
-esac
- $ac_path_EGREP_found && break 3
- done
- done
- done
-IFS=$as_save_IFS
- if test -z "$ac_cv_path_EGREP"; then
- as_fn_error $? "no acceptable egrep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" "$LINENO" 5
- fi
-else
- ac_cv_path_EGREP=$EGREP
-fi
- fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_path_EGREP" >&5
-$as_echo "$ac_cv_path_EGREP" >&6; }
- EGREP="$ac_cv_path_EGREP"
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for fgrep" >&5
-$as_echo_n "checking for fgrep... " >&6; }
-if ${ac_cv_path_FGREP+:} false; then :
-else
- if echo 'ab*c' | $GREP -F 'ab*c' >/dev/null 2>&1
- then ac_cv_path_FGREP="$GREP -F"
- else
- if test -z "$FGREP"; then
- ac_path_FGREP_found=false
-do
- IFS=$as_save_IFS
- for ac_prog in fgrep; do
- ac_path_FGREP="$as_dir/$ac_prog$ac_exec_ext"
- { test -f "$ac_path_FGREP" && $as_test_x "$ac_path_FGREP"; } || continue
-# Check for GNU ac_path_FGREP and select it if it is found.
- # Check for GNU $ac_path_FGREP
-case `"$ac_path_FGREP" --version 2>&1` in
-*GNU*)
- ac_cv_path_FGREP="$ac_path_FGREP" ac_path_FGREP_found=:;;
- ac_count=0
- while :
- do
- $as_echo 'FGREP' >> "conftest.nl"
- "$ac_path_FGREP" FGREP < "conftest.nl" >"conftest.out" 2>/dev/null || break
- if test $ac_count -gt ${ac_path_FGREP_max-0}; then
- ac_path_FGREP_max=$ac_count
- fi
- done
-esac
- $ac_path_FGREP_found && break 3
- done
- done
- done
-IFS=$as_save_IFS
- if test -z "$ac_cv_path_FGREP"; then
- as_fn_error $? "no acceptable fgrep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" "$LINENO" 5
- fi
-else
- ac_cv_path_FGREP=$FGREP
-fi
- fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_path_FGREP" >&5
-$as_echo "$ac_cv_path_FGREP" >&6; }
- FGREP="$ac_cv_path_FGREP"
-test -z "$GREP" && GREP=grep
-# Check whether --with-gnu-ld was given.
-if test "${with_gnu_ld+set}" = set; then :
- withval=$with_gnu_ld; test "$withval" = no || with_gnu_ld=yes
-else
- with_gnu_ld=no
-fi
-ac_prog=ld
-if test "$GCC" = yes; then
- # Check if gcc -print-prog-name=ld gives a path.
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for ld used by $CC" >&5
-$as_echo_n "checking for ld used by $CC... " >&6; }
- case $host in
- *-*-mingw*)
- # gcc leaves a trailing carriage return which upsets mingw
- ac_prog=`($CC -print-prog-name=ld) 2>&5 | tr -d '\015'` ;;
- ac_prog=`($CC -print-prog-name=ld) 2>&5` ;;
- esac
- case $ac_prog in
- # Accept absolute paths.
- re_direlt='/[^/][^/]*/\.\./'
- # Canonicalize the pathname of ld
- ac_prog=`$ECHO "$ac_prog"| $SED 's%\\\\%/%g'`
- while $ECHO "$ac_prog" | $GREP "$re_direlt" > /dev/null 2>&1; do
- ac_prog=`$ECHO $ac_prog| $SED "s%$re_direlt%/%"`
- done
- test -z "$LD" && LD="$ac_prog"
- # If it fails, then pretend we aren't using GCC.
- ac_prog=ld
- # If it is relative, then search for the first ld in PATH.
- with_gnu_ld=unknown
- esac
-elif test "$with_gnu_ld" = yes; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for GNU ld" >&5
-$as_echo_n "checking for GNU ld... " >&6; }
-else
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for non-GNU ld" >&5
-$as_echo_n "checking for non-GNU ld... " >&6; }
-fi
-if ${lt_cv_path_LD+:} false; then :
- $as_echo_n "(cached) " >&6
-else
- if test -z "$LD"; then
- lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
- for ac_dir in $PATH; do
- IFS="$lt_save_ifs"
- test -z "$ac_dir" && ac_dir=.
- if test -f "$ac_dir/$ac_prog" || test -f "$ac_dir/$ac_prog$ac_exeext"; then
- lt_cv_path_LD="$ac_dir/$ac_prog"
- # Check to see if the program is GNU ld. I'd rather use --version,
- # but apparently some variants of GNU ld only accept -v.
- # Break only if it was the GNU/non-GNU ld that we prefer.
- case `"$lt_cv_path_LD" -v 2>&1 </dev/null` in
- *GNU* | *'with BFD'*)
- test "$with_gnu_ld" != no && break
- test "$with_gnu_ld" != yes && break
- esac
- fi
- done
-else
- lt_cv_path_LD="$LD" # Let the user override the test with a path.
-fi
-fi
-LD="$lt_cv_path_LD"
-if test -n "$LD"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $LD" >&5
-$as_echo "$LD" >&6; }
-else
-fi
-test -z "$LD" && as_fn_error $? "no acceptable ld found in \$PATH" "$LINENO" 5
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if the linker ($LD) is GNU ld" >&5
-$as_echo_n "checking if the linker ($LD) is GNU ld... " >&6; }
-if ${lt_cv_prog_gnu_ld+:} false; then :
-else
- # I'd rather use --version here, but apparently some GNU lds only accept -v.
-case `$LD -v 2>&1 </dev/null` in
-*GNU* | *'with BFD'*)
- lt_cv_prog_gnu_ld=yes
- lt_cv_prog_gnu_ld=no
-esac
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_gnu_ld" >&5
-$as_echo "$lt_cv_prog_gnu_ld" >&6; }
-with_gnu_ld=$lt_cv_prog_gnu_ld
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for BSD- or MS-compatible name lister (nm)" >&5
-$as_echo_n "checking for BSD- or MS-compatible name lister (nm)... " >&6; }
-if ${lt_cv_path_NM+:} false; then :
-else
- if test -n "$NM"; then
- # Let the user override the test.
- lt_cv_path_NM="$NM"
-else
- lt_nm_to_check="${ac_tool_prefix}nm"
- if test -n "$ac_tool_prefix" && test "$build" = "$host"; then
- lt_nm_to_check="$lt_nm_to_check nm"
- fi
- for lt_tmp_nm in $lt_nm_to_check; do
- for ac_dir in $PATH /usr/ccs/bin/elf /usr/ccs/bin /usr/ucb /bin; do
- tmp_nm="$ac_dir/$lt_tmp_nm"
- if test -f "$tmp_nm" || test -f "$tmp_nm$ac_exeext" ; then
- # Check to see if the nm accepts a BSD-compat flag.
- # Adding the `sed 1q' prevents false positives on HP-UX, which says:
- # nm: unknown option "B" ignored
- # Tru64's nm complains that /dev/null is an invalid object file
- case `"$tmp_nm" -B /dev/null 2>&1 | sed '1q'` in
- */dev/null* | *'Invalid file or object type'*)
- lt_cv_path_NM="$tmp_nm -B"
- break
- case `"$tmp_nm" -p /dev/null 2>&1 | sed '1q'` in
- */dev/null*)
- lt_cv_path_NM="$tmp_nm -p"
- break
- lt_cv_path_NM=${lt_cv_path_NM="$tmp_nm"} # keep the first match, but
- continue # so that we can try to find one that supports BSD flags
- esac
- esac
- fi
- done
- done
- : ${lt_cv_path_NM=no}
-fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_path_NM" >&5
-$as_echo "$lt_cv_path_NM" >&6; }
-if test "$lt_cv_path_NM" != "no"; then
- NM="$lt_cv_path_NM"
-else
- # Didn't find any BSD compatible name lister, look for dumpbin.
- if test -n "$DUMPBIN"; then :
- else
- for ac_prog in dumpbin "link -dump"
- do
-if ${ac_cv_prog_DUMPBIN+:} false; then :
-else
- ac_cv_prog_DUMPBIN="$DUMPBIN" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_DUMPBIN="$ac_tool_prefix$ac_prog"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-DUMPBIN=$ac_cv_prog_DUMPBIN
-if test -n "$DUMPBIN"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $DUMPBIN" >&5
-$as_echo "$DUMPBIN" >&6; }
-else
-fi
- test -n "$DUMPBIN" && break
- done
-fi
-if test -z "$DUMPBIN"; then
- ac_ct_DUMPBIN=$DUMPBIN
-do
-if ${ac_cv_prog_ac_ct_DUMPBIN+:} false; then :
-else
- if test -n "$ac_ct_DUMPBIN"; then
- ac_cv_prog_ac_ct_DUMPBIN="$ac_ct_DUMPBIN" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_DUMPBIN="$ac_prog"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-ac_ct_DUMPBIN=$ac_cv_prog_ac_ct_DUMPBIN
-if test -n "$ac_ct_DUMPBIN"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_DUMPBIN" >&5
-$as_echo "$ac_ct_DUMPBIN" >&6; }
-else
-fi
- test -n "$ac_ct_DUMPBIN" && break
-done
- if test "x$ac_ct_DUMPBIN" = x; then
- DUMPBIN=":"
- else
-yes:)
-esac
- DUMPBIN=$ac_ct_DUMPBIN
- fi
-fi
- case `$DUMPBIN -symbols /dev/null 2>&1 | sed '1q'` in
- *COFF*)
- DUMPBIN="$DUMPBIN -symbols"
- DUMPBIN=:
- esac
- fi
- if test "$DUMPBIN" != ":"; then
- NM="$DUMPBIN"
- fi
-fi
-test -z "$NM" && NM=nm
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking the name lister ($NM) interface" >&5
-$as_echo_n "checking the name lister ($NM) interface... " >&6; }
-if ${lt_cv_nm_interface+:} false; then :
-else
- lt_cv_nm_interface="BSD nm"
- echo "int some_variable = 0;" > conftest.$ac_ext
- (eval echo "\"\$as_me:$LINENO: $ac_compile\"" >&5)
- (eval "$ac_compile" 2>conftest.err)
- cat conftest.err >&5
- (eval echo "\"\$as_me:$LINENO: $NM \\\"conftest.$ac_objext\\\"\"" >&5)
- (eval "$NM \"conftest.$ac_objext\"" 2>conftest.err > conftest.out)
- (eval echo "\"\$as_me:$LINENO: output\"" >&5)
- cat conftest.out >&5
- if $GREP 'External.*some_variable' conftest.out > /dev/null; then
- lt_cv_nm_interface="MS dumpbin"
- fi
- rm -f conftest*
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_nm_interface" >&5
-$as_echo "$lt_cv_nm_interface" >&6; }
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether ln -s works" >&5
-$as_echo_n "checking whether ln -s works... " >&6; }
-LN_S=$as_ln_s
-if test "$LN_S" = "ln -s"; then
-else
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: no, using $LN_S" >&5
-$as_echo "no, using $LN_S" >&6; }
-fi
-# find the maximum length of command line arguments
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking the maximum length of command line arguments" >&5
-$as_echo_n "checking the maximum length of command line arguments... " >&6; }
-if ${lt_cv_sys_max_cmd_len+:} false; then :
-else
- i=0
- teststring="ABCD"
- case $build_os in
- msdosdjgpp*)
- # On DJGPP, this test can blow up pretty badly due to problems in libc
- # (any single argument exceeding 2000 bytes causes a buffer overrun
- # during glob expansion). Even if it were fixed, the result of this
- # check would be larger than it should be.
- lt_cv_sys_max_cmd_len=12288; # 12K is about right
- gnu*)
- # Under GNU Hurd, this test is not required because there is
- # no limit to the length of command line arguments.
- # Libtool will interpret -1 as no limit whatsoever
- lt_cv_sys_max_cmd_len=-1;
- cygwin* | mingw* | cegcc*)
- # On Win9x/ME, this test blows up -- it succeeds, but takes
- # about 5 minutes as the teststring grows exponentially.
- # Worse, since 9x/ME are not pre-emptively multitasking,
- # you end up with a "frozen" computer, even though with patience
- # the test eventually succeeds (with a max line length of 256k).
- # Instead, let's just punt: use the minimum linelength reported by
- # all of the supported platforms: 8192 (on NT/2K/XP).
- lt_cv_sys_max_cmd_len=8192;
- mint*)
- # On MiNT this can take a long time and run out of memory.
- amigaos*)
- # On AmigaOS with pdksh, this test takes hours, literally.
- # So we just punt and use a minimum line length of 8192.
- netbsd* | freebsd* | openbsd* | darwin* | dragonfly*)
- # This has been around since 386BSD, at least. Likely further.
- if test -x /sbin/sysctl; then
- lt_cv_sys_max_cmd_len=`/sbin/sysctl -n kern.argmax`
- elif test -x /usr/sbin/sysctl; then
- lt_cv_sys_max_cmd_len=`/usr/sbin/sysctl -n kern.argmax`
- else
- lt_cv_sys_max_cmd_len=65536 # usable default for all BSDs
- fi
- # And add a safety zone
- lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \/ 4`
- lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \* 3`
- interix*)
- # We know the value 262144 and hardcode it with a safety zone (like BSD)
- lt_cv_sys_max_cmd_len=196608
- os2*)
- # The test takes a long time on OS/2.
- osf*)
- # Dr. Hans Ekkehard Plesser reports seeing a kernel panic running configure
- # due to this test when exec_disable_arg_limit is 1 on Tru64. It is not
- # nice to cause kernel panics so lets avoid the loop below.
- # First set a reasonable default.
- lt_cv_sys_max_cmd_len=16384
- if test -x /sbin/sysconfig; then
- case `/sbin/sysconfig -q proc exec_disable_arg_limit` in
- *1*) lt_cv_sys_max_cmd_len=-1 ;;
- esac
- fi
- sco3.2v5*)
- lt_cv_sys_max_cmd_len=102400
- sysv5* | sco5v6* | sysv4.2uw2*)
- kargmax=`grep ARG_MAX /etc/conf/cf.d/stune 2>/dev/null`
- if test -n "$kargmax"; then
- lt_cv_sys_max_cmd_len=`echo $kargmax | sed 's/.*[ ]//'`
- else
- lt_cv_sys_max_cmd_len=32768
- fi
- lt_cv_sys_max_cmd_len=`(getconf ARG_MAX) 2> /dev/null`
- if test -n "$lt_cv_sys_max_cmd_len"; then
- else
- # Make teststring a little bigger before we do anything with it.
- # a 1K string should be a reasonable start.
- for i in 1 2 3 4 5 6 7 8 ; do
- teststring=$teststring$teststring
- done
- SHELL=${SHELL-${CONFIG_SHELL-/bin/sh}}
- # If test is not a shell built-in, we'll probably end up computing a
- # maximum length that is only half of the actual maximum length, but
- # we can't tell.
- while { test "X"`env echo "$teststring$teststring" 2>/dev/null` \
- = "X$teststring$teststring"; } >/dev/null 2>&1 &&
- test $i != 17 # 1/2 MB should be enough
- do
- i=`expr $i + 1`
- done
- # Only check the string length outside the loop.
- lt_cv_sys_max_cmd_len=`expr "X$teststring" : ".*" 2>&1`
- teststring=
- # Add a significant safety factor because C++ compilers can tack on
- # massive amounts of additional arguments before passing them to the
- # linker. It appears as though 1/2 is a usable value.
- lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \/ 2`
- fi
- esac
-fi
-if test -n $lt_cv_sys_max_cmd_len ; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_sys_max_cmd_len" >&5
-$as_echo "$lt_cv_sys_max_cmd_len" >&6; }
-else
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: none" >&5
-$as_echo "none" >&6; }
-fi
-max_cmd_len=$lt_cv_sys_max_cmd_len
-: ${CP="cp -f"}
-: ${MV="mv -f"}
-: ${RM="rm -f"}
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the shell understands some XSI constructs" >&5
-$as_echo_n "checking whether the shell understands some XSI constructs... " >&6; }
-# Try some XSI features
-xsi_shell=no
-( _lt_dummy="a/b/c"
- test "${_lt_dummy##*/},${_lt_dummy%/*},${_lt_dummy#??}"${_lt_dummy%"$_lt_dummy"}, \
- = c,a/b,b/c, \
- && eval 'test $(( 1 + 1 )) -eq 2 \
- && test "${#_lt_dummy}" -eq 5' ) >/dev/null 2>&1 \
- && xsi_shell=yes
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $xsi_shell" >&5
-$as_echo "$xsi_shell" >&6; }
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the shell understands \"+=\"" >&5
-$as_echo_n "checking whether the shell understands \"+=\"... " >&6; }
-lt_shell_append=no
-( foo=bar; set foo baz; eval "$1+=\$2" && test "$foo" = barbaz ) \
- >/dev/null 2>&1 \
- && lt_shell_append=yes
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_shell_append" >&5
-$as_echo "$lt_shell_append" >&6; }
-if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
- lt_unset=unset
-else
- lt_unset=false
-fi
-# test EBCDIC or ASCII
-case `echo X|tr X '\101'` in
- A) # ASCII based system
- # \n is not interpreted correctly by Solaris 8 /usr/ucb/tr
- lt_SP2NL='tr \040 \012'
- lt_NL2SP='tr \015\012 \040\040'
- *) # EBCDIC based system
- lt_SP2NL='tr \100 \n'
- lt_NL2SP='tr \r\n \100\100'
-esac
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to convert $build file names to $host format" >&5
-$as_echo_n "checking how to convert $build file names to $host format... " >&6; }
-if ${lt_cv_to_host_file_cmd+:} false; then :
-else
- case $host in
- *-*-mingw* )
- case $build in
- *-*-mingw* ) # actually msys
- lt_cv_to_host_file_cmd=func_convert_file_msys_to_w32
- *-*-cygwin* )
- lt_cv_to_host_file_cmd=func_convert_file_cygwin_to_w32
- * ) # otherwise, assume *nix
- lt_cv_to_host_file_cmd=func_convert_file_nix_to_w32
- esac
- *-*-cygwin* )
- case $build in
- lt_cv_to_host_file_cmd=func_convert_file_msys_to_cygwin
- *-*-cygwin* )
- lt_cv_to_host_file_cmd=func_convert_file_noop
- lt_cv_to_host_file_cmd=func_convert_file_nix_to_cygwin
- esac
- * ) # unhandled hosts (and "normal" native builds)
-esac
-fi
-to_host_file_cmd=$lt_cv_to_host_file_cmd
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_to_host_file_cmd" >&5
-$as_echo "$lt_cv_to_host_file_cmd" >&6; }
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to convert $build file names to toolchain format" >&5
-$as_echo_n "checking how to convert $build file names to toolchain format... " >&6; }
-if ${lt_cv_to_tool_file_cmd+:} false; then :
-else
- #assume ordinary cross tools, or native build.
-lt_cv_to_tool_file_cmd=func_convert_file_noop
-case $host in
- *-*-mingw* )
- case $build in
- lt_cv_to_tool_file_cmd=func_convert_file_msys_to_w32
- esac
-esac
-fi
-to_tool_file_cmd=$lt_cv_to_tool_file_cmd
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_to_tool_file_cmd" >&5
-$as_echo "$lt_cv_to_tool_file_cmd" >&6; }
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $LD option to reload object files" >&5
-$as_echo_n "checking for $LD option to reload object files... " >&6; }
-if ${lt_cv_ld_reload_flag+:} false; then :
-else
- lt_cv_ld_reload_flag='-r'
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_ld_reload_flag" >&5
-$as_echo "$lt_cv_ld_reload_flag" >&6; }
-reload_flag=$lt_cv_ld_reload_flag
-case $reload_flag in
-*) reload_flag=" $reload_flag" ;;
-esac
-reload_cmds='$LD$reload_flag -o $output$reload_objs'
-case $host_os in
- cygwin* | mingw* | pw32* | cegcc*)
- if test "$GCC" != yes; then
- reload_cmds=false
- fi
- darwin*)
- reload_cmds='$LTCC $LTCFLAGS -nostdlib ${wl}-r -o $output$reload_objs'
- else
- reload_cmds='$LD$reload_flag -o $output$reload_objs'
- fi
-esac
- # Extract the first word of "${ac_tool_prefix}objdump", so it can be a program name with args.
-set dummy ${ac_tool_prefix}objdump; ac_word=$2
-if ${ac_cv_prog_OBJDUMP+:} false; then :
-else
- if test -n "$OBJDUMP"; then
- ac_cv_prog_OBJDUMP="$OBJDUMP" # Let the user override the test.
-else
-as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-do
- IFS=$as_save_IFS
- ac_cv_prog_OBJDUMP="${ac_tool_prefix}objdump"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-OBJDUMP=$ac_cv_prog_OBJDUMP
-if test -n "$OBJDUMP"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $OBJDUMP" >&5
-$as_echo "$OBJDUMP" >&6; }
-else
-fi
-fi
-if test -z "$ac_cv_prog_OBJDUMP"; then
- ac_ct_OBJDUMP=$OBJDUMP
- # Extract the first word of "objdump", so it can be a program name with args.
-set dummy objdump; ac_word=$2
-if ${ac_cv_prog_ac_ct_OBJDUMP+:} false; then :
-else
- if test -n "$ac_ct_OBJDUMP"; then
- ac_cv_prog_ac_ct_OBJDUMP="$ac_ct_OBJDUMP" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_OBJDUMP="objdump"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-ac_ct_OBJDUMP=$ac_cv_prog_ac_ct_OBJDUMP
-if test -n "$ac_ct_OBJDUMP"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_OBJDUMP" >&5
-$as_echo "$ac_ct_OBJDUMP" >&6; }
-else
-fi
- if test "x$ac_ct_OBJDUMP" = x; then
- OBJDUMP="false"
- else
-yes:)
-esac
- OBJDUMP=$ac_ct_OBJDUMP
- fi
-else
- OBJDUMP="$ac_cv_prog_OBJDUMP"
-fi
-test -z "$OBJDUMP" && OBJDUMP=objdump
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to recognize dependent libraries" >&5
-$as_echo_n "checking how to recognize dependent libraries... " >&6; }
-if ${lt_cv_deplibs_check_method+:} false; then :
-else
- lt_cv_file_magic_cmd='$MAGIC_CMD'
-lt_cv_file_magic_test_file=
-lt_cv_deplibs_check_method='unknown'
-# Need to set the preceding variable on all platforms that support
-# interlibrary dependencies.
-# 'none' -- dependencies not supported.
-# `unknown' -- same as none, but documents that we really don't know.
-# 'pass_all' -- all dependencies passed with no checks.
-# 'test_compile' -- check by making test program.
-# 'file_magic [[regex]]' -- check by looking for files in library path
-# which responds to the $file_magic_cmd with a given extended regex.
-# If you have `file' or equivalent on your system and you're not sure
-# whether `pass_all' will *always* work, you probably want this one.
-case $host_os in
-aix[4-9]*)
- lt_cv_deplibs_check_method=pass_all
-beos*)
-bsdi[45]*)
- lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [ML]SB (shared object|dynamic lib)'
- lt_cv_file_magic_cmd='/usr/bin/file -L'
- lt_cv_file_magic_test_file=/shlib/libc.so
-cygwin*)
- # func_win32_libid is a shell function defined in ltmain.sh
- lt_cv_deplibs_check_method='file_magic ^x86 archive import|^x86 DLL'
- lt_cv_file_magic_cmd='func_win32_libid'
-mingw* | pw32*)
- # Base MSYS/MinGW do not provide the 'file' command needed by
- # func_win32_libid shell function, so use a weaker test based on 'objdump',
- # unless we find 'file', for example because we are cross-compiling.
- # func_win32_libid assumes BSD nm, so disallow it if using MS dumpbin.
- if ( test "$lt_cv_nm_interface" = "BSD nm" && file / ) >/dev/null 2>&1; then
- else
- # Keep this pattern in sync with the one in func_win32_libid.
- lt_cv_deplibs_check_method='file_magic file format (pei*-i386(.*architecture: i386)?|pe-arm-wince|pe-x86-64)'
- lt_cv_file_magic_cmd='$OBJDUMP -f'
- fi
-cegcc*)
- # use the weaker test based on 'objdump'. See mingw*.
- lt_cv_deplibs_check_method='file_magic file format pe-arm-.*little(.*architecture: arm)?'
-darwin* | rhapsody*)
-freebsd* | dragonfly*)
- if echo __ELF__ | $CC -E - | $GREP __ELF__ > /dev/null; then
- case $host_cpu in
- i*86 )
- # Not sure whether the presence of OpenBSD here was a mistake.
- # Let's accept both of them until this is cleared up.
- lt_cv_deplibs_check_method='file_magic (FreeBSD|OpenBSD|DragonFly)/i[3-9]86 (compact )?demand paged shared library'
- lt_cv_file_magic_cmd=/usr/bin/file
- lt_cv_file_magic_test_file=`echo /usr/lib/libc.so.*`
- esac
- else
- fi
-gnu*)
-haiku*)
-hpux10.20* | hpux11*)
- case $host_cpu in
- ia64*)
- lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|ELF-[0-9][0-9]) shared object file - IA64'
- lt_cv_file_magic_test_file=/usr/lib/hpux32/libc.so
- hppa*64*)
- lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|ELF[ -][0-9][0-9])(-bit)?( [LM]SB)? shared object( file)?[, -]* PA-RISC [0-9]\.[0-9]'
- lt_cv_file_magic_test_file=/usr/lib/pa20_64/libc.sl
- lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|PA-RISC[0-9]\.[0-9]) shared library'
- lt_cv_file_magic_test_file=/usr/lib/libc.sl
- esac
-interix[3-9]*)
- # PIC code is broken on Interix 3.x, that's why |\.a not |_pic\.a here
- lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so|\.a)$'
-irix5* | irix6* | nonstopux*)
- case $LD in
- *-32|*"-32 ") libmagic=32-bit;;
- *-n32|*"-n32 ") libmagic=N32;;
- *-64|*"-64 ") libmagic=64-bit;;
- *) libmagic=never-match;;
- esac
-# This must be glibc/ELF.
-linux* | k*bsd*-gnu | kopensolaris*-gnu)
-netbsd* | netbsdelf*-gnu)
- lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so\.[0-9]+\.[0-9]+|_pic\.a)$'
- else
- lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so|_pic\.a)$'
- fi
-newos6*)
- lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [ML]SB (executable|dynamic lib)'
- lt_cv_file_magic_test_file=/usr/lib/libnls.so
-*nto* | *qnx*)
-openbsd*)
- if test -z "`echo __ELF__ | $CC -E - | $GREP __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so\.[0-9]+\.[0-9]+|\.so|_pic\.a)$'
- else
- fi
-osf3* | osf4* | osf5*)
-rdos*)
-solaris*)
-sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
-sysv4 | sysv4.3*)
- case $host_vendor in
- motorola)
- lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [ML]SB (shared object|dynamic lib) M[0-9][0-9]* Version [0-9]'
- lt_cv_file_magic_test_file=`echo /usr/lib/libc.so*`
- ncr)
- sequent)
- lt_cv_file_magic_cmd='/bin/file'
- lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [LM]SB (shared object|dynamic lib )'
- sni)
- lt_cv_deplibs_check_method="file_magic ELF [0-9][0-9]*-bit [LM]SB dynamic lib"
- lt_cv_file_magic_test_file=/lib/libc.so
- siemens)
- pc)
- esac
-tpf*)
-esac
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_deplibs_check_method" >&5
-$as_echo "$lt_cv_deplibs_check_method" >&6; }
-file_magic_glob=
-want_nocaseglob=no
-if test "$build" = "$host"; then
- case $host_os in
- mingw* | pw32*)
- if ( shopt | grep nocaseglob ) >/dev/null 2>&1; then
- want_nocaseglob=yes
- else
- file_magic_glob=`echo aAbBcCdDeEfFgGhHiIjJkKlLmMnNoOpPqQrRsStTuUvVwWxXyYzZ | $SED -e "s/\(..\)/s\/[\1]\/[\1]\/g;/g"`
- fi
- esac
-fi
-file_magic_cmd=$lt_cv_file_magic_cmd
-deplibs_check_method=$lt_cv_deplibs_check_method
-test -z "$deplibs_check_method" && deplibs_check_method=unknown
- # Extract the first word of "${ac_tool_prefix}dlltool", so it can be a program name with args.
-set dummy ${ac_tool_prefix}dlltool; ac_word=$2
-if ${ac_cv_prog_DLLTOOL+:} false; then :
-else
- if test -n "$DLLTOOL"; then
- ac_cv_prog_DLLTOOL="$DLLTOOL" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- for ac_exec_ext in '' $ac_executable_extensions; do
- ac_cv_prog_DLLTOOL="${ac_tool_prefix}dlltool"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-DLLTOOL=$ac_cv_prog_DLLTOOL
-if test -n "$DLLTOOL"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $DLLTOOL" >&5
-$as_echo "$DLLTOOL" >&6; }
-else
-fi
-fi
-if test -z "$ac_cv_prog_DLLTOOL"; then
- ac_ct_DLLTOOL=$DLLTOOL
- # Extract the first word of "dlltool", so it can be a program name with args.
-set dummy dlltool; ac_word=$2
-if ${ac_cv_prog_ac_ct_DLLTOOL+:} false; then :
-else
- if test -n "$ac_ct_DLLTOOL"; then
- ac_cv_prog_ac_ct_DLLTOOL="$ac_ct_DLLTOOL" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_DLLTOOL="dlltool"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-ac_ct_DLLTOOL=$ac_cv_prog_ac_ct_DLLTOOL
-if test -n "$ac_ct_DLLTOOL"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_DLLTOOL" >&5
-$as_echo "$ac_ct_DLLTOOL" >&6; }
-else
-fi
- if test "x$ac_ct_DLLTOOL" = x; then
- DLLTOOL="false"
- else
-yes:)
-esac
- DLLTOOL=$ac_ct_DLLTOOL
- fi
-else
- DLLTOOL="$ac_cv_prog_DLLTOOL"
-fi
-test -z "$DLLTOOL" && DLLTOOL=dlltool
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to associate runtime and link libraries" >&5
-$as_echo_n "checking how to associate runtime and link libraries... " >&6; }
-if ${lt_cv_sharedlib_from_linklib_cmd+:} false; then :
-else
- lt_cv_sharedlib_from_linklib_cmd='unknown'
-case $host_os in
-cygwin* | mingw* | pw32* | cegcc*)
- # two different shell functions defined in ltmain.sh
- # decide which to use based on capabilities of $DLLTOOL
- case `$DLLTOOL --help 2>&1` in
- *--identify-strict*)
- lt_cv_sharedlib_from_linklib_cmd=func_cygming_dll_for_implib
- lt_cv_sharedlib_from_linklib_cmd=func_cygming_dll_for_implib_fallback
- esac
- # fallback: assume linklib IS sharedlib
- lt_cv_sharedlib_from_linklib_cmd="$ECHO"
-esac
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_sharedlib_from_linklib_cmd" >&5
-$as_echo "$lt_cv_sharedlib_from_linklib_cmd" >&6; }
-sharedlib_from_linklib_cmd=$lt_cv_sharedlib_from_linklib_cmd
-test -z "$sharedlib_from_linklib_cmd" && sharedlib_from_linklib_cmd=$ECHO
- for ac_prog in ar
- do
-if ${ac_cv_prog_AR+:} false; then :
-else
- if test -n "$AR"; then
- ac_cv_prog_AR="$AR" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_AR="$ac_tool_prefix$ac_prog"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-AR=$ac_cv_prog_AR
-if test -n "$AR"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $AR" >&5
-$as_echo "$AR" >&6; }
-else
-fi
- test -n "$AR" && break
- done
-fi
-if test -z "$AR"; then
- ac_ct_AR=$AR
- for ac_prog in ar
-do
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $ac_word" >&5
-$as_echo_n "checking for $ac_word... " >&6; }
-if ${ac_cv_prog_ac_ct_AR+:} false; then :
-else
- if test -n "$ac_ct_AR"; then
- ac_cv_prog_ac_ct_AR="$ac_ct_AR" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- test -z "$as_dir" && as_dir=.
- if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then
- ac_cv_prog_ac_ct_AR="$ac_prog"
- $as_echo "$as_me:${as_lineno-$LINENO}: found $as_dir/$ac_word$ac_exec_ext" >&5
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-ac_ct_AR=$ac_cv_prog_ac_ct_AR
-if test -n "$ac_ct_AR"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_AR" >&5
-$as_echo "$ac_ct_AR" >&6; }
-else
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
-$as_echo "no" >&6; }
-fi
- test -n "$ac_ct_AR" && break
-done
- if test "x$ac_ct_AR" = x; then
- AR="false"
- else
-yes:)
-esac
- AR=$ac_ct_AR
- fi
-fi
-: ${AR=ar}
-: ${AR_FLAGS=cru}
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for archiver @FILE support" >&5
-$as_echo_n "checking for archiver @FILE support... " >&6; }
-if ${lt_cv_ar_at_file+:} false; then :
-else
- lt_cv_ar_at_file=no
- cat confdefs.h - <<_ACEOF >conftest.$ac_ext
-/* end confdefs.h. */
-int
-main ()
- return 0;
-_ACEOF
-if ac_fn_c_try_compile "$LINENO"; then :
- echo conftest.$ac_objext > conftest.lst
- lt_ar_try='$AR $AR_FLAGS libconftest.a @conftest.lst >&5'
- { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$lt_ar_try\""; } >&5
- (eval $lt_ar_try) 2>&5
- ac_status=$?
- $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
- if test "$ac_status" -eq 0; then
- # Ensure the archiver fails upon bogus file names.
- rm -f conftest.$ac_objext libconftest.a
- ac_status=$?
- if test "$ac_status" -ne 0; then
- lt_cv_ar_at_file=@
- fi
- fi
- rm -f conftest.* libconftest.a
-fi
-rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_ar_at_file" >&5
-$as_echo "$lt_cv_ar_at_file" >&6; }
-if test "x$lt_cv_ar_at_file" = xno; then
- archiver_list_spec=
-else
- archiver_list_spec=$lt_cv_ar_at_file
-fi
- # Extract the first word of "${ac_tool_prefix}strip", so it can be a program name with args.
-set dummy ${ac_tool_prefix}strip; ac_word=$2
-if ${ac_cv_prog_STRIP+:} false; then :
-else
- if test -n "$STRIP"; then
- ac_cv_prog_STRIP="$STRIP" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_STRIP="${ac_tool_prefix}strip"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-STRIP=$ac_cv_prog_STRIP
-if test -n "$STRIP"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $STRIP" >&5
-$as_echo "$STRIP" >&6; }
-else
-fi
-fi
-if test -z "$ac_cv_prog_STRIP"; then
- ac_ct_STRIP=$STRIP
- # Extract the first word of "strip", so it can be a program name with args.
-set dummy strip; ac_word=$2
-if ${ac_cv_prog_ac_ct_STRIP+:} false; then :
-else
- if test -n "$ac_ct_STRIP"; then
- ac_cv_prog_ac_ct_STRIP="$ac_ct_STRIP" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_STRIP="strip"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-ac_ct_STRIP=$ac_cv_prog_ac_ct_STRIP
-if test -n "$ac_ct_STRIP"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_STRIP" >&5
-$as_echo "$ac_ct_STRIP" >&6; }
-else
-fi
- if test "x$ac_ct_STRIP" = x; then
- STRIP=":"
- else
- case $cross_compiling:$ac_tool_warned in
-yes:)
-{ $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: using cross tools not prefixed with host triplet" >&5
-$as_echo "$as_me: WARNING: using cross tools not prefixed with host triplet" >&2;}
-ac_tool_warned=yes ;;
-esac
- STRIP=$ac_ct_STRIP
- fi
-else
- STRIP="$ac_cv_prog_STRIP"
-fi
-test -z "$STRIP" && STRIP=:
- # Extract the first word of "${ac_tool_prefix}ranlib", so it can be a program name with args.
-set dummy ${ac_tool_prefix}ranlib; ac_word=$2
-if ${ac_cv_prog_RANLIB+:} false; then :
-else
- if test -n "$RANLIB"; then
- ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_RANLIB="${ac_tool_prefix}ranlib"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-RANLIB=$ac_cv_prog_RANLIB
-if test -n "$RANLIB"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $RANLIB" >&5
-$as_echo "$RANLIB" >&6; }
-else
-fi
-fi
-if test -z "$ac_cv_prog_RANLIB"; then
- ac_ct_RANLIB=$RANLIB
- # Extract the first word of "ranlib", so it can be a program name with args.
-set dummy ranlib; ac_word=$2
-if ${ac_cv_prog_ac_ct_RANLIB+:} false; then :
-else
- if test -n "$ac_ct_RANLIB"; then
- ac_cv_prog_ac_ct_RANLIB="$ac_ct_RANLIB" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_RANLIB="ranlib"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-ac_ct_RANLIB=$ac_cv_prog_ac_ct_RANLIB
-if test -n "$ac_ct_RANLIB"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_RANLIB" >&5
-$as_echo "$ac_ct_RANLIB" >&6; }
-else
-fi
- if test "x$ac_ct_RANLIB" = x; then
- RANLIB=":"
- else
-yes:)
-esac
- RANLIB=$ac_ct_RANLIB
- fi
-else
- RANLIB="$ac_cv_prog_RANLIB"
-fi
-test -z "$RANLIB" && RANLIB=:
-# Determine commands to create old-style static archives.
-old_archive_cmds='$AR $AR_FLAGS $oldlib$oldobjs'
-old_postinstall_cmds='chmod 644 $oldlib'
-old_postuninstall_cmds=
- case $host_os in
- openbsd*)
- old_postinstall_cmds="$old_postinstall_cmds~\$RANLIB -t \$tool_oldlib"
- old_postinstall_cmds="$old_postinstall_cmds~\$RANLIB \$tool_oldlib"
- esac
- old_archive_cmds="$old_archive_cmds~\$RANLIB \$tool_oldlib"
-fi
-case $host_os in
- darwin*)
- lock_old_archive_extraction=yes ;;
- lock_old_archive_extraction=no ;;
-esac
-# If no C compiler was specified, use CC.
-LTCC=${LTCC-"$CC"}
-# If no C compiler flags were specified, use CFLAGS.
-LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
-# Allow CC to be a program name with arguments.
-compiler=$CC
-# Check for command to grab the raw symbol name followed by C symbol from nm.
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking command to parse $NM output from $compiler object" >&5
-$as_echo_n "checking command to parse $NM output from $compiler object... " >&6; }
-if ${lt_cv_sys_global_symbol_pipe+:} false; then :
-else
-# These are sane defaults that work on at least a few old systems.
-# [They come from Ultrix. What could be older than Ultrix?!! ;)]
-# Character class describing NM global symbol codes.
-symcode='[BCDEGRST]'
-# Regexp to match symbols that can be accessed directly from C.
-sympat='\([_A-Za-z][_A-Za-z0-9]*\)'
-# Define system-specific variables.
-case $host_os in
-aix*)
- symcode='[BCDT]'
- symcode='[ABCDGISTW]'
-hpux*)
- if test "$host_cpu" = ia64; then
- symcode='[ABCDEGRST]'
- fi
-irix* | nonstopux*)
- symcode='[BCDEGRST]'
-osf*)
- symcode='[BCDEGQRST]'
-solaris*)
- symcode='[BDRT]'
-sco3.2v5*)
- symcode='[DT]'
-sysv4.2uw2*)
- symcode='[DT]'
-sysv5* | sco5v6* | unixware* | OpenUNIX*)
- symcode='[ABDT]'
-sysv4)
- symcode='[DFNSTU]'
-esac
-# If we're using GNU nm, then use its standard symbol codes.
-case `$NM -V 2>&1` in
- symcode='[ABCDGIRSTW]' ;;
-esac
-# Transform an extracted symbol line into a proper C declaration.
-# Some systems (esp. on ia64) link data and code symbols differently,
-# so use this general approach.
-lt_cv_sys_global_symbol_to_cdecl="sed -n -e 's/^T .* \(.*\)$/extern int \1();/p' -e 's/^$symcode* .* \(.*\)$/extern char \1;/p'"
-# Transform an extracted symbol line into symbol name and symbol address
-lt_cv_sys_global_symbol_to_c_name_address="sed -n -e 's/^: \([^ ]*\)[ ]*$/ {\\\"\1\\\", (void *) 0},/p' -e 's/^$symcode* \([^ ]*\) \([^ ]*\)$/ {\"\2\", (void *) \&\2},/p'"
-lt_cv_sys_global_symbol_to_c_name_address_lib_prefix="sed -n -e 's/^: \([^ ]*\)[ ]*$/ {\\\"\1\\\", (void *) 0},/p' -e 's/^$symcode* \([^ ]*\) \(lib[^ ]*\)$/ {\"\2\", (void *) \&\2},/p' -e 's/^$symcode* \([^ ]*\) \([^ ]*\)$/ {\"lib\2\", (void *) \&\2},/p'"
-# Handle CRLF in mingw tool chain
-opt_cr=
-case $build_os in
-mingw*)
- opt_cr=`$ECHO 'x\{0,1\}' | tr x '\015'` # option cr in regexp
-esac
-# Try without a prefix underscore, then with it.
-for ac_symprfx in "" "_"; do
- # Transform symcode, sympat, and symprfx into a raw symbol and a C symbol.
- symxfrm="\\1 $ac_symprfx\\2 \\2"
- # Write the raw and C identifiers.
- if test "$lt_cv_nm_interface" = "MS dumpbin"; then
- # Fake it for dumpbin and say T for any non-static function
- # and D for any global variable.
- # Also find C++ and __fastcall symbols from MSVC++,
- # which start with @ or ?.
- lt_cv_sys_global_symbol_pipe="$AWK '"\
-" {last_section=section; section=\$ 3};"\
-" /^COFF SYMBOL TABLE/{for(i in hide) delete hide[i]};"\
-" /Section length .*#relocs.*(pick any)/{hide[last_section]=1};"\
-" \$ 0!~/External *\|/{next};"\
-" / 0+ UNDEF /{next}; / UNDEF \([^|]\)*()/{next};"\
-" {if(hide[section]) next};"\
-" {f=0}; \$ 0~/\(\).*\|/{f=1}; {printf f ? \"T \" : \"D \"};"\
-" {split(\$ 0, a, /\||\r/); split(a[2], s)};"\
-" s[1]~/^[@?]/{print s[1], s[1]; next};"\
-" s[1]~prfx {split(s[1],t,\"@\"); print t[1], substr(t[1],length(prfx))}"\
-" ' prfx=^$ac_symprfx"
- else
- lt_cv_sys_global_symbol_pipe="sed -n -e 's/^.*[ ]\($symcode$symcode*\)[ ][ ]*$ac_symprfx$sympat$opt_cr$/$symxfrm/p'"
- fi
- lt_cv_sys_global_symbol_pipe="$lt_cv_sys_global_symbol_pipe | sed '/ __gnu_lto/d'"
- # Check to see that the pipe works correctly.
- pipe_works=no
- rm -f conftest*
- cat > conftest.$ac_ext <<_LT_EOF
-#ifdef __cplusplus
-extern "C" {
-#endif
-char nm_test_var;
-void nm_test_func(void);
-void nm_test_func(void){}
-#ifdef __cplusplus
-#endif
-int main(){nm_test_var='a';nm_test_func();return(0);}
-_LT_EOF
- if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$ac_compile\""; } >&5
- (eval $ac_compile) 2>&5
- ac_status=$?
- # Now try to grab the symbols.
- nlist=conftest.nm
- if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$NM conftest.$ac_objext \| "$lt_cv_sys_global_symbol_pipe" \> $nlist\""; } >&5
- (eval $NM conftest.$ac_objext \| "$lt_cv_sys_global_symbol_pipe" \> $nlist) 2>&5
- ac_status=$?
- test $ac_status = 0; } && test -s "$nlist"; then
- # Try sorting and uniquifying the output.
- if sort "$nlist" | uniq > "$nlist"T; then
- mv -f "$nlist"T "$nlist"
- else
- rm -f "$nlist"T
- fi
- # Make sure that we snagged all the symbols we need.
- if $GREP ' nm_test_var$' "$nlist" >/dev/null; then
- if $GREP ' nm_test_func$' "$nlist" >/dev/null; then
- cat <<_LT_EOF > conftest.$ac_ext
-/* Keep this code in sync between libtool.m4, ltmain, lt_system.h, and tests. */
-#if defined(_WIN32) || defined(__CYGWIN__) || defined(_WIN32_WCE)
-/* DATA imports from DLLs on WIN32 con't be const, because runtime
- relocations are performed -- see ld's documentation on pseudo-relocs. */
-# define LT_DLSYM_CONST
-#elif defined(__osf__)
-/* This system does not cope well with relocations in const data. */
-#else
-# define LT_DLSYM_CONST const
-#endif
-#ifdef __cplusplus
-extern "C" {
-#endif
-_LT_EOF
- # Now generate the symbol file.
- eval "$lt_cv_sys_global_symbol_to_cdecl"' < "$nlist" | $GREP -v main >> conftest.$ac_ext'
- cat <<_LT_EOF >> conftest.$ac_ext
-/* The mapping between symbol names and symbols. */
-LT_DLSYM_CONST struct {
- const char *name;
- void *address;
-lt__PROGRAM__LTX_preloaded_symbols[] =
- { "@PROGRAM@", (void *) 0 },
-_LT_EOF
- $SED "s/^$symcode$symcode* \(.*\) \(.*\)$/ {\"\2\", (void *) \&\2},/" < "$nlist" | $GREP -v main >> conftest.$ac_ext
- cat <<\_LT_EOF >> conftest.$ac_ext
- {0, (void *) 0}
-/* This works around a problem in FreeBSD linker */
-#ifdef FREEBSD_WORKAROUND
-static const void *lt_preloaded_setup() {
- return lt__PROGRAM__LTX_preloaded_symbols;
-#endif
-#ifdef __cplusplus
-#endif
-_LT_EOF
- # Now try linking the two files.
- mv conftest.$ac_objext conftstm.$ac_objext
- lt_globsym_save_LIBS=$LIBS
- lt_globsym_save_CFLAGS=$CFLAGS
- LIBS="conftstm.$ac_objext"
- CFLAGS="$CFLAGS$lt_prog_compiler_no_builtin_flag"
- if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$ac_link\""; } >&5
- (eval $ac_link) 2>&5
- ac_status=$?
- test $ac_status = 0; } && test -s conftest${ac_exeext}; then
- pipe_works=yes
- fi
- LIBS=$lt_globsym_save_LIBS
- CFLAGS=$lt_globsym_save_CFLAGS
- else
- echo "cannot find nm_test_func in $nlist" >&5
- fi
- else
- echo "cannot find nm_test_var in $nlist" >&5
- fi
- else
- echo "cannot run $lt_cv_sys_global_symbol_pipe" >&5
- fi
- else
- echo "$progname: failed program was:" >&5
- cat conftest.$ac_ext >&5
- fi
- rm -rf conftest* conftst*
- # Do not use the global_symbol_pipe unless it works.
- if test "$pipe_works" = yes; then
- break
- else
- fi
-done
-fi
-if test -z "$lt_cv_sys_global_symbol_pipe"; then
- lt_cv_sys_global_symbol_to_cdecl=
-fi
-if test -z "$lt_cv_sys_global_symbol_pipe$lt_cv_sys_global_symbol_to_cdecl"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: failed" >&5
-$as_echo "failed" >&6; }
-else
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: ok" >&5
-$as_echo "ok" >&6; }
-fi
-# Response file support.
-if test "$lt_cv_nm_interface" = "MS dumpbin"; then
- nm_file_list_spec='@'
-elif $NM --help 2>/dev/null | grep '[@]FILE' >/dev/null; then
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for sysroot" >&5
-$as_echo_n "checking for sysroot... " >&6; }
-# Check whether --with-sysroot was given.
-if test "${with_sysroot+set}" = set; then :
- withval=$with_sysroot;
-else
- with_sysroot=no
-fi
-lt_sysroot=
-case ${with_sysroot} in #(
- yes)
- lt_sysroot=`$CC --print-sysroot 2>/dev/null`
- fi
- lt_sysroot=`echo "$with_sysroot" | sed -e "$sed_quote_subst"`
- no|'')
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: ${with_sysroot}" >&5
-$as_echo "${with_sysroot}" >&6; }
- as_fn_error $? "The sysroot must be an absolute path." "$LINENO" 5
-esac
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: ${lt_sysroot:-no}" >&5
-$as_echo "${lt_sysroot:-no}" >&6; }
-# Check whether --enable-libtool-lock was given.
-if test "${enable_libtool_lock+set}" = set; then :
- enableval=$enable_libtool_lock;
-fi
-test "x$enable_libtool_lock" != xno && enable_libtool_lock=yes
-# Some flags need to be propagated to the compiler or linker for good
-# libtool support.
-case $host in
-ia64-*-hpux*)
- # Find out which ABI we are using.
- echo 'int i;' > conftest.$ac_ext
- ac_status=$?
- case `/usr/bin/file conftest.$ac_objext` in
- *ELF-32*)
- HPUX_IA64_MODE="32"
- *ELF-64*)
- HPUX_IA64_MODE="64"
- esac
- fi
- rm -rf conftest*
-*-*-irix6*)
- echo '#line '$LINENO' "configure"' > conftest.$ac_ext
- ac_status=$?
- if test "$lt_cv_prog_gnu_ld" = yes; then
- *32-bit*)
- LD="${LD-ld} -melf32bsmip"
- *N32*)
- LD="${LD-ld} -melf32bmipn32"
- *64-bit*)
- LD="${LD-ld} -melf64bmip"
- esac
- else
- *32-bit*)
- LD="${LD-ld} -32"
- *N32*)
- LD="${LD-ld} -n32"
- *64-bit*)
- LD="${LD-ld} -64"
- esac
- fi
- fi
- rm -rf conftest*
-x86_64-*kfreebsd*-gnu|x86_64-*linux*|ppc*-*linux*|powerpc*-*linux*| \
-s390*-*linux*|s390*-*tpf*|sparc*-*linux*)
- ac_status=$?
- case `/usr/bin/file conftest.o` in
- *32-bit*)
- case $host in
- x86_64-*kfreebsd*-gnu)
- LD="${LD-ld} -m elf_i386_fbsd"
- x86_64-*linux*)
- LD="${LD-ld} -m elf_i386"
- ppc64-*linux*|powerpc64-*linux*)
- LD="${LD-ld} -m elf32ppclinux"
- s390x-*linux*)
- LD="${LD-ld} -m elf_s390"
- sparc64-*linux*)
- LD="${LD-ld} -m elf32_sparc"
- esac
- *64-bit*)
- case $host in
- LD="${LD-ld} -m elf_x86_64_fbsd"
- x86_64-*linux*)
- LD="${LD-ld} -m elf_x86_64"
- ppc*-*linux*|powerpc*-*linux*)
- LD="${LD-ld} -m elf64ppc"
- s390*-*linux*|s390*-*tpf*)
- LD="${LD-ld} -m elf64_s390"
- sparc*-*linux*)
- LD="${LD-ld} -m elf64_sparc"
- esac
- esac
- fi
- rm -rf conftest*
-*-*-sco3.2v5*)
- # On SCO OpenServer 5, we need -belf to get full-featured binaries.
- SAVE_CFLAGS="$CFLAGS"
- CFLAGS="$CFLAGS -belf"
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the C compiler needs -belf" >&5
-$as_echo_n "checking whether the C compiler needs -belf... " >&6; }
-if ${lt_cv_cc_needs_belf+:} false; then :
-else
- ac_ext=c
-ac_cpp='$CPP $CPPFLAGS'
-ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_c_compiler_gnu
-int
-main ()
- return 0;
-_ACEOF
-if ac_fn_c_try_link "$LINENO"; then :
- lt_cv_cc_needs_belf=yes
-else
- lt_cv_cc_needs_belf=no
-fi
-rm -f core conftest.err conftest.$ac_objext \
- conftest$ac_exeext conftest.$ac_ext
- ac_ext=c
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_cc_needs_belf" >&5
-$as_echo "$lt_cv_cc_needs_belf" >&6; }
- if test x"$lt_cv_cc_needs_belf" != x"yes"; then
- # this is probably gcc 2.8.0, egcs 1.0 or newer; no need for -belf
- CFLAGS="$SAVE_CFLAGS"
- fi
-*-*solaris*)
- ac_status=$?
- test $ac_status = 0; }; then
- *64-bit*)
- case $lt_cv_prog_gnu_ld in
- yes*)
- case $host in
- i?86-*-solaris*)
- sparc*-*-solaris*)
- esac
- # GNU ld 2.21 introduced _sol2 emulations. Use them if available.
- if ${LD-ld} -V | grep _sol2 >/dev/null 2>&1; then
- LD="${LD-ld}_sol2"
- fi
- if ${LD-ld} -64 -r -o conftest2.o conftest.o >/dev/null 2>&1; then
- LD="${LD-ld} -64"
- fi
- esac
- esac
- fi
- rm -rf conftest*
-esac
-need_locks="$enable_libtool_lock"
-if test -n "$ac_tool_prefix"; then
- # Extract the first word of "${ac_tool_prefix}mt", so it can be a program name with args.
-set dummy ${ac_tool_prefix}mt; ac_word=$2
-if ${ac_cv_prog_MANIFEST_TOOL+:} false; then :
-else
- if test -n "$MANIFEST_TOOL"; then
- ac_cv_prog_MANIFEST_TOOL="$MANIFEST_TOOL" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_MANIFEST_TOOL="${ac_tool_prefix}mt"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-MANIFEST_TOOL=$ac_cv_prog_MANIFEST_TOOL
-if test -n "$MANIFEST_TOOL"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $MANIFEST_TOOL" >&5
-$as_echo "$MANIFEST_TOOL" >&6; }
-else
-fi
-fi
-if test -z "$ac_cv_prog_MANIFEST_TOOL"; then
- ac_ct_MANIFEST_TOOL=$MANIFEST_TOOL
- # Extract the first word of "mt", so it can be a program name with args.
-set dummy mt; ac_word=$2
-if ${ac_cv_prog_ac_ct_MANIFEST_TOOL+:} false; then :
-else
- if test -n "$ac_ct_MANIFEST_TOOL"; then
- ac_cv_prog_ac_ct_MANIFEST_TOOL="$ac_ct_MANIFEST_TOOL" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_MANIFEST_TOOL="mt"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-ac_ct_MANIFEST_TOOL=$ac_cv_prog_ac_ct_MANIFEST_TOOL
-if test -n "$ac_ct_MANIFEST_TOOL"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_MANIFEST_TOOL" >&5
-$as_echo "$ac_ct_MANIFEST_TOOL" >&6; }
-else
-fi
- if test "x$ac_ct_MANIFEST_TOOL" = x; then
- MANIFEST_TOOL=":"
- else
-yes:)
-esac
- MANIFEST_TOOL=$ac_ct_MANIFEST_TOOL
- fi
-else
- MANIFEST_TOOL="$ac_cv_prog_MANIFEST_TOOL"
-fi
-test -z "$MANIFEST_TOOL" && MANIFEST_TOOL=mt
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if $MANIFEST_TOOL is a manifest tool" >&5
-$as_echo_n "checking if $MANIFEST_TOOL is a manifest tool... " >&6; }
-if ${lt_cv_path_mainfest_tool+:} false; then :
-else
- lt_cv_path_mainfest_tool=no
- echo "$as_me:$LINENO: $MANIFEST_TOOL '-?'" >&5
- $MANIFEST_TOOL '-?' 2>conftest.err > conftest.out
- if $GREP 'Manifest Tool' conftest.out > /dev/null; then
- lt_cv_path_mainfest_tool=yes
- fi
- rm -f conftest*
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_path_mainfest_tool" >&5
-$as_echo "$lt_cv_path_mainfest_tool" >&6; }
-if test "x$lt_cv_path_mainfest_tool" != xyes; then
- MANIFEST_TOOL=:
-fi
- case $host_os in
- rhapsody* | darwin*)
- if test -n "$ac_tool_prefix"; then
- # Extract the first word of "${ac_tool_prefix}dsymutil", so it can be a program name with args.
-set dummy ${ac_tool_prefix}dsymutil; ac_word=$2
-if ${ac_cv_prog_DSYMUTIL+:} false; then :
-else
- if test -n "$DSYMUTIL"; then
- ac_cv_prog_DSYMUTIL="$DSYMUTIL" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_DSYMUTIL="${ac_tool_prefix}dsymutil"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-DSYMUTIL=$ac_cv_prog_DSYMUTIL
-if test -n "$DSYMUTIL"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $DSYMUTIL" >&5
-$as_echo "$DSYMUTIL" >&6; }
-else
-fi
-fi
-if test -z "$ac_cv_prog_DSYMUTIL"; then
- ac_ct_DSYMUTIL=$DSYMUTIL
- # Extract the first word of "dsymutil", so it can be a program name with args.
-set dummy dsymutil; ac_word=$2
-if ${ac_cv_prog_ac_ct_DSYMUTIL+:} false; then :
-else
- if test -n "$ac_ct_DSYMUTIL"; then
- ac_cv_prog_ac_ct_DSYMUTIL="$ac_ct_DSYMUTIL" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_DSYMUTIL="dsymutil"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-ac_ct_DSYMUTIL=$ac_cv_prog_ac_ct_DSYMUTIL
-if test -n "$ac_ct_DSYMUTIL"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_DSYMUTIL" >&5
-$as_echo "$ac_ct_DSYMUTIL" >&6; }
-else
-fi
- if test "x$ac_ct_DSYMUTIL" = x; then
- DSYMUTIL=":"
- else
-yes:)
-esac
- DSYMUTIL=$ac_ct_DSYMUTIL
- fi
-else
- DSYMUTIL="$ac_cv_prog_DSYMUTIL"
-fi
- # Extract the first word of "${ac_tool_prefix}nmedit", so it can be a program name with args.
-set dummy ${ac_tool_prefix}nmedit; ac_word=$2
-if ${ac_cv_prog_NMEDIT+:} false; then :
-else
- if test -n "$NMEDIT"; then
- ac_cv_prog_NMEDIT="$NMEDIT" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_NMEDIT="${ac_tool_prefix}nmedit"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-NMEDIT=$ac_cv_prog_NMEDIT
-if test -n "$NMEDIT"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $NMEDIT" >&5
-$as_echo "$NMEDIT" >&6; }
-else
-fi
-fi
-if test -z "$ac_cv_prog_NMEDIT"; then
- ac_ct_NMEDIT=$NMEDIT
- # Extract the first word of "nmedit", so it can be a program name with args.
-set dummy nmedit; ac_word=$2
-if ${ac_cv_prog_ac_ct_NMEDIT+:} false; then :
-else
- if test -n "$ac_ct_NMEDIT"; then
- ac_cv_prog_ac_ct_NMEDIT="$ac_ct_NMEDIT" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_NMEDIT="nmedit"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-ac_ct_NMEDIT=$ac_cv_prog_ac_ct_NMEDIT
-if test -n "$ac_ct_NMEDIT"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_NMEDIT" >&5
-$as_echo "$ac_ct_NMEDIT" >&6; }
-else
-fi
- if test "x$ac_ct_NMEDIT" = x; then
- NMEDIT=":"
- else
-yes:)
-esac
- NMEDIT=$ac_ct_NMEDIT
- fi
-else
- NMEDIT="$ac_cv_prog_NMEDIT"
-fi
- # Extract the first word of "${ac_tool_prefix}lipo", so it can be a program name with args.
-set dummy ${ac_tool_prefix}lipo; ac_word=$2
-if ${ac_cv_prog_LIPO+:} false; then :
-else
- if test -n "$LIPO"; then
- ac_cv_prog_LIPO="$LIPO" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_LIPO="${ac_tool_prefix}lipo"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-LIPO=$ac_cv_prog_LIPO
-if test -n "$LIPO"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $LIPO" >&5
-$as_echo "$LIPO" >&6; }
-else
-fi
-fi
-if test -z "$ac_cv_prog_LIPO"; then
- ac_ct_LIPO=$LIPO
- # Extract the first word of "lipo", so it can be a program name with args.
-set dummy lipo; ac_word=$2
-if ${ac_cv_prog_ac_ct_LIPO+:} false; then :
-else
- if test -n "$ac_ct_LIPO"; then
- ac_cv_prog_ac_ct_LIPO="$ac_ct_LIPO" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_LIPO="lipo"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-ac_ct_LIPO=$ac_cv_prog_ac_ct_LIPO
-if test -n "$ac_ct_LIPO"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_LIPO" >&5
-$as_echo "$ac_ct_LIPO" >&6; }
-else
-fi
- if test "x$ac_ct_LIPO" = x; then
- LIPO=":"
- else
-yes:)
-esac
- LIPO=$ac_ct_LIPO
- fi
-else
- LIPO="$ac_cv_prog_LIPO"
-fi
- # Extract the first word of "${ac_tool_prefix}otool", so it can be a program name with args.
-set dummy ${ac_tool_prefix}otool; ac_word=$2
-if ${ac_cv_prog_OTOOL+:} false; then :
-else
- if test -n "$OTOOL"; then
- ac_cv_prog_OTOOL="$OTOOL" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_OTOOL="${ac_tool_prefix}otool"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-OTOOL=$ac_cv_prog_OTOOL
-if test -n "$OTOOL"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $OTOOL" >&5
-$as_echo "$OTOOL" >&6; }
-else
-fi
-fi
-if test -z "$ac_cv_prog_OTOOL"; then
- ac_ct_OTOOL=$OTOOL
- # Extract the first word of "otool", so it can be a program name with args.
-set dummy otool; ac_word=$2
-if ${ac_cv_prog_ac_ct_OTOOL+:} false; then :
-else
- if test -n "$ac_ct_OTOOL"; then
- ac_cv_prog_ac_ct_OTOOL="$ac_ct_OTOOL" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_OTOOL="otool"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-ac_ct_OTOOL=$ac_cv_prog_ac_ct_OTOOL
-if test -n "$ac_ct_OTOOL"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_OTOOL" >&5
-$as_echo "$ac_ct_OTOOL" >&6; }
-else
-fi
- if test "x$ac_ct_OTOOL" = x; then
- OTOOL=":"
- else
-yes:)
-esac
- OTOOL=$ac_ct_OTOOL
- fi
-else
- OTOOL="$ac_cv_prog_OTOOL"
-fi
- # Extract the first word of "${ac_tool_prefix}otool64", so it can be a program name with args.
-set dummy ${ac_tool_prefix}otool64; ac_word=$2
-if ${ac_cv_prog_OTOOL64+:} false; then :
-else
- if test -n "$OTOOL64"; then
- ac_cv_prog_OTOOL64="$OTOOL64" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_OTOOL64="${ac_tool_prefix}otool64"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-OTOOL64=$ac_cv_prog_OTOOL64
-if test -n "$OTOOL64"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $OTOOL64" >&5
-$as_echo "$OTOOL64" >&6; }
-else
-fi
-fi
-if test -z "$ac_cv_prog_OTOOL64"; then
- ac_ct_OTOOL64=$OTOOL64
- # Extract the first word of "otool64", so it can be a program name with args.
-set dummy otool64; ac_word=$2
-if ${ac_cv_prog_ac_ct_OTOOL64+:} false; then :
-else
- if test -n "$ac_ct_OTOOL64"; then
- ac_cv_prog_ac_ct_OTOOL64="$ac_ct_OTOOL64" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_OTOOL64="otool64"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-ac_ct_OTOOL64=$ac_cv_prog_ac_ct_OTOOL64
-if test -n "$ac_ct_OTOOL64"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_OTOOL64" >&5
-$as_echo "$ac_ct_OTOOL64" >&6; }
-else
-fi
- if test "x$ac_ct_OTOOL64" = x; then
- OTOOL64=":"
- else
-yes:)
-esac
- OTOOL64=$ac_ct_OTOOL64
- fi
-else
- OTOOL64="$ac_cv_prog_OTOOL64"
-fi
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for -single_module linker flag" >&5
-$as_echo_n "checking for -single_module linker flag... " >&6; }
-if ${lt_cv_apple_cc_single_mod+:} false; then :
-else
- lt_cv_apple_cc_single_mod=no
- if test -z "${LT_MULTI_MODULE}"; then
- # By default we will add the -single_module flag. You can override
- # by either setting the environment variable LT_MULTI_MODULE
- # non-empty at configure time, or by adding -multi_module to the
- # link flags.
- rm -rf libconftest.dylib*
- echo "int foo(void){return 1;}" > conftest.c
- echo "$LTCC $LTCFLAGS $LDFLAGS -o libconftest.dylib \
--dynamiclib -Wl,-single_module conftest.c" >&5
- $LTCC $LTCFLAGS $LDFLAGS -o libconftest.dylib \
- -dynamiclib -Wl,-single_module conftest.c 2>conftest.err
- _lt_result=$?
- # If there is a non-empty error log, and "single_module"
- # appears in it, assume the flag caused a linker warning
- if test -s conftest.err && $GREP single_module conftest.err; then
- # Otherwise, if the output was created with a 0 exit code from
- # the compiler, it worked.
- elif test -f libconftest.dylib && test $_lt_result -eq 0; then
- lt_cv_apple_cc_single_mod=yes
- else
- fi
- rm -f conftest.*
- fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_apple_cc_single_mod" >&5
-$as_echo "$lt_cv_apple_cc_single_mod" >&6; }
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for -exported_symbols_list linker flag" >&5
-$as_echo_n "checking for -exported_symbols_list linker flag... " >&6; }
-if ${lt_cv_ld_exported_symbols_list+:} false; then :
-else
- lt_cv_ld_exported_symbols_list=no
- save_LDFLAGS=$LDFLAGS
- echo "_main" > conftest.sym
- LDFLAGS="$LDFLAGS -Wl,-exported_symbols_list,conftest.sym"
-int
-main ()
- return 0;
-_ACEOF
- lt_cv_ld_exported_symbols_list=yes
-else
-fi
- LDFLAGS="$save_LDFLAGS"
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_ld_exported_symbols_list" >&5
-$as_echo "$lt_cv_ld_exported_symbols_list" >&6; }
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for -force_load linker flag" >&5
-$as_echo_n "checking for -force_load linker flag... " >&6; }
-if ${lt_cv_ld_force_load+:} false; then :
-else
- lt_cv_ld_force_load=no
- cat > conftest.c << _LT_EOF
-int forced_loaded() { return 2;}
-_LT_EOF
- echo "$LTCC $LTCFLAGS -c -o conftest.o conftest.c" >&5
- $LTCC $LTCFLAGS -c -o conftest.o conftest.c 2>&5
- echo "$AR cru libconftest.a conftest.o" >&5
- $AR cru libconftest.a conftest.o 2>&5
- echo "$RANLIB libconftest.a" >&5
- $RANLIB libconftest.a 2>&5
-int main() { return 0;}
-_LT_EOF
- echo "$LTCC $LTCFLAGS $LDFLAGS -o conftest conftest.c -Wl,-force_load,./libconftest.a" >&5
- $LTCC $LTCFLAGS $LDFLAGS -o conftest conftest.c -Wl,-force_load,./libconftest.a 2>conftest.err
- _lt_result=$?
- if test -s conftest.err && $GREP force_load conftest.err; then
- elif test -f conftest && test $_lt_result -eq 0 && $GREP forced_load conftest >/dev/null 2>&1 ; then
- lt_cv_ld_force_load=yes
- else
- fi
- rm -f conftest.err libconftest.a conftest conftest.c
- rm -rf conftest.dSYM
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_ld_force_load" >&5
-$as_echo "$lt_cv_ld_force_load" >&6; }
- case $host_os in
- rhapsody* | darwin1.[012])
- _lt_dar_allow_undefined='${wl}-undefined ${wl}suppress' ;;
- darwin1.*)
- _lt_dar_allow_undefined='${wl}-flat_namespace ${wl}-undefined ${wl}suppress' ;;
- darwin*) # darwin 5.x on
- # if running on 10.5 or later, the deployment target defaults
- # to the OS version, if on x86, and 10.4, the deployment
- # target defaults to 10.4. Don't you love it?
- case ${MACOSX_DEPLOYMENT_TARGET-10.0},$host in
- 10.0,*86*-darwin8*|10.0,*-darwin[91]*)
- _lt_dar_allow_undefined='${wl}-undefined ${wl}dynamic_lookup' ;;
- 10.[012]*)
- 10.*)
- esac
- esac
- if test "$lt_cv_apple_cc_single_mod" = "yes"; then
- _lt_dar_single_mod='$single_module'
- fi
- if test "$lt_cv_ld_exported_symbols_list" = "yes"; then
- _lt_dar_export_syms=' ${wl}-exported_symbols_list,$output_objdir/${libname}-symbols.expsym'
- else
- _lt_dar_export_syms='~$NMEDIT -s $output_objdir/${libname}-symbols.expsym ${lib}'
- fi
- if test "$DSYMUTIL" != ":" && test "$lt_cv_ld_force_load" = "no"; then
- _lt_dsymutil='~$DSYMUTIL $lib || :'
- else
- _lt_dsymutil=
- fi
- esac
-ac_ext=c
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to run the C preprocessor" >&5
-$as_echo_n "checking how to run the C preprocessor... " >&6; }
-# On Suns, sometimes $CPP names a directory.
-if test -n "$CPP" && test -d "$CPP"; then
- CPP=
-fi
-if test -z "$CPP"; then
- if ${ac_cv_prog_CPP+:} false; then :
-else
- # Double quotes because CPP needs to be expanded
- for CPP in "$CC -E" "$CC -E -traditional-cpp" "/lib/cpp"
- do
- ac_preproc_ok=false
-for ac_c_preproc_warn_flag in '' yes
-do
- # Use a header file that comes with gcc, so configuring glibc
- # with a fresh cross-compiler works.
- # Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
- # <limits.h> exists even on freestanding compilers.
- # On the NeXT, cc -E runs the code through the compiler's parser,
- # not just through cpp. "Syntax error" is here to catch this case.
-#ifdef __STDC__
-# include <limits.h>
-#else
-# include <assert.h>
-#endif
- Syntax error
-_ACEOF
-if ac_fn_c_try_cpp "$LINENO"; then :
-else
- # Broken: fails on valid input.
-continue
-fi
-rm -f conftest.err conftest.i conftest.$ac_ext
- # OK, works on sane cases. Now check whether nonexistent headers
- # can be detected and how.
-#include <ac_nonexistent.h>
-_ACEOF
- # Broken: success on invalid input.
-continue
-else
- # Passes both tests.
-ac_preproc_ok=:
-break
-fi
-done
-# Because of `break', _AC_PREPROC_IFELSE's cleaning code was skipped.
-rm -f conftest.i conftest.err conftest.$ac_ext
-if $ac_preproc_ok; then :
- break
-fi
- done
- ac_cv_prog_CPP=$CPP
-fi
- CPP=$ac_cv_prog_CPP
-else
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $CPP" >&5
-$as_echo "$CPP" >&6; }
-ac_preproc_ok=false
-do
-#ifdef __STDC__
-#else
-#endif
- Syntax error
-_ACEOF
-else
-continue
-fi
-_ACEOF
-continue
-else
-ac_preproc_ok=:
-break
-fi
-done
-else
- { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
-$as_echo "$as_me: error: in \`$ac_pwd':" >&2;}
-as_fn_error $? "C preprocessor \"$CPP\" fails sanity check
-See \`config.log' for more details" "$LINENO" 5; }
-fi
-ac_ext=c
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for ANSI C header files" >&5
-$as_echo_n "checking for ANSI C header files... " >&6; }
-if ${ac_cv_header_stdc+:} false; then :
-else
-#include <stdlib.h>
-#include <stdarg.h>
-#include <string.h>
-#include <float.h>
-int
-main ()
- return 0;
-_ACEOF
- ac_cv_header_stdc=yes
-else
- ac_cv_header_stdc=no
-fi
-if test $ac_cv_header_stdc = yes; then
- # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-_ACEOF
-if (eval "$ac_cpp conftest.$ac_ext") 2>&5 |
- $EGREP "memchr" >/dev/null 2>&1; then :
-else
-fi
-rm -f conftest*
-fi
- # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-_ACEOF
- $EGREP "free" >/dev/null 2>&1; then :
-else
-fi
-rm -f conftest*
-fi
- # /bin/cc in Irix-4.0.5 gets non-ANSI ctype macros unless using -ansi.
- if test "$cross_compiling" = yes; then :
-else
-#include <ctype.h>
-#if ((' ' & 0x0FF) == 0x020)
-# define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
-# define TOUPPER(c) (ISLOWER(c) ? 'A' + ((c) - 'a') : (c))
-#else
-# define ISLOWER(c) \
- (('a' <= (c) && (c) <= 'i') \
- || ('j' <= (c) && (c) <= 'r') \
- || ('s' <= (c) && (c) <= 'z'))
-# define TOUPPER(c) (ISLOWER(c) ? ((c) | 0x40) : (c))
-#endif
-#define XOR(e, f) (((e) && !(f)) || (!(e) && (f)))
-int
-main ()
- int i;
- for (i = 0; i < 256; i++)
- if (XOR (islower (i), ISLOWER (i))
- || toupper (i) != TOUPPER (i))
- return 2;
- return 0;
-_ACEOF
-if ac_fn_c_try_run "$LINENO"; then :
-else
-fi
-rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext \
- conftest.$ac_objext conftest.beam conftest.$ac_ext
-fi
-fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_header_stdc" >&5
-$as_echo "$ac_cv_header_stdc" >&6; }
-$as_echo "#define STDC_HEADERS 1" >>confdefs.h
-fi
-# On IRIX 5.3, sys/types and inttypes.h are conflicting.
-for ac_header in sys/types.h sys/stat.h stdlib.h string.h memory.h strings.h \
- inttypes.h stdint.h unistd.h
-do :
- as_ac_Header=`$as_echo "ac_cv_header_$ac_header" | $as_tr_sh`
-ac_fn_c_check_header_compile "$LINENO" "$ac_header" "$as_ac_Header" "$ac_includes_default
-if eval test \"x\$"$as_ac_Header"\" = x"yes"; then :
- cat >>confdefs.h <<_ACEOF
-#define `$as_echo "HAVE_$ac_header" | $as_tr_cpp` 1
-_ACEOF
-fi
-done
-for ac_header in dlfcn.h
-do :
- ac_fn_c_check_header_compile "$LINENO" "dlfcn.h" "ac_cv_header_dlfcn_h" "$ac_includes_default
-if test "x$ac_cv_header_dlfcn_h" = xyes; then :
-#define HAVE_DLFCN_H 1
-_ACEOF
-fi
-done
-# Set options
- enable_dlopen=no
- enable_win32_dll=no
- # Check whether --enable-shared was given.
-if test "${enable_shared+set}" = set; then :
- enableval=$enable_shared; p=${PACKAGE-default}
- case $enableval in
- yes) enable_shared=yes ;;
- no) enable_shared=no ;;
- enable_shared=no
- # Look at the argument we got. We use all the common list separators.
- lt_save_ifs="$IFS"; IFS="${IFS}$PATH_SEPARATOR,"
- for pkg in $enableval; do
- if test "X$pkg" = "X$p"; then
- enable_shared=yes
- fi
- done
- esac
-else
- enable_shared=yes
-fi
- # Check whether --enable-static was given.
-if test "${enable_static+set}" = set; then :
- enableval=$enable_static; p=${PACKAGE-default}
- yes) enable_static=yes ;;
- no) enable_static=no ;;
- enable_static=no
- enable_static=yes
- fi
- done
- esac
-else
- enable_static=yes
-fi
-# Check whether --with-pic was given.
-if test "${with_pic+set}" = set; then :
- withval=$with_pic; lt_p=${PACKAGE-default}
- case $withval in
- yes|no) pic_mode=$withval ;;
- pic_mode=default
- for lt_pkg in $withval; do
- if test "X$lt_pkg" = "X$lt_p"; then
- pic_mode=yes
- fi
- done
- esac
-else
- pic_mode=default
-fi
-test -z "$pic_mode" && pic_mode=default
- # Check whether --enable-fast-install was given.
-if test "${enable_fast_install+set}" = set; then :
- enableval=$enable_fast_install; p=${PACKAGE-default}
- yes) enable_fast_install=yes ;;
- no) enable_fast_install=no ;;
- enable_fast_install=no
- enable_fast_install=yes
- fi
- done
- IFS="$lt_save_ifs"
- esac
-else
-fi
-# This can be used to rebuild libtool when needed
-LIBTOOL_DEPS="$ltmain"
-# Always use our own libtool.
-LIBTOOL='$(SHELL) $(top_builddir)/libtool'
-test -z "$LN_S" && LN_S="ln -s"
-if test -n "${ZSH_VERSION+set}" ; then
- setopt NO_GLOB_SUBST
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for objdir" >&5
-$as_echo_n "checking for objdir... " >&6; }
-if ${lt_cv_objdir+:} false; then :
- $as_echo_n "(cached) " >&6
-else
- rm -f .libs 2>/dev/null
-mkdir .libs 2>/dev/null
-if test -d .libs; then
- lt_cv_objdir=.libs
-else
- # MS-DOS does not allow filenames that begin with a dot.
- lt_cv_objdir=_libs
-fi
-rmdir .libs 2>/dev/null
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_objdir" >&5
-$as_echo "$lt_cv_objdir" >&6; }
-objdir=$lt_cv_objdir
-cat >>confdefs.h <<_ACEOF
-#define LT_OBJDIR "$lt_cv_objdir/"
-_ACEOF
-case $host_os in
-aix3*)
- # AIX sometimes has problems with the GCC collect2 program. For some
- # reason, if we set the COLLECT_NAMES environment variable, the problems
- # vanish in a puff of smoke.
- if test "X${COLLECT_NAMES+set}" != Xset; then
- COLLECT_NAMES=
- export COLLECT_NAMES
- fi
-esac
-# Global variables:
-ofile=libtool
-can_build_shared=yes
-# All known linkers require a `.a' archive for static linking (except MSVC,
-# which needs '.lib').
-libext=a
-with_gnu_ld="$lt_cv_prog_gnu_ld"
-old_CC="$CC"
-old_CFLAGS="$CFLAGS"
-# Set sane defaults for various variables
-test -z "$CC" && CC=cc
-test -z "$LTCC" && LTCC=$CC
-test -z "$LTCFLAGS" && LTCFLAGS=$CFLAGS
-test -z "$LD" && LD=ld
-test -z "$ac_objext" && ac_objext=o
-for cc_temp in $compiler""; do
- case $cc_temp in
- compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
- distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
- *) break;;
- esac
-done
-cc_basename=`$ECHO "$cc_temp" | $SED "s%.*/%%; s%^$host_alias-%%"`
-# Only perform the check for file, if the check method requires it
-test -z "$MAGIC_CMD" && MAGIC_CMD=file
-case $deplibs_check_method in
-file_magic*)
- if test "$file_magic_cmd" = '$MAGIC_CMD'; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for ${ac_tool_prefix}file" >&5
-$as_echo_n "checking for ${ac_tool_prefix}file... " >&6; }
-if ${lt_cv_path_MAGIC_CMD+:} false; then :
-else
- case $MAGIC_CMD in
- lt_cv_path_MAGIC_CMD="$MAGIC_CMD" # Let the user override the test with a path.
- lt_save_MAGIC_CMD="$MAGIC_CMD"
- lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
- ac_dummy="/usr/bin$PATH_SEPARATOR$PATH"
- for ac_dir in $ac_dummy; do
- test -z "$ac_dir" && ac_dir=.
- if test -f $ac_dir/${ac_tool_prefix}file; then
- lt_cv_path_MAGIC_CMD="$ac_dir/${ac_tool_prefix}file"
- if test -n "$file_magic_test_file"; then
- case $deplibs_check_method in
- "file_magic "*)
- file_magic_regex=`expr "$deplibs_check_method" : "file_magic \(.*\)"`
- MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
- if eval $file_magic_cmd \$file_magic_test_file 2> /dev/null |
- $EGREP "$file_magic_regex" > /dev/null; then
- else
- cat <<_LT_EOF 1>&2
-*** Warning: the command libtool uses to detect shared libraries,
-*** $file_magic_cmd, produces output that libtool cannot recognize.
-*** The result is that libtool may fail to recognize shared libraries
-*** as such. This will affect the creation of libtool libraries that
-*** depend on shared libraries, but programs linked with such libtool
-*** libraries will work regardless of this problem. Nevertheless, you
-*** may want to report the problem to your system manager and/or to
-*** bug-libtool at gnu.org
-_LT_EOF
- fi ;;
- esac
- fi
- break
- fi
- done
- MAGIC_CMD="$lt_save_MAGIC_CMD"
-esac
-fi
-MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
-if test -n "$MAGIC_CMD"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $MAGIC_CMD" >&5
-$as_echo "$MAGIC_CMD" >&6; }
-else
-fi
-if test -z "$lt_cv_path_MAGIC_CMD"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for file" >&5
-$as_echo_n "checking for file... " >&6; }
-else
- if test -f $ac_dir/file; then
- lt_cv_path_MAGIC_CMD="$ac_dir/file"
- "file_magic "*)
- else
-_LT_EOF
- fi ;;
- esac
- fi
- break
- fi
- done
-esac
-fi
-else
-fi
- else
- MAGIC_CMD=:
- fi
-fi
- fi
-esac
-# Use C for the default configuration in the libtool script
-lt_save_CC="$CC"
-ac_ext=c
-# Source file extension for C test sources.
-ac_ext=c
-# Object file extension for compiled C test sources.
-objext=o
-objext=$objext
-# Code to be used in simple compile tests
-lt_simple_compile_test_code="int some_variable = 0;"
-# Code to be used in simple link tests
-lt_simple_link_test_code='int main(){return(0);}'
-LTCC=${LTCC-"$CC"}
-compiler=$CC
-# Save the default compiler, since it gets overwritten when the other
-# tags are being tested, and _LT_TAGVAR(compiler, []) is a NOP.
-compiler_DEFAULT=$CC
-# save warnings/boilerplate of simple test code
-ac_outfile=conftest.$ac_objext
-echo "$lt_simple_compile_test_code" >conftest.$ac_ext
-eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
-_lt_compiler_boilerplate=`cat conftest.err`
-$RM conftest*
-echo "$lt_simple_link_test_code" >conftest.$ac_ext
-eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
-_lt_linker_boilerplate=`cat conftest.err`
-$RM -r conftest*
-if test -n "$compiler"; then
-lt_prog_compiler_no_builtin_flag=
-if test "$GCC" = yes; then
- case $cc_basename in
- nvcc*)
- lt_prog_compiler_no_builtin_flag=' -Xcompiler -fno-builtin' ;;
- lt_prog_compiler_no_builtin_flag=' -fno-builtin' ;;
- esac
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler supports -fno-rtti -fno-exceptions" >&5
-$as_echo_n "checking if $compiler supports -fno-rtti -fno-exceptions... " >&6; }
-if ${lt_cv_prog_compiler_rtti_exceptions+:} false; then :
-else
- lt_cv_prog_compiler_rtti_exceptions=no
- ac_outfile=conftest.$ac_objext
- echo "$lt_simple_compile_test_code" > conftest.$ac_ext
- lt_compiler_flag="-fno-rtti -fno-exceptions"
- # Insert the option either (1) after the last *FLAGS variable, or
- # (2) before a word containing "conftest.", or (3) at the end.
- # Note that $ac_compile itself does not contain backslashes and begins
- # with a dollar sign (not a hyphen), so the echo should work correctly.
- # The option is referenced via a variable to avoid confusing sed.
- lt_compile=`echo "$ac_compile" | $SED \
- -e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
- -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
- -e 's:$: $lt_compiler_flag:'`
- (eval echo "\"\$as_me:$LINENO: $lt_compile\"" >&5)
- (eval "$lt_compile" 2>conftest.err)
- ac_status=$?
- cat conftest.err >&5
- echo "$as_me:$LINENO: \$? = $ac_status" >&5
- if (exit $ac_status) && test -s "$ac_outfile"; then
- # The compiler can only warn and ignore the option if not recognized
- # So say no if there are warnings other than the usual output.
- $ECHO "$_lt_compiler_boilerplate" | $SED '/^$/d' >conftest.exp
- $SED '/^$/d; /^ *+/d' conftest.err >conftest.er2
- if test ! -s conftest.er2 || diff conftest.exp conftest.er2 >/dev/null; then
- lt_cv_prog_compiler_rtti_exceptions=yes
- fi
- fi
- $RM conftest*
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_rtti_exceptions" >&5
-$as_echo "$lt_cv_prog_compiler_rtti_exceptions" >&6; }
-if test x"$lt_cv_prog_compiler_rtti_exceptions" = xyes; then
- lt_prog_compiler_no_builtin_flag="$lt_prog_compiler_no_builtin_flag -fno-rtti -fno-exceptions"
-else
-fi
-fi
- lt_prog_compiler_wl=
-lt_prog_compiler_pic=
-lt_prog_compiler_static=
- if test "$GCC" = yes; then
- lt_prog_compiler_wl='-Wl,'
- lt_prog_compiler_static='-static'
- case $host_os in
- aix*)
- # All AIX code is PIC.
- # AIX 5 now supports IA64 processor
- lt_prog_compiler_static='-Bstatic'
- fi
- amigaos*)
- case $host_cpu in
- powerpc)
- # see comment about AmigaOS4 .so support
- lt_prog_compiler_pic='-fPIC'
- m68k)
- # FIXME: we need at least 68020 code to build shared libraries, but
- # adding the `-m68020' flag to GCC prevents building anything better,
- # like `-m68040'.
- lt_prog_compiler_pic='-m68020 -resident32 -malways-restore-a4'
- esac
- beos* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
- # PIC is the default for these OSes.
- mingw* | cygwin* | pw32* | os2* | cegcc*)
- # This hack is so that the source file can tell whether it is being
- # built for inclusion in a dll (and should export symbols for example).
- # Although the cygwin gcc ignores -fPIC, still need this for old-style
- # (--disable-auto-import) libraries
- lt_prog_compiler_pic='-DDLL_EXPORT'
- darwin* | rhapsody*)
- # PIC is the default on this platform
- # Common symbols not allowed in MH_DYLIB files
- lt_prog_compiler_pic='-fno-common'
- haiku*)
- # PIC is the default for Haiku.
- # The "-static" flag exists, but is broken.
- hpux*)
- # PIC is the default for 64-bit PA HP-UX, but not for 32-bit
- # PA HP-UX. On IA64 HP-UX, PIC is the default but the pic flag
- # sets the default TLS model and affects inlining.
- case $host_cpu in
- hppa*64*)
- # +Z the default
- esac
- interix[3-9]*)
- # Interix 3.x gcc -fpic/-fPIC options generate broken code.
- # Instead, we relocate shared libraries at runtime.
- msdosdjgpp*)
- # Just because we use GCC doesn't mean we suddenly get shared libraries
- # on systems that don't support them.
- lt_prog_compiler_can_build_shared=no
- enable_shared=no
- *nto* | *qnx*)
- # QNX uses GNU C++, but need to define -shared option too, otherwise
- # it will coredump.
- lt_prog_compiler_pic='-fPIC -shared'
- sysv4*MP*)
- if test -d /usr/nec; then
- lt_prog_compiler_pic=-Kconform_pic
- fi
- esac
- nvcc*) # Cuda Compiler Driver 2.2
- lt_prog_compiler_wl='-Xlinker '
- if test -n "$lt_prog_compiler_pic"; then
- lt_prog_compiler_pic="-Xcompiler $lt_prog_compiler_pic"
- fi
- esac
- else
- # PORTME Check for flag to pass linker flags through the system compiler.
- case $host_os in
- aix*)
- else
- lt_prog_compiler_static='-bnso -bI:/lib/syscalls.exp'
- fi
- hpux9* | hpux10* | hpux11*)
- # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
- # not for PA HP-UX.
- case $host_cpu in
- hppa*64*|ia64*)
- # +Z the default
- lt_prog_compiler_pic='+Z'
- esac
- # Is there a better lt_prog_compiler_static that works with the bundled CC?
- lt_prog_compiler_static='${wl}-a ${wl}archive'
- irix5* | irix6* | nonstopux*)
- # PIC (with -KPIC) is the default.
- lt_prog_compiler_static='-non_shared'
- linux* | k*bsd*-gnu | kopensolaris*-gnu)
- # old Intel for x86_64 which still supported -KPIC.
- ecc*)
- lt_prog_compiler_pic='-KPIC'
- # icc used to be incompatible with GCC.
- # ICC 10 doesn't accept -KPIC any more.
- icc* | ifort*)
- # Lahey Fortran 8.1.
- lf95*)
- lt_prog_compiler_pic='--shared'
- lt_prog_compiler_static='--static'
- nagfor*)
- # NAG Fortran compiler
- lt_prog_compiler_wl='-Wl,-Wl,,'
- lt_prog_compiler_pic='-PIC'
- pgcc* | pgf77* | pgf90* | pgf95* | pgfortran*)
- # Portland Group compilers (*not* the Pentium gcc compiler,
- # which looks to be a dead project)
- lt_prog_compiler_pic='-fpic'
- ccc*)
- # All Alpha code is PIC.
- xl* | bgxl* | bgf* | mpixl*)
- # IBM XL C 8.0/Fortran 10.1, 11.1 on PPC and BlueGene
- lt_prog_compiler_pic='-qpic'
- lt_prog_compiler_static='-qstaticlink'
- case `$CC -V 2>&1 | sed 5q` in
- *Sun\ Ceres\ Fortran* | *Sun*Fortran*\ [1-7].* | *Sun*Fortran*\ 8.[0-3]*)
- # Sun Fortran 8.3 passes all unrecognized flags to the linker
- lt_prog_compiler_wl=''
- *Sun\ F* | *Sun*Fortran*)
- lt_prog_compiler_wl='-Qoption ld '
- *Sun\ C*)
- # Sun C 5.9
- *Intel*\ [CF]*Compiler*)
- *Portland\ Group*)
- esac
- esac
- newsos6)
- *nto* | *qnx*)
- osf3* | osf4* | osf5*)
- # All OSF/1 code is PIC.
- rdos*)
- solaris*)
- f77* | f90* | f95* | sunf77* | sunf90* | sunf95*)
- lt_prog_compiler_wl='-Qoption ld ';;
- lt_prog_compiler_wl='-Wl,';;
- esac
- sunos4*)
- sysv4 | sysv4.2uw2* | sysv4.3*)
- sysv4*MP*)
- if test -d /usr/nec ;then
- lt_prog_compiler_pic='-Kconform_pic'
- fi
- sysv5* | unixware* | sco3.2v5* | sco5v6* | OpenUNIX*)
- unicos*)
- uts4*)
- lt_prog_compiler_pic='-pic'
- esac
- fi
-case $host_os in
- # For platforms which do not support PIC, -DPIC is meaningless:
- *djgpp*)
- lt_prog_compiler_pic="$lt_prog_compiler_pic -DPIC"
-esac
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $compiler option to produce PIC" >&5
-$as_echo_n "checking for $compiler option to produce PIC... " >&6; }
-if ${lt_cv_prog_compiler_pic+:} false; then :
-else
- lt_cv_prog_compiler_pic=$lt_prog_compiler_pic
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_pic" >&5
-$as_echo "$lt_cv_prog_compiler_pic" >&6; }
-lt_prog_compiler_pic=$lt_cv_prog_compiler_pic
-# Check to make sure the PIC flag actually works.
-if test -n "$lt_prog_compiler_pic"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler PIC flag $lt_prog_compiler_pic works" >&5
-$as_echo_n "checking if $compiler PIC flag $lt_prog_compiler_pic works... " >&6; }
-if ${lt_cv_prog_compiler_pic_works+:} false; then :
-else
- lt_cv_prog_compiler_pic_works=no
- lt_compiler_flag="$lt_prog_compiler_pic -DPIC"
- ac_status=$?
- lt_cv_prog_compiler_pic_works=yes
- fi
- fi
- $RM conftest*
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_pic_works" >&5
-$as_echo "$lt_cv_prog_compiler_pic_works" >&6; }
-if test x"$lt_cv_prog_compiler_pic_works" = xyes; then
- case $lt_prog_compiler_pic in
- *) lt_prog_compiler_pic=" $lt_prog_compiler_pic" ;;
- esac
-else
-fi
-fi
-# Check to make sure the static flag actually works.
-wl=$lt_prog_compiler_wl eval lt_tmp_static_flag=\"$lt_prog_compiler_static\"
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler static flag $lt_tmp_static_flag works" >&5
-$as_echo_n "checking if $compiler static flag $lt_tmp_static_flag works... " >&6; }
-if ${lt_cv_prog_compiler_static_works+:} false; then :
-else
- lt_cv_prog_compiler_static_works=no
- save_LDFLAGS="$LDFLAGS"
- LDFLAGS="$LDFLAGS $lt_tmp_static_flag"
- echo "$lt_simple_link_test_code" > conftest.$ac_ext
- if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
- # The linker can only warn and ignore the option if not recognized
- if test -s conftest.err; then
- # Append any errors to the config.log.
- cat conftest.err 1>&5
- $ECHO "$_lt_linker_boilerplate" | $SED '/^$/d' > conftest.exp
- if diff conftest.exp conftest.er2 >/dev/null; then
- lt_cv_prog_compiler_static_works=yes
- fi
- else
- fi
- fi
- $RM -r conftest*
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_static_works" >&5
-$as_echo "$lt_cv_prog_compiler_static_works" >&6; }
-if test x"$lt_cv_prog_compiler_static_works" = xyes; then
-else
-fi
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler supports -c -o file.$ac_objext" >&5
-$as_echo_n "checking if $compiler supports -c -o file.$ac_objext... " >&6; }
-if ${lt_cv_prog_compiler_c_o+:} false; then :
-else
- lt_cv_prog_compiler_c_o=no
- $RM -r conftest 2>/dev/null
- mkdir conftest
- cd conftest
- mkdir out
- lt_compiler_flag="-o out/conftest2.$ac_objext"
- (eval "$lt_compile" 2>out/conftest.err)
- ac_status=$?
- cat out/conftest.err >&5
- if (exit $ac_status) && test -s out/conftest2.$ac_objext
- then
- $ECHO "$_lt_compiler_boilerplate" | $SED '/^$/d' > out/conftest.exp
- $SED '/^$/d; /^ *+/d' out/conftest.err >out/conftest.er2
- if test ! -s out/conftest.er2 || diff out/conftest.exp out/conftest.er2 >/dev/null; then
- lt_cv_prog_compiler_c_o=yes
- fi
- fi
- chmod u+w . 2>&5
- $RM conftest*
- # SGI C++ compiler will create directory out/ii_files/ for
- # template instantiation
- test -d out/ii_files && $RM out/ii_files/* && rmdir out/ii_files
- $RM out/* && rmdir out
- cd ..
- $RM -r conftest
- $RM conftest*
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_c_o" >&5
-$as_echo "$lt_cv_prog_compiler_c_o" >&6; }
-else
- mkdir conftest
- cd conftest
- mkdir out
- ac_status=$?
- then
- fi
- fi
- chmod u+w . 2>&5
- $RM conftest*
- cd ..
- $RM -r conftest
- $RM conftest*
-fi
-hard_links="nottested"
-if test "$lt_cv_prog_compiler_c_o" = no && test "$need_locks" != no; then
- # do not overwrite the value of need_locks provided by the user
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking if we can lock with hard links" >&5
-$as_echo_n "checking if we can lock with hard links... " >&6; }
- hard_links=yes
- $RM conftest*
- ln conftest.a conftest.b 2>/dev/null && hard_links=no
- touch conftest.a
- ln conftest.a conftest.b 2>&5 || hard_links=no
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $hard_links" >&5
-$as_echo "$hard_links" >&6; }
- if test "$hard_links" = no; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
-$as_echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
- need_locks=warn
- fi
-else
- need_locks=no
-fi
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the $compiler linker ($LD) supports shared libraries" >&5
-$as_echo_n "checking whether the $compiler linker ($LD) supports shared libraries... " >&6; }
- runpath_var=
- allow_undefined_flag=
- always_export_symbols=no
- archive_cmds=
- archive_expsym_cmds=
- compiler_needs_object=no
- enable_shared_with_static_runtimes=no
- export_dynamic_flag_spec=
- export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
- hardcode_automatic=no
- hardcode_direct=no
- hardcode_direct_absolute=no
- hardcode_libdir_flag_spec=
- hardcode_libdir_separator=
- hardcode_minus_L=no
- hardcode_shlibpath_var=unsupported
- inherit_rpath=no
- link_all_deplibs=unknown
- module_cmds=
- module_expsym_cmds=
- old_archive_from_new_cmds=
- old_archive_from_expsyms_cmds=
- thread_safe_flag_spec=
- whole_archive_flag_spec=
- # include_expsyms should be a list of space-separated symbols to be *always*
- # included in the symbol list
- include_expsyms=
- # exclude_expsyms can be an extended regexp of symbols to exclude
- # it will be wrapped by ` (' and `)$', so one must not match beginning or
- # end of line. Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
- # as well as any symbol that contains `d'.
- exclude_expsyms='_GLOBAL_OFFSET_TABLE_|_GLOBAL__F[ID]_.*'
- # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
- # platforms (ab)use it in PIC code, but their linkers get confused if
- # the symbol is explicitly referenced. Since portable code cannot
- # rely on this symbol name, it's probably fine to never include it in
- # preloaded symbol tables.
- # Exclude shared library initialization/finalization symbols.
- extract_expsyms_cmds=
- case $host_os in
- cygwin* | mingw* | pw32* | cegcc*)
- # FIXME: the MSVC++ port hasn't been tested in a loooong time
- # When not using gcc, we currently assume that we are using
- # Microsoft Visual C++.
- if test "$GCC" != yes; then
- with_gnu_ld=no
- fi
- interix*)
- # we just hope/assume this is gcc and not c89 (= MSVC++)
- with_gnu_ld=yes
- openbsd*)
- with_gnu_ld=no
- linux* | k*bsd*-gnu | gnu*)
- link_all_deplibs=no
- esac
- ld_shlibs=yes
- # On some targets, GNU ld is compatible enough with the native linker
- # that we're better off using the native interface for both.
- lt_use_gnu_ld_interface=no
- if test "$with_gnu_ld" = yes; then
- case $host_os in
- aix*)
- # The AIX port of GNU ld has always aspired to compatibility
- # with the native linker. However, as the warning in the GNU ld
- # block says, versions before 2.19.5* couldn't really create working
- # shared libraries, regardless of the interface used.
- case `$LD -v 2>&1` in
- *\ \(GNU\ Binutils\)\ 2.19.5*) ;;
- *\ \(GNU\ Binutils\)\ 2.[2-9]*) ;;
- *\ \(GNU\ Binutils\)\ [3-9]*) ;;
- lt_use_gnu_ld_interface=yes
- esac
- esac
- fi
- if test "$lt_use_gnu_ld_interface" = yes; then
- # If archive_cmds runs LD, not CC, wlarc should be empty
- wlarc='${wl}'
- # Set some defaults for GNU ld with shared library support. These
- # are reset later if shared libraries are not supported. Putting them
- # here allows them to be overridden if necessary.
- runpath_var=LD_RUN_PATH
- hardcode_libdir_flag_spec='${wl}-rpath ${wl}$libdir'
- export_dynamic_flag_spec='${wl}--export-dynamic'
- # ancient GNU ld didn't support --whole-archive et. al.
- if $LD --help 2>&1 | $GREP 'no-whole-archive' > /dev/null; then
- whole_archive_flag_spec="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
- else
- fi
- supports_anon_versioning=no
- *GNU\ gold*) supports_anon_versioning=yes ;;
- *\ [01].* | *\ 2.[0-9].* | *\ 2.10.*) ;; # catch versions < 2.11
- *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
- *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
- *\ 2.11.*) ;; # other 2.11 versions
- *) supports_anon_versioning=yes ;;
- esac
- # See if GNU ld supports shared libraries.
- case $host_os in
- aix[3-9]*)
- # On AIX/PPC, the GNU linker is very broken
- if test "$host_cpu" != ia64; then
- ld_shlibs=no
-*** Warning: the GNU linker, at least up to release 2.19, is reported
-*** to be unable to reliably create shared libraries on AIX.
-*** Therefore, libtool is disabling shared libraries support. If you
-*** really care for shared libraries, you may want to install binutils
-*** 2.20 or above, or modify your PATH so that a non-GNU linker is found.
-*** You will then need to restart the configuration process.
-_LT_EOF
- fi
- amigaos*)
- case $host_cpu in
- powerpc)
- archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_expsym_cmds=''
- m68k)
- archive_cmds='$RM $output_objdir/a2ixlibrary.data~$ECHO "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$ECHO "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$ECHO "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$ECHO "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
- hardcode_libdir_flag_spec='-L$libdir'
- hardcode_minus_L=yes
- esac
- beos*)
- if $LD --help 2>&1 | $GREP ': supported targets:.* elf' > /dev/null; then
- allow_undefined_flag=unsupported
- # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
- # support --undefined. This deserves some investigation. FIXME
- archive_cmds='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- else
- ld_shlibs=no
- fi
- # _LT_TAGVAR(hardcode_libdir_flag_spec, ) is actually meaningless,
- # as there is no search path for DLLs.
- export_dynamic_flag_spec='${wl}--export-all-symbols'
- enable_shared_with_static_runtimes=yes
- export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS][ ]/s/.*[ ]\([^ ]*\)/\1 DATA/;s/^.*[ ]__nm__\([^ ]*\)[ ][^ ]*/\1 DATA/;/^I[ ]/d;/^[AITW][ ]/s/.* //'\'' | sort | uniq > $export_symbols'
- exclude_expsyms='[_]+GLOBAL_OFFSET_TABLE_|[_]+GLOBAL__[FID]_.*|[_]+head_[A-Za-z0-9_]+_dll|[A-Za-z0-9_]+_dll_iname'
- if $LD --help 2>&1 | $GREP 'auto-import' > /dev/null; then
- archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
- # If the export-symbols file already is a .def file (1st line
- # is EXPORTS), use it as is; otherwise, prepend...
- archive_expsym_cmds='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
- cp $export_symbols $output_objdir/$soname.def;
- else
- echo EXPORTS > $output_objdir/$soname.def;
- cat $export_symbols >> $output_objdir/$soname.def;
- fi~
- $CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
- else
- ld_shlibs=no
- fi
- haiku*)
- link_all_deplibs=yes
- interix[3-9]*)
- hardcode_shlibpath_var=no
- hardcode_libdir_flag_spec='${wl}-rpath,$libdir'
- export_dynamic_flag_spec='${wl}-E'
- # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
- # Instead, shared libraries are loaded at an image base (0x10000000 by
- # default) and relocated if they conflict, which is a slow very memory
- # consuming and fragmenting process. To avoid this, we pick a random,
- # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
- # time. Moving up from 0x10000000 also allows more sbrk(2) space.
- archive_cmds='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
- archive_expsym_cmds='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
- gnu* | linux* | tpf* | k*bsd*-gnu | kopensolaris*-gnu)
- tmp_diet=no
- if test "$host_os" = linux-dietlibc; then
- diet\ *) tmp_diet=yes;; # linux-dietlibc with static linking (!diet-dyn)
- esac
- fi
- if $LD --help 2>&1 | $EGREP ': supported targets:.* elf' > /dev/null \
- && test "$tmp_diet" = no
- then
- tmp_addflag=' $pic_flag'
- tmp_sharedflag='-shared'
- case $cc_basename,$host_cpu in
- pgcc*) # Portland Group C compiler
- whole_archive_flag_spec='${wl}--whole-archive`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; func_echo_all \"$new_convenience\"` ${wl}--no-whole-archive'
- pgf77* | pgf90* | pgf95* | pgfortran*)
- # Portland Group f77 and f90 compilers
- tmp_addflag=' $pic_flag -Mnomain' ;;
- ecc*,ia64* | icc*,ia64*) # Intel C compiler on ia64
- tmp_addflag=' -i_dynamic' ;;
- efc*,ia64* | ifort*,ia64*) # Intel Fortran compiler on ia64
- tmp_addflag=' -i_dynamic -nofor_main' ;;
- ifc* | ifort*) # Intel Fortran compiler
- tmp_addflag=' -nofor_main' ;;
- lf95*) # Lahey Fortran 8.1
- tmp_sharedflag='--shared' ;;
- xl[cC]* | bgxl[cC]* | mpixl[cC]*) # IBM XL C 8.0 on PPC (deal with xlf below)
- tmp_sharedflag='-qmkshrobj'
- tmp_addflag= ;;
- compiler_needs_object=yes
- esac
- *Sun\ C*) # Sun C 5.9
- whole_archive_flag_spec='${wl}--whole-archive`new_convenience=; for conv in $convenience\"\"; do test -z \"$conv\" || new_convenience=\"$new_convenience,$conv\"; done; func_echo_all \"$new_convenience\"` ${wl}--no-whole-archive'
- tmp_sharedflag='-G' ;;
- *Sun\ F*) # Sun Fortran 8.3
- esac
- archive_cmds='$CC '"$tmp_sharedflag""$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- if test "x$supports_anon_versioning" = xyes; then
- archive_expsym_cmds='echo "{ global:" > $output_objdir/$libname.ver~
- cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
- echo "local: *; };" >> $output_objdir/$libname.ver~
- $CC '"$tmp_sharedflag""$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
- fi
- xlf* | bgf* | bgxlf* | mpixlf*)
- # IBM XL Fortran 10.1 on PPC cannot create shared libs itself
- whole_archive_flag_spec='--whole-archive$convenience --no-whole-archive'
- archive_cmds='$LD -shared $libobjs $deplibs $linker_flags -soname $soname -o $lib'
- $LD -shared $libobjs $deplibs $linker_flags -soname $soname -version-script $output_objdir/$libname.ver -o $lib'
- fi
- esac
- else
- ld_shlibs=no
- fi
- netbsd* | netbsdelf*-gnu)
- if echo __ELF__ | $CC -E - | $GREP __ELF__ >/dev/null; then
- archive_cmds='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
- wlarc=
- else
- archive_cmds='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_expsym_cmds='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- fi
- solaris*)
- if $LD -v 2>&1 | $GREP 'BFD 2\.8' > /dev/null; then
- ld_shlibs=no
-*** Warning: The releases 2.8.* of the GNU linker cannot reliably
-*** create shared libraries on Solaris systems. Therefore, libtool
-*** is disabling shared libraries support. We urge you to upgrade GNU
-*** binutils to release 2.9.1 or newer. Another option is to modify
-*** your PATH or compiler configuration so that the native linker is
-*** used, and then restart.
-_LT_EOF
- elif $LD --help 2>&1 | $GREP ': supported targets:.* elf' > /dev/null; then
- else
- ld_shlibs=no
- fi
- sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX*)
- *\ [01].* | *\ 2.[0-9].* | *\ 2.1[0-5].*)
- ld_shlibs=no
-*** Warning: Releases of the GNU linker prior to 2.16.91.0.3 can not
-*** reliably create shared libraries on SCO systems. Therefore, libtool
-*** binutils to release 2.16.91.0.3 or newer. Another option is to modify
-_LT_EOF
- # For security reasons, it is highly recommended that you always
- # use absolute paths for naming shared libraries, and exclude the
- # DT_RUNPATH tag from executables and libraries. But doing so
- # requires that you compile everything twice, which is a pain.
- archive_expsym_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- else
- ld_shlibs=no
- fi
- esac
- sunos4*)
- archive_cmds='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- wlarc=
- hardcode_direct=yes
- else
- ld_shlibs=no
- fi
- esac
- if test "$ld_shlibs" = no; then
- runpath_var=
- fi
- else
- # PORTME fill in a description of your system's linker (not GNU ld)
- case $host_os in
- aix3*)
- always_export_symbols=yes
- archive_expsym_cmds='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
- # Note: this linker hardcodes the directories in LIBPATH if there
- # are no directories specified by -L.
- if test "$GCC" = yes && test -z "$lt_prog_compiler_static"; then
- # Neither direct hardcoding nor static linking is supported with a
- # broken collect2.
- hardcode_direct=unsupported
- fi
- aix[4-9]*)
- # On IA64, the linker does run time linking by default, so we don't
- # have to do anything special.
- aix_use_runtimelinking=no
- exp_sym_flag='-Bexport'
- no_entry_flag=""
- else
- # If we're using GNU nm, then we don't want the "-C" option.
- # -C means demangle to AIX nm, but means don't demangle with GNU nm
- # Also, AIX nm treats weak defined symbols like other global
- # defined symbols, whereas GNU nm marks them as "W".
- if $NM -V 2>&1 | $GREP 'GNU' > /dev/null; then
- export_symbols_cmds='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$ 2 == "T") || (\$ 2 == "D") || (\$ 2 == "B") || (\$ 2 == "W")) && (substr(\$ 3,1,1) != ".")) { print \$ 3 } }'\'' | sort -u > $export_symbols'
- else
- export_symbols_cmds='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$ 2 == "T") || (\$ 2 == "D") || (\$ 2 == "B")) && (substr(\$ 3,1,1) != ".")) { print \$ 3 } }'\'' | sort -u > $export_symbols'
- fi
- # Test if we are trying to use run time linking or normal
- # AIX style linking. If -brtl is somewhere in LDFLAGS, we
- # need to do runtime linking.
- case $host_os in aix4.[23]|aix4.[23].*|aix[5-9]*)
- for ld_flag in $LDFLAGS; do
- if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
- aix_use_runtimelinking=yes
- break
- fi
- done
- esac
- exp_sym_flag='-bexport'
- no_entry_flag='-bnoentry'
- fi
- # When large executables or shared objects are built, AIX ld can
- # have problems creating the table of contents. If linking a library
- # or program results in "error TOC overflow" add -mminimal-toc to
- # CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
- # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
- archive_cmds=''
- hardcode_direct_absolute=yes
- hardcode_libdir_separator=':'
- file_list_spec='${wl}-f,'
- case $host_os in aix4.[012]|aix4.[012].*)
- # We only want to do this on AIX 4.2 and lower, the check
- # below for broken collect2 doesn't work under 4.3+
- collect2name=`${CC} -print-prog-name=collect2`
- if test -f "$collect2name" &&
- strings "$collect2name" | $GREP resolve_lib_name >/dev/null
- then
- # We have reworked collect2
- else
- # We have old collect2
- # It fails to find uninstalled libraries when the uninstalled
- # path is not listed in the libpath. Setting hardcode_minus_L
- # to unsupported forces relinking
- fi
- esac
- shared_flag='-shared'
- if test "$aix_use_runtimelinking" = yes; then
- shared_flag="$shared_flag "'${wl}-G'
- fi
- else
- # not using gcc
- if test "$host_cpu" = ia64; then
- # VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
- # chokes on -Wl,-G. The following line is correct:
- shared_flag='-G'
- else
- shared_flag='${wl}-G'
- else
- shared_flag='${wl}-bM:SRE'
- fi
- fi
- fi
- export_dynamic_flag_spec='${wl}-bexpall'
- # It seems that -bexpall does not export symbols beginning with
- # underscore (_), so it is better to generate a list of symbols to export.
- # Warning - without using the other runtime loading flags (-brtl),
- # -berok will link without error, but may produce a broken library.
- allow_undefined_flag='-berok'
- # Determine the default libpath from the value encoded in an
- # empty executable.
- if test "${lt_cv_aix_libpath+set}" = set; then
- aix_libpath=$lt_cv_aix_libpath
-else
- if ${lt_cv_aix_libpath_+:} false; then :
-else
- cat confdefs.h - <<_ACEOF >conftest.$ac_ext
-/* end confdefs.h. */
-int
-main ()
- return 0;
-_ACEOF
- lt_aix_libpath_sed='
- /Import File Strings/,/^$/ {
- /^0/ {
- s/^0 *\([^ ]*\) *$/\1/
- p
- lt_cv_aix_libpath_=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e "$lt_aix_libpath_sed"`
- # Check for a 64-bit object if we didn't find anything.
- if test -z "$lt_cv_aix_libpath_"; then
- lt_cv_aix_libpath_=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e "$lt_aix_libpath_sed"`
- fi
-fi
- lt_cv_aix_libpath_="/usr/lib:/lib"
- fi
-fi
- aix_libpath=$lt_cv_aix_libpath_
-fi
- hardcode_libdir_flag_spec='${wl}-blibpath:$libdir:'"$aix_libpath"
- archive_expsym_cmds='$CC -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then func_echo_all "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
- else
- hardcode_libdir_flag_spec='${wl}-R $libdir:/usr/lib:/lib'
- allow_undefined_flag="-z nodefs"
- archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
- else
-else
-else
-int
-main ()
- return 0;
-_ACEOF
- /^0/ {
- p
- fi
-fi
- fi
-fi
-fi
- # Warning - without using the other run time loading flags,
- no_undefined_flag=' ${wl}-bernotok'
- allow_undefined_flag=' ${wl}-berok'
- # We only use this code for GNU lds that support --whole-archive.
- whole_archive_flag_spec='${wl}--whole-archive$convenience ${wl}--no-whole-archive'
- else
- # Exported symbols can be pulled into shared objects from archives
- whole_archive_flag_spec='$convenience'
- fi
- archive_cmds_need_lc=yes
- # This is similar to how AIX traditionally builds its shared libraries.
- archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
- fi
- fi
- amigaos*)
- case $host_cpu in
- powerpc)
- m68k)
- esac
- bsdi[45]*)
- export_dynamic_flag_spec=-rdynamic
- # hardcode_libdir_flag_spec is actually meaningless, as there is
- # no search path for DLLs.
- cl*)
- # Native MSVC
- hardcode_libdir_flag_spec=' '
- file_list_spec='@'
- # Tell ltmain to make .lib files, not .a files.
- libext=lib
- # Tell ltmain to make .dll files, not .so files.
- shrext_cmds=".dll"
- # FIXME: Setting linknames here is a bad hack.
- archive_cmds='$CC -o $output_objdir/$soname $libobjs $compiler_flags $deplibs -Wl,-dll~linknames='
- sed -n -e 's/\\\\\\\(.*\\\\\\\)/-link\\\ -EXPORT:\\\\\\\1/' -e '1\\\!p' < $export_symbols > $output_objdir/$soname.exp;
- else
- sed -e 's/\\\\\\\(.*\\\\\\\)/-link\\\ -EXPORT:\\\\\\\1/' < $export_symbols > $output_objdir/$soname.exp;
- fi~
- $CC -o $tool_output_objdir$soname $libobjs $compiler_flags $deplibs "@$tool_output_objdir$soname.exp" -Wl,-DLL,-IMPLIB:"$tool_output_objdir$libname.dll.lib"~
- linknames='
- # The linker will not automatically build a static lib if we build a DLL.
- # _LT_TAGVAR(old_archive_from_new_cmds, )='true'
- exclude_expsyms='_NULL_IMPORT_DESCRIPTOR|_IMPORT_DESCRIPTOR_.*'
- export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS][ ]/s/.*[ ]\([^ ]*\)/\1,DATA/'\'' | $SED -e '\''/^[AITW][ ]/s/.*[ ]//'\'' | sort | uniq > $export_symbols'
- # Don't use ranlib
- old_postinstall_cmds='chmod 644 $oldlib'
- postlink_cmds='lt_outputfile="@OUTPUT@"~
- lt_tool_outputfile="@TOOL_OUTPUT@"~
- case $lt_outputfile in
- *.exe|*.EXE) ;;
- lt_outputfile="$lt_outputfile.exe"
- lt_tool_outputfile="$lt_tool_outputfile.exe"
- esac~
- if test "$MANIFEST_TOOL" != ":" && test -f "$lt_outputfile.manifest"; then
- $MANIFEST_TOOL -manifest "$lt_tool_outputfile.manifest" -outputresource:"$lt_tool_outputfile" || exit 1;
- $RM "$lt_outputfile.manifest";
- fi'
- # Assume MSVC wrapper
- libext=lib
- archive_cmds='$CC -o $lib $libobjs $compiler_flags `func_echo_all "$deplibs" | $SED '\''s/ -lc$//'\''` -link -dll~linknames='
- # The linker will automatically build a .lib file if we build a DLL.
- old_archive_from_new_cmds='true'
- # FIXME: Should let the user specify the lib program.
- old_archive_cmds='lib -OUT:$oldlib$oldobjs$old_deplibs'
- esac
- archive_cmds_need_lc=no
- hardcode_automatic=yes
- if test "$lt_cv_ld_force_load" = "yes"; then
- whole_archive_flag_spec='`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience ${wl}-force_load,$conv\"; done; func_echo_all \"$new_convenience\"`'
- else
- whole_archive_flag_spec=''
- fi
- allow_undefined_flag="$_lt_dar_allow_undefined"
- ifort*) _lt_dar_can_shared=yes ;;
- *) _lt_dar_can_shared=$GCC ;;
- esac
- if test "$_lt_dar_can_shared" = "yes"; then
- output_verbose_link_cmd=func_echo_all
- archive_cmds="\$CC -dynamiclib \$allow_undefined_flag -o \$lib \$libobjs \$deplibs \$compiler_flags -install_name \$rpath/\$soname \$verstring $_lt_dar_single_mod${_lt_dsymutil}"
- module_cmds="\$CC \$allow_undefined_flag -o \$lib -bundle \$libobjs \$deplibs \$compiler_flags${_lt_dsymutil}"
- archive_expsym_cmds="sed 's,^,_,' < \$export_symbols > \$output_objdir/\${libname}-symbols.expsym~\$CC -dynamiclib \$allow_undefined_flag -o \$lib \$libobjs \$deplibs \$compiler_flags -install_name \$rpath/\$soname \$verstring ${_lt_dar_single_mod}${_lt_dar_export_syms}${_lt_dsymutil}"
- module_expsym_cmds="sed -e 's,^,_,' < \$export_symbols > \$output_objdir/\${libname}-symbols.expsym~\$CC \$allow_undefined_flag -o \$lib -bundle \$libobjs \$deplibs \$compiler_flags${_lt_dar_export_syms}${_lt_dsymutil}"
- else
- ld_shlibs=no
- fi
- dgux*)
- archive_cmds='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
- # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
- # support. Future versions do this automatically, but an explicit c++rt0.o
- # does not break anything, and helps significantly (at the cost of a little
- # extra space).
- freebsd2.2*)
- archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
- hardcode_libdir_flag_spec='-R$libdir'
- # Unfortunately, older versions of FreeBSD 2 do not have this feature.
- freebsd2.*)
- archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
- freebsd* | dragonfly*)
- archive_cmds='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
- hpux9*)
- archive_cmds='$RM $output_objdir/$soname~$CC -shared $pic_flag ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- else
- archive_cmds='$RM $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- fi
- hardcode_libdir_flag_spec='${wl}+b ${wl}$libdir'
- hardcode_libdir_separator=:
- # hardcode_minus_L: Not really in the search PATH,
- # but as the default location of the library.
- hpux10*)
- if test "$GCC" = yes && test "$with_gnu_ld" = no; then
- archive_cmds='$CC -shared $pic_flag ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
- fi
- if test "$with_gnu_ld" = no; then
- fi
- hpux11*)
- case $host_cpu in
- hppa*64*)
- archive_cmds='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- ia64*)
- archive_cmds='$CC -shared $pic_flag ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
- esac
- else
- case $host_cpu in
- hppa*64*)
- archive_cmds='$CC -b ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- ia64*)
- archive_cmds='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
- # Older versions of the 11.00 compiler do not understand -b yet
- # (HP92453-01 A.11.01.20 doesn't, HP92453-01 B.11.X.35175-35176.GP does)
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking if $CC understands -b" >&5
-$as_echo_n "checking if $CC understands -b... " >&6; }
-if ${lt_cv_prog_compiler__b+:} false; then :
-else
- lt_cv_prog_compiler__b=no
- LDFLAGS="$LDFLAGS -b"
- lt_cv_prog_compiler__b=yes
- fi
- else
- fi
- fi
- $RM -r conftest*
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler__b" >&5
-$as_echo "$lt_cv_prog_compiler__b" >&6; }
-if test x"$lt_cv_prog_compiler__b" = xyes; then
- archive_cmds='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
-else
-fi
- esac
- fi
- case $host_cpu in
- hppa*64*|ia64*)
- esac
- fi
- archive_cmds='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && func_echo_all "${wl}-set_version ${wl}$verstring"` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- # Try to use the -exported_symbol ld option, if it does not
- # work, assume that -exports_file does not work either and
- # implicitly export all symbols.
- # This should be the same for all languages, so no per-tag cache variable.
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the $host_os linker accepts -exported_symbol" >&5
-$as_echo_n "checking whether the $host_os linker accepts -exported_symbol... " >&6; }
-if ${lt_cv_irix_exported_symbol+:} false; then :
-else
- LDFLAGS="$LDFLAGS -shared ${wl}-exported_symbol ${wl}foo ${wl}-update_registry ${wl}/dev/null"
-int foo (void) { return 0; }
-_ACEOF
-if ac_fn_c_try_link "$LINENO"; then :
- lt_cv_irix_exported_symbol=yes
-else
- lt_cv_irix_exported_symbol=no
-fi
-rm -f core conftest.err conftest.$ac_objext \
- conftest$ac_exeext conftest.$ac_ext
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_irix_exported_symbol" >&5
-$as_echo "$lt_cv_irix_exported_symbol" >&6; }
- if test "$lt_cv_irix_exported_symbol" = yes; then
- archive_expsym_cmds='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && func_echo_all "${wl}-set_version ${wl}$verstring"` ${wl}-update_registry ${wl}${output_objdir}/so_locations ${wl}-exports_file ${wl}$export_symbols -o $lib'
- fi
- else
- archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags -soname $soname `test -n "$verstring" && func_echo_all "-set_version $verstring"` -update_registry ${output_objdir}/so_locations -o $lib'
- archive_expsym_cmds='$CC -shared $libobjs $deplibs $compiler_flags -soname $soname `test -n "$verstring" && func_echo_all "-set_version $verstring"` -update_registry ${output_objdir}/so_locations -exports_file $export_symbols -o $lib'
- fi
- archive_cmds_need_lc='no'
- inherit_rpath=yes
- archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags' # a.out
- else
- archive_cmds='$LD -shared -o $lib $libobjs $deplibs $linker_flags' # ELF
- fi
- newsos6)
- *nto* | *qnx*)
- openbsd*)
- if test -f /usr/libexec/ld.so; then
- if test -z "`echo __ELF__ | $CC -E - | $GREP __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- archive_expsym_cmds='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-retain-symbols-file,$export_symbols'
- else
- case $host_os in
- openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
- esac
- fi
- else
- ld_shlibs=no
- fi
- os2*)
- archive_cmds='$ECHO "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$ECHO "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~echo DATA >> $output_objdir/$libname.def~echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
- old_archive_from_new_cmds='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
- osf3*)
- allow_undefined_flag=' ${wl}-expect_unresolved ${wl}\*'
- archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && func_echo_all "${wl}-set_version ${wl}$verstring"` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- allow_undefined_flag=' -expect_unresolved \*'
- archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags -soname $soname `test -n "$verstring" && func_echo_all "-set_version $verstring"` -update_registry ${output_objdir}/so_locations -o $lib'
- fi
- osf4* | osf5*) # as osf3* with the addition of -msym flag
- archive_cmds='$CC -shared${allow_undefined_flag} $pic_flag $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && func_echo_all "${wl}-set_version ${wl}$verstring"` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags -msym -soname $soname `test -n "$verstring" && func_echo_all "-set_version $verstring"` -update_registry ${output_objdir}/so_locations -o $lib'
- archive_expsym_cmds='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; printf "%s\\n" "-hidden">> $lib.exp~
- $CC -shared${allow_undefined_flag} ${wl}-input ${wl}$lib.exp $compiler_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && $ECHO "-set_version $verstring"` -update_registry ${output_objdir}/so_locations -o $lib~$RM $lib.exp'
- # Both c and cxx compiler support -rpath directly
- hardcode_libdir_flag_spec='-rpath $libdir'
- fi
- solaris*)
- no_undefined_flag=' -z defs'
- wlarc='${wl}'
- archive_cmds='$CC -shared $pic_flag ${wl}-z ${wl}text ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds='echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~echo "local: *; };" >> $lib.exp~
- $CC -shared $pic_flag ${wl}-z ${wl}text ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$RM $lib.exp'
- else
- case `$CC -V 2>&1` in
- *"Compilers 5.0"*)
- wlarc=''
- archive_cmds='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
- $LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$RM $lib.exp'
- wlarc='${wl}'
- archive_cmds='$CC -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $compiler_flags'
- $CC -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $compiler_flags~$RM $lib.exp'
- esac
- fi
- case $host_os in
- solaris2.[0-5] | solaris2.[0-5].*) ;;
- # The compiler driver will combine and reorder linker options,
- # but understands `-z linker_flag'. GCC discards it without `$wl',
- # but is careful enough not to reorder.
- # Supported since Solaris 2.6 (maybe 2.5.1?)
- whole_archive_flag_spec='${wl}-z ${wl}allextract$convenience ${wl}-z ${wl}defaultextract'
- else
- whole_archive_flag_spec='-z allextract$convenience -z defaultextract'
- fi
- esac
- sunos4*)
- if test "x$host_vendor" = xsequent; then
- # Use $CC to link under sequent, because it throws in some extra .o
- # files that make .init and .fini sections work.
- archive_cmds='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
- fi
- sysv4)
- case $host_vendor in
- sni)
- hardcode_direct=yes # is this really true???
- siemens)
- ## LD is ld it makes a PLAMLIB
- ## CC just makes a GrossModule.
- archive_cmds='$LD -G -o $lib $libobjs $deplibs $linker_flags'
- reload_cmds='$CC -r -o $output$reload_objs'
- motorola)
- hardcode_direct=no #Motorola manual says yes, but my tests say they lie
- esac
- runpath_var='LD_RUN_PATH'
- sysv4.3*)
- export_dynamic_flag_spec='-Bexport'
- sysv4*MP*)
- hardcode_runpath_var=yes
- ld_shlibs=yes
- fi
- sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7* | sco3.2v5.0.[024]*)
- no_undefined_flag='${wl}-z,text'
- archive_cmds='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- fi
- sysv5* | sco3.2v5* | sco5v6*)
- # Note: We can NOT use -z defs as we might desire, because we do not
- # link with -lc, and that would cause any symbols used from libc to
- # always be unresolved, which means just about no library would
- # ever link correctly. If we're not using GNU ld we use -z text
- # though, which does catch some bad symbols but isn't as heavy-handed
- # as -z defs.
- allow_undefined_flag='${wl}-z,nodefs'
- hardcode_libdir_flag_spec='${wl}-R,$libdir'
- export_dynamic_flag_spec='${wl}-Bexport'
- else
- fi
- uts4*)
- ld_shlibs=no
- esac
- if test x$host_vendor = xsni; then
- case $host in
- sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
- export_dynamic_flag_spec='${wl}-Blargedynsym'
- esac
- fi
- fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ld_shlibs" >&5
-$as_echo "$ld_shlibs" >&6; }
-test "$ld_shlibs" = no && can_build_shared=no
-with_gnu_ld=$with_gnu_ld
-# Do we need to explicitly link libc?
-case "x$archive_cmds_need_lc" in
-x|xyes)
- # Assume -lc should be added
- if test "$enable_shared" = yes && test "$GCC" = yes; then
- case $archive_cmds in
- # FIXME: we may have to deal with multi-command sequences.
- '$CC '*)
- # Test whether the compiler implicitly links with -lc since on some
- # systems, -lgcc has to come before -lc. If gcc already passes -lc
- # to ld, don't add -lc before -lgcc.
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether -lc should be explicitly linked in" >&5
-$as_echo_n "checking whether -lc should be explicitly linked in... " >&6; }
-if ${lt_cv_archive_cmds_need_lc+:} false; then :
-else
- $RM conftest*
- if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$ac_compile\""; } >&5
- (eval $ac_compile) 2>&5
- ac_status=$?
- $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
- test $ac_status = 0; } 2>conftest.err; then
- soname=conftest
- lib=conftest
- libobjs=conftest.$ac_objext
- deplibs=
- wl=$lt_prog_compiler_wl
- pic_flag=$lt_prog_compiler_pic
- compiler_flags=-v
- linker_flags=-v
- verstring=
- output_objdir=.
- libname=conftest
- lt_save_allow_undefined_flag=$allow_undefined_flag
- if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$archive_cmds 2\>\&1 \| $GREP \" -lc \" \>/dev/null 2\>\&1\""; } >&5
- (eval $archive_cmds 2\>\&1 \| $GREP \" -lc \" \>/dev/null 2\>\&1) 2>&5
- ac_status=$?
- then
- lt_cv_archive_cmds_need_lc=no
- else
- lt_cv_archive_cmds_need_lc=yes
- fi
- allow_undefined_flag=$lt_save_allow_undefined_flag
- else
- fi
- $RM conftest*
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_archive_cmds_need_lc" >&5
-$as_echo "$lt_cv_archive_cmds_need_lc" >&6; }
- archive_cmds_need_lc=$lt_cv_archive_cmds_need_lc
- esac
- fi
-esac
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking dynamic linker characteristics" >&5
-$as_echo_n "checking dynamic linker characteristics... " >&6; }
- case $host_os in
- darwin*) lt_awk_arg="/^libraries:/,/LR/" ;;
- *) lt_awk_arg="/^libraries:/" ;;
- esac
- case $host_os in
- mingw* | cegcc*) lt_sed_strip_eq="s,=\([A-Za-z]:\),\1,g" ;;
- *) lt_sed_strip_eq="s,=/,/,g" ;;
- esac
- lt_search_path_spec=`$CC -print-search-dirs | awk $lt_awk_arg | $SED -e "s/^libraries://" -e $lt_sed_strip_eq`
- case $lt_search_path_spec in
- # if the path contains ";" then we assume it to be the separator
- # otherwise default to the standard path separator (i.e. ":") - it is
- # assumed that no part of a normal pathname contains ";" but that should
- # okay in the real world where ";" in dirpaths is itself problematic.
- lt_search_path_spec=`$ECHO "$lt_search_path_spec" | $SED 's/;/ /g'`
- lt_search_path_spec=`$ECHO "$lt_search_path_spec" | $SED "s/$PATH_SEPARATOR/ /g"`
- esac
- # Ok, now we have the path, separated by spaces, we can step through it
- # and add multilib dir if necessary.
- lt_tmp_lt_search_path_spec=
- lt_multi_os_dir=`$CC $CPPFLAGS $CFLAGS $LDFLAGS -print-multi-os-directory 2>/dev/null`
- for lt_sys_path in $lt_search_path_spec; do
- if test -d "$lt_sys_path/$lt_multi_os_dir"; then
- lt_tmp_lt_search_path_spec="$lt_tmp_lt_search_path_spec $lt_sys_path/$lt_multi_os_dir"
- else
- test -d "$lt_sys_path" && \
- lt_tmp_lt_search_path_spec="$lt_tmp_lt_search_path_spec $lt_sys_path"
- fi
- done
- lt_search_path_spec=`$ECHO "$lt_tmp_lt_search_path_spec" | awk '
-BEGIN {RS=" "; FS="/|\n";} {
- lt_foo="";
- lt_count=0;
- for (lt_i = NF; lt_i > 0; lt_i--) {
- if ($lt_i != "" && $lt_i != ".") {
- if ($lt_i == "..") {
- lt_count++;
- } else {
- if (lt_count == 0) {
- lt_foo="/" $lt_i lt_foo;
- } else {
- lt_count--;
- if (lt_foo != "") { lt_freq[lt_foo]++; }
- if (lt_freq[lt_foo] == 1) { print lt_foo; }
- # AWK program above erroneously prepends '/' to C:/dos/paths
- # for these hosts.
- case $host_os in
- mingw* | cegcc*) lt_search_path_spec=`$ECHO "$lt_search_path_spec" |\
- $SED 's,/\([A-Za-z]:\),\1,g'` ;;
- esac
- sys_lib_search_path_spec=`$ECHO "$lt_search_path_spec" | $lt_NL2SP`
-else
- sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
-fi
-library_names_spec=
-libname_spec='lib$name'
-soname_spec=
-shrext_cmds=".so"
-postinstall_cmds=
-postuninstall_cmds=
-finish_cmds=
-finish_eval=
-shlibpath_var=
-shlibpath_overrides_runpath=unknown
-version_type=none
-dynamic_linker="$host_os ld.so"
-sys_lib_dlsearch_path_spec="/lib /usr/lib"
-need_lib_prefix=unknown
-hardcode_into_libs=no
-# when you set need_version to no, make sure it does not cause -set_version
-# flags to be left without arguments
-need_version=unknown
-case $host_os in
-aix3*)
- version_type=linux # correct to gnu/linux during the next big refactor
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
- shlibpath_var=LIBPATH
- # AIX 3 has no versioning support, so we append a major version to the name.
- soname_spec='${libname}${release}${shared_ext}$major'
-aix[4-9]*)
- need_lib_prefix=no
- need_version=no
- hardcode_into_libs=yes
- # AIX 5 supports IA64
- library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
- shlibpath_var=LD_LIBRARY_PATH
- else
- # With GCC up to 2.95.x, collect2 would create an import file
- # for dependence libraries. The import file would start with
- # the line `#! .'. This would cause the generated library to
- # depend on `.', always an invalid library. This was fixed in
- # development snapshots of GCC prior to 3.0.
- case $host_os in
- aix4 | aix4.[01] | aix4.[01].*)
- if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
- echo ' yes '
- echo '#endif'; } | ${CC} -E - | $GREP yes > /dev/null; then
- else
- can_build_shared=no
- fi
- esac
- # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
- # soname into executable. Probably we can add versioning support to
- # collect2, so additional links can be useful in future.
- # If using run time linking (on AIX 4.2 or later) use lib<name>.so
- # instead of lib<name>.a to let people know that these are not
- # typical AIX shared libraries.
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
- else
- # We preserve .a as extension for shared libraries through AIX4.2
- # and later when we are not doing run time linking.
- library_names_spec='${libname}${release}.a $libname.a'
- fi
- fi
-amigaos*)
- case $host_cpu in
- powerpc)
- # Since July 2007 AmigaOS4 officially supports .so libraries.
- # When compiling the executable, add -use-dynld -Lsobjs: to the compileline.
- m68k)
- library_names_spec='$libname.ixlibrary $libname.a'
- # Create ${libname}_ixlibrary.a entries in /sys/libs.
- finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`func_echo_all "$lib" | $SED '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $RM /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
- esac
-beos*)
- library_names_spec='${libname}${shared_ext}'
- dynamic_linker="$host_os ld.so"
- shlibpath_var=LIBRARY_PATH
-bsdi[45]*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
- sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
- sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
- # the default ld.so.conf also contains /usr/contrib/lib and
- # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
- # libtool to hard-code these into programs
-cygwin* | mingw* | pw32* | cegcc*)
- version_type=windows
- need_version=no
- case $GCC,$cc_basename in
- yes,*)
- # gcc
- library_names_spec='$libname.dll.a'
- # DLL is installed to $(libdir)/../bin by postinstall_cmds
- postinstall_cmds='base_file=`basename \${file}`~
- dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i; echo \$dlname'\''`~
- dldir=$destdir/`dirname \$dlpath`~
- test -d \$dldir || mkdir -p \$dldir~
- $install_prog $dir/$dlname \$dldir/$dlname~
- chmod a+x \$dldir/$dlname~
- if test -n '\''$stripme'\'' && test -n '\''$striplib'\''; then
- eval '\''$striplib \$dldir/$dlname'\'' || exit \$?;
- fi'
- postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
- dlpath=$dir/\$dldll~
- $RM \$dlpath'
- shlibpath_overrides_runpath=yes
- case $host_os in
- cygwin*)
- # Cygwin DLLs use 'cyg' prefix rather than 'lib'
- soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- sys_lib_search_path_spec="$sys_lib_search_path_spec /usr/lib/w32api"
- mingw* | cegcc*)
- # MinGW DLLs use traditional 'lib' prefix
- soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- pw32*)
- # pw32 DLLs use 'pw' prefix rather than 'lib'
- library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- esac
- dynamic_linker='Win32 ld.exe'
- *,cl*)
- # Native MSVC
- libname_spec='$name'
- library_names_spec='${libname}.dll.lib'
- case $build_os in
- mingw*)
- lt_save_ifs=$IFS
- IFS=';'
- for lt_path in $LIB
- do
- IFS=$lt_save_ifs
- # Let DOS variable expansion print the short 8.3 style file name.
- lt_path=`cd "$lt_path" 2>/dev/null && cmd //C "for %i in (".") do @echo %~si"`
- sys_lib_search_path_spec="$sys_lib_search_path_spec $lt_path"
- done
- IFS=$lt_save_ifs
- # Convert to MSYS style.
- sys_lib_search_path_spec=`$ECHO "$sys_lib_search_path_spec" | sed -e 's|\\\\|/|g' -e 's| \\([a-zA-Z]\\):| /\\1|g' -e 's|^ ||'`
- cygwin*)
- # Convert to unix form, then to dos form, then back to unix form
- # but this time dos style (no spaces!) so that the unix form looks
- # like /cygdrive/c/PROGRA~1:/cygdr...
- sys_lib_search_path_spec=`cygpath --path --unix "$LIB"`
- sys_lib_search_path_spec=`cygpath --path --dos "$sys_lib_search_path_spec" 2>/dev/null`
- sys_lib_search_path_spec=`cygpath --path --unix "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
- sys_lib_search_path_spec="$LIB"
- if $ECHO "$sys_lib_search_path_spec" | $GREP ';[c-zC-Z]:/' >/dev/null; then
- # It is most probably a Windows format PATH.
- sys_lib_search_path_spec=`$ECHO "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
- else
- sys_lib_search_path_spec=`$ECHO "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
- fi
- # FIXME: find the short name or the path components, as spaces are
- # common. (e.g. "Program Files" -> "PROGRA~1")
- esac
- $install_prog $dir/$dlname \$dldir/$dlname'
- $RM \$dlpath'
- dynamic_linker='Win32 link.exe'
- library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
- esac
- # FIXME: first we should search . and the directory the executable is in
- shlibpath_var=PATH
-darwin* | rhapsody*)
- dynamic_linker="$host_os dyld"
- version_type=darwin
- need_version=no
- library_names_spec='${libname}${release}${major}$shared_ext ${libname}$shared_ext'
- soname_spec='${libname}${release}${major}$shared_ext'
- shlibpath_var=DYLD_LIBRARY_PATH
- shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
- sys_lib_search_path_spec="$sys_lib_search_path_spec /usr/local/lib"
- sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
-dgux*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
-freebsd* | dragonfly*)
- # DragonFly does not have aout. When/if they implement a new
- # versioning mechanism, adjust this.
- if test -x /usr/bin/objformat; then
- objformat=`/usr/bin/objformat`
- else
- case $host_os in
- freebsd[23].*) objformat=aout ;;
- *) objformat=elf ;;
- esac
- fi
- version_type=freebsd-$objformat
- case $version_type in
- freebsd-elf*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
- need_version=no
- freebsd-*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
- need_version=yes
- esac
- case $host_os in
- freebsd2.*)
- freebsd3.[01]* | freebsdelf3.[01]*)
- freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
- freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
- shlibpath_overrides_runpath=no
- *) # from 4.6 on, and DragonFly
- esac
-gnu*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
-haiku*)
- need_version=no
- dynamic_linker="$host_os runtime_loader"
- sys_lib_dlsearch_path_spec='/boot/home/config/lib /boot/common/lib /boot/system/lib'
-hpux9* | hpux10* | hpux11*)
- # Give a soname corresponding to the major version so that dld.sl refuses to
- # link against other versions.
- version_type=sunos
- need_version=no
- case $host_cpu in
- ia64*)
- shrext_cmds='.so'
- dynamic_linker="$host_os dld.so"
- shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
- if test "X$HPUX_IA64_MODE" = X32; then
- sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
- else
- sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
- fi
- sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
- hppa*64*)
- shrext_cmds='.sl'
- dynamic_linker="$host_os dld.sl"
- shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
- sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
- shrext_cmds='.sl'
- shlibpath_var=SHLIB_PATH
- shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
- esac
- # HP-UX runs *really* slowly unless shared libraries are mode 555, ...
- postinstall_cmds='chmod 555 $lib'
- # or fails outright, so override atomically:
- install_override_mode=555
-interix[3-9]*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
- dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
-irix5* | irix6* | nonstopux*)
- case $host_os in
- nonstopux*) version_type=nonstopux ;;
- if test "$lt_cv_prog_gnu_ld" = yes; then
- else
- version_type=irix
- fi ;;
- esac
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
- case $host_os in
- irix5* | nonstopux*)
- libsuff= shlibsuff=
- case $LD in # libtool.m4 will add one of these switches to LD
- *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
- libsuff= shlibsuff= libmagic=32-bit;;
- *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
- libsuff=32 shlibsuff=N32 libmagic=N32;;
- *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
- libsuff=64 shlibsuff=64 libmagic=64-bit;;
- *) libsuff= shlibsuff= libmagic=never-match;;
- esac
- esac
- shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
- sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
- sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
-# No shared lib support for Linux oldld, aout, or coff.
-linux*oldld* | linux*aout* | linux*coff*)
- dynamic_linker=no
-# This must be glibc/ELF.
-linux* | k*bsd*-gnu | kopensolaris*-gnu)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
- # Some binutils ld are patched to set DT_RUNPATH
- if ${lt_cv_shlibpath_overrides_runpath+:} false; then :
- $as_echo_n "(cached) " >&6
-else
- lt_cv_shlibpath_overrides_runpath=no
- save_LDFLAGS=$LDFLAGS
- save_libdir=$libdir
- eval "libdir=/foo; wl=\"$lt_prog_compiler_wl\"; \
- LDFLAGS=\"\$LDFLAGS $hardcode_libdir_flag_spec\""
-int
-main ()
- return 0;
-_ACEOF
- if ($OBJDUMP -p conftest$ac_exeext) 2>/dev/null | grep "RUNPATH.*$libdir" >/dev/null; then :
- lt_cv_shlibpath_overrides_runpath=yes
-fi
-fi
- LDFLAGS=$save_LDFLAGS
- libdir=$save_libdir
-fi
- shlibpath_overrides_runpath=$lt_cv_shlibpath_overrides_runpath
- # This implies no fast_install, which is unacceptable.
- # Some rework will be needed to allow for fast_install
- # before this can be enabled.
- # Append ld.so.conf contents to the search path
- if test -f /etc/ld.so.conf; then
- lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s 2>/dev/null", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;/^[ ]*hwcap[ ]/d;s/[:, ]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;s/"//g;/^$/d' | tr '\n' ' '`
- sys_lib_dlsearch_path_spec="/lib /usr/lib $lt_ld_extra"
- fi
- # We used to test for /lib/ld.so.1 and disable shared libraries on
- # powerpc, because MkLinux only supported shared libraries with the
- # GNU dynamic linker. Since this was broken with cross compilers,
- # most powerpc-linux boxes support dynamic linking these days and
- # people can always --disable-shared, the test was removed, and we
- # assume the GNU/Linux dynamic linker is in use.
- dynamic_linker='GNU/Linux ld.so'
-netbsdelf*-gnu)
- need_version=no
- dynamic_linker='NetBSD ld.elf_so'
-netbsd*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
- dynamic_linker='NetBSD (a.out) ld.so'
- else
- fi
-newsos6)
-*nto* | *qnx*)
- version_type=qnx
- need_version=no
- dynamic_linker='ldqnx.so'
-openbsd*)
- sys_lib_dlsearch_path_spec="/usr/lib"
- # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
- case $host_os in
- openbsd3.3 | openbsd3.3.*) need_version=yes ;;
- *) need_version=no ;;
- esac
- case $host_os in
- openbsd2.[89] | openbsd2.[89].*)
- esac
- else
- fi
-os2*)
- library_names_spec='$libname${shared_ext} $libname.a'
- dynamic_linker='OS/2 ld.exe'
-osf3* | osf4* | osf5*)
- version_type=osf
- need_version=no
- sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
- sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
-rdos*)
- dynamic_linker=no
-solaris*)
- need_version=no
- # ldd complains unless libraries are executable
- postinstall_cmds='chmod +x $lib'
-sunos4*)
- finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
- fi
- need_version=yes
-sysv4 | sysv4.3*)
- sni)
- siemens)
- motorola)
- need_version=no
- sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
- esac
-sysv4*MP*)
- library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
- soname_spec='$libname${shared_ext}.$major'
- fi
-sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
- version_type=freebsd-elf
- need_version=no
- sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
- else
- sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
- case $host_os in
- sco3.2v5*)
- sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
- esac
- fi
- sys_lib_dlsearch_path_spec='/usr/lib'
-tpf*)
- # TPF is a cross-target only. Preferred cross-host = GNU/Linux.
- need_version=no
-uts4*)
- dynamic_linker=no
-esac
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $dynamic_linker" >&5
-$as_echo "$dynamic_linker" >&6; }
-test "$dynamic_linker" = no && can_build_shared=no
-variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
-if test "$GCC" = yes; then
- variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
-fi
-if test "${lt_cv_sys_lib_search_path_spec+set}" = set; then
- sys_lib_search_path_spec="$lt_cv_sys_lib_search_path_spec"
-fi
-if test "${lt_cv_sys_lib_dlsearch_path_spec+set}" = set; then
- sys_lib_dlsearch_path_spec="$lt_cv_sys_lib_dlsearch_path_spec"
-fi
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking how to hardcode library paths into programs" >&5
-$as_echo_n "checking how to hardcode library paths into programs... " >&6; }
-hardcode_action=
-if test -n "$hardcode_libdir_flag_spec" ||
- test -n "$runpath_var" ||
- test "X$hardcode_automatic" = "Xyes" ; then
- # We can hardcode non-existent directories.
- if test "$hardcode_direct" != no &&
- # If the only mechanism to avoid hardcoding is shlibpath_var, we
- # have to relink, otherwise we might link with an installed library
- # when we should be linking with a yet-to-be-installed one
- ## test "$_LT_TAGVAR(hardcode_shlibpath_var, )" != no &&
- test "$hardcode_minus_L" != no; then
- # Linking always hardcodes the temporary library directory.
- hardcode_action=relink
- else
- # We can link without hardcoding, and we can hardcode nonexisting dirs.
- hardcode_action=immediate
- fi
-else
- # We cannot hardcode anything, or else we can only hardcode existing
- # directories.
- hardcode_action=unsupported
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $hardcode_action" >&5
-$as_echo "$hardcode_action" >&6; }
-if test "$hardcode_action" = relink ||
- test "$inherit_rpath" = yes; then
- # Fast installation is not supported
- enable_fast_install=no
-elif test "$shlibpath_overrides_runpath" = yes ||
- test "$enable_shared" = no; then
- # Fast installation is not necessary
- enable_fast_install=needless
-fi
- if test "x$enable_dlopen" != xyes; then
- enable_dlopen=unknown
- enable_dlopen_self=unknown
- enable_dlopen_self_static=unknown
-else
- lt_cv_dlopen=no
- lt_cv_dlopen_libs=
- case $host_os in
- beos*)
- lt_cv_dlopen="load_add_on"
- lt_cv_dlopen_self=yes
- mingw* | pw32* | cegcc*)
- lt_cv_dlopen="LoadLibrary"
- cygwin*)
- lt_cv_dlopen="dlopen"
- darwin*)
- # if libdl is installed we need to link against it
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for dlopen in -ldl" >&5
-$as_echo_n "checking for dlopen in -ldl... " >&6; }
-if ${ac_cv_lib_dl_dlopen+:} false; then :
-else
- ac_check_lib_save_LIBS=$LIBS
-LIBS="-ldl $LIBS"
-cat confdefs.h - <<_ACEOF >conftest.$ac_ext
-/* Override any GCC internal prototype to avoid an error.
- Use char because int might match the return type of a GCC
- builtin and then its argument prototype would still apply. */
-#ifdef __cplusplus
-extern "C"
-#endif
-char dlopen ();
-int
-main ()
-return dlopen ();
- return 0;
-_ACEOF
- ac_cv_lib_dl_dlopen=yes
-else
- ac_cv_lib_dl_dlopen=no
-fi
-LIBS=$ac_check_lib_save_LIBS
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_dl_dlopen" >&5
-$as_echo "$ac_cv_lib_dl_dlopen" >&6; }
-if test "x$ac_cv_lib_dl_dlopen" = xyes; then :
- lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-ldl"
-else
- lt_cv_dlopen="dyld"
-fi
- ac_fn_c_check_func "$LINENO" "shl_load" "ac_cv_func_shl_load"
-if test "x$ac_cv_func_shl_load" = xyes; then :
- lt_cv_dlopen="shl_load"
-else
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for shl_load in -ldld" >&5
-$as_echo_n "checking for shl_load in -ldld... " >&6; }
-if ${ac_cv_lib_dld_shl_load+:} false; then :
-else
-LIBS="-ldld $LIBS"
-#ifdef __cplusplus
-extern "C"
-#endif
-char shl_load ();
-int
-main ()
-return shl_load ();
- return 0;
-_ACEOF
- ac_cv_lib_dld_shl_load=yes
-else
- ac_cv_lib_dld_shl_load=no
-fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_dld_shl_load" >&5
-$as_echo "$ac_cv_lib_dld_shl_load" >&6; }
-if test "x$ac_cv_lib_dld_shl_load" = xyes; then :
- lt_cv_dlopen="shl_load" lt_cv_dlopen_libs="-ldld"
-else
- ac_fn_c_check_func "$LINENO" "dlopen" "ac_cv_func_dlopen"
-if test "x$ac_cv_func_dlopen" = xyes; then :
-else
-else
-LIBS="-ldl $LIBS"
-#ifdef __cplusplus
-extern "C"
-#endif
-char dlopen ();
-int
-main ()
-return dlopen ();
- return 0;
-_ACEOF
-else
-fi
-fi
-else
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for dlopen in -lsvld" >&5
-$as_echo_n "checking for dlopen in -lsvld... " >&6; }
-if ${ac_cv_lib_svld_dlopen+:} false; then :
-else
-LIBS="-lsvld $LIBS"
-#ifdef __cplusplus
-extern "C"
-#endif
-char dlopen ();
-int
-main ()
-return dlopen ();
- return 0;
-_ACEOF
- ac_cv_lib_svld_dlopen=yes
-else
- ac_cv_lib_svld_dlopen=no
-fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_svld_dlopen" >&5
-$as_echo "$ac_cv_lib_svld_dlopen" >&6; }
-if test "x$ac_cv_lib_svld_dlopen" = xyes; then :
- lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-lsvld"
-else
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for dld_link in -ldld" >&5
-$as_echo_n "checking for dld_link in -ldld... " >&6; }
-if ${ac_cv_lib_dld_dld_link+:} false; then :
-else
-LIBS="-ldld $LIBS"
-#ifdef __cplusplus
-extern "C"
-#endif
-char dld_link ();
-int
-main ()
-return dld_link ();
- return 0;
-_ACEOF
- ac_cv_lib_dld_dld_link=yes
-else
- ac_cv_lib_dld_dld_link=no
-fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_dld_dld_link" >&5
-$as_echo "$ac_cv_lib_dld_dld_link" >&6; }
-if test "x$ac_cv_lib_dld_dld_link" = xyes; then :
- lt_cv_dlopen="dld_link" lt_cv_dlopen_libs="-ldld"
-fi
-fi
-fi
-fi
-fi
-fi
- esac
- if test "x$lt_cv_dlopen" != xno; then
- enable_dlopen=yes
- else
- enable_dlopen=no
- fi
- case $lt_cv_dlopen in
- dlopen)
- save_CPPFLAGS="$CPPFLAGS"
- test "x$ac_cv_header_dlfcn_h" = xyes && CPPFLAGS="$CPPFLAGS -DHAVE_DLFCN_H"
- save_LDFLAGS="$LDFLAGS"
- wl=$lt_prog_compiler_wl eval LDFLAGS=\"\$LDFLAGS $export_dynamic_flag_spec\"
- save_LIBS="$LIBS"
- LIBS="$lt_cv_dlopen_libs $LIBS"
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether a program can dlopen itself" >&5
-$as_echo_n "checking whether a program can dlopen itself... " >&6; }
-if ${lt_cv_dlopen_self+:} false; then :
-else
- if test "$cross_compiling" = yes; then :
- lt_cv_dlopen_self=cross
-else
- lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
- lt_status=$lt_dlunknown
- cat > conftest.$ac_ext <<_LT_EOF
-#line $LINENO "configure"
-#include "confdefs.h"
-#if HAVE_DLFCN_H
-#include <dlfcn.h>
-#endif
-#include <stdio.h>
-#ifdef RTLD_GLOBAL
-# define LT_DLGLOBAL RTLD_GLOBAL
-#else
-# ifdef DL_GLOBAL
-# define LT_DLGLOBAL DL_GLOBAL
-# else
-# define LT_DLGLOBAL 0
-# endif
-#endif
-/* We may have to define LT_DLLAZY_OR_NOW in the command line if we
- find out it does not work in some platform. */
-#ifndef LT_DLLAZY_OR_NOW
-# ifdef RTLD_LAZY
-# define LT_DLLAZY_OR_NOW RTLD_LAZY
-# else
-# ifdef DL_LAZY
-# define LT_DLLAZY_OR_NOW DL_LAZY
-# else
-# ifdef RTLD_NOW
-# define LT_DLLAZY_OR_NOW RTLD_NOW
-# else
-# ifdef DL_NOW
-# define LT_DLLAZY_OR_NOW DL_NOW
-# else
-# define LT_DLLAZY_OR_NOW 0
-# endif
-# endif
-# endif
-# endif
-#endif
-/* When -fvisbility=hidden is used, assume the code has been annotated
- correspondingly for the symbols needed. */
-#if defined(__GNUC__) && (((__GNUC__ == 3) && (__GNUC_MINOR__ >= 3)) || (__GNUC__ > 3))
-int fnord () __attribute__((visibility("default")));
-#endif
-int fnord () { return 42; }
-int main ()
- void *self = dlopen (0, LT_DLGLOBAL|LT_DLLAZY_OR_NOW);
- int status = $lt_dlunknown;
- if (self)
- if (dlsym (self,"fnord")) status = $lt_dlno_uscore;
- else
- if (dlsym( self,"_fnord")) status = $lt_dlneed_uscore;
- else puts (dlerror ());
- /* dlclose (self); */
- else
- puts (dlerror ());
- return status;
-_LT_EOF
- if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$ac_link\""; } >&5
- (eval $ac_link) 2>&5
- ac_status=$?
- test $ac_status = 0; } && test -s conftest${ac_exeext} 2>/dev/null; then
- (./conftest; exit; ) >&5 2>/dev/null
- lt_status=$?
- case x$lt_status in
- x$lt_dlno_uscore) lt_cv_dlopen_self=yes ;;
- x$lt_dlneed_uscore) lt_cv_dlopen_self=yes ;;
- x$lt_dlunknown|x*) lt_cv_dlopen_self=no ;;
- esac
- else :
- # compilation failed
- lt_cv_dlopen_self=no
- fi
-fi
-rm -fr conftest*
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_dlopen_self" >&5
-$as_echo "$lt_cv_dlopen_self" >&6; }
- if test "x$lt_cv_dlopen_self" = xyes; then
- wl=$lt_prog_compiler_wl eval LDFLAGS=\"\$LDFLAGS $lt_prog_compiler_static\"
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether a statically linked program can dlopen itself" >&5
-$as_echo_n "checking whether a statically linked program can dlopen itself... " >&6; }
-if ${lt_cv_dlopen_self_static+:} false; then :
-else
- lt_cv_dlopen_self_static=cross
-else
-#if HAVE_DLFCN_H
-#include <dlfcn.h>
-#endif
-#include <stdio.h>
-#ifdef RTLD_GLOBAL
-#else
-# ifdef DL_GLOBAL
-# else
-# endif
-#endif
-# ifdef RTLD_LAZY
-# else
-# ifdef DL_LAZY
-# else
-# ifdef RTLD_NOW
-# else
-# ifdef DL_NOW
-# else
-# endif
-# endif
-# endif
-# endif
-#endif
-#endif
-int main ()
- if (self)
- else
- else
- return status;
-_LT_EOF
- ac_status=$?
- lt_status=$?
- x$lt_dlno_uscore) lt_cv_dlopen_self_static=yes ;;
- x$lt_dlneed_uscore) lt_cv_dlopen_self_static=yes ;;
- x$lt_dlunknown|x*) lt_cv_dlopen_self_static=no ;;
- esac
- else :
- lt_cv_dlopen_self_static=no
- fi
-fi
-rm -fr conftest*
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_dlopen_self_static" >&5
-$as_echo "$lt_cv_dlopen_self_static" >&6; }
- fi
- CPPFLAGS="$save_CPPFLAGS"
- LDFLAGS="$save_LDFLAGS"
- LIBS="$save_LIBS"
- esac
- case $lt_cv_dlopen_self in
- yes|no) enable_dlopen_self=$lt_cv_dlopen_self ;;
- *) enable_dlopen_self=unknown ;;
- esac
- case $lt_cv_dlopen_self_static in
- yes|no) enable_dlopen_self_static=$lt_cv_dlopen_self_static ;;
- *) enable_dlopen_self_static=unknown ;;
- esac
-fi
-striplib=
-old_striplib=
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether stripping libraries is possible" >&5
-$as_echo_n "checking whether stripping libraries is possible... " >&6; }
-if test -n "$STRIP" && $STRIP -V 2>&1 | $GREP "GNU strip" >/dev/null; then
- test -z "$old_striplib" && old_striplib="$STRIP --strip-debug"
- test -z "$striplib" && striplib="$STRIP --strip-unneeded"
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
-$as_echo "yes" >&6; }
-else
-# FIXME - insert some real tests, host_os isn't really good enough
- case $host_os in
- darwin*)
- if test -n "$STRIP" ; then
- striplib="$STRIP -x"
- old_striplib="$STRIP -S"
- else
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
-$as_echo "no" >&6; }
- fi
- esac
-fi
- # Report which library types will actually be built
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking if libtool supports shared libraries" >&5
-$as_echo_n "checking if libtool supports shared libraries... " >&6; }
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $can_build_shared" >&5
-$as_echo "$can_build_shared" >&6; }
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether to build shared libraries" >&5
-$as_echo_n "checking whether to build shared libraries... " >&6; }
- test "$can_build_shared" = "no" && enable_shared=no
- # On AIX, shared libraries and static libraries use the same namespace, and
- # are all built from PIC.
- case $host_os in
- aix3*)
- test "$enable_shared" = yes && enable_static=no
- if test -n "$RANLIB"; then
- archive_cmds="$archive_cmds~\$RANLIB \$lib"
- postinstall_cmds='$RANLIB $lib'
- fi
- aix[4-9]*)
- if test "$host_cpu" != ia64 && test "$aix_use_runtimelinking" = no ; then
- fi
- esac
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $enable_shared" >&5
-$as_echo "$enable_shared" >&6; }
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether to build static libraries" >&5
-$as_echo_n "checking whether to build static libraries... " >&6; }
- # Make sure either enable_shared or enable_static is yes.
- test "$enable_shared" = yes || enable_static=yes
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $enable_static" >&5
-$as_echo "$enable_static" >&6; }
-fi
-ac_ext=c
-ac_cpp='$CPP $CPPFLAGS'
-ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_c_compiler_gnu
-CC="$lt_save_CC"
- ac_config_commands="$ac_config_commands libtool"
-# Only expand once:
-ac_ext=cpp
-ac_cpp='$CXXCPP $CPPFLAGS'
-ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
-if test -z "$CXX"; then
- if test -n "$CCC"; then
- CXX=$CCC
- else
- if test -n "$ac_tool_prefix"; then
- for ac_prog in g++ c++ gpp aCC CC cxx cc++ cl.exe FCC KCC RCC xlC_r xlC
- do
- # Extract the first word of "$ac_tool_prefix$ac_prog", so it can be a program name with args.
-set dummy $ac_tool_prefix$ac_prog; ac_word=$2
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $ac_word" >&5
-$as_echo_n "checking for $ac_word... " >&6; }
-if ${ac_cv_prog_CXX+:} false; then :
-else
- if test -n "$CXX"; then
- ac_cv_prog_CXX="$CXX" # Let the user override the test.
-else
-as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-for as_dir in $PATH
-do
- IFS=$as_save_IFS
- test -z "$as_dir" && as_dir=.
- for ac_exec_ext in '' $ac_executable_extensions; do
- if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then
- ac_cv_prog_CXX="$ac_tool_prefix$ac_prog"
- $as_echo "$as_me:${as_lineno-$LINENO}: found $as_dir/$ac_word$ac_exec_ext" >&5
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-CXX=$ac_cv_prog_CXX
-if test -n "$CXX"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $CXX" >&5
-$as_echo "$CXX" >&6; }
-else
-fi
- test -n "$CXX" && break
- done
-fi
- ac_ct_CXX=$CXX
-do
- # Extract the first word of "$ac_prog", so it can be a program name with args.
-set dummy $ac_prog; ac_word=$2
-if ${ac_cv_prog_ac_ct_CXX+:} false; then :
-else
- if test -n "$ac_ct_CXX"; then
- ac_cv_prog_ac_ct_CXX="$ac_ct_CXX" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_CXX="$ac_prog"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-ac_ct_CXX=$ac_cv_prog_ac_ct_CXX
-if test -n "$ac_ct_CXX"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_CXX" >&5
-$as_echo "$ac_ct_CXX" >&6; }
-else
-fi
- test -n "$ac_ct_CXX" && break
-done
- if test "x$ac_ct_CXX" = x; then
- CXX="g++"
- else
- case $cross_compiling:$ac_tool_warned in
-yes:)
-{ $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: using cross tools not prefixed with host triplet" >&5
-$as_echo "$as_me: WARNING: using cross tools not prefixed with host triplet" >&2;}
-ac_tool_warned=yes ;;
-esac
- CXX=$ac_ct_CXX
- fi
-fi
- fi
-fi
-# Provide some information about the compiler.
-$as_echo "$as_me:${as_lineno-$LINENO}: checking for C++ compiler version" >&5
-set X $ac_compile
-ac_compiler=$2
-for ac_option in --version -v -V -qversion; do
- { { ac_try="$ac_compiler $ac_option >&5"
-case "(($ac_try" in
- *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
- *) ac_try_echo=$ac_try;;
-esac
-eval ac_try_echo="\"\$as_me:${as_lineno-$LINENO}: $ac_try_echo\""
-$as_echo "$ac_try_echo"; } >&5
- (eval "$ac_compiler $ac_option >&5") 2>conftest.err
- ac_status=$?
- if test -s conftest.err; then
- sed '10a\
-... rest of stderr output deleted ...
- 10q' conftest.err >conftest.er1
- cat conftest.er1 >&5
- fi
- rm -f conftest.er1 conftest.err
-done
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are using the GNU C++ compiler" >&5
-$as_echo_n "checking whether we are using the GNU C++ compiler... " >&6; }
-if ${ac_cv_cxx_compiler_gnu+:} false; then :
-else
-int
-main ()
-#ifndef __GNUC__
- choke me
-#endif
- return 0;
-_ACEOF
-if ac_fn_cxx_try_compile "$LINENO"; then :
- ac_compiler_gnu=yes
-else
- ac_compiler_gnu=no
-fi
-rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
-ac_cv_cxx_compiler_gnu=$ac_compiler_gnu
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_cxx_compiler_gnu" >&5
-$as_echo "$ac_cv_cxx_compiler_gnu" >&6; }
-if test $ac_compiler_gnu = yes; then
- GXX=yes
-else
- GXX=
-fi
-ac_test_CXXFLAGS=${CXXFLAGS+set}
-ac_save_CXXFLAGS=$CXXFLAGS
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether $CXX accepts -g" >&5
-$as_echo_n "checking whether $CXX accepts -g... " >&6; }
-if ${ac_cv_prog_cxx_g+:} false; then :
-else
- ac_save_cxx_werror_flag=$ac_cxx_werror_flag
- ac_cxx_werror_flag=yes
- ac_cv_prog_cxx_g=no
- CXXFLAGS="-g"
-int
-main ()
- return 0;
-_ACEOF
- ac_cv_prog_cxx_g=yes
-else
- CXXFLAGS=""
-int
-main ()
- return 0;
-_ACEOF
-else
- ac_cxx_werror_flag=$ac_save_cxx_werror_flag
- CXXFLAGS="-g"
-int
-main ()
- return 0;
-_ACEOF
-fi
-fi
-fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_cxx_g" >&5
-$as_echo "$ac_cv_prog_cxx_g" >&6; }
-if test "$ac_test_CXXFLAGS" = set; then
- CXXFLAGS=$ac_save_CXXFLAGS
-elif test $ac_cv_prog_cxx_g = yes; then
- if test "$GXX" = yes; then
- CXXFLAGS="-g -O2"
- else
- CXXFLAGS="-g"
- fi
-else
- CXXFLAGS="-O2"
- else
- CXXFLAGS=
- fi
-fi
-ac_ext=c
-depcc="$CXX" am_compiler_list=
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking dependency style of $depcc" >&5
-$as_echo_n "checking dependency style of $depcc... " >&6; }
-if ${am_cv_CXX_dependencies_compiler_type+:} false; then :
-else
- if test -z "$AMDEP_TRUE" && test -f "$am_depcomp"; then
- # We make a subdir and do the tests there. Otherwise we can end up
- # making bogus files that we don't know about and never remove. For
- # instance it was reported that on HP-UX the gcc test will end up
- # making a dummy file named `D' -- because `-MD' means `put the output
- # in D'.
- rm -rf conftest.dir
- mkdir conftest.dir
- # Copy depcomp to subdir because otherwise we won't find it if we're
- # using a relative directory.
- cp "$am_depcomp" conftest.dir
- cd conftest.dir
- # We will build objects and dependencies in a subdirectory because
- # it helps to detect inapplicable dependency modes. For instance
- # both Tru64's cc and ICC support -MD to output dependencies as a
- # side effect of compilation, but ICC will put the dependencies in
- # the current directory while Tru64 will put them in the object
- # directory.
- mkdir sub
- am_cv_CXX_dependencies_compiler_type=none
- if test "$am_compiler_list" = ""; then
- am_compiler_list=`sed -n 's/^#*\([a-zA-Z0-9]*\))$/\1/p' < ./depcomp`
- fi
- am__universal=false
- case " $depcc " in #(
- *\ -arch\ *\ -arch\ *) am__universal=true ;;
- esac
- for depmode in $am_compiler_list; do
- # Setup a source with many dependencies, because some compilers
- # like to wrap large dependency lists on column 80 (with \), and
- # we should not choose a depcomp mode which is confused by this.
- # We need to recreate these files for each test, as the compiler may
- # overwrite some of them when testing with obscure command lines.
- # This happens at least with the AIX C compiler.
- : > sub/conftest.c
- for i in 1 2 3 4 5 6; do
- echo '#include "conftst'$i'.h"' >> sub/conftest.c
- # Using `: > sub/conftst$i.h' creates only sub/conftst1.h with
- # Solaris 8's {/usr,}/bin/sh.
- touch sub/conftst$i.h
- done
- echo "${am__include} ${am__quote}sub/conftest.Po${am__quote}" > confmf
- # We check with `-c' and `-o' for the sake of the "dashmstdout"
- # mode. It turns out that the SunPro C++ compiler does not properly
- # handle `-M -o', and we need to detect this. Also, some Intel
- # versions had trouble with output in subdirs
- am__obj=sub/conftest.${OBJEXT-o}
- am__minus_obj="-o $am__obj"
- case $depmode in
- gcc)
- # This depmode causes a compiler race in universal mode.
- test "$am__universal" = false || continue
- nosideeffect)
- # after this tag, mechanisms are not by side-effect, so they'll
- # only be used when explicitly requested
- if test "x$enable_dependency_tracking" = xyes; then
- continue
- else
- break
- fi
- msvc7 | msvc7msys | msvisualcpp | msvcmsys)
- # This compiler won't grok `-c -o', but also, the minuso test has
- # not run yet. These depmodes are late enough in the game, and
- # so weak that their functioning should not be impacted.
- am__obj=conftest.${OBJEXT-o}
- am__minus_obj=
- none) break ;;
- esac
- if depmode=$depmode \
- source=sub/conftest.c object=$am__obj \
- depfile=sub/conftest.Po tmpdepfile=sub/conftest.TPo \
- $SHELL ./depcomp $depcc -c $am__minus_obj sub/conftest.c \
- >/dev/null 2>conftest.err &&
- grep sub/conftst1.h sub/conftest.Po > /dev/null 2>&1 &&
- grep sub/conftst6.h sub/conftest.Po > /dev/null 2>&1 &&
- grep $am__obj sub/conftest.Po > /dev/null 2>&1 &&
- ${MAKE-make} -s -f confmf > /dev/null 2>&1; then
- # icc doesn't choke on unknown options, it will just issue warnings
- # or remarks (even with -Werror). So we grep stderr for any message
- # that says an option was ignored or not supported.
- # When given -MP, icc 7.0 and 7.1 complain thusly:
- # icc: Command line warning: ignoring option '-M'; no argument required
- # The diagnosis changed in icc 8.0:
- # icc: Command line remark: option '-MP' not supported
- if (grep 'ignoring option' conftest.err ||
- grep 'not supported' conftest.err) >/dev/null 2>&1; then :; else
- am_cv_CXX_dependencies_compiler_type=$depmode
- break
- fi
- fi
- done
- cd ..
-else
-fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $am_cv_CXX_dependencies_compiler_type" >&5
-$as_echo "$am_cv_CXX_dependencies_compiler_type" >&6; }
-CXXDEPMODE=depmode=$am_cv_CXX_dependencies_compiler_type
- if
- test "x$enable_dependency_tracking" != xno \
- && test "$am_cv_CXX_dependencies_compiler_type" = gcc3; then
- am__fastdepCXX_TRUE=
- am__fastdepCXX_FALSE='#'
-else
- am__fastdepCXX_TRUE='#'
-fi
-func_stripname_cnf ()
- case ${2} in
- .*) func_stripname_result=`$ECHO "${3}" | $SED "s%^${1}%%; s%\\\\${2}\$%%"`;;
- *) func_stripname_result=`$ECHO "${3}" | $SED "s%^${1}%%; s%${2}\$%%"`;;
- esac
-} # func_stripname_cnf
- if test -n "$CXX" && ( test "X$CXX" != "Xno" &&
- ( (test "X$CXX" = "Xg++" && `g++ -v >/dev/null 2>&1` ) ||
- (test "X$CXX" != "Xg++"))) ; then
- ac_ext=cpp
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to run the C++ preprocessor" >&5
-$as_echo_n "checking how to run the C++ preprocessor... " >&6; }
-if test -z "$CXXCPP"; then
- if ${ac_cv_prog_CXXCPP+:} false; then :
-else
- # Double quotes because CXXCPP needs to be expanded
- for CXXCPP in "$CXX -E" "/lib/cpp"
- do
- ac_preproc_ok=false
-for ac_cxx_preproc_warn_flag in '' yes
-do
- # Use a header file that comes with gcc, so configuring glibc
- # with a fresh cross-compiler works.
- # Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
- # <limits.h> exists even on freestanding compilers.
- # On the NeXT, cc -E runs the code through the compiler's parser,
- # not just through cpp. "Syntax error" is here to catch this case.
-#ifdef __STDC__
-# include <limits.h>
-#else
-# include <assert.h>
-#endif
- Syntax error
-_ACEOF
-if ac_fn_cxx_try_cpp "$LINENO"; then :
-else
- # Broken: fails on valid input.
-continue
-fi
-rm -f conftest.err conftest.i conftest.$ac_ext
- # OK, works on sane cases. Now check whether nonexistent headers
- # can be detected and how.
-#include <ac_nonexistent.h>
-_ACEOF
- # Broken: success on invalid input.
-continue
-else
- # Passes both tests.
-ac_preproc_ok=:
-break
-fi
-done
-# Because of `break', _AC_PREPROC_IFELSE's cleaning code was skipped.
-rm -f conftest.i conftest.err conftest.$ac_ext
-if $ac_preproc_ok; then :
- break
-fi
- done
- ac_cv_prog_CXXCPP=$CXXCPP
-fi
- CXXCPP=$ac_cv_prog_CXXCPP
-else
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $CXXCPP" >&5
-$as_echo "$CXXCPP" >&6; }
-ac_preproc_ok=false
-do
- cat confdefs.h - <<_ACEOF >conftest.$ac_ext
-/* end confdefs.h. */
-#ifdef __STDC__
-#else
-#endif
- Syntax error
-_ACEOF
-else
-continue
-fi
-_ACEOF
-continue
-else
-ac_preproc_ok=:
-break
-fi
-done
-else
- { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
-$as_echo "$as_me: error: in \`$ac_pwd':" >&2;}
-as_fn_error $? "C++ preprocessor \"$CXXCPP\" fails sanity check
-See \`config.log' for more details" "$LINENO" 5; }
-fi
-ac_ext=c
-else
- _lt_caught_CXX_error=yes
-fi
-ac_ext=cpp
-archive_cmds_need_lc_CXX=no
-allow_undefined_flag_CXX=
-always_export_symbols_CXX=no
-archive_expsym_cmds_CXX=
-compiler_needs_object_CXX=no
-export_dynamic_flag_spec_CXX=
-hardcode_direct_CXX=no
-hardcode_direct_absolute_CXX=no
-hardcode_libdir_flag_spec_CXX=
-hardcode_libdir_separator_CXX=
-hardcode_minus_L_CXX=no
-hardcode_shlibpath_var_CXX=unsupported
-hardcode_automatic_CXX=no
-inherit_rpath_CXX=no
-module_cmds_CXX=
-module_expsym_cmds_CXX=
-link_all_deplibs_CXX=unknown
-old_archive_cmds_CXX=$old_archive_cmds
-reload_flag_CXX=$reload_flag
-reload_cmds_CXX=$reload_cmds
-no_undefined_flag_CXX=
-whole_archive_flag_spec_CXX=
-enable_shared_with_static_runtimes_CXX=no
-# Source file extension for C++ test sources.
-ac_ext=cpp
-# Object file extension for compiled C++ test sources.
-objext=o
-objext_CXX=$objext
-# No sense in running all these tests if we already determined that
-# the CXX compiler isn't working. Some variables (like enable_shared)
-# are currently assumed to apply to all compilers on this platform,
-# and will be corrupted by setting them based on a non-working compiler.
-if test "$_lt_caught_CXX_error" != yes; then
- # Code to be used in simple compile tests
- lt_simple_compile_test_code="int some_variable = 0;"
- # Code to be used in simple link tests
- lt_simple_link_test_code='int main(int, char *[]) { return(0); }'
- # ltmain only uses $CC for tagged configurations so make sure $CC is set.
-# If no C compiler was specified, use CC.
-LTCC=${LTCC-"$CC"}
-# If no C compiler flags were specified, use CFLAGS.
-LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
-# Allow CC to be a program name with arguments.
-compiler=$CC
- # save warnings/boilerplate of simple test code
- ac_outfile=conftest.$ac_objext
-echo "$lt_simple_compile_test_code" >conftest.$ac_ext
-eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
-_lt_compiler_boilerplate=`cat conftest.err`
-$RM conftest*
-echo "$lt_simple_link_test_code" >conftest.$ac_ext
-eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
-_lt_linker_boilerplate=`cat conftest.err`
-$RM -r conftest*
- # Allow CC to be a program name with arguments.
- lt_save_CC=$CC
- lt_save_CFLAGS=$CFLAGS
- lt_save_LD=$LD
- lt_save_GCC=$GCC
- GCC=$GXX
- lt_save_with_gnu_ld=$with_gnu_ld
- lt_save_path_LD=$lt_cv_path_LD
- if test -n "${lt_cv_prog_gnu_ldcxx+set}"; then
- lt_cv_prog_gnu_ld=$lt_cv_prog_gnu_ldcxx
- else
- $as_unset lt_cv_prog_gnu_ld
- fi
- if test -n "${lt_cv_path_LDCXX+set}"; then
- lt_cv_path_LD=$lt_cv_path_LDCXX
- else
- $as_unset lt_cv_path_LD
- fi
- test -z "${LDCXX+set}" || LD=$LDCXX
- CC=${CXX-"c++"}
- CFLAGS=$CXXFLAGS
- compiler=$CC
- compiler_CXX=$CC
- for cc_temp in $compiler""; do
- case $cc_temp in
- compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
- distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
- *) break;;
- esac
-done
-cc_basename=`$ECHO "$cc_temp" | $SED "s%.*/%%; s%^$host_alias-%%"`
- if test -n "$compiler"; then
- # We don't want -fno-exception when compiling C++ code, so set the
- # no_builtin_flag separately
- lt_prog_compiler_no_builtin_flag_CXX=' -fno-builtin'
- else
- fi
- # Set up default GNU C++ configuration
-# Check whether --with-gnu-ld was given.
-if test "${with_gnu_ld+set}" = set; then :
- withval=$with_gnu_ld; test "$withval" = no || with_gnu_ld=yes
-else
- with_gnu_ld=no
-fi
-ac_prog=ld
- # Check if gcc -print-prog-name=ld gives a path.
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for ld used by $CC" >&5
-$as_echo_n "checking for ld used by $CC... " >&6; }
- case $host in
- *-*-mingw*)
- # gcc leaves a trailing carriage return which upsets mingw
- ac_prog=`($CC -print-prog-name=ld) 2>&5 | tr -d '\015'` ;;
- ac_prog=`($CC -print-prog-name=ld) 2>&5` ;;
- esac
- case $ac_prog in
- # Accept absolute paths.
- re_direlt='/[^/][^/]*/\.\./'
- # Canonicalize the pathname of ld
- ac_prog=`$ECHO "$ac_prog"| $SED 's%\\\\%/%g'`
- while $ECHO "$ac_prog" | $GREP "$re_direlt" > /dev/null 2>&1; do
- ac_prog=`$ECHO $ac_prog| $SED "s%$re_direlt%/%"`
- done
- test -z "$LD" && LD="$ac_prog"
- # If it fails, then pretend we aren't using GCC.
- ac_prog=ld
- # If it is relative, then search for the first ld in PATH.
- with_gnu_ld=unknown
- esac
-elif test "$with_gnu_ld" = yes; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for GNU ld" >&5
-$as_echo_n "checking for GNU ld... " >&6; }
-else
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for non-GNU ld" >&5
-$as_echo_n "checking for non-GNU ld... " >&6; }
-fi
-if ${lt_cv_path_LD+:} false; then :
-else
- if test -z "$LD"; then
- lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
- for ac_dir in $PATH; do
- IFS="$lt_save_ifs"
- test -z "$ac_dir" && ac_dir=.
- if test -f "$ac_dir/$ac_prog" || test -f "$ac_dir/$ac_prog$ac_exeext"; then
- lt_cv_path_LD="$ac_dir/$ac_prog"
- # Check to see if the program is GNU ld. I'd rather use --version,
- # but apparently some variants of GNU ld only accept -v.
- # Break only if it was the GNU/non-GNU ld that we prefer.
- case `"$lt_cv_path_LD" -v 2>&1 </dev/null` in
- *GNU* | *'with BFD'*)
- test "$with_gnu_ld" != no && break
- test "$with_gnu_ld" != yes && break
- esac
- fi
- done
-else
- lt_cv_path_LD="$LD" # Let the user override the test with a path.
-fi
-fi
-LD="$lt_cv_path_LD"
-if test -n "$LD"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $LD" >&5
-$as_echo "$LD" >&6; }
-else
-fi
-test -z "$LD" && as_fn_error $? "no acceptable ld found in \$PATH" "$LINENO" 5
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if the linker ($LD) is GNU ld" >&5
-$as_echo_n "checking if the linker ($LD) is GNU ld... " >&6; }
-if ${lt_cv_prog_gnu_ld+:} false; then :
-else
- # I'd rather use --version here, but apparently some GNU lds only accept -v.
-case `$LD -v 2>&1 </dev/null` in
-*GNU* | *'with BFD'*)
- lt_cv_prog_gnu_ld=yes
- lt_cv_prog_gnu_ld=no
-esac
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_gnu_ld" >&5
-$as_echo "$lt_cv_prog_gnu_ld" >&6; }
-with_gnu_ld=$lt_cv_prog_gnu_ld
- # Check if GNU C++ uses GNU ld as the underlying linker, since the
- # archiving commands below assume that GNU ld is being used.
- if test "$with_gnu_ld" = yes; then
- archive_cmds_CXX='$CC $pic_flag -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_expsym_cmds_CXX='$CC $pic_flag -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- hardcode_libdir_flag_spec_CXX='${wl}-rpath ${wl}$libdir'
- export_dynamic_flag_spec_CXX='${wl}--export-dynamic'
- # If archive_cmds runs LD, not CC, wlarc should be empty
- # XXX I think wlarc can be eliminated in ltcf-cxx, but I need to
- # investigate it a little bit more. (MM)
- wlarc='${wl}'
- # ancient GNU ld didn't support --whole-archive et. al.
- if eval "`$CC -print-prog-name=ld` --help 2>&1" |
- $GREP 'no-whole-archive' > /dev/null; then
- whole_archive_flag_spec_CXX="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
- else
- fi
- else
- with_gnu_ld=no
- wlarc=
- # A generic and very simple default shared library creation
- # command for GNU C++ for the case where it uses the native
- # linker, instead of GNU ld. If possible, this setting should
- # overridden to take advantage of the native linker features on
- # the platform it is being used on.
- archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $lib'
- fi
- # Commands to make compiler produce verbose output that lists
- # what "hidden" libraries, object files and flags are used when
- # linking a shared library.
- output_verbose_link_cmd='$CC -shared $CFLAGS -v conftest.$objext 2>&1 | $GREP -v "^Configured with:" | $GREP "\-L"'
- else
- GXX=no
- with_gnu_ld=no
- wlarc=
- fi
- # PORTME: fill in a description of your system's C++ link characteristics
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the $compiler linker ($LD) supports shared libraries" >&5
-$as_echo_n "checking whether the $compiler linker ($LD) supports shared libraries... " >&6; }
- ld_shlibs_CXX=yes
- case $host_os in
- aix3*)
- # FIXME: insert proper C++ library support
- ld_shlibs_CXX=no
- aix[4-9]*)
- if test "$host_cpu" = ia64; then
- # On IA64, the linker does run time linking by default, so we don't
- # have to do anything special.
- aix_use_runtimelinking=no
- exp_sym_flag='-Bexport'
- no_entry_flag=""
- else
- # Test if we are trying to use run time linking or normal
- # AIX style linking. If -brtl is somewhere in LDFLAGS, we
- # need to do runtime linking.
- case $host_os in aix4.[23]|aix4.[23].*|aix[5-9]*)
- for ld_flag in $LDFLAGS; do
- case $ld_flag in
- *-brtl*)
- aix_use_runtimelinking=yes
- break
- esac
- done
- esac
- exp_sym_flag='-bexport'
- no_entry_flag='-bnoentry'
- fi
- # When large executables or shared objects are built, AIX ld can
- # have problems creating the table of contents. If linking a library
- # or program results in "error TOC overflow" add -mminimal-toc to
- # CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
- # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
- archive_cmds_CXX=''
- hardcode_direct_CXX=yes
- hardcode_direct_absolute_CXX=yes
- hardcode_libdir_separator_CXX=':'
- link_all_deplibs_CXX=yes
- file_list_spec_CXX='${wl}-f,'
- case $host_os in aix4.[012]|aix4.[012].*)
- # We only want to do this on AIX 4.2 and lower, the check
- # below for broken collect2 doesn't work under 4.3+
- collect2name=`${CC} -print-prog-name=collect2`
- if test -f "$collect2name" &&
- strings "$collect2name" | $GREP resolve_lib_name >/dev/null
- then
- # We have reworked collect2
- else
- # We have old collect2
- hardcode_direct_CXX=unsupported
- # It fails to find uninstalled libraries when the uninstalled
- # path is not listed in the libpath. Setting hardcode_minus_L
- # to unsupported forces relinking
- hardcode_minus_L_CXX=yes
- hardcode_libdir_flag_spec_CXX='-L$libdir'
- fi
- esac
- shared_flag='-shared'
- if test "$aix_use_runtimelinking" = yes; then
- shared_flag="$shared_flag "'${wl}-G'
- fi
- else
- # not using gcc
- # VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
- # chokes on -Wl,-G. The following line is correct:
- shared_flag='-G'
- else
- shared_flag='${wl}-G'
- else
- shared_flag='${wl}-bM:SRE'
- fi
- fi
- fi
- export_dynamic_flag_spec_CXX='${wl}-bexpall'
- # It seems that -bexpall does not export symbols beginning with
- # underscore (_), so it is better to generate a list of symbols to
- # export.
- always_export_symbols_CXX=yes
- # Warning - without using the other runtime loading flags (-brtl),
- # -berok will link without error, but may produce a broken library.
- allow_undefined_flag_CXX='-berok'
- # Determine the default libpath from the value encoded in an empty
- # executable.
- if test "${lt_cv_aix_libpath+set}" = set; then
- aix_libpath=$lt_cv_aix_libpath
-else
- if ${lt_cv_aix_libpath__CXX+:} false; then :
-else
-int
-main ()
- return 0;
-_ACEOF
-if ac_fn_cxx_try_link "$LINENO"; then :
- lt_aix_libpath_sed='
- /Import File Strings/,/^$/ {
- /^0/ {
- s/^0 *\([^ ]*\) *$/\1/
- p
- lt_cv_aix_libpath__CXX=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e "$lt_aix_libpath_sed"`
- # Check for a 64-bit object if we didn't find anything.
- if test -z "$lt_cv_aix_libpath__CXX"; then
- lt_cv_aix_libpath__CXX=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e "$lt_aix_libpath_sed"`
- fi
-fi
-rm -f core conftest.err conftest.$ac_objext \
- conftest$ac_exeext conftest.$ac_ext
- lt_cv_aix_libpath__CXX="/usr/lib:/lib"
- fi
-fi
- aix_libpath=$lt_cv_aix_libpath__CXX
-fi
- hardcode_libdir_flag_spec_CXX='${wl}-blibpath:$libdir:'"$aix_libpath"
- archive_expsym_cmds_CXX='$CC -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then func_echo_all "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
- else
- hardcode_libdir_flag_spec_CXX='${wl}-R $libdir:/usr/lib:/lib'
- allow_undefined_flag_CXX="-z nodefs"
- archive_expsym_cmds_CXX="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
- else
- # empty executable.
-else
-else
-int
-main ()
- return 0;
-_ACEOF
- /^0/ {
- p
- fi
-fi
- fi
-fi
-fi
- # Warning - without using the other run time loading flags,
- no_undefined_flag_CXX=' ${wl}-bernotok'
- allow_undefined_flag_CXX=' ${wl}-berok'
- # We only use this code for GNU lds that support --whole-archive.
- whole_archive_flag_spec_CXX='${wl}--whole-archive$convenience ${wl}--no-whole-archive'
- else
- # Exported symbols can be pulled into shared objects from archives
- whole_archive_flag_spec_CXX='$convenience'
- fi
- archive_cmds_need_lc_CXX=yes
- # This is similar to how AIX traditionally builds its shared
- # libraries.
- archive_expsym_cmds_CXX="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
- fi
- fi
- beos*)
- if $LD --help 2>&1 | $GREP ': supported targets:.* elf' > /dev/null; then
- allow_undefined_flag_CXX=unsupported
- # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
- # support --undefined. This deserves some investigation. FIXME
- archive_cmds_CXX='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- else
- ld_shlibs_CXX=no
- fi
- chorus*)
- case $cc_basename in
- ld_shlibs_CXX=no
- esac
- cygwin* | mingw* | pw32* | cegcc*)
- case $GXX,$cc_basename in
- ,cl* | no,cl*)
- # Native MSVC
- # hardcode_libdir_flag_spec is actually meaningless, as there is
- # no search path for DLLs.
- hardcode_libdir_flag_spec_CXX=' '
- file_list_spec_CXX='@'
- # Tell ltmain to make .lib files, not .a files.
- libext=lib
- # Tell ltmain to make .dll files, not .so files.
- shrext_cmds=".dll"
- # FIXME: Setting linknames here is a bad hack.
- archive_cmds_CXX='$CC -o $output_objdir/$soname $libobjs $compiler_flags $deplibs -Wl,-dll~linknames='
- archive_expsym_cmds_CXX='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
- $SED -n -e 's/\\\\\\\(.*\\\\\\\)/-link\\\ -EXPORT:\\\\\\\1/' -e '1\\\!p' < $export_symbols > $output_objdir/$soname.exp;
- else
- $SED -e 's/\\\\\\\(.*\\\\\\\)/-link\\\ -EXPORT:\\\\\\\1/' < $export_symbols > $output_objdir/$soname.exp;
- fi~
- $CC -o $tool_output_objdir$soname $libobjs $compiler_flags $deplibs "@$tool_output_objdir$soname.exp" -Wl,-DLL,-IMPLIB:"$tool_output_objdir$libname.dll.lib"~
- linknames='
- # The linker will not automatically build a static lib if we build a DLL.
- # _LT_TAGVAR(old_archive_from_new_cmds, CXX)='true'
- enable_shared_with_static_runtimes_CXX=yes
- # Don't use ranlib
- old_postinstall_cmds_CXX='chmod 644 $oldlib'
- postlink_cmds_CXX='lt_outputfile="@OUTPUT@"~
- lt_tool_outputfile="@TOOL_OUTPUT@"~
- case $lt_outputfile in
- *.exe|*.EXE) ;;
- lt_outputfile="$lt_outputfile.exe"
- lt_tool_outputfile="$lt_tool_outputfile.exe"
- esac~
- func_to_tool_file "$lt_outputfile"~
- if test "$MANIFEST_TOOL" != ":" && test -f "$lt_outputfile.manifest"; then
- $MANIFEST_TOOL -manifest "$lt_tool_outputfile.manifest" -outputresource:"$lt_tool_outputfile" || exit 1;
- $RM "$lt_outputfile.manifest";
- fi'
- # g++
- # _LT_TAGVAR(hardcode_libdir_flag_spec, CXX) is actually meaningless,
- # as there is no search path for DLLs.
- export_dynamic_flag_spec_CXX='${wl}--export-all-symbols'
- always_export_symbols_CXX=no
- if $LD --help 2>&1 | $GREP 'auto-import' > /dev/null; then
- archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
- # If the export-symbols file already is a .def file (1st line
- # is EXPORTS), use it as is; otherwise, prepend...
- cp $export_symbols $output_objdir/$soname.def;
- else
- echo EXPORTS > $output_objdir/$soname.def;
- cat $export_symbols >> $output_objdir/$soname.def;
- fi~
- $CC -shared -nostdlib $output_objdir/$soname.def $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
- else
- ld_shlibs_CXX=no
- fi
- esac
- darwin* | rhapsody*)
- archive_cmds_need_lc_CXX=no
- hardcode_direct_CXX=no
- hardcode_automatic_CXX=yes
- hardcode_shlibpath_var_CXX=unsupported
- if test "$lt_cv_ld_force_load" = "yes"; then
- whole_archive_flag_spec_CXX='`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience ${wl}-force_load,$conv\"; done; func_echo_all \"$new_convenience\"`'
- else
- whole_archive_flag_spec_CXX=''
- fi
- allow_undefined_flag_CXX="$_lt_dar_allow_undefined"
- ifort*) _lt_dar_can_shared=yes ;;
- *) _lt_dar_can_shared=$GCC ;;
- esac
- if test "$_lt_dar_can_shared" = "yes"; then
- output_verbose_link_cmd=func_echo_all
- archive_cmds_CXX="\$CC -dynamiclib \$allow_undefined_flag -o \$lib \$libobjs \$deplibs \$compiler_flags -install_name \$rpath/\$soname \$verstring $_lt_dar_single_mod${_lt_dsymutil}"
- module_cmds_CXX="\$CC \$allow_undefined_flag -o \$lib -bundle \$libobjs \$deplibs \$compiler_flags${_lt_dsymutil}"
- archive_expsym_cmds_CXX="sed 's,^,_,' < \$export_symbols > \$output_objdir/\${libname}-symbols.expsym~\$CC -dynamiclib \$allow_undefined_flag -o \$lib \$libobjs \$deplibs \$compiler_flags -install_name \$rpath/\$soname \$verstring ${_lt_dar_single_mod}${_lt_dar_export_syms}${_lt_dsymutil}"
- module_expsym_cmds_CXX="sed -e 's,^,_,' < \$export_symbols > \$output_objdir/\${libname}-symbols.expsym~\$CC \$allow_undefined_flag -o \$lib -bundle \$libobjs \$deplibs \$compiler_flags${_lt_dar_export_syms}${_lt_dsymutil}"
- if test "$lt_cv_apple_cc_single_mod" != "yes"; then
- archive_cmds_CXX="\$CC -r -keep_private_externs -nostdlib -o \${lib}-master.o \$libobjs~\$CC -dynamiclib \$allow_undefined_flag -o \$lib \${lib}-master.o \$deplibs \$compiler_flags -install_name \$rpath/\$soname \$verstring${_lt_dsymutil}"
- archive_expsym_cmds_CXX="sed 's,^,_,' < \$export_symbols > \$output_objdir/\${libname}-symbols.expsym~\$CC -r -keep_private_externs -nostdlib -o \${lib}-master.o \$libobjs~\$CC -dynamiclib \$allow_undefined_flag -o \$lib \${lib}-master.o \$deplibs \$compiler_flags -install_name \$rpath/\$soname \$verstring${_lt_dar_export_syms}${_lt_dsymutil}"
- fi
- else
- ld_shlibs_CXX=no
- fi
- dgux*)
- ec++*)
- ld_shlibs_CXX=no
- ghcx*)
- # Green Hills C++ Compiler
- ld_shlibs_CXX=no
- ld_shlibs_CXX=no
- esac
- freebsd2.*)
- # C++ shared libraries reported to be fairly broken before
- # switch to ELF
- ld_shlibs_CXX=no
- freebsd-elf*)
- freebsd* | dragonfly*)
- # FreeBSD 3 and later use GNU C++ and GNU ld with standard ELF
- # conventions
- ld_shlibs_CXX=yes
- gnu*)
- haiku*)
- archive_cmds_CXX='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- hpux9*)
- hardcode_libdir_flag_spec_CXX='${wl}+b ${wl}$libdir'
- hardcode_libdir_separator_CXX=:
- export_dynamic_flag_spec_CXX='${wl}-E'
- hardcode_minus_L_CXX=yes # Not in the search PATH,
- # but as the default
- # location of the library.
- CC*)
- ld_shlibs_CXX=no
- aCC*)
- archive_cmds_CXX='$RM $output_objdir/$soname~$CC -b ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- # There doesn't appear to be a way to prevent this compiler from
- # explicitly linking system object files so we need to strip them
- # from the output so that they don't get included in the library
- # dependencies.
- output_verbose_link_cmd='templist=`($CC -b $CFLAGS -v conftest.$objext 2>&1) | $EGREP "\-L"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; func_echo_all "$list"'
- archive_cmds_CXX='$RM $output_objdir/$soname~$CC -shared -nostdlib $pic_flag ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- else
- ld_shlibs_CXX=no
- fi
- esac
- hpux10*|hpux11*)
- if test $with_gnu_ld = no; then
- case $host_cpu in
- hppa*64*|ia64*)
- esac
- fi
- case $host_cpu in
- hppa*64*|ia64*)
- hardcode_shlibpath_var_CXX=no
- esac
- CC*)
- ld_shlibs_CXX=no
- aCC*)
- case $host_cpu in
- hppa*64*)
- archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- ia64*)
- archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- esac
- # dependencies.
- output_verbose_link_cmd='templist=`($CC -b $CFLAGS -v conftest.$objext 2>&1) | $GREP "\-L"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; func_echo_all "$list"'
- case $host_cpu in
- hppa*64*)
- archive_cmds_CXX='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- ia64*)
- archive_cmds_CXX='$CC -shared -nostdlib $pic_flag ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- archive_cmds_CXX='$CC -shared -nostdlib $pic_flag ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- esac
- fi
- else
- ld_shlibs_CXX=no
- fi
- esac
- interix[3-9]*)
- hardcode_libdir_flag_spec_CXX='${wl}-rpath,$libdir'
- # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
- # Instead, shared libraries are loaded at an image base (0x10000000 by
- # default) and relocated if they conflict, which is a slow very memory
- # consuming and fragmenting process. To avoid this, we pick a random,
- # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
- # time. Moving up from 0x10000000 also allows more sbrk(2) space.
- archive_cmds_CXX='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
- archive_expsym_cmds_CXX='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
- irix5* | irix6*)
- CC*)
- # SGI C++
- archive_cmds_CXX='$CC -shared -all -multigot $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -soname $soname `test -n "$verstring" && func_echo_all "-set_version $verstring"` -update_registry ${output_objdir}/so_locations -o $lib'
- # Archives containing C++ object files must be created using
- # "CC -ar", where "CC" is the IRIX C++ compiler. This is
- # necessary to make sure instantiated templates are included
- # in the archive.
- old_archive_cmds_CXX='$CC -ar -WR,-u -o $oldlib $oldobjs'
- if test "$with_gnu_ld" = no; then
- archive_cmds_CXX='$CC -shared $pic_flag -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && func_echo_all "${wl}-set_version ${wl}$verstring"` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- archive_cmds_CXX='$CC -shared $pic_flag -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && func_echo_all "${wl}-set_version ${wl}$verstring"` -o $lib'
- fi
- fi
- esac
- inherit_rpath_CXX=yes
- linux* | k*bsd*-gnu | kopensolaris*-gnu)
- KCC*)
- # Kuck and Associates, Inc. (KAI) C++ Compiler
- # KCC will only create a shared library if the output file
- # ends with ".so" (or ".sl" for HP-UX), so rename the library
- # to its proper name (with version) after linking.
- archive_cmds_CXX='tempext=`echo $shared_ext | $SED -e '\''s/\([^()0-9A-Za-z{}]\)/\\\\\1/g'\''`; templib=`echo $lib | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib; mv \$templib $lib'
- archive_expsym_cmds_CXX='tempext=`echo $shared_ext | $SED -e '\''s/\([^()0-9A-Za-z{}]\)/\\\\\1/g'\''`; templib=`echo $lib | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib ${wl}-retain-symbols-file,$export_symbols; mv \$templib $lib'
- # dependencies.
- output_verbose_link_cmd='templist=`$CC $CFLAGS -v conftest.$objext -o libconftest$shared_ext 2>&1 | $GREP "ld"`; rm -f libconftest$shared_ext; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; func_echo_all "$list"'
- # "CC -Bstatic", where "CC" is the KAI C++ compiler.
- old_archive_cmds_CXX='$CC -Bstatic -o $oldlib $oldobjs'
- icpc* | ecpc* )
- # Intel C++
- with_gnu_ld=yes
- # version 8.0 and above of icpc choke on multiply defined symbols
- # if we add $predep_objects and $postdep_objects, however 7.1 and
- # earlier do not add the objects themselves.
- case `$CC -V 2>&1` in
- *"Version 7."*)
- archive_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_expsym_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- *) # Version 8.0 or newer
- tmp_idyn=
- case $host_cpu in
- ia64*) tmp_idyn=' -i_dynamic';;
- esac
- archive_cmds_CXX='$CC -shared'"$tmp_idyn"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_expsym_cmds_CXX='$CC -shared'"$tmp_idyn"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- esac
- pgCC* | pgcpp*)
- # Portland Group C++ compiler
- case `$CC -V` in
- *pgCC\ [1-5].* | *pgcpp\ [1-5].*)
- prelink_cmds_CXX='tpldir=Template.dir~
- rm -rf $tpldir~
- $CC --prelink_objects --instantiation_dir $tpldir $objs $libobjs $compile_deplibs~
- compile_command="$compile_command `find $tpldir -name \*.o | sort | $NL2SP`"'
- old_archive_cmds_CXX='tpldir=Template.dir~
- rm -rf $tpldir~
- $CC --prelink_objects --instantiation_dir $tpldir $oldobjs$old_deplibs~
- $AR $AR_FLAGS $oldlib$oldobjs$old_deplibs `find $tpldir -name \*.o | sort | $NL2SP`~
- $RANLIB $oldlib'
- archive_cmds_CXX='tpldir=Template.dir~
- rm -rf $tpldir~
- $CC --prelink_objects --instantiation_dir $tpldir $predep_objects $libobjs $deplibs $convenience $postdep_objects~
- $CC -shared $pic_flag $predep_objects $libobjs $deplibs `find $tpldir -name \*.o | sort | $NL2SP` $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname -o $lib'
- archive_expsym_cmds_CXX='tpldir=Template.dir~
- rm -rf $tpldir~
- $CC -shared $pic_flag $predep_objects $libobjs $deplibs `find $tpldir -name \*.o | sort | $NL2SP` $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname ${wl}-retain-symbols-file ${wl}$export_symbols -o $lib'
- *) # Version 6 and above use weak symbols
- archive_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname -o $lib'
- archive_expsym_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname ${wl}-retain-symbols-file ${wl}$export_symbols -o $lib'
- esac
- hardcode_libdir_flag_spec_CXX='${wl}--rpath ${wl}$libdir'
- whole_archive_flag_spec_CXX='${wl}--whole-archive`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; func_echo_all \"$new_convenience\"` ${wl}--no-whole-archive'
- cxx*)
- # Compaq C++
- archive_expsym_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib ${wl}-retain-symbols-file $wl$export_symbols'
- runpath_var=LD_RUN_PATH
- hardcode_libdir_flag_spec_CXX='-rpath $libdir'
- # dependencies.
- output_verbose_link_cmd='templist=`$CC -shared $CFLAGS -v conftest.$objext 2>&1 | $GREP "ld"`; templist=`func_echo_all "$templist" | $SED "s/\(^.*ld.*\)\( .*ld .*$\)/\1/"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; func_echo_all "X$list" | $Xsed'
- xl* | mpixl* | bgxl*)
- # IBM XL 8.0 on PPC, with GNU ld
- archive_cmds_CXX='$CC -qmkshrobj $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- if test "x$supports_anon_versioning" = xyes; then
- archive_expsym_cmds_CXX='echo "{ global:" > $output_objdir/$libname.ver~
- cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
- echo "local: *; };" >> $output_objdir/$libname.ver~
- $CC -qmkshrobj $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
- fi
- case `$CC -V 2>&1 | sed 5q` in
- *Sun\ C*)
- # Sun C++ 5.9
- no_undefined_flag_CXX=' -zdefs'
- archive_cmds_CXX='$CC -G${allow_undefined_flag} -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- archive_expsym_cmds_CXX='$CC -G${allow_undefined_flag} -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-retain-symbols-file ${wl}$export_symbols'
- hardcode_libdir_flag_spec_CXX='-R$libdir'
- whole_archive_flag_spec_CXX='${wl}--whole-archive`new_convenience=; for conv in $convenience\"\"; do test -z \"$conv\" || new_convenience=\"$new_convenience,$conv\"; done; func_echo_all \"$new_convenience\"` ${wl}--no-whole-archive'
- compiler_needs_object_CXX=yes
- # Not sure whether something based on
- # $CC $CFLAGS -v conftest.$objext -o libconftest$shared_ext 2>&1
- # would be better.
- output_verbose_link_cmd='func_echo_all'
- # "CC -xar", where "CC" is the Sun C++ compiler. This is
- # in the archive.
- old_archive_cmds_CXX='$CC -xar -o $oldlib $oldobjs'
- esac
- esac
- lynxos*)
- ld_shlibs_CXX=no
- m88k*)
- ld_shlibs_CXX=no
- mvs*)
- cxx*)
- ld_shlibs_CXX=no
- ld_shlibs_CXX=no
- esac
- netbsd*)
- if echo __ELF__ | $CC -E - | $GREP __ELF__ >/dev/null; then
- archive_cmds_CXX='$LD -Bshareable -o $lib $predep_objects $libobjs $deplibs $postdep_objects $linker_flags'
- wlarc=
- fi
- # Workaround some broken pre-1.5 toolchains
- output_verbose_link_cmd='$CC -shared $CFLAGS -v conftest.$objext 2>&1 | $GREP conftest.$objext | $SED -e "s:-lgcc -lc -lgcc::"'
- *nto* | *qnx*)
- ld_shlibs_CXX=yes
- openbsd2*)
- # C++ shared libraries are fairly broken
- ld_shlibs_CXX=no
- openbsd*)
- if test -f /usr/libexec/ld.so; then
- archive_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $lib'
- if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- archive_expsym_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-retain-symbols-file,$export_symbols -o $lib'
- fi
- else
- ld_shlibs_CXX=no
- fi
- osf3* | osf4* | osf5*)
- KCC*)
- archive_cmds_CXX='tempext=`echo $shared_ext | $SED -e '\''s/\([^()0-9A-Za-z{}]\)/\\\\\1/g'\''`; templib=`echo "$lib" | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib; mv \$templib $lib'
- # the KAI C++ compiler.
- case $host in
- osf3*) old_archive_cmds_CXX='$CC -Bstatic -o $oldlib $oldobjs' ;;
- *) old_archive_cmds_CXX='$CC -o $oldlib $oldobjs' ;;
- esac
- RCC*)
- # Rational C++ 2.4.1
- ld_shlibs_CXX=no
- cxx*)
- case $host in
- osf3*)
- allow_undefined_flag_CXX=' ${wl}-expect_unresolved ${wl}\*'
- archive_cmds_CXX='$CC -shared${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $soname `test -n "$verstring" && func_echo_all "${wl}-set_version $verstring"` -update_registry ${output_objdir}/so_locations -o $lib'
- allow_undefined_flag_CXX=' -expect_unresolved \*'
- archive_cmds_CXX='$CC -shared${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -msym -soname $soname `test -n "$verstring" && func_echo_all "-set_version $verstring"` -update_registry ${output_objdir}/so_locations -o $lib'
- archive_expsym_cmds_CXX='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done~
- echo "-hidden">> $lib.exp~
- $CC -shared$allow_undefined_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -msym -soname $soname ${wl}-input ${wl}$lib.exp `test -n "$verstring" && $ECHO "-set_version $verstring"` -update_registry ${output_objdir}/so_locations -o $lib~
- $RM $lib.exp'
- esac
- # dependencies.
- output_verbose_link_cmd='templist=`$CC -shared $CFLAGS -v conftest.$objext 2>&1 | $GREP "ld" | $GREP -v "ld:"`; templist=`func_echo_all "$templist" | $SED "s/\(^.*ld.*\)\( .*ld.*$\)/\1/"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; func_echo_all "$list"'
- if test "$GXX" = yes && test "$with_gnu_ld" = no; then
- case $host in
- osf3*)
- archive_cmds_CXX='$CC -shared -nostdlib ${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && func_echo_all "${wl}-set_version ${wl}$verstring"` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- archive_cmds_CXX='$CC -shared $pic_flag -nostdlib ${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && func_echo_all "${wl}-set_version ${wl}$verstring"` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- esac
- else
- ld_shlibs_CXX=no
- fi
- esac
- psos*)
- ld_shlibs_CXX=no
- sunos4*)
- CC*)
- # Sun C++ 4.x
- ld_shlibs_CXX=no
- lcc*)
- # Lucid
- ld_shlibs_CXX=no
- ld_shlibs_CXX=no
- esac
- solaris*)
- CC* | sunCC*)
- # Sun C++ 4.2, 5.x and Centerline C++
- archive_expsym_cmds_CXX='echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~echo "local: *; };" >> $lib.exp~
- $CC -G${allow_undefined_flag} ${wl}-M ${wl}$lib.exp -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$RM $lib.exp'
- case $host_os in
- solaris2.[0-5] | solaris2.[0-5].*) ;;
- # The compiler driver will combine and reorder linker options,
- # but understands `-z linker_flag'.
- # Supported since Solaris 2.6 (maybe 2.5.1?)
- whole_archive_flag_spec_CXX='-z allextract$convenience -z defaultextract'
- esac
- # in the archive.
- gcx*)
- archive_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
- # The C++ compiler must be used to create the archive.
- old_archive_cmds_CXX='$CC $LDFLAGS -archive -o $oldlib $oldobjs'
- # GNU C++ compiler with Solaris linker
- no_undefined_flag_CXX=' ${wl}-z ${wl}defs'
- if $CC --version | $GREP -v '^2\.7' > /dev/null; then
- archive_cmds_CXX='$CC -shared $pic_flag -nostdlib $LDFLAGS $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
- $CC -shared $pic_flag -nostdlib ${wl}-M $wl$lib.exp -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$RM $lib.exp'
- else
- # g++ 2.7 appears to require `-G' NOT `-shared' on this
- # platform.
- archive_cmds_CXX='$CC -G -nostdlib $LDFLAGS $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
- $CC -G -nostdlib ${wl}-M $wl$lib.exp -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$RM $lib.exp'
- output_verbose_link_cmd='$CC -G $CFLAGS -v conftest.$objext 2>&1 | $GREP -v "^Configured with:" | $GREP "\-L"'
- fi
- hardcode_libdir_flag_spec_CXX='${wl}-R $wl$libdir'
- case $host_os in
- whole_archive_flag_spec_CXX='${wl}-z ${wl}allextract$convenience ${wl}-z ${wl}defaultextract'
- esac
- fi
- esac
- sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7* | sco3.2v5.0.[024]*)
- no_undefined_flag_CXX='${wl}-z,text'
- runpath_var='LD_RUN_PATH'
- CC*)
- archive_cmds_CXX='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds_CXX='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_cmds_CXX='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds_CXX='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- esac
- sysv5* | sco3.2v5* | sco5v6*)
- # Note: We can NOT use -z defs as we might desire, because we do not
- # link with -lc, and that would cause any symbols used from libc to
- # always be unresolved, which means just about no library would
- # ever link correctly. If we're not using GNU ld we use -z text
- # though, which does catch some bad symbols but isn't as heavy-handed
- # as -z defs.
- allow_undefined_flag_CXX='${wl}-z,nodefs'
- hardcode_libdir_flag_spec_CXX='${wl}-R,$libdir'
- export_dynamic_flag_spec_CXX='${wl}-Bexport'
- CC*)
- old_archive_cmds_CXX='$CC -Tprelink_objects $oldobjs~
- '"$old_archive_cmds_CXX"
- reload_cmds_CXX='$CC -Tprelink_objects $reload_objs~
- '"$reload_cmds_CXX"
- esac
- tandem*)
- NCC*)
- # NonStop-UX NCC 3.20
- ld_shlibs_CXX=no
- ld_shlibs_CXX=no
- esac
- vxworks*)
- ld_shlibs_CXX=no
- ld_shlibs_CXX=no
- esac
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ld_shlibs_CXX" >&5
-$as_echo "$ld_shlibs_CXX" >&6; }
- test "$ld_shlibs_CXX" = no && can_build_shared=no
- GCC_CXX="$GXX"
- LD_CXX="$LD"
- ## CAVEAT EMPTOR:
- ## There is no encapsulation within the following macros, do not change
- ## the running order or otherwise move them around unless you know exactly
- ## what you are doing...
- # Dependencies to place before and after the object being linked:
-predep_objects_CXX=
-postdep_objects_CXX=
-predeps_CXX=
-postdeps_CXX=
-compiler_lib_search_path_CXX=
-cat > conftest.$ac_ext <<_LT_EOF
-class Foo
-public:
- Foo (void) { a = 0; }
-private:
- int a;
-_LT_EOF
-_lt_libdeps_save_CFLAGS=$CFLAGS
-case "$CC $CFLAGS " in #(
-*\ -flto*\ *) CFLAGS="$CFLAGS -fno-lto" ;;
-*\ -fwhopr*\ *) CFLAGS="$CFLAGS -fno-whopr" ;;
-*\ -fuse-linker-plugin*\ *) CFLAGS="$CFLAGS -fno-use-linker-plugin" ;;
-esac
-if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$ac_compile\""; } >&5
- (eval $ac_compile) 2>&5
- ac_status=$?
- $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
- test $ac_status = 0; }; then
- # Parse the compiler output and extract the necessary
- # objects, libraries and library flags.
- # Sentinel used to keep track of whether or not we are before
- # the conftest object file.
- pre_test_object_deps_done=no
- for p in `eval "$output_verbose_link_cmd"`; do
- case ${prev}${p} in
- -L* | -R* | -l*)
- # Some compilers place space between "-{L,R}" and the path.
- # Remove the space.
- if test $p = "-L" ||
- test $p = "-R"; then
- prev=$p
- continue
- fi
- # Expand the sysroot to ease extracting the directories later.
- if test -z "$prev"; then
- case $p in
- -L*) func_stripname_cnf '-L' '' "$p"; prev=-L; p=$func_stripname_result ;;
- -R*) func_stripname_cnf '-R' '' "$p"; prev=-R; p=$func_stripname_result ;;
- -l*) func_stripname_cnf '-l' '' "$p"; prev=-l; p=$func_stripname_result ;;
- esac
- fi
- case $p in
- =*) func_stripname_cnf '=' '' "$p"; p=$lt_sysroot$func_stripname_result ;;
- esac
- if test "$pre_test_object_deps_done" = no; then
- case ${prev} in
- -L | -R)
- # Internal compiler library paths should come after those
- # provided the user. The postdeps already come after the
- # user supplied libs so there is no need to process them.
- if test -z "$compiler_lib_search_path_CXX"; then
- compiler_lib_search_path_CXX="${prev}${p}"
- else
- compiler_lib_search_path_CXX="${compiler_lib_search_path_CXX} ${prev}${p}"
- fi
- # The "-l" case would never come before the object being
- # linked, so don't bother handling this case.
- esac
- else
- if test -z "$postdeps_CXX"; then
- postdeps_CXX="${prev}${p}"
- else
- postdeps_CXX="${postdeps_CXX} ${prev}${p}"
- fi
- fi
- prev=
- *.lto.$objext) ;; # Ignore GCC LTO objects
- *.$objext)
- # This assumes that the test object file only shows up
- # once in the compiler output.
- if test "$p" = "conftest.$objext"; then
- pre_test_object_deps_done=yes
- continue
- fi
- if test -z "$predep_objects_CXX"; then
- predep_objects_CXX="$p"
- else
- predep_objects_CXX="$predep_objects_CXX $p"
- fi
- else
- if test -z "$postdep_objects_CXX"; then
- postdep_objects_CXX="$p"
- else
- postdep_objects_CXX="$postdep_objects_CXX $p"
- fi
- fi
- *) ;; # Ignore the rest.
- esac
- done
- # Clean up.
- rm -f a.out a.exe
-else
- echo "libtool.m4: error: problem compiling CXX test program"
-fi
-$RM -f confest.$objext
-CFLAGS=$_lt_libdeps_save_CFLAGS
-# PORTME: override above test on systems where it is broken
-case $host_os in
-interix[3-9]*)
- # Interix 3.5 installs completely hosed .la files for C++, so rather than
- # hack all around it, let's just trust "g++" to DTRT.
- postdeps_CXX=
-linux*)
- *Sun\ C*)
- # Sun C++ 5.9
- # The more standards-conforming stlport4 library is
- # incompatible with the Cstd library. Avoid specifying
- # it if it's in CXXFLAGS. Ignore libCrun as
- # -library=stlport4 depends on it.
- case " $CXX $CXXFLAGS " in
- *" -library=stlport4 "*)
- solaris_use_stlport4=yes
- esac
- if test "$solaris_use_stlport4" != yes; then
- postdeps_CXX='-library=Cstd -library=Crun'
- fi
- esac
-solaris*)
- CC* | sunCC*)
- esac
- # Adding this requires a known-good setup of shared libraries for
- # Sun compiler versions before 5.6, else PIC objects from an old
- # archive will be linked into the output, leading to subtle bugs.
- fi
- esac
-esac
-case " $postdeps_CXX " in
-*" -lc "*) archive_cmds_need_lc_CXX=no ;;
-esac
- compiler_lib_search_dirs_CXX=
-if test -n "${compiler_lib_search_path_CXX}"; then
- compiler_lib_search_dirs_CXX=`echo " ${compiler_lib_search_path_CXX}" | ${SED} -e 's! -L! !g' -e 's!^ !!'`
-fi
- lt_prog_compiler_wl_CXX=
-lt_prog_compiler_pic_CXX=
-lt_prog_compiler_static_CXX=
- # C++ specific cases for pic, static, wl, etc.
- lt_prog_compiler_wl_CXX='-Wl,'
- lt_prog_compiler_static_CXX='-static'
- case $host_os in
- aix*)
- # All AIX code is PIC.
- # AIX 5 now supports IA64 processor
- lt_prog_compiler_static_CXX='-Bstatic'
- fi
- amigaos*)
- case $host_cpu in
- powerpc)
- # see comment about AmigaOS4 .so support
- lt_prog_compiler_pic_CXX='-fPIC'
- m68k)
- # FIXME: we need at least 68020 code to build shared libraries, but
- # adding the `-m68020' flag to GCC prevents building anything better,
- # like `-m68040'.
- lt_prog_compiler_pic_CXX='-m68020 -resident32 -malways-restore-a4'
- esac
- beos* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
- # PIC is the default for these OSes.
- mingw* | cygwin* | os2* | pw32* | cegcc*)
- # This hack is so that the source file can tell whether it is being
- # built for inclusion in a dll (and should export symbols for example).
- # Although the cygwin gcc ignores -fPIC, still need this for old-style
- # (--disable-auto-import) libraries
- lt_prog_compiler_pic_CXX='-DDLL_EXPORT'
- # PIC is the default on this platform
- # Common symbols not allowed in MH_DYLIB files
- lt_prog_compiler_pic_CXX='-fno-common'
- *djgpp*)
- # DJGPP does not support shared libraries at all
- haiku*)
- # PIC is the default for Haiku.
- # The "-static" flag exists, but is broken.
- interix[3-9]*)
- # Interix 3.x gcc -fpic/-fPIC options generate broken code.
- # Instead, we relocate shared libraries at runtime.
- sysv4*MP*)
- if test -d /usr/nec; then
- lt_prog_compiler_pic_CXX=-Kconform_pic
- fi
- hpux*)
- # PIC is the default for 64-bit PA HP-UX, but not for 32-bit
- # PA HP-UX. On IA64 HP-UX, PIC is the default but the pic flag
- # sets the default TLS model and affects inlining.
- case $host_cpu in
- hppa*64*)
- esac
- *qnx* | *nto*)
- # QNX uses GNU C++, but need to define -shared option too, otherwise
- # it will coredump.
- lt_prog_compiler_pic_CXX='-fPIC -shared'
- esac
- else
- case $host_os in
- aix[4-9]*)
- else
- lt_prog_compiler_static_CXX='-bnso -bI:/lib/syscalls.exp'
- fi
- chorus*)
- cxch68*)
- # _LT_TAGVAR(lt_prog_compiler_static, CXX)="--no_auto_instantiation -u __main -u __premain -u _abort -r $COOL_DIR/lib/libOrb.a $MVME_DIR/lib/CC/libC.a $MVME_DIR/lib/classix/libcx.s.a"
- esac
- dgux*)
- ec++*)
- lt_prog_compiler_pic_CXX='-KPIC'
- ghcx*)
- lt_prog_compiler_pic_CXX='-pic'
- esac
- # FreeBSD uses GNU C++
- hpux9* | hpux10* | hpux11*)
- CC*)
- lt_prog_compiler_static_CXX='${wl}-a ${wl}archive'
- if test "$host_cpu" != ia64; then
- lt_prog_compiler_pic_CXX='+Z'
- fi
- aCC*)
- case $host_cpu in
- hppa*64*|ia64*)
- # +Z the default
- esac
- esac
- interix*)
- # This is c89, which is MS Visual C++ (no shared libs)
- # Anyone wants to do a port?
- irix5* | irix6* | nonstopux*)
- CC*)
- lt_prog_compiler_static_CXX='-non_shared'
- # CC pic flag -KPIC is the default.
- esac
- KCC*)
- # KAI C++ Compiler
- lt_prog_compiler_wl_CXX='--backend -Wl,'
- ecpc* )
- # old Intel C++ for x86_64 which still supported -KPIC.
- icpc* )
- # Intel C++, used to be incompatible with GCC.
- # ICC 10 doesn't accept -KPIC any more.
- pgCC* | pgcpp*)
- lt_prog_compiler_pic_CXX='-fpic'
- cxx*)
- # Compaq C++
- # Make sure the PIC flag is empty. It appears that all Alpha
- # Linux and Compaq Tru64 Unix objects are PIC.
- xlc* | xlC* | bgxl[cC]* | mpixl[cC]*)
- # IBM XL 8.0, 9.0 on PPC and BlueGene
- lt_prog_compiler_pic_CXX='-qpic'
- lt_prog_compiler_static_CXX='-qstaticlink'
- *Sun\ C*)
- # Sun C++ 5.9
- lt_prog_compiler_wl_CXX='-Qoption ld '
- esac
- esac
- lynxos*)
- m88k*)
- mvs*)
- cxx*)
- lt_prog_compiler_pic_CXX='-W c,exportall'
- esac
- netbsd* | netbsdelf*-gnu)
- *qnx* | *nto*)
- KCC*)
- RCC*)
- cxx*)
- # Digital/Compaq C++
- esac
- psos*)
- solaris*)
- CC* | sunCC*)
- gcx*)
- lt_prog_compiler_pic_CXX='-PIC'
- esac
- sunos4*)
- CC*)
- # Sun C++ 4.x
- lcc*)
- # Lucid
- esac
- sysv5* | unixware* | sco3.2v5* | sco5v6* | OpenUNIX*)
- CC*)
- esac
- tandem*)
- NCC*)
- esac
- vxworks*)
- lt_prog_compiler_can_build_shared_CXX=no
- esac
- fi
-case $host_os in
- # For platforms which do not support PIC, -DPIC is meaningless:
- *djgpp*)
- lt_prog_compiler_pic_CXX="$lt_prog_compiler_pic_CXX -DPIC"
-esac
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $compiler option to produce PIC" >&5
-$as_echo_n "checking for $compiler option to produce PIC... " >&6; }
-if ${lt_cv_prog_compiler_pic_CXX+:} false; then :
- $as_echo_n "(cached) " >&6
-else
- lt_cv_prog_compiler_pic_CXX=$lt_prog_compiler_pic_CXX
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_pic_CXX" >&5
-$as_echo "$lt_cv_prog_compiler_pic_CXX" >&6; }
-lt_prog_compiler_pic_CXX=$lt_cv_prog_compiler_pic_CXX
-# Check to make sure the PIC flag actually works.
-if test -n "$lt_prog_compiler_pic_CXX"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler PIC flag $lt_prog_compiler_pic_CXX works" >&5
-$as_echo_n "checking if $compiler PIC flag $lt_prog_compiler_pic_CXX works... " >&6; }
-if ${lt_cv_prog_compiler_pic_works_CXX+:} false; then :
-else
- lt_cv_prog_compiler_pic_works_CXX=no
- echo "$lt_simple_compile_test_code" > conftest.$ac_ext
- lt_compiler_flag="$lt_prog_compiler_pic_CXX -DPIC"
- # Insert the option either (1) after the last *FLAGS variable, or
- # (2) before a word containing "conftest.", or (3) at the end.
- # Note that $ac_compile itself does not contain backslashes and begins
- # with a dollar sign (not a hyphen), so the echo should work correctly.
- # The option is referenced via a variable to avoid confusing sed.
- lt_compile=`echo "$ac_compile" | $SED \
- -e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
- -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
- -e 's:$: $lt_compiler_flag:'`
- (eval echo "\"\$as_me:$LINENO: $lt_compile\"" >&5)
- (eval "$lt_compile" 2>conftest.err)
- ac_status=$?
- cat conftest.err >&5
- echo "$as_me:$LINENO: \$? = $ac_status" >&5
- if (exit $ac_status) && test -s "$ac_outfile"; then
- # The compiler can only warn and ignore the option if not recognized
- # So say no if there are warnings other than the usual output.
- $ECHO "$_lt_compiler_boilerplate" | $SED '/^$/d' >conftest.exp
- $SED '/^$/d; /^ *+/d' conftest.err >conftest.er2
- if test ! -s conftest.er2 || diff conftest.exp conftest.er2 >/dev/null; then
- lt_cv_prog_compiler_pic_works_CXX=yes
- fi
- fi
- $RM conftest*
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_pic_works_CXX" >&5
-$as_echo "$lt_cv_prog_compiler_pic_works_CXX" >&6; }
-if test x"$lt_cv_prog_compiler_pic_works_CXX" = xyes; then
- case $lt_prog_compiler_pic_CXX in
- *) lt_prog_compiler_pic_CXX=" $lt_prog_compiler_pic_CXX" ;;
- esac
-else
-fi
-fi
-# Check to make sure the static flag actually works.
-wl=$lt_prog_compiler_wl_CXX eval lt_tmp_static_flag=\"$lt_prog_compiler_static_CXX\"
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler static flag $lt_tmp_static_flag works" >&5
-$as_echo_n "checking if $compiler static flag $lt_tmp_static_flag works... " >&6; }
-if ${lt_cv_prog_compiler_static_works_CXX+:} false; then :
-else
- lt_cv_prog_compiler_static_works_CXX=no
- save_LDFLAGS="$LDFLAGS"
- LDFLAGS="$LDFLAGS $lt_tmp_static_flag"
- echo "$lt_simple_link_test_code" > conftest.$ac_ext
- if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
- # The linker can only warn and ignore the option if not recognized
- # Append any errors to the config.log.
- cat conftest.err 1>&5
- $ECHO "$_lt_linker_boilerplate" | $SED '/^$/d' > conftest.exp
- if diff conftest.exp conftest.er2 >/dev/null; then
- lt_cv_prog_compiler_static_works_CXX=yes
- fi
- else
- fi
- fi
- $RM -r conftest*
- LDFLAGS="$save_LDFLAGS"
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_static_works_CXX" >&5
-$as_echo "$lt_cv_prog_compiler_static_works_CXX" >&6; }
-if test x"$lt_cv_prog_compiler_static_works_CXX" = xyes; then
-else
-fi
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking if $compiler supports -c -o file.$ac_objext" >&5
-$as_echo_n "checking if $compiler supports -c -o file.$ac_objext... " >&6; }
-if ${lt_cv_prog_compiler_c_o_CXX+:} false; then :
-else
- lt_cv_prog_compiler_c_o_CXX=no
- $RM -r conftest 2>/dev/null
- mkdir conftest
- cd conftest
- mkdir out
- lt_compiler_flag="-o out/conftest2.$ac_objext"
- (eval "$lt_compile" 2>out/conftest.err)
- ac_status=$?
- cat out/conftest.err >&5
- if (exit $ac_status) && test -s out/conftest2.$ac_objext
- then
- $ECHO "$_lt_compiler_boilerplate" | $SED '/^$/d' > out/conftest.exp
- $SED '/^$/d; /^ *+/d' out/conftest.err >out/conftest.er2
- if test ! -s out/conftest.er2 || diff out/conftest.exp out/conftest.er2 >/dev/null; then
- lt_cv_prog_compiler_c_o_CXX=yes
- fi
- fi
- chmod u+w . 2>&5
- $RM conftest*
- # SGI C++ compiler will create directory out/ii_files/ for
- # template instantiation
- test -d out/ii_files && $RM out/ii_files/* && rmdir out/ii_files
- $RM out/* && rmdir out
- cd ..
- $RM -r conftest
- $RM conftest*
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_prog_compiler_c_o_CXX" >&5
-$as_echo "$lt_cv_prog_compiler_c_o_CXX" >&6; }
-else
- mkdir conftest
- cd conftest
- mkdir out
- ac_status=$?
- then
- fi
- fi
- chmod u+w . 2>&5
- $RM conftest*
- cd ..
- $RM -r conftest
- $RM conftest*
-fi
-hard_links="nottested"
-if test "$lt_cv_prog_compiler_c_o_CXX" = no && test "$need_locks" != no; then
- # do not overwrite the value of need_locks provided by the user
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking if we can lock with hard links" >&5
-$as_echo_n "checking if we can lock with hard links... " >&6; }
- hard_links=yes
- $RM conftest*
- ln conftest.a conftest.b 2>/dev/null && hard_links=no
- touch conftest.a
- ln conftest.a conftest.b 2>&5 || hard_links=no
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $hard_links" >&5
-$as_echo "$hard_links" >&6; }
- if test "$hard_links" = no; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
-$as_echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
- need_locks=warn
- fi
-else
- need_locks=no
-fi
- export_symbols_cmds_CXX='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
- exclude_expsyms_CXX='_GLOBAL_OFFSET_TABLE_|_GLOBAL__F[ID]_.*'
- case $host_os in
- aix[4-9]*)
- # If we're using GNU nm, then we don't want the "-C" option.
- # -C means demangle to AIX nm, but means don't demangle with GNU nm
- # Also, AIX nm treats weak defined symbols like other global defined
- # symbols, whereas GNU nm marks them as "W".
- if $NM -V 2>&1 | $GREP 'GNU' > /dev/null; then
- export_symbols_cmds_CXX='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$ 2 == "T") || (\$ 2 == "D") || (\$ 2 == "B") || (\$ 2 == "W")) && (substr(\$ 3,1,1) != ".")) { print \$ 3 } }'\'' | sort -u > $export_symbols'
- else
- export_symbols_cmds_CXX='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$ 2 == "T") || (\$ 2 == "D") || (\$ 2 == "B")) && (substr(\$ 3,1,1) != ".")) { print \$ 3 } }'\'' | sort -u > $export_symbols'
- fi
- pw32*)
- export_symbols_cmds_CXX="$ltdll_cmds"
- cygwin* | mingw* | cegcc*)
- cl*)
- exclude_expsyms_CXX='_NULL_IMPORT_DESCRIPTOR|_IMPORT_DESCRIPTOR_.*'
- export_symbols_cmds_CXX='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS][ ]/s/.*[ ]\([^ ]*\)/\1 DATA/;s/^.*[ ]__nm__\([^ ]*\)[ ][^ ]*/\1 DATA/;/^I[ ]/d;/^[AITW][ ]/s/.* //'\'' | sort | uniq > $export_symbols'
- exclude_expsyms_CXX='[_]+GLOBAL_OFFSET_TABLE_|[_]+GLOBAL__[FID]_.*|[_]+head_[A-Za-z0-9_]+_dll|[A-Za-z0-9_]+_dll_iname'
- esac
- linux* | k*bsd*-gnu | gnu*)
- link_all_deplibs_CXX=no
- esac
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ld_shlibs_CXX" >&5
-test "$ld_shlibs_CXX" = no && can_build_shared=no
-with_gnu_ld_CXX=$with_gnu_ld
-# Do we need to explicitly link libc?
-case "x$archive_cmds_need_lc_CXX" in
-x|xyes)
- # Assume -lc should be added
- if test "$enable_shared" = yes && test "$GCC" = yes; then
- case $archive_cmds_CXX in
- # FIXME: we may have to deal with multi-command sequences.
- '$CC '*)
- # Test whether the compiler implicitly links with -lc since on some
- # systems, -lgcc has to come before -lc. If gcc already passes -lc
- # to ld, don't add -lc before -lgcc.
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether -lc should be explicitly linked in" >&5
-$as_echo_n "checking whether -lc should be explicitly linked in... " >&6; }
-if ${lt_cv_archive_cmds_need_lc_CXX+:} false; then :
-else
- $RM conftest*
- if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$ac_compile\""; } >&5
- ac_status=$?
- test $ac_status = 0; } 2>conftest.err; then
- soname=conftest
- lib=conftest
- libobjs=conftest.$ac_objext
- deplibs=
- wl=$lt_prog_compiler_wl_CXX
- pic_flag=$lt_prog_compiler_pic_CXX
- compiler_flags=-v
- linker_flags=-v
- verstring=
- output_objdir=.
- libname=conftest
- lt_save_allow_undefined_flag=$allow_undefined_flag_CXX
- if { { eval echo "\"\$as_me\":${as_lineno-$LINENO}: \"$archive_cmds_CXX 2\>\&1 \| $GREP \" -lc \" \>/dev/null 2\>\&1\""; } >&5
- (eval $archive_cmds_CXX 2\>\&1 \| $GREP \" -lc \" \>/dev/null 2\>\&1) 2>&5
- ac_status=$?
- then
- lt_cv_archive_cmds_need_lc_CXX=no
- else
- lt_cv_archive_cmds_need_lc_CXX=yes
- fi
- allow_undefined_flag_CXX=$lt_save_allow_undefined_flag
- else
- fi
- $RM conftest*
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $lt_cv_archive_cmds_need_lc_CXX" >&5
-$as_echo "$lt_cv_archive_cmds_need_lc_CXX" >&6; }
- archive_cmds_need_lc_CXX=$lt_cv_archive_cmds_need_lc_CXX
- esac
- fi
-esac
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking dynamic linker characteristics" >&5
-$as_echo_n "checking dynamic linker characteristics... " >&6; }
-library_names_spec=
-libname_spec='lib$name'
-soname_spec=
-shrext_cmds=".so"
-postinstall_cmds=
-postuninstall_cmds=
-finish_cmds=
-finish_eval=
-shlibpath_var=
-shlibpath_overrides_runpath=unknown
-version_type=none
-dynamic_linker="$host_os ld.so"
-sys_lib_dlsearch_path_spec="/lib /usr/lib"
-need_lib_prefix=unknown
-hardcode_into_libs=no
-# when you set need_version to no, make sure it does not cause -set_version
-# flags to be left without arguments
-need_version=unknown
-case $host_os in
-aix3*)
- version_type=linux # correct to gnu/linux during the next big refactor
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
- shlibpath_var=LIBPATH
- # AIX 3 has no versioning support, so we append a major version to the name.
- soname_spec='${libname}${release}${shared_ext}$major'
-aix[4-9]*)
- need_lib_prefix=no
- need_version=no
- hardcode_into_libs=yes
- # AIX 5 supports IA64
- library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
- shlibpath_var=LD_LIBRARY_PATH
- else
- # With GCC up to 2.95.x, collect2 would create an import file
- # for dependence libraries. The import file would start with
- # the line `#! .'. This would cause the generated library to
- # depend on `.', always an invalid library. This was fixed in
- # development snapshots of GCC prior to 3.0.
- case $host_os in
- aix4 | aix4.[01] | aix4.[01].*)
- if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
- echo ' yes '
- echo '#endif'; } | ${CC} -E - | $GREP yes > /dev/null; then
- else
- can_build_shared=no
- fi
- esac
- # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
- # soname into executable. Probably we can add versioning support to
- # collect2, so additional links can be useful in future.
- # If using run time linking (on AIX 4.2 or later) use lib<name>.so
- # instead of lib<name>.a to let people know that these are not
- # typical AIX shared libraries.
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
- else
- # We preserve .a as extension for shared libraries through AIX4.2
- # and later when we are not doing run time linking.
- library_names_spec='${libname}${release}.a $libname.a'
- fi
- fi
-amigaos*)
- case $host_cpu in
- powerpc)
- # Since July 2007 AmigaOS4 officially supports .so libraries.
- # When compiling the executable, add -use-dynld -Lsobjs: to the compileline.
- m68k)
- library_names_spec='$libname.ixlibrary $libname.a'
- # Create ${libname}_ixlibrary.a entries in /sys/libs.
- finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`func_echo_all "$lib" | $SED '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $RM /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
- esac
-beos*)
- library_names_spec='${libname}${shared_ext}'
- dynamic_linker="$host_os ld.so"
- shlibpath_var=LIBRARY_PATH
-bsdi[45]*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
- sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
- sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
- # the default ld.so.conf also contains /usr/contrib/lib and
- # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
- # libtool to hard-code these into programs
-cygwin* | mingw* | pw32* | cegcc*)
- version_type=windows
- need_version=no
- case $GCC,$cc_basename in
- yes,*)
- # gcc
- library_names_spec='$libname.dll.a'
- # DLL is installed to $(libdir)/../bin by postinstall_cmds
- postinstall_cmds='base_file=`basename \${file}`~
- dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i; echo \$dlname'\''`~
- dldir=$destdir/`dirname \$dlpath`~
- test -d \$dldir || mkdir -p \$dldir~
- $install_prog $dir/$dlname \$dldir/$dlname~
- chmod a+x \$dldir/$dlname~
- if test -n '\''$stripme'\'' && test -n '\''$striplib'\''; then
- eval '\''$striplib \$dldir/$dlname'\'' || exit \$?;
- fi'
- postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
- dlpath=$dir/\$dldll~
- $RM \$dlpath'
- shlibpath_overrides_runpath=yes
- case $host_os in
- cygwin*)
- # Cygwin DLLs use 'cyg' prefix rather than 'lib'
- soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- mingw* | cegcc*)
- # MinGW DLLs use traditional 'lib' prefix
- soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- pw32*)
- # pw32 DLLs use 'pw' prefix rather than 'lib'
- library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- esac
- dynamic_linker='Win32 ld.exe'
- *,cl*)
- # Native MSVC
- libname_spec='$name'
- library_names_spec='${libname}.dll.lib'
- case $build_os in
- mingw*)
- lt_save_ifs=$IFS
- IFS=';'
- for lt_path in $LIB
- do
- IFS=$lt_save_ifs
- # Let DOS variable expansion print the short 8.3 style file name.
- lt_path=`cd "$lt_path" 2>/dev/null && cmd //C "for %i in (".") do @echo %~si"`
- sys_lib_search_path_spec="$sys_lib_search_path_spec $lt_path"
- done
- IFS=$lt_save_ifs
- # Convert to MSYS style.
- sys_lib_search_path_spec=`$ECHO "$sys_lib_search_path_spec" | sed -e 's|\\\\|/|g' -e 's| \\([a-zA-Z]\\):| /\\1|g' -e 's|^ ||'`
- cygwin*)
- # Convert to unix form, then to dos form, then back to unix form
- # but this time dos style (no spaces!) so that the unix form looks
- # like /cygdrive/c/PROGRA~1:/cygdr...
- sys_lib_search_path_spec=`cygpath --path --unix "$LIB"`
- sys_lib_search_path_spec=`cygpath --path --dos "$sys_lib_search_path_spec" 2>/dev/null`
- sys_lib_search_path_spec=`cygpath --path --unix "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
- sys_lib_search_path_spec="$LIB"
- if $ECHO "$sys_lib_search_path_spec" | $GREP ';[c-zC-Z]:/' >/dev/null; then
- # It is most probably a Windows format PATH.
- sys_lib_search_path_spec=`$ECHO "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
- else
- sys_lib_search_path_spec=`$ECHO "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
- fi
- # FIXME: find the short name or the path components, as spaces are
- # common. (e.g. "Program Files" -> "PROGRA~1")
- esac
- $install_prog $dir/$dlname \$dldir/$dlname'
- $RM \$dlpath'
- dynamic_linker='Win32 link.exe'
- # Assume MSVC wrapper
- library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
- esac
- # FIXME: first we should search . and the directory the executable is in
- shlibpath_var=PATH
-darwin* | rhapsody*)
- dynamic_linker="$host_os dyld"
- version_type=darwin
- need_version=no
- library_names_spec='${libname}${release}${major}$shared_ext ${libname}$shared_ext'
- soname_spec='${libname}${release}${major}$shared_ext'
- shlibpath_var=DYLD_LIBRARY_PATH
- shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
- sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
-dgux*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
-freebsd* | dragonfly*)
- # DragonFly does not have aout. When/if they implement a new
- # versioning mechanism, adjust this.
- if test -x /usr/bin/objformat; then
- objformat=`/usr/bin/objformat`
- else
- case $host_os in
- freebsd[23].*) objformat=aout ;;
- *) objformat=elf ;;
- esac
- fi
- version_type=freebsd-$objformat
- case $version_type in
- freebsd-elf*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
- need_version=no
- freebsd-*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
- need_version=yes
- esac
- case $host_os in
- freebsd2.*)
- freebsd3.[01]* | freebsdelf3.[01]*)
- freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
- freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
- shlibpath_overrides_runpath=no
- *) # from 4.6 on, and DragonFly
- esac
-gnu*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
-haiku*)
- need_version=no
- dynamic_linker="$host_os runtime_loader"
- sys_lib_dlsearch_path_spec='/boot/home/config/lib /boot/common/lib /boot/system/lib'
-hpux9* | hpux10* | hpux11*)
- # Give a soname corresponding to the major version so that dld.sl refuses to
- # link against other versions.
- version_type=sunos
- need_version=no
- case $host_cpu in
- ia64*)
- shrext_cmds='.so'
- dynamic_linker="$host_os dld.so"
- shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
- if test "X$HPUX_IA64_MODE" = X32; then
- sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
- else
- sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
- fi
- sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
- hppa*64*)
- shrext_cmds='.sl'
- dynamic_linker="$host_os dld.sl"
- shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
- sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
- shrext_cmds='.sl'
- shlibpath_var=SHLIB_PATH
- shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
- esac
- # HP-UX runs *really* slowly unless shared libraries are mode 555, ...
- postinstall_cmds='chmod 555 $lib'
- # or fails outright, so override atomically:
- install_override_mode=555
-interix[3-9]*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
- dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
-irix5* | irix6* | nonstopux*)
- case $host_os in
- nonstopux*) version_type=nonstopux ;;
- if test "$lt_cv_prog_gnu_ld" = yes; then
- else
- version_type=irix
- fi ;;
- esac
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
- case $host_os in
- irix5* | nonstopux*)
- libsuff= shlibsuff=
- case $LD in # libtool.m4 will add one of these switches to LD
- *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
- libsuff= shlibsuff= libmagic=32-bit;;
- *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
- libsuff=32 shlibsuff=N32 libmagic=N32;;
- *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
- libsuff=64 shlibsuff=64 libmagic=64-bit;;
- *) libsuff= shlibsuff= libmagic=never-match;;
- esac
- esac
- shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
- sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
- sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
-# No shared lib support for Linux oldld, aout, or coff.
-linux*oldld* | linux*aout* | linux*coff*)
- dynamic_linker=no
-# This must be glibc/ELF.
-linux* | k*bsd*-gnu | kopensolaris*-gnu)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
- # Some binutils ld are patched to set DT_RUNPATH
- if ${lt_cv_shlibpath_overrides_runpath+:} false; then :
-else
- lt_cv_shlibpath_overrides_runpath=no
- save_LDFLAGS=$LDFLAGS
- save_libdir=$libdir
- eval "libdir=/foo; wl=\"$lt_prog_compiler_wl_CXX\"; \
- LDFLAGS=\"\$LDFLAGS $hardcode_libdir_flag_spec_CXX\""
- cat confdefs.h - <<_ACEOF >conftest.$ac_ext
-/* end confdefs.h. */
-int
-main ()
- return 0;
-_ACEOF
- if ($OBJDUMP -p conftest$ac_exeext) 2>/dev/null | grep "RUNPATH.*$libdir" >/dev/null; then :
- lt_cv_shlibpath_overrides_runpath=yes
-fi
-fi
- LDFLAGS=$save_LDFLAGS
- libdir=$save_libdir
-fi
- shlibpath_overrides_runpath=$lt_cv_shlibpath_overrides_runpath
- # This implies no fast_install, which is unacceptable.
- # Some rework will be needed to allow for fast_install
- # before this can be enabled.
- # Append ld.so.conf contents to the search path
- if test -f /etc/ld.so.conf; then
- lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s 2>/dev/null", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;/^[ ]*hwcap[ ]/d;s/[:, ]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;s/"//g;/^$/d' | tr '\n' ' '`
- sys_lib_dlsearch_path_spec="/lib /usr/lib $lt_ld_extra"
- fi
- # We used to test for /lib/ld.so.1 and disable shared libraries on
- # powerpc, because MkLinux only supported shared libraries with the
- # GNU dynamic linker. Since this was broken with cross compilers,
- # most powerpc-linux boxes support dynamic linking these days and
- # people can always --disable-shared, the test was removed, and we
- # assume the GNU/Linux dynamic linker is in use.
- dynamic_linker='GNU/Linux ld.so'
-netbsdelf*-gnu)
- need_version=no
- dynamic_linker='NetBSD ld.elf_so'
-netbsd*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
- dynamic_linker='NetBSD (a.out) ld.so'
- else
- fi
-newsos6)
-*nto* | *qnx*)
- version_type=qnx
- need_version=no
- dynamic_linker='ldqnx.so'
-openbsd*)
- sys_lib_dlsearch_path_spec="/usr/lib"
- # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
- case $host_os in
- openbsd3.3 | openbsd3.3.*) need_version=yes ;;
- *) need_version=no ;;
- esac
- if test -z "`echo __ELF__ | $CC -E - | $GREP __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- case $host_os in
- openbsd2.[89] | openbsd2.[89].*)
- esac
- else
- fi
-os2*)
- library_names_spec='$libname${shared_ext} $libname.a'
- dynamic_linker='OS/2 ld.exe'
-osf3* | osf4* | osf5*)
- version_type=osf
- need_version=no
- sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
- sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
-rdos*)
- dynamic_linker=no
-solaris*)
- need_version=no
- # ldd complains unless libraries are executable
- postinstall_cmds='chmod +x $lib'
-sunos4*)
- finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
- if test "$with_gnu_ld" = yes; then
- fi
- need_version=yes
-sysv4 | sysv4.3*)
- case $host_vendor in
- sni)
- siemens)
- motorola)
- need_version=no
- sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
- esac
-sysv4*MP*)
- if test -d /usr/nec ;then
- library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
- soname_spec='$libname${shared_ext}.$major'
- fi
-sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
- version_type=freebsd-elf
- need_version=no
- sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
- else
- sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
- case $host_os in
- sco3.2v5*)
- sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
- esac
- fi
- sys_lib_dlsearch_path_spec='/usr/lib'
-tpf*)
- # TPF is a cross-target only. Preferred cross-host = GNU/Linux.
- need_version=no
-uts4*)
- dynamic_linker=no
-esac
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $dynamic_linker" >&5
-$as_echo "$dynamic_linker" >&6; }
-test "$dynamic_linker" = no && can_build_shared=no
-variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
-if test "$GCC" = yes; then
- variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
-fi
-if test "${lt_cv_sys_lib_search_path_spec+set}" = set; then
- sys_lib_search_path_spec="$lt_cv_sys_lib_search_path_spec"
-fi
-if test "${lt_cv_sys_lib_dlsearch_path_spec+set}" = set; then
- sys_lib_dlsearch_path_spec="$lt_cv_sys_lib_dlsearch_path_spec"
-fi
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking how to hardcode library paths into programs" >&5
-$as_echo_n "checking how to hardcode library paths into programs... " >&6; }
-hardcode_action_CXX=
-if test -n "$hardcode_libdir_flag_spec_CXX" ||
- test -n "$runpath_var_CXX" ||
- test "X$hardcode_automatic_CXX" = "Xyes" ; then
- # We can hardcode non-existent directories.
- if test "$hardcode_direct_CXX" != no &&
- # If the only mechanism to avoid hardcoding is shlibpath_var, we
- # have to relink, otherwise we might link with an installed library
- # when we should be linking with a yet-to-be-installed one
- ## test "$_LT_TAGVAR(hardcode_shlibpath_var, CXX)" != no &&
- test "$hardcode_minus_L_CXX" != no; then
- # Linking always hardcodes the temporary library directory.
- hardcode_action_CXX=relink
- else
- # We can link without hardcoding, and we can hardcode nonexisting dirs.
- hardcode_action_CXX=immediate
- fi
-else
- # We cannot hardcode anything, or else we can only hardcode existing
- # directories.
- hardcode_action_CXX=unsupported
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $hardcode_action_CXX" >&5
-$as_echo "$hardcode_action_CXX" >&6; }
-if test "$hardcode_action_CXX" = relink ||
- test "$inherit_rpath_CXX" = yes; then
- # Fast installation is not supported
- enable_fast_install=no
-elif test "$shlibpath_overrides_runpath" = yes ||
- test "$enable_shared" = no; then
- # Fast installation is not necessary
- enable_fast_install=needless
-fi
- fi # test -n "$compiler"
- CC=$lt_save_CC
- CFLAGS=$lt_save_CFLAGS
- LDCXX=$LD
- LD=$lt_save_LD
- GCC=$lt_save_GCC
- with_gnu_ld=$lt_save_with_gnu_ld
- lt_cv_path_LDCXX=$lt_cv_path_LD
- lt_cv_path_LD=$lt_save_path_LD
- lt_cv_prog_gnu_ldcxx=$lt_cv_prog_gnu_ld
- lt_cv_prog_gnu_ld=$lt_save_with_gnu_ld
-fi # test "$_lt_caught_CXX_error" != yes
-ac_ext=c
-ac_cpp='$CPP $CPPFLAGS'
-ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_c_compiler_gnu
-# Checks for programs.
-ac_ext=cpp
-ac_cpp='$CXXCPP $CPPFLAGS'
-ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
-if test -z "$CXX"; then
- if test -n "$CCC"; then
- CXX=$CCC
- else
- if test -n "$ac_tool_prefix"; then
- for ac_prog in g++ c++ gpp aCC CC cxx cc++ cl.exe FCC KCC RCC xlC_r xlC
- do
- # Extract the first word of "$ac_tool_prefix$ac_prog", so it can be a program name with args.
-set dummy $ac_tool_prefix$ac_prog; ac_word=$2
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $ac_word" >&5
-$as_echo_n "checking for $ac_word... " >&6; }
-if ${ac_cv_prog_CXX+:} false; then :
-else
- if test -n "$CXX"; then
- ac_cv_prog_CXX="$CXX" # Let the user override the test.
-else
-as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-for as_dir in $PATH
-do
- IFS=$as_save_IFS
- test -z "$as_dir" && as_dir=.
- for ac_exec_ext in '' $ac_executable_extensions; do
- if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then
- ac_cv_prog_CXX="$ac_tool_prefix$ac_prog"
- $as_echo "$as_me:${as_lineno-$LINENO}: found $as_dir/$ac_word$ac_exec_ext" >&5
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-CXX=$ac_cv_prog_CXX
-if test -n "$CXX"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $CXX" >&5
-$as_echo "$CXX" >&6; }
-else
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
-$as_echo "no" >&6; }
-fi
- test -n "$CXX" && break
- done
-fi
- ac_ct_CXX=$CXX
-do
- # Extract the first word of "$ac_prog", so it can be a program name with args.
-set dummy $ac_prog; ac_word=$2
-if ${ac_cv_prog_ac_ct_CXX+:} false; then :
-else
- if test -n "$ac_ct_CXX"; then
- ac_cv_prog_ac_ct_CXX="$ac_ct_CXX" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_CXX="$ac_prog"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-ac_ct_CXX=$ac_cv_prog_ac_ct_CXX
-if test -n "$ac_ct_CXX"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_CXX" >&5
-$as_echo "$ac_ct_CXX" >&6; }
-else
-fi
- test -n "$ac_ct_CXX" && break
-done
- if test "x$ac_ct_CXX" = x; then
- CXX="g++"
- else
- case $cross_compiling:$ac_tool_warned in
-yes:)
-{ $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: using cross tools not prefixed with host triplet" >&5
-$as_echo "$as_me: WARNING: using cross tools not prefixed with host triplet" >&2;}
-ac_tool_warned=yes ;;
-esac
- CXX=$ac_ct_CXX
- fi
-fi
- fi
-fi
-# Provide some information about the compiler.
-$as_echo "$as_me:${as_lineno-$LINENO}: checking for C++ compiler version" >&5
-set X $ac_compile
-ac_compiler=$2
-for ac_option in --version -v -V -qversion; do
- { { ac_try="$ac_compiler $ac_option >&5"
-case "(($ac_try" in
- *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
- *) ac_try_echo=$ac_try;;
-esac
-eval ac_try_echo="\"\$as_me:${as_lineno-$LINENO}: $ac_try_echo\""
-$as_echo "$ac_try_echo"; } >&5
- (eval "$ac_compiler $ac_option >&5") 2>conftest.err
- ac_status=$?
- if test -s conftest.err; then
- sed '10a\
-... rest of stderr output deleted ...
- 10q' conftest.err >conftest.er1
- cat conftest.er1 >&5
- fi
- rm -f conftest.er1 conftest.err
-done
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are using the GNU C++ compiler" >&5
-$as_echo_n "checking whether we are using the GNU C++ compiler... " >&6; }
-if ${ac_cv_cxx_compiler_gnu+:} false; then :
-else
-int
-main ()
-#ifndef __GNUC__
- choke me
-#endif
- return 0;
-_ACEOF
-if ac_fn_cxx_try_compile "$LINENO"; then :
- ac_compiler_gnu=yes
-else
- ac_compiler_gnu=no
-fi
-rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
-ac_cv_cxx_compiler_gnu=$ac_compiler_gnu
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_cxx_compiler_gnu" >&5
-$as_echo "$ac_cv_cxx_compiler_gnu" >&6; }
-if test $ac_compiler_gnu = yes; then
- GXX=yes
-else
- GXX=
-fi
-ac_test_CXXFLAGS=${CXXFLAGS+set}
-ac_save_CXXFLAGS=$CXXFLAGS
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether $CXX accepts -g" >&5
-$as_echo_n "checking whether $CXX accepts -g... " >&6; }
-if ${ac_cv_prog_cxx_g+:} false; then :
-else
- ac_save_cxx_werror_flag=$ac_cxx_werror_flag
- ac_cxx_werror_flag=yes
- ac_cv_prog_cxx_g=no
- CXXFLAGS="-g"
-int
-main ()
- return 0;
-_ACEOF
- ac_cv_prog_cxx_g=yes
-else
- CXXFLAGS=""
-int
-main ()
- return 0;
-_ACEOF
-else
- ac_cxx_werror_flag=$ac_save_cxx_werror_flag
- CXXFLAGS="-g"
-int
-main ()
- return 0;
-_ACEOF
-fi
-fi
-fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_cxx_g" >&5
-$as_echo "$ac_cv_prog_cxx_g" >&6; }
-if test "$ac_test_CXXFLAGS" = set; then
- CXXFLAGS=$ac_save_CXXFLAGS
-elif test $ac_cv_prog_cxx_g = yes; then
- if test "$GXX" = yes; then
- CXXFLAGS="-g -O2"
- else
- CXXFLAGS="-g"
- fi
-else
- CXXFLAGS="-O2"
- else
- CXXFLAGS=
- fi
-fi
-ac_ext=c
-depcc="$CXX" am_compiler_list=
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking dependency style of $depcc" >&5
-$as_echo_n "checking dependency style of $depcc... " >&6; }
-if ${am_cv_CXX_dependencies_compiler_type+:} false; then :
-else
- if test -z "$AMDEP_TRUE" && test -f "$am_depcomp"; then
- # We make a subdir and do the tests there. Otherwise we can end up
- # making bogus files that we don't know about and never remove. For
- # instance it was reported that on HP-UX the gcc test will end up
- # making a dummy file named `D' -- because `-MD' means `put the output
- # in D'.
- rm -rf conftest.dir
- mkdir conftest.dir
- # Copy depcomp to subdir because otherwise we won't find it if we're
- # using a relative directory.
- cp "$am_depcomp" conftest.dir
- cd conftest.dir
- # We will build objects and dependencies in a subdirectory because
- # it helps to detect inapplicable dependency modes. For instance
- # both Tru64's cc and ICC support -MD to output dependencies as a
- # side effect of compilation, but ICC will put the dependencies in
- # the current directory while Tru64 will put them in the object
- # directory.
- mkdir sub
- am_cv_CXX_dependencies_compiler_type=none
- if test "$am_compiler_list" = ""; then
- am_compiler_list=`sed -n 's/^#*\([a-zA-Z0-9]*\))$/\1/p' < ./depcomp`
- fi
- am__universal=false
- case " $depcc " in #(
- *\ -arch\ *\ -arch\ *) am__universal=true ;;
- esac
- for depmode in $am_compiler_list; do
- # Setup a source with many dependencies, because some compilers
- # like to wrap large dependency lists on column 80 (with \), and
- # we should not choose a depcomp mode which is confused by this.
- # We need to recreate these files for each test, as the compiler may
- # overwrite some of them when testing with obscure command lines.
- # This happens at least with the AIX C compiler.
- : > sub/conftest.c
- for i in 1 2 3 4 5 6; do
- echo '#include "conftst'$i'.h"' >> sub/conftest.c
- # Using `: > sub/conftst$i.h' creates only sub/conftst1.h with
- # Solaris 8's {/usr,}/bin/sh.
- touch sub/conftst$i.h
- done
- echo "${am__include} ${am__quote}sub/conftest.Po${am__quote}" > confmf
- # We check with `-c' and `-o' for the sake of the "dashmstdout"
- # mode. It turns out that the SunPro C++ compiler does not properly
- # handle `-M -o', and we need to detect this. Also, some Intel
- # versions had trouble with output in subdirs
- am__obj=sub/conftest.${OBJEXT-o}
- am__minus_obj="-o $am__obj"
- case $depmode in
- gcc)
- # This depmode causes a compiler race in universal mode.
- test "$am__universal" = false || continue
- nosideeffect)
- # after this tag, mechanisms are not by side-effect, so they'll
- # only be used when explicitly requested
- if test "x$enable_dependency_tracking" = xyes; then
- continue
- else
- break
- fi
- msvc7 | msvc7msys | msvisualcpp | msvcmsys)
- # This compiler won't grok `-c -o', but also, the minuso test has
- # not run yet. These depmodes are late enough in the game, and
- # so weak that their functioning should not be impacted.
- am__obj=conftest.${OBJEXT-o}
- am__minus_obj=
- none) break ;;
- esac
- if depmode=$depmode \
- source=sub/conftest.c object=$am__obj \
- depfile=sub/conftest.Po tmpdepfile=sub/conftest.TPo \
- $SHELL ./depcomp $depcc -c $am__minus_obj sub/conftest.c \
- >/dev/null 2>conftest.err &&
- grep sub/conftst1.h sub/conftest.Po > /dev/null 2>&1 &&
- grep sub/conftst6.h sub/conftest.Po > /dev/null 2>&1 &&
- grep $am__obj sub/conftest.Po > /dev/null 2>&1 &&
- ${MAKE-make} -s -f confmf > /dev/null 2>&1; then
- # icc doesn't choke on unknown options, it will just issue warnings
- # or remarks (even with -Werror). So we grep stderr for any message
- # that says an option was ignored or not supported.
- # When given -MP, icc 7.0 and 7.1 complain thusly:
- # icc: Command line warning: ignoring option '-M'; no argument required
- # The diagnosis changed in icc 8.0:
- # icc: Command line remark: option '-MP' not supported
- if (grep 'ignoring option' conftest.err ||
- grep 'not supported' conftest.err) >/dev/null 2>&1; then :; else
- am_cv_CXX_dependencies_compiler_type=$depmode
- break
- fi
- fi
- done
- cd ..
-else
-fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $am_cv_CXX_dependencies_compiler_type" >&5
-$as_echo "$am_cv_CXX_dependencies_compiler_type" >&6; }
-CXXDEPMODE=depmode=$am_cv_CXX_dependencies_compiler_type
- if
- test "x$enable_dependency_tracking" != xno \
- && test "$am_cv_CXX_dependencies_compiler_type" = gcc3; then
- am__fastdepCXX_TRUE=
- am__fastdepCXX_FALSE='#'
-else
- am__fastdepCXX_TRUE='#'
-fi
-ac_ext=c
-if test -n "$ac_tool_prefix"; then
- # Extract the first word of "${ac_tool_prefix}gcc", so it can be a program name with args.
-set dummy ${ac_tool_prefix}gcc; ac_word=$2
-if ${ac_cv_prog_CC+:} false; then :
-else
- if test -n "$CC"; then
- ac_cv_prog_CC="$CC" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_CC="${ac_tool_prefix}gcc"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-CC=$ac_cv_prog_CC
-if test -n "$CC"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $CC" >&5
-$as_echo "$CC" >&6; }
-else
-fi
-fi
-if test -z "$ac_cv_prog_CC"; then
- ac_ct_CC=$CC
- # Extract the first word of "gcc", so it can be a program name with args.
-set dummy gcc; ac_word=$2
-if ${ac_cv_prog_ac_ct_CC+:} false; then :
-else
- if test -n "$ac_ct_CC"; then
- ac_cv_prog_ac_ct_CC="$ac_ct_CC" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_CC="gcc"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-ac_ct_CC=$ac_cv_prog_ac_ct_CC
-if test -n "$ac_ct_CC"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_CC" >&5
-$as_echo "$ac_ct_CC" >&6; }
-else
-fi
- if test "x$ac_ct_CC" = x; then
- CC=""
- else
-yes:)
-esac
- CC=$ac_ct_CC
- fi
-else
- CC="$ac_cv_prog_CC"
-fi
-if test -z "$CC"; then
- # Extract the first word of "${ac_tool_prefix}cc", so it can be a program name with args.
-set dummy ${ac_tool_prefix}cc; ac_word=$2
-else
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_CC="${ac_tool_prefix}cc"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-CC=$ac_cv_prog_CC
-else
-fi
- fi
-fi
- # Extract the first word of "cc", so it can be a program name with args.
-set dummy cc; ac_word=$2
-else
-else
- ac_prog_rejected=no
-do
- IFS=$as_save_IFS
- if test "$as_dir/$ac_word$ac_exec_ext" = "/usr/ucb/cc"; then
- ac_prog_rejected=yes
- continue
- fi
- ac_cv_prog_CC="cc"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-if test $ac_prog_rejected = yes; then
- # We found a bogon in the path, so make sure we never use it.
- set dummy $ac_cv_prog_CC
- shift
- if test $# != 0; then
- # We chose a different compiler from the bogus one.
- # However, it has the same basename, so the bogon will be chosen
- # first if we set CC to just the basename; use the full file name.
- shift
- ac_cv_prog_CC="$as_dir/$ac_word${1+' '}$@"
- fi
-fi
-fi
-fi
-CC=$ac_cv_prog_CC
-else
-fi
-fi
- for ac_prog in cl.exe
- do
-else
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_CC="$ac_tool_prefix$ac_prog"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-CC=$ac_cv_prog_CC
-else
-fi
- test -n "$CC" && break
- done
-fi
- ac_ct_CC=$CC
-do
-else
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_CC="$ac_prog"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-else
-fi
- test -n "$ac_ct_CC" && break
-done
- CC=""
- else
-yes:)
-esac
- CC=$ac_ct_CC
- fi
-fi
-fi
-test -z "$CC" && { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
-$as_echo "$as_me: error: in \`$ac_pwd':" >&2;}
-as_fn_error $? "no acceptable C compiler found in \$PATH
-See \`config.log' for more details" "$LINENO" 5; }
-$as_echo "$as_me:${as_lineno-$LINENO}: checking for C compiler version" >&5
-set X $ac_compile
-ac_compiler=$2
-esac
- ac_status=$?
- sed '10a\
- fi
-done
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are using the GNU C compiler" >&5
-$as_echo_n "checking whether we are using the GNU C compiler... " >&6; }
-if ${ac_cv_c_compiler_gnu+:} false; then :
-else
-int
-main ()
-#ifndef __GNUC__
- choke me
-#endif
- return 0;
-_ACEOF
-if ac_fn_c_try_compile "$LINENO"; then :
-else
-fi
-ac_cv_c_compiler_gnu=$ac_compiler_gnu
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_c_compiler_gnu" >&5
-$as_echo "$ac_cv_c_compiler_gnu" >&6; }
- GCC=yes
-else
- GCC=
-fi
-ac_test_CFLAGS=${CFLAGS+set}
-ac_save_CFLAGS=$CFLAGS
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether $CC accepts -g" >&5
-$as_echo_n "checking whether $CC accepts -g... " >&6; }
-if ${ac_cv_prog_cc_g+:} false; then :
-else
- ac_save_c_werror_flag=$ac_c_werror_flag
- ac_c_werror_flag=yes
- ac_cv_prog_cc_g=no
- CFLAGS="-g"
-int
-main ()
- return 0;
-_ACEOF
- ac_cv_prog_cc_g=yes
-else
- CFLAGS=""
-int
-main ()
- return 0;
-_ACEOF
-else
- ac_c_werror_flag=$ac_save_c_werror_flag
- CFLAGS="-g"
-int
-main ()
- return 0;
-_ACEOF
-fi
-fi
-fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_cc_g" >&5
-$as_echo "$ac_cv_prog_cc_g" >&6; }
-if test "$ac_test_CFLAGS" = set; then
- CFLAGS=$ac_save_CFLAGS
-elif test $ac_cv_prog_cc_g = yes; then
- if test "$GCC" = yes; then
- CFLAGS="-g -O2"
- else
- CFLAGS="-g"
- fi
-else
- CFLAGS="-O2"
- else
- CFLAGS=
- fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $CC option to accept ISO C89" >&5
-$as_echo_n "checking for $CC option to accept ISO C89... " >&6; }
-if ${ac_cv_prog_cc_c89+:} false; then :
-else
- ac_cv_prog_cc_c89=no
-ac_save_CC=$CC
-cat confdefs.h - <<_ACEOF >conftest.$ac_ext
-#include <stdarg.h>
-#include <stdio.h>
-#include <sys/types.h>
-#include <sys/stat.h>
-/* Most of the following tests are stolen from RCS 5.7's src/conf.sh. */
-struct buf { int x; };
-FILE * (*rcsopen) (struct buf *, struct stat *, int);
-static char *e (p, i)
- char **p;
- int i;
- return p[i];
-static char *f (char * (*g) (char **, int), char **p, ...)
- char *s;
- va_list v;
- va_start (v,p);
- s = g (p, va_arg (v,int));
- va_end (v);
- return s;
-/* OSF 4.0 Compaq cc is some sort of almost-ANSI by default. It has
- function prototypes and stuff, but not '\xHH' hex character constants.
- These don't provoke an error unfortunately, instead are silently treated
- as 'x'. The following induces an error, until -std is added to get
- proper ANSI mode. Curiously '\x00'!='x' always comes out true, for an
- array size at least. It's necessary to write '\x00'==0 to get something
- that's true only with -std. */
-int osf4_cc_array ['\x00' == 0 ? 1 : -1];
-/* IBM C 6 for AIX is almost-ANSI by default, but it replaces macro parameters
- inside strings and character constants. */
-#define FOO(x) 'x'
-int xlc6_cc_array[FOO(a) == 'x' ? 1 : -1];
-int test (int i, double x);
-struct s1 {int (*f) (int a);};
-struct s2 {int (*f) (double a);};
-int pairnames (int, char **, FILE *(*)(struct buf *, struct stat *, int), int, int);
-int argc;
-char **argv;
-int
-main ()
-return f (e, argv, 0) != argv[0] || f (e, argv, 1) != argv[1];
- return 0;
-_ACEOF
-for ac_arg in '' -qlanglvl=extc89 -qlanglvl=ansi -std \
- -Ae "-Aa -D_HPUX_SOURCE" "-Xc -D__EXTENSIONS__"
-do
- CC="$ac_save_CC $ac_arg"
- if ac_fn_c_try_compile "$LINENO"; then :
- ac_cv_prog_cc_c89=$ac_arg
-fi
- test "x$ac_cv_prog_cc_c89" != "xno" && break
-done
-rm -f conftest.$ac_ext
-CC=$ac_save_CC
-fi
-# AC_CACHE_VAL
-case "x$ac_cv_prog_cc_c89" in
- x)
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: none needed" >&5
-$as_echo "none needed" >&6; } ;;
- xno)
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: unsupported" >&5
-$as_echo "unsupported" >&6; } ;;
- CC="$CC $ac_cv_prog_cc_c89"
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_cc_c89" >&5
-$as_echo "$ac_cv_prog_cc_c89" >&6; } ;;
-esac
-if test "x$ac_cv_prog_cc_c89" != xno; then :
-fi
-ac_ext=c
-depcc="$CC" am_compiler_list=
-if ${am_cv_CC_dependencies_compiler_type+:} false; then :
-else
- # in D'.
- cd conftest.dir
- # directory.
- mkdir sub
- am_cv_CC_dependencies_compiler_type=none
- fi
- esac
- done
- case $depmode in
- gcc)
- nosideeffect)
- continue
- else
- break
- fi
- am__minus_obj=
- none) break ;;
- esac
- am_cv_CC_dependencies_compiler_type=$depmode
- break
- fi
- fi
- done
- cd ..
-else
-fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $am_cv_CC_dependencies_compiler_type" >&5
-$as_echo "$am_cv_CC_dependencies_compiler_type" >&6; }
-CCDEPMODE=depmode=$am_cv_CC_dependencies_compiler_type
- if
- && test "$am_cv_CC_dependencies_compiler_type" = gcc3; then
- am__fastdepCC_TRUE=
- am__fastdepCC_FALSE='#'
-else
- am__fastdepCC_TRUE='#'
-fi
-ac_ext=c
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to run the C preprocessor" >&5
-$as_echo_n "checking how to run the C preprocessor... " >&6; }
-# On Suns, sometimes $CPP names a directory.
-if test -n "$CPP" && test -d "$CPP"; then
- CPP=
-fi
-if test -z "$CPP"; then
- if ${ac_cv_prog_CPP+:} false; then :
-else
- # Double quotes because CPP needs to be expanded
- for CPP in "$CC -E" "$CC -E -traditional-cpp" "/lib/cpp"
- do
- ac_preproc_ok=false
-for ac_c_preproc_warn_flag in '' yes
-do
- # Use a header file that comes with gcc, so configuring glibc
- # with a fresh cross-compiler works.
- # Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
- # <limits.h> exists even on freestanding compilers.
- # On the NeXT, cc -E runs the code through the compiler's parser,
- # not just through cpp. "Syntax error" is here to catch this case.
-#ifdef __STDC__
-# include <limits.h>
-#else
-# include <assert.h>
-#endif
- Syntax error
-_ACEOF
-if ac_fn_c_try_cpp "$LINENO"; then :
-else
- # Broken: fails on valid input.
-continue
-fi
-rm -f conftest.err conftest.i conftest.$ac_ext
- # OK, works on sane cases. Now check whether nonexistent headers
- # can be detected and how.
-#include <ac_nonexistent.h>
-_ACEOF
- # Broken: success on invalid input.
-continue
-else
- # Passes both tests.
-ac_preproc_ok=:
-break
-fi
-done
-# Because of `break', _AC_PREPROC_IFELSE's cleaning code was skipped.
-rm -f conftest.i conftest.err conftest.$ac_ext
-if $ac_preproc_ok; then :
- break
-fi
- done
- ac_cv_prog_CPP=$CPP
-fi
- CPP=$ac_cv_prog_CPP
-else
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $CPP" >&5
-$as_echo "$CPP" >&6; }
-ac_preproc_ok=false
-do
-#ifdef __STDC__
-#else
-#endif
- Syntax error
-_ACEOF
-else
-continue
-fi
-_ACEOF
-continue
-else
-ac_preproc_ok=:
-break
-fi
-done
-else
- { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
-as_fn_error $? "C preprocessor \"$CPP\" fails sanity check
-fi
-ac_ext=c
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether ln -s works" >&5
-$as_echo_n "checking whether ln -s works... " >&6; }
-LN_S=$as_ln_s
-if test "$LN_S" = "ln -s"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
-$as_echo "yes" >&6; }
-else
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: no, using $LN_S" >&5
-$as_echo "no, using $LN_S" >&6; }
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether ${MAKE-make} sets \$(MAKE)" >&5
-$as_echo_n "checking whether ${MAKE-make} sets \$(MAKE)... " >&6; }
-set x ${MAKE-make}
-ac_make=`$as_echo "$2" | sed 's/+/p/g; s/[^a-zA-Z0-9_]/_/g'`
-if eval \${ac_cv_prog_make_${ac_make}_set+:} false; then :
-else
- cat >conftest.make <<\_ACEOF
-SHELL = /bin/sh
-all:
- @echo '@@@%%%=$(MAKE)=@@@%%%'
-_ACEOF
-# GNU make sometimes prints "make[1]: Entering ...", which would confuse us.
-case `${MAKE-make} -f conftest.make 2>/dev/null` in
- eval ac_cv_prog_make_${ac_make}_set=yes;;
- eval ac_cv_prog_make_${ac_make}_set=no;;
-esac
-rm -f conftest.make
-fi
-if eval test \$ac_cv_prog_make_${ac_make}_set = yes; then
- SET_MAKE=
-else
- SET_MAKE="MAKE=${MAKE-make}"
-fi
- # Extract the first word of "${ac_tool_prefix}ranlib", so it can be a program name with args.
-set dummy ${ac_tool_prefix}ranlib; ac_word=$2
-if ${ac_cv_prog_RANLIB+:} false; then :
-else
- if test -n "$RANLIB"; then
- ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_RANLIB="${ac_tool_prefix}ranlib"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-RANLIB=$ac_cv_prog_RANLIB
-if test -n "$RANLIB"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $RANLIB" >&5
-$as_echo "$RANLIB" >&6; }
-else
-fi
-fi
-if test -z "$ac_cv_prog_RANLIB"; then
- ac_ct_RANLIB=$RANLIB
- # Extract the first word of "ranlib", so it can be a program name with args.
-set dummy ranlib; ac_word=$2
-if ${ac_cv_prog_ac_ct_RANLIB+:} false; then :
-else
- if test -n "$ac_ct_RANLIB"; then
- ac_cv_prog_ac_ct_RANLIB="$ac_ct_RANLIB" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_RANLIB="ranlib"
- break 2
- fi
-done
- done
-IFS=$as_save_IFS
-fi
-fi
-ac_ct_RANLIB=$ac_cv_prog_ac_ct_RANLIB
-if test -n "$ac_ct_RANLIB"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_RANLIB" >&5
-$as_echo "$ac_ct_RANLIB" >&6; }
-else
-fi
- if test "x$ac_ct_RANLIB" = x; then
- RANLIB=":"
- else
-yes:)
-esac
- RANLIB=$ac_ct_RANLIB
- fi
-else
- RANLIB="$ac_cv_prog_RANLIB"
-fi
-# AC_PROG_CXX sets these to -g -O2 without asking questions, and there are answers
-CXXFLAGS=
-# Checks for header files.
-for ac_header in arpa/inet.h fcntl.h netdb.h netinet/in.h stdlib.h string.h sys/socket.h sys/time.h unistd.h getopt.h
-do :
- as_ac_Header=`$as_echo "ac_cv_header_$ac_header" | $as_tr_sh`
-ac_fn_c_check_header_mongrel "$LINENO" "$ac_header" "$as_ac_Header" "$ac_includes_default"
-if eval test \"x\$"$as_ac_Header"\" = x"yes"; then :
- cat >>confdefs.h <<_ACEOF
-#define `$as_echo "HAVE_$ac_header" | $as_tr_cpp` 1
-_ACEOF
-fi
-done
-# Libs
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for pthread_create in -lpthread" >&5
-$as_echo_n "checking for pthread_create in -lpthread... " >&6; }
-if ${ac_cv_lib_pthread_pthread_create+:} false; then :
-else
- ac_check_lib_save_LIBS=$LIBS
-LIBS="-lpthread $LIBS"
-/* Override any GCC internal prototype to avoid an error.
- Use char because int might match the return type of a GCC
- builtin and then its argument prototype would still apply. */
-#ifdef __cplusplus
-extern "C"
-#endif
-char pthread_create ();
-int
-main ()
-return pthread_create ();
- return 0;
-_ACEOF
-if ac_fn_c_try_link "$LINENO"; then :
- ac_cv_lib_pthread_pthread_create=yes
-else
- ac_cv_lib_pthread_pthread_create=no
-fi
-rm -f core conftest.err conftest.$ac_objext \
- conftest$ac_exeext conftest.$ac_ext
-LIBS=$ac_check_lib_save_LIBS
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_pthread_pthread_create" >&5
-$as_echo "$ac_cv_lib_pthread_pthread_create" >&6; }
-if test "x$ac_cv_lib_pthread_pthread_create" = xyes; then :
-#define HAVE_LIBPTHREAD 1
-_ACEOF
- LIBS="-lpthread $LIBS"
-fi
-# Checks for typedefs, structures, and compiler characteristics.
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for stdbool.h that conforms to C99" >&5
-$as_echo_n "checking for stdbool.h that conforms to C99... " >&6; }
-if ${ac_cv_header_stdbool_h+:} false; then :
-else
-#include <stdbool.h>
-#ifndef bool
- "error: bool is not defined"
-#endif
-#ifndef false
- "error: false is not defined"
-#endif
-#if false
- "error: false is not 0"
-#endif
-#ifndef true
- "error: true is not defined"
-#endif
-#if true != 1
- "error: true is not 1"
-#endif
-#ifndef __bool_true_false_are_defined
- "error: __bool_true_false_are_defined is not defined"
-#endif
- struct s { _Bool s: 1; _Bool t; } s;
- char a[true == 1 ? 1 : -1];
- char b[false == 0 ? 1 : -1];
- char c[__bool_true_false_are_defined == 1 ? 1 : -1];
- char d[(bool) 0.5 == true ? 1 : -1];
- /* See body of main program for 'e'. */
- char f[(_Bool) 0.0 == false ? 1 : -1];
- char g[true];
- char h[sizeof (_Bool)];
- char i[sizeof s.t];
- enum { j = false, k = true, l = false * true, m = true * 256 };
- /* The following fails for
- HP aC++/ANSI C B3910B A.05.55 [Dec 04 2003]. */
- _Bool n[m];
- char o[sizeof n == m * sizeof n[0] ? 1 : -1];
- char p[-1 - (_Bool) 0 < 0 && -1 - (bool) 0 < 0 ? 1 : -1];
- /* Catch a bug in an HP-UX C compiler. See
- http://gcc.gnu.org/ml/gcc-patches/2003-12/msg02303.html
- http://lists.gnu.org/archive/html/bug-coreutils/2005-11/msg00161.html
- _Bool q = true;
- _Bool *pq = &q;
-int
-main ()
- bool e = &s;
- *pq |= q;
- *pq |= ! q;
- /* Refer to every declared value, to avoid compiler optimizations. */
- return (!a + !b + !c + !d + !e + !f + !g + !h + !i + !!j + !k + !!l
- + !m + !n + !o + !p + !q + !pq);
- return 0;
-_ACEOF
- ac_cv_header_stdbool_h=yes
-else
- ac_cv_header_stdbool_h=no
-fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_header_stdbool_h" >&5
-$as_echo "$ac_cv_header_stdbool_h" >&6; }
-ac_fn_c_check_type "$LINENO" "_Bool" "ac_cv_type__Bool" "$ac_includes_default"
-if test "x$ac_cv_type__Bool" = xyes; then :
-cat >>confdefs.h <<_ACEOF
-#define HAVE__BOOL 1
-_ACEOF
-fi
-if test $ac_cv_header_stdbool_h = yes; then
-$as_echo "#define HAVE_STDBOOL_H 1" >>confdefs.h
-fi
-ac_fn_c_check_type "$LINENO" "size_t" "ac_cv_type_size_t" "$ac_includes_default"
-if test "x$ac_cv_type_size_t" = xyes; then :
-else
-#define size_t unsigned int
-_ACEOF
-fi
-# Checks for library functions.
-for ac_header in stdlib.h
-do :
- ac_fn_c_check_header_mongrel "$LINENO" "stdlib.h" "ac_cv_header_stdlib_h" "$ac_includes_default"
-if test "x$ac_cv_header_stdlib_h" = xyes; then :
-#define HAVE_STDLIB_H 1
-_ACEOF
-fi
-done
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for GNU libc compatible malloc" >&5
-$as_echo_n "checking for GNU libc compatible malloc... " >&6; }
-if ${ac_cv_func_malloc_0_nonnull+:} false; then :
-else
- if test "$cross_compiling" = yes; then :
- ac_cv_func_malloc_0_nonnull=no
-else
-#if defined STDC_HEADERS || defined HAVE_STDLIB_H
-# include <stdlib.h>
-#else
-char *malloc ();
-#endif
-int
-main ()
-return ! malloc (0);
- return 0;
-_ACEOF
-if ac_fn_c_try_run "$LINENO"; then :
- ac_cv_func_malloc_0_nonnull=yes
-else
-fi
-rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext \
- conftest.$ac_objext conftest.beam conftest.$ac_ext
-fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_func_malloc_0_nonnull" >&5
-$as_echo "$ac_cv_func_malloc_0_nonnull" >&6; }
-if test $ac_cv_func_malloc_0_nonnull = yes; then :
-$as_echo "#define HAVE_MALLOC 1" >>confdefs.h
-else
- $as_echo "#define HAVE_MALLOC 0" >>confdefs.h
- case " $LIBOBJS " in
- *" malloc.$ac_objext "* ) ;;
- *) LIBOBJS="$LIBOBJS malloc.$ac_objext"
-esac
-$as_echo "#define malloc rpl_malloc" >>confdefs.h
-fi
-for ac_func in gettimeofday memset select socket strerror strrchr
-do :
- as_ac_var=`$as_echo "ac_cv_func_$ac_func" | $as_tr_sh`
-ac_fn_c_check_func "$LINENO" "$ac_func" "$as_ac_var"
-if eval test \"x\$"$as_ac_var"\" = x"yes"; then :
-#define `$as_echo "HAVE_$ac_func" | $as_tr_cpp` 1
-_ACEOF
-fi
-done
-# debug compilation support
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether to build with debug information" >&5
-$as_echo_n "checking whether to build with debug information... " >&6; }
-# Check whether --enable-debug was given.
-if test "${enable_debug+set}" = set; then :
- enableval=$enable_debug; debugit="$enableval"
-else
- debugit=no
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $debugit" >&5
-$as_echo "$debugit" >&6; }
-if test x"$debugit" = x"yes"; then
-$as_echo "#define CONF_DEBUG /**/" >>confdefs.h
- AM_CXXFLAGS="-g3 -O0"
-else
-$as_echo "#define CONF_NODEBUG /**/" >>confdefs.h
- AM_CXXFLAGS="-O2"
-fi
-USE_TCL=0
-# Check whether --with-tcl was given.
-if test "${with_tcl+set}" = set; then :
- withval=$with_tcl;
- USE_TCL=$withval
- CPPFLAGS="${CPPFLAGS} -I ${USE_TCL}/include"
- AM_CXXFLAGS="${AM_CXXFLAGS} -I ${USE_TCL}/include"
- for ac_header in tcl.h
-do :
- ac_fn_c_check_header_mongrel "$LINENO" "tcl.h" "ac_cv_header_tcl_h" "$ac_includes_default"
-if test "x$ac_cv_header_tcl_h" = xyes; then :
-#define HAVE_TCL_H 1
-_ACEOF
-fi
-done
-fi
-USE_TCL_VERSION=0
-# Check whether --with-tcl-version was given.
-if test "${with_tcl_version+set}" = set; then :
- withval=$with_tcl_version;
- [ ${USE_TCL} == 0 ] && \
- as_fn_error $? "Use of Tcl requires --with-tcl" "$LINENO" 5
- USE_TCL_VERSION=$withval
- LDFLAGS="$LDFLAGS -L$USE_TCL/lib"
- AM_LDFLAGS="${AM_LDFLAGS} -L$USE_TCL/lib -Wl,-rpath $USE_TCL/lib"
- # -l tcl$USE_TCL_VERSION
- as_ac_Lib=`$as_echo "ac_cv_lib_tcl$USE_TCL_VERSION''_Tcl_PkgProvide" | $as_tr_sh`
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for Tcl_PkgProvide in -ltcl$USE_TCL_VERSION" >&5
-$as_echo_n "checking for Tcl_PkgProvide in -ltcl$USE_TCL_VERSION... " >&6; }
-if eval \${$as_ac_Lib+:} false; then :
-else
-LIBS="-ltcl$USE_TCL_VERSION $LIBS"
-#ifdef __cplusplus
-extern "C"
-#endif
-char Tcl_PkgProvide ();
-int
-main ()
-return Tcl_PkgProvide ();
- return 0;
-_ACEOF
- eval "$as_ac_Lib=yes"
-else
- eval "$as_ac_Lib=no"
-fi
-fi
-eval ac_res=\$$as_ac_Lib
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_res" >&5
-$as_echo "$ac_res" >&6; }
-if eval test \"x\$"$as_ac_Lib"\" = x"yes"; then :
-#define `$as_echo "HAVE_LIBtcl$USE_TCL_VERSION" | $as_tr_cpp` 1
-_ACEOF
- LIBS="-ltcl$USE_TCL_VERSION $LIBS"
-fi
- ac_fn_c_check_func "$LINENO" "Tcl_PkgProvide" "ac_cv_func_Tcl_PkgProvide"
-if test "x$ac_cv_func_Tcl_PkgProvide" = xyes; then :
-else
- as_fn_error $? "Could not link to Tcl!" "$LINENO" 5
-fi
-fi
-USE_SWIG=0
-# Check whether --enable-swig was given.
-if test "${enable_swig+set}" = set; then :
- enableval=$enable_swig;
- [ $USE_TCL_VERSION == 0 ] && \
- as_fn_error $? "Use of SWIG requires --with-tcl-version" "$LINENO" 5
- USE_SWIG=1
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: SWIG enabled." >&5
-$as_echo "SWIG enabled." >&6; }
-fi
- if test $USE_SWIG = 1; then
- SWIG_TRUE=
- SWIG_FALSE='#'
-else
- SWIG_TRUE='#'
- SWIG_FALSE=
-fi
-ac_config_files="$ac_config_files Makefile"
-ac_config_files="$ac_config_files src/Makefile"
-cat >confcache <<\_ACEOF
-# This file is a shell script that caches the results of configure
-# tests run on this system so they can be shared between configure
-# scripts and configure runs, see configure's option --config-cache.
-# It is not useful on other systems. If it contains results you don't
-# want to keep, you may remove or edit it.
-# config.status only pays attention to the cache file if you give it
-# the --recheck option to rerun configure.
-# `ac_cv_env_foo' variables (set or unset) will be overridden when
-# loading this file, other *unset* `ac_cv_foo' will be assigned the
-# following values.
-_ACEOF
-# The following way of writing the cache mishandles newlines in values,
-# but we know of no workaround that is simple, portable, and efficient.
-# So, we kill variables containing newlines.
-# Ultrix sh set writes to stderr and can't be redirected directly,
-# and sets the high bit in the cache file unless we assign to the vars.
- for ac_var in `(set) 2>&1 | sed -n 's/^\([a-zA-Z_][a-zA-Z0-9_]*\)=.*/\1/p'`; do
- eval ac_val=\$$ac_var
- case $ac_val in #(
- *${as_nl}*)
- case $ac_var in #(
- *_cv_*) { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: cache variable $ac_var contains a newline" >&5
-$as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
- esac
- _ | IFS | as_nl) ;; #(
- BASH_ARGV | BASH_SOURCE) eval $ac_var= ;; #(
- *) { eval $ac_var=; unset $ac_var;} ;;
- esac ;;
- esac
- done
- (set) 2>&1 |
- case $as_nl`(ac_space=' '; set) 2>&1` in #(
- *${as_nl}ac_space=\ *)
- # `set' does not quote correctly, so add quotes: double-quote
- # substitution turns \\\\ into \\, and sed turns \\ into \.
- sed -n \
- "s/'/'\\\\''/g;
- s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='\\2'/p"
- # `set' quotes correctly as required by POSIX, so do not add quotes.
- sed -n "/^[_$as_cr_alnum]*_cv_[_$as_cr_alnum]*=/p"
- esac |
- sort
- sed '
- /^ac_cv_env_/b end
- t clear
- :clear
- s/^\([^=]*\)=\(.*[{}].*\)$/test "${\1+set}" = set || &/
- t end
- s/^\([^=]*\)=\(.*\)$/\1=${\1=\2}/
- :end' >>confcache
-if diff "$cache_file" confcache >/dev/null 2>&1; then :; else
- if test -w "$cache_file"; then
- if test "x$cache_file" != "x/dev/null"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: updating cache $cache_file" >&5
-$as_echo "$as_me: updating cache $cache_file" >&6;}
- if test ! -f "$cache_file" || test -h "$cache_file"; then
- cat confcache >"$cache_file"
- else
- case $cache_file in #(
- mv -f confcache "$cache_file"$$ &&
- mv -f "$cache_file"$$ "$cache_file" ;; #(
- mv -f confcache "$cache_file" ;;
- esac
- fi
- fi
- else
- { $as_echo "$as_me:${as_lineno-$LINENO}: not updating unwritable cache $cache_file" >&5
-$as_echo "$as_me: not updating unwritable cache $cache_file" >&6;}
- fi
-fi
-rm -f confcache
-test "x$prefix" = xNONE && prefix=$ac_default_prefix
-# Let make expand exec_prefix.
-test "x$exec_prefix" = xNONE && exec_prefix='${prefix}'
-# Transform confdefs.h into DEFS.
-# Protect against shell expansion while executing Makefile rules.
-# Protect against Makefile macro expansion.
-# If the first sed substitution is executed (which looks for macros that
-# take arguments), then branch to the quote section. Otherwise,
-# look for a macro that doesn't take arguments.
-ac_script='
-:mline
- N
- s,\\\n,,
- b mline
-t clear
-:clear
-s/^[ ]*#[ ]*define[ ][ ]*\([^ (][^ (]*([^)]*)\)[ ]*\(.*\)/-D\1=\2/g
-t quote
-s/^[ ]*#[ ]*define[ ][ ]*\([^ ][^ ]*\)[ ]*\(.*\)/-D\1=\2/g
-t quote
-b any
-:quote
-s/[ `~#$^&*(){}\\|;'\''"<>?]/\\&/g
-s/\[/\\&/g
-s/\]/\\&/g
-s/\$/$$/g
-H
-:any
- g
- s/^\n//
- s/\n/ /g
- p
-DEFS=`sed -n "$ac_script" confdefs.h`
-ac_libobjs=
-ac_ltlibobjs=
-U=
-for ac_i in : $LIBOBJS; do test "x$ac_i" = x: && continue
- # 1. Remove the extension, and $U if already installed.
- ac_script='s/\$U\././;s/\.o$//;s/\.obj$//'
- ac_i=`$as_echo "$ac_i" | sed "$ac_script"`
- # 2. Prepend LIBOBJDIR. When used with automake>=1.10 LIBOBJDIR
- # will be set to the directory where LIBOBJS objects are built.
- as_fn_append ac_libobjs " \${LIBOBJDIR}$ac_i\$U.$ac_objext"
- as_fn_append ac_ltlibobjs " \${LIBOBJDIR}$ac_i"'$U.lo'
-done
-LIBOBJS=$ac_libobjs
-LTLIBOBJS=$ac_ltlibobjs
- if test -n "$EXEEXT"; then
- am__EXEEXT_TRUE=
- am__EXEEXT_FALSE='#'
-else
- am__EXEEXT_TRUE='#'
- am__EXEEXT_FALSE=
-fi
-if test -z "${AMDEP_TRUE}" && test -z "${AMDEP_FALSE}"; then
- as_fn_error $? "conditional \"AMDEP\" was never defined.
-Usually this means the macro was only invoked conditionally." "$LINENO" 5
-fi
-if test -z "${am__fastdepCC_TRUE}" && test -z "${am__fastdepCC_FALSE}"; then
- as_fn_error $? "conditional \"am__fastdepCC\" was never defined.
-fi
-if test -z "${am__fastdepCXX_TRUE}" && test -z "${am__fastdepCXX_FALSE}"; then
- as_fn_error $? "conditional \"am__fastdepCXX\" was never defined.
-fi
-fi
-fi
-if test -z "${SWIG_TRUE}" && test -z "${SWIG_FALSE}"; then
- as_fn_error $? "conditional \"SWIG\" was never defined.
-fi
-: "${CONFIG_STATUS=./config.status}"
-ac_write_fail=0
-ac_clean_files_save=$ac_clean_files
-ac_clean_files="$ac_clean_files $CONFIG_STATUS"
-{ $as_echo "$as_me:${as_lineno-$LINENO}: creating $CONFIG_STATUS" >&5
-$as_echo "$as_me: creating $CONFIG_STATUS" >&6;}
-as_write_fail=0
-cat >$CONFIG_STATUS <<_ASEOF || as_write_fail=1
-#! $SHELL
-# Generated by $as_me.
-# Run this file to recreate the current configuration.
-# Compiler output produced by configure, useful for debugging
-# configure, is in config.log if it exists.
-debug=false
-ac_cs_recheck=false
-ac_cs_silent=false
-SHELL=\${CONFIG_SHELL-$SHELL}
-export SHELL
-_ASEOF
-cat >>$CONFIG_STATUS <<\_ASEOF || as_write_fail=1
-## M4sh Initialization. ##
-# Be more Bourne compatible
-DUALCASE=1; export DUALCASE # for MKS sh
-if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then :
- emulate sh
- NULLCMD=:
- # Pre-4.2 versions of Zsh do word splitting on ${1+"$@"}, which
- # is contrary to our usage. Disable this feature.
- alias -g '${1+"$@"}'='"$@"'
- setopt NO_GLOB_SUBST
-else
- case `(set -o) 2>/dev/null` in #(
- *posix*) :
- set -o posix ;; #(
-esac
-fi
-as_nl='
-export as_nl
-# Printing a long string crashes Solaris 7 /usr/bin/printf.
-as_echo='\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'
-as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo
-as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo$as_echo
-# Prefer a ksh shell builtin over an external printf program on Solaris,
-# but without wasting forks for bash or zsh.
-if test -z "$BASH_VERSION$ZSH_VERSION" \
- && (test "X`print -r -- $as_echo`" = "X$as_echo") 2>/dev/null; then
- as_echo='print -r --'
- as_echo_n='print -rn --'
-elif (test "X`printf %s $as_echo`" = "X$as_echo") 2>/dev/null; then
- as_echo='printf %s\n'
- as_echo_n='printf %s'
-else
- if test "X`(/usr/ucb/echo -n -n $as_echo) 2>/dev/null`" = "X-n $as_echo"; then
- as_echo_body='eval /usr/ucb/echo -n "$1$as_nl"'
- as_echo_n='/usr/ucb/echo -n'
- else
- as_echo_body='eval expr "X$1" : "X\\(.*\\)"'
- as_echo_n_body='eval
- arg=$1;
- case $arg in #(
- *"$as_nl"*)
- expr "X$arg" : "X\\(.*\\)$as_nl";
- arg=`expr "X$arg" : ".*$as_nl\\(.*\\)"`;;
- esac;
- expr "X$arg" : "X\\(.*\\)" | tr -d "$as_nl"
- export as_echo_n_body
- as_echo_n='sh -c $as_echo_n_body as_echo'
- fi
- export as_echo_body
- as_echo='sh -c $as_echo_body as_echo'
-fi
-# The user is always right.
-if test "${PATH_SEPARATOR+set}" != set; then
- PATH_SEPARATOR=:
- (PATH='/bin;/bin'; FPATH=$PATH; sh -c :) >/dev/null 2>&1 && {
- (PATH='/bin:/bin'; FPATH=$PATH; sh -c :) >/dev/null 2>&1 ||
- PATH_SEPARATOR=';'
-fi
-# IFS
-# We need space, tab and new line, in precisely that order. Quoting is
-# there to prevent editors from complaining about space-tab.
-# (If _AS_PATH_WALK were called with IFS unset, it would disable word
-# splitting by setting IFS to empty value.)
-IFS=" "" $as_nl"
-# Find who we are. Look in the path if we contain no directory separator.
-as_myself=
-case $0 in #((
- *[\\/]* ) as_myself=$0 ;;
- *) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-do
- IFS=$as_save_IFS
- test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
- done
-IFS=$as_save_IFS
-esac
-# We did not find ourselves, most probably we were run as `sh COMMAND'
-# in which case we are not to be found in the path.
-if test "x$as_myself" = x; then
- as_myself=$0
-fi
-if test ! -f "$as_myself"; then
- $as_echo "$as_myself: error: cannot find myself; rerun with an absolute file name" >&2
- exit 1
-fi
-# Unset variables that we do not need and which cause bugs (e.g. in
-# pre-3.0 UWIN ksh). But do not cause bugs in bash 2.01; the "|| exit 1"
-# suppresses any "Segmentation fault" message there. '((' could
-# trigger a bug in pdksh 5.2.14.
-for as_var in BASH_ENV ENV MAIL MAILPATH
-do eval test x\${$as_var+set} = xset \
- && ( (unset $as_var) || exit 1) >/dev/null 2>&1 && unset $as_var || :
-done
-PS1='$ '
-PS2='> '
-PS4='+ '
-# NLS nuisances.
-LC_ALL=C
-export LC_ALL
-LANGUAGE=C
-export LANGUAGE
-# CDPATH.
-(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
-# as_fn_error STATUS ERROR [LINENO LOG_FD]
-# Output "`basename $0`: error: ERROR" to stderr. If LINENO and LOG_FD are
-# provided, also output the error to LOG_FD, referencing LINENO. Then exit the
-# script with STATUS, using 1 if that was 0.
-as_fn_error ()
- as_status=$1; test $as_status -eq 0 && as_status=1
- if test "$4"; then
- as_lineno=${as_lineno-"$3"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
- $as_echo "$as_me:${as_lineno-$LINENO}: error: $2" >&$4
- fi
- $as_echo "$as_me: error: $2" >&2
- as_fn_exit $as_status
-} # as_fn_error
-# as_fn_set_status STATUS
-# Set $? to STATUS, without forking.
-as_fn_set_status ()
- return $1
-} # as_fn_set_status
-# as_fn_exit STATUS
-# Exit the shell with STATUS, even in a "trap 0" or "set -e" context.
-as_fn_exit ()
- set +e
- as_fn_set_status $1
- exit $1
-} # as_fn_exit
-# as_fn_unset VAR
-# Portably unset VAR.
-as_fn_unset ()
- { eval $1=; unset $1;}
-as_unset=as_fn_unset
-# as_fn_append VAR VALUE
-# Append the text in VALUE to the end of the definition contained in VAR. Take
-# advantage of any shell optimizations that allow amortized linear growth over
-# repeated appends, instead of the typical quadratic growth present in naive
-# implementations.
-if (eval "as_var=1; as_var+=2; test x\$as_var = x12") 2>/dev/null; then :
- eval 'as_fn_append ()
- eval $1+=\$2
-else
- as_fn_append ()
- eval $1=\$$1\$2
-fi # as_fn_append
-# as_fn_arith ARG...
-# Perform arithmetic evaluation on the ARGs, and store the result in the
-# global $as_val. Take advantage of shells that can avoid forks. The arguments
-# must be portable across $(()) and expr.
-if (eval "test \$(( 1 + 1 )) = 2") 2>/dev/null; then :
- eval 'as_fn_arith ()
- as_val=$(( $* ))
-else
- as_fn_arith ()
- as_val=`expr "$@" || test $? -eq 1`
-fi # as_fn_arith
-if expr a : '\(a\)' >/dev/null 2>&1 &&
- test "X`expr 00001 : '.*\(...\)'`" = X001; then
- as_expr=expr
-else
- as_expr=false
-fi
-if (basename -- /) >/dev/null 2>&1 && test "X`basename -- / 2>&1`" = "X/"; then
- as_basename=basename
-else
- as_basename=false
-fi
-if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
- as_dirname=dirname
-else
- as_dirname=false
-fi
-as_me=`$as_basename -- "$0" ||
-$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
- X"$0" : 'X\(//\)$' \| \
- X"$0" : 'X\(/\)' \| . 2>/dev/null ||
-$as_echo X/"$0" |
- sed '/^.*\/\([^/][^/]*\)\/*$/{
- s//\1/
- q
- /^X\/\(\/\/\)$/{
- s//\1/
- q
- /^X\/\(\/\).*/{
- s//\1/
- q
- s/.*/./; q'`
-# Avoid depending upon Character Ranges.
-as_cr_letters='abcdefghijklmnopqrstuvwxyz'
-as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
-as_cr_Letters=$as_cr_letters$as_cr_LETTERS
-as_cr_digits='0123456789'
-as_cr_alnum=$as_cr_Letters$as_cr_digits
-ECHO_C= ECHO_N= ECHO_T=
-case `echo -n x` in #(((((
--n*)
- case `echo 'xy\c'` in
- *c*) ECHO_T=' ';; # ECHO_T is single tab character.
- xy) ECHO_C='\c';;
- *) echo `echo ksh88 bug on AIX 6.1` > /dev/null
- ECHO_T=' ';;
- esac;;
- ECHO_N='-n';;
-esac
-rm -f conf$$ conf$$.exe conf$$.file
-if test -d conf$$.dir; then
- rm -f conf$$.dir/conf$$.file
-else
- rm -f conf$$.dir
- mkdir conf$$.dir 2>/dev/null
-fi
-if (echo >conf$$.file) 2>/dev/null; then
- if ln -s conf$$.file conf$$ 2>/dev/null; then
- as_ln_s='ln -s'
- # ... but there are two gotchas:
- # 1) On MSYS, both `ln -s file dir' and `ln file dir' fail.
- # 2) DJGPP < 2.04 has no symlinks; `ln -s' creates a wrapper executable.
- # In both cases, we have to default to `cp -p'.
- ln -s conf$$.file conf$$.dir 2>/dev/null && test ! -f conf$$.exe ||
- as_ln_s='cp -p'
- elif ln conf$$.file conf$$ 2>/dev/null; then
- as_ln_s=ln
- else
- as_ln_s='cp -p'
- fi
-else
- as_ln_s='cp -p'
-fi
-rm -f conf$$ conf$$.exe conf$$.dir/conf$$.file conf$$.file
-rmdir conf$$.dir 2>/dev/null
-# as_fn_mkdir_p
-# Create "$as_dir" as a directory, including parents if necessary.
-as_fn_mkdir_p ()
- case $as_dir in #(
- -*) as_dir=./$as_dir;;
- esac
- test -d "$as_dir" || eval $as_mkdir_p || {
- as_dirs=
- while :; do
- *\'*) as_qdir=`$as_echo "$as_dir" | sed "s/'/'\\\\\\\\''/g"`;; #'(
- *) as_qdir=$as_dir;;
- esac
- as_dirs="'$as_qdir' $as_dirs"
- as_dir=`$as_dirname -- "$as_dir" ||
-$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$as_dir" : 'X\(//\)[^/]' \| \
- X"$as_dir" : 'X\(//\)$' \| \
- X"$as_dir" : 'X\(/\)' \| . 2>/dev/null ||
-$as_echo X"$as_dir" |
- sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
- s//\1/
- q
- /^X\(\/\/\)[^/].*/{
- s//\1/
- q
- /^X\(\/\/\)$/{
- s//\1/
- q
- /^X\(\/\).*/{
- s//\1/
- q
- s/.*/./; q'`
- test -d "$as_dir" && break
- done
- test -z "$as_dirs" || eval "mkdir $as_dirs"
- } || test -d "$as_dir" || as_fn_error $? "cannot create directory $as_dir"
-} # as_fn_mkdir_p
-if mkdir -p . 2>/dev/null; then
- as_mkdir_p='mkdir -p "$as_dir"'
-else
- test -d ./-p && rmdir ./-p
- as_mkdir_p=false
-fi
-if test -x / >/dev/null 2>&1; then
- as_test_x='test -x'
-else
- if ls -dL / >/dev/null 2>&1; then
- as_ls_L_option=L
- else
- as_ls_L_option=
- fi
- as_test_x='
- eval sh -c '\''
- if test -d "$1"; then
- test -d "$1/.";
- else
- case $1 in #(
- -*)set "./$1";;
- esac;
- case `ls -ld'$as_ls_L_option' "$1" 2>/dev/null` in #((
- ???[sx]*):;;*)false;;esac;fi
- '\'' sh
-fi
-as_executable_p=$as_test_x
-# Sed expression to map a string onto a valid CPP name.
-as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
-# Sed expression to map a string onto a valid variable name.
-as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
-exec 6>&1
-## Main body of $CONFIG_STATUS script. ##
-_ASEOF
-test $as_write_fail = 0 && chmod +x $CONFIG_STATUS || ac_write_fail=1
-cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
-# Save the log message, to keep $0 and so on meaningful, and to
-# report actual input values of CONFIG_FILES etc. instead of their
-# values after options handling.
-ac_log="
-This file was extended by coaster-c-client $as_me 1.0, which was
-generated by GNU Autoconf 2.68. Invocation command line was
- CONFIG_FILES = $CONFIG_FILES
- CONFIG_HEADERS = $CONFIG_HEADERS
- CONFIG_LINKS = $CONFIG_LINKS
- CONFIG_COMMANDS = $CONFIG_COMMANDS
- $ $0 $@
-on `(hostname || uname -n) 2>/dev/null | sed 1q`
-_ACEOF
-case $ac_config_files in *"
-"*) set x $ac_config_files; shift; ac_config_files=$*;;
-esac
-cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
-# Files that config.status was made for.
-config_files="$ac_config_files"
-config_commands="$ac_config_commands"
-_ACEOF
-ac_cs_usage="\
-\`$as_me' instantiates files and other configuration actions
-from templates according to the current configuration. Unless the files
-and actions are specified as TAGs, all are instantiated by default.
-Usage: $0 [OPTION]... [TAG]...
- -h, --help print this help, then exit
- -V, --version print version number and configuration settings, then exit
- --config print configuration, then exit
- -q, --quiet, --silent
- do not print progress messages
- -d, --debug don't remove temporary files
- --recheck update $as_me by reconfiguring in the same conditions
- --file=FILE[:TEMPLATE]
- instantiate the configuration file FILE
-Configuration files:
-$config_files
-Configuration commands:
-$config_commands
-Report bugs to the package provider."
-_ACEOF
-ac_cs_config="`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`"
-ac_cs_version="\\
-coaster-c-client config.status 1.0
-configured by $0, generated by GNU Autoconf 2.68,
- with options \\"\$ac_cs_config\\"
-Copyright (C) 2010 Free Software Foundation, Inc.
-This config.status script is free software; the Free Software Foundation
-gives unlimited permission to copy, distribute and modify it."
-ac_pwd='$ac_pwd'
-srcdir='$srcdir'
-INSTALL='$INSTALL'
-MKDIR_P='$MKDIR_P'
-AWK='$AWK'
-test -n "\$AWK" || AWK=awk
-_ACEOF
-# The default lists apply if the user does not specify any file.
-ac_need_defaults=:
-while test $# != 0
-do
- case $1 in
- ac_option=`expr "X$1" : 'X\([^=]*\)='`
- ac_optarg=`expr "X$1" : 'X[^=]*=\(.*\)'`
- ac_shift=:
- ac_optarg=
- ac_shift=:
- ac_option=$1
- ac_optarg=$2
- ac_shift=shift
- esac
- case $ac_option in
- # Handling of the options.
- -recheck | --recheck | --rechec | --reche | --rech | --rec | --re | --r)
- ac_cs_recheck=: ;;
- --version | --versio | --versi | --vers | --ver | --ve | --v | -V )
- $as_echo "$ac_cs_version"; exit ;;
- --config | --confi | --conf | --con | --co | --c )
- $as_echo "$ac_cs_config"; exit ;;
- --debug | --debu | --deb | --de | --d | -d )
- debug=: ;;
- --file | --fil | --fi | --f )
- $ac_shift
- case $ac_optarg in
- *\'*) ac_optarg=`$as_echo "$ac_optarg" | sed "s/'/'\\\\\\\\''/g"` ;;
- '') as_fn_error $? "missing file argument" ;;
- esac
- as_fn_append CONFIG_FILES " '$ac_optarg'"
- ac_need_defaults=false;;
- --he | --h | --help | --hel | -h )
- $as_echo "$ac_cs_usage"; exit ;;
- -q | -quiet | --quiet | --quie | --qui | --qu | --q \
- | -silent | --silent | --silen | --sile | --sil | --si | --s)
- ac_cs_silent=: ;;
- # This is an error.
- -*) as_fn_error $? "unrecognized option: \`$1'
-Try \`$0 --help' for more information." ;;
- *) as_fn_append ac_config_targets " $1"
- ac_need_defaults=false ;;
- esac
- shift
-done
-ac_configure_extra_args=
-if $ac_cs_silent; then
- exec 6>/dev/null
- ac_configure_extra_args="$ac_configure_extra_args --silent"
-fi
-_ACEOF
-if \$ac_cs_recheck; then
- set X '$SHELL' '$0' $ac_configure_args \$ac_configure_extra_args --no-create --no-recursion
- shift
- \$as_echo "running CONFIG_SHELL=$SHELL \$*" >&6
- CONFIG_SHELL='$SHELL'
- export CONFIG_SHELL
- exec "\$@"
-fi
-_ACEOF
-exec 5>>config.log
- echo
- sed 'h;s/./-/g;s/^.../## /;s/...$/ ##/;p;x;p;x' <<_ASBOX
-## Running $as_me. ##
-_ASBOX
- $as_echo "$ac_log"
-} >&5
-_ACEOF
-# INIT-COMMANDS
-AMDEP_TRUE="$AMDEP_TRUE" ac_aux_dir="$ac_aux_dir"
-# The HP-UX ksh and POSIX shell print the target directory to stdout
-# if CDPATH is set.
-sed_quote_subst='$sed_quote_subst'
-double_quote_subst='$double_quote_subst'
-delay_variable_subst='$delay_variable_subst'
-macro_version='`$ECHO "$macro_version" | $SED "$delay_single_quote_subst"`'
-macro_revision='`$ECHO "$macro_revision" | $SED "$delay_single_quote_subst"`'
-enable_shared='`$ECHO "$enable_shared" | $SED "$delay_single_quote_subst"`'
-enable_static='`$ECHO "$enable_static" | $SED "$delay_single_quote_subst"`'
-pic_mode='`$ECHO "$pic_mode" | $SED "$delay_single_quote_subst"`'
-enable_fast_install='`$ECHO "$enable_fast_install" | $SED "$delay_single_quote_subst"`'
-SHELL='`$ECHO "$SHELL" | $SED "$delay_single_quote_subst"`'
-ECHO='`$ECHO "$ECHO" | $SED "$delay_single_quote_subst"`'
-PATH_SEPARATOR='`$ECHO "$PATH_SEPARATOR" | $SED "$delay_single_quote_subst"`'
-host_alias='`$ECHO "$host_alias" | $SED "$delay_single_quote_subst"`'
-host='`$ECHO "$host" | $SED "$delay_single_quote_subst"`'
-host_os='`$ECHO "$host_os" | $SED "$delay_single_quote_subst"`'
-build_alias='`$ECHO "$build_alias" | $SED "$delay_single_quote_subst"`'
-build='`$ECHO "$build" | $SED "$delay_single_quote_subst"`'
-build_os='`$ECHO "$build_os" | $SED "$delay_single_quote_subst"`'
-SED='`$ECHO "$SED" | $SED "$delay_single_quote_subst"`'
-Xsed='`$ECHO "$Xsed" | $SED "$delay_single_quote_subst"`'
-GREP='`$ECHO "$GREP" | $SED "$delay_single_quote_subst"`'
-EGREP='`$ECHO "$EGREP" | $SED "$delay_single_quote_subst"`'
-FGREP='`$ECHO "$FGREP" | $SED "$delay_single_quote_subst"`'
-LD='`$ECHO "$LD" | $SED "$delay_single_quote_subst"`'
-NM='`$ECHO "$NM" | $SED "$delay_single_quote_subst"`'
-LN_S='`$ECHO "$LN_S" | $SED "$delay_single_quote_subst"`'
-max_cmd_len='`$ECHO "$max_cmd_len" | $SED "$delay_single_quote_subst"`'
-ac_objext='`$ECHO "$ac_objext" | $SED "$delay_single_quote_subst"`'
-exeext='`$ECHO "$exeext" | $SED "$delay_single_quote_subst"`'
-lt_unset='`$ECHO "$lt_unset" | $SED "$delay_single_quote_subst"`'
-lt_SP2NL='`$ECHO "$lt_SP2NL" | $SED "$delay_single_quote_subst"`'
-lt_NL2SP='`$ECHO "$lt_NL2SP" | $SED "$delay_single_quote_subst"`'
-lt_cv_to_host_file_cmd='`$ECHO "$lt_cv_to_host_file_cmd" | $SED "$delay_single_quote_subst"`'
-lt_cv_to_tool_file_cmd='`$ECHO "$lt_cv_to_tool_file_cmd" | $SED "$delay_single_quote_subst"`'
-reload_flag='`$ECHO "$reload_flag" | $SED "$delay_single_quote_subst"`'
-reload_cmds='`$ECHO "$reload_cmds" | $SED "$delay_single_quote_subst"`'
-OBJDUMP='`$ECHO "$OBJDUMP" | $SED "$delay_single_quote_subst"`'
-deplibs_check_method='`$ECHO "$deplibs_check_method" | $SED "$delay_single_quote_subst"`'
-file_magic_cmd='`$ECHO "$file_magic_cmd" | $SED "$delay_single_quote_subst"`'
-file_magic_glob='`$ECHO "$file_magic_glob" | $SED "$delay_single_quote_subst"`'
-want_nocaseglob='`$ECHO "$want_nocaseglob" | $SED "$delay_single_quote_subst"`'
-DLLTOOL='`$ECHO "$DLLTOOL" | $SED "$delay_single_quote_subst"`'
-sharedlib_from_linklib_cmd='`$ECHO "$sharedlib_from_linklib_cmd" | $SED "$delay_single_quote_subst"`'
-AR='`$ECHO "$AR" | $SED "$delay_single_quote_subst"`'
-AR_FLAGS='`$ECHO "$AR_FLAGS" | $SED "$delay_single_quote_subst"`'
-archiver_list_spec='`$ECHO "$archiver_list_spec" | $SED "$delay_single_quote_subst"`'
-STRIP='`$ECHO "$STRIP" | $SED "$delay_single_quote_subst"`'
-RANLIB='`$ECHO "$RANLIB" | $SED "$delay_single_quote_subst"`'
-old_postinstall_cmds='`$ECHO "$old_postinstall_cmds" | $SED "$delay_single_quote_subst"`'
-old_postuninstall_cmds='`$ECHO "$old_postuninstall_cmds" | $SED "$delay_single_quote_subst"`'
-old_archive_cmds='`$ECHO "$old_archive_cmds" | $SED "$delay_single_quote_subst"`'
-lock_old_archive_extraction='`$ECHO "$lock_old_archive_extraction" | $SED "$delay_single_quote_subst"`'
-CC='`$ECHO "$CC" | $SED "$delay_single_quote_subst"`'
-CFLAGS='`$ECHO "$CFLAGS" | $SED "$delay_single_quote_subst"`'
-compiler='`$ECHO "$compiler" | $SED "$delay_single_quote_subst"`'
-GCC='`$ECHO "$GCC" | $SED "$delay_single_quote_subst"`'
-lt_cv_sys_global_symbol_pipe='`$ECHO "$lt_cv_sys_global_symbol_pipe" | $SED "$delay_single_quote_subst"`'
-lt_cv_sys_global_symbol_to_cdecl='`$ECHO "$lt_cv_sys_global_symbol_to_cdecl" | $SED "$delay_single_quote_subst"`'
-lt_cv_sys_global_symbol_to_c_name_address='`$ECHO "$lt_cv_sys_global_symbol_to_c_name_address" | $SED "$delay_single_quote_subst"`'
-lt_cv_sys_global_symbol_to_c_name_address_lib_prefix='`$ECHO "$lt_cv_sys_global_symbol_to_c_name_address_lib_prefix" | $SED "$delay_single_quote_subst"`'
-nm_file_list_spec='`$ECHO "$nm_file_list_spec" | $SED "$delay_single_quote_subst"`'
-lt_sysroot='`$ECHO "$lt_sysroot" | $SED "$delay_single_quote_subst"`'
-objdir='`$ECHO "$objdir" | $SED "$delay_single_quote_subst"`'
-MAGIC_CMD='`$ECHO "$MAGIC_CMD" | $SED "$delay_single_quote_subst"`'
-lt_prog_compiler_no_builtin_flag='`$ECHO "$lt_prog_compiler_no_builtin_flag" | $SED "$delay_single_quote_subst"`'
-lt_prog_compiler_pic='`$ECHO "$lt_prog_compiler_pic" | $SED "$delay_single_quote_subst"`'
-lt_prog_compiler_wl='`$ECHO "$lt_prog_compiler_wl" | $SED "$delay_single_quote_subst"`'
-lt_prog_compiler_static='`$ECHO "$lt_prog_compiler_static" | $SED "$delay_single_quote_subst"`'
-lt_cv_prog_compiler_c_o='`$ECHO "$lt_cv_prog_compiler_c_o" | $SED "$delay_single_quote_subst"`'
-need_locks='`$ECHO "$need_locks" | $SED "$delay_single_quote_subst"`'
-MANIFEST_TOOL='`$ECHO "$MANIFEST_TOOL" | $SED "$delay_single_quote_subst"`'
-DSYMUTIL='`$ECHO "$DSYMUTIL" | $SED "$delay_single_quote_subst"`'
-NMEDIT='`$ECHO "$NMEDIT" | $SED "$delay_single_quote_subst"`'
-LIPO='`$ECHO "$LIPO" | $SED "$delay_single_quote_subst"`'
-OTOOL='`$ECHO "$OTOOL" | $SED "$delay_single_quote_subst"`'
-OTOOL64='`$ECHO "$OTOOL64" | $SED "$delay_single_quote_subst"`'
-libext='`$ECHO "$libext" | $SED "$delay_single_quote_subst"`'
-shrext_cmds='`$ECHO "$shrext_cmds" | $SED "$delay_single_quote_subst"`'
-extract_expsyms_cmds='`$ECHO "$extract_expsyms_cmds" | $SED "$delay_single_quote_subst"`'
-archive_cmds_need_lc='`$ECHO "$archive_cmds_need_lc" | $SED "$delay_single_quote_subst"`'
-enable_shared_with_static_runtimes='`$ECHO "$enable_shared_with_static_runtimes" | $SED "$delay_single_quote_subst"`'
-export_dynamic_flag_spec='`$ECHO "$export_dynamic_flag_spec" | $SED "$delay_single_quote_subst"`'
-whole_archive_flag_spec='`$ECHO "$whole_archive_flag_spec" | $SED "$delay_single_quote_subst"`'
-compiler_needs_object='`$ECHO "$compiler_needs_object" | $SED "$delay_single_quote_subst"`'
-old_archive_from_new_cmds='`$ECHO "$old_archive_from_new_cmds" | $SED "$delay_single_quote_subst"`'
-old_archive_from_expsyms_cmds='`$ECHO "$old_archive_from_expsyms_cmds" | $SED "$delay_single_quote_subst"`'
-archive_cmds='`$ECHO "$archive_cmds" | $SED "$delay_single_quote_subst"`'
-archive_expsym_cmds='`$ECHO "$archive_expsym_cmds" | $SED "$delay_single_quote_subst"`'
-module_cmds='`$ECHO "$module_cmds" | $SED "$delay_single_quote_subst"`'
-module_expsym_cmds='`$ECHO "$module_expsym_cmds" | $SED "$delay_single_quote_subst"`'
-with_gnu_ld='`$ECHO "$with_gnu_ld" | $SED "$delay_single_quote_subst"`'
-allow_undefined_flag='`$ECHO "$allow_undefined_flag" | $SED "$delay_single_quote_subst"`'
-no_undefined_flag='`$ECHO "$no_undefined_flag" | $SED "$delay_single_quote_subst"`'
-hardcode_libdir_flag_spec='`$ECHO "$hardcode_libdir_flag_spec" | $SED "$delay_single_quote_subst"`'
-hardcode_libdir_separator='`$ECHO "$hardcode_libdir_separator" | $SED "$delay_single_quote_subst"`'
-hardcode_direct='`$ECHO "$hardcode_direct" | $SED "$delay_single_quote_subst"`'
-hardcode_direct_absolute='`$ECHO "$hardcode_direct_absolute" | $SED "$delay_single_quote_subst"`'
-hardcode_minus_L='`$ECHO "$hardcode_minus_L" | $SED "$delay_single_quote_subst"`'
-hardcode_shlibpath_var='`$ECHO "$hardcode_shlibpath_var" | $SED "$delay_single_quote_subst"`'
-hardcode_automatic='`$ECHO "$hardcode_automatic" | $SED "$delay_single_quote_subst"`'
-inherit_rpath='`$ECHO "$inherit_rpath" | $SED "$delay_single_quote_subst"`'
-link_all_deplibs='`$ECHO "$link_all_deplibs" | $SED "$delay_single_quote_subst"`'
-always_export_symbols='`$ECHO "$always_export_symbols" | $SED "$delay_single_quote_subst"`'
-export_symbols_cmds='`$ECHO "$export_symbols_cmds" | $SED "$delay_single_quote_subst"`'
-exclude_expsyms='`$ECHO "$exclude_expsyms" | $SED "$delay_single_quote_subst"`'
-include_expsyms='`$ECHO "$include_expsyms" | $SED "$delay_single_quote_subst"`'
-prelink_cmds='`$ECHO "$prelink_cmds" | $SED "$delay_single_quote_subst"`'
-postlink_cmds='`$ECHO "$postlink_cmds" | $SED "$delay_single_quote_subst"`'
-file_list_spec='`$ECHO "$file_list_spec" | $SED "$delay_single_quote_subst"`'
-variables_saved_for_relink='`$ECHO "$variables_saved_for_relink" | $SED "$delay_single_quote_subst"`'
-need_lib_prefix='`$ECHO "$need_lib_prefix" | $SED "$delay_single_quote_subst"`'
-need_version='`$ECHO "$need_version" | $SED "$delay_single_quote_subst"`'
-version_type='`$ECHO "$version_type" | $SED "$delay_single_quote_subst"`'
-runpath_var='`$ECHO "$runpath_var" | $SED "$delay_single_quote_subst"`'
-shlibpath_var='`$ECHO "$shlibpath_var" | $SED "$delay_single_quote_subst"`'
-shlibpath_overrides_runpath='`$ECHO "$shlibpath_overrides_runpath" | $SED "$delay_single_quote_subst"`'
-libname_spec='`$ECHO "$libname_spec" | $SED "$delay_single_quote_subst"`'
-library_names_spec='`$ECHO "$library_names_spec" | $SED "$delay_single_quote_subst"`'
-soname_spec='`$ECHO "$soname_spec" | $SED "$delay_single_quote_subst"`'
-install_override_mode='`$ECHO "$install_override_mode" | $SED "$delay_single_quote_subst"`'
-postinstall_cmds='`$ECHO "$postinstall_cmds" | $SED "$delay_single_quote_subst"`'
-postuninstall_cmds='`$ECHO "$postuninstall_cmds" | $SED "$delay_single_quote_subst"`'
-finish_cmds='`$ECHO "$finish_cmds" | $SED "$delay_single_quote_subst"`'
-finish_eval='`$ECHO "$finish_eval" | $SED "$delay_single_quote_subst"`'
-hardcode_into_libs='`$ECHO "$hardcode_into_libs" | $SED "$delay_single_quote_subst"`'
-sys_lib_search_path_spec='`$ECHO "$sys_lib_search_path_spec" | $SED "$delay_single_quote_subst"`'
-sys_lib_dlsearch_path_spec='`$ECHO "$sys_lib_dlsearch_path_spec" | $SED "$delay_single_quote_subst"`'
-hardcode_action='`$ECHO "$hardcode_action" | $SED "$delay_single_quote_subst"`'
-enable_dlopen='`$ECHO "$enable_dlopen" | $SED "$delay_single_quote_subst"`'
-enable_dlopen_self='`$ECHO "$enable_dlopen_self" | $SED "$delay_single_quote_subst"`'
-enable_dlopen_self_static='`$ECHO "$enable_dlopen_self_static" | $SED "$delay_single_quote_subst"`'
-old_striplib='`$ECHO "$old_striplib" | $SED "$delay_single_quote_subst"`'
-striplib='`$ECHO "$striplib" | $SED "$delay_single_quote_subst"`'
-compiler_lib_search_dirs='`$ECHO "$compiler_lib_search_dirs" | $SED "$delay_single_quote_subst"`'
-predep_objects='`$ECHO "$predep_objects" | $SED "$delay_single_quote_subst"`'
-postdep_objects='`$ECHO "$postdep_objects" | $SED "$delay_single_quote_subst"`'
-predeps='`$ECHO "$predeps" | $SED "$delay_single_quote_subst"`'
-postdeps='`$ECHO "$postdeps" | $SED "$delay_single_quote_subst"`'
-compiler_lib_search_path='`$ECHO "$compiler_lib_search_path" | $SED "$delay_single_quote_subst"`'
-LD_CXX='`$ECHO "$LD_CXX" | $SED "$delay_single_quote_subst"`'
-reload_flag_CXX='`$ECHO "$reload_flag_CXX" | $SED "$delay_single_quote_subst"`'
-reload_cmds_CXX='`$ECHO "$reload_cmds_CXX" | $SED "$delay_single_quote_subst"`'
-old_archive_cmds_CXX='`$ECHO "$old_archive_cmds_CXX" | $SED "$delay_single_quote_subst"`'
-compiler_CXX='`$ECHO "$compiler_CXX" | $SED "$delay_single_quote_subst"`'
-GCC_CXX='`$ECHO "$GCC_CXX" | $SED "$delay_single_quote_subst"`'
-lt_prog_compiler_no_builtin_flag_CXX='`$ECHO "$lt_prog_compiler_no_builtin_flag_CXX" | $SED "$delay_single_quote_subst"`'
-lt_prog_compiler_pic_CXX='`$ECHO "$lt_prog_compiler_pic_CXX" | $SED "$delay_single_quote_subst"`'
-lt_prog_compiler_wl_CXX='`$ECHO "$lt_prog_compiler_wl_CXX" | $SED "$delay_single_quote_subst"`'
-lt_prog_compiler_static_CXX='`$ECHO "$lt_prog_compiler_static_CXX" | $SED "$delay_single_quote_subst"`'
-lt_cv_prog_compiler_c_o_CXX='`$ECHO "$lt_cv_prog_compiler_c_o_CXX" | $SED "$delay_single_quote_subst"`'
-archive_cmds_need_lc_CXX='`$ECHO "$archive_cmds_need_lc_CXX" | $SED "$delay_single_quote_subst"`'
-enable_shared_with_static_runtimes_CXX='`$ECHO "$enable_shared_with_static_runtimes_CXX" | $SED "$delay_single_quote_subst"`'
-export_dynamic_flag_spec_CXX='`$ECHO "$export_dynamic_flag_spec_CXX" | $SED "$delay_single_quote_subst"`'
-whole_archive_flag_spec_CXX='`$ECHO "$whole_archive_flag_spec_CXX" | $SED "$delay_single_quote_subst"`'
-compiler_needs_object_CXX='`$ECHO "$compiler_needs_object_CXX" | $SED "$delay_single_quote_subst"`'
-old_archive_from_new_cmds_CXX='`$ECHO "$old_archive_from_new_cmds_CXX" | $SED "$delay_single_quote_subst"`'
-old_archive_from_expsyms_cmds_CXX='`$ECHO "$old_archive_from_expsyms_cmds_CXX" | $SED "$delay_single_quote_subst"`'
-archive_cmds_CXX='`$ECHO "$archive_cmds_CXX" | $SED "$delay_single_quote_subst"`'
-archive_expsym_cmds_CXX='`$ECHO "$archive_expsym_cmds_CXX" | $SED "$delay_single_quote_subst"`'
-module_cmds_CXX='`$ECHO "$module_cmds_CXX" | $SED "$delay_single_quote_subst"`'
-module_expsym_cmds_CXX='`$ECHO "$module_expsym_cmds_CXX" | $SED "$delay_single_quote_subst"`'
-with_gnu_ld_CXX='`$ECHO "$with_gnu_ld_CXX" | $SED "$delay_single_quote_subst"`'
-allow_undefined_flag_CXX='`$ECHO "$allow_undefined_flag_CXX" | $SED "$delay_single_quote_subst"`'
-no_undefined_flag_CXX='`$ECHO "$no_undefined_flag_CXX" | $SED "$delay_single_quote_subst"`'
-hardcode_libdir_flag_spec_CXX='`$ECHO "$hardcode_libdir_flag_spec_CXX" | $SED "$delay_single_quote_subst"`'
-hardcode_libdir_separator_CXX='`$ECHO "$hardcode_libdir_separator_CXX" | $SED "$delay_single_quote_subst"`'
-hardcode_direct_CXX='`$ECHO "$hardcode_direct_CXX" | $SED "$delay_single_quote_subst"`'
-hardcode_direct_absolute_CXX='`$ECHO "$hardcode_direct_absolute_CXX" | $SED "$delay_single_quote_subst"`'
-hardcode_minus_L_CXX='`$ECHO "$hardcode_minus_L_CXX" | $SED "$delay_single_quote_subst"`'
-hardcode_shlibpath_var_CXX='`$ECHO "$hardcode_shlibpath_var_CXX" | $SED "$delay_single_quote_subst"`'
-hardcode_automatic_CXX='`$ECHO "$hardcode_automatic_CXX" | $SED "$delay_single_quote_subst"`'
-inherit_rpath_CXX='`$ECHO "$inherit_rpath_CXX" | $SED "$delay_single_quote_subst"`'
-link_all_deplibs_CXX='`$ECHO "$link_all_deplibs_CXX" | $SED "$delay_single_quote_subst"`'
-always_export_symbols_CXX='`$ECHO "$always_export_symbols_CXX" | $SED "$delay_single_quote_subst"`'
-export_symbols_cmds_CXX='`$ECHO "$export_symbols_cmds_CXX" | $SED "$delay_single_quote_subst"`'
-exclude_expsyms_CXX='`$ECHO "$exclude_expsyms_CXX" | $SED "$delay_single_quote_subst"`'
-include_expsyms_CXX='`$ECHO "$include_expsyms_CXX" | $SED "$delay_single_quote_subst"`'
-prelink_cmds_CXX='`$ECHO "$prelink_cmds_CXX" | $SED "$delay_single_quote_subst"`'
-postlink_cmds_CXX='`$ECHO "$postlink_cmds_CXX" | $SED "$delay_single_quote_subst"`'
-file_list_spec_CXX='`$ECHO "$file_list_spec_CXX" | $SED "$delay_single_quote_subst"`'
-hardcode_action_CXX='`$ECHO "$hardcode_action_CXX" | $SED "$delay_single_quote_subst"`'
-compiler_lib_search_dirs_CXX='`$ECHO "$compiler_lib_search_dirs_CXX" | $SED "$delay_single_quote_subst"`'
-predep_objects_CXX='`$ECHO "$predep_objects_CXX" | $SED "$delay_single_quote_subst"`'
-postdep_objects_CXX='`$ECHO "$postdep_objects_CXX" | $SED "$delay_single_quote_subst"`'
-predeps_CXX='`$ECHO "$predeps_CXX" | $SED "$delay_single_quote_subst"`'
-postdeps_CXX='`$ECHO "$postdeps_CXX" | $SED "$delay_single_quote_subst"`'
-compiler_lib_search_path_CXX='`$ECHO "$compiler_lib_search_path_CXX" | $SED "$delay_single_quote_subst"`'
-LTCC='$LTCC'
-LTCFLAGS='$LTCFLAGS'
-compiler='$compiler_DEFAULT'
-# A function that is used when there is no print builtin or printf.
-func_fallback_echo ()
- eval 'cat <<_LTECHO_EOF
-\$1
-_LTECHO_EOF'
-# Quote evaled strings.
-for var in SHELL \
-ECHO \
-PATH_SEPARATOR \
-SED \
-GREP \
-EGREP \
-FGREP \
-LD \
-NM \
-LN_S \
-lt_SP2NL \
-lt_NL2SP \
-reload_flag \
-OBJDUMP \
-deplibs_check_method \
-file_magic_cmd \
-file_magic_glob \
-want_nocaseglob \
-DLLTOOL \
-sharedlib_from_linklib_cmd \
-AR \
-AR_FLAGS \
-archiver_list_spec \
-STRIP \
-RANLIB \
-CC \
-CFLAGS \
-compiler \
-lt_cv_sys_global_symbol_pipe \
-lt_cv_sys_global_symbol_to_cdecl \
-lt_cv_sys_global_symbol_to_c_name_address \
-lt_cv_sys_global_symbol_to_c_name_address_lib_prefix \
-nm_file_list_spec \
-lt_prog_compiler_no_builtin_flag \
-lt_prog_compiler_pic \
-lt_prog_compiler_wl \
-lt_prog_compiler_static \
-lt_cv_prog_compiler_c_o \
-need_locks \
-MANIFEST_TOOL \
-DSYMUTIL \
-NMEDIT \
-LIPO \
-OTOOL \
-OTOOL64 \
-shrext_cmds \
-export_dynamic_flag_spec \
-whole_archive_flag_spec \
-compiler_needs_object \
-with_gnu_ld \
-allow_undefined_flag \
-no_undefined_flag \
-hardcode_libdir_flag_spec \
-hardcode_libdir_separator \
-exclude_expsyms \
-include_expsyms \
-file_list_spec \
-variables_saved_for_relink \
-libname_spec \
-library_names_spec \
-soname_spec \
-install_override_mode \
-finish_eval \
-old_striplib \
-striplib \
-compiler_lib_search_dirs \
-predep_objects \
-postdep_objects \
-predeps \
-postdeps \
-compiler_lib_search_path \
-LD_CXX \
-reload_flag_CXX \
-compiler_CXX \
-lt_prog_compiler_no_builtin_flag_CXX \
-lt_prog_compiler_pic_CXX \
-lt_prog_compiler_wl_CXX \
-lt_prog_compiler_static_CXX \
-lt_cv_prog_compiler_c_o_CXX \
-export_dynamic_flag_spec_CXX \
-whole_archive_flag_spec_CXX \
-compiler_needs_object_CXX \
-with_gnu_ld_CXX \
-allow_undefined_flag_CXX \
-no_undefined_flag_CXX \
-hardcode_libdir_flag_spec_CXX \
-hardcode_libdir_separator_CXX \
-exclude_expsyms_CXX \
-include_expsyms_CXX \
-file_list_spec_CXX \
-compiler_lib_search_dirs_CXX \
-predep_objects_CXX \
-postdep_objects_CXX \
-predeps_CXX \
-postdeps_CXX \
-compiler_lib_search_path_CXX; do
- case \`eval \\\\\$ECHO \\\\""\\\\\$\$var"\\\\"\` in
- eval "lt_\$var=\\\\\\"\\\`\\\$ECHO \\"\\\$\$var\\" | \\\$SED \\"\\\$sed_quote_subst\\"\\\`\\\\\\""
- eval "lt_\$var=\\\\\\"\\\$\$var\\\\\\""
- esac
-done
-# Double-quote double-evaled strings.
-for var in reload_cmds \
-old_postinstall_cmds \
-old_postuninstall_cmds \
-old_archive_cmds \
-extract_expsyms_cmds \
-old_archive_from_new_cmds \
-old_archive_from_expsyms_cmds \
-archive_cmds \
-archive_expsym_cmds \
-module_cmds \
-module_expsym_cmds \
-export_symbols_cmds \
-prelink_cmds \
-postlink_cmds \
-postinstall_cmds \
-postuninstall_cmds \
-finish_cmds \
-sys_lib_search_path_spec \
-sys_lib_dlsearch_path_spec \
-reload_cmds_CXX \
-old_archive_cmds_CXX \
-old_archive_from_new_cmds_CXX \
-old_archive_from_expsyms_cmds_CXX \
-archive_cmds_CXX \
-archive_expsym_cmds_CXX \
-module_cmds_CXX \
-module_expsym_cmds_CXX \
-export_symbols_cmds_CXX \
-prelink_cmds_CXX \
-postlink_cmds_CXX; do
- eval "lt_\$var=\\\\\\"\\\`\\\$ECHO \\"\\\$\$var\\" | \\\$SED -e \\"\\\$double_quote_subst\\" -e \\"\\\$sed_quote_subst\\" -e \\"\\\$delay_variable_subst\\"\\\`\\\\\\""
- esac
-done
-ac_aux_dir='$ac_aux_dir'
-xsi_shell='$xsi_shell'
-lt_shell_append='$lt_shell_append'
-# See if we are running on zsh, and set the options which allow our
-# commands through without removal of \ escapes INIT.
-if test -n "\${ZSH_VERSION+set}" ; then
-fi
- PACKAGE='$PACKAGE'
- VERSION='$VERSION'
- TIMESTAMP='$TIMESTAMP'
- RM='$RM'
- ofile='$ofile'
-_ACEOF
-# Handling of arguments.
-for ac_config_target in $ac_config_targets
-do
- case $ac_config_target in
- "depfiles") CONFIG_COMMANDS="$CONFIG_COMMANDS depfiles" ;;
- "libtool") CONFIG_COMMANDS="$CONFIG_COMMANDS libtool" ;;
- "Makefile") CONFIG_FILES="$CONFIG_FILES Makefile" ;;
- "src/Makefile") CONFIG_FILES="$CONFIG_FILES src/Makefile" ;;
- *) as_fn_error $? "invalid argument: \`$ac_config_target'" "$LINENO" 5;;
- esac
-done
-# If the user did not use the arguments to specify the items to instantiate,
-# then the envvar interface is used. Set only those that are not.
-# We use the long form for the default assignment because of an extremely
-# bizarre bug on SunOS 4.1.3.
-if $ac_need_defaults; then
- test "${CONFIG_FILES+set}" = set || CONFIG_FILES=$config_files
- test "${CONFIG_COMMANDS+set}" = set || CONFIG_COMMANDS=$config_commands
-fi
-# Have a temporary directory for convenience. Make it in the build tree
-# simply because there is no reason against having it here, and in addition,
-# creating and moving files from /tmp can sometimes cause problems.
-# Hook for its removal unless debugging.
-# Note that there is a small window in which the directory will not be cleaned:
-# after its creation but before its name has been assigned to `$tmp'.
-$debug ||
- tmp= ac_tmp=
- trap 'exit_status=$?
- : "${ac_tmp:=$tmp}"
- { test ! -d "$ac_tmp" || rm -fr "$ac_tmp"; } && exit $exit_status
-' 0
- trap 'as_fn_exit 1' 1 2 13 15
-# Create a (secure) tmp directory for tmp files.
- tmp=`(umask 077 && mktemp -d "./confXXXXXX") 2>/dev/null` &&
- test -d "$tmp"
- tmp=./conf$$-$RANDOM
- (umask 077 && mkdir "$tmp")
-} || as_fn_error $? "cannot create a temporary directory in ." "$LINENO" 5
-ac_tmp=$tmp
-# Set up the scripts for CONFIG_FILES section.
-# No need to generate them if there are no CONFIG_FILES.
-# This happens for instance with `./config.status config.h'.
-if test -n "$CONFIG_FILES"; then
-ac_cr=`echo X | tr X '\015'`
-# On cygwin, bash can eat \r inside `` if the user requested igncr.
-# But we know of no other shell where ac_cr would be empty at this
-# point, so we can use a bashism as a fallback.
-if test "x$ac_cr" = x; then
- eval ac_cr=\$\'\\r\'
-fi
-ac_cs_awk_cr=`$AWK 'BEGIN { print "a\rb" }' </dev/null 2>/dev/null`
-if test "$ac_cs_awk_cr" = "a${ac_cr}b"; then
- ac_cs_awk_cr='\\r'
-else
- ac_cs_awk_cr=$ac_cr
-fi
-echo 'BEGIN {' >"$ac_tmp/subs1.awk" &&
-_ACEOF
- echo "cat >conf$$subs.awk <<_ACEOF" &&
- echo "$ac_subst_vars" | sed 's/.*/&!$&$ac_delim/' &&
- echo "_ACEOF"
-} >conf$$subs.sh ||
- as_fn_error $? "could not make $CONFIG_STATUS" "$LINENO" 5
-ac_delim_num=`echo "$ac_subst_vars" | grep -c '^'`
-ac_delim='%!_!# '
-for ac_last_try in false false false false false :; do
- . ./conf$$subs.sh ||
- ac_delim_n=`sed -n "s/.*$ac_delim\$/X/p" conf$$subs.awk | grep -c X`
- if test $ac_delim_n = $ac_delim_num; then
- break
- elif $ac_last_try; then
- else
- ac_delim="$ac_delim!$ac_delim _$ac_delim!! "
- fi
-done
-rm -f conf$$subs.sh
-cat >>"\$ac_tmp/subs1.awk" <<\\_ACAWK &&
-_ACEOF
-sed -n '
-h
-s/^/S["/; s/!.*/"]=/
-p
-g
-s/^[^!]*!//
-:repl
-t repl
-s/'"$ac_delim"'$//
-t delim
-:nl
-h
-s/\(.\{148\}\)..*/\1/
-t more1
-s/["\\]/\\&/g; s/^/"/; s/$/\\n"\\/
-p
-n
-b repl
-:more1
-s/["\\]/\\&/g; s/^/"/; s/$/"\\/
-p
-g
-s/.\{148\}//
-t nl
-:delim
-h
-t more2
-s/["\\]/\\&/g; s/^/"/; s/$/"/
-p
-b
-:more2
-p
-g
-s/.\{148\}//
-t delim
-' <conf$$subs.awk | sed '
- N
- s/\n//
-' >>$CONFIG_STATUS || ac_write_fail=1
-rm -f conf$$subs.awk
-_ACAWK
-cat >>"\$ac_tmp/subs1.awk" <<_ACAWK &&
- for (key in S) S_is_set[key] = 1
- FS = ""
- line = $ 0
- nfields = split(line, field, "@")
- substed = 0
- len = length(field[1])
- for (i = 2; i < nfields; i++) {
- key = field[i]
- keylen = length(key)
- if (S_is_set[key]) {
- value = S[key]
- line = substr(line, 1, len) "" value "" substr(line, len + keylen + 3)
- len += length(value) + length(field[++i])
- substed = 1
- } else
- len += 1 + keylen
- print line
-_ACAWK
-_ACEOF
-if sed "s/$ac_cr//" < /dev/null > /dev/null 2>&1; then
- sed "s/$ac_cr\$//; s/$ac_cr/$ac_cs_awk_cr/g"
-else
- cat
-fi < "$ac_tmp/subs1.awk" > "$ac_tmp/subs.awk" \
- || as_fn_error $? "could not setup config files machinery" "$LINENO" 5
-_ACEOF
-# VPATH may cause trouble with some makes, so we remove sole $(srcdir),
-# ${srcdir} and @srcdir@ entries from VPATH if srcdir is ".", strip leading and
-# trailing colons and then remove the whole line if VPATH becomes empty
-# (actually we leave an empty line to preserve line numbers).
-if test "x$srcdir" = x.; then
- ac_vpsub='/^[ ]*VPATH[ ]*=[ ]*/{
-h
-s///
-s/^/:/
-s/[ ]*$/:/
-s/:\$(srcdir):/:/g
-s/:\${srcdir}:/:/g
-s/:@srcdir@:/:/g
-s/^:*//
-s/:*$//
-x
-s/\(=[ ]*\).*/\1/
-G
-s/\n//
-s/^[^=]*=[ ]*$//
-fi
-fi # test -n "$CONFIG_FILES"
-eval set X " :F $CONFIG_FILES :C $CONFIG_COMMANDS"
-shift
-for ac_tag
-do
- case $ac_tag in
- :[FHLC]) ac_mode=$ac_tag; continue;;
- esac
- case $ac_mode$ac_tag in
- :[FHL]*:*);;
- :L* | :C*:*) as_fn_error $? "invalid tag \`$ac_tag'" "$LINENO" 5;;
- :[FH]-) ac_tag=-:-;;
- :[FH]*) ac_tag=$ac_tag:$ac_tag.in;;
- esac
- ac_save_IFS=$IFS
- IFS=:
- set x $ac_tag
- IFS=$ac_save_IFS
- shift
- ac_file=$1
- shift
- case $ac_mode in
- :L) ac_source=$1;;
- :[FH])
- ac_file_inputs=
- for ac_f
- do
- case $ac_f in
- -) ac_f="$ac_tmp/stdin";;
- *) # Look for the file first in the build tree, then in the source tree
- # (if the path is not absolute). The absolute path cannot be DOS-style,
- # because $ac_f cannot contain `:'.
- test -f "$ac_f" ||
- case $ac_f in
- [\\/$]*) false;;
- *) test -f "$srcdir/$ac_f" && ac_f="$srcdir/$ac_f";;
- esac ||
- as_fn_error 1 "cannot find input file: \`$ac_f'" "$LINENO" 5;;
- esac
- case $ac_f in *\'*) ac_f=`$as_echo "$ac_f" | sed "s/'/'\\\\\\\\''/g"`;; esac
- as_fn_append ac_file_inputs " '$ac_f'"
- done
- # Let's still pretend it is `configure' which instantiates (i.e., don't
- # use $as_me), people would be surprised to read:
- # /* config.h. Generated by config.status. */
- configure_input='Generated from '`
- $as_echo "$*" | sed 's|^[^:]*/||;s|:[^:]*/|, |g'
- `' by configure.'
- if test x"$ac_file" != x-; then
- configure_input="$ac_file. $configure_input"
- { $as_echo "$as_me:${as_lineno-$LINENO}: creating $ac_file" >&5
-$as_echo "$as_me: creating $ac_file" >&6;}
- fi
- # Neutralize special characters interpreted by sed in replacement strings.
- case $configure_input in #(
- ac_sed_conf_input=`$as_echo "$configure_input" |
- sed 's/[\\\\&|]/\\\\&/g'`;; #(
- *) ac_sed_conf_input=$configure_input;;
- esac
- case $ac_tag in
- *:-:* | *:-) cat >"$ac_tmp/stdin" \
- || as_fn_error $? "could not create $ac_file" "$LINENO" 5 ;;
- esac
- esac
- ac_dir=`$as_dirname -- "$ac_file" ||
-$as_expr X"$ac_file" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$ac_file" : 'X\(//\)[^/]' \| \
- X"$ac_file" : 'X\(//\)$' \| \
- X"$ac_file" : 'X\(/\)' \| . 2>/dev/null ||
-$as_echo X"$ac_file" |
- s//\1/
- q
- s//\1/
- q
- /^X\(\/\/\)$/{
- s//\1/
- q
- /^X\(\/\).*/{
- s//\1/
- q
- s/.*/./; q'`
- as_dir="$ac_dir"; as_fn_mkdir_p
- ac_builddir=.
-case "$ac_dir" in
-.) ac_dir_suffix= ac_top_builddir_sub=. ac_top_build_prefix= ;;
- ac_dir_suffix=/`$as_echo "$ac_dir" | sed 's|^\.[\\/]||'`
- # A ".." for each directory in $ac_dir_suffix.
- ac_top_builddir_sub=`$as_echo "$ac_dir_suffix" | sed 's|/[^\\/]*|/..|g;s|/||'`
- case $ac_top_builddir_sub in
- "") ac_top_builddir_sub=. ac_top_build_prefix= ;;
- *) ac_top_build_prefix=$ac_top_builddir_sub/ ;;
- esac ;;
-esac
-ac_abs_top_builddir=$ac_pwd
-ac_abs_builddir=$ac_pwd$ac_dir_suffix
-# for backward compatibility:
-ac_top_builddir=$ac_top_build_prefix
-case $srcdir in
- .) # We are building in place.
- ac_srcdir=.
- ac_top_srcdir=$ac_top_builddir_sub
- ac_abs_top_srcdir=$ac_pwd ;;
- [\\/]* | ?:[\\/]* ) # Absolute name.
- ac_srcdir=$srcdir$ac_dir_suffix;
- ac_top_srcdir=$srcdir
- ac_abs_top_srcdir=$srcdir ;;
- *) # Relative name.
- ac_srcdir=$ac_top_build_prefix$srcdir$ac_dir_suffix
- ac_top_srcdir=$ac_top_build_prefix$srcdir
- ac_abs_top_srcdir=$ac_pwd/$srcdir ;;
-esac
-ac_abs_srcdir=$ac_abs_top_srcdir$ac_dir_suffix
- case $ac_mode in
- :F)
- # CONFIG_FILE
- case $INSTALL in
- [\\/$]* | ?:[\\/]* ) ac_INSTALL=$INSTALL ;;
- *) ac_INSTALL=$ac_top_build_prefix$INSTALL ;;
- esac
- ac_MKDIR_P=$MKDIR_P
- case $MKDIR_P in
- */*) ac_MKDIR_P=$ac_top_build_prefix$MKDIR_P ;;
- esac
-_ACEOF
-# If the template does not know about datarootdir, expand it.
-# FIXME: This hack should be removed a few years after 2.60.
-ac_datarootdir_hack=; ac_datarootdir_seen=
-ac_sed_dataroot='
-/datarootdir/ {
- p
- q
-/@datadir@/p
-/@docdir@/p
-/@infodir@/p
-/@localedir@/p
-/@mandir@/p'
-case `eval "sed -n \"\$ac_sed_dataroot\" $ac_file_inputs"` in
-*datarootdir*) ac_datarootdir_seen=yes;;
-*@datadir@*|*@docdir@*|*@infodir@*|*@localedir@*|*@mandir@*)
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&5
-$as_echo "$as_me: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&2;}
-_ACEOF
- ac_datarootdir_hack='
- s&@datadir@&$datadir&g
- s&@docdir@&$docdir&g
- s&@infodir@&$infodir&g
- s&@localedir@&$localedir&g
- s&@mandir@&$mandir&g
- s&\\\${datarootdir}&$datarootdir&g' ;;
-esac
-_ACEOF
-# Neutralize VPATH when `$srcdir' = `.'.
-# Shell code in configure.ac might set extrasub.
-# FIXME: do we really want to maintain this feature?
-ac_sed_extra="$ac_vpsub
-$extrasub
-_ACEOF
-:t
-/@[a-zA-Z_][a-zA-Z_0-9]*@/!b
-s|@configure_input@|$ac_sed_conf_input|;t t
-s&@top_builddir@&$ac_top_builddir_sub&;t t
-s&@top_build_prefix@&$ac_top_build_prefix&;t t
-s&@srcdir@&$ac_srcdir&;t t
-s&@abs_srcdir@&$ac_abs_srcdir&;t t
-s&@top_srcdir@&$ac_top_srcdir&;t t
-s&@abs_top_srcdir@&$ac_abs_top_srcdir&;t t
-s&@builddir@&$ac_builddir&;t t
-s&@abs_builddir@&$ac_abs_builddir&;t t
-s&@abs_top_builddir@&$ac_abs_top_builddir&;t t
-s&@INSTALL@&$ac_INSTALL&;t t
-s&@MKDIR_P@&$ac_MKDIR_P&;t t
-$ac_datarootdir_hack
-eval sed \"\$ac_sed_extra\" "$ac_file_inputs" | $AWK -f "$ac_tmp/subs.awk" \
- >$ac_tmp/out || as_fn_error $? "could not create $ac_file" "$LINENO" 5
-test -z "$ac_datarootdir_hack$ac_datarootdir_seen" &&
- { ac_out=`sed -n '/\${datarootdir}/p' "$ac_tmp/out"`; test -n "$ac_out"; } &&
- { ac_out=`sed -n '/^[ ]*datarootdir[ ]*:*=/p' \
- "$ac_tmp/out"`; test -z "$ac_out"; } &&
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $ac_file contains a reference to the variable \`datarootdir'
-which seems to be undefined. Please make sure it is defined" >&5
-$as_echo "$as_me: WARNING: $ac_file contains a reference to the variable \`datarootdir'
-which seems to be undefined. Please make sure it is defined" >&2;}
- rm -f "$ac_tmp/stdin"
- case $ac_file in
- -) cat "$ac_tmp/out" && rm -f "$ac_tmp/out";;
- *) rm -f "$ac_file" && mv "$ac_tmp/out" "$ac_file";;
- esac \
- :C) { $as_echo "$as_me:${as_lineno-$LINENO}: executing $ac_file commands" >&5
-$as_echo "$as_me: executing $ac_file commands" >&6;}
- esac
- case $ac_file$ac_mode in
- "depfiles":C) test x"$AMDEP_TRUE" != x"" || {
- # Autoconf 2.62 quotes --file arguments for eval, but not when files
- # are listed without --file. Let's play safe and only enable the eval
- # if we detect the quoting.
- case $CONFIG_FILES in
- *\'*) eval set x "$CONFIG_FILES" ;;
- *) set x $CONFIG_FILES ;;
- esac
- shift
- for mf
- do
- # Strip MF so we end up with the name of the file.
- mf=`echo "$mf" | sed -e 's/:.*$//'`
- # Check whether this is an Automake generated Makefile or not.
- # We used to match only the files named `Makefile.in', but
- # some people rename them; so instead we look at the file content.
- # Grep'ing the first line is not enough: some people post-process
- # each Makefile.in and add a new line on top of each file to say so.
- # Grep'ing the whole file is not good either: AIX grep has a line
- # limit of 2048, but all sed's we know have understand at least 4000.
- if sed -n 's,^#.*generated by automake.*,X,p' "$mf" | grep X >/dev/null 2>&1; then
- dirpart=`$as_dirname -- "$mf" ||
-$as_expr X"$mf" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$mf" : 'X\(//\)[^/]' \| \
- X"$mf" : 'X\(//\)$' \| \
- X"$mf" : 'X\(/\)' \| . 2>/dev/null ||
-$as_echo X"$mf" |
- s//\1/
- q
- s//\1/
- q
- /^X\(\/\/\)$/{
- s//\1/
- q
- /^X\(\/\).*/{
- s//\1/
- q
- s/.*/./; q'`
- else
- continue
- fi
- # Extract the definition of DEPDIR, am__include, and am__quote
- # from the Makefile without running `make'.
- DEPDIR=`sed -n 's/^DEPDIR = //p' < "$mf"`
- test -z "$DEPDIR" && continue
- am__include=`sed -n 's/^am__include = //p' < "$mf"`
- test -z "am__include" && continue
- am__quote=`sed -n 's/^am__quote = //p' < "$mf"`
- # When using ansi2knr, U may be empty or an underscore; expand it
- U=`sed -n 's/^U = //p' < "$mf"`
- # Find all dependency output files, they are included files with
- # $(DEPDIR) in their names. We invoke sed twice because it is the
- # simplest approach to changing $(DEPDIR) to its actual value in the
- # expansion.
- for file in `sed -n "
- s/^$am__include $am__quote\(.*(DEPDIR).*\)$am__quote"'$/\1/p' <"$mf" | \
- sed -e 's/\$(DEPDIR)/'"$DEPDIR"'/g' -e 's/\$U/'"$U"'/g'`; do
- # Make sure the directory exists.
- test -f "$dirpart/$file" && continue
- fdir=`$as_dirname -- "$file" ||
-$as_expr X"$file" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$file" : 'X\(//\)[^/]' \| \
- X"$file" : 'X\(//\)$' \| \
- X"$file" : 'X\(/\)' \| . 2>/dev/null ||
-$as_echo X"$file" |
- s//\1/
- q
- s//\1/
- q
- /^X\(\/\/\)$/{
- s//\1/
- q
- /^X\(\/\).*/{
- s//\1/
- q
- s/.*/./; q'`
- as_dir=$dirpart/$fdir; as_fn_mkdir_p
- # echo "creating $dirpart/$file"
- echo '# dummy' > "$dirpart/$file"
- done
- done
- "libtool":C)
- # See if we are running on zsh, and set the options which allow our
- # commands through without removal of \ escapes.
- if test -n "${ZSH_VERSION+set}" ; then
- fi
- cfgfile="${ofile}T"
- trap "$RM \"$cfgfile\"; exit 1" 1 2 15
- $RM "$cfgfile"
- cat <<_LT_EOF >> "$cfgfile"
-#! $SHELL
-# `$ECHO "$ofile" | sed 's%^.*/%%'` - Provide generalized library-building support services.
-# Generated automatically by $as_me ($PACKAGE$TIMESTAMP) $VERSION
-# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
-# NOTE: Changes made to this file will be lost: look at ltmain.sh.
-# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001, 2003, 2004, 2005,
-# 2006, 2007, 2008, 2009, 2010, 2011 Free Software
-# Foundation, Inc.
-# Written by Gordon Matzigkeit, 1996
-# This file is part of GNU Libtool.
-# GNU Libtool is free software; you can redistribute it and/or
-# modify it under the terms of the GNU General Public License as
-# published by the Free Software Foundation; either version 2 of
-# the License, or (at your option) any later version.
-# As a special exception to the GNU General Public License,
-# if you distribute this file as part of a program or library that
-# is built using GNU Libtool, you may include this file under the
-# same distribution terms that you use for the rest of that program.
-# GNU Libtool is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with GNU Libtool; see the file COPYING. If not, a copy
-# can be downloaded from http://www.gnu.org/licenses/gpl.html, or
-# obtained by writing to the Free Software Foundation, Inc.,
-# 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
-# The names of the tagged configurations supported by this script.
-available_tags="CXX "
-# ### BEGIN LIBTOOL CONFIG
-# Which release of libtool.m4 was used?
-macro_version=$macro_version
-macro_revision=$macro_revision
-# Whether or not to build shared libraries.
-build_libtool_libs=$enable_shared
-# Whether or not to build static libraries.
-build_old_libs=$enable_static
-# What type of objects to build.
-pic_mode=$pic_mode
-# Whether or not to optimize for fast installation.
-fast_install=$enable_fast_install
-# Shell to use when invoking shell scripts.
-SHELL=$lt_SHELL
-# An echo program that protects backslashes.
-ECHO=$lt_ECHO
-# The PATH separator for the build system.
-PATH_SEPARATOR=$lt_PATH_SEPARATOR
-# The host system.
-host_alias=$host_alias
-host=$host
-host_os=$host_os
-# The build system.
-build_alias=$build_alias
-build=$build
-build_os=$build_os
-# A sed program that does not truncate output.
-SED=$lt_SED
-# Sed that helps us avoid accidentally triggering echo(1) options like -n.
-Xsed="\$SED -e 1s/^X//"
-# A grep program that handles long lines.
-GREP=$lt_GREP
-# An ERE matcher.
-EGREP=$lt_EGREP
-# A literal string matcher.
-FGREP=$lt_FGREP
-# A BSD- or MS-compatible name lister.
-NM=$lt_NM
-# Whether we need soft or hard links.
-LN_S=$lt_LN_S
-# What is the maximum length of a command?
-max_cmd_len=$max_cmd_len
-# Object file suffix (normally "o").
-objext=$ac_objext
-# Executable file suffix (normally "").
-exeext=$exeext
-# whether the shell understands "unset".
-lt_unset=$lt_unset
-# turn spaces into newlines.
-SP2NL=$lt_lt_SP2NL
-# turn newlines into spaces.
-NL2SP=$lt_lt_NL2SP
-# convert \$build file names to \$host format.
-to_host_file_cmd=$lt_cv_to_host_file_cmd
-# convert \$build files to toolchain format.
-to_tool_file_cmd=$lt_cv_to_tool_file_cmd
-# An object symbol dumper.
-OBJDUMP=$lt_OBJDUMP
-# Method to check whether dependent libraries are shared objects.
-deplibs_check_method=$lt_deplibs_check_method
-# Command to use when deplibs_check_method = "file_magic".
-file_magic_cmd=$lt_file_magic_cmd
-# How to find potential files when deplibs_check_method = "file_magic".
-file_magic_glob=$lt_file_magic_glob
-# Find potential files using nocaseglob when deplibs_check_method = "file_magic".
-want_nocaseglob=$lt_want_nocaseglob
-# DLL creation program.
-DLLTOOL=$lt_DLLTOOL
-# Command to associate shared and link libraries.
-sharedlib_from_linklib_cmd=$lt_sharedlib_from_linklib_cmd
-# The archiver.
-AR=$lt_AR
-# Flags to create an archive.
-AR_FLAGS=$lt_AR_FLAGS
-# How to feed a file listing to the archiver.
-archiver_list_spec=$lt_archiver_list_spec
-# A symbol stripping program.
-STRIP=$lt_STRIP
-# Commands used to install an old-style archive.
-RANLIB=$lt_RANLIB
-old_postinstall_cmds=$lt_old_postinstall_cmds
-old_postuninstall_cmds=$lt_old_postuninstall_cmds
-# Whether to use a lock for old archive extraction.
-lock_old_archive_extraction=$lock_old_archive_extraction
-# A C compiler.
-LTCC=$lt_CC
-# LTCC compiler flags.
-LTCFLAGS=$lt_CFLAGS
-# Take the output of nm and produce a listing of raw symbols and C names.
-global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
-# Transform the output of nm in a proper C declaration.
-global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
-# Transform the output of nm in a C name address pair.
-global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
-# Transform the output of nm in a C name address pair when lib prefix is needed.
-global_symbol_to_c_name_address_lib_prefix=$lt_lt_cv_sys_global_symbol_to_c_name_address_lib_prefix
-# Specify filename containing input files for \$NM.
-nm_file_list_spec=$lt_nm_file_list_spec
-# The root where to search for dependent libraries,and in which our libraries should be installed.
-lt_sysroot=$lt_sysroot
-# The name of the directory that contains temporary libtool files.
-objdir=$objdir
-# Used to examine libraries when file_magic_cmd begins with "file".
-MAGIC_CMD=$MAGIC_CMD
-# Must we lock files when doing compilation?
-need_locks=$lt_need_locks
-# Manifest tool.
-MANIFEST_TOOL=$lt_MANIFEST_TOOL
-# Tool to manipulate archived DWARF debug symbol files on Mac OS X.
-DSYMUTIL=$lt_DSYMUTIL
-# Tool to change global to local symbols on Mac OS X.
-NMEDIT=$lt_NMEDIT
-# Tool to manipulate fat objects and archives on Mac OS X.
-LIPO=$lt_LIPO
-# ldd/readelf like tool for Mach-O binaries on Mac OS X.
-OTOOL=$lt_OTOOL
-# ldd/readelf like tool for 64 bit Mach-O binaries on Mac OS X 10.4.
-OTOOL64=$lt_OTOOL64
-# Old archive suffix (normally "a").
-libext=$libext
-# Shared library suffix (normally ".so").
-shrext_cmds=$lt_shrext_cmds
-# The commands to extract the exported symbol list from a shared archive.
-extract_expsyms_cmds=$lt_extract_expsyms_cmds
-# Variables whose values should be saved in libtool wrapper scripts and
-# restored at link time.
-variables_saved_for_relink=$lt_variables_saved_for_relink
-# Do we need the "lib" prefix for modules?
-need_lib_prefix=$need_lib_prefix
-# Do we need a version for libraries?
-need_version=$need_version
-# Library versioning type.
-version_type=$version_type
-# Shared library runtime path variable.
-runpath_var=$runpath_var
-# Shared library path variable.
-shlibpath_var=$shlibpath_var
-# Is shlibpath searched before the hard-coded library search path?
-shlibpath_overrides_runpath=$shlibpath_overrides_runpath
-# Format of library name prefix.
-libname_spec=$lt_libname_spec
-# List of archive names. First name is the real one, the rest are links.
-# The last name is the one that the linker finds with -lNAME
-library_names_spec=$lt_library_names_spec
-# The coded name of the library, if different from the real name.
-soname_spec=$lt_soname_spec
-# Permission mode override for installation of shared libraries.
-install_override_mode=$lt_install_override_mode
-# Command to use after installation of a shared archive.
-postinstall_cmds=$lt_postinstall_cmds
-# Command to use after uninstallation of a shared archive.
-postuninstall_cmds=$lt_postuninstall_cmds
-# Commands used to finish a libtool library installation in a directory.
-finish_cmds=$lt_finish_cmds
-# As "finish_cmds", except a single script fragment to be evaled but
-# not shown.
-finish_eval=$lt_finish_eval
-# Whether we should hardcode library paths into libraries.
-hardcode_into_libs=$hardcode_into_libs
-# Compile-time system search path for libraries.
-sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
-# Run-time system search path for libraries.
-sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
-# Whether dlopen is supported.
-dlopen_support=$enable_dlopen
-# Whether dlopen of programs is supported.
-dlopen_self=$enable_dlopen_self
-# Whether dlopen of statically linked programs is supported.
-dlopen_self_static=$enable_dlopen_self_static
-# Commands to strip libraries.
-old_striplib=$lt_old_striplib
-striplib=$lt_striplib
-# The linker used to build libraries.
-LD=$lt_LD
-# How to create reloadable object files.
-reload_flag=$lt_reload_flag
-reload_cmds=$lt_reload_cmds
-# Commands used to build an old-style archive.
-old_archive_cmds=$lt_old_archive_cmds
-# A language specific compiler.
-CC=$lt_compiler
-# Is the compiler the GNU compiler?
-with_gcc=$GCC
-# Compiler flag to turn off builtin functions.
-no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag
-# Additional compiler flags for building library objects.
-pic_flag=$lt_lt_prog_compiler_pic
-# How to pass a linker flag through the compiler.
-wl=$lt_lt_prog_compiler_wl
-# Compiler flag to prevent dynamic linking.
-link_static_flag=$lt_lt_prog_compiler_static
-# Does compiler simultaneously support -c and -o options?
-compiler_c_o=$lt_lt_cv_prog_compiler_c_o
-# Whether or not to add -lc for building shared libraries.
-build_libtool_need_lc=$archive_cmds_need_lc
-# Whether or not to disallow shared libs when runtime libs are static.
-allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes
-# Compiler flag to allow reflexive dlopens.
-export_dynamic_flag_spec=$lt_export_dynamic_flag_spec
-# Compiler flag to generate shared objects directly from archives.
-whole_archive_flag_spec=$lt_whole_archive_flag_spec
-# Whether the compiler copes with passing no objects directly.
-compiler_needs_object=$lt_compiler_needs_object
-# Create an old-style archive from a shared archive.
-old_archive_from_new_cmds=$lt_old_archive_from_new_cmds
-# Create a temporary old-style archive to link instead of a shared archive.
-old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds
-# Commands used to build a shared archive.
-archive_cmds=$lt_archive_cmds
-archive_expsym_cmds=$lt_archive_expsym_cmds
-# Commands used to build a loadable module if different from building
-# a shared archive.
-module_cmds=$lt_module_cmds
-module_expsym_cmds=$lt_module_expsym_cmds
-# Whether we are building with GNU ld or not.
-with_gnu_ld=$lt_with_gnu_ld
-# Flag that allows shared libraries with undefined symbols to be built.
-allow_undefined_flag=$lt_allow_undefined_flag
-# Flag that enforces no undefined symbols.
-no_undefined_flag=$lt_no_undefined_flag
-# Flag to hardcode \$libdir into a binary during linking.
-# This must work even if \$libdir does not exist
-hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec
-# Whether we need a single "-rpath" flag with a separated argument.
-hardcode_libdir_separator=$lt_hardcode_libdir_separator
-# Set to "yes" if using DIR/libNAME\${shared_ext} during linking hardcodes
-# DIR into the resulting binary.
-hardcode_direct=$hardcode_direct
-# DIR into the resulting binary and the resulting library dependency is
-# "absolute",i.e impossible to change by setting \${shlibpath_var} if the
-# library is relocated.
-hardcode_direct_absolute=$hardcode_direct_absolute
-# Set to "yes" if using the -LDIR flag during linking hardcodes DIR
-# into the resulting binary.
-hardcode_minus_L=$hardcode_minus_L
-# Set to "yes" if using SHLIBPATH_VAR=DIR during linking hardcodes DIR
-hardcode_shlibpath_var=$hardcode_shlibpath_var
-# Set to "yes" if building a shared library automatically hardcodes DIR
-# into the library and all subsequent libraries and executables linked
-# against it.
-hardcode_automatic=$hardcode_automatic
-# Set to yes if linker adds runtime paths of dependent libraries
-# to runtime path list.
-inherit_rpath=$inherit_rpath
-# Whether libtool must link a program against all its dependency libraries.
-link_all_deplibs=$link_all_deplibs
-# Set to "yes" if exported symbols are required.
-always_export_symbols=$always_export_symbols
-# The commands to list exported symbols.
-export_symbols_cmds=$lt_export_symbols_cmds
-# Symbols that should not be listed in the preloaded symbols.
-exclude_expsyms=$lt_exclude_expsyms
-# Symbols that must always be exported.
-include_expsyms=$lt_include_expsyms
-# Commands necessary for linking programs (against libraries) with templates.
-prelink_cmds=$lt_prelink_cmds
-# Commands necessary for finishing linking programs.
-postlink_cmds=$lt_postlink_cmds
-# Specify filename containing input files.
-file_list_spec=$lt_file_list_spec
-# How to hardcode a shared library path into an executable.
-hardcode_action=$hardcode_action
-# The directories searched by this compiler when creating a shared library.
-compiler_lib_search_dirs=$lt_compiler_lib_search_dirs
-# Dependencies to place before and after the objects being linked to
-# create a shared library.
-predep_objects=$lt_predep_objects
-postdep_objects=$lt_postdep_objects
-predeps=$lt_predeps
-postdeps=$lt_postdeps
-# The library search path used internally by the compiler when linking
-# a shared library.
-compiler_lib_search_path=$lt_compiler_lib_search_path
-# ### END LIBTOOL CONFIG
-_LT_EOF
- case $host_os in
- aix3*)
- cat <<\_LT_EOF >> "$cfgfile"
-# AIX sometimes has problems with the GCC collect2 program. For some
-# reason, if we set the COLLECT_NAMES environment variable, the problems
-# vanish in a puff of smoke.
-if test "X${COLLECT_NAMES+set}" != Xset; then
- COLLECT_NAMES=
- export COLLECT_NAMES
-fi
-_LT_EOF
- esac
-ltmain="$ac_aux_dir/ltmain.sh"
- # We use sed instead of cat because bash on DJGPP gets confused if
- # if finds mixed CR/LF and LF-only lines. Since sed operates in
- # text mode, it properly converts lines to CR/LF. This bash problem
- # is reportedly fixed, but why not run on old versions too?
- sed '$q' "$ltmain" >> "$cfgfile" \
- || (rm -f "$cfgfile"; exit 1)
- if test x"$xsi_shell" = xyes; then
- sed -e '/^func_dirname ()$/,/^} # func_dirname /c\
-func_dirname ()\
-\ case ${1} in\
-\ */*) func_dirname_result="${1%/*}${2}" ;;\
-\ * ) func_dirname_result="${3}" ;;\
-\ esac\
-} # Extended-shell func_dirname implementation' "$cfgfile" > $cfgfile.tmp \
- && mv -f "$cfgfile.tmp" "$cfgfile" \
- || (rm -f "$cfgfile" && cp "$cfgfile.tmp" "$cfgfile" && rm -f "$cfgfile.tmp")
-test 0 -eq $? || _lt_function_replace_fail=:
- sed -e '/^func_basename ()$/,/^} # func_basename /c\
-func_basename ()\
-\ func_basename_result="${1##*/}"\
-} # Extended-shell func_basename implementation' "$cfgfile" > $cfgfile.tmp \
- sed -e '/^func_dirname_and_basename ()$/,/^} # func_dirname_and_basename /c\
-func_dirname_and_basename ()\
-\ case ${1} in\
-\ esac\
-} # Extended-shell func_dirname_and_basename implementation' "$cfgfile" > $cfgfile.tmp \
- sed -e '/^func_stripname ()$/,/^} # func_stripname /c\
-func_stripname ()\
-\ # pdksh 5.2.14 does not do ${X%$Y} correctly if both X and Y are\
-\ # positional parameters, so assign one to ordinary parameter first.\
-\ func_stripname_result=${3}\
-\ func_stripname_result=${func_stripname_result#"${1}"}\
-\ func_stripname_result=${func_stripname_result%"${2}"}\
-} # Extended-shell func_stripname implementation' "$cfgfile" > $cfgfile.tmp \
- sed -e '/^func_split_long_opt ()$/,/^} # func_split_long_opt /c\
-func_split_long_opt ()\
-\ func_split_long_opt_name=${1%%=*}\
-\ func_split_long_opt_arg=${1#*=}\
-} # Extended-shell func_split_long_opt implementation' "$cfgfile" > $cfgfile.tmp \
- sed -e '/^func_split_short_opt ()$/,/^} # func_split_short_opt /c\
-func_split_short_opt ()\
-\ func_split_short_opt_arg=${1#??}\
-\ func_split_short_opt_name=${1%"$func_split_short_opt_arg"}\
-} # Extended-shell func_split_short_opt implementation' "$cfgfile" > $cfgfile.tmp \
- sed -e '/^func_lo2o ()$/,/^} # func_lo2o /c\
-func_lo2o ()\
-\ case ${1} in\
-\ *.lo) func_lo2o_result=${1%.lo}.${objext} ;;\
-\ *) func_lo2o_result=${1} ;;\
-\ esac\
-} # Extended-shell func_lo2o implementation' "$cfgfile" > $cfgfile.tmp \
- sed -e '/^func_xform ()$/,/^} # func_xform /c\
-func_xform ()\
- func_xform_result=${1%.*}.lo\
-} # Extended-shell func_xform implementation' "$cfgfile" > $cfgfile.tmp \
- sed -e '/^func_arith ()$/,/^} # func_arith /c\
-func_arith ()\
- func_arith_result=$(( $* ))\
-} # Extended-shell func_arith implementation' "$cfgfile" > $cfgfile.tmp \
- sed -e '/^func_len ()$/,/^} # func_len /c\
-func_len ()\
- func_len_result=${#1}\
-} # Extended-shell func_len implementation' "$cfgfile" > $cfgfile.tmp \
-fi
-if test x"$lt_shell_append" = xyes; then
- sed -e '/^func_append ()$/,/^} # func_append /c\
-func_append ()\
- eval "${1}+=\\${2}"\
-} # Extended-shell func_append implementation' "$cfgfile" > $cfgfile.tmp \
- sed -e '/^func_append_quoted ()$/,/^} # func_append_quoted /c\
-func_append_quoted ()\
-\ func_quote_for_eval "${2}"\
-\ eval "${1}+=\\\\ \\$func_quote_for_eval_result"\
-} # Extended-shell func_append_quoted implementation' "$cfgfile" > $cfgfile.tmp \
- # Save a `func_append' function call where possible by direct use of '+='
- sed -e 's%func_append \([a-zA-Z_]\{1,\}\) "%\1+="%g' $cfgfile > $cfgfile.tmp \
- test 0 -eq $? || _lt_function_replace_fail=:
-else
- # Save a `func_append' function call even when '+=' is not available
- sed -e 's%func_append \([a-zA-Z_]\{1,\}\) "%\1="$\1%g' $cfgfile > $cfgfile.tmp \
-fi
-if test x"$_lt_function_replace_fail" = x":"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: Unable to substitute extended shell functions in $ofile" >&5
-$as_echo "$as_me: WARNING: Unable to substitute extended shell functions in $ofile" >&2;}
-fi
- mv -f "$cfgfile" "$ofile" ||
- (rm -f "$ofile" && cp "$cfgfile" "$ofile" && rm -f "$cfgfile")
- chmod +x "$ofile"
- cat <<_LT_EOF >> "$ofile"
-# ### BEGIN LIBTOOL TAG CONFIG: CXX
-LD=$lt_LD_CXX
-reload_flag=$lt_reload_flag_CXX
-reload_cmds=$lt_reload_cmds_CXX
-old_archive_cmds=$lt_old_archive_cmds_CXX
-CC=$lt_compiler_CXX
-with_gcc=$GCC_CXX
-no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_CXX
-pic_flag=$lt_lt_prog_compiler_pic_CXX
-wl=$lt_lt_prog_compiler_wl_CXX
-link_static_flag=$lt_lt_prog_compiler_static_CXX
-compiler_c_o=$lt_lt_cv_prog_compiler_c_o_CXX
-build_libtool_need_lc=$archive_cmds_need_lc_CXX
-allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_CXX
-export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_CXX
-whole_archive_flag_spec=$lt_whole_archive_flag_spec_CXX
-compiler_needs_object=$lt_compiler_needs_object_CXX
-old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_CXX
-old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_CXX
-archive_cmds=$lt_archive_cmds_CXX
-archive_expsym_cmds=$lt_archive_expsym_cmds_CXX
-module_cmds=$lt_module_cmds_CXX
-module_expsym_cmds=$lt_module_expsym_cmds_CXX
-with_gnu_ld=$lt_with_gnu_ld_CXX
-allow_undefined_flag=$lt_allow_undefined_flag_CXX
-no_undefined_flag=$lt_no_undefined_flag_CXX
-hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_CXX
-hardcode_libdir_separator=$lt_hardcode_libdir_separator_CXX
-hardcode_direct=$hardcode_direct_CXX
-hardcode_direct_absolute=$hardcode_direct_absolute_CXX
-hardcode_minus_L=$hardcode_minus_L_CXX
-hardcode_shlibpath_var=$hardcode_shlibpath_var_CXX
-# against it.
-hardcode_automatic=$hardcode_automatic_CXX
-inherit_rpath=$inherit_rpath_CXX
-link_all_deplibs=$link_all_deplibs_CXX
-always_export_symbols=$always_export_symbols_CXX
-export_symbols_cmds=$lt_export_symbols_cmds_CXX
-exclude_expsyms=$lt_exclude_expsyms_CXX
-include_expsyms=$lt_include_expsyms_CXX
-prelink_cmds=$lt_prelink_cmds_CXX
-postlink_cmds=$lt_postlink_cmds_CXX
-file_list_spec=$lt_file_list_spec_CXX
-hardcode_action=$hardcode_action_CXX
-compiler_lib_search_dirs=$lt_compiler_lib_search_dirs_CXX
-predep_objects=$lt_predep_objects_CXX
-postdep_objects=$lt_postdep_objects_CXX
-predeps=$lt_predeps_CXX
-postdeps=$lt_postdeps_CXX
-compiler_lib_search_path=$lt_compiler_lib_search_path_CXX
-# ### END LIBTOOL TAG CONFIG: CXX
-_LT_EOF
- esac
-done # for ac_tag
-as_fn_exit 0
-_ACEOF
-ac_clean_files=$ac_clean_files_save
-test $ac_write_fail = 0 ||
- as_fn_error $? "write failure creating $CONFIG_STATUS" "$LINENO" 5
-# configure is writing to config.log, and then calls config.status.
-# config.status does its own redirection, appending to config.log.
-# Unfortunately, on DOS this fails, as config.log is still kept open
-# by configure, so config.status won't be able to write to it; its
-# output is simply discarded. So we exec the FD to /dev/null,
-# effectively closing config.log, so it can be properly (re)opened and
-# appended to by config.status. When coming back to configure, we
-# need to make the FD available again.
-if test "$no_create" != yes; then
- ac_cs_success=:
- ac_config_status_args=
- test "$silent" = yes &&
- ac_config_status_args="$ac_config_status_args --quiet"
- exec 5>/dev/null
- $SHELL $CONFIG_STATUS $ac_config_status_args || ac_cs_success=false
- exec 5>>config.log
- # Use ||, not &&, to avoid exiting from the if with $? = 1, which
- # would make configure fail if this is the last instruction.
- $ac_cs_success || as_fn_exit 1
-fi
-if test -n "$ac_unrecognized_opts" && test "$enable_option_checking" != no; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: unrecognized options: $ac_unrecognized_opts" >&5
-$as_echo "$as_me: WARNING: unrecognized options: $ac_unrecognized_opts" >&2;}
-fi
Index: modules/provider-coaster-c-client/libtool
--- modules/provider-coaster-c-client/libtool (revision 3826)
+++ modules/provider-coaster-c-client/libtool (working copy)
@@ -1,10246 +0,0 @@
-#! /bin/sh
-# libtool - Provide generalized library-building support services.
-# Generated automatically by config.status (coaster-c-client) 1.0
-# Libtool was configured on host thrash:
-# Foundation, Inc.
-macro_version=2.4.2
-macro_revision=1.3337
-build_libtool_libs=yes
-build_old_libs=yes
-pic_mode=default
-fast_install=yes
-SHELL="/bin/sh"
-ECHO="printf %s\\n"
-PATH_SEPARATOR=":"
-# The host system.
-host_alias=
-host=x86_64-unknown-linux-gnu
-host_os=linux-gnu
-build_alias=
-build=x86_64-unknown-linux-gnu
-build_os=linux-gnu
-SED="/bin/sed"
-Xsed="$SED -e 1s/^X//"
-GREP="/bin/grep"
-# An ERE matcher.
-EGREP="/bin/grep -E"
-FGREP="/bin/grep -F"
-NM="/usr/bin/nm -B"
-LN_S="ln -s"
-max_cmd_len=3458764513820540925
-objext=o
-exeext=
-lt_unset=unset
-SP2NL="tr \\040 \\012"
-NL2SP="tr \\015\\012 \\040\\040"
-# convert $build file names to $host format.
-to_host_file_cmd=func_convert_file_noop
-# convert $build files to toolchain format.
-to_tool_file_cmd=func_convert_file_noop
-OBJDUMP="objdump"
-deplibs_check_method="pass_all"
-file_magic_cmd="\$MAGIC_CMD"
-file_magic_glob=""
-want_nocaseglob="no"
-DLLTOOL="false"
-sharedlib_from_linklib_cmd="printf %s\\n"
-# The archiver.
-AR="ar"
-AR_FLAGS="cru"
-archiver_list_spec="@"
-STRIP="strip"
-RANLIB="ranlib"
-old_postinstall_cmds="chmod 644 \$oldlib~\$RANLIB \$tool_oldlib"
-old_postuninstall_cmds=""
-lock_old_archive_extraction=no
-# A C compiler.
-LTCC="gcc"
-LTCFLAGS="-g -O2"
-global_symbol_pipe="sed -n -e 's/^.*[ ]\\([ABCDGIRSTW][ABCDGIRSTW]*\\)[ ][ ]*\\([_A-Za-z][_A-Za-z0-9]*\\)\$/\\1 \\2 \\2/p' | sed '/ __gnu_lto/d'"
-global_symbol_to_cdecl="sed -n -e 's/^T .* \\(.*\\)\$/extern int \\1();/p' -e 's/^[ABCDGIRSTW]* .* \\(.*\\)\$/extern char \\1;/p'"
-global_symbol_to_c_name_address="sed -n -e 's/^: \\([^ ]*\\)[ ]*\$/ {\\\"\\1\\\", (void *) 0},/p' -e 's/^[ABCDGIRSTW]* \\([^ ]*\\) \\([^ ]*\\)\$/ {\"\\2\", (void *) \\&\\2},/p'"
-global_symbol_to_c_name_address_lib_prefix="sed -n -e 's/^: \\([^ ]*\\)[ ]*\$/ {\\\"\\1\\\", (void *) 0},/p' -e 's/^[ABCDGIRSTW]* \\([^ ]*\\) \\(lib[^ ]*\\)\$/ {\"\\2\", (void *) \\&\\2},/p' -e 's/^[ABCDGIRSTW]* \\([^ ]*\\) \\([^ ]*\\)\$/ {\"lib\\2\", (void *) \\&\\2},/p'"
-# Specify filename containing input files for $NM.
-nm_file_list_spec="@"
-lt_sysroot=
-objdir=.libs
-MAGIC_CMD=file
-need_locks="no"
-# Manifest tool.
-MANIFEST_TOOL=":"
-DSYMUTIL=""
-NMEDIT=""
-LIPO=""
-OTOOL=""
-OTOOL64=""
-libext=a
-shrext_cmds=".so"
-extract_expsyms_cmds=""
-variables_saved_for_relink="PATH LD_LIBRARY_PATH LD_RUN_PATH GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
-need_lib_prefix=no
-need_version=no
-version_type=linux
-runpath_var=LD_RUN_PATH
-shlibpath_var=LD_LIBRARY_PATH
-shlibpath_overrides_runpath=no
-libname_spec="lib\$name"
-library_names_spec="\${libname}\${release}\${shared_ext}\$versuffix \${libname}\${release}\${shared_ext}\$major \$libname\${shared_ext}"
-soname_spec="\${libname}\${release}\${shared_ext}\$major"
-install_override_mode=""
-postinstall_cmds=""
-postuninstall_cmds=""
-finish_cmds="PATH=\\\"\\\$PATH:/sbin\\\" ldconfig -n \$libdir"
-# not shown.
-finish_eval=""
-hardcode_into_libs=yes
-sys_lib_search_path_spec="/usr/lib/gcc/x86_64-linux-gnu/4.6 /usr/lib/x86_64-linux-gnu /usr/lib /lib/x86_64-linux-gnu /lib "
-sys_lib_dlsearch_path_spec="/lib /usr/lib /usr/local/lib /lib/x86_64-linux-gnu /usr/lib/x86_64-linux-gnu /usr/lib/x86_64-linux-gnu/mesa /lib32 /usr/lib32 "
-dlopen_support=unknown
-dlopen_self=unknown
-dlopen_self_static=unknown
-old_striplib="strip --strip-debug"
-striplib="strip --strip-unneeded"
-LD="/usr/bin/ld -m elf_x86_64"
-reload_flag=" -r"
-reload_cmds="\$LD\$reload_flag -o \$output\$reload_objs"
-old_archive_cmds="\$AR \$AR_FLAGS \$oldlib\$oldobjs~\$RANLIB \$tool_oldlib"
-CC="gcc"
-with_gcc=yes
-no_builtin_flag=" -fno-builtin"
-pic_flag=" -fPIC -DPIC"
-wl="-Wl,"
-link_static_flag="-static"
-compiler_c_o="yes"
-build_libtool_need_lc=no
-allow_libtool_libs_with_static_runtimes=no
-export_dynamic_flag_spec="\${wl}--export-dynamic"
-whole_archive_flag_spec="\${wl}--whole-archive\$convenience \${wl}--no-whole-archive"
-compiler_needs_object="no"
-old_archive_from_new_cmds=""
-old_archive_from_expsyms_cmds=""
-archive_cmds="\$CC -shared \$pic_flag \$libobjs \$deplibs \$compiler_flags \${wl}-soname \$wl\$soname -o \$lib"
-archive_expsym_cmds="echo \\\"{ global:\\\" > \$output_objdir/\$libname.ver~
- cat \$export_symbols | sed -e \\\"s/\\\\(.*\\\\)/\\\\1;/\\\" >> \$output_objdir/\$libname.ver~
- echo \\\"local: *; };\\\" >> \$output_objdir/\$libname.ver~
- \$CC -shared \$pic_flag \$libobjs \$deplibs \$compiler_flags \${wl}-soname \$wl\$soname \${wl}-version-script \${wl}\$output_objdir/\$libname.ver -o \$lib"
-module_cmds=""
-module_expsym_cmds=""
-with_gnu_ld="yes"
-allow_undefined_flag=""
-no_undefined_flag=""
-# Flag to hardcode $libdir into a binary during linking.
-# This must work even if $libdir does not exist
-hardcode_libdir_flag_spec="\${wl}-rpath \${wl}\$libdir"
-hardcode_libdir_separator=""
-# Set to "yes" if using DIR/libNAME${shared_ext} during linking hardcodes
-hardcode_direct=no
-# "absolute",i.e impossible to change by setting ${shlibpath_var} if the
-hardcode_direct_absolute=no
-hardcode_minus_L=no
-hardcode_shlibpath_var=unsupported
-# against it.
-hardcode_automatic=no
-inherit_rpath=no
-link_all_deplibs=no
-always_export_symbols=no
-export_symbols_cmds="\$NM \$libobjs \$convenience | \$global_symbol_pipe | \$SED 's/.* //' | sort | uniq > \$export_symbols"
-exclude_expsyms="_GLOBAL_OFFSET_TABLE_|_GLOBAL__F[ID]_.*"
-include_expsyms=""
-prelink_cmds=""
-postlink_cmds=""
-file_list_spec=""
-hardcode_action=immediate
-compiler_lib_search_dirs=""
-predep_objects=""
-postdep_objects=""
-predeps=""
-postdeps=""
-compiler_lib_search_path=""
-# libtool (GNU libtool) 2.4.2
-# Written by Gordon Matzigkeit <gord at gnu.ai.mit.edu>, 1996
-# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001, 2003, 2004, 2005, 2006,
-# 2007, 2008, 2009, 2010, 2011 Free Software Foundation, Inc.
-# This is free software; see the source for copying conditions. There is NO
-# warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
-# GNU Libtool is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2 of the License, or
-# (at your option) any later version.
-# GNU Libtool is distributed in the hope that it will be useful, but
-# WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-# General Public License for more details.
-# or obtained by writing to the Free Software Foundation, Inc.,
-# Usage: $progname [OPTION]... [MODE-ARG]...
-# Provide generalized library-building support services.
-# --config show all configuration variables
-# --debug enable verbose shell tracing
-# -n, --dry-run display commands without modifying any files
-# --features display basic configuration information and exit
-# --mode=MODE use operation mode MODE
-# --preserve-dup-deps don't remove duplicate dependency libraries
-# --quiet, --silent don't print informational messages
-# --no-quiet, --no-silent
-# print informational messages (default)
-# --no-warn don't display warning messages
-# --tag=TAG use configuration variables from tag TAG
-# -v, --verbose print more informational messages than default
-# --no-verbose don't print the extra informational messages
-# --version print version information
-# -h, --help, --help-all print short, long, or detailed help message
-# MODE must be one of the following:
-# clean remove files from the build directory
-# compile compile a source file into a libtool object
-# execute automatically set library path, then run a program
-# finish complete the installation of libtool libraries
-# install install libraries or executables
-# link create a library or an executable
-# uninstall remove libraries from an installed directory
-# MODE-ARGS vary depending on the MODE. When passed as first option,
-# `--mode=MODE' may be abbreviated as `MODE' or a unique abbreviation of that.
-# Try `$progname --help --mode=MODE' for a more detailed description of MODE.
-# When reporting a bug, please describe a test case to reproduce it and
-# include the following information:
-# host-triplet: $host
-# shell: $SHELL
-# compiler: $LTCC
-# compiler flags: $LTCFLAGS
-# linker: $LD (gnu? $with_gnu_ld)
-# $progname: (GNU libtool) 2.4.2 Debian-2.4.2-1ubuntu1
-# automake: $automake_version
-# autoconf: $autoconf_version
-# Report bugs to <bug-libtool at gnu.org>.
-# GNU libtool home page: <http://www.gnu.org/software/libtool/>.
-# General help using GNU software: <http://www.gnu.org/gethelp/>.
-PROGRAM=libtool
-PACKAGE=libtool
-VERSION="2.4.2 Debian-2.4.2-1ubuntu1"
-TIMESTAMP=""
-package_revision=1.3337
-# Be Bourne compatible
-if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
- emulate sh
- NULLCMD=:
- # Zsh 3.x and 4.x performs word splitting on ${1+"$@"}, which
- # is contrary to our usage. Disable this feature.
- alias -g '${1+"$@"}'='"$@"'
- setopt NO_GLOB_SUBST
-else
- case `(set -o) 2>/dev/null` in *posix*) set -o posix;; esac
-fi
-BIN_SH=xpg4; export BIN_SH # for Tru64
-DUALCASE=1; export DUALCASE # for MKS sh
-$1
-_LTECHO_EOF'
-# NLS nuisances: We save the old values to restore during execute mode.
-lt_user_locale=
-lt_safe_locale=
-for lt_var in LANG LANGUAGE LC_ALL LC_CTYPE LC_COLLATE LC_MESSAGES
-do
- eval "if test \"\${$lt_var+set}\" = set; then
- save_$lt_var=\$$lt_var
- $lt_var=C
- export $lt_var
- lt_user_locale=\"$lt_var=\\\$save_\$lt_var; \$lt_user_locale\"
- lt_safe_locale=\"$lt_var=C; \$lt_safe_locale\"
- fi"
-done
-LC_ALL=C
-LANGUAGE=C
-export LANGUAGE LC_ALL
-$lt_unset CDPATH
-# Work around backward compatibility issue on IRIX 6.5. On IRIX 6.4+, sh
-# is ksh but when the shell is invoked as "sh" and the current value of
-# the _XPG environment variable is not equal to 1 (one), the special
-# positional parameter $0, within a function call, is the name of the
-# function.
-progpath="$0"
-: ${CP="cp -f"}
-test "${ECHO+set}" = set || ECHO=${as_echo-'printf %s\n'}
-: ${MAKE="make"}
-: ${MKDIR="mkdir"}
-: ${MV="mv -f"}
-: ${RM="rm -f"}
-: ${SHELL="${CONFIG_SHELL-/bin/sh}"}
-: ${Xsed="$SED -e 1s/^X//"}
-# Global variables:
-EXIT_SUCCESS=0
-EXIT_FAILURE=1
-EXIT_MISMATCH=63 # $? = 63 is used to indicate version mismatch to missing.
-EXIT_SKIP=77 # $? = 77 is used to indicate a skipped test to automake.
-exit_status=$EXIT_SUCCESS
-# Make sure IFS has a sensible default
-lt_nl='
-IFS=" $lt_nl"
-dirname="s,/[^/]*$,,"
-basename="s,^.*/,,"
-# func_dirname file append nondir_replacement
-# Compute the dirname of FILE. If nonempty, add APPEND to the result,
-# otherwise set result to NONDIR_REPLACEMENT.
-func_dirname ()
- case ${1} in
- */*) func_dirname_result="${1%/*}${2}" ;;
- * ) func_dirname_result="${3}" ;;
- esac
-# func_basename file
-func_basename ()
- func_basename_result="${1##*/}"
-# func_dirname_and_basename file append nondir_replacement
-# perform func_basename and func_dirname in a single function
-# call:
-# dirname: Compute the dirname of FILE. If nonempty,
-# add APPEND to the result, otherwise set result
-# to NONDIR_REPLACEMENT.
-# value returned in "$func_dirname_result"
-# basename: Compute filename of FILE.
-# value retuned in "$func_basename_result"
-# Implementation must be kept synchronized with func_dirname
-# and func_basename. For efficiency, we do not delegate to
-# those functions but instead duplicate the functionality here.
- case ${1} in
- esac
-# func_stripname prefix suffix name
-# strip PREFIX and SUFFIX off of NAME.
-# PREFIX and SUFFIX must not contain globbing or regex special
-# characters, hashes, percent signs, but SUFFIX may contain a leading
-# dot (in which case that matches only a dot).
-# func_strip_suffix prefix name
-func_stripname ()
- # pdksh 5.2.14 does not do ${X%$Y} correctly if both X and Y are
- # positional parameters, so assign one to ordinary parameter first.
- func_stripname_result=${3}
- func_stripname_result=${func_stripname_result#"${1}"}
- func_stripname_result=${func_stripname_result%"${2}"}
-# These SED scripts presuppose an absolute path with a trailing slash.
-pathcar='s,^/\([^/]*\).*$,\1,'
-pathcdr='s,^/[^/]*,,'
-removedotparts=':dotsl
- s@/\./@/@g
- t dotsl
- s,/\.$,/,'
-collapseslashes='s@/\{1,\}@/@g'
-finalslash='s,/*$,/,'
-# func_normal_abspath PATH
-# Remove doubled-up and trailing slashes, "." path components,
-# and cancel out any ".." path components in PATH after making
-# it an absolute path.
-# value returned in "$func_normal_abspath_result"
-func_normal_abspath ()
- # Start from root dir and reassemble the path.
- func_normal_abspath_result=
- func_normal_abspath_tpath=$1
- func_normal_abspath_altnamespace=
- case $func_normal_abspath_tpath in
- # Empty path, that just means $cwd.
- func_stripname '' '/' "`pwd`"
- func_normal_abspath_result=$func_stripname_result
- return
- # The next three entries are used to spot a run of precisely
- # two leading slashes without using negated character classes;
- # we take advantage of case's first-match behaviour.
- # Unusual form of absolute path, do nothing.
- # Not necessarily an ordinary path; POSIX reserves leading '//'
- # and for example Cygwin uses it to access remote file shares
- # over CIFS/SMB, so we conserve a leading double slash if found.
- func_normal_abspath_altnamespace=/
- # Absolute path, do nothing.
- # Relative path, prepend $cwd.
- func_normal_abspath_tpath=`pwd`/$func_normal_abspath_tpath
- esac
- # Cancel out all the simple stuff to save iterations. We also want
- # the path to end with a slash for ease of parsing, so make sure
- # there is one (and only one) here.
- func_normal_abspath_tpath=`$ECHO "$func_normal_abspath_tpath" | $SED \
- -e "$removedotparts" -e "$collapseslashes" -e "$finalslash"`
- while :; do
- # Processed it all yet?
- if test "$func_normal_abspath_tpath" = / ; then
- # If we ascended to the root using ".." the result may be empty now.
- if test -z "$func_normal_abspath_result" ; then
- func_normal_abspath_result=/
- fi
- break
- fi
- func_normal_abspath_tcomponent=`$ECHO "$func_normal_abspath_tpath" | $SED \
- -e "$pathcar"`
- -e "$pathcdr"`
- # Figure out what to do with it
- case $func_normal_abspath_tcomponent in
- # Trailing empty path component, ignore it.
- # Parent dir; strip last assembled component from result.
- func_dirname "$func_normal_abspath_result"
- func_normal_abspath_result=$func_dirname_result
- # Actual path component, append it.
- func_normal_abspath_result=$func_normal_abspath_result/$func_normal_abspath_tcomponent
- esac
- done
- # Restore leading double-slash if one was found on entry.
- func_normal_abspath_result=$func_normal_abspath_altnamespace$func_normal_abspath_result
-# func_relative_path SRCDIR DSTDIR
-# generates a relative path from SRCDIR to DSTDIR, with a trailing
-# slash if non-empty, suitable for immediately appending a filename
-# without needing to append a separator.
-# value returned in "$func_relative_path_result"
-func_relative_path ()
- func_relative_path_result=
- func_normal_abspath "$1"
- func_relative_path_tlibdir=$func_normal_abspath_result
- func_normal_abspath "$2"
- func_relative_path_tbindir=$func_normal_abspath_result
- # Ascend the tree starting from libdir
- while :; do
- # check if we have found a prefix of bindir
- case $func_relative_path_tbindir in
- $func_relative_path_tlibdir)
- # found an exact match
- func_relative_path_tcancelled=
- break
- $func_relative_path_tlibdir*)
- # found a matching prefix
- func_stripname "$func_relative_path_tlibdir" '' "$func_relative_path_tbindir"
- func_relative_path_tcancelled=$func_stripname_result
- if test -z "$func_relative_path_result"; then
- func_relative_path_result=.
- fi
- break
- func_dirname $func_relative_path_tlibdir
- func_relative_path_tlibdir=${func_dirname_result}
- if test "x$func_relative_path_tlibdir" = x ; then
- # Have to descend all the way to the root!
- func_relative_path_result=../$func_relative_path_result
- func_relative_path_tcancelled=$func_relative_path_tbindir
- break
- fi
- esac
- done
- # Now calculate path; take care to avoid doubling-up slashes.
- func_stripname '' '/' "$func_relative_path_result"
- func_relative_path_result=$func_stripname_result
- func_stripname '/' '/' "$func_relative_path_tcancelled"
- if test "x$func_stripname_result" != x ; then
- func_relative_path_result=${func_relative_path_result}/${func_stripname_result}
- fi
- # Normalisation. If bindir is libdir, return empty string,
- # else relative path ending with a slash; either way, target
- # file name can be directly appended.
- if test ! -z "$func_relative_path_result"; then
- func_stripname './' '' "$func_relative_path_result/"
- fi
-# The name of this program:
-func_dirname_and_basename "$progpath"
-progname=$func_basename_result
-# Make sure we have an absolute path for reexecution:
-case $progpath in
- [\\/]*|[A-Za-z]:\\*) ;;
- progdir=$func_dirname_result
- progdir=`cd "$progdir" && pwd`
- progpath="$progdir/$progname"
- save_IFS="$IFS"
- IFS=${PATH_SEPARATOR-:}
- for progdir in $PATH; do
- IFS="$save_IFS"
- test -x "$progdir/$progname" && break
- done
- IFS="$save_IFS"
- test -n "$progdir" || progdir=`pwd`
-esac
-# Sed substitution that helps us do robust quoting. It backslashifies
-# metacharacters that are still active within double-quoted strings.
-Xsed="${SED}"' -e 1s/^X//'
-sed_quote_subst='s/\([`"$\\]\)/\\\1/g'
-# Same as above, but do not quote variable references.
-double_quote_subst='s/\(["`\\]\)/\\\1/g'
-# Sed substitution that turns a string into a regex matching for the
-# string literally.
-sed_make_literal_regex='s,[].[^$\\*\/],\\&,g'
-# Sed substitution that converts a w32 file name or path
-# which contains forward slashes, into one that contains
-# (escaped) backslashes. A very naive implementation.
-lt_sed_naive_backslashify='s|\\\\*|\\|g;s|/|\\|g;s|\\|\\\\|g'
-# Re-`\' parameter expansions in output of double_quote_subst that were
-# `\'-ed in input to the same. If an odd number of `\' preceded a '$'
-# in input to double_quote_subst, that '$' was protected from expansion.
-# Since each input `\' is now two `\'s, look for any number of runs of
-# four `\'s followed by two `\'s and then a '$'. `\' that '$'.
-bs='\\'
-bs2='\\\\'
-bs4='\\\\\\\\'
-dollar='\$'
-sed_double_backslash="\
- s/$bs4/&\\
-/g
- s/^$bs2$dollar/$bs&/
- s/\\([^$bs]\\)$bs2$dollar/\\1$bs2$bs$dollar/g
- s/\n//g"
-# Standard options:
-opt_dry_run=false
-opt_help=false
-opt_quiet=false
-opt_verbose=false
-opt_warning=:
-# func_echo arg...
-# Echo program name prefixed message, along with the current mode
-# name if it has been set yet.
-func_echo ()
- $ECHO "$progname: ${opt_mode+$opt_mode: }$*"
-# func_verbose arg...
-# Echo program name prefixed message in verbose mode only.
-func_verbose ()
- $opt_verbose && func_echo ${1+"$@"}
- # A bug in bash halts the script if the last line of a function
- # fails when set -e is in force, so we need another command to
- # work around that:
-# func_echo_all arg...
-# Invoke $ECHO with all args, space-separated.
-func_echo_all ()
- $ECHO "$*"
-# func_error arg...
-# Echo program name prefixed message to standard error.
-func_error ()
- $ECHO "$progname: ${opt_mode+$opt_mode: }"${1+"$@"} 1>&2
-# func_warning arg...
-# Echo program name prefixed warning message to standard error.
-func_warning ()
- $opt_warning && $ECHO "$progname: ${opt_mode+$opt_mode: }warning: "${1+"$@"} 1>&2
- # bash bug again:
-# func_fatal_error arg...
-# Echo program name prefixed message to standard error, and exit.
-func_fatal_error ()
- func_error ${1+"$@"}
- exit $EXIT_FAILURE
-# func_fatal_help arg...
-# Echo program name prefixed message to standard error, followed by
-# a help hint, and exit.
-func_fatal_help ()
- func_fatal_error "$help"
-help="Try \`$progname --help' for more information." ## default
-# func_grep expression filename
-# Check whether EXPRESSION matches any line of FILENAME, without output.
-func_grep ()
- $GREP "$1" "$2" >/dev/null 2>&1
-# func_mkdir_p directory-path
-# Make sure the entire path to DIRECTORY-PATH is available.
-func_mkdir_p ()
- my_directory_path="$1"
- my_dir_list=
- if test -n "$my_directory_path" && test "$opt_dry_run" != ":"; then
- # Protect directory names starting with `-'
- case $my_directory_path in
- -*) my_directory_path="./$my_directory_path" ;;
- esac
- # While some portion of DIR does not yet exist...
- while test ! -d "$my_directory_path"; do
- # ...make a list in topmost first order. Use a colon delimited
- # list incase some portion of path contains whitespace.
- my_dir_list="$my_directory_path:$my_dir_list"
- # If the last portion added has no slash in it, the list is done
- case $my_directory_path in */*) ;; *) break ;; esac
- # ...otherwise throw away the child directory and loop
- my_directory_path=`$ECHO "$my_directory_path" | $SED -e "$dirname"`
- done
- my_dir_list=`$ECHO "$my_dir_list" | $SED 's,:*$,,'`
- save_mkdir_p_IFS="$IFS"; IFS=':'
- for my_dir in $my_dir_list; do
- IFS="$save_mkdir_p_IFS"
- # mkdir can fail with a `File exist' error if two processes
- # try to create one of the directories concurrently. Don't
- # stop in that case!
- $MKDIR "$my_dir" 2>/dev/null || :
- done
- # Bail out if we (or some other process) failed to create a directory.
- test -d "$my_directory_path" || \
- func_fatal_error "Failed to create \`$1'"
- fi
-# func_mktempdir [string]
-# Make a temporary directory that won't clash with other running
-# libtool processes, and avoids race conditions if possible. If
-# given, STRING is the basename for that directory.
-func_mktempdir ()
- my_template="${TMPDIR-/tmp}/${1-$progname}"
- if test "$opt_dry_run" = ":"; then
- # Return a directory name, but don't create it in dry-run mode
- my_tmpdir="${my_template}-$$"
- else
- # If mktemp works, use that first and foremost
- my_tmpdir=`mktemp -d "${my_template}-XXXXXXXX" 2>/dev/null`
- if test ! -d "$my_tmpdir"; then
- # Failing that, at least try and use $RANDOM to avoid a race
- my_tmpdir="${my_template}-${RANDOM-0}$$"
- save_mktempdir_umask=`umask`
- umask 0077
- $MKDIR "$my_tmpdir"
- umask $save_mktempdir_umask
- fi
- # If we're not in dry-run mode, bomb out on failure
- test -d "$my_tmpdir" || \
- func_fatal_error "cannot create temporary directory \`$my_tmpdir'"
- fi
- $ECHO "$my_tmpdir"
-# func_quote_for_eval arg
-# Aesthetically quote ARG to be evaled later.
-# This function returns two values: FUNC_QUOTE_FOR_EVAL_RESULT
-# is double-quoted, suitable for a subsequent eval, whereas
-# FUNC_QUOTE_FOR_EVAL_UNQUOTED_RESULT has merely all characters
-# which are still active within double quotes backslashified.
-func_quote_for_eval ()
- case $1 in
- func_quote_for_eval_unquoted_result=`$ECHO "$1" | $SED "$sed_quote_subst"` ;;
- func_quote_for_eval_unquoted_result="$1" ;;
- esac
- case $func_quote_for_eval_unquoted_result in
- # Double-quote args containing shell metacharacters to delay
- # word splitting, command substitution and and variable
- # expansion for a subsequent eval.
- # Many Bourne shells cannot handle close brackets correctly
- # in scan sets, so we specify it separately.
- func_quote_for_eval_result="\"$func_quote_for_eval_unquoted_result\""
- func_quote_for_eval_result="$func_quote_for_eval_unquoted_result"
- esac
-# func_quote_for_expand arg
-# Aesthetically quote ARG to be evaled later; same as above,
-# but do not quote variable references.
-func_quote_for_expand ()
- case $1 in
- my_arg=`$ECHO "$1" | $SED \
- -e "$double_quote_subst" -e "$sed_double_backslash"` ;;
- my_arg="$1" ;;
- esac
- case $my_arg in
- # word splitting and command substitution for a subsequent eval.
- my_arg="\"$my_arg\""
- esac
- func_quote_for_expand_result="$my_arg"
-# func_show_eval cmd [fail_exp]
-# Unless opt_silent is true, then output CMD. Then, if opt_dryrun is
-# not true, evaluate CMD. If the evaluation of CMD fails, and FAIL_EXP
-# is given, then evaluate it.
-func_show_eval ()
- my_cmd="$1"
- my_fail_exp="${2-:}"
- ${opt_silent-false} || {
- func_quote_for_expand "$my_cmd"
- eval "func_echo $func_quote_for_expand_result"
- if ${opt_dry_run-false}; then :; else
- eval "$my_cmd"
- my_status=$?
- if test "$my_status" -eq 0; then :; else
- eval "(exit $my_status); $my_fail_exp"
- fi
- fi
-# func_show_eval_locale cmd [fail_exp]
-# is given, then evaluate it. Use the saved locale for evaluation.
-func_show_eval_locale ()
- my_cmd="$1"
- eval "$lt_user_locale
- $my_cmd"
- my_status=$?
- eval "$lt_safe_locale"
- fi
- fi
-# func_tr_sh
-# Turn $1 into a string suitable for a shell variable name.
-# Result is stored in $func_tr_sh_result. All characters
-# not in the set a-zA-Z0-9_ are replaced with '_'. Further,
-# if $1 begins with a digit, a '_' is prepended as well.
-func_tr_sh ()
- case $1 in
- [0-9]* | *[!a-zA-Z0-9_]*)
- func_tr_sh_result=`$ECHO "$1" | $SED 's/^\([0-9]\)/_\1/; s/[^a-zA-Z0-9_]/_/g'`
- func_tr_sh_result=$1
- esac
-# func_version
-# Echo version message to standard output and exit.
-func_version ()
- $opt_debug
- $SED -n '/(C)/!b go
- :more
- N
- s/\n# / /
- b more
- :go
- /^# '$PROGRAM' (GNU /,/# warranty; / {
- s/^# //
- s/^# *$//
- s/\((C)\)[ 0-9,-]*\( [1-9][0-9]*\)/\1\2/
- p
- }' < "$progpath"
- exit $?
-# func_usage
-# Echo short help message to standard output and exit.
-func_usage ()
- $opt_debug
- $SED -n '/^# Usage:/,/^# *.*--help/ {
- s/^# //
- s/^# *$//
- s/\$progname/'$progname'/
- p
- }' < "$progpath"
- echo
- $ECHO "run \`$progname --help | more' for full usage"
- exit $?
-# func_help [NOEXIT]
-# Echo long help message to standard output and exit,
-# unless 'noexit' is passed as argument.
-func_help ()
- $opt_debug
- $SED -n '/^# Usage:/,/# Report bugs to/ {
- :print
- s/^# //
- s/^# *$//
- s*\$progname*'$progname'*
- s*\$host*'"$host"'*
- s*\$SHELL*'"$SHELL"'*
- s*\$LTCC*'"$LTCC"'*
- s*\$LTCFLAGS*'"$LTCFLAGS"'*
- s*\$LD*'"$LD"'*
- s/\$with_gnu_ld/'"$with_gnu_ld"'/
- s/\$automake_version/'"`(${AUTOMAKE-automake} --version) 2>/dev/null |$SED 1q`"'/
- s/\$autoconf_version/'"`(${AUTOCONF-autoconf} --version) 2>/dev/null |$SED 1q`"'/
- p
- d
- /^# .* home page:/b print
- /^# General help using/b print
- ' < "$progpath"
- ret=$?
- if test -z "$1"; then
- exit $ret
- fi
-# func_missing_arg argname
-# Echo program name prefixed message to standard error and set global
-# exit_cmd.
-func_missing_arg ()
- $opt_debug
- func_error "missing argument for $1."
- exit_cmd=exit
-# func_split_short_opt shortopt
-# Set func_split_short_opt_name and func_split_short_opt_arg shell
-# variables after splitting SHORTOPT after the 2nd character.
- func_split_short_opt_arg=${1#??}
- func_split_short_opt_name=${1%"$func_split_short_opt_arg"}
-# func_split_long_opt longopt
-# Set func_split_long_opt_name and func_split_long_opt_arg shell
-# variables after splitting LONGOPT at the `=' sign.
- func_split_long_opt_name=${1%%=*}
- func_split_long_opt_arg=${1#*=}
-exit_cmd=:
-magic="%%%MAGIC variable%%%"
-magic_exe="%%%MAGIC EXE variable%%%"
-# Global variables.
-nonopt=
-preserve_args=
-lo2o="s/\\.lo\$/.${objext}/"
-o2lo="s/\\.${objext}\$/.lo/"
-extracted_archives=
-extracted_serial=0
-# If this variable is set in any of the actions, the command in it
-# will be execed at the end. This prevents here-documents from being
-# left over by shells.
-exec_cmd=
-# func_append var value
-# Append VALUE to the end of shell variable VAR.
-func_append ()
- eval "${1}+=\${2}"
-# func_append_quoted var value
-# Quote VALUE and append to the end of shell variable VAR, separated
-# by a space.
- func_quote_for_eval "${2}"
- eval "${1}+=\\ \$func_quote_for_eval_result"
-# func_arith arithmetic-term...
-func_arith ()
-# func_len string
-# STRING may not start with a hyphen.
-func_len ()
-# func_lo2o object
-func_lo2o ()
- case ${1} in
- *.lo) func_lo2o_result=${1%.lo}.${objext} ;;
- *) func_lo2o_result=${1} ;;
- esac
-# func_xform libobj-or-source
-func_xform ()
-# func_fatal_configuration arg...
-# a configuration failure hint, and exit.
-func_fatal_configuration ()
- func_error "See the $PACKAGE documentation for more information."
- func_fatal_error "Fatal configuration error."
-# func_config
-# Display the configuration for all the tags in this script.
-func_config ()
- re_begincf='^# ### BEGIN LIBTOOL'
- re_endcf='^# ### END LIBTOOL'
- # Default configuration.
- $SED "1,/$re_begincf CONFIG/d;/$re_endcf CONFIG/,\$d" < "$progpath"
- # Now print the configurations for the tags.
- for tagname in $taglist; do
- $SED -n "/$re_begincf TAG CONFIG: $tagname\$/,/$re_endcf TAG CONFIG: $tagname\$/p" < "$progpath"
- done
- exit $?
-# func_features
-# Display the features supported by this script.
-func_features ()
- echo "host: $host"
- if test "$build_libtool_libs" = yes; then
- echo "enable shared libraries"
- else
- echo "disable shared libraries"
- fi
- if test "$build_old_libs" = yes; then
- echo "enable static libraries"
- else
- echo "disable static libraries"
- fi
- exit $?
-# func_enable_tag tagname
-# Verify that TAGNAME is valid, and either flag an error and exit, or
-# enable the TAGNAME tag. We also add TAGNAME to the global $taglist
-# variable here.
-func_enable_tag ()
- # Global variable:
- tagname="$1"
- re_begincf="^# ### BEGIN LIBTOOL TAG CONFIG: $tagname\$"
- re_endcf="^# ### END LIBTOOL TAG CONFIG: $tagname\$"
- sed_extractcf="/$re_begincf/,/$re_endcf/p"
- # Validate tagname.
- case $tagname in
- *[!-_A-Za-z0-9,/]*)
- func_fatal_error "invalid tag name: $tagname"
- esac
- # Don't test for the "default" C tag, as we know it's
- # there but not specially marked.
- case $tagname in
- CC) ;;
- if $GREP "$re_begincf" "$progpath" >/dev/null 2>&1; then
- taglist="$taglist $tagname"
- # Evaluate the configuration. Be careful to quote the path
- # and the sed script, to avoid splitting on whitespace, but
- # also don't use non-portable quotes within backquotes within
- # quotes we have to do it in 2 steps:
- extractedcf=`$SED -n -e "$sed_extractcf" < "$progpath"`
- eval "$extractedcf"
- else
- func_error "ignoring unknown tag $tagname"
- fi
- esac
-# func_check_version_match
-# Ensure that we are using m4 macros, and libtool script from the same
-# release of libtool.
-func_check_version_match ()
- if test "$package_revision" != "$macro_revision"; then
- if test "$VERSION" != "$macro_version"; then
- if test -z "$macro_version"; then
- cat >&2 <<_LT_EOF
-$progname: Version mismatch error. This is $PACKAGE $VERSION, but the
-$progname: definition of this LT_INIT comes from an older release.
-$progname: You should recreate aclocal.m4 with macros from $PACKAGE $VERSION
-$progname: and run autoconf again.
-_LT_EOF
- else
- cat >&2 <<_LT_EOF
-$progname: definition of this LT_INIT comes from $PACKAGE $macro_version.
-_LT_EOF
- fi
- else
- cat >&2 <<_LT_EOF
-$progname: Version mismatch error. This is $PACKAGE $VERSION, revision $package_revision,
-$progname: but the definition of this LT_INIT comes from revision $macro_revision.
-$progname: You should recreate aclocal.m4 with macros from revision $package_revision
-$progname: of $PACKAGE $VERSION and run autoconf again.
-_LT_EOF
- fi
- exit $EXIT_MISMATCH
- fi
-# Shorthand for --mode=foo, only valid as the first argument
-case $1 in
-clean|clea|cle|cl)
- shift; set dummy --mode clean ${1+"$@"}; shift
-compile|compil|compi|comp|com|co|c)
- shift; set dummy --mode compile ${1+"$@"}; shift
-execute|execut|execu|exec|exe|ex|e)
- shift; set dummy --mode execute ${1+"$@"}; shift
-finish|finis|fini|fin|fi|f)
- shift; set dummy --mode finish ${1+"$@"}; shift
-install|instal|insta|inst|ins|in|i)
- shift; set dummy --mode install ${1+"$@"}; shift
-link|lin|li|l)
- shift; set dummy --mode link ${1+"$@"}; shift
-uninstall|uninstal|uninsta|uninst|unins|unin|uni|un|u)
- shift; set dummy --mode uninstall ${1+"$@"}; shift
-esac
-# Option defaults:
-opt_debug=:
-opt_dry_run=false
-opt_config=false
-opt_preserve_dup_deps=false
-opt_features=false
-opt_finish=false
-opt_help=false
-opt_help_all=false
-opt_silent=:
-opt_warning=:
-opt_verbose=:
-opt_silent=false
-opt_verbose=false
-# Parse options once, thoroughly. This comes as soon as possible in the
-# script to make things like `--version' happen as quickly as we can.
- # this just eases exit handling
- while test $# -gt 0; do
- opt="$1"
- shift
- case $opt in
- --debug|-x) opt_debug='set -x'
- func_echo "enabling shell trace mode"
- $opt_debug
- --dry-run|--dryrun|-n)
- opt_dry_run=:
- --config)
- opt_config=:
-func_config
- --dlopen|-dlopen)
- optarg="$1"
- opt_dlopen="${opt_dlopen+$opt_dlopen
-}$optarg"
- shift
- --preserve-dup-deps)
- opt_preserve_dup_deps=:
- --features)
- opt_features=:
-func_features
- --finish)
- opt_finish=:
-set dummy --mode finish ${1+"$@"}; shift
- --help)
- opt_help=:
- --help-all)
- opt_help_all=:
-opt_help=': help-all'
- --mode)
- test $# = 0 && func_missing_arg $opt && break
- optarg="$1"
- opt_mode="$optarg"
-case $optarg in
- # Valid mode arguments:
- clean|compile|execute|finish|install|link|relink|uninstall) ;;
- # Catch anything else as an error
- *) func_error "invalid argument for $opt"
- exit_cmd=exit
- break
-esac
- shift
- --no-silent|--no-quiet)
- opt_silent=false
-preserve_args+=" $opt"
- --no-warning|--no-warn)
- opt_warning=false
- --no-verbose)
- opt_verbose=false
- --silent|--quiet)
- opt_silent=:
- opt_verbose=false
- --verbose|-v)
- opt_verbose=:
-opt_silent=false
- --tag)
- optarg="$1"
- opt_tag="$optarg"
-preserve_args+=" $opt $optarg"
-func_enable_tag "$optarg"
- shift
- -\?|-h) func_usage ;;
- --help) func_help ;;
- --version) func_version ;;
- # Separate optargs to long options:
- func_split_long_opt "$opt"
- set dummy "$func_split_long_opt_name" "$func_split_long_opt_arg" ${1+"$@"}
- shift
- # Separate non-argument short options:
- -\?*|-h*|-n*|-v*)
- func_split_short_opt "$opt"
- set dummy "$func_split_short_opt_name" "-$func_split_short_opt_arg" ${1+"$@"}
- shift
- --) break ;;
- -*) func_fatal_help "unrecognized option \`$opt'" ;;
- *) set dummy "$opt" ${1+"$@"}; shift; break ;;
- esac
- done
- # Validate options:
- # save first non-option argument
- if test "$#" -gt 0; then
- nonopt="$opt"
- shift
- fi
- # preserve --debug
- test "$opt_debug" = : || preserve_args+=" --debug"
- case $host in
- *cygwin* | *mingw* | *pw32* | *cegcc*)
- # don't eliminate duplications in $postdeps and $predeps
- opt_duplicate_compiler_generated_deps=:
- opt_duplicate_compiler_generated_deps=$opt_preserve_dup_deps
- esac
- $opt_help || {
- # Sanity checks first:
- func_check_version_match
- if test "$build_libtool_libs" != yes && test "$build_old_libs" != yes; then
- func_fatal_configuration "not configured to build any kind of library"
- fi
- # Darwin sucks
- eval std_shrext=\"$shrext_cmds\"
- # Only execute mode is allowed to have -dlopen flags.
- if test -n "$opt_dlopen" && test "$opt_mode" != execute; then
- func_error "unrecognized option \`-dlopen'"
- $ECHO "$help" 1>&2
- fi
- # Change the help message to a mode-specific one.
- generic_help="$help"
- help="Try \`$progname --help --mode=$opt_mode' for more information."
- # Bail if the options were screwed
- $exit_cmd $EXIT_FAILURE
-## Main. ##
-# func_lalib_p file
-# True iff FILE is a libtool `.la' library or `.lo' object file.
-# This function is only a basic sanity check; it will hardly flush out
-# determined imposters.
-func_lalib_p ()
- test -f "$1" &&
- $SED -e 4q "$1" 2>/dev/null \
- | $GREP "^# Generated by .*$PACKAGE" > /dev/null 2>&1
-# func_lalib_unsafe_p file
-# This function implements the same check as func_lalib_p without
-# resorting to external programs. To this end, it redirects stdin and
-# closes it afterwards, without saving the original file descriptor.
-# As a safety measure, use it only where a negative result would be
-# fatal anyway. Works if `file' does not exist.
-func_lalib_unsafe_p ()
- lalib_p=no
- if test -f "$1" && test -r "$1" && exec 5<&0 <"$1"; then
- for lalib_p_l in 1 2 3 4
- do
- read lalib_p_line
- case "$lalib_p_line" in
- \#\ Generated\ by\ *$PACKAGE* ) lalib_p=yes; break;;
- esac
- done
- exec 0<&5 5<&-
- fi
- test "$lalib_p" = yes
-# func_ltwrapper_script_p file
-# True iff FILE is a libtool wrapper script
-func_ltwrapper_script_p ()
- func_lalib_p "$1"
-# func_ltwrapper_executable_p file
-# True iff FILE is a libtool wrapper executable
-func_ltwrapper_executable_p ()
- func_ltwrapper_exec_suffix=
- case $1 in
- *.exe) ;;
- *) func_ltwrapper_exec_suffix=.exe ;;
- esac
- $GREP "$magic_exe" "$1$func_ltwrapper_exec_suffix" >/dev/null 2>&1
-# func_ltwrapper_scriptname file
-# Assumes file is an ltwrapper_executable
-# uses $file to determine the appropriate filename for a
-# temporary ltwrapper_script.
-func_ltwrapper_scriptname ()
- func_dirname_and_basename "$1" "" "."
- func_stripname '' '.exe' "$func_basename_result"
- func_ltwrapper_scriptname_result="$func_dirname_result/$objdir/${func_stripname_result}_ltshwrapper"
-# func_ltwrapper_p file
-# True iff FILE is a libtool wrapper script or wrapper executable
-func_ltwrapper_p ()
- func_ltwrapper_script_p "$1" || func_ltwrapper_executable_p "$1"
-# func_execute_cmds commands fail_cmd
-# Execute tilde-delimited COMMANDS.
-# If FAIL_CMD is given, eval that upon failure.
-# FAIL_CMD may read-access the current command in variable CMD!
-func_execute_cmds ()
- $opt_debug
- save_ifs=$IFS; IFS='~'
- for cmd in $1; do
- IFS=$save_ifs
- eval cmd=\"$cmd\"
- func_show_eval "$cmd" "${2-:}"
- done
- IFS=$save_ifs
-# func_source file
-# Source FILE, adding directory component if necessary.
-# Note that it is not necessary on cygwin/mingw to append a dot to
-# FILE even if both FILE and FILE.exe exist: automatic-append-.exe
-# behavior happens only for exec(3), not for open(2)! Also, sourcing
-# `FILE.' does not work on cygwin managed mounts.
-func_source ()
- $opt_debug
- case $1 in
- */* | *\\*) . "$1" ;;
- *) . "./$1" ;;
- esac
-# func_resolve_sysroot PATH
-# Replace a leading = in PATH with a sysroot. Store the result into
-# func_resolve_sysroot_result
-func_resolve_sysroot ()
- func_resolve_sysroot_result=$1
- case $func_resolve_sysroot_result in
- func_stripname '=' '' "$func_resolve_sysroot_result"
- func_resolve_sysroot_result=$lt_sysroot$func_stripname_result
- esac
-# func_replace_sysroot PATH
-# If PATH begins with the sysroot, replace it with = and
-# store the result into func_replace_sysroot_result.
-func_replace_sysroot ()
- case "$lt_sysroot:$1" in
- ?*:"$lt_sysroot"*)
- func_stripname "$lt_sysroot" '' "$1"
- func_replace_sysroot_result="=$func_stripname_result"
- # Including no sysroot.
- func_replace_sysroot_result=$1
- esac
-# func_infer_tag arg
-# Infer tagged configuration to use if any are available and
-# if one wasn't chosen via the "--tag" command line option.
-# Only attempt this if the compiler in the base compile
-# command doesn't match the default compiler.
-# arg is usually of the form 'gcc ...'
-func_infer_tag ()
- $opt_debug
- if test -n "$available_tags" && test -z "$tagname"; then
- CC_quoted=
- for arg in $CC; do
- func_append_quoted CC_quoted "$arg"
- done
- CC_expanded=`func_echo_all $CC`
- CC_quoted_expanded=`func_echo_all $CC_quoted`
- case $@ in
- # Blanks in the command may have been stripped by the calling shell,
- # but not from the CC environment variable when configure was run.
- " $CC "* | "$CC "* | " $CC_expanded "* | "$CC_expanded "* | \
- " $CC_quoted"* | "$CC_quoted "* | " $CC_quoted_expanded "* | "$CC_quoted_expanded "*) ;;
- # Blanks at the start of $base_compile will cause this to fail
- # if we don't check for them as well.
- for z in $available_tags; do
- if $GREP "^# ### BEGIN LIBTOOL TAG CONFIG: $z$" < "$progpath" > /dev/null; then
- eval "`${SED} -n -e '/^# ### BEGIN LIBTOOL TAG CONFIG: '$z'$/,/^# ### END LIBTOOL TAG CONFIG: '$z'$/p' < $progpath`"
- CC_quoted=
- # Double-quote args containing other shell metacharacters.
- done
- case "$@ " in
- # The compiler in the base compile command matches
- # the one in the tagged configuration.
- # Assume this is the tagged configuration we want.
- tagname=$z
- break
- esac
- fi
- done
- # If $tagname still isn't set, then no tagged configuration
- # was found and let the user know that the "--tag" command
- # line option must be used.
- if test -z "$tagname"; then
- func_echo "unable to infer tagged configuration"
- func_fatal_error "specify a tag with \`--tag'"
-# else
-# func_verbose "using $tagname tagged configuration"
- fi
- esac
- fi
-# func_write_libtool_object output_name pic_name nonpic_name
-# Create a libtool object file (analogous to a ".la" file),
-# but don't create it if we're doing a dry run.
-func_write_libtool_object ()
- write_libobj=${1}
- write_lobj=\'${2}\'
- else
- write_lobj=none
- fi
- write_oldobj=\'${3}\'
- else
- write_oldobj=none
- fi
- $opt_dry_run || {
- cat >${write_libobj}T <<EOF
-# $write_libobj - a libtool object file
-# Generated by $PROGRAM (GNU $PACKAGE$TIMESTAMP) $VERSION
-# Please DO NOT delete this file!
-# It is necessary for linking the library.
-# Name of the PIC object.
-pic_object=$write_lobj
-# Name of the non-PIC object
-non_pic_object=$write_oldobj
-EOF
- $MV "${write_libobj}T" "${write_libobj}"
-# FILE NAME AND PATH CONVERSION HELPER FUNCTIONS #
-# func_convert_core_file_wine_to_w32 ARG
-# Helper function used by file name conversion functions when $build is *nix,
-# and $host is mingw, cygwin, or some other w32 environment. Relies on a
-# correctly configured wine environment available, with the winepath program
-# in $build's $PATH.
-# ARG is the $build file name to be converted to w32 format.
-# Result is available in $func_convert_core_file_wine_to_w32_result, and will
-# be empty on error (or when ARG is empty)
-func_convert_core_file_wine_to_w32 ()
- $opt_debug
- func_convert_core_file_wine_to_w32_result="$1"
- if test -n "$1"; then
- # Unfortunately, winepath does not exit with a non-zero error code, so we
- # are forced to check the contents of stdout. On the other hand, if the
- # command is not found, the shell will set an exit code of 127 and print
- # *an error message* to stdout. So we must check for both error code of
- # zero AND non-empty stdout, which explains the odd construction:
- func_convert_core_file_wine_to_w32_tmp=`winepath -w "$1" 2>/dev/null`
- if test "$?" -eq 0 && test -n "${func_convert_core_file_wine_to_w32_tmp}"; then
- func_convert_core_file_wine_to_w32_result=`$ECHO "$func_convert_core_file_wine_to_w32_tmp" |
- $SED -e "$lt_sed_naive_backslashify"`
- else
- fi
- fi
-# end: func_convert_core_file_wine_to_w32
-# func_convert_core_path_wine_to_w32 ARG
-# Helper function used by path conversion functions when $build is *nix, and
-# $host is mingw, cygwin, or some other w32 environment. Relies on a correctly
-# configured wine environment available, with the winepath program in $build's
-# $PATH. Assumes ARG has no leading or trailing path separator characters.
-# ARG is path to be converted from $build format to win32.
-# Result is available in $func_convert_core_path_wine_to_w32_result.
-# Unconvertible file (directory) names in ARG are skipped; if no directory names
-# are convertible, then the result may be empty.
-func_convert_core_path_wine_to_w32 ()
- $opt_debug
- # unfortunately, winepath doesn't convert paths, only file names
- func_convert_core_path_wine_to_w32_result=""
- oldIFS=$IFS
- IFS=:
- for func_convert_core_path_wine_to_w32_f in $1; do
- IFS=$oldIFS
- func_convert_core_file_wine_to_w32 "$func_convert_core_path_wine_to_w32_f"
- if test -n "$func_convert_core_file_wine_to_w32_result" ; then
- if test -z "$func_convert_core_path_wine_to_w32_result"; then
- func_convert_core_path_wine_to_w32_result="$func_convert_core_file_wine_to_w32_result"
- else
- func_append func_convert_core_path_wine_to_w32_result ";$func_convert_core_file_wine_to_w32_result"
- fi
- fi
- done
- IFS=$oldIFS
- fi
-# end: func_convert_core_path_wine_to_w32
-# func_cygpath ARGS...
-# Wrapper around calling the cygpath program via LT_CYGPATH. This is used when
-# when (1) $build is *nix and Cygwin is hosted via a wine environment; or (2)
-# $build is MSYS and $host is Cygwin, or (3) $build is Cygwin. In case (1) or
-# (2), returns the Cygwin file name or path in func_cygpath_result (input
-# file name or path is assumed to be in w32 format, as previously converted
-# from $build's *nix or MSYS format). In case (3), returns the w32 file name
-# or path in func_cygpath_result (input file name or path is assumed to be in
-# Cygwin format). Returns an empty string on error.
-# ARGS are passed to cygpath, with the last one being the file name or path to
-# be converted.
-# Specify the absolute *nix (or w32) name to cygpath in the LT_CYGPATH
-# environment variable; do not put it in $PATH.
-func_cygpath ()
- $opt_debug
- if test -n "$LT_CYGPATH" && test -f "$LT_CYGPATH"; then
- func_cygpath_result=`$LT_CYGPATH "$@" 2>/dev/null`
- if test "$?" -ne 0; then
- # on failure, ensure result is empty
- fi
- else
- func_error "LT_CYGPATH is empty or specifies non-existent file: \`$LT_CYGPATH'"
- fi
-#end: func_cygpath
-# func_convert_core_msys_to_w32 ARG
-# Convert file name or path ARG from MSYS format to w32 format. Return
-# result in func_convert_core_msys_to_w32_result.
-func_convert_core_msys_to_w32 ()
- $opt_debug
- # awkward: cmd appends spaces to result
- func_convert_core_msys_to_w32_result=`( cmd //c echo "$1" ) 2>/dev/null |
- $SED -e 's/[ ]*$//' -e "$lt_sed_naive_backslashify"`
-#end: func_convert_core_msys_to_w32
-# func_convert_file_check ARG1 ARG2
-# Verify that ARG1 (a file name in $build format) was converted to $host
-# format in ARG2. Otherwise, emit an error message, but continue (resetting
-# func_to_host_file_result to ARG1).
-func_convert_file_check ()
- $opt_debug
- if test -z "$2" && test -n "$1" ; then
- func_error "Could not determine host file name corresponding to"
- func_error " \`$1'"
- func_error "Continuing, but uninstalled executables may not work."
- # Fallback:
- func_to_host_file_result="$1"
- fi
-# end func_convert_file_check
-# func_convert_path_check FROM_PATHSEP TO_PATHSEP FROM_PATH TO_PATH
-# Verify that FROM_PATH (a path in $build format) was converted to $host
-# format in TO_PATH. Otherwise, emit an error message, but continue, resetting
-# func_to_host_file_result to a simplistic fallback value (see below).
-func_convert_path_check ()
- $opt_debug
- if test -z "$4" && test -n "$3"; then
- func_error "Could not determine the host path corresponding to"
- func_error " \`$3'"
- # Fallback. This is a deliberately simplistic "conversion" and
- # should not be "improved". See libtool.info.
- if test "x$1" != "x$2"; then
- lt_replace_pathsep_chars="s|$1|$2|g"
- func_to_host_path_result=`echo "$3" |
- $SED -e "$lt_replace_pathsep_chars"`
- else
- func_to_host_path_result="$3"
- fi
- fi
-# end func_convert_path_check
-# func_convert_path_front_back_pathsep FRONTPAT BACKPAT REPL ORIG
-# Modifies func_to_host_path_result by prepending REPL if ORIG matches FRONTPAT
-# and appending REPL if ORIG matches BACKPAT.
-func_convert_path_front_back_pathsep ()
- $opt_debug
- case $4 in
- $1 ) func_to_host_path_result="$3$func_to_host_path_result"
- esac
- case $4 in
- $2 ) func_to_host_path_result+="$3"
- esac
-# end func_convert_path_front_back_pathsep
-# $build to $host FILE NAME CONVERSION FUNCTIONS #
-# invoked via `$to_host_file_cmd ARG'
-# In each case, ARG is the path to be converted from $build to $host format.
-# Result will be available in $func_to_host_file_result.
-# func_to_host_file ARG
-# Converts the file name ARG from $build format to $host format. Return result
-# in func_to_host_file_result.
-func_to_host_file ()
- $opt_debug
- $to_host_file_cmd "$1"
-# end func_to_host_file
-# func_to_tool_file ARG LAZY
-# converts the file name ARG from $build format to toolchain format. Return
-# result in func_to_tool_file_result. If the conversion in use is listed
-# in (the comma separated) LAZY, no conversion takes place.
-func_to_tool_file ()
- $opt_debug
- case ,$2, in
- *,"$to_tool_file_cmd",*)
- func_to_tool_file_result=$1
- $to_tool_file_cmd "$1"
- func_to_tool_file_result=$func_to_host_file_result
- esac
-# end func_to_tool_file
-# func_convert_file_noop ARG
-# Copy ARG to func_to_host_file_result.
-func_convert_file_noop ()
-# end func_convert_file_noop
-# func_convert_file_msys_to_w32 ARG
-# Convert file name ARG from (mingw) MSYS to (mingw) w32 format; automatic
-# conversion to w32 is not available inside the cwrapper. Returns result in
-# func_to_host_file_result.
-func_convert_file_msys_to_w32 ()
- $opt_debug
- func_convert_core_msys_to_w32 "$1"
- func_to_host_file_result="$func_convert_core_msys_to_w32_result"
- fi
- func_convert_file_check "$1" "$func_to_host_file_result"
-# end func_convert_file_msys_to_w32
-# func_convert_file_cygwin_to_w32 ARG
-# Convert file name ARG from Cygwin to w32 format. Returns result in
-func_convert_file_cygwin_to_w32 ()
- $opt_debug
- # because $build is cygwin, we call "the" cygpath in $PATH; no need to use
- # LT_CYGPATH in this case.
- func_to_host_file_result=`cygpath -m "$1"`
- fi
-# end func_convert_file_cygwin_to_w32
-# func_convert_file_nix_to_w32 ARG
-# Convert file name ARG from *nix to w32 format. Requires a wine environment
-# and a working winepath. Returns result in func_to_host_file_result.
-func_convert_file_nix_to_w32 ()
- $opt_debug
- func_convert_core_file_wine_to_w32 "$1"
- func_to_host_file_result="$func_convert_core_file_wine_to_w32_result"
- fi
-# end func_convert_file_nix_to_w32
-# func_convert_file_msys_to_cygwin ARG
-# Convert file name ARG from MSYS to Cygwin format. Requires LT_CYGPATH set.
-# Returns result in func_to_host_file_result.
-func_convert_file_msys_to_cygwin ()
- $opt_debug
- func_cygpath -u "$func_convert_core_msys_to_w32_result"
- func_to_host_file_result="$func_cygpath_result"
- fi
-# end func_convert_file_msys_to_cygwin
-# func_convert_file_nix_to_cygwin ARG
-# Convert file name ARG from *nix to Cygwin format. Requires Cygwin installed
-# in a wine environment, working winepath, and LT_CYGPATH set. Returns result
-func_convert_file_nix_to_cygwin ()
- $opt_debug
- # convert from *nix to w32, then use cygpath to convert from w32 to cygwin.
- func_cygpath -u "$func_convert_core_file_wine_to_w32_result"
- fi
-# end func_convert_file_nix_to_cygwin
-# $build to $host PATH CONVERSION FUNCTIONS #
-# invoked via `$to_host_path_cmd ARG'
-# The result will be available in $func_to_host_path_result.
-# Path separators are also converted from $build format to $host format. If
-# ARG begins or ends with a path separator character, it is preserved (but
-# converted to $host format) on output.
-# All path conversion functions are named using the following convention:
-# file name conversion function : func_convert_file_X_to_Y ()
-# path conversion function : func_convert_path_X_to_Y ()
-# where, for any given $build/$host combination the 'X_to_Y' value is the
-# same. If conversion functions are added for new $build/$host combinations,
-# the two new functions must follow this pattern, or func_init_to_host_path_cmd
-# will break.
-# func_init_to_host_path_cmd
-# Ensures that function "pointer" variable $to_host_path_cmd is set to the
-# appropriate value, based on the value of $to_host_file_cmd.
-to_host_path_cmd=
-func_init_to_host_path_cmd ()
- $opt_debug
- if test -z "$to_host_path_cmd"; then
- func_stripname 'func_convert_file_' '' "$to_host_file_cmd"
- to_host_path_cmd="func_convert_path_${func_stripname_result}"
- fi
-# func_to_host_path ARG
-# Converts the path ARG from $build format to $host format. Return result
-# in func_to_host_path_result.
-func_to_host_path ()
- $opt_debug
- func_init_to_host_path_cmd
- $to_host_path_cmd "$1"
-# end func_to_host_path
-# func_convert_path_noop ARG
-# Copy ARG to func_to_host_path_result.
-func_convert_path_noop ()
- func_to_host_path_result="$1"
-# end func_convert_path_noop
-# func_convert_path_msys_to_w32 ARG
-# Convert path ARG from (mingw) MSYS to (mingw) w32 format; automatic
-# func_to_host_path_result.
-func_convert_path_msys_to_w32 ()
- $opt_debug
- # Remove leading and trailing path separator characters from ARG. MSYS
- # behavior is inconsistent here; cygpath turns them into '.;' and ';.';
- # and winepath ignores them completely.
- func_stripname : : "$1"
- func_to_host_path_tmp1=$func_stripname_result
- func_convert_core_msys_to_w32 "$func_to_host_path_tmp1"
- func_to_host_path_result="$func_convert_core_msys_to_w32_result"
- func_convert_path_check : ";" \
- "$func_to_host_path_tmp1" "$func_to_host_path_result"
- func_convert_path_front_back_pathsep ":*" "*:" ";" "$1"
- fi
-# end func_convert_path_msys_to_w32
-# func_convert_path_cygwin_to_w32 ARG
-# Convert path ARG from Cygwin to w32 format. Returns result in
-func_convert_path_cygwin_to_w32 ()
- $opt_debug
- # See func_convert_path_msys_to_w32:
- func_to_host_path_result=`cygpath -m -p "$func_to_host_path_tmp1"`
- fi
-# end func_convert_path_cygwin_to_w32
-# func_convert_path_nix_to_w32 ARG
-# Convert path ARG from *nix to w32 format. Requires a wine environment and
-# a working winepath. Returns result in func_to_host_file_result.
-func_convert_path_nix_to_w32 ()
- $opt_debug
- func_convert_core_path_wine_to_w32 "$func_to_host_path_tmp1"
- func_to_host_path_result="$func_convert_core_path_wine_to_w32_result"
- fi
-# end func_convert_path_nix_to_w32
-# func_convert_path_msys_to_cygwin ARG
-# Convert path ARG from MSYS to Cygwin format. Requires LT_CYGPATH set.
-func_convert_path_msys_to_cygwin ()
- $opt_debug
- func_cygpath -u -p "$func_convert_core_msys_to_w32_result"
- func_to_host_path_result="$func_cygpath_result"
- func_convert_path_check : : \
- func_convert_path_front_back_pathsep ":*" "*:" : "$1"
- fi
-# end func_convert_path_msys_to_cygwin
-# func_convert_path_nix_to_cygwin ARG
-# Convert path ARG from *nix to Cygwin format. Requires Cygwin installed in a
-# a wine environment, working winepath, and LT_CYGPATH set. Returns result in
-func_convert_path_nix_to_cygwin ()
- $opt_debug
- # ARG. msys behavior is inconsistent here, cygpath turns them
- # into '.;' and ';.', and winepath ignores them completely.
- func_cygpath -u -p "$func_convert_core_path_wine_to_w32_result"
- fi
-# end func_convert_path_nix_to_cygwin
-# func_mode_compile arg...
-func_mode_compile ()
- $opt_debug
- # Get the compilation command and the source file.
- base_compile=
- srcfile="$nonopt" # always keep a non-empty value in "srcfile"
- suppress_opt=yes
- suppress_output=
- arg_mode=normal
- libobj=
- later=
- pie_flag=
- for arg
- do
- case $arg_mode in
- arg )
- # do not "continue". Instead, add this to base_compile
- lastarg="$arg"
- arg_mode=normal
- target )
- libobj="$arg"
- arg_mode=normal
- continue
- normal )
- # Accept any command-line options.
- case $arg in
- -o)
- test -n "$libobj" && \
- func_fatal_error "you cannot specify \`-o' more than once"
- arg_mode=target
- continue
- -pie | -fpie | -fPIE)
- pie_flag+=" $arg"
- continue
- -shared | -static | -prefer-pic | -prefer-non-pic)
- later+=" $arg"
- continue
- -no-suppress)
- suppress_opt=no
- continue
- -Xcompiler)
- arg_mode=arg # the next one goes into the "base_compile" arg list
- continue # The current "srcfile" will either be retained or
- ;; # replaced later. I would guess that would be a bug.
- -Wc,*)
- func_stripname '-Wc,' '' "$arg"
- args=$func_stripname_result
- lastarg=
- save_ifs="$IFS"; IFS=','
- for arg in $args; do
- IFS="$save_ifs"
- func_append_quoted lastarg "$arg"
- done
- IFS="$save_ifs"
- func_stripname ' ' '' "$lastarg"
- lastarg=$func_stripname_result
- # Add the arguments to base_compile.
- base_compile+=" $lastarg"
- continue
- # Accept the current argument as the source file.
- # The previous "srcfile" becomes the current argument.
- lastarg="$srcfile"
- srcfile="$arg"
- esac # case $arg
- esac # case $arg_mode
- # Aesthetically quote the previous argument.
- func_append_quoted base_compile "$lastarg"
- done # for arg
- case $arg_mode in
- arg)
- func_fatal_error "you must specify an argument for -Xcompile"
- target)
- func_fatal_error "you must specify a target with \`-o'"
- # Get the name of the library object.
- test -z "$libobj" && {
- func_basename "$srcfile"
- libobj="$func_basename_result"
- esac
- # Recognize several different file suffixes.
- # If the user specifies -o file.o, it is replaced with file.lo
- case $libobj in
- *.[cCFSifmso] | \
- *.ada | *.adb | *.ads | *.asm | \
- *.c++ | *.cc | *.ii | *.class | *.cpp | *.cxx | \
- *.[fF][09]? | *.for | *.java | *.go | *.obj | *.sx | *.cu | *.cup)
- func_xform "$libobj"
- libobj=$func_xform_result
- esac
- case $libobj in
- *.lo) func_lo2o "$libobj"; obj=$func_lo2o_result ;;
- func_fatal_error "cannot determine name of library object from \`$libobj'"
- esac
- func_infer_tag $base_compile
- for arg in $later; do
- case $arg in
- -shared)
- test "$build_libtool_libs" != yes && \
- func_fatal_configuration "can not build a shared library"
- build_old_libs=no
- continue
- -static)
- build_libtool_libs=no
- build_old_libs=yes
- continue
- -prefer-pic)
- pic_mode=yes
- continue
- -prefer-non-pic)
- pic_mode=no
- continue
- esac
- done
- func_quote_for_eval "$libobj"
- test "X$libobj" != "X$func_quote_for_eval_result" \
- && $ECHO "X$libobj" | $GREP '[]~#^*{};<>?"'"'"' &()|`$[]' \
- && func_warning "libobj name \`$libobj' may not contain shell special characters."
- func_dirname_and_basename "$obj" "/" ""
- objname="$func_basename_result"
- xdir="$func_dirname_result"
- lobj=${xdir}$objdir/$objname
- test -z "$base_compile" && \
- func_fatal_help "you must specify a compilation command"
- # Delete any leftover library objects.
- removelist="$obj $lobj $libobj ${libobj}T"
- else
- removelist="$lobj $libobj ${libobj}T"
- fi
- # On Cygwin there's no "real" PIC flag so we must build both object types
- case $host_os in
- cygwin* | mingw* | pw32* | os2* | cegcc*)
- pic_mode=default
- esac
- if test "$pic_mode" = no && test "$deplibs_check_method" != pass_all; then
- # non-PIC code in shared libraries is not supported
- pic_mode=default
- fi
- # Calculate the filename of the output object if compiler does
- # not support -o with -c
- if test "$compiler_c_o" = no; then
- output_obj=`$ECHO "$srcfile" | $SED 's%^.*/%%; s%\.[^.]*$%%'`.${objext}
- lockfile="$output_obj.lock"
- else
- output_obj=
- need_locks=no
- lockfile=
- fi
- # Lock this critical section if it is needed
- # We use this script file to make the link, it avoids creating a new file
- if test "$need_locks" = yes; then
- until $opt_dry_run || ln "$progpath" "$lockfile" 2>/dev/null; do
- func_echo "Waiting for $lockfile to be removed"
- sleep 2
- done
- elif test "$need_locks" = warn; then
- if test -f "$lockfile"; then
- $ECHO "\
-*** ERROR, $lockfile exists and contains:
-`cat $lockfile 2>/dev/null`
-This indicates that another process is trying to use the same
-temporary object file, and libtool could not work around it because
-your compiler does not support \`-c' and \`-o' together. If you
-repeat this compilation, it may succeed, by chance, but you had better
-avoid parallel builds (make -j) in this platform, or get a better
-compiler."
- $opt_dry_run || $RM $removelist
- fi
- removelist+=" $output_obj"
- $ECHO "$srcfile" > "$lockfile"
- fi
- removelist+=" $lockfile"
- trap '$opt_dry_run || $RM $removelist; exit $EXIT_FAILURE' 1 2 15
- func_to_tool_file "$srcfile" func_convert_file_msys_to_w32
- srcfile=$func_to_tool_file_result
- func_quote_for_eval "$srcfile"
- qsrcfile=$func_quote_for_eval_result
- # Only build a PIC object if we are building libtool libraries.
- # Without this assignment, base_compile gets emptied.
- fbsd_hideous_sh_bug=$base_compile
- if test "$pic_mode" != no; then
- command="$base_compile $qsrcfile $pic_flag"
- else
- # Don't build PIC code
- command="$base_compile $qsrcfile"
- fi
- func_mkdir_p "$xdir$objdir"
- if test -z "$output_obj"; then
- # Place PIC objects in $objdir
- command+=" -o $lobj"
- fi
- func_show_eval_locale "$command" \
- 'test -n "$output_obj" && $RM $removelist; exit $EXIT_FAILURE'
- if test "$need_locks" = warn &&
- test "X`cat $lockfile 2>/dev/null`" != "X$srcfile"; then
- $ECHO "\
-*** ERROR, $lockfile contains:
-but it should contain:
-$srcfile
-compiler."
- fi
- # Just move the object if needed, then go on to compile the next one
- if test -n "$output_obj" && test "X$output_obj" != "X$lobj"; then
- func_show_eval '$MV "$output_obj" "$lobj"' \
- 'error=$?; $opt_dry_run || $RM $removelist; exit $error'
- fi
- # Allow error messages only from the first compilation.
- if test "$suppress_opt" = yes; then
- suppress_output=' >/dev/null 2>&1'
- fi
- fi
- # Only build a position-dependent object if we build old libraries.
- if test "$pic_mode" != yes; then
- command="$base_compile $qsrcfile$pie_flag"
- else
- fi
- if test "$compiler_c_o" = yes; then
- command+=" -o $obj"
- fi
- # Suppress compiler output if we already did a PIC compilation.
- command+="$suppress_output"
- '$opt_dry_run || $RM $removelist; exit $EXIT_FAILURE'
- $ECHO "\
-$srcfile
-compiler."
- fi
- if test -n "$output_obj" && test "X$output_obj" != "X$obj"; then
- func_show_eval '$MV "$output_obj" "$obj"' \
- fi
- fi
- $opt_dry_run || {
- func_write_libtool_object "$libobj" "$objdir/$objname" "$objname"
- # Unlock the critical section if it was locked
- if test "$need_locks" != no; then
- removelist=$lockfile
- $RM "$lockfile"
- fi
- exit $EXIT_SUCCESS
-$opt_help || {
- test "$opt_mode" = compile && func_mode_compile ${1+"$@"}
-func_mode_help ()
- # We need to display help for each of the modes.
- case $opt_mode in
- # Generic help is extracted from the usage comments
- # at the start of this file.
- func_help
- clean)
- $ECHO \
-"Usage: $progname [OPTION]... --mode=clean RM [RM-OPTION]... FILE...
-Remove files from the build directory.
-RM is the name of the program to use to delete files associated with each FILE
-(typically \`/bin/rm'). RM-OPTIONS are options (such as \`-f') to be passed
-to RM.
-If FILE is a libtool library, object or program, all the files associated
-with it are deleted. Otherwise, only FILE itself is deleted using RM."
- compile)
- $ECHO \
-"Usage: $progname [OPTION]... --mode=compile COMPILE-COMMAND... SOURCEFILE
-Compile a source file into a libtool library object.
-This mode accepts the following additional options:
- -o OUTPUT-FILE set the output file name to OUTPUT-FILE
- -no-suppress do not suppress compiler output for multiple passes
- -prefer-pic try to build PIC objects only
- -prefer-non-pic try to build non-PIC objects only
- -shared do not build a \`.o' file suitable for static linking
- -static only build a \`.o' file suitable for static linking
- -Wc,FLAG pass FLAG directly to the compiler
-COMPILE-COMMAND is a command to be used in creating a \`standard' object file
-from the given SOURCEFILE.
-The output file name is determined by removing the directory component from
-SOURCEFILE, then substituting the C source code suffix \`.c' with the
-library object suffix, \`.lo'."
- execute)
- $ECHO \
-"Usage: $progname [OPTION]... --mode=execute COMMAND [ARGS]...
-Automatically set library path, then run a program.
- -dlopen FILE add the directory containing FILE to the library path
-This mode sets the library path environment variable according to \`-dlopen'
-flags.
-If any of the ARGS are libtool executable wrappers, then they are translated
-into their corresponding uninstalled binary, and any of their required library
-directories are added to the library path.
-Then, COMMAND is executed, with ARGS as arguments."
- finish)
- $ECHO \
-"Usage: $progname [OPTION]... --mode=finish [LIBDIR]...
-Complete the installation of libtool libraries.
-Each LIBDIR is a directory that contains libtool libraries.
-The commands that this mode executes may require superuser privileges. Use
-the \`--dry-run' option if you just want to see what would be executed."
- install)
- $ECHO \
-"Usage: $progname [OPTION]... --mode=install INSTALL-COMMAND...
-Install executables or libraries.
-INSTALL-COMMAND is the installation command. The first component should be
-either the \`install' or \`cp' program.
-The following components of INSTALL-COMMAND are treated specially:
- -inst-prefix-dir PREFIX-DIR Use PREFIX-DIR as a staging area for installation
-The rest of the components are interpreted as arguments to that command (only
-BSD-compatible install options are recognized)."
- link)
- $ECHO \
-"Usage: $progname [OPTION]... --mode=link LINK-COMMAND...
-Link object files or libraries together to form another library, or to
-create an executable program.
-LINK-COMMAND is a command using the C compiler that you would use to create
-a program from several object files.
-The following components of LINK-COMMAND are treated specially:
- -all-static do not do any dynamic linking at all
- -avoid-version do not add a version suffix if possible
- -bindir BINDIR specify path to binaries directory (for systems where
- libraries must be found in the PATH setting at runtime)
- -dlopen FILE \`-dlpreopen' FILE if it cannot be dlopened at runtime
- -dlpreopen FILE link in FILE and add its symbols to lt_preloaded_symbols
- -export-dynamic allow symbols from OUTPUT-FILE to be resolved with dlsym(3)
- -export-symbols SYMFILE
- try to export only the symbols listed in SYMFILE
- -export-symbols-regex REGEX
- try to export only the symbols matching REGEX
- -LLIBDIR search LIBDIR for required installed libraries
- -lNAME OUTPUT-FILE requires the installed library libNAME
- -module build a library that can dlopened
- -no-fast-install disable the fast-install mode
- -no-install link a not-installable executable
- -no-undefined declare that a library does not refer to external symbols
- -o OUTPUT-FILE create OUTPUT-FILE from the specified objects
- -objectlist FILE Use a list of object files found in FILE to specify objects
- -precious-files-regex REGEX
- don't remove output files matching REGEX
- -release RELEASE specify package release information
- -rpath LIBDIR the created library will eventually be installed in LIBDIR
- -R[ ]LIBDIR add LIBDIR to the runtime path of programs and libraries
- -shared only do dynamic linking of libtool libraries
- -shrext SUFFIX override the standard shared library file extension
- -static do not do any dynamic linking of uninstalled libtool libraries
- -static-libtool-libs
- do not do any dynamic linking of libtool libraries
- -version-info CURRENT[:REVISION[:AGE]]
- specify library version info [each variable defaults to 0]
- -weak LIBNAME declare that the target provides the LIBNAME interface
- -Wc,FLAG
- -Xcompiler FLAG pass linker-specific FLAG directly to the compiler
- -Wl,FLAG
- -Xlinker FLAG pass linker-specific FLAG directly to the linker
- -XCClinker FLAG pass link-specific FLAG to the compiler driver (CC)
-All other options (arguments beginning with \`-') are ignored.
-Every other argument is treated as a filename. Files ending in \`.la' are
-treated as uninstalled libtool libraries, other files are standard or library
-object files.
-If the OUTPUT-FILE ends in \`.la', then a libtool library is created,
-only library objects (\`.lo' files) may be specified, and \`-rpath' is
-required, except when creating a convenience library.
-If OUTPUT-FILE ends in \`.a' or \`.lib', then a standard library is created
-using \`ar' and \`ranlib', or on Windows using \`lib'.
-If OUTPUT-FILE ends in \`.lo' or \`.${objext}', then a reloadable object file
-is created, otherwise an executable program is created."
- uninstall)
- $ECHO \
-"Usage: $progname [OPTION]... --mode=uninstall RM [RM-OPTION]... FILE...
-Remove libraries from an installation directory.
-to RM.
-If FILE is a libtool library, all the files associated with it are deleted.
-Otherwise, only FILE itself is deleted using RM."
- func_fatal_help "invalid operation mode \`$opt_mode'"
- esac
- echo
- $ECHO "Try \`$progname --help' for more information about other modes."
-# Now that we've collected a possible --mode arg, show help if necessary
-if $opt_help; then
- if test "$opt_help" = :; then
- func_mode_help
- else
- func_help noexit
- for opt_mode in compile link execute install finish uninstall clean; do
- func_mode_help
- done
- } | sed -n '1p; 2,$s/^Usage:/ or: /p'
- func_help noexit
- echo
- func_mode_help
- done
- sed '1d
- /^When reporting/,/^Report/{
- H
- d
- $x
- /information about other modes/d
- /more detailed .*MODE/d
- s/^Usage:.*--mode=\([^ ]*\) .*/Description of \1 mode:/'
- fi
- exit $?
-fi
-# func_mode_execute arg...
-func_mode_execute ()
- $opt_debug
- # The first argument is the command name.
- cmd="$nonopt"
- test -z "$cmd" && \
- func_fatal_help "you must specify a COMMAND"
- # Handle -dlopen flags immediately.
- for file in $opt_dlopen; do
- test -f "$file" \
- || func_fatal_help "\`$file' is not a file"
- dir=
- case $file in
- *.la)
- func_resolve_sysroot "$file"
- file=$func_resolve_sysroot_result
- # Check to see that this really is a libtool archive.
- func_lalib_unsafe_p "$file" \
- || func_fatal_help "\`$lib' is not a valid libtool archive"
- # Read the libtool library.
- dlname=
- library_names=
- func_source "$file"
- # Skip this library if it cannot be dlopened.
- if test -z "$dlname"; then
- # Warn if it was a shared library.
- test -n "$library_names" && \
- func_warning "\`$file' was not linked with \`-export-dynamic'"
- continue
- fi
- func_dirname "$file" "" "."
- dir="$func_dirname_result"
- if test -f "$dir/$objdir/$dlname"; then
- dir+="/$objdir"
- else
- if test ! -f "$dir/$dlname"; then
- func_fatal_error "cannot find \`$dlname' in \`$dir' or \`$dir/$objdir'"
- fi
- fi
- *.lo)
- # Just add the directory containing the .lo file.
- func_warning "\`-dlopen' is ignored for non-libtool libraries and objects"
- continue
- esac
- # Get the absolute pathname.
- absdir=`cd "$dir" && pwd`
- test -n "$absdir" && dir="$absdir"
- # Now add the directory to shlibpath_var.
- if eval "test -z \"\$$shlibpath_var\""; then
- eval "$shlibpath_var=\"\$dir\""
- else
- eval "$shlibpath_var=\"\$dir:\$$shlibpath_var\""
- fi
- done
- # This variable tells wrapper scripts just to set shlibpath_var
- # rather than running their programs.
- libtool_execute_magic="$magic"
- # Check if any of the arguments is a wrapper script.
- args=
- for file
- do
- case $file in
- -* | *.la | *.lo ) ;;
- # Do a test to see if this is really a libtool program.
- if func_ltwrapper_script_p "$file"; then
- # Transform arg to wrapped name.
- file="$progdir/$program"
- elif func_ltwrapper_executable_p "$file"; then
- func_ltwrapper_scriptname "$file"
- func_source "$func_ltwrapper_scriptname_result"
- fi
- esac
- # Quote arguments (to preserve shell metacharacters).
- func_append_quoted args "$file"
- done
- if test "X$opt_dry_run" = Xfalse; then
- if test -n "$shlibpath_var"; then
- # Export the shlibpath_var.
- eval "export $shlibpath_var"
- fi
- # Restore saved environment variables
- for lt_var in LANG LANGUAGE LC_ALL LC_CTYPE LC_COLLATE LC_MESSAGES
- do
- eval "if test \"\${save_$lt_var+set}\" = set; then
- $lt_var=\$save_$lt_var; export $lt_var
- else
- $lt_unset $lt_var
- fi"
- done
- # Now prepare to actually exec the command.
- exec_cmd="\$cmd$args"
- else
- # Display what would be done.
- eval "\$ECHO \"\$shlibpath_var=\$$shlibpath_var\""
- echo "export $shlibpath_var"
- fi
- $ECHO "$cmd$args"
- fi
-test "$opt_mode" = execute && func_mode_execute ${1+"$@"}
-# func_mode_finish arg...
-func_mode_finish ()
- $opt_debug
- libs=
- libdirs=
- admincmds=
- for opt in "$nonopt" ${1+"$@"}
- do
- if test -d "$opt"; then
- libdirs+=" $opt"
- elif test -f "$opt"; then
- if func_lalib_unsafe_p "$opt"; then
- libs+=" $opt"
- else
- func_warning "\`$opt' is not a valid libtool archive"
- fi
- else
- func_fatal_error "invalid argument \`$opt'"
- fi
- done
- if test -n "$libs"; then
- if test -n "$lt_sysroot"; then
- sysroot_regex=`$ECHO "$lt_sysroot" | $SED "$sed_make_literal_regex"`
- sysroot_cmd="s/\([ ']\)$sysroot_regex/\1/g;"
- else
- sysroot_cmd=
- fi
- # Remove sysroot references
- if $opt_dry_run; then
- for lib in $libs; do
- echo "removing references to $lt_sysroot and \`=' prefixes from $lib"
- done
- else
- tmpdir=`func_mktempdir`
- sed -e "${sysroot_cmd} s/\([ ']-[LR]\)=/\1/g; s/\([ ']\)=/\1/g" $lib \
- > $tmpdir/tmp-la
- mv -f $tmpdir/tmp-la $lib
- done
- ${RM}r "$tmpdir"
- fi
- fi
- if test -n "$finish_cmds$finish_eval" && test -n "$libdirs"; then
- for libdir in $libdirs; do
- if test -n "$finish_cmds"; then
- # Do each command in the finish commands.
- func_execute_cmds "$finish_cmds" 'admincmds="$admincmds
-'"$cmd"'"'
- fi
- if test -n "$finish_eval"; then
- # Do the single finish_eval.
- eval cmds=\"$finish_eval\"
- $opt_dry_run || eval "$cmds" || admincmds+="
- $cmds"
- fi
- done
- fi
- # Exit here if they wanted silent mode.
- $opt_silent && exit $EXIT_SUCCESS
- echo "----------------------------------------------------------------------"
- echo "Libraries have been installed in:"
- $ECHO " $libdir"
- done
- echo
- echo "If you ever happen to want to link against installed libraries"
- echo "in a given directory, LIBDIR, you must either use libtool, and"
- echo "specify the full pathname of the library, or use the \`-LLIBDIR'"
- echo "flag during linking and do at least one of the following:"
- echo " - add LIBDIR to the \`$shlibpath_var' environment variable"
- echo " during execution"
- fi
- if test -n "$runpath_var"; then
- echo " - add LIBDIR to the \`$runpath_var' environment variable"
- echo " during linking"
- fi
- if test -n "$hardcode_libdir_flag_spec"; then
- libdir=LIBDIR
- eval flag=\"$hardcode_libdir_flag_spec\"
- $ECHO " - use the \`$flag' linker flag"
- fi
- if test -n "$admincmds"; then
- $ECHO " - have your system administrator run these commands:$admincmds"
- fi
- if test -f /etc/ld.so.conf; then
- echo " - have your system administrator add LIBDIR to \`/etc/ld.so.conf'"
- fi
- echo
- echo "See any operating system documentation about shared libraries for"
- case $host in
- solaris2.[6789]|solaris2.1[0-9])
- echo "more information, such as the ld(1), crle(1) and ld.so(8) manual"
- echo "pages."
- echo "more information, such as the ld(1) and ld.so(8) manual pages."
- esac
- fi
-test "$opt_mode" = finish && func_mode_finish ${1+"$@"}
-# func_mode_install arg...
-func_mode_install ()
- $opt_debug
- # There may be an optional sh(1) argument at the beginning of
- # install_prog (especially on Windows NT).
- if test "$nonopt" = "$SHELL" || test "$nonopt" = /bin/sh ||
- # Allow the use of GNU shtool's install command.
- case $nonopt in *shtool*) :;; *) false;; esac; then
- # Aesthetically quote it.
- func_quote_for_eval "$nonopt"
- install_prog="$func_quote_for_eval_result "
- arg=$1
- shift
- else
- install_prog=
- arg=$nonopt
- fi
- # The real first argument should be the name of the installation program.
- func_quote_for_eval "$arg"
- install_prog+="$func_quote_for_eval_result"
- install_shared_prog=$install_prog
- case " $install_prog " in
- *[\\\ /]cp\ *) install_cp=: ;;
- *) install_cp=false ;;
- esac
- # We need to accept at least all the BSD install flags.
- dest=
- files=
- opts=
- prev=
- install_type=
- isdir=no
- stripme=
- no_mode=:
- for arg
- do
- arg2=
- if test -n "$dest"; then
- files+=" $dest"
- dest=$arg
- continue
- fi
- case $arg in
- -d) isdir=yes ;;
- -f)
- if $install_cp; then :; else
- prev=$arg
- fi
- -g | -m | -o)
- prev=$arg
- -s)
- stripme=" -s"
- continue
- # If the previous option needed an argument, then skip it.
- if test -n "$prev"; then
- if test "x$prev" = x-m && test -n "$install_override_mode"; then
- arg2=$install_override_mode
- no_mode=false
- fi
- prev=
- else
- dest=$arg
- continue
- fi
- esac
- # Aesthetically quote the argument.
- install_prog+=" $func_quote_for_eval_result"
- if test -n "$arg2"; then
- func_quote_for_eval "$arg2"
- fi
- install_shared_prog+=" $func_quote_for_eval_result"
- done
- test -z "$install_prog" && \
- func_fatal_help "you must specify an install program"
- test -n "$prev" && \
- func_fatal_help "the \`$prev' option requires an argument"
- if test -n "$install_override_mode" && $no_mode; then
- func_quote_for_eval "$install_override_mode"
- install_shared_prog+=" -m $func_quote_for_eval_result"
- fi
- fi
- if test -z "$files"; then
- if test -z "$dest"; then
- func_fatal_help "no file or destination specified"
- else
- func_fatal_help "you must specify a destination"
- fi
- fi
- # Strip any trailing slash from the destination.
- func_stripname '' '/' "$dest"
- dest=$func_stripname_result
- # Check to see that the destination is a directory.
- test -d "$dest" && isdir=yes
- if test "$isdir" = yes; then
- destdir="$dest"
- destname=
- else
- func_dirname_and_basename "$dest" "" "."
- destdir="$func_dirname_result"
- destname="$func_basename_result"
- # Not a directory, so check to see that there is only one file specified.
- set dummy $files; shift
- test "$#" -gt 1 && \
- func_fatal_help "\`$dest' is not a directory"
- fi
- case $destdir in
- [\\/]* | [A-Za-z]:[\\/]*) ;;
- for file in $files; do
- case $file in
- *.lo) ;;
- func_fatal_help "\`$destdir' must be an absolute directory name"
- esac
- done
- esac
- # This variable tells wrapper scripts just to set variables rather
- # than running their programs.
- libtool_install_magic="$magic"
- staticlibs=
- future_libdirs=
- current_libdirs=
- # Do each installation.
- case $file in
- *.$libext)
- # Do the static libraries later.
- staticlibs+=" $file"
- *.la)
- || func_fatal_help "\`$file' is not a valid libtool archive"
- library_names=
- old_library=
- relink_command=
- # Add the libdir to current_libdirs if it is the destination.
- if test "X$destdir" = "X$libdir"; then
- case "$current_libdirs " in
- *" $libdir "*) ;;
- *) current_libdirs+=" $libdir" ;;
- esac
- else
- # Note the libdir as a future libdir.
- case "$future_libdirs " in
- *" $libdir "*) ;;
- *) future_libdirs+=" $libdir" ;;
- esac
- fi
- func_dirname "$file" "/" ""
- dir+="$objdir"
- if test -n "$relink_command"; then
- # Determine the prefix the user has applied to our future dir.
- inst_prefix_dir=`$ECHO "$destdir" | $SED -e "s%$libdir\$%%"`
- # Don't allow the user to place us outside of our expected
- # location b/c this prevents finding dependent libraries that
- # are installed to the same prefix.
- # At present, this check doesn't affect windows .dll's that
- # are installed into $libdir/../bin (currently, that works fine)
- # but it's something to keep an eye on.
- test "$inst_prefix_dir" = "$destdir" && \
- func_fatal_error "error: cannot install \`$file' to a directory not ending in $libdir"
- if test -n "$inst_prefix_dir"; then
- # Stick the inst_prefix_dir data into the link command.
- relink_command=`$ECHO "$relink_command" | $SED "s%@inst_prefix_dir@%-inst-prefix-dir $inst_prefix_dir%"`
- else
- relink_command=`$ECHO "$relink_command" | $SED "s%@inst_prefix_dir@%%"`
- fi
- func_warning "relinking \`$file'"
- func_show_eval "$relink_command" \
- 'func_fatal_error "error: relink \`$file'\'' with the above command before installing it"'
- fi
- # See the names of the shared library.
- set dummy $library_names; shift
- realname="$1"
- shift
- srcname="$realname"
- test -n "$relink_command" && srcname="$realname"T
- # Install the shared library and build the symlinks.
- func_show_eval "$install_shared_prog $dir/$srcname $destdir/$realname" \
- 'exit $?'
- tstripme="$stripme"
- case $host_os in
- cygwin* | mingw* | pw32* | cegcc*)
- case $realname in
- *.dll.a)
- tstripme=""
- esac
- esac
- if test -n "$tstripme" && test -n "$striplib"; then
- func_show_eval "$striplib $destdir/$realname" 'exit $?'
- fi
- # Delete the old symlinks, and create new ones.
- # Try `ln -sf' first, because the `ln' binary might depend on
- # the symlink we replace! Solaris /bin/ln does not understand -f,
- # so we also need to try rm && ln -s.
- for linkname
- do
- test "$linkname" != "$realname" \
- && func_show_eval "(cd $destdir && { $LN_S -f $realname $linkname || { $RM $linkname && $LN_S $realname $linkname; }; })"
- done
- fi
- # Do each command in the postinstall commands.
- lib="$destdir/$realname"
- func_execute_cmds "$postinstall_cmds" 'exit $?'
- fi
- # Install the pseudo-library for information purposes.
- func_basename "$file"
- name="$func_basename_result"
- instname="$dir/$name"i
- func_show_eval "$install_prog $instname $destdir/$name" 'exit $?'
- # Maybe install the static library, too.
- test -n "$old_library" && staticlibs+=" $dir/$old_library"
- *.lo)
- # Install (i.e. copy) a libtool object.
- # Figure out destination file name, if it wasn't already specified.
- if test -n "$destname"; then
- destfile="$destdir/$destname"
- else
- destfile="$func_basename_result"
- destfile="$destdir/$destfile"
- fi
- # Deduce the name of the destination old-style object file.
- case $destfile in
- *.lo)
- func_lo2o "$destfile"
- staticdest=$func_lo2o_result
- *.$objext)
- staticdest="$destfile"
- destfile=
- func_fatal_help "cannot copy a libtool object to \`$destfile'"
- esac
- # Install the libtool object if requested.
- test -n "$destfile" && \
- func_show_eval "$install_prog $file $destfile" 'exit $?'
- # Install the old object if enabled.
- # Deduce the name of the old-style object file.
- func_lo2o "$file"
- staticobj=$func_lo2o_result
- func_show_eval "$install_prog \$staticobj \$staticdest" 'exit $?'
- fi
- else
- fi
- # If the file is missing, and there is a .exe on the end, strip it
- # because it is most likely a libtool script we actually want to
- # install
- stripped_ext=""
- case $file in
- *.exe)
- if test ! -f "$file"; then
- func_stripname '' '.exe' "$file"
- file=$func_stripname_result
- stripped_ext=".exe"
- fi
- esac
- case $host in
- *cygwin* | *mingw*)
- if func_ltwrapper_executable_p "$file"; then
- wrapper=$func_ltwrapper_scriptname_result
- else
- wrapper=$func_stripname_result
- fi
- wrapper=$file
- esac
- if func_ltwrapper_script_p "$wrapper"; then
- notinst_deplibs=
- relink_command=
- func_source "$wrapper"
- # Check the variables that should have been set.
- test -z "$generated_by_libtool_version" && \
- func_fatal_error "invalid libtool wrapper script \`$wrapper'"
- finalize=yes
- for lib in $notinst_deplibs; do
- # Check to see that each library is installed.
- libdir=
- if test -f "$lib"; then
- func_source "$lib"
- fi
- libfile="$libdir/"`$ECHO "$lib" | $SED 's%^.*/%%g'` ### testsuite: skip nested quoting test
- if test -n "$libdir" && test ! -f "$libfile"; then
- func_warning "\`$lib' has not been installed in \`$libdir'"
- finalize=no
- fi
- done
- relink_command=
- outputname=
- if test "$fast_install" = no && test -n "$relink_command"; then
- $opt_dry_run || {
- if test "$finalize" = yes; then
- func_basename "$file$stripped_ext"
- file="$func_basename_result"
- outputname="$tmpdir/$file"
- # Replace the output file specification.
- relink_command=`$ECHO "$relink_command" | $SED 's%@OUTPUT@%'"$outputname"'%g'`
- $opt_silent || {
- func_quote_for_expand "$relink_command"
- if eval "$relink_command"; then :
- else
- func_error "error: relink \`$file' with the above command before installing it"
- $opt_dry_run || ${RM}r "$tmpdir"
- continue
- fi
- file="$outputname"
- else
- func_warning "cannot relink \`$file'"
- fi
- else
- # Install the binary that we compiled earlier.
- file=`$ECHO "$file$stripped_ext" | $SED "s%\([^/]*\)$%$objdir/\1%"`
- fi
- fi
- # remove .exe since cygwin /usr/bin/install will append another
- # one anyway
- case $install_prog,$host in
- */usr/bin/install*,*cygwin*)
- case $file:$destfile in
- *.exe:*.exe)
- # this is ok
- *.exe:*)
- destfile=$destfile.exe
- *:*.exe)
- func_stripname '' '.exe' "$destfile"
- destfile=$func_stripname_result
- esac
- esac
- func_show_eval "$install_prog\$stripme \$file \$destfile" 'exit $?'
- $opt_dry_run || if test -n "$outputname"; then
- ${RM}r "$tmpdir"
- fi
- esac
- done
- for file in $staticlibs; do
- # Set up the ranlib parameters.
- oldlib="$destdir/$name"
- func_to_tool_file "$oldlib" func_convert_file_msys_to_w32
- tool_oldlib=$func_to_tool_file_result
- func_show_eval "$install_prog \$file \$oldlib" 'exit $?'
- if test -n "$stripme" && test -n "$old_striplib"; then
- func_show_eval "$old_striplib $tool_oldlib" 'exit $?'
- fi
- func_execute_cmds "$old_postinstall_cmds" 'exit $?'
- done
- test -n "$future_libdirs" && \
- func_warning "remember to run \`$progname --finish$future_libdirs'"
- if test -n "$current_libdirs"; then
- # Maybe just do a dry run.
- $opt_dry_run && current_libdirs=" -n$current_libdirs"
- exec_cmd='$SHELL $progpath $preserve_args --finish$current_libdirs'
- else
- fi
-test "$opt_mode" = install && func_mode_install ${1+"$@"}
-# func_generate_dlsyms outputname originator pic_p
-# Extract symbols from dlprefiles and create ${outputname}S.o with
-# a dlpreopen symbol table.
-func_generate_dlsyms ()
- $opt_debug
- my_outputname="$1"
- my_originator="$2"
- my_pic_p="${3-no}"
- my_prefix=`$ECHO "$my_originator" | sed 's%[^a-zA-Z0-9]%_%g'`
- my_dlsyms=
- if test -n "$dlfiles$dlprefiles" || test "$dlself" != no; then
- if test -n "$NM" && test -n "$global_symbol_pipe"; then
- my_dlsyms="${my_outputname}S.c"
- else
- func_error "not configured to extract global symbols from dlpreopened files"
- fi
- fi
- if test -n "$my_dlsyms"; then
- case $my_dlsyms in
- *.c)
- # Discover the nlist of each of the dlfiles.
- nlist="$output_objdir/${my_outputname}.nm"
- func_show_eval "$RM $nlist ${nlist}S ${nlist}T"
- # Parse the name list into a source file.
- func_verbose "creating $output_objdir/$my_dlsyms"
- $opt_dry_run || $ECHO > "$output_objdir/$my_dlsyms" "\
-/* $my_dlsyms - symbol resolution table for \`$my_outputname' dlsym emulation. */
-/* Generated by $PROGRAM (GNU $PACKAGE$TIMESTAMP) $VERSION */
-#ifdef __cplusplus
-extern \"C\" {
-#endif
-#if defined(__GNUC__) && (((__GNUC__ == 4) && (__GNUC_MINOR__ >= 4)) || (__GNUC__ > 4))
-#pragma GCC diagnostic ignored \"-Wstrict-prototypes\"
-#endif
-/* Keep this code in sync between libtool.m4, ltmain, lt_system.h, and tests. */
-#if defined(_WIN32) || defined(__CYGWIN__) || defined(_WIN32_WCE)
-/* DATA imports from DLLs on WIN32 con't be const, because runtime
- relocations are performed -- see ld's documentation on pseudo-relocs. */
-# define LT_DLSYM_CONST
-#elif defined(__osf__)
-/* This system does not cope well with relocations in const data. */
-#else
-# define LT_DLSYM_CONST const
-#endif
-/* External symbol declarations for the compiler. */\
- if test "$dlself" = yes; then
- func_verbose "generating symbol list for \`$output'"
- $opt_dry_run || echo ': @PROGRAM@ ' > "$nlist"
- # Add our own program objects to the symbol list.
- progfiles=`$ECHO "$objs$old_deplibs" | $SP2NL | $SED "$lo2o" | $NL2SP`
- for progfile in $progfiles; do
- func_to_tool_file "$progfile" func_convert_file_msys_to_w32
- func_verbose "extracting global C symbols from \`$func_to_tool_file_result'"
- $opt_dry_run || eval "$NM $func_to_tool_file_result | $global_symbol_pipe >> '$nlist'"
- done
- if test -n "$exclude_expsyms"; then
- $opt_dry_run || {
- eval '$EGREP -v " ($exclude_expsyms)$" "$nlist" > "$nlist"T'
- eval '$MV "$nlist"T "$nlist"'
- fi
- if test -n "$export_symbols_regex"; then
- $opt_dry_run || {
- eval '$EGREP -e "$export_symbols_regex" "$nlist" > "$nlist"T'
- fi
- # Prepare the list of exported symbols
- if test -z "$export_symbols"; then
- export_symbols="$output_objdir/$outputname.exp"
- $opt_dry_run || {
- $RM $export_symbols
- eval "${SED} -n -e '/^: @PROGRAM@ $/d' -e 's/^.* \(.*\)$/\1/p' "'< "$nlist" > "$export_symbols"'
- case $host in
- *cygwin* | *mingw* | *cegcc* )
- eval "echo EXPORTS "'> "$output_objdir/$outputname.def"'
- eval 'cat "$export_symbols" >> "$output_objdir/$outputname.def"'
- esac
- else
- $opt_dry_run || {
- eval "${SED} -e 's/\([].[*^$]\)/\\\\\1/g' -e 's/^/ /' -e 's/$/$/'"' < "$export_symbols" > "$output_objdir/$outputname.exp"'
- eval '$GREP -f "$output_objdir/$outputname.exp" < "$nlist" > "$nlist"T'
- case $host in
- eval 'cat "$nlist" >> "$output_objdir/$outputname.def"'
- esac
- fi
- fi
- for dlprefile in $dlprefiles; do
- func_verbose "extracting global C symbols from \`$dlprefile'"
- func_basename "$dlprefile"
- case $host in
- # if an import library, we need to obtain dlname
- if func_win32_import_lib_p "$dlprefile"; then
- func_tr_sh "$dlprefile"
- eval "curr_lafile=\$libfile_$func_tr_sh_result"
- dlprefile_dlbasename=""
- if test -n "$curr_lafile" && func_lalib_p "$curr_lafile"; then
- # Use subshell, to avoid clobbering current variable values
- dlprefile_dlname=`source "$curr_lafile" && echo "$dlname"`
- if test -n "$dlprefile_dlname" ; then
- func_basename "$dlprefile_dlname"
- dlprefile_dlbasename="$func_basename_result"
- else
- # no lafile. user explicitly requested -dlpreopen <import library>.
- $sharedlib_from_linklib_cmd "$dlprefile"
- dlprefile_dlbasename=$sharedlib_from_linklib_result
- fi
- fi
- $opt_dry_run || {
- if test -n "$dlprefile_dlbasename" ; then
- eval '$ECHO ": $dlprefile_dlbasename" >> "$nlist"'
- else
- func_warning "Could not compute DLL name from $name"
- eval '$ECHO ": $name " >> "$nlist"'
- fi
- func_to_tool_file "$dlprefile" func_convert_file_msys_to_w32
- eval "$NM \"$func_to_tool_file_result\" 2>/dev/null | $global_symbol_pipe |
- $SED -e '/I __imp/d' -e 's/I __nm_/D /;s/_nm__//' >> '$nlist'"
- else # not an import lib
- $opt_dry_run || {
- eval "$NM \"$func_to_tool_file_result\" 2>/dev/null | $global_symbol_pipe >> '$nlist'"
- fi
- $opt_dry_run || {
- esac
- done
- $opt_dry_run || {
- # Make sure we have at least an empty file.
- test -f "$nlist" || : > "$nlist"
- $EGREP -v " ($exclude_expsyms)$" "$nlist" > "$nlist"T
- $MV "$nlist"T "$nlist"
- fi
- # Try sorting and uniquifying the output.
- if $GREP -v "^: " < "$nlist" |
- if sort -k 3 </dev/null >/dev/null 2>&1; then
- sort -k 3
- else
- sort +2
- fi |
- uniq > "$nlist"S; then
- else
- $GREP -v "^: " < "$nlist" > "$nlist"S
- fi
- if test -f "$nlist"S; then
- eval "$global_symbol_to_cdecl"' < "$nlist"S >> "$output_objdir/$my_dlsyms"'
- else
- echo '/* NONE */' >> "$output_objdir/$my_dlsyms"
- fi
- echo >> "$output_objdir/$my_dlsyms" "\
-/* The mapping between symbol names and symbols. */
-typedef struct {
- const char *name;
- void *address;
-} lt_dlsymlist;
-extern LT_DLSYM_CONST lt_dlsymlist
-lt_${my_prefix}_LTX_preloaded_symbols[];
-LT_DLSYM_CONST lt_dlsymlist
-lt_${my_prefix}_LTX_preloaded_symbols[] =
- { \"$my_originator\", (void *) 0 },"
- case $need_lib_prefix in
- no)
- eval "$global_symbol_to_c_name_address" < "$nlist" >> "$output_objdir/$my_dlsyms"
- eval "$global_symbol_to_c_name_address_lib_prefix" < "$nlist" >> "$output_objdir/$my_dlsyms"
- esac
- {0, (void *) 0}
-/* This works around a problem in FreeBSD linker */
-#ifdef FREEBSD_WORKAROUND
-static const void *lt_preloaded_setup() {
- return lt_${my_prefix}_LTX_preloaded_symbols;
-#endif
-#ifdef __cplusplus
-#endif\
- } # !$opt_dry_run
- pic_flag_for_symtable=
- case "$compile_command " in
- *" -static "*) ;;
- case $host in
- # compiling the symbol table file with pic_flag works around
- # a FreeBSD bug that causes programs to crash when -lm is
- # linked before any other PIC object. But we must not use
- # pic_flag when linking with -static. The problem exists in
- # FreeBSD 2.2.6 and is fixed in FreeBSD 3.1.
- *-*-freebsd2.*|*-*-freebsd3.0*|*-*-freebsdelf3.0*)
- pic_flag_for_symtable=" $pic_flag -DFREEBSD_WORKAROUND" ;;
- *-*-hpux*)
- pic_flag_for_symtable=" $pic_flag" ;;
- if test "X$my_pic_p" != Xno; then
- fi
- esac
- esac
- symtab_cflags=
- for arg in $LTCFLAGS; do
- case $arg in
- -pie | -fpie | -fPIE) ;;
- *) symtab_cflags+=" $arg" ;;
- esac
- done
- # Now compile the dynamic symbol file.
- func_show_eval '(cd $output_objdir && $LTCC$symtab_cflags -c$no_builtin_flag$pic_flag_for_symtable "$my_dlsyms")' 'exit $?'
- # Clean up the generated files.
- func_show_eval '$RM "$output_objdir/$my_dlsyms" "$nlist" "${nlist}S" "${nlist}T"'
- # Transform the symbol file into the correct name.
- symfileobj="$output_objdir/${my_outputname}S.$objext"
- case $host in
- if test -f "$output_objdir/$my_outputname.def"; then
- compile_command=`$ECHO "$compile_command" | $SED "s%@SYMFILE@%$output_objdir/$my_outputname.def $symfileobj%"`
- finalize_command=`$ECHO "$finalize_command" | $SED "s%@SYMFILE@%$output_objdir/$my_outputname.def $symfileobj%"`
- else
- compile_command=`$ECHO "$compile_command" | $SED "s%@SYMFILE@%$symfileobj%"`
- finalize_command=`$ECHO "$finalize_command" | $SED "s%@SYMFILE@%$symfileobj%"`
- fi
- esac
- func_fatal_error "unknown suffix for \`$my_dlsyms'"
- esac
- else
- # We keep going just in case the user didn't refer to
- # lt_preloaded_symbols. The linker will fail if global_symbol_pipe
- # really was required.
- # Nullify the symbol file.
- compile_command=`$ECHO "$compile_command" | $SED "s% @SYMFILE@%%"`
- finalize_command=`$ECHO "$finalize_command" | $SED "s% @SYMFILE@%%"`
- fi
-# func_win32_libid arg
-# return the library type of file 'arg'
-# Need a lot of goo to handle *both* DLLs and import libs
-# Has to be a shell function in order to 'eat' the argument
-# that is supplied when $file_magic_command is called.
-# Despite the name, also deal with 64 bit binaries.
-func_win32_libid ()
- $opt_debug
- win32_libid_type="unknown"
- win32_fileres=`file -L $1 2>/dev/null`
- case $win32_fileres in
- *ar\ archive\ import\ library*) # definitely import
- win32_libid_type="x86 archive import"
- *ar\ archive*) # could be an import, or static
- # Keep the egrep pattern in sync with the one in _LT_CHECK_MAGIC_METHOD.
- if eval $OBJDUMP -f $1 | $SED -e '10q' 2>/dev/null |
- $EGREP 'file format (pei*-i386(.*architecture: i386)?|pe-arm-wince|pe-x86-64)' >/dev/null; then
- func_to_tool_file "$1" func_convert_file_msys_to_w32
- win32_nmres=`eval $NM -f posix -A \"$func_to_tool_file_result\" |
- $SED -n -e '
- 1,100{
- / I /{
- s,.*,import,
- p
- q
- case $win32_nmres in
- import*) win32_libid_type="x86 archive import";;
- *) win32_libid_type="x86 archive static";;
- esac
- fi
- *DLL*)
- win32_libid_type="x86 DLL"
- *executable*) # but shell scripts are "executable" too...
- *MS\ Windows\ PE\ Intel*)
- esac
- esac
- $ECHO "$win32_libid_type"
-# func_cygming_dll_for_implib ARG
-# Platform-specific function to extract the
-# name of the DLL associated with the specified
-# import library ARG.
-# Invoked by eval'ing the libtool variable
-# $sharedlib_from_linklib_cmd
-# Result is available in the variable
-# $sharedlib_from_linklib_result
-func_cygming_dll_for_implib ()
- $opt_debug
- sharedlib_from_linklib_result=`$DLLTOOL --identify-strict --identify "$1"`
-# func_cygming_dll_for_implib_fallback_core SECTION_NAME LIBNAMEs
-# The is the core of a fallback implementation of a
-# platform-specific function to extract the name of the
-# DLL associated with the specified import library LIBNAME.
-# SECTION_NAME is either .idata$6 or .idata$7, depending
-# on the platform and compiler that created the implib.
-# Echos the name of the DLL associated with the
-# specified import library.
-func_cygming_dll_for_implib_fallback_core ()
- $opt_debug
- match_literal=`$ECHO "$1" | $SED "$sed_make_literal_regex"`
- $OBJDUMP -s --section "$1" "$2" 2>/dev/null |
- $SED '/^Contents of section '"$match_literal"':/{
- # Place marker at beginning of archive member dllname section
- s/.*/====MARK====/
- p
- d
- # These lines can sometimes be longer than 43 characters, but
- # are always uninteresting
- /:[ ]*file format pe[i]\{,1\}-/d
- /^In archive [^:]*:/d
- # Ensure marker is printed
- /^====MARK====/p
- # Remove all lines with less than 43 characters
- /^.\{43\}/!d
- # From remaining lines, remove first 43 characters
- s/^.\{43\}//' |
- $SED -n '
- # Join marker and all lines until next marker into a single line
- /^====MARK====/ b para
- H
- $ b para
- b
- :para
- x
- s/\n//g
- # Remove the marker
- s/^====MARK====//
- # Remove trailing dots and whitespace
- s/[\. \t]*$//
- # Print
- /./p' |
- # we now have a list, one entry per line, of the stringified
- # contents of the appropriate section of all members of the
- # archive which possess that section. Heuristic: eliminate
- # all those which have a first or second character that is
- # a '.' (that is, objdump's representation of an unprintable
- # character.) This should work for all archives with less than
- # 0x302f exports -- but will fail for DLLs whose name actually
- # begins with a literal '.' or a single character followed by
- # a '.'.
- # Of those that remain, print the first one.
- $SED -e '/^\./d;/^.\./d;q'
-# func_cygming_gnu_implib_p ARG
-# This predicate returns with zero status (TRUE) if
-# ARG is a GNU/binutils-style import library. Returns
-# with nonzero status (FALSE) otherwise.
-func_cygming_gnu_implib_p ()
- $opt_debug
- func_cygming_gnu_implib_tmp=`$NM "$func_to_tool_file_result" | eval "$global_symbol_pipe" | $EGREP ' (_head_[A-Za-z0-9_]+_[ad]l*|[A-Za-z0-9_]+_[ad]l*_iname)$'`
- test -n "$func_cygming_gnu_implib_tmp"
-# func_cygming_ms_implib_p ARG
-# ARG is an MS-style import library. Returns
-func_cygming_ms_implib_p ()
- $opt_debug
- func_cygming_ms_implib_tmp=`$NM "$func_to_tool_file_result" | eval "$global_symbol_pipe" | $GREP '_NULL_IMPORT_DESCRIPTOR'`
- test -n "$func_cygming_ms_implib_tmp"
-# func_cygming_dll_for_implib_fallback ARG
-# This fallback implementation is for use when $DLLTOOL
-# does not support the --identify-strict option.
-func_cygming_dll_for_implib_fallback ()
- $opt_debug
- if func_cygming_gnu_implib_p "$1" ; then
- # binutils import library
- sharedlib_from_linklib_result=`func_cygming_dll_for_implib_fallback_core '.idata$7' "$1"`
- elif func_cygming_ms_implib_p "$1" ; then
- # ms-generated import library
- sharedlib_from_linklib_result=`func_cygming_dll_for_implib_fallback_core '.idata$6' "$1"`
- else
- # unknown
- sharedlib_from_linklib_result=""
- fi
-# func_extract_an_archive dir oldlib
-func_extract_an_archive ()
- $opt_debug
- f_ex_an_ar_dir="$1"; shift
- f_ex_an_ar_oldlib="$1"
- if test "$lock_old_archive_extraction" = yes; then
- lockfile=$f_ex_an_ar_oldlib.lock
- sleep 2
- done
- fi
- func_show_eval "(cd \$f_ex_an_ar_dir && $AR x \"\$f_ex_an_ar_oldlib\")" \
- 'stat=$?; rm -f "$lockfile"; exit $stat'
- $opt_dry_run || rm -f "$lockfile"
- fi
- if ($AR t "$f_ex_an_ar_oldlib" | sort | sort -uc >/dev/null 2>&1); then
- else
- func_fatal_error "object name conflicts in archive: $f_ex_an_ar_dir/$f_ex_an_ar_oldlib"
- fi
-# func_extract_archives gentop oldlib ...
-func_extract_archives ()
- $opt_debug
- my_gentop="$1"; shift
- my_oldlibs=${1+"$@"}
- my_oldobjs=""
- my_xlib=""
- my_xabs=""
- my_xdir=""
- for my_xlib in $my_oldlibs; do
- # Extract the objects.
- case $my_xlib in
- [\\/]* | [A-Za-z]:[\\/]*) my_xabs="$my_xlib" ;;
- *) my_xabs=`pwd`"/$my_xlib" ;;
- esac
- func_basename "$my_xlib"
- my_xlib="$func_basename_result"
- my_xlib_u=$my_xlib
- while :; do
- case " $extracted_archives " in
- *" $my_xlib_u "*)
- func_arith $extracted_serial + 1
- extracted_serial=$func_arith_result
- my_xlib_u=lt$extracted_serial-$my_xlib ;;
- *) break ;;
- esac
- done
- extracted_archives="$extracted_archives $my_xlib_u"
- my_xdir="$my_gentop/$my_xlib_u"
- func_mkdir_p "$my_xdir"
- case $host in
- *-darwin*)
- func_verbose "Extracting $my_xabs"
- # Do not bother doing anything if just a dry run
- $opt_dry_run || {
- darwin_orig_dir=`pwd`
- cd $my_xdir || exit $?
- darwin_archive=$my_xabs
- darwin_curdir=`pwd`
- darwin_base_archive=`basename "$darwin_archive"`
- darwin_arches=`$LIPO -info "$darwin_archive" 2>/dev/null | $GREP Architectures 2>/dev/null || true`
- if test -n "$darwin_arches"; then
- darwin_arches=`$ECHO "$darwin_arches" | $SED -e 's/.*are://'`
- darwin_arch=
- func_verbose "$darwin_base_archive has multiple architectures $darwin_arches"
- for darwin_arch in $darwin_arches ; do
- func_mkdir_p "unfat-$$/${darwin_base_archive}-${darwin_arch}"
- $LIPO -thin $darwin_arch -output "unfat-$$/${darwin_base_archive}-${darwin_arch}/${darwin_base_archive}" "${darwin_archive}"
- cd "unfat-$$/${darwin_base_archive}-${darwin_arch}"
- func_extract_an_archive "`pwd`" "${darwin_base_archive}"
- cd "$darwin_curdir"
- $RM "unfat-$$/${darwin_base_archive}-${darwin_arch}/${darwin_base_archive}"
- done # $darwin_arches
- ## Okay now we've a bunch of thin objects, gotta fatten them up :)
- darwin_filelist=`find unfat-$$ -type f -name \*.o -print -o -name \*.lo -print | $SED -e "$basename" | sort -u`
- darwin_file=
- darwin_files=
- for darwin_file in $darwin_filelist; do
- darwin_files=`find unfat-$$ -name $darwin_file -print | sort | $NL2SP`
- $LIPO -create -output "$darwin_file" $darwin_files
- done # $darwin_filelist
- $RM -rf unfat-$$
- cd "$darwin_orig_dir"
- else
- cd $darwin_orig_dir
- func_extract_an_archive "$my_xdir" "$my_xabs"
- fi # $darwin_arches
- } # !$opt_dry_run
- esac
- my_oldobjs="$my_oldobjs "`find $my_xdir -name \*.$objext -print -o -name \*.lo -print | sort | $NL2SP`
- done
- func_extract_archives_result="$my_oldobjs"
-# func_emit_wrapper [arg=no]
-# Emit a libtool wrapper script on stdout.
-# Don't directly open a file because we may want to
-# incorporate the script contents within a cygwin/mingw
-# wrapper executable. Must ONLY be called from within
-# func_mode_link because it depends on a number of variables
-# set therein.
-# ARG is the value that the WRAPPER_SCRIPT_BELONGS_IN_OBJDIR
-# variable will take. If 'yes', then the emitted script
-# will assume that the directory in which it is stored is
-# the $objdir directory. This is a cygwin/mingw-specific
-# behavior.
-func_emit_wrapper ()
- func_emit_wrapper_arg1=${1-no}
- $ECHO "\
-#! $SHELL
-# $output - temporary wrapper script for $objdir/$outputname
-# Generated by $PROGRAM (GNU $PACKAGE$TIMESTAMP) $VERSION
-# The $output program cannot be directly executed until all the libtool
-# libraries that it depends on are installed.
-# This wrapper script should never be moved out of the build directory.
-# If it is, it will not operate correctly.
-# Sed substitution that helps us do robust quoting. It backslashifies
-# metacharacters that are still active within double-quoted strings.
-sed_quote_subst='$sed_quote_subst'
-# Be Bourne compatible
-if test -n \"\${ZSH_VERSION+set}\" && (emulate sh) >/dev/null 2>&1; then
- emulate sh
- NULLCMD=:
- # Zsh 3.x and 4.x performs word splitting on \${1+\"\$@\"}, which
- # is contrary to our usage. Disable this feature.
- alias -g '\${1+\"\$@\"}'='\"\$@\"'
- setopt NO_GLOB_SUBST
-else
- case \`(set -o) 2>/dev/null\` in *posix*) set -o posix;; esac
-fi
-BIN_SH=xpg4; export BIN_SH # for Tru64
-DUALCASE=1; export DUALCASE # for MKS sh
-# The HP-UX ksh and POSIX shell print the target directory to stdout
-# if CDPATH is set.
-(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
-relink_command=\"$relink_command\"
-# This environment variable determines our operation mode.
-if test \"\$libtool_install_magic\" = \"$magic\"; then
- # install mode needs the following variables:
- generated_by_libtool_version='$macro_version'
- notinst_deplibs='$notinst_deplibs'
-else
- # When we are sourced in execute mode, \$file and \$ECHO are already set.
- if test \"\$libtool_execute_magic\" != \"$magic\"; then
- file=\"\$0\""
- qECHO=`$ECHO "$ECHO" | $SED "$sed_quote_subst"`
- $ECHO "\
-# A function that is used when there is no print builtin or printf.
-func_fallback_echo ()
- eval 'cat <<_LTECHO_EOF
-\$1
-_LTECHO_EOF'
- ECHO=\"$qECHO\"
- fi
-# Very basic option parsing. These options are (a) specific to
-# the libtool wrapper, (b) are identical between the wrapper
-# /script/ and the wrapper /executable/ which is used only on
-# windows platforms, and (c) all begin with the string "--lt-"
-# (application programs are unlikely to have options which match
-# this pattern).
-# There are only two supported options: --lt-debug and
-# --lt-dump-script. There is, deliberately, no --lt-help.
-# The first argument to this parsing function should be the
-# script's $0 value, followed by "$@".
-lt_option_debug=
-func_parse_lt_options ()
- lt_script_arg0=\$0
- shift
- for lt_opt
- do
- case \"\$lt_opt\" in
- --lt-debug) lt_option_debug=1 ;;
- --lt-dump-script)
- lt_dump_D=\`\$ECHO \"X\$lt_script_arg0\" | $SED -e 's/^X//' -e 's%/[^/]*$%%'\`
- test \"X\$lt_dump_D\" = \"X\$lt_script_arg0\" && lt_dump_D=.
- lt_dump_F=\`\$ECHO \"X\$lt_script_arg0\" | $SED -e 's/^X//' -e 's%^.*/%%'\`
- cat \"\$lt_dump_D/\$lt_dump_F\"
- exit 0
- --lt-*)
- \$ECHO \"Unrecognized --lt- option: '\$lt_opt'\" 1>&2
- exit 1
- esac
- done
- # Print the debug banner immediately:
- if test -n \"\$lt_option_debug\"; then
- echo \"${outputname}:${output}:\${LINENO}: libtool wrapper (GNU $PACKAGE$TIMESTAMP) $VERSION\" 1>&2
- fi
-# Used when --lt-debug. Prints its arguments to stdout
-# (redirection is the responsibility of the caller)
-func_lt_dump_args ()
- lt_dump_args_N=1;
- for lt_arg
- do
- \$ECHO \"${outputname}:${output}:\${LINENO}: newargv[\$lt_dump_args_N]: \$lt_arg\"
- lt_dump_args_N=\`expr \$lt_dump_args_N + 1\`
- done
-# Core function for launching the target application
-func_exec_program_core ()
- case $host in
- # Backslashes separate directories on plain windows
- *-*-mingw | *-*-os2* | *-cegcc*)
- $ECHO "\
- \$ECHO \"${outputname}:${output}:\${LINENO}: newargv[0]: \$progdir\\\\\$program\" 1>&2
- func_lt_dump_args \${1+\"\$@\"} 1>&2
- fi
- exec \"\$progdir\\\\\$program\" \${1+\"\$@\"}
- $ECHO "\
- \$ECHO \"${outputname}:${output}:\${LINENO}: newargv[0]: \$progdir/\$program\" 1>&2
- fi
- exec \"\$progdir/\$program\" \${1+\"\$@\"}
- esac
- $ECHO "\
- \$ECHO \"\$0: cannot exec \$program \$*\" 1>&2
- exit 1
-# A function to encapsulate launching the target application
-# Strips options in the --lt-* namespace from \$@ and
-# launches target application with the remaining arguments.
-func_exec_program ()
- case \" \$* \" in
- *\\ --lt-*)
- for lt_wr_arg
- do
- case \$lt_wr_arg in
- --lt-*) ;;
- *) set x \"\$@\" \"\$lt_wr_arg\"; shift;;
- esac
- shift
- done ;;
- esac
- func_exec_program_core \${1+\"\$@\"}
- # Parse options
- func_parse_lt_options \"\$0\" \${1+\"\$@\"}
- # Find the directory that this script lives in.
- thisdir=\`\$ECHO \"\$file\" | $SED 's%/[^/]*$%%'\`
- test \"x\$thisdir\" = \"x\$file\" && thisdir=.
- # Follow symbolic links until we get to the real thisdir.
- file=\`ls -ld \"\$file\" | $SED -n 's/.*-> //p'\`
- while test -n \"\$file\"; do
- destdir=\`\$ECHO \"\$file\" | $SED 's%/[^/]*\$%%'\`
- # If there was a directory component, then change thisdir.
- if test \"x\$destdir\" != \"x\$file\"; then
- case \"\$destdir\" in
- [\\\\/]* | [A-Za-z]:[\\\\/]*) thisdir=\"\$destdir\" ;;
- *) thisdir=\"\$thisdir/\$destdir\" ;;
- esac
- fi
- file=\`\$ECHO \"\$file\" | $SED 's%^.*/%%'\`
- file=\`ls -ld \"\$thisdir/\$file\" | $SED -n 's/.*-> //p'\`
- done
- # Usually 'no', except on cygwin/mingw when embedded into
- # the cwrapper.
- WRAPPER_SCRIPT_BELONGS_IN_OBJDIR=$func_emit_wrapper_arg1
- if test \"\$WRAPPER_SCRIPT_BELONGS_IN_OBJDIR\" = \"yes\"; then
- # special case for '.'
- if test \"\$thisdir\" = \".\"; then
- thisdir=\`pwd\`
- fi
- # remove .libs from thisdir
- case \"\$thisdir\" in
- *[\\\\/]$objdir ) thisdir=\`\$ECHO \"\$thisdir\" | $SED 's%[\\\\/][^\\\\/]*$%%'\` ;;
- $objdir ) thisdir=. ;;
- esac
- fi
- # Try to get the absolute directory name.
- absdir=\`cd \"\$thisdir\" && pwd\`
- test -n \"\$absdir\" && thisdir=\"\$absdir\"
- if test "$fast_install" = yes; then
- $ECHO "\
- program=lt-'$outputname'$exeext
- progdir=\"\$thisdir/$objdir\"
- if test ! -f \"\$progdir/\$program\" ||
- { file=\`ls -1dt \"\$progdir/\$program\" \"\$progdir/../\$program\" 2>/dev/null | ${SED} 1q\`; \\
- test \"X\$file\" != \"X\$progdir/\$program\"; }; then
- file=\"\$\$-\$program\"
- if test ! -d \"\$progdir\"; then
- $MKDIR \"\$progdir\"
- else
- $RM \"\$progdir/\$file\"
- fi"
- $ECHO "\
- # relink executable if necessary
- if test -n \"\$relink_command\"; then
- if relink_command_output=\`eval \$relink_command 2>&1\`; then :
- else
- $ECHO \"\$relink_command_output\" >&2
- exit 1
- fi
- fi
- $MV \"\$progdir/\$file\" \"\$progdir/\$program\" 2>/dev/null ||
- { $RM \"\$progdir/\$program\";
- $MV \"\$progdir/\$file\" \"\$progdir/\$program\"; }
- fi"
- else
- $ECHO "\
- program='$outputname'
- fi
- $ECHO "\
- if test -f \"\$progdir/\$program\"; then"
- # fixup the dll searchpath if we need to.
- # Fix the DLL searchpath if we need to. Do this before prepending
- # to shlibpath, because on Windows, both are PATH and uninstalled
- # libraries must come first.
- if test -n "$dllsearchpath"; then
- $ECHO "\
- # Add the dll search path components to the executable PATH
- PATH=$dllsearchpath:\$PATH
- fi
- # Export our shlibpath_var if we have one.
- if test "$shlibpath_overrides_runpath" = yes && test -n "$shlibpath_var" && test -n "$temp_rpath"; then
- $ECHO "\
- # Add our own library path to $shlibpath_var
- $shlibpath_var=\"$temp_rpath\$$shlibpath_var\"
- # Some systems cannot cope with colon-terminated $shlibpath_var
- # The second colon is a workaround for a bug in BeOS R4 sed
- $shlibpath_var=\`\$ECHO \"\$$shlibpath_var\" | $SED 's/::*\$//'\`
- export $shlibpath_var
- fi
- $ECHO "\
- # Run the actual program with our arguments.
- func_exec_program \${1+\"\$@\"}
- fi
- else
- # The program doesn't exist.
- \$ECHO \"\$0: error: \\\`\$progdir/\$program' does not exist\" 1>&2
- \$ECHO \"This script is just a wrapper for \$program.\" 1>&2
- \$ECHO \"See the $PACKAGE documentation for more information.\" 1>&2
- exit 1
- fi
-fi\
-# func_emit_cwrapperexe_src
-# emit the source code for a wrapper executable on stdout
-# Must ONLY be called from within func_mode_link because
-# it depends on a number of variable set therein.
-func_emit_cwrapperexe_src ()
- cat <<EOF
-/* $cwrappersource - temporary wrapper executable for $objdir/$outputname
- Generated by $PROGRAM (GNU $PACKAGE$TIMESTAMP) $VERSION
- The $output program cannot be directly executed until all the libtool
- libraries that it depends on are installed.
- This wrapper executable should never be moved out of the build directory.
- If it is, it will not operate correctly.
-EOF
- cat <<"EOF"
-#ifdef _MSC_VER
-# define _CRT_SECURE_NO_DEPRECATE 1
-#endif
-#include <stdio.h>
-#include <stdlib.h>
-#ifdef _MSC_VER
-# include <direct.h>
-# include <process.h>
-# include <io.h>
-#else
-# include <unistd.h>
-# include <stdint.h>
-# ifdef __CYGWIN__
-# include <io.h>
-# endif
-#endif
-#include <malloc.h>
-#include <stdarg.h>
-#include <assert.h>
-#include <string.h>
-#include <ctype.h>
-#include <errno.h>
-#include <fcntl.h>
-#include <sys/stat.h>
-/* declarations of non-ANSI functions */
-#if defined(__MINGW32__)
-# ifdef __STRICT_ANSI__
-int _putenv (const char *);
-# endif
-#elif defined(__CYGWIN__)
-char *realpath (const char *, char *);
-int putenv (char *);
-int setenv (const char *, const char *, int);
-# endif
-/* #elif defined (other platforms) ... */
-#endif
-/* portability defines, excluding path handling macros */
-#if defined(_MSC_VER)
-# define setmode _setmode
-# define stat _stat
-# define chmod _chmod
-# define getcwd _getcwd
-# define putenv _putenv
-# define S_IXUSR _S_IEXEC
-# ifndef _INTPTR_T_DEFINED
-# define _INTPTR_T_DEFINED
-# define intptr_t int
-# endif
-#elif defined(__MINGW32__)
-# define HAVE_SETENV
-# define FOPEN_WB "wb"
-#endif
-#if defined(PATH_MAX)
-# define LT_PATHMAX PATH_MAX
-#elif defined(MAXPATHLEN)
-# define LT_PATHMAX MAXPATHLEN
-#else
-# define LT_PATHMAX 1024
-#endif
-#ifndef S_IXOTH
-# define S_IXOTH 0
-#endif
-#ifndef S_IXGRP
-# define S_IXGRP 0
-#endif
-/* path handling portability macros */
-#ifndef DIR_SEPARATOR
-# define DIR_SEPARATOR '/'
-# define PATH_SEPARATOR ':'
-#endif
-#if defined (_WIN32) || defined (__MSDOS__) || defined (__DJGPP__) || \
- defined (__OS2__)
-# define HAVE_DOS_BASED_FILE_SYSTEM
-# ifndef DIR_SEPARATOR_2
-# define DIR_SEPARATOR_2 '\\'
-# endif
-# ifndef PATH_SEPARATOR_2
-# define PATH_SEPARATOR_2 ';'
-# endif
-#endif
-#ifndef DIR_SEPARATOR_2
-# define IS_DIR_SEPARATOR(ch) ((ch) == DIR_SEPARATOR)
-#else /* DIR_SEPARATOR_2 */
-# define IS_DIR_SEPARATOR(ch) \
- (((ch) == DIR_SEPARATOR) || ((ch) == DIR_SEPARATOR_2))
-#endif /* DIR_SEPARATOR_2 */
-#ifndef PATH_SEPARATOR_2
-# define IS_PATH_SEPARATOR(ch) ((ch) == PATH_SEPARATOR)
-#else /* PATH_SEPARATOR_2 */
-# define IS_PATH_SEPARATOR(ch) ((ch) == PATH_SEPARATOR_2)
-#endif /* PATH_SEPARATOR_2 */
-#ifndef FOPEN_WB
-# define FOPEN_WB "w"
-#endif
-#ifndef _O_BINARY
-# define _O_BINARY 0
-#endif
-#define XMALLOC(type, num) ((type *) xmalloc ((num) * sizeof(type)))
-#define XFREE(stale) do { \
- if (stale) { free ((void *) stale); stale = 0; } \
-} while (0)
-#if defined(LT_DEBUGWRAPPER)
-static int lt_debug = 1;
-#else
-static int lt_debug = 0;
-#endif
-const char *program_name = "libtool-wrapper"; /* in case xstrdup fails */
-void *xmalloc (size_t num);
-char *xstrdup (const char *string);
-const char *base_name (const char *name);
-char *find_executable (const char *wrapper);
-char *chase_symlinks (const char *pathspec);
-int make_executable (const char *path);
-int check_executable (const char *path);
-char *strendzap (char *str, const char *pat);
-void lt_debugprintf (const char *file, int line, const char *fmt, ...);
-void lt_fatal (const char *file, int line, const char *message, ...);
-static const char *nonnull (const char *s);
-static const char *nonempty (const char *s);
-void lt_setenv (const char *name, const char *value);
-char *lt_extend_str (const char *orig_value, const char *add, int to_end);
-void lt_update_exe_path (const char *name, const char *value);
-void lt_update_lib_path (const char *name, const char *value);
-char **prepare_spawn (char **argv);
-void lt_dump_script (FILE *f);
-EOF
- cat <<EOF
-volatile const char * MAGIC_EXE = "$magic_exe";
-const char * LIB_PATH_VARNAME = "$shlibpath_var";
-EOF
- func_to_host_path "$temp_rpath"
- cat <<EOF
-const char * LIB_PATH_VALUE = "$func_to_host_path_result";
-EOF
- else
- cat <<"EOF"
-const char * LIB_PATH_VALUE = "";
-EOF
- fi
- func_to_host_path "$dllsearchpath:"
- cat <<EOF
-const char * EXE_PATH_VARNAME = "PATH";
-const char * EXE_PATH_VALUE = "$func_to_host_path_result";
-EOF
- else
- cat <<"EOF"
-const char * EXE_PATH_VARNAME = "";
-const char * EXE_PATH_VALUE = "";
-EOF
- fi
- cat <<EOF
-const char * TARGET_PROGRAM_NAME = "lt-$outputname"; /* hopefully, no .exe */
-EOF
- else
- cat <<EOF
-const char * TARGET_PROGRAM_NAME = "$outputname"; /* hopefully, no .exe */
-EOF
- fi
- cat <<"EOF"
-#define LTWRAPPER_OPTION_PREFIX "--lt-"
-static const char *ltwrapper_option_prefix = LTWRAPPER_OPTION_PREFIX;
-static const char *dumpscript_opt = LTWRAPPER_OPTION_PREFIX "dump-script";
-static const char *debug_opt = LTWRAPPER_OPTION_PREFIX "debug";
-int
-main (int argc, char *argv[])
- char **newargz;
- int newargc;
- char *tmp_pathspec;
- char *actual_cwrapper_path;
- char *actual_cwrapper_name;
- char *target_name;
- char *lt_argv_zero;
- intptr_t rval = 127;
- int i;
- program_name = (char *) xstrdup (base_name (argv[0]));
- newargz = XMALLOC (char *, argc + 1);
- /* very simple arg parsing; don't want to rely on getopt
- * also, copy all non cwrapper options to newargz, except
- * argz[0], which is handled differently
- newargc=0;
- for (i = 1; i < argc; i++)
- if (strcmp (argv[i], dumpscript_opt) == 0)
-EOF
- case "$host" in
- *mingw* | *cygwin* )
- # make stdout use "unix" line endings
- echo " setmode(1,_O_BINARY);"
- esac
- cat <<"EOF"
- lt_dump_script (stdout);
- return 0;
- if (strcmp (argv[i], debug_opt) == 0)
- lt_debug = 1;
- continue;
- if (strcmp (argv[i], ltwrapper_option_prefix) == 0)
- /* however, if there is an option in the LTWRAPPER_OPTION_PREFIX
- namespace, but it is not one of the ones we know about and
- have already dealt with, above (inluding dump-script), then
- report an error. Otherwise, targets might begin to believe
- they are allowed to use options in the LTWRAPPER_OPTION_PREFIX
- namespace. The first time any user complains about this, we'll
- need to make LTWRAPPER_OPTION_PREFIX a configure-time option
- or a configure.ac-settable value.
- lt_fatal (__FILE__, __LINE__,
- "unrecognized %s option: '%s'",
- ltwrapper_option_prefix, argv[i]);
- /* otherwise ... */
- newargz[++newargc] = xstrdup (argv[i]);
- newargz[++newargc] = NULL;
-EOF
- cat <<EOF
- /* The GNU banner must be the first non-error debug message */
- lt_debugprintf (__FILE__, __LINE__, "libtool wrapper (GNU $PACKAGE$TIMESTAMP) $VERSION\n");
-EOF
- cat <<"EOF"
- lt_debugprintf (__FILE__, __LINE__, "(main) argv[0]: %s\n", argv[0]);
- lt_debugprintf (__FILE__, __LINE__, "(main) program_name: %s\n", program_name);
- tmp_pathspec = find_executable (argv[0]);
- if (tmp_pathspec == NULL)
- lt_fatal (__FILE__, __LINE__, "couldn't find %s", argv[0]);
- "(main) found exe (before symlink chase) at: %s\n",
- tmp_pathspec);
- actual_cwrapper_path = chase_symlinks (tmp_pathspec);
- "(main) found exe (after symlink chase) at: %s\n",
- actual_cwrapper_path);
- XFREE (tmp_pathspec);
- actual_cwrapper_name = xstrdup (base_name (actual_cwrapper_path));
- strendzap (actual_cwrapper_path, actual_cwrapper_name);
- /* wrapper name transforms */
- strendzap (actual_cwrapper_name, ".exe");
- tmp_pathspec = lt_extend_str (actual_cwrapper_name, ".exe", 1);
- XFREE (actual_cwrapper_name);
- actual_cwrapper_name = tmp_pathspec;
- tmp_pathspec = 0;
- /* target_name transforms -- use actual target program name; might have lt- prefix */
- target_name = xstrdup (base_name (TARGET_PROGRAM_NAME));
- strendzap (target_name, ".exe");
- tmp_pathspec = lt_extend_str (target_name, ".exe", 1);
- XFREE (target_name);
- target_name = tmp_pathspec;
- tmp_pathspec = 0;
- "(main) libtool target name: %s\n",
- target_name);
-EOF
- cat <<EOF
- newargz[0] =
- XMALLOC (char, (strlen (actual_cwrapper_path) +
- strlen ("$objdir") + 1 + strlen (actual_cwrapper_name) + 1));
- strcpy (newargz[0], actual_cwrapper_path);
- strcat (newargz[0], "$objdir");
- strcat (newargz[0], "/");
-EOF
- cat <<"EOF"
- /* stop here, and copy so we don't have to do this twice */
- tmp_pathspec = xstrdup (newargz[0]);
- /* do NOT want the lt- prefix here, so use actual_cwrapper_name */
- strcat (newargz[0], actual_cwrapper_name);
- /* DO want the lt- prefix here if it exists, so use target_name */
- lt_argv_zero = lt_extend_str (tmp_pathspec, target_name, 1);
- tmp_pathspec = NULL;
-EOF
- case $host_os in
- mingw*)
- cat <<"EOF"
- char* p;
- while ((p = strchr (newargz[0], '\\')) != NULL)
- *p = '/';
- while ((p = strchr (lt_argv_zero, '\\')) != NULL)
- *p = '/';
-EOF
- esac
- cat <<"EOF"
- XFREE (actual_cwrapper_path);
- lt_setenv ("BIN_SH", "xpg4"); /* for Tru64 */
- lt_setenv ("DUALCASE", "1"); /* for MSK sh */
- /* Update the DLL searchpath. EXE_PATH_VALUE ($dllsearchpath) must
- be prepended before (that is, appear after) LIB_PATH_VALUE ($temp_rpath)
- because on Windows, both *_VARNAMEs are PATH but uninstalled
- libraries must come first. */
- lt_update_exe_path (EXE_PATH_VARNAME, EXE_PATH_VALUE);
- lt_update_lib_path (LIB_PATH_VARNAME, LIB_PATH_VALUE);
- lt_debugprintf (__FILE__, __LINE__, "(main) lt_argv_zero: %s\n",
- nonnull (lt_argv_zero));
- for (i = 0; i < newargc; i++)
- lt_debugprintf (__FILE__, __LINE__, "(main) newargz[%d]: %s\n",
- i, nonnull (newargz[i]));
-EOF
- case $host_os in
- mingw*)
- cat <<"EOF"
- /* execv doesn't actually work on mingw as expected on unix */
- newargz = prepare_spawn (newargz);
- rval = _spawnv (_P_WAIT, lt_argv_zero, (const char * const *) newargz);
- if (rval == -1)
- /* failed to start process */
- "(main) failed to launch target \"%s\": %s\n",
- lt_argv_zero, nonnull (strerror (errno)));
- return 127;
- return rval;
-EOF
- cat <<"EOF"
- execv (lt_argv_zero, newargz);
- return rval; /* =127, but avoids unused variable warning */
-EOF
- esac
- cat <<"EOF"
-void *
-xmalloc (size_t num)
- void *p = (void *) malloc (num);
- if (!p)
- lt_fatal (__FILE__, __LINE__, "memory exhausted");
- return p;
-char *
-xstrdup (const char *string)
- return string ? strcpy ((char *) xmalloc (strlen (string) + 1),
- string) : NULL;
-const char *
-base_name (const char *name)
- const char *base;
-#if defined (HAVE_DOS_BASED_FILE_SYSTEM)
- /* Skip over the disk name in MSDOS pathnames. */
- if (isalpha ((unsigned char) name[0]) && name[1] == ':')
- name += 2;
-#endif
- for (base = name; *name; name++)
- if (IS_DIR_SEPARATOR (*name))
- base = name + 1;
- return base;
-int
-check_executable (const char *path)
- struct stat st;
- lt_debugprintf (__FILE__, __LINE__, "(check_executable): %s\n",
- nonempty (path));
- if ((!path) || (!*path))
- return 0;
- if ((stat (path, &st) >= 0)
- && (st.st_mode & (S_IXUSR | S_IXGRP | S_IXOTH)))
- return 1;
- else
- return 0;
-int
-make_executable (const char *path)
- int rval = 0;
- struct stat st;
- lt_debugprintf (__FILE__, __LINE__, "(make_executable): %s\n",
- nonempty (path));
- return 0;
- if (stat (path, &st) >= 0)
- rval = chmod (path, st.st_mode | S_IXOTH | S_IXGRP | S_IXUSR);
- return rval;
-/* Searches for the full path of the wrapper. Returns
- newly allocated full path name if found, NULL otherwise
- Does not chase symlinks, even on platforms that support them.
-char *
-find_executable (const char *wrapper)
- int has_slash = 0;
- const char *p;
- const char *p_next;
- /* static buffer for getcwd */
- char tmp[LT_PATHMAX + 1];
- int tmp_len;
- char *concat_name;
- lt_debugprintf (__FILE__, __LINE__, "(find_executable): %s\n",
- nonempty (wrapper));
- if ((wrapper == NULL) || (*wrapper == '\0'))
- return NULL;
- /* Absolute path? */
- if (isalpha ((unsigned char) wrapper[0]) && wrapper[1] == ':')
- concat_name = xstrdup (wrapper);
- if (check_executable (concat_name))
- return concat_name;
- XFREE (concat_name);
- else
-#endif
- if (IS_DIR_SEPARATOR (wrapper[0]))
-#endif
- for (p = wrapper; *p; p++)
- if (*p == '/')
- has_slash = 1;
- break;
- if (!has_slash)
- /* no slashes; search PATH */
- const char *path = getenv ("PATH");
- if (path != NULL)
- for (p = path; *p; p = p_next)
- const char *q;
- size_t p_len;
- for (q = p; *q; q++)
- if (IS_PATH_SEPARATOR (*q))
- break;
- p_len = q - p;
- p_next = (*q == '\0' ? q : q + 1);
- if (p_len == 0)
- /* empty path: current directory */
- if (getcwd (tmp, LT_PATHMAX) == NULL)
- lt_fatal (__FILE__, __LINE__, "getcwd failed: %s",
- nonnull (strerror (errno)));
- tmp_len = strlen (tmp);
- concat_name =
- XMALLOC (char, tmp_len + 1 + strlen (wrapper) + 1);
- memcpy (concat_name, tmp, tmp_len);
- concat_name[tmp_len] = '/';
- strcpy (concat_name + tmp_len + 1, wrapper);
- else
- concat_name =
- XMALLOC (char, p_len + 1 + strlen (wrapper) + 1);
- memcpy (concat_name, p, p_len);
- concat_name[p_len] = '/';
- strcpy (concat_name + p_len + 1, wrapper);
- /* not found in PATH; assume curdir */
- /* Relative path | not found in path: prepend cwd */
- concat_name = XMALLOC (char, tmp_len + 1 + strlen (wrapper) + 1);
- return NULL;
-char *
-chase_symlinks (const char *pathspec)
-#ifndef S_ISLNK
- return xstrdup (pathspec);
-#else
- char buf[LT_PATHMAX];
- struct stat s;
- char *tmp_pathspec = xstrdup (pathspec);
- char *p;
- int has_symlinks = 0;
- while (strlen (tmp_pathspec) && !has_symlinks)
- "checking path component for symlinks: %s\n",
- tmp_pathspec);
- if (lstat (tmp_pathspec, &s) == 0)
- if (S_ISLNK (s.st_mode) != 0)
- has_symlinks = 1;
- break;
- /* search backwards for last DIR_SEPARATOR */
- p = tmp_pathspec + strlen (tmp_pathspec) - 1;
- while ((p > tmp_pathspec) && (!IS_DIR_SEPARATOR (*p)))
- p--;
- if ((p == tmp_pathspec) && (!IS_DIR_SEPARATOR (*p)))
- /* no more DIR_SEPARATORS left */
- break;
- *p = '\0';
- else
- "error accessing file \"%s\": %s",
- tmp_pathspec, nonnull (strerror (errno)));
- if (!has_symlinks)
- tmp_pathspec = realpath (pathspec, buf);
- if (tmp_pathspec == 0)
- "could not follow symlinks for %s", pathspec);
- return xstrdup (tmp_pathspec);
-#endif
-char *
-strendzap (char *str, const char *pat)
- size_t len, patlen;
- assert (str != NULL);
- assert (pat != NULL);
- len = strlen (str);
- patlen = strlen (pat);
- if (patlen <= len)
- str += len - patlen;
- if (strcmp (str, pat) == 0)
- *str = '\0';
- return str;
-void
-lt_debugprintf (const char *file, int line, const char *fmt, ...)
- va_list args;
- if (lt_debug)
- (void) fprintf (stderr, "%s:%s:%d: ", program_name, file, line);
- va_start (args, fmt);
- (void) vfprintf (stderr, fmt, args);
- va_end (args);
-static void
-lt_error_core (int exit_status, const char *file,
- int line, const char *mode,
- const char *message, va_list ap)
- fprintf (stderr, "%s:%s:%d: %s: ", program_name, file, line, mode);
- vfprintf (stderr, message, ap);
- fprintf (stderr, ".\n");
- if (exit_status >= 0)
- exit (exit_status);
-void
-lt_fatal (const char *file, int line, const char *message, ...)
- va_list ap;
- va_start (ap, message);
- lt_error_core (EXIT_FAILURE, file, line, "FATAL", message, ap);
- va_end (ap);
-nonnull (const char *s)
- return s ? s : "(null)";
-nonempty (const char *s)
- return (s && !*s) ? "(empty)" : nonnull (s);
-void
-lt_setenv (const char *name, const char *value)
- "(lt_setenv) setting '%s' to '%s'\n",
- nonnull (name), nonnull (value));
-#ifdef HAVE_SETENV
- /* always make a copy, for consistency with !HAVE_SETENV */
- char *str = xstrdup (value);
- setenv (name, str, 1);
-#else
- int len = strlen (name) + 1 + strlen (value) + 1;
- char *str = XMALLOC (char, len);
- sprintf (str, "%s=%s", name, value);
- if (putenv (str) != EXIT_SUCCESS)
- XFREE (str);
-#endif
-char *
-lt_extend_str (const char *orig_value, const char *add, int to_end)
- char *new_value;
- if (orig_value && *orig_value)
- int orig_value_len = strlen (orig_value);
- int add_len = strlen (add);
- new_value = XMALLOC (char, add_len + orig_value_len + 1);
- if (to_end)
- strcpy (new_value, orig_value);
- strcpy (new_value + orig_value_len, add);
- else
- strcpy (new_value, add);
- strcpy (new_value + add_len, orig_value);
- else
- new_value = xstrdup (add);
- return new_value;
-void
-lt_update_exe_path (const char *name, const char *value)
- "(lt_update_exe_path) modifying '%s' by prepending '%s'\n",
- if (name && *name && value && *value)
- char *new_value = lt_extend_str (getenv (name), value, 0);
- /* some systems can't cope with a ':'-terminated path #' */
- int len = strlen (new_value);
- while (((len = strlen (new_value)) > 0) && IS_PATH_SEPARATOR (new_value[len-1]))
- new_value[len-1] = '\0';
- lt_setenv (name, new_value);
- XFREE (new_value);
-void
-lt_update_lib_path (const char *name, const char *value)
- "(lt_update_lib_path) modifying '%s' by prepending '%s'\n",
-EOF
- case $host_os in
- mingw*)
- cat <<"EOF"
-/* Prepares an argument vector before calling spawn().
- Note that spawn() does not by itself call the command interpreter
- (getenv ("COMSPEC") != NULL ? getenv ("COMSPEC") :
- ({ OSVERSIONINFO v; v.dwOSVersionInfoSize = sizeof(OSVERSIONINFO);
- GetVersionEx(&v);
- v.dwPlatformId == VER_PLATFORM_WIN32_NT;
- }) ? "cmd.exe" : "command.com").
- Instead it simply concatenates the arguments, separated by ' ', and calls
- CreateProcess(). We must quote the arguments since Win32 CreateProcess()
- interprets characters like ' ', '\t', '\\', '"' (but not '<' and '>') in a
- special way:
- - Space and tab are interpreted as delimiters. They are not treated as
- delimiters if they are surrounded by double quotes: "...".
- - Unescaped double quotes are removed from the input. Their only effect is
- that within double quotes, space and tab are treated like normal
- characters.
- - Backslashes not followed by double quotes are not special.
- - But 2*n+1 backslashes followed by a double quote become
- n backslashes followed by a double quote (n >= 0):
-#define SHELL_SPECIAL_CHARS "\"\\ \001\002\003\004\005\006\007\010\011\012\013\014\015\016\017\020\021\022\023\024\025\026\027\030\031\032\033\034\035\036\037"
-#define SHELL_SPACE_CHARS " \001\002\003\004\005\006\007\010\011\012\013\014\015\016\017\020\021\022\023\024\025\026\027\030\031\032\033\034\035\036\037"
-char **
-prepare_spawn (char **argv)
- size_t argc;
- char **new_argv;
- size_t i;
- /* Count number of arguments. */
- for (argc = 0; argv[argc] != NULL; argc++)
- /* Allocate new argument vector. */
- new_argv = XMALLOC (char *, argc + 1);
- /* Put quoted arguments into the new argument vector. */
- for (i = 0; i < argc; i++)
- const char *string = argv[i];
- if (string[0] == '\0')
- new_argv[i] = xstrdup ("\"\"");
- else if (strpbrk (string, SHELL_SPECIAL_CHARS) != NULL)
- int quote_around = (strpbrk (string, SHELL_SPACE_CHARS) != NULL);
- size_t length;
- unsigned int backslashes;
- const char *s;
- char *quoted_string;
- char *p;
- length = 0;
- backslashes = 0;
- if (quote_around)
- length++;
- for (s = string; *s != '\0'; s++)
- char c = *s;
- if (c == '"')
- length += backslashes + 1;
- length++;
- if (c == '\\')
- backslashes++;
- else
- backslashes = 0;
- if (quote_around)
- quoted_string = XMALLOC (char, length + 1);
- p = quoted_string;
- backslashes = 0;
- if (quote_around)
- *p++ = '"';
- char c = *s;
- if (c == '"')
- unsigned int j;
- for (j = backslashes + 1; j > 0; j--)
- *p++ = '\\';
- *p++ = c;
- if (c == '\\')
- backslashes++;
- else
- backslashes = 0;
- if (quote_around)
- unsigned int j;
- for (j = backslashes; j > 0; j--)
- *p++ = '\\';
- *p++ = '"';
- *p = '\0';
- new_argv[i] = quoted_string;
- else
- new_argv[i] = (char *) string;
- new_argv[argc] = NULL;
- return new_argv;
-EOF
- esac
- cat <<"EOF"
-void lt_dump_script (FILE* f)
-EOF
- func_emit_wrapper yes |
- $SED -n -e '
-s/^\(.\{79\}\)\(..*\)/\1\
-\2/
-h
-s/\([\\"]\)/\\\1/g
-s/$/\\n/
-s/\([^\n]*\).*/ fputs ("\1", f);/p
-g
-D'
- cat <<"EOF"
-EOF
-# end: func_emit_cwrapperexe_src
-# func_win32_import_lib_p ARG
-# True if ARG is an import lib, as indicated by $file_magic_cmd
-func_win32_import_lib_p ()
- $opt_debug
- case `eval $file_magic_cmd \"\$1\" 2>/dev/null | $SED -e 10q` in
- *import*) : ;;
- *) false ;;
- esac
-# func_mode_link arg...
-func_mode_link ()
- $opt_debug
- case $host in
- *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2* | *-cegcc*)
- # It is impossible to link a dll without this setting, and
- # we shouldn't force the makefile maintainer to figure out
- # which system we are compiling for in order to pass an extra
- # flag for every libtool invocation.
- # allow_undefined=no
- # FIXME: Unfortunately, there are problems with the above when trying
- # to make a dll which has undefined symbols, in which case not
- # even a static library is built. For now, we need to specify
- # -no-undefined on the libtool link line when we can be certain
- # that all symbols are satisfied, otherwise we get a static library.
- allow_undefined=yes
- esac
- libtool_args=$nonopt
- base_compile="$nonopt $@"
- compile_command=$nonopt
- finalize_command=$nonopt
- compile_rpath=
- finalize_rpath=
- compile_shlibpath=
- finalize_shlibpath=
- convenience=
- old_convenience=
- deplibs=
- old_deplibs=
- compiler_flags=
- linker_flags=
- dllsearchpath=
- lib_search_path=`pwd`
- inst_prefix_dir=
- new_inherited_linker_flags=
- avoid_version=no
- bindir=
- dlfiles=
- dlprefiles=
- dlself=no
- export_dynamic=no
- export_symbols=
- export_symbols_regex=
- generated=
- libobjs=
- ltlibs=
- module=no
- no_install=no
- objs=
- non_pic_objects=
- precious_files_regex=
- prefer_static_libs=no
- preload=no
- prev=
- prevarg=
- release=
- rpath=
- xrpath=
- perm_rpath=
- temp_rpath=
- thread_safe=no
- vinfo=
- vinfo_number=no
- weak_libs=
- single_module="${wl}-single_module"
- func_infer_tag $base_compile
- # We need to know -static, to get the right output filenames.
- for arg
- do
- case $arg in
- -shared)
- test "$build_libtool_libs" != yes && \
- func_fatal_configuration "can not build a shared library"
- build_old_libs=no
- break
- -all-static | -static | -static-libtool-libs)
- case $arg in
- -all-static)
- if test "$build_libtool_libs" = yes && test -z "$link_static_flag"; then
- func_warning "complete static linking is impossible in this configuration"
- fi
- if test -n "$link_static_flag"; then
- dlopen_self=$dlopen_self_static
- fi
- prefer_static_libs=yes
- -static)
- if test -z "$pic_flag" && test -n "$link_static_flag"; then
- fi
- prefer_static_libs=built
- -static-libtool-libs)
- fi
- esac
- build_libtool_libs=no
- build_old_libs=yes
- break
- esac
- done
- # See if our shared archives depend on static archives.
- test -n "$old_archive_from_new_cmds" && build_old_libs=yes
- # Go through the arguments, transforming them on the way.
- while test "$#" -gt 0; do
- arg="$1"
- shift
- qarg=$func_quote_for_eval_unquoted_result
- libtool_args+=" $func_quote_for_eval_result"
- # If the previous option needs an argument, assign it.
- case $prev in
- output)
- compile_command+=" @OUTPUT@"
- finalize_command+=" @OUTPUT@"
- esac
- case $prev in
- bindir)
- bindir="$arg"
- prev=
- continue
- dlfiles|dlprefiles)
- if test "$preload" = no; then
- # Add the symbol object into the linking commands.
- compile_command+=" @SYMFILE@"
- finalize_command+=" @SYMFILE@"
- preload=yes
- fi
- case $arg in
- *.la | *.lo) ;; # We handle these cases below.
- force)
- if test "$dlself" = no; then
- dlself=needless
- export_dynamic=yes
- fi
- prev=
- continue
- self)
- if test "$prev" = dlprefiles; then
- dlself=yes
- elif test "$prev" = dlfiles && test "$dlopen_self" != yes; then
- dlself=yes
- else
- dlself=needless
- fi
- prev=
- continue
- if test "$prev" = dlfiles; then
- dlfiles+=" $arg"
- else
- dlprefiles+=" $arg"
- fi
- prev=
- continue
- esac
- expsyms)
- export_symbols="$arg"
- test -f "$arg" \
- || func_fatal_error "symbol file \`$arg' does not exist"
- prev=
- continue
- expsyms_regex)
- export_symbols_regex="$arg"
- prev=
- continue
- framework)
- case $host in
- *-*-darwin*)
- case "$deplibs " in
- *" $qarg.ltframework "*) ;;
- *) deplibs+=" $qarg.ltframework" # this is fixed later
- esac
- esac
- prev=
- continue
- inst_prefix)
- inst_prefix_dir="$arg"
- prev=
- continue
- objectlist)
- if test -f "$arg"; then
- save_arg=$arg
- moreargs=
- for fil in `cat "$save_arg"`
- do
-# moreargs+=" $fil"
- arg=$fil
- # A libtool-controlled object.
- # Check to see that this really is a libtool object.
- if func_lalib_unsafe_p "$arg"; then
- pic_object=
- non_pic_object=
- # Read the .lo file
- func_source "$arg"
- if test -z "$pic_object" ||
- test -z "$non_pic_object" ||
- test "$pic_object" = none &&
- test "$non_pic_object" = none; then
- func_fatal_error "cannot find name of object for \`$arg'"
- fi
- # Extract subdirectory from the argument.
- func_dirname "$arg" "/" ""
- xdir="$func_dirname_result"
- if test "$pic_object" != none; then
- # Prepend the subdirectory the object is found in.
- pic_object="$xdir$pic_object"
- if test "$build_libtool_libs" = yes && test "$dlopen_support" = yes; then
- dlfiles+=" $pic_object"
- prev=
- continue
- else
- # If libtool objects are unsupported, then we need to preload.
- prev=dlprefiles
- fi
- fi
- # CHECK ME: I think I busted this. -Ossama
- # Preload the old-style object.
- dlprefiles+=" $pic_object"
- prev=
- fi
- # A PIC object.
- libobjs+=" $pic_object"
- arg="$pic_object"
- fi
- # Non-PIC object.
- if test "$non_pic_object" != none; then
- non_pic_object="$xdir$non_pic_object"
- # A standard non-PIC object
- non_pic_objects+=" $non_pic_object"
- if test -z "$pic_object" || test "$pic_object" = none ; then
- arg="$non_pic_object"
- fi
- else
- # If the PIC object exists, use it instead.
- # $xdir was prepended to $pic_object above.
- non_pic_object="$pic_object"
- fi
- else
- # Only an error if not doing a dry-run.
- if $opt_dry_run; then
- func_lo2o "$arg"
- pic_object=$xdir$objdir/$func_lo2o_result
- non_pic_object=$xdir$func_lo2o_result
- else
- func_fatal_error "\`$arg' is not a valid libtool object"
- fi
- fi
- done
- else
- func_fatal_error "link input file \`$arg' does not exist"
- fi
- arg=$save_arg
- prev=
- continue
- precious_regex)
- precious_files_regex="$arg"
- prev=
- continue
- release)
- release="-$arg"
- prev=
- continue
- rpath | xrpath)
- # We need an absolute path.
- case $arg in
- func_fatal_error "only absolute run-paths are allowed"
- esac
- if test "$prev" = rpath; then
- case "$rpath " in
- *" $arg "*) ;;
- *) rpath+=" $arg" ;;
- esac
- else
- case "$xrpath " in
- *" $arg "*) ;;
- *) xrpath+=" $arg" ;;
- esac
- fi
- prev=
- continue
- shrext)
- shrext_cmds="$arg"
- prev=
- continue
- weak)
- weak_libs+=" $arg"
- prev=
- continue
- xcclinker)
- linker_flags+=" $qarg"
- compiler_flags+=" $qarg"
- prev=
- compile_command+=" $qarg"
- finalize_command+=" $qarg"
- continue
- xcompiler)
- prev=
- continue
- xlinker)
- compiler_flags+=" $wl$qarg"
- prev=
- compile_command+=" $wl$qarg"
- finalize_command+=" $wl$qarg"
- continue
- eval "$prev=\"\$arg\""
- prev=
- continue
- esac
- fi # test -n "$prev"
- prevarg="$arg"
- case $arg in
- -all-static)
- # See comment for -static flag below, for more details.
- compile_command+=" $link_static_flag"
- finalize_command+=" $link_static_flag"
- fi
- continue
- -allow-undefined)
- # FIXME: remove this flag sometime in the future.
- func_fatal_error "\`-allow-undefined' must not be used because it is the default"
- -avoid-version)
- avoid_version=yes
- continue
- -bindir)
- prev=bindir
- continue
- -dlopen)
- prev=dlfiles
- continue
- -dlpreopen)
- prev=dlprefiles
- continue
- -export-dynamic)
- continue
- -export-symbols | -export-symbols-regex)
- if test -n "$export_symbols" || test -n "$export_symbols_regex"; then
- func_fatal_error "more than one -exported-symbols argument is not allowed"
- fi
- if test "X$arg" = "X-export-symbols"; then
- prev=expsyms
- else
- prev=expsyms_regex
- fi
- continue
- -framework)
- prev=framework
- continue
- -inst-prefix-dir)
- prev=inst_prefix
- continue
- # The native IRIX linker understands -LANG:*, -LIST:* and -LNO:*
- # so, if we see these flags be careful not to treat them like -L
- -L[A-Z][A-Z]*:*)
- case $with_gcc/$host in
- no/*-*-irix* | /*-*-irix*)
- compile_command+=" $arg"
- finalize_command+=" $arg"
- esac
- continue
- -L*)
- func_stripname "-L" '' "$arg"
- if test -z "$func_stripname_result"; then
- if test "$#" -gt 0; then
- func_fatal_error "require no space between \`-L' and \`$1'"
- else
- func_fatal_error "need path for \`-L' option"
- fi
- fi
- func_resolve_sysroot "$func_stripname_result"
- dir=$func_resolve_sysroot_result
- case $dir in
- [\\/]* | [A-Za-z]:[\\/]*) ;;
- absdir=`cd "$dir" && pwd`
- test -z "$absdir" && \
- func_fatal_error "cannot determine absolute directory name of \`$dir'"
- dir="$absdir"
- esac
- *" -L$dir "* | *" $arg "*)
- # Will only happen for absolute or sysroot arguments
- # Preserve sysroot, but never include relative directories
- case $dir in
- [\\/]* | [A-Za-z]:[\\/]* | =*) deplibs+=" $arg" ;;
- *) deplibs+=" -L$dir" ;;
- esac
- lib_search_path+=" $dir"
- esac
- case $host in
- testbindir=`$ECHO "$dir" | $SED 's*/lib$*/bin*'`
- case :$dllsearchpath: in
- *":$dir:"*) ;;
- ::) dllsearchpath=$dir;;
- *) dllsearchpath+=":$dir";;
- esac
- *":$testbindir:"*) ;;
- ::) dllsearchpath=$testbindir;;
- *) dllsearchpath+=":$testbindir";;
- esac
- esac
- continue
- -l*)
- if test "X$arg" = "X-lc" || test "X$arg" = "X-lm"; then
- case $host in
- *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-beos* | *-cegcc* | *-*-haiku*)
- # These systems don't actually have a C or math library (as such)
- continue
- *-*-os2*)
- # These systems don't actually have a C library (as such)
- test "X$arg" = "X-lc" && continue
- *-*-openbsd* | *-*-freebsd* | *-*-dragonfly*)
- # Do not include libc due to us having libc/libc_r.
- *-*-rhapsody* | *-*-darwin1.[012])
- # Rhapsody C and math libraries are in the System framework
- deplibs+=" System.ltframework"
- continue
- *-*-sco3.2v5* | *-*-sco5v6*)
- # Causes problems with __ctype
- *-*-sysv4.2uw2* | *-*-sysv5* | *-*-unixware* | *-*-OpenUNIX*)
- # Compiler inserts libc in the correct place for threads to work
- esac
- elif test "X$arg" = "X-lc_r"; then
- case $host in
- # Do not include libc_r directly, use -pthread flag.
- continue
- esac
- fi
- deplibs+=" $arg"
- continue
- -module)
- module=yes
- continue
- # Tru64 UNIX uses -model [arg] to determine the layout of C++
- # classes, name mangling, and exception handling.
- # Darwin uses the -arch flag to determine output architecture.
- -model|-arch|-isysroot|--sysroot)
- compiler_flags+=" $arg"
- prev=xcompiler
- continue
- -mt|-mthreads|-kthread|-Kthread|-pthread|-pthreads|--thread-safe \
- |-threads|-fopenmp|-openmp|-mp|-xopenmp|-omp|-qsmp=*)
- case "$new_inherited_linker_flags " in
- *" $arg "*) ;;
- * ) new_inherited_linker_flags+=" $arg" ;;
- esac
- continue
- -multi_module)
- single_module="${wl}-multi_module"
- continue
- -no-fast-install)
- fast_install=no
- continue
- -no-install)
- case $host in
- *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2* | *-*-darwin* | *-cegcc*)
- # The PATH hackery in wrapper scripts is required on Windows
- # and Darwin in order for the loader to find any dlls it needs.
- func_warning "\`-no-install' is ignored for $host"
- func_warning "assuming \`-no-fast-install' instead"
- fast_install=no
- *) no_install=yes ;;
- esac
- continue
- -no-undefined)
- allow_undefined=no
- continue
- -objectlist)
- prev=objectlist
- continue
- -o) prev=output ;;
- -precious-files-regex)
- prev=precious_regex
- continue
- -release)
- prev=release
- continue
- -rpath)
- prev=rpath
- continue
- -R)
- prev=xrpath
- continue
- -R*)
- func_stripname '-R' '' "$arg"
- dir=$func_stripname_result
- case $dir in
- func_stripname '=' '' "$dir"
- dir=$lt_sysroot$func_stripname_result
- esac
- *" $dir "*) ;;
- *) xrpath+=" $dir" ;;
- esac
- continue
- -shared)
- # The effects of -shared are defined in a previous loop.
- continue
- -shrext)
- prev=shrext
- continue
- -static | -static-libtool-libs)
- # The effects of -static are defined in a previous loop.
- # We used to do the same as -all-static on platforms that
- # didn't have a PIC flag, but the assumption that the effects
- # would be equivalent was wrong. It would break on at least
- # Digital Unix and AIX.
- continue
- -thread-safe)
- thread_safe=yes
- continue
- -version-info)
- prev=vinfo
- continue
- -version-number)
- prev=vinfo
- vinfo_number=yes
- continue
- -weak)
- prev=weak
- continue
- -Wc,*)
- func_stripname '-Wc,' '' "$arg"
- args=$func_stripname_result
- arg=
- save_ifs="$IFS"; IFS=','
- for flag in $args; do
- IFS="$save_ifs"
- func_quote_for_eval "$flag"
- arg+=" $func_quote_for_eval_result"
- compiler_flags+=" $func_quote_for_eval_result"
- done
- IFS="$save_ifs"
- func_stripname ' ' '' "$arg"
- arg=$func_stripname_result
- -Wl,*)
- func_stripname '-Wl,' '' "$arg"
- arg=
- IFS="$save_ifs"
- arg+=" $wl$func_quote_for_eval_result"
- compiler_flags+=" $wl$func_quote_for_eval_result"
- linker_flags+=" $func_quote_for_eval_result"
- done
- IFS="$save_ifs"
- -Xcompiler)
- prev=xcompiler
- continue
- -Xlinker)
- prev=xlinker
- continue
- -XCClinker)
- prev=xcclinker
- continue
- # -msg_* for osf cc
- -msg_*)
- func_quote_for_eval "$arg"
- arg="$func_quote_for_eval_result"
- # Flags to be passed through unchanged, with rationale:
- # -64, -mips[0-9] enable 64-bit mode for the SGI compiler
- # -r[0-9][0-9]* specify processor for the SGI compiler
- # -xarch=*, -xtarget=* enable 64-bit mode for the Sun compiler
- # +DA*, +DD* enable 64-bit mode for the HP compiler
- # -q* compiler args for the IBM compiler
- # -m*, -t[45]*, -txscale* architecture-specific flags for GCC
- # -F/path path to uninstalled frameworks, gcc on darwin
- # -p, -pg, --coverage, -fprofile-* profiling flags for GCC
- # @file GCC response files
- # -tp=* Portland pgcc target processor selection
- # --sysroot=* for sysroot support
- # -O*, -flto*, -fwhopr*, -fuse-linker-plugin GCC link-time optimization
- -64|-mips[0-9]|-r[0-9][0-9]*|-xarch=*|-xtarget=*|+DA*|+DD*|-q*|-m*| \
- -t[45]*|-txscale*|-p|-pg|--coverage|-fprofile-*|-F*|@*|-tp=*|--sysroot=*| \
- -O*|-flto*|-fwhopr*|-fuse-linker-plugin)
- continue
- # Some other compiler flag.
- *.$objext)
- # A standard object.
- objs+=" $arg"
- *.lo)
- pic_object=
- non_pic_object=
- fi
- prev=
- continue
- else
- prev=dlprefiles
- fi
- fi
- prev=
- fi
- # A PIC object.
- arg="$pic_object"
- fi
- # Non-PIC object.
- fi
- else
- fi
- else
- func_lo2o "$arg"
- else
- fi
- fi
- *.$libext)
- # An archive.
- deplibs+=" $arg"
- old_deplibs+=" $arg"
- continue
- *.la)
- # A libtool-controlled library.
- func_resolve_sysroot "$arg"
- # This library was specified with -dlopen.
- dlfiles+=" $func_resolve_sysroot_result"
- prev=
- elif test "$prev" = dlprefiles; then
- # The library was specified with -dlpreopen.
- dlprefiles+=" $func_resolve_sysroot_result"
- prev=
- else
- deplibs+=" $func_resolve_sysroot_result"
- fi
- continue
- # Some other compiler argument.
- # Unknown arguments in both finalize_command and compile_command need
- # to be aesthetically quoted because they are evaled later.
- esac # arg
- # Now actually substitute the argument into the commands.
- if test -n "$arg"; then
- fi
- done # argument parsing loop
- test -n "$prev" && \
- func_fatal_help "the \`$prevarg' option requires an argument"
- if test "$export_dynamic" = yes && test -n "$export_dynamic_flag_spec"; then
- eval arg=\"$export_dynamic_flag_spec\"
- fi
- oldlibs=
- # calculate the name of the file, without its directory
- func_basename "$output"
- outputname="$func_basename_result"
- libobjs_save="$libobjs"
- if test -n "$shlibpath_var"; then
- # get the directories listed in $shlibpath_var
- eval shlib_search_path=\`\$ECHO \"\${$shlibpath_var}\" \| \$SED \'s/:/ /g\'\`
- else
- shlib_search_path=
- fi
- eval sys_lib_search_path=\"$sys_lib_search_path_spec\"
- eval sys_lib_dlsearch_path=\"$sys_lib_dlsearch_path_spec\"
- func_dirname "$output" "/" ""
- output_objdir="$func_dirname_result$objdir"
- func_to_tool_file "$output_objdir/"
- tool_output_objdir=$func_to_tool_file_result
- # Create the object directory.
- func_mkdir_p "$output_objdir"
- # Determine the type of output
- case $output in
- func_fatal_help "you must specify an output file"
- *.$libext) linkmode=oldlib ;;
- *.lo | *.$objext) linkmode=obj ;;
- *.la) linkmode=lib ;;
- *) linkmode=prog ;; # Anything else should be a program.
- esac
- specialdeplibs=
- libs=
- # Find all interdependent deplibs by searching for libraries
- # that are linked more than once (e.g. -la -lb -la)
- for deplib in $deplibs; do
- if $opt_preserve_dup_deps ; then
- case "$libs " in
- *" $deplib "*) specialdeplibs+=" $deplib" ;;
- esac
- fi
- libs+=" $deplib"
- done
- if test "$linkmode" = lib; then
- libs="$predeps $libs $compiler_lib_search_path $postdeps"
- # Compute libraries that are listed more than once in $predeps
- # $postdeps and mark them as special (i.e., whose duplicates are
- # not to be eliminated).
- pre_post_deps=
- if $opt_duplicate_compiler_generated_deps; then
- for pre_post_dep in $predeps $postdeps; do
- case "$pre_post_deps " in
- *" $pre_post_dep "*) specialdeplibs+=" $pre_post_deps" ;;
- esac
- pre_post_deps+=" $pre_post_dep"
- done
- fi
- pre_post_deps=
- fi
- deplibs=
- newdependency_libs=
- newlib_search_path=
- need_relink=no # whether we're linking any uninstalled libtool libraries
- notinst_deplibs= # not-installed libtool libraries
- notinst_path= # paths that contain not-installed libtool libraries
- case $linkmode in
- lib)
- passes="conv dlpreopen link"
- for file in $dlfiles $dlprefiles; do
- case $file in
- *.la) ;;
- func_fatal_help "libraries can \`-dlopen' only libtool libraries: $file"
- esac
- done
- prog)
- compile_deplibs=
- finalize_deplibs=
- alldeplibs=no
- newdlfiles=
- newdlprefiles=
- passes="conv scan dlopen dlpreopen link"
- *) passes="conv"
- esac
- for pass in $passes; do
- # The preopen pass in lib mode reverses $deplibs; put it back here
- # so that -L comes before libs that need it for instance...
- if test "$linkmode,$pass" = "lib,link"; then
- ## FIXME: Find the place where the list is rebuilt in the wrong
- ## order, and fix it there properly
- tmp_deplibs=
- tmp_deplibs="$deplib $tmp_deplibs"
- done
- deplibs="$tmp_deplibs"
- fi
- if test "$linkmode,$pass" = "lib,link" ||
- test "$linkmode,$pass" = "prog,scan"; then
- libs="$deplibs"
- deplibs=
- fi
- if test "$linkmode" = prog; then
- case $pass in
- dlopen) libs="$dlfiles" ;;
- dlpreopen) libs="$dlprefiles" ;;
- link)
- libs="$deplibs %DEPLIBS%"
- test "X$link_all_deplibs" != Xno && libs="$libs $dependency_libs"
- esac
- fi
- if test "$linkmode,$pass" = "lib,dlpreopen"; then
- # Collect and forward deplibs of preopened libtool libs
- for lib in $dlprefiles; do
- # Ignore non-libtool-libs
- dependency_libs=
- func_resolve_sysroot "$lib"
- case $lib in
- *.la) func_source "$func_resolve_sysroot_result" ;;
- esac
- # Collect preopened libtool deplibs, except any this library
- # has declared as weak libs
- for deplib in $dependency_libs; do
- func_basename "$deplib"
- deplib_base=$func_basename_result
- case " $weak_libs " in
- *" $deplib_base "*) ;;
- *) deplibs+=" $deplib" ;;
- esac
- done
- done
- libs="$dlprefiles"
- fi
- if test "$pass" = dlopen; then
- # Collect dlpreopened libraries
- save_deplibs="$deplibs"
- deplibs=
- fi
- for deplib in $libs; do
- lib=
- found=no
- case $deplib in
- if test "$linkmode,$pass" = "prog,link"; then
- compile_deplibs="$deplib $compile_deplibs"
- finalize_deplibs="$deplib $finalize_deplibs"
- else
- compiler_flags+=" $deplib"
- if test "$linkmode" = lib ; then
- *" $deplib "*) ;;
- * ) new_inherited_linker_flags+=" $deplib" ;;
- esac
- fi
- fi
- continue
- -l*)
- if test "$linkmode" != lib && test "$linkmode" != prog; then
- func_warning "\`-l' is ignored for archives/objects"
- continue
- fi
- func_stripname '-l' '' "$deplib"
- name=$func_stripname_result
- searchdirs="$newlib_search_path $lib_search_path $compiler_lib_search_dirs $sys_lib_search_path $shlib_search_path"
- else
- searchdirs="$newlib_search_path $lib_search_path $sys_lib_search_path $shlib_search_path"
- fi
- for searchdir in $searchdirs; do
- for search_ext in .la $std_shrext .so .a; do
- # Search the libtool library
- lib="$searchdir/lib${name}${search_ext}"
- if test -f "$lib"; then
- if test "$search_ext" = ".la"; then
- found=yes
- else
- found=no
- fi
- break 2
- fi
- done
- done
- if test "$found" != yes; then
- # deplib doesn't seem to be a libtool library
- else
- deplibs="$deplib $deplibs"
- test "$linkmode" = lib && newdependency_libs="$deplib $newdependency_libs"
- fi
- continue
- else # deplib is a libtool library
- # If $allow_libtool_libs_with_static_runtimes && $deplib is a stdlib,
- # We need to do some special things here, and not later.
- if test "X$allow_libtool_libs_with_static_runtimes" = "Xyes" ; then
- case " $predeps $postdeps " in
- *" $deplib "*)
- if func_lalib_p "$lib"; then
- library_names=
- old_library=
- func_source "$lib"
- for l in $old_library $library_names; do
- ll="$l"
- done
- if test "X$ll" = "X$old_library" ; then # only static version available
- found=no
- func_dirname "$lib" "" "."
- ladir="$func_dirname_result"
- lib=$ladir/$old_library
- else
- fi
- continue
- fi
- fi
- esac
- fi
- fi
- ;; # -l
- *.ltframework)
- else
- *" $deplib "*) ;;
- esac
- fi
- fi
- continue
- -L*)
- case $linkmode in
- lib)
- test "$pass" = conv && continue
- newdependency_libs="$deplib $newdependency_libs"
- func_stripname '-L' '' "$deplib"
- newlib_search_path+=" $func_resolve_sysroot_result"
- prog)
- if test "$pass" = conv; then
- continue
- fi
- if test "$pass" = scan; then
- else
- fi
- func_warning "\`-L' is ignored for archives/objects"
- esac # linkmode
- continue
- ;; # -L
- -R*)
- if test "$pass" = link; then
- func_stripname '-R' '' "$deplib"
- # Make sure the xrpath contains only unique directories.
- *" $dir "*) ;;
- esac
- fi
- continue
- *.la)
- func_resolve_sysroot "$deplib"
- lib=$func_resolve_sysroot_result
- *.$libext)
- continue
- fi
- case $linkmode in
- lib)
- # Linking convenience modules into shared libraries is allowed,
- # but linking other static libraries is non-portable.
- case " $dlpreconveniencelibs " in
- *" $deplib "*) ;;
- valid_a_lib=no
- case $deplibs_check_method in
- match_pattern*)
- set dummy $deplibs_check_method; shift
- match_pattern_regex=`expr "$deplibs_check_method" : "$1 \(.*\)"`
- if eval "\$ECHO \"$deplib\"" 2>/dev/null | $SED 10q \
- | $EGREP "$match_pattern_regex" > /dev/null; then
- valid_a_lib=yes
- fi
- pass_all)
- valid_a_lib=yes
- esac
- if test "$valid_a_lib" != yes; then
- echo
- $ECHO "*** Warning: Trying to link with static lib archive $deplib."
- echo "*** I have the capability to make that library automatically link in when"
- echo "*** you link to this library. But I can only do this if you have a"
- echo "*** shared version of the library, which you do not appear to have"
- echo "*** because the file extensions .$libext of this argument makes me believe"
- echo "*** that it is just a static archive that I should not use here."
- else
- echo
- $ECHO "*** Warning: Linking the shared library $output against the"
- $ECHO "*** static library $deplib is not portable!"
- fi
- esac
- continue
- prog)
- if test "$pass" != link; then
- else
- fi
- continue
- esac # linkmode
- ;; # *.$libext
- *.lo | *.$objext)
- elif test "$linkmode" = prog; then
- if test "$pass" = dlpreopen || test "$dlopen_support" != yes || test "$build_libtool_libs" = no; then
- # If there is no dlopen support or we're linking statically,
- # we need to preload.
- newdlprefiles+=" $deplib"
- else
- newdlfiles+=" $deplib"
- fi
- fi
- continue
- %DEPLIBS%)
- alldeplibs=yes
- continue
- esac # case $deplib
- if test "$found" = yes || test -f "$lib"; then :
- else
- func_fatal_error "cannot find the library \`$lib' or unhandled argument \`$deplib'"
- fi
- # Check to see that this really is a libtool archive.
- func_lalib_unsafe_p "$lib" \
- || func_fatal_error "\`$lib' is not a valid libtool archive"
- dlname=
- dlopen=
- dlpreopen=
- libdir=
- library_names=
- old_library=
- inherited_linker_flags=
- # If the library was installed with an old release of libtool,
- # it will not redefine variables installed, or shouldnotlink
- installed=yes
- shouldnotlink=no
- avoidtemprpath=
- # Read the .la file
- # Convert "-framework foo" to "foo.ltframework"
- if test -n "$inherited_linker_flags"; then
- tmp_inherited_linker_flags=`$ECHO "$inherited_linker_flags" | $SED 's/-framework \([^ $]*\)/\1.ltframework/g'`
- for tmp_inherited_linker_flag in $tmp_inherited_linker_flags; do
- case " $new_inherited_linker_flags " in
- *" $tmp_inherited_linker_flag "*) ;;
- *) new_inherited_linker_flags+=" $tmp_inherited_linker_flag";;
- esac
- done
- fi
- dependency_libs=`$ECHO " $dependency_libs" | $SED 's% \([^ $]*\).ltframework% -framework \1%g'`
- test "$linkmode,$pass" = "prog,scan" ||
- { test "$linkmode" != prog && test "$linkmode" != lib; }; then
- test -n "$dlopen" && dlfiles+=" $dlopen"
- test -n "$dlpreopen" && dlprefiles+=" $dlpreopen"
- fi
- # Only check for convenience libraries
- deplibs="$lib $deplibs"
- if test -z "$libdir"; then
- if test -z "$old_library"; then
- func_fatal_error "cannot find name of link library for \`$lib'"
- fi
- # It is a libtool convenience library, so add in its objects.
- convenience+=" $ladir/$objdir/$old_library"
- old_convenience+=" $ladir/$objdir/$old_library"
- tmp_libs=
- case "$tmp_libs " in
- esac
- fi
- tmp_libs+=" $deplib"
- done
- elif test "$linkmode" != prog && test "$linkmode" != lib; then
- func_fatal_error "\`$lib' is not a convenience library"
- fi
- continue
- fi # $pass = conv
- # Get the name of the library we link against.
- linklib=
- if test -n "$old_library" &&
- { test "$prefer_static_libs" = yes ||
- test "$prefer_static_libs,$installed" = "built,no"; }; then
- linklib=$old_library
- else
- linklib="$l"
- done
- fi
- if test -z "$linklib"; then
- fi
- func_fatal_error "cannot -dlopen a convenience library: \`$lib'"
- fi
- if test -z "$dlname" ||
- test "$dlopen_support" != yes ||
- test "$build_libtool_libs" = no; then
- # If there is no dlname, no dlopen support or we're linking
- # statically, we need to preload. We also need to preload any
- # dependent libraries so libltdl's deplib preloader doesn't
- # bomb out in the load deplibs phase.
- dlprefiles+=" $lib $dependency_libs"
- else
- newdlfiles+=" $lib"
- fi
- continue
- fi # $pass = dlopen
- case $ladir in
- [\\/]* | [A-Za-z]:[\\/]*) abs_ladir="$ladir" ;;
- abs_ladir=`cd "$ladir" && pwd`
- if test -z "$abs_ladir"; then
- func_warning "cannot determine absolute directory name of \`$ladir'"
- func_warning "passing it literally to the linker, although it might fail"
- abs_ladir="$ladir"
- fi
- esac
- func_basename "$lib"
- laname="$func_basename_result"
- # Find the relevant object directory and library name.
- if test "X$installed" = Xyes; then
- if test ! -f "$lt_sysroot$libdir/$linklib" && test -f "$abs_ladir/$linklib"; then
- func_warning "library \`$lib' was moved."
- dir="$ladir"
- absdir="$abs_ladir"
- libdir="$abs_ladir"
- else
- dir="$lt_sysroot$libdir"
- absdir="$lt_sysroot$libdir"
- fi
- test "X$hardcode_automatic" = Xyes && avoidtemprpath=yes
- else
- if test ! -f "$ladir/$objdir/$linklib" && test -f "$abs_ladir/$linklib"; then
- dir="$ladir"
- # Remove this search path later
- notinst_path+=" $abs_ladir"
- else
- dir="$ladir/$objdir"
- absdir="$abs_ladir/$objdir"
- fi
- fi # $installed = yes
- func_stripname 'lib' '.la' "$laname"
- # This library was specified with -dlpreopen.
- if test "$pass" = dlpreopen; then
- if test -z "$libdir" && test "$linkmode" = prog; then
- func_fatal_error "only libraries may -dlpreopen a convenience library: \`$lib'"
- fi
- case "$host" in
- # special handling for platforms with PE-DLLs.
- *cygwin* | *mingw* | *cegcc* )
- # Linker will automatically link against shared library if both
- # static and shared are present. Therefore, ensure we extract
- # symbols from the import library if a shared library is present
- # (otherwise, the dlopen module name will be incorrect). We do
- # this by putting the import library name into $newdlprefiles.
- # We recover the dlopen module name by 'saving' the la file
- # name in a special purpose variable, and (later) extracting the
- # dlname from the la file.
- if test -n "$dlname"; then
- func_tr_sh "$dir/$linklib"
- eval "libfile_$func_tr_sh_result=\$abs_ladir/\$laname"
- newdlprefiles+=" $dir/$linklib"
- else
- newdlprefiles+=" $dir/$old_library"
- # Keep a list of preopened convenience libraries to check
- # that they are being used correctly in the link pass.
- test -z "$libdir" && \
- dlpreconveniencelibs+=" $dir/$old_library"
- fi
- # Prefer using a static library (so that no silly _DYNAMIC symbols
- # are required to link).
- if test -n "$old_library"; then
- # Otherwise, use the dlname, so that lt_dlopen finds it.
- elif test -n "$dlname"; then
- newdlprefiles+=" $dir/$dlname"
- else
- fi
- esac
- fi # $pass = dlpreopen
- # Link the convenience library
- deplibs="$dir/$old_library $deplibs"
- elif test "$linkmode,$pass" = "prog,link"; then
- compile_deplibs="$dir/$old_library $compile_deplibs"
- finalize_deplibs="$dir/$old_library $finalize_deplibs"
- else
- deplibs="$lib $deplibs" # used for prog,scan pass
- fi
- continue
- fi
- if test "$linkmode" = prog && test "$pass" != link; then
- newlib_search_path+=" $ladir"
- linkalldeplibs=no
- if test "$link_all_deplibs" != no || test -z "$library_names" ||
- linkalldeplibs=yes
- fi
- tmp_libs=
- case $deplib in
- -L*) func_stripname '-L' '' "$deplib"
- esac
- # Need to link against all dependency_libs?
- if test "$linkalldeplibs" = yes; then
- else
- # Need to hardcode shared library paths
- # or/and link against static libraries
- fi
- esac
- fi
- done # for deplib
- continue
- fi # $linkmode = prog...
- if test -n "$library_names" &&
- { { test "$prefer_static_libs" = no ||
- test "$prefer_static_libs,$installed" = "built,yes"; } ||
- test -z "$old_library"; }; then
- # We need to hardcode the library path
- if test -n "$shlibpath_var" && test -z "$avoidtemprpath" ; then
- # Make sure the rpath contains only unique directories.
- case "$temp_rpath:" in
- *"$absdir:"*) ;;
- *) temp_rpath+="$absdir:" ;;
- esac
- fi
- # Hardcode the library path.
- # Skip directories that are in the system default run-time
- # search path.
- case " $sys_lib_dlsearch_path " in
- *" $absdir "*) ;;
- case "$compile_rpath " in
- *" $absdir "*) ;;
- *) compile_rpath+=" $absdir" ;;
- esac
- esac
- *" $libdir "*) ;;
- case "$finalize_rpath " in
- *" $libdir "*) ;;
- *) finalize_rpath+=" $libdir" ;;
- esac
- esac
- fi # $linkmode,$pass = prog,link...
- if test "$alldeplibs" = yes &&
- { test "$deplibs_check_method" = pass_all ||
- { test "$build_libtool_libs" = yes &&
- test -n "$library_names"; }; }; then
- # We only need to search for static libraries
- continue
- fi
- fi
- link_static=no # Whether the deplib will be linked statically
- use_static_libs=$prefer_static_libs
- if test "$use_static_libs" = built && test "$installed" = yes; then
- use_static_libs=no
- fi
- { test "$use_static_libs" = no || test -z "$old_library"; }; then
- case $host in
- *cygwin* | *mingw* | *cegcc*)
- # No point in relinking DLLs because paths are not encoded
- notinst_deplibs+=" $lib"
- need_relink=no
- if test "$installed" = no; then
- need_relink=yes
- fi
- esac
- # This is a shared library
- # Warn about portability, can't link against -module's on some
- # systems (darwin). Don't bleat about dlopened modules though!
- dlopenmodule=""
- for dlpremoduletest in $dlprefiles; do
- if test "X$dlpremoduletest" = "X$lib"; then
- dlopenmodule="$dlpremoduletest"
- break
- fi
- done
- if test -z "$dlopenmodule" && test "$shouldnotlink" = yes && test "$pass" = link; then
- echo
- $ECHO "*** Warning: Linking the executable $output against the loadable module"
- else
- $ECHO "*** Warning: Linking the shared library $output against the loadable module"
- fi
- $ECHO "*** $linklib is not portable!"
- fi
- if test "$linkmode" = lib &&
- test "$hardcode_into_libs" = yes; then
- # search path.
- *" $absdir "*) ;;
- *" $absdir "*) ;;
- esac
- esac
- *" $libdir "*) ;;
- *" $libdir "*) ;;
- esac
- esac
- fi
- if test -n "$old_archive_from_expsyms_cmds"; then
- # figure out the soname
- set dummy $library_names
- shift
- realname="$1"
- shift
- libname=`eval "\\$ECHO \"$libname_spec\""`
- # use dlname if we got it. it's perfectly good, no?
- soname="$dlname"
- elif test -n "$soname_spec"; then
- # bleh windows
- case $host in
- *cygwin* | mingw* | *cegcc*)
- func_arith $current - $age
- major=$func_arith_result
- versuffix="-$major"
- esac
- eval soname=\"$soname_spec\"
- else
- soname="$realname"
- fi
- # Make a new name for the extract_expsyms_cmds to use
- soroot="$soname"
- func_basename "$soroot"
- soname="$func_basename_result"
- func_stripname 'lib' '.dll' "$soname"
- newlib=libimp-$func_stripname_result.a
- # If the library has no export list, then create one now
- if test -f "$output_objdir/$soname-def"; then :
- else
- func_verbose "extracting exported symbol list from \`$soname'"
- func_execute_cmds "$extract_expsyms_cmds" 'exit $?'
- fi
- # Create $newlib
- if test -f "$output_objdir/$newlib"; then :; else
- func_verbose "generating import library for \`$soname'"
- func_execute_cmds "$old_archive_from_expsyms_cmds" 'exit $?'
- fi
- # make sure the library variables are pointing to the new library
- dir=$output_objdir
- linklib=$newlib
- fi # test -n "$old_archive_from_expsyms_cmds"
- if test "$linkmode" = prog || test "$opt_mode" != relink; then
- add_shlibpath=
- add_dir=
- add=
- lib_linked=yes
- case $hardcode_action in
- immediate | unsupported)
- if test "$hardcode_direct" = no; then
- add="$dir/$linklib"
- case $host in
- *-*-sco3.2v5.0.[024]*) add_dir="-L$dir" ;;
- *-*-sysv4*uw2*) add_dir="-L$dir" ;;
- *-*-sysv5OpenUNIX* | *-*-sysv5UnixWare7.[01].[10]* | \
- *-*-unixware7*) add_dir="-L$dir" ;;
- *-*-darwin* )
- # if the lib is a (non-dlopened) module then we can not
- # link against it, someone is ignoring the earlier warnings
- if /usr/bin/file -L $add 2> /dev/null |
- $GREP ": [^:]* bundle" >/dev/null ; then
- if test "X$dlopenmodule" != "X$lib"; then
- $ECHO "*** Warning: lib $linklib is a module, not a shared library"
- if test -z "$old_library" ; then
- echo
- echo "*** And there doesn't seem to be a static archive available"
- echo "*** The link will probably fail, sorry"
- else
- add="$dir/$old_library"
- fi
- elif test -n "$old_library"; then
- fi
- fi
- esac
- elif test "$hardcode_minus_L" = no; then
- case $host in
- *-*-sunos*) add_shlibpath="$dir" ;;
- esac
- add_dir="-L$dir"
- add="-l$name"
- elif test "$hardcode_shlibpath_var" = no; then
- add_shlibpath="$dir"
- add="-l$name"
- else
- lib_linked=no
- fi
- relink)
- if test "$hardcode_direct" = yes &&
- test "$hardcode_direct_absolute" = no; then
- elif test "$hardcode_minus_L" = yes; then
- add_dir="-L$absdir"
- # Try looking first in the location we're being installed to.
- if test -n "$inst_prefix_dir"; then
- case $libdir in
- add_dir+=" -L$inst_prefix_dir$libdir"
- esac
- fi
- add="-l$name"
- elif test "$hardcode_shlibpath_var" = yes; then
- add="-l$name"
- else
- lib_linked=no
- fi
- *) lib_linked=no ;;
- esac
- if test "$lib_linked" != yes; then
- func_fatal_configuration "unsupported hardcode properties"
- fi
- if test -n "$add_shlibpath"; then
- case :$compile_shlibpath: in
- *":$add_shlibpath:"*) ;;
- *) compile_shlibpath+="$add_shlibpath:" ;;
- esac
- fi
- test -n "$add_dir" && compile_deplibs="$add_dir $compile_deplibs"
- test -n "$add" && compile_deplibs="$add $compile_deplibs"
- else
- test -n "$add_dir" && deplibs="$add_dir $deplibs"
- test -n "$add" && deplibs="$add $deplibs"
- if test "$hardcode_direct" != yes &&
- test "$hardcode_minus_L" != yes &&
- test "$hardcode_shlibpath_var" = yes; then
- case :$finalize_shlibpath: in
- *":$libdir:"*) ;;
- *) finalize_shlibpath+="$libdir:" ;;
- esac
- fi
- fi
- fi
- if test "$linkmode" = prog || test "$opt_mode" = relink; then
- add_shlibpath=
- add_dir=
- add=
- # Finalize command for both is simple: just hardcode it.
- add="$libdir/$linklib"
- add_dir="-L$libdir"
- add="-l$name"
- *":$libdir:"*) ;;
- esac
- add="-l$name"
- elif test "$hardcode_automatic" = yes; then
- if test -n "$inst_prefix_dir" &&
- test -f "$inst_prefix_dir$libdir/$linklib" ; then
- add="$inst_prefix_dir$libdir/$linklib"
- else
- fi
- else
- # We cannot seem to hardcode it, guess we'll fake it.
- case $libdir in
- esac
- fi
- add="-l$name"
- fi
- test -n "$add_dir" && finalize_deplibs="$add_dir $finalize_deplibs"
- test -n "$add" && finalize_deplibs="$add $finalize_deplibs"
- else
- fi
- fi
- # Here we assume that one of hardcode_direct or hardcode_minus_L
- # is not unsupported. This is valid on all known static and
- # shared platforms.
- if test "$hardcode_direct" != unsupported; then
- test -n "$old_library" && linklib="$old_library"
- compile_deplibs="$dir/$linklib $compile_deplibs"
- finalize_deplibs="$dir/$linklib $finalize_deplibs"
- else
- compile_deplibs="-l$name -L$dir $compile_deplibs"
- finalize_deplibs="-l$name -L$dir $finalize_deplibs"
- fi
- elif test "$build_libtool_libs" = yes; then
- # Not a shared library
- if test "$deplibs_check_method" != pass_all; then
- # We're trying link a shared library against a static one
- # but the system doesn't support it.
- # Just print a warning and add the library to dependency_libs so
- # that the program can be linked against the static library.
- echo
- $ECHO "*** Warning: This system can not link to static lib archive $lib."
- echo "*** shared version of the library, which you do not appear to have."
- if test "$module" = yes; then
- echo "*** But as you try to build a module library, libtool will still create "
- echo "*** a static module, that should work as long as the dlopening application"
- echo "*** is linked with the -dlopen flag to resolve symbols at runtime."
- if test -z "$global_symbol_pipe"; then
- echo
- echo "*** However, this would only work if libtool was able to extract symbol"
- echo "*** lists from a program, using \`nm' or equivalent, but libtool could"
- echo "*** not find such a program. So, this module is probably useless."
- echo "*** \`nm' from GNU binutils and a full rebuild may help."
- fi
- if test "$build_old_libs" = no; then
- build_libtool_libs=module
- else
- fi
- fi
- else
- link_static=yes
- fi
- fi # link shared/static library?
- if test -n "$dependency_libs" &&
- { test "$hardcode_into_libs" != yes ||
- test "$build_old_libs" = yes ||
- test "$link_static" = yes; }; then
- # Extract -R from dependency_libs
- temp_deplibs=
- for libdir in $dependency_libs; do
- case $libdir in
- -R*) func_stripname '-R' '' "$libdir"
- temp_xrpath=$func_stripname_result
- case " $xrpath " in
- *" $temp_xrpath "*) ;;
- *) xrpath+=" $temp_xrpath";;
- esac;;
- *) temp_deplibs+=" $libdir";;
- esac
- done
- dependency_libs="$temp_deplibs"
- fi
- newlib_search_path+=" $absdir"
- # Link against this library
- test "$link_static" = no && newdependency_libs="$abs_ladir/$laname $newdependency_libs"
- # ... and its dependency_libs
- tmp_libs=
- case $deplib in
- func_resolve_sysroot "$func_stripname_result";;
- *) func_resolve_sysroot "$deplib" ;;
- esac
- *" $func_resolve_sysroot_result "*)
- specialdeplibs+=" $func_resolve_sysroot_result" ;;
- esac
- fi
- tmp_libs+=" $func_resolve_sysroot_result"
- done
- if test "$link_all_deplibs" != no; then
- # Add the search paths of all dependency libraries
- path=
- case $deplib in
- -L*) path="$deplib" ;;
- *.la)
- deplib=$func_resolve_sysroot_result
- func_dirname "$deplib" "" "."
- dir=$func_dirname_result
- case $dir in
- [\\/]* | [A-Za-z]:[\\/]*) absdir="$dir" ;;
- if test -z "$absdir"; then
- func_warning "cannot determine absolute directory name of \`$dir'"
- absdir="$dir"
- fi
- esac
- if $GREP "^installed=no" $deplib > /dev/null; then
- case $host in
- *-*-darwin*)
- depdepl=
- eval deplibrary_names=`${SED} -n -e 's/^library_names=\(.*\)$/\1/p' $deplib`
- if test -n "$deplibrary_names" ; then
- for tmp in $deplibrary_names ; do
- depdepl=$tmp
- done
- if test -f "$absdir/$objdir/$depdepl" ; then
- depdepl="$absdir/$objdir/$depdepl"
- darwin_install_name=`${OTOOL} -L $depdepl | awk '{if (NR == 2) {print $1;exit}}'`
- if test -z "$darwin_install_name"; then
- darwin_install_name=`${OTOOL64} -L $depdepl | awk '{if (NR == 2) {print $1;exit}}'`
- fi
- compiler_flags+=" ${wl}-dylib_file ${wl}${darwin_install_name}:${depdepl}"
- linker_flags+=" -dylib_file ${darwin_install_name}:${depdepl}"
- path=
- fi
- fi
- path="-L$absdir/$objdir"
- esac
- else
- eval libdir=`${SED} -n -e 's/^libdir=\(.*\)$/\1/p' $deplib`
- func_fatal_error "\`$deplib' is not a valid libtool archive"
- test "$absdir" != "$libdir" && \
- func_warning "\`$deplib' seems to be moved"
- path="-L$absdir"
- fi
- esac
- case " $deplibs " in
- *" $path "*) ;;
- *) deplibs="$path $deplibs" ;;
- esac
- done
- fi # link_all_deplibs != no
- fi # linkmode = lib
- done # for deplib in $libs
- if test "$linkmode" = "prog"; then
- compile_deplibs="$new_inherited_linker_flags $compile_deplibs"
- finalize_deplibs="$new_inherited_linker_flags $finalize_deplibs"
- else
- compiler_flags="$compiler_flags "`$ECHO " $new_inherited_linker_flags" | $SED 's% \([^ $]*\).ltframework% -framework \1%g'`
- fi
- fi
- dependency_libs="$newdependency_libs"
- # Link the dlpreopened libraries before other libraries
- for deplib in $save_deplibs; do
- done
- fi
- if test "$pass" != dlopen; then
- if test "$pass" != conv; then
- # Make sure lib_search_path contains only unique directories.
- lib_search_path=
- for dir in $newlib_search_path; do
- case "$lib_search_path " in
- *" $dir "*) ;;
- *) lib_search_path+=" $dir" ;;
- esac
- done
- fi
- if test "$linkmode,$pass" != "prog,link"; then
- vars="deplibs"
- else
- vars="compile_deplibs finalize_deplibs"
- fi
- for var in $vars dependency_libs; do
- # Add libraries to $var in reverse order
- eval tmp_libs=\"\$$var\"
- new_libs=
- for deplib in $tmp_libs; do
- # FIXME: Pedantically, this is the right thing to do, so
- # that some nasty dependency loop isn't accidentally
- # broken:
- #new_libs="$deplib $new_libs"
- # Pragmatically, this seems to cause very few problems in
- # practice:
- case $deplib in
- -L*) new_libs="$deplib $new_libs" ;;
- -R*) ;;
- # And here is the reason: when a library appears more
- # than once as an explicit dependence of a library, or
- # is implicitly linked in more than once by the
- # compiler, it is considered special, and multiple
- # occurrences thereof are not removed. Compare this
- # with having the same library being listed as a
- # dependency of multiple other libraries: in this case,
- # we know (pedantically, we assume) the library does not
- # need to be listed more than once, so we keep only the
- # last copy. This is not always right, but it is rare
- # enough that we require users that really mean to play
- # such unportable linking tricks to link the library
- # using -Wl,-lname, so that libtool does not consider it
- # for duplicate removal.
- case " $specialdeplibs " in
- *" $deplib "*) new_libs="$deplib $new_libs" ;;
- case " $new_libs " in
- *" $deplib "*) ;;
- *) new_libs="$deplib $new_libs" ;;
- esac
- esac
- esac
- done
- tmp_libs=
- for deplib in $new_libs; do
- case $deplib in
- -L*)
- case " $tmp_libs " in
- *" $deplib "*) ;;
- *) tmp_libs+=" $deplib" ;;
- esac
- esac
- done
- eval $var=\"$tmp_libs\"
- done # for var
- fi
- # Last step: remove runtime libs from dependency_libs
- # (they stay in deplibs)
- tmp_libs=
- for i in $dependency_libs ; do
- case " $predeps $postdeps $compiler_lib_search_path " in
- *" $i "*)
- i=""
- esac
- if test -n "$i" ; then
- tmp_libs+=" $i"
- fi
- done
- dependency_libs=$tmp_libs
- done # for pass
- dlfiles="$newdlfiles"
- fi
- if test "$linkmode" = prog || test "$linkmode" = lib; then
- dlprefiles="$newdlprefiles"
- fi
- case $linkmode in
- oldlib)
- if test -n "$dlfiles$dlprefiles" || test "$dlself" != no; then
- func_warning "\`-dlopen' is ignored for archives"
- fi
- case " $deplibs" in
- *\ -l* | *\ -L*)
- func_warning "\`-l' and \`-L' are ignored for archives" ;;
- esac
- test -n "$rpath" && \
- func_warning "\`-rpath' is ignored for archives"
- test -n "$xrpath" && \
- func_warning "\`-R' is ignored for archives"
- test -n "$vinfo" && \
- func_warning "\`-version-info/-version-number' is ignored for archives"
- test -n "$release" && \
- func_warning "\`-release' is ignored for archives"
- test -n "$export_symbols$export_symbols_regex" && \
- func_warning "\`-export-symbols' is ignored for archives"
- # Now set the variables for building old libraries.
- oldlibs="$output"
- objs+="$old_deplibs"
- lib)
- # Make sure we only generate libraries of the form `libNAME.la'.
- case $outputname in
- lib*)
- func_stripname 'lib' '.la' "$outputname"
- eval shared_ext=\"$shrext_cmds\"
- eval libname=\"$libname_spec\"
- test "$module" = no && \
- func_fatal_help "libtool library \`$output' must begin with \`lib'"
- if test "$need_lib_prefix" != no; then
- # Add the "lib" prefix for modules if required
- func_stripname '' '.la' "$outputname"
- else
- libname=$func_stripname_result
- fi
- esac
- if test -n "$objs"; then
- func_fatal_error "cannot build libtool library \`$output' from non-libtool objects on this host:$objs"
- else
- echo
- $ECHO "*** Warning: Linking the shared library $output against the non-libtool"
- $ECHO "*** objects $objs is not portable!"
- libobjs+=" $objs"
- fi
- fi
- test "$dlself" != no && \
- func_warning "\`-dlopen self' is ignored for libtool libraries"
- set dummy $rpath
- shift
- test "$#" -gt 1 && \
- func_warning "ignoring multiple \`-rpath's for a libtool library"
- install_libdir="$1"
- oldlibs=
- if test -z "$rpath"; then
- if test "$build_libtool_libs" = yes; then
- # Building a libtool convenience library.
- # Some compilers have problems with a `.al' extension so
- # convenience libraries should have the same extension an
- # archive normally would.
- oldlibs="$output_objdir/$libname.$libext $oldlibs"
- build_libtool_libs=convenience
- fi
- func_warning "\`-version-info/-version-number' is ignored for convenience libraries"
- func_warning "\`-release' is ignored for convenience libraries"
- else
- # Parse the version information argument.
- save_ifs="$IFS"; IFS=':'
- set dummy $vinfo 0 0 0
- shift
- IFS="$save_ifs"
- test -n "$7" && \
- func_fatal_help "too many parameters to \`-version-info'"
- # convert absolute version numbers to libtool ages
- # this retains compatibility with .la files and attempts
- # to make the code below a bit more comprehensible
- case $vinfo_number in
- yes)
- number_major="$1"
- number_minor="$2"
- number_revision="$3"
- # There are really only two kinds -- those that
- # use the current revision as the major version
- # and those that subtract age and use age as
- # a minor version. But, then there is irix
- # which has an extra 1 added just for fun
- case $version_type in
- # correct linux to gnu/linux during the next big refactor
- darwin|linux|osf|windows|none)
- func_arith $number_major + $number_minor
- current=$func_arith_result
- age="$number_minor"
- revision="$number_revision"
- freebsd-aout|freebsd-elf|qnx|sunos)
- current="$number_major"
- revision="$number_minor"
- age="0"
- irix|nonstopux)
- lt_irix_increment=no
- func_fatal_configuration "$modename: unknown library version type \`$version_type'"
- esac
- no)
- current="$1"
- revision="$2"
- age="$3"
- esac
- # Check that each of the things are valid numbers.
- case $current in
- 0|[1-9]|[1-9][0-9]|[1-9][0-9][0-9]|[1-9][0-9][0-9][0-9]|[1-9][0-9][0-9][0-9][0-9]) ;;
- func_error "CURRENT \`$current' must be a nonnegative integer"
- func_fatal_error "\`$vinfo' is not valid version information"
- esac
- case $revision in
- func_error "REVISION \`$revision' must be a nonnegative integer"
- esac
- case $age in
- func_error "AGE \`$age' must be a nonnegative integer"
- esac
- if test "$age" -gt "$current"; then
- func_error "AGE \`$age' is greater than the current interface number \`$current'"
- fi
- # Calculate the version variables.
- major=
- versuffix=
- verstring=
- none) ;;
- darwin)
- # Like Linux, but with the current version available in
- # verstring for coding it into the library header
- major=.$func_arith_result
- versuffix="$major.$age.$revision"
- # Darwin ld doesn't like 0 for these options...
- func_arith $current + 1
- minor_current=$func_arith_result
- xlcverstring="${wl}-compatibility_version ${wl}$minor_current ${wl}-current_version ${wl}$minor_current.$revision"
- verstring="-compatibility_version $minor_current -current_version $minor_current.$revision"
- freebsd-aout)
- major=".$current"
- versuffix=".$current.$revision";
- freebsd-elf)
- major=".$current"
- versuffix=".$current"
- irix | nonstopux)
- if test "X$lt_irix_increment" = "Xno"; then
- else
- func_arith $current - $age + 1
- fi
- nonstopux) verstring_prefix=nonstopux ;;
- *) verstring_prefix=sgi ;;
- esac
- verstring="$verstring_prefix$major.$revision"
- # Add in all the interfaces that we are compatible with.
- loop=$revision
- while test "$loop" -ne 0; do
- func_arith $revision - $loop
- iface=$func_arith_result
- func_arith $loop - 1
- loop=$func_arith_result
- verstring="$verstring_prefix$major.$iface:$verstring"
- done
- # Before this point, $major must not contain `.'.
- major=.$major
- versuffix="$major.$revision"
- linux) # correct to gnu/linux during the next big refactor
- osf)
- versuffix=".$current.$age.$revision"
- verstring="$current.$age.$revision"
- loop=$age
- func_arith $current - $loop
- verstring="$verstring:${iface}.0"
- done
- # Make executables depend on our current version.
- verstring+=":${current}.0"
- qnx)
- major=".$current"
- sunos)
- major=".$current"
- windows)
- # Use '-' rather than '.', since we only want one
- # extension on DOS 8.3 filesystems.
- func_fatal_configuration "unknown library version type \`$version_type'"
- esac
- # Clear the version info if we defaulted, and they specified a release.
- if test -z "$vinfo" && test -n "$release"; then
- major=
- darwin)
- # we can't check for "0.0" in archive_cmds due to quoting
- # problems, so we reset it completely
- verstring=
- verstring="0.0"
- esac
- if test "$need_version" = no; then
- versuffix=
- else
- versuffix=".0.0"
- fi
- fi
- # Remove version info from name if versioning should be avoided
- if test "$avoid_version" = yes && test "$need_version" = no; then
- major=
- versuffix=
- verstring=""
- fi
- # Check to see if the archive will have undefined symbols.
- if test "$allow_undefined" = yes; then
- if test "$allow_undefined_flag" = unsupported; then
- func_warning "undefined symbols not allowed in $host shared libraries"
- fi
- else
- # Don't allow undefined symbols.
- allow_undefined_flag="$no_undefined_flag"
- fi
- fi
- func_generate_dlsyms "$libname" "$libname" "yes"
- libobjs+=" $symfileobj"
- test "X$libobjs" = "X " && libobjs=
- if test "$opt_mode" != relink; then
- # Remove our outputs, but don't remove object files since they
- # may have been created when compiling PIC objects.
- removelist=
- tempremovelist=`$ECHO "$output_objdir/*"`
- for p in $tempremovelist; do
- case $p in
- *.$objext | *.gcno)
- $output_objdir/$outputname | $output_objdir/$libname.* | $output_objdir/${libname}${release}.*)
- if test "X$precious_files_regex" != "X"; then
- if $ECHO "$p" | $EGREP -e "$precious_files_regex" >/dev/null 2>&1
- then
- continue
- fi
- fi
- removelist+=" $p"
- esac
- done
- test -n "$removelist" && \
- func_show_eval "${RM}r \$removelist"
- fi
- if test "$build_old_libs" = yes && test "$build_libtool_libs" != convenience ; then
- oldlibs+=" $output_objdir/$libname.$libext"
- # Transform .lo files to .o files.
- oldobjs="$objs "`$ECHO "$libobjs" | $SP2NL | $SED "/\.${libext}$/d; $lo2o" | $NL2SP`
- fi
- # Eliminate all temporary directories.
- #for path in $notinst_path; do
- # lib_search_path=`$ECHO "$lib_search_path " | $SED "s% $path % %g"`
- # deplibs=`$ECHO "$deplibs " | $SED "s% -L$path % %g"`
- # dependency_libs=`$ECHO "$dependency_libs " | $SED "s% -L$path % %g"`
- #done
- if test -n "$xrpath"; then
- # If the user specified any rpath flags, then add them.
- temp_xrpath=
- for libdir in $xrpath; do
- func_replace_sysroot "$libdir"
- temp_xrpath+=" -R$func_replace_sysroot_result"
- *" $libdir "*) ;;
- esac
- done
- if test "$hardcode_into_libs" != yes || test "$build_old_libs" = yes; then
- dependency_libs="$temp_xrpath $dependency_libs"
- fi
- fi
- # Make sure dlfiles contains only unique files that won't be dlpreopened
- old_dlfiles="$dlfiles"
- dlfiles=
- for lib in $old_dlfiles; do
- case " $dlprefiles $dlfiles " in
- *" $lib "*) ;;
- *) dlfiles+=" $lib" ;;
- esac
- done
- # Make sure dlprefiles contains only unique files
- old_dlprefiles="$dlprefiles"
- dlprefiles=
- for lib in $old_dlprefiles; do
- case "$dlprefiles " in
- *" $lib "*) ;;
- *) dlprefiles+=" $lib" ;;
- esac
- done
- if test -n "$rpath"; then
- case $host in
- *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2* | *-*-beos* | *-cegcc* | *-*-haiku*)
- # these systems don't actually have a c library (as such)!
- # Rhapsody C library is in the System framework
- *-*-netbsd*)
- # Don't link with libc until the a.out ld.so is fixed.
- # Add libc to deplibs on all other systems if necessary.
- if test "$build_libtool_need_lc" = "yes"; then
- deplibs+=" -lc"
- fi
- esac
- fi
- # Transform deplibs into only deplibs that can be linked in shared.
- name_save=$name
- libname_save=$libname
- release_save=$release
- versuffix_save=$versuffix
- major_save=$major
- # I'm not sure if I'm treating the release correctly. I think
- # release should show up in the -l (ie -lgmp5) so we don't want to
- # add it in twice. Is that correct?
- release=""
- versuffix=""
- major=""
- newdeplibs=
- droppeddeps=no
- pass_all)
- # Don't check for shared/static. Everything works.
- # This might be a little naive. We might want to check
- # whether the library exists or not. But this is on
- # osf3 & osf4 and I'm not really sure... Just
- # implementing what was already the behavior.
- newdeplibs=$deplibs
- test_compile)
- # This code stresses the "libraries are programs" paradigm to its
- # limits. Maybe even breaks it. We compile a program, linking it
- # against the deplibs as a proxy for the library. Then we can check
- # whether they linked in statically or dynamically with ldd.
- $opt_dry_run || $RM conftest.c
- cat > conftest.c <<EOF
- int main() { return 0; }
-EOF
- if $LTCC $LTCFLAGS -o conftest conftest.c $deplibs; then
- ldd_output=`ldd conftest`
- for i in $deplibs; do
- case $i in
- -l*)
- func_stripname -l '' "$i"
- *" $i "*)
- newdeplibs+=" $i"
- i=""
- esac
- fi
- deplib_matches=`eval "\\$ECHO \"$library_names_spec\""`
- set dummy $deplib_matches; shift
- deplib_match=$1
- if test `expr "$ldd_output" : ".*$deplib_match"` -ne 0 ; then
- newdeplibs+=" $i"
- else
- droppeddeps=yes
- echo
- $ECHO "*** Warning: dynamic linker does not accept needed library $i."
- echo "*** shared version of the library, which I believe you do not have"
- echo "*** because a test_compile did reveal that the linker did not use it for"
- echo "*** its dynamic dependency list that programs get resolved with at runtime."
- fi
- fi
- newdeplibs+=" $i"
- esac
- done
- else
- # Error occurred in the first compile. Let's try to salvage
- # the situation: Compile a separate program for each library.
- case $i in
- -l*)
- if $LTCC $LTCFLAGS -o conftest conftest.c $i; then
- *" $i "*)
- newdeplibs+=" $i"
- i=""
- esac
- fi
- deplib_match=$1
- newdeplibs+=" $i"
- else
- droppeddeps=yes
- echo
- echo "*** because a test_compile did reveal that the linker did not use this one"
- echo "*** as a dynamic dependency that programs can get resolved with at runtime."
- fi
- fi
- else
- droppeddeps=yes
- echo
- $ECHO "*** Warning! Library $i is needed by this library but I was not able to"
- echo "*** make it link in! You will probably need to install it or some"
- echo "*** library that it depends on before this library will be fully"
- echo "*** functional. Installing it before continuing would be even better."
- fi
- newdeplibs+=" $i"
- esac
- done
- fi
- file_magic*)
- file_magic_regex=`expr "$deplibs_check_method" : "$1 \(.*\)"`
- for a_deplib in $deplibs; do
- case $a_deplib in
- -l*)
- func_stripname -l '' "$a_deplib"
- *" $a_deplib "*)
- newdeplibs+=" $a_deplib"
- a_deplib=""
- esac
- fi
- if test -n "$a_deplib" ; then
- if test -n "$file_magic_glob"; then
- libnameglob=`func_echo_all "$libname" | $SED -e $file_magic_glob`
- else
- libnameglob=$libname
- fi
- test "$want_nocaseglob" = yes && nocaseglob=`shopt -p nocaseglob`
- for i in $lib_search_path $sys_lib_search_path $shlib_search_path; do
- if test "$want_nocaseglob" = yes; then
- shopt -s nocaseglob
- potential_libs=`ls $i/$libnameglob[.-]* 2>/dev/null`
- $nocaseglob
- else
- fi
- for potent_lib in $potential_libs; do
- # Follow soft links.
- if ls -lLd "$potent_lib" 2>/dev/null |
- $GREP " -> " >/dev/null; then
- continue
- fi
- # The statement above tries to avoid entering an
- # endless loop below, in case of cyclic links.
- # We might still enter an endless loop, since a link
- # loop can be closed while we follow links,
- # but so what?
- potlib="$potent_lib"
- while test -h "$potlib" 2>/dev/null; do
- potliblink=`ls -ld $potlib | ${SED} 's/.* -> //'`
- case $potliblink in
- [\\/]* | [A-Za-z]:[\\/]*) potlib="$potliblink";;
- *) potlib=`$ECHO "$potlib" | $SED 's,[^/]*$,,'`"$potliblink";;
- esac
- done
- if eval $file_magic_cmd \"\$potlib\" 2>/dev/null |
- $SED -e 10q |
- $EGREP "$file_magic_regex" > /dev/null; then
- a_deplib=""
- break 2
- fi
- done
- done
- fi
- droppeddeps=yes
- echo
- $ECHO "*** Warning: linker path does not have real file for library $a_deplib."
- echo "*** because I did check the linker path looking for a file starting"
- if test -z "$potlib" ; then
- $ECHO "*** with $libname but no candidates were found. (...for file magic test)"
- else
- $ECHO "*** with $libname and none of the candidates passed a file format test"
- $ECHO "*** using a file magic. Last file checked: $potlib"
- fi
- fi
- # Add a -L argument.
- esac
- done # Gone through all deplibs.
- match_pattern*)
- case $a_deplib in
- -l*)
- *" $a_deplib "*)
- a_deplib=""
- esac
- fi
- potential_libs=`ls $i/$libname[.-]* 2>/dev/null`
- potlib="$potent_lib" # see symlink-check above in file_magic test
- if eval "\$ECHO \"$potent_lib\"" 2>/dev/null | $SED 10q | \
- $EGREP "$match_pattern_regex" > /dev/null; then
- a_deplib=""
- break 2
- fi
- done
- done
- fi
- droppeddeps=yes
- echo
- $ECHO "*** with $libname but no candidates were found. (...for regex pattern test)"
- else
- $ECHO "*** using a regex pattern. Last file checked: $potlib"
- fi
- fi
- esac
- none | unknown | *)
- newdeplibs=""
- tmp_deplibs=`$ECHO " $deplibs" | $SED 's/ -lc$//; s/ -[LR][^ ]*//g'`
- for i in $predeps $postdeps ; do
- # can't use Xsed below, because $i might contain '/'
- tmp_deplibs=`$ECHO " $tmp_deplibs" | $SED "s,$i,,"`
- done
- fi
- case $tmp_deplibs in
- echo
- if test "X$deplibs_check_method" = "Xnone"; then
- echo "*** Warning: inter-library dependencies are not supported in this platform."
- else
- echo "*** Warning: inter-library dependencies are not known to be supported."
- fi
- echo "*** All declared inter-library dependencies are being dropped."
- droppeddeps=yes
- esac
- esac
- versuffix=$versuffix_save
- major=$major_save
- release=$release_save
- libname=$libname_save
- name=$name_save
- case $host in
- # On Rhapsody replace the C library with the System framework
- newdeplibs=`$ECHO " $newdeplibs" | $SED 's/ -lc / System.ltframework /'`
- esac
- if test "$droppeddeps" = yes; then
- echo
- echo "*** Warning: libtool could not satisfy all declared inter-library"
- $ECHO "*** dependencies of module $libname. Therefore, libtool will create"
- echo "*** a static module, that should work as long as the dlopening"
- echo "*** application is linked with the -dlopen flag."
- echo
- fi
- oldlibs="$output_objdir/$libname.$libext"
- else
- fi
- else
- echo "*** The inter-library dependencies that have been dropped here will be"
- echo "*** automatically added whenever a program is linked with this library"
- echo "*** or is declared to -dlopen it."
- if test "$allow_undefined" = no; then
- echo
- echo "*** Since this library must not contain undefined symbols,"
- echo "*** because either the platform does not support them or"
- echo "*** it was explicitly requested with -no-undefined,"
- echo "*** libtool will only create a static version of it."
- else
- fi
- fi
- fi
- fi
- # Done checking deplibs!
- deplibs=$newdeplibs
- fi
- # Time to change all our "foo.ltframework" stuff back to "-framework foo"
- case $host in
- *-*-darwin*)
- newdeplibs=`$ECHO " $newdeplibs" | $SED 's% \([^ $]*\).ltframework% -framework \1%g'`
- new_inherited_linker_flags=`$ECHO " $new_inherited_linker_flags" | $SED 's% \([^ $]*\).ltframework% -framework \1%g'`
- deplibs=`$ECHO " $deplibs" | $SED 's% \([^ $]*\).ltframework% -framework \1%g'`
- esac
- # move library search paths that coincide with paths to not yet
- # installed libraries to the beginning of the library search list
- new_libs=
- for path in $notinst_path; do
- *" -L$path/$objdir "*) ;;
- new_libs+=" -L$path/$objdir" ;;
- esac
- esac
- done
- case $deplib in
- -L*)
- *" $deplib "*) ;;
- *) new_libs+=" $deplib" ;;
- esac
- esac
- done
- deplibs="$new_libs"
- # All the library-specific variables (install_libdir is set above).
- library_names=
- old_library=
- dlname=
- # Test again, we may have decided not to build it any more
- # Remove ${wl} instances when linking with ld.
- # FIXME: should test the right _cmds variable.
- case $archive_cmds in
- *\$LD\ *) wl= ;;
- esac
- if test "$hardcode_into_libs" = yes; then
- # Hardcode the library paths
- hardcode_libdirs=
- dep_rpath=
- rpath="$finalize_rpath"
- test "$opt_mode" != relink && rpath="$compile_rpath$rpath"
- for libdir in $rpath; do
- if test -n "$hardcode_libdir_flag_spec"; then
- if test -n "$hardcode_libdir_separator"; then
- libdir=$func_replace_sysroot_result
- if test -z "$hardcode_libdirs"; then
- hardcode_libdirs="$libdir"
- else
- # Just accumulate the unique libdirs.
- case $hardcode_libdir_separator$hardcode_libdirs$hardcode_libdir_separator in
- *"$hardcode_libdir_separator$libdir$hardcode_libdir_separator"*)
- hardcode_libdirs+="$hardcode_libdir_separator$libdir"
- esac
- fi
- else
- eval flag=\"$hardcode_libdir_flag_spec\"
- dep_rpath+=" $flag"
- fi
- elif test -n "$runpath_var"; then
- case "$perm_rpath " in
- *" $libdir "*) ;;
- *) perm_rpath+=" $libdir" ;;
- esac
- fi
- done
- # Substitute the hardcoded libdirs into the rpath.
- if test -n "$hardcode_libdir_separator" &&
- test -n "$hardcode_libdirs"; then
- libdir="$hardcode_libdirs"
- eval "dep_rpath=\"$hardcode_libdir_flag_spec\""
- fi
- if test -n "$runpath_var" && test -n "$perm_rpath"; then
- # We should set the runpath_var.
- rpath=
- for dir in $perm_rpath; do
- rpath+="$dir:"
- done
- eval "$runpath_var='$rpath\$$runpath_var'; export $runpath_var"
- fi
- test -n "$dep_rpath" && deplibs="$dep_rpath $deplibs"
- fi
- shlibpath="$finalize_shlibpath"
- test "$opt_mode" != relink && shlibpath="$compile_shlibpath$shlibpath"
- if test -n "$shlibpath"; then
- eval "$shlibpath_var='$shlibpath\$$shlibpath_var'; export $shlibpath_var"
- fi
- # Get the real and link names of the library.
- eval library_names=\"$library_names_spec\"
- shift
- realname="$1"
- shift
- if test -n "$soname_spec"; then
- else
- fi
- if test -z "$dlname"; then
- dlname=$soname
- fi
- lib="$output_objdir/$realname"
- linknames=
- for link
- do
- linknames+=" $link"
- done
- # Use standard objects if they are pic
- test -z "$pic_flag" && libobjs=`$ECHO "$libobjs" | $SP2NL | $SED "$lo2o" | $NL2SP`
- delfiles=
- if test -n "$export_symbols" && test -n "$include_expsyms"; then
- $opt_dry_run || cp "$export_symbols" "$output_objdir/$libname.uexp"
- export_symbols="$output_objdir/$libname.uexp"
- delfiles+=" $export_symbols"
- fi
- orig_export_symbols=
- case $host_os in
- cygwin* | mingw* | cegcc*)
- if test -n "$export_symbols" && test -z "$export_symbols_regex"; then
- # exporting using user supplied symfile
- if test "x`$SED 1q $export_symbols`" != xEXPORTS; then
- # and it's NOT already a .def file. Must figure out
- # which of the given symbols are data symbols and tag
- # them as such. So, trigger use of export_symbols_cmds.
- # export_symbols gets reassigned inside the "prepare
- # the list of exported symbols" if statement, so the
- # include_expsyms logic still works.
- orig_export_symbols="$export_symbols"
- export_symbols=
- always_export_symbols=yes
- fi
- fi
- esac
- # Prepare the list of exported symbols
- if test -z "$export_symbols"; then
- if test "$always_export_symbols" = yes || test -n "$export_symbols_regex"; then
- func_verbose "generating symbol list for \`$libname.la'"
- export_symbols="$output_objdir/$libname.exp"
- $opt_dry_run || $RM $export_symbols
- cmds=$export_symbols_cmds
- save_ifs="$IFS"; IFS='~'
- for cmd1 in $cmds; do
- IFS="$save_ifs"
- # Take the normal branch if the nm_file_list_spec branch
- # doesn't work or if tool conversion is not needed.
- case $nm_file_list_spec~$to_tool_file_cmd in
- *~func_convert_file_noop | *~func_convert_file_msys_to_w32 | ~*)
- try_normal_branch=yes
- eval cmd=\"$cmd1\"
- func_len " $cmd"
- len=$func_len_result
- try_normal_branch=no
- esac
- if test "$try_normal_branch" = yes \
- && { test "$len" -lt "$max_cmd_len" \
- || test "$max_cmd_len" -le -1; }
- then
- func_show_eval "$cmd" 'exit $?'
- skipped_export=false
- elif test -n "$nm_file_list_spec"; then
- output_la=$func_basename_result
- save_libobjs=$libobjs
- save_output=$output
- output=${output_objdir}/${output_la}.nm
- func_to_tool_file "$output"
- libobjs=$nm_file_list_spec$func_to_tool_file_result
- delfiles+=" $output"
- func_verbose "creating $NM input file list: $output"
- for obj in $save_libobjs; do
- func_to_tool_file "$obj"
- $ECHO "$func_to_tool_file_result"
- done > "$output"
- output=$save_output
- libobjs=$save_libobjs
- else
- # The command line is too long to execute in one step.
- func_verbose "using reloadable object file for export list..."
- skipped_export=:
- # Break out early, otherwise skipped_export may be
- # set to false by a later but shorter cmd.
- break
- fi
- done
- IFS="$save_ifs"
- if test -n "$export_symbols_regex" && test "X$skipped_export" != "X:"; then
- func_show_eval '$EGREP -e "$export_symbols_regex" "$export_symbols" > "${export_symbols}T"'
- func_show_eval '$MV "${export_symbols}T" "$export_symbols"'
- fi
- fi
- fi
- tmp_export_symbols="$export_symbols"
- test -n "$orig_export_symbols" && tmp_export_symbols="$orig_export_symbols"
- $opt_dry_run || eval '$ECHO "$include_expsyms" | $SP2NL >> "$tmp_export_symbols"'
- fi
- if test "X$skipped_export" != "X:" && test -n "$orig_export_symbols"; then
- # The given exports_symbols file has to be filtered, so filter it.
- func_verbose "filter symbol list for \`$libname.la' to tag DATA exports"
- # FIXME: $output_objdir/$libname.filter potentially contains lots of
- # 's' commands which not all seds can handle. GNU sed should be fine
- # though. Also, the filter scales superlinearly with the number of
- # global variables. join(1) would be nice here, but unfortunately
- # isn't a blessed tool.
- $opt_dry_run || $SED -e '/[ ,]DATA/!d;s,\(.*\)\([ \,].*\),s|^\1$|\1\2|,' < $export_symbols > $output_objdir/$libname.filter
- delfiles+=" $export_symbols $output_objdir/$libname.filter"
- export_symbols=$output_objdir/$libname.def
- $opt_dry_run || $SED -f $output_objdir/$libname.filter < $orig_export_symbols > $export_symbols
- fi
- tmp_deplibs=
- for test_deplib in $deplibs; do
- case " $convenience " in
- *" $test_deplib "*) ;;
- tmp_deplibs+=" $test_deplib"
- esac
- done
- if test -n "$convenience"; then
- if test -n "$whole_archive_flag_spec" &&
- test "$compiler_needs_object" = yes &&
- test -z "$libobjs"; then
- # extract the archives, so we have objects to list.
- # TODO: could optimize this to just extract one archive.
- whole_archive_flag_spec=
- fi
- if test -n "$whole_archive_flag_spec"; then
- eval libobjs=\"\$libobjs $whole_archive_flag_spec\"
- else
- gentop="$output_objdir/${outputname}x"
- generated+=" $gentop"
- func_extract_archives $gentop $convenience
- libobjs+=" $func_extract_archives_result"
- fi
- fi
- if test "$thread_safe" = yes && test -n "$thread_safe_flag_spec"; then
- eval flag=\"$thread_safe_flag_spec\"
- linker_flags+=" $flag"
- fi
- # Make a backup of the uninstalled library when relinking
- if test "$opt_mode" = relink; then
- $opt_dry_run || eval '(cd $output_objdir && $RM ${realname}U && $MV $realname ${realname}U)' || exit $?
- fi
- # Do each of the archive commands.
- if test "$module" = yes && test -n "$module_cmds" ; then
- if test -n "$export_symbols" && test -n "$module_expsym_cmds"; then
- eval test_cmds=\"$module_expsym_cmds\"
- cmds=$module_expsym_cmds
- else
- eval test_cmds=\"$module_cmds\"
- cmds=$module_cmds
- fi
- else
- if test -n "$export_symbols" && test -n "$archive_expsym_cmds"; then
- eval test_cmds=\"$archive_expsym_cmds\"
- cmds=$archive_expsym_cmds
- else
- eval test_cmds=\"$archive_cmds\"
- cmds=$archive_cmds
- fi
- fi
- func_len " $test_cmds" &&
- len=$func_len_result &&
- test "$len" -lt "$max_cmd_len" || test "$max_cmd_len" -le -1; then
- else
- # The command line is too long to link in one step, link piecewise
- # or, if using GNU ld and skipped_export is not :, use a linker
- # script.
- # Save the value of $output and $libobjs because we want to
- # use them later. If we have whole_archive_flag_spec, we
- # want to use save_libobjs as it was before
- # whole_archive_flag_spec was expanded, because we can't
- # assume the linker understands whole_archive_flag_spec.
- # This may have to be revisited, in case too many
- # convenience libraries get linked in and end up exceeding
- # the spec.
- if test -z "$convenience" || test -z "$whole_archive_flag_spec"; then
- fi
- # Clear the reloadable object creation command queue and
- # initialize k to one.
- test_cmds=
- concat_cmds=
- objlist=
- last_robj=
- k=1
- if test -n "$save_libobjs" && test "X$skipped_export" != "X:" && test "$with_gnu_ld" = yes; then
- output=${output_objdir}/${output_la}.lnkscript
- func_verbose "creating GNU ld script: $output"
- echo 'INPUT (' > $output
- do
- $ECHO "$func_to_tool_file_result" >> $output
- done
- echo ')' >> $output
- output=$func_to_tool_file_result
- elif test -n "$save_libobjs" && test "X$skipped_export" != "X:" && test "X$file_list_spec" != X; then
- func_verbose "creating linker input file list: $output"
- : > $output
- set x $save_libobjs
- shift
- firstobj=
- if test "$compiler_needs_object" = yes; then
- firstobj="$1 "
- shift
- fi
- for obj
- do
- done
- output=$firstobj\"$file_list_spec$func_to_tool_file_result\"
- else
- if test -n "$save_libobjs"; then
- func_verbose "creating reloadable object files..."
- output=$output_objdir/$output_la-${k}.$objext
- eval test_cmds=\"$reload_cmds\"
- len0=$func_len_result
- len=$len0
- # Loop over the list of objects to be linked.
- do
- func_len " $obj"
- func_arith $len + $func_len_result
- len=$func_arith_result
- if test "X$objlist" = X ||
- test "$len" -lt "$max_cmd_len"; then
- objlist+=" $obj"
- else
- # The command $test_cmds is almost too long, add a
- # command to the queue.
- if test "$k" -eq 1 ; then
- # The first file doesn't have a previous command to add.
- reload_objs=$objlist
- eval concat_cmds=\"$reload_cmds\"
- else
- # All subsequent reloadable object files will link in
- # the last one created.
- reload_objs="$objlist $last_robj"
- eval concat_cmds=\"\$concat_cmds~$reload_cmds~\$RM $last_robj\"
- fi
- last_robj=$output_objdir/$output_la-${k}.$objext
- func_arith $k + 1
- k=$func_arith_result
- objlist=" $obj"
- func_len " $last_robj"
- func_arith $len0 + $func_len_result
- fi
- done
- # Handle the remaining objects by creating one last
- # reloadable object file. All subsequent reloadable object
- # files will link in the last one created.
- test -z "$concat_cmds" || concat_cmds=$concat_cmds~
- eval concat_cmds=\"\${concat_cmds}$reload_cmds\"
- if test -n "$last_robj"; then
- eval concat_cmds=\"\${concat_cmds}~\$RM $last_robj\"
- fi
- else
- output=
- fi
- if ${skipped_export-false}; then
- libobjs=$output
- # Append the command to create the export file.
- eval concat_cmds=\"\$concat_cmds$export_symbols_cmds\"
- eval concat_cmds=\"\$concat_cmds~\$RM $last_robj\"
- fi
- fi
- test -n "$save_libobjs" &&
- func_verbose "creating a temporary reloadable object file: $output"
- # Loop through the commands generated above and execute them.
- for cmd in $concat_cmds; do
- IFS="$save_ifs"
- $opt_silent || {
- func_quote_for_expand "$cmd"
- eval "func_echo $func_quote_for_expand_result"
- $opt_dry_run || eval "$cmd" || {
- lt_exit=$?
- # Restore the uninstalled library and exit
- ( cd "$output_objdir" && \
- $RM "${realname}T" && \
- $MV "${realname}U" "$realname" )
- fi
- exit $lt_exit
- done
- IFS="$save_ifs"
- if test -n "$export_symbols_regex" && ${skipped_export-false}; then
- fi
- fi
- fi
- if test -n "$orig_export_symbols"; then
- fi
- fi
- libobjs=$output
- # Restore the value of output.
- if test -n "$convenience" && test -n "$whole_archive_flag_spec"; then
- fi
- # Expand the library linking commands again to reset the
- # value of $libobjs for piecewise linking.
- else
- cmds=$module_cmds
- fi
- else
- else
- fi
- fi
- fi
- if test -n "$delfiles"; then
- # Append the command to remove temporary files to $cmds.
- eval cmds=\"\$cmds~\$RM $delfiles\"
- fi
- # Add any objects from preloaded convenience libraries
- if test -n "$dlprefiles"; then
- func_extract_archives $gentop $dlprefiles
- fi
- for cmd in $cmds; do
- IFS="$save_ifs"
- eval cmd=\"$cmd\"
- $opt_silent || {
- lt_exit=$?
- fi
- exit $lt_exit
- done
- IFS="$save_ifs"
- $opt_dry_run || eval '(cd $output_objdir && $RM ${realname}T && $MV $realname ${realname}T && $MV ${realname}U $realname)' || exit $?
- if test -z "$whole_archive_flag_spec"; then
- func_show_eval '${RM}r "$gentop"'
- fi
- fi
- exit $EXIT_SUCCESS
- fi
- # Create links to the real library.
- for linkname in $linknames; do
- if test "$realname" != "$linkname"; then
- func_show_eval '(cd "$output_objdir" && $RM "$linkname" && $LN_S "$realname" "$linkname")' 'exit $?'
- fi
- done
- # If -module or -export-dynamic was specified, set the dlname.
- if test "$module" = yes || test "$export_dynamic" = yes; then
- # On all known operating systems, these are identical.
- dlname="$soname"
- fi
- fi
- obj)
- func_warning "\`-dlopen' is ignored for objects"
- fi
- *\ -l* | *\ -L*)
- func_warning "\`-l' and \`-L' are ignored for objects" ;;
- esac
- func_warning "\`-rpath' is ignored for objects"
- func_warning "\`-R' is ignored for objects"
- func_warning "\`-version-info' is ignored for objects"
- func_warning "\`-release' is ignored for objects"
- case $output in
- *.lo)
- test -n "$objs$old_deplibs" && \
- func_fatal_error "cannot build library object \`$output' from non-libtool objects"
- libobj=$output
- func_lo2o "$libobj"
- obj=$func_lo2o_result
- libobj=
- obj="$output"
- esac
- # Delete the old objects.
- $opt_dry_run || $RM $obj $libobj
- # Objects from convenience libraries. This assumes
- # single-version convenience libraries. Whenever we create
- # different ones for PIC/non-PIC, this we'll have to duplicate
- # the extraction.
- reload_conv_objs=
- gentop=
- # reload_cmds runs $LD directly, so let us get rid of
- # -Wl from whole_archive_flag_spec and hope we can get by with
- # turning comma into space..
- wl=
- eval tmp_whole_archive_flags=\"$whole_archive_flag_spec\"
- reload_conv_objs=$reload_objs\ `$ECHO "$tmp_whole_archive_flags" | $SED 's|,| |g'`
- else
- gentop="$output_objdir/${obj}x"
- reload_conv_objs="$reload_objs $func_extract_archives_result"
- fi
- fi
- # If we're not building shared, we need to use non_pic_objs
- test "$build_libtool_libs" != yes && libobjs="$non_pic_objects"
- # Create the old-style object.
- reload_objs="$objs$old_deplibs "`$ECHO "$libobjs" | $SP2NL | $SED "/\.${libext}$/d; /\.lib$/d; $lo2o" | $NL2SP`" $reload_conv_objs" ### testsuite: skip nested quoting test
- output="$obj"
- func_execute_cmds "$reload_cmds" 'exit $?'
- # Exit if we aren't doing a library object file.
- if test -z "$libobj"; then
- if test -n "$gentop"; then
- fi
- fi
- if test "$build_libtool_libs" != yes; then
- fi
- # Create an invalid libtool object if no PIC, so that we don't
- # accidentally link it into a program.
- # $show "echo timestamp > $libobj"
- # $opt_dry_run || eval "echo timestamp > $libobj" || exit $?
- fi
- if test -n "$pic_flag" || test "$pic_mode" != default; then
- # Only do commands if we really have different PIC objects.
- reload_objs="$libobjs $reload_conv_objs"
- output="$libobj"
- fi
- fi
- prog)
- case $host in
- *cygwin*) func_stripname '' '.exe' "$output"
- output=$func_stripname_result.exe;;
- esac
- func_warning "\`-version-info' is ignored for programs"
- func_warning "\`-release' is ignored for programs"
- test "$preload" = yes \
- && test "$dlopen_support" = unknown \
- && test "$dlopen_self" = unknown \
- && test "$dlopen_self_static" = unknown && \
- func_warning "\`LT_INIT([dlopen])' not used. Assuming no dlopen support."
- case $host in
- *-*-rhapsody* | *-*-darwin1.[012])
- # On Rhapsody replace the C library is the System framework
- compile_deplibs=`$ECHO " $compile_deplibs" | $SED 's/ -lc / System.ltframework /'`
- finalize_deplibs=`$ECHO " $finalize_deplibs" | $SED 's/ -lc / System.ltframework /'`
- esac
- case $host in
- *-*-darwin*)
- # Don't allow lazy linking, it breaks C++ global constructors
- # But is supposedly fixed on 10.4 or later (yay!).
- if test "$tagname" = CXX ; then
- case ${MACOSX_DEPLOYMENT_TARGET-10.0} in
- 10.[0123])
- compile_command+=" ${wl}-bind_at_load"
- finalize_command+=" ${wl}-bind_at_load"
- esac
- fi
- compile_deplibs=`$ECHO " $compile_deplibs" | $SED 's% \([^ $]*\).ltframework% -framework \1%g'`
- finalize_deplibs=`$ECHO " $finalize_deplibs" | $SED 's% \([^ $]*\).ltframework% -framework \1%g'`
- esac
- new_libs=
- case " $compile_deplibs " in
- esac
- esac
- done
- for deplib in $compile_deplibs; do
- case $deplib in
- -L*)
- *" $deplib "*) ;;
- esac
- esac
- done
- compile_deplibs="$new_libs"
- compile_command+=" $compile_deplibs"
- finalize_command+=" $finalize_deplibs"
- if test -n "$rpath$xrpath"; then
- for libdir in $rpath $xrpath; do
- # This is the magic to use -rpath.
- *" $libdir "*) ;;
- esac
- done
- fi
- # Now hardcode the library paths
- rpath=
- hardcode_libdirs=
- for libdir in $compile_rpath $finalize_rpath; do
- else
- esac
- fi
- else
- rpath+=" $flag"
- fi
- *" $libdir "*) ;;
- esac
- fi
- case $host in
- *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2* | *-cegcc*)
- testbindir=`${ECHO} "$libdir" | ${SED} -e 's*/lib$*/bin*'`
- case :$dllsearchpath: in
- *":$libdir:"*) ;;
- ::) dllsearchpath=$libdir;;
- *) dllsearchpath+=":$libdir";;
- esac
- *":$testbindir:"*) ;;
- ::) dllsearchpath=$testbindir;;
- *) dllsearchpath+=":$testbindir";;
- esac
- esac
- done
- eval rpath=\" $hardcode_libdir_flag_spec\"
- fi
- compile_rpath="$rpath"
- rpath=
- hardcode_libdirs=
- for libdir in $finalize_rpath; do
- else
- esac
- fi
- else
- rpath+=" $flag"
- fi
- case "$finalize_perm_rpath " in
- *" $libdir "*) ;;
- *) finalize_perm_rpath+=" $libdir" ;;
- esac
- fi
- done
- fi
- finalize_rpath="$rpath"
- if test -n "$libobjs" && test "$build_old_libs" = yes; then
- # Transform all the library objects into standard objects.
- compile_command=`$ECHO "$compile_command" | $SP2NL | $SED "$lo2o" | $NL2SP`
- finalize_command=`$ECHO "$finalize_command" | $SP2NL | $SED "$lo2o" | $NL2SP`
- fi
- func_generate_dlsyms "$outputname" "@PROGRAM@" "no"
- # template prelinking step
- if test -n "$prelink_cmds"; then
- func_execute_cmds "$prelink_cmds" 'exit $?'
- fi
- wrappers_required=yes
- case $host in
- *cegcc* | *mingw32ce*)
- # Disable wrappers for cegcc and mingw32ce hosts, we are cross compiling anyway.
- wrappers_required=no
- *cygwin* | *mingw* )
- fi
- if test "$need_relink" = no || test "$build_libtool_libs" != yes; then
- fi
- esac
- if test "$wrappers_required" = no; then
- # Replace the output file specification.
- compile_command=`$ECHO "$compile_command" | $SED 's%@OUTPUT@%'"$output"'%g'`
- link_command="$compile_command$compile_rpath"
- # We have no uninstalled library dependencies, so finalize right now.
- exit_status=0
- func_show_eval "$link_command" 'exit_status=$?'
- if test -n "$postlink_cmds"; then
- postlink_cmds=`func_echo_all "$postlink_cmds" | $SED -e 's%@OUTPUT@%'"$output"'%g' -e 's%@TOOL_OUTPUT@%'"$func_to_tool_file_result"'%g'`
- func_execute_cmds "$postlink_cmds" 'exit $?'
- fi
- # Delete the generated files.
- if test -f "$output_objdir/${outputname}S.${objext}"; then
- func_show_eval '$RM "$output_objdir/${outputname}S.${objext}"'
- fi
- exit $exit_status
- fi
- if test -n "$compile_shlibpath$finalize_shlibpath"; then
- compile_command="$shlibpath_var=\"$compile_shlibpath$finalize_shlibpath\$$shlibpath_var\" $compile_command"
- fi
- if test -n "$finalize_shlibpath"; then
- finalize_command="$shlibpath_var=\"$finalize_shlibpath\$$shlibpath_var\" $finalize_command"
- fi
- compile_var=
- finalize_var=
- if test -n "$runpath_var"; then
- if test -n "$perm_rpath"; then
- rpath=
- rpath+="$dir:"
- done
- compile_var="$runpath_var=\"$rpath\$$runpath_var\" "
- fi
- if test -n "$finalize_perm_rpath"; then
- rpath=
- for dir in $finalize_perm_rpath; do
- rpath+="$dir:"
- done
- finalize_var="$runpath_var=\"$rpath\$$runpath_var\" "
- fi
- fi
- if test "$no_install" = yes; then
- # We don't need to create a wrapper script.
- link_command="$compile_var$compile_command$compile_rpath"
- link_command=`$ECHO "$link_command" | $SED 's%@OUTPUT@%'"$output"'%g'`
- # Delete the old output file.
- $opt_dry_run || $RM $output
- # Link the executable and exit
- func_show_eval "$link_command" 'exit $?'
- fi
- fi
- if test "$hardcode_action" = relink; then
- # Fast installation is not supported
- relink_command="$finalize_var$finalize_command$finalize_rpath"
- func_warning "this platform does not like uninstalled shared libraries"
- func_warning "\`$output' will be relinked during installation"
- else
- if test "$fast_install" != no; then
- link_command="$finalize_var$compile_command$finalize_rpath"
- if test "$fast_install" = yes; then
- relink_command=`$ECHO "$compile_var$compile_command$compile_rpath" | $SED 's%@OUTPUT@%\$progdir/\$file%g'`
- else
- # fast_install is set to needless
- relink_command=
- fi
- else
- fi
- fi
- link_command=`$ECHO "$link_command" | $SED 's%@OUTPUT@%'"$output_objdir/$outputname"'%g'`
- # Delete the old output files.
- $opt_dry_run || $RM $output $output_objdir/$outputname $output_objdir/lt-$outputname
- func_to_tool_file "$output_objdir/$outputname"
- postlink_cmds=`func_echo_all "$postlink_cmds" | $SED -e 's%@OUTPUT@%'"$output_objdir/$outputname"'%g' -e 's%@TOOL_OUTPUT@%'"$func_to_tool_file_result"'%g'`
- fi
- # Now create the wrapper script.
- func_verbose "creating $output"
- # Quote the relink command for shipping.
- if test -n "$relink_command"; then
- # Preserve any variables that may affect compiler behavior
- for var in $variables_saved_for_relink; do
- if eval test -z \"\${$var+set}\"; then
- relink_command="{ test -z \"\${$var+set}\" || $lt_unset $var || { $var=; export $var; }; }; $relink_command"
- elif eval var_value=\$$var; test -z "$var_value"; then
- relink_command="$var=; export $var; $relink_command"
- else
- func_quote_for_eval "$var_value"
- relink_command="$var=$func_quote_for_eval_result; export $var; $relink_command"
- fi
- done
- relink_command="(cd `pwd`; $relink_command)"
- relink_command=`$ECHO "$relink_command" | $SED "$sed_quote_subst"`
- fi
- # Only actually do things if not in dry run mode.
- $opt_dry_run || {
- # win32 will think the script is a binary if it has
- # a .exe suffix, so we strip it off here.
- case $output in
- *.exe) func_stripname '' '.exe' "$output"
- output=$func_stripname_result ;;
- esac
- # test for cygwin because mv fails w/o .exe extensions
- case $host in
- *cygwin*)
- exeext=.exe
- func_stripname '' '.exe' "$outputname"
- outputname=$func_stripname_result ;;
- *) exeext= ;;
- esac
- case $host in
- func_dirname_and_basename "$output" "" "."
- output_name=$func_basename_result
- output_path=$func_dirname_result
- cwrappersource="$output_path/$objdir/lt-$output_name.c"
- cwrapper="$output_path/$output_name.exe"
- $RM $cwrappersource $cwrapper
- trap "$RM $cwrappersource $cwrapper; exit $EXIT_FAILURE" 1 2 15
- func_emit_cwrapperexe_src > $cwrappersource
- # The wrapper executable is built using the $host compiler,
- # because it contains $host paths and files. If cross-
- # compiling, it, like the target executable, must be
- # executed on the $host or under an emulation environment.
- $opt_dry_run || {
- $LTCC $LTCFLAGS -o $cwrapper $cwrappersource
- $STRIP $cwrapper
- # Now, create the wrapper script for func_source use:
- func_ltwrapper_scriptname $cwrapper
- $RM $func_ltwrapper_scriptname_result
- trap "$RM $func_ltwrapper_scriptname_result; exit $EXIT_FAILURE" 1 2 15
- $opt_dry_run || {
- # note: this script will not be executed, so do not chmod.
- if test "x$build" = "x$host" ; then
- $cwrapper --lt-dump-script > $func_ltwrapper_scriptname_result
- else
- func_emit_wrapper no > $func_ltwrapper_scriptname_result
- fi
- $RM $output
- trap "$RM $output; exit $EXIT_FAILURE" 1 2 15
- func_emit_wrapper no > $output
- chmod +x $output
- esac
- esac
- # See if we need to build an old-fashioned archive.
- for oldlib in $oldlibs; do
- if test "$build_libtool_libs" = convenience; then
- oldobjs="$libobjs_save $symfileobj"
- addlibs="$convenience"
- build_libtool_libs=no
- else
- if test "$build_libtool_libs" = module; then
- oldobjs="$libobjs_save"
- else
- oldobjs="$old_deplibs $non_pic_objects"
- if test "$preload" = yes && test -f "$symfileobj"; then
- oldobjs+=" $symfileobj"
- fi
- fi
- addlibs="$old_convenience"
- fi
- if test -n "$addlibs"; then
- func_extract_archives $gentop $addlibs
- oldobjs+=" $func_extract_archives_result"
- fi
- # Do each command in the archive commands.
- if test -n "$old_archive_from_new_cmds" && test "$build_libtool_libs" = yes; then
- cmds=$old_archive_from_new_cmds
- else
- fi
- # POSIX demands no paths to be encoded in archives. We have
- # to avoid creating archives with duplicate basenames if we
- # might have to extract them afterwards, e.g., when creating a
- # static archive out of a convenience library, or when linking
- # the entirety of a libtool archive into another (currently
- # not supported by libtool).
- if (for obj in $oldobjs
- do
- func_basename "$obj"
- $ECHO "$func_basename_result"
- done | sort | sort -uc >/dev/null 2>&1); then
- else
- echo "copying selected object files to avoid basename conflicts..."
- func_mkdir_p "$gentop"
- save_oldobjs=$oldobjs
- oldobjs=
- counter=1
- for obj in $save_oldobjs
- do
- objbase="$func_basename_result"
- case " $oldobjs " in
- " ") oldobjs=$obj ;;
- *[\ /]"$objbase "*)
- while :; do
- # Make sure we don't pick an alternate name that also
- # overlaps.
- newobj=lt$counter-$objbase
- func_arith $counter + 1
- counter=$func_arith_result
- *[\ /]"$newobj "*) ;;
- *) if test ! -f "$gentop/$newobj"; then break; fi ;;
- esac
- done
- func_show_eval "ln $obj $gentop/$newobj || cp $obj $gentop/$newobj"
- oldobjs+=" $gentop/$newobj"
- *) oldobjs+=" $obj" ;;
- esac
- done
- fi
- func_to_tool_file "$oldlib" func_convert_file_msys_to_w32
- tool_oldlib=$func_to_tool_file_result
- eval cmds=\"$old_archive_cmds\"
- func_len " $cmds"
- if test "$len" -lt "$max_cmd_len" || test "$max_cmd_len" -le -1; then
- cmds=$old_archive_cmds
- elif test -n "$archiver_list_spec"; then
- func_verbose "using command file archive linking..."
- for obj in $oldobjs
- do
- done > $output_objdir/$libname.libcmd
- func_to_tool_file "$output_objdir/$libname.libcmd"
- oldobjs=" $archiver_list_spec$func_to_tool_file_result"
- else
- # the command line is too long to link in one step, link in parts
- func_verbose "using piecewise archive linking..."
- save_RANLIB=$RANLIB
- RANLIB=:
- objlist=
- concat_cmds=
- oldobjs=
- # Is there a better way of finding the last object in the list?
- do
- last_oldobj=$obj
- done
- eval test_cmds=\"$old_archive_cmds\"
- len=$len0
- do
- func_len " $obj"
- objlist+=" $obj"
- if test "$len" -lt "$max_cmd_len"; then
- else
- # the above command should be used before it gets too long
- oldobjs=$objlist
- if test "$obj" = "$last_oldobj" ; then
- RANLIB=$save_RANLIB
- fi
- eval concat_cmds=\"\${concat_cmds}$old_archive_cmds\"
- objlist=
- len=$len0
- fi
- done
- oldobjs=$objlist
- if test "X$oldobjs" = "X" ; then
- eval cmds=\"\$concat_cmds\"
- else
- eval cmds=\"\$concat_cmds~\$old_archive_cmds\"
- fi
- fi
- fi
- func_execute_cmds "$cmds" 'exit $?'
- done
- test -n "$generated" && \
- func_show_eval "${RM}r$generated"
- # Now create the libtool archive.
- case $output in
- *.la)
- old_library=
- test "$build_old_libs" = yes && old_library="$libname.$libext"
- else
- fi
- done
- # Quote the link command for shipping.
- relink_command="(cd `pwd`; $SHELL $progpath $preserve_args --mode=relink $libtool_args @inst_prefix_dir@)"
- if test "$hardcode_automatic" = yes ; then
- relink_command=
- fi
- # Only create the output if not a dry run.
- $opt_dry_run || {
- for installed in no yes; do
- if test "$installed" = yes; then
- if test -z "$install_libdir"; then
- break
- fi
- output="$output_objdir/$outputname"i
- # Replace all uninstalled libtool libraries with the installed ones
- newdependency_libs=
- for deplib in $dependency_libs; do
- case $deplib in
- *.la)
- func_basename "$deplib"
- name="$func_basename_result"
- func_resolve_sysroot "$deplib"
- eval libdir=`${SED} -n -e 's/^libdir=\(.*\)$/\1/p' $func_resolve_sysroot_result`
- test -z "$libdir" && \
- newdependency_libs+=" ${lt_sysroot:+=}$libdir/$name"
- -L*)
- func_stripname -L '' "$deplib"
- func_replace_sysroot "$func_stripname_result"
- newdependency_libs+=" -L$func_replace_sysroot_result"
- -R*)
- func_stripname -R '' "$deplib"
- newdependency_libs+=" -R$func_replace_sysroot_result"
- *) newdependency_libs+=" $deplib" ;;
- esac
- done
- newdlfiles=
- for lib in $dlfiles; do
- case $lib in
- *.la)
- func_basename "$lib"
- eval libdir=`${SED} -n -e 's/^libdir=\(.*\)$/\1/p' $lib`
- func_fatal_error "\`$lib' is not a valid libtool archive"
- newdlfiles+=" ${lt_sysroot:+=}$libdir/$name"
- *) newdlfiles+=" $lib" ;;
- esac
- done
- newdlprefiles=
- for lib in $dlprefiles; do
- case $lib in
- *.la)
- # Only pass preopened files to the pseudo-archive (for
- # eventual linking with the app. that links it) if we
- # didn't already link the preopened objects directly into
- # the library:
- newdlprefiles+=" ${lt_sysroot:+=}$libdir/$name"
- esac
- done
- else
- newdlfiles=
- case $lib in
- [\\/]* | [A-Za-z]:[\\/]*) abs="$lib" ;;
- *) abs=`pwd`"/$lib" ;;
- esac
- newdlfiles+=" $abs"
- done
- newdlprefiles=
- case $lib in
- esac
- newdlprefiles+=" $abs"
- done
- fi
- $RM $output
- # place dlname in correct position for cygwin
- # In fact, it would be nice if we could use this code for all target
- # systems that can't hard-code library paths into their executables
- # and that have no shared library path variable independent of PATH,
- # but it turns out we can't easily determine that from inspecting
- # libtool variables, so we have to hard-code the OSs to which it
- # applies here; at the moment, that means platforms that use the PE
- # object format with DLL files. See the long comment at the top of
- # tests/bindir.at for full details.
- tdlname=$dlname
- case $host,$output,$installed,$module,$dlname in
- *cygwin*,*lai,yes,no,*.dll | *mingw*,*lai,yes,no,*.dll | *cegcc*,*lai,yes,no,*.dll)
- # If a -bindir argument was supplied, place the dll there.
- if test "x$bindir" != x ;
- then
- func_relative_path "$install_libdir" "$bindir"
- tdlname=$func_relative_path_result$dlname
- else
- # Otherwise fall back on heuristic.
- tdlname=../bin/$dlname
- fi
- esac
- $ECHO > $output "\
-# $outputname - a libtool library file
-# Generated by $PROGRAM (GNU $PACKAGE$TIMESTAMP) $VERSION
-# Please DO NOT delete this file!
-# It is necessary for linking the library.
-# The name that we can dlopen(3).
-dlname='$tdlname'
-# Names of this library.
-library_names='$library_names'
-# The name of the static archive.
-old_library='$old_library'
-# Linker flags that can not go in dependency_libs.
-inherited_linker_flags='$new_inherited_linker_flags'
-# Libraries that this one depends upon.
-dependency_libs='$dependency_libs'
-# Names of additional weak libraries provided by this library
-weak_library_names='$weak_libs'
-# Version information for $libname.
-current=$current
-age=$age
-revision=$revision
-# Is this an already installed library?
-installed=$installed
-# Should we warn about portability when linking against -modules?
-shouldnotlink=$module
-# Files to dlopen/dlpreopen
-dlopen='$dlfiles'
-dlpreopen='$dlprefiles'
-# Directory that this library needs to be installed in:
-libdir='$install_libdir'"
- if test "$installed" = no && test "$need_relink" = yes; then
- $ECHO >> $output "\
-relink_command=\"$relink_command\""
- fi
- done
- # Do a symbolic link so that the libtool archive can be found in
- # LD_LIBRARY_PATH before the program is installed.
- func_show_eval '( cd "$output_objdir" && $RM "$outputname" && $LN_S "../$outputname" "$outputname" )' 'exit $?'
- esac
-{ test "$opt_mode" = link || test "$opt_mode" = relink; } &&
- func_mode_link ${1+"$@"}
-# func_mode_uninstall arg...
-func_mode_uninstall ()
- $opt_debug
- RM="$nonopt"
- files=
- rmforce=
- exit_status=0
- # This variable tells wrapper scripts just to set variables rather
- # than running their programs.
- libtool_install_magic="$magic"
- for arg
- do
- case $arg in
- -f) RM+=" $arg"; rmforce=yes ;;
- -*) RM+=" $arg" ;;
- *) files+=" $arg" ;;
- esac
- done
- test -z "$RM" && \
- func_fatal_help "you must specify an RM program"
- rmdirs=
- for file in $files; do
- func_dirname "$file" "" "."
- dir="$func_dirname_result"
- if test "X$dir" = X.; then
- odir="$objdir"
- else
- odir="$dir/$objdir"
- fi
- func_basename "$file"
- test "$opt_mode" = uninstall && odir="$dir"
- # Remember odir for removal later, being careful to avoid duplicates
- if test "$opt_mode" = clean; then
- case " $rmdirs " in
- *" $odir "*) ;;
- *) rmdirs+=" $odir" ;;
- esac
- fi
- # Don't error if the file doesn't exist and rm -f was used.
- if { test -L "$file"; } >/dev/null 2>&1 ||
- { test -h "$file"; } >/dev/null 2>&1 ||
- test -f "$file"; then
- elif test -d "$file"; then
- exit_status=1
- continue
- elif test "$rmforce" = yes; then
- continue
- fi
- rmfiles="$file"
- case $name in
- *.la)
- # Possibly a libtool archive, so verify it.
- if func_lalib_p "$file"; then
- func_source $dir/$name
- # Delete the libtool libraries and symlinks.
- for n in $library_names; do
- rmfiles+=" $odir/$n"
- done
- test -n "$old_library" && rmfiles+=" $odir/$old_library"
- case "$opt_mode" in
- clean)
- case " $library_names " in
- *" $dlname "*) ;;
- *) test -n "$dlname" && rmfiles+=" $odir/$dlname" ;;
- esac
- test -n "$libdir" && rmfiles+=" $odir/$name $odir/${name}i"
- uninstall)
- if test -n "$library_names"; then
- # Do each command in the postuninstall commands.
- func_execute_cmds "$postuninstall_cmds" 'test "$rmforce" = yes || exit_status=1'
- fi
- if test -n "$old_library"; then
- # Do each command in the old_postuninstall commands.
- func_execute_cmds "$old_postuninstall_cmds" 'test "$rmforce" = yes || exit_status=1'
- fi
- # FIXME: should reinstall the best remaining shared library.
- esac
- fi
- *.lo)
- # Possibly a libtool object, so verify it.
- # Read the .lo file
- # Add PIC object to the list of files to remove.
- if test -n "$pic_object" &&
- test "$pic_object" != none; then
- rmfiles+=" $dir/$pic_object"
- fi
- # Add non-PIC object to the list of files to remove.
- if test -n "$non_pic_object" &&
- test "$non_pic_object" != none; then
- rmfiles+=" $dir/$non_pic_object"
- fi
- fi
- if test "$opt_mode" = clean ; then
- noexename=$name
- case $file in
- *.exe)
- func_stripname '' '.exe' "$file"
- file=$func_stripname_result
- func_stripname '' '.exe' "$name"
- noexename=$func_stripname_result
- # $file with .exe has already been added to rmfiles,
- # add $file without .exe
- rmfiles+=" $file"
- esac
- # Do a test to see if this is a libtool program.
- if func_ltwrapper_p "$file"; then
- if func_ltwrapper_executable_p "$file"; then
- func_ltwrapper_scriptname "$file"
- relink_command=
- func_source $func_ltwrapper_scriptname_result
- rmfiles+=" $func_ltwrapper_scriptname_result"
- else
- relink_command=
- func_source $dir/$noexename
- fi
- # note $name still contains .exe if it was in $file originally
- # as does the version of $file that was added into $rmfiles
- rmfiles+=" $odir/$name $odir/${name}S.${objext}"
- if test "$fast_install" = yes && test -n "$relink_command"; then
- rmfiles+=" $odir/lt-$name"
- fi
- if test "X$noexename" != "X$name" ; then
- rmfiles+=" $odir/lt-${noexename}.c"
- fi
- fi
- fi
- esac
- func_show_eval "$RM $rmfiles" 'exit_status=1'
- done
- # Try to remove the ${objdir}s in the directories where we deleted files
- for dir in $rmdirs; do
- if test -d "$dir"; then
- func_show_eval "rmdir $dir >/dev/null 2>&1"
- fi
- done
- exit $exit_status
-{ test "$opt_mode" = uninstall || test "$opt_mode" = clean; } &&
- func_mode_uninstall ${1+"$@"}
-test -z "$opt_mode" && {
- help="$generic_help"
- func_fatal_help "you must specify a MODE"
-test -z "$exec_cmd" && \
- func_fatal_help "invalid operation mode \`$opt_mode'"
-if test -n "$exec_cmd"; then
- eval exec "$exec_cmd"
- exit $EXIT_FAILURE
-fi
-exit $exit_status
-# The TAGs below are defined such that we never get into a situation
-# in which we disable both kinds of libraries. Given conflicting
-# choices, we go for a static library, that is the most portable,
-# since we can't tell whether shared libraries were disabled because
-# the user asked for that or because the platform doesn't support
-# them. This is particularly important on AIX, because we don't
-# support having both static and shared libraries enabled at the same
-# time on that platform, so we default to a shared-only configuration.
-# If a disable-shared tag is given, we'll fallback to a static-only
-# configuration. But we'll never go from static-only to shared-only.
-# ### BEGIN LIBTOOL TAG CONFIG: disable-shared
-build_libtool_libs=no
-build_old_libs=yes
-# ### END LIBTOOL TAG CONFIG: disable-shared
-# ### BEGIN LIBTOOL TAG CONFIG: disable-static
-build_old_libs=`case $build_libtool_libs in yes) echo no;; *) echo yes;; esac`
-# ### END LIBTOOL TAG CONFIG: disable-static
-# Local Variables:
-# mode:shell-script
-# sh-indentation:2
-# End:
-# vi:sw=2
-# ### BEGIN LIBTOOL TAG CONFIG: CXX
-# The linker used to build libraries.
-LD="/usr/bin/ld -m elf_x86_64"
-# How to create reloadable object files.
-reload_flag=" -r"
-reload_cmds="\$LD\$reload_flag -o \$output\$reload_objs"
-# Commands used to build an old-style archive.
-old_archive_cmds="\$AR \$AR_FLAGS \$oldlib\$oldobjs~\$RANLIB \$tool_oldlib"
-# A language specific compiler.
-CC="g++"
-# Is the compiler the GNU compiler?
-with_gcc=yes
-# Compiler flag to turn off builtin functions.
-no_builtin_flag=" -fno-builtin"
-# Additional compiler flags for building library objects.
-pic_flag=" -fPIC -DPIC"
-# How to pass a linker flag through the compiler.
-wl="-Wl,"
-# Compiler flag to prevent dynamic linking.
-link_static_flag="-static"
-# Does compiler simultaneously support -c and -o options?
-compiler_c_o="yes"
-# Whether or not to add -lc for building shared libraries.
-build_libtool_need_lc=no
-# Whether or not to disallow shared libs when runtime libs are static.
-allow_libtool_libs_with_static_runtimes=no
-# Compiler flag to allow reflexive dlopens.
-export_dynamic_flag_spec="\${wl}--export-dynamic"
-# Compiler flag to generate shared objects directly from archives.
-whole_archive_flag_spec="\${wl}--whole-archive\$convenience \${wl}--no-whole-archive"
-# Whether the compiler copes with passing no objects directly.
-compiler_needs_object="no"
-# Create an old-style archive from a shared archive.
-old_archive_from_new_cmds=""
-# Create a temporary old-style archive to link instead of a shared archive.
-old_archive_from_expsyms_cmds=""
-# Commands used to build a shared archive.
-archive_cmds="\$CC \$pic_flag -shared -nostdlib \$predep_objects \$libobjs \$deplibs \$postdep_objects \$compiler_flags \${wl}-soname \$wl\$soname -o \$lib"
-archive_expsym_cmds="\$CC \$pic_flag -shared -nostdlib \$predep_objects \$libobjs \$deplibs \$postdep_objects \$compiler_flags \${wl}-soname \$wl\$soname \${wl}-retain-symbols-file \$wl\$export_symbols -o \$lib"
-# Commands used to build a loadable module if different from building
-# a shared archive.
-module_cmds=""
-module_expsym_cmds=""
-# Whether we are building with GNU ld or not.
-with_gnu_ld="yes"
-# Flag that allows shared libraries with undefined symbols to be built.
-allow_undefined_flag=""
-# Flag that enforces no undefined symbols.
-no_undefined_flag=""
-# Flag to hardcode $libdir into a binary during linking.
-# This must work even if $libdir does not exist
-hardcode_libdir_flag_spec="\${wl}-rpath \${wl}\$libdir"
-# Whether we need a single "-rpath" flag with a separated argument.
-hardcode_libdir_separator=""
-# Set to "yes" if using DIR/libNAME${shared_ext} during linking hardcodes
-# DIR into the resulting binary.
-hardcode_direct=no
-# DIR into the resulting binary and the resulting library dependency is
-# "absolute",i.e impossible to change by setting ${shlibpath_var} if the
-# library is relocated.
-hardcode_direct_absolute=no
-# Set to "yes" if using the -LDIR flag during linking hardcodes DIR
-# into the resulting binary.
-hardcode_minus_L=no
-# Set to "yes" if using SHLIBPATH_VAR=DIR during linking hardcodes DIR
-hardcode_shlibpath_var=unsupported
-# Set to "yes" if building a shared library automatically hardcodes DIR
-# into the library and all subsequent libraries and executables linked
-# against it.
-hardcode_automatic=no
-# Set to yes if linker adds runtime paths of dependent libraries
-# to runtime path list.
-inherit_rpath=no
-# Whether libtool must link a program against all its dependency libraries.
-link_all_deplibs=no
-# Set to "yes" if exported symbols are required.
-always_export_symbols=no
-# The commands to list exported symbols.
-export_symbols_cmds="\$NM \$libobjs \$convenience | \$global_symbol_pipe | \$SED 's/.* //' | sort | uniq > \$export_symbols"
-# Symbols that should not be listed in the preloaded symbols.
-exclude_expsyms="_GLOBAL_OFFSET_TABLE_|_GLOBAL__F[ID]_.*"
-# Symbols that must always be exported.
-include_expsyms=""
-# Commands necessary for linking programs (against libraries) with templates.
-prelink_cmds=""
-# Commands necessary for finishing linking programs.
-postlink_cmds=""
-# Specify filename containing input files.
-file_list_spec=""
-# How to hardcode a shared library path into an executable.
-hardcode_action=immediate
-# The directories searched by this compiler when creating a shared library.
-compiler_lib_search_dirs="/usr/lib/gcc/x86_64-linux-gnu/4.6 /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib /lib/x86_64-linux-gnu /lib/../lib /usr/lib/x86_64-linux-gnu /usr/lib/../lib /usr/lib/gcc/x86_64-linux-gnu/4.6/../../.."
-# Dependencies to place before and after the objects being linked to
-# create a shared library.
-predep_objects="/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crti.o /usr/lib/gcc/x86_64-linux-gnu/4.6/crtbeginS.o"
-postdep_objects="/usr/lib/gcc/x86_64-linux-gnu/4.6/crtendS.o /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crtn.o"
-predeps=""
-postdeps="-lstdc++ -lm -lgcc_s -lc -lgcc_s"
-# The library search path used internally by the compiler when linking
-# a shared library.
-compiler_lib_search_path="-L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.."
-# ### END LIBTOOL TAG CONFIG: CXX
Index: modules/provider-coaster-c-client/config/depcomp
--- modules/provider-coaster-c-client/config/depcomp (revision 3826)
+++ modules/provider-coaster-c-client/config/depcomp (working copy)
@@ -1 +0,0 @@
-link /usr/share/automake-1.11/depcomp
\ No newline at end of file
Index: modules/provider-coaster-c-client/config/missing
--- modules/provider-coaster-c-client/config/missing (revision 3826)
+++ modules/provider-coaster-c-client/config/missing (working copy)
@@ -1 +0,0 @@
-link /usr/share/automake-1.11/missing
Index: modules/provider-coaster-c-client/config/config.guess
--- modules/provider-coaster-c-client/config/config.guess (revision 3826)
+++ modules/provider-coaster-c-client/config/config.guess (working copy)
@@ -1,1530 +0,0 @@
-#! /bin/sh
-# Attempt to guess a canonical system name.
-# Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999,
-# 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010,
-# 2011, 2012 Free Software Foundation, Inc.
-timestamp='2012-02-10'
-# This file is free software; you can redistribute it and/or modify it
-# under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2 of the License, or
-# (at your option) any later version.
-# This program is distributed in the hope that it will be useful, but
-# WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-# General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, see <http://www.gnu.org/licenses/>.
-# As a special exception to the GNU General Public License, if you
-# distribute this file as part of a program that contains a
-# configuration script generated by Autoconf, you may include it under
-# the same distribution terms that you use for the rest of that program.
-# Originally written by Per Bothner. Please send patches (context
-# diff format) to <config-patches at gnu.org> and include a ChangeLog
-# entry.
-# This script attempts to guess a canonical system name similar to
-# config.sub. If it succeeds, it prints the system name on stdout, and
-# exits with 0. Otherwise, it exits with 1.
-# You can get the latest version of this script from:
-# http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess;hb=HEAD
-me=`echo "$0" | sed -e 's,.*/,,'`
-usage="\
-Usage: $0 [OPTION]
-Output the configuration name of the system \`$me' is run on.
-Operation modes:
- -h, --help print this help, then exit
- -t, --time-stamp print date of last modification, then exit
- -v, --version print version number, then exit
-Report bugs and patches to <config-patches at gnu.org>."
-version="\
-GNU config.guess ($timestamp)
-Originally written by Per Bothner.
-Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000,
-2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012
-Free Software Foundation, Inc.
-This is free software; see the source for copying conditions. There is NO
-warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
-help="
-Try \`$me --help' for more information."
-# Parse command line
-while test $# -gt 0 ; do
- case $1 in
- --time-stamp | --time* | -t )
- echo "$timestamp" ; exit ;;
- --version | -v )
- echo "$version" ; exit ;;
- --help | --h* | -h )
- echo "$usage"; exit ;;
- -- ) # Stop option processing
- shift; break ;;
- - ) # Use stdin as input.
- break ;;
- echo "$me: invalid option $1$help" >&2
- exit 1 ;;
- break ;;
- esac
-done
-if test $# != 0; then
- echo "$me: too many arguments$help" >&2
- exit 1
-fi
-trap 'exit 1' 1 2 15
-# CC_FOR_BUILD -- compiler used by this script. Note that the use of a
-# compiler to aid in system detection is discouraged as it requires
-# temporary files to be created and, as you can see below, it is a
-# headache to deal with in a portable fashion.
-# Historically, `CC_FOR_BUILD' used to be named `HOST_CC'. We still
-# use `HOST_CC' if defined, but it is deprecated.
-# Portable tmp directory creation inspired by the Autoconf team.
-set_cc_for_build='
-trap "exitcode=\$?; (rm -f \$tmpfiles 2>/dev/null; rmdir \$tmp 2>/dev/null) && exit \$exitcode" 0 ;
-trap "rm -f \$tmpfiles 2>/dev/null; rmdir \$tmp 2>/dev/null; exit 1" 1 2 13 15 ;
-: ${TMPDIR=/tmp} ;
- { tmp=`(umask 077 && mktemp -d "$TMPDIR/cgXXXXXX") 2>/dev/null` && test -n "$tmp" && test -d "$tmp" ; } ||
- { test -n "$RANDOM" && tmp=$TMPDIR/cg$$-$RANDOM && (umask 077 && mkdir $tmp) ; } ||
- { tmp=$TMPDIR/cg-$$ && (umask 077 && mkdir $tmp) && echo "Warning: creating insecure temp directory" >&2 ; } ||
- { echo "$me: cannot create a temporary directory in $TMPDIR" >&2 ; exit 1 ; } ;
-dummy=$tmp/dummy ;
-tmpfiles="$dummy.c $dummy.o $dummy.rel $dummy" ;
-case $CC_FOR_BUILD,$HOST_CC,$CC in
- ,,) echo "int x;" > $dummy.c ;
- for c in cc gcc c89 c99 ; do
- if ($c -c -o $dummy.o $dummy.c) >/dev/null 2>&1 ; then
- CC_FOR_BUILD="$c"; break ;
- fi ;
- done ;
- if test x"$CC_FOR_BUILD" = x ; then
- CC_FOR_BUILD=no_compiler_found ;
- fi
- ,,*) CC_FOR_BUILD=$CC ;;
- ,*,*) CC_FOR_BUILD=$HOST_CC ;;
-esac ; set_cc_for_build= ;'
-# This is needed to find uname on a Pyramid OSx when run in the BSD universe.
-# (ghazi at noc.rutgers.edu 1994-08-24)
-if (test -f /.attbin/uname) >/dev/null 2>&1 ; then
- PATH=$PATH:/.attbin ; export PATH
-fi
-UNAME_MACHINE=`(uname -m) 2>/dev/null` || UNAME_MACHINE=unknown
-UNAME_RELEASE=`(uname -r) 2>/dev/null` || UNAME_RELEASE=unknown
-UNAME_SYSTEM=`(uname -s) 2>/dev/null` || UNAME_SYSTEM=unknown
-UNAME_VERSION=`(uname -v) 2>/dev/null` || UNAME_VERSION=unknown
-# Note: order is significant - the case branches are not exclusive.
-case "${UNAME_MACHINE}:${UNAME_SYSTEM}:${UNAME_RELEASE}:${UNAME_VERSION}" in
- *:NetBSD:*:*)
- # NetBSD (nbsd) targets should (where applicable) match one or
- # more of the tuples: *-*-netbsdelf*, *-*-netbsdaout*,
- # *-*-netbsdecoff* and *-*-netbsd*. For targets that recently
- # switched to ELF, *-*-netbsd* would select the old
- # object file format. This provides both forward
- # compatibility and a consistent mechanism for selecting the
- # Note: NetBSD doesn't particularly care about the vendor
- # portion of the name. We always set it to "unknown".
- sysctl="sysctl -n hw.machine_arch"
- UNAME_MACHINE_ARCH=`(/sbin/$sysctl 2>/dev/null || \
- /usr/sbin/$sysctl 2>/dev/null || echo unknown)`
- case "${UNAME_MACHINE_ARCH}" in
- armeb) machine=armeb-unknown ;;
- arm*) machine=arm-unknown ;;
- sh3el) machine=shl-unknown ;;
- sh3eb) machine=sh-unknown ;;
- sh5el) machine=sh5le-unknown ;;
- *) machine=${UNAME_MACHINE_ARCH}-unknown ;;
- esac
- # The Operating System including object format, if it has switched
- # to ELF recently, or will in the future.
- arm*|i386|m68k|ns32k|sh3*|sparc|vax)
- eval $set_cc_for_build
- if echo __ELF__ | $CC_FOR_BUILD -E - 2>/dev/null \
- | grep -q __ELF__
- then
- # Once all utilities can be ECOFF (netbsdecoff) or a.out (netbsdaout).
- # Return netbsd for either. FIX?
- os=netbsd
- else
- os=netbsdelf
- fi
- os=netbsd
- esac
- # The OS release
- # Debian GNU/NetBSD machines have a different userland, and
- # thus, need a distinct triplet. However, they do not need
- # kernel version information, so it can be replaced with a
- # suitable tag, in the style of linux-gnu.
- case "${UNAME_VERSION}" in
- Debian*)
- release='-gnu'
- release=`echo ${UNAME_RELEASE}|sed -e 's/[-_].*/\./'`
- esac
- # Since CPU_TYPE-MANUFACTURER-KERNEL-OPERATING_SYSTEM:
- # contains redundant information, the shorter form:
- # CPU_TYPE-MANUFACTURER-OPERATING_SYSTEM is used.
- echo "${machine}-${os}${release}"
- exit ;;
- *:OpenBSD:*:*)
- UNAME_MACHINE_ARCH=`arch | sed 's/OpenBSD.//'`
- echo ${UNAME_MACHINE_ARCH}-unknown-openbsd${UNAME_RELEASE}
- exit ;;
- *:ekkoBSD:*:*)
- echo ${UNAME_MACHINE}-unknown-ekkobsd${UNAME_RELEASE}
- exit ;;
- *:SolidBSD:*:*)
- echo ${UNAME_MACHINE}-unknown-solidbsd${UNAME_RELEASE}
- exit ;;
- macppc:MirBSD:*:*)
- echo powerpc-unknown-mirbsd${UNAME_RELEASE}
- exit ;;
- *:MirBSD:*:*)
- echo ${UNAME_MACHINE}-unknown-mirbsd${UNAME_RELEASE}
- exit ;;
- alpha:OSF1:*:*)
- case $UNAME_RELEASE in
- *4.0)
- UNAME_RELEASE=`/usr/sbin/sizer -v | awk '{print $3}'`
- *5.*)
- UNAME_RELEASE=`/usr/sbin/sizer -v | awk '{print $4}'`
- esac
- # According to Compaq, /usr/sbin/psrinfo has been available on
- # OSF/1 and Tru64 systems produced since 1995. I hope that
- # covers most systems running today. This code pipes the CPU
- # types through head -n 1, so we only detect the type of CPU 0.
- ALPHA_CPU_TYPE=`/usr/sbin/psrinfo -v | sed -n -e 's/^ The alpha \(.*\) processor.*$/\1/p' | head -n 1`
- case "$ALPHA_CPU_TYPE" in
- "EV4 (21064)")
- UNAME_MACHINE="alpha" ;;
- "EV4.5 (21064)")
- "LCA4 (21066/21068)")
- "EV5 (21164)")
- UNAME_MACHINE="alphaev5" ;;
- "EV5.6 (21164A)")
- UNAME_MACHINE="alphaev56" ;;
- "EV5.6 (21164PC)")
- UNAME_MACHINE="alphapca56" ;;
- "EV5.7 (21164PC)")
- UNAME_MACHINE="alphapca57" ;;
- "EV6 (21264)")
- UNAME_MACHINE="alphaev6" ;;
- "EV6.7 (21264A)")
- UNAME_MACHINE="alphaev67" ;;
- "EV6.8CB (21264C)")
- UNAME_MACHINE="alphaev68" ;;
- "EV6.8AL (21264B)")
- "EV6.8CX (21264D)")
- "EV6.9A (21264/EV69A)")
- UNAME_MACHINE="alphaev69" ;;
- "EV7 (21364)")
- UNAME_MACHINE="alphaev7" ;;
- "EV7.9 (21364A)")
- UNAME_MACHINE="alphaev79" ;;
- esac
- # A Pn.n version is a patched version.
- # A Vn.n version is a released version.
- # A Tn.n version is a released field test version.
- # A Xn.n version is an unreleased experimental baselevel.
- # 1.2 uses "1.2" for uname -r.
- echo ${UNAME_MACHINE}-dec-osf`echo ${UNAME_RELEASE} | sed -e 's/^[PVTX]//' | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz'`
- # Reset EXIT trap before exiting to avoid spurious non-zero exit code.
- exitcode=$?
- trap '' 0
- exit $exitcode ;;
- Alpha\ *:Windows_NT*:*)
- # How do we know it's Interix rather than the generic POSIX subsystem?
- # Should we change UNAME_MACHINE based on the output of uname instead
- # of the specific Alpha model?
- echo alpha-pc-interix
- exit ;;
- 21064:Windows_NT:50:3)
- echo alpha-dec-winnt3.5
- exit ;;
- Amiga*:UNIX_System_V:4.0:*)
- echo m68k-unknown-sysv4
- exit ;;
- *:[Aa]miga[Oo][Ss]:*:*)
- echo ${UNAME_MACHINE}-unknown-amigaos
- exit ;;
- *:[Mm]orph[Oo][Ss]:*:*)
- echo ${UNAME_MACHINE}-unknown-morphos
- exit ;;
- *:OS/390:*:*)
- echo i370-ibm-openedition
- exit ;;
- *:z/VM:*:*)
- echo s390-ibm-zvmoe
- exit ;;
- *:OS400:*:*)
- echo powerpc-ibm-os400
- exit ;;
- arm:RISC*:1.[012]*:*|arm:riscix:1.[012]*:*)
- echo arm-acorn-riscix${UNAME_RELEASE}
- exit ;;
- arm:riscos:*:*|arm:RISCOS:*:*)
- echo arm-unknown-riscos
- exit ;;
- SR2?01:HI-UX/MPP:*:* | SR8000:HI-UX/MPP:*:*)
- echo hppa1.1-hitachi-hiuxmpp
- exit ;;
- Pyramid*:OSx*:*:* | MIS*:OSx*:*:* | MIS*:SMP_DC-OSx*:*:*)
- # akee at wpdis03.wpafb.af.mil (Earle F. Ake) contributed MIS and NILE.
- if test "`(/bin/universe) 2>/dev/null`" = att ; then
- echo pyramid-pyramid-sysv3
- else
- echo pyramid-pyramid-bsd
- fi
- exit ;;
- NILE*:*:*:dcosx)
- echo pyramid-pyramid-svr4
- exit ;;
- DRS?6000:unix:4.0:6*)
- echo sparc-icl-nx6
- exit ;;
- DRS?6000:UNIX_SV:4.2*:7* | DRS?6000:isis:4.2*:7*)
- case `/usr/bin/uname -p` in
- sparc) echo sparc-icl-nx7; exit ;;
- esac ;;
- s390x:SunOS:*:*)
- echo ${UNAME_MACHINE}-ibm-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit ;;
- sun4H:SunOS:5.*:*)
- echo sparc-hal-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit ;;
- sun4*:SunOS:5.*:* | tadpole*:SunOS:5.*:*)
- echo sparc-sun-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit ;;
- i86pc:AuroraUX:5.*:* | i86xen:AuroraUX:5.*:*)
- echo i386-pc-auroraux${UNAME_RELEASE}
- exit ;;
- i86pc:SunOS:5.*:* | i86xen:SunOS:5.*:*)
- SUN_ARCH="i386"
- # If there is a compiler, see if it is configured for 64-bit objects.
- # Note that the Sun cc does not turn __LP64__ into 1 like gcc does.
- # This test works for both compilers.
- if [ "$CC_FOR_BUILD" != 'no_compiler_found' ]; then
- if (echo '#ifdef __amd64'; echo IS_64BIT_ARCH; echo '#endif') | \
- (CCOPTS= $CC_FOR_BUILD -E - 2>/dev/null) | \
- grep IS_64BIT_ARCH >/dev/null
- then
- SUN_ARCH="x86_64"
- fi
- fi
- echo ${SUN_ARCH}-pc-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit ;;
- sun4*:SunOS:6*:*)
- # According to config.sub, this is the proper way to canonicalize
- # SunOS6. Hard to guess exactly what SunOS6 will be like, but
- # it's likely to be more like Solaris than SunOS4.
- echo sparc-sun-solaris3`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit ;;
- sun4*:SunOS:*:*)
- case "`/usr/bin/arch -k`" in
- Series*|S4*)
- UNAME_RELEASE=`uname -v`
- esac
- # Japanese Language versions have a version number like `4.1.3-JL'.
- echo sparc-sun-sunos`echo ${UNAME_RELEASE}|sed -e 's/-/_/'`
- exit ;;
- sun3*:SunOS:*:*)
- echo m68k-sun-sunos${UNAME_RELEASE}
- exit ;;
- sun*:*:4.2BSD:*)
- UNAME_RELEASE=`(sed 1q /etc/motd | awk '{print substr($5,1,3)}') 2>/dev/null`
- test "x${UNAME_RELEASE}" = "x" && UNAME_RELEASE=3
- case "`/bin/arch`" in
- sun3)
- sun4)
- echo sparc-sun-sunos${UNAME_RELEASE}
- esac
- exit ;;
- aushp:SunOS:*:*)
- echo sparc-auspex-sunos${UNAME_RELEASE}
- exit ;;
- # The situation for MiNT is a little confusing. The machine name
- # can be virtually everything (everything which is not
- # "atarist" or "atariste" at least should have a processor
- # > m68000). The system name ranges from "MiNT" over "FreeMiNT"
- # to the lowercase version "mint" (or "freemint"). Finally
- # the system name "TOS" denotes a system which is actually not
- # MiNT. But MiNT is downward compatible to TOS, so this should
- # be no problem.
- atarist[e]:*MiNT:*:* | atarist[e]:*mint:*:* | atarist[e]:*TOS:*:*)
- echo m68k-atari-mint${UNAME_RELEASE}
- exit ;;
- atari*:*MiNT:*:* | atari*:*mint:*:* | atarist[e]:*TOS:*:*)
- exit ;;
- *falcon*:*MiNT:*:* | *falcon*:*mint:*:* | *falcon*:*TOS:*:*)
- exit ;;
- milan*:*MiNT:*:* | milan*:*mint:*:* | *milan*:*TOS:*:*)
- echo m68k-milan-mint${UNAME_RELEASE}
- exit ;;
- hades*:*MiNT:*:* | hades*:*mint:*:* | *hades*:*TOS:*:*)
- echo m68k-hades-mint${UNAME_RELEASE}
- exit ;;
- *:*MiNT:*:* | *:*mint:*:* | *:*TOS:*:*)
- echo m68k-unknown-mint${UNAME_RELEASE}
- exit ;;
- m68k:machten:*:*)
- echo m68k-apple-machten${UNAME_RELEASE}
- exit ;;
- powerpc:machten:*:*)
- echo powerpc-apple-machten${UNAME_RELEASE}
- exit ;;
- RISC*:Mach:*:*)
- echo mips-dec-mach_bsd4.3
- exit ;;
- RISC*:ULTRIX:*:*)
- echo mips-dec-ultrix${UNAME_RELEASE}
- exit ;;
- VAX*:ULTRIX*:*:*)
- echo vax-dec-ultrix${UNAME_RELEASE}
- exit ;;
- 2020:CLIX:*:* | 2430:CLIX:*:*)
- echo clipper-intergraph-clix${UNAME_RELEASE}
- exit ;;
- mips:*:*:UMIPS | mips:*:*:RISCos)
- sed 's/^ //' << EOF >$dummy.c
-#ifdef __cplusplus
-#include <stdio.h> /* for printf() prototype */
- int main (int argc, char *argv[]) {
-#else
- int main (argc, argv) int argc; char *argv[]; {
-#endif
- #if defined (host_mips) && defined (MIPSEB)
- #if defined (SYSTYPE_SYSV)
- printf ("mips-mips-riscos%ssysv\n", argv[1]); exit (0);
- #endif
- #if defined (SYSTYPE_SVR4)
- printf ("mips-mips-riscos%ssvr4\n", argv[1]); exit (0);
- #endif
- #if defined (SYSTYPE_BSD43) || defined(SYSTYPE_BSD)
- printf ("mips-mips-riscos%sbsd\n", argv[1]); exit (0);
- #endif
- #endif
- exit (-1);
-EOF
- $CC_FOR_BUILD -o $dummy $dummy.c &&
- dummyarg=`echo "${UNAME_RELEASE}" | sed -n 's/\([0-9]*\).*/\1/p'` &&
- SYSTEM_NAME=`$dummy $dummyarg` &&
- { echo "$SYSTEM_NAME"; exit; }
- echo mips-mips-riscos${UNAME_RELEASE}
- exit ;;
- Motorola:PowerMAX_OS:*:*)
- echo powerpc-motorola-powermax
- exit ;;
- Motorola:*:4.3:PL8-*)
- echo powerpc-harris-powermax
- exit ;;
- Night_Hawk:*:*:PowerMAX_OS | Synergy:PowerMAX_OS:*:*)
- exit ;;
- Night_Hawk:Power_UNIX:*:*)
- echo powerpc-harris-powerunix
- exit ;;
- m88k:CX/UX:7*:*)
- echo m88k-harris-cxux7
- exit ;;
- m88k:*:4*:R4*)
- echo m88k-motorola-sysv4
- exit ;;
- m88k:*:3*:R3*)
- echo m88k-motorola-sysv3
- exit ;;
- AViiON:dgux:*:*)
- # DG/UX returns AViiON for all architectures
- UNAME_PROCESSOR=`/usr/bin/uname -p`
- if [ $UNAME_PROCESSOR = mc88100 ] || [ $UNAME_PROCESSOR = mc88110 ]
- then
- if [ ${TARGET_BINARY_INTERFACE}x = m88kdguxelfx ] || \
- [ ${TARGET_BINARY_INTERFACE}x = x ]
- then
- echo m88k-dg-dgux${UNAME_RELEASE}
- else
- echo m88k-dg-dguxbcs${UNAME_RELEASE}
- fi
- else
- echo i586-dg-dgux${UNAME_RELEASE}
- fi
- exit ;;
- M88*:DolphinOS:*:*) # DolphinOS (SVR3)
- echo m88k-dolphin-sysv3
- exit ;;
- M88*:*:R3*:*)
- # Delta 88k system running SVR3
- exit ;;
- XD88*:*:*:*) # Tektronix XD88 system running UTekV (SVR3)
- echo m88k-tektronix-sysv3
- exit ;;
- Tek43[0-9][0-9]:UTek:*:*) # Tektronix 4300 system running UTek (BSD)
- echo m68k-tektronix-bsd
- exit ;;
- *:IRIX*:*:*)
- echo mips-sgi-irix`echo ${UNAME_RELEASE}|sed -e 's/-/_/g'`
- exit ;;
- ????????:AIX?:[12].1:2) # AIX 2.2.1 or AIX 2.1.1 is RT/PC AIX.
- echo romp-ibm-aix # uname -m gives an 8 hex-code CPU id
- exit ;; # Note that: echo "'`uname -s`'" gives 'AIX '
- i*86:AIX:*:*)
- echo i386-ibm-aix
- exit ;;
- ia64:AIX:*:*)
- if [ -x /usr/bin/oslevel ] ; then
- IBM_REV=`/usr/bin/oslevel`
- else
- IBM_REV=${UNAME_VERSION}.${UNAME_RELEASE}
- fi
- echo ${UNAME_MACHINE}-ibm-aix${IBM_REV}
- exit ;;
- *:AIX:2:3)
- if grep bos325 /usr/include/stdio.h >/dev/null 2>&1; then
- #include <sys/systemcfg.h>
- main()
- if (!__power_pc())
- exit(1);
- puts("powerpc-ibm-aix3.2.5");
- exit(0);
-EOF
- if $CC_FOR_BUILD -o $dummy $dummy.c && SYSTEM_NAME=`$dummy`
- then
- echo "$SYSTEM_NAME"
- else
- echo rs6000-ibm-aix3.2.5
- fi
- elif grep bos324 /usr/include/stdio.h >/dev/null 2>&1; then
- echo rs6000-ibm-aix3.2.4
- else
- fi
- exit ;;
- *:AIX:*:[4567])
- IBM_CPU_ID=`/usr/sbin/lsdev -C -c processor -S available | sed 1q | awk '{ print $1 }'`
- if /usr/sbin/lsattr -El ${IBM_CPU_ID} | grep ' POWER' >/dev/null 2>&1; then
- IBM_ARCH=rs6000
- else
- IBM_ARCH=powerpc
- fi
- else
- fi
- echo ${IBM_ARCH}-ibm-aix${IBM_REV}
- exit ;;
- *:AIX:*:*)
- exit ;;
- ibmrt:4.4BSD:*|romp-ibm:BSD:*)
- echo romp-ibm-bsd4.4
- exit ;;
- ibmrt:*BSD:*|romp-ibm:BSD:*) # covers RT/PC BSD and
- echo romp-ibm-bsd${UNAME_RELEASE} # 4.3 with uname added to
- exit ;; # report: romp-ibm BSD 4.3
- *:BOSX:*:*)
- echo rs6000-bull-bosx
- exit ;;
- DPX/2?00:B.O.S.:*:*)
- echo m68k-bull-sysv3
- exit ;;
- 9000/[34]??:4.3bsd:1.*:*)
- echo m68k-hp-bsd
- exit ;;
- hp300:4.4BSD:*:* | 9000/[34]??:4.3bsd:2.*:*)
- echo m68k-hp-bsd4.4
- exit ;;
- 9000/[34678]??:HP-UX:*:*)
- HPUX_REV=`echo ${UNAME_RELEASE}|sed -e 's/[^.]*.[0B]*//'`
- case "${UNAME_MACHINE}" in
- 9000/31? ) HP_ARCH=m68000 ;;
- 9000/[34]?? ) HP_ARCH=m68k ;;
- 9000/[678][0-9][0-9])
- if [ -x /usr/bin/getconf ]; then
- sc_cpu_version=`/usr/bin/getconf SC_CPU_VERSION 2>/dev/null`
- sc_kernel_bits=`/usr/bin/getconf SC_KERNEL_BITS 2>/dev/null`
- case "${sc_cpu_version}" in
- 523) HP_ARCH="hppa1.0" ;; # CPU_PA_RISC1_0
- 528) HP_ARCH="hppa1.1" ;; # CPU_PA_RISC1_1
- 532) # CPU_PA_RISC2_0
- case "${sc_kernel_bits}" in
- 32) HP_ARCH="hppa2.0n" ;;
- 64) HP_ARCH="hppa2.0w" ;;
- '') HP_ARCH="hppa2.0" ;; # HP-UX 10.20
- esac ;;
- esac
- fi
- if [ "${HP_ARCH}" = "" ]; then
- #define _HPUX_SOURCE
- #include <stdlib.h>
- #include <unistd.h>
- int main ()
- #if defined(_SC_KERNEL_BITS)
- long bits = sysconf(_SC_KERNEL_BITS);
- #endif
- long cpu = sysconf (_SC_CPU_VERSION);
- switch (cpu)
- case CPU_PA_RISC1_0: puts ("hppa1.0"); break;
- case CPU_PA_RISC1_1: puts ("hppa1.1"); break;
- case CPU_PA_RISC2_0:
- switch (bits)
- case 64: puts ("hppa2.0w"); break;
- case 32: puts ("hppa2.0n"); break;
- default: puts ("hppa2.0"); break;
- } break;
- #else /* !defined(_SC_KERNEL_BITS) */
- puts ("hppa2.0"); break;
- #endif
- default: puts ("hppa1.0"); break;
- exit (0);
-EOF
- (CCOPTS= $CC_FOR_BUILD -o $dummy $dummy.c 2>/dev/null) && HP_ARCH=`$dummy`
- test -z "$HP_ARCH" && HP_ARCH=hppa
- fi ;;
- esac
- if [ ${HP_ARCH} = "hppa2.0w" ]
- then
- # hppa2.0w-hp-hpux* has a 64-bit kernel and a compiler generating
- # 32-bit code. hppa64-hp-hpux* has the same kernel and a compiler
- # generating 64-bit code. GNU and HP use different nomenclature:
- # $ CC_FOR_BUILD=cc ./config.guess
- # => hppa2.0w-hp-hpux11.23
- # $ CC_FOR_BUILD="cc +DA2.0w" ./config.guess
- # => hppa64-hp-hpux11.23
- if echo __LP64__ | (CCOPTS= $CC_FOR_BUILD -E - 2>/dev/null) |
- grep -q __LP64__
- then
- HP_ARCH="hppa2.0w"
- else
- HP_ARCH="hppa64"
- fi
- fi
- echo ${HP_ARCH}-hp-hpux${HPUX_REV}
- exit ;;
- ia64:HP-UX:*:*)
- echo ia64-hp-hpux${HPUX_REV}
- exit ;;
- 3050*:HI-UX:*:*)
- int
- main ()
- /* The order matters, because CPU_IS_HP_MC68K erroneously returns
- true for CPU_PA_RISC1_0. CPU_IS_PA_RISC returns correct
- results, however. */
- if (CPU_IS_PA_RISC (cpu))
- switch (cpu)
- case CPU_PA_RISC1_0: puts ("hppa1.0-hitachi-hiuxwe2"); break;
- case CPU_PA_RISC1_1: puts ("hppa1.1-hitachi-hiuxwe2"); break;
- case CPU_PA_RISC2_0: puts ("hppa2.0-hitachi-hiuxwe2"); break;
- default: puts ("hppa-hitachi-hiuxwe2"); break;
- else if (CPU_IS_HP_MC68K (cpu))
- puts ("m68k-hitachi-hiuxwe2");
- else puts ("unknown-hitachi-hiuxwe2");
- exit (0);
-EOF
- $CC_FOR_BUILD -o $dummy $dummy.c && SYSTEM_NAME=`$dummy` &&
- echo unknown-hitachi-hiuxwe2
- exit ;;
- 9000/7??:4.3bsd:*:* | 9000/8?[79]:4.3bsd:*:* )
- echo hppa1.1-hp-bsd
- exit ;;
- 9000/8??:4.3bsd:*:*)
- echo hppa1.0-hp-bsd
- exit ;;
- *9??*:MPE/iX:*:* | *3000*:MPE/iX:*:*)
- echo hppa1.0-hp-mpeix
- exit ;;
- hp7??:OSF1:*:* | hp8?[79]:OSF1:*:* )
- echo hppa1.1-hp-osf
- exit ;;
- hp8??:OSF1:*:*)
- echo hppa1.0-hp-osf
- exit ;;
- i*86:OSF1:*:*)
- if [ -x /usr/sbin/sysversion ] ; then
- echo ${UNAME_MACHINE}-unknown-osf1mk
- else
- fi
- exit ;;
- parisc*:Lites*:*:*)
- echo hppa1.1-hp-lites
- exit ;;
- C1*:ConvexOS:*:* | convex:ConvexOS:C1*:*)
- echo c1-convex-bsd
- exit ;;
- C2*:ConvexOS:*:* | convex:ConvexOS:C2*:*)
- if getsysinfo -f scalar_acc
- then echo c32-convex-bsd
- else echo c2-convex-bsd
- fi
- exit ;;
- C34*:ConvexOS:*:* | convex:ConvexOS:C34*:*)
- echo c34-convex-bsd
- exit ;;
- C38*:ConvexOS:*:* | convex:ConvexOS:C38*:*)
- echo c38-convex-bsd
- exit ;;
- C4*:ConvexOS:*:* | convex:ConvexOS:C4*:*)
- echo c4-convex-bsd
- exit ;;
- CRAY*Y-MP:*:*:*)
- echo ymp-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
- exit ;;
- CRAY*[A-Z]90:*:*:*)
- echo ${UNAME_MACHINE}-cray-unicos${UNAME_RELEASE} \
- | sed -e 's/CRAY.*\([A-Z]90\)/\1/' \
- -e y/ABCDEFGHIJKLMNOPQRSTUVWXYZ/abcdefghijklmnopqrstuvwxyz/ \
- -e 's/\.[^.]*$/.X/'
- exit ;;
- CRAY*TS:*:*:*)
- echo t90-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
- exit ;;
- CRAY*T3E:*:*:*)
- echo alphaev5-cray-unicosmk${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
- exit ;;
- CRAY*SV1:*:*:*)
- echo sv1-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
- exit ;;
- *:UNICOS/mp:*:*)
- echo craynv-cray-unicosmp${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
- exit ;;
- F30[01]:UNIX_System_V:*:* | F700:UNIX_System_V:*:*)
- FUJITSU_PROC=`uname -m | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz'`
- FUJITSU_SYS=`uname -p | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz' | sed -e 's/\///'`
- FUJITSU_REL=`echo ${UNAME_RELEASE} | sed -e 's/ /_/'`
- echo "${FUJITSU_PROC}-fujitsu-${FUJITSU_SYS}${FUJITSU_REL}"
- exit ;;
- 5000:UNIX_System_V:4.*:*)
- FUJITSU_REL=`echo ${UNAME_RELEASE} | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz' | sed -e 's/ /_/'`
- echo "sparc-fujitsu-${FUJITSU_SYS}${FUJITSU_REL}"
- exit ;;
- i*86:BSD/386:*:* | i*86:BSD/OS:*:* | *:Ascend\ Embedded/OS:*:*)
- echo ${UNAME_MACHINE}-pc-bsdi${UNAME_RELEASE}
- exit ;;
- sparc*:BSD/OS:*:*)
- echo sparc-unknown-bsdi${UNAME_RELEASE}
- exit ;;
- *:BSD/OS:*:*)
- echo ${UNAME_MACHINE}-unknown-bsdi${UNAME_RELEASE}
- exit ;;
- *:FreeBSD:*:*)
- case ${UNAME_PROCESSOR} in
- amd64)
- echo x86_64-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'` ;;
- echo ${UNAME_PROCESSOR}-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'` ;;
- esac
- exit ;;
- i*:CYGWIN*:*)
- echo ${UNAME_MACHINE}-pc-cygwin
- exit ;;
- *:MINGW*:*)
- echo ${UNAME_MACHINE}-pc-mingw32
- exit ;;
- i*:MSYS*:*)
- echo ${UNAME_MACHINE}-pc-msys
- exit ;;
- i*:windows32*:*)
- # uname -m includes "-pc" on this system.
- echo ${UNAME_MACHINE}-mingw32
- exit ;;
- i*:PW*:*)
- echo ${UNAME_MACHINE}-pc-pw32
- exit ;;
- *:Interix*:*)
- case ${UNAME_MACHINE} in
- x86)
- echo i586-pc-interix${UNAME_RELEASE}
- exit ;;
- authenticamd | genuineintel | EM64T)
- echo x86_64-unknown-interix${UNAME_RELEASE}
- exit ;;
- IA64)
- echo ia64-unknown-interix${UNAME_RELEASE}
- exit ;;
- esac ;;
- [345]86:Windows_95:* | [345]86:Windows_98:* | [345]86:Windows_NT:*)
- echo i${UNAME_MACHINE}-pc-mks
- exit ;;
- 8664:Windows_NT:*)
- echo x86_64-pc-mks
- exit ;;
- i*:Windows_NT*:* | Pentium*:Windows_NT*:*)
- # It also conflicts with pre-2.0 versions of AT&T UWIN. Should we
- # UNAME_MACHINE based on the output of uname instead of i386?
- exit ;;
- i*:UWIN*:*)
- echo ${UNAME_MACHINE}-pc-uwin
- exit ;;
- amd64:CYGWIN*:*:* | x86_64:CYGWIN*:*:*)
- echo x86_64-unknown-cygwin
- exit ;;
- p*:CYGWIN*:*)
- echo powerpcle-unknown-cygwin
- exit ;;
- prep*:SunOS:5.*:*)
- echo powerpcle-unknown-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit ;;
- *:GNU:*:*)
- # the GNU system
- echo `echo ${UNAME_MACHINE}|sed -e 's,[-/].*$,,'`-unknown-gnu`echo ${UNAME_RELEASE}|sed -e 's,/.*$,,'`
- exit ;;
- *:GNU/*:*:*)
- # other systems with GNU libc and userland
- echo ${UNAME_MACHINE}-unknown-`echo ${UNAME_SYSTEM} | sed 's,^[^/]*/,,' | tr '[A-Z]' '[a-z]'``echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`-gnu
- exit ;;
- i*86:Minix:*:*)
- echo ${UNAME_MACHINE}-pc-minix
- exit ;;
- aarch64:Linux:*:*)
- echo ${UNAME_MACHINE}-unknown-linux-gnu
- exit ;;
- aarch64_be:Linux:*:*)
- UNAME_MACHINE=aarch64_be
- exit ;;
- alpha:Linux:*:*)
- case `sed -n '/^cpu model/s/^.*: \(.*\)/\1/p' < /proc/cpuinfo` in
- EV5) UNAME_MACHINE=alphaev5 ;;
- EV56) UNAME_MACHINE=alphaev56 ;;
- PCA56) UNAME_MACHINE=alphapca56 ;;
- PCA57) UNAME_MACHINE=alphapca56 ;;
- EV6) UNAME_MACHINE=alphaev6 ;;
- EV67) UNAME_MACHINE=alphaev67 ;;
- EV68*) UNAME_MACHINE=alphaev68 ;;
- esac
- objdump --private-headers /bin/sh | grep -q ld.so.1
- if test "$?" = 0 ; then LIBC="libc1" ; else LIBC="" ; fi
- echo ${UNAME_MACHINE}-unknown-linux-gnu${LIBC}
- exit ;;
- arm*:Linux:*:*)
- if echo __ARM_EABI__ | $CC_FOR_BUILD -E - 2>/dev/null \
- | grep -q __ARM_EABI__
- then
- else
- if echo __ARM_PCS_VFP | $CC_FOR_BUILD -E - 2>/dev/null \
- | grep -q __ARM_PCS_VFP
- then
- echo ${UNAME_MACHINE}-unknown-linux-gnueabi
- else
- echo ${UNAME_MACHINE}-unknown-linux-gnueabihf
- fi
- fi
- exit ;;
- avr32*:Linux:*:*)
- exit ;;
- cris:Linux:*:*)
- echo ${UNAME_MACHINE}-axis-linux-gnu
- exit ;;
- crisv32:Linux:*:*)
- exit ;;
- frv:Linux:*:*)
- exit ;;
- hexagon:Linux:*:*)
- exit ;;
- i*86:Linux:*:*)
- LIBC=gnu
- #ifdef __dietlibc__
- LIBC=dietlibc
- #endif
-EOF
- eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep '^LIBC'`
- echo "${UNAME_MACHINE}-pc-linux-${LIBC}"
- exit ;;
- ia64:Linux:*:*)
- exit ;;
- m32r*:Linux:*:*)
- exit ;;
- m68*:Linux:*:*)
- exit ;;
- mips:Linux:*:* | mips64:Linux:*:*)
- #undef CPU
- #undef ${UNAME_MACHINE}
- #undef ${UNAME_MACHINE}el
- #if defined(__MIPSEL__) || defined(__MIPSEL) || defined(_MIPSEL) || defined(MIPSEL)
- CPU=${UNAME_MACHINE}el
- #else
- #if defined(__MIPSEB__) || defined(__MIPSEB) || defined(_MIPSEB) || defined(MIPSEB)
- #else
- CPU=
- #endif
- #endif
-EOF
- eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep '^CPU'`
- test x"${CPU}" != x && { echo "${CPU}-unknown-linux-gnu"; exit; }
- or32:Linux:*:*)
- exit ;;
- padre:Linux:*:*)
- echo sparc-unknown-linux-gnu
- exit ;;
- parisc64:Linux:*:* | hppa64:Linux:*:*)
- echo hppa64-unknown-linux-gnu
- exit ;;
- parisc:Linux:*:* | hppa:Linux:*:*)
- # Look for CPU level
- case `grep '^cpu[^a-z]*:' /proc/cpuinfo 2>/dev/null | cut -d' ' -f2` in
- PA7*) echo hppa1.1-unknown-linux-gnu ;;
- PA8*) echo hppa2.0-unknown-linux-gnu ;;
- *) echo hppa-unknown-linux-gnu ;;
- esac
- exit ;;
- ppc64:Linux:*:*)
- echo powerpc64-unknown-linux-gnu
- exit ;;
- ppc:Linux:*:*)
- echo powerpc-unknown-linux-gnu
- exit ;;
- s390:Linux:*:* | s390x:Linux:*:*)
- echo ${UNAME_MACHINE}-ibm-linux
- exit ;;
- sh64*:Linux:*:*)
- exit ;;
- sh*:Linux:*:*)
- exit ;;
- sparc:Linux:*:* | sparc64:Linux:*:*)
- exit ;;
- tile*:Linux:*:*)
- exit ;;
- vax:Linux:*:*)
- echo ${UNAME_MACHINE}-dec-linux-gnu
- exit ;;
- x86_64:Linux:*:*)
- exit ;;
- xtensa*:Linux:*:*)
- exit ;;
- i*86:DYNIX/ptx:4*:*)
- # ptx 4.0 does uname -s correctly, with DYNIX/ptx in there.
- # earlier versions are messed up and put the nodename in both
- # sysname and nodename.
- echo i386-sequent-sysv4
- exit ;;
- i*86:UNIX_SV:4.2MP:2.*)
- # Unixware is an offshoot of SVR4, but it has its own version
- # number series starting with 2...
- # I am not positive that other SVR4 systems won't match this,
- # I just have to hope. -- rms.
- # Use sysv4.2uw... so that sysv4* matches it.
- echo ${UNAME_MACHINE}-pc-sysv4.2uw${UNAME_VERSION}
- exit ;;
- i*86:OS/2:*:*)
- # If we were able to find `uname', then EMX Unix compatibility
- # is probably installed.
- echo ${UNAME_MACHINE}-pc-os2-emx
- exit ;;
- i*86:XTS-300:*:STOP)
- echo ${UNAME_MACHINE}-unknown-stop
- exit ;;
- i*86:atheos:*:*)
- echo ${UNAME_MACHINE}-unknown-atheos
- exit ;;
- i*86:syllable:*:*)
- echo ${UNAME_MACHINE}-pc-syllable
- exit ;;
- i*86:LynxOS:2.*:* | i*86:LynxOS:3.[01]*:* | i*86:LynxOS:4.[02]*:*)
- echo i386-unknown-lynxos${UNAME_RELEASE}
- exit ;;
- i*86:*DOS:*:*)
- echo ${UNAME_MACHINE}-pc-msdosdjgpp
- exit ;;
- i*86:*:4.*:* | i*86:SYSTEM_V:4.*:*)
- UNAME_REL=`echo ${UNAME_RELEASE} | sed 's/\/MP$//'`
- if grep Novell /usr/include/link.h >/dev/null 2>/dev/null; then
- echo ${UNAME_MACHINE}-univel-sysv${UNAME_REL}
- else
- echo ${UNAME_MACHINE}-pc-sysv${UNAME_REL}
- fi
- exit ;;
- i*86:*:5:[678]*)
- # UnixWare 7.x, OpenUNIX and OpenServer 6.
- case `/bin/uname -X | grep "^Machine"` in
- *486*) UNAME_MACHINE=i486 ;;
- *Pentium) UNAME_MACHINE=i586 ;;
- *Pent*|*Celeron) UNAME_MACHINE=i686 ;;
- esac
- echo ${UNAME_MACHINE}-unknown-sysv${UNAME_RELEASE}${UNAME_SYSTEM}${UNAME_VERSION}
- exit ;;
- i*86:*:3.2:*)
- if test -f /usr/options/cb.name; then
- UNAME_REL=`sed -n 's/.*Version //p' </usr/options/cb.name`
- echo ${UNAME_MACHINE}-pc-isc$UNAME_REL
- elif /bin/uname -X 2>/dev/null >/dev/null ; then
- UNAME_REL=`(/bin/uname -X|grep Release|sed -e 's/.*= //')`
- (/bin/uname -X|grep i80486 >/dev/null) && UNAME_MACHINE=i486
- (/bin/uname -X|grep '^Machine.*Pentium' >/dev/null) \
- && UNAME_MACHINE=i586
- (/bin/uname -X|grep '^Machine.*Pent *II' >/dev/null) \
- && UNAME_MACHINE=i686
- (/bin/uname -X|grep '^Machine.*Pentium Pro' >/dev/null) \
- echo ${UNAME_MACHINE}-pc-sco$UNAME_REL
- else
- echo ${UNAME_MACHINE}-pc-sysv32
- fi
- exit ;;
- pc:*:*:*)
- # Left here for compatibility:
- # uname -m prints for DJGPP always 'pc', but it prints nothing about
- # the processor, so we play safe by assuming i586.
- # Note: whatever this is, it MUST be the same as what config.sub
- # prints for the "djgpp" host, or else GDB configury will decide that
- # this is a cross-build.
- echo i586-pc-msdosdjgpp
- exit ;;
- Intel:Mach:3*:*)
- echo i386-pc-mach3
- exit ;;
- paragon:*:*:*)
- echo i860-intel-osf1
- exit ;;
- i860:*:4.*:*) # i860-SVR4
- if grep Stardent /usr/include/sys/uadmin.h >/dev/null 2>&1 ; then
- echo i860-stardent-sysv${UNAME_RELEASE} # Stardent Vistra i860-SVR4
- else # Add other i860-SVR4 vendors below as they are discovered.
- echo i860-unknown-sysv${UNAME_RELEASE} # Unknown i860-SVR4
- fi
- exit ;;
- mini*:CTIX:SYS*5:*)
- # "miniframe"
- echo m68010-convergent-sysv
- exit ;;
- mc68k:UNIX:SYSTEM5:3.51m)
- echo m68k-convergent-sysv
- exit ;;
- M680?0:D-NIX:5.3:*)
- echo m68k-diab-dnix
- exit ;;
- M68*:*:R3V[5678]*:*)
- test -r /sysV68 && { echo 'm68k-motorola-sysv'; exit; } ;;
- 3[345]??:*:4.0:3.0 | 3[34]??A:*:4.0:3.0 | 3[34]??,*:*:4.0:3.0 | 3[34]??/*:*:4.0:3.0 | 4400:*:4.0:3.0 | 4850:*:4.0:3.0 | SKA40:*:4.0:3.0 | SDS2:*:4.0:3.0 | SHG2:*:4.0:3.0 | S7501*:*:4.0:3.0)
- OS_REL=''
- test -r /etc/.relid \
- && OS_REL=.`sed -n 's/[^ ]* [^ ]* \([0-9][0-9]\).*/\1/p' < /etc/.relid`
- /bin/uname -p 2>/dev/null | grep 86 >/dev/null \
- && { echo i486-ncr-sysv4.3${OS_REL}; exit; }
- /bin/uname -p 2>/dev/null | /bin/grep entium >/dev/null \
- && { echo i586-ncr-sysv4.3${OS_REL}; exit; } ;;
- 3[34]??:*:4.0:* | 3[34]??,*:*:4.0:*)
- && { echo i486-ncr-sysv4; exit; } ;;
- NCR*:*:4.2:* | MPRAS*:*:4.2:*)
- OS_REL='.3'
- /bin/uname -p 2>/dev/null | /bin/grep pteron >/dev/null \
- m68*:LynxOS:2.*:* | m68*:LynxOS:3.0*:*)
- echo m68k-unknown-lynxos${UNAME_RELEASE}
- exit ;;
- mc68030:UNIX_System_V:4.*:*)
- echo m68k-atari-sysv4
- exit ;;
- TSUNAMI:LynxOS:2.*:*)
- echo sparc-unknown-lynxos${UNAME_RELEASE}
- exit ;;
- rs6000:LynxOS:2.*:*)
- echo rs6000-unknown-lynxos${UNAME_RELEASE}
- exit ;;
- PowerPC:LynxOS:2.*:* | PowerPC:LynxOS:3.[01]*:* | PowerPC:LynxOS:4.[02]*:*)
- echo powerpc-unknown-lynxos${UNAME_RELEASE}
- exit ;;
- SM[BE]S:UNIX_SV:*:*)
- echo mips-dde-sysv${UNAME_RELEASE}
- exit ;;
- RM*:ReliantUNIX-*:*:*)
- echo mips-sni-sysv4
- exit ;;
- RM*:SINIX-*:*:*)
- exit ;;
- *:SINIX-*:*:*)
- if uname -p 2>/dev/null >/dev/null ; then
- UNAME_MACHINE=`(uname -p) 2>/dev/null`
- echo ${UNAME_MACHINE}-sni-sysv4
- else
- echo ns32k-sni-sysv
- fi
- exit ;;
- PENTIUM:*:4.0*:*) # Unisys `ClearPath HMP IX 4000' SVR4/MP effort
- # says <Richard.M.Bartel at ccMail.Census.GOV>
- echo i586-unisys-sysv4
- exit ;;
- *:UNIX_System_V:4*:FTX*)
- # From Gerald Hewes <hewes at openmarket.com>.
- # How about differentiating between stratus architectures? -djm
- echo hppa1.1-stratus-sysv4
- exit ;;
- *:*:*:FTX*)
- # From seanf at swdc.stratus.com.
- echo i860-stratus-sysv4
- exit ;;
- i*86:VOS:*:*)
- # From Paul.Green at stratus.com.
- echo ${UNAME_MACHINE}-stratus-vos
- exit ;;
- *:VOS:*:*)
- echo hppa1.1-stratus-vos
- exit ;;
- mc68*:A/UX:*:*)
- echo m68k-apple-aux${UNAME_RELEASE}
- exit ;;
- news*:NEWS-OS:6*:*)
- echo mips-sony-newsos6
- exit ;;
- R[34]000:*System_V*:*:* | R4000:UNIX_SYSV:*:* | R*000:UNIX_SV:*:*)
- if [ -d /usr/nec ]; then
- echo mips-nec-sysv${UNAME_RELEASE}
- else
- echo mips-unknown-sysv${UNAME_RELEASE}
- fi
- exit ;;
- BeBox:BeOS:*:*) # BeOS running on hardware made by Be, PPC only.
- echo powerpc-be-beos
- exit ;;
- BeMac:BeOS:*:*) # BeOS running on Mac or Mac clone, PPC only.
- echo powerpc-apple-beos
- exit ;;
- BePC:BeOS:*:*) # BeOS running on Intel PC compatible.
- echo i586-pc-beos
- exit ;;
- BePC:Haiku:*:*) # Haiku running on Intel PC compatible.
- echo i586-pc-haiku
- exit ;;
- SX-4:SUPER-UX:*:*)
- echo sx4-nec-superux${UNAME_RELEASE}
- exit ;;
- SX-5:SUPER-UX:*:*)
- echo sx5-nec-superux${UNAME_RELEASE}
- exit ;;
- SX-6:SUPER-UX:*:*)
- echo sx6-nec-superux${UNAME_RELEASE}
- exit ;;
- SX-7:SUPER-UX:*:*)
- echo sx7-nec-superux${UNAME_RELEASE}
- exit ;;
- SX-8:SUPER-UX:*:*)
- echo sx8-nec-superux${UNAME_RELEASE}
- exit ;;
- SX-8R:SUPER-UX:*:*)
- echo sx8r-nec-superux${UNAME_RELEASE}
- exit ;;
- Power*:Rhapsody:*:*)
- echo powerpc-apple-rhapsody${UNAME_RELEASE}
- exit ;;
- *:Rhapsody:*:*)
- echo ${UNAME_MACHINE}-apple-rhapsody${UNAME_RELEASE}
- exit ;;
- *:Darwin:*:*)
- UNAME_PROCESSOR=`uname -p` || UNAME_PROCESSOR=unknown
- case $UNAME_PROCESSOR in
- i386)
- if (echo '#ifdef __LP64__'; echo IS_64BIT_ARCH; echo '#endif') | \
- then
- UNAME_PROCESSOR="x86_64"
- fi
- fi ;;
- unknown) UNAME_PROCESSOR=powerpc ;;
- esac
- echo ${UNAME_PROCESSOR}-apple-darwin${UNAME_RELEASE}
- exit ;;
- *:procnto*:*:* | *:QNX:[0123456789]*:*)
- if test "$UNAME_PROCESSOR" = "x86"; then
- UNAME_PROCESSOR=i386
- UNAME_MACHINE=pc
- fi
- echo ${UNAME_PROCESSOR}-${UNAME_MACHINE}-nto-qnx${UNAME_RELEASE}
- exit ;;
- *:QNX:*:4*)
- echo i386-pc-qnx
- exit ;;
- NEO-?:NONSTOP_KERNEL:*:*)
- echo neo-tandem-nsk${UNAME_RELEASE}
- exit ;;
- NSE-?:NONSTOP_KERNEL:*:*)
- echo nse-tandem-nsk${UNAME_RELEASE}
- exit ;;
- NSR-?:NONSTOP_KERNEL:*:*)
- echo nsr-tandem-nsk${UNAME_RELEASE}
- exit ;;
- *:NonStop-UX:*:*)
- echo mips-compaq-nonstopux
- exit ;;
- BS2000:POSIX*:*:*)
- echo bs2000-siemens-sysv
- exit ;;
- DS/*:UNIX_System_V:*:*)
- echo ${UNAME_MACHINE}-${UNAME_SYSTEM}-${UNAME_RELEASE}
- exit ;;
- *:Plan9:*:*)
- # "uname -m" is not consistent, so use $cputype instead. 386
- # is converted to i386 for consistency with other x86
- # operating systems.
- if test "$cputype" = "386"; then
- UNAME_MACHINE=i386
- else
- UNAME_MACHINE="$cputype"
- fi
- echo ${UNAME_MACHINE}-unknown-plan9
- exit ;;
- *:TOPS-10:*:*)
- echo pdp10-unknown-tops10
- exit ;;
- *:TENEX:*:*)
- echo pdp10-unknown-tenex
- exit ;;
- KS10:TOPS-20:*:* | KL10:TOPS-20:*:* | TYPE4:TOPS-20:*:*)
- echo pdp10-dec-tops20
- exit ;;
- XKL-1:TOPS-20:*:* | TYPE5:TOPS-20:*:*)
- echo pdp10-xkl-tops20
- exit ;;
- *:TOPS-20:*:*)
- echo pdp10-unknown-tops20
- exit ;;
- *:ITS:*:*)
- echo pdp10-unknown-its
- exit ;;
- SEI:*:*:SEIUX)
- echo mips-sei-seiux${UNAME_RELEASE}
- exit ;;
- *:DragonFly:*:*)
- echo ${UNAME_MACHINE}-unknown-dragonfly`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`
- exit ;;
- *:*VMS:*:*)
- A*) echo alpha-dec-vms ; exit ;;
- I*) echo ia64-dec-vms ; exit ;;
- V*) echo vax-dec-vms ; exit ;;
- esac ;;
- *:XENIX:*:SysV)
- echo i386-pc-xenix
- exit ;;
- i*86:skyos:*:*)
- echo ${UNAME_MACHINE}-pc-skyos`echo ${UNAME_RELEASE}` | sed -e 's/ .*$//'
- exit ;;
- i*86:rdos:*:*)
- echo ${UNAME_MACHINE}-pc-rdos
- exit ;;
- i*86:AROS:*:*)
- echo ${UNAME_MACHINE}-pc-aros
- exit ;;
- x86_64:VMkernel:*:*)
- echo ${UNAME_MACHINE}-unknown-esx
- exit ;;
-esac
-#echo '(No uname command or uname output not recognized.)' 1>&2
-#echo "${UNAME_MACHINE}:${UNAME_SYSTEM}:${UNAME_RELEASE}:${UNAME_VERSION}" 1>&2
-eval $set_cc_for_build
-cat >$dummy.c <<EOF
-#ifdef _SEQUENT_
-# include <sys/types.h>
-# include <sys/utsname.h>
-#endif
-main ()
-#if defined (sony)
-#if defined (MIPSEB)
- /* BFD wants "bsd" instead of "newsos". Perhaps BFD should be changed,
- I don't know.... */
- printf ("mips-sony-bsd\n"); exit (0);
-#else
-#include <sys/param.h>
- printf ("m68k-sony-newsos%s\n",
-#ifdef NEWSOS4
- "4"
-#else
-#endif
- ); exit (0);
-#endif
-#endif
-#if defined (__arm) && defined (__acorn) && defined (__unix)
- printf ("arm-acorn-riscix\n"); exit (0);
-#endif
-#if defined (hp300) && !defined (hpux)
- printf ("m68k-hp-bsd\n"); exit (0);
-#endif
-#if defined (NeXT)
-#if !defined (__ARCHITECTURE__)
-#define __ARCHITECTURE__ "m68k"
-#endif
- int version;
- version=`(hostinfo | sed -n 's/.*NeXT Mach \([0-9]*\).*/\1/p') 2>/dev/null`;
- if (version < 4)
- printf ("%s-next-nextstep%d\n", __ARCHITECTURE__, version);
- else
- printf ("%s-next-openstep%d\n", __ARCHITECTURE__, version);
- exit (0);
-#endif
-#if defined (MULTIMAX) || defined (n16)
-#if defined (UMAXV)
- printf ("ns32k-encore-sysv\n"); exit (0);
-#else
-#if defined (CMU)
- printf ("ns32k-encore-mach\n"); exit (0);
-#else
- printf ("ns32k-encore-bsd\n"); exit (0);
-#endif
-#endif
-#endif
-#if defined (__386BSD__)
- printf ("i386-pc-bsd\n"); exit (0);
-#endif
-#if defined (sequent)
-#if defined (i386)
- printf ("i386-sequent-dynix\n"); exit (0);
-#endif
-#if defined (ns32000)
- printf ("ns32k-sequent-dynix\n"); exit (0);
-#endif
-#endif
-#if defined (_SEQUENT_)
- struct utsname un;
- uname(&un);
- if (strncmp(un.version, "V2", 2) == 0) {
- printf ("i386-sequent-ptx2\n"); exit (0);
- if (strncmp(un.version, "V1", 2) == 0) { /* XXX is V1 correct? */
- printf ("i386-sequent-ptx1\n"); exit (0);
- printf ("i386-sequent-ptx\n"); exit (0);
-#endif
-#if defined (vax)
-# if !defined (ultrix)
-# include <sys/param.h>
-# if defined (BSD)
-# if BSD == 43
- printf ("vax-dec-bsd4.3\n"); exit (0);
-# else
-# if BSD == 199006
- printf ("vax-dec-bsd4.3reno\n"); exit (0);
-# else
- printf ("vax-dec-bsd\n"); exit (0);
-# endif
-# endif
-# else
-# endif
-# else
- printf ("vax-dec-ultrix\n"); exit (0);
-# endif
-#endif
-#if defined (alliant) && defined (i860)
- printf ("i860-alliant-bsd\n"); exit (0);
-#endif
- exit (1);
-EOF
-$CC_FOR_BUILD -o $dummy $dummy.c 2>/dev/null && SYSTEM_NAME=`$dummy` &&
-# Apollos put the system type in the environment.
-test -d /usr/apollo && { echo ${ISP}-apollo-${SYSTYPE}; exit; }
-# Convex versions that predate uname can use getsysinfo(1)
-if [ -x /usr/convex/getsysinfo ]
-then
- case `getsysinfo -f cpu_type` in
- c1*)
- exit ;;
- c2*)
- fi
- exit ;;
- c34*)
- exit ;;
- c38*)
- exit ;;
- c4*)
- exit ;;
- esac
-fi
-cat >&2 <<EOF
-$0: unable to guess system type
-This script, last modified $timestamp, has failed to recognize
-the operating system you are using. It is advised that you
-download the most up to date version of the config scripts from
- http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess;hb=HEAD
-and
- http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub;hb=HEAD
-If the version you run ($0) is already up to date, please
-send the following data and any information you think might be
-pertinent to <config-patches at gnu.org> in order to provide the needed
-information to handle your system.
-config.guess timestamp = $timestamp
-uname -m = `(uname -m) 2>/dev/null || echo unknown`
-uname -r = `(uname -r) 2>/dev/null || echo unknown`
-uname -s = `(uname -s) 2>/dev/null || echo unknown`
-uname -v = `(uname -v) 2>/dev/null || echo unknown`
-/usr/bin/uname -p = `(/usr/bin/uname -p) 2>/dev/null`
-/bin/uname -X = `(/bin/uname -X) 2>/dev/null`
-hostinfo = `(hostinfo) 2>/dev/null`
-/bin/universe = `(/bin/universe) 2>/dev/null`
-/usr/bin/arch -k = `(/usr/bin/arch -k) 2>/dev/null`
-/bin/arch = `(/bin/arch) 2>/dev/null`
-/usr/bin/oslevel = `(/usr/bin/oslevel) 2>/dev/null`
-/usr/convex/getsysinfo = `(/usr/convex/getsysinfo) 2>/dev/null`
-UNAME_MACHINE = ${UNAME_MACHINE}
-UNAME_RELEASE = ${UNAME_RELEASE}
-UNAME_SYSTEM = ${UNAME_SYSTEM}
-UNAME_VERSION = ${UNAME_VERSION}
-EOF
-exit 1
-# Local variables:
-# eval: (add-hook 'write-file-hooks 'time-stamp)
-# time-stamp-start: "timestamp='"
-# time-stamp-format: "%:y-%02m-%02d"
-# time-stamp-end: "'"
-# End:
Index: modules/provider-coaster-c-client/config/config.sub
--- modules/provider-coaster-c-client/config/config.sub (revision 3826)
+++ modules/provider-coaster-c-client/config/config.sub (working copy)
@@ -1,1773 +0,0 @@
-#! /bin/sh
-# Configuration validation subroutine script.
-# This file is (in principle) common to ALL GNU software.
-# The presence of a machine in this file suggests that SOME GNU software
-# can handle that machine. It does not imply ALL GNU software can.
-# it under the terms of the GNU General Public License as published by
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# GNU General Public License for more details.
-# Please send patches to <config-patches at gnu.org>. Submit a context
-# diff and a properly formatted GNU ChangeLog entry.
-# Configuration subroutine to validate and canonicalize a configuration type.
-# Supply the specified configuration type as an argument.
-# If it is invalid, we print an error message on stderr and exit with code 1.
-# Otherwise, we print the canonical config type on stdout and succeed.
-# http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub;hb=HEAD
-# This file is supposed to be the same for all GNU packages
-# and recognize all the CPU types, system types and aliases
-# that are meaningful with *any* GNU software.
-# Each package is responsible for reporting which valid configurations
-# it does not support. The user should be able to distinguish
-# a failure to support a valid configuration from a meaningless
-# configuration.
-# The goal of this file is to map all the various variations of a given
-# machine specification into a single specification in the form:
-# CPU_TYPE-MANUFACTURER-OPERATING_SYSTEM
-# or in some cases, the newer four-part form:
-# CPU_TYPE-MANUFACTURER-KERNEL-OPERATING_SYSTEM
-# It is wrong to echo any other type of specification.
-usage="\
-Usage: $0 [OPTION] CPU-MFR-OPSYS
- $0 [OPTION] ALIAS
-Canonicalize a configuration name.
-Operation modes:
-version="\
-GNU config.sub ($timestamp)
-help="
- case $1 in
- --version | -v )
- shift; break ;;
- break ;;
- exit 1 ;;
- *local*)
- # First pass through any local machine types.
- echo $1
- exit ;;
- break ;;
- esac
-done
-case $# in
- 0) echo "$me: missing argument$help" >&2
- exit 1;;
- 1) ;;
- *) echo "$me: too many arguments$help" >&2
- exit 1;;
-esac
-# Separate what the user gave into CPU-COMPANY and OS or KERNEL-OS (if any).
-# Here we must recognize all the valid KERNEL-OS combinations.
-maybe_os=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\2/'`
-case $maybe_os in
- nto-qnx* | linux-gnu* | linux-android* | linux-dietlibc | linux-newlib* | \
- linux-uclibc* | uclinux-uclibc* | uclinux-gnu* | kfreebsd*-gnu* | \
- knetbsd*-gnu* | netbsd*-gnu* | \
- kopensolaris*-gnu* | \
- storm-chaos* | os2-emx* | rtmk-nova*)
- os=-$maybe_os
- basic_machine=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\1/'`
- android-linux)
- os=-linux-android
- basic_machine=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\1/'`-unknown
- basic_machine=`echo $1 | sed 's/-[^-]*$//'`
- if [ $basic_machine != $1 ]
- then os=`echo $1 | sed 's/.*-/-/'`
- else os=; fi
-esac
-### Let's recognize common machines as not being operating systems so
-### that things like config.sub decstation-3100 work. We also
-### recognize some manufacturers as not being operating systems, so we
-### can provide default operating systems below.
-case $os in
- -sun*os*)
- # Prevent following clause from handling this invalid input.
- -dec* | -mips* | -sequent* | -encore* | -pc532* | -sgi* | -sony* | \
- -att* | -7300* | -3300* | -delta* | -motorola* | -sun[234]* | \
- -unicom* | -ibm* | -next | -hp | -isi* | -apollo | -altos* | \
- -convergent* | -ncr* | -news | -32* | -3600* | -3100* | -hitachi* |\
- -c[123]* | -convex* | -sun | -crds | -omron* | -dg | -ultra | -tti* | \
- -harris | -dolphin | -highlevel | -gould | -cbm | -ns | -masscomp | \
- -apple | -axis | -knuth | -cray | -microblaze)
- os=
- basic_machine=$1
- -bluegene*)
- os=-cnk
- -sim | -cisco | -oki | -wec | -winbond)
- os=
- basic_machine=$1
- -scout)
- -wrs)
- os=-vxworks
- basic_machine=$1
- -chorusos*)
- os=-chorusos
- basic_machine=$1
- -chorusrdb)
- os=-chorusrdb
- basic_machine=$1
- -hiux*)
- os=-hiuxwe2
- -sco6)
- os=-sco5v6
- basic_machine=`echo $1 | sed -e 's/86-.*/86-pc/'`
- -sco5)
- os=-sco3.2v5
- -sco4)
- os=-sco3.2v4
- -sco3.2.[4-9]*)
- os=`echo $os | sed -e 's/sco3.2./sco3.2v/'`
- -sco3.2v[4-9]*)
- # Don't forget version if it is 3.2v4 or newer.
- -sco5v6*)
- -sco*)
- os=-sco3.2v2
- -udk*)
- -isc)
- os=-isc2.2
- -clix*)
- basic_machine=clipper-intergraph
- -isc*)
- -lynx*)
- os=-lynxos
- -ptx*)
- basic_machine=`echo $1 | sed -e 's/86-.*/86-sequent/'`
- -windowsnt*)
- os=`echo $os | sed -e 's/windowsnt/winnt/'`
- -psos*)
- os=-psos
- -mint | -mint[0-9]*)
- basic_machine=m68k-atari
- os=-mint
-esac
-# Decode aliases for certain CPU-COMPANY combinations.
-case $basic_machine in
- # Recognize the basic CPU types without company name.
- # Some are omitted here because they have special meanings below.
- 1750a | 580 \
- | a29k \
- | aarch64 | aarch64_be \
- | alpha | alphaev[4-8] | alphaev56 | alphaev6[78] | alphapca5[67] \
- | alpha64 | alpha64ev[4-8] | alpha64ev56 | alpha64ev6[78] | alpha64pca5[67] \
- | am33_2.0 \
- | arc | arm | arm[bl]e | arme[lb] | armv[2345] | armv[345][lb] | avr | avr32 \
- | be32 | be64 \
- | bfin \
- | c4x | clipper \
- | d10v | d30v | dlx | dsp16xx \
- | epiphany \
- | fido | fr30 | frv \
- | h8300 | h8500 | hppa | hppa1.[01] | hppa2.0 | hppa2.0[nw] | hppa64 \
- | hexagon \
- | i370 | i860 | i960 | ia64 \
- | ip2k | iq2000 \
- | le32 | le64 \
- | lm32 \
- | m32c | m32r | m32rle | m68000 | m68k | m88k \
- | maxq | mb | microblaze | mcore | mep | metag \
- | mips | mipsbe | mipseb | mipsel | mipsle \
- | mips16 \
- | mips64 | mips64el \
- | mips64octeon | mips64octeonel \
- | mips64orion | mips64orionel \
- | mips64r5900 | mips64r5900el \
- | mips64vr | mips64vrel \
- | mips64vr4100 | mips64vr4100el \
- | mips64vr4300 | mips64vr4300el \
- | mips64vr5000 | mips64vr5000el \
- | mips64vr5900 | mips64vr5900el \
- | mipsisa32 | mipsisa32el \
- | mipsisa32r2 | mipsisa32r2el \
- | mipsisa64 | mipsisa64el \
- | mipsisa64r2 | mipsisa64r2el \
- | mipsisa64sb1 | mipsisa64sb1el \
- | mipsisa64sr71k | mipsisa64sr71kel \
- | mipstx39 | mipstx39el \
- | mn10200 | mn10300 \
- | moxie \
- | mt \
- | msp430 \
- | nds32 | nds32le | nds32be \
- | nios | nios2 \
- | ns16k | ns32k \
- | open8 \
- | or32 \
- | pdp10 | pdp11 | pj | pjl \
- | powerpc | powerpc64 | powerpc64le | powerpcle \
- | pyramid \
- | rl78 | rx \
- | score \
- | sh | sh[1234] | sh[24]a | sh[24]aeb | sh[23]e | sh[34]eb | sheb | shbe | shle | sh[1234]le | sh3ele \
- | sh64 | sh64le \
- | sparc | sparc64 | sparc64b | sparc64v | sparc86x | sparclet | sparclite \
- | sparcv8 | sparcv9 | sparcv9b | sparcv9v \
- | spu \
- | tahoe | tic4x | tic54x | tic55x | tic6x | tic80 | tron \
- | ubicom32 \
- | v850 | v850e | v850e1 | v850e2 | v850es | v850e2v3 \
- | we32k \
- | x86 | xc16x | xstormy16 | xtensa \
- | z8k | z80)
- basic_machine=$basic_machine-unknown
- c54x)
- basic_machine=tic54x-unknown
- c55x)
- basic_machine=tic55x-unknown
- c6x)
- basic_machine=tic6x-unknown
- m6811 | m68hc11 | m6812 | m68hc12 | m68hcs12x | picochip)
- os=-none
- m88110 | m680[12346]0 | m683?2 | m68360 | m5200 | v70 | w65 | z8k)
- ms1)
- basic_machine=mt-unknown
- strongarm | thumb | xscale)
- basic_machine=arm-unknown
- xgate)
- os=-none
- xscaleeb)
- basic_machine=armeb-unknown
- xscaleel)
- basic_machine=armel-unknown
- # We use `pc' rather than `unknown'
- # because (1) that's what they normally are, and
- # (2) the word "unknown" tends to confuse beginning users.
- i*86 | x86_64)
- basic_machine=$basic_machine-pc
- # Object if more than one company name word.
- echo Invalid configuration \`$1\': machine \`$basic_machine\' not recognized 1>&2
- exit 1
- # Recognize the basic CPU types with company name.
- 580-* \
- | a29k-* \
- | aarch64-* | aarch64_be-* \
- | alpha-* | alphaev[4-8]-* | alphaev56-* | alphaev6[78]-* \
- | alpha64-* | alpha64ev[4-8]-* | alpha64ev56-* | alpha64ev6[78]-* \
- | alphapca5[67]-* | alpha64pca5[67]-* | arc-* \
- | arm-* | armbe-* | armle-* | armeb-* | armv*-* \
- | avr-* | avr32-* \
- | be32-* | be64-* \
- | bfin-* | bs2000-* \
- | c[123]* | c30-* | [cjt]90-* | c4x-* \
- | clipper-* | craynv-* | cydra-* \
- | d10v-* | d30v-* | dlx-* \
- | elxsi-* \
- | f30[01]-* | f700-* | fido-* | fr30-* | frv-* | fx80-* \
- | h8300-* | h8500-* \
- | hppa-* | hppa1.[01]-* | hppa2.0-* | hppa2.0[nw]-* | hppa64-* \
- | hexagon-* \
- | i*86-* | i860-* | i960-* | ia64-* \
- | ip2k-* | iq2000-* \
- | le32-* | le64-* \
- | lm32-* \
- | m32c-* | m32r-* | m32rle-* \
- | m68000-* | m680[012346]0-* | m68360-* | m683?2-* | m68k-* \
- | m88110-* | m88k-* | maxq-* | mcore-* | metag-* | microblaze-* \
- | mips-* | mipsbe-* | mipseb-* | mipsel-* | mipsle-* \
- | mips16-* \
- | mips64-* | mips64el-* \
- | mips64octeon-* | mips64octeonel-* \
- | mips64orion-* | mips64orionel-* \
- | mips64r5900-* | mips64r5900el-* \
- | mips64vr-* | mips64vrel-* \
- | mips64vr4100-* | mips64vr4100el-* \
- | mips64vr4300-* | mips64vr4300el-* \
- | mips64vr5000-* | mips64vr5000el-* \
- | mips64vr5900-* | mips64vr5900el-* \
- | mipsisa32-* | mipsisa32el-* \
- | mipsisa32r2-* | mipsisa32r2el-* \
- | mipsisa64-* | mipsisa64el-* \
- | mipsisa64r2-* | mipsisa64r2el-* \
- | mipsisa64sb1-* | mipsisa64sb1el-* \
- | mipsisa64sr71k-* | mipsisa64sr71kel-* \
- | mipstx39-* | mipstx39el-* \
- | mmix-* \
- | mt-* \
- | msp430-* \
- | nds32-* | nds32le-* | nds32be-* \
- | nios-* | nios2-* \
- | none-* | np1-* | ns16k-* | ns32k-* \
- | open8-* \
- | orion-* \
- | pdp10-* | pdp11-* | pj-* | pjl-* | pn-* | power-* \
- | powerpc-* | powerpc64-* | powerpc64le-* | powerpcle-* \
- | pyramid-* \
- | rl78-* | romp-* | rs6000-* | rx-* \
- | sh-* | sh[1234]-* | sh[24]a-* | sh[24]aeb-* | sh[23]e-* | sh[34]eb-* | sheb-* | shbe-* \
- | shle-* | sh[1234]le-* | sh3ele-* | sh64-* | sh64le-* \
- | sparc-* | sparc64-* | sparc64b-* | sparc64v-* | sparc86x-* | sparclet-* \
- | sparclite-* \
- | sparcv8-* | sparcv9-* | sparcv9b-* | sparcv9v-* | sv1-* | sx?-* \
- | tahoe-* \
- | tic30-* | tic4x-* | tic54x-* | tic55x-* | tic6x-* | tic80-* \
- | tile*-* \
- | tron-* \
- | ubicom32-* \
- | v850-* | v850e-* | v850e1-* | v850es-* | v850e2-* | v850e2v3-* \
- | vax-* \
- | we32k-* \
- | x86-* | x86_64-* | xc16x-* | xps100-* \
- | xstormy16-* | xtensa*-* \
- | ymp-* \
- | z8k-* | z80-*)
- # Recognize the basic CPU types without company name, with glob match.
- xtensa*)
- # Recognize the various machine names and aliases which stand
- # for a CPU type and a company and sometimes even an OS.
- 386bsd)
- basic_machine=i386-unknown
- os=-bsd
- 3b1 | 7300 | 7300-att | att-7300 | pc7300 | safari | unixpc)
- basic_machine=m68000-att
- 3b*)
- basic_machine=we32k-att
- a29khif)
- basic_machine=a29k-amd
- os=-udi
- abacus)
- basic_machine=abacus-unknown
- adobe68k)
- basic_machine=m68010-adobe
- os=-scout
- alliant | fx80)
- basic_machine=fx80-alliant
- altos | altos3068)
- basic_machine=m68k-altos
- am29k)
- basic_machine=a29k-none
- os=-bsd
- amd64)
- basic_machine=x86_64-pc
- amd64-*)
- basic_machine=x86_64-`echo $basic_machine | sed 's/^[^-]*-//'`
- amdahl)
- basic_machine=580-amdahl
- os=-sysv
- amiga | amiga-*)
- basic_machine=m68k-unknown
- amigaos | amigados)
- os=-amigaos
- amigaunix | amix)
- os=-sysv4
- apollo68)
- basic_machine=m68k-apollo
- os=-sysv
- apollo68bsd)
- os=-bsd
- aros)
- basic_machine=i386-pc
- os=-aros
- aux)
- basic_machine=m68k-apple
- os=-aux
- balance)
- basic_machine=ns32k-sequent
- os=-dynix
- blackfin)
- basic_machine=bfin-unknown
- os=-linux
- blackfin-*)
- basic_machine=bfin-`echo $basic_machine | sed 's/^[^-]*-//'`
- os=-linux
- bluegene*)
- basic_machine=powerpc-ibm
- os=-cnk
- c54x-*)
- basic_machine=tic54x-`echo $basic_machine | sed 's/^[^-]*-//'`
- c55x-*)
- basic_machine=tic55x-`echo $basic_machine | sed 's/^[^-]*-//'`
- c6x-*)
- basic_machine=tic6x-`echo $basic_machine | sed 's/^[^-]*-//'`
- c90)
- basic_machine=c90-cray
- os=-unicos
- cegcc)
- os=-cegcc
- convex-c1)
- basic_machine=c1-convex
- os=-bsd
- convex-c2)
- basic_machine=c2-convex
- os=-bsd
- convex-c32)
- basic_machine=c32-convex
- os=-bsd
- convex-c34)
- basic_machine=c34-convex
- os=-bsd
- convex-c38)
- basic_machine=c38-convex
- os=-bsd
- cray | j90)
- basic_machine=j90-cray
- os=-unicos
- craynv)
- basic_machine=craynv-cray
- os=-unicosmp
- cr16 | cr16-*)
- basic_machine=cr16-unknown
- os=-elf
- crds | unos)
- basic_machine=m68k-crds
- crisv32 | crisv32-* | etraxfs*)
- basic_machine=crisv32-axis
- cris | cris-* | etrax*)
- basic_machine=cris-axis
- crx)
- basic_machine=crx-unknown
- os=-elf
- da30 | da30-*)
- basic_machine=m68k-da30
- decstation | decstation-3100 | pmax | pmax-* | pmin | dec3100 | decstatn)
- basic_machine=mips-dec
- decsystem10* | dec10*)
- basic_machine=pdp10-dec
- os=-tops10
- decsystem20* | dec20*)
- os=-tops20
- delta | 3300 | motorola-3300 | motorola-delta \
- | 3300-motorola | delta-motorola)
- basic_machine=m68k-motorola
- delta88)
- basic_machine=m88k-motorola
- os=-sysv3
- dicos)
- basic_machine=i686-pc
- os=-dicos
- djgpp)
- basic_machine=i586-pc
- os=-msdosdjgpp
- dpx20 | dpx20-*)
- basic_machine=rs6000-bull
- os=-bosx
- dpx2* | dpx2*-bull)
- basic_machine=m68k-bull
- os=-sysv3
- ebmon29k)
- os=-ebmon
- elxsi)
- basic_machine=elxsi-elxsi
- os=-bsd
- encore | umax | mmax)
- basic_machine=ns32k-encore
- es1800 | OSE68k | ose68k | ose | OSE)
- basic_machine=m68k-ericsson
- os=-ose
- fx2800)
- basic_machine=i860-alliant
- genix)
- basic_machine=ns32k-ns
- gmicro)
- basic_machine=tron-gmicro
- os=-sysv
- go32)
- os=-go32
- h3050r* | hiux*)
- basic_machine=hppa1.1-hitachi
- os=-hiuxwe2
- h8300hms)
- basic_machine=h8300-hitachi
- os=-hms
- h8300xray)
- os=-xray
- h8500hms)
- basic_machine=h8500-hitachi
- os=-hms
- harris)
- basic_machine=m88k-harris
- os=-sysv3
- hp300-*)
- basic_machine=m68k-hp
- hp300bsd)
- os=-bsd
- hp300hpux)
- os=-hpux
- hp3k9[0-9][0-9] | hp9[0-9][0-9])
- basic_machine=hppa1.0-hp
- hp9k2[0-9][0-9] | hp9k31[0-9])
- basic_machine=m68000-hp
- hp9k3[2-9][0-9])
- hp9k6[0-9][0-9] | hp6[0-9][0-9])
- hp9k7[0-79][0-9] | hp7[0-79][0-9])
- basic_machine=hppa1.1-hp
- hp9k78[0-9] | hp78[0-9])
- # FIXME: really hppa2.0-hp
- hp9k8[67]1 | hp8[67]1 | hp9k80[24] | hp80[24] | hp9k8[78]9 | hp8[78]9 | hp9k893 | hp893)
- hp9k8[0-9][13679] | hp8[0-9][13679])
- hp9k8[0-9][0-9] | hp8[0-9][0-9])
- hppa-next)
- os=-nextstep3
- hppaosf)
- os=-osf
- hppro)
- os=-proelf
- i370-ibm* | ibm*)
- basic_machine=i370-ibm
- i*86v32)
- basic_machine=`echo $1 | sed -e 's/86.*/86-pc/'`
- os=-sysv32
- i*86v4*)
- os=-sysv4
- i*86v)
- os=-sysv
- i*86sol2)
- os=-solaris2
- i386mach)
- basic_machine=i386-mach
- os=-mach
- i386-vsta | vsta)
- os=-vsta
- iris | iris4d)
- basic_machine=mips-sgi
- case $os in
- -irix*)
- os=-irix4
- esac
- isi68 | isi)
- basic_machine=m68k-isi
- os=-sysv
- m68knommu)
- os=-linux
- m68knommu-*)
- basic_machine=m68k-`echo $basic_machine | sed 's/^[^-]*-//'`
- os=-linux
- m88k-omron*)
- basic_machine=m88k-omron
- magnum | m3230)
- basic_machine=mips-mips
- os=-sysv
- merlin)
- basic_machine=ns32k-utek
- os=-sysv
- microblaze)
- basic_machine=microblaze-xilinx
- mingw32)
- os=-mingw32
- mingw32ce)
- os=-mingw32ce
- miniframe)
- basic_machine=m68000-convergent
- *mint | -mint[0-9]* | *MiNT | *MiNT[0-9]*)
- os=-mint
- mips3*-*)
- basic_machine=`echo $basic_machine | sed -e 's/mips3/mips64/'`
- mips3*)
- basic_machine=`echo $basic_machine | sed -e 's/mips3/mips64/'`-unknown
- monitor)
- basic_machine=m68k-rom68k
- os=-coff
- morphos)
- basic_machine=powerpc-unknown
- os=-morphos
- msdos)
- os=-msdos
- ms1-*)
- basic_machine=`echo $basic_machine | sed -e 's/ms1-/mt-/'`
- msys)
- os=-msys
- mvs)
- os=-mvs
- nacl)
- basic_machine=le32-unknown
- os=-nacl
- ncr3000)
- basic_machine=i486-ncr
- os=-sysv4
- netbsd386)
- os=-netbsd
- netwinder)
- basic_machine=armv4l-rebel
- os=-linux
- news | news700 | news800 | news900)
- basic_machine=m68k-sony
- os=-newsos
- news1000)
- basic_machine=m68030-sony
- os=-newsos
- news-3600 | risc-news)
- basic_machine=mips-sony
- os=-newsos
- necv70)
- basic_machine=v70-nec
- os=-sysv
- next | m*-next )
- basic_machine=m68k-next
- case $os in
- -nextstep* )
- -ns2*)
- os=-nextstep2
- os=-nextstep3
- esac
- nh3000)
- basic_machine=m68k-harris
- os=-cxux
- nh[45]000)
- os=-cxux
- nindy960)
- basic_machine=i960-intel
- os=-nindy
- mon960)
- os=-mon960
- nonstopux)
- basic_machine=mips-compaq
- os=-nonstopux
- np1)
- basic_machine=np1-gould
- neo-tandem)
- basic_machine=neo-tandem
- nse-tandem)
- basic_machine=nse-tandem
- nsr-tandem)
- basic_machine=nsr-tandem
- op50n-* | op60c-*)
- basic_machine=hppa1.1-oki
- os=-proelf
- openrisc | openrisc-*)
- basic_machine=or32-unknown
- os400)
- os=-os400
- OSE68000 | ose68000)
- basic_machine=m68000-ericsson
- os=-ose
- os68k)
- basic_machine=m68k-none
- os=-os68k
- pa-hitachi)
- os=-hiuxwe2
- paragon)
- basic_machine=i860-intel
- os=-osf
- parisc)
- basic_machine=hppa-unknown
- os=-linux
- parisc-*)
- basic_machine=hppa-`echo $basic_machine | sed 's/^[^-]*-//'`
- os=-linux
- pbd)
- basic_machine=sparc-tti
- pbb)
- basic_machine=m68k-tti
- pc532 | pc532-*)
- basic_machine=ns32k-pc532
- pc98)
- pc98-*)
- basic_machine=i386-`echo $basic_machine | sed 's/^[^-]*-//'`
- pentium | p5 | k5 | k6 | nexgen | viac3)
- pentiumpro | p6 | 6x86 | athlon | athlon_*)
- pentiumii | pentium2 | pentiumiii | pentium3)
- pentium4)
- basic_machine=i786-pc
- pentium-* | p5-* | k5-* | k6-* | nexgen-* | viac3-*)
- basic_machine=i586-`echo $basic_machine | sed 's/^[^-]*-//'`
- pentiumpro-* | p6-* | 6x86-* | athlon-*)
- basic_machine=i686-`echo $basic_machine | sed 's/^[^-]*-//'`
- pentiumii-* | pentium2-* | pentiumiii-* | pentium3-*)
- pentium4-*)
- basic_machine=i786-`echo $basic_machine | sed 's/^[^-]*-//'`
- pn)
- basic_machine=pn-gould
- power) basic_machine=power-ibm
- ppc | ppcbe) basic_machine=powerpc-unknown
- ppc-* | ppcbe-*)
- basic_machine=powerpc-`echo $basic_machine | sed 's/^[^-]*-//'`
- ppcle | powerpclittle | ppc-le | powerpc-little)
- basic_machine=powerpcle-unknown
- ppcle-* | powerpclittle-*)
- basic_machine=powerpcle-`echo $basic_machine | sed 's/^[^-]*-//'`
- ppc64) basic_machine=powerpc64-unknown
- ppc64-*) basic_machine=powerpc64-`echo $basic_machine | sed 's/^[^-]*-//'`
- ppc64le | powerpc64little | ppc64-le | powerpc64-little)
- basic_machine=powerpc64le-unknown
- ppc64le-* | powerpc64little-*)
- basic_machine=powerpc64le-`echo $basic_machine | sed 's/^[^-]*-//'`
- ps2)
- basic_machine=i386-ibm
- pw32)
- basic_machine=i586-unknown
- os=-pw32
- rdos)
- os=-rdos
- rom68k)
- os=-coff
- rm[46]00)
- basic_machine=mips-siemens
- rtpc | rtpc-*)
- basic_machine=romp-ibm
- s390 | s390-*)
- basic_machine=s390-ibm
- s390x | s390x-*)
- basic_machine=s390x-ibm
- sa29200)
- os=-udi
- sb1)
- basic_machine=mipsisa64sb1-unknown
- sb1el)
- basic_machine=mipsisa64sb1el-unknown
- sde)
- basic_machine=mipsisa32-sde
- os=-elf
- sei)
- basic_machine=mips-sei
- os=-seiux
- sequent)
- basic_machine=i386-sequent
- sh)
- basic_machine=sh-hitachi
- os=-hms
- sh5el)
- basic_machine=sh5le-unknown
- sh64)
- basic_machine=sh64-unknown
- sparclite-wrs | simso-wrs)
- basic_machine=sparclite-wrs
- os=-vxworks
- sps7)
- os=-sysv2
- spur)
- basic_machine=spur-unknown
- st2000)
- basic_machine=m68k-tandem
- stratus)
- basic_machine=i860-stratus
- os=-sysv4
- strongarm-* | thumb-*)
- basic_machine=arm-`echo $basic_machine | sed 's/^[^-]*-//'`
- sun2)
- basic_machine=m68000-sun
- sun2os3)
- os=-sunos3
- sun2os4)
- os=-sunos4
- sun3os3)
- basic_machine=m68k-sun
- os=-sunos3
- sun3os4)
- os=-sunos4
- sun4os3)
- basic_machine=sparc-sun
- os=-sunos3
- sun4os4)
- os=-sunos4
- sun4sol2)
- os=-solaris2
- sun3 | sun3-*)
- sun4)
- sun386 | sun386i | roadrunner)
- basic_machine=i386-sun
- sv1)
- basic_machine=sv1-cray
- os=-unicos
- symmetry)
- os=-dynix
- t3e)
- basic_machine=alphaev5-cray
- os=-unicos
- t90)
- basic_machine=t90-cray
- os=-unicos
- tile*)
- os=-linux-gnu
- tx39)
- basic_machine=mipstx39-unknown
- tx39el)
- basic_machine=mipstx39el-unknown
- toad1)
- basic_machine=pdp10-xkl
- os=-tops20
- tower | tower-32)
- basic_machine=m68k-ncr
- tpf)
- os=-tpf
- udi29k)
- os=-udi
- ultra3)
- basic_machine=a29k-nyu
- os=-sym1
- v810 | necv810)
- basic_machine=v810-nec
- os=-none
- vaxv)
- basic_machine=vax-dec
- os=-sysv
- vms)
- os=-vms
- vpp*|vx|vx-*)
- basic_machine=f301-fujitsu
- vxworks960)
- basic_machine=i960-wrs
- os=-vxworks
- vxworks68)
- basic_machine=m68k-wrs
- os=-vxworks
- vxworks29k)
- basic_machine=a29k-wrs
- os=-vxworks
- w65*)
- basic_machine=w65-wdc
- os=-none
- w89k-*)
- basic_machine=hppa1.1-winbond
- os=-proelf
- xbox)
- os=-mingw32
- xps | xps100)
- basic_machine=xps100-honeywell
- xscale-* | xscalee[bl]-*)
- basic_machine=`echo $basic_machine | sed 's/^xscale/arm/'`
- ymp)
- basic_machine=ymp-cray
- os=-unicos
- z8k-*-coff)
- basic_machine=z8k-unknown
- os=-sim
- z80-*-coff)
- basic_machine=z80-unknown
- os=-sim
- none)
- basic_machine=none-none
- os=-none
-# Here we handle the default manufacturer of certain CPU types. It is in
-# some cases the only manufacturer, in others, it is the most popular.
- w89k)
- op50n)
- op60c)
- romp)
- mmix)
- basic_machine=mmix-knuth
- rs6000)
- basic_machine=rs6000-ibm
- vax)
- pdp10)
- # there are many clones, so DEC is not a safe bet
- basic_machine=pdp10-unknown
- pdp11)
- basic_machine=pdp11-dec
- we32k)
- sh[1234] | sh[24]a | sh[24]aeb | sh[34]eb | sh[1234]le | sh[23]ele)
- basic_machine=sh-unknown
- sparc | sparcv8 | sparcv9 | sparcv9b | sparcv9v)
- cydra)
- basic_machine=cydra-cydrome
- orion)
- basic_machine=orion-highlevel
- orion105)
- basic_machine=clipper-highlevel
- mac | mpw | mac-mpw)
- pmac | pmac-mpw)
- basic_machine=powerpc-apple
- *-unknown)
- # Make sure to match an already-canonicalized machine name.
- exit 1
-esac
-# Here we canonicalize certain aliases for manufacturers.
- *-digital*)
- basic_machine=`echo $basic_machine | sed 's/digital.*/dec/'`
- *-commodore*)
- basic_machine=`echo $basic_machine | sed 's/commodore.*/cbm/'`
-esac
-# Decode manufacturer-specific aliases for certain operating systems.
-if [ x"$os" != x"" ]
-then
-case $os in
- # First match some system type aliases
- # that might get confused with valid system types.
- # -solaris* is a basic system type, with this one exception.
- -auroraux)
- os=-auroraux
- -solaris1 | -solaris1.*)
- os=`echo $os | sed -e 's|solaris1|sunos4|'`
- -solaris)
- os=-solaris2
- -svr4*)
- os=-sysv4
- -unixware*)
- os=-sysv4.2uw
- -gnu/linux*)
- os=`echo $os | sed -e 's|gnu/linux|linux-gnu|'`
- # First accept the basic system types.
- # The portable systems comes first.
- # Each alternative MUST END IN A *, to match a version number.
- # -sysv* is not here because it comes later, after sysvr4.
- -gnu* | -bsd* | -mach* | -minix* | -genix* | -ultrix* | -irix* \
- | -*vms* | -sco* | -esix* | -isc* | -aix* | -cnk* | -sunos | -sunos[34]*\
- | -hpux* | -unos* | -osf* | -luna* | -dgux* | -auroraux* | -solaris* \
- | -sym* | -kopensolaris* \
- | -amigaos* | -amigados* | -msdos* | -newsos* | -unicos* | -aof* \
- | -aos* | -aros* \
- | -nindy* | -vxsim* | -vxworks* | -ebmon* | -hms* | -mvs* \
- | -clix* | -riscos* | -uniplus* | -iris* | -rtu* | -xenix* \
- | -hiux* | -386bsd* | -knetbsd* | -mirbsd* | -netbsd* \
- | -openbsd* | -solidbsd* \
- | -ekkobsd* | -kfreebsd* | -freebsd* | -riscix* | -lynxos* \
- | -bosx* | -nextstep* | -cxux* | -aout* | -elf* | -oabi* \
- | -ptx* | -coff* | -ecoff* | -winnt* | -domain* | -vsta* \
- | -udi* | -eabi* | -lites* | -ieee* | -go32* | -aux* \
- | -chorusos* | -chorusrdb* | -cegcc* \
- | -cygwin* | -msys* | -pe* | -psos* | -moss* | -proelf* | -rtems* \
- | -mingw32* | -linux-gnu* | -linux-android* \
- | -linux-newlib* | -linux-uclibc* \
- | -uxpv* | -beos* | -mpeix* | -udk* \
- | -interix* | -uwin* | -mks* | -rhapsody* | -darwin* | -opened* \
- | -openstep* | -oskit* | -conix* | -pw32* | -nonstopux* \
- | -storm-chaos* | -tops10* | -tenex* | -tops20* | -its* \
- | -os2* | -vos* | -palmos* | -uclinux* | -nucleus* \
- | -morphos* | -superux* | -rtmk* | -rtmk-nova* | -windiss* \
- | -powermax* | -dnix* | -nx6 | -nx7 | -sei* | -dragonfly* \
- | -skyos* | -haiku* | -rdos* | -toppers* | -drops* | -es*)
- # Remember, each alternative MUST END IN *, to match a version number.
- -qnx*)
- case $basic_machine in
- x86-* | i*86-*)
- os=-nto$os
- esac
- -nto-qnx*)
- -nto*)
- os=`echo $os | sed -e 's|nto|nto-qnx|'`
- -sim | -es1800* | -hms* | -xray | -os68k* | -none* | -v88r* \
- | -windows* | -osx | -abug | -netware* | -os9* | -beos* | -haiku* \
- | -macos* | -mpw* | -magic* | -mmixware* | -mon960* | -lnews*)
- -mac*)
- os=`echo $os | sed -e 's|mac|macos|'`
- -linux-dietlibc)
- os=-linux-dietlibc
- -linux*)
- os=`echo $os | sed -e 's|linux|linux-gnu|'`
- -sunos5*)
- os=`echo $os | sed -e 's|sunos5|solaris2|'`
- -sunos6*)
- os=`echo $os | sed -e 's|sunos6|solaris3|'`
- -opened*)
- os=-openedition
- -os400*)
- os=-os400
- -wince*)
- os=-wince
- -osfrose*)
- os=-osfrose
- -osf*)
- os=-osf
- -utek*)
- os=-bsd
- -dynix*)
- os=-bsd
- -acis*)
- os=-aos
- -atheos*)
- os=-atheos
- -syllable*)
- os=-syllable
- -386bsd)
- os=-bsd
- -ctix* | -uts*)
- os=-sysv
- -nova*)
- os=-rtmk-nova
- -ns2 )
- os=-nextstep2
- -nsk*)
- os=-nsk
- # Preserve the version number of sinix5.
- -sinix5.*)
- os=`echo $os | sed -e 's|sinix|sysv|'`
- -sinix*)
- os=-sysv4
- -tpf*)
- os=-tpf
- -triton*)
- os=-sysv3
- -oss*)
- os=-sysv3
- -svr4)
- os=-sysv4
- -svr3)
- os=-sysv3
- -sysvr4)
- os=-sysv4
- # This must come after -sysvr4.
- -sysv*)
- -ose*)
- os=-ose
- -es1800*)
- os=-ose
- -xenix)
- os=-xenix
- -*mint | -mint[0-9]* | -*MiNT | -MiNT[0-9]*)
- os=-mint
- -aros*)
- os=-aros
- -kaos*)
- os=-kaos
- -zvmoe)
- os=-zvmoe
- -dicos*)
- os=-dicos
- -nacl*)
- -none)
- # Get rid of the `-' at the beginning of $os.
- os=`echo $os | sed 's/[^-]*-//'`
- echo Invalid configuration \`$1\': system \`$os\' not recognized 1>&2
- exit 1
-esac
-else
-# Here we handle the default operating systems that come with various machines.
-# The value should be what the vendor currently ships out the door with their
-# machine or put another way, the most popular os provided with the machine.
-# Note that if you're going to try to match "-MANUFACTURER" here (say,
-# "-sun"), then you have to tell the case statement up towards the top
-# that MANUFACTURER isn't an operating system. Otherwise, code above
-# will signal an error saying that MANUFACTURER isn't an operating
-# system, and we'll never get to this point.
- score-*)
- os=-elf
- spu-*)
- os=-elf
- *-acorn)
- os=-riscix1.2
- arm*-rebel)
- os=-linux
- arm*-semi)
- os=-aout
- c4x-* | tic4x-*)
- os=-coff
- tic54x-*)
- os=-coff
- tic55x-*)
- os=-coff
- tic6x-*)
- os=-coff
- # This must come before the *-dec entry.
- pdp10-*)
- os=-tops20
- pdp11-*)
- os=-none
- *-dec | vax-*)
- os=-ultrix4.2
- m68*-apollo)
- os=-domain
- i386-sun)
- os=-sunos4.0.2
- m68000-sun)
- os=-sunos3
- m68*-cisco)
- os=-aout
- mep-*)
- os=-elf
- mips*-cisco)
- os=-elf
- mips*-*)
- os=-elf
- or32-*)
- os=-coff
- *-tti) # must be before sparc entry or we get the wrong os.
- os=-sysv3
- sparc-* | *-sun)
- os=-sunos4.1.1
- *-be)
- os=-beos
- *-haiku)
- os=-haiku
- *-ibm)
- os=-aix
- *-knuth)
- os=-mmixware
- *-wec)
- os=-proelf
- *-winbond)
- os=-proelf
- *-oki)
- os=-proelf
- *-hp)
- os=-hpux
- *-hitachi)
- os=-hiux
- i860-* | *-att | *-ncr | *-altos | *-motorola | *-convergent)
- os=-sysv
- *-cbm)
- os=-amigaos
- *-dg)
- os=-dgux
- *-dolphin)
- os=-sysv3
- m68k-ccur)
- os=-rtu
- m88k-omron*)
- os=-luna
- *-next )
- os=-nextstep
- *-sequent)
- os=-ptx
- *-crds)
- os=-unos
- *-ns)
- os=-genix
- i370-*)
- os=-mvs
- *-next)
- os=-nextstep3
- *-gould)
- os=-sysv
- *-highlevel)
- os=-bsd
- *-encore)
- os=-bsd
- *-sgi)
- os=-irix
- *-siemens)
- os=-sysv4
- *-masscomp)
- os=-rtu
- f30[01]-fujitsu | f700-fujitsu)
- os=-uxpv
- *-rom68k)
- os=-coff
- *-*bug)
- os=-coff
- *-apple)
- os=-macos
- *-atari*)
- os=-mint
- os=-none
-esac
-fi
-# Here we handle the case where we know the os, and the CPU type, but not the
-# manufacturer. We pick the logical manufacturer.
-vendor=unknown
- *-unknown)
- case $os in
- -riscix*)
- vendor=acorn
- -sunos*)
- vendor=sun
- -cnk*|-aix*)
- vendor=ibm
- -beos*)
- vendor=be
- -hpux*)
- vendor=hp
- -mpeix*)
- vendor=hp
- -hiux*)
- vendor=hitachi
- -unos*)
- vendor=crds
- -dgux*)
- vendor=dg
- -luna*)
- vendor=omron
- -genix*)
- vendor=ns
- -mvs* | -opened*)
- vendor=ibm
- -os400*)
- vendor=ibm
- -ptx*)
- vendor=sequent
- -tpf*)
- vendor=ibm
- -vxsim* | -vxworks* | -windiss*)
- vendor=wrs
- -aux*)
- vendor=apple
- -hms*)
- vendor=hitachi
- -mpw* | -macos*)
- vendor=apple
- vendor=atari
- -vos*)
- vendor=stratus
- esac
- basic_machine=`echo $basic_machine | sed "s/unknown/$vendor/"`
-esac
-echo $basic_machine$os
-exit
-# Local variables:
-# End:
Index: modules/provider-coaster-c-client/config/ltmain.sh
--- modules/provider-coaster-c-client/config/ltmain.sh (revision 3826)
+++ modules/provider-coaster-c-client/config/ltmain.sh (working copy)
@@ -1,9661 +0,0 @@
-# libtool (GNU libtool) 2.4.2
-# Written by Gordon Matzigkeit <gord at gnu.ai.mit.edu>, 1996
-# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001, 2003, 2004, 2005, 2006,
-# 2007, 2008, 2009, 2010, 2011 Free Software Foundation, Inc.
-# This is free software; see the source for copying conditions. There is NO
-# warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
-# GNU Libtool is free software; you can redistribute it and/or modify
-# the Free Software Foundation; either version 2 of the License, or
-# (at your option) any later version.
-# As a special exception to the GNU General Public License,
-# if you distribute this file as part of a program or library that
-# is built using GNU Libtool, you may include this file under the
-# same distribution terms that you use for the rest of that program.
-# GNU Libtool is distributed in the hope that it will be useful, but
-# WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-# General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with GNU Libtool; see the file COPYING. If not, a copy
-# can be downloaded from http://www.gnu.org/licenses/gpl.html,
-# or obtained by writing to the Free Software Foundation, Inc.,
-# 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
-# Usage: $progname [OPTION]... [MODE-ARG]...
-# Provide generalized library-building support services.
-# --config show all configuration variables
-# --debug enable verbose shell tracing
-# -n, --dry-run display commands without modifying any files
-# --features display basic configuration information and exit
-# --mode=MODE use operation mode MODE
-# --preserve-dup-deps don't remove duplicate dependency libraries
-# --quiet, --silent don't print informational messages
-# --no-quiet, --no-silent
-# print informational messages (default)
-# --no-warn don't display warning messages
-# --tag=TAG use configuration variables from tag TAG
-# -v, --verbose print more informational messages than default
-# --no-verbose don't print the extra informational messages
-# --version print version information
-# -h, --help, --help-all print short, long, or detailed help message
-# MODE must be one of the following:
-# clean remove files from the build directory
-# compile compile a source file into a libtool object
-# execute automatically set library path, then run a program
-# finish complete the installation of libtool libraries
-# install install libraries or executables
-# link create a library or an executable
-# uninstall remove libraries from an installed directory
-# MODE-ARGS vary depending on the MODE. When passed as first option,
-# `--mode=MODE' may be abbreviated as `MODE' or a unique abbreviation of that.
-# Try `$progname --help --mode=MODE' for a more detailed description of MODE.
-# When reporting a bug, please describe a test case to reproduce it and
-# include the following information:
-# host-triplet: $host
-# shell: $SHELL
-# compiler: $LTCC
-# compiler flags: $LTCFLAGS
-# linker: $LD (gnu? $with_gnu_ld)
-# $progname: (GNU libtool) 2.4.2 Debian-2.4.2-1ubuntu1
-# automake: $automake_version
-# autoconf: $autoconf_version
-# Report bugs to <bug-libtool at gnu.org>.
-# GNU libtool home page: <http://www.gnu.org/software/libtool/>.
-# General help using GNU software: <http://www.gnu.org/gethelp/>.
-PROGRAM=libtool
-PACKAGE=libtool
-VERSION="2.4.2 Debian-2.4.2-1ubuntu1"
-TIMESTAMP=""
-package_revision=1.3337
-# Be Bourne compatible
-if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
- emulate sh
- NULLCMD=:
- # Zsh 3.x and 4.x performs word splitting on ${1+"$@"}, which
- # is contrary to our usage. Disable this feature.
- alias -g '${1+"$@"}'='"$@"'
- setopt NO_GLOB_SUBST
-else
- case `(set -o) 2>/dev/null` in *posix*) set -o posix;; esac
-fi
-BIN_SH=xpg4; export BIN_SH # for Tru64
-DUALCASE=1; export DUALCASE # for MKS sh
-# A function that is used when there is no print builtin or printf.
-func_fallback_echo ()
- eval 'cat <<_LTECHO_EOF
-$1
-_LTECHO_EOF'
-# NLS nuisances: We save the old values to restore during execute mode.
-lt_user_locale=
-lt_safe_locale=
-for lt_var in LANG LANGUAGE LC_ALL LC_CTYPE LC_COLLATE LC_MESSAGES
-do
- eval "if test \"\${$lt_var+set}\" = set; then
- save_$lt_var=\$$lt_var
- $lt_var=C
- export $lt_var
- lt_user_locale=\"$lt_var=\\\$save_\$lt_var; \$lt_user_locale\"
- lt_safe_locale=\"$lt_var=C; \$lt_safe_locale\"
- fi"
-done
-LC_ALL=C
-LANGUAGE=C
-export LANGUAGE LC_ALL
-$lt_unset CDPATH
-# Work around backward compatibility issue on IRIX 6.5. On IRIX 6.4+, sh
-# is ksh but when the shell is invoked as "sh" and the current value of
-# the _XPG environment variable is not equal to 1 (one), the special
-# positional parameter $0, within a function call, is the name of the
-# function.
-progpath="$0"
-: ${CP="cp -f"}
-test "${ECHO+set}" = set || ECHO=${as_echo-'printf %s\n'}
-: ${MAKE="make"}
-: ${MKDIR="mkdir"}
-: ${MV="mv -f"}
-: ${RM="rm -f"}
-: ${SHELL="${CONFIG_SHELL-/bin/sh}"}
-: ${Xsed="$SED -e 1s/^X//"}
-# Global variables:
-EXIT_SUCCESS=0
-EXIT_FAILURE=1
-EXIT_MISMATCH=63 # $? = 63 is used to indicate version mismatch to missing.
-EXIT_SKIP=77 # $? = 77 is used to indicate a skipped test to automake.
-exit_status=$EXIT_SUCCESS
-# Make sure IFS has a sensible default
-lt_nl='
-IFS=" $lt_nl"
-dirname="s,/[^/]*$,,"
-basename="s,^.*/,,"
-# func_dirname file append nondir_replacement
-# Compute the dirname of FILE. If nonempty, add APPEND to the result,
-# otherwise set result to NONDIR_REPLACEMENT.
-func_dirname ()
- func_dirname_result=`$ECHO "${1}" | $SED "$dirname"`
- if test "X$func_dirname_result" = "X${1}"; then
- func_dirname_result="${3}"
- else
- func_dirname_result="$func_dirname_result${2}"
- fi
-} # func_dirname may be replaced by extended shell implementation
-# func_basename file
-func_basename ()
- func_basename_result=`$ECHO "${1}" | $SED "$basename"`
-} # func_basename may be replaced by extended shell implementation
-# func_dirname_and_basename file append nondir_replacement
-# perform func_basename and func_dirname in a single function
-# call:
-# dirname: Compute the dirname of FILE. If nonempty,
-# add APPEND to the result, otherwise set result
-# to NONDIR_REPLACEMENT.
-# value returned in "$func_dirname_result"
-# basename: Compute filename of FILE.
-# value retuned in "$func_basename_result"
-# Implementation must be kept synchronized with func_dirname
-# and func_basename. For efficiency, we do not delegate to
-# those functions but instead duplicate the functionality here.
-func_dirname_and_basename ()
- # Extract subdirectory from the argument.
- func_dirname_result=`$ECHO "${1}" | $SED -e "$dirname"`
- else
- fi
- func_basename_result=`$ECHO "${1}" | $SED -e "$basename"`
-} # func_dirname_and_basename may be replaced by extended shell implementation
-# func_stripname prefix suffix name
-# strip PREFIX and SUFFIX off of NAME.
-# PREFIX and SUFFIX must not contain globbing or regex special
-# characters, hashes, percent signs, but SUFFIX may contain a leading
-# dot (in which case that matches only a dot).
-# func_strip_suffix prefix name
-func_stripname ()
- case ${2} in
- .*) func_stripname_result=`$ECHO "${3}" | $SED "s%^${1}%%; s%\\\\${2}\$%%"`;;
- *) func_stripname_result=`$ECHO "${3}" | $SED "s%^${1}%%; s%${2}\$%%"`;;
- esac
-} # func_stripname may be replaced by extended shell implementation
-# These SED scripts presuppose an absolute path with a trailing slash.
-pathcar='s,^/\([^/]*\).*$,\1,'
-pathcdr='s,^/[^/]*,,'
-removedotparts=':dotsl
- s@/\./@/@g
- t dotsl
- s,/\.$,/,'
-collapseslashes='s@/\{1,\}@/@g'
-finalslash='s,/*$,/,'
-# func_normal_abspath PATH
-# Remove doubled-up and trailing slashes, "." path components,
-# and cancel out any ".." path components in PATH after making
-# it an absolute path.
-# value returned in "$func_normal_abspath_result"
-func_normal_abspath ()
- # Start from root dir and reassemble the path.
- func_normal_abspath_result=
- func_normal_abspath_tpath=$1
- func_normal_abspath_altnamespace=
- case $func_normal_abspath_tpath in
- # Empty path, that just means $cwd.
- func_stripname '' '/' "`pwd`"
- func_normal_abspath_result=$func_stripname_result
- return
- # The next three entries are used to spot a run of precisely
- # two leading slashes without using negated character classes;
- # we take advantage of case's first-match behaviour.
- # Unusual form of absolute path, do nothing.
- # Not necessarily an ordinary path; POSIX reserves leading '//'
- # and for example Cygwin uses it to access remote file shares
- # over CIFS/SMB, so we conserve a leading double slash if found.
- func_normal_abspath_altnamespace=/
- # Absolute path, do nothing.
- # Relative path, prepend $cwd.
- func_normal_abspath_tpath=`pwd`/$func_normal_abspath_tpath
- esac
- # Cancel out all the simple stuff to save iterations. We also want
- # the path to end with a slash for ease of parsing, so make sure
- # there is one (and only one) here.
- func_normal_abspath_tpath=`$ECHO "$func_normal_abspath_tpath" | $SED \
- -e "$removedotparts" -e "$collapseslashes" -e "$finalslash"`
- while :; do
- # Processed it all yet?
- if test "$func_normal_abspath_tpath" = / ; then
- # If we ascended to the root using ".." the result may be empty now.
- if test -z "$func_normal_abspath_result" ; then
- func_normal_abspath_result=/
- fi
- break
- fi
- func_normal_abspath_tcomponent=`$ECHO "$func_normal_abspath_tpath" | $SED \
- -e "$pathcar"`
- -e "$pathcdr"`
- # Figure out what to do with it
- case $func_normal_abspath_tcomponent in
- # Trailing empty path component, ignore it.
- # Parent dir; strip last assembled component from result.
- func_dirname "$func_normal_abspath_result"
- func_normal_abspath_result=$func_dirname_result
- # Actual path component, append it.
- func_normal_abspath_result=$func_normal_abspath_result/$func_normal_abspath_tcomponent
- esac
- done
- # Restore leading double-slash if one was found on entry.
- func_normal_abspath_result=$func_normal_abspath_altnamespace$func_normal_abspath_result
-# func_relative_path SRCDIR DSTDIR
-# generates a relative path from SRCDIR to DSTDIR, with a trailing
-# slash if non-empty, suitable for immediately appending a filename
-# without needing to append a separator.
-# value returned in "$func_relative_path_result"
-func_relative_path ()
- func_relative_path_result=
- func_normal_abspath "$1"
- func_relative_path_tlibdir=$func_normal_abspath_result
- func_normal_abspath "$2"
- func_relative_path_tbindir=$func_normal_abspath_result
- # Ascend the tree starting from libdir
- while :; do
- # check if we have found a prefix of bindir
- case $func_relative_path_tbindir in
- $func_relative_path_tlibdir)
- # found an exact match
- func_relative_path_tcancelled=
- break
- $func_relative_path_tlibdir*)
- # found a matching prefix
- func_stripname "$func_relative_path_tlibdir" '' "$func_relative_path_tbindir"
- func_relative_path_tcancelled=$func_stripname_result
- if test -z "$func_relative_path_result"; then
- func_relative_path_result=.
- fi
- break
- func_dirname $func_relative_path_tlibdir
- func_relative_path_tlibdir=${func_dirname_result}
- if test "x$func_relative_path_tlibdir" = x ; then
- # Have to descend all the way to the root!
- func_relative_path_result=../$func_relative_path_result
- func_relative_path_tcancelled=$func_relative_path_tbindir
- break
- fi
- esac
- done
- # Now calculate path; take care to avoid doubling-up slashes.
- func_stripname '' '/' "$func_relative_path_result"
- func_relative_path_result=$func_stripname_result
- func_stripname '/' '/' "$func_relative_path_tcancelled"
- if test "x$func_stripname_result" != x ; then
- func_relative_path_result=${func_relative_path_result}/${func_stripname_result}
- fi
- # Normalisation. If bindir is libdir, return empty string,
- # else relative path ending with a slash; either way, target
- # file name can be directly appended.
- if test ! -z "$func_relative_path_result"; then
- func_stripname './' '' "$func_relative_path_result/"
- fi
-# The name of this program:
-func_dirname_and_basename "$progpath"
-progname=$func_basename_result
-# Make sure we have an absolute path for reexecution:
-case $progpath in
- [\\/]*|[A-Za-z]:\\*) ;;
- progdir=$func_dirname_result
- progdir=`cd "$progdir" && pwd`
- progpath="$progdir/$progname"
- save_IFS="$IFS"
- IFS=${PATH_SEPARATOR-:}
- for progdir in $PATH; do
- IFS="$save_IFS"
- test -x "$progdir/$progname" && break
- done
- IFS="$save_IFS"
- test -n "$progdir" || progdir=`pwd`
-esac
-# Sed substitution that helps us do robust quoting. It backslashifies
-# metacharacters that are still active within double-quoted strings.
-Xsed="${SED}"' -e 1s/^X//'
-sed_quote_subst='s/\([`"$\\]\)/\\\1/g'
-# Same as above, but do not quote variable references.
-double_quote_subst='s/\(["`\\]\)/\\\1/g'
-# Sed substitution that turns a string into a regex matching for the
-# string literally.
-sed_make_literal_regex='s,[].[^$\\*\/],\\&,g'
-# Sed substitution that converts a w32 file name or path
-# which contains forward slashes, into one that contains
-# (escaped) backslashes. A very naive implementation.
-lt_sed_naive_backslashify='s|\\\\*|\\|g;s|/|\\|g;s|\\|\\\\|g'
-# Re-`\' parameter expansions in output of double_quote_subst that were
-# `\'-ed in input to the same. If an odd number of `\' preceded a '$'
-# in input to double_quote_subst, that '$' was protected from expansion.
-# Since each input `\' is now two `\'s, look for any number of runs of
-# four `\'s followed by two `\'s and then a '$'. `\' that '$'.
-bs='\\'
-bs2='\\\\'
-bs4='\\\\\\\\'
-dollar='\$'
-sed_double_backslash="\
- s/$bs4/&\\
-/g
- s/^$bs2$dollar/$bs&/
- s/\\([^$bs]\\)$bs2$dollar/\\1$bs2$bs$dollar/g
- s/\n//g"
-# Standard options:
-opt_dry_run=false
-opt_help=false
-opt_quiet=false
-opt_verbose=false
-opt_warning=:
-# func_echo arg...
-# Echo program name prefixed message, along with the current mode
-# name if it has been set yet.
-func_echo ()
- $ECHO "$progname: ${opt_mode+$opt_mode: }$*"
-# func_verbose arg...
-# Echo program name prefixed message in verbose mode only.
-func_verbose ()
- $opt_verbose && func_echo ${1+"$@"}
- # A bug in bash halts the script if the last line of a function
- # fails when set -e is in force, so we need another command to
- # work around that:
-# func_echo_all arg...
-# Invoke $ECHO with all args, space-separated.
-func_echo_all ()
- $ECHO "$*"
-# func_error arg...
-# Echo program name prefixed message to standard error.
-func_error ()
- $ECHO "$progname: ${opt_mode+$opt_mode: }"${1+"$@"} 1>&2
-# func_warning arg...
-# Echo program name prefixed warning message to standard error.
-func_warning ()
- $opt_warning && $ECHO "$progname: ${opt_mode+$opt_mode: }warning: "${1+"$@"} 1>&2
- # bash bug again:
-# func_fatal_error arg...
-# Echo program name prefixed message to standard error, and exit.
-func_fatal_error ()
- func_error ${1+"$@"}
- exit $EXIT_FAILURE
-# func_fatal_help arg...
-# Echo program name prefixed message to standard error, followed by
-# a help hint, and exit.
-func_fatal_help ()
- func_fatal_error "$help"
-help="Try \`$progname --help' for more information." ## default
-# func_grep expression filename
-# Check whether EXPRESSION matches any line of FILENAME, without output.
-func_grep ()
- $GREP "$1" "$2" >/dev/null 2>&1
-# func_mkdir_p directory-path
-# Make sure the entire path to DIRECTORY-PATH is available.
-func_mkdir_p ()
- my_directory_path="$1"
- my_dir_list=
- if test -n "$my_directory_path" && test "$opt_dry_run" != ":"; then
- # Protect directory names starting with `-'
- case $my_directory_path in
- -*) my_directory_path="./$my_directory_path" ;;
- esac
- # While some portion of DIR does not yet exist...
- while test ! -d "$my_directory_path"; do
- # ...make a list in topmost first order. Use a colon delimited
- # list incase some portion of path contains whitespace.
- my_dir_list="$my_directory_path:$my_dir_list"
- # If the last portion added has no slash in it, the list is done
- case $my_directory_path in */*) ;; *) break ;; esac
- # ...otherwise throw away the child directory and loop
- my_directory_path=`$ECHO "$my_directory_path" | $SED -e "$dirname"`
- done
- my_dir_list=`$ECHO "$my_dir_list" | $SED 's,:*$,,'`
- save_mkdir_p_IFS="$IFS"; IFS=':'
- for my_dir in $my_dir_list; do
- IFS="$save_mkdir_p_IFS"
- # mkdir can fail with a `File exist' error if two processes
- # try to create one of the directories concurrently. Don't
- # stop in that case!
- $MKDIR "$my_dir" 2>/dev/null || :
- done
- # Bail out if we (or some other process) failed to create a directory.
- test -d "$my_directory_path" || \
- func_fatal_error "Failed to create \`$1'"
- fi
-# func_mktempdir [string]
-# Make a temporary directory that won't clash with other running
-# libtool processes, and avoids race conditions if possible. If
-# given, STRING is the basename for that directory.
-func_mktempdir ()
- my_template="${TMPDIR-/tmp}/${1-$progname}"
- if test "$opt_dry_run" = ":"; then
- # Return a directory name, but don't create it in dry-run mode
- my_tmpdir="${my_template}-$$"
- else
- # If mktemp works, use that first and foremost
- my_tmpdir=`mktemp -d "${my_template}-XXXXXXXX" 2>/dev/null`
- if test ! -d "$my_tmpdir"; then
- # Failing that, at least try and use $RANDOM to avoid a race
- my_tmpdir="${my_template}-${RANDOM-0}$$"
- save_mktempdir_umask=`umask`
- umask 0077
- $MKDIR "$my_tmpdir"
- umask $save_mktempdir_umask
- fi
- # If we're not in dry-run mode, bomb out on failure
- test -d "$my_tmpdir" || \
- func_fatal_error "cannot create temporary directory \`$my_tmpdir'"
- fi
- $ECHO "$my_tmpdir"
-# func_quote_for_eval arg
-# Aesthetically quote ARG to be evaled later.
-# This function returns two values: FUNC_QUOTE_FOR_EVAL_RESULT
-# is double-quoted, suitable for a subsequent eval, whereas
-# FUNC_QUOTE_FOR_EVAL_UNQUOTED_RESULT has merely all characters
-# which are still active within double quotes backslashified.
-func_quote_for_eval ()
- case $1 in
- func_quote_for_eval_unquoted_result=`$ECHO "$1" | $SED "$sed_quote_subst"` ;;
- func_quote_for_eval_unquoted_result="$1" ;;
- esac
- case $func_quote_for_eval_unquoted_result in
- # Double-quote args containing shell metacharacters to delay
- # word splitting, command substitution and and variable
- # expansion for a subsequent eval.
- # Many Bourne shells cannot handle close brackets correctly
- # in scan sets, so we specify it separately.
- func_quote_for_eval_result="\"$func_quote_for_eval_unquoted_result\""
- func_quote_for_eval_result="$func_quote_for_eval_unquoted_result"
- esac
-# func_quote_for_expand arg
-# Aesthetically quote ARG to be evaled later; same as above,
-# but do not quote variable references.
-func_quote_for_expand ()
- case $1 in
- my_arg=`$ECHO "$1" | $SED \
- -e "$double_quote_subst" -e "$sed_double_backslash"` ;;
- my_arg="$1" ;;
- esac
- case $my_arg in
- # word splitting and command substitution for a subsequent eval.
- my_arg="\"$my_arg\""
- esac
- func_quote_for_expand_result="$my_arg"
-# func_show_eval cmd [fail_exp]
-# Unless opt_silent is true, then output CMD. Then, if opt_dryrun is
-# not true, evaluate CMD. If the evaluation of CMD fails, and FAIL_EXP
-# is given, then evaluate it.
-func_show_eval ()
- my_cmd="$1"
- my_fail_exp="${2-:}"
- ${opt_silent-false} || {
- func_quote_for_expand "$my_cmd"
- eval "func_echo $func_quote_for_expand_result"
- if ${opt_dry_run-false}; then :; else
- eval "$my_cmd"
- my_status=$?
- if test "$my_status" -eq 0; then :; else
- eval "(exit $my_status); $my_fail_exp"
- fi
- fi
-# func_show_eval_locale cmd [fail_exp]
-# is given, then evaluate it. Use the saved locale for evaluation.
-func_show_eval_locale ()
- my_cmd="$1"
- eval "$lt_user_locale
- $my_cmd"
- my_status=$?
- eval "$lt_safe_locale"
- fi
- fi
-# func_tr_sh
-# Turn $1 into a string suitable for a shell variable name.
-# Result is stored in $func_tr_sh_result. All characters
-# not in the set a-zA-Z0-9_ are replaced with '_'. Further,
-# if $1 begins with a digit, a '_' is prepended as well.
-func_tr_sh ()
- case $1 in
- [0-9]* | *[!a-zA-Z0-9_]*)
- func_tr_sh_result=`$ECHO "$1" | $SED 's/^\([0-9]\)/_\1/; s/[^a-zA-Z0-9_]/_/g'`
- func_tr_sh_result=$1
- esac
-# func_version
-# Echo version message to standard output and exit.
-func_version ()
- $opt_debug
- $SED -n '/(C)/!b go
- :more
- N
- s/\n# / /
- b more
- :go
- /^# '$PROGRAM' (GNU /,/# warranty; / {
- s/^# //
- s/^# *$//
- s/\((C)\)[ 0-9,-]*\( [1-9][0-9]*\)/\1\2/
- p
- }' < "$progpath"
- exit $?
-# func_usage
-# Echo short help message to standard output and exit.
-func_usage ()
- $opt_debug
- $SED -n '/^# Usage:/,/^# *.*--help/ {
- s/^# //
- s/^# *$//
- s/\$progname/'$progname'/
- p
- }' < "$progpath"
- echo
- $ECHO "run \`$progname --help | more' for full usage"
- exit $?
-# func_help [NOEXIT]
-# Echo long help message to standard output and exit,
-# unless 'noexit' is passed as argument.
-func_help ()
- $opt_debug
- $SED -n '/^# Usage:/,/# Report bugs to/ {
- :print
- s/^# //
- s/^# *$//
- s*\$progname*'$progname'*
- s*\$host*'"$host"'*
- s*\$SHELL*'"$SHELL"'*
- s*\$LTCC*'"$LTCC"'*
- s*\$LTCFLAGS*'"$LTCFLAGS"'*
- s*\$LD*'"$LD"'*
- s/\$with_gnu_ld/'"$with_gnu_ld"'/
- s/\$automake_version/'"`(${AUTOMAKE-automake} --version) 2>/dev/null |$SED 1q`"'/
- s/\$autoconf_version/'"`(${AUTOCONF-autoconf} --version) 2>/dev/null |$SED 1q`"'/
- p
- d
- /^# .* home page:/b print
- /^# General help using/b print
- ' < "$progpath"
- ret=$?
- if test -z "$1"; then
- exit $ret
- fi
-# func_missing_arg argname
-# Echo program name prefixed message to standard error and set global
-# exit_cmd.
-func_missing_arg ()
- $opt_debug
- func_error "missing argument for $1."
- exit_cmd=exit
-# func_split_short_opt shortopt
-# Set func_split_short_opt_name and func_split_short_opt_arg shell
-# variables after splitting SHORTOPT after the 2nd character.
-func_split_short_opt ()
- my_sed_short_opt='1s/^\(..\).*$/\1/;q'
- my_sed_short_rest='1s/^..\(.*\)$/\1/;q'
- func_split_short_opt_name=`$ECHO "$1" | $SED "$my_sed_short_opt"`
- func_split_short_opt_arg=`$ECHO "$1" | $SED "$my_sed_short_rest"`
-} # func_split_short_opt may be replaced by extended shell implementation
-# func_split_long_opt longopt
-# Set func_split_long_opt_name and func_split_long_opt_arg shell
-# variables after splitting LONGOPT at the `=' sign.
-func_split_long_opt ()
- my_sed_long_opt='1s/^\(--[^=]*\)=.*/\1/;q'
- my_sed_long_arg='1s/^--[^=]*=//'
- func_split_long_opt_name=`$ECHO "$1" | $SED "$my_sed_long_opt"`
- func_split_long_opt_arg=`$ECHO "$1" | $SED "$my_sed_long_arg"`
-} # func_split_long_opt may be replaced by extended shell implementation
-exit_cmd=:
-magic="%%%MAGIC variable%%%"
-magic_exe="%%%MAGIC EXE variable%%%"
-# Global variables.
-nonopt=
-preserve_args=
-lo2o="s/\\.lo\$/.${objext}/"
-o2lo="s/\\.${objext}\$/.lo/"
-extracted_archives=
-extracted_serial=0
-# If this variable is set in any of the actions, the command in it
-# will be execed at the end. This prevents here-documents from being
-# left over by shells.
-exec_cmd=
-# func_append var value
-# Append VALUE to the end of shell variable VAR.
-func_append ()
- eval "${1}=\$${1}\${2}"
-} # func_append may be replaced by extended shell implementation
-# func_append_quoted var value
-# Quote VALUE and append to the end of shell variable VAR, separated
-# by a space.
-func_append_quoted ()
- func_quote_for_eval "${2}"
- eval "${1}=\$${1}\\ \$func_quote_for_eval_result"
-} # func_append_quoted may be replaced by extended shell implementation
-# func_arith arithmetic-term...
-func_arith ()
- func_arith_result=`expr "${@}"`
-} # func_arith may be replaced by extended shell implementation
-# func_len string
-# STRING may not start with a hyphen.
-func_len ()
- func_len_result=`expr "${1}" : ".*" 2>/dev/null || echo $max_cmd_len`
-} # func_len may be replaced by extended shell implementation
-# func_lo2o object
-func_lo2o ()
- func_lo2o_result=`$ECHO "${1}" | $SED "$lo2o"`
-} # func_lo2o may be replaced by extended shell implementation
-# func_xform libobj-or-source
-func_xform ()
- func_xform_result=`$ECHO "${1}" | $SED 's/\.[^.]*$/.lo/'`
-} # func_xform may be replaced by extended shell implementation
-# func_fatal_configuration arg...
-# a configuration failure hint, and exit.
-func_fatal_configuration ()
- func_error "See the $PACKAGE documentation for more information."
- func_fatal_error "Fatal configuration error."
-# func_config
-# Display the configuration for all the tags in this script.
-func_config ()
- re_begincf='^# ### BEGIN LIBTOOL'
- re_endcf='^# ### END LIBTOOL'
- # Default configuration.
- $SED "1,/$re_begincf CONFIG/d;/$re_endcf CONFIG/,\$d" < "$progpath"
- # Now print the configurations for the tags.
- for tagname in $taglist; do
- $SED -n "/$re_begincf TAG CONFIG: $tagname\$/,/$re_endcf TAG CONFIG: $tagname\$/p" < "$progpath"
- done
- exit $?
-# func_features
-# Display the features supported by this script.
-func_features ()
- echo "host: $host"
- if test "$build_libtool_libs" = yes; then
- echo "enable shared libraries"
- else
- echo "disable shared libraries"
- fi
- if test "$build_old_libs" = yes; then
- echo "enable static libraries"
- else
- echo "disable static libraries"
- fi
- exit $?
-# func_enable_tag tagname
-# Verify that TAGNAME is valid, and either flag an error and exit, or
-# enable the TAGNAME tag. We also add TAGNAME to the global $taglist
-# variable here.
-func_enable_tag ()
- # Global variable:
- tagname="$1"
- re_begincf="^# ### BEGIN LIBTOOL TAG CONFIG: $tagname\$"
- re_endcf="^# ### END LIBTOOL TAG CONFIG: $tagname\$"
- sed_extractcf="/$re_begincf/,/$re_endcf/p"
- # Validate tagname.
- case $tagname in
- *[!-_A-Za-z0-9,/]*)
- func_fatal_error "invalid tag name: $tagname"
- esac
- # Don't test for the "default" C tag, as we know it's
- # there but not specially marked.
- case $tagname in
- CC) ;;
- if $GREP "$re_begincf" "$progpath" >/dev/null 2>&1; then
- taglist="$taglist $tagname"
- # Evaluate the configuration. Be careful to quote the path
- # and the sed script, to avoid splitting on whitespace, but
- # also don't use non-portable quotes within backquotes within
- # quotes we have to do it in 2 steps:
- extractedcf=`$SED -n -e "$sed_extractcf" < "$progpath"`
- eval "$extractedcf"
- else
- func_error "ignoring unknown tag $tagname"
- fi
- esac
-# func_check_version_match
-# Ensure that we are using m4 macros, and libtool script from the same
-# release of libtool.
-func_check_version_match ()
- if test "$package_revision" != "$macro_revision"; then
- if test "$VERSION" != "$macro_version"; then
- if test -z "$macro_version"; then
- cat >&2 <<_LT_EOF
-$progname: Version mismatch error. This is $PACKAGE $VERSION, but the
-$progname: definition of this LT_INIT comes from an older release.
-$progname: You should recreate aclocal.m4 with macros from $PACKAGE $VERSION
-$progname: and run autoconf again.
-_LT_EOF
- else
- cat >&2 <<_LT_EOF
-$progname: definition of this LT_INIT comes from $PACKAGE $macro_version.
-_LT_EOF
- fi
- else
- cat >&2 <<_LT_EOF
-$progname: Version mismatch error. This is $PACKAGE $VERSION, revision $package_revision,
-$progname: but the definition of this LT_INIT comes from revision $macro_revision.
-$progname: You should recreate aclocal.m4 with macros from revision $package_revision
-$progname: of $PACKAGE $VERSION and run autoconf again.
-_LT_EOF
- fi
- exit $EXIT_MISMATCH
- fi
-# Shorthand for --mode=foo, only valid as the first argument
-case $1 in
-clean|clea|cle|cl)
- shift; set dummy --mode clean ${1+"$@"}; shift
-compile|compil|compi|comp|com|co|c)
- shift; set dummy --mode compile ${1+"$@"}; shift
-execute|execut|execu|exec|exe|ex|e)
- shift; set dummy --mode execute ${1+"$@"}; shift
-finish|finis|fini|fin|fi|f)
- shift; set dummy --mode finish ${1+"$@"}; shift
-install|instal|insta|inst|ins|in|i)
- shift; set dummy --mode install ${1+"$@"}; shift
-link|lin|li|l)
- shift; set dummy --mode link ${1+"$@"}; shift
-uninstall|uninstal|uninsta|uninst|unins|unin|uni|un|u)
- shift; set dummy --mode uninstall ${1+"$@"}; shift
-esac
-# Option defaults:
-opt_debug=:
-opt_dry_run=false
-opt_config=false
-opt_preserve_dup_deps=false
-opt_features=false
-opt_finish=false
-opt_help=false
-opt_help_all=false
-opt_silent=:
-opt_warning=:
-opt_verbose=:
-opt_silent=false
-opt_verbose=false
-# Parse options once, thoroughly. This comes as soon as possible in the
-# script to make things like `--version' happen as quickly as we can.
- # this just eases exit handling
- while test $# -gt 0; do
- opt="$1"
- shift
- case $opt in
- --debug|-x) opt_debug='set -x'
- func_echo "enabling shell trace mode"
- $opt_debug
- --dry-run|--dryrun|-n)
- opt_dry_run=:
- --config)
- opt_config=:
-func_config
- --dlopen|-dlopen)
- optarg="$1"
- opt_dlopen="${opt_dlopen+$opt_dlopen
-}$optarg"
- shift
- --preserve-dup-deps)
- opt_preserve_dup_deps=:
- --features)
- opt_features=:
-func_features
- --finish)
- opt_finish=:
-set dummy --mode finish ${1+"$@"}; shift
- --help)
- opt_help=:
- --help-all)
- opt_help_all=:
-opt_help=': help-all'
- --mode)
- test $# = 0 && func_missing_arg $opt && break
- optarg="$1"
- opt_mode="$optarg"
-case $optarg in
- # Valid mode arguments:
- clean|compile|execute|finish|install|link|relink|uninstall) ;;
- # Catch anything else as an error
- *) func_error "invalid argument for $opt"
- exit_cmd=exit
- break
-esac
- shift
- --no-silent|--no-quiet)
- opt_silent=false
-func_append preserve_args " $opt"
- --no-warning|--no-warn)
- opt_warning=false
- --no-verbose)
- opt_verbose=false
- --silent|--quiet)
- opt_silent=:
- opt_verbose=false
- --verbose|-v)
- opt_verbose=:
-opt_silent=false
- --tag)
- optarg="$1"
- opt_tag="$optarg"
-func_append preserve_args " $opt $optarg"
-func_enable_tag "$optarg"
- shift
- -\?|-h) func_usage ;;
- --help) func_help ;;
- --version) func_version ;;
- # Separate optargs to long options:
- func_split_long_opt "$opt"
- set dummy "$func_split_long_opt_name" "$func_split_long_opt_arg" ${1+"$@"}
- shift
- # Separate non-argument short options:
- -\?*|-h*|-n*|-v*)
- func_split_short_opt "$opt"
- set dummy "$func_split_short_opt_name" "-$func_split_short_opt_arg" ${1+"$@"}
- shift
- --) break ;;
- -*) func_fatal_help "unrecognized option \`$opt'" ;;
- *) set dummy "$opt" ${1+"$@"}; shift; break ;;
- esac
- done
- # Validate options:
- # save first non-option argument
- if test "$#" -gt 0; then
- nonopt="$opt"
- shift
- fi
- # preserve --debug
- test "$opt_debug" = : || func_append preserve_args " --debug"
- case $host in
- *cygwin* | *mingw* | *pw32* | *cegcc*)
- # don't eliminate duplications in $postdeps and $predeps
- opt_duplicate_compiler_generated_deps=:
- opt_duplicate_compiler_generated_deps=$opt_preserve_dup_deps
- esac
- $opt_help || {
- # Sanity checks first:
- func_check_version_match
- if test "$build_libtool_libs" != yes && test "$build_old_libs" != yes; then
- func_fatal_configuration "not configured to build any kind of library"
- fi
- # Darwin sucks
- eval std_shrext=\"$shrext_cmds\"
- # Only execute mode is allowed to have -dlopen flags.
- if test -n "$opt_dlopen" && test "$opt_mode" != execute; then
- func_error "unrecognized option \`-dlopen'"
- $ECHO "$help" 1>&2
- fi
- # Change the help message to a mode-specific one.
- generic_help="$help"
- help="Try \`$progname --help --mode=$opt_mode' for more information."
- # Bail if the options were screwed
- $exit_cmd $EXIT_FAILURE
-## Main. ##
-# func_lalib_p file
-# True iff FILE is a libtool `.la' library or `.lo' object file.
-# This function is only a basic sanity check; it will hardly flush out
-# determined imposters.
-func_lalib_p ()
- test -f "$1" &&
- $SED -e 4q "$1" 2>/dev/null \
- | $GREP "^# Generated by .*$PACKAGE" > /dev/null 2>&1
-# func_lalib_unsafe_p file
-# This function implements the same check as func_lalib_p without
-# resorting to external programs. To this end, it redirects stdin and
-# closes it afterwards, without saving the original file descriptor.
-# As a safety measure, use it only where a negative result would be
-# fatal anyway. Works if `file' does not exist.
-func_lalib_unsafe_p ()
- lalib_p=no
- if test -f "$1" && test -r "$1" && exec 5<&0 <"$1"; then
- for lalib_p_l in 1 2 3 4
- do
- read lalib_p_line
- case "$lalib_p_line" in
- \#\ Generated\ by\ *$PACKAGE* ) lalib_p=yes; break;;
- esac
- done
- exec 0<&5 5<&-
- fi
- test "$lalib_p" = yes
-# func_ltwrapper_script_p file
-# True iff FILE is a libtool wrapper script
-func_ltwrapper_script_p ()
- func_lalib_p "$1"
-# func_ltwrapper_executable_p file
-# True iff FILE is a libtool wrapper executable
-func_ltwrapper_executable_p ()
- func_ltwrapper_exec_suffix=
- case $1 in
- *.exe) ;;
- *) func_ltwrapper_exec_suffix=.exe ;;
- esac
- $GREP "$magic_exe" "$1$func_ltwrapper_exec_suffix" >/dev/null 2>&1
-# func_ltwrapper_scriptname file
-# Assumes file is an ltwrapper_executable
-# uses $file to determine the appropriate filename for a
-# temporary ltwrapper_script.
-func_ltwrapper_scriptname ()
- func_dirname_and_basename "$1" "" "."
- func_stripname '' '.exe' "$func_basename_result"
- func_ltwrapper_scriptname_result="$func_dirname_result/$objdir/${func_stripname_result}_ltshwrapper"
-# func_ltwrapper_p file
-# True iff FILE is a libtool wrapper script or wrapper executable
-func_ltwrapper_p ()
- func_ltwrapper_script_p "$1" || func_ltwrapper_executable_p "$1"
-# func_execute_cmds commands fail_cmd
-# Execute tilde-delimited COMMANDS.
-# If FAIL_CMD is given, eval that upon failure.
-# FAIL_CMD may read-access the current command in variable CMD!
-func_execute_cmds ()
- $opt_debug
- save_ifs=$IFS; IFS='~'
- for cmd in $1; do
- IFS=$save_ifs
- eval cmd=\"$cmd\"
- func_show_eval "$cmd" "${2-:}"
- done
- IFS=$save_ifs
-# func_source file
-# Source FILE, adding directory component if necessary.
-# Note that it is not necessary on cygwin/mingw to append a dot to
-# FILE even if both FILE and FILE.exe exist: automatic-append-.exe
-# behavior happens only for exec(3), not for open(2)! Also, sourcing
-# `FILE.' does not work on cygwin managed mounts.
-func_source ()
- $opt_debug
- case $1 in
- */* | *\\*) . "$1" ;;
- *) . "./$1" ;;
- esac
-# func_resolve_sysroot PATH
-# Replace a leading = in PATH with a sysroot. Store the result into
-# func_resolve_sysroot_result
-func_resolve_sysroot ()
- func_resolve_sysroot_result=$1
- case $func_resolve_sysroot_result in
- func_stripname '=' '' "$func_resolve_sysroot_result"
- func_resolve_sysroot_result=$lt_sysroot$func_stripname_result
- esac
-# func_replace_sysroot PATH
-# If PATH begins with the sysroot, replace it with = and
-# store the result into func_replace_sysroot_result.
-func_replace_sysroot ()
- case "$lt_sysroot:$1" in
- ?*:"$lt_sysroot"*)
- func_stripname "$lt_sysroot" '' "$1"
- func_replace_sysroot_result="=$func_stripname_result"
- # Including no sysroot.
- func_replace_sysroot_result=$1
- esac
-# func_infer_tag arg
-# Infer tagged configuration to use if any are available and
-# if one wasn't chosen via the "--tag" command line option.
-# Only attempt this if the compiler in the base compile
-# command doesn't match the default compiler.
-# arg is usually of the form 'gcc ...'
-func_infer_tag ()
- $opt_debug
- if test -n "$available_tags" && test -z "$tagname"; then
- CC_quoted=
- for arg in $CC; do
- func_append_quoted CC_quoted "$arg"
- done
- CC_expanded=`func_echo_all $CC`
- CC_quoted_expanded=`func_echo_all $CC_quoted`
- case $@ in
- # Blanks in the command may have been stripped by the calling shell,
- # but not from the CC environment variable when configure was run.
- " $CC "* | "$CC "* | " $CC_expanded "* | "$CC_expanded "* | \
- " $CC_quoted"* | "$CC_quoted "* | " $CC_quoted_expanded "* | "$CC_quoted_expanded "*) ;;
- # Blanks at the start of $base_compile will cause this to fail
- # if we don't check for them as well.
- for z in $available_tags; do
- if $GREP "^# ### BEGIN LIBTOOL TAG CONFIG: $z$" < "$progpath" > /dev/null; then
- eval "`${SED} -n -e '/^# ### BEGIN LIBTOOL TAG CONFIG: '$z'$/,/^# ### END LIBTOOL TAG CONFIG: '$z'$/p' < $progpath`"
- CC_quoted=
- # Double-quote args containing other shell metacharacters.
- done
- case "$@ " in
- # The compiler in the base compile command matches
- # the one in the tagged configuration.
- # Assume this is the tagged configuration we want.
- tagname=$z
- break
- esac
- fi
- done
- # If $tagname still isn't set, then no tagged configuration
- # was found and let the user know that the "--tag" command
- # line option must be used.
- if test -z "$tagname"; then
- func_echo "unable to infer tagged configuration"
- func_fatal_error "specify a tag with \`--tag'"
-# else
-# func_verbose "using $tagname tagged configuration"
- fi
- esac
- fi
-# func_write_libtool_object output_name pic_name nonpic_name
-# Create a libtool object file (analogous to a ".la" file),
-# but don't create it if we're doing a dry run.
-func_write_libtool_object ()
- write_libobj=${1}
- write_lobj=\'${2}\'
- else
- write_lobj=none
- fi
- write_oldobj=\'${3}\'
- else
- write_oldobj=none
- fi
- $opt_dry_run || {
- cat >${write_libobj}T <<EOF
-# $write_libobj - a libtool object file
-# Generated by $PROGRAM (GNU $PACKAGE$TIMESTAMP) $VERSION
-# Please DO NOT delete this file!
-# It is necessary for linking the library.
-# Name of the PIC object.
-pic_object=$write_lobj
-# Name of the non-PIC object
-non_pic_object=$write_oldobj
-EOF
- $MV "${write_libobj}T" "${write_libobj}"
-# FILE NAME AND PATH CONVERSION HELPER FUNCTIONS #
-# func_convert_core_file_wine_to_w32 ARG
-# Helper function used by file name conversion functions when $build is *nix,
-# and $host is mingw, cygwin, or some other w32 environment. Relies on a
-# correctly configured wine environment available, with the winepath program
-# in $build's $PATH.
-# ARG is the $build file name to be converted to w32 format.
-# Result is available in $func_convert_core_file_wine_to_w32_result, and will
-# be empty on error (or when ARG is empty)
-func_convert_core_file_wine_to_w32 ()
- $opt_debug
- func_convert_core_file_wine_to_w32_result="$1"
- if test -n "$1"; then
- # Unfortunately, winepath does not exit with a non-zero error code, so we
- # are forced to check the contents of stdout. On the other hand, if the
- # command is not found, the shell will set an exit code of 127 and print
- # *an error message* to stdout. So we must check for both error code of
- # zero AND non-empty stdout, which explains the odd construction:
- func_convert_core_file_wine_to_w32_tmp=`winepath -w "$1" 2>/dev/null`
- if test "$?" -eq 0 && test -n "${func_convert_core_file_wine_to_w32_tmp}"; then
- func_convert_core_file_wine_to_w32_result=`$ECHO "$func_convert_core_file_wine_to_w32_tmp" |
- $SED -e "$lt_sed_naive_backslashify"`
- else
- fi
- fi
-# end: func_convert_core_file_wine_to_w32
-# func_convert_core_path_wine_to_w32 ARG
-# Helper function used by path conversion functions when $build is *nix, and
-# $host is mingw, cygwin, or some other w32 environment. Relies on a correctly
-# configured wine environment available, with the winepath program in $build's
-# $PATH. Assumes ARG has no leading or trailing path separator characters.
-# ARG is path to be converted from $build format to win32.
-# Result is available in $func_convert_core_path_wine_to_w32_result.
-# Unconvertible file (directory) names in ARG are skipped; if no directory names
-# are convertible, then the result may be empty.
-func_convert_core_path_wine_to_w32 ()
- $opt_debug
- # unfortunately, winepath doesn't convert paths, only file names
- func_convert_core_path_wine_to_w32_result=""
- oldIFS=$IFS
- IFS=:
- for func_convert_core_path_wine_to_w32_f in $1; do
- IFS=$oldIFS
- func_convert_core_file_wine_to_w32 "$func_convert_core_path_wine_to_w32_f"
- if test -n "$func_convert_core_file_wine_to_w32_result" ; then
- if test -z "$func_convert_core_path_wine_to_w32_result"; then
- func_convert_core_path_wine_to_w32_result="$func_convert_core_file_wine_to_w32_result"
- else
- func_append func_convert_core_path_wine_to_w32_result ";$func_convert_core_file_wine_to_w32_result"
- fi
- fi
- done
- IFS=$oldIFS
- fi
-# end: func_convert_core_path_wine_to_w32
-# func_cygpath ARGS...
-# Wrapper around calling the cygpath program via LT_CYGPATH. This is used when
-# when (1) $build is *nix and Cygwin is hosted via a wine environment; or (2)
-# $build is MSYS and $host is Cygwin, or (3) $build is Cygwin. In case (1) or
-# (2), returns the Cygwin file name or path in func_cygpath_result (input
-# file name or path is assumed to be in w32 format, as previously converted
-# from $build's *nix or MSYS format). In case (3), returns the w32 file name
-# or path in func_cygpath_result (input file name or path is assumed to be in
-# Cygwin format). Returns an empty string on error.
-# ARGS are passed to cygpath, with the last one being the file name or path to
-# be converted.
-# Specify the absolute *nix (or w32) name to cygpath in the LT_CYGPATH
-# environment variable; do not put it in $PATH.
-func_cygpath ()
- $opt_debug
- if test -n "$LT_CYGPATH" && test -f "$LT_CYGPATH"; then
- func_cygpath_result=`$LT_CYGPATH "$@" 2>/dev/null`
- if test "$?" -ne 0; then
- # on failure, ensure result is empty
- fi
- else
- func_error "LT_CYGPATH is empty or specifies non-existent file: \`$LT_CYGPATH'"
- fi
-#end: func_cygpath
-# func_convert_core_msys_to_w32 ARG
-# Convert file name or path ARG from MSYS format to w32 format. Return
-# result in func_convert_core_msys_to_w32_result.
-func_convert_core_msys_to_w32 ()
- $opt_debug
- # awkward: cmd appends spaces to result
- func_convert_core_msys_to_w32_result=`( cmd //c echo "$1" ) 2>/dev/null |
- $SED -e 's/[ ]*$//' -e "$lt_sed_naive_backslashify"`
-#end: func_convert_core_msys_to_w32
-# func_convert_file_check ARG1 ARG2
-# Verify that ARG1 (a file name in $build format) was converted to $host
-# format in ARG2. Otherwise, emit an error message, but continue (resetting
-# func_to_host_file_result to ARG1).
-func_convert_file_check ()
- $opt_debug
- if test -z "$2" && test -n "$1" ; then
- func_error "Could not determine host file name corresponding to"
- func_error " \`$1'"
- func_error "Continuing, but uninstalled executables may not work."
- # Fallback:
- func_to_host_file_result="$1"
- fi
-# end func_convert_file_check
-# func_convert_path_check FROM_PATHSEP TO_PATHSEP FROM_PATH TO_PATH
-# Verify that FROM_PATH (a path in $build format) was converted to $host
-# format in TO_PATH. Otherwise, emit an error message, but continue, resetting
-# func_to_host_file_result to a simplistic fallback value (see below).
-func_convert_path_check ()
- $opt_debug
- if test -z "$4" && test -n "$3"; then
- func_error "Could not determine the host path corresponding to"
- func_error " \`$3'"
- # Fallback. This is a deliberately simplistic "conversion" and
- # should not be "improved". See libtool.info.
- if test "x$1" != "x$2"; then
- lt_replace_pathsep_chars="s|$1|$2|g"
- func_to_host_path_result=`echo "$3" |
- $SED -e "$lt_replace_pathsep_chars"`
- else
- func_to_host_path_result="$3"
- fi
- fi
-# end func_convert_path_check
-# func_convert_path_front_back_pathsep FRONTPAT BACKPAT REPL ORIG
-# Modifies func_to_host_path_result by prepending REPL if ORIG matches FRONTPAT
-# and appending REPL if ORIG matches BACKPAT.
-func_convert_path_front_back_pathsep ()
- $opt_debug
- case $4 in
- $1 ) func_to_host_path_result="$3$func_to_host_path_result"
- esac
- case $4 in
- $2 ) func_append func_to_host_path_result "$3"
- esac
-# end func_convert_path_front_back_pathsep
-# $build to $host FILE NAME CONVERSION FUNCTIONS #
-# invoked via `$to_host_file_cmd ARG'
-# In each case, ARG is the path to be converted from $build to $host format.
-# Result will be available in $func_to_host_file_result.
-# func_to_host_file ARG
-# Converts the file name ARG from $build format to $host format. Return result
-# in func_to_host_file_result.
-func_to_host_file ()
- $opt_debug
- $to_host_file_cmd "$1"
-# end func_to_host_file
-# func_to_tool_file ARG LAZY
-# converts the file name ARG from $build format to toolchain format. Return
-# result in func_to_tool_file_result. If the conversion in use is listed
-# in (the comma separated) LAZY, no conversion takes place.
-func_to_tool_file ()
- $opt_debug
- case ,$2, in
- *,"$to_tool_file_cmd",*)
- func_to_tool_file_result=$1
- $to_tool_file_cmd "$1"
- func_to_tool_file_result=$func_to_host_file_result
- esac
-# end func_to_tool_file
-# func_convert_file_noop ARG
-# Copy ARG to func_to_host_file_result.
-func_convert_file_noop ()
-# end func_convert_file_noop
-# func_convert_file_msys_to_w32 ARG
-# Convert file name ARG from (mingw) MSYS to (mingw) w32 format; automatic
-# conversion to w32 is not available inside the cwrapper. Returns result in
-# func_to_host_file_result.
-func_convert_file_msys_to_w32 ()
- $opt_debug
- func_convert_core_msys_to_w32 "$1"
- func_to_host_file_result="$func_convert_core_msys_to_w32_result"
- fi
- func_convert_file_check "$1" "$func_to_host_file_result"
-# end func_convert_file_msys_to_w32
-# func_convert_file_cygwin_to_w32 ARG
-# Convert file name ARG from Cygwin to w32 format. Returns result in
-func_convert_file_cygwin_to_w32 ()
- $opt_debug
- # because $build is cygwin, we call "the" cygpath in $PATH; no need to use
- # LT_CYGPATH in this case.
- func_to_host_file_result=`cygpath -m "$1"`
- fi
-# end func_convert_file_cygwin_to_w32
-# func_convert_file_nix_to_w32 ARG
-# Convert file name ARG from *nix to w32 format. Requires a wine environment
-# and a working winepath. Returns result in func_to_host_file_result.
-func_convert_file_nix_to_w32 ()
- $opt_debug
- func_convert_core_file_wine_to_w32 "$1"
- func_to_host_file_result="$func_convert_core_file_wine_to_w32_result"
- fi
-# end func_convert_file_nix_to_w32
-# func_convert_file_msys_to_cygwin ARG
-# Convert file name ARG from MSYS to Cygwin format. Requires LT_CYGPATH set.
-# Returns result in func_to_host_file_result.
-func_convert_file_msys_to_cygwin ()
- $opt_debug
- func_cygpath -u "$func_convert_core_msys_to_w32_result"
- func_to_host_file_result="$func_cygpath_result"
- fi
-# end func_convert_file_msys_to_cygwin
-# func_convert_file_nix_to_cygwin ARG
-# Convert file name ARG from *nix to Cygwin format. Requires Cygwin installed
-# in a wine environment, working winepath, and LT_CYGPATH set. Returns result
-func_convert_file_nix_to_cygwin ()
- $opt_debug
- # convert from *nix to w32, then use cygpath to convert from w32 to cygwin.
- func_cygpath -u "$func_convert_core_file_wine_to_w32_result"
- fi
-# end func_convert_file_nix_to_cygwin
-# $build to $host PATH CONVERSION FUNCTIONS #
-# invoked via `$to_host_path_cmd ARG'
-# The result will be available in $func_to_host_path_result.
-# Path separators are also converted from $build format to $host format. If
-# ARG begins or ends with a path separator character, it is preserved (but
-# converted to $host format) on output.
-# All path conversion functions are named using the following convention:
-# file name conversion function : func_convert_file_X_to_Y ()
-# path conversion function : func_convert_path_X_to_Y ()
-# where, for any given $build/$host combination the 'X_to_Y' value is the
-# same. If conversion functions are added for new $build/$host combinations,
-# the two new functions must follow this pattern, or func_init_to_host_path_cmd
-# will break.
-# func_init_to_host_path_cmd
-# Ensures that function "pointer" variable $to_host_path_cmd is set to the
-# appropriate value, based on the value of $to_host_file_cmd.
-to_host_path_cmd=
-func_init_to_host_path_cmd ()
- $opt_debug
- if test -z "$to_host_path_cmd"; then
- func_stripname 'func_convert_file_' '' "$to_host_file_cmd"
- to_host_path_cmd="func_convert_path_${func_stripname_result}"
- fi
-# func_to_host_path ARG
-# Converts the path ARG from $build format to $host format. Return result
-# in func_to_host_path_result.
-func_to_host_path ()
- $opt_debug
- func_init_to_host_path_cmd
- $to_host_path_cmd "$1"
-# end func_to_host_path
-# func_convert_path_noop ARG
-# Copy ARG to func_to_host_path_result.
-func_convert_path_noop ()
- func_to_host_path_result="$1"
-# end func_convert_path_noop
-# func_convert_path_msys_to_w32 ARG
-# Convert path ARG from (mingw) MSYS to (mingw) w32 format; automatic
-# func_to_host_path_result.
-func_convert_path_msys_to_w32 ()
- $opt_debug
- # Remove leading and trailing path separator characters from ARG. MSYS
- # behavior is inconsistent here; cygpath turns them into '.;' and ';.';
- # and winepath ignores them completely.
- func_stripname : : "$1"
- func_to_host_path_tmp1=$func_stripname_result
- func_convert_core_msys_to_w32 "$func_to_host_path_tmp1"
- func_to_host_path_result="$func_convert_core_msys_to_w32_result"
- func_convert_path_check : ";" \
- "$func_to_host_path_tmp1" "$func_to_host_path_result"
- func_convert_path_front_back_pathsep ":*" "*:" ";" "$1"
- fi
-# end func_convert_path_msys_to_w32
-# func_convert_path_cygwin_to_w32 ARG
-# Convert path ARG from Cygwin to w32 format. Returns result in
-func_convert_path_cygwin_to_w32 ()
- $opt_debug
- # See func_convert_path_msys_to_w32:
- func_to_host_path_result=`cygpath -m -p "$func_to_host_path_tmp1"`
- fi
-# end func_convert_path_cygwin_to_w32
-# func_convert_path_nix_to_w32 ARG
-# Convert path ARG from *nix to w32 format. Requires a wine environment and
-# a working winepath. Returns result in func_to_host_file_result.
-func_convert_path_nix_to_w32 ()
- $opt_debug
- func_convert_core_path_wine_to_w32 "$func_to_host_path_tmp1"
- func_to_host_path_result="$func_convert_core_path_wine_to_w32_result"
- fi
-# end func_convert_path_nix_to_w32
-# func_convert_path_msys_to_cygwin ARG
-# Convert path ARG from MSYS to Cygwin format. Requires LT_CYGPATH set.
-func_convert_path_msys_to_cygwin ()
- $opt_debug
- func_cygpath -u -p "$func_convert_core_msys_to_w32_result"
- func_to_host_path_result="$func_cygpath_result"
- func_convert_path_check : : \
- func_convert_path_front_back_pathsep ":*" "*:" : "$1"
- fi
-# end func_convert_path_msys_to_cygwin
-# func_convert_path_nix_to_cygwin ARG
-# Convert path ARG from *nix to Cygwin format. Requires Cygwin installed in a
-# a wine environment, working winepath, and LT_CYGPATH set. Returns result in
-func_convert_path_nix_to_cygwin ()
- $opt_debug
- # ARG. msys behavior is inconsistent here, cygpath turns them
- # into '.;' and ';.', and winepath ignores them completely.
- func_cygpath -u -p "$func_convert_core_path_wine_to_w32_result"
- fi
-# end func_convert_path_nix_to_cygwin
-# func_mode_compile arg...
-func_mode_compile ()
- $opt_debug
- # Get the compilation command and the source file.
- base_compile=
- srcfile="$nonopt" # always keep a non-empty value in "srcfile"
- suppress_opt=yes
- suppress_output=
- arg_mode=normal
- libobj=
- later=
- pie_flag=
- for arg
- do
- case $arg_mode in
- arg )
- # do not "continue". Instead, add this to base_compile
- lastarg="$arg"
- arg_mode=normal
- target )
- libobj="$arg"
- arg_mode=normal
- continue
- normal )
- # Accept any command-line options.
- case $arg in
- -o)
- test -n "$libobj" && \
- func_fatal_error "you cannot specify \`-o' more than once"
- arg_mode=target
- continue
- -pie | -fpie | -fPIE)
- func_append pie_flag " $arg"
- continue
- -shared | -static | -prefer-pic | -prefer-non-pic)
- func_append later " $arg"
- continue
- -no-suppress)
- suppress_opt=no
- continue
- -Xcompiler)
- arg_mode=arg # the next one goes into the "base_compile" arg list
- continue # The current "srcfile" will either be retained or
- ;; # replaced later. I would guess that would be a bug.
- -Wc,*)
- func_stripname '-Wc,' '' "$arg"
- args=$func_stripname_result
- lastarg=
- save_ifs="$IFS"; IFS=','
- for arg in $args; do
- IFS="$save_ifs"
- func_append_quoted lastarg "$arg"
- done
- IFS="$save_ifs"
- func_stripname ' ' '' "$lastarg"
- lastarg=$func_stripname_result
- # Add the arguments to base_compile.
- func_append base_compile " $lastarg"
- continue
- # Accept the current argument as the source file.
- # The previous "srcfile" becomes the current argument.
- lastarg="$srcfile"
- srcfile="$arg"
- esac # case $arg
- esac # case $arg_mode
- # Aesthetically quote the previous argument.
- func_append_quoted base_compile "$lastarg"
- done # for arg
- case $arg_mode in
- arg)
- func_fatal_error "you must specify an argument for -Xcompile"
- target)
- func_fatal_error "you must specify a target with \`-o'"
- # Get the name of the library object.
- test -z "$libobj" && {
- func_basename "$srcfile"
- libobj="$func_basename_result"
- esac
- # Recognize several different file suffixes.
- # If the user specifies -o file.o, it is replaced with file.lo
- case $libobj in
- *.[cCFSifmso] | \
- *.ada | *.adb | *.ads | *.asm | \
- *.c++ | *.cc | *.ii | *.class | *.cpp | *.cxx | \
- *.[fF][09]? | *.for | *.java | *.go | *.obj | *.sx | *.cu | *.cup)
- func_xform "$libobj"
- libobj=$func_xform_result
- esac
- case $libobj in
- *.lo) func_lo2o "$libobj"; obj=$func_lo2o_result ;;
- func_fatal_error "cannot determine name of library object from \`$libobj'"
- esac
- func_infer_tag $base_compile
- for arg in $later; do
- case $arg in
- -shared)
- test "$build_libtool_libs" != yes && \
- func_fatal_configuration "can not build a shared library"
- build_old_libs=no
- continue
- -static)
- build_libtool_libs=no
- build_old_libs=yes
- continue
- -prefer-pic)
- pic_mode=yes
- continue
- -prefer-non-pic)
- pic_mode=no
- continue
- esac
- done
- func_quote_for_eval "$libobj"
- test "X$libobj" != "X$func_quote_for_eval_result" \
- && $ECHO "X$libobj" | $GREP '[]~#^*{};<>?"'"'"' &()|`$[]' \
- && func_warning "libobj name \`$libobj' may not contain shell special characters."
- func_dirname_and_basename "$obj" "/" ""
- objname="$func_basename_result"
- xdir="$func_dirname_result"
- lobj=${xdir}$objdir/$objname
- test -z "$base_compile" && \
- func_fatal_help "you must specify a compilation command"
- # Delete any leftover library objects.
- removelist="$obj $lobj $libobj ${libobj}T"
- else
- removelist="$lobj $libobj ${libobj}T"
- fi
- # On Cygwin there's no "real" PIC flag so we must build both object types
- case $host_os in
- cygwin* | mingw* | pw32* | os2* | cegcc*)
- pic_mode=default
- esac
- if test "$pic_mode" = no && test "$deplibs_check_method" != pass_all; then
- # non-PIC code in shared libraries is not supported
- pic_mode=default
- fi
- # Calculate the filename of the output object if compiler does
- # not support -o with -c
- if test "$compiler_c_o" = no; then
- output_obj=`$ECHO "$srcfile" | $SED 's%^.*/%%; s%\.[^.]*$%%'`.${objext}
- lockfile="$output_obj.lock"
- else
- output_obj=
- need_locks=no
- lockfile=
- fi
- # Lock this critical section if it is needed
- # We use this script file to make the link, it avoids creating a new file
- if test "$need_locks" = yes; then
- until $opt_dry_run || ln "$progpath" "$lockfile" 2>/dev/null; do
- func_echo "Waiting for $lockfile to be removed"
- sleep 2
- done
- elif test "$need_locks" = warn; then
- if test -f "$lockfile"; then
- $ECHO "\
-*** ERROR, $lockfile exists and contains:
-`cat $lockfile 2>/dev/null`
-This indicates that another process is trying to use the same
-temporary object file, and libtool could not work around it because
-your compiler does not support \`-c' and \`-o' together. If you
-repeat this compilation, it may succeed, by chance, but you had better
-avoid parallel builds (make -j) in this platform, or get a better
-compiler."
- $opt_dry_run || $RM $removelist
- fi
- func_append removelist " $output_obj"
- $ECHO "$srcfile" > "$lockfile"
- fi
- func_append removelist " $lockfile"
- trap '$opt_dry_run || $RM $removelist; exit $EXIT_FAILURE' 1 2 15
- func_to_tool_file "$srcfile" func_convert_file_msys_to_w32
- srcfile=$func_to_tool_file_result
- func_quote_for_eval "$srcfile"
- qsrcfile=$func_quote_for_eval_result
- # Only build a PIC object if we are building libtool libraries.
- # Without this assignment, base_compile gets emptied.
- fbsd_hideous_sh_bug=$base_compile
- if test "$pic_mode" != no; then
- command="$base_compile $qsrcfile $pic_flag"
- else
- # Don't build PIC code
- command="$base_compile $qsrcfile"
- fi
- func_mkdir_p "$xdir$objdir"
- if test -z "$output_obj"; then
- # Place PIC objects in $objdir
- func_append command " -o $lobj"
- fi
- func_show_eval_locale "$command" \
- 'test -n "$output_obj" && $RM $removelist; exit $EXIT_FAILURE'
- if test "$need_locks" = warn &&
- test "X`cat $lockfile 2>/dev/null`" != "X$srcfile"; then
- $ECHO "\
-*** ERROR, $lockfile contains:
-but it should contain:
-$srcfile
-compiler."
- fi
- # Just move the object if needed, then go on to compile the next one
- if test -n "$output_obj" && test "X$output_obj" != "X$lobj"; then
- func_show_eval '$MV "$output_obj" "$lobj"' \
- 'error=$?; $opt_dry_run || $RM $removelist; exit $error'
- fi
- # Allow error messages only from the first compilation.
- if test "$suppress_opt" = yes; then
- suppress_output=' >/dev/null 2>&1'
- fi
- fi
- # Only build a position-dependent object if we build old libraries.
- if test "$pic_mode" != yes; then
- command="$base_compile $qsrcfile$pie_flag"
- else
- fi
- if test "$compiler_c_o" = yes; then
- func_append command " -o $obj"
- fi
- # Suppress compiler output if we already did a PIC compilation.
- func_append command "$suppress_output"
- '$opt_dry_run || $RM $removelist; exit $EXIT_FAILURE'
- $ECHO "\
-$srcfile
-compiler."
- fi
- if test -n "$output_obj" && test "X$output_obj" != "X$obj"; then
- func_show_eval '$MV "$output_obj" "$obj"' \
- fi
- fi
- $opt_dry_run || {
- func_write_libtool_object "$libobj" "$objdir/$objname" "$objname"
- # Unlock the critical section if it was locked
- if test "$need_locks" != no; then
- removelist=$lockfile
- $RM "$lockfile"
- fi
- exit $EXIT_SUCCESS
-$opt_help || {
- test "$opt_mode" = compile && func_mode_compile ${1+"$@"}
-func_mode_help ()
- # We need to display help for each of the modes.
- case $opt_mode in
- # Generic help is extracted from the usage comments
- # at the start of this file.
- func_help
- clean)
- $ECHO \
-"Usage: $progname [OPTION]... --mode=clean RM [RM-OPTION]... FILE...
-Remove files from the build directory.
-RM is the name of the program to use to delete files associated with each FILE
-(typically \`/bin/rm'). RM-OPTIONS are options (such as \`-f') to be passed
-to RM.
-If FILE is a libtool library, object or program, all the files associated
-with it are deleted. Otherwise, only FILE itself is deleted using RM."
- compile)
- $ECHO \
-"Usage: $progname [OPTION]... --mode=compile COMPILE-COMMAND... SOURCEFILE
-Compile a source file into a libtool library object.
-This mode accepts the following additional options:
- -o OUTPUT-FILE set the output file name to OUTPUT-FILE
- -no-suppress do not suppress compiler output for multiple passes
- -prefer-pic try to build PIC objects only
- -prefer-non-pic try to build non-PIC objects only
- -shared do not build a \`.o' file suitable for static linking
- -static only build a \`.o' file suitable for static linking
- -Wc,FLAG pass FLAG directly to the compiler
-COMPILE-COMMAND is a command to be used in creating a \`standard' object file
-from the given SOURCEFILE.
-The output file name is determined by removing the directory component from
-SOURCEFILE, then substituting the C source code suffix \`.c' with the
-library object suffix, \`.lo'."
- execute)
- $ECHO \
-"Usage: $progname [OPTION]... --mode=execute COMMAND [ARGS]...
-Automatically set library path, then run a program.
- -dlopen FILE add the directory containing FILE to the library path
-This mode sets the library path environment variable according to \`-dlopen'
-flags.
-If any of the ARGS are libtool executable wrappers, then they are translated
-into their corresponding uninstalled binary, and any of their required library
-directories are added to the library path.
-Then, COMMAND is executed, with ARGS as arguments."
- finish)
- $ECHO \
-"Usage: $progname [OPTION]... --mode=finish [LIBDIR]...
-Complete the installation of libtool libraries.
-Each LIBDIR is a directory that contains libtool libraries.
-The commands that this mode executes may require superuser privileges. Use
-the \`--dry-run' option if you just want to see what would be executed."
- install)
- $ECHO \
-"Usage: $progname [OPTION]... --mode=install INSTALL-COMMAND...
-Install executables or libraries.
-INSTALL-COMMAND is the installation command. The first component should be
-either the \`install' or \`cp' program.
-The following components of INSTALL-COMMAND are treated specially:
- -inst-prefix-dir PREFIX-DIR Use PREFIX-DIR as a staging area for installation
-The rest of the components are interpreted as arguments to that command (only
-BSD-compatible install options are recognized)."
- link)
- $ECHO \
-"Usage: $progname [OPTION]... --mode=link LINK-COMMAND...
-Link object files or libraries together to form another library, or to
-create an executable program.
-LINK-COMMAND is a command using the C compiler that you would use to create
-a program from several object files.
-The following components of LINK-COMMAND are treated specially:
- -all-static do not do any dynamic linking at all
- -avoid-version do not add a version suffix if possible
- -bindir BINDIR specify path to binaries directory (for systems where
- libraries must be found in the PATH setting at runtime)
- -dlopen FILE \`-dlpreopen' FILE if it cannot be dlopened at runtime
- -dlpreopen FILE link in FILE and add its symbols to lt_preloaded_symbols
- -export-dynamic allow symbols from OUTPUT-FILE to be resolved with dlsym(3)
- -export-symbols SYMFILE
- try to export only the symbols listed in SYMFILE
- -export-symbols-regex REGEX
- try to export only the symbols matching REGEX
- -LLIBDIR search LIBDIR for required installed libraries
- -lNAME OUTPUT-FILE requires the installed library libNAME
- -module build a library that can dlopened
- -no-fast-install disable the fast-install mode
- -no-install link a not-installable executable
- -no-undefined declare that a library does not refer to external symbols
- -o OUTPUT-FILE create OUTPUT-FILE from the specified objects
- -objectlist FILE Use a list of object files found in FILE to specify objects
- -precious-files-regex REGEX
- don't remove output files matching REGEX
- -release RELEASE specify package release information
- -rpath LIBDIR the created library will eventually be installed in LIBDIR
- -R[ ]LIBDIR add LIBDIR to the runtime path of programs and libraries
- -shared only do dynamic linking of libtool libraries
- -shrext SUFFIX override the standard shared library file extension
- -static do not do any dynamic linking of uninstalled libtool libraries
- -static-libtool-libs
- do not do any dynamic linking of libtool libraries
- -version-info CURRENT[:REVISION[:AGE]]
- specify library version info [each variable defaults to 0]
- -weak LIBNAME declare that the target provides the LIBNAME interface
- -Wc,FLAG
- -Xcompiler FLAG pass linker-specific FLAG directly to the compiler
- -Wl,FLAG
- -Xlinker FLAG pass linker-specific FLAG directly to the linker
- -XCClinker FLAG pass link-specific FLAG to the compiler driver (CC)
-All other options (arguments beginning with \`-') are ignored.
-Every other argument is treated as a filename. Files ending in \`.la' are
-treated as uninstalled libtool libraries, other files are standard or library
-object files.
-If the OUTPUT-FILE ends in \`.la', then a libtool library is created,
-only library objects (\`.lo' files) may be specified, and \`-rpath' is
-required, except when creating a convenience library.
-If OUTPUT-FILE ends in \`.a' or \`.lib', then a standard library is created
-using \`ar' and \`ranlib', or on Windows using \`lib'.
-If OUTPUT-FILE ends in \`.lo' or \`.${objext}', then a reloadable object file
-is created, otherwise an executable program is created."
- uninstall)
- $ECHO \
-"Usage: $progname [OPTION]... --mode=uninstall RM [RM-OPTION]... FILE...
-Remove libraries from an installation directory.
-to RM.
-If FILE is a libtool library, all the files associated with it are deleted.
-Otherwise, only FILE itself is deleted using RM."
- func_fatal_help "invalid operation mode \`$opt_mode'"
- esac
- echo
- $ECHO "Try \`$progname --help' for more information about other modes."
-# Now that we've collected a possible --mode arg, show help if necessary
-if $opt_help; then
- if test "$opt_help" = :; then
- func_mode_help
- else
- func_help noexit
- for opt_mode in compile link execute install finish uninstall clean; do
- func_mode_help
- done
- } | sed -n '1p; 2,$s/^Usage:/ or: /p'
- func_help noexit
- echo
- func_mode_help
- done
- sed '1d
- /^When reporting/,/^Report/{
- H
- d
- $x
- /information about other modes/d
- /more detailed .*MODE/d
- s/^Usage:.*--mode=\([^ ]*\) .*/Description of \1 mode:/'
- fi
- exit $?
-fi
-# func_mode_execute arg...
-func_mode_execute ()
- $opt_debug
- # The first argument is the command name.
- cmd="$nonopt"
- test -z "$cmd" && \
- func_fatal_help "you must specify a COMMAND"
- # Handle -dlopen flags immediately.
- for file in $opt_dlopen; do
- test -f "$file" \
- || func_fatal_help "\`$file' is not a file"
- dir=
- case $file in
- *.la)
- func_resolve_sysroot "$file"
- file=$func_resolve_sysroot_result
- # Check to see that this really is a libtool archive.
- func_lalib_unsafe_p "$file" \
- || func_fatal_help "\`$lib' is not a valid libtool archive"
- # Read the libtool library.
- dlname=
- library_names=
- func_source "$file"
- # Skip this library if it cannot be dlopened.
- if test -z "$dlname"; then
- # Warn if it was a shared library.
- test -n "$library_names" && \
- func_warning "\`$file' was not linked with \`-export-dynamic'"
- continue
- fi
- func_dirname "$file" "" "."
- dir="$func_dirname_result"
- if test -f "$dir/$objdir/$dlname"; then
- func_append dir "/$objdir"
- else
- if test ! -f "$dir/$dlname"; then
- func_fatal_error "cannot find \`$dlname' in \`$dir' or \`$dir/$objdir'"
- fi
- fi
- *.lo)
- # Just add the directory containing the .lo file.
- func_warning "\`-dlopen' is ignored for non-libtool libraries and objects"
- continue
- esac
- # Get the absolute pathname.
- absdir=`cd "$dir" && pwd`
- test -n "$absdir" && dir="$absdir"
- # Now add the directory to shlibpath_var.
- if eval "test -z \"\$$shlibpath_var\""; then
- eval "$shlibpath_var=\"\$dir\""
- else
- eval "$shlibpath_var=\"\$dir:\$$shlibpath_var\""
- fi
- done
- # This variable tells wrapper scripts just to set shlibpath_var
- # rather than running their programs.
- libtool_execute_magic="$magic"
- # Check if any of the arguments is a wrapper script.
- args=
- for file
- do
- case $file in
- -* | *.la | *.lo ) ;;
- # Do a test to see if this is really a libtool program.
- if func_ltwrapper_script_p "$file"; then
- # Transform arg to wrapped name.
- file="$progdir/$program"
- elif func_ltwrapper_executable_p "$file"; then
- func_ltwrapper_scriptname "$file"
- func_source "$func_ltwrapper_scriptname_result"
- fi
- esac
- # Quote arguments (to preserve shell metacharacters).
- func_append_quoted args "$file"
- done
- if test "X$opt_dry_run" = Xfalse; then
- if test -n "$shlibpath_var"; then
- # Export the shlibpath_var.
- eval "export $shlibpath_var"
- fi
- # Restore saved environment variables
- for lt_var in LANG LANGUAGE LC_ALL LC_CTYPE LC_COLLATE LC_MESSAGES
- do
- eval "if test \"\${save_$lt_var+set}\" = set; then
- $lt_var=\$save_$lt_var; export $lt_var
- else
- $lt_unset $lt_var
- fi"
- done
- # Now prepare to actually exec the command.
- exec_cmd="\$cmd$args"
- else
- # Display what would be done.
- eval "\$ECHO \"\$shlibpath_var=\$$shlibpath_var\""
- echo "export $shlibpath_var"
- fi
- $ECHO "$cmd$args"
- fi
-test "$opt_mode" = execute && func_mode_execute ${1+"$@"}
-# func_mode_finish arg...
-func_mode_finish ()
- $opt_debug
- libs=
- libdirs=
- admincmds=
- for opt in "$nonopt" ${1+"$@"}
- do
- if test -d "$opt"; then
- func_append libdirs " $opt"
- elif test -f "$opt"; then
- if func_lalib_unsafe_p "$opt"; then
- func_append libs " $opt"
- else
- func_warning "\`$opt' is not a valid libtool archive"
- fi
- else
- func_fatal_error "invalid argument \`$opt'"
- fi
- done
- if test -n "$libs"; then
- if test -n "$lt_sysroot"; then
- sysroot_regex=`$ECHO "$lt_sysroot" | $SED "$sed_make_literal_regex"`
- sysroot_cmd="s/\([ ']\)$sysroot_regex/\1/g;"
- else
- sysroot_cmd=
- fi
- # Remove sysroot references
- if $opt_dry_run; then
- for lib in $libs; do
- echo "removing references to $lt_sysroot and \`=' prefixes from $lib"
- done
- else
- tmpdir=`func_mktempdir`
- sed -e "${sysroot_cmd} s/\([ ']-[LR]\)=/\1/g; s/\([ ']\)=/\1/g" $lib \
- > $tmpdir/tmp-la
- mv -f $tmpdir/tmp-la $lib
- done
- ${RM}r "$tmpdir"
- fi
- fi
- if test -n "$finish_cmds$finish_eval" && test -n "$libdirs"; then
- for libdir in $libdirs; do
- if test -n "$finish_cmds"; then
- # Do each command in the finish commands.
- func_execute_cmds "$finish_cmds" 'admincmds="$admincmds
-'"$cmd"'"'
- fi
- if test -n "$finish_eval"; then
- # Do the single finish_eval.
- eval cmds=\"$finish_eval\"
- $opt_dry_run || eval "$cmds" || func_append admincmds "
- $cmds"
- fi
- done
- fi
- # Exit here if they wanted silent mode.
- $opt_silent && exit $EXIT_SUCCESS
- echo "----------------------------------------------------------------------"
- echo "Libraries have been installed in:"
- $ECHO " $libdir"
- done
- echo
- echo "If you ever happen to want to link against installed libraries"
- echo "in a given directory, LIBDIR, you must either use libtool, and"
- echo "specify the full pathname of the library, or use the \`-LLIBDIR'"
- echo "flag during linking and do at least one of the following:"
- echo " - add LIBDIR to the \`$shlibpath_var' environment variable"
- echo " during execution"
- fi
- if test -n "$runpath_var"; then
- echo " - add LIBDIR to the \`$runpath_var' environment variable"
- echo " during linking"
- fi
- if test -n "$hardcode_libdir_flag_spec"; then
- libdir=LIBDIR
- eval flag=\"$hardcode_libdir_flag_spec\"
- $ECHO " - use the \`$flag' linker flag"
- fi
- if test -n "$admincmds"; then
- $ECHO " - have your system administrator run these commands:$admincmds"
- fi
- if test -f /etc/ld.so.conf; then
- echo " - have your system administrator add LIBDIR to \`/etc/ld.so.conf'"
- fi
- echo
- echo "See any operating system documentation about shared libraries for"
- case $host in
- solaris2.[6789]|solaris2.1[0-9])
- echo "more information, such as the ld(1), crle(1) and ld.so(8) manual"
- echo "pages."
- echo "more information, such as the ld(1) and ld.so(8) manual pages."
- esac
- fi
-test "$opt_mode" = finish && func_mode_finish ${1+"$@"}
-# func_mode_install arg...
-func_mode_install ()
- $opt_debug
- # There may be an optional sh(1) argument at the beginning of
- # install_prog (especially on Windows NT).
- if test "$nonopt" = "$SHELL" || test "$nonopt" = /bin/sh ||
- # Allow the use of GNU shtool's install command.
- case $nonopt in *shtool*) :;; *) false;; esac; then
- # Aesthetically quote it.
- func_quote_for_eval "$nonopt"
- install_prog="$func_quote_for_eval_result "
- arg=$1
- shift
- else
- install_prog=
- arg=$nonopt
- fi
- # The real first argument should be the name of the installation program.
- func_quote_for_eval "$arg"
- func_append install_prog "$func_quote_for_eval_result"
- install_shared_prog=$install_prog
- case " $install_prog " in
- *[\\\ /]cp\ *) install_cp=: ;;
- *) install_cp=false ;;
- esac
- # We need to accept at least all the BSD install flags.
- dest=
- files=
- opts=
- prev=
- install_type=
- isdir=no
- stripme=
- no_mode=:
- for arg
- do
- arg2=
- if test -n "$dest"; then
- func_append files " $dest"
- dest=$arg
- continue
- fi
- case $arg in
- -d) isdir=yes ;;
- -f)
- if $install_cp; then :; else
- prev=$arg
- fi
- -g | -m | -o)
- prev=$arg
- -s)
- stripme=" -s"
- continue
- # If the previous option needed an argument, then skip it.
- if test -n "$prev"; then
- if test "x$prev" = x-m && test -n "$install_override_mode"; then
- arg2=$install_override_mode
- no_mode=false
- fi
- prev=
- else
- dest=$arg
- continue
- fi
- esac
- # Aesthetically quote the argument.
- func_append install_prog " $func_quote_for_eval_result"
- if test -n "$arg2"; then
- func_quote_for_eval "$arg2"
- fi
- func_append install_shared_prog " $func_quote_for_eval_result"
- done
- test -z "$install_prog" && \
- func_fatal_help "you must specify an install program"
- test -n "$prev" && \
- func_fatal_help "the \`$prev' option requires an argument"
- if test -n "$install_override_mode" && $no_mode; then
- func_quote_for_eval "$install_override_mode"
- func_append install_shared_prog " -m $func_quote_for_eval_result"
- fi
- fi
- if test -z "$files"; then
- if test -z "$dest"; then
- func_fatal_help "no file or destination specified"
- else
- func_fatal_help "you must specify a destination"
- fi
- fi
- # Strip any trailing slash from the destination.
- func_stripname '' '/' "$dest"
- dest=$func_stripname_result
- # Check to see that the destination is a directory.
- test -d "$dest" && isdir=yes
- if test "$isdir" = yes; then
- destdir="$dest"
- destname=
- else
- func_dirname_and_basename "$dest" "" "."
- destdir="$func_dirname_result"
- destname="$func_basename_result"
- # Not a directory, so check to see that there is only one file specified.
- set dummy $files; shift
- test "$#" -gt 1 && \
- func_fatal_help "\`$dest' is not a directory"
- fi
- case $destdir in
- [\\/]* | [A-Za-z]:[\\/]*) ;;
- for file in $files; do
- case $file in
- *.lo) ;;
- func_fatal_help "\`$destdir' must be an absolute directory name"
- esac
- done
- esac
- # This variable tells wrapper scripts just to set variables rather
- # than running their programs.
- libtool_install_magic="$magic"
- staticlibs=
- future_libdirs=
- current_libdirs=
- # Do each installation.
- case $file in
- *.$libext)
- # Do the static libraries later.
- func_append staticlibs " $file"
- *.la)
- || func_fatal_help "\`$file' is not a valid libtool archive"
- library_names=
- old_library=
- relink_command=
- # Add the libdir to current_libdirs if it is the destination.
- if test "X$destdir" = "X$libdir"; then
- case "$current_libdirs " in
- *" $libdir "*) ;;
- *) func_append current_libdirs " $libdir" ;;
- esac
- else
- # Note the libdir as a future libdir.
- case "$future_libdirs " in
- *" $libdir "*) ;;
- *) func_append future_libdirs " $libdir" ;;
- esac
- fi
- func_dirname "$file" "/" ""
- func_append dir "$objdir"
- if test -n "$relink_command"; then
- # Determine the prefix the user has applied to our future dir.
- inst_prefix_dir=`$ECHO "$destdir" | $SED -e "s%$libdir\$%%"`
- # Don't allow the user to place us outside of our expected
- # location b/c this prevents finding dependent libraries that
- # are installed to the same prefix.
- # At present, this check doesn't affect windows .dll's that
- # are installed into $libdir/../bin (currently, that works fine)
- # but it's something to keep an eye on.
- test "$inst_prefix_dir" = "$destdir" && \
- func_fatal_error "error: cannot install \`$file' to a directory not ending in $libdir"
- if test -n "$inst_prefix_dir"; then
- # Stick the inst_prefix_dir data into the link command.
- relink_command=`$ECHO "$relink_command" | $SED "s%@inst_prefix_dir@%-inst-prefix-dir $inst_prefix_dir%"`
- else
- relink_command=`$ECHO "$relink_command" | $SED "s%@inst_prefix_dir@%%"`
- fi
- func_warning "relinking \`$file'"
- func_show_eval "$relink_command" \
- 'func_fatal_error "error: relink \`$file'\'' with the above command before installing it"'
- fi
- # See the names of the shared library.
- set dummy $library_names; shift
- realname="$1"
- shift
- srcname="$realname"
- test -n "$relink_command" && srcname="$realname"T
- # Install the shared library and build the symlinks.
- func_show_eval "$install_shared_prog $dir/$srcname $destdir/$realname" \
- 'exit $?'
- tstripme="$stripme"
- case $host_os in
- cygwin* | mingw* | pw32* | cegcc*)
- case $realname in
- *.dll.a)
- tstripme=""
- esac
- esac
- if test -n "$tstripme" && test -n "$striplib"; then
- func_show_eval "$striplib $destdir/$realname" 'exit $?'
- fi
- # Delete the old symlinks, and create new ones.
- # Try `ln -sf' first, because the `ln' binary might depend on
- # the symlink we replace! Solaris /bin/ln does not understand -f,
- # so we also need to try rm && ln -s.
- for linkname
- do
- test "$linkname" != "$realname" \
- && func_show_eval "(cd $destdir && { $LN_S -f $realname $linkname || { $RM $linkname && $LN_S $realname $linkname; }; })"
- done
- fi
- # Do each command in the postinstall commands.
- lib="$destdir/$realname"
- func_execute_cmds "$postinstall_cmds" 'exit $?'
- fi
- # Install the pseudo-library for information purposes.
- func_basename "$file"
- name="$func_basename_result"
- instname="$dir/$name"i
- func_show_eval "$install_prog $instname $destdir/$name" 'exit $?'
- # Maybe install the static library, too.
- test -n "$old_library" && func_append staticlibs " $dir/$old_library"
- *.lo)
- # Install (i.e. copy) a libtool object.
- # Figure out destination file name, if it wasn't already specified.
- if test -n "$destname"; then
- destfile="$destdir/$destname"
- else
- destfile="$func_basename_result"
- destfile="$destdir/$destfile"
- fi
- # Deduce the name of the destination old-style object file.
- case $destfile in
- *.lo)
- func_lo2o "$destfile"
- staticdest=$func_lo2o_result
- *.$objext)
- staticdest="$destfile"
- destfile=
- func_fatal_help "cannot copy a libtool object to \`$destfile'"
- esac
- # Install the libtool object if requested.
- test -n "$destfile" && \
- func_show_eval "$install_prog $file $destfile" 'exit $?'
- # Install the old object if enabled.
- # Deduce the name of the old-style object file.
- func_lo2o "$file"
- staticobj=$func_lo2o_result
- func_show_eval "$install_prog \$staticobj \$staticdest" 'exit $?'
- fi
- else
- fi
- # If the file is missing, and there is a .exe on the end, strip it
- # because it is most likely a libtool script we actually want to
- # install
- stripped_ext=""
- case $file in
- *.exe)
- if test ! -f "$file"; then
- func_stripname '' '.exe' "$file"
- file=$func_stripname_result
- stripped_ext=".exe"
- fi
- esac
- case $host in
- *cygwin* | *mingw*)
- if func_ltwrapper_executable_p "$file"; then
- wrapper=$func_ltwrapper_scriptname_result
- else
- wrapper=$func_stripname_result
- fi
- wrapper=$file
- esac
- if func_ltwrapper_script_p "$wrapper"; then
- notinst_deplibs=
- relink_command=
- func_source "$wrapper"
- # Check the variables that should have been set.
- test -z "$generated_by_libtool_version" && \
- func_fatal_error "invalid libtool wrapper script \`$wrapper'"
- finalize=yes
- for lib in $notinst_deplibs; do
- # Check to see that each library is installed.
- libdir=
- if test -f "$lib"; then
- func_source "$lib"
- fi
- libfile="$libdir/"`$ECHO "$lib" | $SED 's%^.*/%%g'` ### testsuite: skip nested quoting test
- if test -n "$libdir" && test ! -f "$libfile"; then
- func_warning "\`$lib' has not been installed in \`$libdir'"
- finalize=no
- fi
- done
- relink_command=
- outputname=
- if test "$fast_install" = no && test -n "$relink_command"; then
- $opt_dry_run || {
- if test "$finalize" = yes; then
- func_basename "$file$stripped_ext"
- file="$func_basename_result"
- outputname="$tmpdir/$file"
- # Replace the output file specification.
- relink_command=`$ECHO "$relink_command" | $SED 's%@OUTPUT@%'"$outputname"'%g'`
- $opt_silent || {
- func_quote_for_expand "$relink_command"
- eval "func_echo $func_quote_for_expand_result"
- if eval "$relink_command"; then :
- else
- func_error "error: relink \`$file' with the above command before installing it"
- $opt_dry_run || ${RM}r "$tmpdir"
- continue
- fi
- file="$outputname"
- else
- func_warning "cannot relink \`$file'"
- fi
- else
- # Install the binary that we compiled earlier.
- file=`$ECHO "$file$stripped_ext" | $SED "s%\([^/]*\)$%$objdir/\1%"`
- fi
- fi
- # remove .exe since cygwin /usr/bin/install will append another
- # one anyway
- case $install_prog,$host in
- */usr/bin/install*,*cygwin*)
- case $file:$destfile in
- *.exe:*.exe)
- # this is ok
- *.exe:*)
- destfile=$destfile.exe
- *:*.exe)
- func_stripname '' '.exe' "$destfile"
- destfile=$func_stripname_result
- esac
- esac
- func_show_eval "$install_prog\$stripme \$file \$destfile" 'exit $?'
- $opt_dry_run || if test -n "$outputname"; then
- ${RM}r "$tmpdir"
- fi
- esac
- done
- for file in $staticlibs; do
- # Set up the ranlib parameters.
- oldlib="$destdir/$name"
- func_to_tool_file "$oldlib" func_convert_file_msys_to_w32
- tool_oldlib=$func_to_tool_file_result
- func_show_eval "$install_prog \$file \$oldlib" 'exit $?'
- if test -n "$stripme" && test -n "$old_striplib"; then
- func_show_eval "$old_striplib $tool_oldlib" 'exit $?'
- fi
- func_execute_cmds "$old_postinstall_cmds" 'exit $?'
- done
- test -n "$future_libdirs" && \
- func_warning "remember to run \`$progname --finish$future_libdirs'"
- if test -n "$current_libdirs"; then
- # Maybe just do a dry run.
- $opt_dry_run && current_libdirs=" -n$current_libdirs"
- exec_cmd='$SHELL $progpath $preserve_args --finish$current_libdirs'
- else
- fi
-test "$opt_mode" = install && func_mode_install ${1+"$@"}
-# func_generate_dlsyms outputname originator pic_p
-# Extract symbols from dlprefiles and create ${outputname}S.o with
-# a dlpreopen symbol table.
-func_generate_dlsyms ()
- $opt_debug
- my_outputname="$1"
- my_originator="$2"
- my_pic_p="${3-no}"
- my_prefix=`$ECHO "$my_originator" | sed 's%[^a-zA-Z0-9]%_%g'`
- my_dlsyms=
- if test -n "$dlfiles$dlprefiles" || test "$dlself" != no; then
- if test -n "$NM" && test -n "$global_symbol_pipe"; then
- my_dlsyms="${my_outputname}S.c"
- else
- func_error "not configured to extract global symbols from dlpreopened files"
- fi
- fi
- if test -n "$my_dlsyms"; then
- case $my_dlsyms in
- *.c)
- # Discover the nlist of each of the dlfiles.
- nlist="$output_objdir/${my_outputname}.nm"
- func_show_eval "$RM $nlist ${nlist}S ${nlist}T"
- # Parse the name list into a source file.
- func_verbose "creating $output_objdir/$my_dlsyms"
- $opt_dry_run || $ECHO > "$output_objdir/$my_dlsyms" "\
-/* $my_dlsyms - symbol resolution table for \`$my_outputname' dlsym emulation. */
-/* Generated by $PROGRAM (GNU $PACKAGE$TIMESTAMP) $VERSION */
-#ifdef __cplusplus
-extern \"C\" {
-#endif
-#if defined(__GNUC__) && (((__GNUC__ == 4) && (__GNUC_MINOR__ >= 4)) || (__GNUC__ > 4))
-#pragma GCC diagnostic ignored \"-Wstrict-prototypes\"
-#endif
-/* Keep this code in sync between libtool.m4, ltmain, lt_system.h, and tests. */
-#if defined(_WIN32) || defined(__CYGWIN__) || defined(_WIN32_WCE)
-/* DATA imports from DLLs on WIN32 con't be const, because runtime
- relocations are performed -- see ld's documentation on pseudo-relocs. */
-# define LT_DLSYM_CONST
-#elif defined(__osf__)
-/* This system does not cope well with relocations in const data. */
-#else
-# define LT_DLSYM_CONST const
-#endif
-/* External symbol declarations for the compiler. */\
- if test "$dlself" = yes; then
- func_verbose "generating symbol list for \`$output'"
- $opt_dry_run || echo ': @PROGRAM@ ' > "$nlist"
- # Add our own program objects to the symbol list.
- progfiles=`$ECHO "$objs$old_deplibs" | $SP2NL | $SED "$lo2o" | $NL2SP`
- for progfile in $progfiles; do
- func_to_tool_file "$progfile" func_convert_file_msys_to_w32
- func_verbose "extracting global C symbols from \`$func_to_tool_file_result'"
- $opt_dry_run || eval "$NM $func_to_tool_file_result | $global_symbol_pipe >> '$nlist'"
- done
- if test -n "$exclude_expsyms"; then
- $opt_dry_run || {
- eval '$EGREP -v " ($exclude_expsyms)$" "$nlist" > "$nlist"T'
- eval '$MV "$nlist"T "$nlist"'
- fi
- if test -n "$export_symbols_regex"; then
- $opt_dry_run || {
- eval '$EGREP -e "$export_symbols_regex" "$nlist" > "$nlist"T'
- fi
- # Prepare the list of exported symbols
- if test -z "$export_symbols"; then
- export_symbols="$output_objdir/$outputname.exp"
- $opt_dry_run || {
- $RM $export_symbols
- eval "${SED} -n -e '/^: @PROGRAM@ $/d' -e 's/^.* \(.*\)$/\1/p' "'< "$nlist" > "$export_symbols"'
- case $host in
- *cygwin* | *mingw* | *cegcc* )
- eval "echo EXPORTS "'> "$output_objdir/$outputname.def"'
- eval 'cat "$export_symbols" >> "$output_objdir/$outputname.def"'
- esac
- else
- $opt_dry_run || {
- eval "${SED} -e 's/\([].[*^$]\)/\\\\\1/g' -e 's/^/ /' -e 's/$/$/'"' < "$export_symbols" > "$output_objdir/$outputname.exp"'
- eval '$GREP -f "$output_objdir/$outputname.exp" < "$nlist" > "$nlist"T'
- case $host in
- eval 'cat "$nlist" >> "$output_objdir/$outputname.def"'
- esac
- fi
- fi
- for dlprefile in $dlprefiles; do
- func_verbose "extracting global C symbols from \`$dlprefile'"
- func_basename "$dlprefile"
- case $host in
- # if an import library, we need to obtain dlname
- if func_win32_import_lib_p "$dlprefile"; then
- func_tr_sh "$dlprefile"
- eval "curr_lafile=\$libfile_$func_tr_sh_result"
- dlprefile_dlbasename=""
- if test -n "$curr_lafile" && func_lalib_p "$curr_lafile"; then
- # Use subshell, to avoid clobbering current variable values
- dlprefile_dlname=`source "$curr_lafile" && echo "$dlname"`
- if test -n "$dlprefile_dlname" ; then
- func_basename "$dlprefile_dlname"
- dlprefile_dlbasename="$func_basename_result"
- else
- # no lafile. user explicitly requested -dlpreopen <import library>.
- $sharedlib_from_linklib_cmd "$dlprefile"
- dlprefile_dlbasename=$sharedlib_from_linklib_result
- fi
- fi
- $opt_dry_run || {
- if test -n "$dlprefile_dlbasename" ; then
- eval '$ECHO ": $dlprefile_dlbasename" >> "$nlist"'
- else
- func_warning "Could not compute DLL name from $name"
- eval '$ECHO ": $name " >> "$nlist"'
- fi
- func_to_tool_file "$dlprefile" func_convert_file_msys_to_w32
- eval "$NM \"$func_to_tool_file_result\" 2>/dev/null | $global_symbol_pipe |
- $SED -e '/I __imp/d' -e 's/I __nm_/D /;s/_nm__//' >> '$nlist'"
- else # not an import lib
- $opt_dry_run || {
- eval "$NM \"$func_to_tool_file_result\" 2>/dev/null | $global_symbol_pipe >> '$nlist'"
- fi
- $opt_dry_run || {
- esac
- done
- $opt_dry_run || {
- # Make sure we have at least an empty file.
- test -f "$nlist" || : > "$nlist"
- $EGREP -v " ($exclude_expsyms)$" "$nlist" > "$nlist"T
- $MV "$nlist"T "$nlist"
- fi
- # Try sorting and uniquifying the output.
- if $GREP -v "^: " < "$nlist" |
- if sort -k 3 </dev/null >/dev/null 2>&1; then
- sort -k 3
- else
- sort +2
- fi |
- uniq > "$nlist"S; then
- else
- $GREP -v "^: " < "$nlist" > "$nlist"S
- fi
- if test -f "$nlist"S; then
- eval "$global_symbol_to_cdecl"' < "$nlist"S >> "$output_objdir/$my_dlsyms"'
- else
- echo '/* NONE */' >> "$output_objdir/$my_dlsyms"
- fi
- echo >> "$output_objdir/$my_dlsyms" "\
-/* The mapping between symbol names and symbols. */
-typedef struct {
- const char *name;
- void *address;
-} lt_dlsymlist;
-extern LT_DLSYM_CONST lt_dlsymlist
-lt_${my_prefix}_LTX_preloaded_symbols[];
-LT_DLSYM_CONST lt_dlsymlist
-lt_${my_prefix}_LTX_preloaded_symbols[] =
- { \"$my_originator\", (void *) 0 },"
- case $need_lib_prefix in
- no)
- eval "$global_symbol_to_c_name_address" < "$nlist" >> "$output_objdir/$my_dlsyms"
- eval "$global_symbol_to_c_name_address_lib_prefix" < "$nlist" >> "$output_objdir/$my_dlsyms"
- esac
- {0, (void *) 0}
-/* This works around a problem in FreeBSD linker */
-#ifdef FREEBSD_WORKAROUND
-static const void *lt_preloaded_setup() {
- return lt_${my_prefix}_LTX_preloaded_symbols;
-#endif
-#ifdef __cplusplus
-#endif\
- } # !$opt_dry_run
- pic_flag_for_symtable=
- case "$compile_command " in
- *" -static "*) ;;
- case $host in
- # compiling the symbol table file with pic_flag works around
- # a FreeBSD bug that causes programs to crash when -lm is
- # linked before any other PIC object. But we must not use
- # pic_flag when linking with -static. The problem exists in
- # FreeBSD 2.2.6 and is fixed in FreeBSD 3.1.
- *-*-freebsd2.*|*-*-freebsd3.0*|*-*-freebsdelf3.0*)
- pic_flag_for_symtable=" $pic_flag -DFREEBSD_WORKAROUND" ;;
- *-*-hpux*)
- pic_flag_for_symtable=" $pic_flag" ;;
- if test "X$my_pic_p" != Xno; then
- fi
- esac
- esac
- symtab_cflags=
- for arg in $LTCFLAGS; do
- case $arg in
- -pie | -fpie | -fPIE) ;;
- *) func_append symtab_cflags " $arg" ;;
- esac
- done
- # Now compile the dynamic symbol file.
- func_show_eval '(cd $output_objdir && $LTCC$symtab_cflags -c$no_builtin_flag$pic_flag_for_symtable "$my_dlsyms")' 'exit $?'
- # Clean up the generated files.
- func_show_eval '$RM "$output_objdir/$my_dlsyms" "$nlist" "${nlist}S" "${nlist}T"'
- # Transform the symbol file into the correct name.
- symfileobj="$output_objdir/${my_outputname}S.$objext"
- case $host in
- if test -f "$output_objdir/$my_outputname.def"; then
- compile_command=`$ECHO "$compile_command" | $SED "s%@SYMFILE@%$output_objdir/$my_outputname.def $symfileobj%"`
- finalize_command=`$ECHO "$finalize_command" | $SED "s%@SYMFILE@%$output_objdir/$my_outputname.def $symfileobj%"`
- else
- compile_command=`$ECHO "$compile_command" | $SED "s%@SYMFILE@%$symfileobj%"`
- finalize_command=`$ECHO "$finalize_command" | $SED "s%@SYMFILE@%$symfileobj%"`
- fi
- esac
- func_fatal_error "unknown suffix for \`$my_dlsyms'"
- esac
- else
- # We keep going just in case the user didn't refer to
- # lt_preloaded_symbols. The linker will fail if global_symbol_pipe
- # really was required.
- # Nullify the symbol file.
- compile_command=`$ECHO "$compile_command" | $SED "s% @SYMFILE@%%"`
- finalize_command=`$ECHO "$finalize_command" | $SED "s% @SYMFILE@%%"`
- fi
-# func_win32_libid arg
-# return the library type of file 'arg'
-# Need a lot of goo to handle *both* DLLs and import libs
-# Has to be a shell function in order to 'eat' the argument
-# that is supplied when $file_magic_command is called.
-# Despite the name, also deal with 64 bit binaries.
-func_win32_libid ()
- $opt_debug
- win32_libid_type="unknown"
- win32_fileres=`file -L $1 2>/dev/null`
- case $win32_fileres in
- *ar\ archive\ import\ library*) # definitely import
- win32_libid_type="x86 archive import"
- *ar\ archive*) # could be an import, or static
- # Keep the egrep pattern in sync with the one in _LT_CHECK_MAGIC_METHOD.
- if eval $OBJDUMP -f $1 | $SED -e '10q' 2>/dev/null |
- $EGREP 'file format (pei*-i386(.*architecture: i386)?|pe-arm-wince|pe-x86-64)' >/dev/null; then
- func_to_tool_file "$1" func_convert_file_msys_to_w32
- win32_nmres=`eval $NM -f posix -A \"$func_to_tool_file_result\" |
- $SED -n -e '
- 1,100{
- / I /{
- s,.*,import,
- p
- q
- case $win32_nmres in
- import*) win32_libid_type="x86 archive import";;
- *) win32_libid_type="x86 archive static";;
- esac
- fi
- *DLL*)
- win32_libid_type="x86 DLL"
- *executable*) # but shell scripts are "executable" too...
- *MS\ Windows\ PE\ Intel*)
- esac
- esac
- $ECHO "$win32_libid_type"
-# func_cygming_dll_for_implib ARG
-# Platform-specific function to extract the
-# name of the DLL associated with the specified
-# import library ARG.
-# Invoked by eval'ing the libtool variable
-# $sharedlib_from_linklib_cmd
-# Result is available in the variable
-# $sharedlib_from_linklib_result
-func_cygming_dll_for_implib ()
- $opt_debug
- sharedlib_from_linklib_result=`$DLLTOOL --identify-strict --identify "$1"`
-# func_cygming_dll_for_implib_fallback_core SECTION_NAME LIBNAMEs
-# The is the core of a fallback implementation of a
-# platform-specific function to extract the name of the
-# DLL associated with the specified import library LIBNAME.
-# SECTION_NAME is either .idata$6 or .idata$7, depending
-# on the platform and compiler that created the implib.
-# Echos the name of the DLL associated with the
-# specified import library.
-func_cygming_dll_for_implib_fallback_core ()
- $opt_debug
- match_literal=`$ECHO "$1" | $SED "$sed_make_literal_regex"`
- $OBJDUMP -s --section "$1" "$2" 2>/dev/null |
- $SED '/^Contents of section '"$match_literal"':/{
- # Place marker at beginning of archive member dllname section
- s/.*/====MARK====/
- p
- d
- # These lines can sometimes be longer than 43 characters, but
- # are always uninteresting
- /:[ ]*file format pe[i]\{,1\}-/d
- /^In archive [^:]*:/d
- # Ensure marker is printed
- /^====MARK====/p
- # Remove all lines with less than 43 characters
- /^.\{43\}/!d
- # From remaining lines, remove first 43 characters
- s/^.\{43\}//' |
- $SED -n '
- # Join marker and all lines until next marker into a single line
- /^====MARK====/ b para
- H
- $ b para
- b
- :para
- x
- s/\n//g
- # Remove the marker
- s/^====MARK====//
- # Remove trailing dots and whitespace
- s/[\. \t]*$//
- # Print
- /./p' |
- # we now have a list, one entry per line, of the stringified
- # contents of the appropriate section of all members of the
- # archive which possess that section. Heuristic: eliminate
- # all those which have a first or second character that is
- # a '.' (that is, objdump's representation of an unprintable
- # character.) This should work for all archives with less than
- # 0x302f exports -- but will fail for DLLs whose name actually
- # begins with a literal '.' or a single character followed by
- # a '.'.
- # Of those that remain, print the first one.
- $SED -e '/^\./d;/^.\./d;q'
-# func_cygming_gnu_implib_p ARG
-# This predicate returns with zero status (TRUE) if
-# ARG is a GNU/binutils-style import library. Returns
-# with nonzero status (FALSE) otherwise.
-func_cygming_gnu_implib_p ()
- $opt_debug
- func_cygming_gnu_implib_tmp=`$NM "$func_to_tool_file_result" | eval "$global_symbol_pipe" | $EGREP ' (_head_[A-Za-z0-9_]+_[ad]l*|[A-Za-z0-9_]+_[ad]l*_iname)$'`
- test -n "$func_cygming_gnu_implib_tmp"
-# func_cygming_ms_implib_p ARG
-# ARG is an MS-style import library. Returns
-func_cygming_ms_implib_p ()
- $opt_debug
- func_cygming_ms_implib_tmp=`$NM "$func_to_tool_file_result" | eval "$global_symbol_pipe" | $GREP '_NULL_IMPORT_DESCRIPTOR'`
- test -n "$func_cygming_ms_implib_tmp"
-# func_cygming_dll_for_implib_fallback ARG
-# This fallback implementation is for use when $DLLTOOL
-# does not support the --identify-strict option.
-func_cygming_dll_for_implib_fallback ()
- $opt_debug
- if func_cygming_gnu_implib_p "$1" ; then
- # binutils import library
- sharedlib_from_linklib_result=`func_cygming_dll_for_implib_fallback_core '.idata$7' "$1"`
- elif func_cygming_ms_implib_p "$1" ; then
- # ms-generated import library
- sharedlib_from_linklib_result=`func_cygming_dll_for_implib_fallback_core '.idata$6' "$1"`
- else
- # unknown
- sharedlib_from_linklib_result=""
- fi
-# func_extract_an_archive dir oldlib
-func_extract_an_archive ()
- $opt_debug
- f_ex_an_ar_dir="$1"; shift
- f_ex_an_ar_oldlib="$1"
- if test "$lock_old_archive_extraction" = yes; then
- lockfile=$f_ex_an_ar_oldlib.lock
- sleep 2
- done
- fi
- func_show_eval "(cd \$f_ex_an_ar_dir && $AR x \"\$f_ex_an_ar_oldlib\")" \
- 'stat=$?; rm -f "$lockfile"; exit $stat'
- $opt_dry_run || rm -f "$lockfile"
- fi
- if ($AR t "$f_ex_an_ar_oldlib" | sort | sort -uc >/dev/null 2>&1); then
- else
- func_fatal_error "object name conflicts in archive: $f_ex_an_ar_dir/$f_ex_an_ar_oldlib"
- fi
-# func_extract_archives gentop oldlib ...
-func_extract_archives ()
- $opt_debug
- my_gentop="$1"; shift
- my_oldlibs=${1+"$@"}
- my_oldobjs=""
- my_xlib=""
- my_xabs=""
- my_xdir=""
- for my_xlib in $my_oldlibs; do
- # Extract the objects.
- case $my_xlib in
- [\\/]* | [A-Za-z]:[\\/]*) my_xabs="$my_xlib" ;;
- *) my_xabs=`pwd`"/$my_xlib" ;;
- esac
- func_basename "$my_xlib"
- my_xlib="$func_basename_result"
- my_xlib_u=$my_xlib
- while :; do
- case " $extracted_archives " in
- *" $my_xlib_u "*)
- func_arith $extracted_serial + 1
- extracted_serial=$func_arith_result
- my_xlib_u=lt$extracted_serial-$my_xlib ;;
- *) break ;;
- esac
- done
- extracted_archives="$extracted_archives $my_xlib_u"
- my_xdir="$my_gentop/$my_xlib_u"
- func_mkdir_p "$my_xdir"
- case $host in
- *-darwin*)
- func_verbose "Extracting $my_xabs"
- # Do not bother doing anything if just a dry run
- $opt_dry_run || {
- darwin_orig_dir=`pwd`
- cd $my_xdir || exit $?
- darwin_archive=$my_xabs
- darwin_curdir=`pwd`
- darwin_base_archive=`basename "$darwin_archive"`
- darwin_arches=`$LIPO -info "$darwin_archive" 2>/dev/null | $GREP Architectures 2>/dev/null || true`
- if test -n "$darwin_arches"; then
- darwin_arches=`$ECHO "$darwin_arches" | $SED -e 's/.*are://'`
- darwin_arch=
- func_verbose "$darwin_base_archive has multiple architectures $darwin_arches"
- for darwin_arch in $darwin_arches ; do
- func_mkdir_p "unfat-$$/${darwin_base_archive}-${darwin_arch}"
- $LIPO -thin $darwin_arch -output "unfat-$$/${darwin_base_archive}-${darwin_arch}/${darwin_base_archive}" "${darwin_archive}"
- cd "unfat-$$/${darwin_base_archive}-${darwin_arch}"
- func_extract_an_archive "`pwd`" "${darwin_base_archive}"
- cd "$darwin_curdir"
- $RM "unfat-$$/${darwin_base_archive}-${darwin_arch}/${darwin_base_archive}"
- done # $darwin_arches
- ## Okay now we've a bunch of thin objects, gotta fatten them up :)
- darwin_filelist=`find unfat-$$ -type f -name \*.o -print -o -name \*.lo -print | $SED -e "$basename" | sort -u`
- darwin_file=
- darwin_files=
- for darwin_file in $darwin_filelist; do
- darwin_files=`find unfat-$$ -name $darwin_file -print | sort | $NL2SP`
- $LIPO -create -output "$darwin_file" $darwin_files
- done # $darwin_filelist
- $RM -rf unfat-$$
- cd "$darwin_orig_dir"
- else
- cd $darwin_orig_dir
- func_extract_an_archive "$my_xdir" "$my_xabs"
- fi # $darwin_arches
- } # !$opt_dry_run
- esac
- my_oldobjs="$my_oldobjs "`find $my_xdir -name \*.$objext -print -o -name \*.lo -print | sort | $NL2SP`
- done
- func_extract_archives_result="$my_oldobjs"
-# func_emit_wrapper [arg=no]
-# Emit a libtool wrapper script on stdout.
-# Don't directly open a file because we may want to
-# incorporate the script contents within a cygwin/mingw
-# wrapper executable. Must ONLY be called from within
-# func_mode_link because it depends on a number of variables
-# set therein.
-# ARG is the value that the WRAPPER_SCRIPT_BELONGS_IN_OBJDIR
-# variable will take. If 'yes', then the emitted script
-# will assume that the directory in which it is stored is
-# the $objdir directory. This is a cygwin/mingw-specific
-# behavior.
-func_emit_wrapper ()
- func_emit_wrapper_arg1=${1-no}
- $ECHO "\
-#! $SHELL
-# $output - temporary wrapper script for $objdir/$outputname
-# Generated by $PROGRAM (GNU $PACKAGE$TIMESTAMP) $VERSION
-# The $output program cannot be directly executed until all the libtool
-# libraries that it depends on are installed.
-# This wrapper script should never be moved out of the build directory.
-# If it is, it will not operate correctly.
-# Sed substitution that helps us do robust quoting. It backslashifies
-# metacharacters that are still active within double-quoted strings.
-sed_quote_subst='$sed_quote_subst'
-# Be Bourne compatible
-if test -n \"\${ZSH_VERSION+set}\" && (emulate sh) >/dev/null 2>&1; then
- emulate sh
- NULLCMD=:
- # Zsh 3.x and 4.x performs word splitting on \${1+\"\$@\"}, which
- # is contrary to our usage. Disable this feature.
- alias -g '\${1+\"\$@\"}'='\"\$@\"'
- setopt NO_GLOB_SUBST
-else
- case \`(set -o) 2>/dev/null\` in *posix*) set -o posix;; esac
-fi
-BIN_SH=xpg4; export BIN_SH # for Tru64
-DUALCASE=1; export DUALCASE # for MKS sh
-# The HP-UX ksh and POSIX shell print the target directory to stdout
-# if CDPATH is set.
-(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
-relink_command=\"$relink_command\"
-# This environment variable determines our operation mode.
-if test \"\$libtool_install_magic\" = \"$magic\"; then
- # install mode needs the following variables:
- generated_by_libtool_version='$macro_version'
- notinst_deplibs='$notinst_deplibs'
-else
- # When we are sourced in execute mode, \$file and \$ECHO are already set.
- if test \"\$libtool_execute_magic\" != \"$magic\"; then
- file=\"\$0\""
- qECHO=`$ECHO "$ECHO" | $SED "$sed_quote_subst"`
- $ECHO "\
-# A function that is used when there is no print builtin or printf.
-func_fallback_echo ()
- eval 'cat <<_LTECHO_EOF
-\$1
-_LTECHO_EOF'
- ECHO=\"$qECHO\"
- fi
-# Very basic option parsing. These options are (a) specific to
-# the libtool wrapper, (b) are identical between the wrapper
-# /script/ and the wrapper /executable/ which is used only on
-# windows platforms, and (c) all begin with the string "--lt-"
-# (application programs are unlikely to have options which match
-# this pattern).
-# There are only two supported options: --lt-debug and
-# --lt-dump-script. There is, deliberately, no --lt-help.
-# The first argument to this parsing function should be the
-# script's $0 value, followed by "$@".
-lt_option_debug=
-func_parse_lt_options ()
- lt_script_arg0=\$0
- shift
- for lt_opt
- do
- case \"\$lt_opt\" in
- --lt-debug) lt_option_debug=1 ;;
- --lt-dump-script)
- lt_dump_D=\`\$ECHO \"X\$lt_script_arg0\" | $SED -e 's/^X//' -e 's%/[^/]*$%%'\`
- test \"X\$lt_dump_D\" = \"X\$lt_script_arg0\" && lt_dump_D=.
- lt_dump_F=\`\$ECHO \"X\$lt_script_arg0\" | $SED -e 's/^X//' -e 's%^.*/%%'\`
- cat \"\$lt_dump_D/\$lt_dump_F\"
- exit 0
- --lt-*)
- \$ECHO \"Unrecognized --lt- option: '\$lt_opt'\" 1>&2
- exit 1
- esac
- done
- # Print the debug banner immediately:
- if test -n \"\$lt_option_debug\"; then
- echo \"${outputname}:${output}:\${LINENO}: libtool wrapper (GNU $PACKAGE$TIMESTAMP) $VERSION\" 1>&2
- fi
-# Used when --lt-debug. Prints its arguments to stdout
-# (redirection is the responsibility of the caller)
-func_lt_dump_args ()
- lt_dump_args_N=1;
- for lt_arg
- do
- \$ECHO \"${outputname}:${output}:\${LINENO}: newargv[\$lt_dump_args_N]: \$lt_arg\"
- lt_dump_args_N=\`expr \$lt_dump_args_N + 1\`
- done
-# Core function for launching the target application
-func_exec_program_core ()
- case $host in
- # Backslashes separate directories on plain windows
- *-*-mingw | *-*-os2* | *-cegcc*)
- $ECHO "\
- \$ECHO \"${outputname}:${output}:\${LINENO}: newargv[0]: \$progdir\\\\\$program\" 1>&2
- func_lt_dump_args \${1+\"\$@\"} 1>&2
- fi
- exec \"\$progdir\\\\\$program\" \${1+\"\$@\"}
- $ECHO "\
- \$ECHO \"${outputname}:${output}:\${LINENO}: newargv[0]: \$progdir/\$program\" 1>&2
- fi
- exec \"\$progdir/\$program\" \${1+\"\$@\"}
- esac
- $ECHO "\
- \$ECHO \"\$0: cannot exec \$program \$*\" 1>&2
- exit 1
-# A function to encapsulate launching the target application
-# Strips options in the --lt-* namespace from \$@ and
-# launches target application with the remaining arguments.
-func_exec_program ()
- case \" \$* \" in
- *\\ --lt-*)
- for lt_wr_arg
- do
- case \$lt_wr_arg in
- --lt-*) ;;
- *) set x \"\$@\" \"\$lt_wr_arg\"; shift;;
- esac
- shift
- done ;;
- esac
- func_exec_program_core \${1+\"\$@\"}
- # Parse options
- func_parse_lt_options \"\$0\" \${1+\"\$@\"}
- # Find the directory that this script lives in.
- thisdir=\`\$ECHO \"\$file\" | $SED 's%/[^/]*$%%'\`
- test \"x\$thisdir\" = \"x\$file\" && thisdir=.
- # Follow symbolic links until we get to the real thisdir.
- file=\`ls -ld \"\$file\" | $SED -n 's/.*-> //p'\`
- while test -n \"\$file\"; do
- destdir=\`\$ECHO \"\$file\" | $SED 's%/[^/]*\$%%'\`
- # If there was a directory component, then change thisdir.
- if test \"x\$destdir\" != \"x\$file\"; then
- case \"\$destdir\" in
- [\\\\/]* | [A-Za-z]:[\\\\/]*) thisdir=\"\$destdir\" ;;
- *) thisdir=\"\$thisdir/\$destdir\" ;;
- esac
- fi
- file=\`\$ECHO \"\$file\" | $SED 's%^.*/%%'\`
- file=\`ls -ld \"\$thisdir/\$file\" | $SED -n 's/.*-> //p'\`
- done
- # Usually 'no', except on cygwin/mingw when embedded into
- # the cwrapper.
- WRAPPER_SCRIPT_BELONGS_IN_OBJDIR=$func_emit_wrapper_arg1
- if test \"\$WRAPPER_SCRIPT_BELONGS_IN_OBJDIR\" = \"yes\"; then
- # special case for '.'
- if test \"\$thisdir\" = \".\"; then
- thisdir=\`pwd\`
- fi
- # remove .libs from thisdir
- case \"\$thisdir\" in
- *[\\\\/]$objdir ) thisdir=\`\$ECHO \"\$thisdir\" | $SED 's%[\\\\/][^\\\\/]*$%%'\` ;;
- $objdir ) thisdir=. ;;
- esac
- fi
- # Try to get the absolute directory name.
- absdir=\`cd \"\$thisdir\" && pwd\`
- test -n \"\$absdir\" && thisdir=\"\$absdir\"
- if test "$fast_install" = yes; then
- $ECHO "\
- program=lt-'$outputname'$exeext
- progdir=\"\$thisdir/$objdir\"
- if test ! -f \"\$progdir/\$program\" ||
- { file=\`ls -1dt \"\$progdir/\$program\" \"\$progdir/../\$program\" 2>/dev/null | ${SED} 1q\`; \\
- test \"X\$file\" != \"X\$progdir/\$program\"; }; then
- file=\"\$\$-\$program\"
- if test ! -d \"\$progdir\"; then
- $MKDIR \"\$progdir\"
- else
- $RM \"\$progdir/\$file\"
- fi"
- $ECHO "\
- # relink executable if necessary
- if test -n \"\$relink_command\"; then
- if relink_command_output=\`eval \$relink_command 2>&1\`; then :
- else
- $ECHO \"\$relink_command_output\" >&2
- exit 1
- fi
- fi
- $MV \"\$progdir/\$file\" \"\$progdir/\$program\" 2>/dev/null ||
- { $RM \"\$progdir/\$program\";
- $MV \"\$progdir/\$file\" \"\$progdir/\$program\"; }
- fi"
- else
- $ECHO "\
- program='$outputname'
- fi
- $ECHO "\
- if test -f \"\$progdir/\$program\"; then"
- # fixup the dll searchpath if we need to.
- # Fix the DLL searchpath if we need to. Do this before prepending
- # to shlibpath, because on Windows, both are PATH and uninstalled
- # libraries must come first.
- if test -n "$dllsearchpath"; then
- $ECHO "\
- # Add the dll search path components to the executable PATH
- PATH=$dllsearchpath:\$PATH
- fi
- # Export our shlibpath_var if we have one.
- if test "$shlibpath_overrides_runpath" = yes && test -n "$shlibpath_var" && test -n "$temp_rpath"; then
- $ECHO "\
- # Add our own library path to $shlibpath_var
- $shlibpath_var=\"$temp_rpath\$$shlibpath_var\"
- # Some systems cannot cope with colon-terminated $shlibpath_var
- # The second colon is a workaround for a bug in BeOS R4 sed
- $shlibpath_var=\`\$ECHO \"\$$shlibpath_var\" | $SED 's/::*\$//'\`
- export $shlibpath_var
- fi
- $ECHO "\
- # Run the actual program with our arguments.
- func_exec_program \${1+\"\$@\"}
- fi
- else
- # The program doesn't exist.
- \$ECHO \"\$0: error: \\\`\$progdir/\$program' does not exist\" 1>&2
- \$ECHO \"This script is just a wrapper for \$program.\" 1>&2
- \$ECHO \"See the $PACKAGE documentation for more information.\" 1>&2
- exit 1
- fi
-fi\
-# func_emit_cwrapperexe_src
-# emit the source code for a wrapper executable on stdout
-# Must ONLY be called from within func_mode_link because
-# it depends on a number of variable set therein.
-func_emit_cwrapperexe_src ()
- cat <<EOF
-/* $cwrappersource - temporary wrapper executable for $objdir/$outputname
- Generated by $PROGRAM (GNU $PACKAGE$TIMESTAMP) $VERSION
- The $output program cannot be directly executed until all the libtool
- libraries that it depends on are installed.
- This wrapper executable should never be moved out of the build directory.
- If it is, it will not operate correctly.
-EOF
- cat <<"EOF"
-#ifdef _MSC_VER
-# define _CRT_SECURE_NO_DEPRECATE 1
-#endif
-#include <stdio.h>
-#include <stdlib.h>
-#ifdef _MSC_VER
-# include <direct.h>
-# include <process.h>
-# include <io.h>
-#else
-# include <unistd.h>
-# include <stdint.h>
-# ifdef __CYGWIN__
-# include <io.h>
-# endif
-#endif
-#include <malloc.h>
-#include <stdarg.h>
-#include <assert.h>
-#include <string.h>
-#include <ctype.h>
-#include <errno.h>
-#include <fcntl.h>
-#include <sys/stat.h>
-/* declarations of non-ANSI functions */
-#if defined(__MINGW32__)
-# ifdef __STRICT_ANSI__
-int _putenv (const char *);
-# endif
-#elif defined(__CYGWIN__)
-char *realpath (const char *, char *);
-int putenv (char *);
-int setenv (const char *, const char *, int);
-# endif
-/* #elif defined (other platforms) ... */
-#endif
-/* portability defines, excluding path handling macros */
-#if defined(_MSC_VER)
-# define setmode _setmode
-# define stat _stat
-# define chmod _chmod
-# define getcwd _getcwd
-# define putenv _putenv
-# define S_IXUSR _S_IEXEC
-# ifndef _INTPTR_T_DEFINED
-# define _INTPTR_T_DEFINED
-# define intptr_t int
-# endif
-#elif defined(__MINGW32__)
-# define HAVE_SETENV
-# define FOPEN_WB "wb"
-#endif
-#if defined(PATH_MAX)
-# define LT_PATHMAX PATH_MAX
-#elif defined(MAXPATHLEN)
-# define LT_PATHMAX MAXPATHLEN
-#else
-# define LT_PATHMAX 1024
-#endif
-#ifndef S_IXOTH
-# define S_IXOTH 0
-#endif
-#ifndef S_IXGRP
-# define S_IXGRP 0
-#endif
-/* path handling portability macros */
-#ifndef DIR_SEPARATOR
-# define DIR_SEPARATOR '/'
-# define PATH_SEPARATOR ':'
-#endif
-#if defined (_WIN32) || defined (__MSDOS__) || defined (__DJGPP__) || \
- defined (__OS2__)
-# define HAVE_DOS_BASED_FILE_SYSTEM
-# ifndef DIR_SEPARATOR_2
-# define DIR_SEPARATOR_2 '\\'
-# endif
-# ifndef PATH_SEPARATOR_2
-# define PATH_SEPARATOR_2 ';'
-# endif
-#endif
-#ifndef DIR_SEPARATOR_2
-# define IS_DIR_SEPARATOR(ch) ((ch) == DIR_SEPARATOR)
-#else /* DIR_SEPARATOR_2 */
-# define IS_DIR_SEPARATOR(ch) \
- (((ch) == DIR_SEPARATOR) || ((ch) == DIR_SEPARATOR_2))
-#endif /* DIR_SEPARATOR_2 */
-#ifndef PATH_SEPARATOR_2
-# define IS_PATH_SEPARATOR(ch) ((ch) == PATH_SEPARATOR)
-#else /* PATH_SEPARATOR_2 */
-# define IS_PATH_SEPARATOR(ch) ((ch) == PATH_SEPARATOR_2)
-#endif /* PATH_SEPARATOR_2 */
-#ifndef FOPEN_WB
-# define FOPEN_WB "w"
-#endif
-#ifndef _O_BINARY
-# define _O_BINARY 0
-#endif
-#define XMALLOC(type, num) ((type *) xmalloc ((num) * sizeof(type)))
-#define XFREE(stale) do { \
- if (stale) { free ((void *) stale); stale = 0; } \
-} while (0)
-#if defined(LT_DEBUGWRAPPER)
-static int lt_debug = 1;
-#else
-static int lt_debug = 0;
-#endif
-const char *program_name = "libtool-wrapper"; /* in case xstrdup fails */
-void *xmalloc (size_t num);
-char *xstrdup (const char *string);
-const char *base_name (const char *name);
-char *find_executable (const char *wrapper);
-char *chase_symlinks (const char *pathspec);
-int make_executable (const char *path);
-int check_executable (const char *path);
-char *strendzap (char *str, const char *pat);
-void lt_debugprintf (const char *file, int line, const char *fmt, ...);
-void lt_fatal (const char *file, int line, const char *message, ...);
-static const char *nonnull (const char *s);
-static const char *nonempty (const char *s);
-void lt_setenv (const char *name, const char *value);
-char *lt_extend_str (const char *orig_value, const char *add, int to_end);
-void lt_update_exe_path (const char *name, const char *value);
-void lt_update_lib_path (const char *name, const char *value);
-char **prepare_spawn (char **argv);
-void lt_dump_script (FILE *f);
-EOF
- cat <<EOF
-volatile const char * MAGIC_EXE = "$magic_exe";
-const char * LIB_PATH_VARNAME = "$shlibpath_var";
-EOF
- func_to_host_path "$temp_rpath"
- cat <<EOF
-const char * LIB_PATH_VALUE = "$func_to_host_path_result";
-EOF
- else
- cat <<"EOF"
-const char * LIB_PATH_VALUE = "";
-EOF
- fi
- func_to_host_path "$dllsearchpath:"
- cat <<EOF
-const char * EXE_PATH_VARNAME = "PATH";
-const char * EXE_PATH_VALUE = "$func_to_host_path_result";
-EOF
- else
- cat <<"EOF"
-const char * EXE_PATH_VARNAME = "";
-const char * EXE_PATH_VALUE = "";
-EOF
- fi
- cat <<EOF
-const char * TARGET_PROGRAM_NAME = "lt-$outputname"; /* hopefully, no .exe */
-EOF
- else
- cat <<EOF
-const char * TARGET_PROGRAM_NAME = "$outputname"; /* hopefully, no .exe */
-EOF
- fi
- cat <<"EOF"
-#define LTWRAPPER_OPTION_PREFIX "--lt-"
-static const char *ltwrapper_option_prefix = LTWRAPPER_OPTION_PREFIX;
-static const char *dumpscript_opt = LTWRAPPER_OPTION_PREFIX "dump-script";
-static const char *debug_opt = LTWRAPPER_OPTION_PREFIX "debug";
-int
-main (int argc, char *argv[])
- char **newargz;
- int newargc;
- char *tmp_pathspec;
- char *actual_cwrapper_path;
- char *actual_cwrapper_name;
- char *target_name;
- char *lt_argv_zero;
- intptr_t rval = 127;
- int i;
- program_name = (char *) xstrdup (base_name (argv[0]));
- newargz = XMALLOC (char *, argc + 1);
- /* very simple arg parsing; don't want to rely on getopt
- * also, copy all non cwrapper options to newargz, except
- * argz[0], which is handled differently
- newargc=0;
- for (i = 1; i < argc; i++)
- if (strcmp (argv[i], dumpscript_opt) == 0)
-EOF
- case "$host" in
- *mingw* | *cygwin* )
- # make stdout use "unix" line endings
- echo " setmode(1,_O_BINARY);"
- esac
- cat <<"EOF"
- lt_dump_script (stdout);
- return 0;
- if (strcmp (argv[i], debug_opt) == 0)
- lt_debug = 1;
- continue;
- if (strcmp (argv[i], ltwrapper_option_prefix) == 0)
- /* however, if there is an option in the LTWRAPPER_OPTION_PREFIX
- namespace, but it is not one of the ones we know about and
- have already dealt with, above (inluding dump-script), then
- report an error. Otherwise, targets might begin to believe
- they are allowed to use options in the LTWRAPPER_OPTION_PREFIX
- namespace. The first time any user complains about this, we'll
- need to make LTWRAPPER_OPTION_PREFIX a configure-time option
- or a configure.ac-settable value.
- lt_fatal (__FILE__, __LINE__,
- "unrecognized %s option: '%s'",
- ltwrapper_option_prefix, argv[i]);
- /* otherwise ... */
- newargz[++newargc] = xstrdup (argv[i]);
- newargz[++newargc] = NULL;
-EOF
- cat <<EOF
- /* The GNU banner must be the first non-error debug message */
- lt_debugprintf (__FILE__, __LINE__, "libtool wrapper (GNU $PACKAGE$TIMESTAMP) $VERSION\n");
-EOF
- cat <<"EOF"
- lt_debugprintf (__FILE__, __LINE__, "(main) argv[0]: %s\n", argv[0]);
- lt_debugprintf (__FILE__, __LINE__, "(main) program_name: %s\n", program_name);
- tmp_pathspec = find_executable (argv[0]);
- if (tmp_pathspec == NULL)
- lt_fatal (__FILE__, __LINE__, "couldn't find %s", argv[0]);
- "(main) found exe (before symlink chase) at: %s\n",
- tmp_pathspec);
- actual_cwrapper_path = chase_symlinks (tmp_pathspec);
- "(main) found exe (after symlink chase) at: %s\n",
- actual_cwrapper_path);
- XFREE (tmp_pathspec);
- actual_cwrapper_name = xstrdup (base_name (actual_cwrapper_path));
- strendzap (actual_cwrapper_path, actual_cwrapper_name);
- /* wrapper name transforms */
- strendzap (actual_cwrapper_name, ".exe");
- tmp_pathspec = lt_extend_str (actual_cwrapper_name, ".exe", 1);
- XFREE (actual_cwrapper_name);
- actual_cwrapper_name = tmp_pathspec;
- tmp_pathspec = 0;
- /* target_name transforms -- use actual target program name; might have lt- prefix */
- target_name = xstrdup (base_name (TARGET_PROGRAM_NAME));
- strendzap (target_name, ".exe");
- tmp_pathspec = lt_extend_str (target_name, ".exe", 1);
- XFREE (target_name);
- target_name = tmp_pathspec;
- tmp_pathspec = 0;
- "(main) libtool target name: %s\n",
- target_name);
-EOF
- cat <<EOF
- newargz[0] =
- XMALLOC (char, (strlen (actual_cwrapper_path) +
- strlen ("$objdir") + 1 + strlen (actual_cwrapper_name) + 1));
- strcpy (newargz[0], actual_cwrapper_path);
- strcat (newargz[0], "$objdir");
- strcat (newargz[0], "/");
-EOF
- cat <<"EOF"
- /* stop here, and copy so we don't have to do this twice */
- tmp_pathspec = xstrdup (newargz[0]);
- /* do NOT want the lt- prefix here, so use actual_cwrapper_name */
- strcat (newargz[0], actual_cwrapper_name);
- /* DO want the lt- prefix here if it exists, so use target_name */
- lt_argv_zero = lt_extend_str (tmp_pathspec, target_name, 1);
- tmp_pathspec = NULL;
-EOF
- case $host_os in
- mingw*)
- cat <<"EOF"
- char* p;
- while ((p = strchr (newargz[0], '\\')) != NULL)
- *p = '/';
- while ((p = strchr (lt_argv_zero, '\\')) != NULL)
- *p = '/';
-EOF
- esac
- cat <<"EOF"
- XFREE (actual_cwrapper_path);
- lt_setenv ("BIN_SH", "xpg4"); /* for Tru64 */
- lt_setenv ("DUALCASE", "1"); /* for MSK sh */
- /* Update the DLL searchpath. EXE_PATH_VALUE ($dllsearchpath) must
- be prepended before (that is, appear after) LIB_PATH_VALUE ($temp_rpath)
- because on Windows, both *_VARNAMEs are PATH but uninstalled
- libraries must come first. */
- lt_update_exe_path (EXE_PATH_VARNAME, EXE_PATH_VALUE);
- lt_update_lib_path (LIB_PATH_VARNAME, LIB_PATH_VALUE);
- lt_debugprintf (__FILE__, __LINE__, "(main) lt_argv_zero: %s\n",
- nonnull (lt_argv_zero));
- for (i = 0; i < newargc; i++)
- lt_debugprintf (__FILE__, __LINE__, "(main) newargz[%d]: %s\n",
- i, nonnull (newargz[i]));
-EOF
- case $host_os in
- mingw*)
- cat <<"EOF"
- /* execv doesn't actually work on mingw as expected on unix */
- newargz = prepare_spawn (newargz);
- rval = _spawnv (_P_WAIT, lt_argv_zero, (const char * const *) newargz);
- if (rval == -1)
- /* failed to start process */
- "(main) failed to launch target \"%s\": %s\n",
- lt_argv_zero, nonnull (strerror (errno)));
- return 127;
- return rval;
-EOF
- cat <<"EOF"
- execv (lt_argv_zero, newargz);
- return rval; /* =127, but avoids unused variable warning */
-EOF
- esac
- cat <<"EOF"
-void *
-xmalloc (size_t num)
- void *p = (void *) malloc (num);
- if (!p)
- lt_fatal (__FILE__, __LINE__, "memory exhausted");
- return p;
-char *
-xstrdup (const char *string)
- return string ? strcpy ((char *) xmalloc (strlen (string) + 1),
- string) : NULL;
-const char *
-base_name (const char *name)
- const char *base;
-#if defined (HAVE_DOS_BASED_FILE_SYSTEM)
- /* Skip over the disk name in MSDOS pathnames. */
- if (isalpha ((unsigned char) name[0]) && name[1] == ':')
- name += 2;
-#endif
- for (base = name; *name; name++)
- if (IS_DIR_SEPARATOR (*name))
- base = name + 1;
- return base;
-int
-check_executable (const char *path)
- struct stat st;
- lt_debugprintf (__FILE__, __LINE__, "(check_executable): %s\n",
- nonempty (path));
- if ((!path) || (!*path))
- return 0;
- if ((stat (path, &st) >= 0)
- && (st.st_mode & (S_IXUSR | S_IXGRP | S_IXOTH)))
- return 1;
- else
- return 0;
-int
-make_executable (const char *path)
- int rval = 0;
- struct stat st;
- lt_debugprintf (__FILE__, __LINE__, "(make_executable): %s\n",
- nonempty (path));
- return 0;
- if (stat (path, &st) >= 0)
- rval = chmod (path, st.st_mode | S_IXOTH | S_IXGRP | S_IXUSR);
- return rval;
-/* Searches for the full path of the wrapper. Returns
- newly allocated full path name if found, NULL otherwise
- Does not chase symlinks, even on platforms that support them.
-char *
-find_executable (const char *wrapper)
- int has_slash = 0;
- const char *p;
- const char *p_next;
- /* static buffer for getcwd */
- char tmp[LT_PATHMAX + 1];
- int tmp_len;
- char *concat_name;
- lt_debugprintf (__FILE__, __LINE__, "(find_executable): %s\n",
- nonempty (wrapper));
- if ((wrapper == NULL) || (*wrapper == '\0'))
- return NULL;
- /* Absolute path? */
- if (isalpha ((unsigned char) wrapper[0]) && wrapper[1] == ':')
- concat_name = xstrdup (wrapper);
- if (check_executable (concat_name))
- return concat_name;
- XFREE (concat_name);
- else
-#endif
- if (IS_DIR_SEPARATOR (wrapper[0]))
-#endif
- for (p = wrapper; *p; p++)
- if (*p == '/')
- has_slash = 1;
- break;
- if (!has_slash)
- /* no slashes; search PATH */
- const char *path = getenv ("PATH");
- if (path != NULL)
- for (p = path; *p; p = p_next)
- const char *q;
- size_t p_len;
- for (q = p; *q; q++)
- if (IS_PATH_SEPARATOR (*q))
- break;
- p_len = q - p;
- p_next = (*q == '\0' ? q : q + 1);
- if (p_len == 0)
- /* empty path: current directory */
- if (getcwd (tmp, LT_PATHMAX) == NULL)
- lt_fatal (__FILE__, __LINE__, "getcwd failed: %s",
- nonnull (strerror (errno)));
- tmp_len = strlen (tmp);
- concat_name =
- XMALLOC (char, tmp_len + 1 + strlen (wrapper) + 1);
- memcpy (concat_name, tmp, tmp_len);
- concat_name[tmp_len] = '/';
- strcpy (concat_name + tmp_len + 1, wrapper);
- else
- concat_name =
- XMALLOC (char, p_len + 1 + strlen (wrapper) + 1);
- memcpy (concat_name, p, p_len);
- concat_name[p_len] = '/';
- strcpy (concat_name + p_len + 1, wrapper);
- /* not found in PATH; assume curdir */
- /* Relative path | not found in path: prepend cwd */
- concat_name = XMALLOC (char, tmp_len + 1 + strlen (wrapper) + 1);
- return NULL;
-char *
-chase_symlinks (const char *pathspec)
-#ifndef S_ISLNK
- return xstrdup (pathspec);
-#else
- char buf[LT_PATHMAX];
- struct stat s;
- char *tmp_pathspec = xstrdup (pathspec);
- char *p;
- int has_symlinks = 0;
- while (strlen (tmp_pathspec) && !has_symlinks)
- "checking path component for symlinks: %s\n",
- tmp_pathspec);
- if (lstat (tmp_pathspec, &s) == 0)
- if (S_ISLNK (s.st_mode) != 0)
- has_symlinks = 1;
- break;
- /* search backwards for last DIR_SEPARATOR */
- p = tmp_pathspec + strlen (tmp_pathspec) - 1;
- while ((p > tmp_pathspec) && (!IS_DIR_SEPARATOR (*p)))
- p--;
- if ((p == tmp_pathspec) && (!IS_DIR_SEPARATOR (*p)))
- /* no more DIR_SEPARATORS left */
- break;
- *p = '\0';
- else
- "error accessing file \"%s\": %s",
- tmp_pathspec, nonnull (strerror (errno)));
- if (!has_symlinks)
- tmp_pathspec = realpath (pathspec, buf);
- if (tmp_pathspec == 0)
- "could not follow symlinks for %s", pathspec);
- return xstrdup (tmp_pathspec);
-#endif
-char *
-strendzap (char *str, const char *pat)
- size_t len, patlen;
- assert (str != NULL);
- assert (pat != NULL);
- len = strlen (str);
- patlen = strlen (pat);
- if (patlen <= len)
- str += len - patlen;
- if (strcmp (str, pat) == 0)
- *str = '\0';
- return str;
-void
-lt_debugprintf (const char *file, int line, const char *fmt, ...)
- va_list args;
- if (lt_debug)
- (void) fprintf (stderr, "%s:%s:%d: ", program_name, file, line);
- va_start (args, fmt);
- (void) vfprintf (stderr, fmt, args);
- va_end (args);
-static void
-lt_error_core (int exit_status, const char *file,
- int line, const char *mode,
- const char *message, va_list ap)
- fprintf (stderr, "%s:%s:%d: %s: ", program_name, file, line, mode);
- vfprintf (stderr, message, ap);
- fprintf (stderr, ".\n");
- if (exit_status >= 0)
- exit (exit_status);
-void
-lt_fatal (const char *file, int line, const char *message, ...)
- va_list ap;
- va_start (ap, message);
- lt_error_core (EXIT_FAILURE, file, line, "FATAL", message, ap);
- va_end (ap);
-nonnull (const char *s)
- return s ? s : "(null)";
-nonempty (const char *s)
- return (s && !*s) ? "(empty)" : nonnull (s);
-void
-lt_setenv (const char *name, const char *value)
- "(lt_setenv) setting '%s' to '%s'\n",
- nonnull (name), nonnull (value));
-#ifdef HAVE_SETENV
- /* always make a copy, for consistency with !HAVE_SETENV */
- char *str = xstrdup (value);
- setenv (name, str, 1);
-#else
- int len = strlen (name) + 1 + strlen (value) + 1;
- char *str = XMALLOC (char, len);
- sprintf (str, "%s=%s", name, value);
- if (putenv (str) != EXIT_SUCCESS)
- XFREE (str);
-#endif
-char *
-lt_extend_str (const char *orig_value, const char *add, int to_end)
- char *new_value;
- if (orig_value && *orig_value)
- int orig_value_len = strlen (orig_value);
- int add_len = strlen (add);
- new_value = XMALLOC (char, add_len + orig_value_len + 1);
- if (to_end)
- strcpy (new_value, orig_value);
- strcpy (new_value + orig_value_len, add);
- else
- strcpy (new_value, add);
- strcpy (new_value + add_len, orig_value);
- else
- new_value = xstrdup (add);
- return new_value;
-void
-lt_update_exe_path (const char *name, const char *value)
- "(lt_update_exe_path) modifying '%s' by prepending '%s'\n",
- if (name && *name && value && *value)
- char *new_value = lt_extend_str (getenv (name), value, 0);
- /* some systems can't cope with a ':'-terminated path #' */
- int len = strlen (new_value);
- while (((len = strlen (new_value)) > 0) && IS_PATH_SEPARATOR (new_value[len-1]))
- new_value[len-1] = '\0';
- lt_setenv (name, new_value);
- XFREE (new_value);
-void
-lt_update_lib_path (const char *name, const char *value)
- "(lt_update_lib_path) modifying '%s' by prepending '%s'\n",
-EOF
- case $host_os in
- mingw*)
- cat <<"EOF"
-/* Prepares an argument vector before calling spawn().
- Note that spawn() does not by itself call the command interpreter
- (getenv ("COMSPEC") != NULL ? getenv ("COMSPEC") :
- ({ OSVERSIONINFO v; v.dwOSVersionInfoSize = sizeof(OSVERSIONINFO);
- GetVersionEx(&v);
- v.dwPlatformId == VER_PLATFORM_WIN32_NT;
- }) ? "cmd.exe" : "command.com").
- Instead it simply concatenates the arguments, separated by ' ', and calls
- CreateProcess(). We must quote the arguments since Win32 CreateProcess()
- interprets characters like ' ', '\t', '\\', '"' (but not '<' and '>') in a
- special way:
- - Space and tab are interpreted as delimiters. They are not treated as
- delimiters if they are surrounded by double quotes: "...".
- - Unescaped double quotes are removed from the input. Their only effect is
- that within double quotes, space and tab are treated like normal
- characters.
- - Backslashes not followed by double quotes are not special.
- - But 2*n+1 backslashes followed by a double quote become
- n backslashes followed by a double quote (n >= 0):
-#define SHELL_SPECIAL_CHARS "\"\\ \001\002\003\004\005\006\007\010\011\012\013\014\015\016\017\020\021\022\023\024\025\026\027\030\031\032\033\034\035\036\037"
-#define SHELL_SPACE_CHARS " \001\002\003\004\005\006\007\010\011\012\013\014\015\016\017\020\021\022\023\024\025\026\027\030\031\032\033\034\035\036\037"
-char **
-prepare_spawn (char **argv)
- size_t argc;
- char **new_argv;
- size_t i;
- /* Count number of arguments. */
- for (argc = 0; argv[argc] != NULL; argc++)
- /* Allocate new argument vector. */
- new_argv = XMALLOC (char *, argc + 1);
- /* Put quoted arguments into the new argument vector. */
- for (i = 0; i < argc; i++)
- const char *string = argv[i];
- if (string[0] == '\0')
- new_argv[i] = xstrdup ("\"\"");
- else if (strpbrk (string, SHELL_SPECIAL_CHARS) != NULL)
- int quote_around = (strpbrk (string, SHELL_SPACE_CHARS) != NULL);
- size_t length;
- unsigned int backslashes;
- const char *s;
- char *quoted_string;
- char *p;
- length = 0;
- backslashes = 0;
- if (quote_around)
- length++;
- for (s = string; *s != '\0'; s++)
- char c = *s;
- if (c == '"')
- length += backslashes + 1;
- length++;
- if (c == '\\')
- backslashes++;
- else
- backslashes = 0;
- if (quote_around)
- quoted_string = XMALLOC (char, length + 1);
- p = quoted_string;
- backslashes = 0;
- if (quote_around)
- *p++ = '"';
- char c = *s;
- if (c == '"')
- unsigned int j;
- for (j = backslashes + 1; j > 0; j--)
- *p++ = '\\';
- *p++ = c;
- if (c == '\\')
- backslashes++;
- else
- backslashes = 0;
- if (quote_around)
- unsigned int j;
- for (j = backslashes; j > 0; j--)
- *p++ = '\\';
- *p++ = '"';
- *p = '\0';
- new_argv[i] = quoted_string;
- else
- new_argv[i] = (char *) string;
- new_argv[argc] = NULL;
- return new_argv;
-EOF
- esac
- cat <<"EOF"
-void lt_dump_script (FILE* f)
-EOF
- func_emit_wrapper yes |
- $SED -n -e '
-s/^\(.\{79\}\)\(..*\)/\1\
-\2/
-h
-s/\([\\"]\)/\\\1/g
-s/$/\\n/
-s/\([^\n]*\).*/ fputs ("\1", f);/p
-g
-D'
- cat <<"EOF"
-EOF
-# end: func_emit_cwrapperexe_src
-# func_win32_import_lib_p ARG
-# True if ARG is an import lib, as indicated by $file_magic_cmd
-func_win32_import_lib_p ()
- $opt_debug
- case `eval $file_magic_cmd \"\$1\" 2>/dev/null | $SED -e 10q` in
- *import*) : ;;
- *) false ;;
- esac
-# func_mode_link arg...
-func_mode_link ()
- $opt_debug
- case $host in
- *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2* | *-cegcc*)
- # It is impossible to link a dll without this setting, and
- # we shouldn't force the makefile maintainer to figure out
- # which system we are compiling for in order to pass an extra
- # flag for every libtool invocation.
- # allow_undefined=no
- # FIXME: Unfortunately, there are problems with the above when trying
- # to make a dll which has undefined symbols, in which case not
- # even a static library is built. For now, we need to specify
- # -no-undefined on the libtool link line when we can be certain
- # that all symbols are satisfied, otherwise we get a static library.
- allow_undefined=yes
- esac
- libtool_args=$nonopt
- base_compile="$nonopt $@"
- compile_command=$nonopt
- finalize_command=$nonopt
- compile_rpath=
- finalize_rpath=
- compile_shlibpath=
- finalize_shlibpath=
- convenience=
- old_convenience=
- deplibs=
- old_deplibs=
- compiler_flags=
- linker_flags=
- dllsearchpath=
- lib_search_path=`pwd`
- inst_prefix_dir=
- new_inherited_linker_flags=
- avoid_version=no
- bindir=
- dlfiles=
- dlprefiles=
- dlself=no
- export_dynamic=no
- export_symbols=
- export_symbols_regex=
- generated=
- libobjs=
- ltlibs=
- module=no
- no_install=no
- objs=
- non_pic_objects=
- precious_files_regex=
- prefer_static_libs=no
- preload=no
- prev=
- prevarg=
- release=
- rpath=
- xrpath=
- perm_rpath=
- temp_rpath=
- thread_safe=no
- vinfo=
- vinfo_number=no
- weak_libs=
- single_module="${wl}-single_module"
- func_infer_tag $base_compile
- # We need to know -static, to get the right output filenames.
- for arg
- do
- case $arg in
- -shared)
- test "$build_libtool_libs" != yes && \
- func_fatal_configuration "can not build a shared library"
- build_old_libs=no
- break
- -all-static | -static | -static-libtool-libs)
- case $arg in
- -all-static)
- if test "$build_libtool_libs" = yes && test -z "$link_static_flag"; then
- func_warning "complete static linking is impossible in this configuration"
- fi
- if test -n "$link_static_flag"; then
- dlopen_self=$dlopen_self_static
- fi
- prefer_static_libs=yes
- -static)
- if test -z "$pic_flag" && test -n "$link_static_flag"; then
- fi
- prefer_static_libs=built
- -static-libtool-libs)
- fi
- esac
- build_libtool_libs=no
- build_old_libs=yes
- break
- esac
- done
- # See if our shared archives depend on static archives.
- test -n "$old_archive_from_new_cmds" && build_old_libs=yes
- # Go through the arguments, transforming them on the way.
- while test "$#" -gt 0; do
- arg="$1"
- shift
- qarg=$func_quote_for_eval_unquoted_result
- func_append libtool_args " $func_quote_for_eval_result"
- # If the previous option needs an argument, assign it.
- case $prev in
- output)
- func_append compile_command " @OUTPUT@"
- func_append finalize_command " @OUTPUT@"
- esac
- case $prev in
- bindir)
- bindir="$arg"
- prev=
- continue
- dlfiles|dlprefiles)
- if test "$preload" = no; then
- # Add the symbol object into the linking commands.
- func_append compile_command " @SYMFILE@"
- func_append finalize_command " @SYMFILE@"
- preload=yes
- fi
- case $arg in
- *.la | *.lo) ;; # We handle these cases below.
- force)
- if test "$dlself" = no; then
- dlself=needless
- export_dynamic=yes
- fi
- prev=
- continue
- self)
- if test "$prev" = dlprefiles; then
- dlself=yes
- elif test "$prev" = dlfiles && test "$dlopen_self" != yes; then
- dlself=yes
- else
- dlself=needless
- fi
- prev=
- continue
- if test "$prev" = dlfiles; then
- func_append dlfiles " $arg"
- else
- func_append dlprefiles " $arg"
- fi
- prev=
- continue
- esac
- expsyms)
- export_symbols="$arg"
- test -f "$arg" \
- || func_fatal_error "symbol file \`$arg' does not exist"
- prev=
- continue
- expsyms_regex)
- export_symbols_regex="$arg"
- prev=
- continue
- framework)
- case $host in
- *-*-darwin*)
- case "$deplibs " in
- *" $qarg.ltframework "*) ;;
- *) func_append deplibs " $qarg.ltframework" # this is fixed later
- esac
- esac
- prev=
- continue
- inst_prefix)
- inst_prefix_dir="$arg"
- prev=
- continue
- objectlist)
- if test -f "$arg"; then
- save_arg=$arg
- moreargs=
- for fil in `cat "$save_arg"`
- do
-# func_append moreargs " $fil"
- arg=$fil
- # A libtool-controlled object.
- # Check to see that this really is a libtool object.
- if func_lalib_unsafe_p "$arg"; then
- pic_object=
- non_pic_object=
- # Read the .lo file
- func_source "$arg"
- if test -z "$pic_object" ||
- test -z "$non_pic_object" ||
- test "$pic_object" = none &&
- test "$non_pic_object" = none; then
- func_fatal_error "cannot find name of object for \`$arg'"
- fi
- # Extract subdirectory from the argument.
- func_dirname "$arg" "/" ""
- xdir="$func_dirname_result"
- if test "$pic_object" != none; then
- # Prepend the subdirectory the object is found in.
- pic_object="$xdir$pic_object"
- if test "$build_libtool_libs" = yes && test "$dlopen_support" = yes; then
- func_append dlfiles " $pic_object"
- prev=
- continue
- else
- # If libtool objects are unsupported, then we need to preload.
- prev=dlprefiles
- fi
- fi
- # CHECK ME: I think I busted this. -Ossama
- # Preload the old-style object.
- func_append dlprefiles " $pic_object"
- prev=
- fi
- # A PIC object.
- func_append libobjs " $pic_object"
- arg="$pic_object"
- fi
- # Non-PIC object.
- if test "$non_pic_object" != none; then
- non_pic_object="$xdir$non_pic_object"
- # A standard non-PIC object
- func_append non_pic_objects " $non_pic_object"
- if test -z "$pic_object" || test "$pic_object" = none ; then
- arg="$non_pic_object"
- fi
- else
- # If the PIC object exists, use it instead.
- # $xdir was prepended to $pic_object above.
- non_pic_object="$pic_object"
- fi
- else
- # Only an error if not doing a dry-run.
- if $opt_dry_run; then
- func_lo2o "$arg"
- pic_object=$xdir$objdir/$func_lo2o_result
- non_pic_object=$xdir$func_lo2o_result
- else
- func_fatal_error "\`$arg' is not a valid libtool object"
- fi
- fi
- done
- else
- func_fatal_error "link input file \`$arg' does not exist"
- fi
- arg=$save_arg
- prev=
- continue
- precious_regex)
- precious_files_regex="$arg"
- prev=
- continue
- release)
- release="-$arg"
- prev=
- continue
- rpath | xrpath)
- # We need an absolute path.
- case $arg in
- func_fatal_error "only absolute run-paths are allowed"
- esac
- if test "$prev" = rpath; then
- case "$rpath " in
- *" $arg "*) ;;
- *) func_append rpath " $arg" ;;
- esac
- else
- case "$xrpath " in
- *" $arg "*) ;;
- *) func_append xrpath " $arg" ;;
- esac
- fi
- prev=
- continue
- shrext)
- shrext_cmds="$arg"
- prev=
- continue
- weak)
- func_append weak_libs " $arg"
- prev=
- continue
- xcclinker)
- func_append linker_flags " $qarg"
- func_append compiler_flags " $qarg"
- prev=
- func_append compile_command " $qarg"
- func_append finalize_command " $qarg"
- continue
- xcompiler)
- prev=
- continue
- xlinker)
- func_append compiler_flags " $wl$qarg"
- prev=
- func_append compile_command " $wl$qarg"
- func_append finalize_command " $wl$qarg"
- continue
- eval "$prev=\"\$arg\""
- prev=
- continue
- esac
- fi # test -n "$prev"
- prevarg="$arg"
- case $arg in
- -all-static)
- # See comment for -static flag below, for more details.
- func_append compile_command " $link_static_flag"
- func_append finalize_command " $link_static_flag"
- fi
- continue
- -allow-undefined)
- # FIXME: remove this flag sometime in the future.
- func_fatal_error "\`-allow-undefined' must not be used because it is the default"
- -avoid-version)
- avoid_version=yes
- continue
- -bindir)
- prev=bindir
- continue
- -dlopen)
- prev=dlfiles
- continue
- -dlpreopen)
- prev=dlprefiles
- continue
- -export-dynamic)
- continue
- -export-symbols | -export-symbols-regex)
- if test -n "$export_symbols" || test -n "$export_symbols_regex"; then
- func_fatal_error "more than one -exported-symbols argument is not allowed"
- fi
- if test "X$arg" = "X-export-symbols"; then
- prev=expsyms
- else
- prev=expsyms_regex
- fi
- continue
- -framework)
- prev=framework
- continue
- -inst-prefix-dir)
- prev=inst_prefix
- continue
- # The native IRIX linker understands -LANG:*, -LIST:* and -LNO:*
- # so, if we see these flags be careful not to treat them like -L
- -L[A-Z][A-Z]*:*)
- case $with_gcc/$host in
- no/*-*-irix* | /*-*-irix*)
- func_append compile_command " $arg"
- func_append finalize_command " $arg"
- esac
- continue
- -L*)
- func_stripname "-L" '' "$arg"
- if test -z "$func_stripname_result"; then
- if test "$#" -gt 0; then
- func_fatal_error "require no space between \`-L' and \`$1'"
- else
- func_fatal_error "need path for \`-L' option"
- fi
- fi
- func_resolve_sysroot "$func_stripname_result"
- dir=$func_resolve_sysroot_result
- case $dir in
- [\\/]* | [A-Za-z]:[\\/]*) ;;
- absdir=`cd "$dir" && pwd`
- test -z "$absdir" && \
- func_fatal_error "cannot determine absolute directory name of \`$dir'"
- dir="$absdir"
- esac
- *" -L$dir "* | *" $arg "*)
- # Will only happen for absolute or sysroot arguments
- # Preserve sysroot, but never include relative directories
- case $dir in
- [\\/]* | [A-Za-z]:[\\/]* | =*) func_append deplibs " $arg" ;;
- *) func_append deplibs " -L$dir" ;;
- esac
- func_append lib_search_path " $dir"
- esac
- case $host in
- testbindir=`$ECHO "$dir" | $SED 's*/lib$*/bin*'`
- case :$dllsearchpath: in
- *":$dir:"*) ;;
- ::) dllsearchpath=$dir;;
- *) func_append dllsearchpath ":$dir";;
- esac
- *":$testbindir:"*) ;;
- ::) dllsearchpath=$testbindir;;
- *) func_append dllsearchpath ":$testbindir";;
- esac
- esac
- continue
- -l*)
- if test "X$arg" = "X-lc" || test "X$arg" = "X-lm"; then
- case $host in
- *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-beos* | *-cegcc* | *-*-haiku*)
- # These systems don't actually have a C or math library (as such)
- continue
- *-*-os2*)
- # These systems don't actually have a C library (as such)
- test "X$arg" = "X-lc" && continue
- *-*-openbsd* | *-*-freebsd* | *-*-dragonfly*)
- # Do not include libc due to us having libc/libc_r.
- *-*-rhapsody* | *-*-darwin1.[012])
- # Rhapsody C and math libraries are in the System framework
- func_append deplibs " System.ltframework"
- continue
- *-*-sco3.2v5* | *-*-sco5v6*)
- # Causes problems with __ctype
- *-*-sysv4.2uw2* | *-*-sysv5* | *-*-unixware* | *-*-OpenUNIX*)
- # Compiler inserts libc in the correct place for threads to work
- esac
- elif test "X$arg" = "X-lc_r"; then
- case $host in
- # Do not include libc_r directly, use -pthread flag.
- continue
- esac
- fi
- func_append deplibs " $arg"
- continue
- -module)
- module=yes
- continue
- # Tru64 UNIX uses -model [arg] to determine the layout of C++
- # classes, name mangling, and exception handling.
- # Darwin uses the -arch flag to determine output architecture.
- -model|-arch|-isysroot|--sysroot)
- func_append compiler_flags " $arg"
- prev=xcompiler
- continue
- -mt|-mthreads|-kthread|-Kthread|-pthread|-pthreads|--thread-safe \
- |-threads|-fopenmp|-openmp|-mp|-xopenmp|-omp|-qsmp=*)
- case "$new_inherited_linker_flags " in
- *" $arg "*) ;;
- * ) func_append new_inherited_linker_flags " $arg" ;;
- esac
- continue
- -multi_module)
- single_module="${wl}-multi_module"
- continue
- -no-fast-install)
- fast_install=no
- continue
- -no-install)
- case $host in
- *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2* | *-*-darwin* | *-cegcc*)
- # The PATH hackery in wrapper scripts is required on Windows
- # and Darwin in order for the loader to find any dlls it needs.
- func_warning "\`-no-install' is ignored for $host"
- func_warning "assuming \`-no-fast-install' instead"
- fast_install=no
- *) no_install=yes ;;
- esac
- continue
- -no-undefined)
- allow_undefined=no
- continue
- -objectlist)
- prev=objectlist
- continue
- -o) prev=output ;;
- -precious-files-regex)
- prev=precious_regex
- continue
- -release)
- prev=release
- continue
- -rpath)
- prev=rpath
- continue
- -R)
- prev=xrpath
- continue
- -R*)
- func_stripname '-R' '' "$arg"
- dir=$func_stripname_result
- case $dir in
- func_stripname '=' '' "$dir"
- dir=$lt_sysroot$func_stripname_result
- esac
- *" $dir "*) ;;
- *) func_append xrpath " $dir" ;;
- esac
- continue
- -shared)
- # The effects of -shared are defined in a previous loop.
- continue
- -shrext)
- prev=shrext
- continue
- -static | -static-libtool-libs)
- # The effects of -static are defined in a previous loop.
- # We used to do the same as -all-static on platforms that
- # didn't have a PIC flag, but the assumption that the effects
- # would be equivalent was wrong. It would break on at least
- # Digital Unix and AIX.
- continue
- -thread-safe)
- thread_safe=yes
- continue
- -version-info)
- prev=vinfo
- continue
- -version-number)
- prev=vinfo
- vinfo_number=yes
- continue
- -weak)
- prev=weak
- continue
- -Wc,*)
- func_stripname '-Wc,' '' "$arg"
- args=$func_stripname_result
- arg=
- save_ifs="$IFS"; IFS=','
- for flag in $args; do
- IFS="$save_ifs"
- func_quote_for_eval "$flag"
- func_append arg " $func_quote_for_eval_result"
- func_append compiler_flags " $func_quote_for_eval_result"
- done
- IFS="$save_ifs"
- func_stripname ' ' '' "$arg"
- arg=$func_stripname_result
- -Wl,*)
- func_stripname '-Wl,' '' "$arg"
- arg=
- IFS="$save_ifs"
- func_append arg " $wl$func_quote_for_eval_result"
- func_append compiler_flags " $wl$func_quote_for_eval_result"
- func_append linker_flags " $func_quote_for_eval_result"
- done
- IFS="$save_ifs"
- -Xcompiler)
- prev=xcompiler
- continue
- -Xlinker)
- prev=xlinker
- continue
- -XCClinker)
- prev=xcclinker
- continue
- # -msg_* for osf cc
- -msg_*)
- func_quote_for_eval "$arg"
- arg="$func_quote_for_eval_result"
- # Flags to be passed through unchanged, with rationale:
- # -64, -mips[0-9] enable 64-bit mode for the SGI compiler
- # -r[0-9][0-9]* specify processor for the SGI compiler
- # -xarch=*, -xtarget=* enable 64-bit mode for the Sun compiler
- # +DA*, +DD* enable 64-bit mode for the HP compiler
- # -q* compiler args for the IBM compiler
- # -m*, -t[45]*, -txscale* architecture-specific flags for GCC
- # -F/path path to uninstalled frameworks, gcc on darwin
- # -p, -pg, --coverage, -fprofile-* profiling flags for GCC
- # @file GCC response files
- # -tp=* Portland pgcc target processor selection
- # --sysroot=* for sysroot support
- # -O*, -flto*, -fwhopr*, -fuse-linker-plugin GCC link-time optimization
- -64|-mips[0-9]|-r[0-9][0-9]*|-xarch=*|-xtarget=*|+DA*|+DD*|-q*|-m*| \
- -t[45]*|-txscale*|-p|-pg|--coverage|-fprofile-*|-F*|@*|-tp=*|--sysroot=*| \
- -O*|-flto*|-fwhopr*|-fuse-linker-plugin)
- continue
- # Some other compiler flag.
- *.$objext)
- # A standard object.
- func_append objs " $arg"
- *.lo)
- pic_object=
- non_pic_object=
- fi
- prev=
- continue
- else
- prev=dlprefiles
- fi
- fi
- prev=
- fi
- # A PIC object.
- arg="$pic_object"
- fi
- # Non-PIC object.
- fi
- else
- fi
- else
- func_lo2o "$arg"
- else
- fi
- fi
- *.$libext)
- # An archive.
- func_append old_deplibs " $arg"
- continue
- *.la)
- # A libtool-controlled library.
- func_resolve_sysroot "$arg"
- # This library was specified with -dlopen.
- func_append dlfiles " $func_resolve_sysroot_result"
- prev=
- elif test "$prev" = dlprefiles; then
- # The library was specified with -dlpreopen.
- func_append dlprefiles " $func_resolve_sysroot_result"
- prev=
- else
- func_append deplibs " $func_resolve_sysroot_result"
- fi
- continue
- # Some other compiler argument.
- # Unknown arguments in both finalize_command and compile_command need
- # to be aesthetically quoted because they are evaled later.
- esac # arg
- # Now actually substitute the argument into the commands.
- if test -n "$arg"; then
- fi
- done # argument parsing loop
- test -n "$prev" && \
- func_fatal_help "the \`$prevarg' option requires an argument"
- if test "$export_dynamic" = yes && test -n "$export_dynamic_flag_spec"; then
- eval arg=\"$export_dynamic_flag_spec\"
- fi
- oldlibs=
- # calculate the name of the file, without its directory
- func_basename "$output"
- outputname="$func_basename_result"
- libobjs_save="$libobjs"
- if test -n "$shlibpath_var"; then
- # get the directories listed in $shlibpath_var
- eval shlib_search_path=\`\$ECHO \"\${$shlibpath_var}\" \| \$SED \'s/:/ /g\'\`
- else
- shlib_search_path=
- fi
- eval sys_lib_search_path=\"$sys_lib_search_path_spec\"
- eval sys_lib_dlsearch_path=\"$sys_lib_dlsearch_path_spec\"
- func_dirname "$output" "/" ""
- output_objdir="$func_dirname_result$objdir"
- func_to_tool_file "$output_objdir/"
- tool_output_objdir=$func_to_tool_file_result
- # Create the object directory.
- func_mkdir_p "$output_objdir"
- # Determine the type of output
- case $output in
- func_fatal_help "you must specify an output file"
- *.$libext) linkmode=oldlib ;;
- *.lo | *.$objext) linkmode=obj ;;
- *.la) linkmode=lib ;;
- *) linkmode=prog ;; # Anything else should be a program.
- esac
- specialdeplibs=
- libs=
- # Find all interdependent deplibs by searching for libraries
- # that are linked more than once (e.g. -la -lb -la)
- for deplib in $deplibs; do
- if $opt_preserve_dup_deps ; then
- case "$libs " in
- *" $deplib "*) func_append specialdeplibs " $deplib" ;;
- esac
- fi
- func_append libs " $deplib"
- done
- if test "$linkmode" = lib; then
- libs="$predeps $libs $compiler_lib_search_path $postdeps"
- # Compute libraries that are listed more than once in $predeps
- # $postdeps and mark them as special (i.e., whose duplicates are
- # not to be eliminated).
- pre_post_deps=
- if $opt_duplicate_compiler_generated_deps; then
- for pre_post_dep in $predeps $postdeps; do
- case "$pre_post_deps " in
- *" $pre_post_dep "*) func_append specialdeplibs " $pre_post_deps" ;;
- esac
- func_append pre_post_deps " $pre_post_dep"
- done
- fi
- pre_post_deps=
- fi
- deplibs=
- newdependency_libs=
- newlib_search_path=
- need_relink=no # whether we're linking any uninstalled libtool libraries
- notinst_deplibs= # not-installed libtool libraries
- notinst_path= # paths that contain not-installed libtool libraries
- case $linkmode in
- lib)
- passes="conv dlpreopen link"
- for file in $dlfiles $dlprefiles; do
- case $file in
- *.la) ;;
- func_fatal_help "libraries can \`-dlopen' only libtool libraries: $file"
- esac
- done
- prog)
- compile_deplibs=
- finalize_deplibs=
- alldeplibs=no
- newdlfiles=
- newdlprefiles=
- passes="conv scan dlopen dlpreopen link"
- *) passes="conv"
- esac
- for pass in $passes; do
- # The preopen pass in lib mode reverses $deplibs; put it back here
- # so that -L comes before libs that need it for instance...
- if test "$linkmode,$pass" = "lib,link"; then
- ## FIXME: Find the place where the list is rebuilt in the wrong
- ## order, and fix it there properly
- tmp_deplibs=
- tmp_deplibs="$deplib $tmp_deplibs"
- done
- deplibs="$tmp_deplibs"
- fi
- if test "$linkmode,$pass" = "lib,link" ||
- test "$linkmode,$pass" = "prog,scan"; then
- libs="$deplibs"
- deplibs=
- fi
- if test "$linkmode" = prog; then
- case $pass in
- dlopen) libs="$dlfiles" ;;
- dlpreopen) libs="$dlprefiles" ;;
- link)
- libs="$deplibs %DEPLIBS%"
- test "X$link_all_deplibs" != Xno && libs="$libs $dependency_libs"
- esac
- fi
- if test "$linkmode,$pass" = "lib,dlpreopen"; then
- # Collect and forward deplibs of preopened libtool libs
- for lib in $dlprefiles; do
- # Ignore non-libtool-libs
- dependency_libs=
- func_resolve_sysroot "$lib"
- case $lib in
- *.la) func_source "$func_resolve_sysroot_result" ;;
- esac
- # Collect preopened libtool deplibs, except any this library
- # has declared as weak libs
- for deplib in $dependency_libs; do
- func_basename "$deplib"
- deplib_base=$func_basename_result
- case " $weak_libs " in
- *" $deplib_base "*) ;;
- *) func_append deplibs " $deplib" ;;
- esac
- done
- done
- libs="$dlprefiles"
- fi
- if test "$pass" = dlopen; then
- # Collect dlpreopened libraries
- save_deplibs="$deplibs"
- deplibs=
- fi
- for deplib in $libs; do
- lib=
- found=no
- case $deplib in
- if test "$linkmode,$pass" = "prog,link"; then
- compile_deplibs="$deplib $compile_deplibs"
- finalize_deplibs="$deplib $finalize_deplibs"
- else
- func_append compiler_flags " $deplib"
- if test "$linkmode" = lib ; then
- *" $deplib "*) ;;
- * ) func_append new_inherited_linker_flags " $deplib" ;;
- esac
- fi
- fi
- continue
- -l*)
- if test "$linkmode" != lib && test "$linkmode" != prog; then
- func_warning "\`-l' is ignored for archives/objects"
- continue
- fi
- func_stripname '-l' '' "$deplib"
- name=$func_stripname_result
- searchdirs="$newlib_search_path $lib_search_path $compiler_lib_search_dirs $sys_lib_search_path $shlib_search_path"
- else
- searchdirs="$newlib_search_path $lib_search_path $sys_lib_search_path $shlib_search_path"
- fi
- for searchdir in $searchdirs; do
- for search_ext in .la $std_shrext .so .a; do
- # Search the libtool library
- lib="$searchdir/lib${name}${search_ext}"
- if test -f "$lib"; then
- if test "$search_ext" = ".la"; then
- found=yes
- else
- found=no
- fi
- break 2
- fi
- done
- done
- if test "$found" != yes; then
- # deplib doesn't seem to be a libtool library
- else
- deplibs="$deplib $deplibs"
- test "$linkmode" = lib && newdependency_libs="$deplib $newdependency_libs"
- fi
- continue
- else # deplib is a libtool library
- # If $allow_libtool_libs_with_static_runtimes && $deplib is a stdlib,
- # We need to do some special things here, and not later.
- if test "X$allow_libtool_libs_with_static_runtimes" = "Xyes" ; then
- case " $predeps $postdeps " in
- *" $deplib "*)
- if func_lalib_p "$lib"; then
- library_names=
- old_library=
- func_source "$lib"
- for l in $old_library $library_names; do
- ll="$l"
- done
- if test "X$ll" = "X$old_library" ; then # only static version available
- found=no
- func_dirname "$lib" "" "."
- ladir="$func_dirname_result"
- lib=$ladir/$old_library
- else
- fi
- continue
- fi
- fi
- esac
- fi
- fi
- ;; # -l
- *.ltframework)
- else
- *" $deplib "*) ;;
- esac
- fi
- fi
- continue
- -L*)
- case $linkmode in
- lib)
- test "$pass" = conv && continue
- newdependency_libs="$deplib $newdependency_libs"
- func_stripname '-L' '' "$deplib"
- func_append newlib_search_path " $func_resolve_sysroot_result"
- prog)
- if test "$pass" = conv; then
- continue
- fi
- if test "$pass" = scan; then
- else
- fi
- func_warning "\`-L' is ignored for archives/objects"
- esac # linkmode
- continue
- ;; # -L
- -R*)
- if test "$pass" = link; then
- func_stripname '-R' '' "$deplib"
- # Make sure the xrpath contains only unique directories.
- *" $dir "*) ;;
- esac
- fi
- continue
- *.la)
- func_resolve_sysroot "$deplib"
- lib=$func_resolve_sysroot_result
- *.$libext)
- continue
- fi
- case $linkmode in
- lib)
- # Linking convenience modules into shared libraries is allowed,
- # but linking other static libraries is non-portable.
- case " $dlpreconveniencelibs " in
- *" $deplib "*) ;;
- valid_a_lib=no
- case $deplibs_check_method in
- match_pattern*)
- set dummy $deplibs_check_method; shift
- match_pattern_regex=`expr "$deplibs_check_method" : "$1 \(.*\)"`
- if eval "\$ECHO \"$deplib\"" 2>/dev/null | $SED 10q \
- | $EGREP "$match_pattern_regex" > /dev/null; then
- valid_a_lib=yes
- fi
- pass_all)
- valid_a_lib=yes
- esac
- if test "$valid_a_lib" != yes; then
- echo
- $ECHO "*** Warning: Trying to link with static lib archive $deplib."
- echo "*** I have the capability to make that library automatically link in when"
- echo "*** you link to this library. But I can only do this if you have a"
- echo "*** shared version of the library, which you do not appear to have"
- echo "*** because the file extensions .$libext of this argument makes me believe"
- echo "*** that it is just a static archive that I should not use here."
- else
- echo
- $ECHO "*** Warning: Linking the shared library $output against the"
- $ECHO "*** static library $deplib is not portable!"
- fi
- esac
- continue
- prog)
- if test "$pass" != link; then
- else
- fi
- continue
- esac # linkmode
- ;; # *.$libext
- *.lo | *.$objext)
- elif test "$linkmode" = prog; then
- if test "$pass" = dlpreopen || test "$dlopen_support" != yes || test "$build_libtool_libs" = no; then
- # If there is no dlopen support or we're linking statically,
- # we need to preload.
- func_append newdlprefiles " $deplib"
- else
- func_append newdlfiles " $deplib"
- fi
- fi
- continue
- %DEPLIBS%)
- alldeplibs=yes
- continue
- esac # case $deplib
- if test "$found" = yes || test -f "$lib"; then :
- else
- func_fatal_error "cannot find the library \`$lib' or unhandled argument \`$deplib'"
- fi
- # Check to see that this really is a libtool archive.
- func_lalib_unsafe_p "$lib" \
- || func_fatal_error "\`$lib' is not a valid libtool archive"
- dlname=
- dlopen=
- dlpreopen=
- libdir=
- library_names=
- old_library=
- inherited_linker_flags=
- # If the library was installed with an old release of libtool,
- # it will not redefine variables installed, or shouldnotlink
- installed=yes
- shouldnotlink=no
- avoidtemprpath=
- # Read the .la file
- # Convert "-framework foo" to "foo.ltframework"
- if test -n "$inherited_linker_flags"; then
- tmp_inherited_linker_flags=`$ECHO "$inherited_linker_flags" | $SED 's/-framework \([^ $]*\)/\1.ltframework/g'`
- for tmp_inherited_linker_flag in $tmp_inherited_linker_flags; do
- case " $new_inherited_linker_flags " in
- *" $tmp_inherited_linker_flag "*) ;;
- *) func_append new_inherited_linker_flags " $tmp_inherited_linker_flag";;
- esac
- done
- fi
- dependency_libs=`$ECHO " $dependency_libs" | $SED 's% \([^ $]*\).ltframework% -framework \1%g'`
- test "$linkmode,$pass" = "prog,scan" ||
- { test "$linkmode" != prog && test "$linkmode" != lib; }; then
- test -n "$dlopen" && func_append dlfiles " $dlopen"
- test -n "$dlpreopen" && func_append dlprefiles " $dlpreopen"
- fi
- # Only check for convenience libraries
- deplibs="$lib $deplibs"
- if test -z "$libdir"; then
- if test -z "$old_library"; then
- func_fatal_error "cannot find name of link library for \`$lib'"
- fi
- # It is a libtool convenience library, so add in its objects.
- func_append convenience " $ladir/$objdir/$old_library"
- func_append old_convenience " $ladir/$objdir/$old_library"
- tmp_libs=
- case "$tmp_libs " in
- esac
- fi
- func_append tmp_libs " $deplib"
- done
- elif test "$linkmode" != prog && test "$linkmode" != lib; then
- func_fatal_error "\`$lib' is not a convenience library"
- fi
- continue
- fi # $pass = conv
- # Get the name of the library we link against.
- linklib=
- if test -n "$old_library" &&
- { test "$prefer_static_libs" = yes ||
- test "$prefer_static_libs,$installed" = "built,no"; }; then
- linklib=$old_library
- else
- linklib="$l"
- done
- fi
- if test -z "$linklib"; then
- fi
- func_fatal_error "cannot -dlopen a convenience library: \`$lib'"
- fi
- if test -z "$dlname" ||
- test "$dlopen_support" != yes ||
- test "$build_libtool_libs" = no; then
- # If there is no dlname, no dlopen support or we're linking
- # statically, we need to preload. We also need to preload any
- # dependent libraries so libltdl's deplib preloader doesn't
- # bomb out in the load deplibs phase.
- func_append dlprefiles " $lib $dependency_libs"
- else
- func_append newdlfiles " $lib"
- fi
- continue
- fi # $pass = dlopen
- case $ladir in
- [\\/]* | [A-Za-z]:[\\/]*) abs_ladir="$ladir" ;;
- abs_ladir=`cd "$ladir" && pwd`
- if test -z "$abs_ladir"; then
- func_warning "cannot determine absolute directory name of \`$ladir'"
- func_warning "passing it literally to the linker, although it might fail"
- abs_ladir="$ladir"
- fi
- esac
- func_basename "$lib"
- laname="$func_basename_result"
- # Find the relevant object directory and library name.
- if test "X$installed" = Xyes; then
- if test ! -f "$lt_sysroot$libdir/$linklib" && test -f "$abs_ladir/$linklib"; then
- func_warning "library \`$lib' was moved."
- dir="$ladir"
- absdir="$abs_ladir"
- libdir="$abs_ladir"
- else
- dir="$lt_sysroot$libdir"
- absdir="$lt_sysroot$libdir"
- fi
- test "X$hardcode_automatic" = Xyes && avoidtemprpath=yes
- else
- if test ! -f "$ladir/$objdir/$linklib" && test -f "$abs_ladir/$linklib"; then
- dir="$ladir"
- # Remove this search path later
- func_append notinst_path " $abs_ladir"
- else
- dir="$ladir/$objdir"
- absdir="$abs_ladir/$objdir"
- fi
- fi # $installed = yes
- func_stripname 'lib' '.la' "$laname"
- # This library was specified with -dlpreopen.
- if test "$pass" = dlpreopen; then
- if test -z "$libdir" && test "$linkmode" = prog; then
- func_fatal_error "only libraries may -dlpreopen a convenience library: \`$lib'"
- fi
- case "$host" in
- # special handling for platforms with PE-DLLs.
- *cygwin* | *mingw* | *cegcc* )
- # Linker will automatically link against shared library if both
- # static and shared are present. Therefore, ensure we extract
- # symbols from the import library if a shared library is present
- # (otherwise, the dlopen module name will be incorrect). We do
- # this by putting the import library name into $newdlprefiles.
- # We recover the dlopen module name by 'saving' the la file
- # name in a special purpose variable, and (later) extracting the
- # dlname from the la file.
- if test -n "$dlname"; then
- func_tr_sh "$dir/$linklib"
- eval "libfile_$func_tr_sh_result=\$abs_ladir/\$laname"
- func_append newdlprefiles " $dir/$linklib"
- else
- func_append newdlprefiles " $dir/$old_library"
- # Keep a list of preopened convenience libraries to check
- # that they are being used correctly in the link pass.
- test -z "$libdir" && \
- func_append dlpreconveniencelibs " $dir/$old_library"
- fi
- # Prefer using a static library (so that no silly _DYNAMIC symbols
- # are required to link).
- if test -n "$old_library"; then
- # Otherwise, use the dlname, so that lt_dlopen finds it.
- elif test -n "$dlname"; then
- func_append newdlprefiles " $dir/$dlname"
- else
- fi
- esac
- fi # $pass = dlpreopen
- # Link the convenience library
- deplibs="$dir/$old_library $deplibs"
- elif test "$linkmode,$pass" = "prog,link"; then
- compile_deplibs="$dir/$old_library $compile_deplibs"
- finalize_deplibs="$dir/$old_library $finalize_deplibs"
- else
- deplibs="$lib $deplibs" # used for prog,scan pass
- fi
- continue
- fi
- if test "$linkmode" = prog && test "$pass" != link; then
- func_append newlib_search_path " $ladir"
- linkalldeplibs=no
- if test "$link_all_deplibs" != no || test -z "$library_names" ||
- linkalldeplibs=yes
- fi
- tmp_libs=
- case $deplib in
- -L*) func_stripname '-L' '' "$deplib"
- esac
- # Need to link against all dependency_libs?
- if test "$linkalldeplibs" = yes; then
- else
- # Need to hardcode shared library paths
- # or/and link against static libraries
- fi
- esac
- fi
- done # for deplib
- continue
- fi # $linkmode = prog...
- if test -n "$library_names" &&
- { { test "$prefer_static_libs" = no ||
- test "$prefer_static_libs,$installed" = "built,yes"; } ||
- test -z "$old_library"; }; then
- # We need to hardcode the library path
- if test -n "$shlibpath_var" && test -z "$avoidtemprpath" ; then
- # Make sure the rpath contains only unique directories.
- case "$temp_rpath:" in
- *"$absdir:"*) ;;
- *) func_append temp_rpath "$absdir:" ;;
- esac
- fi
- # Hardcode the library path.
- # Skip directories that are in the system default run-time
- # search path.
- case " $sys_lib_dlsearch_path " in
- *" $absdir "*) ;;
- case "$compile_rpath " in
- *" $absdir "*) ;;
- *) func_append compile_rpath " $absdir" ;;
- esac
- esac
- *" $libdir "*) ;;
- case "$finalize_rpath " in
- *" $libdir "*) ;;
- *) func_append finalize_rpath " $libdir" ;;
- esac
- esac
- fi # $linkmode,$pass = prog,link...
- if test "$alldeplibs" = yes &&
- { test "$deplibs_check_method" = pass_all ||
- { test "$build_libtool_libs" = yes &&
- test -n "$library_names"; }; }; then
- # We only need to search for static libraries
- continue
- fi
- fi
- link_static=no # Whether the deplib will be linked statically
- use_static_libs=$prefer_static_libs
- if test "$use_static_libs" = built && test "$installed" = yes; then
- use_static_libs=no
- fi
- { test "$use_static_libs" = no || test -z "$old_library"; }; then
- case $host in
- *cygwin* | *mingw* | *cegcc*)
- # No point in relinking DLLs because paths are not encoded
- func_append notinst_deplibs " $lib"
- need_relink=no
- if test "$installed" = no; then
- need_relink=yes
- fi
- esac
- # This is a shared library
- # Warn about portability, can't link against -module's on some
- # systems (darwin). Don't bleat about dlopened modules though!
- dlopenmodule=""
- for dlpremoduletest in $dlprefiles; do
- if test "X$dlpremoduletest" = "X$lib"; then
- dlopenmodule="$dlpremoduletest"
- break
- fi
- done
- if test -z "$dlopenmodule" && test "$shouldnotlink" = yes && test "$pass" = link; then
- echo
- $ECHO "*** Warning: Linking the executable $output against the loadable module"
- else
- $ECHO "*** Warning: Linking the shared library $output against the loadable module"
- fi
- $ECHO "*** $linklib is not portable!"
- fi
- if test "$linkmode" = lib &&
- test "$hardcode_into_libs" = yes; then
- # search path.
- *" $absdir "*) ;;
- *" $absdir "*) ;;
- esac
- esac
- *" $libdir "*) ;;
- *" $libdir "*) ;;
- esac
- esac
- fi
- if test -n "$old_archive_from_expsyms_cmds"; then
- # figure out the soname
- set dummy $library_names
- shift
- realname="$1"
- shift
- libname=`eval "\\$ECHO \"$libname_spec\""`
- # use dlname if we got it. it's perfectly good, no?
- soname="$dlname"
- elif test -n "$soname_spec"; then
- # bleh windows
- case $host in
- *cygwin* | mingw* | *cegcc*)
- func_arith $current - $age
- major=$func_arith_result
- versuffix="-$major"
- esac
- eval soname=\"$soname_spec\"
- else
- soname="$realname"
- fi
- # Make a new name for the extract_expsyms_cmds to use
- soroot="$soname"
- func_basename "$soroot"
- soname="$func_basename_result"
- func_stripname 'lib' '.dll' "$soname"
- newlib=libimp-$func_stripname_result.a
- # If the library has no export list, then create one now
- if test -f "$output_objdir/$soname-def"; then :
- else
- func_verbose "extracting exported symbol list from \`$soname'"
- func_execute_cmds "$extract_expsyms_cmds" 'exit $?'
- fi
- # Create $newlib
- if test -f "$output_objdir/$newlib"; then :; else
- func_verbose "generating import library for \`$soname'"
- func_execute_cmds "$old_archive_from_expsyms_cmds" 'exit $?'
- fi
- # make sure the library variables are pointing to the new library
- dir=$output_objdir
- linklib=$newlib
- fi # test -n "$old_archive_from_expsyms_cmds"
- if test "$linkmode" = prog || test "$opt_mode" != relink; then
- add_shlibpath=
- add_dir=
- add=
- lib_linked=yes
- case $hardcode_action in
- immediate | unsupported)
- if test "$hardcode_direct" = no; then
- add="$dir/$linklib"
- case $host in
- *-*-sco3.2v5.0.[024]*) add_dir="-L$dir" ;;
- *-*-sysv4*uw2*) add_dir="-L$dir" ;;
- *-*-sysv5OpenUNIX* | *-*-sysv5UnixWare7.[01].[10]* | \
- *-*-unixware7*) add_dir="-L$dir" ;;
- *-*-darwin* )
- # if the lib is a (non-dlopened) module then we can not
- # link against it, someone is ignoring the earlier warnings
- if /usr/bin/file -L $add 2> /dev/null |
- $GREP ": [^:]* bundle" >/dev/null ; then
- if test "X$dlopenmodule" != "X$lib"; then
- $ECHO "*** Warning: lib $linklib is a module, not a shared library"
- if test -z "$old_library" ; then
- echo
- echo "*** And there doesn't seem to be a static archive available"
- echo "*** The link will probably fail, sorry"
- else
- add="$dir/$old_library"
- fi
- elif test -n "$old_library"; then
- fi
- fi
- esac
- elif test "$hardcode_minus_L" = no; then
- case $host in
- *-*-sunos*) add_shlibpath="$dir" ;;
- esac
- add_dir="-L$dir"
- add="-l$name"
- elif test "$hardcode_shlibpath_var" = no; then
- add_shlibpath="$dir"
- add="-l$name"
- else
- lib_linked=no
- fi
- relink)
- if test "$hardcode_direct" = yes &&
- test "$hardcode_direct_absolute" = no; then
- elif test "$hardcode_minus_L" = yes; then
- add_dir="-L$absdir"
- # Try looking first in the location we're being installed to.
- if test -n "$inst_prefix_dir"; then
- case $libdir in
- func_append add_dir " -L$inst_prefix_dir$libdir"
- esac
- fi
- add="-l$name"
- elif test "$hardcode_shlibpath_var" = yes; then
- add="-l$name"
- else
- lib_linked=no
- fi
- *) lib_linked=no ;;
- esac
- if test "$lib_linked" != yes; then
- func_fatal_configuration "unsupported hardcode properties"
- fi
- if test -n "$add_shlibpath"; then
- case :$compile_shlibpath: in
- *":$add_shlibpath:"*) ;;
- *) func_append compile_shlibpath "$add_shlibpath:" ;;
- esac
- fi
- test -n "$add_dir" && compile_deplibs="$add_dir $compile_deplibs"
- test -n "$add" && compile_deplibs="$add $compile_deplibs"
- else
- test -n "$add_dir" && deplibs="$add_dir $deplibs"
- test -n "$add" && deplibs="$add $deplibs"
- if test "$hardcode_direct" != yes &&
- test "$hardcode_minus_L" != yes &&
- test "$hardcode_shlibpath_var" = yes; then
- case :$finalize_shlibpath: in
- *":$libdir:"*) ;;
- *) func_append finalize_shlibpath "$libdir:" ;;
- esac
- fi
- fi
- fi
- if test "$linkmode" = prog || test "$opt_mode" = relink; then
- add_shlibpath=
- add_dir=
- add=
- # Finalize command for both is simple: just hardcode it.
- add="$libdir/$linklib"
- add_dir="-L$libdir"
- add="-l$name"
- *":$libdir:"*) ;;
- esac
- add="-l$name"
- elif test "$hardcode_automatic" = yes; then
- if test -n "$inst_prefix_dir" &&
- test -f "$inst_prefix_dir$libdir/$linklib" ; then
- add="$inst_prefix_dir$libdir/$linklib"
- else
- fi
- else
- # We cannot seem to hardcode it, guess we'll fake it.
- case $libdir in
- esac
- fi
- add="-l$name"
- fi
- test -n "$add_dir" && finalize_deplibs="$add_dir $finalize_deplibs"
- test -n "$add" && finalize_deplibs="$add $finalize_deplibs"
- else
- fi
- fi
- # Here we assume that one of hardcode_direct or hardcode_minus_L
- # is not unsupported. This is valid on all known static and
- # shared platforms.
- if test "$hardcode_direct" != unsupported; then
- test -n "$old_library" && linklib="$old_library"
- compile_deplibs="$dir/$linklib $compile_deplibs"
- finalize_deplibs="$dir/$linklib $finalize_deplibs"
- else
- compile_deplibs="-l$name -L$dir $compile_deplibs"
- finalize_deplibs="-l$name -L$dir $finalize_deplibs"
- fi
- elif test "$build_libtool_libs" = yes; then
- # Not a shared library
- if test "$deplibs_check_method" != pass_all; then
- # We're trying link a shared library against a static one
- # but the system doesn't support it.
- # Just print a warning and add the library to dependency_libs so
- # that the program can be linked against the static library.
- echo
- $ECHO "*** Warning: This system can not link to static lib archive $lib."
- echo "*** shared version of the library, which you do not appear to have."
- if test "$module" = yes; then
- echo "*** But as you try to build a module library, libtool will still create "
- echo "*** a static module, that should work as long as the dlopening application"
- echo "*** is linked with the -dlopen flag to resolve symbols at runtime."
- if test -z "$global_symbol_pipe"; then
- echo
- echo "*** However, this would only work if libtool was able to extract symbol"
- echo "*** lists from a program, using \`nm' or equivalent, but libtool could"
- echo "*** not find such a program. So, this module is probably useless."
- echo "*** \`nm' from GNU binutils and a full rebuild may help."
- fi
- if test "$build_old_libs" = no; then
- build_libtool_libs=module
- else
- fi
- fi
- else
- link_static=yes
- fi
- fi # link shared/static library?
- if test -n "$dependency_libs" &&
- { test "$hardcode_into_libs" != yes ||
- test "$build_old_libs" = yes ||
- test "$link_static" = yes; }; then
- # Extract -R from dependency_libs
- temp_deplibs=
- for libdir in $dependency_libs; do
- case $libdir in
- -R*) func_stripname '-R' '' "$libdir"
- temp_xrpath=$func_stripname_result
- case " $xrpath " in
- *" $temp_xrpath "*) ;;
- *) func_append xrpath " $temp_xrpath";;
- esac;;
- *) func_append temp_deplibs " $libdir";;
- esac
- done
- dependency_libs="$temp_deplibs"
- fi
- func_append newlib_search_path " $absdir"
- # Link against this library
- test "$link_static" = no && newdependency_libs="$abs_ladir/$laname $newdependency_libs"
- # ... and its dependency_libs
- tmp_libs=
- case $deplib in
- func_resolve_sysroot "$func_stripname_result";;
- *) func_resolve_sysroot "$deplib" ;;
- esac
- *" $func_resolve_sysroot_result "*)
- func_append specialdeplibs " $func_resolve_sysroot_result" ;;
- esac
- fi
- func_append tmp_libs " $func_resolve_sysroot_result"
- done
- if test "$link_all_deplibs" != no; then
- # Add the search paths of all dependency libraries
- path=
- case $deplib in
- -L*) path="$deplib" ;;
- *.la)
- deplib=$func_resolve_sysroot_result
- func_dirname "$deplib" "" "."
- dir=$func_dirname_result
- case $dir in
- [\\/]* | [A-Za-z]:[\\/]*) absdir="$dir" ;;
- if test -z "$absdir"; then
- func_warning "cannot determine absolute directory name of \`$dir'"
- absdir="$dir"
- fi
- esac
- if $GREP "^installed=no" $deplib > /dev/null; then
- case $host in
- *-*-darwin*)
- depdepl=
- eval deplibrary_names=`${SED} -n -e 's/^library_names=\(.*\)$/\1/p' $deplib`
- if test -n "$deplibrary_names" ; then
- for tmp in $deplibrary_names ; do
- depdepl=$tmp
- done
- if test -f "$absdir/$objdir/$depdepl" ; then
- depdepl="$absdir/$objdir/$depdepl"
- darwin_install_name=`${OTOOL} -L $depdepl | awk '{if (NR == 2) {print $1;exit}}'`
- if test -z "$darwin_install_name"; then
- darwin_install_name=`${OTOOL64} -L $depdepl | awk '{if (NR == 2) {print $1;exit}}'`
- fi
- func_append compiler_flags " ${wl}-dylib_file ${wl}${darwin_install_name}:${depdepl}"
- func_append linker_flags " -dylib_file ${darwin_install_name}:${depdepl}"
- path=
- fi
- fi
- path="-L$absdir/$objdir"
- esac
- else
- eval libdir=`${SED} -n -e 's/^libdir=\(.*\)$/\1/p' $deplib`
- func_fatal_error "\`$deplib' is not a valid libtool archive"
- test "$absdir" != "$libdir" && \
- func_warning "\`$deplib' seems to be moved"
- path="-L$absdir"
- fi
- esac
- case " $deplibs " in
- *" $path "*) ;;
- *) deplibs="$path $deplibs" ;;
- esac
- done
- fi # link_all_deplibs != no
- fi # linkmode = lib
- done # for deplib in $libs
- if test "$linkmode" = "prog"; then
- compile_deplibs="$new_inherited_linker_flags $compile_deplibs"
- finalize_deplibs="$new_inherited_linker_flags $finalize_deplibs"
- else
- compiler_flags="$compiler_flags "`$ECHO " $new_inherited_linker_flags" | $SED 's% \([^ $]*\).ltframework% -framework \1%g'`
- fi
- fi
- dependency_libs="$newdependency_libs"
- # Link the dlpreopened libraries before other libraries
- for deplib in $save_deplibs; do
- done
- fi
- if test "$pass" != dlopen; then
- if test "$pass" != conv; then
- # Make sure lib_search_path contains only unique directories.
- lib_search_path=
- for dir in $newlib_search_path; do
- case "$lib_search_path " in
- *" $dir "*) ;;
- *) func_append lib_search_path " $dir" ;;
- esac
- done
- fi
- if test "$linkmode,$pass" != "prog,link"; then
- vars="deplibs"
- else
- vars="compile_deplibs finalize_deplibs"
- fi
- for var in $vars dependency_libs; do
- # Add libraries to $var in reverse order
- eval tmp_libs=\"\$$var\"
- new_libs=
- for deplib in $tmp_libs; do
- # FIXME: Pedantically, this is the right thing to do, so
- # that some nasty dependency loop isn't accidentally
- # broken:
- #new_libs="$deplib $new_libs"
- # Pragmatically, this seems to cause very few problems in
- # practice:
- case $deplib in
- -L*) new_libs="$deplib $new_libs" ;;
- -R*) ;;
- # And here is the reason: when a library appears more
- # than once as an explicit dependence of a library, or
- # is implicitly linked in more than once by the
- # compiler, it is considered special, and multiple
- # occurrences thereof are not removed. Compare this
- # with having the same library being listed as a
- # dependency of multiple other libraries: in this case,
- # we know (pedantically, we assume) the library does not
- # need to be listed more than once, so we keep only the
- # last copy. This is not always right, but it is rare
- # enough that we require users that really mean to play
- # such unportable linking tricks to link the library
- # using -Wl,-lname, so that libtool does not consider it
- # for duplicate removal.
- case " $specialdeplibs " in
- *" $deplib "*) new_libs="$deplib $new_libs" ;;
- case " $new_libs " in
- *" $deplib "*) ;;
- *) new_libs="$deplib $new_libs" ;;
- esac
- esac
- esac
- done
- tmp_libs=
- for deplib in $new_libs; do
- case $deplib in
- -L*)
- case " $tmp_libs " in
- *" $deplib "*) ;;
- *) func_append tmp_libs " $deplib" ;;
- esac
- esac
- done
- eval $var=\"$tmp_libs\"
- done # for var
- fi
- # Last step: remove runtime libs from dependency_libs
- # (they stay in deplibs)
- tmp_libs=
- for i in $dependency_libs ; do
- case " $predeps $postdeps $compiler_lib_search_path " in
- *" $i "*)
- i=""
- esac
- if test -n "$i" ; then
- func_append tmp_libs " $i"
- fi
- done
- dependency_libs=$tmp_libs
- done # for pass
- dlfiles="$newdlfiles"
- fi
- if test "$linkmode" = prog || test "$linkmode" = lib; then
- dlprefiles="$newdlprefiles"
- fi
- case $linkmode in
- oldlib)
- if test -n "$dlfiles$dlprefiles" || test "$dlself" != no; then
- func_warning "\`-dlopen' is ignored for archives"
- fi
- case " $deplibs" in
- *\ -l* | *\ -L*)
- func_warning "\`-l' and \`-L' are ignored for archives" ;;
- esac
- test -n "$rpath" && \
- func_warning "\`-rpath' is ignored for archives"
- test -n "$xrpath" && \
- func_warning "\`-R' is ignored for archives"
- test -n "$vinfo" && \
- func_warning "\`-version-info/-version-number' is ignored for archives"
- test -n "$release" && \
- func_warning "\`-release' is ignored for archives"
- test -n "$export_symbols$export_symbols_regex" && \
- func_warning "\`-export-symbols' is ignored for archives"
- # Now set the variables for building old libraries.
- oldlibs="$output"
- func_append objs "$old_deplibs"
- lib)
- # Make sure we only generate libraries of the form `libNAME.la'.
- case $outputname in
- lib*)
- func_stripname 'lib' '.la' "$outputname"
- eval shared_ext=\"$shrext_cmds\"
- eval libname=\"$libname_spec\"
- test "$module" = no && \
- func_fatal_help "libtool library \`$output' must begin with \`lib'"
- if test "$need_lib_prefix" != no; then
- # Add the "lib" prefix for modules if required
- func_stripname '' '.la' "$outputname"
- else
- libname=$func_stripname_result
- fi
- esac
- if test -n "$objs"; then
- func_fatal_error "cannot build libtool library \`$output' from non-libtool objects on this host:$objs"
- else
- echo
- $ECHO "*** Warning: Linking the shared library $output against the non-libtool"
- $ECHO "*** objects $objs is not portable!"
- func_append libobjs " $objs"
- fi
- fi
- test "$dlself" != no && \
- func_warning "\`-dlopen self' is ignored for libtool libraries"
- set dummy $rpath
- shift
- test "$#" -gt 1 && \
- func_warning "ignoring multiple \`-rpath's for a libtool library"
- install_libdir="$1"
- oldlibs=
- if test -z "$rpath"; then
- if test "$build_libtool_libs" = yes; then
- # Building a libtool convenience library.
- # Some compilers have problems with a `.al' extension so
- # convenience libraries should have the same extension an
- # archive normally would.
- oldlibs="$output_objdir/$libname.$libext $oldlibs"
- build_libtool_libs=convenience
- fi
- func_warning "\`-version-info/-version-number' is ignored for convenience libraries"
- func_warning "\`-release' is ignored for convenience libraries"
- else
- # Parse the version information argument.
- save_ifs="$IFS"; IFS=':'
- set dummy $vinfo 0 0 0
- shift
- IFS="$save_ifs"
- test -n "$7" && \
- func_fatal_help "too many parameters to \`-version-info'"
- # convert absolute version numbers to libtool ages
- # this retains compatibility with .la files and attempts
- # to make the code below a bit more comprehensible
- case $vinfo_number in
- yes)
- number_major="$1"
- number_minor="$2"
- number_revision="$3"
- # There are really only two kinds -- those that
- # use the current revision as the major version
- # and those that subtract age and use age as
- # a minor version. But, then there is irix
- # which has an extra 1 added just for fun
- case $version_type in
- # correct linux to gnu/linux during the next big refactor
- darwin|linux|osf|windows|none)
- func_arith $number_major + $number_minor
- current=$func_arith_result
- age="$number_minor"
- revision="$number_revision"
- freebsd-aout|freebsd-elf|qnx|sunos)
- current="$number_major"
- revision="$number_minor"
- age="0"
- irix|nonstopux)
- lt_irix_increment=no
- func_fatal_configuration "$modename: unknown library version type \`$version_type'"
- esac
- no)
- current="$1"
- revision="$2"
- age="$3"
- esac
- # Check that each of the things are valid numbers.
- case $current in
- 0|[1-9]|[1-9][0-9]|[1-9][0-9][0-9]|[1-9][0-9][0-9][0-9]|[1-9][0-9][0-9][0-9][0-9]) ;;
- func_error "CURRENT \`$current' must be a nonnegative integer"
- func_fatal_error "\`$vinfo' is not valid version information"
- esac
- case $revision in
- func_error "REVISION \`$revision' must be a nonnegative integer"
- esac
- case $age in
- func_error "AGE \`$age' must be a nonnegative integer"
- esac
- if test "$age" -gt "$current"; then
- func_error "AGE \`$age' is greater than the current interface number \`$current'"
- fi
- # Calculate the version variables.
- major=
- versuffix=
- verstring=
- none) ;;
- darwin)
- # Like Linux, but with the current version available in
- # verstring for coding it into the library header
- major=.$func_arith_result
- versuffix="$major.$age.$revision"
- # Darwin ld doesn't like 0 for these options...
- func_arith $current + 1
- minor_current=$func_arith_result
- xlcverstring="${wl}-compatibility_version ${wl}$minor_current ${wl}-current_version ${wl}$minor_current.$revision"
- verstring="-compatibility_version $minor_current -current_version $minor_current.$revision"
- freebsd-aout)
- major=".$current"
- versuffix=".$current.$revision";
- freebsd-elf)
- major=".$current"
- versuffix=".$current"
- irix | nonstopux)
- if test "X$lt_irix_increment" = "Xno"; then
- else
- func_arith $current - $age + 1
- fi
- nonstopux) verstring_prefix=nonstopux ;;
- *) verstring_prefix=sgi ;;
- esac
- verstring="$verstring_prefix$major.$revision"
- # Add in all the interfaces that we are compatible with.
- loop=$revision
- while test "$loop" -ne 0; do
- func_arith $revision - $loop
- iface=$func_arith_result
- func_arith $loop - 1
- loop=$func_arith_result
- verstring="$verstring_prefix$major.$iface:$verstring"
- done
- # Before this point, $major must not contain `.'.
- major=.$major
- versuffix="$major.$revision"
- linux) # correct to gnu/linux during the next big refactor
- osf)
- versuffix=".$current.$age.$revision"
- verstring="$current.$age.$revision"
- loop=$age
- func_arith $current - $loop
- verstring="$verstring:${iface}.0"
- done
- # Make executables depend on our current version.
- func_append verstring ":${current}.0"
- qnx)
- major=".$current"
- sunos)
- major=".$current"
- windows)
- # Use '-' rather than '.', since we only want one
- # extension on DOS 8.3 filesystems.
- func_fatal_configuration "unknown library version type \`$version_type'"
- esac
- # Clear the version info if we defaulted, and they specified a release.
- if test -z "$vinfo" && test -n "$release"; then
- major=
- darwin)
- # we can't check for "0.0" in archive_cmds due to quoting
- # problems, so we reset it completely
- verstring=
- verstring="0.0"
- esac
- if test "$need_version" = no; then
- versuffix=
- else
- versuffix=".0.0"
- fi
- fi
- # Remove version info from name if versioning should be avoided
- if test "$avoid_version" = yes && test "$need_version" = no; then
- major=
- versuffix=
- verstring=""
- fi
- # Check to see if the archive will have undefined symbols.
- if test "$allow_undefined" = yes; then
- if test "$allow_undefined_flag" = unsupported; then
- func_warning "undefined symbols not allowed in $host shared libraries"
- fi
- else
- # Don't allow undefined symbols.
- allow_undefined_flag="$no_undefined_flag"
- fi
- fi
- func_generate_dlsyms "$libname" "$libname" "yes"
- func_append libobjs " $symfileobj"
- test "X$libobjs" = "X " && libobjs=
- if test "$opt_mode" != relink; then
- # Remove our outputs, but don't remove object files since they
- # may have been created when compiling PIC objects.
- removelist=
- tempremovelist=`$ECHO "$output_objdir/*"`
- for p in $tempremovelist; do
- case $p in
- *.$objext | *.gcno)
- $output_objdir/$outputname | $output_objdir/$libname.* | $output_objdir/${libname}${release}.*)
- if test "X$precious_files_regex" != "X"; then
- if $ECHO "$p" | $EGREP -e "$precious_files_regex" >/dev/null 2>&1
- then
- continue
- fi
- fi
- func_append removelist " $p"
- esac
- done
- test -n "$removelist" && \
- func_show_eval "${RM}r \$removelist"
- fi
- if test "$build_old_libs" = yes && test "$build_libtool_libs" != convenience ; then
- func_append oldlibs " $output_objdir/$libname.$libext"
- # Transform .lo files to .o files.
- oldobjs="$objs "`$ECHO "$libobjs" | $SP2NL | $SED "/\.${libext}$/d; $lo2o" | $NL2SP`
- fi
- # Eliminate all temporary directories.
- #for path in $notinst_path; do
- # lib_search_path=`$ECHO "$lib_search_path " | $SED "s% $path % %g"`
- # deplibs=`$ECHO "$deplibs " | $SED "s% -L$path % %g"`
- # dependency_libs=`$ECHO "$dependency_libs " | $SED "s% -L$path % %g"`
- #done
- if test -n "$xrpath"; then
- # If the user specified any rpath flags, then add them.
- temp_xrpath=
- for libdir in $xrpath; do
- func_replace_sysroot "$libdir"
- func_append temp_xrpath " -R$func_replace_sysroot_result"
- *" $libdir "*) ;;
- esac
- done
- if test "$hardcode_into_libs" != yes || test "$build_old_libs" = yes; then
- dependency_libs="$temp_xrpath $dependency_libs"
- fi
- fi
- # Make sure dlfiles contains only unique files that won't be dlpreopened
- old_dlfiles="$dlfiles"
- dlfiles=
- for lib in $old_dlfiles; do
- case " $dlprefiles $dlfiles " in
- *" $lib "*) ;;
- *) func_append dlfiles " $lib" ;;
- esac
- done
- # Make sure dlprefiles contains only unique files
- old_dlprefiles="$dlprefiles"
- dlprefiles=
- for lib in $old_dlprefiles; do
- case "$dlprefiles " in
- *" $lib "*) ;;
- *) func_append dlprefiles " $lib" ;;
- esac
- done
- if test -n "$rpath"; then
- case $host in
- *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2* | *-*-beos* | *-cegcc* | *-*-haiku*)
- # these systems don't actually have a c library (as such)!
- # Rhapsody C library is in the System framework
- *-*-netbsd*)
- # Don't link with libc until the a.out ld.so is fixed.
- # Add libc to deplibs on all other systems if necessary.
- if test "$build_libtool_need_lc" = "yes"; then
- func_append deplibs " -lc"
- fi
- esac
- fi
- # Transform deplibs into only deplibs that can be linked in shared.
- name_save=$name
- libname_save=$libname
- release_save=$release
- versuffix_save=$versuffix
- major_save=$major
- # I'm not sure if I'm treating the release correctly. I think
- # release should show up in the -l (ie -lgmp5) so we don't want to
- # add it in twice. Is that correct?
- release=""
- versuffix=""
- major=""
- newdeplibs=
- droppeddeps=no
- pass_all)
- # Don't check for shared/static. Everything works.
- # This might be a little naive. We might want to check
- # whether the library exists or not. But this is on
- # osf3 & osf4 and I'm not really sure... Just
- # implementing what was already the behavior.
- newdeplibs=$deplibs
- test_compile)
- # This code stresses the "libraries are programs" paradigm to its
- # limits. Maybe even breaks it. We compile a program, linking it
- # against the deplibs as a proxy for the library. Then we can check
- # whether they linked in statically or dynamically with ldd.
- $opt_dry_run || $RM conftest.c
- cat > conftest.c <<EOF
- int main() { return 0; }
-EOF
- if $LTCC $LTCFLAGS -o conftest conftest.c $deplibs; then
- ldd_output=`ldd conftest`
- for i in $deplibs; do
- case $i in
- -l*)
- func_stripname -l '' "$i"
- *" $i "*)
- func_append newdeplibs " $i"
- i=""
- esac
- fi
- deplib_matches=`eval "\\$ECHO \"$library_names_spec\""`
- set dummy $deplib_matches; shift
- deplib_match=$1
- if test `expr "$ldd_output" : ".*$deplib_match"` -ne 0 ; then
- else
- droppeddeps=yes
- echo
- $ECHO "*** Warning: dynamic linker does not accept needed library $i."
- echo "*** shared version of the library, which I believe you do not have"
- echo "*** because a test_compile did reveal that the linker did not use it for"
- echo "*** its dynamic dependency list that programs get resolved with at runtime."
- fi
- fi
- esac
- done
- else
- # Error occurred in the first compile. Let's try to salvage
- # the situation: Compile a separate program for each library.
- case $i in
- -l*)
- if $LTCC $LTCFLAGS -o conftest conftest.c $i; then
- *" $i "*)
- i=""
- esac
- fi
- deplib_match=$1
- else
- droppeddeps=yes
- echo
- echo "*** because a test_compile did reveal that the linker did not use this one"
- echo "*** as a dynamic dependency that programs can get resolved with at runtime."
- fi
- fi
- else
- droppeddeps=yes
- echo
- $ECHO "*** Warning! Library $i is needed by this library but I was not able to"
- echo "*** make it link in! You will probably need to install it or some"
- echo "*** library that it depends on before this library will be fully"
- echo "*** functional. Installing it before continuing would be even better."
- fi
- esac
- done
- fi
- file_magic*)
- file_magic_regex=`expr "$deplibs_check_method" : "$1 \(.*\)"`
- for a_deplib in $deplibs; do
- case $a_deplib in
- -l*)
- func_stripname -l '' "$a_deplib"
- *" $a_deplib "*)
- func_append newdeplibs " $a_deplib"
- a_deplib=""
- esac
- fi
- if test -n "$a_deplib" ; then
- if test -n "$file_magic_glob"; then
- libnameglob=`func_echo_all "$libname" | $SED -e $file_magic_glob`
- else
- libnameglob=$libname
- fi
- test "$want_nocaseglob" = yes && nocaseglob=`shopt -p nocaseglob`
- for i in $lib_search_path $sys_lib_search_path $shlib_search_path; do
- if test "$want_nocaseglob" = yes; then
- shopt -s nocaseglob
- potential_libs=`ls $i/$libnameglob[.-]* 2>/dev/null`
- $nocaseglob
- else
- fi
- for potent_lib in $potential_libs; do
- # Follow soft links.
- if ls -lLd "$potent_lib" 2>/dev/null |
- $GREP " -> " >/dev/null; then
- continue
- fi
- # The statement above tries to avoid entering an
- # endless loop below, in case of cyclic links.
- # We might still enter an endless loop, since a link
- # loop can be closed while we follow links,
- # but so what?
- potlib="$potent_lib"
- while test -h "$potlib" 2>/dev/null; do
- potliblink=`ls -ld $potlib | ${SED} 's/.* -> //'`
- case $potliblink in
- [\\/]* | [A-Za-z]:[\\/]*) potlib="$potliblink";;
- *) potlib=`$ECHO "$potlib" | $SED 's,[^/]*$,,'`"$potliblink";;
- esac
- done
- if eval $file_magic_cmd \"\$potlib\" 2>/dev/null |
- $SED -e 10q |
- $EGREP "$file_magic_regex" > /dev/null; then
- a_deplib=""
- break 2
- fi
- done
- done
- fi
- droppeddeps=yes
- echo
- $ECHO "*** Warning: linker path does not have real file for library $a_deplib."
- echo "*** because I did check the linker path looking for a file starting"
- if test -z "$potlib" ; then
- $ECHO "*** with $libname but no candidates were found. (...for file magic test)"
- else
- $ECHO "*** with $libname and none of the candidates passed a file format test"
- $ECHO "*** using a file magic. Last file checked: $potlib"
- fi
- fi
- # Add a -L argument.
- esac
- done # Gone through all deplibs.
- match_pattern*)
- case $a_deplib in
- -l*)
- *" $a_deplib "*)
- a_deplib=""
- esac
- fi
- potential_libs=`ls $i/$libname[.-]* 2>/dev/null`
- potlib="$potent_lib" # see symlink-check above in file_magic test
- if eval "\$ECHO \"$potent_lib\"" 2>/dev/null | $SED 10q | \
- $EGREP "$match_pattern_regex" > /dev/null; then
- a_deplib=""
- break 2
- fi
- done
- done
- fi
- droppeddeps=yes
- echo
- $ECHO "*** with $libname but no candidates were found. (...for regex pattern test)"
- else
- $ECHO "*** using a regex pattern. Last file checked: $potlib"
- fi
- fi
- esac
- none | unknown | *)
- newdeplibs=""
- tmp_deplibs=`$ECHO " $deplibs" | $SED 's/ -lc$//; s/ -[LR][^ ]*//g'`
- for i in $predeps $postdeps ; do
- # can't use Xsed below, because $i might contain '/'
- tmp_deplibs=`$ECHO " $tmp_deplibs" | $SED "s,$i,,"`
- done
- fi
- case $tmp_deplibs in
- echo
- if test "X$deplibs_check_method" = "Xnone"; then
- echo "*** Warning: inter-library dependencies are not supported in this platform."
- else
- echo "*** Warning: inter-library dependencies are not known to be supported."
- fi
- echo "*** All declared inter-library dependencies are being dropped."
- droppeddeps=yes
- esac
- esac
- versuffix=$versuffix_save
- major=$major_save
- release=$release_save
- libname=$libname_save
- name=$name_save
- case $host in
- # On Rhapsody replace the C library with the System framework
- newdeplibs=`$ECHO " $newdeplibs" | $SED 's/ -lc / System.ltframework /'`
- esac
- if test "$droppeddeps" = yes; then
- echo
- echo "*** Warning: libtool could not satisfy all declared inter-library"
- $ECHO "*** dependencies of module $libname. Therefore, libtool will create"
- echo "*** a static module, that should work as long as the dlopening"
- echo "*** application is linked with the -dlopen flag."
- echo
- fi
- oldlibs="$output_objdir/$libname.$libext"
- else
- fi
- else
- echo "*** The inter-library dependencies that have been dropped here will be"
- echo "*** automatically added whenever a program is linked with this library"
- echo "*** or is declared to -dlopen it."
- if test "$allow_undefined" = no; then
- echo
- echo "*** Since this library must not contain undefined symbols,"
- echo "*** because either the platform does not support them or"
- echo "*** it was explicitly requested with -no-undefined,"
- echo "*** libtool will only create a static version of it."
- else
- fi
- fi
- fi
- fi
- # Done checking deplibs!
- deplibs=$newdeplibs
- fi
- # Time to change all our "foo.ltframework" stuff back to "-framework foo"
- case $host in
- *-*-darwin*)
- newdeplibs=`$ECHO " $newdeplibs" | $SED 's% \([^ $]*\).ltframework% -framework \1%g'`
- new_inherited_linker_flags=`$ECHO " $new_inherited_linker_flags" | $SED 's% \([^ $]*\).ltframework% -framework \1%g'`
- deplibs=`$ECHO " $deplibs" | $SED 's% \([^ $]*\).ltframework% -framework \1%g'`
- esac
- # move library search paths that coincide with paths to not yet
- # installed libraries to the beginning of the library search list
- new_libs=
- for path in $notinst_path; do
- *" -L$path/$objdir "*) ;;
- func_append new_libs " -L$path/$objdir" ;;
- esac
- esac
- done
- case $deplib in
- -L*)
- *" $deplib "*) ;;
- *) func_append new_libs " $deplib" ;;
- esac
- esac
- done
- deplibs="$new_libs"
- # All the library-specific variables (install_libdir is set above).
- library_names=
- old_library=
- dlname=
- # Test again, we may have decided not to build it any more
- # Remove ${wl} instances when linking with ld.
- # FIXME: should test the right _cmds variable.
- case $archive_cmds in
- *\$LD\ *) wl= ;;
- esac
- if test "$hardcode_into_libs" = yes; then
- # Hardcode the library paths
- hardcode_libdirs=
- dep_rpath=
- rpath="$finalize_rpath"
- test "$opt_mode" != relink && rpath="$compile_rpath$rpath"
- for libdir in $rpath; do
- if test -n "$hardcode_libdir_flag_spec"; then
- if test -n "$hardcode_libdir_separator"; then
- libdir=$func_replace_sysroot_result
- if test -z "$hardcode_libdirs"; then
- hardcode_libdirs="$libdir"
- else
- # Just accumulate the unique libdirs.
- case $hardcode_libdir_separator$hardcode_libdirs$hardcode_libdir_separator in
- *"$hardcode_libdir_separator$libdir$hardcode_libdir_separator"*)
- func_append hardcode_libdirs "$hardcode_libdir_separator$libdir"
- esac
- fi
- else
- eval flag=\"$hardcode_libdir_flag_spec\"
- func_append dep_rpath " $flag"
- fi
- elif test -n "$runpath_var"; then
- case "$perm_rpath " in
- *" $libdir "*) ;;
- *) func_append perm_rpath " $libdir" ;;
- esac
- fi
- done
- # Substitute the hardcoded libdirs into the rpath.
- if test -n "$hardcode_libdir_separator" &&
- test -n "$hardcode_libdirs"; then
- libdir="$hardcode_libdirs"
- eval "dep_rpath=\"$hardcode_libdir_flag_spec\""
- fi
- if test -n "$runpath_var" && test -n "$perm_rpath"; then
- # We should set the runpath_var.
- rpath=
- for dir in $perm_rpath; do
- func_append rpath "$dir:"
- done
- eval "$runpath_var='$rpath\$$runpath_var'; export $runpath_var"
- fi
- test -n "$dep_rpath" && deplibs="$dep_rpath $deplibs"
- fi
- shlibpath="$finalize_shlibpath"
- test "$opt_mode" != relink && shlibpath="$compile_shlibpath$shlibpath"
- if test -n "$shlibpath"; then
- eval "$shlibpath_var='$shlibpath\$$shlibpath_var'; export $shlibpath_var"
- fi
- # Get the real and link names of the library.
- eval library_names=\"$library_names_spec\"
- shift
- realname="$1"
- shift
- if test -n "$soname_spec"; then
- else
- fi
- if test -z "$dlname"; then
- dlname=$soname
- fi
- lib="$output_objdir/$realname"
- linknames=
- for link
- do
- func_append linknames " $link"
- done
- # Use standard objects if they are pic
- test -z "$pic_flag" && libobjs=`$ECHO "$libobjs" | $SP2NL | $SED "$lo2o" | $NL2SP`
- delfiles=
- if test -n "$export_symbols" && test -n "$include_expsyms"; then
- $opt_dry_run || cp "$export_symbols" "$output_objdir/$libname.uexp"
- export_symbols="$output_objdir/$libname.uexp"
- func_append delfiles " $export_symbols"
- fi
- orig_export_symbols=
- case $host_os in
- cygwin* | mingw* | cegcc*)
- if test -n "$export_symbols" && test -z "$export_symbols_regex"; then
- # exporting using user supplied symfile
- if test "x`$SED 1q $export_symbols`" != xEXPORTS; then
- # and it's NOT already a .def file. Must figure out
- # which of the given symbols are data symbols and tag
- # them as such. So, trigger use of export_symbols_cmds.
- # export_symbols gets reassigned inside the "prepare
- # the list of exported symbols" if statement, so the
- # include_expsyms logic still works.
- orig_export_symbols="$export_symbols"
- export_symbols=
- always_export_symbols=yes
- fi
- fi
- esac
- # Prepare the list of exported symbols
- if test -z "$export_symbols"; then
- if test "$always_export_symbols" = yes || test -n "$export_symbols_regex"; then
- func_verbose "generating symbol list for \`$libname.la'"
- export_symbols="$output_objdir/$libname.exp"
- $opt_dry_run || $RM $export_symbols
- cmds=$export_symbols_cmds
- save_ifs="$IFS"; IFS='~'
- for cmd1 in $cmds; do
- IFS="$save_ifs"
- # Take the normal branch if the nm_file_list_spec branch
- # doesn't work or if tool conversion is not needed.
- case $nm_file_list_spec~$to_tool_file_cmd in
- *~func_convert_file_noop | *~func_convert_file_msys_to_w32 | ~*)
- try_normal_branch=yes
- eval cmd=\"$cmd1\"
- func_len " $cmd"
- len=$func_len_result
- try_normal_branch=no
- esac
- if test "$try_normal_branch" = yes \
- && { test "$len" -lt "$max_cmd_len" \
- || test "$max_cmd_len" -le -1; }
- then
- func_show_eval "$cmd" 'exit $?'
- skipped_export=false
- elif test -n "$nm_file_list_spec"; then
- output_la=$func_basename_result
- save_libobjs=$libobjs
- save_output=$output
- output=${output_objdir}/${output_la}.nm
- func_to_tool_file "$output"
- libobjs=$nm_file_list_spec$func_to_tool_file_result
- func_append delfiles " $output"
- func_verbose "creating $NM input file list: $output"
- for obj in $save_libobjs; do
- func_to_tool_file "$obj"
- $ECHO "$func_to_tool_file_result"
- done > "$output"
- output=$save_output
- libobjs=$save_libobjs
- else
- # The command line is too long to execute in one step.
- func_verbose "using reloadable object file for export list..."
- skipped_export=:
- # Break out early, otherwise skipped_export may be
- # set to false by a later but shorter cmd.
- break
- fi
- done
- IFS="$save_ifs"
- if test -n "$export_symbols_regex" && test "X$skipped_export" != "X:"; then
- func_show_eval '$EGREP -e "$export_symbols_regex" "$export_symbols" > "${export_symbols}T"'
- func_show_eval '$MV "${export_symbols}T" "$export_symbols"'
- fi
- fi
- fi
- tmp_export_symbols="$export_symbols"
- test -n "$orig_export_symbols" && tmp_export_symbols="$orig_export_symbols"
- $opt_dry_run || eval '$ECHO "$include_expsyms" | $SP2NL >> "$tmp_export_symbols"'
- fi
- if test "X$skipped_export" != "X:" && test -n "$orig_export_symbols"; then
- # The given exports_symbols file has to be filtered, so filter it.
- func_verbose "filter symbol list for \`$libname.la' to tag DATA exports"
- # FIXME: $output_objdir/$libname.filter potentially contains lots of
- # 's' commands which not all seds can handle. GNU sed should be fine
- # though. Also, the filter scales superlinearly with the number of
- # global variables. join(1) would be nice here, but unfortunately
- # isn't a blessed tool.
- $opt_dry_run || $SED -e '/[ ,]DATA/!d;s,\(.*\)\([ \,].*\),s|^\1$|\1\2|,' < $export_symbols > $output_objdir/$libname.filter
- func_append delfiles " $export_symbols $output_objdir/$libname.filter"
- export_symbols=$output_objdir/$libname.def
- $opt_dry_run || $SED -f $output_objdir/$libname.filter < $orig_export_symbols > $export_symbols
- fi
- tmp_deplibs=
- for test_deplib in $deplibs; do
- case " $convenience " in
- *" $test_deplib "*) ;;
- func_append tmp_deplibs " $test_deplib"
- esac
- done
- if test -n "$convenience"; then
- if test -n "$whole_archive_flag_spec" &&
- test "$compiler_needs_object" = yes &&
- test -z "$libobjs"; then
- # extract the archives, so we have objects to list.
- # TODO: could optimize this to just extract one archive.
- whole_archive_flag_spec=
- fi
- if test -n "$whole_archive_flag_spec"; then
- eval libobjs=\"\$libobjs $whole_archive_flag_spec\"
- else
- gentop="$output_objdir/${outputname}x"
- func_append generated " $gentop"
- func_extract_archives $gentop $convenience
- func_append libobjs " $func_extract_archives_result"
- fi
- fi
- if test "$thread_safe" = yes && test -n "$thread_safe_flag_spec"; then
- eval flag=\"$thread_safe_flag_spec\"
- func_append linker_flags " $flag"
- fi
- # Make a backup of the uninstalled library when relinking
- if test "$opt_mode" = relink; then
- $opt_dry_run || eval '(cd $output_objdir && $RM ${realname}U && $MV $realname ${realname}U)' || exit $?
- fi
- # Do each of the archive commands.
- if test "$module" = yes && test -n "$module_cmds" ; then
- if test -n "$export_symbols" && test -n "$module_expsym_cmds"; then
- eval test_cmds=\"$module_expsym_cmds\"
- cmds=$module_expsym_cmds
- else
- eval test_cmds=\"$module_cmds\"
- cmds=$module_cmds
- fi
- else
- if test -n "$export_symbols" && test -n "$archive_expsym_cmds"; then
- eval test_cmds=\"$archive_expsym_cmds\"
- cmds=$archive_expsym_cmds
- else
- eval test_cmds=\"$archive_cmds\"
- cmds=$archive_cmds
- fi
- fi
- func_len " $test_cmds" &&
- len=$func_len_result &&
- test "$len" -lt "$max_cmd_len" || test "$max_cmd_len" -le -1; then
- else
- # The command line is too long to link in one step, link piecewise
- # or, if using GNU ld and skipped_export is not :, use a linker
- # script.
- # Save the value of $output and $libobjs because we want to
- # use them later. If we have whole_archive_flag_spec, we
- # want to use save_libobjs as it was before
- # whole_archive_flag_spec was expanded, because we can't
- # assume the linker understands whole_archive_flag_spec.
- # This may have to be revisited, in case too many
- # convenience libraries get linked in and end up exceeding
- # the spec.
- if test -z "$convenience" || test -z "$whole_archive_flag_spec"; then
- fi
- # Clear the reloadable object creation command queue and
- # initialize k to one.
- test_cmds=
- concat_cmds=
- objlist=
- last_robj=
- k=1
- if test -n "$save_libobjs" && test "X$skipped_export" != "X:" && test "$with_gnu_ld" = yes; then
- output=${output_objdir}/${output_la}.lnkscript
- func_verbose "creating GNU ld script: $output"
- echo 'INPUT (' > $output
- do
- $ECHO "$func_to_tool_file_result" >> $output
- done
- echo ')' >> $output
- output=$func_to_tool_file_result
- elif test -n "$save_libobjs" && test "X$skipped_export" != "X:" && test "X$file_list_spec" != X; then
- func_verbose "creating linker input file list: $output"
- : > $output
- set x $save_libobjs
- shift
- firstobj=
- if test "$compiler_needs_object" = yes; then
- firstobj="$1 "
- shift
- fi
- for obj
- do
- done
- output=$firstobj\"$file_list_spec$func_to_tool_file_result\"
- else
- if test -n "$save_libobjs"; then
- func_verbose "creating reloadable object files..."
- output=$output_objdir/$output_la-${k}.$objext
- eval test_cmds=\"$reload_cmds\"
- len0=$func_len_result
- len=$len0
- # Loop over the list of objects to be linked.
- do
- func_len " $obj"
- func_arith $len + $func_len_result
- len=$func_arith_result
- if test "X$objlist" = X ||
- test "$len" -lt "$max_cmd_len"; then
- func_append objlist " $obj"
- else
- # The command $test_cmds is almost too long, add a
- # command to the queue.
- if test "$k" -eq 1 ; then
- # The first file doesn't have a previous command to add.
- reload_objs=$objlist
- eval concat_cmds=\"$reload_cmds\"
- else
- # All subsequent reloadable object files will link in
- # the last one created.
- reload_objs="$objlist $last_robj"
- eval concat_cmds=\"\$concat_cmds~$reload_cmds~\$RM $last_robj\"
- fi
- last_robj=$output_objdir/$output_la-${k}.$objext
- func_arith $k + 1
- k=$func_arith_result
- objlist=" $obj"
- func_len " $last_robj"
- func_arith $len0 + $func_len_result
- fi
- done
- # Handle the remaining objects by creating one last
- # reloadable object file. All subsequent reloadable object
- # files will link in the last one created.
- test -z "$concat_cmds" || concat_cmds=$concat_cmds~
- eval concat_cmds=\"\${concat_cmds}$reload_cmds\"
- if test -n "$last_robj"; then
- eval concat_cmds=\"\${concat_cmds}~\$RM $last_robj\"
- fi
- else
- output=
- fi
- if ${skipped_export-false}; then
- libobjs=$output
- # Append the command to create the export file.
- eval concat_cmds=\"\$concat_cmds$export_symbols_cmds\"
- eval concat_cmds=\"\$concat_cmds~\$RM $last_robj\"
- fi
- fi
- test -n "$save_libobjs" &&
- func_verbose "creating a temporary reloadable object file: $output"
- # Loop through the commands generated above and execute them.
- for cmd in $concat_cmds; do
- IFS="$save_ifs"
- $opt_silent || {
- func_quote_for_expand "$cmd"
- eval "func_echo $func_quote_for_expand_result"
- $opt_dry_run || eval "$cmd" || {
- lt_exit=$?
- # Restore the uninstalled library and exit
- ( cd "$output_objdir" && \
- $RM "${realname}T" && \
- $MV "${realname}U" "$realname" )
- fi
- exit $lt_exit
- done
- IFS="$save_ifs"
- if test -n "$export_symbols_regex" && ${skipped_export-false}; then
- fi
- fi
- fi
- if test -n "$orig_export_symbols"; then
- fi
- fi
- libobjs=$output
- # Restore the value of output.
- if test -n "$convenience" && test -n "$whole_archive_flag_spec"; then
- fi
- # Expand the library linking commands again to reset the
- # value of $libobjs for piecewise linking.
- else
- cmds=$module_cmds
- fi
- else
- else
- fi
- fi
- fi
- if test -n "$delfiles"; then
- # Append the command to remove temporary files to $cmds.
- eval cmds=\"\$cmds~\$RM $delfiles\"
- fi
- # Add any objects from preloaded convenience libraries
- if test -n "$dlprefiles"; then
- func_extract_archives $gentop $dlprefiles
- fi
- for cmd in $cmds; do
- IFS="$save_ifs"
- eval cmd=\"$cmd\"
- $opt_silent || {
- lt_exit=$?
- fi
- exit $lt_exit
- done
- IFS="$save_ifs"
- $opt_dry_run || eval '(cd $output_objdir && $RM ${realname}T && $MV $realname ${realname}T && $MV ${realname}U $realname)' || exit $?
- if test -z "$whole_archive_flag_spec"; then
- func_show_eval '${RM}r "$gentop"'
- fi
- fi
- exit $EXIT_SUCCESS
- fi
- # Create links to the real library.
- for linkname in $linknames; do
- if test "$realname" != "$linkname"; then
- func_show_eval '(cd "$output_objdir" && $RM "$linkname" && $LN_S "$realname" "$linkname")' 'exit $?'
- fi
- done
- # If -module or -export-dynamic was specified, set the dlname.
- if test "$module" = yes || test "$export_dynamic" = yes; then
- # On all known operating systems, these are identical.
- dlname="$soname"
- fi
- fi
- obj)
- func_warning "\`-dlopen' is ignored for objects"
- fi
- *\ -l* | *\ -L*)
- func_warning "\`-l' and \`-L' are ignored for objects" ;;
- esac
- func_warning "\`-rpath' is ignored for objects"
- func_warning "\`-R' is ignored for objects"
- func_warning "\`-version-info' is ignored for objects"
- func_warning "\`-release' is ignored for objects"
- case $output in
- *.lo)
- test -n "$objs$old_deplibs" && \
- func_fatal_error "cannot build library object \`$output' from non-libtool objects"
- libobj=$output
- func_lo2o "$libobj"
- obj=$func_lo2o_result
- libobj=
- obj="$output"
- esac
- # Delete the old objects.
- $opt_dry_run || $RM $obj $libobj
- # Objects from convenience libraries. This assumes
- # single-version convenience libraries. Whenever we create
- # different ones for PIC/non-PIC, this we'll have to duplicate
- # the extraction.
- reload_conv_objs=
- gentop=
- # reload_cmds runs $LD directly, so let us get rid of
- # -Wl from whole_archive_flag_spec and hope we can get by with
- # turning comma into space..
- wl=
- eval tmp_whole_archive_flags=\"$whole_archive_flag_spec\"
- reload_conv_objs=$reload_objs\ `$ECHO "$tmp_whole_archive_flags" | $SED 's|,| |g'`
- else
- gentop="$output_objdir/${obj}x"
- reload_conv_objs="$reload_objs $func_extract_archives_result"
- fi
- fi
- # If we're not building shared, we need to use non_pic_objs
- test "$build_libtool_libs" != yes && libobjs="$non_pic_objects"
- # Create the old-style object.
- reload_objs="$objs$old_deplibs "`$ECHO "$libobjs" | $SP2NL | $SED "/\.${libext}$/d; /\.lib$/d; $lo2o" | $NL2SP`" $reload_conv_objs" ### testsuite: skip nested quoting test
- output="$obj"
- func_execute_cmds "$reload_cmds" 'exit $?'
- # Exit if we aren't doing a library object file.
- if test -z "$libobj"; then
- if test -n "$gentop"; then
- fi
- fi
- if test "$build_libtool_libs" != yes; then
- fi
- # Create an invalid libtool object if no PIC, so that we don't
- # accidentally link it into a program.
- # $show "echo timestamp > $libobj"
- # $opt_dry_run || eval "echo timestamp > $libobj" || exit $?
- fi
- if test -n "$pic_flag" || test "$pic_mode" != default; then
- # Only do commands if we really have different PIC objects.
- reload_objs="$libobjs $reload_conv_objs"
- output="$libobj"
- fi
- fi
- prog)
- case $host in
- *cygwin*) func_stripname '' '.exe' "$output"
- output=$func_stripname_result.exe;;
- esac
- func_warning "\`-version-info' is ignored for programs"
- func_warning "\`-release' is ignored for programs"
- test "$preload" = yes \
- && test "$dlopen_support" = unknown \
- && test "$dlopen_self" = unknown \
- && test "$dlopen_self_static" = unknown && \
- func_warning "\`LT_INIT([dlopen])' not used. Assuming no dlopen support."
- case $host in
- *-*-rhapsody* | *-*-darwin1.[012])
- # On Rhapsody replace the C library is the System framework
- compile_deplibs=`$ECHO " $compile_deplibs" | $SED 's/ -lc / System.ltframework /'`
- finalize_deplibs=`$ECHO " $finalize_deplibs" | $SED 's/ -lc / System.ltframework /'`
- esac
- case $host in
- *-*-darwin*)
- # Don't allow lazy linking, it breaks C++ global constructors
- # But is supposedly fixed on 10.4 or later (yay!).
- if test "$tagname" = CXX ; then
- case ${MACOSX_DEPLOYMENT_TARGET-10.0} in
- 10.[0123])
- func_append compile_command " ${wl}-bind_at_load"
- func_append finalize_command " ${wl}-bind_at_load"
- esac
- fi
- compile_deplibs=`$ECHO " $compile_deplibs" | $SED 's% \([^ $]*\).ltframework% -framework \1%g'`
- finalize_deplibs=`$ECHO " $finalize_deplibs" | $SED 's% \([^ $]*\).ltframework% -framework \1%g'`
- esac
- new_libs=
- case " $compile_deplibs " in
- esac
- esac
- done
- for deplib in $compile_deplibs; do
- case $deplib in
- -L*)
- *" $deplib "*) ;;
- esac
- esac
- done
- compile_deplibs="$new_libs"
- func_append compile_command " $compile_deplibs"
- func_append finalize_command " $finalize_deplibs"
- if test -n "$rpath$xrpath"; then
- for libdir in $rpath $xrpath; do
- # This is the magic to use -rpath.
- *" $libdir "*) ;;
- esac
- done
- fi
- # Now hardcode the library paths
- rpath=
- hardcode_libdirs=
- for libdir in $compile_rpath $finalize_rpath; do
- else
- esac
- fi
- else
- func_append rpath " $flag"
- fi
- *" $libdir "*) ;;
- esac
- fi
- case $host in
- *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2* | *-cegcc*)
- testbindir=`${ECHO} "$libdir" | ${SED} -e 's*/lib$*/bin*'`
- case :$dllsearchpath: in
- *":$libdir:"*) ;;
- ::) dllsearchpath=$libdir;;
- *) func_append dllsearchpath ":$libdir";;
- esac
- *":$testbindir:"*) ;;
- ::) dllsearchpath=$testbindir;;
- *) func_append dllsearchpath ":$testbindir";;
- esac
- esac
- done
- eval rpath=\" $hardcode_libdir_flag_spec\"
- fi
- compile_rpath="$rpath"
- rpath=
- hardcode_libdirs=
- for libdir in $finalize_rpath; do
- else
- esac
- fi
- else
- fi
- case "$finalize_perm_rpath " in
- *" $libdir "*) ;;
- *) func_append finalize_perm_rpath " $libdir" ;;
- esac
- fi
- done
- fi
- finalize_rpath="$rpath"
- if test -n "$libobjs" && test "$build_old_libs" = yes; then
- # Transform all the library objects into standard objects.
- compile_command=`$ECHO "$compile_command" | $SP2NL | $SED "$lo2o" | $NL2SP`
- finalize_command=`$ECHO "$finalize_command" | $SP2NL | $SED "$lo2o" | $NL2SP`
- fi
- func_generate_dlsyms "$outputname" "@PROGRAM@" "no"
- # template prelinking step
- if test -n "$prelink_cmds"; then
- func_execute_cmds "$prelink_cmds" 'exit $?'
- fi
- wrappers_required=yes
- case $host in
- *cegcc* | *mingw32ce*)
- # Disable wrappers for cegcc and mingw32ce hosts, we are cross compiling anyway.
- wrappers_required=no
- *cygwin* | *mingw* )
- fi
- if test "$need_relink" = no || test "$build_libtool_libs" != yes; then
- fi
- esac
- if test "$wrappers_required" = no; then
- # Replace the output file specification.
- compile_command=`$ECHO "$compile_command" | $SED 's%@OUTPUT@%'"$output"'%g'`
- link_command="$compile_command$compile_rpath"
- # We have no uninstalled library dependencies, so finalize right now.
- exit_status=0
- func_show_eval "$link_command" 'exit_status=$?'
- if test -n "$postlink_cmds"; then
- postlink_cmds=`func_echo_all "$postlink_cmds" | $SED -e 's%@OUTPUT@%'"$output"'%g' -e 's%@TOOL_OUTPUT@%'"$func_to_tool_file_result"'%g'`
- func_execute_cmds "$postlink_cmds" 'exit $?'
- fi
- # Delete the generated files.
- if test -f "$output_objdir/${outputname}S.${objext}"; then
- func_show_eval '$RM "$output_objdir/${outputname}S.${objext}"'
- fi
- exit $exit_status
- fi
- if test -n "$compile_shlibpath$finalize_shlibpath"; then
- compile_command="$shlibpath_var=\"$compile_shlibpath$finalize_shlibpath\$$shlibpath_var\" $compile_command"
- fi
- if test -n "$finalize_shlibpath"; then
- finalize_command="$shlibpath_var=\"$finalize_shlibpath\$$shlibpath_var\" $finalize_command"
- fi
- compile_var=
- finalize_var=
- if test -n "$runpath_var"; then
- if test -n "$perm_rpath"; then
- rpath=
- done
- compile_var="$runpath_var=\"$rpath\$$runpath_var\" "
- fi
- if test -n "$finalize_perm_rpath"; then
- rpath=
- for dir in $finalize_perm_rpath; do
- done
- finalize_var="$runpath_var=\"$rpath\$$runpath_var\" "
- fi
- fi
- if test "$no_install" = yes; then
- # We don't need to create a wrapper script.
- link_command="$compile_var$compile_command$compile_rpath"
- link_command=`$ECHO "$link_command" | $SED 's%@OUTPUT@%'"$output"'%g'`
- # Delete the old output file.
- $opt_dry_run || $RM $output
- # Link the executable and exit
- func_show_eval "$link_command" 'exit $?'
- fi
- fi
- if test "$hardcode_action" = relink; then
- # Fast installation is not supported
- relink_command="$finalize_var$finalize_command$finalize_rpath"
- func_warning "this platform does not like uninstalled shared libraries"
- func_warning "\`$output' will be relinked during installation"
- else
- if test "$fast_install" != no; then
- link_command="$finalize_var$compile_command$finalize_rpath"
- if test "$fast_install" = yes; then
- relink_command=`$ECHO "$compile_var$compile_command$compile_rpath" | $SED 's%@OUTPUT@%\$progdir/\$file%g'`
- else
- # fast_install is set to needless
- relink_command=
- fi
- else
- fi
- fi
- link_command=`$ECHO "$link_command" | $SED 's%@OUTPUT@%'"$output_objdir/$outputname"'%g'`
- # Delete the old output files.
- $opt_dry_run || $RM $output $output_objdir/$outputname $output_objdir/lt-$outputname
- func_to_tool_file "$output_objdir/$outputname"
- postlink_cmds=`func_echo_all "$postlink_cmds" | $SED -e 's%@OUTPUT@%'"$output_objdir/$outputname"'%g' -e 's%@TOOL_OUTPUT@%'"$func_to_tool_file_result"'%g'`
- fi
- # Now create the wrapper script.
- func_verbose "creating $output"
- # Quote the relink command for shipping.
- if test -n "$relink_command"; then
- # Preserve any variables that may affect compiler behavior
- for var in $variables_saved_for_relink; do
- if eval test -z \"\${$var+set}\"; then
- relink_command="{ test -z \"\${$var+set}\" || $lt_unset $var || { $var=; export $var; }; }; $relink_command"
- elif eval var_value=\$$var; test -z "$var_value"; then
- relink_command="$var=; export $var; $relink_command"
- else
- func_quote_for_eval "$var_value"
- relink_command="$var=$func_quote_for_eval_result; export $var; $relink_command"
- fi
- done
- relink_command="(cd `pwd`; $relink_command)"
- relink_command=`$ECHO "$relink_command" | $SED "$sed_quote_subst"`
- fi
- # Only actually do things if not in dry run mode.
- $opt_dry_run || {
- # win32 will think the script is a binary if it has
- # a .exe suffix, so we strip it off here.
- case $output in
- *.exe) func_stripname '' '.exe' "$output"
- output=$func_stripname_result ;;
- esac
- # test for cygwin because mv fails w/o .exe extensions
- case $host in
- *cygwin*)
- exeext=.exe
- func_stripname '' '.exe' "$outputname"
- outputname=$func_stripname_result ;;
- *) exeext= ;;
- esac
- case $host in
- func_dirname_and_basename "$output" "" "."
- output_name=$func_basename_result
- output_path=$func_dirname_result
- cwrappersource="$output_path/$objdir/lt-$output_name.c"
- cwrapper="$output_path/$output_name.exe"
- $RM $cwrappersource $cwrapper
- trap "$RM $cwrappersource $cwrapper; exit $EXIT_FAILURE" 1 2 15
- func_emit_cwrapperexe_src > $cwrappersource
- # The wrapper executable is built using the $host compiler,
- # because it contains $host paths and files. If cross-
- # compiling, it, like the target executable, must be
- # executed on the $host or under an emulation environment.
- $opt_dry_run || {
- $LTCC $LTCFLAGS -o $cwrapper $cwrappersource
- $STRIP $cwrapper
- # Now, create the wrapper script for func_source use:
- func_ltwrapper_scriptname $cwrapper
- $RM $func_ltwrapper_scriptname_result
- trap "$RM $func_ltwrapper_scriptname_result; exit $EXIT_FAILURE" 1 2 15
- $opt_dry_run || {
- # note: this script will not be executed, so do not chmod.
- if test "x$build" = "x$host" ; then
- $cwrapper --lt-dump-script > $func_ltwrapper_scriptname_result
- else
- func_emit_wrapper no > $func_ltwrapper_scriptname_result
- fi
- $RM $output
- trap "$RM $output; exit $EXIT_FAILURE" 1 2 15
- func_emit_wrapper no > $output
- chmod +x $output
- esac
- esac
- # See if we need to build an old-fashioned archive.
- for oldlib in $oldlibs; do
- if test "$build_libtool_libs" = convenience; then
- oldobjs="$libobjs_save $symfileobj"
- addlibs="$convenience"
- build_libtool_libs=no
- else
- if test "$build_libtool_libs" = module; then
- oldobjs="$libobjs_save"
- else
- oldobjs="$old_deplibs $non_pic_objects"
- if test "$preload" = yes && test -f "$symfileobj"; then
- func_append oldobjs " $symfileobj"
- fi
- fi
- addlibs="$old_convenience"
- fi
- if test -n "$addlibs"; then
- func_extract_archives $gentop $addlibs
- func_append oldobjs " $func_extract_archives_result"
- fi
- # Do each command in the archive commands.
- if test -n "$old_archive_from_new_cmds" && test "$build_libtool_libs" = yes; then
- cmds=$old_archive_from_new_cmds
- else
- fi
- # POSIX demands no paths to be encoded in archives. We have
- # to avoid creating archives with duplicate basenames if we
- # might have to extract them afterwards, e.g., when creating a
- # static archive out of a convenience library, or when linking
- # the entirety of a libtool archive into another (currently
- # not supported by libtool).
- if (for obj in $oldobjs
- do
- func_basename "$obj"
- $ECHO "$func_basename_result"
- done | sort | sort -uc >/dev/null 2>&1); then
- else
- echo "copying selected object files to avoid basename conflicts..."
- func_mkdir_p "$gentop"
- save_oldobjs=$oldobjs
- oldobjs=
- counter=1
- for obj in $save_oldobjs
- do
- objbase="$func_basename_result"
- case " $oldobjs " in
- " ") oldobjs=$obj ;;
- *[\ /]"$objbase "*)
- while :; do
- # Make sure we don't pick an alternate name that also
- # overlaps.
- newobj=lt$counter-$objbase
- func_arith $counter + 1
- counter=$func_arith_result
- *[\ /]"$newobj "*) ;;
- *) if test ! -f "$gentop/$newobj"; then break; fi ;;
- esac
- done
- func_show_eval "ln $obj $gentop/$newobj || cp $obj $gentop/$newobj"
- func_append oldobjs " $gentop/$newobj"
- *) func_append oldobjs " $obj" ;;
- esac
- done
- fi
- func_to_tool_file "$oldlib" func_convert_file_msys_to_w32
- tool_oldlib=$func_to_tool_file_result
- eval cmds=\"$old_archive_cmds\"
- func_len " $cmds"
- if test "$len" -lt "$max_cmd_len" || test "$max_cmd_len" -le -1; then
- cmds=$old_archive_cmds
- elif test -n "$archiver_list_spec"; then
- func_verbose "using command file archive linking..."
- for obj in $oldobjs
- do
- done > $output_objdir/$libname.libcmd
- func_to_tool_file "$output_objdir/$libname.libcmd"
- oldobjs=" $archiver_list_spec$func_to_tool_file_result"
- else
- # the command line is too long to link in one step, link in parts
- func_verbose "using piecewise archive linking..."
- save_RANLIB=$RANLIB
- RANLIB=:
- objlist=
- concat_cmds=
- oldobjs=
- # Is there a better way of finding the last object in the list?
- do
- last_oldobj=$obj
- done
- eval test_cmds=\"$old_archive_cmds\"
- len=$len0
- do
- func_len " $obj"
- if test "$len" -lt "$max_cmd_len"; then
- else
- # the above command should be used before it gets too long
- oldobjs=$objlist
- if test "$obj" = "$last_oldobj" ; then
- RANLIB=$save_RANLIB
- fi
- eval concat_cmds=\"\${concat_cmds}$old_archive_cmds\"
- objlist=
- len=$len0
- fi
- done
- oldobjs=$objlist
- if test "X$oldobjs" = "X" ; then
- eval cmds=\"\$concat_cmds\"
- else
- eval cmds=\"\$concat_cmds~\$old_archive_cmds\"
- fi
- fi
- fi
- func_execute_cmds "$cmds" 'exit $?'
- done
- test -n "$generated" && \
- func_show_eval "${RM}r$generated"
- # Now create the libtool archive.
- case $output in
- *.la)
- old_library=
- test "$build_old_libs" = yes && old_library="$libname.$libext"
- else
- fi
- done
- # Quote the link command for shipping.
- relink_command="(cd `pwd`; $SHELL $progpath $preserve_args --mode=relink $libtool_args @inst_prefix_dir@)"
- if test "$hardcode_automatic" = yes ; then
- relink_command=
- fi
- # Only create the output if not a dry run.
- $opt_dry_run || {
- for installed in no yes; do
- if test "$installed" = yes; then
- if test -z "$install_libdir"; then
- break
- fi
- output="$output_objdir/$outputname"i
- # Replace all uninstalled libtool libraries with the installed ones
- newdependency_libs=
- for deplib in $dependency_libs; do
- case $deplib in
- *.la)
- func_basename "$deplib"
- name="$func_basename_result"
- func_resolve_sysroot "$deplib"
- eval libdir=`${SED} -n -e 's/^libdir=\(.*\)$/\1/p' $func_resolve_sysroot_result`
- test -z "$libdir" && \
- func_append newdependency_libs " ${lt_sysroot:+=}$libdir/$name"
- -L*)
- func_stripname -L '' "$deplib"
- func_replace_sysroot "$func_stripname_result"
- func_append newdependency_libs " -L$func_replace_sysroot_result"
- -R*)
- func_stripname -R '' "$deplib"
- func_append newdependency_libs " -R$func_replace_sysroot_result"
- *) func_append newdependency_libs " $deplib" ;;
- esac
- done
- newdlfiles=
- for lib in $dlfiles; do
- case $lib in
- *.la)
- func_basename "$lib"
- eval libdir=`${SED} -n -e 's/^libdir=\(.*\)$/\1/p' $lib`
- func_fatal_error "\`$lib' is not a valid libtool archive"
- func_append newdlfiles " ${lt_sysroot:+=}$libdir/$name"
- *) func_append newdlfiles " $lib" ;;
- esac
- done
- newdlprefiles=
- for lib in $dlprefiles; do
- case $lib in
- *.la)
- # Only pass preopened files to the pseudo-archive (for
- # eventual linking with the app. that links it) if we
- # didn't already link the preopened objects directly into
- # the library:
- func_append newdlprefiles " ${lt_sysroot:+=}$libdir/$name"
- esac
- done
- else
- newdlfiles=
- case $lib in
- [\\/]* | [A-Za-z]:[\\/]*) abs="$lib" ;;
- *) abs=`pwd`"/$lib" ;;
- esac
- func_append newdlfiles " $abs"
- done
- newdlprefiles=
- case $lib in
- esac
- func_append newdlprefiles " $abs"
- done
- fi
- $RM $output
- # place dlname in correct position for cygwin
- # In fact, it would be nice if we could use this code for all target
- # systems that can't hard-code library paths into their executables
- # and that have no shared library path variable independent of PATH,
- # but it turns out we can't easily determine that from inspecting
- # libtool variables, so we have to hard-code the OSs to which it
- # applies here; at the moment, that means platforms that use the PE
- # object format with DLL files. See the long comment at the top of
- # tests/bindir.at for full details.
- tdlname=$dlname
- case $host,$output,$installed,$module,$dlname in
- *cygwin*,*lai,yes,no,*.dll | *mingw*,*lai,yes,no,*.dll | *cegcc*,*lai,yes,no,*.dll)
- # If a -bindir argument was supplied, place the dll there.
- if test "x$bindir" != x ;
- then
- func_relative_path "$install_libdir" "$bindir"
- tdlname=$func_relative_path_result$dlname
- else
- # Otherwise fall back on heuristic.
- tdlname=../bin/$dlname
- fi
- esac
- $ECHO > $output "\
-# $outputname - a libtool library file
-# Generated by $PROGRAM (GNU $PACKAGE$TIMESTAMP) $VERSION
-# Please DO NOT delete this file!
-# It is necessary for linking the library.
-# The name that we can dlopen(3).
-dlname='$tdlname'
-# Names of this library.
-library_names='$library_names'
-# The name of the static archive.
-old_library='$old_library'
-# Linker flags that can not go in dependency_libs.
-inherited_linker_flags='$new_inherited_linker_flags'
-# Libraries that this one depends upon.
-dependency_libs='$dependency_libs'
-# Names of additional weak libraries provided by this library
-weak_library_names='$weak_libs'
-# Version information for $libname.
-current=$current
-age=$age
-revision=$revision
-# Is this an already installed library?
-installed=$installed
-# Should we warn about portability when linking against -modules?
-shouldnotlink=$module
-# Files to dlopen/dlpreopen
-dlopen='$dlfiles'
-dlpreopen='$dlprefiles'
-# Directory that this library needs to be installed in:
-libdir='$install_libdir'"
- if test "$installed" = no && test "$need_relink" = yes; then
- $ECHO >> $output "\
-relink_command=\"$relink_command\""
- fi
- done
- # Do a symbolic link so that the libtool archive can be found in
- # LD_LIBRARY_PATH before the program is installed.
- func_show_eval '( cd "$output_objdir" && $RM "$outputname" && $LN_S "../$outputname" "$outputname" )' 'exit $?'
- esac
-{ test "$opt_mode" = link || test "$opt_mode" = relink; } &&
- func_mode_link ${1+"$@"}
-# func_mode_uninstall arg...
-func_mode_uninstall ()
- $opt_debug
- RM="$nonopt"
- files=
- rmforce=
- exit_status=0
- # This variable tells wrapper scripts just to set variables rather
- # than running their programs.
- libtool_install_magic="$magic"
- for arg
- do
- case $arg in
- -f) func_append RM " $arg"; rmforce=yes ;;
- -*) func_append RM " $arg" ;;
- *) func_append files " $arg" ;;
- esac
- done
- test -z "$RM" && \
- func_fatal_help "you must specify an RM program"
- rmdirs=
- for file in $files; do
- func_dirname "$file" "" "."
- dir="$func_dirname_result"
- if test "X$dir" = X.; then
- odir="$objdir"
- else
- odir="$dir/$objdir"
- fi
- func_basename "$file"
- test "$opt_mode" = uninstall && odir="$dir"
- # Remember odir for removal later, being careful to avoid duplicates
- if test "$opt_mode" = clean; then
- case " $rmdirs " in
- *" $odir "*) ;;
- *) func_append rmdirs " $odir" ;;
- esac
- fi
- # Don't error if the file doesn't exist and rm -f was used.
- if { test -L "$file"; } >/dev/null 2>&1 ||
- { test -h "$file"; } >/dev/null 2>&1 ||
- test -f "$file"; then
- elif test -d "$file"; then
- exit_status=1
- continue
- elif test "$rmforce" = yes; then
- continue
- fi
- rmfiles="$file"
- case $name in
- *.la)
- # Possibly a libtool archive, so verify it.
- if func_lalib_p "$file"; then
- func_source $dir/$name
- # Delete the libtool libraries and symlinks.
- for n in $library_names; do
- func_append rmfiles " $odir/$n"
- done
- test -n "$old_library" && func_append rmfiles " $odir/$old_library"
- case "$opt_mode" in
- clean)
- case " $library_names " in
- *" $dlname "*) ;;
- *) test -n "$dlname" && func_append rmfiles " $odir/$dlname" ;;
- esac
- test -n "$libdir" && func_append rmfiles " $odir/$name $odir/${name}i"
- uninstall)
- if test -n "$library_names"; then
- # Do each command in the postuninstall commands.
- func_execute_cmds "$postuninstall_cmds" 'test "$rmforce" = yes || exit_status=1'
- fi
- if test -n "$old_library"; then
- # Do each command in the old_postuninstall commands.
- func_execute_cmds "$old_postuninstall_cmds" 'test "$rmforce" = yes || exit_status=1'
- fi
- # FIXME: should reinstall the best remaining shared library.
- esac
- fi
- *.lo)
- # Possibly a libtool object, so verify it.
- # Read the .lo file
- # Add PIC object to the list of files to remove.
- if test -n "$pic_object" &&
- test "$pic_object" != none; then
- func_append rmfiles " $dir/$pic_object"
- fi
- # Add non-PIC object to the list of files to remove.
- if test -n "$non_pic_object" &&
- test "$non_pic_object" != none; then
- func_append rmfiles " $dir/$non_pic_object"
- fi
- fi
- if test "$opt_mode" = clean ; then
- noexename=$name
- case $file in
- *.exe)
- func_stripname '' '.exe' "$file"
- file=$func_stripname_result
- func_stripname '' '.exe' "$name"
- noexename=$func_stripname_result
- # $file with .exe has already been added to rmfiles,
- # add $file without .exe
- func_append rmfiles " $file"
- esac
- # Do a test to see if this is a libtool program.
- if func_ltwrapper_p "$file"; then
- if func_ltwrapper_executable_p "$file"; then
- func_ltwrapper_scriptname "$file"
- relink_command=
- func_source $func_ltwrapper_scriptname_result
- func_append rmfiles " $func_ltwrapper_scriptname_result"
- else
- relink_command=
- func_source $dir/$noexename
- fi
- # note $name still contains .exe if it was in $file originally
- # as does the version of $file that was added into $rmfiles
- func_append rmfiles " $odir/$name $odir/${name}S.${objext}"
- if test "$fast_install" = yes && test -n "$relink_command"; then
- func_append rmfiles " $odir/lt-$name"
- fi
- if test "X$noexename" != "X$name" ; then
- func_append rmfiles " $odir/lt-${noexename}.c"
- fi
- fi
- fi
- esac
- func_show_eval "$RM $rmfiles" 'exit_status=1'
- done
- # Try to remove the ${objdir}s in the directories where we deleted files
- for dir in $rmdirs; do
- if test -d "$dir"; then
- func_show_eval "rmdir $dir >/dev/null 2>&1"
- fi
- done
- exit $exit_status
-{ test "$opt_mode" = uninstall || test "$opt_mode" = clean; } &&
- func_mode_uninstall ${1+"$@"}
-test -z "$opt_mode" && {
- help="$generic_help"
- func_fatal_help "you must specify a MODE"
-test -z "$exec_cmd" && \
- func_fatal_help "invalid operation mode \`$opt_mode'"
-if test -n "$exec_cmd"; then
- eval exec "$exec_cmd"
- exit $EXIT_FAILURE
-fi
-exit $exit_status
-# The TAGs below are defined such that we never get into a situation
-# in which we disable both kinds of libraries. Given conflicting
-# choices, we go for a static library, that is the most portable,
-# since we can't tell whether shared libraries were disabled because
-# the user asked for that or because the platform doesn't support
-# them. This is particularly important on AIX, because we don't
-# support having both static and shared libraries enabled at the same
-# time on that platform, so we default to a shared-only configuration.
-# If a disable-shared tag is given, we'll fallback to a static-only
-# configuration. But we'll never go from static-only to shared-only.
-# ### BEGIN LIBTOOL TAG CONFIG: disable-shared
-build_libtool_libs=no
-build_old_libs=yes
-# ### END LIBTOOL TAG CONFIG: disable-shared
-# ### BEGIN LIBTOOL TAG CONFIG: disable-static
-build_old_libs=`case $build_libtool_libs in yes) echo no;; *) echo yes;; esac`
-# ### END LIBTOOL TAG CONFIG: disable-static
-# Local Variables:
-# mode:shell-script
-# sh-indentation:2
-# End:
-# vi:sw=2
Index: modules/provider-coaster-c-client/config/install-sh
--- modules/provider-coaster-c-client/config/install-sh (revision 3826)
+++ modules/provider-coaster-c-client/config/install-sh (working copy)
@@ -1,520 +0,0 @@
-#!/bin/sh
-# install - install a program, script, or datafile
-scriptversion=2009-04-28.21; # UTC
-# This originates from X11R5 (mit/util/scripts/install.sh), which was
-# later released in X11R6 (xc/config/util/install.sh) with the
-# following copyright and license.
-# Copyright (C) 1994 X Consortium
-# Permission is hereby granted, free of charge, to any person obtaining a copy
-# of this software and associated documentation files (the "Software"), to
-# deal in the Software without restriction, including without limitation the
-# rights to use, copy, modify, merge, publish, distribute, sublicense, and/or
-# sell copies of the Software, and to permit persons to whom the Software is
-# furnished to do so, subject to the following conditions:
-# The above copyright notice and this permission notice shall be included in
-# all copies or substantial portions of the Software.
-# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
-# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
-# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
-# X CONSORTIUM BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN
-# AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNEC-
-# TION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
-# Except as contained in this notice, the name of the X Consortium shall not
-# be used in advertising or otherwise to promote the sale, use or other deal-
-# ings in this Software without prior written authorization from the X Consor-
-# tium.
-# FSF changes to this file are in the public domain.
-# Calling this script install-sh is preferred over install.sh, to prevent
-# `make' implicit rules from creating a file called install from it
-# when there is no Makefile.
-# This script is compatible with the BSD install script, but was written
-# from scratch.
-nl='
-IFS=" "" $nl"
-# set DOITPROG to echo to test this script
-# Don't use :- since 4.3BSD and earlier shells don't like it.
-doit=${DOITPROG-}
-if test -z "$doit"; then
- doit_exec=exec
-else
- doit_exec=$doit
-fi
-# Put in absolute file names if you don't have them in your path;
-# or use environment vars.
-chgrpprog=${CHGRPPROG-chgrp}
-chmodprog=${CHMODPROG-chmod}
-chownprog=${CHOWNPROG-chown}
-cmpprog=${CMPPROG-cmp}
-cpprog=${CPPROG-cp}
-mkdirprog=${MKDIRPROG-mkdir}
-mvprog=${MVPROG-mv}
-rmprog=${RMPROG-rm}
-stripprog=${STRIPPROG-strip}
-posix_glob='?'
-initialize_posix_glob='
- test "$posix_glob" != "?" || {
- if (set -f) 2>/dev/null; then
- posix_glob=
- else
- posix_glob=:
- fi
-posix_mkdir=
-# Desired mode of installed file.
-mode=0755
-chgrpcmd=
-chmodcmd=$chmodprog
-chowncmd=
-mvcmd=$mvprog
-rmcmd="$rmprog -f"
-stripcmd=
-src=
-dst=
-dir_arg=
-dst_arg=
-copy_on_change=false
-no_target_directory=
-usage="\
-Usage: $0 [OPTION]... [-T] SRCFILE DSTFILE
- or: $0 [OPTION]... SRCFILES... DIRECTORY
- or: $0 [OPTION]... -t DIRECTORY SRCFILES...
- or: $0 [OPTION]... -d DIRECTORIES...
-In the 1st form, copy SRCFILE to DSTFILE.
-In the 2nd and 3rd, copy all SRCFILES to DIRECTORY.
-In the 4th, create DIRECTORIES.
-Options:
- --help display this help and exit.
- --version display version info and exit.
- -c (ignored)
- -C install only if different (preserve the last data modification time)
- -d create directories instead of installing files.
- -g GROUP $chgrpprog installed files to GROUP.
- -m MODE $chmodprog installed files to MODE.
- -o USER $chownprog installed files to USER.
- -s $stripprog installed files.
- -t DIRECTORY install into DIRECTORY.
- -T report an error if DSTFILE is a directory.
-Environment variables override the default commands:
- CHGRPPROG CHMODPROG CHOWNPROG CMPPROG CPPROG MKDIRPROG MVPROG
- RMPROG STRIPPROG
-while test $# -ne 0; do
- case $1 in
- -c) ;;
- -C) copy_on_change=true;;
- -d) dir_arg=true;;
- -g) chgrpcmd="$chgrpprog $2"
- shift;;
- --help) echo "$usage"; exit $?;;
- -m) mode=$2
- case $mode in
- echo "$0: invalid mode: $mode" >&2
- exit 1;;
- esac
- shift;;
- -o) chowncmd="$chownprog $2"
- shift;;
- -s) stripcmd=$stripprog;;
- -t) dst_arg=$2
- shift;;
- -T) no_target_directory=true;;
- --version) echo "$0 $scriptversion"; exit $?;;
- --) shift
- break;;
- -*) echo "$0: invalid option: $1" >&2
- exit 1;;
- *) break;;
- esac
- shift
-done
-if test $# -ne 0 && test -z "$dir_arg$dst_arg"; then
- # When -d is used, all remaining arguments are directories to create.
- # When -t is used, the destination is already specified.
- # Otherwise, the last argument is the destination. Remove it from $@.
- for arg
- do
- if test -n "$dst_arg"; then
- # $@ is not empty: it contains at least $arg.
- set fnord "$@" "$dst_arg"
- shift # fnord
- fi
- shift # arg
- dst_arg=$arg
- done
-fi
-if test $# -eq 0; then
- if test -z "$dir_arg"; then
- echo "$0: no input file specified." >&2
- exit 1
- fi
- # It's OK to call `install-sh -d' without argument.
- # This can happen when creating conditional directories.
- exit 0
-fi
-if test -z "$dir_arg"; then
- trap '(exit $?); exit' 1 2 13 15
- # Set umask so as not to create temps with too-generous modes.
- # However, 'strip' requires both read and write access to temps.
- case $mode in
- # Optimize common cases.
- *644) cp_umask=133;;
- *755) cp_umask=22;;
- *[0-7])
- if test -z "$stripcmd"; then
- u_plus_rw=
- else
- u_plus_rw='% 200'
- fi
- cp_umask=`expr '(' 777 - $mode % 1000 ')' $u_plus_rw`;;
- u_plus_rw=
- else
- u_plus_rw=,u+rw
- fi
- cp_umask=$mode$u_plus_rw;;
- esac
-fi
-for src
-do
- # Protect names starting with `-'.
- case $src in
- -*) src=./$src;;
- esac
- if test -n "$dir_arg"; then
- dst=$src
- dstdir=$dst
- test -d "$dstdir"
- dstdir_status=$?
- else
- # Waiting for this to be detected by the "$cpprog $src $dsttmp" command
- # might cause directories to be created, which would be especially bad
- # if $src (and thus $dsttmp) contains '*'.
- if test ! -f "$src" && test ! -d "$src"; then
- echo "$0: $src does not exist." >&2
- exit 1
- fi
- if test -z "$dst_arg"; then
- echo "$0: no destination specified." >&2
- exit 1
- fi
- dst=$dst_arg
- case $dst in
- -*) dst=./$dst;;
- esac
- # If destination is a directory, append the input filename; won't work
- # if double slashes aren't ignored.
- if test -d "$dst"; then
- if test -n "$no_target_directory"; then
- echo "$0: $dst_arg: Is a directory" >&2
- exit 1
- fi
- dstdir=$dst
- dst=$dstdir/`basename "$src"`
- dstdir_status=0
- else
- # Prefer dirname, but fall back on a substitute if dirname fails.
- dstdir=`
- (dirname "$dst") 2>/dev/null ||
- expr X"$dst" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$dst" : 'X\(//\)[^/]' \| \
- X"$dst" : 'X\(//\)$' \| \
- X"$dst" : 'X\(/\)' \| . 2>/dev/null ||
- echo X"$dst" |
- sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
- s//\1/
- q
- /^X\(\/\/\)[^/].*/{
- s//\1/
- q
- /^X\(\/\/\)$/{
- s//\1/
- q
- /^X\(\/\).*/{
- s//\1/
- q
- s/.*/./; q'
- test -d "$dstdir"
- dstdir_status=$?
- fi
- fi
- obsolete_mkdir_used=false
- if test $dstdir_status != 0; then
- case $posix_mkdir in
- # Create intermediate dirs using mode 755 as modified by the umask.
- # This is like FreeBSD 'install' as of 1997-10-28.
- umask=`umask`
- case $stripcmd.$umask in
- *[2367][2367]) mkdir_umask=$umask;;
- .*0[02][02] | .[02][02] | .[02]) mkdir_umask=22;;
- *[0-7])
- mkdir_umask=`expr $umask + 22 \
- - $umask % 100 % 40 + $umask % 20 \
- - $umask % 10 % 4 + $umask % 2
- *) mkdir_umask=$umask,go-w;;
- esac
- # With -d, create the new directory with the user-specified mode.
- # Otherwise, rely on $mkdir_umask.
- mkdir_mode=-m$mode
- else
- mkdir_mode=
- fi
- posix_mkdir=false
- case $umask in
- *[123567][0-7][0-7])
- # POSIX mkdir -p sets u+wx bits regardless of umask, which
- # is incompatible with FreeBSD 'install' when (umask & 300) != 0.
- tmpdir=${TMPDIR-/tmp}/ins$RANDOM-$$
- trap 'ret=$?; rmdir "$tmpdir/d" "$tmpdir" 2>/dev/null; exit $ret' 0
- if (umask $mkdir_umask &&
- exec $mkdirprog $mkdir_mode -p -- "$tmpdir/d") >/dev/null 2>&1
- then
- if test -z "$dir_arg" || {
- # Check for POSIX incompatibilities with -m.
- # HP-UX 11.23 and IRIX 6.5 mkdir -m -p sets group- or
- # other-writeable bit of parent directory when it shouldn't.
- # FreeBSD 6.1 mkdir -m -p sets mode of existing directory.
- ls_ld_tmpdir=`ls -ld "$tmpdir"`
- case $ls_ld_tmpdir in
- d????-?r-*) different_mode=700;;
- d????-?--*) different_mode=755;;
- *) false;;
- esac &&
- $mkdirprog -m$different_mode -p -- "$tmpdir" && {
- ls_ld_tmpdir_1=`ls -ld "$tmpdir"`
- test "$ls_ld_tmpdir" = "$ls_ld_tmpdir_1"
- then posix_mkdir=:
- fi
- rmdir "$tmpdir/d" "$tmpdir"
- else
- # Remove any dirs left behind by ancient mkdir implementations.
- rmdir ./$mkdir_mode ./-p ./-- 2>/dev/null
- fi
- trap '' 0;;
- esac;;
- esac
- if
- $posix_mkdir && (
- umask $mkdir_umask &&
- $doit_exec $mkdirprog $mkdir_mode -p -- "$dstdir"
- then :
- else
- # The umask is ridiculous, or mkdir does not conform to POSIX,
- # or it failed possibly due to a race condition. Create the
- # directory the slow way, step by step, checking for races as we go.
- case $dstdir in
- /*) prefix='/';;
- -*) prefix='./';;
- *) prefix='';;
- esac
- eval "$initialize_posix_glob"
- oIFS=$IFS
- IFS=/
- $posix_glob set -f
- set fnord $dstdir
- shift
- $posix_glob set +f
- IFS=$oIFS
- prefixes=
- for d
- do
- test -z "$d" && continue
- prefix=$prefix$d
- if test -d "$prefix"; then
- prefixes=
- else
- if $posix_mkdir; then
- (umask=$mkdir_umask &&
- $doit_exec $mkdirprog $mkdir_mode -p -- "$dstdir") && break
- # Don't fail if two instances are running concurrently.
- test -d "$prefix" || exit 1
- else
- case $prefix in
- *\'*) qprefix=`echo "$prefix" | sed "s/'/'\\\\\\\\''/g"`;;
- *) qprefix=$prefix;;
- esac
- prefixes="$prefixes '$qprefix'"
- fi
- fi
- prefix=$prefix/
- done
- if test -n "$prefixes"; then
- (umask $mkdir_umask &&
- eval "\$doit_exec \$mkdirprog $prefixes") ||
- test -d "$dstdir" || exit 1
- obsolete_mkdir_used=true
- fi
- fi
- fi
- { test -z "$chowncmd" || $doit $chowncmd "$dst"; } &&
- { test -z "$chgrpcmd" || $doit $chgrpcmd "$dst"; } &&
- { test "$obsolete_mkdir_used$chowncmd$chgrpcmd" = false ||
- test -z "$chmodcmd" || $doit $chmodcmd $mode "$dst"; } || exit 1
- else
- # Make a couple of temp file names in the proper directory.
- dsttmp=$dstdir/_inst.$$_
- rmtmp=$dstdir/_rm.$$_
- # Trap to clean up those temp files at exit.
- trap 'ret=$?; rm -f "$dsttmp" "$rmtmp" && exit $ret' 0
- # Copy the file name to the temp name.
- (umask $cp_umask && $doit_exec $cpprog "$src" "$dsttmp") &&
- # and set any options; do chmod last to preserve setuid bits.
- # If any of these fail, we abort the whole thing. If we want to
- # ignore errors from any of these, just make sure not to ignore
- # errors from the above "$doit $cpprog $src $dsttmp" command.
- { test -z "$chowncmd" || $doit $chowncmd "$dsttmp"; } &&
- { test -z "$chgrpcmd" || $doit $chgrpcmd "$dsttmp"; } &&
- { test -z "$stripcmd" || $doit $stripcmd "$dsttmp"; } &&
- { test -z "$chmodcmd" || $doit $chmodcmd $mode "$dsttmp"; } &&
- # If -C, don't bother to copy if it wouldn't change the file.
- if $copy_on_change &&
- old=`LC_ALL=C ls -dlL "$dst" 2>/dev/null` &&
- new=`LC_ALL=C ls -dlL "$dsttmp" 2>/dev/null` &&
- eval "$initialize_posix_glob" &&
- $posix_glob set -f &&
- set X $old && old=:$2:$4:$5:$6 &&
- set X $new && new=:$2:$4:$5:$6 &&
- $posix_glob set +f &&
- test "$old" = "$new" &&
- $cmpprog "$dst" "$dsttmp" >/dev/null 2>&1
- then
- rm -f "$dsttmp"
- else
- # Rename the file to the real destination.
- $doit $mvcmd -f "$dsttmp" "$dst" 2>/dev/null ||
- # The rename failed, perhaps because mv can't rename something else
- # to itself, or perhaps because mv is so ancient that it does not
- # support -f.
- # Now remove or move aside any old file at destination location.
- # We try this two ways since rm can't unlink itself on some
- # systems and the destination file might be busy for other
- # reasons. In this case, the final cleanup might fail but the new
- # file should still install successfully.
- test ! -f "$dst" ||
- $doit $rmcmd -f "$dst" 2>/dev/null ||
- { $doit $mvcmd -f "$dst" "$rmtmp" 2>/dev/null &&
- { $doit $rmcmd -f "$rmtmp" 2>/dev/null; :; }
- { echo "$0: cannot unlink or rename $dst" >&2
- (exit 1); exit 1
- # Now rename the file to the real destination.
- $doit $mvcmd "$dsttmp" "$dst"
- fi || exit 1
- trap '' 0
- fi
-done
-# Local variables:
-# eval: (add-hook 'write-file-hooks 'time-stamp)
-# time-stamp-start: "scriptversion="
-# time-stamp-format: "%:y-%02m-%02d.%02H"
-# time-stamp-time-zone: "UTC"
-# time-stamp-end: "; # UTC"
-# End:
Index: modules/provider-coaster-c-client/aclocal.m4
--- modules/provider-coaster-c-client/aclocal.m4 (revision 3826)
+++ modules/provider-coaster-c-client/aclocal.m4 (working copy)
@@ -1,9577 +0,0 @@
-# generated automatically by aclocal 1.11.3 -*- Autoconf -*-
-# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004,
-# 2005, 2006, 2007, 2008, 2009, 2010, 2011 Free Software Foundation,
-# Inc.
-# This file is free software; the Free Software Foundation
-# gives unlimited permission to copy and/or distribute it,
-# with or without modifications, as long as this notice is preserved.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY, to the extent permitted by law; without
-# even the implied warranty of MERCHANTABILITY or FITNESS FOR A
-# PARTICULAR PURPOSE.
-m4_ifndef([AC_AUTOCONF_VERSION],
- [m4_copy([m4_PACKAGE_VERSION], [AC_AUTOCONF_VERSION])])dnl
-m4_if(m4_defn([AC_AUTOCONF_VERSION]), [2.68],,
-[m4_warning([this file was generated for autoconf 2.68.
-You have another version of autoconf. It may work, but is not guaranteed to.
-If you have problems, you may need to regenerate the build system entirely.
-To do so, use the procedure documented by the package, typically `autoreconf'.])])
-# libtool.m4 - Configure libtool for the host system. -*-Autoconf-*-
-# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001, 2003, 2004, 2005,
-# 2006, 2007, 2008, 2009, 2010, 2011 Free Software
-# Foundation, Inc.
-# Written by Gordon Matzigkeit, 1996
-# This file is free software; the Free Software Foundation gives
-# unlimited permission to copy and/or distribute it, with or without
-# modifications, as long as this notice is preserved.
-m4_define([_LT_COPYING], [dnl
-# Foundation, Inc.
-# This file is part of GNU Libtool.
-# GNU Libtool is free software; you can redistribute it and/or
-# modify it under the terms of the GNU General Public License as
-# published by the Free Software Foundation; either version 2 of
-# the License, or (at your option) any later version.
-# As a special exception to the GNU General Public License,
-# if you distribute this file as part of a program or library that
-# is built using GNU Libtool, you may include this file under the
-# same distribution terms that you use for the rest of that program.
-# GNU Libtool is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with GNU Libtool; see the file COPYING. If not, a copy
-# can be downloaded from http://www.gnu.org/licenses/gpl.html, or
-# obtained by writing to the Free Software Foundation, Inc.,
-# 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
-# serial 57 LT_INIT
-# LT_PREREQ(VERSION)
-# Complain and exit if this libtool version is less that VERSION.
-m4_defun([LT_PREREQ],
-[m4_if(m4_version_compare(m4_defn([LT_PACKAGE_VERSION]), [$1]), -1,
- [m4_default([$3],
- [m4_fatal([Libtool version $1 or higher is required],
- 63)])],
- [$2])])
-# _LT_CHECK_BUILDDIR
-# Complain if the absolute build directory name contains unusual characters
-m4_defun([_LT_CHECK_BUILDDIR],
-[case `pwd` in
- AC_MSG_WARN([Libtool does not cope well with whitespace in `pwd`]) ;;
-esac
-# LT_INIT([OPTIONS])
-AC_DEFUN([LT_INIT],
-[AC_PREREQ([2.58])dnl We use AC_INCLUDES_DEFAULT
-AC_REQUIRE([AC_CONFIG_AUX_DIR_DEFAULT])dnl
-AC_BEFORE([$0], [LT_LANG])dnl
-AC_BEFORE([$0], [LT_OUTPUT])dnl
-AC_BEFORE([$0], [LTDL_INIT])dnl
-m4_require([_LT_CHECK_BUILDDIR])dnl
-dnl Autoconf doesn't catch unexpanded LT_ macros by default:
-m4_pattern_forbid([^_?LT_[A-Z_]+$])dnl
-m4_pattern_allow([^(_LT_EOF|LT_DLGLOBAL|LT_DLLAZY_OR_NOW|LT_MULTI_MODULE)$])dnl
-dnl aclocal doesn't pull ltoptions.m4, ltsugar.m4, or ltversion.m4
-dnl unless we require an AC_DEFUNed macro:
-AC_REQUIRE([LTOPTIONS_VERSION])dnl
-AC_REQUIRE([LTSUGAR_VERSION])dnl
-AC_REQUIRE([LTVERSION_VERSION])dnl
-AC_REQUIRE([LTOBSOLETE_VERSION])dnl
-m4_require([_LT_PROG_LTMAIN])dnl
-_LT_SHELL_INIT([SHELL=${CONFIG_SHELL-/bin/sh}])
-dnl Parse OPTIONS
-_LT_SET_OPTIONS([$0], [$1])
-# This can be used to rebuild libtool when needed
-LIBTOOL_DEPS="$ltmain"
-# Always use our own libtool.
-LIBTOOL='$(SHELL) $(top_builddir)/libtool'
-AC_SUBST(LIBTOOL)dnl
-_LT_SETUP
-# Only expand once:
-m4_define([LT_INIT])
-])# LT_INIT
-# Old names:
-AU_ALIAS([AC_PROG_LIBTOOL], [LT_INIT])
-AU_ALIAS([AM_PROG_LIBTOOL], [LT_INIT])
-dnl aclocal-1.4 backwards compatibility:
-dnl AC_DEFUN([AC_PROG_LIBTOOL], [])
-dnl AC_DEFUN([AM_PROG_LIBTOOL], [])
-# _LT_CC_BASENAME(CC)
-# Calculate cc_basename. Skip known compiler wrappers and cross-prefix.
-m4_defun([_LT_CC_BASENAME],
-[for cc_temp in $1""; do
- case $cc_temp in
- compile | *[[\\/]]compile | ccache | *[[\\/]]ccache ) ;;
- distcc | *[[\\/]]distcc | purify | *[[\\/]]purify ) ;;
- *) break;;
- esac
-done
-cc_basename=`$ECHO "$cc_temp" | $SED "s%.*/%%; s%^$host_alias-%%"`
-# _LT_FILEUTILS_DEFAULTS
-# It is okay to use these file commands and assume they have been set
-# sensibly after `m4_require([_LT_FILEUTILS_DEFAULTS])'.
-m4_defun([_LT_FILEUTILS_DEFAULTS],
-[: ${CP="cp -f"}
-: ${MV="mv -f"}
-: ${RM="rm -f"}
-])# _LT_FILEUTILS_DEFAULTS
-# _LT_SETUP
-m4_defun([_LT_SETUP],
-[AC_REQUIRE([AC_CANONICAL_HOST])dnl
-AC_REQUIRE([AC_CANONICAL_BUILD])dnl
-AC_REQUIRE([_LT_PREPARE_SED_QUOTE_VARS])dnl
-AC_REQUIRE([_LT_PROG_ECHO_BACKSLASH])dnl
-_LT_DECL([], [PATH_SEPARATOR], [1], [The PATH separator for the build system])dnl
-dnl
-_LT_DECL([], [host_alias], [0], [The host system])dnl
-_LT_DECL([], [host], [0])dnl
-_LT_DECL([], [host_os], [0])dnl
-dnl
-_LT_DECL([], [build_alias], [0], [The build system])dnl
-_LT_DECL([], [build], [0])dnl
-_LT_DECL([], [build_os], [0])dnl
-dnl
-AC_REQUIRE([AC_PROG_CC])dnl
-AC_REQUIRE([LT_PATH_LD])dnl
-AC_REQUIRE([LT_PATH_NM])dnl
-dnl
-AC_REQUIRE([AC_PROG_LN_S])dnl
-test -z "$LN_S" && LN_S="ln -s"
-_LT_DECL([], [LN_S], [1], [Whether we need soft or hard links])dnl
-dnl
-AC_REQUIRE([LT_CMD_MAX_LEN])dnl
-_LT_DECL([objext], [ac_objext], [0], [Object file suffix (normally "o")])dnl
-_LT_DECL([], [exeext], [0], [Executable file suffix (normally "")])dnl
-dnl
-m4_require([_LT_FILEUTILS_DEFAULTS])dnl
-m4_require([_LT_CHECK_SHELL_FEATURES])dnl
-m4_require([_LT_PATH_CONVERSION_FUNCTIONS])dnl
-m4_require([_LT_CMD_RELOAD])dnl
-m4_require([_LT_CHECK_MAGIC_METHOD])dnl
-m4_require([_LT_CHECK_SHAREDLIB_FROM_LINKLIB])dnl
-m4_require([_LT_CMD_OLD_ARCHIVE])dnl
-m4_require([_LT_CMD_GLOBAL_SYMBOLS])dnl
-m4_require([_LT_WITH_SYSROOT])dnl
-_LT_CONFIG_LIBTOOL_INIT([
-# See if we are running on zsh, and set the options which allow our
-# commands through without removal of \ escapes INIT.
-if test -n "\${ZSH_VERSION+set}" ; then
- setopt NO_GLOB_SUBST
-fi
-if test -n "${ZSH_VERSION+set}" ; then
-fi
-_LT_CHECK_OBJDIR
-m4_require([_LT_TAG_COMPILER])dnl
-case $host_os in
-aix3*)
- # AIX sometimes has problems with the GCC collect2 program. For some
- # reason, if we set the COLLECT_NAMES environment variable, the problems
- # vanish in a puff of smoke.
- if test "X${COLLECT_NAMES+set}" != Xset; then
- COLLECT_NAMES=
- export COLLECT_NAMES
- fi
-esac
-# Global variables:
-ofile=libtool
-can_build_shared=yes
-# All known linkers require a `.a' archive for static linking (except MSVC,
-# which needs '.lib').
-libext=a
-with_gnu_ld="$lt_cv_prog_gnu_ld"
-old_CC="$CC"
-old_CFLAGS="$CFLAGS"
-# Set sane defaults for various variables
-test -z "$CC" && CC=cc
-test -z "$LTCC" && LTCC=$CC
-test -z "$LTCFLAGS" && LTCFLAGS=$CFLAGS
-test -z "$LD" && LD=ld
-test -z "$ac_objext" && ac_objext=o
-_LT_CC_BASENAME([$compiler])
-# Only perform the check for file, if the check method requires it
-test -z "$MAGIC_CMD" && MAGIC_CMD=file
-case $deplibs_check_method in
-file_magic*)
- if test "$file_magic_cmd" = '$MAGIC_CMD'; then
- _LT_PATH_MAGIC
- fi
-esac
-# Use C for the default configuration in the libtool script
-LT_SUPPORTED_TAG([CC])
-_LT_LANG_C_CONFIG
-_LT_LANG_DEFAULT_CONFIG
-_LT_CONFIG_COMMANDS
-])# _LT_SETUP
-# _LT_PREPARE_SED_QUOTE_VARS
-# Define a few sed substitution that help us do robust quoting.
-m4_defun([_LT_PREPARE_SED_QUOTE_VARS],
-[# Backslashify metacharacters that are still active within
-# double-quoted strings.
-sed_quote_subst='s/\([["`$\\]]\)/\\\1/g'
-# Same as above, but do not quote variable references.
-double_quote_subst='s/\([["`\\]]\)/\\\1/g'
-# Sed substitution to delay expansion of an escaped shell variable in a
-# double_quote_subst'ed string.
-delay_variable_subst='s/\\\\\\\\\\\$/\\\\\\$/g'
-# Sed substitution to delay expansion of an escaped single quote.
-delay_single_quote_subst='s/'\''/'\'\\\\\\\'\''/g'
-# Sed substitution to avoid accidental globbing in evaled expressions
-no_glob_subst='s/\*/\\\*/g'
-# _LT_PROG_LTMAIN
-# Note that this code is called both from `configure', and `config.status'
-# now that we use AC_CONFIG_COMMANDS to generate libtool. Notably,
-# `config.status' has no value for ac_aux_dir unless we are using Automake,
-# so we pass a copy along to make sure it has a sensible value anyway.
-m4_defun([_LT_PROG_LTMAIN],
-[m4_ifdef([AC_REQUIRE_AUX_FILE], [AC_REQUIRE_AUX_FILE([ltmain.sh])])dnl
-_LT_CONFIG_LIBTOOL_INIT([ac_aux_dir='$ac_aux_dir'])
-ltmain="$ac_aux_dir/ltmain.sh"
-])# _LT_PROG_LTMAIN
-# So that we can recreate a full libtool script including additional
-# tags, we accumulate the chunks of code to send to AC_CONFIG_COMMANDS
-# in macros and then make a single call at the end using the `libtool'
-# label.
-# _LT_CONFIG_LIBTOOL_INIT([INIT-COMMANDS])
-# Register INIT-COMMANDS to be passed to AC_CONFIG_COMMANDS later.
-m4_define([_LT_CONFIG_LIBTOOL_INIT],
-[m4_ifval([$1],
- [m4_append([_LT_OUTPUT_LIBTOOL_INIT],
- [$1
-# Initialize.
-m4_define([_LT_OUTPUT_LIBTOOL_INIT])
-# _LT_CONFIG_LIBTOOL([COMMANDS])
-# Register COMMANDS to be passed to AC_CONFIG_COMMANDS later.
-m4_define([_LT_CONFIG_LIBTOOL],
-[m4_ifval([$1],
- [m4_append([_LT_OUTPUT_LIBTOOL_COMMANDS],
- [$1
-# Initialize.
-m4_define([_LT_OUTPUT_LIBTOOL_COMMANDS])
-# _LT_CONFIG_SAVE_COMMANDS([COMMANDS], [INIT_COMMANDS])
-m4_defun([_LT_CONFIG_SAVE_COMMANDS],
-[_LT_CONFIG_LIBTOOL([$1])
-_LT_CONFIG_LIBTOOL_INIT([$2])
-# _LT_FORMAT_COMMENT([COMMENT])
-# Add leading comment marks to the start of each line, and a trailing
-# full-stop to the whole comment if one is not present already.
-m4_define([_LT_FORMAT_COMMENT],
-[m4_ifval([$1], [
-m4_bpatsubst([m4_bpatsubst([$1], [^ *], [# ])],
- [['`$\]], [\\\&])]m4_bmatch([$1], [[!?.]$], [], [.])
-# _LT_DECL([CONFIGNAME], VARNAME, VALUE, [DESCRIPTION], [IS-TAGGED?])
-# CONFIGNAME is the name given to the value in the libtool script.
-# VARNAME is the (base) name used in the configure script.
-# VALUE may be 0, 1 or 2 for a computed quote escaped value based on
-# VARNAME. Any other value will be used directly.
-m4_define([_LT_DECL],
-[lt_if_append_uniq([lt_decl_varnames], [$2], [, ],
- [lt_dict_add_subkey([lt_decl_dict], [$2], [libtool_name],
- [m4_ifval([$1], [$1], [$2])])
- lt_dict_add_subkey([lt_decl_dict], [$2], [value], [$3])
- m4_ifval([$4],
- [lt_dict_add_subkey([lt_decl_dict], [$2], [description], [$4])])
- [tagged?], [m4_ifval([$5], [yes], [no])])])
-# _LT_TAGDECL([CONFIGNAME], VARNAME, VALUE, [DESCRIPTION])
-m4_define([_LT_TAGDECL], [_LT_DECL([$1], [$2], [$3], [$4], [yes])])
-# lt_decl_tag_varnames([SEPARATOR], [VARNAME1...])
-m4_define([lt_decl_tag_varnames],
-[_lt_decl_filter([tagged?], [yes], $@)])
-# _lt_decl_filter(SUBKEY, VALUE, [SEPARATOR], [VARNAME1..])
-m4_define([_lt_decl_filter],
-[m4_case([$#],
- [0], [m4_fatal([$0: too few arguments: $#])],
- [1], [m4_fatal([$0: too few arguments: $#: $1])],
- [2], [lt_dict_filter([lt_decl_dict], [$1], [$2], [], lt_decl_varnames)],
- [3], [lt_dict_filter([lt_decl_dict], [$1], [$2], [$3], lt_decl_varnames)],
- [lt_dict_filter([lt_decl_dict], $@)])[]dnl
-# lt_decl_quote_varnames([SEPARATOR], [VARNAME1...])
-m4_define([lt_decl_quote_varnames],
-[_lt_decl_filter([value], [1], $@)])
-# lt_decl_dquote_varnames([SEPARATOR], [VARNAME1...])
-m4_define([lt_decl_dquote_varnames],
-[_lt_decl_filter([value], [2], $@)])
-# lt_decl_varnames_tagged([SEPARATOR], [VARNAME1...])
-m4_define([lt_decl_varnames_tagged],
-[m4_assert([$# <= 2])dnl
-_$0(m4_quote(m4_default([$1], [[, ]])),
- m4_ifval([$2], [[$2]], [m4_dquote(lt_decl_tag_varnames)]),
- m4_split(m4_normalize(m4_quote(_LT_TAGS)), [ ]))])
-m4_define([_lt_decl_varnames_tagged],
-[m4_ifval([$3], [lt_combine([$1], [$2], [_], $3)])])
-# lt_decl_all_varnames([SEPARATOR], [VARNAME1...])
-m4_define([lt_decl_all_varnames],
-[_$0(m4_quote(m4_default([$1], [[, ]])),
- m4_if([$2], [],
- m4_quote(lt_decl_varnames),
- m4_quote(m4_shift($@))))[]dnl
-m4_define([_lt_decl_all_varnames],
-[lt_join($@, lt_decl_varnames_tagged([$1],
- lt_decl_tag_varnames([[, ]], m4_shift($@))))dnl
-# _LT_CONFIG_STATUS_DECLARE([VARNAME])
-# Quote a variable value, and forward it to `config.status' so that its
-# declaration there will have the same value as in `configure'. VARNAME
-# must have a single quote delimited value for this to work.
-m4_define([_LT_CONFIG_STATUS_DECLARE],
-[$1='`$ECHO "$][$1" | $SED "$delay_single_quote_subst"`'])
-# _LT_CONFIG_STATUS_DECLARATIONS
-# We delimit libtool config variables with single quotes, so when
-# we write them to config.status, we have to be sure to quote all
-# embedded single quotes properly. In configure, this macro expands
-# each variable declared with _LT_DECL (and _LT_TAGDECL) into:
-# <var>='`$ECHO "$<var>" | $SED "$delay_single_quote_subst"`'
-m4_defun([_LT_CONFIG_STATUS_DECLARATIONS],
-[m4_foreach([_lt_var], m4_quote(lt_decl_all_varnames),
- [m4_n([_LT_CONFIG_STATUS_DECLARE(_lt_var)])])])
-# _LT_LIBTOOL_TAGS
-# Output comment and list of tags supported by the script
-m4_defun([_LT_LIBTOOL_TAGS],
-[_LT_FORMAT_COMMENT([The names of the tagged configurations supported by this script])dnl
-available_tags="_LT_TAGS"dnl
-# _LT_LIBTOOL_DECLARE(VARNAME, [TAG])
-# Extract the dictionary values for VARNAME (optionally with TAG) and
-# expand to a commented shell variable setting:
-# # Some comment about what VAR is for.
-# visible_name=$lt_internal_name
-m4_define([_LT_LIBTOOL_DECLARE],
-[_LT_FORMAT_COMMENT(m4_quote(lt_dict_fetch([lt_decl_dict], [$1],
- [description])))[]dnl
-m4_pushdef([_libtool_name],
- m4_quote(lt_dict_fetch([lt_decl_dict], [$1], [libtool_name])))[]dnl
-m4_case(m4_quote(lt_dict_fetch([lt_decl_dict], [$1], [value])),
- [0], [_libtool_name=[$]$1],
- [1], [_libtool_name=$lt_[]$1],
- [2], [_libtool_name=$lt_[]$1],
- [_libtool_name=lt_dict_fetch([lt_decl_dict], [$1], [value])])[]dnl
-m4_ifval([$2], [_$2])[]m4_popdef([_libtool_name])[]dnl
-# _LT_LIBTOOL_CONFIG_VARS
-# Produce commented declarations of non-tagged libtool config variables
-# suitable for insertion in the LIBTOOL CONFIG section of the `libtool'
-# script. Tagged libtool config variables (even for the LIBTOOL CONFIG
-# section) are produced by _LT_LIBTOOL_TAG_VARS.
-m4_defun([_LT_LIBTOOL_CONFIG_VARS],
- m4_quote(_lt_decl_filter([tagged?], [no], [], lt_decl_varnames)),
- [m4_n([_LT_LIBTOOL_DECLARE(_lt_var)])])])
-# _LT_LIBTOOL_TAG_VARS(TAG)
-m4_define([_LT_LIBTOOL_TAG_VARS],
-[m4_foreach([_lt_var], m4_quote(lt_decl_tag_varnames),
- [m4_n([_LT_LIBTOOL_DECLARE(_lt_var, [$1])])])])
-# _LT_TAGVAR(VARNAME, [TAGNAME])
-m4_define([_LT_TAGVAR], [m4_ifval([$2], [$1_$2], [$1])])
-# _LT_CONFIG_COMMANDS
-# Send accumulated output to $CONFIG_STATUS. Thanks to the lists of
-# variables for single and double quote escaping we saved from calls
-# to _LT_DECL, we can put quote escaped variables declarations
-# into `config.status', and then the shell code to quote escape them in
-# for loops in `config.status'. Finally, any additional code accumulated
-# from calls to _LT_CONFIG_LIBTOOL_INIT is expanded.
-m4_defun([_LT_CONFIG_COMMANDS],
-[AC_PROVIDE_IFELSE([LT_OUTPUT],
- dnl If the libtool generation code has been placed in $CONFIG_LT,
- dnl instead of duplicating it all over again into config.status,
- dnl then we will have config.status run $CONFIG_LT later, so it
- dnl needs to know what name is stored there:
- [AC_CONFIG_COMMANDS([libtool],
- [$SHELL $CONFIG_LT || AS_EXIT(1)], [CONFIG_LT='$CONFIG_LT'])],
- dnl If the libtool generation code is destined for config.status,
- dnl expand the accumulated commands and init code now:
- [_LT_OUTPUT_LIBTOOL_COMMANDS], [_LT_OUTPUT_LIBTOOL_COMMANDS_INIT])])
-])#_LT_CONFIG_COMMANDS
-# Initialize.
-m4_define([_LT_OUTPUT_LIBTOOL_COMMANDS_INIT],
-# The HP-UX ksh and POSIX shell print the target directory to stdout
-# if CDPATH is set.
-(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
-sed_quote_subst='$sed_quote_subst'
-double_quote_subst='$double_quote_subst'
-delay_variable_subst='$delay_variable_subst'
-_LT_CONFIG_STATUS_DECLARATIONS
-LTCC='$LTCC'
-LTCFLAGS='$LTCFLAGS'
-compiler='$compiler_DEFAULT'
-# A function that is used when there is no print builtin or printf.
-func_fallback_echo ()
- eval 'cat <<_LTECHO_EOF
-\$[]1
-_LTECHO_EOF'
-# Quote evaled strings.
-for var in lt_decl_all_varnames([[ \
-]], lt_decl_quote_varnames); do
- case \`eval \\\\\$ECHO \\\\""\\\\\$\$var"\\\\"\` in
- eval "lt_\$var=\\\\\\"\\\`\\\$ECHO \\"\\\$\$var\\" | \\\$SED \\"\\\$sed_quote_subst\\"\\\`\\\\\\""
- eval "lt_\$var=\\\\\\"\\\$\$var\\\\\\""
- esac
-done
-# Double-quote double-evaled strings.
-]], lt_decl_dquote_varnames); do
- eval "lt_\$var=\\\\\\"\\\`\\\$ECHO \\"\\\$\$var\\" | \\\$SED -e \\"\\\$double_quote_subst\\" -e \\"\\\$sed_quote_subst\\" -e \\"\\\$delay_variable_subst\\"\\\`\\\\\\""
- esac
-done
-_LT_OUTPUT_LIBTOOL_INIT
-# _LT_GENERATED_FILE_INIT(FILE, [COMMENT])
-# Generate a child script FILE with all initialization necessary to
-# reuse the environment learned by the parent script, and make the
-# file executable. If COMMENT is supplied, it is inserted after the
-# `#!' sequence but before initialization text begins. After this
-# macro, additional text can be appended to FILE to form the body of
-# the child script. The macro ends with non-zero status if the
-# file could not be fully written (such as if the disk is full).
-m4_ifdef([AS_INIT_GENERATED],
-[m4_defun([_LT_GENERATED_FILE_INIT],[AS_INIT_GENERATED($@)])],
-[m4_require([AS_PREPARE])]dnl
-[m4_pushdef([AS_MESSAGE_LOG_FD])]dnl
-[lt_write_fail=0
-cat >$1 <<_ASEOF || lt_write_fail=1
-#! $SHELL
-# Generated by $as_me.
-$2
-SHELL=\${CONFIG_SHELL-$SHELL}
-export SHELL
-_ASEOF
-cat >>$1 <<\_ASEOF || lt_write_fail=1
-AS_SHELL_SANITIZE
-_AS_PREPARE
-exec AS_MESSAGE_FD>&1
-_ASEOF
-test $lt_write_fail = 0 && chmod +x $1[]dnl
-m4_popdef([AS_MESSAGE_LOG_FD])])])# _LT_GENERATED_FILE_INIT
-# LT_OUTPUT
-# This macro allows early generation of the libtool script (before
-# AC_OUTPUT is called), incase it is used in configure for compilation
-# tests.
-AC_DEFUN([LT_OUTPUT],
-[: ${CONFIG_LT=./config.lt}
-AC_MSG_NOTICE([creating $CONFIG_LT])
-_LT_GENERATED_FILE_INIT(["$CONFIG_LT"],
-[# Run this file to recreate a libtool stub with the current configuration.])
-cat >>"$CONFIG_LT" <<\_LTEOF
-lt_cl_silent=false
-exec AS_MESSAGE_LOG_FD>>config.log
- echo
- AS_BOX([Running $as_me.])
-} >&AS_MESSAGE_LOG_FD
-lt_cl_help="\
-\`$as_me' creates a local libtool stub from the current configuration,
-for use in further configure time tests before the real libtool is
-generated.
-Usage: $[0] [[OPTIONS]]
- -h, --help print this help, then exit
- -V, --version print version number, then exit
- -q, --quiet do not print progress messages
- -d, --debug don't remove temporary files
-Report bugs to <bug-libtool at gnu.org>."
-lt_cl_version="\
-m4_ifset([AC_PACKAGE_NAME], [AC_PACKAGE_NAME ])config.lt[]dnl
-m4_ifset([AC_PACKAGE_VERSION], [ AC_PACKAGE_VERSION])
-configured by $[0], generated by m4_PACKAGE_STRING.
-Copyright (C) 2011 Free Software Foundation, Inc.
-This config.lt script is free software; the Free Software Foundation
-gives unlimited permision to copy, distribute and modify it."
-while test $[#] != 0
-do
- case $[1] in
- --version | --v* | -V )
- echo "$lt_cl_version"; exit 0 ;;
- --help | --h* | -h )
- echo "$lt_cl_help"; exit 0 ;;
- --debug | --d* | -d )
- debug=: ;;
- --quiet | --q* | --silent | --s* | -q )
- lt_cl_silent=: ;;
- -*) AC_MSG_ERROR([unrecognized option: $[1]
-Try \`$[0] --help' for more information.]) ;;
- *) AC_MSG_ERROR([unrecognized argument: $[1]
- esac
- shift
-done
-if $lt_cl_silent; then
- exec AS_MESSAGE_FD>/dev/null
-fi
-_LTEOF
-cat >>"$CONFIG_LT" <<_LTEOF
-_LT_OUTPUT_LIBTOOL_COMMANDS_INIT
-_LTEOF
-AC_MSG_NOTICE([creating $ofile])
-AS_EXIT(0)
-_LTEOF
-chmod +x "$CONFIG_LT"
-# configure is writing to config.log, but config.lt does its own redirection,
-# appending to config.log, which fails on DOS, as config.log is still kept
-# open by configure. Here we exec the FD to /dev/null, effectively closing
-# config.log, so it can be properly (re)opened and appended to by config.lt.
-lt_cl_success=:
-test "$silent" = yes &&
- lt_config_lt_args="$lt_config_lt_args --quiet"
-exec AS_MESSAGE_LOG_FD>/dev/null
-$SHELL "$CONFIG_LT" $lt_config_lt_args || lt_cl_success=false
-$lt_cl_success || AS_EXIT(1)
-])# LT_OUTPUT
-# _LT_CONFIG(TAG)
-# If TAG is the built-in tag, create an initial libtool script with a
-# default configuration from the untagged config vars. Otherwise add code
-# to config.status for appending the configuration named by TAG from the
-# matching tagged config vars.
-m4_defun([_LT_CONFIG],
-[m4_require([_LT_FILEUTILS_DEFAULTS])dnl
-_LT_CONFIG_SAVE_COMMANDS([
- m4_define([_LT_TAG], m4_if([$1], [], [C], [$1]))dnl
- m4_if(_LT_TAG, [C], [
- # See if we are running on zsh, and set the options which allow our
- # commands through without removal of \ escapes.
- if test -n "${ZSH_VERSION+set}" ; then
- fi
- cfgfile="${ofile}T"
- trap "$RM \"$cfgfile\"; exit 1" 1 2 15
- $RM "$cfgfile"
- cat <<_LT_EOF >> "$cfgfile"
-#! $SHELL
-# `$ECHO "$ofile" | sed 's%^.*/%%'` - Provide generalized library-building support services.
-# Generated automatically by $as_me ($PACKAGE$TIMESTAMP) $VERSION
-# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
-# NOTE: Changes made to this file will be lost: look at ltmain.sh.
-_LT_COPYING
-_LT_LIBTOOL_TAGS
-# ### BEGIN LIBTOOL CONFIG
-_LT_LIBTOOL_CONFIG_VARS
-_LT_LIBTOOL_TAG_VARS
-# ### END LIBTOOL CONFIG
-_LT_EOF
- case $host_os in
- aix3*)
- cat <<\_LT_EOF >> "$cfgfile"
-# AIX sometimes has problems with the GCC collect2 program. For some
-# reason, if we set the COLLECT_NAMES environment variable, the problems
-# vanish in a puff of smoke.
-if test "X${COLLECT_NAMES+set}" != Xset; then
- COLLECT_NAMES=
-fi
-_LT_EOF
- esac
- _LT_PROG_LTMAIN
- # We use sed instead of cat because bash on DJGPP gets confused if
- # if finds mixed CR/LF and LF-only lines. Since sed operates in
- # text mode, it properly converts lines to CR/LF. This bash problem
- # is reportedly fixed, but why not run on old versions too?
- sed '$q' "$ltmain" >> "$cfgfile" \
- || (rm -f "$cfgfile"; exit 1)
- _LT_PROG_REPLACE_SHELLFNS
- mv -f "$cfgfile" "$ofile" ||
- (rm -f "$ofile" && cp "$cfgfile" "$ofile" && rm -f "$cfgfile")
- chmod +x "$ofile"
-[cat <<_LT_EOF >> "$ofile"
-dnl Unfortunately we have to use $1 here, since _LT_TAG is not expanded
-dnl in a comment (ie after a #).
-# ### BEGIN LIBTOOL TAG CONFIG: $1
-_LT_LIBTOOL_TAG_VARS(_LT_TAG)
-# ### END LIBTOOL TAG CONFIG: $1
-_LT_EOF
-])dnl /m4_if
-[m4_if([$1], [], [
- PACKAGE='$PACKAGE'
- VERSION='$VERSION'
- TIMESTAMP='$TIMESTAMP'
- RM='$RM'
- ofile='$ofile'], [])
-])dnl /_LT_CONFIG_SAVE_COMMANDS
-])# _LT_CONFIG
-# LT_SUPPORTED_TAG(TAG)
-# Trace this macro to discover what tags are supported by the libtool
-# --tag option, using:
-# autoconf --trace 'LT_SUPPORTED_TAG:$1'
-AC_DEFUN([LT_SUPPORTED_TAG], [])
-# C support is built-in for now
-m4_define([_LT_LANG_C_enabled], [])
-m4_define([_LT_TAGS], [])
-# LT_LANG(LANG)
-# Enable libtool support for the given language if not already enabled.
-AC_DEFUN([LT_LANG],
-[AC_BEFORE([$0], [LT_OUTPUT])dnl
-m4_case([$1],
- [C], [_LT_LANG(C)],
- [C++], [_LT_LANG(CXX)],
- [Go], [_LT_LANG(GO)],
- [Java], [_LT_LANG(GCJ)],
- [Fortran 77], [_LT_LANG(F77)],
- [Fortran], [_LT_LANG(FC)],
- [Windows Resource], [_LT_LANG(RC)],
- [m4_ifdef([_LT_LANG_]$1[_CONFIG],
- [_LT_LANG($1)],
- [m4_fatal([$0: unsupported language: "$1"])])])dnl
-])# LT_LANG
-# _LT_LANG(LANGNAME)
-m4_defun([_LT_LANG],
-[m4_ifdef([_LT_LANG_]$1[_enabled], [],
- [LT_SUPPORTED_TAG([$1])dnl
- m4_append([_LT_TAGS], [$1 ])dnl
- m4_define([_LT_LANG_]$1[_enabled], [])dnl
- _LT_LANG_$1_CONFIG($1)])dnl
-])# _LT_LANG
-m4_ifndef([AC_PROG_GO], [
-# NOTE: This macro has been submitted for inclusion into #
-# GNU Autoconf as AC_PROG_GO. When it is available in #
-# a released version of Autoconf we should remove this #
-# macro and use it instead. #
-m4_defun([AC_PROG_GO],
-[AC_LANG_PUSH(Go)dnl
-AC_ARG_VAR([GOC], [Go compiler command])dnl
-AC_ARG_VAR([GOFLAGS], [Go compiler flags])dnl
-_AC_ARG_VAR_LDFLAGS()dnl
-AC_CHECK_TOOL(GOC, gccgo)
-if test -z "$GOC"; then
- if test -n "$ac_tool_prefix"; then
- AC_CHECK_PROG(GOC, [${ac_tool_prefix}gccgo], [${ac_tool_prefix}gccgo])
- fi
-fi
- AC_CHECK_PROG(GOC, gccgo, gccgo, false)
-fi
-])#m4_defun
-])#m4_ifndef
-# _LT_LANG_DEFAULT_CONFIG
-m4_defun([_LT_LANG_DEFAULT_CONFIG],
-[AC_PROVIDE_IFELSE([AC_PROG_CXX],
- [LT_LANG(CXX)],
- [m4_define([AC_PROG_CXX], defn([AC_PROG_CXX])[LT_LANG(CXX)])])
-AC_PROVIDE_IFELSE([AC_PROG_F77],
- [LT_LANG(F77)],
- [m4_define([AC_PROG_F77], defn([AC_PROG_F77])[LT_LANG(F77)])])
-AC_PROVIDE_IFELSE([AC_PROG_FC],
- [LT_LANG(FC)],
- [m4_define([AC_PROG_FC], defn([AC_PROG_FC])[LT_LANG(FC)])])
-dnl The call to [A][M_PROG_GCJ] is quoted like that to stop aclocal
-dnl pulling things in needlessly.
-AC_PROVIDE_IFELSE([AC_PROG_GCJ],
- [LT_LANG(GCJ)],
- [AC_PROVIDE_IFELSE([A][M_PROG_GCJ],
- [LT_LANG(GCJ)],
- [AC_PROVIDE_IFELSE([LT_PROG_GCJ],
- [LT_LANG(GCJ)],
- [m4_ifdef([AC_PROG_GCJ],
- [m4_define([AC_PROG_GCJ], defn([AC_PROG_GCJ])[LT_LANG(GCJ)])])
- m4_ifdef([A][M_PROG_GCJ],
- [m4_define([A][M_PROG_GCJ], defn([A][M_PROG_GCJ])[LT_LANG(GCJ)])])
- m4_ifdef([LT_PROG_GCJ],
- [m4_define([LT_PROG_GCJ], defn([LT_PROG_GCJ])[LT_LANG(GCJ)])])])])])
-AC_PROVIDE_IFELSE([AC_PROG_GO],
- [LT_LANG(GO)],
- [m4_define([AC_PROG_GO], defn([AC_PROG_GO])[LT_LANG(GO)])])
-AC_PROVIDE_IFELSE([LT_PROG_RC],
- [LT_LANG(RC)],
- [m4_define([LT_PROG_RC], defn([LT_PROG_RC])[LT_LANG(RC)])])
-])# _LT_LANG_DEFAULT_CONFIG
-# Obsolete macros:
-AU_DEFUN([AC_LIBTOOL_CXX], [LT_LANG(C++)])
-AU_DEFUN([AC_LIBTOOL_F77], [LT_LANG(Fortran 77)])
-AU_DEFUN([AC_LIBTOOL_FC], [LT_LANG(Fortran)])
-AU_DEFUN([AC_LIBTOOL_GCJ], [LT_LANG(Java)])
-AU_DEFUN([AC_LIBTOOL_RC], [LT_LANG(Windows Resource)])
-dnl AC_DEFUN([AC_LIBTOOL_CXX], [])
-dnl AC_DEFUN([AC_LIBTOOL_F77], [])
-dnl AC_DEFUN([AC_LIBTOOL_FC], [])
-dnl AC_DEFUN([AC_LIBTOOL_GCJ], [])
-dnl AC_DEFUN([AC_LIBTOOL_RC], [])
-# _LT_TAG_COMPILER
-m4_defun([_LT_TAG_COMPILER],
-[AC_REQUIRE([AC_PROG_CC])dnl
-_LT_DECL([LTCC], [CC], [1], [A C compiler])dnl
-_LT_DECL([LTCFLAGS], [CFLAGS], [1], [LTCC compiler flags])dnl
-_LT_TAGDECL([CC], [compiler], [1], [A language specific compiler])dnl
-_LT_TAGDECL([with_gcc], [GCC], [0], [Is the compiler the GNU compiler?])dnl
-# If no C compiler was specified, use CC.
-LTCC=${LTCC-"$CC"}
-# If no C compiler flags were specified, use CFLAGS.
-LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
-# Allow CC to be a program name with arguments.
-compiler=$CC
-])# _LT_TAG_COMPILER
-# _LT_COMPILER_BOILERPLATE
-# Check for compiler boilerplate output or warnings with
-# the simple compiler test code.
-m4_defun([_LT_COMPILER_BOILERPLATE],
-[m4_require([_LT_DECL_SED])dnl
-ac_outfile=conftest.$ac_objext
-echo "$lt_simple_compile_test_code" >conftest.$ac_ext
-eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
-_lt_compiler_boilerplate=`cat conftest.err`
-$RM conftest*
-])# _LT_COMPILER_BOILERPLATE
-# _LT_LINKER_BOILERPLATE
-# Check for linker boilerplate output or warnings with
-# the simple link test code.
-m4_defun([_LT_LINKER_BOILERPLATE],
-echo "$lt_simple_link_test_code" >conftest.$ac_ext
-eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
-_lt_linker_boilerplate=`cat conftest.err`
-$RM -r conftest*
-])# _LT_LINKER_BOILERPLATE
-# _LT_REQUIRED_DARWIN_CHECKS
-m4_defun_once([_LT_REQUIRED_DARWIN_CHECKS],[
- case $host_os in
- rhapsody* | darwin*)
- AC_CHECK_TOOL([DSYMUTIL], [dsymutil], [:])
- AC_CHECK_TOOL([NMEDIT], [nmedit], [:])
- AC_CHECK_TOOL([LIPO], [lipo], [:])
- AC_CHECK_TOOL([OTOOL], [otool], [:])
- AC_CHECK_TOOL([OTOOL64], [otool64], [:])
- _LT_DECL([], [DSYMUTIL], [1],
- [Tool to manipulate archived DWARF debug symbol files on Mac OS X])
- _LT_DECL([], [NMEDIT], [1],
- [Tool to change global to local symbols on Mac OS X])
- _LT_DECL([], [LIPO], [1],
- [Tool to manipulate fat objects and archives on Mac OS X])
- _LT_DECL([], [OTOOL], [1],
- [ldd/readelf like tool for Mach-O binaries on Mac OS X])
- _LT_DECL([], [OTOOL64], [1],
- [ldd/readelf like tool for 64 bit Mach-O binaries on Mac OS X 10.4])
- AC_CACHE_CHECK([for -single_module linker flag],[lt_cv_apple_cc_single_mod],
- [lt_cv_apple_cc_single_mod=no
- if test -z "${LT_MULTI_MODULE}"; then
- # By default we will add the -single_module flag. You can override
- # by either setting the environment variable LT_MULTI_MODULE
- # non-empty at configure time, or by adding -multi_module to the
- # link flags.
- rm -rf libconftest.dylib*
- echo "int foo(void){return 1;}" > conftest.c
- echo "$LTCC $LTCFLAGS $LDFLAGS -o libconftest.dylib \
--dynamiclib -Wl,-single_module conftest.c" >&AS_MESSAGE_LOG_FD
- $LTCC $LTCFLAGS $LDFLAGS -o libconftest.dylib \
- -dynamiclib -Wl,-single_module conftest.c 2>conftest.err
- _lt_result=$?
- # If there is a non-empty error log, and "single_module"
- # appears in it, assume the flag caused a linker warning
- if test -s conftest.err && $GREP single_module conftest.err; then
- cat conftest.err >&AS_MESSAGE_LOG_FD
- # Otherwise, if the output was created with a 0 exit code from
- # the compiler, it worked.
- elif test -f libconftest.dylib && test $_lt_result -eq 0; then
- lt_cv_apple_cc_single_mod=yes
- else
- fi
- rm -f conftest.*
- fi])
- AC_CACHE_CHECK([for -exported_symbols_list linker flag],
- [lt_cv_ld_exported_symbols_list],
- [lt_cv_ld_exported_symbols_list=no
- save_LDFLAGS=$LDFLAGS
- echo "_main" > conftest.sym
- LDFLAGS="$LDFLAGS -Wl,-exported_symbols_list,conftest.sym"
- AC_LINK_IFELSE([AC_LANG_PROGRAM([],[])],
- [lt_cv_ld_exported_symbols_list=yes],
- [lt_cv_ld_exported_symbols_list=no])
- LDFLAGS="$save_LDFLAGS"
- AC_CACHE_CHECK([for -force_load linker flag],[lt_cv_ld_force_load],
- [lt_cv_ld_force_load=no
- cat > conftest.c << _LT_EOF
-int forced_loaded() { return 2;}
-_LT_EOF
- echo "$LTCC $LTCFLAGS -c -o conftest.o conftest.c" >&AS_MESSAGE_LOG_FD
- $LTCC $LTCFLAGS -c -o conftest.o conftest.c 2>&AS_MESSAGE_LOG_FD
- echo "$AR cru libconftest.a conftest.o" >&AS_MESSAGE_LOG_FD
- $AR cru libconftest.a conftest.o 2>&AS_MESSAGE_LOG_FD
- echo "$RANLIB libconftest.a" >&AS_MESSAGE_LOG_FD
- $RANLIB libconftest.a 2>&AS_MESSAGE_LOG_FD
-int main() { return 0;}
-_LT_EOF
- echo "$LTCC $LTCFLAGS $LDFLAGS -o conftest conftest.c -Wl,-force_load,./libconftest.a" >&AS_MESSAGE_LOG_FD
- $LTCC $LTCFLAGS $LDFLAGS -o conftest conftest.c -Wl,-force_load,./libconftest.a 2>conftest.err
- _lt_result=$?
- if test -s conftest.err && $GREP force_load conftest.err; then
- elif test -f conftest && test $_lt_result -eq 0 && $GREP forced_load conftest >/dev/null 2>&1 ; then
- lt_cv_ld_force_load=yes
- else
- fi
- rm -f conftest.err libconftest.a conftest conftest.c
- rm -rf conftest.dSYM
- case $host_os in
- rhapsody* | darwin1.[[012]])
- _lt_dar_allow_undefined='${wl}-undefined ${wl}suppress' ;;
- darwin1.*)
- _lt_dar_allow_undefined='${wl}-flat_namespace ${wl}-undefined ${wl}suppress' ;;
- darwin*) # darwin 5.x on
- # if running on 10.5 or later, the deployment target defaults
- # to the OS version, if on x86, and 10.4, the deployment
- # target defaults to 10.4. Don't you love it?
- case ${MACOSX_DEPLOYMENT_TARGET-10.0},$host in
- 10.0,*86*-darwin8*|10.0,*-darwin[[91]]*)
- _lt_dar_allow_undefined='${wl}-undefined ${wl}dynamic_lookup' ;;
- 10.[[012]]*)
- 10.*)
- esac
- esac
- if test "$lt_cv_apple_cc_single_mod" = "yes"; then
- _lt_dar_single_mod='$single_module'
- fi
- if test "$lt_cv_ld_exported_symbols_list" = "yes"; then
- _lt_dar_export_syms=' ${wl}-exported_symbols_list,$output_objdir/${libname}-symbols.expsym'
- else
- _lt_dar_export_syms='~$NMEDIT -s $output_objdir/${libname}-symbols.expsym ${lib}'
- fi
- if test "$DSYMUTIL" != ":" && test "$lt_cv_ld_force_load" = "no"; then
- _lt_dsymutil='~$DSYMUTIL $lib || :'
- else
- _lt_dsymutil=
- fi
- esac
-# _LT_DARWIN_LINKER_FEATURES([TAG])
-# Checks for linker and compiler features on darwin
-m4_defun([_LT_DARWIN_LINKER_FEATURES],
- m4_require([_LT_REQUIRED_DARWIN_CHECKS])
- _LT_TAGVAR(archive_cmds_need_lc, $1)=no
- _LT_TAGVAR(hardcode_direct, $1)=no
- _LT_TAGVAR(hardcode_automatic, $1)=yes
- _LT_TAGVAR(hardcode_shlibpath_var, $1)=unsupported
- if test "$lt_cv_ld_force_load" = "yes"; then
- _LT_TAGVAR(whole_archive_flag_spec, $1)='`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience ${wl}-force_load,$conv\"; done; func_echo_all \"$new_convenience\"`'
- m4_case([$1], [F77], [_LT_TAGVAR(compiler_needs_object, $1)=yes],
- [FC], [_LT_TAGVAR(compiler_needs_object, $1)=yes])
- else
- _LT_TAGVAR(whole_archive_flag_spec, $1)=''
- fi
- _LT_TAGVAR(link_all_deplibs, $1)=yes
- _LT_TAGVAR(allow_undefined_flag, $1)="$_lt_dar_allow_undefined"
- case $cc_basename in
- ifort*) _lt_dar_can_shared=yes ;;
- *) _lt_dar_can_shared=$GCC ;;
- esac
- if test "$_lt_dar_can_shared" = "yes"; then
- output_verbose_link_cmd=func_echo_all
- _LT_TAGVAR(archive_cmds, $1)="\$CC -dynamiclib \$allow_undefined_flag -o \$lib \$libobjs \$deplibs \$compiler_flags -install_name \$rpath/\$soname \$verstring $_lt_dar_single_mod${_lt_dsymutil}"
- _LT_TAGVAR(module_cmds, $1)="\$CC \$allow_undefined_flag -o \$lib -bundle \$libobjs \$deplibs \$compiler_flags${_lt_dsymutil}"
- _LT_TAGVAR(archive_expsym_cmds, $1)="sed 's,^,_,' < \$export_symbols > \$output_objdir/\${libname}-symbols.expsym~\$CC -dynamiclib \$allow_undefined_flag -o \$lib \$libobjs \$deplibs \$compiler_flags -install_name \$rpath/\$soname \$verstring ${_lt_dar_single_mod}${_lt_dar_export_syms}${_lt_dsymutil}"
- _LT_TAGVAR(module_expsym_cmds, $1)="sed -e 's,^,_,' < \$export_symbols > \$output_objdir/\${libname}-symbols.expsym~\$CC \$allow_undefined_flag -o \$lib -bundle \$libobjs \$deplibs \$compiler_flags${_lt_dar_export_syms}${_lt_dsymutil}"
- m4_if([$1], [CXX],
-[ if test "$lt_cv_apple_cc_single_mod" != "yes"; then
- _LT_TAGVAR(archive_cmds, $1)="\$CC -r -keep_private_externs -nostdlib -o \${lib}-master.o \$libobjs~\$CC -dynamiclib \$allow_undefined_flag -o \$lib \${lib}-master.o \$deplibs \$compiler_flags -install_name \$rpath/\$soname \$verstring${_lt_dsymutil}"
- _LT_TAGVAR(archive_expsym_cmds, $1)="sed 's,^,_,' < \$export_symbols > \$output_objdir/\${libname}-symbols.expsym~\$CC -r -keep_private_externs -nostdlib -o \${lib}-master.o \$libobjs~\$CC -dynamiclib \$allow_undefined_flag -o \$lib \${lib}-master.o \$deplibs \$compiler_flags -install_name \$rpath/\$soname \$verstring${_lt_dar_export_syms}${_lt_dsymutil}"
- fi
- else
- _LT_TAGVAR(ld_shlibs, $1)=no
- fi
-# _LT_SYS_MODULE_PATH_AIX([TAGNAME])
-# Links a minimal program and checks the executable
-# for the system default hardcoded library path. In most cases,
-# this is /usr/lib:/lib, but when the MPI compilers are used
-# the location of the communication and MPI libs are included too.
-# If we don't find anything, use the default library path according
-# to the aix ld manual.
-# Store the results from the different compilers for each TAGNAME.
-# Allow to override them for all tags through lt_cv_aix_libpath.
-m4_defun([_LT_SYS_MODULE_PATH_AIX],
-if test "${lt_cv_aix_libpath+set}" = set; then
- aix_libpath=$lt_cv_aix_libpath
-else
- AC_CACHE_VAL([_LT_TAGVAR([lt_cv_aix_libpath_], [$1])],
- [AC_LINK_IFELSE([AC_LANG_PROGRAM],[
- lt_aix_libpath_sed='[
- /Import File Strings/,/^$/ {
- /^0/ {
- s/^0 *\([^ ]*\) *$/\1/
- p
- _LT_TAGVAR([lt_cv_aix_libpath_], [$1])=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e "$lt_aix_libpath_sed"`
- # Check for a 64-bit object if we didn't find anything.
- if test -z "$_LT_TAGVAR([lt_cv_aix_libpath_], [$1])"; then
- _LT_TAGVAR([lt_cv_aix_libpath_], [$1])=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e "$lt_aix_libpath_sed"`
- fi],[])
- _LT_TAGVAR([lt_cv_aix_libpath_], [$1])="/usr/lib:/lib"
- fi
- aix_libpath=$_LT_TAGVAR([lt_cv_aix_libpath_], [$1])
-fi
-])# _LT_SYS_MODULE_PATH_AIX
-# _LT_SHELL_INIT(ARG)
-m4_define([_LT_SHELL_INIT],
-[m4_divert_text([M4SH-INIT], [$1
-])])# _LT_SHELL_INIT
-# _LT_PROG_ECHO_BACKSLASH
-# Find how we can fake an echo command that does not interpret backslash.
-# In particular, with Autoconf 2.60 or later we add some code to the start
-# of the generated configure script which will find a shell with a builtin
-# printf (which we can use as an echo command).
-m4_defun([_LT_PROG_ECHO_BACKSLASH],
-[ECHO='\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'
-ECHO=$ECHO$ECHO$ECHO$ECHO$ECHO
-ECHO=$ECHO$ECHO$ECHO$ECHO$ECHO$ECHO
-AC_MSG_CHECKING([how to print strings])
-# Test print first, because it will be a builtin if present.
-if test "X`( print -r -- -n ) 2>/dev/null`" = X-n && \
- test "X`print -r -- $ECHO 2>/dev/null`" = "X$ECHO"; then
- ECHO='print -r --'
-elif test "X`printf %s $ECHO 2>/dev/null`" = "X$ECHO"; then
- ECHO='printf %s\n'
-else
- # Use this function as a fallback that always works.
- func_fallback_echo ()
-$[]1
-_LTECHO_EOF'
- ECHO='func_fallback_echo'
-fi
-# func_echo_all arg...
-# Invoke $ECHO with all args, space-separated.
-func_echo_all ()
- $ECHO "$*"
-case "$ECHO" in
- printf*) AC_MSG_RESULT([printf]) ;;
- print*) AC_MSG_RESULT([print -r]) ;;
- *) AC_MSG_RESULT([cat]) ;;
-esac
-m4_ifdef([_AS_DETECT_SUGGESTED],
-[_AS_DETECT_SUGGESTED([
- test -n "${ZSH_VERSION+set}${BASH_VERSION+set}" || (
- ECHO='\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'
- ECHO=$ECHO$ECHO$ECHO$ECHO$ECHO
- ECHO=$ECHO$ECHO$ECHO$ECHO$ECHO$ECHO
- PATH=/empty FPATH=/empty; export PATH FPATH
- test "X`printf %s $ECHO`" = "X$ECHO" \
- || test "X`print -r -- $ECHO`" = "X$ECHO" )])])
-_LT_DECL([], [SHELL], [1], [Shell to use when invoking shell scripts])
-_LT_DECL([], [ECHO], [1], [An echo program that protects backslashes])
-])# _LT_PROG_ECHO_BACKSLASH
-# _LT_WITH_SYSROOT
-AC_DEFUN([_LT_WITH_SYSROOT],
-[AC_MSG_CHECKING([for sysroot])
-AC_ARG_WITH([sysroot],
-[ --with-sysroot[=DIR] Search for dependent libraries within DIR
- (or the compiler's sysroot if not specified).],
-[], [with_sysroot=no])
-dnl lt_sysroot will always be passed unquoted. We quote it here
-dnl in case the user passed a directory name.
-lt_sysroot=
-case ${with_sysroot} in #(
- yes)
- if test "$GCC" = yes; then
- lt_sysroot=`$CC --print-sysroot 2>/dev/null`
- fi
- lt_sysroot=`echo "$with_sysroot" | sed -e "$sed_quote_subst"`
- no|'')
- AC_MSG_RESULT([${with_sysroot}])
- AC_MSG_ERROR([The sysroot must be an absolute path.])
-esac
- AC_MSG_RESULT([${lt_sysroot:-no}])
-_LT_DECL([], [lt_sysroot], [0], [The root where to search for ]dnl
-[dependent libraries, and in which our libraries should be installed.])])
-# _LT_ENABLE_LOCK
-m4_defun([_LT_ENABLE_LOCK],
-[AC_ARG_ENABLE([libtool-lock],
- [AS_HELP_STRING([--disable-libtool-lock],
- [avoid locking (might break parallel builds)])])
-test "x$enable_libtool_lock" != xno && enable_libtool_lock=yes
-# Some flags need to be propagated to the compiler or linker for good
-# libtool support.
-case $host in
-ia64-*-hpux*)
- # Find out which ABI we are using.
- echo 'int i;' > conftest.$ac_ext
- if AC_TRY_EVAL(ac_compile); then
- case `/usr/bin/file conftest.$ac_objext` in
- *ELF-32*)
- HPUX_IA64_MODE="32"
- *ELF-64*)
- HPUX_IA64_MODE="64"
- esac
- fi
- rm -rf conftest*
-*-*-irix6*)
- echo '[#]line '$LINENO' "configure"' > conftest.$ac_ext
- if test "$lt_cv_prog_gnu_ld" = yes; then
- *32-bit*)
- LD="${LD-ld} -melf32bsmip"
- *N32*)
- LD="${LD-ld} -melf32bmipn32"
- *64-bit*)
- LD="${LD-ld} -melf64bmip"
- esac
- else
- *32-bit*)
- LD="${LD-ld} -32"
- *N32*)
- LD="${LD-ld} -n32"
- *64-bit*)
- LD="${LD-ld} -64"
- esac
- fi
- fi
- rm -rf conftest*
-x86_64-*kfreebsd*-gnu|x86_64-*linux*|ppc*-*linux*|powerpc*-*linux*| \
-s390*-*linux*|s390*-*tpf*|sparc*-*linux*)
- case `/usr/bin/file conftest.o` in
- *32-bit*)
- case $host in
- x86_64-*kfreebsd*-gnu)
- LD="${LD-ld} -m elf_i386_fbsd"
- x86_64-*linux*)
- LD="${LD-ld} -m elf_i386"
- ppc64-*linux*|powerpc64-*linux*)
- LD="${LD-ld} -m elf32ppclinux"
- s390x-*linux*)
- LD="${LD-ld} -m elf_s390"
- sparc64-*linux*)
- LD="${LD-ld} -m elf32_sparc"
- esac
- *64-bit*)
- case $host in
- LD="${LD-ld} -m elf_x86_64_fbsd"
- x86_64-*linux*)
- LD="${LD-ld} -m elf_x86_64"
- ppc*-*linux*|powerpc*-*linux*)
- LD="${LD-ld} -m elf64ppc"
- s390*-*linux*|s390*-*tpf*)
- LD="${LD-ld} -m elf64_s390"
- sparc*-*linux*)
- LD="${LD-ld} -m elf64_sparc"
- esac
- esac
- fi
- rm -rf conftest*
-*-*-sco3.2v5*)
- # On SCO OpenServer 5, we need -belf to get full-featured binaries.
- SAVE_CFLAGS="$CFLAGS"
- CFLAGS="$CFLAGS -belf"
- AC_CACHE_CHECK([whether the C compiler needs -belf], lt_cv_cc_needs_belf,
- [AC_LANG_PUSH(C)
- AC_LINK_IFELSE([AC_LANG_PROGRAM([[]],[[]])],[lt_cv_cc_needs_belf=yes],[lt_cv_cc_needs_belf=no])
- AC_LANG_POP])
- if test x"$lt_cv_cc_needs_belf" != x"yes"; then
- # this is probably gcc 2.8.0, egcs 1.0 or newer; no need for -belf
- CFLAGS="$SAVE_CFLAGS"
- fi
-*-*solaris*)
- *64-bit*)
- case $lt_cv_prog_gnu_ld in
- yes*)
- case $host in
- i?86-*-solaris*)
- sparc*-*-solaris*)
- esac
- # GNU ld 2.21 introduced _sol2 emulations. Use them if available.
- if ${LD-ld} -V | grep _sol2 >/dev/null 2>&1; then
- LD="${LD-ld}_sol2"
- fi
- if ${LD-ld} -64 -r -o conftest2.o conftest.o >/dev/null 2>&1; then
- LD="${LD-ld} -64"
- fi
- esac
- esac
- fi
- rm -rf conftest*
-esac
-need_locks="$enable_libtool_lock"
-])# _LT_ENABLE_LOCK
-# _LT_PROG_AR
-m4_defun([_LT_PROG_AR],
-[AC_CHECK_TOOLS(AR, [ar], false)
-: ${AR=ar}
-: ${AR_FLAGS=cru}
-_LT_DECL([], [AR], [1], [The archiver])
-_LT_DECL([], [AR_FLAGS], [1], [Flags to create an archive])
-AC_CACHE_CHECK([for archiver @FILE support], [lt_cv_ar_at_file],
- [lt_cv_ar_at_file=no
- AC_COMPILE_IFELSE([AC_LANG_PROGRAM],
- [echo conftest.$ac_objext > conftest.lst
- lt_ar_try='$AR $AR_FLAGS libconftest.a @conftest.lst >&AS_MESSAGE_LOG_FD'
- AC_TRY_EVAL([lt_ar_try])
- if test "$ac_status" -eq 0; then
- # Ensure the archiver fails upon bogus file names.
- rm -f conftest.$ac_objext libconftest.a
- if test "$ac_status" -ne 0; then
- lt_cv_ar_at_file=@
- fi
- fi
- rm -f conftest.* libconftest.a
-if test "x$lt_cv_ar_at_file" = xno; then
- archiver_list_spec=
-else
- archiver_list_spec=$lt_cv_ar_at_file
-fi
-_LT_DECL([], [archiver_list_spec], [1],
- [How to feed a file listing to the archiver])
-])# _LT_PROG_AR
-# _LT_CMD_OLD_ARCHIVE
-m4_defun([_LT_CMD_OLD_ARCHIVE],
-[_LT_PROG_AR
-AC_CHECK_TOOL(STRIP, strip, :)
-test -z "$STRIP" && STRIP=:
-_LT_DECL([], [STRIP], [1], [A symbol stripping program])
-AC_CHECK_TOOL(RANLIB, ranlib, :)
-test -z "$RANLIB" && RANLIB=:
-_LT_DECL([], [RANLIB], [1],
- [Commands used to install an old-style archive])
-# Determine commands to create old-style static archives.
-old_archive_cmds='$AR $AR_FLAGS $oldlib$oldobjs'
-old_postinstall_cmds='chmod 644 $oldlib'
-old_postuninstall_cmds=
-if test -n "$RANLIB"; then
- case $host_os in
- openbsd*)
- old_postinstall_cmds="$old_postinstall_cmds~\$RANLIB -t \$tool_oldlib"
- old_postinstall_cmds="$old_postinstall_cmds~\$RANLIB \$tool_oldlib"
- esac
- old_archive_cmds="$old_archive_cmds~\$RANLIB \$tool_oldlib"
-fi
-case $host_os in
- darwin*)
- lock_old_archive_extraction=yes ;;
- lock_old_archive_extraction=no ;;
-esac
-_LT_DECL([], [old_postinstall_cmds], [2])
-_LT_DECL([], [old_postuninstall_cmds], [2])
-_LT_TAGDECL([], [old_archive_cmds], [2],
- [Commands used to build an old-style archive])
-_LT_DECL([], [lock_old_archive_extraction], [0],
- [Whether to use a lock for old archive extraction])
-])# _LT_CMD_OLD_ARCHIVE
-# _LT_COMPILER_OPTION(MESSAGE, VARIABLE-NAME, FLAGS,
-# [OUTPUT-FILE], [ACTION-SUCCESS], [ACTION-FAILURE])
-# Check whether the given compiler option works
-AC_DEFUN([_LT_COMPILER_OPTION],
-m4_require([_LT_DECL_SED])dnl
-AC_CACHE_CHECK([$1], [$2],
- [$2=no
- m4_if([$4], , [ac_outfile=conftest.$ac_objext], [ac_outfile=$4])
- echo "$lt_simple_compile_test_code" > conftest.$ac_ext
- lt_compiler_flag="$3"
- # Insert the option either (1) after the last *FLAGS variable, or
- # (2) before a word containing "conftest.", or (3) at the end.
- # Note that $ac_compile itself does not contain backslashes and begins
- # with a dollar sign (not a hyphen), so the echo should work correctly.
- # The option is referenced via a variable to avoid confusing sed.
- lt_compile=`echo "$ac_compile" | $SED \
- -e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
- -e 's: [[^ ]]*conftest\.: $lt_compiler_flag&:; t' \
- -e 's:$: $lt_compiler_flag:'`
- (eval echo "\"\$as_me:$LINENO: $lt_compile\"" >&AS_MESSAGE_LOG_FD)
- (eval "$lt_compile" 2>conftest.err)
- ac_status=$?
- echo "$as_me:$LINENO: \$? = $ac_status" >&AS_MESSAGE_LOG_FD
- if (exit $ac_status) && test -s "$ac_outfile"; then
- # The compiler can only warn and ignore the option if not recognized
- # So say no if there are warnings other than the usual output.
- $ECHO "$_lt_compiler_boilerplate" | $SED '/^$/d' >conftest.exp
- $SED '/^$/d; /^ *+/d' conftest.err >conftest.er2
- if test ! -s conftest.er2 || diff conftest.exp conftest.er2 >/dev/null; then
- $2=yes
- fi
- fi
- $RM conftest*
-if test x"[$]$2" = xyes; then
- m4_if([$5], , :, [$5])
-else
- m4_if([$6], , :, [$6])
-fi
-])# _LT_COMPILER_OPTION
-# Old name:
-AU_ALIAS([AC_LIBTOOL_COMPILER_OPTION], [_LT_COMPILER_OPTION])
-dnl AC_DEFUN([AC_LIBTOOL_COMPILER_OPTION], [])
-# _LT_LINKER_OPTION(MESSAGE, VARIABLE-NAME, FLAGS,
-# [ACTION-SUCCESS], [ACTION-FAILURE])
-# Check whether the given linker option works
-AC_DEFUN([_LT_LINKER_OPTION],
- [$2=no
- save_LDFLAGS="$LDFLAGS"
- LDFLAGS="$LDFLAGS $3"
- echo "$lt_simple_link_test_code" > conftest.$ac_ext
- if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
- # The linker can only warn and ignore the option if not recognized
- if test -s conftest.err; then
- # Append any errors to the config.log.
- cat conftest.err 1>&AS_MESSAGE_LOG_FD
- $ECHO "$_lt_linker_boilerplate" | $SED '/^$/d' > conftest.exp
- if diff conftest.exp conftest.er2 >/dev/null; then
- $2=yes
- fi
- else
- $2=yes
- fi
- fi
- $RM -r conftest*
- m4_if([$4], , :, [$4])
-else
-fi
-])# _LT_LINKER_OPTION
-# Old name:
-AU_ALIAS([AC_LIBTOOL_LINKER_OPTION], [_LT_LINKER_OPTION])
-dnl AC_DEFUN([AC_LIBTOOL_LINKER_OPTION], [])
-# LT_CMD_MAX_LEN
-AC_DEFUN([LT_CMD_MAX_LEN],
-# find the maximum length of command line arguments
-AC_MSG_CHECKING([the maximum length of command line arguments])
-AC_CACHE_VAL([lt_cv_sys_max_cmd_len], [dnl
- i=0
- teststring="ABCD"
- case $build_os in
- msdosdjgpp*)
- # On DJGPP, this test can blow up pretty badly due to problems in libc
- # (any single argument exceeding 2000 bytes causes a buffer overrun
- # during glob expansion). Even if it were fixed, the result of this
- # check would be larger than it should be.
- lt_cv_sys_max_cmd_len=12288; # 12K is about right
- gnu*)
- # Under GNU Hurd, this test is not required because there is
- # no limit to the length of command line arguments.
- # Libtool will interpret -1 as no limit whatsoever
- lt_cv_sys_max_cmd_len=-1;
- cygwin* | mingw* | cegcc*)
- # On Win9x/ME, this test blows up -- it succeeds, but takes
- # about 5 minutes as the teststring grows exponentially.
- # Worse, since 9x/ME are not pre-emptively multitasking,
- # you end up with a "frozen" computer, even though with patience
- # the test eventually succeeds (with a max line length of 256k).
- # Instead, let's just punt: use the minimum linelength reported by
- # all of the supported platforms: 8192 (on NT/2K/XP).
- lt_cv_sys_max_cmd_len=8192;
- mint*)
- # On MiNT this can take a long time and run out of memory.
- amigaos*)
- # On AmigaOS with pdksh, this test takes hours, literally.
- # So we just punt and use a minimum line length of 8192.
- netbsd* | freebsd* | openbsd* | darwin* | dragonfly*)
- # This has been around since 386BSD, at least. Likely further.
- if test -x /sbin/sysctl; then
- lt_cv_sys_max_cmd_len=`/sbin/sysctl -n kern.argmax`
- elif test -x /usr/sbin/sysctl; then
- lt_cv_sys_max_cmd_len=`/usr/sbin/sysctl -n kern.argmax`
- else
- lt_cv_sys_max_cmd_len=65536 # usable default for all BSDs
- fi
- # And add a safety zone
- lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \/ 4`
- lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \* 3`
- interix*)
- # We know the value 262144 and hardcode it with a safety zone (like BSD)
- lt_cv_sys_max_cmd_len=196608
- os2*)
- # The test takes a long time on OS/2.
- osf*)
- # Dr. Hans Ekkehard Plesser reports seeing a kernel panic running configure
- # due to this test when exec_disable_arg_limit is 1 on Tru64. It is not
- # nice to cause kernel panics so lets avoid the loop below.
- # First set a reasonable default.
- lt_cv_sys_max_cmd_len=16384
- if test -x /sbin/sysconfig; then
- case `/sbin/sysconfig -q proc exec_disable_arg_limit` in
- *1*) lt_cv_sys_max_cmd_len=-1 ;;
- esac
- fi
- sco3.2v5*)
- lt_cv_sys_max_cmd_len=102400
- sysv5* | sco5v6* | sysv4.2uw2*)
- kargmax=`grep ARG_MAX /etc/conf/cf.d/stune 2>/dev/null`
- if test -n "$kargmax"; then
- lt_cv_sys_max_cmd_len=`echo $kargmax | sed 's/.*[[ ]]//'`
- else
- lt_cv_sys_max_cmd_len=32768
- fi
- lt_cv_sys_max_cmd_len=`(getconf ARG_MAX) 2> /dev/null`
- if test -n "$lt_cv_sys_max_cmd_len"; then
- else
- # Make teststring a little bigger before we do anything with it.
- # a 1K string should be a reasonable start.
- for i in 1 2 3 4 5 6 7 8 ; do
- teststring=$teststring$teststring
- done
- SHELL=${SHELL-${CONFIG_SHELL-/bin/sh}}
- # If test is not a shell built-in, we'll probably end up computing a
- # maximum length that is only half of the actual maximum length, but
- # we can't tell.
- while { test "X"`env echo "$teststring$teststring" 2>/dev/null` \
- = "X$teststring$teststring"; } >/dev/null 2>&1 &&
- test $i != 17 # 1/2 MB should be enough
- do
- i=`expr $i + 1`
- done
- # Only check the string length outside the loop.
- lt_cv_sys_max_cmd_len=`expr "X$teststring" : ".*" 2>&1`
- teststring=
- # Add a significant safety factor because C++ compilers can tack on
- # massive amounts of additional arguments before passing them to the
- # linker. It appears as though 1/2 is a usable value.
- lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \/ 2`
- fi
- esac
-if test -n $lt_cv_sys_max_cmd_len ; then
- AC_MSG_RESULT($lt_cv_sys_max_cmd_len)
-else
- AC_MSG_RESULT(none)
-fi
-max_cmd_len=$lt_cv_sys_max_cmd_len
-_LT_DECL([], [max_cmd_len], [0],
- [What is the maximum length of a command?])
-])# LT_CMD_MAX_LEN
-# Old name:
-AU_ALIAS([AC_LIBTOOL_SYS_MAX_CMD_LEN], [LT_CMD_MAX_LEN])
-dnl AC_DEFUN([AC_LIBTOOL_SYS_MAX_CMD_LEN], [])
-# _LT_HEADER_DLFCN
-m4_defun([_LT_HEADER_DLFCN],
-[AC_CHECK_HEADERS([dlfcn.h], [], [], [AC_INCLUDES_DEFAULT])dnl
-])# _LT_HEADER_DLFCN
-# _LT_TRY_DLOPEN_SELF (ACTION-IF-TRUE, ACTION-IF-TRUE-W-USCORE,
-# ACTION-IF-FALSE, ACTION-IF-CROSS-COMPILING)
-m4_defun([_LT_TRY_DLOPEN_SELF],
-[m4_require([_LT_HEADER_DLFCN])dnl
-if test "$cross_compiling" = yes; then :
- [$4]
-else
- lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
- lt_status=$lt_dlunknown
- cat > conftest.$ac_ext <<_LT_EOF
-[#line $LINENO "configure"
-#include "confdefs.h"
-#if HAVE_DLFCN_H
-#include <dlfcn.h>
-#endif
-#include <stdio.h>
-#ifdef RTLD_GLOBAL
-# define LT_DLGLOBAL RTLD_GLOBAL
-#else
-# ifdef DL_GLOBAL
-# define LT_DLGLOBAL DL_GLOBAL
-# else
-# define LT_DLGLOBAL 0
-# endif
-#endif
-/* We may have to define LT_DLLAZY_OR_NOW in the command line if we
- find out it does not work in some platform. */
-#ifndef LT_DLLAZY_OR_NOW
-# ifdef RTLD_LAZY
-# define LT_DLLAZY_OR_NOW RTLD_LAZY
-# else
-# ifdef DL_LAZY
-# define LT_DLLAZY_OR_NOW DL_LAZY
-# else
-# ifdef RTLD_NOW
-# define LT_DLLAZY_OR_NOW RTLD_NOW
-# else
-# ifdef DL_NOW
-# define LT_DLLAZY_OR_NOW DL_NOW
-# else
-# define LT_DLLAZY_OR_NOW 0
-# endif
-# endif
-# endif
-# endif
-#endif
-/* When -fvisbility=hidden is used, assume the code has been annotated
- correspondingly for the symbols needed. */
-#if defined(__GNUC__) && (((__GNUC__ == 3) && (__GNUC_MINOR__ >= 3)) || (__GNUC__ > 3))
-int fnord () __attribute__((visibility("default")));
-#endif
-int fnord () { return 42; }
-int main ()
- void *self = dlopen (0, LT_DLGLOBAL|LT_DLLAZY_OR_NOW);
- int status = $lt_dlunknown;
- if (self)
- if (dlsym (self,"fnord")) status = $lt_dlno_uscore;
- else
- if (dlsym( self,"_fnord")) status = $lt_dlneed_uscore;
- else puts (dlerror ());
- /* dlclose (self); */
- else
- puts (dlerror ());
- return status;
-_LT_EOF
- if AC_TRY_EVAL(ac_link) && test -s conftest${ac_exeext} 2>/dev/null; then
- (./conftest; exit; ) >&AS_MESSAGE_LOG_FD 2>/dev/null
- lt_status=$?
- case x$lt_status in
- x$lt_dlno_uscore) $1 ;;
- x$lt_dlneed_uscore) $2 ;;
- x$lt_dlunknown|x*) $3 ;;
- esac
- else :
- # compilation failed
- $3
- fi
-fi
-rm -fr conftest*
-])# _LT_TRY_DLOPEN_SELF
-# LT_SYS_DLOPEN_SELF
-AC_DEFUN([LT_SYS_DLOPEN_SELF],
-if test "x$enable_dlopen" != xyes; then
- enable_dlopen=unknown
- enable_dlopen_self=unknown
- enable_dlopen_self_static=unknown
-else
- lt_cv_dlopen=no
- lt_cv_dlopen_libs=
- case $host_os in
- beos*)
- lt_cv_dlopen="load_add_on"
- lt_cv_dlopen_self=yes
- mingw* | pw32* | cegcc*)
- lt_cv_dlopen="LoadLibrary"
- cygwin*)
- lt_cv_dlopen="dlopen"
- darwin*)
- # if libdl is installed we need to link against it
- AC_CHECK_LIB([dl], [dlopen],
- [lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-ldl"],[
- lt_cv_dlopen="dyld"
- AC_CHECK_FUNC([shl_load],
- [lt_cv_dlopen="shl_load"],
- [AC_CHECK_LIB([dld], [shl_load],
- [lt_cv_dlopen="shl_load" lt_cv_dlopen_libs="-ldld"],
- [AC_CHECK_FUNC([dlopen],
- [lt_cv_dlopen="dlopen"],
- [AC_CHECK_LIB([dl], [dlopen],
- [AC_CHECK_LIB([svld], [dlopen],
- [lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-lsvld"],
- [AC_CHECK_LIB([dld], [dld_link],
- [lt_cv_dlopen="dld_link" lt_cv_dlopen_libs="-ldld"])
- esac
- if test "x$lt_cv_dlopen" != xno; then
- enable_dlopen=yes
- else
- enable_dlopen=no
- fi
- case $lt_cv_dlopen in
- dlopen)
- save_CPPFLAGS="$CPPFLAGS"
- test "x$ac_cv_header_dlfcn_h" = xyes && CPPFLAGS="$CPPFLAGS -DHAVE_DLFCN_H"
- wl=$lt_prog_compiler_wl eval LDFLAGS=\"\$LDFLAGS $export_dynamic_flag_spec\"
- save_LIBS="$LIBS"
- LIBS="$lt_cv_dlopen_libs $LIBS"
- AC_CACHE_CHECK([whether a program can dlopen itself],
- lt_cv_dlopen_self, [dnl
- _LT_TRY_DLOPEN_SELF(
- lt_cv_dlopen_self=yes, lt_cv_dlopen_self=yes,
- lt_cv_dlopen_self=no, lt_cv_dlopen_self=cross)
- if test "x$lt_cv_dlopen_self" = xyes; then
- wl=$lt_prog_compiler_wl eval LDFLAGS=\"\$LDFLAGS $lt_prog_compiler_static\"
- AC_CACHE_CHECK([whether a statically linked program can dlopen itself],
- lt_cv_dlopen_self_static, [dnl
- lt_cv_dlopen_self_static=yes, lt_cv_dlopen_self_static=yes,
- lt_cv_dlopen_self_static=no, lt_cv_dlopen_self_static=cross)
- fi
- CPPFLAGS="$save_CPPFLAGS"
- LIBS="$save_LIBS"
- esac
- case $lt_cv_dlopen_self in
- yes|no) enable_dlopen_self=$lt_cv_dlopen_self ;;
- *) enable_dlopen_self=unknown ;;
- esac
- case $lt_cv_dlopen_self_static in
- yes|no) enable_dlopen_self_static=$lt_cv_dlopen_self_static ;;
- *) enable_dlopen_self_static=unknown ;;
- esac
-fi
-_LT_DECL([dlopen_support], [enable_dlopen], [0],
- [Whether dlopen is supported])
-_LT_DECL([dlopen_self], [enable_dlopen_self], [0],
- [Whether dlopen of programs is supported])
-_LT_DECL([dlopen_self_static], [enable_dlopen_self_static], [0],
- [Whether dlopen of statically linked programs is supported])
-])# LT_SYS_DLOPEN_SELF
-# Old name:
-AU_ALIAS([AC_LIBTOOL_DLOPEN_SELF], [LT_SYS_DLOPEN_SELF])
-dnl AC_DEFUN([AC_LIBTOOL_DLOPEN_SELF], [])
-# _LT_COMPILER_C_O([TAGNAME])
-# Check to see if options -c and -o are simultaneously supported by compiler.
-# This macro does not hard code the compiler like AC_PROG_CC_C_O.
-m4_defun([_LT_COMPILER_C_O],
-AC_CACHE_CHECK([if $compiler supports -c -o file.$ac_objext],
- [_LT_TAGVAR(lt_cv_prog_compiler_c_o, $1)],
- [_LT_TAGVAR(lt_cv_prog_compiler_c_o, $1)=no
- $RM -r conftest 2>/dev/null
- mkdir conftest
- cd conftest
- mkdir out
- lt_compiler_flag="-o out/conftest2.$ac_objext"
- (eval "$lt_compile" 2>out/conftest.err)
- ac_status=$?
- cat out/conftest.err >&AS_MESSAGE_LOG_FD
- if (exit $ac_status) && test -s out/conftest2.$ac_objext
- then
- $ECHO "$_lt_compiler_boilerplate" | $SED '/^$/d' > out/conftest.exp
- $SED '/^$/d; /^ *+/d' out/conftest.err >out/conftest.er2
- if test ! -s out/conftest.er2 || diff out/conftest.exp out/conftest.er2 >/dev/null; then
- _LT_TAGVAR(lt_cv_prog_compiler_c_o, $1)=yes
- fi
- fi
- chmod u+w . 2>&AS_MESSAGE_LOG_FD
- $RM conftest*
- # SGI C++ compiler will create directory out/ii_files/ for
- # template instantiation
- test -d out/ii_files && $RM out/ii_files/* && rmdir out/ii_files
- $RM out/* && rmdir out
- cd ..
- $RM -r conftest
- $RM conftest*
-_LT_TAGDECL([compiler_c_o], [lt_cv_prog_compiler_c_o], [1],
- [Does compiler simultaneously support -c and -o options?])
-])# _LT_COMPILER_C_O
-# _LT_COMPILER_FILE_LOCKS([TAGNAME])
-# Check to see if we can do hard links to lock some files if needed
-m4_defun([_LT_COMPILER_FILE_LOCKS],
-[m4_require([_LT_ENABLE_LOCK])dnl
-_LT_COMPILER_C_O([$1])
-hard_links="nottested"
-if test "$_LT_TAGVAR(lt_cv_prog_compiler_c_o, $1)" = no && test "$need_locks" != no; then
- # do not overwrite the value of need_locks provided by the user
- AC_MSG_CHECKING([if we can lock with hard links])
- hard_links=yes
- $RM conftest*
- ln conftest.a conftest.b 2>/dev/null && hard_links=no
- touch conftest.a
- ln conftest.a conftest.b 2>&5 || hard_links=no
- AC_MSG_RESULT([$hard_links])
- if test "$hard_links" = no; then
- AC_MSG_WARN([`$CC' does not support `-c -o', so `make -j' may be unsafe])
- need_locks=warn
- fi
-else
- need_locks=no
-fi
-_LT_DECL([], [need_locks], [1], [Must we lock files when doing compilation?])
-])# _LT_COMPILER_FILE_LOCKS
-# _LT_CHECK_OBJDIR
-m4_defun([_LT_CHECK_OBJDIR],
-[AC_CACHE_CHECK([for objdir], [lt_cv_objdir],
-[rm -f .libs 2>/dev/null
-mkdir .libs 2>/dev/null
-if test -d .libs; then
- lt_cv_objdir=.libs
-else
- # MS-DOS does not allow filenames that begin with a dot.
- lt_cv_objdir=_libs
-fi
-rmdir .libs 2>/dev/null])
-objdir=$lt_cv_objdir
-_LT_DECL([], [objdir], [0],
- [The name of the directory that contains temporary libtool files])dnl
-m4_pattern_allow([LT_OBJDIR])dnl
-AC_DEFINE_UNQUOTED(LT_OBJDIR, "$lt_cv_objdir/",
- [Define to the sub-directory in which libtool stores uninstalled libraries.])
-])# _LT_CHECK_OBJDIR
-# _LT_LINKER_HARDCODE_LIBPATH([TAGNAME])
-# Check hardcoding attributes.
-m4_defun([_LT_LINKER_HARDCODE_LIBPATH],
-[AC_MSG_CHECKING([how to hardcode library paths into programs])
-_LT_TAGVAR(hardcode_action, $1)=
-if test -n "$_LT_TAGVAR(hardcode_libdir_flag_spec, $1)" ||
- test -n "$_LT_TAGVAR(runpath_var, $1)" ||
- test "X$_LT_TAGVAR(hardcode_automatic, $1)" = "Xyes" ; then
- # We can hardcode non-existent directories.
- if test "$_LT_TAGVAR(hardcode_direct, $1)" != no &&
- # If the only mechanism to avoid hardcoding is shlibpath_var, we
- # have to relink, otherwise we might link with an installed library
- # when we should be linking with a yet-to-be-installed one
- ## test "$_LT_TAGVAR(hardcode_shlibpath_var, $1)" != no &&
- test "$_LT_TAGVAR(hardcode_minus_L, $1)" != no; then
- # Linking always hardcodes the temporary library directory.
- _LT_TAGVAR(hardcode_action, $1)=relink
- else
- # We can link without hardcoding, and we can hardcode nonexisting dirs.
- _LT_TAGVAR(hardcode_action, $1)=immediate
- fi
-else
- # We cannot hardcode anything, or else we can only hardcode existing
- # directories.
- _LT_TAGVAR(hardcode_action, $1)=unsupported
-fi
-AC_MSG_RESULT([$_LT_TAGVAR(hardcode_action, $1)])
-if test "$_LT_TAGVAR(hardcode_action, $1)" = relink ||
- test "$_LT_TAGVAR(inherit_rpath, $1)" = yes; then
- # Fast installation is not supported
- enable_fast_install=no
-elif test "$shlibpath_overrides_runpath" = yes ||
- test "$enable_shared" = no; then
- # Fast installation is not necessary
- enable_fast_install=needless
-fi
-_LT_TAGDECL([], [hardcode_action], [0],
- [How to hardcode a shared library path into an executable])
-])# _LT_LINKER_HARDCODE_LIBPATH
-# _LT_CMD_STRIPLIB
-m4_defun([_LT_CMD_STRIPLIB],
-[m4_require([_LT_DECL_EGREP])
-striplib=
-old_striplib=
-AC_MSG_CHECKING([whether stripping libraries is possible])
-if test -n "$STRIP" && $STRIP -V 2>&1 | $GREP "GNU strip" >/dev/null; then
- test -z "$old_striplib" && old_striplib="$STRIP --strip-debug"
- test -z "$striplib" && striplib="$STRIP --strip-unneeded"
- AC_MSG_RESULT([yes])
-else
-# FIXME - insert some real tests, host_os isn't really good enough
- case $host_os in
- darwin*)
- if test -n "$STRIP" ; then
- striplib="$STRIP -x"
- old_striplib="$STRIP -S"
- else
- AC_MSG_RESULT([no])
- fi
- esac
-fi
-_LT_DECL([], [old_striplib], [1], [Commands to strip libraries])
-_LT_DECL([], [striplib], [1])
-])# _LT_CMD_STRIPLIB
-# _LT_SYS_DYNAMIC_LINKER([TAG])
-# PORTME Fill in your ld.so characteristics
-m4_defun([_LT_SYS_DYNAMIC_LINKER],
-m4_require([_LT_DECL_EGREP])dnl
-m4_require([_LT_DECL_OBJDUMP])dnl
-AC_MSG_CHECKING([dynamic linker characteristics])
-m4_if([$1],
-if test "$GCC" = yes; then
- case $host_os in
- darwin*) lt_awk_arg="/^libraries:/,/LR/" ;;
- *) lt_awk_arg="/^libraries:/" ;;
- esac
- case $host_os in
- mingw* | cegcc*) lt_sed_strip_eq="s,=\([[A-Za-z]]:\),\1,g" ;;
- *) lt_sed_strip_eq="s,=/,/,g" ;;
- esac
- lt_search_path_spec=`$CC -print-search-dirs | awk $lt_awk_arg | $SED -e "s/^libraries://" -e $lt_sed_strip_eq`
- case $lt_search_path_spec in
- # if the path contains ";" then we assume it to be the separator
- # otherwise default to the standard path separator (i.e. ":") - it is
- # assumed that no part of a normal pathname contains ";" but that should
- # okay in the real world where ";" in dirpaths is itself problematic.
- lt_search_path_spec=`$ECHO "$lt_search_path_spec" | $SED 's/;/ /g'`
- lt_search_path_spec=`$ECHO "$lt_search_path_spec" | $SED "s/$PATH_SEPARATOR/ /g"`
- esac
- # Ok, now we have the path, separated by spaces, we can step through it
- # and add multilib dir if necessary.
- lt_tmp_lt_search_path_spec=
- lt_multi_os_dir=`$CC $CPPFLAGS $CFLAGS $LDFLAGS -print-multi-os-directory 2>/dev/null`
- for lt_sys_path in $lt_search_path_spec; do
- if test -d "$lt_sys_path/$lt_multi_os_dir"; then
- lt_tmp_lt_search_path_spec="$lt_tmp_lt_search_path_spec $lt_sys_path/$lt_multi_os_dir"
- else
- test -d "$lt_sys_path" && \
- lt_tmp_lt_search_path_spec="$lt_tmp_lt_search_path_spec $lt_sys_path"
- fi
- done
- lt_search_path_spec=`$ECHO "$lt_tmp_lt_search_path_spec" | awk '
-BEGIN {RS=" "; FS="/|\n";} {
- lt_foo="";
- lt_count=0;
- for (lt_i = NF; lt_i > 0; lt_i--) {
- if ($lt_i != "" && $lt_i != ".") {
- if ($lt_i == "..") {
- lt_count++;
- } else {
- if (lt_count == 0) {
- lt_foo="/" $lt_i lt_foo;
- } else {
- lt_count--;
- if (lt_foo != "") { lt_freq[[lt_foo]]++; }
- if (lt_freq[[lt_foo]] == 1) { print lt_foo; }
- # AWK program above erroneously prepends '/' to C:/dos/paths
- # for these hosts.
- case $host_os in
- mingw* | cegcc*) lt_search_path_spec=`$ECHO "$lt_search_path_spec" |\
- $SED 's,/\([[A-Za-z]]:\),\1,g'` ;;
- esac
- sys_lib_search_path_spec=`$ECHO "$lt_search_path_spec" | $lt_NL2SP`
-else
- sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
-fi])
-library_names_spec=
-libname_spec='lib$name'
-soname_spec=
-shrext_cmds=".so"
-postinstall_cmds=
-postuninstall_cmds=
-finish_cmds=
-finish_eval=
-shlibpath_var=
-shlibpath_overrides_runpath=unknown
-version_type=none
-dynamic_linker="$host_os ld.so"
-sys_lib_dlsearch_path_spec="/lib /usr/lib"
-need_lib_prefix=unknown
-hardcode_into_libs=no
-# when you set need_version to no, make sure it does not cause -set_version
-# flags to be left without arguments
-need_version=unknown
-case $host_os in
-aix3*)
- version_type=linux # correct to gnu/linux during the next big refactor
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
- shlibpath_var=LIBPATH
- # AIX 3 has no versioning support, so we append a major version to the name.
- soname_spec='${libname}${release}${shared_ext}$major'
-aix[[4-9]]*)
- need_lib_prefix=no
- need_version=no
- hardcode_into_libs=yes
- if test "$host_cpu" = ia64; then
- # AIX 5 supports IA64
- library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
- shlibpath_var=LD_LIBRARY_PATH
- else
- # With GCC up to 2.95.x, collect2 would create an import file
- # for dependence libraries. The import file would start with
- # the line `#! .'. This would cause the generated library to
- # depend on `.', always an invalid library. This was fixed in
- # development snapshots of GCC prior to 3.0.
- case $host_os in
- aix4 | aix4.[[01]] | aix4.[[01]].*)
- if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
- echo ' yes '
- echo '#endif'; } | ${CC} -E - | $GREP yes > /dev/null; then
- else
- can_build_shared=no
- fi
- esac
- # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
- # soname into executable. Probably we can add versioning support to
- # collect2, so additional links can be useful in future.
- if test "$aix_use_runtimelinking" = yes; then
- # If using run time linking (on AIX 4.2 or later) use lib<name>.so
- # instead of lib<name>.a to let people know that these are not
- # typical AIX shared libraries.
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
- else
- # We preserve .a as extension for shared libraries through AIX4.2
- # and later when we are not doing run time linking.
- library_names_spec='${libname}${release}.a $libname.a'
- fi
- fi
-amigaos*)
- case $host_cpu in
- powerpc)
- # Since July 2007 AmigaOS4 officially supports .so libraries.
- # When compiling the executable, add -use-dynld -Lsobjs: to the compileline.
- m68k)
- library_names_spec='$libname.ixlibrary $libname.a'
- # Create ${libname}_ixlibrary.a entries in /sys/libs.
- finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`func_echo_all "$lib" | $SED '\''s%^.*/\([[^/]]*\)\.ixlibrary$%\1%'\''`; test $RM /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
- esac
-beos*)
- library_names_spec='${libname}${shared_ext}'
- dynamic_linker="$host_os ld.so"
- shlibpath_var=LIBRARY_PATH
-bsdi[[45]]*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
- sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
- sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
- # the default ld.so.conf also contains /usr/contrib/lib and
- # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
- # libtool to hard-code these into programs
-cygwin* | mingw* | pw32* | cegcc*)
- version_type=windows
- shrext_cmds=".dll"
- need_version=no
- case $GCC,$cc_basename in
- yes,*)
- # gcc
- library_names_spec='$libname.dll.a'
- # DLL is installed to $(libdir)/../bin by postinstall_cmds
- postinstall_cmds='base_file=`basename \${file}`~
- dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i; echo \$dlname'\''`~
- dldir=$destdir/`dirname \$dlpath`~
- test -d \$dldir || mkdir -p \$dldir~
- $install_prog $dir/$dlname \$dldir/$dlname~
- chmod a+x \$dldir/$dlname~
- if test -n '\''$stripme'\'' && test -n '\''$striplib'\''; then
- eval '\''$striplib \$dldir/$dlname'\'' || exit \$?;
- fi'
- postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
- dlpath=$dir/\$dldll~
- $RM \$dlpath'
- shlibpath_overrides_runpath=yes
- case $host_os in
- cygwin*)
- # Cygwin DLLs use 'cyg' prefix rather than 'lib'
- soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[[.]]/-/g'`${versuffix}${shared_ext}'
-m4_if([$1], [],[
- sys_lib_search_path_spec="$sys_lib_search_path_spec /usr/lib/w32api"])
- mingw* | cegcc*)
- # MinGW DLLs use traditional 'lib' prefix
- soname_spec='${libname}`echo ${release} | $SED -e 's/[[.]]/-/g'`${versuffix}${shared_ext}'
- pw32*)
- # pw32 DLLs use 'pw' prefix rather than 'lib'
- library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[[.]]/-/g'`${versuffix}${shared_ext}'
- esac
- dynamic_linker='Win32 ld.exe'
- *,cl*)
- # Native MSVC
- libname_spec='$name'
- library_names_spec='${libname}.dll.lib'
- case $build_os in
- mingw*)
- lt_save_ifs=$IFS
- IFS=';'
- for lt_path in $LIB
- do
- IFS=$lt_save_ifs
- # Let DOS variable expansion print the short 8.3 style file name.
- lt_path=`cd "$lt_path" 2>/dev/null && cmd //C "for %i in (".") do @echo %~si"`
- sys_lib_search_path_spec="$sys_lib_search_path_spec $lt_path"
- done
- IFS=$lt_save_ifs
- # Convert to MSYS style.
- sys_lib_search_path_spec=`$ECHO "$sys_lib_search_path_spec" | sed -e 's|\\\\|/|g' -e 's| \\([[a-zA-Z]]\\):| /\\1|g' -e 's|^ ||'`
- cygwin*)
- # Convert to unix form, then to dos form, then back to unix form
- # but this time dos style (no spaces!) so that the unix form looks
- # like /cygdrive/c/PROGRA~1:/cygdr...
- sys_lib_search_path_spec=`cygpath --path --unix "$LIB"`
- sys_lib_search_path_spec=`cygpath --path --dos "$sys_lib_search_path_spec" 2>/dev/null`
- sys_lib_search_path_spec=`cygpath --path --unix "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
- sys_lib_search_path_spec="$LIB"
- if $ECHO "$sys_lib_search_path_spec" | [$GREP ';[c-zC-Z]:/' >/dev/null]; then
- # It is most probably a Windows format PATH.
- sys_lib_search_path_spec=`$ECHO "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
- else
- sys_lib_search_path_spec=`$ECHO "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
- fi
- # FIXME: find the short name or the path components, as spaces are
- # common. (e.g. "Program Files" -> "PROGRA~1")
- esac
- $install_prog $dir/$dlname \$dldir/$dlname'
- $RM \$dlpath'
- dynamic_linker='Win32 link.exe'
- # Assume MSVC wrapper
- library_names_spec='${libname}`echo ${release} | $SED -e 's/[[.]]/-/g'`${versuffix}${shared_ext} $libname.lib'
- esac
- # FIXME: first we should search . and the directory the executable is in
- shlibpath_var=PATH
-darwin* | rhapsody*)
- dynamic_linker="$host_os dyld"
- version_type=darwin
- need_version=no
- library_names_spec='${libname}${release}${major}$shared_ext ${libname}$shared_ext'
- soname_spec='${libname}${release}${major}$shared_ext'
- shlibpath_var=DYLD_LIBRARY_PATH
- shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
-m4_if([$1], [],[
- sys_lib_search_path_spec="$sys_lib_search_path_spec /usr/local/lib"])
- sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
-dgux*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
-freebsd* | dragonfly*)
- # DragonFly does not have aout. When/if they implement a new
- # versioning mechanism, adjust this.
- if test -x /usr/bin/objformat; then
- objformat=`/usr/bin/objformat`
- else
- case $host_os in
- freebsd[[23]].*) objformat=aout ;;
- *) objformat=elf ;;
- esac
- fi
- version_type=freebsd-$objformat
- case $version_type in
- freebsd-elf*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
- need_version=no
- freebsd-*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
- need_version=yes
- esac
- case $host_os in
- freebsd2.*)
- freebsd3.[[01]]* | freebsdelf3.[[01]]*)
- freebsd3.[[2-9]]* | freebsdelf3.[[2-9]]* | \
- freebsd4.[[0-5]] | freebsdelf4.[[0-5]] | freebsd4.1.1 | freebsdelf4.1.1)
- shlibpath_overrides_runpath=no
- *) # from 4.6 on, and DragonFly
- esac
-gnu*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
-haiku*)
- need_version=no
- dynamic_linker="$host_os runtime_loader"
- sys_lib_dlsearch_path_spec='/boot/home/config/lib /boot/common/lib /boot/system/lib'
-hpux9* | hpux10* | hpux11*)
- # Give a soname corresponding to the major version so that dld.sl refuses to
- # link against other versions.
- version_type=sunos
- need_version=no
- case $host_cpu in
- ia64*)
- shrext_cmds='.so'
- dynamic_linker="$host_os dld.so"
- shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
- if test "X$HPUX_IA64_MODE" = X32; then
- sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
- else
- sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
- fi
- sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
- hppa*64*)
- shrext_cmds='.sl'
- dynamic_linker="$host_os dld.sl"
- shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
- sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
- shrext_cmds='.sl'
- shlibpath_var=SHLIB_PATH
- shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
- esac
- # HP-UX runs *really* slowly unless shared libraries are mode 555, ...
- postinstall_cmds='chmod 555 $lib'
- # or fails outright, so override atomically:
- install_override_mode=555
-interix[[3-9]]*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
- dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
-irix5* | irix6* | nonstopux*)
- case $host_os in
- nonstopux*) version_type=nonstopux ;;
- else
- version_type=irix
- fi ;;
- esac
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
- case $host_os in
- irix5* | nonstopux*)
- libsuff= shlibsuff=
- case $LD in # libtool.m4 will add one of these switches to LD
- *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
- libsuff= shlibsuff= libmagic=32-bit;;
- *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
- libsuff=32 shlibsuff=N32 libmagic=N32;;
- *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
- libsuff=64 shlibsuff=64 libmagic=64-bit;;
- *) libsuff= shlibsuff= libmagic=never-match;;
- esac
- esac
- shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
- sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
- sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
-# No shared lib support for Linux oldld, aout, or coff.
-linux*oldld* | linux*aout* | linux*coff*)
- dynamic_linker=no
-# This must be glibc/ELF.
-linux* | k*bsd*-gnu | kopensolaris*-gnu)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
- # Some binutils ld are patched to set DT_RUNPATH
- AC_CACHE_VAL([lt_cv_shlibpath_overrides_runpath],
- [lt_cv_shlibpath_overrides_runpath=no
- save_libdir=$libdir
- eval "libdir=/foo; wl=\"$_LT_TAGVAR(lt_prog_compiler_wl, $1)\"; \
- LDFLAGS=\"\$LDFLAGS $_LT_TAGVAR(hardcode_libdir_flag_spec, $1)\""
- [AS_IF([ ($OBJDUMP -p conftest$ac_exeext) 2>/dev/null | grep "RUNPATH.*$libdir" >/dev/null],
- [lt_cv_shlibpath_overrides_runpath=yes])])
- LDFLAGS=$save_LDFLAGS
- libdir=$save_libdir
- shlibpath_overrides_runpath=$lt_cv_shlibpath_overrides_runpath
- # This implies no fast_install, which is unacceptable.
- # Some rework will be needed to allow for fast_install
- # before this can be enabled.
- # Append ld.so.conf contents to the search path
- if test -f /etc/ld.so.conf; then
- lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s 2>/dev/null", \[$]2)); skip = 1; } { if (!skip) print \[$]0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;/^[ ]*hwcap[ ]/d;s/[:, ]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;s/"//g;/^$/d' | tr '\n' ' '`
- sys_lib_dlsearch_path_spec="/lib /usr/lib $lt_ld_extra"
- fi
- # We used to test for /lib/ld.so.1 and disable shared libraries on
- # powerpc, because MkLinux only supported shared libraries with the
- # GNU dynamic linker. Since this was broken with cross compilers,
- # most powerpc-linux boxes support dynamic linking these days and
- # people can always --disable-shared, the test was removed, and we
- # assume the GNU/Linux dynamic linker is in use.
- dynamic_linker='GNU/Linux ld.so'
-netbsdelf*-gnu)
- need_version=no
- dynamic_linker='NetBSD ld.elf_so'
-netbsd*)
- need_version=no
- if echo __ELF__ | $CC -E - | $GREP __ELF__ >/dev/null; then
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
- dynamic_linker='NetBSD (a.out) ld.so'
- else
- fi
-newsos6)
-*nto* | *qnx*)
- version_type=qnx
- need_version=no
- dynamic_linker='ldqnx.so'
-openbsd*)
- sys_lib_dlsearch_path_spec="/usr/lib"
- # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
- case $host_os in
- openbsd3.3 | openbsd3.3.*) need_version=yes ;;
- *) need_version=no ;;
- esac
- if test -z "`echo __ELF__ | $CC -E - | $GREP __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- case $host_os in
- openbsd2.[[89]] | openbsd2.[[89]].*)
- esac
- else
- fi
-os2*)
- library_names_spec='$libname${shared_ext} $libname.a'
- dynamic_linker='OS/2 ld.exe'
-osf3* | osf4* | osf5*)
- version_type=osf
- need_version=no
- sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
- sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
-rdos*)
- dynamic_linker=no
-solaris*)
- need_version=no
- # ldd complains unless libraries are executable
- postinstall_cmds='chmod +x $lib'
-sunos4*)
- finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
- if test "$with_gnu_ld" = yes; then
- fi
- need_version=yes
-sysv4 | sysv4.3*)
- case $host_vendor in
- sni)
- runpath_var=LD_RUN_PATH
- siemens)
- motorola)
- need_version=no
- sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
- esac
-sysv4*MP*)
- if test -d /usr/nec ;then
- library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
- soname_spec='$libname${shared_ext}.$major'
- fi
-sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
- version_type=freebsd-elf
- need_version=no
- sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
- else
- sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
- case $host_os in
- sco3.2v5*)
- sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
- esac
- fi
- sys_lib_dlsearch_path_spec='/usr/lib'
-tpf*)
- # TPF is a cross-target only. Preferred cross-host = GNU/Linux.
- need_version=no
-uts4*)
- dynamic_linker=no
-esac
-AC_MSG_RESULT([$dynamic_linker])
-test "$dynamic_linker" = no && can_build_shared=no
-variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
- variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
-fi
-if test "${lt_cv_sys_lib_search_path_spec+set}" = set; then
- sys_lib_search_path_spec="$lt_cv_sys_lib_search_path_spec"
-fi
-if test "${lt_cv_sys_lib_dlsearch_path_spec+set}" = set; then
- sys_lib_dlsearch_path_spec="$lt_cv_sys_lib_dlsearch_path_spec"
-fi
-_LT_DECL([], [variables_saved_for_relink], [1],
- [Variables whose values should be saved in libtool wrapper scripts and
- restored at link time])
-_LT_DECL([], [need_lib_prefix], [0],
- [Do we need the "lib" prefix for modules?])
-_LT_DECL([], [need_version], [0], [Do we need a version for libraries?])
-_LT_DECL([], [version_type], [0], [Library versioning type])
-_LT_DECL([], [runpath_var], [0], [Shared library runtime path variable])
-_LT_DECL([], [shlibpath_var], [0],[Shared library path variable])
-_LT_DECL([], [shlibpath_overrides_runpath], [0],
- [Is shlibpath searched before the hard-coded library search path?])
-_LT_DECL([], [libname_spec], [1], [Format of library name prefix])
-_LT_DECL([], [library_names_spec], [1],
- [[List of archive names. First name is the real one, the rest are links.
- The last name is the one that the linker finds with -lNAME]])
-_LT_DECL([], [soname_spec], [1],
- [[The coded name of the library, if different from the real name]])
-_LT_DECL([], [install_override_mode], [1],
- [Permission mode override for installation of shared libraries])
-_LT_DECL([], [postinstall_cmds], [2],
- [Command to use after installation of a shared archive])
-_LT_DECL([], [postuninstall_cmds], [2],
- [Command to use after uninstallation of a shared archive])
-_LT_DECL([], [finish_cmds], [2],
- [Commands used to finish a libtool library installation in a directory])
-_LT_DECL([], [finish_eval], [1],
- [[As "finish_cmds", except a single script fragment to be evaled but
- not shown]])
-_LT_DECL([], [hardcode_into_libs], [0],
- [Whether we should hardcode library paths into libraries])
-_LT_DECL([], [sys_lib_search_path_spec], [2],
- [Compile-time system search path for libraries])
-_LT_DECL([], [sys_lib_dlsearch_path_spec], [2],
- [Run-time system search path for libraries])
-])# _LT_SYS_DYNAMIC_LINKER
-# _LT_PATH_TOOL_PREFIX(TOOL)
-# find a file program which can recognize shared library
-AC_DEFUN([_LT_PATH_TOOL_PREFIX],
-[m4_require([_LT_DECL_EGREP])dnl
-AC_MSG_CHECKING([for $1])
-AC_CACHE_VAL(lt_cv_path_MAGIC_CMD,
-[case $MAGIC_CMD in
- lt_cv_path_MAGIC_CMD="$MAGIC_CMD" # Let the user override the test with a path.
- lt_save_MAGIC_CMD="$MAGIC_CMD"
- lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
-dnl $ac_dummy forces splitting on constant user-supplied paths.
-dnl POSIX.2 word splitting is done only on the output of word expansions,
-dnl not every word. This closes a longstanding sh security hole.
- ac_dummy="m4_if([$2], , $PATH, [$2])"
- for ac_dir in $ac_dummy; do
- IFS="$lt_save_ifs"
- test -z "$ac_dir" && ac_dir=.
- if test -f $ac_dir/$1; then
- lt_cv_path_MAGIC_CMD="$ac_dir/$1"
- if test -n "$file_magic_test_file"; then
- case $deplibs_check_method in
- "file_magic "*)
- file_magic_regex=`expr "$deplibs_check_method" : "file_magic \(.*\)"`
- MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
- if eval $file_magic_cmd \$file_magic_test_file 2> /dev/null |
- $EGREP "$file_magic_regex" > /dev/null; then
- else
- cat <<_LT_EOF 1>&2
-*** Warning: the command libtool uses to detect shared libraries,
-*** $file_magic_cmd, produces output that libtool cannot recognize.
-*** The result is that libtool may fail to recognize shared libraries
-*** as such. This will affect the creation of libtool libraries that
-*** depend on shared libraries, but programs linked with such libtool
-*** libraries will work regardless of this problem. Nevertheless, you
-*** may want to report the problem to your system manager and/or to
-*** bug-libtool at gnu.org
-_LT_EOF
- fi ;;
- esac
- fi
- break
- fi
- done
- MAGIC_CMD="$lt_save_MAGIC_CMD"
-esac])
-MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
-if test -n "$MAGIC_CMD"; then
- AC_MSG_RESULT($MAGIC_CMD)
-else
- AC_MSG_RESULT(no)
-fi
-_LT_DECL([], [MAGIC_CMD], [0],
- [Used to examine libraries when file_magic_cmd begins with "file"])dnl
-])# _LT_PATH_TOOL_PREFIX
-# Old name:
-AU_ALIAS([AC_PATH_TOOL_PREFIX], [_LT_PATH_TOOL_PREFIX])
-dnl aclocal-1.4 backwards compatibility:
-dnl AC_DEFUN([AC_PATH_TOOL_PREFIX], [])
-# _LT_PATH_MAGIC
-# find a file program which can recognize a shared library
-m4_defun([_LT_PATH_MAGIC],
-[_LT_PATH_TOOL_PREFIX(${ac_tool_prefix}file, /usr/bin$PATH_SEPARATOR$PATH)
-if test -z "$lt_cv_path_MAGIC_CMD"; then
- _LT_PATH_TOOL_PREFIX(file, /usr/bin$PATH_SEPARATOR$PATH)
- else
- MAGIC_CMD=:
- fi
-fi
-])# _LT_PATH_MAGIC
-# LT_PATH_LD
-# find the pathname to the GNU or non-GNU linker
-AC_DEFUN([LT_PATH_LD],
-AC_REQUIRE([AC_CANONICAL_HOST])dnl
-AC_REQUIRE([AC_CANONICAL_BUILD])dnl
-m4_require([_LT_PROG_ECHO_BACKSLASH])dnl
-AC_ARG_WITH([gnu-ld],
- [AS_HELP_STRING([--with-gnu-ld],
- [assume the C compiler uses GNU ld @<:@default=no@:>@])],
- [test "$withval" = no || with_gnu_ld=yes],
- [with_gnu_ld=no])dnl
-ac_prog=ld
- # Check if gcc -print-prog-name=ld gives a path.
- AC_MSG_CHECKING([for ld used by $CC])
- case $host in
- *-*-mingw*)
- # gcc leaves a trailing carriage return which upsets mingw
- ac_prog=`($CC -print-prog-name=ld) 2>&5 | tr -d '\015'` ;;
- ac_prog=`($CC -print-prog-name=ld) 2>&5` ;;
- esac
- case $ac_prog in
- # Accept absolute paths.
- re_direlt='/[[^/]][[^/]]*/\.\./'
- # Canonicalize the pathname of ld
- ac_prog=`$ECHO "$ac_prog"| $SED 's%\\\\%/%g'`
- while $ECHO "$ac_prog" | $GREP "$re_direlt" > /dev/null 2>&1; do
- ac_prog=`$ECHO $ac_prog| $SED "s%$re_direlt%/%"`
- done
- test -z "$LD" && LD="$ac_prog"
- # If it fails, then pretend we aren't using GCC.
- ac_prog=ld
- # If it is relative, then search for the first ld in PATH.
- with_gnu_ld=unknown
- esac
-elif test "$with_gnu_ld" = yes; then
- AC_MSG_CHECKING([for GNU ld])
-else
- AC_MSG_CHECKING([for non-GNU ld])
-fi
-AC_CACHE_VAL(lt_cv_path_LD,
-[if test -z "$LD"; then
- for ac_dir in $PATH; do
- if test -f "$ac_dir/$ac_prog" || test -f "$ac_dir/$ac_prog$ac_exeext"; then
- lt_cv_path_LD="$ac_dir/$ac_prog"
- # Check to see if the program is GNU ld. I'd rather use --version,
- # but apparently some variants of GNU ld only accept -v.
- # Break only if it was the GNU/non-GNU ld that we prefer.
- case `"$lt_cv_path_LD" -v 2>&1 </dev/null` in
- *GNU* | *'with BFD'*)
- test "$with_gnu_ld" != no && break
- test "$with_gnu_ld" != yes && break
- esac
- fi
- done
-else
- lt_cv_path_LD="$LD" # Let the user override the test with a path.
-fi])
-LD="$lt_cv_path_LD"
-if test -n "$LD"; then
- AC_MSG_RESULT($LD)
-else
- AC_MSG_RESULT(no)
-fi
-test -z "$LD" && AC_MSG_ERROR([no acceptable ld found in \$PATH])
-_LT_PATH_LD_GNU
-AC_SUBST([LD])
-_LT_TAGDECL([], [LD], [1], [The linker used to build libraries])
-])# LT_PATH_LD
-# Old names:
-AU_ALIAS([AM_PROG_LD], [LT_PATH_LD])
-AU_ALIAS([AC_PROG_LD], [LT_PATH_LD])
-dnl AC_DEFUN([AM_PROG_LD], [])
-dnl AC_DEFUN([AC_PROG_LD], [])
-# _LT_PATH_LD_GNU
-m4_defun([_LT_PATH_LD_GNU],
-[AC_CACHE_CHECK([if the linker ($LD) is GNU ld], lt_cv_prog_gnu_ld,
-[# I'd rather use --version here, but apparently some GNU lds only accept -v.
-case `$LD -v 2>&1 </dev/null` in
-*GNU* | *'with BFD'*)
- lt_cv_prog_gnu_ld=yes
- lt_cv_prog_gnu_ld=no
-esac])
-with_gnu_ld=$lt_cv_prog_gnu_ld
-])# _LT_PATH_LD_GNU
-# _LT_CMD_RELOAD
-# find reload flag for linker
-# -- PORTME Some linkers may need a different reload flag.
-m4_defun([_LT_CMD_RELOAD],
-[AC_CACHE_CHECK([for $LD option to reload object files],
- lt_cv_ld_reload_flag,
- [lt_cv_ld_reload_flag='-r'])
-reload_flag=$lt_cv_ld_reload_flag
-case $reload_flag in
-*) reload_flag=" $reload_flag" ;;
-esac
-reload_cmds='$LD$reload_flag -o $output$reload_objs'
-case $host_os in
- cygwin* | mingw* | pw32* | cegcc*)
- if test "$GCC" != yes; then
- reload_cmds=false
- fi
- darwin*)
- reload_cmds='$LTCC $LTCFLAGS -nostdlib ${wl}-r -o $output$reload_objs'
- else
- reload_cmds='$LD$reload_flag -o $output$reload_objs'
- fi
-esac
-_LT_TAGDECL([], [reload_flag], [1], [How to create reloadable object files])dnl
-_LT_TAGDECL([], [reload_cmds], [2])dnl
-])# _LT_CMD_RELOAD
-# _LT_CHECK_MAGIC_METHOD
-# how to check for library dependencies
-# -- PORTME fill in with the dynamic library characteristics
-m4_defun([_LT_CHECK_MAGIC_METHOD],
-AC_CACHE_CHECK([how to recognize dependent libraries],
-lt_cv_deplibs_check_method,
-[lt_cv_file_magic_cmd='$MAGIC_CMD'
-lt_cv_file_magic_test_file=
-lt_cv_deplibs_check_method='unknown'
-# Need to set the preceding variable on all platforms that support
-# interlibrary dependencies.
-# 'none' -- dependencies not supported.
-# `unknown' -- same as none, but documents that we really don't know.
-# 'pass_all' -- all dependencies passed with no checks.
-# 'test_compile' -- check by making test program.
-# 'file_magic [[regex]]' -- check by looking for files in library path
-# which responds to the $file_magic_cmd with a given extended regex.
-# If you have `file' or equivalent on your system and you're not sure
-# whether `pass_all' will *always* work, you probably want this one.
-case $host_os in
-aix[[4-9]]*)
- lt_cv_deplibs_check_method=pass_all
-beos*)
-bsdi[[45]]*)
- lt_cv_deplibs_check_method='file_magic ELF [[0-9]][[0-9]]*-bit [[ML]]SB (shared object|dynamic lib)'
- lt_cv_file_magic_cmd='/usr/bin/file -L'
- lt_cv_file_magic_test_file=/shlib/libc.so
-cygwin*)
- # func_win32_libid is a shell function defined in ltmain.sh
- lt_cv_deplibs_check_method='file_magic ^x86 archive import|^x86 DLL'
- lt_cv_file_magic_cmd='func_win32_libid'
-mingw* | pw32*)
- # Base MSYS/MinGW do not provide the 'file' command needed by
- # func_win32_libid shell function, so use a weaker test based on 'objdump',
- # unless we find 'file', for example because we are cross-compiling.
- # func_win32_libid assumes BSD nm, so disallow it if using MS dumpbin.
- if ( test "$lt_cv_nm_interface" = "BSD nm" && file / ) >/dev/null 2>&1; then
- else
- # Keep this pattern in sync with the one in func_win32_libid.
- lt_cv_deplibs_check_method='file_magic file format (pei*-i386(.*architecture: i386)?|pe-arm-wince|pe-x86-64)'
- lt_cv_file_magic_cmd='$OBJDUMP -f'
- fi
-cegcc*)
- # use the weaker test based on 'objdump'. See mingw*.
- lt_cv_deplibs_check_method='file_magic file format pe-arm-.*little(.*architecture: arm)?'
- if echo __ELF__ | $CC -E - | $GREP __ELF__ > /dev/null; then
- case $host_cpu in
- i*86 )
- # Not sure whether the presence of OpenBSD here was a mistake.
- # Let's accept both of them until this is cleared up.
- lt_cv_deplibs_check_method='file_magic (FreeBSD|OpenBSD|DragonFly)/i[[3-9]]86 (compact )?demand paged shared library'
- lt_cv_file_magic_cmd=/usr/bin/file
- lt_cv_file_magic_test_file=`echo /usr/lib/libc.so.*`
- esac
- else
- fi
-gnu*)
-haiku*)
-hpux10.20* | hpux11*)
- case $host_cpu in
- ia64*)
- lt_cv_deplibs_check_method='file_magic (s[[0-9]][[0-9]][[0-9]]|ELF-[[0-9]][[0-9]]) shared object file - IA64'
- lt_cv_file_magic_test_file=/usr/lib/hpux32/libc.so
- hppa*64*)
- [lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|ELF[ -][0-9][0-9])(-bit)?( [LM]SB)? shared object( file)?[, -]* PA-RISC [0-9]\.[0-9]']
- lt_cv_file_magic_test_file=/usr/lib/pa20_64/libc.sl
- lt_cv_deplibs_check_method='file_magic (s[[0-9]][[0-9]][[0-9]]|PA-RISC[[0-9]]\.[[0-9]]) shared library'
- lt_cv_file_magic_test_file=/usr/lib/libc.sl
- esac
-interix[[3-9]]*)
- # PIC code is broken on Interix 3.x, that's why |\.a not |_pic\.a here
- lt_cv_deplibs_check_method='match_pattern /lib[[^/]]+(\.so|\.a)$'
- case $LD in
- *-32|*"-32 ") libmagic=32-bit;;
- *-n32|*"-n32 ") libmagic=N32;;
- *-64|*"-64 ") libmagic=64-bit;;
- *) libmagic=never-match;;
- esac
-netbsd* | netbsdelf*-gnu)
- lt_cv_deplibs_check_method='match_pattern /lib[[^/]]+(\.so\.[[0-9]]+\.[[0-9]]+|_pic\.a)$'
- else
- lt_cv_deplibs_check_method='match_pattern /lib[[^/]]+(\.so|_pic\.a)$'
- fi
-newos6*)
- lt_cv_deplibs_check_method='file_magic ELF [[0-9]][[0-9]]*-bit [[ML]]SB (executable|dynamic lib)'
- lt_cv_file_magic_test_file=/usr/lib/libnls.so
-*nto* | *qnx*)
-openbsd*)
- lt_cv_deplibs_check_method='match_pattern /lib[[^/]]+(\.so\.[[0-9]]+\.[[0-9]]+|\.so|_pic\.a)$'
- else
- fi
-rdos*)
-solaris*)
-sysv4 | sysv4.3*)
- motorola)
- lt_cv_deplibs_check_method='file_magic ELF [[0-9]][[0-9]]*-bit [[ML]]SB (shared object|dynamic lib) M[[0-9]][[0-9]]* Version [[0-9]]'
- lt_cv_file_magic_test_file=`echo /usr/lib/libc.so*`
- ncr)
- sequent)
- lt_cv_file_magic_cmd='/bin/file'
- lt_cv_deplibs_check_method='file_magic ELF [[0-9]][[0-9]]*-bit [[LM]]SB (shared object|dynamic lib )'
- sni)
- lt_cv_deplibs_check_method="file_magic ELF [[0-9]][[0-9]]*-bit [[LM]]SB dynamic lib"
- lt_cv_file_magic_test_file=/lib/libc.so
- siemens)
- pc)
- esac
-tpf*)
-esac
-file_magic_glob=
-want_nocaseglob=no
-if test "$build" = "$host"; then
- case $host_os in
- mingw* | pw32*)
- if ( shopt | grep nocaseglob ) >/dev/null 2>&1; then
- want_nocaseglob=yes
- else
- file_magic_glob=`echo aAbBcCdDeEfFgGhHiIjJkKlLmMnNoOpPqQrRsStTuUvVwWxXyYzZ | $SED -e "s/\(..\)/s\/[[\1]]\/[[\1]]\/g;/g"`
- fi
- esac
-fi
-file_magic_cmd=$lt_cv_file_magic_cmd
-deplibs_check_method=$lt_cv_deplibs_check_method
-test -z "$deplibs_check_method" && deplibs_check_method=unknown
-_LT_DECL([], [deplibs_check_method], [1],
- [Method to check whether dependent libraries are shared objects])
-_LT_DECL([], [file_magic_cmd], [1],
- [Command to use when deplibs_check_method = "file_magic"])
-_LT_DECL([], [file_magic_glob], [1],
- [How to find potential files when deplibs_check_method = "file_magic"])
-_LT_DECL([], [want_nocaseglob], [1],
- [Find potential files using nocaseglob when deplibs_check_method = "file_magic"])
-])# _LT_CHECK_MAGIC_METHOD
-# LT_PATH_NM
-# find the pathname to a BSD- or MS-compatible name lister
-AC_DEFUN([LT_PATH_NM],
-[AC_REQUIRE([AC_PROG_CC])dnl
-AC_CACHE_CHECK([for BSD- or MS-compatible name lister (nm)], lt_cv_path_NM,
-[if test -n "$NM"; then
- # Let the user override the test.
- lt_cv_path_NM="$NM"
-else
- lt_nm_to_check="${ac_tool_prefix}nm"
- if test -n "$ac_tool_prefix" && test "$build" = "$host"; then
- lt_nm_to_check="$lt_nm_to_check nm"
- fi
- for lt_tmp_nm in $lt_nm_to_check; do
- for ac_dir in $PATH /usr/ccs/bin/elf /usr/ccs/bin /usr/ucb /bin; do
- tmp_nm="$ac_dir/$lt_tmp_nm"
- if test -f "$tmp_nm" || test -f "$tmp_nm$ac_exeext" ; then
- # Check to see if the nm accepts a BSD-compat flag.
- # Adding the `sed 1q' prevents false positives on HP-UX, which says:
- # nm: unknown option "B" ignored
- # Tru64's nm complains that /dev/null is an invalid object file
- case `"$tmp_nm" -B /dev/null 2>&1 | sed '1q'` in
- */dev/null* | *'Invalid file or object type'*)
- lt_cv_path_NM="$tmp_nm -B"
- break
- case `"$tmp_nm" -p /dev/null 2>&1 | sed '1q'` in
- */dev/null*)
- lt_cv_path_NM="$tmp_nm -p"
- break
- lt_cv_path_NM=${lt_cv_path_NM="$tmp_nm"} # keep the first match, but
- continue # so that we can try to find one that supports BSD flags
- esac
- esac
- fi
- done
- done
- : ${lt_cv_path_NM=no}
-fi])
-if test "$lt_cv_path_NM" != "no"; then
- NM="$lt_cv_path_NM"
-else
- # Didn't find any BSD compatible name lister, look for dumpbin.
- if test -n "$DUMPBIN"; then :
- else
- AC_CHECK_TOOLS(DUMPBIN, [dumpbin "link -dump"], :)
- case `$DUMPBIN -symbols /dev/null 2>&1 | sed '1q'` in
- *COFF*)
- DUMPBIN="$DUMPBIN -symbols"
- DUMPBIN=:
- esac
- fi
- AC_SUBST([DUMPBIN])
- if test "$DUMPBIN" != ":"; then
- NM="$DUMPBIN"
- fi
-fi
-test -z "$NM" && NM=nm
-AC_SUBST([NM])
-_LT_DECL([], [NM], [1], [A BSD- or MS-compatible name lister])dnl
-AC_CACHE_CHECK([the name lister ($NM) interface], [lt_cv_nm_interface],
- [lt_cv_nm_interface="BSD nm"
- echo "int some_variable = 0;" > conftest.$ac_ext
- (eval echo "\"\$as_me:$LINENO: $ac_compile\"" >&AS_MESSAGE_LOG_FD)
- (eval "$ac_compile" 2>conftest.err)
- cat conftest.err >&AS_MESSAGE_LOG_FD
- (eval echo "\"\$as_me:$LINENO: $NM \\\"conftest.$ac_objext\\\"\"" >&AS_MESSAGE_LOG_FD)
- (eval "$NM \"conftest.$ac_objext\"" 2>conftest.err > conftest.out)
- (eval echo "\"\$as_me:$LINENO: output\"" >&AS_MESSAGE_LOG_FD)
- cat conftest.out >&AS_MESSAGE_LOG_FD
- if $GREP 'External.*some_variable' conftest.out > /dev/null; then
- lt_cv_nm_interface="MS dumpbin"
- fi
- rm -f conftest*])
-])# LT_PATH_NM
-# Old names:
-AU_ALIAS([AM_PROG_NM], [LT_PATH_NM])
-AU_ALIAS([AC_PROG_NM], [LT_PATH_NM])
-dnl AC_DEFUN([AM_PROG_NM], [])
-dnl AC_DEFUN([AC_PROG_NM], [])
-# _LT_CHECK_SHAREDLIB_FROM_LINKLIB
-# how to determine the name of the shared library
-# associated with a specific link library.
-m4_defun([_LT_CHECK_SHAREDLIB_FROM_LINKLIB],
-m4_require([_LT_DECL_DLLTOOL])
-AC_CACHE_CHECK([how to associate runtime and link libraries],
-lt_cv_sharedlib_from_linklib_cmd,
-[lt_cv_sharedlib_from_linklib_cmd='unknown'
-case $host_os in
- # two different shell functions defined in ltmain.sh
- # decide which to use based on capabilities of $DLLTOOL
- case `$DLLTOOL --help 2>&1` in
- *--identify-strict*)
- lt_cv_sharedlib_from_linklib_cmd=func_cygming_dll_for_implib
- lt_cv_sharedlib_from_linklib_cmd=func_cygming_dll_for_implib_fallback
- esac
- # fallback: assume linklib IS sharedlib
- lt_cv_sharedlib_from_linklib_cmd="$ECHO"
-esac
-sharedlib_from_linklib_cmd=$lt_cv_sharedlib_from_linklib_cmd
-test -z "$sharedlib_from_linklib_cmd" && sharedlib_from_linklib_cmd=$ECHO
-_LT_DECL([], [sharedlib_from_linklib_cmd], [1],
- [Command to associate shared and link libraries])
-])# _LT_CHECK_SHAREDLIB_FROM_LINKLIB
-# _LT_PATH_MANIFEST_TOOL
-# locate the manifest tool
-m4_defun([_LT_PATH_MANIFEST_TOOL],
-[AC_CHECK_TOOL(MANIFEST_TOOL, mt, :)
-test -z "$MANIFEST_TOOL" && MANIFEST_TOOL=mt
-AC_CACHE_CHECK([if $MANIFEST_TOOL is a manifest tool], [lt_cv_path_mainfest_tool],
- [lt_cv_path_mainfest_tool=no
- echo "$as_me:$LINENO: $MANIFEST_TOOL '-?'" >&AS_MESSAGE_LOG_FD
- $MANIFEST_TOOL '-?' 2>conftest.err > conftest.out
- if $GREP 'Manifest Tool' conftest.out > /dev/null; then
- lt_cv_path_mainfest_tool=yes
- fi
- rm -f conftest*])
-if test "x$lt_cv_path_mainfest_tool" != xyes; then
- MANIFEST_TOOL=:
-fi
-_LT_DECL([], [MANIFEST_TOOL], [1], [Manifest tool])dnl
-])# _LT_PATH_MANIFEST_TOOL
-# LT_LIB_M
-# check for math library
-AC_DEFUN([LT_LIB_M],
-[AC_REQUIRE([AC_CANONICAL_HOST])dnl
-LIBM=
-case $host in
-*-*-beos* | *-*-cegcc* | *-*-cygwin* | *-*-haiku* | *-*-pw32* | *-*-darwin*)
- # These system don't have libm, or don't need it
-*-ncr-sysv4.3*)
- AC_CHECK_LIB(mw, _mwvalidcheckl, LIBM="-lmw")
- AC_CHECK_LIB(m, cos, LIBM="$LIBM -lm")
- AC_CHECK_LIB(m, cos, LIBM="-lm")
-esac
-AC_SUBST([LIBM])
-])# LT_LIB_M
-# Old name:
-AU_ALIAS([AC_CHECK_LIBM], [LT_LIB_M])
-dnl AC_DEFUN([AC_CHECK_LIBM], [])
-# _LT_COMPILER_NO_RTTI([TAGNAME])
-m4_defun([_LT_COMPILER_NO_RTTI],
-[m4_require([_LT_TAG_COMPILER])dnl
-_LT_TAGVAR(lt_prog_compiler_no_builtin_flag, $1)=
- case $cc_basename in
- nvcc*)
- _LT_TAGVAR(lt_prog_compiler_no_builtin_flag, $1)=' -Xcompiler -fno-builtin' ;;
- _LT_TAGVAR(lt_prog_compiler_no_builtin_flag, $1)=' -fno-builtin' ;;
- esac
- _LT_COMPILER_OPTION([if $compiler supports -fno-rtti -fno-exceptions],
- lt_cv_prog_compiler_rtti_exceptions,
- [-fno-rtti -fno-exceptions], [],
- [_LT_TAGVAR(lt_prog_compiler_no_builtin_flag, $1)="$_LT_TAGVAR(lt_prog_compiler_no_builtin_flag, $1) -fno-rtti -fno-exceptions"])
-fi
-_LT_TAGDECL([no_builtin_flag], [lt_prog_compiler_no_builtin_flag], [1],
- [Compiler flag to turn off builtin functions])
-])# _LT_COMPILER_NO_RTTI
-# _LT_CMD_GLOBAL_SYMBOLS
-m4_defun([_LT_CMD_GLOBAL_SYMBOLS],
-AC_REQUIRE([AC_PROG_CC])dnl
-AC_REQUIRE([AC_PROG_AWK])dnl
-AC_REQUIRE([LT_PATH_NM])dnl
-AC_REQUIRE([LT_PATH_LD])dnl
-m4_require([_LT_TAG_COMPILER])dnl
-# Check for command to grab the raw symbol name followed by C symbol from nm.
-AC_MSG_CHECKING([command to parse $NM output from $compiler object])
-AC_CACHE_VAL([lt_cv_sys_global_symbol_pipe],
-# These are sane defaults that work on at least a few old systems.
-# [They come from Ultrix. What could be older than Ultrix?!! ;)]
-# Character class describing NM global symbol codes.
-symcode='[[BCDEGRST]]'
-# Regexp to match symbols that can be accessed directly from C.
-sympat='\([[_A-Za-z]][[_A-Za-z0-9]]*\)'
-# Define system-specific variables.
-case $host_os in
-aix*)
- symcode='[[BCDT]]'
- symcode='[[ABCDGISTW]]'
-hpux*)
- symcode='[[ABCDEGRST]]'
- fi
-irix* | nonstopux*)
- symcode='[[BCDEGRST]]'
-osf*)
- symcode='[[BCDEGQRST]]'
-solaris*)
- symcode='[[BDRT]]'
-sco3.2v5*)
- symcode='[[DT]]'
-sysv4.2uw2*)
- symcode='[[DT]]'
-sysv5* | sco5v6* | unixware* | OpenUNIX*)
- symcode='[[ABDT]]'
-sysv4)
- symcode='[[DFNSTU]]'
-esac
-# If we're using GNU nm, then use its standard symbol codes.
-case `$NM -V 2>&1` in
- symcode='[[ABCDGIRSTW]]' ;;
-esac
-# Transform an extracted symbol line into a proper C declaration.
-# Some systems (esp. on ia64) link data and code symbols differently,
-# so use this general approach.
-lt_cv_sys_global_symbol_to_cdecl="sed -n -e 's/^T .* \(.*\)$/extern int \1();/p' -e 's/^$symcode* .* \(.*\)$/extern char \1;/p'"
-# Transform an extracted symbol line into symbol name and symbol address
-lt_cv_sys_global_symbol_to_c_name_address="sed -n -e 's/^: \([[^ ]]*\)[[ ]]*$/ {\\\"\1\\\", (void *) 0},/p' -e 's/^$symcode* \([[^ ]]*\) \([[^ ]]*\)$/ {\"\2\", (void *) \&\2},/p'"
-lt_cv_sys_global_symbol_to_c_name_address_lib_prefix="sed -n -e 's/^: \([[^ ]]*\)[[ ]]*$/ {\\\"\1\\\", (void *) 0},/p' -e 's/^$symcode* \([[^ ]]*\) \(lib[[^ ]]*\)$/ {\"\2\", (void *) \&\2},/p' -e 's/^$symcode* \([[^ ]]*\) \([[^ ]]*\)$/ {\"lib\2\", (void *) \&\2},/p'"
-# Handle CRLF in mingw tool chain
-opt_cr=
-case $build_os in
-mingw*)
- opt_cr=`$ECHO 'x\{0,1\}' | tr x '\015'` # option cr in regexp
-esac
-# Try without a prefix underscore, then with it.
-for ac_symprfx in "" "_"; do
- # Transform symcode, sympat, and symprfx into a raw symbol and a C symbol.
- symxfrm="\\1 $ac_symprfx\\2 \\2"
- # Write the raw and C identifiers.
- if test "$lt_cv_nm_interface" = "MS dumpbin"; then
- # Fake it for dumpbin and say T for any non-static function
- # and D for any global variable.
- # Also find C++ and __fastcall symbols from MSVC++,
- # which start with @ or ?.
- lt_cv_sys_global_symbol_pipe="$AWK ['"\
-" {last_section=section; section=\$ 3};"\
-" /^COFF SYMBOL TABLE/{for(i in hide) delete hide[i]};"\
-" /Section length .*#relocs.*(pick any)/{hide[last_section]=1};"\
-" \$ 0!~/External *\|/{next};"\
-" / 0+ UNDEF /{next}; / UNDEF \([^|]\)*()/{next};"\
-" {if(hide[section]) next};"\
-" {f=0}; \$ 0~/\(\).*\|/{f=1}; {printf f ? \"T \" : \"D \"};"\
-" {split(\$ 0, a, /\||\r/); split(a[2], s)};"\
-" s[1]~/^[@?]/{print s[1], s[1]; next};"\
-" s[1]~prfx {split(s[1],t,\"@\"); print t[1], substr(t[1],length(prfx))}"\
-" ' prfx=^$ac_symprfx]"
- else
- lt_cv_sys_global_symbol_pipe="sed -n -e 's/^.*[[ ]]\($symcode$symcode*\)[[ ]][[ ]]*$ac_symprfx$sympat$opt_cr$/$symxfrm/p'"
- fi
- lt_cv_sys_global_symbol_pipe="$lt_cv_sys_global_symbol_pipe | sed '/ __gnu_lto/d'"
- # Check to see that the pipe works correctly.
- pipe_works=no
- rm -f conftest*
-#ifdef __cplusplus
-extern "C" {
-#endif
-char nm_test_var;
-void nm_test_func(void);
-void nm_test_func(void){}
-#ifdef __cplusplus
-#endif
-int main(){nm_test_var='a';nm_test_func();return(0);}
-_LT_EOF
- if AC_TRY_EVAL(ac_compile); then
- # Now try to grab the symbols.
- nlist=conftest.nm
- if AC_TRY_EVAL(NM conftest.$ac_objext \| "$lt_cv_sys_global_symbol_pipe" \> $nlist) && test -s "$nlist"; then
- # Try sorting and uniquifying the output.
- if sort "$nlist" | uniq > "$nlist"T; then
- mv -f "$nlist"T "$nlist"
- else
- rm -f "$nlist"T
- fi
- # Make sure that we snagged all the symbols we need.
- if $GREP ' nm_test_var$' "$nlist" >/dev/null; then
- if $GREP ' nm_test_func$' "$nlist" >/dev/null; then
- cat <<_LT_EOF > conftest.$ac_ext
-/* Keep this code in sync between libtool.m4, ltmain, lt_system.h, and tests. */
-#if defined(_WIN32) || defined(__CYGWIN__) || defined(_WIN32_WCE)
-/* DATA imports from DLLs on WIN32 con't be const, because runtime
- relocations are performed -- see ld's documentation on pseudo-relocs. */
-# define LT@&t at _DLSYM_CONST
-#elif defined(__osf__)
-/* This system does not cope well with relocations in const data. */
-#else
-# define LT@&t at _DLSYM_CONST const
-#endif
-#ifdef __cplusplus
-extern "C" {
-#endif
-_LT_EOF
- # Now generate the symbol file.
- eval "$lt_cv_sys_global_symbol_to_cdecl"' < "$nlist" | $GREP -v main >> conftest.$ac_ext'
- cat <<_LT_EOF >> conftest.$ac_ext
-/* The mapping between symbol names and symbols. */
-LT@&t at _DLSYM_CONST struct {
- const char *name;
- void *address;
-lt__PROGRAM__LTX_preloaded_symbols[[]] =
- { "@PROGRAM@", (void *) 0 },
-_LT_EOF
- $SED "s/^$symcode$symcode* \(.*\) \(.*\)$/ {\"\2\", (void *) \&\2},/" < "$nlist" | $GREP -v main >> conftest.$ac_ext
- cat <<\_LT_EOF >> conftest.$ac_ext
- {0, (void *) 0}
-/* This works around a problem in FreeBSD linker */
-#ifdef FREEBSD_WORKAROUND
-static const void *lt_preloaded_setup() {
- return lt__PROGRAM__LTX_preloaded_symbols;
-#endif
-#ifdef __cplusplus
-#endif
-_LT_EOF
- # Now try linking the two files.
- mv conftest.$ac_objext conftstm.$ac_objext
- lt_globsym_save_LIBS=$LIBS
- lt_globsym_save_CFLAGS=$CFLAGS
- LIBS="conftstm.$ac_objext"
- CFLAGS="$CFLAGS$_LT_TAGVAR(lt_prog_compiler_no_builtin_flag, $1)"
- if AC_TRY_EVAL(ac_link) && test -s conftest${ac_exeext}; then
- pipe_works=yes
- fi
- LIBS=$lt_globsym_save_LIBS
- CFLAGS=$lt_globsym_save_CFLAGS
- else
- echo "cannot find nm_test_func in $nlist" >&AS_MESSAGE_LOG_FD
- fi
- else
- echo "cannot find nm_test_var in $nlist" >&AS_MESSAGE_LOG_FD
- fi
- else
- echo "cannot run $lt_cv_sys_global_symbol_pipe" >&AS_MESSAGE_LOG_FD
- fi
- else
- echo "$progname: failed program was:" >&AS_MESSAGE_LOG_FD
- cat conftest.$ac_ext >&5
- fi
- rm -rf conftest* conftst*
- # Do not use the global_symbol_pipe unless it works.
- if test "$pipe_works" = yes; then
- break
- else
- fi
-done
-if test -z "$lt_cv_sys_global_symbol_pipe"; then
- lt_cv_sys_global_symbol_to_cdecl=
-fi
-if test -z "$lt_cv_sys_global_symbol_pipe$lt_cv_sys_global_symbol_to_cdecl"; then
- AC_MSG_RESULT(failed)
-else
- AC_MSG_RESULT(ok)
-fi
-# Response file support.
-if test "$lt_cv_nm_interface" = "MS dumpbin"; then
- nm_file_list_spec='@'
-elif $NM --help 2>/dev/null | grep '[[@]]FILE' >/dev/null; then
-fi
-_LT_DECL([global_symbol_pipe], [lt_cv_sys_global_symbol_pipe], [1],
- [Take the output of nm and produce a listing of raw symbols and C names])
-_LT_DECL([global_symbol_to_cdecl], [lt_cv_sys_global_symbol_to_cdecl], [1],
- [Transform the output of nm in a proper C declaration])
-_LT_DECL([global_symbol_to_c_name_address],
- [lt_cv_sys_global_symbol_to_c_name_address], [1],
- [Transform the output of nm in a C name address pair])
-_LT_DECL([global_symbol_to_c_name_address_lib_prefix],
- [lt_cv_sys_global_symbol_to_c_name_address_lib_prefix], [1],
- [Transform the output of nm in a C name address pair when lib prefix is needed])
-_LT_DECL([], [nm_file_list_spec], [1],
- [Specify filename containing input files for $NM])
-]) # _LT_CMD_GLOBAL_SYMBOLS
-# _LT_COMPILER_PIC([TAGNAME])
-m4_defun([_LT_COMPILER_PIC],
-_LT_TAGVAR(lt_prog_compiler_wl, $1)=
-_LT_TAGVAR(lt_prog_compiler_pic, $1)=
-_LT_TAGVAR(lt_prog_compiler_static, $1)=
-m4_if([$1], [CXX], [
- # C++ specific cases for pic, static, wl, etc.
- if test "$GXX" = yes; then
- _LT_TAGVAR(lt_prog_compiler_wl, $1)='-Wl,'
- _LT_TAGVAR(lt_prog_compiler_static, $1)='-static'
- case $host_os in
- aix*)
- # All AIX code is PIC.
- # AIX 5 now supports IA64 processor
- _LT_TAGVAR(lt_prog_compiler_static, $1)='-Bstatic'
- fi
- amigaos*)
- case $host_cpu in
- powerpc)
- # see comment about AmigaOS4 .so support
- _LT_TAGVAR(lt_prog_compiler_pic, $1)='-fPIC'
- m68k)
- # FIXME: we need at least 68020 code to build shared libraries, but
- # adding the `-m68020' flag to GCC prevents building anything better,
- # like `-m68040'.
- _LT_TAGVAR(lt_prog_compiler_pic, $1)='-m68020 -resident32 -malways-restore-a4'
- esac
- beos* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
- # PIC is the default for these OSes.
- mingw* | cygwin* | os2* | pw32* | cegcc*)
- # This hack is so that the source file can tell whether it is being
- # built for inclusion in a dll (and should export symbols for example).
- # Although the cygwin gcc ignores -fPIC, still need this for old-style
- # (--disable-auto-import) libraries
- m4_if([$1], [GCJ], [],
- [_LT_TAGVAR(lt_prog_compiler_pic, $1)='-DDLL_EXPORT'])
- darwin* | rhapsody*)
- # PIC is the default on this platform
- # Common symbols not allowed in MH_DYLIB files
- _LT_TAGVAR(lt_prog_compiler_pic, $1)='-fno-common'
- *djgpp*)
- # DJGPP does not support shared libraries at all
- haiku*)
- # PIC is the default for Haiku.
- # The "-static" flag exists, but is broken.
- interix[[3-9]]*)
- # Interix 3.x gcc -fpic/-fPIC options generate broken code.
- # Instead, we relocate shared libraries at runtime.
- sysv4*MP*)
- if test -d /usr/nec; then
- _LT_TAGVAR(lt_prog_compiler_pic, $1)=-Kconform_pic
- fi
- hpux*)
- # PIC is the default for 64-bit PA HP-UX, but not for 32-bit
- # PA HP-UX. On IA64 HP-UX, PIC is the default but the pic flag
- # sets the default TLS model and affects inlining.
- case $host_cpu in
- hppa*64*)
- esac
- *qnx* | *nto*)
- # QNX uses GNU C++, but need to define -shared option too, otherwise
- # it will coredump.
- _LT_TAGVAR(lt_prog_compiler_pic, $1)='-fPIC -shared'
- esac
- else
- case $host_os in
- aix[[4-9]]*)
- else
- _LT_TAGVAR(lt_prog_compiler_static, $1)='-bnso -bI:/lib/syscalls.exp'
- fi
- chorus*)
- cxch68*)
- # Green Hills C++ Compiler
- # _LT_TAGVAR(lt_prog_compiler_static, $1)="--no_auto_instantiation -u __main -u __premain -u _abort -r $COOL_DIR/lib/libOrb.a $MVME_DIR/lib/CC/libC.a $MVME_DIR/lib/classix/libcx.s.a"
- esac
- dgux*)
- ec++*)
- _LT_TAGVAR(lt_prog_compiler_pic, $1)='-KPIC'
- ghcx*)
- _LT_TAGVAR(lt_prog_compiler_pic, $1)='-pic'
- esac
- freebsd* | dragonfly*)
- # FreeBSD uses GNU C++
- hpux9* | hpux10* | hpux11*)
- CC*)
- _LT_TAGVAR(lt_prog_compiler_static, $1)='${wl}-a ${wl}archive'
- if test "$host_cpu" != ia64; then
- _LT_TAGVAR(lt_prog_compiler_pic, $1)='+Z'
- fi
- aCC*)
- case $host_cpu in
- hppa*64*|ia64*)
- # +Z the default
- esac
- esac
- interix*)
- # This is c89, which is MS Visual C++ (no shared libs)
- # Anyone wants to do a port?
- irix5* | irix6* | nonstopux*)
- CC*)
- _LT_TAGVAR(lt_prog_compiler_static, $1)='-non_shared'
- # CC pic flag -KPIC is the default.
- esac
- linux* | k*bsd*-gnu | kopensolaris*-gnu)
- KCC*)
- # KAI C++ Compiler
- _LT_TAGVAR(lt_prog_compiler_wl, $1)='--backend -Wl,'
- ecpc* )
- # old Intel C++ for x86_64 which still supported -KPIC.
- icpc* )
- # Intel C++, used to be incompatible with GCC.
- # ICC 10 doesn't accept -KPIC any more.
- pgCC* | pgcpp*)
- # Portland Group C++ compiler
- _LT_TAGVAR(lt_prog_compiler_pic, $1)='-fpic'
- cxx*)
- # Compaq C++
- # Make sure the PIC flag is empty. It appears that all Alpha
- # Linux and Compaq Tru64 Unix objects are PIC.
- xlc* | xlC* | bgxl[[cC]]* | mpixl[[cC]]*)
- # IBM XL 8.0, 9.0 on PPC and BlueGene
- _LT_TAGVAR(lt_prog_compiler_pic, $1)='-qpic'
- _LT_TAGVAR(lt_prog_compiler_static, $1)='-qstaticlink'
- case `$CC -V 2>&1 | sed 5q` in
- *Sun\ C*)
- # Sun C++ 5.9
- _LT_TAGVAR(lt_prog_compiler_wl, $1)='-Qoption ld '
- esac
- esac
- lynxos*)
- m88k*)
- mvs*)
- cxx*)
- _LT_TAGVAR(lt_prog_compiler_pic, $1)='-W c,exportall'
- esac
- netbsd* | netbsdelf*-gnu)
- *qnx* | *nto*)
- osf3* | osf4* | osf5*)
- KCC*)
- RCC*)
- # Rational C++ 2.4.1
- cxx*)
- # Digital/Compaq C++
- esac
- psos*)
- solaris*)
- CC* | sunCC*)
- # Sun C++ 4.2, 5.x and Centerline C++
- gcx*)
- _LT_TAGVAR(lt_prog_compiler_pic, $1)='-PIC'
- esac
- sunos4*)
- CC*)
- # Sun C++ 4.x
- lcc*)
- # Lucid
- esac
- sysv5* | unixware* | sco3.2v5* | sco5v6* | OpenUNIX*)
- CC*)
- esac
- tandem*)
- NCC*)
- # NonStop-UX NCC 3.20
- esac
- vxworks*)
- _LT_TAGVAR(lt_prog_compiler_can_build_shared, $1)=no
- esac
- fi
- if test "$GCC" = yes; then
- case $host_os in
- aix*)
- fi
- amigaos*)
- case $host_cpu in
- powerpc)
- m68k)
- # like `-m68040'.
- esac
- mingw* | cygwin* | pw32* | os2* | cegcc*)
- haiku*)
- hpux*)
- case $host_cpu in
- hppa*64*)
- # +Z the default
- esac
- interix[[3-9]]*)
- msdosdjgpp*)
- # Just because we use GCC doesn't mean we suddenly get shared libraries
- # on systems that don't support them.
- enable_shared=no
- *nto* | *qnx*)
- sysv4*MP*)
- fi
- esac
- nvcc*) # Cuda Compiler Driver 2.2
- _LT_TAGVAR(lt_prog_compiler_wl, $1)='-Xlinker '
- if test -n "$_LT_TAGVAR(lt_prog_compiler_pic, $1)"; then
- _LT_TAGVAR(lt_prog_compiler_pic, $1)="-Xcompiler $_LT_TAGVAR(lt_prog_compiler_pic, $1)"
- fi
- esac
- else
- # PORTME Check for flag to pass linker flags through the system compiler.
- case $host_os in
- aix*)
- else
- fi
- # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
- # not for PA HP-UX.
- case $host_cpu in
- hppa*64*|ia64*)
- # +Z the default
- esac
- # Is there a better lt_prog_compiler_static that works with the bundled CC?
- # PIC (with -KPIC) is the default.
- # old Intel for x86_64 which still supported -KPIC.
- ecc*)
- # icc used to be incompatible with GCC.
- icc* | ifort*)
- # Lahey Fortran 8.1.
- lf95*)
- _LT_TAGVAR(lt_prog_compiler_pic, $1)='--shared'
- _LT_TAGVAR(lt_prog_compiler_static, $1)='--static'
- nagfor*)
- # NAG Fortran compiler
- _LT_TAGVAR(lt_prog_compiler_wl, $1)='-Wl,-Wl,,'
- pgcc* | pgf77* | pgf90* | pgf95* | pgfortran*)
- # Portland Group compilers (*not* the Pentium gcc compiler,
- # which looks to be a dead project)
- ccc*)
- # All Alpha code is PIC.
- xl* | bgxl* | bgf* | mpixl*)
- # IBM XL C 8.0/Fortran 10.1, 11.1 on PPC and BlueGene
- *Sun\ Ceres\ Fortran* | *Sun*Fortran*\ [[1-7]].* | *Sun*Fortran*\ 8.[[0-3]]*)
- # Sun Fortran 8.3 passes all unrecognized flags to the linker
- _LT_TAGVAR(lt_prog_compiler_wl, $1)=''
- *Sun\ F* | *Sun*Fortran*)
- *Sun\ C*)
- # Sun C 5.9
- *Intel*\ [[CF]]*Compiler*)
- *Portland\ Group*)
- esac
- esac
- newsos6)
- *nto* | *qnx*)
- # All OSF/1 code is PIC.
- rdos*)
- solaris*)
- f77* | f90* | f95* | sunf77* | sunf90* | sunf95*)
- _LT_TAGVAR(lt_prog_compiler_wl, $1)='-Qoption ld ';;
- _LT_TAGVAR(lt_prog_compiler_wl, $1)='-Wl,';;
- esac
- sunos4*)
- sysv4 | sysv4.2uw2* | sysv4.3*)
- sysv4*MP*)
- _LT_TAGVAR(lt_prog_compiler_pic, $1)='-Kconform_pic'
- fi
- unicos*)
- uts4*)
- esac
- fi
-case $host_os in
- # For platforms which do not support PIC, -DPIC is meaningless:
- *djgpp*)
- _LT_TAGVAR(lt_prog_compiler_pic, $1)="$_LT_TAGVAR(lt_prog_compiler_pic, $1)@&t at m4_if([$1],[],[ -DPIC],[m4_if([$1],[CXX],[ -DPIC],[])])"
-esac
-AC_CACHE_CHECK([for $compiler option to produce PIC],
- [_LT_TAGVAR(lt_cv_prog_compiler_pic, $1)],
- [_LT_TAGVAR(lt_cv_prog_compiler_pic, $1)=$_LT_TAGVAR(lt_prog_compiler_pic, $1)])
-_LT_TAGVAR(lt_prog_compiler_pic, $1)=$_LT_TAGVAR(lt_cv_prog_compiler_pic, $1)
-# Check to make sure the PIC flag actually works.
-if test -n "$_LT_TAGVAR(lt_prog_compiler_pic, $1)"; then
- _LT_COMPILER_OPTION([if $compiler PIC flag $_LT_TAGVAR(lt_prog_compiler_pic, $1) works],
- [_LT_TAGVAR(lt_cv_prog_compiler_pic_works, $1)],
- [$_LT_TAGVAR(lt_prog_compiler_pic, $1)@&t at m4_if([$1],[],[ -DPIC],[m4_if([$1],[CXX],[ -DPIC],[])])], [],
- [case $_LT_TAGVAR(lt_prog_compiler_pic, $1) in
- *) _LT_TAGVAR(lt_prog_compiler_pic, $1)=" $_LT_TAGVAR(lt_prog_compiler_pic, $1)" ;;
- esac],
- _LT_TAGVAR(lt_prog_compiler_can_build_shared, $1)=no])
-fi
-_LT_TAGDECL([pic_flag], [lt_prog_compiler_pic], [1],
- [Additional compiler flags for building library objects])
-_LT_TAGDECL([wl], [lt_prog_compiler_wl], [1],
- [How to pass a linker flag through the compiler])
-# Check to make sure the static flag actually works.
-wl=$_LT_TAGVAR(lt_prog_compiler_wl, $1) eval lt_tmp_static_flag=\"$_LT_TAGVAR(lt_prog_compiler_static, $1)\"
-_LT_LINKER_OPTION([if $compiler static flag $lt_tmp_static_flag works],
- _LT_TAGVAR(lt_cv_prog_compiler_static_works, $1),
- $lt_tmp_static_flag,
- [_LT_TAGVAR(lt_prog_compiler_static, $1)=])
-_LT_TAGDECL([link_static_flag], [lt_prog_compiler_static], [1],
- [Compiler flag to prevent dynamic linking])
-])# _LT_COMPILER_PIC
-# _LT_LINKER_SHLIBS([TAGNAME])
-# See if the linker supports building shared libraries.
-m4_defun([_LT_LINKER_SHLIBS],
-[AC_REQUIRE([LT_PATH_LD])dnl
-m4_require([_LT_PATH_MANIFEST_TOOL])dnl
-m4_require([_LT_FILEUTILS_DEFAULTS])dnl
-m4_require([_LT_DECL_SED])dnl
-m4_require([_LT_CMD_GLOBAL_SYMBOLS])dnl
-AC_MSG_CHECKING([whether the $compiler linker ($LD) supports shared libraries])
- _LT_TAGVAR(export_symbols_cmds, $1)='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
- _LT_TAGVAR(exclude_expsyms, $1)=['_GLOBAL_OFFSET_TABLE_|_GLOBAL__F[ID]_.*']
- case $host_os in
- aix[[4-9]]*)
- # If we're using GNU nm, then we don't want the "-C" option.
- # -C means demangle to AIX nm, but means don't demangle with GNU nm
- # Also, AIX nm treats weak defined symbols like other global defined
- # symbols, whereas GNU nm marks them as "W".
- if $NM -V 2>&1 | $GREP 'GNU' > /dev/null; then
- _LT_TAGVAR(export_symbols_cmds, $1)='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$ 2 == "T") || (\$ 2 == "D") || (\$ 2 == "B") || (\$ 2 == "W")) && ([substr](\$ 3,1,1) != ".")) { print \$ 3 } }'\'' | sort -u > $export_symbols'
- else
- _LT_TAGVAR(export_symbols_cmds, $1)='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$ 2 == "T") || (\$ 2 == "D") || (\$ 2 == "B")) && ([substr](\$ 3,1,1) != ".")) { print \$ 3 } }'\'' | sort -u > $export_symbols'
- fi
- pw32*)
- _LT_TAGVAR(export_symbols_cmds, $1)="$ltdll_cmds"
- cygwin* | mingw* | cegcc*)
- cl*)
- _LT_TAGVAR(exclude_expsyms, $1)='_NULL_IMPORT_DESCRIPTOR|_IMPORT_DESCRIPTOR_.*'
- _LT_TAGVAR(export_symbols_cmds, $1)='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[[BCDGRS]][[ ]]/s/.*[[ ]]\([[^ ]]*\)/\1 DATA/;s/^.*[[ ]]__nm__\([[^ ]]*\)[[ ]][[^ ]]*/\1 DATA/;/^I[[ ]]/d;/^[[AITW]][[ ]]/s/.* //'\'' | sort | uniq > $export_symbols'
- _LT_TAGVAR(exclude_expsyms, $1)=['[_]+GLOBAL_OFFSET_TABLE_|[_]+GLOBAL__[FID]_.*|[_]+head_[A-Za-z0-9_]+_dll|[A-Za-z0-9_]+_dll_iname']
- esac
- linux* | k*bsd*-gnu | gnu*)
- _LT_TAGVAR(link_all_deplibs, $1)=no
- esac
- runpath_var=
- _LT_TAGVAR(allow_undefined_flag, $1)=
- _LT_TAGVAR(always_export_symbols, $1)=no
- _LT_TAGVAR(archive_cmds, $1)=
- _LT_TAGVAR(archive_expsym_cmds, $1)=
- _LT_TAGVAR(compiler_needs_object, $1)=no
- _LT_TAGVAR(enable_shared_with_static_runtimes, $1)=no
- _LT_TAGVAR(export_dynamic_flag_spec, $1)=
- _LT_TAGVAR(hardcode_automatic, $1)=no
- _LT_TAGVAR(hardcode_direct, $1)=no
- _LT_TAGVAR(hardcode_direct_absolute, $1)=no
- _LT_TAGVAR(hardcode_libdir_flag_spec, $1)=
- _LT_TAGVAR(hardcode_libdir_separator, $1)=
- _LT_TAGVAR(hardcode_minus_L, $1)=no
- _LT_TAGVAR(hardcode_shlibpath_var, $1)=unsupported
- _LT_TAGVAR(inherit_rpath, $1)=no
- _LT_TAGVAR(link_all_deplibs, $1)=unknown
- _LT_TAGVAR(module_cmds, $1)=
- _LT_TAGVAR(module_expsym_cmds, $1)=
- _LT_TAGVAR(old_archive_from_new_cmds, $1)=
- _LT_TAGVAR(old_archive_from_expsyms_cmds, $1)=
- _LT_TAGVAR(thread_safe_flag_spec, $1)=
- _LT_TAGVAR(whole_archive_flag_spec, $1)=
- # include_expsyms should be a list of space-separated symbols to be *always*
- # included in the symbol list
- _LT_TAGVAR(include_expsyms, $1)=
- # exclude_expsyms can be an extended regexp of symbols to exclude
- # it will be wrapped by ` (' and `)$', so one must not match beginning or
- # end of line. Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
- # as well as any symbol that contains `d'.
- # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
- # platforms (ab)use it in PIC code, but their linkers get confused if
- # the symbol is explicitly referenced. Since portable code cannot
- # rely on this symbol name, it's probably fine to never include it in
- # preloaded symbol tables.
- # Exclude shared library initialization/finalization symbols.
-dnl Note also adjust exclude_expsyms for C++ above.
- extract_expsyms_cmds=
- case $host_os in
- # FIXME: the MSVC++ port hasn't been tested in a loooong time
- # When not using gcc, we currently assume that we are using
- # Microsoft Visual C++.
- with_gnu_ld=no
- fi
- interix*)
- # we just hope/assume this is gcc and not c89 (= MSVC++)
- with_gnu_ld=yes
- openbsd*)
- with_gnu_ld=no
- esac
- _LT_TAGVAR(ld_shlibs, $1)=yes
- # On some targets, GNU ld is compatible enough with the native linker
- # that we're better off using the native interface for both.
- lt_use_gnu_ld_interface=no
- case $host_os in
- aix*)
- # The AIX port of GNU ld has always aspired to compatibility
- # with the native linker. However, as the warning in the GNU ld
- # block says, versions before 2.19.5* couldn't really create working
- # shared libraries, regardless of the interface used.
- case `$LD -v 2>&1` in
- *\ \(GNU\ Binutils\)\ 2.19.5*) ;;
- *\ \(GNU\ Binutils\)\ 2.[[2-9]]*) ;;
- *\ \(GNU\ Binutils\)\ [[3-9]]*) ;;
- lt_use_gnu_ld_interface=yes
- esac
- esac
- fi
- if test "$lt_use_gnu_ld_interface" = yes; then
- # If archive_cmds runs LD, not CC, wlarc should be empty
- wlarc='${wl}'
- # Set some defaults for GNU ld with shared library support. These
- # are reset later if shared libraries are not supported. Putting them
- # here allows them to be overridden if necessary.
- _LT_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}-rpath ${wl}$libdir'
- _LT_TAGVAR(export_dynamic_flag_spec, $1)='${wl}--export-dynamic'
- # ancient GNU ld didn't support --whole-archive et. al.
- if $LD --help 2>&1 | $GREP 'no-whole-archive' > /dev/null; then
- _LT_TAGVAR(whole_archive_flag_spec, $1)="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
- else
- fi
- supports_anon_versioning=no
- *GNU\ gold*) supports_anon_versioning=yes ;;
- *\ [[01]].* | *\ 2.[[0-9]].* | *\ 2.10.*) ;; # catch versions < 2.11
- *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
- *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
- *\ 2.11.*) ;; # other 2.11 versions
- *) supports_anon_versioning=yes ;;
- esac
- # See if GNU ld supports shared libraries.
- case $host_os in
- aix[[3-9]]*)
- # On AIX/PPC, the GNU linker is very broken
- _LT_TAGVAR(ld_shlibs, $1)=no
-*** Warning: the GNU linker, at least up to release 2.19, is reported
-*** to be unable to reliably create shared libraries on AIX.
-*** Therefore, libtool is disabling shared libraries support. If you
-*** really care for shared libraries, you may want to install binutils
-*** 2.20 or above, or modify your PATH so that a non-GNU linker is found.
-*** You will then need to restart the configuration process.
-_LT_EOF
- fi
- amigaos*)
- case $host_cpu in
- powerpc)
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- _LT_TAGVAR(archive_expsym_cmds, $1)=''
- m68k)
- _LT_TAGVAR(archive_cmds, $1)='$RM $output_objdir/a2ixlibrary.data~$ECHO "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$ECHO "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$ECHO "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$ECHO "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
- _LT_TAGVAR(hardcode_libdir_flag_spec, $1)='-L$libdir'
- _LT_TAGVAR(hardcode_minus_L, $1)=yes
- esac
- beos*)
- if $LD --help 2>&1 | $GREP ': supported targets:.* elf' > /dev/null; then
- _LT_TAGVAR(allow_undefined_flag, $1)=unsupported
- # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
- # support --undefined. This deserves some investigation. FIXME
- _LT_TAGVAR(archive_cmds, $1)='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- else
- fi
- # _LT_TAGVAR(hardcode_libdir_flag_spec, $1) is actually meaningless,
- # as there is no search path for DLLs.
- _LT_TAGVAR(export_dynamic_flag_spec, $1)='${wl}--export-all-symbols'
- _LT_TAGVAR(enable_shared_with_static_runtimes, $1)=yes
- if $LD --help 2>&1 | $GREP 'auto-import' > /dev/null; then
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
- # If the export-symbols file already is a .def file (1st line
- # is EXPORTS), use it as is; otherwise, prepend...
- _LT_TAGVAR(archive_expsym_cmds, $1)='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
- cp $export_symbols $output_objdir/$soname.def;
- else
- echo EXPORTS > $output_objdir/$soname.def;
- cat $export_symbols >> $output_objdir/$soname.def;
- fi~
- $CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
- else
- fi
- haiku*)
- _LT_TAGVAR(link_all_deplibs, $1)=yes
- interix[[3-9]]*)
- _LT_TAGVAR(hardcode_shlibpath_var, $1)=no
- _LT_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}-rpath,$libdir'
- _LT_TAGVAR(export_dynamic_flag_spec, $1)='${wl}-E'
- # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
- # Instead, shared libraries are loaded at an image base (0x10000000 by
- # default) and relocated if they conflict, which is a slow very memory
- # consuming and fragmenting process. To avoid this, we pick a random,
- # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
- # time. Moving up from 0x10000000 also allows more sbrk(2) space.
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
- _LT_TAGVAR(archive_expsym_cmds, $1)='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
- gnu* | linux* | tpf* | k*bsd*-gnu | kopensolaris*-gnu)
- tmp_diet=no
- if test "$host_os" = linux-dietlibc; then
- diet\ *) tmp_diet=yes;; # linux-dietlibc with static linking (!diet-dyn)
- esac
- fi
- if $LD --help 2>&1 | $EGREP ': supported targets:.* elf' > /dev/null \
- && test "$tmp_diet" = no
- then
- tmp_addflag=' $pic_flag'
- tmp_sharedflag='-shared'
- case $cc_basename,$host_cpu in
- pgcc*) # Portland Group C compiler
- _LT_TAGVAR(whole_archive_flag_spec, $1)='${wl}--whole-archive`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; func_echo_all \"$new_convenience\"` ${wl}--no-whole-archive'
- pgf77* | pgf90* | pgf95* | pgfortran*)
- # Portland Group f77 and f90 compilers
- tmp_addflag=' $pic_flag -Mnomain' ;;
- ecc*,ia64* | icc*,ia64*) # Intel C compiler on ia64
- tmp_addflag=' -i_dynamic' ;;
- efc*,ia64* | ifort*,ia64*) # Intel Fortran compiler on ia64
- tmp_addflag=' -i_dynamic -nofor_main' ;;
- ifc* | ifort*) # Intel Fortran compiler
- tmp_addflag=' -nofor_main' ;;
- lf95*) # Lahey Fortran 8.1
- tmp_sharedflag='--shared' ;;
- xl[[cC]]* | bgxl[[cC]]* | mpixl[[cC]]*) # IBM XL C 8.0 on PPC (deal with xlf below)
- tmp_sharedflag='-qmkshrobj'
- tmp_addflag= ;;
- _LT_TAGVAR(compiler_needs_object, $1)=yes
- esac
- *Sun\ C*) # Sun C 5.9
- _LT_TAGVAR(whole_archive_flag_spec, $1)='${wl}--whole-archive`new_convenience=; for conv in $convenience\"\"; do test -z \"$conv\" || new_convenience=\"$new_convenience,$conv\"; done; func_echo_all \"$new_convenience\"` ${wl}--no-whole-archive'
- tmp_sharedflag='-G' ;;
- *Sun\ F*) # Sun Fortran 8.3
- esac
- _LT_TAGVAR(archive_cmds, $1)='$CC '"$tmp_sharedflag""$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- if test "x$supports_anon_versioning" = xyes; then
- _LT_TAGVAR(archive_expsym_cmds, $1)='echo "{ global:" > $output_objdir/$libname.ver~
- cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
- echo "local: *; };" >> $output_objdir/$libname.ver~
- $CC '"$tmp_sharedflag""$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
- fi
- xlf* | bgf* | bgxlf* | mpixlf*)
- # IBM XL Fortran 10.1 on PPC cannot create shared libs itself
- _LT_TAGVAR(whole_archive_flag_spec, $1)='--whole-archive$convenience --no-whole-archive'
- _LT_TAGVAR(archive_cmds, $1)='$LD -shared $libobjs $deplibs $linker_flags -soname $soname -o $lib'
- $LD -shared $libobjs $deplibs $linker_flags -soname $soname -version-script $output_objdir/$libname.ver -o $lib'
- fi
- esac
- else
- fi
- _LT_TAGVAR(archive_cmds, $1)='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
- wlarc=
- else
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- _LT_TAGVAR(archive_expsym_cmds, $1)='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- fi
- solaris*)
- if $LD -v 2>&1 | $GREP 'BFD 2\.8' > /dev/null; then
-*** Warning: The releases 2.8.* of the GNU linker cannot reliably
-*** create shared libraries on Solaris systems. Therefore, libtool
-*** is disabling shared libraries support. We urge you to upgrade GNU
-*** binutils to release 2.9.1 or newer. Another option is to modify
-*** your PATH or compiler configuration so that the native linker is
-*** used, and then restart.
-_LT_EOF
- elif $LD --help 2>&1 | $GREP ': supported targets:.* elf' > /dev/null; then
- else
- fi
- sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX*)
- *\ [[01]].* | *\ 2.[[0-9]].* | *\ 2.1[[0-5]].*)
-*** Warning: Releases of the GNU linker prior to 2.16.91.0.3 can not
-*** reliably create shared libraries on SCO systems. Therefore, libtool
-*** binutils to release 2.16.91.0.3 or newer. Another option is to modify
-_LT_EOF
- # For security reasons, it is highly recommended that you always
- # use absolute paths for naming shared libraries, and exclude the
- # DT_RUNPATH tag from executables and libraries. But doing so
- # requires that you compile everything twice, which is a pain.
- _LT_TAGVAR(archive_expsym_cmds, $1)='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- else
- fi
- esac
- sunos4*)
- _LT_TAGVAR(archive_cmds, $1)='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- wlarc=
- _LT_TAGVAR(hardcode_direct, $1)=yes
- else
- fi
- esac
- if test "$_LT_TAGVAR(ld_shlibs, $1)" = no; then
- runpath_var=
- fi
- else
- # PORTME fill in a description of your system's linker (not GNU ld)
- case $host_os in
- aix3*)
- _LT_TAGVAR(always_export_symbols, $1)=yes
- _LT_TAGVAR(archive_expsym_cmds, $1)='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
- # Note: this linker hardcodes the directories in LIBPATH if there
- # are no directories specified by -L.
- if test "$GCC" = yes && test -z "$lt_prog_compiler_static"; then
- # Neither direct hardcoding nor static linking is supported with a
- # broken collect2.
- _LT_TAGVAR(hardcode_direct, $1)=unsupported
- fi
- aix[[4-9]]*)
- if test "$host_cpu" = ia64; then
- # On IA64, the linker does run time linking by default, so we don't
- # have to do anything special.
- aix_use_runtimelinking=no
- exp_sym_flag='-Bexport'
- no_entry_flag=""
- else
- # defined symbols, whereas GNU nm marks them as "W".
- else
- fi
- # Test if we are trying to use run time linking or normal
- # AIX style linking. If -brtl is somewhere in LDFLAGS, we
- # need to do runtime linking.
- case $host_os in aix4.[[23]]|aix4.[[23]].*|aix[[5-9]]*)
- for ld_flag in $LDFLAGS; do
- if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
- aix_use_runtimelinking=yes
- break
- fi
- done
- esac
- exp_sym_flag='-bexport'
- no_entry_flag='-bnoentry'
- fi
- # When large executables or shared objects are built, AIX ld can
- # have problems creating the table of contents. If linking a library
- # or program results in "error TOC overflow" add -mminimal-toc to
- # CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
- # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
- _LT_TAGVAR(archive_cmds, $1)=''
- _LT_TAGVAR(hardcode_direct_absolute, $1)=yes
- _LT_TAGVAR(hardcode_libdir_separator, $1)=':'
- _LT_TAGVAR(file_list_spec, $1)='${wl}-f,'
- case $host_os in aix4.[[012]]|aix4.[[012]].*)
- # We only want to do this on AIX 4.2 and lower, the check
- # below for broken collect2 doesn't work under 4.3+
- collect2name=`${CC} -print-prog-name=collect2`
- if test -f "$collect2name" &&
- strings "$collect2name" | $GREP resolve_lib_name >/dev/null
- then
- # We have reworked collect2
- else
- # We have old collect2
- # It fails to find uninstalled libraries when the uninstalled
- # path is not listed in the libpath. Setting hardcode_minus_L
- # to unsupported forces relinking
- fi
- esac
- shared_flag='-shared'
- if test "$aix_use_runtimelinking" = yes; then
- shared_flag="$shared_flag "'${wl}-G'
- fi
- else
- # not using gcc
- # VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
- # chokes on -Wl,-G. The following line is correct:
- shared_flag='-G'
- else
- shared_flag='${wl}-G'
- else
- shared_flag='${wl}-bM:SRE'
- fi
- fi
- fi
- _LT_TAGVAR(export_dynamic_flag_spec, $1)='${wl}-bexpall'
- # It seems that -bexpall does not export symbols beginning with
- # underscore (_), so it is better to generate a list of symbols to export.
- # Warning - without using the other runtime loading flags (-brtl),
- # -berok will link without error, but may produce a broken library.
- _LT_TAGVAR(allow_undefined_flag, $1)='-berok'
- # Determine the default libpath from the value encoded in an
- # empty executable.
- _LT_SYS_MODULE_PATH_AIX([$1])
- _LT_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}-blibpath:$libdir:'"$aix_libpath"
- _LT_TAGVAR(archive_expsym_cmds, $1)='$CC -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then func_echo_all "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
- else
- _LT_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}-R $libdir:/usr/lib:/lib'
- _LT_TAGVAR(allow_undefined_flag, $1)="-z nodefs"
- _LT_TAGVAR(archive_expsym_cmds, $1)="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
- else
- # Warning - without using the other run time loading flags,
- _LT_TAGVAR(no_undefined_flag, $1)=' ${wl}-bernotok'
- _LT_TAGVAR(allow_undefined_flag, $1)=' ${wl}-berok'
- # We only use this code for GNU lds that support --whole-archive.
- _LT_TAGVAR(whole_archive_flag_spec, $1)='${wl}--whole-archive$convenience ${wl}--no-whole-archive'
- else
- # Exported symbols can be pulled into shared objects from archives
- _LT_TAGVAR(whole_archive_flag_spec, $1)='$convenience'
- fi
- _LT_TAGVAR(archive_cmds_need_lc, $1)=yes
- # This is similar to how AIX traditionally builds its shared libraries.
- _LT_TAGVAR(archive_expsym_cmds, $1)="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
- fi
- fi
- amigaos*)
- case $host_cpu in
- powerpc)
- m68k)
- esac
- bsdi[[45]]*)
- _LT_TAGVAR(export_dynamic_flag_spec, $1)=-rdynamic
- # hardcode_libdir_flag_spec is actually meaningless, as there is
- # no search path for DLLs.
- cl*)
- # Native MSVC
- _LT_TAGVAR(hardcode_libdir_flag_spec, $1)=' '
- _LT_TAGVAR(file_list_spec, $1)='@'
- # Tell ltmain to make .lib files, not .a files.
- libext=lib
- # Tell ltmain to make .dll files, not .so files.
- shrext_cmds=".dll"
- # FIXME: Setting linknames here is a bad hack.
- _LT_TAGVAR(archive_cmds, $1)='$CC -o $output_objdir/$soname $libobjs $compiler_flags $deplibs -Wl,-dll~linknames='
- sed -n -e 's/\\\\\\\(.*\\\\\\\)/-link\\\ -EXPORT:\\\\\\\1/' -e '1\\\!p' < $export_symbols > $output_objdir/$soname.exp;
- else
- sed -e 's/\\\\\\\(.*\\\\\\\)/-link\\\ -EXPORT:\\\\\\\1/' < $export_symbols > $output_objdir/$soname.exp;
- fi~
- $CC -o $tool_output_objdir$soname $libobjs $compiler_flags $deplibs "@$tool_output_objdir$soname.exp" -Wl,-DLL,-IMPLIB:"$tool_output_objdir$libname.dll.lib"~
- linknames='
- # The linker will not automatically build a static lib if we build a DLL.
- # _LT_TAGVAR(old_archive_from_new_cmds, $1)='true'
- _LT_TAGVAR(export_symbols_cmds, $1)='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[[BCDGRS]][[ ]]/s/.*[[ ]]\([[^ ]]*\)/\1,DATA/'\'' | $SED -e '\''/^[[AITW]][[ ]]/s/.*[[ ]]//'\'' | sort | uniq > $export_symbols'
- # Don't use ranlib
- _LT_TAGVAR(old_postinstall_cmds, $1)='chmod 644 $oldlib'
- _LT_TAGVAR(postlink_cmds, $1)='lt_outputfile="@OUTPUT@"~
- lt_tool_outputfile="@TOOL_OUTPUT@"~
- case $lt_outputfile in
- *.exe|*.EXE) ;;
- lt_outputfile="$lt_outputfile.exe"
- lt_tool_outputfile="$lt_tool_outputfile.exe"
- esac~
- if test "$MANIFEST_TOOL" != ":" && test -f "$lt_outputfile.manifest"; then
- $MANIFEST_TOOL -manifest "$lt_tool_outputfile.manifest" -outputresource:"$lt_tool_outputfile" || exit 1;
- $RM "$lt_outputfile.manifest";
- fi'
- # Assume MSVC wrapper
- libext=lib
- _LT_TAGVAR(archive_cmds, $1)='$CC -o $lib $libobjs $compiler_flags `func_echo_all "$deplibs" | $SED '\''s/ -lc$//'\''` -link -dll~linknames='
- # The linker will automatically build a .lib file if we build a DLL.
- _LT_TAGVAR(old_archive_from_new_cmds, $1)='true'
- # FIXME: Should let the user specify the lib program.
- _LT_TAGVAR(old_archive_cmds, $1)='lib -OUT:$oldlib$oldobjs$old_deplibs'
- esac
- _LT_DARWIN_LINKER_FEATURES($1)
- dgux*)
- _LT_TAGVAR(archive_cmds, $1)='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
- # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
- # support. Future versions do this automatically, but an explicit c++rt0.o
- # does not break anything, and helps significantly (at the cost of a little
- # extra space).
- freebsd2.2*)
- _LT_TAGVAR(archive_cmds, $1)='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
- _LT_TAGVAR(hardcode_libdir_flag_spec, $1)='-R$libdir'
- # Unfortunately, older versions of FreeBSD 2 do not have this feature.
- freebsd2.*)
- _LT_TAGVAR(archive_cmds, $1)='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
- hpux9*)
- _LT_TAGVAR(archive_cmds, $1)='$RM $output_objdir/$soname~$CC -shared $pic_flag ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- else
- _LT_TAGVAR(archive_cmds, $1)='$RM $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- fi
- _LT_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}+b ${wl}$libdir'
- _LT_TAGVAR(hardcode_libdir_separator, $1)=:
- # hardcode_minus_L: Not really in the search PATH,
- # but as the default location of the library.
- hpux10*)
- if test "$GCC" = yes && test "$with_gnu_ld" = no; then
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared $pic_flag ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
- else
- _LT_TAGVAR(archive_cmds, $1)='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
- fi
- if test "$with_gnu_ld" = no; then
- fi
- hpux11*)
- case $host_cpu in
- hppa*64*)
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- ia64*)
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared $pic_flag ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
- esac
- else
- case $host_cpu in
- hppa*64*)
- _LT_TAGVAR(archive_cmds, $1)='$CC -b ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- ia64*)
- _LT_TAGVAR(archive_cmds, $1)='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
- m4_if($1, [], [
- # Older versions of the 11.00 compiler do not understand -b yet
- # (HP92453-01 A.11.01.20 doesn't, HP92453-01 B.11.X.35175-35176.GP does)
- _LT_LINKER_OPTION([if $CC understands -b],
- _LT_TAGVAR(lt_cv_prog_compiler__b, $1), [-b],
- [_LT_TAGVAR(archive_cmds, $1)='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'],
- [_LT_TAGVAR(archive_cmds, $1)='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'])],
- [_LT_TAGVAR(archive_cmds, $1)='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'])
- esac
- fi
- case $host_cpu in
- hppa*64*|ia64*)
- esac
- fi
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && func_echo_all "${wl}-set_version ${wl}$verstring"` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- # Try to use the -exported_symbol ld option, if it does not
- # work, assume that -exports_file does not work either and
- # implicitly export all symbols.
- # This should be the same for all languages, so no per-tag cache variable.
- AC_CACHE_CHECK([whether the $host_os linker accepts -exported_symbol],
- [lt_cv_irix_exported_symbol],
- [save_LDFLAGS="$LDFLAGS"
- LDFLAGS="$LDFLAGS -shared ${wl}-exported_symbol ${wl}foo ${wl}-update_registry ${wl}/dev/null"
- AC_LINK_IFELSE(
- [AC_LANG_SOURCE(
- [AC_LANG_CASE([C], [[int foo (void) { return 0; }]],
- [C++], [[int foo (void) { return 0; }]],
- [Fortran 77], [[
- subroutine foo
- end]],
- [Fortran], [[
- subroutine foo
- end]])])],
- [lt_cv_irix_exported_symbol=yes],
- [lt_cv_irix_exported_symbol=no])
- LDFLAGS="$save_LDFLAGS"])
- if test "$lt_cv_irix_exported_symbol" = yes; then
- _LT_TAGVAR(archive_expsym_cmds, $1)='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && func_echo_all "${wl}-set_version ${wl}$verstring"` ${wl}-update_registry ${wl}${output_objdir}/so_locations ${wl}-exports_file ${wl}$export_symbols -o $lib'
- fi
- else
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared $libobjs $deplibs $compiler_flags -soname $soname `test -n "$verstring" && func_echo_all "-set_version $verstring"` -update_registry ${output_objdir}/so_locations -o $lib'
- _LT_TAGVAR(archive_expsym_cmds, $1)='$CC -shared $libobjs $deplibs $compiler_flags -soname $soname `test -n "$verstring" && func_echo_all "-set_version $verstring"` -update_registry ${output_objdir}/so_locations -exports_file $export_symbols -o $lib'
- fi
- _LT_TAGVAR(archive_cmds_need_lc, $1)='no'
- _LT_TAGVAR(inherit_rpath, $1)=yes
- if echo __ELF__ | $CC -E - | $GREP __ELF__ >/dev/null; then
- _LT_TAGVAR(archive_cmds, $1)='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags' # a.out
- else
- _LT_TAGVAR(archive_cmds, $1)='$LD -shared -o $lib $libobjs $deplibs $linker_flags' # ELF
- fi
- newsos6)
- *nto* | *qnx*)
- openbsd*)
- if test -f /usr/libexec/ld.so; then
- if test -z "`echo __ELF__ | $CC -E - | $GREP __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- _LT_TAGVAR(archive_expsym_cmds, $1)='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-retain-symbols-file,$export_symbols'
- else
- case $host_os in
- openbsd[[01]].* | openbsd2.[[0-7]] | openbsd2.[[0-7]].*)
- esac
- fi
- else
- fi
- os2*)
- _LT_TAGVAR(archive_cmds, $1)='$ECHO "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$ECHO "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~echo DATA >> $output_objdir/$libname.def~echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
- _LT_TAGVAR(old_archive_from_new_cmds, $1)='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
- osf3*)
- _LT_TAGVAR(allow_undefined_flag, $1)=' ${wl}-expect_unresolved ${wl}\*'
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && func_echo_all "${wl}-set_version ${wl}$verstring"` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- _LT_TAGVAR(allow_undefined_flag, $1)=' -expect_unresolved \*'
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags -soname $soname `test -n "$verstring" && func_echo_all "-set_version $verstring"` -update_registry ${output_objdir}/so_locations -o $lib'
- fi
- osf4* | osf5*) # as osf3* with the addition of -msym flag
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared${allow_undefined_flag} $pic_flag $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && func_echo_all "${wl}-set_version ${wl}$verstring"` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags -msym -soname $soname `test -n "$verstring" && func_echo_all "-set_version $verstring"` -update_registry ${output_objdir}/so_locations -o $lib'
- _LT_TAGVAR(archive_expsym_cmds, $1)='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; printf "%s\\n" "-hidden">> $lib.exp~
- $CC -shared${allow_undefined_flag} ${wl}-input ${wl}$lib.exp $compiler_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && $ECHO "-set_version $verstring"` -update_registry ${output_objdir}/so_locations -o $lib~$RM $lib.exp'
- # Both c and cxx compiler support -rpath directly
- _LT_TAGVAR(hardcode_libdir_flag_spec, $1)='-rpath $libdir'
- fi
- solaris*)
- _LT_TAGVAR(no_undefined_flag, $1)=' -z defs'
- wlarc='${wl}'
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared $pic_flag ${wl}-z ${wl}text ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- _LT_TAGVAR(archive_expsym_cmds, $1)='echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~echo "local: *; };" >> $lib.exp~
- $CC -shared $pic_flag ${wl}-z ${wl}text ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$RM $lib.exp'
- else
- case `$CC -V 2>&1` in
- *"Compilers 5.0"*)
- wlarc=''
- _LT_TAGVAR(archive_cmds, $1)='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
- $LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$RM $lib.exp'
- wlarc='${wl}'
- _LT_TAGVAR(archive_cmds, $1)='$CC -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $compiler_flags'
- $CC -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $compiler_flags~$RM $lib.exp'
- esac
- fi
- case $host_os in
- solaris2.[[0-5]] | solaris2.[[0-5]].*) ;;
- # The compiler driver will combine and reorder linker options,
- # but understands `-z linker_flag'. GCC discards it without `$wl',
- # but is careful enough not to reorder.
- # Supported since Solaris 2.6 (maybe 2.5.1?)
- _LT_TAGVAR(whole_archive_flag_spec, $1)='${wl}-z ${wl}allextract$convenience ${wl}-z ${wl}defaultextract'
- else
- _LT_TAGVAR(whole_archive_flag_spec, $1)='-z allextract$convenience -z defaultextract'
- fi
- esac
- sunos4*)
- if test "x$host_vendor" = xsequent; then
- # Use $CC to link under sequent, because it throws in some extra .o
- # files that make .init and .fini sections work.
- _LT_TAGVAR(archive_cmds, $1)='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- _LT_TAGVAR(archive_cmds, $1)='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
- fi
- sysv4)
- case $host_vendor in
- sni)
- _LT_TAGVAR(hardcode_direct, $1)=yes # is this really true???
- siemens)
- ## LD is ld it makes a PLAMLIB
- ## CC just makes a GrossModule.
- _LT_TAGVAR(archive_cmds, $1)='$LD -G -o $lib $libobjs $deplibs $linker_flags'
- _LT_TAGVAR(reload_cmds, $1)='$CC -r -o $output$reload_objs'
- motorola)
- _LT_TAGVAR(hardcode_direct, $1)=no #Motorola manual says yes, but my tests say they lie
- esac
- runpath_var='LD_RUN_PATH'
- sysv4.3*)
- _LT_TAGVAR(export_dynamic_flag_spec, $1)='-Bexport'
- sysv4*MP*)
- runpath_var=LD_RUN_PATH
- hardcode_runpath_var=yes
- fi
- sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[[01]].[[10]]* | unixware7* | sco3.2v5.0.[[024]]*)
- _LT_TAGVAR(no_undefined_flag, $1)='${wl}-z,text'
- _LT_TAGVAR(archive_cmds_need_lc, $1)=no
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- _LT_TAGVAR(archive_expsym_cmds, $1)='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- _LT_TAGVAR(archive_cmds, $1)='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- _LT_TAGVAR(archive_expsym_cmds, $1)='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- fi
- sysv5* | sco3.2v5* | sco5v6*)
- # Note: We can NOT use -z defs as we might desire, because we do not
- # link with -lc, and that would cause any symbols used from libc to
- # always be unresolved, which means just about no library would
- # ever link correctly. If we're not using GNU ld we use -z text
- # though, which does catch some bad symbols but isn't as heavy-handed
- # as -z defs.
- _LT_TAGVAR(allow_undefined_flag, $1)='${wl}-z,nodefs'
- _LT_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}-R,$libdir'
- _LT_TAGVAR(export_dynamic_flag_spec, $1)='${wl}-Bexport'
- else
- fi
- uts4*)
- esac
- if test x$host_vendor = xsni; then
- case $host in
- sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
- _LT_TAGVAR(export_dynamic_flag_spec, $1)='${wl}-Blargedynsym'
- esac
- fi
- fi
-AC_MSG_RESULT([$_LT_TAGVAR(ld_shlibs, $1)])
-test "$_LT_TAGVAR(ld_shlibs, $1)" = no && can_build_shared=no
-_LT_TAGVAR(with_gnu_ld, $1)=$with_gnu_ld
-_LT_DECL([], [libext], [0], [Old archive suffix (normally "a")])dnl
-_LT_DECL([], [shrext_cmds], [1], [Shared library suffix (normally ".so")])dnl
-_LT_DECL([], [extract_expsyms_cmds], [2],
- [The commands to extract the exported symbol list from a shared archive])
-# Do we need to explicitly link libc?
-case "x$_LT_TAGVAR(archive_cmds_need_lc, $1)" in
-x|xyes)
- # Assume -lc should be added
- if test "$enable_shared" = yes && test "$GCC" = yes; then
- case $_LT_TAGVAR(archive_cmds, $1) in
- # FIXME: we may have to deal with multi-command sequences.
- '$CC '*)
- # Test whether the compiler implicitly links with -lc since on some
- # systems, -lgcc has to come before -lc. If gcc already passes -lc
- # to ld, don't add -lc before -lgcc.
- AC_CACHE_CHECK([whether -lc should be explicitly linked in],
- [lt_cv_]_LT_TAGVAR(archive_cmds_need_lc, $1),
- [$RM conftest*
- echo "$lt_simple_compile_test_code" > conftest.$ac_ext
- if AC_TRY_EVAL(ac_compile) 2>conftest.err; then
- soname=conftest
- lib=conftest
- libobjs=conftest.$ac_objext
- deplibs=
- wl=$_LT_TAGVAR(lt_prog_compiler_wl, $1)
- pic_flag=$_LT_TAGVAR(lt_prog_compiler_pic, $1)
- compiler_flags=-v
- linker_flags=-v
- verstring=
- output_objdir=.
- libname=conftest
- lt_save_allow_undefined_flag=$_LT_TAGVAR(allow_undefined_flag, $1)
- if AC_TRY_EVAL(_LT_TAGVAR(archive_cmds, $1) 2\>\&1 \| $GREP \" -lc \" \>/dev/null 2\>\&1)
- then
- lt_cv_[]_LT_TAGVAR(archive_cmds_need_lc, $1)=no
- else
- lt_cv_[]_LT_TAGVAR(archive_cmds_need_lc, $1)=yes
- fi
- _LT_TAGVAR(allow_undefined_flag, $1)=$lt_save_allow_undefined_flag
- else
- cat conftest.err 1>&5
- fi
- $RM conftest*
- _LT_TAGVAR(archive_cmds_need_lc, $1)=$lt_cv_[]_LT_TAGVAR(archive_cmds_need_lc, $1)
- esac
- fi
-esac
-_LT_TAGDECL([build_libtool_need_lc], [archive_cmds_need_lc], [0],
- [Whether or not to add -lc for building shared libraries])
-_LT_TAGDECL([allow_libtool_libs_with_static_runtimes],
- [enable_shared_with_static_runtimes], [0],
- [Whether or not to disallow shared libs when runtime libs are static])
-_LT_TAGDECL([], [export_dynamic_flag_spec], [1],
- [Compiler flag to allow reflexive dlopens])
-_LT_TAGDECL([], [whole_archive_flag_spec], [1],
- [Compiler flag to generate shared objects directly from archives])
-_LT_TAGDECL([], [compiler_needs_object], [1],
- [Whether the compiler copes with passing no objects directly])
-_LT_TAGDECL([], [old_archive_from_new_cmds], [2],
- [Create an old-style archive from a shared archive])
-_LT_TAGDECL([], [old_archive_from_expsyms_cmds], [2],
- [Create a temporary old-style archive to link instead of a shared archive])
-_LT_TAGDECL([], [archive_cmds], [2], [Commands used to build a shared archive])
-_LT_TAGDECL([], [archive_expsym_cmds], [2])
-_LT_TAGDECL([], [module_cmds], [2],
- [Commands used to build a loadable module if different from building
- a shared archive.])
-_LT_TAGDECL([], [module_expsym_cmds], [2])
-_LT_TAGDECL([], [with_gnu_ld], [1],
- [Whether we are building with GNU ld or not])
-_LT_TAGDECL([], [allow_undefined_flag], [1],
- [Flag that allows shared libraries with undefined symbols to be built])
-_LT_TAGDECL([], [no_undefined_flag], [1],
- [Flag that enforces no undefined symbols])
-_LT_TAGDECL([], [hardcode_libdir_flag_spec], [1],
- [Flag to hardcode $libdir into a binary during linking.
- This must work even if $libdir does not exist])
-_LT_TAGDECL([], [hardcode_libdir_separator], [1],
- [Whether we need a single "-rpath" flag with a separated argument])
-_LT_TAGDECL([], [hardcode_direct], [0],
- [Set to "yes" if using DIR/libNAME${shared_ext} during linking hardcodes
- DIR into the resulting binary])
-_LT_TAGDECL([], [hardcode_direct_absolute], [0],
- DIR into the resulting binary and the resulting library dependency is
- "absolute", i.e impossible to change by setting ${shlibpath_var} if the
- library is relocated])
-_LT_TAGDECL([], [hardcode_minus_L], [0],
- [Set to "yes" if using the -LDIR flag during linking hardcodes DIR
- into the resulting binary])
-_LT_TAGDECL([], [hardcode_shlibpath_var], [0],
- [Set to "yes" if using SHLIBPATH_VAR=DIR during linking hardcodes DIR
-_LT_TAGDECL([], [hardcode_automatic], [0],
- [Set to "yes" if building a shared library automatically hardcodes DIR
- into the library and all subsequent libraries and executables linked
- against it])
-_LT_TAGDECL([], [inherit_rpath], [0],
- [Set to yes if linker adds runtime paths of dependent libraries
- to runtime path list])
-_LT_TAGDECL([], [link_all_deplibs], [0],
- [Whether libtool must link a program against all its dependency libraries])
-_LT_TAGDECL([], [always_export_symbols], [0],
- [Set to "yes" if exported symbols are required])
-_LT_TAGDECL([], [export_symbols_cmds], [2],
- [The commands to list exported symbols])
-_LT_TAGDECL([], [exclude_expsyms], [1],
- [Symbols that should not be listed in the preloaded symbols])
-_LT_TAGDECL([], [include_expsyms], [1],
- [Symbols that must always be exported])
-_LT_TAGDECL([], [prelink_cmds], [2],
- [Commands necessary for linking programs (against libraries) with templates])
-_LT_TAGDECL([], [postlink_cmds], [2],
- [Commands necessary for finishing linking programs])
-_LT_TAGDECL([], [file_list_spec], [1],
- [Specify filename containing input files])
-dnl FIXME: Not yet implemented
-dnl _LT_TAGDECL([], [thread_safe_flag_spec], [1],
-dnl [Compiler flag to generate thread safe objects])
-])# _LT_LINKER_SHLIBS
-# _LT_LANG_C_CONFIG([TAG])
-# Ensure that the configuration variables for a C compiler are suitably
-# defined. These variables are subsequently used by _LT_CONFIG to write
-# the compiler configuration to `libtool'.
-m4_defun([_LT_LANG_C_CONFIG],
-[m4_require([_LT_DECL_EGREP])dnl
-lt_save_CC="$CC"
-AC_LANG_PUSH(C)
-# Source file extension for C test sources.
-ac_ext=c
-# Object file extension for compiled C test sources.
-objext=o
-_LT_TAGVAR(objext, $1)=$objext
-# Code to be used in simple compile tests
-lt_simple_compile_test_code="int some_variable = 0;"
-# Code to be used in simple link tests
-lt_simple_link_test_code='int main(){return(0);}'
-_LT_TAG_COMPILER
-# Save the default compiler, since it gets overwritten when the other
-# tags are being tested, and _LT_TAGVAR(compiler, []) is a NOP.
-compiler_DEFAULT=$CC
-# save warnings/boilerplate of simple test code
-_LT_COMPILER_BOILERPLATE
-_LT_LINKER_BOILERPLATE
-if test -n "$compiler"; then
- _LT_COMPILER_NO_RTTI($1)
- _LT_COMPILER_PIC($1)
- _LT_COMPILER_C_O($1)
- _LT_COMPILER_FILE_LOCKS($1)
- _LT_LINKER_SHLIBS($1)
- _LT_SYS_DYNAMIC_LINKER($1)
- _LT_LINKER_HARDCODE_LIBPATH($1)
- LT_SYS_DLOPEN_SELF
- _LT_CMD_STRIPLIB
- # Report which library types will actually be built
- AC_MSG_CHECKING([if libtool supports shared libraries])
- AC_MSG_RESULT([$can_build_shared])
- AC_MSG_CHECKING([whether to build shared libraries])
- test "$can_build_shared" = "no" && enable_shared=no
- # On AIX, shared libraries and static libraries use the same namespace, and
- # are all built from PIC.
- case $host_os in
- aix3*)
- test "$enable_shared" = yes && enable_static=no
- if test -n "$RANLIB"; then
- archive_cmds="$archive_cmds~\$RANLIB \$lib"
- postinstall_cmds='$RANLIB $lib'
- fi
- aix[[4-9]]*)
- if test "$host_cpu" != ia64 && test "$aix_use_runtimelinking" = no ; then
- fi
- esac
- AC_MSG_RESULT([$enable_shared])
- AC_MSG_CHECKING([whether to build static libraries])
- # Make sure either enable_shared or enable_static is yes.
- test "$enable_shared" = yes || enable_static=yes
- AC_MSG_RESULT([$enable_static])
- _LT_CONFIG($1)
-fi
-AC_LANG_POP
-CC="$lt_save_CC"
-])# _LT_LANG_C_CONFIG
-# _LT_LANG_CXX_CONFIG([TAG])
-# Ensure that the configuration variables for a C++ compiler are suitably
-m4_defun([_LT_LANG_CXX_CONFIG],
-[m4_require([_LT_FILEUTILS_DEFAULTS])dnl
-m4_require([_LT_DECL_EGREP])dnl
-if test -n "$CXX" && ( test "X$CXX" != "Xno" &&
- ( (test "X$CXX" = "Xg++" && `g++ -v >/dev/null 2>&1` ) ||
- (test "X$CXX" != "Xg++"))) ; then
- AC_PROG_CXXCPP
-else
- _lt_caught_CXX_error=yes
-fi
-AC_LANG_PUSH(C++)
-_LT_TAGVAR(archive_cmds_need_lc, $1)=no
-_LT_TAGVAR(allow_undefined_flag, $1)=
-_LT_TAGVAR(always_export_symbols, $1)=no
-_LT_TAGVAR(archive_expsym_cmds, $1)=
-_LT_TAGVAR(compiler_needs_object, $1)=no
-_LT_TAGVAR(export_dynamic_flag_spec, $1)=
-_LT_TAGVAR(hardcode_direct, $1)=no
-_LT_TAGVAR(hardcode_direct_absolute, $1)=no
-_LT_TAGVAR(hardcode_libdir_flag_spec, $1)=
-_LT_TAGVAR(hardcode_libdir_separator, $1)=
-_LT_TAGVAR(hardcode_minus_L, $1)=no
-_LT_TAGVAR(hardcode_shlibpath_var, $1)=unsupported
-_LT_TAGVAR(hardcode_automatic, $1)=no
-_LT_TAGVAR(inherit_rpath, $1)=no
-_LT_TAGVAR(module_cmds, $1)=
-_LT_TAGVAR(module_expsym_cmds, $1)=
-_LT_TAGVAR(link_all_deplibs, $1)=unknown
-_LT_TAGVAR(old_archive_cmds, $1)=$old_archive_cmds
-_LT_TAGVAR(reload_flag, $1)=$reload_flag
-_LT_TAGVAR(reload_cmds, $1)=$reload_cmds
-_LT_TAGVAR(no_undefined_flag, $1)=
-_LT_TAGVAR(whole_archive_flag_spec, $1)=
-_LT_TAGVAR(enable_shared_with_static_runtimes, $1)=no
-# Source file extension for C++ test sources.
-ac_ext=cpp
-# Object file extension for compiled C++ test sources.
-objext=o
-# No sense in running all these tests if we already determined that
-# the CXX compiler isn't working. Some variables (like enable_shared)
-# are currently assumed to apply to all compilers on this platform,
-# and will be corrupted by setting them based on a non-working compiler.
-if test "$_lt_caught_CXX_error" != yes; then
- # Code to be used in simple compile tests
- lt_simple_compile_test_code="int some_variable = 0;"
- # Code to be used in simple link tests
- lt_simple_link_test_code='int main(int, char *[[]]) { return(0); }'
- # ltmain only uses $CC for tagged configurations so make sure $CC is set.
- _LT_TAG_COMPILER
- # save warnings/boilerplate of simple test code
- _LT_COMPILER_BOILERPLATE
- _LT_LINKER_BOILERPLATE
- # Allow CC to be a program name with arguments.
- lt_save_CC=$CC
- lt_save_CFLAGS=$CFLAGS
- lt_save_LD=$LD
- lt_save_GCC=$GCC
- GCC=$GXX
- lt_save_with_gnu_ld=$with_gnu_ld
- lt_save_path_LD=$lt_cv_path_LD
- if test -n "${lt_cv_prog_gnu_ldcxx+set}"; then
- lt_cv_prog_gnu_ld=$lt_cv_prog_gnu_ldcxx
- else
- $as_unset lt_cv_prog_gnu_ld
- fi
- if test -n "${lt_cv_path_LDCXX+set}"; then
- lt_cv_path_LD=$lt_cv_path_LDCXX
- else
- $as_unset lt_cv_path_LD
- fi
- test -z "${LDCXX+set}" || LD=$LDCXX
- CC=${CXX-"c++"}
- CFLAGS=$CXXFLAGS
- compiler=$CC
- _LT_TAGVAR(compiler, $1)=$CC
- _LT_CC_BASENAME([$compiler])
- if test -n "$compiler"; then
- # We don't want -fno-exception when compiling C++ code, so set the
- # no_builtin_flag separately
- _LT_TAGVAR(lt_prog_compiler_no_builtin_flag, $1)=' -fno-builtin'
- else
- fi
- # Set up default GNU C++ configuration
- LT_PATH_LD
- # Check if GNU C++ uses GNU ld as the underlying linker, since the
- # archiving commands below assume that GNU ld is being used.
- if test "$with_gnu_ld" = yes; then
- _LT_TAGVAR(archive_cmds, $1)='$CC $pic_flag -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib'
- _LT_TAGVAR(archive_expsym_cmds, $1)='$CC $pic_flag -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- # XXX I think wlarc can be eliminated in ltcf-cxx, but I need to
- # investigate it a little bit more. (MM)
- wlarc='${wl}'
- if eval "`$CC -print-prog-name=ld` --help 2>&1" |
- $GREP 'no-whole-archive' > /dev/null; then
- else
- fi
- else
- with_gnu_ld=no
- wlarc=
- # A generic and very simple default shared library creation
- # command for GNU C++ for the case where it uses the native
- # linker, instead of GNU ld. If possible, this setting should
- # overridden to take advantage of the native linker features on
- # the platform it is being used on.
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $lib'
- fi
- # Commands to make compiler produce verbose output that lists
- # what "hidden" libraries, object files and flags are used when
- # linking a shared library.
- output_verbose_link_cmd='$CC -shared $CFLAGS -v conftest.$objext 2>&1 | $GREP -v "^Configured with:" | $GREP "\-L"'
- else
- GXX=no
- with_gnu_ld=no
- wlarc=
- fi
- # PORTME: fill in a description of your system's C++ link characteristics
- AC_MSG_CHECKING([whether the $compiler linker ($LD) supports shared libraries])
- case $host_os in
- aix3*)
- # FIXME: insert proper C++ library support
- aix[[4-9]]*)
- no_entry_flag=""
- else
- case $ld_flag in
- *-brtl*)
- break
- esac
- done
- esac
- fi
- then
- else
- fi
- esac
- fi
- else
- # not using gcc
- shared_flag='-G'
- else
- else
- fi
- fi
- fi
- # export.
- # Determine the default libpath from the value encoded in an empty
- # executable.
- else
- else
- else
- fi
- # libraries.
- fi
- fi
- beos*)
- else
- fi
- chorus*)
- case $cc_basename in
- esac
- cygwin* | mingw* | pw32* | cegcc*)
- case $GXX,$cc_basename in
- ,cl* | no,cl*)
- # Native MSVC
- libext=lib
- $SED -n -e 's/\\\\\\\(.*\\\\\\\)/-link\\\ -EXPORT:\\\\\\\1/' -e '1\\\!p' < $export_symbols > $output_objdir/$soname.exp;
- else
- $SED -e 's/\\\\\\\(.*\\\\\\\)/-link\\\ -EXPORT:\\\\\\\1/' < $export_symbols > $output_objdir/$soname.exp;
- fi~
- linknames='
- *.exe|*.EXE) ;;
- esac~
- func_to_tool_file "$lt_outputfile"~
- fi'
- # g++
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
- else
- fi~
- $CC -shared -nostdlib $output_objdir/$soname.def $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
- else
- fi
- esac
- dgux*)
- ec++*)
- ghcx*)
- esac
- freebsd2.*)
- # C++ shared libraries reported to be fairly broken before
- # switch to ELF
- freebsd-elf*)
- # FreeBSD 3 and later use GNU C++ and GNU ld with standard ELF
- # conventions
- gnu*)
- haiku*)
- hpux9*)
- _LT_TAGVAR(hardcode_minus_L, $1)=yes # Not in the search PATH,
- # location of the library.
- CC*)
- aCC*)
- _LT_TAGVAR(archive_cmds, $1)='$RM $output_objdir/$soname~$CC -b ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- # There doesn't appear to be a way to prevent this compiler from
- # explicitly linking system object files so we need to strip them
- # from the output so that they don't get included in the library
- # dependencies.
- output_verbose_link_cmd='templist=`($CC -b $CFLAGS -v conftest.$objext 2>&1) | $EGREP "\-L"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; func_echo_all "$list"'
- _LT_TAGVAR(archive_cmds, $1)='$RM $output_objdir/$soname~$CC -shared -nostdlib $pic_flag ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- else
- fi
- esac
- hpux10*|hpux11*)
- if test $with_gnu_ld = no; then
- case $host_cpu in
- hppa*64*|ia64*)
- esac
- fi
- case $host_cpu in
- hppa*64*|ia64*)
- esac
- CC*)
- aCC*)
- case $host_cpu in
- hppa*64*)
- _LT_TAGVAR(archive_cmds, $1)='$CC -b ${wl}+h ${wl}$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- ia64*)
- _LT_TAGVAR(archive_cmds, $1)='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- _LT_TAGVAR(archive_cmds, $1)='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- esac
- # dependencies.
- output_verbose_link_cmd='templist=`($CC -b $CFLAGS -v conftest.$objext 2>&1) | $GREP "\-L"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; func_echo_all "$list"'
- case $host_cpu in
- hppa*64*)
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- ia64*)
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib $pic_flag ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib $pic_flag ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- esac
- fi
- else
- fi
- esac
- interix[[3-9]]*)
- irix5* | irix6*)
- CC*)
- # SGI C++
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared -all -multigot $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -soname $soname `test -n "$verstring" && func_echo_all "-set_version $verstring"` -update_registry ${output_objdir}/so_locations -o $lib'
- # Archives containing C++ object files must be created using
- # "CC -ar", where "CC" is the IRIX C++ compiler. This is
- # necessary to make sure instantiated templates are included
- # in the archive.
- _LT_TAGVAR(old_archive_cmds, $1)='$CC -ar -WR,-u -o $oldlib $oldobjs'
- if test "$GXX" = yes; then
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared $pic_flag -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && func_echo_all "${wl}-set_version ${wl}$verstring"` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared $pic_flag -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && func_echo_all "${wl}-set_version ${wl}$verstring"` -o $lib'
- fi
- fi
- esac
- KCC*)
- # Kuck and Associates, Inc. (KAI) C++ Compiler
- # KCC will only create a shared library if the output file
- # ends with ".so" (or ".sl" for HP-UX), so rename the library
- # to its proper name (with version) after linking.
- _LT_TAGVAR(archive_cmds, $1)='tempext=`echo $shared_ext | $SED -e '\''s/\([[^()0-9A-Za-z{}]]\)/\\\\\1/g'\''`; templib=`echo $lib | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib; mv \$templib $lib'
- _LT_TAGVAR(archive_expsym_cmds, $1)='tempext=`echo $shared_ext | $SED -e '\''s/\([[^()0-9A-Za-z{}]]\)/\\\\\1/g'\''`; templib=`echo $lib | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib ${wl}-retain-symbols-file,$export_symbols; mv \$templib $lib'
- # dependencies.
- output_verbose_link_cmd='templist=`$CC $CFLAGS -v conftest.$objext -o libconftest$shared_ext 2>&1 | $GREP "ld"`; rm -f libconftest$shared_ext; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; func_echo_all "$list"'
- # "CC -Bstatic", where "CC" is the KAI C++ compiler.
- _LT_TAGVAR(old_archive_cmds, $1)='$CC -Bstatic -o $oldlib $oldobjs'
- icpc* | ecpc* )
- # Intel C++
- with_gnu_ld=yes
- # version 8.0 and above of icpc choke on multiply defined symbols
- # if we add $predep_objects and $postdep_objects, however 7.1 and
- # earlier do not add the objects themselves.
- *"Version 7."*)
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib'
- _LT_TAGVAR(archive_expsym_cmds, $1)='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- *) # Version 8.0 or newer
- tmp_idyn=
- case $host_cpu in
- ia64*) tmp_idyn=' -i_dynamic';;
- esac
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared'"$tmp_idyn"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- _LT_TAGVAR(archive_expsym_cmds, $1)='$CC -shared'"$tmp_idyn"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- esac
- pgCC* | pgcpp*)
- case `$CC -V` in
- *pgCC\ [[1-5]].* | *pgcpp\ [[1-5]].*)
- _LT_TAGVAR(prelink_cmds, $1)='tpldir=Template.dir~
- rm -rf $tpldir~
- $CC --prelink_objects --instantiation_dir $tpldir $objs $libobjs $compile_deplibs~
- compile_command="$compile_command `find $tpldir -name \*.o | sort | $NL2SP`"'
- _LT_TAGVAR(old_archive_cmds, $1)='tpldir=Template.dir~
- rm -rf $tpldir~
- $CC --prelink_objects --instantiation_dir $tpldir $oldobjs$old_deplibs~
- $AR $AR_FLAGS $oldlib$oldobjs$old_deplibs `find $tpldir -name \*.o | sort | $NL2SP`~
- $RANLIB $oldlib'
- _LT_TAGVAR(archive_cmds, $1)='tpldir=Template.dir~
- rm -rf $tpldir~
- $CC --prelink_objects --instantiation_dir $tpldir $predep_objects $libobjs $deplibs $convenience $postdep_objects~
- $CC -shared $pic_flag $predep_objects $libobjs $deplibs `find $tpldir -name \*.o | sort | $NL2SP` $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname -o $lib'
- _LT_TAGVAR(archive_expsym_cmds, $1)='tpldir=Template.dir~
- rm -rf $tpldir~
- $CC -shared $pic_flag $predep_objects $libobjs $deplibs `find $tpldir -name \*.o | sort | $NL2SP` $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname ${wl}-retain-symbols-file ${wl}$export_symbols -o $lib'
- *) # Version 6 and above use weak symbols
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname -o $lib'
- _LT_TAGVAR(archive_expsym_cmds, $1)='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname ${wl}-retain-symbols-file ${wl}$export_symbols -o $lib'
- esac
- _LT_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}--rpath ${wl}$libdir'
- cxx*)
- # Compaq C++
- _LT_TAGVAR(archive_expsym_cmds, $1)='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib ${wl}-retain-symbols-file $wl$export_symbols'
- # dependencies.
- output_verbose_link_cmd='templist=`$CC -shared $CFLAGS -v conftest.$objext 2>&1 | $GREP "ld"`; templist=`func_echo_all "$templist" | $SED "s/\(^.*ld.*\)\( .*ld .*$\)/\1/"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; func_echo_all "X$list" | $Xsed'
- xl* | mpixl* | bgxl*)
- # IBM XL 8.0 on PPC, with GNU ld
- _LT_TAGVAR(archive_cmds, $1)='$CC -qmkshrobj $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- $CC -qmkshrobj $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
- fi
- case `$CC -V 2>&1 | sed 5q` in
- *Sun\ C*)
- # Sun C++ 5.9
- _LT_TAGVAR(no_undefined_flag, $1)=' -zdefs'
- _LT_TAGVAR(archive_cmds, $1)='$CC -G${allow_undefined_flag} -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- _LT_TAGVAR(archive_expsym_cmds, $1)='$CC -G${allow_undefined_flag} -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-retain-symbols-file ${wl}$export_symbols'
- # Not sure whether something based on
- # $CC $CFLAGS -v conftest.$objext -o libconftest$shared_ext 2>&1
- # would be better.
- output_verbose_link_cmd='func_echo_all'
- # "CC -xar", where "CC" is the Sun C++ compiler. This is
- # in the archive.
- _LT_TAGVAR(old_archive_cmds, $1)='$CC -xar -o $oldlib $oldobjs'
- esac
- esac
- lynxos*)
- m88k*)
- mvs*)
- cxx*)
- esac
- netbsd*)
- _LT_TAGVAR(archive_cmds, $1)='$LD -Bshareable -o $lib $predep_objects $libobjs $deplibs $postdep_objects $linker_flags'
- wlarc=
- fi
- # Workaround some broken pre-1.5 toolchains
- output_verbose_link_cmd='$CC -shared $CFLAGS -v conftest.$objext 2>&1 | $GREP conftest.$objext | $SED -e "s:-lgcc -lc -lgcc::"'
- *nto* | *qnx*)
- openbsd2*)
- # C++ shared libraries are fairly broken
- openbsd*)
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $lib'
- if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- _LT_TAGVAR(archive_expsym_cmds, $1)='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-retain-symbols-file,$export_symbols -o $lib'
- fi
- output_verbose_link_cmd=func_echo_all
- else
- fi
- osf3* | osf4* | osf5*)
- KCC*)
- _LT_TAGVAR(archive_cmds, $1)='tempext=`echo $shared_ext | $SED -e '\''s/\([[^()0-9A-Za-z{}]]\)/\\\\\1/g'\''`; templib=`echo "$lib" | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib; mv \$templib $lib'
- # the KAI C++ compiler.
- case $host in
- osf3*) _LT_TAGVAR(old_archive_cmds, $1)='$CC -Bstatic -o $oldlib $oldobjs' ;;
- *) _LT_TAGVAR(old_archive_cmds, $1)='$CC -o $oldlib $oldobjs' ;;
- esac
- RCC*)
- # Rational C++ 2.4.1
- cxx*)
- case $host in
- osf3*)
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $soname `test -n "$verstring" && func_echo_all "${wl}-set_version $verstring"` -update_registry ${output_objdir}/so_locations -o $lib'
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -msym -soname $soname `test -n "$verstring" && func_echo_all "-set_version $verstring"` -update_registry ${output_objdir}/so_locations -o $lib'
- _LT_TAGVAR(archive_expsym_cmds, $1)='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done~
- echo "-hidden">> $lib.exp~
- $CC -shared$allow_undefined_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -msym -soname $soname ${wl}-input ${wl}$lib.exp `test -n "$verstring" && $ECHO "-set_version $verstring"` -update_registry ${output_objdir}/so_locations -o $lib~
- $RM $lib.exp'
- esac
- # dependencies.
- output_verbose_link_cmd='templist=`$CC -shared $CFLAGS -v conftest.$objext 2>&1 | $GREP "ld" | $GREP -v "ld:"`; templist=`func_echo_all "$templist" | $SED "s/\(^.*ld.*\)\( .*ld.*$\)/\1/"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; func_echo_all "$list"'
- if test "$GXX" = yes && test "$with_gnu_ld" = no; then
- case $host in
- osf3*)
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared -nostdlib ${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && func_echo_all "${wl}-set_version ${wl}$verstring"` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared $pic_flag -nostdlib ${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && func_echo_all "${wl}-set_version ${wl}$verstring"` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- esac
- else
- fi
- esac
- psos*)
- sunos4*)
- CC*)
- # Sun C++ 4.x
- lcc*)
- # Lucid
- esac
- solaris*)
- CC* | sunCC*)
- # Sun C++ 4.2, 5.x and Centerline C++
- _LT_TAGVAR(archive_cmds_need_lc,$1)=yes
- $CC -G${allow_undefined_flag} ${wl}-M ${wl}$lib.exp -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$RM $lib.exp'
- case $host_os in
- esac
- # in the archive.
- gcx*)
- # Green Hills C++ Compiler
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
- # The C++ compiler must be used to create the archive.
- _LT_TAGVAR(old_archive_cmds, $1)='$CC $LDFLAGS -archive -o $oldlib $oldobjs'
- # GNU C++ compiler with Solaris linker
- _LT_TAGVAR(no_undefined_flag, $1)=' ${wl}-z ${wl}defs'
- if $CC --version | $GREP -v '^2\.7' > /dev/null; then
- _LT_TAGVAR(archive_cmds, $1)='$CC -shared $pic_flag -nostdlib $LDFLAGS $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
- $CC -shared $pic_flag -nostdlib ${wl}-M $wl$lib.exp -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$RM $lib.exp'
- else
- # g++ 2.7 appears to require `-G' NOT `-shared' on this
- # platform.
- _LT_TAGVAR(archive_cmds, $1)='$CC -G -nostdlib $LDFLAGS $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
- $CC -G -nostdlib ${wl}-M $wl$lib.exp -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$RM $lib.exp'
- output_verbose_link_cmd='$CC -G $CFLAGS -v conftest.$objext 2>&1 | $GREP -v "^Configured with:" | $GREP "\-L"'
- fi
- _LT_TAGVAR(hardcode_libdir_flag_spec, $1)='${wl}-R $wl$libdir'
- case $host_os in
- esac
- fi
- esac
- CC*)
- esac
- # as -z defs.
- CC*)
- _LT_TAGVAR(old_archive_cmds, $1)='$CC -Tprelink_objects $oldobjs~
- '"$_LT_TAGVAR(old_archive_cmds, $1)"
- _LT_TAGVAR(reload_cmds, $1)='$CC -Tprelink_objects $reload_objs~
- '"$_LT_TAGVAR(reload_cmds, $1)"
- esac
- tandem*)
- NCC*)
- # NonStop-UX NCC 3.20
- esac
- vxworks*)
- esac
- AC_MSG_RESULT([$_LT_TAGVAR(ld_shlibs, $1)])
- test "$_LT_TAGVAR(ld_shlibs, $1)" = no && can_build_shared=no
- _LT_TAGVAR(GCC, $1)="$GXX"
- _LT_TAGVAR(LD, $1)="$LD"
- ## CAVEAT EMPTOR:
- ## There is no encapsulation within the following macros, do not change
- ## the running order or otherwise move them around unless you know exactly
- ## what you are doing...
- _LT_SYS_HIDDEN_LIBDEPS($1)
- _LT_CONFIG($1)
- fi # test -n "$compiler"
- CC=$lt_save_CC
- CFLAGS=$lt_save_CFLAGS
- LDCXX=$LD
- LD=$lt_save_LD
- GCC=$lt_save_GCC
- with_gnu_ld=$lt_save_with_gnu_ld
- lt_cv_path_LDCXX=$lt_cv_path_LD
- lt_cv_path_LD=$lt_save_path_LD
- lt_cv_prog_gnu_ldcxx=$lt_cv_prog_gnu_ld
- lt_cv_prog_gnu_ld=$lt_save_with_gnu_ld
-fi # test "$_lt_caught_CXX_error" != yes
-AC_LANG_POP
-])# _LT_LANG_CXX_CONFIG
-# _LT_FUNC_STRIPNAME_CNF
-# func_stripname_cnf prefix suffix name
-# strip PREFIX and SUFFIX off of NAME.
-# PREFIX and SUFFIX must not contain globbing or regex special
-# characters, hashes, percent signs, but SUFFIX may contain a leading
-# dot (in which case that matches only a dot).
-# This function is identical to the (non-XSI) version of func_stripname,
-# except this one can be used by m4 code that may be executed by configure,
-# rather than the libtool script.
-m4_defun([_LT_FUNC_STRIPNAME_CNF],[dnl
-AC_REQUIRE([_LT_DECL_SED])
-AC_REQUIRE([_LT_PROG_ECHO_BACKSLASH])
-func_stripname_cnf ()
- case ${2} in
- .*) func_stripname_result=`$ECHO "${3}" | $SED "s%^${1}%%; s%\\\\${2}\$%%"`;;
- *) func_stripname_result=`$ECHO "${3}" | $SED "s%^${1}%%; s%${2}\$%%"`;;
- esac
-} # func_stripname_cnf
-])# _LT_FUNC_STRIPNAME_CNF
-# _LT_SYS_HIDDEN_LIBDEPS([TAGNAME])
-# Figure out "hidden" library dependencies from verbose
-# compiler output when linking a shared library.
-# Parse the compiler output and extract the necessary
-# objects, libraries and library flags.
-m4_defun([_LT_SYS_HIDDEN_LIBDEPS],
-AC_REQUIRE([_LT_FUNC_STRIPNAME_CNF])dnl
-# Dependencies to place before and after the object being linked:
-_LT_TAGVAR(predep_objects, $1)=
-_LT_TAGVAR(postdep_objects, $1)=
-_LT_TAGVAR(predeps, $1)=
-_LT_TAGVAR(postdeps, $1)=
-_LT_TAGVAR(compiler_lib_search_path, $1)=
-dnl we can't use the lt_simple_compile_test_code here,
-dnl because it contains code intended for an executable,
-dnl not a library. It's possible we should let each
-dnl tag define a new lt_????_link_test_code variable,
-dnl but it's only used here...
-m4_if([$1], [], [cat > conftest.$ac_ext <<_LT_EOF
-int a;
-void foo (void) { a = 0; }
-_LT_EOF
-], [$1], [CXX], [cat > conftest.$ac_ext <<_LT_EOF
-class Foo
-public:
- Foo (void) { a = 0; }
-private:
- int a;
-_LT_EOF
-], [$1], [F77], [cat > conftest.$ac_ext <<_LT_EOF
- subroutine foo
- implicit none
- integer*4 a
- a=0
- return
- end
-_LT_EOF
-], [$1], [FC], [cat > conftest.$ac_ext <<_LT_EOF
- subroutine foo
- implicit none
- integer a
- a=0
- return
- end
-_LT_EOF
-], [$1], [GCJ], [cat > conftest.$ac_ext <<_LT_EOF
-public class foo {
- private int a;
- public void bar (void) {
- a = 0;
-_LT_EOF
-], [$1], [GO], [cat > conftest.$ac_ext <<_LT_EOF
-package foo
-func foo() {
-_LT_EOF
-_lt_libdeps_save_CFLAGS=$CFLAGS
-case "$CC $CFLAGS " in #(
-*\ -flto*\ *) CFLAGS="$CFLAGS -fno-lto" ;;
-*\ -fwhopr*\ *) CFLAGS="$CFLAGS -fno-whopr" ;;
-*\ -fuse-linker-plugin*\ *) CFLAGS="$CFLAGS -fno-use-linker-plugin" ;;
-esac
-dnl Parse the compiler output and extract the necessary
-dnl objects, libraries and library flags.
-if AC_TRY_EVAL(ac_compile); then
- # Parse the compiler output and extract the necessary
- # objects, libraries and library flags.
- # Sentinel used to keep track of whether or not we are before
- # the conftest object file.
- pre_test_object_deps_done=no
- for p in `eval "$output_verbose_link_cmd"`; do
- case ${prev}${p} in
- -L* | -R* | -l*)
- # Some compilers place space between "-{L,R}" and the path.
- # Remove the space.
- if test $p = "-L" ||
- test $p = "-R"; then
- prev=$p
- continue
- fi
- # Expand the sysroot to ease extracting the directories later.
- if test -z "$prev"; then
- case $p in
- -L*) func_stripname_cnf '-L' '' "$p"; prev=-L; p=$func_stripname_result ;;
- -R*) func_stripname_cnf '-R' '' "$p"; prev=-R; p=$func_stripname_result ;;
- -l*) func_stripname_cnf '-l' '' "$p"; prev=-l; p=$func_stripname_result ;;
- esac
- fi
- case $p in
- =*) func_stripname_cnf '=' '' "$p"; p=$lt_sysroot$func_stripname_result ;;
- esac
- if test "$pre_test_object_deps_done" = no; then
- case ${prev} in
- -L | -R)
- # Internal compiler library paths should come after those
- # provided the user. The postdeps already come after the
- # user supplied libs so there is no need to process them.
- if test -z "$_LT_TAGVAR(compiler_lib_search_path, $1)"; then
- _LT_TAGVAR(compiler_lib_search_path, $1)="${prev}${p}"
- else
- _LT_TAGVAR(compiler_lib_search_path, $1)="${_LT_TAGVAR(compiler_lib_search_path, $1)} ${prev}${p}"
- fi
- # The "-l" case would never come before the object being
- # linked, so don't bother handling this case.
- esac
- else
- if test -z "$_LT_TAGVAR(postdeps, $1)"; then
- _LT_TAGVAR(postdeps, $1)="${prev}${p}"
- else
- _LT_TAGVAR(postdeps, $1)="${_LT_TAGVAR(postdeps, $1)} ${prev}${p}"
- fi
- fi
- prev=
- *.lto.$objext) ;; # Ignore GCC LTO objects
- *.$objext)
- # This assumes that the test object file only shows up
- # once in the compiler output.
- if test "$p" = "conftest.$objext"; then
- pre_test_object_deps_done=yes
- continue
- fi
- if test -z "$_LT_TAGVAR(predep_objects, $1)"; then
- _LT_TAGVAR(predep_objects, $1)="$p"
- else
- _LT_TAGVAR(predep_objects, $1)="$_LT_TAGVAR(predep_objects, $1) $p"
- fi
- else
- if test -z "$_LT_TAGVAR(postdep_objects, $1)"; then
- _LT_TAGVAR(postdep_objects, $1)="$p"
- else
- _LT_TAGVAR(postdep_objects, $1)="$_LT_TAGVAR(postdep_objects, $1) $p"
- fi
- fi
- *) ;; # Ignore the rest.
- esac
- done
- # Clean up.
- rm -f a.out a.exe
-else
- echo "libtool.m4: error: problem compiling $1 test program"
-fi
-$RM -f confest.$objext
-CFLAGS=$_lt_libdeps_save_CFLAGS
-# PORTME: override above test on systems where it is broken
-m4_if([$1], [CXX],
-[case $host_os in
-interix[[3-9]]*)
- # Interix 3.5 installs completely hosed .la files for C++, so rather than
- # hack all around it, let's just trust "g++" to DTRT.
- _LT_TAGVAR(predep_objects,$1)=
- _LT_TAGVAR(postdep_objects,$1)=
- _LT_TAGVAR(postdeps,$1)=
-linux*)
- *Sun\ C*)
- # Sun C++ 5.9
- # The more standards-conforming stlport4 library is
- # incompatible with the Cstd library. Avoid specifying
- # it if it's in CXXFLAGS. Ignore libCrun as
- # -library=stlport4 depends on it.
- case " $CXX $CXXFLAGS " in
- *" -library=stlport4 "*)
- solaris_use_stlport4=yes
- esac
- if test "$solaris_use_stlport4" != yes; then
- _LT_TAGVAR(postdeps,$1)='-library=Cstd -library=Crun'
- fi
- esac
-solaris*)
- CC* | sunCC*)
- esac
- # Adding this requires a known-good setup of shared libraries for
- # Sun compiler versions before 5.6, else PIC objects from an old
- # archive will be linked into the output, leading to subtle bugs.
- fi
- esac
-esac
-case " $_LT_TAGVAR(postdeps, $1) " in
-*" -lc "*) _LT_TAGVAR(archive_cmds_need_lc, $1)=no ;;
-esac
- _LT_TAGVAR(compiler_lib_search_dirs, $1)=
-if test -n "${_LT_TAGVAR(compiler_lib_search_path, $1)}"; then
- _LT_TAGVAR(compiler_lib_search_dirs, $1)=`echo " ${_LT_TAGVAR(compiler_lib_search_path, $1)}" | ${SED} -e 's! -L! !g' -e 's!^ !!'`
-fi
-_LT_TAGDECL([], [compiler_lib_search_dirs], [1],
- [The directories searched by this compiler when creating a shared library])
-_LT_TAGDECL([], [predep_objects], [1],
- [Dependencies to place before and after the objects being linked to
- create a shared library])
-_LT_TAGDECL([], [postdep_objects], [1])
-_LT_TAGDECL([], [predeps], [1])
-_LT_TAGDECL([], [postdeps], [1])
-_LT_TAGDECL([], [compiler_lib_search_path], [1],
- [The library search path used internally by the compiler when linking
- a shared library])
-])# _LT_SYS_HIDDEN_LIBDEPS
-# _LT_LANG_F77_CONFIG([TAG])
-# Ensure that the configuration variables for a Fortran 77 compiler are
-# suitably defined. These variables are subsequently used by _LT_CONFIG
-# to write the compiler configuration to `libtool'.
-m4_defun([_LT_LANG_F77_CONFIG],
-[AC_LANG_PUSH(Fortran 77)
-if test -z "$F77" || test "X$F77" = "Xno"; then
- _lt_disable_F77=yes
-fi
-# Source file extension for f77 test sources.
-ac_ext=f
-# Object file extension for compiled f77 test sources.
-objext=o
-# the F77 compiler isn't working. Some variables (like enable_shared)
-if test "$_lt_disable_F77" != yes; then
- lt_simple_compile_test_code="\
- subroutine t
- return
- end
- lt_simple_link_test_code="\
- program t
- end
- _LT_TAG_COMPILER
- lt_save_CC="$CC"
- lt_save_GCC=$GCC
- CC=${F77-"f77"}
- CFLAGS=$FFLAGS
- compiler=$CC
- GCC=$G77
- case $host_os in
- aix3*)
- fi
- aix[[4-9]]*)
- fi
- esac
- _LT_TAGVAR(GCC, $1)="$G77"
- ## CAVEAT EMPTOR:
- _LT_CONFIG($1)
- GCC=$lt_save_GCC
- CC="$lt_save_CC"
- CFLAGS="$lt_save_CFLAGS"
-fi # test "$_lt_disable_F77" != yes
-AC_LANG_POP
-])# _LT_LANG_F77_CONFIG
-# _LT_LANG_FC_CONFIG([TAG])
-# Ensure that the configuration variables for a Fortran compiler are
-m4_defun([_LT_LANG_FC_CONFIG],
-[AC_LANG_PUSH(Fortran)
-if test -z "$FC" || test "X$FC" = "Xno"; then
- _lt_disable_FC=yes
-fi
-# Source file extension for fc test sources.
-ac_ext=${ac_fc_srcext-f}
-# Object file extension for compiled fc test sources.
-objext=o
-# the FC compiler isn't working. Some variables (like enable_shared)
-if test "$_lt_disable_FC" != yes; then
- subroutine t
- return
- end
- program t
- end
- _LT_TAG_COMPILER
- lt_save_CC="$CC"
- lt_save_GCC=$GCC
- CC=${FC-"f95"}
- CFLAGS=$FCFLAGS
- compiler=$CC
- GCC=$ac_cv_fc_compiler_gnu
- case $host_os in
- aix3*)
- fi
- aix[[4-9]]*)
- fi
- esac
- _LT_TAGVAR(GCC, $1)="$ac_cv_fc_compiler_gnu"
- ## CAVEAT EMPTOR:
- _LT_CONFIG($1)
- GCC=$lt_save_GCC
- CC=$lt_save_CC
-fi # test "$_lt_disable_FC" != yes
-AC_LANG_POP
-])# _LT_LANG_FC_CONFIG
-# _LT_LANG_GCJ_CONFIG([TAG])
-# Ensure that the configuration variables for the GNU Java Compiler compiler
-# are suitably defined. These variables are subsequently used by _LT_CONFIG
-m4_defun([_LT_LANG_GCJ_CONFIG],
-[AC_REQUIRE([LT_PROG_GCJ])dnl
-AC_LANG_SAVE
-# Source file extension for Java test sources.
-ac_ext=java
-# Object file extension for compiled Java test sources.
-objext=o
-lt_simple_compile_test_code="class foo {}"
-lt_simple_link_test_code='public class conftest { public static void main(String[[]] argv) {}; }'
-# ltmain only uses $CC for tagged configurations so make sure $CC is set.
-_LT_TAG_COMPILER
-# Allow CC to be a program name with arguments.
-lt_save_CC=$CC
-lt_save_CFLAGS=$CFLAGS
-lt_save_GCC=$GCC
-GCC=yes
-CC=${GCJ-"gcj"}
-CFLAGS=$GCJFLAGS
-compiler=$CC
-_LT_TAGVAR(compiler, $1)=$CC
-_LT_TAGVAR(LD, $1)="$LD"
-_LT_CC_BASENAME([$compiler])
-# GCJ did not exist at the time GCC didn't implicitly link libc in.
- _LT_CONFIG($1)
-fi
-AC_LANG_RESTORE
-GCC=$lt_save_GCC
-CC=$lt_save_CC
-CFLAGS=$lt_save_CFLAGS
-])# _LT_LANG_GCJ_CONFIG
-# _LT_LANG_GO_CONFIG([TAG])
-# Ensure that the configuration variables for the GNU Go compiler
-m4_defun([_LT_LANG_GO_CONFIG],
-[AC_REQUIRE([LT_PROG_GO])dnl
-AC_LANG_SAVE
-# Source file extension for Go test sources.
-ac_ext=go
-# Object file extension for compiled Go test sources.
-objext=o
-lt_simple_compile_test_code="package main; func main() { }"
-lt_simple_link_test_code='package main; func main() { }'
-_LT_TAG_COMPILER
-lt_save_CC=$CC
-lt_save_GCC=$GCC
-GCC=yes
-CC=${GOC-"gccgo"}
-CFLAGS=$GOFLAGS
-compiler=$CC
-# Go did not exist at the time GCC didn't implicitly link libc in.
- _LT_CONFIG($1)
-fi
-AC_LANG_RESTORE
-GCC=$lt_save_GCC
-CC=$lt_save_CC
-])# _LT_LANG_GO_CONFIG
-# _LT_LANG_RC_CONFIG([TAG])
-# Ensure that the configuration variables for the Windows resource compiler
-m4_defun([_LT_LANG_RC_CONFIG],
-[AC_REQUIRE([LT_PROG_RC])dnl
-AC_LANG_SAVE
-# Source file extension for RC test sources.
-ac_ext=rc
-# Object file extension for compiled RC test sources.
-objext=o
-lt_simple_compile_test_code='sample MENU { MENUITEM "&Soup", 100, CHECKED }'
-lt_simple_link_test_code="$lt_simple_compile_test_code"
-_LT_TAG_COMPILER
-lt_save_CC="$CC"
-lt_save_GCC=$GCC
-GCC=
-CC=${RC-"windres"}
-CFLAGS=
-compiler=$CC
-_LT_TAGVAR(lt_cv_prog_compiler_c_o, $1)=yes
- _LT_CONFIG($1)
-fi
-GCC=$lt_save_GCC
-AC_LANG_RESTORE
-CC=$lt_save_CC
-])# _LT_LANG_RC_CONFIG
-# LT_PROG_GCJ
-AC_DEFUN([LT_PROG_GCJ],
-[m4_ifdef([AC_PROG_GCJ], [AC_PROG_GCJ],
- [m4_ifdef([A][M_PROG_GCJ], [A][M_PROG_GCJ],
- [AC_CHECK_TOOL(GCJ, gcj,)
- test "x${GCJFLAGS+set}" = xset || GCJFLAGS="-g -O2"
- AC_SUBST(GCJFLAGS)])])[]dnl
-# Old name:
-AU_ALIAS([LT_AC_PROG_GCJ], [LT_PROG_GCJ])
-dnl aclocal-1.4 backwards compatibility:
-dnl AC_DEFUN([LT_AC_PROG_GCJ], [])
-# LT_PROG_GO
-AC_DEFUN([LT_PROG_GO],
-[AC_CHECK_TOOL(GOC, gccgo,)
-# LT_PROG_RC
-AC_DEFUN([LT_PROG_RC],
-[AC_CHECK_TOOL(RC, windres,)
-# Old name:
-AU_ALIAS([LT_AC_PROG_RC], [LT_PROG_RC])
-dnl AC_DEFUN([LT_AC_PROG_RC], [])
-# _LT_DECL_EGREP
-# If we don't have a new enough Autoconf to choose the best grep
-# available, choose the one first in the user's PATH.
-m4_defun([_LT_DECL_EGREP],
-[AC_REQUIRE([AC_PROG_EGREP])dnl
-AC_REQUIRE([AC_PROG_FGREP])dnl
-test -z "$GREP" && GREP=grep
-_LT_DECL([], [GREP], [1], [A grep program that handles long lines])
-_LT_DECL([], [EGREP], [1], [An ERE matcher])
-_LT_DECL([], [FGREP], [1], [A literal string matcher])
-dnl Non-bleeding-edge autoconf doesn't subst GREP, so do it here too
-AC_SUBST([GREP])
-# _LT_DECL_OBJDUMP
-# If we don't have a new enough Autoconf to choose the best objdump
-m4_defun([_LT_DECL_OBJDUMP],
-[AC_CHECK_TOOL(OBJDUMP, objdump, false)
-test -z "$OBJDUMP" && OBJDUMP=objdump
-_LT_DECL([], [OBJDUMP], [1], [An object symbol dumper])
-AC_SUBST([OBJDUMP])
-# _LT_DECL_DLLTOOL
-# Ensure DLLTOOL variable is set.
-m4_defun([_LT_DECL_DLLTOOL],
-[AC_CHECK_TOOL(DLLTOOL, dlltool, false)
-test -z "$DLLTOOL" && DLLTOOL=dlltool
-_LT_DECL([], [DLLTOOL], [1], [DLL creation program])
-AC_SUBST([DLLTOOL])
-# _LT_DECL_SED
-# Check for a fully-functional sed program, that truncates
-# as few characters as possible. Prefer GNU sed if found.
-m4_defun([_LT_DECL_SED],
-[AC_PROG_SED
-test -z "$SED" && SED=sed
-Xsed="$SED -e 1s/^X//"
-_LT_DECL([], [SED], [1], [A sed program that does not truncate output])
-_LT_DECL([], [Xsed], ["\$SED -e 1s/^X//"],
- [Sed that helps us avoid accidentally triggering echo(1) options like -n])
-])# _LT_DECL_SED
-m4_ifndef([AC_PROG_SED], [
-# NOTE: This macro has been submitted for inclusion into #
-# GNU Autoconf as AC_PROG_SED. When it is available in #
-# a released version of Autoconf we should remove this #
-# macro and use it instead. #
-m4_defun([AC_PROG_SED],
-[AC_MSG_CHECKING([for a sed that does not truncate output])
-AC_CACHE_VAL(lt_cv_path_SED,
-[# Loop through the user's path and test for sed and gsed.
-# Then use that list of sed's as ones to test for truncation.
-as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-for as_dir in $PATH
-do
- IFS=$as_save_IFS
- test -z "$as_dir" && as_dir=.
- for lt_ac_prog in sed gsed; do
- for ac_exec_ext in '' $ac_executable_extensions; do
- if $as_executable_p "$as_dir/$lt_ac_prog$ac_exec_ext"; then
- lt_ac_sed_list="$lt_ac_sed_list $as_dir/$lt_ac_prog$ac_exec_ext"
- fi
- done
- done
-done
-IFS=$as_save_IFS
-lt_ac_max=0
-lt_ac_count=0
-# Add /usr/xpg4/bin/sed as it is typically found on Solaris
-# along with /bin/sed that truncates output.
-for lt_ac_sed in $lt_ac_sed_list /usr/xpg4/bin/sed; do
- test ! -f $lt_ac_sed && continue
- cat /dev/null > conftest.in
- lt_ac_count=0
- echo $ECHO_N "0123456789$ECHO_C" >conftest.in
- # Check for GNU sed and select it if it is found.
- if "$lt_ac_sed" --version 2>&1 < /dev/null | grep 'GNU' > /dev/null; then
- lt_cv_path_SED=$lt_ac_sed
- break
- fi
- while true; do
- cat conftest.in conftest.in >conftest.tmp
- mv conftest.tmp conftest.in
- cp conftest.in conftest.nl
- echo >>conftest.nl
- $lt_ac_sed -e 's/a$//' < conftest.nl >conftest.out || break
- cmp -s conftest.out conftest.nl || break
- # 10000 chars as input seems more than enough
- test $lt_ac_count -gt 10 && break
- lt_ac_count=`expr $lt_ac_count + 1`
- if test $lt_ac_count -gt $lt_ac_max; then
- lt_ac_max=$lt_ac_count
- fi
- done
-done
-SED=$lt_cv_path_SED
-AC_SUBST([SED])
-AC_MSG_RESULT([$SED])
-])#AC_PROG_SED
-])#m4_ifndef
-# Old name:
-AU_ALIAS([LT_AC_PROG_SED], [AC_PROG_SED])
-dnl AC_DEFUN([LT_AC_PROG_SED], [])
-# _LT_CHECK_SHELL_FEATURES
-# Find out whether the shell is Bourne or XSI compatible,
-# or has some other useful features.
-m4_defun([_LT_CHECK_SHELL_FEATURES],
-[AC_MSG_CHECKING([whether the shell understands some XSI constructs])
-# Try some XSI features
-xsi_shell=no
-( _lt_dummy="a/b/c"
- test "${_lt_dummy##*/},${_lt_dummy%/*},${_lt_dummy#??}"${_lt_dummy%"$_lt_dummy"}, \
- = c,a/b,b/c, \
- && eval 'test $(( 1 + 1 )) -eq 2 \
- && test "${#_lt_dummy}" -eq 5' ) >/dev/null 2>&1 \
- && xsi_shell=yes
-AC_MSG_RESULT([$xsi_shell])
-_LT_CONFIG_LIBTOOL_INIT([xsi_shell='$xsi_shell'])
-AC_MSG_CHECKING([whether the shell understands "+="])
-lt_shell_append=no
-( foo=bar; set foo baz; eval "$[1]+=\$[2]" && test "$foo" = barbaz ) \
- >/dev/null 2>&1 \
- && lt_shell_append=yes
-AC_MSG_RESULT([$lt_shell_append])
-_LT_CONFIG_LIBTOOL_INIT([lt_shell_append='$lt_shell_append'])
-if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
- lt_unset=unset
-else
- lt_unset=false
-fi
-_LT_DECL([], [lt_unset], [0], [whether the shell understands "unset"])dnl
-# test EBCDIC or ASCII
-case `echo X|tr X '\101'` in
- A) # ASCII based system
- # \n is not interpreted correctly by Solaris 8 /usr/ucb/tr
- lt_SP2NL='tr \040 \012'
- lt_NL2SP='tr \015\012 \040\040'
- *) # EBCDIC based system
- lt_SP2NL='tr \100 \n'
- lt_NL2SP='tr \r\n \100\100'
-esac
-_LT_DECL([SP2NL], [lt_SP2NL], [1], [turn spaces into newlines])dnl
-_LT_DECL([NL2SP], [lt_NL2SP], [1], [turn newlines into spaces])dnl
-])# _LT_CHECK_SHELL_FEATURES
-# _LT_PROG_FUNCTION_REPLACE (FUNCNAME, REPLACEMENT-BODY)
-# In `$cfgfile', look for function FUNCNAME delimited by `^FUNCNAME ()$' and
-# '^} FUNCNAME ', and replace its body with REPLACEMENT-BODY.
-m4_defun([_LT_PROG_FUNCTION_REPLACE],
-[dnl {
-sed -e '/^$1 ()$/,/^} # $1 /c\
-$1 ()\
-m4_bpatsubsts([$2], [$], [\\], [^\([ ]\)], [\\\1])
-} # Extended-shell $1 implementation' "$cfgfile" > $cfgfile.tmp \
- && mv -f "$cfgfile.tmp" "$cfgfile" \
- || (rm -f "$cfgfile" && cp "$cfgfile.tmp" "$cfgfile" && rm -f "$cfgfile.tmp")
-test 0 -eq $? || _lt_function_replace_fail=:
-# _LT_PROG_REPLACE_SHELLFNS
-# Replace existing portable implementations of several shell functions with
-# equivalent extended shell implementations where those features are available..
-m4_defun([_LT_PROG_REPLACE_SHELLFNS],
-[if test x"$xsi_shell" = xyes; then
- _LT_PROG_FUNCTION_REPLACE([func_dirname], [dnl
- case ${1} in
- */*) func_dirname_result="${1%/*}${2}" ;;
- * ) func_dirname_result="${3}" ;;
- esac])
- _LT_PROG_FUNCTION_REPLACE([func_basename], [dnl
- func_basename_result="${1##*/}"])
- _LT_PROG_FUNCTION_REPLACE([func_dirname_and_basename], [dnl
- case ${1} in
- esac
- _LT_PROG_FUNCTION_REPLACE([func_stripname], [dnl
- # pdksh 5.2.14 does not do ${X%$Y} correctly if both X and Y are
- # positional parameters, so assign one to ordinary parameter first.
- func_stripname_result=${3}
- func_stripname_result=${func_stripname_result#"${1}"}
- func_stripname_result=${func_stripname_result%"${2}"}])
- _LT_PROG_FUNCTION_REPLACE([func_split_long_opt], [dnl
- func_split_long_opt_name=${1%%=*}
- func_split_long_opt_arg=${1#*=}])
- _LT_PROG_FUNCTION_REPLACE([func_split_short_opt], [dnl
- func_split_short_opt_arg=${1#??}
- func_split_short_opt_name=${1%"$func_split_short_opt_arg"}])
- _LT_PROG_FUNCTION_REPLACE([func_lo2o], [dnl
- case ${1} in
- *.lo) func_lo2o_result=${1%.lo}.${objext} ;;
- *) func_lo2o_result=${1} ;;
- esac])
- _LT_PROG_FUNCTION_REPLACE([func_xform], [ func_xform_result=${1%.*}.lo])
- _LT_PROG_FUNCTION_REPLACE([func_arith], [ func_arith_result=$(( $[*] ))])
- _LT_PROG_FUNCTION_REPLACE([func_len], [ func_len_result=${#1}])
-fi
-if test x"$lt_shell_append" = xyes; then
- _LT_PROG_FUNCTION_REPLACE([func_append], [ eval "${1}+=\\${2}"])
- _LT_PROG_FUNCTION_REPLACE([func_append_quoted], [dnl
- func_quote_for_eval "${2}"
-dnl m4 expansion turns \\\\ into \\, and then the shell eval turns that into \
- eval "${1}+=\\\\ \\$func_quote_for_eval_result"])
- # Save a `func_append' function call where possible by direct use of '+='
- sed -e 's%func_append \([[a-zA-Z_]]\{1,\}\) "%\1+="%g' $cfgfile > $cfgfile.tmp \
- test 0 -eq $? || _lt_function_replace_fail=:
-else
- # Save a `func_append' function call even when '+=' is not available
- sed -e 's%func_append \([[a-zA-Z_]]\{1,\}\) "%\1="$\1%g' $cfgfile > $cfgfile.tmp \
-fi
-if test x"$_lt_function_replace_fail" = x":"; then
- AC_MSG_WARN([Unable to substitute extended shell functions in $ofile])
-fi
-# _LT_PATH_CONVERSION_FUNCTIONS
-# Determine which file name conversion functions should be used by
-# func_to_host_file (and, implicitly, by func_to_host_path). These are needed
-# for certain cross-compile configurations and native mingw.
-m4_defun([_LT_PATH_CONVERSION_FUNCTIONS],
-[AC_REQUIRE([AC_CANONICAL_HOST])dnl
-AC_REQUIRE([AC_CANONICAL_BUILD])dnl
-AC_MSG_CHECKING([how to convert $build file names to $host format])
-AC_CACHE_VAL(lt_cv_to_host_file_cmd,
-[case $host in
- *-*-mingw* )
- case $build in
- *-*-mingw* ) # actually msys
- lt_cv_to_host_file_cmd=func_convert_file_msys_to_w32
- *-*-cygwin* )
- lt_cv_to_host_file_cmd=func_convert_file_cygwin_to_w32
- * ) # otherwise, assume *nix
- lt_cv_to_host_file_cmd=func_convert_file_nix_to_w32
- esac
- *-*-cygwin* )
- case $build in
- lt_cv_to_host_file_cmd=func_convert_file_msys_to_cygwin
- *-*-cygwin* )
- lt_cv_to_host_file_cmd=func_convert_file_noop
- lt_cv_to_host_file_cmd=func_convert_file_nix_to_cygwin
- esac
- * ) # unhandled hosts (and "normal" native builds)
-esac
-to_host_file_cmd=$lt_cv_to_host_file_cmd
-AC_MSG_RESULT([$lt_cv_to_host_file_cmd])
-_LT_DECL([to_host_file_cmd], [lt_cv_to_host_file_cmd],
- [0], [convert $build file names to $host format])dnl
-AC_MSG_CHECKING([how to convert $build file names to toolchain format])
-AC_CACHE_VAL(lt_cv_to_tool_file_cmd,
-[#assume ordinary cross tools, or native build.
-lt_cv_to_tool_file_cmd=func_convert_file_noop
-case $host in
- *-*-mingw* )
- case $build in
- lt_cv_to_tool_file_cmd=func_convert_file_msys_to_w32
- esac
-esac
-to_tool_file_cmd=$lt_cv_to_tool_file_cmd
-AC_MSG_RESULT([$lt_cv_to_tool_file_cmd])
-_LT_DECL([to_tool_file_cmd], [lt_cv_to_tool_file_cmd],
- [0], [convert $build files to toolchain format])dnl
-])# _LT_PATH_CONVERSION_FUNCTIONS
-# Helper functions for option handling. -*- Autoconf -*-
-# Copyright (C) 2004, 2005, 2007, 2008, 2009 Free Software Foundation,
-# Inc.
-# Written by Gary V. Vaughan, 2004
-# This file is free software; the Free Software Foundation gives
-# unlimited permission to copy and/or distribute it, with or without
-# modifications, as long as this notice is preserved.
-# serial 7 ltoptions.m4
-# This is to help aclocal find these macros, as it can't see m4_define.
-AC_DEFUN([LTOPTIONS_VERSION], [m4_if([1])])
-# _LT_MANGLE_OPTION(MACRO-NAME, OPTION-NAME)
-m4_define([_LT_MANGLE_OPTION],
-[[_LT_OPTION_]m4_bpatsubst($1__$2, [[^a-zA-Z0-9_]], [_])])
-# _LT_SET_OPTION(MACRO-NAME, OPTION-NAME)
-# Set option OPTION-NAME for macro MACRO-NAME, and if there is a
-# matching handler defined, dispatch to it. Other OPTION-NAMEs are
-# saved as a flag.
-m4_define([_LT_SET_OPTION],
-[m4_define(_LT_MANGLE_OPTION([$1], [$2]))dnl
-m4_ifdef(_LT_MANGLE_DEFUN([$1], [$2]),
- _LT_MANGLE_DEFUN([$1], [$2]),
- [m4_warning([Unknown $1 option `$2'])])[]dnl
-# _LT_IF_OPTION(MACRO-NAME, OPTION-NAME, IF-SET, [IF-NOT-SET])
-# Execute IF-SET if OPTION is set, IF-NOT-SET otherwise.
-m4_define([_LT_IF_OPTION],
-[m4_ifdef(_LT_MANGLE_OPTION([$1], [$2]), [$3], [$4])])
-# _LT_UNLESS_OPTIONS(MACRO-NAME, OPTION-LIST, IF-NOT-SET)
-# Execute IF-NOT-SET unless all options in OPTION-LIST for MACRO-NAME
-# are set.
-m4_define([_LT_UNLESS_OPTIONS],
-[m4_foreach([_LT_Option], m4_split(m4_normalize([$2])),
- [m4_ifdef(_LT_MANGLE_OPTION([$1], _LT_Option),
- [m4_define([$0_found])])])[]dnl
-m4_ifdef([$0_found], [m4_undefine([$0_found])], [$3
-])[]dnl
-# _LT_SET_OPTIONS(MACRO-NAME, OPTION-LIST)
-# OPTION-LIST is a space-separated list of Libtool options associated
-# with MACRO-NAME. If any OPTION has a matching handler declared with
-# LT_OPTION_DEFINE, dispatch to that macro; otherwise complain about
-# the unknown option and exit.
-m4_defun([_LT_SET_OPTIONS],
-[# Set options
-m4_foreach([_LT_Option], m4_split(m4_normalize([$2])),
- [_LT_SET_OPTION([$1], _LT_Option)])
-m4_if([$1],[LT_INIT],[
- dnl
- dnl Simply set some default values (i.e off) if boolean options were not
- dnl specified:
- _LT_UNLESS_OPTIONS([LT_INIT], [dlopen], [enable_dlopen=no
- _LT_UNLESS_OPTIONS([LT_INIT], [win32-dll], [enable_win32_dll=no
- dnl
- dnl If no reference was made to various pairs of opposing options, then
- dnl we run the default mode handler for the pair. For example, if neither
- dnl `shared' nor `disable-shared' was passed, we enable building of shared
- dnl archives by default:
- _LT_UNLESS_OPTIONS([LT_INIT], [shared disable-shared], [_LT_ENABLE_SHARED])
- _LT_UNLESS_OPTIONS([LT_INIT], [static disable-static], [_LT_ENABLE_STATIC])
- _LT_UNLESS_OPTIONS([LT_INIT], [pic-only no-pic], [_LT_WITH_PIC])
- _LT_UNLESS_OPTIONS([LT_INIT], [fast-install disable-fast-install],
- [_LT_ENABLE_FAST_INSTALL])
-])# _LT_SET_OPTIONS
-# _LT_MANGLE_DEFUN(MACRO-NAME, OPTION-NAME)
-m4_define([_LT_MANGLE_DEFUN],
-[[_LT_OPTION_DEFUN_]m4_bpatsubst(m4_toupper([$1__$2]), [[^A-Z0-9_]], [_])])
-# LT_OPTION_DEFINE(MACRO-NAME, OPTION-NAME, CODE)
-m4_define([LT_OPTION_DEFINE],
-[m4_define(_LT_MANGLE_DEFUN([$1], [$2]), [$3])[]dnl
-])# LT_OPTION_DEFINE
-# dlopen
-LT_OPTION_DEFINE([LT_INIT], [dlopen], [enable_dlopen=yes
-AU_DEFUN([AC_LIBTOOL_DLOPEN],
-[_LT_SET_OPTION([LT_INIT], [dlopen])
-AC_DIAGNOSE([obsolete],
-[$0: Remove this warning and the call to _LT_SET_OPTION when you
-put the `dlopen' option into LT_INIT's first parameter.])
-dnl AC_DEFUN([AC_LIBTOOL_DLOPEN], [])
-# win32-dll
-# Declare package support for building win32 dll's.
-LT_OPTION_DEFINE([LT_INIT], [win32-dll],
-[enable_win32_dll=yes
-case $host in
-*-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-cegcc*)
- AC_CHECK_TOOL(AS, as, false)
- AC_CHECK_TOOL(DLLTOOL, dlltool, false)
- AC_CHECK_TOOL(OBJDUMP, objdump, false)
-esac
-test -z "$AS" && AS=as
-_LT_DECL([], [AS], [1], [Assembler program])dnl
-_LT_DECL([], [DLLTOOL], [1], [DLL creation program])dnl
-_LT_DECL([], [OBJDUMP], [1], [Object dumper program])dnl
-])# win32-dll
-AU_DEFUN([AC_LIBTOOL_WIN32_DLL],
-_LT_SET_OPTION([LT_INIT], [win32-dll])
-put the `win32-dll' option into LT_INIT's first parameter.])
-dnl AC_DEFUN([AC_LIBTOOL_WIN32_DLL], [])
-# _LT_ENABLE_SHARED([DEFAULT])
-# implement the --enable-shared flag, and supports the `shared' and
-# `disable-shared' LT_INIT options.
-# DEFAULT is either `yes' or `no'. If omitted, it defaults to `yes'.
-m4_define([_LT_ENABLE_SHARED],
-[m4_define([_LT_ENABLE_SHARED_DEFAULT], [m4_if($1, no, no, yes)])dnl
-AC_ARG_ENABLE([shared],
- [AS_HELP_STRING([--enable-shared@<:@=PKGS@:>@],
- [build shared libraries @<:@default=]_LT_ENABLE_SHARED_DEFAULT[@:>@])],
- [p=${PACKAGE-default}
- case $enableval in
- yes) enable_shared=yes ;;
- no) enable_shared=no ;;
- enable_shared=no
- # Look at the argument we got. We use all the common list separators.
- lt_save_ifs="$IFS"; IFS="${IFS}$PATH_SEPARATOR,"
- for pkg in $enableval; do
- IFS="$lt_save_ifs"
- if test "X$pkg" = "X$p"; then
- enable_shared=yes
- fi
- done
- esac],
- [enable_shared=]_LT_ENABLE_SHARED_DEFAULT)
- _LT_DECL([build_libtool_libs], [enable_shared], [0],
- [Whether or not to build shared libraries])
-])# _LT_ENABLE_SHARED
-LT_OPTION_DEFINE([LT_INIT], [shared], [_LT_ENABLE_SHARED([yes])])
-LT_OPTION_DEFINE([LT_INIT], [disable-shared], [_LT_ENABLE_SHARED([no])])
-# Old names:
-AC_DEFUN([AC_ENABLE_SHARED],
-[_LT_SET_OPTION([LT_INIT], m4_if([$1], [no], [disable-])[shared])
-AC_DEFUN([AC_DISABLE_SHARED],
-[_LT_SET_OPTION([LT_INIT], [disable-shared])
-AU_DEFUN([AM_ENABLE_SHARED], [AC_ENABLE_SHARED($@)])
-AU_DEFUN([AM_DISABLE_SHARED], [AC_DISABLE_SHARED($@)])
-dnl AC_DEFUN([AM_ENABLE_SHARED], [])
-dnl AC_DEFUN([AM_DISABLE_SHARED], [])
-# _LT_ENABLE_STATIC([DEFAULT])
-# implement the --enable-static flag, and support the `static' and
-# `disable-static' LT_INIT options.
-m4_define([_LT_ENABLE_STATIC],
-[m4_define([_LT_ENABLE_STATIC_DEFAULT], [m4_if($1, no, no, yes)])dnl
-AC_ARG_ENABLE([static],
- [AS_HELP_STRING([--enable-static@<:@=PKGS@:>@],
- [build static libraries @<:@default=]_LT_ENABLE_STATIC_DEFAULT[@:>@])],
- yes) enable_static=yes ;;
- no) enable_static=no ;;
- enable_static=no
- enable_static=yes
- fi
- done
- esac],
- [enable_static=]_LT_ENABLE_STATIC_DEFAULT)
- _LT_DECL([build_old_libs], [enable_static], [0],
- [Whether or not to build static libraries])
-])# _LT_ENABLE_STATIC
-LT_OPTION_DEFINE([LT_INIT], [static], [_LT_ENABLE_STATIC([yes])])
-LT_OPTION_DEFINE([LT_INIT], [disable-static], [_LT_ENABLE_STATIC([no])])
-# Old names:
-AC_DEFUN([AC_ENABLE_STATIC],
-[_LT_SET_OPTION([LT_INIT], m4_if([$1], [no], [disable-])[static])
-AC_DEFUN([AC_DISABLE_STATIC],
-[_LT_SET_OPTION([LT_INIT], [disable-static])
-AU_DEFUN([AM_ENABLE_STATIC], [AC_ENABLE_STATIC($@)])
-AU_DEFUN([AM_DISABLE_STATIC], [AC_DISABLE_STATIC($@)])
-dnl AC_DEFUN([AM_ENABLE_STATIC], [])
-dnl AC_DEFUN([AM_DISABLE_STATIC], [])
-# _LT_ENABLE_FAST_INSTALL([DEFAULT])
-# implement the --enable-fast-install flag, and support the `fast-install'
-# and `disable-fast-install' LT_INIT options.
-m4_define([_LT_ENABLE_FAST_INSTALL],
-[m4_define([_LT_ENABLE_FAST_INSTALL_DEFAULT], [m4_if($1, no, no, yes)])dnl
-AC_ARG_ENABLE([fast-install],
- [AS_HELP_STRING([--enable-fast-install@<:@=PKGS@:>@],
- [optimize for fast installation @<:@default=]_LT_ENABLE_FAST_INSTALL_DEFAULT[@:>@])],
- yes) enable_fast_install=yes ;;
- no) enable_fast_install=no ;;
- enable_fast_install=no
- enable_fast_install=yes
- fi
- done
- esac],
- [enable_fast_install=]_LT_ENABLE_FAST_INSTALL_DEFAULT)
-_LT_DECL([fast_install], [enable_fast_install], [0],
- [Whether or not to optimize for fast installation])dnl
-])# _LT_ENABLE_FAST_INSTALL
-LT_OPTION_DEFINE([LT_INIT], [fast-install], [_LT_ENABLE_FAST_INSTALL([yes])])
-LT_OPTION_DEFINE([LT_INIT], [disable-fast-install], [_LT_ENABLE_FAST_INSTALL([no])])
-# Old names:
-AU_DEFUN([AC_ENABLE_FAST_INSTALL],
-[_LT_SET_OPTION([LT_INIT], m4_if([$1], [no], [disable-])[fast-install])
-[$0: Remove this warning and the call to _LT_SET_OPTION when you put
-the `fast-install' option into LT_INIT's first parameter.])
-AU_DEFUN([AC_DISABLE_FAST_INSTALL],
-[_LT_SET_OPTION([LT_INIT], [disable-fast-install])
-the `disable-fast-install' option into LT_INIT's first parameter.])
-dnl AC_DEFUN([AC_ENABLE_FAST_INSTALL], [])
-dnl AC_DEFUN([AM_DISABLE_FAST_INSTALL], [])
-# _LT_WITH_PIC([MODE])
-# implement the --with-pic flag, and support the `pic-only' and `no-pic'
-# LT_INIT options.
-# MODE is either `yes' or `no'. If omitted, it defaults to `both'.
-m4_define([_LT_WITH_PIC],
-[AC_ARG_WITH([pic],
- [AS_HELP_STRING([--with-pic@<:@=PKGS@:>@],
- [try to use only PIC/non-PIC objects @<:@default=use both@:>@])],
- [lt_p=${PACKAGE-default}
- case $withval in
- yes|no) pic_mode=$withval ;;
- pic_mode=default
- for lt_pkg in $withval; do
- if test "X$lt_pkg" = "X$lt_p"; then
- pic_mode=yes
- fi
- done
- esac],
- [pic_mode=default])
-test -z "$pic_mode" && pic_mode=m4_default([$1], [default])
-_LT_DECL([], [pic_mode], [0], [What type of objects to build])dnl
-])# _LT_WITH_PIC
-LT_OPTION_DEFINE([LT_INIT], [pic-only], [_LT_WITH_PIC([yes])])
-LT_OPTION_DEFINE([LT_INIT], [no-pic], [_LT_WITH_PIC([no])])
-# Old name:
-AU_DEFUN([AC_LIBTOOL_PICMODE],
-[_LT_SET_OPTION([LT_INIT], [pic-only])
-put the `pic-only' option into LT_INIT's first parameter.])
-dnl AC_DEFUN([AC_LIBTOOL_PICMODE], [])
-m4_define([_LTDL_MODE], [])
-LT_OPTION_DEFINE([LTDL_INIT], [nonrecursive],
- [m4_define([_LTDL_MODE], [nonrecursive])])
-LT_OPTION_DEFINE([LTDL_INIT], [recursive],
- [m4_define([_LTDL_MODE], [recursive])])
-LT_OPTION_DEFINE([LTDL_INIT], [subproject],
- [m4_define([_LTDL_MODE], [subproject])])
-m4_define([_LTDL_TYPE], [])
-LT_OPTION_DEFINE([LTDL_INIT], [installable],
- [m4_define([_LTDL_TYPE], [installable])])
-LT_OPTION_DEFINE([LTDL_INIT], [convenience],
- [m4_define([_LTDL_TYPE], [convenience])])
-# ltsugar.m4 -- libtool m4 base layer. -*-Autoconf-*-
-# Copyright (C) 2004, 2005, 2007, 2008 Free Software Foundation, Inc.
-# serial 6 ltsugar.m4
-AC_DEFUN([LTSUGAR_VERSION], [m4_if([0.1])])
-# lt_join(SEP, ARG1, [ARG2...])
-# Produce ARG1SEPARG2...SEPARGn, omitting [] arguments and their
-# associated separator.
-# Needed until we can rely on m4_join from Autoconf 2.62, since all earlier
-# versions in m4sugar had bugs.
-m4_define([lt_join],
-[m4_if([$#], [1], [],
- [$#], [2], [[$2]],
- [m4_if([$2], [], [], [[$2]_])$0([$1], m4_shift(m4_shift($@)))])])
-m4_define([_lt_join],
-[m4_if([$#$2], [2], [],
- [m4_if([$2], [], [], [[$1$2]])$0([$1], m4_shift(m4_shift($@)))])])
-# lt_car(LIST)
-# lt_cdr(LIST)
-# Manipulate m4 lists.
-# These macros are necessary as long as will still need to support
-# Autoconf-2.59 which quotes differently.
-m4_define([lt_car], [[$1]])
-m4_define([lt_cdr],
-[m4_if([$#], 0, [m4_fatal([$0: cannot be called without arguments])],
- [$#], 1, [],
- [m4_dquote(m4_shift($@))])])
-m4_define([lt_unquote], $1)
-# lt_append(MACRO-NAME, STRING, [SEPARATOR])
-# Redefine MACRO-NAME to hold its former content plus `SEPARATOR'`STRING'.
-# Note that neither SEPARATOR nor STRING are expanded; they are appended
-# to MACRO-NAME as is (leaving the expansion for when MACRO-NAME is invoked).
-# No SEPARATOR is output if MACRO-NAME was previously undefined (different
-# than defined and empty).
-# This macro is needed until we can rely on Autoconf 2.62, since earlier
-# versions of m4sugar mistakenly expanded SEPARATOR but not STRING.
-m4_define([lt_append],
-[m4_define([$1],
- m4_ifdef([$1], [m4_defn([$1])[$3]])[$2])])
-# lt_combine(SEP, PREFIX-LIST, INFIX, SUFFIX1, [SUFFIX2...])
-# Produce a SEP delimited list of all paired combinations of elements of
-# PREFIX-LIST with SUFFIX1 through SUFFIXn. Each element of the list
-# has the form PREFIXmINFIXSUFFIXn.
-# Needed until we can rely on m4_combine added in Autoconf 2.62.
-m4_define([lt_combine],
-[m4_if(m4_eval([$# > 3]), [1],
- [m4_pushdef([_Lt_sep], [m4_define([_Lt_sep], m4_defn([lt_car]))])]]dnl
-[[m4_foreach([_Lt_prefix], [$2],
- [m4_foreach([_Lt_suffix],
- ]m4_dquote(m4_dquote(m4_shift(m4_shift(m4_shift($@)))))[,
- [_Lt_sep([$1])[]m4_defn([_Lt_prefix])[$3]m4_defn([_Lt_suffix])])])])])
-# lt_if_append_uniq(MACRO-NAME, VARNAME, [SEPARATOR], [UNIQ], [NOT-UNIQ])
-# Iff MACRO-NAME does not yet contain VARNAME, then append it (delimited
-# by SEPARATOR if supplied) and expand UNIQ, else NOT-UNIQ.
-m4_define([lt_if_append_uniq],
-[m4_ifdef([$1],
- [m4_if(m4_index([$3]m4_defn([$1])[$3], [$3$2$3]), [-1],
- [lt_append([$1], [$2], [$3])$4],
- [$5])],
- [lt_append([$1], [$2], [$3])$4])])
-# lt_dict_add(DICT, KEY, VALUE)
-m4_define([lt_dict_add],
-[m4_define([$1($2)], [$3])])
-# lt_dict_add_subkey(DICT, KEY, SUBKEY, VALUE)
-m4_define([lt_dict_add_subkey],
-[m4_define([$1($2:$3)], [$4])])
-# lt_dict_fetch(DICT, KEY, [SUBKEY])
-m4_define([lt_dict_fetch],
-[m4_ifval([$3],
- m4_ifdef([$1($2:$3)], [m4_defn([$1($2:$3)])]),
- m4_ifdef([$1($2)], [m4_defn([$1($2)])]))])
-# lt_if_dict_fetch(DICT, KEY, [SUBKEY], VALUE, IF-TRUE, [IF-FALSE])
-m4_define([lt_if_dict_fetch],
-[m4_if(lt_dict_fetch([$1], [$2], [$3]), [$4],
- [$5],
- [$6])])
-# lt_dict_filter(DICT, [SUBKEY], VALUE, [SEPARATOR], KEY, [...])
-m4_define([lt_dict_filter],
-[m4_if([$5], [], [],
- [lt_join(m4_quote(m4_default([$4], [[, ]])),
- lt_unquote(m4_split(m4_normalize(m4_foreach(_Lt_key, lt_car([m4_shiftn(4, $@)]),
- [lt_if_dict_fetch([$1], _Lt_key, [$2], [$3], [_Lt_key ])])))))])[]dnl
-# ltversion.m4 -- version numbers -*- Autoconf -*-
-# Copyright (C) 2004 Free Software Foundation, Inc.
-# Written by Scott James Remnant, 2004
-# @configure_input@
-# serial 3337 ltversion.m4
-# This file is part of GNU Libtool
-m4_define([LT_PACKAGE_VERSION], [2.4.2])
-m4_define([LT_PACKAGE_REVISION], [1.3337])
-AC_DEFUN([LTVERSION_VERSION],
-[macro_version='2.4.2'
-macro_revision='1.3337'
-_LT_DECL(, macro_version, 0, [Which release of libtool.m4 was used?])
-_LT_DECL(, macro_revision, 0)
-# lt~obsolete.m4 -- aclocal satisfying obsolete definitions. -*-Autoconf-*-
-# Copyright (C) 2004, 2005, 2007, 2009 Free Software Foundation, Inc.
-# Written by Scott James Remnant, 2004.
-# serial 5 lt~obsolete.m4
-# These exist entirely to fool aclocal when bootstrapping libtool.
-# In the past libtool.m4 has provided macros via AC_DEFUN (or AU_DEFUN)
-# which have later been changed to m4_define as they aren't part of the
-# exported API, or moved to Autoconf or Automake where they belong.
-# The trouble is, aclocal is a bit thick. It'll see the old AC_DEFUN
-# in /usr/share/aclocal/libtool.m4 and remember it, then when it sees us
-# using a macro with the same name in our local m4/libtool.m4 it'll
-# pull the old libtool.m4 in (it doesn't see our shiny new m4_define
-# and doesn't know about Autoconf macros at all.)
-# So we provide this file, which has a silly filename so it's always
-# included after everything else. This provides aclocal with the
-# AC_DEFUNs it wants, but when m4 processes it, it doesn't do anything
-# because those macros already exist, or will be overwritten later.
-# We use AC_DEFUN over AU_DEFUN for compatibility with aclocal-1.6.
-# Anytime we withdraw an AC_DEFUN or AU_DEFUN, remember to add it here.
-# Yes, that means every name once taken will need to remain here until
-# we give up compatibility with versions before 1.7, at which point
-# we need to keep only those names which we still refer to.
-AC_DEFUN([LTOBSOLETE_VERSION], [m4_if([1])])
-m4_ifndef([AC_LIBTOOL_LINKER_OPTION], [AC_DEFUN([AC_LIBTOOL_LINKER_OPTION])])
-m4_ifndef([AC_PROG_EGREP], [AC_DEFUN([AC_PROG_EGREP])])
-m4_ifndef([_LT_AC_PROG_ECHO_BACKSLASH], [AC_DEFUN([_LT_AC_PROG_ECHO_BACKSLASH])])
-m4_ifndef([_LT_AC_SHELL_INIT], [AC_DEFUN([_LT_AC_SHELL_INIT])])
-m4_ifndef([_LT_AC_SYS_LIBPATH_AIX], [AC_DEFUN([_LT_AC_SYS_LIBPATH_AIX])])
-m4_ifndef([_LT_PROG_LTMAIN], [AC_DEFUN([_LT_PROG_LTMAIN])])
-m4_ifndef([_LT_AC_TAGVAR], [AC_DEFUN([_LT_AC_TAGVAR])])
-m4_ifndef([AC_LTDL_ENABLE_INSTALL], [AC_DEFUN([AC_LTDL_ENABLE_INSTALL])])
-m4_ifndef([AC_LTDL_PREOPEN], [AC_DEFUN([AC_LTDL_PREOPEN])])
-m4_ifndef([_LT_AC_SYS_COMPILER], [AC_DEFUN([_LT_AC_SYS_COMPILER])])
-m4_ifndef([_LT_AC_LOCK], [AC_DEFUN([_LT_AC_LOCK])])
-m4_ifndef([AC_LIBTOOL_SYS_OLD_ARCHIVE], [AC_DEFUN([AC_LIBTOOL_SYS_OLD_ARCHIVE])])
-m4_ifndef([_LT_AC_TRY_DLOPEN_SELF], [AC_DEFUN([_LT_AC_TRY_DLOPEN_SELF])])
-m4_ifndef([AC_LIBTOOL_PROG_CC_C_O], [AC_DEFUN([AC_LIBTOOL_PROG_CC_C_O])])
-m4_ifndef([AC_LIBTOOL_SYS_HARD_LINK_LOCKS], [AC_DEFUN([AC_LIBTOOL_SYS_HARD_LINK_LOCKS])])
-m4_ifndef([AC_LIBTOOL_OBJDIR], [AC_DEFUN([AC_LIBTOOL_OBJDIR])])
-m4_ifndef([AC_LTDL_OBJDIR], [AC_DEFUN([AC_LTDL_OBJDIR])])
-m4_ifndef([AC_LIBTOOL_PROG_LD_HARDCODE_LIBPATH], [AC_DEFUN([AC_LIBTOOL_PROG_LD_HARDCODE_LIBPATH])])
-m4_ifndef([AC_LIBTOOL_SYS_LIB_STRIP], [AC_DEFUN([AC_LIBTOOL_SYS_LIB_STRIP])])
-m4_ifndef([AC_PATH_MAGIC], [AC_DEFUN([AC_PATH_MAGIC])])
-m4_ifndef([AC_PROG_LD_GNU], [AC_DEFUN([AC_PROG_LD_GNU])])
-m4_ifndef([AC_PROG_LD_RELOAD_FLAG], [AC_DEFUN([AC_PROG_LD_RELOAD_FLAG])])
-m4_ifndef([AC_DEPLIBS_CHECK_METHOD], [AC_DEFUN([AC_DEPLIBS_CHECK_METHOD])])
-m4_ifndef([AC_LIBTOOL_PROG_COMPILER_NO_RTTI], [AC_DEFUN([AC_LIBTOOL_PROG_COMPILER_NO_RTTI])])
-m4_ifndef([AC_LIBTOOL_SYS_GLOBAL_SYMBOL_PIPE], [AC_DEFUN([AC_LIBTOOL_SYS_GLOBAL_SYMBOL_PIPE])])
-m4_ifndef([AC_LIBTOOL_PROG_COMPILER_PIC], [AC_DEFUN([AC_LIBTOOL_PROG_COMPILER_PIC])])
-m4_ifndef([AC_LIBTOOL_PROG_LD_SHLIBS], [AC_DEFUN([AC_LIBTOOL_PROG_LD_SHLIBS])])
-m4_ifndef([AC_LIBTOOL_POSTDEP_PREDEP], [AC_DEFUN([AC_LIBTOOL_POSTDEP_PREDEP])])
-m4_ifndef([LT_AC_PROG_EGREP], [AC_DEFUN([LT_AC_PROG_EGREP])])
-m4_ifndef([LT_AC_PROG_SED], [AC_DEFUN([LT_AC_PROG_SED])])
-m4_ifndef([_LT_CC_BASENAME], [AC_DEFUN([_LT_CC_BASENAME])])
-m4_ifndef([_LT_COMPILER_BOILERPLATE], [AC_DEFUN([_LT_COMPILER_BOILERPLATE])])
-m4_ifndef([_LT_LINKER_BOILERPLATE], [AC_DEFUN([_LT_LINKER_BOILERPLATE])])
-m4_ifndef([_AC_PROG_LIBTOOL], [AC_DEFUN([_AC_PROG_LIBTOOL])])
-m4_ifndef([AC_LIBTOOL_SETUP], [AC_DEFUN([AC_LIBTOOL_SETUP])])
-m4_ifndef([_LT_AC_CHECK_DLFCN], [AC_DEFUN([_LT_AC_CHECK_DLFCN])])
-m4_ifndef([AC_LIBTOOL_SYS_DYNAMIC_LINKER], [AC_DEFUN([AC_LIBTOOL_SYS_DYNAMIC_LINKER])])
-m4_ifndef([_LT_AC_TAGCONFIG], [AC_DEFUN([_LT_AC_TAGCONFIG])])
-m4_ifndef([AC_DISABLE_FAST_INSTALL], [AC_DEFUN([AC_DISABLE_FAST_INSTALL])])
-m4_ifndef([_LT_AC_LANG_CXX], [AC_DEFUN([_LT_AC_LANG_CXX])])
-m4_ifndef([_LT_AC_LANG_F77], [AC_DEFUN([_LT_AC_LANG_F77])])
-m4_ifndef([_LT_AC_LANG_GCJ], [AC_DEFUN([_LT_AC_LANG_GCJ])])
-m4_ifndef([AC_LIBTOOL_LANG_C_CONFIG], [AC_DEFUN([AC_LIBTOOL_LANG_C_CONFIG])])
-m4_ifndef([_LT_AC_LANG_C_CONFIG], [AC_DEFUN([_LT_AC_LANG_C_CONFIG])])
-m4_ifndef([AC_LIBTOOL_LANG_CXX_CONFIG], [AC_DEFUN([AC_LIBTOOL_LANG_CXX_CONFIG])])
-m4_ifndef([_LT_AC_LANG_CXX_CONFIG], [AC_DEFUN([_LT_AC_LANG_CXX_CONFIG])])
-m4_ifndef([AC_LIBTOOL_LANG_F77_CONFIG], [AC_DEFUN([AC_LIBTOOL_LANG_F77_CONFIG])])
-m4_ifndef([_LT_AC_LANG_F77_CONFIG], [AC_DEFUN([_LT_AC_LANG_F77_CONFIG])])
-m4_ifndef([AC_LIBTOOL_LANG_GCJ_CONFIG], [AC_DEFUN([AC_LIBTOOL_LANG_GCJ_CONFIG])])
-m4_ifndef([_LT_AC_LANG_GCJ_CONFIG], [AC_DEFUN([_LT_AC_LANG_GCJ_CONFIG])])
-m4_ifndef([AC_LIBTOOL_LANG_RC_CONFIG], [AC_DEFUN([AC_LIBTOOL_LANG_RC_CONFIG])])
-m4_ifndef([_LT_AC_LANG_RC_CONFIG], [AC_DEFUN([_LT_AC_LANG_RC_CONFIG])])
-m4_ifndef([AC_LIBTOOL_CONFIG], [AC_DEFUN([AC_LIBTOOL_CONFIG])])
-m4_ifndef([_LT_AC_FILE_LTDLL_C], [AC_DEFUN([_LT_AC_FILE_LTDLL_C])])
-m4_ifndef([_LT_REQUIRED_DARWIN_CHECKS], [AC_DEFUN([_LT_REQUIRED_DARWIN_CHECKS])])
-m4_ifndef([_LT_AC_PROG_CXXCPP], [AC_DEFUN([_LT_AC_PROG_CXXCPP])])
-m4_ifndef([_LT_PREPARE_SED_QUOTE_VARS], [AC_DEFUN([_LT_PREPARE_SED_QUOTE_VARS])])
-m4_ifndef([_LT_PROG_ECHO_BACKSLASH], [AC_DEFUN([_LT_PROG_ECHO_BACKSLASH])])
-m4_ifndef([_LT_PROG_F77], [AC_DEFUN([_LT_PROG_F77])])
-m4_ifndef([_LT_PROG_FC], [AC_DEFUN([_LT_PROG_FC])])
-m4_ifndef([_LT_PROG_CXX], [AC_DEFUN([_LT_PROG_CXX])])
-# Copyright (C) 2002, 2003, 2005, 2006, 2007, 2008, 2011 Free Software
-# Foundation, Inc.
-# gives unlimited permission to copy and/or distribute it,
-# with or without modifications, as long as this notice is preserved.
-# serial 1
-# AM_AUTOMAKE_VERSION(VERSION)
-# Automake X.Y traces this macro to ensure aclocal.m4 has been
-# generated from the m4 files accompanying Automake X.Y.
-# (This private macro should not be called outside this file.)
-AC_DEFUN([AM_AUTOMAKE_VERSION],
-[am__api_version='1.11'
-dnl Some users find AM_AUTOMAKE_VERSION and mistake it for a way to
-dnl require some minimum version. Point them to the right macro.
-m4_if([$1], [1.11.3], [],
- [AC_FATAL([Do not call $0, use AM_INIT_AUTOMAKE([$1]).])])dnl
-# _AM_AUTOCONF_VERSION(VERSION)
-# aclocal traces this macro to find the Autoconf version.
-# This is a private macro too. Using m4_define simplifies
-# the logic in aclocal, which can simply ignore this definition.
-m4_define([_AM_AUTOCONF_VERSION], [])
-# AM_SET_CURRENT_AUTOMAKE_VERSION
-# Call AM_AUTOMAKE_VERSION and AM_AUTOMAKE_VERSION so they can be traced.
-# This function is AC_REQUIREd by AM_INIT_AUTOMAKE.
-AC_DEFUN([AM_SET_CURRENT_AUTOMAKE_VERSION],
-[AM_AUTOMAKE_VERSION([1.11.3])dnl
-m4_ifndef([AC_AUTOCONF_VERSION],
- [m4_copy([m4_PACKAGE_VERSION], [AC_AUTOCONF_VERSION])])dnl
-_AM_AUTOCONF_VERSION(m4_defn([AC_AUTOCONF_VERSION]))])
-# AM_AUX_DIR_EXPAND -*- Autoconf -*-
-# Copyright (C) 2001, 2003, 2005, 2011 Free Software Foundation, Inc.
-# serial 1
-# For projects using AC_CONFIG_AUX_DIR([foo]), Autoconf sets
-# $ac_aux_dir to `$srcdir/foo'. In other projects, it is set to
-# `$srcdir', `$srcdir/..', or `$srcdir/../..'.
-# Of course, Automake must honor this variable whenever it calls a
-# tool from the auxiliary directory. The problem is that $srcdir (and
-# therefore $ac_aux_dir as well) can be either absolute or relative,
-# depending on how configure is run. This is pretty annoying, since
-# it makes $ac_aux_dir quite unusable in subdirectories: in the top
-# source directory, any form will work fine, but in subdirectories a
-# relative path needs to be adjusted first.
-# $ac_aux_dir/missing
-# fails when called from a subdirectory if $ac_aux_dir is relative
-# $top_srcdir/$ac_aux_dir/missing
-# fails if $ac_aux_dir is absolute,
-# fails when called from a subdirectory in a VPATH build with
-# a relative $ac_aux_dir
-# The reason of the latter failure is that $top_srcdir and $ac_aux_dir
-# are both prefixed by $srcdir. In an in-source build this is usually
-# harmless because $srcdir is `.', but things will broke when you
-# start a VPATH build or use an absolute $srcdir.
-# So we could use something similar to $top_srcdir/$ac_aux_dir/missing,
-# iff we strip the leading $srcdir from $ac_aux_dir. That would be:
-# am_aux_dir='\$(top_srcdir)/'`expr "$ac_aux_dir" : "$srcdir//*\(.*\)"`
-# and then we would define $MISSING as
-# MISSING="\${SHELL} $am_aux_dir/missing"
-# This will work as long as MISSING is not called from configure, because
-# unfortunately $(top_srcdir) has no meaning in configure.
-# However there are other variables, like CC, which are often used in
-# configure, and could therefore not use this "fixed" $ac_aux_dir.
-# Another solution, used here, is to always expand $ac_aux_dir to an
-# absolute PATH. The drawback is that using absolute paths prevent a
-# configured tree to be moved without reconfiguration.
-AC_DEFUN([AM_AUX_DIR_EXPAND],
-[dnl Rely on autoconf to set up CDPATH properly.
-AC_PREREQ([2.50])dnl
-# expand $ac_aux_dir to an absolute path
-am_aux_dir=`cd $ac_aux_dir && pwd`
-# AM_CONDITIONAL -*- Autoconf -*-
-# Copyright (C) 1997, 2000, 2001, 2003, 2004, 2005, 2006, 2008
-# Free Software Foundation, Inc.
-# serial 9
-# AM_CONDITIONAL(NAME, SHELL-CONDITION)
-# Define a conditional.
-AC_DEFUN([AM_CONDITIONAL],
-[AC_PREREQ(2.52)dnl
- ifelse([$1], [TRUE], [AC_FATAL([$0: invalid condition: $1])],
- [$1], [FALSE], [AC_FATAL([$0: invalid condition: $1])])dnl
-AC_SUBST([$1_TRUE])dnl
-AC_SUBST([$1_FALSE])dnl
-_AM_SUBST_NOTMAKE([$1_TRUE])dnl
-_AM_SUBST_NOTMAKE([$1_FALSE])dnl
-m4_define([_AM_COND_VALUE_$1], [$2])dnl
-if $2; then
- $1_TRUE=
- $1_FALSE='#'
-else
- $1_TRUE='#'
- $1_FALSE=
-fi
-AC_CONFIG_COMMANDS_PRE(
-[if test -z "${$1_TRUE}" && test -z "${$1_FALSE}"; then
- AC_MSG_ERROR([[conditional "$1" was never defined.
-Usually this means the macro was only invoked conditionally.]])
-fi])])
-# Copyright (C) 1999, 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2009,
-# 2010, 2011 Free Software Foundation, Inc.
-# serial 12
-# There are a few dirty hacks below to avoid letting `AC_PROG_CC' be
-# written in clear, in which case automake, when reading aclocal.m4,
-# will think it sees a *use*, and therefore will trigger all it's
-# C support machinery. Also note that it means that autoscan, seeing
-# CC etc. in the Makefile, will ask for an AC_PROG_CC use...
-# _AM_DEPENDENCIES(NAME)
-# See how the compiler implements dependency checking.
-# NAME is "CC", "CXX", "GCJ", or "OBJC".
-# We try a few techniques and use that to set a single cache variable.
-# We don't AC_REQUIRE the corresponding AC_PROG_CC since the latter was
-# modified to invoke _AM_DEPENDENCIES(CC); we would have a circular
-# dependency, and given that the user is not expected to run this macro,
-# just rely on AC_PROG_CC.
-AC_DEFUN([_AM_DEPENDENCIES],
-[AC_REQUIRE([AM_SET_DEPDIR])dnl
-AC_REQUIRE([AM_OUTPUT_DEPENDENCY_COMMANDS])dnl
-AC_REQUIRE([AM_MAKE_INCLUDE])dnl
-AC_REQUIRE([AM_DEP_TRACK])dnl
-ifelse([$1], CC, [depcc="$CC" am_compiler_list=],
- [$1], CXX, [depcc="$CXX" am_compiler_list=],
- [$1], OBJC, [depcc="$OBJC" am_compiler_list='gcc3 gcc'],
- [$1], UPC, [depcc="$UPC" am_compiler_list=],
- [$1], GCJ, [depcc="$GCJ" am_compiler_list='gcc3 gcc'],
- [depcc="$$1" am_compiler_list=])
-AC_CACHE_CHECK([dependency style of $depcc],
- [am_cv_$1_dependencies_compiler_type],
-[if test -z "$AMDEP_TRUE" && test -f "$am_depcomp"; then
- # We make a subdir and do the tests there. Otherwise we can end up
- # making bogus files that we don't know about and never remove. For
- # instance it was reported that on HP-UX the gcc test will end up
- # making a dummy file named `D' -- because `-MD' means `put the output
- # in D'.
- rm -rf conftest.dir
- mkdir conftest.dir
- # Copy depcomp to subdir because otherwise we won't find it if we're
- # using a relative directory.
- cp "$am_depcomp" conftest.dir
- cd conftest.dir
- # We will build objects and dependencies in a subdirectory because
- # it helps to detect inapplicable dependency modes. For instance
- # both Tru64's cc and ICC support -MD to output dependencies as a
- # side effect of compilation, but ICC will put the dependencies in
- # the current directory while Tru64 will put them in the object
- # directory.
- mkdir sub
- am_cv_$1_dependencies_compiler_type=none
- if test "$am_compiler_list" = ""; then
- am_compiler_list=`sed -n ['s/^#*\([a-zA-Z0-9]*\))$/\1/p'] < ./depcomp`
- fi
- am__universal=false
- m4_case([$1], [CC],
- [case " $depcc " in #(
- *\ -arch\ *\ -arch\ *) am__universal=true ;;
- esac],
- [CXX],
- esac])
- for depmode in $am_compiler_list; do
- # Setup a source with many dependencies, because some compilers
- # like to wrap large dependency lists on column 80 (with \), and
- # we should not choose a depcomp mode which is confused by this.
- # We need to recreate these files for each test, as the compiler may
- # overwrite some of them when testing with obscure command lines.
- # This happens at least with the AIX C compiler.
- : > sub/conftest.c
- for i in 1 2 3 4 5 6; do
- echo '#include "conftst'$i'.h"' >> sub/conftest.c
- # Using `: > sub/conftst$i.h' creates only sub/conftst1.h with
- # Solaris 8's {/usr,}/bin/sh.
- touch sub/conftst$i.h
- done
- echo "${am__include} ${am__quote}sub/conftest.Po${am__quote}" > confmf
- # We check with `-c' and `-o' for the sake of the "dashmstdout"
- # mode. It turns out that the SunPro C++ compiler does not properly
- # handle `-M -o', and we need to detect this. Also, some Intel
- # versions had trouble with output in subdirs
- am__obj=sub/conftest.${OBJEXT-o}
- am__minus_obj="-o $am__obj"
- case $depmode in
- gcc)
- # This depmode causes a compiler race in universal mode.
- test "$am__universal" = false || continue
- nosideeffect)
- # after this tag, mechanisms are not by side-effect, so they'll
- # only be used when explicitly requested
- if test "x$enable_dependency_tracking" = xyes; then
- continue
- else
- break
- fi
- msvc7 | msvc7msys | msvisualcpp | msvcmsys)
- # This compiler won't grok `-c -o', but also, the minuso test has
- # not run yet. These depmodes are late enough in the game, and
- # so weak that their functioning should not be impacted.
- am__obj=conftest.${OBJEXT-o}
- am__minus_obj=
- none) break ;;
- esac
- if depmode=$depmode \
- source=sub/conftest.c object=$am__obj \
- depfile=sub/conftest.Po tmpdepfile=sub/conftest.TPo \
- $SHELL ./depcomp $depcc -c $am__minus_obj sub/conftest.c \
- >/dev/null 2>conftest.err &&
- grep sub/conftst1.h sub/conftest.Po > /dev/null 2>&1 &&
- grep sub/conftst6.h sub/conftest.Po > /dev/null 2>&1 &&
- grep $am__obj sub/conftest.Po > /dev/null 2>&1 &&
- ${MAKE-make} -s -f confmf > /dev/null 2>&1; then
- # icc doesn't choke on unknown options, it will just issue warnings
- # or remarks (even with -Werror). So we grep stderr for any message
- # that says an option was ignored or not supported.
- # When given -MP, icc 7.0 and 7.1 complain thusly:
- # icc: Command line warning: ignoring option '-M'; no argument required
- # The diagnosis changed in icc 8.0:
- # icc: Command line remark: option '-MP' not supported
- if (grep 'ignoring option' conftest.err ||
- grep 'not supported' conftest.err) >/dev/null 2>&1; then :; else
- am_cv_$1_dependencies_compiler_type=$depmode
- break
- fi
- fi
- done
- cd ..
-else
-fi
-AC_SUBST([$1DEPMODE], [depmode=$am_cv_$1_dependencies_compiler_type])
-AM_CONDITIONAL([am__fastdep$1], [
- test "x$enable_dependency_tracking" != xno \
- && test "$am_cv_$1_dependencies_compiler_type" = gcc3])
-# AM_SET_DEPDIR
-# Choose a directory name for dependency files.
-# This macro is AC_REQUIREd in _AM_DEPENDENCIES
-AC_DEFUN([AM_SET_DEPDIR],
-[AC_REQUIRE([AM_SET_LEADING_DOT])dnl
-AC_SUBST([DEPDIR], ["${am__leading_dot}deps"])dnl
-# AM_DEP_TRACK
-AC_DEFUN([AM_DEP_TRACK],
-[AC_ARG_ENABLE(dependency-tracking,
-[ --disable-dependency-tracking speeds up one-time build
- --enable-dependency-tracking do not reject slow dependency extractors])
-if test "x$enable_dependency_tracking" != xno; then
- am_depcomp="$ac_aux_dir/depcomp"
- AMDEPBACKSLASH='\'
- am__nodep='_no'
-fi
-AM_CONDITIONAL([AMDEP], [test "x$enable_dependency_tracking" != xno])
-AC_SUBST([AMDEPBACKSLASH])dnl
-_AM_SUBST_NOTMAKE([AMDEPBACKSLASH])dnl
-AC_SUBST([am__nodep])dnl
-_AM_SUBST_NOTMAKE([am__nodep])dnl
-# Generate code to set up dependency tracking. -*- Autoconf -*-
-# Copyright (C) 1999, 2000, 2001, 2002, 2003, 2004, 2005, 2008
-#serial 5
-# _AM_OUTPUT_DEPENDENCY_COMMANDS
-AC_DEFUN([_AM_OUTPUT_DEPENDENCY_COMMANDS],
- # Autoconf 2.62 quotes --file arguments for eval, but not when files
- # are listed without --file. Let's play safe and only enable the eval
- # if we detect the quoting.
- case $CONFIG_FILES in
- *\'*) eval set x "$CONFIG_FILES" ;;
- *) set x $CONFIG_FILES ;;
- esac
- shift
- for mf
- do
- # Strip MF so we end up with the name of the file.
- mf=`echo "$mf" | sed -e 's/:.*$//'`
- # Check whether this is an Automake generated Makefile or not.
- # We used to match only the files named `Makefile.in', but
- # some people rename them; so instead we look at the file content.
- # Grep'ing the first line is not enough: some people post-process
- # each Makefile.in and add a new line on top of each file to say so.
- # Grep'ing the whole file is not good either: AIX grep has a line
- # limit of 2048, but all sed's we know have understand at least 4000.
- if sed -n 's,^#.*generated by automake.*,X,p' "$mf" | grep X >/dev/null 2>&1; then
- dirpart=`AS_DIRNAME("$mf")`
- else
- continue
- fi
- # Extract the definition of DEPDIR, am__include, and am__quote
- # from the Makefile without running `make'.
- DEPDIR=`sed -n 's/^DEPDIR = //p' < "$mf"`
- test -z "$DEPDIR" && continue
- am__include=`sed -n 's/^am__include = //p' < "$mf"`
- test -z "am__include" && continue
- am__quote=`sed -n 's/^am__quote = //p' < "$mf"`
- # When using ansi2knr, U may be empty or an underscore; expand it
- U=`sed -n 's/^U = //p' < "$mf"`
- # Find all dependency output files, they are included files with
- # $(DEPDIR) in their names. We invoke sed twice because it is the
- # simplest approach to changing $(DEPDIR) to its actual value in the
- # expansion.
- for file in `sed -n "
- s/^$am__include $am__quote\(.*(DEPDIR).*\)$am__quote"'$/\1/p' <"$mf" | \
- sed -e 's/\$(DEPDIR)/'"$DEPDIR"'/g' -e 's/\$U/'"$U"'/g'`; do
- # Make sure the directory exists.
- test -f "$dirpart/$file" && continue
- fdir=`AS_DIRNAME(["$file"])`
- AS_MKDIR_P([$dirpart/$fdir])
- # echo "creating $dirpart/$file"
- echo '# dummy' > "$dirpart/$file"
- done
- done
-])# _AM_OUTPUT_DEPENDENCY_COMMANDS
-# AM_OUTPUT_DEPENDENCY_COMMANDS
-# This macro should only be invoked once -- use via AC_REQUIRE.
-# This code is only required when automatic dependency tracking
-# is enabled. FIXME. This creates each `.P' file that we will
-# need in order to bootstrap the dependency handling code.
-AC_DEFUN([AM_OUTPUT_DEPENDENCY_COMMANDS],
-[AC_CONFIG_COMMANDS([depfiles],
- [test x"$AMDEP_TRUE" != x"" || _AM_OUTPUT_DEPENDENCY_COMMANDS],
- [AMDEP_TRUE="$AMDEP_TRUE" ac_aux_dir="$ac_aux_dir"])
-# Do all the work for Automake. -*- Autoconf -*-
-# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004,
-# 2005, 2006, 2008, 2009 Free Software Foundation, Inc.
-# serial 16
-# This macro actually does too much. Some checks are only needed if
-# your package does certain things. But this isn't really a big deal.
-# AM_INIT_AUTOMAKE(PACKAGE, VERSION, [NO-DEFINE])
-# AM_INIT_AUTOMAKE([OPTIONS])
-# The call with PACKAGE and VERSION arguments is the old style
-# call (pre autoconf-2.50), which is being phased out. PACKAGE
-# and VERSION should now be passed to AC_INIT and removed from
-# the call to AM_INIT_AUTOMAKE.
-# We support both call styles for the transition. After
-# the next Automake release, Autoconf can make the AC_INIT
-# arguments mandatory, and then we can depend on a new Autoconf
-# release and drop the old call support.
-AC_DEFUN([AM_INIT_AUTOMAKE],
-[AC_PREREQ([2.62])dnl
-dnl Autoconf wants to disallow AM_ names. We explicitly allow
-dnl the ones we care about.
-m4_pattern_allow([^AM_[A-Z]+FLAGS$])dnl
-AC_REQUIRE([AM_SET_CURRENT_AUTOMAKE_VERSION])dnl
-AC_REQUIRE([AC_PROG_INSTALL])dnl
-if test "`cd $srcdir && pwd`" != "`pwd`"; then
- # Use -I$(srcdir) only when $(srcdir) != ., so that make's output
- # is not polluted with repeated "-I."
- AC_SUBST([am__isrc], [' -I$(srcdir)'])_AM_SUBST_NOTMAKE([am__isrc])dnl
- # test to see if srcdir already configured
- if test -f $srcdir/config.status; then
- AC_MSG_ERROR([source directory already configured; run "make distclean" there first])
- fi
-fi
-# test whether we have cygpath
-if test -z "$CYGPATH_W"; then
- if (cygpath --version) >/dev/null 2>/dev/null; then
- CYGPATH_W='cygpath -w'
- else
- CYGPATH_W=echo
- fi
-fi
-AC_SUBST([CYGPATH_W])
-# Define the identity of the package.
-dnl Distinguish between old-style and new-style calls.
-m4_ifval([$2],
-[m4_ifval([$3], [_AM_SET_OPTION([no-define])])dnl
- AC_SUBST([PACKAGE], [$1])dnl
- AC_SUBST([VERSION], [$2])],
-[_AM_SET_OPTIONS([$1])dnl
-dnl Diagnose old-style AC_INIT with new-style AM_AUTOMAKE_INIT.
-m4_if(m4_ifdef([AC_PACKAGE_NAME], 1)m4_ifdef([AC_PACKAGE_VERSION], 1), 11,,
- [m4_fatal([AC_INIT should be called with package and version arguments])])dnl
- AC_SUBST([PACKAGE], ['AC_PACKAGE_TARNAME'])dnl
- AC_SUBST([VERSION], ['AC_PACKAGE_VERSION'])])dnl
-_AM_IF_OPTION([no-define],,
-[AC_DEFINE_UNQUOTED(PACKAGE, "$PACKAGE", [Name of package])
- AC_DEFINE_UNQUOTED(VERSION, "$VERSION", [Version number of package])])dnl
-# Some tools Automake needs.
-AC_REQUIRE([AM_SANITY_CHECK])dnl
-AC_REQUIRE([AC_ARG_PROGRAM])dnl
-AM_MISSING_PROG(ACLOCAL, aclocal-${am__api_version})
-AM_MISSING_PROG(AUTOCONF, autoconf)
-AM_MISSING_PROG(AUTOMAKE, automake-${am__api_version})
-AM_MISSING_PROG(AUTOHEADER, autoheader)
-AM_MISSING_PROG(MAKEINFO, makeinfo)
-AC_REQUIRE([AM_PROG_INSTALL_SH])dnl
-AC_REQUIRE([AM_PROG_INSTALL_STRIP])dnl
-AC_REQUIRE([AM_PROG_MKDIR_P])dnl
-# We need awk for the "check" target. The system "awk" is bad on
-# some platforms.
-AC_REQUIRE([AC_PROG_AWK])dnl
-AC_REQUIRE([AC_PROG_MAKE_SET])dnl
-AC_REQUIRE([AM_SET_LEADING_DOT])dnl
-_AM_IF_OPTION([tar-ustar], [_AM_PROG_TAR([ustar])],
- [_AM_IF_OPTION([tar-pax], [_AM_PROG_TAR([pax])],
- [_AM_PROG_TAR([v7])])])
-_AM_IF_OPTION([no-dependencies],,
-[AC_PROVIDE_IFELSE([AC_PROG_CC],
- [_AM_DEPENDENCIES(CC)],
- [define([AC_PROG_CC],
- defn([AC_PROG_CC])[_AM_DEPENDENCIES(CC)])])dnl
-AC_PROVIDE_IFELSE([AC_PROG_CXX],
- [_AM_DEPENDENCIES(CXX)],
- [define([AC_PROG_CXX],
- defn([AC_PROG_CXX])[_AM_DEPENDENCIES(CXX)])])dnl
-AC_PROVIDE_IFELSE([AC_PROG_OBJC],
- [_AM_DEPENDENCIES(OBJC)],
- [define([AC_PROG_OBJC],
- defn([AC_PROG_OBJC])[_AM_DEPENDENCIES(OBJC)])])dnl
-_AM_IF_OPTION([silent-rules], [AC_REQUIRE([AM_SILENT_RULES])])dnl
-dnl The `parallel-tests' driver may need to know about EXEEXT, so add the
-dnl `am__EXEEXT' conditional if _AM_COMPILER_EXEEXT was seen. This macro
-dnl is hooked onto _AC_COMPILER_EXEEXT early, see below.
-AC_CONFIG_COMMANDS_PRE(dnl
-[m4_provide_if([_AM_COMPILER_EXEEXT],
- [AM_CONDITIONAL([am__EXEEXT], [test -n "$EXEEXT"])])])dnl
-dnl Hook into `_AC_COMPILER_EXEEXT' early to learn its expansion. Do not
-dnl add the conditional right here, as _AC_COMPILER_EXEEXT may be further
-dnl mangled by Autoconf and run in a shell conditional statement.
-m4_define([_AC_COMPILER_EXEEXT],
-m4_defn([_AC_COMPILER_EXEEXT])[m4_provide([_AM_COMPILER_EXEEXT])])
-# When config.status generates a header, we must update the stamp-h file.
-# This file resides in the same directory as the config header
-# that is generated. The stamp files are numbered to have different names.
-# Autoconf calls _AC_AM_CONFIG_HEADER_HOOK (when defined) in the
-# loop where config.status creates the headers, so we can generate
-# our stamp files there.
-AC_DEFUN([_AC_AM_CONFIG_HEADER_HOOK],
-[# Compute $1's index in $config_headers.
-_am_arg=$1
-_am_stamp_count=1
-for _am_header in $config_headers :; do
- case $_am_header in
- $_am_arg | $_am_arg:* )
- break ;;
- _am_stamp_count=`expr $_am_stamp_count + 1` ;;
- esac
-done
-echo "timestamp for $_am_arg" >`AS_DIRNAME(["$_am_arg"])`/stamp-h[]$_am_stamp_count])
-# Copyright (C) 2001, 2003, 2005, 2008, 2011 Free Software Foundation,
-# Inc.
-# serial 1
-# AM_PROG_INSTALL_SH
-# Define $install_sh.
-AC_DEFUN([AM_PROG_INSTALL_SH],
-[AC_REQUIRE([AM_AUX_DIR_EXPAND])dnl
-if test x"${install_sh}" != xset; then
- case $am_aux_dir in
- install_sh="\${SHELL} '$am_aux_dir/install-sh'" ;;
- install_sh="\${SHELL} $am_aux_dir/install-sh"
- esac
-fi
-AC_SUBST(install_sh)])
-# Copyright (C) 2003, 2005 Free Software Foundation, Inc.
-# serial 2
-# Check whether the underlying file-system supports filenames
-# with a leading dot. For instance MS-DOS doesn't.
-AC_DEFUN([AM_SET_LEADING_DOT],
-[rm -rf .tst 2>/dev/null
-mkdir .tst 2>/dev/null
-if test -d .tst; then
- am__leading_dot=.
-else
- am__leading_dot=_
-fi
-rmdir .tst 2>/dev/null
-AC_SUBST([am__leading_dot])])
-# Check to see how 'make' treats includes. -*- Autoconf -*-
-# Copyright (C) 2001, 2002, 2003, 2005, 2009 Free Software Foundation, Inc.
-# serial 4
-# AM_MAKE_INCLUDE()
-# Check to see how make treats includes.
-AC_DEFUN([AM_MAKE_INCLUDE],
-[am_make=${MAKE-make}
-cat > confinc << 'END'
-am__doit:
- @echo this is the am__doit target
-.PHONY: am__doit
-END
-# If we don't find an include directive, just comment out the code.
-AC_MSG_CHECKING([for style of include used by $am_make])
-am__include="#"
-am__quote=
-_am_result=none
-# First try GNU make style include.
-echo "include confinc" > confmf
-# Ignore all kinds of additional output from `make'.
-case `$am_make -s -f confmf 2> /dev/null` in #(
-*the\ am__doit\ target*)
- am__include=include
- am__quote=
- _am_result=GNU
-esac
-# Now try BSD make style include.
-if test "$am__include" = "#"; then
- echo '.include "confinc"' > confmf
- case `$am_make -s -f confmf 2> /dev/null` in #(
- *the\ am__doit\ target*)
- am__include=.include
- am__quote="\""
- _am_result=BSD
- esac
-fi
-AC_SUBST([am__include])
-AC_SUBST([am__quote])
-AC_MSG_RESULT([$_am_result])
-rm -f confinc confmf
-# Fake the existence of programs that GNU maintainers use. -*- Autoconf -*-
-# Copyright (C) 1997, 1999, 2000, 2001, 2003, 2004, 2005, 2008
-# serial 6
-# AM_MISSING_PROG(NAME, PROGRAM)
-AC_DEFUN([AM_MISSING_PROG],
-[AC_REQUIRE([AM_MISSING_HAS_RUN])
-$1=${$1-"${am_missing_run}$2"}
-AC_SUBST($1)])
-# AM_MISSING_HAS_RUN
-# Define MISSING if not defined so far and test if it supports --run.
-# If it does, set am_missing_run to use it, otherwise, to nothing.
-AC_DEFUN([AM_MISSING_HAS_RUN],
-AC_REQUIRE_AUX_FILE([missing])dnl
-if test x"${MISSING+set}" != xset; then
- MISSING="\${SHELL} \"$am_aux_dir/missing\"" ;;
- MISSING="\${SHELL} $am_aux_dir/missing" ;;
- esac
-fi
-# Use eval to expand $SHELL
-if eval "$MISSING --run true"; then
- am_missing_run="$MISSING --run "
-else
- am_missing_run=
- AC_MSG_WARN([`missing' script is too old or missing])
-fi
-# Copyright (C) 2003, 2004, 2005, 2006, 2011 Free Software Foundation,
-# Inc.
-# serial 1
-# AM_PROG_MKDIR_P
-# Check for `mkdir -p'.
-AC_DEFUN([AM_PROG_MKDIR_P],
-[AC_PREREQ([2.60])dnl
-AC_REQUIRE([AC_PROG_MKDIR_P])dnl
-dnl Automake 1.8 to 1.9.6 used to define mkdir_p. We now use MKDIR_P,
-dnl while keeping a definition of mkdir_p for backward compatibility.
-dnl @MKDIR_P@ is magic: AC_OUTPUT adjusts its value for each Makefile.
-dnl However we cannot define mkdir_p as $(MKDIR_P) for the sake of
-dnl Makefile.ins that do not define MKDIR_P, so we do our own
-dnl adjustment using top_builddir (which is defined more often than
-dnl MKDIR_P).
-AC_SUBST([mkdir_p], ["$MKDIR_P"])dnl
-case $mkdir_p in
- */*) mkdir_p="\$(top_builddir)/$mkdir_p" ;;
-esac
-# Copyright (C) 2001, 2002, 2003, 2005, 2008, 2010 Free Software
-# Foundation, Inc.
-# serial 5
-# _AM_MANGLE_OPTION(NAME)
-AC_DEFUN([_AM_MANGLE_OPTION],
-[[_AM_OPTION_]m4_bpatsubst($1, [[^a-zA-Z0-9_]], [_])])
-# _AM_SET_OPTION(NAME)
-# Set option NAME. Presently that only means defining a flag for this option.
-AC_DEFUN([_AM_SET_OPTION],
-[m4_define(_AM_MANGLE_OPTION([$1]), 1)])
-# _AM_SET_OPTIONS(OPTIONS)
-# OPTIONS is a space-separated list of Automake options.
-AC_DEFUN([_AM_SET_OPTIONS],
-[m4_foreach_w([_AM_Option], [$1], [_AM_SET_OPTION(_AM_Option)])])
-# _AM_IF_OPTION(OPTION, IF-SET, [IF-NOT-SET])
-AC_DEFUN([_AM_IF_OPTION],
-[m4_ifset(_AM_MANGLE_OPTION([$1]), [$2], [$3])])
-# Check to make sure that the build environment is sane. -*- Autoconf -*-
-# Copyright (C) 1996, 1997, 2000, 2001, 2003, 2005, 2008
-# serial 5
-# AM_SANITY_CHECK
-AC_DEFUN([AM_SANITY_CHECK],
-[AC_MSG_CHECKING([whether build environment is sane])
-# Just in case
-sleep 1
-echo timestamp > conftest.file
-# Reject unsafe characters in $srcdir or the absolute working directory
-# name. Accept space and tab only in the latter.
-am_lf='
-case `pwd` in
- *[[\\\"\#\$\&\'\`$am_lf]]*)
- AC_MSG_ERROR([unsafe absolute working directory name]);;
-esac
-case $srcdir in
- *[[\\\"\#\$\&\'\`$am_lf\ \ ]]*)
- AC_MSG_ERROR([unsafe srcdir value: `$srcdir']);;
-esac
-# Do `set' in a subshell so we don't clobber the current shell's
-# arguments. Must try -L first in case configure is actually a
-# symlink; some systems play weird games with the mod time of symlinks
-# (eg FreeBSD returns the mod time of the symlink's containing
-# directory).
-if (
- set X `ls -Lt "$srcdir/configure" conftest.file 2> /dev/null`
- if test "$[*]" = "X"; then
- # -L didn't work.
- set X `ls -t "$srcdir/configure" conftest.file`
- fi
- rm -f conftest.file
- if test "$[*]" != "X $srcdir/configure conftest.file" \
- && test "$[*]" != "X conftest.file $srcdir/configure"; then
- # If neither matched, then we have a broken ls. This can happen
- # if, for instance, CONFIG_SHELL is bash and it inherits a
- # broken ls alias from the environment. This has actually
- # happened. Such a system could not be considered "sane".
- AC_MSG_ERROR([ls -t appears to fail. Make sure there is not a broken
-alias in your environment])
- fi
- test "$[2]" = conftest.file
-then
- # Ok.
-else
- AC_MSG_ERROR([newly created file is older than distributed files!
-Check your system clock])
-fi
-AC_MSG_RESULT(yes)])
-# serial 1
-# AM_PROG_INSTALL_STRIP
-# One issue with vendor `install' (even GNU) is that you can't
-# specify the program used to strip binaries. This is especially
-# annoying in cross-compiling environments, where the build's strip
-# is unlikely to handle the host's binaries.
-# Fortunately install-sh will honor a STRIPPROG variable, so we
-# always use install-sh in `make install-strip', and initialize
-# STRIPPROG with the value of the STRIP variable (set by the user).
-AC_DEFUN([AM_PROG_INSTALL_STRIP],
-[AC_REQUIRE([AM_PROG_INSTALL_SH])dnl
-# Installed binaries are usually stripped using `strip' when the user
-# run `make install-strip'. However `strip' might not be the right
-# tool to use in cross-compilation environments, therefore Automake
-# will honor the `STRIP' environment variable to overrule this program.
-dnl Don't test for $cross_compiling = yes, because it might be `maybe'.
-if test "$cross_compiling" != no; then
- AC_CHECK_TOOL([STRIP], [strip], :)
-fi
-INSTALL_STRIP_PROGRAM="\$(install_sh) -c -s"
-AC_SUBST([INSTALL_STRIP_PROGRAM])])
-# Copyright (C) 2006, 2008, 2010 Free Software Foundation, Inc.
-# serial 3
-# _AM_SUBST_NOTMAKE(VARIABLE)
-# Prevent Automake from outputting VARIABLE = @VARIABLE@ in Makefile.in.
-# This macro is traced by Automake.
-AC_DEFUN([_AM_SUBST_NOTMAKE])
-# AM_SUBST_NOTMAKE(VARIABLE)
-# Public sister of _AM_SUBST_NOTMAKE.
-AC_DEFUN([AM_SUBST_NOTMAKE], [_AM_SUBST_NOTMAKE($@)])
-# Check how to create a tarball. -*- Autoconf -*-
-# Copyright (C) 2004, 2005, 2012 Free Software Foundation, Inc.
-# serial 2
-# _AM_PROG_TAR(FORMAT)
-# Check how to create a tarball in format FORMAT.
-# FORMAT should be one of `v7', `ustar', or `pax'.
-# Substitute a variable $(am__tar) that is a command
-# writing to stdout a FORMAT-tarball containing the directory
-# $tardir.
-# tardir=directory && $(am__tar) > result.tar
-# Substitute a variable $(am__untar) that extract such
-# a tarball read from stdin.
-# $(am__untar) < result.tar
-AC_DEFUN([_AM_PROG_TAR],
-[# Always define AMTAR for backward compatibility. Yes, it's still used
-# in the wild :-( We should find a proper way to deprecate it ...
-AC_SUBST([AMTAR], ['$${TAR-tar}'])
-m4_if([$1], [v7],
- [am__tar='$${TAR-tar} chof - "$$tardir"' am__untar='$${TAR-tar} xf -'],
- [m4_case([$1], [ustar],, [pax],,
- [m4_fatal([Unknown tar format])])
-AC_MSG_CHECKING([how to create a $1 tar archive])
-# Loop over all known methods to create a tar archive until one works.
-_am_tools='gnutar m4_if([$1], [ustar], [plaintar]) pax cpio none'
-_am_tools=${am_cv_prog_tar_$1-$_am_tools}
-# Do not fold the above two line into one, because Tru64 sh and
-# Solaris sh will not grok spaces in the rhs of `-'.
-for _am_tool in $_am_tools
-do
- case $_am_tool in
- gnutar)
- for _am_tar in tar gnutar gtar;
- do
- AM_RUN_LOG([$_am_tar --version]) && break
- done
- am__tar="$_am_tar --format=m4_if([$1], [pax], [posix], [$1]) -chf - "'"$$tardir"'
- am__tar_="$_am_tar --format=m4_if([$1], [pax], [posix], [$1]) -chf - "'"$tardir"'
- am__untar="$_am_tar -xf -"
- plaintar)
- # Must skip GNU tar: if it does not support --format= it doesn't create
- # ustar tarball either.
- (tar --version) >/dev/null 2>&1 && continue
- am__tar='tar chf - "$$tardir"'
- am__tar_='tar chf - "$tardir"'
- am__untar='tar xf -'
- pax)
- am__tar='pax -L -x $1 -w "$$tardir"'
- am__tar_='pax -L -x $1 -w "$tardir"'
- am__untar='pax -r'
- cpio)
- am__tar='find "$$tardir" -print | cpio -o -H $1 -L'
- am__tar_='find "$tardir" -print | cpio -o -H $1 -L'
- am__untar='cpio -i -H $1 -d'
- none)
- am__tar=false
- am__tar_=false
- am__untar=false
- esac
- # If the value was cached, stop now. We just wanted to have am__tar
- # and am__untar set.
- test -n "${am_cv_prog_tar_$1}" && break
- # tar/untar a dummy directory, and stop if the command works
- echo GrepMe > conftest.dir/file
- AM_RUN_LOG([tardir=conftest.dir && eval $am__tar_ >conftest.tar])
- if test -s conftest.tar; then
- AM_RUN_LOG([$am__untar <conftest.tar])
- grep GrepMe conftest.dir/file >/dev/null 2>&1 && break
- fi
-done
-rm -rf conftest.dir
-AC_CACHE_VAL([am_cv_prog_tar_$1], [am_cv_prog_tar_$1=$_am_tool])
-AC_MSG_RESULT([$am_cv_prog_tar_$1])])
-AC_SUBST([am__tar])
-AC_SUBST([am__untar])
-]) # _AM_PROG_TAR
More information about the Swift-commit
