[Swift-commit] r7253 - in trunk: . bin
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Wed Oct 30 13:10:44 CDT 2013
Author: davidk
Date: 2013-10-30 13:10:44 -0500 (Wed, 30 Oct 2013)
New Revision: 7253
Removed:
   trunk/bin/grid/
   trunk/bin/slurm-qdel
   trunk/bin/slurm-qstat
   trunk/bin/slurm-qsub
   trunk/bin/slurm-qsub-emulator
   trunk/bin/swiftconfig
   trunk/bin/swiftstat
Modified:
   trunk/build.xml
Log:
Some bin/ directory cleanup
Removed the slurm-* commands since they are now replaced with the slurm provider
Removed the bin/grid directory - the older scripts for submitting directly to OSG
Deleted: trunk/bin/slurm-qdel
--- trunk/bin/slurm-qdel	2013-10-30 17:47:19 UTC (rev 7252)
+++ trunk/bin/slurm-qdel	2013-10-30 18:10:44 UTC (rev 7253)
@@ -1,8 +0,0 @@
-#! /bin/sh
-now=$(date "+%Y.%m%d.%H:%M:%S")
-echo $now $0: $* >> $HOME/pbslog
-qdel $*
Deleted: trunk/bin/slurm-qstat
--- trunk/bin/slurm-qstat	2013-10-30 17:47:19 UTC (rev 7252)
+++ trunk/bin/slurm-qstat	2013-10-30 18:10:44 UTC (rev 7253)
@@ -1,13 +0,0 @@
-#! /bin/sh
-#echo 'Job id              Name             User            Time Use S Queue'
-#echo '------------------- ---------------- --------------- -------- - -----'
-#/software/slurm-2.4-el6-x86_64/bin/qstat $* | tail -n +2
-qstat $* | sed -e 's/\t/    /' -e 's/:  */: /'
Deleted: trunk/bin/slurm-qsub
--- trunk/bin/slurm-qsub	2013-10-30 17:47:19 UTC (rev 7252)
+++ trunk/bin/slurm-qsub	2013-10-30 18:10:44 UTC (rev 7253)
@@ -1,78 +0,0 @@
-#! /bin/sh
-slurmqsub=$( which slurm-qsub-emulator )
-script=$1.slurm
-echo '#! /bin/sh' >$script
-# echo 'export PBS_NODELIST=SLURM_NODELIST'' >>$script  # FIXME: convert SLURM_NODELIST to PBS_NODEFILE here...
-cat $1 | grep -v '^#PBS' >>$script
-chmod +x $script
-srunargs=$(awk <$1 '
-/#PBS -S/ { shell=$3 }
-/#PBS -N/ { jobname=$3 }
-/#PBS -m/ { m = $3 }
-/#PBS -l nodes/ { nodes = $3; ppn=$3;
-                  sub(/nodes=/,"",nodes); sub(/:.*/,"",nodes);
-                  sub(/^.*ppn=/,"",ppn);  }
-/#PBS -l walltime/ { walltime = $3; sub(/walltime=/,"",walltime);}
-#/#PBS -l advres/ { advres = "," $3; sub(/advres=/,"",advres); advres="," advres }
-/#PBS -l advres/ { advres = "," $3; }
-/#PBS -q/ { queue = $3 }
-/#PBS -o/ { sofile = $3 }
-/#PBS -e/ { sefile = $3 }
-END {
-   #printf("shell=%s jobname=%s m=%s nodespec=%s nodes=%s ppn=%s walltime=%s queue=%s sofile=%s sefile=%s\n",
-   #        shell, jobname, m, nodespec, nodes, ppn, walltime, queue, sofile, sefile);
-   #printf("-p %s -t %s -N %s -D %s -J %s -e %s -o %s", queue, walltime, nodes, "/tmp", jobname, sefile, sofile);
-#   printf("-S %s -N %s -m %s -l nodes=%s:ppn=%s -l walltime=%s -q %s -o %s -e %s",
-#            shell, jobname, m, nodes, ppn, walltime, queue, sofile, sefile);
-   printf("-N %s -m %s -l nodes=%s:ppn=%s,walltime=%s%s -q %s -o %s -e %s",
-             jobname, m, nodes, ppn, walltime, advres, queue, sofile, sefile);
-echo "  " qsub args: $slurmqsub $srunargs $script >>$HOME/pbslog
-job=$($slurmqsub $srunargs $script)
-echo "  " qsub output: $job >>$HOME/pbslog
-jid=$(echo $job | sed -e 's/^.* //')
-echo "  " qsub job id: $jid >>$HOME/pbslog
-echo $jid
-# srun $srunargs $script
-#   cqsub -q ${QUEUE}   \
-#         -k zeptoos    \
-#         -t ${MAXTIME} \ # minutes
-#         -n ${NODES}   \
-#         --cwd ${LOGDIR} \
-#         -E ${LOGDIR}/cobalt.${$}.stderr \
-#         -o ${LOGDIR}/cobalt.${$}.stdout \
-#         -e "WORKER_LOGGING_LEVEL=DEBUG:ZOID_ENABLE_NAT=true" \
-#         $WORKER $EXECUTION_URL $ID $LOG_DIR
-# LOGDIR=/tmp/swiftlog
-#        WORKER_LOGGING_LEVEL=DEBUG srun \
-#          -p ${QUEUE} \
-#          -t ${MAXTIME} \
-#          -N ${NODES}   \
-#          -D ${LOGDIR} \
-#          -J swift-worker \
-#          -e ${LOGDIR}/cobalt.${$}.stderr \
-#             $SWIFT_BIN/$WORKER $EXECUTION_URL $ID $LOG_DIR
-#PBS -S /bin/bash
-#PBS -N cog-000000
-#PBS -m n
-#PBS -l nodes=1:ppn=1
-#PBS -l walltime=00:05:00
-#PBS -q sandyb
-#PBS -o /home/wilde/.globus/scripts/PBS4051523028032512638.submit.stdout
-#PBS -e /home/wilde/.globus/scripts/PBS4051523028032512638.submit.stderr
Deleted: trunk/bin/slurm-qsub-emulator
--- trunk/bin/slurm-qsub-emulator	2013-10-30 17:47:19 UTC (rev 7252)
+++ trunk/bin/slurm-qsub-emulator	2013-10-30 18:10:44 UTC (rev 7253)
@@ -1,433 +0,0 @@
-#! /usr/bin/perl -w
-# qsub - submit a batch job in familar pbs format.
-#  Copyright (C) 2007 The Regents of the University of California.
-#  Produced at Lawrence Livermore National Laboratory (cf, DISCLAIMER).
-#  Written by Danny Auble <auble1 at llnl.gov>.
-#  CODE-OCEC-09-009. All rights reserved.
-#  This file is part of SLURM, a resource management program.
-#  For details, see <http://www.schedmd.com/slurmdocs/>.
-#  Please also read the included file: DISCLAIMER.
-#  SLURM is free software; you can redistribute it and/or modify it under
-#  the terms of the GNU General Public License as published by the Free
-#  Software Foundation; either version 2 of the License, or (at your option)
-#  any later version.
-#  In addition, as a special exception, the copyright holders give permission
-#  to link the code of portions of this program with the OpenSSL library under
-#  certain conditions as described in each individual source file, and
-#  distribute linked combinations including the two. You must obey the GNU
-#  General Public License in all respects for all of the code used other than
-#  OpenSSL. If you modify file(s) with this exception, you may extend this
-#  exception to your version of the file(s), but you are not obligated to do
-#  so. If you do not wish to do so, delete this exception statement from your
-#  version.  If you delete this exception statement from all source files in
-#  the program, then also delete it here.
-#  SLURM is distributed in the hope that it will be useful, but WITHOUT ANY
-#  WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
-#  FOR A PARTICULAR PURPOSE.  See the GNU General Public License for more
-#  details.
-#  You should have received a copy of the GNU General Public License along
-#  with SLURM; if not, write to the Free Software Foundation, Inc.,
-#  51 Franklin Street, Fifth Floor, Boston, MA 02110-1301  USA.
-use strict;
-use FindBin;
-use Getopt::Long 2.24 qw(:config no_ignore_case require_order);
-use lib qw(/software/slurm-2.4-el6-x86_64/lib64/perl5);
-use autouse 'Pod::Usage' => qw(pod2usage);
-use Slurm ':all';
-use Switch;
-my ($start_time,
-    $account,
- #   $checkpoint_interval,
-    $directive_prefix,
-    $err_path,
-    $interactive,
-    $hold,
-#    $join,
-#    $keep,
-    $resource_list,
-    $mail_options,
-    $mail_user_list,
-    $job_name,
-    $out_path,
-    $priority,
-    $destination,
-#    $rerunable,
-#    $script_path,
-#    $running_user_list,
-#    $variable_list,
-#    $all_env,
-    $additional_attributes,
-#    $no_std,
-    $help,
-    $man);
-# my $sbatch = "${FindBin::Bin}/sbatch";
-# my $salloc = "${FindBin::Bin}/salloc";
-# my $srun = "${FindBin::Bin}/srun";
-my $sbatch = "sbatch";
-my $salloc = "salloc";
-GetOptions('a=s'      => \$start_time,
-	   'A=s'      => \$account,
-#	   'c=i'      => \$checkpoint_interval,
-	   'C=s'      => \$directive_prefix,
-	   'e=s'      => \$err_path,
-	   'h'        => \$hold,
-	   'I'        => \$interactive,
-	   'j:s'      => sub { warn "option -j is the default, " .
-				    "stdout/stderr go into the same file\n" },
-#	   'k=s'      => \$keep,
-	   'l=s'      => \$resource_list,
-	   'm=s'      => \$mail_options,
-	   'M=s'      => \$mail_user_list,
-	   'N=s'      => \$job_name,
-	   'o=s'      => \$out_path,
-	   'p=i'      => \$priority,
-	   'q=s'      => \$destination,
-#	   'r=s'      => \$rerunable,
-#	   'S=s'      => \$script_path,
-#	   'u=s'      => \$running_user_list,
-	   'v=s'      => sub { warn "option -v is not supported, " .
-				    "since the current environment " .
-				    "is exported by default\n" },
-	   'V'        => sub { warn "option -V is not necessary, " .
-	   'W'        => \$additional_attributes,
-#	   'z'        => \$no_std,
-	   'help|?'   => \$help,
-	   'man'      => \$man,
-	or pod2usage(2);
-# Display usage if necessary
-pod2usage(0) if $help;
-if ($man) {
-        if ($< == 0) {   # Cannot invoke perldoc as root
-		my $id = eval { getpwnam("nobody") };
-		$id = eval { getpwnam("nouser") } unless defined $id;
-		$id = -2                          unless defined $id;
-		$<  = $id;
-        $> = $<;                         # Disengage setuid
-        $ENV{PATH} = "/bin:/usr/bin";    # Untaint PATH
-        delete @ENV{'IFS', 'CDPATH', 'ENV', 'BASH_ENV'};
-        if ($0 =~ /^([-\/\w\.]+)$/) { $0 = $1; }    # Untaint $0
-        else { die "Illegal characters were found in \$0 ($0)\n"; }
-        pod2usage(-exitstatus => 0, -verbose => 2);
-# Use sole remaining argument as jobIds
-my $script;
-if ($ARGV[0]) {
-	foreach (@ARGV) {
-	        $script .= "$_ ";
-} else {
-        pod2usage(2);
-my %res_opts;
-my %node_opts;
-if($resource_list) {
-	%res_opts = %{parse_resource_list($resource_list)};
-# 	while((my $key, my $val) = each(%res_opts)) {
-# 		print "$key = ";
-# 		if($val) {
-# 			print "$val\n";
-# 		} else {
-# 			print "\n";
-	if($res_opts{nodes}) {
-		%node_opts =  %{parse_node_opts($res_opts{nodes})};
-my $command;
-if($interactive) {
-	$command = "$salloc";
-} else {
-	$command = "$sbatch";
-	$command .= " -D $directive_prefix" if $directive_prefix;
-	$command .= " -e $err_path" if $err_path;
-	$command .= " -o $out_path" if $out_path;
-$command .= " -N$node_opts{node_cnt}" if $node_opts{node_cnt};
-$command .= " -n$node_opts{task_cnt}" if $node_opts{task_cnt};
-$command .= " -w$node_opts{hostlist}" if $node_opts{hostlist};
-if($res_opts{walltime}) {
-	$command .= " -t$res_opts{walltime}";
-} elsif($res_opts{cput}) {
-	$command .= " -t$res_opts{cput}";
-} elsif($res_opts{pcput}) {
-	$command .= " -t$res_opts{pcput}";
-$command .= " --tmp=$res_opts{file}" if $res_opts{file};
-$command .= " --mem=$res_opts{mem}" if $res_opts{mem};
-$command .= " --nice=$res_opts{nice}" if $res_opts{nice};
-$command .= " --reservation=$res_opts{advres}" if $res_opts{advres};
-# Cray-specific options
-$command .= " -n$res_opts{mppwidth}"		    if $res_opts{mppwidth};
-$command .= " -w$res_opts{mppnodes}"		    if $res_opts{mppnodes};
-$command .= " --cpus-per-task=$res_opts{mppdepth}"  if $res_opts{mppdepth};
-$command .= " --ntasks-per-node=$res_opts{mppnppn}" if $res_opts{mppnppn};
-$command .= " --begin=$start_time" if $start_time;
-$command .= " --account=$account" if $account;
-$command .= " -H" if $hold;
-if($mail_options) {
-	$command .= " --mail-type=FAIL" if $mail_options =~ /a/;
-	$command .= " --mail-type=BEGIN" if $mail_options =~ /b/;
-	$command .= " --mail-type=END" if $mail_options =~ /e/;
-$command .= " --mail-user=$mail_user_list" if $mail_user_list;
-$command .= " -J $job_name" if $job_name;
-$command .= " --nice=$priority" if $priority;
-$command .= " -p $destination" if $destination;
-$command .= " -C $additional_attributes" if $additional_attributes;
-$command .= " --exclusive"; # MWilde: added for midway, which schedules by core.
-$command .= " $script";
-system("(echo; echo $command; echo) >> \$HOME/pbslog");
-system($command);
-sub parse_resource_list {
-	my ($rl) = @_;
-	my %opt = ('arch' => "",
-		   'cput' => "",
-		   'file' => "",
-		   'host' => "",
-		   'mem' => "",
-		   'nice' => "",
-		   'nodes' => "",
-		   'opsys' => "",
-		   'other' => "",
-		   'pcput' => "",
-		   'pmem' => "",
-		   'pvmem' => "",
-		   'software' => "",
-		   'vmem' => "",
-		   'advres' => "",
-		   # Cray-specific resources
-		   'mppwidth' => "",
-		   'mppdepth' => "",
-		   'mppnppn' => "",
-		   'mppmem' => "",
-		   'mppnodes' => "",
-		   'walltime' => ""
-	my @keys = keys(%opt);
-	foreach my $key (@keys) {
-		# print "key=$key rl=$rl\n";
-		($opt{$key}) = $rl =~ m/$key=([-\w:\+=+]+)/;
-                # print " set to $opt{$key}\n";
-	if($opt{cput}) {
-		$opt{cput} = get_minutes($opt{cput});
-	if($opt{mppmem}) {
-		$opt{mem} = convert_mb_format($opt{mppmem});
-	} elsif($opt{mem}) {
-		$opt{mem} = convert_mb_format($opt{mem});
-	if($opt{file}) {
-		$opt{file} = convert_mb_format($opt{file});
-	return \%opt;
-sub parse_node_opts {
-	my ($node_string) = @_;
-	my %opt = ('node_cnt' => 0,
-		   'hostlist' => "",
-		   'task_cnt' => 0
-	while($node_string =~ /ppn=(\d+)/g) {
-		$opt{task_cnt} += $1;
-	my $hl = Slurm::Hostlist::create("");
-	my @parts = split(/\+/, $node_string);
-	foreach my $part (@parts) {
-		my @sub_parts = split(/:/, $part);
-		foreach my $sub_part (@sub_parts) {
-			if($sub_part =~ /ppn=(\d+)/) {
-				next;
-			} elsif($sub_part =~ /^(\d+)/) {
-				$opt{node_cnt} += $1;
-			} else {
-				if(!Slurm::Hostlist::push($hl, $sub_part)) {
-					print "problem pushing host $sub_part onto hostlist\n";
-	$opt{hostlist} = Slurm::Hostlist::ranged_string($hl);
-	my $hl_cnt = Slurm::Hostlist::count($hl);
-	$opt{node_cnt} = $hl_cnt if $hl_cnt > $opt{node_cnt};
-	# we always want at least one here
-	if(!$opt{node_cnt}) {
-		$opt{node_cnt} = 1;
-	# figure out the amount of tasks based of the node cnt and the amount
-	# of ppn's in the request
-	if($opt{task_cnt}) {
-		$opt{task_cnt} *= $opt{node_cnt};
-	return \%opt;
-sub get_minutes {
-    my ($duration) = @_;
-    $duration = 0 unless $duration;
-    my $minutes = 0;
-    # Convert [[HH:]MM:]SS to duration in minutes
-    if ($duration =~ /^(?:(\d+):)?(\d*):(\d+)$/) {
-        my ($hh, $mm, $ss) = ($1 || 0, $2 || 0, $3);
-	$minutes += 1 if $ss > 0;
-        $minutes += $mm;
-        $minutes += $hh * 60;
-    } elsif ($duration =~ /^(\d+)$/) {  # Convert number in minutes to seconds
-	    my $mod = $duration % 60;
-	    $minutes = int($duration / 60);
-	    $minutes++ if $mod;
-    } else { # Unsupported format
-        die("Invalid time limit specified ($duration)\n");
-    return $minutes;
-sub convert_mb_format {
-	my ($value) = @_;
-	my ($amount, $suffix) = $value =~ /(\d+)($|[KMGT])/i;
-	return if !$amount;
-	$suffix = lc($suffix);
-	if (!$suffix) {
-		$amount /= 1048576;
-	} elsif ($suffix eq "k") {
-		$amount /= 1024;
-	} elsif ($suffix eq "m") {
-		#do nothing this is what we want.
-	} elsif ($suffix eq "g") {
-		$amount *= 1024;
-	} elsif ($suffix eq "t") {
-		$amount *= 1048576;
-	} else {
-		print "don't know what to do with suffix $suffix\n";
-		return;
-	$amount .= "M";
-	return $amount;
-__END__
-=head1 NAME
-B<qsub> - submit a batch job in a familiar pbs format
-=head1 SYNOPSIS
-qsub  [-a date_time]
-      [-A account_string]
-      [-b secs]
-      [-C directive_prefix]
-      [-e path]
-      [-I]
-      [-l resource_list]
-      [-m mail_options] [-M  user_list]
-      [-N name]
-      [-o path]
-      [-p priority]
-      [-q destination]
-      [-W additional_attributes]
-      [-h]
-      [script]
-=head1 DESCRIPTION
-The B<qsub> command displays information about nodes. It is aimed to be feature-compatible with PBS' qsub.
-=head1 OPTIONS
-=over 4
-=item B<-a>
-Display information for all nodes. This is the default if no node name is specified.
-=item B<-I>
-Interactive execution.
-=item B<-j> join
-It is not necessary (currently also not possible) since stderr/stdout are always joined.
-=item B<-v> [variable_list]
-Exporting single variables via -v is not supported, since the entire login environment
-is exported by the default.
-=item B<-V>
-The -V option to export the current environment is not required since it is done by default.
-=item B<-?> | B<--help>
-brief help message
-=item B<--man>
-full documentation
-=back
-=cut
Deleted: trunk/bin/swiftconfig
--- trunk/bin/swiftconfig	2013-10-30 17:47:19 UTC (rev 7252)
+++ trunk/bin/swiftconfig	2013-10-30 18:10:44 UTC (rev 7253)
@@ -1,419 +0,0 @@
-#!/usr/bin/perl -w
-use strict;
-use File::Copy;
-use File::Path;
-use Pod::Usage;
-use Cwd;
-use Cwd qw(abs_path);
-use FindBin qw($Bin);
-use lib "$FindBin::Bin/../lib/perl";   # Use libs in swiftconfig_home/lib/perl
-use SwiftConfig;
-use Getopt::Long;
-use XML::Simple;
-use File::Which qw(which where);
-use Data::Dumper;
-# Variables for command line options
-my $option_list         = q{};      # List information about config
-my $option_remove       = q{};      # Remove entry from sites.xml
-my $option_edit         = q{};      # Edit mode
-my $option_default      = q{};      # When adding a site, use all defaults
-my @option_templates    = ();       # Create config from template specified
-my $option_copy         = q{};      # Copy an existing configuration
-my $option_applications = q{};      # Edit applications
-my $option_import       = q{};      # Import existing configuration
-my @option_profiles 	= ();       # Specify one or more profiles to edit
-my $option_groups       = q{};      # Edit site groupings
-# Assign variables from command line options
-GetOptions(
-    'remove=s'              	=> \$option_remove,
-    'default|defaults'      	=> \$option_default,
-    'full'                  	=> sub { $option_default = 0; },
-    'template|templates=s{,}'   => \@option_templates,
-    'edit=s'                	=> \$option_edit,
-    'copy=s'                	=> \$option_copy,
-    'apps|applications'     	=> \$option_applications,
-    'import=s'              	=> \$option_import,
-    'list=s'                	=> \$option_list,
-    'help|man|h'              	=> sub { pod2usage(-verbose => 2); },
-    'profile|profiles=s{,}' 	=> \@option_profiles,
-    'group|groups'              => \$option_groups,
-# Prepare data
-my $xml = new XML::Simple();
-initialize_swiftconfig();
-# Check command line options
-if(    !$option_remove
-    && !@option_templates
-    && !$option_edit
-    && !$option_copy
-    && !$option_applications
-    && !$option_import
-    && !$option_list
-    && !$option_groups) {
-    print "Incorrect usage. See swiftconfig -help for more information\n";
-    exit;
-# Create all required directories
-my $dotswift_directory = "$ENV{'HOME'}/.swift";
-create_directory("$ENV{'HOME'}/.ssh");
-create_directory("$dotswift_directory");
-create_directory("$dotswift_directory/sites");
-# Determine the template directory
-my @execution_path = split( '/', abs_path($0) );
- at execution_path = splice( @execution_path, 0, $#execution_path - 1 );
-my $template_directory = join( '/', @execution_path ) . '/etc/sites';
-# Add configuration from a template
-if (@option_templates) {
-    foreach my $option_template(@option_templates) {
-    	# Update XML info
-    	my $from_directory   = "$template_directory/$option_template";
-    	my $sites_input_file = "$from_directory/sites.xml";
-    	if ( !-e "$sites_input_file" ) {
-    	    die "Unable to find template for $option_template\n";
-	    my $xml_ref          = update_xml("$sites_input_file", 0, $option_default);
-    	my $new_sitename     = $xml_ref->{handle};
-    	my $output_directory = "$dotswift_directory/sites/$new_sitename";
-    	if ( -d "$output_directory" ) {
-    	    print "Configuration for $new_sitename already exists\n";
-	    next;
-    	# Update and copy files to reflect input
-    	my @files_to_copy = <$from_directory/*>;
-    	create_directory("$output_directory");
-    	foreach my $file_to_copy (@files_to_copy) {
-    	    copy_file($file_to_copy, $output_directory);
-    	my $xml_out_ref = $xml->XMLout(
-    	    $xml_ref,
-    	    RootName      => 'pool',
-    	    SuppressEmpty => 1,
-    	write_file( "$output_directory/sites.xml", $xml_out_ref );
-    	update_site_applications($new_sitename, $option_default);
-    	# Handle SSH
-    	if ( $xml_ref->{execution}{provider} eq 'ssh' ) {
-        	add_ssh( $new_sitename, $xml_ref->{execution}{url} );
-    	print "Successfully added $option_template\n";
-# Remove an entry
-if ($option_remove) {
-    if ( !-d "$dotswift_directory/sites/$option_remove" ) {
-        die "Unable to find configuration named $option_remove\n";
-    # Remove directory
-    rmtree("$dotswift_directory/sites/$option_remove")
-        || die 'Unable to remove directory '
-        . "$dotswift_directory/sites/$option_remove\n";
-# Modify a site entry
-if ($option_edit) {
-    my $output_directory = "$dotswift_directory/sites/$option_edit";
-    my $xml_filename = "$output_directory/sites.xml";
-    if ( !-e "$xml_filename" ) {
-        die "Unable to find configuration for $option_edit\n";
-    my $xml_ref = $xml->XMLin(
-        $xml_filename,
-        ForceArray => [qw(workdirectory profile)],
-        KeyAttr    => [],
-    if(@option_profiles) {
-	$xml_ref = edit_profile($xml_filename, @option_profiles);
-    else {
-    	$xml_ref = update_xml("$xml_filename", 1, $option_default);
-	    update_site_applications($option_edit, $option_default);
-   # Save
-        $xml_ref,
-    # Add/modify/remove ssh entries as needed
-        add_ssh( $xml_ref->{handle}, $xml_ref->{execution}{url} );
-# Copy a configuration
-if($option_copy) {
-    my $input_directory = "$dotswift_directory/sites/$option_copy";
-    my $input_site = "$input_directory/sites.xml";
-    if( !-e $input_site) {
-        die "Unable to find configuration for $option_copy\n";
-    my $new_config_name = get_entry( 'New Configuration Name', '', 0);
-    my $output_directory = "$dotswift_directory/sites/$new_config_name";
-    if(-d "$output_directory") {
-        die "Configuration for $new_config_name already exists\n";
-    create_directory($output_directory);
-    my @files_to_copy = <$input_directory/*>;
-    # Rename and save
-        $xml_filename,
-        KeyAttr    => [],
-    $xml_ref->{handle} = $new_config_name;
-        $xml_ref,
-    # Edit sites
-    my $initial_exurl = $xml_ref->{execution}{url};
-    $xml_ref = update_xml( "$output_directory/sites.xml", 1, $option_default,);
-    my $new_exurl = $xml_ref->{execution}{url};
-    $xml_out_ref = $xml->XMLout(
-        $xml_ref,
-    # Add ssh entries as needed
-# Edit site groupings
-if($option_groups) {
-    my @groups = glob("$dotswift_directory/groups/*");
-    foreach(@groups) {
-        $_ = strip_directory($_);
-        my ($base, $ext) = split('\.');
-        $_ = $base;
-    push(@groups, 'new');
-    my $group_selection = get_entry('Select group', 'new', 0, @groups);
-    if($group_selection eq 'new') {
-        $group_selection = get_entry('Name of new group', '', 0);
-        if(-e "$dotswift_directory/groups/$group_selection.group") {
-            print "Group named $group_selection already exists!\n";
-            exit;
-        open(GROUPFILE, ">$dotswift_directory/groups/$group_selection.group")
-            || die "Unable to create group file $dotswift_directory/groups/$group_selection.group";
-        print "Group $group_selection created\n";
-        close(GROUPFILE);
-    my $quit = 0;
-    my $group_filename = "$dotswift_directory/groups/$group_selection.group";
-    while($quit == 0) {
-        print "\n(A)dd, (r)emove, (l)ist, or (q)uit: ";
-           my $command = <STDIN>;
-           chomp($command);
-           if(lc($command) eq 'a') {
-               add_to_group($group_filename);
-           elsif(lc($command) eq 'q') {
-               $quit = 1;
-           elsif(lc($command) eq 'r') {
-                remove_from_group($group_filename);
-           elsif(lc($command) eq 'l') {
-                list_group($group_filename);
-           else {
-               print "Unknown option: $command\n";
-# Add/Edit applications
-if($option_applications) {
-       my @applications = glob("$dotswift_directory/apps/*");
-       foreach(@applications) {
-           $_ = $base;
-       push(@applications, 'new');
-       my $application_set = get_entry('Select application set', 'linux', 0,
-                                       @applications);
-       if($application_set eq 'new') {
-           $application_set = get_entry('Name of new application set', '', 0);
-           my $now = time();
-           if(-e "$dotswift_directory/apps/$application_set.apps") {
-               print "Set named $application_set already exists\n";
-               exit;
-           open(APPFILE, ">$dotswift_directory/apps/$application_set.apps")
-               || die "Unable to create file $dotswift_directory/apps/$application_set.apps";
-           print "$application_set set created\n";
-           close(APPFILE);
-       my $quit = 0;
-           print "\n(E)dit, (a)dd, (r)emove, (l)ist, or (q)uit: ";
-           chomp($command);
-               add_application("$dotswift_directory/apps/$application_set.apps");
-               $quit = 1;
-                remove_application("$dotswift_directory/apps/$application_set.apps");
-                list_applications("$dotswift_directory/apps/$application_set.apps");
-           elsif(lc($command) eq 'e') {
-                edit_application("$dotswift_directory/apps/$application_set.apps");
-           else {
-# Import existing configurations
-if($option_import) {
-    if($option_import =~ m/\.xml/gi) {
-        import_xml($option_import);
-    if($option_import =~ m/\.data/gi) {
-        import_tc($option_import);
-# List various about swiftconfig
-if($option_list) {
-    if ($option_list eq "templates") {
-        print_directory($template_directory);
-    elsif ($option_list eq "configs" || $option_list eq "sites") {
-        print_directory("$dotswift_directory/sites");
-    # Assume it's the name of a configuration
-    else {
-        my @matched_configs = glob("$dotswift_directory/sites/$option_list");
-        foreach my $site (@matched_configs) {
-            if(-e "$site/sites.xml") {
-                print "sites.xml:\n";
-                system("cat $site/sites.xml");
-                print "\n";
-            else {
-                print "Unable to find configuration $option_list\n";
-            if(-e "$site/apps") {
-                open(APPFILE, "$site/apps") || die "Unable to open $site/apps";
-                my @appdata = <APPFILE>;
-                close(APPFILE);
-                print "Application sets: ";
-                foreach my $app(@appdata) {
-                    chomp($app);
-                    print "$app ";
-                print "\n\n";
-__END__
-=head1 NAME
-swiftconfig - Utility for managing Swift configuration
-=head1 SYNOPSIS
-swiftconfig [B<-option> value]
-=head1 OVERVIEW
-The swiftconfig program allows users to configure Swift. It enables users to
-add configurations based on templates, copy configurations, remove configurations,
-and edit configurations.
-=head1 DESCRIPTION
-General operations:
-   -template sitename	Add a configuration based on a template
-   -remove site	     Removes a site configuration
-   -edit site	          Specifies the name of a configuration to edit
-   -copy site            Copies a configuration
-   -defaults             Do not prompt for values, always use defaults
-   -full                 Edit every available configuration option
-   -import               Import a sites.xml file into swiftconfig
-   -list                 Options: templates, configs, or a config
-   -apps                 Edit or create application sets
-   -groups               Edit site groupings
-=head1 EXAMPLES
-List all templates available for adding
-   swiftconfig -list templates
-Add a site from template into a working configuration
-   swiftconfig -template ssh
-Edit a configuration
-   swiftconfig -edit teraport
-Remove a site
-   swiftconfig -remove teraport
-Edit application sets
-    swiftconfig -apps
-List all configurations
-    swiftconfig -list configs
-List information about one particular configuration
-    swiftconfig -list configuration_name
-=cut
Deleted: trunk/bin/swiftstat
--- trunk/bin/swiftstat	2013-10-30 17:47:19 UTC (rev 7252)
+++ trunk/bin/swiftstat	2013-10-30 18:10:44 UTC (rev 7253)
@@ -1,3 +0,0 @@
-#!/bin/bash
-watch --no-title -n 5 "find -L $HOME/.swift/runs/current -name swift.out -exec echo \; -exec dirname {} \; -exec tail -1 {} \;"
Modified: trunk/build.xml
--- trunk/build.xml	2013-10-30 17:47:19 UTC (rev 7252)
+++ trunk/build.xml	2013-10-30 18:10:44 UTC (rev 7253)
@@ -75,8 +75,8 @@
 		<copy todir="${dist.dir}/libexec">
 			<fileset dir="${cog.dir}/modules/${module.name}/libexec"/>
 		</copy>
-		<copy todir="${dist.dir}/bin" flatten="true">
-			<fileset dir="${cog.dir}/modules/${module.name}/bin" excludes="grid/TODO,grid/README"/>
+		<copy todir="${dist.dir}/bin">
+			<fileset dir="${cog.dir}/modules/${module.name}/bin"/>
 		</copy>
 		<copy todir="${dist.dir}/lib/perl">
 			<fileset dir="${cog.dir}/modules/${module.name}/lib/perl"/>
@@ -85,41 +85,15 @@
 		<chmod perm="+x">
 			<fileset dir="${dist.dir}/bin">
-				<include name="VDL2Karajan"/>
-				<include name="vdlc"/>
-				<include name="swift-plot-log"/>
-				<include name="swiftconfig"/>
-				<include name="swiftrun"/>
-                                <include name="nswift"/>
 				<include name="gensites"/>
-				<include name="chxml"/>
+                                <include name="nswift"/>
 				<include name="start-coaster-service"/>
 				<include name="stop-coaster-service"/>
-				<include name="run-worker.sh"/>
-				<include name="start-grid-service"/>
-                                <include name="run-gwms-workers"/>
-				<include name="foreachsite"/>
-				<include name="gen_gridsites"/>
-				<include name="get_greensites"/>
-				<include name="maketcfrominst"/>
-				<include name="mk_catalog.rb"/>
-				<include name="mk_cats.rb"/>
-				<include name="mk_osg_sitetest.rm"/>
-				<include name="osgcat"/>
-				<include name="ress.rb"/>
-				<include name="ressfields"/>
-				<include name="run_workers"/>
-				<include name="sites"/>
-				<include name="start-ranger-service"/>
-				<include name="start-swift-service"/>
-				<include name="swift-workers"/>
-				<include name="worker.sh"/>
-				<include name="workers.ranger.sh"/>
-                                <include name="slurm-qsub"/>
-                                <include name="slurm-qsub-emulator"/>
-  				<include name="slurm-qdel"/>
-				<include name="slurm-qstat"/>
+				<include name="swiftrun"/>
+				<include name="swift-plot-log"/>
                                 <include name="swift-service"/>
+				<include name="VDL2Karajan"/>
+				<include name="vdlc"/>
 			</fileset>
 		</chmod>
 		<chmod perm="+x">
