[Swift-commit] r7230 - SwiftApps/Swift-MapRed/mapred_combiner_V4
yadunandb at ci.uchicago.edu
Thu Oct 24 15:39:05 CDT 2013
Author: yadunandb
Date: 2013-10-24 15:39:05 -0500 (Thu, 24 Oct 2013)
New Revision: 7230
Added:
SwiftApps/Swift-MapRed/mapred_combiner_V4/map_wrapper.sh
SwiftApps/Swift-MapRed/mapred_combiner_V4/reduce_wrapper.sh
Log:
Adding missed files
Added: SwiftApps/Swift-MapRed/mapred_combiner_V4/map_wrapper.sh
--- SwiftApps/Swift-MapRed/mapred_combiner_V4/map_wrapper.sh (rev 0)
+++ SwiftApps/Swift-MapRed/mapred_combiner_V4/map_wrapper.sh 2013-10-24 20:39:05 UTC (rev 7230)
@@ -0,0 +1,53 @@
+#!/bin/bash
+# By default with ARG1:100 and SLICESIZE=10000, this script will generate
+# 10^6 records.
+if [ ! -z $1 ] && [ -f $1 ]; then
+ USER_MAP_SCRIPT=$1;
+ shift 1;
+fi
+MAP_ARGS=$*
+FILE="input_$RANDOM.txt"
+HOSTNAME=$(hostname -f)
+if [[ "$HOSTNAME" == *midway* ]]; then # On midway node
+ EXECSERVER=/scratch/midway/yadunand/bin/exec_server
+ LOGFOLDER=/scratch/midway/yadunand
+ FOLDER="/dev/shm"
+ HOSTNAME="midway_$HOSTNAME"
+elif [[ "$HOSTNAME" == *nid* ]]; then # On beagle node
+ EXECSERVER=/lustre/beagle/yadunandb/bin/exec_server
+ LOGFOLDER=/lustre/beagle/yadunandb/Swift-MapRed/mapred_combiner_V5
+ FOLDER="/dev/shm"
+ HOSTNAME="beagle_$HOSTNAME"
+fi
+TIMEOUT=1200
+NC_LISTEN_PORT=29900
+# Start services on Node
+JOBS_LEVEL=`echo $PWD | grep -o ".*jobs"`
+if [ "$?" == "0" ]
+then
+ mkdir $JOBS_LEVEL/CHIRPING
+ if [ "$?" == "0" ]
+ then
+ killall -u $USER chirp_server;
+ echo "unix:$USER rwlds" > $FOLDER/acl.conf
+ echo "hostname:* rwl" >> $FOLDER/acl.conf
+ which chirp_server 1>&2
+ timeout $TIMEOUT chirp_server -A $FOLDER/acl.conf -r $FOLDER &
+ timeout $TIMEOUT $EXECSERVER &> $LOGFOLDER/exec_server_log-$HOSTNAME.log &
+ fi
+ FILE=$FOLDER/$FILE;
+else
+ FILE=$PWD/$FILE
+fi
+chmod a+x $USER_MAP_SCRIPT
+./$USER_MAP_SCRIPT ${MAP_ARGS[*]} > $FILE
+echo "$HOSTNAME $FILE"
+ps -u $USER 1>&2
+ls -thor $FILE 1>&2
+exit 0;
Property changes on: SwiftApps/Swift-MapRed/mapred_combiner_V4/map_wrapper.sh
___________________________________________________________________
Added: svn:executable
Added: SwiftApps/Swift-MapRed/mapred_combiner_V4/reduce_wrapper.sh
--- SwiftApps/Swift-MapRed/mapred_combiner_V4/reduce_wrapper.sh (rev 0)
+++ SwiftApps/Swift-MapRed/mapred_combiner_V4/reduce_wrapper.sh 2013-10-24 20:39:05 UTC (rev 7230)
@@ -0,0 +1,154 @@
+#!/bin/bash
+# The reducer is expecting to receive filenames as args
+# Each file would contains strings in the format HOSTNAME FILEPATH
+# Reduce options:
+# "naive" : Takes multiple files and applies the reduce script on them
+# "plain" : Fetches the files from the filepointers and then applies the reduce script
+# "local" : Does a local combine on every unique node and then uses plain reduce to finish
+# The files passed here are filepointers which need to be resolved
+# before they can be processed by the core reduce function.
+ARGS=($*)
+USER_REDUCE_SCRIPT=${ARGS[0]}
+chmod a+x $USER_REDUCE_SCRIPT
+CMD=${ARGS[1]}
+FILES=(${ARGS[*]:2})
+LOGS=ON # ON | OFF
+ EXECCLIENT=/scratch/midway/yadunand/bin/exec_client
+ FOLDER="/dev/shm"
+ HOSTID="midway_$HOSTNAME"
+ SITE="midway"
+ EXECCLIENT=/lustre/beagle/yadunandb/bin/exec_client
+ FOLDER="/dev/shm"
+ HOSTID="beagle_$HOSTNAME"
+ SITE="beagle"
+fi
+log()
+ [ "$LOGS" == "ON" ] && echo -e "[$(date +'%Y-%m-%d %H:%M:%S.%N')] : $*" 1>&2
+fetch()
+ log "Fetch args : \n$*\n"
+ ID=$1
+ TOKEN=$2
+ IFS=$'\ ' PTR=($(echo $TOKEN | sed 's/_/\ /'))
+ REMOTE=${PTR[1]}
+ FILE=${PTR[2]}
+ TARGETFILE=$(basename $FILE)
+ REPODIR=$(dirname $FILE)
+ if [ "$REMOTE" == "$HOSTNAME" ]
+ then # Move to an identifiable file if local
+ log "mv $FILE $REPODIR/$ID.$RANDOM.imd2"
+ #ls -thor $FILE 1>&2
+ [ ! -f $FILE ] && echo "$FILE missing" 1>&2
+ mv $FILE $REPODIR/$ID.$RANDOM.imd2
+ #ls -thor $REPODIR/$ID.$RANDOM.imd2 1>&2
+ else # Fetch to an identifiable file if remote
+ log "chirp_get $REMOTE $TARGETFILE $REPODIR/$ID.$RANDOM.imd2"
+ chirp_get $REMOTE $TARGETFILE $REPODIR/$ID.$RANDOM.imd2
+ fi
+plain ()
+ ID=$1; shift
+ IFS=$'\r\n' FILES=($(grep -h "$SITE" $*))
+ for file_token in ${FILES[*]}
+ do
+ log "fetch $ID $file_token &"
+ fetch $ID $file_token &
+ done
+ wait
+ #cat $(reduce $FOLDER/$ID*imd2)
+ log "./$USER_REDUCE_SCRIPT $FOLDER/$ID*imd2"
+ ./$USER_REDUCE_SCRIPT $FOLDER/$ID*imd2
+ rm -rf $FOLDER/$ID*imd2 &> /dev/null &
+ exit 0
+#TODO: FIX for changes in reduce definition
+local_combine_fetch_plain()
+ ID=$1; shift
+ LOCATIONS=($(awk '{ print $1 }' $* | grep $SITE | sort -u))
+ log "Starting local_combiner_fetch_plain"
+ for LOCATION in ${LOCATIONS[*]}
+ do
+ Node=($(echo "$LOCATION" | sed 's/[^ ]*_//' ))
+ FILES=($(grep -h $Node $* | awk '{ print $2 }'))
+############## LOCAL COMBINER CODE ###################
+ cat <<EOF > $Node.sh
+#!/bin/bash
+ID=$RANDOM
+FILES=(${FILES[*]})
+SITE=$SITE
+reduce()
+EOF
+ cat $USER_REDUCE_SCRIPT >> $Node.sh
+ cat <<'EOF' >> $Node.sh
+DIRNAME=$(dirname ${FILES[0]})
+RESULT=$DIRNAME/$(hostname -f).$RANDOM.comb
+reduce ${FILES[*]} > $RESULT
+echo -e "$SITE"_"$(hostname -f) $RESULT"
+EOF
+ chmod a+x $Node.sh;
+############# END LOCAL COMBINER #####################
+ #TODO: Move client with swift ?
+ cp $EXECCLIENT ./
+ TEMP=`./exec_client $Node $Node.sh`
+ # Fetch will return files in $FOLDER which match comb.$ID*imd2
+ fetch "comb.$ID" "${TEMP[*]}"
+ done
+ wait
+ log "Finished local_combiner_fetch"
+ ls $FOLDER/comb.$ID*imd2 1>&2
+ ./$USER_REDUCE_SCRIPT $FOLDER/comb.$ID*imd2
+ log "Finished running ./$USER_REDUCE_SCRIPT $FOLDER/comb.$ID*imd2"
+ID=$RANDOM
+case "$CMD" in
+ "naive")
+ echo "Using naive reduce" 1>&2
+ ./$USER_REDUCE_SCRIPT ${FILES[*]}
+ "plain")
+ echo "Using plain reduce" 1>&2
+ echo "plain $ID ${FILES[*]}" 1>&2
+ plain $ID ${FILES[*]}
+ "local")
+ echo "Using local combiners" 1>&2
+ local_combine_fetch_plain $ID ${FILES[*]}
+ "local_k_way")
+ local_combine $ID ${FILES[*]}
+ echo "ERROR: Unknown reduction method requested" 1>&2
+esac
+exit 0
Property changes on: SwiftApps/Swift-MapRed/mapred_combiner_V4/reduce_wrapper.sh
More information about the Swift-commit
