[Swift-commit] r7205 - in SwiftTutorials/swift-cloud-tutorial: app doc part02
davidk at ci.uchicago.edu
Tue Oct 22 11:39:56 CDT 2013
Author: davidk
Date: 2013-10-22 11:39:56 -0500 (Tue, 22 Oct 2013)
New Revision: 7205
Modified:
SwiftTutorials/swift-cloud-tutorial/app/simulate.py
SwiftTutorials/swift-cloud-tutorial/doc/README
SwiftTutorials/swift-cloud-tutorial/part02/apps
Log:
Python example
Modified: SwiftTutorials/swift-cloud-tutorial/app/simulate.py
--- SwiftTutorials/swift-cloud-tutorial/app/simulate.py 2013-10-22 15:59:07 UTC (rev 7204)
+++ SwiftTutorials/swift-cloud-tutorial/app/simulate.py 2013-10-22 16:39:56 UTC (rev 7205)
@@ -5,6 +5,7 @@
import time
import math
import random
+import getpass
def parse():
from optparse import OptionParser
@@ -48,7 +49,7 @@
print >> sys.stderr, "Called as: ", str(sys.argv)
print >> sys.stderr, "Start time: ", datetime.datetime.now()
print >> sys.stderr, "Running on node: ", socket.gethostname()
- print >> sys.stderr, "Running as user: ",os.getlogin()
+ print >> sys.stderr, "Running as user: ", getpass.getuser()
print >> sys.stderr, "\nEnvironment:\n\n"
print >> sys.stderr, os.environ
Modified: SwiftTutorials/swift-cloud-tutorial/doc/README
--- SwiftTutorials/swift-cloud-tutorial/doc/README 2013-10-22 15:59:07 UTC (rev 7204)
+++ SwiftTutorials/swift-cloud-tutorial/doc/README 2013-10-22 16:39:56 UTC (rev 7205)
@@ -345,6 +345,16 @@
example of naming the output files of an ensemble run. In this case, the output files will be named
`output/sim_N.out`.
+In part 2, we also update the apps file. Instead of using shell script (simulate.sh), we use
+the equivalent python version (simulate.py). The new apps file now looks like this:
+localhost simulate simulate.py
+Swift does not need to know anything about the language an application is written in. The application
+can be written in Perl, Python, Java, Fortran, or any other language.
To run the script and view the output:
$ cd ../part02
Modified: SwiftTutorials/swift-cloud-tutorial/part02/apps
--- SwiftTutorials/swift-cloud-tutorial/part02/apps 2013-10-22 15:59:07 UTC (rev 7204)
+++ SwiftTutorials/swift-cloud-tutorial/part02/apps 2013-10-22 16:39:56 UTC (rev 7205)
@@ -1 +1 @@
-localhost simulate simulate.sh
More information about the Swift-commit
