[Swift-commit] r7196 - branches/release-0.94/bin
davidk at ci.uchicago.edu
Mon Oct 21 19:24:11 CDT 2013
Author: davidk
Date: 2013-10-21 19:24:10 -0500 (Mon, 21 Oct 2013)
New Revision: 7196
Modified:
branches/release-0.94/bin/start-coaster-service
Log:
Moving start-coaster-service to 0.94.2 RC2 release
Modified: branches/release-0.94/bin/start-coaster-service
--- branches/release-0.94/bin/start-coaster-service 2013-10-21 23:17:04 UTC (rev 7195)
+++ branches/release-0.94/bin/start-coaster-service 2013-10-22 00:24:10 UTC (rev 7196)
@@ -1,6 +1,6 @@
-#!/bin/bash
+#!/bin/bash
-# crash: Report a problem and exit
+# Report a problem and exit
crash()
MSG=$1
@@ -8,239 +8,51 @@
exit 1
-# Start futuregrid workers
-start-workers-futuregrid()
+# Wait for a file to be created, up to given amount of time
+wait_for_file()
- # Setup environment
- PORT=$1
- EXECUTIONURL=http://localhost:$PORT
- export EC2_ACCESS_KEY=$FUTUREGRID_IAAS_ACCESS_KEY
- export EC2_SECRET_KEY=$FUTUREGRID_IAAS_SECRET_KEY
- # Check that SWIFTVMBOOT_DIR looks ok
- if [ ! -d "$SWIFTVMBOOT_DIR" ] || [ ! -x "$SWIFTVMBOOT_DIR/futuregrid/bin/bootit.sh" ]; then
- crash "SWIFTVMBOOT_DIR incorrectly defined in coaster-service.conf"
- fi
- # Install ve
- if [ ! -d "$SWIFTVMBOOT_DIR/futuregrid/ve" ]; then
- echo Setting up environment
- python $SWIFTVMBOOT_DIR/futuregrid/bin/virtualenv.py $SWIFTVMBOOT_DIR/futuregrid/ve
- if [ $? -ne 0 ]; then
- echo "Failed to created the needed python virtual environment"
- exit 1
+ FILE=$1
+ TIME=$2
+ count=0
+ while [ ! -s "$FILE" ]; do
+ sleep 1
+ (( count += 1 ))
+ if [ $count -ge $TIME ]; then
+ crash "Timed out waiting for coaster port file $FILE"
fi
- fi
- # Install cloudinitd
- source $SWIFTVMBOOT_DIR/futuregrid/ve/bin/activate
- easy_install cloudinitd
- echo "Failed to install cloudinitd"
- exit 1
- fi
- # Register key
- echo "Registering the key names in all the clouds"
- python $SWIFTVMBOOT_DIR/futuregrid/bin/register_key.py $SWIFTVMBOOT_DIR/futuregrid/hosts.txt
- echo "Failed to register the key names"
- exit 1
- fi
- # Start virtual machines
- echo Starting virtual machines.. please wait
- $SWIFTVMBOOT_DIR/futuregrid/bin/bootit.sh | tee -a bootit.log
- SWIFTVMBOOT_OUTPUT=$SWIFTVMBOOT_DIR/futuregrid/output.json
- if [ ! -f "$SWIFTVMBOOT_OUTPUT" ]; then
- crash "Error: Swift VM output file $SWIFTVMBOOT_OUTPUT does not exist!"
- fi
- SWIFTVM_INSTANCE=`grep "Starting up run" bootit.log |awk '{print $4}'`
- echo $SWIFTVM_INSTANCE >> $HOME/.swift/.swiftvm_instances
- WORKER_HOSTS=`grep hostname $SWIFTVMBOOT_OUTPUT |awk '{print $2}'|sed 's/\"//g;s/,//g;s/null//g'`
- # Start worker script
- for MACHINE in $WORKER_HOSTS
- do
- echo $MACHINE >> $HOME/.swift/machines
- scp $SWIFT_BIN/$WORKER $WORKER_USERNAME@$MACHINE:$WORKER_LOCATION > /dev/null 2>&1
- if [ "$SSH_TUNNELING" == "yes" ]; then
- ssh -R *:$PORT:localhost:$PORT $WORKER_USERNAME@$MACHINE sleep 999 &
- echo $! >> $PID_FILE
- echo "Starting worker on $MACHINE"
- ssh $WORKER_USERNAME@$MACHINE "$WORKER_LOCATION/$WORKER http://localhost:$PORT $MACHINE $LOG_DIR" &
- else
- ssh $WORKER_USERNAME@$MACHINE "$WORKER_LOCATION/$WORKER $EXECUTIONURL $MACHINE $LOG_DIR" &
- fi
done
-# Globus Provision workers
-start-workers-gp()
+run_command()
- PORT=$1
- if [ ! -d "$SWIFTVMBOOT_DIR" ] || [ ! -x "$SWIFTVMBOOT_DIR/bin/gp-instance-create" ]; then
- fi
- SEDFILE=`mktemp XXXXXX`
- echo "s at _CLUSTER-NODES_@$EC2_NODES@"
- echo "s at _INSTANCE-TYPE_@$EC2_INSTANCE_TYPE@"
- echo "s at _KEYPAIR_@$EC2_KEYPAIR@"
- echo "s at _KEYFILE_@$EC2_KEYFILE@"
- echo "s at _AMI_@$EC2_AMI@"
- } > $SEDFILE
- sed -f $SEDFILE < "$SWIFTVMBOOT_DIR/ec2.template.conf" > "$SWIFTVMBOOT_DIR/ec2.conf"
- rm $SEDFILE
- echo Creating instance..
- "$SWIFTVMBOOT_DIR/bin/gp-instance-create" -c "$SWIFTVMBOOT_DIR/ec2.conf" | sed -r "s/\x1B\[([0-9]{1,2}(;[0-9]{1,2})?)?[m|K]//g" | tee -a gpic.out
- SWIFTVM_INSTANCE=`awk '{print $4}' gpic.out`
- rm gpic.out
- echo Starting instance..
- "$SWIFTVMBOOT_DIR/bin/gp-instance-start" "$SWIFTVM_INSTANCE" | sed -r "s/\x1B\[([0-9]{1,2}(;[0-9]{1,2})?)?[m|K]//g"
- WORKER_HOSTS=`$SWIFTVMBOOT_DIR/bin/gp-instance-describe $SWIFTVM_INSTANCE|sed -r "s/\x1B\[([0-9]{1,2}(;[0-9]{1,2})?)?[m|K]//g"|awk '{print $3}'`
- if [ -f "$HOME/.swift/machines" ]; then
- rm $HOME/.swift/machines
- fi
- do
- # Create a list of machines for other applications, if needed
- # Enable ssh tunneling if needed
- ssh -q -o StrictHostKeyChecking=no -R *:$PORT:localhost:$PORT $WORKER_USERNAME@$MACHINE sleep 999 &
- fi
- # Copy and start worker script
- scp -q -o StrictHostKeyChecking=no $SWIFT_BIN/$WORKER $WORKER_USERNAME@$MACHINE:$WORKER_LOCATION > /dev/null 2>&1
- ssh -q -o StrictHostKeyChecking=no $WORKER_USERNAME@$MACHINE "$WORKER_LOCATION/$WORKER $EXECUTIONURL $MACHINE $LOG_DIR" &
- done
+ command="$@"
+ echo "Running $command" >> $LOG
+ $command >> $LOG 2>&1
-# EC2 workers
-start-workers-ec2()
+run_command_bg()
- PORT=$1
- if [ ! -d "$SWIFTVMBOOT_DIR" ] || [ ! -x "$SWIFTVMBOOT_DIR/ec2/bin/ec2-run-instances" ]; then
- fi
- export EC2_HOME="$SWIFTVMBOOT_DIR/ec2"
- export EC2_PRIVATE_KEY="$EC2_KEYFILE"
- export EC2_CERT="$EC2_CERTFILE"
- $SWIFTVMBOOT_DIR/ec2/bin/ec2-run-instances "$EC2_AMI" -t "$EC2_INSTANCE_TYPE" -n "$EC2_NODES" -K "$EC2_KEYFILE" -C "$EC2_CERT"
- SWIFTVM_INSTANCES=$( $SWIFTVMBOOT_DIR/ec2/bin/ec2-describe-instances | grep INSTANCE | grep -v terminated |awk '{print $2}' )
- echo $SWIFTVM_INSTANCES >> $HOME/.swift/.swiftvm_instances
- echo Waiting for nodes to boot..
- # Wait until all instances are listed as running
- while /bin/true
- do
- SWIFTVM_INSTANCES_AS_STRING=$( echo $SWIFTVM_INSTANCES | tr "\\n" " ")
- STATUS_LIST=$( $SWIFTVMBOOT_DIR/ec2/bin/ec2-describe-instances $SWIFTVM_INSTANCES_AS_STRING | grep INSTANCE | grep -v terminated | awk '{print $6}' |sort -u )
- if [ "$STATUS_LIST" == "running" ]; then
- break
- fi
- sleep 5
- done
- # There is some delay between when the machines are 'running', and when system utilities like sshd are started
- sleep 30
- WORKER_HOSTS=$( $SWIFTVMBOOT_DIR/ec2/bin/ec2-describe-instances $SWIFTVM_INSTANCES_AS_STRING | grep INSTANCE | grep -v terminated | awk '{print $4}' )
- fi
- SSH_OPTS="-i $EC2_KEYFILE -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no"
- do
- scp $SSH_OPTS $SWIFT_BIN/$WORKER $WORKER_USERNAME@$MACHINE:$WORKER_LOCATION > /dev/null 2>&1
- ssh $SSH_OPTS -R *:$PORT:localhost:$PORT $WORKER_USERNAME@$MACHINE sleep 999 > /dev/null 2>&1 &
- sleep 10
- ssh $SSH_OPTS $WORKER_USERNAME@$MACHINE "$WORKER_LOCATION/$WORKER http://localhost:$PORT $MACHINE $LOG_DIR" 2>&1 &
- else
- ssh $SSH_OPTS $WORKER_USERNAME@$MACHINE "$WORKER_LOCATION/$WORKER $EXECUTIONURL $MACHINE $LOG_DIR" > /dev/null 2>&1 &
- fi
- # Copy SSH key for easier access
- cat $HOME/.ssh/*.pub | ssh $SSH_OPTS $WORKER_USERNAME@$MACHINE 'umask 077; cat >> $HOME/.ssh/authorized_keys' > /dev/null 2>&1
- done
+ command="$@"
+ $command >> $LOG 2>&1 &
+ echo $! >> $PID_FILE
# Start SSH workers
start-workers-ssh()
- PORT=$1
- EXECUTIONURL=http://$IPADDR:$PORT
- if [ -z "$PORT" ]; then
- crash "start-workers-ssh: Port number not specified, giving up"
- fi
- if [ -n "$WORKER_RELAY_HOST" ]; then
- scp -A $SWIFT_BIN/$WORKER $WORKER_USERNAME@$WORKER_RELAY_HOST:/tmp > /dev/null 2>&1
- fi
do
- SSH_COMMAND="ssh -A "
- SSH_COMMAND="$SSH_COMMAND -n -R $PORT:localhost:$PORT"
+ run_command_bg ssh -N -T -R *:$LOCAL_PORT:localhost:$LOCAL_PORT "$WORKER_USERNAME@$MACHINE"
fi
- # Use a relay host
- ssh -A $WORKER_USERNAME@$WORKER_RELAY_HOST ssh $MACHINE mkdir -p $WORKER_LOCATION > /dev/null 2>&1
- ssh -A $WORKER_USERNAME@$WORKER_RELAY_HOST "scp /tmp/$WORKER $WORKER_USERNAME@$MACHINE:$WORKER_LOCATION" > /dev/null 2>&1
- echo Starting worker on $MACHINE
- eval "$SSH_COMMAND $WORKER_USERNAME at WORKER_RELAY_HOST WORKER_LOGGING_LEVEL=$WORKER_LOGGING_LEVEL $WORKER_LOCATION/$WORKER $EXECUTIONURL $MACHINE $WORKER_LOG_DIR" &
# Connect directly
- else
- ssh $WORKER_USERNAME@$MACHINE mkdir -p $WORKER_LOCATION > /dev/null 2>&1
- eval "$SSH_COMMAND $WORKER_USERNAME@$MACHINE WORKER_LOGGING_LEVEL=$WORKER_LOGGING_LEVEL $WORKER_LOCATION/$WORKER $EXECUTIONURL $MACHINE $WORKER_LOG_DIR" &
- fi
+ run_command ssh $WORKER_USERNAME@$MACHINE mkdir -p $WORKER_LOCATION
+ run_command scp $WORKER $WORKER_USERNAME@$MACHINE:$WORKER_LOCATION
+ echo Starting worker on $MACHINE
+ run_command_bg ssh $WORKER_USERNAME@$MACHINE "WORKER_LOGGING_LEVEL=$WORKER_LOGGING_LEVEL $WORKER_LOCATION/worker.pl $WORKERURL $MACHINE $WORKER_LOG_DIR"
done
return 0
@@ -248,152 +60,19 @@
# Start local workers
start-workers-local()
- PORT=$1
- crash "start-workers-local: Port number not specified, giving up"
- fi
echo Starting worker on local machine
- $WORKER $EXECUTIONURL LOCAL $LOG_DIR &
+ run_command_bg $WORKER $WORKERURL LOCAL $WORKER_LOG_DIR
return 0
# Start condor workers
-start-workers-condor()
+start-workers-scheduler()
- PORT=$1
- fi
echo Starting workers
- if [ -z "$CONDOR_WORKERS" ]; then
- crash "CONDOR_WORKERS undefined - please check coaster-service.conf"
- fi
- if [ -z "$CONDOR_MACHINE_COUNT" ]; then
- export CONDOR_MACHINE_COUNT=1
- fi
-cat <<EOF > start_workers.submit
-output = workers.stdout
-error = workers.stderr
-executable = $WORKER_LOCATION/$WORKER
-arguments = $EXECUTIONURL node .
-notification = Never
-leave_in_queue = FALSE
-machine_count = $CONDOR_MACHINE_COUNT
-+AccountingGroup="group_friends.$USER"
-queue $CONDOR_WORKERS
-EOF
- scp start_workers.submit $WORKER_USERNAME@$WORKER_RELAY_HOST:
- scp $SWIFT_BIN/$WORKER $WORKER_USERNAME@$WORKER_RELAY_HOST:$WORKER_LOCATION > /dev/null 2>&1
- ssh $WORKER_USERNAME@$WORKER_RELAY_HOST "condor_submit start_workers.submit"
- else
- condor_submit start_workers.submit
- fi
+ run_command $SCHEDULER_COMMAND
-# Start condor workers
-start-workers-slurm()
- PORT=$1
- fi
- echo Starting workers
- if [ -z "$MACHINE_COUNT" ]; then
- export MACHINE_COUNT=1
- fi
-#!/bin/bash
-#SBATCH --output=start_workers.stdout
-#SBATCH --error=start_workers.stderr
-#SBATCH --nodes=$MACHINE_COUNT
-#SBATCH --exclusive
-#SBATCH --ntasks-per-node=1
-#SBATCH --cpus-per-task=12
-#SBATCH --partition=normal
-#SBATCH --time=11:59:00
-#SBATCH -A TG-ASC090068
-export WORKER_LOGGING_LEVEL=NONE
-ibrun $WORKER_LOCATION/$WORKER $EXECUTIONURL node .
-EOF
- ssh $WORKER_USERNAME@$WORKER_RELAY_HOST "sbatch start_workers.submit"
- else
- sbatch start_workers.submit
- fi
-# Start GWMS workers
-start-workers-gwms()
- PORT=$1
- fi
- fi
- if [ -z "$WORKER_LOGGING_LEVEL" ]; then
- WORKER_LOGGING_LEVEL=INFO
- fi
- ssh $WORKER_USERNAME@$WORKER_RELAY_HOST "mkdir -p condor"
- ssh $WORKER_USERNAME@$WORKER_RELAY_HOST "grid-proxy-init"
- ssh $WORKER_USERNAME@$WORKER_RELAY_HOST "WORKER_INIT_CMD='$WORKER_INIT_CMD' WORKER_LOGGING_LEVEL=$WORKER_LOGGING_LEVEL run-gwms-workers $EXECUTIONURL $CONDOR_WORKERS"
- else
- mkdir -p condor
- run-gwms-workers $EXECUTIONURL $CONDOR_WORKERS
- fi
-# Start cobalt workers
-start-workers-cobalt()
- PORT=$1
- crash "start-workers-cobalt: Port number not specified, giving up"
- fi
- TIMESTAMP=$(date "+%Y.%m%d.%H%M%S")
- R=${RANDOM}
- ID="${TIMESTAMP}.${R}"
- # -t in minutes
- set -x
- cqsub -q ${QUEUE} \
- -k ${KERNEL} \
- -t ${MAXTIME} \
- -n ${NODES} \
- -C ${PWD}/${LOG_DIR} \
- -E cobalt.${$}.stderr \
- -o cobalt.${$}.stdout \
- -e "WORKER_LOGGING_LEVEL=DEBUG:ZOID_ENABLE_NAT=true" \
- $SWIFT_BIN/$WORKER $EXECUTIONURL $ID $PWD/$LOG_DIR
- return 0
+# Parse command line arguments
while [ $# -gt 0 ]; do
case $1 in
-conf) CMDLN_CONF=$2; shift 2;;
@@ -401,110 +80,88 @@
esac
done
-if [ ! -d "$HOME/.swift" ]; then
- mkdir -p "$HOME/.swift" || crash "Unable to create $HOME/.swift"
-fi
+# Determine the location of needed files
+export SWIFT_BIN="$( cd "$( dirname "$0" )" && pwd )"
+export WORKER="$SWIFT_BIN/worker.pl"
+export WORKER_LOGGING_LEVEL="NONE"
+export PID_FILE="$HOME/.swift/.coaster-service-pids"
+export COASTER_SERVICE="$SWIFT_BIN/coaster-service"
+export LOG="start-coaster-service.log"
+mkdir -p "$HOME/.swift" || crash "Unable to create $HOME/.swift"
-PID_FILE="$HOME/.swift/.coaster-service-pids"
-RUN_DIR=$PWD
# Import settings
if [ -f "$CMDLN_CONF" ]; then
CONFIG_FILE=$CMDLN_CONF
-elif [ -f "$RUN_DIR/coaster-service.conf" ]; then
- CONFIG_FILE="$RUN_DIR/coaster-service.conf"
-elif [ -f "$HOME/.swift/coaster-service.conf" ]; then
- CONFIG_FILE="$HOME/.swift/coaster-service.conf"
-elif [ -f "$(dirname $(readlink -f $0))/../etc/coaster-service.conf" ]; then
- CONFIG_FILE="$(dirname $(readlink -f $0))/../etc/coaster-service.conf"
+elif [ -f "coaster-service.conf" ]; then
+ CONFIG_FILE="coaster-service.conf"
else
crash "Cannot find coaster-service.conf!"
fi
echo "Start-coaster-service..."
echo "Configuration: $CONFIG_FILE"
source $CONFIG_FILE
-# Determine IP address to which workers should connect
+if [ "$SSH_TUNNELING" == "yes" ]; then
+ IPADDR=localhost
+fi
if [ -z "$IPADDR" ]; then
- IPADDR=localhost
- elif [ -n "$GLOBUS_HOSTNAME" ]; then
+ if [ -n "$GLOBUS_HOSTNAME" ]; then
IPADDR=$GLOBUS_HOSTNAME
- elif [ -x "/sbin/ifconfig" ]; then
- IPADDR=$( /sbin/ifconfig 2>/dev/null | grep 'inet addr' | grep -v 127.0.0.1 | cut -d ':' -f 2 | awk '{print $1}' |head -1)
else
- crash "Unable to determine IP address of system. Please add to coaster-service.conf"
+ crash "Unable to determine IP address"
fi
fi
echo Service address: $IPADDR
-# Find swift
-if [ ! -x "$SWIFT" ]; then
- SWIFT=`which swift`
- if [ ! -x "$SWIFT" ]; then
- crash "Unable to find swift! Please either add to your $PATH or specify the path in coaster-service.conf"
- fi
-fi
-SWIFT_BIN=`dirname $SWIFT`
-WORKER=worker.pl
# Verify worker script is there
-if [ ! -x "$SWIFT_BIN/$WORKER" ]; then
- crash "Error: Unable to find worker at $SWIFT_BIN/$WORKER!"
+if [ ! -x "$WORKER" ]; then
+ crash "Error: Unable to find worker $WORKER!"
fi
-# Try to create $LOG_DIR if needed, relative to $RUN_DIR
-if [ ! -d "$RUN_DIR/$LOG_DIR" ]; then
- mkdir -p "$RUN_DIR/$LOG_DIR" > /dev/null 2>&1
- if [ ! -d "$RUN_DIR/$LOG_DIR" ]; then
- crash "Unable to make directory $RUN_DIR/$LOG_DIR!"
- fi
-fi
-# Set paths to log files
-SWIFT_LOG="$RUN_DIR/$LOG_DIR"/swift.out
-COASTER_LOG="$RUN_DIR/$LOG_DIR"/coaster.log
# Verify we can find coaster service
-if [ ! -x "$SWIFT_BIN/coaster-service" ]; then
- crash "Unable to find $SWIFT_BIN/coaster-service!"
+if [ ! -x "$COASTER_SERVICE" ]; then
+ crash "Unable to find $COASTER_SERVICE!"
fi
# Create files for storing port info, if needed
if [ -z "$LOCAL_PORT" ]; then
- LOCAL_PORT_FILE=`mktemp XXXXXX`
+ LOCAL_PORT_FILE=$( mktemp )
fi
if [ -z "$SERVICE_PORT" ]; then
- SERVICE_PORT_FILE=`mktemp XXXXXX`
+ SERVICE_PORT_FILE=$( mktemp )
fi
# Check values in configuration file to determine how we should start coaster-service
echo Starting coaster-service
if [ -z "$SERVICE_PORT" ] && [ -z "$LOCAL_PORT" ]; then
- $SWIFT_BIN/coaster-service -nosec -portfile $SERVICE_PORT_FILE -localportfile $LOCAL_PORT_FILE -passive > $COASTER_LOG 2>&1 &
+ run_command_bg $COASTER_SERVICE -nosec -portfile $SERVICE_PORT_FILE -localportfile $LOCAL_PORT_FILE -passive
elif [ -n "$SERVICE_PORT" ] && [ -z "$LOCAL_PORT" ]; then
- $SWIFT_BIN/coaster-service -nosec -port $SERVICE_PORT -localportfile $LOCAL_PORT_FILE -passive > $COASTER_LOG 2>&1 &
+ run_command_bg $COASTER_SERVICE -nosec -port $SERVICE_PORT -localportfile $LOCAL_PORT_FILE -passive
elif [ -z "$SERVICE_PORT" ] && [ -n "$LOCAL_PORT" ]; then
- $SWIFT_BIN/coaster-service -nosec -portfile $SERVICE_PORT_FILE --localport $LOCAL_PORT -passive > $COASTER_LOG 2>&1 &
+ run_command_bg $COASTER_SERVICE -nosec -portfile $SERVICE_PORT_FILE --localport $LOCAL_PORT -passive
elif [ -n "$SERVICE_PORT" ] && [ -n "$LOCAL_PORT" ]; then
- $SWIFT_BIN/coaster-service -nosec -port $SERVICE_PORT -localport $LOCAL_PORT -passive > $COASTER_LOG 2>&1 &
-else
- crash "Unknown SERVICE_PORT type specified!"
+ run_command_bg $COASTER_SERVICE -nosec -port $SERVICE_PORT -localport $LOCAL_PORT -passive
fi
-echo $! >> $PID_FILE
-sleep 15
+# If waiting on port files to be created, wait for files to be created, but no longer
+if [ -z "$SERVICE_PORT" ]; then
+ wait_for_file $SERVICE_PORT_FILE 60
+fi
+if [ -z "$LOCAL_PORT" ]; then
+ wait_for_file $LOCAL_PORT_FILE 60
+fi
# Determine SERVICE_PORT
if [ ! -f "$SERVICE_PORT_FILE" ]; then
crash "Unable to determine SERVICE_PORT!"
fi
- SERVICE_PORT=`cat $SERVICE_PORT_FILE`
+ SERVICE_PORT=$( cat $SERVICE_PORT_FILE )
rm $SERVICE_PORT_FILE
fi
@@ -513,7 +170,7 @@
if [ ! -f "$LOCAL_PORT_FILE" ]; then
crash "Unable to determine LOCAL_PORT!"
fi
- LOCAL_PORT=`cat $LOCAL_PORT_FILE`
+ LOCAL_PORT=$( cat $LOCAL_PORT_FILE )
rm $LOCAL_PORT_FILE
fi
@@ -522,72 +179,23 @@
# Generate sites.xml
export EXECUTIONURL="http://$IPADDR:$SERVICE_PORT"
+export WORKERURL="http://$IPADDR:$LOCAL_PORT"
echo Generating sites.xml
if [ -f "gensites.template" ]; then
- gensites `cat gensites.template` -p $CONFIG_FILE > $RUN_DIR/sites.xml
+ gensites $( cat gensites.template ) -p $CONFIG_FILE > sites.xml
else
- gensites persistent-coasters -p $CONFIG_FILE > $RUN_DIR/sites.xml
+ gensites persistent-coasters -p $CONFIG_FILE > sites.xml
fi
-# Workaround for bug #467. This is needed to property set jobspernode when using persistent coasters.
-echo "app echo (string i) { echo i; }" > jobspernode.swift
-echo "echo(\"hi\");" >> jobspernode.swift
-echo "persistent-coasters echo /bin/echo null null null" >> jobspernode.apps
-swift -sites.file sites.xml -tc.file jobspernode.apps -config cf jobspernode.swift > /dev/null 2>&1 &
-DUMMYPID=$!
-sleep 15 # This won't run until later when the workers are started
# Start workers
case $WORKER_MODE in
- ssh)
- start-workers-ssh $LOCAL_PORT
- local)
- start-workers-local $LOCAL_PORT
- cobalt)
- start-workers-cobalt $LOCAL_PORT
- futuregrid)
- start-workers-futuregrid $LOCAL_PORT
- gp)
- start-workers-gp $LOCAL_PORT
- ec2)
- start-workers-ec2 $LOCAL_PORT
- condor)
- start-workers-condor $LOCAL_PORT
- gwms)
- start-workers-gwms $LOCAL_PORT
- slurm)
- start-workers-slurm $LOCAL_PORT
- crash "Unknown WORKER_MODE. Please modify coaster-service.conf"
+ ssh) start-workers-ssh;;
+ local) start-workers-local;;
+ scheduler) start-workers-scheduler;;
+ *) crash "Unknown WORKER_MODE";;
esac
-# Wait for dummy script to finish
-wait $DUMMYPID
-rm -rf jobspernode* swift.log > /dev/null 2>&1
-# Generate config file
-if [ "$SHARED_FILESYSTEM" == "no" ]; then
-echo Generating config file
-cat > $RUN_DIR/cf << EOF
-use.provider.staging=true
-wrapperlog.always.transfer=false
-execution.retries=10
-provider.staging.pin.swiftfiles=false
-sitedir.keep=false
-use.wrapper.staging=false
-EOF
-fi
# Local Variables:
# tab-width: 3
# sh-basic-offset: 3
More information about the Swift-commit
