[Swift-commit] r7190 - trunk/docs/quickstart
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Mon Oct 21 17:30:58 CDT 2013
Author: davidk
Date: 2013-10-21 17:30:58 -0500 (Mon, 21 Oct 2013)
New Revision: 7190
Modified:
   trunk/docs/quickstart/quickstart.txt
Log:
Quickstart simplification
Modified: trunk/docs/quickstart/quickstart.txt
--- trunk/docs/quickstart/quickstart.txt	2013-10-21 20:18:40 UTC (rev 7189)
+++ trunk/docs/quickstart/quickstart.txt	2013-10-21 22:30:58 UTC (rev 7190)
@@ -1,101 +1,26 @@
 Swift Quickstart
-[abstract]
-Abstract
-This guide describes the steps needed to download, install, configure,
-and run the basic examples for Swift. If you are using a pre-installed
-version of Swift, you can skip directly to the configuration section.
+Download Swift
+The latest stable Swift release is Swift 0.94.1.
-Stable Releases vs. Development Releases
-Stable releases of Swift have undergone more extensive testing than development releases.
-In general, they are more stable, have fewer bugs, and have been tested on a variety of
-systems.
+1. Download the file from http://swiftlang.org/packages/swift-0.94.1.tar.gz.
+2. Extract by running "tar xfz swift-0.94.1.tar.gz"
+3. Add to PATH by running "export PATH=$PATH:/path/to/swift-0.94.1/bin"
-The development version of Swift is aimed at developers and testers. The
-development code has the highest chance of containing buggy and/or untested
-code. If you need stability, use the latest stable release.
+Run Swift
+Example Swift scripts can be found in the swift-0.94.1/examples directory.
+Scripts have a .swift file extension. Run the following commands
+to launch a simple hello world application.
-Downloading a Swift Distribution
-There are two main ways of getting the Swift implementation: binary
-releases and the source repository.
-Binary Releases
-For the majority of users, downloading and installing binary releases is recommended.
-Since Swift is written in Java, the binary packages will run on all supported platforms with
-Java Runtime Environment 1.5 or greater. Binary releases can be obtained from the
-http://www.ci.uchicago.edu/swift/downloads/index.php[Swift downloads page].
-Once downloaded, simply unpack the downloaded package (swift-<version>.tar.gz) into a
-directory of your choice:
-tar -xzvf swift-<version>.tar.gz
-This will create a swift-<version> directory containing the build.
-Source Repository
-The source code for Swift is available to developers who have an interest in contributing
-new features. To build Swift from source code, you will need http://ant.apache.org/[Apache Ant]
-and http://www.oracle.com/technetwork/java/javase/downloads/index.html[Java JDK]. Once
-built, the dist/swift-svn directory will contain your build.
-To download and build Swift 0.94, follow these instructions:
-$ mkdir swift-0.94
-$ cd swift-0.94
-$ svn co https://svn.code.sf.net/p/cogkit/svn/branches/4.1.10/src/cog
-$ cd cog/modules
-$ svn co https://svn.ci.uchicago.edu/svn/vdl2/branches/release-0.94 swift
-$ cd swift
-$ ant redist
-Setting your PATH
-Once Swift is installed, it is useful to add the swift binary to your PATH
-environment variable. To do this, first determine where the Swift bin
-directory is located. If you installed Swift from a binary release, it will
-be in the swift-0.94/bin directory where you installed it. If you followed
-the instructions above for installing Swift from a source repository, it
-will be located in swift-<version>/cog/modules/swift/dist/swift-svn/bin.
-Add the following line to the bottom of ~/.bashrc:
-export PATH=$PATH:/full/path/to/swift
-When you login, test this out by typing the command
-$ which swift
-This should point you to the path of the Swift binary.
-Running Swift Examples
-The Swift examples can be found in the examples directory in the Swift
-distribution. The examples are written in the Swift scripting language, and
-have .swift as a file extension.
-Execution of a Swift script is done using the swift command, which
-takes the Swift script file name as an argument:
-cd examples/tutorial
+cd swift-0.94.1/examples/
 swift hello.swift
 When you run this application, it should create a file called hello.txt.
-If this file gets created, you have successfully ran your first
-Swift script!
 More documentation on how to run Swift can be found at
-http://www.ci.uchicago.edu/swift/docs/index.php
+http://www.ci.uchicago.edu/swift/docs/index.php.
