[Swift-commit] r7179 - SwiftTutorials/OSDC-2013-10-17/doc
wilde at ci.uchicago.edu
Fri Oct 18 08:41:39 CDT 2013
Author: wilde
Date: 2013-10-18 08:41:38 -0500 (Fri, 18 Oct 2013)
New Revision: 7179
Modified:
SwiftTutorials/OSDC-2013-10-17/doc/README
Log:
Initial adjustments from Cray to OSDC. More needed.
Modified: SwiftTutorials/OSDC-2013-10-17/doc/README
--- SwiftTutorials/OSDC-2013-10-17/doc/README 2013-10-18 03:58:38 UTC (rev 7178)
+++ SwiftTutorials/OSDC-2013-10-17/doc/README 2013-10-18 13:41:38 UTC (rev 7179)
@@ -1,5 +1,5 @@
-Swift Cray Tutorial
+Swift Tutorial for Open Science Data Cloud Resources
@@ -9,7 +9,7 @@
This tutorial is viewable at:
-http://swift-lang.org/tutorials/cray/swift-cray-tutorial.html
+http://swift-lang.org/tutorials/osdc/swift-osdc-tutorial.html
@@ -23,7 +23,7 @@
Compute-node exercises, running apps via qsub and aprun:
- p4 - Running apps on Cray compute nodes
+ p4 - Running apps on OSDC compute nodes
p5 - Running on multiple pools of compute nodes
p6 - Running a more complex workflow pattern
@@ -48,21 +48,21 @@
clusters, clouds, grids, and supercomputers.
In this tutorial, you'll be able to first try a few Swift examples
-(parts 1-3) on the Cray login host, to get a sense of the
-language. Then in parts 4-6 you'll run similar workflows on Cray
+(parts 1-3) on an OSDC login host, to get a sense of the
+language. Then in parts 4-6 you'll run similar workflows on OSDC
compute nodes, and see how more complex workflows can be expressed
with Swift scripts.
Swift tutorial setup
-To install the tutorial scripts on Cray "Raven" XE6-XK7 test system,
+To install the tutorial scripts on an OSDC login host,
do:
$ cd $HOME
-$ tar xzf /home/users/p01532/swift-cray-tutorial.tgz
-$ cd swift-cray-tutorial
+$ tar xzf /glusterfs/users/swiftlang/tutorial/swift-osdc-tutorial.tgz
+$ cd swift-osdc-tutorial
$ source setup.sh # You must run this with "source" !
@@ -85,10 +85,10 @@
the Swift Subversion repository, do:
-$ svn co https://svn.ci.uchicago.edu/svn/vdl2/SwiftTutorials/swift-cray-tutorial Cray-Swift
+$ svn co https://svn.ci.uchicago.edu/svn/vdl2/SwiftTutorials/swift-osdc-tutorial OSDC-Swift
-This will create a directory called "Cray-Swift" which contains all of the
+This will create a directory called "OSDC-Swift" which contains all of the
files used in this tutorial.
@@ -480,14 +480,14 @@
on the site's compute nodes.
-Running applications on Cray compute nodes with Swift
+Running applications on OSDC compute nodes with Swift
-Part 4: Running a parallel ensemble on Cray compute nodes
+Part 4: Running a parallel ensemble on OSDC compute nodes
`p4.swift` will run our mock "simulation"
-applications on Cray compute nodes. The script is similar to as
+applications on OSDC compute nodes. The script is similar to as
`p3.swift`, but specifies that each simulation app invocation should
additionally return the log file which the application writes to
`stderr`.
@@ -511,9 +511,11 @@
`sim_N.log`. The log files provide data on the runtime environment of
each app invocation. For example:
+FIXME: The output below needs to get recaptured for OSDC nodes
$ cat output/sim_0.log
-Called as: /home/users/p01532/swift-cray-tutorial/app/simulate.sh: --timesteps 1 --range 100 --nvalues 5
+Called as: /home/users/p01532/swift-osdc-tutorial/app/simulate.sh: --timesteps 1 --range 100 --nvalues 5
Start time: Tue Aug 27 12:17:43 CDT 2013
Running on node: nid00018
@@ -542,7 +544,7 @@
To tell Swift to run the apps on compute nodes, we specify in the
-`apps` file that the apps should be executed on the `raven` site
+`apps` file that the apps should be executed on the `osdc` site
(instead of the `localhost` site). We can specify the location of
each app in the third field of the `apps` file, with either an
absolute pathname or the name of an executable to be located in
@@ -610,13 +612,16 @@
Swift's `sites.xml` configuration file allows many parameters to
-specify how jobs should be run on a given cluster. Consider for
-example that Raven has several queues, each with limitiations on the
-size of jobs that can be run in them. All Raven queues will only run
-2 jobs per user at one. The Raven queue "small" will only allow up to
-4 nodes per job and 1 hours of walltime per job. The following
-site.xml parameters will allow us to match this:
+specify how jobs should be run on a given cluster.
+FIXME: Translate this concept from Cray to OSDC:
+Consider for example that Raven has several queues, each with
+limitiations on the size of jobs that can be run in them. All Raven
+queues will only run 2 jobs per user at one. The Raven queue "small"
+will only allow up to 4 nodes per job and 1 hours of walltime per job.
+The following site.xml parameters will allow us to match this:
<profile namespace="globus" key="queue">small</profile>
<profile namespace="globus" key="slots">2</profile>
@@ -746,6 +751,8 @@
$ swift p6.swift -steps=5 -nsim=1000
+FIXME: Adjust from Cray to OSDC concepts: (perhaps show how to add more nodes dynamically)
The other change required is to the sites.xml to control how many nodes you request.
Change the "maxnodes" values to control the number of nodes to request.
@@ -835,6 +842,8 @@
+FIXME: Adjust to OSDC from Cray (show two pools of VMs):
Now lets make further use of Swift's ability to route specific apps to
specific pools of resources. The Cray Raven system has two node types,
XE6 32-core 2 x IL-16, and XK7 16-core 1 x IL-16 plus one GPU. Each
More information about the Swift-commit
