[Swift-commit] r7174 - in SwiftTutorials/OSDC-2013-10-17: . .scs part03 part04 part05 part06
davidk at ci.uchicago.edu
Thu Oct 17 17:15:28 CDT 2013
Author: davidk
Date: 2013-10-17 17:15:27 -0500 (Thu, 17 Oct 2013)
New Revision: 7174
Added:
SwiftTutorials/OSDC-2013-10-17/.scs/
SwiftTutorials/OSDC-2013-10-17/.scs/coaster-service.conf
SwiftTutorials/OSDC-2013-10-17/.scs/get_ip_list.sh
Removed:
SwiftTutorials/OSDC-2013-10-17/part05/OLD.p5.swift
SwiftTutorials/OSDC-2013-10-17/part05/OLDbias.dat
SwiftTutorials/OSDC-2013-10-17/part05/multipools
Modified:
SwiftTutorials/OSDC-2013-10-17/part03/p3.kml
SwiftTutorials/OSDC-2013-10-17/part03/sites.xml
SwiftTutorials/OSDC-2013-10-17/part04/apps
SwiftTutorials/OSDC-2013-10-17/part05/apps
SwiftTutorials/OSDC-2013-10-17/part06/apps
SwiftTutorials/OSDC-2013-10-17/setup.sh
Log:
Update scripts to use start-coaster-service
Added: SwiftTutorials/OSDC-2013-10-17/.scs/coaster-service.conf
--- SwiftTutorials/OSDC-2013-10-17/.scs/coaster-service.conf (rev 0)
+++ SwiftTutorials/OSDC-2013-10-17/.scs/coaster-service.conf 2013-10-17 22:15:27 UTC (rev 7174)
@@ -0,0 +1,10 @@
+export WORKER_LOCATION=/home/ubuntu
+export WORKER_MODE=ssh
+export WORKER_USERNAME=ubuntu
+export WORKER_HOSTS="172.16.1.136"
+export IPADDR="128.135.107.145"
+export WORKER_LOG_DIR=/home/ubuntu
+export WORK=/home/ubuntu/work
+export JOBSPERNODE=1
+export JOBTHROTTLE=10
+export SSH_TUNNELING=yes
Added: SwiftTutorials/OSDC-2013-10-17/.scs/get_ip_list.sh
--- SwiftTutorials/OSDC-2013-10-17/.scs/get_ip_list.sh (rev 0)
+++ SwiftTutorials/OSDC-2013-10-17/.scs/get_ip_list.sh 2013-10-17 22:15:27 UTC (rev 7174)
@@ -0,0 +1,4 @@
+#!/bin/bash
+nova list |grep ACTIVE|awk '{print ( $(NF-1) )}'|cut -d'=' -f2
Property changes on: SwiftTutorials/OSDC-2013-10-17/.scs/get_ip_list.sh
___________________________________________________________________
Added: svn:executable
Modified: SwiftTutorials/OSDC-2013-10-17/part03/p3.kml
--- SwiftTutorials/OSDC-2013-10-17/part03/p3.kml 2013-10-17 18:29:32 UTC (rev 7173)
+++ SwiftTutorials/OSDC-2013-10-17/part03/p3.kml 2013-10-17 22:15:27 UTC (rev 7174)
@@ -127,7 +127,7 @@
<set name="sims">
<vdl:new type="file[]" dbgname="sims" waitCount="1" _defline="18">
<vdl:mapping descriptor="concurrent_mapper">
- <vdl:parameter name="prefix">sims-59494c94-f159-4e5b-8084-2a4706a394e3</vdl:parameter>
+ <vdl:parameter name="prefix">sims-c0f5445c-ca5b-436d-b75d-d39bf185a6c2</vdl:parameter>
</vdl:mapping>
</vdl:new>
</set>
Modified: SwiftTutorials/OSDC-2013-10-17/part03/sites.xml
--- SwiftTutorials/OSDC-2013-10-17/part03/sites.xml 2013-10-17 18:29:32 UTC (rev 7173)
+++ SwiftTutorials/OSDC-2013-10-17/part03/sites.xml 2013-10-17 22:15:27 UTC (rev 7174)
@@ -1,11 +1,13 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
- <pool handle="localhost">
- <execution provider="local" />
- <profile namespace="karajan" key="jobThrottle">0.20</profile>
- <profile namespace="karajan" key="initialScore">10000</profile>
- <filesystem provider="local"/>
- <workdirectory>.swift/tmp</workdirectory>
- <profile namespace="swift" key="stagingMethod">local</profile>
- </pool>
+<config>
+ <pool handle="persistent-coasters">
+ <execution provider="coaster-persistent"
+ url="http://10.102.14.1:33516"
+ jobmanager="local:local"/>
+ <profile namespace="globus" key="workerManager">passive</profile>
+ <profile namespace="globus" key="jobsPerNode">1</profile>
+ <profile key="jobThrottle" namespace="karajan">10</profile>
+ <profile namespace="karajan" key="initialScore">10000</profile>
+ <filesystem provider="local" url="none" />
+ <workdirectory>/home/ubuntu/work</workdirectory>
+ </pool>
</config>
Modified: SwiftTutorials/OSDC-2013-10-17/part04/apps
--- SwiftTutorials/OSDC-2013-10-17/part04/apps 2013-10-17 18:29:32 UTC (rev 7173)
+++ SwiftTutorials/OSDC-2013-10-17/part04/apps 2013-10-17 22:15:27 UTC (rev 7174)
@@ -1,2 +1,2 @@
-raven simulate simulate.sh
-raven stats stats.sh
+persistent-coasters simulate /home/ubuntu/bin/simulate.sh
+persistent-coasters stats /home/ubuntu/bin/stats.sh
Deleted: SwiftTutorials/OSDC-2013-10-17/part05/OLD.p5.swift
--- SwiftTutorials/OSDC-2013-10-17/part05/OLD.p5.swift 2013-10-17 18:29:32 UTC (rev 7173)
+++ SwiftTutorials/OSDC-2013-10-17/part05/OLD.p5.swift 2013-10-17 22:15:27 UTC (rev 7174)
@@ -1,37 +0,0 @@
-type file;
-app (file out, file log) simulation (int timesteps, int sim_range, file bias_file, int scale, int sim_count)
- simulate "-t" timesteps "-r" sim_range "-B" @bias_file "-x" scale "-n" sim_count stdout=@out stderr=@log;
-app (file out) analyze (file s[])
- analyze @filenames(s) stdout=@filename(out);
-# Command line params to this script
-int nsim = @toInt(@arg("nsim", "10")); # number of simulation programs to run
-int steps = @toInt(@arg("steps", "1")); # number of "steps" each simulation (==seconds of runtime)
-int range = @toInt(@arg("range", "100")); # range of the generated random numbers
-int count = @toInt(@arg("count", "10")); # number of random numbers generated per simulation
-# Perform nsim "simulations"
-tracef("\n*** Script parameters: nsim=%i steps=%i range=%i count=%i\n\n", nsim, steps, range, count);
-file sims[]; # Array of files to hold each simulation output
-file bias<"bias.dat">; # Input data file to "bias" the numbers:
- # 1 line: scale offset ( N = n*scale + offset)
-foreach i in [0:nsim-1] {
- file simout <single_file_mapper; file=@strcat("output/sim_",i,".out")>;
- file simlog <single_file_mapper; file=@strcat("output/sim_",i,".log")>;
- (simout, simlog) = simulation(steps, range, bias, 100000, count);
- sims[i] = simout;
-# Generate "analysis" file containing average of all "simulations"
-file stats<"output/stats.out">;
-stats = analyze(sims);
Deleted: SwiftTutorials/OSDC-2013-10-17/part05/OLDbias.dat
--- SwiftTutorials/OSDC-2013-10-17/part05/OLDbias.dat 2013-10-17 18:29:32 UTC (rev 7173)
+++ SwiftTutorials/OSDC-2013-10-17/part05/OLDbias.dat 2013-10-17 22:15:27 UTC (rev 7174)
@@ -1,1000 +0,0 @@
- 301
- 439
- 591
- 484
- 300
- 459
- 395
- 351
- 375
- 131
- 144
- 12
- 465
- 682
- 245
- 140
- 862
- 772
- 52
- 728
- 696
- 801
- 487
- 501
- 273
- 869
- 976
- 731
- 634
- 594
- 944
- 973
- 521
- 260
- 997
- 165
- 240
- 844
- 30
- 145
- 29
- 185
- 19
- 332
- 932
- 740
- 750
- 774
- 882
- 258
- 64
- 988
- 980
- 627
- 114
- 722
- 522
- 333
- 201
- 737
- 773
- 226
- 99
- 705
- 435
- 560
- 311
- 96
- 538
- 176
- 831
- 993
- 761
- 917
- 311
- 983
- 259
- 494
- 713
- 503
- 580
- 23
- 687
- 394
- 935
- 386
- 420
- 598
- 424
- 954
- 92
- 528
- 43
- 384
- 531
- 494
- 335
- 913
- 140
- 271
- 817
- 101
- 996
- 742
- 36
- 592
- 321
- 499
- 579
- 454
- 333
- 276
- 360
- 159
- 909
- 791
- 913
- 665
- 862
- 663
- 455
- 39
- 415
- 798
- 222
- 758
- 178
- 656
- 144
- 450
- 182
- 507
- 269
- 839
- 911
- 400
- 506
- 602
- 69
- 729
- 697
- 242
- 39
- 557
- 756
- 677
- 403
- 930
- 660
- 730
- 974
- 23
- 227
- 67
- 465
- 950
- 819
- 100
- 858
- 123
- 979
- 610
- 428
- 623
- 12
- 369
- 96
- 86
- 531
- 777
- 809
- 9
- 589
- 267
- 957
- 722
- 352
- 655
- 145
- 848
- 232
- 752
- 958
- 902
- 206
- 165
- 52
- 452
- 185
- 109
- 676
- 736
- 803
- 893
- 163
- 403
- 573
- 121
- 992
- 818
- 571
- 304
- 822
- 390
- 192
- 174
- 571
- 648
- 924
- 817
- 334
- 791
- 561
- 679
- 457
- 549
- 339
- 264
- 316
- 338
- 726
- 471
- 144
- 748
- 778
- 851
- 432
- 260
- 731
- 436
- 376
- 631
- 373
- 680
- 223
- 169
- 916
- 252
- 236
- 2
- 565
- 749
- 206
- 788
- 801
- 460
- 730
- 795
- 17
- 992
- 847
- 229
- 187
- 690
- 111
- 731
- 754
- 677
- 845
- 707
- 815
- 258
- 526
- 475
- 559
- 970
- 440
- 682
- 471
- 378
- 560
- 821
- 851
- 819
- 106
- 624
- 766
- 628
- 362
- 149
- 523
- 215
- 207
- 446
- 783
- 845
- 556
- 273
- 921
- 519
- 81
- 598
- 440
- 899
- 218
- 623
- 861
- 475
- 789
- 643
- 165
- 526
- 705
- 803
- 907
- 725
- 814
- 306
- 39
- 795
- 144
- 986
- 79
- 726
- 664
- 99
- 71
- 516
- 948
- 601
- 67
- 111
- 856
- 915
- 747
- 621
- 360
- 93
- 787
- 880
- 694
- 5
- 982
- 336
- 426
- 346
- 639
- 10
- 427
- 757
- 981
- 102
- 325
- 305
- 691
- 619
- 398
- 686
- 922
- 674
- 349
- 580
- 165
- 321
- 492
- 432
- 329
- 477
- 894
- 444
- 57
- 577
- 323
- 278
- 179
- 421
- 614
- 616
- 436
- 892
- 432
- 558
- 140
- 517
- 975
- 198
- 805
- 422
- 745
- 250
- 482
- 958
- 538
- 177
- 791
- 489
- 932
- 620
- 138
- 978
- 689
- 192
- 742
- 626
- 946
- 106
- 31
- 178
- 205
- 285
- 576
- 105
- 179
- 307
- 830
- 576
- 679
- 231
- 454
- 833
- 116
- 160
- 616
- 250
- 760
- 205
- 74
- 989
- 576
- 843
- 931
- 267
- 849
- 108
- 850
- 937
- 746
- 607
- 35
- 539
- 550
- 553
- 886
- 459
- 786
- 720
- 650
- 735
- 126
- 100
- 297
- 303
- 921
- 105
- 46
- 954
- 663
- 568
- 478
- 886
- 817
- 690
- 261
- 642
- 511
- 967
- 727
- 492
- 4
- 810
- 320
- 338
- 498
- 842
- 454
- 366
- 316
- 802
- 641
- 293
- 544
- 957
- 768
- 553
- 692
- 749
- 944
- 19
- 762
- 991
- 234
- 247
- 556
- 625
- 189
- 725
- 818
- 764
- 636
- 370
- 138
- 161
- 853
- 309
- 613
- 250
- 75
- 728
- 230
- 248
- 562
- 110
- 879
- 993
- 626
- 308
- 124
- 593
- 169
- 125
- 304
- 143
- 312
- 525
- 639
- 492
- 377
- 153
- 97
- 90
- 1
- 483
- 139
- 277
- 7
- 707
- 977
- 513
- 458
- 95
- 208
- 149
- 293
- 690
- 456
- 558
- 245
- 327
- 500
- 222
- 776
- 863
- 322
- 363
- 892
- 414
- 442
- 283
- 627
- 656
- 785
- 468
- 371
- 657
- 840
- 449
- 500
- 522
- 337
- 784
- 475
- 667
- 345
- 151
- 541
- 843
- 285
- 270
- 684
- 381
- 608
- 731
- 492
- 233
- 540
- 185
- 975
- 422
- 199
- 595
- 242
- 995
- 892
- 509
- 916
- 493
- 549
- 588
- 203
- 653
- 276
- 808
- 245
- 277
- 827
- 724
- 118
- 566
- 406
- 927
- 498
- 727
- 309
- 165
- 412
- 28
- 937
- 797
- 556
- 322
- 59
- 741
- 675
- 89
- 877
- 283
- 518
- 509
- 6
- 486
- 421
- 644
- 258
- 920
- 623
- 725
- 859
- 88
- 773
- 499
- 973
- 661
- 947
- 347
- 679
- 935
- 717
- 65
- 265
- 388
- 740
- 252
- 249
- 969
- 26
- 149
- 338
- 913
- 605
- 639
- 649
- 914
- 890
- 522
- 621
- 779
- 470
- 321
- 171
- 304
- 425
- 626
- 378
- 491
- 925
- 900
- 705
- 830
- 631
- 844
- 274
- 539
- 511
- 664
- 777
- 251
- 190
- 967
- 569
- 140
- 327
- 863
- 525
- 368
- 540
- 475
- 716
- 189
- 442
- 729
- 112
- 726
- 505
- 678
- 323
- 128
- 983
- 660
- 853
- 326
- 312
- 378
- 544
- 278
- 127
- 322
- 360
- 645
- 233
- 665
- 3
- 788
- 698
- 342
- 93
- 214
- 976
- 756
- 677
- 375
- 947
- 363
- 999
- 499
- 139
- 245
- 745
- 830
- 798
- 135
- 83
- 902
- 779
- 617
- 636
- 753
- 867
- 724
- 743
- 924
- 480
- 836
- 409
- 100
- 73
- 298
- 711
- 35
- 289
- 381
- 361
- 901
- 640
- 919
- 708
- 562
- 592
- 26
- 471
- 395
- 728
- 433
- 69
- 856
- 550
- 225
- 714
- 999
- 936
- 266
- 81
- 343
- 123
- 37
- 740
- 593
- 905
- 715
- 481
- 265
- 357
- 338
- 150
- 875
- 938
- 603
- 98
- 245
- 721
- 373
- 901
- 795
- 325
- 955
- 448
- 816
- 753
- 850
- 462
- 628
- 220
- 694
- 423
- 241
- 718
- 730
- 682
- 944
- 408
- 151
- 10
- 826
- 26
- 269
- 439
- 973
- 842
- 884
- 103
- 792
- 435
- 675
- 442
- 955
- 992
- 256
- 206
- 666
- 637
- 725
- 52
- 21
- 108
- 622
- 943
- 583
- 919
- 796
- 80
- 52
- 678
- 845
- 155
- 331
- 909
- 888
- 945
- 979
- 967
- 104
- 446
- 807
- 572
- 354
- 639
- 68
- 813
- 11
- 129
- 647
- 743
- 897
- 600
- 992
- 20
- 896
- 398
- 16
- 434
- 662
- 86
- 200
- 211
- 287
- 485
- 670
- 446
- 495
- 407
- 916
- 395
- 920
- 959
- 817
- 524
- 146
- 378
- 849
- 457
- 536
- 582
- 608
- 686
- 127
- 346
- 934
- 950
- 420
- 294
- 439
- 688
- 953
- 66
- 603
- 875
- 372
- 355
- 105
- 405
- 371
- 246
- 829
- 146
- 403
- 811
- 484
- 266
- 181
- 496
- 25
- 189
- 806
- 1
- 171
- 737
- 381
- 720
- 321
- 862
- 7
- 177
- 838
- 502
- 708
- 819
- 205
- 256
- 166
- 712
- 492
- 716
- 130
- 562
- 308
- 365
- 694
- 372
- 917
- 165
- 366
- 412
- 480
- 681
- 824
- 306
- 970
- 160
- 555
- 336
- 61
- 816
- 611
- 432
- 536
- 830
- 171
- 793
- 33
- 364
- 998
- 814
- 952
- 89
- 24
- 653
- 651
- 8
- 789
- 807
- 869
- 332
- 897
- 499
- 701
- 354
- 688
- 339
- 93
- 822
- 801
- 758
- 915
- 546
- 520
- 469
- 512
- 911
- 482
- 387
- 187
Modified: SwiftTutorials/OSDC-2013-10-17/part05/apps
--- SwiftTutorials/OSDC-2013-10-17/part05/apps 2013-10-17 18:29:32 UTC (rev 7173)
+++ SwiftTutorials/OSDC-2013-10-17/part05/apps 2013-10-17 22:15:27 UTC (rev 7174)
@@ -1,2 +1,2 @@
Deleted: SwiftTutorials/OSDC-2013-10-17/part05/multipools
--- SwiftTutorials/OSDC-2013-10-17/part05/multipools 2013-10-17 18:29:32 UTC (rev 7173)
+++ SwiftTutorials/OSDC-2013-10-17/part05/multipools 2013-10-17 22:15:27 UTC (rev 7174)
@@ -1,3 +0,0 @@
-ravenGPU simulate simulate.sh
-localhost stats stats.sh
Modified: SwiftTutorials/OSDC-2013-10-17/part06/apps
--- SwiftTutorials/OSDC-2013-10-17/part06/apps 2013-10-17 18:29:32 UTC (rev 7173)
+++ SwiftTutorials/OSDC-2013-10-17/part06/apps 2013-10-17 22:15:27 UTC (rev 7174)
@@ -1,4 +1,4 @@
-raven genseed simulate.sh
-raven genbias simulate.sh
+persistent-coasters genseed /home/ubuntu/bin/simulate.sh
+persistent-coasters genbias /home/ubuntu/bin/simulate.sh
Modified: SwiftTutorials/OSDC-2013-10-17/setup.sh
--- SwiftTutorials/OSDC-2013-10-17/setup.sh 2013-10-17 18:29:32 UTC (rev 7173)
+++ SwiftTutorials/OSDC-2013-10-17/setup.sh 2013-10-17 22:15:27 UTC (rev 7174)
@@ -61,30 +61,18 @@
lazy.errors=false
use.provider.staging=true
-provider.staging.pin.swiftfiles=true
+provider.staging.pin.swiftfiles=false
use.wrapper.staging=false
END
-cat >gen.sites <<END
-<config xmlns="http://swift-lang.org/sites">
- <profile namespace="karajan" key="jobThrottle">0.04</profile>
- <workdirectory>/lus/scratch/$USER/swiftwork</workdirectory>
- </pool>
-</config>
-END
-for p in 01 02 03; do
- cp gen.sites part${p}/sites.xml
+# Start coaster-service and generate sites.xml
+cd .scs
+start-coaster-service
+for p in 04 05 06; do
+ cp sites.xml ../part${p}/sites.xml
done
-rm gen.sites
+cd ..
return
More information about the Swift-commit
