[Swift-commit] r7165 - SwiftTutorials/CIC_2013-08-09/app
yadunandb at ci.uchicago.edu
Tue Oct 15 15:27:17 CDT 2013
Author: yadunandb
Date: 2013-10-15 15:27:17 -0500 (Tue, 15 Oct 2013)
New Revision: 7165
Added:
SwiftTutorials/CIC_2013-08-09/app/simulate.py
SwiftTutorials/CIC_2013-08-09/app/stats.py
Log:
Python apps for demo
Added: SwiftTutorials/CIC_2013-08-09/app/simulate.py
--- SwiftTutorials/CIC_2013-08-09/app/simulate.py (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/app/simulate.py 2013-10-15 20:27:17 UTC (rev 7165)
@@ -0,0 +1,124 @@
+#!/usr/bin/env python
+import sys
+import os
+import socket
+import time
+import math
+import random
+def parse():
+ from optparse import OptionParser
+ parser=OptionParser()
+ parser.add_option("-b", "--bias", type="int", dest="bias", default=0,
+ help="offset bias: add this integer to all results");
+ parser.add_option("-B", "--biasfile", type="string", dest="biasfile",
+ default="none", help="file of integer biases to add to results" );
+ parser.add_option("-l", "--log", type="string", dest="log", default="yes",
+ help="generate a log in stderr if not nul");
+ parser.add_option("-n", "--nvalues", type="int", dest="nvalues",default=1,
+ help="print this many values per simulation" );
+ parser.add_option("-s", "--seed", type="int", dest="initseed", default=0,
+ help="use this integer [0..32767] as a seed");
+ parser.add_option("-S", "--seedfile", type="string", dest="seedfile",
+ default="none", help="use this file (containing integer seeds [0..32767]) one per line" );
+ parser.add_option("-t", "--timesteps", type="int", dest="timesteps",
+ default=0, help='number of simulated "timesteps" in seconds (determines runtime)' );
+ parser.add_option("-r", "--range", type="int", dest="range", default=100,
+ help="range (limit) of generated results" );
+ parser.add_option("-w", "--width", type="int", dest="width", default=8,
+ help="Width ?" );
+ parser.add_option("-x", "--scale", type="int", dest="scale", default=1,
+ help="scale the results by this integer" );
+ # Not implemented yet
+ parser.add_option("-p", "--paramfile", type="string", dest="paramfile", default="none",
+ help="Not implemented yet" );
+ return (parser.parse_args());
+def log():
+ import datetime
+ print >> sys.stderr, "Called as: ", str(sys.argv)
+ print >> sys.stderr, "Start time: ", datetime.datetime.now()
+ print >> sys.stderr, "Running on node: ", socket.gethostname()
+ print >> sys.stderr, "Running as user: ",os.getlogin()
+ print >> sys.stderr, "\nEnvironment:\n\n"
+ print >> sys.stderr, os.environ
+def printparams(options):
+ print 'bias =',options.bias
+ print 'biasfile = ',options.biasfile
+ print 'log = ', options.log
+ print 'nvalues = ',options.nvalues
+ print 'seed = ', options.initseed
+ print 'seedfile = ', options.seedfile
+ print 'timesteps = ', options.timesteps
+ print 'range = ', options.range
+ print 'width = ', options.width
+ print 'scale = ', options.scale
+ print 'paramfile = ', options.paramfile
+def simulate(options):
+ time.sleep(options.timesteps)
+ bias=[];
+ if (options.biasfile != "none"):
+ try:
+ with open(options.biasfile) as biasfile:
+ lines = biasfile.read().splitlines()
+ for line in lines:
+ bias.append(int(line))
+ except IOError:
+ print "Error accessing content from file: ", options.biasfile
+ bias_count = len(bias)
+ for i in range(options.nvalues):
+ value = (random.random() +
+ random.random()*math.pow(2,16) +
+ random.random()*math.pow(2,32) +
+ random.random()*math.pow(2,48))
+ value=( (int(value)%options.range) * options.scale + options.bias)
+ if ( i < bias_count ):
+ value = value + bias[i]
+ elif ( bias_count > 0 ):
+ value = value + bias[bias_count-1]
+ print '{num:{fill}{width}}'.format(num=value, fill=' ', width=options.width)
+def seed(options):
+ if (options.initseed != 0 ):
+ random.seed(options.initseed)
+ if (options.seedfile != "none"):
+ try:
+ with open(options.seedfile) as seedfile:
+ lines=seedfile.read().splitlines()
+ seed = 0
+ seed = seed + int(line)
+ random.seed(seed)
+ except IOError:
+ print "Could not open file: ", options.seedfile
+if __name__ == "__main__":
+ (options, args) = parse()
+ printparams(options)
+ seed(options)
+ simulate(options)
+ log()
Property changes on: SwiftTutorials/CIC_2013-08-09/app/simulate.py
___________________________________________________________________
Added: svn:executable
Added: SwiftTutorials/CIC_2013-08-09/app/stats.py
--- SwiftTutorials/CIC_2013-08-09/app/stats.py (rev 0)
+++ SwiftTutorials/CIC_2013-08-09/app/stats.py 2013-10-15 20:27:17 UTC (rev 7165)
@@ -0,0 +1,31 @@
+import socket
+import sys
+import os
+def log():
+ import datetime
+def stat():
+ total = 0
+ count = 0
+ for f in sys.argv[1:]:
+ try:
+ with open(f) as ifile:
+ lines = ifile.read().splitlines()
+ total += int(line)
+ count += 1
+ except IOError:
+ print total/count
+ log()
+ stat()
Property changes on: SwiftTutorials/CIC_2013-08-09/app/stats.py
More information about the Swift-commit
