[Swift-commit] r7161 - in SwiftApps/Swift-MapRed: . EPlus
ketan at ci.uchicago.edu
Mon Oct 14 16:44:19 CDT 2013
Author: ketan
Date: 2013-10-14 16:44:19 -0500 (Mon, 14 Oct 2013)
New Revision: 7161
Added:
SwiftApps/Swift-MapRed/EPlus/
SwiftApps/Swift-MapRed/EPlus/CHICAGO-EXAMPLE.imf
SwiftApps/Swift-MapRed/EPlus/CHICAGO.epw
SwiftApps/Swift-MapRed/EPlus/RunEP.sh
SwiftApps/Swift-MapRed/EPlus/sweep1.swift
Log:
adding eplus app
Added: SwiftApps/Swift-MapRed/EPlus/CHICAGO-EXAMPLE.imf
--- SwiftApps/Swift-MapRed/EPlus/CHICAGO-EXAMPLE.imf (rev 0)
+++ SwiftApps/Swift-MapRed/EPlus/CHICAGO-EXAMPLE.imf 2013-10-14 21:44:19 UTC (rev 7161)
@@ -0,0 +1,9361 @@
+##set1 ORIENTATION[] 0
+##set1 HEIGHT[] 10
+! DOE Commercial Reference Building
+! Large office, new construction 90.1-2004
+! Version 1.3_5.0
+! EnergyPlus Version 5.0
+! ASHRAE Standards 90.1-2004 and 62-1999
+! Description: 12 story plus basement, office building.
+! Form: Area = 46,320 m2 (498,588 ft2); Number of Stories = 12; Shape = rectangle, Aspect ratio = 1.5
+! Envelope: Envelope thermal properties vary with climate according to ASHRAE Standard 90.1-2004.
+! Opaque constructions: mass walls; built-up flat roof (insulation above deck); slab-on-grade floor
+! Windows: window-to-wall ratio = 38.0%, equal distribution of windows
+! Infiltration in perimeter zones only
+! = 0.4 cfm/ft2 above grade wall area at 0.3 in wc (75 Pa) adjusted to 0.016 in wc (4 Pa).
+! 25% of full value when ventilation system on.
+! HVAC: 2 water-cooled chillers, VAV with reheat and plenum zones
+! Economizer per 90.1-2004
+! Int. gains: lights = 10.76 W/m2 (1.0 W/ft2) (building area method);
+! elec. plug loads = 10.76 W/m2 (1.0 W/ft2)
+! gas plug load = 0 W/m2 (0 W/ft2)
+! people = 2,397 total, 5.38/100 m2 (5.0/1000 ft2); basement 2.69/100 m2 (2.5/1000 ft2)
+! elevators = 12 @ 25 HP each, 91% motor efficiency, motor heat exhausted directly
+! Detached Shading: None
+! Daylight: None
+! Natural Ventilation: None
+! Zonal Equipment: None
+! Air Primary Loops: VAV WITH REHEAT
+! Plant Loops: SHWSys1, HeatSys1, CoolSys1, TowerWaterSys
+! System Equipment Autosize: Yes
+! Purchased Cooling: None
+! Purchased Heating: None
+! Coils: Coil:Cooling:Water; Coil:Heating:Water
+! Pumps: Yes
+! Boilers: Boiler:HotWater (gas-fired)
+! Chillers: Chiller:Electric:ReformulatedEIR (water-cooled)
+!***** NOTICE *****
+!***** The Reference Buildings were prepared as an account of work sponsored by an *****
+!***** agency of the United States government. Neither the United States *****
+!***** government nor any agency thereof, nor any of their employees, makes *****
+!***** any warranty, express or implied, or assumes any legal liability or *****
+!***** responsibility for the accuracy, completeness, or usefulness of any *****
+!***** information, apparatus, product, or process disclosed, or represents *****
+!***** that its use would not infringe privately owned rights. Reference *****
+!***** herein to any specific commercial product, process, or service by *****
+!***** trade name, trademark, manufacturer, or otherwise does not necessarily *****
+!***** constitute or imply its endorsement, recommendation, or favoring by *****
+!***** the United States government or any agency thereof. The views and *****
+!***** opinions of authors expressed herein do not necessarily state or *****
+!***** reflect those of the United States government or any agency thereof. *****
+!***** Access to and use of the Reference Buildings imposes the following obligations *****
+!***** on the user. The user agrees to credit DOE, NREL, PNNL, and LBNL in *****
+!***** any publication(s) that that result from the use of Reference Buildings. *****
+!***** However, the names of DOE/NREL/PNNL/LBNL may not be used in any *****
+!***** advertising or publicity that implies endorsement or promotion of any *****
+!***** products, services or commercial entities. *****
+! Reference citation for the Commercial Reference Buildings:
+! Deru, M.; Field, K.; Studer, D.; Benne, K.; Griffith, B.; Torcellini, P;
+! Halverson, M.; Winiarski, D.; Liu, B.; Rosenberg, M.; Huang, J.;
+! Yazdanian, M.; Crawley, D. (2010).
+! U.S. Department of Energy Commercial Reference Building Models of the National Building Stock.
+! Washington, DC: U.S. Department of Energy, Energy Efficiency and
+! Renewable Energy, Office of Building Technologies.
+! ***GENERAL SIMULATION PARAMETERS***
+! Number of Zones: 19
+ Version,8.0;
+ SimulationControl,
+ YES, !- Do Zone Sizing Calculation
+ YES, !- Do System Sizing Calculation
+ YES, !- Do Plant Sizing Calculation
+ NO, !- Run Simulation for Sizing Periods
+ YES; !- Run Simulation for Weather File Run Periods
+ Building,
+ Ref Bldg Large Office New2004_v1.3_5.0, !- Name
+ ORIENTATION[], !- North Axis {deg}
+ City, !- Terrain
+ 0.0400, !- Loads Convergence Tolerance Value
+ 0.2000, !- Temperature Convergence Tolerance Value {deltaC}
+ FullInteriorAndExterior, !- Solar Distribution
+ 25, !- Maximum Number of Warmup Days
+ 6; !- Minimum Number of Warmup Days
+ RunPeriod,
+ , !- Name
+ 1, !- Begin Month
+ 1, !- Begin Day of Month
+ 1, !- End Month
+ 2, !- End Day of Month
+ Sunday, !- Day of Week for Start Day
+ No, !- Use Weather File Holidays and Special Days
+ No, !- Use Weather File Daylight Saving Period
+ No, !- Apply Weekend Holiday Rule
+ Yes, !- Use Weather File Rain Indicators
+ Yes, !- Use Weather File Snow Indicators
+ 1.0000; !- Number of Times Runperiod to be Repeated
+! ***HOLIDAYS & DAYLIGHT SAVINGS***
+ RunPeriodControl:DaylightSavingTime,
+ 2nd Sunday in March, !- Start Date
+ 1st Sunday in November; !- End Date
+ RunPeriodControl:SpecialDays,
+ New Years Day, !- Name
+ January 1, !- Start Date
+ 1, !- Duration {days}
+ Holiday; !- Special Day Type
+ Veterans Day, !- Name
+ November 11, !- Start Date
+ Christmas, !- Name
+ December 25, !- Start Date
+ Independence Day, !- Name
+ July 4, !- Start Date
+ MLK Day, !- Name
+ 3rd Monday in January, !- Start Date
+ Presidents Day, !- Name
+ 3rd Monday in February, !- Start Date
+ Memorial Day, !- Name
+ Last Monday in May, !- Start Date
+ Labor Day, !- Name
+ 1st Monday in September, !- Start Date
+ Columbus Day, !- Name
+ 2nd Monday in October, !- Start Date
+ Thanksgiving, !- Name
+ 4th Thursday in November,!- Start Date
+! ***SCHEDULE TYPES***
+ ScheduleTypeLimits,
+ Any Number; !- Name
+ Fraction, !- Name
+ 0.0, !- Lower Limit Value
+ 1.0, !- Upper Limit Value
+ CONTINUOUS; !- Numeric Type
+ Temperature, !- Name
+ -60, !- Lower Limit Value
+ 200, !- Upper Limit Value
+ On/Off, !- Name
+ 0, !- Lower Limit Value
+ 1, !- Upper Limit Value
+ DISCRETE; !- Numeric Type
+ Control Type, !- Name
+ 4, !- Upper Limit Value
+ Humidity, !- Name
+ 10, !- Lower Limit Value
+ 90, !- Upper Limit Value
+ Number; !- Name
+! ***ALWAYS ON SCHEDULE***
+ Schedule:Compact,
+ ALWAYS_ON, !- Name
+ On/Off, !- Schedule Type Limits Name
+ Through: 12/31, !- Field 1
+ For: AllDays, !- Field 2
+ Until: 24:00,1; !- Field 3
+! ***MISC SIMULATION PARAMETERS***
+ SurfaceConvectionAlgorithm:Inside,TARP;
+ SurfaceConvectionAlgorithm:Outside,DOE-2;
+ HeatBalanceAlgorithm,ConductionTransferFunction,200.0000;
+ ZoneAirHeatBalanceAlgorithm,
+ AnalyticalSolution; !- Algorithm
+ Sizing:Parameters,
+ 1.33, !- Heating Sizing Factor
+ 1.33, !- Cooling Sizing Factor
+ 6; !- Timesteps in Averaging Window
+ ConvergenceLimits,
+ 2, !- Minimum System Timestep {minutes}
+ 25; !- Maximum HVAC Iterations
+ ShadowCalculation,
+ AverageOverDaysInFrequency, !- Calculation Method
+ 7, !- Calculation Frequency
+ 15000; !- Maximum Figures in Shadow Overlap Calculations
+ Timestep,6;
+! WeatherFileName=USA_IL_Chicago-OHare_TMY2.epw
+ Site:Location,
+ USA IL-CHICAGO-OHARE, !- Name
+ 41.77, !- Latitude {deg}
+ -87.75, !- Longitude {deg}
+ -6.00, !- Time Zone {hr}
+ 190; !- Elevation {m}
+! CHICAGO_IL_USA Annual Heating 99.6%, MaxDB=-20.6�C
+ SizingPeriod:DesignDay,
+ CHICAGO Ann Htg 99.6% Condns DB, !- Name
+ 1, !- Month
+ 21, !- Day of Month
+ WinterDesignDay, !- Day Type
+ -20.6, !- Maximum Dry-Bulb Temperature {C}
+ 0.0, !- Daily Dry-Bulb Temperature Range {deltaC}
+ , !- Dry-Bulb Temperature Range Modifier Type
+ , !- Dry-Bulb Temperature Range Modifier Day Schedule Name
+ Wetbulb, !- Humidity Condition Type
+ -20.6, !- Wetbulb or DewPoint at Maximum Dry-Bulb {C}
+ , !- Humidity Condition Day Schedule Name
+ , !- Humidity Ratio at Maximum Dry-Bulb {kgWater/kgDryAir}
+ , !- Enthalpy at Maximum Dry-Bulb {J/kg}
+ , !- Daily Wet-Bulb Temperature Range {deltaC}
+ 99063., !- Barometric Pressure {Pa}
+ 4.9, !- Wind Speed {m/s}
+ 270, !- Wind Direction {deg}
+ No, !- Rain Indicator
+ No, !- Snow Indicator
+ No, !- Daylight Saving Time Indicator
+ ASHRAEClearSky, !- Solar Model Indicator
+ , !- Beam Solar Day Schedule Name
+ , !- Diffuse Solar Day Schedule Name
+ , !- ASHRAE Clear Sky Optical Depth for Beam Irradiance (taub) {dimensionless}
+ , !- ASHRAE Clear Sky Optical Depth for Diffuse Irradiance (taud) {dimensionless}
+ 0.00; !- Sky Clearness
+! CHICAGO_IL_USA Annual Cooling (WB=>MDB) .4%, MDB=31.2�C WB=25.5�C
+ CHICAGO Ann Clg .4% Condns WB=>MDB, !- Name
+ 7, !- Month
+ SummerDesignDay, !- Day Type
+ 31.2, !- Maximum Dry-Bulb Temperature {C}
+ 10.7, !- Daily Dry-Bulb Temperature Range {deltaC}
+ 25.5, !- Wetbulb or DewPoint at Maximum Dry-Bulb {C}
+ 5.3, !- Wind Speed {m/s}
+ 230, !- Wind Direction {deg}
+ 1.00; !- Sky Clearness
+ Site:WaterMainsTemperature,
+ CORRELATION, !- Calculation Method
+ , !- Temperature Schedule Name
+ 9.69, !- Annual Average Outdoor Air Temperature {C}
+ 28.10; !- Maximum Difference In Monthly Average Outdoor Air Temperatures {deltaC}
+ Site:GroundTemperature:BuildingSurface,19.527,19.502,19.536,19.598,20.002,21.640,22.225,22.375,21.449,20.121,19.802,19.633;
+! ***OPAQUE CONSTRUCTIONS AND MATERIALS***
+! Exterior Walls
+ Construction,
+ Mass Non-res Ext Wall, !- Name
+ 1IN Stucco, !- Outside Layer
+ 8IN Concrete HW, !- Layer 2
+ Mass NonRes Wall Insulation, !- Layer 3
+ 1/2IN Gypsum; !- Layer 4
+ Material,
+ Mass NonRes Wall Insulation, !- Name
+ MediumRough, !- Roughness
+ 0.0495494599433393, !- Thickness {m}
+ 0.049, !- Conductivity {W/m-K}
+ 265.0000, !- Density {kg/m3}
+ 836.8000, !- Specific Heat {J/kg-K}
+ 0.9000, !- Thermal Absorptance
+ 0.7000, !- Solar Absorptance
+ 0.7000; !- Visible Absorptance
+! Roof
+ Construction,
+ IEAD Non-res Roof, !- Name
+ Roof Membrane, !- Outside Layer
+ IEAD NonRes Roof Insulation, !- Layer 2
+ Metal Decking; !- Layer 3
+ Material,
+ IEAD NonRes Roof Insulation, !- Name
+ 0.127338688569477, !- Thickness {m}
+! Slab on grade, unheated
+ Construction,
+ ext-slab, !- Name
+ HW CONCRETE, !- Outside Layer
+ CP02 CARPET PAD; !- Layer 2
+! Interior Walls
+ Construction,
+ int-walls, !- Name
+ 1/2IN Gypsum, !- Outside Layer
+ 1/2IN Gypsum; !- Layer 2
+! Interior Floors
+ Construction,
+ INT-FLOOR-TOPSIDE, !- Name
+ MAT-CC05 4 HW CONCRETE, !- Outside Layer
+ Construction,
+ INT-FLOOR-UNDERSIDE, !- Name
+ CP02 CARPET PAD, !- Outside Layer
+ MAT-CC05 4 HW CONCRETE; !- Layer 2
+ Construction,
+ Underground Wall Non-res,!- Name
+ 8IN Concrete HW, !- Outside Layer
+ UGWall NonRes Insulation;!- Layer 2
+ Material,
+ UGWall NonRes Insulation,!- Name
+ 0.0001, !- Thickness {m}
+! ***WINDOW/DOOR CONSTRUCTIONS AND MATERIALS***
+ Construction,
+ Window Non-res Fixed, !- Name
+ NonRes Fixed Assembly Window; !- Outside Layer
+ WindowMaterial:SimpleGlazingSystem,
+ NonRes Fixed Assembly Window, !- Name
+ 3.23646, !- U-Factor {W/m2-K}
+ 0.39, !- Solar Heat Gain Coefficient
+ ; !- Visible Transmittance
+! ***COMMON CONSTRUCTIONS AND MATERIALS***
+ Construction,
+ DropCeiling, !- Name
+ Std AC02; !- Outside Layer
+ Construction,
+ AIR-WALL, !- Name
+ MAT-AIR-WALL; !- Outside Layer
+ Construction,
+ InteriorFurnishings, !- Name
+ Std Wood 6inch; !- Outside Layer
+ Material,
+ Std Wood 6inch, !- Name
+ MediumSmooth, !- Roughness
+ 0.15, !- Thickness {m}
+ 0.12, !- Conductivity {W/m-K}
+ 540.0000, !- Density {kg/m3}
+ 1210, !- Specific Heat {J/kg-K}
+ 0.9000000, !- Thermal Absorptance
+ 0.7000000, !- Solar Absorptance
+ 0.7000000; !- Visible Absorptance
+ Material,
+ Wood Siding, !- Name
+ 0.0100, !- Thickness {m}
+ 0.1100, !- Conductivity {W/m-K}
+ 544.6200, !- Density {kg/m3}
+ 1210.0000, !- Specific Heat {J/kg-K}
+ 0.7800, !- Solar Absorptance
+ 0.7800; !- Visible Absorptance
+ Material,
+ 1/2IN Gypsum, !- Name
+ Smooth, !- Roughness
+ 0.0127, !- Thickness {m}
+ 0.1600, !- Conductivity {W/m-K}
+ 784.9000, !- Density {kg/m3}
+ 830.0000, !- Specific Heat {J/kg-K}
+ 0.9200, !- Solar Absorptance
+ 0.9200; !- Visible Absorptance
+ Material,
+ 1IN Stucco, !- Name
+ 0.0253, !- Thickness {m}
+ 0.6918, !- Conductivity {W/m-K}
+ 1858.0000, !- Density {kg/m3}
+ 837.0000, !- Specific Heat {J/kg-K}
+ Material,
+ 8IN CONCRETE HW, !- Name
+ Rough, !- Roughness
+ 0.2032, !- Thickness {m}
+ 1.3110, !- Conductivity {W/m-K}
+ 2240.0000, !- Density {kg/m3}
+ Material,
+ Metal Siding, !- Name
+ 0.0015, !- Thickness {m}
+ 44.9600, !- Conductivity {W/m-K}
+ 7688.8600, !- Density {kg/m3}
+ 410.0000, !- Specific Heat {J/kg-K}
+ 0.2000, !- Solar Absorptance
+ 0.2000; !- Visible Absorptance
+ Material,
+ HW CONCRETE, !- Name
+ 0.1016, !- Thickness {m}
+ Material:NoMass,
+ CP02 CARPET PAD, !- Name
+ VeryRough, !- Roughness
+ 0.2165, !- Thermal Resistance {m2-K/W}
+ 0.8000; !- Visible Absorptance
+ Material,
+ Roof Membrane, !- Name
+ 0.0095, !- Thickness {m}
+ 1121.2900, !- Density {kg/m3}
+ 1460.0000, !- Specific Heat {J/kg-K}
+ Material,
+ Metal Decking, !- Name
+ 45.0060, !- Conductivity {W/m-K}
+ 7680.0000, !- Density {kg/m3}
+ 418.4000, !- Specific Heat {J/kg-K}
+ 0.3000; !- Visible Absorptance
+ Material,
+ Metal Roofing, !- Name
+ Material,
+ MAT-CC05 4 HW CONCRETE, !- Name
+! Acoustic tile for drop ceiling
+ Material,
+ Std AC02, !- Name
+ 1.2700000E-02, !- Thickness {m}
+ 5.7000000E-02, !- Conductivity {W/m-K}
+ 288.0000, !- Density {kg/m3}
+ 1339.000, !- Specific Heat {J/kg-K}
+ 0.2000000; !- Visible Absorptance
+ Material:NoMass,
+ MAT-AIR-WALL, !- Name
+ 0.2079491, !- Thermal Resistance {m2-K/W}
+ 0.9, !- Thermal Absorptance
+ 0.7; !- Solar Absorptance
+! ZONE LIST:
+! Basement
+! Core_bottom
+! Core_mid (mult=10)
+! Core_top
+! GroundFloor_Plenum
+! MidFloor_Plenum (mult=10)
+! Perimeter_bot_ZN_1
+! Perimeter_bot_ZN_2
+! Perimeter_bot_ZN_3
+! Perimeter_bot_ZN_4
+! Perimeter_mid_ZN_1 (mult=10)
+! Perimeter_mid_ZN_2 (mult=10)
+! Perimeter_mid_ZN_3 (mult=10)
+! Perimeter_mid_ZN_4 (mult=10)
+! Perimeter_top_ZN_1
+! Perimeter_top_ZN_2
+! Perimeter_top_ZN_3
+! Perimeter_top_ZN_4
+! TopFloor_Plenum
+! ***ZONES***
+ Zone,
+ Basement, !- Name
+ 0.0000, !- Direction of Relative North {deg}
+ 0.0000, !- X Origin {m}
+ 0.0400, !- Y Origin {m}
+ 0.2000, !- Z Origin {m}
+ 1, !- Type
+ 1, !- Multiplier
+ , !- Ceiling Height {m}
+ , !- Volume {m3}
+ autocalculate, !- Floor Area {m2}
+ , !- Zone Inside Convection Algorithm
+ , !- Zone Outside Convection Algorithm
+ Yes; !- Part of Total Floor Area
+ Zone,
+ Core_bottom, !- Name
+ 0.0000, !- Y Origin {m}
+ 0.0000, !- Z Origin {m}
+ 1, !- Type
+ 1, !- Multiplier
+ , !- Volume {m3}
+ Zone,
+ Core_mid, !- Name
+ 1, !- Type
+ HEIGHT[], !- Multiplier
+ , !- Volume {m3}
+ Zone,
+ Core_top, !- Name
+ 1, !- Type
+ 1, !- Multiplier
+ , !- Volume {m3}
+ Zone,
+ GroundFloor_Plenum, !- Name
+ 1, !- Type
+ 1, !- Multiplier
+ , !- Volume {m3}
+ No; !- Part of Total Floor Area
+ Zone,
+ MidFloor_Plenum, !- Name
+ 1, !- Type
+ , !- Volume {m3}
+ Zone,
+ Perimeter_bot_ZN_1, !- Name
+ 1, !- Type
+ 1, !- Multiplier
+ , !- Volume {m3}
+ Zone,
+ Perimeter_bot_ZN_2, !- Name
+ 1, !- Type
+ 1, !- Multiplier
+ , !- Volume {m3}
+ Zone,
+ Perimeter_bot_ZN_3, !- Name
+ 1, !- Type
+ 1, !- Multiplier
+ , !- Volume {m3}
+ Zone,
+ Perimeter_bot_ZN_4, !- Name
+ 1, !- Type
+ 1, !- Multiplier
+ , !- Volume {m3}
+ Zone,
+ Perimeter_mid_ZN_1, !- Name
+ 1, !- Type
+ HEIGHT[], !- Multiplier HEIGHT[]
+ , !- Volume {m3}
+ Zone,
+ Perimeter_mid_ZN_2, !- Name
+ 1, !- Type
+ , !- Volume {m3}
+ Zone,
+ Perimeter_mid_ZN_3, !- Name
+ 1, !- Type
+ , !- Volume {m3}
+ Zone,
+ Perimeter_mid_ZN_4, !- Name
+ 1, !- Type
+ , !- Volume {m3}
+ Zone,
+ Perimeter_top_ZN_1, !- Name
+ 1, !- Type
+ 1, !- Multiplier
+ , !- Volume {m3}
+ Zone,
+ Perimeter_top_ZN_2, !- Name
+ 1, !- Type
+ 1, !- Multiplier
+ , !- Volume {m3}
+ Zone,
+ Perimeter_top_ZN_3, !- Name
+ 1, !- Type
+ 1, !- Multiplier
+ , !- Volume {m3}
+ Zone,
+ Perimeter_top_ZN_4, !- Name
+ 1, !- Type
+ 1, !- Multiplier
+ , !- Volume {m3}
+ Zone,
+ TopFloor_Plenum, !- Name
+ 1, !- Type
+ 1, !- Multiplier
+ , !- Volume {m3}
+! ***WALLS***
+ BuildingSurface:Detailed,
+ Basement_Ceiling_1, !- Name
+ Ceiling, !- Surface Type
+ INT-FLOOR-UNDERSIDE, !- Construction Name
+ Basement, !- Zone Name
+ Surface, !- Outside Boundary Condition
+ Perimeter_bot_ZN_1_Floor,!- Outside Boundary Condition Object
+ NoSun, !- Sun Exposure
+ NoWind, !- Wind Exposure
+ AutoCalculate, !- View Factor to Ground
+ 4, !- Number of Vertices
+ 4.5732,4.5732,0.0000, !- X,Y,Z ==> Vertex 1 {m}
+ 0.0000,0.0000,0.0000, !- X,Y,Z ==> Vertex 2 {m}
+ 73.1072,0.0000,0.0000, !- X,Y,Z ==> Vertex 3 {m}
+ 68.5340,4.5732,0.0000; !- X,Y,Z ==> Vertex 4 {m}
+ Basement_Ceiling_2, !- Name
+ Perimeter_bot_ZN_2_Floor,!- Outside Boundary Condition Object
+ 68.5340,4.5732,0.0000, !- X,Y,Z ==> Vertex 1 {m}
+ 73.1072,0.0000,0.0000, !- X,Y,Z ==> Vertex 2 {m}
+ 73.1072,48.7381,0.0000, !- X,Y,Z ==> Vertex 3 {m}
+ 68.5340,44.1650,0.0000; !- X,Y,Z ==> Vertex 4 {m}
+ Basement_Ceiling_3, !- Name
+ Perimeter_bot_ZN_3_Floor,!- Outside Boundary Condition Object
+ 68.5340,44.1650,0.0000, !- X,Y,Z ==> Vertex 1 {m}
+ 73.1072,48.7381,0.0000, !- X,Y,Z ==> Vertex 2 {m}
+ 0.0000,48.7381,0.0000, !- X,Y,Z ==> Vertex 3 {m}
+ 4.5732,44.1650,0.0000; !- X,Y,Z ==> Vertex 4 {m}
+ Basement_Ceiling_4, !- Name
+ Perimeter_bot_ZN_4_Floor,!- Outside Boundary Condition Object
+ 4.5732,44.1650,0.0000, !- X,Y,Z ==> Vertex 1 {m}
+ 0.0000,48.7381,0.0000, !- X,Y,Z ==> Vertex 2 {m}
+ 0.0000,0.0000,0.0000, !- X,Y,Z ==> Vertex 3 {m}
+ 4.5732,4.5732,0.0000; !- X,Y,Z ==> Vertex 4 {m}
+ Basement_Ceiling_5, !- Name
+ Core_bot_ZN_5_Floor, !- Outside Boundary Condition Object
+ 4.5732,4.5732,0.0000, !- X,Y,Z ==> Vertex 2 {m}
+ 68.5340,4.5732,0.0000, !- X,Y,Z ==> Vertex 3 {m}
+ Basement_Floor, !- Name
+ Floor, !- Surface Type
+ ext-slab, !- Construction Name
+ Ground, !- Outside Boundary Condition
+ , !- Outside Boundary Condition Object
+ 73.1072,48.7381,-2.4390, !- X,Y,Z ==> Vertex 1 {m}
+ 73.1072,0.0000,-2.4390, !- X,Y,Z ==> Vertex 2 {m}
+ 0.0000,0.0000,-2.4390, !- X,Y,Z ==> Vertex 3 {m}
+ 0.0000,48.7381,-2.4390; !- X,Y,Z ==> Vertex 4 {m}
+ Basement_Wall_East, !- Name
+ Wall, !- Surface Type
+ Underground Wall Non-res,!- Construction Name
+ 73.1072,0.0000,0.0000, !- X,Y,Z ==> Vertex 1 {m}
+ 73.1072,48.7381,-2.4390, !- X,Y,Z ==> Vertex 3 {m}
+ 73.1072,48.7381,0.0000; !- X,Y,Z ==> Vertex 4 {m}
+ Basement_Wall_North, !- Name
+ 73.1072,48.7381,0.0000, !- X,Y,Z ==> Vertex 1 {m}
+ 73.1072,48.7381,-2.4390, !- X,Y,Z ==> Vertex 2 {m}
+ 0.0000,48.7381,-2.4390, !- X,Y,Z ==> Vertex 3 {m}
+ 0.0000,48.7381,0.0000; !- X,Y,Z ==> Vertex 4 {m}
+ Basement_Wall_South, !- Name
+ 0.0000,0.0000,0.0000, !- X,Y,Z ==> Vertex 1 {m}
+ 0.0000,0.0000,-2.4390, !- X,Y,Z ==> Vertex 2 {m}
+ 73.1072,0.0000,-2.4390, !- X,Y,Z ==> Vertex 3 {m}
+ 73.1072,0.0000,0.0000; !- X,Y,Z ==> Vertex 4 {m}
+ Basement_Wall_West, !- Name
+ 0.0000,48.7381,0.0000, !- X,Y,Z ==> Vertex 1 {m}
+ 0.0000,48.7381,-2.4390, !- X,Y,Z ==> Vertex 2 {m}
+ 0.0000,0.0000,0.0000; !- X,Y,Z ==> Vertex 4 {m}
+ Building_Roof, !- Name
+ Roof, !- Surface Type
+ IEAD Non-res Roof, !- Construction Name
+ TopFloor_Plenum, !- Zone Name
+ Outdoors, !- Outside Boundary Condition
+ SunExposed, !- Sun Exposure
+ WindExposed, !- Wind Exposure
+ 73.1072,0.0000,47.5584, !- X,Y,Z ==> Vertex 1 {m}
+ 73.1072,48.7381,47.5584, !- X,Y,Z ==> Vertex 2 {m}
+ 0.0000,48.7381,47.5584, !- X,Y,Z ==> Vertex 3 {m}
+ 0.0000,0.0000,47.5584; !- X,Y,Z ==> Vertex 4 {m}
+ Core_bot_ZN_5_Ceiling, !- Name
+ DropCeiling, !- Construction Name
+ Core_bottom, !- Zone Name
+ GroundFloor_Plenum_Floor_5, !- Outside Boundary Condition Object
+ 4.5732,44.1650,2.7440, !- X,Y,Z ==> Vertex 1 {m}
+ 4.5732,4.5732,2.7440, !- X,Y,Z ==> Vertex 2 {m}
+ 68.5340,4.5732,2.7440, !- X,Y,Z ==> Vertex 3 {m}
+ 68.5340,44.1650,2.7440; !- X,Y,Z ==> Vertex 4 {m}
+ Core_bot_ZN_5_Floor, !- Name
+ INT-FLOOR-TOPSIDE, !- Construction Name
+ Basement_Ceiling_5, !- Outside Boundary Condition Object
+ 68.5340,4.5732,0.0000, !- X,Y,Z ==> Vertex 2 {m}
+ 4.5732,4.5732,0.0000, !- X,Y,Z ==> Vertex 3 {m}
+ Core_bot_ZN_5_Wall_East, !- Name
+ int-walls, !- Construction Name
+ Perimeter_bot_ZN_2_Wall_West, !- Outside Boundary Condition Object
+ 68.5340,4.5732,2.7440, !- X,Y,Z ==> Vertex 1 {m}
+ 68.5340,44.1650,0.0000, !- X,Y,Z ==> Vertex 3 {m}
+ Core_bot_ZN_5_Wall_North,!- Name
+ Perimeter_bot_ZN_3_Wall_South, !- Outside Boundary Condition Object
+ 68.5340,44.1650,2.7440, !- X,Y,Z ==> Vertex 1 {m}
+ 68.5340,44.1650,0.0000, !- X,Y,Z ==> Vertex 2 {m}
+ 4.5732,44.1650,0.0000, !- X,Y,Z ==> Vertex 3 {m}
+ 4.5732,44.1650,2.7440; !- X,Y,Z ==> Vertex 4 {m}
+ Core_bot_ZN_5_Wall_South,!- Name
+ Perimeter_bot_ZN_1_Wall_North, !- Outside Boundary Condition Object
+ 4.5732,4.5732,2.7440, !- X,Y,Z ==> Vertex 1 {m}
+ 68.5340,4.5732,2.7440; !- X,Y,Z ==> Vertex 4 {m}
+ Core_bot_ZN_5_Wall_West, !- Name
+ Perimeter_bot_ZN_4_Wall_East, !- Outside Boundary Condition Object
+ 4.5732,44.1650,0.0000, !- X,Y,Z ==> Vertex 2 {m}
+ 4.5732,4.5732,2.7440; !- X,Y,Z ==> Vertex 4 {m}
+ Core_mid_ZN_5_Ceiling, !- Name
+ Core_mid, !- Zone Name
+ MidFloor_Plenum_Floor_5, !- Outside Boundary Condition Object
+ 4.5732,44.1650,22.5600, !- X,Y,Z ==> Vertex 1 {m}
+ 4.5732,4.5732,22.5600, !- X,Y,Z ==> Vertex 2 {m}
+ 68.5340,4.5732,22.5600, !- X,Y,Z ==> Vertex 3 {m}
+ 68.5340,44.1650,22.5600; !- X,Y,Z ==> Vertex 4 {m}
+ Core_mid_ZN_5_Floor, !- Name
+ Core_mid_ZN_5_Floor, !- Outside Boundary Condition Object
+ 68.5340,44.1650,19.8160, !- X,Y,Z ==> Vertex 1 {m}
+ 68.5340,4.5732,19.8160, !- X,Y,Z ==> Vertex 2 {m}
+ 4.5732,4.5732,19.8160, !- X,Y,Z ==> Vertex 3 {m}
+ 4.5732,44.1650,19.8160; !- X,Y,Z ==> Vertex 4 {m}
+ Core_mid_ZN_5_Wall_East, !- Name
+ Perimeter_mid_ZN_2_Wall_West, !- Outside Boundary Condition Object
+ 68.5340,4.5732,22.5600, !- X,Y,Z ==> Vertex 1 {m}
+ 68.5340,44.1650,19.8160, !- X,Y,Z ==> Vertex 3 {m}
+ Core_mid_ZN_5_Wall_North,!- Name
+ Perimeter_mid_ZN_3_Wall_South, !- Outside Boundary Condition Object
+ 68.5340,44.1650,22.5600, !- X,Y,Z ==> Vertex 1 {m}
+ 68.5340,44.1650,19.8160, !- X,Y,Z ==> Vertex 2 {m}
+ 4.5732,44.1650,19.8160, !- X,Y,Z ==> Vertex 3 {m}
+ 4.5732,44.1650,22.5600; !- X,Y,Z ==> Vertex 4 {m}
+ Core_mid_ZN_5_Wall_South,!- Name
+ Perimeter_mid_ZN_1_Wall_North, !- Outside Boundary Condition Object
+ 4.5732,4.5732,22.5600, !- X,Y,Z ==> Vertex 1 {m}
+ 4.5732,4.5732,19.8160, !- X,Y,Z ==> Vertex 2 {m}
+ 68.5340,4.5732,19.8160, !- X,Y,Z ==> Vertex 3 {m}
+ 68.5340,4.5732,22.5600; !- X,Y,Z ==> Vertex 4 {m}
+ Core_mid_ZN_5_Wall_West, !- Name
+ Perimeter_mid_ZN_4_Wall_East, !- Outside Boundary Condition Object
+ 4.5732,44.1650,19.8160, !- X,Y,Z ==> Vertex 2 {m}
+ 4.5732,4.5732,22.5600; !- X,Y,Z ==> Vertex 4 {m}
+ Core_top_ZN_5_Ceiling, !- Name
+ Core_top, !- Zone Name
+ TopFloor_Plenum_Floor_5, !- Outside Boundary Condition Object
+ 4.5732,44.1650,46.3392, !- X,Y,Z ==> Vertex 1 {m}
+ 4.5732,4.5732,46.3392, !- X,Y,Z ==> Vertex 2 {m}
+ 68.5340,4.5732,46.3392, !- X,Y,Z ==> Vertex 3 {m}
+ 68.5340,44.1650,46.3392; !- X,Y,Z ==> Vertex 4 {m}
+ Core_top_ZN_5_Floor, !- Name
+ Core_top_ZN_5_Floor, !- Outside Boundary Condition Object
+ 68.5340,44.1650,43.5952, !- X,Y,Z ==> Vertex 1 {m}
+ 68.5340,4.5732,43.5952, !- X,Y,Z ==> Vertex 2 {m}
+ 4.5732,4.5732,43.5952, !- X,Y,Z ==> Vertex 3 {m}
+ 4.5732,44.1650,43.5952; !- X,Y,Z ==> Vertex 4 {m}
+ Core_top_ZN_5_Wall_East, !- Name
+ Perimeter_top_ZN_2_Wall_West, !- Outside Boundary Condition Object
+ 68.5340,4.5732,46.3392, !- X,Y,Z ==> Vertex 1 {m}
+ 68.5340,44.1650,43.5952, !- X,Y,Z ==> Vertex 3 {m}
+ Core_top_ZN_5_Wall_North,!- Name
+ Perimeter_top_ZN_3_Wall_South, !- Outside Boundary Condition Object
+ 68.5340,44.1650,46.3392, !- X,Y,Z ==> Vertex 1 {m}
+ 68.5340,44.1650,43.5952, !- X,Y,Z ==> Vertex 2 {m}
+ 4.5732,44.1650,43.5952, !- X,Y,Z ==> Vertex 3 {m}
+ 4.5732,44.1650,46.3392; !- X,Y,Z ==> Vertex 4 {m}
+ Core_top_ZN_5_Wall_South,!- Name
+ Perimeter_top_ZN_1_Wall_North, !- Outside Boundary Condition Object
+ 4.5732,4.5732,46.3392, !- X,Y,Z ==> Vertex 1 {m}
+ 4.5732,4.5732,43.5952, !- X,Y,Z ==> Vertex 2 {m}
+ 68.5340,4.5732,43.5952, !- X,Y,Z ==> Vertex 3 {m}
+ 68.5340,4.5732,46.3392; !- X,Y,Z ==> Vertex 4 {m}
+ Core_top_ZN_5_Wall_West, !- Name
+ Perimeter_top_ZN_4_Wall_East, !- Outside Boundary Condition Object
+ 4.5732,44.1650,43.5952, !- X,Y,Z ==> Vertex 2 {m}
+ 4.5732,4.5732,46.3392; !- X,Y,Z ==> Vertex 4 {m}
+ GroundFloor_Plenum_Ceiling, !- Name
+ GroundFloor_Plenum, !- Zone Name
+ GroundFloor_Plenum_Ceiling, !- Outside Boundary Condition Object
+ 73.1072,0.0000,3.9632, !- X,Y,Z ==> Vertex 1 {m}
+ 73.1072,48.7381,3.9632, !- X,Y,Z ==> Vertex 2 {m}
+ 0.0000,48.7381,3.9632, !- X,Y,Z ==> Vertex 3 {m}
+ 0.0000,0.0000,3.9632; !- X,Y,Z ==> Vertex 4 {m}
+ GroundFloor_Plenum_Floor_1, !- Name
+ Perimeter_bot_ZN_1_Ceiling, !- Outside Boundary Condition Object
+ 68.5340,4.5732,2.7440, !- X,Y,Z ==> Vertex 2 {m}
+ 73.1072,0.0000,2.7440, !- X,Y,Z ==> Vertex 3 {m}
+ 0.0000,0.0000,2.7440; !- X,Y,Z ==> Vertex 4 {m}
+ GroundFloor_Plenum_Floor_2, !- Name
+ Perimeter_bot_ZN_2_Ceiling, !- Outside Boundary Condition Object
+ 73.1072,48.7381,2.7440, !- X,Y,Z ==> Vertex 1 {m}
+ 73.1072,0.0000,2.7440, !- X,Y,Z ==> Vertex 2 {m}
+ GroundFloor_Plenum_Floor_3, !- Name
+ Perimeter_bot_ZN_3_Ceiling, !- Outside Boundary Condition Object
+ 4.5732,44.1650,2.7440, !- X,Y,Z ==> Vertex 2 {m}
+ 0.0000,48.7381,2.7440, !- X,Y,Z ==> Vertex 3 {m}
+ 73.1072,48.7381,2.7440; !- X,Y,Z ==> Vertex 4 {m}
+ GroundFloor_Plenum_Floor_4, !- Name
+ Perimeter_bot_ZN_4_Ceiling, !- Outside Boundary Condition Object
+ 0.0000,0.0000,2.7440, !- X,Y,Z ==> Vertex 3 {m}
+ 0.0000,48.7381,2.7440; !- X,Y,Z ==> Vertex 4 {m}
+ GroundFloor_Plenum_Floor_5, !- Name
+ Core_bot_ZN_5_Ceiling, !- Outside Boundary Condition Object
+ 4.5732,44.1650,2.7440, !- X,Y,Z ==> Vertex 3 {m}
+ GroundFloor_Plenum_Wall_East, !- Name
+ Mass Non-res Ext Wall, !- Construction Name
+ 73.1072,48.7381,2.7440, !- X,Y,Z ==> Vertex 3 {m}
+ 73.1072,48.7381,3.9632; !- X,Y,Z ==> Vertex 4 {m}
+ GroundFloor_Plenum_Wall_North, !- Name
+ 73.1072,48.7381,3.9632, !- X,Y,Z ==> Vertex 1 {m}
+ 73.1072,48.7381,2.7440, !- X,Y,Z ==> Vertex 2 {m}
+ 0.0000,48.7381,3.9632; !- X,Y,Z ==> Vertex 4 {m}
+ GroundFloor_Plenum_Wall_South, !- Name
+ 0.0000,0.0000,3.9632, !- X,Y,Z ==> Vertex 1 {m}
+ 0.0000,0.0000,2.7440, !- X,Y,Z ==> Vertex 2 {m}
+ 73.1072,0.0000,3.9632; !- X,Y,Z ==> Vertex 4 {m}
+ GroundFloor_Plenum_West, !- Name
+ 0.0000,48.7381,3.9632, !- X,Y,Z ==> Vertex 1 {m}
+ 0.0000,48.7381,2.7440, !- X,Y,Z ==> Vertex 2 {m}
+ MidFloor_Plenum_Ceiling, !- Name
+ MidFloor_Plenum, !- Zone Name
+ MidFloor_Plenum_Ceiling, !- Outside Boundary Condition Object
+ 73.1072,48.7381,23.7792, !- X,Y,Z ==> Vertex 1 {m}
+ 0.0000,48.7381,23.7792, !- X,Y,Z ==> Vertex 2 {m}
+ 0.0000,0.0000,23.7792, !- X,Y,Z ==> Vertex 3 {m}
+ 73.1072,0.0000,23.7792; !- X,Y,Z ==> Vertex 4 {m}
+ MidFloor_Plenum_Floor_1, !- Name
+ Perimeter_mid_ZN_1_Ceiling, !- Outside Boundary Condition Object
+ 73.1072,0.0000,22.5600, !- X,Y,Z ==> Vertex 1 {m}
+ 0.0000,0.0000,22.5600, !- X,Y,Z ==> Vertex 2 {m}
+ 4.5732,4.5732,22.5600, !- X,Y,Z ==> Vertex 3 {m}
+ MidFloor_Plenum_Floor_2, !- Name
+ Perimeter_mid_ZN_2_Ceiling, !- Outside Boundary Condition Object
+ 68.5340,4.5732,22.5600, !- X,Y,Z ==> Vertex 2 {m}
+ 68.5340,44.1650,22.5600, !- X,Y,Z ==> Vertex 3 {m}
+ 73.1072,48.7381,22.5600; !- X,Y,Z ==> Vertex 4 {m}
+ MidFloor_Plenum_Floor_3, !- Name
+ Perimeter_mid_ZN_3_Ceiling, !- Outside Boundary Condition Object
+ 0.0000,48.7381,22.5600, !- X,Y,Z ==> Vertex 1 {m}
+ 73.1072,48.7381,22.5600, !- X,Y,Z ==> Vertex 2 {m}
+ MidFloor_Plenum_Floor_4, !- Name
+ Perimeter_mid_ZN_4_Ceiling, !- Outside Boundary Condition Object
+ 0.0000,0.0000,22.5600, !- X,Y,Z ==> Vertex 1 {m}
+ 0.0000,48.7381,22.5600, !- X,Y,Z ==> Vertex 2 {m}
+ 4.5732,44.1650,22.5600, !- X,Y,Z ==> Vertex 3 {m}
+ MidFloor_Plenum_Floor_5, !- Name
+ Core_mid_ZN_5_Ceiling, !- Outside Boundary Condition Object
+ MidFloor_Plenum_Wall_East, !- Name
+ 73.1072,0.0000,23.7792, !- X,Y,Z ==> Vertex 1 {m}
+ 73.1072,0.0000,22.5600, !- X,Y,Z ==> Vertex 2 {m}
+ 73.1072,48.7381,22.5600, !- X,Y,Z ==> Vertex 3 {m}
+ 73.1072,48.7381,23.7792; !- X,Y,Z ==> Vertex 4 {m}
+ MidFloor_Plenum_Wall_North, !- Name
+ 0.0000,48.7381,22.5600, !- X,Y,Z ==> Vertex 3 {m}
+ 0.0000,48.7381,23.7792; !- X,Y,Z ==> Vertex 4 {m}
+ MidFloor_Plenum_Wall_South, !- Name
+ 0.0000,0.0000,23.7792, !- X,Y,Z ==> Vertex 1 {m}
+ 73.1072,0.0000,22.5600, !- X,Y,Z ==> Vertex 3 {m}
+ MidFloor_Plenum_Wall_West, !- Name
+ 0.0000,48.7381,23.7792, !- X,Y,Z ==> Vertex 1 {m}
+ 0.0000,0.0000,22.5600, !- X,Y,Z ==> Vertex 3 {m}
+ 0.0000,0.0000,23.7792; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_bot_ZN_1_Ceiling, !- Name
+ Perimeter_bot_ZN_1, !- Zone Name
+ GroundFloor_Plenum_Floor_1, !- Outside Boundary Condition Object
+ Perimeter_bot_ZN_1_Floor,!- Name
+ Basement_Ceiling_1, !- Outside Boundary Condition Object
+ Perimeter_bot_ZN_1_Wall_East, !- Name
+ Perimeter_bot_ZN_2_Wall_South, !- Outside Boundary Condition Object
+ 73.1072,0.0000,2.7440, !- X,Y,Z ==> Vertex 1 {m}
+ Perimeter_bot_ZN_1_Wall_North, !- Name
+ Core_bot_ZN_5_Wall_South,!- Outside Boundary Condition Object
+ Perimeter_bot_ZN_1_Wall_South, !- Name
+ 0.0000,0.0000,2.7440, !- X,Y,Z ==> Vertex 1 {m}
+ 73.1072,0.0000,2.7440; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_bot_ZN_1_Wall_West, !- Name
+ Perimeter_bot_ZN_4_Wall_South, !- Outside Boundary Condition Object
+ Perimeter_bot_ZN_2_Ceiling, !- Name
+ Perimeter_bot_ZN_2, !- Zone Name
+ GroundFloor_Plenum_Floor_2, !- Outside Boundary Condition Object
+ Perimeter_bot_ZN_2_Floor,!- Name
+ Basement_Ceiling_2, !- Outside Boundary Condition Object
+ Perimeter_bot_ZN_2_Wall_East, !- Name
+ Perimeter_bot_ZN_2_Wall_North, !- Name
+ Perimeter_bot_ZN_3_Wall_East, !- Outside Boundary Condition Object
+ Perimeter_bot_ZN_2_Wall_South, !- Name
+ Perimeter_bot_ZN_1_Wall_East, !- Outside Boundary Condition Object
+ Perimeter_bot_ZN_2_Wall_West, !- Name
+ Core_bot_ZN_5_Wall_East, !- Outside Boundary Condition Object
+ Perimeter_bot_ZN_3_Ceiling, !- Name
+ Perimeter_bot_ZN_3, !- Zone Name
+ GroundFloor_Plenum_Floor_3, !- Outside Boundary Condition Object
+ Perimeter_bot_ZN_3_Floor,!- Name
+ Basement_Ceiling_3, !- Outside Boundary Condition Object
+ Perimeter_bot_ZN_3_Wall_East, !- Name
+ Perimeter_bot_ZN_2_Wall_North, !- Outside Boundary Condition Object
+ Perimeter_bot_ZN_3_Wall_North, !- Name
+ Perimeter_bot_ZN_3_Wall_South, !- Name
+ Core_bot_ZN_5_Wall_North,!- Outside Boundary Condition Object
+ Perimeter_bot_ZN_3_Wall_West, !- Name
+ Perimeter_bot_ZN_4_Wall_North, !- Outside Boundary Condition Object
+ 0.0000,48.7381,2.7440, !- X,Y,Z ==> Vertex 1 {m}
+ Perimeter_bot_ZN_4_Ceiling, !- Name
+ Perimeter_bot_ZN_4, !- Zone Name
+ GroundFloor_Plenum_Floor_4, !- Outside Boundary Condition Object
+ Perimeter_bot_ZN_4_Floor,!- Name
+ Basement_Ceiling_4, !- Outside Boundary Condition Object
+ Perimeter_bot_ZN_4_Wall_East, !- Name
+ Core_bot_ZN_5_Wall_West, !- Outside Boundary Condition Object
+ Perimeter_bot_ZN_4_Wall_North, !- Name
+ Perimeter_bot_ZN_3_Wall_West, !- Outside Boundary Condition Object
+ Perimeter_bot_ZN_4_Wall_South, !- Name
+ Perimeter_bot_ZN_1_Wall_West, !- Outside Boundary Condition Object
+ Perimeter_bot_ZN_4_Wall_West, !- Name
+ Perimeter_mid_ZN_1_Ceiling, !- Name
+ Perimeter_mid_ZN_1, !- Zone Name
+ MidFloor_Plenum_Floor_1, !- Outside Boundary Condition Object
+ Perimeter_mid_ZN_1_Floor,!- Name
+ Perimeter_mid_ZN_1_Floor,!- Outside Boundary Condition Object
+ 68.5340,4.5732,19.8160, !- X,Y,Z ==> Vertex 1 {m}
+ 73.1072,0.0000,19.8160, !- X,Y,Z ==> Vertex 2 {m}
+ 0.0000,0.0000,19.8160, !- X,Y,Z ==> Vertex 3 {m}
+ 4.5732,4.5732,19.8160; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_mid_ZN_1_Wall_East, !- Name
+ Perimeter_mid_ZN_2_Wall_South, !- Outside Boundary Condition Object
+ Perimeter_mid_ZN_1_Wall_North, !- Name
+ Core_mid_ZN_5_Wall_South,!- Outside Boundary Condition Object
+ Perimeter_mid_ZN_1_Wall_South, !- Name
+ 0.0000,0.0000,19.8160, !- X,Y,Z ==> Vertex 2 {m}
+ 73.1072,0.0000,19.8160, !- X,Y,Z ==> Vertex 3 {m}
+ 73.1072,0.0000,22.5600; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_mid_ZN_1_Wall_West, !- Name
+ Perimeter_mid_ZN_4_Wall_South, !- Outside Boundary Condition Object
+ 0.0000,0.0000,22.5600; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_mid_ZN_2_Ceiling, !- Name
+ Perimeter_mid_ZN_2, !- Zone Name
+ MidFloor_Plenum_Floor_2, !- Outside Boundary Condition Object
+ Perimeter_mid_ZN_2_Floor,!- Name
+ Perimeter_mid_ZN_2_Floor,!- Outside Boundary Condition Object
+ 73.1072,48.7381,19.8160, !- X,Y,Z ==> Vertex 2 {m}
+ 68.5340,4.5732,19.8160; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_mid_ZN_2_Wall_East, !- Name
+ 73.1072,48.7381,19.8160, !- X,Y,Z ==> Vertex 3 {m}
+ Perimeter_mid_ZN_2_Wall_North, !- Name
+ Perimeter_mid_ZN_3_Wall_East, !- Outside Boundary Condition Object
+ 73.1072,48.7381,22.5600, !- X,Y,Z ==> Vertex 1 {m}
+ Perimeter_mid_ZN_2_Wall_South, !- Name
+ Perimeter_mid_ZN_1_Wall_East, !- Outside Boundary Condition Object
+ Perimeter_mid_ZN_2_Wall_West, !- Name
+ Core_mid_ZN_5_Wall_East, !- Outside Boundary Condition Object
+ Perimeter_mid_ZN_3_Ceiling, !- Name
+ Perimeter_mid_ZN_3, !- Zone Name
+ MidFloor_Plenum_Floor_3, !- Outside Boundary Condition Object
+ Perimeter_mid_ZN_3_Floor,!- Name
+ Perimeter_mid_ZN_3_Floor,!- Outside Boundary Condition Object
+ 4.5732,44.1650,19.8160, !- X,Y,Z ==> Vertex 1 {m}
+ 0.0000,48.7381,19.8160, !- X,Y,Z ==> Vertex 2 {m}
+ 68.5340,44.1650,19.8160; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_mid_ZN_3_Wall_East, !- Name
+ Perimeter_mid_ZN_2_Wall_North, !- Outside Boundary Condition Object
+ Perimeter_mid_ZN_3_Wall_North, !- Name
+ 0.0000,48.7381,19.8160, !- X,Y,Z ==> Vertex 3 {m}
+ 0.0000,48.7381,22.5600; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_mid_ZN_3_Wall_South, !- Name
+ Core_mid_ZN_5_Wall_North,!- Outside Boundary Condition Object
+ Perimeter_mid_ZN_3_Wall_West, !- Name
+ Perimeter_mid_ZN_4_Wall_North, !- Outside Boundary Condition Object
+ Perimeter_mid_ZN_4_Ceiling, !- Name
+ Perimeter_mid_ZN_4, !- Zone Name
+ MidFloor_Plenum_Floor_4, !- Outside Boundary Condition Object
+ Perimeter_mid_ZN_4_Floor,!- Name
+ Perimeter_mid_ZN_4_Floor,!- Outside Boundary Condition Object
+ 4.5732,4.5732,19.8160, !- X,Y,Z ==> Vertex 1 {m}
+ Perimeter_mid_ZN_4_Wall_East, !- Name
+ Core_mid_ZN_5_Wall_West, !- Outside Boundary Condition Object
+ Perimeter_mid_ZN_4_Wall_North, !- Name
+ Perimeter_mid_ZN_3_Wall_West, !- Outside Boundary Condition Object
+ Perimeter_mid_ZN_4_Wall_South, !- Name
+ Perimeter_mid_ZN_1_Wall_West, !- Outside Boundary Condition Object
+ Perimeter_mid_ZN_4_Wall_West, !- Name
+ Perimeter_top_ZN_1_Ceiling, !- Name
+ Perimeter_top_ZN_1, !- Zone Name
+ TopFloor_Plenum_Floor_1, !- Outside Boundary Condition Object
+ 0.0000,0.0000,46.3392, !- X,Y,Z ==> Vertex 2 {m}
+ 73.1072,0.0000,46.3392, !- X,Y,Z ==> Vertex 3 {m}
+ Perimeter_top_ZN_1_Floor,!- Name
+ Perimeter_top_ZN_1_Floor,!- Outside Boundary Condition Object
+ 68.5340,4.5732,43.5952, !- X,Y,Z ==> Vertex 1 {m}
+ 73.1072,0.0000,43.5952, !- X,Y,Z ==> Vertex 2 {m}
+ 0.0000,0.0000,43.5952, !- X,Y,Z ==> Vertex 3 {m}
+ 4.5732,4.5732,43.5952; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_top_ZN_1_Wall_East, !- Name
+ Perimeter_top_ZN_2_Wall_South, !- Outside Boundary Condition Object
+ 73.1072,0.0000,46.3392, !- X,Y,Z ==> Vertex 1 {m}
+ Perimeter_top_ZN_1_Wall_North, !- Name
+ Core_top_ZN_5_Wall_South,!- Outside Boundary Condition Object
+ Perimeter_top_ZN_1_Wall_South, !- Name
+ 0.0000,0.0000,46.3392, !- X,Y,Z ==> Vertex 1 {m}
+ 0.0000,0.0000,43.5952, !- X,Y,Z ==> Vertex 2 {m}
+ 73.1072,0.0000,43.5952, !- X,Y,Z ==> Vertex 3 {m}
+ 73.1072,0.0000,46.3392; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_top_ZN_1_Wall_West, !- Name
+ Perimeter_top_ZN_4_Wall_South, !- Outside Boundary Condition Object
+ 0.0000,0.0000,46.3392; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_top_ZN_2_Ceiling, !- Name
+ Perimeter_top_ZN_2, !- Zone Name
+ TopFloor_Plenum_Floor_2, !- Outside Boundary Condition Object
+ 73.1072,0.0000,46.3392, !- X,Y,Z ==> Vertex 2 {m}
+ 73.1072,48.7381,46.3392, !- X,Y,Z ==> Vertex 3 {m}
+ Perimeter_top_ZN_2_Floor,!- Name
+ Perimeter_top_ZN_2_Floor,!- Outside Boundary Condition Object
+ 73.1072,48.7381,43.5952, !- X,Y,Z ==> Vertex 2 {m}
+ 68.5340,4.5732,43.5952; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_top_ZN_2_Wall_East, !- Name
+ 73.1072,48.7381,43.5952, !- X,Y,Z ==> Vertex 3 {m}
+ 73.1072,48.7381,46.3392; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_top_ZN_2_Wall_North, !- Name
+ Perimeter_top_ZN_3_Wall_East, !- Outside Boundary Condition Object
+ 73.1072,48.7381,46.3392, !- X,Y,Z ==> Vertex 1 {m}
+ Perimeter_top_ZN_2_Wall_South, !- Name
+ Perimeter_top_ZN_1_Wall_East, !- Outside Boundary Condition Object
+ Perimeter_top_ZN_2_Wall_West, !- Name
+ Core_top_ZN_5_Wall_East, !- Outside Boundary Condition Object
+ Perimeter_top_ZN_3_Ceiling, !- Name
+ Perimeter_top_ZN_3, !- Zone Name
+ TopFloor_Plenum_Floor_3, !- Outside Boundary Condition Object
+ 73.1072,48.7381,46.3392, !- X,Y,Z ==> Vertex 2 {m}
+ 0.0000,48.7381,46.3392, !- X,Y,Z ==> Vertex 3 {m}
+ Perimeter_top_ZN_3_Floor,!- Name
+ Perimeter_top_ZN_3_Floor,!- Outside Boundary Condition Object
+ 4.5732,44.1650,43.5952, !- X,Y,Z ==> Vertex 1 {m}
+ 0.0000,48.7381,43.5952, !- X,Y,Z ==> Vertex 2 {m}
+ 68.5340,44.1650,43.5952; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_top_ZN_3_Wall_East, !- Name
+ Perimeter_top_ZN_2_Wall_North, !- Outside Boundary Condition Object
+ Perimeter_top_ZN_3_Wall_North, !- Name
+ 0.0000,48.7381,43.5952, !- X,Y,Z ==> Vertex 3 {m}
+ 0.0000,48.7381,46.3392; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_top_ZN_3_Wall_South, !- Name
+ Core_top_ZN_5_Wall_North,!- Outside Boundary Condition Object
+ Perimeter_top_ZN_3_Wall_West, !- Name
+ Perimeter_top_ZN_4_Wall_North, !- Outside Boundary Condition Object
+ 0.0000,48.7381,46.3392, !- X,Y,Z ==> Vertex 1 {m}
+ Perimeter_top_ZN_4_Ceiling, !- Name
+ Perimeter_top_ZN_4, !- Zone Name
+ TopFloor_Plenum_Floor_4, !- Outside Boundary Condition Object
+ 0.0000,48.7381,46.3392, !- X,Y,Z ==> Vertex 2 {m}
+ 0.0000,0.0000,46.3392, !- X,Y,Z ==> Vertex 3 {m}
+ Perimeter_top_ZN_4_Floor,!- Name
+ Perimeter_top_ZN_4_Floor,!- Outside Boundary Condition Object
+ 4.5732,4.5732,43.5952, !- X,Y,Z ==> Vertex 1 {m}
+ Perimeter_top_ZN_4_Wall_East, !- Name
+ Core_top_ZN_5_Wall_West, !- Outside Boundary Condition Object
+ Perimeter_top_ZN_4_Wall_North, !- Name
+ Perimeter_top_ZN_3_Wall_West, !- Outside Boundary Condition Object
+ Perimeter_top_ZN_4_Wall_South, !- Name
+ Perimeter_top_ZN_1_Wall_West, !- Outside Boundary Condition Object
+ Perimeter_top_ZN_4_Wall_West, !- Name
+ TopFloor_Plenum_Floor_1, !- Name
+ Perimeter_top_ZN_1_Ceiling, !- Outside Boundary Condition Object
+ 4.5732,4.5732,46.3392, !- X,Y,Z ==> Vertex 3 {m}
+ TopFloor_Plenum_Floor_2, !- Name
+ Perimeter_top_ZN_2_Ceiling, !- Outside Boundary Condition Object
+ 68.5340,4.5732,46.3392, !- X,Y,Z ==> Vertex 2 {m}
+ 68.5340,44.1650,46.3392, !- X,Y,Z ==> Vertex 3 {m}
+ TopFloor_Plenum_Floor_3, !- Name
+ Perimeter_top_ZN_3_Ceiling, !- Outside Boundary Condition Object
+ TopFloor_Plenum_Floor_4, !- Name
+ Perimeter_top_ZN_4_Ceiling, !- Outside Boundary Condition Object
+ 4.5732,44.1650,46.3392, !- X,Y,Z ==> Vertex 3 {m}
+ TopFloor_Plenum_Floor_5, !- Name
+ Core_top_ZN_5_Ceiling, !- Outside Boundary Condition Object
+ 68.5340,44.1650,46.3392, !- X,Y,Z ==> Vertex 2 {m}
+ TopFloor_Plenum_Wall_East, !- Name
+ 73.1072,48.7381,47.5584; !- X,Y,Z ==> Vertex 4 {m}
+ TopFloor_Plenum_Wall_North, !- Name
+ 0.0000,0.0000,47.5584, !- X,Y,Z ==> Vertex 1 {m}
+ 73.1072,0.0000,47.5584; !- X,Y,Z ==> Vertex 4 {m}
+ TopFloor_Plenum_Wall_South, !- Name
+ 73.1072,48.7381,47.5584, !- X,Y,Z ==> Vertex 1 {m}
+ 0.0000,48.7381,47.5584; !- X,Y,Z ==> Vertex 4 {m}
+ TopFloor_Plenum_Wall_West, !- Name
+ 0.0000,48.7381,47.5584, !- X,Y,Z ==> Vertex 1 {m}
+! ***WINDOWS***
+ FenestrationSurface:Detailed,
+ Perimeter_bot_ZN_1_Wall_South_Window, !- Name
+ Window, !- Surface Type
+ Window Non-res Fixed, !- Construction Name
+ Perimeter_bot_ZN_1_Wall_South, !- Building Surface Name
+ , !- Shading Control Name
+ , !- Frame and Divider Name
+ 1.0000, !- Multiplier
+ 0.0000,0.0000,2.5000, !- X,Y,Z ==> Vertex 1 {m}
+ 0.0000,0.0000,0.9146, !- X,Y,Z ==> Vertex 2 {m}
+ 73.1070,0.0000,0.9146, !- X,Y,Z ==> Vertex 3 {m}
+ 73.1070,0.0000,2.5000; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_bot_ZN_2_Wall_East_Window, !- Name
+ Perimeter_bot_ZN_2_Wall_East, !- Building Surface Name
+ 73.1072,0.0000,2.5000, !- X,Y,Z ==> Vertex 1 {m}
+ 73.1072,0.0000,0.9146, !- X,Y,Z ==> Vertex 2 {m}
+ 73.1072,48.7380,0.9146, !- X,Y,Z ==> Vertex 3 {m}
+ 73.1072,48.7380,2.5000; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_bot_ZN_3_Wall_North_Window, !- Name
+ Perimeter_bot_ZN_3_Wall_North, !- Building Surface Name
+ 73.1070,48.7381,2.5000, !- X,Y,Z ==> Vertex 1 {m}
+ 73.1070,48.7381,0.9146, !- X,Y,Z ==> Vertex 2 {m}
+ 0.0000,48.7381,0.9146, !- X,Y,Z ==> Vertex 3 {m}
+ 0.0000,48.7381,2.5000; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_bot_ZN_4_Wall_West_Window, !- Name
+ Perimeter_bot_ZN_4_Wall_West, !- Building Surface Name
+ 0.0000,48.7380,2.5000, !- X,Y,Z ==> Vertex 1 {m}
+ 0.0000,48.7380,0.9146, !- X,Y,Z ==> Vertex 2 {m}
+ 0.0000,0.0000,0.9146, !- X,Y,Z ==> Vertex 3 {m}
+ 0.0000,0.0000,2.5000; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_mid_ZN_1_Wall_South_Window, !- Name
+ Perimeter_mid_ZN_1_Wall_South, !- Building Surface Name
+ 0.0000,0.0000,22.3160, !- X,Y,Z ==> Vertex 1 {m}
+ 0.0000,0.0000,20.7306, !- X,Y,Z ==> Vertex 2 {m}
+ 73.1070,0.0000,20.7306, !- X,Y,Z ==> Vertex 3 {m}
+ 73.1070,0.0000,22.3160; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_mid_ZN_2_Wall_East_Window, !- Name
+ Perimeter_mid_ZN_2_Wall_East, !- Building Surface Name
+ 73.1072,0.0000,22.3160, !- X,Y,Z ==> Vertex 1 {m}
+ 73.1072,0.0000,20.7306, !- X,Y,Z ==> Vertex 2 {m}
+ 73.1072,48.7380,20.7306, !- X,Y,Z ==> Vertex 3 {m}
+ 73.1072,48.7380,22.3160; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_mid_ZN_3_Wall_North_Window, !- Name
+ Perimeter_mid_ZN_3_Wall_North, !- Building Surface Name
+ 73.1070,48.7381,22.3160, !- X,Y,Z ==> Vertex 1 {m}
+ 73.1070,48.7381,20.7306, !- X,Y,Z ==> Vertex 2 {m}
+ 0.0000,48.7381,20.7306, !- X,Y,Z ==> Vertex 3 {m}
+ 0.0000,48.7381,22.3160; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_mid_ZN_4_Wall_West_Window, !- Name
+ Perimeter_mid_ZN_4_Wall_West, !- Building Surface Name
+ 0.0000,48.7380,22.3160, !- X,Y,Z ==> Vertex 1 {m}
+ 0.0000,48.7380,20.7306, !- X,Y,Z ==> Vertex 2 {m}
+ 0.0000,0.0000,20.7306, !- X,Y,Z ==> Vertex 3 {m}
+ 0.0000,0.0000,22.3160; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_top_ZN_1_Wall_South_Window, !- Name
+ Perimeter_top_ZN_1_Wall_South, !- Building Surface Name
+ 0.0000,0.0000,46.0952, !- X,Y,Z ==> Vertex 1 {m}
+ 0.0000,0.0000,44.5098, !- X,Y,Z ==> Vertex 2 {m}
+ 73.1070,0.0000,44.5098, !- X,Y,Z ==> Vertex 3 {m}
+ 73.1070,0.0000,46.0952; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_top_ZN_2_Wall_East_Window, !- Name
+ Perimeter_top_ZN_2_Wall_East, !- Building Surface Name
+ 73.1072,0.0000,46.0952, !- X,Y,Z ==> Vertex 1 {m}
+ 73.1072,0.0000,44.5098, !- X,Y,Z ==> Vertex 2 {m}
+ 73.1072,48.7380,44.5098, !- X,Y,Z ==> Vertex 3 {m}
+ 73.1072,48.7380,46.0952; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_top_ZN_3_Wall_North_Window, !- Name
+ Perimeter_top_ZN_3_Wall_North, !- Building Surface Name
+ 73.1070,48.7381,46.0952, !- X,Y,Z ==> Vertex 1 {m}
+ 73.1070,48.7381,44.5098, !- X,Y,Z ==> Vertex 2 {m}
+ 0.0000,48.7381,44.5098, !- X,Y,Z ==> Vertex 3 {m}
+ 0.0000,48.7381,46.0952; !- X,Y,Z ==> Vertex 4 {m}
+ Perimeter_top_ZN_4_Wall_West_Window, !- Name
+ Perimeter_top_ZN_4_Wall_West, !- Building Surface Name
+ 0.0000,48.7380,46.0952, !- X,Y,Z ==> Vertex 1 {m}
+ 0.0000,48.7380,44.5098, !- X,Y,Z ==> Vertex 2 {m}
+ 0.0000,0.0000,44.5098, !- X,Y,Z ==> Vertex 3 {m}
+ 0.0000,0.0000,46.0952; !- X,Y,Z ==> Vertex 4 {m}
+! ***GEOMETRY RULES***
+ GlobalGeometryRules,
+ UpperLeftCorner, !- Starting Vertex Position
+ Counterclockwise, !- Vertex Entry Direction
+ Relative, !- Coordinate System
+ Relative; !- Daylighting Reference Point Coordinate System
+! ***PEOPLE***
+ People,
+ Basement People, !- Name
+ Basement, !- Zone or ZoneList Name
+ BLDG_OCC_SCH, !- Number of People Schedule Name
+ Area/Person, !- Number of People Calculation Method
+ , !- Number of People
+ , !- People per Zone Floor Area {person/m2}
+ 37.16, !- Zone Floor Area per Person {m2/person}
+ 0.3000, !- Fraction Radiant
+ AUTOCALCULATE, !- Sensible Heat Fraction
+ ACTIVITY_SCH, !- Activity Level Schedule Name
+ , !- Carbon Dioxide Generation Rate {m3/s-W}
+ No, !- Enable ASHRAE 55 Comfort Warnings
+ ZoneAveraged, !- Mean Radiant Temperature Calculation Type
+ , !- Surface Name/Angle Factor List Name
+ WORK_EFF_SCH, !- Work Efficiency Schedule Name
+ CLOTHING_SCH, !- Clothing Insulation Schedule Name
+ AIR_VELO_SCH, !- Air Velocity Schedule Name
+ FANGER; !- Thermal Comfort Model 1 Type
+ People,
+ Core_bottom People, !- Name
+ Core_bottom, !- Zone or ZoneList Name
+ 18.58, !- Zone Floor Area per Person {m2/person}
+ People,
+ Core_mid People, !- Name
+ Core_mid, !- Zone or ZoneList Name
+ People,
+ Core_top People, !- Name
+ Core_top, !- Zone or ZoneList Name
+ People,
+ Perimeter_bot_ZN_1 People, !- Name
+ Perimeter_bot_ZN_1, !- Zone or ZoneList Name
+ People,
+ Perimeter_bot_ZN_2 People, !- Name
+ Perimeter_bot_ZN_2, !- Zone or ZoneList Name
+ People,
+ Perimeter_bot_ZN_3 People, !- Name
+ Perimeter_bot_ZN_3, !- Zone or ZoneList Name
+ People,
+ Perimeter_bot_ZN_4 People, !- Name
+ Perimeter_bot_ZN_4, !- Zone or ZoneList Name
+ People,
+ Perimeter_mid_ZN_1 People, !- Name
+ Perimeter_mid_ZN_1, !- Zone or ZoneList Name
+ People,
+ Perimeter_mid_ZN_2 People, !- Name
+ Perimeter_mid_ZN_2, !- Zone or ZoneList Name
+ People,
+ Perimeter_mid_ZN_3 People, !- Name
+ Perimeter_mid_ZN_3, !- Zone or ZoneList Name
+ People,
+ Perimeter_mid_ZN_4 People, !- Name
+ Perimeter_mid_ZN_4, !- Zone or ZoneList Name
+ People,
+ Perimeter_top_ZN_1 People, !- Name
+ Perimeter_top_ZN_1, !- Zone or ZoneList Name
+ People,
+ Perimeter_top_ZN_2 People, !- Name
+ Perimeter_top_ZN_2, !- Zone or ZoneList Name
+ People,
+ Perimeter_top_ZN_3 People, !- Name
+ Perimeter_top_ZN_3, !- Zone or ZoneList Name
+ People,
+ Perimeter_top_ZN_4 People, !- Name
+ Perimeter_top_ZN_4, !- Zone or ZoneList Name
+! ***LIGHTS***
+ Lights,
+ Basement_Lights, !- Name
+ BLDG_LIGHT_SCH, !- Schedule Name
+ Watts/Area, !- Design Level Calculation Method
+ , !- Lighting Level {W}
+ 10.76, !- Watts per Zone Floor Area {W/m2}
+ , !- Watts per Person {W/person}
+ 0.0000, !- Return Air Fraction
+ 0.7000, !- Fraction Radiant
+ 0.2000, !- Fraction Visible
+ 1.0000, !- Fraction Replaceable
+ General, !- End-Use Subcategory
+ No; !- Return Air Fraction Calculated from Plenum Temperature
+ Lights,
+ Core_bottom_Lights, !- Name
+ Lights,
+ Core_mid_Lights, !- Name
+ Lights,
+ Core_top_Lights, !- Name
+ Lights,
+ Perimeter_bot_ZN_1_Lights, !- Name
+ Lights,
+ Perimeter_bot_ZN_2_Lights, !- Name
+ Lights,
+ Perimeter_bot_ZN_3_Lights, !- Name
+ Lights,
+ Perimeter_bot_ZN_4_Lights, !- Name
+ Lights,
+ Perimeter_mid_ZN_1_Lights, !- Name
+ Lights,
+ Perimeter_mid_ZN_2_Lights, !- Name
+ Lights,
+ Perimeter_mid_ZN_3_Lights, !- Name
+ Lights,
+ Perimeter_mid_ZN_4_Lights, !- Name
+ Lights,
+ Perimeter_top_ZN_1_Lights, !- Name
+ Lights,
+ Perimeter_top_ZN_2_Lights, !- Name
+ Lights,
+ Perimeter_top_ZN_3_Lights, !- Name
+ Lights,
+ Perimeter_top_ZN_4_Lights, !- Name
+! ***EQUIPMENT GAINS***
+ ElectricEquipment,
+ Basement_PlugMisc_Equip, !- Name
+ BLDG_EQUIP_SCH, !- Schedule Name
+ , !- Design Level {W}
+ 0.0000, !- Fraction Latent
+ 0.5000, !- Fraction Radiant
+ 0.0000, !- Fraction Lost
+ General; !- End-Use Subcategory
+ Core_bottom_PlugMisc_Equip, !- Name
+ Core_mid_PlugMisc_Equip, !- Name
+ Core_top_PlugMisc_Equip, !- Name
+ Perimeter_bot_ZN_1_PlugMisc_Equip, !- Name
+ Perimeter_bot_ZN_2_PlugMisc_Equip, !- Name
+ Perimeter_bot_ZN_3_PlugMisc_Equip, !- Name
+ Perimeter_bot_ZN_4_PlugMisc_Equip, !- Name
+ Perimeter_mid_ZN_1_PlugMisc_Equip, !- Name
+ Perimeter_mid_ZN_2_PlugMisc_Equip, !- Name
+ Perimeter_mid_ZN_3_PlugMisc_Equip, !- Name
+ Perimeter_mid_ZN_4_PlugMisc_Equip, !- Name
+ Perimeter_top_ZN_1_PlugMisc_Equip, !- Name
+ Perimeter_top_ZN_2_PlugMisc_Equip, !- Name
+ Perimeter_top_ZN_3_PlugMisc_Equip, !- Name
+ Perimeter_top_ZN_4_PlugMisc_Equip, !- Name
+! ***EXTERIOR LOADS***
+ Exterior:Lights,
+ Exterior Facade Lighting,!- Name
+ ALWAYS_ON, !- Schedule Name
+ 51262, !- Design Level {W}
+ AstronomicalClock, !- Control Option
+ Exterior Facade Lighting;!- End-Use Subcategory
+ Exterior:FuelEquipment,
+ Elevators, !- Name
+ Electricity, !- Fuel Use Type
+ BLDG_ELEVATORS, !- Schedule Name
+ 244443.956043956, !- Design Level {W}
+ Elevators; !- End-Use Subcategory
+! ***INFILTRATION***
+ ZoneInfiltration:DesignFlowRate,
+ GroundFloor_Plenum_Infiltration, !- Name
+ GroundFloor_Plenum, !- Zone or ZoneList Name
+ INFIL_QUARTER_ON_SCH, !- Schedule Name
+ Flow/ExteriorArea, !- Design Flow Rate Calculation Method
+ , !- Design Flow Rate {m3/s}
+ , !- Flow per Zone Floor Area {m3/s-m2}
+ 0.000302, !- Flow per Exterior Surface Area {m3/s-m2}
+ , !- Air Changes per Hour {1/hr}
+ 1.0000, !- Constant Term Coefficient
+ 0.0000, !- Temperature Term Coefficient
+ 0.0000, !- Velocity Term Coefficient
+ 0.0000; !- Velocity Squared Term Coefficient
+ MidFloor_Plenum_Infiltration, !- Name
+ MidFloor_Plenum, !- Zone or ZoneList Name
+ Perimeter_bot_ZN_1_Infiltration, !- Name
+ Perimeter_bot_ZN_2_Infiltration, !- Name
+ Perimeter_bot_ZN_3_Infiltration, !- Name
+ Perimeter_bot_ZN_4_Infiltration, !- Name
+ Perimeter_mid_ZN_1_Infiltration, !- Name
+ Perimeter_mid_ZN_2_Infiltration, !- Name
+ Perimeter_mid_ZN_3_Infiltration, !- Name
+ Perimeter_mid_ZN_4_Infiltration, !- Name
+ Perimeter_top_ZN_1_Infiltration, !- Name
+ Perimeter_top_ZN_2_Infiltration, !- Name
+ Perimeter_top_ZN_3_Infiltration, !- Name
+ Perimeter_top_ZN_4_Infiltration, !- Name
+ TopFloor_Plenum_Infiltration, !- Name
+ TopFloor_Plenum, !- Zone or ZoneList Name
+! ***INTERNAL MASS***
+ InternalMass,
+ Basement Internal Mass, !- Name
+ InteriorFurnishings, !- Construction Name
+ 7126.2120; !- Surface Area {m2}
+ InternalMass,
+ Core_bottom Internal Mass, !- Name
+ 5064.6464; !- Surface Area {m2}
+ InternalMass,
+ Core_mid Internal Mass, !- Name
+ InternalMass,
+ Core_top Internal Mass, !- Name
+ InternalMass,
+ Perimeter_bot_ZN_1 Internal Mass, !- Name
+ 626.8394; !- Surface Area {m2}
+ InternalMass,
+ Perimeter_bot_ZN_2 Internal Mass, !- Name
+ 403.9503; !- Surface Area {m2}
+ InternalMass,
+ Perimeter_bot_ZN_3 Internal Mass, !- Name
+ 626.8257; !- Surface Area {m2}
+ InternalMass,
+ Perimeter_bot_ZN_4 Internal Mass, !- Name
+ InternalMass,
+ Perimeter_mid_ZN_1 Internal Mass, !- Name
+ InternalMass,
+ Perimeter_mid_ZN_2 Internal Mass, !- Name
+ InternalMass,
+ Perimeter_mid_ZN_3 Internal Mass, !- Name
+ InternalMass,
+ Perimeter_mid_ZN_4 Internal Mass, !- Name
+ InternalMass,
+ Perimeter_top_ZN_1 Internal Mass, !- Name
+ InternalMass,
+ Perimeter_top_ZN_2 Internal Mass, !- Name
+ InternalMass,
+ Perimeter_top_ZN_3 Internal Mass, !- Name
+ InternalMass,
+ Perimeter_top_ZN_4 Internal Mass, !- Name
+! ***INTERNAL GAINS SCHEDULES***
+ Schedule:Compact,
+ BLDG_ELEVATORS, !- Name
+ Fraction, !- Schedule Type Limits Name
+ Until: 04:00,0.05, !- Field 3
+ Until: 05:00,0.10, !- Field 5
+ Until: 06:00,0.20, !- Field 7
+ Until: 07:00,0.40, !- Field 9
+ Until: 09:00,0.50, !- Field 11
+ Until: 10:00,0.35, !- Field 13
+ Until: 16:00,0.15, !- Field 15
+ Until: 17:00,0.35, !- Field 17
+ Until: 19:00,0.50, !- Field 19
+ Until: 21:00,0.40, !- Field 21
+ Until: 22:00,0.30, !- Field 23
+ Until: 23:00,0.20, !- Field 25
+ Until: 24:00,0.10; !- Field 27
+ Schedule:Compact,
+ INFIL_QUARTER_ON_SCH, !- Name
+ For: Weekdays SummerDesignDay, !- Field 2
+ Until: 06:00,1.0, !- Field 3
+ Until: 22:00,0.25, !- Field 5
+ Until: 24:00,1.0, !- Field 7
+ For: Saturday WinterDesignDay, !- Field 9
+ Until: 06:00,1.0, !- Field 10
+ Until: 18:00,0.25, !- Field 12
+ Until: 24:00,1.0, !- Field 14
+ For: Sunday Holidays AllOtherDays, !- Field 16
+ Until: 24:00,1.0; !- Field 17
+ Schedule:Compact,
+ BLDG_OCC_SCH, !- Name
+ For: SummerDesignDay, !- Field 2
+ Until: 06:00,0.0, !- Field 3
+ Until: 22:00,1.0, !- Field 5
+ Until: 24:00,0.05, !- Field 7
+ For: Weekdays, !- Field 9
+ Until: 06:00,0.0, !- Field 10
+ Until: 07:00,0.1, !- Field 12
+ Until: 08:00,0.2, !- Field 14
+ Until: 12:00,0.95, !- Field 16
+ Until: 13:00,0.5, !- Field 18
+ Until: 17:00,0.95, !- Field 20
+ Until: 18:00,0.7, !- Field 22
+ Until: 20:00,0.4, !- Field 24
+ Until: 22:00,0.1, !- Field 26
+ Until: 24:00,0.05, !- Field 28
+ For: Saturday, !- Field 30
+ Until: 06:00,0.0, !- Field 31
+ Until: 08:00,0.1, !- Field 33
+ Until: 14:00,0.5, !- Field 35
+ Until: 17:00,0.1, !- Field 37
+ Until: 24:00,0.0, !- Field 39
+ For: AllOtherDays, !- Field 41
+ Until: 24:00,0.0; !- Field 42
+ Schedule:Compact,
+ BLDG_LIGHT_SCH, !- Name
+ For: Weekdays, !- Field 2
+ Until: 05:00,0.05, !- Field 3
+ Until: 07:00,0.1, !- Field 5
+ Until: 08:00,0.3, !- Field 7
+ Until: 17:00,0.9, !- Field 9
+ Until: 18:00,0.7, !- Field 11
+ Until: 20:00,0.5, !- Field 13
+ Until: 22:00,0.3, !- Field 15
+ Until: 23:00,0.1, !- Field 17
+ Until: 24:00,0.05, !- Field 19
+ For: Saturday, !- Field 21
+ Until: 06:00,0.05, !- Field 22
+ Until: 08:00,0.1, !- Field 24
+ Until: 14:00,0.5, !- Field 26
+ Until: 17:00,0.15, !- Field 28
+ Until: 24:00,0.05, !- Field 30
+ For: SummerDesignDay, !- Field 32
+ Until: 24:00,1.0, !- Field 33
+ For: WinterDesignDay, !- Field 35
+ Until: 24:00,0.0, !- Field 36
+ For: AllOtherDays, !- Field 38
+ Until: 24:00,0.05; !- Field 39
+ Schedule:Compact,
+ BLDG_EQUIP_SCH, !- Name
+ Until: 08:00,0.40, !- Field 3
+ Until: 12:00,0.90, !- Field 5
+ Until: 13:00,0.80, !- Field 7
+ Until: 17:00,0.90, !- Field 9
+ Until: 18:00,0.80, !- Field 11
+ Until: 20:00,0.60, !- Field 13
+ Until: 22:00,0.50, !- Field 15
+ Until: 24:00,0.40, !- Field 17
+ For: Saturday, !- Field 19
+ Until: 06:00,0.30, !- Field 20
+ Until: 08:00,0.4, !- Field 22
+ Until: 14:00,0.5, !- Field 24
+ Until: 17:00,0.35, !- Field 26
+ Until: 24:00,0.30, !- Field 28
+ For: SummerDesignDay, !- Field 30
+ Until: 24:00,1.0, !- Field 31
+ For: WinterDesignDay, !- Field 33
+ Until: 24:00,0.0, !- Field 34
+ For: AllOtherDays, !- Field 36
+ Until: 24:00,0.30; !- Field 37
+ Schedule:Compact,
+ ACTIVITY_SCH, !- Name
+ Any Number, !- Schedule Type Limits Name
+ Until: 24:00,120; !- Field 3
+ Schedule:Compact,
+ WORK_EFF_SCH, !- Name
+ Until: 24:00,0.0; !- Field 3
+ Schedule:Compact,
+ AIR_VELO_SCH, !- Name
+ Until: 24:00,0.2; !- Field 3
+ Schedule:Compact,
+ CLOTHING_SCH, !- Name
+ Through: 04/30, !- Field 1
+ Through: 09/30, !- Field 5
+ For: AllDays, !- Field 6
+ Until: 24:00,0.5, !- Field 7
+ Through: 12/31, !- Field 9
+ For: AllDays, !- Field 10
+ Until: 24:00,1.0; !- Field 11
+! ***HVAC EQUIPMENT***
+ Fan:VariableVolume,
+ VAV_1_Fan, !- Name
+ HVACOperationSchd, !- Availability Schedule Name
+ 0.6045, !- Fan Efficiency
+ 1017.592, !- Pressure Rise {Pa}
+ AUTOSIZE, !- Maximum Flow Rate {m3/s}
+ FixedFlowRate, !- Fan Power Minimum Flow Rate Input Method
+ , !- Fan Power Minimum Flow Fraction
+ 0.0000, !- Fan Power Minimum Air Flow Rate {m3/s}
+ 0.93, !- Motor Efficiency
+ 1.0, !- Motor In Airstream Fraction
+ 0.0407598940, !- Fan Power Coefficient 1
+ 0.08804497, !- Fan Power Coefficient 2
+ -0.072926120, !- Fan Power Coefficient 3
+ 0.9437398230, !- Fan Power Coefficient 4
+ 0, !- Fan Power Coefficient 5
+ VAV_1_HeatC-VAV_1_FanNode, !- Air Inlet Node Name
+ VAV_1 Supply Equipment Outlet Node, !- Air Outlet Node Name
+ Fan Energy; !- End-Use Subcategory
+ VAV_2_Fan, !- Name
+ 0.6175, !- Fan Efficiency
+ 0.95, !- Motor Efficiency
+ VAV_2_HeatC-VAV_2_FanNode, !- Air Inlet Node Name
+ VAV_2 Supply Equipment Outlet Node, !- Air Outlet Node Name
+ VAV_3_Fan, !- Name
+ VAV_3_HeatC-VAV_3_FanNode, !- Air Inlet Node Name
+ VAV_3 Supply Equipment Outlet Node, !- Air Outlet Node Name
+ VAV_5_Fan, !- Name
+ 0.5915, !- Fan Efficiency
+ 1109.648, !- Pressure Rise {Pa}
+ 0.91, !- Motor Efficiency
+ VAV_5_HeatC-VAV_5_FanNode, !- Air Inlet Node Name
+ VAV_5 Supply Equipment Outlet Node, !- Air Outlet Node Name
+ Coil:Heating:Water,
+ Basement VAV Box Reheat Coil, !- Name
+ ALWAYS_ON, !- Availability Schedule Name
+ AUTOSIZE, !- U-Factor Times Area Value {W/K}
+ AUTOSIZE, !- Maximum Water Flow Rate {m3/s}
+ Basement VAV Box Reheat CoilDemand Inlet Node, !- Water Inlet Node Name
+ Basement VAV Box Reheat CoilDemand Outlet Node, !- Water Outlet Node Name
+ Basement VAV Box Damper Node, !- Air Inlet Node Name
+ Basement VAV Box Outlet Node Name, !- Air Outlet Node Name
+ UFactorTimesAreaAndDesignWaterFlowRate, !- Performance Input Method
+ AUTOSIZE, !- Rated Capacity {W}
+ 82.2, !- Rated Inlet Water Temperature {C}
+ 16.6, !- Rated Inlet Air Temperature {C}
+ 71.1, !- Rated Outlet Water Temperature {C}
+ 32.2, !- Rated Outlet Air Temperature {C}
+ ; !- Rated Ratio for Air and Water Convection
+ Core_bottom VAV Box Reheat Coil, !- Name
+ Core_bottom VAV Box Reheat CoilDemand Inlet Node, !- Water Inlet Node Name
+ Core_bottom VAV Box Reheat CoilDemand Outlet Node, !- Water Outlet Node Name
+ Core_bottom VAV Box Damper Node, !- Air Inlet Node Name
+ Core_bottom VAV Box Outlet Node Name, !- Air Outlet Node Name
+ Core_mid VAV Box Reheat Coil, !- Name
+ Core_mid VAV Box Reheat CoilDemand Inlet Node, !- Water Inlet Node Name
+ Core_mid VAV Box Reheat CoilDemand Outlet Node, !- Water Outlet Node Name
+ Core_mid VAV Box Damper Node, !- Air Inlet Node Name
+ Core_mid VAV Box Outlet Node Name, !- Air Outlet Node Name
+ Core_top VAV Box Reheat Coil, !- Name
+ Core_top VAV Box Reheat CoilDemand Inlet Node, !- Water Inlet Node Name
+ Core_top VAV Box Reheat CoilDemand Outlet Node, !- Water Outlet Node Name
+ Core_top VAV Box Damper Node, !- Air Inlet Node Name
+ Core_top VAV Box Outlet Node Name, !- Air Outlet Node Name
+ Perimeter_bot_ZN_1 VAV Box Reheat Coil, !- Name
+ Perimeter_bot_ZN_1 VAV Box Reheat CoilDemand Inlet Node, !- Water Inlet Node Name
+ Perimeter_bot_ZN_1 VAV Box Reheat CoilDemand Outlet Node, !- Water Outlet Node Name
+ Perimeter_bot_ZN_1 VAV Box Damper Node, !- Air Inlet Node Name
+ Perimeter_bot_ZN_1 VAV Box Outlet Node Name, !- Air Outlet Node Name
+ Perimeter_bot_ZN_2 VAV Box Reheat Coil, !- Name
+ Perimeter_bot_ZN_2 VAV Box Reheat CoilDemand Inlet Node, !- Water Inlet Node Name
+ Perimeter_bot_ZN_2 VAV Box Reheat CoilDemand Outlet Node, !- Water Outlet Node Name
+ Perimeter_bot_ZN_2 VAV Box Damper Node, !- Air Inlet Node Name
+ Perimeter_bot_ZN_2 VAV Box Outlet Node Name, !- Air Outlet Node Name
+ Perimeter_bot_ZN_3 VAV Box Reheat Coil, !- Name
+ Perimeter_bot_ZN_3 VAV Box Reheat CoilDemand Inlet Node, !- Water Inlet Node Name
+ Perimeter_bot_ZN_3 VAV Box Reheat CoilDemand Outlet Node, !- Water Outlet Node Name
+ Perimeter_bot_ZN_3 VAV Box Damper Node, !- Air Inlet Node Name
+ Perimeter_bot_ZN_3 VAV Box Outlet Node Name, !- Air Outlet Node Name
+ Perimeter_bot_ZN_4 VAV Box Reheat Coil, !- Name
+ Perimeter_bot_ZN_4 VAV Box Reheat CoilDemand Inlet Node, !- Water Inlet Node Name
+ Perimeter_bot_ZN_4 VAV Box Reheat CoilDemand Outlet Node, !- Water Outlet Node Name
+ Perimeter_bot_ZN_4 VAV Box Damper Node, !- Air Inlet Node Name
+ Perimeter_bot_ZN_4 VAV Box Outlet Node Name, !- Air Outlet Node Name
+ Perimeter_mid_ZN_1 VAV Box Reheat Coil, !- Name
+ Perimeter_mid_ZN_1 VAV Box Reheat CoilDemand Inlet Node, !- Water Inlet Node Name
+ Perimeter_mid_ZN_1 VAV Box Reheat CoilDemand Outlet Node, !- Water Outlet Node Name
+ Perimeter_mid_ZN_1 VAV Box Damper Node, !- Air Inlet Node Name
+ Perimeter_mid_ZN_1 VAV Box Outlet Node Name, !- Air Outlet Node Name
+ Perimeter_mid_ZN_2 VAV Box Reheat Coil, !- Name
+ Perimeter_mid_ZN_2 VAV Box Reheat CoilDemand Inlet Node, !- Water Inlet Node Name
+ Perimeter_mid_ZN_2 VAV Box Reheat CoilDemand Outlet Node, !- Water Outlet Node Name
+ Perimeter_mid_ZN_2 VAV Box Damper Node, !- Air Inlet Node Name
+ Perimeter_mid_ZN_2 VAV Box Outlet Node Name, !- Air Outlet Node Name
+ Perimeter_mid_ZN_3 VAV Box Reheat Coil, !- Name
+ Perimeter_mid_ZN_3 VAV Box Reheat CoilDemand Inlet Node, !- Water Inlet Node Name
+ Perimeter_mid_ZN_3 VAV Box Reheat CoilDemand Outlet Node, !- Water Outlet Node Name
+ Perimeter_mid_ZN_3 VAV Box Damper Node, !- Air Inlet Node Name
+ Perimeter_mid_ZN_3 VAV Box Outlet Node Name, !- Air Outlet Node Name
+ Perimeter_mid_ZN_4 VAV Box Reheat Coil, !- Name
+ Perimeter_mid_ZN_4 VAV Box Reheat CoilDemand Inlet Node, !- Water Inlet Node Name
+ Perimeter_mid_ZN_4 VAV Box Reheat CoilDemand Outlet Node, !- Water Outlet Node Name
+ Perimeter_mid_ZN_4 VAV Box Damper Node, !- Air Inlet Node Name
+ Perimeter_mid_ZN_4 VAV Box Outlet Node Name, !- Air Outlet Node Name
+ Perimeter_top_ZN_1 VAV Box Reheat Coil, !- Name
+ Perimeter_top_ZN_1 VAV Box Reheat CoilDemand Inlet Node, !- Water Inlet Node Name
+ Perimeter_top_ZN_1 VAV Box Reheat CoilDemand Outlet Node, !- Water Outlet Node Name
+ Perimeter_top_ZN_1 VAV Box Damper Node, !- Air Inlet Node Name
+ Perimeter_top_ZN_1 VAV Box Outlet Node Name, !- Air Outlet Node Name
+ Perimeter_top_ZN_2 VAV Box Reheat Coil, !- Name
+ Perimeter_top_ZN_2 VAV Box Reheat CoilDemand Inlet Node, !- Water Inlet Node Name
+ Perimeter_top_ZN_2 VAV Box Reheat CoilDemand Outlet Node, !- Water Outlet Node Name
+ Perimeter_top_ZN_2 VAV Box Damper Node, !- Air Inlet Node Name
+ Perimeter_top_ZN_2 VAV Box Outlet Node Name, !- Air Outlet Node Name
+ Perimeter_top_ZN_3 VAV Box Reheat Coil, !- Name
+ Perimeter_top_ZN_3 VAV Box Reheat CoilDemand Inlet Node, !- Water Inlet Node Name
+ Perimeter_top_ZN_3 VAV Box Reheat CoilDemand Outlet Node, !- Water Outlet Node Name
+ Perimeter_top_ZN_3 VAV Box Damper Node, !- Air Inlet Node Name
+ Perimeter_top_ZN_3 VAV Box Outlet Node Name, !- Air Outlet Node Name
+ Perimeter_top_ZN_4 VAV Box Reheat Coil, !- Name
+ Perimeter_top_ZN_4 VAV Box Reheat CoilDemand Inlet Node, !- Water Inlet Node Name
+ Perimeter_top_ZN_4 VAV Box Reheat CoilDemand Outlet Node, !- Water Outlet Node Name
+ Perimeter_top_ZN_4 VAV Box Damper Node, !- Air Inlet Node Name
+ Perimeter_top_ZN_4 VAV Box Outlet Node Name, !- Air Outlet Node Name
+ VAV_1_HeatC, !- Name
+ VAV_1_HeatCDemand Inlet Node, !- Water Inlet Node Name
+ VAV_1_HeatCDemand Outlet Node, !- Water Outlet Node Name
+ VAV_1_CoolC-VAV_1_HeatCNode, !- Air Inlet Node Name
+ VAV_1_HeatC-VAV_1_FanNode, !- Air Outlet Node Name
+ VAV_2_HeatC, !- Name
+ VAV_2_HeatCDemand Inlet Node, !- Water Inlet Node Name
+ VAV_2_HeatCDemand Outlet Node, !- Water Outlet Node Name
+ VAV_2_CoolC-VAV_2_HeatCNode, !- Air Inlet Node Name
+ VAV_2_HeatC-VAV_2_FanNode, !- Air Outlet Node Name
+ VAV_3_HeatC, !- Name
+ VAV_3_HeatCDemand Inlet Node, !- Water Inlet Node Name
+ VAV_3_HeatCDemand Outlet Node, !- Water Outlet Node Name
+ VAV_3_CoolC-VAV_3_HeatCNode, !- Air Inlet Node Name
+ VAV_3_HeatC-VAV_3_FanNode, !- Air Outlet Node Name
+ VAV_5_HeatC, !- Name
+ VAV_5_HeatCDemand Inlet Node, !- Water Inlet Node Name
+ VAV_5_HeatCDemand Outlet Node, !- Water Outlet Node Name
+ VAV_5_CoolC-VAV_5_HeatCNode, !- Air Inlet Node Name
+ VAV_5_HeatC-VAV_5_FanNode, !- Air Outlet Node Name
+ Coil:Cooling:Water,
+ VAV_3_CoolC, !- Name
+ AUTOSIZE, !- Design Water Flow Rate {m3/s}
+ AUTOSIZE, !- Design Air Flow Rate {m3/s}
+ AUTOSIZE, !- Design Inlet Water Temperature {C}
+ AUTOSIZE, !- Design Inlet Air Temperature {C}
+ AUTOSIZE, !- Design Outlet Air Temperature {C}
+ AUTOSIZE, !- Design Inlet Air Humidity Ratio {kgWater/kgDryAir}
+ AUTOSIZE, !- Design Outlet Air Humidity Ratio {kgWater/kgDryAir}
+ VAV_3_CoolCDemand Inlet Node, !- Water Inlet Node Name
+ VAV_3_CoolCDemand Outlet Node, !- Water Outlet Node Name
+ VAV_3_OA-VAV_3_CoolCNode,!- Air Inlet Node Name
+ VAV_3_CoolC-VAV_3_HeatCNode, !- Air Outlet Node Name
+ SimpleAnalysis, !- Type of Analysis
+ CrossFlow; !- Heat Exchanger Configuration
+ VAV_2_CoolC, !- Name
+ VAV_2_CoolCDemand Inlet Node, !- Water Inlet Node Name
+ VAV_2_CoolCDemand Outlet Node, !- Water Outlet Node Name
+ VAV_2_OA-VAV_2_CoolCNode,!- Air Inlet Node Name
+ VAV_2_CoolC-VAV_2_HeatCNode, !- Air Outlet Node Name
+ VAV_1_CoolC, !- Name
+ VAV_1_CoolCDemand Inlet Node, !- Water Inlet Node Name
+ VAV_1_CoolCDemand Outlet Node, !- Water Outlet Node Name
+ VAV_1_OA-VAV_1_CoolCNode,!- Air Inlet Node Name
+ VAV_1_CoolC-VAV_1_HeatCNode, !- Air Outlet Node Name
+ VAV_5_CoolC, !- Name
+ VAV_5_CoolCDemand Inlet Node, !- Water Inlet Node Name
+ VAV_5_CoolCDemand Outlet Node, !- Water Outlet Node Name
+ VAV_5_OA-VAV_5_CoolCNode,!- Air Inlet Node Name
+ VAV_5_CoolC-VAV_5_HeatCNode, !- Air Outlet Node Name
+ AirTerminal:SingleDuct:VAV:Reheat,
+ Basement VAV Box Component, !- Name
+ Basement VAV Box Damper Node, !- Damper Air Outlet Node Name
+ Basement VAV Box Inlet Node Name, !- Air Inlet Node Name
+ AUTOSIZE, !- Maximum Air Flow Rate {m3/s}
+ Constant, !- Zone Minimum Air Flow Input Method
+ 0.3, !- Constant Minimum Air Flow Fraction
+ , !- Fixed Minimum Air Flow Rate {m3/s}
+ , !- Minimum Air Flow Fraction Schedule Name
+ Coil:Heating:Water, !- Reheat Coil Object Type
+ Basement VAV Box Reheat Coil, !- Reheat Coil Name
+ AUTOSIZE, !- Maximum Hot Water or Steam Flow Rate {m3/s}
+ 0.0, !- Minimum Hot Water or Steam Flow Rate {m3/s}
+ 0.001, !- Convergence Tolerance
+ NORMAL; !- Damper Heating Action
+ Core_bottom VAV Box Component, !- Name
+ Core_bottom VAV Box Damper Node, !- Damper Air Outlet Node Name
+ Core_bottom VAV Box Inlet Node Name, !- Air Inlet Node Name
+ Core_bottom VAV Box Reheat Coil, !- Reheat Coil Name
+ Core_mid VAV Box Component, !- Name
+ Core_mid VAV Box Damper Node, !- Damper Air Outlet Node Name
+ Core_mid VAV Box Inlet Node Name, !- Air Inlet Node Name
+ Core_mid VAV Box Reheat Coil, !- Reheat Coil Name
+ Core_top VAV Box Component, !- Name
+ Core_top VAV Box Damper Node, !- Damper Air Outlet Node Name
+ Core_top VAV Box Inlet Node Name, !- Air Inlet Node Name
+ Core_top VAV Box Reheat Coil, !- Reheat Coil Name
+ Perimeter_bot_ZN_1 VAV Box Component, !- Name
+ Perimeter_bot_ZN_1 VAV Box Damper Node, !- Damper Air Outlet Node Name
+ Perimeter_bot_ZN_1 VAV Box Inlet Node Name, !- Air Inlet Node Name
+ Perimeter_bot_ZN_1 VAV Box Reheat Coil, !- Reheat Coil Name
+ Perimeter_bot_ZN_2 VAV Box Component, !- Name
+ Perimeter_bot_ZN_2 VAV Box Damper Node, !- Damper Air Outlet Node Name
+ Perimeter_bot_ZN_2 VAV Box Inlet Node Name, !- Air Inlet Node Name
+ Perimeter_bot_ZN_2 VAV Box Reheat Coil, !- Reheat Coil Name
+ Perimeter_bot_ZN_3 VAV Box Component, !- Name
+ Perimeter_bot_ZN_3 VAV Box Damper Node, !- Damper Air Outlet Node Name
+ Perimeter_bot_ZN_3 VAV Box Inlet Node Name, !- Air Inlet Node Name
+ Perimeter_bot_ZN_3 VAV Box Reheat Coil, !- Reheat Coil Name
+ Perimeter_bot_ZN_4 VAV Box Component, !- Name
+ Perimeter_bot_ZN_4 VAV Box Damper Node, !- Damper Air Outlet Node Name
+ Perimeter_bot_ZN_4 VAV Box Inlet Node Name, !- Air Inlet Node Name
+ Perimeter_bot_ZN_4 VAV Box Reheat Coil, !- Reheat Coil Name
+ Perimeter_mid_ZN_1 VAV Box Component, !- Name
+ Perimeter_mid_ZN_1 VAV Box Damper Node, !- Damper Air Outlet Node Name
+ Perimeter_mid_ZN_1 VAV Box Inlet Node Name, !- Air Inlet Node Name
+ Perimeter_mid_ZN_1 VAV Box Reheat Coil, !- Reheat Coil Name
+ Perimeter_mid_ZN_2 VAV Box Component, !- Name
+ Perimeter_mid_ZN_2 VAV Box Damper Node, !- Damper Air Outlet Node Name
+ Perimeter_mid_ZN_2 VAV Box Inlet Node Name, !- Air Inlet Node Name
+ Perimeter_mid_ZN_2 VAV Box Reheat Coil, !- Reheat Coil Name
+ Perimeter_mid_ZN_3 VAV Box Component, !- Name
+ Perimeter_mid_ZN_3 VAV Box Damper Node, !- Damper Air Outlet Node Name
+ Perimeter_mid_ZN_3 VAV Box Inlet Node Name, !- Air Inlet Node Name
+ Perimeter_mid_ZN_3 VAV Box Reheat Coil, !- Reheat Coil Name
+ Perimeter_mid_ZN_4 VAV Box Component, !- Name
+ Perimeter_mid_ZN_4 VAV Box Damper Node, !- Damper Air Outlet Node Name
+ Perimeter_mid_ZN_4 VAV Box Inlet Node Name, !- Air Inlet Node Name
+ Perimeter_mid_ZN_4 VAV Box Reheat Coil, !- Reheat Coil Name
+ Perimeter_top_ZN_1 VAV Box Component, !- Name
+ Perimeter_top_ZN_1 VAV Box Damper Node, !- Damper Air Outlet Node Name
+ Perimeter_top_ZN_1 VAV Box Inlet Node Name, !- Air Inlet Node Name
+ Perimeter_top_ZN_1 VAV Box Reheat Coil, !- Reheat Coil Name
+ Perimeter_top_ZN_2 VAV Box Component, !- Name
+ Perimeter_top_ZN_2 VAV Box Damper Node, !- Damper Air Outlet Node Name
+ Perimeter_top_ZN_2 VAV Box Inlet Node Name, !- Air Inlet Node Name
+ Perimeter_top_ZN_2 VAV Box Reheat Coil, !- Reheat Coil Name
+ Perimeter_top_ZN_3 VAV Box Component, !- Name
+ Perimeter_top_ZN_3 VAV Box Damper Node, !- Damper Air Outlet Node Name
+ Perimeter_top_ZN_3 VAV Box Inlet Node Name, !- Air Inlet Node Name
+ Perimeter_top_ZN_3 VAV Box Reheat Coil, !- Reheat Coil Name
+ Perimeter_top_ZN_4 VAV Box Component, !- Name
+ Perimeter_top_ZN_4 VAV Box Damper Node, !- Damper Air Outlet Node Name
+ Perimeter_top_ZN_4 VAV Box Inlet Node Name, !- Air Inlet Node Name
+ Perimeter_top_ZN_4 VAV Box Reheat Coil, !- Reheat Coil Name
+ ZoneHVAC:EquipmentList,
+ Basement Equipment, !- Name
+ ZoneHVAC:AirDistributionUnit, !- Zone Equipment 1 Object Type
+ Basement VAV Box, !- Zone Equipment 1 Name
+ 1, !- Zone Equipment 1 Cooling Sequence
+ 1; !- Zone Equipment 1 Heating or No-Load Sequence
+ Core_bottom Equipment, !- Name
+ Core_bottom VAV Box, !- Zone Equipment 1 Name
+ Core_mid Equipment, !- Name
+ Core_mid VAV Box, !- Zone Equipment 1 Name
+ Core_top Equipment, !- Name
+ Core_top VAV Box, !- Zone Equipment 1 Name
+ Perimeter_bot_ZN_1 Equipment, !- Name
+ Perimeter_bot_ZN_1 VAV Box, !- Zone Equipment 1 Name
+ Perimeter_bot_ZN_2 Equipment, !- Name
+ Perimeter_bot_ZN_2 VAV Box, !- Zone Equipment 1 Name
+ Perimeter_bot_ZN_3 Equipment, !- Name
+ Perimeter_bot_ZN_3 VAV Box, !- Zone Equipment 1 Name
+ Perimeter_bot_ZN_4 Equipment, !- Name
+ Perimeter_bot_ZN_4 VAV Box, !- Zone Equipment 1 Name
+ Perimeter_mid_ZN_1 Equipment, !- Name
+ Perimeter_mid_ZN_1 VAV Box, !- Zone Equipment 1 Name
+ Perimeter_mid_ZN_2 Equipment, !- Name
+ Perimeter_mid_ZN_2 VAV Box, !- Zone Equipment 1 Name
+ Perimeter_mid_ZN_3 Equipment, !- Name
+ Perimeter_mid_ZN_3 VAV Box, !- Zone Equipment 1 Name
+ Perimeter_mid_ZN_4 Equipment, !- Name
+ Perimeter_mid_ZN_4 VAV Box, !- Zone Equipment 1 Name
+ Perimeter_top_ZN_1 Equipment, !- Name
+ Perimeter_top_ZN_1 VAV Box, !- Zone Equipment 1 Name
+ Perimeter_top_ZN_2 Equipment, !- Name
+ Perimeter_top_ZN_2 VAV Box, !- Zone Equipment 1 Name
+ Perimeter_top_ZN_3 Equipment, !- Name
+ Perimeter_top_ZN_3 VAV Box, !- Zone Equipment 1 Name
+ Perimeter_top_ZN_4 Equipment, !- Name
+ Perimeter_top_ZN_4 VAV Box, !- Zone Equipment 1 Name
+! ***SIZING & CONTROLS***
+ Sizing:Zone,
+ SupplyAirTemperature, !- Zone Cooling Design Supply Air Temperature Input Method
+ 12.8000, !- Zone Cooling Design Supply Air Temperature {C}
+ , !- Zone Cooling Design Supply Air Temperature Difference {deltaC}
+ SupplyAirTemperature, !- Zone Heating Design Supply Air Temperature Input Method
+ 50.0000, !- Zone Heating Design Supply Air Temperature {C}
+ , !- Zone Heating Design Supply Air Temperature Difference {deltaC}
+ 0.0085, !- Zone Cooling Design Supply Air Humidity Ratio {kgWater/kgDryAir}
+ 0.0080, !- Zone Heating Design Supply Air Humidity Ratio {kgWater/kgDryAir}
+ SZ DSOA Basement, !- Design Specification Outdoor Air Object Name
+ , !- Zone Heating Sizing Factor
+ , !- Zone Cooling Sizing Factor
+ DesignDay, !- Cooling Design Air Flow Method
+ , !- Cooling Design Air Flow Rate {m3/s}
+ , !- Cooling Minimum Air Flow per Zone Floor Area {m3/s-m2}
+ , !- Cooling Minimum Air Flow {m3/s}
+ , !- Cooling Minimum Air Flow Fraction
+ DesignDay, !- Heating Design Air Flow Method
+ , !- Heating Design Air Flow Rate {m3/s}
+ , !- Heating Maximum Air Flow per Zone Floor Area {m3/s-m2}
+ , !- Heating Maximum Air Flow {m3/s}
+ ; !- Heating Maximum Air Flow Fraction
+ DesignSpecification:OutdoorAir,
+ SZ DSOA Basement, !- Name
+ Flow/Person, !- Outdoor Air Method
+ 0.0125, !- Outdoor Air Flow per Person {m3/s-person}
+ , !- Outdoor Air Flow per Zone Floor Area {m3/s-m2}
+ ; !- Outdoor Air Flow per Zone {m3/s}
+ Sizing:Zone,
+ SZ DSOA Core_bottom, !- Design Specification Outdoor Air Object Name
+ SZ DSOA Core_bottom, !- Name
+ Sizing:Zone,
+ SZ DSOA Core_mid, !- Design Specification Outdoor Air Object Name
+ SZ DSOA Core_mid, !- Name
+ Sizing:Zone,
+ SZ DSOA Core_top, !- Design Specification Outdoor Air Object Name
+ SZ DSOA Core_top, !- Name
+ Sizing:Zone,
+ SZ DSOA Perimeter_bot_ZN_1, !- Design Specification Outdoor Air Object Name
+ SZ DSOA Perimeter_bot_ZN_1, !- Name
+ Sizing:Zone,
+ SZ DSOA Perimeter_bot_ZN_2, !- Design Specification Outdoor Air Object Name
+ SZ DSOA Perimeter_bot_ZN_2, !- Name
+ Sizing:Zone,
+ SZ DSOA Perimeter_bot_ZN_3, !- Design Specification Outdoor Air Object Name
+ SZ DSOA Perimeter_bot_ZN_3, !- Name
+ Sizing:Zone,
+ SZ DSOA Perimeter_bot_ZN_4, !- Design Specification Outdoor Air Object Name
+ SZ DSOA Perimeter_bot_ZN_4, !- Name
+ Sizing:Zone,
+ SZ DSOA Perimeter_mid_ZN_1, !- Design Specification Outdoor Air Object Name
+ SZ DSOA Perimeter_mid_ZN_1, !- Name
+ Sizing:Zone,
+ SZ DSOA Perimeter_mid_ZN_2, !- Design Specification Outdoor Air Object Name
+ SZ DSOA Perimeter_mid_ZN_2, !- Name
+ Sizing:Zone,
+ SZ DSOA Perimeter_mid_ZN_3, !- Design Specification Outdoor Air Object Name
+ SZ DSOA Perimeter_mid_ZN_3, !- Name
+ Sizing:Zone,
+ SZ DSOA Perimeter_mid_ZN_4, !- Design Specification Outdoor Air Object Name
+ SZ DSOA Perimeter_mid_ZN_4, !- Name
+ Sizing:Zone,
+ SZ DSOA Perimeter_top_ZN_1, !- Design Specification Outdoor Air Object Name
+ SZ DSOA Perimeter_top_ZN_1, !- Name
+ Sizing:Zone,
+ SZ DSOA Perimeter_top_ZN_2, !- Design Specification Outdoor Air Object Name
+ SZ DSOA Perimeter_top_ZN_2, !- Name
+ Sizing:Zone,
+ SZ DSOA Perimeter_top_ZN_3, !- Design Specification Outdoor Air Object Name
+ SZ DSOA Perimeter_top_ZN_3, !- Name
+ Sizing:Zone,
+ SZ DSOA Perimeter_top_ZN_4, !- Design Specification Outdoor Air Object Name
+ SZ DSOA Perimeter_top_ZN_4, !- Name
+ ZoneControl:Thermostat,
+ Basement Thermostat, !- Name
+ Dual Zone Control Type Sched, !- Control Type Schedule Name
+ ThermostatSetpoint:DualSetpoint, !- Control 1 Object Type
+ Basement DualSPSched; !- Control 1 Name
+ Core_bottom Thermostat, !- Name
+ Core_bottom DualSPSched; !- Control 1 Name
+ Core_mid Thermostat, !- Name
+ Core_mid DualSPSched; !- Control 1 Name
+ Core_top Thermostat, !- Name
+ Core_top DualSPSched; !- Control 1 Name
+ Perimeter_bot_ZN_1 Thermostat, !- Name
+ Perimeter_bot_ZN_1 DualSPSched; !- Control 1 Name
+ Perimeter_bot_ZN_2 Thermostat, !- Name
+ Perimeter_bot_ZN_2 DualSPSched; !- Control 1 Name
+ Perimeter_bot_ZN_3 Thermostat, !- Name
+ Perimeter_bot_ZN_3 DualSPSched; !- Control 1 Name
+ Perimeter_bot_ZN_4 Thermostat, !- Name
+ Perimeter_bot_ZN_4 DualSPSched; !- Control 1 Name
+ Perimeter_mid_ZN_1 Thermostat, !- Name
+ Perimeter_mid_ZN_1 DualSPSched; !- Control 1 Name
+ Perimeter_mid_ZN_2 Thermostat, !- Name
+ Perimeter_mid_ZN_2 DualSPSched; !- Control 1 Name
+ Perimeter_mid_ZN_3 Thermostat, !- Name
+ Perimeter_mid_ZN_3 DualSPSched; !- Control 1 Name
+ Perimeter_mid_ZN_4 Thermostat, !- Name
+ Perimeter_mid_ZN_4 DualSPSched; !- Control 1 Name
+ Perimeter_top_ZN_1 Thermostat, !- Name
+ Perimeter_top_ZN_1 DualSPSched; !- Control 1 Name
+ Perimeter_top_ZN_2 Thermostat, !- Name
+ Perimeter_top_ZN_2 DualSPSched; !- Control 1 Name
+ Perimeter_top_ZN_3 Thermostat, !- Name
+ Perimeter_top_ZN_3 DualSPSched; !- Control 1 Name
+ Perimeter_top_ZN_4 Thermostat, !- Name
+ Perimeter_top_ZN_4 DualSPSched; !- Control 1 Name
+ Basement DualSPSched, !- Name
+ HTGSETP_SCH, !- Heating Setpoint Temperature Schedule Name
+ CLGSETP_SCH; !- Cooling Setpoint Temperature Schedule Name
+ Core_bottom DualSPSched, !- Name
+ Core_mid DualSPSched, !- Name
+ Core_top DualSPSched, !- Name
+ Perimeter_bot_ZN_1 DualSPSched, !- Name
+ Perimeter_bot_ZN_2 DualSPSched, !- Name
+ Perimeter_bot_ZN_3 DualSPSched, !- Name
+ Perimeter_bot_ZN_4 DualSPSched, !- Name
+ Perimeter_mid_ZN_1 DualSPSched, !- Name
+ Perimeter_mid_ZN_2 DualSPSched, !- Name
+ Perimeter_mid_ZN_3 DualSPSched, !- Name
+ Perimeter_mid_ZN_4 DualSPSched, !- Name
+ Perimeter_top_ZN_1 DualSPSched, !- Name
+ Perimeter_top_ZN_2 DualSPSched, !- Name
+ Perimeter_top_ZN_3 DualSPSched, !- Name
+ Perimeter_top_ZN_4 DualSPSched, !- Name
+ Sizing:System,
+ VAV_1, !- AirLoop Name
+ Sensible, !- Type of Load to Size On
+ AUTOSIZE, !- Design Outdoor Air Flow Rate {m3/s}
+ 0.3, !- Minimum System Air Flow Ratio
+ 7.0, !- Preheat Design Temperature {C}
+ 0.008, !- Preheat Design Humidity Ratio {kgWater/kgDryAir}
+ 12.8000, !- Precool Design Temperature {C}
+ 0.008, !- Precool Design Humidity Ratio {kgWater/kgDryAir}
+ 12.8000, !- Central Cooling Design Supply Air Temperature {C}
+ 16.7000, !- Central Heating Design Supply Air Temperature {C}
+ NonCoincident, !- Sizing Option
+ No, !- 100% Outdoor Air in Cooling
+ No, !- 100% Outdoor Air in Heating
+ 0.0085, !- Central Cooling Design Supply Air Humidity Ratio {kgWater/kgDryAir}
+ 0.0080, !- Central Heating Design Supply Air Humidity Ratio {kgWater/kgDryAir}
+ ZoneSum; !- System Outdoor Air Method
+ Sizing:System,
+ VAV_2, !- AirLoop Name
+ Sizing:System,
+ VAV_3, !- AirLoop Name
+ Sizing:System,
+ VAV_5, !- AirLoop Name
+ Controller:OutdoorAir,
+ VAV_1_OA_Controller, !- Name
+ VAV_1_OARelief Node, !- Relief Air Outlet Node Name
+ VAV_1 Supply Equipment Inlet Node, !- Return Air Node Name
+ VAV_1_OA-VAV_1_CoolCNode,!- Mixed Air Node Name
+ VAV_1_OAInlet Node, !- Actuator Node Name
+ AUTOSIZE, !- Minimum Outdoor Air Flow Rate {m3/s}
+ AUTOSIZE, !- Maximum Outdoor Air Flow Rate {m3/s}
+ DifferentialDryBulb, !- Economizer Control Type
+ ModulateFlow, !- Economizer Control Action Type
+ 28.0, !- Economizer Maximum Limit Dry-Bulb Temperature {C}
+ 64000.0, !- Economizer Maximum Limit Enthalpy {J/kg}
+ , !- Economizer Maximum Limit Dewpoint Temperature {C}
+ , !- Electronic Enthalpy Limit Curve Name
+ -100.0, !- Economizer Minimum Limit Dry-Bulb Temperature {C}
+ NoLockout, !- Lockout Type
+ FixedMinimum, !- Minimum Limit Type
+ MinOA_MotorizedDamper_Sched, !- Minimum Outdoor Air Schedule Name
+ , !- Minimum Fraction of Outdoor Air Schedule Name
+ , !- Maximum Fraction of Outdoor Air Schedule Name
+ ; !- Mechanical Ventilation Controller Name
+ VAV_2_OA_Controller, !- Name
+ VAV_2_OARelief Node, !- Relief Air Outlet Node Name
+ VAV_2 Supply Equipment Inlet Node, !- Return Air Node Name
+ VAV_2_OA-VAV_2_CoolCNode,!- Mixed Air Node Name
+ VAV_2_OAInlet Node, !- Actuator Node Name
+ VAV_3_OA_Controller, !- Name
+ VAV_3_OARelief Node, !- Relief Air Outlet Node Name
+ VAV_3 Supply Equipment Inlet Node, !- Return Air Node Name
+ VAV_3_OA-VAV_3_CoolCNode,!- Mixed Air Node Name
+ VAV_3_OAInlet Node, !- Actuator Node Name
+ VAV_5_OA_Controller, !- Name
+ VAV_5_OARelief Node, !- Relief Air Outlet Node Name
+ VAV_5 Supply Equipment Inlet Node, !- Return Air Node Name
+ VAV_5_OA-VAV_5_CoolCNode,!- Mixed Air Node Name
+ VAV_5_OAInlet Node, !- Actuator Node Name
+ SetpointManager:Scheduled,
+ VAV_1 SAT setpoint, !- Name
+ Temperature, !- Control Variable
+ Seasonal-Reset-Supply-Air-Temp-Sch, !- Schedule Name
+ VAV_1 Supply Equipment Outlet Node; !- Setpoint Node or NodeList Name
+ VAV_2 SAT setpoint, !- Name
+ VAV_2 Supply Equipment Outlet Node; !- Setpoint Node or NodeList Name
+ VAV_3 SAT setpoint, !- Name
+ VAV_3 Supply Equipment Outlet Node; !- Setpoint Node or NodeList Name
+ VAV_5 SAT setpoint, !- Name
+ VAV_5 Supply Equipment Outlet Node; !- Setpoint Node or NodeList Name
+! ***AIR LOOPS***
+ AirLoopHVAC,
+ VAV_1, !- Name
+ VAV_1_Controllers, !- Controller List Name
+ VAV_1 Availability Manager List, !- Availability Manager List Name
+ AUTOSIZE, !- Design Supply Air Flow Rate {m3/s}
+ VAV_1 Air Loop Branches, !- Branch List Name
+ , !- Connector List Name
+ VAV_1 Supply Equipment Inlet Node, !- Supply Side Inlet Node Name
+ VAV_1 Zone Equipment Outlet Node, !- Demand Side Outlet Node Name
+ VAV_1 Zone Equipment Inlet Node, !- Demand Side Inlet Node Names
+ VAV_1 Supply Equipment Outlet Node; !- Supply Side Outlet Node Names
+ AirLoopHVAC,
+ VAV_2, !- Name
+ VAV_2_Controllers, !- Controller List Name
+ VAV_2 Availability Manager List, !- Availability Manager List Name
+ VAV_2 Air Loop Branches, !- Branch List Name
+ VAV_2 Supply Equipment Inlet Node, !- Supply Side Inlet Node Name
+ VAV_2 Zone Equipment Outlet Node, !- Demand Side Outlet Node Name
+ VAV_2 Zone Equipment Inlet Node, !- Demand Side Inlet Node Names
+ VAV_2 Supply Equipment Outlet Node; !- Supply Side Outlet Node Names
+ AirLoopHVAC,
+ VAV_3, !- Name
+ VAV_3_Controllers, !- Controller List Name
+ VAV_3 Availability Manager List, !- Availability Manager List Name
+ VAV_3 Air Loop Branches, !- Branch List Name
+ VAV_3 Supply Equipment Inlet Node, !- Supply Side Inlet Node Name
+ VAV_3 Zone Equipment Outlet Node, !- Demand Side Outlet Node Name
+ VAV_3 Zone Equipment Inlet Node, !- Demand Side Inlet Node Names
+ VAV_3 Supply Equipment Outlet Node; !- Supply Side Outlet Node Names
+ AirLoopHVAC,
+ VAV_5, !- Name
+ VAV_5_Controllers, !- Controller List Name
+ VAV_5 Availability Manager List, !- Availability Manager List Name
+ VAV_5 Air Loop Branches, !- Branch List Name
+ VAV_5 Supply Equipment Inlet Node, !- Supply Side Inlet Node Name
+ VAV_5 Zone Equipment Outlet Node, !- Demand Side Outlet Node Name
+ VAV_5 Zone Equipment Inlet Node, !- Demand Side Inlet Node Names
+ VAV_5 Supply Equipment Outlet Node; !- Supply Side Outlet Node Names
+! ***CONNECTIONS***
+ ZoneHVAC:EquipmentConnections,
+ Basement, !- Zone Name
+ Basement Equipment, !- Zone Conditioning Equipment List Name
+ Basement Inlet Nodes, !- Zone Air Inlet Node or NodeList Name
+ , !- Zone Air Exhaust Node or NodeList Name
+ Basement Air Node, !- Zone Air Node Name
+ Basement Return Air Node Name; !- Zone Return Air Node Name
+ Core_bottom, !- Zone Name
+ Core_bottom Equipment, !- Zone Conditioning Equipment List Name
+ Core_bottom Inlet Nodes, !- Zone Air Inlet Node or NodeList Name
+ Core_bottom Air Node, !- Zone Air Node Name
+ Core_bottom Return Air Node Name; !- Zone Return Air Node Name
+ Core_mid, !- Zone Name
+ Core_mid Equipment, !- Zone Conditioning Equipment List Name
+ Core_mid Inlet Nodes, !- Zone Air Inlet Node or NodeList Name
+ Core_mid Air Node, !- Zone Air Node Name
+ Core_mid Return Air Node Name; !- Zone Return Air Node Name
+ Core_top Equipment, !- Zone Conditioning Equipment List Name
+ Core_top Inlet Nodes, !- Zone Air Inlet Node or NodeList Name
+ Core_top Air Node, !- Zone Air Node Name
+ Core_top Return Air Node Name; !- Zone Return Air Node Name
+ Perimeter_bot_ZN_1 Equipment, !- Zone Conditioning Equipment List Name
+ Perimeter_bot_ZN_1 Inlet Nodes, !- Zone Air Inlet Node or NodeList Name
+ Perimeter_bot_ZN_1 Air Node, !- Zone Air Node Name
+ Perimeter_bot_ZN_1 Return Air Node Name; !- Zone Return Air Node Name
+ Perimeter_bot_ZN_2 Equipment, !- Zone Conditioning Equipment List Name
+ Perimeter_bot_ZN_2 Inlet Nodes, !- Zone Air Inlet Node or NodeList Name
+ Perimeter_bot_ZN_2 Air Node, !- Zone Air Node Name
+ Perimeter_bot_ZN_2 Return Air Node Name; !- Zone Return Air Node Name
+ Perimeter_bot_ZN_3 Equipment, !- Zone Conditioning Equipment List Name
+ Perimeter_bot_ZN_3 Inlet Nodes, !- Zone Air Inlet Node or NodeList Name
+ Perimeter_bot_ZN_3 Air Node, !- Zone Air Node Name
+ Perimeter_bot_ZN_3 Return Air Node Name; !- Zone Return Air Node Name
+ Perimeter_bot_ZN_4 Equipment, !- Zone Conditioning Equipment List Name
+ Perimeter_bot_ZN_4 Inlet Nodes, !- Zone Air Inlet Node or NodeList Name
+ Perimeter_bot_ZN_4 Air Node, !- Zone Air Node Name
+ Perimeter_bot_ZN_4 Return Air Node Name; !- Zone Return Air Node Name
+ Perimeter_mid_ZN_1 Equipment, !- Zone Conditioning Equipment List Name
+ Perimeter_mid_ZN_1 Inlet Nodes, !- Zone Air Inlet Node or NodeList Name
+ Perimeter_mid_ZN_1 Air Node, !- Zone Air Node Name
+ Perimeter_mid_ZN_1 Return Air Node Name; !- Zone Return Air Node Name
+ Perimeter_mid_ZN_2 Equipment, !- Zone Conditioning Equipment List Name
+ Perimeter_mid_ZN_2 Inlet Nodes, !- Zone Air Inlet Node or NodeList Name
+ Perimeter_mid_ZN_2 Air Node, !- Zone Air Node Name
+ Perimeter_mid_ZN_2 Return Air Node Name; !- Zone Return Air Node Name
+ Perimeter_mid_ZN_3 Equipment, !- Zone Conditioning Equipment List Name
+ Perimeter_mid_ZN_3 Inlet Nodes, !- Zone Air Inlet Node or NodeList Name
+ Perimeter_mid_ZN_3 Air Node, !- Zone Air Node Name
+ Perimeter_mid_ZN_3 Return Air Node Name; !- Zone Return Air Node Name
+ Perimeter_mid_ZN_4 Equipment, !- Zone Conditioning Equipment List Name
+ Perimeter_mid_ZN_4 Inlet Nodes, !- Zone Air Inlet Node or NodeList Name
+ Perimeter_mid_ZN_4 Air Node, !- Zone Air Node Name
+ Perimeter_mid_ZN_4 Return Air Node Name; !- Zone Return Air Node Name
+ Perimeter_top_ZN_1 Equipment, !- Zone Conditioning Equipment List Name
+ Perimeter_top_ZN_1 Inlet Nodes, !- Zone Air Inlet Node or NodeList Name
+ Perimeter_top_ZN_1 Air Node, !- Zone Air Node Name
+ Perimeter_top_ZN_1 Return Air Node Name; !- Zone Return Air Node Name
+ Perimeter_top_ZN_2 Equipment, !- Zone Conditioning Equipment List Name
+ Perimeter_top_ZN_2 Inlet Nodes, !- Zone Air Inlet Node or NodeList Name
+ Perimeter_top_ZN_2 Air Node, !- Zone Air Node Name
+ Perimeter_top_ZN_2 Return Air Node Name; !- Zone Return Air Node Name
+ Perimeter_top_ZN_3 Equipment, !- Zone Conditioning Equipment List Name
+ Perimeter_top_ZN_3 Inlet Nodes, !- Zone Air Inlet Node or NodeList Name
+ Perimeter_top_ZN_3 Air Node, !- Zone Air Node Name
+ Perimeter_top_ZN_3 Return Air Node Name; !- Zone Return Air Node Name
+ Perimeter_top_ZN_4 Equipment, !- Zone Conditioning Equipment List Name
+ Perimeter_top_ZN_4 Inlet Nodes, !- Zone Air Inlet Node or NodeList Name
+ Perimeter_top_ZN_4 Air Node, !- Zone Air Node Name
+ Perimeter_top_ZN_4 Return Air Node Name; !- Zone Return Air Node Name
+ Basement VAV Box, !- Name
+ Basement VAV Box Outlet Node Name, !- Air Distribution Unit Outlet Node Name
+ AirTerminal:SingleDuct:VAV:Reheat, !- Air Terminal Object Type
+ Basement VAV Box Component; !- Air Terminal Name
+ Core_bottom VAV Box, !- Name
+ Core_bottom VAV Box Outlet Node Name, !- Air Distribution Unit Outlet Node Name
+ Core_bottom VAV Box Component; !- Air Terminal Name
+ Core_mid VAV Box, !- Name
+ Core_mid VAV Box Outlet Node Name, !- Air Distribution Unit Outlet Node Name
+ Core_mid VAV Box Component; !- Air Terminal Name
+ Core_top VAV Box, !- Name
+ Core_top VAV Box Outlet Node Name, !- Air Distribution Unit Outlet Node Name
+ Core_top VAV Box Component; !- Air Terminal Name
+ Perimeter_bot_ZN_1 VAV Box, !- Name
+ Perimeter_bot_ZN_1 VAV Box Outlet Node Name, !- Air Distribution Unit Outlet Node Name
+ Perimeter_bot_ZN_1 VAV Box Component; !- Air Terminal Name
+ Perimeter_bot_ZN_2 VAV Box, !- Name
+ Perimeter_bot_ZN_2 VAV Box Outlet Node Name, !- Air Distribution Unit Outlet Node Name
+ Perimeter_bot_ZN_2 VAV Box Component; !- Air Terminal Name
+ Perimeter_bot_ZN_3 VAV Box, !- Name
+ Perimeter_bot_ZN_3 VAV Box Outlet Node Name, !- Air Distribution Unit Outlet Node Name
+ Perimeter_bot_ZN_3 VAV Box Component; !- Air Terminal Name
+ Perimeter_bot_ZN_4 VAV Box, !- Name
+ Perimeter_bot_ZN_4 VAV Box Outlet Node Name, !- Air Distribution Unit Outlet Node Name
+ Perimeter_bot_ZN_4 VAV Box Component; !- Air Terminal Name
+ Perimeter_mid_ZN_1 VAV Box, !- Name
+ Perimeter_mid_ZN_1 VAV Box Outlet Node Name, !- Air Distribution Unit Outlet Node Name
+ Perimeter_mid_ZN_1 VAV Box Component; !- Air Terminal Name
+ Perimeter_mid_ZN_2 VAV Box, !- Name
+ Perimeter_mid_ZN_2 VAV Box Outlet Node Name, !- Air Distribution Unit Outlet Node Name
+ Perimeter_mid_ZN_2 VAV Box Component; !- Air Terminal Name
+ Perimeter_mid_ZN_3 VAV Box, !- Name
+ Perimeter_mid_ZN_3 VAV Box Outlet Node Name, !- Air Distribution Unit Outlet Node Name
+ Perimeter_mid_ZN_3 VAV Box Component; !- Air Terminal Name
+ Perimeter_mid_ZN_4 VAV Box, !- Name
+ Perimeter_mid_ZN_4 VAV Box Outlet Node Name, !- Air Distribution Unit Outlet Node Name
+ Perimeter_mid_ZN_4 VAV Box Component; !- Air Terminal Name
+ Perimeter_top_ZN_1 VAV Box, !- Name
+ Perimeter_top_ZN_1 VAV Box Outlet Node Name, !- Air Distribution Unit Outlet Node Name
+ Perimeter_top_ZN_1 VAV Box Component; !- Air Terminal Name
+ Perimeter_top_ZN_2 VAV Box, !- Name
+ Perimeter_top_ZN_2 VAV Box Outlet Node Name, !- Air Distribution Unit Outlet Node Name
+ Perimeter_top_ZN_2 VAV Box Component; !- Air Terminal Name
+ Perimeter_top_ZN_3 VAV Box, !- Name
+ Perimeter_top_ZN_3 VAV Box Outlet Node Name, !- Air Distribution Unit Outlet Node Name
+ Perimeter_top_ZN_3 VAV Box Component; !- Air Terminal Name
+ Perimeter_top_ZN_4 VAV Box, !- Name
+ Perimeter_top_ZN_4 VAV Box Outlet Node Name, !- Air Distribution Unit Outlet Node Name
+ Perimeter_top_ZN_4 VAV Box Component; !- Air Terminal Name
+ NodeList,
+ Basement Inlet Nodes, !- Name
+ Basement VAV Box Outlet Node Name; !- Node 1 Name
+ NodeList,
+ Core_bottom Inlet Nodes, !- Name
+ Core_bottom VAV Box Outlet Node Name; !- Node 1 Name
+ NodeList,
+ Core_mid Inlet Nodes, !- Name
+ Core_mid VAV Box Outlet Node Name; !- Node 1 Name
+ NodeList,
+ Core_top Inlet Nodes, !- Name
+ Core_top VAV Box Outlet Node Name; !- Node 1 Name
+ NodeList,
+ Perimeter_bot_ZN_1 Inlet Nodes, !- Name
+ Perimeter_bot_ZN_1 VAV Box Outlet Node Name; !- Node 1 Name
+ NodeList,
+ Perimeter_bot_ZN_2 Inlet Nodes, !- Name
+ Perimeter_bot_ZN_2 VAV Box Outlet Node Name; !- Node 1 Name
+ NodeList,
+ Perimeter_bot_ZN_3 Inlet Nodes, !- Name
+ Perimeter_bot_ZN_3 VAV Box Outlet Node Name; !- Node 1 Name
+ NodeList,
+ Perimeter_bot_ZN_4 Inlet Nodes, !- Name
+ Perimeter_bot_ZN_4 VAV Box Outlet Node Name; !- Node 1 Name
+ NodeList,
+ Perimeter_mid_ZN_1 Inlet Nodes, !- Name
+ Perimeter_mid_ZN_1 VAV Box Outlet Node Name; !- Node 1 Name
+ NodeList,
+ Perimeter_mid_ZN_2 Inlet Nodes, !- Name
+ Perimeter_mid_ZN_2 VAV Box Outlet Node Name; !- Node 1 Name
+ NodeList,
+ Perimeter_mid_ZN_3 Inlet Nodes, !- Name
+ Perimeter_mid_ZN_3 VAV Box Outlet Node Name; !- Node 1 Name
+ NodeList,
+ Perimeter_mid_ZN_4 Inlet Nodes, !- Name
+ Perimeter_mid_ZN_4 VAV Box Outlet Node Name; !- Node 1 Name
+ NodeList,
+ Perimeter_top_ZN_1 Inlet Nodes, !- Name
+ Perimeter_top_ZN_1 VAV Box Outlet Node Name; !- Node 1 Name
+ NodeList,
+ Perimeter_top_ZN_2 Inlet Nodes, !- Name
+ Perimeter_top_ZN_2 VAV Box Outlet Node Name; !- Node 1 Name
+ NodeList,
+ Perimeter_top_ZN_3 Inlet Nodes, !- Name
+ Perimeter_top_ZN_3 VAV Box Outlet Node Name; !- Node 1 Name
+ NodeList,
+ Perimeter_top_ZN_4 Inlet Nodes, !- Name
+ Perimeter_top_ZN_4 VAV Box Outlet Node Name; !- Node 1 Name
+ NodeList,
+ VAV_1_OANode List, !- Name
+ VAV_1_OAInlet Node; !- Node 1 Name
+ NodeList,
+ VAV_2_OANode List, !- Name
+ VAV_2_OAInlet Node; !- Node 1 Name
+ NodeList,
+ VAV_3_OANode List, !- Name
+ VAV_3_OAInlet Node; !- Node 1 Name
+ NodeList,
+ VAV_5_OANode List, !- Name
+ VAV_5_OAInlet Node; !- Node 1 Name
+ AvailabilityManagerAssignmentList,
+ VAV_1 Availability Manager List, !- Name
+ AvailabilityManager:NightCycle, !- Availability Manager 1 Object Type
+ VAV_1 Availability Manager; !- Availability Manager 1 Name
+ VAV_2 Availability Manager List, !- Name
+ VAV_2 Availability Manager; !- Availability Manager 1 Name
+ VAV_3 Availability Manager List, !- Name
+ VAV_3 Availability Manager; !- Availability Manager 1 Name
+ VAV_5 Availability Manager List, !- Name
+ VAV_5 Availability Manager; !- Availability Manager 1 Name
+ VAV_1 Availability Manager, !- Name
+ ALWAYS_ON, !- Applicability Schedule Name
+ HVACOperationSchd, !- Fan Schedule Name
+ CycleOnAny, !- Control Type
+ 1.0, !- Thermostat Tolerance {deltaC}
+ 1800; !- Cycling Run Time {s}
+ VAV_2 Availability Manager, !- Name
+ VAV_3 Availability Manager, !- Name
+ VAV_5 Availability Manager, !- Name
+ BranchList,
+ VAV_1 Air Loop Branches, !- Name
+ VAV_1 Air Loop Main Branch; !- Branch 1 Name
+ BranchList,
+ VAV_2 Air Loop Branches, !- Name
+ VAV_2 Air Loop Main Branch; !- Branch 1 Name
+ BranchList,
+ VAV_3 Air Loop Branches, !- Name
+ VAV_3 Air Loop Main Branch; !- Branch 1 Name
+ BranchList,
+ VAV_5 Air Loop Branches, !- Name
+ VAV_5 Air Loop Main Branch; !- Branch 1 Name
+ Branch,
+ VAV_1 Air Loop Main Branch, !- Name
+ , !- Pressure Drop Curve Name
+ AirLoopHVAC:OutdoorAirSystem, !- Component 1 Object Type
+ VAV_1_OA, !- Component 1 Name
+ VAV_1 Supply Equipment Inlet Node, !- Component 1 Inlet Node Name
+ VAV_1_OA-VAV_1_CoolCNode,!- Component 1 Outlet Node Name
+ Passive, !- Component 1 Branch Control Type
+ Coil:Cooling:Water, !- Component 2 Object Type
+ VAV_1_CoolC, !- Component 2 Name
+ VAV_1_OA-VAV_1_CoolCNode,!- Component 2 Inlet Node Name
+ VAV_1_CoolC-VAV_1_HeatCNode, !- Component 2 Outlet Node Name
+ Passive, !- Component 2 Branch Control Type
+ Coil:Heating:Water, !- Component 3 Object Type
+ VAV_1_HeatC, !- Component 3 Name
+ VAV_1_CoolC-VAV_1_HeatCNode, !- Component 3 Inlet Node Name
+ VAV_1_HeatC-VAV_1_FanNode, !- Component 3 Outlet Node Name
+ Passive, !- Component 3 Branch Control Type
+ Fan:VariableVolume, !- Component 4 Object Type
+ VAV_1_Fan, !- Component 4 Name
+ VAV_1_HeatC-VAV_1_FanNode, !- Component 4 Inlet Node Name
+ VAV_1 Supply Equipment Outlet Node, !- Component 4 Outlet Node Name
+ Active; !- Component 4 Branch Control Type
+ Branch,
+ VAV_2 Air Loop Main Branch, !- Name
+ VAV_2_OA, !- Component 1 Name
+ VAV_2 Supply Equipment Inlet Node, !- Component 1 Inlet Node Name
+ VAV_2_OA-VAV_2_CoolCNode,!- Component 1 Outlet Node Name
+ VAV_2_CoolC, !- Component 2 Name
+ VAV_2_OA-VAV_2_CoolCNode,!- Component 2 Inlet Node Name
+ VAV_2_CoolC-VAV_2_HeatCNode, !- Component 2 Outlet Node Name
+ VAV_2_HeatC, !- Component 3 Name
+ VAV_2_CoolC-VAV_2_HeatCNode, !- Component 3 Inlet Node Name
+ VAV_2_HeatC-VAV_2_FanNode, !- Component 3 Outlet Node Name
+ VAV_2_Fan, !- Component 4 Name
+ VAV_2_HeatC-VAV_2_FanNode, !- Component 4 Inlet Node Name
+ VAV_2 Supply Equipment Outlet Node, !- Component 4 Outlet Node Name
+ Branch,
+ VAV_3 Air Loop Main Branch, !- Name
+ VAV_3_OA, !- Component 1 Name
+ VAV_3 Supply Equipment Inlet Node, !- Component 1 Inlet Node Name
+ VAV_3_OA-VAV_3_CoolCNode,!- Component 1 Outlet Node Name
+ VAV_3_CoolC, !- Component 2 Name
+ VAV_3_OA-VAV_3_CoolCNode,!- Component 2 Inlet Node Name
+ VAV_3_CoolC-VAV_3_HeatCNode, !- Component 2 Outlet Node Name
+ VAV_3_HeatC, !- Component 3 Name
+ VAV_3_CoolC-VAV_3_HeatCNode, !- Component 3 Inlet Node Name
+ VAV_3_HeatC-VAV_3_FanNode, !- Component 3 Outlet Node Name
+ VAV_3_Fan, !- Component 4 Name
+ VAV_3_HeatC-VAV_3_FanNode, !- Component 4 Inlet Node Name
+ VAV_3 Supply Equipment Outlet Node, !- Component 4 Outlet Node Name
+ Branch,
+ VAV_5 Air Loop Main Branch, !- Name
+ VAV_5_OA, !- Component 1 Name
+ VAV_5 Supply Equipment Inlet Node, !- Component 1 Inlet Node Name
+ VAV_5_OA-VAV_5_CoolCNode,!- Component 1 Outlet Node Name
+ VAV_5_CoolC, !- Component 2 Name
+ VAV_5_OA-VAV_5_CoolCNode,!- Component 2 Inlet Node Name
+ VAV_5_CoolC-VAV_5_HeatCNode, !- Component 2 Outlet Node Name
+ VAV_5_HeatC, !- Component 3 Name
+ VAV_5_CoolC-VAV_5_HeatCNode, !- Component 3 Inlet Node Name
+ VAV_5_HeatC-VAV_5_FanNode, !- Component 3 Outlet Node Name
+ VAV_5_Fan, !- Component 4 Name
+ VAV_5_HeatC-VAV_5_FanNode, !- Component 4 Inlet Node Name
+ VAV_5 Supply Equipment Outlet Node, !- Component 4 Outlet Node Name
+ AirLoopHVAC:ControllerList,
+ VAV_1_Controllers, !- Name
+ Controller:WaterCoil, !- Controller 1 Object Type
+ VAV_1_CoolC_Controller, !- Controller 1 Name
+ Controller:WaterCoil, !- Controller 2 Object Type
+ VAV_1_HeatC_Controller; !- Controller 2 Name
+ VAV_1_OA_Controllers, !- Name
+ Controller:OutdoorAir, !- Controller 1 Object Type
+ VAV_1_OA_Controller; !- Controller 1 Name
+ VAV_2_Controllers, !- Name
+ VAV_2_CoolC_Controller, !- Controller 1 Name
+ VAV_2_HeatC_Controller; !- Controller 2 Name
+ VAV_2_OA_Controllers, !- Name
+ VAV_2_OA_Controller; !- Controller 1 Name
+ VAV_3_Controllers, !- Name
+ VAV_3_CoolC_Controller, !- Controller 1 Name
+ VAV_3_HeatC_Controller; !- Controller 2 Name
+ VAV_3_OA_Controllers, !- Name
+ VAV_3_OA_Controller; !- Controller 1 Name
+ VAV_5_Controllers, !- Name
+ VAV_5_CoolC_Controller, !- Controller 1 Name
+ VAV_5_HeatC_Controller; !- Controller 2 Name
+ VAV_5_OA_Controllers, !- Name
+ VAV_5_OA_Controller; !- Controller 1 Name
+ AirLoopHVAC:OutdoorAirSystem:EquipmentList,
+ VAV_1_OA_Equipment, !- Name
+ OutdoorAir:Mixer, !- Component 1 Object Type
+ VAV_1_OAMixing Box; !- Component 1 Name
+ VAV_2_OA_Equipment, !- Name
+ VAV_2_OAMixing Box; !- Component 1 Name
+ VAV_3_OA_Equipment, !- Name
+ VAV_3_OAMixing Box; !- Component 1 Name
+ VAV_5_OA_Equipment, !- Name
+ VAV_5_OAMixing Box; !- Component 1 Name
+ VAV_1_OA, !- Name
+ VAV_1_OA_Controllers, !- Controller List Name
+ VAV_1_OA_Equipment, !- Outdoor Air Equipment List Name
+ VAV_1 Availability Manager List; !- Availability Manager List Name
+ VAV_2_OA, !- Name
+ VAV_2_OA_Controllers, !- Controller List Name
+ VAV_2_OA_Equipment, !- Outdoor Air Equipment List Name
+ VAV_2 Availability Manager List; !- Availability Manager List Name
+ VAV_3_OA, !- Name
+ VAV_3_OA_Controllers, !- Controller List Name
+ VAV_3_OA_Equipment, !- Outdoor Air Equipment List Name
+ VAV_3 Availability Manager List; !- Availability Manager List Name
+ VAV_5_OA, !- Name
+ VAV_5_OA_Controllers, !- Controller List Name
+ VAV_5_OA_Equipment, !- Outdoor Air Equipment List Name
+ VAV_5 Availability Manager List; !- Availability Manager List Name
+ OutdoorAir:NodeList,
+ VAV_1_OANode List; !- Node or NodeList Name 1
+ VAV_2_OANode List; !- Node or NodeList Name 1
+ VAV_3_OANode List; !- Node or NodeList Name 1
+ VAV_5_OANode List; !- Node or NodeList Name 1
+ OutdoorAir:Mixer,
+ VAV_1_OAMixing Box, !- Name
+ VAV_1_OAInlet Node, !- Outdoor Air Stream Node Name
+ VAV_1_OARelief Node, !- Relief Air Stream Node Name
+ VAV_1 Supply Equipment Inlet Node; !- Return Air Stream Node Name
+ OutdoorAir:Mixer,
+ VAV_2_OAMixing Box, !- Name
+ VAV_2_OAInlet Node, !- Outdoor Air Stream Node Name
+ VAV_2_OARelief Node, !- Relief Air Stream Node Name
+ VAV_2 Supply Equipment Inlet Node; !- Return Air Stream Node Name
+ OutdoorAir:Mixer,
+ VAV_3_OAMixing Box, !- Name
+ VAV_3_OAInlet Node, !- Outdoor Air Stream Node Name
+ VAV_3_OARelief Node, !- Relief Air Stream Node Name
+ VAV_3 Supply Equipment Inlet Node; !- Return Air Stream Node Name
+ OutdoorAir:Mixer,
+ VAV_5_OAMixing Box, !- Name
+ VAV_5_OAInlet Node, !- Outdoor Air Stream Node Name
+ VAV_5_OARelief Node, !- Relief Air Stream Node Name
+ VAV_5 Supply Equipment Inlet Node; !- Return Air Stream Node Name
+ SetpointManager:MixedAir,
+ VAV_1_CoolC SAT Manager, !- Name
+ VAV_1 Supply Equipment Outlet Node, !- Reference Setpoint Node Name
+ VAV_1_HeatC-VAV_1_FanNode, !- Fan Inlet Node Name
+ VAV_1 Supply Equipment Outlet Node, !- Fan Outlet Node Name
+ VAV_1_CoolC-VAV_1_HeatCNode; !- Setpoint Node or NodeList Name
+ VAV_1_HeatC SAT Manager, !- Name
+ VAV_1_HeatC-VAV_1_FanNode; !- Setpoint Node or NodeList Name
+ VAV_1_OAMixed Air Temp Manager, !- Name
+ VAV_1_OA-VAV_1_CoolCNode;!- Setpoint Node or NodeList Name
+ VAV_2_CoolC SAT Manager, !- Name
+ VAV_2 Supply Equipment Outlet Node, !- Reference Setpoint Node Name
+ VAV_2_HeatC-VAV_2_FanNode, !- Fan Inlet Node Name
+ VAV_2 Supply Equipment Outlet Node, !- Fan Outlet Node Name
+ VAV_2_CoolC-VAV_2_HeatCNode; !- Setpoint Node or NodeList Name
+ VAV_2_HeatC SAT Manager, !- Name
+ VAV_2_HeatC-VAV_2_FanNode; !- Setpoint Node or NodeList Name
+ VAV_2_OAMixed Air Temp Manager, !- Name
+ VAV_2_OA-VAV_2_CoolCNode;!- Setpoint Node or NodeList Name
+ VAV_3_CoolC SAT Manager, !- Name
+ VAV_3 Supply Equipment Outlet Node, !- Reference Setpoint Node Name
+ VAV_3_HeatC-VAV_3_FanNode, !- Fan Inlet Node Name
+ VAV_3 Supply Equipment Outlet Node, !- Fan Outlet Node Name
+ VAV_3_CoolC-VAV_3_HeatCNode; !- Setpoint Node or NodeList Name
+ VAV_3_HeatC SAT Manager, !- Name
+ VAV_3_HeatC-VAV_3_FanNode; !- Setpoint Node or NodeList Name
+ VAV_3_OAMixed Air Temp Manager, !- Name
+ VAV_3_OA-VAV_3_CoolCNode;!- Setpoint Node or NodeList Name
+ VAV_5_CoolC SAT Manager, !- Name
+ VAV_5 Supply Equipment Outlet Node, !- Reference Setpoint Node Name
+ VAV_5_HeatC-VAV_5_FanNode, !- Fan Inlet Node Name
+ VAV_5 Supply Equipment Outlet Node, !- Fan Outlet Node Name
+ VAV_5_CoolC-VAV_5_HeatCNode; !- Setpoint Node or NodeList Name
+ VAV_5_HeatC SAT Manager, !- Name
+ VAV_5_HeatC-VAV_5_FanNode; !- Setpoint Node or NodeList Name
+ VAV_5_OAMixed Air Temp Manager, !- Name
+ VAV_5_OA-VAV_5_CoolCNode;!- Setpoint Node or NodeList Name
+ AirLoopHVAC:SupplyPath,
+ VAV_1, !- Name
+ VAV_1 Zone Equipment Inlet Node, !- Supply Air Path Inlet Node Name
+ AirLoopHVAC:ZoneSplitter,!- Component 1 Object Type
+ VAV_1 Supply Air Splitter; !- Component 1 Name
+ VAV_2, !- Name
+ VAV_2 Zone Equipment Inlet Node, !- Supply Air Path Inlet Node Name
+ VAV_2 Supply Air Splitter; !- Component 1 Name
+ VAV_3, !- Name
+ VAV_3 Zone Equipment Inlet Node, !- Supply Air Path Inlet Node Name
+ VAV_3 Supply Air Splitter; !- Component 1 Name
+ VAV_5, !- Name
+ VAV_5 Zone Equipment Inlet Node, !- Supply Air Path Inlet Node Name
+ VAV_5 Supply Air Splitter; !- Component 1 Name
+ VAV_1 Supply Air Splitter, !- Name
+ VAV_1 Zone Equipment Inlet Node, !- Inlet Node Name
+ Core_bottom VAV Box Inlet Node Name, !- Outlet 1 Node Name
+ Perimeter_bot_ZN_3 VAV Box Inlet Node Name, !- Outlet 2 Node Name
+ Perimeter_bot_ZN_2 VAV Box Inlet Node Name, !- Outlet 3 Node Name
+ Perimeter_bot_ZN_1 VAV Box Inlet Node Name, !- Outlet 4 Node Name
+ Perimeter_bot_ZN_4 VAV Box Inlet Node Name; !- Outlet 5 Node Name
+ VAV_2 Supply Air Splitter, !- Name
+ VAV_2 Zone Equipment Inlet Node, !- Inlet Node Name
+ Core_mid VAV Box Inlet Node Name, !- Outlet 1 Node Name
+ Perimeter_mid_ZN_3 VAV Box Inlet Node Name, !- Outlet 2 Node Name
+ Perimeter_mid_ZN_2 VAV Box Inlet Node Name, !- Outlet 3 Node Name
+ Perimeter_mid_ZN_1 VAV Box Inlet Node Name, !- Outlet 4 Node Name
+ Perimeter_mid_ZN_4 VAV Box Inlet Node Name; !- Outlet 5 Node Name
+ VAV_3 Supply Air Splitter, !- Name
+ VAV_3 Zone Equipment Inlet Node, !- Inlet Node Name
+ Core_top VAV Box Inlet Node Name, !- Outlet 1 Node Name
+ Perimeter_top_ZN_3 VAV Box Inlet Node Name, !- Outlet 2 Node Name
+ Perimeter_top_ZN_2 VAV Box Inlet Node Name, !- Outlet 3 Node Name
+ Perimeter_top_ZN_1 VAV Box Inlet Node Name, !- Outlet 4 Node Name
+ Perimeter_top_ZN_4 VAV Box Inlet Node Name; !- Outlet 5 Node Name
+ VAV_5 Supply Air Splitter, !- Name
+ VAV_5 Zone Equipment Inlet Node, !- Inlet Node Name
+ Basement VAV Box Inlet Node Name; !- Outlet 1 Node Name
+ AirLoopHVAC:ReturnPath,
+ VAV_1 Return Air Path, !- Name
+ VAV_1 Zone Equipment Outlet Node, !- Return Air Path Outlet Node Name
+ AirLoopHVAC:ReturnPlenum,!- Component 1 Object Type
+ VAV_1 Return Plenum, !- Component 1 Name
+ AirLoopHVAC:ZoneMixer, !- Component 2 Object Type
+ VAV_1 Return Air Mixer; !- Component 2 Name
+ VAV_2 Return Air Path, !- Name
+ VAV_2 Zone Equipment Outlet Node, !- Return Air Path Outlet Node Name
+ VAV_2 Return Plenum, !- Component 1 Name
+ VAV_2 Return Air Mixer; !- Component 2 Name
+ VAV_3 Return Air Path, !- Name
+ VAV_3 Zone Equipment Outlet Node, !- Return Air Path Outlet Node Name
+ VAV_3 Return Plenum, !- Component 1 Name
+ VAV_3 Return Air Mixer; !- Component 2 Name
+ VAV_5 Return Air Path, !- Name
+ VAV_5 Zone Equipment Outlet Node, !- Return Air Path Outlet Node Name
+ AirLoopHVAC:ZoneMixer, !- Component 1 Object Type
+ VAV_5 Return Air Mixer; !- Component 1 Name
+ VAV_2 Return Plenum, !- Name
+ MidFloor_Plenum, !- Zone Name
+ MIDFLOOR_PLENUMPlenumNode, !- Zone Node Name
+ MIDFLOOR_PLENUMPlenumOutletNode, !- Outlet Node Name
+ , !- Induced Air Outlet Node or NodeList Name
+ Core_mid Return Air Node Name, !- Inlet 1 Node Name
+ Perimeter_mid_ZN_3 Return Air Node Name, !- Inlet 2 Node Name
+ Perimeter_mid_ZN_2 Return Air Node Name, !- Inlet 3 Node Name
+ Perimeter_mid_ZN_1 Return Air Node Name, !- Inlet 4 Node Name
+ Perimeter_mid_ZN_4 Return Air Node Name; !- Inlet 5 Node Name
+ VAV_1 Return Plenum, !- Name
+ GroundFloor_Plenum, !- Zone Name
+ GROUNDFLOOR_PLENUMPlenumNode, !- Zone Node Name
+ GROUNDFLOOR_PLENUMPlenumOutletNode, !- Outlet Node Name
+ Core_bottom Return Air Node Name, !- Inlet 1 Node Name
+ Perimeter_bot_ZN_3 Return Air Node Name, !- Inlet 2 Node Name
+ Perimeter_bot_ZN_2 Return Air Node Name, !- Inlet 3 Node Name
+ Perimeter_bot_ZN_1 Return Air Node Name, !- Inlet 4 Node Name
+ Perimeter_bot_ZN_4 Return Air Node Name; !- Inlet 5 Node Name
+ VAV_3 Return Plenum, !- Name
+ TopFloor_Plenum, !- Zone Name
+ TOPFLOOR_PLENUMPlenumNode, !- Zone Node Name
+ TOPFLOOR_PLENUMPlenumOutletNode, !- Outlet Node Name
+ Core_top Return Air Node Name, !- Inlet 1 Node Name
+ Perimeter_top_ZN_3 Return Air Node Name, !- Inlet 2 Node Name
+ Perimeter_top_ZN_2 Return Air Node Name, !- Inlet 3 Node Name
+ Perimeter_top_ZN_1 Return Air Node Name, !- Inlet 4 Node Name
+ Perimeter_top_ZN_4 Return Air Node Name; !- Inlet 5 Node Name
+ VAV_1 Return Air Mixer, !- Name
+ VAV_1 Zone Equipment Outlet Node, !- Outlet Node Name
+ GROUNDFLOOR_PLENUMPlenumOutletNode; !- Inlet 1 Node Name
+ VAV_2 Return Air Mixer, !- Name
+ VAV_2 Zone Equipment Outlet Node, !- Outlet Node Name
+ MIDFLOOR_PLENUMPlenumOutletNode; !- Inlet 1 Node Name
+ VAV_3 Return Air Mixer, !- Name
+ VAV_3 Zone Equipment Outlet Node, !- Outlet Node Name
+ TOPFLOOR_PLENUMPlenumOutletNode; !- Inlet 1 Node Name
+ VAV_5 Return Air Mixer, !- Name
+ VAV_5 Zone Equipment Outlet Node, !- Outlet Node Name
+ Basement Return Air Node Name; !- Inlet 1 Node Name
+! ***SCHEDULES***
+ Schedule:Compact,
+ CLGSETP_SCH, !- Name
+ Temperature, !- Schedule Type Limits Name
+ Through: 12/31, !- Field 1
+ Until: 06:00,26.7, !- Field 3
+ Until: 22:00,24.0, !- Field 5
+ Until: 24:00,26.7, !- Field 7
+ For: Saturday, !- Field 9
+ Until: 06:00,26.7, !- Field 10
+ Until: 18:00,24.0, !- Field 12
+ Until: 24:00,26.7, !- Field 14
+ For WinterDesignDay, !- Field 16
+ Until: 24:00,26.7, !- Field 17
+ For: AllOtherDays, !- Field 19
+ Until: 24:00,26.7; !- Field 20
+ Schedule:Compact,
+ HTGSETP_SCH, !- Name
+ Until: 06:00,15.6, !- Field 3
+ Until: 22:00,21.0, !- Field 5
+ Until: 24:00,15.6, !- Field 7
+ For SummerDesignDay, !- Field 9
+ Until: 24:00,15.6, !- Field 10
+ For: Saturday, !- Field 12
+ Until: 06:00,15.6, !- Field 13
+ Until: 18:00,21.0, !- Field 15
+ Until: 24:00,15.6, !- Field 17
+ For: WinterDesignDay, !- Field 19
+ Until: 24:00,21.0, !- Field 20
+ For: AllOtherDays, !- Field 22
+ Until: 24:00,15.6; !- Field 23
+ Schedule:Compact,
+ Seasonal-Reset-Supply-Air-Temp-Sch, !- Name
+ For: AllDays, !- Field 2
+ Until: 24:00,12.8; !- Field 3
+ Schedule:Compact,
+ MinOA_MotorizedDamper_Sched, !- Name
+ Until: 07:00,0.0, !- Field 3
+ Until: 24:00,0.0, !- Field 7
+ Until: 07:00,0.0, !- Field 10
+ Until: 18:00,1.0, !- Field 12
+ Until: 24:00,0.0, !- Field 14
+ For: AllOtherDays, !- Field 16
+ Until: 24:00,0.0; !- Field 17
+ Schedule:Compact,
+ Dual Zone Control Type Sched, !- Name
+ Control Type, !- Schedule Type Limits Name
+ Until: 24:00,4; !- Field 3
+ Schedule:Compact,
+ HVACOperationSchd, !- Name
+ On/Off, !- Schedule Type Limits Name
+! ***EQUIPMENT***
+ Output:PreprocessorMessage,Conversion 7.2 => 8.0,Warning,
+Boiler:HotWater="HeatSys1 Boiler",
+ defaults for this object have changed. Results may be different than previous. See ,
+InputOutputReference document for details.;
+ Boiler:HotWater,
+ HeatSys1 Boiler, !- Name
+ NATURALGAS, !- Fuel Type
+ AUTOSIZE, !- Nominal Capacity {W}
+ 0.78, !- Nominal Thermal Efficiency
+ LeavingBoiler, !- Efficiency Curve Temperature Evaluation Variable
+ , !- Normalized Boiler Efficiency Curve Name
+ 82.2000, !- Design Water Outlet Temperature {C}
+ 0.0, !- Minimum Part Load Ratio
+ 1.2, !- Maximum Part Load Ratio
+ 1.0, !- Optimum Part Load Ratio
+ HeatSys1 Pump-HeatSys1 BoilerNode, !- Boiler Water Inlet Node Name
+ HeatSys1 Supply Equipment Outlet Node, !- Boiler Water Outlet Node Name
+ 95.0, !- Water Outlet Upper Temperature Limit {C}
+ LeavingSetpointModulated,!- Boiler Flow Mode
+ 0.0000, !- Parasitic Electric Load {W}
+ 1.0000; !- Sizing Factor
+ HeatSys1 Boiler Setpoint Manager, !- Name
+ HW-Loop-Temp-Schedule, !- Schedule Name
+ HeatSys1 Supply Equipment Outlet Node; !- Setpoint Node or NodeList Name
+Chiller:Electric:ReformulatedEIR="CoolSys1 Chiller 1",
+ defaults for this object have changed. See InputOutputReference document for details.;
+ Chiller:Electric:ReformulatedEIR,
+ CoolSys1 Chiller 1, !- Name
+ AUTOSIZE, !- Reference Capacity {W}
+ 5.5, !- Reference COP {W/W}
+ 6.67, !- Reference Leaving Chilled Water Temperature {C}
+ 35, !- Reference Leaving Condenser Water Temperature {C}
+ AutoSize, !- Reference Chilled Water Flow Rate {m3/s}
+ AutoSize, !- Reference Condenser Water Flow Rate {m3/s}
+ WC Screw Default 90.1-2004 Cap_fT, !- Cooling Capacity Function of Temperature Curve Name
+ WC Screw Default 90.1-2004 EIR_fT, !- Electric Input to Cooling Output Ratio Function of Temperature Curve Name
+ WC Screw GTE 300tons Default 90.1-2004 EIR_fPLR, !- Electric Input to Cooling Output Ratio Function of Part Load Ratio Curve Name
+ 0.1, !- Minimum Part Load Ratio
+ 1, !- Maximum Part Load Ratio
+ 1, !- Optimum Part Load Ratio
+ 0.2, !- Minimum Unloading Ratio
+ CoolSys1 Pump-CoolSys1 ChillerNode 1, !- Chilled Water Inlet Node Name
+ CoolSys1 Supply Equipment Outlet Node 1, !- Chilled Water Outlet Node Name
+ CoolSys1 Chiller Water Inlet Node 1, !- Condenser Inlet Node Name
+ CoolSys1 Chiller Water Outlet Node 1, !- Condenser Outlet Node Name
+ 1, !- Fraction of Compressor Electric Consumption Rejected by Condenser
+ 2, !- Leaving Chilled Water Lower Temperature Limit {C}
+ LeavingSetpointModulated,!- Chiller Flow Mode Type
+ , !- Design Heat Recovery Water Flow Rate {m3/s}
+ , !- Heat Recovery Inlet Node Name
+ , !- Heat Recovery Outlet Node Name
+ 0.4; !- Sizing Factor
+ CoolSys1 Chiller 1 Setpoint Manager, !- Name
+ CW-Loop-Temp-Schedule, !- Schedule Name
+ CoolSys1 Supply Equipment Outlet Node 1; !- Setpoint Node or NodeList Name
+Chiller:Electric:ReformulatedEIR="CoolSys1 Chiller 2",
+ CoolSys1 Chiller 2, !- Name
+ CoolSys1 Pump-CoolSys1 ChillerNode 2, !- Chilled Water Inlet Node Name
+ CoolSys1 Supply Equipment Outlet Node 2, !- Chilled Water Outlet Node Name
+ CoolSys1 Chiller Water Inlet Node 2, !- Condenser Inlet Node Name
+ CoolSys1 Chiller Water Outlet Node 2, !- Condenser Outlet Node Name
+ CoolSys1 Chiller 2 Setpoint Manager, !- Name
+ CoolSys1 Supply Equipment Outlet Node 2; !- Setpoint Node or NodeList Name
+ CoolingTower:SingleSpeed,
+ TowerWaterSys CoolTower, !- Name
+ TowerWaterSys Pump-TowerWaterSys CoolTowerNode, !- Water Inlet Node Name
+ TowerWaterSys Supply Equipment Outlet Node, !- Water Outlet Node Name
+ AUTOSIZE, !- Fan Power at Design Air Flow Rate {W}
+ AUTOSIZE, !- U-Factor Times Area Value at Design Air Flow Rate {W/K}
+ AUTOSIZE, !- Air Flow Rate in Free Convection Regime {m3/s}
+ AUTOSIZE, !- U-Factor Times Area Value at Free Convection Air Flow Rate {W/K}
+ , !- Nominal Capacity {W}
+ , !- Free Convection Capacity {W}
+ , !- Basin Heater Capacity {W/K}
+ , !- Basin Heater Setpoint Temperature {C}
+ , !- Basin Heater Operating Schedule Name
+ SaturatedExit, !- Evaporation Loss Mode
+ , !- Evaporation Loss Factor {percent/K}
+ 0.0080, !- Drift Loss Percent {percent}
+ ConcentrationRatio, !- Blowdown Calculation Mode
+ 3.0000, !- Blowdown Concentration Ratio
+ , !- Blowdown Makeup Water Usage Schedule Name
+ , !- Supply Water Storage Tank Name
+ TowerWaterSys CoolTower OA ref Node, !- Outdoor Air Inlet Node Name
+ FanCycling, !- Capacity Control
+ , !- Number of Cells
+ , !- Cell Control
+ , !- Cell Minimum Water Flow Rate Fraction
+ , !- Cell Maximum Water Flow Rate Fraction
+ Pump:VariableSpeed,
+ CoolSys1 Pump, !- Name
+ CoolSys1 Supply Inlet Node, !- Inlet Node Name
+ CoolSys1 Pump-CoolSys1 ChillerNodeviaConnector, !- Outlet Node Name
+ AUTOSIZE, !- Rated Flow Rate {m3/s}
+ 179352, !- Rated Pump Head {Pa}
+ AUTOSIZE, !- Rated Power Consumption {W}
+ 0.9, !- Motor Efficiency
+ 0.0, !- Fraction of Motor Inefficiencies to Fluid Stream
+ 0, !- Coefficient 1 of the Part Load Performance Curve
+ 1, !- Coefficient 2 of the Part Load Performance Curve
+ 0, !- Coefficient 3 of the Part Load Performance Curve
+ 0, !- Coefficient 4 of the Part Load Performance Curve
+ 0.0, !- Minimum Flow Rate {m3/s}
+ Intermittent, !- Pump Control Type
+ ; !- Pump Flow Rate Schedule Name
+ HeatSys1 Pump, !- Name
+ HeatSys1 Supply Inlet Node, !- Inlet Node Name
+ HeatSys1 Pump-HeatSys1 BoilerNodeviaConnector, !- Outlet Node Name
+ 0.875, !- Motor Efficiency
+ Pump:ConstantSpeed,
+ TowerWaterSys Pump, !- Name
+ TowerWaterSys Supply Inlet Node, !- Inlet Node Name
+ TowerWaterSys Pump-TowerWaterSys CoolTowerNodeviaConnector, !- Outlet Node Name
+ 0.87, !- Motor Efficiency
+ PlantEquipmentList,
+ CoolSys1 Equipment List, !- Name
+ Chiller:Electric:ReformulatedEIR, !- Equipment 1 Object Type
+ CoolSys1 Chiller 1, !- Equipment 1 Name
+ Chiller:Electric:ReformulatedEIR, !- Equipment 2 Object Type
+ CoolSys1 Chiller 2; !- Equipment 2 Name
+ HeatSys1 Equipment List, !- Name
+ Boiler:HotWater, !- Equipment 1 Object Type
+ HeatSys1 Boiler; !- Equipment 1 Name
+ CondenserEquipmentList,
+ TowerWaterSys Equipment List, !- Name
+ CoolingTower:SingleSpeed,!- Equipment 1 Object Type
+ TowerWaterSys CoolTower; !- Equipment 1 Name
+ Sizing:Plant,
+ CoolSys1, !- Plant or Condenser Loop Name
+ Cooling, !- Loop Type
+ 6.67, !- Design Loop Exit Temperature {C}
+ 6.67; !- Loop Design Temperature Difference {deltaC}
+ Sizing:Plant,
+ HeatSys1, !- Plant or Condenser Loop Name
+ Heating, !- Loop Type
+ 82.2, !- Design Loop Exit Temperature {C}
+ 11.1; !- Loop Design Temperature Difference {deltaC}
+ Sizing:Plant,
+ TowerWaterSys, !- Plant or Condenser Loop Name
+ CONDENSER, !- Loop Type
+ 29.4, !- Design Loop Exit Temperature {C}
+ 5.6; !- Loop Design Temperature Difference {deltaC}
+ VAV_1_CoolC_Controller, !- Name
+ Reverse, !- Action
+ Flow, !- Actuator Variable
+ VAV_1_CoolC-VAV_1_HeatCNode, !- Sensor Node Name
+ VAV_1_CoolCDemand Inlet Node, !- Actuator Node Name
+ , !- Controller Convergence Tolerance {deltaC}
+ AUTOSIZE, !- Maximum Actuated Flow {m3/s}
+ 0.0; !- Minimum Actuated Flow {m3/s}
+ VAV_1_HeatC_Controller, !- Name
+ Normal, !- Action
+ VAV_1_HeatC-VAV_1_FanNode, !- Sensor Node Name
+ VAV_1_HeatCDemand Inlet Node, !- Actuator Node Name
+ 0.0001, !- Controller Convergence Tolerance {deltaC}
+ VAV_2_CoolC_Controller, !- Name
+ VAV_2_CoolC-VAV_2_HeatCNode, !- Sensor Node Name
+ VAV_2_CoolCDemand Inlet Node, !- Actuator Node Name
+ VAV_2_HeatC_Controller, !- Name
+ Normal, !- Action
+ VAV_2_HeatC-VAV_2_FanNode, !- Sensor Node Name
+ VAV_2_HeatCDemand Inlet Node, !- Actuator Node Name
+ VAV_3_CoolC_Controller, !- Name
+ VAV_3_CoolC-VAV_3_HeatCNode, !- Sensor Node Name
+ VAV_3_CoolCDemand Inlet Node, !- Actuator Node Name
+ VAV_3_HeatC_Controller, !- Name
+ Normal, !- Action
+ VAV_3_HeatC-VAV_3_FanNode, !- Sensor Node Name
+ VAV_3_HeatCDemand Inlet Node, !- Actuator Node Name
+ VAV_5_CoolC_Controller, !- Name
+ VAV_5_CoolC-VAV_5_HeatCNode, !- Sensor Node Name
+ VAV_5_CoolCDemand Inlet Node, !- Actuator Node Name
+ VAV_5_HeatC_Controller, !- Name
+ Normal, !- Action
+ VAV_5_HeatC-VAV_5_FanNode, !- Sensor Node Name
+ VAV_5_HeatCDemand Inlet Node, !- Actuator Node Name
+! Curve adapted by R. Lord for ANSI/ASHRAE/IESNA 90.1-2004 performance
+! for a water-cooled, screw/scroll chiller
+ Curve:Biquadratic,
+ WC Screw Default 90.1-2004 Cap_fT, !- Name
+ 0.9061150, !- Coefficient1 Constant
+ 0.0292277, !- Coefficient2 x
+ -0.0003647, !- Coefficient3 x**2
+ -0.0009709, !- Coefficient4 y
+ -0.0000905, !- Coefficient5 y**2
+ 0.0002527, !- Coefficient6 x*y
+ 0.0, !- Minimum Value of x
+ 20.0, !- Maximum Value of x
+ 0.0, !- Minimum Value of y
+ 50.0; !- Maximum Value of y
+ WC Screw Default 90.1-2004 EIR_fT, !- Name
+ 0.3617105, !- Coefficient1 Constant
+ -0.0229833, !- Coefficient2 x
+ -0.0009519, !- Coefficient3 x**2
+ 0.0131889, !- Coefficient4 y
+ 0.0003752, !- Coefficient5 y**2
+ -0.0007059, !- Coefficient6 x*y
+ CoolSys1 Loop Setpoint Manager, !- Name
+ CoolSys1 Supply Outlet Node; !- Setpoint Node or NodeList Name
+ HeatSys1 Loop Setpoint Manager, !- Name
+ HeatSys1 Supply Outlet Node; !- Setpoint Node or NodeList Name
+ PlantEquipmentOperationSchemes,
+ CoolSys1 Loop Operation Scheme List, !- Name
+ PlantEquipmentOperation:CoolingLoad, !- Control Scheme 1 Object Type
+ CoolSys1 Operation Scheme, !- Control Scheme 1 Name
+ ALWAYS_ON; !- Control Scheme 1 Schedule Name
+ HeatSys1 Loop Operation Scheme List, !- Name
+ PlantEquipmentOperation:HeatingLoad, !- Control Scheme 1 Object Type
+ HeatSys1 Operation Scheme, !- Control Scheme 1 Name
+ CondenserEquipmentOperationSchemes,
+ TowerWaterSys Loop Operation Scheme List, !- Name
+ TowerWaterSys Operation Scheme, !- Control Scheme 1 Name
+ HeatSys1 Operation Scheme, !- Name
+ 0.0, !- Load Range 1 Lower Limit {W}
+ 1000000000000000, !- Load Range 1 Upper Limit {W}
+ HeatSys1 Equipment List; !- Range 1 Equipment List Name
+ CoolSys1 Operation Scheme, !- Name
+ 100000000000000, !- Load Range 1 Upper Limit {W}
+ CoolSys1 Equipment List; !- Range 1 Equipment List Name
+ TowerWaterSys Operation Scheme, !- Name
+ 1000000000000, !- Load Range 1 Upper Limit {W}
+ TowerWaterSys Equipment List; !- Range 1 Equipment List Name
+! ***LOOPS***
+ PlantLoop,
+ CoolSys1, !- Name
+ Water, !- Fluid Type
+ , !- User Defined Fluid Type
+ CoolSys1 Loop Operation Scheme List, !- Plant Equipment Operation Scheme Name
+ CoolSys1 Supply Outlet Node, !- Loop Temperature Setpoint Node Name
+ 98.0, !- Maximum Loop Temperature {C}
+ 1.0, !- Minimum Loop Temperature {C}
+ AUTOSIZE, !- Maximum Loop Flow Rate {m3/s}
+ 0.0, !- Minimum Loop Flow Rate {m3/s}
+ AUTOSIZE, !- Plant Loop Volume {m3}
+ CoolSys1 Supply Inlet Node, !- Plant Side Inlet Node Name
+ CoolSys1 Supply Outlet Node, !- Plant Side Outlet Node Name
+ CoolSys1 Supply Branches,!- Plant Side Branch List Name
+ CoolSys1 Supply Connectors, !- Plant Side Connector List Name
+ CoolSys1 Demand Inlet Node, !- Demand Side Inlet Node Name
+ CoolSys1 Demand Outlet Node, !- Demand Side Outlet Node Name
+ CoolSys1 Demand Branches,!- Demand Side Branch List Name
+ CoolSys1 Demand Connectors, !- Demand Side Connector List Name
+ Uniform; !- Load Distribution Scheme
+ PlantLoop,
+ HeatSys1, !- Name
+ HeatSys1 Loop Operation Scheme List, !- Plant Equipment Operation Scheme Name
+ HeatSys1 Supply Outlet Node, !- Loop Temperature Setpoint Node Name
+ 100.0, !- Maximum Loop Temperature {C}
+ 10.0, !- Minimum Loop Temperature {C}
+ HeatSys1 Supply Inlet Node, !- Plant Side Inlet Node Name
+ HeatSys1 Supply Outlet Node, !- Plant Side Outlet Node Name
+ HeatSys1 Supply Branches,!- Plant Side Branch List Name
+ HeatSys1 Supply Connectors, !- Plant Side Connector List Name
+ HeatSys1 Demand Inlet Node, !- Demand Side Inlet Node Name
+ HeatSys1 Demand Outlet Node, !- Demand Side Outlet Node Name
+ HeatSys1 Demand Branches,!- Demand Side Branch List Name
+ HeatSys1 Demand Connectors, !- Demand Side Connector List Name
+ Optimal; !- Load Distribution Scheme
+ CondenserLoop,
+ TowerWaterSys, !- Name
+ TowerWaterSys Loop Operation Scheme List, !- Condenser Equipment Operation Scheme Name
+ TowerWaterSys Supply Outlet Node, !- Condenser Loop Temperature Setpoint Node Name
+ 80.0, !- Maximum Loop Temperature {C}
+ 5.0, !- Minimum Loop Temperature {C}
+ AUTOSIZE, !- Condenser Loop Volume {m3}
+ TowerWaterSys Supply Inlet Node, !- Condenser Side Inlet Node Name
+ TowerWaterSys Supply Outlet Node, !- Condenser Side Outlet Node Name
+ TowerWaterSys Supply Branches, !- Condenser Side Branch List Name
+ TowerWaterSys Supply Connectors, !- Condenser Side Connector List Name
+ TowerWaterSys Demand Inlet Node, !- Demand Side Inlet Node Name
+ TowerWaterSys Demand Outlet Node, !- Demand Side Outlet Node Name
+ TowerWaterSys Demand Branches, !- Condenser Demand Side Branch List Name
+ TowerWaterSys Demand Connectors, !- Condenser Demand Side Connector List Name
+ Sequential; !- Load Distribution Scheme
+ SetpointManager:FollowOutdoorAirTemperature,
+ OutdoorAirWetBulb, !- Reference Temperature Type
+ 0, !- Offset Temperature Difference {deltaC}
+ 80.0, !- Maximum Setpoint Temperature {C}
+ 5.0, !- Minimum Setpoint Temperature {C}
+ TowerWaterSys Supply Outlet Node; !- Setpoint Node or NodeList Name
+ BranchList,
+ CoolSys1 Demand Branches,!- Name
+ CoolSys1 Demand Inlet Branch, !- Branch 1 Name
+ CoolSys1 Demand Load Branch 1, !- Branch 2 Name
+ CoolSys1 Demand Load Branch 2, !- Branch 3 Name
+ CoolSys1 Demand Load Branch 3, !- Branch 4 Name
+ CoolSys1 Demand Load Branch 4, !- Branch 5 Name
+ CoolSys1 Demand Bypass Branch, !- Branch 6 Name
+ CoolSys1 Demand Outlet Branch; !- Branch 7 Name
+ BranchList,
+ CoolSys1 Supply Branches,!- Name
+ CoolSys1 Supply Inlet Branch, !- Branch 1 Name
+ CoolSys1 Supply Equipment Branch 1, !- Branch 2 Name
+ CoolSys1 Supply Equipment Branch 2, !- Branch 3 Name
+ CoolSys1 Supply Equipment Bypass Branch, !- Branch 4 Name
+ CoolSys1 Supply Outlet Branch; !- Branch 5 Name
+ BranchList,
+ HeatSys1 Demand Branches,!- Name
+ HeatSys1 Demand Inlet Branch, !- Branch 1 Name
+ HeatSys1 Demand Load Branch 1, !- Branch 2 Name
+ HeatSys1 Demand Load Branch 2, !- Branch 3 Name
+ HeatSys1 Demand Load Branch 3, !- Branch 4 Name
+ HeatSys1 Demand Load Branch 4, !- Branch 5 Name
+ HeatSys1 Demand Load Branch 5, !- Branch 6 Name
+ HeatSys1 Demand Load Branch 6, !- Branch 7 Name
+ HeatSys1 Demand Load Branch 7, !- Branch 8 Name
+ HeatSys1 Demand Load Branch 8, !- Branch 9 Name
+ HeatSys1 Demand Load Branch 9, !- Branch 10 Name
+ HeatSys1 Demand Load Branch 10, !- Branch 11 Name
+ HeatSys1 Demand Load Branch 11, !- Branch 12 Name
+ HeatSys1 Demand Load Branch 12, !- Branch 13 Name
+ HeatSys1 Demand Load Branch 13, !- Branch 14 Name
+ HeatSys1 Demand Load Branch 14, !- Branch 15 Name
+ HeatSys1 Demand Load Branch 15, !- Branch 16 Name
+ HeatSys1 Demand Load Branch 16, !- Branch 17 Name
+ HeatSys1 Demand Load Branch 17, !- Branch 18 Name
+ HeatSys1 Demand Load Branch 18, !- Branch 19 Name
+ HeatSys1 Demand Load Branch 19, !- Branch 20 Name
+ HeatSys1 Demand Load Branch 20, !- Branch 21 Name
+ HeatSys1 Demand Bypass Branch, !- Branch 22 Name
+ HeatSys1 Demand Outlet Branch; !- Branch 23 Name
+ BranchList,
+ HeatSys1 Supply Branches,!- Name
+ HeatSys1 Supply Inlet Branch, !- Branch 1 Name
+ HeatSys1 Supply Equipment Branch, !- Branch 2 Name
+ HeatSys1 Supply Equipment Bypass Branch, !- Branch 3 Name
+ HeatSys1 Supply Outlet Branch; !- Branch 4 Name
+ BranchList,
+ TowerWaterSys Demand Branches, !- Name
+ TowerWaterSys Demand Inlet Branch, !- Branch 1 Name
+ TowerWaterSys Demand Load Branch 1, !- Branch 2 Name
+ TowerWaterSys Demand Load Branch 2, !- Branch 3 Name
+ TowerWaterSys Demand Bypass Branch, !- Branch 4 Name
+ TowerWaterSys Demand Outlet Branch; !- Branch 5 Name
+ BranchList,
+ TowerWaterSys Supply Branches, !- Name
+ TowerWaterSys Supply Inlet Branch, !- Branch 1 Name
+ TowerWaterSys Supply Equipment Branch, !- Branch 2 Name
+ TowerWaterSys Supply Equipment Bypass Branch, !- Branch 3 Name
+ TowerWaterSys Supply Outlet Branch; !- Branch 4 Name
+ Branch,
+ CoolSys1 Demand Bypass Branch, !- Name
+ , !- Maximum Flow Rate {m3/s}
+ Pipe:Adiabatic, !- Component 1 Object Type
+ CoolSys1 Demand Bypass Pipe, !- Component 1 Name
+ CoolSys1 Demand Bypass Pipe Inlet Node, !- Component 1 Inlet Node Name
+ CoolSys1 Demand Bypass Pipe Outlet Node, !- Component 1 Outlet Node Name
+ Bypass; !- Component 1 Branch Control Type
+ Branch,
+ CoolSys1 Demand Inlet Branch, !- Name
+ CoolSys1 Demand Inlet Pipe, !- Component 1 Name
+ CoolSys1 Demand Inlet Node, !- Component 1 Inlet Node Name
+ CoolSys1 Demand Inlet Pipe-CoolSys1 Demand Mixer, !- Component 1 Outlet Node Name
+ Passive; !- Component 1 Branch Control Type
+ Branch,
+ CoolSys1 Demand Load Branch 1, !- Name
+ Coil:Cooling:Water, !- Component 1 Object Type
+ VAV_5_CoolC, !- Component 1 Name
+ VAV_5_CoolCDemand Inlet Node, !- Component 1 Inlet Node Name
+ VAV_5_CoolCDemand Outlet Node, !- Component 1 Outlet Node Name
+ Active; !- Component 1 Branch Control Type
+ Branch,
+ CoolSys1 Demand Load Branch 2, !- Name
+ VAV_1_CoolC, !- Component 1 Name
+ VAV_1_CoolCDemand Inlet Node, !- Component 1 Inlet Node Name
+ VAV_1_CoolCDemand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ CoolSys1 Demand Load Branch 3, !- Name
+ VAV_2_CoolC, !- Component 1 Name
+ VAV_2_CoolCDemand Inlet Node, !- Component 1 Inlet Node Name
+ VAV_2_CoolCDemand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ CoolSys1 Demand Load Branch 4, !- Name
+ VAV_3_CoolC, !- Component 1 Name
+ VAV_3_CoolCDemand Inlet Node, !- Component 1 Inlet Node Name
+ VAV_3_CoolCDemand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ CoolSys1 Demand Outlet Branch, !- Name
+ CoolSys1 Demand Outlet Pipe, !- Component 1 Name
+ CoolSys1 Demand Mixer-CoolSys1 Demand Outlet Pipe, !- Component 1 Inlet Node Name
+ CoolSys1 Demand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ CoolSys1 Supply Equipment Branch 1, !- Name
+ Chiller:Electric:ReformulatedEIR, !- Component 1 Object Type
+ CoolSys1 Chiller 1, !- Component 1 Name
+ CoolSys1 Pump-CoolSys1 ChillerNode 1, !- Component 1 Inlet Node Name
+ CoolSys1 Supply Equipment Outlet Node 1, !- Component 1 Outlet Node Name
+ Branch,
+ CoolSys1 Supply Equipment Branch 2, !- Name
+ CoolSys1 Chiller 2, !- Component 1 Name
+ CoolSys1 Pump-CoolSys1 ChillerNode 2, !- Component 1 Inlet Node Name
+ CoolSys1 Supply Equipment Outlet Node 2, !- Component 1 Outlet Node Name
+ Branch,
+ CoolSys1 Supply Equipment Bypass Branch, !- Name
+ CoolSys1 Supply Equipment Bypass Pipe, !- Component 1 Name
+ CoolSys1 Supply Equip Bypass Inlet Node, !- Component 1 Inlet Node Name
+ CoolSys1 Supply Equip Bypass Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ CoolSys1 Supply Inlet Branch, !- Name
+ Pump:VariableSpeed, !- Component 1 Object Type
+ CoolSys1 Pump, !- Component 1 Name
+ CoolSys1 Supply Inlet Node, !- Component 1 Inlet Node Name
+ CoolSys1 Pump-CoolSys1 ChillerNodeviaConnector, !- Component 1 Outlet Node Name
+ Branch,
+ CoolSys1 Supply Outlet Branch, !- Name
+ CoolSys1 Supply Outlet Pipe, !- Component 1 Name
+ CoolSys1 Supply Mixer-CoolSys1 Supply Outlet Pipe, !- Component 1 Inlet Node Name
+ CoolSys1 Supply Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Demand Bypass Branch, !- Name
+ HeatSys1 Demand Bypass Pipe, !- Component 1 Name
+ HeatSys1 Demand Bypass Pipe Inlet Node, !- Component 1 Inlet Node Name
+ HeatSys1 Demand Bypass Pipe Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Demand Inlet Branch, !- Name
+ HeatSys1 Demand Inlet Pipe, !- Component 1 Name
+ HeatSys1 Demand Inlet Node, !- Component 1 Inlet Node Name
+ HeatSys1 Demand Inlet Pipe-HeatSys1 Demand Mixer, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Demand Load Branch 1, !- Name
+ Coil:Heating:Water, !- Component 1 Object Type
+ Basement VAV Box Reheat Coil, !- Component 1 Name
+ Basement VAV Box Reheat CoilDemand Inlet Node, !- Component 1 Inlet Node Name
+ Basement VAV Box Reheat CoilDemand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Demand Load Branch 10, !- Name
+ Perimeter_mid_ZN_2 VAV Box Reheat Coil, !- Component 1 Name
+ Perimeter_mid_ZN_2 VAV Box Reheat CoilDemand Inlet Node, !- Component 1 Inlet Node Name
+ Perimeter_mid_ZN_2 VAV Box Reheat CoilDemand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Demand Load Branch 11, !- Name
+ Perimeter_mid_ZN_1 VAV Box Reheat Coil, !- Component 1 Name
+ Perimeter_mid_ZN_1 VAV Box Reheat CoilDemand Inlet Node, !- Component 1 Inlet Node Name
+ Perimeter_mid_ZN_1 VAV Box Reheat CoilDemand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Demand Load Branch 12, !- Name
+ Perimeter_mid_ZN_4 VAV Box Reheat Coil, !- Component 1 Name
+ Perimeter_mid_ZN_4 VAV Box Reheat CoilDemand Inlet Node, !- Component 1 Inlet Node Name
+ Perimeter_mid_ZN_4 VAV Box Reheat CoilDemand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Demand Load Branch 13, !- Name
+ Perimeter_top_ZN_3 VAV Box Reheat Coil, !- Component 1 Name
+ Perimeter_top_ZN_3 VAV Box Reheat CoilDemand Inlet Node, !- Component 1 Inlet Node Name
+ Perimeter_top_ZN_3 VAV Box Reheat CoilDemand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Demand Load Branch 14, !- Name
+ Perimeter_top_ZN_2 VAV Box Reheat Coil, !- Component 1 Name
+ Perimeter_top_ZN_2 VAV Box Reheat CoilDemand Inlet Node, !- Component 1 Inlet Node Name
+ Perimeter_top_ZN_2 VAV Box Reheat CoilDemand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Demand Load Branch 15, !- Name
+ Perimeter_top_ZN_1 VAV Box Reheat Coil, !- Component 1 Name
+ Perimeter_top_ZN_1 VAV Box Reheat CoilDemand Inlet Node, !- Component 1 Inlet Node Name
+ Perimeter_top_ZN_1 VAV Box Reheat CoilDemand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Demand Load Branch 16, !- Name
+ Perimeter_top_ZN_4 VAV Box Reheat Coil, !- Component 1 Name
+ Perimeter_top_ZN_4 VAV Box Reheat CoilDemand Inlet Node, !- Component 1 Inlet Node Name
+ Perimeter_top_ZN_4 VAV Box Reheat CoilDemand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Demand Load Branch 17, !- Name
+ VAV_5_HeatC, !- Component 1 Name
+ VAV_5_HeatCDemand Inlet Node, !- Component 1 Inlet Node Name
+ VAV_5_HeatCDemand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Demand Load Branch 18, !- Name
+ VAV_1_HeatC, !- Component 1 Name
+ VAV_1_HeatCDemand Inlet Node, !- Component 1 Inlet Node Name
+ VAV_1_HeatCDemand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Demand Load Branch 19, !- Name
+ VAV_2_HeatC, !- Component 1 Name
+ VAV_2_HeatCDemand Inlet Node, !- Component 1 Inlet Node Name
+ VAV_2_HeatCDemand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Demand Load Branch 2, !- Name
+ Core_bottom VAV Box Reheat Coil, !- Component 1 Name
+ Core_bottom VAV Box Reheat CoilDemand Inlet Node, !- Component 1 Inlet Node Name
+ Core_bottom VAV Box Reheat CoilDemand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Demand Load Branch 20, !- Name
+ VAV_3_HeatC, !- Component 1 Name
+ VAV_3_HeatCDemand Inlet Node, !- Component 1 Inlet Node Name
+ VAV_3_HeatCDemand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Demand Load Branch 3, !- Name
+ Core_mid VAV Box Reheat Coil, !- Component 1 Name
+ Core_mid VAV Box Reheat CoilDemand Inlet Node, !- Component 1 Inlet Node Name
+ Core_mid VAV Box Reheat CoilDemand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Demand Load Branch 4, !- Name
+ Core_top VAV Box Reheat Coil, !- Component 1 Name
+ Core_top VAV Box Reheat CoilDemand Inlet Node, !- Component 1 Inlet Node Name
+ Core_top VAV Box Reheat CoilDemand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Demand Load Branch 5, !- Name
+ Perimeter_bot_ZN_3 VAV Box Reheat Coil, !- Component 1 Name
+ Perimeter_bot_ZN_3 VAV Box Reheat CoilDemand Inlet Node, !- Component 1 Inlet Node Name
+ Perimeter_bot_ZN_3 VAV Box Reheat CoilDemand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Demand Load Branch 6, !- Name
+ Perimeter_bot_ZN_2 VAV Box Reheat Coil, !- Component 1 Name
+ Perimeter_bot_ZN_2 VAV Box Reheat CoilDemand Inlet Node, !- Component 1 Inlet Node Name
+ Perimeter_bot_ZN_2 VAV Box Reheat CoilDemand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Demand Load Branch 7, !- Name
+ Perimeter_bot_ZN_1 VAV Box Reheat Coil, !- Component 1 Name
+ Perimeter_bot_ZN_1 VAV Box Reheat CoilDemand Inlet Node, !- Component 1 Inlet Node Name
+ Perimeter_bot_ZN_1 VAV Box Reheat CoilDemand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Demand Load Branch 8, !- Name
+ Perimeter_bot_ZN_4 VAV Box Reheat Coil, !- Component 1 Name
+ Perimeter_bot_ZN_4 VAV Box Reheat CoilDemand Inlet Node, !- Component 1 Inlet Node Name
+ Perimeter_bot_ZN_4 VAV Box Reheat CoilDemand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Demand Load Branch 9, !- Name
+ Perimeter_mid_ZN_3 VAV Box Reheat Coil, !- Component 1 Name
+ Perimeter_mid_ZN_3 VAV Box Reheat CoilDemand Inlet Node, !- Component 1 Inlet Node Name
+ Perimeter_mid_ZN_3 VAV Box Reheat CoilDemand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Demand Outlet Branch, !- Name
+ HeatSys1 Demand Outlet Pipe, !- Component 1 Name
+ HeatSys1 Demand Mixer-HeatSys1 Demand Outlet Pipe, !- Component 1 Inlet Node Name
+ HeatSys1 Demand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Supply Equipment Branch, !- Name
+ Boiler:HotWater, !- Component 1 Object Type
+ HeatSys1 Boiler, !- Component 1 Name
+ HeatSys1 Pump-HeatSys1 BoilerNode, !- Component 1 Inlet Node Name
+ HeatSys1 Supply Equipment Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Supply Equipment Bypass Branch, !- Name
+ HeatSys1 Supply Equipment Bypass Pipe, !- Component 1 Name
+ HeatSys1 Supply Equip Bypass Inlet Node, !- Component 1 Inlet Node Name
+ HeatSys1 Supply Equip Bypass Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Supply Inlet Branch, !- Name
+ HeatSys1 Pump, !- Component 1 Name
+ HeatSys1 Supply Inlet Node, !- Component 1 Inlet Node Name
+ HeatSys1 Pump-HeatSys1 BoilerNodeviaConnector, !- Component 1 Outlet Node Name
+ Branch,
+ HeatSys1 Supply Outlet Branch, !- Name
+ HeatSys1 Supply Outlet Pipe, !- Component 1 Name
+ HeatSys1 Supply Mixer-HeatSys1 Supply Outlet Pipe, !- Component 1 Inlet Node Name
+ HeatSys1 Supply Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ TowerWaterSys Demand Bypass Branch, !- Name
+ TowerWaterSys Demand Bypass Pipe, !- Component 1 Name
+ TowerWaterSys Demand Bypass Pipe Inlet Node, !- Component 1 Inlet Node Name
+ TowerWaterSys Demand Bypass Pipe Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ TowerWaterSys Demand Inlet Branch, !- Name
+ TowerWaterSys Demand Inlet Pipe, !- Component 1 Name
+ TowerWaterSys Demand Inlet Node, !- Component 1 Inlet Node Name
+ TowerWaterSys Demand Inlet Pipe-TowerWaterSys Demand Mixer, !- Component 1 Outlet Node Name
+ Branch,
+ TowerWaterSys Demand Load Branch 1, !- Name
+ CoolSys1 Chiller Water Inlet Node 1, !- Component 1 Inlet Node Name
+ CoolSys1 Chiller Water Outlet Node 1, !- Component 1 Outlet Node Name
+ Branch,
+ TowerWaterSys Demand Load Branch 2, !- Name
+ CoolSys1 Chiller Water Inlet Node 2, !- Component 1 Inlet Node Name
+ CoolSys1 Chiller Water Outlet Node 2, !- Component 1 Outlet Node Name
+ Branch,
+ TowerWaterSys Demand Outlet Branch, !- Name
+ TowerWaterSys Demand Outlet Pipe, !- Component 1 Name
+ TowerWaterSys Demand Mixer-TowerWaterSys Demand Outlet Pipe, !- Component 1 Inlet Node Name
+ TowerWaterSys Demand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ TowerWaterSys Supply Equipment Branch, !- Name
+ CoolingTower:SingleSpeed,!- Component 1 Object Type
+ TowerWaterSys CoolTower, !- Component 1 Name
+ TowerWaterSys Pump-TowerWaterSys CoolTowerNode, !- Component 1 Inlet Node Name
+ TowerWaterSys Supply Equipment Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ TowerWaterSys Supply Equipment Bypass Branch, !- Name
+ TowerWaterSys Supply Equipment Bypass Pipe, !- Component 1 Name
+ TowerWaterSys Supply Equip Bypass Inlet Node, !- Component 1 Inlet Node Name
+ TowerWaterSys Supply Equip Bypass Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ TowerWaterSys Supply Inlet Branch, !- Name
+ Pump:ConstantSpeed, !- Component 1 Object Type
+ TowerWaterSys Pump, !- Component 1 Name
+ TowerWaterSys Supply Inlet Node, !- Component 1 Inlet Node Name
+ TowerWaterSys Pump-TowerWaterSys CoolTowerNodeviaConnector, !- Component 1 Outlet Node Name
+ Branch,
+ TowerWaterSys Supply Outlet Branch, !- Name
+ TowerWaterSys Supply Outlet Pipe, !- Component 1 Name
+ TowerWaterSys Supply Mixer-TowerWaterSys Supply Outlet Pipe, !- Component 1 Inlet Node Name
+ TowerWaterSys Supply Outlet Node, !- Component 1 Outlet Node Name
+ OutdoorAir:Node,
+ TowerWaterSys CoolTower OA ref Node; !- Name
+ ConnectorList,
+ CoolSys1 Demand Connectors, !- Name
+ Connector:Splitter, !- Connector 1 Object Type
+ CoolSys1 Demand Splitter,!- Connector 1 Name
+ Connector:Mixer, !- Connector 2 Object Type
+ CoolSys1 Demand Mixer; !- Connector 2 Name
+ ConnectorList,
+ CoolSys1 Supply Connectors, !- Name
+ CoolSys1 Supply Splitter,!- Connector 1 Name
+ CoolSys1 Supply Mixer; !- Connector 2 Name
+ ConnectorList,
+ HeatSys1 Demand Connectors, !- Name
+ HeatSys1 Demand Splitter,!- Connector 1 Name
+ HeatSys1 Demand Mixer; !- Connector 2 Name
+ ConnectorList,
+ HeatSys1 Supply Connectors, !- Name
+ HeatSys1 Supply Splitter,!- Connector 1 Name
+ HeatSys1 Supply Mixer; !- Connector 2 Name
+ ConnectorList,
+ TowerWaterSys Demand Connectors, !- Name
+ TowerWaterSys Demand Splitter, !- Connector 1 Name
+ TowerWaterSys Demand Mixer; !- Connector 2 Name
+ ConnectorList,
+ TowerWaterSys Supply Connectors, !- Name
+ TowerWaterSys Supply Splitter, !- Connector 1 Name
+ TowerWaterSys Supply Mixer; !- Connector 2 Name
+ CoolSys1 Demand Splitter,!- Name
+ CoolSys1 Demand Inlet Branch, !- Inlet Branch Name
+ CoolSys1 Demand Load Branch 1, !- Outlet Branch 1 Name
+ CoolSys1 Demand Load Branch 2, !- Outlet Branch 2 Name
+ CoolSys1 Demand Load Branch 3, !- Outlet Branch 3 Name
+ CoolSys1 Demand Load Branch 4, !- Outlet Branch 4 Name
+ CoolSys1 Demand Bypass Branch; !- Outlet Branch 5 Name
+ CoolSys1 Supply Splitter,!- Name
+ CoolSys1 Supply Inlet Branch, !- Inlet Branch Name
+ CoolSys1 Supply Equipment Branch 1, !- Outlet Branch 1 Name
+ CoolSys1 Supply Equipment Branch 2, !- Outlet Branch 2 Name
+ CoolSys1 Supply Equipment Bypass Branch; !- Outlet Branch 3 Name
+ HeatSys1 Demand Splitter,!- Name
+ HeatSys1 Demand Inlet Branch, !- Inlet Branch Name
+ HeatSys1 Demand Load Branch 1, !- Outlet Branch 1 Name
+ HeatSys1 Demand Load Branch 2, !- Outlet Branch 2 Name
+ HeatSys1 Demand Load Branch 3, !- Outlet Branch 3 Name
+ HeatSys1 Demand Load Branch 4, !- Outlet Branch 4 Name
+ HeatSys1 Demand Load Branch 5, !- Outlet Branch 5 Name
+ HeatSys1 Demand Load Branch 6, !- Outlet Branch 6 Name
+ HeatSys1 Demand Load Branch 7, !- Outlet Branch 7 Name
+ HeatSys1 Demand Load Branch 8, !- Outlet Branch 8 Name
+ HeatSys1 Demand Load Branch 9, !- Outlet Branch 9 Name
+ HeatSys1 Demand Load Branch 10, !- Outlet Branch 10 Name
+ HeatSys1 Demand Load Branch 11, !- Outlet Branch 11 Name
+ HeatSys1 Demand Load Branch 12, !- Outlet Branch 12 Name
+ HeatSys1 Demand Load Branch 13, !- Outlet Branch 13 Name
+ HeatSys1 Demand Load Branch 14, !- Outlet Branch 14 Name
+ HeatSys1 Demand Load Branch 15, !- Outlet Branch 15 Name
+ HeatSys1 Demand Load Branch 16, !- Outlet Branch 16 Name
+ HeatSys1 Demand Load Branch 17, !- Outlet Branch 17 Name
+ HeatSys1 Demand Load Branch 18, !- Outlet Branch 18 Name
+ HeatSys1 Demand Load Branch 19, !- Outlet Branch 19 Name
+ HeatSys1 Demand Load Branch 20, !- Outlet Branch 20 Name
+ HeatSys1 Demand Bypass Branch; !- Outlet Branch 21 Name
+ HeatSys1 Supply Splitter,!- Name
+ HeatSys1 Supply Inlet Branch, !- Inlet Branch Name
+ HeatSys1 Supply Equipment Branch, !- Outlet Branch 1 Name
+ HeatSys1 Supply Equipment Bypass Branch; !- Outlet Branch 2 Name
+ TowerWaterSys Demand Splitter, !- Name
+ TowerWaterSys Demand Inlet Branch, !- Inlet Branch Name
+ TowerWaterSys Demand Load Branch 1, !- Outlet Branch 1 Name
+ TowerWaterSys Demand Load Branch 2, !- Outlet Branch 2 Name
+ TowerWaterSys Demand Bypass Branch; !- Outlet Branch 3 Name
+ TowerWaterSys Supply Splitter, !- Name
+ TowerWaterSys Supply Inlet Branch, !- Inlet Branch Name
+ TowerWaterSys Supply Equipment Branch, !- Outlet Branch 1 Name
+ TowerWaterSys Supply Equipment Bypass Branch; !- Outlet Branch 2 Name
+ Connector:Mixer,
+ CoolSys1 Demand Mixer, !- Name
+ CoolSys1 Demand Outlet Branch, !- Outlet Branch Name
+ CoolSys1 Demand Load Branch 1, !- Inlet Branch 1 Name
+ CoolSys1 Demand Load Branch 2, !- Inlet Branch 2 Name
+ CoolSys1 Demand Load Branch 3, !- Inlet Branch 3 Name
+ CoolSys1 Demand Load Branch 4, !- Inlet Branch 4 Name
+ CoolSys1 Demand Bypass Branch; !- Inlet Branch 5 Name
+ Connector:Mixer,
+ CoolSys1 Supply Mixer, !- Name
+ CoolSys1 Supply Outlet Branch, !- Outlet Branch Name
+ CoolSys1 Supply Equipment Branch 1, !- Inlet Branch 1 Name
+ CoolSys1 Supply Equipment Branch 2, !- Inlet Branch 2 Name
+ CoolSys1 Supply Equipment Bypass Branch; !- Inlet Branch 3 Name
+ Connector:Mixer,
+ HeatSys1 Demand Mixer, !- Name
+ HeatSys1 Demand Outlet Branch, !- Outlet Branch Name
+ HeatSys1 Demand Load Branch 1, !- Inlet Branch 1 Name
+ HeatSys1 Demand Load Branch 2, !- Inlet Branch 2 Name
+ HeatSys1 Demand Load Branch 3, !- Inlet Branch 3 Name
+ HeatSys1 Demand Load Branch 4, !- Inlet Branch 4 Name
+ HeatSys1 Demand Load Branch 5, !- Inlet Branch 5 Name
+ HeatSys1 Demand Load Branch 6, !- Inlet Branch 6 Name
+ HeatSys1 Demand Load Branch 7, !- Inlet Branch 7 Name
+ HeatSys1 Demand Load Branch 8, !- Inlet Branch 8 Name
+ HeatSys1 Demand Load Branch 9, !- Inlet Branch 9 Name
+ HeatSys1 Demand Load Branch 10, !- Inlet Branch 10 Name
+ HeatSys1 Demand Load Branch 11, !- Inlet Branch 11 Name
+ HeatSys1 Demand Load Branch 12, !- Inlet Branch 12 Name
+ HeatSys1 Demand Load Branch 13, !- Inlet Branch 13 Name
+ HeatSys1 Demand Load Branch 14, !- Inlet Branch 14 Name
+ HeatSys1 Demand Load Branch 15, !- Inlet Branch 15 Name
+ HeatSys1 Demand Load Branch 16, !- Inlet Branch 16 Name
+ HeatSys1 Demand Load Branch 17, !- Inlet Branch 17 Name
+ HeatSys1 Demand Load Branch 18, !- Inlet Branch 18 Name
+ HeatSys1 Demand Load Branch 19, !- Inlet Branch 19 Name
+ HeatSys1 Demand Load Branch 20, !- Inlet Branch 20 Name
+ HeatSys1 Demand Bypass Branch; !- Inlet Branch 21 Name
+ Connector:Mixer,
+ HeatSys1 Supply Mixer, !- Name
+ HeatSys1 Supply Outlet Branch, !- Outlet Branch Name
+ HeatSys1 Supply Equipment Branch, !- Inlet Branch 1 Name
+ HeatSys1 Supply Equipment Bypass Branch; !- Inlet Branch 2 Name
+ Connector:Mixer,
+ TowerWaterSys Demand Mixer, !- Name
+ TowerWaterSys Demand Outlet Branch, !- Outlet Branch Name
+ TowerWaterSys Demand Load Branch 1, !- Inlet Branch 1 Name
+ TowerWaterSys Demand Load Branch 2, !- Inlet Branch 2 Name
+ TowerWaterSys Demand Bypass Branch; !- Inlet Branch 3 Name
+ Connector:Mixer,
+ TowerWaterSys Supply Mixer, !- Name
+ TowerWaterSys Supply Outlet Branch, !- Outlet Branch Name
+ TowerWaterSys Supply Equipment Branch, !- Inlet Branch 1 Name
+ TowerWaterSys Supply Equipment Bypass Branch; !- Inlet Branch 2 Name
+ Pipe:Adiabatic,
+ CoolSys1 Demand Bypass Pipe, !- Name
+ CoolSys1 Demand Bypass Pipe Inlet Node, !- Inlet Node Name
+ CoolSys1 Demand Bypass Pipe Outlet Node; !- Outlet Node Name
+ Pipe:Adiabatic,
+ CoolSys1 Demand Inlet Pipe, !- Name
+ CoolSys1 Demand Inlet Node, !- Inlet Node Name
+ CoolSys1 Demand Inlet Pipe-CoolSys1 Demand Mixer; !- Outlet Node Name
+ Pipe:Adiabatic,
+ CoolSys1 Demand Outlet Pipe, !- Name
+ CoolSys1 Demand Mixer-CoolSys1 Demand Outlet Pipe, !- Inlet Node Name
+ CoolSys1 Demand Outlet Node; !- Outlet Node Name
+ Pipe:Adiabatic,
+ CoolSys1 Supply Equipment Bypass Pipe, !- Name
+ CoolSys1 Supply Equip Bypass Inlet Node, !- Inlet Node Name
+ CoolSys1 Supply Equip Bypass Outlet Node; !- Outlet Node Name
+ Pipe:Adiabatic,
+ CoolSys1 Supply Outlet Pipe, !- Name
+ CoolSys1 Supply Mixer-CoolSys1 Supply Outlet Pipe, !- Inlet Node Name
+ CoolSys1 Supply Outlet Node; !- Outlet Node Name
+ Pipe:Adiabatic,
+ HeatSys1 Demand Bypass Pipe, !- Name
+ HeatSys1 Demand Bypass Pipe Inlet Node, !- Inlet Node Name
+ HeatSys1 Demand Bypass Pipe Outlet Node; !- Outlet Node Name
+ Pipe:Adiabatic,
+ HeatSys1 Demand Inlet Pipe, !- Name
+ HeatSys1 Demand Inlet Node, !- Inlet Node Name
+ HeatSys1 Demand Inlet Pipe-HeatSys1 Demand Mixer; !- Outlet Node Name
+ Pipe:Adiabatic,
+ HeatSys1 Demand Outlet Pipe, !- Name
+ HeatSys1 Demand Mixer-HeatSys1 Demand Outlet Pipe, !- Inlet Node Name
+ HeatSys1 Demand Outlet Node; !- Outlet Node Name
+ Pipe:Adiabatic,
+ HeatSys1 Supply Equipment Bypass Pipe, !- Name
+ HeatSys1 Supply Equip Bypass Inlet Node, !- Inlet Node Name
+ HeatSys1 Supply Equip Bypass Outlet Node; !- Outlet Node Name
+ Pipe:Adiabatic,
+ HeatSys1 Supply Outlet Pipe, !- Name
+ HeatSys1 Supply Mixer-HeatSys1 Supply Outlet Pipe, !- Inlet Node Name
+ HeatSys1 Supply Outlet Node; !- Outlet Node Name
+ Pipe:Adiabatic,
+ TowerWaterSys Demand Bypass Pipe, !- Name
+ TowerWaterSys Demand Bypass Pipe Inlet Node, !- Inlet Node Name
+ TowerWaterSys Demand Bypass Pipe Outlet Node; !- Outlet Node Name
+ Pipe:Adiabatic,
+ TowerWaterSys Demand Inlet Pipe, !- Name
+ TowerWaterSys Demand Inlet Node, !- Inlet Node Name
+ TowerWaterSys Demand Inlet Pipe-TowerWaterSys Demand Mixer; !- Outlet Node Name
+ Pipe:Adiabatic,
+ TowerWaterSys Demand Outlet Pipe, !- Name
+ TowerWaterSys Demand Mixer-TowerWaterSys Demand Outlet Pipe, !- Inlet Node Name
+ TowerWaterSys Demand Outlet Node; !- Outlet Node Name
+ Pipe:Adiabatic,
+ TowerWaterSys Supply Equipment Bypass Pipe, !- Name
+ TowerWaterSys Supply Equip Bypass Inlet Node, !- Inlet Node Name
+ TowerWaterSys Supply Equip Bypass Outlet Node; !- Outlet Node Name
+ Pipe:Adiabatic,
+ TowerWaterSys Supply Outlet Pipe, !- Name
+ TowerWaterSys Supply Mixer-TowerWaterSys Supply Outlet Pipe, !- Inlet Node Name
+ TowerWaterSys Supply Outlet Node; !- Outlet Node Name
+! ***SCHEDULES***
+ Schedule:Compact,
+ CW-Loop-Temp-Schedule, !- Name
+ Until: 24:00,6.7; !- Field 3
+ Schedule:Compact,
+ HW-Loop-Temp-Schedule, !- Name
+ Until: 24:00,82.2; !- Field 3
+! ***SWH EQUIPMENT***
+ WaterHeater:Mixed,
+ SWHSys1 Water Heater, !- Name
+ 0.7571, !- Tank Volume {m3}
+ SWHSys1 Water Heater Setpoint Temperature Schedule Name, !- Setpoint Temperature Schedule Name
+ 2.0, !- Deadband Temperature Difference {deltaC}
+ 82.2222, !- Maximum Temperature Limit {C}
+ Cycle, !- Heater Control Type
+ 845000, !- Heater Maximum Capacity {W}
+ , !- Heater Minimum Capacity {W}
+ , !- Heater Ignition Minimum Flow Rate {m3/s}
+ , !- Heater Ignition Delay {s}
+ NATURALGAS, !- Heater Fuel Type
+ 0.8, !- Heater Thermal Efficiency
+ , !- Part Load Factor Curve Name
+ 20, !- Off Cycle Parasitic Fuel Consumption Rate {W}
+ NATURALGAS, !- Off Cycle Parasitic Fuel Type
+ 0.8, !- Off Cycle Parasitic Heat Fraction to Tank
+ , !- On Cycle Parasitic Fuel Consumption Rate {W}
+ NATURALGAS, !- On Cycle Parasitic Fuel Type
+ , !- On Cycle Parasitic Heat Fraction to Tank
+ SCHEDULE, !- Ambient Temperature Indicator
+ SWHSys1 Water Heater Ambient Temperature Schedule Name, !- Ambient Temperature Schedule Name
+ , !- Ambient Temperature Zone Name
+ , !- Ambient Temperature Outdoor Air Node Name
+ 6.0, !- Off Cycle Loss Coefficient to Ambient Temperature {W/K}
+ , !- Off Cycle Loss Fraction to Zone
+ 6.0, !- On Cycle Loss Coefficient to Ambient Temperature {W/K}
+ , !- On Cycle Loss Fraction to Zone
+ , !- Peak Use Flow Rate {m3/s}
+ , !- Use Flow Rate Fraction Schedule Name
+ , !- Cold Water Supply Temperature Schedule Name
+ SWHSys1 Pump-SWHSys1 Water HeaterNode, !- Use Side Inlet Node Name
+ SWHSys1 Supply Equipment Outlet Node, !- Use Side Outlet Node Name
+ 1.0, !- Use Side Effectiveness
+ , !- Source Side Inlet Node Name
+ , !- Source Side Outlet Node Name
+ 1.0, !- Source Side Effectiveness
+ AUTOSIZE, !- Use Side Design Flow Rate {m3/s}
+ AUTOSIZE, !- Source Side Design Flow Rate {m3/s}
+ 1.5; !- Indirect Water Heating Recovery Time {hr}
+ WaterUse:Equipment,
+ Core_bottom Water Equipment, !- Name
+ , !- End-Use Subcategory
+ 2.24e-005, !- Peak Flow Rate {m3/s}
+ BLDG_SWH_SCH, !- Flow Rate Fraction Schedule Name
+ Water Equipment Temp Sched, !- Target Temperature Schedule Name
+ Water Equipment Hot Supply Temp Sched, !- Hot Water Supply Temperature Schedule Name
+ Core_bottom, !- Zone Name
+ Water Equipment Sensible fract sched, !- Sensible Fraction Schedule Name
+ Water Equipment Latent fract sched; !- Latent Fraction Schedule Name
+ Core_mid Water Equipment,!- Name
+ Core_mid, !- Zone Name
+ Core_top Water Equipment,!- Name
+ Core_top, !- Zone Name
+ SWHSys1 Equipment List, !- Name
+ WaterHeater:Mixed, !- Equipment 1 Object Type
+ SWHSys1 Water Heater; !- Equipment 1 Name
+ SWHSys1 Pump, !- Name
+ SWHSys1 Supply Inlet Node, !- Inlet Node Name
+ SWHSys1 Pump-SWHSys1 Water HeaterNodeviaConnector, !- Outlet Node Name
+ 0.85, !- Motor Efficiency
+! ***SWH SIZING & CONTROLS***
+ Sizing:Plant,
+ SWHSys1, !- Plant or Condenser Loop Name
+ 60, !- Design Loop Exit Temperature {C}
+ 5.0; !- Loop Design Temperature Difference {deltaC}
+ SetpointManager:Scheduled,
+ SWHSys1 Loop Setpoint Manager, !- Name
+ Temperature, !- Control Variable
+ SWHSys1-Loop-Temp-Schedule, !- Schedule Name
+ SWHSys1 Supply Outlet Node; !- Setpoint Node or NodeList Name
+ SWHSys1 Loop Operation Scheme List, !- Name
+ SWHSys1 Operation Scheme,!- Control Scheme 1 Name
+ SWHSys1 Operation Scheme,!- Name
+ SWHSys1 Equipment List; !- Range 1 Equipment List Name
+! ***SWH LOOP***
+ PlantLoop,
+ SWHSys1, !- Name
+ SWHSys1 Loop Operation Scheme List, !- Plant Equipment Operation Scheme Name
+ SWHSys1 Supply Outlet Node, !- Loop Temperature Setpoint Node Name
+ 60.0, !- Maximum Loop Temperature {C}
+ SWHSys1 Supply Inlet Node, !- Plant Side Inlet Node Name
+ SWHSys1 Supply Outlet Node, !- Plant Side Outlet Node Name
+ SWHSys1 Supply Branches, !- Plant Side Branch List Name
+ SWHSys1 Supply Connectors, !- Plant Side Connector List Name
+ SWHSys1 Demand Inlet Node, !- Demand Side Inlet Node Name
+ SWHSys1 Demand Outlet Node, !- Demand Side Outlet Node Name
+ SWHSys1 Demand Branches, !- Demand Side Branch List Name
+ SWHSys1 Demand Connectors, !- Demand Side Connector List Name
+! ***SWH CONNECTIONS***
+ BranchList,
+ SWHSys1 Demand Branches, !- Name
+ SWHSys1 Demand Inlet Branch, !- Branch 1 Name
+ SWHSys1 Demand Load Branch 1, !- Branch 2 Name
+ SWHSys1 Demand Load Branch 2, !- Branch 3 Name
+ SWHSys1 Demand Load Branch 3, !- Branch 4 Name
+ SWHSys1 Demand Bypass Branch, !- Branch 5 Name
+ SWHSys1 Demand Outlet Branch; !- Branch 6 Name
+ BranchList,
+ SWHSys1 Supply Branches, !- Name
+ SWHSys1 Supply Inlet Branch, !- Branch 1 Name
+ SWHSys1 Supply Equipment Branch, !- Branch 2 Name
+ SWHSys1 Supply Equipment Bypass Branch, !- Branch 3 Name
+ SWHSys1 Supply Outlet Branch; !- Branch 4 Name
+ Branch,
+ SWHSys1 Demand Bypass Branch, !- Name
+ SWHSys1 Demand Bypass Pipe, !- Component 1 Name
+ SWHSys1 Demand Bypass Pipe Inlet Node, !- Component 1 Inlet Node Name
+ SWHSys1 Demand Bypass Pipe Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ SWHSys1 Demand Inlet Branch, !- Name
+ SWHSys1 Demand Inlet Pipe, !- Component 1 Name
+ SWHSys1 Demand Inlet Node, !- Component 1 Inlet Node Name
+ SWHSys1 Demand Inlet Pipe-SWHSys1 Demand Mixer, !- Component 1 Outlet Node Name
+ Branch,
+ SWHSys1 Demand Load Branch 1, !- Name
+ WaterUse:Connections, !- Component 1 Object Type
+ Core_bottom Water Equipment, !- Component 1 Name
+ Core_bottom Water Equipment Water Inlet Node, !- Component 1 Inlet Node Name
+ Core_bottom Water Equipment Water Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ SWHSys1 Demand Load Branch 2, !- Name
+ Core_mid Water Equipment,!- Component 1 Name
+ Core_mid Water Equipment Water Inlet Node, !- Component 1 Inlet Node Name
+ Core_mid Water Equipment Water Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ SWHSys1 Demand Load Branch 3, !- Name
+ Core_top Water Equipment,!- Component 1 Name
+ Core_top Water Equipment Water Inlet Node, !- Component 1 Inlet Node Name
+ Core_top Water Equipment Water Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ SWHSys1 Demand Outlet Branch, !- Name
+ SWHSys1 Demand Outlet Pipe, !- Component 1 Name
+ SWHSys1 Demand Mixer-SWHSys1 Demand Outlet Pipe, !- Component 1 Inlet Node Name
+ SWHSys1 Demand Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ SWHSys1 Supply Equipment Branch, !- Name
+ WaterHeater:Mixed, !- Component 1 Object Type
+ SWHSys1 Water Heater, !- Component 1 Name
+ SWHSys1 Pump-SWHSys1 Water HeaterNode, !- Component 1 Inlet Node Name
+ SWHSys1 Supply Equipment Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ SWHSys1 Supply Equipment Bypass Branch, !- Name
+ , !- Pressure Drop Curve Name
+ SWHSys1 Supply Equipment Bypass Pipe, !- Component 1 Name
+ SWHSys1 Supply Equip Bypass Inlet Node, !- Component 1 Inlet Node Name
+ SWHSys1 Supply Equip Bypass Outlet Node, !- Component 1 Outlet Node Name
+ Branch,
+ SWHSys1 Supply Inlet Branch, !- Name
+ SWHSys1 Pump, !- Component 1 Name
+ SWHSys1 Supply Inlet Node, !- Component 1 Inlet Node Name
+ SWHSys1 Pump-SWHSys1 Water HeaterNodeviaConnector, !- Component 1 Outlet Node Name
+ Branch,
+ SWHSys1 Supply Outlet Branch, !- Name
+ SWHSys1 Supply Outlet Pipe, !- Component 1 Name
+ SWHSys1 Supply Mixer-SWHSys1 Supply Outlet Pipe, !- Component 1 Inlet Node Name
+ SWHSys1 Supply Outlet Node, !- Component 1 Outlet Node Name
+ ConnectorList,
+ SWHSys1 Demand Connectors, !- Name
+ SWHSys1 Demand Splitter, !- Connector 1 Name
+ SWHSys1 Demand Mixer; !- Connector 2 Name
+ ConnectorList,
+ SWHSys1 Supply Connectors, !- Name
+ SWHSys1 Supply Splitter, !- Connector 1 Name
+ SWHSys1 Supply Mixer; !- Connector 2 Name
+ Core_bottom Water Equipment Water Inlet Node, !- Inlet Node Name
+ Core_bottom Water Equipment Water Outlet Node, !- Outlet Node Name
+ , !- Reclamation Water Storage Tank Name
+ , !- Hot Water Supply Temperature Schedule Name
+ , !- Drain Water Heat Exchanger Type
+ , !- Drain Water Heat Exchanger Destination
+ , !- Drain Water Heat Exchanger U-Factor Times Area {W/K}
+ Core_bottom Water Equipment; !- Water Use Equipment 1 Name
+ Core_mid Water Equipment Water Inlet Node, !- Inlet Node Name
+ Core_mid Water Equipment Water Outlet Node, !- Outlet Node Name
+ Core_mid Water Equipment;!- Water Use Equipment 1 Name
+ Core_top Water Equipment Water Inlet Node, !- Inlet Node Name
+ Core_top Water Equipment Water Outlet Node, !- Outlet Node Name
+ Core_top Water Equipment;!- Water Use Equipment 1 Name
+ SWHSys1 Demand Splitter, !- Name
+ SWHSys1 Demand Inlet Branch, !- Inlet Branch Name
+ SWHSys1 Demand Load Branch 1, !- Outlet Branch 1 Name
+ SWHSys1 Demand Load Branch 2, !- Outlet Branch 2 Name
+ SWHSys1 Demand Load Branch 3, !- Outlet Branch 3 Name
+ SWHSys1 Demand Bypass Branch; !- Outlet Branch 4 Name
+ SWHSys1 Supply Splitter, !- Name
+ SWHSys1 Supply Inlet Branch, !- Inlet Branch Name
+ SWHSys1 Supply Equipment Branch, !- Outlet Branch 1 Name
+ SWHSys1 Supply Equipment Bypass Branch; !- Outlet Branch 2 Name
+ Connector:Mixer,
+ SWHSys1 Demand Mixer, !- Name
+ SWHSys1 Demand Outlet Branch, !- Outlet Branch Name
+ SWHSys1 Demand Load Branch 1, !- Inlet Branch 1 Name
+ SWHSys1 Demand Load Branch 2, !- Inlet Branch 2 Name
+ SWHSys1 Demand Load Branch 3, !- Inlet Branch 3 Name
+ SWHSys1 Demand Bypass Branch; !- Inlet Branch 4 Name
+ Connector:Mixer,
+ SWHSys1 Supply Mixer, !- Name
+ SWHSys1 Supply Outlet Branch, !- Outlet Branch Name
+ SWHSys1 Supply Equipment Branch, !- Inlet Branch 1 Name
+ SWHSys1 Supply Equipment Bypass Branch; !- Inlet Branch 2 Name
+ Pipe:Adiabatic,
+ SWHSys1 Demand Bypass Pipe, !- Name
+ SWHSys1 Demand Bypass Pipe Inlet Node, !- Inlet Node Name
+ SWHSys1 Demand Bypass Pipe Outlet Node; !- Outlet Node Name
+ Pipe:Adiabatic,
+ SWHSys1 Demand Inlet Pipe, !- Name
+ SWHSys1 Demand Inlet Node, !- Inlet Node Name
+ SWHSys1 Demand Inlet Pipe-SWHSys1 Demand Mixer; !- Outlet Node Name
+ Pipe:Adiabatic,
+ SWHSys1 Demand Outlet Pipe, !- Name
+ SWHSys1 Demand Mixer-SWHSys1 Demand Outlet Pipe, !- Inlet Node Name
+ SWHSys1 Demand Outlet Node; !- Outlet Node Name
+ Pipe:Adiabatic,
+ SWHSys1 Supply Equipment Bypass Pipe, !- Name
+ SWHSys1 Supply Equip Bypass Inlet Node, !- Inlet Node Name
+ SWHSys1 Supply Equip Bypass Outlet Node; !- Outlet Node Name
+ Pipe:Adiabatic,
+ SWHSys1 Supply Outlet Pipe, !- Name
+ SWHSys1 Supply Mixer-SWHSys1 Supply Outlet Pipe, !- Inlet Node Name
+ SWHSys1 Supply Outlet Node; !- Outlet Node Name
+! ***SWH SCHEDULES***
+ Schedule:Compact,
+ BLDG_SWH_SCH, !- Name
+ Fraction, !- Schedule Type Limits Name
+ For: Weekdays SummerDesignDay, !- Field 2
+ Until: 05:00,0.05, !- Field 3
+ Until: 06:00,0.08, !- Field 5
+ Until: 07:00,0.07, !- Field 7
+ Until: 08:00,0.19, !- Field 9
+ Until: 09:00,0.35, !- Field 11
+ Until: 10:00,0.38, !- Field 13
+ Until: 11:00,0.39, !- Field 15
+ Until: 12:00,0.47, !- Field 17
+ Until: 13:00,0.57, !- Field 19
+ Until: 14:00,0.54, !- Field 21
+ Until: 15:00,0.34, !- Field 23
+ Until: 16:00,0.33, !- Field 25
+ Until: 17:00,0.44, !- Field 27
+ Until: 18:00,0.26, !- Field 29
+ Until: 19:00,0.21, !- Field 31
+ Until: 20:00,0.15, !- Field 33
+ Until: 21:00,0.17, !- Field 35
+ Until: 22:00,0.08, !- Field 37
+ Until: 24:00,0.05, !- Field 39
+ For: Saturday WinterDesignDay, !- Field 41
+ Until: 05:00,0.05, !- Field 42
+ Until: 06:00,0.08, !- Field 44
+ Until: 07:00,0.07, !- Field 46
+ Until: 08:00,0.11, !- Field 48
+ Until: 09:00,0.15, !- Field 50
+ Until: 10:00,0.21, !- Field 52
+ Until: 11:00,0.19, !- Field 54
+ Until: 12:00,0.23, !- Field 56
+ Until: 13:00,0.20, !- Field 58
+ Until: 14:00,0.19, !- Field 60
+ Until: 15:00,0.15, !- Field 62
+ Until: 16:00,0.13, !- Field 64
+ Until: 17:00,0.14, !- Field 66
+ Until: 21:00,0.07, !- Field 68
+ Until: 22:00,0.09, !- Field 70
+ Until: 24:00,0.05, !- Field 72
+ For: AllOtherDays, !- Field 74
+ Until: 05:00,0.04, !- Field 75
+ Until: 06:00,0.07, !- Field 77
+ Until: 11:00,0.04, !- Field 79
+ Until: 13:00,0.06, !- Field 81
+ Until: 14:00,0.09, !- Field 83
+ Until: 15:00,0.06, !- Field 85
+ Until: 21:00,0.04, !- Field 87
+ Until: 22:00,0.07, !- Field 89
+ Until: 24:00,0.04; !- Field 91
+ Schedule:Compact,
+ Water Equipment Latent fract sched, !- Name
+ Until: 24:00,0.05; !- Field 3
+ Schedule:Compact,
+ Water Equipment Sensible fract sched, !- Name
+ Until: 24:00,0.2; !- Field 3
+ Schedule:Compact,
+ SWHSys1 Water Heater Ambient Temperature Schedule Name, !- Name
+ Until: 24:00,22.0; !- Field 3
+ Schedule:Compact,
+ Water Equipment Temp Sched, !- Name
+ Until: 24:00,43.3; !- Field 3
+ Schedule:Compact,
+ Water Equipment Hot Supply Temp Sched, !- Name
+ Schedule:Compact,
+ SWHSys1 Water Heater Setpoint Temperature Schedule Name, !- Name
+ Until: 24:00,60.0; !- Field 3
+ Schedule:Compact,
+ SWHSys1-Loop-Temp-Schedule, !- Name
+! ***ECONOMICS***
+! IN_EIAMonthlyRateGas, Source EIA historical Nov2003 thru Oct2004
+! Indiana 1999 state average electricity emissions factors based on eGRID, 1065, AirData
+! PSI_CS_CommercialElectricService, source http://www.cinergypsi.com/pdfs/RateCS.pdf, effective 2004-05-24
+! PSI_LLF_LowLoadFactorService,source http://www.cinergypsi.com/pdfs/RATELLF.pdf, effective 2004-05-24
+ UtilityCost:Tariff,
+ PSI_LLF_LowLoadFactorService, !- Name
+ Electricity:Facility, !- Output Meter Name
+ kWh, !- Conversion Factor Choice
+ , !- Energy Conversion Factor
+ , !- Demand Conversion Factor
+ , !- Time of Use Period Schedule Name
+ , !- Season Schedule Name
+ , !- Month Schedule Name
+ HalfHour, !- Demand Window Length
+ 15.00, !- Monthly Charge or Variable Name
+ , !- Minimum Monthly Charge or Variable Name
+ , !- Real Time Pricing Charge Schedule Name
+ , !- Customer Baseline Load Schedule Name
+ Comm Elect; !- Group Name
+ UtilityCost:Charge:Block,
+ AnnualEnergyCharge, !- Name
+ PSI_LLF_LowLoadFactorService, !- Tariff Name
+ totalEnergy, !- Source Variable
+ Annual, !- Season
+ EnergyCharges, !- Category Variable Name
+ , !- Remaining Into Variable
+ , !- Block Size Multiplier Value or Variable Name
+ 300, !- Block Size 1 Value or Variable Name
+ 0.108222, !- Block 1 Cost per Unit Value or Variable Name
+ 700, !- Block Size 2 Value or Variable Name
+ 0.087021, !- Block 2 Cost per Unit Value or Variable Name
+ 1500, !- Block Size 3 Value or Variable Name
+ 0.078420, !- Block 3 Cost per Unit Value or Variable Name
+ remaining, !- Block Size 4 Value or Variable Name
+ 0.058320; !- Block 4 Cost per Unit Value or Variable Name
+ AnnualDemandBaseCharge, !- Name
+ Annual, !- Season
+ TotalDemand, !- Block Size Multiplier Value or Variable Name
+ 190, !- Block Size 1 Value or Variable Name
+ 0.0, !- Block 1 Cost per Unit Value or Variable Name
+ 110, !- Block Size 2 Value or Variable Name
+ 0.051773, !- Block 2 Cost per Unit Value or Variable Name
+ remaining, !- Block Size 3 Value or Variable Name
+ 0.046965; !- Block 3 Cost per Unit Value or Variable Name
+ UtilityCost:Charge:Simple,
+ FuelCostAdjustEnergyCharge, !- Name
+ Annual, !- Season
+ 0.002028; !- Cost per Unit Value or Variable Name
+ QualPollutionControlAdjustEnergyCharge, !- Name
+ Annual, !- Season
+ 0.000536; !- Cost per Unit Value or Variable Name
+ SoxNoxRiderAdjustEnergyCharge, !- Name
+ Annual, !- Season
+ 0.001127; !- Cost per Unit Value or Variable Name
+ DSMRiderAdjustEnergyCharge, !- Name
+ Annual, !- Season
+ -0.000370; !- Cost per Unit Value or Variable Name
+ PurchPowerTrackerAdjustEnergyCharge, !- Name
+ Annual, !- Season
+ -0.000031; !- Cost per Unit Value or Variable Name
+ MidwestISOAdjustEnergyCharge, !- Name
+ Annual, !- Season
+ -0.000216; !- Cost per Unit Value or Variable Name
+ CleanCoalRiderEnergyCharge, !- Name
+ Annual, !- Season
+ 0.000833; !- Cost per Unit Value or Variable Name
+ UtilityCost:Qualify,
+ MinDemand75kw, !- Name
+ TotalDemand, !- Variable Name
+ Minimum, !- Qualify Type
+ 75, !- Threshold Value or Variable Name
+ Annual, !- Season
+ Count, !- Threshold Test
+ 12; !- Number of Months
+ TaxofeightPercent, !- Name
+ SubTotal, !- Source Variable
+ Annual, !- Season
+ Taxes, !- Category Variable Name
+ 0.08; !- Cost per Unit Value or Variable Name
+!end PSI_LLF_LowLoadFactorService
+ PSI_CS_CommercialElectricService, !- Name
+ , !- Demand Window Length
+ 9.40, !- Monthly Charge or Variable Name
+ PSI_CS_CommercialElectricService, !- Tariff Name
+ Annual, !- Season
+ 0.082409, !- Block 1 Cost per Unit Value or Variable Name
+ 0.072873, !- Block 2 Cost per Unit Value or Variable Name
+ 0.061696, !- Block 3 Cost per Unit Value or Variable Name
+ 0.041179; !- Block 4 Cost per Unit Value or Variable Name
+ Annual, !- Season
+ Annual, !- Season
+ Annual, !- Season
+ Annual, !- Season
+ 0.000021; !- Cost per Unit Value or Variable Name
+ Annual, !- Season
+ 0.000034; !- Cost per Unit Value or Variable Name
+ Annual, !- Season
+ -0.000203; !- Cost per Unit Value or Variable Name
+ Annual, !- Season
+ 0.000807; !- Cost per Unit Value or Variable Name
+ MaxDemand75kw, !- Name
+ Maximum, !- Qualify Type
+ Annual, !- Season
+ 1; !- Number of Months
+ Annual, !- Season
+ IN_EIAMonthlyRateGas, !- Name
+ Gas:Facility, !- Output Meter Name
+ MCF, !- Conversion Factor Choice
+ 0.0, !- Monthly Charge or Variable Name
+ Comm Gas; !- Group Name
+ MonthlyRateGasCharge, !- Name
+ IN_EIAMonthlyRateGas, !- Tariff Name
+ Annual, !- Season
+ IN_MonthlyGasRates; !- Cost per Unit Value or Variable Name
+ UtilityCost:Variable,
+ IN_MonthlyGasRates, !- Name
+ Currency, !- Variable Type
+ 8.22, !- January Value
+ 7.51, !- February Value
+ 8.97, !- March Value
+ 9.01, !- April Value
+ 9.16, !- May Value
+ 10.44, !- June Value
+ 10.32, !- July Value
+ 10.13, !- August Value
+ 9.20, !- September Value
+ 8.18, !- October Value
+ 7.83, !- November Value
+ 7.63; !- December Value
+ TaxofEightPercent, !- Name
+ Annual, !- Season
+! ***GENERAL REPORTING***
+ OutputControl:ReportingTolerances,
+ 0.556, !- Tolerance for Time Heating Setpoint Not Met {deltaC}
+ 0.556; !- Tolerance for Time Cooling Setpoint Not Met {deltaC}
+ Output:SQLite,
+ SimpleAndTabular; !- Option Type
+ EnvironmentalImpactFactors,
+ 0.663, !- District Heating Efficiency
+ 4.18, !- District Cooling COP {W/W}
+ 0.585, !- Steam Conversion Efficiency
+ 80.7272, !- Total Carbon Equivalent Emission Factor From N2O {kg/kg}
+ 6.2727, !- Total Carbon Equivalent Emission Factor From CH4 {kg/kg}
+ 0.2727; !- Total Carbon Equivalent Emission Factor From CO2 {kg/kg}
+! Indiana electricity source and emission factors based on Deru and Torcellini 2007
+ FuelFactors,
+ Electricity, !- Existing Fuel Resource Name
+ kg, !- Units of Measure
+ , !- Energy per Unit Factor
+ 3.546, !- Source Energy Factor {J/J}
+ , !- Source Energy Schedule Name
+ 3.417E+02, !- CO2 Emission Factor {g/MJ}
+ , !- CO2 Emission Factor Schedule Name
+ 1.186E-01, !- CO Emission Factor {g/MJ}
+ , !- CO Emission Factor Schedule Name
+ 7.472E-01, !- CH4 Emission Factor {g/MJ}
+ , !- CH4 Emission Factor Schedule Name
+ 6.222E-01, !- NOx Emission Factor {g/MJ}
+ , !- NOx Emission Factor Schedule Name
+ 8.028E-03, !- N2O Emission Factor {g/MJ}
+ , !- N2O Emission Factor Schedule Name
+ 1.872E+00, !- SO2 Emission Factor {g/MJ}
+ , !- SO2 Emission Factor Schedule Name
+ 0.0, !- PM Emission Factor {g/MJ}
+ , !- PM Emission Factor Schedule Name
+ 1.739E-02, !- PM10 Emission Factor {g/MJ}
+ , !- PM10 Emission Factor Schedule Name
+ 0.0, !- PM2.5 Emission Factor {g/MJ}
+ , !- PM2.5 Emission Factor Schedule Name
+ 0.0, !- NH3 Emission Factor {g/MJ}
+ , !- NH3 Emission Factor Schedule Name
+ 1.019E-02, !- NMVOC Emission Factor {g/MJ}
+ , !- NMVOC Emission Factor Schedule Name
+ 5.639E-06, !- Hg Emission Factor {g/MJ}
+ , !- Hg Emission Factor Schedule Name
+ 2.778E-05, !- Pb Emission Factor {g/MJ}
+ , !- Pb Emission Factor Schedule Name
+ 0.4309556, !- Water Emission Factor {L/MJ}
+ , !- Water Emission Factor Schedule Name
+ 0, !- Nuclear High Level Emission Factor {g/MJ}
+ , !- Nuclear High Level Emission Factor Schedule Name
+ 0; !- Nuclear Low Level Emission Factor {m3/MJ}
+! Deru and Torcellini 2007
+! Source Energy and Emission Factors for Energy Use in Buildings
+! NREL/TP-550-38617
+! source factor and Higher Heating Values from Table 5
+! post-combustion emission factors for boiler from Table 9 (with factor of 1000 correction for natural gas)
+ FuelFactors,
+ NaturalGas, !- Existing Fuel Resource Name
+ m3, !- Units of Measure
+ 37631000, !- Energy per Unit Factor
+ 1.092, !- Source Energy Factor {J/J}
+ 5.21E+01, !- CO2 Emission Factor {g/MJ}
+ 3.99E-02, !- CO Emission Factor {g/MJ}
+ 1.06E-03, !- CH4 Emission Factor {g/MJ}
+ 4.73E-02, !- NOx Emission Factor {g/MJ}
+ 1.06E-03, !- N2O Emission Factor {g/MJ}
+ 2.68E-04, !- SO2 Emission Factor {g/MJ}
+ 3.59E-03, !- PM10 Emission Factor {g/MJ}
+ 0, !- NH3 Emission Factor {g/MJ}
+ 2.61E-03, !- NMVOC Emission Factor {g/MJ}
+ 1.11E-07, !- Hg Emission Factor {g/MJ}
+ 2.13E-07, !- Pb Emission Factor {g/MJ}
+ 0, !- Water Emission Factor {L/MJ}
+ Curve:Bicubic,
+ WC Screw GTE 300tons Default 90.1-2004 EIR_fPLR, !- Name
+ -2.737954E-01, !- Coefficient1 Constant
+ 2.822257E-02, !- Coefficient2 x
+ -8.097657E-05, !- Coefficient3 x**2
+ 9.612284E-01, !- Coefficient4 y
+ 3.029741E-01, !- Coefficient5 y**2
+ -2.421933E-02, !- Coefficient6 x*y
+ 0.000000E+00, !- Coefficient7 x**3
+ -3.885224E-02, !- Coefficient8 y**3
+ 0.000000E+00, !- Coefficient9 x**2*y
+ 0.000000E+00, !- Coefficient10 x*y**2
+ 18.54, !- Minimum Value of x
+ 31.63, !- Maximum Value of x
+ 0.20, !- Minimum Value of y
+ 1.02; !- Maximum Value of y
+ OutputControl:Table:Style,
+ HTML; !- Column Separator
+ Output:Table:SummaryReports,
+ AllSummary; !- Report 1 Name
+ Output:Meter,Electricity:Facility,hourly;
+ Output:Meter,Heating:Electricity,hourly;
+ Output:Meter,Cooling:Electricity,hourly;
+ Output:Meter,InteriorLights:Electricity,hourly;
+ Output:Meter,ExteriorLights:Electricity,hourly;
+ Output:Meter,InteriorEquipment:Electricity,hourly;
+ Output:Meter,ExteriorEquipment:Electricity,hourly;
+ Output:Meter,Fans:Electricity,hourly;
+ Output:Meter,Pumps:Electricity,hourly;
+ Output:Meter,HeatRejection:Electricity,hourly;
+ Output:Meter,Humidifier:Electricity,hourly;
+ Output:Meter,Refrigeration:Electricity,hourly;
+ Output:Meter,WaterSystems:Electricity,hourly;
+ Output:Meter,Gas:Facility,hourly;
+ Output:Meter,Heating:Gas,hourly;
+ Output:Meter,InteriorEquipment:Gas,hourly;
+ Output:Meter,WaterSystems:Gas,hourly;
Added: SwiftApps/Swift-MapRed/EPlus/CHICAGO.epw
--- SwiftApps/Swift-MapRed/EPlus/CHICAGO.epw (rev 0)
+++ SwiftApps/Swift-MapRed/EPlus/CHICAGO.epw 2013-10-14 21:44:19 UTC (rev 7161)
@@ -0,0 +1,8768 @@
+LOCATION,Chicago Ohare Intl Ap,IL,USA,TMY3,725300,41.98,-87.92,-6.0,201.0
+DESIGN CONDITIONS,1,Climate Design Data 2009 ASHRAE Handbook,,Heating,1,-20,-16.6,-25.7,0.4,-19.2,-22.1,0.5,-15.7,12.4,-3.5,11.4,-3.2,4.9,270,Cooling,7,10.5,33.3,23.7,31.6,23,30.1,22.1,25.5,31.2,24.5,29.6,23.5,28.1,5.2,230,23.8,19.2,28.9,22.9,18,27.7,21.9,17,26.5,79.2,31.4,75.1,29.6,70.9,28.2,617,Extremes,11.1,9.4,8.6,28.5,-23.7,35.9,4.5,1.9,-27,37.3,-29.6,38.4,-32.2,39.5,-35.5,40.9
+TYPICAL/EXTREME PERIODS,6,Summer - Week Nearest Max Temperature For Period,Extreme,7/13,7/19,Summer - Week Nearest Average Temperature For Period,Typical,8/24,8/30,Winter - Week Nearest Min Temperature For Period,Extreme,1/27,2/ 2,Winter - Week Nearest Average Temperature For Period,Typical,12/22,12/28,Autumn - Week Nearest Average Temperature For Period,Typical,10/27,11/ 2,Spring - Week Nearest Average Temperature For Period,Typical,4/26,5/ 2
+GROUND TEMPERATURES,3,.5,,,,-1.89,-3.06,-0.99,2.23,10.68,17.20,21.60,22.94,20.66,15.60,8.83,2.56,2,,,,2.39,0.31,0.74,2.45,8.10,13.21,17.30,19.50,19.03,16.16,11.50,6.56,4,,,,5.93,3.80,3.34,3.98,7.18,10.62,13.78,15.98,16.49,15.25,12.51,9.17
+HOLIDAYS/DAYLIGHT SAVINGS,No,0,0,0
+COMMENTS 1,Custom/User Format -- WMO#725300; NREL TMY Data Set (2008); Period of Record 1973-2005 (Generally)
+COMMENTS 2, -- Ground temps produced with a standard soil diffusivity of 2.3225760E-03 {m**2/day}
+DATA PERIODS,1,1,Data,Sunday, 1/ 1,12/31
+1986,1,1,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.2,-16.1,73,99500,0,0,218,0,0,0,0,0,0,0,270,2.6,9,9,24.1,2740,9,999999999,40,0.0000,0,88,999.000,999.0,99.0
+1986,1,1,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.7,-15.6,73,99600,0,0,227,0,0,0,0,0,0,0,250,2.6,10,10,24.1,1680,9,999999999,50,0.0000,0,88,999.000,999.0,99.0
+1986,1,1,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.1,-15.0,73,99500,0,0,230,0,0,0,0,0,0,0,240,2.1,10,10,24.1,1400,9,999999999,50,0.0000,0,88,999.000,999.0,99.0
+1986,1,1,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.1,-15.0,73,99500,0,0,230,0,0,0,0,0,0,0,230,2.6,10,10,24.1,1400,9,999999999,50,0.0000,0,88,999.000,999.0,99.0
+1986,1,1,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.6,-14.4,73,99500,0,0,232,0,0,0,0,0,0,0,240,2.6,10,10,24.1,1400,9,999999999,50,0.0000,0,88,999.000,999.0,99.0
+1986,1,1,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.6,-14.4,73,99500,0,0,232,0,0,0,0,0,0,0,210,2.6,10,10,24.1,1830,9,999999999,50,0.0000,0,88,999.000,999.0,99.0
+1986,1,1,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.6,-13.9,77,99500,0,0,232,0,0,0,0,0,0,0,180,3.1,10,10,24.1,1680,9,999999999,50,0.0000,0,88,999.000,999.0,99.0
+1986,1,1,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.0,-13.3,77,99500,43,908,224,12,22,10,1272,873,1226,205,180,2.6,8,8,24.1,2130,9,999999999,50,0.1180,0,88,999.000,999.0,99.0
+1986,1,1,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.9,-13.3,71,99500,236,1415,207,115,397,47,11560,28042,6849,828,190,3.1,0,0,24.1,77777,9,999999999,50,0.1180,0,88,999.000,999.0,99.0
+1986,1,1,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.7,-13.3,60,99500,410,1415,214,244,587,71,24978,51257,10062,1322,220,5.7,2,0,24.1,77777,9,999999999,50,0.1180,0,88,999.000,999.0,99.0
+1986,1,1,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.0,-11.1,63,99400,531,1415,221,341,688,80,35572,64725,11177,1581,210,5.7,0,0,24.1,77777,9,999999999,60,0.1180,0,88,999.000,999.0,99.0
+1986,1,1,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-9.4,63,99300,591,1415,236,364,521,144,38026,50467,16854,2863,220,5.7,6,2,24.1,77777,9,999999999,60,0.1180,0,88,999.000,999.0,99.0
+1986,1,1,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-8.3,63,99200,586,1415,256,231,151,168,25174,14990,18939,3969,230,5.2,10,8,24.1,6710,9,999999999,69,0.1180,0,88,999.000,999.0,99.0
+1986,1,1,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-7.8,61,99200,516,1415,267,180,54,161,19805,5145,17920,4317,260,4.1,10,9,24.1,6710,9,999999999,69,0.1180,0,88,999.000,999.0,99.0
+1986,1,1,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-7.2,64,99200,386,1415,267,118,93,93,13001,8251,10739,2056,260,3.1,9,9,24.1,3660,9,999999999,69,0.1180,0,88,999.000,999.0,99.0
+1986,1,1,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-6.1,69,99200,206,1415,276,48,36,43,5294,2635,4908,1083,210,1.5,10,10,19.3,3660,9,999999999,80,0.1180,0,88,999.000,999.0,99.0
+1986,1,1,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-6.1,69,99200,25,696,276,5,0,5,0,0,0,0,0,0.0,10,10,19.3,3660,9,999999999,80,0.1180,0,88,999.000,999.0,99.0
+1986,1,1,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-6.1,72,99200,0,0,273,0,0,0,0,0,0,0,0,0.0,10,10,16.1,2440,9,999999999,80,0.1180,0,88,999.000,999.0,99.0
+1986,1,1,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-6.1,75,99200,0,0,271,0,0,0,0,0,0,0,160,2.1,10,10,16.1,2440,9,999999999,80,0.1180,0,88,999.000,999.0,99.0
+1986,1,1,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.6,72,99200,0,0,276,0,0,0,0,0,0,0,160,2.6,10,10,16.1,3050,9,999999999,80,0.1180,0,88,999.000,999.0,99.0
+1986,1,1,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.0,78,99100,0,0,275,0,0,0,0,0,0,0,0,0.0,10,10,16.1,3050,9,999999999,80,0.1180,0,88,999.000,999.0,99.0
+1986,1,1,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.0,75,99100,0,0,277,0,0,0,0,0,0,0,160,2.6,10,10,16.1,3050,9,999999999,80,0.1180,0,88,999.000,999.0,99.0
+1986,1,1,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.0,78,99000,0,0,254,0,0,0,0,0,0,0,180,2.6,6,6,16.1,3050,9,999999999,80,0.1180,0,88,999.000,999.0,99.0
+1986,1,1,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-6.1,72,99000,0,0,247,0,0,0,0,0,0,0,190,2.6,3,3,16.1,77777,9,999999999,80,0.1180,0,88,999.000,999.0,99.0
+1986,1,2,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-6.1,85,99000,0,0,237,0,0,0,0,0,0,0,170,2.1,2,2,16.1,77777,9,999999999,80,0.1180,0,88,999.000,999.0,99.0
+1986,1,2,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-6.1,78,99000,0,0,243,0,0,0,0,0,0,0,200,3.1,4,3,16.1,77777,9,999999999,69,0.1180,0,88,999.000,999.0,99.0
+1986,1,2,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-6.7,78,98900,0,0,239,0,0,0,0,0,0,0,180,2.6,2,2,16.1,77777,9,999999999,69,0.1180,0,88,999.000,999.0,99.0
+1986,1,2,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-6.1,78,98900,0,0,249,0,0,0,0,0,0,0,120,2.1,8,6,16.1,3050,9,999999999,69,0.1180,0,88,999.000,999.0,99.0
+1986,1,2,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.6,72,98900,0,0,263,0,0,0,0,0,0,0,190,3.6,10,8,16.1,3050,9,999999999,80,0.1180,0,88,999.000,999.0,99.0
+1986,1,2,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.6,72,98900,0,0,263,0,0,0,0,0,0,0,210,3.1,10,8,16.1,7620,9,999999999,80,0.1180,0,88,999.000,999.0,99.0
+1986,1,2,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-5.6,69,99000,0,0,278,0,0,0,0,0,0,0,200,2.6,10,10,16.1,7620,9,999999999,80,0.1180,0,88,999.000,999.0,99.0
+1986,1,2,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-5.6,69,98900,43,908,278,8,0,8,1000,0,1000,300,190,2.6,10,10,14.5,2440,9,999999999,80,0.1050,0,88,999.000,999.0,99.0
+1986,1,2,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-5.0,69,99000,236,1415,282,46,5,45,5200,100,5200,1630,180,3.6,10,10,12.9,2440,9,999999999,80,0.1050,0,88,999.000,999.0,99.0
+1986,1,2,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-5.0,67,99000,410,1415,284,123,1,122,13600,100,13500,4170,160,3.6,10,10,12.9,2440,9,999999999,80,0.1050,0,88,999.000,999.0,99.0
+1986,1,2,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-5.0,62,98900,532,1415,289,133,1,133,15100,100,15100,5110,180,3.6,10,10,12.9,2440,9,999999999,80,0.1050,0,88,999.000,999.0,99.0
+1986,1,2,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-4.4,64,98800,593,1415,289,176,2,176,19900,200,19800,6550,160,2.1,10,10,11.3,1830,9,999999999,80,0.1050,0,88,999.000,999.0,99.0
+1986,1,2,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-3.9,67,98600,588,1415,290,186,3,185,20800,200,20700,6720,0,0.0,10,10,12.9,1830,9,999999999,89,0.1050,0,88,999.000,999.0,99.0
+1986,1,2,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-1.1,92,98500,519,1415,286,166,0,166,18400,0,18400,5800,160,2.6,10,10,0.6,240,9,999999999,100,0.1050,0,88,999.000,999.0,99.0
+1986,1,2,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-1.1,96,98400,389,1415,283,122,0,122,13500,0,13500,4030,120,2.1,10,10,4.8,910,9,999999999,100,0.1050,0,88,999.000,999.0,99.0
+1986,1,2,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-1.1,89,98300,209,1415,288,54,0,54,6000,0,6000,1770,90,3.6,10,10,4.8,1830,9,999999999,100,0.1050,0,88,999.000,999.0,99.0
+1986,1,2,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-0.6,92,98300,26,719,289,10,0,10,0,0,0,0,170,7.7,10,10,0.8,180,9,999999999,100,0.1050,0,88,999.000,999.0,99.0
+1986,1,2,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-0.6,100,98300,0,0,284,0,0,0,0,0,0,0,120,3.1,10,10,2.4,150,9,999999999,100,0.1050,0,88,999.000,999.0,99.0
+1986,1,2,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-0.6,92,98100,0,0,289,0,0,0,0,0,0,0,130,3.6,10,10,6.4,270,9,999999999,100,0.1050,0,88,999.000,999.0,99.0
+1986,1,2,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-0.6,89,98100,0,0,291,0,0,0,0,0,0,0,140,3.6,10,10,8.0,270,9,999999999,100,0.1050,0,88,999.000,999.0,99.0
+1986,1,2,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,0.0,89,97900,0,0,294,0,0,0,0,0,0,0,120,4.1,10,10,8.0,1010,9,999999999,110,0.1050,0,88,999.000,999.0,99.0
+1986,1,2,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,0.6,89,97900,0,0,297,0,0,0,0,0,0,0,90,3.1,10,10,9.7,1160,9,999999999,110,0.1050,0,88,999.000,999.0,99.0
+1986,1,2,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-0.6,96,97800,0,0,286,0,0,0,0,0,0,0,0,0.0,10,10,6.4,1160,9,999999999,100,0.1050,0,88,999.000,999.0,99.0
+1986,1,2,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-0.6,96,97800,0,0,286,0,0,0,0,0,0,0,320,2.6,10,10,2.4,180,9,999999999,100,0.1050,0,88,999.000,999.0,99.0
+1986,1,3,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-0.6,96,97900,0,0,286,0,0,0,0,0,0,0,300,2.6,10,10,2.4,180,9,999999999,100,0.1050,0,88,999.000,999.0,99.0
+1986,1,3,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-0.6,96,98100,0,0,286,0,0,0,0,0,0,0,320,4.6,10,10,6.4,180,9,999999999,100,0.1050,0,88,999.000,999.0,99.0
+1986,1,3,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-0.6,92,98300,0,0,289,0,0,0,0,0,0,0,340,7.2,10,10,6.4,210,9,999999999,100,0.1050,0,88,999.000,999.0,99.0
+1986,1,3,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-1.7,89,98400,0,0,285,0,0,0,0,0,0,0,340,6.2,10,10,6.4,310,9,999999999,100,0.1050,0,88,999.000,999.0,99.0
+1986,1,3,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-3.3,85,98600,0,0,279,0,0,0,0,0,0,0,320,5.7,10,10,11.3,400,9,999999999,89,0.1050,0,88,999.000,999.0,99.0
+1986,1,3,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-4.4,85,98800,0,0,273,0,0,0,0,0,0,0,300,6.2,10,10,11.3,580,9,999999999,80,0.1050,0,88,999.000,999.0,99.0
+1986,1,3,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-5.6,85,99000,0,0,268,0,0,0,0,0,0,0,310,5.2,10,10,11.3,580,9,999999999,80,0.1050,0,88,999.000,999.0,99.0
+1986,1,3,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-5.6,85,99100,43,908,268,20,0,20,2200,0,2200,630,300,4.6,10,10,11.3,580,9,999999999,80,0.0430,0,88,999.000,999.0,99.0
+1986,1,3,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-6.1,88,99200,237,1415,263,82,1,81,8800,0,8800,2380,320,5.2,10,10,11.3,580,9,999999999,80,0.0430,0,88,999.000,999.0,99.0
+1986,1,3,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-6.1,88,99400,411,1415,263,166,0,166,17900,0,17900,4850,300,5.2,10,10,11.3,580,9,999999999,80,0.0430,0,88,999.000,999.0,99.0
+1986,1,3,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.9,-6.1,85,99400,533,1415,265,216,0,215,23500,0,23500,6720,300,4.6,10,10,6.4,580,9,999999999,80,0.0430,0,88,999.000,999.0,99.0
+1986,1,3,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-5.6,85,99400,594,1415,268,218,1,218,24100,100,24100,7410,300,4.1,10,10,6.4,640,9,999999999,80,0.0430,0,88,999.000,999.0,99.0
+1986,1,3,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-5.6,81,99400,590,1415,270,216,1,215,23800,100,23800,7320,300,3.6,10,10,8.0,700,9,999999999,80,0.0430,0,88,999.000,999.0,99.0
+1986,1,3,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-5.6,81,99500,521,1415,270,208,1,207,22600,100,22600,6490,290,4.6,10,10,8.0,700,9,999999999,80,0.0430,0,88,999.000,999.0,99.0
+1986,1,3,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-5.6,81,99500,392,1415,270,148,1,148,16100,100,16100,4460,290,2.1,10,10,9.7,640,9,999999999,80,0.0430,0,88,999.000,999.0,99.0
+1986,1,3,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-5.6,81,99500,212,1415,270,77,1,77,8300,0,8300,2160,280,1.5,10,10,9.7,640,9,999999999,80,0.0430,0,88,999.000,999.0,99.0
+1986,1,3,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-5.0,85,99600,28,743,270,14,0,14,0,0,0,0,260,2.6,10,10,9.7,580,9,999999999,80,0.0430,0,88,999.000,999.0,99.0
+1986,1,3,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-5.6,81,99600,0,0,270,0,0,0,0,0,0,0,250,2.1,10,10,9.7,580,9,999999999,80,0.0430,0,88,999.000,999.0,99.0
+1986,1,3,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-5.6,81,99600,0,0,270,0,0,0,0,0,0,0,240,2.6,10,10,9.7,580,9,999999999,80,0.0430,0,88,999.000,999.0,99.0
+1986,1,3,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-5.0,85,99700,0,0,270,0,0,0,0,0,0,0,210,2.1,10,10,9.7,460,9,999999999,80,0.0430,0,88,999.000,999.0,99.0
+1986,1,3,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-4.4,89,99600,0,0,271,0,0,0,0,0,0,0,170,2.1,10,10,8.0,430,9,999999999,80,0.0430,0,88,999.000,999.0,99.0
+1986,1,3,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-4.4,89,99600,0,0,271,0,0,0,0,0,0,0,170,3.6,10,10,9.7,370,9,999999999,80,0.0430,0,88,999.000,999.0,99.0
+1986,1,3,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-4.4,89,99500,0,0,271,0,0,0,0,0,0,0,180,4.6,10,10,9.7,370,9,999999999,80,0.0430,0,88,999.000,999.0,99.0
+1986,1,3,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-5.0,85,99500,0,0,270,0,0,0,0,0,0,0,160,4.1,10,10,9.7,340,9,999999999,80,0.0430,0,88,999.000,999.0,99.0
+1986,1,4,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-5.0,85,99400,0,0,270,0,0,0,0,0,0,0,170,4.1,10,10,9.7,340,9,999999999,80,0.0430,0,88,999.000,999.0,99.0
+1986,1,4,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-5.0,85,99300,0,0,270,0,0,0,0,0,0,0,160,5.2,10,10,8.0,340,9,999999999,80,0.0430,0,88,999.000,999.0,99.0
+1986,1,4,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-5.0,85,99300,0,0,270,0,0,0,0,0,0,0,170,5.7,10,10,8.0,340,9,999999999,80,0.0430,0,88,999.000,999.0,99.0
+1986,1,4,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-5.0,88,99200,0,0,268,0,0,0,0,0,0,0,190,5.2,10,10,6.4,270,9,999999999,80,0.0430,0,88,999.000,999.0,99.0
+1986,1,4,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-5.0,88,99200,0,0,268,0,0,0,0,0,0,0,170,4.6,10,10,6.4,240,9,999999999,80,0.0430,0,88,999.000,999.0,99.0
+1986,1,4,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-5.0,88,99000,0,0,268,0,0,0,0,0,0,0,150,4.1,10,10,6.4,180,9,999999999,80,0.0430,0,88,999.000,999.0,99.0
+1986,1,4,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-3.9,92,98900,0,0,271,0,0,0,0,0,0,0,160,4.1,10,10,2.4,120,9,999999999,80,0.0430,0,88,999.000,999.0,99.0
+1986,1,4,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-3.9,92,98900,43,908,271,19,0,19,2100,0,2100,610,140,4.6,10,10,2.4,120,9,999999999,80,0.2080,0,88,999.000,999.0,99.0
+1986,1,4,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-3.9,89,98800,237,1415,274,77,0,77,8400,0,8400,2320,150,4.6,10,10,3.2,210,9,999999999,89,0.2080,0,88,999.000,999.0,99.0
+1986,1,4,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-3.9,85,98700,412,1415,276,129,1,128,14200,100,14200,4300,150,5.2,10,10,4.8,310,9,999999999,80,0.2080,0,88,999.000,999.0,99.0
+1986,1,4,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-3.3,89,98500,535,1415,276,183,1,183,20300,100,20300,6250,140,3.6,10,10,3.2,400,9,999999999,89,0.2080,0,88,999.000,999.0,99.0
+1986,1,4,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-2.8,89,98400,597,1415,279,192,1,192,21500,100,21400,6940,130,3.6,10,10,4.8,340,9,999999999,89,0.2080,0,88,999.000,999.0,99.0
+1986,1,4,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-2.8,85,98200,593,1415,281,194,0,194,21600,0,21600,6950,210,2.1,10,10,4.8,340,9,999999999,89,0.2080,0,88,999.000,999.0,99.0
+1986,1,4,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-2.8,85,98200,524,1415,281,156,1,156,17500,100,17500,5630,320,2.1,10,10,4.8,310,9,999999999,89,0.2080,0,88,999.000,999.0,99.0
+1986,1,4,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-2.2,92,98200,396,1415,280,130,0,130,14300,0,14300,4220,330,3.1,10,10,3.2,120,9,999999999,89,0.2080,0,88,999.000,999.0,99.0
+1986,1,4,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-2.8,89,98300,216,1415,279,61,0,61,6700,0,6700,1940,330,4.1,10,10,3.2,210,9,999999999,89,0.2080,0,88,999.000,999.0,99.0
+1986,1,4,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-5.0,85,98300,30,743,270,14,0,14,1600,0,1600,470,330,7.7,10,10,3.2,430,9,999999999,80,0.2080,0,88,999.000,999.0,99.0
+1986,1,4,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-6.1,85,98500,0,0,265,0,0,0,0,0,0,0,330,7.2,10,10,2.4,240,9,999999999,69,0.2080,0,88,999.000,999.0,99.0
+1986,1,4,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-7.2,85,98600,0,0,259,0,0,0,0,0,0,0,320,7.7,10,10,4.8,430,9,999999999,69,0.2080,0,88,999.000,999.0,99.0
+1986,1,4,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-7.2,85,98700,0,0,259,0,0,0,0,0,0,0,310,6.7,10,10,4.8,460,9,999999999,69,0.2080,0,88,999.000,999.0,99.0
+1986,1,4,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-6.7,85,98800,0,0,262,0,0,0,0,0,0,0,310,8.2,10,10,6.4,460,9,999999999,69,0.2080,0,88,999.000,999.0,99.0
+1986,1,4,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-6.7,88,98900,0,0,260,0,0,0,0,0,0,0,330,8.8,10,10,8.0,460,9,999999999,69,0.2080,0,88,999.000,999.0,99.0
+1986,1,4,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-9.4,78,99100,0,0,232,0,0,0,0,0,0,0,330,6.7,5,5,11.3,77777,9,999999999,60,0.2080,0,88,999.000,999.0,99.0
+1986,1,4,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-10.6,77,99100,0,0,215,0,0,0,0,0,0,0,290,5.2,0,0,19.3,77777,9,999999999,60,0.2080,0,88,999.000,999.0,99.0
+1986,1,5,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-11.1,74,99200,0,0,235,0,0,0,0,0,0,0,310,6.2,8,8,19.3,760,9,999999999,60,0.2080,0,88,999.000,999.0,99.0
+1986,1,5,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-10.0,78,99200,0,0,238,0,0,0,0,0,0,0,310,5.2,8,8,14.5,1010,9,999999999,60,0.2080,0,88,999.000,999.0,99.0
+1986,1,5,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-10.6,77,99300,0,0,232,0,0,0,0,0,0,0,290,3.6,7,7,14.5,880,9,999999999,60,0.2080,0,88,999.000,999.0,99.0
+1986,1,5,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-11.7,81,99300,0,0,219,0,0,0,0,0,0,0,290,4.1,4,4,14.5,77777,9,999999999,60,0.2080,0,88,999.000,999.0,99.0
+1986,1,5,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.2,-15.0,80,99400,0,0,196,0,0,0,0,0,0,0,270,5.7,0,0,11.3,77777,9,999999999,50,0.2080,0,88,999.000,999.0,99.0
+1986,1,5,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-14.4,-17.2,80,99400,0,0,187,0,0,0,0,0,0,0,270,5.2,0,0,11.3,77777,9,999999999,40,0.2080,0,88,999.000,999.0,99.0
+1986,1,5,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-15.0,-18.9,73,99400,0,0,184,0,0,0,0,0,0,0,270,5.2,1,0,11.3,77777,9,999999999,40,0.2080,0,88,999.000,999.0,99.0
+1986,1,5,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-13.9,-15.6,87,99400,43,908,198,26,54,21,2500,1600,2400,380,250,6.2,7,3,16.1,77777,9,999999999,50,0.0580,0,88,999.000,999.0,99.0
+1986,1,5,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-13.9,-15.6,87,99400,238,1415,196,122,419,49,12200,29600,7100,860,250,6.2,3,2,16.1,77777,9,999999999,50,0.0580,0,88,999.000,999.0,99.0
+1986,1,5,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-11.7,-15.6,73,99400,413,1415,197,269,715,56,27300,63300,8700,1080,240,5.7,1,0,24.1,77777,9,999999999,50,0.0580,0,88,999.000,999.0,99.0
+1986,1,5,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-9.4,-14.4,67,99200,536,1415,205,383,831,64,39700,78300,9900,1320,230,6.2,0,0,24.1,77777,9,999999999,50,0.0580,0,88,999.000,999.0,99.0
+1986,1,5,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-13.3,65,99000,599,1415,210,436,859,69,45600,82600,10500,1460,240,7.7,0,0,24.1,77777,9,999999999,50,0.0580,0,88,999.000,999.0,99.0
+1986,1,5,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.7,-12.2,65,98800,596,1415,215,433,858,69,45300,82400,10500,1460,220,7.7,0,0,24.1,77777,9,999999999,50,0.0580,0,88,999.000,999.0,99.0
+1986,1,5,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.6,-11.7,63,98800,528,1415,223,347,729,74,35600,67900,10100,1420,230,6.2,3,1,24.1,77777,9,999999999,60,0.0580,0,88,999.000,999.0,99.0
+1986,1,5,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.9,-10.6,60,98700,399,1415,233,245,558,88,25000,47600,11500,1550,220,8.2,2,2,24.1,77777,9,999999999,60,0.0580,0,88,999.000,999.0,99.0
+1986,1,5,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-10.6,58,98700,219,1415,239,83,187,54,8800,12200,6900,1010,240,9.3,5,4,24.1,77777,9,999999999,60,0.0580,0,88,999.000,999.0,99.0
+1986,1,5,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-10.0,66,98700,31,766,232,17,62,12,1600,2000,1500,210,240,7.7,2,2,24.1,77777,9,999999999,60,0.0580,0,88,999.000,999.0,99.0
+1986,1,5,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-10.0,68,98700,0,0,227,0,0,0,0,0,0,0,260,7.2,1,1,24.1,77777,9,999999999,60,0.0580,0,88,999.000,999.0,99.0
+1986,1,5,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-10.6,68,98700,0,0,224,0,0,0,0,0,0,0,260,7.2,1,1,24.1,77777,9,999999999,60,0.0580,0,88,999.000,999.0,99.0
+1986,1,5,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-11.1,71,98700,0,0,220,0,0,0,0,0,0,0,270,6.7,1,1,24.1,77777,9,999999999,60,0.0580,0,88,999.000,999.0,99.0
+1986,1,5,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-11.1,77,98800,0,0,212,0,0,0,0,0,0,0,270,6.7,0,0,24.1,77777,9,999999999,60,0.0580,0,88,999.000,999.0,99.0
+1986,1,5,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-12.8,74,98800,0,0,207,0,0,0,0,0,0,0,280,5.2,0,0,24.1,77777,9,999999999,50,0.0580,0,88,999.000,999.0,99.0
+1986,1,5,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-13.3,71,98800,0,0,207,0,0,0,0,0,0,0,270,5.2,0,0,24.1,77777,9,999999999,50,0.0580,0,88,999.000,999.0,99.0
+1986,1,5,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.0,-13.9,74,98800,0,0,210,0,0,0,0,0,0,0,280,5.2,2,2,24.1,77777,9,999999999,50,0.0580,0,88,999.000,999.0,99.0
+1986,1,6,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.1,-14.4,77,98900,0,0,199,0,0,0,0,0,0,0,280,5.7,0,0,19.3,77777,9,999999999,50,0.0580,0,88,999.000,999.0,99.0
+1986,1,6,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.1,-15.0,73,99000,0,0,205,0,0,0,0,0,0,0,270,4.6,2,2,19.3,77777,9,999999999,50,0.0580,0,88,999.000,999.0,99.0
+1986,1,6,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.2,-15.6,77,99100,0,0,195,0,0,0,0,0,0,0,280,4.1,0,0,19.3,77777,9,999999999,50,0.0580,0,88,999.000,999.0,99.0
+1986,1,6,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-13.9,-17.2,76,99200,0,0,189,0,0,0,0,0,0,0,290,3.6,0,0,19.3,77777,9,999999999,40,0.0580,0,88,999.000,999.0,99.0
+1986,1,6,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-13.9,-16.7,80,99300,0,0,189,0,0,0,0,0,0,0,310,3.6,0,0,19.3,77777,9,999999999,40,0.0580,0,88,999.000,999.0,99.0
+1986,1,6,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-14.4,-17.8,76,99400,0,0,187,0,0,0,0,0,0,0,310,3.6,0,0,19.3,77777,9,999999999,40,0.0580,0,88,999.000,999.0,99.0
+1986,1,6,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-14.4,-18.9,69,99500,0,0,186,0,0,0,0,0,0,0,330,4.6,1,0,24.1,77777,9,999999999,40,0.0580,0,88,999.000,999.0,99.0
+1986,1,6,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-15.0,-23.9,47,99600,43,908,187,22,45,18,2200,1300,2100,320,320,3.1,7,2,24.1,77777,9,999999999,30,0.0610,0,88,999.000,999.0,99.0
+1986,1,6,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-13.9,-23.3,45,99700,239,1415,188,126,434,50,12500,30700,7300,870,340,5.2,4,1,24.1,77777,9,999999999,30,0.0610,0,88,999.000,999.0,99.0
+1986,1,6,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-13.3,-22.2,48,99800,414,1415,190,255,632,66,26200,55600,9800,1250,350,4.1,4,1,24.1,77777,9,999999999,40,0.0610,0,88,999.000,999.0,99.0
+1986,1,6,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-12.2,-21.7,46,99900,538,1415,199,331,532,126,34600,50500,15300,2440,330,4.1,10,3,24.1,77777,9,999999999,40,0.0610,0,88,999.000,999.0,99.0
+1986,1,6,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-11.1,-20.6,46,99800,601,1415,210,204,90,166,22400,8800,18700,4790,300,4.1,10,7,24.1,7620,9,999999999,40,0.0610,0,88,999.000,999.0,99.0
+1986,1,6,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-11.7,-20.6,48,99800,599,1415,212,235,97,193,25700,9500,21600,5360,310,2.6,10,8,24.1,7620,9,999999999,40,0.0610,0,88,999.000,999.0,99.0
+1986,1,6,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-11.1,-20.6,46,99900,531,1415,224,132,9,128,14900,600,14700,4970,330,3.6,10,10,24.1,7620,9,999999999,40,0.0610,0,88,999.000,999.0,99.0
+1986,1,6,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-11.7,-21.1,46,99900,403,1415,211,151,99,123,16400,8900,13800,2730,280,2.6,10,8,24.1,7620,9,999999999,40,0.0610,0,88,999.000,999.0,99.0
+1986,1,6,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-12.2,-20.6,50,100000,223,1415,204,92,87,78,9800,6000,8800,1660,310,2.6,10,6,16.1,7620,9,999999999,40,0.0610,0,88,999.000,999.0,99.0
+1986,1,6,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-14.4,-21.1,57,100100,33,790,190,19,50,14,1800,1300,1700,240,320,3.6,6,2,16.1,77777,9,999999999,40,0.0610,0,88,999.000,999.0,99.0
+1986,1,6,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-15.6,-22.2,57,100200,0,0,186,0,0,0,0,0,0,0,320,3.1,4,2,24.1,77777,9,999999999,30,0.0610,0,88,999.000,999.0,99.0
+1986,1,6,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.2,-23.3,59,100200,0,0,175,0,0,0,0,0,0,0,350,4.6,0,0,24.1,77777,9,999999999,30,0.0610,0,88,999.000,999.0,99.0
+1986,1,6,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.2,-23.9,56,100300,0,0,174,0,0,0,0,0,0,0,330,4.1,0,0,24.1,77777,9,999999999,30,0.0610,0,88,999.000,999.0,99.0
+1986,1,6,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-18.9,-25.0,59,100300,0,0,169,0,0,0,0,0,0,0,280,2.1,0,0,19.3,77777,9,999999999,30,0.0610,0,88,999.000,999.0,99.0
+1986,1,6,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-18.3,-25.0,56,100400,0,0,171,0,0,0,0,0,0,0,320,4.1,0,0,19.3,77777,9,999999999,30,0.0610,0,88,999.000,999.0,99.0
+1986,1,6,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.8,-25.6,51,100500,0,0,172,0,0,0,0,0,0,0,350,4.1,0,0,19.3,77777,9,999999999,30,0.0610,0,88,999.000,999.0,99.0
+1986,1,6,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-18.9,-26.1,53,100600,0,0,168,0,0,0,0,0,0,0,350,4.6,0,0,19.3,77777,9,999999999,30,0.0610,0,88,999.000,999.0,99.0
+1986,1,7,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-18.9,-26.7,51,100600,0,0,168,0,0,0,0,0,0,0,330,4.1,0,0,19.3,77777,9,999999999,30,0.0610,0,88,999.000,999.0,99.0
+1986,1,7,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-19.4,-26.7,53,100700,0,0,167,0,0,0,0,0,0,0,330,3.6,0,0,24.1,77777,9,999999999,30,0.0610,0,88,999.000,999.0,99.0
+1986,1,7,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-20.0,-26.7,56,100800,0,0,165,0,0,0,0,0,0,0,310,3.1,0,0,24.1,77777,9,999999999,30,0.0610,0,88,999.000,999.0,99.0
+1986,1,7,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-20.6,-26.7,58,100900,0,0,163,0,0,0,0,0,0,0,310,4.1,0,0,24.1,77777,9,999999999,30,0.0610,0,88,999.000,999.0,99.0
+1986,1,7,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-21.1,-26.7,61,100900,0,0,167,0,0,0,0,0,0,0,300,3.1,2,2,24.1,77777,9,999999999,30,0.0610,0,88,999.000,999.0,99.0
+1986,1,7,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-22.2,-27.8,61,101000,0,0,162,0,0,0,0,0,0,0,310,3.1,1,1,24.1,77777,9,999999999,30,0.0610,0,88,999.000,999.0,99.0
+1986,1,7,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-22.8,-27.8,64,101100,0,0,157,0,0,0,0,0,0,0,300,2.1,0,0,24.1,77777,9,999999999,30,0.0610,0,88,999.000,999.0,99.0
+1986,1,7,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-21.7,-27.2,61,101100,44,908,160,29,187,13,2400,7900,1900,240,320,3.1,0,0,24.1,77777,9,999999999,30,0.0410,0,88,999.000,999.0,99.0
+1986,1,7,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-18.3,-25.6,53,101300,240,1415,170,140,622,31,14400,48300,6200,630,350,5.2,0,0,24.1,77777,9,999999999,30,0.0410,0,88,999.000,999.0,99.0
+1986,1,7,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-16.1,-24.4,49,101300,416,1415,177,283,800,44,29500,71700,8400,980,350,6.2,0,0,24.1,77777,9,999999999,30,0.0410,0,88,999.000,999.0,99.0
+1986,1,7,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-14.4,-24.4,43,101400,540,1415,182,392,879,53,41000,82700,9300,1210,350,6.7,0,0,24.1,77777,9,999999999,30,0.0410,0,88,999.000,999.0,99.0
+1986,1,7,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-14.4,-24.4,43,101400,604,1415,182,445,901,57,46600,86200,9600,1310,310,5.2,0,0,24.1,77777,9,999999999,30,0.0410,0,88,999.000,999.0,99.0
+1986,1,7,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-13.3,-23.9,41,101400,602,1415,185,442,900,57,46400,86000,9600,1310,310,5.2,0,0,24.1,77777,9,999999999,30,0.0410,0,88,999.000,999.0,99.0
+1986,1,7,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-12.8,-23.3,41,101400,534,1415,187,381,869,52,40200,81600,9200,1190,320,5.7,0,0,24.1,77777,9,999999999,30,0.0410,0,88,999.000,999.0,99.0
+1986,1,7,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-13.3,-23.9,41,101400,406,1415,185,268,788,42,28400,70200,8100,960,320,4.6,0,0,24.1,77777,9,999999999,30,0.0410,0,88,999.000,999.0,99.0
+1986,1,7,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-13.9,-23.3,45,101500,227,1415,184,124,597,30,13000,44200,5800,600,320,5.2,0,0,24.1,77777,9,999999999,30,0.0410,0,88,999.000,999.0,99.0
+1986,1,7,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-16.1,-24.4,49,101500,36,814,177,24,145,11,1900,6000,1600,210,330,5.7,0,0,24.1,77777,9,999999999,30,0.0410,0,88,999.000,999.0,99.0
+1986,1,7,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-16.7,-24.4,51,101500,0,0,175,0,0,0,0,0,0,0,320,3.6,0,0,24.1,77777,9,999999999,30,0.0410,0,88,999.000,999.0,99.0
+1986,1,7,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-18.3,-25.0,56,101600,0,0,171,0,0,0,0,0,0,0,350,4.1,0,0,24.1,77777,9,999999999,30,0.0410,0,88,999.000,999.0,99.0
+1986,1,7,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-18.3,-25.0,56,101700,0,0,171,0,0,0,0,0,0,0,310,2.6,0,0,24.1,77777,9,999999999,30,0.0410,0,88,999.000,999.0,99.0
+1986,1,7,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-19.4,-25.6,59,101700,0,0,167,0,0,0,0,0,0,0,280,2.6,0,0,24.1,77777,9,999999999,30,0.0410,0,88,999.000,999.0,99.0
+1986,1,7,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-20.0,-25.6,62,101800,0,0,166,0,0,0,0,0,0,0,330,2.6,0,0,24.1,77777,9,999999999,30,0.0410,0,88,999.000,999.0,99.0
+1986,1,7,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-19.4,-26.1,56,101800,0,0,167,0,0,0,0,0,0,0,360,2.1,0,0,24.1,77777,9,999999999,30,0.0410,0,88,999.000,999.0,99.0
+1986,1,7,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-20.0,-26.1,58,101700,0,0,165,0,0,0,0,0,0,0,300,2.1,0,0,24.1,77777,9,999999999,30,0.0410,0,88,999.000,999.0,99.0
+1986,1,8,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-21.1,-26.1,64,101700,0,0,163,0,0,0,0,0,0,0,250,2.1,0,0,24.1,77777,9,999999999,30,0.0410,0,88,999.000,999.0,99.0
+1986,1,8,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-21.1,-26.1,64,101600,0,0,163,0,0,0,0,0,0,0,280,2.1,0,0,19.3,77777,9,999999999,30,0.0410,0,88,999.000,999.0,99.0
+1986,1,8,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-21.1,-26.1,64,101700,0,0,163,0,0,0,0,0,0,0,290,2.1,0,0,19.3,77777,9,999999999,30,0.0410,0,88,999.000,999.0,99.0
+1986,1,8,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-21.1,-26.7,61,101800,0,0,167,0,0,0,0,0,0,0,280,2.1,2,2,19.3,77777,9,999999999,30,0.0410,0,88,999.000,999.0,99.0
+1986,1,8,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-21.7,-26.7,64,101800,0,0,164,0,0,0,0,0,0,0,250,2.1,1,1,19.3,77777,9,999999999,30,0.0410,0,88,999.000,999.0,99.0
+1986,1,8,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-21.7,-26.1,68,101800,0,0,161,0,0,0,0,0,0,0,250,2.1,0,0,19.3,77777,9,999999999,30,0.0410,0,88,999.000,999.0,99.0
+1986,1,8,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-21.7,-26.7,64,101800,0,0,161,0,0,0,0,0,0,0,240,1.5,0,0,19.3,77777,9,999999999,30,0.0410,0,88,999.000,999.0,99.0
+1986,1,8,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-21.1,-26.1,64,101700,44,908,163,29,182,14,2400,7700,2000,250,240,2.1,0,0,11.3,77777,9,999999999,30,0.0450,0,88,999.000,999.0,99.0
+1986,1,8,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-17.2,-22.8,62,101800,241,1415,175,141,619,32,14100,46700,6100,630,220,2.1,0,0,11.3,77777,9,999999999,30,0.0450,0,88,999.000,999.0,99.0
+1986,1,8,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-14.4,-22.2,52,101800,418,1415,187,256,642,64,26500,56700,9700,1220,230,4.1,3,1,16.1,77777,9,999999999,40,0.0450,0,88,999.000,999.0,99.0
+1986,1,8,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-12.8,-22.2,45,101700,543,1415,192,363,707,88,37600,66600,11900,1730,240,4.6,7,1,19.3,77777,9,999999999,30,0.0450,0,88,999.000,999.0,99.0
+1986,1,8,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-12.2,-22.2,44,101700,606,1415,196,417,646,139,42500,61000,16300,2620,230,4.1,8,2,24.1,77777,9,999999999,40,0.0450,0,88,999.000,999.0,99.0
+1986,1,8,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.6,-21.1,42,101500,605,1415,199,409,726,97,42800,69900,12800,1960,230,5.2,6,1,24.1,77777,9,999999999,40,0.0450,0,88,999.000,999.0,99.0
+1986,1,8,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.0,-21.1,40,101400,538,1415,201,357,731,79,37600,69000,11300,1570,220,7.2,3,1,24.1,77777,9,999999999,40,0.0450,0,88,999.000,999.0,99.0
+1986,1,8,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-9.4,-20.6,40,101300,410,1415,199,260,739,46,27400,65900,8200,960,210,7.2,1,0,24.1,77777,9,999999999,40,0.0450,0,88,999.000,999.0,99.0
+1986,1,8,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-9.4,-19.4,44,101200,231,1415,200,123,554,34,12700,41000,5900,640,230,5.2,2,0,24.1,77777,9,999999999,40,0.0450,0,88,999.000,999.0,99.0
+1986,1,8,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.0,-18.9,49,101200,38,837,203,24,112,13,1900,4600,1700,240,220,3.6,3,1,24.1,77777,9,999999999,40,0.0450,0,88,999.000,999.0,99.0
+1986,1,8,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.0,-17.8,53,101100,0,0,200,0,0,0,0,0,0,0,230,5.2,0,0,24.1,77777,9,999999999,40,0.0450,0,88,999.000,999.0,99.0
+1986,1,8,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.0,-17.8,53,101000,0,0,200,0,0,0,0,0,0,0,220,3.6,0,0,24.1,77777,9,999999999,40,0.0450,0,88,999.000,999.0,99.0
+1986,1,8,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-9.4,-17.8,51,101000,0,0,202,0,0,0,0,0,0,0,220,4.6,1,0,24.1,77777,9,999999999,40,0.0450,0,88,999.000,999.0,99.0
+1986,1,8,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-17.8,49,100900,0,0,207,0,0,0,0,0,0,0,210,4.1,2,1,24.1,77777,9,999999999,40,0.0450,0,88,999.000,999.0,99.0
+1986,1,8,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-17.8,49,100700,0,0,203,0,0,0,0,0,0,0,210,5.7,2,0,24.1,77777,9,999999999,40,0.0450,0,88,999.000,999.0,99.0
+1986,1,8,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-17.2,49,100700,0,0,206,0,0,0,0,0,0,0,220,7.7,0,0,24.1,77777,9,999999999,40,0.0450,0,88,999.000,999.0,99.0
+1986,1,8,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-17.8,49,100600,0,0,203,0,0,0,0,0,0,0,230,6.2,0,0,24.1,77777,9,999999999,40,0.0450,0,88,999.000,999.0,99.0
+1986,1,9,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-15.6,59,100500,0,0,205,0,0,0,0,0,0,0,220,6.2,0,0,24.1,77777,9,999999999,50,0.0450,0,88,999.000,999.0,99.0
+1986,1,9,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-16.1,56,100400,0,0,205,0,0,0,0,0,0,0,220,7.7,0,0,24.1,77777,9,999999999,50,0.0450,0,88,999.000,999.0,99.0
+1986,1,9,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-14.4,62,100400,0,0,208,0,0,0,0,0,0,0,220,6.7,0,0,24.1,77777,9,999999999,50,0.0450,0,88,999.000,999.0,99.0
+1986,1,9,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-14.4,62,100300,0,0,208,0,0,0,0,0,0,0,230,6.7,0,0,24.1,77777,9,999999999,50,0.0450,0,88,999.000,999.0,99.0
+1986,1,9,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-14.4,62,100100,0,0,208,0,0,0,0,0,0,0,210,6.7,0,0,24.1,77777,9,999999999,50,0.0450,0,88,999.000,999.0,99.0
+1986,1,9,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-14.4,62,100000,0,0,208,0,0,0,0,0,0,0,220,6.7,0,0,24.1,77777,9,999999999,50,0.0450,0,88,999.000,999.0,99.0
+1986,1,9,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-14.4,59,100000,0,0,210,0,0,0,0,0,0,0,220,6.2,0,0,24.1,77777,9,999999999,50,0.0450,0,88,999.000,999.0,99.0
+1986,1,9,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-14.4,59,100000,45,931,210,18,16,17,2000,800,1900,410,230,7.2,0,0,24.1,77777,9,999999999,50,0.1970,0,88,999.000,999.0,99.0
+1986,1,9,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.6,-14.4,50,99900,242,1415,226,90,160,61,9400,11000,7500,1150,220,8.8,4,3,24.1,77777,9,999999999,50,0.1970,0,88,999.000,999.0,99.0
+1986,1,9,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.9,-13.3,48,99900,419,1415,236,207,241,134,21500,21600,15100,2770,230,6.7,9,5,24.1,6710,9,999999999,50,0.1970,0,88,999.000,999.0,99.0
+1986,1,9,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-12.2,49,99700,545,1415,246,277,182,206,29600,17600,22800,4800,210,7.2,9,7,24.1,6100,9,999999999,50,0.1970,0,88,999.000,999.0,99.0
+1986,1,9,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-10.6,47,99600,609,1415,251,323,325,182,34200,32700,20100,3950,230,6.7,9,5,24.1,6100,9,999999999,60,0.1970,0,88,999.000,999.0,99.0
+1986,1,9,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-9.4,48,99400,608,1415,253,359,347,209,37700,34800,22600,4690,230,7.2,8,3,24.1,77777,9,999999999,60,0.1970,0,88,999.000,999.0,99.0
+1986,1,9,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-9.4,44,99300,542,1415,257,273,298,159,29000,29100,17800,3350,230,9.3,7,3,24.1,77777,9,999999999,60,0.1970,0,88,999.000,999.0,99.0
+1986,1,9,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-8.9,46,99300,414,1415,251,211,389,97,22100,34100,12100,1810,230,6.2,3,1,24.1,77777,9,999999999,69,0.1970,0,88,999.000,999.0,99.0
+1986,1,9,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-8.3,48,99200,235,1415,255,89,199,57,9600,13500,7300,1060,220,7.2,2,2,24.1,77777,9,999999999,69,0.1970,0,88,999.000,999.0,99.0
+1986,1,9,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-8.3,54,99200,40,861,246,14,6,13,1500,300,1400,320,230,6.7,6,1,24.1,77777,9,999999999,69,0.1970,0,88,999.000,999.0,99.0
+1986,1,9,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-7.8,56,99200,0,0,249,0,0,0,0,0,0,0,220,5.2,3,2,24.1,77777,9,999999999,69,0.1970,0,88,999.000,999.0,99.0
+1986,1,9,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-7.8,56,99200,0,0,256,0,0,0,0,0,0,0,240,6.2,7,5,24.1,6710,9,999999999,69,0.1970,0,88,999.000,999.0,99.0
+1986,1,9,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-7.2,54,99200,0,0,276,0,0,0,0,0,0,0,240,6.7,10,9,24.1,5490,9,999999999,69,0.1970,0,88,999.000,999.0,99.0
+1986,1,9,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-6.7,59,99200,0,0,282,0,0,0,0,0,0,0,240,4.6,10,10,24.1,5490,9,999999999,69,0.1970,0,88,999.000,999.0,99.0
+1986,1,9,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-5.6,67,99300,0,0,281,0,0,0,0,0,0,0,250,5.2,10,10,24.1,4270,9,999999999,80,0.1970,0,88,999.000,999.0,99.0
+1986,1,9,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-5.0,72,99300,0,0,279,0,0,0,0,0,0,0,260,3.6,10,10,24.1,3660,9,999999999,80,0.1970,0,88,999.000,999.0,99.0
+1986,1,9,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-4.4,78,99200,0,0,278,0,0,0,0,0,0,0,270,6.7,10,10,24.1,3660,9,999999999,80,0.1970,0,88,999.000,999.0,99.0
+1986,1,10,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-3.9,82,99200,0,0,278,0,0,0,0,0,0,0,260,7.2,10,10,24.1,3660,9,999999999,89,0.1970,0,88,999.000,999.0,99.0
+1986,1,10,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-3.9,82,99300,0,0,270,0,0,0,0,0,0,0,280,4.1,10,9,19.3,3660,9,999999999,89,0.1970,0,88,999.000,999.0,99.0
+1986,1,10,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-3.3,82,99400,0,0,267,0,0,0,0,0,0,0,310,4.6,8,8,16.1,3660,9,999999999,89,0.1970,0,88,999.000,999.0,99.0
+1986,1,10,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-3.3,79,99400,0,0,270,0,0,0,0,0,0,0,320,4.6,8,8,16.1,3660,9,999999999,89,0.1970,0,88,999.000,999.0,99.0
+1986,1,10,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-3.3,79,99500,0,0,265,0,0,0,0,0,0,0,320,5.7,7,7,16.1,3660,9,999999999,89,0.1970,0,88,999.000,999.0,99.0
+1986,1,10,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.0,78,99700,0,0,242,0,0,0,0,0,0,0,320,4.1,1,1,19.3,77777,9,999999999,80,0.1970,0,88,999.000,999.0,99.0
+1986,1,10,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-5.0,85,99800,0,0,242,0,0,0,0,0,0,0,320,4.1,2,2,19.3,77777,9,999999999,80,0.1970,0,88,999.000,999.0,99.0
+1986,1,10,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-5.6,81,99900,45,931,234,22,69,16,2100,2000,2000,280,310,3.1,0,0,16.1,77777,9,999999999,80,0.1050,0,88,999.000,999.0,99.0
+1986,1,10,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-5.0,75,100000,243,1415,240,123,427,47,12300,30600,7000,830,310,4.1,0,0,24.1,77777,9,999999999,80,0.1050,0,88,999.000,999.0,99.0
+1986,1,10,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-5.6,67,100000,421,1415,243,257,629,67,26600,55600,9900,1270,320,5.2,0,0,24.1,77777,9,999999999,80,0.1050,0,88,999.000,999.0,99.0
+1986,1,10,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-5.0,64,100000,547,1415,248,365,727,81,38200,68900,11400,1620,330,4.1,0,0,24.1,77777,9,999999999,80,0.1050,0,88,999.000,999.0,99.0
+1986,1,10,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-5.0,62,100000,612,1415,250,419,760,87,42900,72600,11300,1680,300,3.1,0,0,24.1,77777,9,999999999,80,0.1050,0,88,999.000,999.0,99.0
+1986,1,10,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-5.0,59,100000,612,1415,252,418,762,87,42900,72800,11300,1680,290,3.1,0,0,24.1,77777,9,999999999,80,0.1050,0,88,999.000,999.0,99.0
+1986,1,10,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-5.0,62,100000,545,1415,250,360,725,80,37900,68700,11300,1600,270,3.1,0,0,24.1,77777,9,999999999,80,0.1050,0,88,999.000,999.0,99.0
+1986,1,10,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-5.6,59,100000,418,1415,250,250,626,66,26200,55300,9800,1250,280,3.6,0,0,24.1,77777,9,999999999,80,0.1050,0,88,999.000,999.0,99.0
+1986,1,10,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-5.6,64,100000,239,1415,246,113,410,45,11700,29200,6700,800,280,3.6,0,0,24.1,77777,9,999999999,80,0.1050,0,88,999.000,999.0,99.0
+1986,1,10,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-6.1,69,100000,43,908,239,21,52,16,2000,1500,1900,280,260,3.1,2,0,24.1,77777,9,999999999,80,0.1050,0,88,999.000,999.0,99.0
+1986,1,10,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-6.1,78,100000,0,0,233,0,0,0,0,0,0,0,240,2.6,0,0,24.1,77777,9,999999999,80,0.1050,0,88,999.000,999.0,99.0
+1986,1,10,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-6.7,85,100000,0,0,227,0,0,0,0,0,0,0,240,2.6,0,0,24.1,77777,9,999999999,69,0.1050,0,88,999.000,999.0,99.0
+1986,1,10,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-6.7,88,99900,0,0,225,0,0,0,0,0,0,0,230,2.1,0,0,24.1,77777,9,999999999,69,0.1050,0,88,999.000,999.0,99.0
+1986,1,10,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-7.2,92,99900,0,0,221,0,0,0,0,0,0,0,240,2.6,2,0,24.1,77777,9,999999999,69,0.1050,0,88,999.000,999.0,99.0
+1986,1,10,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-5.6,92,99900,0,0,263,0,0,0,0,0,0,0,280,4.1,10,10,9.7,210,9,999999999,80,0.1050,0,88,999.000,999.0,99.0
+1986,1,10,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-6.1,92,99900,0,0,260,0,0,0,0,0,0,0,260,4.1,10,10,8.0,180,9,999999999,80,0.1050,0,88,999.000,999.0,99.0
+1986,1,10,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-6.1,96,99800,0,0,258,0,0,0,0,0,0,0,260,4.6,10,10,2.4,120,9,999999999,80,0.1050,0,88,999.000,999.0,99.0
+1986,1,11,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-5.0,96,99800,0,0,264,0,0,0,0,0,0,0,260,4.6,10,10,4.8,180,9,999999999,80,0.1050,0,88,999.000,999.0,99.0
+1986,1,11,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-3.9,96,99800,0,0,269,0,0,0,0,0,0,0,260,6.2,10,10,4.8,180,9,999999999,89,0.1050,0,88,999.000,999.0,99.0
+1986,1,11,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-3.3,96,99600,0,0,272,0,0,0,0,0,0,0,270,5.7,10,10,4.8,180,9,999999999,89,0.1050,0,88,999.000,999.0,99.0
+1986,1,11,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-2.8,100,99600,0,0,272,0,0,0,0,0,0,0,230,3.1,10,10,4.8,180,9,999999999,89,0.1050,0,88,999.000,999.0,99.0
+1986,1,11,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-3.3,100,99500,0,0,270,0,0,0,0,0,0,0,260,4.6,10,10,4.8,180,9,999999999,89,0.1050,0,88,999.000,999.0,99.0
+1986,1,11,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-4.4,92,99500,0,0,269,0,0,0,0,0,0,0,260,4.6,10,10,4.8,180,9,999999999,80,0.1050,0,88,999.000,999.0,99.0
+1986,1,11,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-4.4,96,99400,0,0,266,0,0,0,0,0,0,0,220,3.1,10,10,4.8,120,9,999999999,80,0.1050,0,88,999.000,999.0,99.0
+1986,1,11,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.9,-5.0,92,99400,46,931,266,12,2,11,1300,0,1300,400,210,4.1,10,10,3.2,120,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1986,1,11,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-4.4,92,99300,245,1414,269,57,6,56,6400,100,6400,1940,220,5.7,10,10,3.2,150,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1986,1,11,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-3.9,89,99300,423,1414,266,159,75,136,17300,6900,15300,3450,230,4.6,9,9,4.8,210,9,999999999,89,0.0550,0,88,999.000,999.0,99.0
+1986,1,11,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-3.3,85,99200,550,1414,265,205,183,133,22000,18000,15000,2700,240,5.7,9,8,4.8,210,9,999999999,89,0.0550,0,88,999.000,999.0,99.0
+1986,1,11,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-2.8,82,99100,615,1414,259,352,483,140,37100,47200,16500,2790,230,5.7,9,4,8.0,77777,9,999999999,89,0.0550,0,88,999.000,999.0,99.0
+1986,1,11,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-2.2,73,99000,615,1414,265,372,518,146,39200,50600,17100,2930,230,5.7,8,3,9.7,77777,9,999999999,89,0.0550,0,88,999.000,999.0,99.0
+1986,1,11,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-2.2,65,98900,549,1414,269,333,574,110,34300,53600,13400,2080,220,5.7,8,2,12.9,77777,9,999999999,89,0.0550,0,88,999.000,999.0,99.0
+1986,1,11,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-1.7,65,98800,422,1414,268,244,642,53,25400,57400,8200,1060,220,5.2,3,1,14.5,77777,9,999999999,100,0.0550,0,88,999.000,999.0,99.0
+1986,1,11,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-1.1,73,98800,244,1414,260,120,515,32,12400,39100,5700,640,220,5.2,0,0,16.1,77777,9,999999999,100,0.0550,0,88,999.000,999.0,99.0
+1986,1,11,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-1.1,79,98800,45,931,255,25,120,14,2100,5100,1800,260,210,4.6,2,0,16.1,77777,9,999999999,100,0.0550,0,88,999.000,999.0,99.0
+1986,1,11,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-0.6,82,98700,0,0,256,0,0,0,0,0,0,0,220,4.6,0,0,16.1,77777,9,999999999,100,0.0550,0,88,999.000,999.0,99.0
+1986,1,11,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-0.6,79,98700,0,0,258,0,0,0,0,0,0,0,220,6.7,0,0,16.1,77777,9,999999999,100,0.0550,0,88,999.000,999.0,99.0
+1986,1,11,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-0.6,79,98600,0,0,258,0,0,0,0,0,0,0,220,6.2,0,0,24.1,77777,9,999999999,100,0.0550,0,88,999.000,999.0,99.0
+1986,1,11,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-0.6,76,98500,0,0,260,0,0,0,0,0,0,0,260,6.7,0,0,24.1,77777,9,999999999,100,0.0550,0,88,999.000,999.0,99.0
+1986,1,11,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-0.6,82,98500,0,0,256,0,0,0,0,0,0,0,250,6.7,0,0,24.1,77777,9,999999999,100,0.0550,0,88,999.000,999.0,99.0
+1986,1,11,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-1.1,82,98500,0,0,254,0,0,0,0,0,0,0,230,7.2,0,0,24.1,77777,9,999999999,100,0.0550,0,88,999.000,999.0,99.0
+1986,1,11,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.7,82,98400,0,0,251,0,0,0,0,0,0,0,260,6.7,0,0,24.1,77777,9,999999999,100,0.0550,0,88,999.000,999.0,99.0
+1986,1,12,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-2.2,79,98400,0,0,250,0,0,0,0,0,0,0,260,6.7,0,0,24.1,77777,9,999999999,89,0.0550,0,88,999.000,999.0,99.0
+1986,1,12,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-2.8,73,98400,0,0,252,0,0,0,0,0,0,0,260,7.7,0,0,24.1,77777,9,999999999,89,0.0550,0,88,999.000,999.0,99.0
+1986,1,12,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-4.4,57,98400,0,0,257,0,0,0,0,0,0,0,270,8.8,0,0,24.1,77777,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1986,1,12,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,-5.0,53,98400,0,0,258,0,0,0,0,0,0,0,260,8.2,0,0,24.1,77777,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1986,1,12,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-4.4,57,98300,0,0,257,0,0,0,0,0,0,0,260,8.8,0,0,24.1,77777,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1986,1,12,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-5.6,57,98300,0,0,251,0,0,0,0,0,0,0,260,7.7,0,0,24.1,77777,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1986,1,12,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-5.6,59,98300,0,0,250,0,0,0,0,0,0,0,260,7.2,0,0,24.1,77777,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1986,1,12,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-5.6,62,98300,47,931,247,24,78,17,2200,2800,2100,300,250,7.2,0,0,24.1,77777,9,999999999,80,0.1020,0,88,999.000,999.0,99.0
+1986,1,12,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-5.0,57,98300,247,1414,275,91,139,66,9500,9700,7800,1260,270,8.2,7,7,24.1,1070,9,999999999,80,0.1020,0,88,999.000,999.0,99.0
+1986,1,12,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-5.0,57,98300,426,1414,293,75,1,74,8600,100,8600,2970,260,10.3,10,10,24.1,880,9,999999999,80,0.1020,0,88,999.000,999.0,99.0
+1986,1,12,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-4.4,59,98300,553,1414,294,121,5,119,13900,300,13800,4810,270,7.7,10,10,24.1,880,9,999999999,80,0.1020,0,88,999.000,999.0,99.0
+1986,1,12,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-5.0,57,98300,619,1414,293,156,1,156,17800,100,17800,6200,260,7.2,10,10,24.1,1160,9,999999999,80,0.1020,0,88,999.000,999.0,99.0
+1986,1,12,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-4.4,59,98400,619,1414,294,170,1,170,19300,100,19300,6580,270,7.7,10,10,24.1,1400,9,999999999,80,0.1020,0,88,999.000,999.0,99.0
+1986,1,12,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-4.4,57,98400,553,1414,296,168,4,167,18900,300,18700,6070,270,8.8,10,10,24.1,1400,9,999999999,80,0.1020,0,88,999.000,999.0,99.0
+1986,1,12,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-2.2,73,98500,427,1414,294,116,5,114,12900,300,12800,4090,270,7.7,10,10,12.9,1400,9,999999999,89,0.1020,0,88,999.000,999.0,99.0
+1986,1,12,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-2.8,73,98600,248,1414,291,59,3,58,6600,100,6500,2000,280,7.2,10,10,4.8,640,9,999999999,89,0.1020,0,88,999.000,999.0,99.0
+1986,1,12,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-2.2,82,98800,48,955,287,12,0,12,1400,0,1400,430,320,6.2,10,10,3.2,370,9,999999999,89,0.1020,0,88,999.000,999.0,99.0
+1986,1,12,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-5.6,69,99000,0,0,278,0,0,0,0,0,0,0,340,8.8,10,10,19.3,700,9,999999999,80,0.1020,0,88,999.000,999.0,99.0
+1986,1,12,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-6.1,81,99200,0,0,267,0,0,0,0,0,0,0,330,10.3,10,10,19.3,1400,9,999999999,80,0.1020,0,88,999.000,999.0,99.0
+1986,1,12,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-12.2,57,99300,0,0,254,0,0,0,0,0,0,0,330,7.7,10,10,19.3,1680,9,999999999,50,0.1020,0,88,999.000,999.0,99.0
+1986,1,12,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-13.9,55,99400,0,0,215,0,0,0,0,0,0,0,330,6.7,0,0,24.1,77777,9,999999999,50,0.1020,0,88,999.000,999.0,99.0
+1986,1,12,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-14.4,54,99500,0,0,213,0,0,0,0,0,0,0,320,8.2,0,0,24.1,77777,9,999999999,50,0.1020,0,88,999.000,999.0,99.0
+1986,1,12,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-14.4,57,99600,0,0,211,0,0,0,0,0,0,0,320,7.7,0,0,24.1,77777,9,999999999,50,0.1020,0,88,999.000,999.0,99.0
+1986,1,12,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-9.4,-16.1,59,99700,0,0,203,0,0,0,0,0,0,0,330,6.7,0,0,24.1,77777,9,999999999,50,0.1020,0,88,999.000,999.0,99.0
+1986,1,13,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-9.4,-15.6,62,99800,0,0,204,0,0,0,0,0,0,0,330,6.7,0,0,24.1,77777,9,999999999,50,0.1020,0,88,999.000,999.0,99.0
+1986,1,13,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-9.4,-15.0,64,99800,0,0,224,0,0,0,0,0,0,0,330,5.7,8,8,24.1,1010,9,999999999,50,0.1020,0,88,999.000,999.0,99.0
+1986,1,13,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.0,-15.0,67,99800,0,0,222,0,0,0,0,0,0,0,350,7.7,8,8,24.1,1010,9,999999999,50,0.1020,0,88,999.000,999.0,99.0
+1986,1,13,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.0,-15.6,64,99900,0,0,222,0,0,0,0,0,0,0,330,8.8,8,8,24.1,1010,9,999999999,50,0.1020,0,88,999.000,999.0,99.0
+1986,1,13,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.1,-15.6,70,99900,0,0,207,0,0,0,0,0,0,0,330,6.7,3,3,24.1,77777,9,999999999,50,0.1020,0,88,999.000,999.0,99.0
+1986,1,13,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.1,-16.1,67,100000,0,0,198,0,0,0,0,0,0,0,320,5.7,0,0,24.1,77777,9,999999999,50,0.1020,0,88,999.000,999.0,99.0
+1986,1,13,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.1,-16.7,64,100000,0,0,198,0,0,0,0,0,0,0,320,4.6,0,0,24.1,77777,9,999999999,40,0.1020,0,88,999.000,999.0,99.0
+1986,1,13,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-11.1,-16.7,64,100100,48,955,198,23,39,19,2300,1600,2200,390,330,6.2,3,0,24.1,77777,9,999999999,40,0.1380,0,88,999.000,999.0,99.0
+1986,1,13,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.0,-16.1,61,100100,249,1414,201,119,356,55,12300,25200,7900,990,330,5.7,2,0,24.1,77777,9,999999999,50,0.1380,0,88,999.000,999.0,99.0
+1986,1,13,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.3,-15.6,56,100100,428,1414,207,253,582,74,26000,51500,10300,1380,330,4.1,0,0,24.1,77777,9,999999999,50,0.1380,0,88,999.000,999.0,99.0
+1986,1,13,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.2,-14.4,57,100100,556,1414,211,359,679,90,37400,64300,12000,1780,330,4.1,0,0,24.1,77777,9,999999999,50,0.1380,0,88,999.000,999.0,99.0
+1986,1,13,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.1,-13.9,55,99900,622,1414,215,418,718,100,43700,69500,13000,2040,280,3.6,1,0,24.1,77777,9,999999999,50,0.1380,0,88,999.000,999.0,99.0
+1986,1,13,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.0,-13.3,53,99800,623,1414,224,393,619,120,40700,59400,14400,2370,260,2.6,6,1,24.1,77777,9,999999999,50,0.1380,0,88,999.000,999.0,99.0
+1986,1,13,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.1,-13.3,57,99800,558,1414,234,261,115,216,28600,11200,24200,5570,260,5.2,10,7,24.1,6100,9,999999999,50,0.1380,0,88,999.000,999.0,99.0
+1986,1,13,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.1,-13.9,55,99600,431,1414,227,216,313,121,22900,28400,14200,2440,250,4.1,8,4,24.1,77777,9,999999999,50,0.1380,0,88,999.000,999.0,99.0
+1986,1,13,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.2,-14.4,57,99600,253,1414,244,27,3,26,3200,0,3200,1050,250,5.2,10,10,24.1,6100,9,999999999,50,0.1380,0,88,999.000,999.0,99.0
+1986,1,13,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.3,-14.4,62,99500,51,978,240,9,1,9,1100,0,1100,340,240,3.1,10,10,24.1,6100,9,999999999,50,0.1380,0,88,999.000,999.0,99.0
+1986,1,13,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-13.3,68,99400,0,0,241,0,0,0,0,0,0,0,240,3.1,10,10,24.1,6100,9,999999999,50,0.1380,0,88,999.000,999.0,99.0
+1986,1,13,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-13.3,71,99400,0,0,239,0,0,0,0,0,0,0,0,0.0,10,10,24.1,6100,9,999999999,50,0.1380,0,88,999.000,999.0,99.0
+1986,1,13,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-11.7,71,99200,0,0,247,0,0,0,0,0,0,0,180,3.1,10,10,24.1,3050,9,999999999,60,0.1380,0,88,999.000,999.0,99.0
+1986,1,13,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-11.7,71,99100,0,0,247,0,0,0,0,0,0,0,180,3.1,10,10,24.1,3050,9,999999999,60,0.1380,0,88,999.000,999.0,99.0
+1986,1,13,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-11.1,71,99100,0,0,249,0,0,0,0,0,0,0,190,3.1,10,10,24.1,3050,9,999999999,60,0.1380,0,88,999.000,999.0,99.0
+1986,1,13,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-10.6,74,99000,0,0,250,0,0,0,0,0,0,0,180,3.1,10,10,24.1,3050,9,999999999,60,0.1380,0,88,999.000,999.0,99.0
+1986,1,13,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-11.1,71,98800,0,0,249,0,0,0,0,0,0,0,190,3.1,10,10,24.1,3050,9,999999999,60,0.1380,0,88,999.000,999.0,99.0
+1986,1,14,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-11.1,74,98700,0,0,247,0,0,0,0,0,0,0,180,5.2,10,10,24.1,2740,9,999999999,60,0.1380,0,88,999.000,999.0,99.0
+1986,1,14,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-10.6,81,98600,0,0,245,0,0,0,0,0,0,0,190,4.1,10,10,24.1,2130,9,999999999,60,0.1380,0,88,999.000,999.0,99.0
+1986,1,14,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-8.9,72,98500,0,0,260,0,0,0,0,0,0,0,190,2.6,10,10,24.1,1520,9,999999999,60,0.1380,0,88,999.000,999.0,99.0
+1986,1,14,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-8.9,72,98500,0,0,260,0,0,0,0,0,0,0,190,2.6,10,10,24.1,1160,9,999999999,60,0.1380,0,88,999.000,999.0,99.0
+1986,1,14,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-10.0,74,98500,0,0,252,0,0,0,0,0,0,0,0,0.0,10,10,24.1,1400,9,999999999,60,0.1380,0,88,999.000,999.0,99.0
+1986,1,14,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-10.0,78,98500,0,0,250,0,0,0,0,0,0,0,330,2.1,10,10,19.3,1160,9,999999999,60,0.1380,0,88,999.000,999.0,99.0
+1986,1,14,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-8.9,78,98700,0,0,255,0,0,0,0,0,0,0,340,2.6,10,10,19.3,700,9,999999999,60,0.1380,0,88,999.000,999.0,99.0
+1986,1,14,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-9.4,69,98800,49,955,259,16,3,16,1800,0,1800,550,350,6.2,10,10,14.5,700,9,999999999,60,0.0620,0,88,999.000,999.0,99.0
+1986,1,14,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.0,-10.0,68,99000,251,1414,257,79,7,77,8600,200,8500,2400,350,4.6,10,10,11.3,1830,9,999999999,60,0.0620,0,88,999.000,999.0,99.0
+1986,1,14,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-9.4,69,99100,431,1414,259,131,8,128,14500,500,14300,4420,330,6.2,10,10,11.3,1680,9,999999999,60,0.0620,0,88,999.000,999.0,99.0
+1986,1,14,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-9.4,69,99200,559,1414,259,154,2,154,17500,100,17400,5800,330,5.7,10,10,11.3,1680,9,999999999,60,0.0620,0,88,999.000,999.0,99.0
+1986,1,14,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.9,-9.4,66,99300,626,1414,261,188,6,186,21200,500,21000,7020,330,6.7,10,10,11.3,700,9,999999999,60,0.0620,0,88,999.000,999.0,99.0
+1986,1,14,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.9,-10.6,60,99400,627,1414,260,191,4,189,21500,300,21300,7100,350,4.1,10,10,12.9,760,9,999999999,60,0.0620,0,88,999.000,999.0,99.0
+1986,1,14,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-12.2,51,99400,562,1414,226,389,832,58,40900,78700,9500,1260,360,5.2,0,0,16.1,77777,9,999999999,50,0.0620,0,88,999.000,999.0,99.0
+1986,1,14,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-12.2,49,99600,436,1414,232,257,655,57,26800,58800,8600,1120,350,6.2,2,1,19.3,77777,9,999999999,50,0.0620,0,88,999.000,999.0,99.0
+1986,1,14,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.9,-12.8,51,99700,257,1414,228,110,383,41,11500,28400,6300,750,340,6.2,3,1,19.3,77777,9,999999999,50,0.0620,0,88,999.000,999.0,99.0
+1986,1,14,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.6,-13.3,55,99900,54,1002,218,29,144,15,2400,6400,2000,270,350,4.6,0,0,24.1,77777,9,999999999,50,0.0620,0,88,999.000,999.0,99.0
+1986,1,14,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-12.8,62,100000,0,0,214,0,0,0,0,0,0,0,360,4.1,0,0,24.1,77777,9,999999999,50,0.0620,0,88,999.000,999.0,99.0
+1986,1,14,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-12.8,65,100000,0,0,213,0,0,0,0,0,0,0,340,3.6,0,0,24.1,77777,9,999999999,50,0.0620,0,88,999.000,999.0,99.0
+1986,1,14,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-12.2,68,100100,0,0,213,0,0,0,0,0,0,0,330,3.6,0,0,24.1,77777,9,999999999,50,0.0620,0,88,999.000,999.0,99.0
+1986,1,14,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-9.4,-12.8,77,100100,0,0,210,0,0,0,0,0,0,0,320,2.6,1,1,24.1,77777,9,999999999,50,0.0620,0,88,999.000,999.0,99.0
+1986,1,14,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-9.4,-13.3,74,100100,0,0,205,0,0,0,0,0,0,0,270,1.5,0,0,24.1,77777,9,999999999,50,0.0620,0,88,999.000,999.0,99.0
+1986,1,14,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.7,-13.3,88,100100,0,0,198,0,0,0,0,0,0,0,270,2.1,0,0,24.1,77777,9,999999999,50,0.0620,0,88,999.000,999.0,99.0
+1986,1,14,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-14.4,-15.6,91,100100,0,0,189,0,0,0,0,0,0,0,270,2.1,0,0,24.1,77777,9,999999999,50,0.0620,0,88,999.000,999.0,99.0
+1986,1,15,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-14.4,-16.1,87,100100,0,0,188,0,0,0,0,0,0,0,230,2.1,0,0,24.1,77777,9,999999999,50,0.0620,0,88,999.000,999.0,99.0
+1986,1,15,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-14.4,-15.6,91,100100,0,0,189,0,0,0,0,0,0,0,230,2.1,0,0,24.1,77777,9,999999999,50,0.0620,0,88,999.000,999.0,99.0
+1986,1,15,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-14.4,-15.6,91,100100,0,0,189,0,0,0,0,0,0,0,230,2.6,0,0,24.1,77777,9,999999999,50,0.0620,0,88,999.000,999.0,99.0
+1986,1,15,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-13.9,-15.0,91,100100,0,0,191,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,50,0.0620,0,88,999.000,999.0,99.0
+1986,1,15,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.8,-13.9,92,100100,0,0,195,0,0,0,0,0,0,0,200,2.1,0,0,24.1,77777,9,999999999,50,0.0620,0,88,999.000,999.0,99.0
+1986,1,15,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.2,-15.0,80,100000,0,0,196,0,0,0,0,0,0,0,170,2.1,0,0,24.1,77777,9,999999999,50,0.0620,0,88,999.000,999.0,99.0
+1986,1,15,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.0,-12.8,80,100000,0,0,204,0,0,0,0,0,0,0,170,3.1,2,0,16.1,77777,9,999999999,50,0.0620,0,88,999.000,999.0,99.0
+1986,1,15,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.3,-11.1,81,100000,50,978,215,24,33,21,2500,1300,2400,430,210,3.6,8,1,16.1,77777,9,999999999,60,0.1020,0,88,999.000,999.0,99.0
+1986,1,15,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.1,-8.9,81,100000,253,1414,227,88,153,60,9300,10800,7300,1120,210,4.6,10,2,16.1,77777,9,999999999,60,0.1020,0,88,999.000,999.0,99.0
+1986,1,15,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-9.4,69,100000,434,1414,229,244,522,81,24900,46200,10600,1500,210,5.7,7,1,16.1,77777,9,999999999,60,0.1020,0,88,999.000,999.0,99.0
+1986,1,15,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-8.9,63,99900,562,1414,231,376,711,91,39200,67500,12200,1800,210,7.2,4,0,16.1,77777,9,999999999,60,0.1020,0,88,999.000,999.0,99.0
+1986,1,15,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-7.8,61,99800,629,1414,238,426,731,99,44700,71000,12900,2030,230,5.2,4,0,11.3,77777,9,999999999,69,0.1020,0,88,999.000,999.0,99.0
+1986,1,15,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-6.7,59,99600,631,1414,245,432,680,127,44500,65200,15300,2500,220,8.2,9,0,9.7,77777,9,999999999,69,0.1020,0,88,999.000,999.0,99.0
+1986,1,15,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-6.1,57,99600,566,1414,249,368,629,116,37900,59100,14100,2200,220,7.2,9,0,9.7,77777,9,999999999,80,0.1020,0,88,999.000,999.0,99.0
+1986,1,15,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-5.6,55,99500,440,1414,262,193,250,115,20500,22900,13400,2290,210,6.2,8,2,9.7,77777,9,999999999,80,0.1020,0,88,999.000,999.0,99.0
+1986,1,15,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-5.6,55,99500,262,1414,258,110,247,65,11500,17900,8100,1190,220,5.2,9,1,9.7,77777,9,999999999,80,0.1020,0,88,999.000,999.0,99.0
+1986,1,15,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-5.6,64,99600,57,1025,256,22,26,20,2400,1100,2300,410,220,3.1,9,3,9.7,77777,9,999999999,80,0.1020,0,88,999.000,999.0,99.0
+1986,1,15,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-5.6,67,99700,0,0,248,0,0,0,0,0,0,0,250,1.5,7,1,9.7,77777,9,999999999,80,0.1020,0,88,999.000,999.0,99.0
+1986,1,15,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-6.1,78,99700,0,0,238,0,0,0,0,0,0,0,180,1.5,6,1,11.3,77777,9,999999999,80,0.1020,0,88,999.000,999.0,99.0
+1986,1,15,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-6.1,75,99700,0,0,243,0,0,0,0,0,0,0,180,2.6,7,2,11.3,77777,9,999999999,80,0.1020,0,88,999.000,999.0,99.0
+1986,1,15,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-6.1,75,99700,0,0,245,0,0,0,0,0,0,0,180,1.5,8,3,11.3,77777,9,999999999,80,0.1020,0,88,999.000,999.0,99.0
+1986,1,15,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-6.1,92,99700,0,0,230,0,0,0,0,0,0,0,170,1.5,3,1,11.3,77777,9,999999999,80,0.1020,0,88,999.000,999.0,99.0
+1986,1,15,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-6.7,78,99700,0,0,231,0,0,0,0,0,0,0,180,2.1,0,0,12.9,77777,9,999999999,69,0.1020,0,88,999.000,999.0,99.0
+1986,1,15,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-6.7,88,99700,0,0,225,0,0,0,0,0,0,0,170,2.1,0,0,12.9,77777,9,999999999,69,0.1020,0,88,999.000,999.0,99.0
+1986,1,16,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-7.2,88,99700,0,0,223,0,0,0,0,0,0,0,130,2.1,0,0,12.9,77777,9,999999999,69,0.1020,0,88,999.000,999.0,99.0
+1986,1,16,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-7.8,92,99700,0,0,219,0,0,0,0,0,0,0,170,2.6,0,0,11.3,77777,9,999999999,69,0.1020,0,88,999.000,999.0,99.0
+1986,1,16,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-8.3,92,99700,0,0,217,0,0,0,0,0,0,0,160,2.1,0,0,11.3,77777,9,999999999,69,0.1020,0,88,999.000,999.0,99.0
+1986,1,16,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-7.2,88,99700,0,0,223,0,0,0,0,0,0,0,170,2.6,0,0,11.3,77777,9,999999999,69,0.1020,0,88,999.000,999.0,99.0
+1986,1,16,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-7.2,85,99700,0,0,225,0,0,0,0,0,0,0,140,2.6,0,0,11.3,77777,9,999999999,69,0.1020,0,88,999.000,999.0,99.0
+1986,1,16,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-6.7,88,99700,0,0,225,0,0,0,0,0,0,0,170,2.6,0,0,9.7,77777,9,999999999,69,0.1020,0,88,999.000,999.0,99.0
+1986,1,16,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-6.7,85,99700,0,0,235,0,0,0,0,0,0,0,160,2.6,2,2,8.0,77777,9,999999999,69,0.1020,0,88,999.000,999.0,99.0
+1986,1,16,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.9,-6.1,85,99600,52,978,234,16,22,15,1800,900,1800,310,160,3.1,3,1,6.4,77777,9,999999999,80,0.1740,0,88,999.000,999.0,99.0
+1986,1,16,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-4.4,78,99600,255,1414,251,105,121,83,11300,9000,9600,1780,180,4.1,10,3,8.0,77777,9,999999999,80,0.1740,0,88,999.000,999.0,99.0
+1986,1,16,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-3.3,73,99600,436,1414,264,206,199,144,22200,18200,16500,3230,170,4.1,10,5,9.7,77777,9,999999999,89,0.1740,0,88,999.000,999.0,99.0
+1986,1,16,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-2.8,67,99600,565,1414,296,137,0,137,15600,0,15600,5390,170,3.1,10,10,9.7,5490,9,999999999,89,0.1740,0,88,999.000,999.0,99.0
+1986,1,16,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-2.2,62,99500,633,1414,284,247,112,197,26900,11300,21800,4750,190,3.6,9,7,12.9,6100,9,999999999,89,0.1740,0,88,999.000,999.0,99.0
+1986,1,16,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,-0.6,58,99300,635,1414,280,388,587,123,40100,56500,14600,2440,180,4.1,4,1,16.1,77777,9,999999999,100,0.1740,0,88,999.000,999.0,99.0
+1986,1,16,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,0.6,54,99200,571,1414,290,333,547,113,34500,51600,13600,2170,180,5.7,3,1,19.3,77777,9,999999999,110,0.1740,0,88,999.000,999.0,99.0
+1986,1,16,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,1.7,57,99200,445,1414,303,181,148,135,19700,13700,15400,3040,180,6.7,9,4,11.3,77777,9,999999999,120,0.1740,0,88,999.000,999.0,99.0
+1986,1,16,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,2.2,59,99100,267,1414,304,93,113,72,10200,8600,8500,1540,180,4.6,8,4,11.3,77777,9,999999999,120,0.1740,0,88,999.000,999.0,99.0
+1986,1,16,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,2.2,66,99200,60,1049,294,18,16,17,2000,900,1900,420,180,5.2,6,3,9.7,77777,9,999999999,120,0.1740,0,88,999.000,999.0,99.0
+1986,1,16,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,2.8,68,99200,0,0,326,0,0,0,0,0,0,0,180,7.7,10,10,9.7,2740,9,999999999,129,0.1740,0,88,999.000,999.0,99.0
+1986,1,16,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,2.8,68,99200,0,0,326,0,0,0,0,0,0,0,180,5.7,10,10,9.7,2740,9,999999999,129,0.1740,0,88,999.000,999.0,99.0
+1986,1,16,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,3.3,69,99200,0,0,330,0,0,0,0,0,0,0,190,7.2,10,10,9.7,1400,9,999999999,129,0.1740,0,88,999.000,999.0,99.0
+1986,1,16,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,2.8,68,99100,0,0,311,0,0,0,0,0,0,0,190,7.2,10,8,9.7,2440,9,999999999,129,0.1740,0,88,999.000,999.0,99.0
+1986,1,16,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,2.8,68,99100,0,0,326,0,0,0,0,0,0,0,210,6.7,10,10,11.3,2440,9,999999999,129,0.1740,0,88,999.000,999.0,99.0
+1986,1,16,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,3.3,74,99100,0,0,325,0,0,0,0,0,0,0,210,6.7,10,10,11.3,1400,9,999999999,129,0.1740,0,88,999.000,999.0,99.0
+1986,1,16,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,3.9,80,99000,0,0,322,0,0,0,0,0,0,0,210,7.2,10,10,11.3,1160,9,999999999,129,0.1740,0,88,999.000,999.0,99.0
+1986,1,17,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,3.9,83,99100,0,0,320,0,0,0,0,0,0,0,210,5.7,10,10,11.3,7620,9,999999999,139,0.1740,0,88,999.000,999.0,99.0
+1986,1,17,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,3.9,86,99100,0,0,317,0,0,0,0,0,0,0,240,5.2,10,10,9.7,7620,9,999999999,129,0.1740,0,88,999.000,999.0,99.0
+1986,1,17,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,2.2,79,99100,0,0,277,0,0,0,0,0,0,0,240,6.2,1,1,11.3,77777,9,999999999,120,0.1740,0,88,999.000,999.0,99.0
+1986,1,17,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,1.7,82,99100,0,0,266,0,0,0,0,0,0,0,230,4.6,0,0,11.3,77777,9,999999999,120,0.1740,0,88,999.000,999.0,99.0
+1986,1,17,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,1.1,86,99100,0,0,262,0,0,0,0,0,0,0,220,5.2,0,0,11.3,77777,9,999999999,110,0.1740,0,88,999.000,999.0,99.0
+1986,1,17,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,0.6,86,99200,0,0,259,0,0,0,0,0,0,0,240,4.6,0,0,11.3,77777,9,999999999,110,0.1740,0,88,999.000,999.0,99.0
+1986,1,17,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,0.6,86,99200,0,0,268,0,0,0,0,0,0,0,230,5.2,2,2,11.3,77777,9,999999999,110,0.1740,0,88,999.000,999.0,99.0
+1986,1,17,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,0.6,86,99300,53,1001,268,27,114,17,2500,4200,2300,300,230,4.6,2,2,11.3,77777,9,999999999,110,0.0620,0,88,999.000,999.0,99.0
+1986,1,17,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,0.6,82,99300,258,1414,266,136,504,42,13900,37400,7000,770,230,5.2,1,1,11.3,77777,9,999999999,110,0.0620,0,88,999.000,999.0,99.0
+1986,1,17,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,1.7,74,99300,440,1414,273,281,736,49,29300,66700,8400,1030,220,5.2,0,0,11.3,77777,9,999999999,120,0.0620,0,88,999.000,999.0,99.0
+1986,1,17,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,2.2,66,99300,569,1414,288,359,683,82,37700,65300,11300,1660,230,4.6,1,1,14.5,77777,9,999999999,120,0.0620,0,88,999.000,999.0,99.0
+1986,1,17,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,2.2,59,99200,637,1414,289,442,797,81,46000,77000,11100,1660,230,6.7,4,0,14.5,77777,9,999999999,120,0.0620,0,88,999.000,999.0,99.0
+1986,1,17,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,2.2,53,99200,639,1414,306,397,612,120,41200,59100,14400,2400,230,8.8,10,2,19.3,77777,9,999999999,120,0.0620,0,88,999.000,999.0,99.0
+1986,1,17,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,1.7,53,99200,575,1414,308,310,454,125,33000,43800,15000,2440,250,5.7,10,4,16.1,77777,9,999999999,120,0.0620,0,88,999.000,999.0,99.0
+1986,1,17,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,1.7,55,99200,450,1414,327,113,41,101,12500,3800,11300,2810,220,5.2,10,9,16.1,6100,9,999999999,120,0.0620,0,88,999.000,999.0,99.0
+1986,1,17,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,2.2,59,99200,271,1414,324,76,27,71,8300,2200,7900,1760,230,5.7,10,9,16.1,4270,9,999999999,120,0.0620,0,88,999.000,999.0,99.0
+1986,1,17,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,2.8,68,99200,64,1095,302,21,18,19,2200,1000,2100,460,210,4.6,10,6,12.9,6710,9,999999999,129,0.0620,0,88,999.000,999.0,99.0
+1986,1,17,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,2.2,71,99200,0,0,305,0,0,0,0,0,0,0,210,4.1,10,8,12.9,6710,9,999999999,120,0.0620,0,88,999.000,999.0,99.0
+1986,1,17,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,2.8,77,99200,0,0,310,0,0,0,0,0,0,0,210,4.1,10,9,12.9,6710,9,999999999,129,0.0620,0,88,999.000,999.0,99.0
+1986,1,17,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,3.3,80,99200,0,0,296,0,0,0,0,0,0,0,210,4.6,10,6,12.9,6710,9,999999999,129,0.0620,0,88,999.000,999.0,99.0
+1986,1,17,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,3.9,86,99200,0,0,287,0,0,0,0,0,0,0,190,5.2,8,3,11.3,77777,9,999999999,129,0.0620,0,88,999.000,999.0,99.0
+1986,1,17,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,3.9,86,99100,0,0,289,0,0,0,0,0,0,0,210,4.1,6,4,11.3,7620,9,999999999,129,0.0620,0,88,999.000,999.0,99.0
+1986,1,17,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,3.3,80,99100,0,0,320,0,0,0,0,0,0,0,190,4.1,10,10,11.3,7620,9,999999999,129,0.0620,0,88,999.000,999.0,99.0
+1986,1,17,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,2.8,80,99000,0,0,316,0,0,0,0,0,0,0,190,4.6,10,10,11.3,3660,9,999999999,129,0.0620,0,88,999.000,999.0,99.0
+1986,1,18,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,4.4,86,99000,0,0,321,0,0,0,0,0,0,0,190,6.2,10,10,11.3,3660,9,999999999,139,0.0620,0,88,999.000,999.0,99.0
+1986,1,18,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,5.0,89,98900,0,0,321,0,0,0,0,0,0,0,190,5.7,10,10,8.0,3660,9,999999999,139,0.0620,0,88,999.000,999.0,99.0
+1986,1,18,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,4.4,86,98800,0,0,321,0,0,0,0,0,0,0,180,5.7,10,10,8.0,3050,9,999999999,139,0.0620,0,88,999.000,999.0,99.0
+1986,1,18,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,4.4,86,98700,0,0,321,0,0,0,0,0,0,0,180,5.7,10,10,8.0,3050,9,999999999,139,0.0620,0,88,999.000,999.0,99.0
+1986,1,18,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,5.0,86,98600,0,0,324,0,0,0,0,0,0,0,200,7.7,10,10,9.7,2440,9,999999999,139,0.0620,0,88,999.000,999.0,99.0
+1986,1,18,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,5.0,86,98600,0,0,308,0,0,0,0,0,0,0,200,6.7,8,8,9.7,2440,9,999999999,139,0.0620,0,88,999.000,999.0,99.0
+1986,1,18,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,5.0,86,98600,0,0,324,0,0,0,0,0,0,0,190,5.7,10,10,9.7,2440,9,999999999,139,0.0620,0,88,999.000,999.0,99.0
+1986,1,18,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,4.4,86,98600,55,1001,321,11,1,11,1300,0,1300,410,230,6.2,10,10,8.0,3050,9,999999999,139,0.1110,0,88,999.000,999.0,99.0
+1986,1,18,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,2.8,77,98700,261,1413,319,46,9,44,5300,200,5200,1660,240,7.2,10,10,8.0,640,9,999999999,129,0.1110,0,88,999.000,999.0,99.0
+1986,1,18,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,1.7,74,98700,443,1413,300,177,124,138,19100,11400,15500,3100,240,6.2,10,8,8.0,3050,9,999999999,120,0.1110,0,88,999.000,999.0,99.0
+1986,1,18,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,1.1,73,98800,573,1413,287,264,239,166,28000,23700,18300,3530,240,7.7,10,5,11.3,77777,9,999999999,110,0.1110,0,88,999.000,999.0,99.0
+1986,1,18,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,1.1,76,98700,641,1413,287,304,295,169,32600,30100,18900,3630,240,7.2,10,6,11.3,520,9,999999999,110,0.1110,0,88,999.000,999.0,99.0
+1986,1,18,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,1.1,79,98700,644,1413,307,159,8,155,18200,600,17900,6310,250,6.2,10,10,11.3,430,9,999999999,110,0.1110,0,88,999.000,999.0,99.0
+1986,1,18,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,0.0,79,98600,580,1413,301,140,7,137,16000,500,15800,5470,260,7.2,10,10,11.3,370,9,999999999,110,0.1110,0,88,999.000,999.0,99.0
+1986,1,18,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,0.0,82,98700,455,1413,299,110,2,109,12400,100,12400,4100,260,5.7,10,10,8.0,340,9,999999999,110,0.1110,0,88,999.000,999.0,99.0
+1986,1,18,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-0.6,82,98700,276,1413,295,46,3,46,5400,100,5400,1750,260,6.2,10,10,8.0,340,9,999999999,100,0.1110,0,88,999.000,999.0,99.0
+1986,1,18,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-0.6,85,98700,67,1119,293,12,0,12,1400,0,1400,450,270,6.7,10,10,8.0,310,9,999999999,100,0.1110,0,88,999.000,999.0,99.0
+1986,1,18,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-0.6,85,98800,0,0,293,0,0,0,0,0,0,0,280,5.7,10,10,8.0,310,9,999999999,100,0.1110,0,88,999.000,999.0,99.0
+1986,1,18,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-0.6,85,98800,0,0,293,0,0,0,0,0,0,0,280,3.6,10,10,8.0,310,9,999999999,100,0.1110,0,88,999.000,999.0,99.0
+1986,1,18,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-0.6,85,98800,0,0,293,0,0,0,0,0,0,0,290,3.1,10,10,6.4,310,9,999999999,100,0.1110,0,88,999.000,999.0,99.0
+1986,1,18,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-0.6,85,98800,0,0,293,0,0,0,0,0,0,0,290,2.6,10,10,6.4,310,9,999999999,100,0.1110,0,88,999.000,999.0,99.0
+1986,1,18,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-0.6,85,98800,0,0,293,0,0,0,0,0,0,0,300,3.1,10,10,6.4,310,9,999999999,100,0.1110,0,88,999.000,999.0,99.0
+1986,1,18,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-0.6,85,98800,0,0,293,0,0,0,0,0,0,0,310,3.6,10,10,6.4,520,9,999999999,100,0.1110,0,88,999.000,999.0,99.0
+1986,1,18,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-0.6,85,98800,0,0,293,0,0,0,0,0,0,0,360,6.2,10,10,6.4,640,9,999999999,100,0.1110,0,88,999.000,999.0,99.0
+1986,1,19,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-0.6,82,98800,0,0,295,0,0,0,0,0,0,0,10,4.6,10,10,8.0,240,9,999999999,100,0.1110,0,88,999.000,999.0,99.0
+1986,1,19,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-0.6,82,98700,0,0,295,0,0,0,0,0,0,0,20,5.7,10,10,12.9,640,9,999999999,100,0.1110,0,88,999.000,999.0,99.0
+1986,1,19,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-0.6,82,98800,0,0,295,0,0,0,0,0,0,0,360,4.1,10,10,12.9,760,9,999999999,100,0.1110,0,88,999.000,999.0,99.0
+1986,1,19,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-1.1,82,98800,0,0,293,0,0,0,0,0,0,0,20,5.2,10,10,16.1,760,9,999999999,100,0.1110,0,88,999.000,999.0,99.0
+1986,1,19,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.7,82,98800,0,0,290,0,0,0,0,0,0,0,360,4.1,10,10,16.1,640,9,999999999,100,0.1110,0,88,999.000,999.0,99.0
+1986,1,19,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-1.7,79,98900,0,0,292,0,0,0,0,0,0,0,350,5.2,10,10,19.3,580,9,999999999,100,0.1110,0,88,999.000,999.0,99.0
+1986,1,19,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.7,82,98900,0,0,290,0,0,0,0,0,0,0,10,4.6,10,10,19.3,580,9,999999999,100,0.1110,0,88,999.000,999.0,99.0
+1986,1,19,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-3.9,70,98900,56,1024,287,13,1,13,1500,0,1500,470,350,5.2,10,10,16.1,640,9,999999999,89,0.0620,0,88,999.000,999.0,99.0
+1986,1,19,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-4.4,67,98900,264,1413,287,84,1,84,9200,0,9200,2590,10,6.7,10,10,16.1,700,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1986,1,19,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-3.3,73,99000,446,1413,288,135,1,134,14900,100,14900,4640,10,4.6,10,10,16.1,640,9,999999999,89,0.0620,0,88,999.000,999.0,99.0
+1986,1,19,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-3.3,76,99000,576,1413,286,180,1,180,20200,100,20100,6530,350,5.2,10,10,16.1,580,9,999999999,89,0.0620,0,88,999.000,999.0,99.0
+1986,1,19,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-3.9,73,98900,646,1413,285,225,1,225,25100,100,25100,8030,360,6.2,10,10,16.1,520,9,999999999,89,0.0620,0,88,999.000,999.0,99.0
+1986,1,19,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-3.9,73,98900,648,1413,285,217,1,217,24300,100,24300,7900,330,6.2,10,10,19.3,490,9,999999999,89,0.0620,0,88,999.000,999.0,99.0
+1986,1,19,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-5.0,69,98900,585,1413,282,215,0,215,23700,0,23700,7270,330,5.2,10,10,19.3,460,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1986,1,19,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-5.6,69,98900,460,1413,278,146,1,145,16100,100,16100,4960,320,5.2,10,10,19.3,490,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1986,1,19,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-6.1,67,98900,281,1413,278,87,0,87,9500,0,9500,2740,340,7.2,10,10,16.1,520,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1986,1,19,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-5.6,72,98900,71,1142,276,24,0,24,2700,0,2700,770,350,5.7,10,10,12.9,520,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1986,1,19,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-6.1,69,99000,0,0,276,0,0,0,0,0,0,0,340,5.2,10,10,16.1,520,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1986,1,19,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-6.1,69,99000,0,0,276,0,0,0,0,0,0,0,330,4.1,10,10,16.1,490,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1986,1,19,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-6.1,69,99000,0,0,276,0,0,0,0,0,0,0,360,5.2,10,10,11.3,490,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1986,1,19,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.6,75,99000,0,0,274,0,0,0,0,0,0,0,330,3.6,10,10,11.3,580,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1986,1,19,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-6.1,72,99000,0,0,273,0,0,0,0,0,0,0,330,4.1,10,10,11.3,520,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1986,1,19,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-6.1,72,99000,0,0,273,0,0,0,0,0,0,0,330,4.1,10,10,11.3,520,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1986,1,19,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-6.1,75,99000,0,0,271,0,0,0,0,0,0,0,330,3.1,10,10,11.3,520,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1986,1,20,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-6.1,81,99000,0,0,267,0,0,0,0,0,0,0,290,3.6,10,10,11.3,580,9,999999999,69,0.0620,0,88,999.000,999.0,99.0
+1986,1,20,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-6.1,75,98900,0,0,271,0,0,0,0,0,0,0,300,4.6,10,10,11.3,520,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1986,1,20,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-6.1,78,98900,0,0,269,0,0,0,0,0,0,0,350,5.2,10,10,11.3,400,9,999999999,69,0.0620,0,88,999.000,999.0,99.0
+1986,1,20,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-6.1,78,98900,0,0,269,0,0,0,0,0,0,0,310,4.1,10,10,11.3,400,9,999999999,69,0.0620,0,88,999.000,999.0,99.0
+1986,1,20,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-6.1,78,99000,0,0,269,0,0,0,0,0,0,0,320,3.6,10,10,11.3,400,9,999999999,69,0.0620,0,88,999.000,999.0,99.0
+1986,1,20,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-6.1,78,99000,0,0,269,0,0,0,0,0,0,0,320,3.1,10,10,11.3,370,9,999999999,69,0.0620,0,88,999.000,999.0,99.0
+1986,1,20,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-6.1,78,99000,0,0,269,0,0,0,0,0,0,0,330,2.6,10,10,11.3,370,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1986,1,20,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-6.1,78,99100,58,1024,269,20,0,20,2200,0,2200,660,310,2.6,10,10,11.3,370,9,999999999,80,0.0820,0,88,999.000,999.0,99.0
+1986,1,20,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-6.1,78,99100,267,1413,269,75,0,75,8300,0,8300,2450,330,2.1,10,10,11.3,370,9,999999999,80,0.0820,0,88,999.000,999.0,99.0
+1986,1,20,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-6.1,75,99200,450,1413,271,145,0,145,16000,0,16000,4880,320,2.1,10,10,11.3,370,9,999999999,80,0.0820,0,88,999.000,999.0,99.0
+1986,1,20,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-6.1,72,99200,580,1413,273,186,1,185,20700,100,20700,6670,260,3.1,10,10,11.3,400,9,999999999,80,0.0820,0,88,999.000,999.0,99.0
+1986,1,20,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-6.1,72,99200,650,1413,273,213,1,212,23800,100,23800,7810,280,3.6,10,10,11.3,430,9,999999999,80,0.0820,0,88,999.000,999.0,99.0
+1986,1,20,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-5.6,72,99000,653,1413,276,213,1,213,23900,100,23900,7850,30,2.6,10,10,9.7,460,9,999999999,80,0.0820,0,88,999.000,999.0,99.0
+1986,1,20,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-5.6,67,99000,590,1413,251,376,664,99,39400,63600,12700,1970,130,1.5,2,2,8.0,77777,9,999999999,80,0.0820,0,88,999.000,999.0,99.0
+1986,1,20,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-5.6,62,99000,465,1413,247,290,710,58,30400,64900,8900,1170,250,2.1,0,0,9.7,77777,9,999999999,80,0.0820,0,88,999.000,999.0,99.0
+1986,1,20,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-5.6,59,99000,287,1413,250,149,532,43,15800,41400,7300,800,180,2.1,0,0,9.7,77777,9,999999999,80,0.0820,0,88,999.000,999.0,99.0
+1986,1,20,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-5.0,72,99100,75,1166,246,30,86,23,3100,3100,2900,410,260,3.1,4,1,8.0,77777,9,999999999,80,0.0820,0,88,999.000,999.0,99.0
+1986,1,20,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-5.6,78,99100,0,0,246,0,0,0,0,0,0,0,240,2.1,8,3,8.0,77777,9,999999999,80,0.0820,0,88,999.000,999.0,99.0
+1986,1,20,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-5.0,82,99100,0,0,244,0,0,0,0,0,0,0,230,2.1,6,2,8.0,77777,9,999999999,80,0.0820,0,88,999.000,999.0,99.0
+1986,1,20,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-4.4,85,99100,0,0,256,0,0,0,0,0,0,0,190,2.1,10,7,9.7,7620,9,999999999,80,0.0820,0,88,999.000,999.0,99.0
+1986,1,20,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-3.3,85,99100,0,0,279,0,0,0,0,0,0,0,180,2.6,10,10,8.0,270,9,999999999,89,0.0820,0,88,999.000,999.0,99.0
+1986,1,20,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-3.3,85,99100,0,0,279,0,0,0,0,0,0,0,190,3.6,10,10,8.0,240,9,999999999,89,0.0820,0,88,999.000,999.0,99.0
+1986,1,20,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-3.3,85,99000,0,0,279,0,0,0,0,0,0,0,190,4.1,10,10,8.0,210,9,999999999,89,0.0820,0,88,999.000,999.0,99.0
+1986,1,20,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-3.3,85,99000,0,0,279,0,0,0,0,0,0,0,180,5.7,10,10,8.0,180,9,999999999,89,0.0820,0,88,999.000,999.0,99.0
+1986,1,21,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-2.8,89,99000,0,0,279,0,0,0,0,0,0,0,180,3.1,10,10,6.4,150,9,999999999,89,0.0820,0,88,999.000,999.0,99.0
+1986,1,21,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-2.8,89,99000,0,0,279,0,0,0,0,0,0,0,190,3.6,10,10,6.4,120,9,999999999,89,0.0820,0,88,999.000,999.0,99.0
+1986,1,21,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-2.2,89,98900,0,0,282,0,0,0,0,0,0,0,140,4.6,10,10,4.8,90,9,999999999,89,0.0820,0,88,999.000,999.0,99.0
+1986,1,21,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-2.2,89,98800,0,0,282,0,0,0,0,0,0,0,140,4.6,10,10,2.4,90,9,999999999,89,0.0820,0,88,999.000,999.0,99.0
+1986,1,21,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-1.7,92,98700,0,0,282,0,0,0,0,0,0,0,130,5.2,10,10,2.4,120,9,999999999,100,0.0820,0,88,999.000,999.0,99.0
+1986,1,21,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-1.7,92,98600,0,0,282,0,0,0,0,0,0,0,140,5.2,10,10,2.4,180,9,999999999,100,0.0820,0,88,999.000,999.0,99.0
+1986,1,21,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-2.8,85,98400,0,0,252,0,0,0,0,0,0,0,140,7.2,5,2,2.4,77777,9,999999999,89,0.0820,0,88,999.000,999.0,99.0
+1986,1,21,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-2.2,82,98300,60,1048,259,22,15,21,2400,800,2400,500,140,5.7,7,3,6.4,77777,9,999999999,89,0.1700,0,88,999.000,999.0,99.0
+1986,1,21,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-1.1,79,98300,270,1413,264,108,190,71,11300,13900,8700,1360,150,5.7,6,2,6.4,77777,9,999999999,100,0.1700,0,88,999.000,999.0,99.0
+1986,1,21,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,0.0,70,98200,453,1413,281,197,155,147,21200,14400,16600,3320,160,6.2,10,4,8.0,77777,9,999999999,110,0.1700,0,88,999.000,999.0,99.0
+1986,1,21,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,0.6,65,98100,585,1413,288,328,402,160,33900,38800,17800,3220,170,6.7,10,4,8.0,77777,9,999999999,110,0.1700,0,88,999.000,999.0,99.0
+1986,1,21,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,1.7,63,97900,654,1413,296,368,392,186,39400,40100,20700,4080,180,5.7,10,4,8.0,77777,9,999999999,120,0.1700,0,88,999.000,999.0,99.0
+1986,1,21,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,2.8,64,97800,658,1413,302,324,320,175,34900,32800,19500,3790,180,5.2,10,4,9.7,77777,9,999999999,129,0.1700,0,88,999.000,999.0,99.0
+1986,1,21,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,3.9,64,97700,595,1413,317,264,162,196,28600,16100,21800,4650,190,7.2,10,7,9.7,7620,9,999999999,129,0.1700,0,88,999.000,999.0,99.0
+1986,1,21,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,4.4,59,97700,470,1413,337,110,34,98,12000,3100,11000,2790,180,6.7,10,9,9.7,6710,9,999999999,139,0.1700,0,88,999.000,999.0,99.0
+1986,1,21,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,5.6,69,97700,292,1413,326,85,53,74,9300,4400,8400,1870,200,7.7,9,8,11.3,6100,9,999999999,150,0.1700,0,88,999.000,999.0,99.0
+1986,1,21,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,6.1,69,97800,79,1189,313,28,17,26,3000,1000,2900,610,220,7.7,8,3,12.9,77777,9,999999999,150,0.1700,0,88,999.000,999.0,99.0
+1986,1,21,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,2.8,80,97900,0,0,286,0,0,0,0,0,0,0,240,10.8,7,3,16.1,77777,9,999999999,129,0.1700,0,88,999.000,999.0,99.0
+1986,1,21,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,0.0,82,98100,0,0,299,0,0,0,0,0,0,0,260,12.9,10,10,8.0,310,9,999999999,110,0.1700,0,88,999.000,999.0,99.0
+1986,1,21,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,0.0,85,98100,0,0,296,0,0,0,0,0,0,0,270,11.8,10,10,8.0,310,9,999999999,110,0.1700,0,88,999.000,999.0,99.0
+1986,1,21,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,0.0,85,98200,0,0,296,0,0,0,0,0,0,0,280,10.8,10,10,8.0,310,9,999999999,110,0.1700,0,88,999.000,999.0,99.0
+1986,1,21,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,0.6,89,98300,0,0,297,0,0,0,0,0,0,0,260,11.3,10,10,8.0,310,9,999999999,110,0.1700,0,88,999.000,999.0,99.0
+1986,1,21,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-0.6,82,98300,0,0,295,0,0,0,0,0,0,0,240,7.7,10,10,9.7,340,9,999999999,100,0.1700,0,88,999.000,999.0,99.0
+1986,1,21,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,0.0,89,98300,0,0,294,0,0,0,0,0,0,0,250,6.7,10,10,6.4,270,9,999999999,110,0.1700,0,88,999.000,999.0,99.0
+1986,1,22,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,0.0,89,98400,0,0,294,0,0,0,0,0,0,0,250,7.7,10,10,12.9,270,9,999999999,110,0.1700,0,88,999.000,999.0,99.0
+1986,1,22,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-0.6,85,98500,0,0,293,0,0,0,0,0,0,0,280,5.7,10,10,11.3,270,9,999999999,100,0.1700,0,88,999.000,999.0,99.0
+1986,1,22,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-0.6,89,98700,0,0,291,0,0,0,0,0,0,0,280,6.2,10,10,11.3,310,9,999999999,100,0.1700,0,88,999.000,999.0,99.0
+1986,1,22,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-1.7,85,98800,0,0,287,0,0,0,0,0,0,0,300,5.2,10,10,12.9,460,9,999999999,100,0.1700,0,88,999.000,999.0,99.0
+1986,1,22,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-1.7,85,99000,0,0,287,0,0,0,0,0,0,0,320,5.2,10,10,12.9,490,9,999999999,100,0.1700,0,88,999.000,999.0,99.0
+1986,1,22,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-2.2,82,99200,0,0,287,0,0,0,0,0,0,0,320,5.2,10,10,16.1,880,9,999999999,89,0.1700,0,88,999.000,999.0,99.0
+1986,1,22,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-2.8,76,99400,0,0,288,0,0,0,0,0,0,0,330,7.2,10,10,16.1,760,9,999999999,89,0.1700,0,88,999.000,999.0,99.0
+1986,1,22,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-4.4,70,99600,62,1071,285,10,1,10,1200,0,1200,380,320,8.2,10,10,16.1,880,9,999999999,80,0.0940,0,88,999.000,999.0,99.0
+1986,1,22,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-4.4,70,99800,273,1412,285,56,19,52,6100,1500,5800,1370,310,5.2,10,10,24.1,700,9,999999999,80,0.0940,0,88,999.000,999.0,99.0
+1986,1,22,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-4.4,70,99900,457,1412,277,165,52,148,18000,4800,16500,3810,330,5.2,9,9,24.1,640,9,999999999,80,0.0940,0,88,999.000,999.0,99.0
+1986,1,22,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-5.0,64,100000,589,1412,261,356,473,157,36900,45700,17700,3150,310,3.6,4,4,24.1,77777,9,999999999,80,0.0940,0,88,999.000,999.0,99.0
+1986,1,22,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-5.0,62,100000,659,1412,265,384,527,137,41100,52300,16600,2770,320,4.1,5,5,24.1,77777,9,999999999,80,0.0940,0,88,999.000,999.0,99.0
+1986,1,22,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-5.0,59,100100,663,1412,257,437,771,74,46200,75300,10700,1620,270,4.1,1,1,24.1,77777,9,999999999,80,0.0940,0,88,999.000,999.0,99.0
+1986,1,22,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-6.1,52,100100,600,1412,253,405,775,76,42300,74200,10600,1550,310,4.1,0,0,24.1,77777,9,999999999,80,0.0940,0,88,999.000,999.0,99.0
+1986,1,22,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-7.2,48,100200,475,1412,252,294,688,64,30500,62900,9200,1240,280,4.1,0,0,24.1,77777,9,999999999,69,0.0940,0,88,999.000,999.0,99.0
+1986,1,22,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-7.8,44,100300,297,1412,253,152,511,47,16100,40200,7600,870,270,3.1,0,0,24.1,77777,9,999999999,69,0.0940,0,88,999.000,999.0,99.0
+1986,1,22,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-7.2,56,100300,83,1236,249,30,114,20,3000,4900,2700,350,310,2.6,3,1,24.1,77777,9,999999999,69,0.0940,0,88,999.000,999.0,99.0
+1986,1,22,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-7.8,66,100400,0,0,238,0,0,0,0,0,0,0,320,2.6,4,1,24.1,77777,9,999999999,69,0.0940,0,88,999.000,999.0,99.0
+1986,1,22,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-7.8,72,100500,0,0,234,0,0,0,0,0,0,0,320,2.6,3,1,24.1,77777,9,999999999,69,0.0940,0,88,999.000,999.0,99.0
+1986,1,22,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-7.8,75,100500,0,0,228,0,0,0,0,0,0,0,320,2.6,2,0,24.1,77777,9,999999999,69,0.0940,0,88,999.000,999.0,99.0
+1986,1,22,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-7.8,78,100600,0,0,226,0,0,0,0,0,0,0,280,3.1,2,0,24.1,77777,9,999999999,69,0.0940,0,88,999.000,999.0,99.0
+1986,1,22,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-7.8,85,100600,0,0,226,0,0,0,0,0,0,0,10,2.1,3,1,24.1,77777,9,999999999,69,0.0940,0,88,999.000,999.0,99.0
+1986,1,22,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-8.3,78,100600,0,0,224,0,0,0,0,0,0,0,10,2.6,0,0,24.1,77777,9,999999999,69,0.0940,0,88,999.000,999.0,99.0
+1986,1,22,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-8.3,85,100600,0,0,220,0,0,0,0,0,0,0,300,2.1,3,0,24.1,77777,9,999999999,69,0.0940,0,88,999.000,999.0,99.0
+1986,1,23,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-7.8,85,100600,0,0,230,0,0,0,0,0,0,0,300,2.1,10,2,24.1,77777,9,999999999,69,0.0940,0,88,999.000,999.0,99.0
+1986,1,23,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-7.8,85,100600,0,0,244,0,0,0,0,0,0,0,320,2.1,10,8,24.1,7620,9,999999999,69,0.0940,0,88,999.000,999.0,99.0
+1986,1,23,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-7.8,81,100600,0,0,246,0,0,0,0,0,0,0,340,2.6,10,8,24.1,7620,9,999999999,69,0.0940,0,88,999.000,999.0,99.0
+1986,1,23,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-9.4,81,100600,0,0,224,0,0,0,0,0,0,0,10,2.1,2,2,24.1,77777,9,999999999,60,0.0940,0,88,999.000,999.0,99.0
+1986,1,23,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-9.4,84,100600,0,0,216,0,0,0,0,0,0,0,360,2.1,0,0,24.1,77777,9,999999999,60,0.0940,0,88,999.000,999.0,99.0
+1986,1,23,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-9.4,92,100600,0,0,212,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,60,0.0940,0,88,999.000,999.0,99.0
+1986,1,23,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-9.4,88,100700,0,0,214,0,0,0,0,0,0,0,310,2.1,0,0,14.5,77777,9,999999999,60,0.0940,0,88,999.000,999.0,99.0
+1986,1,23,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-9.4,88,100800,64,1071,223,20,24,18,2200,1100,2100,370,270,2.1,3,3,11.3,77777,9,999999999,60,0.1750,0,88,999.000,999.0,99.0
+1986,1,23,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.9,-6.7,81,100800,277,1412,229,129,338,61,13400,25200,8400,1100,10,2.1,0,0,11.3,77777,9,999999999,69,0.1750,0,88,999.000,999.0,99.0
+1986,1,23,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-5.0,78,100800,461,1412,238,265,527,91,27100,47300,11500,1680,170,3.6,1,0,9.7,77777,9,999999999,80,0.1750,0,88,999.000,999.0,99.0
+1986,1,23,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-4.4,72,100700,593,1412,249,357,575,114,36800,54700,13700,2220,170,4.6,1,1,9.7,77777,9,999999999,80,0.1750,0,88,999.000,999.0,99.0
+1986,1,23,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-5.6,62,100600,664,1412,247,387,567,120,40300,55200,14300,2450,180,3.1,1,0,11.3,77777,9,999999999,80,0.1750,0,88,999.000,999.0,99.0
+1986,1,23,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-6.1,55,100600,668,1412,251,439,671,121,45700,65400,14700,2480,170,3.6,1,0,12.9,77777,9,999999999,80,0.1750,0,88,999.000,999.0,99.0
+1986,1,23,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-6.1,52,100500,605,1412,253,380,628,111,39500,60100,13700,2190,200,3.1,1,0,12.9,77777,9,999999999,80,0.1750,0,88,999.000,999.0,99.0
+1986,1,23,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-5.6,53,100500,481,1412,255,274,539,92,28400,49000,11700,1720,210,2.6,1,0,12.9,77777,9,999999999,80,0.1750,0,88,999.000,999.0,99.0
+1986,1,23,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-7.2,45,100500,302,1412,256,139,356,64,14800,27600,8800,1160,230,2.1,0,0,14.5,77777,9,999999999,69,0.1750,0,88,999.000,999.0,99.0
+1986,1,23,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-7.2,52,100500,88,1259,248,28,52,24,3100,2500,2900,500,190,2.1,0,0,14.5,77777,9,999999999,69,0.1750,0,88,999.000,999.0,99.0
+1986,1,23,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-6.7,66,100500,0,0,239,0,0,0,0,0,0,0,190,2.1,0,0,14.5,77777,9,999999999,69,0.1750,0,88,999.000,999.0,99.0
+1986,1,23,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-6.1,75,100500,0,0,235,0,0,0,0,0,0,0,140,3.1,0,0,14.5,77777,9,999999999,80,0.1750,0,88,999.000,999.0,99.0
+1986,1,23,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-5.0,82,100500,0,0,236,0,0,0,0,0,0,0,140,2.6,0,0,12.9,77777,9,999999999,80,0.1750,0,88,999.000,999.0,99.0
+1986,1,23,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-5.6,78,100500,0,0,236,0,0,0,0,0,0,0,140,3.1,0,0,12.9,77777,9,999999999,80,0.1750,0,88,999.000,999.0,99.0
+1986,1,23,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-6.1,81,100500,0,0,231,0,0,0,0,0,0,0,120,2.1,0,0,12.9,77777,9,999999999,80,0.1750,0,88,999.000,999.0,99.0
+1986,1,23,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-5.6,81,100500,0,0,234,0,0,0,0,0,0,0,140,1.5,0,0,14.5,77777,9,999999999,80,0.1750,0,88,999.000,999.0,99.0
+1986,1,23,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-5.0,85,100400,0,0,234,0,0,0,0,0,0,0,140,2.1,0,0,12.9,77777,9,999999999,80,0.1750,0,88,999.000,999.0,99.0
+1986,1,24,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-5.6,81,100300,0,0,234,0,0,0,0,0,0,0,140,3.1,2,0,12.9,77777,9,999999999,80,0.1750,0,88,999.000,999.0,99.0
+1986,1,24,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-4.4,85,100300,0,0,253,0,0,0,0,0,0,0,140,4.1,8,6,11.3,7620,9,999999999,80,0.1750,0,88,999.000,999.0,99.0
+1986,1,24,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-4.4,78,100300,0,0,278,0,0,0,0,0,0,0,130,4.6,10,10,11.3,3660,9,999999999,80,0.1750,0,88,999.000,999.0,99.0
+1986,1,24,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-4.4,78,100300,0,0,278,0,0,0,0,0,0,0,150,4.1,10,10,11.3,3660,9,999999999,80,0.1750,0,88,999.000,999.0,99.0
+1986,1,24,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-4.4,78,100200,0,0,278,0,0,0,0,0,0,0,140,4.1,10,10,11.3,3660,9,999999999,80,0.1750,0,88,999.000,999.0,99.0
+1986,1,24,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-4.4,78,100200,0,0,278,0,0,0,0,0,0,0,130,3.6,10,10,11.3,3660,9,999999999,80,0.1750,0,88,999.000,999.0,99.0
+1986,1,24,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-3.9,82,100100,0,0,278,0,0,0,0,0,0,0,140,5.2,10,10,12.9,3050,9,999999999,89,0.1750,0,88,999.000,999.0,99.0
+1986,1,24,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-4.4,75,100100,67,1094,280,12,11,11,1300,600,1300,290,150,4.1,10,10,9.7,3050,9,999999999,80,0.0890,0,88,999.000,999.0,99.0
+1986,1,24,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-4.4,72,100000,280,1412,282,40,4,40,4800,100,4700,1570,140,6.2,10,10,9.7,3050,9,999999999,80,0.0890,0,88,999.000,999.0,99.0
+1986,1,24,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-4.4,70,100000,465,1412,285,112,5,110,12700,300,12600,4180,150,6.2,10,10,9.7,3050,9,999999999,80,0.0890,0,88,999.000,999.0,99.0
+1986,1,24,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-4.4,64,100000,598,1412,289,171,8,168,19400,600,19100,6400,140,6.7,10,10,11.3,3050,9,999999999,80,0.0890,0,88,999.000,999.0,99.0
+1986,1,24,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-3.9,67,99800,669,1412,290,219,5,216,24500,400,24300,8050,160,5.7,10,10,11.3,3050,9,999999999,89,0.0890,0,88,999.000,999.0,99.0
+1986,1,24,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-4.4,59,99600,673,1412,294,215,7,212,24200,600,23900,8000,140,8.2,10,10,11.3,3050,9,999999999,80,0.0890,0,88,999.000,999.0,99.0
+1986,1,24,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-5.0,59,99500,611,1412,291,186,4,185,21000,300,20800,6900,160,7.2,10,10,11.3,2440,9,999999999,80,0.0890,0,88,999.000,999.0,99.0
+1986,1,24,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-5.6,57,99400,486,1412,290,142,1,141,15800,100,15800,5050,160,7.2,10,10,11.3,1680,9,999999999,80,0.0890,0,88,999.000,999.0,99.0
+1986,1,24,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-5.0,59,99300,308,1412,291,82,2,82,9200,100,9100,2780,170,7.7,10,10,11.3,1830,9,999999999,80,0.0890,0,88,999.000,999.0,99.0
+1986,1,24,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-5.0,57,99200,92,1282,293,23,0,23,2600,0,2600,780,170,10.8,10,10,12.9,1830,9,999999999,80,0.0890,0,88,999.000,999.0,99.0
+1986,1,24,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-3.9,62,99200,0,0,294,0,0,0,0,0,0,0,180,7.7,10,10,9.7,370,9,999999999,89,0.0890,0,88,999.000,999.0,99.0
+1986,1,24,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-1.1,96,99200,0,0,283,0,0,0,0,0,0,0,140,6.7,10,10,2.4,180,9,999999999,100,0.0890,0,88,999.000,999.0,99.0
+1986,1,24,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-0.6,92,99100,0,0,289,0,0,0,0,0,0,0,180,7.7,10,10,9.7,370,9,999999999,100,0.0890,0,88,999.000,999.0,99.0
+1986,1,24,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-0.6,85,99000,0,0,293,0,0,0,0,0,0,0,180,6.7,10,10,8.0,270,9,999999999,100,0.0890,0,88,999.000,999.0,99.0
+1986,1,24,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,0.0,89,98900,0,0,294,0,0,0,0,0,0,0,180,9.3,10,10,8.0,340,9,999999999,110,0.0890,0,88,999.000,999.0,99.0
+1986,1,24,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,0.0,89,98800,0,0,294,0,0,0,0,0,0,0,180,8.2,10,10,11.3,370,9,999999999,110,0.0890,0,88,999.000,999.0,99.0
+1986,1,24,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,0.0,85,98700,0,0,296,0,0,0,0,0,0,0,180,6.2,10,10,16.1,1680,9,999999999,110,0.0890,0,88,999.000,999.0,99.0
+1986,1,25,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,0.0,85,98600,0,0,296,0,0,0,0,0,0,0,200,5.7,10,10,12.9,1370,9,999999999,110,0.0890,0,88,999.000,999.0,99.0
+1986,1,25,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-0.6,79,98600,0,0,298,0,0,0,0,0,0,0,200,4.6,10,10,16.1,1370,9,999999999,100,0.0890,0,88,999.000,999.0,99.0
+1986,1,25,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-1.1,79,98600,0,0,295,0,0,0,0,0,0,0,230,6.7,10,10,16.1,1370,9,999999999,100,0.0890,0,88,999.000,999.0,99.0
+1986,1,25,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-1.1,82,98600,0,0,293,0,0,0,0,0,0,0,240,6.7,10,10,16.1,370,9,999999999,100,0.0890,0,88,999.000,999.0,99.0
+1986,1,25,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-1.7,85,98700,0,0,287,0,0,0,0,0,0,0,270,8.2,10,10,11.3,310,9,999999999,100,0.0890,0,88,999.000,999.0,99.0
+1986,1,25,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-3.9,82,98700,0,0,278,0,0,0,0,0,0,0,260,6.7,10,10,11.3,700,9,999999999,89,0.0890,0,88,999.000,999.0,99.0
+1986,1,25,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.0,75,98800,0,0,277,0,0,0,0,0,0,0,260,6.2,10,10,12.9,700,9,999999999,80,0.0890,0,88,999.000,999.0,99.0
+1986,1,25,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-5.0,75,98900,69,1117,277,20,0,20,2300,0,2300,670,250,5.2,10,10,16.1,760,9,999999999,80,0.1290,0,88,999.000,999.0,99.0
+1986,1,25,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-5.0,75,98900,284,1411,269,53,0,53,6100,0,6100,1970,240,7.7,10,9,19.3,640,9,999999999,80,0.1290,0,88,999.000,999.0,99.0
+1986,1,25,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-6.1,69,99000,469,1411,268,195,200,128,20700,18700,14400,2590,260,7.7,9,9,19.3,880,9,999999999,80,0.1290,0,88,999.000,999.0,99.0
+1986,1,25,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-7.8,64,99000,602,1411,272,164,0,164,18600,0,18600,6330,260,8.2,10,10,24.1,880,9,999999999,69,0.1290,0,88,999.000,999.0,99.0
+1986,1,25,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-7.2,66,99000,674,1411,272,188,9,183,21300,700,21000,7280,270,8.2,10,10,24.1,1010,9,999999999,69,0.1290,0,88,999.000,999.0,99.0
+1986,1,25,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-7.2,64,98900,678,1411,275,160,2,159,18400,200,18400,6610,270,7.7,10,10,24.1,1010,9,999999999,69,0.1290,0,88,999.000,999.0,99.0
+1986,1,25,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-7.2,64,98900,616,1411,275,172,5,170,19500,400,19300,6570,280,9.8,10,10,24.1,1010,9,999999999,69,0.1290,0,88,999.000,999.0,99.0
+1986,1,25,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-8.9,56,98900,491,1411,241,280,565,85,29300,51900,11100,1620,270,7.2,1,1,24.1,77777,9,999999999,60,0.1290,0,88,999.000,999.0,99.0
+1986,1,25,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-10.6,51,98900,313,1411,237,150,418,59,15600,33200,8200,1060,270,10.3,1,1,24.1,77777,9,999999999,60,0.1290,0,88,999.000,999.0,99.0
+1986,1,25,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-10.0,58,99000,97,1306,234,31,95,22,3100,4200,2800,390,270,8.8,1,1,24.1,77777,9,999999999,60,0.1290,0,88,999.000,999.0,99.0
+1986,1,25,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-11.1,63,99000,0,0,221,0,0,0,0,0,0,0,270,7.7,0,0,24.1,77777,9,999999999,60,0.1290,0,88,999.000,999.0,99.0
+1986,1,25,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-10.6,65,99100,0,0,222,0,0,0,0,0,0,0,260,6.2,0,0,24.1,77777,9,999999999,60,0.1290,0,88,999.000,999.0,99.0
+1986,1,25,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-10.0,68,99100,0,0,257,0,0,0,0,0,0,0,270,8.8,10,10,24.1,1830,9,999999999,60,0.1290,0,88,999.000,999.0,99.0
+1986,1,25,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-10.6,65,99100,0,0,256,0,0,0,0,0,0,0,270,7.7,10,10,24.1,1520,9,999999999,60,0.1290,0,88,999.000,999.0,99.0
+1986,1,25,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-9.4,71,99100,0,0,257,0,0,0,0,0,0,0,270,6.7,10,10,24.1,640,9,999999999,60,0.1290,0,88,999.000,999.0,99.0
+1986,1,25,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-10.0,68,99100,0,0,257,0,0,0,0,0,0,0,270,7.2,10,10,24.1,490,9,999999999,60,0.1290,0,88,999.000,999.0,99.0
+1986,1,25,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-11.1,68,99000,0,0,251,0,0,0,0,0,0,0,300,6.7,10,10,24.1,490,9,999999999,60,0.1290,0,88,999.000,999.0,99.0
+1986,1,26,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-11.1,71,99000,0,0,249,0,0,0,0,0,0,0,300,7.2,10,10,9.7,490,9,999999999,60,0.1290,0,88,999.000,999.0,99.0
+1986,1,26,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-11.1,71,99000,0,0,249,0,0,0,0,0,0,0,280,4.6,10,10,11.3,490,9,999999999,60,0.1290,0,88,999.000,999.0,99.0
+1986,1,26,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-11.1,74,98900,0,0,247,0,0,0,0,0,0,0,280,4.1,10,10,9.7,490,9,999999999,60,0.1290,0,88,999.000,999.0,99.0
+1986,1,26,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-11.1,77,98900,0,0,245,0,0,0,0,0,0,0,280,5.2,10,10,6.4,490,9,999999999,60,0.1290,0,88,999.000,999.0,99.0
+1986,1,26,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-11.7,71,98900,0,0,247,0,0,0,0,0,0,0,290,5.2,10,10,11.3,640,9,999999999,60,0.1290,0,88,999.000,999.0,99.0
+1986,1,26,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-11.1,74,98900,0,0,247,0,0,0,0,0,0,0,290,4.6,10,10,9.7,640,9,999999999,60,0.1290,0,88,999.000,999.0,99.0
+1986,1,26,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-12.8,71,98900,0,0,242,0,0,0,0,0,0,0,340,6.7,10,10,14.5,1400,9,999999999,50,0.1290,0,88,999.000,999.0,99.0
+1986,1,26,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.9,-12.8,74,99000,72,1141,239,16,2,16,1900,0,1900,570,340,5.2,10,10,11.3,1370,9,999999999,50,0.0510,0,88,999.000,999.0,99.0
+1986,1,26,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.9,-13.9,68,99000,288,1411,238,58,3,57,6600,100,6500,2100,360,7.2,10,10,11.3,1370,9,999999999,50,0.0510,0,88,999.000,999.0,99.0
+1986,1,26,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-9.4,-15.6,62,99000,474,1411,235,125,1,124,14000,100,14000,4580,310,7.7,10,10,11.3,1370,9,999999999,50,0.0510,0,88,999.000,999.0,99.0
+1986,1,26,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.0,-17.2,56,99100,607,1411,231,180,8,177,20300,600,20100,6690,330,8.2,10,10,19.3,1370,9,999999999,40,0.0510,0,88,999.000,999.0,99.0
+1986,1,26,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.6,-16.1,64,99000,679,1411,230,186,11,181,21300,900,20800,7260,320,10.3,10,10,3.2,520,9,999999999,40,0.0510,0,88,999.000,999.0,99.0
+1986,1,26,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.6,-17.2,58,99000,684,1411,229,191,2,190,21700,200,21600,7530,320,8.8,10,10,9.7,1370,9,999999999,40,0.0510,0,88,999.000,999.0,99.0
+1986,1,26,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.6,-18.9,51,99000,622,1411,213,274,257,161,29500,26000,18000,3410,340,8.8,8,7,16.1,1680,9,999999999,40,0.0510,0,88,999.000,999.0,99.0
+1986,1,26,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-11.1,-20.6,46,99100,497,1411,224,111,8,108,12700,500,12500,4260,340,7.2,10,10,16.1,1680,9,999999999,40,0.0510,0,88,999.000,999.0,99.0
+1986,1,26,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-13.3,-21.7,50,99200,318,1411,206,121,112,96,13100,9200,11000,2090,350,11.8,8,8,19.3,1830,9,999999999,40,0.0510,0,88,999.000,999.0,99.0
+1986,1,26,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-14.4,-24.4,43,99200,102,1352,190,42,196,25,4300,8900,3600,440,350,10.8,3,3,24.1,77777,9,999999999,30,0.0510,0,88,999.000,999.0,99.0
+1986,1,26,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-15.6,-25.0,45,99400,0,0,186,0,0,0,0,0,0,0,330,10.3,3,3,24.1,77777,9,999999999,30,0.0510,0,88,999.000,999.0,99.0
+1986,1,26,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-16.1,-25.6,44,99400,0,0,184,0,0,0,0,0,0,0,330,10.8,3,3,24.1,77777,9,999999999,30,0.0510,0,88,999.000,999.0,99.0
+1986,1,26,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.2,-26.1,46,99400,0,0,173,0,0,0,0,0,0,0,330,11.3,0,0,24.1,77777,9,999999999,30,0.0510,0,88,999.000,999.0,99.0
+1986,1,26,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.8,-25.6,51,99500,0,0,175,0,0,0,0,0,0,0,350,10.8,1,1,24.1,77777,9,999999999,30,0.0510,0,88,999.000,999.0,99.0
+1986,1,26,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.8,-27.8,42,99500,0,0,170,0,0,0,0,0,0,0,340,10.8,0,0,24.1,77777,9,999999999,30,0.0510,0,88,999.000,999.0,99.0
+1986,1,26,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-18.9,-26.7,51,99500,0,0,168,0,0,0,0,0,0,0,340,10.8,0,0,24.1,77777,9,999999999,30,0.0510,0,88,999.000,999.0,99.0
+1986,1,26,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-19.4,-27.2,50,99500,0,0,169,0,0,0,0,0,0,0,340,8.2,1,1,24.1,77777,9,999999999,30,0.0510,0,88,999.000,999.0,99.0
+1986,1,27,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-19.4,-27.2,50,99400,0,0,166,0,0,0,0,0,0,0,330,10.3,0,0,24.1,77777,9,999999999,30,0.0510,0,88,999.000,999.0,99.0
+1986,1,27,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-20.0,-27.8,50,99400,0,0,164,0,0,0,0,0,0,0,330,9.3,0,0,24.1,77777,9,999999999,30,0.0510,0,88,999.000,999.0,99.0
+1986,1,27,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-20.0,-27.8,50,99400,0,0,164,0,0,0,0,0,0,0,350,6.7,0,0,24.1,77777,9,999999999,30,0.0510,0,88,999.000,999.0,99.0
+1986,1,27,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-20.0,-27.8,50,99400,0,0,164,0,0,0,0,0,0,0,350,7.2,0,0,24.1,77777,9,999999999,30,0.0510,0,88,999.000,999.0,99.0
+1986,1,27,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-20.0,-27.8,50,99400,0,0,164,0,0,0,0,0,0,0,310,8.2,0,0,24.1,77777,9,999999999,30,0.0510,0,88,999.000,999.0,99.0
+1986,1,27,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-21.1,-28.3,52,99400,0,0,161,0,0,0,0,0,0,0,330,7.2,0,0,24.1,77777,9,999999999,30,0.0510,0,88,999.000,999.0,99.0
+1986,1,27,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-21.1,-28.3,52,99400,0,0,161,0,0,0,0,0,0,0,310,8.2,0,0,24.1,77777,9,999999999,30,0.0510,0,88,999.000,999.0,99.0
+1986,1,27,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-21.1,-28.3,52,99400,75,1164,161,39,242,17,3500,11600,2700,310,330,8.8,0,0,24.1,77777,9,999999999,30,0.0530,0,88,999.000,999.0,99.0
+1986,1,27,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-20.0,-27.8,50,99500,292,1411,164,174,655,36,17800,52900,6800,730,330,8.2,0,0,24.1,77777,9,999999999,30,0.0530,0,88,999.000,999.0,99.0
+1986,1,27,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-17.8,-27.2,44,99500,478,1411,170,325,809,48,34100,74600,8700,1090,340,7.7,0,0,24.1,77777,9,999999999,30,0.0530,0,88,999.000,999.0,99.0
+1986,1,27,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-16.7,-27.2,40,99400,612,1411,173,444,887,58,46700,85000,9600,1330,330,7.7,0,0,24.1,77777,9,999999999,30,0.0530,0,88,999.000,999.0,99.0
+1986,1,27,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-16.1,-27.2,38,99300,684,1411,175,509,917,63,53400,89100,10100,1470,320,7.7,0,0,24.1,77777,9,999999999,30,0.0530,0,88,999.000,999.0,99.0
+1986,1,27,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-15.0,-26.7,37,99300,689,1411,178,513,921,63,54000,89500,10100,1470,340,8.2,0,0,24.1,77777,9,999999999,30,0.0530,0,88,999.000,999.0,99.0
+1986,1,27,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-15.0,-27.2,35,99200,627,1411,178,455,894,59,48100,86000,9700,1360,310,6.7,0,0,24.1,77777,9,999999999,30,0.0530,0,88,999.000,999.0,99.0
+1986,1,27,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-15.6,-27.2,36,99200,503,1411,180,308,657,75,32500,61100,10600,1470,320,7.7,1,1,24.1,77777,9,999999999,30,0.0530,0,88,999.000,999.0,99.0
+1986,1,27,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-15.6,-26.7,38,99200,324,1411,177,191,681,37,20500,57500,7200,810,290,7.2,0,0,24.1,77777,9,999999999,30,0.0530,0,88,999.000,999.0,99.0
+1986,1,27,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-17.2,-27.2,42,99200,107,1376,175,44,211,25,4300,10700,3400,440,310,7.7,7,1,24.1,77777,9,999999999,30,0.0530,0,88,999.000,999.0,99.0
+1986,1,27,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.8,-26.7,46,99200,0,0,180,0,0,0,0,0,0,0,300,6.2,10,4,24.1,77777,9,999999999,30,0.0530,0,88,999.000,999.0,99.0
+1986,1,27,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.8,-27.2,44,99200,0,0,184,0,0,0,0,0,0,0,310,5.7,8,7,24.1,7620,9,999999999,30,0.0530,0,88,999.000,999.0,99.0
+1986,1,27,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-18.3,-26.1,51,99200,0,0,177,0,0,0,0,0,0,0,300,3.1,3,3,24.1,77777,9,999999999,30,0.0530,0,88,999.000,999.0,99.0
+1986,1,27,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.8,-26.1,48,99200,0,0,198,0,0,0,0,0,0,0,310,2.6,10,10,24.1,3050,9,999999999,30,0.0530,0,88,999.000,999.0,99.0
+1986,1,27,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.2,-25.0,51,99200,0,0,195,0,0,0,0,0,0,0,290,3.1,9,9,24.1,3050,9,999999999,30,0.0530,0,88,999.000,999.0,99.0
+1986,1,27,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.2,-25.0,51,99200,0,0,200,0,0,0,0,0,0,0,290,4.1,10,10,24.1,3050,9,999999999,30,0.0530,0,88,999.000,999.0,99.0
+1986,1,27,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.2,-25.0,51,99100,0,0,200,0,0,0,0,0,0,0,280,4.1,10,10,24.1,3050,9,999999999,30,0.0530,0,88,999.000,999.0,99.0
+1986,1,28,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.2,-25.0,51,99100,0,0,200,0,0,0,0,0,0,0,280,3.6,10,10,24.1,3660,9,999999999,30,0.0530,0,88,999.000,999.0,99.0
+1986,1,28,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.2,-24.4,54,99000,0,0,201,0,0,0,0,0,0,0,250,3.6,10,10,24.1,3660,9,999999999,30,0.0530,0,88,999.000,999.0,99.0
+1986,1,28,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.2,-24.4,54,99000,0,0,201,0,0,0,0,0,0,0,250,4.6,10,10,24.1,3660,9,999999999,30,0.0530,0,88,999.000,999.0,99.0
+1986,1,28,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-16.7,-23.9,54,99000,0,0,203,0,0,0,0,0,0,0,250,3.6,10,10,24.1,3660,9,999999999,30,0.0530,0,88,999.000,999.0,99.0
+1986,1,28,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-16.7,-23.9,54,99000,0,0,203,0,0,0,0,0,0,0,230,2.6,10,10,24.1,3660,9,999999999,30,0.0530,0,88,999.000,999.0,99.0
+1986,1,28,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-16.7,-23.3,57,98900,0,0,203,0,0,0,0,0,0,0,230,3.1,10,10,24.1,3660,9,999999999,30,0.0530,0,88,999.000,999.0,99.0
+1986,1,28,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-16.7,-22.8,60,99000,0,0,204,0,0,0,0,0,0,0,260,3.1,10,10,24.1,2130,9,999999999,30,0.0530,0,88,999.000,999.0,99.0
+1986,1,28,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-16.1,-23.3,54,98900,78,1164,205,23,1,22,2500,0,2500,740,200,4.1,10,10,24.1,1830,9,999999999,30,0.1040,0,88,999.000,999.0,99.0
+1986,1,28,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-15.0,-23.9,47,98900,296,1410,208,58,5,56,6500,200,6500,2090,190,3.1,10,10,24.1,1830,9,999999999,30,0.1040,0,88,999.000,999.0,99.0
+1986,1,28,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-12.8,-22.2,45,98900,483,1410,217,127,9,124,14300,600,14100,4630,190,4.6,10,10,24.1,2740,9,999999999,30,0.1040,0,88,999.000,999.0,99.0
+1986,1,28,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-12.8,-22.2,45,98900,617,1410,217,184,8,181,20800,600,20500,6850,190,4.6,10,10,24.1,2740,9,999999999,30,0.1040,0,88,999.000,999.0,99.0
+1986,1,28,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-11.1,-21.1,44,98700,689,1410,224,176,5,173,20100,400,19900,7090,200,4.1,10,10,24.1,7620,9,999999999,40,0.1040,0,88,999.000,999.0,99.0
+1986,1,28,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.6,-19.4,48,98600,695,1410,227,219,7,216,24800,600,24500,8270,210,5.2,10,10,24.1,1680,9,999999999,40,0.1040,0,88,999.000,999.0,99.0
+1986,1,28,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-9.4,-18.3,49,98500,633,1410,221,268,223,169,28900,22700,18700,3620,140,2.6,9,8,24.1,2740,9,999999999,40,0.1040,0,88,999.000,999.0,99.0
+1986,1,28,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.9,-15.6,59,98500,508,1410,237,121,6,119,13800,400,13700,4620,190,4.1,10,10,24.1,2740,9,999999999,50,0.1040,0,88,999.000,999.0,99.0
+1986,1,28,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.9,-14.4,65,98400,330,1410,238,73,1,72,8200,0,8200,2630,190,4.6,10,10,24.1,1400,9,999999999,50,0.1040,0,88,999.000,999.0,99.0
+1986,1,28,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.3,-13.9,65,98400,112,1399,241,19,1,19,2200,0,2200,690,190,4.1,10,10,24.1,1400,9,999999999,50,0.1040,0,88,999.000,999.0,99.0
+1986,1,28,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-12.8,71,98400,0,0,242,0,0,0,0,0,0,0,180,5.2,10,10,24.1,2440,9,999999999,50,0.1040,0,88,999.000,999.0,99.0
+1986,1,28,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-13.3,65,98400,0,0,243,0,0,0,0,0,0,0,190,5.7,10,10,24.1,2440,9,999999999,50,0.1040,0,88,999.000,999.0,99.0
+1986,1,28,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-12.8,68,98300,0,0,243,0,0,0,0,0,0,0,180,5.7,10,10,16.1,1400,9,999999999,50,0.1040,0,88,999.000,999.0,99.0
+1986,1,28,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-12.2,71,98300,0,0,244,0,0,0,0,0,0,0,170,3.6,10,10,11.3,760,9,999999999,50,0.1040,0,88,999.000,999.0,99.0
+1986,1,28,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-11.1,81,98300,0,0,243,0,0,0,0,0,0,0,170,5.7,10,10,3.2,580,9,999999999,60,0.1040,0,88,999.000,999.0,99.0
+1986,1,28,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-9.4,92,98300,0,0,245,0,0,0,0,0,0,0,170,4.6,10,10,6.4,240,9,999999999,60,0.1040,0,88,999.000,999.0,99.0
+1986,1,28,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-9.4,92,98200,0,0,245,0,0,0,0,0,0,0,170,3.1,10,10,9.7,460,9,999999999,60,0.1040,0,88,999.000,999.0,99.0
+1986,1,29,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-8.9,92,98100,0,0,247,0,0,0,0,0,0,0,200,2.6,10,10,6.4,430,9,999999999,60,0.1040,0,88,999.000,999.0,99.0
+1986,1,29,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-8.3,92,98100,0,0,250,0,0,0,0,0,0,0,0,0.0,10,10,6.4,370,9,999999999,69,0.1040,0,88,999.000,999.0,99.0
+1986,1,29,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-7.8,96,98100,0,0,250,0,0,0,0,0,0,0,0,0.0,10,10,6.4,760,9,999999999,69,0.1040,0,88,999.000,999.0,99.0
+1986,1,29,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-7.8,96,98100,0,0,250,0,0,0,0,0,0,0,0,0.0,10,10,8.0,460,9,999999999,69,0.1040,0,88,999.000,999.0,99.0
+1986,1,29,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-7.8,96,98200,0,0,250,0,0,0,0,0,0,0,280,2.1,10,10,8.0,1370,9,999999999,69,0.1040,0,88,999.000,999.0,99.0
+1986,1,29,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-7.8,92,98300,0,0,252,0,0,0,0,0,0,0,320,5.7,10,10,9.7,1370,9,999999999,69,0.1040,0,88,999.000,999.0,99.0
+1986,1,29,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-9.4,84,98400,0,0,249,0,0,0,0,0,0,0,320,7.7,10,10,8.0,490,9,999999999,60,0.1040,0,88,999.000,999.0,99.0
+1986,1,29,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-11.1,77,98600,81,1187,245,24,2,24,2700,0,2700,790,340,6.7,10,10,8.0,490,9,999999999,60,0.0950,0,88,999.000,999.0,99.0
+1986,1,29,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.9,-11.7,81,98800,301,1410,234,94,31,88,10400,2600,9800,2160,320,8.2,9,9,9.7,490,9,999999999,60,0.0950,0,88,999.000,999.0,99.0
+1986,1,29,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.3,-12.8,71,98900,487,1410,226,116,51,98,12700,4700,11100,2830,330,8.8,8,7,9.7,6100,9,999999999,50,0.0950,0,88,999.000,999.0,99.0
+1986,1,29,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.9,-13.3,71,99100,622,1410,239,180,2,179,20300,200,20200,6840,330,6.7,10,10,11.3,1830,9,999999999,50,0.0950,0,88,999.000,999.0,99.0
+1986,1,29,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.3,-13.9,65,99100,694,1410,229,366,147,293,40000,14800,32700,7960,330,6.7,10,8,11.3,6100,9,999999999,50,0.0950,0,88,999.000,999.0,99.0
+1986,1,29,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.3,-13.9,65,99200,700,1410,217,420,527,158,44700,52800,18400,3310,330,7.2,7,3,11.3,77777,9,999999999,50,0.0950,0,88,999.000,999.0,99.0
+1986,1,29,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-14.4,59,99200,639,1410,220,342,376,172,36800,38300,19400,3700,310,7.2,4,4,16.1,77777,9,999999999,50,0.0950,0,88,999.000,999.0,99.0
+1986,1,29,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.3,-14.4,62,99400,514,1410,217,293,446,132,30700,41800,15400,2560,320,7.2,3,3,16.1,77777,9,999999999,50,0.0950,0,88,999.000,999.0,99.0
+1986,1,29,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.9,-15.0,62,99500,335,1410,212,168,361,84,17600,29200,10600,1560,310,6.7,2,2,16.1,77777,9,999999999,50,0.0950,0,88,999.000,999.0,99.0
+1986,1,29,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.6,-15.6,67,99600,117,1410,207,43,182,26,4300,8400,3600,460,310,6.7,2,2,16.1,77777,9,999999999,50,0.0950,0,88,999.000,999.0,99.0
+1986,1,29,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.6,-15.6,67,99800,0,12,231,0,0,0,0,0,0,0,300,6.2,10,10,24.1,1010,9,999999999,50,0.0950,0,88,999.000,999.0,99.0
+1986,1,29,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.1,-16.1,67,99900,0,0,207,0,0,0,0,0,0,0,320,6.2,3,3,24.1,77777,9,999999999,50,0.0950,0,88,999.000,999.0,99.0
+1986,1,29,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.7,-16.7,67,99900,0,0,196,0,0,0,0,0,0,0,310,5.2,0,0,24.1,77777,9,999999999,40,0.0950,0,88,999.000,999.0,99.0
+1986,1,29,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.2,-17.2,67,100000,0,0,194,0,0,0,0,0,0,0,320,3.6,0,0,24.1,77777,9,999999999,40,0.0950,0,88,999.000,999.0,99.0
+1986,1,29,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.8,-17.8,67,100000,0,0,192,0,0,0,0,0,0,0,280,4.6,0,0,24.1,77777,9,999999999,40,0.0950,0,88,999.000,999.0,99.0
+1986,1,29,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-13.3,-17.8,70,100200,0,0,190,0,0,0,0,0,0,0,310,5.7,0,0,24.1,77777,9,999999999,40,0.0950,0,88,999.000,999.0,99.0
+1986,1,29,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-13.9,-18.9,66,100200,0,0,188,0,0,0,0,0,0,0,310,3.6,0,0,24.1,77777,9,999999999,40,0.0950,0,88,999.000,999.0,99.0
+1986,1,30,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-16.1,-21.1,66,100200,0,0,180,0,0,0,0,0,0,0,270,2.1,0,0,24.1,77777,9,999999999,40,0.0950,0,88,999.000,999.0,99.0
+1986,1,30,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-16.7,-21.1,69,100200,0,0,178,0,0,0,0,0,0,0,230,2.1,0,0,24.1,77777,9,999999999,40,0.0950,0,88,999.000,999.0,99.0
+1986,1,30,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.2,-21.1,72,100200,0,0,177,0,0,0,0,0,0,0,260,2.1,0,0,24.1,77777,9,999999999,40,0.0950,0,88,999.000,999.0,99.0
+1986,1,30,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.2,-20.6,76,100200,0,0,177,0,0,0,0,0,0,0,190,2.1,0,0,24.1,77777,9,999999999,40,0.0950,0,88,999.000,999.0,99.0
+1986,1,30,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.2,-20.6,76,100300,0,0,177,0,0,0,0,0,0,0,250,2.1,1,0,24.1,77777,9,999999999,40,0.0950,0,88,999.000,999.0,99.0
+1986,1,30,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-15.6,-18.9,76,100300,0,0,211,0,0,0,0,0,0,0,250,3.1,10,10,24.1,3660,9,999999999,40,0.0950,0,88,999.000,999.0,99.0
+1986,1,30,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-15.0,-18.9,73,100400,0,0,213,0,0,0,0,0,0,0,240,2.6,10,10,24.1,2740,9,999999999,40,0.0950,0,88,999.000,999.0,99.0
+1986,1,30,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-14.4,-18.3,73,100400,84,1210,215,26,1,26,2900,0,2900,840,240,2.6,10,10,24.1,2740,9,999999999,40,0.1800,0,88,999.000,999.0,99.0
+1986,1,30,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-13.3,-17.8,70,100400,305,1410,219,69,3,68,7700,100,7700,2440,220,2.1,10,10,14.5,2740,9,999999999,40,0.1800,0,88,999.000,999.0,99.0
+1986,1,30,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-11.1,-17.2,61,100400,492,1410,227,123,5,121,13900,300,13800,4600,240,4.1,10,10,14.5,1830,9,999999999,40,0.1800,0,88,999.000,999.0,99.0
+1986,1,30,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.6,-17.2,58,100400,627,1410,229,141,2,140,16200,100,16200,5780,240,3.6,10,10,14.5,2440,9,999999999,40,0.1800,0,88,999.000,999.0,99.0
+1986,1,30,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-9.4,-15.0,64,100400,700,1410,236,187,8,183,21400,600,21100,7450,240,4.1,10,10,19.3,3050,9,999999999,50,0.1800,0,88,999.000,999.0,99.0
+1986,1,30,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.9,-15.0,62,100300,706,1410,237,201,4,199,22900,300,22700,7930,230,3.1,10,10,19.3,3050,9,999999999,50,0.1800,0,88,999.000,999.0,99.0
+1986,1,30,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.3,-13.9,65,100200,644,1410,241,199,3,198,22400,300,22300,7460,210,4.6,10,10,19.3,2740,9,999999999,50,0.1800,0,88,999.000,999.0,99.0
+1986,1,30,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.2,-13.3,62,100300,520,1410,245,146,1,146,16400,100,16400,5380,240,3.1,10,10,16.1,2740,9,999999999,50,0.1800,0,88,999.000,999.0,99.0
+1986,1,30,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.2,-12.8,65,100200,341,1410,246,92,1,91,10200,0,10200,3140,230,3.6,10,10,16.1,2130,9,999999999,50,0.1800,0,88,999.000,999.0,99.0
+1986,1,30,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.1,-13.3,57,100200,122,1410,249,31,0,31,3400,0,3400,1000,240,3.6,10,10,12.9,2130,9,999999999,50,0.1800,0,88,999.000,999.0,99.0
+1986,1,30,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-12.2,62,100200,0,59,250,0,0,0,0,0,0,0,220,2.6,10,10,12.9,910,9,999999999,50,0.1800,0,88,999.000,999.0,99.0
+1986,1,30,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-12.2,68,100200,0,0,246,0,0,0,0,0,0,0,210,2.1,10,10,12.9,700,9,999999999,50,0.1800,0,88,999.000,999.0,99.0
+1986,1,30,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-12.2,65,100200,0,0,248,0,0,0,0,0,0,0,0,0.0,10,10,12.9,700,9,999999999,50,0.1800,0,88,999.000,999.0,99.0
+1986,1,30,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-11.1,65,100200,0,0,253,0,0,0,0,0,0,0,0,0.0,10,10,8.0,460,9,999999999,60,0.1800,0,88,999.000,999.0,99.0
+1986,1,30,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-9.4,78,100200,0,0,253,0,0,0,0,0,0,0,210,2.1,10,10,8.0,370,9,999999999,60,0.1800,0,88,999.000,999.0,99.0
+1986,1,30,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-8.3,92,100300,0,0,250,0,0,0,0,0,0,0,210,1.5,10,10,6.4,340,9,999999999,69,0.1800,0,88,999.000,999.0,99.0
+1986,1,30,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-8.9,92,100300,0,0,247,0,0,0,0,0,0,0,0,0.0,10,10,9.7,1010,9,999999999,60,0.1800,0,88,999.000,999.0,99.0
+1986,1,31,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-8.3,92,100300,0,0,250,0,0,0,0,0,0,0,0,0.0,10,10,11.3,1160,9,999999999,69,0.1800,0,88,999.000,999.0,99.0
+1986,1,31,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-8.3,88,100300,0,0,252,0,0,0,0,0,0,0,0,0.0,10,10,16.1,1010,9,999999999,69,0.1800,0,88,999.000,999.0,99.0
+1986,1,31,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-7.8,92,100200,0,0,252,0,0,0,0,0,0,0,40,3.1,10,10,16.1,1010,9,999999999,69,0.1800,0,88,999.000,999.0,99.0
+1986,1,31,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-7.8,92,100200,0,0,252,0,0,0,0,0,0,0,50,2.6,10,10,16.1,1160,9,999999999,69,0.1800,0,88,999.000,999.0,99.0
+1986,1,31,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-7.8,92,100200,0,0,252,0,0,0,0,0,0,0,50,3.1,10,10,16.1,1680,9,999999999,69,0.1800,0,88,999.000,999.0,99.0
+1986,1,31,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-7.8,88,100300,0,0,255,0,0,0,0,0,0,0,40,3.1,10,10,16.1,1370,9,999999999,69,0.1800,0,88,999.000,999.0,99.0
+1986,1,31,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-7.8,85,100300,0,0,256,0,0,0,0,0,0,0,30,3.1,10,10,16.1,1680,9,999999999,69,0.1800,0,88,999.000,999.0,99.0
+1986,1,31,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.0,-7.8,81,100300,88,1233,259,27,0,27,3000,0,3000,860,40,4.1,10,10,11.3,2130,9,999999999,69,0.1010,0,88,999.000,999.0,99.0
+1986,1,31,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.9,-7.2,78,100300,310,1409,264,98,1,98,10800,0,10800,3110,30,3.1,10,10,11.3,2440,9,999999999,69,0.1010,0,88,999.000,999.0,99.0
+1986,1,31,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-6.1,81,100300,497,1409,267,183,1,183,20100,100,20100,5930,100,4.6,10,10,8.0,2440,9,999999999,80,0.1010,0,88,999.000,999.0,99.0
+1986,1,31,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-6.1,75,100300,632,1409,271,234,1,233,25900,100,25800,8070,70,6.2,10,10,11.3,490,9,999999999,80,0.1010,0,88,999.000,999.0,99.0
+1986,1,31,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-6.1,72,100200,705,1409,273,250,1,249,27900,100,27800,9090,70,4.1,10,10,11.3,640,9,999999999,80,0.1010,0,88,999.000,999.0,99.0
+1986,1,31,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-5.6,72,100200,712,1409,259,309,212,202,33900,21800,22800,5050,120,4.6,10,7,11.3,490,9,999999999,80,0.1010,0,88,999.000,999.0,99.0
+1986,1,31,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-5.6,72,100100,650,1409,276,182,3,180,20600,200,20500,7050,100,6.7,10,10,14.5,700,9,999999999,80,0.1010,0,88,999.000,999.0,99.0
+1986,1,31,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-5.6,75,100100,526,1409,274,120,6,117,13700,400,13500,4640,80,7.2,10,10,16.1,3050,9,999999999,80,0.1010,0,88,999.000,999.0,99.0
+1986,1,31,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-5.6,75,100100,347,1409,274,69,4,68,7900,200,7800,2570,110,5.7,10,10,12.9,1520,9,999999999,80,0.1010,0,88,999.000,999.0,99.0
+1986,1,31,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-6.1,72,100000,127,1409,273,20,2,20,2300,0,2300,730,100,6.7,10,10,11.3,2740,9,999999999,80,0.1010,0,88,999.000,999.0,99.0
+1986,1,31,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-6.1,75,100000,0,82,271,0,0,0,0,0,0,0,100,5.7,10,10,11.3,2740,9,999999999,80,0.1010,0,88,999.000,999.0,99.0
+1986,1,31,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.6,75,100000,0,0,274,0,0,0,0,0,0,0,100,6.7,10,10,11.3,2740,9,999999999,80,0.1010,0,88,999.000,999.0,99.0
+1986,1,31,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.6,75,100000,0,0,274,0,0,0,0,0,0,0,100,6.7,10,10,11.3,2740,9,999999999,80,0.1010,0,88,999.000,999.0,99.0
+1986,1,31,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-4.4,78,100000,0,0,278,0,0,0,0,0,0,0,90,6.7,10,10,11.3,2740,9,999999999,80,0.1010,0,88,999.000,999.0,99.0
+1986,1,31,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.6,-6.2,78,99900,0,0,270,0,0,0,0,0,0,0,100,6.5,10,10,11.3,1400,9,999999999,80,0.1010,0,88,999.000,999.0,99.0
+1986,1,31,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.2,-8.1,75,99900,0,0,262,0,0,0,0,0,0,0,130,6.3,10,10,11.3,1400,9,999999999,80,0.1010,0,88,999.000,999.0,99.0
+1986,1,31,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.8,-10.0,85,99700,0,0,254,0,0,0,0,0,0,0,110,6.1,10,10,11.3,1400,9,999999999,89,0.1010,0,88,999.000,999.0,99.0
+1977,2,1,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.3,-12.0,70,99100,0,0,213,0,0,0,0,0,0,0,260,5.8,0,0,24.1,77777,9,999999999,40,0.1010,0,88,999.000,999.0,99.0
+1977,2,1,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-13.9,70,99200,0,0,207,0,0,0,0,0,0,0,270,5.6,0,0,24.1,77777,9,999999999,40,0.1010,0,88,999.000,999.0,99.0
+1977,2,1,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.5,-15.8,70,99200,0,0,200,0,0,0,0,0,0,0,280,5.4,0,0,24.1,77777,9,999999999,40,0.1010,0,88,999.000,999.0,99.0
+1977,2,1,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.2,-17.8,64,99200,0,0,193,0,0,0,0,0,0,0,280,5.2,0,0,24.1,77777,9,999999999,40,0.1010,0,88,999.000,999.0,99.0
+1977,2,1,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-13.3,-17.8,70,99300,0,0,190,0,0,0,0,0,0,0,270,5.7,0,0,24.1,77777,9,999999999,40,0.1010,0,88,999.000,999.0,99.0
+1977,2,1,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-13.3,-18.3,66,99400,0,0,190,0,0,0,0,0,0,0,280,6.2,0,0,24.1,77777,9,999999999,40,0.1010,0,88,999.000,999.0,99.0
+1977,2,1,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-13.9,-18.9,66,99400,0,0,194,0,0,0,0,0,0,0,280,4.6,2,2,24.1,77777,9,999999999,40,0.1010,0,88,999.000,999.0,99.0
+1977,2,1,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-13.9,-17.8,73,99600,92,1256,204,31,15,30,3400,900,3300,690,290,6.2,8,7,24.1,7620,9,999999999,40,0.1100,0,88,999.000,999.0,99.0
+1977,2,1,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-12.2,-16.1,73,99600,315,1409,208,102,65,88,11200,5500,10000,2200,290,4.1,7,6,24.1,7620,9,999999999,50,0.1100,0,88,999.000,999.0,99.0
+1977,2,1,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.6,-15.6,67,99700,503,1409,209,296,465,129,30800,43300,15200,2500,310,5.7,3,3,24.1,77777,9,999999999,50,0.1100,0,88,999.000,999.0,99.0
+1977,2,1,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.9,-15.0,62,99800,639,1409,206,450,764,103,47200,74300,13400,2120,300,4.6,1,0,24.1,77777,9,999999999,50,0.1100,0,88,999.000,999.0,99.0
+1977,2,1,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-13.9,62,99800,712,1409,210,510,797,106,54000,79100,13800,2300,290,4.6,0,0,24.1,77777,9,999999999,50,0.1100,0,88,999.000,999.0,99.0
+1977,2,1,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.7,-11.7,68,99800,719,1409,215,516,803,107,54800,79800,14000,2330,240,4.6,0,0,24.1,77777,9,999999999,60,0.1100,0,88,999.000,999.0,99.0
+1977,2,1,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.1,-11.1,68,99800,657,1409,218,458,772,100,48600,75600,13200,2100,250,5.7,0,0,24.1,77777,9,999999999,60,0.1100,0,88,999.000,999.0,99.0
+1977,2,1,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.6,-10.6,68,99800,533,1409,220,347,702,84,36600,66000,11600,1650,270,3.1,0,0,24.1,77777,9,999999999,60,0.1100,0,88,999.000,999.0,99.0
+1977,2,1,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.0,-11.1,63,99800,353,1409,221,197,546,62,20600,45500,9100,1140,280,3.1,0,0,24.1,77777,9,999999999,60,0.1100,0,88,999.000,999.0,99.0
+1977,2,1,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.1,-11.7,65,99900,134,1409,217,49,204,30,5200,10200,4200,530,300,2.6,0,0,24.1,77777,9,999999999,60,0.1100,0,88,999.000,999.0,99.0
+1977,2,1,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-13.3,68,99900,1,129,209,0,0,0,0,0,0,0,290,2.6,0,0,24.1,77777,9,999999999,50,0.1100,0,88,999.000,999.0,99.0
+1977,2,1,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.1,-13.9,80,100000,0,0,200,0,0,0,0,0,0,0,260,2.1,0,0,24.1,77777,9,999999999,50,0.1100,0,88,999.000,999.0,99.0
+1977,2,1,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.7,-15.0,77,100000,0,0,197,0,0,0,0,0,0,0,260,2.1,0,0,24.1,77777,9,999999999,50,0.1100,0,88,999.000,999.0,99.0
+1977,2,1,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-13.3,-15.6,84,100000,0,0,192,0,0,0,0,0,0,0,230,2.1,0,0,24.1,77777,9,999999999,50,0.1100,0,88,999.000,999.0,99.0
+1977,2,1,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-13.9,-16.1,83,100000,0,0,190,0,0,0,0,0,0,0,240,2.6,0,0,24.1,77777,9,999999999,40,0.1100,0,88,999.000,999.0,99.0
+1977,2,1,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-13.9,-16.7,80,100000,0,0,189,0,0,0,0,0,0,0,210,2.1,0,0,24.1,77777,9,999999999,40,0.1100,0,88,999.000,999.0,99.0
+1977,2,1,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-13.9,-18.9,66,100000,0,0,188,0,0,0,0,0,0,0,220,2.6,0,0,24.1,77777,9,999999999,40,0.1100,0,88,999.000,999.0,99.0
+1977,2,2,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-13.3,-17.8,70,100000,0,0,190,0,0,0,0,0,0,0,210,2.6,0,0,24.1,77777,9,999999999,40,0.1100,0,88,999.000,999.0,99.0
+1977,2,2,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-14.4,-18.9,69,100100,0,0,186,0,0,0,0,0,0,0,200,2.1,0,0,24.1,77777,9,999999999,40,0.1100,0,88,999.000,999.0,99.0
+1977,2,2,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-13.9,-17.8,73,100000,0,0,192,0,0,0,0,0,0,0,190,2.1,2,1,12.9,77777,9,999999999,40,0.1100,0,88,999.000,999.0,99.0
+1977,2,2,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-15.0,-19.4,69,100000,0,0,188,0,0,0,0,0,0,0,220,2.6,3,1,11.3,77777,9,999999999,40,0.1100,0,88,999.000,999.0,99.0
+1977,2,2,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-14.4,-17.8,76,100000,0,0,191,0,0,0,0,0,0,0,200,2.1,3,1,4.0,77777,9,999999999,40,0.1100,0,88,999.000,999.0,99.0
+1977,2,2,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-15.6,-19.4,72,100000,0,0,186,0,0,0,0,0,0,0,200,2.6,2,1,4.8,77777,9,999999999,40,0.1100,0,88,999.000,999.0,99.0
+1977,2,2,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-13.9,-16.7,80,100000,0,0,195,0,0,0,0,0,0,0,170,3.1,7,2,3.2,77777,9,999999999,40,0.1100,0,88,999.000,999.0,99.0
+1977,2,2,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-13.3,-15.6,84,100000,96,1279,200,47,102,38,4700,4100,4400,740,170,3.1,8,3,2.4,77777,9,999999999,50,0.0540,0,88,999.000,999.0,99.0
+1977,2,2,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.6,-15.0,70,100000,320,1408,217,125,65,111,13700,5600,12500,2620,170,3.6,9,7,3.2,7620,9,999999999,50,0.0540,0,88,999.000,999.0,99.0
+1977,2,2,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.2,-11.7,71,99900,508,1408,240,252,55,232,27500,5300,25600,5490,190,7.2,10,9,4.8,7620,9,999999999,60,0.0540,0,88,999.000,999.0,99.0
+1977,2,2,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.7,-11.1,71,99800,644,1408,233,328,173,249,35200,17400,27200,6040,190,5.2,10,7,9.7,7620,9,999999999,60,0.0540,0,88,999.000,999.0,99.0
+1977,2,2,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-9.4,68,99700,718,1408,235,451,431,232,48100,44800,25200,5410,200,6.7,10,3,14.5,77777,9,999999999,60,0.0540,0,88,999.000,999.0,99.0
+1977,2,2,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-5.6,78,99500,724,1408,248,383,367,195,41400,38300,21700,4400,200,5.7,10,4,14.5,77777,9,999999999,80,0.0540,0,88,999.000,999.0,99.0
+1977,2,2,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-6.1,69,99400,663,1408,276,220,10,216,24800,900,24300,8020,200,8.2,10,10,19.3,2130,9,999999999,80,0.0540,0,88,999.000,999.0,99.0
+1977,2,2,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-7.2,61,99300,539,1408,277,141,1,140,15900,100,15900,5340,190,7.2,10,10,19.3,2130,9,999999999,69,0.0540,0,88,999.000,999.0,99.0
+1977,2,2,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-8.3,56,99200,359,1408,276,101,5,100,11300,300,11200,3430,210,9.3,10,10,8.0,610,9,999999999,69,0.0540,0,88,999.000,999.0,99.0
+1977,2,2,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-7.8,63,99100,139,1408,272,37,5,37,4100,0,4100,1170,200,6.2,10,10,3.2,310,9,999999999,69,0.0540,0,88,999.000,999.0,99.0
+1977,2,2,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-7.8,66,99100,1,153,270,1,0,1,0,0,0,0,190,6.2,10,10,1.6,310,9,999999999,69,0.0540,0,88,999.000,999.0,99.0
+1977,2,2,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-7.2,72,99000,0,0,268,0,0,0,0,0,0,0,200,7.2,10,10,3.2,340,9,999999999,69,0.0540,0,88,999.000,999.0,99.0
+1977,2,2,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-6.7,75,99000,0,0,268,0,0,0,0,0,0,0,200,7.2,10,10,8.0,670,9,999999999,69,0.0540,0,88,999.000,999.0,99.0
+1977,2,2,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-5.6,78,98900,0,0,272,0,0,0,0,0,0,0,210,7.2,10,10,8.0,340,9,999999999,80,0.0540,0,88,999.000,999.0,99.0
+1977,2,2,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.0,78,98900,0,0,275,0,0,0,0,0,0,0,240,7.7,10,10,11.3,270,9,999999999,80,0.0540,0,88,999.000,999.0,99.0
+1977,2,2,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.0,78,98900,0,0,275,0,0,0,0,0,0,0,260,7.2,10,10,11.3,270,9,999999999,80,0.0540,0,88,999.000,999.0,99.0
+1977,2,2,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.6,75,98800,0,0,266,0,0,0,0,0,0,0,240,7.7,10,9,11.3,310,9,999999999,80,0.0540,0,88,999.000,999.0,99.0
+1977,2,3,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-5.6,78,98700,0,0,272,0,0,0,0,0,0,0,240,5.7,10,10,11.3,310,9,999999999,80,0.0540,0,88,999.000,999.0,99.0
+1977,2,3,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.6,75,98600,0,0,274,0,0,0,0,0,0,0,230,6.2,10,10,11.3,980,9,999999999,80,0.0540,0,88,999.000,999.0,99.0
+1977,2,3,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.0,78,98600,0,0,275,0,0,0,0,0,0,0,250,6.2,10,10,11.3,980,9,999999999,80,0.0540,0,88,999.000,999.0,99.0
+1977,2,3,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.6,75,98500,0,0,274,0,0,0,0,0,0,0,250,6.7,10,10,11.3,980,9,999999999,80,0.0540,0,88,999.000,999.0,99.0
+1977,2,3,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-6.1,75,98500,0,0,271,0,0,0,0,0,0,0,250,6.7,10,10,11.3,850,9,999999999,69,0.0540,0,88,999.000,999.0,99.0
+1977,2,3,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-6.1,75,98500,0,0,271,0,0,0,0,0,0,0,250,7.2,10,10,12.9,980,9,999999999,69,0.0540,0,88,999.000,999.0,99.0
+1977,2,3,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-6.7,69,98500,0,0,273,0,0,0,0,0,0,0,260,7.7,10,10,12.9,980,9,999999999,69,0.0540,0,88,999.000,999.0,99.0
+1977,2,3,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-7.2,66,98500,100,1326,272,25,3,25,2800,0,2800,840,260,6.7,10,10,16.1,760,9,999999999,69,0.0550,0,88,999.000,999.0,99.0
+1977,2,3,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-7.8,66,98500,325,1408,270,106,3,105,11600,200,11500,3320,240,7.7,10,10,16.1,670,9,999999999,69,0.0550,0,88,999.000,999.0,99.0
+1977,2,3,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-6.7,72,98500,514,1408,263,205,14,200,22400,1200,22000,6340,250,8.2,10,9,16.1,580,9,999999999,69,0.0550,0,88,999.000,999.0,99.0
+1977,2,3,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-7.2,69,98600,650,1408,270,166,2,165,19000,200,18900,6650,250,6.2,10,10,16.1,580,9,999999999,69,0.0550,0,88,999.000,999.0,99.0
+1977,2,3,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-8.3,61,98500,724,1408,258,436,315,274,45800,32700,28900,6650,250,7.7,10,8,16.1,2440,9,999999999,69,0.0550,0,88,999.000,999.0,99.0
+1977,2,3,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-8.9,61,98400,730,1408,256,426,328,256,45100,34100,27300,6120,240,10.8,10,8,16.1,2440,9,999999999,60,0.0550,0,88,999.000,999.0,99.0
+1977,2,3,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-8.9,58,98400,669,1408,258,327,167,248,35300,16900,27200,6080,240,7.2,10,8,16.1,2440,9,999999999,60,0.0550,0,88,999.000,999.0,99.0
+1977,2,3,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-7.8,63,98400,545,1408,272,160,11,155,17900,800,17600,5750,250,7.7,10,10,16.1,1400,9,999999999,69,0.0550,0,88,999.000,999.0,99.0
+1977,2,3,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-6.7,66,98400,365,1408,268,121,52,108,13300,4600,12100,2720,250,7.2,10,9,16.1,1400,9,999999999,69,0.0550,0,88,999.000,999.0,99.0
+1977,2,3,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-6.1,66,98400,145,1408,253,60,93,51,6500,5200,5900,1070,260,5.2,10,4,16.1,77777,9,999999999,69,0.0550,0,88,999.000,999.0,99.0
+1977,2,3,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-6.1,69,98300,2,176,249,2,2,2,0,0,0,0,240,5.7,7,3,19.3,77777,9,999999999,69,0.0550,0,88,999.000,999.0,99.0
+1977,2,3,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.6,72,98300,0,0,252,0,0,0,0,0,0,0,250,6.7,7,4,19.3,7620,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1977,2,3,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.6,72,98300,0,0,276,0,0,0,0,0,0,0,260,3.6,10,10,19.3,850,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1977,2,3,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.6,72,98300,0,0,276,0,0,0,0,0,0,0,250,3.6,10,10,19.3,850,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1977,2,3,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.6,72,98300,0,0,276,0,0,0,0,0,0,0,260,5.2,10,10,19.3,850,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1977,2,3,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.6,72,98300,0,0,259,0,0,0,0,0,0,0,270,3.1,9,7,19.3,2440,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1977,2,3,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.6,72,98200,0,0,276,0,0,0,0,0,0,0,250,3.1,10,10,19.3,670,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1977,2,4,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-6.1,72,98200,0,0,273,0,0,0,0,0,0,0,240,2.6,10,10,19.3,670,9,999999999,69,0.0550,0,88,999.000,999.0,99.0
+1977,2,4,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-6.1,72,98200,0,0,273,0,0,0,0,0,0,0,230,3.1,10,10,6.4,400,9,999999999,69,0.0550,0,88,999.000,999.0,99.0
+1977,2,4,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.6,75,98100,0,0,274,0,0,0,0,0,0,0,220,3.1,10,10,9.7,460,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1977,2,4,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.0,78,98000,0,0,275,0,0,0,0,0,0,0,200,1.5,10,10,9.7,400,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1977,2,4,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.0,78,97900,0,0,275,0,0,0,0,0,0,0,200,3.1,10,10,8.0,520,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1977,2,4,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.0,78,97900,0,0,275,0,0,0,0,0,0,0,190,2.6,10,10,2.4,340,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1977,2,4,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.0,78,97900,0,0,275,0,0,0,0,0,0,0,160,2.1,10,10,1.6,240,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1977,2,4,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-5.0,78,97800,105,1349,275,29,1,29,3200,0,3200,930,170,2.1,10,10,1.3,210,9,999999999,80,0.0780,0,88,999.000,999.0,99.0
+1977,2,4,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-4.4,82,97800,330,1408,275,83,6,82,9300,300,9300,2890,160,1.5,10,10,1.3,150,9,999999999,80,0.0780,0,88,999.000,999.0,99.0
+1977,2,4,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-3.3,85,97800,519,1408,279,199,10,195,21800,800,21500,6330,300,1.5,10,10,0.8,150,9,999999999,89,0.0780,0,88,999.000,999.0,99.0
+1977,2,4,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-3.3,85,97800,656,1408,279,180,5,178,20500,400,20300,7040,340,4.6,10,10,0.8,180,9,999999999,89,0.0780,0,88,999.000,999.0,99.0
+1977,2,4,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-2.8,85,97800,730,1408,281,288,9,284,32100,900,31600,10000,20,7.7,10,10,0.8,270,9,999999999,89,0.0780,0,88,999.000,999.0,99.0
+1977,2,4,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-4.4,75,97800,736,1408,280,235,6,232,26600,500,26300,9000,10,6.7,10,10,1.3,240,9,999999999,80,0.0780,0,88,999.000,999.0,99.0
+1977,2,4,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-5.0,75,97900,675,1408,277,217,1,216,24300,100,24300,8120,360,8.2,10,10,3.2,370,9,999999999,80,0.0780,0,88,999.000,999.0,99.0
+1977,2,4,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-6.7,72,98000,551,1408,271,176,1,176,19700,100,19600,6260,350,7.7,10,10,11.3,580,9,999999999,69,0.0780,0,88,999.000,999.0,99.0
+1977,2,4,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-7.2,75,98200,371,1408,266,116,2,115,12700,100,12700,3800,350,8.2,10,10,3.2,520,9,999999999,69,0.0780,0,88,999.000,999.0,99.0
+1977,2,4,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.0,-10.0,68,98300,150,1408,244,40,30,37,4400,2000,4200,880,330,9.3,8,8,19.3,980,9,999999999,60,0.0780,0,88,999.000,999.0,99.0
+1977,2,4,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.6,-11.1,65,98500,2,223,246,1,0,1,0,0,0,0,350,7.7,9,9,19.3,980,9,999999999,60,0.0780,0,88,999.000,999.0,99.0
+1977,2,4,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-12.8,62,98600,0,0,227,0,0,0,0,0,0,0,320,6.2,5,5,24.1,77777,9,999999999,50,0.0780,0,88,999.000,999.0,99.0
+1977,2,4,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-11.7,65,98700,0,0,239,0,0,0,0,0,0,0,320,7.2,8,8,24.1,980,9,999999999,60,0.0780,0,88,999.000,999.0,99.0
+1977,2,4,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-13.3,62,98700,0,0,227,0,0,0,0,0,0,0,320,6.2,6,6,24.1,1400,9,999999999,50,0.0780,0,88,999.000,999.0,99.0
+1977,2,4,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-14.4,62,98800,0,0,219,0,0,0,0,0,0,0,320,5.2,4,4,24.1,77777,9,999999999,50,0.0780,0,88,999.000,999.0,99.0
+1977,2,4,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.0,-15.6,64,98800,0,0,202,0,0,0,0,0,0,0,310,4.6,0,0,24.1,77777,9,999999999,50,0.0780,0,88,999.000,999.0,99.0
+1977,2,4,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.1,-16.7,64,98800,0,0,198,0,0,0,0,0,0,0,320,5.2,0,0,24.1,77777,9,999999999,40,0.0780,0,88,999.000,999.0,99.0
+1977,2,5,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.7,-22.2,42,98900,0,0,191,0,0,0,0,0,0,0,300,5.2,0,0,24.1,77777,9,999999999,30,0.0780,0,88,999.000,999.0,99.0
+1977,2,5,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.8,-21.7,48,98900,0,0,189,0,0,0,0,0,0,0,300,4.1,0,0,24.1,77777,9,999999999,40,0.0780,0,88,999.000,999.0,99.0
+1977,2,5,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-14.4,-22.8,50,98900,0,0,183,0,0,0,0,0,0,0,290,4.1,0,0,24.1,77777,9,999999999,30,0.0780,0,88,999.000,999.0,99.0
+1977,2,5,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-16.1,-22.2,60,98900,0,0,182,0,0,0,0,0,0,0,290,4.6,1,1,24.1,77777,9,999999999,30,0.0780,0,88,999.000,999.0,99.0
+1977,2,5,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-16.7,-23.3,57,98900,0,0,180,0,0,0,0,0,0,0,290,4.6,1,1,24.1,77777,9,999999999,30,0.0780,0,88,999.000,999.0,99.0
+1977,2,5,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-15.6,-21.1,63,99000,0,0,196,0,0,0,0,0,0,0,280,4.6,7,7,24.1,3660,9,999999999,40,0.0780,0,88,999.000,999.0,99.0
+1977,2,5,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-15.6,-22.2,57,99000,0,0,195,0,0,0,0,0,0,0,280,4.1,7,7,24.1,3660,9,999999999,30,0.0780,0,88,999.000,999.0,99.0
+1977,2,5,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-16.1,-22.2,60,99100,109,1372,182,41,157,27,4200,7300,3600,480,290,4.6,1,1,24.1,77777,9,999999999,30,0.1140,0,88,999.000,999.0,99.0
+1977,2,5,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-14.4,-21.7,55,99200,335,1407,184,193,535,65,19700,43600,9300,1170,300,5.2,0,0,24.1,77777,9,999999999,40,0.1140,0,88,999.000,999.0,99.0
+1977,2,5,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-14.4,-21.1,57,99300,525,1407,184,354,705,91,36900,65800,12200,1760,320,6.2,0,0,24.1,77777,9,999999999,40,0.1140,0,88,999.000,999.0,99.0
+1977,2,5,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-13.3,-20.6,55,99300,661,1407,188,480,787,109,50300,76900,14000,2260,290,7.2,0,0,24.1,77777,9,999999999,40,0.1140,0,88,999.000,999.0,99.0
+1977,2,5,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-12.8,-20.6,53,99400,736,1407,189,544,813,119,57400,80700,15000,2600,320,7.7,0,0,24.1,77777,9,999999999,40,0.1140,0,88,999.000,999.0,99.0
+1977,2,5,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-12.2,-20.6,50,99400,743,1407,191,553,823,120,58500,81800,15200,2630,310,5.2,0,0,24.1,77777,9,999999999,40,0.1140,0,88,999.000,999.0,99.0
+1977,2,5,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-12.2,-20.6,50,99400,681,1407,191,493,792,111,52000,77800,14200,2340,310,5.2,0,0,24.1,77777,9,999999999,40,0.1140,0,88,999.000,999.0,99.0
+1977,2,5,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-12.8,-20.6,53,99600,557,1407,189,377,721,95,39700,68200,12600,1860,290,5.2,0,0,24.1,77777,9,999999999,40,0.1140,0,88,999.000,999.0,99.0
+1977,2,5,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-12.8,-21.1,50,99700,377,1407,189,220,572,70,23000,48600,9900,1280,290,5.7,0,0,24.1,77777,9,999999999,40,0.1140,0,88,999.000,999.0,99.0
+1977,2,5,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-13.9,-22.2,50,99700,156,1407,185,61,241,36,6500,13200,5100,650,300,3.6,0,0,24.1,77777,9,999999999,30,0.1140,0,88,999.000,999.0,99.0
+1977,2,5,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-15.0,-23.3,49,99800,3,246,181,2,2,1,0,0,0,0,290,2.6,0,0,24.1,77777,9,999999999,30,0.1140,0,88,999.000,999.0,99.0
+1977,2,5,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.8,-23.9,59,99900,0,0,173,0,0,0,0,0,0,0,260,3.6,0,0,24.1,77777,9,999999999,30,0.1140,0,88,999.000,999.0,99.0
+1977,2,5,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.8,-23.3,62,99900,0,0,173,0,0,0,0,0,0,0,300,2.6,0,0,24.1,77777,9,999999999,30,0.1140,0,88,999.000,999.0,99.0
+1977,2,5,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-18.3,-23.9,62,99900,0,0,171,0,0,0,0,0,0,0,270,3.6,0,0,24.1,77777,9,999999999,30,0.1140,0,88,999.000,999.0,99.0
+1977,2,5,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-16.7,-25.0,49,100000,0,0,175,0,0,0,0,0,0,0,280,3.1,0,0,24.1,77777,9,999999999,30,0.1140,0,88,999.000,999.0,99.0
+1977,2,5,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-18.3,-23.9,62,100000,0,0,171,0,0,0,0,0,0,0,290,2.1,0,0,24.1,77777,9,999999999,30,0.1140,0,88,999.000,999.0,99.0
+1977,2,5,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-19.4,-25.0,62,100000,0,0,168,0,0,0,0,0,0,0,280,3.1,0,0,24.1,77777,9,999999999,30,0.1140,0,88,999.000,999.0,99.0
+1977,2,6,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-19.4,-25.0,62,100100,0,0,168,0,0,0,0,0,0,0,280,3.1,0,0,24.1,77777,9,999999999,30,0.1140,0,88,999.000,999.0,99.0
+1977,2,6,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-19.4,-25.0,62,100100,0,0,168,0,0,0,0,0,0,0,270,2.1,0,0,24.1,77777,9,999999999,30,0.1140,0,88,999.000,999.0,99.0
+1977,2,6,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-21.1,-26.1,64,100100,0,0,163,0,0,0,0,0,0,0,270,2.6,0,0,24.1,77777,9,999999999,30,0.1140,0,88,999.000,999.0,99.0
+1977,2,6,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-21.1,-26.7,61,100100,0,0,162,0,0,0,0,0,0,0,270,3.1,0,0,24.1,77777,9,999999999,30,0.1140,0,88,999.000,999.0,99.0
+1977,2,6,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-21.7,-26.7,64,100100,0,0,161,0,0,0,0,0,0,0,280,3.1,0,0,24.1,77777,9,999999999,30,0.1140,0,88,999.000,999.0,99.0
+1977,2,6,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-21.1,-26.1,64,100200,0,0,163,0,0,0,0,0,0,0,270,3.1,0,0,24.1,77777,9,999999999,30,0.1140,0,88,999.000,999.0,99.0
+1977,2,6,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-21.1,-26.7,61,100300,0,0,162,0,0,0,0,0,0,0,280,3.1,0,0,24.1,77777,9,999999999,30,0.1140,0,88,999.000,999.0,99.0
+1977,2,6,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-21.1,-25.6,68,100400,114,1395,163,45,151,31,4500,7100,3900,560,270,2.1,0,0,24.1,77777,9,999999999,30,0.1300,0,88,999.000,999.0,99.0
+1977,2,6,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-18.3,-22.8,68,100500,341,1407,172,195,514,70,19900,41900,9700,1240,290,3.1,0,0,24.1,77777,9,999999999,30,0.1300,0,88,999.000,999.0,99.0
+1977,2,6,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-15.6,-21.1,63,100500,530,1407,181,356,683,98,36900,63700,12700,1880,270,3.6,0,0,24.1,77777,9,999999999,40,0.1300,0,88,999.000,999.0,99.0
+1977,2,6,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-13.9,-19.4,63,100600,667,1407,187,481,766,117,50300,74800,14600,2410,260,3.1,0,0,24.1,77777,9,999999999,40,0.1300,0,88,999.000,999.0,99.0
+1977,2,6,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-12.2,-18.9,58,100500,742,1407,192,553,793,134,57800,78400,16300,2890,280,4.6,1,0,24.1,77777,9,999999999,40,0.1300,0,88,999.000,999.0,99.0
+1977,2,6,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.6,-18.3,53,100500,749,1407,198,557,794,135,58400,78600,16400,2930,300,4.1,1,0,24.1,77777,9,999999999,40,0.1300,0,88,999.000,999.0,99.0
+1977,2,6,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-9.4,-18.3,49,100500,688,1407,201,496,774,119,52100,75900,14900,2490,340,5.2,0,0,24.1,77777,9,999999999,40,0.1300,0,88,999.000,999.0,99.0
+1977,2,6,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.0,-18.3,51,100500,563,1407,200,379,701,101,39700,66300,13000,1970,290,4.1,0,0,24.1,77777,9,999999999,40,0.1300,0,88,999.000,999.0,99.0
+1977,2,6,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.6,-18.9,51,100600,383,1407,197,221,546,75,22900,46400,10200,1360,280,5.2,0,0,24.1,77777,9,999999999,40,0.1300,0,88,999.000,999.0,99.0
+1977,2,6,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-12.2,-20.0,53,100700,161,1407,192,62,218,38,6600,12200,5100,680,290,5.7,0,0,24.1,77777,9,999999999,40,0.1300,0,88,999.000,999.0,99.0
+1977,2,6,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-13.9,-21.1,55,100700,4,270,186,2,2,1,0,0,0,0,280,3.6,0,0,24.1,77777,9,999999999,40,0.1300,0,88,999.000,999.0,99.0
+1977,2,6,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-15.6,-22.2,57,100800,0,0,180,0,0,0,0,0,0,0,260,3.1,0,0,24.1,77777,9,999999999,30,0.1300,0,88,999.000,999.0,99.0
+1977,2,6,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-16.1,-21.7,63,100800,0,0,179,0,0,0,0,0,0,0,270,3.1,0,0,24.1,77777,9,999999999,40,0.1300,0,88,999.000,999.0,99.0
+1977,2,6,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-19.4,-23.9,68,100900,0,0,169,0,0,0,0,0,0,0,260,2.6,0,0,24.1,77777,9,999999999,30,0.1300,0,88,999.000,999.0,99.0
+1977,2,6,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-18.3,-22.8,68,100900,0,0,172,0,0,0,0,0,0,0,260,2.6,0,0,24.1,77777,9,999999999,30,0.1300,0,88,999.000,999.0,99.0
+1977,2,6,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-19.4,-24.4,65,100900,0,0,168,0,0,0,0,0,0,0,260,2.6,0,0,24.1,77777,9,999999999,30,0.1300,0,88,999.000,999.0,99.0
+1977,2,6,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-21.1,-25.0,71,100900,0,0,163,0,0,0,0,0,0,0,240,1.5,0,0,24.1,77777,9,999999999,30,0.1300,0,88,999.000,999.0,99.0
+1977,2,7,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-20.0,-24.4,68,100900,0,0,167,0,0,0,0,0,0,0,260,1.5,0,0,24.1,77777,9,999999999,30,0.1300,0,88,999.000,999.0,99.0
+1977,2,7,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-20.6,-25.0,68,100900,0,0,165,0,0,0,0,0,0,0,270,3.1,0,0,24.1,77777,9,999999999,30,0.1300,0,88,999.000,999.0,99.0
+1977,2,7,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-20.0,-24.4,68,100900,0,0,167,0,0,0,0,0,0,0,260,2.6,0,0,24.1,77777,9,999999999,30,0.1300,0,88,999.000,999.0,99.0
+1977,2,7,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-20.0,-24.4,68,101000,0,0,167,0,0,0,0,0,0,0,260,2.1,0,0,24.1,77777,9,999999999,30,0.1300,0,88,999.000,999.0,99.0
+1977,2,7,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-20.0,-24.4,68,101000,0,0,167,0,0,0,0,0,0,0,270,2.1,0,0,24.1,77777,9,999999999,30,0.1300,0,88,999.000,999.0,99.0
+1977,2,7,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-19.4,-23.9,68,101000,0,0,169,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,30,0.1300,0,88,999.000,999.0,99.0
+1977,2,7,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-21.7,-27.8,58,101000,0,12,160,0,0,0,0,0,0,0,250,1.5,0,0,24.1,77777,9,999999999,30,0.1300,0,88,999.000,999.0,99.0
+1977,2,7,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-20.0,-24.4,68,101100,119,1406,167,51,259,27,4900,13200,3800,460,260,2.6,0,0,11.3,77777,9,999999999,30,0.0810,0,88,999.000,999.0,99.0
+1977,2,7,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-17.2,-21.1,72,101100,346,1406,177,211,625,57,21900,51900,9100,1060,270,1.5,0,0,12.9,77777,9,999999999,40,0.0810,0,88,999.000,999.0,99.0
+1977,2,7,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-14.4,-18.9,69,101100,536,1406,186,375,777,78,38400,72600,10600,1470,310,1.5,0,0,12.9,77777,9,999999999,40,0.0810,0,88,999.000,999.0,99.0
+1977,2,7,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-12.8,-17.8,67,101100,673,1406,192,501,850,93,51800,82500,12200,1870,280,1.5,0,0,12.9,77777,9,999999999,40,0.0810,0,88,999.000,999.0,99.0
+1977,2,7,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.0,-16.7,59,101100,748,1406,201,569,879,101,59200,86400,13100,2120,240,3.1,0,0,19.3,77777,9,999999999,40,0.0810,0,88,999.000,999.0,99.0
+1977,2,7,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-9.4,-17.2,54,101000,755,1406,202,574,883,102,60000,86900,13200,2150,270,3.6,0,0,19.3,77777,9,999999999,40,0.0810,0,88,999.000,999.0,99.0
+1977,2,7,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.9,-17.2,51,100900,694,1406,204,516,856,95,53700,83400,12400,1930,270,3.6,0,0,24.1,77777,9,999999999,40,0.0810,0,88,999.000,999.0,99.0
+1977,2,7,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.9,-17.2,51,100900,569,1406,204,400,795,81,41400,75100,10900,1550,230,3.6,0,0,24.1,77777,9,999999999,40,0.0810,0,88,999.000,999.0,99.0
+1977,2,7,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-9.4,-17.8,51,100900,389,1406,202,240,659,61,25400,57000,9500,1150,230,4.1,0,0,24.1,77777,9,999999999,40,0.0810,0,88,999.000,999.0,99.0
+1977,2,7,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-11.1,-18.9,53,100800,167,1406,196,72,343,34,7600,20800,5100,600,240,3.6,0,0,24.1,77777,9,999999999,40,0.0810,0,88,999.000,999.0,99.0
+1977,2,7,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-12.8,-20.0,55,100900,5,293,190,4,10,3,0,0,0,0,240,3.1,0,0,24.1,77777,9,999999999,40,0.0810,0,88,999.000,999.0,99.0
+1977,2,7,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-13.3,-20.0,58,100800,0,0,211,0,0,0,0,0,0,0,190,3.6,9,9,19.3,2440,9,999999999,40,0.0810,0,88,999.000,999.0,99.0
+1977,2,7,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.2,-17.2,67,100800,0,0,224,0,0,0,0,0,0,0,220,3.1,10,10,19.3,2440,9,999999999,40,0.0810,0,88,999.000,999.0,99.0
+1977,2,7,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.7,-16.7,67,100700,0,0,226,0,0,0,0,0,0,0,220,3.6,10,10,16.1,2440,9,999999999,40,0.0810,0,88,999.000,999.0,99.0
+1977,2,7,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.7,-16.7,67,100700,0,0,226,0,0,0,0,0,0,0,200,3.1,10,10,16.1,2440,9,999999999,40,0.0810,0,88,999.000,999.0,99.0
+1977,2,7,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.1,-16.7,64,100600,0,0,228,0,0,0,0,0,0,0,210,3.6,10,10,16.1,2440,9,999999999,40,0.0810,0,88,999.000,999.0,99.0
+1977,2,7,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.6,-16.1,64,100600,0,0,230,0,0,0,0,0,0,0,190,3.1,10,10,24.1,3350,9,999999999,50,0.0810,0,88,999.000,999.0,99.0
+1977,2,8,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.6,-16.1,64,100600,0,0,230,0,0,0,0,0,0,0,220,4.1,10,10,24.1,3050,9,999999999,50,0.0810,0,88,999.000,999.0,99.0
+1977,2,8,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.6,-16.1,64,100600,0,0,230,0,0,0,0,0,0,0,220,3.1,10,10,24.1,2440,9,999999999,50,0.0810,0,88,999.000,999.0,99.0
+1977,2,8,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.6,-15.6,67,100500,0,0,231,0,0,0,0,0,0,0,200,2.6,10,10,19.3,2440,9,999999999,50,0.0810,0,88,999.000,999.0,99.0
+1977,2,8,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.6,-15.6,67,100500,0,0,231,0,0,0,0,0,0,0,200,3.6,10,10,19.3,2440,9,999999999,50,0.0810,0,88,999.000,999.0,99.0
+1977,2,8,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.6,-15.0,70,100500,0,0,220,0,0,0,0,0,0,0,210,3.6,9,8,19.3,2440,9,999999999,50,0.0810,0,88,999.000,999.0,99.0
+1977,2,8,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.6,-16.1,64,100400,0,0,219,0,0,0,0,0,0,0,210,4.6,9,8,19.3,2440,9,999999999,50,0.0810,0,88,999.000,999.0,99.0
+1977,2,8,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.6,-15.0,70,100400,0,35,225,0,0,0,0,0,0,0,210,5.2,10,9,8.0,2440,9,999999999,50,0.0810,0,88,999.000,999.0,99.0
+1977,2,8,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-11.1,-16.7,64,100400,124,1406,211,36,50,31,3900,2600,3600,640,200,5.2,7,6,9.7,7620,9,999999999,40,0.1030,0,88,999.000,999.0,99.0
+1977,2,8,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.6,-15.6,67,100400,352,1406,210,168,240,107,17500,20100,12500,2150,200,7.2,8,4,14.5,77777,9,999999999,50,0.1030,0,88,999.000,999.0,99.0
+1977,2,8,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-9.4,-13.9,70,100300,542,1406,214,288,374,144,30000,35500,16200,2840,220,5.7,3,3,16.1,77777,9,999999999,50,0.1030,0,88,999.000,999.0,99.0
+1977,2,8,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-12.8,68,100200,679,1406,211,496,809,105,52400,79600,13800,2230,200,8.2,0,0,19.3,77777,9,999999999,50,0.1030,0,88,999.000,999.0,99.0
+1977,2,8,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.7,-13.9,57,100100,754,1406,214,547,809,113,58100,80800,14600,2530,200,8.2,0,0,24.1,77777,9,999999999,50,0.1030,0,88,999.000,999.0,99.0
+1977,2,8,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.6,-13.3,55,100000,761,1406,218,564,834,114,58200,81700,13800,2300,210,8.2,0,0,24.1,77777,9,999999999,50,0.1030,0,88,999.000,999.0,99.0
+1977,2,8,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.0,-12.8,55,99900,700,1406,220,508,811,107,54100,80200,14000,2300,210,8.8,0,0,24.1,77777,9,999999999,50,0.1030,0,88,999.000,999.0,99.0
+1977,2,8,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-13.9,48,99900,575,1406,221,393,745,91,41600,71200,12300,1820,200,7.2,0,0,24.1,77777,9,999999999,50,0.1030,0,88,999.000,999.0,99.0
+1977,2,8,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.9,-13.3,48,99800,395,1406,223,236,609,68,24800,52700,9900,1260,200,7.7,0,0,24.1,77777,9,999999999,50,0.1030,0,88,999.000,999.0,99.0
+1977,2,8,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-13.3,50,99800,173,1406,221,72,294,38,7500,17900,5300,650,190,5.7,0,0,24.1,77777,9,999999999,50,0.1030,0,88,999.000,999.0,99.0
+1977,2,8,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.0,-13.3,52,99700,6,340,220,4,6,3,0,0,0,0,180,5.2,0,0,24.1,77777,9,999999999,50,0.1030,0,88,999.000,999.0,99.0
+1977,2,8,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-13.3,55,99700,0,0,218,0,0,0,0,0,0,0,180,5.7,0,0,24.1,77777,9,999999999,50,0.1030,0,88,999.000,999.0,99.0
+1977,2,8,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-12.2,57,99600,0,0,220,0,0,0,0,0,0,0,190,6.2,0,0,24.1,77777,9,999999999,50,0.1030,0,88,999.000,999.0,99.0
+1977,2,8,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-12.2,60,99600,0,0,218,0,0,0,0,0,0,0,190,5.2,0,0,24.1,77777,9,999999999,50,0.1030,0,88,999.000,999.0,99.0
+1977,2,8,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-11.7,62,99500,0,0,219,0,0,0,0,0,0,0,200,8.2,0,0,24.1,77777,9,999999999,60,0.1030,0,88,999.000,999.0,99.0
+1977,2,8,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-12.2,57,99500,0,0,228,0,0,0,0,0,0,0,210,7.2,2,2,24.1,77777,9,999999999,50,0.1030,0,88,999.000,999.0,99.0
+1977,2,8,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-13.9,50,99400,0,0,223,0,0,0,0,0,0,0,210,7.2,2,1,24.1,77777,9,999999999,50,0.1030,0,88,999.000,999.0,99.0
+1977,2,9,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-12.8,55,99300,0,0,238,0,0,0,0,0,0,0,200,7.2,8,7,19.3,7620,9,999999999,50,0.1030,0,88,999.000,999.0,99.0
+1977,2,9,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-12.2,55,99300,0,0,241,0,0,0,0,0,0,0,220,8.2,9,7,19.3,7620,9,999999999,50,0.1030,0,88,999.000,999.0,99.0
+1977,2,9,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-10.6,60,99300,0,0,244,0,0,0,0,0,0,0,230,5.7,9,7,19.3,7620,9,999999999,60,0.1030,0,88,999.000,999.0,99.0
+1977,2,9,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-8.9,69,99200,0,0,239,0,0,0,0,0,0,0,220,4.1,9,4,19.3,77777,9,999999999,60,0.1030,0,88,999.000,999.0,99.0
+1977,2,9,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-8.9,71,99200,0,0,235,0,0,0,0,0,0,0,200,6.2,8,3,19.3,77777,9,999999999,60,0.1030,0,88,999.000,999.0,99.0
+1977,2,9,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-7.8,75,99200,0,0,240,0,0,0,0,0,0,0,220,5.7,9,4,16.1,77777,9,999999999,69,0.1030,0,88,999.000,999.0,99.0
+1977,2,9,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-7.2,78,99200,0,82,247,0,0,0,0,0,0,0,230,3.6,9,7,8.0,2740,9,999999999,69,0.1030,0,88,999.000,999.0,99.0
+1977,2,9,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-6.7,78,99200,129,1405,266,51,3,50,5400,0,5400,1320,210,3.6,10,10,8.0,2740,9,999999999,69,0.0400,0,88,999.000,999.0,99.0
+1977,2,9,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-5.6,78,99300,358,1405,272,156,7,154,16700,500,16600,4200,220,5.7,10,10,9.7,2740,9,999999999,80,0.0400,0,88,999.000,999.0,99.0
+1977,2,9,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-4.4,78,99200,548,1405,260,270,193,195,29100,18800,21700,4550,210,7.7,9,7,9.7,3660,9,999999999,80,0.0400,0,88,999.000,999.0,99.0
+1977,2,9,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-3.3,73,99200,685,1405,267,436,413,235,46100,42500,25300,5460,230,6.7,9,6,9.7,3660,9,999999999,89,0.0400,0,88,999.000,999.0,99.0
+1977,2,9,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-2.8,67,99200,760,1405,277,395,217,277,42600,22400,30500,7120,220,5.2,8,7,9.7,3660,9,999999999,89,0.0400,0,88,999.000,999.0,99.0
+1977,2,9,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-2.2,70,99200,767,1405,268,576,770,156,59900,76000,18300,3360,210,4.1,3,3,9.7,77777,9,999999999,89,0.0400,0,88,999.000,999.0,99.0
+1977,2,9,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-2.8,65,99200,706,1405,269,499,648,175,52900,64900,20100,3720,200,5.2,3,3,8.0,77777,9,999999999,89,0.0400,0,88,999.000,999.0,99.0
+1977,2,9,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-1.7,65,99200,581,1405,268,403,816,68,42700,78100,10200,1430,220,5.2,1,1,8.0,77777,9,999999999,100,0.0400,0,88,999.000,999.0,99.0
+1977,2,9,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,-1.7,62,99200,401,1405,265,254,747,45,27200,66400,8200,970,200,5.7,0,0,8.0,77777,9,999999999,100,0.0400,0,88,999.000,999.0,99.0
+1977,2,9,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-2.2,62,99200,178,1405,263,86,490,26,9000,33200,4700,500,220,4.6,0,0,8.0,77777,9,999999999,89,0.0400,0,88,999.000,999.0,99.0
+1977,2,9,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-2.2,67,99300,7,363,259,9,41,3,0,0,0,0,210,4.6,0,0,8.0,77777,9,999999999,89,0.0400,0,88,999.000,999.0,99.0
+1977,2,9,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-1.7,70,99300,0,0,259,0,0,0,0,0,0,0,210,6.2,0,0,9.7,77777,9,999999999,100,0.0400,0,88,999.000,999.0,99.0
+1977,2,9,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-1.7,73,99300,0,0,257,0,0,0,0,0,0,0,220,5.2,0,0,9.7,77777,9,999999999,100,0.0400,0,88,999.000,999.0,99.0
+1977,2,9,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-1.7,76,99400,0,0,255,0,0,0,0,0,0,0,220,5.2,0,0,11.3,77777,9,999999999,100,0.0400,0,88,999.000,999.0,99.0
+1977,2,9,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-1.7,76,99400,0,0,255,0,0,0,0,0,0,0,220,4.1,0,0,9.7,77777,9,999999999,100,0.0400,0,88,999.000,999.0,99.0
+1977,2,9,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-2.8,79,99400,0,0,248,0,0,0,0,0,0,0,220,3.1,0,0,8.0,77777,9,999999999,89,0.0400,0,88,999.000,999.0,99.0
+1977,2,9,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-3.3,75,99500,0,0,248,0,0,0,0,0,0,0,210,2.1,0,0,8.0,77777,9,999999999,89,0.0400,0,88,999.000,999.0,99.0
+1977,2,10,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-3.3,79,99500,0,0,245,0,0,0,0,0,0,0,210,2.6,0,0,8.0,77777,9,999999999,89,0.0400,0,88,999.000,999.0,99.0
+1977,2,10,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-3.9,82,99500,0,0,241,0,0,0,0,0,0,0,190,2.6,0,0,6.4,77777,9,999999999,89,0.0400,0,88,999.000,999.0,99.0
+1977,2,10,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-4.4,78,99500,0,0,241,0,0,0,0,0,0,0,190,3.1,0,0,6.4,77777,9,999999999,80,0.0400,0,88,999.000,999.0,99.0
+1977,2,10,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-5.0,82,99400,0,0,244,0,0,0,0,0,0,0,190,3.1,2,2,4.8,77777,9,999999999,80,0.0400,0,88,999.000,999.0,99.0
+1977,2,10,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-4.4,85,99500,0,0,245,0,0,0,0,0,0,0,200,3.6,2,2,4.0,77777,9,999999999,80,0.0400,0,88,999.000,999.0,99.0
+1977,2,10,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-4.4,85,99500,0,0,245,0,0,0,0,0,0,0,190,3.1,2,2,4.0,77777,9,999999999,80,0.0400,0,88,999.000,999.0,99.0
+1977,2,10,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-4.4,85,99500,1,105,247,0,0,0,0,0,0,0,180,3.1,3,3,2.4,77777,9,999999999,80,0.2010,0,88,999.000,999.0,99.0
+1977,2,10,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-3.9,85,99500,135,1405,243,39,75,32,4200,3500,3800,580,190,3.1,1,1,2.4,77777,9,999999999,89,0.2010,0,88,999.000,999.0,99.0
+1977,2,10,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,0.0,89,99500,363,1405,260,177,350,86,18400,29300,10800,1590,200,4.6,1,1,4.8,77777,9,999999999,110,0.2010,0,88,999.000,999.0,99.0
+1977,2,10,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,1.7,89,99400,554,1405,267,330,509,129,34800,48700,15500,2510,220,5.2,2,1,6.4,77777,9,999999999,120,0.2010,0,88,999.000,999.0,99.0
+1977,2,10,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,1.1,79,99400,692,1405,266,459,634,147,47400,61600,17000,2970,230,4.6,1,0,6.4,77777,9,999999999,110,0.2010,0,88,999.000,999.0,99.0
+1977,2,10,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,1.1,73,99400,767,1405,270,527,674,160,54700,66400,18400,3430,240,4.6,1,0,8.0,77777,9,999999999,110,0.2010,0,88,999.000,999.0,99.0
+1977,2,10,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,1.7,71,99300,774,1405,275,533,687,156,55600,67900,18000,3390,240,6.2,0,0,8.0,77777,9,999999999,120,0.2010,0,88,999.000,999.0,99.0
+1977,2,10,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,1.7,68,99200,713,1405,277,475,654,145,49400,63900,16900,3000,220,5.7,0,0,8.0,77777,9,999999999,120,0.2010,0,88,999.000,999.0,99.0
+1977,2,10,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.8,2.2,68,99200,587,1405,280,363,579,123,37600,54800,14600,2350,220,5.2,0,0,8.0,77777,9,999999999,120,0.2010,0,88,999.000,999.0,99.0
+1977,2,10,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,2.2,66,99200,406,1405,282,212,428,90,22500,37400,11700,1670,220,5.7,0,0,9.7,77777,9,999999999,120,0.2010,0,88,999.000,999.0,99.0
+1977,2,10,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,1.7,68,99200,184,1405,277,65,144,47,6900,8400,5800,870,220,5.2,0,0,9.7,77777,9,999999999,120,0.2010,0,88,999.000,999.0,99.0
+1977,2,10,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,0.6,68,99200,9,386,272,4,1,4,0,0,0,0,230,3.1,0,0,8.0,77777,9,999999999,110,0.2010,0,88,999.000,999.0,99.0
+1977,2,10,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,0.6,73,99300,0,0,268,0,0,0,0,0,0,0,200,2.6,0,0,9.7,77777,9,999999999,110,0.2010,0,88,999.000,999.0,99.0
+1977,2,10,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,1.1,76,99300,0,0,268,0,0,0,0,0,0,0,220,5.2,0,0,9.7,77777,9,999999999,110,0.2010,0,88,999.000,999.0,99.0
+1977,2,10,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,1.7,79,99200,0,0,269,0,0,0,0,0,0,0,210,5.7,0,0,9.7,77777,9,999999999,120,0.2010,0,88,999.000,999.0,99.0
+1977,2,10,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,1.1,79,99200,0,0,266,0,0,0,0,0,0,0,230,7.2,0,0,9.7,77777,9,999999999,110,0.2010,0,88,999.000,999.0,99.0
+1977,2,10,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,0.6,76,99200,0,0,265,0,0,0,0,0,0,0,230,5.2,0,0,9.7,77777,9,999999999,110,0.2010,0,88,999.000,999.0,99.0
+1977,2,10,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,0.6,76,99200,0,0,265,0,0,0,0,0,0,0,230,5.2,0,0,9.7,77777,9,999999999,110,0.2010,0,88,999.000,999.0,99.0
+1977,2,11,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,0.6,79,99200,0,0,263,0,0,0,0,0,0,0,230,7.7,0,0,9.7,77777,9,999999999,110,0.2010,0,88,999.000,999.0,99.0
+1977,2,11,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,0.6,79,99200,0,0,263,0,0,0,0,0,0,0,240,5.2,0,0,8.0,77777,9,999999999,110,0.2010,0,88,999.000,999.0,99.0
+1977,2,11,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,0.6,79,99200,0,0,263,0,0,0,0,0,0,0,240,5.2,0,0,6.4,77777,9,999999999,110,0.2010,0,88,999.000,999.0,99.0
+1977,2,11,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,0.6,85,99200,0,0,259,0,0,0,0,0,0,0,240,4.1,0,0,6.4,77777,9,999999999,110,0.2010,0,88,999.000,999.0,99.0
+1977,2,11,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-0.6,79,99200,0,0,258,0,0,0,0,0,0,0,230,4.1,0,0,8.0,77777,9,999999999,100,0.2010,0,88,999.000,999.0,99.0
+1977,2,11,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-1.1,82,99300,0,0,254,0,0,0,0,0,0,0,240,3.1,0,0,6.4,77777,9,999999999,100,0.2010,0,88,999.000,999.0,99.0
+1977,2,11,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-1.7,82,99300,1,129,259,0,0,0,0,0,0,0,230,4.1,3,2,4.0,77777,9,999999999,100,0.1490,0,88,999.000,999.0,99.0
+1977,2,11,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-0.6,85,99400,140,1404,262,46,72,39,5000,4000,4600,810,230,3.1,5,2,4.8,77777,9,999999999,100,0.1490,0,88,999.000,999.0,99.0
+1977,2,11,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,1.1,86,99400,369,1404,270,181,251,115,19000,21400,13300,2330,240,4.6,5,2,6.4,77777,9,999999999,110,0.1490,0,88,999.000,999.0,99.0
+1977,2,11,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,2.2,79,99400,560,1404,283,345,484,152,35800,46300,17300,3030,250,4.6,7,3,8.0,77777,9,999999999,120,0.1490,0,88,999.000,999.0,99.0
+1977,2,11,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,1.7,68,99400,698,1404,283,467,601,168,49400,60200,19400,3540,270,4.1,7,1,9.7,77777,9,999999999,120,0.1490,0,88,999.000,999.0,99.0
+1977,2,11,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,1.1,59,99400,773,1404,293,522,551,219,54600,55800,23700,4950,260,5.2,9,2,12.9,77777,9,999999999,120,0.1490,0,88,999.000,999.0,99.0
+1977,2,11,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,1.1,52,99400,780,1404,296,558,673,185,57400,65900,20700,3910,240,5.2,8,1,16.1,77777,9,999999999,110,0.1490,0,88,999.000,999.0,99.0
+1977,2,11,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,0.6,49,99400,719,1404,298,481,588,181,50900,59100,20500,3880,240,4.6,6,1,16.1,77777,9,999999999,110,0.1490,0,88,999.000,999.0,99.0
+1977,2,11,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,0.6,40,99400,593,1404,309,325,498,116,35100,48500,14600,2260,240,4.6,1,1,19.3,77777,9,999999999,110,0.1490,0,88,999.000,999.0,99.0
+1977,2,11,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,0.6,49,99400,412,1404,292,228,514,79,23700,44800,10400,1450,230,2.6,0,0,19.3,77777,9,999999999,110,0.1490,0,88,999.000,999.0,99.0
+1977,2,11,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,0.0,50,99400,190,1404,292,65,150,46,7000,8900,5800,850,0,0.0,3,1,19.3,77777,9,999999999,110,0.1490,0,88,999.000,999.0,99.0
+1977,2,11,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,-1.7,56,99400,10,433,281,3,2,2,0,0,0,0,180,3.1,3,2,19.3,77777,9,999999999,100,0.1490,0,88,999.000,999.0,99.0
+1977,2,11,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,-0.6,65,99400,0,0,269,0,0,0,0,0,0,0,170,3.6,0,0,19.3,77777,9,999999999,100,0.1490,0,88,999.000,999.0,99.0
+1977,2,11,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,-1.1,68,99400,0,0,272,0,0,0,0,0,0,0,180,3.6,2,2,19.3,77777,9,999999999,100,0.1490,0,88,999.000,999.0,99.0
+1977,2,11,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,0.6,73,99400,0,0,279,0,0,0,0,0,0,0,160,2.6,3,3,19.3,77777,9,999999999,110,0.1490,0,88,999.000,999.0,99.0
+1977,2,11,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,0.6,73,99300,0,0,309,0,0,0,0,0,0,0,160,2.6,10,10,19.3,2740,9,999999999,110,0.1490,0,88,999.000,999.0,99.0
+1977,2,11,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,1.1,76,99300,0,0,309,0,0,0,0,0,0,0,210,2.1,10,10,14.5,880,9,999999999,110,0.1490,0,88,999.000,999.0,99.0
+1977,2,11,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,2.2,79,99200,0,0,313,0,0,0,0,0,0,0,180,2.6,10,10,11.3,1010,9,999999999,120,0.1490,0,88,999.000,999.0,99.0
+1977,2,12,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,3.9,83,99100,0,0,320,0,0,0,0,0,0,0,190,3.1,10,10,6.4,880,9,999999999,139,0.1490,0,88,999.000,999.0,99.0
+1977,2,12,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,3.9,83,99000,0,0,320,0,0,0,0,0,0,0,200,4.6,10,10,6.4,1010,9,999999999,139,0.1490,0,88,999.000,999.0,99.0
+1977,2,12,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,3.3,80,99000,0,0,320,0,0,0,0,0,0,0,200,3.1,10,10,6.4,880,9,999999999,129,0.1490,0,88,999.000,999.0,99.0
+1977,2,12,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,2.2,76,98900,0,0,316,0,0,0,0,0,0,0,190,3.1,10,10,6.4,1160,9,999999999,120,0.1490,0,88,999.000,999.0,99.0
+1977,2,12,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,1.1,76,98800,0,0,309,0,0,0,0,0,0,0,170,3.6,10,10,6.4,2130,9,999999999,110,0.1490,0,88,999.000,999.0,99.0
+1977,2,12,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,0.0,73,98700,0,0,306,0,0,0,0,0,0,0,190,2.6,10,10,8.0,2130,9,999999999,110,0.1490,0,88,999.000,999.0,99.0
+1977,2,12,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,0.6,76,98600,1,152,306,0,0,0,0,0,0,0,200,4.1,10,10,6.4,2130,9,999999999,110,0.0890,0,88,999.000,999.0,99.0
+1977,2,12,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,1.7,79,98500,146,1404,310,25,1,25,2900,0,2900,900,200,5.2,10,10,6.4,1400,9,999999999,120,0.0890,0,88,999.000,999.0,99.0
+1977,2,12,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,1.7,76,98400,375,1404,313,98,0,98,11000,0,11000,3470,190,5.2,10,10,6.4,3050,9,999999999,120,0.0890,0,88,999.000,999.0,99.0
+1977,2,12,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,1.7,73,98300,566,1404,315,96,8,93,11300,500,11100,4010,200,5.7,10,10,6.4,5490,9,999999999,120,0.0890,0,88,999.000,999.0,99.0
+1977,2,12,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,2.8,76,98200,704,1404,319,124,8,120,14700,600,14400,5410,210,7.7,10,10,6.4,460,9,999999999,120,0.0890,0,88,999.000,999.0,99.0
+1977,2,12,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,2.8,79,98100,779,1404,316,239,4,236,27100,400,26900,9460,230,5.2,10,10,2.4,180,9,999999999,120,0.0890,0,88,999.000,999.0,99.0
+1977,2,12,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,1.1,79,98000,787,1404,307,148,6,145,17600,400,17300,6630,270,7.2,10,10,2.4,150,9,999999999,110,0.0890,0,88,999.000,999.0,99.0
+1977,2,12,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,0.6,82,97900,725,1404,301,263,2,262,29400,200,29300,9570,240,4.1,10,10,4.8,210,9,999999999,110,0.0890,0,88,999.000,999.0,99.0
+1977,2,12,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,1.1,79,97900,600,1404,287,263,183,186,28700,18200,20900,4430,270,9.3,7,7,12.9,1400,9,999999999,110,0.0890,0,88,999.000,999.0,99.0
+1977,2,12,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,-1.1,63,97900,418,1404,310,101,9,98,11400,500,11300,3660,260,6.7,10,10,14.5,1010,9,999999999,100,0.0890,0,88,999.000,999.0,99.0
+1977,2,12,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-1.7,65,97900,195,1404,304,58,4,57,6300,100,6300,1780,260,6.2,10,10,14.5,980,9,999999999,100,0.0890,0,88,999.000,999.0,99.0
+1977,2,12,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-2.2,62,97900,12,456,303,2,0,2,0,0,0,0,260,7.2,10,10,14.5,980,9,999999999,89,0.0890,0,88,999.000,999.0,99.0
+1977,2,12,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,-2.2,65,97900,0,0,301,0,0,0,0,0,0,0,260,7.2,10,10,24.1,1160,9,999999999,89,0.0890,0,88,999.000,999.0,99.0
+1977,2,12,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-2.2,67,97900,0,0,298,0,0,0,0,0,0,0,270,6.7,10,10,24.1,610,9,999999999,89,0.0890,0,88,999.000,999.0,99.0
+1977,2,12,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-2.2,70,97800,0,0,296,0,0,0,0,0,0,0,260,7.7,10,10,24.1,670,9,999999999,89,0.0890,0,88,999.000,999.0,99.0
+1977,2,12,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-2.2,70,97800,0,0,296,0,0,0,0,0,0,0,260,6.7,10,10,24.1,670,9,999999999,89,0.0890,0,88,999.000,999.0,99.0
+1977,2,12,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-3.9,62,97800,0,0,294,0,0,0,0,0,0,0,260,5.7,10,10,24.1,760,9,999999999,80,0.0890,0,88,999.000,999.0,99.0
+1977,2,12,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-4.4,62,97700,0,0,291,0,0,0,0,0,0,0,270,7.7,10,10,24.1,760,9,999999999,80,0.0890,0,88,999.000,999.0,99.0
+1977,2,13,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-4.4,61,97700,0,0,291,0,0,0,0,0,0,0,280,7.7,10,10,24.1,610,9,999999999,80,0.0890,0,88,999.000,999.0,99.0
+1977,2,13,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-3.9,64,97800,0,0,292,0,0,0,0,0,0,0,290,6.2,10,10,24.1,670,9,999999999,80,0.0890,0,88,999.000,999.0,99.0
+1977,2,13,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-5.0,62,97800,0,0,289,0,0,0,0,0,0,0,270,8.8,10,10,24.1,760,9,999999999,80,0.0890,0,88,999.000,999.0,99.0
+1977,2,13,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-5.6,59,97800,0,0,274,0,0,0,0,0,0,0,300,7.7,8,8,24.1,1160,9,999999999,80,0.0890,0,88,999.000,999.0,99.0
+1977,2,13,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-5.0,62,97800,0,0,289,0,0,0,0,0,0,0,290,7.2,10,10,24.1,1160,9,999999999,80,0.0890,0,88,999.000,999.0,99.0
+1977,2,13,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-6.7,57,97900,0,0,284,0,0,0,0,0,0,0,300,8.2,10,10,24.1,1160,9,999999999,69,0.0890,0,88,999.000,999.0,99.0
+1977,2,13,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-5.6,59,97900,2,199,288,1,0,1,0,0,0,0,300,8.2,10,10,24.1,850,9,999999999,80,0.0650,0,88,999.000,999.0,99.0
+1977,2,13,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-6.1,57,98000,151,1403,287,27,1,27,3100,0,3100,960,300,9.8,10,10,24.1,980,9,999999999,80,0.0650,0,88,999.000,999.0,99.0
+1977,2,13,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-5.0,62,98100,381,1403,289,117,7,115,12900,400,12800,3870,290,7.7,10,10,24.1,980,9,999999999,80,0.0650,0,88,999.000,999.0,99.0
+1977,2,13,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-3.3,70,98100,573,1403,290,159,2,158,17900,200,17900,6010,290,6.2,10,10,19.3,980,9,999999999,89,0.0650,0,88,999.000,999.0,99.0
+1977,2,13,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-5.0,59,98100,711,1403,291,231,5,229,26100,400,25900,8730,290,6.2,10,10,19.3,670,9,999999999,80,0.0650,0,88,999.000,999.0,99.0
+1977,2,13,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-6.1,57,98100,786,1403,287,268,1,268,30300,100,30200,10290,290,8.2,10,10,24.1,760,9,999999999,80,0.0650,0,88,999.000,999.0,99.0
+1977,2,13,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-5.0,62,98100,793,1403,289,267,2,266,30200,200,30100,10310,290,7.2,10,10,16.1,670,9,999999999,80,0.0650,0,88,999.000,999.0,99.0
+1977,2,13,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-5.6,59,98100,732,1403,288,239,0,239,26900,0,26900,9140,300,7.2,10,10,19.3,760,9,999999999,80,0.0650,0,88,999.000,999.0,99.0
+1977,2,13,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-5.6,57,98100,606,1403,276,200,147,137,22200,14800,15800,3270,270,6.7,8,8,24.1,850,9,999999999,80,0.0650,0,88,999.000,999.0,99.0
+1977,2,13,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-6.1,55,98200,424,1403,264,237,559,70,24900,49600,9800,1320,280,8.8,4,4,24.1,77777,9,999999999,80,0.0650,0,88,999.000,999.0,99.0
+1977,2,13,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-6.1,57,98200,201,1403,260,82,253,47,8700,16000,6400,850,290,5.2,3,3,24.1,77777,9,999999999,80,0.0650,0,88,999.000,999.0,99.0
+1977,2,13,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-6.1,59,98200,13,479,255,9,22,6,0,0,0,0,280,3.1,3,2,24.1,77777,9,999999999,69,0.0650,0,88,999.000,999.0,99.0
+1977,2,13,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-6.7,64,98300,0,0,240,0,0,0,0,0,0,0,240,2.1,0,0,24.1,77777,9,999999999,69,0.0650,0,88,999.000,999.0,99.0
+1977,2,13,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-7.2,66,98300,0,0,236,0,0,0,0,0,0,0,230,2.1,0,0,24.1,77777,9,999999999,69,0.0650,0,88,999.000,999.0,99.0
+1977,2,13,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-6.1,69,98300,0,0,247,0,0,0,0,0,0,0,250,2.6,2,2,24.1,77777,9,999999999,69,0.0650,0,88,999.000,999.0,99.0
+1977,2,13,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.0,75,98300,0,0,248,0,0,0,0,0,0,0,260,2.6,2,2,24.1,77777,9,999999999,80,0.0650,0,88,999.000,999.0,99.0
+1977,2,13,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.6,72,98400,0,0,247,0,0,0,0,0,0,0,280,2.6,2,2,24.1,77777,9,999999999,80,0.0650,0,88,999.000,999.0,99.0
+1977,2,13,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-6.1,72,98400,0,0,273,0,0,0,0,0,0,0,290,2.6,10,10,24.1,2740,9,999999999,69,0.0650,0,88,999.000,999.0,99.0
+1977,2,14,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-6.1,72,98400,0,0,273,0,0,0,0,0,0,0,310,3.1,10,10,24.1,2740,9,999999999,69,0.0650,0,88,999.000,999.0,99.0
+1977,2,14,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-6.7,69,98400,0,0,273,0,0,0,0,0,0,0,320,4.1,10,10,24.1,3660,9,999999999,69,0.0650,0,88,999.000,999.0,99.0
+1977,2,14,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-6.7,69,98400,0,0,273,0,0,0,0,0,0,0,320,3.6,10,10,24.1,3660,9,999999999,69,0.0650,0,88,999.000,999.0,99.0
+1977,2,14,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-7.8,63,98400,0,0,272,0,0,0,0,0,0,0,320,3.6,10,10,24.1,2740,9,999999999,69,0.0650,0,88,999.000,999.0,99.0
+1977,2,14,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-7.8,63,98500,0,0,272,0,0,0,0,0,0,0,280,2.6,10,10,24.1,1160,9,999999999,69,0.0650,0,88,999.000,999.0,99.0
+1977,2,14,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-8.3,61,98600,0,0,271,0,0,0,0,0,0,0,290,4.1,10,10,24.1,980,9,999999999,69,0.0650,0,88,999.000,999.0,99.0
+1977,2,14,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-8.9,63,98700,3,222,266,1,0,1,0,0,0,0,310,5.2,10,10,24.1,1160,9,999999999,60,0.1340,0,88,999.000,999.0,99.0
+1977,2,14,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-10.6,53,98700,157,1403,254,37,20,35,4100,1300,3900,860,310,6.2,8,8,24.1,1160,9,999999999,60,0.1340,0,88,999.000,999.0,99.0
+1977,2,14,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-10.6,51,98800,387,1403,269,62,7,60,7200,300,7200,2430,280,6.2,10,10,24.1,1400,9,999999999,60,0.1340,0,88,999.000,999.0,99.0
+1977,2,14,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-11.1,49,98800,579,1403,268,170,8,166,19100,600,18800,6250,310,5.7,10,10,24.1,1400,9,999999999,60,0.1340,0,88,999.000,999.0,99.0
+1977,2,14,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-10.6,49,98800,717,1403,271,213,9,208,24200,800,23800,8270,320,6.2,10,10,24.1,1220,9,999999999,60,0.1340,0,88,999.000,999.0,99.0
+1977,2,14,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-11.7,45,98800,792,1403,270,261,11,255,29600,1000,29000,10050,320,7.2,10,10,24.1,1220,9,999999999,60,0.1340,0,88,999.000,999.0,99.0
+1977,2,14,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-11.7,45,98800,799,1403,270,238,2,237,27200,200,27100,9650,310,6.7,10,10,24.1,1220,9,999999999,60,0.1340,0,88,999.000,999.0,99.0
+1977,2,14,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-10.0,51,98800,738,1403,272,195,2,194,22400,200,22300,8020,340,7.7,10,10,3.2,310,9,999999999,60,0.1340,0,88,999.000,999.0,99.0
+1977,2,14,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-8.9,61,98900,612,1403,269,157,5,155,17900,400,17800,6160,320,6.2,10,10,16.1,1160,9,999999999,60,0.1340,0,88,999.000,999.0,99.0
+1977,2,14,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-10.6,53,99000,430,1403,260,144,47,129,15700,4300,14400,3360,330,9.3,9,9,24.1,1400,9,999999999,60,0.1340,0,88,999.000,999.0,99.0
+1977,2,14,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-11.1,53,99100,207,1403,264,53,37,48,5900,2700,5500,1190,320,8.8,10,10,24.1,1400,9,999999999,60,0.1340,0,88,999.000,999.0,99.0
+1977,2,14,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-11.1,55,99200,15,503,262,2,0,2,0,0,0,0,330,7.2,10,10,24.1,1400,9,999999999,60,0.1340,0,88,999.000,999.0,99.0
+1977,2,14,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-10.0,63,99300,0,0,261,0,0,0,0,0,0,0,320,4.6,10,10,24.1,1400,9,999999999,60,0.1340,0,88,999.000,999.0,99.0
+1977,2,14,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-10.6,63,99400,0,0,251,0,0,0,0,0,0,0,300,4.1,9,9,24.1,1400,9,999999999,60,0.1340,0,88,999.000,999.0,99.0
+1977,2,14,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-10.0,66,99400,0,0,259,0,0,0,0,0,0,0,300,4.6,10,10,24.1,760,9,999999999,60,0.1340,0,88,999.000,999.0,99.0
+1977,2,14,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-9.4,68,99500,0,0,259,0,0,0,0,0,0,0,300,4.1,10,10,24.1,850,9,999999999,60,0.1340,0,88,999.000,999.0,99.0
+1977,2,14,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-10.0,68,99500,0,0,257,0,0,0,0,0,0,0,350,6.2,10,10,19.3,850,9,999999999,60,0.1340,0,88,999.000,999.0,99.0
+1977,2,14,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-10.0,68,99500,0,0,257,0,0,0,0,0,0,0,360,7.2,10,10,8.0,1400,9,999999999,60,0.1340,0,88,999.000,999.0,99.0
+1977,2,15,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-11.7,62,99600,0,0,253,0,0,0,0,0,0,0,350,7.7,10,10,24.1,1160,9,999999999,60,0.1340,0,88,999.000,999.0,99.0
+1977,2,15,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-13.3,57,99600,0,0,249,0,0,0,0,0,0,0,330,8.2,10,10,24.1,980,9,999999999,50,0.1340,0,88,999.000,999.0,99.0
+1977,2,15,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-13.9,59,99700,0,0,245,0,0,0,0,0,0,0,330,7.2,10,10,24.1,980,9,999999999,50,0.1340,0,88,999.000,999.0,99.0
+1977,2,15,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-9.4,-15.6,61,99700,0,0,208,0,0,0,0,0,0,0,320,5.7,1,1,24.1,77777,9,999999999,50,0.1340,0,88,999.000,999.0,99.0
+1977,2,15,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.0,-16.1,61,99800,0,0,201,0,0,0,0,0,0,0,310,4.6,0,0,24.1,77777,9,999999999,40,0.1340,0,88,999.000,999.0,99.0
+1977,2,15,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.1,-17.2,61,99800,0,0,197,0,0,0,0,0,0,0,320,5.2,0,0,24.1,77777,9,999999999,40,0.1340,0,88,999.000,999.0,99.0
+1977,2,15,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.6,-17.2,58,99900,4,245,199,4,14,2,0,0,0,0,320,4.1,1,0,24.1,77777,9,999999999,40,0.0640,0,88,999.000,999.0,99.0
+1977,2,15,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.0,-18.9,49,99900,163,1402,199,73,385,28,7500,23400,4800,510,330,6.7,1,0,24.1,77777,9,999999999,40,0.0640,0,88,999.000,999.0,99.0
+1977,2,15,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.9,-17.8,49,100000,394,1402,203,242,662,57,24800,57800,8500,1070,330,7.2,4,0,24.1,77777,9,999999999,40,0.0640,0,88,999.000,999.0,99.0
+1977,2,15,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.2,-16.7,47,100000,585,1402,210,403,784,76,42000,74800,10600,1530,350,6.2,4,0,24.1,77777,9,999999999,40,0.0640,0,88,999.000,999.0,99.0
+1977,2,15,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.1,-15.6,48,100000,724,1402,214,523,841,90,55000,82700,12200,1940,310,6.7,4,0,24.1,77777,9,999999999,50,0.0640,0,88,999.000,999.0,99.0
+1977,2,15,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.6,-15.6,46,100000,799,1402,216,592,879,91,62900,87600,12800,2120,320,5.2,3,0,24.1,77777,9,999999999,50,0.0640,0,88,999.000,999.0,99.0
+1977,2,15,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-17.8,35,100000,806,1402,218,603,901,86,63000,88800,11800,1820,320,7.7,2,0,24.1,77777,9,999999999,40,0.0640,0,88,999.000,999.0,99.0
+1977,2,15,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-17.8,35,100000,744,1402,218,548,885,81,57600,86600,11400,1670,360,6.7,2,0,24.1,77777,9,999999999,40,0.0640,0,88,999.000,999.0,99.0
+1977,2,15,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-17.8,35,100000,618,1402,218,437,852,63,46100,81800,9900,1380,10,4.6,0,0,24.1,77777,9,999999999,40,0.0640,0,88,999.000,999.0,99.0
+1977,2,15,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-17.2,37,100000,436,1402,218,276,741,49,29400,67200,8400,1030,10,3.6,0,0,24.1,77777,9,999999999,40,0.0640,0,88,999.000,999.0,99.0
+1977,2,15,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.6,-17.8,38,100000,212,1402,214,103,482,32,10600,34700,5400,600,350,5.2,0,0,24.1,77777,9,999999999,40,0.0640,0,88,999.000,999.0,99.0
+1977,2,15,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.2,-17.8,43,100100,17,549,209,12,46,7,0,0,0,0,350,4.1,0,0,24.1,77777,9,999999999,40,0.0640,0,88,999.000,999.0,99.0
+1977,2,15,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-16.7,47,100100,0,0,210,0,0,0,0,0,0,0,340,4.6,0,0,24.1,77777,9,999999999,40,0.0640,0,88,999.000,999.0,99.0
+1977,2,15,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-16.7,51,100100,0,0,206,0,0,0,0,0,0,0,330,5.2,0,0,24.1,77777,9,999999999,40,0.0640,0,88,999.000,999.0,99.0
+1977,2,15,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-16.7,54,100100,0,0,204,0,0,0,0,0,0,0,340,4.1,0,0,24.1,77777,9,999999999,40,0.0640,0,88,999.000,999.0,99.0
+1977,2,15,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-9.4,-17.2,54,100100,0,0,202,0,0,0,0,0,0,0,350,4.1,0,0,24.1,77777,9,999999999,40,0.0640,0,88,999.000,999.0,99.0
+1977,2,15,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.0,-17.2,56,100100,0,0,200,0,0,0,0,0,0,0,340,3.1,0,0,24.1,77777,9,999999999,40,0.0640,0,88,999.000,999.0,99.0
+1977,2,15,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.1,-17.8,58,100100,0,0,197,0,0,0,0,0,0,0,330,2.6,0,0,24.1,77777,9,999999999,40,0.0640,0,88,999.000,999.0,99.0
+1977,2,16,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.1,-16.7,64,100000,0,0,198,0,0,0,0,0,0,0,340,3.1,0,0,24.1,77777,9,999999999,40,0.0640,0,88,999.000,999.0,99.0
+1977,2,16,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.7,-17.8,61,100000,0,0,195,0,0,0,0,0,0,0,340,2.1,0,0,24.1,77777,9,999999999,40,0.0640,0,88,999.000,999.0,99.0
+1977,2,16,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.8,-17.8,67,100000,0,0,192,0,0,0,0,0,0,0,300,2.6,0,0,24.1,77777,9,999999999,40,0.0640,0,88,999.000,999.0,99.0
+1977,2,16,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.8,-17.2,70,100000,0,0,192,0,0,0,0,0,0,0,280,2.1,0,0,24.1,77777,9,999999999,40,0.0640,0,88,999.000,999.0,99.0
+1977,2,16,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.2,-17.2,67,100000,0,0,194,0,0,0,0,0,0,0,300,1.5,0,0,24.1,77777,9,999999999,40,0.0640,0,88,999.000,999.0,99.0
+1977,2,16,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-13.3,-17.8,70,100000,0,0,190,0,0,0,0,0,0,0,290,1.5,0,0,24.1,77777,9,999999999,40,0.0640,0,88,999.000,999.0,99.0
+1977,2,16,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-11.7,-15.0,77,100000,5,292,227,1,0,1,0,0,0,0,290,2.1,10,10,24.1,1160,9,999999999,50,0.0460,0,88,999.000,999.0,99.0
+1977,2,16,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.0,-15.0,67,100100,169,1401,222,60,76,51,6500,4600,5900,1070,290,1.5,8,8,24.1,1220,9,999999999,50,0.0460,0,88,999.000,999.0,99.0
+1977,2,16,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-15.6,54,100100,400,1401,223,150,221,87,16200,19600,10600,1650,340,3.1,6,6,24.1,1220,9,999999999,50,0.0460,0,88,999.000,999.0,99.0
+1977,2,16,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.7,-16.1,47,100100,592,1401,219,380,736,69,40000,70700,10000,1460,290,2.1,2,2,24.1,77777,9,999999999,40,0.0460,0,88,999.000,999.0,99.0
+1977,2,16,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.6,-15.6,46,100100,730,1401,223,518,834,83,54900,82400,11800,1860,270,4.1,2,2,24.1,77777,9,999999999,50,0.0460,0,88,999.000,999.0,99.0
+1977,2,16,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-17.8,35,100000,805,1401,222,584,907,63,61600,89600,9900,1640,290,3.6,1,1,24.1,77777,9,999999999,40,0.0460,0,88,999.000,999.0,99.0
+1977,2,16,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.9,-17.8,33,99900,812,1401,223,576,899,57,61100,88900,9400,1560,240,4.1,1,1,24.1,77777,9,999999999,40,0.0460,0,88,999.000,999.0,99.0
+1977,2,16,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.9,-17.2,35,99900,751,1401,224,525,843,75,55200,82600,10700,1660,290,2.1,1,1,24.1,77777,9,999999999,40,0.0460,0,88,999.000,999.0,99.0
+1977,2,16,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-17.8,32,99800,624,1401,221,425,845,51,45200,81400,8900,1290,280,3.1,0,0,24.1,77777,9,999999999,40,0.0460,0,88,999.000,999.0,99.0
+1977,2,16,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-18.3,31,99800,442,1401,221,280,764,42,30000,69500,8000,1010,290,4.1,0,0,24.1,77777,9,999999999,40,0.0460,0,88,999.000,999.0,99.0
+1977,2,16,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-17.8,35,99800,218,1401,218,109,534,29,11500,39100,5400,580,230,3.6,1,0,24.1,77777,9,999999999,40,0.0460,0,88,999.000,999.0,99.0
+1977,2,16,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.1,-17.8,40,99800,19,572,212,16,71,8,0,0,0,0,260,3.1,1,0,24.1,77777,9,999999999,40,0.0460,0,88,999.000,999.0,99.0
+1977,2,16,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-15.6,50,99800,0,0,212,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,50,0.0460,0,88,999.000,999.0,99.0
+1977,2,16,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-13.9,62,99800,0,0,210,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,50,0.0460,0,88,999.000,999.0,99.0
+1977,2,16,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-15.0,62,99800,0,0,206,0,0,0,0,0,0,0,240,2.1,0,0,24.1,77777,9,999999999,50,0.0460,0,88,999.000,999.0,99.0
+1977,2,16,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-15.0,59,99700,0,0,208,0,0,0,0,0,0,0,230,1.5,0,0,24.1,77777,9,999999999,50,0.0460,0,88,999.000,999.0,99.0
+1977,2,16,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-9.4,-16.7,56,99600,0,0,203,0,0,0,0,0,0,0,180,2.6,0,0,24.1,77777,9,999999999,40,0.0460,0,88,999.000,999.0,99.0
+1977,2,16,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.6,-17.2,58,99600,0,0,199,0,0,0,0,0,0,0,200,2.1,0,0,24.1,77777,9,999999999,40,0.0460,0,88,999.000,999.0,99.0
+1977,2,17,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-9.4,-15.0,64,99600,0,0,216,0,0,0,0,0,0,0,190,2.6,7,5,24.1,7620,9,999999999,50,0.0460,0,88,999.000,999.0,99.0
+1977,2,17,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-15.6,59,99500,0,0,212,0,0,0,0,0,0,0,180,3.1,3,2,24.1,77777,9,999999999,50,0.0460,0,88,999.000,999.0,99.0
+1977,2,17,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-16.1,52,99500,0,0,215,0,0,0,0,0,0,0,200,3.1,2,2,24.1,77777,9,999999999,50,0.0460,0,88,999.000,999.0,99.0
+1977,2,17,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-16.7,49,99400,0,0,215,0,0,0,0,0,0,0,200,4.1,2,2,24.1,77777,9,999999999,40,0.0460,0,88,999.000,999.0,99.0
+1977,2,17,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-13.9,62,99400,0,0,217,0,0,0,0,0,0,0,190,4.1,2,2,24.1,77777,9,999999999,50,0.0460,0,88,999.000,999.0,99.0
+1977,2,17,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-17.2,49,99400,0,0,210,0,0,0,0,0,0,0,190,4.1,1,1,24.1,77777,9,999999999,40,0.0460,0,88,999.000,999.0,99.0
+1977,2,17,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-13.3,65,99400,6,315,217,1,2,1,0,0,0,0,200,3.6,2,2,24.1,77777,9,999999999,50,0.1350,0,88,999.000,999.0,99.0
+1977,2,17,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.7,-13.3,60,99400,175,1401,231,31,29,27,3400,1800,3200,570,190,5.2,7,7,24.1,2440,9,999999999,50,0.1350,0,88,999.000,999.0,99.0
+1977,2,17,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.0,-11.7,60,99400,406,1401,248,109,43,96,11900,3900,10800,2600,190,6.2,9,9,24.1,1680,9,999999999,60,0.1350,0,88,999.000,999.0,99.0
+1977,2,17,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-9.4,63,99300,598,1401,264,122,8,119,14200,500,14000,5010,200,6.7,10,10,24.1,1370,9,999999999,60,0.1350,0,88,999.000,999.0,99.0
+1977,2,17,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-8.3,56,99200,737,1401,268,307,65,272,33600,6600,30100,7930,190,8.2,10,9,19.3,1370,9,999999999,69,0.1350,0,88,999.000,999.0,99.0
+1977,2,17,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-7.8,52,99200,812,1401,275,319,71,278,35100,7200,30900,8650,200,8.8,10,9,19.3,1370,9,999999999,69,0.1350,0,88,999.000,999.0,99.0
+1977,2,17,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-8.3,48,99000,819,1401,277,344,264,191,37900,28100,21400,4490,190,8.2,10,9,19.3,1370,9,999999999,69,0.1350,0,88,999.000,999.0,99.0
+1977,2,17,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-7.8,48,98900,757,1401,288,179,8,175,20800,600,20500,7550,200,6.7,10,10,19.3,1160,9,999999999,69,0.1350,0,88,999.000,999.0,99.0
+1977,2,17,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-7.2,46,98800,631,1401,285,201,57,175,22100,5600,19500,5140,200,7.7,9,9,24.1,7620,9,999999999,69,0.1350,0,88,999.000,999.0,99.0
+1977,2,17,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-7.2,48,98700,448,1401,291,50,5,48,6000,200,5900,2100,170,7.2,10,10,24.1,7620,9,999999999,69,0.1350,0,88,999.000,999.0,99.0
+1977,2,17,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-6.7,52,98700,224,1401,289,32,17,29,3500,1300,3300,790,170,8.2,10,10,19.3,7620,9,999999999,69,0.1350,0,88,999.000,999.0,99.0
+1977,2,17,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-6.7,54,98800,21,595,287,6,0,6,0,0,0,0,190,5.2,10,10,19.3,7620,9,999999999,69,0.1350,0,88,999.000,999.0,99.0
+1977,2,17,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-6.1,59,98800,0,0,271,0,0,0,0,0,0,0,180,6.2,8,8,24.1,7620,9,999999999,80,0.1350,0,88,999.000,999.0,99.0
+1977,2,17,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-5.6,64,98800,0,0,276,0,0,0,0,0,0,0,180,5.7,9,9,24.1,7620,9,999999999,80,0.1350,0,88,999.000,999.0,99.0
+1977,2,17,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-5.0,67,98700,0,0,276,0,0,0,0,0,0,0,180,4.6,10,9,19.3,2740,9,999999999,80,0.1350,0,88,999.000,999.0,99.0
+1977,2,17,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-4.4,67,98700,0,0,287,0,0,0,0,0,0,0,180,4.6,10,10,19.3,2740,9,999999999,80,0.1350,0,88,999.000,999.0,99.0
+1977,2,17,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-3.9,70,98700,0,0,287,0,0,0,0,0,0,0,180,3.6,10,10,19.3,1220,9,999999999,89,0.1350,0,88,999.000,999.0,99.0
+1977,2,17,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-3.3,73,98600,0,0,288,0,0,0,0,0,0,0,180,4.1,10,10,16.1,490,9,999999999,89,0.1350,0,88,999.000,999.0,99.0
+1977,2,18,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-3.3,73,98500,0,0,288,0,0,0,0,0,0,0,180,5.2,10,10,11.3,400,9,999999999,89,0.1350,0,88,999.000,999.0,99.0
+1977,2,18,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-2.8,76,98500,0,0,288,0,0,0,0,0,0,0,180,2.1,10,10,8.0,850,9,999999999,89,0.1350,0,88,999.000,999.0,99.0
+1977,2,18,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-2.8,76,98500,0,0,288,0,0,0,0,0,0,0,210,3.1,10,10,8.0,850,9,999999999,89,0.1350,0,88,999.000,999.0,99.0
+1977,2,18,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-3.3,79,98500,0,0,283,0,0,0,0,0,0,0,190,2.6,10,10,6.4,180,9,999999999,89,0.1350,0,88,999.000,999.0,99.0
+1977,2,18,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-4.4,82,98500,0,0,253,0,0,0,0,0,0,0,210,2.1,6,5,3.2,180,9,999999999,80,0.1350,0,88,999.000,999.0,99.0
+1977,2,18,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-2.8,89,98600,0,0,279,0,0,0,0,0,0,0,260,3.1,10,10,0.4,60,9,999999999,89,0.1350,0,88,999.000,999.0,99.0
+1977,2,18,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-2.2,89,98600,7,362,282,2,0,2,0,0,0,0,260,2.1,10,10,0.4,60,9,999999999,89,0.1290,0,88,999.000,999.0,99.0
+1977,2,18,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-1.7,92,98700,182,1400,282,34,0,34,3900,0,3900,1210,260,4.1,10,10,0.8,90,9,999999999,100,0.1290,0,88,999.000,999.0,99.0
+1977,2,18,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-1.7,89,98600,413,1400,285,112,3,111,12500,200,12500,3970,290,3.1,10,10,1.6,120,9,999999999,100,0.1290,0,88,999.000,999.0,99.0
+1977,2,18,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,0.6,92,98600,605,1400,260,372,605,111,38700,58000,13600,2200,270,3.6,4,1,4.8,77777,9,999999999,110,0.1290,0,88,999.000,999.0,99.0
+1977,2,18,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,0.0,73,98700,743,1400,276,399,419,177,42400,42400,19900,3850,270,3.6,8,3,8.0,77777,9,999999999,110,0.1290,0,88,999.000,999.0,99.0
+1977,2,18,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,-2.8,55,98700,819,1400,288,389,244,247,41900,25900,26700,6070,260,5.7,9,7,11.3,7620,9,999999999,89,0.1290,0,88,999.000,999.0,99.0
+1977,2,18,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,-3.3,51,98600,825,1400,280,477,468,202,50800,47900,22500,4710,260,5.7,8,3,12.9,77777,9,999999999,89,0.1290,0,88,999.000,999.0,99.0
+1977,2,18,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,-4.4,47,98600,763,1400,293,234,66,198,25800,6600,22200,6340,260,6.2,8,8,12.9,3660,9,999999999,80,0.1290,0,88,999.000,999.0,99.0
+1977,2,18,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,-5.0,44,98600,637,1400,291,261,212,166,28300,21600,18400,3550,280,6.7,7,7,12.9,6100,9,999999999,80,0.1290,0,88,999.000,999.0,99.0
+1977,2,18,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,-5.0,45,98600,454,1400,272,246,504,85,25700,45300,10900,1580,290,5.2,1,1,19.3,77777,9,999999999,80,0.1290,0,88,999.000,999.0,99.0
+1977,2,18,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,-5.6,47,98700,229,1400,267,95,290,49,10100,19800,6900,880,280,5.2,1,1,19.3,77777,9,999999999,80,0.1290,0,88,999.000,999.0,99.0
+1977,2,18,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-6.1,55,98700,24,618,256,9,12,8,0,0,0,0,280,3.6,1,1,19.3,77777,9,999999999,80,0.1290,0,88,999.000,999.0,99.0
+1977,2,18,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-5.0,64,98800,0,0,268,0,0,0,0,0,0,0,270,3.1,7,7,19.3,3350,9,999999999,80,0.1290,0,88,999.000,999.0,99.0
+1977,2,18,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-4.4,64,98900,0,0,281,0,0,0,0,0,0,0,260,2.6,9,9,19.3,1400,9,999999999,80,0.1290,0,88,999.000,999.0,99.0
+1977,2,18,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-4.4,67,98900,0,0,263,0,0,0,0,0,0,0,290,3.1,5,5,24.1,77777,9,999999999,80,0.1290,0,88,999.000,999.0,99.0
+1977,2,18,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-3.9,75,98900,0,0,250,0,0,0,0,0,0,0,350,4.1,3,1,24.1,77777,9,999999999,80,0.1290,0,88,999.000,999.0,99.0
+1977,2,18,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-5.0,72,98900,0,0,246,0,0,0,0,0,0,0,260,2.1,3,1,24.1,77777,9,999999999,80,0.1290,0,88,999.000,999.0,99.0
+1977,2,18,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-5.6,78,98900,0,0,250,0,0,0,0,0,0,0,250,2.6,5,5,24.1,77777,9,999999999,80,0.1290,0,88,999.000,999.0,99.0
+1977,2,19,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-5.6,78,98900,0,0,240,0,0,0,0,0,0,0,290,2.1,1,1,24.1,77777,9,999999999,80,0.1290,0,88,999.000,999.0,99.0
+1977,2,19,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-5.0,85,98900,0,0,257,0,0,0,0,0,0,0,320,3.1,9,8,16.1,1680,9,999999999,80,0.1290,0,88,999.000,999.0,99.0
+1977,2,19,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-5.0,82,98900,0,0,259,0,0,0,0,0,0,0,320,3.1,9,8,16.1,1680,9,999999999,80,0.1290,0,88,999.000,999.0,99.0
+1977,2,19,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-3.3,82,98900,0,0,281,0,0,0,0,0,0,0,320,1.5,10,10,16.1,1370,9,999999999,89,0.1290,0,88,999.000,999.0,99.0
+1977,2,19,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-3.9,78,99000,0,0,280,0,0,0,0,0,0,0,340,3.1,10,10,16.1,1370,9,999999999,80,0.1290,0,88,999.000,999.0,99.0
+1977,2,19,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-4.4,72,99000,0,0,282,0,0,0,0,0,0,0,320,4.1,10,10,19.3,1370,9,999999999,80,0.1290,0,88,999.000,999.0,99.0
+1977,2,19,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-4.4,72,99000,9,385,282,2,0,2,0,0,0,0,350,3.1,10,10,12.9,1370,9,999999999,80,0.1240,0,88,999.000,999.0,99.0
+1977,2,19,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-3.9,75,99000,188,1400,283,35,16,33,3900,1100,3700,850,330,5.2,10,10,6.4,520,9,999999999,80,0.1240,0,88,999.000,999.0,99.0
+1977,2,19,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-3.3,79,99000,420,1400,283,107,6,105,12000,400,11900,3850,340,5.2,10,10,3.2,400,9,999999999,89,0.1240,0,88,999.000,999.0,99.0
+1977,2,19,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-3.9,75,99100,612,1400,283,156,5,154,17800,400,17700,6140,40,5.7,10,10,8.0,520,9,999999999,80,0.1240,0,88,999.000,999.0,99.0
+1977,2,19,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-4.4,75,99200,750,1400,280,201,2,200,23100,200,23000,8280,10,6.2,10,10,8.0,400,9,999999999,80,0.1240,0,88,999.000,999.0,99.0
+1977,2,19,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-4.4,78,99200,825,1400,278,218,6,215,25300,500,25000,9200,360,7.2,10,10,6.4,400,9,999999999,80,0.1240,0,88,999.000,999.0,99.0
+1977,2,19,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-5.0,72,99200,832,1400,279,298,6,294,33600,600,33200,11340,10,6.7,10,10,9.7,370,9,999999999,80,0.1240,0,88,999.000,999.0,99.0
+1977,2,19,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-5.6,72,99200,770,1400,276,216,1,215,24700,100,24600,8840,350,6.7,10,10,3.2,310,9,999999999,80,0.1240,0,88,999.000,999.0,99.0
+1977,2,19,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-5.0,78,99200,643,1400,275,192,0,192,21700,0,21700,7340,10,5.2,10,10,1.6,270,9,999999999,80,0.1240,0,88,999.000,999.0,99.0
+1977,2,19,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-5.0,82,99300,460,1400,273,128,0,128,14300,0,14300,4620,350,5.2,10,10,4.0,460,9,999999999,80,0.1240,0,88,999.000,999.0,99.0
+1977,2,19,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-5.6,78,99300,235,1400,272,54,0,54,6100,0,6100,1870,340,3.1,10,10,4.0,490,9,999999999,80,0.1240,0,88,999.000,999.0,99.0
+1977,2,19,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-6.1,78,99400,26,665,269,11,0,11,1300,0,1300,390,350,4.1,10,10,4.0,520,9,999999999,80,0.1240,0,88,999.000,999.0,99.0
+1977,2,19,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-10.0,74,99400,0,0,228,0,0,0,0,0,0,0,310,3.1,3,3,24.1,77777,9,999999999,60,0.1240,0,88,999.000,999.0,99.0
+1977,2,19,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-10.6,74,99400,0,0,226,0,0,0,0,0,0,0,280,1.5,3,3,24.1,77777,9,999999999,60,0.1240,0,88,999.000,999.0,99.0
+1977,2,19,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-8.9,78,99400,0,0,255,0,0,0,0,0,0,0,270,1.5,10,10,24.1,980,9,999999999,60,0.1240,0,88,999.000,999.0,99.0
+1977,2,19,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-8.3,81,99400,0,0,256,0,0,0,0,0,0,0,240,2.6,10,10,19.3,1160,9,999999999,69,0.1240,0,88,999.000,999.0,99.0
+1977,2,19,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-8.3,78,99300,0,0,258,0,0,0,0,0,0,0,230,2.1,10,10,19.3,1160,9,999999999,69,0.1240,0,88,999.000,999.0,99.0
+1977,2,19,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-8.9,74,99300,0,0,258,0,0,0,0,0,0,0,240,2.1,10,10,24.1,1830,9,999999999,60,0.1240,0,88,999.000,999.0,99.0
+1977,2,20,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-8.9,74,99300,0,0,258,0,0,0,0,0,0,0,270,2.6,10,10,16.1,2440,9,999999999,60,0.1240,0,88,999.000,999.0,99.0
+1977,2,20,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-8.9,74,99200,0,0,258,0,0,0,0,0,0,0,270,2.6,10,10,16.1,2440,9,999999999,60,0.1240,0,88,999.000,999.0,99.0
+1977,2,20,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-9.4,71,99200,0,0,257,0,0,0,0,0,0,0,280,3.1,10,10,19.3,2440,9,999999999,60,0.1240,0,88,999.000,999.0,99.0
+1977,2,20,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-10.0,68,99200,0,0,250,0,0,0,0,0,0,0,300,2.1,10,9,19.3,2440,9,999999999,60,0.1240,0,88,999.000,999.0,99.0
+1977,2,20,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-12.2,65,99200,0,0,222,0,0,0,0,0,0,0,310,3.6,2,2,19.3,77777,9,999999999,50,0.1240,0,88,999.000,999.0,99.0
+1977,2,20,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-13.3,71,99200,0,0,214,0,0,0,0,0,0,0,290,2.6,2,2,19.3,77777,9,999999999,50,0.1240,0,88,999.000,999.0,99.0
+1977,2,20,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.0,-13.3,77,99200,10,408,204,8,18,5,0,0,0,0,290,2.1,0,0,19.3,77777,9,999999999,50,0.0890,0,88,999.000,999.0,99.0
+1977,2,20,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-11.1,77,99200,194,1399,212,90,381,37,9200,24900,5700,660,290,3.1,0,0,24.1,77777,9,999999999,60,0.0890,0,88,999.000,999.0,99.0
+1977,2,20,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.6,-10.0,71,99300,426,1399,220,263,662,62,27700,59200,9600,1200,320,3.1,0,0,24.1,77777,9,999999999,60,0.0890,0,88,999.000,999.0,99.0
+1977,2,20,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-8.3,69,99300,618,1399,230,428,784,81,44500,75400,11000,1640,340,2.1,0,0,24.1,77777,9,999999999,69,0.0890,0,88,999.000,999.0,99.0
+1977,2,20,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-6.7,69,99300,757,1399,249,458,364,261,48600,38100,27900,6330,350,3.1,5,4,24.1,77777,9,999999999,69,0.0890,0,88,999.000,999.0,99.0
+1977,2,20,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-7.2,64,99300,832,1399,267,217,72,175,24100,7200,19800,6020,350,4.1,9,9,24.1,760,9,999999999,69,0.0890,0,88,999.000,999.0,99.0
+1977,2,20,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-7.8,59,99200,839,1399,276,244,11,238,28100,1000,27500,9980,330,4.6,10,10,24.1,980,9,999999999,69,0.0890,0,88,999.000,999.0,99.0
+1977,2,20,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-10.0,49,99200,776,1399,274,273,11,267,30800,1000,30200,10200,340,5.7,10,10,24.1,1400,9,999999999,60,0.0890,0,88,999.000,999.0,99.0
+1977,2,20,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-7.2,64,99200,649,1399,275,157,7,154,18100,500,17800,6340,40,4.1,10,10,24.1,980,9,999999999,69,0.0890,0,88,999.000,999.0,99.0
+1977,2,20,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-7.2,69,99300,466,1399,263,136,38,123,14900,3500,13700,3360,10,3.6,10,9,12.9,1160,9,999999999,69,0.0890,0,88,999.000,999.0,99.0
+1977,2,20,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-7.2,72,99300,241,1399,268,57,3,57,6400,100,6400,1960,20,4.1,10,10,11.3,980,9,999999999,69,0.0890,0,88,999.000,999.0,99.0
+1977,2,20,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-8.3,69,99400,28,688,265,6,0,6,700,0,700,230,50,3.6,10,10,8.0,1370,9,999999999,69,0.0890,0,88,999.000,999.0,99.0
+1977,2,20,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-8.3,72,99400,0,0,263,0,0,0,0,0,0,0,30,3.1,10,10,9.7,1370,9,999999999,69,0.0890,0,88,999.000,999.0,99.0
+1977,2,20,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-8.9,69,99400,0,0,262,0,0,0,0,0,0,0,10,3.1,10,10,14.5,1830,9,999999999,60,0.0890,0,88,999.000,999.0,99.0
+1977,2,20,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-8.9,69,99400,0,0,262,0,0,0,0,0,0,0,10,2.6,10,10,16.1,1680,9,999999999,60,0.0890,0,88,999.000,999.0,99.0
+1977,2,20,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-8.9,71,99500,0,0,260,0,0,0,0,0,0,0,20,4.6,10,10,12.9,370,9,999999999,60,0.0890,0,88,999.000,999.0,99.0
+1977,2,20,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-9.4,71,99500,0,0,257,0,0,0,0,0,0,0,40,4.1,10,10,11.3,370,9,999999999,60,0.0890,0,88,999.000,999.0,99.0
+1977,2,20,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-11.1,68,99400,0,0,236,0,0,0,0,0,0,0,50,2.6,7,7,19.3,460,9,999999999,60,0.0890,0,88,999.000,999.0,99.0
+1977,2,21,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-11.1,71,99400,0,0,225,0,0,0,0,0,0,0,40,1.5,4,3,19.3,77777,9,999999999,60,0.0890,0,88,999.000,999.0,99.0
+1977,2,21,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-12.2,77,99400,0,0,212,0,0,0,0,0,0,0,0,0.0,1,1,19.3,77777,9,999999999,50,0.0890,0,88,999.000,999.0,99.0
+1977,2,21,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-9.4,-12.2,80,99400,0,0,206,0,0,0,0,0,0,0,0,0.0,0,0,16.1,77777,9,999999999,50,0.0890,0,88,999.000,999.0,99.0
+1977,2,21,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-9.4,-12.8,77,99400,0,0,206,0,0,0,0,0,0,0,0,0.0,0,0,16.1,77777,9,999999999,50,0.0890,0,88,999.000,999.0,99.0
+1977,2,21,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.7,-15.0,77,99400,0,0,197,0,0,0,0,0,0,0,0,0.0,0,0,16.1,77777,9,999999999,50,0.0890,0,88,999.000,999.0,99.0
+1977,2,21,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.1,-14.4,77,99300,0,0,199,0,0,0,0,0,0,0,0,0.0,0,0,16.1,77777,9,999999999,50,0.0890,0,88,999.000,999.0,99.0
+1977,2,21,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.3,-11.1,81,99300,12,454,215,7,12,6,0,0,0,0,180,2.1,4,1,14.5,77777,9,999999999,60,0.0930,0,88,999.000,999.0,99.0
+1977,2,21,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.7,-10.0,77,99300,201,1398,250,12,0,12,1500,0,1500,500,170,3.1,10,10,12.9,6100,9,999999999,60,0.0930,0,88,999.000,999.0,99.0
+1977,2,21,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.0,-8.9,74,99300,433,1398,245,164,133,123,17900,12200,14100,2760,190,3.1,10,8,9.7,6100,9,999999999,60,0.0930,0,88,999.000,999.0,99.0
+1977,2,21,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-6.7,75,99200,625,1398,243,379,545,135,40400,53600,16400,2700,170,5.2,8,3,11.3,77777,9,999999999,69,0.0930,0,88,999.000,999.0,99.0
+1977,2,21,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-7.2,64,99200,764,1398,250,475,581,157,49200,57300,17800,3380,210,6.2,10,4,12.9,77777,9,999999999,69,0.0930,0,88,999.000,999.0,99.0
+1977,2,21,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-9.4,51,99100,839,1398,261,394,247,246,42500,26300,26700,6110,210,7.2,10,8,12.9,4570,9,999999999,60,0.0930,0,88,999.000,999.0,99.0
+1977,2,21,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-8.9,52,99000,845,1398,277,236,20,224,27300,1700,26300,9610,200,7.7,10,10,12.9,4570,9,999999999,60,0.0930,0,88,999.000,999.0,99.0
+1977,2,21,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-8.3,50,98800,783,1398,283,189,7,185,21900,600,21600,8010,190,7.7,10,10,12.9,4570,9,999999999,69,0.0930,0,88,999.000,999.0,99.0
+1977,2,21,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-7.8,50,98700,655,1398,278,268,56,242,29400,5600,26800,6730,180,7.7,9,9,19.3,6100,9,999999999,69,0.0930,0,88,999.000,999.0,99.0
+1977,2,21,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-8.9,44,98400,472,1398,273,211,265,123,22700,25000,14200,2470,180,7.7,9,8,19.3,6100,9,999999999,60,0.0930,0,88,999.000,999.0,99.0
+1977,2,21,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-8.9,44,98300,246,1398,261,100,219,63,10700,15300,8000,1190,170,8.8,9,4,24.1,77777,9,999999999,60,0.0930,0,88,999.000,999.0,99.0
+1977,2,21,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-8.3,48,98200,31,711,255,8,12,7,900,500,900,140,170,9.3,5,2,24.1,77777,9,999999999,69,0.0930,0,88,999.000,999.0,99.0
+1977,2,21,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-7.8,54,98100,0,0,244,0,0,0,0,0,0,0,180,8.8,0,0,24.1,77777,9,999999999,69,0.0930,0,88,999.000,999.0,99.0
+1977,2,21,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-6.7,59,98000,0,0,245,0,0,0,0,0,0,0,170,8.2,0,0,24.1,77777,9,999999999,69,0.0930,0,88,999.000,999.0,99.0
+1977,2,21,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-6.1,61,98000,0,0,245,0,0,0,0,0,0,0,180,8.2,0,0,24.1,77777,9,999999999,69,0.0930,0,88,999.000,999.0,99.0
+1977,2,21,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-6.1,61,97800,0,0,245,0,0,0,0,0,0,0,180,8.2,0,0,24.1,77777,9,999999999,69,0.0930,0,88,999.000,999.0,99.0
+1977,2,21,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-5.6,62,97700,0,0,247,0,0,0,0,0,0,0,190,7.7,0,0,24.1,77777,9,999999999,80,0.0930,0,88,999.000,999.0,99.0
+1977,2,21,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-5.6,62,97600,0,0,247,0,0,0,0,0,0,0,180,6.7,0,0,24.1,77777,9,999999999,80,0.0930,0,88,999.000,999.0,99.0
+1977,2,22,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-5.0,64,97500,0,0,248,0,0,0,0,0,0,0,180,6.2,0,0,19.3,77777,9,999999999,80,0.0930,0,88,999.000,999.0,99.0
+1977,2,22,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-4.4,67,97400,0,0,248,0,0,0,0,0,0,0,180,5.7,0,0,19.3,77777,9,999999999,80,0.0930,0,88,999.000,999.0,99.0
+1977,2,22,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-5.0,64,97400,0,0,248,0,0,0,0,0,0,0,190,4.1,0,0,19.3,77777,9,999999999,80,0.0930,0,88,999.000,999.0,99.0
+1977,2,22,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-3.9,70,97300,0,0,249,0,0,0,0,0,0,0,180,4.1,1,0,19.3,77777,9,999999999,80,0.0930,0,88,999.000,999.0,99.0
+1977,2,22,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-3.9,70,97400,0,0,249,0,0,0,0,0,0,0,200,3.6,2,0,19.3,77777,9,999999999,80,0.0930,0,88,999.000,999.0,99.0
+1977,2,22,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-4.4,67,97400,0,0,253,0,0,0,0,0,0,0,240,3.6,4,1,19.3,77777,9,999999999,80,0.0930,0,88,999.000,999.0,99.0
+1977,2,22,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-4.4,70,97400,14,478,257,7,2,6,0,0,0,0,240,2.6,8,3,19.3,77777,9,999999999,80,0.1600,0,88,999.000,999.0,99.0
+1977,2,22,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-2.8,70,97500,207,1398,271,60,41,54,6600,3000,6100,1310,240,4.1,8,6,9.7,7620,9,999999999,89,0.1600,0,88,999.000,999.0,99.0
+1977,2,22,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-1.1,68,97600,440,1398,272,214,347,105,22400,31200,12600,1980,240,2.6,5,2,9.7,77777,9,999999999,100,0.1600,0,88,999.000,999.0,99.0
+1977,2,22,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,-2.2,53,97600,632,1398,290,305,251,192,32500,25500,20900,4230,320,2.6,8,6,12.9,7620,9,999999999,89,0.1600,0,88,999.000,999.0,99.0
+1977,2,22,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,-2.2,46,97700,770,1398,299,385,317,210,41600,33400,23200,4900,150,2.1,8,6,12.9,7620,9,999999999,89,0.1600,0,88,999.000,999.0,99.0
+1977,2,22,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,-2.2,44,97700,845,1398,310,347,107,282,38100,10900,31500,9030,100,2.1,9,8,12.9,7620,9,999999999,89,0.1600,0,88,999.000,999.0,99.0
+1977,2,22,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,-1.7,40,97700,852,1398,321,336,69,294,36900,7000,32600,9380,170,2.6,9,8,11.3,7620,9,999999999,100,0.1600,0,88,999.000,999.0,99.0
+1977,2,22,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,-2.8,46,97700,789,1398,305,358,187,254,39200,19400,28200,6650,50,4.1,9,8,9.7,7620,9,999999999,89,0.1600,0,88,999.000,999.0,99.0
+1977,2,22,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,-3.3,51,97800,661,1398,295,276,112,223,30300,11100,25000,6380,40,4.6,9,8,9.7,7620,9,999999999,89,0.1600,0,88,999.000,999.0,99.0
+1977,2,22,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-3.3,60,97900,478,1398,292,122,19,116,13900,1200,13500,4420,50,5.2,10,9,9.7,7620,9,999999999,89,0.1600,0,88,999.000,999.0,99.0
+1977,2,22,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-3.3,65,97900,252,1398,281,45,27,40,4900,2100,4600,1070,30,5.7,9,8,9.7,7620,9,999999999,89,0.1600,0,88,999.000,999.0,99.0
+1977,2,22,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-2.8,70,98000,34,734,293,7,0,7,800,0,800,270,40,7.2,10,10,8.0,7620,9,999999999,89,0.1600,0,88,999.000,999.0,99.0
+1977,2,22,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-2.8,70,98100,0,0,285,0,0,0,0,0,0,0,50,5.2,10,9,8.0,7620,9,999999999,89,0.1600,0,88,999.000,999.0,99.0
+1977,2,22,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-2.2,73,98000,0,0,294,0,0,0,0,0,0,0,50,3.6,10,10,11.3,1520,9,999999999,89,0.1600,0,88,999.000,999.0,99.0
+1977,2,22,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-1.7,73,98000,0,0,297,0,0,0,0,0,0,0,40,4.1,10,10,11.3,1520,9,999999999,100,0.1600,0,88,999.000,999.0,99.0
+1977,2,22,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-1.7,70,98000,0,0,299,0,0,0,0,0,0,0,40,3.6,10,10,11.3,980,9,999999999,100,0.1600,0,88,999.000,999.0,99.0
+1977,2,22,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-1.1,73,98000,0,0,300,0,0,0,0,0,0,0,40,3.6,10,10,11.3,1160,9,999999999,100,0.1600,0,88,999.000,999.0,99.0
+1977,2,22,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,-0.6,73,97900,0,0,303,0,0,0,0,0,0,0,30,2.1,10,10,11.3,7620,9,999999999,100,0.1600,0,88,999.000,999.0,99.0
+1977,2,23,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,0.0,73,97900,0,0,306,0,0,0,0,0,0,0,40,2.1,10,10,9.7,2740,9,999999999,110,0.1600,0,88,999.000,999.0,99.0
+1977,2,23,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,1.7,76,98100,0,0,313,0,0,0,0,0,0,0,110,3.1,10,10,8.0,2740,9,999999999,120,0.1600,0,88,999.000,999.0,99.0
+1977,2,23,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,2.2,76,97700,0,0,316,0,0,0,0,0,0,0,120,2.1,10,10,11.3,2440,9,999999999,120,0.1600,0,88,999.000,999.0,99.0
+1977,2,23,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,5.6,71,97700,0,0,340,0,0,0,0,0,0,0,170,5.2,10,10,11.3,2130,9,999999999,150,0.1600,0,88,999.000,999.0,99.0
+1977,2,23,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,4.4,69,97700,0,0,336,0,0,0,0,0,0,0,160,4.6,10,10,12.9,2440,9,999999999,139,0.1600,0,88,999.000,999.0,99.0
+1977,2,23,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,1.7,57,97600,0,0,333,0,0,0,0,0,0,0,160,5.2,10,10,12.9,2440,9,999999999,120,0.1600,0,88,999.000,999.0,99.0
+1977,2,23,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,-2.8,39,97600,16,524,330,5,0,5,0,0,0,0,160,6.7,10,10,12.9,2130,9,999999999,89,0.0930,0,88,999.000,999.0,99.0
+1977,2,23,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,7.8,77,97600,214,1397,332,68,148,46,7400,9600,5900,830,150,9.8,8,8,12.9,6100,9,999999999,170,0.0930,0,88,999.000,999.0,99.0
+1977,2,23,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,9.4,75,97600,446,1397,351,131,45,116,14300,4100,13000,3150,170,9.3,10,9,12.9,6100,9,999999999,189,0.0930,0,88,999.000,999.0,99.0
+1977,2,23,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,10.0,75,97500,639,1397,364,187,0,187,21100,0,21100,7190,180,6.7,10,10,12.9,880,9,999999999,189,0.0930,0,88,999.000,999.0,99.0
+1977,2,23,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,9.4,72,97400,777,1397,364,177,7,173,20600,500,20300,7590,160,7.7,10,10,12.9,700,9,999999999,179,0.0930,0,88,999.000,999.0,99.0
+1977,2,23,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,10.0,75,97300,852,1397,364,202,7,198,23600,600,23300,8820,140,7.7,10,10,11.3,700,9,999999999,189,0.0930,0,88,999.000,999.0,99.0
+1977,2,23,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,10.0,78,97300,858,1397,362,153,6,149,18300,400,18000,7060,160,7.2,10,10,6.4,700,9,999999999,189,0.0930,0,88,999.000,999.0,99.0
+1977,2,23,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,10.6,80,97200,795,1397,363,212,0,212,24400,0,24400,8930,170,5.7,10,10,14.5,1830,9,999999999,200,0.0930,0,88,999.000,999.0,99.0
+1977,2,23,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,11.1,83,97200,668,1397,363,132,4,130,15400,300,15300,5650,150,6.2,10,10,9.7,1680,9,999999999,200,0.0930,0,88,999.000,999.0,99.0
+1977,2,23,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,10.6,83,96900,484,1397,359,131,4,129,14700,300,14600,4780,150,11.3,10,10,19.3,3050,9,999999999,200,0.0930,0,88,999.000,999.0,99.0
+1977,2,23,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,10.0,80,97000,257,1397,359,60,0,60,6700,0,6700,2090,150,10.3,10,10,19.3,3050,9,999999999,189,0.0930,0,88,999.000,999.0,99.0
+1977,2,23,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,9.4,80,97000,36,780,356,11,0,11,1300,0,1300,400,150,9.3,10,10,19.3,1680,9,999999999,179,0.0930,0,88,999.000,999.0,99.0
+1977,2,23,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,8.3,75,97000,0,0,354,0,0,0,0,0,0,0,150,10.3,10,10,19.3,1680,9,999999999,170,0.0930,0,88,999.000,999.0,99.0
+1977,2,23,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,7.8,75,96900,0,0,351,0,0,0,0,0,0,0,150,11.3,10,10,19.3,700,9,999999999,170,0.0930,0,88,999.000,999.0,99.0
+1977,2,23,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,7.2,74,96900,0,0,348,0,0,0,0,0,0,0,160,10.3,10,10,19.3,580,9,999999999,160,0.0930,0,88,999.000,999.0,99.0
+1977,2,23,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,7.2,77,96800,0,0,345,0,0,0,0,0,0,0,160,7.7,10,10,9.7,460,9,999999999,160,0.0930,0,88,999.000,999.0,99.0
+1977,2,23,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,7.8,83,96700,0,0,343,0,0,0,0,0,0,0,160,8.8,10,10,19.3,460,9,999999999,170,0.0930,0,88,999.000,999.0,99.0
+1977,2,23,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,7.8,83,96600,0,0,343,0,0,0,0,0,0,0,170,8.2,10,10,19.3,520,9,999999999,170,0.0930,0,88,999.000,999.0,99.0
+1977,2,24,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,7.8,83,96500,0,0,343,0,0,0,0,0,0,0,170,8.2,10,10,19.3,460,9,999999999,170,0.0930,0,88,999.000,999.0,99.0
+1977,2,24,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,7.8,83,96400,0,0,343,0,0,0,0,0,0,0,180,8.2,10,10,16.1,490,9,999999999,170,0.0930,0,88,999.000,999.0,99.0
+1977,2,24,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,7.2,83,96300,0,0,339,0,0,0,0,0,0,0,180,7.7,10,10,16.1,1010,9,999999999,160,0.0930,0,88,999.000,999.0,99.0
+1977,2,24,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,6.7,83,96200,0,0,336,0,0,0,0,0,0,0,190,7.7,10,10,16.1,430,9,999999999,150,0.0930,0,88,999.000,999.0,99.0
+1977,2,24,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,6.7,83,96200,0,0,336,0,0,0,0,0,0,0,170,6.2,10,10,16.1,850,9,999999999,150,0.0930,0,88,999.000,999.0,99.0
+1977,2,24,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,6.1,83,96200,0,0,333,0,0,0,0,0,0,0,180,6.7,10,10,9.7,400,9,999999999,150,0.0930,0,88,999.000,999.0,99.0
+1977,2,24,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,4.4,89,96200,19,547,318,5,0,5,0,0,0,0,230,7.2,10,10,8.0,400,9,999999999,139,0.1930,0,88,999.000,999.0,99.0
+1977,2,24,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,1.7,86,96200,221,1396,305,33,0,33,3800,0,3800,1250,200,7.2,10,10,8.0,270,9,999999999,120,0.1930,0,88,999.000,999.0,99.0
+1977,2,24,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,1.1,82,96200,453,1396,305,120,1,119,13400,100,13400,4370,210,8.2,10,10,9.7,340,9,999999999,110,0.1930,0,88,999.000,999.0,99.0
+1977,2,24,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,1.7,92,96300,646,1396,300,186,1,185,21000,100,21000,7190,210,10.3,10,10,8.0,310,9,999999999,110,0.1930,0,88,999.000,999.0,99.0
+1977,2,24,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,0.0,85,96300,784,1396,296,244,1,244,27800,100,27700,9730,220,10.3,10,10,9.7,460,9,999999999,100,0.1930,0,88,999.000,999.0,99.0
+1977,2,24,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-0.6,82,96400,859,1396,295,286,1,285,32500,100,32400,11400,220,9.8,10,10,4.8,310,9,999999999,100,0.1930,0,88,999.000,999.0,99.0
+1977,2,24,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-1.1,85,96400,865,1396,290,290,1,289,32900,100,32900,11560,240,11.3,10,10,8.0,490,9,999999999,100,0.1930,0,88,999.000,999.0,99.0
+1977,2,24,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-2.2,79,96400,802,1396,289,267,1,267,30300,100,30200,10450,240,11.8,10,10,12.9,640,9,999999999,89,0.1930,0,88,999.000,999.0,99.0
+1977,2,24,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-2.8,73,96500,674,1396,291,205,1,204,23100,100,23100,7870,240,9.3,10,10,12.9,670,9,999999999,89,0.1930,0,88,999.000,999.0,99.0
+1977,2,24,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-3.3,75,96700,490,1396,286,134,0,134,15100,0,15100,4940,250,10.3,10,10,19.3,700,9,999999999,89,0.1930,0,88,999.000,999.0,99.0
+1977,2,24,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-3.9,72,96800,263,1396,285,61,0,61,6800,0,6800,2130,250,12.4,10,10,19.3,880,9,999999999,80,0.1930,0,88,999.000,999.0,99.0
+1977,2,24,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-3.3,73,96900,39,803,288,15,0,15,1700,0,1700,520,240,11.3,10,10,24.1,760,9,999999999,89,0.1930,0,88,999.000,999.0,99.0
+1977,2,24,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-3.3,73,97000,0,0,288,0,0,0,0,0,0,0,240,10.3,10,10,19.3,760,9,999999999,89,0.1930,0,88,999.000,999.0,99.0
+1977,2,24,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-3.9,70,97000,0,0,287,0,0,0,0,0,0,0,250,9.8,10,10,24.1,880,9,999999999,80,0.1930,0,88,999.000,999.0,99.0
+1977,2,24,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-3.3,70,97100,0,0,290,0,0,0,0,0,0,0,250,11.8,10,10,24.1,880,9,999999999,89,0.1930,0,88,999.000,999.0,99.0
+1977,2,24,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-4.4,67,97200,0,0,266,0,0,0,0,0,0,0,250,9.3,6,6,24.1,1010,9,999999999,80,0.1930,0,88,999.000,999.0,99.0
+1977,2,24,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-3.3,70,97200,0,0,290,0,0,0,0,0,0,0,250,8.2,10,10,24.1,1160,9,999999999,89,0.1930,0,88,999.000,999.0,99.0
+1977,2,24,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-2.8,70,97100,0,0,293,0,0,0,0,0,0,0,230,9.3,10,10,24.1,1370,9,999999999,89,0.1930,0,88,999.000,999.0,99.0
+1977,2,25,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-2.2,70,97200,0,0,296,0,0,0,0,0,0,0,240,10.8,10,10,24.1,1160,9,999999999,89,0.1930,0,88,999.000,999.0,99.0
+1977,2,25,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-3.3,65,97200,0,0,287,0,0,0,0,0,0,0,250,9.8,9,9,24.1,1160,9,999999999,89,0.1930,0,88,999.000,999.0,99.0
+1977,2,25,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-3.3,65,97300,0,0,287,0,0,0,0,0,0,0,260,11.8,9,9,24.1,1160,9,999999999,89,0.1930,0,88,999.000,999.0,99.0
+1977,2,25,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-4.4,64,97400,0,0,289,0,0,0,0,0,0,0,260,12.4,10,10,24.1,980,9,999999999,80,0.1930,0,88,999.000,999.0,99.0
+1977,2,25,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-5.0,64,97500,0,0,278,0,0,0,0,0,0,0,260,8.8,9,9,24.1,1160,9,999999999,80,0.1930,0,88,999.000,999.0,99.0
+1977,2,25,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-5.6,62,97600,0,0,260,0,0,0,0,0,0,0,250,11.3,4,4,24.1,77777,9,999999999,80,0.1930,0,88,999.000,999.0,99.0
+1977,2,25,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-6.1,61,97700,21,593,260,10,28,7,0,0,0,0,260,9.3,5,5,24.1,77777,9,999999999,69,0.0810,0,88,999.000,999.0,99.0
+1977,2,25,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-6.1,59,97900,228,1396,285,60,0,60,6700,0,6700,1980,250,12.4,10,10,24.1,980,9,999999999,69,0.0810,0,88,999.000,999.0,99.0
+1977,2,25,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-5.0,62,97900,460,1396,289,88,13,84,10200,700,10000,3410,260,11.8,10,10,24.1,910,9,999999999,80,0.0810,0,88,999.000,999.0,99.0
+1977,2,25,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-3.9,64,98000,653,1396,284,218,67,186,23900,6600,20800,5510,250,11.8,9,9,24.1,850,9,999999999,80,0.0810,0,88,999.000,999.0,99.0
+1977,2,25,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-4.4,59,98100,791,1396,275,466,437,219,48900,44400,23700,5030,250,10.3,7,7,24.1,850,9,999999999,80,0.0810,0,88,999.000,999.0,99.0
+1977,2,25,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-4.4,57,98200,866,1396,288,271,60,234,29900,6100,26100,7920,260,10.3,9,9,24.1,850,9,999999999,80,0.0810,0,88,999.000,999.0,99.0
+1977,2,25,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-3.9,60,98200,871,1396,297,270,27,253,31000,2400,29500,10660,250,11.3,10,10,24.1,980,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1977,2,25,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-3.3,60,98200,808,1396,300,194,6,191,22600,500,22400,8350,270,9.3,10,10,24.1,980,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1977,2,25,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-2.8,62,98300,680,1396,300,199,9,195,22600,700,22300,7690,250,11.3,10,10,24.1,980,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1977,2,25,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-2.8,60,98300,496,1396,303,159,1,159,17700,100,17700,5530,260,7.7,10,10,24.1,980,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1977,2,25,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-2.8,60,98400,269,1396,294,90,29,85,9900,2400,9400,2010,250,9.3,9,9,24.1,1160,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1977,2,25,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-2.8,62,98400,42,826,281,16,39,12,1600,1200,1500,200,270,7.2,7,7,24.1,1160,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1977,2,25,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-2.8,67,98500,0,0,267,0,0,0,0,0,0,0,250,6.7,3,3,24.1,77777,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1977,2,25,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-2.8,67,98500,0,0,256,0,0,0,0,0,0,0,250,7.2,0,0,24.1,77777,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1977,2,25,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-2.8,67,98700,0,0,256,0,0,0,0,0,0,0,250,6.2,0,0,24.1,77777,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1977,2,25,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-3.3,70,98800,0,0,260,0,0,0,0,0,0,0,230,4.1,2,2,24.1,77777,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1977,2,25,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-2.2,76,98800,0,0,292,0,0,0,0,0,0,0,250,5.2,10,10,24.1,880,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1977,2,25,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-2.8,73,98900,0,0,267,0,0,0,0,0,0,0,250,2.1,5,5,24.1,77777,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1977,2,26,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-3.9,70,99000,0,0,254,0,0,0,0,0,0,0,290,4.1,1,1,24.1,77777,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1977,2,26,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-5.0,67,99000,0,0,246,0,0,0,0,0,0,0,300,3.6,0,0,24.1,77777,9,999999999,80,0.0810,0,88,999.000,999.0,99.0
+1977,2,26,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-5.6,67,99000,0,0,243,0,0,0,0,0,0,0,280,2.6,0,0,24.1,77777,9,999999999,80,0.0810,0,88,999.000,999.0,99.0
+1977,2,26,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.6,72,98900,0,0,240,0,0,0,0,0,0,0,290,3.6,0,0,24.1,77777,9,999999999,80,0.0810,0,88,999.000,999.0,99.0
+1977,2,26,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-6.1,75,99100,0,0,235,0,0,0,0,0,0,0,240,2.6,0,0,24.1,77777,9,999999999,80,0.0810,0,88,999.000,999.0,99.0
+1977,2,26,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-6.1,78,99000,0,0,233,0,0,0,0,0,0,0,300,2.1,0,0,24.1,77777,9,999999999,80,0.0810,0,88,999.000,999.0,99.0
+1977,2,26,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-7.2,81,99200,24,639,245,8,1,7,0,0,0,0,220,3.1,9,7,16.1,7620,9,999999999,69,0.1530,0,88,999.000,999.0,99.0
+1977,2,26,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-4.4,82,99200,235,1395,255,83,49,75,9100,3800,8400,1740,260,2.1,9,6,16.1,7620,9,999999999,80,0.1530,0,88,999.000,999.0,99.0
+1977,2,26,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-3.9,72,99200,467,1395,277,109,36,97,12000,3300,10900,2770,330,2.6,10,9,19.3,7620,9,999999999,89,0.1530,0,88,999.000,999.0,99.0
+1977,2,26,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-5.6,62,99100,660,1395,285,92,10,87,11100,600,10800,4030,360,3.6,10,10,19.3,3050,9,999999999,80,0.1530,0,88,999.000,999.0,99.0
+1977,2,26,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-5.6,62,99100,798,1395,285,195,21,183,22700,1700,21800,8040,30,3.6,10,10,24.1,3050,9,999999999,80,0.1530,0,88,999.000,999.0,99.0
+1977,2,26,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-6.1,57,99000,872,1395,287,208,1,207,24300,100,24200,9230,40,3.1,10,10,19.3,3050,9,999999999,80,0.1530,0,88,999.000,999.0,99.0
+1977,2,26,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-5.6,59,99000,878,1395,288,216,8,211,25200,700,24800,9400,40,4.1,10,10,19.3,3050,9,999999999,80,0.1530,0,88,999.000,999.0,99.0
+1977,2,26,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-6.1,57,98800,814,1395,287,204,1,203,23600,100,23600,8780,30,5.7,10,10,19.3,2440,9,999999999,80,0.1530,0,88,999.000,999.0,99.0
+1977,2,26,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-7.2,56,98800,686,1395,282,198,4,196,22500,300,22300,7760,20,5.7,10,10,19.3,2440,9,999999999,69,0.1530,0,88,999.000,999.0,99.0
+1977,2,26,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-8.3,54,98900,501,1395,278,121,1,121,13800,100,13800,4670,30,5.2,10,10,19.3,2440,9,999999999,69,0.1530,0,88,999.000,999.0,99.0
+1977,2,26,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-8.9,54,98800,274,1395,275,63,0,63,7100,0,7100,2220,30,5.2,10,10,24.1,2440,9,999999999,60,0.1530,0,88,999.000,999.0,99.0
+1977,2,26,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-8.3,58,98800,45,849,274,17,0,17,1900,0,1900,580,20,7.2,10,10,24.1,2440,9,999999999,69,0.1530,0,88,999.000,999.0,99.0
+1977,2,26,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-7.8,61,98800,0,0,274,0,0,0,0,0,0,0,30,8.2,10,10,24.1,2440,9,999999999,69,0.1530,0,88,999.000,999.0,99.0
+1977,2,26,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-7.8,61,98800,0,0,274,0,0,0,0,0,0,0,20,5.2,10,10,19.3,2440,9,999999999,69,0.1530,0,88,999.000,999.0,99.0
+1977,2,26,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-7.2,66,98700,0,0,272,0,0,0,0,0,0,0,20,6.2,10,10,19.3,2440,9,999999999,69,0.1530,0,88,999.000,999.0,99.0
+1977,2,26,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-7.2,66,98600,0,0,272,0,0,0,0,0,0,0,20,8.8,10,10,19.3,2440,9,999999999,69,0.1530,0,88,999.000,999.0,99.0
+1977,2,26,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-7.2,66,98500,0,0,272,0,0,0,0,0,0,0,30,8.8,10,10,19.3,2130,9,999999999,69,0.1530,0,88,999.000,999.0,99.0
+1977,2,26,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-6.7,69,98400,0,0,273,0,0,0,0,0,0,0,10,10.3,10,10,19.3,2130,9,999999999,69,0.1530,0,88,999.000,999.0,99.0
+1977,2,27,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-6.7,69,98400,0,0,273,0,0,0,0,0,0,0,10,7.2,10,10,24.1,700,9,999999999,69,0.1530,0,88,999.000,999.0,99.0
+1977,2,27,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-7.2,66,98300,0,0,272,0,0,0,0,0,0,0,360,7.2,10,10,24.1,700,9,999999999,69,0.1530,0,88,999.000,999.0,99.0
+1977,2,27,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-6.1,72,98200,0,0,273,0,0,0,0,0,0,0,360,7.2,10,10,8.0,700,9,999999999,69,0.1530,0,88,999.000,999.0,99.0
+1977,2,27,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-6.1,75,98200,0,0,271,0,0,0,0,0,0,0,350,7.2,10,10,6.4,670,9,999999999,69,0.1530,0,88,999.000,999.0,99.0
+1977,2,27,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-5.6,81,98300,0,0,270,0,0,0,0,0,0,0,330,6.7,10,10,6.4,400,9,999999999,80,0.1530,0,88,999.000,999.0,99.0
+1977,2,27,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-5.6,81,98300,0,0,270,0,0,0,0,0,0,0,310,5.7,10,10,2.4,670,9,999999999,80,0.1530,0,88,999.000,999.0,99.0
+1977,2,27,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-5.6,85,98400,27,662,268,11,0,11,1300,0,1300,390,310,5.2,10,10,2.4,670,9,999999999,80,0.1740,0,88,999.000,999.0,99.0
+1977,2,27,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-5.6,85,98500,241,1394,268,71,0,71,7800,0,7800,2260,300,5.2,10,10,2.4,670,9,999999999,80,0.1740,0,88,999.000,999.0,99.0
+1977,2,27,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-5.0,85,98600,474,1394,263,129,35,117,14200,3300,13000,3250,310,5.7,10,9,4.8,910,9,999999999,80,0.1740,0,88,999.000,999.0,99.0
+1977,2,27,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-5.0,82,98600,667,1394,255,315,209,215,34200,21200,24100,5280,310,5.7,7,7,11.3,910,9,999999999,80,0.1740,0,88,999.000,999.0,99.0
+1977,2,27,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-6.1,69,98800,805,1394,268,292,77,248,32200,7800,27700,7890,300,5.2,9,9,11.3,700,9,999999999,69,0.1740,0,88,999.000,999.0,99.0
+1977,2,27,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-5.6,69,98800,879,1394,278,142,2,141,17100,100,17100,6810,300,6.7,10,10,12.9,700,9,999999999,80,0.1740,0,88,999.000,999.0,99.0
+1977,2,27,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-5.6,69,98800,884,1394,278,243,26,227,26900,2600,25200,7850,290,7.2,10,10,8.0,760,9,999999999,80,0.1740,0,88,999.000,999.0,99.0
+1977,2,27,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-5.6,67,98900,821,1394,281,225,9,220,26000,800,25500,9340,290,5.2,10,10,12.9,880,9,999999999,80,0.1740,0,88,999.000,999.0,99.0
+1977,2,27,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-5.0,69,99000,692,1394,282,202,3,201,23000,300,22900,7930,290,5.2,10,10,16.1,880,9,999999999,80,0.1740,0,88,999.000,999.0,99.0
+1977,2,27,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-4.4,72,99000,507,1394,282,123,5,122,14100,300,14000,4720,270,5.2,10,10,8.0,850,9,999999999,80,0.1740,0,88,999.000,999.0,99.0
+1977,2,27,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-4.4,72,99000,280,1394,282,56,2,56,6400,100,6400,2050,270,4.1,10,10,12.9,1680,9,999999999,80,0.1740,0,88,999.000,999.0,99.0
+1977,2,27,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-5.0,69,99100,48,895,282,15,0,15,1700,0,1700,530,270,3.6,10,10,16.1,2440,9,999999999,80,0.1740,0,88,999.000,999.0,99.0
+1977,2,27,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-4.4,75,99100,0,0,280,0,0,0,0,0,0,0,250,4.1,10,10,16.1,2130,9,999999999,80,0.1740,0,88,999.000,999.0,99.0
+1977,2,27,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-3.9,78,99200,0,0,280,0,0,0,0,0,0,0,270,4.1,10,10,19.3,2130,9,999999999,80,0.1740,0,88,999.000,999.0,99.0
+1977,2,27,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-4.4,75,99200,0,0,280,0,0,0,0,0,0,0,270,3.6,10,10,19.3,2130,9,999999999,80,0.1740,0,88,999.000,999.0,99.0
+1977,2,27,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.0,78,99200,0,0,254,0,0,0,0,0,0,0,240,3.6,7,6,19.3,2130,9,999999999,80,0.1740,0,88,999.000,999.0,99.0
+1977,2,27,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.0,78,99200,0,0,275,0,0,0,0,0,0,0,250,3.6,10,10,16.1,1370,9,999999999,80,0.1740,0,88,999.000,999.0,99.0
+1977,2,27,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.0,75,99300,0,0,277,0,0,0,0,0,0,0,250,4.1,10,10,16.1,1010,9,999999999,80,0.1740,0,88,999.000,999.0,99.0
+1977,2,28,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.6,75,99300,0,0,274,0,0,0,0,0,0,0,280,4.1,10,10,14.5,980,9,999999999,80,0.1740,0,88,999.000,999.0,99.0
+1977,2,28,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-6.7,72,99300,0,0,271,0,0,0,0,0,0,0,280,5.2,10,10,24.1,1160,9,999999999,69,0.1740,0,88,999.000,999.0,99.0
+1977,2,28,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-7.8,69,99300,0,0,267,0,0,0,0,0,0,0,280,5.2,10,10,24.1,1160,9,999999999,69,0.1740,0,88,999.000,999.0,99.0
+1977,2,28,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-8.9,69,99300,0,0,249,0,0,0,0,0,0,0,270,4.1,8,8,24.1,1160,9,999999999,60,0.1740,0,88,999.000,999.0,99.0
+1977,2,28,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-8.9,69,99300,0,0,262,0,0,0,0,0,0,0,250,2.1,10,10,24.1,980,9,999999999,60,0.1740,0,88,999.000,999.0,99.0
+1977,2,28,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-10.0,68,99300,0,0,236,0,0,0,0,0,0,0,240,3.1,5,5,24.1,77777,9,999999999,60,0.1740,0,88,999.000,999.0,99.0
+1977,2,28,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.7,-11.1,71,99300,30,708,223,13,16,11,1300,600,1300,230,230,3.1,7,2,19.3,77777,9,999999999,60,0.1130,0,88,999.000,999.0,99.0
+1977,2,28,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.9,-7.8,75,99400,248,1394,240,111,241,69,11800,17000,8700,1320,240,4.1,8,4,16.1,77777,9,999999999,69,0.1130,0,88,999.000,999.0,99.0
+1977,2,28,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-6.1,78,99400,481,1394,243,274,372,146,29000,35200,16800,3030,270,5.2,9,3,16.1,77777,9,999999999,80,0.1130,0,88,999.000,999.0,99.0
+1977,2,28,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-6.7,66,99400,674,1394,251,361,356,190,38900,36700,21100,4210,270,6.7,9,4,16.1,77777,9,999999999,69,0.1130,0,88,999.000,999.0,99.0
+1977,2,28,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-7.2,56,99400,812,1394,259,554,554,232,58000,56500,25000,5450,270,5.7,9,5,19.3,7620,9,999999999,69,0.1130,0,88,999.000,999.0,99.0
+1977,2,28,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-7.2,54,99400,886,1394,257,652,702,207,67500,69700,23100,4920,280,6.7,8,3,19.3,77777,9,999999999,69,0.1130,0,88,999.000,999.0,99.0
+1977,2,28,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-6.7,52,99400,891,1394,259,651,717,193,67700,71500,21800,4680,250,4.1,7,2,19.3,77777,9,999999999,69,0.1130,0,88,999.000,999.0,99.0
+1977,2,28,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-6.7,50,99300,827,1394,261,573,657,185,59500,65000,20800,4160,270,6.7,7,2,24.1,77777,9,999999999,69,0.1130,0,88,999.000,999.0,99.0
+1977,2,28,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-7.8,48,99300,698,1394,262,433,531,168,46000,53200,19200,3550,260,5.2,4,4,24.1,77777,9,999999999,69,0.1130,0,88,999.000,999.0,99.0
+1977,2,28,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-7.2,48,99200,513,1394,267,285,452,121,30300,42500,14600,2330,270,4.1,5,5,24.1,77777,9,999999999,69,0.1130,0,88,999.000,999.0,99.0
+1977,2,28,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-7.8,48,99200,285,1394,262,106,153,75,11200,11600,8900,1430,260,4.1,4,4,24.1,77777,9,999999999,69,0.1130,0,88,999.000,999.0,99.0
+1977,2,28,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-8.3,52,99200,52,917,251,19,32,16,2000,1400,1900,330,240,3.6,2,2,24.1,77777,9,999999999,69,0.1130,0,88,999.000,999.0,99.0
+1977,2,28,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-7.8,61,99300,0,0,238,0,0,0,0,0,0,0,240,3.1,0,0,24.1,77777,9,999999999,69,0.1130,0,88,999.000,999.0,99.0
+1977,2,28,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-6.7,69,99300,0,0,236,0,0,0,0,0,0,0,240,3.6,0,0,24.1,77777,9,999999999,69,0.1130,0,88,999.000,999.0,99.0
+1977,2,28,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-6.1,75,99300,0,0,235,0,0,0,0,0,0,0,240,3.1,0,0,24.1,77777,9,999999999,80,0.1130,0,88,999.000,999.0,99.0
+1977,2,28,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.3,-5.6,75,99300,0,0,239,0,0,0,0,0,0,0,240,3.5,0,0,24.1,77777,9,999999999,69,0.1130,0,88,999.000,999.0,99.0
+1977,2,28,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.5,-5.2,78,99300,0,0,242,0,0,0,0,0,0,0,260,3.8,0,0,24.1,77777,9,999999999,80,0.1130,0,88,999.000,999.0,99.0
+1977,2,28,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.2,-4.8,75,99300,0,0,245,0,0,0,0,0,0,0,270,4.2,0,0,24.1,77777,9,999999999,69,0.1130,0,88,999.000,999.0,99.0
+1985,3,1,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.9,-4.4,65,98800,0,0,248,0,0,0,0,0,0,0,230,4.6,0,0,24.1,77777,9,999999999,89,0.1130,0,88,999.000,999.0,99.0
+1985,3,1,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-4.0,65,98700,0,0,251,0,0,0,0,0,0,0,240,5.0,0,0,24.1,77777,9,999999999,89,0.1130,0,88,999.000,999.0,99.0
+1985,3,1,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.5,-3.6,62,98700,0,0,272,0,0,0,0,0,0,0,220,5.3,6,6,24.1,3660,9,999999999,89,0.1130,0,88,999.000,999.0,99.0
+1985,3,1,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-3.3,62,98600,0,0,297,0,0,0,0,0,0,0,240,5.7,10,10,24.1,3660,9,999999999,89,0.1130,0,88,999.000,999.0,99.0
+1985,3,1,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-2.8,65,98500,0,0,298,0,0,0,0,0,0,0,230,6.2,10,10,24.1,1520,9,999999999,89,0.1130,0,88,999.000,999.0,99.0
+1985,3,1,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-1.7,70,98500,0,0,299,0,0,0,0,0,0,0,230,5.7,10,10,24.1,1520,9,999999999,100,0.1130,0,88,999.000,999.0,99.0
+1985,3,1,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-1.1,73,98400,34,731,300,7,0,7,800,0,800,270,240,5.7,10,10,16.1,1160,9,999999999,100,0.0980,0,88,999.000,999.0,99.0
+1985,3,1,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,0.0,82,98400,256,1393,299,39,1,39,4500,0,4500,1500,240,7.2,10,10,8.0,700,9,999999999,110,0.0980,0,88,999.000,999.0,99.0
+1985,3,1,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,1.1,89,98300,489,1393,300,74,7,72,8800,400,8700,3080,220,5.7,10,10,6.4,240,9,999999999,110,0.0980,0,88,999.000,999.0,99.0
+1985,3,1,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,1.7,86,98300,681,1393,305,212,8,208,24000,700,23600,8030,240,6.2,10,10,8.0,210,9,999999999,120,0.0980,0,88,999.000,999.0,99.0
+1985,3,1,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,1.7,89,98300,819,1393,303,254,9,249,29000,800,28600,10160,250,7.2,10,10,6.4,150,9,999999999,120,0.0980,0,88,999.000,999.0,99.0
+1985,3,1,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,2.2,89,98300,893,1393,306,154,5,151,18500,400,18300,7260,250,7.2,10,10,6.4,150,9,999999999,120,0.0980,0,88,999.000,999.0,99.0
+1985,3,1,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,2.2,89,98300,898,1393,306,180,5,177,21400,400,21200,8290,250,6.7,10,10,6.4,150,9,999999999,120,0.0980,0,88,999.000,999.0,99.0
+1985,3,1,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,2.8,89,98300,833,1393,309,152,2,151,18100,100,18000,7050,260,5.7,10,10,1.6,90,9,999999999,120,0.0980,0,88,999.000,999.0,99.0
+1985,3,1,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,3.9,93,98300,704,1393,312,239,2,238,26800,200,26700,8920,260,5.2,10,10,3.2,120,9,999999999,129,0.0980,0,88,999.000,999.0,99.0
+1985,3,1,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,3.9,86,98400,519,1393,317,151,1,151,17000,100,16900,5530,270,6.2,10,10,4.8,240,9,999999999,129,0.0980,0,88,999.000,999.0,99.0
+1985,3,1,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,3.9,89,98400,291,1393,282,136,362,62,14500,27800,8700,1120,260,4.1,2,2,8.0,77777,9,999999999,129,0.0980,0,88,999.000,999.0,99.0
+1985,3,1,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,2.8,89,98500,55,940,267,27,81,18,2500,3200,2300,310,240,3.6,0,0,6.4,77777,9,999999999,120,0.0980,0,88,999.000,999.0,99.0
+1985,3,1,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,1.1,96,98600,0,0,256,0,0,0,0,0,0,0,250,3.1,0,0,6.4,77777,9,999999999,110,0.0980,0,88,999.000,999.0,99.0
+1985,3,1,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,1.7,89,98700,0,0,262,0,0,0,0,0,0,0,270,3.6,0,0,9.7,77777,9,999999999,120,0.0980,0,88,999.000,999.0,99.0
+1985,3,1,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,0.0,89,98800,0,0,255,0,0,0,0,0,0,0,270,3.1,0,0,14.5,77777,9,999999999,110,0.0980,0,88,999.000,999.0,99.0
+1985,3,1,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.7,82,98900,0,0,251,0,0,0,0,0,0,0,280,3.1,0,0,24.1,77777,9,999999999,100,0.0980,0,88,999.000,999.0,99.0
+1985,3,1,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-2.8,79,99000,0,0,248,0,0,0,0,0,0,0,310,4.1,0,0,24.1,77777,9,999999999,89,0.0980,0,88,999.000,999.0,99.0
+1985,3,1,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-2.8,76,99100,0,0,250,0,0,0,0,0,0,0,300,4.1,0,0,24.1,77777,9,999999999,89,0.0980,0,88,999.000,999.0,99.0
+1985,3,2,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-3.3,73,99200,0,0,249,0,0,0,0,0,0,0,300,3.1,0,0,24.1,77777,9,999999999,89,0.0980,0,88,999.000,999.0,99.0
+1985,3,2,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-4.4,72,99200,0,0,244,0,0,0,0,0,0,0,300,3.6,0,0,24.1,77777,9,999999999,80,0.0980,0,88,999.000,999.0,99.0
+1985,3,2,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-5.0,69,99300,0,0,244,0,0,0,0,0,0,0,310,4.6,0,0,24.1,77777,9,999999999,80,0.0980,0,88,999.000,999.0,99.0
+1985,3,2,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-6.1,69,99400,0,0,239,0,0,0,0,0,0,0,320,4.6,0,0,24.1,77777,9,999999999,80,0.0980,0,88,999.000,999.0,99.0
+1985,3,2,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-6.1,75,99500,0,0,235,0,0,0,0,0,0,0,310,4.6,0,0,24.1,77777,9,999999999,80,0.0980,0,88,999.000,999.0,99.0
+1985,3,2,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-6.1,72,99500,0,0,237,0,0,0,0,0,0,0,340,3.1,0,0,24.1,77777,9,999999999,80,0.0980,0,88,999.000,999.0,99.0
+1985,3,2,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-7.2,69,99600,38,777,234,17,27,14,1700,1100,1700,290,330,3.6,0,0,24.1,77777,9,999999999,69,0.1390,0,88,999.000,999.0,99.0
+1985,3,2,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-6.1,64,99800,263,1392,243,121,371,52,12500,27600,7200,920,360,3.6,0,0,24.1,77777,9,999999999,80,0.1390,0,88,999.000,999.0,99.0
+1985,3,2,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-5.0,59,99900,496,1392,257,285,557,88,29700,51400,11400,1680,50,3.6,1,1,24.1,77777,9,999999999,80,0.1390,0,88,999.000,999.0,99.0
+1985,3,2,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-3.3,62,100000,688,1392,269,426,578,141,44200,56300,16300,2880,70,4.1,3,3,24.1,77777,9,999999999,89,0.1390,0,88,999.000,999.0,99.0
+1985,3,2,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-3.3,60,100000,826,1392,271,508,574,169,53100,57100,19100,3870,40,5.2,3,3,24.1,77777,9,999999999,89,0.1390,0,88,999.000,999.0,99.0
+1985,3,2,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,-3.3,55,100100,899,1392,275,601,613,206,64700,63300,23700,5190,40,6.2,4,3,24.1,77777,9,999999999,89,0.1390,0,88,999.000,999.0,99.0
+1985,3,2,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-3.9,55,100100,904,1392,270,612,638,199,63700,63700,22300,4900,60,5.2,7,2,24.1,77777,9,999999999,89,0.1390,0,88,999.000,999.0,99.0
+1985,3,2,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-4.4,55,100100,840,1392,272,461,377,234,50000,40100,25800,5780,40,5.7,10,4,24.1,77777,9,999999999,80,0.1390,0,88,999.000,999.0,99.0
+1985,3,2,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-5.0,55,100100,710,1392,277,305,189,209,33400,19500,23500,5250,60,6.2,10,7,24.1,7620,9,999999999,80,0.1390,0,88,999.000,999.0,99.0
+1985,3,2,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-6.1,57,100100,525,1392,269,198,135,148,21700,13100,16800,3430,40,6.7,10,7,24.1,7620,9,999999999,80,0.1390,0,88,999.000,999.0,99.0
+1985,3,2,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-5.6,64,100100,297,1392,276,101,21,97,11100,1000,10900,3030,50,6.2,10,9,24.1,7620,9,999999999,80,0.1390,0,88,999.000,999.0,99.0
+1985,3,2,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-5.6,67,100100,59,963,281,17,0,17,1900,0,1900,590,50,6.2,10,10,24.1,7620,9,999999999,80,0.1390,0,88,999.000,999.0,99.0
+1985,3,2,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-5.6,69,100200,0,0,265,0,0,0,0,0,0,0,60,5.2,10,8,24.1,7620,9,999999999,80,0.1390,0,88,999.000,999.0,99.0
+1985,3,2,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.0,75,100200,0,0,260,0,0,0,0,0,0,0,50,5.7,10,7,24.1,7620,9,999999999,80,0.1390,0,88,999.000,999.0,99.0
+1985,3,2,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.6,72,100100,0,0,259,0,0,0,0,0,0,0,50,5.7,10,7,24.1,2440,9,999999999,80,0.1390,0,88,999.000,999.0,99.0
+1985,3,2,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.0,75,100100,0,0,264,0,0,0,0,0,0,0,70,5.2,10,8,24.1,2440,9,999999999,80,0.1390,0,88,999.000,999.0,99.0
+1985,3,2,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-4.4,75,100100,0,0,272,0,0,0,0,0,0,0,80,4.1,10,9,24.1,2440,9,999999999,80,0.1390,0,88,999.000,999.0,99.0
+1985,3,2,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-3.9,79,100100,0,0,272,0,0,0,0,0,0,0,60,5.7,10,9,24.1,2440,9,999999999,89,0.1390,0,88,999.000,999.0,99.0
+1985,3,3,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-3.9,75,100100,0,0,283,0,0,0,0,0,0,0,60,5.2,10,10,24.1,2440,9,999999999,89,0.1390,0,88,999.000,999.0,99.0
+1985,3,3,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-4.4,72,100100,0,0,282,0,0,0,0,0,0,0,80,4.6,10,10,24.1,2440,9,999999999,80,0.1390,0,88,999.000,999.0,99.0
+1985,3,3,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-4.4,72,100100,0,0,282,0,0,0,0,0,0,0,60,5.2,10,10,24.1,6100,9,999999999,80,0.1390,0,88,999.000,999.0,99.0
+1985,3,3,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-4.4,72,100100,0,0,282,0,0,0,0,0,0,0,80,5.2,10,10,24.1,6100,9,999999999,80,0.1390,0,88,999.000,999.0,99.0
+1985,3,3,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-4.4,72,100100,0,0,282,0,0,0,0,0,0,0,90,4.6,10,10,24.1,6100,9,999999999,80,0.1390,0,88,999.000,999.0,99.0
+1985,3,3,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-5.0,72,100100,0,0,279,0,0,0,0,0,0,0,80,8.2,10,10,24.1,6100,9,999999999,80,0.1390,0,88,999.000,999.0,99.0
+1985,3,3,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-5.0,72,100100,41,823,279,11,0,11,1300,0,1300,400,80,7.2,10,10,24.1,6100,9,999999999,80,0.1360,0,88,999.000,999.0,99.0
+1985,3,3,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-4.4,72,100100,270,1392,282,42,2,42,4900,0,4900,1620,90,7.7,10,10,24.1,6100,9,999999999,80,0.1360,0,88,999.000,999.0,99.0
+1985,3,3,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-4.4,67,100100,503,1392,269,215,100,179,23600,9600,20100,4640,100,8.2,10,7,24.1,6100,9,999999999,80,0.1360,0,88,999.000,999.0,99.0
+1985,3,3,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-4.4,64,100000,695,1392,281,194,53,168,21400,5200,18800,5260,90,9.8,10,9,24.1,6100,9,999999999,80,0.1360,0,88,999.000,999.0,99.0
+1985,3,3,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-3.9,67,99900,833,1392,290,250,99,191,27900,10400,21700,5150,90,9.8,10,10,24.1,6100,9,999999999,89,0.1360,0,88,999.000,999.0,99.0
+1985,3,3,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-3.9,67,99800,906,1392,290,267,3,265,30800,300,30600,11280,90,10.3,10,10,24.1,3050,9,999999999,89,0.1360,0,88,999.000,999.0,99.0
+1985,3,3,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-3.9,70,99600,911,1392,287,210,8,205,24700,600,24300,9380,100,12.4,10,10,24.1,460,9,999999999,89,0.1360,0,88,999.000,999.0,99.0
+1985,3,3,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-3.9,70,99500,846,1392,287,236,9,231,27300,800,26800,9850,90,12.4,10,10,24.1,520,9,999999999,89,0.1360,0,88,999.000,999.0,99.0
+1985,3,3,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-5.0,67,99300,716,1392,284,181,9,177,20900,700,20600,7420,90,13.4,10,10,24.1,1680,9,999999999,80,0.1360,0,88,999.000,999.0,99.0
+1985,3,3,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-5.6,64,99300,530,1392,283,135,3,134,15300,200,15300,5170,110,14.9,10,10,24.1,760,9,999999999,80,0.1360,0,88,999.000,999.0,99.0
+1985,3,3,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-5.6,64,99200,302,1392,283,64,2,64,7300,100,7300,2340,110,12.9,10,10,24.1,1010,9,999999999,80,0.1360,0,88,999.000,999.0,99.0
+1985,3,3,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-4.4,78,99000,62,986,278,16,0,16,1800,0,1800,570,110,10.3,10,10,1.6,150,9,999999999,80,0.1360,0,88,999.000,999.0,99.0
+1985,3,3,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-3.3,89,99000,0,0,276,0,0,0,0,0,0,0,120,8.8,10,10,1.6,340,9,999999999,89,0.1360,0,88,999.000,999.0,99.0
+1985,3,3,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-3.9,82,98900,0,0,278,0,0,0,0,0,0,0,110,12.4,10,10,6.4,490,9,999999999,89,0.1360,0,88,999.000,999.0,99.0
+1985,3,3,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-3.9,82,98700,0,0,278,0,0,0,0,0,0,0,110,12.9,10,10,6.4,340,9,999999999,89,0.1360,0,88,999.000,999.0,99.0
+1985,3,3,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-3.3,85,98700,0,0,279,0,0,0,0,0,0,0,110,8.2,10,10,6.4,310,9,999999999,89,0.1360,0,88,999.000,999.0,99.0
+1985,3,3,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-2.2,89,98500,0,0,282,0,0,0,0,0,0,0,100,5.7,10,10,8.0,340,9,999999999,89,0.1360,0,88,999.000,999.0,99.0
+1985,3,3,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-2.2,89,98400,0,0,282,0,0,0,0,0,0,0,110,6.7,10,10,9.7,240,9,999999999,89,0.1360,0,88,999.000,999.0,99.0
+1985,3,4,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-1.7,89,98200,0,0,285,0,0,0,0,0,0,0,100,5.2,10,10,8.0,270,9,999999999,100,0.1360,0,88,999.000,999.0,99.0
+1985,3,4,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-1.1,89,98000,0,0,288,0,0,0,0,0,0,0,110,4.1,10,10,9.7,210,9,999999999,100,0.1360,0,88,999.000,999.0,99.0
+1985,3,4,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-0.6,89,97700,0,0,291,0,0,0,0,0,0,0,130,8.8,10,10,8.0,240,9,999999999,100,0.1360,0,88,999.000,999.0,99.0
+1985,3,4,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-1.7,89,97700,0,0,285,0,0,0,0,0,0,0,100,6.7,10,10,8.0,240,9,999999999,100,0.1360,0,88,999.000,999.0,99.0
+1985,3,4,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-1.7,89,97500,0,0,285,0,0,0,0,0,0,0,80,4.6,10,10,11.3,210,9,999999999,100,0.1360,0,88,999.000,999.0,99.0
+1985,3,4,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-1.1,89,97300,0,0,288,0,0,0,0,0,0,0,90,4.6,10,10,9.7,150,9,999999999,100,0.1360,0,88,999.000,999.0,99.0
+1985,3,4,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-0.6,92,97100,45,846,289,9,0,9,1100,0,1100,340,90,4.1,10,10,6.4,120,9,999999999,100,0.1290,0,88,999.000,999.0,99.0
+1985,3,4,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,0.0,92,97000,277,1391,291,41,0,41,4800,0,4800,1600,90,2.6,10,10,1.6,90,9,999999999,100,0.1290,0,88,999.000,999.0,99.0
+1985,3,4,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,0.0,92,96900,510,1391,291,98,1,98,11400,100,11400,4020,0,0.0,10,10,1.2,60,9,999999999,100,0.1290,0,88,999.000,999.0,99.0
+1985,3,4,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,1.7,86,96900,702,1391,305,136,0,136,16000,0,16000,6010,180,5.2,10,10,0.8,30,9,999999999,120,0.1290,0,88,999.000,999.0,99.0
+1985,3,4,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,8.3,90,96900,840,1391,341,176,0,176,20700,0,20700,8010,230,9.8,10,10,6.4,370,9,999999999,170,0.1290,0,88,999.000,999.0,99.0
+1985,3,4,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,7.2,89,97000,913,1391,334,206,1,205,24200,100,24200,9390,240,7.7,10,10,24.1,460,9,999999999,160,0.1290,0,88,999.000,999.0,99.0
+1985,3,4,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.8,4.4,80,97000,917,1391,302,519,428,237,55200,44200,25900,6180,260,9.8,8,6,24.1,3050,9,999999999,139,0.1290,0,88,999.000,999.0,99.0
+1985,3,4,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,2.2,66,97100,852,1391,299,597,621,218,63500,63700,24300,5270,260,11.8,5,5,24.1,77777,9,999999999,120,0.1290,0,88,999.000,999.0,99.0
+1985,3,4,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,-0.6,63,97200,722,1391,304,211,55,183,23300,5500,20500,5770,250,9.3,9,9,24.1,760,9,999999999,100,0.1290,0,88,999.000,999.0,99.0
+1985,3,4,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-2.2,65,97400,536,1391,301,132,23,123,14500,2200,13700,3580,260,10.3,10,10,24.1,880,9,999999999,89,0.1290,0,88,999.000,999.0,99.0
+1985,3,4,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-5.6,62,97600,307,1391,285,53,4,52,6100,100,6100,2010,270,13.4,10,10,24.1,880,9,999999999,80,0.1290,0,88,999.000,999.0,99.0
+1985,3,4,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-7.2,56,97700,66,1032,282,12,1,12,1400,0,1400,450,270,10.3,10,10,24.1,1160,9,999999999,69,0.1290,0,88,999.000,999.0,99.0
+1985,3,4,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-8.3,56,97900,0,0,276,0,0,0,0,0,0,0,260,14.4,10,10,24.1,1160,9,999999999,69,0.1290,0,88,999.000,999.0,99.0
+1985,3,4,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-7.8,64,98000,0,0,272,0,0,0,0,0,0,0,260,14.4,10,10,6.4,1010,9,999999999,69,0.1290,0,88,999.000,999.0,99.0
+1985,3,4,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-8.3,63,98000,0,0,269,0,0,0,0,0,0,0,260,10.3,10,10,11.3,1160,9,999999999,69,0.1290,0,88,999.000,999.0,99.0
+1985,3,4,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-8.3,66,98200,0,0,267,0,0,0,0,0,0,0,260,10.8,10,10,6.4,1160,9,999999999,69,0.1290,0,88,999.000,999.0,99.0
+1985,3,4,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-8.3,66,98300,0,0,259,0,0,0,0,0,0,0,260,15.4,9,9,24.1,1160,9,999999999,69,0.1290,0,88,999.000,999.0,99.0
+1985,3,4,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-8.9,66,98400,0,0,248,0,0,0,0,0,0,0,260,12.4,7,7,24.1,1010,9,999999999,60,0.1290,0,88,999.000,999.0,99.0
+1985,3,5,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-9.4,63,98500,0,0,256,0,0,0,0,0,0,0,270,13.9,9,9,24.1,1010,9,999999999,60,0.1290,0,88,999.000,999.0,99.0
+1985,3,5,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-9.4,66,98700,0,0,261,0,0,0,0,0,0,0,270,10.8,10,10,12.9,1010,9,999999999,60,0.1290,0,88,999.000,999.0,99.0
+1985,3,5,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-10.0,63,98700,0,0,261,0,0,0,0,0,0,0,260,9.3,10,10,12.9,1010,9,999999999,60,0.1290,0,88,999.000,999.0,99.0
+1985,3,5,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-10.0,63,98800,0,0,261,0,0,0,0,0,0,0,270,10.8,10,10,24.1,1010,9,999999999,60,0.1290,0,88,999.000,999.0,99.0
+1985,3,5,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-9.4,66,98900,0,0,261,0,0,0,0,0,0,0,280,12.9,10,10,24.1,1010,9,999999999,60,0.1290,0,88,999.000,999.0,99.0
+1985,3,5,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-10.0,66,99100,0,0,252,0,0,0,0,0,0,0,270,10.8,9,9,24.1,1010,9,999999999,60,0.1290,0,88,999.000,999.0,99.0
+1985,3,5,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-9.4,69,99200,50,892,252,14,1,14,1600,0,1600,500,270,6.7,9,9,24.1,1010,9,999999999,60,0.1480,0,88,999.000,999.0,99.0
+1985,3,5,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.9,-9.4,66,99400,285,1390,261,69,4,69,7800,100,7800,2410,290,8.2,10,10,14.5,1010,9,999999999,60,0.1480,0,88,999.000,999.0,99.0
+1985,3,5,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-8.9,72,99600,518,1390,260,112,8,109,12900,500,12700,4400,300,7.7,10,10,24.1,640,9,999999999,69,0.1480,0,88,999.000,999.0,99.0
+1985,3,5,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-11.1,53,99700,709,1390,247,369,314,209,39600,32700,22900,4770,290,8.2,7,7,24.1,760,9,999999999,60,0.1480,0,88,999.000,999.0,99.0
+1985,3,5,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-10.6,58,99900,846,1390,246,459,322,263,49400,34300,28500,6670,300,8.2,7,7,24.1,760,9,999999999,60,0.1480,0,88,999.000,999.0,99.0
+1985,3,5,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-11.1,53,100000,919,1390,247,473,292,280,51200,31300,30400,7570,310,8.2,7,7,24.1,760,9,999999999,60,0.1480,0,88,999.000,999.0,99.0
+1985,3,5,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-11.1,53,100100,923,1390,257,362,107,291,39900,10900,32600,9980,330,6.7,9,9,24.1,760,9,999999999,60,0.1480,0,88,999.000,999.0,99.0
+1985,3,5,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-10.6,53,100100,858,1390,260,430,204,304,46700,21300,33500,8360,340,8.2,9,9,24.1,760,9,999999999,60,0.1480,0,88,999.000,999.0,99.0
+1985,3,5,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-11.7,49,100300,728,1390,258,276,74,238,30400,7400,26500,7150,340,7.7,9,9,24.1,880,9,999999999,60,0.1480,0,88,999.000,999.0,99.0
+1985,3,5,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-12.2,51,100500,542,1390,248,194,107,153,21300,10500,17200,3570,360,8.2,8,8,24.1,880,9,999999999,60,0.1480,0,88,999.000,999.0,99.0
+1985,3,5,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-12.8,53,100600,313,1390,256,59,1,59,6800,0,6800,2230,350,8.2,10,10,24.1,880,9,999999999,50,0.1480,0,88,999.000,999.0,99.0
+1985,3,5,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.0,-12.8,55,100700,70,1054,247,19,3,18,2100,0,2100,630,350,6.7,9,9,24.1,980,9,999999999,50,0.1480,0,88,999.000,999.0,99.0
+1985,3,5,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-13.3,55,100700,0,0,227,0,0,0,0,0,0,0,320,5.2,3,3,24.1,77777,9,999999999,50,0.1480,0,88,999.000,999.0,99.0
+1985,3,5,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-13.3,57,100900,0,0,216,0,0,0,0,0,0,0,350,4.1,0,0,24.1,77777,9,999999999,50,0.1480,0,88,999.000,999.0,99.0
+1985,3,5,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-12.8,65,100900,0,0,213,0,0,0,0,0,0,0,330,3.6,0,0,24.1,77777,9,999999999,50,0.1480,0,88,999.000,999.0,99.0
+1985,3,5,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-12.2,68,100900,0,0,213,0,0,0,0,0,0,0,320,3.1,0,0,24.1,77777,9,999999999,60,0.1480,0,88,999.000,999.0,99.0
+1985,3,5,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-11.1,68,101000,0,0,244,0,0,0,0,0,0,0,310,3.1,9,9,24.1,980,9,999999999,60,0.1480,0,88,999.000,999.0,99.0
+1985,3,5,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-11.1,63,101000,0,0,256,0,0,0,0,0,0,0,320,2.6,10,10,24.1,1010,9,999999999,60,0.1480,0,88,999.000,999.0,99.0
+1985,3,6,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-11.1,60,101100,0,0,258,0,0,0,0,0,0,0,360,2.6,10,10,24.1,1010,9,999999999,60,0.1480,0,88,999.000,999.0,99.0
+1985,3,6,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-11.1,60,101100,0,0,258,0,0,0,0,0,0,0,320,2.1,10,10,24.1,1010,9,999999999,60,0.1480,0,88,999.000,999.0,99.0
+1985,3,6,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-11.1,60,101100,0,0,258,0,0,0,0,0,0,0,360,3.1,10,10,24.1,1010,9,999999999,60,0.1480,0,88,999.000,999.0,99.0
+1985,3,6,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-10.6,63,101100,0,0,251,0,0,0,0,0,0,0,0,0.0,9,9,24.1,1010,9,999999999,60,0.1480,0,88,999.000,999.0,99.0
+1985,3,6,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-10.0,63,101100,0,0,261,0,0,0,0,0,0,0,0,0.0,10,10,24.1,880,9,999999999,60,0.1480,0,88,999.000,999.0,99.0
+1985,3,6,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-9.4,69,101200,0,0,252,0,0,0,0,0,0,0,30,1.5,9,9,24.1,880,9,999999999,60,0.1480,0,88,999.000,999.0,99.0
+1985,3,6,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-8.9,66,101200,54,915,257,13,14,12,1500,600,1400,250,110,3.6,9,9,24.1,1010,9,999999999,69,0.0690,0,88,999.000,999.0,99.0
+1985,3,6,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-8.3,66,101300,292,1389,250,133,240,83,14000,18500,10100,1620,120,4.6,7,7,24.1,880,9,999999999,69,0.0690,0,88,999.000,999.0,99.0
+1985,3,6,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-8.9,61,101300,525,1389,252,232,128,184,25000,12400,20300,4270,120,3.6,7,7,24.1,760,9,999999999,69,0.0690,0,88,999.000,999.0,99.0
+1985,3,6,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-8.9,56,101300,716,1389,256,328,315,167,36000,32900,19000,3660,100,3.6,7,7,24.1,760,9,999999999,69,0.0690,0,88,999.000,999.0,99.0
+1985,3,6,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-8.9,52,101300,853,1389,245,583,814,85,61100,80600,11400,1950,120,3.1,1,1,24.1,77777,9,999999999,69,0.0690,0,88,999.000,999.0,99.0
+1985,3,6,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-8.9,50,101200,926,1389,247,574,656,138,61600,66900,16900,3690,110,2.6,4,1,24.1,77777,9,999999999,69,0.0690,0,88,999.000,999.0,99.0
+1985,3,6,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-10.6,42,101100,930,1389,247,659,794,129,69000,79300,15800,3170,110,4.6,8,1,24.1,77777,9,999999999,60,0.0690,0,88,999.000,999.0,99.0
+1985,3,6,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-9.4,46,100900,864,1389,249,614,777,132,65600,78700,16500,3280,130,5.2,9,1,24.1,77777,9,999999999,60,0.0690,0,88,999.000,999.0,99.0
+1985,3,6,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-9.4,44,100900,734,1389,251,464,674,110,49500,67300,13800,2440,130,4.1,8,1,24.1,77777,9,999999999,60,0.0690,0,88,999.000,999.0,99.0
+1985,3,6,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-8.9,46,100800,547,1389,257,292,418,129,31000,40000,15200,2510,120,6.2,10,3,24.1,77777,9,999999999,69,0.0690,0,88,999.000,999.0,99.0
+1985,3,6,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-8.3,54,100700,318,1389,261,101,144,68,10900,11600,8200,1260,130,4.1,10,7,24.1,7620,9,999999999,69,0.0690,0,88,999.000,999.0,99.0
+1985,3,6,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-7.8,56,100700,74,1077,261,27,12,25,2800,700,2800,590,180,5.2,10,7,24.1,7620,9,999999999,69,0.0690,0,88,999.000,999.0,99.0
+1985,3,6,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-7.2,59,100600,0,0,279,0,0,0,0,0,0,0,160,5.2,10,10,24.1,7620,9,999999999,69,0.0690,0,88,999.000,999.0,99.0
+1985,3,6,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-6.7,64,100500,0,0,277,0,0,0,0,0,0,0,170,3.6,10,10,24.1,7620,9,999999999,69,0.0690,0,88,999.000,999.0,99.0
+1985,3,6,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-6.7,64,100400,0,0,277,0,0,0,0,0,0,0,170,6.2,10,10,24.1,7620,9,999999999,69,0.0690,0,88,999.000,999.0,99.0
+1985,3,6,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-6.1,67,100300,0,0,278,0,0,0,0,0,0,0,160,6.2,10,10,24.1,7620,9,999999999,80,0.0690,0,88,999.000,999.0,99.0
+1985,3,6,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-6.1,67,100300,0,0,265,0,0,0,0,0,0,0,160,6.2,10,8,24.1,7620,9,999999999,80,0.0690,0,88,999.000,999.0,99.0
+1985,3,6,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-6.1,67,100200,0,0,270,0,0,0,0,0,0,0,180,5.2,10,9,24.1,7010,9,999999999,80,0.0690,0,88,999.000,999.0,99.0
+1985,3,7,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-5.6,67,100100,0,0,281,0,0,0,0,0,0,0,170,6.2,10,10,24.1,7010,9,999999999,80,0.0690,0,88,999.000,999.0,99.0
+1985,3,7,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-5.6,64,100000,0,0,270,0,0,0,0,0,0,0,180,5.2,10,8,24.1,7010,9,999999999,80,0.0690,0,88,999.000,999.0,99.0
+1985,3,7,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-5.6,64,99900,0,0,283,0,0,0,0,0,0,0,180,5.2,10,10,24.1,7010,9,999999999,80,0.0690,0,88,999.000,999.0,99.0
+1985,3,7,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-5.6,64,100000,0,0,283,0,0,0,0,0,0,0,200,2.1,10,10,24.1,7010,9,999999999,80,0.0690,0,88,999.000,999.0,99.0
+1985,3,7,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-5.6,64,99900,0,0,283,0,0,0,0,0,0,0,160,2.6,10,10,24.1,3050,9,999999999,80,0.0690,0,88,999.000,999.0,99.0
+1985,3,7,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-5.6,64,99800,0,0,283,0,0,0,0,0,0,0,150,4.1,10,10,24.1,3050,9,999999999,80,0.0690,0,88,999.000,999.0,99.0
+1985,3,7,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-5.0,67,99800,59,960,284,7,1,7,900,0,900,270,180,2.6,10,10,24.1,1680,9,999999999,80,0.0790,0,88,999.000,999.0,99.0
+1985,3,7,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-3.9,70,99600,299,1389,287,67,7,65,7500,300,7500,2360,180,4.6,10,10,24.1,1680,9,999999999,89,0.0790,0,88,999.000,999.0,99.0
+1985,3,7,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-3.3,73,99600,532,1389,288,71,10,67,8500,600,8300,2980,180,5.7,10,10,11.3,490,9,999999999,89,0.0790,0,88,999.000,999.0,99.0
+1985,3,7,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-1.7,82,99500,723,1389,290,179,5,176,20600,400,20400,7430,190,4.6,10,10,14.5,270,9,999999999,100,0.0790,0,88,999.000,999.0,99.0
+1985,3,7,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-1.1,73,99400,860,1389,300,262,11,255,30100,1000,29500,10660,190,8.2,10,10,24.1,2440,9,999999999,100,0.0790,0,88,999.000,999.0,99.0
+1985,3,7,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,-0.6,68,99300,933,1389,308,295,7,290,33900,600,33500,12200,190,7.7,10,10,24.1,2440,9,999999999,100,0.0790,0,88,999.000,999.0,99.0
+1985,3,7,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,-0.6,68,99200,936,1389,308,269,3,267,31200,300,31000,11560,190,5.7,10,10,24.1,1160,9,999999999,100,0.0790,0,88,999.000,999.0,99.0
+1985,3,7,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,-0.6,68,99100,870,1389,308,268,4,265,30700,400,30400,11020,200,4.6,10,10,24.1,1010,9,999999999,100,0.0790,0,88,999.000,999.0,99.0
+1985,3,7,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,0.0,68,99000,739,1389,311,250,2,249,28200,200,28100,9500,200,6.7,10,10,24.1,1010,9,999999999,110,0.0790,0,88,999.000,999.0,99.0
+1985,3,7,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,1.1,73,99000,553,1389,312,194,0,194,21500,0,21500,6690,190,4.6,10,10,24.1,1010,9,999999999,110,0.0790,0,88,999.000,999.0,99.0
+1985,3,7,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,1.7,76,99000,324,1389,313,86,1,86,9600,0,9600,2970,210,7.7,10,10,24.1,1010,9,999999999,120,0.0790,0,88,999.000,999.0,99.0
+1985,3,7,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,2.8,83,99000,77,1099,314,22,0,22,2500,0,2500,750,220,5.7,10,10,11.3,240,9,999999999,129,0.0790,0,88,999.000,999.0,99.0
+1985,3,7,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,3.3,86,99000,0,0,315,0,0,0,0,0,0,0,210,4.1,10,10,11.3,210,9,999999999,129,0.0790,0,88,999.000,999.0,99.0
+1985,3,7,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,4.4,93,99000,0,0,316,0,0,0,0,0,0,0,220,4.6,10,10,11.3,210,9,999999999,139,0.0790,0,88,999.000,999.0,99.0
+1985,3,7,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,4.4,86,99000,0,0,321,0,0,0,0,0,0,0,240,4.6,10,10,14.5,210,9,999999999,139,0.0790,0,88,999.000,999.0,99.0
+1985,3,7,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,4.4,86,99000,0,0,321,0,0,0,0,0,0,0,220,5.2,10,10,12.9,210,9,999999999,139,0.0790,0,88,999.000,999.0,99.0
+1985,3,7,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,4.4,86,99000,0,0,290,0,0,0,0,0,0,0,240,6.2,3,3,24.1,77777,9,999999999,139,0.0790,0,88,999.000,999.0,99.0
+1985,3,7,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,3.9,86,99100,0,0,284,0,0,0,0,0,0,0,260,4.6,10,2,8.0,77777,9,999999999,129,0.0790,0,88,999.000,999.0,99.0
+1985,3,8,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,3.9,86,99100,0,0,280,0,0,0,0,0,0,0,260,4.1,10,1,11.3,77777,9,999999999,129,0.0790,0,88,999.000,999.0,99.0
+1985,3,8,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,2.8,86,99200,0,0,275,0,0,0,0,0,0,0,270,5.2,8,1,11.3,77777,9,999999999,129,0.0790,0,88,999.000,999.0,99.0
+1985,3,8,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,1.7,86,99200,0,0,264,0,0,0,0,0,0,0,270,3.1,0,0,11.3,77777,9,999999999,120,0.0790,0,88,999.000,999.0,99.0
+1985,3,8,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,0.6,86,99300,0,0,268,0,0,0,0,0,0,0,270,3.6,2,2,11.3,77777,9,999999999,110,0.0790,0,88,999.000,999.0,99.0
+1985,3,8,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-0.6,82,99400,0,0,295,0,0,0,0,0,0,0,300,4.6,10,10,11.3,340,9,999999999,100,0.0790,0,88,999.000,999.0,99.0
+1985,3,8,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.7,82,99500,0,0,290,0,0,0,0,0,0,0,300,4.1,10,10,11.3,370,9,999999999,100,0.0790,0,88,999.000,999.0,99.0
+1985,3,8,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-1.7,82,99500,64,1006,271,25,1,25,2800,0,2800,790,300,4.1,8,7,9.7,430,9,999999999,100,0.0990,0,88,999.000,999.0,99.0
+1985,3,8,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-1.7,79,99600,307,1388,258,123,297,58,13200,23400,8000,1040,290,3.1,2,1,9.7,77777,9,999999999,100,0.0990,0,88,999.000,999.0,99.0
+1985,3,8,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-1.1,73,99700,539,1388,260,346,711,71,36000,67000,9900,1420,280,3.6,0,0,12.9,77777,9,999999999,100,0.0990,0,88,999.000,999.0,99.0
+1985,3,8,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-1.1,68,99700,730,1388,264,512,806,89,54100,79500,12100,1960,290,2.6,0,0,19.3,77777,9,999999999,100,0.0990,0,88,999.000,999.0,99.0
+1985,3,8,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,-0.6,63,99800,867,1388,271,631,850,101,67200,85200,13800,2480,270,4.1,0,0,24.1,77777,9,999999999,100,0.0990,0,88,999.000,999.0,99.0
+1985,3,8,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,-1.7,48,99800,939,1388,281,698,874,107,74600,88100,14800,2850,270,3.1,0,0,24.1,77777,9,999999999,100,0.0990,0,88,999.000,999.0,99.0
+1985,3,8,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,-2.2,43,99800,942,1388,285,706,883,108,75500,89000,14900,2880,300,5.2,0,0,24.1,77777,9,999999999,100,0.0990,0,88,999.000,999.0,99.0
+1985,3,8,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,-2.2,41,99800,876,1388,287,647,866,102,69000,86900,14000,2530,270,5.2,0,0,24.1,77777,9,999999999,89,0.0990,0,88,999.000,999.0,99.0
+1985,3,8,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,-2.2,40,99800,745,1388,289,525,813,91,55600,80400,12300,2010,260,7.7,0,0,24.1,77777,9,999999999,100,0.0990,0,88,999.000,999.0,99.0
+1985,3,8,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,-2.2,41,99800,558,1388,287,363,727,73,38000,69000,10200,1470,270,5.2,0,0,24.1,77777,9,999999999,89,0.0990,0,88,999.000,999.0,99.0
+1985,3,8,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,-3.3,39,99900,329,1388,283,175,535,51,18500,44000,8100,960,280,5.2,0,0,24.1,77777,9,999999999,89,0.0990,0,88,999.000,999.0,99.0
+1985,3,8,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.8,-2.2,50,99900,81,1122,276,34,126,22,3400,5500,2900,390,280,4.6,0,0,24.1,77777,9,999999999,100,0.0990,0,88,999.000,999.0,99.0
+1985,3,8,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,-3.9,51,100000,0,0,266,0,0,0,0,0,0,0,280,3.6,0,0,24.1,77777,9,999999999,89,0.0990,0,88,999.000,999.0,99.0
+1985,3,8,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,-3.3,55,100000,0,0,264,0,0,0,0,0,0,0,270,3.6,0,0,24.1,77777,9,999999999,89,0.0990,0,88,999.000,999.0,99.0
+1985,3,8,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,-3.3,60,100000,0,0,260,0,0,0,0,0,0,0,260,2.6,0,0,24.1,77777,9,999999999,89,0.0990,0,88,999.000,999.0,99.0
+1985,3,8,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-3.3,65,100000,0,0,256,0,0,0,0,0,0,0,260,3.1,0,0,24.1,77777,9,999999999,89,0.0990,0,88,999.000,999.0,99.0
+1985,3,8,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-3.3,65,100000,0,0,256,0,0,0,0,0,0,0,260,3.1,0,0,24.1,77777,9,999999999,89,0.0990,0,88,999.000,999.0,99.0
+1985,3,8,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-3.3,67,100000,0,0,253,0,0,0,0,0,0,0,270,3.1,0,0,24.1,77777,9,999999999,89,0.0990,0,88,999.000,999.0,99.0
+1985,3,9,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-3.3,73,100000,0,0,249,0,0,0,0,0,0,0,260,2.6,0,0,24.1,77777,9,999999999,89,0.0990,0,88,999.000,999.0,99.0
+1985,3,9,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-3.3,73,100000,0,0,249,0,0,0,0,0,0,0,270,3.1,0,0,24.1,77777,9,999999999,89,0.0990,0,88,999.000,999.0,99.0
+1985,3,9,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-3.3,76,100000,0,0,248,0,0,0,0,0,0,0,270,2.1,0,0,24.1,77777,9,999999999,89,0.0990,0,88,999.000,999.0,99.0
+1985,3,9,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-3.9,79,100000,0,0,243,0,0,0,0,0,0,0,270,1.5,0,0,24.1,77777,9,999999999,89,0.0990,0,88,999.000,999.0,99.0
+1985,3,9,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-3.9,82,100100,0,0,241,0,0,0,0,0,0,0,260,1.5,0,0,24.1,77777,9,999999999,89,0.0990,0,88,999.000,999.0,99.0
+1985,3,9,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-3.9,82,100100,0,0,241,0,0,0,0,0,0,0,270,2.1,0,0,24.1,77777,9,999999999,89,0.0990,0,88,999.000,999.0,99.0
+1985,3,9,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-3.9,75,100100,69,1029,245,26,59,21,2700,2200,2500,370,280,2.1,0,0,24.1,77777,9,999999999,89,0.1420,0,88,999.000,999.0,99.0
+1985,3,9,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-3.9,64,100200,314,1387,253,155,431,59,16100,34500,8200,1070,310,3.1,0,0,24.1,77777,9,999999999,89,0.1420,0,88,999.000,999.0,99.0
+1985,3,9,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-3.3,60,100200,546,1387,260,342,648,88,36000,61500,11700,1740,290,3.6,0,0,24.1,77777,9,999999999,89,0.1420,0,88,999.000,999.0,99.0
+1985,3,9,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,-3.9,51,100200,737,1387,266,511,755,111,54400,75400,14200,2470,280,5.2,0,0,24.1,77777,9,999999999,89,0.1420,0,88,999.000,999.0,99.0
+1985,3,9,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,-3.9,46,100200,874,1387,272,636,811,126,66200,80600,15300,2870,290,4.1,0,0,24.1,77777,9,999999999,89,0.1420,0,88,999.000,999.0,99.0
+1985,3,9,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,-3.3,44,100100,946,1387,277,701,834,134,73300,83300,16300,3340,270,4.1,0,0,24.1,77777,9,999999999,89,0.1420,0,88,999.000,999.0,99.0
+1985,3,9,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,-3.3,38,100000,948,1387,286,704,836,134,73700,83500,16400,3350,280,4.1,0,0,24.1,77777,9,999999999,89,0.1420,0,88,999.000,999.0,99.0
+1985,3,9,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,-2.2,40,100000,882,1387,289,640,809,127,66700,80400,15400,2920,270,6.2,0,0,24.1,77777,9,999999999,100,0.1420,0,88,999.000,999.0,99.0
+1985,3,9,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,-2.8,38,100000,751,1387,288,522,760,113,55700,76000,14400,2540,290,5.2,0,0,24.1,77777,9,999999999,89,0.1420,0,88,999.000,999.0,99.0
+1985,3,9,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,-2.2,38,99900,564,1387,291,356,659,90,37600,62900,11900,1800,260,5.2,0,0,24.1,77777,9,999999999,89,0.1420,0,88,999.000,999.0,99.0
+1985,3,9,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,-3.9,36,99900,334,1387,285,168,452,61,17500,37100,8500,1110,270,6.7,0,0,24.1,77777,9,999999999,89,0.1420,0,88,999.000,999.0,99.0
+1985,3,9,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,-3.9,42,99900,86,1144,276,33,83,25,3400,3300,3100,440,260,2.6,0,0,24.1,77777,9,999999999,89,0.1420,0,88,999.000,999.0,99.0
+1985,3,9,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,-3.9,51,99900,0,0,266,0,0,0,0,0,0,0,240,2.6,0,0,24.1,77777,9,999999999,89,0.1420,0,88,999.000,999.0,99.0
+1985,3,9,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,-3.3,57,99900,0,0,262,0,0,0,0,0,0,0,240,2.1,0,0,24.1,77777,9,999999999,89,0.1420,0,88,999.000,999.0,99.0
+1985,3,9,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-2.8,65,99900,0,0,258,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,89,0.1420,0,88,999.000,999.0,99.0
+1985,3,9,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-2.8,67,99900,0,0,256,0,0,0,0,0,0,0,270,2.1,0,0,24.1,77777,9,999999999,89,0.1420,0,88,999.000,999.0,99.0
+1985,3,9,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-3.3,70,99900,0,0,252,0,0,0,0,0,0,0,260,2.6,0,0,24.1,77777,9,999999999,89,0.1420,0,88,999.000,999.0,99.0
+1985,3,9,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-3.9,73,99900,0,0,247,0,0,0,0,0,0,0,230,1.5,0,0,24.1,77777,9,999999999,89,0.1420,0,88,999.000,999.0,99.0
+1985,3,10,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-3.9,75,99900,0,0,245,0,0,0,0,0,0,0,220,1.5,0,0,24.1,77777,9,999999999,89,0.1420,0,88,999.000,999.0,99.0
+1985,3,10,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-3.3,76,99800,0,0,248,0,0,0,0,0,0,0,210,1.5,0,0,24.1,77777,9,999999999,89,0.1420,0,88,999.000,999.0,99.0
+1985,3,10,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-3.9,73,99700,0,0,247,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,89,0.1420,0,88,999.000,999.0,99.0
+1985,3,10,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-3.9,67,99600,0,0,251,0,0,0,0,0,0,0,200,2.1,0,0,24.1,77777,9,999999999,89,0.1420,0,88,999.000,999.0,99.0
+1985,3,10,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-3.9,70,99600,0,0,249,0,0,0,0,0,0,0,210,2.6,0,0,24.1,77777,9,999999999,89,0.1420,0,88,999.000,999.0,99.0
+1985,3,10,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-2.8,70,99600,0,0,254,0,0,0,0,0,0,0,220,3.1,0,0,24.1,77777,9,999999999,89,0.1420,0,88,999.000,999.0,99.0
+1985,3,10,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-2.2,70,99600,74,1074,257,26,22,24,2800,1300,2700,570,220,2.6,0,0,24.1,77777,9,999999999,89,0.2330,0,88,999.000,999.0,99.0
+1985,3,10,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-1.1,68,99600,321,1386,264,142,295,75,15000,23600,9500,1370,210,4.6,0,0,24.1,77777,9,999999999,100,0.2330,0,88,999.000,999.0,99.0
+1985,3,10,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,0.0,52,99600,554,1386,284,322,514,117,34400,49400,14600,2260,240,5.2,0,0,24.1,77777,9,999999999,110,0.2330,0,88,999.000,999.0,99.0
+1985,3,10,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,0.6,45,99500,745,1386,296,490,633,151,51000,62400,17400,3230,230,5.2,0,0,24.1,77777,9,999999999,110,0.2330,0,88,999.000,999.0,99.0
+1985,3,10,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,0.0,35,99500,880,1386,310,615,698,172,64500,70000,19900,4220,240,5.2,0,0,24.1,77777,9,999999999,110,0.2330,0,88,999.000,999.0,99.0
+1985,3,10,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,0.0,35,99400,952,1386,316,646,686,176,68300,69400,20500,4770,230,6.2,1,1,24.1,77777,9,999999999,110,0.2330,0,88,999.000,999.0,99.0
+1985,3,10,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,2.2,38,99300,955,1386,328,640,597,230,68800,61900,26000,6290,210,6.2,3,2,24.1,77777,9,999999999,120,0.2330,0,88,999.000,999.0,99.0
+1985,3,10,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,1.1,38,99200,888,1386,325,573,562,215,61500,57900,24200,5390,230,6.2,4,3,24.1,77777,9,999999999,120,0.2330,0,88,999.000,999.0,99.0
+1985,3,10,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,3.3,41,99200,756,1386,341,389,260,248,41600,27300,26600,5960,220,8.2,9,6,24.1,7620,9,999999999,129,0.2330,0,88,999.000,999.0,99.0
+1985,3,10,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,3.9,48,99100,569,1386,328,263,198,182,28600,19600,20500,4290,220,6.7,10,4,24.1,77777,9,999999999,139,0.2330,0,88,999.000,999.0,99.0
+1985,3,10,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,4.4,53,99100,339,1386,333,103,21,98,11400,1100,11200,3310,210,8.8,10,7,24.1,7620,9,999999999,139,0.2330,0,88,999.000,999.0,99.0
+1985,3,10,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,4.4,57,99100,90,1190,333,27,1,27,3000,0,3000,880,210,6.7,10,8,24.1,7620,9,999999999,139,0.2330,0,88,999.000,999.0,99.0
+1985,3,10,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,5.0,62,99000,0,0,338,0,0,0,0,0,0,0,210,7.2,10,9,24.1,2130,9,999999999,139,0.2330,0,88,999.000,999.0,99.0
+1985,3,10,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,5.0,64,99000,0,0,345,0,0,0,0,0,0,0,220,6.7,10,10,24.1,1220,9,999999999,139,0.2330,0,88,999.000,999.0,99.0
+1985,3,10,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,4.4,64,99000,0,0,341,0,0,0,0,0,0,0,210,7.2,10,10,24.1,1370,9,999999999,139,0.2330,0,88,999.000,999.0,99.0
+1985,3,10,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,4.4,69,98900,0,0,336,0,0,0,0,0,0,0,190,5.2,10,10,24.1,1220,9,999999999,139,0.2330,0,88,999.000,999.0,99.0
+1985,3,10,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,3.3,64,98900,0,0,335,0,0,0,0,0,0,0,190,5.2,10,10,24.1,1070,9,999999999,129,0.2330,0,88,999.000,999.0,99.0
+1985,3,10,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,3.3,64,98800,0,0,335,0,0,0,0,0,0,0,210,5.7,10,10,24.1,760,9,999999999,129,0.2330,0,88,999.000,999.0,99.0
+1985,3,11,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,3.3,66,98700,0,0,332,0,0,0,0,0,0,0,210,4.6,10,10,24.1,610,9,999999999,129,0.2330,0,88,999.000,999.0,99.0
+1985,3,11,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,3.9,74,98600,0,0,328,0,0,0,0,0,0,0,200,4.1,10,10,24.1,610,9,999999999,129,0.2330,0,88,999.000,999.0,99.0
+1985,3,11,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,3.9,77,98500,0,0,325,0,0,0,0,0,0,0,190,3.1,10,10,24.1,460,9,999999999,129,0.2330,0,88,999.000,999.0,99.0
+1985,3,11,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,4.4,86,98400,0,0,321,0,0,0,0,0,0,0,190,3.1,10,10,4.8,240,9,999999999,139,0.2330,0,88,999.000,999.0,99.0
+1985,3,11,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,4.4,89,98400,0,0,318,0,0,0,0,0,0,0,180,1.5,10,10,4.8,210,9,999999999,139,0.2330,0,88,999.000,999.0,99.0
+1985,3,11,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,5.0,93,98300,0,0,319,0,0,0,0,0,0,0,170,2.6,10,10,4.8,240,9,999999999,139,0.2330,0,88,999.000,999.0,99.0
+1985,3,11,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,5.0,89,98100,80,1120,321,10,2,10,1200,0,1200,390,150,4.1,10,10,8.0,180,9,999999999,139,0.0810,0,88,999.000,999.0,99.0
+1985,3,11,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,5.6,93,98200,329,1386,322,65,13,62,7500,500,7300,2360,180,1.5,10,10,9.7,180,9,999999999,150,0.0810,0,88,999.000,999.0,99.0
+1985,3,11,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,6.7,89,98100,561,1386,331,116,2,115,13400,100,13400,4760,190,2.6,10,10,14.5,180,9,999999999,160,0.0810,0,88,999.000,999.0,99.0
+1985,3,11,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.8,5.6,86,98100,752,1386,327,212,10,206,24200,800,23800,8510,180,4.6,10,10,11.3,180,9,999999999,150,0.0810,0,88,999.000,999.0,99.0
+1985,3,11,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.8,6.7,93,98000,887,1386,328,287,8,282,32900,700,32400,11630,190,3.6,10,10,11.3,210,9,999999999,160,0.0810,0,88,999.000,999.0,99.0
+1985,3,11,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,6.7,89,97800,959,1386,331,294,3,292,33900,300,33700,12480,200,5.2,10,10,12.9,310,9,999999999,160,0.0810,0,88,999.000,999.0,99.0
+1985,3,11,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,7.2,86,97700,961,1386,336,325,2,323,37200,200,37000,13340,200,4.6,10,10,16.1,310,9,999999999,160,0.0810,0,88,999.000,999.0,99.0
+1985,3,11,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,7.8,86,97600,894,1386,340,281,0,281,32200,0,32200,11660,210,5.2,10,10,16.1,310,9,999999999,170,0.0810,0,88,999.000,999.0,99.0
+1985,3,11,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,8.3,90,97600,762,1386,341,232,2,231,26400,200,26300,9270,220,6.2,10,10,8.0,240,9,999999999,170,0.0810,0,88,999.000,999.0,99.0
+1985,3,11,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,8.3,93,97500,575,1386,338,183,0,183,20500,0,20500,6660,220,4.6,10,10,6.4,180,9,999999999,170,0.0810,0,88,999.000,999.0,99.0
+1985,3,11,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,9.4,96,97400,345,1386,342,62,1,62,7200,0,7200,2400,220,5.7,10,10,2.8,120,9,999999999,179,0.0810,0,88,999.000,999.0,99.0
+1985,3,11,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,9.4,96,97400,94,1212,342,15,0,15,1800,0,1800,560,230,6.7,10,10,3.2,150,9,999999999,179,0.0810,0,88,999.000,999.0,99.0
+1985,3,11,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,9.4,93,97400,0,0,345,0,0,0,0,0,0,0,250,8.8,10,10,11.3,490,9,999999999,189,0.0810,0,88,999.000,999.0,99.0
+1985,3,11,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,5.6,93,97400,0,0,322,0,0,0,0,0,0,0,280,12.4,10,10,16.1,400,9,999999999,150,0.0810,0,88,999.000,999.0,99.0
+1985,3,11,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,0.6,82,97700,0,0,301,0,0,0,0,0,0,0,290,10.8,10,10,24.1,610,9,999999999,110,0.0810,0,88,999.000,999.0,99.0
+1985,3,11,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,0.0,79,97700,0,0,301,0,0,0,0,0,0,0,300,11.3,10,10,24.1,610,9,999999999,110,0.0810,0,88,999.000,999.0,99.0
+1985,3,11,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-1.1,76,98000,0,0,297,0,0,0,0,0,0,0,310,8.2,10,10,24.1,610,9,999999999,100,0.0810,0,88,999.000,999.0,99.0
+1985,3,11,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-1.7,76,98200,0,0,294,0,0,0,0,0,0,0,310,10.3,10,10,24.1,610,9,999999999,100,0.0810,0,88,999.000,999.0,99.0
+1985,3,12,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-1.7,79,98300,0,0,292,0,0,0,0,0,0,0,300,9.8,10,10,24.1,670,9,999999999,100,0.0810,0,88,999.000,999.0,99.0
+1985,3,12,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-2.2,79,98400,0,0,289,0,0,0,0,0,0,0,320,11.3,10,10,24.1,760,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1985,3,12,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-3.9,70,98500,0,0,262,0,0,0,0,0,0,0,300,8.8,4,4,24.1,77777,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1985,3,12,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-3.9,73,98600,0,0,247,0,0,0,0,0,0,0,300,10.3,0,0,24.1,77777,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1985,3,12,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-3.9,70,98800,0,0,249,0,0,0,0,0,0,0,300,8.2,0,0,24.1,77777,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1985,3,12,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-4.4,70,99000,0,0,247,0,0,0,0,0,0,0,300,7.2,0,0,24.1,77777,9,999999999,80,0.0810,0,88,999.000,999.0,99.0
+1985,3,12,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-4.4,70,99100,86,1143,247,34,106,24,3400,4700,3000,420,300,8.8,0,0,24.1,77777,9,999999999,80,0.1200,0,88,999.000,999.0,99.0
+1985,3,12,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-3.9,64,99200,336,1385,253,175,493,57,18300,40700,8400,1050,300,8.8,0,0,24.1,77777,9,999999999,89,0.1200,0,88,999.000,999.0,99.0
+1985,3,12,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-3.9,57,99300,568,1385,259,367,697,83,39000,66900,11400,1690,300,8.2,0,0,24.1,77777,9,999999999,89,0.1200,0,88,999.000,999.0,99.0
+1985,3,12,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,-3.9,51,99400,759,1385,266,537,796,103,56200,78500,13100,2200,310,7.2,0,0,24.1,77777,9,999999999,89,0.1200,0,88,999.000,999.0,99.0
+1985,3,12,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,-3.9,47,99400,894,1385,270,659,844,116,69500,84400,14900,2820,340,10.3,0,0,24.1,77777,9,999999999,89,0.1200,0,88,999.000,999.0,99.0
+1985,3,12,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.8,-5.0,40,99500,965,1385,273,723,864,123,76600,86800,15900,3270,360,9.3,0,0,24.1,77777,9,999999999,80,0.1200,0,88,999.000,999.0,99.0
+1985,3,12,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,-5.0,39,99600,967,1385,275,727,868,123,77000,87300,15900,3280,350,9.3,0,0,24.1,77777,9,999999999,80,0.1200,0,88,999.000,999.0,99.0
+1985,3,12,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,-5.0,36,99600,899,1385,279,666,848,117,70200,84900,15000,2860,310,5.2,0,0,24.1,77777,9,999999999,80,0.1200,0,88,999.000,999.0,99.0
+1985,3,12,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,-5.6,36,99600,767,1385,282,511,711,119,54400,71200,14800,2710,330,6.2,5,1,24.1,77777,9,999999999,80,0.1200,0,88,999.000,999.0,99.0
+1985,3,12,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.8,-6.1,37,99600,580,1385,284,332,337,192,35100,33600,21000,4220,330,4.1,10,3,24.1,77777,9,999999999,80,0.1200,0,88,999.000,999.0,99.0
+1985,3,12,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,-6.1,39,99600,350,1385,288,105,46,94,11600,4000,10600,2420,330,3.6,10,6,24.1,7620,9,999999999,80,0.1200,0,88,999.000,999.0,99.0
+1985,3,12,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-5.6,49,99600,98,1235,277,36,15,35,4000,900,3900,800,60,3.6,10,6,24.1,7620,9,999999999,80,0.1200,0,88,999.000,999.0,99.0
+1985,3,12,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-5.6,53,99600,0,0,273,0,0,0,0,0,0,0,120,2.6,7,6,24.1,7620,9,999999999,80,0.1200,0,88,999.000,999.0,99.0
+1985,3,12,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-5.6,59,99600,0,0,288,0,0,0,0,0,0,0,130,3.1,10,10,24.1,7620,9,999999999,80,0.1200,0,88,999.000,999.0,99.0
+1985,3,12,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-5.0,62,99600,0,0,289,0,0,0,0,0,0,0,140,3.6,10,10,24.1,7620,9,999999999,80,0.1200,0,88,999.000,999.0,99.0
+1985,3,12,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-5.0,67,99600,0,0,270,0,0,0,0,0,0,0,130,3.1,9,8,24.1,7620,9,999999999,80,0.1200,0,88,999.000,999.0,99.0
+1985,3,12,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-6.1,61,99600,0,0,265,0,0,0,0,0,0,0,160,3.1,8,7,24.1,7620,9,999999999,80,0.1200,0,88,999.000,999.0,99.0
+1985,3,12,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-6.7,59,99600,0,0,282,0,0,0,0,0,0,0,150,3.1,10,10,24.1,2740,9,999999999,69,0.1200,0,88,999.000,999.0,99.0
+1985,3,13,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-6.1,59,99600,0,0,285,0,0,0,0,0,0,0,180,3.6,10,10,24.1,2440,9,999999999,80,0.1200,0,88,999.000,999.0,99.0
+1985,3,13,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-6.1,57,99600,0,0,287,0,0,0,0,0,0,0,210,4.1,10,10,24.1,2130,9,999999999,80,0.1200,0,88,999.000,999.0,99.0
+1985,3,13,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-6.7,54,99500,0,0,287,0,0,0,0,0,0,0,170,4.6,10,10,24.1,2130,9,999999999,69,0.1200,0,88,999.000,999.0,99.0
+1985,3,13,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-7.2,52,99400,0,0,286,0,0,0,0,0,0,0,180,4.1,10,10,24.1,1680,9,999999999,69,0.1200,0,88,999.000,999.0,99.0
+1985,3,13,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-6.7,54,99400,0,0,287,0,0,0,0,0,0,0,190,5.2,10,10,24.1,1370,9,999999999,69,0.1200,0,88,999.000,999.0,99.0
+1985,3,13,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-2.2,85,99400,0,0,284,0,0,0,0,0,0,0,230,4.1,10,10,4.8,340,9,999999999,89,0.1200,0,88,999.000,999.0,99.0
+1985,3,13,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-1.7,89,99400,92,1188,285,14,1,14,1700,0,1700,530,180,4.1,10,10,3.2,180,9,999999999,100,0.2340,0,88,999.000,999.0,99.0
+1985,3,13,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-1.1,92,99300,343,1384,286,42,2,41,4900,100,4900,1700,180,3.1,10,10,3.2,150,9,999999999,100,0.2340,0,88,999.000,999.0,99.0
+1985,3,13,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-0.6,96,99300,575,1384,286,126,3,125,14600,200,14500,5140,190,3.1,10,10,1.2,120,9,999999999,100,0.2340,0,88,999.000,999.0,99.0
+1985,3,13,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,0.0,100,99200,765,1384,287,179,4,177,20900,300,20700,7700,190,5.2,10,10,1.2,120,9,999999999,110,0.2340,0,88,999.000,999.0,99.0
+1985,3,13,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,0.6,96,99200,901,1384,292,159,2,158,19100,200,19000,7590,200,5.2,10,10,3.2,150,9,999999999,110,0.2340,0,88,999.000,999.0,99.0
+1985,3,13,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,0.6,96,99200,971,1384,292,165,4,162,20000,300,19700,7980,200,4.6,10,10,11.3,180,9,999999999,110,0.2340,0,88,999.000,999.0,99.0
+1985,3,13,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,1.1,96,99100,973,1384,295,171,4,169,20700,300,20500,8270,220,5.2,10,10,11.3,180,9,999999999,110,0.2340,0,88,999.000,999.0,99.0
+1985,3,13,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,1.1,96,99000,905,1384,295,151,0,150,18100,0,18100,7280,230,5.2,10,10,16.1,210,9,999999999,110,0.2340,0,88,999.000,999.0,99.0
+1985,3,13,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,1.7,93,99000,773,1384,300,251,2,249,28400,200,28300,9820,270,6.2,10,10,16.1,240,9,999999999,120,0.2340,0,88,999.000,999.0,99.0
+1985,3,13,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,1.7,93,98900,585,1384,300,162,1,161,18300,100,18300,6210,280,6.2,10,10,19.3,340,9,999999999,120,0.2340,0,88,999.000,999.0,99.0
+1985,3,13,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,1.7,89,99000,355,1384,284,110,104,84,12200,9000,9900,1840,260,4.6,7,7,24.1,760,9,999999999,120,0.2340,0,88,999.000,999.0,99.0
+1985,3,13,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,1.7,89,99000,103,1257,303,10,0,10,1200,0,1200,390,250,3.6,10,10,24.1,760,9,999999999,120,0.2340,0,88,999.000,999.0,99.0
+1985,3,13,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,1.7,89,99100,0,0,303,0,0,0,0,0,0,0,300,7.7,10,10,16.1,580,9,999999999,120,0.2340,0,88,999.000,999.0,99.0
+1985,3,13,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,0.0,82,99200,0,0,299,0,0,0,0,0,0,0,300,4.6,10,10,14.5,1160,9,999999999,110,0.2340,0,88,999.000,999.0,99.0
+1985,3,13,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-0.6,82,99200,0,0,295,0,0,0,0,0,0,0,280,4.6,10,10,14.5,1160,9,999999999,100,0.2340,0,88,999.000,999.0,99.0
+1985,3,13,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-0.6,82,99200,0,0,295,0,0,0,0,0,0,0,260,5.2,10,10,14.5,1160,9,999999999,100,0.2340,0,88,999.000,999.0,99.0
+1985,3,13,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-1.1,89,99200,0,0,258,0,0,0,0,0,0,0,250,4.1,2,2,14.5,77777,9,999999999,100,0.2340,0,88,999.000,999.0,99.0
+1985,3,13,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-1.7,89,99200,0,0,260,0,0,0,0,0,0,0,250,4.6,4,4,14.5,77777,9,999999999,100,0.2340,0,88,999.000,999.0,99.0
+1985,3,14,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-1.7,92,99200,0,0,245,0,0,0,0,0,0,0,250,4.1,0,0,19.3,77777,9,999999999,100,0.2340,0,88,999.000,999.0,99.0
+1985,3,14,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-2.8,92,99200,0,0,240,0,0,0,0,0,0,0,250,3.1,0,0,19.3,77777,9,999999999,89,0.2340,0,88,999.000,999.0,99.0
+1985,3,14,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-2.8,92,99200,0,0,240,0,0,0,0,0,0,0,250,3.1,0,0,19.3,77777,9,999999999,89,0.2340,0,88,999.000,999.0,99.0
+1985,3,14,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-3.3,92,99200,0,0,238,0,0,0,0,0,0,0,250,3.1,0,0,24.1,77777,9,999999999,89,0.2340,0,88,999.000,999.0,99.0
+1985,3,14,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-3.9,92,99300,0,0,235,0,0,0,0,0,0,0,250,3.1,0,0,24.1,77777,9,999999999,89,0.2340,0,88,999.000,999.0,99.0
+1985,3,14,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-3.3,92,99300,0,0,238,0,0,0,0,0,0,0,240,3.6,0,0,24.1,77777,9,999999999,89,0.2340,0,88,999.000,999.0,99.0
+1985,3,14,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-3.3,89,99400,98,1233,239,45,257,20,4300,13400,3200,360,250,4.1,0,0,24.1,77777,9,999999999,89,0.0550,0,88,999.000,999.0,99.0
+1985,3,14,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-2.2,79,99400,351,1383,250,207,668,39,21900,57600,7300,830,280,5.2,0,0,24.1,77777,9,999999999,89,0.0550,0,88,999.000,999.0,99.0
+1985,3,14,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-1.7,70,99400,583,1383,259,397,815,56,42100,77800,9200,1300,290,4.6,0,0,24.1,77777,9,999999999,100,0.0550,0,88,999.000,999.0,99.0
+1985,3,14,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,-1.1,65,99400,772,1383,278,525,745,110,56200,75000,14200,2540,290,6.7,3,3,24.1,77777,9,999999999,100,0.0550,0,88,999.000,999.0,99.0
+1985,3,14,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,-1.7,60,99400,907,1383,277,631,789,115,66700,79100,14700,2860,280,6.2,2,2,24.1,77777,9,999999999,100,0.0550,0,88,999.000,999.0,99.0
+1985,3,14,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,-1.7,54,99400,978,1383,283,720,833,132,75700,83600,16500,3510,300,6.2,2,2,24.1,77777,9,999999999,100,0.0550,0,88,999.000,999.0,99.0
+1985,3,14,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,-1.7,48,99400,979,1383,297,541,365,283,59000,39400,31100,8140,320,8.2,5,5,24.1,77777,9,999999999,100,0.0550,0,88,999.000,999.0,99.0
+1985,3,14,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,-2.8,49,99400,911,1383,295,449,326,234,49200,35000,26100,6110,320,7.2,7,7,24.1,1220,9,999999999,89,0.0550,0,88,999.000,999.0,99.0
+1985,3,14,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,-4.4,44,99500,778,1383,287,431,442,183,46100,45000,20700,4110,320,5.7,5,5,24.1,77777,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1985,3,14,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,-5.6,37,99500,590,1383,288,341,492,132,36400,47900,15800,2610,330,8.8,4,4,24.1,77777,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1985,3,14,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,-5.6,40,99600,360,1383,282,194,479,72,20100,40100,9700,1300,330,7.2,3,3,24.1,77777,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1985,3,14,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,-5.6,43,99700,107,1280,277,46,145,31,4500,6900,3900,560,230,6.2,3,3,24.1,77777,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1985,3,14,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,-6.1,49,99700,0,0,257,0,0,0,0,0,0,0,330,4.1,0,0,24.1,77777,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1985,3,14,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-6.1,52,99800,0,0,253,0,0,0,0,0,0,0,330,3.6,0,0,24.1,77777,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1985,3,14,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-6.1,57,99800,0,0,249,0,0,0,0,0,0,0,320,3.6,0,0,24.1,77777,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1985,3,14,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-6.7,57,99900,0,0,246,0,0,0,0,0,0,0,350,4.1,0,0,24.1,77777,9,999999999,69,0.0550,0,88,999.000,999.0,99.0
+1985,3,14,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-5.6,64,99900,0,0,246,0,0,0,0,0,0,0,320,3.6,0,0,24.1,77777,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1985,3,14,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-6.1,67,99900,0,0,241,0,0,0,0,0,0,0,300,2.6,0,0,24.1,77777,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1985,3,15,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-6.1,69,100000,0,0,239,0,0,0,0,0,0,0,300,3.1,0,0,24.1,77777,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1985,3,15,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.6,75,100000,0,0,237,0,0,0,0,0,0,0,340,4.1,0,0,24.1,77777,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1985,3,15,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-5.6,78,100000,0,0,236,0,0,0,0,0,0,0,340,3.1,0,0,24.1,77777,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1985,3,15,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-5.6,81,100100,0,0,234,0,0,0,0,0,0,0,300,2.1,0,0,24.1,77777,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1985,3,15,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-5.6,81,100100,0,0,234,0,0,0,0,0,0,0,290,2.1,0,0,24.1,77777,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1985,3,15,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-5.6,85,100200,0,0,232,0,0,0,0,0,0,0,290,1.5,0,0,24.1,77777,9,999999999,80,0.0550,0,88,999.000,999.0,99.0
+1985,3,15,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-5.0,88,100200,105,1279,232,45,245,21,4300,12900,3200,380,0,0.0,0,0,24.1,77777,9,999999999,80,0.0650,0,88,999.000,999.0,99.0
+1985,3,15,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-3.3,76,100300,358,1383,248,207,641,43,21800,55400,7400,890,0,0.0,0,0,24.1,77777,9,999999999,89,0.0650,0,88,999.000,999.0,99.0
+1985,3,15,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-2.8,62,100300,590,1383,260,404,809,61,42700,77300,9600,1340,220,3.1,0,0,24.1,77777,9,999999999,89,0.0650,0,88,999.000,999.0,99.0
+1985,3,15,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,-5.6,43,100400,779,1383,266,572,885,75,60100,87100,10800,1730,240,2.6,0,0,24.1,77777,9,999999999,80,0.0650,0,88,999.000,999.0,99.0
+1985,3,15,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,-3.9,51,100300,914,1383,266,694,925,84,72600,92000,11600,2110,270,3.6,0,0,24.1,77777,9,999999999,89,0.0650,0,88,999.000,999.0,99.0
+1985,3,15,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,-4.4,45,100300,984,1383,269,758,942,89,79200,94000,12100,2380,270,4.6,0,0,24.1,77777,9,999999999,80,0.0650,0,88,999.000,999.0,99.0
+1985,3,15,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.8,-3.9,44,100200,985,1383,274,757,940,89,79100,93800,12100,2380,270,3.1,0,0,24.1,77777,9,999999999,89,0.0650,0,88,999.000,999.0,99.0
+1985,3,15,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,-4.4,41,100100,916,1383,276,696,926,84,72900,92100,11600,2110,190,2.1,0,0,24.1,77777,9,999999999,80,0.0650,0,88,999.000,999.0,99.0
+1985,3,15,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,-3.3,44,100000,784,1383,277,575,887,75,60500,87400,10800,1740,270,5.2,0,0,24.1,77777,9,999999999,89,0.0650,0,88,999.000,999.0,99.0
+1985,3,15,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,-3.9,41,100000,596,1383,278,408,812,61,43200,77700,9600,1350,190,4.1,0,0,24.1,77777,9,999999999,89,0.0650,0,88,999.000,999.0,99.0
+1985,3,15,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,-2.8,46,100000,365,1383,277,214,656,44,22700,56900,7600,900,240,4.1,0,0,24.1,77777,9,999999999,89,0.0650,0,88,999.000,999.0,99.0
+1985,3,15,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,-2.2,56,100000,112,1302,269,48,261,22,4700,14000,3400,400,210,4.1,0,0,24.1,77777,9,999999999,100,0.0650,0,88,999.000,999.0,99.0
+1985,3,15,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-1.7,70,99900,0,0,259,0,0,0,0,0,0,0,210,3.6,0,0,24.1,77777,9,999999999,100,0.0650,0,88,999.000,999.0,99.0
+1985,3,15,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-1.7,73,99900,0,0,257,0,0,0,0,0,0,0,190,3.6,0,0,24.1,77777,9,999999999,100,0.0650,0,88,999.000,999.0,99.0
+1985,3,15,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-1.7,73,99800,0,0,257,0,0,0,0,0,0,0,190,3.6,0,0,24.1,77777,9,999999999,100,0.0650,0,88,999.000,999.0,99.0
+1985,3,15,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-1.7,76,99800,0,0,255,0,0,0,0,0,0,0,220,3.6,0,0,24.1,77777,9,999999999,100,0.0650,0,88,999.000,999.0,99.0
+1985,3,15,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-1.1,79,99800,0,0,255,0,0,0,0,0,0,0,210,3.6,0,0,24.1,77777,9,999999999,100,0.0650,0,88,999.000,999.0,99.0
+1985,3,15,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-1.1,79,99700,0,0,255,0,0,0,0,0,0,0,190,3.1,0,0,24.1,77777,9,999999999,100,0.0650,0,88,999.000,999.0,99.0
+1985,3,16,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-1.1,82,99700,0,0,254,0,0,0,0,0,0,0,220,2.6,0,0,24.1,77777,9,999999999,100,0.0650,0,88,999.000,999.0,99.0
+1985,3,16,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.1,85,99600,0,0,251,0,0,0,0,0,0,0,210,3.6,0,0,24.1,77777,9,999999999,100,0.0650,0,88,999.000,999.0,99.0
+1985,3,16,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.1,85,99500,0,0,251,0,0,0,0,0,0,0,200,3.6,0,0,24.1,77777,9,999999999,100,0.0650,0,88,999.000,999.0,99.0
+1985,3,16,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-1.1,82,99400,0,0,254,0,0,0,0,0,0,0,220,4.1,0,0,24.1,77777,9,999999999,100,0.0650,0,88,999.000,999.0,99.0
+1985,3,16,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-1.1,82,99400,0,0,254,0,0,0,0,0,0,0,220,5.2,0,0,24.1,77777,9,999999999,100,0.0650,0,88,999.000,999.0,99.0
+1985,3,16,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-1.7,76,99300,0,0,255,0,0,0,0,0,0,0,220,5.7,0,0,24.1,77777,9,999999999,100,0.0650,0,88,999.000,999.0,99.0
+1985,3,16,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-1.7,73,99300,112,1301,262,38,68,32,4200,3500,3800,670,220,6.2,7,1,24.1,77777,9,999999999,100,0.1430,0,88,999.000,999.0,99.0
+1985,3,16,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-1.1,68,99200,366,1382,269,182,345,92,19000,29100,11300,1710,220,8.8,10,1,24.1,77777,9,999999999,100,0.1430,0,88,999.000,999.0,99.0
+1985,3,16,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,-0.6,65,99200,597,1382,285,246,188,165,27000,18800,18800,3940,250,9.8,8,5,24.1,7320,9,999999999,100,0.1430,0,88,999.000,999.0,99.0
+1985,3,16,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,0.6,68,99200,786,1382,294,474,354,273,50500,37300,29200,6780,290,10.3,10,7,24.1,4270,9,999999999,110,0.1430,0,88,999.000,999.0,99.0
+1985,3,16,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,0.6,63,99200,920,1382,293,570,552,204,61800,57200,23600,5310,290,9.3,5,5,24.1,77777,9,999999999,110,0.1430,0,88,999.000,999.0,99.0
+1985,3,16,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,-0.6,54,99200,990,1382,299,359,116,276,39800,12300,30900,8560,290,7.7,6,6,24.1,910,9,999999999,100,0.1430,0,88,999.000,999.0,99.0
+1985,3,16,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,-0.6,48,99200,991,1382,306,539,292,330,58200,31500,35600,9880,310,7.2,6,6,24.1,910,9,999999999,100,0.1430,0,88,999.000,999.0,99.0
+1985,3,16,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,-1.1,48,99200,922,1382,306,490,350,257,53500,37600,28300,6890,300,9.8,7,7,24.1,910,9,999999999,100,0.1430,0,88,999.000,999.0,99.0
+1985,3,16,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.8,-2.2,50,99200,789,1382,310,276,75,233,30400,7500,26000,7450,330,10.3,9,9,24.1,910,9,999999999,89,0.1430,0,88,999.000,999.0,99.0
+1985,3,16,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.8,-2.8,48,99200,601,1382,302,232,151,167,25500,15200,18900,3990,320,9.3,8,8,24.1,910,9,999999999,89,0.1430,0,88,999.000,999.0,99.0
+1985,3,16,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.8,-4.4,42,99300,370,1382,290,138,257,70,14900,21900,9000,1270,330,11.3,5,5,24.1,77777,9,999999999,80,0.1430,0,88,999.000,999.0,99.0
+1985,3,16,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,-4.4,49,99300,116,1324,281,39,20,37,4200,1300,4100,850,330,8.2,5,5,24.1,77777,9,999999999,80,0.1430,0,88,999.000,999.0,99.0
+1985,3,16,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-4.4,59,99400,0,0,255,0,0,0,0,0,0,0,330,4.6,0,0,24.1,77777,9,999999999,80,0.1430,0,88,999.000,999.0,99.0
+1985,3,16,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-4.4,62,99400,0,0,252,0,0,0,0,0,0,0,350,4.1,0,0,24.1,77777,9,999999999,80,0.1430,0,88,999.000,999.0,99.0
+1985,3,16,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-5.6,64,99400,0,0,246,0,0,0,0,0,0,0,280,3.6,0,0,24.1,77777,9,999999999,80,0.1430,0,88,999.000,999.0,99.0
+1985,3,16,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-5.6,69,99400,0,0,252,0,0,0,0,0,0,0,270,3.6,3,3,24.1,77777,9,999999999,80,0.1430,0,88,999.000,999.0,99.0
+1985,3,16,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.6,72,99400,0,0,247,0,0,0,0,0,0,0,260,4.1,2,2,24.1,77777,9,999999999,80,0.1430,0,88,999.000,999.0,99.0
+1985,3,16,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.6,72,99400,0,0,244,0,0,0,0,0,0,0,270,3.1,1,1,24.1,77777,9,999999999,80,0.1430,0,88,999.000,999.0,99.0
+1985,3,17,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-5.6,69,99300,0,0,252,0,0,0,0,0,0,0,270,3.1,3,3,24.1,77777,9,999999999,80,0.1430,0,88,999.000,999.0,99.0
+1985,3,17,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-5.0,69,99300,0,0,257,0,0,0,0,0,0,0,280,3.6,4,4,24.1,77777,9,999999999,80,0.1430,0,88,999.000,999.0,99.0
+1985,3,17,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-4.4,72,99300,0,0,253,0,0,0,0,0,0,0,290,4.1,2,2,24.1,77777,9,999999999,80,0.1430,0,88,999.000,999.0,99.0
+1985,3,17,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-4.4,75,99200,0,0,253,0,0,0,0,0,0,0,290,3.6,3,3,24.1,77777,9,999999999,80,0.1430,0,88,999.000,999.0,99.0
+1985,3,17,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-4.4,75,99300,0,0,262,0,0,0,0,0,0,0,300,3.6,7,7,24.1,1220,9,999999999,80,0.1430,0,88,999.000,999.0,99.0
+1985,3,17,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-4.4,75,99300,0,0,253,0,0,0,0,0,0,0,310,5.2,3,3,24.1,77777,9,999999999,80,0.1430,0,88,999.000,999.0,99.0
+1985,3,17,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-3.9,79,99500,119,1346,251,47,224,25,4600,12000,3500,440,330,4.6,2,2,24.1,77777,9,999999999,89,0.0780,0,88,999.000,999.0,99.0
+1985,3,17,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-3.3,73,99500,373,1381,258,196,497,63,20500,42600,8900,1180,360,4.1,2,2,24.1,77777,9,999999999,89,0.0780,0,88,999.000,999.0,99.0
+1985,3,17,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-3.3,70,99600,604,1381,276,212,159,143,23500,16000,16500,3420,20,4.1,8,8,24.1,910,9,999999999,89,0.0780,0,88,999.000,999.0,99.0
+1985,3,17,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-3.3,73,99700,793,1381,274,377,195,265,41100,20300,29400,7000,40,6.7,8,8,24.1,610,9,999999999,89,0.0780,0,88,999.000,999.0,99.0
+1985,3,17,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-4.4,62,99700,927,1381,277,310,135,219,34600,14400,24900,6390,10,6.2,8,8,24.1,610,9,999999999,80,0.0780,0,88,999.000,999.0,99.0
+1985,3,17,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-5.0,62,99800,996,1381,281,354,124,265,39400,13200,29800,8280,10,8.2,9,9,24.1,610,9,999999999,80,0.0780,0,88,999.000,999.0,99.0
+1985,3,17,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-5.0,59,99800,996,1381,277,483,198,340,52800,21000,37700,10630,30,8.8,8,8,24.1,610,9,999999999,80,0.0780,0,88,999.000,999.0,99.0
+1985,3,17,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-5.6,59,99800,928,1381,267,459,406,188,50300,42100,21900,4910,30,8.8,6,6,24.1,760,9,999999999,80,0.0780,0,88,999.000,999.0,99.0
+1985,3,17,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-5.6,62,99900,794,1381,256,546,760,110,57000,75200,13600,2400,40,7.7,2,2,24.1,77777,9,999999999,80,0.0780,0,88,999.000,999.0,99.0
+1985,3,17,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-6.1,61,99900,606,1381,256,413,708,105,43400,68300,13400,2120,40,9.8,3,3,24.1,77777,9,999999999,80,0.0780,0,88,999.000,999.0,99.0
+1985,3,17,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-6.1,64,100000,375,1381,248,209,569,57,22100,49100,8800,1080,40,8.8,1,1,24.1,77777,9,999999999,80,0.0780,0,88,999.000,999.0,99.0
+1985,3,17,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-7.8,66,100000,121,1369,234,45,201,24,4400,11000,3400,430,40,9.3,0,0,24.1,77777,9,999999999,69,0.0780,0,88,999.000,999.0,99.0
+1985,3,17,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-7.8,72,100000,0,0,230,0,0,0,0,0,0,0,40,6.7,0,0,24.1,77777,9,999999999,69,0.0780,0,88,999.000,999.0,99.0
+1985,3,17,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-7.8,75,100000,0,0,228,0,0,0,0,0,0,0,10,5.2,0,0,24.1,77777,9,999999999,69,0.0780,0,88,999.000,999.0,99.0
+1985,3,17,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-7.8,75,100000,0,0,228,0,0,0,0,0,0,0,10,4.1,0,0,24.1,77777,9,999999999,69,0.0780,0,88,999.000,999.0,99.0
+1985,3,17,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-7.8,85,100000,0,0,222,0,0,0,0,0,0,0,330,2.6,0,0,24.1,77777,9,999999999,69,0.0780,0,88,999.000,999.0,99.0
+1985,3,17,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-7.8,85,100000,0,0,222,0,0,0,0,0,0,0,310,1.5,0,0,24.1,77777,9,999999999,69,0.0780,0,88,999.000,999.0,99.0
+1985,3,17,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-7.8,88,100000,0,0,221,0,0,0,0,0,0,0,290,2.1,0,0,24.1,77777,9,999999999,69,0.0780,0,88,999.000,999.0,99.0
+1985,3,18,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-7.8,92,100000,0,0,219,0,0,0,0,0,0,0,300,1.5,0,0,24.1,77777,9,999999999,69,0.0780,0,88,999.000,999.0,99.0
+1985,3,18,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-7.8,96,100000,0,0,217,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,69,0.0780,0,88,999.000,999.0,99.0
+1985,3,18,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-8.3,96,100000,0,0,215,0,0,0,0,0,0,0,290,2.6,0,0,24.1,77777,9,999999999,69,0.0780,0,88,999.000,999.0,99.0
+1985,3,18,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-7.8,96,100000,0,0,217,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,69,0.0780,0,88,999.000,999.0,99.0
+1985,3,18,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-8.3,96,100000,0,0,215,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,69,0.0780,0,88,999.000,999.0,99.0
+1985,3,18,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-8.3,96,100000,0,12,215,0,0,0,0,0,0,0,220,1.5,0,0,24.1,77777,9,999999999,69,0.0780,0,88,999.000,999.0,99.0
+1985,3,18,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.1,-8.3,85,100100,126,1380,220,42,115,31,4400,5200,3900,560,0,0.0,0,0,24.1,77777,9,999999999,69,0.1610,0,88,999.000,999.0,99.0
+1985,3,18,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-5.6,81,100100,380,1380,234,200,472,72,20800,40400,9600,1320,240,3.1,0,0,24.1,77777,9,999999999,80,0.1610,0,88,999.000,999.0,99.0
+1985,3,18,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-6.1,67,100100,611,1380,241,394,661,103,41500,64000,13100,2090,220,3.6,0,0,24.1,77777,9,999999999,80,0.1610,0,88,999.000,999.0,99.0
+1985,3,18,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-7.8,50,100100,800,1380,247,562,753,127,59800,75700,15700,2970,220,3.1,0,0,24.1,77777,9,999999999,69,0.1610,0,88,999.000,999.0,99.0
+1985,3,18,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-7.8,44,100000,933,1380,253,688,807,143,71300,80300,16800,3420,200,3.6,0,0,24.1,77777,9,999999999,69,0.1610,0,88,999.000,999.0,99.0
+1985,3,18,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,-8.3,38,99900,1002,1380,259,751,828,150,78100,82700,17900,4000,210,6.2,0,0,24.1,77777,9,999999999,69,0.1610,0,88,999.000,999.0,99.0
+1985,3,18,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,-8.3,36,99800,1002,1380,261,753,832,150,78400,83100,17900,4000,200,4.6,0,0,24.1,77777,9,999999999,69,0.1610,0,88,999.000,999.0,99.0
+1985,3,18,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,-7.8,35,99700,933,1380,266,690,812,143,71600,80800,16800,3410,210,5.2,0,0,24.1,77777,9,999999999,69,0.1610,0,88,999.000,999.0,99.0
+1985,3,18,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,-7.8,34,99600,799,1380,268,565,760,127,60200,76400,15800,2970,200,6.7,0,0,24.1,77777,9,999999999,69,0.1610,0,88,999.000,999.0,99.0
+1985,3,18,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,-8.3,33,99500,611,1380,267,394,663,103,41500,64200,13100,2090,180,7.7,0,0,24.1,77777,9,999999999,69,0.1610,0,88,999.000,999.0,99.0
+1985,3,18,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,-7.8,37,99400,380,1380,264,200,475,71,20800,40700,9500,1300,190,8.2,0,0,24.1,77777,9,999999999,69,0.1610,0,88,999.000,999.0,99.0
+1985,3,18,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-7.2,43,99400,126,1380,263,37,96,27,3800,4300,3400,480,190,7.7,1,1,24.1,77777,9,999999999,69,0.1610,0,88,999.000,999.0,99.0
+1985,3,18,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-6.7,48,99400,0,12,254,0,0,0,0,0,0,0,180,6.7,0,0,24.1,77777,9,999999999,69,0.1610,0,88,999.000,999.0,99.0
+1985,3,18,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-6.1,52,99400,0,0,253,0,0,0,0,0,0,0,190,6.7,0,0,24.1,77777,9,999999999,80,0.1610,0,88,999.000,999.0,99.0
+1985,3,18,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-5.6,53,99300,0,0,255,0,0,0,0,0,0,0,190,6.7,0,0,24.1,77777,9,999999999,80,0.1610,0,88,999.000,999.0,99.0
+1985,3,18,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,-5.0,53,99200,0,0,258,0,0,0,0,0,0,0,180,7.2,0,0,24.1,77777,9,999999999,80,0.1610,0,88,999.000,999.0,99.0
+1985,3,18,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-4.4,57,99200,0,0,257,0,0,0,0,0,0,0,190,5.2,0,0,24.1,77777,9,999999999,80,0.1610,0,88,999.000,999.0,99.0
+1985,3,18,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-3.9,60,99200,0,0,257,0,0,0,0,0,0,0,200,6.2,0,0,24.1,77777,9,999999999,89,0.1610,0,88,999.000,999.0,99.0
+1985,3,19,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-4.4,57,99100,0,0,257,0,0,0,0,0,0,0,190,6.2,0,0,24.1,77777,9,999999999,80,0.1610,0,88,999.000,999.0,99.0
+1985,3,19,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-3.9,62,99000,0,0,255,0,0,0,0,0,0,0,190,5.2,0,0,24.1,77777,9,999999999,89,0.1610,0,88,999.000,999.0,99.0
+1985,3,19,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-2.8,65,98900,0,0,258,0,0,0,0,0,0,0,220,8.2,0,0,24.1,77777,9,999999999,89,0.1610,0,88,999.000,999.0,99.0
+1985,3,19,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,-1.1,70,98800,0,0,280,0,0,0,0,0,0,0,240,7.7,7,6,24.1,2740,9,999999999,100,0.1610,0,88,999.000,999.0,99.0
+1985,3,19,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,0.0,70,98700,0,0,281,0,0,0,0,0,0,0,230,7.2,6,4,24.1,2740,9,999999999,110,0.1610,0,88,999.000,999.0,99.0
+1985,3,19,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,0.6,73,98700,0,34,289,0,0,0,0,0,0,0,240,7.2,8,7,24.1,2740,9,999999999,110,0.1610,0,88,999.000,999.0,99.0
+1985,3,19,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,1.1,73,98800,133,1379,282,44,30,41,4800,1900,4600,930,240,6.7,8,3,24.1,77777,9,999999999,110,0.1670,0,88,999.000,999.0,99.0
+1985,3,19,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.8,1.7,66,98800,388,1379,307,136,78,114,14900,7000,12900,2940,240,7.7,9,8,24.1,7620,9,999999999,120,0.1670,0,88,999.000,999.0,99.0
+1985,3,19,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,2.2,61,98800,618,1379,322,176,1,176,20000,100,20000,6830,260,5.2,10,9,24.1,2740,9,999999999,120,0.1670,0,88,999.000,999.0,99.0
+1985,3,19,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,2.8,59,98800,807,1379,328,340,130,263,37000,13600,29000,7010,260,5.2,9,9,24.1,1220,9,999999999,129,0.1670,0,88,999.000,999.0,99.0
+1985,3,19,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,4.4,62,98800,940,1379,311,628,561,246,66800,58000,27200,6670,260,6.2,10,3,24.1,77777,9,999999999,139,0.1670,0,88,999.000,999.0,99.0
+1985,3,19,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,5.6,58,98800,1008,1379,315,682,617,231,71000,61900,25700,6670,280,5.2,10,1,24.1,77777,9,999999999,150,0.1670,0,88,999.000,999.0,99.0
+1985,3,19,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,5.6,54,98800,1008,1379,320,731,725,202,77000,73300,23300,5940,250,4.6,8,1,24.1,77777,9,999999999,150,0.1670,0,88,999.000,999.0,99.0
+1985,3,19,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,5.6,52,98800,938,1379,327,664,733,166,70300,74300,19700,4470,290,4.6,2,2,24.1,77777,9,999999999,150,0.1670,0,88,999.000,999.0,99.0
+1985,3,19,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,4.4,48,98800,805,1379,321,517,650,140,54700,65100,16600,3250,310,5.2,2,1,24.1,77777,9,999999999,139,0.1670,0,88,999.000,999.0,99.0
+1985,3,19,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,3.9,41,98800,616,1379,328,371,565,121,38700,54300,14300,2400,280,6.7,2,1,19.3,77777,9,999999999,129,0.1670,0,88,999.000,999.0,99.0
+1985,3,19,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,2.8,41,98800,385,1379,315,197,436,78,21300,37700,10700,1420,310,6.7,2,0,24.1,77777,9,999999999,129,0.1670,0,88,999.000,999.0,99.0
+1985,3,19,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,2.2,46,98900,131,1379,311,38,94,28,3900,4400,3500,500,270,3.6,1,1,24.1,77777,9,999999999,120,0.1670,0,88,999.000,999.0,99.0
+1985,3,19,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,1.7,51,98900,0,34,296,0,0,0,0,0,0,0,270,3.6,0,0,24.1,77777,9,999999999,120,0.1670,0,88,999.000,999.0,99.0
+1985,3,19,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,2.2,57,99000,0,0,292,0,0,0,0,0,0,0,260,4.1,0,0,19.3,77777,9,999999999,120,0.1670,0,88,999.000,999.0,99.0
+1985,3,19,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,0.0,58,99000,0,0,278,0,0,0,0,0,0,0,270,4.1,0,0,24.1,77777,9,999999999,110,0.1670,0,88,999.000,999.0,99.0
+1985,3,19,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,-1.1,56,99100,0,0,275,0,0,0,0,0,0,0,320,4.1,0,0,24.1,77777,9,999999999,100,0.1670,0,88,999.000,999.0,99.0
+1985,3,19,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,-1.7,60,99200,0,0,268,0,0,0,0,0,0,0,320,4.1,0,0,24.1,77777,9,999999999,100,0.1670,0,88,999.000,999.0,99.0
+1985,3,19,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,-3.3,60,99200,0,0,260,0,0,0,0,0,0,0,340,4.6,0,0,24.1,77777,9,999999999,89,0.1670,0,88,999.000,999.0,99.0
+1985,3,20,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-3.9,60,99300,0,0,257,0,0,0,0,0,0,0,270,2.1,0,0,24.1,77777,9,999999999,89,0.1670,0,88,999.000,999.0,99.0
+1985,3,20,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-3.9,62,99300,0,0,255,0,0,0,0,0,0,0,280,2.6,0,0,24.1,77777,9,999999999,89,0.1670,0,88,999.000,999.0,99.0
+1985,3,20,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-4.4,64,99300,0,0,251,0,0,0,0,0,0,0,290,2.1,0,0,24.1,77777,9,999999999,80,0.1670,0,88,999.000,999.0,99.0
+1985,3,20,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-4.4,70,99300,0,0,247,0,0,0,0,0,0,0,280,3.1,0,0,24.1,77777,9,999999999,80,0.1670,0,88,999.000,999.0,99.0
+1985,3,20,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-4.4,70,99400,0,0,247,0,0,0,0,0,0,0,290,2.6,0,0,24.1,77777,9,999999999,80,0.1670,0,88,999.000,999.0,99.0
+1985,3,20,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-4.4,70,99400,0,80,247,0,0,0,0,0,0,0,290,3.1,0,0,24.1,77777,9,999999999,80,0.1670,0,88,999.000,999.0,99.0
+1985,3,20,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-3.3,65,99600,140,1379,256,46,150,32,4900,7800,4100,570,340,5.2,0,0,24.1,77777,9,999999999,89,0.1460,0,88,999.000,999.0,99.0
+1985,3,20,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,-2.8,58,99700,395,1379,264,212,501,70,22100,43600,9600,1300,20,6.2,0,0,24.1,77777,9,999999999,89,0.1460,0,88,999.000,999.0,99.0
+1985,3,20,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,-2.2,58,99800,625,1379,267,406,679,99,42900,66200,12800,2050,20,7.7,0,0,24.1,77777,9,999999999,100,0.1460,0,88,999.000,999.0,99.0
+1985,3,20,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,-3.3,53,99900,813,1379,266,575,765,125,61300,77200,15700,2970,50,7.2,1,0,24.1,77777,9,999999999,89,0.1460,0,88,999.000,999.0,99.0
+1985,3,20,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,-2.2,58,100000,946,1379,267,699,798,153,74700,81200,18800,4210,50,9.3,3,0,24.1,77777,9,999999999,100,0.1460,0,88,999.000,999.0,99.0
+1985,3,20,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,-2.8,55,100100,1014,1379,267,766,802,177,81500,81600,21300,5360,40,8.8,5,0,24.1,77777,9,999999999,89,0.1460,0,88,999.000,999.0,99.0
+1985,3,20,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,-3.3,55,100100,1013,1379,264,766,803,177,81600,81700,21300,5350,40,10.3,5,0,24.1,77777,9,999999999,89,0.1460,0,88,999.000,999.0,99.0
+1985,3,20,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-4.4,53,100100,944,1379,261,701,782,167,74400,79300,19900,4530,40,7.2,5,0,24.1,77777,9,999999999,80,0.1460,0,88,999.000,999.0,99.0
+1985,3,20,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-5.6,51,100100,810,1379,263,541,576,204,57600,58900,22900,4750,50,7.7,8,1,24.1,77777,9,999999999,80,0.1460,0,88,999.000,999.0,99.0
+1985,3,20,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-5.6,59,100100,621,1379,258,370,519,138,39600,51100,16500,2770,50,6.7,9,2,24.1,77777,9,999999999,80,0.1460,0,88,999.000,999.0,99.0
+1985,3,20,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-5.6,59,100200,390,1379,258,199,346,103,20800,29900,12300,1940,50,6.7,9,2,24.1,77777,9,999999999,80,0.1460,0,88,999.000,999.0,99.0
+1985,3,20,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-5.6,67,100200,135,1379,251,44,57,39,4800,3100,4500,810,40,6.2,10,2,24.1,77777,9,999999999,80,0.1460,0,88,999.000,999.0,99.0
+1985,3,20,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.0,78,100200,0,57,242,0,0,0,0,0,0,0,30,5.2,7,1,24.1,77777,9,999999999,80,0.1460,0,88,999.000,999.0,99.0
+1985,3,20,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-4.4,82,100200,0,0,243,0,0,0,0,0,0,0,30,5.7,5,1,24.1,77777,9,999999999,80,0.1460,0,88,999.000,999.0,99.0
+1985,3,20,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-4.4,85,100200,0,0,241,0,0,0,0,0,0,0,30,6.7,4,1,24.1,77777,9,999999999,80,0.1460,0,88,999.000,999.0,99.0
+1985,3,20,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-4.4,85,100200,0,0,241,0,0,0,0,0,0,0,40,5.2,3,1,24.1,77777,9,999999999,80,0.1460,0,88,999.000,999.0,99.0
+1985,3,20,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-4.4,89,100200,0,0,239,0,0,0,0,0,0,0,30,3.1,3,1,24.1,77777,9,999999999,80,0.1460,0,88,999.000,999.0,99.0
+1985,3,20,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-4.4,92,100200,0,0,233,0,0,0,0,0,0,0,40,3.1,0,0,24.1,77777,9,999999999,80,0.1460,0,88,999.000,999.0,99.0
+1985,3,21,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-4.4,92,100200,0,0,233,0,0,0,0,0,0,0,40,3.1,0,0,24.1,77777,9,999999999,80,0.1460,0,88,999.000,999.0,99.0
+1985,3,21,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-5.6,85,100100,0,0,232,0,0,0,0,0,0,0,50,3.1,0,0,24.1,77777,9,999999999,80,0.1460,0,88,999.000,999.0,99.0
+1985,3,21,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.6,72,100100,0,0,240,0,0,0,0,0,0,0,70,5.2,0,0,24.1,77777,9,999999999,80,0.1460,0,88,999.000,999.0,99.0
+1985,3,21,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.6,72,100100,0,0,240,0,0,0,0,0,0,0,90,3.1,0,0,24.1,77777,9,999999999,80,0.1460,0,88,999.000,999.0,99.0
+1985,3,21,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.6,72,100100,0,0,240,0,0,0,0,0,0,0,100,4.1,0,0,24.1,77777,9,999999999,80,0.1460,0,88,999.000,999.0,99.0
+1985,3,21,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-5.0,82,100200,1,126,236,1,1,1,0,0,0,0,120,4.6,0,0,24.1,77777,9,999999999,80,0.1040,0,88,999.000,999.0,99.0
+1985,3,21,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-5.0,72,100200,148,1378,242,55,241,30,5700,13900,4200,530,120,5.2,0,0,24.1,77777,9,999999999,80,0.1040,0,88,999.000,999.0,99.0
+1985,3,21,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-6.7,57,100200,402,1378,246,232,597,60,24600,52700,9100,1150,130,5.2,0,0,24.1,77777,9,999999999,69,0.1040,0,88,999.000,999.0,99.0
+1985,3,21,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-7.8,46,100200,632,1378,251,432,765,83,45200,74000,11200,1710,120,7.2,0,0,24.1,77777,9,999999999,69,0.1040,0,88,999.000,999.0,99.0
+1985,3,21,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-8.3,41,100200,820,1378,255,597,831,104,63000,82800,13600,2400,130,5.7,1,0,24.1,77777,9,999999999,69,0.1040,0,88,999.000,999.0,99.0
+1985,3,21,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,-8.9,36,100200,952,1378,258,722,870,122,76400,87400,15800,3210,120,6.2,2,0,24.1,77777,9,999999999,60,0.1040,0,88,999.000,999.0,99.0
+1985,3,21,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,-8.3,34,100100,1020,1378,271,719,827,108,74700,82500,13400,2740,120,6.2,3,1,24.1,77777,9,999999999,69,0.1040,0,88,999.000,999.0,99.0
+1985,3,21,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,-8.3,33,100000,1019,1378,273,731,810,133,77300,81500,16900,3840,120,6.2,4,1,24.1,77777,9,999999999,69,0.1040,0,88,999.000,999.0,99.0
+1985,3,21,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,-8.3,30,99900,949,1378,281,642,671,181,67700,67800,20900,4900,150,5.2,6,2,24.1,77777,9,999999999,69,0.1040,0,88,999.000,999.0,99.0
+1985,3,21,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.8,-8.3,31,99900,815,1378,281,511,558,183,55100,57200,21200,4240,110,5.7,8,3,24.1,77777,9,999999999,69,0.1040,0,88,999.000,999.0,99.0
+1985,3,21,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,-8.3,34,99800,626,1378,279,224,150,156,24800,15200,17800,3770,90,7.2,9,4,24.1,77777,9,999999999,69,0.1040,0,88,999.000,999.0,99.0
+1985,3,21,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,-7.8,37,99800,395,1378,279,160,136,122,17400,12200,13900,2710,70,5.7,10,5,24.1,77777,9,999999999,69,0.1040,0,88,999.000,999.0,99.0
+1985,3,21,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-5.6,55,99700,140,1378,267,41,43,37,4500,2400,4300,770,60,6.7,9,4,24.1,77777,9,999999999,80,0.1040,0,88,999.000,999.0,99.0
+1985,3,21,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-4.4,67,99700,0,80,257,0,0,0,0,0,0,0,50,4.6,6,2,24.1,77777,9,999999999,80,0.1040,0,88,999.000,999.0,99.0
+1985,3,21,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-3.3,79,99700,0,0,256,0,0,0,0,0,0,0,50,3.1,6,3,24.1,77777,9,999999999,89,0.1040,0,88,999.000,999.0,99.0
+1985,3,21,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-3.3,76,99700,0,0,248,0,0,0,0,0,0,0,50,3.1,2,0,24.1,77777,9,999999999,89,0.1040,0,88,999.000,999.0,99.0
+1985,3,21,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-3.9,62,99600,0,0,255,0,0,0,0,0,0,0,80,6.7,0,0,24.1,77777,9,999999999,89,0.1040,0,88,999.000,999.0,99.0
+1985,3,21,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-6.1,55,99600,0,0,251,0,0,0,0,0,0,0,100,6.2,0,0,24.1,77777,9,999999999,80,0.1040,0,88,999.000,999.0,99.0
+1985,3,21,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-7.8,52,99600,0,0,245,0,0,0,0,0,0,0,90,4.6,0,0,24.1,77777,9,999999999,69,0.1040,0,88,999.000,999.0,99.0
+1985,3,22,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-8.3,52,99500,0,0,243,0,0,0,0,0,0,0,80,3.1,0,0,24.1,77777,9,999999999,69,0.1040,0,88,999.000,999.0,99.0
+1985,3,22,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-7.8,59,99500,0,0,244,0,0,0,0,0,0,0,70,3.6,1,1,24.1,77777,9,999999999,69,0.1040,0,88,999.000,999.0,99.0
+1985,3,22,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-7.8,59,99400,0,0,239,0,0,0,0,0,0,0,60,3.1,0,0,24.1,77777,9,999999999,69,0.1040,0,88,999.000,999.0,99.0
+1985,3,22,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-7.2,75,99300,0,0,235,0,0,0,0,0,0,0,50,2.6,3,1,14.5,77777,9,999999999,69,0.1040,0,88,999.000,999.0,99.0
+1985,3,22,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-7.2,75,99400,0,0,235,0,0,0,0,0,0,0,50,2.6,2,1,14.5,77777,9,999999999,69,0.1040,0,88,999.000,999.0,99.0
+1985,3,22,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-6.7,75,99300,2,172,240,0,1,0,0,0,0,0,40,3.1,4,2,19.3,77777,9,999999999,69,0.1350,0,88,999.000,999.0,99.0
+1985,3,22,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-5.6,67,99400,155,1377,254,52,134,37,5500,7000,4700,670,60,3.1,5,3,24.1,77777,9,999999999,80,0.1350,0,88,999.000,999.0,99.0
+1985,3,22,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-4.4,64,99300,410,1377,264,164,227,98,17800,20500,11700,1890,60,4.6,4,4,24.1,77777,9,999999999,80,0.1350,0,88,999.000,999.0,99.0
+1985,3,22,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-4.4,53,99300,639,1377,266,406,631,115,42600,61400,14000,2350,60,5.7,3,1,24.1,77777,9,999999999,80,0.1350,0,88,999.000,999.0,99.0
+1985,3,22,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,-5.0,45,99200,827,1377,275,564,649,175,58700,64600,19800,4020,60,4.6,7,2,24.1,77777,9,999999999,80,0.1350,0,88,999.000,999.0,99.0
+1985,3,22,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,-4.4,45,99200,958,1377,281,624,600,207,65200,60200,23200,5590,30,5.2,7,3,24.1,77777,9,999999999,80,0.1350,0,88,999.000,999.0,99.0
+1985,3,22,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,-3.3,47,99200,1026,1377,299,429,193,285,47600,20600,32200,9240,60,6.2,8,8,24.1,2740,9,999999999,89,0.1350,0,88,999.000,999.0,99.0
+1985,3,22,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,-3.9,47,99100,1024,1377,292,567,415,258,60800,43200,28600,7990,70,6.2,8,7,24.1,2740,9,999999999,89,0.1350,0,88,999.000,999.0,99.0
+1985,3,22,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,-4.4,44,99100,954,1377,293,432,200,294,47600,21200,32900,8830,50,6.2,8,7,24.1,2740,9,999999999,80,0.1350,0,88,999.000,999.0,99.0
+1985,3,22,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,-3.9,46,99000,820,1377,314,223,13,215,25800,1100,25100,9250,50,7.7,10,10,24.1,2740,9,999999999,89,0.1350,0,88,999.000,999.0,99.0
+1985,3,22,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,-3.9,46,99000,631,1377,314,145,9,141,16800,700,16500,5900,40,5.2,10,10,24.1,2740,9,999999999,89,0.1350,0,88,999.000,999.0,99.0
+1985,3,22,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,-3.9,47,99000,400,1377,311,89,6,88,10200,300,10100,3340,30,7.2,10,10,24.1,2440,9,999999999,89,0.1350,0,88,999.000,999.0,99.0
+1985,3,22,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,-3.9,51,98900,145,1377,307,29,2,28,3200,0,3200,980,50,5.7,10,10,24.1,2440,9,999999999,89,0.1350,0,88,999.000,999.0,99.0
+1985,3,22,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,-3.3,53,99000,1,103,307,0,0,0,0,0,0,0,40,5.7,10,10,24.1,2440,9,999999999,89,0.1350,0,88,999.000,999.0,99.0
+1985,3,22,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,-2.2,58,99000,0,0,308,0,0,0,0,0,0,0,40,4.6,10,10,24.1,1680,9,999999999,89,0.1350,0,88,999.000,999.0,99.0
+1985,3,22,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,-2.2,50,99000,0,0,318,0,0,0,0,0,0,0,70,5.2,10,10,24.1,1680,9,999999999,89,0.1350,0,88,999.000,999.0,99.0
+1985,3,22,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,-1.7,54,99000,0,0,316,0,0,0,0,0,0,0,120,5.2,10,10,24.1,1370,9,999999999,100,0.1350,0,88,999.000,999.0,99.0
+1985,3,22,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,-1.1,58,99000,0,0,315,0,0,0,0,0,0,0,120,3.6,10,10,24.1,700,9,999999999,100,0.1350,0,88,999.000,999.0,99.0
+1985,3,22,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,0.0,65,98900,0,0,313,0,0,0,0,0,0,0,120,4.6,10,10,24.1,760,9,999999999,110,0.1350,0,88,999.000,999.0,99.0
+1985,3,23,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,0.0,68,98900,0,0,311,0,0,0,0,0,0,0,90,4.6,10,10,14.5,760,9,999999999,110,0.1350,0,88,999.000,999.0,99.0
+1985,3,23,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,0.0,68,98900,0,0,311,0,0,0,0,0,0,0,80,4.1,10,10,11.3,1010,9,999999999,110,0.1350,0,88,999.000,999.0,99.0
+1985,3,23,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,0.6,76,98800,0,0,306,0,0,0,0,0,0,0,70,4.6,10,10,9.7,700,9,999999999,110,0.1350,0,88,999.000,999.0,99.0
+1985,3,23,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,0.6,76,98800,0,0,306,0,0,0,0,0,0,0,60,3.1,10,10,9.7,1070,9,999999999,110,0.1350,0,88,999.000,999.0,99.0
+1985,3,23,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,0.6,79,98800,0,0,304,0,0,0,0,0,0,0,50,3.1,10,10,8.0,640,9,999999999,110,0.1350,0,88,999.000,999.0,99.0
+1985,3,23,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,1.1,86,98800,2,195,302,1,0,1,0,0,0,0,40,3.1,10,10,8.0,580,9,999999999,110,0.0760,0,88,999.000,999.0,99.0
+1985,3,23,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,1.1,86,98800,162,1376,302,28,3,28,3200,0,3200,1010,60,4.1,10,10,8.0,610,9,999999999,110,0.0760,0,88,999.000,999.0,99.0
+1985,3,23,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,0.6,79,98700,417,1376,304,107,1,106,12000,100,12000,3900,120,4.6,10,10,11.3,490,9,999999999,110,0.0760,0,88,999.000,999.0,99.0
+1985,3,23,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,1.1,79,98700,646,1376,307,114,4,113,13600,300,13400,5010,130,3.6,10,10,6.4,370,9,999999999,110,0.0760,0,88,999.000,999.0,99.0
+1985,3,23,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,2.2,86,98700,833,1376,308,295,2,294,33400,200,33300,11490,140,3.1,10,10,8.0,310,9,999999999,120,0.0760,0,88,999.000,999.0,99.0
+1985,3,23,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,2.8,86,98700,965,1376,311,200,2,199,23900,200,23800,9450,150,2.1,10,10,4.0,270,9,999999999,129,0.0760,0,88,999.000,999.0,99.0
+1985,3,23,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,3.3,89,98600,1032,1376,312,214,2,213,25700,200,25600,10250,170,2.1,10,10,2.4,180,9,999999999,129,0.0760,0,88,999.000,999.0,99.0
+1985,3,23,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,3.9,89,98500,1030,1376,315,230,1,229,27300,100,27300,10850,130,2.1,10,10,2.4,180,9,999999999,129,0.0760,0,88,999.000,999.0,99.0
+1985,3,23,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,3.9,86,98400,959,1376,317,203,1,202,24100,100,24000,9540,160,2.1,10,10,2.4,240,9,999999999,129,0.0760,0,88,999.000,999.0,99.0
+1985,3,23,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,3.9,86,98400,825,1376,317,169,1,168,19900,100,19900,7690,170,3.1,10,10,2.4,240,9,999999999,129,0.0760,0,88,999.000,999.0,99.0
+1985,3,23,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,3.9,86,98300,635,1376,317,219,0,219,24500,0,24500,7960,160,2.6,10,10,2.4,210,9,999999999,129,0.0760,0,88,999.000,999.0,99.0
+1985,3,23,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,4.4,86,98300,404,1376,321,77,1,77,8900,100,8900,3040,140,1.5,10,10,2.4,240,9,999999999,139,0.0760,0,88,999.000,999.0,99.0
+1985,3,23,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,4.4,89,98300,150,1376,318,24,0,24,2800,0,2800,880,120,3.1,10,10,1.6,210,9,999999999,139,0.0760,0,88,999.000,999.0,99.0
+1985,3,23,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,4.4,89,98200,1,126,318,1,0,1,0,0,0,0,90,3.1,10,10,1.6,210,9,999999999,139,0.0760,0,88,999.000,999.0,99.0
+1985,3,23,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,5.0,93,98200,0,0,319,0,0,0,0,0,0,0,270,1.5,10,10,3.2,210,9,999999999,139,0.0760,0,88,999.000,999.0,99.0
+1985,3,23,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,5.0,93,98200,0,0,319,0,0,0,0,0,0,0,230,6.2,10,10,3.2,180,9,999999999,139,0.0760,0,88,999.000,999.0,99.0
+1985,3,23,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,3.9,89,98200,0,0,315,0,0,0,0,0,0,0,230,5.2,10,10,3.2,210,9,999999999,129,0.0760,0,88,999.000,999.0,99.0
+1985,3,23,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,3.9,93,98200,0,0,312,0,0,0,0,0,0,0,230,5.2,10,10,3.2,210,9,999999999,129,0.0760,0,88,999.000,999.0,99.0
+1985,3,23,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,3.3,93,98100,0,0,309,0,0,0,0,0,0,0,220,4.6,10,10,3.2,180,9,999999999,129,0.0760,0,88,999.000,999.0,99.0
+1985,3,24,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,3.3,93,98100,0,0,309,0,0,0,0,0,0,0,220,3.1,10,10,3.2,210,9,999999999,129,0.0760,0,88,999.000,999.0,99.0
+1985,3,24,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,3.3,93,98000,0,0,309,0,0,0,0,0,0,0,210,3.1,10,10,3.2,240,9,999999999,129,0.0760,0,88,999.000,999.0,99.0
+1985,3,24,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,3.3,93,98000,0,0,309,0,0,0,0,0,0,0,200,3.1,10,10,3.2,210,9,999999999,129,0.0760,0,88,999.000,999.0,99.0
+1985,3,24,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,2.8,93,98000,0,0,306,0,0,0,0,0,0,0,220,2.6,10,10,3.2,210,9,999999999,129,0.0760,0,88,999.000,999.0,99.0
+1985,3,24,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,2.8,93,98000,0,0,306,0,0,0,0,0,0,0,230,1.5,10,10,3.2,180,9,999999999,129,0.0760,0,88,999.000,999.0,99.0
+1985,3,24,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,2.8,93,98000,4,241,306,1,0,1,0,0,0,0,290,2.1,10,10,3.2,150,9,999999999,129,0.2100,0,88,999.000,999.0,99.0
+1985,3,24,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,2.8,93,98100,170,1375,306,23,0,23,2700,0,2700,870,0,0.0,10,10,2.4,180,9,999999999,129,0.2100,0,88,999.000,999.0,99.0
+1985,3,24,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,3.3,100,98100,424,1375,304,65,0,65,7600,0,7600,2700,270,3.1,10,10,2.4,120,9,999999999,129,0.2100,0,88,999.000,999.0,99.0
+1985,3,24,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,3.3,96,98200,653,1375,307,126,1,126,14800,100,14800,5500,270,1.5,10,10,2.4,120,9,999999999,129,0.2100,0,88,999.000,999.0,99.0
+1985,3,24,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,3.9,93,98300,840,1375,312,272,1,271,31000,100,30900,10990,40,3.1,10,10,6.4,240,9,999999999,129,0.2100,0,88,999.000,999.0,99.0
+1985,3,24,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,3.9,96,98300,971,1375,310,214,0,214,25400,0,25400,10040,50,5.2,10,10,4.8,210,9,999999999,129,0.2100,0,88,999.000,999.0,99.0
+1985,3,24,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,3.3,89,98400,1037,1375,312,209,0,209,25100,0,25100,10120,30,4.1,10,10,4.8,180,9,999999999,129,0.2100,0,88,999.000,999.0,99.0
+1985,3,24,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,2.8,93,98500,1035,1375,306,365,1,364,41900,100,41800,15110,30,4.6,10,10,4.8,240,9,999999999,129,0.2100,0,88,999.000,999.0,99.0
+1985,3,24,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,3.3,100,98600,964,1375,304,214,1,213,25300,100,25300,9970,30,5.2,10,10,1.2,90,9,999999999,129,0.2100,0,88,999.000,999.0,99.0
+1985,3,24,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,2.2,93,98800,830,1375,303,168,1,167,19800,100,19800,7680,10,7.2,10,10,2.4,120,9,999999999,120,0.2100,0,88,999.000,999.0,99.0
+1985,3,24,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,1.7,93,98900,640,1375,300,186,0,186,21100,0,21100,7240,20,6.2,10,10,6.4,150,9,999999999,120,0.2100,0,88,999.000,999.0,99.0
+1985,3,24,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,1.1,89,99000,409,1375,300,107,0,106,11900,0,11900,3860,40,6.7,10,10,11.3,240,9,999999999,110,0.2100,0,88,999.000,999.0,99.0
+1985,3,24,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,1.1,89,99200,154,1375,300,35,0,35,3900,0,3900,1180,30,7.7,10,10,16.1,240,9,999999999,110,0.2100,0,88,999.000,999.0,99.0
+1985,3,24,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,0.6,89,99200,2,149,297,1,0,1,0,0,0,0,30,8.8,10,10,16.1,270,9,999999999,110,0.2100,0,88,999.000,999.0,99.0
+1985,3,24,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,0.6,89,99400,0,0,297,0,0,0,0,0,0,0,30,7.7,10,10,24.1,270,9,999999999,110,0.2100,0,88,999.000,999.0,99.0
+1985,3,24,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,0.0,85,99500,0,0,296,0,0,0,0,0,0,0,30,7.2,10,10,24.1,270,9,999999999,110,0.2100,0,88,999.000,999.0,99.0
+1985,3,24,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,0.0,85,99600,0,0,296,0,0,0,0,0,0,0,30,7.7,10,10,24.1,310,9,999999999,110,0.2100,0,88,999.000,999.0,99.0
+1985,3,24,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-0.6,85,99700,0,0,293,0,0,0,0,0,0,0,50,6.2,10,10,24.1,340,9,999999999,100,0.2100,0,88,999.000,999.0,99.0
+1985,3,24,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-0.6,85,99800,0,0,293,0,0,0,0,0,0,0,50,6.7,10,10,19.3,370,9,999999999,100,0.2100,0,88,999.000,999.0,99.0
+1985,3,25,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.1,85,99900,0,0,290,0,0,0,0,0,0,0,50,5.7,10,10,14.5,370,9,999999999,100,0.2100,0,88,999.000,999.0,99.0
+1985,3,25,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.7,82,99900,0,0,290,0,0,0,0,0,0,0,40,5.7,10,10,11.3,460,9,999999999,100,0.2100,0,88,999.000,999.0,99.0
+1985,3,25,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.7,82,100000,0,0,290,0,0,0,0,0,0,0,50,5.2,10,10,11.3,460,9,999999999,100,0.2100,0,88,999.000,999.0,99.0
+1985,3,25,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-1.1,82,100000,0,0,293,0,0,0,0,0,0,0,50,5.2,10,10,11.3,400,9,999999999,100,0.2100,0,88,999.000,999.0,99.0
+1985,3,25,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-1.1,82,100100,0,0,293,0,0,0,0,0,0,0,60,4.1,10,10,14.5,460,9,999999999,100,0.2100,0,88,999.000,999.0,99.0
+1985,3,25,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-1.7,79,100100,5,286,292,2,0,2,0,0,0,0,80,4.6,10,10,24.1,520,9,999999999,100,0.0780,0,88,999.000,999.0,99.0
+1985,3,25,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-2.2,76,100200,177,1375,292,43,0,43,4800,0,4800,1430,90,4.1,10,10,24.1,520,9,999999999,100,0.0780,0,88,999.000,999.0,99.0
+1985,3,25,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-1.7,73,100200,431,1375,297,129,0,128,14300,0,14300,4490,80,3.1,10,10,24.1,520,9,999999999,100,0.0780,0,88,999.000,999.0,99.0
+1985,3,25,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-1.1,73,100300,660,1375,300,240,2,240,26900,200,26800,8630,60,3.6,10,10,24.1,520,9,999999999,100,0.0780,0,88,999.000,999.0,99.0
+1985,3,25,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-1.1,70,100400,846,1375,302,282,0,282,32100,0,32100,11330,40,3.1,10,10,24.1,520,9,999999999,100,0.0780,0,88,999.000,999.0,99.0
+1985,3,25,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,-0.6,68,100400,977,1375,308,334,0,333,38200,0,38200,13810,120,2.6,10,10,24.1,520,9,999999999,110,0.0780,0,88,999.000,999.0,99.0
+1985,3,25,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,0.0,68,100400,1043,1375,311,369,2,368,42500,200,42300,15280,120,1.5,10,10,24.1,520,9,999999999,110,0.0780,0,88,999.000,999.0,99.0
+1985,3,25,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,0.0,65,100400,1041,1375,313,381,1,381,43700,100,43700,15580,230,2.1,10,10,19.3,610,9,999999999,110,0.0780,0,88,999.000,999.0,99.0
+1985,3,25,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,0.0,65,100400,969,1375,313,350,1,349,39900,100,39800,14140,0,0.0,10,10,11.3,610,9,999999999,110,0.0780,0,88,999.000,999.0,99.0
+1985,3,25,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,0.0,63,100300,834,1375,316,279,2,278,31700,200,31600,11120,220,2.6,10,10,11.3,760,9,999999999,110,0.0780,0,88,999.000,999.0,99.0
+1985,3,25,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,0.0,63,100300,645,1375,316,228,1,227,25400,100,25300,8220,220,3.6,10,10,11.3,760,9,999999999,110,0.0780,0,88,999.000,999.0,99.0
+1985,3,25,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,0.0,65,100300,414,1375,313,129,0,129,14300,0,14300,4400,210,3.6,10,10,12.9,760,9,999999999,110,0.0780,0,88,999.000,999.0,99.0
+1985,3,25,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,0.0,68,100300,159,1375,285,56,179,36,5900,10000,4800,640,220,2.1,5,5,12.9,77777,9,999999999,110,0.0780,0,88,999.000,999.0,99.0
+1985,3,25,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-0.6,73,100200,2,195,271,2,1,2,0,0,0,0,0,0.0,2,2,16.1,77777,9,999999999,100,0.0780,0,88,999.000,999.0,99.0
+1985,3,25,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-1.1,82,100200,0,0,262,0,0,0,0,0,0,0,130,2.6,2,2,16.1,77777,9,999999999,100,0.0780,0,88,999.000,999.0,99.0
+1985,3,25,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-1.1,82,100300,0,0,262,0,0,0,0,0,0,0,130,3.1,2,2,9.7,77777,9,999999999,100,0.0780,0,88,999.000,999.0,99.0
+1985,3,25,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-1.7,85,100300,0,0,249,0,0,0,0,0,0,0,150,3.1,0,0,9.7,77777,9,999999999,100,0.0780,0,88,999.000,999.0,99.0
+1985,3,25,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-1.1,89,100200,0,0,250,0,0,0,0,0,0,0,170,2.1,0,0,9.7,77777,9,999999999,100,0.0780,0,88,999.000,999.0,99.0
+1985,3,25,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-1.1,92,100200,0,0,247,0,0,0,0,0,0,0,150,2.6,0,0,6.4,77777,9,999999999,100,0.0780,0,88,999.000,999.0,99.0
+1985,3,26,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-1.1,89,100200,0,0,250,0,0,0,0,0,0,0,160,2.1,0,0,6.4,77777,9,999999999,100,0.0780,0,88,999.000,999.0,99.0
+1985,3,26,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-1.7,89,100100,0,0,247,0,0,0,0,0,0,0,170,2.6,0,0,6.4,77777,9,999999999,100,0.0780,0,88,999.000,999.0,99.0
+1985,3,26,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-1.7,92,100100,0,0,245,0,0,0,0,0,0,0,170,3.1,0,0,6.4,77777,9,999999999,100,0.0780,0,88,999.000,999.0,99.0
+1985,3,26,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-1.1,89,100100,0,0,250,0,0,0,0,0,0,0,170,3.1,0,0,6.4,77777,9,999999999,100,0.0780,0,88,999.000,999.0,99.0
+1985,3,26,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-1.1,89,100100,0,0,250,0,0,0,0,0,0,0,170,3.1,0,0,6.4,77777,9,999999999,100,0.0780,0,88,999.000,999.0,99.0
+1985,3,26,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-1.7,89,100100,6,309,247,3,2,2,0,0,0,0,170,3.1,0,0,8.0,77777,9,999999999,100,0.1560,0,88,999.000,999.0,99.0
+1985,3,26,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-0.6,82,100100,184,1374,256,69,212,41,7300,12900,5500,730,190,3.6,0,0,3.2,77777,9,999999999,100,0.1560,0,88,999.000,999.0,99.0
+1985,3,26,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,1.7,74,100000,439,1374,273,245,530,78,25600,47600,10400,1470,190,5.2,0,0,6.4,77777,9,999999999,120,0.1560,0,88,999.000,999.0,99.0
+1985,3,26,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,2.2,66,99900,667,1374,282,438,682,108,46300,67100,13600,2280,200,7.2,0,0,8.0,77777,9,999999999,120,0.1560,0,88,999.000,999.0,99.0
+1985,3,26,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,2.8,57,99900,852,1374,294,604,765,131,64600,77500,16300,3250,190,8.8,0,0,11.3,77777,9,999999999,129,0.1560,0,88,999.000,999.0,99.0
+1985,3,26,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,3.3,53,99800,983,1374,302,724,796,156,77600,81300,19300,4560,190,8.2,2,0,16.1,77777,9,999999999,129,0.1560,0,88,999.000,999.0,99.0
+1985,3,26,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,3.9,48,99600,1049,1374,312,798,753,224,83800,76000,25600,7100,190,7.7,9,0,16.1,77777,9,999999999,139,0.1560,0,88,999.000,999.0,99.0
+1985,3,26,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,4.4,46,99500,1046,1374,323,734,652,239,76800,65500,26700,7460,220,7.7,10,1,16.1,77777,9,999999999,139,0.1560,0,88,999.000,999.0,99.0
+1985,3,26,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,5.0,45,99400,974,1374,329,688,637,237,74000,66100,26900,6760,200,10.3,8,1,16.1,77777,9,999999999,150,0.1560,0,88,999.000,999.0,99.0
+1985,3,26,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,5.6,45,99300,839,1374,337,561,628,179,58500,62500,20200,4180,190,9.8,5,2,16.1,77777,9,999999999,150,0.1560,0,88,999.000,999.0,99.0
+1985,3,26,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,5.0,43,99200,649,1374,336,393,460,178,41300,45600,19700,3720,190,8.8,9,2,16.1,77777,9,999999999,139,0.1560,0,88,999.000,999.0,99.0
+1985,3,26,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,5.0,45,99100,419,1374,329,213,412,90,22800,36700,11600,1670,190,8.2,6,1,16.1,77777,9,999999999,139,0.1560,0,88,999.000,999.0,99.0
+1985,3,26,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,4.4,46,99000,164,1374,328,54,90,43,5700,4900,5100,800,180,10.3,8,2,16.1,77777,9,999999999,139,0.1560,0,88,999.000,999.0,99.0
+1985,3,26,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,4.4,50,98900,3,218,323,1,0,1,0,0,0,0,190,11.3,8,2,16.1,77777,9,999999999,139,0.1560,0,88,999.000,999.0,99.0
+1985,3,26,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,4.4,51,98900,0,0,326,0,0,0,0,0,0,0,190,8.8,9,4,16.1,77777,9,999999999,139,0.1560,0,88,999.000,999.0,99.0
+1985,3,26,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,4.4,51,98900,0,0,348,0,0,0,0,0,0,0,200,8.2,10,9,19.3,6100,9,999999999,139,0.1560,0,88,999.000,999.0,99.0
+1985,3,26,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,3.9,49,98700,0,0,347,0,0,0,0,0,0,0,190,10.3,10,9,19.3,6100,9,999999999,129,0.1560,0,88,999.000,999.0,99.0
+1985,3,26,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,3.9,49,98700,0,0,347,0,0,0,0,0,0,0,190,11.3,10,9,19.3,6100,9,999999999,129,0.1560,0,88,999.000,999.0,99.0
+1985,3,26,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,3.9,48,98700,0,0,360,0,0,0,0,0,0,0,200,8.8,10,10,19.3,2440,9,999999999,139,0.1560,0,88,999.000,999.0,99.0
+1985,3,27,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,6.1,64,98600,0,0,352,0,0,0,0,0,0,0,190,7.7,10,10,11.3,1680,9,999999999,150,0.1560,0,88,999.000,999.0,99.0
+1985,3,27,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,6.7,67,98400,0,0,343,0,0,0,0,0,0,0,190,8.8,9,9,11.3,2740,9,999999999,160,0.1560,0,88,999.000,999.0,99.0
+1985,3,27,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,6.7,62,98300,0,0,348,0,0,0,0,0,0,0,190,8.2,10,9,14.5,2440,9,999999999,160,0.1560,0,88,999.000,999.0,99.0
+1985,3,27,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,6.7,62,98200,0,0,348,0,0,0,0,0,0,0,200,7.7,10,9,19.3,2440,9,999999999,160,0.1560,0,88,999.000,999.0,99.0
+1985,3,27,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,7.8,65,98100,0,0,362,0,0,0,0,0,0,0,190,6.7,10,10,8.0,1680,9,999999999,170,0.1560,0,88,999.000,999.0,99.0
+1985,3,27,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,8.3,75,98100,8,355,354,0,0,0,0,0,0,0,190,7.7,10,10,8.0,910,9,999999999,179,0.0930,0,88,999.000,999.0,99.0
+1985,3,27,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,9.4,80,98000,192,1373,356,19,4,18,2200,0,2200,720,210,7.2,10,10,9.7,2440,9,999999999,189,0.0930,0,88,999.000,999.0,99.0
+1985,3,27,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,10.0,80,97900,446,1373,359,115,6,113,13000,400,12900,4220,230,9.3,10,10,11.3,2130,9,999999999,189,0.0930,0,88,999.000,999.0,99.0
+1985,3,27,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,11.1,87,97900,674,1373,360,101,3,99,12000,200,11900,4560,220,6.7,10,10,8.0,400,9,999999999,209,0.0930,0,88,999.000,999.0,99.0
+1985,3,27,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,11.7,87,97900,859,1373,364,137,4,134,16500,300,16300,6500,210,6.2,10,10,4.8,310,9,999999999,209,0.0930,0,88,999.000,999.0,99.0
+1985,3,27,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,12.2,87,97900,989,1373,367,272,4,270,31900,400,31600,12070,230,7.7,10,10,11.3,370,9,999999999,220,0.0930,0,88,999.000,999.0,99.0
+1985,3,27,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,12.8,73,97900,1054,1373,367,528,335,272,58500,36300,30500,8660,240,7.2,8,8,16.1,910,9,999999999,229,0.0930,0,88,999.000,999.0,99.0
+1985,3,27,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,10.0,55,97900,1051,1373,356,633,583,188,67400,59400,21800,6110,270,9.8,4,4,16.1,77777,9,999999999,189,0.0930,0,88,999.000,999.0,99.0
+1985,3,27,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,10.6,55,98000,979,1373,370,468,309,248,51600,33400,27800,7050,250,9.8,8,7,24.1,910,9,999999999,200,0.0930,0,88,999.000,999.0,99.0
+1985,3,27,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,11.7,55,98000,844,1373,376,399,151,307,43400,15800,33700,8420,270,8.2,8,7,24.1,910,9,999999999,209,0.0930,0,88,999.000,999.0,99.0
+1985,3,27,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,11.1,59,98000,654,1373,367,267,191,177,29500,19500,20200,4340,280,6.2,10,7,24.1,7620,9,999999999,209,0.0930,0,88,999.000,999.0,99.0
+1985,3,27,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,10.0,59,98100,423,1373,385,112,1,112,12600,100,12600,4080,270,5.2,10,10,24.1,7620,9,999999999,189,0.0930,0,88,999.000,999.0,99.0
+1985,3,27,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,8.9,65,98100,169,1373,336,56,74,48,6200,4500,5600,1010,270,3.1,8,4,24.1,77777,9,999999999,179,0.0930,0,88,999.000,999.0,99.0
+1985,3,27,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,8.3,69,98100,3,240,333,2,0,2,0,0,0,0,0,0.0,8,6,24.1,7620,9,999999999,170,0.0930,0,88,999.000,999.0,99.0
+1985,3,27,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,8.3,75,98100,0,0,320,0,0,0,0,0,0,0,0,0.0,6,3,24.1,77777,9,999999999,179,0.0930,0,88,999.000,999.0,99.0
+1985,3,27,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,8.9,72,98000,0,0,351,0,0,0,0,0,0,0,140,3.1,10,9,24.1,7620,9,999999999,179,0.0930,0,88,999.000,999.0,99.0
+1985,3,27,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,8.9,75,97900,0,0,357,0,0,0,0,0,0,0,120,3.6,10,10,24.1,6710,9,999999999,179,0.0930,0,88,999.000,999.0,99.0
+1985,3,27,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,8.9,75,97800,0,0,357,0,0,0,0,0,0,0,110,6.2,10,10,16.1,700,9,999999999,179,0.0930,0,88,999.000,999.0,99.0
+1985,3,27,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,10.6,87,97700,0,0,357,0,0,0,0,0,0,0,170,3.6,10,10,11.3,700,9,999999999,200,0.0930,0,88,999.000,999.0,99.0
+1985,3,28,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,13.3,97,97600,0,0,366,0,0,0,0,0,0,0,160,4.6,10,10,6.4,310,9,999999999,229,0.0930,0,88,999.000,999.0,99.0
+1985,3,28,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,12.8,90,97400,0,0,368,0,0,0,0,0,0,0,210,11.3,10,10,8.0,370,9,999999999,229,0.0930,0,88,999.000,999.0,99.0
+1985,3,28,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,13.9,93,97400,0,0,372,0,0,0,0,0,0,0,270,8.8,10,10,14.5,700,9,999999999,240,0.0930,0,88,999.000,999.0,99.0
+1985,3,28,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,6.7,96,97400,0,0,326,0,0,0,0,0,0,0,10,5.7,10,10,8.0,700,9,999999999,160,0.0930,0,88,999.000,999.0,99.0
+1985,3,28,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,6.1,96,97600,0,0,323,0,0,0,0,0,0,0,40,4.6,10,10,6.4,210,9,999999999,150,0.0930,0,88,999.000,999.0,99.0
+1985,3,28,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,5.6,96,97800,10,400,319,0,0,0,0,0,0,0,30,5.2,10,10,6.4,210,9,999999999,150,0.1090,0,88,999.000,999.0,99.0
+1985,3,28,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,5.6,96,97700,199,1372,310,33,23,29,3600,1700,3300,770,60,2.6,9,9,11.3,910,9,999999999,150,0.1090,0,88,999.000,999.0,99.0
+1985,3,28,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,6.1,93,97700,453,1372,316,140,83,113,15400,7800,12800,2560,60,3.6,9,9,8.0,910,9,999999999,150,0.1090,0,88,999.000,999.0,99.0
+1985,3,28,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,6.1,93,97700,680,1372,325,83,5,81,10200,300,10000,3850,10,4.6,10,10,4.8,1010,9,999999999,150,0.1090,0,88,999.000,999.0,99.0
+1985,3,28,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,7.2,93,97700,865,1372,331,123,6,119,15000,400,14700,5880,40,4.1,10,10,8.0,1070,9,999999999,160,0.1090,0,88,999.000,999.0,99.0
+1985,3,28,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,5.6,96,97700,994,1372,319,303,3,301,35100,300,34900,13070,30,4.1,10,10,6.4,580,9,999999999,150,0.1090,0,88,999.000,999.0,99.0
+1985,3,28,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,5.0,93,97700,1060,1372,319,286,6,281,33600,500,33200,12840,50,4.1,10,10,6.4,610,9,999999999,139,0.1090,0,88,999.000,999.0,99.0
+1985,3,28,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,3.9,93,97700,1056,1372,312,342,7,336,39600,700,39100,14530,50,5.2,10,10,6.4,370,9,999999999,129,0.1090,0,88,999.000,999.0,99.0
+1985,3,28,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,4.4,93,97600,984,1372,316,271,1,270,31600,100,31500,12050,20,5.7,10,10,6.4,310,9,999999999,139,0.1090,0,88,999.000,999.0,99.0
+1985,3,28,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,5.6,100,97500,848,1372,317,168,6,164,19900,500,19600,7650,50,6.2,10,10,3.2,90,9,999999999,150,0.1090,0,88,999.000,999.0,99.0
+1985,3,28,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,6.7,100,97400,659,1372,323,201,4,199,22700,300,22600,7710,80,4.6,10,10,3.2,180,9,999999999,160,0.1090,0,88,999.000,999.0,99.0
+1985,3,28,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,7.2,100,97400,428,1372,326,69,0,69,8100,0,8100,2840,40,4.1,10,10,3.2,180,9,999999999,160,0.1090,0,88,999.000,999.0,99.0
+1985,3,28,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,7.2,100,97400,173,1372,326,23,0,23,2700,0,2700,880,40,3.1,10,10,3.2,180,9,999999999,160,0.1090,0,88,999.000,999.0,99.0
+1985,3,28,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.8,7.8,100,97500,4,263,330,2,0,2,0,0,0,0,40,2.6,10,10,2.0,60,9,999999999,170,0.1090,0,88,999.000,999.0,99.0
+1985,3,28,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,7.2,100,97600,0,0,326,0,0,0,0,0,0,0,0,0.0,10,10,1.2,30,9,999999999,160,0.1090,0,88,999.000,999.0,99.0
+1985,3,28,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,7.2,100,97700,0,0,310,0,0,0,0,0,0,0,260,2.1,8,8,0.2,60,9,999999999,160,0.1090,0,88,999.000,999.0,99.0
+1985,3,28,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,7.8,100,97800,0,0,330,0,0,0,0,0,0,0,270,2.6,10,10,0.6,60,9,999999999,170,0.1090,0,88,999.000,999.0,99.0
+1985,3,28,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,7.8,93,97900,0,0,335,0,0,0,0,0,0,0,250,4.1,10,10,2.4,90,9,999999999,170,0.1090,0,88,999.000,999.0,99.0
+1985,3,28,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,8.9,93,98000,0,0,341,0,0,0,0,0,0,0,270,5.2,10,10,6.4,180,9,999999999,179,0.1090,0,88,999.000,999.0,99.0
+1985,3,29,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,8.3,86,98000,0,0,343,0,0,0,0,0,0,0,300,5.2,10,10,8.0,210,9,999999999,170,0.1090,0,88,999.000,999.0,99.0
+1985,3,29,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,7.8,86,98200,0,0,340,0,0,0,0,0,0,0,270,6.2,10,10,12.9,610,9,999999999,170,0.1090,0,88,999.000,999.0,99.0
+1985,3,29,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,6.7,86,98300,0,0,289,0,0,0,0,0,0,0,280,4.1,0,0,16.1,77777,9,999999999,160,0.1090,0,88,999.000,999.0,99.0
+1985,3,29,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,5.6,86,98300,0,0,283,0,0,0,0,0,0,0,310,4.1,0,0,16.1,77777,9,999999999,150,0.1090,0,88,999.000,999.0,99.0
+1985,3,29,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,5.0,89,98400,0,0,306,0,0,0,0,0,0,0,260,2.1,8,8,16.1,2740,9,999999999,139,0.1090,0,88,999.000,999.0,99.0
+1985,3,29,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,4.4,93,98500,12,446,301,2,0,2,0,0,0,0,260,2.6,10,8,24.1,2740,9,999999999,139,0.0820,0,88,999.000,999.0,99.0
+1985,3,29,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,5.0,93,98700,206,1371,319,61,4,60,6700,100,6700,1900,270,3.1,10,10,24.1,2440,9,999999999,139,0.0820,0,88,999.000,999.0,99.0
+1985,3,29,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,5.0,86,98700,460,1371,324,112,3,111,12700,200,12700,4240,300,2.6,10,10,16.1,2440,9,999999999,139,0.0820,0,88,999.000,999.0,99.0
+1985,3,29,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,5.6,77,98700,687,1371,335,231,3,229,25900,300,25800,8660,290,2.6,10,10,16.1,2440,9,999999999,150,0.0820,0,88,999.000,999.0,99.0
+1985,3,29,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,5.6,74,98800,871,1371,338,256,6,252,29500,500,29200,10730,300,3.1,10,10,16.1,2440,9,999999999,150,0.0820,0,88,999.000,999.0,99.0
+1985,3,29,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,5.6,66,98800,1000,1371,346,331,5,328,38200,500,37900,13890,280,2.6,10,10,19.3,2440,9,999999999,150,0.0820,0,88,999.000,999.0,99.0
+1985,3,29,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,5.6,62,98800,1065,1371,351,354,4,352,41100,400,40800,15040,300,3.1,10,10,24.1,2440,9,999999999,150,0.0820,0,88,999.000,999.0,99.0
+1985,3,29,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,5.6,60,98800,1061,1371,354,374,5,370,43100,500,42700,15500,300,2.6,10,10,24.1,2440,9,999999999,150,0.0820,0,88,999.000,999.0,99.0
+1985,3,29,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,3.3,51,98800,989,1371,351,305,3,302,35200,300,35000,13060,340,3.6,10,10,24.1,2440,9,999999999,129,0.0820,0,88,999.000,999.0,99.0
+1985,3,29,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,5.6,72,98900,853,1371,340,305,0,305,34500,0,34500,11960,80,6.2,10,10,24.1,2440,9,999999999,150,0.0820,0,88,999.000,999.0,99.0
+1985,3,29,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,4.4,83,99000,663,1371,323,146,0,146,16900,0,16900,6220,50,5.2,10,10,16.1,2440,9,999999999,139,0.0820,0,88,999.000,999.0,99.0
+1985,3,29,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,3.3,86,99200,432,1371,315,125,0,124,13900,0,13900,4420,60,7.2,10,10,16.1,640,9,999999999,129,0.0820,0,88,999.000,999.0,99.0
+1985,3,29,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,2.2,83,99200,178,1371,311,41,0,41,4600,0,4600,1390,60,5.2,10,10,16.1,700,9,999999999,120,0.0820,0,88,999.000,999.0,99.0
+1985,3,29,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,1.7,82,99200,5,286,307,3,0,3,0,0,0,0,80,4.6,10,10,16.1,760,9,999999999,120,0.0820,0,88,999.000,999.0,99.0
+1985,3,29,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,2.2,89,99200,0,0,306,0,0,0,0,0,0,0,40,7.7,10,10,16.1,610,9,999999999,120,0.0820,0,88,999.000,999.0,99.0
+1985,3,29,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,1.1,86,99300,0,0,302,0,0,0,0,0,0,0,30,6.7,10,10,16.1,760,9,999999999,110,0.0820,0,88,999.000,999.0,99.0
+1985,3,29,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,0.6,89,99300,0,0,297,0,0,0,0,0,0,0,30,7.7,10,10,19.3,760,9,999999999,110,0.0820,0,88,999.000,999.0,99.0
+1985,3,29,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,0.0,85,99400,0,0,296,0,0,0,0,0,0,0,30,6.7,10,10,19.3,340,9,999999999,110,0.0820,0,88,999.000,999.0,99.0
+1985,3,29,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,0.0,89,99500,0,0,294,0,0,0,0,0,0,0,30,7.7,10,10,24.1,460,9,999999999,110,0.0820,0,88,999.000,999.0,99.0
+1985,3,30,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-0.6,85,99500,0,0,293,0,0,0,0,0,0,0,30,6.2,10,10,24.1,340,9,999999999,100,0.0820,0,88,999.000,999.0,99.0
+1985,3,30,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-0.6,85,99500,0,0,293,0,0,0,0,0,0,0,20,6.7,10,10,24.1,340,9,999999999,100,0.0820,0,88,999.000,999.0,99.0
+1985,3,30,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-0.6,85,99600,0,0,293,0,0,0,0,0,0,0,30,7.2,10,10,24.1,610,9,999999999,100,0.0820,0,88,999.000,999.0,99.0
+1985,3,30,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.1,85,99500,0,0,290,0,0,0,0,0,0,0,40,8.8,10,10,24.1,460,9,999999999,100,0.0820,0,88,999.000,999.0,99.0
+1985,3,30,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.1,85,99500,0,0,290,0,0,0,0,0,0,0,40,8.2,10,10,24.1,370,9,999999999,100,0.0820,0,88,999.000,999.0,99.0
+1985,3,30,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-1.1,85,99600,14,468,290,4,0,4,0,0,0,0,40,7.2,10,10,6.4,310,9,999999999,100,0.1080,0,88,999.000,999.0,99.0
+1985,3,30,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-0.6,89,99700,214,1371,291,49,0,49,5500,0,5500,1690,40,7.2,10,10,6.4,310,9,999999999,100,0.1080,0,88,999.000,999.0,99.0
+1985,3,30,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,0.0,85,99600,467,1371,296,138,1,138,15500,100,15400,4940,60,7.2,10,10,11.3,310,9,999999999,110,0.1080,0,88,999.000,999.0,99.0
+1985,3,30,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-1.1,79,99600,693,1371,295,225,0,225,25400,0,25400,8630,70,7.7,10,10,12.9,310,9,999999999,100,0.1080,0,88,999.000,999.0,99.0
+1985,3,30,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-1.1,79,99600,877,1371,295,290,0,290,33100,0,33100,11830,70,8.8,10,10,16.1,310,9,999999999,100,0.1080,0,88,999.000,999.0,99.0
+1985,3,30,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-1.1,82,99600,1006,1371,293,349,1,349,40100,100,40100,14500,50,8.8,10,10,24.1,310,9,999999999,100,0.1080,0,88,999.000,999.0,99.0
+1985,3,30,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-1.1,82,99600,1070,1371,293,408,1,407,46700,100,46600,16490,60,8.2,10,10,24.1,310,9,999999999,100,0.1080,0,88,999.000,999.0,99.0
+1985,3,30,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-1.1,82,99600,1066,1371,293,385,1,384,44200,100,44200,15900,50,9.3,10,10,4.0,400,9,999999999,100,0.1080,0,88,999.000,999.0,99.0
+1985,3,30,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-0.6,85,99500,993,1371,293,343,1,342,39300,100,39300,14210,50,8.8,10,10,16.1,430,9,999999999,100,0.1080,0,88,999.000,999.0,99.0
+1985,3,30,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-1.7,85,99500,857,1371,287,318,1,317,35900,100,35800,12280,50,9.3,10,10,19.3,520,9,999999999,100,0.1080,0,88,999.000,999.0,99.0
+1985,3,30,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-1.7,82,99400,668,1371,290,220,1,220,24800,100,24700,8290,50,10.8,10,10,16.1,580,9,999999999,100,0.1080,0,88,999.000,999.0,99.0
+1985,3,30,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-1.7,76,99400,437,1371,294,140,1,140,15500,100,15500,4790,70,9.3,10,10,16.1,1520,9,999999999,100,0.1080,0,88,999.000,999.0,99.0
+1985,3,30,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-1.7,70,99300,182,1371,299,47,0,47,5200,0,5200,1540,60,8.2,10,10,14.5,1520,9,999999999,100,0.1080,0,88,999.000,999.0,99.0
+1985,3,30,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-1.1,79,99200,6,308,295,3,0,3,0,0,0,0,60,8.2,10,10,16.1,1520,9,999999999,100,0.1080,0,88,999.000,999.0,99.0
+1985,3,30,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-1.1,79,99000,0,0,295,0,0,0,0,0,0,0,70,9.3,10,10,16.1,1160,9,999999999,100,0.1080,0,88,999.000,999.0,99.0
+1985,3,30,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-1.1,79,98900,0,0,295,0,0,0,0,0,0,0,80,9.3,10,10,16.1,1010,9,999999999,100,0.1080,0,88,999.000,999.0,99.0
+1985,3,30,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-1.1,79,99000,0,0,295,0,0,0,0,0,0,0,100,7.7,10,10,16.1,640,9,999999999,100,0.1080,0,88,999.000,999.0,99.0
+1985,3,30,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-0.6,85,98900,0,0,293,0,0,0,0,0,0,0,80,7.2,10,10,8.0,340,9,999999999,100,0.1080,0,88,999.000,999.0,99.0
+1985,3,30,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,0.6,92,98700,0,0,294,0,0,0,0,0,0,0,80,7.2,10,10,6.4,240,9,999999999,110,0.1080,0,88,999.000,999.0,99.0
+1985,3,31,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,0.6,92,98500,0,0,294,0,0,0,0,0,0,0,80,8.2,10,10,8.0,270,9,999999999,110,0.1080,0,88,999.000,999.0,99.0
+1985,3,31,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,0.6,92,98300,0,0,294,0,0,0,0,0,0,0,90,8.8,10,10,6.4,210,9,999999999,110,0.1080,0,88,999.000,999.0,99.0
+1985,3,31,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,0.6,92,98100,0,0,294,0,0,0,0,0,0,0,90,8.8,10,10,6.4,180,9,999999999,110,0.1080,0,88,999.000,999.0,99.0
+1985,3,31,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,0.6,92,97800,0,0,294,0,0,0,0,0,0,0,90,9.8,10,10,6.4,150,9,999999999,110,0.1080,0,88,999.000,999.0,99.0
+1985,3,31,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,1.1,93,97700,0,0,297,0,0,0,0,0,0,0,110,7.7,10,10,6.4,150,9,999999999,110,0.1080,0,88,999.000,999.0,99.0
+1985,3,31,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,2.2,96,97400,17,514,301,4,0,4,0,0,0,0,110,8.8,10,10,6.4,180,9,999999999,120,0.1030,0,88,999.000,999.0,99.0
+1985,3,31,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,2.2,96,97300,221,1370,301,33,0,33,3800,0,3800,1260,120,6.2,10,10,9.7,180,9,999999999,120,0.1030,0,88,999.000,999.0,99.0
+1985,3,31,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,2.8,93,97200,474,1370,306,91,1,91,10600,100,10600,3700,120,5.7,10,10,2.4,150,9,999999999,120,0.1030,0,88,999.000,999.0,99.0
+1985,3,31,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,3.9,96,97100,700,1370,310,147,1,146,17100,100,17100,6390,160,6.2,10,10,2.4,120,9,999999999,129,0.1030,0,88,999.000,999.0,99.0
+1985,3,31,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,5.6,96,97100,883,1370,319,293,2,292,33500,200,33400,11940,230,7.7,10,10,24.1,370,9,999999999,150,0.1030,0,88,999.000,999.0,99.0
+1985,3,31,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,5.6,93,97100,1011,1370,322,349,1,348,40100,100,40000,14530,210,9.3,10,10,24.1,520,9,999999999,150,0.1030,0,88,999.000,999.0,99.0
+1985,3,31,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.8,3.3,74,97000,1075,1370,325,370,0,370,42700,0,42700,15610,230,8.2,10,10,24.1,640,9,999999999,129,0.1030,0,88,999.000,999.0,99.0
+1985,3,31,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,2.2,76,97000,1071,1370,316,225,1,224,27000,100,26900,10830,240,9.3,10,10,11.3,640,9,999999999,120,0.1030,0,88,999.000,999.0,99.0
+1985,3,31,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,1.7,79,97000,998,1370,310,203,0,203,24300,0,24300,9750,210,11.3,10,10,24.1,640,9,999999999,120,0.1030,0,88,999.000,999.0,99.0
+1985,3,31,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,0.0,73,97000,862,1370,306,284,1,284,32500,100,32400,11550,230,12.9,10,10,24.1,880,9,999999999,100,0.1030,0,88,999.000,999.0,99.0
+1985,3,31,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,0.0,82,97100,672,1370,299,127,1,126,14900,100,14800,5580,230,10.3,10,10,19.3,880,9,999999999,100,0.1030,0,88,999.000,999.0,99.0
+1985,3,31,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,0.0,100,97200,441,1370,287,75,0,75,8700,0,8700,3080,240,10.3,10,10,3.2,270,9,999999999,100,0.1030,0,88,999.000,999.0,99.0
+1985,3,31,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-1.1,85,97200,187,1370,290,29,0,29,3400,0,3400,1080,230,11.3,10,10,3.2,760,9,999999999,100,0.1030,0,88,999.000,999.0,99.0
+1985,3,31,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-1.7,85,97300,7,331,287,2,0,2,0,0,0,0,230,12.4,10,10,9.7,700,9,999999999,100,0.1030,0,88,999.000,999.0,99.0
+1985,3,31,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-2.2,85,97400,0,0,284,0,0,0,0,0,0,0,230,9.3,10,10,8.0,760,9,999999999,89,0.1030,0,88,999.000,999.0,99.0
+1985,3,31,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-2.8,82,97400,0,0,284,0,0,0,0,0,0,0,260,10.3,10,10,9.7,700,9,999999999,89,0.1030,0,88,999.000,999.0,99.0
+1985,3,31,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.1,-3.0,85,97600,0,0,283,0,0,0,0,0,0,0,260,9.3,10,10,9.7,700,9,999999999,89,0.1030,0,88,999.000,999.0,99.0
+1985,3,31,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.4,-3.3,82,97600,0,0,282,0,0,0,0,0,0,0,260,8.2,10,10,12.9,1010,9,999999999,89,0.1030,0,88,999.000,999.0,99.0
+1985,3,31,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-3.6,75,97700,0,0,280,0,0,0,0,0,0,0,260,7.2,10,10,16.1,1010,9,999999999,80,0.1030,0,88,999.000,999.0,99.0
+2002,4,1,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-0.9,-4.0,66,99200,0,0,242,0,0,0,0,0,0,0,280,6.2,0,0,16.0,77777,9,999999999,50,0.1400,0,88,0.160,0.0,1.0
+2002,4,1,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-1.1,-4.3,72,99200,0,0,241,0,0,0,0,0,0,0,280,5.2,0,0,16.0,77777,9,999999999,50,0.1400,0,88,0.160,0.0,1.0
+2002,4,1,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-1.4,-4.6,72,99100,0,0,239,0,0,0,0,0,0,0,290,4.1,0,0,16.0,77777,9,999999999,50,0.1400,0,88,0.160,0.0,1.0
+2002,4,1,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-1.7,-5.0,76,99200,0,0,238,0,0,0,0,0,0,0,290,3.1,0,0,16.0,77777,9,999999999,50,0.1400,0,88,0.160,0.0,1.0
+2002,4,1,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-2.2,-5.6,75,99200,0,0,236,0,0,0,0,0,0,0,250,2.1,0,0,16.0,77777,9,999999999,60,0.1400,0,88,0.160,0.0,1.0
+2002,4,1,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-2.8,-5.0,83,99300,19,536,234,0,0,0,0,0,0,0,250,1.5,0,0,16.0,77777,9,999999999,60,0.1400,0,88,0.160,0.0,1.0
+2002,4,1,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-1.1,-4.4,76,99300,227,1369,241,124,236,85,12700,15800,10100,1740,270,2.6,0,0,16.0,77777,9,999999999,60,0.1400,0,88,0.160,0.0,1.0
+2002,4,1,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.1,-5.0,61,99300,480,1369,248,298,488,127,31000,45200,15100,2450,0,0.0,0,0,16.0,77777,9,999999999,69,0.1400,0,88,0.160,0.0,1.0
+2002,4,1,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,-5.6,53,99400,705,1369,262,485,602,174,51300,60600,20000,3730,300,1.5,3,3,16.0,77777,9,999999999,69,0.1400,0,88,0.160,0.0,1.0
+2002,4,1,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,-5.0,50,99300,889,1369,284,554,395,297,59400,42200,32000,8000,330,2.6,8,8,16.0,7620,9,999999999,80,0.1400,0,88,0.160,0.0,1.0
+2002,4,1,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,-5.6,47,99200,1016,1369,273,328,42,297,36200,4300,33000,11250,0,0.0,6,5,16.0,6096,9,999999999,89,0.1400,0,88,0.160,0.0,1.0
+2002,4,1,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,4.4,-4.4,51,99200,1080,1369,282,267,12,257,31700,1000,30900,12100,260,3.6,8,7,16.0,6096,9,999999999,100,0.1400,0,88,0.160,0.0,1.0
+2002,4,1,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,4.4,-5.6,46,99200,1075,1369,291,167,0,167,20500,0,20500,8490,190,2.1,9,9,16.0,4572,9,999999999,110,0.1400,0,88,0.160,0.0,1.0
+2002,4,1,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.8,-1.1,75,99100,1002,1369,297,157,0,157,19200,0,19200,7880,190,2.6,10,10,4.0,671,9,999999999,120,0.1400,0,88,0.160,0.0,1.0
+2002,4,1,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.6,0.0,96,99000,866,1369,289,131,0,131,15900,0,15900,6400,0,0.0,10,10,0.8,152,9,999999999,139,0.1400,0,88,0.160,1.0,1.0
+2002,4,1,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.6,0.6,100,98900,676,1369,290,82,0,82,10000,0,10000,3880,130,1.5,10,10,1.6,152,9,999999999,139,0.1400,0,88,0.160,1.0,1.0
+2002,4,1,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.6,0.0,96,99000,445,1369,289,75,0,75,8800,0,8800,3090,0,0.0,10,10,1.6,152,9,999999999,150,0.1400,0,88,0.160,1.0,1.0
+2002,4,1,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.6,0.0,96,98900,191,1369,289,38,0,38,4300,0,4300,1350,110,3.1,10,10,1.6,213,9,999999999,150,0.1400,0,88,0.160,1.0,1.0
+2002,4,1,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.6,0.0,96,98800,8,354,289,0,0,0,0,0,0,0,90,4.1,10,10,4.8,91,9,999999999,160,0.1400,0,88,0.160,0.0,1.0
+2002,4,1,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.1,0.0,92,98800,0,0,291,0,0,0,0,0,0,0,80,5.2,10,10,4.8,91,9,999999999,160,0.1400,0,88,0.160,0.0,1.0
+2002,4,1,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.1,0.6,96,98800,0,0,292,0,0,0,0,0,0,0,80,4.6,10,10,4.8,914,9,999999999,160,0.1400,0,88,0.160,0.0,1.0
+2002,4,1,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.7,0.0,88,98700,0,0,294,0,0,0,0,0,0,0,100,5.2,10,10,8.0,152,9,999999999,170,0.1400,0,88,0.160,0.0,1.0
+2002,4,1,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.7,0.0,88,98600,0,0,294,0,0,0,0,0,0,0,80,4.6,10,10,8.0,152,9,999999999,170,0.1400,0,88,0.160,0.0,1.0
+2002,4,1,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,0.0,85,98500,0,0,296,0,0,0,0,0,0,0,80,5.2,10,10,8.0,152,9,999999999,170,0.1400,0,88,0.160,0.0,1.0
+2002,4,2,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,0.0,85,98300,0,0,296,0,0,0,0,0,0,0,90,5.7,10,10,9.6,213,9,999999999,179,0.1410,0,88,0.160,0.0,1.0
+2002,4,2,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,0.0,85,98300,0,0,296,0,0,0,0,0,0,0,90,4.6,10,10,9.6,213,9,999999999,179,0.1410,0,88,0.160,0.0,1.0
+2002,4,2,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,1.3,94,98200,0,0,283,0,0,0,0,0,0,0,60,3.6,8,8,11.2,213,9,999999999,179,0.1410,0,88,0.160,0.0,1.0
+2002,4,2,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,1.5,95,98200,0,0,298,0,0,0,0,0,0,0,40,4.6,10,10,9.6,213,9,999999999,189,0.1410,0,88,0.160,0.0,1.0
+2002,4,2,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.8,2.2,96,98300,0,0,301,0,0,0,0,0,0,0,10,3.6,10,10,8.0,792,9,999999999,200,0.1410,0,88,0.160,0.0,1.0
+2002,4,2,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.3,2.8,97,98200,22,581,304,0,0,0,0,0,0,0,30,4.1,10,10,8.0,640,9,999999999,209,0.1410,0,88,0.160,0.0,1.0
+2002,4,2,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.3,2.8,97,98100,234,1368,304,51,0,51,5800,0,5800,1800,30,4.1,10,10,4.0,183,9,999999999,209,0.1410,0,88,0.160,0.0,1.0
+2002,4,2,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.3,2.8,97,98100,486,1368,304,51,0,51,6200,0,6200,2290,40,5.2,10,10,4.0,183,9,999999999,209,0.1410,0,88,0.160,0.0,1.0
+2002,4,2,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,4.4,3.3,93,98200,712,1368,309,338,166,252,36700,17100,27800,6370,70,2.1,10,10,4.0,183,9,999999999,209,0.1410,0,88,0.160,0.0,1.0
+2002,4,2,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,3.9,89,98300,894,1368,315,274,18,262,31600,1600,30600,11210,320,3.1,10,10,4.8,244,9,999999999,200,0.1410,0,88,0.160,0.0,1.0
+2002,4,2,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,3.9,86,98200,1022,1368,317,347,30,324,38200,3100,35900,12170,320,6.7,10,10,8.0,305,9,999999999,189,0.1410,0,88,0.160,0.0,1.0
+2002,4,2,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,3.3,82,98300,1085,1368,317,188,6,183,22900,500,22600,9200,300,5.7,10,10,8.0,305,9,999999999,189,0.1410,0,88,0.160,0.0,1.0
+2002,4,2,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,3.3,82,98400,1080,1368,317,339,24,320,39600,2200,37900,14210,310,7.2,10,10,14.4,427,9,999999999,170,0.1410,0,88,0.160,0.0,1.0
+2002,4,2,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.7,2.8,76,98400,1006,1368,319,233,6,229,27700,500,27300,10770,320,8.8,10,10,16.0,427,9,999999999,160,0.1410,0,88,0.160,0.0,1.0
+2002,4,2,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,2.2,76,98500,870,1368,316,170,0,170,20200,0,20200,7980,300,6.2,10,10,16.0,488,9,999999999,150,0.1410,0,88,0.160,0.0,1.0
+2002,4,2,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.0,1.7,79,98600,680,1368,310,104,0,104,12400,0,12400,4780,300,6.7,10,10,12.8,488,9,999999999,139,0.1410,0,88,0.160,0.0,1.0
+2002,4,2,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,1.1,82,98700,450,1368,305,60,0,60,7100,0,7100,2580,310,6.2,10,10,9.6,488,9,999999999,120,0.1410,0,88,0.160,0.0,1.0
+2002,4,2,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,0.6,79,98800,196,1368,304,19,0,19,2300,0,2300,760,310,7.7,10,10,9.6,457,9,999999999,100,0.1410,0,88,0.160,0.0,1.0
+2002,4,2,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.8,-0.6,78,98900,9,376,298,0,0,0,0,0,0,0,300,9.3,10,10,16.0,640,9,999999999,100,0.1410,0,88,0.160,0.0,1.0
+2002,4,2,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.3,-1.1,72,99000,0,0,300,0,0,0,0,0,0,0,310,7.2,10,10,16.0,701,9,999999999,89,0.1410,0,88,0.160,0.0,1.0
+2002,4,2,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.8,-1.1,75,99100,0,0,297,0,0,0,0,0,0,0,310,7.2,10,10,16.0,579,9,999999999,80,0.1410,0,88,0.160,0.0,1.0
+2002,4,2,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,-1.1,78,99100,0,0,295,0,0,0,0,0,0,0,330,6.7,10,10,11.2,488,9,999999999,80,0.1410,0,88,0.160,0.0,1.0
+2002,4,2,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,-1.7,74,99200,0,0,294,0,0,0,0,0,0,0,350,6.7,10,10,9.6,457,9,999999999,80,0.1410,0,88,0.160,0.0,1.0
+2002,4,2,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.1,-2.2,77,99300,0,0,289,0,0,0,0,0,0,0,360,4.1,10,10,12.8,9144,9,999999999,80,0.1410,0,88,0.160,0.0,1.0
+2002,4,3,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.0,-2.2,83,99400,0,0,257,0,0,0,0,0,0,0,340,4.6,8,3,16.0,77777,9,999999999,80,0.1420,0,88,0.160,0.0,1.0
+2002,4,3,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.0,-2.8,79,99500,0,0,284,0,0,0,0,0,0,0,350,5.7,10,10,16.0,549,9,999999999,69,0.1420,0,88,0.160,0.0,1.0
+2002,4,3,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-0.6,-3.3,80,99500,0,0,258,0,0,0,0,0,0,0,330,3.6,10,5,16.0,77777,9,999999999,69,0.1420,0,88,0.160,0.0,1.0
+2002,4,3,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-0.6,-2.8,83,99600,0,0,252,0,0,0,0,0,0,0,310,3.6,7,2,16.0,77777,9,999999999,69,0.1420,0,88,0.160,0.0,1.0
+2002,4,3,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-1.1,-2.2,91,99700,0,0,272,0,0,0,0,0,0,0,310,2.1,10,9,16.0,2286,9,999999999,69,0.1420,0,88,0.160,0.0,1.0
+2002,4,3,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-0.6,-2.2,88,99800,25,627,264,0,0,0,0,0,0,0,310,3.1,10,7,16.0,1676,9,999999999,69,0.1420,0,88,0.160,0.0,1.0
+2002,4,3,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.0,-1.1,91,99800,241,1367,286,119,87,104,13000,7000,11800,2200,310,3.6,10,10,12.8,1524,9,999999999,69,0.1420,0,88,0.160,0.0,1.0
+2002,4,3,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.1,-0.6,88,99900,493,1367,283,101,0,101,11700,0,11700,4090,290,3.6,10,9,14.4,1524,9,999999999,69,0.1420,0,88,0.160,0.0,1.0
+2002,4,3,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,-2.2,71,100000,718,1367,286,152,0,152,17800,0,17800,6680,310,4.1,10,9,16.0,1463,9,999999999,69,0.1420,0,88,0.160,0.0,1.0
+2002,4,3,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,-1.7,74,100000,900,1367,294,197,0,197,23300,0,23300,9110,300,2.6,10,10,16.0,1372,9,999999999,69,0.1420,0,88,0.160,0.0,1.0
+2002,4,3,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.3,-3.3,60,100000,1027,1367,297,229,6,225,27400,500,27000,10710,320,6.2,10,10,16.0,1463,9,999999999,69,0.1420,0,88,0.160,0.0,1.0
+2002,4,3,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.3,-3.3,60,100000,1090,1367,297,267,6,262,31700,500,31300,12320,310,5.2,10,10,16.0,16764,9,999999999,69,0.1420,0,88,0.160,0.0,1.0
+2002,4,3,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,4.4,-3.9,53,100100,1084,1367,301,232,12,222,27900,1000,27100,10800,270,5.2,10,10,16.0,1829,9,999999999,69,0.1420,0,88,0.160,0.0,1.0
+2002,4,3,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.3,-1.7,69,100100,1011,1367,299,647,424,333,70000,45800,36100,10340,320,4.6,10,10,16.0,1829,9,999999999,69,0.1420,0,88,0.160,0.0,1.0
+2002,4,3,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,-2.2,63,100200,874,1367,301,545,469,245,57400,48300,26500,6210,310,3.6,10,10,16.0,2134,9,999999999,69,0.1420,0,88,0.160,0.0,1.0
+2002,4,3,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.3,-1.7,69,100200,684,1367,299,409,423,197,42600,42300,21300,4230,310,5.2,10,10,16.0,2134,9,999999999,69,0.1420,0,88,0.160,0.0,1.0
+2002,4,3,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,0.0,85,100300,454,1367,296,247,360,127,25500,32800,14500,2450,0,0.0,10,10,6.4,914,9,999999999,69,0.1420,0,88,0.160,0.0,1.0
+2002,4,3,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,-1.1,78,100300,200,1367,295,81,189,53,8500,11800,6800,990,310,5.7,10,10,16.0,1981,9,999999999,69,0.1420,0,88,0.160,0.0,1.0
+2002,4,3,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.7,-2.2,74,100300,10,399,292,0,0,0,0,0,0,0,280,3.1,10,10,16.0,1433,9,999999999,69,0.1420,0,88,0.160,0.0,1.0
+2002,4,3,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.1,-2.2,77,100400,0,0,289,0,0,0,0,0,0,0,300,3.1,10,10,16.0,1981,9,999999999,60,0.1420,0,88,0.160,0.0,1.0
+2002,4,3,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.1,-1.7,80,100400,0,0,282,0,0,0,0,0,0,0,280,3.1,10,9,16.0,914,9,999999999,60,0.1420,0,88,0.160,0.0,1.0
+2002,4,3,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.6,-1.7,83,100400,0,0,287,0,0,0,0,0,0,0,360,3.1,10,10,12.8,762,9,999999999,60,0.1420,0,88,0.160,0.0,1.0
+2002,4,3,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.0,-3.3,76,100500,0,0,283,0,0,0,0,0,0,0,350,4.1,10,10,14.4,914,9,999999999,60,0.1420,0,88,0.160,0.0,1.0
+2002,4,3,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.0,-3.9,72,100400,0,0,283,0,0,0,0,0,0,0,340,4.1,10,10,9.6,10790,9,999999999,60,0.1420,0,88,0.160,0.0,1.0
+2002,4,4,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-0.6,-5.6,66,100400,0,0,271,0,0,0,0,0,0,0,360,2.1,9,9,16.0,1158,9,999999999,60,0.1430,0,88,0.160,0.0,1.0
+2002,4,4,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-0.6,-5.0,69,100400,0,0,279,0,0,0,0,0,0,0,350,2.6,10,10,16.0,1341,9,999999999,69,0.1430,0,88,0.160,0.0,1.0
+2002,4,4,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-0.6,-5.6,66,100400,0,0,278,0,0,0,0,0,0,0,350,3.6,10,10,16.0,1524,9,999999999,69,0.1430,0,88,0.160,0.0,1.0
+2002,4,4,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-1.1,-5.6,68,100500,0,0,276,0,0,0,0,0,0,0,330,4.1,10,10,16.0,1524,9,999999999,69,0.1430,0,88,0.160,0.0,1.0
+2002,4,4,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-1.1,-6.7,62,100500,0,0,275,0,0,0,0,0,0,0,330,4.1,10,10,16.0,1676,9,999999999,69,0.1430,0,88,0.160,0.0,1.0
+2002,4,4,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-1.1,-6.1,66,100600,28,672,276,0,0,0,0,0,0,0,310,3.1,10,10,16.0,1524,9,999999999,60,0.1430,0,88,0.160,0.0,1.0
+2002,4,4,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-0.6,-5.6,66,100600,248,1367,278,126,151,99,13400,11100,11400,2120,320,3.6,10,10,16.0,1524,9,999999999,69,0.1430,0,88,0.160,0.0,1.0
+2002,4,4,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.0,-5.0,66,100600,500,1367,268,201,101,164,22000,9600,18500,4380,310,3.1,8,8,16.0,1524,9,999999999,69,0.1430,0,88,0.160,0.0,1.0
+2002,4,4,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.6,-8.3,47,100600,724,1367,267,437,374,238,46500,39100,25700,5620,270,2.1,8,8,16.0,1463,9,999999999,69,0.1430,0,88,0.160,0.0,1.0
+2002,4,4,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.1,-6.7,52,100600,906,1367,284,565,394,303,60700,42200,32600,8320,300,3.6,10,10,16.0,1372,9,999999999,69,0.1430,0,88,0.160,0.0,1.0
+2002,4,4,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,-6.1,51,100600,1032,1367,276,241,12,232,28700,1000,28000,11000,310,2.6,8,8,16.0,1067,9,999999999,60,0.1430,0,88,0.160,0.0,1.0
+2002,4,4,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,-3.9,62,100600,1095,1367,292,188,0,188,22900,0,22900,9430,320,4.1,10,10,16.0,9022,9,999999999,60,0.1430,0,88,0.160,0.0,1.0
+2002,4,4,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.7,-3.3,67,100600,1089,1367,290,184,0,184,22500,0,22500,9250,320,4.6,10,10,16.0,884,9,999999999,60,0.1430,0,88,0.160,0.0,1.0
+2002,4,4,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.7,-2.8,70,100500,1015,1367,291,175,0,175,21200,0,21200,8690,360,3.6,10,10,12.8,792,9,999999999,60,0.1430,0,88,0.160,0.0,1.0
+2002,4,4,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.1,-2.2,77,100500,879,1367,289,131,0,131,15900,0,15900,6440,40,3.6,10,10,12.8,792,9,999999999,60,0.1430,0,88,0.160,0.0,1.0
+2002,4,4,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.6,-2.2,80,100500,689,1367,287,98,0,98,11800,0,11800,4570,50,3.6,10,10,8.0,792,9,999999999,60,0.1430,0,88,0.160,0.0,1.0
+2002,4,4,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.0,-1.7,87,100500,458,1367,285,86,0,86,10000,0,10000,3490,50,2.6,10,10,1.6,792,9,999999999,60,0.1430,0,88,0.160,0.0,1.0
+2002,4,4,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.0,-1.1,91,100500,205,1367,286,39,0,39,4400,0,4400,1410,50,2.6,10,10,2.4,488,9,999999999,69,0.1430,0,88,0.160,0.0,1.0
+2002,4,4,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.0,-1.7,87,100600,12,444,285,0,0,0,0,0,0,0,40,2.6,10,10,9.6,305,9,999999999,69,0.1430,0,88,0.160,0.0,1.0
+2002,4,4,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-0.6,-1.1,96,100600,0,0,283,0,0,0,0,0,0,0,20,2.1,10,10,6.4,1676,9,999999999,60,0.1430,0,88,0.160,0.0,1.0
+2002,4,4,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-0.6,-1.7,91,100600,0,0,282,0,0,0,0,0,0,0,0,0.0,10,10,12.8,1494,9,999999999,60,0.1430,0,88,0.160,0.0,1.0
+2002,4,4,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-1.7,-1.7,100,100600,0,0,255,0,0,0,0,0,0,0,0,0.0,5,5,16.0,77777,9,999999999,60,0.1430,0,88,0.160,0.0,1.0
+2002,4,4,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-1.1,-1.7,95,100500,0,0,257,0,0,0,0,0,0,0,0,0.0,5,5,12.8,77777,9,999999999,50,0.1430,0,88,0.160,0.0,1.0
+2002,4,4,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-3.9,-3.9,100,100500,0,0,245,0,0,0,0,0,0,0,0,0.0,5,5,11.2,77777,9,999999999,50,0.1430,0,88,0.160,0.0,1.0
+2002,4,5,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-3.3,-3.3,100,100500,0,0,246,0,0,0,0,0,0,0,0,0.0,4,4,4.8,77777,9,999999999,50,0.1440,0,88,0.160,0.0,1.0
+2002,4,5,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-3.9,-3.9,100,100400,0,0,231,0,0,0,0,0,0,0,220,1.5,0,0,6.4,77777,9,999999999,50,0.1440,0,88,0.160,0.0,1.0
+2002,4,5,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-3.3,-3.3,100,100400,0,0,234,0,0,0,0,0,0,0,300,2.1,0,0,8.0,77777,9,999999999,50,0.1440,0,88,0.160,0.0,1.0
+2002,4,5,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-3.3,-3.9,95,100400,0,0,256,0,0,0,0,0,0,0,0,0.0,8,8,6.4,2438,9,999999999,50,0.1440,0,88,0.160,0.0,1.0
+2002,4,5,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-3.9,-4.4,96,100500,0,0,254,0,0,0,0,0,0,0,260,1.5,8,8,9.6,2438,9,999999999,50,0.1440,0,88,0.160,0.0,1.0
+2002,4,5,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-3.9,-4.4,96,100500,31,694,243,0,18,0,0,0,0,0,0,0.0,4,4,11.2,4572,9,999999999,50,0.1440,0,88,0.160,0.0,1.0
+2002,4,5,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-2.2,-3.9,87,100500,255,1366,247,115,114,93,12200,8600,10600,1990,250,1.5,3,3,8.0,77777,9,999999999,60,0.1440,0,88,0.160,0.0,1.0
+2002,4,5,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.0,-4.4,69,100600,506,1366,269,251,214,171,27100,20600,19400,3950,260,2.6,8,8,14.4,2591,9,999999999,60,0.1440,0,88,0.160,0.0,1.0
+2002,4,5,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.7,-4.4,61,100500,731,1366,275,390,264,249,41500,27600,26700,5960,260,3.1,8,8,16.0,1676,9,999999999,69,0.1440,0,88,0.160,0.0,1.0
+2002,4,5,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.3,-3.9,57,100500,912,1366,297,502,261,327,54600,27500,36200,9510,310,5.7,10,10,16.0,1524,9,999999999,69,0.1440,0,88,0.160,0.0,1.0
+2002,4,5,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.8,-3.3,62,100500,1038,1366,281,365,36,337,40200,3700,37400,12800,280,5.7,8,8,16.0,2743,9,999999999,69,0.1440,0,88,0.160,0.0,1.0
+2002,4,5,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.3,-3.9,57,100400,1100,1366,282,345,18,331,40400,1600,39100,14670,280,5.2,8,8,16.0,1676,9,999999999,69,0.1440,0,88,0.160,0.0,1.0
+2002,4,5,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,4.4,-4.4,51,100400,1093,1366,301,381,30,357,42000,3100,39600,14310,320,5.7,10,10,16.0,2286,9,999999999,69,0.1440,0,88,0.160,0.0,1.0
+2002,4,5,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.0,-4.4,48,100300,1019,1366,303,181,0,181,21900,0,21900,8950,310,6.2,10,10,16.0,1676,9,999999999,69,0.1440,0,88,0.160,0.0,1.0
+2002,4,5,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,4.4,-5.0,48,100300,883,1366,300,119,0,119,14600,0,14600,5940,290,6.2,10,10,16.0,1524,9,999999999,69,0.1440,0,88,0.160,0.0,1.0
+2002,4,5,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.0,-4.4,48,100300,693,1366,303,213,18,204,24200,1500,23500,8120,320,4.1,10,10,16.0,1494,9,999999999,69,0.1440,0,88,0.160,0.0,1.0
+2002,4,5,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.8,-3.9,59,100300,463,1366,294,106,0,106,12100,0,12100,4120,70,4.6,10,10,16.0,1402,9,999999999,69,0.1440,0,88,0.160,0.0,1.0
+2002,4,5,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,-3.9,62,100300,209,1366,273,90,160,66,9400,10200,7800,1290,40,2.1,7,7,16.0,1981,9,999999999,69,0.1440,0,88,0.160,0.0,1.0
+2002,4,5,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,-3.9,62,100300,13,467,292,0,0,0,0,0,0,0,360,1.5,10,10,16.0,2286,9,999999999,60,0.1440,0,88,0.160,0.0,1.0
+2002,4,5,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.6,-3.3,73,100300,0,0,272,0,0,0,0,0,0,0,60,5.2,8,8,16.0,2134,9,999999999,60,0.1440,0,88,0.160,0.0,1.0
+2002,4,5,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.0,-3.9,72,100400,0,0,256,0,0,0,0,0,0,0,70,2.6,3,3,16.0,77777,9,999999999,60,0.1440,0,88,0.160,0.0,1.0
+2002,4,5,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.0,-4.4,69,100400,0,0,274,0,0,0,0,0,0,0,70,2.1,9,9,16.0,1981,9,999999999,50,0.1440,0,88,0.160,0.0,1.0
+2002,4,5,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-1.1,-4.4,76,100400,0,0,270,0,0,0,0,0,0,0,0,0.0,9,9,16.0,1981,9,999999999,50,0.1440,0,88,0.160,0.0,1.0
+2002,4,5,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-2.2,-4.4,83,100400,0,0,251,0,0,0,0,0,0,0,0,0.0,5,5,16.0,77777,9,999999999,50,0.1440,0,88,0.160,0.0,1.0
+2002,4,6,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-2.2,-4.4,83,100400,0,0,247,0,0,0,0,0,0,0,0,0.0,3,3,12.8,77777,9,999999999,50,0.1450,0,88,0.160,0.0,1.0
+2002,4,6,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-2.8,-4.4,87,100400,0,0,245,0,0,0,0,0,0,0,0,0.0,3,3,11.2,77777,9,999999999,50,0.1450,0,88,0.160,0.0,1.0
+2002,4,6,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-2.2,-4.4,83,100400,0,0,237,0,0,0,0,0,0,0,310,1.5,0,0,12.8,77777,9,999999999,40,0.1450,0,88,0.160,0.0,1.0
+2002,4,6,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-2.8,-5.0,83,100400,0,0,234,0,0,0,0,0,0,0,0,0.0,0,0,12.8,77777,9,999999999,50,0.1450,0,88,0.160,0.0,1.0
+2002,4,6,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-3.3,-5.0,87,100500,0,0,232,0,0,0,0,0,0,0,0,0.0,0,0,11.2,77777,9,999999999,50,0.1450,0,88,0.160,0.0,1.0
+2002,4,6,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-2.8,-5.0,83,100600,35,739,234,1,54,1,400,3000,300,40,300,1.5,0,0,14.4,77777,9,999999999,50,0.1450,0,88,0.160,0.0,1.0
+2002,4,6,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,-0.6,-5.0,69,100600,262,1365,242,150,297,93,15500,21700,11300,1890,330,1.5,0,0,11.2,77777,9,999999999,50,0.1450,0,88,0.160,0.0,1.0
+2002,4,6,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.7,-6.1,53,100600,513,1365,249,329,523,132,34300,49400,15700,2570,10,2.1,0,0,16.0,77777,9,999999999,50,0.1450,0,88,0.160,0.0,1.0
+2002,4,6,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,-6.1,51,100700,737,1365,264,489,570,180,51800,57700,20600,3950,0,0.0,4,4,16.0,77777,9,999999999,60,0.1450,0,88,0.160,0.0,1.0
+2002,4,6,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.8,-7.2,44,100700,917,1365,265,660,704,186,69100,70800,21400,4840,50,2.1,4,4,16.0,77777,9,999999999,60,0.1450,0,88,0.160,0.0,1.0
+2002,4,6,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.0,-6.1,42,100600,1043,1365,275,767,736,203,80900,74700,23700,6520,90,3.6,4,4,16.0,77777,9,999999999,69,0.1450,0,88,0.160,0.0,1.0
+2002,4,6,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,4.4,-5.6,46,100600,1104,1365,285,782,631,270,81300,63300,30000,9630,80,3.6,8,8,16.0,1494,9,999999999,69,0.1450,0,88,0.160,0.0,1.0
+2002,4,6,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,-4.4,46,100500,1098,1365,279,815,749,211,86200,76200,24800,7620,130,4.6,4,4,16.0,77777,9,999999999,69,0.1450,0,88,0.160,0.0,1.0
+2002,4,6,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,-5.0,43,100400,1023,1365,293,740,722,197,78000,73200,23000,6110,150,4.1,8,8,16.0,1524,9,999999999,80,0.1450,0,88,0.160,0.0,1.0
+2002,4,6,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,-5.0,43,100300,887,1365,280,637,712,172,66600,71600,20000,4330,110,6.7,4,4,16.0,6096,9,999999999,80,0.1450,0,88,0.160,0.0,1.0
+2002,4,6,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,-5.0,44,100300,697,1365,276,454,547,174,47900,55000,19800,3710,120,5.2,3,3,16.0,7620,9,999999999,80,0.1450,0,88,0.160,0.0,1.0
+2002,4,6,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,-5.6,42,100200,467,1365,264,259,384,127,26800,35300,14700,2450,140,6.2,0,0,16.0,7620,9,999999999,80,0.1450,0,88,0.160,0.0,1.0
+2002,4,6,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,-6.1,45,100100,214,1365,272,99,290,54,10300,19200,7300,980,130,6.2,8,5,16.0,77777,9,999999999,80,0.1450,0,88,0.160,0.0,1.0
+2002,4,6,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.7,-5.0,58,100100,15,489,250,0,0,0,0,0,0,0,150,5.7,0,0,16.0,77777,9,999999999,89,0.1450,0,88,0.160,0.0,1.0
+2002,4,6,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.6,-3.9,69,100000,0,0,258,0,0,0,0,0,0,0,150,5.2,3,3,16.0,7620,9,999999999,100,0.1450,0,88,0.160,0.0,1.0
+2002,4,6,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.6,-3.9,69,99900,0,0,260,0,0,0,0,0,0,0,160,3.6,5,4,16.0,7620,9,999999999,120,0.1450,0,88,0.160,0.0,1.0
+2002,4,6,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,-5.6,53,99800,0,0,282,0,0,0,0,0,0,0,160,5.2,10,9,16.0,7620,9,999999999,120,0.1450,0,88,0.160,0.0,1.0
+2002,4,6,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.3,-5.6,49,99700,0,0,276,0,0,0,0,0,0,0,170,5.7,9,7,16.0,7620,9,999999999,120,0.1450,0,88,0.160,0.0,1.0
+2002,4,6,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.8,-6.1,49,99600,0,0,284,0,0,0,0,0,0,0,170,9.3,10,9,16.0,7620,9,999999999,120,0.1450,0,88,0.160,0.0,1.0
+2002,4,7,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.8,-6.1,49,99500,0,0,284,0,0,0,0,0,0,0,180,6.7,9,9,16.0,7620,9,999999999,129,0.1460,0,88,0.160,0.0,1.0
+2002,4,7,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9*9?9?9?9*9*9?9*9*9,2.9,-6.3,48,99500,0,0,284,0,0,0,0,0,0,0,190,6.2,9,9,16.0,7620,9,999999999,129,0.1460,0,88,0.160,999.0,99.0
+2002,4,7,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.8,-6.7,46,99500,0,0,283,0,0,0,0,0,0,0,190,5.7,9,9,16.0,7620,9,999999999,139,0.1460,0,88,0.160,0.0,1.0
+2002,4,7,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.8,-6.7,46,99400,0,0,283,0,0,0,0,0,0,0,190,6.7,10,9,16.0,7620,9,999999999,150,0.1460,0,88,0.160,0.0,1.0
+2002,4,7,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.8,-5.6,51,99400,0,0,269,0,0,0,0,0,0,0,180,7.2,10,5,16.0,7620,9,999999999,160,0.1460,0,88,0.160,0.0,1.0
+2002,4,7,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.3,-5.6,49,99400,39,784,287,1,0,1,100,0,100,40,190,6.7,10,9,16.0,2286,9,999999999,170,0.1460,0,88,0.160,0.0,1.0
+2002,4,7,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.8,-3.9,59,99400,269,1364,294,46,0,46,5300,0,5300,1750,190,5.7,10,10,16.0,1981,9,999999999,189,0.1460,0,88,0.160,0.0,1.0
+2002,4,7,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.7,-1.1,81,99500,519,1364,293,57,0,57,6900,0,6900,2580,190,4.1,10,10,8.0,1067,9,999999999,209,0.1460,0,88,0.160,1.0,1.0
+2002,4,7,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.7,0.0,88,99400,743,1364,294,92,0,92,11200,0,11200,4450,190,5.7,10,10,9.6,1372,9,999999999,220,0.1460,0,88,0.160,1.0,1.0
+2002,4,7,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,0.0,85,99400,923,1364,296,127,0,127,15600,0,15600,6390,180,6.2,10,10,8.0,1829,9,999999999,229,0.1460,0,88,0.160,1.0,1.0
+2002,4,7,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.8,1.1,89,99300,1048,1364,300,136,0,136,16900,0,16900,7050,180,4.6,10,10,9.6,1829,9,999999999,229,0.1460,0,88,0.160,1.0,1.0
+2002,4,7,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,2.8,93,99200,1109,1364,306,158,0,158,19600,0,19600,8150,180,5.7,10,10,6.4,762,9,999999999,240,0.1460,0,88,0.160,1.0,1.0
+2002,4,7,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.0,3.9,93,99200,1102,1364,293,155,0,155,19200,0,19200,8000,180,5.7,10,7,12.8,4572,9,999999999,240,0.1460,0,88,0.160,0.0,1.0
+2002,4,7,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,5.0,96,99100,1028,1364,316,169,0,169,20600,0,20600,8470,180,5.2,10,10,12.8,1676,9,999999999,250,0.1460,0,88,0.160,0.0,1.0
+2002,4,7,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,5.0,93,99100,891,1364,319,136,0,136,16500,0,16500,6690,180,4.6,10,10,9.6,1067,9,999999999,250,0.1460,0,88,0.160,0.0,1.0
+2002,4,7,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,5.0,93,99000,701,1364,319,142,0,142,16600,0,16600,6260,180,3.1,10,10,11.2,1676,9,999999999,250,0.1460,0,88,0.160,0.0,1.0
+2002,4,7,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.7,5.0,89,99000,471,1364,321,71,0,71,8400,0,8400,3020,180,2.6,10,10,12.8,1676,9,999999999,250,0.1460,0,88,0.160,0.0,1.0
+2002,4,7,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.2,5.0,86,98900,218,1364,324,44,0,44,5000,0,5000,1580,180,2.1,10,10,16.0,1981,9,999999999,240,0.1460,0,88,0.160,0.0,1.0
+2002,4,7,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,5.0,82,99000,16,512,326,0,0,0,0,0,0,0,210,3.1,10,10,12.8,1829,9,999999999,250,0.1460,0,88,0.160,0.0,1.0
+2002,4,7,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,5.6,83,99000,0,0,329,0,0,0,0,0,0,0,220,3.6,10,10,12.8,1524,9,999999999,250,0.1460,0,88,0.160,0.0,1.0
+2002,4,7,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.9,6.7,86,99000,0,0,334,0,0,0,0,0,0,0,210,5.7,10,10,12.8,1524,9,999999999,259,0.1460,0,88,0.160,0.0,1.0
+2002,4,7,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.9,7.8,93,99000,0,0,335,0,0,0,0,0,0,0,210,6.2,10,10,11.2,1036,9,999999999,259,0.1460,0,88,0.160,0.0,1.0
+2002,4,7,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,9.4,7.8,90,99000,0,0,337,0,0,0,0,0,0,0,210,6.7,10,10,12.8,1128,9,999999999,250,0.1460,0,88,0.160,0.0,1.0
+2002,4,7,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,9.4,7.8,90,98900,0,0,337,0,0,0,0,0,0,0,210,5.7,10,10,11.2,1067,9,999999999,250,0.1460,0,88,0.160,0.0,1.0
+2002,4,8,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.9,7.8,93,98900,0,0,335,0,0,0,0,0,0,0,200,3.6,10,10,8.0,975,9,999999999,259,0.1470,0,88,0.160,0.0,1.0
+2002,4,8,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.9,7.8,93,98800,0,0,335,0,0,0,0,0,0,0,220,3.1,10,10,11.2,853,9,999999999,259,0.1470,0,88,0.160,0.0,1.0
+2002,4,8,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.9,7.8,93,98800,0,0,335,0,0,0,0,0,0,0,200,1.5,10,10,11.2,792,9,999999999,270,0.1470,0,88,0.160,0.0,1.0
+2002,4,8,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.9,7.8,93,98800,0,0,335,0,0,0,0,0,0,0,210,2.1,10,10,11.2,701,9,999999999,270,0.1470,0,88,0.160,0.0,1.0
+2002,4,8,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,7.2,93,98800,0,0,331,0,0,0,0,0,0,0,0,0.0,10,10,8.0,640,9,999999999,270,0.1470,0,88,0.160,0.0,1.0
+2002,4,8,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,8.3,100,98800,42,807,332,1,0,1,100,0,100,40,140,2.1,10,10,1.2,305,9,999999999,279,0.1470,0,88,0.160,0.0,1.0
+2002,4,8,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.9,8.3,96,98800,276,1363,335,55,0,55,6300,0,6300,2030,150,3.1,10,10,1.6,152,9,999999999,279,0.1470,0,88,0.160,0.0,1.0
+2002,4,8,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,9.4,8.9,97,98800,526,1363,338,71,0,71,8500,0,8500,3140,0,0.0,10,10,1.6,152,9,999999999,290,0.1470,0,88,0.160,0.0,1.0
+2002,4,8,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,9.4,9.4,100,98700,748,1363,339,99,0,99,12000,0,12000,4760,150,3.6,10,10,2.8,213,9,999999999,300,0.1470,0,88,0.160,0.0,1.0
+2002,4,8,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.0,9.4,96,98700,928,1363,342,108,0,108,13400,0,13400,5540,150,4.6,10,10,2.0,152,9,999999999,300,0.1470,0,88,0.160,1.0,1.0
+2002,4,8,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.6,10.6,100,98600,1053,1363,346,130,0,130,16200,0,16200,6790,150,3.1,10,10,3.2,152,9,999999999,309,0.1470,0,88,0.160,1.0,1.0
+2002,4,8,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.6,10.6,100,98500,1113,1363,346,133,0,133,16700,0,16700,7000,140,3.1,10,10,3.2,2316,9,999999999,309,0.1470,0,88,0.160,2.0,1.0
+2002,4,8,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.1,10.6,97,98400,1106,1363,349,137,0,137,17100,0,17100,7180,110,2.6,10,10,3.2,213,9,999999999,320,0.1470,0,88,0.160,2.0,1.0
+2002,4,8,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.1,11.1,100,98300,1032,1363,349,140,0,140,17300,0,17300,7210,60,3.6,10,10,2.4,213,9,999999999,320,0.1470,0,88,0.160,1.0,1.0
+2002,4,8,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.1,11.1,100,98200,895,1363,349,114,0,114,14000,0,14000,5750,90,2.6,10,10,2.4,152,9,999999999,320,0.1470,0,88,0.160,0.0,1.0
+2002,4,8,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.6,10.6,100,98200,705,1363,346,110,0,110,13200,0,13200,5090,60,3.1,10,10,1.6,152,9,999999999,320,0.1470,0,88,0.160,0.0,1.0
+2002,4,8,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.6,10.6,100,98200,475,1363,346,61,0,61,7300,0,7300,2660,50,2.6,10,10,1.6,152,9,999999999,320,0.1470,0,88,0.160,1.0,1.0
+2002,4,8,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.6,10.6,100,98100,223,1363,346,28,0,28,3300,0,3300,1100,10,2.6,10,10,0.8,61,9,999999999,320,0.1470,0,88,0.160,0.0,1.0
+2002,4,8,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.9,8.9,100,98200,18,534,336,0,0,0,0,0,0,0,360,4.6,10,10,0.4,61,9,999999999,309,0.1470,0,88,0.160,0.0,1.0
+2002,4,8,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,7.2,96,98200,0,0,329,0,0,0,0,0,0,0,20,5.2,10,10,4.8,122,9,999999999,300,0.1470,0,88,0.160,0.0,1.0
+2002,4,8,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,8.3,100,98300,0,0,332,0,0,0,0,0,0,0,360,4.1,10,10,4.8,122,9,999999999,290,0.1470,0,88,0.160,2.0,1.0
+2002,4,8,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,8.3,100,98400,0,0,332,0,0,0,0,0,0,0,360,5.2,10,10,6.4,183,9,999999999,279,0.1470,0,88,0.160,1.0,1.0
+2002,4,8,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,7.8,97,98500,0,0,332,0,0,0,0,0,0,0,340,4.6,10,10,6.4,183,9,999999999,259,0.1470,0,88,0.160,0.0,1.0
+2002,4,8,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,7.2,96,98600,0,0,329,0,0,0,0,0,0,0,340,6.2,10,10,9.6,2621,9,999999999,250,0.1470,0,88,0.160,2.0,1.0
+2002,4,9,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,7.2,96,98700,0,0,329,0,0,0,0,0,0,0,350,4.6,10,10,11.2,305,9,999999999,229,0.1480,0,88,0.160,0.0,1.0
+2002,4,9,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,7.2,96,98800,0,0,329,0,0,0,0,0,0,0,340,4.6,10,10,12.8,305,9,999999999,220,0.1480,0,88,0.160,0.0,1.0
+2002,4,9,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.2,6.7,97,98900,0,0,326,0,0,0,0,0,0,0,340,5.2,10,10,16.0,244,9,999999999,200,0.1480,0,88,0.160,0.0,1.0
+2002,4,9,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.2,6.7,97,99100,0,0,326,0,0,0,0,0,0,0,350,4.6,10,10,16.0,518,9,999999999,189,0.1480,0,88,0.160,0.0,1.0
+2002,4,9,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.7,5.9,95,99200,0,0,322,0,0,0,0,0,0,0,340,4.6,10,10,12.8,274,9,999999999,179,0.1480,0,88,0.160,0.0,1.0
+2002,4,9,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.7,5.0,89,99400,47,852,321,3,17,3,500,600,500,50,350,4.6,10,10,4.8,2926,9,999999999,160,0.1480,0,88,0.160,0.0,1.0
+2002,4,9,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,5.0,93,99600,282,1362,319,126,69,111,13700,5800,12500,2500,10,5.7,10,10,11.2,335,9,999999999,139,0.1480,0,88,0.160,0.0,1.0
+2002,4,9,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,5.0,93,99700,532,1362,319,99,0,99,11500,0,11500,4160,30,4.1,10,10,4.8,274,9,999999999,120,0.1480,0,88,0.160,0.0,1.0
+2002,4,9,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,5.0,96,99800,754,1362,316,118,0,118,14200,0,14200,5550,50,3.1,10,10,8.0,518,9,999999999,100,0.1480,0,88,0.160,0.0,1.0
+2002,4,9,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,5.0,96,99900,934,1362,316,114,0,114,14100,0,14100,5830,60,2.6,10,10,8.0,274,9,999999999,100,0.1480,0,88,0.160,0.0,1.0
+2002,4,9,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.7,5.0,89,100000,1058,1362,321,130,0,130,16200,0,16200,6790,60,4.1,10,10,9.6,610,9,999999999,89,0.1480,0,88,0.160,0.0,1.0
+2002,4,9,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,4.4,89,100000,1118,1362,318,157,0,157,19500,0,19500,8120,80,3.1,10,10,14.4,1006,9,999999999,89,0.1480,0,88,0.160,0.0,1.0
+2002,4,9,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,4.4,79,100100,1110,1362,310,494,204,327,54200,22100,36100,11910,90,3.6,8,8,16.0,914,9,999999999,89,0.1480,0,88,0.160,0.0,1.0
+2002,4,9,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,3.3,71,100200,1036,1362,311,770,651,274,82200,67800,30600,8860,50,2.6,8,8,16.0,914,9,999999999,100,0.1480,0,88,0.160,0.0,1.0
+2002,4,9,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.9,2.8,66,100200,899,1362,298,654,736,167,68800,74300,19600,4310,0,0.0,3,3,16.0,77777,9,999999999,110,0.1480,0,88,0.160,0.0,1.0
+2002,4,9,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.0,3.3,63,100200,709,1362,305,466,523,193,48800,52600,21400,4200,40,2.1,4,4,16.0,77777,9,999999999,100,0.1480,0,88,0.160,0.0,1.0
+2002,4,9,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,1.7,63,100300,480,1362,294,250,287,149,26400,27300,16800,3110,70,3.1,3,3,16.0,77777,9,999999999,89,0.1480,0,88,0.160,0.0,1.0
+2002,4,9,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,1.1,63,100300,227,1362,279,106,235,67,11100,15900,8500,1290,110,3.1,0,0,16.0,77777,9,999999999,80,0.1480,0,88,0.160,0.0,1.0
+2002,4,9,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,1.1,70,100400,20,556,272,0,0,0,0,0,0,0,120,4.1,0,0,16.0,77777,9,999999999,80,0.1480,0,88,0.160,0.0,1.0
+2002,4,9,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.3,0.6,82,100400,0,0,261,0,0,0,0,0,0,0,160,4.1,0,0,16.0,77777,9,999999999,80,0.1480,0,88,0.160,0.0,1.0
+2002,4,9,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.8,0.6,85,100400,0,0,259,0,0,0,0,0,0,0,160,2.1,0,0,16.0,77777,9,999999999,80,0.1480,0,88,0.160,0.0,1.0
+2002,4,9,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.8,0.6,85,100500,0,0,259,0,0,0,0,0,0,0,0,0.0,0,0,16.0,77777,9,999999999,80,0.1480,0,88,0.160,0.0,1.0
+2002,4,9,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.8,0.6,85,100500,0,0,259,0,0,0,0,0,0,0,170,2.6,0,0,14.4,77777,9,999999999,89,0.1480,0,88,0.160,0.0,1.0
+2002,4,9,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,0.9,91,100500,0,0,257,0,0,0,0,0,0,0,170,2.6,0,0,14.4,77777,9,999999999,89,0.1480,0,88,0.160,0.0,1.0
+2002,4,10,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.7,0.4,91,100500,0,0,255,0,0,0,0,0,0,0,190,2.6,0,0,9.6,77777,9,999999999,89,0.1490,0,88,0.160,0.0,1.0
+2002,4,10,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,-0.5,82,100500,0,0,256,0,0,0,0,0,0,0,180,2.6,0,0,11.2,77777,9,999999999,89,0.1490,0,88,0.160,0.0,1.0
+2002,4,10,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.7,0.0,88,100600,0,0,255,0,0,0,0,0,0,0,180,2.1,0,0,8.0,77777,9,999999999,89,0.1490,0,88,0.160,0.0,1.0
+2002,4,10,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.7,0.6,92,100600,0,0,255,0,0,0,0,0,0,0,180,2.1,0,0,6.4,77777,9,999999999,89,0.1490,0,88,0.160,0.0,1.0
+2002,4,10,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.7,0.6,92,100600,0,0,255,0,0,0,0,0,0,0,180,2.1,0,0,6.4,77777,9,999999999,89,0.1490,0,88,0.160,0.0,1.0
+2002,4,10,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,1.1,92,100600,51,896,257,5,90,3,900,5300,600,110,170,3.1,0,0,4.8,77777,9,999999999,89,0.1490,0,88,0.160,0.0,1.0
+2002,4,10,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.0,2.8,86,100600,289,1362,270,169,338,97,17000,25800,11500,1850,170,4.6,0,0,6.4,77777,9,999999999,100,0.1490,0,88,0.160,0.0,1.0
+2002,4,10,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,3.9,76,100700,538,1362,282,346,527,138,36300,50400,16300,2710,180,3.1,0,0,8.0,77777,9,999999999,110,0.1490,0,88,0.160,0.0,1.0
+2002,4,10,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.0,3.9,66,100600,760,1362,291,526,643,166,54300,63400,18900,3600,150,6.2,0,0,9.6,77777,9,999999999,120,0.1490,0,88,0.160,0.0,1.0
+2002,4,10,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.7,4.4,61,100600,939,1362,298,690,734,183,72500,74100,21300,4960,180,5.2,0,0,12.8,77777,9,999999999,120,0.1490,0,88,0.160,0.0,1.0
+2002,4,10,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,13.3,4.4,55,100600,1062,1362,323,809,796,187,86100,81200,22600,6350,180,6.2,9,5,16.0,77777,9,999999999,129,0.1490,0,88,0.160,0.0,1.0
+2002,4,10,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,14.4,3.9,49,100400,1122,1362,309,830,733,224,87700,74500,26100,8610,170,5.7,0,0,16.0,77777,9,999999999,139,0.1490,0,88,0.160,0.0,1.0
+2002,4,10,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,16.1,2.8,41,100400,1115,1362,329,850,827,172,88500,82900,20500,5900,180,6.7,3,3,16.0,77777,9,999999999,139,0.1490,0,88,0.160,0.0,1.0
+2002,4,10,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,16.7,1.1,35,100300,1040,1362,316,787,824,157,81900,82500,18800,4590,190,7.2,0,0,16.0,77777,9,999999999,150,0.1490,0,88,0.160,0.0,1.0
+2002,4,10,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,17.2,0.6,33,100200,903,1362,318,660,742,167,69500,74900,19700,4330,200,6.7,0,0,16.0,77777,9,999999999,150,0.1490,0,88,0.160,0.0,1.0
+2002,4,10,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,17.8,0.6,31,100100,713,1362,337,483,641,146,50000,63000,16900,3080,190,7.7,4,4,16.0,7620,9,999999999,139,0.1490,0,88,0.160,0.0,1.0
+2002,4,10,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,16.7,0.6,34,100100,484,1362,329,291,506,111,30700,47100,13900,2110,180,6.7,3,3,16.0,7620,9,999999999,139,0.1490,0,88,0.160,0.0,1.0
+2002,4,10,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,15.6,1.1,37,100000,231,1362,342,103,262,58,10600,18100,7500,1060,180,5.7,10,8,16.0,7620,9,999999999,129,0.1490,0,88,0.160,0.0,1.0
+2002,4,10,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,13.3,1.7,45,100000,21,579,315,0,0,0,0,0,0,0,170,4.6,3,3,16.0,7620,9,999999999,129,0.1490,0,88,0.160,0.0,1.0
+2002,4,10,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,12.8,2.2,48,100000,0,0,314,0,0,0,0,0,0,0,160,4.6,4,3,16.0,7620,9,999999999,120,0.1490,0,88,0.160,0.0,1.0
+2002,4,10,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,12.2,3.3,54,100000,0,0,324,0,0,0,0,0,0,0,160,5.2,10,7,16.0,7620,9,999999999,110,0.1490,0,88,0.160,0.0,1.0
+2002,4,10,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.7,3.3,56,100000,0,0,334,0,0,0,0,0,0,0,170,4.1,10,9,16.0,7620,9,999999999,110,0.1490,0,88,0.160,0.0,1.0
+2002,4,10,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.1,3.8,61,100000,0,0,313,0,0,0,0,0,0,0,170,4.6,9,5,14.4,77777,9,999999999,110,0.1490,0,88,0.160,0.0,1.0
+2002,4,10,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.7,0.0,44,99900,0,0,311,0,0,0,0,0,0,0,170,5.7,9,5,16.0,77777,9,999999999,110,0.1490,0,88,0.160,0.0,1.0
+2002,4,11,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.7,4.3,60,99900,0,0,319,0,0,0,0,0,0,0,180,5.7,9,6,16.0,77777,9,999999999,120,0.1490,0,88,0.160,0.0,1.0
+2002,4,11,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.7,4.3,60,99800,0,0,319,0,0,0,0,0,0,0,180,3.1,9,6,16.0,77777,9,999999999,120,0.1490,0,88,0.160,0.0,1.0
+2002,4,11,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.6,4.3,65,99800,0,0,314,0,0,0,0,0,0,0,200,2.1,8,6,16.0,6096,9,999999999,120,0.1490,0,88,0.160,0.0,1.0
+2002,4,11,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.1,4.4,63,99800,0,0,316,0,0,0,0,0,0,0,190,5.2,8,6,16.0,6096,9,999999999,120,0.1490,0,88,0.160,0.0,1.0
+2002,4,11,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.1,3.7,60,99800,0,0,319,0,0,0,0,0,0,0,190,3.1,8,7,16.0,6096,9,999999999,120,0.1490,0,88,0.160,0.0,1.0
+2002,4,11,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.0,4.4,68,99700,55,919,320,7,89,4,1100,5000,800,110,180,4.1,10,8,16.0,6096,9,999999999,120,0.1490,0,88,0.160,0.0,1.0
+2002,4,11,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,12.2,4.4,59,99800,296,1361,313,167,309,100,17300,24100,12100,2030,190,5.2,3,3,16.0,7620,9,999999999,120,0.1490,0,88,0.160,0.0,1.0
+2002,4,11,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,14.4,5.0,53,99800,544,1361,332,338,476,147,35100,45600,16900,2910,220,7.2,7,6,16.0,7620,9,999999999,120,0.1490,0,88,0.160,0.0,1.0
+2002,4,11,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,16.1,5.6,50,99800,766,1361,337,466,379,252,49700,39900,27200,6130,200,6.7,8,5,16.0,6096,9,999999999,120,0.1490,0,88,0.160,0.0,1.0
+2002,4,11,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,18.9,5.6,42,99800,944,1361,342,683,673,216,71000,67400,24200,5760,200,7.7,2,2,16.0,6096,9,999999999,129,0.1490,0,88,0.160,0.0,1.0
+2002,4,11,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,20.0,4.4,36,99700,1067,1361,346,797,760,199,84400,77400,23600,6790,200,6.7,2,2,16.0,7620,9,999999999,129,0.1490,0,88,0.160,0.0,1.0
+2002,4,11,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,21.1,5.0,35,99500,1127,1361,352,818,661,269,85300,66500,30100,10280,200,8.2,2,2,16.0,7620,9,999999999,139,0.1490,0,88,0.160,0.0,1.0
+2002,4,11,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,21.1,5.0,35,99500,1119,1361,355,755,545,306,80700,56900,33800,11940,180,6.7,4,3,16.0,7620,9,999999999,139,0.1490,0,88,0.160,0.0,1.0
+2002,4,11,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,22.8,5.0,31,99400,1043,1361,372,700,555,273,74800,57800,30400,8980,200,7.2,7,6,16.0,7620,9,999999999,139,0.1490,0,88,0.160,0.0,1.0
+2002,4,11,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,23.9,3.9,27,99400,906,1361,352,643,689,183,67300,69300,21000,4720,210,6.7,0,0,16.0,7620,9,999999999,139,0.1490,0,88,0.160,0.0,1.0
+2002,4,11,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,23.3,4.4,29,99300,717,1361,357,483,630,151,50000,61900,17400,3180,200,7.7,1,1,16.0,7620,9,999999999,129,0.1490,0,88,0.160,0.0,1.0
+2002,4,11,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,23.3,3.3,27,99200,488,1361,364,292,494,114,30700,46100,14100,2170,180,8.8,3,3,16.0,7620,9,999999999,120,0.1490,0,88,0.160,0.0,1.0
+2002,4,11,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,22.2,2.2,27,99100,236,1361,370,112,305,59,11600,21300,7900,1070,190,6.7,7,7,16.0,7620,9,999999999,110,0.1490,0,88,0.160,0.0,1.0
+2002,4,11,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,21.1,3.9,32,99200,23,601,381,0,0,0,0,0,0,0,190,6.7,9,9,16.0,7620,9,999999999,120,0.1490,0,88,0.160,0.0,1.0
+2002,4,11,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,20.0,6.1,40,99200,0,0,378,0,0,0,0,0,0,0,190,4.1,9,9,16.0,7620,9,999999999,139,0.1490,0,88,0.160,0.0,1.0
+2002,4,11,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,18.9,7.2,47,99200,0,0,373,0,0,0,0,0,0,0,180,4.6,9,9,16.0,7620,9,999999999,150,0.1490,0,88,0.160,0.0,1.0
+2002,4,11,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,18.9,7.4,47,99200,0,0,374,0,0,0,0,0,0,0,190,4.6,9,9,16.0,7620,9,999999999,179,0.1490,0,88,0.160,0.0,1.0
+2002,4,11,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,18.3,7.8,50,99200,0,0,371,0,0,0,0,0,0,0,190,5.2,9,9,16.0,6096,9,999999999,209,0.1490,0,88,0.160,0.0,1.0
+2002,4,11,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,18.3,11.1,63,99000,0,0,354,0,0,0,0,0,0,0,200,6.2,5,5,16.0,77777,9,999999999,240,0.1490,0,88,0.160,0.0,1.0
+2002,4,12,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,18.3,12.2,68,99100,0,0,377,0,0,0,0,0,0,0,200,6.2,9,9,16.0,6096,9,999999999,259,0.1500,0,88,0.160,0.0,1.0
+2002,4,12,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,18.9,12.2,65,99000,0,0,380,0,0,0,0,0,0,0,210,7.7,9,9,16.0,3962,9,999999999,270,0.1500,0,88,0.160,0.0,1.0
+2002,4,12,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,18.3,12.8,70,99000,0,0,388,0,0,0,0,0,0,0,230,6.2,10,10,16.0,3962,9,999999999,290,0.1500,0,88,0.160,0.0,1.0
+2002,4,12,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,17.2,12.8,75,99100,0,0,382,0,0,0,0,0,0,0,230,6.2,10,10,16.0,4572,9,999999999,279,0.1500,0,88,0.160,0.0,1.0
+2002,4,12,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,16.7,12.8,78,99100,0,0,380,0,0,0,0,0,0,0,210,4.1,10,10,14.4,3048,9,999999999,270,0.1500,0,88,0.160,0.0,1.0
+2002,4,12,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,15.6,12.8,83,99100,60,963,356,8,59,6,1100,2900,900,120,220,3.6,8,8,11.2,2743,9,999999999,270,0.1500,0,88,0.160,0.0,1.0
+2002,4,12,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,15.6,12.8,83,99300,302,1360,374,173,191,131,18300,15300,14900,2850,230,3.1,10,10,12.8,3048,9,999999999,259,0.1500,0,88,0.160,0.0,1.0
+2002,4,12,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,16.1,13.3,83,99300,550,1360,367,91,0,91,10700,0,10700,3940,260,4.6,9,9,16.0,1981,9,999999999,250,0.1500,0,88,0.160,0.0,1.0
+2002,4,12,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,16.7,13.3,80,99300,771,1360,370,197,6,193,22800,500,22500,8320,260,4.6,9,9,16.0,457,9,999999999,240,0.1500,0,88,0.160,0.0,1.0
+2002,4,12,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,16.1,12.8,81,99400,949,1360,376,202,0,202,24000,0,24000,9540,270,4.6,10,10,16.0,518,9,999999999,240,0.1500,0,88,0.160,0.0,1.0
+2002,4,12,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,16.1,12.8,81,99400,1072,1360,376,235,0,235,28100,0,28100,11280,300,4.6,10,10,16.0,610,9,999999999,229,0.1500,0,88,0.160,0.0,1.0
+2002,4,12,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,15.6,12.8,83,99400,1131,1360,374,224,0,224,27100,0,27100,11000,310,3.6,10,10,16.0,427,9,999999999,229,0.1500,0,88,0.160,0.0,1.0
+2002,4,12,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,12.8,11.1,89,99500,1123,1360,358,220,0,220,26700,0,26700,10820,60,5.2,10,10,16.0,427,9,999999999,220,0.1500,0,88,0.160,0.0,1.0
+2002,4,12,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.7,10.6,93,99500,1047,1360,352,204,0,204,24600,0,24600,9990,60,5.2,10,10,12.8,427,9,999999999,209,0.1500,0,88,0.160,0.0,1.0
+2002,4,12,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.1,10.0,93,99500,910,1360,348,176,0,176,21000,0,21000,8390,50,4.6,10,10,16.0,244,9,999999999,200,0.1500,0,88,0.160,0.0,1.0
+2002,4,12,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.6,8.9,89,99500,721,1360,344,165,0,165,19200,0,19200,7140,80,4.1,10,10,16.0,244,9,999999999,200,0.1500,0,88,0.160,0.0,1.0
+2002,4,12,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.0,8.9,93,99500,492,1360,341,67,0,67,8000,0,8000,2920,50,3.6,10,10,16.0,244,9,999999999,189,0.1500,0,88,0.160,0.0,1.0
+2002,4,12,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,9.4,8.3,93,99500,240,1360,338,21,0,21,2500,0,2500,870,40,4.1,10,10,16.0,244,9,999999999,179,0.1500,0,88,0.160,0.0,1.0
+2002,4,12,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,7.8,97,99600,25,623,332,0,0,0,0,0,0,0,60,2.6,10,10,12.8,213,9,999999999,179,0.1500,0,88,0.160,0.0,1.0
+2002,4,12,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,7.8,97,99600,0,0,332,0,0,0,0,0,0,0,80,3.1,10,10,11.2,152,9,999999999,179,0.1500,0,88,0.160,0.0,1.0
+2002,4,12,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.9,7.8,93,99700,0,0,335,0,0,0,0,0,0,0,70,2.1,10,10,11.2,213,9,999999999,179,0.1500,0,88,0.160,0.0,1.0
+2002,4,12,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,7.2,93,99700,0,0,331,0,0,0,0,0,0,0,0,0.0,10,10,11.2,305,9,999999999,179,0.1500,0,88,0.160,0.0,1.0
+2002,4,12,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.9,7.8,93,99700,0,0,335,0,0,0,0,0,0,0,0,0.0,10,10,11.2,305,9,999999999,179,0.1500,0,88,0.160,0.0,1.0
+2002,4,12,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,7.2,93,99600,0,0,315,0,0,0,0,0,0,0,0,0.0,8,8,11.2,366,9,999999999,170,0.1500,0,88,0.160,0.0,1.0
+2002,4,13,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.7,6.7,100,99700,0,0,299,0,0,0,0,0,0,0,0,0.0,6,6,8.0,77777,9,999999999,170,0.1510,0,88,0.160,0.0,1.0
+2002,4,13,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.7,6.7,100,99700,0,0,297,0,0,0,0,0,0,0,0,0.0,5,5,8.0,77777,9,999999999,170,0.1510,0,88,0.160,0.0,1.0
+2002,4,13,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.7,6.1,96,99600,0,0,294,0,0,0,0,0,0,0,0,0.0,4,4,6.4,77777,9,999999999,170,0.1510,0,88,0.160,0.0,1.0
+2002,4,13,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,5.6,100,99600,0,0,289,0,0,0,0,0,0,0,320,1.5,4,4,8.0,77777,9,999999999,160,0.1510,0,88,0.160,0.0,1.0
+2002,4,13,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.7,6.7,100,99700,0,0,295,0,0,0,0,0,0,0,330,1.5,4,4,8.0,77777,9,999999999,160,0.1510,0,88,0.160,0.0,1.0
+2002,4,13,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.2,6.7,97,99700,64,985,297,10,115,6,1500,6600,1100,150,350,2.1,4,4,8.0,77777,9,999999999,150,0.1510,0,88,0.160,0.0,1.0
+2002,4,13,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,6.7,90,99700,309,1359,299,180,346,101,18100,27300,11900,1930,20,3.6,3,3,9.6,77777,9,999999999,150,0.1510,0,88,0.160,0.0,1.0
+2002,4,13,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.0,6.1,77,99800,556,1359,306,365,557,136,38300,53700,16300,2680,30,2.1,3,3,14.4,77777,9,999999999,150,0.1510,0,88,0.160,0.0,1.0
+2002,4,13,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.7,7.2,74,99800,777,1359,314,524,599,181,56000,61100,21000,4090,30,2.6,3,3,16.0,77777,9,999999999,139,0.1510,0,88,0.160,0.0,1.0
+2002,4,13,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,13.3,7.2,67,99800,954,1359,338,645,521,278,67900,53900,29900,7910,50,3.6,8,8,16.0,914,9,999999999,139,0.1510,0,88,0.160,0.0,1.0
+2002,4,13,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,14.4,7.8,65,99700,1076,1359,313,506,163,377,55500,17300,41700,13320,90,3.1,0,0,16.0,77777,9,999999999,139,0.1510,0,88,0.160,0.0,1.0
+2002,4,13,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,15.6,8.9,64,99600,1135,1359,336,878,703,289,91200,70400,32200,11250,80,3.1,4,4,16.0,77777,9,999999999,139,0.1510,0,88,0.160,0.0,1.0
+2002,4,13,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,16.7,8.9,60,99700,1126,1359,339,874,863,157,92000,86900,19700,5740,60,4.1,3,3,16.0,77777,9,999999999,139,0.1510,0,88,0.160,0.0,1.0
+2002,4,13,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,16.1,9.4,64,99600,1051,1359,337,793,752,210,83500,76200,24400,6890,70,3.1,3,3,16.0,7620,9,999999999,129,0.1510,0,88,0.160,0.0,1.0
+2002,4,13,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,16.1,9.4,64,99500,914,1359,342,621,541,256,65500,55900,27800,6860,80,2.1,6,5,16.0,7620,9,999999999,129,0.1510,0,88,0.160,0.0,1.0
+2002,4,13,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,16.1,9.4,64,99500,724,1359,362,396,277,248,42000,28900,26600,5920,50,4.1,9,9,16.0,7620,9,999999999,129,0.1510,0,88,0.160,0.0,1.0
+2002,4,13,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,15.6,9.4,67,99500,496,1359,352,185,75,157,20200,7100,17600,4230,90,4.6,10,8,16.0,7620,9,999999999,129,0.1510,0,88,0.160,0.0,1.0
+2002,4,13,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,12.8,8.3,74,99300,244,1359,354,59,5,58,6600,100,6600,2010,100,3.1,10,10,16.0,7620,9,999999999,129,0.1510,0,88,0.160,0.0,1.0
+2002,4,13,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.1,7.8,80,99400,27,668,315,0,0,0,0,0,0,0,90,4.1,10,4,16.0,6096,9,999999999,139,0.1510,0,88,0.160,0.0,1.0
+2002,4,13,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.0,6.7,80,99400,0,0,309,0,0,0,0,0,0,0,90,2.6,10,4,16.0,6096,9,999999999,150,0.1510,0,88,0.160,0.0,1.0
+2002,4,13,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,9.4,6.7,83,99400,0,0,311,0,0,0,0,0,0,0,90,3.1,8,6,16.0,6096,9,999999999,160,0.1510,0,88,0.160,0.0,1.0
+2002,4,13,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.9,6.7,86,99300,0,0,309,0,0,0,0,0,0,0,100,2.1,6,6,16.0,6096,9,999999999,170,0.1510,0,88,0.160,0.0,1.0
+2002,4,13,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,6.7,90,99300,0,0,322,0,0,0,0,0,0,0,130,2.6,9,9,14.4,6096,9,999999999,170,0.1510,0,88,0.160,0.0,1.0
+2002,4,13,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,6.7,93,99200,0,0,285,0,0,0,0,0,0,0,150,2.1,0,0,12.8,6096,9,999999999,179,0.1510,0,88,0.160,0.0,1.0
+2002,4,14,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.7,6.7,100,99100,0,0,289,0,0,0,0,0,0,0,0,0.0,2,2,6.4,6096,9,999999999,179,0.1520,0,88,0.160,0.0,1.0
+2002,4,14,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,6.1,100,99000,0,0,282,0,0,0,0,0,0,0,170,2.1,1,1,8.0,6096,9,999999999,179,0.1520,0,88,0.160,0.0,1.0
+2002,4,14,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.7,6.1,96,99000,0,0,292,0,0,0,0,0,0,0,0,0.0,3,3,8.0,6096,9,999999999,179,0.1520,0,88,0.160,0.0,1.0
+2002,4,14,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,7.2,96,98900,0,0,285,0,0,0,0,0,0,0,0,0.0,0,0,8.0,6096,9,999999999,179,0.1520,0,88,0.160,0.0,1.0
+2002,4,14,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,7.2,96,98900,0,0,285,0,0,0,0,0,0,0,130,1.5,0,0,8.0,6096,9,999999999,170,0.1520,0,88,0.160,0.0,1.0
+2002,4,14,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.7,6.7,100,98900,69,1030,280,0,0,0,0,0,0,0,150,2.6,0,0,4.8,77777,9,999999999,160,0.1520,0,88,0.160,0.0,1.0
+2002,4,14,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.1,10.0,93,98900,315,1359,301,178,325,103,18600,26200,12500,2080,190,2.6,0,0,4.8,77777,9,999999999,160,0.1520,0,88,0.160,0.0,1.0
+2002,4,14,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,15.0,11.7,81,98900,562,1359,320,350,481,150,36400,46400,17200,2990,220,2.6,0,0,9.6,77777,9,999999999,160,0.1520,0,88,0.160,0.0,1.0
+2002,4,14,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,17.2,11.7,70,98800,782,1359,330,543,648,169,56200,64200,19200,3750,210,4.1,0,0,12.8,77777,9,999999999,160,0.1520,0,88,0.160,0.0,1.0
+2002,4,14,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,18.9,11.1,61,98800,959,1359,352,701,745,174,74100,75600,20600,4920,190,5.2,3,3,14.4,77777,9,999999999,160,0.1520,0,88,0.160,0.0,1.0
+2002,4,14,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,20.6,9.4,49,98700,1081,1359,358,808,784,183,86300,80200,22300,6520,220,5.7,3,3,16.0,77777,9,999999999,170,0.1520,0,88,0.160,0.0,1.0
+2002,4,14,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,22.2,10.6,48,98500,1139,1359,352,884,823,192,91100,82100,22100,6890,210,7.7,0,0,16.0,77777,9,999999999,170,0.1520,0,88,0.160,0.0,1.0
+2002,4,14,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,22.8,11.7,50,98400,1130,1359,372,826,677,262,86500,68200,29600,10190,190,6.2,3,3,16.0,77777,9,999999999,179,0.1520,0,88,0.160,0.0,1.0
+2002,4,14,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,23.9,10.0,41,98400,1055,1359,375,805,800,182,85700,81700,22100,6120,190,9.3,3,3,16.0,77777,9,999999999,189,0.1520,0,88,0.160,0.0,1.0
+2002,4,14,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,23.9,8.9,38,98300,917,1359,402,666,665,216,69000,66400,24000,5530,220,6.2,9,9,16.0,1829,9,999999999,200,0.1520,0,88,0.160,0.0,1.0
+2002,4,14,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,23.9,9.4,40,98200,728,1359,384,423,359,230,45200,37600,25000,5410,200,7.2,6,6,16.0,7620,9,999999999,200,0.1520,0,88,0.160,0.0,1.0
+2002,4,14,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,24.4,9.4,39,98200,500,1359,380,257,294,149,27300,28400,16800,3100,220,5.7,4,4,16.0,77777,9,999999999,209,0.1520,0,88,0.160,0.0,1.0
+2002,4,14,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,23.3,9.4,41,98100,249,1359,377,85,80,70,9200,6000,8100,1500,210,6.7,5,5,16.0,77777,9,999999999,209,0.1520,0,88,0.160,0.0,1.0
+2002,4,14,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,22.2,10.6,48,98200,29,691,367,0,0,0,0,0,0,0,200,5.2,3,3,16.0,77777,9,999999999,229,0.1520,0,88,0.160,0.0,1.0
+2002,4,14,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,22.2,12.2,53,98200,0,0,389,0,0,0,0,0,0,0,200,4.6,8,8,16.0,2591,9,999999999,250,0.1520,0,88,0.160,0.0,1.0
+2002,4,14,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,21.1,13.9,63,98200,0,0,379,0,0,0,0,0,0,0,200,6.2,7,7,16.0,7620,9,999999999,259,0.1520,0,88,0.160,0.0,1.0
+2002,4,14,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,20.6,14.4,68,98200,0,0,383,0,0,0,0,0,0,0,210,6.7,8,8,16.0,77777,9,999999999,259,0.1520,0,88,0.160,0.0,1.0
+2002,4,14,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,20.0,14.4,70,98200,0,0,388,0,0,0,0,0,0,0,210,6.7,9,9,16.0,7620,9,999999999,259,0.1520,0,88,0.160,0.0,1.0
+2002,4,14,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,20.0,14.4,70,98200,0,0,399,0,0,0,0,0,0,0,210,5.2,10,10,16.0,2438,9,999999999,259,0.1520,0,88,0.160,0.0,1.0
+2002,4,15,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,20.0,15.0,73,98200,0,0,381,0,0,0,0,0,0,0,230,5.2,9,8,16.0,7620,9,999999999,270,0.1530,0,88,0.160,0.0,1.0
+2002,4,15,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,19.4,15.0,76,98200,0,0,372,0,0,0,0,0,0,0,230,3.6,10,7,16.0,7620,9,999999999,270,0.1530,0,88,0.160,0.0,1.0
+2002,4,15,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,18.3,15.0,81,98300,0,0,372,0,0,0,0,0,0,0,220,3.1,10,8,16.0,7620,9,999999999,270,0.1530,0,88,0.160,0.0,1.0
+2002,4,15,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,17.8,14.4,80,98300,0,0,363,0,0,0,0,0,0,0,220,2.1,10,7,16.0,7620,9,999999999,279,0.1530,0,88,0.160,0.0,1.0
+2002,4,15,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,16.7,14.4,86,98300,0,0,345,0,0,0,0,0,0,0,210,3.1,3,3,16.0,7620,9,999999999,279,0.1530,0,88,0.160,0.0,1.0
+2002,4,15,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,17.8,14.4,80,98400,74,1075,353,0,0,0,0,0,0,0,220,4.6,4,4,16.0,77777,9,999999999,290,0.1530,0,88,0.160,0.0,1.0
+2002,4,15,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,20.0,14.4,70,98500,321,1358,364,185,263,123,19100,21300,14000,2590,240,5.2,4,4,16.0,77777,9,999999999,290,0.1530,0,88,0.160,0.0,1.0
+2002,4,15,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,21.1,14.4,66,98600,568,1358,366,321,312,190,33800,31100,20800,4170,240,6.2,3,3,16.0,77777,9,999999999,290,0.1530,0,88,0.160,0.0,1.0
+2002,4,15,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,23.3,15.6,62,98600,787,1358,375,530,556,206,55900,56700,22900,4760,260,6.7,2,2,16.0,77777,9,999999999,290,0.1530,0,88,0.160,0.0,1.0
+2002,4,15,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,25.6,16.1,56,98600,964,1358,375,695,697,199,72800,70300,22800,5570,240,6.7,0,0,14.4,77777,9,999999999,279,0.1530,0,88,0.160,0.0,1.0
+2002,4,15,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,27.2,16.7,53,98600,1085,1358,384,827,790,194,88000,80600,23400,6950,220,5.7,0,0,16.0,77777,9,999999999,270,0.1530,0,88,0.160,0.0,1.0
+2002,4,15,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,28.3,16.7,49,98600,1143,1358,390,890,865,159,93600,87200,20100,6110,200,7.2,0,0,16.0,77777,9,999999999,259,0.1530,0,88,0.160,0.0,1.0
+2002,4,15,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,30.0,15.6,42,98600,1134,1358,397,862,791,200,92000,80900,24300,8080,210,7.2,0,0,16.0,77777,9,999999999,259,0.1530,0,88,0.160,0.0,1.0
+2002,4,15,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,30.6,13.3,35,98600,1058,1358,397,776,746,193,82300,76000,22900,6510,210,7.7,0,0,16.0,77777,9,999999999,259,0.1530,0,88,0.160,0.0,1.0
+2002,4,15,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,31.1,12.8,33,98500,921,1358,417,661,707,180,69300,71300,20900,4770,220,9.3,3,3,16.0,77777,9,999999999,259,0.1530,0,88,0.160,0.0,1.0
+2002,4,15,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,30.6,12.8,34,98600,732,1358,414,484,595,163,51900,60300,19300,3540,200,8.2,3,3,16.0,77777,9,999999999,259,0.1530,0,88,0.160,0.0,1.0
+2002,4,15,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,30.0,12.8,35,98500,504,1358,411,299,473,123,31400,44500,14800,2370,210,7.2,3,3,16.0,77777,9,999999999,250,0.1530,0,88,0.160,0.0,1.0
+2002,4,15,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,28.9,12.8,37,98400,253,1358,411,119,272,68,12200,19700,8500,1250,200,6.7,5,5,16.0,77777,9,999999999,250,0.1530,0,88,0.160,0.0,1.0
+2002,4,15,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,27.2,14.4,45,98600,32,713,398,0,0,0,0,0,0,0,190,6.2,3,3,16.0,7620,9,999999999,250,0.1530,0,88,0.160,0.0,1.0
+2002,4,15,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,26.1,15.6,52,98600,0,0,377,0,0,0,0,0,0,0,200,5.7,0,0,16.0,77777,9,999999999,250,0.1530,0,88,0.160,0.0,1.0
+2002,4,15,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,25.6,16.1,56,98700,0,0,375,0,0,0,0,0,0,0,190,7.2,0,0,16.0,77777,9,999999999,250,0.1530,0,88,0.160,0.0,1.0
+2002,4,15,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,24.4,16.7,62,98700,0,0,370,0,0,0,0,0,0,0,200,7.7,0,0,16.0,77777,9,999999999,240,0.1530,0,88,0.160,0.0,1.0
+2002,4,15,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,23.9,16.7,64,98800,0,0,367,0,0,0,0,0,0,0,200,7.2,0,0,16.0,77777,9,999999999,240,0.1530,0,88,0.160,0.0,1.0
+2002,4,15,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,23.3,16.7,66,98700,0,0,364,0,0,0,0,0,0,0,210,7.7,0,0,16.0,77777,9,999999999,229,0.1530,0,88,0.160,0.0,1.0
+2002,4,16,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,22.8,16.7,68,98800,0,0,362,0,0,0,0,0,0,0,210,6.2,0,0,16.0,77777,9,999999999,240,0.1540,0,88,0.160,0.0,1.0
+2002,4,16,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,21.7,16.7,73,98800,0,0,357,0,0,0,0,0,0,0,210,5.7,0,0,16.0,77777,9,999999999,240,0.1540,0,88,0.160,0.0,1.0
+2002,4,16,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,21.1,16.7,76,98800,0,0,354,0,0,0,0,0,0,0,210,6.7,0,0,16.0,77777,9,999999999,250,0.1540,0,88,0.160,0.0,1.0
+2002,4,16,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,21.1,16.7,76,98800,0,0,354,0,0,0,0,0,0,0,200,6.7,0,0,16.0,77777,9,999999999,250,0.1540,0,88,0.160,0.0,1.0
+2002,4,16,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,20.6,16.7,78,98900,0,0,367,0,0,0,0,0,0,0,200,6.2,3,3,16.0,77777,9,999999999,259,0.1540,0,88,0.160,0.0,1.0
+2002,4,16,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,20.0,16.7,81,98900,79,1097,349,0,0,0,0,0,0,0,190,5.7,0,0,14.4,77777,9,999999999,270,0.1540,0,88,0.160,0.0,1.0
+2002,4,16,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,21.7,16.7,73,99000,327,1357,357,192,362,104,19400,29300,12300,1980,200,6.2,0,0,16.0,77777,9,999999999,270,0.1540,0,88,0.160,0.0,1.0
+2002,4,16,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,23.3,17.2,69,99000,574,1357,365,376,555,141,39600,53900,16800,2800,200,6.7,0,0,16.0,77777,9,999999999,279,0.1540,0,88,0.160,0.0,1.0
+2002,4,16,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,24.4,17.2,64,98900,793,1357,370,549,642,173,56800,63600,19600,3880,220,7.2,0,0,16.0,77777,9,999999999,279,0.1540,0,88,0.160,0.0,1.0
+2002,4,16,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,25.6,17.8,62,98900,968,1357,394,720,751,182,75900,76100,21400,5210,190,9.8,3,3,16.0,77777,9,999999999,279,0.1540,0,88,0.160,0.0,1.0
+2002,4,16,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,27.2,17.8,56,98900,1089,1357,405,826,784,196,87900,80000,23600,7090,190,9.3,4,4,16.0,77777,9,999999999,279,0.1540,0,88,0.160,0.0,1.0
+2002,4,16,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,28.3,16.7,49,98700,1147,1357,407,829,643,284,86300,64500,31700,11530,200,8.8,3,3,16.0,77777,9,999999999,270,0.1540,0,88,0.160,0.0,1.0
+2002,4,16,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,30.0,16.1,43,98800,1138,1357,415,886,827,191,91400,82500,22000,6860,190,10.8,3,3,16.0,77777,9,999999999,270,0.1540,0,88,0.160,0.0,1.0
+2002,4,16,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,30.6,15.0,39,98700,1062,1357,417,811,800,183,86300,81700,22300,6260,200,10.8,3,3,16.0,77777,9,999999999,270,0.1540,0,88,0.160,0.0,1.0
+2002,4,16,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,30.6,13.9,36,98700,924,1357,426,661,636,227,70800,65900,25800,6110,190,10.8,6,6,16.0,7620,9,999999999,270,0.1540,0,88,0.160,0.0,1.0
+2002,4,16,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,30.0,13.3,36,98700,735,1357,421,380,218,261,41100,22500,28900,6710,200,8.2,10,6,16.0,7620,9,999999999,259,0.1540,0,88,0.160,0.0,1.0
+2002,4,16,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,30.0,13.3,36,98700,508,1357,421,150,17,143,16800,1200,16400,5340,200,6.7,10,6,16.0,7620,9,999999999,259,0.1540,0,88,0.160,0.0,1.0
+2002,4,16,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,28.9,12.8,37,98600,257,1357,448,68,11,66,7600,300,7500,2250,200,7.7,10,10,16.0,6096,9,999999999,259,0.1540,0,88,0.160,0.0,1.0
+2002,4,16,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,27.8,13.3,41,98700,34,735,421,0,0,0,0,0,0,0,190,5.7,9,8,16.0,6096,9,999999999,270,0.1540,0,88,0.160,0.0,1.0
+2002,4,16,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,26.1,15.0,50,98800,0,0,399,0,0,0,0,0,0,0,200,7.7,9,5,16.0,6096,9,999999999,279,0.1540,0,88,0.160,0.0,1.0
+2002,4,16,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,25.0,16.1,58,98800,0,0,402,0,0,0,0,0,0,0,200,6.7,10,7,16.0,6096,9,999999999,290,0.1540,0,88,0.160,0.0,1.0
+2002,4,16,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,24.4,16.7,62,98800,0,0,392,0,0,0,0,0,0,0,210,8.2,6,5,14.4,6096,9,999999999,320,0.1540,0,88,0.160,0.0,1.0
+2002,4,16,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,23.9,16.7,64,98900,0,0,412,0,0,0,0,0,0,0,220,9.3,9,9,16.0,6096,9,999999999,340,0.1540,0,88,0.160,0.0,1.0
+2002,4,16,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,22.8,16.7,68,98800,0,0,369,0,0,0,0,0,0,0,210,8.2,1,1,16.0,6096,9,999999999,359,0.1540,0,88,0.160,0.0,1.0
+2002,4,17,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,22.2,16.7,71,98900,0,0,388,0,0,0,0,0,0,0,220,5.7,8,7,16.0,6096,9,999999999,359,0.1550,0,88,0.160,0.0,1.0
+2002,4,17,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,22.2,16.7,71,98900,0,0,388,0,0,0,0,0,0,0,210,4.6,10,7,16.0,4572,9,999999999,359,0.1550,0,88,0.160,0.0,1.0
+2002,4,17,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,22.2,16.7,71,98900,0,0,403,0,0,0,0,0,0,0,220,6.2,10,9,16.0,2591,9,999999999,359,0.1550,0,88,0.160,0.0,1.0
+2002,4,17,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,18.9,17.8,93,99000,0,0,387,0,0,0,0,0,0,0,190,3.6,10,9,16.0,2896,9,999999999,350,0.1550,0,88,0.160,1.0,1.0
+2002,4,17,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,18.9,17.2,90,99000,0,0,386,0,0,0,0,0,0,0,190,4.6,10,9,16.0,1280,9,999999999,350,0.1550,0,88,0.160,0.0,1.0
+2002,4,17,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,19.4,16.1,81,99000,84,1141,373,0,0,0,0,0,0,0,210,5.2,7,7,16.0,6096,9,999999999,350,0.1550,0,88,0.160,0.0,1.0
+2002,4,17,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,20.6,16.1,75,99100,333,1356,385,198,294,126,20400,24300,14500,2650,220,5.2,8,8,16.0,1280,9,999999999,329,0.1550,0,88,0.160,0.0,1.0
+2002,4,17,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,21.1,16.7,76,99200,579,1356,389,340,386,175,36200,38700,19600,3770,220,5.7,9,8,16.0,1097,9,999999999,320,0.1550,0,88,0.160,0.0,1.0
+2002,4,17,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,22.8,17.8,73,99200,798,1356,408,470,336,272,50200,35600,29200,6830,240,6.2,9,9,16.0,1189,9,999999999,300,0.1550,0,88,0.160,0.0,1.0
+2002,4,17,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,23.9,17.8,69,99300,973,1356,405,372,79,316,41100,8100,35300,11440,240,5.2,8,8,16.0,1463,9,999999999,279,0.1550,0,88,0.160,0.0,1.0
+2002,4,17,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,25.0,17.2,62,99200,1093,1356,396,734,506,325,77700,52700,35100,12110,250,7.2,5,5,16.0,77777,9,999999999,259,0.1550,0,88,0.160,0.0,1.0
+2002,4,17,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,26.7,16.7,54,99200,1151,1356,401,896,799,216,95200,81500,25900,9130,270,6.7,4,4,16.0,77777,9,999999999,240,0.1550,0,88,0.160,0.0,1.0
+2002,4,17,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,27.2,15.6,49,99200,1141,1356,402,850,749,219,90300,76300,25900,8990,260,5.2,4,4,16.0,77777,9,999999999,229,0.1550,0,88,0.160,0.0,1.0
+2002,4,17,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,28.3,16.1,48,99200,1065,1356,412,793,758,196,84100,77200,23300,6720,250,4.1,5,5,16.0,77777,9,999999999,229,0.1550,0,88,0.160,0.0,1.0
+2002,4,17,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,28.9,13.9,40,99200,928,1356,406,655,671,195,68400,67500,22200,5170,230,4.1,3,3,16.0,77777,9,999999999,220,0.1550,0,88,0.160,0.0,1.0
+2002,4,17,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,28.9,12.2,36,99200,739,1356,404,490,595,165,52500,60400,19500,3600,280,5.2,3,3,16.0,77777,9,999999999,220,0.1550,0,88,0.160,0.0,1.0
+2002,4,17,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,28.3,11.1,34,99200,511,1356,399,300,456,127,31400,43100,15100,2460,270,3.6,3,3,16.0,77777,9,999999999,220,0.1550,0,88,0.160,0.0,1.0
+2002,4,17,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,27.2,7.8,29,99100,261,1356,385,129,343,63,13400,25200,8600,1150,340,5.7,2,2,16.0,77777,9,999999999,220,0.1550,0,88,0.160,0.0,1.0
+2002,4,17,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,25.6,6.7,30,99300,36,757,380,1,0,1,100,0,100,40,40,2.6,3,3,16.0,77777,9,999999999,229,0.1550,0,88,0.160,0.0,1.0
+2002,4,17,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,23.3,11.1,46,99300,0,0,358,0,0,0,0,0,0,0,60,3.6,0,0,16.0,77777,9,999999999,240,0.1550,0,88,0.160,0.0,1.0
+2002,4,17,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,22.8,10.0,44,99300,0,0,354,0,0,0,0,0,0,0,80,3.1,0,0,16.0,77777,9,999999999,240,0.1550,0,88,0.160,0.0,1.0
+2002,4,17,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,21.1,11.1,53,99300,0,0,347,0,0,0,0,0,0,0,100,2.1,0,0,16.0,77777,9,999999999,259,0.1550,0,88,0.160,0.0,1.0
+2002,4,17,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,20.6,13.3,63,99300,0,0,390,0,0,0,0,0,0,0,80,2.6,9,9,16.0,2134,9,999999999,270,0.1550,0,88,0.160,0.0,1.0
+2002,4,17,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,19.4,14.4,73,99200,0,0,371,0,0,0,0,0,0,0,100,1.5,10,7,16.0,77777,9,999999999,279,0.1550,0,88,0.160,0.0,1.0
+2002,4,18,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,18.9,14.4,75,99300,0,0,364,0,0,0,0,0,0,0,170,2.1,10,6,14.4,77777,9,999999999,290,0.1550,0,88,0.160,0.0,1.0
+2002,4,18,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,18.3,14.4,78,99200,0,0,355,0,0,0,0,0,0,0,190,2.6,5,4,16.0,77777,9,999999999,290,0.1550,0,88,0.160,0.0,1.0
+2002,4,18,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,21.1,16.7,76,99200,0,0,354,0,0,0,0,0,0,0,210,3.6,0,0,16.0,77777,9,999999999,300,0.1550,0,88,0.160,0.0,1.0
+2002,4,18,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,20.6,16.1,75,99100,0,0,351,0,0,0,0,0,0,0,200,4.1,0,0,16.0,77777,9,999999999,290,0.1550,0,88,0.160,0.0,1.0
+2002,4,18,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,21.1,16.1,73,99100,0,0,353,0,0,0,0,0,0,0,210,5.7,0,0,12.8,77777,9,999999999,279,0.1550,0,88,0.160,0.0,1.0
+2002,4,18,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,20.6,16.7,78,99100,89,1163,351,0,0,0,0,0,0,0,210,5.2,0,0,16.0,77777,9,999999999,270,0.1550,0,88,0.160,0.0,1.0
+2002,4,18,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,22.2,17.2,73,99200,339,1355,367,156,133,122,16600,11300,13800,2680,210,5.7,1,1,16.0,77777,9,999999999,259,0.1550,0,88,0.160,0.0,1.0
+2002,4,18,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,23.9,17.8,69,99100,585,1355,369,381,461,182,39200,44800,19800,3740,210,6.2,0,0,16.0,77777,9,999999999,250,0.1550,0,88,0.160,0.0,1.0
+2002,4,18,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,25.0,18.3,66,99100,803,1355,391,457,293,283,48600,31000,30200,7190,220,6.2,4,3,16.0,7620,9,999999999,240,0.1550,0,88,0.160,0.0,1.0
+2002,4,18,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,25.0,18.3,66,99000,978,1355,391,416,103,342,45900,10600,38200,12250,200,6.7,5,3,16.0,7620,9,999999999,240,0.1550,0,88,0.160,0.0,1.0
+2002,4,18,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,27.2,18.3,58,98900,1098,1355,399,845,693,282,87600,69300,31300,10020,200,7.7,2,2,16.0,7620,9,999999999,229,0.1550,0,88,0.160,0.0,1.0
+2002,4,18,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,27.8,17.8,55,98700,1155,1355,412,817,589,314,87500,61500,35000,13680,190,8.2,6,5,16.0,7620,9,999999999,229,0.1550,0,88,0.160,0.0,1.0
+2002,4,18,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,30.6,17.2,45,98700,1145,1355,420,785,563,308,84100,58800,34400,13030,190,8.2,3,3,16.0,77777,9,999999999,240,0.1550,0,88,0.160,0.0,1.0
+2002,4,18,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,31.1,16.1,40,98700,1068,1355,421,817,770,208,86300,78200,24500,7150,180,8.8,3,3,16.0,77777,9,999999999,250,0.1550,0,88,0.160,0.0,1.0
+2002,4,18,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,30.6,15.6,40,98500,931,1355,424,667,600,254,70700,62100,27900,6980,210,8.2,6,5,16.0,77777,9,999999999,250,0.1550,0,88,0.160,0.0,1.0
+2002,4,18,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,30.0,13.9,37,98500,743,1355,419,231,41,209,25500,4100,23200,6640,200,6.7,9,5,16.0,6096,9,999999999,270,0.1550,0,88,0.160,0.0,1.0
+2002,4,18,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,30.6,12.8,34,98500,515,1355,424,103,0,103,11900,0,11900,4240,200,6.7,10,6,16.0,4500,9,999999999,290,0.1550,0,88,0.160,0.0,1.0
+2002,4,18,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,29.4,13.9,39,98300,265,1355,431,134,236,88,13900,17400,10500,1760,200,8.2,8,8,16.0,4572,9,999999999,309,0.1550,0,88,0.160,0.0,1.0
+2002,4,18,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,28.3,16.7,49,98400,39,779,437,1,0,1,100,0,100,40,200,7.2,9,9,16.0,4572,9,999999999,320,0.1550,0,88,0.160,0.0,1.0
+2002,4,18,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,27.2,17.2,54,98400,0,0,408,0,0,0,0,0,0,0,200,7.7,5,5,16.0,77777,9,999999999,320,0.1550,0,88,0.160,0.0,1.0
+2002,4,18,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,26.7,18.3,60,98400,0,0,430,0,0,0,0,0,0,0,210,8.8,9,9,16.0,7500,9,999999999,329,0.1550,0,88,0.160,0.0,1.0
+2002,4,18,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,26.1,16.1,54,98500,0,0,424,0,0,0,0,0,0,0,230,6.7,9,9,16.0,7620,9,999999999,329,0.1550,0,88,0.160,0.0,1.0
+2002,4,18,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,23.9,11.7,46,98700,0,0,417,0,0,0,0,0,0,0,310,8.2,10,10,12.8,1981,9,999999999,340,0.1550,0,88,0.160,0.0,1.0
+2002,4,18,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,19.4,14.4,73,98700,0,0,377,0,0,0,0,0,0,0,280,3.6,8,8,16.0,4572,9,999999999,350,0.1550,0,88,0.160,1.0,1.0
+2002,4,19,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,18.9,13.9,73,98600,0,0,382,0,0,0,0,0,0,0,200,5.2,10,9,16.0,4572,9,999999999,340,0.1560,0,88,0.160,0.0,1.0
+2002,4,19,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,19.4,13.3,68,98700,0,0,353,0,0,0,0,0,0,0,270,4.1,4,2,16.0,77777,9,999999999,329,0.1560,0,88,0.160,0.0,1.0
+2002,4,19,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,18.9,13.9,73,98700,0,0,355,0,0,0,0,0,0,0,270,2.6,3,3,16.0,4572,9,999999999,309,0.1560,0,88,0.160,0.0,1.0
+2002,4,19,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,17.8,14.4,80,98800,0,0,369,0,0,0,0,0,0,0,240,1.5,10,8,16.0,6096,9,999999999,270,0.1560,0,88,0.160,0.0,1.0
+2002,4,19,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,17.2,13.9,81,98900,0,0,352,0,0,0,0,0,0,0,220,1.5,6,5,16.0,6096,9,999999999,229,0.1560,0,88,0.160,0.0,1.0
+2002,4,19,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,17.8,11.7,67,98900,94,1208,366,0,0,0,0,0,0,0,340,5.7,9,8,16.0,6096,9,999999999,179,0.1560,0,88,0.160,0.0,1.0
+2002,4,19,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,17.2,11.1,67,99100,345,1355,336,155,133,121,16600,11400,13700,2660,340,6.2,2,1,16.0,6096,9,999999999,189,0.1560,0,88,0.160,0.0,1.0
+2002,4,19,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,17.2,11.1,67,99200,590,1355,362,125,0,125,14500,0,14500,5250,350,5.7,9,8,16.0,6096,9,999999999,189,0.1560,0,88,0.160,0.0,1.0
+2002,4,19,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,17.8,10.0,60,99300,808,1355,364,293,55,260,32200,5600,28900,8380,350,5.2,9,8,16.0,6096,9,999999999,189,0.1560,0,88,0.160,0.0,1.0
+2002,4,19,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,15.6,10.0,69,99300,982,1355,332,668,491,312,69900,50800,33000,9400,50,8.8,2,2,16.0,7620,9,999999999,200,0.1560,0,88,0.160,0.0,1.0
+2002,4,19,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,15.0,9.4,69,99400,1102,1355,344,826,729,231,86900,73800,26700,8510,50,6.2,8,7,16.0,7620,9,999999999,209,0.1560,0,88,0.160,0.0,1.0
+2002,4,19,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,15.6,8.3,62,99400,1158,1355,351,823,619,292,85600,62100,32400,12300,50,7.2,8,8,16.0,701,9,999999999,229,0.1560,0,88,0.160,0.0,1.0
+2002,4,19,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,12.8,6.7,66,99400,1148,1355,326,838,713,233,88700,72400,27100,9740,50,8.8,6,6,16.0,7620,9,999999999,229,0.1560,0,88,0.160,0.0,1.0
+2002,4,19,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,13.9,6.7,62,99400,1072,1355,326,776,663,250,80900,66700,28000,8480,30,8.2,4,4,16.0,7620,9,999999999,240,0.1560,0,88,0.160,0.0,1.0
+2002,4,19,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,13.3,5.6,60,99400,935,1355,337,559,345,320,60100,37100,34400,9170,20,8.2,8,8,16.0,7620,9,999999999,240,0.1560,0,88,0.160,0.0,1.0
+2002,4,19,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,12.2,5.0,61,99400,746,1355,311,458,436,217,47700,44200,23400,4900,30,8.8,2,2,16.0,7620,9,999999999,250,0.1560,0,88,0.160,0.0,1.0
+2002,4,19,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.1,4.4,63,99400,519,1355,296,233,167,169,25300,16200,19000,3930,40,7.7,0,0,16.0,7620,9,999999999,259,0.1560,0,88,0.160,0.0,1.0
+2002,4,19,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.0,3.9,66,99300,270,1355,314,135,248,86,14100,18500,10400,1710,30,8.8,9,7,16.0,7620,9,999999999,270,0.1560,0,88,0.160,0.0,1.0
+2002,4,19,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.9,3.3,68,99300,41,801,298,1,0,1,100,0,100,40,20,9.3,3,3,16.0,3658,9,999999999,259,0.1560,0,88,0.160,0.0,1.0
+2002,4,19,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,3.3,71,99300,0,0,327,0,0,0,0,0,0,0,30,6.2,10,10,16.0,2743,9,999999999,259,0.1560,0,88,0.160,0.0,1.0
+2002,4,19,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,4.4,79,99400,0,0,326,0,0,0,0,0,0,0,30,6.2,10,10,9.6,1981,9,999999999,259,0.1560,0,88,0.160,3.0,1.0
+2002,4,19,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,3.9,76,99500,0,0,325,0,0,0,0,0,0,0,30,2.6,10,10,14.4,2134,9,999999999,270,0.1560,0,88,0.160,0.0,1.0
+2002,4,19,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.2,4.4,82,99400,0,0,323,0,0,0,0,0,0,0,50,5.7,10,10,11.2,1676,9,999999999,279,0.1560,0,88,0.160,0.0,1.0
+2002,4,19,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.7,3.3,79,99400,0,0,320,0,0,0,0,0,0,0,30,6.2,10,10,11.2,2134,9,999999999,290,0.1560,0,88,0.160,0.0,1.0
+2002,4,20,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.7,3.9,82,99400,0,0,320,0,0,0,0,0,0,0,20,6.2,10,10,11.2,1494,9,999999999,279,0.1570,0,88,0.160,0.0,1.0
+2002,4,20,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,2.2,79,99400,0,0,313,0,0,0,0,0,0,0,30,7.7,10,10,11.2,1219,9,999999999,270,0.1570,0,88,0.160,0.0,1.0
+2002,4,20,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,0.6,70,99400,0,0,312,0,0,0,0,0,0,0,30,7.2,10,10,11.2,1524,9,999999999,259,0.1570,0,88,0.160,0.0,1.0
+2002,4,20,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,-0.6,64,99500,0,0,310,0,0,0,0,0,0,0,40,6.2,10,10,16.0,1524,9,999999999,240,0.1570,0,88,0.160,0.0,1.0
+2002,4,20,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.0,-0.6,67,99500,0,0,308,0,0,0,0,0,0,0,30,6.7,10,10,16.0,1676,9,999999999,229,0.1570,0,88,0.160,0.0,1.0
+2002,4,20,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.0,-1.7,61,99600,100,1230,306,0,0,0,0,0,0,0,20,7.7,10,10,16.0,1829,9,999999999,209,0.1570,0,88,0.160,0.0,1.0
+2002,4,20,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,-1.7,58,99700,351,1354,294,121,26,114,13200,2300,12600,2830,40,8.2,8,8,16.0,2438,9,999999999,200,0.1570,0,88,0.160,0.0,1.0
+2002,4,20,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.7,-0.6,59,99600,596,1354,273,221,62,194,24300,6100,21600,5500,40,8.8,0,0,16.0,77777,9,999999999,179,0.1570,0,88,0.160,0.0,1.0
+2002,4,20,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.2,-0.6,57,99700,812,1354,275,567,531,247,59000,54200,26400,5950,30,8.8,0,0,16.0,77777,9,999999999,170,0.1570,0,88,0.160,0.0,1.0
+2002,4,20,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,-1.1,53,99800,986,1354,291,719,678,223,74800,68100,25100,6430,40,8.2,4,4,16.0,77777,9,999999999,170,0.1570,0,88,0.160,0.0,1.0
+2002,4,20,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,-1.1,51,99700,1105,1354,306,690,416,350,72700,43300,37300,13540,40,10.3,8,8,16.0,2438,9,999999999,170,0.1570,0,88,0.160,0.0,1.0
+2002,4,20,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,-1.7,50,99600,1162,1354,304,883,679,299,91800,68000,33300,12730,40,9.3,8,8,16.0,3048,9,999999999,170,0.1570,0,88,0.160,0.0,1.0
+2002,4,20,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,-1.7,50,99700,1151,1354,310,410,60,359,45300,6200,40100,15730,40,8.2,9,9,16.0,2743,9,999999999,170,0.1570,0,88,0.160,0.0,1.0
+2002,4,20,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,-3.3,44,99700,1075,1354,317,286,12,276,33800,1000,33000,12800,30,7.2,10,10,16.0,2743,9,999999999,170,0.1570,0,88,0.160,0.0,1.0
+2002,4,20,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.2,-2.2,50,99600,938,1354,316,268,18,256,31300,1600,30200,11390,40,8.2,10,10,16.0,2591,9,999999999,170,0.1570,0,88,0.160,0.0,1.0
+2002,4,20,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.2,-2.2,50,99600,749,1354,307,381,236,250,41500,24500,27900,6490,30,6.7,10,9,16.0,2591,9,999999999,170,0.1570,0,88,0.160,0.0,1.0
+2002,4,20,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,-4.4,45,99600,523,1354,308,99,0,99,11500,0,11500,4140,30,9.8,10,10,16.0,2438,9,999999999,170,0.1570,0,88,0.160,0.0,1.0
+2002,4,20,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,-3.9,49,99500,274,1354,307,57,0,57,6500,0,6500,2080,30,8.8,10,10,16.0,3048,9,999999999,170,0.1570,0,88,0.160,0.0,1.0
+2002,4,20,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,-3.3,51,99600,44,824,299,2,0,2,300,0,300,80,40,8.2,10,9,16.0,2134,9,999999999,179,0.1570,0,88,0.160,0.0,1.0
+2002,4,20,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,-2.8,53,99500,0,0,308,0,0,0,0,0,0,0,40,9.8,10,10,16.0,1981,9,999999999,189,0.1570,0,88,0.160,0.0,1.0
+2002,4,20,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,-3.3,51,99500,0,0,307,0,0,0,0,0,0,0,40,6.7,10,10,16.0,1981,9,999999999,189,0.1570,0,88,0.160,0.0,1.0
+2002,4,20,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,-2.2,54,99500,0,0,311,0,0,0,0,0,0,0,40,6.7,10,10,16.0,1981,9,999999999,209,0.1570,0,88,0.160,0.0,1.0
+2002,4,20,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,-1.7,56,99500,0,0,311,0,0,0,0,0,0,0,40,7.7,10,10,16.0,1829,9,999999999,220,0.1570,0,88,0.160,0.0,1.0
+2002,4,20,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.0,1.1,76,99300,0,0,309,0,0,0,0,0,0,0,50,6.7,10,10,16.0,2286,9,999999999,229,0.1570,0,88,0.160,0.0,1.0
+2002,4,21,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.0,1.7,79,99300,0,0,310,0,0,0,0,0,0,0,40,6.2,10,10,16.0,2743,9,999999999,240,0.1580,0,88,0.160,0.0,1.0
+2002,4,21,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.0,1.7,79,99200,0,0,310,0,0,0,0,0,0,0,40,7.2,10,10,16.0,1829,9,999999999,240,0.1580,0,88,0.160,0.0,1.0
+2002,4,21,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,2.8,93,99200,0,0,306,0,0,0,0,0,0,0,40,7.2,10,10,11.2,1829,9,999999999,250,0.1580,0,88,0.160,0.0,1.0
+2002,4,21,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,2.8,93,99100,0,0,306,0,0,0,0,0,0,0,50,7.7,10,10,11.2,2286,9,999999999,250,0.1580,0,88,0.160,1.0,1.0
+2002,4,21,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,2.8,93,99200,0,0,306,0,0,0,0,0,0,0,40,7.2,10,10,9.6,427,9,999999999,250,0.1580,0,88,0.160,2.0,1.0
+2002,4,21,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,2.8,93,99200,105,1274,306,0,0,0,0,0,0,0,60,8.8,10,10,9.6,427,9,999999999,250,0.1580,0,88,0.160,0.0,1.0
+2002,4,21,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,4.4,2.8,89,99200,357,1353,309,40,0,40,4800,0,4800,1690,60,8.8,10,10,16.0,488,9,999999999,250,0.1580,0,88,0.160,0.0,1.0
+2002,4,21,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,4.4,3.3,93,99200,601,1353,309,83,0,83,10000,0,10000,3780,80,7.7,10,10,8.0,427,9,999999999,250,0.1580,0,88,0.160,0.0,1.0
+2002,4,21,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,3.3,96,99000,817,1353,307,91,0,91,11300,0,11300,4570,90,7.7,10,10,14.4,305,9,999999999,250,0.1580,0,88,0.160,0.0,1.0
+2002,4,21,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.0,3.3,89,98900,990,1353,312,170,0,170,20600,0,20600,8440,100,10.8,10,10,16.0,427,9,999999999,240,0.1580,0,88,0.160,0.0,1.0
+2002,4,21,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.0,3.3,89,98900,1109,1353,312,172,0,172,21200,0,21200,8780,80,7.2,10,10,16.0,427,9,999999999,229,0.1580,0,88,0.160,0.0,1.0
+2002,4,21,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,3.3,85,98700,1165,1353,315,181,0,181,22400,0,22400,9240,100,8.2,10,10,16.0,488,9,999999999,229,0.1580,0,88,0.160,0.0,1.0
+2002,4,21,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.0,3.3,89,98700,1155,1353,312,161,0,161,20100,0,20100,8340,100,9.3,10,10,12.8,488,9,999999999,220,0.1580,0,88,0.160,0.0,1.0
+2002,4,21,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.0,3.9,93,98600,1078,1353,312,128,0,128,16100,0,16100,6740,100,8.2,10,10,6.4,457,9,999999999,220,0.1580,0,88,0.160,0.0,1.0
+2002,4,21,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,4.4,4.4,100,98400,941,1353,310,108,0,108,13500,0,13500,5580,100,7.2,10,10,3.2,274,9,999999999,209,0.1580,0,88,0.160,1.0,1.0
+2002,4,21,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.0,4.4,96,98600,753,1353,313,221,29,204,24200,2900,22600,6570,60,4.1,10,10,3.2,274,9,999999999,200,0.1580,0,88,0.160,1.0,1.0
+2002,4,21,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,4.4,4.4,100,98500,526,1353,310,62,0,62,7500,0,7500,2800,60,6.2,10,10,3.2,335,9,999999999,189,0.1580,0,88,0.160,0.0,1.0
+2002,4,21,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,4.4,4.4,100,98600,278,1353,310,40,0,40,4700,0,4700,1580,60,5.2,10,10,4.0,335,9,999999999,170,0.1580,0,88,0.160,0.0,1.0
+2002,4,21,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,3.9,100,98600,46,846,308,2,0,2,300,0,300,80,70,4.6,10,10,8.0,183,9,999999999,160,0.1580,0,88,0.160,0.0,1.0
+2002,4,21,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,3.9,100,98700,0,0,308,0,0,0,0,0,0,0,60,3.6,10,10,4.8,183,9,999999999,139,0.1580,0,88,0.160,0.0,1.0
+2002,4,21,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,3.9,100,98700,0,0,308,0,0,0,0,0,0,0,30,3.1,10,10,4.8,183,9,999999999,129,0.1580,0,88,0.160,0.0,1.0
+2002,4,21,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,3.9,100,98700,0,0,308,0,0,0,0,0,0,0,20,2.1,10,10,8.0,274,9,999999999,129,0.1580,0,88,0.160,0.0,1.0
+2002,4,21,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,3.9,100,98700,0,0,308,0,0,0,0,0,0,0,10,2.6,10,10,16.0,152,9,999999999,129,0.1580,0,88,0.160,0.0,1.0
+2002,4,21,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,3.9,100,98700,0,0,308,0,0,0,0,0,0,0,360,2.6,10,10,9.6,152,9,999999999,129,0.1580,0,88,0.160,0.0,1.0
+2002,4,22,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,3.3,96,98700,0,0,307,0,0,0,0,0,0,0,350,2.1,10,10,11.2,152,9,999999999,129,0.1590,0,88,0.160,0.0,1.0
+2002,4,22,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,3.3,96,98700,0,0,307,0,0,0,0,0,0,0,350,4.1,10,10,11.2,152,9,999999999,120,0.1590,0,88,0.160,0.0,1.0
+2002,4,22,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.3,3.3,100,98800,0,0,304,0,0,0,0,0,0,0,350,3.6,10,10,16.0,152,9,999999999,120,0.1590,0,88,0.160,0.0,1.0
+2002,4,22,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.8,2.2,96,99000,0,0,301,0,0,0,0,0,0,0,340,5.2,10,10,16.0,152,9,999999999,110,0.1590,0,88,0.160,0.0,1.0
+2002,4,22,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,1.7,96,99100,0,0,298,0,0,0,0,0,0,0,340,4.6,10,10,12.8,213,9,999999999,110,0.1590,0,88,0.160,0.0,1.0
+2002,4,22,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,0.6,89,99100,111,1296,282,0,0,0,0,0,0,0,340,4.6,8,8,16.0,579,9,999999999,100,0.1590,0,88,0.160,0.0,1.0
+2002,4,22,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.8,0.6,85,99200,362,1352,299,191,217,133,20500,18900,15400,2940,340,5.7,10,10,16.0,396,9,999999999,100,0.1590,0,88,0.160,0.0,1.0
+2002,4,22,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.3,0.6,82,99300,606,1352,301,206,43,187,22600,4200,20700,5400,310,6.2,10,10,16.0,579,9,999999999,100,0.1590,0,88,0.160,0.0,1.0
+2002,4,22,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,0.6,79,99400,822,1352,304,117,0,117,14200,0,14200,5720,320,4.1,10,10,16.0,640,9,999999999,100,0.1590,0,88,0.160,0.0,1.0
+2002,4,22,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,0.0,76,99400,995,1352,303,126,0,126,15600,0,15600,6510,330,5.7,10,10,16.0,671,9,999999999,100,0.1590,0,88,0.160,0.0,1.0
+2002,4,22,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,4.4,-0.6,70,99500,1113,1352,305,191,0,191,23400,0,23400,9610,350,5.2,10,10,16.0,762,9,999999999,100,0.1590,0,88,0.160,0.0,1.0
+2002,4,22,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,4.4,0.6,76,99500,1169,1352,306,151,0,151,18900,0,18900,7890,310,5.7,10,10,16.0,1097,9,999999999,100,0.1590,0,88,0.160,0.0,1.0
+2002,4,22,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,0.0,65,99600,1158,1352,313,208,18,193,23200,1800,21600,9130,330,3.6,10,10,16.0,1036,9,999999999,100,0.1590,0,88,0.160,0.0,1.0
+2002,4,22,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,-1.1,61,99600,1081,1352,310,829,639,317,87900,66500,34600,11550,320,3.1,10,10,16.0,975,9,999999999,100,0.1590,0,88,0.160,0.0,1.0
+2002,4,22,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,-0.6,64,99600,944,1352,310,708,802,146,73200,80000,17200,3650,300,2.6,10,10,16.0,975,9,999999999,89,0.1590,0,88,0.160,0.0,1.0
+2002,4,22,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.0,0.6,73,99600,756,1352,309,547,755,124,57800,75600,15400,2820,50,3.6,10,10,16.0,1036,9,999999999,89,0.1590,0,88,0.160,0.0,1.0
+2002,4,22,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,4.4,0.6,76,99700,530,1352,306,354,642,102,36600,60300,12900,1970,50,2.6,10,10,16.0,1036,9,999999999,89,0.1590,0,88,0.160,0.0,1.0
+2002,4,22,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,0.0,76,99700,282,1352,303,155,434,65,15700,33200,8800,1120,60,3.1,10,10,16.0,1494,9,999999999,89,0.1590,0,88,0.160,0.0,1.0
+2002,4,22,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.3,0.0,79,99700,49,868,301,7,51,6,1000,2400,900,120,60,3.6,10,10,16.0,1524,9,999999999,89,0.1590,0,88,0.160,0.0,1.0
+2002,4,22,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,0.0,76,99800,0,0,303,0,0,0,0,0,0,0,110,2.1,10,10,16.0,945,9,999999999,89,0.1590,0,88,0.160,0.0,1.0
+2002,4,22,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.3,0.6,82,99800,0,0,301,0,0,0,0,0,0,0,120,1.5,10,10,16.0,975,9,999999999,89,0.1590,0,88,0.160,0.0,1.0
+2002,4,22,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,0.0,76,99800,0,0,303,0,0,0,0,0,0,0,100,2.6,10,10,16.0,1494,9,999999999,89,0.1590,0,88,0.160,0.0,1.0
+2002,4,22,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,0.6,89,99800,0,0,297,0,0,0,0,0,0,0,150,1.5,10,10,16.0,1433,9,999999999,89,0.1590,0,88,0.160,0.0,1.0
+2002,4,22,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.3,1.1,85,99800,0,0,302,0,0,0,0,0,0,0,130,2.6,10,10,16.0,1372,9,999999999,100,0.1590,0,88,0.160,0.0,1.0
+2002,4,23,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.8,0.6,85,99800,0,0,285,0,0,0,0,0,0,0,0,0.0,8,8,14.4,1250,9,999999999,100,0.1600,0,88,0.160,0.0,1.0
+2002,4,23,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.6,0.0,96,99800,0,0,263,0,0,0,0,0,0,0,0,0.0,4,4,11.2,77777,9,999999999,100,0.1600,0,88,0.160,0.0,1.0
+2002,4,23,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.1,0.0,92,99800,0,0,270,0,0,0,0,0,0,0,140,1.5,6,6,12.8,77777,9,999999999,100,0.1600,0,88,0.160,0.0,1.0
+2002,4,23,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.6,-0.6,91,99800,0,0,261,0,0,0,0,0,0,0,140,1.5,3,3,9.6,77777,9,999999999,100,0.1600,0,88,0.160,0.0,1.0
+2002,4,23,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,0.6,0.0,96,99800,0,0,263,0,0,0,0,0,0,0,200,1.5,4,4,12.8,77777,9,999999999,100,0.1600,0,88,0.160,0.0,1.0
+2002,4,23,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,1.7,0.6,92,99900,116,1340,266,0,0,0,0,0,0,0,190,2.1,3,3,11.2,77777,9,999999999,100,0.1600,0,88,0.160,0.0,1.0
+2002,4,23,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,0.6,79,99900,368,1352,275,238,479,107,24300,40700,13200,2030,150,3.1,4,3,12.8,77777,9,999999999,100,0.1600,0,88,0.160,0.0,1.0
+2002,4,23,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,0.6,68,99900,611,1352,284,433,677,126,44700,65100,15200,2500,150,4.6,3,3,16.0,77777,9,999999999,110,0.1600,0,88,0.160,0.0,1.0
+2002,4,23,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,1.1,63,99900,826,1352,291,611,763,144,64500,76800,17400,3470,140,4.1,3,3,16.0,77777,9,999999999,110,0.1600,0,88,0.160,0.0,1.0
+2002,4,23,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,0.0,56,99900,999,1352,323,762,817,157,78900,81600,18400,4260,190,4.6,10,10,16.0,1829,9,999999999,120,0.1600,0,88,0.160,0.0,1.0
+2002,4,23,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,9.4,0.6,54,99800,1117,1352,313,862,844,164,90300,84800,20100,5870,180,2.6,8,8,16.0,1524,9,999999999,120,0.1600,0,88,0.160,0.0,1.0
+2002,4,23,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.1,2.2,54,99700,1172,1352,339,907,847,171,95200,85200,21100,7200,170,5.2,10,10,16.0,1524,9,999999999,129,0.1600,0,88,0.160,0.0,1.0
+2002,4,23,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,12.8,3.9,55,99800,1161,1352,318,898,845,170,94100,85000,20900,6910,170,3.6,4,4,16.0,77777,9,999999999,139,0.1600,0,88,0.160,0.0,1.0
+2002,4,23,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,13.9,5.0,55,99700,1084,1352,322,823,818,165,85700,82000,19800,5390,140,4.6,3,3,16.0,77777,9,999999999,150,0.1600,0,88,0.160,0.0,1.0
+2002,4,23,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,14.4,5.0,53,99600,947,1352,310,702,755,172,74200,76600,20400,4810,140,4.1,0,0,16.0,77777,9,999999999,160,0.1600,0,88,0.160,0.0,1.0
+2002,4,23,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,15.6,5.6,51,99500,760,1352,330,508,601,170,52500,59300,19100,3690,150,5.2,3,3,16.0,77777,9,999999999,160,0.1600,0,88,0.160,0.0,1.0
+2002,4,23,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,14.4,5.0,53,99500,534,1352,310,328,521,122,34700,49900,15000,2360,110,7.2,0,0,16.0,77777,9,999999999,160,0.1600,0,88,0.160,0.0,1.0
+2002,4,23,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,12.8,4.4,57,99400,286,1352,303,147,364,70,15300,28000,9400,1280,110,5.7,0,0,16.0,77777,9,999999999,160,0.1600,0,88,0.160,0.0,1.0
+2002,4,23,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.7,4.4,61,99500,52,912,298,8,53,6,1000,2500,900,120,140,6.7,0,0,16.0,77777,9,999999999,160,0.1600,0,88,0.160,0.0,1.0
+2002,4,23,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,9.4,4.4,71,99500,0,0,289,0,0,0,0,0,0,0,150,4.6,0,0,16.0,77777,9,999999999,160,0.1600,0,88,0.160,0.0,1.0
+2002,4,23,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,4.4,79,99400,0,0,282,0,0,0,0,0,0,0,150,4.1,0,0,16.0,77777,9,999999999,160,0.1600,0,88,0.160,0.0,1.0
+2002,4,23,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,5.6,83,99400,0,0,286,0,0,0,0,0,0,0,150,4.1,0,0,14.4,77777,9,999999999,160,0.1600,0,88,0.160,0.0,1.0
+2002,4,23,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.9,5.6,80,99300,0,0,288,0,0,0,0,0,0,0,150,3.6,0,0,14.4,77777,9,999999999,160,0.1600,0,88,0.160,0.0,1.0
+2002,4,23,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,9.4,5.0,74,99300,0,0,289,0,0,0,0,0,0,0,150,4.6,0,0,14.4,77777,9,999999999,160,0.1600,0,88,0.160,0.0,1.0
+2002,4,24,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.9,5.0,77,99200,0,0,287,0,0,0,0,0,0,0,160,3.6,0,0,12.8,77777,9,999999999,160,0.1600,0,88,0.160,0.0,1.0
+2002,4,24,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,4.4,79,99200,0,0,282,0,0,0,0,0,0,0,160,3.1,0,0,12.8,77777,9,999999999,170,0.1600,0,88,0.160,0.0,1.0
+2002,4,24,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,9.4,5.6,77,99100,0,0,290,0,0,0,0,0,0,0,170,4.6,0,0,16.0,77777,9,999999999,170,0.1600,0,88,0.160,0.0,1.0
+2002,4,24,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,9.4,5.6,77,99000,0,0,303,0,0,0,0,0,0,0,170,4.1,3,3,16.0,77777,9,999999999,170,0.1600,0,88,0.160,0.0,1.0
+2002,4,24,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,9.4,6.1,80,99000,0,11,303,0,0,0,0,0,0,0,180,4.1,3,3,16.0,77777,9,999999999,170,0.1600,0,88,0.160,0.0,1.0
+2002,4,24,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.1,6.1,71,99000,122,1351,298,0,0,0,0,0,0,0,180,5.2,0,0,16.0,77777,9,999999999,160,0.1600,0,88,0.160,0.0,1.0
+2002,4,24,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,13.3,6.1,62,99000,373,1351,307,221,387,114,22500,33100,13400,2180,180,7.2,0,0,16.0,77777,9,999999999,170,0.1600,0,88,0.160,0.0,1.0
+2002,4,24,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,15.6,6.1,53,99000,616,1351,317,405,558,150,42800,55000,17600,3040,180,5.7,0,0,16.0,77777,9,999999999,170,0.1600,0,88,0.160,0.0,1.0
+2002,4,24,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,17.8,6.7,48,98900,831,1351,327,591,683,170,61600,68300,19500,4030,200,6.7,0,0,16.0,77777,9,999999999,170,0.1600,0,88,0.160,0.0,1.0
+2002,4,24,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,19.4,7.2,45,98800,1003,1351,350,755,769,183,80000,78200,21800,5600,190,10.3,3,3,16.0,77777,9,999999999,179,0.1600,0,88,0.160,0.0,1.0
+2002,4,24,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,21.7,8.9,44,98700,1120,1351,363,868,814,192,92900,83300,23600,7610,180,9.3,3,3,16.0,77777,9,999999999,189,0.1600,0,88,0.160,0.0,1.0
+2002,4,24,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,22.8,10.0,44,98500,1175,1351,389,889,673,302,92500,67500,33700,13540,200,7.7,8,8,16.0,7620,9,999999999,200,0.1600,0,88,0.160,0.0,1.0
+2002,4,24,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,21.7,10.6,49,98500,1164,1351,374,559,168,414,61400,17900,45900,17350,180,6.2,10,6,16.0,5486,9,999999999,229,0.1600,0,88,0.160,0.0,1.0
+2002,4,24,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,21.1,11.1,53,98400,1087,1351,390,222,12,212,26800,900,26100,10440,190,6.7,10,9,16.0,1524,9,999999999,259,0.1600,0,88,0.160,0.0,1.0
+2002,4,24,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,19.4,13.3,68,98400,950,1351,376,114,0,114,14200,0,14200,5880,210,6.7,10,8,14.4,1219,9,999999999,290,0.1600,0,88,0.160,0.0,1.0
+2002,4,24,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,16.1,15.6,97,98200,763,1351,380,88,0,88,10800,0,10800,4330,180,10.3,10,10,4.0,914,9,999999999,279,0.1600,0,88,0.160,6.0,1.0
+2002,4,24,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,16.7,15.6,93,98200,537,1351,383,57,0,57,6900,0,6900,2610,200,7.2,10,10,9.6,2438,9,999999999,270,0.1600,0,88,0.160,0.0,1.0
+2002,4,24,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.1,10.0,93,98400,290,1351,348,27,0,27,3300,0,3300,1130,310,12.9,10,10,16.0,427,9,999999999,250,0.1600,0,88,0.160,0.0,1.0
+2002,4,24,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.0,7.2,83,98700,54,934,339,6,0,6,700,0,700,240,310,10.3,10,10,16.0,1524,9,999999999,200,0.1600,0,88,0.160,0.0,1.0
+2002,4,24,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.0,6.1,77,98800,0,0,329,0,0,0,0,0,0,0,300,6.2,9,9,16.0,1981,9,999999999,150,0.1600,0,88,0.160,0.0,1.0
+2002,4,24,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.9,1.7,61,99000,0,0,301,0,0,0,0,0,0,0,300,10.3,5,5,16.0,77777,9,999999999,110,0.1600,0,88,0.160,0.0,1.0
+2002,4,24,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,0.0,58,99100,0,0,295,0,0,0,0,0,0,0,300,8.8,5,5,16.0,77777,9,999999999,89,0.1600,0,88,0.160,0.0,1.0
+2002,4,24,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.7,-1.1,57,99200,0,0,289,0,0,0,0,0,0,0,300,9.3,5,5,16.0,77777,9,999999999,69,0.1600,0,88,0.160,0.0,1.0
+2002,4,24,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,-2.8,51,99400,0,0,280,0,0,0,0,0,0,0,300,7.7,3,3,16.0,77777,9,999999999,50,0.1600,0,88,0.160,0.0,1.0
+2002,4,25,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.0,-2.8,55,99400,0,0,276,0,0,0,0,0,0,0,300,7.2,4,3,16.0,77777,9,999999999,50,0.1610,0,88,0.160,0.0,1.0
+2002,4,25,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,4.4,-2.2,61,99500,0,0,271,0,0,0,0,0,0,0,280,4.6,4,2,16.0,77777,9,999999999,50,0.1610,0,88,0.160,0.0,1.0
+2002,4,25,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.3,-2.2,66,99500,0,0,270,0,0,0,0,0,0,0,270,4.1,3,3,16.0,77777,9,999999999,50,0.1610,0,88,0.160,0.0,1.0
+2002,4,25,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.3,-2.8,63,99500,0,0,269,0,0,0,0,0,0,0,260,4.1,3,3,16.0,77777,9,999999999,50,0.1610,0,88,0.160,0.0,1.0
+2002,4,25,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.8,-2.8,65,99500,0,56,267,0,0,0,0,0,0,0,250,3.6,4,3,16.0,77777,9,999999999,50,0.1610,0,88,0.160,0.0,1.0
+2002,4,25,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,-2.2,63,99500,128,1350,261,0,0,0,0,0,0,0,240,4.6,0,0,16.0,77777,9,999999999,50,0.1610,0,88,0.160,0.0,1.0
+2002,4,25,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,-2.8,53,99500,379,1350,267,227,405,114,23300,34800,13500,2180,240,5.2,0,0,16.0,77777,9,999999999,50,0.1610,0,88,0.160,0.0,1.0
+2002,4,25,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,-2.8,46,99500,621,1350,275,404,546,153,42700,53900,17800,3120,260,8.8,0,0,16.0,77777,9,999999999,60,0.1610,0,88,0.160,0.0,1.0
+2002,4,25,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.9,-2.2,45,99400,835,1350,280,590,671,175,61500,67000,20000,4150,260,10.3,0,0,16.0,77777,9,999999999,60,0.1610,0,88,0.160,0.0,1.0
+2002,4,25,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,9.4,-4.4,36,99500,1006,1350,292,755,763,185,79900,77600,22000,5710,270,12.4,3,3,16.0,77777,9,999999999,60,0.1610,0,88,0.160,0.0,1.0
+2002,4,25,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.6,-4.4,33,99500,1123,1350,297,862,826,173,89800,82800,20700,6240,290,11.3,3,3,16.0,77777,9,999999999,69,0.1610,0,88,0.160,0.0,1.0
+2002,4,25,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.1,-3.3,35,99500,1178,1350,300,925,835,195,95800,83500,22800,8160,270,12.4,3,3,16.0,77777,9,999999999,69,0.1610,0,88,0.160,0.0,1.0
+2002,4,25,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.7,-3.3,34,99600,1167,1350,303,892,791,207,95300,80900,25200,9370,280,11.3,3,3,16.0,77777,9,999999999,69,0.1610,0,88,0.160,0.0,1.0
+2002,4,25,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,12.2,-2.8,34,99600,1090,1350,306,841,812,183,86600,81000,21100,5890,280,11.3,3,3,16.0,77777,9,999999999,69,0.1610,0,88,0.160,0.0,1.0
+2002,4,25,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,12.2,-3.3,33,99600,953,1350,305,702,743,176,74100,75400,20800,4970,280,9.8,3,3,16.0,77777,9,999999999,69,0.1610,0,88,0.160,0.0,1.0
+2002,4,25,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,12.2,-3.9,31,99600,766,1350,304,520,625,164,53800,61900,18700,3610,290,8.2,3,3,16.0,77777,9,999999999,69,0.1610,0,88,0.160,0.0,1.0
+2002,4,25,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.7,-4.4,31,99600,541,1350,302,345,573,114,35300,53800,13700,2170,290,9.3,3,3,16.0,77777,9,999999999,69,0.1610,0,88,0.160,0.0,1.0
+2002,4,25,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.6,-5.0,31,99600,294,1350,293,153,382,70,16000,29800,9500,1280,280,8.8,4,2,16.0,77777,9,999999999,69,0.1610,0,88,0.160,0.0,1.0
+2002,4,25,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.0,-4.4,34,99700,57,956,282,9,38,8,1200,1500,1100,130,280,6.2,0,0,16.0,77777,9,999999999,69,0.1610,0,88,0.160,0.0,1.0
+2002,4,25,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,-3.9,40,99700,0,0,276,0,0,0,0,0,0,0,270,2.6,0,0,16.0,77777,9,999999999,69,0.1610,0,88,0.160,0.0,1.0
+2002,4,25,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,-3.3,44,99800,0,0,275,0,0,0,0,0,0,0,270,2.1,0,0,16.0,77777,9,999999999,69,0.1610,0,88,0.160,0.0,1.0
+2002,4,25,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,-1.7,56,99800,0,0,270,0,0,0,0,0,0,0,250,2.1,0,0,16.0,77777,9,999999999,69,0.1610,0,88,0.160,0.0,1.0
+2002,4,25,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,-2.2,56,99800,0,0,279,0,0,0,0,0,0,0,250,1.5,4,3,16.0,77777,9,999999999,69,0.1610,0,88,0.160,0.0,1.0
+2002,4,25,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,-2.2,56,99800,0,0,267,0,0,0,0,0,0,0,290,3.6,0,0,16.0,77777,9,999999999,69,0.1610,0,88,0.160,0.0,1.0
+2002,4,26,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.0,-2.8,55,99900,0,0,264,0,0,0,0,0,0,0,280,3.6,0,0,16.0,77777,9,999999999,69,0.1620,0,88,0.160,0.0,1.0
+2002,4,26,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.0,-3.3,53,99900,0,0,264,0,0,0,0,0,0,0,310,4.1,0,0,16.0,77777,9,999999999,69,0.1620,0,88,0.160,0.0,1.0
+2002,4,26,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,-3.3,57,99900,0,0,260,0,0,0,0,0,0,0,310,3.6,0,0,16.0,77777,9,999999999,69,0.1620,0,88,0.160,0.0,1.0
+2002,4,26,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.8,-3.9,59,100000,0,0,255,0,0,0,0,0,0,0,320,3.1,0,0,16.0,77777,9,999999999,69,0.1620,0,88,0.160,0.0,1.0
+2002,4,26,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.2,-3.9,62,100000,0,79,253,0,0,0,0,0,0,0,350,2.6,0,0,16.0,77777,9,999999999,69,0.1620,0,88,0.160,0.0,1.0
+2002,4,26,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,2.8,-3.9,59,100100,133,1349,255,0,0,0,0,0,0,0,350,3.6,0,0,16.0,77777,9,999999999,69,0.1620,0,88,0.160,0.0,1.0
+2002,4,26,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,3.9,-5.0,50,100200,384,1349,258,234,424,113,23900,36600,13500,2150,350,4.1,0,0,16.0,77777,9,999999999,69,0.1620,0,88,0.160,0.0,1.0
+2002,4,26,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,-6.1,40,100200,625,1349,263,410,558,151,43400,55200,17700,3080,30,4.6,0,0,16.0,77777,9,999999999,69,0.1620,0,88,0.160,0.0,1.0
+2002,4,26,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,-6.1,39,100200,839,1349,265,583,652,177,60700,65100,20100,4220,0,0.0,0,0,16.0,77777,9,999999999,69,0.1620,0,88,0.160,0.0,1.0
+2002,4,26,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.2,-5.6,38,100300,1010,1349,270,723,666,224,75600,67100,25300,6800,360,1.5,0,0,16.0,77777,9,999999999,80,0.1620,0,88,0.160,0.0,1.0
+2002,4,26,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,-6.7,32,100300,1127,1349,285,862,789,201,91900,80600,24400,8110,0,0.0,3,3,16.0,77777,9,999999999,80,0.1620,0,88,0.160,0.0,1.0
+2002,4,26,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.9,-5.0,35,100200,1181,1349,277,925,865,166,97500,87200,21000,7320,0,0.0,0,0,16.0,77777,9,999999999,89,0.1620,0,88,0.160,0.0,1.0
+2002,4,26,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.0,-4.4,34,100300,1170,1349,282,915,869,161,96800,87700,20600,6870,30,2.6,0,0,16.0,77777,9,999999999,89,0.1620,0,88,0.160,0.0,1.0
+2002,4,26,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.6,-1.7,42,100200,1093,1349,288,841,806,186,89800,82500,22800,6920,50,3.1,0,0,16.0,77777,9,999999999,89,0.1620,0,88,0.160,0.0,1.0
+2002,4,26,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.0,-0.6,47,100100,956,1349,286,697,725,181,73400,73500,21200,5120,80,4.1,0,0,16.0,77777,9,999999999,89,0.1620,0,88,0.160,0.0,1.0
+2002,4,26,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.0,-1.1,45,100100,769,1349,286,526,637,162,54600,63100,18500,3590,100,4.6,0,0,16.0,77777,9,999999999,100,0.1620,0,88,0.160,0.0,1.0
+2002,4,26,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.9,-0.6,51,100100,544,1349,282,335,516,126,35400,49600,15300,2460,100,5.7,0,0,16.0,77777,9,999999999,100,0.1620,0,88,0.160,0.0,1.0
+2002,4,26,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,-2.2,48,100100,298,1349,288,153,366,73,16000,28700,9700,1340,90,4.6,3,3,16.0,77777,9,999999999,100,0.1620,0,88,0.160,0.0,1.0
+2002,4,26,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.7,-2.8,49,100100,60,978,271,8,11,8,1000,500,1000,160,100,5.2,0,0,16.0,77777,9,999999999,100,0.1620,0,88,0.160,0.0,1.0
+2002,4,26,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,-1.7,56,100100,0,0,270,0,0,0,0,0,0,0,100,3.6,0,0,16.0,77777,9,999999999,100,0.1620,0,88,0.160,0.0,1.0
+2002,4,26,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,-2.2,54,100100,0,0,269,0,0,0,0,0,0,0,90,2.6,0,0,16.0,77777,9,999999999,100,0.1620,0,88,0.160,0.0,1.0
+2002,4,26,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,-3.3,51,100100,0,0,271,0,0,0,0,0,0,0,90,2.6,1,1,16.0,77777,9,999999999,110,0.1620,0,88,0.160,0.0,1.0
+2002,4,26,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,-4.4,46,100100,0,0,279,0,0,0,0,0,0,0,100,2.6,5,4,16.0,77777,9,999999999,110,0.1620,0,88,0.160,0.0,1.0
+2002,4,26,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,-4.4,46,100100,0,0,277,0,0,0,0,0,0,0,90,2.6,3,3,16.0,6096,9,999999999,110,0.1620,0,88,0.160,0.0,1.0
+2002,4,27,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,-4.4,46,100000,0,0,279,0,0,0,0,0,0,0,90,3.1,4,4,16.0,6096,9,999999999,120,0.1630,0,88,0.160,0.0,1.0
+2002,4,27,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,-4.4,45,100000,0,0,293,0,0,0,0,0,0,0,90,3.6,9,8,16.0,6096,9,999999999,120,0.1630,0,88,0.160,0.0,1.0
+2002,4,27,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,-4.4,45,100000,0,0,308,0,0,0,0,0,0,0,100,4.1,10,10,16.0,3048,9,999999999,129,0.1630,0,88,0.160,0.0,1.0
+2002,4,27,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.7,-5.6,39,99800,0,0,309,0,0,0,0,0,0,0,110,4.6,10,10,16.0,3048,9,999999999,129,0.1630,0,88,0.160,0.0,1.0
+2002,4,27,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.7,-7.8,32,99800,1,124,307,0,0,0,0,0,0,0,90,3.6,10,10,16.0,2743,9,999999999,139,0.1630,0,88,0.160,0.0,1.0
+2002,4,27,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,-5.0,43,99800,138,1349,308,32,0,32,3600,0,3600,1070,90,4.1,10,10,16.0,2743,9,999999999,139,0.1630,0,88,0.160,0.0,1.0
+2002,4,27,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.7,-1.7,54,99800,389,1349,314,39,0,39,4700,0,4700,1700,90,4.6,10,10,16.0,2743,9,999999999,170,0.1630,0,88,0.160,0.0,1.0
+2002,4,27,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.7,-1.7,54,99800,630,1349,314,82,0,82,9900,0,9900,3810,80,6.2,10,10,16.0,1829,9,999999999,189,0.1630,0,88,0.160,0.0,1.0
+2002,4,27,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,-1.1,53,99700,843,1349,311,136,0,136,16400,0,16400,6580,100,6.7,10,9,16.0,2591,9,999999999,220,0.1630,0,88,0.160,0.0,1.0
+2002,4,27,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,0.6,60,99600,1014,1349,313,157,0,157,19200,0,19200,7950,100,6.2,10,9,16.0,2591,9,999999999,229,0.1630,0,88,0.160,0.0,1.0
+2002,4,27,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,1.7,65,99400,1130,1349,302,148,0,148,18500,0,18500,7720,100,6.2,9,7,16.0,4572,9,999999999,240,0.1630,0,88,0.160,0.0,1.0
+2002,4,27,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,4.4,79,99200,1184,1349,317,151,0,151,19000,0,19000,7900,90,4.6,10,9,12.8,1463,9,999999999,250,0.1630,0,88,0.160,0.0,1.0
+2002,4,27,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.2,6.1,93,99100,1173,1349,325,143,0,143,18000,0,18000,7520,100,6.7,10,10,6.4,610,9,999999999,270,0.1630,0,88,0.160,2.0,1.0
+2002,4,27,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.2,6.7,97,99000,1096,1349,326,134,0,134,16800,0,16800,7040,100,7.7,10,10,6.4,335,9,999999999,290,0.1630,0,88,0.160,2.0,1.0
+2002,4,27,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.2,7.2,100,98800,959,1349,326,120,0,120,14900,0,14900,6170,110,9.3,10,10,4.8,335,9,999999999,309,0.1630,0,88,0.160,2.0,1.0
+2002,4,27,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.2,7.2,100,98400,772,1349,326,89,0,89,11000,0,11000,4400,110,9.3,10,10,4.0,2438,9,999999999,300,0.1630,0,88,0.160,2.0,1.0
+2002,4,27,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.8,7.2,96,98300,548,1349,329,58,0,58,7100,0,7100,2670,120,10.3,10,10,8.0,244,9,999999999,300,0.1630,0,88,0.160,0.0,1.0
+2002,4,27,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,7.2,93,98200,302,1349,331,27,0,27,3300,0,3300,1140,130,8.8,10,10,8.0,244,9,999999999,290,0.1630,0,88,0.160,0.0,1.0
+2002,4,27,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,8.3,100,98100,63,1000,332,5,0,5,600,0,600,200,140,6.7,10,10,2.4,244,9,999999999,279,0.1630,0,88,0.160,0.0,1.0
+2002,4,27,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.9,8.9,100,98000,0,0,336,0,0,0,0,0,0,0,150,6.7,10,10,2.4,244,9,999999999,259,0.1630,0,88,0.160,0.0,1.0
+2002,4,27,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.9,8.9,100,97900,0,0,336,0,0,0,0,0,0,0,150,6.2,10,10,4.0,213,9,999999999,250,0.1630,0,88,0.160,0.0,1.0
+2002,4,27,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,9.4,9.4,100,97700,0,0,339,0,0,0,0,0,0,0,150,6.2,10,10,4.0,152,9,999999999,250,0.1630,0,88,0.160,0.0,1.0
+2002,4,27,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.6,10.6,100,97600,0,0,346,0,0,0,0,0,0,0,180,6.2,10,10,3.2,1158,9,999999999,250,0.1630,0,88,0.160,0.0,1.0
+2002,4,27,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.7,11.7,100,97300,0,0,353,0,0,0,0,0,0,0,170,5.2,10,10,8.0,152,9,999999999,250,0.1630,0,88,0.160,0.0,1.0
+2002,4,28,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,12.2,11.7,97,97200,0,0,346,0,0,0,0,0,0,0,190,3.6,9,9,11.2,3048,9,999999999,250,0.1630,0,88,0.160,0.0,1.0
+2002,4,28,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,13.9,12.8,93,97100,0,0,355,0,0,0,0,0,0,0,190,4.6,9,9,14.4,3048,9,999999999,240,0.1630,0,88,0.160,0.0,1.0
+2002,4,28,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,15.0,12.2,83,97100,0,0,360,0,0,0,0,0,0,0,240,8.8,9,9,16.0,975,9,999999999,240,0.1630,0,88,0.160,0.0,1.0
+2002,4,28,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,12.8,8.9,77,97200,0,0,355,0,0,0,0,0,0,0,240,9.3,10,10,16.0,1006,9,999999999,240,0.1630,0,88,0.160,0.0,1.0
+2002,4,28,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.7,8.3,80,97100,1,146,349,0,0,0,0,0,0,0,250,7.2,10,10,16.0,914,9,999999999,240,0.1630,0,88,0.160,0.0,1.0
+2002,4,28,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.0,9.4,96,97200,144,1348,342,46,0,46,5000,0,5000,1370,240,8.2,10,10,6.4,427,9,999999999,240,0.1630,0,88,0.160,0.0,1.0
+2002,4,28,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,7.8,97,97300,394,1348,332,108,0,108,12100,0,12100,3870,260,11.3,10,10,4.8,305,9,999999999,229,0.1630,0,88,0.160,0.0,1.0
+2002,4,28,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,8.3,100,97400,634,1348,332,82,0,82,9900,0,9900,3820,260,9.3,10,10,9.6,183,9,999999999,229,0.1630,0,88,0.160,0.0,1.0
+2002,4,28,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.7,5.6,93,97700,847,1348,322,123,0,123,15000,0,15000,6050,280,9.3,10,10,16.0,244,9,999999999,229,0.1630,0,88,0.160,0.0,1.0
+2002,4,28,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.7,4.4,85,97900,1017,1348,321,119,0,119,14900,0,14900,6230,310,9.8,10,10,16.0,366,9,999999999,220,0.1630,0,88,0.160,0.0,1.0
+2002,4,28,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,3.9,86,98100,1133,1348,317,142,0,142,17800,0,17800,7450,320,9.8,10,10,16.0,427,9,999999999,209,0.1630,0,88,0.160,0.0,1.0
+2002,4,28,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,3.3,85,98300,1187,1348,315,151,0,151,19000,0,19000,7910,310,7.7,10,10,16.0,427,9,999999999,200,0.1630,0,88,0.160,0.0,1.0
+2002,4,28,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,2.8,82,98400,1175,1348,314,143,0,143,18000,0,18000,7520,320,8.8,10,10,16.0,427,9,999999999,189,0.1630,0,88,0.160,0.0,1.0
+2002,4,28,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,2.8,82,98600,1099,1348,314,134,0,134,16800,0,16800,7050,310,8.8,10,10,16.0,488,9,999999999,179,0.1630,0,88,0.160,0.0,1.0
+2002,4,28,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,2.8,82,98700,962,1348,314,137,0,137,16800,0,16800,6950,310,7.7,10,10,16.0,549,9,999999999,160,0.1630,0,88,0.160,0.0,1.0
+2002,4,28,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,2.2,76,98800,776,1348,316,122,0,122,14700,0,14700,5800,320,7.7,10,10,16.0,640,9,999999999,160,0.1630,0,88,0.160,0.0,1.0
+2002,4,28,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,2.2,76,98900,551,1348,316,89,0,89,10500,0,10500,3890,330,9.8,10,10,16.0,640,9,999999999,150,0.1630,0,88,0.160,0.0,1.0
+2002,4,28,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,1.7,73,98900,305,1348,315,18,0,18,2300,0,2300,790,320,8.8,10,10,16.0,762,9,999999999,139,0.1630,0,88,0.160,0.0,1.0
+2002,4,28,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,1.7,73,99000,66,1022,315,2,0,2,300,0,300,80,10,5.7,10,10,16.0,914,9,999999999,129,0.1630,0,88,0.160,0.0,1.0
+2002,4,28,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,1.7,73,99100,0,0,315,0,0,0,0,0,0,0,340,3.1,10,10,16.0,975,9,999999999,129,0.1630,0,88,0.160,0.0,1.0
+2002,4,28,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,2.2,76,99200,0,0,316,0,0,0,0,0,0,0,330,3.6,10,10,16.0,975,9,999999999,129,0.1630,0,88,0.160,0.0,1.0
+2002,4,28,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,1.7,76,99100,0,0,313,0,0,0,0,0,0,0,360,3.1,10,10,16.0,1036,9,999999999,129,0.1630,0,88,0.160,0.0,1.0
+2002,4,28,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,2.2,79,99200,0,0,313,0,0,0,0,0,0,0,0,0.0,10,10,16.0,823,9,999999999,129,0.1630,0,88,0.160,0.0,1.0
+2002,4,28,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.0,2.8,86,99200,0,0,311,0,0,0,0,0,0,0,90,1.5,10,10,16.0,1097,9,999999999,129,0.1630,0,88,0.160,0.0,1.0
+2002,4,29,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,4.4,3.3,93,99200,0,0,309,0,0,0,0,0,0,0,0,0.0,10,10,16.0,975,9,999999999,129,0.1640,0,88,0.160,0.0,1.0
+2002,4,29,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.0,3.3,89,99200,0,0,312,0,0,0,0,0,0,0,0,0.0,10,10,16.0,1219,9,999999999,129,0.1640,0,88,0.160,0.0,1.0
+2002,4,29,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,2.8,82,99200,0,0,314,0,0,0,0,0,0,0,240,2.1,10,10,16.0,1219,9,999999999,129,0.1640,0,88,0.160,0.0,1.0
+2002,4,29,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,3.3,85,99100,0,0,315,0,0,0,0,0,0,0,200,1.5,10,10,16.0,1219,9,999999999,129,0.1640,0,88,0.160,0.0,1.0
+2002,4,29,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,5.6,3.3,85,99100,2,168,315,0,0,0,0,0,0,0,230,2.1,10,10,14.4,1158,9,999999999,129,0.1640,0,88,0.160,0.0,1.0
+2002,4,29,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.1,3.3,82,99100,149,1347,317,44,0,44,4800,0,4800,1360,260,3.1,10,10,16.0,1158,9,999999999,129,0.1640,0,88,0.160,0.0,1.0
+2002,4,29,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,6.7,2.8,76,99200,399,1347,319,123,6,121,13700,400,13500,4190,290,5.2,10,10,16.0,1097,9,999999999,120,0.1640,0,88,0.160,0.0,1.0
+2002,4,29,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,7.2,2.8,74,99200,639,1347,321,218,19,209,24500,1600,23800,7890,270,6.7,10,10,16.0,1097,9,999999999,120,0.1640,0,88,0.160,0.0,1.0
+2002,4,29,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.3,2.8,68,99100,851,1347,326,246,12,238,28400,1000,27800,10280,280,3.6,10,10,16.0,1219,9,999999999,120,0.1640,0,88,0.160,0.0,1.0
+2002,4,29,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,9.4,3.3,66,99100,1021,1347,316,528,212,367,57700,22500,40600,12150,270,5.7,8,8,16.0,1067,9,999999999,120,0.1640,0,88,0.160,0.0,1.0
+2002,4,29,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.0,3.9,66,99100,1136,1347,319,492,102,406,54300,10500,45400,17200,240,7.2,8,8,16.0,1006,9,999999999,110,0.1640,0,88,0.160,0.0,1.0
+2002,4,29,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.0,4.4,68,99000,1190,1347,336,653,276,408,71200,30000,44700,18990,250,5.7,10,10,16.0,945,9,999999999,110,0.1640,0,88,0.160,0.0,1.0
+2002,4,29,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.1,5.6,69,99100,1178,1347,326,184,12,174,22900,900,22200,8950,260,6.2,8,8,16.0,1067,9,999999999,120,0.1640,0,88,0.160,0.0,1.0
+2002,4,29,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,13.9,5.0,55,99000,1101,1347,339,788,538,348,83100,56000,37200,13490,260,6.7,8,8,16.0,1463,9,999999999,129,0.1640,0,88,0.160,0.0,1.0
+2002,4,29,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,15.0,3.9,47,98900,965,1347,328,709,737,179,74800,74800,21100,5160,270,6.2,4,4,16.0,77777,9,999999999,129,0.1640,0,88,0.160,0.0,1.0
+2002,4,29,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,15.6,3.9,46,98900,779,1347,328,532,631,166,55100,62600,18900,3710,280,5.2,3,3,16.0,77777,9,999999999,120,0.1640,0,88,0.160,0.0,1.0
+2002,4,29,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,16.1,3.9,44,98800,555,1347,330,341,510,130,36000,49300,15700,2550,270,5.2,3,3,16.0,77777,9,999999999,120,0.1640,0,88,0.160,0.0,1.0
+2002,4,29,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,15.6,1.7,39,98700,309,1347,322,165,324,90,16800,25700,10900,1690,260,6.2,4,2,16.0,77777,9,999999999,110,0.1640,0,88,0.160,0.0,1.0
+2002,4,29,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,14.4,1.7,42,98800,69,1044,307,13,46,11,1600,1700,1500,180,240,3.1,0,0,16.0,77777,9,999999999,100,0.1640,0,88,0.160,0.0,1.0
+2002,4,29,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,13.3,2.2,47,98800,0,0,303,0,0,0,0,0,0,0,220,3.6,0,0,16.0,77777,9,999999999,100,0.1640,0,88,0.160,0.0,1.0
+2002,4,29,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,12.2,2.2,50,98800,0,0,298,0,0,0,0,0,0,0,220,2.6,0,0,16.0,77777,9,999999999,100,0.1640,0,88,0.160,0.0,1.0
+2002,4,29,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.7,2.2,52,98800,0,0,296,0,0,0,0,0,0,0,230,4.1,0,0,16.0,77777,9,999999999,110,0.1640,0,88,0.160,0.0,1.0
+2002,4,29,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.7,2.2,52,98700,0,0,296,0,0,0,0,0,0,0,230,4.1,0,0,16.0,77777,9,999999999,110,0.1640,0,88,0.160,0.0,1.0
+2002,4,29,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.7,2.2,52,98700,0,0,302,0,0,0,0,0,0,0,230,4.6,1,1,16.0,77777,9,999999999,120,0.1640,0,88,0.160,0.0,1.0
+2002,4,30,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.7,3.3,56,98600,0,0,326,0,0,0,0,0,0,0,260,4.6,8,8,16.0,3353,9,999999999,120,0.1650,0,88,0.160,0.0,1.0
+2002,4,30,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.1,3.9,61,98700,0,0,324,0,0,0,0,0,0,0,280,4.1,9,8,16.0,77777,9,999999999,120,0.1650,0,88,0.160,0.0,1.0
+2002,4,30,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.1,5.0,66,98800,0,0,342,0,0,0,0,0,0,0,310,3.6,10,10,16.0,3048,9,999999999,129,0.1650,0,88,0.160,0.0,1.0
+2002,4,30,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.1,4.4,63,98800,0,0,332,0,0,0,0,0,0,0,300,3.1,9,9,16.0,3048,9,999999999,120,0.1650,0,88,0.160,0.0,1.0
+2002,4,30,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.1,2.2,54,98800,3,213,339,0,0,0,0,0,0,0,340,3.6,10,10,16.0,2591,9,999999999,120,0.1650,0,88,0.160,0.0,1.0
+2002,4,30,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.6,1.7,54,98800,154,1347,320,56,8,55,6000,100,6000,1560,330,5.2,8,8,16.0,77777,9,999999999,120,0.1650,0,88,0.160,0.0,1.0
+2002,4,30,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.1,1.7,52,98900,404,1347,322,245,291,158,25300,26100,17500,3410,340,3.6,9,8,16.0,2134,9,999999999,120,0.1650,0,88,0.160,0.0,1.0
+2002,4,30,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.7,0.0,44,99000,643,1347,323,211,31,196,23200,3100,21700,5810,320,3.1,9,8,16.0,77777,9,999999999,120,0.1650,0,88,0.160,0.0,1.0
+2002,4,30,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,12.2,-0.6,41,99000,855,1347,331,336,73,290,37000,7400,32300,9580,310,5.2,10,9,16.0,4572,9,999999999,120,0.1650,0,88,0.160,0.0,1.0
+2002,4,30,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,12.2,-3.3,33,99000,1024,1347,321,207,6,203,25000,500,24600,9900,260,3.6,9,8,16.0,4572,9,999999999,129,0.1650,0,88,0.160,0.0,1.0
+2002,4,30,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,12.8,-4.4,29,99000,1139,1347,330,308,12,297,36500,1000,35600,13770,340,2.6,10,9,16.0,3048,9,999999999,129,0.1650,0,88,0.160,0.0,1.0
+2002,4,30,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,13.3,-5.0,26,98900,1193,1347,331,266,6,261,32200,500,31800,12590,320,2.1,10,9,16.0,3048,9,999999999,139,0.1650,0,88,0.160,0.0,1.0
+2002,4,30,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,13.3,-6.1,24,98900,1181,1347,330,422,36,390,46600,3700,43300,17860,0,0.0,10,9,16.0,3048,9,999999999,139,0.1650,0,88,0.160,0.0,1.0
+2002,4,30,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,14.4,-4.4,26,98800,1104,1347,346,368,24,348,43000,2200,41100,15280,290,1.5,10,10,16.0,6096,9,999999999,139,0.1650,0,88,0.160,0.0,1.0
+2002,4,30,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,14.4,-4.4,26,98800,968,1347,346,297,18,284,34500,1600,33400,12500,220,1.5,10,10,16.0,6096,9,999999999,150,0.1650,0,88,0.160,0.0,1.0
+2002,4,30,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,15.0,-3.3,27,98700,782,1347,322,233,30,216,25700,3000,24000,7080,200,2.1,6,5,16.0,6096,9,999999999,150,0.1650,0,88,0.160,0.0,1.0
+2002,4,30,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,15.0,-3.9,26,98700,558,1347,321,347,371,192,36400,36900,21100,4220,170,2.1,5,5,16.0,6096,9,999999999,139,0.1650,0,88,0.160,0.0,1.0
+2002,4,30,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,12.8,2.2,48,98600,313,1347,347,115,105,90,12400,8700,10400,1960,140,4.6,10,10,16.0,6096,9,999999999,139,0.1650,0,88,0.160,0.0,1.0
+2002,4,30,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.7,5.0,63,98700,73,1066,299,16,66,13,2000,2800,1800,220,140,4.1,0,0,16.0,4572,9,999999999,139,0.1650,0,88,0.160,0.0,1.0
+2002,4,30,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,11.1,5.6,69,98800,0,0,310,0,0,0,0,0,0,0,210,2.1,3,3,16.0,6096,9,999999999,139,0.1650,0,88,0.160,0.0,1.0
+2002,4,30,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,10.6,6.1,74,98800,0,0,332,0,0,0,0,0,0,0,0,0.0,9,9,16.0,3353,9,999999999,139,0.1650,0,88,0.160,0.0,1.0
+2002,4,30,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,9.8,5.9,77,98700,0,0,307,0,0,0,0,0,0,0,190,0.4,4,4,16.0,77777,9,999999999,139,0.1650,0,88,0.160,0.0,1.0
+2002,4,30,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,9.0,5.6,80,98700,0,0,333,0,0,0,0,0,0,0,170,0.7,10,10,16.0,3048,9,999999999,139,0.1650,0,88,0.160,0.0,1.0
+2002,4,30,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9?9?9?9,8.2,5.4,77,98600,0,0,329,0,0,0,0,0,0,0,170,1.1,10,10,16.0,2286,9,999999999,139,0.1650,0,88,0.160,0.0,1.0
+1980,5,1,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.4,5.1,96,99000,0,0,296,0,0,0,0,0,0,0,270,1.5,4,4,19.3,77777,9,999999999,150,0.1650,0,88,999.000,999.0,99.0
+1980,5,1,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.6,4.9,93,99000,0,0,297,0,0,0,0,0,0,0,240,1.9,6,6,14.5,1070,9,999999999,139,0.1650,0,88,999.000,999.0,99.0
+1980,5,1,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.8,4.6,96,99000,0,0,297,0,0,0,0,0,0,0,200,2.2,7,7,14.5,1160,9,999999999,129,0.1650,0,88,999.000,999.0,99.0
+1980,5,1,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,4.4,96,99000,0,0,304,0,0,0,0,0,0,0,190,2.6,9,9,19.3,1160,9,999999999,139,0.1650,0,88,999.000,999.0,99.0
+1980,5,1,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,5.6,93,99000,4,258,313,0,0,0,0,0,0,0,140,3.1,9,9,14.5,1160,9,999999999,150,0.2790,0,88,999.000,999.0,99.0
+1980,5,1,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.8,6.7,93,99000,161,1345,304,23,1,23,2700,0,2700,860,30,2.1,8,6,14.5,1160,9,999999999,160,0.2790,0,88,999.000,999.0,99.0
+1980,5,1,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,9.4,83,99100,410,1345,316,195,307,101,20300,27300,12000,1890,150,2.6,2,2,14.5,77777,9,999999999,189,0.2790,0,88,999.000,999.0,99.0
+1980,5,1,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,8.9,75,99100,648,1345,340,270,113,215,29300,11500,23700,5290,140,2.6,8,8,12.9,2130,9,999999999,179,0.2790,0,88,999.000,999.0,99.0
+1980,5,1,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,8.9,70,99200,859,1345,363,266,3,264,30600,300,30400,11110,240,2.1,10,10,11.3,2130,9,999999999,179,0.2790,0,88,999.000,999.0,99.0
+1980,5,1,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,9.4,70,99200,1028,1345,367,302,25,282,33300,2500,31300,11100,300,1.5,10,10,9.7,1160,9,999999999,189,0.2790,0,88,999.000,999.0,99.0
+1980,5,1,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,8.9,65,99200,1143,1345,369,354,5,350,41600,500,41200,15520,330,2.6,10,10,11.3,1010,9,999999999,179,0.2790,0,88,999.000,999.0,99.0
+1980,5,1,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,9.4,65,99200,1196,1345,372,435,2,433,50600,200,50400,18110,30,2.1,10,10,11.3,1010,9,999999999,189,0.2790,0,88,999.000,999.0,99.0
+1980,5,1,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,9.4,67,99200,1184,1345,370,427,6,421,49600,600,49100,17730,360,2.6,10,10,11.3,760,9,999999999,189,0.2790,0,88,999.000,999.0,99.0
+1980,5,1,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,10.0,72,99200,1107,1345,367,332,1,331,38900,100,38900,14780,180,3.1,10,10,12.9,700,9,999999999,189,0.2790,0,88,999.000,999.0,99.0
+1980,5,1,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,11.1,72,99200,971,1345,374,270,4,267,31600,300,31300,11990,220,3.6,10,10,12.9,880,9,999999999,209,0.2790,0,88,999.000,999.0,99.0
+1980,5,1,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,10.0,67,99100,785,1345,373,227,3,225,26100,300,25900,9440,210,2.1,10,10,14.5,880,9,999999999,189,0.2790,0,88,999.000,999.0,99.0
+1980,5,1,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,10.0,65,99100,562,1345,352,226,156,162,24900,15500,18400,3830,70,2.6,8,7,14.5,1830,9,999999999,189,0.2790,0,88,999.000,999.0,99.0
+1980,5,1,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,10.0,67,99100,318,1345,350,96,67,81,10600,5600,9300,1760,160,2.1,7,7,12.9,1830,9,999999999,189,0.2790,0,88,999.000,999.0,99.0
+1980,5,1,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,9.4,75,99100,77,1110,326,16,7,15,1700,400,1700,380,190,2.1,3,3,12.9,77777,9,999999999,189,0.2790,0,88,999.000,999.0,99.0
+1980,5,1,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,8.3,77,99200,0,0,314,0,0,0,0,0,0,0,110,3.1,2,2,12.9,77777,9,999999999,170,0.2790,0,88,999.000,999.0,99.0
+1980,5,1,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,8.3,83,99200,0,0,300,0,0,0,0,0,0,0,100,3.1,0,0,14.5,77777,9,999999999,179,0.2790,0,88,999.000,999.0,99.0
+1980,5,1,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,7.8,86,99200,0,0,295,0,0,0,0,0,0,0,90,3.1,0,0,14.5,77777,9,999999999,170,0.2790,0,88,999.000,999.0,99.0
+1980,5,1,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,7.8,96,99200,0,0,332,0,0,0,0,0,0,0,60,3.1,10,10,0.4,60,9,999999999,170,0.2790,0,88,999.000,999.0,99.0
+1980,5,1,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,7.8,100,99200,0,0,330,0,0,0,0,0,0,0,40,2.6,10,10,0.2,30,9,999999999,170,0.2790,0,88,999.000,999.0,99.0
+1980,5,2,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,7.2,96,99200,0,0,329,0,0,0,0,0,0,0,120,2.1,10,10,0.2,30,9,999999999,160,0.2790,0,88,999.000,999.0,99.0
+1980,5,2,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,6.7,96,99200,0,0,326,0,0,0,0,0,0,0,10,2.1,10,10,0.2,30,9,999999999,160,0.2790,0,88,999.000,999.0,99.0
+1980,5,2,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,6.1,96,99200,0,0,323,0,0,0,0,0,0,0,10,2.1,10,10,0.4,60,9,999999999,150,0.2790,0,88,999.000,999.0,99.0
+1980,5,2,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,6.1,93,99200,0,0,309,0,0,0,0,0,0,0,300,2.1,8,8,4.8,1520,9,999999999,150,0.2790,0,88,999.000,999.0,99.0
+1980,5,2,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,5.6,93,99300,5,280,307,0,0,0,0,0,0,0,170,1.5,8,8,2.4,1520,9,999999999,150,0.2700,0,88,999.000,999.0,99.0
+1980,5,2,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,6.7,96,99300,166,1344,326,33,0,33,3700,0,3700,1160,320,1.5,10,10,0.4,30,9,999999999,160,0.2700,0,88,999.000,999.0,99.0
+1980,5,2,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,8.3,100,99400,414,1344,323,108,26,100,11900,2400,11100,2750,230,2.1,9,9,1.6,1520,9,999999999,179,0.2700,0,88,999.000,999.0,99.0
+1980,5,2,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,8.9,83,99300,652,1344,350,117,4,115,13800,300,13700,5150,320,1.5,10,10,3.2,2740,9,999999999,179,0.2700,0,88,999.000,999.0,99.0
+1980,5,2,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,10.6,72,99300,863,1344,338,552,437,271,57500,44900,28600,6970,230,3.1,6,4,4.8,7620,9,999999999,200,0.2700,0,88,999.000,999.0,99.0
+1980,5,2,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,10.0,57,99300,1031,1344,342,710,621,230,74000,62600,25800,7330,320,2.6,3,1,8.0,77777,9,999999999,200,0.2700,0,88,999.000,999.0,99.0
+1980,5,2,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,7.8,44,99300,1146,1344,348,824,696,229,87200,70800,26800,9760,30,3.1,2,1,11.3,77777,9,999999999,170,0.2700,0,88,999.000,999.0,99.0
+1980,5,2,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,7.8,40,99200,1198,1344,367,801,526,330,85900,55000,36800,17150,320,4.1,4,4,19.3,77777,9,999999999,170,0.2700,0,88,999.000,999.0,99.0
+1980,5,2,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,8.3,40,99200,1186,1344,370,788,480,364,83700,50100,39400,18190,20,3.6,4,4,19.3,77777,9,999999999,179,0.2700,0,88,999.000,999.0,99.0
+1980,5,2,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,7.2,34,99200,1109,1344,368,773,549,319,82300,57200,34900,12610,20,4.1,2,2,19.3,77777,9,999999999,160,0.2700,0,88,999.000,999.0,99.0
+1980,5,2,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,10.0,43,99100,974,1344,368,652,596,221,68100,59900,24600,6310,30,7.2,2,2,24.1,77777,9,999999999,189,0.2700,0,88,999.000,999.0,99.0
+1980,5,2,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,8.9,41,99100,788,1344,365,339,293,168,37600,31200,19300,3870,60,6.2,2,2,24.1,77777,9,999999999,179,0.2700,0,88,999.000,999.0,99.0
+1980,5,2,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,7.2,41,99100,566,1344,343,321,462,128,34300,44900,15400,2510,70,5.2,0,0,24.1,77777,9,999999999,170,0.2700,0,88,999.000,999.0,99.0
+1980,5,2,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,6.1,43,99100,322,1344,332,134,241,78,14500,19800,9800,1470,80,3.1,0,0,19.3,77777,9,999999999,150,0.2700,0,88,999.000,999.0,99.0
+1980,5,2,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,5.6,48,99100,80,1132,321,26,15,24,2800,900,2700,580,70,4.1,0,0,19.3,77777,9,999999999,150,0.2700,0,88,999.000,999.0,99.0
+1980,5,2,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,5.6,54,99200,0,0,314,0,0,0,0,0,0,0,10,3.1,2,0,19.3,77777,9,999999999,150,0.2700,0,88,999.000,999.0,99.0
+1980,5,2,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,5.6,64,99200,0,0,302,0,0,0,0,0,0,0,140,2.1,0,0,19.3,77777,9,999999999,150,0.2700,0,88,999.000,999.0,99.0
+1980,5,2,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,5.6,74,99200,0,0,292,0,0,0,0,0,0,0,340,2.1,0,0,19.3,77777,9,999999999,150,0.2700,0,88,999.000,999.0,99.0
+1980,5,2,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,6.7,80,99200,0,0,306,0,0,0,0,0,0,0,320,1.5,3,3,19.3,77777,9,999999999,160,0.2700,0,88,999.000,999.0,99.0
+1980,5,2,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,7.2,89,99200,0,0,290,0,0,0,0,0,0,0,280,2.6,0,0,19.3,77777,9,999999999,160,0.2700,0,88,999.000,999.0,99.0
+1980,5,3,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,6.7,93,99200,0,0,285,0,0,0,0,0,0,0,190,2.1,0,0,19.3,77777,9,999999999,160,0.2700,0,88,999.000,999.0,99.0
+1980,5,3,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,7.2,89,99200,0,0,290,0,0,0,0,0,0,0,360,2.1,0,0,19.3,77777,9,999999999,160,0.2700,0,88,999.000,999.0,99.0
+1980,5,3,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,6.1,93,99200,0,0,282,0,0,0,0,0,0,0,320,3.1,0,0,19.3,77777,9,999999999,150,0.2700,0,88,999.000,999.0,99.0
+1980,5,3,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,6.1,89,99200,0,0,284,0,0,0,0,0,0,0,320,2.6,0,0,24.1,77777,9,999999999,150,0.2700,0,88,999.000,999.0,99.0
+1980,5,3,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,5.0,93,99300,6,302,276,3,10,2,0,0,0,0,310,2.1,0,0,19.3,77777,9,999999999,139,0.0920,0,88,999.000,999.0,99.0
+1980,5,3,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,7.8,89,99300,171,1344,292,73,317,33,7500,19800,5000,590,230,1.5,0,0,19.3,77777,9,999999999,170,0.0920,0,88,999.000,999.0,99.0
+1980,5,3,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,9.4,78,99400,419,1344,310,251,621,57,25900,55900,8400,1120,310,1.5,0,0,16.1,77777,9,999999999,189,0.0920,0,88,999.000,999.0,99.0
+1980,5,3,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,6.1,48,99400,656,1344,324,456,767,79,47900,75200,11100,1720,290,2.6,0,0,16.1,77777,9,999999999,150,0.0920,0,88,999.000,999.0,99.0
+1980,5,3,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,6.1,42,99400,866,1344,334,641,840,97,68400,84600,13700,2500,360,2.1,0,0,16.1,77777,9,999999999,150,0.0920,0,88,999.000,999.0,99.0
+1980,5,3,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,7.2,41,99400,1034,1344,343,792,883,109,81700,88200,13600,2980,300,3.1,0,0,16.1,77777,9,999999999,170,0.0920,0,88,999.000,999.0,99.0
+1980,5,3,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,7.8,36,99300,1148,1344,357,894,906,117,92000,90800,14300,4150,360,5.2,0,0,19.3,77777,9,999999999,170,0.0920,0,88,999.000,999.0,99.0
+1980,5,3,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,8.3,36,99300,1201,1344,360,937,912,121,96500,91400,14600,5080,50,5.2,0,0,19.3,77777,9,999999999,179,0.0920,0,88,999.000,999.0,99.0
+1980,5,3,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,7.2,34,99300,1188,1344,356,930,915,120,95900,91700,14600,4820,50,5.2,0,0,24.1,77777,9,999999999,160,0.0920,0,88,999.000,999.0,99.0
+1980,5,3,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,7.2,33,99300,1112,1344,359,860,900,115,88800,90100,14100,3690,20,5.2,0,0,24.1,77777,9,999999999,160,0.0920,0,88,999.000,999.0,99.0
+1980,5,3,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,6.7,32,99200,976,1344,358,735,868,105,76300,86600,13200,2620,360,5.2,0,0,24.1,77777,9,999999999,160,0.0920,0,88,999.000,999.0,99.0
+1980,5,3,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,5.6,31,99200,791,1344,354,570,818,90,61000,81900,12700,2160,10,5.2,0,0,24.1,77777,9,999999999,150,0.0920,0,88,999.000,999.0,99.0
+1980,5,3,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,5.0,32,99200,569,1344,348,373,720,70,39300,69100,10000,1470,10,4.6,0,0,24.1,77777,9,999999999,150,0.0920,0,88,999.000,999.0,99.0
+1980,5,3,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,2.8,30,99200,325,1344,338,174,534,48,18600,44400,7800,910,20,3.1,0,0,24.1,77777,9,999999999,129,0.0920,0,88,999.000,999.0,99.0
+1980,5,3,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,2.8,36,99200,83,1153,325,34,137,21,3400,6000,2900,370,10,3.1,0,0,19.3,77777,9,999999999,129,0.0920,0,88,999.000,999.0,99.0
+1980,5,3,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,3.9,46,99200,0,0,314,0,0,0,0,0,0,0,0,0.0,0,0,19.3,77777,9,999999999,139,0.0920,0,88,999.000,999.0,99.0
+1980,5,3,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,6.7,64,99200,0,0,307,0,0,0,0,0,0,0,280,2.6,0,0,24.1,77777,9,999999999,160,0.0920,0,88,999.000,999.0,99.0
+1980,5,3,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,7.8,75,99200,0,0,304,0,0,0,0,0,0,0,270,2.1,0,0,24.1,77777,9,999999999,170,0.0920,0,88,999.000,999.0,99.0
+1980,5,3,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,6.1,72,99200,0,0,298,0,0,0,0,0,0,0,250,2.6,0,0,24.1,77777,9,999999999,150,0.0920,0,88,999.000,999.0,99.0
+1980,5,3,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,6.7,77,99200,0,0,296,0,0,0,0,0,0,0,250,2.1,0,0,24.1,77777,9,999999999,160,0.0920,0,88,999.000,999.0,99.0
+1980,5,4,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,4.4,59,99200,0,0,300,0,0,0,0,0,0,0,270,2.6,0,0,24.1,77777,9,999999999,139,0.0920,0,88,999.000,999.0,99.0
+1980,5,4,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,3.9,55,99200,0,0,302,0,0,0,0,0,0,0,270,2.1,0,0,24.1,77777,9,999999999,139,0.0920,0,88,999.000,999.0,99.0
+1980,5,4,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,5.0,59,99200,0,0,304,0,0,0,0,0,0,0,270,1.5,0,0,24.1,77777,9,999999999,139,0.0920,0,88,999.000,999.0,99.0
+1980,5,4,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,3.3,64,99200,0,0,290,0,0,0,0,0,0,0,270,2.1,0,0,24.1,77777,9,999999999,129,0.0920,0,88,999.000,999.0,99.0
+1980,5,4,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,5.6,77,99200,7,347,290,3,1,3,0,0,0,0,270,3.1,0,0,24.1,77777,9,999999999,150,0.2070,0,88,999.000,999.0,99.0
+1980,5,4,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,7.2,80,99300,175,1343,297,63,142,44,6600,8200,5500,810,260,2.1,0,0,19.3,77777,9,999999999,160,0.2070,0,88,999.000,999.0,99.0
+1980,5,4,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,7.2,54,99200,423,1343,323,227,436,88,24000,39200,11600,1630,280,2.6,0,0,19.3,77777,9,999999999,170,0.2070,0,88,999.000,999.0,99.0
+1980,5,4,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,7.2,44,99300,660,1343,338,427,606,127,44300,59300,15100,2640,250,4.1,0,0,19.3,77777,9,999999999,170,0.2070,0,88,999.000,999.0,99.0
+1980,5,4,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,7.8,35,99200,870,1343,359,615,702,158,64700,70900,18700,4010,280,5.2,0,0,19.3,77777,9,999999999,170,0.2070,0,88,999.000,999.0,99.0
+1980,5,4,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,5.0,24,99200,1037,1343,370,773,765,180,82200,78100,21800,5990,310,6.2,0,0,24.1,77777,9,999999999,139,0.2070,0,88,999.000,999.0,99.0
+1980,5,4,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,3.3,21,99100,1151,1343,370,880,800,192,90900,80000,22300,7480,300,5.2,0,0,24.1,77777,9,999999999,129,0.2070,0,88,999.000,999.0,99.0
+1980,5,4,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,3.3,19,99100,1203,1343,376,929,814,198,96400,81500,23300,9340,300,5.2,0,0,24.1,77777,9,999999999,129,0.2070,0,88,999.000,999.0,99.0
+1980,5,4,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,3.3,19,99000,1191,1343,378,915,808,197,94900,80800,23000,8830,330,4.1,0,0,24.1,77777,9,999999999,129,0.2070,0,88,999.000,999.0,99.0
+1980,5,4,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,4.4,21,98900,1114,1343,393,794,667,241,83700,67500,27500,9370,240,3.1,3,3,24.1,77777,9,999999999,139,0.2070,0,88,999.000,999.0,99.0
+1980,5,4,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,3.9,19,98900,979,1343,395,736,746,193,77700,75500,22500,5680,270,4.1,2,2,24.1,77777,9,999999999,129,0.2070,0,88,999.000,999.0,99.0
+1980,5,4,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,3.3,18,98800,794,1343,394,505,585,160,52800,58300,18300,3680,310,2.6,2,2,24.1,77777,9,999999999,129,0.2070,0,88,999.000,999.0,99.0
+1980,5,4,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,2.2,17,98800,572,1343,389,328,467,131,35100,45500,15700,2590,240,2.6,2,2,24.1,77777,9,999999999,120,0.2070,0,88,999.000,999.0,99.0
+1980,5,4,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,5.0,25,98700,329,1343,379,144,270,79,15200,22100,9700,1450,280,3.1,2,2,24.1,77777,9,999999999,139,0.2070,0,88,999.000,999.0,99.0
+1980,5,4,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,5.0,28,98700,87,1175,371,24,25,21,2600,1200,2500,430,270,2.6,2,2,19.3,77777,9,999999999,150,0.2070,0,88,999.000,999.0,99.0
+1980,5,4,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,5.0,33,98700,0,0,346,0,0,0,0,0,0,0,230,3.6,0,0,19.3,77777,9,999999999,139,0.2070,0,88,999.000,999.0,99.0
+1980,5,4,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,5.0,39,98700,0,0,333,0,0,0,0,0,0,0,240,4.1,0,0,19.3,77777,9,999999999,139,0.2070,0,88,999.000,999.0,99.0
+1980,5,4,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,5.0,40,98700,0,0,330,0,0,0,0,0,0,0,260,3.6,0,0,24.1,77777,9,999999999,139,0.2070,0,88,999.000,999.0,99.0
+1980,5,4,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,5.6,48,98700,0,0,321,0,0,0,0,0,0,0,230,4.6,0,0,24.1,77777,9,999999999,150,0.2070,0,88,999.000,999.0,99.0
+1980,5,4,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,4.4,50,98600,0,0,312,0,0,0,0,0,0,0,240,4.1,0,0,24.1,77777,9,999999999,139,0.2070,0,88,999.000,999.0,99.0
+1980,5,5,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,3.3,41,98600,0,0,319,0,0,0,0,0,0,0,230,4.1,0,0,24.1,77777,9,999999999,129,0.2070,0,88,999.000,999.0,99.0
+1980,5,5,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,3.3,43,98600,0,0,316,0,0,0,0,0,0,0,250,4.1,0,0,24.1,77777,9,999999999,129,0.2070,0,88,999.000,999.0,99.0
+1980,5,5,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,3.3,46,98500,0,0,311,0,0,0,0,0,0,0,250,3.6,0,0,24.1,77777,9,999999999,129,0.2070,0,88,999.000,999.0,99.0
+1980,5,5,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,4.4,55,98500,0,0,305,0,0,0,0,0,0,0,240,4.1,0,0,24.1,77777,9,999999999,139,0.2070,0,88,999.000,999.0,99.0
+1980,5,5,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,5.0,57,98500,8,369,312,3,7,2,0,0,0,0,240,4.1,1,1,24.1,77777,9,999999999,139,0.1070,0,88,999.000,999.0,99.0
+1980,5,5,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,6.1,50,98500,180,1342,322,77,299,36,7700,19100,5200,640,240,5.2,0,0,24.1,77777,9,999999999,150,0.1070,0,88,999.000,999.0,99.0
+1980,5,5,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,6.7,45,98400,427,1342,332,253,594,63,26500,53800,9400,1230,240,3.6,0,0,24.1,77777,9,999999999,160,0.1070,0,88,999.000,999.0,99.0
+1980,5,5,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,7.2,41,98400,664,1342,343,449,729,87,46800,71300,11500,1840,250,6.2,0,0,24.1,77777,9,999999999,160,0.1070,0,88,999.000,999.0,99.0
+1980,5,5,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,7.8,36,98300,873,1342,357,638,813,106,67400,81700,14200,2680,260,6.2,0,0,24.1,77777,9,999999999,170,0.1070,0,88,999.000,999.0,99.0
+1980,5,5,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,8.3,35,98300,1040,1342,363,785,856,119,80800,85500,14400,3120,260,7.2,0,0,24.1,77777,9,999999999,179,0.1070,0,88,999.000,999.0,99.0
+1980,5,5,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,8.3,29,98300,1153,1342,377,890,883,128,91300,88400,15200,4430,220,6.2,0,0,24.1,77777,9,999999999,170,0.1070,0,88,999.000,999.0,99.0
+1980,5,5,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,8.3,28,98200,1206,1342,382,937,894,132,96200,89600,15500,5480,250,6.2,0,0,24.1,77777,9,999999999,179,0.1070,0,88,999.000,999.0,99.0
+1980,5,5,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,7.2,23,98100,1193,1342,389,930,897,131,95500,89900,15500,5180,240,5.2,0,0,24.1,77777,9,999999999,160,0.1070,0,88,999.000,999.0,99.0
+1980,5,5,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,4.4,19,98000,1116,1342,412,846,714,252,88800,72100,28700,9830,250,3.6,6,6,24.1,1520,9,999999999,139,0.1070,0,88,999.000,999.0,99.0
+1980,5,5,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,3.3,21,98100,981,1342,400,597,494,236,64400,51400,26800,7040,280,7.7,7,7,19.3,1520,9,999999999,129,0.1070,0,88,999.000,999.0,99.0
+1980,5,5,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,6.1,26,98000,797,1342,396,446,438,186,47800,44900,21100,4320,250,4.1,6,6,24.1,2130,9,999999999,150,0.1070,0,88,999.000,999.0,99.0
+1980,5,5,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,6.1,26,97900,575,1342,407,224,164,155,24800,16400,17700,3690,230,5.2,8,8,24.1,2130,9,999999999,150,0.1070,0,88,999.000,999.0,99.0
+1980,5,5,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,3.9,23,98000,333,1342,402,156,245,96,16500,20400,11500,1890,310,3.1,8,8,24.1,1830,9,999999999,129,0.1070,0,88,999.000,999.0,99.0
+1980,5,5,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,2.2,41,98100,90,1197,343,25,14,23,2600,800,2600,560,20,9.8,8,8,24.1,2440,9,999999999,120,0.1070,0,88,999.000,999.0,99.0
+1980,5,5,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,-1.7,37,98300,0,0,306,0,0,0,0,0,0,0,360,8.8,2,2,24.1,77777,9,999999999,100,0.1070,0,88,999.000,999.0,99.0
+1980,5,5,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,-1.7,40,98300,0,0,292,0,0,0,0,0,0,0,20,6.7,0,0,24.1,77777,9,999999999,100,0.1070,0,88,999.000,999.0,99.0
+1980,5,5,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,-0.6,40,98300,0,0,298,0,0,0,0,0,0,0,10,5.2,0,0,24.1,77777,9,999999999,100,0.1070,0,88,999.000,999.0,99.0
+1980,5,5,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,-1.1,40,98300,0,0,304,0,0,0,0,0,0,0,30,6.2,2,2,24.1,77777,9,999999999,100,0.1070,0,88,999.000,999.0,99.0
+1980,5,5,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,-1.1,43,98400,0,0,300,0,0,0,0,0,0,0,20,3.6,2,2,24.1,77777,9,999999999,100,0.1070,0,88,999.000,999.0,99.0
+1980,5,6,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,-0.6,46,98300,0,0,298,0,0,0,0,0,0,0,360,2.6,2,2,24.1,77777,9,999999999,100,0.1070,0,88,999.000,999.0,99.0
+1980,5,6,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,0.6,54,98300,0,0,302,0,0,0,0,0,0,0,340,2.1,5,5,24.1,77777,9,999999999,110,0.1070,0,88,999.000,999.0,99.0
+1980,5,6,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,1.1,61,98300,0,0,309,0,0,0,0,0,0,0,300,2.6,8,8,24.1,3050,9,999999999,110,0.1070,0,88,999.000,999.0,99.0
+1980,5,6,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,2.2,66,98300,0,0,297,0,0,0,0,0,0,0,300,2.1,4,4,24.1,77777,9,999999999,120,0.1070,0,88,999.000,999.0,99.0
+1980,5,6,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.8,1.7,66,98300,9,391,292,2,4,2,0,0,0,0,270,3.1,3,3,24.1,77777,9,999999999,120,0.1210,0,88,999.000,999.0,99.0
+1980,5,6,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,3.3,68,98400,184,1342,295,74,225,43,7700,13900,5800,770,290,3.1,2,2,24.1,77777,9,999999999,129,0.1210,0,88,999.000,999.0,99.0
+1980,5,6,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,2.2,49,98400,431,1342,301,255,580,68,26600,52500,9700,1310,250,3.6,0,0,24.1,77777,9,999999999,120,0.1210,0,88,999.000,999.0,99.0
+1980,5,6,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,1.7,38,98400,667,1342,314,459,730,93,47400,71300,11900,1920,250,4.1,0,0,24.1,77777,9,999999999,120,0.1210,0,88,999.000,999.0,99.0
+1980,5,6,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,1.7,35,98300,876,1342,319,647,813,114,68000,81500,14700,2830,240,5.2,0,0,24.1,77777,9,999999999,120,0.1210,0,88,999.000,999.0,99.0
+1980,5,6,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,1.1,31,98300,1043,1342,326,797,856,129,84700,86600,17300,4170,260,6.2,0,0,24.1,77777,9,999999999,110,0.1210,0,88,999.000,999.0,99.0
+1980,5,6,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,-1.7,22,98200,1156,1342,330,911,894,138,93300,89400,16100,4630,250,6.2,0,0,24.1,77777,9,999999999,89,0.1210,0,88,999.000,999.0,99.0
+1980,5,6,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,-1.7,20,98100,1208,1342,349,954,887,153,97400,88700,17300,6000,280,6.7,2,2,24.1,77777,9,999999999,89,0.1210,0,88,999.000,999.0,99.0
+1980,5,6,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,-1.7,21,98100,1195,1342,355,764,556,268,80500,56300,30300,13440,280,7.2,5,5,24.1,77777,9,999999999,100,0.1210,0,88,999.000,999.0,99.0
+1980,5,6,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,-1.1,20,98000,1119,1342,364,750,588,260,78600,59300,29100,10180,290,7.2,6,6,24.1,1830,9,999999999,100,0.1210,0,88,999.000,999.0,99.0
+1980,5,6,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,-1.1,22,97900,984,1342,369,403,208,250,44500,22500,27900,7360,290,7.7,8,8,16.1,1830,9,999999999,100,0.1210,0,88,999.000,999.0,99.0
+1980,5,6,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,-2.2,21,97900,799,1342,365,372,232,234,40300,24700,25600,5740,310,5.7,8,8,16.1,2440,9,999999999,89,0.1210,0,88,999.000,999.0,99.0
+1980,5,6,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,-1.7,24,97900,578,1342,351,262,283,141,28500,28500,16200,2910,300,7.2,7,7,16.1,2440,9,999999999,100,0.1210,0,88,999.000,999.0,99.0
+1980,5,6,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,-3.3,21,97900,336,1342,340,125,142,90,13700,12200,10700,1970,310,7.7,4,4,16.1,77777,9,999999999,89,0.1210,0,88,999.000,999.0,99.0
+1980,5,6,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,-3.9,24,98000,94,1219,323,33,65,27,3400,2700,3200,480,310,5.2,6,2,19.3,77777,9,999999999,89,0.1210,0,88,999.000,999.0,99.0
+1980,5,6,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,-6.1,22,98100,0,0,303,0,0,0,0,0,0,0,320,6.7,0,0,24.1,77777,9,999999999,69,0.1210,0,88,999.000,999.0,99.0
+1980,5,6,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,-1.1,46,98300,0,0,286,0,0,0,0,0,0,0,360,6.2,0,0,24.1,77777,9,999999999,100,0.1210,0,88,999.000,999.0,99.0
+1980,5,6,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,0.0,54,98400,0,0,282,0,0,0,0,0,0,0,20,5.7,0,0,24.1,77777,9,999999999,110,0.1210,0,88,999.000,999.0,99.0
+1980,5,6,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,0.6,61,98500,0,0,279,0,0,0,0,0,0,0,360,3.6,0,0,24.1,77777,9,999999999,110,0.1210,0,88,999.000,999.0,99.0
+1980,5,6,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,0.6,73,98500,0,0,268,0,0,0,0,0,0,0,30,4.6,0,0,24.1,77777,9,999999999,110,0.1210,0,88,999.000,999.0,99.0
+1980,5,7,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,1.1,73,98500,0,0,270,0,0,0,0,0,0,0,10,2.6,0,0,24.1,77777,9,999999999,110,0.1210,0,88,999.000,999.0,99.0
+1980,5,7,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,-0.6,70,98500,0,0,264,0,0,0,0,0,0,0,320,4.1,0,0,24.1,77777,9,999999999,100,0.1210,0,88,999.000,999.0,99.0
+1980,5,7,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-0.6,76,98600,0,0,260,0,0,0,0,0,0,0,290,3.6,0,0,24.1,77777,9,999999999,100,0.1210,0,88,999.000,999.0,99.0
+1980,5,7,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-0.6,76,98600,0,0,260,0,0,0,0,0,0,0,320,3.6,0,0,24.1,77777,9,999999999,100,0.1210,0,88,999.000,999.0,99.0
+1980,5,7,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-0.6,76,98700,10,414,260,5,4,5,0,0,0,0,290,3.6,0,0,24.1,77777,9,999999999,100,0.1550,0,88,999.000,999.0,99.0
+1980,5,7,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,0.0,70,98700,189,1341,267,76,232,43,7900,14500,5900,770,310,3.6,0,0,24.1,77777,9,999999999,110,0.1550,0,88,999.000,999.0,99.0
+1980,5,7,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,-0.6,58,98800,435,1341,275,252,534,78,26000,48200,10400,1470,300,4.6,0,0,24.1,77777,9,999999999,100,0.1550,0,88,999.000,999.0,99.0
+1980,5,7,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,-1.1,50,98800,671,1341,281,453,680,111,47500,67200,13900,2380,300,6.2,1,0,24.1,77777,9,999999999,100,0.1550,0,88,999.000,999.0,99.0
+1980,5,7,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,-1.7,44,98800,879,1341,297,571,568,197,61600,58800,23000,5020,310,5.2,3,3,24.1,77777,9,999999999,100,0.1550,0,88,999.000,999.0,99.0
+1980,5,7,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,-3.9,36,98800,1045,1341,313,614,374,321,67000,40500,35300,10710,310,5.7,8,8,24.1,1400,9,999999999,80,0.1550,0,88,999.000,999.0,99.0
+1980,5,7,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,-2.8,41,98900,1158,1341,328,263,11,253,31700,900,30900,12220,310,6.2,10,10,24.1,1400,9,999999999,89,0.1550,0,88,999.000,999.0,99.0
+1980,5,7,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,-3.3,38,98900,1210,1341,330,364,31,335,40200,3200,37300,16650,300,5.7,10,10,24.1,1680,9,999999999,89,0.1550,0,88,999.000,999.0,99.0
+1980,5,7,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,-2.2,37,98900,1197,1341,322,645,274,399,70500,29800,43900,19240,310,7.2,8,8,24.1,1680,9,999999999,89,0.1550,0,88,999.000,999.0,99.0
+1980,5,7,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,-2.2,34,98900,1121,1341,327,643,372,332,70800,40400,36900,12830,310,7.2,8,8,24.1,1400,9,999999999,89,0.1550,0,88,999.000,999.0,99.0
+1980,5,7,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,-2.8,35,98900,986,1341,322,358,127,265,39900,13600,29900,8450,310,5.2,8,8,24.1,2440,9,999999999,89,0.1550,0,88,999.000,999.0,99.0
+1980,5,7,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,-3.9,34,98900,802,1341,313,353,248,206,38700,26400,22900,4950,310,6.2,7,7,24.1,1680,9,999999999,89,0.1550,0,88,999.000,999.0,99.0
+1980,5,7,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,-3.9,35,98900,582,1341,311,275,222,179,29300,22400,19600,3870,310,7.2,7,7,24.1,1680,9,999999999,89,0.1550,0,88,999.000,999.0,99.0
+1980,5,7,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,-4.4,36,98900,340,1341,305,106,83,85,11600,7200,9800,1860,320,7.7,7,7,19.3,3050,9,999999999,80,0.1550,0,88,999.000,999.0,99.0
+1980,5,7,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,-4.4,41,98900,97,1241,292,28,33,25,3100,1700,2900,520,320,5.2,5,5,19.3,77777,9,999999999,80,0.1550,0,88,999.000,999.0,99.0
+1980,5,7,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,-0.6,56,98900,0,0,294,0,0,0,0,0,0,0,340,4.6,5,5,16.1,77777,9,999999999,100,0.1550,0,88,999.000,999.0,99.0
+1980,5,7,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,-2.8,48,98900,0,0,294,0,0,0,0,0,0,0,340,2.6,6,6,24.1,1830,9,999999999,89,0.1550,0,88,999.000,999.0,99.0
+1980,5,7,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,-1.7,58,99000,0,0,296,0,0,0,0,0,0,0,320,1.5,8,8,24.1,1830,9,999999999,100,0.1550,0,88,999.000,999.0,99.0
+1980,5,7,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,-1.1,60,99000,0,0,303,0,0,0,0,0,0,0,280,2.1,9,9,24.1,1830,9,999999999,100,0.1550,0,88,999.000,999.0,99.0
+1980,5,7,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,-1.1,58,99000,0,0,306,0,0,0,0,0,0,0,310,2.6,9,9,24.1,1830,9,999999999,100,0.1550,0,88,999.000,999.0,99.0
+1980,5,8,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,-2.2,53,99000,0,0,313,0,0,0,0,0,0,0,310,2.6,10,10,24.1,1830,9,999999999,89,0.1550,0,88,999.000,999.0,99.0
+1980,5,8,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,-2.2,53,99000,0,0,313,0,0,0,0,0,0,0,290,3.6,10,10,24.1,1830,9,999999999,89,0.1550,0,88,999.000,999.0,99.0
+1980,5,8,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,-2.8,51,99000,0,0,313,0,0,0,0,0,0,0,310,4.1,10,10,24.1,1830,9,999999999,89,0.1550,0,88,999.000,999.0,99.0
+1980,5,8,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,-2.8,51,99000,0,0,313,0,0,0,0,0,0,0,310,4.1,10,10,24.1,1830,9,999999999,89,0.1550,0,88,999.000,999.0,99.0
+1980,5,8,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,-2.2,56,99000,12,436,296,4,1,4,0,0,0,0,320,5.2,8,8,24.1,1830,9,999999999,89,0.1260,0,88,999.000,999.0,99.0
+1980,5,8,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,-1.1,63,99100,193,1341,295,51,56,42,5500,3800,5000,890,320,5.2,8,8,24.1,1830,9,999999999,100,0.1260,0,88,999.000,999.0,99.0
+1980,5,8,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,-1.1,58,99100,439,1341,299,155,86,127,17000,8000,14400,3410,320,6.2,8,8,24.1,2440,9,999999999,100,0.1260,0,88,999.000,999.0,99.0
+1980,5,8,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,0.0,54,99100,674,1341,310,256,215,148,28100,22400,16900,3160,350,3.1,8,8,24.1,2440,9,999999999,110,0.1260,0,88,999.000,999.0,99.0
+1980,5,8,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,0.0,48,99100,882,1341,318,439,248,275,47400,26600,29900,7370,330,3.1,8,8,24.1,2440,9,999999999,110,0.1260,0,88,999.000,999.0,99.0
+1980,5,8,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,0.0,50,99100,1048,1341,315,652,481,275,69900,50100,30600,9410,320,5.7,8,8,24.1,1010,9,999999999,110,0.1260,0,88,999.000,999.0,99.0
+1980,5,8,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,-1.7,43,99100,1160,1341,332,284,6,279,34100,500,33600,13200,300,3.1,10,10,24.1,1160,9,999999999,100,0.1260,0,88,999.000,999.0,99.0
+1980,5,8,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,-1.7,44,99100,1212,1341,329,329,7,323,39300,600,38800,14910,70,5.2,10,10,19.3,1160,9,999999999,100,0.1260,0,88,999.000,999.0,99.0
+1980,5,8,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,-1.1,43,99100,1199,1341,335,378,11,368,44600,1000,43700,16320,70,4.1,10,10,19.3,1160,9,999999999,100,0.1260,0,88,999.000,999.0,99.0
+1980,5,8,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,-1.7,43,99100,1123,1341,332,354,3,351,41400,300,41200,15480,10,2.1,10,10,19.3,1160,9,999999999,100,0.1260,0,88,999.000,999.0,99.0
+1980,5,8,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,-2.2,37,99000,988,1341,322,498,291,284,54600,31500,31400,8570,30,3.6,8,8,24.1,1680,9,999999999,89,0.1260,0,88,999.000,999.0,99.0
+1980,5,8,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,-2.8,37,99000,805,1341,319,363,202,242,39900,21200,27200,6540,280,4.1,8,8,24.1,1680,9,999999999,89,0.1260,0,88,999.000,999.0,99.0
+1980,5,8,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,-2.8,37,99000,585,1341,326,225,105,180,24600,10500,20000,4300,320,5.7,9,9,24.1,1680,9,999999999,89,0.1260,0,88,999.000,999.0,99.0
+1980,5,8,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,-2.8,38,99000,343,1341,324,122,55,109,13500,4800,12200,2720,310,3.1,9,9,24.1,1680,9,999999999,89,0.1260,0,88,999.000,999.0,99.0
+1980,5,8,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,-3.3,38,99000,101,1262,321,21,9,20,2300,500,2200,500,30,2.6,9,9,24.1,1680,9,999999999,89,0.1260,0,88,999.000,999.0,99.0
+1980,5,8,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,0.0,54,99000,0,0,310,0,0,0,0,0,0,0,140,3.1,8,8,24.1,1680,9,999999999,110,0.1260,0,88,999.000,999.0,99.0
+1980,5,8,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,0.6,56,99000,0,0,327,0,0,0,0,0,0,0,140,2.6,10,10,24.1,1680,9,999999999,110,0.1260,0,88,999.000,999.0,99.0
+1980,5,8,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,0.0,60,99000,0,0,303,0,0,0,0,0,0,0,150,1.5,8,8,24.1,1680,9,999999999,110,0.1260,0,88,999.000,999.0,99.0
+1980,5,8,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,0.6,61,99000,0,0,321,0,0,0,0,0,0,0,300,1.5,10,10,24.1,1830,9,999999999,110,0.1260,0,88,999.000,999.0,99.0
+1980,5,8,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,0.0,63,99100,0,0,296,0,0,0,0,0,0,0,310,2.1,7,7,24.1,2440,9,999999999,110,0.1260,0,88,999.000,999.0,99.0
+1980,5,9,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,1.1,79,99000,0,0,275,0,0,0,0,0,0,0,300,1.0,2,2,24.1,77777,9,999999999,110,0.1260,0,88,999.000,999.0,99.0
+1980,5,9,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,0.6,89,99000,0,0,257,0,0,0,0,0,0,0,300,1.5,0,0,24.1,77777,9,999999999,110,0.1260,0,88,999.000,999.0,99.0
+1980,5,9,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-0.6,79,99100,0,0,258,0,0,0,0,0,0,0,360,2.6,0,0,24.1,77777,9,999999999,100,0.1260,0,88,999.000,999.0,99.0
+1980,5,9,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,0.0,82,99100,0,0,259,0,0,0,0,0,0,0,330,1.0,0,0,24.1,77777,9,999999999,110,0.1260,0,88,999.000,999.0,99.0
+1980,5,9,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-1.1,82,99100,13,480,254,10,31,6,0,0,0,0,280,1.0,0,0,24.1,77777,9,999999999,100,0.0730,0,88,999.000,999.0,99.0
+1980,5,9,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,2.2,89,99200,197,1340,270,90,381,33,9200,25800,5400,600,0,0.0,1,1,19.3,77777,9,999999999,120,0.0730,0,88,999.000,999.0,99.0
+1980,5,9,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,2.2,66,99200,443,1340,288,261,614,57,27000,56200,8400,1160,0,0.0,1,1,19.3,77777,9,999999999,120,0.0730,0,88,999.000,999.0,99.0
+1980,5,9,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,0.6,50,99200,678,1340,290,480,803,71,50000,78300,10300,1560,250,2.6,0,0,19.3,77777,9,999999999,110,0.0730,0,88,999.000,999.0,99.0
+1980,5,9,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,0.6,47,99200,885,1340,300,611,809,74,63700,80500,10400,1980,310,3.1,2,1,19.3,77777,9,999999999,110,0.0730,0,88,999.000,999.0,99.0
+1980,5,9,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,0.6,42,99200,1050,1340,314,763,763,163,79300,76400,19200,5010,320,4.6,3,3,24.1,77777,9,999999999,110,0.0730,0,88,999.000,999.0,99.0
+1980,5,9,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,0.0,37,99100,1163,1340,335,643,229,444,70400,24300,49200,18950,240,4.6,8,8,24.1,1400,9,999999999,110,0.0730,0,88,999.000,999.0,99.0
+1980,5,9,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,-2.2,30,99000,1214,1340,338,410,133,289,46300,14300,33200,14120,260,5.2,8,8,24.1,1830,9,999999999,100,0.0730,0,88,999.000,999.0,99.0
+1980,5,9,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,1.1,35,98900,1201,1340,342,740,466,321,79700,48700,35900,17100,300,3.1,7,7,24.1,1830,9,999999999,110,0.0730,0,88,999.000,999.0,99.0
+1980,5,9,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,0.6,34,98800,1125,1340,334,677,489,266,73700,51200,30600,10960,240,2.6,5,5,24.1,77777,9,999999999,110,0.0730,0,88,999.000,999.0,99.0
+1980,5,9,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,0.6,32,98800,991,1340,331,699,748,146,73100,75000,17500,4070,260,5.2,2,2,24.1,77777,9,999999999,110,0.0730,0,88,999.000,999.0,99.0
+1980,5,9,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,-1.1,28,98700,807,1340,329,553,741,108,58200,73800,13600,2490,230,5.2,2,2,24.1,77777,9,999999999,100,0.0730,0,88,999.000,999.0,99.0
+1980,5,9,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,-1.7,28,98600,588,1340,315,399,771,64,42800,74800,9900,1420,220,4.6,0,0,24.1,77777,9,999999999,100,0.0730,0,88,999.000,999.0,99.0
+1980,5,9,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,-2.8,27,98500,347,1340,309,197,596,45,20600,51300,7300,910,200,4.1,1,0,24.1,77777,9,999999999,89,0.0730,0,88,999.000,999.0,99.0
+1980,5,9,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,-2.8,30,98500,104,1284,302,42,221,21,4100,11600,3100,380,230,2.1,0,0,24.1,77777,9,999999999,89,0.0730,0,88,999.000,999.0,99.0
+1980,5,9,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,-2.2,36,98500,0,0,302,0,0,0,0,0,0,0,0,0.0,2,1,24.1,77777,9,999999999,89,0.0730,0,88,999.000,999.0,99.0
+1980,5,9,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,-1.1,43,98500,0,0,296,0,0,0,0,0,0,0,0,0.0,3,1,24.1,77777,9,999999999,100,0.0730,0,88,999.000,999.0,99.0
+1980,5,9,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,0.0,54,98500,0,0,288,0,0,0,0,0,0,0,140,3.1,3,1,24.1,77777,9,999999999,110,0.0730,0,88,999.000,999.0,99.0
+1980,5,9,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,0.6,54,98500,0,0,297,0,0,0,0,0,0,0,140,3.1,8,3,16.1,77777,9,999999999,110,0.0730,0,88,999.000,999.0,99.0
+1980,5,9,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,-0.6,54,98500,0,0,285,0,0,0,0,0,0,0,150,3.1,4,1,24.1,77777,9,999999999,100,0.0730,0,88,999.000,999.0,99.0
+1980,5,10,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,-0.6,52,98500,0,0,325,0,0,0,0,0,0,0,160,3.1,10,10,24.1,3660,9,999999999,100,0.0730,0,88,999.000,999.0,99.0
+1980,5,10,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,-0.6,52,98400,0,0,310,0,0,0,0,0,0,0,170,3.1,10,8,24.1,3660,9,999999999,100,0.0730,0,88,999.000,999.0,99.0
+1980,5,10,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,0.0,48,98400,0,0,325,0,0,0,0,0,0,0,190,3.1,10,9,24.1,2740,9,999999999,110,0.0730,0,88,999.000,999.0,99.0
+1980,5,10,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,0.0,48,98400,0,0,318,0,0,0,0,0,0,0,180,3.1,10,8,24.1,2740,9,999999999,110,0.0730,0,88,999.000,999.0,99.0
+1980,5,10,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,1.1,50,98400,14,502,337,3,0,3,0,0,0,0,170,3.6,10,10,24.1,2740,9,999999999,110,0.1210,0,88,999.000,999.0,99.0
+1980,5,10,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,1.1,49,98400,201,1339,340,23,0,23,2700,0,2700,910,190,4.6,10,10,19.3,1680,9,999999999,110,0.1210,0,88,999.000,999.0,99.0
+1980,5,10,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,3.3,57,98400,446,1339,343,95,9,92,10900,500,10800,3670,170,7.2,10,10,24.1,1680,9,999999999,129,0.1210,0,88,999.000,999.0,99.0
+1980,5,10,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,4.4,55,98300,681,1339,352,198,10,193,22600,800,22200,7820,180,5.7,10,10,24.1,2740,9,999999999,139,0.1210,0,88,999.000,999.0,99.0
+1980,5,10,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,5.6,55,98300,888,1339,359,280,8,275,32300,700,31800,11680,170,5.7,10,10,24.1,2740,9,999999999,150,0.1210,0,88,999.000,999.0,99.0
+1980,5,10,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,5.6,52,98200,1053,1339,355,481,139,371,52700,14800,41000,12950,170,10.3,9,9,24.1,2740,9,999999999,150,0.1210,0,88,999.000,999.0,99.0
+1980,5,10,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,3.9,37,98100,1165,1339,362,430,54,383,47500,5600,42700,17300,170,11.8,9,8,24.1,7620,9,999999999,129,0.1210,0,88,999.000,999.0,99.0
+1980,5,10,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,5.0,36,97900,1216,1339,358,607,284,348,67300,30900,39100,17740,170,9.8,5,5,24.1,77777,9,999999999,139,0.1210,0,88,999.000,999.0,99.0
+1980,5,10,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,4.4,31,97800,1203,1339,360,847,648,263,89300,65700,30200,13750,170,7.7,7,3,24.1,77777,9,999999999,139,0.1210,0,88,999.000,999.0,99.0
+1980,5,10,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,4.4,34,97700,1127,1339,392,307,8,300,36400,700,35800,13850,160,9.8,10,10,24.1,2740,9,999999999,139,0.1210,0,88,999.000,999.0,99.0
+1980,5,10,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,5.6,40,97600,993,1339,385,232,8,226,27600,700,27100,10690,160,8.2,10,10,24.1,1680,9,999999999,150,0.1210,0,88,999.000,999.0,99.0
+1980,5,10,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,6.1,43,97600,810,1339,383,208,9,203,24300,700,23800,8940,160,6.2,10,10,24.1,1680,9,999999999,150,0.1210,0,88,999.000,999.0,99.0
+1980,5,10,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,6.7,45,97600,591,1339,383,134,6,131,15500,400,15300,5470,170,10.3,10,10,19.3,1400,9,999999999,160,0.1210,0,88,999.000,999.0,99.0
+1980,5,10,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,10.6,80,97700,350,1339,363,42,0,42,5000,0,5000,1760,190,5.2,10,10,8.0,580,9,999999999,200,0.1210,0,88,999.000,999.0,99.0
+1980,5,10,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,10.6,83,97600,108,1306,359,12,1,12,1400,0,1400,460,180,3.1,10,10,8.0,760,9,999999999,200,0.1210,0,88,999.000,999.0,99.0
+1980,5,10,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,11.1,83,97500,0,0,363,0,0,0,0,0,0,0,170,3.6,10,10,12.9,1160,9,999999999,200,0.1210,0,88,999.000,999.0,99.0
+1980,5,10,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,10.0,83,97500,0,0,339,0,0,0,0,0,0,0,130,3.1,8,8,12.9,2440,9,999999999,189,0.1210,0,88,999.000,999.0,99.0
+1980,5,10,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,10.6,86,97500,0,0,340,0,0,0,0,0,0,0,120,3.1,8,8,14.5,1160,9,999999999,200,0.1210,0,88,999.000,999.0,99.0
+1980,5,10,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,8.9,86,97500,0,0,310,0,0,0,0,0,0,0,140,1.5,2,2,19.3,77777,9,999999999,179,0.1210,0,88,999.000,999.0,99.0
+1980,5,10,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,8.9,93,97400,0,0,306,0,0,0,0,0,0,0,140,2.1,2,2,19.3,77777,9,999999999,179,0.1210,0,88,999.000,999.0,99.0
+1980,5,11,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,8.3,96,97400,0,0,296,0,0,0,0,0,0,0,280,1.0,1,1,19.3,77777,9,999999999,170,0.1210,0,88,999.000,999.0,99.0
+1980,5,11,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,9.4,93,97500,0,0,299,0,0,0,0,0,0,0,230,2.6,0,0,24.1,77777,9,999999999,189,0.1210,0,88,999.000,999.0,99.0
+1980,5,11,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,10.0,86,97600,0,0,344,0,0,0,0,0,0,0,250,2.6,9,9,19.3,1070,9,999999999,189,0.1210,0,88,999.000,999.0,99.0
+1980,5,11,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,10.0,86,97800,0,0,353,0,0,0,0,0,0,0,330,6.2,10,10,24.1,520,9,999999999,189,0.1210,0,88,999.000,999.0,99.0
+1980,5,11,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,7.2,80,97900,16,524,302,6,7,5,0,0,0,0,350,6.7,1,1,24.1,77777,9,999999999,160,0.1520,0,88,999.000,999.0,99.0
+1980,5,11,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,5.0,77,98200,205,1339,287,85,259,45,8900,17000,6300,800,340,6.2,0,0,24.1,77777,9,999999999,139,0.1520,0,88,999.000,999.0,99.0
+1980,5,11,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,5.0,69,98300,450,1339,294,263,545,79,27200,49700,10500,1510,350,6.2,0,0,24.1,77777,9,999999999,139,0.1520,0,88,999.000,999.0,99.0
+1980,5,11,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,5.6,66,98300,684,1339,300,464,693,109,49000,68800,13800,2370,360,5.2,0,0,24.1,77777,9,999999999,150,0.1520,0,88,999.000,999.0,99.0
+1980,5,11,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,5.0,59,98400,890,1339,324,534,461,227,57000,47700,25200,5940,360,3.6,6,6,24.1,3660,9,999999999,139,0.1520,0,88,999.000,999.0,99.0
+1980,5,11,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,4.4,53,98500,1055,1339,321,758,650,243,79000,65500,27300,8190,60,1.5,7,3,24.1,77777,9,999999999,139,0.1520,0,88,999.000,999.0,99.0
+1980,5,11,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,5.0,53,98500,1167,1339,341,590,270,354,65000,29400,39300,15510,0,0.0,8,8,24.1,3050,9,999999999,139,0.1520,0,88,999.000,999.0,99.0
+1980,5,11,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,3.9,46,98500,1218,1339,333,888,653,292,93100,65800,33100,16120,230,2.6,5,5,24.1,77777,9,999999999,129,0.1520,0,88,999.000,999.0,99.0
+1980,5,11,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,3.9,41,98500,1205,1339,338,828,654,239,88100,66600,28000,12700,150,2.1,4,4,24.1,77777,9,999999999,129,0.1520,0,88,999.000,999.0,99.0
+1980,5,11,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,5.0,42,98500,1129,1339,345,810,674,241,85500,68300,27700,9880,30,2.6,4,4,24.1,77777,9,999999999,139,0.1520,0,88,999.000,999.0,99.0
+1980,5,11,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,5.6,48,98500,995,1339,353,558,298,337,60500,32200,36500,10560,100,5.2,8,8,24.1,2440,9,999999999,150,0.1520,0,88,999.000,999.0,99.0
+1980,5,11,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,5.6,50,98500,813,1339,332,473,462,194,50800,47400,22000,4600,90,3.6,8,3,24.1,77777,9,999999999,150,0.1520,0,88,999.000,999.0,99.0
+1980,5,11,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,5.0,50,98600,594,1339,332,348,498,129,37400,48900,15700,2560,90,4.1,5,4,24.1,77777,9,999999999,139,0.1520,0,88,999.000,999.0,99.0
+1980,5,11,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,4.4,51,98600,354,1339,340,95,105,68,10700,9200,8200,1500,80,3.6,9,8,19.3,2440,9,999999999,139,0.1520,0,88,999.000,999.0,99.0
+1980,5,11,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,3.9,55,98600,112,1327,349,15,1,15,1800,0,1800,570,70,3.1,10,10,19.3,2130,9,999999999,129,0.1520,0,88,999.000,999.0,99.0
+1980,5,11,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,5.0,62,98600,0,0,347,0,0,0,0,0,0,0,50,2.6,10,10,19.3,1830,9,999999999,139,0.1520,0,88,999.000,999.0,99.0
+1980,5,11,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,4.4,64,98700,0,0,341,0,0,0,0,0,0,0,0,0.0,10,10,19.3,1830,9,999999999,139,0.1520,0,88,999.000,999.0,99.0
+1980,5,11,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,5.0,66,98700,0,0,342,0,0,0,0,0,0,0,120,1.5,10,10,19.3,1400,9,999999999,139,0.1520,0,88,999.000,999.0,99.0
+1980,5,11,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,4.4,62,98700,0,0,344,0,0,0,0,0,0,0,110,2.1,10,10,24.1,2440,9,999999999,139,0.1520,0,88,999.000,999.0,99.0
+1980,5,11,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,3.9,61,98700,0,0,341,0,0,0,0,0,0,0,110,2.1,10,10,24.1,2440,9,999999999,129,0.1520,0,88,999.000,999.0,99.0
+1980,5,12,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,4.4,62,98700,0,0,344,0,0,0,0,0,0,0,120,1.0,10,10,24.1,2440,9,999999999,139,0.1520,0,88,999.000,999.0,99.0
+1980,5,12,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,5.6,69,98700,0,0,343,0,0,0,0,0,0,0,140,1.5,10,10,24.1,2440,9,999999999,150,0.1520,0,88,999.000,999.0,99.0
+1980,5,12,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,6.7,77,98700,0,0,342,0,0,0,0,0,0,0,180,1.0,10,10,24.1,2440,9,999999999,160,0.1520,0,88,999.000,999.0,99.0
+1980,5,12,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,7.8,83,98700,0,0,343,0,0,0,0,0,0,0,360,1.5,10,10,24.1,2440,9,999999999,170,0.1520,0,88,999.000,999.0,99.0
+1980,5,12,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,5.6,74,98700,17,546,308,7,1,7,0,0,0,0,30,1.5,10,4,24.1,77777,9,999999999,150,0.1680,0,88,999.000,999.0,99.0
+1980,5,12,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,6.7,74,98800,209,1338,344,31,4,31,3700,0,3700,1180,360,1.5,10,10,24.1,2440,9,999999999,160,0.1680,0,88,999.000,999.0,99.0
+1980,5,12,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,6.7,72,98800,453,1338,347,121,8,119,13800,500,13600,4470,40,1.5,10,10,19.3,2440,9,999999999,160,0.1680,0,88,999.000,999.0,99.0
+1980,5,12,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,6.1,64,98800,687,1338,352,199,5,197,22800,400,22600,7980,30,2.6,10,10,19.3,2440,9,999999999,150,0.1680,0,88,999.000,999.0,99.0
+1980,5,12,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,6.1,58,98700,893,1338,360,261,4,258,30200,400,30000,11220,30,4.1,10,10,19.3,2130,9,999999999,150,0.1680,0,88,999.000,999.0,99.0
+1980,5,12,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,3.9,48,98800,1057,1338,360,383,6,379,44300,600,43800,15900,50,3.6,10,10,19.3,2440,9,999999999,139,0.1680,0,88,999.000,999.0,99.0
+1980,5,12,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,3.9,46,98600,1169,1338,363,340,6,335,40300,500,39800,15170,50,5.2,10,10,19.3,2440,9,999999999,129,0.1680,0,88,999.000,999.0,99.0
+1980,5,12,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,3.3,44,98600,1220,1338,345,839,571,317,90800,59800,36200,18310,60,3.6,8,8,19.3,2440,9,999999999,129,0.1680,0,88,999.000,999.0,99.0
+1980,5,12,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,4.4,46,98700,1207,1338,328,885,756,201,95200,77700,25000,10910,50,4.1,2,2,24.1,77777,9,999999999,139,0.1680,0,88,999.000,999.0,99.0
+1980,5,12,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,3.3,40,98500,1131,1338,335,783,612,265,82000,61700,29800,10840,60,6.2,6,3,24.1,77777,9,999999999,129,0.1680,0,88,999.000,999.0,99.0
+1980,5,12,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,1.7,39,98500,998,1338,334,508,293,290,55700,31700,32000,8910,70,5.2,9,6,24.1,2440,9,999999999,120,0.1680,0,88,999.000,999.0,99.0
+1980,5,12,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,1.1,38,98500,815,1338,342,305,163,206,34000,17200,23500,5610,80,5.7,9,8,24.1,1830,9,999999999,110,0.1680,0,88,999.000,999.0,99.0
+1980,5,12,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,2.2,39,98400,597,1338,328,329,380,161,34600,37300,17900,3280,50,3.6,8,3,24.1,77777,9,999999999,120,0.1680,0,88,999.000,999.0,99.0
+1980,5,12,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,2.8,46,98300,357,1338,356,66,3,65,7600,100,7600,2560,70,4.1,10,10,24.1,3660,9,999999999,129,0.1680,0,88,999.000,999.0,99.0
+1980,5,12,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,3.3,49,98300,115,1338,354,21,1,21,2400,0,2400,740,60,4.1,10,10,24.1,1010,9,999999999,129,0.1680,0,88,999.000,999.0,99.0
+1980,5,12,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,3.3,53,98200,0,11,348,0,0,0,0,0,0,0,70,5.2,10,10,24.1,760,9,999999999,129,0.1680,0,88,999.000,999.0,99.0
+1980,5,12,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,5.6,69,98200,0,0,343,0,0,0,0,0,0,0,70,6.2,10,10,14.5,580,9,999999999,150,0.1680,0,88,999.000,999.0,99.0
+1980,5,12,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,7.2,86,98100,0,0,336,0,0,0,0,0,0,0,50,3.6,10,10,14.5,460,9,999999999,160,0.1680,0,88,999.000,999.0,99.0
+1980,5,12,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,7.2,93,98000,0,0,331,0,0,0,0,0,0,0,30,2.6,10,10,11.3,340,9,999999999,160,0.1680,0,88,999.000,999.0,99.0
+1980,5,12,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,7.2,96,98000,0,0,329,0,0,0,0,0,0,0,50,5.2,10,10,9.7,270,9,999999999,160,0.1680,0,88,999.000,999.0,99.0
+1980,5,13,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,7.2,96,97900,0,0,329,0,0,0,0,0,0,0,50,3.1,10,10,11.3,310,9,999999999,160,0.1680,0,88,999.000,999.0,99.0
+1980,5,13,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,7.8,100,97900,0,0,330,0,0,0,0,0,0,0,40,4.1,10,10,11.3,310,9,999999999,170,0.1680,0,88,999.000,999.0,99.0
+1980,5,13,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,7.8,96,98000,0,0,332,0,0,0,0,0,0,0,20,3.1,10,10,11.3,340,9,999999999,170,0.1680,0,88,999.000,999.0,99.0
+1980,5,13,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,7.8,96,98000,0,0,332,0,0,0,0,0,0,0,30,3.6,10,10,11.3,370,9,999999999,170,0.1680,0,88,999.000,999.0,99.0
+1980,5,13,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.8,7.2,96,98100,19,568,329,8,0,8,0,0,0,0,50,5.7,10,10,12.9,370,9,999999999,160,0.3350,0,88,999.000,999.0,99.0
+1980,5,13,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.8,6.1,89,98200,213,1337,328,41,1,41,4700,0,4700,1490,40,5.2,10,10,24.1,520,9,999999999,150,0.3350,0,88,999.000,999.0,99.0
+1980,5,13,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,6.1,83,98100,456,1337,333,135,1,135,15200,100,15100,4880,80,2.6,10,10,24.1,520,9,999999999,150,0.3350,0,88,999.000,999.0,99.0
+1980,5,13,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,7.2,83,98100,689,1337,339,164,1,163,19000,100,18900,6980,120,2.1,10,10,24.1,460,9,999999999,160,0.3350,0,88,999.000,999.0,99.0
+1980,5,13,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,7.8,77,98100,895,1337,348,246,1,246,28700,100,28700,10860,140,3.1,10,10,24.1,370,9,999999999,170,0.3350,0,88,999.000,999.0,99.0
+1980,5,13,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,8.3,80,98100,1059,1337,349,314,2,313,36900,200,36700,14010,100,3.1,10,10,11.3,520,9,999999999,170,0.3350,0,88,999.000,999.0,99.0
+1980,5,13,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,12.2,78,97900,1171,1337,358,488,132,372,54000,14100,41600,16250,130,6.2,8,8,9.7,460,9,999999999,220,0.3350,0,88,999.000,999.0,99.0
+1980,5,13,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,13.9,81,97900,1222,1337,384,240,4,235,29200,300,28900,11630,300,6.2,10,10,8.0,700,9,999999999,240,0.3350,0,88,999.000,999.0,99.0
+1980,5,13,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,10.0,53,97900,1209,1337,383,513,69,450,56600,7100,50100,21580,250,12.9,9,9,16.1,1160,9,999999999,189,0.3350,0,88,999.000,999.0,99.0
+1980,5,13,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,10.6,65,98100,1133,1337,356,567,234,369,62100,25400,40500,14950,310,8.2,7,7,16.1,760,9,999999999,200,0.3350,0,88,999.000,999.0,99.0
+1980,5,13,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,8.9,65,98200,1000,1337,359,378,64,330,41700,6600,36700,12350,320,8.2,9,9,16.1,580,9,999999999,179,0.3350,0,88,999.000,999.0,99.0
+1980,5,13,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,7.2,77,98400,818,1337,345,302,44,275,33200,4500,30500,8920,340,9.3,10,10,16.1,520,9,999999999,160,0.3350,0,88,999.000,999.0,99.0
+1980,5,13,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,6.1,77,98500,599,1337,338,198,6,195,22200,500,22000,7280,330,8.2,10,10,14.5,490,9,999999999,150,0.3350,0,88,999.000,999.0,99.0
+1980,5,13,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,5.0,80,98700,360,1337,329,64,3,64,7500,100,7500,2540,340,6.7,10,10,14.5,460,9,999999999,139,0.3350,0,88,999.000,999.0,99.0
+1980,5,13,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,5.0,80,98800,119,1337,329,23,0,23,2600,0,2600,800,340,5.2,10,10,12.9,430,9,999999999,139,0.3350,0,88,999.000,999.0,99.0
+1980,5,13,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,5.6,89,98900,0,33,324,0,0,0,0,0,0,0,330,5.2,10,10,11.3,520,9,999999999,150,0.3350,0,88,999.000,999.0,99.0
+1980,5,13,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,6.1,93,99000,0,0,325,0,0,0,0,0,0,0,320,4.1,10,10,11.3,430,9,999999999,150,0.3350,0,88,999.000,999.0,99.0
+1980,5,13,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,4.4,83,99100,0,0,323,0,0,0,0,0,0,0,310,4.1,10,10,16.1,760,9,999999999,139,0.3350,0,88,999.000,999.0,99.0
+1980,5,13,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,4.4,86,99100,0,0,321,0,0,0,0,0,0,0,330,3.1,10,10,19.3,760,9,999999999,139,0.3350,0,88,999.000,999.0,99.0
+1980,5,13,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,4.4,83,99100,0,0,314,0,0,0,0,0,0,0,330,2.6,9,9,24.1,1680,9,999999999,139,0.3350,0,88,999.000,999.0,99.0
+1980,5,14,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,4.4,80,99100,0,0,326,0,0,0,0,0,0,0,310,4.1,10,10,24.1,1680,9,999999999,139,0.3350,0,88,999.000,999.0,99.0
+1980,5,14,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,5.0,83,99200,0,0,326,0,0,0,0,0,0,0,300,3.1,10,10,24.1,1680,9,999999999,139,0.3350,0,88,999.000,999.0,99.0
+1980,5,14,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,4.4,83,99200,0,0,299,0,0,0,0,0,0,0,290,3.1,6,6,24.1,1680,9,999999999,139,0.3350,0,88,999.000,999.0,99.0
+1980,5,14,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,3.9,86,99200,0,0,284,0,0,0,0,0,0,0,270,2.6,2,2,24.1,77777,9,999999999,129,0.3350,0,88,999.000,999.0,99.0
+1980,5,14,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,3.9,89,99300,21,590,287,11,17,9,0,0,0,0,290,3.1,4,4,24.1,77777,9,999999999,129,0.0740,0,88,999.000,999.0,99.0
+1980,5,14,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,5.0,86,99300,216,1337,293,101,324,48,10500,21900,7000,860,300,3.1,3,3,24.1,77777,9,999999999,139,0.0740,0,88,999.000,999.0,99.0
+1980,5,14,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,5.6,80,99300,459,1337,288,291,686,54,30500,63500,8600,1140,320,3.6,0,0,24.1,77777,9,999999999,150,0.0740,0,88,999.000,999.0,99.0
+1980,5,14,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,4.4,62,99400,692,1337,298,490,802,73,52300,79600,11100,1700,30,2.1,0,0,24.1,77777,9,999999999,139,0.0740,0,88,999.000,999.0,99.0
+1980,5,14,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,3.9,55,99400,897,1337,312,652,727,162,68800,73600,19200,4290,360,2.1,2,2,24.1,77777,9,999999999,139,0.0740,0,88,999.000,999.0,99.0
+1980,5,14,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,3.3,48,99400,1061,1337,322,707,620,213,74600,62900,24500,7420,360,3.1,3,3,24.1,77777,9,999999999,129,0.0740,0,88,999.000,999.0,99.0
+1980,5,14,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,3.3,46,99400,1172,1337,333,812,634,254,85600,64300,29100,11960,10,3.1,6,6,24.1,1680,9,999999999,129,0.0740,0,88,999.000,999.0,99.0
+1980,5,14,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,4.4,53,99400,1223,1337,355,471,187,300,52900,20400,34200,15650,40,3.6,10,10,24.1,1680,9,999999999,139,0.0740,0,88,999.000,999.0,99.0
+1980,5,14,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,5.6,55,99400,1211,1337,349,514,155,373,57100,16600,42000,18180,100,3.6,9,9,24.1,1680,9,999999999,150,0.0740,0,88,999.000,999.0,99.0
+1980,5,14,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,5.0,51,99400,1135,1337,332,859,741,229,91000,75300,26900,9640,90,3.1,5,5,24.1,77777,9,999999999,139,0.0740,0,88,999.000,999.0,99.0
+1980,5,14,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,3.9,49,99300,1002,1337,328,692,680,183,73500,69200,21600,5710,70,4.1,5,5,24.1,77777,9,999999999,129,0.0740,0,88,999.000,999.0,99.0
+1980,5,14,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,3.3,48,99300,820,1337,327,410,421,153,45200,43400,18500,3590,70,4.1,5,5,24.1,77777,9,999999999,129,0.0740,0,88,999.000,999.0,99.0
+1980,5,14,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,2.2,46,99300,602,1337,323,346,403,166,36300,39600,18400,3400,100,5.2,5,5,24.1,77777,9,999999999,120,0.0740,0,88,999.000,999.0,99.0
+1980,5,14,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,1.1,45,99300,364,1337,299,210,617,46,22200,53900,7600,940,90,5.2,0,0,24.1,77777,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1980,5,14,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,-0.6,45,99300,122,1337,291,48,260,23,4800,14000,3500,410,110,4.6,0,0,24.1,77777,9,999999999,100,0.0740,0,88,999.000,999.0,99.0
+1980,5,14,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,1.1,59,99300,0,56,296,0,0,0,0,0,0,0,120,3.1,3,3,24.1,77777,9,999999999,120,0.0740,0,88,999.000,999.0,99.0
+1980,5,14,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,0.6,56,99300,0,0,306,0,0,0,0,0,0,0,110,2.6,7,7,24.1,2740,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1980,5,14,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,0.6,56,99300,0,0,318,0,0,0,0,0,0,0,130,2.6,9,9,24.1,2130,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1980,5,14,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,0.6,52,99300,0,0,323,0,0,0,0,0,0,0,140,3.1,9,9,24.1,2130,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1980,5,14,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,1.1,52,99300,0,0,335,0,0,0,0,0,0,0,140,2.6,10,10,24.1,2130,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1980,5,15,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,1.1,54,99300,0,0,332,0,0,0,0,0,0,0,170,1.5,10,10,24.1,2130,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1980,5,15,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,1.7,57,99400,0,0,333,0,0,0,0,0,0,0,330,1.0,10,10,24.1,2130,9,999999999,120,0.0740,0,88,999.000,999.0,99.0
+1980,5,15,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,5.0,80,99500,0,0,329,0,0,0,0,0,0,0,10,4.1,10,10,19.3,2130,9,999999999,139,0.0740,0,88,999.000,999.0,99.0
+1980,5,15,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,6.7,89,99500,0,0,331,0,0,0,0,0,0,0,110,3.6,10,10,24.1,2130,9,999999999,160,0.0740,0,88,999.000,999.0,99.0
+1980,5,15,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.8,7.2,96,99500,22,612,329,7,0,7,0,0,0,0,110,2.6,10,10,24.1,2130,9,999999999,160,0.0740,0,88,999.000,999.0,99.0
+1980,5,15,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,7.2,93,99600,219,1336,322,34,9,32,3700,700,3600,860,60,2.6,9,9,16.1,2130,9,999999999,160,0.0740,0,88,999.000,999.0,99.0
+1980,5,15,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,7.8,93,99700,462,1336,314,184,180,121,19600,17100,13700,2420,50,3.6,7,7,11.3,2130,9,999999999,170,0.0740,0,88,999.000,999.0,99.0
+1980,5,15,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,7.2,77,99700,695,1336,323,335,241,209,35900,25100,22800,4780,40,2.6,7,7,11.3,1220,9,999999999,160,0.0740,0,88,999.000,999.0,99.0
+1980,5,15,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,6.1,64,99700,900,1336,305,671,860,89,69600,85600,11900,2200,70,3.6,0,0,14.5,77777,9,999999999,150,0.0740,0,88,999.000,999.0,99.0
+1980,5,15,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,6.1,60,99700,1063,1336,315,759,813,109,78200,81300,13400,3230,30,2.6,3,1,16.1,77777,9,999999999,160,0.0740,0,88,999.000,999.0,99.0
+1980,5,15,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,7.2,58,99700,1174,1336,324,855,835,118,87900,83700,14200,4640,50,5.7,4,1,24.1,77777,9,999999999,170,0.0740,0,88,999.000,999.0,99.0
+1980,5,15,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,6.7,54,99700,1225,1336,326,911,894,88,94500,89900,11900,4580,60,4.1,1,1,24.1,77777,9,999999999,160,0.0740,0,88,999.000,999.0,99.0
+1980,5,15,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,6.1,52,99700,1212,1336,325,953,933,104,98500,93700,13300,4930,60,4.1,1,1,24.1,77777,9,999999999,160,0.0740,0,88,999.000,999.0,99.0
+1980,5,15,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,6.1,54,99800,1137,1336,327,834,853,107,86200,85500,13300,3880,70,5.2,2,2,24.1,77777,9,999999999,160,0.0740,0,88,999.000,999.0,99.0
+1980,5,15,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,5.6,52,99700,1004,1336,316,764,891,95,79500,89100,12400,2680,30,5.2,0,0,24.1,77777,9,999999999,150,0.0740,0,88,999.000,999.0,99.0
+1980,5,15,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,4.4,50,99700,822,1336,312,597,838,83,62500,83000,11300,1940,50,5.2,0,0,24.1,77777,9,999999999,139,0.0740,0,88,999.000,999.0,99.0
+1980,5,15,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,4.4,51,99800,605,1336,310,406,759,66,43600,74000,10100,1470,20,5.2,0,0,24.1,77777,9,999999999,139,0.0740,0,88,999.000,999.0,99.0
+1980,5,15,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,3.9,55,99800,367,1336,302,209,603,46,22000,52800,7500,940,60,5.2,0,0,24.1,77777,9,999999999,139,0.0740,0,88,999.000,999.0,99.0
+1980,5,15,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,2.8,57,99800,126,1336,294,48,259,23,4800,14200,3500,420,50,4.1,0,0,24.1,77777,9,999999999,129,0.0740,0,88,999.000,999.0,99.0
+1980,5,15,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,2.8,63,99800,0,78,287,0,0,0,0,0,0,0,50,5.2,1,0,24.1,77777,9,999999999,129,0.0740,0,88,999.000,999.0,99.0
+1980,5,15,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,3.9,74,99900,0,0,284,0,0,0,0,0,0,0,50,3.6,0,0,24.1,77777,9,999999999,139,0.0740,0,88,999.000,999.0,99.0
+1980,5,15,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,3.9,77,99900,0,0,282,0,0,0,0,0,0,0,70,3.6,0,0,24.1,77777,9,999999999,139,0.0740,0,88,999.000,999.0,99.0
+1980,5,15,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,3.9,83,99900,0,0,277,0,0,0,0,0,0,0,40,2.6,0,0,24.1,77777,9,999999999,139,0.0740,0,88,999.000,999.0,99.0
+1980,5,15,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,3.3,83,99900,0,0,284,0,0,0,0,0,0,0,40,2.6,2,2,24.1,77777,9,999999999,129,0.0740,0,88,999.000,999.0,99.0
+1980,5,16,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,3.3,83,99900,0,0,289,0,0,0,0,0,0,0,40,3.1,4,4,24.1,77777,9,999999999,129,0.0740,0,88,999.000,999.0,99.0
+1980,5,16,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,3.3,86,100000,0,0,289,0,0,0,0,0,0,0,30,2.6,5,5,24.1,77777,9,999999999,129,0.0740,0,88,999.000,999.0,99.0
+1980,5,16,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,3.3,83,99900,0,0,293,0,0,0,0,0,0,0,30,3.1,6,6,24.1,2440,9,999999999,129,0.0740,0,88,999.000,999.0,99.0
+1980,5,16,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,3.9,86,99900,0,0,297,0,0,0,0,0,0,0,40,2.1,7,7,24.1,1680,9,999999999,139,0.0740,0,88,999.000,999.0,99.0
+1980,5,16,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,3.9,83,99900,24,634,287,8,0,8,0,0,0,0,60,3.1,7,2,24.1,77777,9,999999999,139,0.2900,0,88,999.000,999.0,99.0
+1980,5,16,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,6.1,83,100000,223,1336,288,87,107,70,9500,7700,8200,1490,70,3.1,6,0,16.1,77777,9,999999999,160,0.2900,0,88,999.000,999.0,99.0
+1980,5,16,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,6.7,72,100000,465,1336,301,252,338,134,26800,32100,15600,2730,90,3.1,6,0,16.1,77777,9,999999999,160,0.2900,0,88,999.000,999.0,99.0
+1980,5,16,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,6.7,62,100000,697,1336,310,452,496,192,47300,49900,21200,4170,90,4.1,6,0,19.3,77777,9,999999999,160,0.2900,0,88,999.000,999.0,99.0
+1980,5,16,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,6.7,58,99900,902,1336,325,543,365,295,58500,39200,32000,8170,90,6.2,9,2,19.3,77777,9,999999999,160,0.2900,0,88,999.000,999.0,99.0
+1980,5,16,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,6.7,56,100000,1065,1336,331,725,491,332,76400,51100,35600,12040,90,5.2,10,3,19.3,77777,9,999999999,160,0.2900,0,88,999.000,999.0,99.0
+1980,5,16,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,6.7,52,99900,1176,1336,339,694,337,397,75900,36600,43600,18190,90,6.2,10,4,19.3,77777,9,999999999,160,0.2900,0,88,999.000,999.0,99.0
+1980,5,16,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,5.6,50,99900,1226,1336,368,424,7,418,49800,700,49200,17920,70,7.7,10,10,19.3,4570,9,999999999,150,0.2900,0,88,999.000,999.0,99.0
+1980,5,16,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,5.0,48,99900,1214,1336,367,436,1,434,50800,100,50700,18290,80,5.2,10,10,19.3,3660,9,999999999,150,0.2900,0,88,999.000,999.0,99.0
+1980,5,16,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,4.4,48,99800,1139,1336,364,421,5,417,48800,500,48400,17410,90,7.2,10,10,19.3,3660,9,999999999,139,0.2900,0,88,999.000,999.0,99.0
+1980,5,16,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,4.4,50,99700,1006,1336,360,270,4,267,31800,300,31500,12230,80,5.7,10,10,19.3,3660,9,999999999,139,0.2900,0,88,999.000,999.0,99.0
+1980,5,16,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,4.4,50,99600,825,1336,360,239,4,237,27600,300,27400,10110,80,6.2,10,10,16.1,1680,9,999999999,139,0.2900,0,88,999.000,999.0,99.0
+1980,5,16,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,6.1,60,99600,608,1336,357,102,2,101,12100,100,12000,4500,70,5.7,10,10,12.9,1680,9,999999999,160,0.2900,0,88,999.000,999.0,99.0
+1980,5,16,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,7.8,72,99600,370,1336,354,50,1,49,5800,0,5800,2050,100,4.1,10,10,12.9,1680,9,999999999,170,0.2900,0,88,999.000,999.0,99.0
+1980,5,16,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,10.0,93,99700,130,1336,348,20,0,20,2300,0,2300,730,240,2.1,10,10,11.3,1680,9,999999999,189,0.2900,0,88,999.000,999.0,99.0
+1980,5,16,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,10.0,93,99700,1,100,348,0,0,0,0,0,0,0,100,3.6,10,10,6.4,1160,9,999999999,189,0.2900,0,88,999.000,999.0,99.0
+1980,5,16,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,10.0,90,99600,0,0,351,0,0,0,0,0,0,0,100,4.1,10,10,9.7,1400,9,999999999,200,0.2900,0,88,999.000,999.0,99.0
+1980,5,16,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,9.4,90,99600,0,0,347,0,0,0,0,0,0,0,90,5.7,10,10,8.0,1010,9,999999999,189,0.2900,0,88,999.000,999.0,99.0
+1980,5,16,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,8.9,93,99600,0,0,341,0,0,0,0,0,0,0,80,6.2,10,10,9.7,1010,9,999999999,179,0.2900,0,88,999.000,999.0,99.0
+1980,5,16,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,8.3,86,99500,0,0,343,0,0,0,0,0,0,0,80,5.2,10,10,11.3,700,9,999999999,179,0.2900,0,88,999.000,999.0,99.0
+1980,5,17,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,8.3,89,99500,0,0,341,0,0,0,0,0,0,0,100,5.2,10,10,11.3,490,9,999999999,179,0.2900,0,88,999.000,999.0,99.0
+1980,5,17,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,8.3,93,99400,0,0,338,0,0,0,0,0,0,0,90,5.7,10,10,9.7,370,9,999999999,179,0.2900,0,88,999.000,999.0,99.0
+1980,5,17,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,8.3,93,99300,0,0,338,0,0,0,0,0,0,0,80,4.1,10,10,9.7,270,9,999999999,179,0.2900,0,88,999.000,999.0,99.0
+1980,5,17,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,8.3,93,99300,0,0,338,0,0,0,0,0,0,0,80,3.6,10,10,9.7,210,9,999999999,179,0.2900,0,88,999.000,999.0,99.0
+1980,5,17,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,8.9,90,99200,25,656,344,9,0,9,0,0,0,0,80,4.6,10,10,6.4,210,9,999999999,179,0.1590,0,88,999.000,999.0,99.0
+1980,5,17,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,9.4,96,99200,226,1335,342,55,0,55,6200,0,6200,1890,70,4.6,10,10,6.4,180,9,999999999,189,0.1590,0,88,999.000,999.0,99.0
+1980,5,17,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,9.4,93,99300,468,1335,345,131,1,131,14800,100,14800,4860,80,3.1,10,10,6.4,180,9,999999999,189,0.1590,0,88,999.000,999.0,99.0
+1980,5,17,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,10.6,93,99100,699,1335,352,250,1,249,28000,100,28000,9390,80,5.7,10,10,4.8,150,9,999999999,200,0.1590,0,88,999.000,999.0,99.0
+1980,5,17,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,11.1,93,99100,904,1335,355,338,1,338,38500,100,38400,13480,80,4.6,10,10,4.8,150,9,999999999,209,0.1590,0,88,999.000,999.0,99.0
+1980,5,17,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,11.7,93,99100,1067,1335,358,355,0,355,41200,0,41200,15330,70,4.1,10,10,3.2,120,9,999999999,209,0.1590,0,88,999.000,999.0,99.0
+1980,5,17,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,12.2,96,99000,1177,1335,359,405,0,404,47200,0,47200,17280,70,4.1,10,10,0.8,60,9,999999999,220,0.1590,0,88,999.000,999.0,99.0
+1980,5,17,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,12.2,96,99000,1228,1335,359,434,0,434,50800,0,50800,18370,80,3.6,10,10,0.4,60,9,999999999,220,0.1590,0,88,999.000,999.0,99.0
+1980,5,17,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,12.8,96,98900,1215,1335,362,436,1,435,50900,100,50800,18320,70,5.2,10,10,1.3,60,9,999999999,229,0.1590,0,88,999.000,999.0,99.0
+1980,5,17,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,12.8,96,98800,1140,1335,362,432,1,431,49900,100,49800,17770,60,4.1,10,10,1.3,60,9,999999999,229,0.1590,0,88,999.000,999.0,99.0
+1980,5,17,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,12.8,100,98700,1008,1335,360,205,2,204,24700,200,24600,9920,50,2.6,10,10,0.8,60,9,999999999,229,0.1590,0,88,999.000,999.0,99.0
+1980,5,17,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,12.2,96,98700,827,1335,359,157,1,156,18700,100,18600,7350,20,3.1,10,10,2.4,90,9,999999999,220,0.1590,0,88,999.000,999.0,99.0
+1980,5,17,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,11.7,96,98600,611,1335,355,109,1,109,12900,100,12900,4810,10,4.1,10,10,3.2,150,9,999999999,209,0.1590,0,88,999.000,999.0,99.0
+1980,5,17,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,11.7,100,98400,373,1335,353,55,0,55,6500,0,6500,2270,60,3.1,10,10,3.2,60,9,999999999,209,0.1590,0,88,999.000,999.0,99.0
+1980,5,17,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,11.1,96,98400,133,1335,352,17,0,17,2000,0,2000,640,20,3.1,10,10,3.2,60,9,999999999,209,0.1590,0,88,999.000,999.0,99.0
+1980,5,17,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,11.1,96,98400,1,122,352,0,0,0,0,0,0,0,40,4.1,10,10,0.8,30,9,999999999,209,0.1590,0,88,999.000,999.0,99.0
+1980,5,17,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,10.6,96,98500,0,0,349,0,0,0,0,0,0,0,10,2.6,10,10,0.6,60,9,999999999,200,0.1590,0,88,999.000,999.0,99.0
+1980,5,17,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,10.6,100,98600,0,0,346,0,0,0,0,0,0,0,0,0.0,10,10,0.4,30,9,999999999,200,0.1590,0,88,999.000,999.0,99.0
+1980,5,17,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,11.1,100,98500,0,0,349,0,0,0,0,0,0,0,340,3.1,10,10,0.4,90,9,999999999,209,0.1590,0,88,999.000,999.0,99.0
+1980,5,17,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,11.1,100,98500,0,0,349,0,0,0,0,0,0,0,340,3.1,10,10,0.4,90,9,999999999,209,0.1590,0,88,999.000,999.0,99.0
+1980,5,18,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,10.6,100,98500,0,0,346,0,0,0,0,0,0,0,300,2.1,10,10,1.6,90,9,999999999,200,0.1590,0,88,999.000,999.0,99.0
+1980,5,18,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,11.7,100,98500,0,0,353,0,0,0,0,0,0,0,260,3.1,10,10,0.4,60,9,999999999,209,0.1590,0,88,999.000,999.0,99.0
+1980,5,18,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,12.2,100,98500,0,0,356,0,0,0,0,0,0,0,310,4.1,10,10,0.4,90,9,999999999,220,0.1590,0,88,999.000,999.0,99.0
+1980,5,18,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,12.2,100,98600,0,0,356,0,0,0,0,0,0,0,310,3.1,10,10,3.2,150,9,999999999,220,0.1590,0,88,999.000,999.0,99.0
+1980,5,18,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,12.2,100,98600,27,678,356,10,0,10,1200,0,1200,360,350,2.6,10,10,3.2,210,9,999999999,220,0.1590,0,88,999.000,999.0,99.0
+1980,5,18,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,11.7,96,98600,229,1335,355,38,0,38,4400,0,4400,1440,340,3.1,10,10,3.2,180,9,999999999,209,0.1590,0,88,999.000,999.0,99.0
+1980,5,18,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,11.7,96,98700,471,1335,355,128,0,128,14500,0,14500,4800,270,2.6,10,10,8.0,210,9,999999999,209,0.1590,0,88,999.000,999.0,99.0
+1980,5,18,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,11.7,90,98700,702,1335,361,217,1,216,24600,100,24600,8610,270,2.1,10,10,9.7,240,9,999999999,209,0.1590,0,88,999.000,999.0,99.0
+1980,5,18,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,12.8,87,98800,906,1335,371,333,0,333,37900,0,37900,13390,230,2.1,10,10,14.5,310,9,999999999,229,0.1590,0,88,999.000,999.0,99.0
+1980,5,18,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,11.7,87,98900,1068,1335,364,361,1,360,41900,100,41800,15480,240,3.1,10,10,16.1,520,9,999999999,220,0.1590,0,88,999.000,999.0,99.0
+1980,5,18,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,12.8,84,98900,1179,1335,374,437,1,436,50700,100,50700,18140,210,3.1,10,10,16.1,880,9,999999999,229,0.1590,0,88,999.000,999.0,99.0
+1980,5,18,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,11.7,75,98900,1229,1335,375,442,1,442,51800,100,51700,18590,250,3.1,10,10,16.1,580,9,999999999,209,0.1590,0,88,999.000,999.0,99.0
+1980,5,18,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,12.2,78,98900,1217,1335,376,416,1,414,48600,100,48600,17770,270,3.1,10,10,16.1,640,9,999999999,220,0.1590,0,88,999.000,999.0,99.0
+1980,5,18,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,12.2,78,98900,1142,1335,376,400,0,400,46500,0,46500,16990,280,2.1,10,10,14.5,580,9,999999999,220,0.1590,0,88,999.000,999.0,99.0
+1980,5,18,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,12.8,84,98900,1010,1335,374,348,1,347,40100,100,40100,14700,360,3.1,10,10,14.5,580,9,999999999,229,0.1590,0,88,999.000,999.0,99.0
+1980,5,18,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,12.8,84,99000,829,1335,374,284,1,284,32400,100,32300,11450,240,2.6,10,10,19.3,700,9,999999999,229,0.1590,0,88,999.000,999.0,99.0
+1980,5,18,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,12.8,84,99000,613,1335,374,180,0,180,20400,0,20400,7030,280,1.5,10,10,12.9,1010,9,999999999,229,0.1590,0,88,999.000,999.0,99.0
+1980,5,18,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,12.8,87,99000,376,1335,371,56,0,56,6600,0,6600,2310,90,3.1,10,10,8.0,760,9,999999999,229,0.1590,0,88,999.000,999.0,99.0
+1980,5,18,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,12.2,93,99000,136,1335,361,29,0,29,3300,0,3300,1000,70,3.1,10,10,6.4,1680,9,999999999,220,0.1590,0,88,999.000,999.0,99.0
+1980,5,18,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,12.2,96,99000,1,145,359,1,0,1,0,0,0,0,90,3.1,10,10,6.4,150,9,999999999,220,0.1590,0,88,999.000,999.0,99.0
+1980,5,18,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,11.1,93,99100,0,0,355,0,0,0,0,0,0,0,50,2.6,10,10,4.8,120,9,999999999,209,0.1590,0,88,999.000,999.0,99.0
+1980,5,18,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,11.1,93,99100,0,0,355,0,0,0,0,0,0,0,60,2.6,10,10,8.0,180,9,999999999,209,0.1590,0,88,999.000,999.0,99.0
+1980,5,18,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,11.1,96,99100,0,0,352,0,0,0,0,0,0,0,60,2.1,10,10,2.4,120,9,999999999,209,0.1590,0,88,999.000,999.0,99.0
+1980,5,18,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,11.1,100,99100,0,0,349,0,0,0,0,0,0,0,70,3.1,10,10,2.4,90,9,999999999,209,0.1590,0,88,999.000,999.0,99.0
+1980,5,19,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,9.4,100,99100,0,0,339,0,0,0,0,0,0,0,60,2.6,10,10,3.2,120,9,999999999,189,0.1590,0,88,999.000,999.0,99.0
+1980,5,19,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,8.9,96,99100,0,0,338,0,0,0,0,0,0,0,80,2.1,10,10,6.4,270,9,999999999,179,0.1590,0,88,999.000,999.0,99.0
+1980,5,19,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,8.9,96,99100,0,0,338,0,0,0,0,0,0,0,0,0.0,10,10,6.4,340,9,999999999,179,0.1590,0,88,999.000,999.0,99.0
+1980,5,19,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,10.6,100,99100,0,0,346,0,0,0,0,0,0,0,70,2.1,10,10,6.4,180,9,999999999,200,0.1590,0,88,999.000,999.0,99.0
+1980,5,19,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,11.1,100,99100,28,700,349,12,0,12,1400,0,1400,420,60,3.1,10,10,6.4,180,9,999999999,209,0.3040,0,88,999.000,999.0,99.0
+1980,5,19,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,10.6,96,99200,232,1334,349,67,0,67,7400,0,7400,2180,50,3.6,10,10,6.4,90,9,999999999,200,0.3040,0,88,999.000,999.0,99.0
+1980,5,19,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,10.6,96,99200,473,1334,349,149,0,149,16600,0,16600,5310,40,4.6,10,10,8.0,120,9,999999999,200,0.3040,0,88,999.000,999.0,99.0
+1980,5,19,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,10.0,93,99200,704,1334,348,216,1,216,24600,100,24600,8630,50,3.1,10,10,11.3,150,9,999999999,189,0.3040,0,88,999.000,999.0,99.0
+1980,5,19,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,11.7,93,99200,907,1334,358,294,1,294,33900,100,33800,12400,40,3.1,10,10,12.9,240,9,999999999,209,0.3040,0,88,999.000,999.0,99.0
+1980,5,19,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,12.2,90,99200,1070,1334,364,387,1,386,44700,100,44600,16190,70,3.1,10,10,12.9,490,9,999999999,220,0.3040,0,88,999.000,999.0,99.0
+1980,5,19,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,12.8,84,99200,1180,1334,350,601,263,367,66100,28600,40700,16960,50,4.1,7,7,16.1,1680,9,999999999,229,0.3040,0,88,999.000,999.0,99.0
+1980,5,19,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,12.2,70,99300,1231,1334,353,643,255,407,70600,27700,45000,22640,50,4.1,5,5,19.3,77777,9,999999999,220,0.3040,0,88,999.000,999.0,99.0
+1980,5,19,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,13.3,70,99200,1218,1334,357,759,442,354,81200,46200,38900,20720,40,5.2,4,4,24.1,77777,9,999999999,240,0.3040,0,88,999.000,999.0,99.0
+1980,5,19,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,11.7,65,99200,1143,1334,350,835,644,282,87200,64800,31600,12030,40,5.2,3,3,24.1,77777,9,999999999,209,0.3040,0,88,999.000,999.0,99.0
+1980,5,19,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,11.1,63,99200,1012,1334,334,720,654,224,75400,66000,25300,6980,70,5.2,0,0,24.1,77777,9,999999999,209,0.3040,0,88,999.000,999.0,99.0
+1980,5,19,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,10.0,59,99100,832,1334,333,552,580,192,59600,59700,22300,4650,80,2.6,0,0,24.1,77777,9,999999999,200,0.3040,0,88,999.000,999.0,99.0
+1980,5,19,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,10.6,63,99100,616,1334,332,357,457,147,38000,45200,17100,2990,50,4.6,0,0,24.1,77777,9,999999999,200,0.3040,0,88,999.000,999.0,99.0
+1980,5,19,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,10.0,67,99100,379,1334,323,170,271,94,18300,24000,11500,1810,50,4.6,0,0,24.1,77777,9,999999999,189,0.3040,0,88,999.000,999.0,99.0
+1980,5,19,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,9.4,70,99100,140,1334,318,38,32,35,4200,2100,4000,840,50,4.1,0,0,24.1,77777,9,999999999,189,0.3040,0,88,999.000,999.0,99.0
+1980,5,19,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,8.9,75,99100,2,167,310,1,0,1,0,0,0,0,50,3.1,0,0,24.1,77777,9,999999999,179,0.3040,0,88,999.000,999.0,99.0
+1980,5,19,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,8.9,80,99200,0,0,305,0,0,0,0,0,0,0,50,3.1,0,0,24.1,77777,9,999999999,179,0.3040,0,88,999.000,999.0,99.0
+1980,5,19,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,8.3,83,99200,0,0,300,0,0,0,0,0,0,0,50,2.1,0,0,24.1,77777,9,999999999,179,0.3040,0,88,999.000,999.0,99.0
+1980,5,19,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,8.3,89,99200,0,0,295,0,0,0,0,0,0,0,40,2.1,0,0,24.1,77777,9,999999999,170,0.3040,0,88,999.000,999.0,99.0
+1980,5,19,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,7.2,89,99200,0,0,290,0,0,0,0,0,0,0,10,1.5,0,0,19.3,77777,9,999999999,160,0.3040,0,88,999.000,999.0,99.0
+1980,5,20,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,6.7,93,99200,0,0,285,0,0,0,0,0,0,0,10,2.1,0,0,16.1,77777,9,999999999,160,0.3040,0,88,999.000,999.0,99.0
+1980,5,20,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,6.1,93,99100,0,0,282,0,0,0,0,0,0,0,0,0.0,0,0,19.3,77777,9,999999999,150,0.3040,0,88,999.000,999.0,99.0
+1980,5,20,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,5.6,93,99100,0,0,279,0,0,0,0,0,0,0,0,0.0,2,0,14.5,77777,9,999999999,150,0.3040,0,88,999.000,999.0,99.0
+1980,5,20,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,5.6,89,99100,0,0,281,0,0,0,0,0,0,0,0,0.0,1,0,12.9,77777,9,999999999,150,0.3040,0,88,999.000,999.0,99.0
+1980,5,20,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.8,6.7,93,99200,30,722,294,9,8,8,900,400,900,210,0,0.0,2,2,14.5,77777,9,999999999,160,0.1920,0,88,999.000,999.0,99.0
+1980,5,20,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,9.4,90,99200,235,1334,311,87,189,53,9200,13200,6900,970,0,0.0,2,2,12.9,77777,9,999999999,189,0.1920,0,88,999.000,999.0,99.0
+1980,5,20,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,8.3,72,99200,476,1334,315,263,464,97,28100,43300,12600,1820,30,3.1,1,1,16.1,77777,9,999999999,179,0.1920,0,88,999.000,999.0,99.0
+1980,5,20,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,7.2,58,99200,706,1334,324,452,601,132,47100,59500,15600,2860,40,5.2,1,1,16.1,77777,9,999999999,170,0.1920,0,88,999.000,999.0,99.0
+1980,5,20,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,8.3,54,99200,909,1334,340,628,680,162,66300,69000,19200,4380,50,4.1,2,2,19.3,77777,9,999999999,179,0.1920,0,88,999.000,999.0,99.0
+1980,5,20,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,10.0,53,99200,1071,1334,352,718,631,209,75900,64200,24200,7530,40,3.1,2,2,24.1,77777,9,999999999,200,0.1920,0,88,999.000,999.0,99.0
+1980,5,20,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,10.0,51,99200,1181,1334,355,800,614,254,84400,62300,29100,12490,60,2.6,2,2,24.1,77777,9,999999999,200,0.1920,0,88,999.000,999.0,99.0
+1980,5,20,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,10.0,46,99200,1232,1334,363,858,634,271,90700,64300,31200,16380,20,3.1,2,2,24.1,77777,9,999999999,189,0.1920,0,88,999.000,999.0,99.0
+1980,5,20,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,9.4,43,99100,1220,1334,365,888,724,224,95000,74100,27100,12950,70,4.1,2,2,24.1,77777,9,999999999,189,0.1920,0,88,999.000,999.0,99.0
+1980,5,20,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,10.6,45,99100,1145,1334,373,826,648,270,86700,65300,30500,11640,30,3.6,4,3,24.1,77777,9,999999999,200,0.1920,0,88,999.000,999.0,99.0
+1980,5,20,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,8.9,40,99100,1013,1334,367,711,662,208,74900,67000,23900,6580,40,5.7,2,2,24.1,77777,9,999999999,179,0.1920,0,88,999.000,999.0,99.0
+1980,5,20,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,10.0,48,99100,834,1334,364,533,560,184,57800,57700,21600,4450,30,5.2,3,3,24.1,77777,9,999999999,200,0.1920,0,88,999.000,999.0,99.0
+1980,5,20,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,9.4,47,99100,618,1334,360,355,465,141,38000,46000,16600,2860,30,5.2,3,3,24.1,77777,9,999999999,189,0.1920,0,88,999.000,999.0,99.0
+1980,5,20,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,8.9,49,99100,382,1334,357,123,131,86,13700,11800,10300,1910,40,3.6,5,4,24.1,77777,9,999999999,179,0.1920,0,88,999.000,999.0,99.0
+1980,5,20,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,8.9,58,99100,143,1334,338,37,55,32,4200,3200,3800,670,40,3.6,6,2,24.1,77777,9,999999999,179,0.1920,0,88,999.000,999.0,99.0
+1980,5,20,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,9.4,70,99100,2,189,318,0,0,0,0,0,0,0,50,3.1,2,0,24.1,77777,9,999999999,189,0.1920,0,88,999.000,999.0,99.0
+1980,5,20,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,8.9,75,99000,0,0,310,0,0,0,0,0,0,0,40,1.5,0,0,24.1,77777,9,999999999,179,0.1920,0,88,999.000,999.0,99.0
+1980,5,20,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,8.9,93,99200,0,0,296,0,0,0,0,0,0,0,190,1.0,0,0,24.1,77777,9,999999999,179,0.1920,0,88,999.000,999.0,99.0
+1980,5,20,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,8.3,96,99200,0,0,291,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,179,0.1920,0,88,999.000,999.0,99.0
+1980,5,20,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,7.2,93,99200,0,0,297,0,0,0,0,0,0,0,0,0.0,2,2,19.3,77777,9,999999999,160,0.1920,0,88,999.000,999.0,99.0
+1980,5,21,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,6.1,89,99200,0,0,293,0,0,0,0,0,0,0,0,0.0,2,2,16.1,77777,9,999999999,150,0.1920,0,88,999.000,999.0,99.0
+1980,5,21,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,5.6,89,99100,0,0,293,0,0,0,0,0,0,0,0,0.0,3,3,12.9,77777,9,999999999,150,0.1920,0,88,999.000,999.0,99.0
+1980,5,21,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,6.7,93,99200,0,0,297,0,0,0,0,0,0,0,210,2.1,3,3,14.5,77777,9,999999999,160,0.1920,0,88,999.000,999.0,99.0
+1980,5,21,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,7.2,89,99200,0,0,299,0,0,0,0,0,0,0,0,0.0,8,2,12.9,77777,9,999999999,160,0.1920,0,88,999.000,999.0,99.0
+1980,5,21,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,7.2,89,99300,31,722,302,15,10,14,1600,500,1600,340,330,1.5,9,3,14.5,77777,9,999999999,160,0.1220,0,88,999.000,999.0,99.0
+1980,5,21,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,8.9,86,99300,237,1333,313,98,178,67,10400,12500,8200,1280,0,0.0,8,3,11.3,77777,9,999999999,179,0.1220,0,88,999.000,999.0,99.0
+1980,5,21,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,10.0,75,99400,478,1333,326,227,244,139,24100,23400,15700,2850,0,0.0,6,2,8.0,77777,9,999999999,189,0.1220,0,88,999.000,999.0,99.0
+1980,5,21,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,8.9,58,99400,708,1333,333,461,661,108,48800,66000,13600,2410,320,2.1,3,1,9.7,77777,9,999999999,179,0.1220,0,88,999.000,999.0,99.0
+1980,5,21,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,8.3,47,99400,911,1333,339,669,788,128,69800,78900,15800,3250,250,2.1,2,0,12.9,77777,9,999999999,179,0.1220,0,88,999.000,999.0,99.0
+1980,5,21,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,8.3,36,99400,1073,1333,360,814,839,136,86500,84900,18000,4730,0,0.0,1,0,19.3,77777,9,999999999,179,0.1220,0,88,999.000,999.0,99.0
+1980,5,21,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,7.2,30,99300,1183,1333,367,920,875,140,94100,87600,16200,5320,50,3.1,0,0,24.1,77777,9,999999999,160,0.1220,0,88,999.000,999.0,99.0
+1980,5,21,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,8.9,33,99300,1233,1333,372,959,878,144,98100,87900,16500,6830,90,2.6,0,0,24.1,77777,9,999999999,179,0.1220,0,88,999.000,999.0,99.0
+1980,5,21,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,8.3,30,99300,1221,1333,374,952,880,143,97400,88100,16400,6390,80,5.2,0,0,24.1,77777,9,999999999,170,0.1220,0,88,999.000,999.0,99.0
+1980,5,21,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,3.9,22,99300,1147,1333,368,886,869,138,91000,86900,16000,4600,50,3.6,0,0,24.1,77777,9,999999999,129,0.1220,0,88,999.000,999.0,99.0
+1980,5,21,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,7.8,30,99300,1015,1333,378,673,680,155,72400,69800,19200,5070,60,4.1,4,1,24.1,77777,9,999999999,170,0.1220,0,88,999.000,999.0,99.0
+1980,5,21,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,7.2,30,99200,836,1333,374,583,746,117,61200,74400,14400,2730,90,3.6,4,1,24.1,77777,9,999999999,160,0.1220,0,88,999.000,999.0,99.0
+1980,5,21,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,7.2,31,99200,621,1333,371,389,581,121,40700,56400,14400,2450,90,4.6,4,1,24.1,77777,9,999999999,160,0.1220,0,88,999.000,999.0,99.0
+1980,5,21,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,7.2,34,99200,385,1333,363,200,430,77,21500,37600,10600,1400,80,2.1,4,1,24.1,77777,9,999999999,160,0.1220,0,88,999.000,999.0,99.0
+1980,5,21,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,6.1,39,99300,146,1333,339,51,180,32,5400,9800,4400,570,110,3.6,2,0,24.1,77777,9,999999999,150,0.1220,0,88,999.000,999.0,99.0
+1980,5,21,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,7.2,50,99300,3,211,328,1,1,1,0,0,0,0,110,3.1,0,0,24.1,77777,9,999999999,160,0.1220,0,88,999.000,999.0,99.0
+1980,5,21,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,6.7,48,99400,0,0,327,0,0,0,0,0,0,0,110,2.6,0,0,24.1,77777,9,999999999,160,0.1220,0,88,999.000,999.0,99.0
+1980,5,21,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,7.2,64,99400,0,0,311,0,0,0,0,0,0,0,180,1.5,0,0,24.1,77777,9,999999999,160,0.1220,0,88,999.000,999.0,99.0
+1980,5,21,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,6.1,69,99400,0,0,300,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,150,0.1220,0,88,999.000,999.0,99.0
+1980,5,21,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,7.2,80,99400,0,0,297,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,170,0.1220,0,88,999.000,999.0,99.0
+1980,5,22,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,7.2,80,99400,0,0,297,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,170,0.1220,0,88,999.000,999.0,99.0
+1980,5,22,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,6.1,80,99400,0,0,290,0,0,0,0,0,0,0,330,2.1,0,0,24.1,77777,9,999999999,150,0.1220,0,88,999.000,999.0,99.0
+1980,5,22,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,6.7,86,99400,0,0,289,0,0,0,0,0,0,0,0,0.0,0,0,16.1,77777,9,999999999,160,0.1220,0,88,999.000,999.0,99.0
+1980,5,22,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,5.6,86,99400,0,0,283,0,0,0,0,0,0,0,0,0.0,0,0,12.9,77777,9,999999999,150,0.1220,0,88,999.000,999.0,99.0
+1980,5,22,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,5.6,77,99500,33,744,296,12,22,10,1300,800,1200,210,280,2.1,1,1,9.7,77777,9,999999999,150,0.1370,0,88,999.000,999.0,99.0
+1980,5,22,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,10.0,80,99500,240,1332,311,106,320,48,11200,22900,7100,850,0,0.0,0,0,6.4,77777,9,999999999,189,0.1370,0,88,999.000,999.0,99.0
+1980,5,22,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,11.7,65,99500,480,1332,335,289,581,78,30100,54100,10600,1530,0,0.0,0,0,4.0,77777,9,999999999,209,0.1370,0,88,999.000,999.0,99.0
+1980,5,22,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,10.0,48,99500,710,1332,349,486,713,105,51600,71400,13500,2360,150,2.1,0,0,4.8,77777,9,999999999,200,0.1370,0,88,999.000,999.0,99.0
+1980,5,22,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,8.9,39,99500,912,1332,358,667,785,126,69700,78700,15700,3230,130,2.6,0,0,9.7,77777,9,999999999,179,0.1370,0,88,999.000,999.0,99.0
+1980,5,22,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,8.3,34,99500,1074,1332,366,819,836,141,86500,84500,18300,4880,140,3.1,0,0,11.3,77777,9,999999999,179,0.1370,0,88,999.000,999.0,99.0
+1980,5,22,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,7.2,31,99500,1184,1332,364,916,859,150,97700,87100,20200,7200,170,2.6,0,0,11.3,77777,9,999999999,160,0.1370,0,88,999.000,999.0,99.0
+1980,5,22,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,6.7,28,99400,1234,1332,369,964,871,155,98400,87200,17500,7200,80,4.1,0,0,12.9,77777,9,999999999,160,0.1370,0,88,999.000,999.0,99.0
+1980,5,22,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,7.2,27,99300,1222,1332,375,951,867,153,97100,86800,17300,6700,90,5.2,0,0,12.9,77777,9,999999999,160,0.1370,0,88,999.000,999.0,99.0
+1980,5,22,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,8.9,32,99300,1148,1332,382,849,816,146,90700,82700,19300,6210,80,5.2,3,1,12.9,77777,9,999999999,179,0.1370,0,88,999.000,999.0,99.0
+1980,5,22,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,8.3,30,99200,1017,1332,381,717,762,135,75900,76800,17100,4130,100,4.6,2,1,12.9,77777,9,999999999,170,0.1370,0,88,999.000,999.0,99.0
+1980,5,22,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,8.3,31,99200,838,1332,371,597,748,127,63900,76000,16000,3200,90,4.6,2,0,12.9,77777,9,999999999,170,0.1370,0,88,999.000,999.0,99.0
+1980,5,22,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,8.9,34,99100,623,1332,369,398,639,101,42100,62600,12800,2110,70,5.7,2,0,19.3,77777,9,999999999,179,0.1370,0,88,999.000,999.0,99.0
+1980,5,22,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,8.3,37,99100,388,1332,358,207,479,70,21700,41900,9500,1310,80,4.6,2,0,24.1,77777,9,999999999,179,0.1370,0,88,999.000,999.0,99.0
+1980,5,22,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,7.8,40,99100,150,1332,349,52,158,35,5500,8700,4500,630,60,3.1,3,0,24.1,77777,9,999999999,170,0.1370,0,88,999.000,999.0,99.0
+1980,5,22,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,6.7,41,99100,3,233,340,1,1,1,0,0,0,0,50,4.1,0,0,24.1,77777,9,999999999,160,0.1370,0,88,999.000,999.0,99.0
+1980,5,22,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,6.7,45,99100,0,0,332,0,0,0,0,0,0,0,60,2.6,0,0,24.1,77777,9,999999999,160,0.1370,0,88,999.000,999.0,99.0
+1980,5,22,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,6.7,50,99100,0,0,325,0,0,0,0,0,0,0,140,3.1,0,0,24.1,77777,9,999999999,160,0.1370,0,88,999.000,999.0,99.0
+1980,5,22,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,5.0,48,99100,0,0,318,0,0,0,0,0,0,0,50,2.6,0,0,24.1,77777,9,999999999,139,0.1370,0,88,999.000,999.0,99.0
+1980,5,22,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,5.6,54,99100,0,0,314,0,0,0,0,0,0,0,50,1.5,0,0,24.1,77777,9,999999999,150,0.1370,0,88,999.000,999.0,99.0
+1980,5,23,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,6.1,62,99000,0,0,307,0,0,0,0,0,0,0,20,2.6,3,0,19.3,77777,9,999999999,150,0.1370,0,88,999.000,999.0,99.0
+1980,5,23,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,6.7,64,99000,0,0,307,0,0,0,0,0,0,0,20,2.1,3,0,19.3,77777,9,999999999,160,0.1370,0,88,999.000,999.0,99.0
+1980,5,23,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,6.1,62,98900,0,0,307,0,0,0,0,0,0,0,30,2.1,3,0,19.3,77777,9,999999999,150,0.1370,0,88,999.000,999.0,99.0
+1980,5,23,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,5.0,55,98900,0,0,324,0,0,0,0,0,0,0,70,2.1,7,4,19.3,7620,9,999999999,139,0.1370,0,88,999.000,999.0,99.0
+1980,5,23,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,5.6,62,98900,34,766,320,14,8,13,1500,400,1500,320,20,2.6,8,4,16.1,77777,9,999999999,150,0.1050,0,88,999.000,999.0,99.0
+1980,5,23,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,7.8,67,98900,242,1332,337,81,99,63,8800,7400,7500,1350,30,1.5,9,7,14.5,3660,9,999999999,170,0.1050,0,88,999.000,999.0,99.0
+1980,5,23,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,8.9,56,98900,482,1332,357,169,77,141,18500,7300,15900,3880,50,3.1,9,7,11.3,3660,9,999999999,179,0.1050,0,88,999.000,999.0,99.0
+1980,5,23,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,9.4,51,98900,711,1332,374,319,164,231,34800,17000,25700,5900,70,3.1,10,8,14.5,3660,9,999999999,189,0.1050,0,88,999.000,999.0,99.0
+1980,5,23,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,9.4,46,98900,914,1332,383,546,379,285,59100,40800,31100,7950,90,4.1,9,8,19.3,7620,9,999999999,189,0.1050,0,88,999.000,999.0,99.0
+1980,5,23,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,10.0,42,98800,1075,1332,395,592,365,296,63200,38100,32400,10980,70,4.6,9,8,19.3,2740,9,999999999,200,0.1050,0,88,999.000,999.0,99.0
+1980,5,23,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,10.0,46,98800,1185,1332,394,358,108,261,40500,11600,30100,11970,70,5.7,10,9,24.1,2740,9,999999999,189,0.1050,0,88,999.000,999.0,99.0
+1980,5,23,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,10.0,53,98700,1236,1332,383,499,106,401,55400,11300,44800,21580,60,5.7,10,9,19.3,2440,9,999999999,189,0.1050,0,88,999.000,999.0,99.0
+1980,5,23,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,10.0,55,98700,1223,1332,390,230,26,206,25600,2600,23200,11170,60,4.6,10,10,12.9,2440,9,999999999,189,0.1050,0,88,999.000,999.0,99.0
+1980,5,23,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,11.1,59,98700,1150,1332,392,364,2,362,42700,200,42500,15960,50,3.6,10,10,11.3,2440,9,999999999,209,0.1050,0,88,999.000,999.0,99.0
+1980,5,23,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,10.0,53,98600,1019,1332,394,300,8,294,35100,700,34600,13200,70,4.6,10,10,11.3,2440,9,999999999,189,0.1050,0,88,999.000,999.0,99.0
+1980,5,23,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,12.2,59,98600,840,1332,400,254,7,250,29300,600,28900,10630,60,4.6,10,10,11.3,1400,9,999999999,220,0.1050,0,88,999.000,999.0,99.0
+1980,5,23,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,14.4,62,98500,626,1332,411,154,3,153,17800,200,17700,6350,80,5.2,10,10,11.3,2440,9,999999999,250,0.1050,0,88,999.000,999.0,99.0
+1980,5,23,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,12.2,63,98500,391,1332,393,86,0,86,9800,0,9800,3300,50,4.6,10,10,11.3,1160,9,999999999,220,0.1050,0,88,999.000,999.0,99.0
+1980,5,23,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,12.2,73,98500,153,1332,381,30,0,30,3400,0,3400,1060,50,4.6,10,10,11.3,2440,9,999999999,220,0.1050,0,88,999.000,999.0,99.0
+1980,5,23,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,11.1,75,98500,4,255,372,1,0,1,0,0,0,0,50,3.6,10,10,12.9,2440,9,999999999,209,0.1050,0,88,999.000,999.0,99.0
+1980,5,23,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,11.1,75,98600,0,0,372,0,0,0,0,0,0,0,50,3.1,10,10,11.3,2440,9,999999999,209,0.1050,0,88,999.000,999.0,99.0
+1980,5,23,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,11.1,81,98500,0,0,343,0,0,0,0,0,0,0,30,3.1,8,7,11.3,2440,9,999999999,209,0.1050,0,88,999.000,999.0,99.0
+1980,5,23,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,11.1,81,98500,0,0,366,0,0,0,0,0,0,0,30,2.1,10,10,11.3,2440,9,999999999,209,0.1050,0,88,999.000,999.0,99.0
+1980,5,23,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,11.7,84,98500,0,0,349,0,0,0,0,0,0,0,30,2.6,10,8,9.7,3660,9,999999999,209,0.1050,0,88,999.000,999.0,99.0
+1980,5,24,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,11.1,81,98500,0,0,366,0,0,0,0,0,0,0,30,2.1,10,10,9.7,460,9,999999999,209,0.1050,0,88,999.000,999.0,99.0
+1980,5,24,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,11.7,84,98400,0,0,366,0,0,0,0,0,0,0,30,2.1,10,10,8.0,340,9,999999999,209,0.1050,0,88,999.000,999.0,99.0
+1980,5,24,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,11.7,87,98400,0,0,364,0,0,0,0,0,0,0,50,2.1,10,10,6.4,2440,9,999999999,209,0.1050,0,88,999.000,999.0,99.0
+1980,5,24,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,12.8,90,98500,0,0,368,0,0,0,0,0,0,0,30,3.6,10,10,4.8,120,9,999999999,229,0.1050,0,88,999.000,999.0,99.0
+1980,5,24,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,13.3,93,98500,36,788,368,14,0,14,1600,0,1600,480,50,2.6,10,10,0.8,60,9,999999999,229,0.0860,0,88,999.000,999.0,99.0
+1980,5,24,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,13.3,93,98500,245,1331,368,65,0,65,7200,0,7200,2200,40,2.6,10,10,0.8,60,9,999999999,229,0.0860,0,88,999.000,999.0,99.0
+1980,5,24,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,13.9,90,98600,484,1331,375,162,1,162,18000,100,18000,5670,30,3.1,10,10,0.8,60,9,999999999,240,0.0860,0,88,999.000,999.0,99.0
+1980,5,24,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,14.4,87,98600,713,1331,382,264,1,264,29700,100,29600,9860,10,2.1,10,10,2.4,610,9,999999999,250,0.0860,0,88,999.000,999.0,99.0
+1980,5,24,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,15.0,84,98600,915,1331,388,348,2,347,39600,200,39500,13830,20,1.5,10,10,3.2,1830,9,999999999,259,0.0860,0,88,999.000,999.0,99.0
+1980,5,24,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,15.0,76,98600,1076,1331,397,381,0,381,44100,0,44100,16120,20,2.1,10,10,4.8,1830,9,999999999,259,0.0860,0,88,999.000,999.0,99.0
+1980,5,24,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,15.6,68,98600,1186,1331,374,865,729,212,92400,74600,25700,10810,30,3.1,4,4,8.0,77777,9,999999999,270,0.0860,0,88,999.000,999.0,99.0
+1980,5,24,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,16.1,62,98600,1237,1331,386,803,647,200,86700,66600,24700,12690,60,4.1,4,4,9.7,77777,9,999999999,279,0.0860,0,88,999.000,999.0,99.0
+1980,5,24,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,16.1,58,98500,1225,1331,388,927,836,157,99100,84800,21000,8910,50,4.1,3,3,9.7,77777,9,999999999,279,0.0860,0,88,999.000,999.0,99.0
+1980,5,24,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,16.1,60,98500,1151,1331,385,811,716,192,87300,73500,23600,8730,50,5.7,7,3,11.3,77777,9,999999999,279,0.0860,0,88,999.000,999.0,99.0
+1980,5,24,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,16.1,62,98400,1020,1331,383,517,344,254,55800,35900,28300,8290,40,5.7,10,3,11.3,77777,9,999999999,279,0.0860,0,88,999.000,999.0,99.0
+1980,5,24,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,16.1,68,98400,842,1331,374,492,457,204,52800,47100,23000,5030,50,4.6,10,3,11.3,77777,9,999999999,279,0.0860,0,88,999.000,999.0,99.0
+1980,5,24,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,16.1,68,98400,628,1331,374,390,518,148,41700,51400,17400,3030,50,5.7,10,3,11.3,77777,9,999999999,279,0.0860,0,88,999.000,999.0,99.0
+1980,5,24,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,16.1,81,98400,394,1331,369,152,153,108,16700,13900,12600,2410,40,4.1,10,6,4.8,7620,9,999999999,279,0.0860,0,88,999.000,999.0,99.0
+1980,5,24,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,14.4,84,98500,156,1331,356,50,61,44,5500,3600,5100,920,30,3.1,10,6,4.8,7620,9,999999999,250,0.0860,0,88,999.000,999.0,99.0
+1980,5,24,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,13.9,93,98500,4,277,354,2,0,2,0,0,0,0,10,1.5,10,8,1.3,150,9,999999999,240,0.0860,0,88,999.000,999.0,99.0
+1980,5,24,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,13.3,90,98600,0,0,354,0,0,0,0,0,0,0,20,3.6,8,8,8.0,2440,9,999999999,240,0.0860,0,88,999.000,999.0,99.0
+1980,5,24,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,12.8,87,98500,0,0,338,0,0,0,0,0,0,0,30,1.5,4,4,9.7,77777,9,999999999,229,0.0860,0,88,999.000,999.0,99.0
+1980,5,24,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,12.2,87,98500,0,0,340,0,0,0,0,0,0,0,10,2.1,6,6,9.7,2440,9,999999999,220,0.0860,0,88,999.000,999.0,99.0
+1980,5,24,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,11.7,84,98500,0,0,328,0,0,0,0,0,0,0,30,2.1,2,2,9.7,77777,9,999999999,209,0.0860,0,88,999.000,999.0,99.0
+1980,5,25,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,11.1,83,98500,0,0,315,0,0,0,0,0,0,0,10,1.5,0,0,11.3,77777,9,999999999,209,0.0860,0,88,999.000,999.0,99.0
+1980,5,25,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,11.1,90,98500,0,0,310,0,0,0,0,0,0,0,320,1.5,0,0,8.0,77777,9,999999999,209,0.0860,0,88,999.000,999.0,99.0
+1980,5,25,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,11.1,90,98500,0,0,331,0,0,0,0,0,0,0,0,0.0,6,6,6.4,2440,9,999999999,209,0.0860,0,88,999.000,999.0,99.0
+1980,5,25,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,12.8,87,98500,0,0,347,0,0,0,0,0,0,0,10,2.6,7,7,6.4,2440,9,999999999,229,0.0860,0,88,999.000,999.0,99.0
+1980,5,25,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,12.2,87,98600,37,788,349,9,3,9,1000,200,1000,230,310,2.1,8,8,4.8,2440,9,999999999,220,0.1370,0,88,999.000,999.0,99.0
+1980,5,25,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,13.3,87,98700,247,1331,364,37,18,34,4100,1400,3900,930,360,2.1,10,9,4.8,2440,9,999999999,240,0.1370,0,88,999.000,999.0,99.0
+1980,5,25,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,13.3,73,98700,486,1331,354,250,363,116,26200,34000,13800,2220,30,3.1,4,4,4.8,77777,9,999999999,240,0.1370,0,88,999.000,999.0,99.0
+1980,5,25,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,13.9,66,98700,715,1331,360,449,581,135,46800,57600,15800,2940,360,2.6,2,2,6.4,77777,9,999999999,250,0.1370,0,88,999.000,999.0,99.0
+1980,5,25,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,14.4,58,98800,916,1331,377,628,654,175,66000,66200,20300,4750,30,3.1,3,3,6.4,77777,9,999999999,250,0.1370,0,88,999.000,999.0,99.0
+1980,5,25,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,15.6,54,98800,1077,1331,387,769,737,170,82600,75700,21100,6360,30,3.1,2,2,8.0,77777,9,999999999,270,0.1370,0,88,999.000,999.0,99.0
+1980,5,25,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,15.6,51,98800,1187,1331,380,882,817,151,94100,82800,20100,7360,30,4.6,0,0,11.3,77777,9,999999999,270,0.1370,0,88,999.000,999.0,99.0
+1980,5,25,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,15.0,47,98800,1238,1331,382,954,856,155,97300,85700,17400,7390,40,3.6,0,0,11.3,77777,9,999999999,259,0.1370,0,88,999.000,999.0,99.0
+1980,5,25,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,12.2,39,98800,1226,1331,379,950,862,154,97000,86300,17400,6900,40,6.2,0,0,14.5,77777,9,999999999,220,0.1370,0,88,999.000,999.0,99.0
+1980,5,25,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,12.8,50,98800,1152,1331,375,799,674,215,85200,68800,25500,9750,50,6.7,6,2,14.5,77777,9,999999999,229,0.1370,0,88,999.000,999.0,99.0
+1980,5,25,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,13.3,54,98800,1022,1331,372,683,584,235,71500,58800,26200,7480,40,6.7,10,2,14.5,77777,9,999999999,240,0.1370,0,88,999.000,999.0,99.0
+1980,5,25,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,11.7,50,98800,844,1331,368,564,537,224,60000,55300,24800,5580,50,5.2,10,2,14.5,77777,9,999999999,220,0.1370,0,88,999.000,999.0,99.0
+1980,5,25,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,10.0,49,98800,631,1331,358,376,498,141,40300,49500,16800,2870,40,7.7,10,2,11.3,77777,9,999999999,189,0.1370,0,88,999.000,999.0,99.0
+1980,5,25,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,8.9,51,98900,396,1331,337,213,498,67,22400,44000,9300,1270,40,5.7,0,0,24.1,77777,9,999999999,179,0.1370,0,88,999.000,999.0,99.0
+1980,5,25,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,7.8,58,99000,159,1331,321,56,189,34,5900,10800,4700,600,30,5.7,0,0,24.1,77777,9,999999999,170,0.1370,0,88,999.000,999.0,99.0
+1980,5,25,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,6.1,60,99000,5,299,309,2,2,1,0,0,0,0,30,3.1,0,0,24.1,77777,9,999999999,150,0.1370,0,88,999.000,999.0,99.0
+1980,5,25,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,5.6,64,99000,0,0,302,0,0,0,0,0,0,0,40,4.1,0,0,24.1,77777,9,999999999,150,0.1370,0,88,999.000,999.0,99.0
+1980,5,25,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,5.6,64,99100,0,0,302,0,0,0,0,0,0,0,40,4.1,0,0,24.1,77777,9,999999999,150,0.1370,0,88,999.000,999.0,99.0
+1980,5,25,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,5.0,64,99100,0,0,299,0,0,0,0,0,0,0,50,3.6,0,0,24.1,77777,9,999999999,139,0.1370,0,88,999.000,999.0,99.0
+1980,5,25,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,5.0,64,99100,0,0,299,0,0,0,0,0,0,0,50,3.1,0,0,24.1,77777,9,999999999,139,0.1370,0,88,999.000,999.0,99.0
+1980,5,26,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,4.4,66,99200,0,0,294,0,0,0,0,0,0,0,40,3.1,0,0,24.1,77777,9,999999999,139,0.1370,0,88,999.000,999.0,99.0
+1980,5,26,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,3.3,61,99200,0,0,293,0,0,0,0,0,0,0,50,3.1,0,0,24.1,77777,9,999999999,129,0.1370,0,88,999.000,999.0,99.0
+1980,5,26,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,1.1,49,99300,0,0,295,0,0,0,0,0,0,0,50,3.1,0,0,24.1,77777,9,999999999,120,0.1370,0,88,999.000,999.0,99.0
+1980,5,26,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,2.2,59,99300,0,0,289,0,0,0,0,0,0,0,40,3.1,0,0,24.1,77777,9,999999999,120,0.1370,0,88,999.000,999.0,99.0
+1980,5,26,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,3.3,68,99400,38,809,286,14,3,14,1600,0,1600,490,50,2.6,0,0,24.1,77777,9,999999999,129,0.2850,0,88,999.000,999.0,99.0
+1980,5,26,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,4.4,62,99400,249,1331,298,96,162,65,10100,11700,7900,1220,70,3.1,0,0,24.1,77777,9,999999999,139,0.2850,0,88,999.000,999.0,99.0
+1980,5,26,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,3.3,48,99500,488,1331,309,265,402,117,27900,37700,14000,2240,70,4.1,0,0,24.1,77777,9,999999999,129,0.2850,0,88,999.000,999.0,99.0
+1980,5,26,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,1.7,37,99500,716,1331,317,462,551,164,49300,55800,19200,3560,70,5.2,0,0,24.1,77777,9,999999999,120,0.2850,0,88,999.000,999.0,99.0
+1980,5,26,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,1.7,32,99600,917,1331,327,651,650,201,67800,65300,22700,5360,90,3.1,0,0,24.1,77777,9,999999999,120,0.2850,0,88,999.000,999.0,99.0
+1980,5,26,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,1.1,29,99600,1078,1331,331,800,705,226,84200,71500,26100,8270,90,5.7,0,0,24.1,77777,9,999999999,120,0.2850,0,88,999.000,999.0,99.0
+1980,5,26,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,2.2,31,99600,1188,1331,332,904,738,243,95800,75100,28600,12410,60,4.1,0,0,24.1,77777,9,999999999,120,0.2850,0,88,999.000,999.0,99.0
+1980,5,26,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,2.2,29,99600,1239,1331,337,952,753,249,101300,76700,29700,15840,70,5.2,0,0,24.1,77777,9,999999999,120,0.2850,0,88,999.000,999.0,99.0
+1980,5,26,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,1.7,27,99500,1227,1331,339,940,750,247,100000,76400,29400,14840,50,3.6,0,0,24.1,77777,9,999999999,120,0.2850,0,88,999.000,999.0,99.0
+1980,5,26,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,1.7,25,99500,1154,1331,344,870,730,237,92200,74200,27800,10720,70,5.2,0,0,24.1,77777,9,999999999,120,0.2850,0,88,999.000,999.0,99.0
+1980,5,26,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,0.0,23,99500,1024,1331,340,747,689,217,78600,69700,24900,7010,50,3.6,0,0,24.1,77777,9,999999999,110,0.2850,0,88,999.000,999.0,99.0
+1980,5,26,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,1.7,28,99500,846,1331,337,578,616,187,60200,61500,21000,4530,50,5.2,0,0,24.1,77777,9,999999999,120,0.2850,0,88,999.000,999.0,99.0
+1980,5,26,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,1.1,29,99400,633,1331,337,325,315,176,35100,32400,19700,3830,50,5.2,4,1,24.1,77777,9,999999999,120,0.2850,0,88,999.000,999.0,99.0
+1980,5,26,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,0.0,29,99400,399,1331,322,201,270,121,21300,24300,14000,2440,60,4.1,8,0,24.1,77777,9,999999999,110,0.2850,0,88,999.000,999.0,99.0
+1980,5,26,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,-0.6,34,99400,162,1331,315,51,22,48,5500,1500,5400,1120,50,4.1,8,1,24.1,77777,9,999999999,110,0.2850,0,88,999.000,999.0,99.0
+1980,5,26,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,-2.2,33,99500,6,322,306,1,0,1,0,0,0,0,50,4.1,5,1,24.1,77777,9,999999999,89,0.2850,0,88,999.000,999.0,99.0
+1980,5,26,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,-1.1,41,99600,0,0,293,0,0,0,0,0,0,0,50,2.6,3,0,24.1,77777,9,999999999,100,0.2850,0,88,999.000,999.0,99.0
+1980,5,26,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,-0.6,43,99500,0,0,293,0,0,0,0,0,0,0,60,2.6,0,0,24.1,77777,9,999999999,100,0.2850,0,88,999.000,999.0,99.0
+1980,5,26,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,0.6,52,99500,0,0,287,0,0,0,0,0,0,0,10,2.1,0,0,24.1,77777,9,999999999,110,0.2850,0,88,999.000,999.0,99.0
+1980,5,26,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,1.1,56,99500,0,0,286,0,0,0,0,0,0,0,30,2.1,0,0,24.1,77777,9,999999999,110,0.2850,0,88,999.000,999.0,99.0
+1980,5,27,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,1.1,56,99500,0,0,286,0,0,0,0,0,0,0,20,2.1,0,0,24.1,77777,9,999999999,110,0.2850,0,88,999.000,999.0,99.0
+1980,5,27,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,1.7,71,99400,0,0,275,0,0,0,0,0,0,0,20,2.1,0,0,24.1,77777,9,999999999,120,0.2850,0,88,999.000,999.0,99.0
+1980,5,27,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,2.2,71,99500,0,0,278,0,0,0,0,0,0,0,20,1.0,0,0,24.1,77777,9,999999999,120,0.2850,0,88,999.000,999.0,99.0
+1980,5,27,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,2.8,83,99500,0,0,277,0,0,0,0,0,0,0,0,0.0,5,1,24.1,77777,9,999999999,129,0.2850,0,88,999.000,999.0,99.0
+1980,5,27,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,2.8,79,99500,40,831,283,14,17,12,1500,700,1400,250,0,0.0,5,2,24.1,77777,9,999999999,129,0.1550,0,88,999.000,999.0,99.0
+1980,5,27,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,6.7,77,99600,251,1330,302,109,292,54,11500,21300,7500,970,160,2.1,3,1,24.1,77777,9,999999999,160,0.1550,0,88,999.000,999.0,99.0
+1980,5,27,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,7.8,56,99600,489,1330,338,244,292,136,26000,28200,15600,2770,170,2.1,8,3,19.3,77777,9,999999999,170,0.1550,0,88,999.000,999.0,99.0
+1980,5,27,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,7.2,47,99600,717,1330,353,386,319,213,41500,33500,23400,4940,190,3.6,10,5,19.3,77777,9,999999999,170,0.1550,0,88,999.000,999.0,99.0
+1980,5,27,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,7.2,42,99600,919,1330,364,515,383,249,54600,39700,27200,6870,170,4.6,10,6,24.1,7620,9,999999999,160,0.1550,0,88,999.000,999.0,99.0
+1980,5,27,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,7.2,36,99600,1079,1330,369,737,572,271,79500,59700,30900,10130,190,4.6,9,3,24.1,77777,9,999999999,170,0.1550,0,88,999.000,999.0,99.0
+1980,5,27,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,8.3,35,99500,1189,1330,375,878,719,233,93300,73300,27600,11990,190,4.1,6,2,24.1,77777,9,999999999,179,0.1550,0,88,999.000,999.0,99.0
+1980,5,27,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,8.3,31,99500,1240,1330,378,915,797,169,97000,80600,21700,10280,180,4.6,3,1,24.1,77777,9,999999999,170,0.1550,0,88,999.000,999.0,99.0
+1980,5,27,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,7.2,27,99400,1228,1330,382,891,787,163,94900,79700,21200,9400,170,3.1,3,1,24.1,77777,9,999999999,160,0.1550,0,88,999.000,999.0,99.0
+1980,5,27,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,7.2,26,99300,1155,1330,385,824,730,189,88700,75000,23400,8740,200,4.1,7,1,24.1,77777,9,999999999,160,0.1550,0,88,999.000,999.0,99.0
+1980,5,27,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,7.2,26,99300,1025,1330,393,698,585,247,75600,61000,28400,8140,170,4.6,8,2,24.1,77777,9,999999999,170,0.1550,0,88,999.000,999.0,99.0
+1980,5,27,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,6.7,24,99200,848,1330,390,573,627,174,60000,62900,19900,4270,120,2.6,8,1,24.1,77777,9,999999999,160,0.1550,0,88,999.000,999.0,99.0
+1980,5,27,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,7.2,26,99200,635,1330,388,405,617,112,42600,60400,13700,2330,140,3.1,4,1,24.1,77777,9,999999999,170,0.1550,0,88,999.000,999.0,99.0
+1980,5,27,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,7.8,29,99200,402,1330,380,197,387,82,21200,34400,10800,1500,170,4.1,4,1,24.1,77777,9,999999999,170,0.1550,0,88,999.000,999.0,99.0
+1980,5,27,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,6.1,32,99200,165,1330,362,52,136,36,5600,7600,4700,640,150,3.1,4,1,24.1,77777,9,999999999,150,0.1550,0,88,999.000,999.0,99.0
+1980,5,27,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,6.7,39,99200,6,344,357,1,1,0,0,0,0,0,120,3.6,3,3,24.1,77777,9,999999999,160,0.1550,0,88,999.000,999.0,99.0
+1980,5,27,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,6.1,43,99200,0,0,332,0,0,0,0,0,0,0,120,4.1,2,0,24.1,77777,9,999999999,150,0.1550,0,88,999.000,999.0,99.0
+1980,5,27,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,7.2,49,99200,0,0,330,0,0,0,0,0,0,0,140,2.1,2,0,24.1,77777,9,999999999,170,0.1550,0,88,999.000,999.0,99.0
+1980,5,27,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,7.8,60,99200,0,0,329,0,0,0,0,0,0,0,150,2.1,2,2,16.1,77777,9,999999999,170,0.1550,0,88,999.000,999.0,99.0
+1980,5,27,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,6.1,52,99200,0,0,325,0,0,0,0,0,0,0,150,3.6,1,1,24.1,77777,9,999999999,150,0.1550,0,88,999.000,999.0,99.0
+1980,5,28,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,5.0,48,99200,0,0,328,0,0,0,0,0,0,0,150,3.1,4,2,24.1,77777,9,999999999,139,0.1550,0,88,999.000,999.0,99.0
+1980,5,28,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,6.1,52,99200,0,0,333,0,0,0,0,0,0,0,170,2.1,7,3,19.3,77777,9,999999999,150,0.1550,0,88,999.000,999.0,99.0
+1980,5,28,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,7.2,56,99200,0,0,334,0,0,0,0,0,0,0,170,2.6,9,3,19.3,77777,9,999999999,170,0.1550,0,88,999.000,999.0,99.0
+1980,5,28,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,8.9,63,99300,0,0,336,0,0,0,0,0,0,0,150,2.6,9,3,19.3,77777,9,999999999,179,0.1550,0,88,999.000,999.0,99.0
+1980,5,28,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,10.0,67,99300,41,831,337,17,22,15,1800,900,1800,310,160,2.6,9,3,24.1,77777,9,999999999,189,0.0910,0,88,999.000,999.0,99.0
+1980,5,28,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,11.7,63,99300,253,1330,352,117,267,66,12100,19500,8400,1210,180,3.6,8,3,24.1,77777,9,999999999,220,0.0910,0,88,999.000,999.0,99.0
+1980,5,28,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,12.8,57,99300,491,1330,367,251,353,120,26300,33200,14100,2310,180,3.1,8,3,24.1,77777,9,999999999,229,0.0910,0,88,999.000,999.0,99.0
+1980,5,28,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,12.8,53,99300,718,1330,369,461,630,119,48500,62900,14500,2650,180,5.2,6,2,24.1,77777,9,999999999,229,0.0910,0,88,999.000,999.0,99.0
+1980,5,28,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,13.3,50,99300,919,1330,378,612,672,145,65200,68600,17700,4050,180,5.2,5,2,24.1,77777,9,999999999,240,0.0910,0,88,999.000,999.0,99.0
+1980,5,28,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,15.0,47,99200,1080,1330,395,693,626,183,74100,64100,21900,6870,190,5.2,5,2,24.1,77777,9,999999999,259,0.0910,0,88,999.000,999.0,99.0
+1980,5,28,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,15.0,44,99200,1190,1330,404,817,606,273,85900,61300,31000,13940,170,5.2,7,3,24.1,77777,9,999999999,259,0.0910,0,88,999.000,999.0,99.0
+1980,5,28,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,15.6,43,99200,1240,1330,455,402,11,392,47600,1000,46600,17270,190,5.2,10,10,12.9,1400,9,999999999,270,0.0910,0,88,999.000,999.0,99.0
+1980,5,28,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,18.3,79,99200,1229,1330,416,308,12,297,37100,1000,36200,14060,350,3.1,10,10,12.9,1370,9,999999999,320,0.0910,0,88,999.000,999.0,99.0
+1980,5,28,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,17.2,58,99100,1156,1330,425,465,119,361,51500,12700,40400,15480,60,2.6,10,9,16.1,1830,9,999999999,300,0.0910,0,88,999.000,999.0,99.0
+1980,5,28,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,15.6,54,99000,1027,1330,405,644,537,230,70300,56100,26900,7580,60,6.7,8,7,16.1,6100,9,999999999,270,0.0910,0,88,999.000,999.0,99.0
+1980,5,28,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,17.2,90,99100,850,1330,397,157,2,156,18800,200,18700,7450,20,1.5,10,10,8.0,760,9,999999999,300,0.0910,0,88,999.000,999.0,99.0
+1980,5,28,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,17.8,87,99200,637,1330,404,93,2,93,11300,100,11200,4280,90,4.1,10,10,9.7,760,9,999999999,309,0.0910,0,88,999.000,999.0,99.0
+1980,5,28,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,17.8,87,99100,404,1330,404,58,5,56,6800,200,6800,2370,90,4.1,10,10,9.7,760,9,999999999,309,0.0910,0,88,999.000,999.0,99.0
+1980,5,28,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,17.2,81,99000,167,1330,406,45,3,44,4900,0,4900,1440,110,5.2,10,10,8.0,1680,9,999999999,300,0.0910,0,88,999.000,999.0,99.0
+1980,5,28,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,17.8,97,99100,7,366,394,2,0,2,0,0,0,0,260,2.1,10,10,4.8,460,9,999999999,309,0.0910,0,88,999.000,999.0,99.0
+1980,5,28,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,18.3,97,99100,0,0,398,0,0,0,0,0,0,0,150,4.1,10,10,4.8,760,9,999999999,320,0.0910,0,88,999.000,999.0,99.0
+1980,5,28,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,18.3,100,98900,0,0,395,0,0,0,0,0,0,0,160,5.2,10,10,4.8,610,9,999999999,320,0.0910,0,88,999.000,999.0,99.0
+1980,5,28,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,17.2,93,99000,0,0,394,0,0,0,0,0,0,0,160,4.1,10,10,8.0,1830,9,999999999,300,0.0910,0,88,999.000,999.0,99.0
+1980,5,28,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,16.7,84,99000,0,0,363,0,0,0,0,0,0,0,160,4.1,9,4,9.7,77777,9,999999999,290,0.0910,0,88,999.000,999.0,99.0
+1980,5,29,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,16.1,87,98900,0,0,351,0,0,0,0,0,0,0,160,2.6,2,2,16.1,77777,9,999999999,279,0.0910,0,88,999.000,999.0,99.0
+1980,5,29,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,15.6,90,99000,0,0,375,0,0,0,0,0,0,0,320,4.6,9,9,12.9,1520,9,999999999,270,0.0910,0,88,999.000,999.0,99.0
+1980,5,29,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,15.6,90,98900,0,0,375,0,0,0,0,0,0,0,150,3.6,9,9,9.7,1520,9,999999999,270,0.0910,0,88,999.000,999.0,99.0
+1980,5,29,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,16.1,93,98900,0,0,386,0,0,0,0,0,0,0,280,1.5,10,10,8.0,1520,9,999999999,279,0.0910,0,88,999.000,999.0,99.0
+1980,5,29,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,16.1,90,98900,42,853,390,11,0,11,1300,0,1300,400,300,1.5,10,10,6.4,3660,9,999999999,279,0.1960,0,88,999.000,999.0,99.0
+1980,5,29,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,16.7,93,98900,255,1329,390,58,1,58,6600,0,6600,2070,120,2.6,10,10,6.4,3050,9,999999999,290,0.1960,0,88,999.000,999.0,99.0
+1980,5,29,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,17.2,87,98900,492,1329,400,84,0,84,9900,0,9900,3560,120,3.1,10,10,6.4,1520,9,999999999,300,0.1960,0,88,999.000,999.0,99.0
+1980,5,29,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,17.8,87,98900,720,1329,404,256,0,255,28700,0,28700,9740,140,3.6,10,10,4.8,2130,9,999999999,309,0.1960,0,88,999.000,999.0,99.0
+1980,5,29,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,16.7,71,98900,920,1329,414,309,0,308,35400,0,35400,12920,150,4.1,10,10,4.8,2130,9,999999999,290,0.1960,0,88,999.000,999.0,99.0
+1980,5,29,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,18.3,71,98800,1081,1329,388,646,383,333,70700,41600,36800,12090,120,3.6,10,4,6.4,77777,9,999999999,320,0.1960,0,88,999.000,999.0,99.0
+1980,5,29,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,18.3,64,98700,1190,1329,385,885,755,206,94900,77400,25400,10780,150,4.6,4,1,4.8,77777,9,999999999,320,0.1960,0,88,999.000,999.0,99.0
+1980,5,29,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,19.4,65,98700,1241,1329,401,821,566,292,86500,57200,33000,18750,210,3.6,8,3,8.0,77777,9,999999999,340,0.1960,0,88,999.000,999.0,99.0
+1980,5,29,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,19.4,63,98600,1230,1329,425,560,149,422,61900,15900,47100,22440,180,5.7,10,8,9.7,1070,9,999999999,340,0.1960,0,88,999.000,999.0,99.0
+1980,5,29,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,16.7,81,98700,1157,1329,402,256,3,254,31000,200,30800,12280,320,9.8,10,10,1.3,760,9,999999999,290,0.1960,0,88,999.000,999.0,99.0
+1980,5,29,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,16.7,84,98600,1028,1329,399,172,27,151,19100,2700,17000,6420,180,1.5,10,10,9.7,2130,9,999999999,290,0.1960,0,88,999.000,999.0,99.0
+1980,5,29,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,16.7,79,98500,852,1329,386,461,269,289,49500,28700,31100,7680,160,9.3,9,8,16.1,2440,9,999999999,290,0.1960,0,88,999.000,999.0,99.0
+1980,5,29,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,16.1,76,98400,640,1329,385,244,113,190,26800,11500,21200,4670,180,2.1,9,8,19.3,2440,9,999999999,279,0.1960,0,88,999.000,999.0,99.0
+1980,5,29,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,16.7,73,98300,407,1329,372,197,302,106,21200,27500,12800,2080,30,2.6,8,3,19.3,77777,9,999999999,290,0.1960,0,88,999.000,999.0,99.0
+1980,5,29,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,15.6,71,98400,170,1329,359,48,86,38,5200,4900,4600,680,310,1.5,3,1,24.1,77777,9,999999999,270,0.1960,0,88,999.000,999.0,99.0
+1980,5,29,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,16.7,87,98400,8,366,355,1,1,1,0,0,0,0,120,3.1,2,2,24.1,77777,9,999999999,290,0.1960,0,88,999.000,999.0,99.0
+1980,5,29,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,15.6,78,98600,0,0,356,0,0,0,0,0,0,0,130,3.1,2,2,24.1,77777,9,999999999,270,0.1960,0,88,999.000,999.0,99.0
+1980,5,29,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,16.1,84,98600,0,0,354,0,0,0,0,0,0,0,120,2.1,2,2,24.1,77777,9,999999999,279,0.1960,0,88,999.000,999.0,99.0
+1980,5,29,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,15.6,84,98500,0,0,339,0,0,0,0,0,0,0,160,3.1,2,0,19.3,77777,9,999999999,270,0.1960,0,88,999.000,999.0,99.0
+1980,5,29,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,16.1,78,98400,0,0,348,0,0,0,0,0,0,0,170,4.6,0,0,24.1,77777,9,999999999,279,0.1960,0,88,999.000,999.0,99.0
+1980,5,30,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,16.1,78,98400,0,0,348,0,0,0,0,0,0,0,160,4.6,0,0,24.1,77777,9,999999999,279,0.1960,0,88,999.000,999.0,99.0
+1980,5,30,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,16.1,81,98400,0,0,345,0,0,0,0,0,0,0,150,4.6,0,0,14.5,77777,9,999999999,279,0.1960,0,88,999.000,999.0,99.0
+1980,5,30,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,16.7,87,98300,0,0,343,0,0,0,0,0,0,0,160,5.2,0,0,8.0,77777,9,999999999,290,0.1960,0,88,999.000,999.0,99.0
+1980,5,30,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,16.7,87,98300,0,0,377,0,0,0,0,0,0,0,150,4.6,8,8,6.4,240,9,999999999,290,0.1960,0,88,999.000,999.0,99.0
+1980,5,30,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,17.8,90,98300,43,853,381,18,2,18,2000,0,2000,600,170,6.7,8,8,3.2,210,9,999999999,300,0.1340,0,88,999.000,999.0,99.0
+1980,5,30,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,18.3,87,98300,256,1329,408,46,3,46,5400,100,5300,1740,170,5.2,10,10,6.4,310,9,999999999,320,0.1340,0,88,999.000,999.0,99.0
+1980,5,30,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,18.9,87,98400,494,1329,411,88,12,83,10300,700,10000,3530,170,5.2,10,10,4.0,370,9,999999999,329,0.1340,0,88,999.000,999.0,99.0
+1980,5,30,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,19.4,90,98300,721,1329,412,203,2,202,23300,200,23200,8380,150,5.2,10,10,6.4,1520,9,999999999,340,0.1340,0,88,999.000,999.0,99.0
+1980,5,30,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,20.6,84,98300,921,1329,414,375,76,323,41400,7800,36000,11260,150,7.2,9,9,8.0,1520,9,999999999,359,0.1340,0,88,999.000,999.0,99.0
+1980,5,30,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,20.6,87,98300,1082,1329,423,405,20,389,46900,1900,45300,16380,180,4.6,10,10,9.7,1520,9,999999999,359,0.1340,0,88,999.000,999.0,99.0
+1980,5,30,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,17.8,79,98100,1191,1329,402,382,194,208,44000,21200,24900,9680,170,6.7,9,9,11.3,1520,9,999999999,309,0.1340,0,88,999.000,999.0,99.0
+1980,5,30,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,16.7,69,98200,1242,1329,381,964,779,234,103100,79600,28500,15320,160,7.7,5,4,24.1,77777,9,999999999,290,0.1340,0,88,999.000,999.0,99.0
+1980,5,30,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,19.4,69,98100,1231,1329,399,810,553,296,88400,58000,34600,18620,160,8.2,5,4,24.1,77777,9,999999999,340,0.1340,0,88,999.000,999.0,99.0
+1980,5,30,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,18.3,56,98000,1158,1329,412,751,574,250,79300,58200,28500,11500,160,9.3,6,5,24.1,1520,9,999999999,309,0.1340,0,88,999.000,999.0,99.0
+1980,5,30,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,18.3,56,97900,1030,1329,416,500,321,251,54000,33500,28000,8380,160,9.8,6,6,24.1,1520,9,999999999,309,0.1340,0,88,999.000,999.0,99.0
+1980,5,30,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,18.9,53,97800,853,1329,437,353,142,262,38900,15000,29200,7390,170,10.8,8,8,16.1,1520,9,999999999,320,0.1340,0,88,999.000,999.0,99.0
+1980,5,30,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,19.4,59,97700,642,1329,425,274,158,199,30100,16100,22300,4900,190,11.8,7,7,16.1,1520,9,999999999,340,0.1340,0,88,999.000,999.0,99.0
+1980,5,30,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,16.1,52,97900,409,1329,400,202,378,87,21600,33800,11200,1610,240,8.8,4,4,24.1,77777,9,999999999,270,0.1340,0,88,999.000,999.0,99.0
+1980,5,30,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,13.9,54,98100,173,1329,380,61,184,38,6500,11000,5100,680,240,10.3,3,3,24.1,77777,9,999999999,240,0.1340,0,88,999.000,999.0,99.0
+1980,5,30,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,12.8,53,98100,8,388,364,2,3,1,0,0,0,0,240,9.3,1,1,24.1,77777,9,999999999,229,0.1340,0,88,999.000,999.0,99.0
+1980,5,30,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,12.8,57,98300,0,0,352,0,0,0,0,0,0,0,260,6.2,0,0,24.1,77777,9,999999999,229,0.1340,0,88,999.000,999.0,99.0
+1980,5,30,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,13.3,61,98300,0,0,350,0,0,0,0,0,0,0,230,8.2,0,0,24.1,77777,9,999999999,229,0.1340,0,88,999.000,999.0,99.0
+1980,5,30,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,13.9,66,98300,0,0,348,0,0,0,0,0,0,0,220,5.7,0,0,24.1,77777,9,999999999,240,0.1340,0,88,999.000,999.0,99.0
+1980,5,30,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,13.9,68,98300,0,0,345,0,0,0,0,0,0,0,220,5.2,0,0,24.1,77777,9,999999999,240,0.1340,0,88,999.000,999.0,99.0
+1980,5,31,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,13.9,70,98400,0,0,360,0,0,0,0,0,0,0,210,4.6,4,4,24.1,77777,9,999999999,240,0.1340,0,88,999.000,999.0,99.0
+1980,5,31,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,14.4,76,98400,0,0,347,0,0,0,0,0,0,0,240,4.6,1,1,24.1,77777,9,999999999,250,0.1340,0,88,999.000,999.0,99.0
+1980,5,31,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,14.4,81,98500,0,0,369,0,0,0,0,0,0,0,280,4.6,8,8,24.1,2440,9,999999999,250,0.1340,0,88,999.000,999.0,99.0
+1980,5,31,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,13.3,75,98700,0,0,358,0,0,0,0,0,0,0,320,5.2,6,6,24.1,2440,9,999999999,240,0.1340,0,88,999.000,999.0,99.0
+1980,5,31,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,12.2,78,98800,44,874,336,13,5,13,1500,300,1400,330,290,3.1,2,2,24.1,77777,9,999999999,220,0.2560,0,88,999.000,999.0,99.0
+1980,5,31,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,13.3,81,98900,258,1328,329,103,195,65,10900,14400,8100,1220,280,3.6,0,0,24.1,77777,9,999999999,240,0.2560,0,88,999.000,999.0,99.0
+1980,5,31,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,13.9,73,99000,495,1328,340,271,425,112,28700,40100,13700,2140,300,5.2,0,0,24.1,77777,9,999999999,250,0.2560,0,88,999.000,999.0,99.0
+1980,5,31,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,13.9,68,99000,721,1328,345,464,567,155,48000,55900,17600,3330,290,6.2,0,0,24.1,77777,9,999999999,240,0.2560,0,88,999.000,999.0,99.0
+1980,5,31,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,13.3,61,99100,922,1328,350,645,656,188,67600,66200,21500,5120,280,6.2,0,0,24.1,77777,9,999999999,240,0.2560,0,88,999.000,999.0,99.0
+1980,5,31,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,13.3,55,99100,1082,1328,358,797,715,211,84200,72800,24800,7880,310,4.1,0,0,24.1,77777,9,999999999,240,0.2560,0,88,999.000,999.0,99.0
+1980,5,31,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,11.7,48,99100,1192,1328,359,901,749,226,95900,76500,27200,11850,290,5.7,0,0,24.1,77777,9,999999999,209,0.2560,0,88,999.000,999.0,99.0
+1980,5,31,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,11.7,46,99100,1243,1328,362,942,756,233,100800,77300,28300,15340,350,5.7,0,0,24.1,77777,9,999999999,209,0.2560,0,88,999.000,999.0,99.0
+1980,5,31,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,12.2,47,99100,1232,1328,365,930,746,236,99200,76200,28400,14690,320,3.6,1,0,24.1,77777,9,999999999,220,0.2560,0,88,999.000,999.0,99.0
+1980,5,31,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,11.1,42,99100,1159,1328,382,817,623,272,85700,62900,30700,12480,260,5.2,3,3,24.1,77777,9,999999999,209,0.2560,0,88,999.000,999.0,99.0
+1980,5,31,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,10.6,40,99100,1031,1328,381,702,592,242,73300,59600,27000,7860,320,3.6,3,3,24.1,77777,9,999999999,200,0.2560,0,88,999.000,999.0,99.0
+1980,5,31,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,10.6,40,99100,855,1328,378,562,469,261,59000,48200,27900,6700,320,2.1,8,2,24.1,77777,9,999999999,200,0.2560,0,88,999.000,999.0,99.0
+1980,5,31,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,11.1,43,99100,644,1328,379,372,365,196,39900,37600,21600,4370,310,2.6,10,3,24.1,77777,9,999999999,209,0.2560,0,88,999.000,999.0,99.0
+1980,5,31,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,12.8,53,99100,412,1328,387,102,61,83,11400,5700,9600,1860,340,2.1,10,7,24.1,7620,9,999999999,229,0.2560,0,88,999.000,999.0,99.0
+1980,5,31,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,10.0,49,99100,176,1328,380,45,5,44,5000,0,5000,1470,70,4.1,10,8,24.1,7620,9,999999999,189,0.2560,0,88,999.000,999.0,99.0
+1980,5,31,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,8.9,49,99100,9,410,381,2,0,2,0,0,0,0,70,5.7,10,9,24.1,7620,9,999999999,179,0.2560,0,88,999.000,999.0,99.0
+1980,5,31,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,10.0,61,99000,0,0,371,0,0,0,0,0,0,0,70,3.6,10,9,24.1,7620,9,999999999,200,0.2560,0,88,999.000,999.0,99.0
+1980,5,31,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.9,10.7,70,99000,0,0,373,0,0,0,0,0,0,0,60,3.7,10,9,24.1,7620,9,999999999,200,0.2560,0,88,999.000,999.0,99.0
+1980,5,31,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.9,11.4,72,99000,0,0,384,0,0,0,0,0,0,0,50,3.7,10,10,24.1,7620,9,999999999,200,0.2560,0,88,999.000,999.0,99.0
+1980,5,31,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.0,12.1,75,99000,0,0,375,0,0,0,0,0,0,0,60,3.8,10,9,24.1,7620,9,999999999,200,0.2560,0,88,999.000,999.0,99.0
+1979,6,1,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.1,12.9,84,99200,0,0,387,0,0,0,0,0,0,0,290,3.9,10,10,4.8,210,9,999999999,300,0.2560,0,88,999.000,999.0,99.0
+1979,6,1,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.2,13.6,87,99200,0,0,389,0,0,0,0,0,0,0,270,4.0,10,10,4.8,270,9,999999999,300,0.2560,0,88,999.000,999.0,99.0
+1979,6,1,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.2,14.3,84,99200,0,0,389,0,0,0,0,0,0,0,280,4.0,10,10,6.4,270,9,999999999,279,0.2560,0,88,999.000,999.0,99.0
+1979,6,1,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,15.0,81,99300,0,0,391,0,0,0,0,0,0,0,290,4.1,10,10,8.0,240,9,999999999,259,0.2560,0,88,999.000,999.0,99.0
+1979,6,1,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,14.4,81,99400,45,874,387,11,1,11,1300,0,1300,400,300,3.6,10,10,8.0,310,9,999999999,250,0.0950,0,88,999.000,999.0,99.0
+1979,6,1,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,12.8,81,99400,258,1328,376,47,2,47,5400,0,5400,1770,330,6.7,10,10,12.9,310,9,999999999,229,0.0950,0,88,999.000,999.0,99.0
+1979,6,1,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,11.7,78,99500,495,1328,373,103,1,103,12000,100,11900,4210,320,7.2,10,10,24.1,400,9,999999999,220,0.0950,0,88,999.000,999.0,99.0
+1979,6,1,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,11.7,73,99600,722,1328,354,350,185,249,38000,19100,27600,6410,310,5.2,10,7,24.1,460,9,999999999,220,0.0950,0,88,999.000,999.0,99.0
+1979,6,1,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,11.7,63,99600,922,1328,344,642,711,146,68400,72600,17900,4100,330,5.7,8,1,24.1,77777,9,999999999,220,0.0950,0,88,999.000,999.0,99.0
+1979,6,1,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,15.6,76,99600,1083,1328,354,808,796,156,84700,80100,19200,5420,350,4.1,7,1,24.1,77777,9,999999999,270,0.0950,0,88,999.000,999.0,99.0
+1979,6,1,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,9.4,47,99600,1192,1328,352,881,814,148,94300,82600,20000,7450,330,5.7,6,1,24.1,77777,9,999999999,189,0.0950,0,88,999.000,999.0,99.0
+1979,6,1,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,8.3,41,99600,1243,1328,361,909,763,193,95200,76700,23300,11800,320,4.1,5,2,24.1,77777,9,999999999,179,0.0950,0,88,999.000,999.0,99.0
+1979,6,1,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,8.3,38,99600,1232,1328,366,708,534,211,76100,54800,25200,13230,10,7.2,4,2,24.1,77777,9,999999999,170,0.0950,0,88,999.000,999.0,99.0
+1979,6,1,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,8.9,40,99600,1160,1328,374,794,646,228,84300,65800,26700,10630,300,4.1,8,4,24.1,77777,9,999999999,179,0.0950,0,88,999.000,999.0,99.0
+1979,6,1,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,8.3,37,99600,1031,1328,369,760,798,141,80300,80400,17800,4430,310,5.2,4,2,24.1,77777,9,999999999,179,0.0950,0,88,999.000,999.0,99.0
+1979,6,1,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,7.8,33,99600,856,1328,369,589,732,119,61900,73100,14700,2850,320,3.1,3,1,24.1,77777,9,999999999,170,0.0950,0,88,999.000,999.0,99.0
+1979,6,1,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,6.1,32,99600,644,1328,362,408,673,83,42900,65800,11000,1770,30,3.1,2,1,24.1,77777,9,999999999,150,0.0950,0,88,999.000,999.0,99.0
+1979,6,1,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,7.8,38,99600,412,1328,352,239,598,57,25600,53900,8900,1120,0,0.0,0,0,24.1,77777,9,999999999,170,0.0950,0,88,999.000,999.0,99.0
+1979,6,1,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,7.8,44,99600,176,1328,341,71,293,33,7300,18800,4900,590,110,3.1,1,0,24.1,77777,9,999999999,170,0.0950,0,88,999.000,999.0,99.0
+1979,6,1,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,6.7,50,99600,9,410,339,5,5,4,0,0,0,0,100,3.6,3,3,24.1,77777,9,999999999,160,0.0950,0,88,999.000,999.0,99.0
+1979,6,1,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,5.6,57,99600,0,0,322,0,0,0,0,0,0,0,140,3.1,3,3,19.3,77777,9,999999999,150,0.0950,0,88,999.000,999.0,99.0
+1979,6,1,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,5.6,64,99600,0,0,302,0,0,0,0,0,0,0,150,2.6,1,0,19.3,77777,9,999999999,150,0.0950,0,88,999.000,999.0,99.0
+1979,6,1,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,7.8,72,99600,0,0,337,0,0,0,0,0,0,0,180,1.5,8,8,19.3,3660,9,999999999,170,0.0950,0,88,999.000,999.0,99.0
+1979,6,1,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,7.8,69,99600,0,0,330,0,0,0,0,0,0,0,180,3.1,6,6,16.1,3660,9,999999999,170,0.0950,0,88,999.000,999.0,99.0
+1979,6,2,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,8.9,75,99600,0,0,335,0,0,0,0,0,0,0,210,2.1,7,7,16.1,3660,9,999999999,179,0.0950,0,88,999.000,999.0,99.0
+1979,6,2,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,8.9,75,99600,0,0,340,0,0,0,0,0,0,0,220,2.1,8,8,19.3,3050,9,999999999,179,0.0950,0,88,999.000,999.0,99.0
+1979,6,2,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,8.9,75,99600,0,0,340,0,0,0,0,0,0,0,210,3.1,8,8,19.3,3050,9,999999999,179,0.0950,0,88,999.000,999.0,99.0
+1979,6,2,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,8.9,77,99600,0,0,329,0,0,0,0,0,0,0,200,2.6,6,6,19.3,3050,9,999999999,179,0.0950,0,88,999.000,999.0,99.0
+1979,6,2,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,9.4,83,99600,46,874,327,18,26,16,1900,1100,1900,330,210,2.6,7,6,11.3,3050,9,999999999,189,0.0870,0,88,999.000,999.0,99.0
+1979,6,2,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,11.1,83,99600,259,1328,336,107,153,77,11200,11300,9000,1490,230,1.5,7,6,19.3,3050,9,999999999,209,0.0870,0,88,999.000,999.0,99.0
+1979,6,2,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,10.0,61,99600,496,1328,345,223,326,101,23900,30800,12400,1910,230,3.1,5,3,19.3,77777,9,999999999,200,0.0870,0,88,999.000,999.0,99.0
+1979,6,2,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,10.6,55,99600,723,1328,353,463,609,130,48500,60600,15400,2880,290,3.1,7,2,19.3,77777,9,999999999,200,0.0870,0,88,999.000,999.0,99.0
+1979,6,2,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,11.1,51,99600,923,1328,362,628,610,203,65500,61300,22800,5470,270,2.6,8,2,24.1,77777,9,999999999,209,0.0870,0,88,999.000,999.0,99.0
+1979,6,2,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,10.6,46,99500,1083,1328,370,771,694,202,81800,70800,23900,7600,270,4.1,8,3,24.1,77777,9,999999999,200,0.0870,0,88,999.000,999.0,99.0
+1979,6,2,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,10.0,40,99500,1192,1328,378,851,637,277,89400,64400,31500,14370,200,3.1,8,3,24.1,77777,9,999999999,189,0.0870,0,88,999.000,999.0,99.0
+1979,6,2,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,8.9,37,99400,1244,1328,390,837,509,359,89800,53200,39900,24340,200,5.2,9,7,24.1,1520,9,999999999,179,0.0870,0,88,999.000,999.0,99.0
+1979,6,2,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,10.6,40,99300,1233,1328,391,906,674,279,95600,68200,32100,17310,220,4.1,10,6,24.1,1520,9,999999999,200,0.0870,0,88,999.000,999.0,99.0
+1979,6,2,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,11.7,43,99300,1161,1328,392,657,402,305,70900,42000,34100,14550,190,4.1,9,6,24.1,7620,9,999999999,209,0.0870,0,88,999.000,999.0,99.0
+1979,6,2,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,11.1,42,99200,1033,1328,423,316,0,316,36900,0,36900,14000,180,5.2,10,10,24.1,7620,9,999999999,209,0.0870,0,88,999.000,999.0,99.0
+1979,6,2,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,8.3,35,99200,857,1328,407,262,19,250,30300,1700,29300,10770,240,4.1,10,9,24.1,7620,9,999999999,179,0.0870,0,88,999.000,999.0,99.0
+1979,6,2,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,10.0,40,99100,646,1328,406,169,1,168,19400,100,19300,6920,240,5.2,10,9,24.1,7620,9,999999999,189,0.0870,0,88,999.000,999.0,99.0
+1979,6,2,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,10.0,42,99100,415,1328,389,150,167,99,16300,15300,11500,1910,240,5.2,8,7,24.1,7620,9,999999999,200,0.0870,0,88,999.000,999.0,99.0
+1979,6,2,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,9.4,46,99100,179,1328,363,57,114,42,6100,6700,5200,760,240,3.1,8,3,24.1,77777,9,999999999,189,0.0870,0,88,999.000,999.0,99.0
+1979,6,2,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,8.9,51,99100,10,432,348,5,7,4,0,0,0,0,220,3.1,7,2,24.1,77777,9,999999999,179,0.0870,0,88,999.000,999.0,99.0
+1979,6,2,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,8.3,56,99200,0,0,333,0,0,0,0,0,0,0,220,3.1,4,1,24.1,77777,9,999999999,179,0.0870,0,88,999.000,999.0,99.0
+1979,6,2,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,8.3,52,99200,0,0,331,0,0,0,0,0,0,0,230,3.6,1,0,24.1,77777,9,999999999,170,0.0870,0,88,999.000,999.0,99.0
+1979,6,2,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,7.2,56,99200,0,0,320,0,0,0,0,0,0,0,210,3.6,0,0,24.1,77777,9,999999999,160,0.0870,0,88,999.000,999.0,99.0
+1979,6,2,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,8.9,60,99200,0,0,325,0,0,0,0,0,0,0,230,4.1,2,0,24.1,77777,9,999999999,179,0.0870,0,88,999.000,999.0,99.0
+1979,6,3,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,9.4,63,99200,0,0,325,0,0,0,0,0,0,0,230,5.2,1,0,24.1,77777,9,999999999,189,0.0870,0,88,999.000,999.0,99.0
+1979,6,3,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,9.4,63,99100,0,0,325,0,0,0,0,0,0,0,220,4.1,0,0,24.1,77777,9,999999999,189,0.0870,0,88,999.000,999.0,99.0
+1979,6,3,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,9.4,67,99100,0,0,320,0,0,0,0,0,0,0,240,4.1,0,0,24.1,77777,9,999999999,189,0.0870,0,88,999.000,999.0,99.0
+1979,6,3,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,9.4,72,99200,0,0,315,0,0,0,0,0,0,0,240,4.6,0,0,24.1,77777,9,999999999,189,0.0870,0,88,999.000,999.0,99.0
+1979,6,3,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,9.4,75,99200,47,896,313,22,85,14,2000,3100,1900,240,240,4.1,0,0,24.1,77777,9,999999999,189,0.0850,0,88,999.000,999.0,99.0
+1979,6,3,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,9.4,67,99100,260,1328,320,132,457,42,13700,35000,6800,780,250,5.7,1,0,24.1,77777,9,999999999,189,0.0850,0,88,999.000,999.0,99.0
+1979,6,3,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,11.1,65,99100,497,1328,338,287,574,71,30200,54200,9900,1420,260,5.7,3,1,24.1,77777,9,999999999,209,0.0850,0,88,999.000,999.0,99.0
+1979,6,3,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,12.2,61,99100,723,1328,344,489,740,84,51800,73500,11700,1930,260,5.7,1,0,24.1,77777,9,999999999,220,0.0850,0,88,999.000,999.0,99.0
+1979,6,3,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,12.2,53,99000,923,1328,354,671,822,97,69500,81900,12400,2370,260,4.1,0,0,24.1,77777,9,999999999,220,0.0850,0,88,999.000,999.0,99.0
+1979,6,3,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,11.7,45,99000,1084,1328,364,832,884,108,85900,88500,13500,3440,260,4.1,0,0,24.1,77777,9,999999999,209,0.0850,0,88,999.000,999.0,99.0
+1979,6,3,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,10.0,38,99000,1193,1328,368,930,905,115,95900,90800,14100,5040,240,3.6,0,0,24.1,77777,9,999999999,200,0.0850,0,88,999.000,999.0,99.0
+1979,6,3,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,10.0,34,98900,1244,1328,388,880,772,155,94400,78400,20800,9900,270,5.2,2,2,24.1,77777,9,999999999,189,0.0850,0,88,999.000,999.0,99.0
+1979,6,3,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,7.2,26,98800,1233,1328,397,822,646,220,88200,66200,26500,13920,250,7.2,3,3,24.1,77777,9,999999999,170,0.0850,0,88,999.000,999.0,99.0
+1979,6,3,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,6.7,25,98800,1162,1328,400,844,736,199,90600,75500,24400,9460,290,5.2,5,5,24.1,77777,9,999999999,160,0.0850,0,88,999.000,999.0,99.0
+1979,6,3,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,7.2,31,98800,1034,1328,386,476,264,271,52800,28700,30400,8830,70,6.7,5,5,24.1,77777,9,999999999,160,0.0850,0,88,999.000,999.0,99.0
+1979,6,3,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,6.7,33,98700,859,1328,374,526,584,149,55800,59100,17500,3810,120,6.7,4,4,24.1,77777,9,999999999,160,0.0850,0,88,999.000,999.0,99.0
+1979,6,3,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,7.2,36,98700,648,1328,369,429,663,107,45400,65300,13500,2270,120,5.2,3,3,19.3,77777,9,999999999,170,0.0850,0,88,999.000,999.0,99.0
+1979,6,3,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,8.3,37,98600,417,1328,369,226,469,82,23600,41700,10500,1520,140,4.6,2,2,19.3,77777,9,999999999,170,0.0850,0,88,999.000,999.0,99.0
+1979,6,3,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,7.8,42,98600,181,1328,355,74,255,40,7800,15700,5700,710,130,3.6,2,2,19.3,77777,9,999999999,170,0.0850,0,88,999.000,999.0,99.0
+1979,6,3,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,7.8,47,98600,11,454,342,5,15,3,0,0,0,0,130,3.6,1,1,19.3,77777,9,999999999,170,0.0850,0,88,999.000,999.0,99.0
+1979,6,3,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,7.2,50,98600,0,0,328,0,0,0,0,0,0,0,140,3.1,1,0,19.3,77777,9,999999999,160,0.0850,0,88,999.000,999.0,99.0
+1979,6,3,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,7.8,50,98600,0,0,331,0,0,0,0,0,0,0,170,2.1,1,0,19.3,77777,9,999999999,170,0.0850,0,88,999.000,999.0,99.0
+1979,6,3,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,8.3,58,98600,0,0,324,0,0,0,0,0,0,0,200,2.6,0,0,16.1,77777,9,999999999,179,0.0850,0,88,999.000,999.0,99.0
+1979,6,3,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,8.9,56,98600,0,0,330,0,0,0,0,0,0,0,230,3.6,0,0,19.3,77777,9,999999999,179,0.0850,0,88,999.000,999.0,99.0
+1979,6,4,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,8.9,58,98600,0,0,327,0,0,0,0,0,0,0,230,4.1,0,0,24.1,77777,9,999999999,179,0.0850,0,88,999.000,999.0,99.0
+1979,6,4,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,8.9,54,98500,0,0,332,0,0,0,0,0,0,0,240,5.2,0,0,24.1,77777,9,999999999,179,0.0850,0,88,999.000,999.0,99.0
+1979,6,4,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,8.9,51,98600,0,0,337,0,0,0,0,0,0,0,230,5.2,0,0,24.1,77777,9,999999999,179,0.0850,0,88,999.000,999.0,99.0
+1979,6,4,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,8.3,49,98600,0,0,347,0,0,0,0,0,0,0,220,5.2,2,2,24.1,77777,9,999999999,179,0.0850,0,88,999.000,999.0,99.0
+1979,6,4,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,8.9,52,98600,47,896,352,15,3,15,1700,0,1700,520,250,5.2,4,4,24.1,77777,9,999999999,179,0.2420,0,88,999.000,999.0,99.0
+1979,6,4,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,9.4,54,98600,262,1327,346,102,194,64,10900,14400,8000,1190,230,5.2,2,2,24.1,77777,9,999999999,189,0.2420,0,88,999.000,999.0,99.0
+1979,6,4,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,10.6,49,98600,498,1327,356,268,425,107,28400,40200,13300,2030,230,6.7,1,1,24.1,77777,9,999999999,200,0.2420,0,88,999.000,999.0,99.0
+1979,6,4,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,11.1,46,98600,724,1327,358,471,586,150,48800,57900,17200,3250,240,5.7,0,0,24.1,77777,9,999999999,209,0.2420,0,88,999.000,999.0,99.0
+1979,6,4,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,12.2,41,98500,924,1327,376,652,674,181,68500,68200,21000,4970,230,5.7,0,0,24.1,77777,9,999999999,220,0.2420,0,88,999.000,999.0,99.0
+1979,6,4,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,11.1,33,98500,1084,1327,393,757,670,207,80200,68300,24300,7800,210,6.7,2,1,24.1,77777,9,999999999,200,0.2420,0,88,999.000,999.0,99.0
+1979,6,4,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,9.4,28,98400,1193,1327,397,826,619,268,87000,62700,30600,14030,230,9.8,5,1,24.1,77777,9,999999999,189,0.2420,0,88,999.000,999.0,99.0
+1979,6,4,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,8.9,26,98300,1245,1327,405,895,625,307,93800,63000,34700,20210,220,9.3,7,2,24.1,77777,9,999999999,179,0.2420,0,88,999.000,999.0,99.0
+1979,6,4,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,8.3,28,98300,1234,1327,413,614,284,349,68300,31000,39400,19960,220,8.8,8,7,24.1,7620,9,999999999,179,0.2420,0,88,999.000,999.0,99.0
+1979,6,4,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,8.3,26,98300,1163,1327,435,395,32,367,43700,3300,40800,16920,220,6.2,10,9,24.1,7620,9,999999999,179,0.2420,0,88,999.000,999.0,99.0
+1979,6,4,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,8.9,28,98300,1035,1327,424,504,180,363,55200,19100,40300,12520,210,8.2,9,8,24.1,7620,9,999999999,179,0.2420,0,88,999.000,999.0,99.0
+1979,6,4,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,7.8,26,98200,860,1327,431,415,194,290,45500,20400,32200,8240,220,7.2,10,9,24.1,7620,9,999999999,170,0.2420,0,88,999.000,999.0,99.0
+1979,6,4,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,7.2,26,98100,650,1327,424,193,44,171,21200,4300,19100,5280,230,6.2,10,9,24.1,7620,9,999999999,160,0.2420,0,88,999.000,999.0,99.0
+1979,6,4,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,7.2,29,98100,419,1327,406,135,86,108,14800,8000,12300,2430,240,4.1,9,8,24.1,3660,9,999999999,160,0.2420,0,88,999.000,999.0,99.0
+1979,6,4,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,7.8,31,98200,184,1327,413,52,0,52,5700,0,5700,1670,230,4.1,9,9,24.1,3050,9,999999999,170,0.2420,0,88,999.000,999.0,99.0
+1979,6,4,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,8.3,36,98200,12,453,404,2,0,2,0,0,0,0,250,2.6,9,9,24.1,3050,9,999999999,170,0.2420,0,88,999.000,999.0,99.0
+1979,6,4,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,11.7,53,98300,0,0,405,0,0,0,0,0,0,0,10,6.7,10,10,24.1,1830,9,999999999,209,0.2420,0,88,999.000,999.0,99.0
+1979,6,4,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,14.4,76,98400,0,0,393,0,0,0,0,0,0,0,360,2.6,10,10,16.1,1830,9,999999999,250,0.2420,0,88,999.000,999.0,99.0
+1979,6,4,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,14.4,84,98300,0,0,374,0,0,0,0,0,0,0,130,3.1,10,9,24.1,3050,9,999999999,250,0.2420,0,88,999.000,999.0,99.0
+1979,6,4,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,13.9,81,98300,0,0,365,0,0,0,0,0,0,0,180,2.6,8,8,24.1,7620,9,999999999,240,0.2420,0,88,999.000,999.0,99.0
+1979,6,5,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,14.4,78,98200,0,0,390,0,0,0,0,0,0,0,200,2.6,10,10,24.1,7620,9,999999999,250,0.2420,0,88,999.000,999.0,99.0
+1979,6,5,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,14.4,81,98300,0,0,387,0,0,0,0,0,0,0,260,3.1,10,10,24.1,1830,9,999999999,250,0.2420,0,88,999.000,999.0,99.0
+1979,6,5,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,15.6,84,98300,0,0,392,0,0,0,0,0,0,0,0,0.0,10,10,24.1,3050,9,999999999,270,0.2420,0,88,999.000,999.0,99.0
+1979,6,5,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,15.6,84,98300,0,0,381,0,0,0,0,0,0,0,130,2.1,9,9,24.1,1830,9,999999999,270,0.2420,0,88,999.000,999.0,99.0
+1979,6,5,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,15.0,84,98300,48,918,364,17,22,15,1800,900,1800,310,50,3.6,8,7,14.5,3050,9,999999999,259,0.0800,0,88,999.000,999.0,99.0
+1979,6,5,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,14.4,84,98400,263,1327,339,126,380,51,12900,28900,7200,920,80,2.6,2,1,11.3,77777,9,999999999,250,0.0800,0,88,999.000,999.0,99.0
+1979,6,5,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,12.8,75,98400,498,1327,338,299,623,64,31100,58500,9100,1310,50,7.2,2,1,14.5,77777,9,999999999,229,0.0800,0,88,999.000,999.0,99.0
+1979,6,5,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,12.8,78,98500,724,1327,349,385,417,156,41400,42400,18200,3390,20,6.2,7,5,12.9,7320,9,999999999,229,0.0800,0,88,999.000,999.0,99.0
+1979,6,5,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,12.8,78,98500,924,1327,346,585,575,183,61400,58100,20900,5030,40,5.2,5,4,16.1,77777,9,999999999,229,0.0800,0,88,999.000,999.0,99.0
+1979,6,5,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,12.8,75,98600,1084,1327,348,629,524,199,66900,53500,23000,7540,30,6.2,5,4,19.3,77777,9,999999999,229,0.0800,0,88,999.000,999.0,99.0
+1979,6,5,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,13.3,68,98600,1194,1327,342,929,907,111,95900,91000,13800,4960,40,4.6,0,0,24.1,77777,9,999999999,240,0.0800,0,88,999.000,999.0,99.0
+1979,6,5,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,13.9,64,98600,1245,1327,362,927,815,160,99100,82700,21400,10270,30,8.2,2,2,24.1,77777,9,999999999,250,0.0800,0,88,999.000,999.0,99.0
+1979,6,5,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,13.9,68,98600,1235,1327,388,530,174,368,59100,18700,41700,20090,20,6.7,9,9,24.1,1830,9,999999999,240,0.0800,0,88,999.000,999.0,99.0
+1979,6,5,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,13.3,63,98500,1164,1327,376,444,192,275,49800,20900,31400,12010,30,7.7,8,7,24.1,2440,9,999999999,240,0.0800,0,88,999.000,999.0,99.0
+1979,6,5,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,13.3,63,98500,1036,1327,348,770,857,100,79900,85700,12800,2970,20,6.7,0,0,24.1,77777,9,999999999,229,0.0800,0,88,999.000,999.0,99.0
+1979,6,5,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,11.1,53,98500,862,1327,347,619,820,88,64700,81400,11700,2090,10,8.2,0,0,24.1,77777,9,999999999,209,0.0800,0,88,999.000,999.0,99.0
+1979,6,5,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,8.3,49,98500,652,1327,336,449,772,72,48100,76000,10700,1630,20,9.8,0,0,24.1,77777,9,999999999,179,0.0800,0,88,999.000,999.0,99.0
+1979,6,5,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,5.6,45,98500,421,1327,326,252,639,52,26600,58100,8200,1080,30,6.2,0,0,24.1,77777,9,999999999,150,0.0800,0,88,999.000,999.0,99.0
+1979,6,5,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,3.9,46,98500,186,1327,314,81,366,32,8600,24200,5200,580,30,5.7,0,0,24.1,77777,9,999999999,129,0.0800,0,88,999.000,999.0,99.0
+1979,6,5,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,3.9,49,98500,13,475,309,7,22,5,0,0,0,0,20,4.6,1,0,24.1,77777,9,999999999,129,0.0800,0,88,999.000,999.0,99.0
+1979,6,5,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,3.9,53,98500,0,0,305,0,0,0,0,0,0,0,20,3.6,0,0,24.1,77777,9,999999999,129,0.0800,0,88,999.000,999.0,99.0
+1979,6,5,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,4.4,57,98500,0,0,303,0,0,0,0,0,0,0,30,3.1,0,0,24.1,77777,9,999999999,139,0.0800,0,88,999.000,999.0,99.0
+1979,6,5,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,4.4,57,98500,0,0,303,0,0,0,0,0,0,0,10,3.6,0,0,24.1,77777,9,999999999,139,0.0800,0,88,999.000,999.0,99.0
+1979,6,5,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,4.4,57,98500,0,0,303,0,0,0,0,0,0,0,360,3.1,0,0,24.1,77777,9,999999999,139,0.0800,0,88,999.000,999.0,99.0
+1979,6,6,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,5.0,59,98400,0,0,304,0,0,0,0,0,0,0,360,2.1,0,0,24.1,77777,9,999999999,139,0.0800,0,88,999.000,999.0,99.0
+1979,6,6,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,5.6,64,98400,0,0,302,0,0,0,0,0,0,0,350,2.6,0,0,24.1,77777,9,999999999,150,0.0800,0,88,999.000,999.0,99.0
+1979,6,6,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,6.1,72,98400,0,0,298,0,0,0,0,0,0,0,10,2.6,0,0,24.1,77777,9,999999999,150,0.0800,0,88,999.000,999.0,99.0
+1979,6,6,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,6.1,72,98400,0,0,307,0,0,0,0,0,0,0,10,3.1,2,2,24.1,77777,9,999999999,150,0.0800,0,88,999.000,999.0,99.0
+1979,6,6,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,7.2,77,98500,49,917,304,21,80,14,2000,3000,1800,240,350,2.6,3,1,24.1,77777,9,999999999,160,0.0840,0,88,999.000,999.0,99.0
+1979,6,6,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,8.3,75,98500,263,1326,307,128,450,38,13300,34800,6400,720,10,3.1,0,0,19.3,77777,9,999999999,179,0.0840,0,88,999.000,999.0,99.0
+1979,6,6,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,10.6,72,98500,499,1326,322,320,684,61,33400,64400,9100,1280,10,2.1,0,0,11.3,77777,9,999999999,200,0.0840,0,88,999.000,999.0,99.0
+1979,6,6,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,13.3,66,98500,725,1326,351,471,704,85,49900,69900,11600,1950,190,1.5,2,1,11.3,77777,9,999999999,240,0.0840,0,88,999.000,999.0,99.0
+1979,6,6,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,15.0,60,98500,924,1326,378,633,693,148,67500,70700,18100,4170,100,1.5,4,3,8.0,77777,9,999999999,259,0.0840,0,88,999.000,999.0,99.0
+1979,6,6,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,15.6,56,98500,1085,1326,384,785,768,154,82400,77400,19000,5420,180,2.1,3,2,8.0,77777,9,999999999,270,0.0840,0,88,999.000,999.0,99.0
+1979,6,6,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,15.6,47,98400,1194,1326,393,863,837,107,89100,84000,13300,4850,150,2.1,2,1,8.0,77777,9,999999999,270,0.0840,0,88,999.000,999.0,99.0
+1979,6,6,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,15.6,44,98400,1246,1326,408,881,667,253,93700,67900,29800,17010,170,3.6,7,3,8.0,77777,9,999999999,270,0.0840,0,88,999.000,999.0,99.0
+1979,6,6,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,16.1,42,98300,1235,1326,414,856,699,204,92400,71900,25400,13150,180,5.2,8,2,12.9,77777,9,999999999,279,0.0840,0,88,999.000,999.0,99.0
+1979,6,6,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,16.1,40,98300,1165,1326,417,766,648,196,82300,66500,23800,9450,220,5.2,7,2,12.9,77777,9,999999999,270,0.0840,0,88,999.000,999.0,99.0
+1979,6,6,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,15.6,38,98200,1038,1326,420,721,748,136,76500,75500,17300,4400,180,6.7,4,2,12.9,77777,9,999999999,270,0.0840,0,88,999.000,999.0,99.0
+1979,6,6,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,32.2,15.0,35,98200,863,1326,422,554,610,158,58600,61600,18400,4030,120,6.2,3,2,12.9,77777,9,999999999,259,0.0840,0,88,999.000,999.0,99.0
+1979,6,6,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,15.6,42,98100,654,1326,414,422,645,106,44700,63700,13300,2270,120,5.7,4,3,11.3,77777,9,999999999,270,0.0840,0,88,999.000,999.0,99.0
+1979,6,6,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,13.9,40,98100,423,1326,402,231,435,95,24700,39300,12200,1770,120,5.7,2,2,11.3,77777,9,999999999,240,0.0840,0,88,999.000,999.0,99.0
+1979,6,6,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,13.9,45,98000,188,1326,391,74,266,38,8000,16800,5600,670,110,4.1,3,2,11.3,77777,9,999999999,240,0.0840,0,88,999.000,999.0,99.0
+1979,6,6,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,13.9,49,98100,13,497,403,5,4,4,0,0,0,0,150,3.1,8,7,9.7,2440,9,999999999,250,0.0840,0,88,999.000,999.0,99.0
+1979,6,6,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.7,16.7,54,98100,0,0,440,0,0,0,0,0,0,0,210,4.1,10,10,12.9,2440,9,999999999,290,0.0840,0,88,999.000,999.0,99.0
+1979,6,6,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,27.2,15.6,49,98200,0,0,409,0,0,0,0,0,0,0,200,5.7,6,6,19.3,3050,9,999999999,270,0.0840,0,88,999.000,999.0,99.0
+1979,6,6,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.7,15.6,51,98300,0,0,411,0,0,0,0,0,0,0,190,4.1,7,7,19.3,3050,9,999999999,270,0.0840,0,88,999.000,999.0,99.0
+1979,6,6,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.6,16.1,56,98300,0,0,395,0,0,0,0,0,0,0,180,4.1,4,4,19.3,77777,9,999999999,279,0.0840,0,88,999.000,999.0,99.0
+1979,6,7,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.9,16.1,62,98200,0,0,383,0,0,0,0,0,0,0,180,3.6,3,3,19.3,77777,9,999999999,279,0.0840,0,88,999.000,999.0,99.0
+1979,6,7,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.9,16.7,64,98200,0,0,380,0,0,0,0,0,0,0,190,4.6,2,2,19.3,77777,9,999999999,290,0.0840,0,88,999.000,999.0,99.0
+1979,6,7,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,24.4,16.7,62,98200,0,0,406,0,0,0,0,0,0,0,170,5.2,8,8,19.3,2440,9,999999999,290,0.0840,0,88,999.000,999.0,99.0
+1979,6,7,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,17.8,71,98200,0,0,410,0,0,0,0,0,0,0,170,4.1,9,9,19.3,2130,9,999999999,300,0.0840,0,88,999.000,999.0,99.0
+1979,6,7,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,18.3,76,98300,50,917,383,17,12,16,1800,600,1800,390,180,4.1,8,4,16.1,77777,9,999999999,320,0.1470,0,88,999.000,999.0,99.0
+1979,6,7,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,18.9,76,98300,264,1326,386,99,104,78,10700,8100,9100,1680,180,5.2,9,4,19.3,77777,9,999999999,329,0.1470,0,88,999.000,999.0,99.0
+1979,6,7,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,19.4,71,98300,500,1326,434,138,7,135,15600,500,15400,5160,180,6.2,10,10,11.3,670,9,999999999,340,0.1470,0,88,999.000,999.0,99.0
+1979,6,7,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,20.0,71,98300,725,1326,438,156,21,145,17300,2100,16200,4860,170,4.1,10,10,11.3,580,9,999999999,350,0.1470,0,88,999.000,999.0,99.0
+1979,6,7,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,20.0,76,98300,925,1326,431,177,10,170,21300,800,20800,8280,160,6.2,10,10,6.4,270,9,999999999,350,0.1470,0,88,999.000,999.0,99.0
+1979,6,7,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,21.1,85,98300,1085,1326,430,344,3,341,40200,300,39900,15060,170,5.2,10,10,8.0,610,9,999999999,370,0.1470,0,88,999.000,999.0,99.0
+1979,6,7,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,18.3,87,98300,1194,1326,408,213,8,206,26300,600,25800,10390,220,4.6,10,10,8.0,760,9,999999999,320,0.1470,0,88,999.000,999.0,99.0
+1979,6,7,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,18.9,90,98300,1246,1326,408,213,2,212,26500,200,26400,10710,190,3.6,10,10,9.7,2440,9,999999999,329,0.1470,0,88,999.000,999.0,99.0
+1979,6,7,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,20.0,84,98300,1236,1326,422,382,0,381,45100,0,45100,16930,210,3.1,10,10,12.9,2440,9,999999999,350,0.1470,0,88,999.000,999.0,99.0
+1979,6,7,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,21.1,85,98300,1165,1326,430,224,2,222,27400,200,27200,11020,220,2.6,10,10,11.3,610,9,999999999,370,0.1470,0,88,999.000,999.0,99.0
+1979,6,7,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,20.6,82,98300,1039,1326,417,285,93,212,32300,10000,24500,7350,190,3.6,9,9,11.3,2440,9,999999999,359,0.1470,0,88,999.000,999.0,99.0
+1979,6,7,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,21.1,77,98200,865,1326,419,397,159,294,43500,16800,32600,8390,150,3.1,8,8,11.3,2440,9,999999999,370,0.1470,0,88,999.000,999.0,99.0
+1979,6,7,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,20.6,74,98200,655,1326,418,349,265,219,37200,27400,23700,5010,160,2.6,8,8,12.9,2440,9,999999999,359,0.1470,0,88,999.000,999.0,99.0
+1979,6,7,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,20.6,69,98300,425,1326,406,195,291,103,21100,26900,12500,2000,210,3.1,4,4,12.9,77777,9,999999999,359,0.1470,0,88,999.000,999.0,99.0
+1979,6,7,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,20.0,74,98400,190,1326,396,59,83,47,6500,5600,5700,990,240,1.5,4,4,14.5,77777,9,999999999,350,0.1470,0,88,999.000,999.0,99.0
+1979,6,7,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,20.0,79,98400,14,497,387,5,4,4,0,0,0,0,170,2.1,3,3,14.5,77777,9,999999999,350,0.1470,0,88,999.000,999.0,99.0
+1979,6,7,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,20.6,84,98500,0,0,376,0,0,0,0,0,0,0,160,2.1,1,1,14.5,77777,9,999999999,359,0.1470,0,88,999.000,999.0,99.0
+1979,6,7,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,20.6,84,98500,0,0,369,0,0,0,0,0,0,0,160,2.1,0,0,16.1,77777,9,999999999,359,0.1470,0,88,999.000,999.0,99.0
+1979,6,7,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,20.0,82,98500,0,0,368,0,0,0,0,0,0,0,170,4.1,0,0,12.9,77777,9,999999999,350,0.1470,0,88,999.000,999.0,99.0
+1979,6,7,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,20.6,84,98500,0,0,376,0,0,0,0,0,0,0,170,3.6,1,1,11.3,77777,9,999999999,359,0.1470,0,88,999.000,999.0,99.0
+1979,6,8,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,20.0,87,98600,0,0,363,0,0,0,0,0,0,0,180,3.1,0,0,11.3,77777,9,999999999,350,0.1470,0,88,999.000,999.0,99.0
+1979,6,8,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,20.0,90,98600,0,0,376,0,0,0,0,0,0,0,160,2.6,3,3,9.7,77777,9,999999999,350,0.1470,0,88,999.000,999.0,99.0
+1979,6,8,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,20.0,87,98700,0,0,388,0,0,0,0,0,0,0,230,4.1,6,6,8.0,3050,9,999999999,350,0.1470,0,88,999.000,999.0,99.0
+1979,6,8,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,20.0,90,98800,0,0,385,0,0,0,0,0,0,0,240,3.1,6,6,8.0,3050,9,999999999,350,0.1470,0,88,999.000,999.0,99.0
+1979,6,8,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,19.4,90,98800,50,917,375,15,30,12,1500,1000,1500,200,210,1.5,4,4,6.4,77777,9,999999999,340,0.1000,0,88,999.000,999.0,99.0
+1979,6,8,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,21.1,90,98900,265,1326,374,124,365,51,12700,27800,7100,920,210,2.6,3,1,6.4,77777,9,999999999,370,0.1000,0,88,999.000,999.0,99.0
+1979,6,8,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,21.7,82,98900,500,1326,386,289,567,74,30400,53500,10200,1480,230,3.1,3,1,6.4,77777,9,999999999,390,0.1000,0,88,999.000,999.0,99.0
+1979,6,8,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,22.2,72,99000,725,1326,407,473,632,126,49700,63000,15200,2810,210,2.6,2,2,6.4,77777,9,999999999,400,0.1000,0,88,999.000,999.0,99.0
+1979,6,8,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,23.3,72,99000,925,1326,409,587,640,139,62900,65500,17100,3950,190,3.1,6,1,8.0,77777,9,999999999,430,0.1000,0,88,999.000,999.0,99.0
+1979,6,8,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,23.3,70,99000,1085,1326,417,756,704,177,81000,72300,21700,6800,210,4.1,6,2,11.3,77777,9,999999999,430,0.1000,0,88,999.000,999.0,99.0
+1979,6,8,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,23.3,65,99100,1195,1326,443,623,328,326,69300,35700,37000,15980,220,4.1,7,7,11.3,910,9,999999999,419,0.1000,0,88,999.000,999.0,99.0
+1979,6,8,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,23.3,63,99000,1246,1326,441,811,460,378,86700,48100,41400,26340,190,3.1,7,6,11.3,910,9,999999999,419,0.1000,0,88,999.000,999.0,99.0
+1979,6,8,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,33.3,23.3,56,99000,1237,1326,467,592,185,419,65500,19800,47000,23120,160,5.2,9,8,11.3,1070,9,999999999,430,0.1000,0,88,999.000,999.0,99.0
+1979,6,8,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,20.0,57,99000,1166,1326,423,923,801,218,98600,81800,26400,10510,320,5.2,5,5,11.3,77777,9,999999999,350,0.1000,0,88,999.000,999.0,99.0
+1979,6,8,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,21.1,82,99000,1040,1326,433,143,1,143,17800,100,17800,7410,170,4.6,10,10,8.0,760,9,999999999,370,0.1000,0,88,999.000,999.0,99.0
+1979,6,8,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,21.1,87,99100,866,1326,426,118,5,115,14500,300,14300,5780,350,1.5,10,10,6.4,1370,9,999999999,370,0.1000,0,88,999.000,999.0,99.0
+1979,6,8,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,21.1,82,99100,657,1326,433,204,4,201,23000,300,22900,7920,60,4.6,10,10,8.0,670,9,999999999,370,0.1000,0,88,999.000,999.0,99.0
+1979,6,8,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,20.0,79,99100,427,1326,428,66,6,65,7900,300,7800,2740,60,3.1,10,10,6.4,1160,9,999999999,350,0.1000,0,88,999.000,999.0,99.0
+1979,6,8,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,18.3,90,99200,192,1326,404,21,3,21,2600,0,2600,830,20,4.6,10,10,2.4,120,9,999999999,320,0.1000,0,88,999.000,999.0,99.0
+1979,6,8,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,16.7,90,99200,15,519,393,3,0,3,0,0,0,0,20,5.2,10,10,3.2,90,9,999999999,290,0.1000,0,88,999.000,999.0,99.0
+1979,6,8,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,16.1,90,99300,0,0,390,0,0,0,0,0,0,0,40,3.6,10,10,3.2,90,9,999999999,279,0.1000,0,88,999.000,999.0,99.0
+1979,6,8,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,15.6,100,99300,0,0,377,0,0,0,0,0,0,0,40,4.1,10,10,1.3,30,9,999999999,270,0.1000,0,88,999.000,999.0,99.0
+1979,6,8,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,15.6,100,99300,0,0,377,0,0,0,0,0,0,0,30,4.6,10,10,2.4,60,9,999999999,270,0.1000,0,88,999.000,999.0,99.0
+1979,6,8,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,15.6,97,99300,0,0,380,0,0,0,0,0,0,0,50,2.6,10,10,0.8,60,9,999999999,270,0.1000,0,88,999.000,999.0,99.0
+1979,6,9,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,15.6,93,99300,0,0,383,0,0,0,0,0,0,0,50,2.6,10,10,1.6,60,9,999999999,270,0.1000,0,88,999.000,999.0,99.0
+1979,6,9,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,16.1,97,99200,0,0,384,0,0,0,0,0,0,0,360,1.5,10,10,3.2,120,9,999999999,279,0.1000,0,88,999.000,999.0,99.0
+1979,6,9,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,16.1,93,99200,0,0,386,0,0,0,0,0,0,0,110,3.1,10,10,3.2,120,9,999999999,279,0.1000,0,88,999.000,999.0,99.0
+1979,6,9,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,16.1,93,99200,0,0,386,0,0,0,0,0,0,0,180,1.5,10,10,3.2,180,9,999999999,279,0.1000,0,88,999.000,999.0,99.0
+1979,6,9,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,16.7,90,99200,51,939,393,15,0,15,1700,0,1700,530,220,1.5,10,10,3.2,120,9,999999999,290,0.1380,0,88,999.000,999.0,99.0
+1979,6,9,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,17.2,90,99200,265,1325,397,59,2,59,6700,100,6700,2130,80,1.5,10,10,3.2,120,9,999999999,300,0.1380,0,88,999.000,999.0,99.0
+1979,6,9,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,17.8,90,99200,500,1325,400,139,1,139,15800,100,15700,5270,150,2.6,10,10,2.4,180,9,999999999,309,0.1380,0,88,999.000,999.0,99.0
+1979,6,9,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,18.3,87,99300,725,1325,408,263,0,263,29600,0,29600,10000,20,2.6,10,10,2.4,120,9,999999999,320,0.1380,0,88,999.000,999.0,99.0
+1979,6,9,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,18.3,87,99300,925,1325,408,335,0,335,38300,0,38300,13690,10,2.6,10,10,2.4,180,9,999999999,320,0.1380,0,88,999.000,999.0,99.0
+1979,6,9,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,18.9,79,99200,1085,1325,409,374,67,319,41300,6900,35700,13410,130,2.1,9,9,2.4,210,9,999999999,329,0.1380,0,88,999.000,999.0,99.0
+1979,6,9,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,21.1,74,99200,1195,1325,443,321,2,320,38400,200,38300,14790,150,2.1,10,10,3.2,240,9,999999999,370,0.1380,0,88,999.000,999.0,99.0
+1979,6,9,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,21.1,72,99200,1247,1325,446,409,2,407,48300,200,48100,17760,140,1.5,10,10,3.2,490,9,999999999,379,0.1380,0,88,999.000,999.0,99.0
+1979,6,9,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,19.4,69,99100,1237,1325,437,377,7,371,44800,600,44200,16620,50,3.1,10,10,4.8,490,9,999999999,340,0.1380,0,88,999.000,999.0,99.0
+1979,6,9,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,18.3,67,99100,1167,1325,433,341,2,339,40300,200,40200,15330,50,4.1,10,10,6.4,490,9,999999999,320,0.1380,0,88,999.000,999.0,99.0
+1979,6,9,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,18.3,69,99000,1041,1325,397,589,361,305,64700,39200,33900,10230,70,3.6,9,6,6.4,7620,9,999999999,320,0.1380,0,88,999.000,999.0,99.0
+1979,6,9,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,18.3,69,98900,867,1325,391,508,451,214,54600,46600,24000,5480,100,4.1,9,4,6.4,77777,9,999999999,320,0.1380,0,88,999.000,999.0,99.0
+1979,6,9,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,17.8,71,98800,659,1325,391,298,216,191,32100,22400,20900,4250,70,4.1,9,6,4.8,7620,9,999999999,309,0.1380,0,88,999.000,999.0,99.0
+1979,6,9,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,16.7,76,98800,429,1325,383,162,128,121,17700,11900,13900,2730,60,4.1,9,7,4.8,7620,9,999999999,290,0.1380,0,88,999.000,999.0,99.0
+1979,6,9,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,17.8,84,98800,194,1325,407,25,1,25,3000,0,3000,970,20,4.1,10,10,4.8,1400,9,999999999,309,0.1380,0,88,999.000,999.0,99.0
+1979,6,9,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,18.3,90,98800,16,541,404,1,0,1,0,0,0,0,50,3.1,10,10,4.8,1160,9,999999999,320,0.1380,0,88,999.000,999.0,99.0
+1979,6,9,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,18.9,90,98800,0,0,408,0,0,0,0,0,0,0,130,3.1,10,10,4.8,1400,9,999999999,329,0.1380,0,88,999.000,999.0,99.0
+1979,6,9,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,18.9,93,98700,0,0,366,0,0,0,0,0,0,0,150,2.1,3,3,2.4,77777,9,999999999,329,0.1380,0,88,999.000,999.0,99.0
+1979,6,9,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,19.4,97,98700,0,0,363,0,0,0,0,0,0,0,150,2.6,2,2,2.4,77777,9,999999999,340,0.1380,0,88,999.000,999.0,99.0
+1979,6,9,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,18.9,90,98600,0,0,354,0,0,0,0,0,0,0,190,4.6,0,0,2.4,77777,9,999999999,329,0.1380,0,88,999.000,999.0,99.0
+1979,6,10,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,20.0,93,98500,0,0,369,0,0,0,0,0,0,0,180,3.6,2,2,2.4,77777,9,999999999,350,0.1380,0,88,999.000,999.0,99.0
+1979,6,10,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,20.0,93,98500,0,0,373,0,0,0,0,0,0,0,180,2.6,3,3,6.4,77777,9,999999999,350,0.1380,0,88,999.000,999.0,99.0
+1979,6,10,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,21.1,90,98400,0,0,424,0,0,0,0,0,0,0,240,3.1,10,10,8.0,1830,9,999999999,370,0.1380,0,88,999.000,999.0,99.0
+1979,6,10,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,20.6,90,98400,0,0,408,0,0,0,0,0,0,0,210,4.1,9,9,16.1,2440,9,999999999,359,0.1380,0,88,999.000,999.0,99.0
+1979,6,10,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,20.6,90,98300,51,939,408,10,5,10,1100,300,1100,260,180,3.6,10,9,19.3,2440,9,999999999,359,0.0870,0,88,999.000,999.0,99.0
+1979,6,10,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,21.1,93,98200,266,1325,420,69,22,64,7500,1800,7100,1640,170,4.6,10,10,12.9,2740,9,999999999,370,0.0870,0,88,999.000,999.0,99.0
+1979,6,10,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,21.7,90,98100,500,1325,427,101,9,97,11700,600,11500,4040,200,7.2,10,10,11.3,460,9,999999999,379,0.0870,0,88,999.000,999.0,99.0
+1979,6,10,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,17.2,84,98300,726,1325,403,186,8,182,21600,600,21300,7820,260,6.7,10,10,24.1,850,9,999999999,300,0.0870,0,88,999.000,999.0,99.0
+1979,6,10,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,15.0,81,98300,925,1325,391,264,12,256,30900,1000,30100,11430,250,7.7,10,10,24.1,370,9,999999999,259,0.0870,0,88,999.000,999.0,99.0
+1979,6,10,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,12.2,81,98500,1085,1325,373,317,6,312,37300,500,36900,14150,270,8.2,10,10,24.1,490,9,999999999,220,0.0870,0,88,999.000,999.0,99.0
+1979,6,10,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,11.1,72,98500,1195,1325,374,360,7,354,42700,600,42100,15920,260,7.2,10,10,24.1,520,9,999999999,209,0.0870,0,88,999.000,999.0,99.0
+1979,6,10,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,11.1,72,98500,1247,1325,374,383,3,380,45400,300,45200,16950,250,9.3,10,10,24.1,520,9,999999999,209,0.0870,0,88,999.000,999.0,99.0
+1979,6,10,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,11.1,72,98600,1238,1325,374,409,3,406,48200,300,47900,17690,260,8.8,10,10,24.1,610,9,999999999,209,0.0870,0,88,999.000,999.0,99.0
+1979,6,10,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,11.1,75,98700,1168,1325,372,379,3,376,44500,300,44200,16480,290,10.3,10,10,24.1,490,9,999999999,209,0.0870,0,88,999.000,999.0,99.0
+1979,6,10,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,10.6,70,98800,1042,1325,374,402,0,402,46100,0,46100,16420,290,10.3,10,10,24.1,670,9,999999999,200,0.0870,0,88,999.000,999.0,99.0
+1979,6,10,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,10.0,67,98900,869,1325,373,175,1,174,20800,100,20800,8230,290,10.3,10,10,24.1,760,9,999999999,189,0.0870,0,88,999.000,999.0,99.0
+1979,6,10,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,9.4,65,99000,660,1325,372,234,0,234,26300,0,26300,8730,280,8.2,10,10,24.1,760,9,999999999,189,0.0870,0,88,999.000,999.0,99.0
+1979,6,10,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,9.4,65,99100,430,1325,372,145,1,144,16000,100,16000,4920,300,8.2,10,10,24.1,760,9,999999999,189,0.0870,0,88,999.000,999.0,99.0
+1979,6,10,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,8.3,60,99200,196,1325,371,46,0,46,5200,0,5200,1580,330,9.3,10,10,24.1,760,9,999999999,179,0.0870,0,88,999.000,999.0,99.0
+1979,6,10,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,10.0,67,99300,16,541,363,7,1,7,0,0,0,0,300,3.6,9,9,24.1,760,9,999999999,189,0.0870,0,88,999.000,999.0,99.0
+1979,6,10,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,9.4,75,99400,0,0,313,0,0,0,0,0,0,0,270,3.1,0,0,24.1,77777,9,999999999,189,0.0870,0,88,999.000,999.0,99.0
+1979,6,10,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,7.8,77,99400,0,0,302,0,0,0,0,0,0,0,240,3.1,0,0,24.1,77777,9,999999999,170,0.0870,0,88,999.000,999.0,99.0
+1979,6,10,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,8.3,77,99400,0,0,304,0,0,0,0,0,0,0,240,3.6,0,0,24.1,77777,9,999999999,179,0.0870,0,88,999.000,999.0,99.0
+1979,6,10,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,10.0,80,99400,0,0,311,0,0,0,0,0,0,0,250,5.2,0,0,24.1,77777,9,999999999,189,0.0870,0,88,999.000,999.0,99.0
+1979,6,11,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,10.0,80,99400,0,0,311,0,0,0,0,0,0,0,240,4.6,0,0,24.1,77777,9,999999999,189,0.0870,0,88,999.000,999.0,99.0
+1979,6,11,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,10.0,80,99400,0,0,311,0,0,0,0,0,0,0,250,3.6,0,0,24.1,77777,9,999999999,189,0.0870,0,88,999.000,999.0,99.0
+1979,6,11,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,10.0,80,99400,0,0,311,0,0,0,0,0,0,0,260,3.6,0,0,24.1,77777,9,999999999,189,0.0870,0,88,999.000,999.0,99.0
+1979,6,11,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,10.0,80,99400,0,0,311,0,0,0,0,0,0,0,260,4.1,0,0,24.1,77777,9,999999999,189,0.0870,0,88,999.000,999.0,99.0
+1979,6,11,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,9.4,80,99400,51,938,308,17,2,17,1900,0,1900,580,270,3.1,0,0,24.1,77777,9,999999999,189,0.3390,0,88,999.000,999.0,99.0
+1979,6,11,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,11.1,75,99500,266,1325,322,100,137,72,10500,10300,8500,1370,290,3.6,0,0,24.1,77777,9,999999999,209,0.3390,0,88,999.000,999.0,99.0
+1979,6,11,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,11.1,65,99500,501,1325,332,264,351,130,27500,33200,14900,2530,310,5.2,0,0,24.1,77777,9,999999999,209,0.3390,0,88,999.000,999.0,99.0
+1979,6,11,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,11.7,61,99500,725,1325,340,455,494,183,48200,50100,20700,4050,300,4.6,0,0,24.1,77777,9,999999999,220,0.3390,0,88,999.000,999.0,99.0
+1979,6,11,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,12.8,59,99500,925,1325,349,634,584,224,68000,60600,25600,6210,270,4.6,0,0,24.1,77777,9,999999999,229,0.3390,0,88,999.000,999.0,99.0
+1979,6,11,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,12.2,51,99500,1085,1325,357,787,649,253,82200,65400,28500,9400,290,7.2,0,0,24.1,77777,9,999999999,220,0.3390,0,88,999.000,999.0,99.0
+1979,6,11,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,12.2,50,99500,1195,1325,359,889,681,272,93500,68900,31200,14430,300,6.2,0,0,24.1,77777,9,999999999,220,0.3390,0,88,999.000,999.0,99.0
+1979,6,11,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,11.1,43,99500,1247,1325,363,939,698,280,99200,70700,32500,19020,300,6.7,0,0,24.1,77777,9,999999999,209,0.3390,0,88,999.000,999.0,99.0
+1979,6,11,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,9.4,37,99400,1238,1325,371,896,654,284,94500,66200,32600,18340,290,5.2,1,1,24.1,77777,9,999999999,189,0.3390,0,88,999.000,999.0,99.0
+1979,6,11,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,12.2,44,99400,1168,1325,401,611,214,422,67200,22800,47000,18840,290,7.2,7,7,24.1,1520,9,999999999,229,0.3390,0,88,999.000,999.0,99.0
+1979,6,11,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,11.7,42,99400,1043,1325,400,595,247,400,64900,26200,44200,13980,300,6.2,7,7,24.1,1220,9,999999999,220,0.3390,0,88,999.000,999.0,99.0
+1979,6,11,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,10.6,39,99300,870,1325,394,403,164,296,44200,17300,32800,8490,320,9.3,6,6,24.1,1220,9,999999999,200,0.3390,0,88,999.000,999.0,99.0
+1979,6,11,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,10.6,40,99300,662,1325,387,328,252,203,35200,26100,22200,4580,320,6.7,5,5,24.1,77777,9,999999999,200,0.3390,0,88,999.000,999.0,99.0
+1979,6,11,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,11.1,43,99300,432,1325,382,169,110,133,18300,10300,15000,3010,300,5.2,4,4,24.1,77777,9,999999999,209,0.3390,0,88,999.000,999.0,99.0
+1979,6,11,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,10.6,45,99300,198,1325,373,54,46,48,6000,3100,5600,1020,40,5.2,3,3,24.1,77777,9,999999999,200,0.3390,0,88,999.000,999.0,99.0
+1979,6,11,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,6.1,41,99400,17,563,351,3,0,3,0,0,0,0,110,4.1,3,3,24.1,77777,9,999999999,160,0.3390,0,88,999.000,999.0,99.0
+1979,6,11,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,8.3,60,99400,0,0,348,0,0,0,0,0,0,0,140,2.1,7,7,24.1,2440,9,999999999,179,0.3390,0,88,999.000,999.0,99.0
+1979,6,11,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,8.3,62,99400,0,0,336,0,0,0,0,0,0,0,0,0.0,4,4,24.1,77777,9,999999999,179,0.3390,0,88,999.000,999.0,99.0
+1979,6,11,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,8.3,67,99400,0,0,328,0,0,0,0,0,0,0,160,2.1,3,3,24.1,77777,9,999999999,179,0.3390,0,88,999.000,999.0,99.0
+1979,6,11,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,8.9,70,99400,0,0,331,0,0,0,0,0,0,0,200,2.1,4,4,24.1,77777,9,999999999,179,0.3390,0,88,999.000,999.0,99.0
+1979,6,12,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,8.9,67,99400,0,0,334,0,0,0,0,0,0,0,0,0.0,4,4,24.1,77777,9,999999999,179,0.3390,0,88,999.000,999.0,99.0
+1979,6,12,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,8.9,75,99400,0,0,310,0,0,0,0,0,0,0,230,2.6,0,0,24.1,77777,9,999999999,179,0.3390,0,88,999.000,999.0,99.0
+1979,6,12,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,8.3,67,99400,0,0,314,0,0,0,0,0,0,0,100,2.1,0,0,24.1,77777,9,999999999,179,0.3390,0,88,999.000,999.0,99.0
+1979,6,12,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,8.9,77,99400,0,0,308,0,0,0,0,0,0,0,20,3.1,0,0,24.1,77777,9,999999999,179,0.3390,0,88,999.000,999.0,99.0
+1979,6,12,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,8.9,77,99500,51,938,308,21,49,16,2000,1600,2000,270,30,3.1,0,0,24.1,77777,9,999999999,179,0.1300,0,88,999.000,999.0,99.0
+1979,6,12,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,9.4,75,99500,266,1325,313,127,380,50,13000,29100,7100,910,40,3.1,0,0,24.1,77777,9,999999999,189,0.1300,0,88,999.000,999.0,99.0
+1979,6,12,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,10.0,65,99600,501,1325,326,305,598,78,32000,56400,10600,1550,90,3.1,0,0,19.3,77777,9,999999999,200,0.1300,0,88,999.000,999.0,99.0
+1979,6,12,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,10.0,57,99600,725,1325,336,502,724,104,53500,72800,13500,2380,60,4.1,0,0,19.3,77777,9,999999999,200,0.1300,0,88,999.000,999.0,99.0
+1979,6,12,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,10.0,53,99600,925,1325,348,636,701,145,67900,71600,17800,4110,60,3.1,1,1,24.1,77777,9,999999999,200,0.1300,0,88,999.000,999.0,99.0
+1979,6,12,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,11.1,51,99600,1085,1325,374,628,488,227,69000,51100,27100,8610,70,3.6,6,6,24.1,2440,9,999999999,209,0.1300,0,88,999.000,999.0,99.0
+1979,6,12,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,9.4,51,99600,1195,1325,374,722,397,362,76800,41500,39400,19930,70,4.6,8,8,24.1,2440,9,999999999,189,0.1300,0,88,999.000,999.0,99.0
+1979,6,12,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,7.8,49,99700,1247,1325,374,475,148,335,53300,15900,38300,19390,70,5.2,9,9,24.1,2440,9,999999999,170,0.1300,0,88,999.000,999.0,99.0
+1979,6,12,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,7.8,49,99700,1238,1325,366,780,443,366,83600,46300,40300,24570,100,3.1,9,8,24.1,2440,9,999999999,170,0.1300,0,88,999.000,999.0,99.0
+1979,6,12,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,9.4,44,99600,1169,1325,379,770,470,355,82000,49100,38600,17720,90,5.7,8,7,24.1,7620,9,999999999,189,0.1300,0,88,999.000,999.0,99.0
+1979,6,12,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,8.9,43,99500,1044,1325,365,693,535,271,74500,55800,30500,9430,70,6.2,8,3,24.1,77777,9,999999999,179,0.1300,0,88,999.000,999.0,99.0
+1979,6,12,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,6.7,37,99600,871,1325,365,590,550,229,62900,56800,25500,5920,80,5.2,9,4,24.1,77777,9,999999999,160,0.1300,0,88,999.000,999.0,99.0
+1979,6,12,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,5.0,36,99600,663,1325,366,293,219,184,31700,22700,20300,4070,70,6.2,9,7,24.1,3050,9,999999999,139,0.1300,0,88,999.000,999.0,99.0
+1979,6,12,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,3.9,36,99500,434,1325,364,147,54,130,16200,5000,14500,3470,60,5.2,9,8,24.1,7620,9,999999999,139,0.1300,0,88,999.000,999.0,99.0
+1979,6,12,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,3.9,39,99500,200,1325,341,67,66,57,7300,4500,6600,1210,60,5.2,7,3,24.1,77777,9,999999999,139,0.1300,0,88,999.000,999.0,99.0
+1979,6,12,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,3.3,40,99600,18,563,360,3,0,3,0,0,0,0,60,4.6,10,9,24.1,7620,9,999999999,129,0.1300,0,88,999.000,999.0,99.0
+1979,6,12,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,3.9,44,99600,0,0,365,0,0,0,0,0,0,0,60,5.2,10,10,24.1,7620,9,999999999,129,0.1300,0,88,999.000,999.0,99.0
+1979,6,12,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,4.4,48,99600,0,0,364,0,0,0,0,0,0,0,50,4.1,10,10,24.1,3050,9,999999999,139,0.1300,0,88,999.000,999.0,99.0
+1979,6,12,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,4.4,50,99600,0,0,360,0,0,0,0,0,0,0,90,4.1,10,10,24.1,3050,9,999999999,139,0.1300,0,88,999.000,999.0,99.0
+1979,6,12,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,6.1,56,99600,0,0,363,0,0,0,0,0,0,0,70,4.1,10,10,24.1,1400,9,999999999,160,0.1300,0,88,999.000,999.0,99.0
+1979,6,13,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,9.4,78,99600,0,0,358,0,0,0,0,0,0,0,10,4.1,10,10,11.3,1400,9,999999999,189,0.1300,0,88,999.000,999.0,99.0
+1979,6,13,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,11.1,87,99600,0,0,360,0,0,0,0,0,0,0,40,4.1,10,10,19.3,1400,9,999999999,209,0.1300,0,88,999.000,999.0,99.0
+1979,6,13,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,11.7,81,99600,0,0,369,0,0,0,0,0,0,0,90,4.6,10,10,24.1,1400,9,999999999,220,0.1300,0,88,999.000,999.0,99.0
+1979,6,13,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,10.6,72,99600,0,0,361,0,0,0,0,0,0,0,90,5.2,10,9,24.1,1400,9,999999999,200,0.1300,0,88,999.000,999.0,99.0
+1979,6,13,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,10.6,70,99600,52,938,356,10,0,10,1200,0,1200,370,60,4.1,8,8,24.1,1400,9,999999999,200,0.0950,0,88,999.000,999.0,99.0
+1979,6,13,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,11.7,75,99600,266,1324,351,90,123,65,9600,9200,7700,1210,100,6.2,8,7,19.3,1370,9,999999999,220,0.0950,0,88,999.000,999.0,99.0
+1979,6,13,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,12.8,75,99700,500,1324,358,212,139,159,23000,13500,17900,3680,110,5.2,8,7,19.3,2440,9,999999999,229,0.0950,0,88,999.000,999.0,99.0
+1979,6,13,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,14.4,73,99700,725,1324,361,450,567,138,46900,56300,16100,3040,140,4.6,4,4,11.3,77777,9,999999999,250,0.0950,0,88,999.000,999.0,99.0
+1979,6,13,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,15.6,71,99700,924,1324,371,631,565,235,67500,58600,26500,6540,160,5.7,4,4,11.3,77777,9,999999999,270,0.0950,0,88,999.000,999.0,99.0
+1979,6,13,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,15.6,66,99700,1085,1324,393,392,97,312,43600,10400,35000,11680,130,3.6,8,8,12.9,910,9,999999999,270,0.0950,0,88,999.000,999.0,99.0
+1979,6,13,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,15.6,66,99700,1195,1324,393,527,208,339,58500,22700,38000,16760,170,3.1,8,8,12.9,850,9,999999999,270,0.0950,0,88,999.000,999.0,99.0
+1979,6,13,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,15.6,64,99600,1247,1324,396,499,147,360,55700,15800,40900,20880,130,3.1,8,8,14.5,850,9,999999999,270,0.0950,0,88,999.000,999.0,99.0
+1979,6,13,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,16.7,71,99600,1239,1324,414,365,4,362,43500,400,43200,16350,150,3.6,10,10,14.5,670,9,999999999,290,0.0950,0,88,999.000,999.0,99.0
+1979,6,13,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,16.1,78,99700,1169,1324,401,301,6,296,36100,500,35600,13880,150,3.1,10,10,12.9,760,9,999999999,279,0.0950,0,88,999.000,999.0,99.0
+1979,6,13,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,16.1,68,99600,1044,1324,394,523,287,297,57600,31100,33000,10000,160,4.1,9,8,11.3,850,9,999999999,279,0.0950,0,88,999.000,999.0,99.0
+1979,6,13,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,16.1,66,99700,872,1324,405,385,151,285,42200,15900,31700,8190,160,3.1,9,9,11.3,850,9,999999999,279,0.0950,0,88,999.000,999.0,99.0
+1979,6,13,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,16.1,66,99600,664,1324,397,345,242,224,37600,24800,25100,5590,160,5.2,8,8,12.9,850,9,999999999,279,0.0950,0,88,999.000,999.0,99.0
+1979,6,13,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,16.1,68,99600,435,1324,377,222,381,98,23600,34700,12200,1830,150,4.1,4,4,12.9,77777,9,999999999,279,0.0950,0,88,999.000,999.0,99.0
+1979,6,13,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,15.0,66,99600,201,1324,362,79,274,39,8600,17900,5900,690,110,4.6,3,1,11.3,77777,9,999999999,259,0.0950,0,88,999.000,999.0,99.0
+1979,6,13,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,15.0,71,99600,19,585,356,8,20,6,0,0,0,0,120,4.1,3,1,11.3,77777,9,999999999,270,0.0950,0,88,999.000,999.0,99.0
+1979,6,13,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,15.0,73,99600,0,0,347,0,0,0,0,0,0,0,120,4.1,2,0,9.7,77777,9,999999999,259,0.0950,0,88,999.000,999.0,99.0
+1979,6,13,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,15.0,78,99700,0,0,341,0,0,0,0,0,0,0,120,3.1,0,0,8.0,77777,9,999999999,259,0.0950,0,88,999.000,999.0,99.0
+1979,6,13,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,15.6,84,99600,0,0,357,0,0,0,0,0,0,0,140,4.6,4,4,9.7,77777,9,999999999,270,0.0950,0,88,999.000,999.0,99.0
+1979,6,13,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,15.0,81,99600,0,0,345,0,0,0,0,0,0,0,150,3.6,3,1,8.0,77777,9,999999999,259,0.0950,0,88,999.000,999.0,99.0
+1979,6,14,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,15.0,84,99500,0,0,336,0,0,0,0,0,0,0,150,3.6,0,0,8.0,77777,9,999999999,259,0.0950,0,88,999.000,999.0,99.0
+1979,6,14,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,15.0,84,99500,0,0,336,0,0,0,0,0,0,0,180,4.1,0,0,8.0,77777,9,999999999,259,0.0950,0,88,999.000,999.0,99.0
+1979,6,14,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,15.6,87,99500,0,0,370,0,0,0,0,0,0,0,160,3.1,8,8,8.0,1400,9,999999999,270,0.0950,0,88,999.000,999.0,99.0
+1979,6,14,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,15.0,87,99500,0,0,351,0,0,0,0,0,0,0,160,4.1,4,4,8.0,77777,9,999999999,259,0.0950,0,88,999.000,999.0,99.0
+1979,6,14,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,15.6,87,99500,52,938,348,17,2,16,1800,0,1800,550,170,4.6,7,2,4.8,77777,9,999999999,270,0.2800,0,88,999.000,999.0,99.0
+1979,6,14,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,15.6,84,99600,266,1324,363,93,15,90,10200,700,10000,2800,160,4.1,10,6,6.4,7620,9,999999999,270,0.2800,0,88,999.000,999.0,99.0
+1979,6,14,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,16.1,76,99600,500,1324,375,209,155,150,22700,15100,17000,3470,170,5.7,10,6,6.4,7620,9,999999999,279,0.2800,0,88,999.000,999.0,99.0
+1979,6,14,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,16.7,71,99600,725,1324,388,378,268,230,40400,28200,25000,5440,200,4.1,10,7,6.4,7620,9,999999999,290,0.2800,0,88,999.000,999.0,99.0
+1979,6,14,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,17.8,69,99500,924,1324,399,554,311,336,59400,33400,36000,9810,190,6.2,10,7,6.4,7620,9,999999999,309,0.2800,0,88,999.000,999.0,99.0
+1979,6,14,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,18.3,64,99500,1084,1324,436,445,136,333,49300,14500,37300,12460,190,5.7,10,10,8.0,7620,9,999999999,320,0.2800,0,88,999.000,999.0,99.0
+1979,6,14,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,18.3,60,99500,1195,1324,430,401,59,347,44300,6000,38800,17170,210,5.2,10,9,8.0,7620,9,999999999,320,0.2800,0,88,999.000,999.0,99.0
+1979,6,14,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,18.3,58,99500,1247,1324,417,715,325,408,78800,35400,45400,25460,190,6.2,10,7,8.0,7620,9,999999999,320,0.2800,0,88,999.000,999.0,99.0
+1979,6,14,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,18.9,57,99400,1239,1324,424,477,129,356,53300,13800,40300,19960,210,6.2,10,7,9.7,7620,9,999999999,329,0.2800,0,88,999.000,999.0,99.0
+1979,6,14,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,18.3,50,99400,1170,1324,418,833,527,367,88400,55000,39800,18460,190,7.7,10,3,11.3,77777,9,999999999,320,0.2800,0,88,999.000,999.0,99.0
+1979,6,14,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,17.2,46,99300,1045,1324,416,719,534,298,76700,55600,32700,10480,210,7.7,8,3,12.9,77777,9,999999999,300,0.2800,0,88,999.000,999.0,99.0
+1979,6,14,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,16.7,46,99300,873,1324,413,568,431,284,61300,46200,30800,7670,180,8.8,10,3,16.1,77777,9,999999999,290,0.2800,0,88,999.000,999.0,99.0
+1979,6,14,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,16.1,43,99200,666,1324,411,390,396,192,42100,41100,21400,4290,210,6.2,8,2,16.1,77777,9,999999999,279,0.2800,0,88,999.000,999.0,99.0
+1979,6,14,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,15.6,43,99200,437,1324,407,204,223,131,21700,20800,14800,2670,200,9.3,5,2,16.1,77777,9,999999999,270,0.2800,0,88,999.000,999.0,99.0
+1979,6,14,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,14.4,41,99200,203,1324,403,58,66,48,6400,4600,5700,1020,190,5.7,4,2,16.1,77777,9,999999999,250,0.2800,0,88,999.000,999.0,99.0
+1979,6,14,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,14.4,47,99200,19,585,391,5,0,5,0,0,0,0,180,4.1,4,2,16.1,77777,9,999999999,250,0.2800,0,88,999.000,999.0,99.0
+1979,6,14,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.6,14.4,50,99300,0,0,373,0,0,0,0,0,0,0,170,5.2,0,0,19.3,77777,9,999999999,250,0.2800,0,88,999.000,999.0,99.0
+1979,6,14,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.1,15.0,50,99300,0,0,376,0,0,0,0,0,0,0,180,7.2,0,0,19.3,77777,9,999999999,259,0.2800,0,88,999.000,999.0,99.0
+1979,6,14,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.1,15.0,50,99300,0,0,376,0,0,0,0,0,0,0,190,7.2,0,0,19.3,77777,9,999999999,259,0.2800,0,88,999.000,999.0,99.0
+1979,6,14,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.0,15.0,54,99300,0,0,371,0,0,0,0,0,0,0,190,7.7,0,0,24.1,77777,9,999999999,259,0.2800,0,88,999.000,999.0,99.0
+1979,6,15,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.0,14.4,52,99300,0,0,370,0,0,0,0,0,0,0,190,7.7,0,0,24.1,77777,9,999999999,250,0.2800,0,88,999.000,999.0,99.0
+1979,6,15,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.9,14.4,56,99200,0,0,365,0,0,0,0,0,0,0,200,8.2,0,0,24.1,77777,9,999999999,259,0.2800,0,88,999.000,999.0,99.0
+1979,6,15,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,14.4,58,99200,0,0,362,0,0,0,0,0,0,0,190,6.2,0,0,24.1,77777,9,999999999,250,0.2800,0,88,999.000,999.0,99.0
+1979,6,15,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,14.4,59,99300,0,0,359,0,0,0,0,0,0,0,200,4.6,0,0,24.1,77777,9,999999999,250,0.2800,0,88,999.000,999.0,99.0
+1979,6,15,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,15.0,64,99300,52,938,357,18,13,17,1900,700,1900,410,200,5.2,0,0,14.5,77777,9,999999999,259,0.2190,0,88,999.000,999.0,99.0
+1979,6,15,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,15.6,64,99300,266,1324,361,113,246,63,11700,18500,8000,1140,200,7.7,0,0,12.9,77777,9,999999999,270,0.2190,0,88,999.000,999.0,99.0
+1979,6,15,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,16.1,60,99300,500,1324,369,284,474,104,30300,44900,13300,1970,190,8.2,0,0,12.9,77777,9,999999999,279,0.2190,0,88,999.000,999.0,99.0
+1979,6,15,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,17.2,60,99400,725,1324,377,476,607,141,49500,60200,16400,3100,220,8.2,0,0,11.3,77777,9,999999999,300,0.2190,0,88,999.000,999.0,99.0
+1979,6,15,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,17.2,56,99400,924,1324,382,655,690,170,69000,70000,20000,4730,210,7.2,0,0,11.3,77777,9,999999999,300,0.2190,0,88,999.000,999.0,99.0
+1979,6,15,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,17.8,53,99300,1084,1324,391,799,740,191,85200,75700,23100,7300,220,8.8,0,0,12.9,77777,9,999999999,309,0.2190,0,88,999.000,999.0,99.0
+1979,6,15,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,17.2,48,99300,1194,1324,396,900,770,203,96700,79100,25200,11010,200,9.3,0,0,12.9,77777,9,999999999,300,0.2190,0,88,999.000,999.0,99.0
+1979,6,15,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,17.2,46,99300,1247,1324,407,856,681,212,92200,70000,26100,14730,210,9.8,1,1,12.9,77777,9,999999999,300,0.2190,0,88,999.000,999.0,99.0
+1979,6,15,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,17.8,45,99200,1239,1324,414,888,719,213,95600,73800,26300,14150,190,9.3,3,1,12.9,77777,9,999999999,309,0.2190,0,88,999.000,999.0,99.0
+1979,6,15,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,16.7,41,99200,1170,1324,408,875,762,201,94100,78200,24800,9960,200,6.2,0,0,12.9,77777,9,999999999,290,0.2190,0,88,999.000,999.0,99.0
+1979,6,15,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,16.7,41,99100,1046,1324,408,763,731,185,81400,74700,22300,6460,210,5.7,0,0,12.9,77777,9,999999999,290,0.2190,0,88,999.000,999.0,99.0
+1979,6,15,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,16.1,39,99100,874,1324,407,602,667,163,63700,67400,19100,4220,200,7.2,0,0,14.5,77777,9,999999999,279,0.2190,0,88,999.000,999.0,99.0
+1979,6,15,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,15.0,38,99000,667,1324,415,398,498,149,42900,50000,17600,3110,200,9.3,2,2,14.5,77777,9,999999999,259,0.2190,0,88,999.000,999.0,99.0
+1979,6,15,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,14.4,37,99100,438,1324,406,213,377,90,23000,34500,11500,1670,200,6.2,2,1,16.1,77777,9,999999999,250,0.2190,0,88,999.000,999.0,99.0
+1979,6,15,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,13.3,37,99100,204,1324,404,61,63,52,6700,4400,6100,1100,190,5.2,7,2,16.1,77777,9,999999999,229,0.2190,0,88,999.000,999.0,99.0
+1979,6,15,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,13.3,40,99100,20,585,393,5,2,5,0,0,0,0,200,5.7,2,1,16.1,77777,9,999999999,240,0.2190,0,88,999.000,999.0,99.0
+1979,6,15,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,27.2,12.8,41,99200,0,0,379,0,0,0,0,0,0,0,210,5.7,0,0,19.3,77777,9,999999999,229,0.2190,0,88,999.000,999.0,99.0
+1979,6,15,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.1,13.3,45,99200,0,0,374,0,0,0,0,0,0,0,210,7.2,0,0,19.3,77777,9,999999999,240,0.2190,0,88,999.000,999.0,99.0
+1979,6,15,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.6,13.3,47,99200,0,0,372,0,0,0,0,0,0,0,210,6.2,0,0,19.3,77777,9,999999999,240,0.2190,0,88,999.000,999.0,99.0
+1979,6,15,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.0,13.3,48,99200,0,0,369,0,0,0,0,0,0,0,220,6.2,0,0,24.1,77777,9,999999999,240,0.2190,0,88,999.000,999.0,99.0
+1979,6,16,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.9,13.3,52,99200,0,0,363,0,0,0,0,0,0,0,200,5.7,0,0,24.1,77777,9,999999999,240,0.2190,0,88,999.000,999.0,99.0
+1979,6,16,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,12.8,52,99200,0,0,360,0,0,0,0,0,0,0,200,5.2,0,0,24.1,77777,9,999999999,229,0.2190,0,88,999.000,999.0,99.0
+1979,6,16,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,12.8,55,99200,0,0,355,0,0,0,0,0,0,0,200,4.6,0,0,24.1,77777,9,999999999,229,0.2190,0,88,999.000,999.0,99.0
+1979,6,16,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,12.8,57,99200,0,0,352,0,0,0,0,0,0,0,190,4.6,0,0,24.1,77777,9,999999999,229,0.2190,0,88,999.000,999.0,99.0
+1979,6,16,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,12.8,61,99200,52,937,347,19,5,18,2100,0,2100,610,180,4.1,2,0,24.1,77777,9,999999999,229,0.2780,0,88,999.000,999.0,99.0
+1979,6,16,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,13.9,61,99200,266,1324,353,105,181,68,11100,13600,8300,1280,180,4.1,0,0,14.5,77777,9,999999999,240,0.2780,0,88,999.000,999.0,99.0
+1979,6,16,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,15.0,58,99200,500,1324,365,273,407,118,28700,38500,14200,2270,180,4.1,0,0,16.1,77777,9,999999999,259,0.2780,0,88,999.000,999.0,99.0
+1979,6,16,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,15.6,56,99200,724,1324,372,466,536,171,49600,54400,19800,3750,200,5.7,2,0,16.1,77777,9,999999999,270,0.2780,0,88,999.000,999.0,99.0
+1979,6,16,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,16.7,54,99100,923,1324,394,600,463,275,63100,47900,29600,7750,190,5.7,7,2,16.1,77777,9,999999999,290,0.2780,0,88,999.000,999.0,99.0
+1979,6,16,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,17.2,53,99100,1084,1324,395,767,593,280,82600,61900,31800,10740,190,8.2,7,1,16.1,77777,9,999999999,300,0.2780,0,88,999.000,999.0,99.0
+1979,6,16,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,17.8,51,99100,1194,1324,402,856,642,274,90000,64900,31300,14560,190,7.2,7,1,16.1,77777,9,999999999,309,0.2780,0,88,999.000,999.0,99.0
+1979,6,16,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,17.2,46,99000,1247,1324,412,872,592,312,91400,59600,35100,21240,180,6.7,6,2,16.1,77777,9,999999999,300,0.2780,0,88,999.000,999.0,99.0
+1979,6,16,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,17.2,45,98900,1239,1324,416,900,634,305,94500,63900,34500,19890,180,7.2,7,2,16.1,77777,9,999999999,300,0.2780,0,88,999.000,999.0,99.0
+1979,6,16,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,17.2,43,98800,1171,1324,418,852,648,278,89400,65400,31500,13470,180,9.3,5,2,16.1,77777,9,999999999,290,0.2780,0,88,999.000,999.0,99.0
+1979,6,16,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,16.1,40,98700,1047,1324,417,712,547,280,76500,57000,31300,9840,190,7.7,5,2,16.1,77777,9,999999999,279,0.2780,0,88,999.000,999.0,99.0
+1979,6,16,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,15.6,39,98700,875,1324,416,508,389,252,55500,41800,27800,6680,180,7.2,7,2,16.1,77777,9,999999999,270,0.2780,0,88,999.000,999.0,99.0
+1979,6,16,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,15.6,40,98600,668,1324,414,389,400,188,40800,40000,20600,4030,190,7.2,8,2,16.1,77777,9,999999999,270,0.2780,0,88,999.000,999.0,99.0
+1979,6,16,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,14.4,39,98600,439,1324,416,173,146,125,18900,13700,14400,2830,180,7.2,8,4,16.1,77777,9,999999999,250,0.2780,0,88,999.000,999.0,99.0
+1979,6,16,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,14.4,40,98500,206,1324,413,52,26,48,5700,1900,5400,1200,170,7.7,9,4,16.1,77777,9,999999999,250,0.2780,0,88,999.000,999.0,99.0
+1979,6,16,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,13.9,41,98500,20,607,403,6,0,6,0,0,0,0,190,6.2,8,3,16.1,77777,9,999999999,240,0.2780,0,88,999.000,999.0,99.0
+1979,6,16,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,27.8,13.9,43,98500,0,0,400,0,0,0,0,0,0,0,200,7.2,5,3,19.3,77777,9,999999999,250,0.2780,0,88,999.000,999.0,99.0
+1979,6,16,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,27.8,13.9,43,98500,0,0,400,0,0,0,0,0,0,0,200,9.3,3,3,19.3,77777,9,999999999,250,0.2780,0,88,999.000,999.0,99.0
+1979,6,16,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.7,13.9,45,98500,0,0,385,0,0,0,0,0,0,0,210,7.2,1,1,19.3,77777,9,999999999,240,0.2780,0,88,999.000,999.0,99.0
+1979,6,16,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.6,14.4,50,98500,0,0,373,0,0,0,0,0,0,0,200,6.2,0,0,19.3,77777,9,999999999,250,0.2780,0,88,999.000,999.0,99.0
+1979,6,17,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.0,15.0,54,98400,0,0,371,0,0,0,0,0,0,0,210,6.2,0,0,24.1,77777,9,999999999,259,0.2780,0,88,999.000,999.0,99.0
+1979,6,17,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,24.4,15.6,58,98400,0,0,369,0,0,0,0,0,0,0,220,5.7,0,0,24.1,77777,9,999999999,270,0.2780,0,88,999.000,999.0,99.0
+1979,6,17,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.9,16.1,62,98400,0,0,367,0,0,0,0,0,0,0,200,5.7,0,0,24.1,77777,9,999999999,279,0.2780,0,88,999.000,999.0,99.0
+1979,6,17,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,16.7,66,98400,0,0,364,0,0,0,0,0,0,0,210,6.2,0,0,19.3,77777,9,999999999,290,0.2780,0,88,999.000,999.0,99.0
+1979,6,17,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,17.8,71,98500,51,937,366,21,54,16,2100,1700,2000,270,220,4.1,0,0,11.3,77777,9,999999999,309,0.1220,0,88,999.000,999.0,99.0
+1979,6,17,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,18.3,74,98600,265,1323,411,58,34,51,6400,2700,5800,1360,270,4.6,9,9,12.9,670,9,999999999,320,0.1220,0,88,999.000,999.0,99.0
+1979,6,17,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,16.7,71,98700,499,1323,394,153,61,129,16700,5800,14500,3680,290,4.6,9,8,19.3,760,9,999999999,290,0.1220,0,88,999.000,999.0,99.0
+1979,6,17,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,17.2,69,98800,724,1323,377,442,550,140,46100,54600,16200,3070,300,5.2,6,2,24.1,77777,9,999999999,300,0.1220,0,88,999.000,999.0,99.0
+1979,6,17,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,17.2,69,98800,923,1323,395,500,363,245,53100,37600,26900,6830,10,6.2,8,7,19.3,610,9,999999999,300,0.1220,0,88,999.000,999.0,99.0
+1979,6,17,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,14.4,71,98900,1083,1323,388,512,108,423,56400,11200,47200,16950,40,6.7,9,9,19.3,490,9,999999999,250,0.1220,0,88,999.000,999.0,99.0
+1979,6,17,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,15.6,71,99000,1194,1323,387,597,236,383,65600,25700,42400,19160,10,5.2,9,8,19.3,3050,9,999999999,270,0.1220,0,88,999.000,999.0,99.0
+1979,6,17,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,15.0,68,99000,1247,1323,395,391,132,266,44500,14200,31000,15490,30,6.2,9,9,19.3,520,9,999999999,259,0.1220,0,88,999.000,999.0,99.0
+1979,6,17,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,14.4,66,99000,1240,1323,369,828,604,260,87800,61400,30100,17160,20,6.7,9,4,24.1,77777,9,999999999,250,0.1220,0,88,999.000,999.0,99.0
+1979,6,17,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,14.4,62,99100,1171,1323,378,750,452,349,80000,47200,38100,17630,30,5.2,9,5,24.1,7620,9,999999999,250,0.1220,0,88,999.000,999.0,99.0
+1979,6,17,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,13.3,59,99100,1047,1323,368,700,560,256,75700,58500,29400,8960,20,6.2,7,3,24.1,77777,9,999999999,240,0.1220,0,88,999.000,999.0,99.0
+1979,6,17,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,12.8,61,99100,876,1323,375,447,240,289,48300,25700,31200,7850,30,6.2,8,7,24.1,3050,9,999999999,229,0.1220,0,88,999.000,999.0,99.0
+1979,6,17,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,12.2,65,99200,669,1323,390,89,4,87,10800,300,10700,4120,40,7.7,10,10,24.1,1680,9,999999999,220,0.1220,0,88,999.000,999.0,99.0
+1979,6,17,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,12.8,70,99200,441,1323,354,229,385,102,24300,35200,12600,1920,30,6.2,4,4,24.1,77777,9,999999999,229,0.1220,0,88,999.000,999.0,99.0
+1979,6,17,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,11.1,70,99200,207,1323,350,66,112,49,7100,7300,5900,900,20,6.2,6,6,24.1,3050,9,999999999,209,0.1220,0,88,999.000,999.0,99.0
+1979,6,17,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,10.6,72,99200,21,607,371,4,0,4,0,0,0,0,10,6.2,10,10,24.1,1680,9,999999999,200,0.1220,0,88,999.000,999.0,99.0
+1979,6,17,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,10.0,70,99300,0,0,347,0,0,0,0,0,0,0,20,4.1,7,7,24.1,2440,9,999999999,200,0.1220,0,88,999.000,999.0,99.0
+1979,6,17,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,10.0,70,99400,0,0,353,0,0,0,0,0,0,0,20,4.6,8,8,24.1,2440,9,999999999,200,0.1220,0,88,999.000,999.0,99.0
+1979,6,17,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,10.0,70,99300,0,0,360,0,0,0,0,0,0,0,40,6.2,9,9,24.1,1680,9,999999999,200,0.1220,0,88,999.000,999.0,99.0
+1979,6,17,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,10.6,75,99200,0,0,368,0,0,0,0,0,0,0,40,5.7,10,10,24.1,1680,9,999999999,200,0.1220,0,88,999.000,999.0,99.0
+1979,6,18,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,11.1,78,99200,0,0,369,0,0,0,0,0,0,0,50,5.7,10,10,11.3,1680,9,999999999,209,0.1220,0,88,999.000,999.0,99.0
+1979,6,18,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,11.1,83,99200,0,0,363,0,0,0,0,0,0,0,50,3.6,10,10,24.1,2130,9,999999999,209,0.1220,0,88,999.000,999.0,99.0
+1979,6,18,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,11.1,87,99400,0,0,360,0,0,0,0,0,0,0,60,4.6,10,10,19.3,2130,9,999999999,209,0.1220,0,88,999.000,999.0,99.0
+1979,6,18,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,11.1,87,99200,0,0,360,0,0,0,0,0,0,0,110,5.7,10,10,24.1,3050,9,999999999,209,0.1220,0,88,999.000,999.0,99.0
+1979,6,18,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,11.7,90,99400,51,937,343,15,0,15,1700,0,1700,530,30,5.2,9,8,24.1,2740,9,999999999,220,0.3190,0,88,999.000,999.0,99.0
+1979,6,18,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,11.1,87,99500,265,1323,350,59,12,57,6700,400,6700,2080,40,6.2,10,9,24.1,2740,9,999999999,209,0.3190,0,88,999.000,999.0,99.0
+1979,6,18,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,12.2,87,99500,499,1323,349,205,77,176,22500,7400,19700,4680,70,6.2,10,8,24.1,7620,9,999999999,220,0.3190,0,88,999.000,999.0,99.0
+1979,6,18,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,12.2,78,99600,723,1323,365,213,48,187,23500,4800,20900,6050,60,7.7,10,9,24.1,910,9,999999999,220,0.3190,0,88,999.000,999.0,99.0
+1979,6,18,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,12.2,75,99600,922,1323,379,182,1,181,21800,100,21700,8720,60,5.7,10,10,24.1,7620,9,999999999,220,0.3190,0,88,999.000,999.0,99.0
+1979,6,18,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,11.7,70,99600,1083,1323,381,315,3,312,37000,300,36800,14150,60,5.2,10,10,24.1,2740,9,999999999,220,0.3190,0,88,999.000,999.0,99.0
+1979,6,18,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,11.1,72,99600,1194,1323,374,212,7,206,26200,500,25700,10390,40,5.2,10,10,19.3,1160,9,999999999,209,0.3190,0,88,999.000,999.0,99.0
+1979,6,18,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,11.7,81,99700,1247,1323,369,259,4,255,31700,300,31400,12510,50,4.1,10,10,9.7,1370,9,999999999,220,0.3190,0,88,999.000,999.0,99.0
+1979,6,18,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,13.3,87,99600,1240,1323,374,365,1,365,43500,100,43400,16450,50,6.7,10,10,11.3,1370,9,999999999,240,0.3190,0,88,999.000,999.0,99.0
+1979,6,18,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,12.8,75,99500,1172,1323,372,407,6,401,47500,600,47000,17230,30,6.7,10,9,11.3,1370,9,999999999,229,0.3190,0,88,999.000,999.0,99.0
+1979,6,18,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,12.8,70,99600,1048,1323,359,569,266,359,61900,28800,39000,12510,50,6.2,10,6,19.3,7620,9,999999999,229,0.3190,0,88,999.000,999.0,99.0
+1979,6,18,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,12.2,65,99600,877,1323,353,564,421,285,60900,45100,30900,7730,20,5.2,10,3,24.1,77777,9,999999999,220,0.3190,0,88,999.000,999.0,99.0
+1979,6,18,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,10.6,61,99600,670,1323,357,337,213,230,36700,21800,25700,5750,40,6.2,8,6,24.1,2740,9,999999999,200,0.3190,0,88,999.000,999.0,99.0
+1979,6,18,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,10.0,63,99600,442,1323,379,102,2,101,11600,100,11600,3940,40,5.7,10,10,24.1,760,9,999999999,200,0.3190,0,88,999.000,999.0,99.0
+1979,6,18,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,8.9,65,99600,208,1323,330,60,48,53,6600,3600,6100,1310,30,5.7,5,2,24.1,77777,9,999999999,179,0.3190,0,88,999.000,999.0,99.0
+1979,6,18,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,8.3,69,99600,21,628,325,7,0,7,0,0,0,0,30,3.6,8,3,24.1,77777,9,999999999,179,0.3190,0,88,999.000,999.0,99.0
+1979,6,18,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,7.8,69,99600,0,0,319,0,0,0,0,0,0,0,30,5.2,7,2,24.1,77777,9,999999999,170,0.3190,0,88,999.000,999.0,99.0
+1979,6,18,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,8.3,72,99600,0,0,323,0,0,0,0,0,0,0,50,3.1,5,3,24.1,77777,9,999999999,179,0.3190,0,88,999.000,999.0,99.0
+1979,6,18,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,8.9,72,99600,0,0,328,0,0,0,0,0,0,0,40,3.1,4,4,24.1,77777,9,999999999,179,0.3190,0,88,999.000,999.0,99.0
+1979,6,18,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,10.0,78,99600,0,0,352,0,0,0,0,0,0,0,30,3.6,9,9,24.1,3050,9,999999999,200,0.3190,0,88,999.000,999.0,99.0
+1979,6,19,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,10.6,78,99600,0,0,365,0,0,0,0,0,0,0,40,2.6,10,10,24.1,3050,9,999999999,200,0.3190,0,88,999.000,999.0,99.0
+1979,6,19,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,11.1,70,99600,0,0,367,0,0,0,0,0,0,0,70,3.6,9,9,24.1,3660,9,999999999,209,0.3190,0,88,999.000,999.0,99.0
+1979,6,19,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,11.7,73,99600,0,0,368,0,0,0,0,0,0,0,50,5.2,9,9,24.1,3050,9,999999999,220,0.3190,0,88,999.000,999.0,99.0
+1979,6,19,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,11.7,73,99600,0,0,378,0,0,0,0,0,0,0,100,5.2,10,10,24.1,980,9,999999999,220,0.3190,0,88,999.000,999.0,99.0
+1979,6,19,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,12.2,72,99600,51,937,348,16,1,16,1800,0,1800,550,120,4.6,5,4,12.9,77777,9,999999999,220,0.3440,0,88,999.000,999.0,99.0
+1979,6,19,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,11.7,68,99600,264,1323,360,61,18,57,6700,1500,6400,1490,110,6.2,8,7,12.9,3660,9,999999999,220,0.3440,0,88,999.000,999.0,99.0
+1979,6,19,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,12.2,68,99600,498,1323,356,188,118,144,20600,11500,16300,3330,120,6.2,5,5,11.3,77777,9,999999999,220,0.3440,0,88,999.000,999.0,99.0
+1979,6,19,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,13.9,66,99600,722,1323,377,259,80,214,28400,8000,24000,6750,120,5.2,8,7,9.7,1370,9,999999999,250,0.3440,0,88,999.000,999.0,99.0
+1979,6,19,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,15.6,66,99600,922,1323,373,609,543,229,65300,56300,25900,6350,110,6.2,3,3,6.4,77777,9,999999999,270,0.3440,0,88,999.000,999.0,99.0
+1979,6,19,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,16.7,64,99500,1082,1323,386,647,354,356,70500,38400,39000,13210,100,6.7,4,4,6.4,77777,9,999999999,290,0.3440,0,88,999.000,999.0,99.0
+1979,6,19,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,15.6,64,99500,1193,1323,390,788,450,381,83500,46900,41100,21040,120,7.2,7,7,6.4,1830,9,999999999,270,0.3440,0,88,999.000,999.0,99.0
+1979,6,19,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,17.8,66,99500,1247,1323,408,515,67,452,56900,6900,50400,24640,100,6.2,8,8,6.4,1520,9,999999999,309,0.3440,0,88,999.000,999.0,99.0
+1979,6,19,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,20.0,65,99400,1240,1323,426,799,362,459,87200,39300,50300,28050,140,7.7,8,8,6.4,1520,9,999999999,350,0.3440,0,88,999.000,999.0,99.0
+1979,6,19,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,20.6,65,99400,1172,1323,415,799,474,378,84500,49400,40600,19250,150,7.2,5,5,6.4,77777,9,999999999,359,0.3440,0,88,999.000,999.0,99.0
+1979,6,19,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,21.1,65,99300,1048,1323,434,584,306,342,63700,33200,37400,11850,130,6.2,8,8,6.4,1220,9,999999999,370,0.3440,0,88,999.000,999.0,99.0
+1979,6,19,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,21.1,63,99300,877,1323,419,541,360,302,58100,38600,32500,8280,130,7.2,4,4,6.4,77777,9,999999999,379,0.3440,0,88,999.000,999.0,99.0
+1979,6,19,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,21.1,63,99200,671,1323,437,199,10,194,22700,800,22300,7840,130,6.2,8,8,6.4,1220,9,999999999,379,0.3440,0,88,999.000,999.0,99.0
+1979,6,19,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,20.6,65,99200,443,1323,419,175,148,126,19200,14000,14500,2860,120,5.7,8,6,6.4,2740,9,999999999,359,0.3440,0,88,999.000,999.0,99.0
+1979,6,19,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,20.0,67,99200,209,1323,398,58,55,50,6400,3900,5800,1060,110,6.2,2,2,6.4,77777,9,999999999,350,0.3440,0,88,999.000,999.0,99.0
+1979,6,19,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,20.0,69,99100,22,628,399,6,0,6,0,0,0,0,140,8.8,3,3,6.4,77777,9,999999999,350,0.3440,0,88,999.000,999.0,99.0
+1979,6,19,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.6,20.0,71,99200,0,0,392,0,0,0,0,0,0,0,150,7.7,2,2,6.4,77777,9,999999999,350,0.3440,0,88,999.000,999.0,99.0
+1979,6,19,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.6,20.0,71,99100,0,0,392,0,0,0,0,0,0,0,140,8.8,2,2,8.0,77777,9,999999999,350,0.3440,0,88,999.000,999.0,99.0
+1979,6,19,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.0,20.0,74,99100,0,0,384,0,0,0,0,0,0,0,140,7.2,1,1,8.0,77777,9,999999999,350,0.3440,0,88,999.000,999.0,99.0
+1979,6,19,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,24.4,20.0,76,99100,0,0,381,0,0,0,0,0,0,0,140,5.7,1,1,8.0,77777,9,999999999,350,0.3440,0,88,999.000,999.0,99.0
+1979,6,20,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.0,20.0,74,99000,0,0,393,0,0,0,0,0,0,0,150,7.2,4,3,8.0,77777,9,999999999,350,0.3440,0,88,999.000,999.0,99.0
+1979,6,20,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,24.4,20.0,76,99000,0,0,386,0,0,0,0,0,0,0,160,8.8,2,2,8.0,77777,9,999999999,350,0.3440,0,88,999.000,999.0,99.0
+1979,6,20,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,24.4,20.6,79,99000,0,0,391,0,0,0,0,0,0,0,170,5.7,3,3,8.0,77777,9,999999999,359,0.3440,0,88,999.000,999.0,99.0
+1979,6,20,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,24.4,20.0,76,98900,0,0,390,0,0,0,0,0,0,0,150,7.2,3,3,8.0,77777,9,999999999,350,0.3440,0,88,999.000,999.0,99.0
+1979,6,20,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,20.0,76,98900,50,937,404,13,0,13,1500,0,1500,470,170,7.2,9,7,8.0,1220,9,999999999,350,0.3670,0,88,999.000,999.0,99.0
+1979,6,20,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,20.6,76,99000,263,1323,424,74,5,73,8200,200,8200,2460,200,2.6,10,9,12.9,1220,9,999999999,359,0.3670,0,88,999.000,999.0,99.0
+1979,6,20,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,20.6,76,98900,497,1323,415,193,44,177,21200,4200,19600,4700,170,5.7,10,8,14.5,2740,9,999999999,359,0.3670,0,88,999.000,999.0,99.0
+1979,6,20,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,20.6,74,98800,722,1323,427,294,99,240,32300,10000,26900,7390,170,7.2,10,9,14.5,2740,9,999999999,359,0.3670,0,88,999.000,999.0,99.0
+1979,6,20,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,21.1,69,98800,921,1323,413,572,385,303,61800,41400,32900,8670,170,7.7,9,5,19.3,7620,9,999999999,370,0.3670,0,88,999.000,999.0,99.0
+1979,6,20,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,20.6,63,98800,1082,1323,415,580,280,350,63300,30400,38400,12950,180,10.3,9,4,24.1,77777,9,999999999,359,0.3670,0,88,999.000,999.0,99.0
+1979,6,20,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,21.1,61,98700,1193,1323,418,728,335,425,79400,36400,46500,21460,180,9.3,7,3,24.1,77777,9,999999999,370,0.3670,0,88,999.000,999.0,99.0
+1979,6,20,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,21.1,59,98700,1247,1323,425,858,520,367,92000,54400,40700,26060,170,10.8,8,4,24.1,77777,9,999999999,370,0.3670,0,88,999.000,999.0,99.0
+1979,6,20,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,21.7,57,98500,1240,1323,428,853,551,335,92200,57700,38000,22800,170,9.8,4,3,24.1,77777,9,999999999,379,0.3670,0,88,999.000,999.0,99.0
+1979,6,20,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,32.2,21.7,54,98400,1172,1323,438,800,518,341,85700,54100,37600,17300,190,9.8,4,4,24.1,77777,9,999999999,390,0.3670,0,88,999.000,999.0,99.0
+1979,6,20,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,32.2,21.7,54,98300,1049,1323,438,714,566,265,77100,59100,30100,9340,210,8.8,4,4,19.3,77777,9,999999999,379,0.3670,0,88,999.000,999.0,99.0
+1979,6,20,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,18.3,45,98200,878,1323,460,333,68,288,36700,6900,32100,9880,210,7.2,9,9,24.1,1370,9,999999999,320,0.3670,0,88,999.000,999.0,99.0
+1979,6,20,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,16.7,41,98300,672,1323,448,257,73,220,28200,7300,24500,6590,220,11.3,8,8,24.1,1370,9,999999999,290,0.3670,0,88,999.000,999.0,99.0
+1979,6,20,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,16.1,43,98600,444,1323,425,157,71,133,17200,6600,15000,3570,260,8.2,7,6,24.1,7620,9,999999999,279,0.3670,0,88,999.000,999.0,99.0
+1979,6,20,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,15.6,46,98700,210,1323,415,48,6,47,5400,100,5400,1650,250,4.1,8,6,24.1,7620,9,999999999,270,0.3670,0,88,999.000,999.0,99.0
+1979,6,20,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,14.4,50,98700,22,628,392,7,0,7,0,0,0,0,230,3.6,4,4,24.1,77777,9,999999999,250,0.3670,0,88,999.000,999.0,99.0
+1979,6,20,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,15.0,64,98800,0,0,357,0,0,0,0,0,0,0,210,3.1,0,0,24.1,77777,9,999999999,259,0.3670,0,88,999.000,999.0,99.0
+1979,6,20,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,15.0,66,98800,0,0,355,0,0,0,0,0,0,0,230,4.1,0,0,24.1,77777,9,999999999,259,0.3670,0,88,999.000,999.0,99.0
+1979,6,20,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,16.1,76,98800,0,0,351,0,0,0,0,0,0,0,220,4.1,0,0,24.1,77777,9,999999999,279,0.3670,0,88,999.000,999.0,99.0
+1979,6,20,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,15.0,66,98800,0,0,355,0,0,0,0,0,0,0,190,3.1,0,0,24.1,77777,9,999999999,259,0.3670,0,88,999.000,999.0,99.0
+1979,6,21,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,14.4,71,98800,0,0,346,0,0,0,0,0,0,0,200,3.1,0,0,24.1,77777,9,999999999,250,0.3670,0,88,999.000,999.0,99.0
+1979,6,21,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,15.0,73,98800,0,0,347,0,0,0,0,0,0,0,210,3.6,0,0,24.1,77777,9,999999999,259,0.3670,0,88,999.000,999.0,99.0
+1979,6,21,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,15.0,68,98800,0,0,352,0,0,0,0,0,0,0,220,4.1,0,0,24.1,77777,9,999999999,259,0.3670,0,88,999.000,999.0,99.0
+1979,6,21,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,14.4,68,98900,0,0,349,0,0,0,0,0,0,0,230,3.6,0,0,24.1,77777,9,999999999,250,0.3670,0,88,999.000,999.0,99.0
+1979,6,21,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,15.0,73,98900,50,937,347,17,12,16,1800,600,1800,390,230,4.1,0,0,24.1,77777,9,999999999,259,0.2220,0,88,999.000,999.0,99.0
+1979,6,21,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,16.1,71,98900,263,1322,356,110,238,63,11500,17800,8000,1140,250,5.2,0,0,24.1,77777,9,999999999,279,0.2220,0,88,999.000,999.0,99.0
+1979,6,21,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,16.7,64,98900,496,1322,367,281,465,105,29900,44000,13300,1990,250,6.7,0,0,24.1,77777,9,999999999,290,0.2220,0,88,999.000,999.0,99.0
+1979,6,21,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,16.1,56,99000,721,1322,375,473,603,142,49100,59800,16500,3100,250,6.2,0,0,24.1,77777,9,999999999,279,0.2220,0,88,999.000,999.0,99.0
+1979,6,21,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,16.7,51,99000,920,1322,387,649,682,172,68400,69100,20200,4760,230,6.2,0,0,24.1,77777,9,999999999,290,0.2220,0,88,999.000,999.0,99.0
+1979,6,21,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,15.6,44,98900,1081,1322,391,801,740,193,85300,75700,23300,7340,250,9.3,0,0,24.1,77777,9,999999999,270,0.2220,0,88,999.000,999.0,99.0
+1979,6,21,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,15.6,42,99000,1193,1322,405,855,727,196,92000,74700,24400,10620,250,10.3,1,1,24.1,77777,9,999999999,270,0.2220,0,88,999.000,999.0,99.0
+1979,6,21,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,13.3,35,99000,1247,1322,405,876,703,211,94400,72200,26100,14700,270,10.3,1,1,24.1,77777,9,999999999,240,0.2220,0,88,999.000,999.0,99.0
+1979,6,21,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,13.3,35,99000,1240,1322,405,895,734,205,96600,75500,25700,13770,290,8.8,1,1,24.1,77777,9,999999999,240,0.2220,0,88,999.000,999.0,99.0
+1979,6,21,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,14.4,37,98900,1173,1322,412,864,720,224,92100,73500,26700,11140,270,8.2,2,2,24.1,77777,9,999999999,250,0.2220,0,88,999.000,999.0,99.0
+1979,6,21,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,13.3,35,98900,1049,1322,410,678,563,231,71200,56900,26000,7970,280,9.3,2,2,24.1,77777,9,999999999,240,0.2220,0,88,999.000,999.0,99.0
+1979,6,21,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,12.8,35,98900,879,1322,401,580,584,193,60600,58600,21600,4910,280,10.3,1,1,24.1,77777,9,999999999,229,0.2220,0,88,999.000,999.0,99.0
+1979,6,21,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,12.2,35,98900,672,1322,397,407,541,133,42500,53100,15400,2800,270,10.3,1,1,24.1,77777,9,999999999,220,0.2220,0,88,999.000,999.0,99.0
+1979,6,21,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,12.8,37,98900,444,1322,388,211,353,94,22700,32400,11800,1750,270,8.8,0,0,24.1,77777,9,999999999,229,0.2220,0,88,999.000,999.0,99.0
+1979,6,21,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,12.8,40,98900,211,1322,382,76,157,52,8200,10300,6500,960,270,7.2,1,0,24.1,77777,9,999999999,229,0.2220,0,88,999.000,999.0,99.0
+1979,6,21,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,13.3,45,98900,23,628,374,8,2,8,0,0,0,0,260,4.1,0,0,24.1,77777,9,999999999,229,0.2220,0,88,999.000,999.0,99.0
+1979,6,21,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,24.4,13.3,50,98900,0,0,366,0,0,0,0,0,0,0,250,4.1,0,0,24.1,77777,9,999999999,240,0.2220,0,88,999.000,999.0,99.0
+1979,6,21,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,13.3,55,98900,0,0,358,0,0,0,0,0,0,0,250,4.1,0,0,24.1,77777,9,999999999,240,0.2220,0,88,999.000,999.0,99.0
+1979,6,21,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,13.9,64,99000,0,0,351,0,0,0,0,0,0,0,260,3.1,0,0,24.1,77777,9,999999999,250,0.2220,0,88,999.000,999.0,99.0
+1979,6,21,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,13.3,68,98900,0,0,342,0,0,0,0,0,0,0,260,2.6,0,0,24.1,77777,9,999999999,240,0.2220,0,88,999.000,999.0,99.0
+1979,6,22,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,13.3,75,99000,0,0,335,0,0,0,0,0,0,0,250,3.6,0,0,24.1,77777,9,999999999,240,0.2220,0,88,999.000,999.0,99.0
+1979,6,22,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,13.3,75,99000,0,0,335,0,0,0,0,0,0,0,280,3.1,0,0,24.1,77777,9,999999999,240,0.2220,0,88,999.000,999.0,99.0
+1979,6,22,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,13.3,78,99100,0,0,332,0,0,0,0,0,0,0,320,3.6,0,0,24.1,77777,9,999999999,240,0.2220,0,88,999.000,999.0,99.0
+1979,6,22,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,12.8,81,99000,0,0,332,0,0,0,0,0,0,0,310,2.6,3,1,19.3,77777,9,999999999,229,0.2220,0,88,999.000,999.0,99.0
+1979,6,22,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,13.3,87,99200,49,937,331,19,53,15,2000,1700,1900,250,270,3.1,5,1,19.3,77777,9,999999999,240,0.0980,0,88,999.000,999.0,99.0
+1979,6,22,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,15.0,81,99200,262,1322,350,121,303,60,12600,22600,8100,1080,310,3.1,7,2,24.1,77777,9,999999999,259,0.0980,0,88,999.000,999.0,99.0
+1979,6,22,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,15.0,71,99200,495,1322,365,276,435,112,29200,41100,13800,2140,360,5.2,8,3,24.1,77777,9,999999999,259,0.0980,0,88,999.000,999.0,99.0
+1979,6,22,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,15.6,66,99300,720,1322,376,481,545,183,50900,55200,20800,4030,360,3.1,9,4,24.1,77777,9,999999999,270,0.0980,0,88,999.000,999.0,99.0
+1979,6,22,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,15.6,64,99300,920,1322,386,453,281,256,49500,30300,28300,7110,260,3.1,9,6,24.1,2740,9,999999999,270,0.0980,0,88,999.000,999.0,99.0
+1979,6,22,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,15.6,62,99200,1081,1322,379,682,529,248,74300,55300,29000,9400,260,3.1,9,3,24.1,77777,9,999999999,270,0.0980,0,88,999.000,999.0,99.0
+1979,6,22,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,15.6,58,99200,1192,1322,381,849,752,168,89600,75900,21000,8460,20,5.7,3,2,24.1,77777,9,999999999,270,0.0980,0,88,999.000,999.0,99.0
+1979,6,22,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,15.6,60,99200,1246,1322,373,904,821,127,92700,82400,14900,7140,10,5.2,3,1,24.1,77777,9,999999999,270,0.0980,0,88,999.000,999.0,99.0
+1979,6,22,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,15.6,62,99300,1240,1322,375,866,726,183,91200,73200,22400,11450,80,4.1,5,2,24.1,77777,9,999999999,270,0.0980,0,88,999.000,999.0,99.0
+1979,6,22,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,15.0,60,99300,1173,1322,363,872,838,127,89600,84000,15000,5040,100,5.2,1,0,24.1,77777,9,999999999,259,0.0980,0,88,999.000,999.0,99.0
+1979,6,22,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,15.0,60,99200,1050,1322,378,728,650,212,77000,66000,24500,7390,70,4.1,7,3,24.1,77777,9,999999999,259,0.0980,0,88,999.000,999.0,99.0
+1979,6,22,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,14.4,59,99200,879,1322,375,619,670,174,65100,67600,20100,4500,80,4.6,7,3,24.1,77777,9,999999999,250,0.0980,0,88,999.000,999.0,99.0
+1979,6,22,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,12.8,59,99200,673,1322,364,280,249,154,30800,26000,17500,3320,40,3.6,7,3,24.1,77777,9,999999999,229,0.0980,0,88,999.000,999.0,99.0
+1979,6,22,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,12.8,61,99200,445,1322,358,245,476,86,25400,43200,10900,1620,40,4.6,4,2,24.1,77777,9,999999999,229,0.0980,0,88,999.000,999.0,99.0
+1979,6,22,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,11.1,63,99200,212,1322,341,87,279,44,9400,18800,6400,780,50,6.2,3,1,24.1,77777,9,999999999,209,0.0980,0,88,999.000,999.0,99.0
+1979,6,22,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,10.6,72,99300,23,650,328,9,24,7,0,0,0,0,30,4.6,2,1,24.1,77777,9,999999999,200,0.0980,0,88,999.000,999.0,99.0
+1979,6,22,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,10.6,78,99400,0,0,327,0,0,0,0,0,0,0,40,6.2,2,2,24.1,77777,9,999999999,200,0.0980,0,88,999.000,999.0,99.0
+1979,6,22,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,9.4,75,99400,0,0,329,0,0,0,0,0,0,0,30,6.7,4,4,24.1,77777,9,999999999,189,0.0980,0,88,999.000,999.0,99.0
+1979,6,22,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,8.9,77,99500,0,0,338,0,0,0,0,0,0,0,20,7.2,8,8,24.1,580,9,999999999,179,0.0980,0,88,999.000,999.0,99.0
+1979,6,22,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,8.3,75,99600,0,0,354,0,0,0,0,0,0,0,30,7.7,10,10,24.1,520,9,999999999,179,0.0980,0,88,999.000,999.0,99.0
+1979,6,23,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,6.1,67,99600,0,0,349,0,0,0,0,0,0,0,20,9.8,10,10,24.1,580,9,999999999,160,0.0980,0,88,999.000,999.0,99.0
+1979,6,23,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,5.6,66,99600,0,0,346,0,0,0,0,0,0,0,20,8.8,10,10,24.1,580,9,999999999,150,0.0980,0,88,999.000,999.0,99.0
+1979,6,23,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,4.4,64,99600,0,0,341,0,0,0,0,0,0,0,20,8.8,10,10,24.1,610,9,999999999,139,0.0980,0,88,999.000,999.0,99.0
+1979,6,23,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,4.4,69,99700,0,0,336,0,0,0,0,0,0,0,40,6.7,10,10,24.1,610,9,999999999,139,0.0980,0,88,999.000,999.0,99.0
+1979,6,23,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,4.4,69,99700,49,915,327,14,4,13,1500,200,1400,330,40,6.7,9,9,24.1,670,9,999999999,139,0.1490,0,88,999.000,999.0,99.0
+1979,6,23,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,5.0,71,99800,261,1322,337,46,8,44,5300,200,5200,1690,30,7.7,10,10,24.1,580,9,999999999,139,0.1490,0,88,999.000,999.0,99.0
+1979,6,23,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,5.6,71,99800,494,1322,340,122,3,121,13900,200,13900,4760,40,7.7,10,10,24.1,580,9,999999999,150,0.1490,0,88,999.000,999.0,99.0
+1979,6,23,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,6.1,69,99800,719,1322,346,154,1,153,18000,100,18000,6820,20,6.2,10,10,24.1,580,9,999999999,160,0.1490,0,88,999.000,999.0,99.0
+1979,6,23,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,7.2,69,99800,919,1322,353,234,9,228,27600,700,27100,10460,30,7.2,10,10,24.1,580,9,999999999,170,0.1490,0,88,999.000,999.0,99.0
+1979,6,23,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,7.2,64,99900,1080,1322,341,511,205,343,56500,21900,38600,12770,20,6.2,8,8,24.1,610,9,999999999,160,0.1490,0,88,999.000,999.0,99.0
+1979,6,23,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,7.8,65,99800,1192,1322,327,796,567,282,83400,57200,31700,14870,40,6.2,9,3,24.1,77777,9,999999999,170,0.1490,0,88,999.000,999.0,99.0
+1979,6,23,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,7.8,65,99800,1246,1322,324,904,694,247,96200,70800,29400,17050,30,5.2,9,2,24.1,77777,9,999999999,170,0.1490,0,88,999.000,999.0,99.0
+1979,6,23,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,8.3,65,99800,1240,1322,327,909,665,283,95800,67300,32600,18710,40,7.2,10,2,24.1,77777,9,999999999,179,0.1490,0,88,999.000,999.0,99.0
+1979,6,23,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,7.2,60,99800,1173,1322,337,609,281,359,67100,30600,40000,16710,30,8.2,10,6,24.1,7620,9,999999999,170,0.1490,0,88,999.000,999.0,99.0
+1979,6,23,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,7.2,60,99800,1050,1322,346,437,182,293,48800,19500,33300,10380,30,7.7,10,8,24.1,7620,9,999999999,170,0.1490,0,88,999.000,999.0,99.0
+1979,6,23,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,5.6,55,99700,880,1322,342,442,167,331,48100,17600,36400,9590,30,7.2,10,8,24.1,7620,9,999999999,150,0.1490,0,88,999.000,999.0,99.0
+1979,6,23,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,5.6,55,99700,674,1322,336,287,180,195,31500,18500,22000,4890,20,8.8,9,7,24.1,7620,9,999999999,150,0.1490,0,88,999.000,999.0,99.0
+1979,6,23,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,7.2,62,99700,446,1322,344,124,13,120,14000,800,13800,4480,20,7.2,9,8,24.1,7620,9,999999999,160,0.1490,0,88,999.000,999.0,99.0
+1979,6,23,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,6.1,58,99700,213,1322,342,54,2,53,6000,0,6000,1800,20,6.2,9,8,24.1,7620,9,999999999,160,0.1490,0,88,999.000,999.0,99.0
+1979,6,23,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,4.4,55,99800,23,650,335,5,0,5,0,0,0,0,20,5.2,8,8,24.1,3050,9,999999999,139,0.1490,0,88,999.000,999.0,99.0
+1979,6,23,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,3.9,55,99800,0,0,339,0,0,0,0,0,0,0,360,5.2,9,9,24.1,2740,9,999999999,139,0.1490,0,88,999.000,999.0,99.0
+1979,6,23,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,3.3,53,100000,0,0,339,0,0,0,0,0,0,0,20,4.1,9,9,24.1,2740,9,999999999,129,0.1490,0,88,999.000,999.0,99.0
+1979,6,23,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,3.9,55,100000,0,0,339,0,0,0,0,0,0,0,350,4.1,9,9,24.1,2740,9,999999999,139,0.1490,0,88,999.000,999.0,99.0
+1979,6,23,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,3.3,55,99900,0,0,345,0,0,0,0,0,0,0,10,3.6,10,10,24.1,2440,9,999999999,129,0.1490,0,88,999.000,999.0,99.0
+1979,6,24,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,3.3,55,99900,0,0,345,0,0,0,0,0,0,0,10,4.1,10,10,24.1,2440,9,999999999,129,0.1490,0,88,999.000,999.0,99.0
+1979,6,24,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,3.3,57,99900,0,0,321,0,0,0,0,0,0,0,20,4.6,7,7,24.1,2440,9,999999999,129,0.1490,0,88,999.000,999.0,99.0
+1979,6,24,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,3.9,61,99900,0,0,313,0,0,0,0,0,0,0,20,4.1,5,5,24.1,77777,9,999999999,139,0.1490,0,88,999.000,999.0,99.0
+1979,6,24,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,3.3,64,99900,0,0,300,0,0,0,0,0,0,0,10,3.6,2,2,24.1,77777,9,999999999,129,0.1490,0,88,999.000,999.0,99.0
+1979,6,24,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,3.9,69,100000,48,914,294,19,61,13,1800,2300,1700,220,20,3.6,1,1,24.1,77777,9,999999999,139,0.1050,0,88,999.000,999.0,99.0
+1979,6,24,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,7.2,74,100000,260,1322,307,121,377,46,12400,28700,6700,840,20,3.6,1,1,24.1,77777,9,999999999,170,0.1050,0,88,999.000,999.0,99.0
+1979,6,24,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,10.0,75,100000,493,1322,316,307,634,69,32400,59900,10000,1390,10,5.2,0,0,24.1,77777,9,999999999,200,0.1050,0,88,999.000,999.0,99.0
+1979,6,24,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,10.6,70,100100,718,1322,324,502,752,91,52600,74400,12100,2030,10,5.2,0,0,24.1,77777,9,999999999,200,0.1050,0,88,999.000,999.0,99.0
+1979,6,24,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,12.2,70,100200,918,1322,333,675,811,109,71800,81900,14900,2990,30,5.2,0,0,24.1,77777,9,999999999,220,0.1050,0,88,999.000,999.0,99.0
+1979,6,24,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,12.2,65,100200,1079,1322,338,821,852,121,84200,85200,14500,3620,20,5.2,0,0,24.1,77777,9,999999999,220,0.1050,0,88,999.000,999.0,99.0
+1979,6,24,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,12.2,63,100200,1191,1322,347,724,660,127,78700,67400,17900,6670,40,4.6,1,1,24.1,77777,9,999999999,220,0.1050,0,88,999.000,999.0,99.0
+1979,6,24,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,11.7,57,100200,1246,1322,366,726,478,274,80100,50200,32700,19220,60,5.2,7,5,24.1,3050,9,999999999,220,0.1050,0,88,999.000,999.0,99.0
+1979,6,24,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,11.1,55,100200,1240,1322,352,950,892,112,98000,89600,13800,6280,30,6.2,1,1,24.1,77777,9,999999999,209,0.1050,0,88,999.000,999.0,99.0
+1979,6,24,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,10.0,51,100200,1173,1322,344,850,813,127,87400,81500,14900,5050,70,4.6,0,0,24.1,77777,9,999999999,200,0.1050,0,88,999.000,999.0,99.0
+1979,6,24,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,10.0,51,99900,1050,1322,344,792,847,119,81800,84700,14400,3330,50,3.6,0,0,24.1,77777,9,999999999,200,0.1050,0,88,999.000,999.0,99.0
+1979,6,24,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,8.3,46,100100,880,1322,342,645,812,105,68900,81800,14300,2740,30,6.2,0,0,24.1,77777,9,999999999,179,0.1050,0,88,999.000,999.0,99.0
+1979,6,24,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,7.8,44,100100,674,1322,341,461,738,86,48600,72600,11500,1870,10,5.2,0,0,24.1,77777,9,999999999,170,0.1050,0,88,999.000,999.0,99.0
+1979,6,24,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,6.7,42,100100,446,1322,337,265,603,63,28200,55600,9400,1240,30,5.2,0,0,24.1,77777,9,999999999,160,0.1050,0,88,999.000,999.0,99.0
+1979,6,24,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,4.4,40,100100,213,1322,327,94,350,39,9800,24500,5800,710,20,4.6,0,0,24.1,77777,9,999999999,139,0.1050,0,88,999.000,999.0,99.0
+1979,6,24,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,2.8,44,100100,24,650,311,11,26,9,0,0,0,0,20,4.1,0,0,24.1,77777,9,999999999,129,0.1050,0,88,999.000,999.0,99.0
+1979,6,24,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,1.1,45,100200,0,0,299,0,0,0,0,0,0,0,20,3.6,0,0,24.1,77777,9,999999999,120,0.1050,0,88,999.000,999.0,99.0
+1979,6,24,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,0.6,49,100200,0,0,292,0,0,0,0,0,0,0,30,2.6,0,0,24.1,77777,9,999999999,110,0.1050,0,88,999.000,999.0,99.0
+1979,6,24,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,0.6,52,100200,0,0,287,0,0,0,0,0,0,0,20,2.6,0,0,24.1,77777,9,999999999,110,0.1050,0,88,999.000,999.0,99.0
+1979,6,24,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,0.6,54,100200,0,0,285,0,0,0,0,0,0,0,350,2.1,0,0,24.1,77777,9,999999999,110,0.1050,0,88,999.000,999.0,99.0
+1979,6,25,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,-0.6,56,100200,0,0,277,0,0,0,0,0,0,0,10,2.1,0,0,24.1,77777,9,999999999,100,0.1050,0,88,999.000,999.0,99.0
+1979,6,25,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,-0.6,58,100200,0,0,275,0,0,0,0,0,0,0,320,1.5,0,0,24.1,77777,9,999999999,100,0.1050,0,88,999.000,999.0,99.0
+1979,6,25,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,-1.1,56,100200,0,0,275,0,0,0,0,0,0,0,360,2.1,0,0,24.1,77777,9,999999999,100,0.1050,0,88,999.000,999.0,99.0
+1979,6,25,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,-0.6,60,100300,0,0,273,0,0,0,0,0,0,0,310,3.1,0,0,24.1,77777,9,999999999,100,0.1050,0,88,999.000,999.0,99.0
+1979,6,25,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,0.6,63,100300,47,914,276,21,61,16,2100,1900,2000,270,30,2.6,0,0,24.1,77777,9,999999999,110,0.1130,0,88,999.000,999.0,99.0
+1979,6,25,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,6.7,72,100300,259,1322,301,127,412,46,13000,31300,6900,840,10,2.1,0,0,24.1,77777,9,999999999,160,0.1130,0,88,999.000,999.0,99.0
+1979,6,25,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,11.1,72,100400,492,1322,324,307,628,72,32300,59200,10200,1440,10,2.1,0,0,24.1,77777,9,999999999,209,0.1130,0,88,999.000,999.0,99.0
+1979,6,25,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,13.3,63,100400,717,1322,348,497,724,102,52900,72700,13400,2330,120,2.1,2,0,24.1,77777,9,999999999,240,0.1130,0,88,999.000,999.0,99.0
+1979,6,25,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,13.3,55,100400,917,1322,365,649,769,114,68800,77500,15000,3080,130,3.1,2,1,16.1,77777,9,999999999,240,0.1130,0,88,999.000,999.0,99.0
+1979,6,25,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,12.8,48,100400,1078,1322,365,815,835,130,87100,84700,17800,4740,230,2.1,1,0,16.1,77777,9,999999999,229,0.1130,0,88,999.000,999.0,99.0
+1979,6,25,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,12.2,44,100400,1191,1322,371,923,838,165,97600,84700,21200,8290,190,3.1,4,0,16.1,77777,9,999999999,229,0.1130,0,88,999.000,999.0,99.0
+1979,6,25,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,11.7,39,100300,1245,1322,383,895,741,194,93700,74500,23400,12450,160,3.1,7,1,16.1,77777,9,999999999,220,0.1130,0,88,999.000,999.0,99.0
+1979,6,25,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,10.0,36,100200,1239,1322,377,898,753,190,94200,75800,23100,11820,80,7.2,8,1,16.1,77777,9,999999999,189,0.1130,0,88,999.000,999.0,99.0
+1979,6,25,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,10.0,38,100200,1173,1322,375,810,737,156,86300,74600,20000,7380,70,4.1,3,1,16.1,77777,9,999999999,200,0.1130,0,88,999.000,999.0,99.0
+1979,6,25,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,9.4,35,100200,1051,1322,377,745,769,134,79400,77800,17400,4520,120,5.2,3,1,19.3,77777,9,999999999,189,0.1130,0,88,999.000,999.0,99.0
+1979,6,25,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,8.3,34,100100,881,1322,373,607,753,106,64700,75800,14100,2760,120,5.2,2,1,19.3,77777,9,999999999,179,0.1130,0,88,999.000,999.0,99.0
+1979,6,25,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,7.2,32,100100,675,1322,361,460,729,90,48300,71500,11800,1920,120,5.2,0,0,19.3,77777,9,999999999,160,0.1130,0,88,999.000,999.0,99.0
+1979,6,25,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,5.6,31,100100,447,1322,354,266,598,66,28200,55000,9600,1300,120,4.6,0,0,19.3,77777,9,999999999,150,0.1130,0,88,999.000,999.0,99.0
+1979,6,25,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,4.4,31,100100,213,1322,345,93,333,40,9600,23300,5900,720,100,5.2,0,0,19.3,77777,9,999999999,139,0.1130,0,88,999.000,999.0,99.0
+1979,6,25,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,2.8,33,100100,24,650,330,11,23,9,0,0,0,0,90,4.1,0,0,19.3,77777,9,999999999,129,0.1130,0,88,999.000,999.0,99.0
+1979,6,25,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,2.8,37,100100,0,0,323,0,0,0,0,0,0,0,110,3.6,0,0,24.1,77777,9,999999999,129,0.1130,0,88,999.000,999.0,99.0
+1979,6,25,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,2.8,40,100100,0,0,318,0,0,0,0,0,0,0,140,3.1,0,0,24.1,77777,9,999999999,129,0.1130,0,88,999.000,999.0,99.0
+1979,6,25,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,2.8,44,100100,0,0,311,0,0,0,0,0,0,0,140,3.6,0,0,24.1,77777,9,999999999,129,0.1130,0,88,999.000,999.0,99.0
+1979,6,25,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,2.8,47,100100,0,0,306,0,0,0,0,0,0,0,170,1.5,0,0,19.3,77777,9,999999999,129,0.1130,0,88,999.000,999.0,99.0
+1979,6,26,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,2.2,47,100100,0,0,303,0,0,0,0,0,0,0,180,2.6,0,0,11.3,77777,9,999999999,120,0.1130,0,88,999.000,999.0,99.0
+1979,6,26,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,2.8,51,100100,0,0,301,0,0,0,0,0,0,0,170,2.6,0,0,12.9,77777,9,999999999,129,0.1130,0,88,999.000,999.0,99.0
+1979,6,26,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,3.3,55,100200,0,0,299,0,0,0,0,0,0,0,200,2.6,0,0,19.3,77777,9,999999999,129,0.1130,0,88,999.000,999.0,99.0
+1979,6,26,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,2.8,55,100200,0,0,297,0,0,0,0,0,0,0,160,2.1,1,0,19.3,77777,9,999999999,129,0.1130,0,88,999.000,999.0,99.0
+1979,6,26,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,3.3,57,100200,47,892,303,21,79,14,2000,2900,1800,240,160,2.1,2,1,14.5,77777,9,999999999,129,0.0790,0,88,999.000,999.0,99.0
+1979,6,26,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,8.3,67,100200,257,1322,320,125,405,46,12900,30700,6900,840,150,3.1,4,1,19.3,77777,9,999999999,179,0.0790,0,88,999.000,999.0,99.0
+1979,6,26,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,12.2,63,100200,491,1322,352,283,514,90,29200,47900,11400,1740,190,4.1,5,2,19.3,77777,9,999999999,220,0.0790,0,88,999.000,999.0,99.0
+1979,6,26,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,12.2,53,100200,716,1322,366,446,529,158,47800,53700,18700,3430,210,6.2,8,2,19.3,77777,9,999999999,220,0.0790,0,88,999.000,999.0,99.0
+1979,6,26,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,11.7,46,100200,916,1322,368,631,783,86,65500,78100,11400,2250,200,6.2,3,1,19.3,77777,9,999999999,220,0.0790,0,88,999.000,999.0,99.0
+1979,6,26,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,12.8,44,100100,1078,1322,381,764,796,112,78700,79700,13600,3490,190,6.2,3,1,24.1,77777,9,999999999,229,0.0790,0,88,999.000,999.0,99.0
+1979,6,26,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,12.8,41,100100,1190,1322,387,889,866,106,91700,86900,13300,4810,200,5.2,1,1,24.1,77777,9,999999999,229,0.0790,0,88,999.000,999.0,99.0
+1979,6,26,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,12.8,38,100000,1245,1322,398,866,722,183,91200,72800,22500,11830,220,4.1,3,2,24.1,77777,9,999999999,229,0.0790,0,88,999.000,999.0,99.0
+1979,6,26,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,13.3,38,99900,1239,1322,405,754,592,197,81600,61000,24300,13270,240,5.7,3,3,24.1,77777,9,999999999,240,0.0790,0,88,999.000,999.0,99.0
+1979,6,26,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,13.3,37,99800,1173,1322,404,866,793,161,91800,80100,20500,7580,250,5.2,2,2,24.1,77777,9,999999999,240,0.0790,0,88,999.000,999.0,99.0
+1979,6,26,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,12.2,32,99700,1051,1322,409,747,836,82,78000,83800,11200,2750,180,4.6,2,2,24.1,77777,9,999999999,220,0.0790,0,88,999.000,999.0,99.0
+1979,6,26,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,12.2,32,99700,881,1322,409,612,727,128,64000,72600,15500,3130,210,5.2,2,2,24.1,77777,9,999999999,220,0.0790,0,88,999.000,999.0,99.0
+1979,6,26,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,12.2,32,99700,675,1322,409,378,484,132,41200,48800,16300,2740,240,6.2,7,2,24.1,77777,9,999999999,220,0.0790,0,88,999.000,999.0,99.0
+1979,6,26,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,10.6,31,99700,447,1322,404,225,409,88,24300,37600,11600,1630,260,6.2,7,3,24.1,77777,9,999999999,200,0.0790,0,88,999.000,999.0,99.0
+1979,6,26,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,7.8,30,99700,214,1322,387,68,130,47,7300,8600,5900,850,230,4.1,8,3,24.1,77777,9,999999999,170,0.0790,0,88,999.000,999.0,99.0
+1979,6,26,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,6.1,31,99800,24,650,401,8,5,7,0,0,0,0,230,3.1,10,9,24.1,7620,9,999999999,150,0.0790,0,88,999.000,999.0,99.0
+1979,6,26,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,5.0,33,99800,0,0,399,0,0,0,0,0,0,0,210,3.1,10,10,24.1,7620,9,999999999,150,0.0790,0,88,999.000,999.0,99.0
+1979,6,26,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,5.6,36,99700,0,0,369,0,0,0,0,0,0,0,210,3.6,9,7,24.1,7620,9,999999999,150,0.0790,0,88,999.000,999.0,99.0
+1979,6,26,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,7.8,41,99600,0,0,375,0,0,0,0,0,0,0,200,3.6,8,7,24.1,7620,9,999999999,170,0.0790,0,88,999.000,999.0,99.0
+1979,6,26,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,8.3,44,99600,0,0,378,0,0,0,0,0,0,0,210,4.1,9,8,24.1,7620,9,999999999,179,0.0790,0,88,999.000,999.0,99.0
+1979,6,27,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,8.3,44,99600,0,0,378,0,0,0,0,0,0,0,200,3.6,9,8,24.1,7620,9,999999999,179,0.0790,0,88,999.000,999.0,99.0
+1979,6,27,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,8.3,46,99600,0,0,395,0,0,0,0,0,0,0,190,4.1,10,10,24.1,7620,9,999999999,179,0.0790,0,88,999.000,999.0,99.0
+1979,6,27,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,9.4,49,99500,0,0,396,0,0,0,0,0,0,0,210,4.1,10,10,24.1,7620,9,999999999,189,0.0790,0,88,999.000,999.0,99.0
+1979,6,27,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,8.9,49,99500,0,0,367,0,0,0,0,0,0,0,200,4.1,9,7,24.1,7620,9,999999999,179,0.0790,0,88,999.000,999.0,99.0
+1979,6,27,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,8.9,51,99500,46,892,364,12,2,12,1400,0,1400,430,200,4.1,10,7,24.1,7620,9,999999999,179,0.1950,0,88,999.000,999.0,99.0
+1979,6,27,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,10.0,55,99600,256,1322,372,72,32,66,7900,2600,7400,1660,200,3.1,10,8,24.1,7620,9,999999999,200,0.1950,0,88,999.000,999.0,99.0
+1979,6,27,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,11.7,55,99700,490,1322,376,261,264,163,27500,25500,18000,3460,240,5.2,10,7,19.3,7620,9,999999999,220,0.1950,0,88,999.000,999.0,99.0
+1979,6,27,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,13.3,54,99700,715,1322,396,218,30,202,24000,3000,22400,6400,220,4.6,10,8,16.1,3660,9,999999999,240,0.1950,0,88,999.000,999.0,99.0
+1979,6,27,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,14.4,52,99700,915,1322,415,357,75,305,39300,7700,34000,10740,220,4.1,10,9,16.1,3660,9,999999999,250,0.1950,0,88,999.000,999.0,99.0
+1979,6,27,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,16.7,51,99600,1077,1322,447,315,3,312,37000,300,36800,14130,220,3.6,10,10,16.1,3660,9,999999999,290,0.1950,0,88,999.000,999.0,99.0
+1979,6,27,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,16.7,49,99600,1189,1322,437,546,128,431,60100,13600,47800,20530,210,4.6,10,9,16.1,7620,9,999999999,290,0.1950,0,88,999.000,999.0,99.0
+1979,6,27,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,17.2,48,99500,1245,1322,435,421,37,386,46600,3800,43000,21370,230,5.7,9,8,16.1,7620,9,999999999,300,0.1950,0,88,999.000,999.0,99.0
+1979,6,27,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,18.3,48,99500,1239,1322,444,659,355,326,71500,37200,36600,22180,250,4.1,9,8,16.1,7620,9,999999999,320,0.1950,0,88,999.000,999.0,99.0
+1979,6,27,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,17.8,46,99500,1173,1322,443,627,273,384,68800,29700,42400,18030,230,5.2,10,8,16.1,7620,9,999999999,309,0.1950,0,88,999.000,999.0,99.0
+1979,6,27,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,17.8,46,99500,1051,1322,443,534,242,342,58300,26200,37400,11920,210,3.6,10,8,19.3,7620,9,999999999,309,0.1950,0,88,999.000,999.0,99.0
+1979,6,27,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,16.7,45,99400,881,1322,431,488,289,296,52700,31000,32000,8120,260,5.2,10,7,24.1,7620,9,999999999,290,0.1950,0,88,999.000,999.0,99.0
+1979,6,27,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,16.1,45,99400,675,1322,422,293,118,234,32000,12100,25800,5870,280,4.6,9,6,24.1,3050,9,999999999,279,0.1950,0,88,999.000,999.0,99.0
+1979,6,27,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,16.7,46,99400,447,1322,413,203,259,116,21800,24400,13600,2300,260,4.6,5,3,24.1,77777,9,999999999,290,0.1950,0,88,999.000,999.0,99.0
+1979,6,27,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,16.1,48,99400,214,1322,409,67,77,55,7400,5500,6500,1170,250,4.1,5,4,24.1,77777,9,999999999,279,0.1950,0,88,999.000,999.0,99.0
+1979,6,27,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,15.6,54,99400,24,650,391,7,2,7,0,0,0,0,230,5.2,4,3,24.1,77777,9,999999999,270,0.1950,0,88,999.000,999.0,99.0
+1979,6,27,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.9,14.4,56,99600,0,0,401,0,0,0,0,0,0,0,340,4.6,8,8,24.1,1520,9,999999999,259,0.1950,0,88,999.000,999.0,99.0
+1979,6,27,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,13.3,57,99600,0,0,399,0,0,0,0,0,0,0,120,2.6,9,9,24.1,1830,9,999999999,240,0.1950,0,88,999.000,999.0,99.0
+1979,6,27,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,12.8,61,99600,0,0,381,0,0,0,0,0,0,0,160,2.1,8,8,16.1,1520,9,999999999,229,0.1950,0,88,999.000,999.0,99.0
+1979,6,27,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,12.8,63,99600,0,0,386,0,0,0,0,0,0,0,230,1.5,9,9,12.9,1370,9,999999999,229,0.1950,0,88,999.000,999.0,99.0
+1979,6,28,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,12.8,63,99600,0,0,362,0,0,0,0,0,0,0,0,0.0,4,4,11.3,77777,9,999999999,229,0.1950,0,88,999.000,999.0,99.0
+1979,6,28,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,13.3,68,99500,0,0,384,0,0,0,0,0,0,0,210,2.1,9,9,9.7,1370,9,999999999,240,0.1950,0,88,999.000,999.0,99.0
+1979,6,28,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,13.9,70,99500,0,0,384,0,0,0,0,0,0,0,0,0.0,9,9,9.7,980,9,999999999,240,0.1950,0,88,999.000,999.0,99.0
+1979,6,28,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,14.4,73,99500,0,0,396,0,0,0,0,0,0,0,130,2.6,10,10,8.0,370,9,999999999,250,0.1950,0,88,999.000,999.0,99.0
+1979,6,28,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,15.0,76,99500,45,892,397,14,0,14,1600,0,1600,490,40,3.1,10,10,3.2,400,9,999999999,259,0.0900,0,88,999.000,999.0,99.0
+1979,6,28,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,15.6,76,99600,255,1322,347,127,441,41,13100,33500,6600,760,60,2.6,0,0,6.4,77777,9,999999999,270,0.0900,0,88,999.000,999.0,99.0
+1979,6,28,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,18.3,76,99600,488,1322,364,304,649,63,31600,60800,9100,1290,80,2.1,0,0,6.4,77777,9,999999999,320,0.0900,0,88,999.000,999.0,99.0
+1979,6,28,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,20.0,71,99600,713,1322,387,469,681,99,49900,68400,13000,2260,100,3.6,1,1,6.4,77777,9,999999999,350,0.0900,0,88,999.000,999.0,99.0
+1979,6,28,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,20.0,65,99600,914,1322,388,665,814,99,68700,81000,12600,2360,110,3.1,0,0,8.0,77777,9,999999999,350,0.0900,0,88,999.000,999.0,99.0
+1979,6,28,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,20.0,61,99500,1076,1322,414,704,628,190,75000,64200,22600,7150,110,3.1,5,4,8.0,77777,9,999999999,350,0.0900,0,88,999.000,999.0,99.0
+1979,6,28,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,18.9,57,99400,1189,1322,409,850,675,240,90100,68700,28200,12670,80,4.6,10,3,6.4,77777,9,999999999,329,0.0900,0,88,999.000,999.0,99.0
+1979,6,28,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,18.3,55,99400,1244,1322,412,874,555,349,94000,58100,39200,24480,110,4.6,10,4,6.4,77777,9,999999999,320,0.0900,0,88,999.000,999.0,99.0
+1979,6,28,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,20.0,57,99300,1239,1322,417,828,576,288,87400,58200,32700,18970,70,4.1,10,3,4.8,77777,9,999999999,350,0.0900,0,88,999.000,999.0,99.0
+1979,6,28,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,19.4,53,99200,1173,1322,423,755,541,274,82600,56700,32100,13830,140,3.1,10,4,4.8,77777,9,999999999,340,0.0900,0,88,999.000,999.0,99.0
+1979,6,28,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,17.8,53,99200,1051,1322,418,580,318,327,63500,34500,36000,11330,90,5.2,10,6,6.4,7620,9,999999999,309,0.0900,0,88,999.000,999.0,99.0
+1979,6,28,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,18.9,57,99100,881,1322,405,582,616,172,61300,62200,19800,4480,90,5.2,7,2,6.4,77777,9,999999999,329,0.0900,0,88,999.000,999.0,99.0
+1979,6,28,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,18.3,53,99000,675,1322,415,360,390,162,38500,39200,18400,3430,110,5.2,5,4,6.4,77777,9,999999999,320,0.0900,0,88,999.000,999.0,99.0
+1979,6,28,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,17.2,54,99000,448,1322,401,243,383,114,25500,35100,13600,2170,100,5.2,7,3,6.4,77777,9,999999999,300,0.0900,0,88,999.000,999.0,99.0
+1979,6,28,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,16.1,60,98900,214,1322,406,67,102,50,7100,6800,6000,910,90,4.1,9,8,8.0,3660,9,999999999,279,0.0900,0,88,999.000,999.0,99.0
+1979,6,28,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,15.6,60,98900,24,650,423,2,0,1,0,0,0,0,70,3.6,10,10,8.0,1370,9,999999999,270,0.0900,0,88,999.000,999.0,99.0
+1979,6,28,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,15.0,66,98900,0,0,409,0,0,0,0,0,0,0,110,4.6,10,10,19.3,7620,9,999999999,259,0.0900,0,88,999.000,999.0,99.0
+1979,6,28,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,16.1,68,98900,0,0,414,0,0,0,0,0,0,0,200,1.5,10,10,8.0,3660,9,999999999,279,0.0900,0,88,999.000,999.0,99.0
+1979,6,28,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,14.4,73,98900,0,0,396,0,0,0,0,0,0,0,40,10.3,10,10,4.8,610,9,999999999,250,0.0900,0,88,999.000,999.0,99.0
+1979,6,28,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,15.6,81,98800,0,0,395,0,0,0,0,0,0,0,60,6.2,10,10,4.8,3660,9,999999999,270,0.0900,0,88,999.000,999.0,99.0
+1979,6,29,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,16.1,87,98700,0,0,381,0,0,0,0,0,0,0,120,3.6,9,9,16.1,3660,9,999999999,279,0.0900,0,88,999.000,999.0,99.0
+1979,6,29,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,14.4,90,98700,0,0,345,0,0,0,0,0,0,0,160,4.1,4,4,14.5,77777,9,999999999,250,0.0900,0,88,999.000,999.0,99.0
+1979,6,29,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,13.9,90,98600,0,0,357,0,0,0,0,0,0,0,160,4.1,8,8,6.4,3050,9,999999999,240,0.0900,0,88,999.000,999.0,99.0
+1979,6,29,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,17.2,93,98600,0,0,394,0,0,0,0,0,0,0,170,3.1,10,10,6.4,610,9,999999999,300,0.0900,0,88,999.000,999.0,99.0
+1979,6,29,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,19.4,93,98500,44,870,409,9,0,9,1100,0,1100,340,210,3.6,10,10,2.4,270,9,999999999,340,0.1400,0,88,999.000,999.0,99.0
+1979,6,29,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,17.2,93,98500,253,1322,394,23,1,23,2800,0,2800,960,130,5.2,10,10,11.3,610,9,999999999,300,0.1400,0,88,999.000,999.0,99.0
+1979,6,29,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,18.9,93,98500,487,1322,405,117,2,117,13500,100,13400,4610,150,5.2,10,10,11.3,370,9,999999999,329,0.1400,0,88,999.000,999.0,99.0
+1979,6,29,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,21.1,100,98400,712,1322,414,212,1,212,24300,100,24200,8640,190,6.2,10,10,6.4,340,9,999999999,370,0.1400,0,88,999.000,999.0,99.0
+1979,6,29,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,22.8,97,98400,913,1322,429,281,3,279,32500,300,32400,12080,210,6.7,10,10,6.4,340,9,999999999,409,0.1400,0,88,999.000,999.0,99.0
+1979,6,29,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,22.2,87,98300,1075,1322,422,368,89,295,41000,9500,33200,10900,210,6.2,9,9,9.7,2440,9,999999999,390,0.1400,0,88,999.000,999.0,99.0
+1979,6,29,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,23.3,82,98200,1188,1322,428,600,180,438,65900,19200,48700,20790,230,4.6,8,8,9.7,580,9,999999999,419,0.1400,0,88,999.000,999.0,99.0
+1979,6,29,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,18.9,74,98200,1244,1322,427,232,6,226,28600,500,28200,11310,230,6.7,10,10,9.7,520,9,999999999,329,0.1400,0,88,999.000,999.0,99.0
+1979,6,29,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,16.1,78,98300,1238,1322,401,173,1,172,21800,100,21700,8930,270,5.2,10,10,11.3,610,9,999999999,279,0.1400,0,88,999.000,999.0,99.0
+1979,6,29,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,16.7,81,98300,1173,1322,402,225,10,216,27600,800,26900,10790,340,1.5,10,10,9.7,610,9,999999999,290,0.1400,0,88,999.000,999.0,99.0
+1979,6,29,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,17.8,81,98300,1051,1322,410,205,7,199,24800,500,24400,9880,360,4.1,10,10,8.0,1220,9,999999999,300,0.1400,0,88,999.000,999.0,99.0
+1979,6,29,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,18.3,81,98300,881,1322,414,261,7,256,30200,600,29800,11150,10,5.7,10,10,16.1,610,9,999999999,320,0.1400,0,88,999.000,999.0,99.0
+1979,6,29,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,17.8,79,98300,675,1322,413,199,1,198,22700,100,22600,7990,10,6.2,10,10,19.3,370,9,999999999,309,0.1400,0,88,999.000,999.0,99.0
+1979,6,29,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,15.0,76,98400,448,1322,397,106,2,105,12100,100,12000,4090,10,6.7,10,10,14.5,240,9,999999999,259,0.1400,0,88,999.000,999.0,99.0
+1979,6,29,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,14.4,81,98400,214,1322,387,43,2,43,4900,0,4900,1560,10,6.2,10,10,14.5,270,9,999999999,250,0.1400,0,88,999.000,999.0,99.0
+1979,6,29,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,15.0,84,98500,24,650,388,9,0,9,0,0,0,0,350,7.2,10,10,14.5,310,9,999999999,259,0.1400,0,88,999.000,999.0,99.0
+1979,6,29,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,15.6,84,98500,0,0,392,0,0,0,0,0,0,0,350,6.7,10,10,14.5,340,9,999999999,270,0.1400,0,88,999.000,999.0,99.0
+1979,6,29,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,15.6,84,98500,0,0,392,0,0,0,0,0,0,0,350,6.7,10,10,19.3,460,9,999999999,270,0.1400,0,88,999.000,999.0,99.0
+1979,6,29,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,15.6,84,98500,0,0,392,0,0,0,0,0,0,0,340,5.7,10,10,19.3,2440,9,999999999,270,0.1400,0,88,999.000,999.0,99.0
+1979,6,29,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,15.0,81,98500,0,0,356,0,0,0,0,0,0,0,340,5.2,5,4,19.3,77777,9,999999999,259,0.1400,0,88,999.000,999.0,99.0
+1979,6,30,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,13.9,81,98500,0,0,343,0,0,0,0,0,0,0,350,6.7,2,2,19.3,77777,9,999999999,240,0.1400,0,88,999.000,999.0,99.0
+1979,6,30,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,13.3,84,98500,0,0,327,0,0,0,0,0,0,0,360,6.2,0,0,19.3,77777,9,999999999,240,0.1400,0,88,999.000,999.0,99.0
+1979,6,30,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,11.7,87,98600,0,0,315,0,0,0,0,0,0,0,310,4.1,0,0,16.1,77777,9,999999999,209,0.1400,0,88,999.000,999.0,99.0
+1979,6,30,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,11.7,90,98600,0,0,326,0,0,0,0,0,0,0,310,2.6,3,3,12.9,77777,9,999999999,209,0.1400,0,88,999.000,999.0,99.0
+1979,6,30,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,11.1,96,98700,43,870,315,14,25,12,1500,1000,1500,250,280,3.1,2,2,9.7,77777,9,999999999,209,0.1390,0,88,999.000,999.0,99.0
+1979,6,30,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,12.2,96,98700,252,1321,321,108,266,57,11300,19500,7600,1030,310,2.1,2,2,9.7,77777,9,999999999,220,0.1390,0,88,999.000,999.0,99.0
+1979,6,30,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,17.8,90,98700,485,1321,354,274,512,84,28400,47700,10800,1630,340,4.1,2,1,12.9,77777,9,999999999,309,0.1390,0,88,999.000,999.0,99.0
+1979,6,30,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,20.0,82,98700,711,1321,375,440,592,119,46200,59000,14400,2650,330,4.1,3,1,14.5,77777,9,999999999,350,0.1390,0,88,999.000,999.0,99.0
+1979,6,30,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,17.2,79,98700,911,1321,366,655,728,150,69600,74200,18300,4160,330,4.1,2,2,19.3,77777,9,999999999,300,0.1390,0,88,999.000,999.0,99.0
+1979,6,30,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,13.3,52,98700,1074,1321,375,739,715,154,77400,72000,18800,5320,340,4.1,3,2,19.3,77777,9,999999999,240,0.1390,0,88,999.000,999.0,99.0
+1979,6,30,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,11.1,40,98600,1187,1321,385,824,571,309,89100,59800,35300,16560,320,4.1,3,3,24.1,77777,9,999999999,200,0.1390,0,88,999.000,999.0,99.0
+1979,6,30,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,11.7,41,98600,1243,1321,392,857,671,222,91800,68800,27000,15200,310,5.2,4,4,24.1,77777,9,999999999,220,0.1390,0,88,999.000,999.0,99.0
+1979,6,30,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,10.6,36,98600,1238,1321,400,671,386,308,73100,40500,35100,20830,340,4.1,6,6,24.1,1370,9,999999999,200,0.1390,0,88,999.000,999.0,99.0
+1979,6,30,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,12.2,41,98500,1172,1321,413,584,289,328,65000,31500,37000,15150,310,5.2,8,8,24.1,1370,9,999999999,220,0.1390,0,88,999.000,999.0,99.0
+1979,6,30,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,12.2,39,98500,1051,1321,416,622,366,331,68000,39700,36400,11480,20,6.2,8,8,24.1,1370,9,999999999,220,0.1390,0,88,999.000,999.0,99.0
+1979,6,30,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,16.1,73,98500,881,1321,388,316,267,138,35500,27800,16900,3500,50,5.2,8,8,24.1,1370,9,999999999,279,0.1390,0,88,999.000,999.0,99.0
+1979,6,30,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,15.6,56,98500,676,1321,391,292,182,199,32100,18800,22500,4990,310,2.6,5,4,24.1,77777,9,999999999,270,0.1390,0,88,999.000,999.0,99.0
+1979,6,30,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,16.1,60,98500,448,1321,406,88,47,72,9700,4300,8200,2140,310,2.1,8,8,24.1,1370,9,999999999,279,0.1390,0,88,999.000,999.0,99.0
+1979,6,30,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,15.6,76,98600,214,1321,390,40,0,40,4600,0,4600,1470,360,7.7,9,9,24.1,1370,9,999999999,270,0.1390,0,88,999.000,999.0,99.0
+1979,6,30,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,13.9,75,98600,24,650,352,7,4,7,0,0,0,0,330,2.6,5,3,24.1,77777,9,999999999,240,0.1390,0,88,999.000,999.0,99.0
+1979,6,30,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,10.6,61,98600,0,0,348,0,0,0,0,0,0,0,350,3.1,3,3,24.1,77777,9,999999999,200,0.1390,0,88,999.000,999.0,99.0
+1979,6,30,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.0,11.1,68,98600,0,0,333,0,0,0,0,0,0,0,340,3.2,0,0,24.1,77777,9,999999999,209,0.1390,0,88,999.000,999.0,99.0
+1979,6,30,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.7,11.7,70,98600,0,0,332,0,0,0,0,0,0,0,360,3.4,0,0,24.1,77777,9,999999999,209,0.1390,0,88,999.000,999.0,99.0
+1979,6,30,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.4,12.2,78,98600,0,0,331,0,0,0,0,0,0,0,340,3.5,0,0,24.1,77777,9,999999999,209,0.1390,0,88,999.000,999.0,99.0
+1986,7,1,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.0,12.8,87,99100,0,0,381,0,0,0,0,0,0,0,70,3.7,10,10,11.3,370,9,999999999,250,0.1390,0,88,999.000,999.0,99.0
+1986,7,1,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,13.3,87,99000,0,0,380,0,0,0,0,0,0,0,90,3.8,10,10,11.3,370,9,999999999,240,0.1390,0,88,999.000,999.0,99.0
+1986,7,1,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.4,13.9,87,98900,0,0,379,0,0,0,0,0,0,0,90,4.0,10,10,11.3,340,9,999999999,240,0.1390,0,88,999.000,999.0,99.0
+1986,7,1,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,14.4,90,98900,0,0,378,0,0,0,0,0,0,0,110,4.1,10,10,11.3,310,9,999999999,250,0.1390,0,88,999.000,999.0,99.0
+1986,7,1,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,14.4,90,99000,42,848,378,11,0,11,1300,0,1300,400,100,2.6,10,10,6.4,310,9,999999999,250,0.3450,0,88,999.000,999.0,99.0
+1986,7,1,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,15.0,93,98900,249,1321,379,46,0,46,5300,0,5300,1720,80,3.6,10,10,4.8,310,9,999999999,259,0.3450,0,88,999.000,999.0,99.0
+1986,7,1,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,15.0,93,99000,483,1321,379,156,0,156,17400,0,17400,5570,50,4.6,10,10,4.8,240,9,999999999,259,0.3450,0,88,999.000,999.0,99.0
+1986,7,1,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,15.6,93,99000,709,1321,383,223,1,222,25300,100,25300,8880,60,4.1,10,10,4.8,180,9,999999999,270,0.3450,0,88,999.000,999.0,99.0
+1986,7,1,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,15.6,90,99000,910,1321,386,301,1,301,34700,100,34600,12680,90,2.6,10,10,4.8,180,9,999999999,270,0.3450,0,88,999.000,999.0,99.0
+1986,7,1,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,15.6,87,98900,1072,1321,389,360,1,360,42000,100,41900,15570,80,1.5,10,10,4.8,310,9,999999999,270,0.3450,0,88,999.000,999.0,99.0
+1986,7,1,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,16.1,87,98900,1186,1321,392,434,1,433,50600,100,50500,18170,20,3.1,10,10,4.8,370,9,999999999,279,0.3450,0,88,999.000,999.0,99.0
+1986,7,1,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,16.1,87,98900,1242,1321,392,436,1,434,51100,100,51000,18520,10,3.1,10,10,4.8,310,9,999999999,279,0.3450,0,88,999.000,999.0,99.0
+1986,7,1,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,16.1,84,98800,1237,1321,395,465,0,465,54300,0,54300,19300,70,2.6,10,10,4.8,400,9,999999999,279,0.3450,0,88,999.000,999.0,99.0
+1986,7,1,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,16.1,90,98700,1172,1321,390,416,0,416,48500,0,48500,17650,50,3.1,10,10,4.8,490,9,999999999,279,0.3450,0,88,999.000,999.0,99.0
+1986,7,1,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,16.1,90,98700,1051,1321,390,394,1,393,45300,100,45300,16300,10,3.1,10,10,4.8,370,9,999999999,279,0.3450,0,88,999.000,999.0,99.0
+1986,7,1,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,15.6,97,98700,881,1321,380,171,1,171,20500,100,20500,8180,10,4.1,10,10,1.6,210,9,999999999,270,0.3450,0,88,999.000,999.0,99.0
+1986,7,1,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,15.6,100,98700,675,1321,377,139,0,139,16300,0,16300,6140,10,4.1,10,10,2.8,210,9,999999999,270,0.3450,0,88,999.000,999.0,99.0
+1986,7,1,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,16.1,100,98700,448,1321,380,121,1,121,13700,100,13700,4520,10,3.1,10,10,4.8,210,9,999999999,279,0.3450,0,88,999.000,999.0,99.0
+1986,7,1,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,16.1,100,98700,214,1321,380,58,0,58,6400,0,6400,1920,10,3.1,10,10,4.8,210,9,999999999,279,0.3450,0,88,999.000,999.0,99.0
+1986,7,1,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,16.1,100,98700,24,650,380,10,0,10,0,0,0,0,10,4.1,10,10,4.8,210,9,999999999,279,0.3450,0,88,999.000,999.0,99.0
+1986,7,1,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,16.1,100,98800,0,0,380,0,0,0,0,0,0,0,320,3.1,10,10,6.4,520,9,999999999,279,0.3450,0,88,999.000,999.0,99.0
+1986,7,1,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,15.6,90,98800,0,0,386,0,0,0,0,0,0,0,320,3.6,10,10,6.4,520,9,999999999,270,0.3450,0,88,999.000,999.0,99.0
+1986,7,1,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,15.6,90,98800,0,0,386,0,0,0,0,0,0,0,320,3.6,10,10,6.4,580,9,999999999,270,0.3450,0,88,999.000,999.0,99.0
+1986,7,1,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,15.6,90,98700,0,0,386,0,0,0,0,0,0,0,320,3.1,10,10,6.4,580,9,999999999,270,0.3450,0,88,999.000,999.0,99.0
+1986,7,2,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,15.6,90,98800,0,0,386,0,0,0,0,0,0,0,320,2.6,10,10,6.4,580,9,999999999,270,0.3450,0,88,999.000,999.0,99.0
+1986,7,2,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,16.1,93,98800,0,0,386,0,0,0,0,0,0,0,330,2.6,10,10,6.4,460,9,999999999,279,0.3450,0,88,999.000,999.0,99.0
+1986,7,2,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,15.6,90,98800,0,0,386,0,0,0,0,0,0,0,310,2.6,10,10,6.4,880,9,999999999,270,0.3450,0,88,999.000,999.0,99.0
+1986,7,2,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,15.6,90,98800,0,0,386,0,0,0,0,0,0,0,320,4.1,10,10,6.4,880,9,999999999,270,0.3450,0,88,999.000,999.0,99.0
+1986,7,2,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,15.6,90,98900,40,848,386,14,0,14,1600,0,1600,490,320,3.6,10,10,8.0,760,9,999999999,270,0.1040,0,88,999.000,999.0,99.0
+1986,7,2,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,15.6,87,98900,247,1321,389,74,0,74,8200,0,8200,2410,310,3.6,10,10,8.0,880,9,999999999,270,0.1040,0,88,999.000,999.0,99.0
+1986,7,2,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,15.6,87,99000,482,1321,389,154,1,154,17200,100,17200,5510,290,4.1,10,10,8.0,880,9,999999999,270,0.1040,0,88,999.000,999.0,99.0
+1986,7,2,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,15.0,81,99000,707,1321,391,241,1,241,27300,100,27200,9340,350,4.1,10,10,11.3,1370,9,999999999,259,0.1040,0,88,999.000,999.0,99.0
+1986,7,2,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,15.0,76,99100,908,1321,397,327,1,326,37300,100,37300,13330,330,4.1,10,10,11.3,910,9,999999999,259,0.1040,0,88,999.000,999.0,99.0
+1986,7,2,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,14.4,71,99100,1071,1321,399,375,1,374,43500,100,43400,15950,320,2.6,10,10,11.3,1070,9,999999999,250,0.1040,0,88,999.000,999.0,99.0
+1986,7,2,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,15.0,68,99100,1185,1321,395,406,62,351,45000,6300,39300,17100,350,3.1,9,9,14.5,1070,9,999999999,259,0.1040,0,88,999.000,999.0,99.0
+1986,7,2,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,15.0,62,99100,1242,1321,396,639,330,327,69100,34600,36600,22590,330,3.1,8,8,16.1,1070,9,999999999,259,0.1040,0,88,999.000,999.0,99.0
+1986,7,2,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,15.0,58,99100,1237,1321,395,686,362,346,73900,37900,38300,23380,310,3.1,7,7,19.3,1070,9,999999999,259,0.1040,0,88,999.000,999.0,99.0
+1986,7,2,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,15.6,60,99100,1172,1321,396,702,499,258,77200,52300,30600,12960,300,3.6,7,7,19.3,1070,9,999999999,270,0.1040,0,88,999.000,999.0,99.0
+1986,7,2,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,15.0,58,99100,1050,1321,401,499,229,317,54800,24800,35000,10930,320,3.6,8,8,24.1,1070,9,999999999,259,0.1040,0,88,999.000,999.0,99.0
+1986,7,2,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,15.6,64,99100,881,1321,390,450,338,225,49600,36400,25300,5900,50,5.2,7,7,24.1,1070,9,999999999,270,0.1040,0,88,999.000,999.0,99.0
+1986,7,2,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,15.6,64,99100,675,1321,390,397,420,183,41800,42200,20200,3930,50,4.6,8,7,24.1,7620,9,999999999,270,0.1040,0,88,999.000,999.0,99.0
+1986,7,2,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,16.1,71,99100,447,1321,374,198,252,114,21400,23700,13300,2250,40,3.1,4,4,24.1,77777,9,999999999,279,0.1040,0,88,999.000,999.0,99.0
+1986,7,2,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,13.9,66,99200,213,1321,363,94,252,54,9800,16900,7100,980,40,3.6,3,3,24.1,77777,9,999999999,250,0.1040,0,88,999.000,999.0,99.0
+1986,7,2,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,11.7,65,99200,23,650,346,9,26,7,0,0,0,0,40,6.7,2,2,24.1,77777,9,999999999,209,0.1040,0,88,999.000,999.0,99.0
+1986,7,2,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,12.2,75,99300,0,0,328,0,0,0,0,0,0,0,40,3.1,0,0,24.1,77777,9,999999999,220,0.1040,0,88,999.000,999.0,99.0
+1986,7,2,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,12.8,81,99400,0,0,326,0,0,0,0,0,0,0,40,2.6,0,0,24.1,77777,9,999999999,229,0.1040,0,88,999.000,999.0,99.0
+1986,7,2,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,12.2,84,99400,0,0,321,0,0,0,0,0,0,0,30,3.1,0,0,16.1,77777,9,999999999,220,0.1040,0,88,999.000,999.0,99.0
+1986,7,2,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,12.2,87,99500,0,0,318,0,0,0,0,0,0,0,20,2.1,0,0,16.1,77777,9,999999999,220,0.1040,0,88,999.000,999.0,99.0
+1986,7,3,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,11.7,93,99500,0,0,310,0,0,0,0,0,0,0,10,2.1,0,0,16.1,77777,9,999999999,220,0.1040,0,88,999.000,999.0,99.0
+1986,7,3,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,11.7,93,99500,0,0,310,0,0,0,0,0,0,0,320,2.1,0,0,16.1,77777,9,999999999,220,0.1040,0,88,999.000,999.0,99.0
+1986,7,3,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,11.1,93,99500,0,0,307,0,0,0,0,0,0,0,330,2.1,0,0,16.1,77777,9,999999999,209,0.1040,0,88,999.000,999.0,99.0
+1986,7,3,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,10.0,90,99600,0,0,304,0,0,0,0,0,0,0,340,1.5,0,0,16.1,77777,9,999999999,200,0.1040,0,88,999.000,999.0,99.0
+1986,7,3,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,10.0,86,99600,39,826,306,15,6,15,1700,300,1700,370,10,2.1,0,0,16.1,77777,9,999999999,189,0.2450,0,88,999.000,999.0,99.0
+1986,7,3,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,10.6,81,99600,246,1321,314,99,196,62,10400,14100,7800,1160,30,2.6,0,0,24.1,77777,9,999999999,200,0.2450,0,88,999.000,999.0,99.0
+1986,7,3,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,11.1,72,99700,480,1321,324,265,424,110,28000,39700,13500,2090,40,3.6,1,0,24.1,77777,9,999999999,209,0.2450,0,88,999.000,999.0,99.0
+1986,7,3,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,10.6,65,99700,706,1321,329,456,566,152,47100,55700,17300,3230,30,3.1,1,0,24.1,77777,9,999999999,200,0.2450,0,88,999.000,999.0,99.0
+1986,7,3,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,10.6,61,99700,907,1321,334,639,656,185,66700,66200,21200,4960,120,2.6,1,0,24.1,77777,9,999999999,200,0.2450,0,88,999.000,999.0,99.0
+1986,7,3,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,10.6,55,99700,1070,1321,342,789,718,204,83500,73200,24100,7520,150,3.1,0,0,24.1,77777,9,999999999,200,0.2450,0,88,999.000,999.0,99.0
+1986,7,3,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,7.8,38,99700,1184,1321,352,900,756,219,96000,77300,26500,11450,170,3.1,0,0,24.1,77777,9,999999999,170,0.2450,0,88,999.000,999.0,99.0
+1986,7,3,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,9.4,41,99600,1241,1321,356,953,771,226,102100,79000,27800,15290,110,2.1,0,0,24.1,77777,9,999999999,189,0.2450,0,88,999.000,999.0,99.0
+1986,7,3,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,11.1,43,99500,1237,1321,370,895,702,236,95600,71700,28300,15560,170,3.1,1,1,24.1,77777,9,999999999,209,0.2450,0,88,999.000,999.0,99.0
+1986,7,3,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,10.6,45,99500,1171,1321,373,802,552,312,86600,57700,35300,15780,100,5.2,3,3,24.1,77777,9,999999999,200,0.2450,0,88,999.000,999.0,99.0
+1986,7,3,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,11.7,46,99400,1050,1321,377,729,656,207,77200,66700,24000,7260,110,6.2,3,3,24.1,77777,9,999999999,209,0.2450,0,88,999.000,999.0,99.0
+1986,7,3,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,11.7,46,99300,881,1321,377,577,545,214,62000,56400,24400,5590,110,7.7,3,3,24.1,77777,9,999999999,209,0.2450,0,88,999.000,999.0,99.0
+1986,7,3,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,12.2,48,99300,675,1321,374,421,522,156,45200,52500,18300,3290,130,4.6,2,2,24.1,77777,9,999999999,220,0.2450,0,88,999.000,999.0,99.0
+1986,7,3,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,12.8,48,99300,447,1321,372,220,367,97,23500,33700,12100,1810,180,5.2,1,1,24.1,77777,9,999999999,229,0.2450,0,88,999.000,999.0,99.0
+1986,7,3,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,12.8,52,99200,213,1321,360,76,145,53,8100,9600,6600,980,190,6.2,0,0,24.1,77777,9,999999999,229,0.2450,0,88,999.000,999.0,99.0
+1986,7,3,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,13.3,57,99200,23,628,355,9,2,9,0,0,0,0,180,4.1,0,0,24.1,77777,9,999999999,240,0.2450,0,88,999.000,999.0,99.0
+1986,7,3,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,13.3,61,99200,0,0,350,0,0,0,0,0,0,0,180,6.2,0,0,24.1,77777,9,999999999,240,0.2450,0,88,999.000,999.0,99.0
+1986,7,3,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,13.3,63,99200,0,0,348,0,0,0,0,0,0,0,190,6.7,0,0,24.1,77777,9,999999999,240,0.2450,0,88,999.000,999.0,99.0
+1986,7,3,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,13.3,66,99200,0,0,345,0,0,0,0,0,0,0,180,6.2,0,0,24.1,77777,9,999999999,240,0.2450,0,88,999.000,999.0,99.0
+1986,7,3,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,12.2,63,99200,0,0,355,0,0,0,0,0,0,0,180,5.7,3,3,24.1,77777,9,999999999,220,0.2450,0,88,999.000,999.0,99.0
+1986,7,4,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,11.1,65,99200,0,0,373,0,0,0,0,0,0,0,180,5.2,9,9,24.1,2440,9,999999999,209,0.2450,0,88,999.000,999.0,99.0
+1986,7,4,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,11.7,70,99200,0,0,363,0,0,0,0,0,0,0,180,6.7,8,8,24.1,1520,9,999999999,209,0.2450,0,88,999.000,999.0,99.0
+1986,7,4,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,12.8,78,99000,0,0,346,0,0,0,0,0,0,0,190,7.7,4,4,24.1,77777,9,999999999,229,0.2450,0,88,999.000,999.0,99.0
+1986,7,4,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,13.9,81,99000,0,0,373,0,0,0,0,0,0,0,180,8.8,9,9,24.1,1160,9,999999999,240,0.2450,0,88,999.000,999.0,99.0
+1986,7,4,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,15.0,84,99000,38,804,347,16,19,14,1700,700,1600,290,180,7.7,8,2,24.1,77777,9,999999999,259,0.1260,0,88,999.000,999.0,99.0
+1986,7,4,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,15.6,81,98900,244,1321,357,107,243,62,11100,17500,7800,1130,190,7.7,9,3,24.1,77777,9,999999999,270,0.1260,0,88,999.000,999.0,99.0
+1986,7,4,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,16.1,69,99000,478,1321,377,254,402,108,26900,37600,13300,2050,190,8.2,9,4,24.1,77777,9,999999999,279,0.1260,0,88,999.000,999.0,99.0
+1986,7,4,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,16.7,66,99000,704,1321,386,350,216,234,38100,22300,26200,5970,210,9.8,9,5,24.1,7620,9,999999999,290,0.1260,0,88,999.000,999.0,99.0
+1986,7,4,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,18.3,67,98900,906,1321,397,518,365,266,56300,39300,29300,7330,210,10.8,9,5,24.1,7620,9,999999999,320,0.1260,0,88,999.000,999.0,99.0
+1986,7,4,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,18.9,63,98900,1069,1321,411,750,566,290,80200,59100,32400,10800,210,10.8,9,6,24.1,7620,9,999999999,329,0.1260,0,88,999.000,999.0,99.0
+1986,7,4,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,19.4,65,98900,1183,1321,423,468,104,375,51900,11100,42000,17570,200,8.2,10,8,24.1,7010,9,999999999,340,0.1260,0,88,999.000,999.0,99.0
+1986,7,4,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,20.0,65,98900,1240,1321,415,969,764,249,103100,77900,29800,16690,220,8.8,6,6,24.1,7010,9,999999999,350,0.1260,0,88,999.000,999.0,99.0
+1986,7,4,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,20.6,59,98800,1236,1321,413,905,746,204,97600,76700,25600,13510,220,11.8,6,2,24.1,77777,9,999999999,359,0.1260,0,88,999.000,999.0,99.0
+1986,7,4,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,21.1,61,98800,1171,1321,422,825,627,268,86800,63400,30500,13130,190,10.3,9,4,24.1,77777,9,999999999,370,0.1260,0,88,999.000,999.0,99.0
+1986,7,4,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,20.6,55,98800,1050,1321,424,736,635,230,77200,64200,26100,7960,220,8.2,9,3,24.1,77777,9,999999999,359,0.1260,0,88,999.000,999.0,99.0
+1986,7,4,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,20.6,55,98700,880,1321,420,569,582,181,59600,58600,20500,4670,210,10.3,8,2,24.1,77777,9,999999999,359,0.1260,0,88,999.000,999.0,99.0
+1986,7,4,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,20.6,57,98700,675,1321,417,416,529,147,44900,53300,17600,3080,200,10.3,8,2,24.1,77777,9,999999999,359,0.1260,0,88,999.000,999.0,99.0
+1986,7,4,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,21.1,63,98700,446,1321,426,213,297,114,23000,28000,13500,2250,200,8.8,8,6,24.1,7620,9,999999999,370,0.1260,0,88,999.000,999.0,99.0
+1986,7,4,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,21.1,65,98700,212,1321,415,67,77,55,7400,5400,6500,1170,200,10.3,7,4,24.1,7620,9,999999999,370,0.1260,0,88,999.000,999.0,99.0
+1986,7,4,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,21.7,69,98800,23,628,410,7,7,6,0,0,0,0,190,9.3,7,3,24.1,77777,9,999999999,379,0.1260,0,88,999.000,999.0,99.0
+1986,7,4,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.7,21.7,74,98800,0,0,400,0,0,0,0,0,0,0,220,7.2,6,2,24.1,77777,9,999999999,390,0.1260,0,88,999.000,999.0,99.0
+1986,7,4,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.7,21.7,74,98900,0,0,404,0,0,0,0,0,0,0,190,8.8,3,3,24.1,77777,9,999999999,390,0.1260,0,88,999.000,999.0,99.0
+1986,7,4,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.7,21.1,72,98900,0,0,403,0,0,0,0,0,0,0,190,8.2,3,3,24.1,77777,9,999999999,379,0.1260,0,88,999.000,999.0,99.0
+1986,7,4,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.6,21.7,79,99000,0,0,382,0,0,0,0,0,0,0,180,8.2,0,0,24.1,77777,9,999999999,390,0.1260,0,88,999.000,999.0,99.0
+1986,7,5,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.6,20.6,74,98900,0,0,381,0,0,0,0,0,0,0,190,8.8,0,0,24.1,77777,9,999999999,359,0.1260,0,88,999.000,999.0,99.0
+1986,7,5,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.6,20.0,72,98900,0,0,380,0,0,0,0,0,0,0,180,7.7,0,0,24.1,77777,9,999999999,350,0.1260,0,88,999.000,999.0,99.0
+1986,7,5,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.0,18.3,67,99000,0,0,382,0,0,0,0,0,0,0,180,9.8,3,1,16.1,77777,9,999999999,320,0.1260,0,88,999.000,999.0,99.0
+1986,7,5,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.0,18.9,69,99000,0,0,383,0,0,0,0,0,0,0,180,7.7,4,1,16.1,77777,9,999999999,329,0.1260,0,88,999.000,999.0,99.0
+1986,7,5,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,20.0,74,99000,37,804,384,13,21,12,1500,800,1400,250,190,8.2,4,1,19.3,77777,9,999999999,350,0.1320,0,88,999.000,999.0,99.0
+1986,7,5,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,20.0,79,99100,242,1321,378,101,235,58,10500,16900,7400,1050,210,6.2,4,1,16.1,77777,9,999999999,350,0.1320,0,88,999.000,999.0,99.0
+1986,7,5,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,20.6,74,99100,476,1321,381,285,574,76,29700,53500,10400,1490,220,7.7,0,0,12.9,77777,9,999999999,359,0.1320,0,88,999.000,999.0,99.0
+1986,7,5,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,21.1,72,99100,702,1321,387,474,695,102,50300,69600,13200,2290,210,7.7,0,0,12.9,77777,9,999999999,379,0.1320,0,88,999.000,999.0,99.0
+1986,7,5,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,21.1,65,99200,904,1321,395,650,761,126,67900,76300,15600,3220,190,7.2,1,0,12.9,77777,9,999999999,370,0.1320,0,88,999.000,999.0,99.0
+1986,7,5,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,21.1,61,99200,1068,1321,401,795,803,142,84000,81100,18300,4940,190,7.7,1,0,12.9,77777,9,999999999,370,0.1320,0,88,999.000,999.0,99.0
+1986,7,5,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,21.7,57,99200,1182,1321,411,896,819,159,94900,82900,20600,7790,200,5.7,2,0,12.9,77777,9,999999999,390,0.1320,0,88,999.000,999.0,99.0
+1986,7,5,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,21.1,55,99200,1239,1321,418,866,748,160,92300,75900,21000,10230,200,7.7,2,1,11.3,77777,9,999999999,370,0.1320,0,88,999.000,999.0,99.0
+1986,7,5,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,32.2,21.1,52,99200,1235,1321,424,905,808,147,92500,80900,16600,7430,200,7.7,1,1,11.3,77777,9,999999999,370,0.1320,0,88,999.000,999.0,99.0
+1986,7,5,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,32.8,21.1,50,99100,1171,1321,433,836,750,170,88100,75600,20900,7850,190,8.8,2,2,16.1,77777,9,999999999,370,0.1320,0,88,999.000,999.0,99.0
+1986,7,5,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,32.8,20.6,49,99100,1049,1321,437,731,652,212,77200,66200,24500,7400,190,8.8,3,3,24.1,77777,9,999999999,370,0.1320,0,88,999.000,999.0,99.0
+1986,7,5,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,21.1,54,99100,880,1321,431,581,589,188,60700,59200,21200,4820,190,8.2,3,3,24.1,77777,9,999999999,379,0.1320,0,88,999.000,999.0,99.0
+1986,7,5,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,21.1,54,99100,674,1321,427,408,514,147,44000,51700,17600,3080,190,9.3,2,2,24.1,77777,9,999999999,379,0.1320,0,88,999.000,999.0,99.0
+1986,7,5,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,20.6,55,99100,446,1321,407,255,546,72,26800,50000,9900,1400,180,7.7,0,0,24.1,77777,9,999999999,359,0.1320,0,88,999.000,999.0,99.0
+1986,7,5,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,21.1,61,99100,211,1321,401,88,285,43,9400,19200,6300,760,190,9.3,0,0,24.1,77777,9,999999999,370,0.1320,0,88,999.000,999.0,99.0
+1986,7,5,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,21.1,65,99100,22,628,395,10,14,9,0,0,0,0,190,8.8,0,0,24.1,77777,9,999999999,370,0.1320,0,88,999.000,999.0,99.0
+1986,7,5,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,27.2,21.1,69,99200,0,0,389,0,0,0,0,0,0,0,180,9.3,0,0,24.1,77777,9,999999999,370,0.1320,0,88,999.000,999.0,99.0
+1986,7,5,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,27.2,20.6,67,99200,0,0,389,0,0,0,0,0,0,0,180,7.7,0,0,24.1,77777,9,999999999,359,0.1320,0,88,999.000,999.0,99.0
+1986,7,5,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,27.2,20.0,65,99300,0,0,388,0,0,0,0,0,0,0,180,7.2,0,0,24.1,77777,9,999999999,350,0.1320,0,88,999.000,999.0,99.0
+1986,7,5,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.1,18.3,62,99300,0,0,380,0,0,0,0,0,0,0,190,8.2,0,0,24.1,77777,9,999999999,320,0.1320,0,88,999.000,999.0,99.0
+1986,7,6,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.1,18.3,62,99300,0,0,380,0,0,0,0,0,0,0,190,7.2,0,0,24.1,77777,9,999999999,320,0.1320,0,88,999.000,999.0,99.0
+1986,7,6,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.1,18.3,62,99300,0,0,380,0,0,0,0,0,0,0,190,8.2,0,0,24.1,77777,9,999999999,320,0.1320,0,88,999.000,999.0,99.0
+1986,7,6,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,17.8,71,99300,0,0,366,0,0,0,0,0,0,0,220,6.7,0,0,24.1,77777,9,999999999,309,0.1320,0,88,999.000,999.0,99.0
+1986,7,6,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,18.9,82,99300,0,0,362,0,0,0,0,0,0,0,190,5.2,0,0,24.1,77777,9,999999999,329,0.1320,0,88,999.000,999.0,99.0
+1986,7,6,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,18.9,84,99300,36,782,359,16,36,13,1600,1000,1600,220,190,5.2,0,0,24.1,77777,9,999999999,329,0.1210,0,88,999.000,999.0,99.0
+1986,7,6,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,19.4,79,99400,240,1321,368,111,356,46,11300,26100,6600,830,190,7.2,0,0,24.1,77777,9,999999999,340,0.1210,0,88,999.000,999.0,99.0
+1986,7,6,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,20.6,74,99400,474,1321,381,282,576,74,29500,53700,10200,1460,210,6.2,1,0,16.1,77777,9,999999999,370,0.1210,0,88,999.000,999.0,99.0
+1986,7,6,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,21.1,72,99400,700,1321,387,474,706,97,49100,69500,12300,2070,210,5.7,0,0,12.9,77777,9,999999999,379,0.1210,0,88,999.000,999.0,99.0
+1986,7,6,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,22.2,70,99400,903,1321,396,653,780,116,68700,78500,15000,3050,210,7.7,0,0,11.3,77777,9,999999999,400,0.1210,0,88,999.000,999.0,99.0
+1986,7,6,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,22.8,67,99500,1067,1321,403,797,821,130,84900,83300,17600,4600,210,4.6,0,0,11.3,77777,9,999999999,409,0.1210,0,88,999.000,999.0,99.0
+1986,7,6,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,22.8,61,99500,1181,1321,412,897,844,139,91700,84500,16000,5500,200,5.7,0,0,11.3,77777,9,999999999,409,0.1210,0,88,999.000,999.0,99.0
+1986,7,6,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,22.8,59,99500,1238,1321,423,884,785,144,90200,78700,16300,7460,210,7.2,1,1,11.3,77777,9,999999999,409,0.1210,0,88,999.000,999.0,99.0
+1986,7,6,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,32.2,22.8,58,99500,1235,1321,436,867,692,218,93100,71000,26600,14300,210,7.2,3,3,11.3,77777,9,999999999,419,0.1210,0,88,999.000,999.0,99.0
+1986,7,6,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,32.8,22.2,54,99500,1170,1321,442,845,663,257,89200,67200,29600,12580,230,7.7,4,4,11.3,77777,9,999999999,400,0.1210,0,88,999.000,999.0,99.0
+1986,7,6,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,32.2,22.8,58,99500,1049,1321,440,705,567,254,76300,59200,29200,8950,220,7.2,4,4,11.3,77777,9,999999999,419,0.1210,0,88,999.000,999.0,99.0
+1986,7,6,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,32.2,22.2,56,99400,880,1321,442,491,397,226,52400,41000,25000,5920,210,7.2,5,5,11.3,77777,9,999999999,400,0.1210,0,88,999.000,999.0,99.0
+1986,7,6,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,22.2,59,99400,674,1321,429,432,609,122,45300,60100,14600,2610,180,5.7,3,3,11.3,77777,9,999999999,400,0.1210,0,88,999.000,999.0,99.0
+1986,7,6,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,22.8,63,99500,445,1321,423,237,466,81,24700,42400,10400,1540,220,6.7,2,2,11.3,77777,9,999999999,409,0.1210,0,88,999.000,999.0,99.0
+1986,7,6,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,20.6,87,99800,211,1321,423,25,4,24,2900,0,2900,960,290,6.2,10,10,11.3,880,9,999999999,359,0.1210,0,88,999.000,999.0,99.0
+1986,7,6,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,20.0,97,99800,22,628,410,4,0,4,0,0,0,0,310,2.6,10,10,14.5,1160,9,999999999,359,0.1210,0,88,999.000,999.0,99.0
+1986,7,6,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,20.0,97,99600,0,0,370,0,0,0,0,0,0,0,270,2.1,3,3,19.3,77777,9,999999999,350,0.1210,0,88,999.000,999.0,99.0
+1986,7,6,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,17.8,97,99700,0,0,353,0,0,0,0,0,0,0,190,3.6,2,2,24.1,77777,9,999999999,309,0.1210,0,88,999.000,999.0,99.0
+1986,7,6,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,18.9,90,99800,0,0,354,0,0,0,0,0,0,0,190,3.1,0,0,19.3,77777,9,999999999,329,0.1210,0,88,999.000,999.0,99.0
+1986,7,6,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,20.6,97,99800,0,0,365,0,0,0,0,0,0,0,230,2.6,1,1,16.1,77777,9,999999999,370,0.1210,0,88,999.000,999.0,99.0
+1986,7,7,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,20.0,93,99800,0,0,357,0,0,0,0,0,0,0,240,2.6,0,0,16.1,77777,9,999999999,350,0.1210,0,88,999.000,999.0,99.0
+1986,7,7,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,20.6,100,99800,0,0,391,0,0,0,0,0,0,0,280,2.6,8,8,12.9,180,9,999999999,370,0.1210,0,88,999.000,999.0,99.0
+1986,7,7,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,21.1,100,99800,0,0,414,0,0,0,0,0,0,0,280,2.6,10,10,12.9,180,9,999999999,379,0.1210,0,88,999.000,999.0,99.0
+1986,7,7,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,21.1,100,99900,0,0,414,0,0,0,0,0,0,0,0,0.0,10,10,11.3,180,9,999999999,379,0.1210,0,88,999.000,999.0,99.0
+1986,7,7,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,19.4,93,100000,34,782,409,4,0,4,500,0,500,160,290,2.6,10,10,16.1,1160,9,999999999,340,0.1980,0,88,999.000,999.0,99.0
+1986,7,7,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,18.9,90,100000,237,1321,397,72,10,70,7900,300,7900,2280,10,3.6,9,9,19.3,1400,9,999999999,329,0.1980,0,88,999.000,999.0,99.0
+1986,7,7,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,18.3,84,100100,472,1321,410,130,3,129,14700,200,14600,4860,360,2.6,10,10,24.1,2440,9,999999999,320,0.1980,0,88,999.000,999.0,99.0
+1986,7,7,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,17.8,79,100100,699,1321,413,197,8,193,22700,700,22300,8000,40,3.1,10,10,24.1,2740,9,999999999,309,0.1980,0,88,999.000,999.0,99.0
+1986,7,7,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,16.1,64,100100,901,1321,408,514,295,312,55200,31700,33600,8800,20,2.6,10,9,24.1,2440,9,999999999,279,0.1980,0,88,999.000,999.0,99.0
+1986,7,7,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,16.1,64,100000,1065,1321,400,535,237,343,58400,25700,37600,12280,80,3.6,10,8,24.1,2440,9,999999999,279,0.1980,0,88,999.000,999.0,99.0
+1986,7,7,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,13.9,44,100000,1180,1321,400,771,507,316,83000,53000,35600,16510,130,2.6,7,4,24.1,7620,9,999999999,250,0.1980,0,88,999.000,999.0,99.0
+1986,7,7,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,12.2,36,100000,1238,1321,419,792,453,366,84800,47300,40300,24860,80,3.6,7,7,19.3,2440,9,999999999,220,0.1980,0,88,999.000,999.0,99.0
+1986,7,7,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,14.4,46,100000,1234,1321,419,745,390,379,79400,40700,41300,25300,80,4.1,10,8,19.3,2440,9,999999999,259,0.1980,0,88,999.000,999.0,99.0
+1986,7,7,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,13.9,45,100000,1169,1321,436,350,10,341,41400,900,40600,15420,50,4.1,10,10,19.3,2440,9,999999999,250,0.1980,0,88,999.000,999.0,99.0
+1986,7,7,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,13.3,44,100000,1048,1321,435,242,1,241,28900,100,28800,11530,50,3.1,10,10,24.1,3050,9,999999999,240,0.1980,0,88,999.000,999.0,99.0
+1986,7,7,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,15.0,52,99900,879,1321,431,208,17,197,24700,1400,23700,9150,40,3.6,10,10,24.1,3050,9,999999999,259,0.1980,0,88,999.000,999.0,99.0
+1986,7,7,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,17.2,66,99800,673,1321,425,105,8,101,12600,500,12400,4710,40,4.1,10,10,24.1,3660,9,999999999,300,0.1980,0,88,999.000,999.0,99.0
+1986,7,7,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,17.8,71,99800,444,1321,422,96,5,94,11000,300,10900,3750,70,3.6,10,10,24.1,3660,9,999999999,309,0.1980,0,88,999.000,999.0,99.0
+1986,7,7,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,15.6,62,99800,210,1321,419,47,1,47,5300,0,5300,1650,50,3.1,10,10,24.1,3660,9,999999999,270,0.1980,0,88,999.000,999.0,99.0
+1986,7,7,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,15.0,62,99700,21,606,416,9,0,9,0,0,0,0,80,2.6,10,10,24.1,3660,9,999999999,270,0.1980,0,88,999.000,999.0,99.0
+1986,7,7,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,14.4,60,99700,0,0,415,0,0,0,0,0,0,0,120,3.1,10,10,24.1,3660,9,999999999,259,0.1980,0,88,999.000,999.0,99.0
+1986,7,7,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,15.6,68,99700,0,0,410,0,0,0,0,0,0,0,80,3.6,10,10,24.1,880,9,999999999,270,0.1980,0,88,999.000,999.0,99.0
+1986,7,7,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,16.1,73,99700,0,0,396,0,0,0,0,0,0,0,50,3.1,9,9,24.1,880,9,999999999,279,0.1980,0,88,999.000,999.0,99.0
+1986,7,7,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,17.8,81,99700,0,0,410,0,0,0,0,0,0,0,280,3.1,10,10,19.3,880,9,999999999,309,0.1980,0,88,999.000,999.0,99.0
+1986,7,8,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,18.9,90,99600,0,0,408,0,0,0,0,0,0,0,150,2.1,10,10,24.1,880,9,999999999,329,0.1980,0,88,999.000,999.0,99.0
+1986,7,8,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,19.4,100,99500,0,0,402,0,0,0,0,0,0,0,190,2.6,10,10,19.3,880,9,999999999,340,0.1980,0,88,999.000,999.0,99.0
+1986,7,8,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,18.3,100,99500,0,0,395,0,0,0,0,0,0,0,240,2.1,10,10,24.1,1520,9,999999999,320,0.1980,0,88,999.000,999.0,99.0
+1986,7,8,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,18.3,100,99500,0,0,395,0,0,0,0,0,0,0,0,0.0,10,10,16.1,760,9,999999999,320,0.1980,0,88,999.000,999.0,99.0
+1986,7,8,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,17.2,100,99500,33,760,388,8,0,8,1000,0,1000,300,170,2.1,10,10,14.5,1220,9,999999999,300,0.1110,0,88,999.000,999.0,99.0
+1986,7,8,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,20.0,100,99500,235,1321,406,37,1,37,4300,0,4300,1420,190,2.1,10,10,8.0,1010,9,999999999,350,0.1110,0,88,999.000,999.0,99.0
+1986,7,8,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,20.6,100,99500,470,1321,410,90,0,90,10500,0,10500,3710,150,2.1,10,10,3.2,460,9,999999999,359,0.1110,0,88,999.000,999.0,99.0
+1986,7,8,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,21.1,97,99400,697,1321,406,231,100,178,25600,10400,20100,4520,170,3.1,10,9,6.4,1070,9,999999999,379,0.1110,0,88,999.000,999.0,99.0
+1986,7,8,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,22.8,85,99400,899,1321,421,377,181,252,41600,19200,28500,7440,210,5.7,10,8,11.3,2740,9,999999999,419,0.1110,0,88,999.000,999.0,99.0
+1986,7,8,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,22.8,85,99400,1064,1321,409,608,423,265,65500,44200,29900,9690,170,4.1,9,6,11.3,7620,9,999999999,419,0.1110,0,88,999.000,999.0,99.0
+1986,7,8,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,22.8,77,99300,1179,1321,430,625,334,326,69400,36400,36900,15370,240,4.6,10,8,11.3,610,9,999999999,409,0.1110,0,88,999.000,999.0,99.0
+1986,7,8,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,22.8,74,99200,1237,1321,433,635,238,411,69800,25900,45500,24680,230,5.2,10,8,11.3,760,9,999999999,409,0.1110,0,88,999.000,999.0,99.0
+1986,7,8,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,22.8,74,99200,1233,1321,455,204,34,172,22700,3400,19500,9850,250,4.1,10,10,11.3,760,9,999999999,409,0.1110,0,88,999.000,999.0,99.0
+1986,7,8,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,23.3,79,99100,1169,1321,452,170,6,165,21300,400,20900,8550,220,5.2,10,10,11.3,2440,9,999999999,419,0.1110,0,88,999.000,999.0,99.0
+1986,7,8,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,23.9,79,99100,1048,1321,428,402,64,350,44200,6600,39000,13890,210,5.7,9,7,11.3,2440,9,999999999,440,0.1110,0,88,999.000,999.0,99.0
+1986,7,8,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,23.3,74,99100,878,1321,437,307,169,195,34200,18200,22000,5000,230,5.2,9,8,11.3,2440,9,999999999,419,0.1110,0,88,999.000,999.0,99.0
+1986,7,8,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,23.3,77,99000,672,1321,422,373,388,175,39300,38900,19500,3730,230,5.7,9,6,11.3,2440,9,999999999,430,0.1110,0,88,999.000,999.0,99.0
+1986,7,8,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,23.3,79,99000,443,1321,452,142,28,133,15600,2600,14700,3580,230,3.1,10,10,11.3,1010,9,999999999,419,0.1110,0,88,999.000,999.0,99.0
+1986,7,8,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,20.6,74,98900,208,1321,439,40,4,40,4600,0,4600,1460,240,3.6,10,10,11.3,2440,9,999999999,359,0.1110,0,88,999.000,999.0,99.0
+1986,7,8,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,22.2,82,99000,21,606,441,3,0,3,0,0,0,0,310,2.1,10,10,9.7,760,9,999999999,400,0.1110,0,88,999.000,999.0,99.0
+1986,7,8,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,23.3,100,99000,0,0,429,0,0,0,0,0,0,0,340,3.1,10,10,8.0,760,9,999999999,419,0.1110,0,88,999.000,999.0,99.0
+1986,7,8,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,23.3,100,99000,0,0,429,0,0,0,0,0,0,0,280,10.8,10,10,8.0,210,9,999999999,419,0.1110,0,88,999.000,999.0,99.0
+1986,7,8,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,23.3,100,99000,0,0,429,0,0,0,0,0,0,0,260,7.7,10,10,8.0,610,9,999999999,419,0.1110,0,88,999.000,999.0,99.0
+1986,7,8,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,22.2,100,98600,0,0,422,0,0,0,0,0,0,0,170,7.7,10,10,8.0,610,9,999999999,400,0.1110,0,88,999.000,999.0,99.0
+1986,7,9,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,21.1,100,98800,0,0,414,0,0,0,0,0,0,0,230,3.1,10,10,16.1,1010,9,999999999,370,0.1110,0,88,999.000,999.0,99.0
+1986,7,9,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,21.1,100,98900,0,0,414,0,0,0,0,0,0,0,320,3.1,10,10,19.3,1010,9,999999999,370,0.1110,0,88,999.000,999.0,99.0
+1986,7,9,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,20.0,90,98900,0,0,416,0,0,0,0,0,0,0,280,2.6,10,10,24.1,700,9,999999999,350,0.1110,0,88,999.000,999.0,99.0
+1986,7,9,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,20.0,93,99000,0,0,412,0,0,0,0,0,0,0,270,1.5,10,10,24.1,610,9,999999999,350,0.1110,0,88,999.000,999.0,99.0
+1986,7,9,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,20.6,97,99000,32,738,413,12,0,12,1400,0,1400,420,320,2.1,10,10,24.1,640,9,999999999,359,0.2750,0,88,999.000,999.0,99.0
+1986,7,9,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,20.6,93,99000,233,1321,417,52,0,52,5900,0,5900,1850,330,4.1,10,10,24.1,460,9,999999999,359,0.2750,0,88,999.000,999.0,99.0
+1986,7,9,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,20.0,90,99100,468,1321,416,99,3,98,11400,200,11400,3960,340,5.2,10,10,24.1,460,9,999999999,350,0.2750,0,88,999.000,999.0,99.0
+1986,7,9,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,20.0,90,99100,695,1321,416,180,2,179,20800,200,20700,7560,20,3.6,10,10,11.3,310,9,999999999,350,0.2750,0,88,999.000,999.0,99.0
+1986,7,9,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,17.2,87,99100,898,1321,400,267,2,265,30900,200,30800,11550,50,5.2,10,10,16.1,310,9,999999999,300,0.2750,0,88,999.000,999.0,99.0
+1986,7,9,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,16.7,79,99200,1063,1321,405,409,2,408,47100,200,46900,16760,40,5.7,10,10,24.1,580,9,999999999,290,0.2750,0,88,999.000,999.0,99.0
+1986,7,9,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,16.7,73,99200,1178,1321,412,428,0,428,49900,0,49900,18000,60,5.7,10,10,24.1,610,9,999999999,290,0.2750,0,88,999.000,999.0,99.0
+1986,7,9,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,16.7,73,99200,1236,1321,400,528,128,409,58600,13700,45800,22860,40,4.6,9,9,24.1,610,9,999999999,290,0.2750,0,88,999.000,999.0,99.0
+1986,7,9,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,16.1,66,99200,1232,1321,373,929,648,322,96900,65000,36100,20360,360,5.2,10,2,24.1,77777,9,999999999,279,0.2750,0,88,999.000,999.0,99.0
+1986,7,9,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,16.1,64,99200,1168,1321,376,799,544,316,85900,56900,35600,15790,10,5.2,8,2,24.1,77777,9,999999999,279,0.2750,0,88,999.000,999.0,99.0
+1986,7,9,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,15.0,60,99200,1047,1321,374,729,581,268,78500,60600,30400,9440,20,5.7,6,2,24.1,77777,9,999999999,259,0.2750,0,88,999.000,999.0,99.0
+1986,7,9,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,14.4,60,99200,878,1321,371,506,318,295,54500,34100,31900,8060,30,6.2,5,2,24.1,77777,9,999999999,259,0.2750,0,88,999.000,999.0,99.0
+1986,7,9,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,13.3,55,99200,671,1321,365,384,446,157,40900,44800,18100,3310,30,5.2,3,1,24.1,77777,9,999999999,240,0.2750,0,88,999.000,999.0,99.0
+1986,7,9,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,10.6,49,99200,442,1321,356,214,338,101,22700,31000,12300,1900,40,6.2,2,1,24.1,77777,9,999999999,200,0.2750,0,88,999.000,999.0,99.0
+1986,7,9,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,10.0,53,99200,207,1321,348,66,95,52,7300,6600,6300,1100,30,5.2,1,1,24.1,77777,9,999999999,200,0.2750,0,88,999.000,999.0,99.0
+1986,7,9,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,9.4,55,99200,20,606,346,5,1,5,0,0,0,0,40,4.6,3,2,24.1,77777,9,999999999,189,0.2750,0,88,999.000,999.0,99.0
+1986,7,9,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,11.1,68,99300,0,0,336,0,0,0,0,0,0,0,30,3.1,2,1,24.1,77777,9,999999999,209,0.2750,0,88,999.000,999.0,99.0
+1986,7,9,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,12.2,81,99300,0,0,330,0,0,0,0,0,0,0,30,2.6,2,1,24.1,77777,9,999999999,220,0.2750,0,88,999.000,999.0,99.0
+1986,7,9,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,11.7,81,99200,0,0,320,0,0,0,0,0,0,0,10,2.1,0,0,24.1,77777,9,999999999,220,0.2750,0,88,999.000,999.0,99.0
+1986,7,9,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,11.7,87,99200,0,0,315,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,220,0.2750,0,88,999.000,999.0,99.0
+1986,7,10,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,12.2,87,99200,0,0,318,0,0,0,0,0,0,0,30,2.6,0,0,24.1,77777,9,999999999,220,0.2750,0,88,999.000,999.0,99.0
+1986,7,10,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,12.8,87,99200,0,0,321,0,0,0,0,0,0,0,10,2.1,0,0,24.1,77777,9,999999999,229,0.2750,0,88,999.000,999.0,99.0
+1986,7,10,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,12.2,87,99200,0,0,324,0,0,0,0,0,0,0,10,2.6,4,1,24.1,77777,9,999999999,220,0.2750,0,88,999.000,999.0,99.0
+1986,7,10,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,12.8,87,99200,0,0,327,0,0,0,0,0,0,0,360,1.5,4,1,24.1,77777,9,999999999,229,0.2750,0,88,999.000,999.0,99.0
+1986,7,10,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,13.3,87,99200,31,716,356,9,1,9,1100,0,1100,330,10,3.1,10,8,24.1,3050,9,999999999,240,0.1530,0,88,999.000,999.0,99.0
+1986,7,10,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,15.0,87,99200,230,1322,385,48,4,47,5400,100,5400,1710,10,2.1,10,10,24.1,1070,9,999999999,259,0.1530,0,88,999.000,999.0,99.0
+1986,7,10,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,16.7,84,99200,466,1322,399,106,22,98,11600,2000,10900,2850,70,3.1,10,10,24.1,2440,9,999999999,290,0.1530,0,88,999.000,999.0,99.0
+1986,7,10,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,17.8,84,99200,693,1322,407,254,15,246,28600,1400,27800,9320,130,3.6,10,10,24.1,1070,9,999999999,309,0.1530,0,88,999.000,999.0,99.0
+1986,7,10,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,18.9,82,99200,896,1322,417,278,8,273,32200,700,31700,11770,120,5.7,10,10,24.1,1220,9,999999999,329,0.1530,0,88,999.000,999.0,99.0
+1986,7,10,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,19.4,79,99000,1061,1322,424,372,2,370,43100,200,42900,15780,120,7.7,10,10,8.0,910,9,999999999,340,0.1530,0,88,999.000,999.0,99.0
+1986,7,10,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,18.9,79,99000,1177,1322,421,361,2,359,42600,200,42400,16020,100,5.7,10,10,6.4,910,9,999999999,329,0.1530,0,88,999.000,999.0,99.0
+1986,7,10,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,20.0,87,99000,1235,1322,419,278,2,276,33700,200,33600,13310,130,5.2,10,10,6.4,910,9,999999999,350,0.1530,0,88,999.000,999.0,99.0
+1986,7,10,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,20.6,79,98900,1232,1322,432,394,2,392,46500,200,46400,17260,140,5.2,10,10,6.4,910,9,999999999,359,0.1530,0,88,999.000,999.0,99.0
+1986,7,10,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,20.0,76,98900,1167,1322,431,421,0,421,49000,0,49000,17750,140,4.1,10,10,8.0,910,9,999999999,350,0.1530,0,88,999.000,999.0,99.0
+1986,7,10,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,21.1,85,98900,1046,1322,430,238,1,238,28600,100,28500,11410,120,4.6,10,10,8.0,580,9,999999999,379,0.1530,0,88,999.000,999.0,99.0
+1986,7,10,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,20.0,90,98800,877,1322,416,194,1,193,22900,100,22900,9000,100,6.7,10,10,3.2,580,9,999999999,350,0.1530,0,88,999.000,999.0,99.0
+1986,7,10,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,18.9,87,98800,670,1322,411,222,1,221,25000,100,25000,8540,70,5.2,10,10,8.0,910,9,999999999,329,0.1530,0,88,999.000,999.0,99.0
+1986,7,10,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,18.3,84,98700,441,1322,410,134,0,134,15000,0,15000,4790,100,6.7,10,10,8.0,640,9,999999999,320,0.1530,0,88,999.000,999.0,99.0
+1986,7,10,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,18.3,81,98600,206,1322,414,53,0,53,5900,0,5900,1780,110,6.2,10,10,9.7,580,9,999999999,320,0.1530,0,88,999.000,999.0,99.0
+1986,7,10,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,19.4,90,98600,20,584,412,8,0,8,0,0,0,0,130,6.2,10,10,9.7,460,9,999999999,340,0.1530,0,88,999.000,999.0,99.0
+1986,7,10,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,19.4,90,98600,0,0,412,0,0,0,0,0,0,0,140,4.1,10,10,8.0,240,9,999999999,340,0.1530,0,88,999.000,999.0,99.0
+1986,7,10,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,20.0,90,98600,0,0,416,0,0,0,0,0,0,0,110,3.1,10,10,6.4,240,9,999999999,350,0.1530,0,88,999.000,999.0,99.0
+1986,7,10,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,19.4,90,98500,0,0,412,0,0,0,0,0,0,0,140,2.6,10,10,8.0,370,9,999999999,340,0.1530,0,88,999.000,999.0,99.0
+1986,7,10,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,18.9,90,98500,0,0,408,0,0,0,0,0,0,0,150,4.1,10,10,11.3,400,9,999999999,329,0.1530,0,88,999.000,999.0,99.0
+1986,7,11,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,19.4,93,98500,0,0,409,0,0,0,0,0,0,0,160,4.1,10,10,8.0,210,9,999999999,340,0.1530,0,88,999.000,999.0,99.0
+1986,7,11,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,20.0,97,98500,0,0,410,0,0,0,0,0,0,0,170,4.1,10,10,6.4,210,9,999999999,350,0.1530,0,88,999.000,999.0,99.0
+1986,7,11,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,20.0,97,98500,0,0,410,0,0,0,0,0,0,0,200,4.1,10,10,6.4,580,9,999999999,350,0.1530,0,88,999.000,999.0,99.0
+1986,7,11,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,20.0,97,98500,0,0,410,0,0,0,0,0,0,0,180,3.1,10,10,8.0,700,9,999999999,350,0.1530,0,88,999.000,999.0,99.0
+1986,7,11,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,20.0,97,98400,29,716,410,13,0,13,1500,0,1500,450,190,3.1,10,10,6.4,210,9,999999999,350,0.2260,0,88,999.000,999.0,99.0
+1986,7,11,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,20.0,97,98400,228,1322,410,61,0,61,6800,0,6800,2050,220,3.6,10,10,8.0,340,9,999999999,350,0.2260,0,88,999.000,999.0,99.0
+1986,7,11,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,20.0,93,98500,464,1322,412,130,1,129,14600,100,14600,4810,200,4.1,10,10,6.4,180,9,999999999,350,0.2260,0,88,999.000,999.0,99.0
+1986,7,11,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,20.6,93,98500,691,1322,417,217,1,216,24600,100,24600,8580,180,4.6,10,10,4.8,180,9,999999999,359,0.2260,0,88,999.000,999.0,99.0
+1986,7,11,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,20.6,93,98500,894,1322,417,176,1,175,21000,100,21000,8380,220,5.7,10,10,8.0,240,9,999999999,359,0.2260,0,88,999.000,999.0,99.0
+1986,7,11,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,20.6,90,98500,1060,1322,419,214,0,214,25900,0,25900,10510,220,5.2,10,10,6.4,310,9,999999999,359,0.2260,0,88,999.000,999.0,99.0
+1986,7,11,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,21.1,94,98500,1175,1322,420,271,1,270,32700,100,32600,12940,190,4.1,10,10,8.0,340,9,999999999,370,0.2260,0,88,999.000,999.0,99.0
+1986,7,11,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,21.1,90,98400,1234,1322,424,451,1,450,52700,100,52600,18890,200,5.7,10,10,16.1,760,9,999999999,370,0.2260,0,88,999.000,999.0,99.0
+1986,7,11,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,21.7,90,98300,1231,1322,427,422,1,421,49600,100,49500,18100,240,3.1,10,10,24.1,1680,9,999999999,379,0.2260,0,88,999.000,999.0,99.0
+1986,7,11,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,21.7,87,98400,1167,1322,431,402,0,401,46900,0,46900,17210,230,5.2,10,10,24.1,490,9,999999999,379,0.2260,0,88,999.000,999.0,99.0
+1986,7,11,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,21.7,85,98300,1045,1322,422,410,82,345,45200,8400,38600,13690,180,5.7,10,9,24.1,490,9,999999999,379,0.2260,0,88,999.000,999.0,99.0
+1986,7,11,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,21.7,79,98300,876,1322,413,509,382,256,55400,41000,28200,6820,180,5.7,8,7,24.1,3660,9,999999999,379,0.2260,0,88,999.000,999.0,99.0
+1986,7,11,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,21.1,77,98200,669,1322,404,384,374,195,41400,38900,21700,4380,200,5.2,5,5,24.1,77777,9,999999999,370,0.2260,0,88,999.000,999.0,99.0
+1986,7,11,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,21.1,77,98200,440,1322,401,203,200,137,22100,18800,15900,3110,190,4.1,8,4,24.1,77777,9,999999999,370,0.2260,0,88,999.000,999.0,99.0
+1986,7,11,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,21.1,79,98300,204,1322,436,52,8,51,5800,100,5800,1730,200,4.1,10,10,24.1,1010,9,999999999,370,0.2260,0,88,999.000,999.0,99.0
+1986,7,11,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,20.6,79,98300,19,584,405,7,0,7,0,0,0,0,190,4.1,9,7,24.1,1010,9,999999999,359,0.2260,0,88,999.000,999.0,99.0
+1986,7,11,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.9,21.1,85,98300,0,0,430,0,0,0,0,0,0,0,180,3.6,10,10,16.1,700,9,999999999,370,0.2260,0,88,999.000,999.0,99.0
+1986,7,11,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,21.1,87,98300,0,0,426,0,0,0,0,0,0,0,220,3.1,10,10,11.3,580,9,999999999,370,0.2260,0,88,999.000,999.0,99.0
+1986,7,11,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,19.4,90,98300,0,0,412,0,0,0,0,0,0,0,230,5.7,10,10,6.4,760,9,999999999,340,0.2260,0,88,999.000,999.0,99.0
+1986,7,11,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,21.1,94,98300,0,0,420,0,0,0,0,0,0,0,200,3.6,10,10,8.0,760,9,999999999,370,0.2260,0,88,999.000,999.0,99.0
+1986,7,12,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,20.6,93,98300,0,0,377,0,0,0,0,0,0,0,220,3.1,3,3,11.3,77777,9,999999999,359,0.2260,0,88,999.000,999.0,99.0
+1986,7,12,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,18.9,93,98200,0,0,358,0,0,0,0,0,0,0,230,2.6,1,1,11.3,77777,9,999999999,320,0.2260,0,88,999.000,999.0,99.0
+1986,7,12,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,18.3,93,98200,0,0,347,0,0,0,0,0,0,0,250,3.1,0,0,11.3,77777,9,999999999,309,0.2260,0,88,999.000,999.0,99.0
+1986,7,12,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,18.3,97,98300,0,0,345,0,0,0,0,0,0,0,220,3.6,0,0,14.5,77777,9,999999999,320,0.2260,0,88,999.000,999.0,99.0
+1986,7,12,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,18.9,97,98300,28,694,360,10,0,10,1200,0,1200,360,200,3.1,7,2,16.1,77777,9,999999999,329,0.3160,0,88,999.000,999.0,99.0
+1986,7,12,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,19.4,93,98300,225,1322,370,76,43,69,8300,3300,7800,1650,220,2.6,8,3,19.3,77777,9,999999999,340,0.3160,0,88,999.000,999.0,99.0
+1986,7,12,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,20.6,97,98300,461,1322,413,76,39,63,8500,3600,7200,1920,210,4.1,10,10,4.8,90,9,999999999,359,0.3160,0,88,999.000,999.0,99.0
+1986,7,12,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,21.7,97,98300,689,1322,421,232,4,230,26200,400,26000,8920,190,3.1,10,10,3.2,120,9,999999999,379,0.3160,0,88,999.000,999.0,99.0
+1986,7,12,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,21.1,97,98400,893,1322,417,151,6,147,18300,400,18000,7240,270,6.7,10,10,0.0,0,9,999999999,370,0.3160,0,88,999.000,999.0,99.0
+1986,7,12,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,22.2,90,98300,1058,1322,431,412,8,406,47400,800,46800,16680,0,0.0,10,10,11.3,340,9,999999999,390,0.3160,0,88,999.000,999.0,99.0
+1986,7,12,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,20.0,74,98300,1174,1322,423,370,49,326,40900,5000,36500,15700,200,3.1,10,9,14.5,880,9,999999999,350,0.3160,0,88,999.000,999.0,99.0
+1986,7,12,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,20.6,79,98300,1233,1322,432,357,14,344,42600,1200,41500,15740,210,3.6,10,10,14.5,640,9,999999999,359,0.3160,0,88,999.000,999.0,99.0
+1986,7,12,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,20.0,72,98200,1230,1322,406,784,375,433,85700,40800,47700,25300,240,5.7,10,6,16.1,7620,9,999999999,350,0.3160,0,88,999.000,999.0,99.0
+1986,7,12,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,20.6,69,98200,1166,1322,418,652,298,388,71400,32400,42700,17840,240,5.7,8,7,24.1,7620,9,999999999,359,0.3160,0,88,999.000,999.0,99.0
+1986,7,12,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,20.6,65,98200,1045,1322,409,681,411,355,73900,44500,38700,12300,240,4.6,8,3,24.1,77777,9,999999999,359,0.3160,0,88,999.000,999.0,99.0
+1986,7,12,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,20.6,69,98200,875,1322,446,160,21,146,17700,2100,16300,5480,240,6.2,10,10,24.1,910,9,999999999,359,0.3160,0,88,999.000,999.0,99.0
+1986,7,12,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,20.0,67,98200,668,1322,412,337,246,213,36000,25500,23100,4870,230,6.2,8,6,24.1,2440,9,999999999,350,0.3160,0,88,999.000,999.0,99.0
+1986,7,12,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,20.0,69,98200,439,1322,409,171,124,130,18600,11700,14800,2950,230,6.7,8,6,24.1,2130,9,999999999,350,0.3160,0,88,999.000,999.0,99.0
+1986,7,12,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,20.6,76,98200,203,1322,397,74,6,73,8000,200,8000,2130,230,5.2,8,4,24.1,77777,9,999999999,359,0.3160,0,88,999.000,999.0,99.0
+1986,7,12,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,21.1,82,98200,18,562,401,3,0,3,0,0,0,0,230,5.7,6,6,24.1,2130,9,999999999,370,0.3160,0,88,999.000,999.0,99.0
+1986,7,12,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.9,21.1,85,98300,0,0,389,0,0,0,0,0,0,0,230,4.6,3,3,24.1,77777,9,999999999,370,0.3160,0,88,999.000,999.0,99.0
+1986,7,12,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,21.7,90,98400,0,0,400,0,0,0,0,0,0,0,240,5.2,7,7,16.1,910,9,999999999,379,0.3160,0,88,999.000,999.0,99.0
+1986,7,12,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,21.1,87,98400,0,0,377,0,0,0,0,0,0,0,260,5.7,1,1,16.1,77777,9,999999999,370,0.3160,0,88,999.000,999.0,99.0
+1986,7,12,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,20.6,90,98400,0,0,370,0,0,0,0,0,0,0,280,4.6,1,1,14.5,77777,9,999999999,359,0.3160,0,88,999.000,999.0,99.0
+1986,7,13,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,18.3,84,98500,0,0,356,0,0,0,0,0,0,0,290,4.1,0,0,24.1,77777,9,999999999,320,0.3160,0,88,999.000,999.0,99.0
+1986,7,13,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,17.8,87,98500,0,0,356,0,0,0,0,0,0,0,280,2.6,1,1,24.1,77777,9,999999999,309,0.3160,0,88,999.000,999.0,99.0
+1986,7,13,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,17.8,93,98600,0,0,351,0,0,0,0,0,0,0,260,3.1,1,1,24.1,77777,9,999999999,309,0.3160,0,88,999.000,999.0,99.0
+1986,7,13,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,17.8,97,98600,0,0,348,0,0,0,0,0,0,0,240,2.6,3,1,24.1,77777,9,999999999,309,0.3160,0,88,999.000,999.0,99.0
+1986,7,13,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,17.2,97,98700,27,672,353,9,2,9,1100,0,1100,330,240,1.5,6,3,24.1,77777,9,999999999,300,0.2060,0,88,999.000,999.0,99.0
+1986,7,13,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,17.8,90,98800,223,1322,362,70,82,56,7600,5900,6600,1190,230,3.6,7,3,24.1,77777,9,999999999,309,0.2060,0,88,999.000,999.0,99.0
+1986,7,13,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,17.8,81,98800,459,1322,355,253,453,94,26900,42000,12300,1750,250,4.1,0,0,24.1,77777,9,999999999,309,0.2060,0,88,999.000,999.0,99.0
+1986,7,13,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,17.8,71,98800,687,1322,366,446,602,131,46400,59400,15500,2800,240,4.6,0,0,24.1,77777,9,999999999,309,0.2060,0,88,999.000,999.0,99.0
+1986,7,13,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,17.8,64,98800,891,1322,374,627,683,163,65900,69200,19200,4340,230,6.7,1,0,24.1,77777,9,999999999,309,0.2060,0,88,999.000,999.0,99.0
+1986,7,13,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,18.3,62,98800,1057,1322,388,733,667,197,77700,68000,23200,7040,240,7.7,5,1,24.1,77777,9,999999999,320,0.2060,0,88,999.000,999.0,99.0
+1986,7,13,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,18.3,58,98800,1173,1322,393,819,682,210,87400,69800,25300,10530,250,8.8,3,1,24.1,77777,9,999999999,320,0.2060,0,88,999.000,999.0,99.0
+1986,7,13,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,17.2,49,98800,1232,1322,401,881,729,199,95100,75000,25100,12880,270,9.3,3,1,24.1,77777,9,999999999,300,0.2060,0,88,999.000,999.0,99.0
+1986,7,13,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,15.6,44,98900,1229,1322,408,854,647,250,90700,65900,29300,15760,270,10.3,3,3,24.1,77777,9,999999999,270,0.2060,0,88,999.000,999.0,99.0
+1986,7,13,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,13.9,40,98900,1165,1322,406,822,653,245,86900,66300,28400,11800,290,10.8,3,3,24.1,77777,9,999999999,250,0.2060,0,88,999.000,999.0,99.0
+1986,7,13,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,14.4,41,99000,1044,1322,403,763,707,204,80800,71900,23900,7050,270,9.8,2,2,24.1,77777,9,999999999,250,0.2060,0,88,999.000,999.0,99.0
+1986,7,13,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,14.4,43,99000,874,1322,394,589,634,169,61900,64000,19500,4360,280,7.7,1,1,24.1,77777,9,999999999,250,0.2060,0,88,999.000,999.0,99.0
+1986,7,13,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,13.9,41,99000,667,1322,394,393,525,129,41100,51600,15000,2710,290,7.7,1,1,24.1,77777,9,999999999,240,0.2060,0,88,999.000,999.0,99.0
+1986,7,13,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,14.4,46,99000,437,1322,381,234,438,90,25100,40000,11900,1670,280,6.7,0,0,24.1,77777,9,999999999,250,0.2060,0,88,999.000,999.0,99.0
+1986,7,13,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,13.9,49,99100,201,1322,373,75,172,49,8000,11000,6300,900,310,3.6,0,0,24.1,77777,9,999999999,250,0.2060,0,88,999.000,999.0,99.0
+1986,7,13,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,16.1,64,99200,17,562,364,8,3,8,0,0,0,0,290,2.6,0,0,24.1,77777,9,999999999,279,0.2060,0,88,999.000,999.0,99.0
+1986,7,13,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,16.7,73,99200,0,0,357,0,0,0,0,0,0,0,270,2.6,0,0,24.1,77777,9,999999999,290,0.2060,0,88,999.000,999.0,99.0
+1986,7,13,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,16.7,79,99300,0,0,351,0,0,0,0,0,0,0,280,2.6,0,0,24.1,77777,9,999999999,290,0.2060,0,88,999.000,999.0,99.0
+1986,7,13,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,16.1,84,99300,0,0,343,0,0,0,0,0,0,0,240,3.1,0,0,24.1,77777,9,999999999,279,0.2060,0,88,999.000,999.0,99.0
+1986,7,13,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,16.1,87,99400,0,0,340,0,0,0,0,0,0,0,250,3.1,0,0,24.1,77777,9,999999999,279,0.2060,0,88,999.000,999.0,99.0
+1986,7,14,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,16.7,90,99400,0,0,340,0,0,0,0,0,0,0,270,3.1,0,0,24.1,77777,9,999999999,290,0.2060,0,88,999.000,999.0,99.0
+1986,7,14,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,16.1,90,99400,0,0,338,0,0,0,0,0,0,0,290,2.6,0,0,24.1,77777,9,999999999,279,0.2060,0,88,999.000,999.0,99.0
+1986,7,14,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,16.1,93,99400,0,0,335,0,0,0,0,0,0,0,330,2.6,0,0,24.1,77777,9,999999999,279,0.2060,0,88,999.000,999.0,99.0
+1986,7,14,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,15.6,90,99500,0,0,349,0,0,0,0,0,0,0,320,2.1,7,3,24.1,77777,9,999999999,270,0.2060,0,88,999.000,999.0,99.0
+1986,7,14,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,16.1,87,99500,25,650,367,7,2,7,0,0,0,0,230,1.5,8,7,24.1,2440,9,999999999,279,0.1200,0,88,999.000,999.0,99.0
+1986,7,14,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,16.1,81,99600,220,1322,373,72,111,53,7600,7500,6400,970,10,1.5,8,7,24.1,2440,9,999999999,279,0.1200,0,88,999.000,999.0,99.0
+1986,7,14,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,16.7,79,99700,456,1322,376,173,99,138,18700,9400,15500,3150,80,2.6,10,6,24.1,7620,9,999999999,290,0.1200,0,88,999.000,999.0,99.0
+1986,7,14,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,16.7,73,99600,685,1322,386,334,259,199,35900,27000,21900,4510,70,3.1,10,7,24.1,7620,9,999999999,290,0.1200,0,88,999.000,999.0,99.0
+1986,7,14,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,16.7,69,99600,889,1322,391,440,196,307,48000,20700,34100,8970,60,3.6,10,7,24.1,7620,9,999999999,290,0.1200,0,88,999.000,999.0,99.0
+1986,7,14,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,17.2,69,99600,1055,1322,390,615,406,289,65600,42300,31800,10410,70,4.1,10,6,24.1,7620,9,999999999,300,0.1200,0,88,999.000,999.0,99.0
+1986,7,14,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,16.1,62,99600,1172,1322,389,750,445,353,79700,46500,38500,17940,110,2.6,10,5,24.1,77777,9,999999999,279,0.1200,0,88,999.000,999.0,99.0
+1986,7,14,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,16.7,62,99600,1230,1322,392,663,395,294,72500,41400,33800,19050,60,5.2,10,5,24.1,77777,9,999999999,290,0.1200,0,88,999.000,999.0,99.0
+1986,7,14,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,16.7,60,99600,1228,1322,392,658,394,291,72000,41300,33600,18600,60,5.2,10,4,24.1,77777,9,999999999,290,0.1200,0,88,999.000,999.0,99.0
+1986,7,14,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,16.7,62,99600,1164,1322,377,832,780,143,89100,79200,19200,6640,60,5.2,3,1,24.1,77777,9,999999999,290,0.1200,0,88,999.000,999.0,99.0
+1986,7,14,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,16.7,64,99500,1043,1322,380,734,660,212,77400,67000,24500,7270,60,5.7,7,2,24.1,77777,9,999999999,290,0.1200,0,88,999.000,999.0,99.0
+1986,7,14,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,16.1,64,99500,873,1322,380,579,601,182,60600,60400,20600,4640,80,5.2,8,3,24.1,77777,9,999999999,279,0.1200,0,88,999.000,999.0,99.0
+1986,7,14,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,15.6,66,99500,666,1322,373,320,270,183,34500,28100,20300,4050,80,5.7,7,3,24.1,77777,9,999999999,270,0.1200,0,88,999.000,999.0,99.0
+1986,7,14,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,15.0,68,99500,436,1322,367,228,384,102,24100,35000,12600,1920,90,4.6,5,3,24.1,77777,9,999999999,259,0.1200,0,88,999.000,999.0,99.0
+1986,7,14,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,13.9,66,99500,199,1322,363,77,213,45,8100,13800,6000,800,50,4.6,4,3,24.1,77777,9,999999999,250,0.1200,0,88,999.000,999.0,99.0
+1986,7,14,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,13.3,63,99500,17,540,376,4,1,4,0,0,0,0,90,4.1,8,7,24.1,2130,9,999999999,240,0.1200,0,88,999.000,999.0,99.0
+1986,7,14,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,14.4,73,99500,0,0,367,0,0,0,0,0,0,0,70,3.6,6,6,24.1,2130,9,999999999,250,0.1200,0,88,999.000,999.0,99.0
+1986,7,14,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,15.0,73,99500,0,0,381,0,0,0,0,0,0,0,80,4.1,8,8,24.1,1680,9,999999999,259,0.1200,0,88,999.000,999.0,99.0
+1986,7,14,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,15.6,76,99500,0,0,390,0,0,0,0,0,0,0,110,2.6,9,9,24.1,1680,9,999999999,270,0.1200,0,88,999.000,999.0,99.0
+1986,7,14,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,15.6,73,99500,0,0,404,0,0,0,0,0,0,0,40,2.6,10,10,24.1,880,9,999999999,270,0.1200,0,88,999.000,999.0,99.0
+1986,7,15,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,16.1,78,99500,0,0,390,0,0,0,0,0,0,0,100,2.1,9,9,24.1,880,9,999999999,279,0.1200,0,88,999.000,999.0,99.0
+1986,7,15,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,16.1,78,99500,0,0,390,0,0,0,0,0,0,0,60,4.1,9,9,24.1,1010,9,999999999,279,0.1200,0,88,999.000,999.0,99.0
+1986,7,15,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,17.2,87,99500,0,0,367,0,0,0,0,0,0,0,90,3.1,5,5,24.1,77777,9,999999999,300,0.1200,0,88,999.000,999.0,99.0
+1986,7,15,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,17.8,93,99500,0,0,356,0,0,0,0,0,0,0,110,3.1,2,2,24.1,77777,9,999999999,309,0.1200,0,88,999.000,999.0,99.0
+1986,7,15,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,17.2,90,99500,24,650,359,10,2,10,0,0,0,0,130,1.5,3,3,24.1,77777,9,999999999,300,0.2170,0,88,999.000,999.0,99.0
+1986,7,15,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,17.8,84,99500,218,1322,353,85,186,54,9000,12500,6900,1000,120,2.6,0,0,24.1,77777,9,999999999,309,0.2170,0,88,999.000,999.0,99.0
+1986,7,15,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,18.3,79,99500,454,1322,361,246,427,98,26000,39400,12500,1840,140,3.6,1,0,11.3,77777,9,999999999,320,0.2170,0,88,999.000,999.0,99.0
+1986,7,15,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,20.0,76,99500,683,1322,400,269,200,165,29300,20900,18500,3610,180,3.6,8,6,11.3,310,9,999999999,350,0.2170,0,88,999.000,999.0,99.0
+1986,7,15,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,21.7,79,99400,887,1322,413,427,187,301,46700,19700,33400,8780,170,4.1,8,7,11.3,340,9,999999999,390,0.2170,0,88,999.000,999.0,99.0
+1986,7,15,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,22.8,74,99400,1053,1322,418,641,397,322,67600,41300,34600,11640,220,4.6,10,5,11.3,77777,9,999999999,409,0.2170,0,88,999.000,999.0,99.0
+1986,7,15,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,21.7,65,99400,1170,1322,420,755,451,354,80300,47100,38500,17890,180,1.5,10,4,11.3,77777,9,999999999,390,0.2170,0,88,999.000,999.0,99.0
+1986,7,15,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,22.2,61,99300,1229,1322,426,891,611,320,92900,61300,35800,19860,200,4.6,10,3,11.3,77777,9,999999999,400,0.2170,0,88,999.000,999.0,99.0
+1986,7,15,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,22.8,59,99200,1227,1322,437,800,497,337,86200,52000,37800,21520,190,4.1,8,4,11.3,77777,9,999999999,409,0.2170,0,88,999.000,999.0,99.0
+1986,7,15,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,23.3,61,99200,1163,1322,450,709,415,343,75600,43300,37500,16860,190,6.7,8,7,11.3,1070,9,999999999,419,0.2170,0,88,999.000,999.0,99.0
+1986,7,15,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,23.3,61,99200,1041,1322,434,646,422,312,68300,43900,33700,10960,180,7.2,8,3,14.5,77777,9,999999999,419,0.2170,0,88,999.000,999.0,99.0
+1986,7,15,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,32.2,23.9,61,99200,871,1322,438,540,481,222,57600,49700,24800,5740,180,7.2,8,3,19.3,77777,9,999999999,440,0.2170,0,88,999.000,999.0,99.0
+1986,7,15,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,32.2,23.3,59,99100,664,1322,460,226,101,175,24900,10400,19700,4360,180,8.8,10,8,24.1,7620,9,999999999,419,0.2170,0,88,999.000,999.0,99.0
+1986,7,15,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,22.8,67,99100,434,1322,465,74,5,72,8600,300,8500,3000,190,7.2,10,10,19.3,1130,9,999999999,409,0.2170,0,88,999.000,999.0,99.0
+1986,7,15,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,23.3,72,99100,197,1322,463,37,2,37,4300,0,4300,1350,210,6.7,10,10,19.3,1220,9,999999999,430,0.2170,0,88,999.000,999.0,99.0
+1986,7,15,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,20.0,87,99200,16,518,419,1,0,1,0,0,0,0,130,4.1,10,10,16.1,760,9,999999999,350,0.2170,0,88,999.000,999.0,99.0
+1986,7,15,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,21.7,94,99100,0,0,424,0,0,0,0,0,0,0,130,3.1,10,10,19.3,2440,9,999999999,390,0.2170,0,88,999.000,999.0,99.0
+1986,7,15,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.9,22.2,90,99100,0,0,396,0,0,0,0,0,0,0,180,2.6,5,5,16.1,77777,9,999999999,400,0.2170,0,88,999.000,999.0,99.0
+1986,7,15,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.6,23.9,91,99100,0,0,392,0,0,0,0,0,0,0,260,4.1,1,1,12.9,77777,9,999999999,440,0.2170,0,88,999.000,999.0,99.0
+1986,7,15,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.6,23.9,91,99100,0,0,416,0,0,0,0,0,0,0,10,2.6,7,7,12.9,2130,9,999999999,440,0.2170,0,88,999.000,999.0,99.0
+1986,7,16,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,22.2,97,99200,0,0,380,0,0,0,0,0,0,0,230,1.5,2,2,12.9,77777,9,999999999,400,0.2170,0,88,999.000,999.0,99.0
+1986,7,16,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,21.7,97,99200,0,0,365,0,0,0,0,0,0,0,0,0.0,0,0,11.3,77777,9,999999999,390,0.2170,0,88,999.000,999.0,99.0
+1986,7,16,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.9,22.8,94,99200,0,0,374,0,0,0,0,0,0,0,270,2.6,0,0,11.3,77777,9,999999999,409,0.2170,0,88,999.000,999.0,99.0
+1986,7,16,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.9,22.2,90,99200,0,0,374,0,0,0,0,0,0,0,230,3.1,0,0,11.3,77777,9,999999999,400,0.2170,0,88,999.000,999.0,99.0
+1986,7,16,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,22.8,94,99200,23,628,374,11,12,10,0,0,0,0,240,3.1,0,0,14.5,77777,9,999999999,419,0.1530,0,88,999.000,999.0,99.0
+1986,7,16,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,22.8,85,99200,215,1322,383,91,263,47,9400,17800,6500,840,250,4.6,0,0,14.5,77777,9,999999999,419,0.1530,0,88,999.000,999.0,99.0
+1986,7,16,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,22.8,79,99300,452,1322,389,255,511,79,26400,46800,10400,1510,260,4.1,0,0,16.1,77777,9,999999999,409,0.1530,0,88,999.000,999.0,99.0
+1986,7,16,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,22.8,72,99300,680,1322,397,448,655,109,47200,65100,13700,2380,260,6.2,0,0,16.1,77777,9,999999999,409,0.1530,0,88,999.000,999.0,99.0
+1986,7,16,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,22.8,65,99200,885,1322,406,629,738,132,67200,75400,16600,3570,240,8.2,0,0,24.1,77777,9,999999999,409,0.1530,0,88,999.000,999.0,99.0
+1986,7,16,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,22.8,61,99200,1052,1322,412,777,770,160,80800,77300,19200,5150,260,6.7,2,0,24.1,77777,9,999999999,409,0.1530,0,88,999.000,999.0,99.0
+1986,7,16,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,23.3,61,99200,1169,1322,416,879,810,159,93000,81900,20400,7370,250,4.6,0,0,24.1,77777,9,999999999,419,0.1530,0,88,999.000,999.0,99.0
+1986,7,16,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,32.2,22.8,58,99200,1228,1322,418,931,816,169,98600,82500,21800,10060,270,6.2,1,0,24.1,77777,9,999999999,419,0.1530,0,88,999.000,999.0,99.0
+1986,7,16,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,32.8,23.3,58,99200,1226,1322,430,885,693,240,94200,70700,28600,14900,270,6.2,8,1,24.1,77777,9,999999999,430,0.1530,0,88,999.000,999.0,99.0
+1986,7,16,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,33.3,23.3,56,99200,1161,1322,439,826,627,272,86500,63300,30800,12810,270,5.7,10,2,24.1,77777,9,999999999,430,0.1530,0,88,999.000,999.0,99.0
+1986,7,16,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,33.3,22.8,54,99200,1040,1322,443,719,589,255,77800,61500,29300,8810,250,5.7,8,3,24.1,77777,9,999999999,409,0.1530,0,88,999.000,999.0,99.0
+1986,7,16,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,32.8,22.8,56,99200,870,1322,429,576,649,148,61100,65900,17700,3860,260,6.7,4,1,24.1,77777,9,999999999,419,0.1530,0,88,999.000,999.0,99.0
+1986,7,16,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,32.8,23.3,58,99200,663,1322,430,413,602,111,43500,59500,13600,2380,250,4.6,3,1,24.1,77777,9,999999999,430,0.1530,0,88,999.000,999.0,99.0
+1986,7,16,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,22.8,59,99200,432,1322,423,225,444,80,23300,40100,10200,1510,260,5.2,2,1,24.1,77777,9,999999999,409,0.1530,0,88,999.000,999.0,99.0
+1986,7,16,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,23.3,65,99200,195,1322,418,71,190,43,7500,12200,5700,770,230,4.1,3,1,24.1,77777,9,999999999,419,0.1530,0,88,999.000,999.0,99.0
+1986,7,16,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,23.9,70,99200,15,518,415,8,6,8,0,0,0,0,210,3.1,3,1,24.1,77777,9,999999999,440,0.1530,0,88,999.000,999.0,99.0
+1986,7,16,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,28.9,23.3,72,99300,0,0,401,0,0,0,0,0,0,0,200,4.1,2,0,24.1,77777,9,999999999,430,0.1530,0,88,999.000,999.0,99.0
+1986,7,16,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,27.8,23.9,79,99300,0,0,403,0,0,0,0,0,0,0,240,4.6,3,1,24.1,77777,9,999999999,440,0.1530,0,88,999.000,999.0,99.0
+1986,7,16,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,27.2,23.3,79,99300,0,0,399,0,0,0,0,0,0,0,250,4.1,3,1,16.1,77777,9,999999999,419,0.1530,0,88,999.000,999.0,99.0
+1986,7,16,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.1,23.3,85,99300,0,0,394,0,0,0,0,0,0,0,250,3.1,3,1,16.1,77777,9,999999999,430,0.1530,0,88,999.000,999.0,99.0
+1986,7,17,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.6,23.3,88,99300,0,0,384,0,0,0,0,0,0,0,220,4.1,0,0,11.3,77777,9,999999999,430,0.1530,0,88,999.000,999.0,99.0
+1986,7,17,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.0,23.3,91,99300,0,0,381,0,0,0,0,0,0,0,220,3.6,0,0,11.3,77777,9,999999999,430,0.1530,0,88,999.000,999.0,99.0
+1986,7,17,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,24.4,22.8,91,99300,0,0,377,0,0,0,0,0,0,0,220,2.6,0,0,11.3,77777,9,999999999,409,0.1530,0,88,999.000,999.0,99.0
+1986,7,17,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.9,22.2,90,99300,0,0,374,0,0,0,0,0,0,0,240,3.1,0,0,11.3,77777,9,999999999,400,0.1530,0,88,999.000,999.0,99.0
+1986,7,17,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,22.2,94,99400,21,606,371,9,0,9,0,0,0,0,230,2.1,0,0,19.3,77777,9,999999999,400,0.3940,0,88,999.000,999.0,99.0
+1986,7,17,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,22.8,88,99400,212,1322,380,71,60,61,7700,4200,7000,1300,220,3.1,0,0,24.1,77777,9,999999999,419,0.3940,0,88,999.000,999.0,99.0
+1986,7,17,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,23.3,79,99400,449,1322,392,214,256,126,22700,24100,14500,2540,220,4.1,0,0,24.1,77777,9,999999999,419,0.3940,0,88,999.000,999.0,99.0
+1986,7,17,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,23.9,72,99500,678,1322,404,399,408,187,41600,41000,20600,4030,220,4.6,0,0,12.9,77777,9,999999999,440,0.3940,0,88,999.000,999.0,99.0
+1986,7,17,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,22.8,61,99400,883,1322,412,583,514,237,61700,53100,26200,6260,270,6.7,0,0,16.1,77777,9,999999999,409,0.3940,0,88,999.000,999.0,99.0
+1986,7,17,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,22.8,59,99400,1050,1322,415,733,576,272,78600,60100,30700,9640,220,5.7,0,0,16.1,77777,9,999999999,409,0.3940,0,88,999.000,999.0,99.0
+1986,7,17,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,32.2,22.8,58,99400,1167,1322,426,808,577,296,87400,60400,34000,14670,240,5.2,1,1,16.1,77777,9,999999999,419,0.3940,0,88,999.000,999.0,99.0
+1986,7,17,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,33.3,22.8,54,99400,1227,1322,443,804,440,394,85200,45900,42600,25290,220,6.7,3,3,16.1,77777,9,999999999,409,0.3940,0,88,999.000,999.0,99.0
+1986,7,17,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,33.3,22.2,52,99300,1224,1322,442,921,618,346,98900,64600,38900,21840,240,5.7,3,3,16.1,77777,9,999999999,400,0.3940,0,88,999.000,999.0,99.0
+1986,7,17,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,33.3,21.7,50,99300,1160,1322,445,761,465,351,80900,48500,38200,17120,240,5.7,4,4,16.1,77777,9,999999999,379,0.3940,0,88,999.000,999.0,99.0
+1986,7,17,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,33.9,22.8,52,99300,1039,1322,446,707,480,329,74400,49900,35100,11540,260,7.7,3,3,16.1,77777,9,999999999,409,0.3940,0,88,999.000,999.0,99.0
+1986,7,17,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,33.3,21.7,50,99300,869,1322,441,540,434,254,56800,44700,27400,6630,260,8.8,3,3,19.3,77777,9,999999999,379,0.3940,0,88,999.000,999.0,99.0
+1986,7,17,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,32.8,21.7,52,99300,661,1322,438,354,300,204,37900,31100,22300,4610,230,7.7,3,3,24.1,77777,9,999999999,390,0.3940,0,88,999.000,999.0,99.0
+1986,7,17,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,21.7,57,99300,430,1322,419,180,218,109,19300,20300,12700,2140,260,7.2,1,1,24.1,77777,9,999999999,390,0.3940,0,88,999.000,999.0,99.0
+1986,7,17,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,21.7,57,99300,193,1322,419,49,36,44,5400,2600,5000,1100,260,5.2,1,1,24.1,77777,9,999999999,390,0.3940,0,88,999.000,999.0,99.0
+1986,7,17,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,21.7,63,99300,14,496,402,6,0,6,0,0,0,0,230,3.1,0,0,24.1,77777,9,999999999,390,0.3940,0,88,999.000,999.0,99.0
+1986,7,17,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,29.4,21.1,61,99300,0,0,401,0,0,0,0,0,0,0,230,3.6,0,0,24.1,77777,9,999999999,370,0.3940,0,88,999.000,999.0,99.0
+1986,7,17,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.7,22.2,77,99300,0,0,388,0,0,0,0,0,0,0,230,3.1,0,0,19.3,77777,9,999999999,400,0.3940,0,88,999.000,999.0,99.0
+1986,7,17,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.1,22.8,82,99400,0,0,386,0,0,0,0,0,0,0,230,3.1,0,0,11.3,77777,9,999999999,409,0.3940,0,88,999.000,999.0,99.0
+1986,7,17,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.1,22.8,82,99400,0,0,386,0,0,0,0,0,0,0,240,3.6,0,0,11.3,77777,9,999999999,409,0.3940,0,88,999.000,999.0,99.0
+1986,7,18,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.6,22.8,85,99300,0,0,383,0,0,0,0,0,0,0,230,4.6,0,0,11.3,77777,9,999999999,419,0.3940,0,88,999.000,999.0,99.0
+1986,7,18,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.0,22.8,88,99300,0,0,380,0,0,0,0,0,0,0,230,3.6,0,0,11.3,77777,9,999999999,419,0.3940,0,88,999.000,999.0,99.0
+1986,7,18,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.0,22.8,88,99300,0,0,380,0,0,0,0,0,0,0,250,3.6,0,0,24.1,77777,9,999999999,419,0.3940,0,88,999.000,999.0,99.0
+1986,7,18,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,24.4,22.2,88,99300,0,0,376,0,0,0,0,0,0,0,260,3.6,0,0,24.1,77777,9,999999999,400,0.3940,0,88,999.000,999.0,99.0
+1986,7,18,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,21.7,87,99300,20,584,373,9,0,9,0,0,0,0,240,3.1,0,0,24.1,77777,9,999999999,390,0.3050,0,88,999.000,999.0,99.0
+1986,7,18,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,22.2,82,99400,209,1322,390,66,89,51,7100,6300,6100,1080,270,3.1,1,1,24.1,77777,9,999999999,400,0.3050,0,88,999.000,999.0,99.0
+1986,7,18,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,22.2,74,99400,446,1322,398,207,303,104,21800,27800,12400,1960,260,4.6,1,1,24.1,77777,9,999999999,400,0.3050,0,88,999.000,999.0,99.0
+1986,7,18,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,22.2,67,99400,676,1322,407,412,489,161,43800,49200,18600,3410,250,4.6,1,1,24.1,77777,9,999999999,400,0.3050,0,88,999.000,999.0,99.0
+1986,7,18,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,22.2,63,99400,881,1322,405,597,586,203,64100,60700,23600,5280,280,5.7,0,0,19.3,77777,9,999999999,400,0.3050,0,88,999.000,999.0,99.0
+1986,7,18,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,22.2,57,99400,1048,1322,415,747,645,232,78100,65200,26300,7980,300,5.7,0,0,24.1,77777,9,999999999,400,0.3050,0,88,999.000,999.0,99.0
+1986,7,18,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,32.2,22.8,58,99400,1166,1322,418,845,671,250,89100,68100,28900,12040,240,6.2,0,0,24.1,77777,9,999999999,419,0.3050,0,88,999.000,999.0,99.0
+1986,7,18,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,33.3,22.8,54,99300,1225,1322,424,907,696,258,95900,70800,30200,15910,240,6.2,0,0,24.1,77777,9,999999999,409,0.3050,0,88,999.000,999.0,99.0
+1986,7,18,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,33.3,22.8,54,99300,1223,1322,424,899,690,258,95200,70100,30200,15730,240,6.2,0,0,24.1,77777,9,999999999,409,0.3050,0,88,999.000,999.0,99.0
+1986,7,18,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,33.3,23.3,56,99200,1159,1322,425,846,679,249,89300,68900,28800,11710,240,6.7,0,0,24.1,77777,9,999999999,430,0.3050,0,88,999.000,999.0,99.0
+1986,7,18,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,33.3,21.7,50,99200,1038,1322,423,735,641,229,76900,64800,26000,7690,240,7.2,0,0,24.1,77777,9,999999999,379,0.3050,0,88,999.000,999.0,99.0
+1986,7,18,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,33.9,22.2,51,99200,867,1322,427,580,578,200,62500,59800,23200,5100,230,7.2,0,0,24.1,77777,9,999999999,400,0.3050,0,88,999.000,999.0,99.0
+1986,7,18,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,32.2,22.8,58,99200,659,1322,418,396,476,158,42100,47700,18300,3310,230,8.8,0,0,24.1,77777,9,999999999,419,0.3050,0,88,999.000,999.0,99.0
+1986,7,18,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,22.8,59,99200,428,1322,415,208,313,107,21800,28300,12600,2020,230,7.7,0,0,24.1,77777,9,999999999,409,0.3050,0,88,999.000,999.0,99.0
+1986,7,18,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,22.8,63,99200,191,1322,409,63,79,51,6800,5300,6000,1080,230,5.2,0,0,24.1,77777,9,999999999,409,0.3050,0,88,999.000,999.0,99.0
+1986,7,18,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,22.8,67,99200,13,474,411,4,0,4,0,0,0,0,230,3.1,2,1,24.1,77777,9,999999999,409,0.3050,0,88,999.000,999.0,99.0
+1986,7,18,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,28.9,22.8,70,99200,0,0,418,0,0,0,0,0,0,0,240,4.6,8,3,24.1,77777,9,999999999,419,0.3050,0,88,999.000,999.0,99.0
+1986,7,18,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,27.2,22.2,74,99200,0,0,398,0,0,0,0,0,0,0,260,2.1,4,1,24.1,77777,9,999999999,400,0.3050,0,88,999.000,999.0,99.0
+1986,7,18,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.7,22.2,77,99300,0,0,408,0,0,0,0,0,0,0,260,3.6,6,4,24.1,7620,9,999999999,400,0.3050,0,88,999.000,999.0,99.0
+1986,7,18,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.1,22.8,82,99200,0,0,406,0,0,0,0,0,0,0,240,4.1,6,4,24.1,7620,9,999999999,409,0.3050,0,88,999.000,999.0,99.0
+1986,7,19,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.6,22.2,82,99200,0,0,402,0,0,0,0,0,0,0,250,3.1,7,4,24.1,7620,9,999999999,400,0.3050,0,88,999.000,999.0,99.0
+1986,7,19,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,24.4,22.2,88,99100,0,0,393,0,0,0,0,0,0,0,230,2.6,6,3,24.1,77777,9,999999999,400,0.3050,0,88,999.000,999.0,99.0
+1986,7,19,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,24.4,22.2,88,99100,0,0,393,0,0,0,0,0,0,0,260,3.1,6,3,24.1,77777,9,999999999,400,0.3050,0,88,999.000,999.0,99.0
+1986,7,19,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.9,21.7,87,99100,0,0,389,0,0,0,0,0,0,0,230,2.6,7,3,24.1,77777,9,999999999,390,0.3050,0,88,999.000,999.0,99.0
+1986,7,19,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,21.7,90,99100,19,562,392,6,1,6,0,0,0,0,260,3.1,10,5,24.1,77777,9,999999999,379,0.1580,0,88,999.000,999.0,99.0
+1986,7,19,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,22.2,88,99100,206,1323,396,82,81,69,8800,5600,7900,1460,240,3.6,10,4,24.1,77777,9,999999999,400,0.1580,0,88,999.000,999.0,99.0
+1986,7,19,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,22.2,74,99100,444,1323,408,246,360,124,25300,32900,14300,2380,230,4.1,9,3,24.1,77777,9,999999999,400,0.1580,0,88,999.000,999.0,99.0
+1986,7,19,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,22.8,72,99100,674,1323,414,356,360,171,37500,36200,19100,3640,240,3.6,8,3,24.1,77777,9,999999999,409,0.1580,0,88,999.000,999.0,99.0
+1986,7,19,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,22.8,63,99100,879,1323,427,425,274,241,46300,29400,26700,6370,190,4.6,8,3,24.1,77777,9,999999999,409,0.1580,0,88,999.000,999.0,99.0
+1986,7,19,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,22.2,57,99100,1047,1323,439,533,198,375,58300,21000,41600,13220,260,3.1,8,5,24.1,7620,9,999999999,400,0.1580,0,88,999.000,999.0,99.0
+1986,7,19,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,32.8,23.3,58,99000,1164,1323,464,631,223,434,69200,23700,48300,19280,230,2.6,10,8,24.1,6710,9,999999999,430,0.1580,0,88,999.000,999.0,99.0
+1986,7,19,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,32.8,23.9,60,99000,1224,1323,464,544,149,406,60300,15900,45500,21610,190,4.6,10,8,16.1,6710,9,999999999,440,0.1580,0,88,999.000,999.0,99.0
+1986,7,19,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,33.3,22.2,52,98800,1222,1323,458,791,417,404,83600,43500,43300,25320,180,6.2,9,7,16.1,6710,9,999999999,400,0.1580,0,88,999.000,999.0,99.0
+1986,7,19,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,34.4,21.7,47,98800,1158,1323,464,634,354,323,68000,37000,35500,15530,200,6.7,9,7,16.1,6710,9,999999999,379,0.1580,0,88,999.000,999.0,99.0
+1986,7,19,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,35.0,21.7,46,98700,1036,1323,467,674,507,276,72200,52900,30700,9490,220,10.3,9,7,16.1,6710,9,999999999,390,0.1580,0,88,999.000,999.0,99.0
+1986,7,19,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,33.9,23.9,56,98700,866,1323,451,462,382,212,49600,39500,23700,5420,240,8.2,8,4,16.1,77777,9,999999999,440,0.1580,0,88,999.000,999.0,99.0
+1986,7,19,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,32.8,25.0,64,98600,657,1323,443,375,366,193,40300,37900,21400,4310,240,6.2,7,3,16.1,77777,9,999999999,469,0.1580,0,88,999.000,999.0,99.0
+1986,7,19,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,24.4,66,98700,426,1323,459,144,34,133,15800,3200,14800,3510,250,6.2,9,8,16.1,1010,9,999999999,459,0.1580,0,88,999.000,999.0,99.0
+1986,7,19,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,25.0,72,98800,188,1323,476,12,9,10,1300,600,1200,280,270,4.1,10,10,16.1,760,9,999999999,469,0.1580,0,88,999.000,999.0,99.0
+1986,7,19,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,21.1,77,98900,12,474,440,4,0,4,0,0,0,0,10,5.2,10,10,16.1,1070,9,999999999,379,0.1580,0,88,999.000,999.0,99.0
+1986,7,19,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.0,22.2,85,98900,0,0,426,0,0,0,0,0,0,0,280,2.1,10,9,19.3,2740,9,999999999,400,0.1580,0,88,999.000,999.0,99.0
+1986,7,19,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,24.4,22.2,88,98900,0,0,413,0,0,0,0,0,0,0,270,2.1,10,8,16.1,7620,9,999999999,400,0.1580,0,88,999.000,999.0,99.0
+1986,7,19,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,24.4,22.2,88,98900,0,0,413,0,0,0,0,0,0,0,310,4.1,10,8,16.1,7620,9,999999999,400,0.1580,0,88,999.000,999.0,99.0
+1986,7,19,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.0,22.2,85,98900,0,0,396,0,0,0,0,0,0,0,310,4.1,7,3,16.1,77777,9,999999999,400,0.1580,0,88,999.000,999.0,99.0
+1986,7,20,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,24.4,21.7,85,98900,0,0,392,0,0,0,0,0,0,0,340,6.2,7,3,16.1,77777,9,999999999,390,0.1580,0,88,999.000,999.0,99.0
+1986,7,20,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.9,20.6,82,98900,0,0,388,0,0,0,0,0,0,0,330,5.2,7,3,16.1,77777,9,999999999,359,0.1580,0,88,999.000,999.0,99.0
+1986,7,20,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,20.6,85,98900,0,0,385,0,0,0,0,0,0,0,330,3.6,6,3,16.1,77777,9,999999999,359,0.1580,0,88,999.000,999.0,99.0
+1986,7,20,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,20.6,87,99000,0,0,379,0,0,0,0,0,0,0,320,4.6,6,2,16.1,77777,9,999999999,359,0.1580,0,88,999.000,999.0,99.0
+1986,7,20,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,20.6,90,99000,17,540,363,9,1,9,0,0,0,0,330,3.6,2,0,16.1,77777,9,999999999,359,0.2520,0,88,999.000,999.0,99.0
+1986,7,20,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,20.0,84,99000,203,1323,373,68,105,51,7100,6800,6100,940,330,4.1,5,1,16.1,77777,9,999999999,350,0.2520,0,88,999.000,999.0,99.0
+1986,7,20,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,20.0,79,99100,441,1323,378,218,298,118,23200,27900,13900,2350,360,4.6,4,1,24.1,77777,9,999999999,350,0.2520,0,88,999.000,999.0,99.0
+1986,7,20,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,20.6,74,99100,671,1323,388,413,410,203,44100,42600,22500,4600,320,4.6,7,1,24.1,77777,9,999999999,359,0.2520,0,88,999.000,999.0,99.0
+1986,7,20,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,20.6,69,99100,877,1323,394,585,537,226,62200,55500,25300,5890,330,4.6,8,1,24.1,77777,9,999999999,359,0.2520,0,88,999.000,999.0,99.0
+1986,7,20,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,19.4,61,99200,1045,1323,407,700,533,276,74900,55600,30900,9670,330,3.6,9,3,24.1,77777,9,999999999,340,0.2520,0,88,999.000,999.0,99.0
+1986,7,20,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,17.8,51,99200,1163,1323,414,777,543,298,84000,56800,34000,14510,310,3.6,4,4,24.1,77777,9,999999999,309,0.2520,0,88,999.000,999.0,99.0
+1986,7,20,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,16.7,48,99100,1223,1323,413,797,511,322,86100,53500,36600,20050,320,5.2,4,4,24.1,77777,9,999999999,290,0.2520,0,88,999.000,999.0,99.0
+1986,7,20,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,15.0,43,99200,1220,1323,408,897,660,285,94200,66700,32600,17020,320,5.2,3,3,24.1,77777,9,999999999,259,0.2520,0,88,999.000,999.0,99.0
+1986,7,20,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,13.9,39,99200,1156,1323,405,768,555,281,83500,58100,32600,13350,320,5.7,2,2,24.1,77777,9,999999999,250,0.2520,0,88,999.000,999.0,99.0
+1986,7,20,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,13.9,39,99200,1035,1323,405,684,554,249,74000,57800,28600,8480,10,6.7,3,2,24.1,77777,9,999999999,250,0.2520,0,88,999.000,999.0,99.0
+1986,7,20,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,15.0,43,99200,864,1323,408,548,484,231,58200,49900,25500,5940,320,4.6,4,3,24.1,77777,9,999999999,259,0.2520,0,88,999.000,999.0,99.0
+1986,7,20,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,16.1,51,99200,655,1323,400,367,374,181,39500,38700,20300,3990,30,7.2,7,3,24.1,77777,9,999999999,279,0.2520,0,88,999.000,999.0,99.0
+1986,7,20,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,15.0,49,99200,424,1323,396,187,215,118,19900,19900,13500,2350,30,4.6,7,3,24.1,77777,9,999999999,259,0.2520,0,88,999.000,999.0,99.0
+1986,7,20,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,15.0,54,99200,186,1323,387,59,54,51,6400,3600,5900,1080,30,4.6,8,3,24.1,77777,9,999999999,259,0.2520,0,88,999.000,999.0,99.0
+1986,7,20,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,15.6,60,99200,12,452,378,5,0,5,0,0,0,0,40,4.1,7,2,24.1,77777,9,999999999,270,0.2520,0,88,999.000,999.0,99.0
+1986,7,20,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,17.2,73,99300,0,0,372,0,0,0,0,0,0,0,30,3.6,6,2,24.1,77777,9,999999999,300,0.2520,0,88,999.000,999.0,99.0
+1986,7,20,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,17.2,81,99300,0,0,359,0,0,0,0,0,0,0,30,2.6,4,1,24.1,77777,9,999999999,300,0.2520,0,88,999.000,999.0,99.0
+1986,7,20,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,17.2,84,99300,0,0,356,0,0,0,0,0,0,0,360,1.5,4,1,24.1,77777,9,999999999,300,0.2520,0,88,999.000,999.0,99.0
+1986,7,20,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,17.2,84,99400,0,0,349,0,0,0,0,0,0,0,360,3.1,4,0,24.1,77777,9,999999999,300,0.2520,0,88,999.000,999.0,99.0
+1986,7,21,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,17.8,90,99400,0,0,347,0,0,0,0,0,0,0,360,3.1,4,0,24.1,77777,9,999999999,309,0.2520,0,88,999.000,999.0,99.0
+1986,7,21,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,17.8,93,99400,0,0,359,0,0,0,0,0,0,0,20,2.6,6,3,24.1,77777,9,999999999,309,0.2520,0,88,999.000,999.0,99.0
+1986,7,21,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,17.8,97,99400,0,0,362,0,0,0,0,0,0,0,350,2.1,7,5,24.1,3660,9,999999999,309,0.2520,0,88,999.000,999.0,99.0
+1986,7,21,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,17.2,97,99400,0,0,350,0,0,0,0,0,0,0,330,2.6,4,2,24.1,77777,9,999999999,300,0.2520,0,88,999.000,999.0,99.0
+1986,7,21,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,17.2,93,99400,16,540,352,10,15,8,0,0,0,0,310,2.1,6,2,24.1,77777,9,999999999,300,0.0820,0,88,999.000,999.0,99.0
+1986,7,21,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,17.8,90,99500,200,1323,354,90,341,37,9100,23200,5600,670,360,2.6,1,1,24.1,77777,9,999999999,309,0.0820,0,88,999.000,999.0,99.0
+1986,7,21,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,18.3,81,99500,438,1323,358,266,630,56,27600,57700,8400,1140,50,4.1,0,0,24.1,77777,9,999999999,320,0.0820,0,88,999.000,999.0,99.0
+1986,7,21,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,18.9,76,99500,669,1323,374,430,684,82,45200,67300,11100,1800,30,2.6,1,1,24.1,77777,9,999999999,329,0.0820,0,88,999.000,999.0,99.0
+1986,7,21,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,18.9,71,99500,875,1323,380,618,803,84,64200,79900,11300,2100,10,2.6,1,1,24.1,77777,9,999999999,329,0.0820,0,88,999.000,999.0,99.0
+1986,7,21,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,18.3,62,99600,1043,1323,397,701,675,165,75000,69300,20300,5800,10,2.6,3,3,16.1,77777,9,999999999,320,0.0820,0,88,999.000,999.0,99.0
+1986,7,21,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,18.3,62,99500,1161,1323,388,833,811,117,85600,81300,14100,4590,10,2.6,1,1,16.1,77777,9,999999999,320,0.0820,0,88,999.000,999.0,99.0
+1986,7,21,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,18.3,57,99500,1221,1323,406,789,638,197,85100,65700,24300,12050,40,2.6,3,3,16.1,77777,9,999999999,320,0.0820,0,88,999.000,999.0,99.0
+1986,7,21,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,18.3,57,99500,1219,1323,409,861,728,187,90100,73200,22500,10410,10,5.2,4,4,19.3,77777,9,999999999,320,0.0820,0,88,999.000,999.0,99.0
+1986,7,21,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,17.8,55,99500,1155,1323,405,813,781,128,83400,78200,15000,4720,60,6.7,3,3,19.3,77777,9,999999999,309,0.0820,0,88,999.000,999.0,99.0
+1986,7,21,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,15.6,54,99500,1033,1323,405,430,198,275,47500,21500,30700,9020,50,5.7,7,7,19.3,2440,9,999999999,270,0.0820,0,88,999.000,999.0,99.0
+1986,7,21,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,15.6,56,99500,862,1323,429,300,29,281,34400,2600,32700,11720,60,4.1,10,10,19.3,2130,9,999999999,270,0.0820,0,88,999.000,999.0,99.0
+1986,7,21,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,19.4,84,99500,653,1323,418,109,9,105,13100,600,12800,4810,340,4.6,10,10,11.3,1220,9,999999999,340,0.0820,0,88,999.000,999.0,99.0
+1986,7,21,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,18.9,84,99400,421,1323,403,87,48,72,9600,4400,8200,2100,40,3.6,9,9,16.1,1220,9,999999999,329,0.0820,0,88,999.000,999.0,99.0
+1986,7,21,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,17.8,74,99400,183,1323,382,61,162,39,6500,10100,5100,690,70,4.1,4,4,24.1,77777,9,999999999,309,0.0820,0,88,999.000,999.0,99.0
+1986,7,21,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,17.2,73,99400,11,430,372,6,15,4,0,0,0,0,50,4.1,2,2,24.1,77777,9,999999999,300,0.0820,0,88,999.000,999.0,99.0
+1986,7,21,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,17.8,79,99500,0,0,373,0,0,0,0,0,0,0,70,3.6,3,3,16.1,77777,9,999999999,309,0.0820,0,88,999.000,999.0,99.0
+1986,7,21,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,18.3,81,99500,0,0,370,0,0,0,0,0,0,0,120,2.6,2,2,16.1,77777,9,999999999,320,0.0820,0,88,999.000,999.0,99.0
+1986,7,21,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,18.9,84,99600,0,0,378,0,0,0,0,0,0,0,110,3.1,6,4,16.1,3050,9,999999999,329,0.0820,0,88,999.000,999.0,99.0
+1986,7,21,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,18.9,93,99600,0,0,369,0,0,0,0,0,0,0,0,0.0,6,4,11.3,3050,9,999999999,329,0.0820,0,88,999.000,999.0,99.0
+1986,7,22,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,18.9,97,99600,0,0,355,0,0,0,0,0,0,0,0,0.0,1,1,11.3,77777,9,999999999,329,0.0820,0,88,999.000,999.0,99.0
+1986,7,22,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,18.3,97,99600,0,0,345,0,0,0,0,0,0,0,0,0.0,0,0,11.3,77777,9,999999999,320,0.0820,0,88,999.000,999.0,99.0
+1986,7,22,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,18.3,97,99600,0,0,345,0,0,0,0,0,0,0,330,2.1,0,0,11.3,77777,9,999999999,320,0.0820,0,88,999.000,999.0,99.0
+1986,7,22,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,18.3,97,99600,0,0,345,0,0,0,0,0,0,0,0,0.0,0,0,11.3,77777,9,999999999,320,0.0820,0,88,999.000,999.0,99.0
+1986,7,22,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,17.8,97,99600,15,518,342,8,2,7,0,0,0,0,0,0.0,0,0,11.3,77777,9,999999999,309,0.2170,0,88,999.000,999.0,99.0
+1986,7,22,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,19.4,97,99700,197,1323,351,74,157,50,7800,9900,6300,920,0,0.0,0,0,11.3,77777,9,999999999,340,0.2170,0,88,999.000,999.0,99.0
+1986,7,22,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,20.0,82,99800,436,1323,368,233,421,93,24700,38400,12000,1730,0,0.0,0,0,11.3,77777,9,999999999,350,0.2170,0,88,999.000,999.0,99.0
+1986,7,22,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,20.0,74,99800,666,1323,377,425,577,132,44000,56600,15400,2760,270,1.5,0,0,11.3,77777,9,999999999,350,0.2170,0,88,999.000,999.0,99.0
+1986,7,22,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,19.4,65,99800,873,1323,385,608,656,172,63600,66100,19900,4420,10,1.5,2,0,8.0,77777,9,999999999,340,0.2170,0,88,999.000,999.0,99.0
+1986,7,22,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,18.9,59,99900,1041,1323,413,752,646,240,78400,65100,27000,8070,300,2.1,5,5,11.3,77777,9,999999999,329,0.2170,0,88,999.000,999.0,99.0
+1986,7,22,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,17.2,53,99900,1159,1323,419,423,119,318,47200,12800,36000,13930,270,2.6,7,7,16.1,1070,9,999999999,300,0.2170,0,88,999.000,999.0,99.0
+1986,7,22,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,17.8,53,99800,1220,1323,418,661,385,305,71900,40300,34600,18660,310,2.6,6,6,16.1,1220,9,999999999,309,0.2170,0,88,999.000,999.0,99.0
+1986,7,22,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,15.0,43,99800,1217,1323,418,641,312,352,71000,34000,39700,19080,0,0.0,6,6,12.9,1220,9,999999999,259,0.2170,0,88,999.000,999.0,99.0
+1986,7,22,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,19.4,59,99800,1153,1323,432,543,227,344,59800,24700,38300,15020,40,3.6,8,8,12.9,1220,9,999999999,340,0.2170,0,88,999.000,999.0,99.0
+1986,7,22,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,18.9,53,99800,1031,1323,426,662,485,283,70700,50500,31200,9640,30,1.5,6,6,12.9,1220,9,999999999,329,0.2170,0,88,999.000,999.0,99.0
+1986,7,22,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,18.9,60,99800,860,1323,413,498,385,247,54200,41300,27300,6440,40,4.1,6,6,16.1,1220,9,999999999,329,0.2170,0,88,999.000,999.0,99.0
+1986,7,22,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,17.8,56,99800,651,1323,412,332,264,202,35500,27300,22100,4540,50,2.6,6,6,16.1,1220,9,999999999,309,0.2170,0,88,999.000,999.0,99.0
+1986,7,22,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,17.8,58,99800,419,1323,399,162,149,115,17700,13800,13400,2590,80,3.1,3,3,16.1,77777,9,999999999,309,0.2170,0,88,999.000,999.0,99.0
+1986,7,22,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,17.8,60,99800,180,1323,392,52,95,39,5600,5700,4800,700,50,3.6,2,2,24.1,77777,9,999999999,309,0.2170,0,88,999.000,999.0,99.0
+1986,7,22,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,16.7,58,99800,10,408,376,5,1,5,0,0,0,0,60,3.6,0,0,24.1,77777,9,999999999,290,0.2170,0,88,999.000,999.0,99.0
+1986,7,22,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,24.4,17.2,64,99900,0,0,370,0,0,0,0,0,0,0,60,2.6,0,0,16.1,77777,9,999999999,300,0.2170,0,88,999.000,999.0,99.0
+1986,7,22,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,17.8,74,99900,0,0,363,0,0,0,0,0,0,0,130,1.5,0,0,16.1,77777,9,999999999,309,0.2170,0,88,999.000,999.0,99.0
+1986,7,22,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,18.3,81,99900,0,0,358,0,0,0,0,0,0,0,0,0.0,0,0,11.3,77777,9,999999999,320,0.2170,0,88,999.000,999.0,99.0
+1986,7,22,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,18.3,90,99900,0,0,350,0,0,0,0,0,0,0,0,0.0,0,0,11.3,77777,9,999999999,320,0.2170,0,88,999.000,999.0,99.0
+1986,7,23,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,18.3,93,99900,0,0,347,0,0,0,0,0,0,0,0,0.0,0,0,11.3,77777,9,999999999,320,0.2170,0,88,999.000,999.0,99.0
+1986,7,23,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,17.8,97,99900,0,0,342,0,0,0,0,0,0,0,0,0.0,0,0,11.3,77777,9,999999999,309,0.2170,0,88,999.000,999.0,99.0
+1986,7,23,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,17.8,97,99900,0,0,342,0,0,0,0,0,0,0,0,0.0,0,0,11.3,77777,9,999999999,309,0.2170,0,88,999.000,999.0,99.0
+1986,7,23,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,17.2,97,99900,0,0,339,0,0,0,0,0,0,0,0,0.0,0,0,11.3,77777,9,999999999,300,0.2170,0,88,999.000,999.0,99.0
+1986,7,23,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,17.2,97,100000,14,496,339,7,1,7,0,0,0,0,0,0.0,2,0,9.7,77777,9,999999999,300,0.2560,0,88,999.000,999.0,99.0
+1986,7,23,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,18.3,93,100000,194,1323,354,65,96,51,7100,6500,6200,1080,0,0.0,5,1,4.8,77777,9,999999999,320,0.2560,0,88,999.000,999.0,99.0
+1986,7,23,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,20.0,76,100000,433,1323,381,201,283,107,21400,26400,12800,2090,130,2.6,4,1,4.8,77777,9,999999999,350,0.2560,0,88,999.000,999.0,99.0
+1986,7,23,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,20.0,67,100000,664,1323,385,407,494,157,43100,49600,18200,3290,170,3.1,3,0,4.8,77777,9,999999999,359,0.2560,0,88,999.000,999.0,99.0
+1986,7,23,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,18.3,55,100000,871,1323,399,571,585,183,59400,58800,20700,4640,90,2.6,1,1,4.8,77777,9,999999999,320,0.2560,0,88,999.000,999.0,99.0
+1986,7,23,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,17.2,48,100000,1039,1323,416,676,476,300,71700,49600,32700,10440,160,4.1,4,4,4.8,77777,9,999999999,300,0.2560,0,88,999.000,999.0,99.0
+1986,7,23,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,17.8,50,100000,1158,1323,420,725,462,318,77700,48300,35400,15250,200,5.2,5,5,9.7,77777,9,999999999,309,0.2560,0,88,999.000,999.0,99.0
+1986,7,23,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,16.7,43,99900,1218,1323,419,879,624,302,92000,62800,34000,17700,180,3.6,3,3,12.9,77777,9,999999999,290,0.2560,0,88,999.000,999.0,99.0
+1986,7,23,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,17.8,46,99800,1216,1323,424,884,661,273,93100,67000,31400,15970,190,4.1,4,4,11.3,77777,9,999999999,309,0.2560,0,88,999.000,999.0,99.0
+1986,7,23,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,18.3,47,99800,1152,1323,434,691,423,321,74000,44200,35500,15090,210,5.2,6,6,11.3,1370,9,999999999,320,0.2560,0,88,999.000,999.0,99.0
+1986,7,23,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,18.3,50,99700,1030,1323,428,549,330,291,60300,35800,32400,9550,190,5.2,6,6,11.3,1370,9,999999999,320,0.2560,0,88,999.000,999.0,99.0
+1986,7,23,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,18.3,48,99600,858,1323,421,471,375,227,50000,38700,24900,5790,200,4.6,3,3,11.3,77777,9,999999999,320,0.2560,0,88,999.000,999.0,99.0
+1986,7,23,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,18.3,50,99600,649,1323,418,372,408,172,39200,40700,19200,3610,200,3.6,3,3,11.3,77777,9,999999999,320,0.2560,0,88,999.000,999.0,99.0
+1986,7,23,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,18.3,53,99600,416,1323,408,172,156,123,18700,14400,14200,2770,220,3.6,2,2,19.3,77777,9,999999999,320,0.2560,0,88,999.000,999.0,99.0
+1986,7,23,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,18.9,60,99500,177,1323,394,52,79,42,5800,5100,5100,880,210,3.1,3,1,19.3,77777,9,999999999,329,0.2560,0,88,999.000,999.0,99.0
+1986,7,23,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,18.9,65,99500,9,386,394,2,0,2,0,0,0,0,210,2.6,5,2,14.5,77777,9,999999999,329,0.2560,0,88,999.000,999.0,99.0
+1986,7,23,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.0,19.4,71,99600,0,0,383,0,0,0,0,0,0,0,200,2.6,3,1,14.5,77777,9,999999999,340,0.2560,0,88,999.000,999.0,99.0
+1986,7,23,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.0,19.4,71,99600,0,0,376,0,0,0,0,0,0,0,190,2.1,0,0,12.9,77777,9,999999999,340,0.2560,0,88,999.000,999.0,99.0
+1986,7,23,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,24.4,19.4,74,99600,0,0,373,0,0,0,0,0,0,0,190,3.1,0,0,11.3,77777,9,999999999,340,0.2560,0,88,999.000,999.0,99.0
+1986,7,23,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,20.0,82,99500,0,0,368,0,0,0,0,0,0,0,180,3.6,0,0,11.3,77777,9,999999999,350,0.2560,0,88,999.000,999.0,99.0
+1986,7,24,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,19.4,82,99500,0,0,365,0,0,0,0,0,0,0,190,3.1,0,0,11.3,77777,9,999999999,340,0.2560,0,88,999.000,999.0,99.0
+1986,7,24,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,19.4,82,99500,0,0,365,0,0,0,0,0,0,0,190,3.1,0,0,11.3,77777,9,999999999,340,0.2560,0,88,999.000,999.0,99.0
+1986,7,24,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,19.4,84,99500,0,0,362,0,0,0,0,0,0,0,200,3.1,2,0,8.0,77777,9,999999999,340,0.2560,0,88,999.000,999.0,99.0
+1986,7,24,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,19.4,82,99500,0,0,365,0,0,0,0,0,0,0,210,4.1,3,0,8.0,77777,9,999999999,340,0.2560,0,88,999.000,999.0,99.0
+1986,7,24,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,19.4,82,99500,13,474,372,4,1,4,0,0,0,0,200,4.1,6,1,6.4,77777,9,999999999,340,0.2180,0,88,999.000,999.0,99.0
+1986,7,24,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,19.4,79,99400,191,1324,383,54,30,50,5900,2200,5600,1220,210,4.6,4,3,4.8,77777,9,999999999,340,0.2180,0,88,999.000,999.0,99.0
+1986,7,24,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,20.0,74,99400,430,1324,389,209,326,102,21900,29600,12300,1920,200,5.2,3,2,4.8,77777,9,999999999,350,0.2180,0,88,999.000,999.0,99.0
+1986,7,24,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,20.6,69,99400,661,1324,394,402,472,164,42400,47300,18700,3450,200,5.7,8,1,4.8,77777,9,999999999,359,0.2180,0,88,999.000,999.0,99.0
+1986,7,24,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,20.6,67,99300,869,1324,412,534,423,255,56100,43600,27400,6650,220,7.2,8,5,4.8,3660,9,999999999,359,0.2180,0,88,999.000,999.0,99.0
+1986,7,24,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,21.1,65,99300,1037,1324,419,505,194,352,55500,20600,39200,12230,210,6.7,8,5,4.8,8230,9,999999999,370,0.2180,0,88,999.000,999.0,99.0
+1986,7,24,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,21.7,67,99300,1156,1324,435,596,252,374,65200,27400,41300,16590,210,6.2,10,8,6.4,3660,9,999999999,390,0.2180,0,88,999.000,999.0,99.0
+1986,7,24,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,22.2,63,99300,1216,1324,423,806,531,316,87300,55600,36100,19040,200,5.2,3,3,6.4,77777,9,999999999,400,0.2180,0,88,999.000,999.0,99.0
+1986,7,24,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,21.7,59,99200,1214,1324,441,660,307,377,72800,33400,42100,20270,210,6.7,8,7,6.4,3660,9,999999999,390,0.2180,0,88,999.000,999.0,99.0
+1986,7,24,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,22.8,59,99200,1150,1324,444,701,373,375,76700,40500,41400,16360,190,7.7,8,6,6.4,3660,9,999999999,409,0.2180,0,88,999.000,999.0,99.0
+1986,7,24,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,32.2,22.2,56,99100,1028,1324,435,706,579,254,76000,60400,29000,8520,230,6.7,3,3,6.4,77777,9,999999999,400,0.2180,0,88,999.000,999.0,99.0
+1986,7,24,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,21.7,57,99000,856,1324,432,540,523,201,58100,54000,23100,5060,200,6.7,4,4,6.4,77777,9,999999999,379,0.2180,0,88,999.000,999.0,99.0
+1986,7,24,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,22.2,59,98900,647,1324,429,381,440,166,40200,43900,18700,3470,200,6.7,3,3,9.7,77777,9,999999999,400,0.2180,0,88,999.000,999.0,99.0
+1986,7,24,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,22.2,61,99000,414,1324,416,197,322,96,20700,28900,11700,1790,210,9.8,1,1,9.7,77777,9,999999999,400,0.2180,0,88,999.000,999.0,99.0
+1986,7,24,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,22.8,67,98900,174,1324,411,56,98,43,5900,5700,5200,790,220,6.7,4,1,11.3,77777,9,999999999,409,0.2180,0,88,999.000,999.0,99.0
+1986,7,24,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,23.3,74,98900,8,364,405,2,0,2,0,0,0,0,190,6.2,3,1,8.0,77777,9,999999999,419,0.2180,0,88,999.000,999.0,99.0
+1986,7,24,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,27.8,22.8,74,99000,0,0,415,0,0,0,0,0,0,0,200,5.7,4,4,8.0,77777,9,999999999,409,0.2180,0,88,999.000,999.0,99.0
+1986,7,24,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,27.8,22.8,74,99000,0,0,433,0,0,0,0,0,0,0,190,5.7,8,8,8.0,2130,9,999999999,409,0.2180,0,88,999.000,999.0,99.0
+1986,7,24,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.7,23.3,82,99000,0,0,428,0,0,0,0,0,0,0,190,5.7,8,8,8.0,1830,9,999999999,430,0.2180,0,88,999.000,999.0,99.0
+1986,7,24,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.7,22.8,79,99000,0,0,449,0,0,0,0,0,0,0,180,4.6,10,10,8.0,2440,9,999999999,409,0.2180,0,88,999.000,999.0,99.0
+1986,7,25,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.6,21.7,79,98900,0,0,382,0,0,0,0,0,0,0,190,6.7,0,0,6.4,77777,9,999999999,390,0.2180,0,88,999.000,999.0,99.0
+1986,7,25,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.6,22.2,82,98800,0,0,441,0,0,0,0,0,0,0,190,7.2,10,10,6.4,1830,9,999999999,400,0.2180,0,88,999.000,999.0,99.0
+1986,7,25,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,21.7,90,98800,0,0,427,0,0,0,0,0,0,0,230,5.2,10,10,6.4,520,9,999999999,379,0.2180,0,88,999.000,999.0,99.0
+1986,7,25,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,22.2,94,98900,0,0,428,0,0,0,0,0,0,0,250,3.6,10,10,6.4,1520,9,999999999,400,0.2180,0,88,999.000,999.0,99.0
+1986,7,25,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,20.6,90,99000,12,452,419,1,0,1,0,0,0,0,250,4.1,10,10,16.1,1400,9,999999999,359,0.1510,0,88,999.000,999.0,99.0
+1986,7,25,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,20.6,93,98900,188,1324,417,26,3,25,3000,0,3000,960,220,3.6,10,10,16.1,1400,9,999999999,359,0.1510,0,88,999.000,999.0,99.0
+1986,7,25,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,20.6,93,98800,427,1324,417,63,6,61,7500,300,7400,2590,180,4.6,10,10,19.3,1370,9,999999999,359,0.1510,0,88,999.000,999.0,99.0
+1986,7,25,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,21.1,90,98800,659,1324,412,179,34,162,19700,3400,18000,5090,210,3.1,9,9,19.3,1370,9,999999999,370,0.1510,0,88,999.000,999.0,99.0
+1986,7,25,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,21.7,82,98900,867,1324,416,395,234,241,43000,25100,26600,6290,180,4.1,8,8,19.3,1370,9,999999999,390,0.1510,0,88,999.000,999.0,99.0
+1986,7,25,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,21.7,87,98900,1036,1324,431,337,12,327,39200,1100,38300,14370,210,5.7,10,10,19.3,1370,9,999999999,379,0.1510,0,88,999.000,999.0,99.0
+1986,7,25,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,21.7,82,98900,1154,1324,437,366,40,332,40600,4100,37000,15370,240,4.1,10,10,19.3,1370,9,999999999,390,0.1510,0,88,999.000,999.0,99.0
+1986,7,25,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,22.2,77,98900,1215,1324,448,375,7,368,44400,600,43800,16450,280,3.1,10,10,24.1,1370,9,999999999,400,0.1510,0,88,999.000,999.0,99.0
+1986,7,25,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,22.8,72,98900,1213,1324,436,596,293,326,66400,31900,37100,17190,260,4.6,8,8,24.1,1370,9,999999999,409,0.1510,0,88,999.000,999.0,99.0
+1986,7,25,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,21.7,61,98900,1148,1324,433,785,653,216,83500,66700,25500,9860,320,4.6,6,6,24.1,1070,9,999999999,390,0.1510,0,88,999.000,999.0,99.0
+1986,7,25,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,20.6,61,99000,1026,1324,425,512,221,340,56300,23500,38000,11610,330,4.1,7,6,24.1,1010,9,999999999,359,0.1510,0,88,999.000,999.0,99.0
+1986,7,25,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,20.0,59,98900,854,1324,397,594,721,128,63500,73400,16100,3320,20,5.7,0,0,24.1,77777,9,999999999,350,0.1510,0,88,999.000,999.0,99.0
+1986,7,25,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,20.6,67,99000,644,1324,389,407,622,103,42800,61300,13000,2190,30,6.2,0,0,24.1,77777,9,999999999,359,0.1510,0,88,999.000,999.0,99.0
+1986,7,25,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,20.0,74,99000,411,1324,377,224,485,73,23200,43200,9800,1380,40,6.2,0,0,24.1,77777,9,999999999,350,0.1510,0,88,999.000,999.0,99.0
+1986,7,25,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,19.4,79,99000,171,1324,380,64,119,48,6700,6800,5800,900,30,5.7,3,2,24.1,77777,9,999999999,340,0.1510,0,88,999.000,999.0,99.0
+1986,7,25,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,19.4,82,99100,7,364,377,2,3,2,0,0,0,0,50,4.6,2,2,24.1,77777,9,999999999,340,0.1510,0,88,999.000,999.0,99.0
+1986,7,25,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,18.3,79,99200,0,0,361,0,0,0,0,0,0,0,50,3.6,0,0,24.1,77777,9,999999999,320,0.1510,0,88,999.000,999.0,99.0
+1986,7,25,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,18.3,81,99200,0,0,358,0,0,0,0,0,0,0,20,3.1,0,0,24.1,77777,9,999999999,320,0.1510,0,88,999.000,999.0,99.0
+1986,7,25,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,17.8,84,99200,0,0,353,0,0,0,0,0,0,0,20,3.1,0,0,24.1,77777,9,999999999,309,0.1510,0,88,999.000,999.0,99.0
+1986,7,25,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,18.3,90,99200,0,0,350,0,0,0,0,0,0,0,10,2.6,0,0,24.1,77777,9,999999999,320,0.1510,0,88,999.000,999.0,99.0
+1986,7,26,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,18.3,90,99200,0,0,350,0,0,0,0,0,0,0,10,2.6,0,0,24.1,77777,9,999999999,320,0.1510,0,88,999.000,999.0,99.0
+1986,7,26,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,18.9,97,99200,0,0,348,0,0,0,0,0,0,0,10,1.5,0,0,24.1,77777,9,999999999,329,0.1510,0,88,999.000,999.0,99.0
+1986,7,26,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,17.8,97,99200,0,0,342,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,309,0.1510,0,88,999.000,999.0,99.0
+1986,7,26,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,18.3,97,99200,0,0,345,0,0,0,0,0,0,0,20,2.1,0,0,24.1,77777,9,999999999,320,0.1510,0,88,999.000,999.0,99.0
+1986,7,26,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,18.3,97,99300,11,430,356,6,16,5,0,0,0,0,30,2.6,2,2,24.1,77777,9,999999999,320,0.0820,0,88,999.000,999.0,99.0
+1986,7,26,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,18.9,90,99300,184,1324,361,75,273,37,7600,17800,5200,660,50,3.1,1,1,24.1,77777,9,999999999,329,0.0820,0,88,999.000,999.0,99.0
+1986,7,26,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,19.4,84,99300,424,1324,384,216,388,91,22900,35100,11600,1690,50,2.6,5,5,24.1,77777,9,999999999,340,0.0820,0,88,999.000,999.0,99.0
+1986,7,26,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,18.9,79,99300,656,1324,390,255,86,212,28000,8600,23700,6310,60,4.1,6,6,24.1,520,9,999999999,329,0.0820,0,88,999.000,999.0,99.0
+1986,7,26,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,18.9,74,99400,864,1324,395,485,422,208,51900,43600,23400,5300,50,3.6,6,6,24.1,580,9,999999999,329,0.0820,0,88,999.000,999.0,99.0
+1986,7,26,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,18.9,67,99400,1034,1324,398,760,757,165,81200,77700,20500,5660,120,3.6,4,4,24.1,77777,9,999999999,329,0.0820,0,88,999.000,999.0,99.0
+1986,7,26,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,19.4,67,99400,1152,1324,404,764,583,254,80400,59100,28900,11600,40,3.6,5,5,16.1,77777,9,999999999,340,0.0820,0,88,999.000,999.0,99.0
+1986,7,26,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,19.4,65,99400,1213,1324,408,684,474,247,75700,49800,30000,14500,140,3.1,5,5,16.1,77777,9,999999999,340,0.0820,0,88,999.000,999.0,99.0
+1986,7,26,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,17.8,55,99300,1211,1324,401,883,769,176,92900,77500,21800,9490,60,3.6,3,2,16.1,77777,9,999999999,309,0.0820,0,88,999.000,999.0,99.0
+1986,7,26,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,16.7,51,99300,1146,1324,404,765,571,268,80100,57600,30100,11930,70,4.6,8,3,16.1,77777,9,999999999,290,0.0820,0,88,999.000,999.0,99.0
+1986,7,26,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,15.0,49,99200,1024,1324,406,700,583,247,75600,60800,28400,8200,80,4.6,10,6,16.1,6100,9,999999999,259,0.0820,0,88,999.000,999.0,99.0
+1986,7,26,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,16.7,54,99200,852,1324,419,467,248,307,50800,26100,34000,8670,120,3.1,10,8,16.1,6100,9,999999999,290,0.0820,0,88,999.000,999.0,99.0
+1986,7,26,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,17.2,58,99200,641,1324,410,259,163,179,28400,16700,20300,4410,120,2.6,9,7,16.1,6100,9,999999999,300,0.0820,0,88,999.000,999.0,99.0
+1986,7,26,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,16.7,58,99200,408,1324,395,214,388,95,22600,34600,11900,1770,80,2.6,8,4,24.1,77777,9,999999999,290,0.0820,0,88,999.000,999.0,99.0
+1986,7,26,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,16.1,60,99200,168,1324,388,64,139,46,6700,7900,5700,860,120,3.6,6,4,24.1,7620,9,999999999,279,0.0820,0,88,999.000,999.0,99.0
+1986,7,26,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,18.9,79,99100,6,342,377,4,10,3,0,0,0,0,70,4.1,5,2,24.1,77777,9,999999999,329,0.0820,0,88,999.000,999.0,99.0
+1986,7,26,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,19.4,84,99200,0,0,381,0,0,0,0,0,0,0,60,4.1,4,4,19.3,77777,9,999999999,340,0.0820,0,88,999.000,999.0,99.0
+1986,7,26,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,19.4,87,99200,0,0,367,0,0,0,0,0,0,0,120,3.1,2,1,12.9,77777,9,999999999,340,0.0820,0,88,999.000,999.0,99.0
+1986,7,26,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,18.9,93,99200,0,0,351,0,0,0,0,0,0,0,0,0.0,0,0,12.9,77777,9,999999999,329,0.0820,0,88,999.000,999.0,99.0
+1986,7,26,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,18.9,93,99200,0,0,351,0,0,0,0,0,0,0,0,0.0,0,0,12.9,77777,9,999999999,329,0.0820,0,88,999.000,999.0,99.0
+1986,7,27,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,18.9,93,99200,0,0,351,0,0,0,0,0,0,0,0,0.0,0,0,11.3,77777,9,999999999,329,0.0820,0,88,999.000,999.0,99.0
+1986,7,27,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,18.3,100,99200,0,0,342,0,0,0,0,0,0,0,0,0.0,0,0,11.3,77777,9,999999999,320,0.0820,0,88,999.000,999.0,99.0
+1986,7,27,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,18.3,100,99100,0,0,342,0,0,0,0,0,0,0,0,0.0,0,0,11.3,77777,9,999999999,320,0.0820,0,88,999.000,999.0,99.0
+1986,7,27,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,18.3,97,99100,0,0,345,0,0,0,0,0,0,0,0,0.0,0,0,11.3,77777,9,999999999,320,0.0820,0,88,999.000,999.0,99.0
+1986,7,27,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,17.2,100,99200,10,408,336,6,2,5,0,0,0,0,0,0.0,2,0,8.0,77777,9,999999999,300,0.1680,0,88,999.000,999.0,99.0
+1986,7,27,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,19.4,93,99100,181,1324,354,70,195,43,7300,12000,5600,770,130,2.6,0,0,11.3,77777,9,999999999,340,0.1680,0,88,999.000,999.0,99.0
+1986,7,27,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,20.0,82,99100,421,1324,368,230,471,79,23600,42200,10200,1480,130,3.6,0,0,11.3,77777,9,999999999,350,0.1680,0,88,999.000,999.0,99.0
+1986,7,27,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,18.9,67,99100,654,1324,379,424,627,111,44200,61800,13700,2360,130,4.1,0,0,16.1,77777,9,999999999,329,0.1680,0,88,999.000,999.0,99.0
+1986,7,27,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,17.8,58,99100,862,1324,383,610,706,147,64400,71600,17700,3790,170,4.1,2,0,24.1,77777,9,999999999,309,0.1680,0,88,999.000,999.0,99.0
+1986,7,27,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,17.2,51,99100,1031,1324,390,760,771,156,79100,77300,18700,4790,170,5.2,0,0,24.1,77777,9,999999999,300,0.1680,0,88,999.000,999.0,99.0
+1986,7,27,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,16.1,46,99100,1151,1324,392,874,808,168,91700,81400,20800,7160,190,4.1,0,0,24.1,77777,9,999999999,279,0.1680,0,88,999.000,999.0,99.0
+1986,7,27,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,16.7,45,99100,1211,1324,399,925,816,174,97400,82300,21900,9400,150,4.6,0,0,16.1,77777,9,999999999,290,0.1680,0,88,999.000,999.0,99.0
+1986,7,27,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,15.6,40,99000,1209,1324,400,926,820,173,97500,82700,21800,9270,140,5.2,0,0,16.1,77777,9,999999999,270,0.1680,0,88,999.000,999.0,99.0
+1986,7,27,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,15.6,39,98900,1145,1324,416,803,658,232,85000,66900,27000,10390,180,7.2,8,2,12.9,77777,9,999999999,270,0.1680,0,88,999.000,999.0,99.0
+1986,7,27,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,16.1,39,99000,1022,1324,420,686,644,186,72700,65700,21900,6150,180,5.7,5,2,19.3,77777,9,999999999,279,0.1680,0,88,999.000,999.0,99.0
+1986,7,27,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,16.7,41,98900,849,1324,425,503,443,218,53600,45700,24200,5480,190,6.2,7,3,24.1,77777,9,999999999,290,0.1680,0,88,999.000,999.0,99.0
+1986,7,27,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,17.2,45,98900,639,1324,423,355,337,192,38000,34700,21200,4260,210,4.6,7,4,24.1,7620,9,999999999,300,0.1680,0,88,999.000,999.0,99.0
+1986,7,27,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,18.3,51,98800,405,1324,415,208,372,94,21900,33100,11800,1750,180,6.2,4,3,24.1,77777,9,999999999,320,0.1680,0,88,999.000,999.0,99.0
+1986,7,27,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,18.9,55,98800,164,1324,413,46,58,39,5100,3600,4600,820,170,5.2,7,3,24.1,77777,9,999999999,329,0.1680,0,88,999.000,999.0,99.0
+1986,7,27,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,19.4,63,98700,6,320,400,2,1,2,0,0,0,0,190,4.6,3,2,24.1,77777,9,999999999,340,0.1680,0,88,999.000,999.0,99.0
+1986,7,27,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.7,20.0,67,98800,0,0,423,0,0,0,0,0,0,0,180,4.1,8,8,16.1,2440,9,999999999,350,0.1680,0,88,999.000,999.0,99.0
+1986,7,27,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.1,20.0,69,98800,0,0,409,0,0,0,0,0,0,0,190,4.1,6,6,12.9,2440,9,999999999,350,0.1680,0,88,999.000,999.0,99.0
+1986,7,27,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.6,20.0,72,98800,0,0,417,0,0,0,0,0,0,0,190,5.2,8,8,12.9,2440,9,999999999,350,0.1680,0,88,999.000,999.0,99.0
+1986,7,27,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.0,20.6,76,98800,0,0,415,0,0,0,0,0,0,0,250,2.6,8,8,12.9,2440,9,999999999,359,0.1680,0,88,999.000,999.0,99.0
+1986,7,28,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,17.8,93,98900,0,0,398,0,0,0,0,0,0,0,320,5.2,10,10,6.4,910,9,999999999,309,0.1680,0,88,999.000,999.0,99.0
+1986,7,28,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,18.3,97,98600,0,0,356,0,0,0,0,0,0,0,180,3.6,2,2,16.1,77777,9,999999999,320,0.1680,0,88,999.000,999.0,99.0
+1986,7,28,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,18.3,97,98700,0,0,379,0,0,0,0,0,0,0,180,3.6,8,8,12.9,3660,9,999999999,320,0.1680,0,88,999.000,999.0,99.0
+1986,7,28,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,18.3,97,98700,0,0,398,0,0,0,0,0,0,0,180,1.5,10,10,11.3,880,9,999999999,320,0.1680,0,88,999.000,999.0,99.0
+1986,7,28,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,18.9,97,98700,9,386,402,2,0,2,0,0,0,0,190,2.6,10,10,8.0,880,9,999999999,329,0.2050,0,88,999.000,999.0,99.0
+1986,7,28,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,18.9,93,98800,178,1325,394,25,13,24,2800,900,2700,640,180,2.6,9,9,8.0,880,9,999999999,329,0.2050,0,88,999.000,999.0,99.0
+1986,7,28,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,19.4,84,98800,418,1325,362,221,420,88,23500,37800,11500,1630,140,2.6,0,0,8.0,77777,9,999999999,340,0.2050,0,88,999.000,999.0,99.0
+1986,7,28,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,20.6,82,98800,651,1325,402,292,148,218,31600,15100,24200,5400,230,2.1,7,7,8.0,460,9,999999999,359,0.2050,0,88,999.000,999.0,99.0
+1986,7,28,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,21.7,85,98800,860,1325,434,268,6,264,30900,500,30500,11220,190,3.1,10,10,9.7,400,9,999999999,390,0.2050,0,88,999.000,999.0,99.0
+1986,7,28,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,22.8,79,98800,1029,1325,427,375,98,299,41700,10500,33500,10250,310,2.1,8,8,11.3,520,9,999999999,409,0.2050,0,88,999.000,999.0,99.0
+1986,7,28,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,22.8,72,98700,1149,1325,429,510,283,263,57300,30900,30400,11020,310,5.2,7,7,11.3,520,9,999999999,409,0.2050,0,88,999.000,999.0,99.0
+1986,7,28,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,22.2,65,98700,1209,1325,430,742,336,434,80900,36500,47500,23130,260,5.2,6,6,11.3,610,9,999999999,400,0.2050,0,88,999.000,999.0,99.0
+1986,7,28,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,22.2,63,98700,1207,1325,433,736,414,357,78600,43300,39100,20690,300,6.2,6,6,16.1,760,9,999999999,400,0.2050,0,88,999.000,999.0,99.0
+1986,7,28,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,21.1,59,98700,1143,1325,437,416,75,351,46000,7700,39300,15810,310,5.2,7,7,16.1,910,9,999999999,370,0.2050,0,88,999.000,999.0,99.0
+1986,7,28,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,21.1,61,98700,1020,1325,433,575,336,315,62700,36400,34600,10260,320,5.2,7,7,16.1,1160,9,999999999,370,0.2050,0,88,999.000,999.0,99.0
+1986,7,28,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,21.1,74,98800,847,1325,410,506,394,253,54800,42200,27800,6550,30,6.7,6,6,16.1,1220,9,999999999,370,0.2050,0,88,999.000,999.0,99.0
+1986,7,28,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,21.1,72,98800,636,1325,400,362,429,155,38300,42700,17800,3200,30,4.6,2,2,12.9,77777,9,999999999,379,0.2050,0,88,999.000,999.0,99.0
+1986,7,28,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,20.6,74,98900,402,1325,388,192,348,87,20400,30900,11100,1600,10,3.6,1,1,12.9,77777,9,999999999,359,0.2050,0,88,999.000,999.0,99.0
+1986,7,28,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,18.3,67,98900,161,1325,375,55,119,41,5900,6600,5100,750,340,4.1,0,0,19.3,77777,9,999999999,320,0.2050,0,88,999.000,999.0,99.0
+1986,7,28,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,20.0,87,99000,5,298,370,1,0,1,0,0,0,0,30,4.1,1,1,19.3,77777,9,999999999,350,0.2050,0,88,999.000,999.0,99.0
+1986,7,28,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,19.4,87,99000,0,0,360,0,0,0,0,0,0,0,50,3.1,0,0,16.1,77777,9,999999999,340,0.2050,0,88,999.000,999.0,99.0
+1986,7,28,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,18.9,87,99100,0,0,356,0,0,0,0,0,0,0,20,2.1,0,0,16.1,77777,9,999999999,329,0.2050,0,88,999.000,999.0,99.0
+1986,7,28,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,18.9,97,99100,0,0,348,0,0,0,0,0,0,0,260,2.1,0,0,16.1,77777,9,999999999,329,0.2050,0,88,999.000,999.0,99.0
+1986,7,28,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,18.9,97,99100,0,0,348,0,0,0,0,0,0,0,260,2.6,0,0,16.1,77777,9,999999999,329,0.2050,0,88,999.000,999.0,99.0
+1986,7,29,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,18.9,93,99100,0,0,405,0,0,0,0,0,0,0,280,2.6,10,10,16.1,7620,9,999999999,329,0.2050,0,88,999.000,999.0,99.0
+1986,7,29,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,17.8,87,99100,0,0,404,0,0,0,0,0,0,0,280,3.6,10,10,16.1,7620,9,999999999,309,0.2050,0,88,999.000,999.0,99.0
+1986,7,29,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,17.8,87,99200,0,0,384,0,0,0,0,0,0,0,270,3.1,10,8,16.1,7620,9,999999999,309,0.2050,0,88,999.000,999.0,99.0
+1986,7,29,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,17.8,87,99200,0,0,404,0,0,0,0,0,0,0,280,3.6,10,10,16.1,3050,9,999999999,309,0.2050,0,88,999.000,999.0,99.0
+1986,7,29,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,17.8,87,99200,8,364,384,2,1,1,0,0,0,0,290,2.6,8,8,16.1,3050,9,999999999,309,0.1410,0,88,999.000,999.0,99.0
+1986,7,29,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,18.3,84,99200,174,1325,371,64,172,41,6600,10400,5300,730,350,3.6,3,3,24.1,77777,9,999999999,320,0.1410,0,88,999.000,999.0,99.0
+1986,7,29,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,18.9,82,99200,415,1325,362,232,506,72,24000,45300,9800,1370,360,5.7,0,0,24.1,77777,9,999999999,329,0.1410,0,88,999.000,999.0,99.0
+1986,7,29,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,18.3,74,99200,648,1325,366,425,659,100,44800,65100,12800,2150,30,6.7,0,0,24.1,77777,9,999999999,320,0.1410,0,88,999.000,999.0,99.0
+1986,7,29,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,18.3,69,99200,857,1325,379,611,752,121,63600,75100,14900,2900,20,4.1,1,1,24.1,77777,9,999999999,320,0.1410,0,88,999.000,999.0,99.0
+1986,7,29,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,18.3,67,99300,1027,1325,391,544,407,227,59300,42500,26200,7540,350,2.1,3,3,24.1,77777,9,999999999,320,0.1410,0,88,999.000,999.0,99.0
+1986,7,29,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,17.2,58,99300,1147,1325,386,811,761,148,86100,77100,19300,6380,30,4.6,1,1,24.1,77777,9,999999999,300,0.1410,0,88,999.000,999.0,99.0
+1986,7,29,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,16.7,54,99300,1208,1325,381,927,842,155,98700,85400,20800,8380,340,3.6,0,0,24.1,77777,9,999999999,290,0.1410,0,88,999.000,999.0,99.0
+1986,7,29,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,16.1,51,99300,1205,1325,383,925,842,155,98600,85400,20700,8300,50,3.1,0,0,24.1,77777,9,999999999,279,0.1410,0,88,999.000,999.0,99.0
+1986,7,29,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,15.0,46,99300,1141,1325,385,868,830,150,92100,84000,19600,6320,30,2.1,0,0,24.1,77777,9,999999999,259,0.1410,0,88,999.000,999.0,99.0
+1986,7,29,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,14.4,44,99300,1017,1325,384,752,795,139,79200,80100,17500,4280,40,4.1,0,0,24.1,77777,9,999999999,250,0.1410,0,88,999.000,999.0,99.0
+1986,7,29,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,13.9,44,99200,844,1325,381,601,749,122,62500,74600,14900,2860,30,4.1,0,0,24.1,77777,9,999999999,250,0.1410,0,88,999.000,999.0,99.0
+1986,7,29,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,13.3,44,99200,633,1325,377,417,665,98,44000,65500,12700,2080,10,3.6,0,0,24.1,77777,9,999999999,240,0.1410,0,88,999.000,999.0,99.0
+1986,7,29,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,13.9,49,99200,398,1325,373,221,502,69,22800,44400,9500,1300,40,3.6,0,0,24.1,77777,9,999999999,250,0.1410,0,88,999.000,999.0,99.0
+1986,7,29,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,13.3,52,99300,157,1325,370,54,157,36,5700,8900,4700,640,50,4.1,3,1,24.1,77777,9,999999999,240,0.1410,0,88,999.000,999.0,99.0
+1986,7,29,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,12.2,52,99200,4,276,364,1,2,1,0,0,0,0,50,2.6,3,1,24.1,77777,9,999999999,220,0.1410,0,88,999.000,999.0,99.0
+1986,7,29,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,12.8,57,99200,0,0,352,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,229,0.1410,0,88,999.000,999.0,99.0
+1986,7,29,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,14.4,66,99200,0,0,351,0,0,0,0,0,0,0,150,2.1,0,0,24.1,77777,9,999999999,250,0.1410,0,88,999.000,999.0,99.0
+1986,7,29,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,16.1,87,99200,0,0,340,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,279,0.1410,0,88,999.000,999.0,99.0
+1986,7,29,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,15.6,87,99200,0,0,337,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,270,0.1410,0,88,999.000,999.0,99.0
+1986,7,30,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,16.1,90,99200,0,0,338,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,279,0.1410,0,88,999.000,999.0,99.0
+1986,7,30,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,15.6,87,99200,0,0,337,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,270,0.1410,0,88,999.000,999.0,99.0
+1986,7,30,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,15.0,97,99200,0,0,326,0,0,0,0,0,0,0,260,2.1,0,0,24.1,77777,9,999999999,259,0.1410,0,88,999.000,999.0,99.0
+1986,7,30,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,15.0,93,99300,0,0,329,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,259,0.1410,0,88,999.000,999.0,99.0
+1986,7,30,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,14.4,93,99300,7,342,340,1,0,1,0,0,0,0,0,0.0,7,3,16.1,77777,9,999999999,250,0.1970,0,88,999.000,999.0,99.0
+1986,7,30,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,15.6,93,99300,171,1325,359,33,16,31,3600,1100,3500,800,0,0.0,8,7,9.7,7620,9,999999999,270,0.1970,0,88,999.000,999.0,99.0
+1986,7,30,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,17.2,84,99300,412,1325,370,135,89,107,14800,8200,12200,2400,0,0.0,7,5,8.0,7620,9,999999999,300,0.1970,0,88,999.000,999.0,99.0
+1986,7,30,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,17.8,74,99300,646,1325,399,260,109,207,28400,11100,22900,5110,180,2.1,10,8,9.7,7620,9,999999999,309,0.1970,0,88,999.000,999.0,99.0
+1986,7,30,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,16.7,64,99300,855,1325,412,367,109,296,40300,11100,33100,9860,190,2.6,9,9,8.0,7620,9,999999999,290,0.1970,0,88,999.000,999.0,99.0
+1986,7,30,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,16.7,58,99300,1025,1325,402,596,361,315,65000,39100,34700,10350,180,4.1,7,6,11.3,7620,9,999999999,290,0.1970,0,88,999.000,999.0,99.0
+1986,7,30,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,16.1,49,99300,1145,1325,403,775,535,310,83100,55900,34700,14160,170,3.1,7,3,16.1,77777,9,999999999,279,0.1970,0,88,999.000,999.0,99.0
+1986,7,30,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,16.1,45,99200,1206,1325,412,821,567,302,89000,59400,34900,17210,130,3.6,6,3,11.3,77777,9,999999999,279,0.1970,0,88,999.000,999.0,99.0
+1986,7,30,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,15.6,44,99100,1204,1325,423,725,484,283,79100,50700,33000,15940,130,6.2,9,7,11.3,3050,9,999999999,270,0.1970,0,88,999.000,999.0,99.0
+1986,7,30,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,13.9,41,99100,1138,1325,424,692,287,444,74700,31100,47900,19140,130,4.1,10,8,16.1,3050,9,999999999,240,0.1970,0,88,999.000,999.0,99.0
+1986,7,30,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,12.2,36,99100,1015,1325,404,657,553,232,71300,57700,27100,7520,130,3.1,6,3,16.1,77777,9,999999999,220,0.1970,0,88,999.000,999.0,99.0
+1986,7,30,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,15.0,43,99100,842,1325,422,432,275,257,46700,29400,28000,6640,120,4.6,8,7,16.1,3050,9,999999999,259,0.1970,0,88,999.000,999.0,99.0
+1986,7,30,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,13.9,40,99000,630,1325,421,241,182,154,26200,18700,17200,3270,150,5.2,8,7,24.1,3050,9,999999999,250,0.1970,0,88,999.000,999.0,99.0
+1986,7,30,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,13.9,41,99000,395,1325,409,135,123,98,14800,11200,11500,2190,160,3.6,7,5,24.1,3050,9,999999999,240,0.1970,0,88,999.000,999.0,99.0
+1986,7,30,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,12.8,42,99000,154,1325,393,48,90,37,5000,4800,4500,670,190,4.1,4,3,24.1,77777,9,999999999,229,0.1970,0,88,999.000,999.0,99.0
+1986,7,30,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,15.6,54,99000,3,232,387,0,0,0,0,0,0,0,180,3.1,2,2,24.1,77777,9,999999999,270,0.1970,0,88,999.000,999.0,99.0
+1986,7,30,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,24.4,16.1,60,99000,0,0,376,0,0,0,0,0,0,0,180,3.1,1,1,24.1,77777,9,999999999,279,0.1970,0,88,999.000,999.0,99.0
+1986,7,30,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.9,16.7,64,99000,0,0,367,0,0,0,0,0,0,0,170,3.6,0,0,24.1,77777,9,999999999,290,0.1970,0,88,999.000,999.0,99.0
+1986,7,30,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,17.2,73,99000,0,0,360,0,0,0,0,0,0,0,170,2.6,0,0,24.1,77777,9,999999999,300,0.1970,0,88,999.000,999.0,99.0
+1986,7,30,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,17.2,76,99000,0,0,357,0,0,0,0,0,0,0,170,1.5,0,0,24.1,77777,9,999999999,300,0.1970,0,88,999.000,999.0,99.0
+1986,7,31,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,17.2,87,99000,0,0,346,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,300,0.1970,0,88,999.000,999.0,99.0
+1986,7,31,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,17.2,79,98900,0,0,354,0,0,0,0,0,0,0,150,2.6,0,0,24.1,77777,9,999999999,300,0.1970,0,88,999.000,999.0,99.0
+1986,7,31,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,16.7,76,98900,0,0,361,0,0,0,0,0,0,0,150,2.1,3,1,24.1,77777,9,999999999,290,0.1970,0,88,999.000,999.0,99.0
+1986,7,31,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,16.7,79,98900,0,0,394,0,0,0,0,0,0,0,0,0.0,10,9,24.1,7620,9,999999999,290,0.1970,0,88,999.000,999.0,99.0
+1986,7,31,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,17.2,90,98900,6,320,378,2,0,2,0,0,0,0,0,0.0,8,8,16.1,3050,9,999999999,300,0.3810,0,88,999.000,999.0,99.0
+1986,7,31,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,17.8,79,99000,167,1326,393,29,1,29,3300,0,3300,1060,0,0.0,8,8,16.1,2440,9,999999999,309,0.3810,0,88,999.000,999.0,99.0
+1986,7,31,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,17.2,66,99000,409,1326,384,179,184,122,19400,16900,14200,2740,190,4.1,3,3,14.5,77777,9,999999999,300,0.3810,0,88,999.000,999.0,99.0
+1986,7,31,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,17.8,67,99000,643,1326,371,373,405,175,39000,40300,19400,3670,220,2.1,0,0,14.5,77777,9,999999999,309,0.3810,0,88,999.000,999.0,99.0
+1986,7,31,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,17.8,58,99000,852,1326,383,559,514,226,59200,53000,25000,5710,0,0.0,0,0,19.3,77777,9,999999999,309,0.3810,0,88,999.000,999.0,99.0
+1986,7,31,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,17.8,53,99000,1023,1326,391,718,587,262,77000,61200,29600,8700,140,2.1,0,0,19.3,77777,9,999999999,309,0.3810,0,88,999.000,999.0,99.0
+1986,7,31,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,16.7,46,99000,1143,1326,395,827,625,285,86100,62800,31800,12400,270,3.6,0,0,19.3,77777,9,999999999,290,0.3810,0,88,999.000,999.0,99.0
+1986,7,31,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,17.8,46,99000,1204,1326,403,886,641,300,92500,64500,33800,16350,240,2.6,1,0,19.3,77777,9,999999999,309,0.3810,0,88,999.000,999.0,99.0
+1986,7,31,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,20.6,52,98900,1201,1326,430,858,578,331,92100,60500,37200,18590,290,4.6,3,3,19.3,77777,9,999999999,359,0.3810,0,88,999.000,999.0,99.0
+1986,7,31,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,18.9,48,98900,1136,1326,435,638,262,412,69200,28400,44800,17480,280,4.6,6,6,16.1,1680,9,999999999,329,0.3810,0,88,999.000,999.0,99.0
+1986,7,31,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,19.4,59,98800,1013,1326,432,560,173,427,60600,18300,46600,14300,320,6.7,8,8,16.1,1680,9,999999999,340,0.3810,0,88,999.000,999.0,99.0
+1986,7,31,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,20.0,57,99000,839,1326,432,340,58,303,37300,5900,33600,9890,350,4.6,9,7,19.3,1680,9,999999999,350,0.3810,0,88,999.000,999.0,99.0
+1986,7,31,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,20.6,69,98900,627,1326,418,227,22,216,25400,1900,24500,8030,140,2.6,7,7,19.3,1680,9,999999999,359,0.3810,0,88,999.000,999.0,99.0
+1986,7,31,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,18.3,60,99000,391,1326,430,119,14,115,13300,900,13000,4050,340,4.1,9,9,19.3,1680,9,999999999,320,0.3810,0,88,999.000,999.0,99.0
+1986,7,31,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,17.8,62,99000,150,1326,414,26,0,26,3000,0,3000,940,330,4.1,9,8,19.3,7620,9,999999999,309,0.3810,0,88,999.000,999.0,99.0
+1986,7,31,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,16.7,60,99000,3,210,403,0,0,0,0,0,0,0,320,3.1,8,7,19.3,7620,9,999999999,290,0.3810,0,88,999.000,999.0,99.0
+1986,7,31,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.9,16.1,62,99000,0,0,379,0,0,0,0,0,0,0,330,4.6,5,2,19.3,77777,9,999999999,279,0.3810,0,88,999.000,999.0,99.0
+1986,7,31,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.0,16.1,50,99100,0,0,378,0,0,0,0,0,0,0,330,4.3,7,3,19.3,77777,9,999999999,220,0.3810,0,88,999.000,999.0,99.0
+1986,7,31,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,16.1,59,99100,0,0,358,0,0,0,0,0,0,0,330,4.0,0,0,24.1,77777,9,999999999,220,0.3810,0,88,999.000,999.0,99.0
+1986,7,31,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.3,16.1,66,99100,0,0,354,0,0,0,0,0,0,0,300,3.7,0,0,24.1,77777,9,999999999,229,0.3810,0,88,999.000,999.0,99.0
+1989,8,1,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.4,16.1,87,99500,0,0,350,0,0,0,0,0,0,0,10,3.5,0,0,8.0,77777,9,999999999,259,0.3810,0,88,999.000,999.0,99.0
+1989,8,1,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.5,16.1,93,99500,0,0,363,0,0,0,0,0,0,0,360,3.2,4,4,8.0,77777,9,999999999,290,0.3810,0,88,999.000,999.0,99.0
+1989,8,1,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.7,16.1,97,99600,0,0,375,0,0,0,0,0,0,0,350,2.9,8,8,8.0,1280,9,999999999,290,0.3810,0,88,999.000,999.0,99.0
+1989,8,1,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,16.1,90,99600,0,0,365,0,0,0,0,0,0,0,330,2.6,7,7,8.0,1830,9,999999999,279,0.3810,0,88,999.000,999.0,99.0
+1989,8,1,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,15.6,87,99600,5,298,364,0,0,0,0,0,0,0,10,2.6,7,7,6.4,1830,9,999999999,270,0.1220,0,88,999.000,999.0,99.0
+1989,8,1,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,16.7,90,99700,163,1326,374,31,31,27,3500,1900,3200,570,350,2.1,8,8,6.4,1830,9,999999999,290,0.1220,0,88,999.000,999.0,99.0
+1989,8,1,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,17.8,87,99700,405,1326,371,191,243,116,20200,22100,13400,2320,340,3.1,5,5,6.4,77777,9,999999999,309,0.1220,0,88,999.000,999.0,99.0
+1989,8,1,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,17.2,73,99800,639,1326,389,295,188,203,32000,19200,22800,4990,30,4.1,7,7,6.4,1980,9,999999999,300,0.1220,0,88,999.000,999.0,99.0
+1989,8,1,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,16.7,64,99800,849,1326,386,361,270,187,40000,29000,21400,4630,70,4.1,4,4,6.4,77777,9,999999999,290,0.1220,0,88,999.000,999.0,99.0
+1989,8,1,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,17.2,60,99800,1020,1326,389,741,759,152,77000,76200,18300,4570,110,2.1,2,2,8.0,77777,9,999999999,300,0.1220,0,88,999.000,999.0,99.0
+1989,8,1,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,17.8,58,99800,1140,1326,383,865,841,137,88400,84100,15900,4580,50,2.6,0,0,8.0,77777,9,999999999,309,0.1220,0,88,999.000,999.0,99.0
+1989,8,1,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,17.8,56,99700,1201,1326,385,925,858,142,94300,85900,16300,5970,360,3.1,0,0,8.0,77777,9,999999999,309,0.1220,0,88,999.000,999.0,99.0
+1989,8,1,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,17.8,56,99700,1199,1326,393,872,788,156,92800,79800,20400,8080,50,3.1,1,1,8.0,77777,9,999999999,309,0.1220,0,88,999.000,999.0,99.0
+1989,8,1,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,17.2,53,99600,1133,1326,404,581,413,226,64200,43300,27100,9800,90,3.1,3,3,9.7,77777,9,999999999,300,0.1220,0,88,999.000,999.0,99.0
+1989,8,1,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,16.1,52,99600,1009,1326,388,615,607,151,66100,62400,18500,4950,70,4.1,1,1,12.9,77777,9,999999999,279,0.1220,0,88,999.000,999.0,99.0
+1989,8,1,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,16.1,49,99600,835,1326,386,596,766,111,62500,76600,14100,2660,50,3.6,0,0,12.9,77777,9,999999999,279,0.1220,0,88,999.000,999.0,99.0
+1989,8,1,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,15.0,47,99500,623,1326,382,410,679,89,43400,66900,11900,1900,130,2.1,0,0,12.9,77777,9,999999999,259,0.1220,0,88,999.000,999.0,99.0
+1989,8,1,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,15.0,51,99500,387,1326,376,217,523,63,22500,46000,9100,1200,140,2.1,0,0,12.9,77777,9,999999999,270,0.1220,0,88,999.000,999.0,99.0
+1989,8,1,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,15.0,51,99500,145,1326,376,56,207,33,5800,11200,4600,590,40,3.6,0,0,12.9,77777,9,999999999,270,0.1220,0,88,999.000,999.0,99.0
+1989,8,1,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,16.1,64,99400,2,188,364,2,2,1,0,0,0,0,130,2.6,0,0,12.9,77777,9,999999999,279,0.1220,0,88,999.000,999.0,99.0
+1989,8,1,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,16.1,66,99500,0,0,361,0,0,0,0,0,0,0,130,2.1,0,0,12.9,77777,9,999999999,279,0.1220,0,88,999.000,999.0,99.0
+1989,8,1,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,15.6,81,99600,0,0,342,0,0,0,0,0,0,0,230,1.5,0,0,12.9,77777,9,999999999,270,0.1220,0,88,999.000,999.0,99.0
+1989,8,1,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,16.1,84,99600,0,0,343,0,0,0,0,0,0,0,0,0.0,0,0,12.9,77777,9,999999999,279,0.1220,0,88,999.000,999.0,99.0
+1989,8,1,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,16.7,90,99600,0,0,340,0,0,0,0,0,0,0,230,2.1,0,0,14.5,77777,9,999999999,290,0.1220,0,88,999.000,999.0,99.0
+1989,8,2,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,15.6,87,99500,0,0,337,0,0,0,0,0,0,0,230,2.1,0,0,14.5,77777,9,999999999,270,0.1220,0,88,999.000,999.0,99.0
+1989,8,2,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,15.6,90,99500,0,0,334,0,0,0,0,0,0,0,210,2.1,0,0,16.1,77777,9,999999999,270,0.1220,0,88,999.000,999.0,99.0
+1989,8,2,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,16.1,90,99500,0,0,344,0,0,0,0,0,0,0,220,3.1,3,1,14.5,77777,9,999999999,279,0.1220,0,88,999.000,999.0,99.0
+1989,8,2,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,15.0,87,99500,0,0,334,0,0,0,0,0,0,0,210,2.6,0,0,12.9,77777,9,999999999,259,0.1220,0,88,999.000,999.0,99.0
+1989,8,2,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,15.6,84,99500,4,276,339,3,2,2,0,0,0,0,0,0.0,0,0,6.4,77777,9,999999999,270,0.1440,0,88,999.000,999.0,99.0
+1989,8,2,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,16.1,87,99600,159,1326,340,62,198,37,6300,11300,5000,660,0,0.0,0,0,6.4,77777,9,999999999,279,0.1440,0,88,999.000,999.0,99.0
+1989,8,2,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,17.8,79,99600,402,1326,358,224,499,71,23000,44200,9600,1340,0,0.0,0,0,6.4,77777,9,999999999,309,0.1440,0,88,999.000,999.0,99.0
+1989,8,2,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,17.8,69,99700,636,1326,369,419,658,100,44000,64800,12800,2120,220,3.1,0,0,6.4,77777,9,999999999,309,0.1440,0,88,999.000,999.0,99.0
+1989,8,2,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,18.3,60,99600,847,1326,383,603,744,124,62400,74100,15000,2890,230,3.1,0,0,11.3,77777,9,999999999,320,0.1440,0,88,999.000,999.0,99.0
+1989,8,2,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,17.2,54,99600,1018,1326,385,758,783,152,78700,78600,18300,4540,250,3.6,2,0,11.3,77777,9,999999999,300,0.1440,0,88,999.000,999.0,99.0
+1989,8,2,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,17.8,51,99600,1138,1326,394,863,808,164,90400,81400,20400,6690,180,4.1,2,0,11.3,77777,9,999999999,309,0.1440,0,88,999.000,999.0,99.0
+1989,8,2,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,17.2,49,99500,1199,1326,393,919,823,170,96800,83100,21500,8660,210,4.1,2,0,11.3,77777,9,999999999,300,0.1440,0,88,999.000,999.0,99.0
+1989,8,2,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,17.8,50,99400,1197,1326,397,918,838,157,97500,84900,20700,8030,190,5.7,0,0,12.9,77777,9,999999999,309,0.1440,0,88,999.000,999.0,99.0
+1989,8,2,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,18.3,51,99300,1131,1326,397,858,824,151,90700,83300,19500,6140,220,4.6,0,0,12.9,77777,9,999999999,320,0.1440,0,88,999.000,999.0,99.0
+1989,8,2,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,18.3,51,99300,1007,1326,397,745,792,140,78100,79700,17500,4190,220,4.1,0,0,12.9,77777,9,999999999,320,0.1440,0,88,999.000,999.0,99.0
+1989,8,2,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,18.9,53,99200,832,1326,398,588,738,122,62700,75100,15500,3080,220,4.1,0,0,16.1,77777,9,999999999,329,0.1440,0,88,999.000,999.0,99.0
+1989,8,2,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,18.9,55,99200,619,1326,396,403,647,98,42200,63400,12600,2060,230,4.1,0,0,16.1,77777,9,999999999,329,0.1440,0,88,999.000,999.0,99.0
+1989,8,2,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,19.4,63,99200,383,1326,387,208,480,68,21400,41900,9300,1270,220,3.6,0,0,16.1,77777,9,999999999,340,0.1440,0,88,999.000,999.0,99.0
+1989,8,2,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,18.9,65,99200,140,1326,381,52,153,35,5300,8100,4400,630,220,2.6,2,0,16.1,77777,9,999999999,329,0.1440,0,88,999.000,999.0,99.0
+1989,8,2,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,19.4,74,99100,1,166,380,0,1,0,0,0,0,0,170,2.6,3,1,11.3,77777,9,999999999,340,0.1440,0,88,999.000,999.0,99.0
+1989,8,2,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,19.4,79,99100,0,0,368,0,0,0,0,0,0,0,180,3.1,1,0,11.3,77777,9,999999999,340,0.1440,0,88,999.000,999.0,99.0
+1989,8,2,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,19.4,79,99100,0,0,368,0,0,0,0,0,0,0,180,3.6,1,0,11.3,77777,9,999999999,340,0.1440,0,88,999.000,999.0,99.0
+1989,8,2,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,19.4,82,99100,0,0,372,0,0,0,0,0,0,0,190,3.6,4,1,11.3,77777,9,999999999,340,0.1440,0,88,999.000,999.0,99.0
+1989,8,2,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,19.4,84,99100,0,0,374,0,0,0,0,0,0,0,180,3.1,8,2,11.3,77777,9,999999999,340,0.1440,0,88,999.000,999.0,99.0
+1989,8,3,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,19.4,87,99100,0,0,367,0,0,0,0,0,0,0,190,3.1,4,1,12.9,77777,9,999999999,340,0.1440,0,88,999.000,999.0,99.0
+1989,8,3,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,19.4,87,99100,0,0,367,0,0,0,0,0,0,0,220,3.1,3,1,14.5,77777,9,999999999,340,0.1440,0,88,999.000,999.0,99.0
+1989,8,3,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,18.3,84,99000,0,0,362,0,0,0,0,0,0,0,220,4.1,3,1,11.3,77777,9,999999999,320,0.1440,0,88,999.000,999.0,99.0
+1989,8,3,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,17.8,79,99000,0,0,373,0,0,0,0,0,0,0,190,3.1,8,3,9.7,77777,9,999999999,309,0.1440,0,88,999.000,999.0,99.0
+1989,8,3,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,18.9,84,99000,4,254,371,1,0,1,0,0,0,0,190,3.6,7,2,6.4,77777,9,999999999,329,0.1600,0,88,999.000,999.0,99.0
+1989,8,3,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,19.4,82,99100,156,1327,377,56,109,43,5900,5900,5200,800,220,3.6,8,2,6.4,77777,9,999999999,340,0.1600,0,88,999.000,999.0,99.0
+1989,8,3,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,20.6,76,99000,398,1327,394,192,292,103,20400,26400,12400,2010,220,5.7,9,3,6.4,77777,9,999999999,359,0.1600,0,88,999.000,999.0,99.0
+1989,8,3,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,21.7,74,99000,634,1327,400,392,530,137,41900,52800,16600,2790,250,7.2,5,2,6.4,77777,9,999999999,390,0.1600,0,88,999.000,999.0,99.0
+1989,8,3,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,22.2,70,99000,844,1327,404,518,474,214,55000,48800,23900,5330,200,6.2,3,1,8.0,77777,9,999999999,400,0.1600,0,88,999.000,999.0,99.0
+1989,8,3,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,22.8,67,98900,1016,1327,416,657,557,228,68500,56200,25500,7240,220,5.7,3,2,8.0,77777,9,999999999,409,0.1600,0,88,999.000,999.0,99.0
+1989,8,3,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,22.8,63,98900,1136,1327,430,754,514,311,80700,53700,34700,13760,230,6.2,10,4,8.0,77777,9,999999999,409,0.1600,0,88,999.000,999.0,99.0
+1989,8,3,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,22.2,61,98800,1197,1327,426,767,482,330,82400,50400,36800,18110,200,8.2,10,3,8.0,77777,9,999999999,400,0.1600,0,88,999.000,999.0,99.0
+1989,8,3,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,22.2,61,98800,1194,1327,426,842,562,333,90300,58800,37300,18100,210,6.7,10,3,8.0,77777,9,999999999,400,0.1600,0,88,999.000,999.0,99.0
+1989,8,3,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,22.8,59,98700,1129,1327,440,819,618,289,84900,62000,32100,11960,210,8.2,10,5,11.3,77777,9,999999999,409,0.1600,0,88,999.000,999.0,99.0
+1989,8,3,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,22.2,57,98600,1004,1327,436,613,458,264,65500,47700,29300,8440,210,8.2,8,4,16.1,77777,9,999999999,400,0.1600,0,88,999.000,999.0,99.0
+1989,8,3,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,21.7,55,98500,829,1327,432,525,488,218,55600,50200,24200,5350,210,8.2,6,3,16.1,77777,9,999999999,379,0.1600,0,88,999.000,999.0,99.0
+1989,8,3,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,22.2,61,98500,616,1327,426,349,349,185,37100,35700,20500,4050,210,6.7,7,3,16.1,77777,9,999999999,400,0.1600,0,88,999.000,999.0,99.0
+1989,8,3,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,22.8,63,98400,379,1327,423,183,275,104,19400,24300,12400,2040,200,7.2,6,2,16.1,77777,9,999999999,409,0.1600,0,88,999.000,999.0,99.0
+1989,8,3,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,22.2,65,98400,136,1327,420,41,53,36,4500,3000,4200,750,200,6.2,7,3,16.1,77777,9,999999999,390,0.1600,0,88,999.000,999.0,99.0
+1989,8,3,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,22.2,65,98400,1,144,464,0,0,0,0,0,0,0,200,5.7,10,10,16.1,2290,9,999999999,390,0.1600,0,88,999.000,999.0,99.0
+1989,8,3,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.1,22.2,79,98400,0,0,444,0,0,0,0,0,0,0,230,4.1,10,10,11.3,940,9,999999999,400,0.1600,0,88,999.000,999.0,99.0
+1989,8,3,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.6,23.9,91,98300,0,0,444,0,0,0,0,0,0,0,190,4.1,10,10,11.3,1130,9,999999999,440,0.1600,0,88,999.000,999.0,99.0
+1989,8,3,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.6,23.3,88,98300,0,0,443,0,0,0,0,0,0,0,190,5.2,10,10,11.3,980,9,999999999,430,0.1600,0,88,999.000,999.0,99.0
+1989,8,3,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.1,23.3,85,98200,0,0,446,0,0,0,0,0,0,0,200,6.7,10,10,11.3,1130,9,999999999,419,0.1600,0,88,999.000,999.0,99.0
+1989,8,4,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,26.1,23.3,85,98100,0,0,446,0,0,0,0,0,0,0,230,6.2,10,10,6.4,640,9,999999999,419,0.1600,0,88,999.000,999.0,99.0
+1989,8,4,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,20.6,85,98100,0,0,426,0,0,0,0,0,0,0,290,8.8,10,10,2.4,0,9,999999999,359,0.1600,0,88,999.000,999.0,99.0
+1989,8,4,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,24.4,22.2,88,98100,0,0,434,0,0,0,0,0,0,0,270,5.7,10,10,4.8,340,9,999999999,400,0.1600,0,88,999.000,999.0,99.0
+1989,8,4,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,24.4,22.2,88,98200,0,0,434,0,0,0,0,0,0,0,270,5.7,10,10,4.8,850,9,999999999,400,0.1600,0,88,999.000,999.0,99.0
+1989,8,4,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,22.8,94,98200,3,232,432,0,0,0,0,0,0,0,260,3.6,10,10,12.9,850,9,999999999,409,0.1760,0,88,999.000,999.0,99.0
+1989,8,4,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,18.9,74,98200,152,1327,427,31,2,30,3400,0,3400,1060,230,2.1,10,10,12.9,700,9,999999999,329,0.1760,0,88,999.000,999.0,99.0
+1989,8,4,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,21.1,87,98300,395,1327,426,97,0,97,11000,0,11000,3630,260,5.2,10,10,12.9,730,9,999999999,370,0.1760,0,88,999.000,999.0,99.0
+1989,8,4,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,23.9,97,98200,631,1327,436,92,6,89,11100,400,10900,4110,240,3.6,10,10,11.3,640,9,999999999,440,0.1760,0,88,999.000,999.0,99.0
+1989,8,4,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,24.4,91,98200,842,1327,447,220,0,220,25600,0,25600,9730,270,4.1,10,10,12.9,640,9,999999999,450,0.1760,0,88,999.000,999.0,99.0
+1989,8,4,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,23.9,82,98300,1013,1327,453,302,3,300,35300,300,35100,13390,270,4.1,10,10,12.9,490,9,999999999,440,0.1760,0,88,999.000,999.0,99.0
+1989,8,4,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,24.4,75,98300,1134,1327,467,358,2,356,42000,200,41800,15720,290,5.2,10,10,12.9,580,9,999999999,450,0.1760,0,88,999.000,999.0,99.0
+1989,8,4,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,23.9,70,98300,1195,1327,470,415,1,414,48500,100,48500,17690,280,2.6,10,10,12.9,610,9,999999999,440,0.1760,0,88,999.000,999.0,99.0
+1989,8,4,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,24.4,70,98300,1192,1327,433,847,590,313,91300,61700,35700,16790,240,1.5,4,4,12.9,77777,9,999999999,450,0.1760,0,88,999.000,999.0,99.0
+1989,8,4,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,24.4,70,98300,1126,1327,440,761,600,249,79900,60700,28200,10380,220,3.1,6,6,12.9,1010,9,999999999,450,0.1760,0,88,999.000,999.0,99.0
+1989,8,4,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,25.0,70,98300,1001,1327,443,505,362,229,54600,37800,26000,7200,230,4.1,6,6,12.9,820,9,999999999,459,0.1760,0,88,999.000,999.0,99.0
+1989,8,4,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,25.0,70,98200,826,1327,440,532,531,199,56800,54700,22700,4830,210,4.6,5,5,12.9,77777,9,999999999,459,0.1760,0,88,999.000,999.0,99.0
+1989,8,4,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,24.4,68,98200,612,1327,439,327,368,156,34300,36400,17600,3190,220,4.1,5,5,12.9,77777,9,999999999,450,0.1760,0,88,999.000,999.0,99.0
+1989,8,4,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,25.0,75,98200,375,1327,433,156,199,99,16500,17500,11600,1930,220,5.2,5,5,12.9,77777,9,999999999,469,0.1760,0,88,999.000,999.0,99.0
+1989,8,4,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,25.0,80,98200,132,1327,416,38,68,31,4000,3200,3700,560,220,3.1,2,2,11.3,77777,9,999999999,469,0.1760,0,88,999.000,999.0,99.0
+1989,8,4,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,25.0,82,98300,1,100,424,1,0,1,0,0,0,0,220,2.1,5,5,11.3,77777,9,999999999,459,0.1760,0,88,999.000,999.0,99.0
+1989,8,4,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,27.8,25.6,88,98300,0,0,425,0,0,0,0,0,0,0,210,3.1,6,6,11.3,1010,9,999999999,480,0.1760,0,88,999.000,999.0,99.0
+1989,8,4,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,28.3,25.0,82,98100,0,0,439,0,0,0,0,0,0,0,160,5.7,10,8,11.3,1010,9,999999999,459,0.1760,0,88,999.000,999.0,99.0
+1989,8,4,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,28.3,25.0,82,98200,0,0,432,0,0,0,0,0,0,0,250,6.2,7,7,11.3,1010,9,999999999,459,0.1760,0,88,999.000,999.0,99.0
+1989,8,4,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,18.9,84,98500,0,0,414,0,0,0,0,0,0,0,320,6.2,10,10,11.3,1100,9,999999999,329,0.1760,0,88,999.000,999.0,99.0
+1989,8,5,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,18.3,90,98600,0,0,404,0,0,0,0,0,0,0,40,6.2,10,10,11.3,610,9,999999999,320,0.1760,0,88,999.000,999.0,99.0
+1989,8,5,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,18.3,87,98700,0,0,408,0,0,0,0,0,0,0,30,5.7,10,10,16.1,1520,9,999999999,320,0.1760,0,88,999.000,999.0,99.0
+1989,8,5,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,18.3,87,98600,0,0,408,0,0,0,0,0,0,0,60,4.1,10,10,16.1,1430,9,999999999,320,0.1760,0,88,999.000,999.0,99.0
+1989,8,5,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,17.8,87,98700,0,0,404,0,0,0,0,0,0,0,180,3.1,10,10,8.0,910,9,999999999,309,0.1760,0,88,999.000,999.0,99.0
+1989,8,5,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,18.9,90,98100,2,210,408,0,0,0,0,0,0,0,160,8.8,10,10,11.3,910,9,999999999,329,0.0810,0,88,999.000,999.0,99.0
+1989,8,5,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,18.9,87,98200,149,1327,411,31,1,31,3500,0,3500,1080,180,2.1,10,10,16.1,3050,9,999999999,329,0.0810,0,88,999.000,999.0,99.0
+1989,8,5,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,20.0,90,98400,392,1327,416,110,7,108,12300,400,12200,3890,300,3.6,10,10,16.1,1830,9,999999999,350,0.0810,0,88,999.000,999.0,99.0
+1989,8,5,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,21.1,90,98400,628,1327,412,208,126,148,23100,12900,17000,3620,260,4.6,9,9,16.1,1680,9,999999999,370,0.0810,0,88,999.000,999.0,99.0
+1989,8,5,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,20.6,85,98500,839,1327,405,259,64,218,28500,6500,24400,7560,230,3.6,8,8,16.1,1830,9,999999999,359,0.0810,0,88,999.000,999.0,99.0
+1989,8,5,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,20.6,74,98500,1011,1327,381,752,849,100,77500,84900,12700,2810,230,4.6,0,0,24.1,77777,9,999999999,359,0.0810,0,88,999.000,999.0,99.0
+1989,8,5,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,21.1,69,98500,1131,1327,416,657,407,307,70300,42500,34000,13370,220,4.6,6,6,24.1,1430,9,999999999,370,0.0810,0,88,999.000,999.0,99.0
+1989,8,5,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,21.7,67,98500,1192,1327,396,912,885,112,93800,88800,13800,4950,230,5.7,0,0,24.1,77777,9,999999999,379,0.0810,0,88,999.000,999.0,99.0
+1989,8,5,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,21.7,67,98500,1190,1327,444,435,148,302,48900,15900,34600,14190,260,4.6,10,9,24.1,3050,9,999999999,379,0.0810,0,88,999.000,999.0,99.0
+1989,8,5,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,17.2,53,98300,1123,1327,447,284,9,276,33900,800,33300,13030,290,3.6,10,10,24.1,3050,9,999999999,300,0.0810,0,88,999.000,999.0,99.0
+1989,8,5,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,17.8,48,98200,998,1327,421,616,528,216,67000,55100,25500,6730,270,2.6,8,4,24.1,77777,9,999999999,309,0.0810,0,88,999.000,999.0,99.0
+1989,8,5,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,18.3,50,98200,822,1327,414,498,533,165,51900,53400,18700,3960,240,3.1,3,2,24.1,77777,9,999999999,320,0.0810,0,88,999.000,999.0,99.0
+1989,8,5,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,18.3,51,98200,608,1327,405,378,666,70,39800,64900,10000,1540,260,4.1,1,1,24.1,77777,9,999999999,309,0.0810,0,88,999.000,999.0,99.0
+1989,8,5,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,18.3,57,98300,371,1327,389,215,587,49,22000,51500,7600,980,260,5.2,0,0,24.1,77777,9,999999999,320,0.0810,0,88,999.000,999.0,99.0
+1989,8,5,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,18.9,65,98300,127,1327,381,51,256,26,5100,14000,3800,460,270,4.1,0,0,24.1,77777,9,999999999,329,0.0810,0,88,999.000,999.0,99.0
+1989,8,5,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,19.4,74,98300,0,77,373,2,1,1,0,0,0,0,270,3.6,0,0,24.1,77777,9,999999999,340,0.0810,0,88,999.000,999.0,99.0
+1989,8,5,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.9,20.0,79,98400,0,0,384,0,0,0,0,0,0,0,290,2.6,2,2,24.1,77777,9,999999999,350,0.0810,0,88,999.000,999.0,99.0
+1989,8,5,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.9,19.4,76,98400,0,0,378,0,0,0,0,0,0,0,290,3.1,1,1,24.1,77777,9,999999999,340,0.0810,0,88,999.000,999.0,99.0
+1989,8,5,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,18.3,79,98400,0,0,361,0,0,0,0,0,0,0,270,2.6,0,0,24.1,77777,9,999999999,320,0.0810,0,88,999.000,999.0,99.0
+1989,8,5,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,17.2,73,98400,0,0,360,0,0,0,0,0,0,0,290,3.1,0,0,24.1,77777,9,999999999,290,0.0810,0,88,999.000,999.0,99.0
+1989,8,6,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,16.1,78,98500,0,0,348,0,0,0,0,0,0,0,280,3.1,0,0,24.1,77777,9,999999999,279,0.0810,0,88,999.000,999.0,99.0
+1989,8,6,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,15.6,76,98500,0,0,347,0,0,0,0,0,0,0,300,3.1,0,0,24.1,77777,9,999999999,270,0.0810,0,88,999.000,999.0,99.0
+1989,8,6,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,15.6,78,98500,0,0,344,0,0,0,0,0,0,0,300,3.1,0,0,24.1,77777,9,999999999,270,0.0810,0,88,999.000,999.0,99.0
+1989,8,6,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,14.4,78,98500,0,0,338,0,0,0,0,0,0,0,310,3.1,0,0,24.1,77777,9,999999999,250,0.0810,0,88,999.000,999.0,99.0
+1989,8,6,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,14.4,81,98600,2,188,336,2,3,1,0,0,0,0,300,3.1,0,0,24.1,77777,9,999999999,250,0.1080,0,88,999.000,999.0,99.0
+1989,8,6,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,15.0,81,98600,145,1328,339,58,239,32,6100,12900,4700,570,320,4.1,0,0,24.1,77777,9,999999999,259,0.1080,0,88,999.000,999.0,99.0
+1989,8,6,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,15.0,73,98700,389,1328,347,224,556,59,23200,49100,8900,1130,330,5.2,0,0,24.1,77777,9,999999999,259,0.1080,0,88,999.000,999.0,99.0
+1989,8,6,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,15.0,68,98700,625,1328,352,419,707,83,43400,68700,11000,1730,330,6.2,0,0,24.1,77777,9,999999999,259,0.1080,0,88,999.000,999.0,99.0
+1989,8,6,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,15.6,68,98800,836,1328,384,321,181,205,35100,19400,22900,5080,10,6.2,7,7,24.1,3050,9,999999999,270,0.1080,0,88,999.000,999.0,99.0
+1989,8,6,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,15.6,71,98800,1008,1328,407,292,9,285,34200,800,33600,12870,340,5.7,10,10,24.1,980,9,999999999,270,0.1080,0,88,999.000,999.0,99.0
+1989,8,6,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,14.4,84,99000,1129,1328,384,202,6,197,24800,500,24400,9920,30,9.8,10,10,16.1,370,9,999999999,250,0.1080,0,88,999.000,999.0,99.0
+1989,8,6,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,15.0,93,99000,1190,1328,379,242,8,235,29600,600,29000,11590,20,8.2,10,10,9.7,270,9,999999999,259,0.1080,0,88,999.000,999.0,99.0
+1989,8,6,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,13.9,81,99000,1187,1328,384,389,7,383,45800,700,45200,16770,10,6.7,10,10,16.1,910,9,999999999,240,0.1080,0,88,999.000,999.0,99.0
+1989,8,6,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,11.1,65,99100,1121,1328,373,509,187,350,56300,20000,39400,13950,20,8.2,9,9,19.3,730,9,999999999,209,0.1080,0,88,999.000,999.0,99.0
+1989,8,6,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,10.0,67,99200,995,1328,373,271,53,232,30100,5400,26000,9180,350,7.7,10,10,24.1,850,9,999999999,189,0.1080,0,88,999.000,999.0,99.0
+1989,8,6,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,8.9,65,99200,819,1328,369,263,5,260,30100,400,29900,10770,360,8.8,10,10,24.1,880,9,999999999,179,0.1080,0,88,999.000,999.0,99.0
+1989,8,6,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,8.9,63,99200,604,1328,372,152,5,149,17400,400,17200,6120,360,6.7,10,10,24.1,880,9,999999999,179,0.1080,0,88,999.000,999.0,99.0
+1989,8,6,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,8.3,58,99200,366,1328,341,168,219,107,17700,19100,12400,2120,50,6.7,8,4,24.1,77777,9,999999999,179,0.1080,0,88,999.000,999.0,99.0
+1989,8,6,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,8.3,62,99200,123,1328,325,43,136,30,4400,6600,3800,540,40,2.6,5,1,24.1,77777,9,999999999,179,0.1080,0,88,999.000,999.0,99.0
+1989,8,6,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,8.9,72,99200,0,55,318,0,0,0,0,0,0,0,0,0.0,3,1,24.1,77777,9,999999999,179,0.1080,0,88,999.000,999.0,99.0
+1989,8,6,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,10.0,83,99200,0,0,319,0,0,0,0,0,0,0,300,2.6,3,2,24.1,77777,9,999999999,189,0.1080,0,88,999.000,999.0,99.0
+1989,8,6,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,10.6,87,99300,0,0,323,0,0,0,0,0,0,0,280,3.1,3,3,24.1,77777,9,999999999,200,0.1080,0,88,999.000,999.0,99.0
+1989,8,6,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,10.6,90,99300,0,0,320,0,0,0,0,0,0,0,280,2.6,3,3,24.1,77777,9,999999999,200,0.1080,0,88,999.000,999.0,99.0
+1989,8,6,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,10.0,86,99300,0,0,312,0,0,0,0,0,0,0,280,2.6,1,1,24.1,77777,9,999999999,189,0.1080,0,88,999.000,999.0,99.0
+1989,8,7,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,10.0,90,99300,0,0,325,0,0,0,0,0,0,0,290,3.1,6,6,24.1,1980,9,999999999,200,0.1080,0,88,999.000,999.0,99.0
+1989,8,7,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,11.1,90,99300,0,0,340,0,0,0,0,0,0,0,290,3.1,8,8,24.1,1250,9,999999999,209,0.1080,0,88,999.000,999.0,99.0
+1989,8,7,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,10.6,87,99300,0,0,340,0,0,0,0,0,0,0,300,2.6,8,8,24.1,1830,9,999999999,200,0.1080,0,88,999.000,999.0,99.0
+1989,8,7,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,7.8,77,99300,0,0,317,0,0,0,0,0,0,0,300,2.6,4,4,24.1,77777,9,999999999,170,0.1080,0,88,999.000,999.0,99.0
+1989,8,7,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,8.9,83,99300,1,166,324,1,1,1,0,0,0,0,310,2.6,6,6,24.1,1980,9,999999999,179,0.0880,0,88,999.000,999.0,99.0
+1989,8,7,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,9.4,80,99300,141,1328,314,57,252,30,5700,14400,4200,530,310,2.1,1,1,24.1,77777,9,999999999,189,0.0880,0,88,999.000,999.0,99.0
+1989,8,7,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,10.0,70,99400,385,1328,332,238,587,65,24500,51400,9500,1230,300,3.1,2,2,24.1,77777,9,999999999,200,0.0880,0,88,999.000,999.0,99.0
+1989,8,7,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,8.9,58,99300,622,1328,338,416,654,106,43300,63900,13300,2200,10,3.1,2,2,24.1,77777,9,999999999,179,0.0880,0,88,999.000,999.0,99.0
+1989,8,7,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,7.8,47,99300,834,1328,347,586,735,120,60600,73200,14600,2780,310,4.6,2,2,24.1,77777,9,999999999,170,0.0880,0,88,999.000,999.0,99.0
+1989,8,7,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,8.3,47,99300,1006,1328,354,725,730,167,77000,74700,20400,5370,310,4.6,3,3,24.1,77777,9,999999999,179,0.0880,0,88,999.000,999.0,99.0
+1989,8,7,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,8.3,46,99300,1127,1328,365,804,691,214,85200,70500,25300,9030,320,5.2,6,6,24.1,1680,9,999999999,179,0.0880,0,88,999.000,999.0,99.0
+1989,8,7,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,7.8,44,99300,1188,1328,375,670,314,388,73500,34100,42900,18760,320,5.7,8,8,24.1,1680,9,999999999,170,0.0880,0,88,999.000,999.0,99.0
+1989,8,7,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,8.3,43,99300,1185,1328,375,479,220,281,53700,24000,32200,13080,10,6.2,7,7,24.1,1830,9,999999999,179,0.0880,0,88,999.000,999.0,99.0
+1989,8,7,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,9.4,49,99300,1118,1328,367,872,743,242,91500,75300,28000,9850,40,3.6,6,6,24.1,1680,9,999999999,189,0.0880,0,88,999.000,999.0,99.0
+1989,8,7,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,10.6,53,99300,992,1328,368,679,683,166,72300,69800,20000,5200,30,3.6,6,6,24.1,1680,9,999999999,200,0.0880,0,88,999.000,999.0,99.0
+1989,8,7,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,10.6,55,99200,816,1328,356,569,687,144,59800,69200,17200,3490,40,3.6,3,3,24.1,77777,9,999999999,200,0.0880,0,88,999.000,999.0,99.0
+1989,8,7,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,10.0,53,99200,601,1328,365,311,309,170,33300,31400,19000,3650,10,4.6,6,6,24.1,1370,9,999999999,200,0.0880,0,88,999.000,999.0,99.0
+1989,8,7,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,10.0,55,99200,362,1328,349,196,474,65,20100,40600,9000,1210,40,3.1,2,2,24.1,77777,9,999999999,200,0.0880,0,88,999.000,999.0,99.0
+1989,8,7,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,10.0,63,99200,118,1328,328,44,190,26,4500,9100,3700,460,130,2.6,0,0,24.1,77777,9,999999999,200,0.0880,0,88,999.000,999.0,99.0
+1989,8,7,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,10.0,70,99200,0,33,321,0,0,0,0,0,0,0,140,2.6,0,0,24.1,77777,9,999999999,200,0.0880,0,88,999.000,999.0,99.0
+1989,8,7,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,10.0,75,99200,0,0,316,0,0,0,0,0,0,0,200,2.6,0,0,24.1,77777,9,999999999,189,0.0880,0,88,999.000,999.0,99.0
+1989,8,7,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,10.6,81,99200,0,0,314,0,0,0,0,0,0,0,200,2.6,0,0,24.1,77777,9,999999999,200,0.0880,0,88,999.000,999.0,99.0
+1989,8,7,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,10.0,80,99200,0,0,311,0,0,0,0,0,0,0,220,2.6,0,0,24.1,77777,9,999999999,189,0.0880,0,88,999.000,999.0,99.0
+1989,8,7,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,9.4,80,99100,0,0,308,0,0,0,0,0,0,0,230,3.1,0,0,24.1,77777,9,999999999,189,0.0880,0,88,999.000,999.0,99.0
+1989,8,8,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,10.6,83,99100,0,0,312,0,0,0,0,0,0,0,240,3.1,0,0,24.1,77777,9,999999999,200,0.0880,0,88,999.000,999.0,99.0
+1989,8,8,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,10.6,83,99100,0,0,312,0,0,0,0,0,0,0,240,3.6,0,0,16.1,77777,9,999999999,200,0.0880,0,88,999.000,999.0,99.0
+1989,8,8,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,10.0,83,99300,0,0,309,0,0,0,0,0,0,0,240,3.1,0,0,16.1,77777,9,999999999,189,0.0880,0,88,999.000,999.0,99.0
+1989,8,8,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,7.8,77,99300,0,0,302,0,0,0,0,0,0,0,240,3.1,0,0,16.1,77777,9,999999999,170,0.0880,0,88,999.000,999.0,99.0
+1989,8,8,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,8.9,83,99300,1,144,303,1,1,1,0,0,0,0,250,2.6,0,0,16.1,77777,9,999999999,179,0.1450,0,88,999.000,999.0,99.0
+1989,8,8,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,10.0,83,99300,138,1329,309,50,163,33,5200,8500,4300,590,260,3.6,0,0,19.3,77777,9,999999999,189,0.1450,0,88,999.000,999.0,99.0
+1989,8,8,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,10.6,72,99300,382,1329,322,211,489,69,21700,42600,9400,1290,270,3.6,0,0,19.3,77777,9,999999999,200,0.1450,0,88,999.000,999.0,99.0
+1989,8,8,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,10.6,61,99300,619,1329,334,409,659,99,42800,64600,12700,2070,270,3.6,0,0,19.3,77777,9,999999999,200,0.1450,0,88,999.000,999.0,99.0
+1989,8,8,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,10.0,51,99300,831,1329,344,599,755,123,61900,75000,14900,2800,310,4.1,0,0,19.3,77777,9,999999999,200,0.1450,0,88,999.000,999.0,99.0
+1989,8,8,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,11.1,48,99300,1003,1329,367,718,680,200,75400,69000,23200,6270,280,5.7,2,2,19.3,77777,9,999999999,209,0.1450,0,88,999.000,999.0,99.0
+1989,8,8,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,11.1,45,99300,1124,1329,396,667,335,381,72500,36400,41700,15450,230,7.2,8,8,19.3,1830,9,999999999,209,0.1450,0,88,999.000,999.0,99.0
+1989,8,8,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,10.0,43,99200,1185,1329,375,824,575,308,88900,60200,35100,16000,250,5.2,4,4,19.3,77777,9,999999999,189,0.1450,0,88,999.000,999.0,99.0
+1989,8,8,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,11.1,42,99200,1182,1329,388,822,623,265,86400,63100,30200,13220,290,5.2,5,5,19.3,77777,9,999999999,209,0.1450,0,88,999.000,999.0,99.0
+1989,8,8,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,11.1,45,99200,1115,1329,396,499,226,309,55200,24600,34600,11970,260,7.2,8,8,19.3,1680,9,999999999,209,0.1450,0,88,999.000,999.0,99.0
+1989,8,8,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,12.2,48,99200,989,1329,406,450,112,366,49500,11500,40900,13360,250,4.1,9,9,19.3,1830,9,999999999,220,0.1450,0,88,999.000,999.0,99.0
+1989,8,8,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,12.8,48,99100,812,1329,401,360,195,240,39600,20500,27000,6550,250,4.6,8,8,24.1,1680,9,999999999,229,0.1450,0,88,999.000,999.0,99.0
+1989,8,8,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,12.2,52,99100,596,1329,386,257,133,197,27900,13400,21900,4750,260,5.7,7,7,24.1,2440,9,999999999,220,0.1450,0,88,999.000,999.0,99.0
+1989,8,8,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,13.3,55,99100,357,1329,393,147,86,124,16100,7700,14000,3060,0,0.0,8,8,24.1,1520,9,999999999,240,0.1450,0,88,999.000,999.0,99.0
+1989,8,8,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,14.4,73,99200,114,1318,396,11,1,11,1300,0,1300,430,50,6.7,10,10,6.4,1520,9,999999999,250,0.1450,0,88,999.000,999.0,99.0
+1989,8,8,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,15.0,78,99200,0,0,394,0,0,0,0,0,0,0,230,2.6,10,10,11.3,1370,9,999999999,259,0.1450,0,88,999.000,999.0,99.0
+1989,8,8,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,14.4,84,99300,0,0,384,0,0,0,0,0,0,0,250,2.1,10,10,11.3,1370,9,999999999,250,0.1450,0,88,999.000,999.0,99.0
+1989,8,8,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,13.9,81,99300,0,0,384,0,0,0,0,0,0,0,290,3.1,10,10,11.3,1830,9,999999999,250,0.1450,0,88,999.000,999.0,99.0
+1989,8,8,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,15.6,90,99300,0,0,386,0,0,0,0,0,0,0,290,2.6,10,10,11.3,2740,9,999999999,270,0.1450,0,88,999.000,999.0,99.0
+1989,8,8,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,15.6,90,99300,0,0,386,0,0,0,0,0,0,0,340,1.5,10,10,11.3,2440,9,999999999,270,0.1450,0,88,999.000,999.0,99.0
+1989,8,9,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,15.6,90,99300,0,0,367,0,0,0,0,0,0,0,240,3.1,8,8,16.1,2440,9,999999999,270,0.1450,0,88,999.000,999.0,99.0
+1989,8,9,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,15.6,87,99300,0,0,389,0,0,0,0,0,0,0,230,3.1,10,10,16.1,1520,9,999999999,270,0.1450,0,88,999.000,999.0,99.0
+1989,8,9,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,15.0,84,99300,0,0,388,0,0,0,0,0,0,0,240,3.6,10,10,16.1,1680,9,999999999,259,0.1450,0,88,999.000,999.0,99.0
+1989,8,9,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,12.8,81,99400,0,0,346,0,0,0,0,0,0,0,0,0.0,5,5,16.1,77777,9,999999999,229,0.1450,0,88,999.000,999.0,99.0
+1989,8,9,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,13.9,90,99400,1,122,336,1,2,1,0,0,0,0,210,1.5,3,2,11.3,77777,9,999999999,250,0.0810,0,88,999.000,999.0,99.0
+1989,8,9,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,14.4,93,99500,134,1329,332,49,117,37,5100,5600,4600,680,230,2.6,10,1,11.3,77777,9,999999999,250,0.0810,0,88,999.000,999.0,99.0
+1989,8,9,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,15.0,81,99600,378,1329,345,207,501,62,21300,43700,8900,1170,240,4.1,5,1,11.3,77777,9,999999999,259,0.0810,0,88,999.000,999.0,99.0
+1989,8,9,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,14.4,66,99600,616,1329,363,358,451,147,37800,44600,17100,2990,280,4.6,8,2,11.3,77777,9,999999999,250,0.0810,0,88,999.000,999.0,99.0
+1989,8,9,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,15.0,62,99600,828,1329,360,603,740,138,63600,74800,16900,3420,280,4.1,8,0,11.3,77777,9,999999999,259,0.0810,0,88,999.000,999.0,99.0
+1989,8,9,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,15.6,56,99600,1001,1329,372,761,779,170,80800,79600,20800,5400,310,3.1,9,0,11.3,77777,9,999999999,270,0.0810,0,88,999.000,999.0,99.0
+1989,8,9,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,15.0,51,99600,1122,1329,384,807,745,173,83900,74800,20600,6550,240,3.6,10,1,11.3,77777,9,999999999,270,0.0810,0,88,999.000,999.0,99.0
+1989,8,9,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,13.3,44,99600,1183,1329,390,863,710,227,91600,72500,27000,11470,320,2.6,10,2,11.3,77777,9,999999999,240,0.0810,0,88,999.000,999.0,99.0
+1989,8,9,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,13.9,49,99600,1179,1329,418,418,130,302,46900,14000,34500,13740,280,1.5,9,9,11.3,3050,9,999999999,250,0.0810,0,88,999.000,999.0,99.0
+1989,8,9,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,13.9,44,99600,1112,1329,427,518,181,366,57100,19300,40900,14320,270,2.1,9,9,12.9,1680,9,999999999,250,0.0810,0,88,999.000,999.0,99.0
+1989,8,9,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,15.0,54,99600,986,1329,407,496,125,403,54500,12900,44900,14340,80,5.7,8,8,12.9,1830,9,999999999,259,0.0810,0,88,999.000,999.0,99.0
+1989,8,9,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,15.6,58,99600,808,1329,405,346,260,187,38100,27800,21200,4470,90,5.7,8,8,11.3,1520,9,999999999,270,0.0810,0,88,999.000,999.0,99.0
+1989,8,9,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,15.0,60,99600,592,1329,407,202,65,172,22100,6400,19200,5040,180,4.6,9,9,12.9,1520,9,999999999,259,0.0810,0,88,999.000,999.0,99.0
+1989,8,9,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,14.4,60,99500,353,1329,395,116,116,85,12700,10200,10000,1870,190,4.6,8,8,14.5,1680,9,999999999,259,0.0810,0,88,999.000,999.0,99.0
+1989,8,9,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,15.0,68,99500,109,1296,395,19,4,19,2200,0,2200,690,190,4.1,9,9,14.5,1680,9,999999999,259,0.0810,0,88,999.000,999.0,99.0
+1989,8,9,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,15.6,76,99500,0,0,376,0,0,0,0,0,0,0,180,3.6,7,7,14.5,1830,9,999999999,270,0.0810,0,88,999.000,999.0,99.0
+1989,8,9,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,15.0,78,99600,0,0,356,0,0,0,0,0,0,0,190,3.1,3,3,16.1,77777,9,999999999,259,0.0810,0,88,999.000,999.0,99.0
+1989,8,9,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,14.4,73,99600,0,0,343,0,0,0,0,0,0,0,200,3.1,0,0,16.1,77777,9,999999999,250,0.0810,0,88,999.000,999.0,99.0
+1989,8,9,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,13.9,78,99700,0,0,335,0,0,0,0,0,0,0,210,2.6,0,0,16.1,77777,9,999999999,250,0.0810,0,88,999.000,999.0,99.0
+1989,8,9,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,13.9,78,99700,0,0,335,0,0,0,0,0,0,0,210,2.6,0,0,16.1,77777,9,999999999,250,0.0810,0,88,999.000,999.0,99.0
+1989,8,10,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,13.9,78,99700,0,0,335,0,0,0,0,0,0,0,220,2.6,0,0,12.9,77777,9,999999999,250,0.0810,0,88,999.000,999.0,99.0
+1989,8,10,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,14.4,81,99700,0,0,347,0,0,0,0,0,0,0,230,3.1,5,2,11.3,77777,9,999999999,250,0.0810,0,88,999.000,999.0,99.0
+1989,8,10,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,13.9,81,99800,0,0,347,0,0,0,0,0,0,0,220,3.1,7,3,11.3,77777,9,999999999,250,0.0810,0,88,999.000,999.0,99.0
+1989,8,10,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,12.8,75,99800,0,0,346,0,0,0,0,0,0,0,210,2.6,6,3,11.3,77777,9,999999999,229,0.0810,0,88,999.000,999.0,99.0
+1989,8,10,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,13.3,81,99800,0,100,344,0,0,0,0,0,0,0,230,2.6,6,3,11.3,77777,9,999999999,240,0.2980,0,88,999.000,999.0,99.0
+1989,8,10,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,13.9,81,99900,130,1330,332,41,33,37,4400,2100,4200,860,240,2.1,2,0,11.3,77777,9,999999999,250,0.2980,0,88,999.000,999.0,99.0
+1989,8,10,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,14.4,73,99900,375,1330,343,176,274,97,18600,24200,11800,1880,250,3.1,1,0,11.3,77777,9,999999999,250,0.2980,0,88,999.000,999.0,99.0
+1989,8,10,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,15.0,64,99900,613,1330,357,364,458,151,38300,45300,17400,3070,240,4.1,1,0,11.3,77777,9,999999999,259,0.2980,0,88,999.000,999.0,99.0
+1989,8,10,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,15.6,58,100000,826,1330,369,555,583,190,59500,60000,22100,4580,230,3.1,0,0,11.3,77777,9,999999999,270,0.2980,0,88,999.000,999.0,99.0
+1989,8,10,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,16.7,58,100000,998,1330,388,666,524,270,70900,54500,29900,8520,260,4.1,3,2,11.3,77777,9,999999999,290,0.2980,0,88,999.000,999.0,99.0
+1989,8,10,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,15.6,51,100000,1119,1330,393,778,586,281,83900,61300,32200,11700,260,5.2,2,2,11.3,77777,9,999999999,279,0.2980,0,88,999.000,999.0,99.0
+1989,8,10,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,16.1,51,99900,1180,1330,391,824,584,303,89000,61100,34700,15390,260,3.6,1,1,11.3,77777,9,999999999,279,0.2980,0,88,999.000,999.0,99.0
+1989,8,10,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,13.9,43,99900,1177,1330,400,770,488,335,82200,51000,37000,16890,300,4.1,3,3,11.3,77777,9,999999999,250,0.2980,0,88,999.000,999.0,99.0
+1989,8,10,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,15.0,44,99800,1109,1330,411,751,484,345,79300,50400,37100,14150,270,4.1,5,5,14.5,77777,9,999999999,259,0.2980,0,88,999.000,999.0,99.0
+1989,8,10,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,14.4,43,99800,982,1330,425,530,249,344,57000,26900,37100,10730,280,3.6,8,8,12.9,1680,9,999999999,259,0.2980,0,88,999.000,999.0,99.0
+1989,8,10,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,15.6,56,99800,804,1330,417,178,67,137,20200,7100,15900,3720,50,8.2,9,9,12.9,1680,9,999999999,270,0.2980,0,88,999.000,999.0,99.0
+1989,8,10,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,18.3,79,99800,588,1330,416,95,4,93,11300,300,11200,4160,30,6.2,10,10,16.1,1520,9,999999999,320,0.2980,0,88,999.000,999.0,99.0
+1989,8,10,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,17.2,79,99800,348,1330,409,36,0,36,4300,0,4300,1540,30,4.1,10,10,14.5,1520,9,999999999,300,0.2980,0,88,999.000,999.0,99.0
+1989,8,10,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,17.2,87,99800,104,1274,400,28,0,28,3100,0,3100,920,320,4.1,10,10,8.0,1520,9,999999999,300,0.2980,0,88,999.000,999.0,99.0
+1989,8,10,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,16.7,81,99800,0,0,402,0,0,0,0,0,0,0,270,3.1,10,10,8.0,3050,9,999999999,290,0.2980,0,88,999.000,999.0,99.0
+1989,8,10,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,16.7,76,99800,0,0,408,0,0,0,0,0,0,0,240,1.5,10,10,9.7,3050,9,999999999,290,0.2980,0,88,999.000,999.0,99.0
+1989,8,10,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,16.7,79,99900,0,0,386,0,0,0,0,0,0,0,0,0.0,8,8,9.7,3050,9,999999999,290,0.2980,0,88,999.000,999.0,99.0
+1989,8,10,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,16.7,84,99900,0,0,374,0,0,0,0,0,0,0,260,1.5,7,7,11.3,3050,9,999999999,290,0.2980,0,88,999.000,999.0,99.0
+1989,8,10,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,15.6,81,99900,0,0,360,0,0,0,0,0,0,0,270,2.6,4,4,11.3,77777,9,999999999,270,0.2980,0,88,999.000,999.0,99.0
+1989,8,11,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,15.6,84,99800,0,0,346,0,0,0,0,0,0,0,230,2.6,1,1,11.3,77777,9,999999999,270,0.2980,0,88,999.000,999.0,99.0
+1989,8,11,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,15.6,87,99800,0,0,343,0,0,0,0,0,0,0,220,2.1,1,1,11.3,77777,9,999999999,270,0.2980,0,88,999.000,999.0,99.0
+1989,8,11,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,15.6,90,99800,0,0,334,0,0,0,0,0,0,0,0,0.0,0,0,11.3,77777,9,999999999,270,0.2980,0,88,999.000,999.0,99.0
+1989,8,11,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,15.0,90,99900,0,0,331,0,0,0,0,0,0,0,270,1.5,0,0,11.3,77777,9,999999999,259,0.2980,0,88,999.000,999.0,99.0
+1989,8,11,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,14.4,90,99900,0,78,334,1,1,0,0,0,0,0,0,0.0,1,1,6.4,77777,9,999999999,250,0.0920,0,88,999.000,999.0,99.0
+1989,8,11,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,15.6,97,99900,126,1330,343,43,136,29,4400,6800,3700,520,0,0.0,3,3,6.4,77777,9,999999999,270,0.0920,0,88,999.000,999.0,99.0
+1989,8,11,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,17.2,84,100000,372,1330,356,199,517,52,20700,45200,8100,1010,0,0.0,1,1,6.4,77777,9,999999999,300,0.0920,0,88,999.000,999.0,99.0
+1989,8,11,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,16.7,64,100000,610,1330,367,410,723,75,42800,70300,10500,1610,190,2.1,0,0,9.7,77777,9,999999999,290,0.0920,0,88,999.000,999.0,99.0
+1989,8,11,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,15.6,58,100000,823,1330,381,526,625,136,55500,63200,16300,3350,190,3.1,2,2,9.7,77777,9,999999999,270,0.0920,0,88,999.000,999.0,99.0
+1989,8,11,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,15.0,49,100000,996,1330,396,719,738,162,76500,75500,19900,5110,150,2.1,3,3,9.7,77777,9,999999999,270,0.0920,0,88,999.000,999.0,99.0
+1989,8,11,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,15.0,49,100000,1117,1330,399,709,580,218,74900,59100,25200,8890,0,0.0,4,4,9.7,77777,9,999999999,270,0.0920,0,88,999.000,999.0,99.0
+1989,8,11,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,16.1,69,99900,1177,1330,388,625,304,354,68800,33100,39500,16360,250,3.6,7,7,9.7,1460,9,999999999,279,0.0920,0,88,999.000,999.0,99.0
+1989,8,11,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,17.2,60,99900,1174,1330,434,181,47,140,21400,5100,16800,6260,320,4.6,10,10,9.7,1520,9,999999999,300,0.0920,0,88,999.000,999.0,99.0
+1989,8,11,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,15.0,64,99900,1106,1330,412,233,7,227,28200,600,27700,11120,130,5.2,10,10,8.0,1520,9,999999999,259,0.0920,0,88,999.000,999.0,99.0
+1989,8,11,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,16.7,69,99800,979,1330,398,482,294,263,52800,31800,29300,7830,190,3.6,8,8,8.0,7620,9,999999999,290,0.0920,0,88,999.000,999.0,99.0
+1989,8,11,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,16.7,62,99800,801,1330,382,491,545,160,51100,54500,18200,3740,230,3.1,7,2,8.0,77777,9,999999999,290,0.0920,0,88,999.000,999.0,99.0
+1989,8,11,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,16.7,58,99800,584,1330,383,357,626,79,37700,61100,10800,1660,260,2.1,3,1,8.0,77777,9,999999999,290,0.0920,0,88,999.000,999.0,99.0
+1989,8,11,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,18.3,69,99700,343,1330,379,176,440,60,18000,37100,8400,1120,0,0.0,3,1,8.0,77777,9,999999999,320,0.0920,0,88,999.000,999.0,99.0
+1989,8,11,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,16.1,69,99700,99,1230,365,39,152,24,3900,7000,3300,420,270,2.6,1,1,8.0,77777,9,999999999,279,0.0920,0,88,999.000,999.0,99.0
+1989,8,11,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,16.7,81,99700,0,0,349,0,0,0,0,0,0,0,260,1.5,0,0,8.0,77777,9,999999999,290,0.0920,0,88,999.000,999.0,99.0
+1989,8,11,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,16.7,87,99800,0,0,343,0,0,0,0,0,0,0,0,0.0,0,0,8.0,77777,9,999999999,290,0.0920,0,88,999.000,999.0,99.0
+1989,8,11,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,16.7,93,99800,0,0,345,0,0,0,0,0,0,0,0,0.0,1,1,8.0,77777,9,999999999,290,0.0920,0,88,999.000,999.0,99.0
+1989,8,11,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,16.7,93,99800,0,0,358,0,0,0,0,0,0,0,0,0.0,5,5,6.4,77777,9,999999999,290,0.0920,0,88,999.000,999.0,99.0
+1989,8,11,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,17.2,93,99800,0,0,359,0,0,0,0,0,0,0,0,0.0,8,4,6.4,77777,9,999999999,300,0.0920,0,88,999.000,999.0,99.0
+1989,8,12,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,15.0,87,99700,0,0,351,0,0,0,0,0,0,0,300,1.5,9,4,6.4,77777,9,999999999,259,0.0920,0,88,999.000,999.0,99.0
+1989,8,12,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,16.1,93,99700,0,0,352,0,0,0,0,0,0,0,0,0.0,9,4,6.4,77777,9,999999999,279,0.0920,0,88,999.000,999.0,99.0
+1989,8,12,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,16.1,93,99700,0,0,349,0,0,0,0,0,0,0,210,2.1,8,3,6.4,77777,9,999999999,279,0.0920,0,88,999.000,999.0,99.0
+1989,8,12,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,15.0,93,99800,0,0,339,0,0,0,0,0,0,0,230,1.5,7,2,6.4,77777,9,999999999,259,0.0920,0,88,999.000,999.0,99.0
+1989,8,12,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,15.6,93,99800,0,55,338,0,0,0,0,0,0,0,0,0.0,6,1,4.8,77777,9,999999999,270,0.0920,0,88,999.000,999.0,99.0
+1989,8,12,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,12.8,81,99800,123,1330,332,29,8,28,3100,500,3100,680,220,2.1,6,1,4.8,77777,9,999999999,229,0.3880,0,88,999.000,999.0,99.0
+1989,8,12,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,16.7,81,99800,368,1330,349,162,191,108,17000,16700,12400,2150,170,3.1,2,0,4.8,77777,9,999999999,290,0.3880,0,88,999.000,999.0,99.0
+1989,8,12,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,17.2,69,99800,607,1330,365,341,375,168,36500,38200,19000,3600,170,2.6,0,0,6.4,77777,9,999999999,300,0.3880,0,88,999.000,999.0,99.0
+1989,8,12,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,16.7,60,99800,820,1330,373,528,493,221,55600,50600,24300,5370,180,3.6,0,0,6.4,77777,9,999999999,290,0.3880,0,88,999.000,999.0,99.0
+1989,8,12,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,16.1,54,99800,993,1330,378,687,569,259,73300,59200,29000,8060,150,2.1,0,0,6.4,77777,9,999999999,279,0.3880,0,88,999.000,999.0,99.0
+1989,8,12,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,15.6,49,99800,1114,1330,395,771,544,312,82200,56800,34500,12860,140,2.6,2,2,6.4,77777,9,999999999,270,0.3880,0,88,999.000,999.0,99.0
+1989,8,12,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,15.0,49,99700,1175,1330,399,775,483,346,82500,50400,37900,17310,180,3.1,4,4,8.0,77777,9,999999999,259,0.3880,0,88,999.000,999.0,99.0
+1989,8,12,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,15.6,46,99700,1171,1330,408,767,436,381,80900,45400,40800,18910,360,5.2,4,4,8.0,77777,9,999999999,270,0.3880,0,88,999.000,999.0,99.0
+1989,8,12,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,17.2,76,99600,1103,1330,412,534,112,440,58700,11600,49100,17840,330,4.1,10,10,8.0,1520,9,999999999,300,0.3880,0,88,999.000,999.0,99.0
+1989,8,12,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,16.1,76,99600,975,1330,385,402,182,268,44600,19400,30400,8510,270,5.2,8,8,8.0,2440,9,999999999,279,0.3880,0,88,999.000,999.0,99.0
+1989,8,12,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,18.3,84,99500,797,1330,384,379,188,265,41300,19700,29500,7150,280,5.2,8,7,8.0,7620,9,999999999,320,0.3880,0,88,999.000,999.0,99.0
+1989,8,12,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,15.6,76,99500,579,1330,390,220,44,201,24100,4300,22300,5610,170,1.5,10,9,8.0,7620,9,999999999,270,0.3880,0,88,999.000,999.0,99.0
+1989,8,12,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,16.1,78,99500,338,1330,401,77,1,77,8800,0,8800,2860,130,3.1,10,10,9.7,7620,9,999999999,279,0.3880,0,88,999.000,999.0,99.0
+1989,8,12,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,14.4,68,99500,95,1208,391,29,1,29,3200,0,3200,930,130,3.1,10,9,9.7,7620,9,999999999,250,0.3880,0,88,999.000,999.0,99.0
+1989,8,12,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,15.6,81,99400,0,0,357,0,0,0,0,0,0,0,320,2.6,8,3,9.7,77777,9,999999999,270,0.3880,0,88,999.000,999.0,99.0
+1989,8,12,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,14.4,78,99500,0,0,353,0,0,0,0,0,0,0,320,2.6,3,3,9.7,77777,9,999999999,250,0.3880,0,88,999.000,999.0,99.0
+1989,8,12,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,15.0,84,99500,0,0,347,0,0,0,0,0,0,0,330,3.1,4,2,9.7,77777,9,999999999,259,0.3880,0,88,999.000,999.0,99.0
+1989,8,12,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,15.0,90,99500,0,0,338,0,0,0,0,0,0,0,240,2.1,2,1,9.7,77777,9,999999999,259,0.3880,0,88,999.000,999.0,99.0
+1989,8,12,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,15.0,90,99500,0,0,338,0,0,0,0,0,0,0,320,3.1,2,1,9.7,77777,9,999999999,259,0.3880,0,88,999.000,999.0,99.0
+1989,8,13,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,13.9,84,99400,0,0,330,0,0,0,0,0,0,0,300,2.1,2,0,11.3,77777,9,999999999,250,0.3880,0,88,999.000,999.0,99.0
+1989,8,13,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,13.9,90,99400,0,0,325,0,0,0,0,0,0,0,0,0.0,2,0,11.3,77777,9,999999999,250,0.3880,0,88,999.000,999.0,99.0
+1989,8,13,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,13.9,87,99400,0,0,338,0,0,0,0,0,0,0,300,1.5,5,2,11.3,77777,9,999999999,250,0.3880,0,88,999.000,999.0,99.0
+1989,8,13,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,13.9,90,99400,0,0,339,0,0,0,0,0,0,0,0,0.0,7,3,11.3,77777,9,999999999,250,0.3880,0,88,999.000,999.0,99.0
+1989,8,13,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,13.3,90,99400,0,11,328,0,0,0,0,0,0,0,260,2.1,9,1,6.4,77777,9,999999999,240,0.3880,0,88,999.000,999.0,99.0
+1989,8,13,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,13.3,84,99400,119,1331,327,39,69,32,4200,3600,3800,670,290,2.1,2,0,6.4,77777,9,999999999,240,0.1970,0,88,999.000,999.0,99.0
+1989,8,13,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,16.1,87,99400,365,1331,340,186,390,78,19600,33400,10400,1420,270,2.1,0,0,6.4,77777,9,999999999,279,0.1970,0,88,999.000,999.0,99.0
+1989,8,13,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,16.7,73,99500,604,1331,357,377,570,116,39000,55100,13900,2340,280,3.6,0,0,9.7,77777,9,999999999,290,0.1970,0,88,999.000,999.0,99.0
+1989,8,13,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,17.2,66,99500,817,1331,368,564,673,146,59000,67800,17300,3530,280,3.6,0,0,9.7,77777,9,999999999,300,0.1970,0,88,999.000,999.0,99.0
+1989,8,13,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,16.1,58,99500,990,1331,372,723,738,169,76600,75300,20400,5250,270,3.1,0,0,9.7,77777,9,999999999,279,0.1970,0,88,999.000,999.0,99.0
+1989,8,13,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,16.7,54,99400,1111,1331,381,834,774,182,86000,77400,21200,6540,270,3.6,0,0,9.7,77777,9,999999999,290,0.1970,0,88,999.000,999.0,99.0
+1989,8,13,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,17.8,56,99400,1172,1331,385,883,782,189,91500,78400,22300,8300,260,2.1,0,0,9.7,77777,9,999999999,309,0.1970,0,88,999.000,999.0,99.0
+1989,8,13,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,18.9,57,99300,1168,1331,409,762,531,293,82400,55600,33500,14180,260,3.1,3,3,9.7,77777,9,999999999,329,0.1970,0,88,999.000,999.0,99.0
+1989,8,13,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,17.8,56,99300,1100,1331,398,748,564,279,80500,58900,31700,10980,270,4.1,8,2,9.7,77777,9,999999999,309,0.1970,0,88,999.000,999.0,99.0
+1989,8,13,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,17.2,54,99200,971,1331,404,537,381,257,57200,39600,28200,7700,260,4.6,4,4,9.7,77777,9,999999999,300,0.1970,0,88,999.000,999.0,99.0
+1989,8,13,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,16.7,51,99200,792,1331,407,479,440,215,50400,45000,23600,5080,270,4.1,4,4,9.7,77777,9,999999999,290,0.1970,0,88,999.000,999.0,99.0
+1989,8,13,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,16.1,54,99200,575,1331,394,310,240,205,33400,23900,23000,4890,260,3.1,10,3,9.7,77777,9,999999999,279,0.1970,0,88,999.000,999.0,99.0
+1989,8,13,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,16.7,58,99200,333,1331,434,52,5,51,6100,200,6100,2060,260,7.7,10,10,11.3,1310,9,999999999,290,0.1970,0,88,999.000,999.0,99.0
+1989,8,13,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,18.3,93,99300,90,1187,401,15,1,15,1800,0,1800,560,190,1.5,10,10,8.0,1070,9,999999999,320,0.1970,0,88,999.000,999.0,99.0
+1989,8,13,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,18.3,90,99200,0,0,404,0,0,0,0,0,0,0,230,2.6,10,10,9.7,1520,9,999999999,320,0.1970,0,88,999.000,999.0,99.0
+1989,8,13,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,17.2,84,99200,0,0,392,0,0,0,0,0,0,0,280,2.6,9,9,9.7,7620,9,999999999,300,0.1970,0,88,999.000,999.0,99.0
+1989,8,13,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,16.7,76,99200,0,0,408,0,0,0,0,0,0,0,310,2.6,10,10,9.7,7620,9,999999999,290,0.1970,0,88,999.000,999.0,99.0
+1989,8,13,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,15.6,71,99200,0,0,396,0,0,0,0,0,0,0,300,3.6,10,9,9.7,7620,9,999999999,270,0.1970,0,88,999.000,999.0,99.0
+1989,8,13,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,15.6,71,99300,0,0,407,0,0,0,0,0,0,0,300,4.1,10,10,9.7,2440,9,999999999,270,0.1970,0,88,999.000,999.0,99.0
+1989,8,14,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,16.7,76,99200,0,0,408,0,0,0,0,0,0,0,300,3.6,10,10,9.7,2290,9,999999999,290,0.1970,0,88,999.000,999.0,99.0
+1989,8,14,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,16.7,76,99200,0,0,408,0,0,0,0,0,0,0,270,3.6,10,10,9.7,2130,9,999999999,290,0.1970,0,88,999.000,999.0,99.0
+1989,8,14,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,16.7,76,99200,0,0,408,0,0,0,0,0,0,0,270,2.6,10,10,11.3,2290,9,999999999,290,0.1970,0,88,999.000,999.0,99.0
+1989,8,14,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,17.2,84,99200,0,0,403,0,0,0,0,0,0,0,280,2.1,10,10,11.3,3050,9,999999999,300,0.1970,0,88,999.000,999.0,99.0
+1989,8,14,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,17.2,87,99200,0,0,400,0,0,0,0,0,0,0,0,0.0,10,10,6.4,2740,9,999999999,300,0.1970,0,88,999.000,999.0,99.0
+1989,8,14,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,16.1,81,99200,115,1320,398,25,1,25,2800,0,2800,870,290,3.1,10,10,6.4,3050,9,999999999,279,0.1330,0,88,999.000,999.0,99.0
+1989,8,14,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,17.2,79,99200,361,1331,409,82,1,82,9400,0,9300,3080,280,4.1,10,10,6.4,2740,9,999999999,300,0.1330,0,88,999.000,999.0,99.0
+1989,8,14,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,17.2,79,99200,600,1331,409,176,1,175,19900,100,19900,6820,290,4.1,10,10,6.4,2740,9,999999999,300,0.1330,0,88,999.000,999.0,99.0
+1989,8,14,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,18.3,79,99100,814,1331,416,237,0,237,27300,0,27300,10060,210,6.2,10,10,6.4,3660,9,999999999,320,0.1330,0,88,999.000,999.0,99.0
+1989,8,14,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,18.9,69,99100,987,1331,421,334,111,251,37300,11900,28400,8090,220,5.2,9,9,6.4,3660,9,999999999,329,0.1330,0,88,999.000,999.0,99.0
+1989,8,14,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,19.4,69,99100,1109,1331,425,481,89,406,53000,9200,45300,16840,230,6.7,9,9,6.4,3660,9,999999999,340,0.1330,0,88,999.000,999.0,99.0
+1989,8,14,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,19.4,69,99100,1169,1331,425,331,119,225,37700,12900,26400,9920,270,6.7,9,9,6.4,3660,9,999999999,340,0.1330,0,88,999.000,999.0,99.0
+1989,8,14,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,16.1,62,99100,1165,1331,423,328,3,325,38900,300,38600,14850,250,5.7,10,10,9.7,2130,9,999999999,279,0.1330,0,88,999.000,999.0,99.0
+1989,8,14,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,17.8,71,99100,1096,1331,422,402,45,364,44300,4600,40500,15120,260,6.2,10,10,9.7,3050,9,999999999,309,0.1330,0,88,999.000,999.0,99.0
+1989,8,14,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,16.1,78,99100,968,1331,401,149,3,147,18300,200,18100,7430,230,4.1,10,10,9.7,2440,9,999999999,279,0.1330,0,88,999.000,999.0,99.0
+1989,8,14,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,17.8,90,99100,788,1331,400,247,9,241,28200,800,27800,9980,190,2.6,10,10,11.3,3050,9,999999999,309,0.1330,0,88,999.000,999.0,99.0
+1989,8,14,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,18.3,87,99000,570,1331,408,152,1,152,17400,100,17300,6010,230,2.1,10,10,11.3,3050,9,999999999,320,0.1330,0,88,999.000,999.0,99.0
+1989,8,14,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,17.8,87,99000,328,1331,404,42,2,42,5000,100,5000,1730,220,2.6,10,10,11.3,3050,9,999999999,309,0.1330,0,88,999.000,999.0,99.0
+1989,8,14,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,19.4,97,99000,85,1143,406,13,0,13,1500,0,1500,490,190,2.6,10,10,8.0,700,9,999999999,340,0.1330,0,88,999.000,999.0,99.0
+1989,8,14,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,19.4,97,99000,0,0,394,0,0,0,0,0,0,0,190,3.1,10,9,9.7,3050,9,999999999,340,0.1330,0,88,999.000,999.0,99.0
+1989,8,14,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,18.3,93,99000,0,0,401,0,0,0,0,0,0,0,180,2.6,10,10,9.7,210,9,999999999,320,0.1330,0,88,999.000,999.0,99.0
+1989,8,14,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,11.7,61,99000,0,0,393,0,0,0,0,0,0,0,200,2.6,10,10,9.7,180,9,999999999,209,0.1330,0,88,999.000,999.0,99.0
+1989,8,14,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,16.1,90,99000,0,0,361,0,0,0,0,0,0,0,220,2.1,6,6,12.9,2290,9,999999999,279,0.1330,0,88,999.000,999.0,99.0
+1989,8,14,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,15.6,90,99000,0,0,349,0,0,0,0,0,0,0,240,2.6,3,3,12.9,77777,9,999999999,270,0.1330,0,88,999.000,999.0,99.0
+1989,8,15,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,14.4,84,98900,0,0,344,0,0,0,0,0,0,0,220,2.6,2,2,12.9,77777,9,999999999,250,0.1330,0,88,999.000,999.0,99.0
+1989,8,15,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,16.7,97,98900,0,0,358,0,0,0,0,0,0,0,240,2.1,6,6,12.9,3660,9,999999999,290,0.1330,0,88,999.000,999.0,99.0
+1989,8,15,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,16.1,93,98900,0,0,376,0,0,0,0,0,0,0,240,2.1,9,9,8.0,3350,9,999999999,279,0.1330,0,88,999.000,999.0,99.0
+1989,8,15,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,16.1,97,98900,0,0,359,0,0,0,0,0,0,0,0,0.0,7,7,8.0,3350,9,999999999,279,0.1330,0,88,999.000,999.0,99.0
+1989,8,15,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,17.2,97,99000,0,0,391,0,0,0,0,0,0,0,210,2.6,10,10,4.8,610,9,999999999,300,0.1330,0,88,999.000,999.0,99.0
+1989,8,15,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,16.1,87,99000,111,1299,392,23,1,23,2600,0,2600,810,250,2.6,10,10,4.8,370,9,999999999,279,0.1150,0,88,999.000,999.0,99.0
+1989,8,15,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,18.3,93,99000,357,1332,390,66,35,57,7300,3000,6500,1620,300,3.6,9,9,4.8,3660,9,999999999,320,0.1150,0,88,999.000,999.0,99.0
+1989,8,15,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,18.3,87,99000,597,1332,382,202,55,178,22300,5400,19800,5200,310,3.6,8,7,4.8,3050,9,999999999,320,0.1150,0,88,999.000,999.0,99.0
+1989,8,15,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,19.4,84,99000,811,1332,398,418,237,272,45500,24800,30300,7420,290,3.1,8,8,4.8,180,9,999999999,340,0.1150,0,88,999.000,999.0,99.0
+1989,8,15,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,18.9,74,99000,985,1332,406,378,135,277,41900,14400,31200,8890,300,3.1,9,8,4.8,430,9,999999999,329,0.1150,0,88,999.000,999.0,99.0
+1989,8,15,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,18.9,74,99000,1106,1332,406,558,244,354,60900,26500,38900,13580,350,4.6,9,8,4.8,640,9,999999999,329,0.1150,0,88,999.000,999.0,99.0
+1989,8,15,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,18.9,71,99000,1166,1332,409,464,134,346,51600,14400,39000,15140,40,6.2,9,8,6.4,980,9,999999999,329,0.1150,0,88,999.000,999.0,99.0
+1989,8,15,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,17.8,74,99000,1162,1332,419,273,7,267,32900,600,32400,12780,30,7.2,10,10,6.4,1400,9,999999999,309,0.1150,0,88,999.000,999.0,99.0
+1989,8,15,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,18.9,79,99000,1093,1332,409,469,214,292,51900,23300,32700,10650,50,6.7,9,9,6.4,580,9,999999999,329,0.1150,0,88,999.000,999.0,99.0
+1989,8,15,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,18.3,76,99000,964,1332,420,332,2,331,38200,200,38100,13900,10,5.2,10,10,9.7,1310,9,999999999,320,0.1150,0,88,999.000,999.0,99.0
+1989,8,15,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,18.9,76,99000,784,1332,412,240,66,200,26300,6600,22400,6700,30,5.2,9,9,9.7,1220,9,999999999,329,0.1150,0,88,999.000,999.0,99.0
+1989,8,15,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,17.2,76,99000,565,1332,392,272,137,213,29200,13600,23400,5060,40,7.7,8,8,11.3,1310,9,999999999,300,0.1150,0,88,999.000,999.0,99.0
+1989,8,15,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,16.7,79,99000,323,1332,394,95,21,90,10400,1800,10000,2300,40,6.2,9,9,11.3,700,9,999999999,290,0.1150,0,88,999.000,999.0,99.0
+1989,8,15,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,16.1,78,99000,81,1121,401,8,1,7,900,0,900,280,40,6.7,10,10,12.9,490,9,999999999,279,0.1150,0,88,999.000,999.0,99.0
+1989,8,15,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,16.1,78,99000,0,0,401,0,0,0,0,0,0,0,90,5.2,10,10,11.3,520,9,999999999,279,0.1150,0,88,999.000,999.0,99.0
+1989,8,15,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,15.6,78,99100,0,0,398,0,0,0,0,0,0,0,60,4.1,10,10,12.9,1130,9,999999999,270,0.1150,0,88,999.000,999.0,99.0
+1989,8,15,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,15.6,81,99100,0,0,366,0,0,0,0,0,0,0,50,3.1,6,6,12.9,730,9,999999999,270,0.1150,0,88,999.000,999.0,99.0
+1989,8,15,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,15.6,84,99100,0,0,339,0,0,0,0,0,0,0,110,2.1,0,0,12.9,77777,9,999999999,270,0.1150,0,88,999.000,999.0,99.0
+1989,8,15,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,15.6,90,99200,0,0,357,0,0,0,0,0,0,0,30,3.1,6,6,12.9,610,9,999999999,270,0.1150,0,88,999.000,999.0,99.0
+1989,8,16,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,14.4,90,99100,0,0,339,0,0,0,0,0,0,0,340,2.1,2,2,12.9,77777,9,999999999,250,0.1150,0,88,999.000,999.0,99.0
+1989,8,16,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,13.9,93,99100,0,0,322,0,0,0,0,0,0,0,310,1.5,0,0,12.9,77777,9,999999999,240,0.1150,0,88,999.000,999.0,99.0
+1989,8,16,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,13.3,90,99200,0,0,322,0,0,0,0,0,0,0,0,0.0,0,0,12.9,77777,9,999999999,240,0.1150,0,88,999.000,999.0,99.0
+1989,8,16,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,13.9,93,99200,0,0,342,0,0,0,0,0,0,0,290,2.1,7,5,9.7,7620,9,999999999,240,0.1150,0,88,999.000,999.0,99.0
+1989,8,16,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,12.8,87,99200,0,0,340,0,0,0,0,0,0,0,290,2.1,8,5,6.4,7620,9,999999999,229,0.1150,0,88,999.000,999.0,99.0
+1989,8,16,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,12.8,84,99200,108,1277,356,31,11,30,3400,700,3300,710,330,3.1,9,8,6.4,640,9,999999999,229,0.1100,0,88,999.000,999.0,99.0
+1989,8,16,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,13.9,78,99300,354,1332,376,80,39,69,8700,3400,7800,1910,310,3.6,10,9,6.4,580,9,999999999,250,0.1100,0,88,999.000,999.0,99.0
+1989,8,16,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,15.6,81,99300,594,1332,384,208,1,208,23300,100,23200,7540,330,4.6,9,9,6.4,6100,9,999999999,270,0.1100,0,88,999.000,999.0,99.0
+1989,8,16,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,15.0,71,99300,808,1332,378,292,111,223,32100,11700,25000,6060,340,4.1,9,7,11.3,6100,9,999999999,259,0.1100,0,88,999.000,999.0,99.0
+1989,8,16,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,13.9,61,99300,982,1332,372,539,346,281,58800,37400,31100,8460,20,4.1,8,4,12.9,77777,9,999999999,240,0.1100,0,88,999.000,999.0,99.0
+1989,8,16,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,13.9,59,99300,1103,1332,385,653,479,254,71000,50100,29400,10000,30,4.6,9,7,12.9,1220,9,999999999,240,0.1100,0,88,999.000,999.0,99.0
+1989,8,16,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,13.3,59,99300,1163,1332,382,698,431,318,74700,45000,35300,15150,40,3.6,8,7,12.9,1680,9,999999999,240,0.1100,0,88,999.000,999.0,99.0
+1989,8,16,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,15.0,60,99300,1159,1332,381,771,531,305,82800,55500,34400,14280,20,4.1,8,4,16.1,77777,9,999999999,259,0.1100,0,88,999.000,999.0,99.0
+1989,8,16,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,15.0,62,99300,1089,1332,389,703,555,246,73500,56000,27500,9140,30,5.2,7,7,12.9,1010,9,999999999,259,0.1100,0,88,999.000,999.0,99.0
+1989,8,16,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,14.4,58,99300,960,1332,374,669,694,165,70800,70700,19800,4850,50,5.7,5,2,11.3,77777,9,999999999,259,0.1100,0,88,999.000,999.0,99.0
+1989,8,16,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,13.3,55,99300,779,1332,370,516,665,123,54500,67000,15100,2910,40,4.6,3,2,12.9,77777,9,999999999,240,0.1100,0,88,999.000,999.0,99.0
+1989,8,16,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,13.9,59,99300,560,1332,368,348,585,99,36000,56000,12400,1980,80,4.1,2,2,12.9,77777,9,999999999,240,0.1100,0,88,999.000,999.0,99.0
+1989,8,16,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,14.4,66,99300,318,1332,363,163,424,59,16500,34700,8200,1080,60,4.6,2,2,16.1,77777,9,999999999,250,0.1100,0,88,999.000,999.0,99.0
+1989,8,16,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,14.4,68,99300,76,1077,360,32,105,22,3100,4500,2800,390,60,4.1,2,2,12.9,77777,9,999999999,250,0.1100,0,88,999.000,999.0,99.0
+1989,8,16,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,14.4,73,99300,0,0,354,0,0,0,0,0,0,0,60,3.6,2,2,16.1,77777,9,999999999,250,0.1100,0,88,999.000,999.0,99.0
+1989,8,16,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,14.4,78,99400,0,0,344,0,0,0,0,0,0,0,30,2.6,1,1,16.1,77777,9,999999999,250,0.1100,0,88,999.000,999.0,99.0
+1989,8,16,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,14.4,81,99400,0,0,342,0,0,0,0,0,0,0,20,2.6,1,1,16.1,77777,9,999999999,250,0.1100,0,88,999.000,999.0,99.0
+1989,8,16,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,10.0,72,99400,0,0,318,0,0,0,0,0,0,0,0,0.0,0,0,16.1,77777,9,999999999,189,0.1100,0,88,999.000,999.0,99.0
+1989,8,16,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,8.3,69,99500,0,0,312,0,0,0,0,0,0,0,340,2.1,0,0,16.1,77777,9,999999999,179,0.1100,0,88,999.000,999.0,99.0
+1989,8,17,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,8.3,67,99500,0,0,314,0,0,0,0,0,0,0,0,0.0,0,0,16.1,77777,9,999999999,179,0.1100,0,88,999.000,999.0,99.0
+1989,8,17,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,8.3,67,99500,0,0,314,0,0,0,0,0,0,0,330,2.1,0,0,16.1,77777,9,999999999,179,0.1100,0,88,999.000,999.0,99.0
+1989,8,17,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,8.9,75,99500,0,0,310,0,0,0,0,0,0,0,280,2.1,0,0,16.1,77777,9,999999999,179,0.1100,0,88,999.000,999.0,99.0
+1989,8,17,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,7.2,72,99600,0,0,303,0,0,0,0,0,0,0,330,1.5,0,0,11.3,77777,9,999999999,170,0.1100,0,88,999.000,999.0,99.0
+1989,8,17,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,7.2,72,99700,0,0,303,0,0,0,0,0,0,0,330,1.5,0,0,11.3,77777,9,999999999,170,0.1100,0,88,999.000,999.0,99.0
+1989,8,17,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,8.9,72,99700,104,1255,312,31,9,30,3400,600,3300,710,340,3.1,0,0,9.7,77777,9,999999999,179,0.3730,0,88,999.000,999.0,99.0
+1989,8,17,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,9.4,61,99700,350,1333,347,100,69,82,11000,6000,9500,1800,350,3.1,5,5,11.3,77777,9,999999999,189,0.3730,0,88,999.000,999.0,99.0
+1989,8,17,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,15.6,78,99800,591,1333,344,332,383,161,34600,37500,17900,3270,20,2.6,0,0,11.3,77777,9,999999999,270,0.3730,0,88,999.000,999.0,99.0
+1989,8,17,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,16.1,71,99800,805,1333,371,472,349,259,50500,37100,28100,6520,50,4.1,3,3,16.1,77777,9,999999999,279,0.3730,0,88,999.000,999.0,99.0
+1989,8,17,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,15.6,62,99800,979,1333,382,669,495,302,70100,51300,32300,9260,60,4.6,4,4,16.1,77777,9,999999999,270,0.3730,0,88,999.000,999.0,99.0
+1989,8,17,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,14.4,56,99800,1100,1333,381,733,503,314,77900,52500,34500,12410,50,5.2,3,3,16.1,77777,9,999999999,259,0.3730,0,88,999.000,999.0,99.0
+1989,8,17,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,12.2,45,99800,1160,1333,380,832,576,327,88800,60200,36300,15420,70,6.7,2,2,16.1,77777,9,999999999,220,0.3730,0,88,999.000,999.0,99.0
+1989,8,17,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,11.7,42,99800,1155,1333,382,796,539,325,85000,56300,36000,15080,80,6.2,2,2,12.9,77777,9,999999999,220,0.3730,0,88,999.000,999.0,99.0
+1989,8,17,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,12.2,45,99800,1086,1333,383,760,521,332,80100,54300,35800,12710,60,7.2,3,3,11.3,77777,9,999999999,220,0.3730,0,88,999.000,999.0,99.0
+1989,8,17,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,12.8,48,99800,956,1333,377,650,561,244,69300,58300,27400,7080,50,6.2,2,2,11.3,77777,9,999999999,229,0.3730,0,88,999.000,999.0,99.0
+1989,8,17,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,12.2,48,99800,775,1333,362,495,491,206,52000,50100,22800,4770,40,5.2,0,0,11.3,77777,9,999999999,220,0.3730,0,88,999.000,999.0,99.0
+1989,8,17,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,11.7,50,99800,555,1333,356,303,358,152,32300,35800,17400,3170,50,6.7,0,0,11.3,77777,9,999999999,220,0.3730,0,88,999.000,999.0,99.0
+1989,8,17,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,12.8,57,99800,312,1333,352,127,162,88,13300,13100,10200,1710,30,5.2,0,0,16.1,77777,9,999999999,229,0.3730,0,88,999.000,999.0,99.0
+1989,8,17,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,13.3,63,99800,72,1055,348,25,4,25,2800,0,2800,810,30,4.6,0,0,16.1,77777,9,999999999,240,0.3730,0,88,999.000,999.0,99.0
+1989,8,17,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,14.4,76,99800,0,0,341,0,0,0,0,0,0,0,30,3.6,0,0,16.1,77777,9,999999999,259,0.3730,0,88,999.000,999.0,99.0
+1989,8,17,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,14.4,78,99800,0,0,338,0,0,0,0,0,0,0,30,2.6,0,0,16.1,77777,9,999999999,250,0.3730,0,88,999.000,999.0,99.0
+1989,8,17,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,13.9,78,99900,0,0,335,0,0,0,0,0,0,0,30,3.1,0,0,16.1,77777,9,999999999,250,0.3730,0,88,999.000,999.0,99.0
+1989,8,17,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,13.3,81,99900,0,0,329,0,0,0,0,0,0,0,320,1.5,0,0,16.1,77777,9,999999999,240,0.3730,0,88,999.000,999.0,99.0
+1989,8,17,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,10.6,65,100000,0,0,329,0,0,0,0,0,0,0,350,3.1,0,0,16.1,77777,9,999999999,200,0.3730,0,88,999.000,999.0,99.0
+1989,8,18,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,7.2,60,100000,0,0,315,0,0,0,0,0,0,0,310,1.5,0,0,16.1,77777,9,999999999,170,0.3730,0,88,999.000,999.0,99.0
+1989,8,18,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,11.7,87,100000,0,0,315,0,0,0,0,0,0,0,350,2.6,0,0,16.1,77777,9,999999999,220,0.3730,0,88,999.000,999.0,99.0
+1989,8,18,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,11.7,90,100000,0,0,313,0,0,0,0,0,0,0,270,2.1,0,0,16.1,77777,9,999999999,220,0.3730,0,88,999.000,999.0,99.0
+1989,8,18,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,12.2,93,100000,0,0,313,0,0,0,0,0,0,0,320,2.1,0,0,14.5,77777,9,999999999,220,0.3730,0,88,999.000,999.0,99.0
+1989,8,18,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,12.2,93,100000,0,0,313,0,0,0,0,0,0,0,350,2.1,0,0,14.5,77777,9,999999999,220,0.3730,0,88,999.000,999.0,99.0
+1989,8,18,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,11.7,84,100000,100,1233,317,43,208,23,4200,10800,3200,410,340,2.1,0,0,12.9,77777,9,999999999,220,0.0820,0,88,999.000,999.0,99.0
+1989,8,18,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,12.2,68,100100,347,1333,336,201,577,48,20400,49600,7500,940,10,2.6,0,0,12.9,77777,9,999999999,220,0.0820,0,88,999.000,999.0,99.0
+1989,8,18,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,11.7,57,100100,587,1333,346,398,736,69,41600,71300,10100,1490,60,3.6,0,0,16.1,77777,9,999999999,220,0.0820,0,88,999.000,999.0,99.0
+1989,8,18,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,15.6,64,100100,802,1333,373,548,719,111,56900,71500,13700,2520,60,4.1,2,2,16.1,77777,9,999999999,270,0.0820,0,88,999.000,999.0,99.0
+1989,8,18,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,15.0,58,100100,976,1333,378,681,765,115,72300,77400,15500,3390,70,4.6,2,2,16.1,77777,9,999999999,270,0.0820,0,88,999.000,999.0,99.0
+1989,8,18,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,12.2,45,100000,1097,1333,380,808,816,130,86100,82800,17800,4860,70,5.2,2,2,16.1,77777,9,999999999,220,0.0820,0,88,999.000,999.0,99.0
+1989,8,18,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,12.8,47,100000,1157,1333,380,856,813,145,91100,82400,19300,6350,90,3.6,2,2,16.1,77777,9,999999999,229,0.0820,0,88,999.000,999.0,99.0
+1989,8,18,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,12.8,47,100000,1152,1333,375,846,832,120,86600,83400,14400,4380,100,4.6,1,1,16.1,77777,9,999999999,229,0.0820,0,88,999.000,999.0,99.0
+1989,8,18,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,12.2,47,100000,1082,1333,372,779,832,98,80300,83400,12500,3220,70,4.6,1,1,16.1,77777,9,999999999,229,0.0820,0,88,999.000,999.0,99.0
+1989,8,18,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,12.2,47,99900,952,1333,365,691,823,97,71100,82100,12400,2470,100,4.6,0,0,16.1,77777,9,999999999,229,0.0820,0,88,999.000,999.0,99.0
+1989,8,18,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,12.2,47,99900,770,1333,365,551,799,84,58500,80000,12200,2030,60,4.6,0,0,16.1,77777,9,999999999,229,0.0820,0,88,999.000,999.0,99.0
+1989,8,18,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,10.6,45,99900,550,1333,357,367,719,66,38200,68900,9700,1400,70,5.7,0,0,16.1,77777,9,999999999,200,0.0820,0,88,999.000,999.0,99.0
+1989,8,18,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,10.6,48,99800,307,1333,352,171,539,45,17700,44000,7600,850,100,4.1,0,0,16.1,77777,9,999999999,200,0.0820,0,88,999.000,999.0,99.0
+1989,8,18,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,11.1,55,99800,67,1011,345,34,143,20,3200,5900,2800,350,80,5.2,0,0,16.1,77777,9,999999999,209,0.0820,0,88,999.000,999.0,99.0
+1989,8,18,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,12.8,66,99700,0,0,341,0,0,0,0,0,0,0,110,4.1,0,0,16.1,77777,9,999999999,229,0.0820,0,88,999.000,999.0,99.0
+1989,8,18,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,12.8,70,99700,0,0,336,0,0,0,0,0,0,0,130,2.1,0,0,16.1,77777,9,999999999,229,0.0820,0,88,999.000,999.0,99.0
+1989,8,18,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,13.3,73,99700,0,0,337,0,0,0,0,0,0,0,120,3.1,0,0,16.1,77777,9,999999999,240,0.0820,0,88,999.000,999.0,99.0
+1989,8,18,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,13.9,87,99700,0,0,327,0,0,0,0,0,0,0,130,1.5,0,0,16.1,77777,9,999999999,250,0.0820,0,88,999.000,999.0,99.0
+1989,8,18,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,13.3,84,99700,0,0,327,0,0,0,0,0,0,0,120,2.1,0,0,16.1,77777,9,999999999,240,0.0820,0,88,999.000,999.0,99.0
+1989,8,19,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,13.3,93,99600,0,0,319,0,0,0,0,0,0,0,280,1.5,0,0,16.1,77777,9,999999999,240,0.0820,0,88,999.000,999.0,99.0
+1989,8,19,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,12.8,93,99600,0,0,316,0,0,0,0,0,0,0,180,1.5,0,0,16.1,77777,9,999999999,229,0.0820,0,88,999.000,999.0,99.0
+1989,8,19,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,12.8,93,99600,0,0,316,0,0,0,0,0,0,0,0,0.0,0,0,16.1,77777,9,999999999,229,0.0820,0,88,999.000,999.0,99.0
+1989,8,19,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,12.8,97,99600,0,0,314,0,0,0,0,0,0,0,0,0.0,0,0,16.1,77777,9,999999999,229,0.0820,0,88,999.000,999.0,99.0
+1989,8,19,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,13.3,97,99500,0,0,317,0,0,0,0,0,0,0,170,1.5,0,0,9.7,77777,9,999999999,240,0.0820,0,88,999.000,999.0,99.0
+1989,8,19,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,13.3,93,99500,97,1212,319,33,59,27,3500,3000,3300,560,150,2.6,0,0,9.7,77777,9,999999999,240,0.1920,0,88,999.000,999.0,99.0
+1989,8,19,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,14.4,81,99500,343,1334,336,171,375,73,18000,31400,9900,1330,160,4.1,0,0,9.7,77777,9,999999999,250,0.1920,0,88,999.000,999.0,99.0
+1989,8,19,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,15.0,71,99500,584,1334,349,365,573,111,37600,55100,13500,2210,170,3.6,0,0,9.7,77777,9,999999999,259,0.1920,0,88,999.000,999.0,99.0
+1989,8,19,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,15.6,64,99400,799,1334,361,553,680,142,58000,68300,16900,3370,210,3.6,0,0,9.7,77777,9,999999999,270,0.1920,0,88,999.000,999.0,99.0
+1989,8,19,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,14.4,54,99400,973,1334,383,651,670,158,69200,68500,19100,4760,180,3.1,4,3,12.9,77777,9,999999999,250,0.1920,0,88,999.000,999.0,99.0
+1989,8,19,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,13.9,50,99300,1094,1334,382,753,541,305,80100,56400,33700,11830,180,3.6,8,2,12.9,77777,9,999999999,240,0.1920,0,88,999.000,999.0,99.0
+1989,8,19,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,13.9,49,99200,1154,1334,392,804,640,245,84500,64900,28200,10980,170,4.1,10,4,12.9,77777,9,999999999,250,0.1920,0,88,999.000,999.0,99.0
+1989,8,19,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,13.9,49,99200,1149,1334,409,637,317,362,69800,34400,40000,15330,170,5.7,10,8,12.9,7620,9,999999999,250,0.1920,0,88,999.000,999.0,99.0
+1989,8,19,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,15.0,51,99100,1078,1334,407,624,383,312,66200,39900,33800,11660,180,4.1,10,7,11.3,7620,9,999999999,259,0.1920,0,88,999.000,999.0,99.0
+1989,8,19,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,15.6,52,99000,948,1334,408,458,232,291,49600,25000,31800,8440,180,7.7,10,7,11.3,7620,9,999999999,270,0.1920,0,88,999.000,999.0,99.0
+1989,8,19,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,15.0,52,99000,766,1334,404,349,175,248,38100,18200,27600,6550,170,7.2,10,7,9.7,7620,9,999999999,259,0.1920,0,88,999.000,999.0,99.0
+1989,8,19,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,15.6,56,98900,545,1334,402,203,76,171,22200,7400,19200,4790,170,6.7,10,7,9.7,7620,9,999999999,270,0.1920,0,88,999.000,999.0,99.0
+1989,8,19,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,15.6,58,98800,301,1334,399,89,52,77,9700,4400,8700,1980,170,5.7,10,7,8.0,7620,9,999999999,270,0.1920,0,88,999.000,999.0,99.0
+1989,8,19,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,15.6,60,98800,63,989,411,19,1,19,2200,0,2200,650,160,5.2,10,9,8.0,6100,9,999999999,270,0.1920,0,88,999.000,999.0,99.0
+1989,8,19,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.9,15.6,60,98700,0,0,411,0,0,0,0,0,0,0,160,6.7,10,9,11.3,1370,9,999999999,270,0.1920,0,88,999.000,999.0,99.0
+1989,8,19,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,16.1,64,98700,0,0,420,0,0,0,0,0,0,0,170,6.2,10,10,11.3,1370,9,999999999,279,0.1920,0,88,999.000,999.0,99.0
+1989,8,19,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,16.7,69,98700,0,0,418,0,0,0,0,0,0,0,160,6.7,10,10,11.3,2740,9,999999999,290,0.1920,0,88,999.000,999.0,99.0
+1989,8,19,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,18.3,81,98600,0,0,414,0,0,0,0,0,0,0,170,7.2,10,10,11.3,1130,9,999999999,320,0.1920,0,88,999.000,999.0,99.0
+1989,8,19,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,20.0,100,98500,0,0,406,0,0,0,0,0,0,0,180,7.7,10,10,6.4,460,9,999999999,350,0.1920,0,88,999.000,999.0,99.0
+1989,8,20,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,20.0,100,98400,0,0,406,0,0,0,0,0,0,0,170,6.2,10,10,9.7,490,9,999999999,350,0.1920,0,88,999.000,999.0,99.0
+1989,8,20,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,20.0,93,98400,0,0,412,0,0,0,0,0,0,0,210,7.2,10,10,9.7,460,9,999999999,350,0.1920,0,88,999.000,999.0,99.0
+1989,8,20,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,20.6,97,98400,0,0,413,0,0,0,0,0,0,0,260,5.2,10,10,9.7,910,9,999999999,359,0.1920,0,88,999.000,999.0,99.0
+1989,8,20,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,20.6,93,98400,0,0,417,0,0,0,0,0,0,0,230,5.2,10,10,9.7,910,9,999999999,359,0.1920,0,88,999.000,999.0,99.0
+1989,8,20,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,20.6,93,98500,0,0,417,0,0,0,0,0,0,0,260,4.1,10,10,9.7,340,9,999999999,359,0.1920,0,88,999.000,999.0,99.0
+1989,8,20,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,20.6,93,98500,93,1190,368,22,12,21,2400,700,2400,520,220,3.6,1,1,8.0,77777,9,999999999,359,0.3160,0,88,999.000,999.0,99.0
+1989,8,20,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,20.6,90,98500,339,1334,399,108,65,91,11800,5700,10300,2370,220,3.6,8,8,8.0,340,9,999999999,359,0.3160,0,88,999.000,999.0,99.0
+1989,8,20,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,21.1,90,98500,581,1334,424,153,9,149,17500,700,17200,5980,240,5.2,10,10,8.0,340,9,999999999,370,0.3160,0,88,999.000,999.0,99.0
+1989,8,20,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,21.1,82,98500,796,1334,421,355,57,320,38900,5800,35400,9820,260,5.7,9,9,8.0,460,9,999999999,370,0.3160,0,88,999.000,999.0,99.0
+1989,8,20,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,20.0,69,98600,970,1334,420,407,128,313,44700,13600,34800,9860,240,5.7,8,8,9.7,940,9,999999999,350,0.3160,0,88,999.000,999.0,99.0
+1989,8,20,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,20.0,67,98600,1091,1334,412,739,468,353,77500,48700,37600,13710,250,5.2,6,6,11.3,910,9,999999999,350,0.3160,0,88,999.000,999.0,99.0
+1989,8,20,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,19.4,61,98600,1151,1334,417,579,269,345,63600,29300,38300,14590,230,6.2,6,6,12.9,1070,9,999999999,340,0.3160,0,88,999.000,999.0,99.0
+1989,8,20,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,18.9,55,98600,1145,1334,428,763,491,338,81000,51200,36900,15160,280,5.2,7,7,12.9,1220,9,999999999,329,0.3160,0,88,999.000,999.0,99.0
+1989,8,20,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,17.8,55,98600,1074,1334,420,519,143,403,56700,15200,44400,14640,270,4.6,9,7,16.1,1250,9,999999999,309,0.3160,0,88,999.000,999.0,99.0
+1989,8,20,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,18.3,53,98600,943,1334,427,531,302,315,57100,32500,34100,9210,290,6.7,8,7,16.1,1250,9,999999999,320,0.3160,0,88,999.000,999.0,99.0
+1989,8,20,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,17.8,56,98600,761,1334,417,359,196,246,39100,20400,27500,6470,280,5.7,8,7,16.1,1310,9,999999999,300,0.3160,0,88,999.000,999.0,99.0
+1989,8,20,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,17.2,53,98600,540,1334,419,238,164,171,25800,16200,19300,4020,270,5.7,7,7,19.3,2290,9,999999999,300,0.3160,0,88,999.000,999.0,99.0
+1989,8,20,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,15.0,51,98600,295,1334,396,97,70,81,10500,5700,9300,1760,270,6.2,5,4,24.1,77777,9,999999999,259,0.3160,0,88,999.000,999.0,99.0
+1989,8,20,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,15.6,62,98700,59,945,375,18,6,17,1900,300,1900,420,270,3.1,2,2,24.1,77777,9,999999999,270,0.3160,0,88,999.000,999.0,99.0
+1989,8,20,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,15.6,66,98700,0,0,358,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,270,0.3160,0,88,999.000,999.0,99.0
+1989,8,20,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,16.1,78,98800,0,0,348,0,0,0,0,0,0,0,270,2.6,0,0,24.1,77777,9,999999999,279,0.3160,0,88,999.000,999.0,99.0
+1989,8,20,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,16.1,81,98800,0,0,345,0,0,0,0,0,0,0,260,3.1,0,0,24.1,77777,9,999999999,279,0.3160,0,88,999.000,999.0,99.0
+1989,8,20,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,16.1,87,98900,0,0,340,0,0,0,0,0,0,0,260,3.6,0,0,24.1,77777,9,999999999,279,0.3160,0,88,999.000,999.0,99.0
+1989,8,20,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,16.1,84,98900,0,0,343,0,0,0,0,0,0,0,270,3.6,0,0,19.3,77777,9,999999999,279,0.3160,0,88,999.000,999.0,99.0
+1989,8,21,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,15.6,87,98900,0,0,337,0,0,0,0,0,0,0,280,2.6,0,0,16.1,77777,9,999999999,270,0.3160,0,88,999.000,999.0,99.0
+1989,8,21,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,15.6,90,99000,0,0,334,0,0,0,0,0,0,0,270,2.1,0,0,16.1,77777,9,999999999,270,0.3160,0,88,999.000,999.0,99.0
+1989,8,21,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,15.0,93,99000,0,0,329,0,0,0,0,0,0,0,0,0.0,0,0,16.1,77777,9,999999999,259,0.3160,0,88,999.000,999.0,99.0
+1989,8,21,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,15.0,93,99000,0,0,329,0,0,0,0,0,0,0,260,2.1,0,0,16.1,77777,9,999999999,259,0.3160,0,88,999.000,999.0,99.0
+1989,8,21,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,15.6,93,99000,0,0,343,0,0,0,0,0,0,0,200,1.5,2,2,16.1,77777,9,999999999,270,0.3160,0,88,999.000,999.0,99.0
+1989,8,21,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,15.0,90,99000,90,1168,342,26,36,23,2900,1800,2700,480,0,0.0,2,2,16.1,77777,9,999999999,259,0.1920,0,88,999.000,999.0,99.0
+1989,8,21,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,17.2,79,99100,336,1335,366,156,278,84,16000,23000,10200,1550,0,0.0,2,2,16.1,77777,9,999999999,300,0.1920,0,88,999.000,999.0,99.0
+1989,8,21,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,16.1,66,99100,577,1335,373,340,443,146,35500,43200,16800,2920,160,2.6,2,2,16.1,77777,9,999999999,279,0.1920,0,88,999.000,999.0,99.0
+1989,8,21,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,15.6,54,99100,793,1335,382,509,557,175,54600,57100,20600,4050,130,1.5,1,1,16.1,77777,9,999999999,270,0.1920,0,88,999.000,999.0,99.0
+1989,8,21,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,15.6,49,99200,967,1335,395,657,609,212,68400,61300,23800,6090,180,3.1,2,2,16.1,77777,9,999999999,270,0.1920,0,88,999.000,999.0,99.0
+1989,8,21,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,15.0,44,99100,1088,1335,400,773,685,209,81500,69800,24500,7830,0,0.0,2,2,16.1,77777,9,999999999,259,0.1920,0,88,999.000,999.0,99.0
+1989,8,21,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,15.0,43,99100,1148,1335,404,841,731,208,89400,74700,25000,9220,0,0.0,2,2,16.1,77777,9,999999999,259,0.1920,0,88,999.000,999.0,99.0
+1989,8,21,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,17.2,48,99100,1142,1335,409,834,706,225,88100,71900,26500,9730,130,3.6,2,2,16.1,77777,9,999999999,300,0.1920,0,88,999.000,999.0,99.0
+1989,8,21,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,16.7,43,99100,1070,1335,422,572,354,285,61100,36900,31400,10380,160,5.2,4,4,12.9,77777,9,999999999,290,0.1920,0,88,999.000,999.0,99.0
+1989,8,21,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,15.6,43,99000,939,1335,417,431,261,245,47200,28200,27300,6850,200,4.1,5,5,11.3,77777,9,999999999,270,0.1920,0,88,999.000,999.0,99.0
+1989,8,21,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,15.6,44,99000,756,1335,418,473,494,190,49900,50300,21400,4290,200,5.7,7,6,24.1,7620,9,999999999,270,0.1920,0,88,999.000,999.0,99.0
+1989,8,21,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,16.7,51,99000,534,1335,414,203,141,145,22100,13900,16500,3400,200,4.6,8,6,24.1,7620,9,999999999,290,0.1920,0,88,999.000,999.0,99.0
+1989,8,21,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,17.2,54,99000,289,1335,423,91,73,75,9900,5900,8700,1620,190,5.2,10,8,24.1,3660,9,999999999,300,0.1920,0,88,999.000,999.0,99.0
+1989,8,21,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,18.3,62,99000,55,923,418,13,0,13,1500,0,1500,470,200,4.6,10,8,24.1,2290,9,999999999,320,0.1920,0,88,999.000,999.0,99.0
+1989,8,21,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.0,19.4,71,98900,0,0,422,0,0,0,0,0,0,0,170,4.1,10,9,24.1,2290,9,999999999,340,0.1920,0,88,999.000,999.0,99.0
+1989,8,21,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.9,20.0,79,98800,0,0,428,0,0,0,0,0,0,0,180,3.6,10,10,24.1,1680,9,999999999,350,0.1920,0,88,999.000,999.0,99.0
+1989,8,21,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,24.4,20.6,79,99000,0,0,432,0,0,0,0,0,0,0,180,5.2,10,10,24.1,1980,9,999999999,359,0.1920,0,88,999.000,999.0,99.0
+1989,8,21,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.9,21.1,85,98900,0,0,430,0,0,0,0,0,0,0,170,5.7,10,10,24.1,1830,9,999999999,379,0.1920,0,88,999.000,999.0,99.0
+1989,8,21,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.9,21.1,85,98900,0,0,430,0,0,0,0,0,0,0,180,5.2,10,10,24.1,1830,9,999999999,379,0.1920,0,88,999.000,999.0,99.0
+1989,8,22,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,21.1,90,98900,0,0,424,0,0,0,0,0,0,0,190,3.6,10,10,24.1,1520,9,999999999,370,0.1920,0,88,999.000,999.0,99.0
+1989,8,22,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,20.6,87,98900,0,0,423,0,0,0,0,0,0,0,200,5.7,10,10,24.1,1830,9,999999999,359,0.1920,0,88,999.000,999.0,99.0
+1989,8,22,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,20.0,82,98800,0,0,413,0,0,0,0,0,0,0,190,6.2,9,9,19.3,1520,9,999999999,350,0.1920,0,88,999.000,999.0,99.0
+1989,8,22,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,20.0,84,98800,0,0,422,0,0,0,0,0,0,0,210,6.7,10,10,19.3,2130,9,999999999,350,0.1920,0,88,999.000,999.0,99.0
+1989,8,22,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,19.4,82,98700,0,0,410,0,0,0,0,0,0,0,220,7.7,9,9,19.3,2590,9,999999999,340,0.1920,0,88,999.000,999.0,99.0
+1989,8,22,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,20.6,87,98700,86,1146,423,4,2,4,500,100,500,110,210,7.7,10,10,11.3,1130,9,999999999,359,0.0740,0,88,999.000,999.0,99.0
+1989,8,22,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,20.6,90,98800,332,1336,419,50,15,46,5500,1300,5200,1310,230,5.2,10,10,8.0,980,9,999999999,359,0.0740,0,88,999.000,999.0,99.0
+1989,8,22,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,20.6,93,98800,574,1336,417,95,9,91,11300,600,11000,4040,230,3.6,10,10,8.0,760,9,999999999,359,0.0740,0,88,999.000,999.0,99.0
+1989,8,22,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,21.1,94,98800,789,1336,420,215,2,214,24900,200,24800,9180,210,4.1,10,10,16.1,700,9,999999999,370,0.0740,0,88,999.000,999.0,99.0
+1989,8,22,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,21.1,87,98800,964,1336,426,325,2,324,37500,200,37300,13690,230,4.1,10,10,16.1,580,9,999999999,370,0.0740,0,88,999.000,999.0,99.0
+1989,8,22,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,21.7,87,98800,1085,1336,431,317,2,315,37200,200,37100,14210,220,4.1,10,10,16.1,520,9,999999999,379,0.0740,0,88,999.000,999.0,99.0
+1989,8,22,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,22.2,85,98800,1144,1336,438,431,3,428,49800,300,49600,17720,220,6.2,10,10,16.1,340,9,999999999,400,0.0740,0,88,999.000,999.0,99.0
+1989,8,22,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,22.8,85,98800,1138,1336,442,375,5,370,43800,500,43400,16130,220,6.7,10,10,16.1,400,9,999999999,409,0.0740,0,88,999.000,999.0,99.0
+1989,8,22,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,22.2,77,98800,1066,1336,435,350,94,274,39100,10100,31000,9800,220,6.2,9,9,16.1,640,9,999999999,400,0.0740,0,88,999.000,999.0,99.0
+1989,8,22,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,22.8,72,98800,934,1336,424,617,533,240,65600,55300,26800,6720,220,5.2,7,6,16.1,790,9,999999999,409,0.0740,0,88,999.000,999.0,99.0
+1989,8,22,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,22.8,72,98700,751,1336,418,393,389,171,41800,39600,19500,3810,230,5.7,4,4,16.1,77777,9,999999999,409,0.0740,0,88,999.000,999.0,99.0
+1989,8,22,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,22.8,70,98700,529,1336,418,287,454,104,30600,43600,13300,1980,220,5.2,6,3,16.1,77777,9,999999999,409,0.0740,0,88,999.000,999.0,99.0
+1989,8,22,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,22.8,74,98700,283,1336,422,112,211,66,11900,16300,8400,1220,220,4.1,7,6,16.1,7620,9,999999999,409,0.0740,0,88,999.000,999.0,99.0
+1989,8,22,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,22.8,79,98700,51,879,412,22,40,18,2300,1700,2200,370,220,3.6,5,5,16.1,77777,9,999999999,409,0.0740,0,88,999.000,999.0,99.0
+1989,8,22,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,25.6,22.8,85,98700,0,0,406,0,0,0,0,0,0,0,220,3.1,5,5,16.1,77777,9,999999999,409,0.0740,0,88,999.000,999.0,99.0
+1989,8,22,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,24.4,21.7,85,98800,0,0,388,0,0,0,0,0,0,0,230,3.6,2,2,16.1,77777,9,999999999,390,0.0740,0,88,999.000,999.0,99.0
+1989,8,22,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,24.4,21.7,85,98700,0,0,388,0,0,0,0,0,0,0,190,3.6,8,2,19.3,77777,9,999999999,390,0.0740,0,88,999.000,999.0,99.0
+1989,8,22,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,24.4,21.1,82,98700,0,0,387,0,0,0,0,0,0,0,270,3.1,7,2,19.3,77777,9,999999999,370,0.0740,0,88,999.000,999.0,99.0
+1989,8,22,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,21.1,90,98900,0,0,386,0,0,0,0,0,0,0,360,2.1,4,4,24.1,77777,9,999999999,370,0.0740,0,88,999.000,999.0,99.0
+1989,8,23,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,21.7,94,98900,0,0,384,0,0,0,0,0,0,0,320,3.1,10,3,24.1,77777,9,999999999,390,0.0740,0,88,999.000,999.0,99.0
+1989,8,23,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,21.7,94,98900,0,0,380,0,0,0,0,0,0,0,310,3.1,8,2,24.1,77777,9,999999999,390,0.0740,0,88,999.000,999.0,99.0
+1989,8,23,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,21.1,90,98900,0,0,386,0,0,0,0,0,0,0,330,3.1,4,4,24.1,77777,9,999999999,370,0.0740,0,88,999.000,999.0,99.0
+1989,8,23,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,19.4,84,98900,0,0,374,0,0,0,0,0,0,0,350,4.6,8,2,24.1,77777,9,999999999,340,0.0740,0,88,999.000,999.0,99.0
+1989,8,23,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,20.0,90,98900,0,0,404,0,0,0,0,0,0,0,30,5.2,10,9,24.1,7620,9,999999999,350,0.0740,0,88,999.000,999.0,99.0
+1989,8,23,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,20.0,90,99000,83,1125,416,19,1,19,2200,0,2200,670,50,5.7,10,10,12.9,3050,9,999999999,350,0.1640,0,88,999.000,999.0,99.0
+1989,8,23,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,19.4,87,99200,328,1336,415,50,9,47,5800,300,5700,1910,40,3.6,10,10,12.9,340,9,999999999,340,0.1640,0,88,999.000,999.0,99.0
+1989,8,23,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,19.4,87,99100,570,1336,415,157,4,155,17800,300,17700,6080,10,6.2,10,10,11.3,310,9,999999999,340,0.1640,0,88,999.000,999.0,99.0
+1989,8,23,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,19.4,84,99100,786,1336,418,212,8,207,24500,700,24100,8940,260,6.2,10,10,11.3,340,9,999999999,340,0.1640,0,88,999.000,999.0,99.0
+1989,8,23,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,19.4,90,99300,961,1336,412,156,6,152,19100,400,18800,7620,20,6.7,10,10,9.7,460,9,999999999,340,0.1640,0,88,999.000,999.0,99.0
+1989,8,23,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,18.9,87,99300,1082,1336,411,243,2,242,29200,200,29100,11630,40,7.2,10,10,11.3,310,9,999999999,329,0.1640,0,88,999.000,999.0,99.0
+1989,8,23,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,18.9,87,99200,1141,1336,411,214,4,210,26100,300,25800,10470,40,6.7,10,10,11.3,370,9,999999999,329,0.1640,0,88,999.000,999.0,99.0
+1989,8,23,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,17.8,81,99200,1134,1336,410,382,0,382,44500,0,44500,16450,40,6.7,10,10,19.3,520,9,999999999,309,0.1640,0,88,999.000,999.0,99.0
+1989,8,23,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,18.3,81,99200,1062,1336,414,348,2,346,40400,200,40300,15040,40,7.2,10,10,19.3,490,9,999999999,320,0.1640,0,88,999.000,999.0,99.0
+1989,8,23,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,17.8,79,99100,930,1336,413,306,1,306,35300,100,35200,12910,40,7.7,10,10,19.3,520,9,999999999,309,0.1640,0,88,999.000,999.0,99.0
+1989,8,23,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,17.2,81,99100,746,1336,387,246,122,177,27300,12800,20200,4610,40,7.7,8,8,19.3,550,9,999999999,300,0.1640,0,88,999.000,999.0,99.0
+1989,8,23,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,17.2,81,99100,523,1336,406,137,10,133,15600,700,15300,5210,30,7.7,10,10,19.3,550,9,999999999,300,0.1640,0,88,999.000,999.0,99.0
+1989,8,23,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,17.2,81,99200,277,1336,406,78,4,77,8700,200,8600,2600,40,6.7,10,10,19.3,580,9,999999999,300,0.1640,0,88,999.000,999.0,99.0
+1989,8,23,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,15.6,76,99200,47,857,390,17,2,16,1800,0,1800,550,20,6.2,9,9,19.3,1830,9,999999999,270,0.1640,0,88,999.000,999.0,99.0
+1989,8,23,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,16.1,78,99200,0,0,390,0,0,0,0,0,0,0,40,5.7,9,9,16.1,1980,9,999999999,279,0.1640,0,88,999.000,999.0,99.0
+1989,8,23,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,17.8,87,99200,0,0,404,0,0,0,0,0,0,0,50,5.2,10,10,16.1,760,9,999999999,309,0.1640,0,88,999.000,999.0,99.0
+1989,8,23,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,18.3,87,99200,0,0,408,0,0,0,0,0,0,0,50,4.6,10,10,16.1,760,9,999999999,320,0.1640,0,88,999.000,999.0,99.0
+1989,8,23,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,18.3,84,99200,0,0,410,0,0,0,0,0,0,0,50,6.2,10,10,16.1,370,9,999999999,320,0.1640,0,88,999.000,999.0,99.0
+1989,8,23,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,17.8,81,99200,0,0,410,0,0,0,0,0,0,0,50,4.6,10,10,19.3,940,9,999999999,309,0.1640,0,88,999.000,999.0,99.0
+1989,8,24,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,17.2,81,99200,0,0,387,0,0,0,0,0,0,0,50,5.2,8,8,19.3,1070,9,999999999,300,0.1640,0,88,999.000,999.0,99.0
+1989,8,24,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,17.2,84,99200,0,0,377,0,0,0,0,0,0,0,50,5.2,7,7,24.1,580,9,999999999,300,0.1640,0,88,999.000,999.0,99.0
+1989,8,24,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,17.2,84,99200,0,0,383,0,0,0,0,0,0,0,50,6.2,8,8,24.1,910,9,999999999,300,0.1640,0,88,999.000,999.0,99.0
+1989,8,24,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,16.7,84,99300,0,0,361,0,0,0,0,0,0,0,70,5.7,3,3,24.1,77777,9,999999999,290,0.1640,0,88,999.000,999.0,99.0
+1989,8,24,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,16.7,81,99300,0,0,402,0,0,0,0,0,0,0,50,6.2,10,10,19.3,580,9,999999999,290,0.1640,0,88,999.000,999.0,99.0
+1989,8,24,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,16.7,81,99400,80,1103,402,14,0,14,1600,0,1600,520,70,4.6,10,10,19.3,490,9,999999999,290,0.1700,0,88,999.000,999.0,99.0
+1989,8,24,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,16.7,79,99400,324,1337,405,72,4,71,8200,200,8100,2640,80,4.6,10,10,24.1,460,9,999999999,290,0.1700,0,88,999.000,999.0,99.0
+1989,8,24,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,17.2,81,99400,567,1337,406,149,4,148,17100,300,17000,5870,90,5.7,10,10,24.1,460,9,999999999,300,0.1700,0,88,999.000,999.0,99.0
+1989,8,24,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,17.8,81,99400,783,1337,410,273,10,267,31000,900,30400,10590,60,6.7,10,10,12.9,460,9,999999999,309,0.1700,0,88,999.000,999.0,99.0
+1989,8,24,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,17.2,76,99400,957,1337,412,309,3,306,35600,300,35400,13130,50,5.2,10,10,12.9,520,9,999999999,300,0.1700,0,88,999.000,999.0,99.0
+1989,8,24,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,17.2,76,99400,1078,1337,401,503,213,329,54900,23100,36200,11740,50,5.2,9,9,12.9,520,9,999999999,300,0.1700,0,88,999.000,999.0,99.0
+1989,8,24,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,17.2,73,99500,1137,1337,395,548,217,362,59900,23600,39800,14810,50,6.7,8,8,12.9,640,9,999999999,300,0.1700,0,88,999.000,999.0,99.0
+1989,8,24,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,16.1,66,99400,1130,1337,391,665,384,338,70500,40000,36500,14440,50,7.2,7,7,12.9,760,9,999999999,279,0.1700,0,88,999.000,999.0,99.0
+1989,8,24,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,16.7,71,99400,1058,1337,394,558,239,367,60300,25900,39800,12830,40,7.2,8,8,11.3,640,9,999999999,290,0.1700,0,88,999.000,999.0,99.0
+1989,8,24,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,16.1,69,99400,925,1337,388,491,283,293,53000,30500,31900,8290,40,7.2,7,7,12.9,700,9,999999999,279,0.1700,0,88,999.000,999.0,99.0
+1989,8,24,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,16.1,66,99400,741,1337,380,433,444,184,45700,45100,20700,4100,50,7.7,4,4,12.9,77777,9,999999999,279,0.1700,0,88,999.000,999.0,99.0
+1989,8,24,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,15.6,66,99400,518,1337,358,314,557,94,32200,52400,11900,1830,60,8.8,0,0,16.1,77777,9,999999999,270,0.1700,0,88,999.000,999.0,99.0
+1989,8,24,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,15.6,68,99300,271,1337,355,126,323,59,13100,24400,8200,1060,50,7.7,0,0,16.1,77777,9,999999999,270,0.1700,0,88,999.000,999.0,99.0
+1989,8,24,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,15.6,73,99300,43,813,350,21,27,18,2200,1100,2100,370,40,6.2,0,0,11.3,77777,9,999999999,270,0.1700,0,88,999.000,999.0,99.0
+1989,8,24,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,17.2,81,99400,0,0,381,0,0,0,0,0,0,0,40,7.2,7,7,16.1,1310,9,999999999,300,0.1700,0,88,999.000,999.0,99.0
+1989,8,24,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,17.2,84,99400,0,0,377,0,0,0,0,0,0,0,50,5.7,7,7,16.1,1310,9,999999999,300,0.1700,0,88,999.000,999.0,99.0
+1989,8,24,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,17.8,90,99400,0,0,375,0,0,0,0,0,0,0,50,4.1,7,7,16.1,1130,9,999999999,309,0.1700,0,88,999.000,999.0,99.0
+1989,8,24,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,16.1,73,99400,0,0,407,0,0,0,0,0,0,0,90,5.2,10,10,16.1,1130,9,999999999,279,0.1700,0,88,999.000,999.0,99.0
+1989,8,24,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,15.6,76,99400,0,0,347,0,0,0,0,0,0,0,90,5.2,0,0,16.1,77777,9,999999999,270,0.1700,0,88,999.000,999.0,99.0
+1989,8,25,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,15.6,78,99400,0,0,344,0,0,0,0,0,0,0,100,4.1,0,0,16.1,77777,9,999999999,270,0.1700,0,88,999.000,999.0,99.0
+1989,8,25,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,15.6,84,99400,0,0,339,0,0,0,0,0,0,0,110,3.1,0,0,16.1,77777,9,999999999,270,0.1700,0,88,999.000,999.0,99.0
+1989,8,25,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,16.1,84,99400,0,0,343,0,0,0,0,0,0,0,100,4.1,0,0,16.1,77777,9,999999999,279,0.1700,0,88,999.000,999.0,99.0
+1989,8,25,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,16.1,84,99400,0,0,376,0,0,0,0,0,0,0,90,4.1,8,8,16.1,2740,9,999999999,279,0.1700,0,88,999.000,999.0,99.0
+1989,8,25,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,15.6,90,99500,0,0,341,0,0,0,0,0,0,0,120,3.1,1,1,16.1,77777,9,999999999,270,0.1700,0,88,999.000,999.0,99.0
+1989,8,25,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,15.0,81,99500,77,1081,350,26,55,21,2700,2200,2500,360,110,3.1,3,2,16.1,77777,9,999999999,259,0.1520,0,88,999.000,999.0,99.0
+1989,8,25,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,15.0,76,99600,321,1337,359,153,230,96,15900,18900,11400,1890,100,4.6,8,3,16.1,77777,9,999999999,259,0.1520,0,88,999.000,999.0,99.0
+1989,8,25,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,15.0,68,99600,563,1337,367,252,214,161,26900,21400,17800,3400,80,6.2,7,3,16.1,77777,9,999999999,259,0.1520,0,88,999.000,999.0,99.0
+1989,8,25,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,15.6,66,99600,780,1337,373,459,427,207,48200,43600,22800,4800,80,6.2,9,3,16.1,77777,9,999999999,270,0.1520,0,88,999.000,999.0,99.0
+1989,8,25,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,15.0,60,99600,954,1337,369,668,680,178,70200,69000,20800,5100,120,4.1,5,1,16.1,77777,9,999999999,259,0.1520,0,88,999.000,999.0,99.0
+1989,8,25,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,13.3,52,99500,1075,1337,370,737,686,180,78400,70300,21800,6590,120,5.7,5,1,16.1,77777,9,999999999,240,0.1520,0,88,999.000,999.0,99.0
+1989,8,25,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,14.4,54,99500,1134,1337,374,803,745,166,83900,75000,20200,6470,90,5.2,3,1,16.1,77777,9,999999999,250,0.1520,0,88,999.000,999.0,99.0
+1989,8,25,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,13.9,50,99400,1126,1337,370,849,814,156,89000,82100,19700,6030,60,4.1,0,0,16.1,77777,9,999999999,250,0.1520,0,88,999.000,999.0,99.0
+1989,8,25,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,14.4,54,99400,1054,1337,374,736,731,154,76600,73500,18500,4900,60,7.2,2,1,16.1,77777,9,999999999,250,0.1520,0,88,999.000,999.0,99.0
+1989,8,25,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,13.9,52,99300,920,1337,374,630,691,150,66800,70400,18200,4150,60,6.7,3,1,16.1,77777,9,999999999,250,0.1520,0,88,999.000,999.0,99.0
+1989,8,25,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,14.4,58,99200,735,1337,369,474,649,112,49900,65100,14000,2550,60,6.7,3,1,16.1,77777,9,999999999,259,0.1520,0,88,999.000,999.0,99.0
+1989,8,25,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,14.4,60,99200,512,1337,366,298,507,101,30500,47400,12300,1930,60,5.7,4,1,16.1,77777,9,999999999,259,0.1520,0,88,999.000,999.0,99.0
+1989,8,25,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,14.4,64,99200,265,1337,361,117,291,58,12200,21800,7900,1040,50,5.2,3,1,16.1,77777,9,999999999,259,0.1520,0,88,999.000,999.0,99.0
+1989,8,25,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,14.4,68,99300,39,791,355,16,24,14,1700,1000,1700,290,50,5.2,2,1,16.1,77777,9,999999999,250,0.1520,0,88,999.000,999.0,99.0
+1989,8,25,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,14.4,71,99300,0,0,346,0,0,0,0,0,0,0,30,3.6,0,0,16.1,77777,9,999999999,259,0.1520,0,88,999.000,999.0,99.0
+1989,8,25,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,14.4,76,99300,0,0,347,0,0,0,0,0,0,0,40,3.6,3,1,16.1,77777,9,999999999,259,0.1520,0,88,999.000,999.0,99.0
+1989,8,25,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,15.0,76,99400,0,0,350,0,0,0,0,0,0,0,30,3.1,3,1,16.1,77777,9,999999999,259,0.1520,0,88,999.000,999.0,99.0
+1989,8,25,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,15.0,78,99300,0,0,394,0,0,0,0,0,0,0,30,2.6,10,10,16.1,1220,9,999999999,259,0.1520,0,88,999.000,999.0,99.0
+1989,8,25,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,15.0,84,99300,0,0,351,0,0,0,0,0,0,0,20,2.1,3,3,16.1,77777,9,999999999,259,0.1520,0,88,999.000,999.0,99.0
+1989,8,26,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,16.1,87,99300,0,0,367,0,0,0,0,0,0,0,10,2.6,7,7,16.1,1220,9,999999999,279,0.1520,0,88,999.000,999.0,99.0
+1989,8,26,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,15.6,90,99300,0,0,361,0,0,0,0,0,0,0,320,1.5,7,7,16.1,1220,9,999999999,270,0.1520,0,88,999.000,999.0,99.0
+1989,8,26,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,15.6,90,99300,0,0,349,0,0,0,0,0,0,0,30,1.5,3,3,16.1,77777,9,999999999,270,0.1520,0,88,999.000,999.0,99.0
+1989,8,26,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,15.6,90,99200,0,0,334,0,0,0,0,0,0,0,0,0.0,0,0,16.1,77777,9,999999999,270,0.1520,0,88,999.000,999.0,99.0
+1989,8,26,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,16.1,84,99400,0,0,343,0,0,0,0,0,0,0,140,2.6,0,0,16.1,77777,9,999999999,279,0.1520,0,88,999.000,999.0,99.0
+1989,8,26,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,15.6,81,99300,73,1059,384,17,4,17,2000,0,2000,610,170,2.6,9,9,16.1,1190,9,999999999,270,0.1480,0,88,999.000,999.0,99.0
+1989,8,26,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,14.4,68,99300,317,1338,391,78,25,72,8600,2100,8100,1910,170,4.1,9,9,12.9,1220,9,999999999,250,0.1480,0,88,999.000,999.0,99.0
+1989,8,26,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,14.4,68,99400,560,1338,403,179,17,172,20200,1300,19600,6440,170,3.1,10,10,12.9,1220,9,999999999,250,0.1480,0,88,999.000,999.0,99.0
+1989,8,26,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,15.0,66,99400,776,1338,409,204,6,201,23700,500,23400,8680,170,4.1,10,10,11.3,1220,9,999999999,259,0.1480,0,88,999.000,999.0,99.0
+1989,8,26,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,15.6,66,99400,951,1338,413,312,10,305,36000,900,35400,13040,170,3.6,10,10,11.3,1220,9,999999999,270,0.1480,0,88,999.000,999.0,99.0
+1989,8,26,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,16.7,69,99400,1071,1338,418,354,11,346,41300,1000,40500,15090,160,2.6,10,10,11.3,1250,9,999999999,290,0.1480,0,88,999.000,999.0,99.0
+1989,8,26,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,17.8,69,99400,1130,1338,425,329,6,323,38700,500,38300,14640,200,3.6,10,10,11.3,1250,9,999999999,309,0.1480,0,88,999.000,999.0,99.0
+1989,8,26,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,18.3,67,99300,1123,1338,433,329,4,325,38700,400,38400,14680,170,3.6,10,10,12.9,1310,9,999999999,320,0.1480,0,88,999.000,999.0,99.0
+1989,8,26,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,18.9,63,99300,1049,1338,431,352,4,349,40800,400,40500,15030,180,3.6,10,9,9.7,2440,9,999999999,329,0.1480,0,88,999.000,999.0,99.0
+1989,8,26,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,18.9,67,99200,915,1338,437,247,7,242,28900,600,28400,10860,200,2.6,10,10,9.7,1490,9,999999999,329,0.1480,0,88,999.000,999.0,99.0
+1989,8,26,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,19.4,71,99100,730,1338,434,231,25,217,26400,2100,25200,8850,210,2.6,10,10,8.0,1010,9,999999999,340,0.1480,0,88,999.000,999.0,99.0
+1989,8,26,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,19.4,82,99000,506,1338,421,61,8,58,7400,400,7200,2610,110,5.7,10,10,6.4,880,9,999999999,340,0.1480,0,88,999.000,999.0,99.0
+1989,8,26,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,19.4,79,99100,259,1338,424,58,1,58,6600,0,6600,2080,40,2.6,10,10,6.4,820,9,999999999,340,0.1480,0,88,999.000,999.0,99.0
+1989,8,26,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,19.4,84,99200,36,747,392,11,9,10,1200,500,1100,260,150,2.6,7,7,6.4,850,9,999999999,340,0.1480,0,88,999.000,999.0,99.0
+1989,8,26,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,18.3,79,99200,0,0,386,0,0,0,0,0,0,0,120,3.6,6,6,6.4,1220,9,999999999,320,0.1480,0,88,999.000,999.0,99.0
+1989,8,26,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,18.3,79,99200,0,0,405,0,0,0,0,0,0,0,120,3.6,9,9,6.4,980,9,999999999,320,0.1480,0,88,999.000,999.0,99.0
+1989,8,26,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,18.3,81,99300,0,0,414,0,0,0,0,0,0,0,120,2.6,10,10,6.4,1340,9,999999999,320,0.1480,0,88,999.000,999.0,99.0
+1989,8,26,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,18.9,87,99300,0,0,411,0,0,0,0,0,0,0,120,2.1,10,10,6.4,1680,9,999999999,329,0.1480,0,88,999.000,999.0,99.0
+1989,8,26,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,18.9,87,99200,0,0,400,0,0,0,0,0,0,0,0,0.0,9,9,6.4,1010,9,999999999,329,0.1480,0,88,999.000,999.0,99.0
+1989,8,27,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,19.4,97,99200,0,0,406,0,0,0,0,0,0,0,0,0.0,10,10,6.4,820,9,999999999,340,0.1480,0,88,999.000,999.0,99.0
+1989,8,27,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,19.4,93,99200,0,0,409,0,0,0,0,0,0,0,0,0.0,10,10,6.4,1010,9,999999999,340,0.1480,0,88,999.000,999.0,99.0
+1989,8,27,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,18.9,97,99200,0,0,348,0,0,0,0,0,0,0,0,0.0,0,0,6.4,77777,9,999999999,329,0.1480,0,88,999.000,999.0,99.0
+1989,8,27,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,18.9,97,99300,0,0,366,0,0,0,0,0,0,0,230,1.5,4,4,6.4,77777,9,999999999,329,0.1480,0,88,999.000,999.0,99.0
+1989,8,27,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,18.3,97,99300,0,0,360,0,0,0,0,0,0,0,310,1.5,3,3,6.4,77777,9,999999999,320,0.1480,0,88,999.000,999.0,99.0
+1989,8,27,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,18.3,97,99300,70,1037,360,19,3,19,2200,0,2200,660,200,2.1,6,3,6.4,77777,9,999999999,320,0.3240,0,88,999.000,999.0,99.0
+1989,8,27,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,20.6,85,99300,313,1338,381,114,132,83,12400,11000,9900,1810,0,0.0,6,2,6.4,77777,9,999999999,359,0.3240,0,88,999.000,999.0,99.0
+1989,8,27,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,20.6,79,99400,556,1338,387,297,321,162,31500,32000,18200,3430,340,3.1,7,2,6.4,77777,9,999999999,359,0.3240,0,88,999.000,999.0,99.0
+1989,8,27,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,20.6,72,99400,773,1338,390,473,475,196,50000,48500,21900,4500,290,2.6,4,1,8.0,77777,9,999999999,370,0.3240,0,88,999.000,999.0,99.0
+1989,8,27,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,21.1,69,99400,947,1338,416,442,141,341,48100,14900,37600,10450,320,3.1,6,6,8.0,1070,9,999999999,370,0.3240,0,88,999.000,999.0,99.0
+1989,8,27,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,21.1,65,99400,1068,1338,422,571,243,374,61600,26300,40500,13300,350,3.1,6,6,11.3,1070,9,999999999,379,0.3240,0,88,999.000,999.0,99.0
+1989,8,27,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,21.1,65,99400,1126,1338,427,669,278,433,72000,30100,46600,17630,50,5.7,7,7,8.0,1100,9,999999999,379,0.3240,0,88,999.000,999.0,99.0
+1989,8,27,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,22.2,74,99400,1118,1338,408,773,551,308,82400,57500,34200,12610,60,6.2,3,3,6.4,77777,9,999999999,400,0.3240,0,88,999.000,999.0,99.0
+1989,8,27,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,21.7,72,99400,1045,1338,398,726,599,253,78000,62500,29100,8590,50,4.1,4,1,6.4,77777,9,999999999,390,0.3240,0,88,999.000,999.0,99.0
+1989,8,27,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,21.1,69,99400,911,1338,406,545,403,267,57000,41600,28600,7280,90,3.1,7,3,8.0,77777,9,999999999,370,0.3240,0,88,999.000,999.0,99.0
+1989,8,27,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,21.7,72,99300,725,1338,403,414,312,243,43900,32700,26200,5800,100,5.2,6,2,8.0,77777,9,999999999,390,0.3240,0,88,999.000,999.0,99.0
+1989,8,27,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,21.1,74,99300,500,1338,396,255,275,150,26800,26700,16900,3120,110,4.6,5,2,8.0,77777,9,999999999,379,0.3240,0,88,999.000,999.0,99.0
+1989,8,27,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,20.6,76,99300,253,1338,400,83,20,79,9000,1600,8700,1890,60,3.6,8,5,6.4,7620,9,999999999,359,0.3240,0,88,999.000,999.0,99.0
+1989,8,27,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,20.6,85,99400,33,703,391,12,0,12,1400,0,1400,430,120,3.1,8,5,6.4,7620,9,999999999,370,0.3240,0,88,999.000,999.0,99.0
+1989,8,27,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,20.6,87,99500,0,0,388,0,0,0,0,0,0,0,130,2.6,7,5,6.4,7620,9,999999999,359,0.3240,0,88,999.000,999.0,99.0
+1989,8,27,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,20.0,87,99500,0,0,382,0,0,0,0,0,0,0,120,2.6,7,4,6.4,7620,9,999999999,350,0.3240,0,88,999.000,999.0,99.0
+1989,8,27,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,20.6,90,99400,0,0,382,0,0,0,0,0,0,0,130,2.1,7,4,6.4,7620,9,999999999,359,0.3240,0,88,999.000,999.0,99.0
+1989,8,27,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,20.6,90,99400,0,0,385,0,0,0,0,0,0,0,110,2.1,8,5,6.4,7620,9,999999999,359,0.3240,0,88,999.000,999.0,99.0
+1989,8,27,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,20.6,93,99400,0,0,383,0,0,0,0,0,0,0,130,3.1,8,5,6.4,7620,9,999999999,359,0.3240,0,88,999.000,999.0,99.0
+1989,8,28,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,20.6,93,99400,0,0,383,0,0,0,0,0,0,0,70,2.6,9,5,6.4,7620,9,999999999,359,0.3240,0,88,999.000,999.0,99.0
+1989,8,28,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,20.6,93,99300,0,0,390,0,0,0,0,0,0,0,60,3.1,9,7,4.8,7620,9,999999999,359,0.3240,0,88,999.000,999.0,99.0
+1989,8,28,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,20.6,93,99300,0,0,390,0,0,0,0,0,0,0,90,2.6,9,7,4.8,7620,9,999999999,359,0.3240,0,88,999.000,999.0,99.0
+1989,8,28,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,20.6,93,99300,0,0,390,0,0,0,0,0,0,0,150,2.6,9,7,4.8,7620,9,999999999,359,0.3240,0,88,999.000,999.0,99.0
+1989,8,28,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,20.6,93,99300,0,0,417,0,0,0,0,0,0,0,140,3.1,10,10,4.8,1070,9,999999999,359,0.3240,0,88,999.000,999.0,99.0
+1989,8,28,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,20.6,93,99300,67,1015,417,11,1,11,1300,0,1300,420,320,5.2,10,10,4.8,1400,9,999999999,359,0.1300,0,88,999.000,999.0,99.0
+1989,8,28,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,20.6,93,99200,309,1339,417,41,4,40,4800,100,4800,1630,90,3.1,10,10,6.4,1070,9,999999999,359,0.1300,0,88,999.000,999.0,99.0
+1989,8,28,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,20.6,93,99200,553,1339,417,73,3,72,8800,200,8700,3250,120,4.6,10,10,4.8,400,9,999999999,359,0.1300,0,88,999.000,999.0,99.0
+1989,8,28,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,22.2,94,99200,769,1339,428,247,6,243,28100,500,27800,9850,120,3.6,10,10,4.8,520,9,999999999,400,0.1300,0,88,999.000,999.0,99.0
+1989,8,28,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,21.7,85,99200,944,1339,434,318,0,318,36600,0,36600,13340,280,3.1,10,10,4.8,430,9,999999999,390,0.1300,0,88,999.000,999.0,99.0
+1989,8,28,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,22.2,88,99200,1064,1339,434,226,0,226,27200,0,27200,10960,240,3.1,10,10,4.8,1100,9,999999999,400,0.1300,0,88,999.000,999.0,99.0
+1989,8,28,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,22.2,79,99100,1123,1339,444,326,0,326,38400,0,38400,14700,140,3.1,10,10,6.4,1310,9,999999999,400,0.1300,0,88,999.000,999.0,99.0
+1989,8,28,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,22.2,77,99100,1114,1339,426,508,302,254,55200,31600,28800,10170,190,4.6,9,8,11.3,3960,9,999999999,400,0.1300,0,88,999.000,999.0,99.0
+1989,8,28,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,22.8,72,99000,1040,1339,436,495,175,358,54200,18600,39800,12280,190,5.2,10,8,11.3,3960,9,999999999,409,0.1300,0,88,999.000,999.0,99.0
+1989,8,28,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,22.2,77,99000,906,1339,448,293,9,287,33800,800,33200,12170,210,3.6,10,10,11.3,1220,9,999999999,400,0.1300,0,88,999.000,999.0,99.0
+1989,8,28,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,22.2,79,99000,719,1339,444,221,8,217,25200,700,24900,8760,210,3.1,10,10,11.3,3660,9,999999999,400,0.1300,0,88,999.000,999.0,99.0
+1989,8,28,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,22.2,79,99000,494,1339,444,105,4,104,12200,300,12100,4220,240,4.6,10,10,11.3,3350,9,999999999,400,0.1300,0,88,999.000,999.0,99.0
+1989,8,28,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,21.7,77,99000,246,1339,422,50,29,45,5500,2300,5100,1190,220,4.6,8,8,11.3,3350,9,999999999,390,0.1300,0,88,999.000,999.0,99.0
+1989,8,28,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,21.7,82,99000,29,681,398,12,13,11,1300,500,1300,230,240,4.1,5,4,11.3,77777,9,999999999,390,0.1300,0,88,999.000,999.0,99.0
+1989,8,28,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.3,21.1,87,99000,0,0,382,0,0,0,0,0,0,0,220,2.6,3,2,16.1,77777,9,999999999,370,0.1300,0,88,999.000,999.0,99.0
+1989,8,28,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,21.1,90,99100,0,0,367,0,0,0,0,0,0,0,220,2.6,0,0,16.1,77777,9,999999999,370,0.1300,0,88,999.000,999.0,99.0
+1989,8,28,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,21.1,94,99000,0,0,364,0,0,0,0,0,0,0,240,2.6,0,0,16.1,77777,9,999999999,379,0.1300,0,88,999.000,999.0,99.0
+1989,8,28,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,21.1,94,99000,0,0,364,0,0,0,0,0,0,0,240,3.6,0,0,16.1,77777,9,999999999,379,0.1300,0,88,999.000,999.0,99.0
+1989,8,28,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,20.6,90,99000,0,0,379,0,0,0,0,0,0,0,250,2.6,4,3,16.1,77777,9,999999999,359,0.1300,0,88,999.000,999.0,99.0
+1989,8,29,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,20.6,97,98900,0,0,374,0,0,0,0,0,0,0,230,2.6,3,3,16.1,77777,9,999999999,359,0.1300,0,88,999.000,999.0,99.0
+1989,8,29,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,20.6,97,99000,0,0,370,0,0,0,0,0,0,0,240,3.1,2,2,11.3,77777,9,999999999,359,0.1300,0,88,999.000,999.0,99.0
+1989,8,29,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,20.6,97,99000,0,0,374,0,0,0,0,0,0,0,240,2.1,4,3,11.3,77777,9,999999999,359,0.1300,0,88,999.000,999.0,99.0
+1989,8,29,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,20.6,97,99000,0,0,377,0,0,0,0,0,0,0,250,2.6,5,4,8.0,77777,9,999999999,359,0.1300,0,88,999.000,999.0,99.0
+1989,8,29,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,20.6,97,99000,0,0,387,0,0,0,0,0,0,0,220,2.6,8,7,8.0,7620,9,999999999,359,0.1300,0,88,999.000,999.0,99.0
+1989,8,29,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,21.1,100,99100,64,994,414,19,0,19,2200,0,2200,660,210,2.6,10,10,4.8,120,9,999999999,370,0.1560,0,88,999.000,999.0,99.0
+1989,8,29,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,21.1,97,99100,305,1340,417,74,6,72,8300,200,8200,2600,260,4.1,10,10,6.4,1130,9,999999999,379,0.1560,0,88,999.000,999.0,99.0
+1989,8,29,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,21.1,90,99200,549,1340,424,80,2,79,9500,100,9500,3520,260,3.6,10,10,11.3,1980,9,999999999,370,0.1560,0,88,999.000,999.0,99.0
+1989,8,29,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,22.2,94,99100,766,1340,428,118,7,114,14300,500,14000,5460,230,3.6,10,10,11.3,1980,9,999999999,400,0.1560,0,88,999.000,999.0,99.0
+1989,8,29,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,22.8,85,99000,940,1340,421,408,139,310,44700,14700,34400,9420,270,4.1,9,8,12.9,3050,9,999999999,409,0.1560,0,88,999.000,999.0,99.0
+1989,8,29,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,22.8,82,99000,1061,1340,433,417,129,314,46200,13800,35200,11090,270,5.2,10,9,12.9,610,9,999999999,409,0.1560,0,88,999.000,999.0,99.0
+1989,8,29,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,20.0,63,99000,1119,1340,418,791,671,225,83200,68200,26100,9000,290,5.2,8,6,12.9,3050,9,999999999,350,0.1560,0,88,999.000,999.0,99.0
+1989,8,29,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,20.0,61,99000,1110,1340,417,661,376,347,72200,40800,38300,13220,270,5.2,8,5,16.1,3050,9,999999999,350,0.1560,0,88,999.000,999.0,99.0
+1989,8,29,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,20.6,59,99000,1036,1340,433,580,388,277,61800,40400,30400,9270,280,5.2,9,7,16.1,3050,9,999999999,359,0.1560,0,88,999.000,999.0,99.0
+1989,8,29,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,19.4,61,99000,900,1340,429,332,170,216,36900,18100,24800,6310,290,5.7,9,8,16.1,3050,9,999999999,340,0.1560,0,88,999.000,999.0,99.0
+1989,8,29,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,18.3,58,99000,714,1340,417,444,419,217,47300,43900,23900,5040,280,5.7,10,7,24.1,7620,9,999999999,320,0.1560,0,88,999.000,999.0,99.0
+1989,8,29,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,18.3,60,99000,488,1340,421,186,78,157,20300,7400,17600,4230,290,5.2,10,8,24.1,7620,9,999999999,320,0.1560,0,88,999.000,999.0,99.0
+1989,8,29,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,17.2,60,99000,240,1340,423,48,19,44,5200,1500,4900,1160,300,5.2,10,9,24.1,6100,9,999999999,300,0.1560,0,88,999.000,999.0,99.0
+1989,8,29,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,15.6,60,99000,26,636,391,12,2,12,1400,0,1400,420,290,3.6,8,6,24.1,6100,9,999999999,270,0.1560,0,88,999.000,999.0,99.0
+1989,8,29,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,15.0,64,99100,0,0,382,0,0,0,0,0,0,0,300,3.1,7,6,24.1,6100,9,999999999,259,0.1560,0,88,999.000,999.0,99.0
+1989,8,29,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,15.0,68,99100,0,0,363,0,0,0,0,0,0,0,310,4.1,5,2,24.1,77777,9,999999999,259,0.1560,0,88,999.000,999.0,99.0
+1989,8,29,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,14.4,71,99100,0,0,357,0,0,0,0,0,0,0,300,4.1,5,2,24.1,77777,9,999999999,250,0.1560,0,88,999.000,999.0,99.0
+1989,8,29,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,13.9,76,99100,0,0,344,0,0,0,0,0,0,0,300,3.1,3,1,24.1,77777,9,999999999,250,0.1560,0,88,999.000,999.0,99.0
+1989,8,29,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,13.9,78,99200,0,0,342,0,0,0,0,0,0,0,280,3.1,4,1,24.1,77777,9,999999999,250,0.1560,0,88,999.000,999.0,99.0
+1989,8,30,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,13.9,81,99200,0,0,339,0,0,0,0,0,0,0,310,2.6,4,1,24.1,77777,9,999999999,250,0.1560,0,88,999.000,999.0,99.0
+1989,8,30,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,12.8,75,99200,0,0,331,0,0,0,0,0,0,0,310,3.1,2,0,24.1,77777,9,999999999,229,0.1560,0,88,999.000,999.0,99.0
+1989,8,30,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,12.2,75,99200,0,0,328,0,0,0,0,0,0,0,300,3.1,0,0,24.1,77777,9,999999999,220,0.1560,0,88,999.000,999.0,99.0
+1989,8,30,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,12.2,81,99300,0,0,323,0,0,0,0,0,0,0,300,2.6,0,0,24.1,77777,9,999999999,220,0.1560,0,88,999.000,999.0,99.0
+1989,8,30,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,12.2,84,99300,0,0,321,0,0,0,0,0,0,0,280,2.6,0,0,24.1,77777,9,999999999,220,0.1560,0,88,999.000,999.0,99.0
+1989,8,30,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,12.2,84,99400,61,972,321,26,42,22,2700,1900,2600,450,290,3.1,0,0,24.1,77777,9,999999999,220,0.1710,0,88,999.000,999.0,99.0
+1989,8,30,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,12.8,70,99400,301,1340,347,136,275,73,14100,21700,9200,1340,320,3.6,2,2,24.1,77777,9,999999999,229,0.1710,0,88,999.000,999.0,99.0
+1989,8,30,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,12.2,61,99400,545,1340,355,326,507,116,34500,48900,14500,2240,330,4.6,2,2,24.1,77777,9,999999999,220,0.1710,0,88,999.000,999.0,99.0
+1989,8,30,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,12.2,55,99500,762,1340,363,504,600,158,52000,59500,18000,3510,350,4.1,2,2,24.1,77777,9,999999999,220,0.1710,0,88,999.000,999.0,99.0
+1989,8,30,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,12.2,52,99500,937,1340,364,654,713,150,69300,72800,18300,4250,10,3.1,1,1,24.1,77777,9,999999999,229,0.1710,0,88,999.000,999.0,99.0
+1989,8,30,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,12.2,48,99500,1057,1340,374,750,683,206,78900,69400,24000,7100,360,3.6,2,2,24.1,77777,9,999999999,220,0.1710,0,88,999.000,999.0,99.0
+1989,8,30,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,12.8,47,99500,1115,1340,387,618,404,279,66500,42200,31300,11210,330,2.6,4,4,24.1,77777,9,999999999,229,0.1710,0,88,999.000,999.0,99.0
+1989,8,30,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,12.8,44,99400,1106,1340,381,795,758,163,82700,76200,19700,5820,200,2.6,1,1,24.1,77777,9,999999999,229,0.1710,0,88,999.000,999.0,99.0
+1989,8,30,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,11.7,37,99300,1031,1340,388,747,767,151,77600,77000,18200,4550,280,2.1,1,1,24.1,77777,9,999999999,220,0.1710,0,88,999.000,999.0,99.0
+1989,8,30,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,12.2,38,99300,895,1340,389,601,665,151,63300,67500,18100,4010,220,2.6,1,1,24.1,77777,9,999999999,220,0.1710,0,88,999.000,999.0,99.0
+1989,8,30,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,13.3,41,99300,708,1340,390,414,539,125,43100,53500,14700,2730,0,0.0,1,1,24.1,77777,9,999999999,240,0.1710,0,88,999.000,999.0,99.0
+1989,8,30,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,14.4,46,99300,482,1340,381,284,531,90,29100,49000,11400,1720,260,2.1,0,0,24.1,77777,9,999999999,259,0.1710,0,88,999.000,999.0,99.0
+1989,8,30,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,16.1,56,99300,233,1340,375,102,270,53,10500,18900,7200,950,0,0.0,0,0,24.1,77777,9,999999999,279,0.1710,0,88,999.000,999.0,99.0
+1989,8,30,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,15.6,62,99200,23,592,363,13,10,11,0,0,0,0,120,4.1,0,0,24.1,77777,9,999999999,270,0.1710,0,88,999.000,999.0,99.0
+1989,8,30,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,15.0,64,99300,0,0,357,0,0,0,0,0,0,0,120,4.1,0,0,16.1,77777,9,999999999,259,0.1710,0,88,999.000,999.0,99.0
+1989,8,30,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,15.6,76,99200,0,0,347,0,0,0,0,0,0,0,130,3.6,0,0,16.1,77777,9,999999999,270,0.1710,0,88,999.000,999.0,99.0
+1989,8,30,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,15.0,73,99200,0,0,347,0,0,0,0,0,0,0,130,3.1,0,0,16.1,77777,9,999999999,259,0.1710,0,88,999.000,999.0,99.0
+1989,8,30,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,14.4,76,99200,0,0,341,0,0,0,0,0,0,0,130,3.1,0,0,16.1,77777,9,999999999,250,0.1710,0,88,999.000,999.0,99.0
+1989,8,30,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,13.9,73,99200,0,0,340,0,0,0,0,0,0,0,150,2.6,0,0,16.1,77777,9,999999999,250,0.1710,0,88,999.000,999.0,99.0
+1989,8,31,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,13.9,76,99200,0,0,337,0,0,0,0,0,0,0,130,2.6,0,0,16.1,77777,9,999999999,250,0.1710,0,88,999.000,999.0,99.0
+1989,8,31,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,13.3,75,99200,0,0,335,0,0,0,0,0,0,0,180,3.1,0,0,16.1,77777,9,999999999,240,0.1710,0,88,999.000,999.0,99.0
+1989,8,31,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,13.3,75,99200,0,0,335,0,0,0,0,0,0,0,170,3.1,0,0,16.1,77777,9,999999999,240,0.1710,0,88,999.000,999.0,99.0
+1989,8,31,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,13.9,84,99200,0,0,330,0,0,0,0,0,0,0,160,2.6,0,0,16.1,77777,9,999999999,250,0.1710,0,88,999.000,999.0,99.0
+1989,8,31,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,13.9,84,99200,0,0,330,0,0,0,0,0,0,0,150,2.6,0,0,16.1,77777,9,999999999,250,0.1710,0,88,999.000,999.0,99.0
+1989,8,31,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,13.9,84,99200,59,950,330,24,34,21,2600,1500,2500,430,170,4.1,0,0,16.1,77777,9,999999999,250,0.1760,0,88,999.000,999.0,99.0
+1989,8,31,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,15.0,76,99200,297,1341,344,143,348,64,14900,27400,8800,1150,170,4.1,0,0,16.1,77777,9,999999999,259,0.1760,0,88,999.000,999.0,99.0
+1989,8,31,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,16.7,69,99100,542,1341,362,330,554,102,33800,52500,12600,1990,200,4.6,1,0,16.1,77777,9,999999999,290,0.1760,0,88,999.000,999.0,99.0
+1989,8,31,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,17.8,67,99100,759,1341,383,481,587,145,50000,58500,16800,3260,190,6.7,2,2,16.1,77777,9,999999999,309,0.1760,0,88,999.000,999.0,99.0
+1989,8,31,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,18.3,55,99000,933,1341,415,609,577,203,63200,58000,22700,5490,190,7.7,7,5,16.1,6100,9,999999999,320,0.1760,0,88,999.000,999.0,99.0
+1989,8,31,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,19.4,65,98900,1053,1341,444,259,8,252,30700,700,30200,11900,200,6.7,10,10,16.1,1680,9,999999999,340,0.1760,0,88,999.000,999.0,99.0
+1989,8,31,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,19.4,69,98900,1111,1341,437,298,5,294,35300,400,35000,13590,200,7.7,10,10,16.1,1680,9,999999999,340,0.1760,0,88,999.000,999.0,99.0
+1989,8,31,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,20.6,76,98900,1102,1341,436,265,0,265,31600,0,31600,12540,200,6.7,10,10,9.7,700,9,999999999,359,0.1760,0,88,999.000,999.0,99.0
+1989,8,31,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,21.7,87,98700,1026,1341,431,166,1,165,20300,100,20200,8340,200,6.2,10,10,8.0,370,9,999999999,379,0.1760,0,88,999.000,999.0,99.0
+1989,8,31,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,21.1,85,98600,890,1341,430,251,3,249,29200,300,29000,10910,200,6.2,10,10,9.7,460,9,999999999,379,0.1760,0,88,999.000,999.0,99.0
+1989,8,31,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,20.6,82,98500,702,1341,417,335,236,209,35700,24600,22800,4790,200,6.2,9,9,12.9,460,9,999999999,359,0.1760,0,88,999.000,999.0,99.0
+1989,8,31,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,20.6,87,98600,475,1341,423,62,10,59,7500,500,7300,2600,220,7.2,10,10,16.1,460,9,999999999,359,0.1760,0,88,999.000,999.0,99.0
+1989,8,31,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,20.6,93,98500,226,1341,417,25,3,25,3000,0,3000,1000,210,4.6,10,10,12.9,270,9,999999999,359,0.1760,0,88,999.000,999.0,99.0
+1989,8,31,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,20.0,93,98500,20,570,412,4,0,4,0,0,0,0,220,5.7,10,10,12.9,1680,9,999999999,350,0.1760,0,88,999.000,999.0,99.0
+1989,8,31,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,20.0,97,98400,0,0,410,0,0,0,0,0,0,0,270,4.1,10,10,8.0,1680,9,999999999,350,0.1760,0,88,999.000,999.0,99.0
+1989,8,31,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,19.4,93,98300,0,0,383,0,0,0,0,0,0,0,220,7.2,7,7,12.9,3050,9,999999999,340,0.1760,0,88,999.000,999.0,99.0
+1989,8,31,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.2,17.9,90,98200,0,0,399,0,0,0,0,0,0,0,200,6.6,10,10,16.1,1370,9,999999999,329,0.1760,0,88,999.000,999.0,99.0
+1989,8,31,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.7,16.4,84,98200,0,0,389,0,0,0,0,0,0,0,180,6.0,10,10,16.1,1310,9,999999999,309,0.1760,0,88,999.000,999.0,99.0
+1989,8,31,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.3,14.9,90,98100,0,0,380,0,0,0,0,0,0,0,180,5.4,10,10,16.1,1830,9,999999999,340,0.1760,0,88,999.000,999.0,99.0
+1987,9,1,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.9,13.4,86,99700,0,0,344,0,0,0,0,0,0,0,260,4.9,8,6,24.1,3050,9,999999999,189,0.1760,0,88,999.000,999.0,99.0
+1987,9,1,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.5,11.9,86,99600,0,0,335,0,0,0,0,0,0,0,260,4.3,8,6,24.1,3050,9,999999999,189,0.1760,0,88,999.000,999.0,99.0
+1987,9,1,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.0,10.4,86,99600,0,0,321,0,0,0,0,0,0,0,270,3.7,5,4,24.1,77777,9,999999999,189,0.1760,0,88,999.000,999.0,99.0
+1987,9,1,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,8.9,90,99600,0,0,304,0,0,0,0,0,0,0,260,3.1,3,1,24.1,77777,9,999999999,179,0.1760,0,88,999.000,999.0,99.0
+1987,9,1,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,8.9,93,99600,0,0,301,0,0,0,0,0,0,0,270,2.6,2,1,24.1,77777,9,999999999,179,0.1760,0,88,999.000,999.0,99.0
+1987,9,1,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,8.9,90,99700,57,928,308,20,35,17,2200,1600,2100,350,270,3.1,5,2,24.1,77777,9,999999999,179,0.0960,0,88,999.000,999.0,99.0
+1987,9,1,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,8.3,69,99700,296,1342,318,145,439,47,15000,35200,7200,880,280,4.1,2,1,24.1,77777,9,999999999,179,0.0960,0,88,999.000,999.0,99.0
+1987,9,1,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,8.3,58,99700,540,1342,324,353,694,71,36500,65900,9900,1440,280,3.6,0,0,24.1,77777,9,999999999,179,0.0960,0,88,999.000,999.0,99.0
+1987,9,1,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,7.8,49,99700,757,1342,333,546,798,90,57300,79500,12400,2080,280,3.6,0,0,24.1,77777,9,999999999,170,0.0960,0,88,999.000,999.0,99.0
+1987,9,1,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,7.2,42,99700,932,1342,347,647,742,127,67600,74400,15700,3320,250,5.7,3,1,24.1,77777,9,999999999,160,0.0960,0,88,999.000,999.0,99.0
+1987,9,1,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,7.2,40,99600,1052,1342,357,723,695,173,77000,71200,21000,5980,270,3.6,5,2,24.1,77777,9,999999999,170,0.0960,0,88,999.000,999.0,99.0
+1987,9,1,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,7.2,37,99600,1109,1342,358,782,769,141,82800,77800,18300,5260,260,6.7,5,1,24.1,77777,9,999999999,170,0.0960,0,88,999.000,999.0,99.0
+1987,9,1,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,8.3,37,99500,1100,1342,369,752,652,213,79400,66400,24800,8100,260,4.6,7,2,24.1,77777,9,999999999,179,0.0960,0,88,999.000,999.0,99.0
+1987,9,1,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,8.9,36,99400,1024,1342,376,725,728,164,77200,74600,20100,5370,310,5.7,7,2,24.1,77777,9,999999999,179,0.0960,0,88,999.000,999.0,99.0
+1987,9,1,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,8.9,36,99300,888,1342,376,612,610,205,63200,60900,22800,5140,280,5.2,8,2,24.1,77777,9,999999999,179,0.0960,0,88,999.000,999.0,99.0
+1987,9,1,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,9.4,36,99300,699,1342,374,460,639,124,48000,63300,14900,2680,270,5.2,6,1,24.1,77777,9,999999999,189,0.0960,0,88,999.000,999.0,99.0
+1987,9,1,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,9.4,39,99200,473,1342,368,276,584,68,28900,54300,9700,1350,230,5.7,3,1,24.1,77777,9,999999999,189,0.0960,0,88,999.000,999.0,99.0
+1987,9,1,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,10.0,46,99200,223,1342,351,106,384,41,10800,27300,6200,740,240,4.6,1,0,24.1,77777,9,999999999,189,0.0960,0,88,999.000,999.0,99.0
+1987,9,1,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,10.0,53,99200,19,548,341,13,31,10,0,0,0,0,230,4.6,0,0,24.1,77777,9,999999999,200,0.0960,0,88,999.000,999.0,99.0
+1987,9,1,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,10.0,53,99200,0,0,341,0,0,0,0,0,0,0,220,5.2,0,0,24.1,77777,9,999999999,200,0.0960,0,88,999.000,999.0,99.0
+1987,9,1,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,9.4,53,99100,0,0,338,0,0,0,0,0,0,0,220,6.2,0,0,24.1,77777,9,999999999,189,0.0960,0,88,999.000,999.0,99.0
+1987,9,1,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,9.4,53,99100,0,0,365,0,0,0,0,0,0,0,230,4.6,8,7,24.1,2440,9,999999999,189,0.0960,0,88,999.000,999.0,99.0
+1987,9,1,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,10.0,55,99200,0,0,390,0,0,0,0,0,0,0,270,5.2,10,10,24.1,1400,9,999999999,200,0.0960,0,88,999.000,999.0,99.0
+1987,9,1,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,11.1,65,99200,0,0,383,0,0,0,0,0,0,0,260,5.7,10,10,16.1,1400,9,999999999,209,0.0960,0,88,999.000,999.0,99.0
+1987,9,2,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,13.3,87,99200,0,0,339,0,0,0,0,0,0,0,250,3.6,4,3,24.1,77777,9,999999999,240,0.0960,0,88,999.000,999.0,99.0
+1987,9,2,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,12.8,87,99100,0,0,332,0,0,0,0,0,0,0,260,2.6,3,2,24.1,77777,9,999999999,229,0.0960,0,88,999.000,999.0,99.0
+1987,9,2,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,13.3,87,99200,0,0,374,0,0,0,0,0,0,0,310,3.1,10,10,24.1,310,9,999999999,240,0.0960,0,88,999.000,999.0,99.0
+1987,9,2,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,14.4,90,99200,0,0,378,0,0,0,0,0,0,0,10,5.7,10,10,16.1,490,9,999999999,250,0.0960,0,88,999.000,999.0,99.0
+1987,9,2,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,12.8,87,99300,0,0,353,0,0,0,0,0,0,0,30,4.6,8,8,24.1,2440,9,999999999,229,0.0960,0,88,999.000,999.0,99.0
+1987,9,2,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,12.8,87,99300,54,906,343,21,57,15,2000,2000,1900,250,20,4.1,6,6,24.1,1070,9,999999999,229,0.0850,0,88,999.000,999.0,99.0
+1987,9,2,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,13.3,81,99400,292,1342,362,95,101,72,10300,8200,8500,1560,350,5.2,8,8,24.1,580,9,999999999,240,0.0850,0,88,999.000,999.0,99.0
+1987,9,2,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,13.3,81,99500,536,1342,362,235,149,175,25500,14600,19600,4100,10,4.6,8,8,24.1,520,9,999999999,240,0.0850,0,88,999.000,999.0,99.0
+1987,9,2,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,12.2,68,99500,754,1342,369,350,175,251,38100,18200,27900,6560,20,7.7,8,8,24.1,760,9,999999999,220,0.0850,0,88,999.000,999.0,99.0
+1987,9,2,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,11.1,63,99600,928,1342,362,436,167,319,47500,17700,35300,9560,30,7.2,8,7,24.1,880,9,999999999,209,0.0850,0,88,999.000,999.0,99.0
+1987,9,2,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,12.2,63,99600,1048,1342,368,410,200,252,45500,21700,28500,8180,20,6.2,8,7,24.1,880,9,999999999,220,0.0850,0,88,999.000,999.0,99.0
+1987,9,2,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,12.2,61,99600,1105,1342,371,480,224,294,53100,24400,33000,10820,20,4.1,8,7,24.1,880,9,999999999,220,0.0850,0,88,999.000,999.0,99.0
+1987,9,2,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,11.7,57,99700,1095,1342,374,601,429,248,65300,44900,28600,9370,50,6.7,8,7,24.1,880,9,999999999,220,0.0850,0,88,999.000,999.0,99.0
+1987,9,2,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,11.1,59,99700,1019,1342,381,472,169,342,51700,18000,38000,11360,50,7.2,10,9,24.1,880,9,999999999,209,0.0850,0,88,999.000,999.0,99.0
+1987,9,2,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,10.6,55,99700,882,1342,353,606,687,151,63900,69600,18100,3930,40,7.2,8,2,24.1,77777,9,999999999,200,0.0850,0,88,999.000,999.0,99.0
+1987,9,2,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,10.6,57,99700,693,1342,345,414,594,105,43700,59200,13100,2310,10,6.7,5,1,24.1,77777,9,999999999,200,0.0850,0,88,999.000,999.0,99.0
+1987,9,2,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,9.4,55,99700,466,1342,342,273,588,67,28600,54500,9700,1320,50,5.2,3,1,24.1,77777,9,999999999,189,0.0850,0,88,999.000,999.0,99.0
+1987,9,2,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,10.0,63,99800,216,1342,328,104,390,40,10600,27300,6200,720,40,5.2,2,0,24.1,77777,9,999999999,200,0.0850,0,88,999.000,999.0,99.0
+1987,9,2,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,10.0,70,99800,17,503,321,13,34,9,0,0,0,0,10,4.1,1,0,24.1,77777,9,999999999,200,0.0850,0,88,999.000,999.0,99.0
+1987,9,2,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,10.6,72,99800,0,0,322,0,0,0,0,0,0,0,30,3.6,0,0,24.1,77777,9,999999999,200,0.0850,0,88,999.000,999.0,99.0
+1987,9,2,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,10.0,80,99900,0,0,311,0,0,0,0,0,0,0,10,2.6,1,0,24.1,77777,9,999999999,189,0.0850,0,88,999.000,999.0,99.0
+1987,9,2,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,10.0,80,99900,0,0,317,0,0,0,0,0,0,0,30,2.6,3,1,24.1,77777,9,999999999,189,0.0850,0,88,999.000,999.0,99.0
+1987,9,2,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,10.0,86,99900,0,0,306,0,0,0,0,0,0,0,20,2.1,0,0,24.1,77777,9,999999999,189,0.0850,0,88,999.000,999.0,99.0
+1987,9,2,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,10.0,96,99900,0,0,299,0,0,0,0,0,0,0,310,2.1,0,0,24.1,77777,9,999999999,200,0.0850,0,88,999.000,999.0,99.0
+1987,9,3,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,10.0,96,99900,0,0,299,0,0,0,0,0,0,0,270,1.5,0,0,24.1,77777,9,999999999,200,0.0850,0,88,999.000,999.0,99.0
+1987,9,3,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,9.4,96,99900,0,0,296,0,0,0,0,0,0,0,310,1.5,0,0,24.1,77777,9,999999999,189,0.0850,0,88,999.000,999.0,99.0
+1987,9,3,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,9.4,96,99900,0,0,296,0,0,0,0,0,0,0,310,1.5,0,0,24.1,77777,9,999999999,189,0.0850,0,88,999.000,999.0,99.0
+1987,9,3,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,8.9,96,100000,0,0,293,0,0,0,0,0,0,0,320,1.5,0,0,16.1,77777,9,999999999,179,0.0850,0,88,999.000,999.0,99.0
+1987,9,3,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,8.9,96,100000,0,0,293,0,0,0,0,0,0,0,330,1.5,0,0,24.1,77777,9,999999999,179,0.0850,0,88,999.000,999.0,99.0
+1987,9,3,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,8.9,96,100000,52,884,293,21,15,20,2300,800,2200,480,270,1.5,0,0,24.1,77777,9,999999999,179,0.2260,0,88,999.000,999.0,99.0
+1987,9,3,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,12.2,84,100100,288,1343,321,128,268,69,13200,20700,8700,1260,300,1.5,0,0,24.1,77777,9,999999999,220,0.2260,0,88,999.000,999.0,99.0
+1987,9,3,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,11.7,65,100100,532,1343,335,312,495,113,33100,47500,14200,2170,100,5.2,0,0,24.1,77777,9,999999999,220,0.2260,0,88,999.000,999.0,99.0
+1987,9,3,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,8.9,49,100100,750,1343,340,504,628,150,52200,62300,17400,3310,70,4.6,0,0,24.1,77777,9,999999999,179,0.2260,0,88,999.000,999.0,99.0
+1987,9,3,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,8.3,44,100100,924,1343,344,666,705,176,69800,71300,20600,4780,110,6.2,0,0,24.1,77777,9,999999999,179,0.2260,0,88,999.000,999.0,99.0
+1987,9,3,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,7.8,41,100100,1044,1343,346,778,747,192,82200,76100,22800,6450,120,5.2,0,0,24.1,77777,9,999999999,170,0.2260,0,88,999.000,999.0,99.0
+1987,9,3,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,7.8,41,100000,1101,1343,346,831,763,200,88100,77900,24000,7650,90,5.7,0,0,24.1,77777,9,999999999,170,0.2260,0,88,999.000,999.0,99.0
+1987,9,3,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,7.2,38,100000,1091,1343,348,822,762,198,87100,77800,23800,7390,130,5.2,0,0,24.1,77777,9,999999999,170,0.2260,0,88,999.000,999.0,99.0
+1987,9,3,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,7.2,38,100000,1014,1343,348,750,737,188,79000,75000,22200,5940,80,5.2,0,0,24.1,77777,9,999999999,170,0.2260,0,88,999.000,999.0,99.0
+1987,9,3,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,7.8,41,99900,877,1343,346,622,688,169,65000,69300,19600,4290,100,4.6,0,0,24.1,77777,9,999999999,170,0.2260,0,88,999.000,999.0,99.0
+1987,9,3,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,8.3,44,99900,687,1343,344,450,600,140,46500,58900,16300,2930,90,4.1,0,0,24.1,77777,9,999999999,179,0.2260,0,88,999.000,999.0,99.0
+1987,9,3,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,8.9,47,99900,460,1343,343,255,447,100,26900,41200,12700,1880,90,4.6,0,0,24.1,77777,9,999999999,179,0.2260,0,88,999.000,999.0,99.0
+1987,9,3,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,8.3,54,99900,210,1343,329,81,172,54,8600,11200,6800,1010,50,5.2,0,0,24.1,77777,9,999999999,179,0.2260,0,88,999.000,999.0,99.0
+1987,9,3,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,8.3,58,99900,14,481,324,9,2,8,0,0,0,0,10,3.1,0,0,24.1,77777,9,999999999,179,0.2260,0,88,999.000,999.0,99.0
+1987,9,3,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,8.9,60,99900,0,0,325,0,0,0,0,0,0,0,50,3.1,0,0,24.1,77777,9,999999999,179,0.2260,0,88,999.000,999.0,99.0
+1987,9,3,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,10.6,75,99900,0,0,319,0,0,0,0,0,0,0,30,2.6,2,0,24.1,77777,9,999999999,200,0.2260,0,88,999.000,999.0,99.0
+1987,9,3,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,11.7,75,99900,0,0,325,0,0,0,0,0,0,0,60,3.1,3,0,24.1,77777,9,999999999,220,0.2260,0,88,999.000,999.0,99.0
+1987,9,3,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,11.7,90,99900,0,0,313,0,0,0,0,0,0,0,20,2.6,0,0,24.1,77777,9,999999999,220,0.2260,0,88,999.000,999.0,99.0
+1987,9,3,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,11.1,93,99900,0,0,307,0,0,0,0,0,0,0,10,2.1,0,0,16.1,77777,9,999999999,209,0.2260,0,88,999.000,999.0,99.0
+1987,9,4,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,11.1,93,99900,0,0,307,0,0,0,0,0,0,0,170,2.1,0,0,11.3,77777,9,999999999,209,0.2260,0,88,999.000,999.0,99.0
+1987,9,4,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,11.1,90,99900,0,0,310,0,0,0,0,0,0,0,140,1.5,0,0,11.3,77777,9,999999999,209,0.2260,0,88,999.000,999.0,99.0
+1987,9,4,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,11.7,87,99900,0,0,315,0,0,0,0,0,0,0,110,2.1,0,0,11.3,77777,9,999999999,220,0.2260,0,88,999.000,999.0,99.0
+1987,9,4,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,11.1,87,99900,0,0,312,0,0,0,0,0,0,0,130,2.1,0,0,11.3,77777,9,999999999,209,0.2260,0,88,999.000,999.0,99.0
+1987,9,4,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,11.1,93,99900,0,0,307,0,0,0,0,0,0,0,130,2.1,1,0,11.3,77777,9,999999999,209,0.2260,0,88,999.000,999.0,99.0
+1987,9,4,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,11.1,87,99900,49,862,312,22,33,18,2200,1400,2100,370,130,2.6,1,0,8.0,77777,9,999999999,209,0.1560,0,88,999.000,999.0,99.0
+1987,9,4,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,11.1,75,99900,284,1344,322,137,367,58,14400,28300,8400,1040,130,3.1,0,0,9.7,77777,9,999999999,209,0.1560,0,88,999.000,999.0,99.0
+1987,9,4,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,11.1,63,99900,529,1344,334,328,593,92,34000,56100,11800,1810,180,3.6,0,0,12.9,77777,9,999999999,209,0.1560,0,88,999.000,999.0,99.0
+1987,9,4,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,11.7,55,99900,746,1344,348,517,709,119,54400,71100,14800,2710,170,2.6,0,0,16.1,77777,9,999999999,220,0.1560,0,88,999.000,999.0,99.0
+1987,9,4,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,12.2,52,99900,921,1344,357,675,774,139,69600,77200,16500,3430,170,3.1,0,0,16.1,77777,9,999999999,229,0.1560,0,88,999.000,999.0,99.0
+1987,9,4,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,13.3,50,99800,1040,1344,366,781,806,151,81300,81000,18400,4620,170,2.6,0,0,16.1,77777,9,999999999,240,0.1560,0,88,999.000,999.0,99.0
+1987,9,4,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,14.4,49,99800,1097,1344,376,831,819,157,86900,82400,19400,5480,140,2.6,0,0,16.1,77777,9,999999999,259,0.1560,0,88,999.000,999.0,99.0
+1987,9,4,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,13.9,44,99700,1086,1344,381,821,817,156,85800,82200,19200,5300,130,3.1,0,0,16.1,77777,9,999999999,250,0.1560,0,88,999.000,999.0,99.0
+1987,9,4,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,16.1,48,99700,1009,1344,389,748,792,148,77700,79400,17900,4250,140,5.2,0,0,16.1,77777,9,999999999,279,0.1560,0,88,999.000,999.0,99.0
+1987,9,4,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,15.6,44,99600,871,1344,391,625,751,134,66400,76400,16700,3480,170,3.1,0,0,16.1,77777,9,999999999,270,0.1560,0,88,999.000,999.0,99.0
+1987,9,4,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,15.6,47,99600,681,1344,386,456,674,111,47800,66800,13900,2400,150,3.6,0,0,16.1,77777,9,999999999,270,0.1560,0,88,999.000,999.0,99.0
+1987,9,4,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,15.0,51,99600,453,1344,376,263,533,81,27100,48600,10700,1540,120,4.6,0,0,16.1,77777,9,999999999,270,0.1560,0,88,999.000,999.0,99.0
+1987,9,4,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,14.4,52,99600,203,1344,370,85,251,46,8800,16300,6300,820,120,4.1,0,0,12.9,77777,9,999999999,250,0.1560,0,88,999.000,999.0,99.0
+1987,9,4,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,14.4,62,99600,12,437,356,8,6,7,0,0,0,0,120,3.1,0,0,12.9,77777,9,999999999,259,0.1560,0,88,999.000,999.0,99.0
+1987,9,4,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,15.6,71,99600,0,0,353,0,0,0,0,0,0,0,120,2.6,0,0,12.9,77777,9,999999999,270,0.1560,0,88,999.000,999.0,99.0
+1987,9,4,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,16.1,73,99600,0,0,353,0,0,0,0,0,0,0,150,3.1,0,0,12.9,77777,9,999999999,279,0.1560,0,88,999.000,999.0,99.0
+1987,9,4,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,15.0,66,99600,0,0,355,0,0,0,0,0,0,0,140,3.1,0,0,12.9,77777,9,999999999,259,0.1560,0,88,999.000,999.0,99.0
+1987,9,4,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,14.4,73,99600,0,0,343,0,0,0,0,0,0,0,170,3.1,0,0,12.9,77777,9,999999999,250,0.1560,0,88,999.000,999.0,99.0
+1987,9,4,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,14.4,73,99500,0,0,343,0,0,0,0,0,0,0,170,3.1,0,0,11.3,77777,9,999999999,250,0.1560,0,88,999.000,999.0,99.0
+1987,9,5,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,13.9,70,99500,0,0,343,0,0,0,0,0,0,0,170,4.6,0,0,11.3,77777,9,999999999,240,0.1560,0,88,999.000,999.0,99.0
+1987,9,5,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,13.3,70,99500,0,0,340,0,0,0,0,0,0,0,180,4.1,0,0,11.3,77777,9,999999999,240,0.1560,0,88,999.000,999.0,99.0
+1987,9,5,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,13.3,75,99500,0,0,335,0,0,0,0,0,0,0,170,3.1,0,0,11.3,77777,9,999999999,240,0.1560,0,88,999.000,999.0,99.0
+1987,9,5,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,12.8,81,99500,0,0,326,0,0,0,0,0,0,0,190,1.5,0,0,11.3,77777,9,999999999,229,0.1560,0,88,999.000,999.0,99.0
+1987,9,5,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,13.3,90,99500,0,0,322,0,0,0,0,0,0,0,0,0.0,0,0,11.3,77777,9,999999999,240,0.1560,0,88,999.000,999.0,99.0
+1987,9,5,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,13.3,93,99600,47,840,319,20,14,18,2100,800,2000,440,0,0.0,0,0,8.0,77777,9,999999999,240,0.2170,0,88,999.000,999.0,99.0
+1987,9,5,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,14.4,78,99600,280,1344,338,124,271,67,12900,20700,8600,1220,170,1.5,0,0,8.0,77777,9,999999999,250,0.2170,0,88,999.000,999.0,99.0
+1987,9,5,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,14.4,64,99600,525,1344,354,309,503,110,32800,48100,14000,2110,180,3.1,0,0,8.0,77777,9,999999999,259,0.2170,0,88,999.000,999.0,99.0
+1987,9,5,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,15.0,56,99600,742,1344,368,497,631,145,51600,62600,16900,3190,160,2.1,0,0,11.3,77777,9,999999999,259,0.2170,0,88,999.000,999.0,99.0
+1987,9,5,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,15.6,51,99600,917,1344,380,654,702,170,68600,71100,20000,4580,180,2.1,0,0,19.3,77777,9,999999999,270,0.2170,0,88,999.000,999.0,99.0
+1987,9,5,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,15.6,46,99500,1036,1344,388,764,742,186,80700,75700,22200,6150,180,2.6,0,0,19.3,77777,9,999999999,270,0.2170,0,88,999.000,999.0,99.0
+1987,9,5,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,13.9,39,99500,1092,1344,392,816,760,193,86600,77700,23300,7230,230,3.1,0,0,19.3,77777,9,999999999,250,0.2170,0,88,999.000,999.0,99.0
+1987,9,5,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,13.3,35,99400,1081,1344,415,733,612,237,76700,61900,26800,8460,190,2.6,3,3,14.5,77777,9,999999999,240,0.2170,0,88,999.000,999.0,99.0
+1987,9,5,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,11.7,30,99400,1004,1344,418,679,591,234,70400,59400,26000,7040,150,4.1,4,4,14.5,77777,9,999999999,209,0.2170,0,88,999.000,999.0,99.0
+1987,9,5,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.6,12.8,34,99300,865,1344,414,575,567,207,61400,58500,23600,5200,200,3.1,3,3,11.3,77777,9,999999999,229,0.2170,0,88,999.000,999.0,99.0
+1987,9,5,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,13.9,40,99300,675,1344,389,436,594,134,45000,58200,15700,2790,130,4.1,0,0,11.3,77777,9,999999999,250,0.2170,0,88,999.000,999.0,99.0
+1987,9,5,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,12.8,41,99200,447,1344,379,244,440,96,25800,40200,12400,1790,130,4.6,0,0,11.3,77777,9,999999999,229,0.2170,0,88,999.000,999.0,99.0
+1987,9,5,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,12.2,45,99200,196,1344,368,74,155,51,7800,9600,6400,950,120,3.6,1,0,11.3,77777,9,999999999,220,0.2170,0,88,999.000,999.0,99.0
+1987,9,5,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,13.9,57,99200,10,392,366,3,1,3,0,0,0,0,130,2.6,2,1,11.3,77777,9,999999999,240,0.2170,0,88,999.000,999.0,99.0
+1987,9,5,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,13.3,57,99200,0,0,367,0,0,0,0,0,0,0,140,2.1,6,2,11.3,77777,9,999999999,240,0.2170,0,88,999.000,999.0,99.0
+1987,9,5,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,14.4,66,99200,0,0,369,0,0,0,0,0,0,0,140,1.5,10,4,11.3,77777,9,999999999,250,0.2170,0,88,999.000,999.0,99.0
+1987,9,5,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,15.6,71,99200,0,0,371,0,0,0,0,0,0,0,140,2.6,10,4,11.3,77777,9,999999999,270,0.2170,0,88,999.000,999.0,99.0
+1987,9,5,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,16.7,81,99200,0,0,355,0,0,0,0,0,0,0,150,1.5,6,1,9.7,77777,9,999999999,290,0.2170,0,88,999.000,999.0,99.0
+1987,9,5,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,16.1,87,99200,0,0,340,0,0,0,0,0,0,0,0,0.0,2,0,9.7,77777,9,999999999,279,0.2170,0,88,999.000,999.0,99.0
+1987,9,6,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,16.7,90,99100,0,0,352,0,0,0,0,0,0,0,180,2.1,3,2,8.0,77777,9,999999999,290,0.2170,0,88,999.000,999.0,99.0
+1987,9,6,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,16.1,84,99100,0,0,343,0,0,0,0,0,0,0,160,2.1,2,0,8.0,77777,9,999999999,279,0.2170,0,88,999.000,999.0,99.0
+1987,9,6,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,15.0,84,99100,0,0,343,0,0,0,0,0,0,0,180,2.1,3,1,8.0,77777,9,999999999,259,0.2170,0,88,999.000,999.0,99.0
+1987,9,6,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,15.0,81,99100,0,0,345,0,0,0,0,0,0,0,180,2.6,3,1,8.0,77777,9,999999999,259,0.2170,0,88,999.000,999.0,99.0
+1987,9,6,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,15.0,84,99100,0,0,336,0,0,0,0,0,0,0,190,2.1,2,0,8.0,77777,9,999999999,259,0.2170,0,88,999.000,999.0,99.0
+1987,9,6,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,15.0,84,99100,44,818,347,20,32,17,2100,1300,2000,350,190,1.5,7,2,8.0,77777,9,999999999,259,0.1170,0,88,999.000,999.0,99.0
+1987,9,6,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,15.6,76,99100,275,1345,347,138,395,55,13900,30400,7700,980,190,2.6,3,0,8.0,77777,9,999999999,270,0.1170,0,88,999.000,999.0,99.0
+1987,9,6,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,16.1,69,99100,521,1345,365,315,593,82,32800,56200,11000,1630,170,3.1,1,1,8.0,77777,9,999999999,279,0.1170,0,88,999.000,999.0,99.0
+1987,9,6,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,16.1,58,99100,739,1345,372,511,735,102,52700,72500,12800,2200,200,2.6,1,0,9.7,77777,9,999999999,279,0.1170,0,88,999.000,999.0,99.0
+1987,9,6,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,16.7,51,99100,913,1345,395,625,716,134,66600,73200,16800,3680,220,3.1,1,1,11.3,77777,9,999999999,290,0.1170,0,88,999.000,999.0,99.0
+1987,9,6,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,30.0,17.2,46,99100,1032,1345,399,769,830,126,81500,84000,16900,3980,190,3.6,0,0,11.3,77777,9,999999999,300,0.1170,0,88,999.000,999.0,99.0
+1987,9,6,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,29.4,17.2,48,99100,1088,1345,423,695,519,272,74800,54200,30800,10100,190,5.2,6,6,11.3,1680,9,999999999,300,0.1170,0,88,999.000,999.0,99.0
+1987,9,6,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,18.3,55,99100,1077,1345,405,713,637,198,75400,65000,23200,7110,300,5.2,2,2,9.7,77777,9,999999999,320,0.1170,0,88,999.000,999.0,99.0
+1987,9,6,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,16.1,46,99100,999,1345,440,456,151,343,49900,16000,38000,11080,270,3.1,9,9,12.9,3050,9,999999999,279,0.1170,0,88,999.000,999.0,99.0
+1987,9,6,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,17.8,60,99000,860,1345,438,242,12,234,28100,1000,27400,10220,320,2.1,10,10,14.5,2440,9,999999999,309,0.1170,0,88,999.000,999.0,99.0
+1987,9,6,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,17.2,56,99000,669,1345,429,254,68,220,27900,6800,24500,6510,350,1.5,9,9,16.1,3050,9,999999999,300,0.1170,0,88,999.000,999.0,99.0
+1987,9,6,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,20.0,72,99000,440,1345,411,198,228,123,21000,21200,14100,2470,0,0.0,8,7,16.1,3050,9,999999999,350,0.1170,0,88,999.000,999.0,99.0
+1987,9,6,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,19.4,74,99000,189,1345,410,56,22,53,6100,1600,5900,1260,0,0.0,8,8,12.9,3050,9,999999999,340,0.1170,0,88,999.000,999.0,99.0
+1987,9,6,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,19.4,79,99000,8,370,404,3,0,2,0,0,0,0,0,0.0,10,8,12.9,1680,9,999999999,340,0.1170,0,88,999.000,999.0,99.0
+1987,9,6,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,19.4,87,99100,0,0,395,0,0,0,0,0,0,0,240,1.5,10,8,12.9,1680,9,999999999,340,0.1170,0,88,999.000,999.0,99.0
+1987,9,6,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,19.4,87,99100,0,0,404,0,0,0,0,0,0,0,230,2.1,10,9,12.9,1830,9,999999999,340,0.1170,0,88,999.000,999.0,99.0
+1987,9,6,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.2,18.9,82,99100,0,0,417,0,0,0,0,0,0,0,260,1.5,10,10,12.9,1830,9,999999999,329,0.1170,0,88,999.000,999.0,99.0
+1987,9,6,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,18.3,81,99100,0,0,414,0,0,0,0,0,0,0,260,2.6,10,10,12.9,1830,9,999999999,320,0.1170,0,88,999.000,999.0,99.0
+1987,9,6,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,18.3,81,99100,0,0,414,0,0,0,0,0,0,0,270,2.1,10,10,12.9,1830,9,999999999,320,0.1170,0,88,999.000,999.0,99.0
+1987,9,7,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,18.9,87,99100,0,0,411,0,0,0,0,0,0,0,0,0.0,10,10,12.9,1830,9,999999999,329,0.1170,0,88,999.000,999.0,99.0
+1987,9,7,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,18.3,90,99100,0,0,404,0,0,0,0,0,0,0,0,0.0,10,10,12.9,2130,9,999999999,320,0.1170,0,88,999.000,999.0,99.0
+1987,9,7,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,18.3,93,99100,0,0,382,0,0,0,0,0,0,0,0,0.0,10,8,12.9,2130,9,999999999,320,0.1170,0,88,999.000,999.0,99.0
+1987,9,7,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,17.8,93,99100,0,0,362,0,0,0,0,0,0,0,0,0.0,9,4,12.9,77777,9,999999999,309,0.1170,0,88,999.000,999.0,99.0
+1987,9,7,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,18.3,93,99100,0,0,401,0,0,0,0,0,0,0,0,0.0,10,10,12.9,1160,9,999999999,320,0.1170,0,88,999.000,999.0,99.0
+1987,9,7,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,18.3,90,99200,42,796,404,11,2,10,1200,0,1200,370,0,0.0,10,10,11.3,2130,9,999999999,320,0.1090,0,88,999.000,999.0,99.0
+1987,9,7,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,18.3,87,99200,271,1346,408,67,3,66,7500,100,7500,2320,280,4.6,10,10,11.3,1160,9,999999999,320,0.1090,0,88,999.000,999.0,99.0
+1987,9,7,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,18.3,87,99200,517,1346,408,124,3,122,14100,200,14000,4850,270,4.1,10,10,9.7,1400,9,999999999,320,0.1090,0,88,999.000,999.0,99.0
+1987,9,7,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,18.3,81,99200,735,1346,414,219,9,214,25000,800,24600,8770,290,3.6,10,10,11.3,1400,9,999999999,320,0.1090,0,88,999.000,999.0,99.0
+1987,9,7,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,18.3,76,99200,909,1346,420,267,4,264,30900,400,30700,11480,10,2.1,10,10,12.9,1520,9,999999999,320,0.1090,0,88,999.000,999.0,99.0
+1987,9,7,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,18.3,71,99200,1028,1346,426,317,3,315,36900,300,36700,13860,10,2.6,10,10,16.1,1520,9,999999999,320,0.1090,0,88,999.000,999.0,99.0
+1987,9,7,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,18.3,71,99200,1084,1346,426,389,5,385,45000,500,44600,16200,30,2.1,10,10,16.1,1520,9,999999999,320,0.1090,0,88,999.000,999.0,99.0
+1987,9,7,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,20.0,82,99200,1072,1346,425,410,0,410,47100,0,47100,16740,10,4.6,10,10,14.5,3050,9,999999999,350,0.1090,0,88,999.000,999.0,99.0
+1987,9,7,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,19.4,82,99200,994,1346,421,379,0,378,43200,0,43200,15260,60,3.6,10,10,9.7,1400,9,999999999,340,0.1090,0,88,999.000,999.0,99.0
+1987,9,7,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,18.9,82,99100,854,1346,417,310,1,309,35100,100,35100,12230,50,4.1,10,10,9.7,1400,9,999999999,329,0.1090,0,88,999.000,999.0,99.0
+1987,9,7,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,18.9,84,99100,663,1346,414,219,0,219,24700,0,24700,8330,360,3.6,10,10,8.0,1400,9,999999999,329,0.1090,0,88,999.000,999.0,99.0
+1987,9,7,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,18.9,84,99100,433,1346,414,129,1,129,14400,100,14400,4580,30,3.6,10,10,8.0,1400,9,999999999,329,0.1090,0,88,999.000,999.0,99.0
+1987,9,7,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,18.9,87,99000,182,1346,411,50,0,50,5500,0,5500,1610,20,3.6,10,10,6.4,2130,9,999999999,329,0.1090,0,88,999.000,999.0,99.0
+1987,9,7,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,18.9,90,99000,6,325,408,4,0,4,0,0,0,0,360,4.1,10,10,6.4,1980,9,999999999,329,0.1090,0,88,999.000,999.0,99.0
+1987,9,7,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,18.9,90,99100,0,0,408,0,0,0,0,0,0,0,90,2.6,10,10,6.4,1400,9,999999999,329,0.1090,0,88,999.000,999.0,99.0
+1987,9,7,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,18.9,93,99100,0,0,405,0,0,0,0,0,0,0,20,3.6,10,10,6.4,150,9,999999999,329,0.1090,0,88,999.000,999.0,99.0
+1987,9,7,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,18.3,93,99100,0,0,401,0,0,0,0,0,0,0,30,3.1,10,10,6.4,180,9,999999999,320,0.1090,0,88,999.000,999.0,99.0
+1987,9,7,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,17.8,90,99100,0,0,400,0,0,0,0,0,0,0,20,3.1,10,10,11.3,210,9,999999999,309,0.1090,0,88,999.000,999.0,99.0
+1987,9,7,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,17.2,87,99100,0,0,400,0,0,0,0,0,0,0,20,3.1,10,10,11.3,240,9,999999999,300,0.1090,0,88,999.000,999.0,99.0
+1987,9,8,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,17.2,87,99000,0,0,389,0,0,0,0,0,0,0,360,3.1,9,9,11.3,270,9,999999999,300,0.1090,0,88,999.000,999.0,99.0
+1987,9,8,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,17.2,90,99000,0,0,397,0,0,0,0,0,0,0,40,1.5,10,10,8.0,150,9,999999999,300,0.1090,0,88,999.000,999.0,99.0
+1987,9,8,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,17.2,93,98900,0,0,394,0,0,0,0,0,0,0,360,3.1,10,10,9.7,150,9,999999999,300,0.1090,0,88,999.000,999.0,99.0
+1987,9,8,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,16.7,93,99000,0,0,390,0,0,0,0,0,0,0,0,0.0,10,10,4.0,120,9,999999999,290,0.1090,0,88,999.000,999.0,99.0
+1987,9,8,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,17.2,97,99000,0,0,391,0,0,0,0,0,0,0,300,1.5,10,10,4.0,150,9,999999999,300,0.1090,0,88,999.000,999.0,99.0
+1987,9,8,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,16.7,90,99000,39,774,393,15,0,15,1700,0,1700,520,280,1.5,10,10,2.4,180,9,999999999,290,0.0840,0,88,999.000,999.0,99.0
+1987,9,8,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,17.2,90,99000,267,1346,397,75,1,75,8300,0,8300,2500,0,0.0,10,10,2.4,180,9,999999999,300,0.0840,0,88,999.000,999.0,99.0
+1987,9,8,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,16.7,81,99000,513,1346,402,182,1,181,20100,100,20100,6240,300,2.1,10,10,3.2,1680,9,999999999,290,0.0840,0,88,999.000,999.0,99.0
+1987,9,8,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,17.2,81,99000,731,1346,406,251,1,251,28400,100,28300,9680,280,2.1,10,10,3.2,880,9,999999999,300,0.0840,0,88,999.000,999.0,99.0
+1987,9,8,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,17.2,81,99100,905,1346,406,324,1,323,36900,100,36800,13070,270,3.6,10,10,3.2,760,9,999999999,300,0.0840,0,88,999.000,999.0,99.0
+1987,9,8,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,17.2,71,99100,1024,1346,398,539,228,363,58700,24200,40300,12090,260,3.1,8,8,8.0,520,9,999999999,300,0.0840,0,88,999.000,999.0,99.0
+1987,9,8,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,17.2,66,99000,1079,1346,404,432,53,390,47700,5500,43300,15410,260,3.1,8,8,8.0,580,9,999999999,300,0.0840,0,88,999.000,999.0,99.0
+1987,9,8,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,16.7,60,99000,1067,1346,410,514,280,290,56500,30400,32400,9840,250,3.6,8,8,8.0,760,9,999999999,290,0.0840,0,88,999.000,999.0,99.0
+1987,9,8,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,17.2,60,98900,988,1346,399,695,694,181,73200,70600,21300,5440,250,3.1,5,5,8.0,77777,9,999999999,300,0.0840,0,88,999.000,999.0,99.0
+1987,9,8,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,16.7,56,98900,848,1346,405,539,469,241,56500,48200,26100,6020,290,3.1,6,6,8.0,910,9,999999999,290,0.0840,0,88,999.000,999.0,99.0
+1987,9,8,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,16.7,54,98800,656,1346,401,375,476,140,40000,47600,16700,2880,300,1.5,4,4,9.7,77777,9,999999999,290,0.0840,0,88,999.000,999.0,99.0
+1987,9,8,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,16.1,56,98900,426,1346,398,198,324,94,20800,29200,11600,1750,0,0.0,5,5,11.3,77777,9,999999999,279,0.0840,0,88,999.000,999.0,99.0
+1987,9,8,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,18.3,71,98900,175,1346,414,47,15,45,5100,1100,5000,1090,310,2.1,9,9,11.3,1010,9,999999999,320,0.0840,0,88,999.000,999.0,99.0
+1987,9,8,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,17.8,79,98900,5,280,376,3,8,2,0,0,0,0,130,3.1,4,4,8.0,77777,9,999999999,309,0.0840,0,88,999.000,999.0,99.0
+1987,9,8,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,17.8,84,99000,0,0,364,0,0,0,0,0,0,0,160,2.1,2,2,8.0,77777,9,999999999,309,0.0840,0,88,999.000,999.0,99.0
+1987,9,8,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,17.8,93,99000,0,0,345,0,0,0,0,0,0,0,320,2.6,0,0,8.0,77777,9,999999999,309,0.0840,0,88,999.000,999.0,99.0
+1987,9,8,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,17.2,93,99000,0,0,341,0,0,0,0,0,0,0,10,2.6,0,0,8.0,77777,9,999999999,300,0.0840,0,88,999.000,999.0,99.0
+1987,9,8,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,18.3,97,99100,0,0,398,0,0,0,0,0,0,0,340,3.1,10,10,4.8,120,9,999999999,320,0.0840,0,88,999.000,999.0,99.0
+1987,9,8,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,17.2,97,99100,0,0,391,0,0,0,0,0,0,0,320,2.1,10,10,4.8,150,9,999999999,300,0.0840,0,88,999.000,999.0,99.0
+1987,9,9,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,17.2,97,99100,0,0,380,0,0,0,0,0,0,0,320,2.1,10,9,4.8,150,9,999999999,300,0.0840,0,88,999.000,999.0,99.0
+1987,9,9,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,17.2,97,99100,0,0,391,0,0,0,0,0,0,0,310,2.1,10,10,0.8,30,9,999999999,300,0.0840,0,88,999.000,999.0,99.0
+1987,9,9,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,16.1,97,99100,0,0,373,0,0,0,0,0,0,0,330,2.1,10,9,3.2,120,9,999999999,279,0.0840,0,88,999.000,999.0,99.0
+1987,9,9,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,15.6,100,99200,0,0,327,0,0,0,0,0,0,0,300,2.1,0,0,8.0,77777,9,999999999,270,0.0840,0,88,999.000,999.0,99.0
+1987,9,9,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,13.9,97,99200,0,0,320,0,0,0,0,0,0,0,260,1.5,0,0,11.3,77777,9,999999999,250,0.0840,0,88,999.000,999.0,99.0
+1987,9,9,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,14.4,100,99200,37,752,320,21,55,15,1900,1600,1900,260,310,1.5,0,0,11.3,77777,9,999999999,250,0.1040,0,88,999.000,999.0,99.0
+1987,9,9,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,15.0,87,99200,263,1347,334,133,436,46,13500,33200,7000,840,350,2.1,0,0,16.1,77777,9,999999999,259,0.1040,0,88,999.000,999.0,99.0
+1987,9,9,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,15.0,78,99200,509,1347,369,237,189,165,25600,18300,18700,3820,320,1.5,7,7,16.1,6100,9,999999999,259,0.1040,0,88,999.000,999.0,99.0
+1987,9,9,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,15.0,66,99300,727,1347,366,462,634,115,48400,63400,14200,2580,290,2.1,2,2,24.1,77777,9,999999999,259,0.1040,0,88,999.000,999.0,99.0
+1987,9,9,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,15.0,62,99300,901,1347,372,633,704,157,66600,71400,18700,4160,10,2.6,2,2,24.1,77777,9,999999999,259,0.1040,0,88,999.000,999.0,99.0
+1987,9,9,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,15.0,60,99300,1020,1347,387,518,285,299,56400,30900,33000,9440,300,3.6,6,6,24.1,1220,9,999999999,259,0.1040,0,88,999.000,999.0,99.0
+1987,9,9,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,13.9,49,99200,1075,1347,395,588,299,347,63900,32400,37900,12210,270,3.1,5,5,24.1,77777,9,999999999,250,0.1040,0,88,999.000,999.0,99.0
+1987,9,9,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,13.3,50,99200,1062,1347,388,716,633,213,75300,64200,24500,7310,280,1.5,5,5,24.1,77777,9,999999999,240,0.1040,0,88,999.000,999.0,99.0
+1987,9,9,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,14.4,49,99200,983,1347,402,632,531,240,67600,55200,27200,7150,70,2.6,6,6,24.1,1370,9,999999999,250,0.1040,0,88,999.000,999.0,99.0
+1987,9,9,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,15.6,66,99200,842,1347,393,438,214,303,47500,22400,33500,8400,70,4.1,8,8,24.1,1370,9,999999999,270,0.1040,0,88,999.000,999.0,99.0
+1987,9,9,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,14.4,56,99200,650,1347,384,423,607,127,43700,59200,15000,2610,40,4.1,4,4,24.1,77777,9,999999999,259,0.1040,0,88,999.000,999.0,99.0
+1987,9,9,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,13.3,57,99200,419,1347,367,238,503,80,24400,44700,10500,1490,60,3.6,2,2,24.1,77777,9,999999999,240,0.1040,0,88,999.000,999.0,99.0
+1987,9,9,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,13.3,63,99200,168,1347,359,69,167,48,7200,9400,6000,910,90,3.6,2,2,24.1,77777,9,999999999,240,0.1040,0,88,999.000,999.0,99.0
+1987,9,9,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,11.7,57,99200,4,236,346,4,6,3,0,0,0,0,50,3.1,0,0,19.3,77777,9,999999999,220,0.1040,0,88,999.000,999.0,99.0
+1987,9,9,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,12.8,63,99200,0,0,344,0,0,0,0,0,0,0,80,3.6,0,0,19.3,77777,9,999999999,229,0.1040,0,88,999.000,999.0,99.0
+1987,9,9,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,13.9,76,99200,0,0,337,0,0,0,0,0,0,0,0,0.0,0,0,19.3,77777,9,999999999,250,0.1040,0,88,999.000,999.0,99.0
+1987,9,9,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,13.9,87,99200,0,0,327,0,0,0,0,0,0,0,0,0.0,0,0,16.1,77777,9,999999999,250,0.1040,0,88,999.000,999.0,99.0
+1987,9,9,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,13.9,90,99200,0,0,325,0,0,0,0,0,0,0,360,2.1,0,0,16.1,77777,9,999999999,250,0.1040,0,88,999.000,999.0,99.0
+1987,9,9,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,13.3,93,99200,0,0,319,0,0,0,0,0,0,0,350,1.5,0,0,16.1,77777,9,999999999,240,0.1040,0,88,999.000,999.0,99.0
+1987,9,10,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,12.8,97,99200,0,0,314,0,0,0,0,0,0,0,0,0.0,0,0,16.1,77777,9,999999999,229,0.1040,0,88,999.000,999.0,99.0
+1987,9,10,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,12.8,97,99200,0,0,314,0,0,0,0,0,0,0,0,0.0,0,0,16.1,77777,9,999999999,229,0.1040,0,88,999.000,999.0,99.0
+1987,9,10,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,12.8,100,99200,0,0,312,0,0,0,0,0,0,0,0,0.0,0,0,16.1,77777,9,999999999,229,0.1040,0,88,999.000,999.0,99.0
+1987,9,10,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,12.8,97,99200,0,0,314,0,0,0,0,0,0,0,0,0.0,0,0,16.1,77777,9,999999999,229,0.1040,0,88,999.000,999.0,99.0
+1987,9,10,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,11.7,93,99200,0,0,321,0,0,0,0,0,0,0,0,0.0,3,2,16.1,77777,9,999999999,209,0.1040,0,88,999.000,999.0,99.0
+1987,9,10,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,12.2,97,99200,35,730,321,17,23,15,1800,900,1800,310,0,0.0,7,2,6.4,77777,9,999999999,220,0.1130,0,88,999.000,999.0,99.0
+1987,9,10,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,15.6,90,99200,259,1348,345,120,301,61,12400,22200,8100,1110,130,2.1,7,2,8.0,77777,9,999999999,270,0.1130,0,88,999.000,999.0,99.0
+1987,9,10,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,15.0,68,99200,505,1348,367,275,369,135,28500,34800,15400,2630,130,2.6,10,3,11.3,77777,9,999999999,259,0.1130,0,88,999.000,999.0,99.0
+1987,9,10,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,13.3,55,99200,723,1348,370,462,507,187,48500,51300,20900,4100,140,3.1,8,2,16.1,77777,9,999999999,240,0.1130,0,88,999.000,999.0,99.0
+1987,9,10,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,13.3,50,99200,897,1348,382,593,599,190,61500,60100,21400,4870,140,3.6,8,3,24.1,77777,9,999999999,240,0.1130,0,88,999.000,999.0,99.0
+1987,9,10,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,13.3,48,99200,1015,1348,385,618,510,230,66800,53200,26600,7230,120,1.5,10,3,24.1,77777,9,999999999,240,0.1130,0,88,999.000,999.0,99.0
+1987,9,10,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,13.3,45,99100,1070,1348,394,783,676,241,81500,68200,27300,8290,340,1.5,10,4,24.1,77777,9,999999999,240,0.1130,0,88,999.000,999.0,99.0
+1987,9,10,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,14.4,47,99100,1057,1348,398,754,613,268,80600,63900,30400,9230,70,4.1,9,4,19.3,77777,9,999999999,250,0.1130,0,88,999.000,999.0,99.0
+1987,9,10,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,14.4,54,99100,977,1348,403,416,167,293,45800,17800,32800,9200,70,4.6,10,8,19.3,7620,9,999999999,250,0.1130,0,88,999.000,999.0,99.0
+1987,9,10,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,14.4,60,99100,836,1348,403,206,3,205,24200,200,24000,9130,30,6.2,10,9,19.3,7620,9,999999999,259,0.1130,0,88,999.000,999.0,99.0
+1987,9,10,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,13.9,61,99100,644,1348,408,175,11,170,20100,900,19700,6910,10,4.6,10,10,19.3,7620,9,999999999,240,0.1130,0,88,999.000,999.0,99.0
+1987,9,10,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,13.3,61,99100,413,1348,404,78,1,78,9100,100,9000,3120,40,3.6,10,10,19.3,3050,9,999999999,240,0.1130,0,88,999.000,999.0,99.0
+1987,9,10,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,13.3,63,99000,161,1348,401,30,3,29,3400,0,3400,1040,40,3.6,10,10,19.3,3050,9,999999999,240,0.1130,0,88,999.000,999.0,99.0
+1987,9,10,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,13.9,66,99000,3,213,402,0,0,0,0,0,0,0,50,4.1,10,10,19.3,3050,9,999999999,250,0.1130,0,88,999.000,999.0,99.0
+1987,9,10,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,14.4,68,99000,0,0,403,0,0,0,0,0,0,0,90,5.2,10,10,24.1,2740,9,999999999,250,0.1130,0,88,999.000,999.0,99.0
+1987,9,10,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,14.4,66,99000,0,0,405,0,0,0,0,0,0,0,80,3.1,10,10,24.1,3050,9,999999999,250,0.1130,0,88,999.000,999.0,99.0
+1987,9,10,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,15.6,73,98900,0,0,404,0,0,0,0,0,0,0,90,3.1,10,10,16.1,2440,9,999999999,270,0.1130,0,88,999.000,999.0,99.0
+1987,9,10,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,15.6,81,98900,0,0,357,0,0,0,0,0,0,0,350,2.1,3,3,16.1,77777,9,999999999,270,0.1130,0,88,999.000,999.0,99.0
+1987,9,10,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,15.6,84,98900,0,0,351,0,0,0,0,0,0,0,120,2.1,3,2,14.5,77777,9,999999999,270,0.1130,0,88,999.000,999.0,99.0
+1987,9,11,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,15.0,93,98800,0,0,351,0,0,0,0,0,0,0,280,1.5,6,6,11.3,3050,9,999999999,259,0.1130,0,88,999.000,999.0,99.0
+1987,9,11,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,14.4,93,98800,0,0,332,0,0,0,0,0,0,0,220,2.1,3,1,9.7,77777,9,999999999,250,0.1130,0,88,999.000,999.0,99.0
+1987,9,11,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,14.4,97,98800,0,0,323,0,0,0,0,0,0,0,230,1.5,0,0,8.0,77777,9,999999999,250,0.1130,0,88,999.000,999.0,99.0
+1987,9,11,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,13.9,97,98800,0,0,320,0,0,0,0,0,0,0,250,2.6,0,0,4.8,77777,9,999999999,240,0.1130,0,88,999.000,999.0,99.0
+1987,9,11,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,14.4,97,98900,0,0,329,0,0,0,0,0,0,0,0,0.0,1,1,4.8,77777,9,999999999,250,0.1130,0,88,999.000,999.0,99.0
+1987,9,11,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,13.3,97,98900,32,708,327,18,34,14,1700,1000,1700,240,0,0.0,6,2,4.8,77777,9,999999999,240,0.0880,0,88,999.000,999.0,99.0
+1987,9,11,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,15.0,90,98900,255,1348,342,111,195,73,11500,14200,8900,1410,250,3.1,7,2,8.0,77777,9,999999999,259,0.0880,0,88,999.000,999.0,99.0
+1987,9,11,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,16.7,81,98900,501,1348,355,289,531,89,29800,49500,11300,1720,250,3.6,4,1,8.0,77777,9,999999999,290,0.0880,0,88,999.000,999.0,99.0
+1987,9,11,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,16.7,71,98900,719,1348,366,377,504,104,39700,50500,12800,2340,240,4.1,4,1,11.3,77777,9,999999999,290,0.0880,0,88,999.000,999.0,99.0
+1987,9,11,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,16.7,66,99000,893,1348,383,570,578,183,59300,58100,20700,4680,250,3.6,5,4,12.9,77777,9,999999999,290,0.0880,0,88,999.000,999.0,99.0
+1987,9,11,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,16.1,64,98900,1011,1348,383,646,606,187,68000,61600,21700,5830,210,3.6,4,4,16.1,77777,9,999999999,279,0.0880,0,88,999.000,999.0,99.0
+1987,9,11,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,16.7,60,98900,1065,1348,389,655,499,257,70500,52100,29200,8980,250,3.6,5,3,19.3,77777,9,999999999,290,0.0880,0,88,999.000,999.0,99.0
+1987,9,11,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,16.1,54,98900,1052,1348,394,751,701,199,79100,71300,23300,6710,250,4.1,3,3,19.3,77777,9,999999999,279,0.0880,0,88,999.000,999.0,99.0
+1987,9,11,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,15.6,51,98900,972,1348,387,696,819,100,71700,81700,12700,2540,260,3.1,1,1,19.3,77777,9,999999999,270,0.0880,0,88,999.000,999.0,99.0
+1987,9,11,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,15.0,47,98800,830,1348,389,561,737,103,58900,73700,13400,2470,230,3.1,4,1,19.3,77777,9,999999999,259,0.0880,0,88,999.000,999.0,99.0
+1987,9,11,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,13.3,42,98800,637,1348,399,404,560,137,43100,55700,16700,2780,230,4.1,4,4,24.1,77777,9,999999999,229,0.0880,0,88,999.000,999.0,99.0
+1987,9,11,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,13.9,49,98800,406,1348,385,208,406,84,22000,36000,11100,1540,220,4.1,8,2,24.1,77777,9,999999999,250,0.0880,0,88,999.000,999.0,99.0
+1987,9,11,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,15.0,60,98800,153,1348,381,50,83,41,5500,4900,4900,860,220,2.6,10,4,24.1,77777,9,999999999,259,0.0880,0,88,999.000,999.0,99.0
+1987,9,11,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,15.0,60,98900,2,169,378,2,1,1,0,0,0,0,190,2.1,10,3,24.1,77777,9,999999999,259,0.0880,0,88,999.000,999.0,99.0
+1987,9,11,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,15.0,73,98900,0,0,364,0,0,0,0,0,0,0,210,2.1,10,4,24.1,77777,9,999999999,259,0.0880,0,88,999.000,999.0,99.0
+1987,9,11,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,14.4,71,99000,0,0,361,0,0,0,0,0,0,0,330,7.7,9,3,24.1,77777,9,999999999,250,0.0880,0,88,999.000,999.0,99.0
+1987,9,11,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,11.7,63,99000,0,0,365,0,0,0,0,0,0,0,300,2.6,10,7,24.1,7620,9,999999999,209,0.0880,0,88,999.000,999.0,99.0
+1987,9,11,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,12.8,73,99000,0,0,345,0,0,0,0,0,0,0,310,2.6,10,2,24.1,77777,9,999999999,229,0.0880,0,88,999.000,999.0,99.0
+1987,9,11,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,12.8,78,99000,0,0,340,0,0,0,0,0,0,0,300,2.1,7,2,16.1,77777,9,999999999,229,0.0880,0,88,999.000,999.0,99.0
+1987,9,12,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,12.8,87,99000,0,0,332,0,0,0,0,0,0,0,160,2.1,7,2,16.1,77777,9,999999999,229,0.0880,0,88,999.000,999.0,99.0
+1987,9,12,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,13.3,93,98900,0,0,330,0,0,0,0,0,0,0,0,0.0,7,2,11.3,77777,9,999999999,240,0.0880,0,88,999.000,999.0,99.0
+1987,9,12,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,13.3,93,98900,0,0,341,0,0,0,0,0,0,0,160,1.5,9,6,14.5,3050,9,999999999,240,0.0880,0,88,999.000,999.0,99.0
+1987,9,12,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,14.4,90,98900,0,0,378,0,0,0,0,0,0,0,230,1.5,10,10,16.1,2130,9,999999999,250,0.0880,0,88,999.000,999.0,99.0
+1987,9,12,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,14.4,87,98900,0,0,371,0,0,0,0,0,0,0,300,3.1,9,9,12.9,2130,9,999999999,250,0.0880,0,88,999.000,999.0,99.0
+1987,9,12,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,14.4,90,99000,30,686,368,11,2,11,1300,0,1300,400,290,3.6,9,9,16.1,2130,9,999999999,250,0.0840,0,88,999.000,999.0,99.0
+1987,9,12,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,15.0,93,99000,251,1349,379,32,4,31,3800,100,3700,1240,0,0.0,10,10,9.7,1520,9,999999999,259,0.0840,0,88,999.000,999.0,99.0
+1987,9,12,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,15.0,81,98900,497,1349,372,199,44,183,21800,4200,20200,4760,330,2.1,8,8,12.9,2130,9,999999999,259,0.0840,0,88,999.000,999.0,99.0
+1987,9,12,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,14.4,66,98900,715,1349,372,449,584,136,46500,57700,15900,2930,260,2.1,5,5,11.3,77777,9,999999999,250,0.0840,0,88,999.000,999.0,99.0
+1987,9,12,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,13.9,59,98900,889,1349,368,550,641,123,58700,65500,15500,3280,200,2.6,2,2,12.9,77777,9,999999999,240,0.0840,0,88,999.000,999.0,99.0
+1987,9,12,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,12.8,50,98900,1007,1349,375,689,693,167,73100,70800,20100,5220,200,4.1,2,2,16.1,77777,9,999999999,229,0.0840,0,88,999.000,999.0,99.0
+1987,9,12,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,13.9,49,98800,1060,1349,398,766,708,204,80600,72000,23900,6980,230,5.7,6,6,16.1,1220,9,999999999,250,0.0840,0,88,999.000,999.0,99.0
+1987,9,12,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,11.7,45,98800,1047,1349,394,402,140,293,44700,15000,33000,10030,260,6.2,7,7,24.1,1220,9,999999999,209,0.0840,0,88,999.000,999.0,99.0
+1987,9,12,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,11.7,43,98800,966,1349,383,597,547,201,62200,55200,22600,5710,230,6.7,6,3,24.1,77777,9,999999999,209,0.0840,0,88,999.000,999.0,99.0
+1987,9,12,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,10.0,36,98800,824,1349,386,436,442,164,47300,45500,19500,3860,240,6.7,8,3,24.1,77777,9,999999999,189,0.0840,0,88,999.000,999.0,99.0
+1987,9,12,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,8.3,36,98800,630,1349,367,400,651,93,42100,64000,12200,1970,230,7.7,4,1,24.1,77777,9,999999999,179,0.0840,0,88,999.000,999.0,99.0
+1987,9,12,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,10.0,45,98800,399,1349,366,193,306,101,20000,26900,12000,1890,280,5.2,8,2,24.1,77777,9,999999999,200,0.0840,0,88,999.000,999.0,99.0
+1987,9,12,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,10.0,55,98800,146,1349,353,56,141,40,5800,7200,5000,740,280,4.6,8,3,24.1,77777,9,999999999,189,0.0840,0,88,999.000,999.0,99.0
+1987,9,12,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,10.6,59,98900,1,124,351,1,1,0,0,0,0,0,280,2.1,8,3,24.1,77777,9,999999999,200,0.0840,0,88,999.000,999.0,99.0
+1987,9,12,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,10.0,70,99000,0,0,327,0,0,0,0,0,0,0,260,2.1,4,1,24.1,77777,9,999999999,200,0.0840,0,88,999.000,999.0,99.0
+1987,9,12,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,10.6,81,99000,0,0,314,0,0,0,0,0,0,0,270,2.1,2,0,24.1,77777,9,999999999,200,0.0840,0,88,999.000,999.0,99.0
+1987,9,12,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,11.1,84,99000,0,0,321,0,0,0,0,0,0,0,280,2.6,3,1,24.1,77777,9,999999999,209,0.0840,0,88,999.000,999.0,99.0
+1987,9,12,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,11.1,84,99000,0,0,325,0,0,0,0,0,0,0,270,3.1,6,2,24.1,77777,9,999999999,209,0.0840,0,88,999.000,999.0,99.0
+1987,9,12,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,11.1,90,99000,0,0,310,0,0,0,0,0,0,0,260,2.6,3,0,24.1,77777,9,999999999,209,0.0840,0,88,999.000,999.0,99.0
+1987,9,13,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,10.6,93,99000,0,0,305,0,0,0,0,0,0,0,260,2.6,3,0,24.1,77777,9,999999999,200,0.0840,0,88,999.000,999.0,99.0
+1987,9,13,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,10.0,96,99000,0,0,299,0,0,0,0,0,0,0,240,1.5,0,0,24.1,77777,9,999999999,189,0.0840,0,88,999.000,999.0,99.0
+1987,9,13,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,10.0,96,99000,0,0,299,0,0,0,0,0,0,0,240,1.5,0,0,24.1,77777,9,999999999,189,0.0840,0,88,999.000,999.0,99.0
+1987,9,13,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,8.9,96,99000,0,0,293,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,179,0.0840,0,88,999.000,999.0,99.0
+1987,9,13,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,8.9,96,99000,0,0,293,0,0,0,0,0,0,0,170,2.1,0,0,24.1,77777,9,999999999,179,0.0840,0,88,999.000,999.0,99.0
+1987,9,13,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,8.9,96,99100,28,664,299,17,58,11,1500,1900,1400,190,190,2.1,1,1,24.1,77777,9,999999999,179,0.0800,0,88,999.000,999.0,99.0
+1987,9,13,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,11.7,87,99100,246,1350,332,96,265,47,10200,19100,6700,830,220,1.5,4,4,24.1,77777,9,999999999,220,0.0800,0,88,999.000,999.0,99.0
+1987,9,13,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,10.6,65,99100,493,1350,356,145,55,124,15800,5200,13900,3520,240,3.1,7,7,24.1,2130,9,999999999,200,0.0800,0,88,999.000,999.0,99.0
+1987,9,13,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,11.1,63,99200,711,1350,362,373,245,242,40300,25200,27000,6150,290,3.6,7,7,24.1,2130,9,999999999,209,0.0800,0,88,999.000,999.0,99.0
+1987,9,13,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,12.2,73,99200,884,1350,371,231,103,163,26200,11000,19000,4660,280,3.1,9,9,16.1,1220,9,999999999,220,0.0800,0,88,999.000,999.0,99.0
+1987,9,13,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,12.8,81,99200,1002,1350,376,160,4,158,19700,300,19500,7960,290,3.6,10,10,24.1,1980,9,999999999,229,0.0800,0,88,999.000,999.0,99.0
+1987,9,13,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,11.7,75,99200,1056,1350,375,165,14,154,18400,1400,17300,6610,310,3.6,10,10,19.3,1980,9,999999999,209,0.0800,0,88,999.000,999.0,99.0
+1987,9,13,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,11.1,65,99200,1041,1350,373,293,19,278,34500,1700,33200,12730,330,2.1,10,9,24.1,1980,9,999999999,209,0.0800,0,88,999.000,999.0,99.0
+1987,9,13,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,10.6,53,99100,960,1350,365,646,702,142,69000,71900,17700,4150,320,2.1,6,5,24.1,1980,9,999999999,200,0.0800,0,88,999.000,999.0,99.0
+1987,9,13,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,10.6,53,99100,818,1350,362,509,575,157,53000,57600,18000,3710,230,2.1,4,4,24.1,77777,9,999999999,200,0.0800,0,88,999.000,999.0,99.0
+1987,9,13,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,11.1,57,99100,624,1350,384,213,68,181,23300,6700,20200,5350,320,2.1,9,9,24.1,1830,9,999999999,209,0.0800,0,88,999.000,999.0,99.0
+1987,9,13,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,11.7,57,99100,392,1350,388,85,25,77,9300,2200,8600,2160,230,2.1,9,9,24.1,1830,9,999999999,220,0.0800,0,88,999.000,999.0,99.0
+1987,9,13,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,12.2,65,99100,139,1350,366,49,50,44,5300,2800,5000,920,310,1.5,7,7,24.1,1680,9,999999999,220,0.0800,0,88,999.000,999.0,99.0
+1987,9,13,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,11.7,70,99200,0,79,363,2,0,2,0,0,0,0,90,4.1,8,8,24.1,1160,9,999999999,209,0.0800,0,88,999.000,999.0,99.0
+1987,9,13,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,11.1,63,99200,0,0,362,0,0,0,0,0,0,0,120,1.5,7,7,24.1,1160,9,999999999,209,0.0800,0,88,999.000,999.0,99.0
+1987,9,13,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,12.2,70,99200,0,0,350,0,0,0,0,0,0,0,80,3.1,4,4,24.1,77777,9,999999999,220,0.0800,0,88,999.000,999.0,99.0
+1987,9,13,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,12.2,90,99300,0,0,326,0,0,0,0,0,0,0,320,1.5,2,2,24.1,77777,9,999999999,220,0.0800,0,88,999.000,999.0,99.0
+1987,9,13,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,12.2,97,99300,0,0,311,0,0,0,0,0,0,0,330,2.6,0,0,24.1,77777,9,999999999,220,0.0800,0,88,999.000,999.0,99.0
+1987,9,13,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,11.1,96,99400,0,0,305,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,209,0.0800,0,88,999.000,999.0,99.0
+1987,9,14,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,10.0,96,99400,0,0,299,0,0,0,0,0,0,0,280,2.1,0,0,24.1,77777,9,999999999,189,0.0800,0,88,999.000,999.0,99.0
+1987,9,14,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,10.0,96,99400,0,0,299,0,0,0,0,0,0,0,280,2.1,0,0,16.1,77777,9,999999999,189,0.0800,0,88,999.000,999.0,99.0
+1987,9,14,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,10.0,100,99400,0,0,297,0,0,0,0,0,0,0,0,0.0,0,0,12.9,77777,9,999999999,189,0.0800,0,88,999.000,999.0,99.0
+1987,9,14,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,8.9,100,99500,0,0,291,0,0,0,0,0,0,0,0,0.0,0,0,12.9,77777,9,999999999,179,0.0800,0,88,999.000,999.0,99.0
+1987,9,14,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,8.3,96,99500,0,0,291,0,0,0,0,0,0,0,0,0.0,0,0,12.9,77777,9,999999999,179,0.0800,0,88,999.000,999.0,99.0
+1987,9,14,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,8.9,100,99600,26,642,291,17,54,11,1500,1800,1400,190,240,2.1,0,0,8.0,77777,9,999999999,179,0.0830,0,88,999.000,999.0,99.0
+1987,9,14,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,12.8,97,99600,242,1351,314,124,457,40,12600,33700,6600,740,0,0.0,0,0,8.0,77777,9,999999999,229,0.0830,0,88,999.000,999.0,99.0
+1987,9,14,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,12.8,73,99600,489,1351,334,314,688,61,32400,64200,9100,1250,0,0.0,0,0,9.7,77777,9,999999999,229,0.0830,0,88,999.000,999.0,99.0
+1987,9,14,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,11.7,57,99600,706,1351,352,469,701,98,49700,70100,12900,2190,0,0.0,1,1,14.5,77777,9,999999999,220,0.0830,0,88,999.000,999.0,99.0
+1987,9,14,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,10.0,48,99700,880,1351,349,656,854,93,67600,84800,12200,2140,90,3.1,0,0,24.1,77777,9,999999999,200,0.0830,0,88,999.000,999.0,99.0
+1987,9,14,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,11.1,48,99600,997,1351,356,751,845,120,79500,85400,16200,3560,0,0.0,3,0,24.1,77777,9,999999999,209,0.0830,0,88,999.000,999.0,99.0
+1987,9,14,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,9.4,40,99600,1051,1351,366,755,818,113,77500,81800,13800,3100,120,2.1,3,1,24.1,77777,9,999999999,189,0.0830,0,88,999.000,999.0,99.0
+1987,9,14,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,11.1,45,99500,1036,1351,368,760,836,112,78000,83500,13700,2990,110,3.1,3,1,16.1,77777,9,999999999,209,0.0830,0,88,999.000,999.0,99.0
+1987,9,14,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,13.3,52,99400,954,1351,375,662,748,128,69200,75100,15900,3440,90,3.6,3,2,16.1,77777,9,999999999,240,0.0830,0,88,999.000,999.0,99.0
+1987,9,14,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,13.3,54,99300,811,1351,367,545,738,97,57400,73800,12900,2320,40,4.6,3,1,14.5,77777,9,999999999,240,0.0830,0,88,999.000,999.0,99.0
+1987,9,14,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,13.3,54,99300,617,1351,372,392,600,115,40600,58100,13900,2330,90,3.6,8,2,14.5,77777,9,999999999,240,0.0830,0,88,999.000,999.0,99.0
+1987,9,14,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,13.9,61,99300,384,1351,382,130,56,114,14200,5000,12800,2950,110,3.6,9,7,16.1,7620,9,999999999,240,0.0830,0,88,999.000,999.0,99.0
+1987,9,14,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,13.3,63,99300,132,1351,390,31,31,27,3300,1700,3200,560,80,3.6,10,9,16.1,2440,9,999999999,240,0.0830,0,88,999.000,999.0,99.0
+1987,9,14,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,13.3,66,99300,0,56,387,0,0,0,0,0,0,0,100,3.6,10,9,16.1,1680,9,999999999,240,0.0830,0,88,999.000,999.0,99.0
+1987,9,14,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,13.9,68,99300,0,0,388,0,0,0,0,0,0,0,120,4.1,9,9,19.3,1830,9,999999999,250,0.0830,0,88,999.000,999.0,99.0
+1987,9,14,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,14.4,73,99400,0,0,396,0,0,0,0,0,0,0,80,2.1,10,10,16.1,1400,9,999999999,250,0.0830,0,88,999.000,999.0,99.0
+1987,9,14,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,16.7,90,99300,0,0,393,0,0,0,0,0,0,0,70,5.2,10,10,12.9,2440,9,999999999,290,0.0830,0,88,999.000,999.0,99.0
+1987,9,14,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,16.7,90,99200,0,0,358,0,0,0,0,0,0,0,70,3.6,10,4,16.1,77777,9,999999999,290,0.0830,0,88,999.000,999.0,99.0
+1987,9,14,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,17.2,93,99200,0,0,394,0,0,0,0,0,0,0,70,3.1,10,10,16.1,2440,9,999999999,300,0.0830,0,88,999.000,999.0,99.0
+1987,9,15,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,17.2,93,99200,0,0,394,0,0,0,0,0,0,0,100,2.6,10,10,16.1,2740,9,999999999,300,0.0830,0,88,999.000,999.0,99.0
+1987,9,15,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,16.7,90,99100,0,0,393,0,0,0,0,0,0,0,110,3.6,10,10,11.3,2440,9,999999999,290,0.0830,0,88,999.000,999.0,99.0
+1987,9,15,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,16.7,90,99100,0,0,393,0,0,0,0,0,0,0,110,3.1,10,10,12.9,2130,9,999999999,290,0.0830,0,88,999.000,999.0,99.0
+1987,9,15,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,16.7,90,99100,0,0,393,0,0,0,0,0,0,0,50,3.6,10,10,11.3,2130,9,999999999,290,0.0830,0,88,999.000,999.0,99.0
+1987,9,15,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,15.6,84,99100,0,0,363,0,0,0,0,0,0,0,90,3.6,6,6,16.1,2130,9,999999999,270,0.0830,0,88,999.000,999.0,99.0
+1987,9,15,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,15.6,84,99100,24,619,367,12,0,12,1400,0,1400,420,90,3.6,8,7,16.1,7620,9,999999999,270,0.3230,0,88,999.000,999.0,99.0
+1987,9,15,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,15.6,81,99200,238,1351,384,53,5,52,6000,100,6000,1850,120,4.1,10,9,16.1,7620,9,999999999,270,0.3230,0,88,999.000,999.0,99.0
+1987,9,15,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,16.1,78,99100,484,1351,382,179,130,131,19500,12500,15000,3010,120,4.1,8,8,24.1,7620,9,999999999,279,0.3230,0,88,999.000,999.0,99.0
+1987,9,15,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,17.2,73,99100,702,1351,389,375,252,243,40600,25900,27100,6140,130,3.1,8,7,24.1,7620,9,999999999,300,0.3230,0,88,999.000,999.0,99.0
+1987,9,15,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,16.7,64,99100,876,1351,397,478,316,271,51500,33800,29500,7170,120,2.1,8,7,24.1,7620,9,999999999,290,0.3230,0,88,999.000,999.0,99.0
+1987,9,15,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,16.7,60,99000,993,1351,399,649,465,303,67900,48200,32300,9310,210,2.1,8,6,24.1,7620,9,999999999,290,0.3230,0,88,999.000,999.0,99.0
+1987,9,15,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,17.2,58,99000,1046,1351,405,603,366,316,65600,39600,34800,10400,270,2.1,8,6,24.1,7620,9,999999999,300,0.3230,0,88,999.000,999.0,99.0
+1987,9,15,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,18.3,62,98900,1031,1351,439,264,4,261,31200,300,30900,12090,170,2.6,10,10,11.3,1220,9,999999999,320,0.3230,0,88,999.000,999.0,99.0
+1987,9,15,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,18.3,64,99000,949,1351,436,234,3,232,27600,300,27400,10660,190,3.1,10,10,11.3,1160,9,999999999,320,0.3230,0,88,999.000,999.0,99.0
+1987,9,15,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,18.9,67,99000,805,1351,437,229,7,225,26400,600,26100,9560,170,3.1,10,10,11.3,2440,9,999999999,329,0.3230,0,88,999.000,999.0,99.0
+1987,9,15,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,18.9,69,98900,610,1351,421,257,64,228,28100,6300,25300,6290,190,2.6,10,9,11.3,2440,9,999999999,329,0.3230,0,88,999.000,999.0,99.0
+1987,9,15,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,18.9,71,98900,377,1351,418,113,12,110,12600,700,12400,3820,180,3.1,10,9,11.3,7620,9,999999999,329,0.3230,0,88,999.000,999.0,99.0
+1987,9,15,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,18.9,74,98900,125,1351,427,29,0,29,3200,0,3200,970,180,3.1,10,10,11.3,1830,9,999999999,329,0.3230,0,88,999.000,999.0,99.0
+1987,9,15,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,22.8,18.9,79,98900,0,11,421,0,0,0,0,0,0,0,210,2.1,10,10,12.9,1830,9,999999999,329,0.3230,0,88,999.000,999.0,99.0
+1987,9,15,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,18.9,84,98900,0,0,414,0,0,0,0,0,0,0,0,0.0,10,10,12.9,2440,9,999999999,329,0.3230,0,88,999.000,999.0,99.0
+1987,9,15,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,18.9,87,98900,0,0,411,0,0,0,0,0,0,0,0,0.0,10,10,12.9,7620,9,999999999,329,0.3230,0,88,999.000,999.0,99.0
+1987,9,15,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,18.9,87,98900,0,0,411,0,0,0,0,0,0,0,180,1.5,10,10,9.7,2740,9,999999999,329,0.3230,0,88,999.000,999.0,99.0
+1987,9,15,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,18.9,87,98900,0,0,411,0,0,0,0,0,0,0,180,2.1,10,10,9.7,1160,9,999999999,329,0.3230,0,88,999.000,999.0,99.0
+1987,9,15,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,18.9,90,98900,0,0,408,0,0,0,0,0,0,0,190,2.1,10,10,9.7,1160,9,999999999,329,0.3230,0,88,999.000,999.0,99.0
+1987,9,16,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,19.4,93,98900,0,0,409,0,0,0,0,0,0,0,170,2.6,10,10,8.0,1400,9,999999999,340,0.3230,0,88,999.000,999.0,99.0
+1987,9,16,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,19.4,97,98900,0,0,406,0,0,0,0,0,0,0,0,0.0,10,10,8.0,1400,9,999999999,340,0.3230,0,88,999.000,999.0,99.0
+1987,9,16,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,19.4,97,98900,0,0,406,0,0,0,0,0,0,0,0,0.0,10,10,6.4,1400,9,999999999,340,0.3230,0,88,999.000,999.0,99.0
+1987,9,16,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,19.4,97,98800,0,0,406,0,0,0,0,0,0,0,150,2.1,10,10,8.0,1680,9,999999999,340,0.3230,0,88,999.000,999.0,99.0
+1987,9,16,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,19.4,97,98800,0,0,386,0,0,0,0,0,0,0,130,3.1,10,8,4.8,1680,9,999999999,340,0.3230,0,88,999.000,999.0,99.0
+1987,9,16,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,19.4,97,98800,23,597,406,6,1,6,0,0,0,0,170,3.1,10,10,4.0,1680,9,999999999,340,0.0680,0,88,999.000,999.0,99.0
+1987,9,16,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,19.4,97,98800,234,1352,406,50,5,50,5800,100,5700,1780,140,4.1,10,10,4.0,3050,9,999999999,340,0.0680,0,88,999.000,999.0,99.0
+1987,9,16,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,19.4,93,98700,480,1352,409,135,3,134,15200,200,15100,4970,140,2.6,10,10,2.4,1680,9,999999999,340,0.0680,0,88,999.000,999.0,99.0
+1987,9,16,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,19.4,97,98800,698,1352,406,159,0,159,18500,0,18500,6860,160,4.6,10,10,1.6,310,9,999999999,340,0.0680,0,88,999.000,999.0,99.0
+1987,9,16,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,20.0,100,98800,871,1352,406,189,8,184,22400,600,22000,8550,160,4.6,10,10,2.4,310,9,999999999,350,0.0680,0,88,999.000,999.0,99.0
+1987,9,16,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,20.0,97,98700,988,1352,410,188,2,186,22600,200,22500,9090,140,5.7,10,10,2.4,240,9,999999999,350,0.0680,0,88,999.000,999.0,99.0
+1987,9,16,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,20.0,97,98700,1041,1352,410,196,1,195,23700,100,23600,9620,160,5.7,10,10,3.2,240,9,999999999,350,0.0680,0,88,999.000,999.0,99.0
+1987,9,16,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,19.4,93,98600,1025,1352,409,218,0,217,26000,0,26000,10450,160,5.2,10,10,3.2,240,9,999999999,340,0.0680,0,88,999.000,999.0,99.0
+1987,9,16,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,20.0,93,98500,943,1352,412,334,2,333,38200,200,38100,13640,140,4.6,10,10,4.8,1010,9,999999999,350,0.0680,0,88,999.000,999.0,99.0
+1987,9,16,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,20.0,90,98400,799,1352,404,323,107,259,35400,10800,29000,8300,130,6.2,9,9,4.8,1160,9,999999999,350,0.0680,0,88,999.000,999.0,99.0
+1987,9,16,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,20.0,87,98400,603,1352,399,224,158,153,24700,16000,17500,3680,120,4.1,8,8,4.8,1010,9,999999999,350,0.0680,0,88,999.000,999.0,99.0
+1987,9,16,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,20.0,87,98300,370,1352,419,132,7,130,14500,400,14300,4150,90,3.6,10,10,4.8,430,9,999999999,350,0.0680,0,88,999.000,999.0,99.0
+1987,9,16,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,19.4,84,98300,118,1318,406,33,24,31,3600,1500,3500,740,140,4.1,9,9,4.8,700,9,999999999,340,0.0680,0,88,999.000,999.0,99.0
+1987,9,16,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.7,19.4,87,98300,0,0,367,0,0,0,0,0,0,0,130,4.6,4,1,4.8,77777,9,999999999,340,0.0680,0,88,999.000,999.0,99.0
+1987,9,16,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,20.0,93,98300,0,0,373,0,0,0,0,0,0,0,140,3.6,9,3,4.8,77777,9,999999999,350,0.0680,0,88,999.000,999.0,99.0
+1987,9,16,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,20.0,93,98300,0,0,412,0,0,0,0,0,0,0,120,3.6,10,10,4.8,760,9,999999999,350,0.0680,0,88,999.000,999.0,99.0
+1987,9,16,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,18.3,90,98300,0,0,404,0,0,0,0,0,0,0,220,5.2,10,10,4.8,430,9,999999999,320,0.0680,0,88,999.000,999.0,99.0
+1987,9,16,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,17.8,93,98000,0,0,398,0,0,0,0,0,0,0,40,3.1,10,10,11.3,700,9,999999999,300,0.0680,0,88,999.000,999.0,99.0
+1987,9,16,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,18.3,93,98000,0,0,401,0,0,0,0,0,0,0,310,1.5,10,10,4.8,370,9,999999999,309,0.0680,0,88,999.000,999.0,99.0
+1987,9,17,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,19.4,93,97800,0,0,409,0,0,0,0,0,0,0,200,3.6,10,10,4.8,2440,9,999999999,340,0.0680,0,88,999.000,999.0,99.0
+1987,9,17,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,18.3,93,97800,0,0,401,0,0,0,0,0,0,0,210,5.2,10,10,4.8,430,9,999999999,309,0.0680,0,88,999.000,999.0,99.0
+1987,9,17,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,18.3,93,97900,0,0,401,0,0,0,0,0,0,0,210,5.2,10,10,12.9,270,9,999999999,309,0.0680,0,88,999.000,999.0,99.0
+1987,9,17,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,18.3,93,97900,0,0,401,0,0,0,0,0,0,0,190,4.6,10,10,11.3,340,9,999999999,309,0.0680,0,88,999.000,999.0,99.0
+1987,9,17,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,18.3,93,97900,0,0,401,0,0,0,0,0,0,0,190,4.1,10,10,11.3,400,9,999999999,309,0.0680,0,88,999.000,999.0,99.0
+1987,9,17,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,17.8,90,97900,21,575,400,5,0,5,0,0,0,0,180,3.6,10,10,8.0,340,9,999999999,300,0.2270,0,88,999.000,999.0,99.0
+1987,9,17,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,17.8,90,97900,229,1353,400,36,6,35,4200,100,4200,1340,190,5.7,10,10,9.7,370,9,999999999,300,0.2270,0,88,999.000,999.0,99.0
+1987,9,17,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,17.8,90,97900,476,1353,400,59,2,58,7100,100,7000,2560,180,4.1,10,10,3.2,400,9,999999999,300,0.2270,0,88,999.000,999.0,99.0
+1987,9,17,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,18.3,97,97900,694,1353,398,100,6,97,12100,400,11900,4560,190,3.1,10,10,2.8,210,9,999999999,320,0.2270,0,88,999.000,999.0,99.0
+1987,9,17,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,18.3,97,97900,867,1353,398,128,1,127,15500,100,15500,6260,220,3.6,10,10,2.8,210,9,999999999,320,0.2270,0,88,999.000,999.0,99.0
+1987,9,17,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,19.4,87,97900,983,1353,415,284,5,281,33200,400,32900,12480,240,4.1,10,10,16.1,310,9,999999999,340,0.2270,0,88,999.000,999.0,99.0
+1987,9,17,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,17.8,81,97900,1036,1353,410,331,3,329,38500,300,38200,14290,260,5.2,10,10,24.1,580,9,999999999,300,0.2270,0,88,999.000,999.0,99.0
+1987,9,17,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,18.3,84,97900,1020,1353,410,300,1,299,35000,100,34900,13280,240,5.2,10,10,24.1,580,9,999999999,309,0.2270,0,88,999.000,999.0,99.0
+1987,9,17,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,17.8,79,97900,937,1353,413,312,2,311,35900,200,35700,13010,260,7.2,10,10,24.1,1010,9,999999999,309,0.2270,0,88,999.000,999.0,99.0
+1987,9,17,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,18.3,84,97900,792,1353,410,151,1,151,18000,100,17900,6980,270,8.8,10,10,19.3,640,9,999999999,309,0.2270,0,88,999.000,999.0,99.0
+1987,9,17,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,18.9,93,97900,596,1353,405,198,1,198,22200,100,22200,7270,280,6.7,10,10,16.1,370,9,999999999,320,0.2270,0,88,999.000,999.0,99.0
+1987,9,17,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,18.3,87,98100,363,1353,388,94,42,82,10200,3700,9300,2220,320,7.2,9,8,19.3,2440,9,999999999,320,0.2270,0,88,999.000,999.0,99.0
+1987,9,17,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,18.3,90,98100,111,1274,393,22,1,22,2500,0,2500,780,280,4.1,10,9,16.1,2440,9,999999999,309,0.2270,0,88,999.000,999.0,99.0
+1987,9,17,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,17.8,90,98100,0,0,400,0,0,0,0,0,0,0,310,4.6,10,10,19.3,2440,9,999999999,300,0.2270,0,88,999.000,999.0,99.0
+1987,9,17,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,18.3,93,98200,0,0,401,0,0,0,0,0,0,0,320,3.6,10,10,19.3,490,9,999999999,309,0.2270,0,88,999.000,999.0,99.0
+1987,9,17,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,17.2,90,98300,0,0,355,0,0,0,0,0,0,0,280,3.1,2,2,19.3,77777,9,999999999,300,0.2270,0,88,999.000,999.0,99.0
+1987,9,17,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,17.2,93,98300,0,0,348,0,0,0,0,0,0,0,280,3.1,1,1,19.3,77777,9,999999999,290,0.2270,0,88,999.000,999.0,99.0
+1987,9,17,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,17.2,97,98300,0,0,345,0,0,0,0,0,0,0,290,2.6,1,1,14.5,77777,9,999999999,300,0.2270,0,88,999.000,999.0,99.0
+1987,9,17,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,17.2,97,98300,0,0,359,0,0,0,0,0,0,0,290,3.1,5,5,9.7,77777,9,999999999,300,0.2270,0,88,999.000,999.0,99.0
+1987,9,18,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,17.8,97,98300,0,0,394,0,0,0,0,0,0,0,290,2.6,10,10,9.7,430,9,999999999,309,0.2270,0,88,999.000,999.0,99.0
+1987,9,18,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,17.2,93,98300,0,0,394,0,0,0,0,0,0,0,290,3.6,10,10,9.7,700,9,999999999,290,0.2270,0,88,999.000,999.0,99.0
+1987,9,18,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,17.8,97,98300,0,0,394,0,0,0,0,0,0,0,310,2.1,10,10,9.7,270,9,999999999,309,0.2270,0,88,999.000,999.0,99.0
+1987,9,18,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,17.2,93,98300,0,0,394,0,0,0,0,0,0,0,340,3.1,10,10,11.3,270,9,999999999,290,0.2270,0,88,999.000,999.0,99.0
+1987,9,18,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,17.2,97,98400,0,0,391,0,0,0,0,0,0,0,340,3.6,10,10,11.3,180,9,999999999,300,0.2270,0,88,999.000,999.0,99.0
+1987,9,18,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,16.7,97,98500,19,553,387,5,0,5,0,0,0,0,310,5.2,10,10,9.7,210,9,999999999,290,0.2690,0,88,999.000,999.0,99.0
+1987,9,18,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,15.6,93,98500,225,1354,383,44,0,44,5000,0,5000,1600,320,4.1,10,10,16.1,270,9,999999999,270,0.2690,0,88,999.000,999.0,99.0
+1987,9,18,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,15.6,93,98600,472,1354,383,91,3,90,10600,200,10500,3680,320,4.1,10,10,11.3,240,9,999999999,270,0.2690,0,88,999.000,999.0,99.0
+1987,9,18,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,15.0,84,98600,689,1354,388,192,3,190,21900,200,21800,7750,300,3.6,10,10,24.1,310,9,999999999,259,0.2690,0,88,999.000,999.0,99.0
+1987,9,18,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,15.0,84,98600,862,1354,388,227,3,225,26400,300,26300,9920,300,3.6,10,10,24.1,370,9,999999999,259,0.2690,0,88,999.000,999.0,99.0
+1987,9,18,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,15.6,84,98700,979,1354,392,299,6,294,34600,500,34200,12850,330,3.1,10,10,24.1,370,9,999999999,270,0.2690,0,88,999.000,999.0,99.0
+1987,9,18,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,16.1,81,98600,1030,1354,398,314,4,312,36700,400,36400,13740,360,4.1,10,10,24.1,460,9,999999999,279,0.2690,0,88,999.000,999.0,99.0
+1987,9,18,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,15.6,76,98600,1014,1354,401,310,4,307,36100,400,35800,13480,320,3.1,10,10,24.1,490,9,999999999,270,0.2690,0,88,999.000,999.0,99.0
+1987,9,18,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,16.1,84,98700,931,1354,395,171,2,170,20600,200,20500,8240,300,3.6,10,10,11.3,580,9,999999999,279,0.2690,0,88,999.000,999.0,99.0
+1987,9,18,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,16.7,90,98600,786,1354,393,169,0,169,19900,0,19900,7610,250,2.1,10,10,8.0,370,9,999999999,290,0.2690,0,88,999.000,999.0,99.0
+1987,9,18,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,17.2,93,98600,590,1354,394,102,0,102,12000,0,12000,4460,320,2.1,10,10,8.0,400,9,999999999,300,0.2690,0,88,999.000,999.0,99.0
+1987,9,18,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,16.1,90,98700,356,1354,390,61,1,61,7100,0,7100,2420,310,3.1,10,10,8.0,400,9,999999999,279,0.2690,0,88,999.000,999.0,99.0
+1987,9,18,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,16.1,93,98700,104,1252,386,18,0,18,2100,0,2100,660,280,2.1,10,10,11.3,1160,9,999999999,279,0.2690,0,88,999.000,999.0,99.0
+1987,9,18,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,16.1,97,98700,0,0,384,0,0,0,0,0,0,0,260,3.6,10,10,12.9,1160,9,999999999,279,0.2690,0,88,999.000,999.0,99.0
+1987,9,18,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,15.6,93,98700,0,0,383,0,0,0,0,0,0,0,250,3.1,10,10,11.3,1520,9,999999999,270,0.2690,0,88,999.000,999.0,99.0
+1987,9,18,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,15.6,97,98700,0,0,380,0,0,0,0,0,0,0,270,2.6,10,10,11.3,460,9,999999999,270,0.2690,0,88,999.000,999.0,99.0
+1987,9,18,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,15.0,93,98700,0,0,355,0,0,0,0,0,0,0,290,3.1,7,7,16.1,1400,9,999999999,259,0.2690,0,88,999.000,999.0,99.0
+1987,9,18,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,14.4,97,98700,0,0,323,0,0,0,0,0,0,0,290,3.6,0,0,16.1,77777,9,999999999,250,0.2690,0,88,999.000,999.0,99.0
+1987,9,18,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,13.3,97,98700,0,0,317,0,0,0,0,0,0,0,270,3.1,0,0,16.1,77777,9,999999999,240,0.2690,0,88,999.000,999.0,99.0
+1987,9,19,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,12.2,97,98700,0,0,311,0,0,0,0,0,0,0,260,3.1,0,0,19.3,77777,9,999999999,220,0.2690,0,88,999.000,999.0,99.0
+1987,9,19,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,11.1,96,98700,0,0,305,0,0,0,0,0,0,0,240,2.1,0,0,24.1,77777,9,999999999,209,0.2690,0,88,999.000,999.0,99.0
+1987,9,19,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,10.6,96,98700,0,0,302,0,0,0,0,0,0,0,220,2.1,0,0,24.1,77777,9,999999999,200,0.2690,0,88,999.000,999.0,99.0
+1987,9,19,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,10.6,96,98700,0,0,302,0,0,0,0,0,0,0,210,2.1,0,0,24.1,77777,9,999999999,200,0.2690,0,88,999.000,999.0,99.0
+1987,9,19,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,10.6,96,98700,0,0,302,0,0,0,0,0,0,0,210,2.6,0,0,19.3,77777,9,999999999,200,0.2690,0,88,999.000,999.0,99.0
+1987,9,19,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,10.6,100,98700,17,530,300,10,11,9,0,0,0,0,230,3.1,0,0,19.3,77777,9,999999999,200,0.1500,0,88,999.000,999.0,99.0
+1987,9,19,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,10.6,90,98700,220,1354,307,98,294,49,10200,19900,6900,880,240,5.2,0,0,24.1,77777,9,999999999,200,0.1500,0,88,999.000,999.0,99.0
+1987,9,19,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,10.6,78,98800,467,1354,316,279,561,82,28700,51500,10900,1570,260,4.1,0,0,24.1,77777,9,999999999,200,0.1500,0,88,999.000,999.0,99.0
+1987,9,19,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,10.6,67,98800,685,1354,327,464,691,110,48500,68400,13800,2380,260,4.1,0,0,24.1,77777,9,999999999,200,0.1500,0,88,999.000,999.0,99.0
+1987,9,19,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,10.0,59,98800,858,1354,333,622,769,129,65900,78100,16200,3280,260,4.1,0,0,24.1,77777,9,999999999,189,0.1500,0,88,999.000,999.0,99.0
+1987,9,19,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,9.4,53,98800,974,1354,352,593,496,233,63600,51600,26400,6770,260,4.1,3,3,24.1,77777,9,999999999,189,0.1500,0,88,999.000,999.0,99.0
+1987,9,19,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,8.9,47,98700,1025,1354,366,559,309,323,60600,33400,35300,10310,270,4.6,6,6,24.1,910,9,999999999,179,0.1500,0,88,999.000,999.0,99.0
+1987,9,19,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,7.8,44,98700,1008,1354,369,588,300,363,63100,32400,39000,11550,230,7.7,7,7,24.1,910,9,999999999,170,0.1500,0,88,999.000,999.0,99.0
+1987,9,19,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,7.8,41,98600,924,1354,381,392,171,274,43100,18100,30700,8110,250,5.2,8,8,24.1,910,9,999999999,170,0.1500,0,88,999.000,999.0,99.0
+1987,9,19,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,7.8,47,98600,779,1354,377,262,67,223,28800,6700,24900,7230,210,5.2,9,9,24.1,2130,9,999999999,170,0.1500,0,88,999.000,999.0,99.0
+1987,9,19,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,8.3,52,98600,583,1354,382,144,0,144,16500,0,16500,5800,240,3.6,10,10,24.1,1220,9,999999999,170,0.1500,0,88,999.000,999.0,99.0
+1987,9,19,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,9.4,61,98700,348,1354,378,48,5,47,5700,200,5700,1940,260,5.2,10,10,24.1,1220,9,999999999,189,0.1500,0,88,999.000,999.0,99.0
+1987,9,19,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,10.0,70,98700,97,1208,360,17,0,17,2000,0,2000,620,260,3.6,9,9,24.1,1220,9,999999999,189,0.1500,0,88,999.000,999.0,99.0
+1987,9,19,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,10.6,81,98700,0,0,333,0,0,0,0,0,0,0,250,2.6,5,5,24.1,77777,9,999999999,200,0.1500,0,88,999.000,999.0,99.0
+1987,9,19,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,10.6,90,98700,0,0,317,0,0,0,0,0,0,0,220,3.1,2,2,24.1,77777,9,999999999,200,0.1500,0,88,999.000,999.0,99.0
+1987,9,19,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,11.1,90,98700,0,0,340,0,0,0,0,0,0,0,220,2.6,8,8,24.1,1220,9,999999999,209,0.1500,0,88,999.000,999.0,99.0
+1987,9,19,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,10.6,90,98700,0,0,317,0,0,0,0,0,0,0,220,2.6,2,2,24.1,77777,9,999999999,200,0.1500,0,88,999.000,999.0,99.0
+1987,9,19,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,10.6,90,98700,0,0,320,0,0,0,0,0,0,0,250,3.1,3,3,24.1,77777,9,999999999,200,0.1500,0,88,999.000,999.0,99.0
+1987,9,19,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,10.0,86,98700,0,0,306,0,0,0,0,0,0,0,270,2.6,2,0,24.1,77777,9,999999999,189,0.1500,0,88,999.000,999.0,99.0
+1987,9,20,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,10.6,93,98700,0,0,329,0,0,0,0,0,0,0,200,2.6,7,7,24.1,4570,9,999999999,200,0.1500,0,88,999.000,999.0,99.0
+1987,9,20,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,10.6,90,98700,0,0,332,0,0,0,0,0,0,0,220,2.6,9,7,24.1,2130,9,999999999,200,0.1500,0,88,999.000,999.0,99.0
+1987,9,20,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,10.6,93,98600,0,0,335,0,0,0,0,0,0,0,210,2.1,9,8,24.1,1680,9,999999999,200,0.1500,0,88,999.000,999.0,99.0
+1987,9,20,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,10.6,93,98600,0,0,335,0,0,0,0,0,0,0,210,2.6,9,8,24.1,1680,9,999999999,200,0.1500,0,88,999.000,999.0,99.0
+1987,9,20,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,11.1,96,98600,0,0,352,0,0,0,0,0,0,0,230,3.1,10,10,19.3,1400,9,999999999,209,0.1500,0,88,999.000,999.0,99.0
+1987,9,20,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,11.1,96,98600,16,508,352,0,1,0,0,0,0,0,210,3.6,10,10,24.1,700,9,999999999,209,0.0630,0,88,999.000,999.0,99.0
+1987,9,20,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,11.1,93,98600,216,1355,355,56,6,55,6200,100,6200,1850,220,3.6,10,10,24.1,430,9,999999999,209,0.0630,0,88,999.000,999.0,99.0
+1987,9,20,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,11.1,90,98600,463,1355,358,123,6,121,13900,400,13800,4540,250,4.1,10,10,24.1,270,9,999999999,209,0.0630,0,88,999.000,999.0,99.0
+1987,9,20,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,11.1,84,98600,680,1355,363,182,11,177,21000,900,20500,7310,250,5.2,10,10,24.1,340,9,999999999,209,0.0630,0,88,999.000,999.0,99.0
+1987,9,20,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,10.6,75,98700,853,1355,358,411,157,311,44500,16500,34200,8660,260,4.6,9,9,24.1,400,9,999999999,200,0.0630,0,88,999.000,999.0,99.0
+1987,9,20,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,10.6,87,98700,969,1355,357,171,39,142,18900,3900,16100,5660,250,4.6,10,10,24.1,880,9,999999999,200,0.0630,0,88,999.000,999.0,99.0
+1987,9,20,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,10.0,65,98700,1020,1355,352,471,163,347,51500,17300,38500,11400,250,5.2,8,7,24.1,520,9,999999999,189,0.0630,0,88,999.000,999.0,99.0
+1987,9,20,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,9.4,70,98700,1003,1355,367,306,3,304,35600,300,35400,13310,290,6.2,10,10,24.1,1010,9,999999999,189,0.0630,0,88,999.000,999.0,99.0
+1987,9,20,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,9.4,65,98700,918,1355,372,256,19,243,29900,1600,28800,10840,280,6.2,10,10,24.1,1160,9,999999999,189,0.0630,0,88,999.000,999.0,99.0
+1987,9,20,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,9.4,63,98700,773,1355,375,205,3,204,23800,200,23600,8690,300,6.2,10,10,24.1,1160,9,999999999,189,0.0630,0,88,999.000,999.0,99.0
+1987,9,20,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,9.4,67,98800,576,1355,370,106,10,102,12500,600,12200,4420,280,5.2,10,10,24.1,1370,9,999999999,189,0.0630,0,88,999.000,999.0,99.0
+1987,9,20,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,10.6,72,98800,341,1355,348,134,182,88,14200,15300,10400,1690,260,5.2,9,7,24.1,1160,9,999999999,200,0.0630,0,88,999.000,999.0,99.0
+1987,9,20,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,11.1,81,98800,91,1163,356,14,11,13,1500,600,1500,340,230,4.1,9,9,8.0,400,9,999999999,209,0.0630,0,88,999.000,999.0,99.0
+1987,9,20,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,11.1,90,98900,0,0,340,0,0,0,0,0,0,0,250,2.6,8,8,24.1,1400,9,999999999,209,0.0630,0,88,999.000,999.0,99.0
+1987,9,20,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,10.6,93,98900,0,0,320,0,0,0,0,0,0,0,250,2.6,4,4,24.1,77777,9,999999999,200,0.0630,0,88,999.000,999.0,99.0
+1987,9,20,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,10.6,96,98900,0,0,312,0,0,0,0,0,0,0,250,3.1,2,2,24.1,77777,9,999999999,200,0.0630,0,88,999.000,999.0,99.0
+1987,9,20,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,10.0,93,98900,0,0,301,0,0,0,0,0,0,0,260,2.6,0,0,24.1,77777,9,999999999,189,0.0630,0,88,999.000,999.0,99.0
+1987,9,20,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,10.6,96,98900,0,0,302,0,0,0,0,0,0,0,250,3.6,0,0,24.1,77777,9,999999999,200,0.0630,0,88,999.000,999.0,99.0
+1987,9,20,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,10.0,96,98800,0,0,299,0,0,0,0,0,0,0,260,3.6,0,0,24.1,77777,9,999999999,189,0.0630,0,88,999.000,999.0,99.0
+1987,9,21,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,10.0,100,98800,0,0,297,0,0,0,0,0,0,0,260,3.6,0,0,24.1,77777,9,999999999,189,0.0630,0,88,999.000,999.0,99.0
+1987,9,21,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,9.4,96,98900,0,0,296,0,0,0,0,0,0,0,250,3.1,0,0,24.1,77777,9,999999999,189,0.0630,0,88,999.000,999.0,99.0
+1987,9,21,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,9.4,96,98900,0,0,306,0,0,0,0,0,0,0,250,3.1,3,2,24.1,77777,9,999999999,189,0.0630,0,88,999.000,999.0,99.0
+1987,9,21,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,9.4,96,98900,0,0,317,0,0,0,0,0,0,0,270,3.1,7,6,24.1,1680,9,999999999,189,0.0630,0,88,999.000,999.0,99.0
+1987,9,21,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,9.4,96,98900,0,0,317,0,0,0,0,0,0,0,270,3.6,7,6,24.1,1680,9,999999999,189,0.0630,0,88,999.000,999.0,99.0
+1987,9,21,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,10.0,96,98900,14,486,329,5,2,5,0,0,0,0,270,3.1,9,8,19.3,1830,9,999999999,189,0.0830,0,88,999.000,999.0,99.0
+1987,9,21,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,10.6,93,98900,212,1356,352,63,2,63,7000,0,7000,1990,310,3.6,10,10,12.9,180,9,999999999,200,0.0830,0,88,999.000,999.0,99.0
+1987,9,21,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,11.1,93,99000,458,1356,355,91,7,88,10500,400,10300,3570,270,3.6,10,10,16.1,240,9,999999999,209,0.0830,0,88,999.000,999.0,99.0
+1987,9,21,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,11.7,87,99000,676,1356,364,167,12,161,19300,900,18900,6800,240,4.1,10,10,12.9,490,9,999999999,220,0.0830,0,88,999.000,999.0,99.0
+1987,9,21,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,11.7,84,99000,848,1356,366,264,2,263,30300,200,30200,10950,270,4.6,10,10,14.5,460,9,999999999,209,0.0830,0,88,999.000,999.0,99.0
+1987,9,21,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,12.2,87,99000,964,1356,367,175,9,169,21200,700,20700,8310,280,4.6,10,10,11.3,700,9,999999999,220,0.0830,0,88,999.000,999.0,99.0
+1987,9,21,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,13.3,93,99000,1014,1356,368,207,3,205,24900,200,24700,9930,270,5.2,10,10,11.3,760,9,999999999,240,0.0830,0,88,999.000,999.0,99.0
+1987,9,21,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,13.3,84,99100,997,1356,377,311,3,308,36000,300,35800,13380,270,4.6,10,10,16.1,880,9,999999999,240,0.0830,0,88,999.000,999.0,99.0
+1987,9,21,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,13.9,93,99100,912,1356,372,196,5,193,23300,400,23000,9060,330,5.2,10,10,11.3,760,9,999999999,240,0.0830,0,88,999.000,999.0,99.0
+1987,9,21,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,13.3,84,99100,766,1356,367,165,4,163,19400,300,19200,7300,320,4.6,10,9,16.1,760,9,999999999,240,0.0830,0,88,999.000,999.0,99.0
+1987,9,21,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,12.2,81,99100,569,1356,373,115,7,112,13400,500,13200,4740,310,3.6,10,10,24.1,1010,9,999999999,220,0.0830,0,88,999.000,999.0,99.0
+1987,9,21,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,12.8,90,99200,334,1356,368,64,12,61,7400,500,7300,2360,310,3.6,10,10,11.3,1160,9,999999999,229,0.0830,0,88,999.000,999.0,99.0
+1987,9,21,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,12.8,93,99200,85,1119,365,11,1,11,1300,0,1300,420,310,3.6,10,10,11.3,1010,9,999999999,229,0.0830,0,88,999.000,999.0,99.0
+1987,9,21,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,12.8,93,99200,0,0,365,0,0,0,0,0,0,0,300,4.1,10,10,11.3,700,9,999999999,229,0.0830,0,88,999.000,999.0,99.0
+1987,9,21,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,12.8,93,99200,0,0,365,0,0,0,0,0,0,0,310,4.1,10,10,16.1,2130,9,999999999,229,0.0830,0,88,999.000,999.0,99.0
+1987,9,21,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,12.8,97,99200,0,0,339,0,0,0,0,0,0,0,310,4.1,8,7,16.1,2130,9,999999999,229,0.0830,0,88,999.000,999.0,99.0
+1987,9,21,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,12.8,93,99200,0,0,365,0,0,0,0,0,0,0,330,4.6,10,10,16.1,1400,9,999999999,229,0.0830,0,88,999.000,999.0,99.0
+1987,9,21,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,12.2,90,99300,0,0,364,0,0,0,0,0,0,0,320,4.6,10,10,19.3,400,9,999999999,220,0.0830,0,88,999.000,999.0,99.0
+1987,9,21,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,12.2,90,99300,0,0,354,0,0,0,0,0,0,0,340,4.6,9,9,24.1,400,9,999999999,220,0.0830,0,88,999.000,999.0,99.0
+1987,9,22,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,12.2,90,99300,0,0,364,0,0,0,0,0,0,0,320,4.1,10,10,24.1,460,9,999999999,220,0.0830,0,88,999.000,999.0,99.0
+1987,9,22,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,12.2,90,99300,0,0,335,0,0,0,0,0,0,0,310,4.6,5,5,24.1,77777,9,999999999,220,0.0830,0,88,999.000,999.0,99.0
+1987,9,22,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,12.2,93,99300,0,0,339,0,0,0,0,0,0,0,310,4.6,7,7,24.1,520,9,999999999,220,0.0830,0,88,999.000,999.0,99.0
+1987,9,22,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,11.7,90,99300,0,0,351,0,0,0,0,0,0,0,320,5.2,9,9,24.1,370,9,999999999,209,0.0830,0,88,999.000,999.0,99.0
+1987,9,22,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,11.7,90,99300,0,0,361,0,0,0,0,0,0,0,320,4.6,10,10,24.1,340,9,999999999,209,0.0830,0,88,999.000,999.0,99.0
+1987,9,22,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,11.7,90,99400,13,441,351,3,1,3,0,0,0,0,330,5.7,9,9,24.1,1680,9,999999999,220,0.0820,0,88,999.000,999.0,99.0
+1987,9,22,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,11.7,87,99400,207,1357,346,73,35,67,7900,2600,7500,1550,330,5.2,10,8,24.1,700,9,999999999,220,0.0820,0,88,999.000,999.0,99.0
+1987,9,22,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,12.2,87,99500,454,1357,367,98,12,94,11300,700,11000,3740,320,5.2,10,10,24.1,370,9,999999999,220,0.0820,0,88,999.000,999.0,99.0
+1987,9,22,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,12.8,84,99500,671,1357,356,384,310,228,40500,32000,24600,5270,340,5.2,8,8,24.1,2440,9,999999999,229,0.0820,0,88,999.000,999.0,99.0
+1987,9,22,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,12.8,78,99600,843,1357,380,336,19,324,37800,1900,36700,12380,340,6.2,10,10,24.1,460,9,999999999,229,0.0820,0,88,999.000,999.0,99.0
+1987,9,22,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,13.3,68,99600,959,1357,395,288,13,279,33500,1200,32700,12240,30,5.2,10,10,24.1,580,9,999999999,240,0.0820,0,88,999.000,999.0,99.0
+1987,9,22,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,13.3,70,99600,1009,1357,392,272,10,264,31900,900,31300,12060,350,5.7,10,10,24.1,1370,9,999999999,240,0.0820,0,88,999.000,999.0,99.0
+1987,9,22,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,12.8,68,99500,991,1357,391,298,11,290,34700,1000,34000,12790,30,5.2,10,10,24.1,1370,9,999999999,229,0.0820,0,88,999.000,999.0,99.0
+1987,9,22,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,12.2,57,99500,906,1357,383,418,235,260,45400,25200,28500,6990,40,5.2,8,8,24.1,1370,9,999999999,220,0.0820,0,88,999.000,999.0,99.0
+1987,9,22,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,13.9,84,99500,759,1357,381,111,5,109,13500,300,13300,5210,20,2.6,10,10,24.1,700,9,999999999,250,0.0820,0,88,999.000,999.0,99.0
+1987,9,22,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,13.3,78,99500,561,1357,383,145,28,134,16000,2700,14900,3970,30,3.6,10,10,24.1,1160,9,999999999,240,0.0820,0,88,999.000,999.0,99.0
+1987,9,22,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,12.8,75,99500,326,1357,382,82,9,80,9200,400,9100,2870,40,3.1,10,10,24.1,700,9,999999999,229,0.0820,0,88,999.000,999.0,99.0
+1987,9,22,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,12.2,81,99500,79,1097,337,29,48,24,3000,2300,2900,500,330,2.1,8,3,24.1,77777,9,999999999,220,0.0820,0,88,999.000,999.0,99.0
+1987,9,22,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,11.7,90,99500,0,0,319,0,0,0,0,0,0,0,270,2.1,3,1,24.1,77777,9,999999999,220,0.0820,0,88,999.000,999.0,99.0
+1987,9,22,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,10.6,87,99600,0,0,323,0,0,0,0,0,0,0,260,3.1,3,3,24.1,77777,9,999999999,200,0.0820,0,88,999.000,999.0,99.0
+1987,9,22,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,10.0,86,99600,0,0,306,0,0,0,0,0,0,0,280,2.6,0,0,24.1,77777,9,999999999,189,0.0820,0,88,999.000,999.0,99.0
+1987,9,22,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,10.6,93,99600,0,0,305,0,0,0,0,0,0,0,270,3.1,0,0,24.1,77777,9,999999999,200,0.0820,0,88,999.000,999.0,99.0
+1987,9,22,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,10.0,93,99600,0,0,301,0,0,0,0,0,0,0,280,3.1,0,0,24.1,77777,9,999999999,189,0.0820,0,88,999.000,999.0,99.0
+1987,9,22,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,10.6,93,99500,0,0,335,0,0,0,0,0,0,0,280,3.1,8,8,24.1,1400,9,999999999,200,0.0820,0,88,999.000,999.0,99.0
+1987,9,23,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,10.6,93,99500,0,0,342,0,0,0,0,0,0,0,280,3.1,9,9,24.1,1400,9,999999999,200,0.0820,0,88,999.000,999.0,99.0
+1987,9,23,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,10.0,93,99500,0,0,307,0,0,0,0,0,0,0,280,2.6,1,1,24.1,77777,9,999999999,189,0.0820,0,88,999.000,999.0,99.0
+1987,9,23,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,9.4,93,99400,0,0,299,0,0,0,0,0,0,0,270,3.1,0,0,24.1,77777,9,999999999,189,0.0820,0,88,999.000,999.0,99.0
+1987,9,23,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,9.4,96,99400,0,0,296,0,0,0,0,0,0,0,270,3.1,0,0,24.1,77777,9,999999999,189,0.0820,0,88,999.000,999.0,99.0
+1987,9,23,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,8.9,93,99500,0,0,296,0,0,0,0,0,0,0,270,3.1,0,0,24.1,77777,9,999999999,179,0.0820,0,88,999.000,999.0,99.0
+1987,9,23,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,8.9,93,99500,12,419,296,8,14,7,0,0,0,0,260,3.1,0,0,24.1,77777,9,999999999,179,0.1140,0,88,999.000,999.0,99.0
+1987,9,23,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,10.0,86,99500,203,1357,306,91,319,42,9100,21400,5900,740,250,3.6,0,0,24.1,77777,9,999999999,189,0.1140,0,88,999.000,999.0,99.0
+1987,9,23,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,10.6,72,99500,449,1357,322,273,604,69,28200,55200,9900,1340,270,3.6,0,0,24.1,77777,9,999999999,200,0.1140,0,88,999.000,999.0,99.0
+1987,9,23,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,10.0,61,99500,667,1357,331,458,735,92,47100,71600,11800,1890,270,3.6,0,0,24.1,77777,9,999999999,200,0.1140,0,88,999.000,999.0,99.0
+1987,9,23,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,10.6,57,99400,839,1357,339,612,803,109,63700,80200,14000,2570,280,4.6,0,0,24.1,77777,9,999999999,200,0.1140,0,88,999.000,999.0,99.0
+1987,9,23,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,10.6,51,99400,954,1357,354,677,780,123,71000,78500,15700,3310,280,5.7,1,1,24.1,77777,9,999999999,200,0.1140,0,88,999.000,999.0,99.0
+1987,9,23,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,10.6,48,99300,1004,1357,370,636,578,203,66400,58500,23000,6100,300,6.2,4,4,24.1,77777,9,999999999,200,0.1140,0,88,999.000,999.0,99.0
+1987,9,23,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,10.0,46,99200,985,1357,372,619,572,199,64600,57800,22500,5800,280,7.2,5,5,24.1,77777,9,999999999,189,0.1140,0,88,999.000,999.0,99.0
+1987,9,23,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,10.0,43,99200,899,1357,372,576,567,196,62000,58700,23000,5050,280,6.7,3,3,24.1,77777,9,999999999,189,0.1140,0,88,999.000,999.0,99.0
+1987,9,23,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,10.0,40,99100,753,1357,362,535,776,100,55500,76700,12800,2190,270,6.7,0,0,24.1,77777,9,999999999,189,0.1140,0,88,999.000,999.0,99.0
+1987,9,23,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,8.9,39,99000,554,1357,358,360,677,80,37700,65000,11100,1630,270,6.7,0,0,24.1,77777,9,999999999,179,0.1140,0,88,999.000,999.0,99.0
+1987,9,23,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,10.6,48,99000,319,1357,352,171,487,54,17500,39800,8100,1000,270,6.2,0,0,24.1,77777,9,999999999,200,0.1140,0,88,999.000,999.0,99.0
+1987,9,23,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,10.6,48,99000,73,1052,352,34,104,23,3200,4400,2900,410,270,3.1,0,0,24.1,77777,9,999999999,200,0.1140,0,88,999.000,999.0,99.0
+1987,9,23,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,10.6,55,99000,0,0,342,0,0,0,0,0,0,0,280,2.6,0,0,24.1,77777,9,999999999,200,0.1140,0,88,999.000,999.0,99.0
+1987,9,23,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,11.1,59,99100,0,0,339,0,0,0,0,0,0,0,230,2.1,0,0,24.1,77777,9,999999999,209,0.1140,0,88,999.000,999.0,99.0
+1987,9,23,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,11.1,75,99100,0,0,322,0,0,0,0,0,0,0,230,2.1,0,0,24.1,77777,9,999999999,209,0.1140,0,88,999.000,999.0,99.0
+1987,9,23,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,11.1,81,99100,0,0,317,0,0,0,0,0,0,0,270,3.1,0,0,24.1,77777,9,999999999,209,0.1140,0,88,999.000,999.0,99.0
+1987,9,23,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,10.6,75,99000,0,0,319,0,0,0,0,0,0,0,250,3.6,0,0,24.1,77777,9,999999999,200,0.1140,0,88,999.000,999.0,99.0
+1987,9,23,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,10.6,78,99000,0,0,316,0,0,0,0,0,0,0,260,4.1,0,0,24.1,77777,9,999999999,200,0.1140,0,88,999.000,999.0,99.0
+1987,9,24,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,10.6,81,99000,0,0,314,0,0,0,0,0,0,0,270,3.6,0,0,24.1,77777,9,999999999,200,0.1140,0,88,999.000,999.0,99.0
+1987,9,24,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,10.6,83,98900,0,0,312,0,0,0,0,0,0,0,260,4.1,0,0,24.1,77777,9,999999999,200,0.1140,0,88,999.000,999.0,99.0
+1987,9,24,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,10.0,86,98900,0,0,306,0,0,0,0,0,0,0,250,3.1,0,0,24.1,77777,9,999999999,189,0.1140,0,88,999.000,999.0,99.0
+1987,9,24,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,10.0,93,99000,0,0,301,0,0,0,0,0,0,0,350,1.5,0,0,24.1,77777,9,999999999,189,0.1140,0,88,999.000,999.0,99.0
+1987,9,24,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,10.0,96,99000,0,0,299,0,0,0,0,0,0,0,340,3.1,0,0,24.1,77777,9,999999999,189,0.1140,0,88,999.000,999.0,99.0
+1987,9,24,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,9.4,96,99000,10,396,325,3,1,2,0,0,0,0,250,2.1,8,8,14.5,310,9,999999999,189,0.1340,0,88,999.000,999.0,99.0
+1987,9,24,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,12.2,90,99100,198,1358,322,82,264,42,8500,16900,6000,750,320,2.6,1,1,16.1,77777,9,999999999,220,0.1340,0,88,999.000,999.0,99.0
+1987,9,24,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,13.9,81,99100,445,1358,339,250,488,87,25400,43900,11000,1620,10,2.1,4,1,24.1,77777,9,999999999,240,0.1340,0,88,999.000,999.0,99.0
+1987,9,24,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,13.3,75,99200,662,1358,386,206,26,193,23400,2100,22300,7630,40,3.6,10,10,24.1,700,9,999999999,240,0.1340,0,88,999.000,999.0,99.0
+1987,9,24,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,11.1,59,99200,834,1358,351,564,681,140,59100,68700,16800,3410,40,6.7,2,2,24.1,77777,9,999999999,209,0.1340,0,88,999.000,999.0,99.0
+1987,9,24,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,11.1,59,99200,948,1358,339,640,724,129,66700,72600,15800,3390,30,7.2,0,0,24.1,77777,9,999999999,209,0.1340,0,88,999.000,999.0,99.0
+1987,9,24,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,11.7,63,99200,998,1358,355,710,675,208,73900,68100,23700,6160,20,6.7,4,4,24.1,77777,9,999999999,209,0.1340,0,88,999.000,999.0,99.0
+1987,9,24,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,11.1,55,99200,979,1358,363,695,744,153,73900,76100,18900,4540,50,8.2,4,4,24.1,77777,9,999999999,209,0.1340,0,88,999.000,999.0,99.0
+1987,9,24,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,10.6,57,99200,893,1358,356,603,598,205,64500,61900,23700,5260,50,6.2,4,4,24.1,77777,9,999999999,200,0.1340,0,88,999.000,999.0,99.0
+1987,9,24,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,9.4,53,99200,746,1358,352,436,503,157,46800,51200,18600,3430,50,7.7,3,3,24.1,77777,9,999999999,189,0.1340,0,88,999.000,999.0,99.0
+1987,9,24,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,8.3,52,99300,547,1358,346,319,521,107,32800,49200,12900,2070,10,6.7,3,3,24.1,77777,9,999999999,179,0.1340,0,88,999.000,999.0,99.0
+1987,9,24,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,7.8,54,99300,311,1358,340,141,263,79,14500,20900,9600,1460,40,6.7,3,3,24.1,77777,9,999999999,170,0.1340,0,88,999.000,999.0,99.0
+1987,9,24,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,7.8,65,99300,68,1007,339,12,5,11,1300,300,1200,290,50,5.2,7,7,24.1,3050,9,999999999,170,0.1340,0,88,999.000,999.0,99.0
+1987,9,24,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,8.3,75,99300,0,0,317,0,0,0,0,0,0,0,10,4.1,2,2,24.1,77777,9,999999999,179,0.1340,0,88,999.000,999.0,99.0
+1987,9,24,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,8.3,77,99400,0,0,304,0,0,0,0,0,0,0,10,4.6,0,0,24.1,77777,9,999999999,179,0.1340,0,88,999.000,999.0,99.0
+1987,9,24,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,7.2,80,99400,0,0,297,0,0,0,0,0,0,0,360,3.6,0,0,24.1,77777,9,999999999,170,0.1340,0,88,999.000,999.0,99.0
+1987,9,24,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,7.8,83,99500,0,0,297,0,0,0,0,0,0,0,350,3.1,0,0,24.1,77777,9,999999999,170,0.1340,0,88,999.000,999.0,99.0
+1987,9,24,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,7.8,86,99500,0,0,295,0,0,0,0,0,0,0,360,3.1,0,0,24.1,77777,9,999999999,170,0.1340,0,88,999.000,999.0,99.0
+1987,9,24,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,7.2,89,99500,0,0,290,0,0,0,0,0,0,0,360,2.6,0,0,24.1,77777,9,999999999,160,0.1340,0,88,999.000,999.0,99.0
+1987,9,25,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,7.2,89,99500,0,0,290,0,0,0,0,0,0,0,350,2.6,0,0,24.1,77777,9,999999999,160,0.1340,0,88,999.000,999.0,99.0
+1987,9,25,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,7.2,89,99500,0,0,290,0,0,0,0,0,0,0,340,2.1,0,0,16.1,77777,9,999999999,160,0.1340,0,88,999.000,999.0,99.0
+1987,9,25,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,7.2,93,99500,0,0,287,0,0,0,0,0,0,0,340,2.6,0,0,16.1,77777,9,999999999,160,0.1340,0,88,999.000,999.0,99.0
+1987,9,25,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,6.7,96,99600,0,0,282,0,0,0,0,0,0,0,320,2.6,0,0,16.1,77777,9,999999999,160,0.1340,0,88,999.000,999.0,99.0
+1987,9,25,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,6.7,96,99600,0,0,282,0,0,0,0,0,0,0,320,2.1,0,0,16.1,77777,9,999999999,160,0.1340,0,88,999.000,999.0,99.0
+1987,9,25,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,6.1,96,99700,9,374,289,4,5,3,0,0,0,0,320,1.5,2,2,16.1,77777,9,999999999,150,0.1430,0,88,999.000,999.0,99.0
+1987,9,25,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,7.8,96,99800,194,1359,297,70,173,44,7200,10900,5600,790,260,1.5,2,2,19.3,77777,9,999999999,170,0.1430,0,88,999.000,999.0,99.0
+1987,9,25,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,8.9,80,99800,440,1359,318,206,323,99,21500,29300,12000,1850,170,2.1,3,3,24.1,77777,9,999999999,179,0.1430,0,88,999.000,999.0,99.0
+1987,9,25,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,9.4,65,99800,657,1359,333,420,602,124,43300,58800,14800,2560,200,2.1,2,2,24.1,77777,9,999999999,189,0.1430,0,88,999.000,999.0,99.0
+1987,9,25,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,9.4,61,99800,829,1359,338,536,616,156,55900,61800,18100,3720,170,3.1,2,2,24.1,77777,9,999999999,189,0.1430,0,88,999.000,999.0,99.0
+1987,9,25,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,8.9,56,99800,943,1359,336,695,801,132,72100,80200,16200,3400,170,2.6,1,1,24.1,77777,9,999999999,179,0.1430,0,88,999.000,999.0,99.0
+1987,9,25,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,8.9,53,99800,992,1359,341,626,640,153,66600,65500,18600,4640,300,3.1,1,1,24.1,77777,9,999999999,179,0.1430,0,88,999.000,999.0,99.0
+1987,9,25,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,8.3,47,99700,973,1359,339,708,788,137,73500,79000,16800,3680,220,3.6,0,0,24.1,77777,9,999999999,179,0.1430,0,88,999.000,999.0,99.0
+1987,9,25,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,7.2,42,99600,887,1359,341,650,791,129,67200,78800,15600,3050,270,3.1,0,0,24.1,77777,9,999999999,160,0.1430,0,88,999.000,999.0,99.0
+1987,9,25,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,5.6,38,99500,739,1359,339,512,726,113,54000,72700,14300,2550,320,2.6,0,0,24.1,77777,9,999999999,150,0.1430,0,88,999.000,999.0,99.0
+1987,9,25,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,5.6,38,99500,540,1359,339,342,628,89,35500,59700,11700,1770,240,3.1,0,0,24.1,77777,9,999999999,150,0.1430,0,88,999.000,999.0,99.0
+1987,9,25,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,5.6,40,99400,304,1359,333,155,421,59,15700,33500,8200,1060,230,2.6,0,0,24.1,77777,9,999999999,150,0.1430,0,88,999.000,999.0,99.0
+1987,9,25,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,5.6,52,99400,62,963,316,29,63,22,2800,2300,2600,390,0,0.0,0,0,24.1,77777,9,999999999,150,0.1430,0,88,999.000,999.0,99.0
+1987,9,25,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,6.7,69,99400,0,0,303,0,0,0,0,0,0,0,220,2.1,0,0,24.1,77777,9,999999999,160,0.1430,0,88,999.000,999.0,99.0
+1987,9,25,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,6.7,69,99400,0,0,303,0,0,0,0,0,0,0,210,2.6,0,0,24.1,77777,9,999999999,160,0.1430,0,88,999.000,999.0,99.0
+1987,9,25,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,7.2,80,99400,0,0,297,0,0,0,0,0,0,0,230,2.6,0,0,24.1,77777,9,999999999,170,0.1430,0,88,999.000,999.0,99.0
+1987,9,25,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,6.1,72,99400,0,0,298,0,0,0,0,0,0,0,230,3.1,0,0,24.1,77777,9,999999999,150,0.1430,0,88,999.000,999.0,99.0
+1987,9,25,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,5.6,74,99400,0,0,292,0,0,0,0,0,0,0,220,3.1,0,0,24.1,77777,9,999999999,150,0.1430,0,88,999.000,999.0,99.0
+1987,9,25,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,5.6,74,99300,0,0,292,0,0,0,0,0,0,0,180,2.1,0,0,24.1,77777,9,999999999,150,0.1430,0,88,999.000,999.0,99.0
+1987,9,26,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,6.1,83,99300,0,0,288,0,0,0,0,0,0,0,180,1.5,0,0,24.1,77777,9,999999999,150,0.1430,0,88,999.000,999.0,99.0
+1987,9,26,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,6.7,89,99300,0,0,287,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,160,0.1430,0,88,999.000,999.0,99.0
+1987,9,26,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,5.6,86,99300,0,0,283,0,0,0,0,0,0,0,200,1.5,0,0,24.1,77777,9,999999999,150,0.1430,0,88,999.000,999.0,99.0
+1987,9,26,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,5.0,80,99300,0,0,285,0,0,0,0,0,0,0,180,2.1,0,0,24.1,77777,9,999999999,139,0.1430,0,88,999.000,999.0,99.0
+1987,9,26,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,5.0,80,99400,0,0,285,0,0,0,0,0,0,0,180,2.1,0,0,16.1,77777,9,999999999,139,0.1430,0,88,999.000,999.0,99.0
+1987,9,26,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,4.4,77,99400,8,351,284,6,3,6,0,0,0,0,180,1.5,0,0,16.1,77777,9,999999999,139,0.1610,0,88,999.000,999.0,99.0
+1987,9,26,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,6.7,74,99400,189,1360,298,79,231,46,8100,14400,6100,830,200,1.5,0,0,19.3,77777,9,999999999,160,0.1610,0,88,999.000,999.0,99.0
+1987,9,26,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,7.8,60,99400,436,1360,319,253,524,81,25700,47000,10600,1520,220,4.1,0,0,24.1,77777,9,999999999,170,0.1610,0,88,999.000,999.0,99.0
+1987,9,26,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,7.8,49,99500,652,1360,333,438,671,111,45500,65800,13800,2320,220,3.6,0,0,24.1,77777,9,999999999,170,0.1610,0,88,999.000,999.0,99.0
+1987,9,26,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,9.4,44,99500,824,1360,351,589,744,132,61900,75100,16300,3200,210,5.2,0,0,24.1,77777,9,999999999,189,0.1610,0,88,999.000,999.0,99.0
+1987,9,26,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,8.9,39,99500,938,1360,358,694,787,145,71300,78400,17000,3560,230,4.1,0,0,24.1,77777,9,999999999,179,0.1610,0,88,999.000,999.0,99.0
+1987,9,26,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,8.9,35,99400,987,1360,367,738,801,150,76000,80000,17800,3990,230,3.6,0,0,24.1,77777,9,999999999,179,0.1610,0,88,999.000,999.0,99.0
+1987,9,26,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,10.0,35,99300,967,1360,373,718,793,148,73900,79200,17500,3810,180,5.7,0,0,24.1,77777,9,999999999,189,0.1610,0,88,999.000,999.0,99.0
+1987,9,26,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.8,11.1,36,99300,880,1360,380,637,762,138,67300,77400,17100,3560,180,4.1,0,0,24.1,77777,9,999999999,209,0.1610,0,88,999.000,999.0,99.0
+1987,9,26,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.3,10.0,32,99200,732,1360,381,505,706,120,52900,70400,14800,2670,190,6.2,0,0,24.1,77777,9,999999999,189,0.1610,0,88,999.000,999.0,99.0
+1987,9,26,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,9.4,30,99200,533,1360,403,324,503,125,34100,48100,15200,2430,180,4.6,4,4,24.1,77777,9,999999999,189,0.1610,0,88,999.000,999.0,99.0
+1987,9,26,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,10.6,37,99200,296,1360,393,111,91,91,12000,7400,10400,1970,170,2.6,4,4,24.1,77777,9,999999999,200,0.1610,0,88,999.000,999.0,99.0
+1987,9,26,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,12.8,48,99200,57,941,384,20,31,17,2100,1400,2000,350,170,2.6,4,4,24.1,77777,9,999999999,229,0.1610,0,88,999.000,999.0,99.0
+1987,9,26,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,24.4,12.2,47,99200,0,0,401,0,0,0,0,0,0,0,180,3.1,8,8,24.1,2440,9,999999999,220,0.1610,0,88,999.000,999.0,99.0
+1987,9,26,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.9,11.7,46,99200,0,0,397,0,0,0,0,0,0,0,180,3.6,8,8,19.3,2440,9,999999999,209,0.1610,0,88,999.000,999.0,99.0
+1987,9,26,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,12.8,59,99200,0,0,392,0,0,0,0,0,0,0,170,4.6,9,9,19.3,2440,9,999999999,229,0.1610,0,88,999.000,999.0,99.0
+1987,9,26,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,12.2,59,99300,0,0,374,0,0,0,0,0,0,0,190,4.1,7,7,19.3,2440,9,999999999,220,0.1610,0,88,999.000,999.0,99.0
+1987,9,26,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,13.3,66,99300,0,0,365,0,0,0,0,0,0,0,190,3.6,5,5,16.1,77777,9,999999999,240,0.1610,0,88,999.000,999.0,99.0
+1987,9,26,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,13.3,68,99300,0,0,357,0,0,0,0,0,0,0,190,3.1,3,3,16.1,77777,9,999999999,240,0.1610,0,88,999.000,999.0,99.0
+1987,9,27,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,13.3,75,99300,0,0,335,0,0,0,0,0,0,0,190,3.6,0,0,16.1,77777,9,999999999,240,0.1610,0,88,999.000,999.0,99.0
+1987,9,27,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,13.3,81,99300,0,0,329,0,0,0,0,0,0,0,180,2.6,0,0,16.1,77777,9,999999999,240,0.1610,0,88,999.000,999.0,99.0
+1987,9,27,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,13.3,78,99300,0,0,332,0,0,0,0,0,0,0,200,3.1,0,0,12.9,77777,9,999999999,240,0.1610,0,88,999.000,999.0,99.0
+1987,9,27,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,13.3,70,99300,0,0,354,0,0,0,0,0,0,0,210,3.6,3,3,12.9,77777,9,999999999,240,0.1610,0,88,999.000,999.0,99.0
+1987,9,27,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,13.9,76,99400,0,0,349,0,0,0,0,0,0,0,220,3.6,2,2,12.9,77777,9,999999999,250,0.1610,0,88,999.000,999.0,99.0
+1987,9,27,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,13.9,78,99500,7,329,352,2,2,2,0,0,0,0,220,3.1,4,4,16.1,77777,9,999999999,250,0.1160,0,88,999.000,999.0,99.0
+1987,9,27,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,14.4,76,99500,185,1361,352,68,179,43,7000,11000,5500,770,200,3.6,2,2,16.1,77777,9,999999999,259,0.1160,0,88,999.000,999.0,99.0
+1987,9,27,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,15.0,68,99500,431,1361,359,246,540,71,25300,48600,9800,1360,200,4.6,1,1,24.1,77777,9,999999999,259,0.1160,0,88,999.000,999.0,99.0
+1987,9,27,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,15.6,62,99500,648,1361,370,420,681,90,44100,67300,12000,1930,200,5.7,1,1,24.1,77777,9,999999999,270,0.1160,0,88,999.000,999.0,99.0
+1987,9,27,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,15.0,56,99600,819,1361,393,497,475,207,52400,48700,23000,4910,220,5.7,7,6,24.1,2740,9,999999999,259,0.1160,0,88,999.000,999.0,99.0
+1987,9,27,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,14.4,58,99400,933,1361,391,572,437,269,60000,45200,28900,7410,210,4.6,7,7,24.1,2740,9,999999999,259,0.1160,0,88,999.000,999.0,99.0
+1987,9,27,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,15.0,52,99500,981,1361,404,487,188,350,53000,19900,38700,10940,210,4.6,7,7,24.1,2740,9,999999999,259,0.1160,0,88,999.000,999.0,99.0
+1987,9,27,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,13.3,38,99400,961,1361,409,569,469,234,60800,48700,26300,6630,210,4.6,4,4,24.1,77777,9,999999999,240,0.1160,0,88,999.000,999.0,99.0
+1987,9,27,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,14.4,41,99400,874,1361,403,609,760,116,63500,76000,14600,2800,180,4.6,2,2,24.1,77777,9,999999999,250,0.1160,0,88,999.000,999.0,99.0
+1987,9,27,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.1,11.7,30,99400,725,1361,398,508,761,98,52600,74900,12500,2090,180,7.7,0,0,24.1,77777,9,999999999,209,0.1160,0,88,999.000,999.0,99.0
+1987,9,27,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,31.7,11.1,28,99400,526,1361,400,333,653,77,34800,62000,10800,1550,190,5.7,0,0,24.1,77777,9,999999999,209,0.1160,0,88,999.000,999.0,99.0
+1987,9,27,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,28.9,12.2,36,99400,289,1361,400,143,357,66,14900,27600,9000,1200,180,3.1,2,2,24.1,77777,9,999999999,220,0.1160,0,88,999.000,999.0,99.0
+1987,9,27,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,12.8,47,99400,52,896,380,24,39,19,2400,1700,2300,390,190,3.1,2,2,24.1,77777,9,999999999,229,0.1160,0,88,999.000,999.0,99.0
+1987,9,27,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,23.9,12.2,48,99400,0,0,362,0,0,0,0,0,0,0,180,3.6,0,0,19.3,77777,9,999999999,220,0.1160,0,88,999.000,999.0,99.0
+1987,9,27,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,21.1,12.8,59,99400,0,0,349,0,0,0,0,0,0,0,190,3.1,0,0,19.3,77777,9,999999999,229,0.1160,0,88,999.000,999.0,99.0
+1987,9,27,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,12.2,68,99400,0,0,342,0,0,0,0,0,0,0,180,3.1,2,1,16.1,77777,9,999999999,220,0.1160,0,88,999.000,999.0,99.0
+1987,9,27,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,12.2,63,99500,0,0,352,0,0,0,0,0,0,0,170,4.6,2,2,16.1,77777,9,999999999,220,0.1160,0,88,999.000,999.0,99.0
+1987,9,27,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,12.2,70,99500,0,0,348,0,0,0,0,0,0,0,180,3.1,3,3,12.9,77777,9,999999999,220,0.1160,0,88,999.000,999.0,99.0
+1987,9,27,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,11.7,75,99500,0,0,325,0,0,0,0,0,0,0,190,2.6,0,0,12.9,77777,9,999999999,209,0.1160,0,88,999.000,999.0,99.0
+1987,9,28,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,11.7,81,99500,0,0,320,0,0,0,0,0,0,0,180,3.1,0,0,11.3,77777,9,999999999,220,0.1160,0,88,999.000,999.0,99.0
+1987,9,28,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,11.7,84,99500,0,0,317,0,0,0,0,0,0,0,180,2.1,0,0,11.3,77777,9,999999999,220,0.1160,0,88,999.000,999.0,99.0
+1987,9,28,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,11.7,87,99400,0,0,315,0,0,0,0,0,0,0,170,2.1,0,0,11.3,77777,9,999999999,220,0.1160,0,88,999.000,999.0,99.0
+1987,9,28,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,11.7,87,99400,0,0,315,0,0,0,0,0,0,0,170,2.6,0,0,8.0,77777,9,999999999,220,0.1160,0,88,999.000,999.0,99.0
+1987,9,28,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,11.7,81,99400,0,0,331,0,0,0,0,0,0,0,190,3.1,2,2,8.0,77777,9,999999999,220,0.1160,0,88,999.000,999.0,99.0
+1987,9,28,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,12.2,81,99500,6,306,346,4,5,4,0,0,0,0,180,3.6,6,6,9.7,2440,9,999999999,220,0.0730,0,88,999.000,999.0,99.0
+1987,9,28,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,12.2,73,99500,180,1361,341,79,200,51,7900,12100,6300,940,180,3.6,2,2,8.0,77777,9,999999999,220,0.0730,0,88,999.000,999.0,99.0
+1987,9,28,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,12.8,61,99500,426,1361,354,248,606,53,25300,54800,8100,1080,180,3.6,1,1,9.7,77777,9,999999999,229,0.0730,0,88,999.000,999.0,99.0
+1987,9,28,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,13.9,59,99500,643,1361,368,434,714,90,45500,70400,12100,1920,210,4.6,2,2,9.7,77777,9,999999999,240,0.0730,0,88,999.000,999.0,99.0
+1987,9,28,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,13.9,61,99500,814,1361,378,405,316,213,43800,33600,23700,5150,210,5.2,6,6,9.7,2740,9,999999999,240,0.0730,0,88,999.000,999.0,99.0
+1987,9,28,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,15.6,56,99400,927,1361,379,657,823,89,67700,82000,11700,2240,180,4.1,1,1,11.3,77777,9,999999999,270,0.0730,0,88,999.000,999.0,99.0
+1987,9,28,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,16.1,60,99400,975,1361,395,612,461,278,64400,47800,30000,8150,200,4.6,6,6,12.9,2740,9,999999999,279,0.0730,0,88,999.000,999.0,99.0
+1987,9,28,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.7,15.6,51,99300,955,1361,406,712,733,192,74200,74000,22200,5310,200,5.2,7,6,14.5,7620,9,999999999,270,0.0730,0,88,999.000,999.0,99.0
+1987,9,28,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,15.0,47,99200,867,1361,441,236,15,226,27400,1300,26600,9950,180,7.2,10,10,14.5,7620,9,999999999,259,0.0730,0,88,999.000,999.0,99.0
+1987,9,28,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,27.2,15.6,49,99100,718,1361,420,286,138,212,31200,14300,23700,5390,180,7.2,9,8,16.1,2740,9,999999999,270,0.0730,0,88,999.000,999.0,99.0
+1987,9,28,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.6,15.6,54,99100,518,1361,420,190,51,170,20800,4900,18900,4600,180,5.7,10,9,14.5,2740,9,999999999,270,0.0730,0,88,999.000,999.0,99.0
+1987,9,28,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,15.6,58,99100,282,1361,425,75,2,75,8400,100,8400,2560,190,4.1,10,10,12.9,2740,9,999999999,270,0.0730,0,88,999.000,999.0,99.0
+1987,9,28,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,16.1,64,99100,48,851,420,14,1,14,1600,0,1600,500,180,3.1,10,10,11.3,1830,9,999999999,279,0.0730,0,88,999.000,999.0,99.0
+1987,9,28,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,16.1,81,99200,0,0,398,0,0,0,0,0,0,0,310,4.6,10,10,16.1,1830,9,999999999,279,0.0730,0,88,999.000,999.0,99.0
+1987,9,28,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,16.1,87,99200,0,0,392,0,0,0,0,0,0,0,310,2.1,10,10,16.1,1160,9,999999999,279,0.0730,0,88,999.000,999.0,99.0
+1987,9,28,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,16.7,93,99200,0,0,390,0,0,0,0,0,0,0,260,5.2,10,10,14.5,1160,9,999999999,290,0.0730,0,88,999.000,999.0,99.0
+1987,9,28,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,16.7,97,99100,0,0,387,0,0,0,0,0,0,0,210,2.1,10,10,16.1,1520,9,999999999,290,0.0730,0,88,999.000,999.0,99.0
+1987,9,28,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,16.7,97,99100,0,0,387,0,0,0,0,0,0,0,210,2.6,10,10,11.3,2130,9,999999999,290,0.0730,0,88,999.000,999.0,99.0
+1987,9,28,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,16.7,97,99000,0,0,387,0,0,0,0,0,0,0,210,4.1,10,10,6.4,180,9,999999999,290,0.0730,0,88,999.000,999.0,99.0
+1987,9,29,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,16.7,97,99000,0,0,387,0,0,0,0,0,0,0,230,3.1,10,10,6.4,210,9,999999999,290,0.0730,0,88,999.000,999.0,99.0
+1987,9,29,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,16.7,100,98900,0,0,384,0,0,0,0,0,0,0,220,2.6,10,10,8.0,430,9,999999999,290,0.0730,0,88,999.000,999.0,99.0
+1987,9,29,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,16.1,97,98900,0,0,384,0,0,0,0,0,0,0,220,3.6,10,10,6.4,430,9,999999999,279,0.0730,0,88,999.000,999.0,99.0
+1987,9,29,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,15.6,97,98800,0,0,380,0,0,0,0,0,0,0,210,3.1,10,10,6.4,430,9,999999999,270,0.0730,0,88,999.000,999.0,99.0
+1987,9,29,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,15.6,97,98800,0,0,362,0,0,0,0,0,0,0,230,4.1,8,8,6.4,400,9,999999999,270,0.0730,0,88,999.000,999.0,99.0
+1987,9,29,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,13.9,97,98800,5,284,359,1,0,1,0,0,0,0,240,3.6,10,9,8.0,460,9,999999999,240,0.1170,0,88,999.000,999.0,99.0
+1987,9,29,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,13.9,97,98800,176,1362,320,77,285,38,7600,17800,5300,660,240,3.6,0,0,9.7,77777,9,999999999,240,0.1170,0,88,999.000,999.0,99.0
+1987,9,29,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,12.8,81,98800,422,1362,326,250,580,67,25800,51900,9700,1280,280,4.1,0,0,14.5,77777,9,999999999,229,0.1170,0,88,999.000,999.0,99.0
+1987,9,29,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,11.7,70,98900,638,1362,330,429,713,90,45100,70200,12100,1920,280,5.7,0,0,19.3,77777,9,999999999,209,0.1170,0,88,999.000,999.0,99.0
+1987,9,29,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,11.7,65,98800,809,1362,350,555,699,134,58200,70400,16300,3180,280,7.2,3,3,24.1,77777,9,999999999,209,0.1170,0,88,999.000,999.0,99.0
+1987,9,29,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,10.6,67,98800,922,1362,377,353,81,298,38900,8300,33300,10340,270,7.7,10,10,24.1,1070,9,999999999,200,0.1170,0,88,999.000,999.0,99.0
+1987,9,29,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,11.1,68,98800,970,1362,380,303,5,300,35100,500,34800,12920,300,4.6,10,10,24.1,1160,9,999999999,209,0.1170,0,88,999.000,999.0,99.0
+1987,9,29,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,10.6,61,98800,949,1362,361,560,378,294,60500,40700,32000,8380,270,4.6,7,7,24.1,1010,9,999999999,200,0.1170,0,88,999.000,999.0,99.0
+1987,9,29,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,10.6,63,98800,861,1362,383,276,69,232,30400,7000,26000,7970,300,5.7,10,10,24.1,1830,9,999999999,200,0.1170,0,88,999.000,999.0,99.0
+1987,9,29,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,11.1,61,98800,711,1362,365,275,193,173,29900,20200,19300,3830,280,5.2,7,7,24.1,1830,9,999999999,209,0.1170,0,88,999.000,999.0,99.0
+1987,9,29,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,11.7,63,98800,511,1362,355,233,242,141,24800,23500,15900,2900,300,5.7,4,4,24.1,77777,9,999999999,209,0.1170,0,88,999.000,999.0,99.0
+1987,9,29,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,11.1,63,98800,274,1362,349,109,247,58,11400,18600,7600,1040,310,5.2,3,3,24.1,77777,9,999999999,209,0.1170,0,88,999.000,999.0,99.0
+1987,9,29,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,11.1,68,98900,43,829,329,22,54,17,2200,1700,2100,290,300,5.2,0,0,24.1,77777,9,999999999,209,0.1170,0,88,999.000,999.0,99.0
+1987,9,29,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,11.7,78,98900,0,0,323,0,0,0,0,0,0,0,280,3.6,0,0,24.1,77777,9,999999999,220,0.1170,0,88,999.000,999.0,99.0
+1987,9,29,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,11.7,81,98900,0,0,334,0,0,0,0,0,0,0,300,3.1,3,3,24.1,77777,9,999999999,220,0.1170,0,88,999.000,999.0,99.0
+1987,9,29,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,11.7,75,99000,0,0,357,0,0,0,0,0,0,0,320,6.2,8,8,24.1,1400,9,999999999,209,0.1170,0,88,999.000,999.0,99.0
+1987,9,29,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,11.1,78,99000,0,0,333,0,0,0,0,0,0,0,320,5.7,3,3,24.1,77777,9,999999999,209,0.1170,0,88,999.000,999.0,99.0
+1987,9,29,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,10.6,81,99000,0,0,314,0,0,0,0,0,0,0,320,3.6,0,0,24.1,77777,9,999999999,200,0.1170,0,88,999.000,999.0,99.0
+1987,9,29,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,10.6,90,99000,0,0,307,0,0,0,0,0,0,0,310,3.1,0,0,24.1,77777,9,999999999,200,0.1170,0,88,999.000,999.0,99.0
+1987,9,30,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,10.6,93,99000,0,0,305,0,0,0,0,0,0,0,300,3.1,0,0,24.1,77777,9,999999999,200,0.1170,0,88,999.000,999.0,99.0
+1987,9,30,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,10.0,93,99000,0,0,301,0,0,0,0,0,0,0,290,3.1,0,0,24.1,77777,9,999999999,189,0.1170,0,88,999.000,999.0,99.0
+1987,9,30,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,10.6,96,99000,0,0,302,0,0,0,0,0,0,0,280,4.6,0,0,24.1,77777,9,999999999,200,0.1170,0,88,999.000,999.0,99.0
+1987,9,30,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,10.0,96,99000,0,0,299,0,0,0,0,0,0,0,280,2.6,0,0,24.1,77777,9,999999999,189,0.1170,0,88,999.000,999.0,99.0
+1987,9,30,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,9.4,93,99000,0,0,299,0,0,0,0,0,0,0,290,3.1,0,0,24.1,77777,9,999999999,189,0.1170,0,88,999.000,999.0,99.0
+1987,9,30,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,8.3,90,99000,4,261,295,3,0,3,0,0,0,0,280,3.1,1,0,24.1,77777,9,999999999,179,0.2490,0,88,999.000,999.0,99.0
+1987,9,30,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,8.9,83,99100,171,1363,309,55,88,44,6000,5500,5300,920,270,3.6,4,1,24.1,77777,9,999999999,179,0.2490,0,88,999.000,999.0,99.0
+1987,9,30,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,8.3,75,99100,417,1363,337,174,177,119,18900,16200,13900,2670,310,6.2,8,8,24.1,2130,9,999999999,179,0.2490,0,88,999.000,999.0,99.0
+1987,9,30,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,7.2,69,99100,633,1363,343,206,29,193,23300,2400,22200,7410,310,4.6,9,9,24.1,1680,9,999999999,160,0.2490,0,88,999.000,999.0,99.0
+1987,9,30,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,7.2,64,99100,804,1363,327,446,362,229,47900,38400,25200,5570,330,5.7,4,4,24.1,77777,9,999999999,160,0.2490,0,88,999.000,999.0,99.0
+1987,9,30,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,6.7,52,99100,916,1363,339,617,524,260,64600,54100,28100,6980,330,6.2,4,4,24.1,77777,9,999999999,160,0.2490,0,88,999.000,999.0,99.0
+1987,9,30,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,3.9,41,99100,964,1363,338,633,535,250,67100,55500,27700,7130,340,5.2,4,4,24.1,77777,9,999999999,129,0.2490,0,88,999.000,999.0,99.0
+1987,9,30,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,2.8,34,99100,942,1363,345,523,415,233,55700,43000,25900,6410,340,6.2,4,4,24.1,77777,9,999999999,129,0.2490,0,88,999.000,999.0,99.0
+1987,9,30,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,1.7,33,99100,854,1363,343,562,513,236,58800,52700,25700,5860,340,7.7,5,5,24.1,77777,9,999999999,120,0.2490,0,88,999.000,999.0,99.0
+1987,9,30,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,-0.6,28,99100,704,1363,340,444,484,191,46300,48700,21100,4140,340,8.8,5,5,24.1,77777,9,999999999,100,0.2490,0,88,999.000,999.0,99.0
+1987,9,30,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,1.1,37,99100,504,1363,330,234,233,147,24800,22500,16400,3050,320,5.7,4,4,24.1,77777,9,999999999,120,0.2490,0,88,999.000,999.0,99.0
+1987,9,30,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,0.0,34,99200,267,1363,326,102,116,79,11000,9000,9300,1700,330,5.2,3,3,24.1,77777,9,999999999,110,0.2490,0,88,999.000,999.0,99.0
+1987,9,30,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,0.6,40,99200,39,784,317,13,6,12,1400,300,1300,300,330,4.6,3,3,24.1,77777,9,999999999,110,0.2490,0,88,999.000,999.0,99.0
+1987,9,30,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,1.7,51,99200,0,0,296,0,0,0,0,0,0,0,350,3.1,0,0,24.1,77777,9,999999999,120,0.2490,0,88,999.000,999.0,99.0
+1987,9,30,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,2.8,64,99300,0,0,287,0,0,0,0,0,0,0,300,2.6,0,0,24.1,77777,9,999999999,129,0.2490,0,88,999.000,999.0,99.0
+1987,9,30,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,3.3,71,99300,0,0,283,0,0,0,0,0,0,0,300,2.1,0,0,24.1,77777,9,999999999,129,0.2490,0,88,999.000,999.0,99.0
+1987,9,30,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.0,4.3,77,99400,0,0,287,0,0,0,0,0,0,0,290,2.2,0,0,24.1,77777,9,999999999,129,0.2490,0,88,999.000,999.0,99.0
+1987,9,30,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.7,5.2,80,99300,0,0,291,0,0,0,0,0,0,0,0,2.2,0,0,24.1,77777,9,999999999,129,0.2490,0,88,999.000,999.0,99.0
+1987,9,30,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.4,6.2,80,99300,0,0,295,0,0,0,0,0,0,0,270,2.3,0,0,24.1,77777,9,999999999,129,0.2490,0,88,999.000,999.0,99.0
+1978,10,1,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.2,7.1,80,99400,0,0,345,0,0,0,0,0,0,0,300,2.4,10,10,24.1,880,9,999999999,200,0.2490,0,88,999.000,999.0,99.0
+1978,10,1,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.9,8.1,83,99300,0,0,350,0,0,0,0,0,0,0,290,2.5,10,10,24.1,880,9,999999999,200,0.2490,0,88,999.000,999.0,99.0
+1978,10,1,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.6,9.0,80,99300,0,0,354,0,0,0,0,0,0,0,300,2.5,10,10,24.1,1010,9,999999999,189,0.2490,0,88,999.000,999.0,99.0
+1978,10,1,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,10.0,80,99400,0,0,359,0,0,0,0,0,0,0,320,2.6,10,10,24.1,1010,9,999999999,189,0.2490,0,88,999.000,999.0,99.0
+1978,10,1,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,8.9,86,99500,0,0,316,0,0,0,0,0,0,0,290,2.6,4,4,24.1,77777,9,999999999,179,0.2490,0,88,999.000,999.0,99.0
+1978,10,1,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,8.3,89,99500,3,239,295,2,0,2,0,0,0,0,290,3.1,0,0,14.5,77777,9,999999999,179,0.2010,0,88,999.000,999.0,99.0
+1978,10,1,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,10.0,90,99600,165,1364,304,63,145,44,6500,8000,5500,820,290,2.1,0,0,19.3,77777,9,999999999,200,0.2010,0,88,999.000,999.0,99.0
+1978,10,1,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,10.0,75,99600,411,1364,316,223,436,88,23300,38700,11600,1630,320,3.6,0,0,24.1,77777,9,999999999,200,0.2010,0,88,999.000,999.0,99.0
+1978,10,1,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,9.4,65,99600,627,1364,323,402,596,122,41100,57700,14500,2460,350,3.1,0,0,24.1,77777,9,999999999,189,0.2010,0,88,999.000,999.0,99.0
+1978,10,1,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,8.3,58,99600,797,1364,324,556,687,147,57600,68700,17300,3390,360,2.6,0,0,24.1,77777,9,999999999,179,0.2010,0,88,999.000,999.0,99.0
+1978,10,1,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,8.9,54,99600,910,1364,346,621,696,151,65400,70700,18100,4010,30,3.6,3,3,24.1,77777,9,999999999,179,0.2010,0,88,999.000,999.0,99.0
+1978,10,1,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,7.8,47,99600,957,1364,350,688,674,208,71100,67700,23500,5680,100,3.1,3,3,24.1,77777,9,999999999,170,0.2010,0,88,999.000,999.0,99.0
+1978,10,1,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,8.3,49,99500,935,1364,351,647,607,225,68900,62900,25600,6110,50,3.1,4,3,24.1,77777,9,999999999,179,0.2010,0,88,999.000,999.0,99.0
+1978,10,1,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,7.8,47,99500,846,1364,350,510,484,206,54100,49800,23100,5000,0,0.0,4,3,24.1,77777,9,999999999,170,0.2010,0,88,999.000,999.0,99.0
+1978,10,1,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,8.3,49,99500,696,1364,347,429,523,159,45500,52600,18600,3360,100,5.7,4,2,24.1,77777,9,999999999,179,0.2010,0,88,999.000,999.0,99.0
+1978,10,1,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,8.3,54,99500,495,1364,335,276,453,109,29100,42500,13600,2070,70,4.6,3,1,24.1,77777,9,999999999,179,0.2010,0,88,999.000,999.0,99.0
+1978,10,1,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,7.8,56,99500,258,1364,330,107,225,64,11300,16400,8200,1200,110,3.6,1,1,24.1,77777,9,999999999,170,0.2010,0,88,999.000,999.0,99.0
+1978,10,1,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,7.8,62,99500,35,739,316,17,11,16,1800,600,1800,390,100,5.2,1,0,19.3,77777,9,999999999,170,0.2010,0,88,999.000,999.0,99.0
+1978,10,1,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,8.9,72,99500,0,0,312,0,0,0,0,0,0,0,110,4.1,0,0,24.1,77777,9,999999999,179,0.2010,0,88,999.000,999.0,99.0
+1978,10,1,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,8.9,80,99500,0,0,305,0,0,0,0,0,0,0,130,3.1,0,0,24.1,77777,9,999999999,179,0.2010,0,88,999.000,999.0,99.0
+1978,10,1,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,8.9,80,99500,0,0,305,0,0,0,0,0,0,0,150,2.1,0,0,24.1,77777,9,999999999,179,0.2010,0,88,999.000,999.0,99.0
+1978,10,1,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,8.9,86,99500,0,0,300,0,0,0,0,0,0,0,140,2.6,0,0,24.1,77777,9,999999999,179,0.2010,0,88,999.000,999.0,99.0
+1978,10,1,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,8.9,86,99500,0,0,300,0,0,0,0,0,0,0,150,3.1,0,0,24.1,77777,9,999999999,179,0.2010,0,88,999.000,999.0,99.0
+1978,10,1,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,8.9,93,99500,0,0,296,0,0,0,0,0,0,0,150,2.1,0,0,24.1,77777,9,999999999,179,0.2010,0,88,999.000,999.0,99.0
+1978,10,2,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,8.3,86,99500,0,0,298,0,0,0,0,0,0,0,160,2.1,0,0,11.3,77777,9,999999999,179,0.2010,0,88,999.000,999.0,99.0
+1978,10,2,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,7.8,89,99500,0,0,292,0,0,0,0,0,0,0,170,2.6,0,0,9.7,77777,9,999999999,170,0.2010,0,88,999.000,999.0,99.0
+1978,10,2,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,7.2,89,99400,0,0,290,0,0,0,0,0,0,0,160,2.6,0,0,11.3,77777,9,999999999,160,0.2010,0,88,999.000,999.0,99.0
+1978,10,2,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,7.2,89,99400,0,0,290,0,0,0,0,0,0,0,160,2.6,0,0,11.3,77777,9,999999999,160,0.2010,0,88,999.000,999.0,99.0
+1978,10,2,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,7.2,89,99400,0,0,290,0,0,0,0,0,0,0,160,3.1,0,0,9.7,77777,9,999999999,160,0.2010,0,88,999.000,999.0,99.0
+1978,10,2,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,7.8,89,99400,3,216,298,4,18,2,0,0,0,0,180,3.1,1,1,8.0,77777,9,999999999,170,0.0570,0,88,999.000,999.0,99.0
+1978,10,2,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,8.9,86,99500,161,1365,310,65,274,31,6500,16600,4500,550,180,3.6,3,2,8.0,77777,9,999999999,179,0.0570,0,88,999.000,999.0,99.0
+1978,10,2,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,11.1,81,99400,406,1365,327,247,570,73,25100,50200,10200,1360,200,5.2,3,2,9.7,77777,9,999999999,209,0.0570,0,88,999.000,999.0,99.0
+1978,10,2,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,11.7,70,99400,622,1365,344,348,522,105,36000,50800,12800,2160,190,4.1,5,3,14.5,77777,9,999999999,209,0.0570,0,88,999.000,999.0,99.0
+1978,10,2,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,11.7,61,99400,792,1365,351,433,465,158,46500,47600,18800,3570,190,7.2,6,2,19.3,77777,9,999999999,209,0.0570,0,88,999.000,999.0,99.0
+1978,10,2,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,11.7,57,99300,904,1365,357,633,783,108,66700,78800,14300,2790,170,6.2,3,2,24.1,77777,9,999999999,220,0.0570,0,88,999.000,999.0,99.0
+1978,10,2,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,11.7,51,99200,951,1365,369,545,556,152,57600,56700,18000,4280,160,6.7,3,3,24.1,77777,9,999999999,209,0.0570,0,88,999.000,999.0,99.0
+1978,10,2,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,11.1,48,99100,929,1365,362,659,849,74,68400,84700,10600,2050,180,7.2,3,1,24.1,77777,9,999999999,209,0.0570,0,88,999.000,999.0,99.0
+1978,10,2,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,10.6,48,99000,839,1365,364,582,726,130,61500,73500,16100,3200,160,5.7,7,2,24.1,77777,9,999999999,200,0.0570,0,88,999.000,999.0,99.0
+1978,10,2,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,10.0,48,98900,689,1365,373,292,229,174,31500,23800,19400,3820,170,5.2,10,6,24.1,7620,9,999999999,200,0.0570,0,88,999.000,999.0,99.0
+1978,10,2,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,9.4,49,98900,488,1365,396,120,10,116,13600,600,13400,4520,170,4.6,10,10,24.1,7620,9,999999999,189,0.0570,0,88,999.000,999.0,99.0
+1978,10,2,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,10.0,53,99100,251,1365,394,49,0,49,5600,0,5600,1800,210,4.1,10,10,16.1,7620,9,999999999,200,0.0570,0,88,999.000,999.0,99.0
+1978,10,2,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,12.8,78,99000,31,694,380,6,1,6,700,0,700,230,150,3.1,10,10,12.9,3050,9,999999999,229,0.0570,0,88,999.000,999.0,99.0
+1978,10,2,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,13.9,87,99000,0,0,378,0,0,0,0,0,0,0,240,2.1,10,10,12.9,3050,9,999999999,240,0.0570,0,88,999.000,999.0,99.0
+1978,10,2,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,13.9,87,98900,0,0,378,0,0,0,0,0,0,0,140,3.6,10,10,16.1,3050,9,999999999,240,0.0570,0,88,999.000,999.0,99.0
+1978,10,2,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,13.3,84,98800,0,0,377,0,0,0,0,0,0,0,160,3.6,10,10,16.1,1400,9,999999999,240,0.0570,0,88,999.000,999.0,99.0
+1978,10,2,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,13.3,87,98800,0,0,374,0,0,0,0,0,0,0,180,2.1,10,10,12.9,1010,9,999999999,240,0.0570,0,88,999.000,999.0,99.0
+1978,10,2,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,13.3,90,98900,0,0,371,0,0,0,0,0,0,0,190,4.1,10,10,9.7,1010,9,999999999,240,0.0570,0,88,999.000,999.0,99.0
+1978,10,2,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,13.3,90,98800,0,0,371,0,0,0,0,0,0,0,190,3.1,10,10,9.7,1010,9,999999999,240,0.0570,0,88,999.000,999.0,99.0
+1978,10,3,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,13.9,93,98700,0,0,372,0,0,0,0,0,0,0,180,3.1,10,10,6.4,700,9,999999999,240,0.0570,0,88,999.000,999.0,99.0
+1978,10,3,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,13.9,93,98700,0,0,372,0,0,0,0,0,0,0,210,3.1,10,10,6.4,210,9,999999999,240,0.0570,0,88,999.000,999.0,99.0
+1978,10,3,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,13.9,93,98600,0,0,372,0,0,0,0,0,0,0,190,3.1,10,10,4.0,210,9,999999999,240,0.0570,0,88,999.000,999.0,99.0
+1978,10,3,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,13.9,93,98500,0,0,372,0,0,0,0,0,0,0,190,3.1,10,10,4.0,370,9,999999999,240,0.0570,0,88,999.000,999.0,99.0
+1978,10,3,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,13.9,93,98500,0,0,372,0,0,0,0,0,0,0,210,3.1,10,10,3.2,270,9,999999999,240,0.0570,0,88,999.000,999.0,99.0
+1978,10,3,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,13.9,93,98500,2,193,372,0,0,0,0,0,0,0,220,3.6,10,10,4.0,370,9,999999999,240,0.0860,0,88,999.000,999.0,99.0
+1978,10,3,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,13.9,90,98600,156,1365,375,29,2,29,3300,0,3300,1030,250,4.1,10,10,4.0,400,9,999999999,240,0.0860,0,88,999.000,999.0,99.0
+1978,10,3,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,13.9,90,98600,401,1365,375,108,1,107,12000,100,12000,3860,260,3.6,10,10,4.0,240,9,999999999,240,0.0860,0,88,999.000,999.0,99.0
+1978,10,3,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,13.3,87,98600,617,1365,374,198,6,195,22200,500,22000,7330,230,4.1,10,10,4.0,240,9,999999999,240,0.0860,0,88,999.000,999.0,99.0
+1978,10,3,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,12.8,87,98600,787,1365,371,255,3,253,29000,300,28800,10130,250,4.6,10,10,4.0,210,9,999999999,229,0.0860,0,88,999.000,999.0,99.0
+1978,10,3,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,12.8,84,98600,898,1365,374,297,2,296,34000,200,33900,12210,240,5.2,10,10,4.0,210,9,999999999,229,0.0860,0,88,999.000,999.0,99.0
+1978,10,3,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,12.8,75,98500,945,1365,358,403,174,281,44300,18500,31500,8430,250,4.6,8,7,12.9,520,9,999999999,229,0.0860,0,88,999.000,999.0,99.0
+1978,10,3,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,10.0,59,98400,922,1365,360,510,340,278,55100,36500,30400,7630,240,6.2,8,7,19.3,700,9,999999999,189,0.0860,0,88,999.000,999.0,99.0
+1978,10,3,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,7.8,47,98400,833,1365,363,380,231,237,41000,24600,25900,5900,260,6.2,7,7,24.1,760,9,999999999,170,0.0860,0,88,999.000,999.0,99.0
+1978,10,3,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,6.7,47,98400,682,1365,349,394,402,191,40900,40200,20800,4090,260,6.7,5,5,24.1,77777,9,999999999,160,0.0860,0,88,999.000,999.0,99.0
+1978,10,3,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,5.6,46,98400,481,1365,343,194,189,127,20700,18000,14300,2560,240,7.2,5,5,24.1,77777,9,999999999,150,0.0860,0,88,999.000,999.0,99.0
+1978,10,3,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,5.6,50,98500,243,1365,337,90,90,73,9600,6700,8400,1560,260,5.7,5,5,24.1,77777,9,999999999,150,0.0860,0,88,999.000,999.0,99.0
+1978,10,3,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,5.6,55,98500,27,649,321,18,39,14,1700,1000,1700,240,250,5.2,2,2,24.1,77777,9,999999999,150,0.0860,0,88,999.000,999.0,99.0
+1978,10,3,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,6.1,62,98500,0,0,307,0,0,0,0,0,0,0,240,4.1,0,0,24.1,77777,9,999999999,150,0.0860,0,88,999.000,999.0,99.0
+1978,10,3,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,6.7,69,98500,0,0,303,0,0,0,0,0,0,0,250,4.6,0,0,24.1,77777,9,999999999,160,0.0860,0,88,999.000,999.0,99.0
+1978,10,3,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,6.7,77,98500,0,0,296,0,0,0,0,0,0,0,240,3.6,0,0,24.1,77777,9,999999999,160,0.0860,0,88,999.000,999.0,99.0
+1978,10,3,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,6.7,80,98500,0,0,294,0,0,0,0,0,0,0,230,3.6,0,0,24.1,77777,9,999999999,160,0.0860,0,88,999.000,999.0,99.0
+1978,10,3,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,7.2,83,98500,0,0,294,0,0,0,0,0,0,0,230,4.1,0,0,24.1,77777,9,999999999,160,0.0860,0,88,999.000,999.0,99.0
+1978,10,3,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,7.2,89,98500,0,0,302,0,0,0,0,0,0,0,230,3.6,3,3,24.1,77777,9,999999999,160,0.0860,0,88,999.000,999.0,99.0
+1978,10,4,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,7.2,86,98500,0,0,304,0,0,0,0,0,0,0,240,4.1,3,3,24.1,77777,9,999999999,160,0.0860,0,88,999.000,999.0,99.0
+1978,10,4,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,8.3,93,98500,0,0,313,0,0,0,0,0,0,0,240,4.1,7,6,24.1,2440,9,999999999,170,0.0860,0,88,999.000,999.0,99.0
+1978,10,4,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,7.8,89,98500,0,0,316,0,0,0,0,0,0,0,240,4.1,8,7,24.1,240,9,999999999,170,0.0860,0,88,999.000,999.0,99.0
+1978,10,4,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,8.3,89,98600,0,0,319,0,0,0,0,0,0,0,240,4.1,9,7,24.1,370,9,999999999,170,0.0860,0,88,999.000,999.0,99.0
+1978,10,4,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,7.8,93,98700,0,0,296,0,0,0,0,0,0,0,240,4.1,1,1,24.1,77777,9,999999999,170,0.0860,0,88,999.000,999.0,99.0
+1978,10,4,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,7.8,93,98700,2,148,300,0,1,0,0,0,0,0,250,3.6,2,2,16.1,77777,9,999999999,170,0.1160,0,88,999.000,999.0,99.0
+1978,10,4,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,8.3,89,98800,151,1366,315,52,82,42,5500,4800,5000,880,240,4.1,6,6,24.1,3050,9,999999999,170,0.1160,0,88,999.000,999.0,99.0
+1978,10,4,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,8.3,86,98900,397,1366,334,118,84,93,12900,7600,10700,2070,240,5.2,9,9,24.1,3050,9,999999999,179,0.1160,0,88,999.000,999.0,99.0
+1978,10,4,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,8.3,75,98900,612,1366,337,161,61,133,17700,5900,15000,4090,260,4.1,8,8,24.1,1010,9,999999999,179,0.1160,0,88,999.000,999.0,99.0
+1978,10,4,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,6.7,64,98900,781,1366,345,375,275,215,40400,29100,23700,5100,270,6.2,10,9,24.1,880,9,999999999,160,0.1160,0,88,999.000,999.0,99.0
+1978,10,4,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,6.7,60,98900,893,1366,360,183,8,178,21800,600,21400,8380,260,4.6,10,10,24.1,880,9,999999999,160,0.1160,0,88,999.000,999.0,99.0
+1978,10,4,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,6.7,62,98900,939,1366,358,214,1,214,25400,100,25300,9920,250,4.6,10,10,24.1,1010,9,999999999,160,0.1160,0,88,999.000,999.0,99.0
+1978,10,4,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,7.2,60,98900,916,1366,364,229,13,221,27000,1100,26300,10050,250,5.2,10,10,24.1,1010,9,999999999,160,0.1160,0,88,999.000,999.0,99.0
+1978,10,4,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,7.2,58,98900,826,1366,340,471,353,255,50500,37500,27700,6400,240,4.6,7,6,24.1,1010,9,999999999,160,0.1160,0,88,999.000,999.0,99.0
+1978,10,4,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,7.8,56,98800,675,1366,355,251,92,205,27500,9100,23000,6140,220,3.6,8,8,24.1,1010,9,999999999,170,0.1160,0,88,999.000,999.0,99.0
+1978,10,4,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,7.2,54,98800,474,1366,340,259,371,128,26600,34200,14700,2470,210,4.6,9,4,24.1,77777,9,999999999,160,0.1160,0,88,999.000,999.0,99.0
+1978,10,4,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,7.8,62,98800,236,1366,338,94,101,76,10100,7300,8800,1620,200,3.1,9,6,24.1,7620,9,999999999,170,0.1160,0,88,999.000,999.0,99.0
+1978,10,4,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,7.2,64,98800,24,626,341,15,3,15,0,0,0,0,180,3.1,10,8,24.1,3660,9,999999999,160,0.1160,0,88,999.000,999.0,99.0
+1978,10,4,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,7.8,67,98800,0,0,342,0,0,0,0,0,0,0,130,3.6,10,8,24.1,3660,9,999999999,170,0.1160,0,88,999.000,999.0,99.0
+1978,10,4,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,8.3,72,98800,0,0,347,0,0,0,0,0,0,0,220,1.5,10,9,19.3,3660,9,999999999,179,0.1160,0,88,999.000,999.0,99.0
+1978,10,4,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,7.8,72,98700,0,0,354,0,0,0,0,0,0,0,160,3.1,10,10,24.1,3660,9,999999999,170,0.1160,0,88,999.000,999.0,99.0
+1978,10,4,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,7.8,69,98700,0,0,356,0,0,0,0,0,0,0,150,4.1,10,10,24.1,3660,9,999999999,170,0.1160,0,88,999.000,999.0,99.0
+1978,10,4,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,7.8,69,98700,0,0,356,0,0,0,0,0,0,0,180,4.1,10,10,19.3,1370,9,999999999,170,0.1160,0,88,999.000,999.0,99.0
+1978,10,4,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,9.4,83,98700,0,0,353,0,0,0,0,0,0,0,190,3.6,10,10,11.3,1160,9,999999999,189,0.1160,0,88,999.000,999.0,99.0
+1978,10,5,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,10.6,83,98500,0,0,359,0,0,0,0,0,0,0,160,4.1,10,10,19.3,1160,9,999999999,200,0.1160,0,88,999.000,999.0,99.0
+1978,10,5,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,10.0,83,98400,0,0,356,0,0,0,0,0,0,0,180,4.6,10,10,19.3,1220,9,999999999,189,0.1160,0,88,999.000,999.0,99.0
+1978,10,5,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,10.0,83,98300,0,0,356,0,0,0,0,0,0,0,170,5.7,10,10,24.1,1160,9,999999999,189,0.1160,0,88,999.000,999.0,99.0
+1978,10,5,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,10.0,78,98200,0,0,362,0,0,0,0,0,0,0,180,7.2,10,10,24.1,1160,9,999999999,189,0.1160,0,88,999.000,999.0,99.0
+1978,10,5,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,11.1,78,98100,0,0,369,0,0,0,0,0,0,0,210,8.2,10,10,24.1,460,9,999999999,209,0.1160,0,88,999.000,999.0,99.0
+1978,10,5,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,11.1,81,98100,1,125,366,1,0,1,0,0,0,0,200,6.7,10,10,24.1,370,9,999999999,209,0.1700,0,88,999.000,999.0,99.0
+1978,10,5,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,11.1,81,98200,147,1367,333,48,18,46,5200,1200,5100,1040,240,4.6,4,4,19.3,77777,9,999999999,209,0.1700,0,88,999.000,999.0,99.0
+1978,10,5,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,10.0,72,98200,392,1367,332,152,170,102,16100,15100,11700,1990,250,5.7,3,3,24.1,77777,9,999999999,189,0.1700,0,88,999.000,999.0,99.0
+1978,10,5,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,8.3,62,98200,607,1367,319,396,635,108,40700,61400,13400,2180,250,5.2,0,0,24.1,77777,9,999999999,170,0.1700,0,88,999.000,999.0,99.0
+1978,10,5,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,6.7,56,98200,776,1367,324,523,680,130,54500,68100,15700,2980,240,7.7,1,1,24.1,77777,9,999999999,160,0.1700,0,88,999.000,999.0,99.0
+1978,10,5,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,6.7,58,98200,887,1367,331,596,608,195,61400,60800,21800,4810,250,7.2,4,4,24.1,77777,9,999999999,160,0.1700,0,88,999.000,999.0,99.0
+1978,10,5,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,6.7,58,98200,933,1367,353,319,122,235,35500,13000,26600,6960,230,9.3,9,9,24.1,880,9,999999999,160,0.1700,0,88,999.000,999.0,99.0
+1978,10,5,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,6.7,67,98200,910,1367,352,211,2,210,24900,200,24800,9630,230,9.8,10,10,24.1,700,9,999999999,160,0.1700,0,88,999.000,999.0,99.0
+1978,10,5,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,6.7,69,98200,819,1367,349,145,11,139,17400,800,17000,6590,240,7.2,10,10,19.3,640,9,999999999,160,0.1700,0,88,999.000,999.0,99.0
+1978,10,5,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,7.8,75,98200,668,1367,351,94,3,93,11400,200,11300,4320,240,6.2,10,10,19.3,760,9,999999999,170,0.1700,0,88,999.000,999.0,99.0
+1978,10,5,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,9.4,86,98300,466,1367,350,90,1,90,10500,100,10400,3650,250,5.2,10,10,24.1,760,9,999999999,189,0.1700,0,88,999.000,999.0,99.0
+1978,10,5,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,8.9,83,98300,228,1367,350,25,3,25,3000,0,3000,1000,260,4.6,10,10,24.1,760,9,999999999,179,0.1700,0,88,999.000,999.0,99.0
+1978,10,5,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,8.3,83,98300,21,581,346,9,0,9,0,0,0,0,250,7.2,10,10,24.1,640,9,999999999,170,0.1700,0,88,999.000,999.0,99.0
+1978,10,5,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,7.8,80,98400,0,0,345,0,0,0,0,0,0,0,260,7.2,10,10,24.1,490,9,999999999,170,0.1700,0,88,999.000,999.0,99.0
+1978,10,5,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,7.8,80,98400,0,0,345,0,0,0,0,0,0,0,270,7.7,10,10,24.1,700,9,999999999,170,0.1700,0,88,999.000,999.0,99.0
+1978,10,5,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,7.8,83,98500,0,0,343,0,0,0,0,0,0,0,270,5.7,10,10,12.9,700,9,999999999,170,0.1700,0,88,999.000,999.0,99.0
+1978,10,5,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,7.8,83,98500,0,0,343,0,0,0,0,0,0,0,280,9.3,10,10,19.3,580,9,999999999,170,0.1700,0,88,999.000,999.0,99.0
+1978,10,5,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,7.8,80,98600,0,0,345,0,0,0,0,0,0,0,280,8.2,10,10,19.3,520,9,999999999,170,0.1700,0,88,999.000,999.0,99.0
+1978,10,5,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,7.2,77,98600,0,0,345,0,0,0,0,0,0,0,290,7.7,10,10,24.1,580,9,999999999,160,0.1700,0,88,999.000,999.0,99.0
+1978,10,6,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,7.2,77,98600,0,0,345,0,0,0,0,0,0,0,290,6.2,10,10,24.1,490,9,999999999,160,0.1700,0,88,999.000,999.0,99.0
+1978,10,6,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,7.2,77,98700,0,0,345,0,0,0,0,0,0,0,280,7.7,10,10,24.1,700,9,999999999,160,0.1700,0,88,999.000,999.0,99.0
+1978,10,6,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,6.7,77,98600,0,0,332,0,0,0,0,0,0,0,270,6.7,9,9,24.1,640,9,999999999,160,0.1700,0,88,999.000,999.0,99.0
+1978,10,6,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,6.7,77,98700,0,0,342,0,0,0,0,0,0,0,280,7.2,10,10,24.1,760,9,999999999,160,0.1700,0,88,999.000,999.0,99.0
+1978,10,6,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,6.7,77,98700,0,0,342,0,0,0,0,0,0,0,280,8.2,10,10,24.1,640,9,999999999,160,0.1700,0,88,999.000,999.0,99.0
+1978,10,6,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,6.7,80,98800,1,103,339,2,0,2,0,0,0,0,300,5.2,10,10,24.1,370,9,999999999,160,0.0660,0,88,999.000,999.0,99.0
+1978,10,6,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,7.2,83,98800,142,1368,330,35,23,33,3900,1500,3700,800,290,7.2,10,9,24.1,400,9,999999999,160,0.0660,0,88,999.000,999.0,99.0
+1978,10,6,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,7.2,77,98900,387,1368,328,134,78,111,14600,7000,12600,2880,290,7.7,9,8,24.1,460,9,999999999,160,0.0660,0,88,999.000,999.0,99.0
+1978,10,6,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,6.7,67,98900,602,1368,324,413,642,125,42100,61400,15000,2450,300,7.2,6,5,24.1,700,9,999999999,160,0.0660,0,88,999.000,999.0,99.0
+1978,10,6,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,6.1,62,99000,770,1368,344,405,323,220,43400,34100,24200,5210,300,7.7,10,9,24.1,700,9,999999999,150,0.0660,0,88,999.000,999.0,99.0
+1978,10,6,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,4.4,57,99000,881,1368,350,259,2,258,29900,200,29800,11000,300,5.2,10,10,24.1,760,9,999999999,139,0.0660,0,88,999.000,999.0,99.0
+1978,10,6,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,3.9,57,99100,927,1368,346,267,11,259,31000,1000,30300,11350,300,5.2,10,10,24.1,760,9,999999999,129,0.0660,0,88,999.000,999.0,99.0
+1978,10,6,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,4.4,64,99100,903,1368,341,267,5,264,30900,400,30600,11340,280,6.7,10,10,24.1,760,9,999999999,139,0.0660,0,88,999.000,999.0,99.0
+1978,10,6,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,3.3,57,99100,813,1368,343,213,0,213,24700,0,24700,9180,300,6.7,10,10,24.1,1160,9,999999999,129,0.0660,0,88,999.000,999.0,99.0
+1978,10,6,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,3.3,61,99200,661,1368,338,174,8,170,19900,600,19600,6960,290,5.2,10,10,24.1,1160,9,999999999,129,0.0660,0,88,999.000,999.0,99.0
+1978,10,6,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,2.8,59,99200,459,1368,337,137,5,136,15400,300,15300,4860,280,6.7,10,10,24.1,1160,9,999999999,129,0.0660,0,88,999.000,999.0,99.0
+1978,10,6,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,2.8,59,99300,221,1368,337,53,0,53,5900,0,5900,1810,290,5.7,10,10,24.1,1370,9,999999999,129,0.0660,0,88,999.000,999.0,99.0
+1978,10,6,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,3.3,64,99300,18,536,335,8,0,8,0,0,0,0,270,4.6,10,10,24.1,1370,9,999999999,129,0.0660,0,88,999.000,999.0,99.0
+1978,10,6,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,2.8,61,99300,0,0,334,0,0,0,0,0,0,0,290,5.2,10,10,24.1,1160,9,999999999,129,0.0660,0,88,999.000,999.0,99.0
+1978,10,6,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,2.8,61,99400,0,0,334,0,0,0,0,0,0,0,270,4.1,10,10,24.1,880,9,999999999,129,0.0660,0,88,999.000,999.0,99.0
+1978,10,6,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,1.1,56,99400,0,0,329,0,0,0,0,0,0,0,290,4.6,10,10,24.1,1010,9,999999999,110,0.0660,0,88,999.000,999.0,99.0
+1978,10,6,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,1.7,61,99400,0,0,328,0,0,0,0,0,0,0,290,4.1,10,10,24.1,1160,9,999999999,120,0.0660,0,88,999.000,999.0,99.0
+1978,10,6,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,1.7,68,99400,0,0,289,0,0,0,0,0,0,0,290,5.2,3,3,24.1,77777,9,999999999,120,0.0660,0,88,999.000,999.0,99.0
+1978,10,6,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,1.7,73,99400,0,0,273,0,0,0,0,0,0,0,290,4.1,0,0,24.1,77777,9,999999999,120,0.0660,0,88,999.000,999.0,99.0
+1978,10,7,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,2.2,79,99400,0,0,271,0,0,0,0,0,0,0,270,4.1,0,0,24.1,77777,9,999999999,120,0.0660,0,88,999.000,999.0,99.0
+1978,10,7,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,2.2,82,99400,0,0,269,0,0,0,0,0,0,0,270,3.1,1,0,24.1,77777,9,999999999,120,0.0660,0,88,999.000,999.0,99.0
+1978,10,7,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,2.8,76,99400,0,0,304,0,0,0,0,0,0,0,280,5.2,8,8,24.1,3660,9,999999999,129,0.0660,0,88,999.000,999.0,99.0
+1978,10,7,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,2.8,79,99400,0,0,296,0,0,0,0,0,0,0,290,4.1,7,7,24.1,3660,9,999999999,129,0.0660,0,88,999.000,999.0,99.0
+1978,10,7,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,2.8,83,99400,0,0,281,0,0,0,0,0,0,0,300,4.1,2,2,24.1,77777,9,999999999,129,0.0660,0,88,999.000,999.0,99.0
+1978,10,7,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,2.2,86,99500,0,80,276,0,1,0,0,0,0,0,290,3.1,3,2,24.1,77777,9,999999999,120,0.1120,0,88,999.000,999.0,99.0
+1978,10,7,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,3.3,83,99500,137,1369,286,52,178,33,5300,9200,4400,590,290,4.1,3,3,24.1,77777,9,999999999,129,0.1120,0,88,999.000,999.0,99.0
+1978,10,7,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,4.4,77,99500,382,1369,297,204,423,83,21300,36500,11000,1520,330,6.2,3,3,24.1,77777,9,999999999,139,0.1120,0,88,999.000,999.0,99.0
+1978,10,7,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,3.9,69,99600,596,1369,312,320,294,189,33700,29600,20700,4140,310,5.2,7,7,24.1,1680,9,999999999,139,0.1120,0,88,999.000,999.0,99.0
+1978,10,7,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,3.9,61,99600,765,1369,324,289,52,259,31600,5300,28700,7980,340,5.2,8,8,24.1,1680,9,999999999,129,0.1120,0,88,999.000,999.0,99.0
+1978,10,7,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,2.2,51,99600,876,1369,335,325,88,268,35700,8900,30000,9060,290,6.7,9,9,24.1,880,9,999999999,120,0.1120,0,88,999.000,999.0,99.0
+1978,10,7,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,1.7,53,99700,920,1369,329,315,82,259,34700,8300,29000,9170,320,5.7,10,9,24.1,1010,9,999999999,120,0.1120,0,88,999.000,999.0,99.0
+1978,10,7,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,1.7,53,99600,897,1369,338,274,5,270,31500,400,31200,11460,330,7.7,10,10,24.1,1160,9,999999999,120,0.1120,0,88,999.000,999.0,99.0
+1978,10,7,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,1.1,54,99700,806,1369,332,244,8,239,27900,700,27500,9890,320,6.2,10,10,24.1,1160,9,999999999,110,0.1120,0,88,999.000,999.0,99.0
+1978,10,7,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,0.6,52,99700,654,1369,332,138,1,137,16000,100,16000,5890,320,6.2,10,10,24.1,1400,9,999999999,110,0.1120,0,88,999.000,999.0,99.0
+1978,10,7,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,1.1,54,99700,452,1369,332,120,4,119,13600,300,13500,4410,310,5.7,10,10,24.1,1400,9,999999999,110,0.1120,0,88,999.000,999.0,99.0
+1978,10,7,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,0.6,56,99700,214,1369,318,43,17,40,4700,1300,4500,1040,300,4.1,9,9,24.1,1370,9,999999999,110,0.1120,0,88,999.000,999.0,99.0
+1978,10,7,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,1.1,61,99700,16,513,324,5,0,5,0,0,0,0,330,3.6,10,10,24.1,1370,9,999999999,120,0.1120,0,88,999.000,999.0,99.0
+1978,10,7,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,2.2,68,99800,0,0,323,0,0,0,0,0,0,0,300,2.6,10,10,24.1,1370,9,999999999,120,0.1120,0,88,999.000,999.0,99.0
+1978,10,7,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,0.6,63,99800,0,0,319,0,0,0,0,0,0,0,340,4.1,10,10,24.1,1370,9,999999999,110,0.1120,0,88,999.000,999.0,99.0
+1978,10,7,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,0.6,71,99800,0,0,284,0,0,0,0,0,0,0,360,3.1,4,4,24.1,77777,9,999999999,110,0.1120,0,88,999.000,999.0,99.0
+1978,10,7,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-1.1,76,99900,0,0,271,0,0,0,0,0,0,0,310,2.6,4,4,24.1,77777,9,999999999,100,0.1120,0,88,999.000,999.0,99.0
+1978,10,7,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,0.6,85,99900,0,0,277,0,0,0,0,0,0,0,290,2.6,6,6,24.1,1400,9,999999999,110,0.1120,0,88,999.000,999.0,99.0
+1978,10,7,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,0.0,85,99900,0,0,256,0,0,0,0,0,0,0,280,3.1,0,0,24.1,77777,9,999999999,110,0.1120,0,88,999.000,999.0,99.0
+1978,10,8,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-0.6,85,99900,0,0,254,0,0,0,0,0,0,0,270,2.6,0,0,24.1,77777,9,999999999,100,0.1120,0,88,999.000,999.0,99.0
+1978,10,8,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.1,85,99900,0,0,251,0,0,0,0,0,0,0,260,2.6,0,0,24.1,77777,9,999999999,100,0.1120,0,88,999.000,999.0,99.0
+1978,10,8,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-0.6,89,99900,0,0,252,0,0,0,0,0,0,0,270,2.6,0,0,24.1,77777,9,999999999,100,0.1120,0,88,999.000,999.0,99.0
+1978,10,8,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.7,82,100000,0,0,251,0,0,0,0,0,0,0,270,2.6,0,0,24.1,77777,9,999999999,100,0.1120,0,88,999.000,999.0,99.0
+1978,10,8,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-1.7,85,100000,0,0,249,0,0,0,0,0,0,0,270,3.1,0,0,24.1,77777,9,999999999,100,0.1120,0,88,999.000,999.0,99.0
+1978,10,8,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-2.2,85,100100,0,57,251,1,3,0,0,0,0,0,250,2.6,1,1,24.1,77777,9,999999999,89,0.0760,0,88,999.000,999.0,99.0
+1978,10,8,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,0.0,89,100100,132,1369,255,57,284,28,5600,15600,4100,490,260,2.1,1,0,24.1,77777,9,999999999,110,0.0760,0,88,999.000,999.0,99.0
+1978,10,8,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,1.7,71,100100,377,1369,275,231,633,51,23200,55200,8000,1000,270,3.6,1,0,24.1,77777,9,999999999,120,0.0760,0,88,999.000,999.0,99.0
+1978,10,8,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,1.7,59,100200,591,1369,286,411,778,68,42700,75100,10200,1460,250,3.6,0,0,24.1,77777,9,999999999,120,0.0760,0,88,999.000,999.0,99.0
+1978,10,8,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,0.0,48,100100,759,1369,299,528,768,95,54900,76100,12500,2120,230,4.1,2,2,24.1,77777,9,999999999,110,0.0760,0,88,999.000,999.0,99.0
+1978,10,8,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,0.6,45,100100,870,1369,306,636,794,124,65500,79000,15100,2880,290,4.1,2,2,24.1,77777,9,999999999,110,0.0760,0,88,999.000,999.0,99.0
+1978,10,8,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,0.6,43,100000,914,1369,299,697,893,93,71800,88800,12300,2210,220,3.1,0,0,24.1,77777,9,999999999,110,0.0760,0,88,999.000,999.0,99.0
+1978,10,8,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,1.1,45,99900,890,1369,299,673,879,94,69300,87300,12400,2140,190,1.5,1,0,24.1,77777,9,999999999,110,0.0760,0,88,999.000,999.0,99.0
+1978,10,8,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,0.6,39,99900,799,1369,316,581,758,132,60800,76200,16200,3090,200,1.5,7,2,24.1,77777,9,999999999,110,0.0760,0,88,999.000,999.0,99.0
+1978,10,8,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,0.6,40,99900,647,1369,317,370,473,143,39200,47000,16900,2920,190,3.1,9,3,24.1,77777,9,999999999,110,0.0760,0,88,999.000,999.0,99.0
+1978,10,8,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,1.1,44,99800,445,1369,315,231,407,97,24300,37000,12200,1810,190,2.1,9,3,24.1,77777,9,999999999,120,0.0760,0,88,999.000,999.0,99.0
+1978,10,8,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,1.1,47,99800,207,1369,312,85,205,53,8700,13300,6600,970,200,2.6,9,4,24.1,77777,9,999999999,120,0.0760,0,88,999.000,999.0,99.0
+1978,10,8,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,0.6,54,99800,14,468,297,11,15,9,0,0,0,0,180,2.6,8,3,24.1,77777,9,999999999,110,0.0760,0,88,999.000,999.0,99.0
+1978,10,8,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,1.1,61,99800,0,0,286,0,0,0,0,0,0,0,170,3.6,3,1,24.1,77777,9,999999999,120,0.0760,0,88,999.000,999.0,99.0
+1978,10,8,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,1.1,68,99800,0,0,280,0,0,0,0,0,0,0,180,3.6,3,1,24.1,77777,9,999999999,120,0.0760,0,88,999.000,999.0,99.0
+1978,10,8,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,1.1,68,99700,0,0,275,0,0,0,0,0,0,0,170,3.1,0,0,24.1,77777,9,999999999,120,0.0760,0,88,999.000,999.0,99.0
+1978,10,8,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,1.1,76,99700,0,0,268,0,0,0,0,0,0,0,170,3.1,0,0,24.1,77777,9,999999999,110,0.0760,0,88,999.000,999.0,99.0
+1978,10,8,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,1.1,76,99700,0,0,268,0,0,0,0,0,0,0,160,3.1,0,0,24.1,77777,9,999999999,110,0.0760,0,88,999.000,999.0,99.0
+1978,10,8,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,1.1,76,99700,0,0,287,0,0,0,0,0,0,0,160,2.6,6,6,24.1,3050,9,999999999,110,0.0760,0,88,999.000,999.0,99.0
+1978,10,9,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,2.2,76,99700,0,0,300,0,0,0,0,0,0,0,160,3.1,8,8,24.1,3050,9,999999999,120,0.0760,0,88,999.000,999.0,99.0
+1978,10,9,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,2.2,71,99700,0,0,312,0,0,0,0,0,0,0,160,3.6,9,9,24.1,2440,9,999999999,120,0.0760,0,88,999.000,999.0,99.0
+1978,10,9,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,2.8,68,99700,0,0,317,0,0,0,0,0,0,0,160,3.1,9,9,24.1,1830,9,999999999,129,0.0760,0,88,999.000,999.0,99.0
+1978,10,9,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,3.3,68,99600,0,0,330,0,0,0,0,0,0,0,180,4.1,10,10,24.1,1830,9,999999999,129,0.0760,0,88,999.000,999.0,99.0
+1978,10,9,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,3.9,69,99600,0,0,333,0,0,0,0,0,0,0,160,5.2,10,10,24.1,1680,9,999999999,139,0.0760,0,88,999.000,999.0,99.0
+1978,10,9,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,3.3,64,99500,0,34,335,0,0,0,0,0,0,0,170,4.1,10,10,24.1,2440,9,999999999,129,0.0760,0,88,999.000,999.0,99.0
+1978,10,9,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,3.3,64,99500,128,1370,310,52,84,44,5600,4400,5100,920,190,5.2,6,6,24.1,2440,9,999999999,129,0.0760,0,88,999.000,999.0,99.0
+1978,10,9,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,4.4,62,99500,371,1370,319,152,44,139,16500,4000,15400,3330,180,6.2,6,6,24.1,3050,9,999999999,139,0.0760,0,88,999.000,999.0,99.0
+1978,10,9,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,5.6,57,99500,586,1370,325,309,489,95,31900,47100,11700,1920,180,5.2,4,4,24.1,77777,9,999999999,150,0.0760,0,88,999.000,999.0,99.0
+1978,10,9,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,7.2,58,99400,754,1370,329,532,735,121,55600,73500,15100,2730,190,6.7,2,2,24.1,77777,9,999999999,170,0.0760,0,88,999.000,999.0,99.0
+1978,10,9,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,8.3,54,99400,864,1370,340,596,724,132,62800,73500,16300,3330,190,7.7,3,2,24.1,77777,9,999999999,179,0.0760,0,88,999.000,999.0,99.0
+1978,10,9,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,9.4,49,99400,908,1370,361,454,334,230,49600,35900,25700,6030,190,8.2,4,4,24.1,77777,9,999999999,189,0.0760,0,88,999.000,999.0,99.0
+1978,10,9,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,10.0,49,99300,884,1370,358,607,703,147,63800,71200,17700,3750,190,7.7,2,2,24.1,77777,9,999999999,189,0.0760,0,88,999.000,999.0,99.0
+1978,10,9,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,10.0,46,99300,792,1370,363,536,621,172,55100,61500,19400,3830,210,9.8,9,2,24.1,77777,9,999999999,189,0.0760,0,88,999.000,999.0,99.0
+1978,10,9,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,10.0,44,99300,640,1370,370,386,465,166,40300,46000,18700,3430,190,9.3,9,3,24.1,77777,9,999999999,189,0.0760,0,88,999.000,999.0,99.0
+1978,10,9,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,10.0,44,99300,437,1370,370,197,258,113,20900,23800,13200,2230,210,6.7,8,3,24.1,77777,9,999999999,189,0.0760,0,88,999.000,999.0,99.0
+1978,10,9,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,9.4,47,99300,199,1370,360,85,217,53,8700,13800,6700,970,200,5.2,9,3,24.1,77777,9,999999999,189,0.0760,0,88,999.000,999.0,99.0
+1978,10,9,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.9,8.9,52,99300,11,422,346,9,14,8,0,0,0,0,190,4.1,6,2,24.1,77777,9,999999999,179,0.0760,0,88,999.000,999.0,99.0
+1978,10,9,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,8.9,56,99300,0,0,336,0,0,0,0,0,0,0,180,6.2,4,1,24.1,77777,9,999999999,179,0.0760,0,88,999.000,999.0,99.0
+1978,10,9,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,8.3,56,99400,0,0,333,0,0,0,0,0,0,0,190,5.7,4,1,24.1,77777,9,999999999,179,0.0760,0,88,999.000,999.0,99.0
+1978,10,9,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,8.3,58,99500,0,0,330,0,0,0,0,0,0,0,200,4.6,3,1,24.1,77777,9,999999999,179,0.0760,0,88,999.000,999.0,99.0
+1978,10,9,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,8.3,60,99500,0,0,328,0,0,0,0,0,0,0,190,5.2,3,1,24.1,77777,9,999999999,179,0.0760,0,88,999.000,999.0,99.0
+1978,10,9,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,8.3,67,99500,0,0,320,0,0,0,0,0,0,0,170,3.6,3,1,24.1,77777,9,999999999,179,0.0760,0,88,999.000,999.0,99.0
+1978,10,9,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,7.8,67,99500,0,0,311,0,0,0,0,0,0,0,180,4.1,0,0,24.1,77777,9,999999999,170,0.0760,0,88,999.000,999.0,99.0
+1978,10,10,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,7.8,69,99500,0,0,330,0,0,0,0,0,0,0,170,5.2,6,6,24.1,3050,9,999999999,170,0.0760,0,88,999.000,999.0,99.0
+1978,10,10,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,8.3,69,99500,0,0,342,0,0,0,0,0,0,0,190,4.1,8,8,24.1,1400,9,999999999,179,0.0760,0,88,999.000,999.0,99.0
+1978,10,10,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,8.9,67,99500,0,0,366,0,0,0,0,0,0,0,190,5.2,10,10,24.1,1400,9,999999999,179,0.0760,0,88,999.000,999.0,99.0
+1978,10,10,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,10.0,75,99500,0,0,364,0,0,0,0,0,0,0,180,4.6,10,10,24.1,1680,9,999999999,189,0.0760,0,88,999.000,999.0,99.0
+1978,10,10,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,10.0,75,99500,0,0,364,0,0,0,0,0,0,0,180,4.6,10,10,24.1,1680,9,999999999,189,0.0760,0,88,999.000,999.0,99.0
+1978,10,10,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,8.9,77,99500,0,11,355,0,0,0,0,0,0,0,160,5.7,10,10,24.1,1680,9,999999999,179,0.0760,0,88,999.000,999.0,99.0
+1978,10,10,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,8.3,72,99500,123,1371,357,20,2,20,2300,0,2300,720,180,4.6,10,10,16.1,2440,9,999999999,179,0.0990,0,88,999.000,999.0,99.0
+1978,10,10,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,8.3,67,99500,366,1371,362,97,6,95,10800,300,10800,3400,180,6.2,10,10,16.1,2440,9,999999999,179,0.0990,0,88,999.000,999.0,99.0
+1978,10,10,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,9.4,65,99500,581,1371,372,135,9,131,15500,600,15300,5370,190,5.7,10,10,16.1,3050,9,999999999,189,0.0990,0,88,999.000,999.0,99.0
+1978,10,10,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,10.0,65,99500,748,1371,376,205,7,202,23700,600,23300,8420,190,4.1,10,10,16.1,3050,9,999999999,200,0.0990,0,88,999.000,999.0,99.0
+1978,10,10,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,10.6,70,99500,858,1371,374,243,2,242,28100,200,28000,10350,210,6.2,10,10,16.1,3050,9,999999999,200,0.0990,0,88,999.000,999.0,99.0
+1978,10,10,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,10.6,70,99500,902,1371,374,277,3,275,31900,300,31700,11630,200,5.7,10,10,16.1,880,9,999999999,200,0.0990,0,88,999.000,999.0,99.0
+1978,10,10,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,10.6,72,99400,877,1371,371,257,5,254,29700,400,29400,10840,190,6.2,10,10,16.1,700,9,999999999,200,0.0990,0,88,999.000,999.0,99.0
+1978,10,10,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,11.1,75,99400,785,1371,372,274,4,272,31000,400,30800,10550,210,4.1,10,10,16.1,3050,9,999999999,209,0.0990,0,88,999.000,999.0,99.0
+1978,10,10,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,10.0,67,99400,633,1371,373,190,2,189,21500,200,21400,7280,190,5.2,10,10,16.1,3050,9,999999999,189,0.0990,0,88,999.000,999.0,99.0
+1978,10,10,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,9.4,67,99300,430,1371,342,221,319,119,23300,29300,14100,2380,180,4.1,6,6,16.1,7620,9,999999999,189,0.0990,0,88,999.000,999.0,99.0
+1978,10,10,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,9.4,67,99300,192,1371,360,37,23,33,4000,1600,3800,860,170,3.1,9,9,16.1,1220,9,999999999,189,0.0990,0,88,999.000,999.0,99.0
+1978,10,10,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,7.8,60,99200,9,400,368,2,0,2,0,0,0,0,170,4.1,10,10,16.1,1160,9,999999999,170,0.0990,0,88,999.000,999.0,99.0
+1978,10,10,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,7.2,56,99200,0,0,370,0,0,0,0,0,0,0,160,5.7,10,10,16.1,880,9,999999999,170,0.0990,0,88,999.000,999.0,99.0
+1978,10,10,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,7.2,56,99200,0,0,370,0,0,0,0,0,0,0,180,6.2,10,10,16.1,880,9,999999999,170,0.0990,0,88,999.000,999.0,99.0
+1978,10,10,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,7.8,60,99200,0,0,368,0,0,0,0,0,0,0,180,6.2,10,10,19.3,1010,9,999999999,170,0.0990,0,88,999.000,999.0,99.0
+1978,10,10,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,8.3,67,99200,0,0,352,0,0,0,0,0,0,0,190,4.1,10,9,19.3,2440,9,999999999,179,0.0990,0,88,999.000,999.0,99.0
+1978,10,10,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,8.3,67,99100,0,0,362,0,0,0,0,0,0,0,170,4.1,10,10,19.3,1010,9,999999999,179,0.0990,0,88,999.000,999.0,99.0
+1978,10,10,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,8.3,67,99100,0,0,362,0,0,0,0,0,0,0,190,5.7,10,10,19.3,1680,9,999999999,179,0.0990,0,88,999.000,999.0,99.0
+1978,10,11,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,8.3,69,99000,0,0,360,0,0,0,0,0,0,0,160,5.7,10,10,19.3,1830,9,999999999,170,0.0990,0,88,999.000,999.0,99.0
+1978,10,11,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,10.0,86,99000,0,0,353,0,0,0,0,0,0,0,160,4.1,10,10,11.3,1680,9,999999999,189,0.0990,0,88,999.000,999.0,99.0
+1978,10,11,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,10.6,90,98900,0,0,354,0,0,0,0,0,0,0,140,3.6,10,10,8.0,1680,9,999999999,200,0.0990,0,88,999.000,999.0,99.0
+1978,10,11,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,9.4,90,98900,0,0,322,0,0,0,0,0,0,0,150,3.1,6,6,9.7,1680,9,999999999,189,0.0990,0,88,999.000,999.0,99.0
+1978,10,11,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,10.0,83,98800,0,0,356,0,0,0,0,0,0,0,160,3.6,10,10,8.0,1010,9,999999999,189,0.0990,0,88,999.000,999.0,99.0
+1978,10,11,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,10.0,80,98800,0,0,359,0,0,0,0,0,0,0,160,4.1,10,10,8.0,1010,9,999999999,189,0.0990,0,88,999.000,999.0,99.0
+1978,10,11,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,10.0,80,98800,118,1360,359,33,2,33,3700,0,3700,1060,170,5.2,10,10,8.0,760,9,999999999,189,0.1210,0,88,999.000,999.0,99.0
+1978,10,11,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,10.6,80,98700,361,1372,363,79,3,78,9000,100,8900,2930,170,5.2,10,10,8.0,880,9,999999999,200,0.1210,0,88,999.000,999.0,99.0
+1978,10,11,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,11.1,75,98700,575,1372,339,323,373,163,34200,37300,18500,3450,180,5.2,4,4,9.7,77777,9,999999999,209,0.1210,0,88,999.000,999.0,99.0
+1978,10,11,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,11.1,70,98600,743,1372,347,475,533,181,49900,54000,20600,3980,170,5.7,5,5,9.7,77777,9,999999999,209,0.1210,0,88,999.000,999.0,99.0
+1978,10,11,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,10.6,72,98600,852,1372,371,225,11,218,26100,900,25600,9560,200,4.1,10,10,9.7,460,9,999999999,200,0.1210,0,88,999.000,999.0,99.0
+1978,10,11,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,11.1,75,98500,896,1372,372,251,2,250,29100,200,29000,10850,230,4.1,10,10,9.7,580,9,999999999,209,0.1210,0,88,999.000,999.0,99.0
+1978,10,11,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,11.7,75,98300,871,1372,375,264,3,261,30200,300,30100,10990,190,5.2,10,10,9.7,700,9,999999999,209,0.1210,0,88,999.000,999.0,99.0
+1978,10,11,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,12.2,75,98300,779,1372,379,213,2,212,24500,200,24400,8910,190,4.6,10,10,9.7,760,9,999999999,220,0.1210,0,88,999.000,999.0,99.0
+1978,10,11,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,11.7,73,98200,626,1372,378,181,0,181,20500,0,20500,7030,200,6.2,10,10,9.7,760,9,999999999,209,0.1210,0,88,999.000,999.0,99.0
+1978,10,11,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,11.7,73,98200,423,1372,360,156,107,122,16900,9800,13800,2740,190,5.2,10,8,9.7,1520,9,999999999,209,0.1210,0,88,999.000,999.0,99.0
+1978,10,11,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,10.6,70,98100,185,1372,350,61,52,54,6600,3400,6200,1140,200,6.2,8,7,9.7,3050,9,999999999,200,0.1210,0,88,999.000,999.0,99.0
+1978,10,11,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,10.6,72,98100,8,354,371,4,0,4,0,0,0,0,220,5.2,10,10,9.7,640,9,999999999,200,0.1210,0,88,999.000,999.0,99.0
+1978,10,11,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,11.1,78,98100,0,0,369,0,0,0,0,0,0,0,200,5.2,10,10,9.7,700,9,999999999,209,0.1210,0,88,999.000,999.0,99.0
+1978,10,11,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,11.1,78,98100,0,0,369,0,0,0,0,0,0,0,200,5.7,10,10,9.7,3050,9,999999999,209,0.1210,0,88,999.000,999.0,99.0
+1978,10,11,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,11.1,78,98100,0,0,369,0,0,0,0,0,0,0,200,5.2,10,10,9.7,3050,9,999999999,209,0.1210,0,88,999.000,999.0,99.0
+1978,10,11,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,11.1,83,98100,0,0,333,0,0,0,0,0,0,0,210,6.2,6,5,9.7,3050,9,999999999,200,0.1210,0,88,999.000,999.0,99.0
+1978,10,11,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,11.1,83,98100,0,0,331,0,0,0,0,0,0,0,210,8.2,4,4,8.0,77777,9,999999999,200,0.1210,0,88,999.000,999.0,99.0
+1978,10,11,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,11.7,84,98100,0,0,366,0,0,0,0,0,0,0,220,6.7,10,10,8.0,3050,9,999999999,209,0.1210,0,88,999.000,999.0,99.0
+1978,10,12,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,11.7,84,98200,0,0,349,0,0,0,0,0,0,0,220,5.2,8,8,8.0,3050,9,999999999,209,0.1210,0,88,999.000,999.0,99.0
+1978,10,12,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,11.7,87,98200,0,0,346,0,0,0,0,0,0,0,240,5.2,8,8,8.0,3050,9,999999999,209,0.1210,0,88,999.000,999.0,99.0
+1978,10,12,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,10.6,83,98200,0,0,325,0,0,0,0,0,0,0,240,4.1,3,3,8.0,77777,9,999999999,200,0.1210,0,88,999.000,999.0,99.0
+1978,10,12,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,9.4,93,98300,0,0,299,0,0,0,0,0,0,0,240,3.6,0,0,11.3,77777,9,999999999,189,0.1210,0,88,999.000,999.0,99.0
+1978,10,12,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,8.3,93,98300,0,0,293,0,0,0,0,0,0,0,250,2.6,0,0,11.3,77777,9,999999999,170,0.1210,0,88,999.000,999.0,99.0
+1978,10,12,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,8.3,89,98400,0,0,315,0,0,0,0,0,0,0,250,3.1,7,6,11.3,2740,9,999999999,170,0.1210,0,88,999.000,999.0,99.0
+1978,10,12,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,8.3,86,98500,114,1338,327,36,9,35,3900,0,3900,1090,270,2.6,9,8,11.3,2740,9,999999999,170,0.0820,0,88,999.000,999.0,99.0
+1978,10,12,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,9.4,86,98600,356,1373,333,147,96,121,15700,8300,13500,2660,230,3.1,9,8,11.3,2740,9,999999999,189,0.0820,0,88,999.000,999.0,99.0
+1978,10,12,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,7.8,65,98700,570,1373,344,261,137,203,28000,13500,22400,4800,260,3.1,9,8,11.3,2740,9,999999999,170,0.0820,0,88,999.000,999.0,99.0
+1978,10,12,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,5.6,52,98800,737,1373,355,277,59,245,30400,5900,27200,7440,260,4.6,10,9,11.3,2740,9,999999999,150,0.0820,0,88,999.000,999.0,99.0
+1978,10,12,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,4.4,45,98800,846,1373,351,447,255,287,47500,27100,30700,7450,290,5.7,10,8,19.3,2740,9,999999999,139,0.0820,0,88,999.000,999.0,99.0
+1978,10,12,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,3.3,41,98800,889,1373,345,451,260,280,48400,27800,30300,7450,280,6.2,9,7,24.1,2740,9,999999999,129,0.0820,0,88,999.000,999.0,99.0
+1978,10,12,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,4.4,50,98800,864,1373,360,300,12,293,34200,1100,33500,11780,270,4.6,10,10,24.1,2740,9,999999999,139,0.0820,0,88,999.000,999.0,99.0
+1978,10,12,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,7.8,72,98800,772,1373,354,109,6,106,13300,400,13000,5100,230,3.1,10,10,24.1,1400,9,999999999,170,0.0820,0,88,999.000,999.0,99.0
+1978,10,12,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,7.8,72,98800,619,1373,354,134,3,133,15600,200,15500,5600,230,3.1,10,10,24.1,1400,9,999999999,170,0.0820,0,88,999.000,999.0,99.0
+1978,10,12,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,7.8,69,98900,416,1373,356,60,7,57,7000,300,6900,2400,220,3.1,10,10,24.1,2740,9,999999999,170,0.0820,0,88,999.000,999.0,99.0
+1978,10,12,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,7.8,77,98900,178,1373,348,20,3,20,2400,0,2400,780,240,3.1,10,10,19.3,2440,9,999999999,170,0.0820,0,88,999.000,999.0,99.0
+1978,10,12,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,7.2,74,99000,6,309,348,3,0,3,0,0,0,0,240,3.1,10,10,19.3,2440,9,999999999,160,0.0820,0,88,999.000,999.0,99.0
+1978,10,12,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,7.2,77,99000,0,0,345,0,0,0,0,0,0,0,210,2.6,10,10,19.3,2130,9,999999999,160,0.0820,0,88,999.000,999.0,99.0
+1978,10,12,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,7.2,74,99100,0,0,348,0,0,0,0,0,0,0,240,3.1,10,10,19.3,1400,9,999999999,160,0.0820,0,88,999.000,999.0,99.0
+1978,10,12,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,7.8,80,99100,0,0,345,0,0,0,0,0,0,0,260,3.1,10,10,24.1,1400,9,999999999,170,0.0820,0,88,999.000,999.0,99.0
+1978,10,12,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,7.8,86,99100,0,0,315,0,0,0,0,0,0,0,250,2.1,7,6,24.1,2440,9,999999999,170,0.0820,0,88,999.000,999.0,99.0
+1978,10,12,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,6.1,86,99200,0,0,298,0,0,0,0,0,0,0,260,3.1,4,3,24.1,77777,9,999999999,150,0.0820,0,88,999.000,999.0,99.0
+1978,10,12,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,5.6,86,99200,0,0,296,0,0,0,0,0,0,0,290,3.6,3,3,24.1,77777,9,999999999,150,0.0820,0,88,999.000,999.0,99.0
+1978,10,13,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,5.6,86,99300,0,0,296,0,0,0,0,0,0,0,300,2.6,4,3,24.1,77777,9,999999999,150,0.0820,0,88,999.000,999.0,99.0
+1978,10,13,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,5.0,89,99300,0,0,298,0,0,0,0,0,0,0,280,2.6,6,6,24.1,3050,9,999999999,139,0.0820,0,88,999.000,999.0,99.0
+1978,10,13,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,4.4,89,99300,0,0,281,0,0,0,0,0,0,0,280,3.1,3,1,24.1,77777,9,999999999,139,0.0820,0,88,999.000,999.0,99.0
+1978,10,13,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,3.9,93,99400,0,0,271,0,0,0,0,0,0,0,270,3.6,0,0,24.1,77777,9,999999999,139,0.0820,0,88,999.000,999.0,99.0
+1978,10,13,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,2.8,89,99400,0,0,267,0,0,0,0,0,0,0,280,3.6,0,0,24.1,77777,9,999999999,129,0.0820,0,88,999.000,999.0,99.0
+1978,10,13,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,2.2,89,99400,0,0,270,0,0,0,0,0,0,0,270,3.1,1,1,19.3,77777,9,999999999,120,0.0820,0,88,999.000,999.0,99.0
+1978,10,13,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,3.3,86,99500,109,1293,278,47,242,24,4600,12800,3500,430,280,3.6,1,1,24.1,77777,9,999999999,129,0.0740,0,88,999.000,999.0,99.0
+1978,10,13,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,5.6,77,99500,351,1373,290,210,611,49,21100,52200,7700,950,300,3.1,1,0,24.1,77777,9,999999999,150,0.0740,0,88,999.000,999.0,99.0
+1978,10,13,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,5.0,64,99500,564,1373,299,384,755,67,39700,72200,9900,1410,340,3.1,1,0,24.1,77777,9,999999999,150,0.0740,0,88,999.000,999.0,99.0
+1978,10,13,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,3.9,48,99500,731,1373,318,511,753,102,52300,74000,12800,2140,320,4.6,2,1,24.1,77777,9,999999999,139,0.0740,0,88,999.000,999.0,99.0
+1978,10,13,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,0.6,36,99500,840,1373,321,568,659,159,59000,66100,18500,3790,310,2.6,3,2,24.1,77777,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1978,10,13,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,0.6,36,99500,883,1373,327,580,600,189,59900,60000,21200,4640,340,5.2,5,4,24.1,77777,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1978,10,13,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,0.0,32,99500,858,1373,329,476,463,182,51000,47700,21100,4400,340,5.2,4,3,24.1,77777,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1978,10,13,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,1.1,36,99500,765,1373,332,424,379,210,45600,40000,23300,4910,330,3.6,6,5,24.1,3050,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1978,10,13,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,1.1,39,99500,612,1373,325,379,521,142,39700,51200,16800,2850,60,3.6,4,4,24.1,77777,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1978,10,13,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,0.6,42,99500,409,1373,317,188,342,84,19800,30200,10800,1540,40,3.6,4,4,24.1,77777,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1978,10,13,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,1.1,47,99500,171,1373,317,56,65,47,6000,4000,5500,990,60,5.2,8,6,24.1,1520,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1978,10,13,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,2.2,53,99500,5,286,320,4,3,3,0,0,0,0,20,3.1,9,7,24.1,1520,9,999999999,120,0.0740,0,88,999.000,999.0,99.0
+1978,10,13,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,2.2,61,99600,0,0,315,0,0,0,0,0,0,0,350,2.6,10,8,24.1,7620,9,999999999,120,0.0740,0,88,999.000,999.0,99.0
+1978,10,13,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,3.3,64,99600,0,0,319,0,0,0,0,0,0,0,340,4.1,8,8,24.1,1370,9,999999999,129,0.0740,0,88,999.000,999.0,99.0
+1978,10,13,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,3.3,68,99600,0,0,321,0,0,0,0,0,0,0,360,6.2,9,9,24.1,2440,9,999999999,129,0.0740,0,88,999.000,999.0,99.0
+1978,10,13,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,3.9,69,99600,0,0,333,0,0,0,0,0,0,0,340,4.1,10,10,24.1,1010,9,999999999,139,0.0740,0,88,999.000,999.0,99.0
+1978,10,13,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,2.8,68,99600,0,0,326,0,0,0,0,0,0,0,350,6.2,10,10,24.1,1400,9,999999999,129,0.0740,0,88,999.000,999.0,99.0
+1978,10,13,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,1.7,66,99600,0,0,323,0,0,0,0,0,0,0,340,7.2,10,10,24.1,1160,9,999999999,120,0.0740,0,88,999.000,999.0,99.0
+1978,10,14,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,0.6,61,99600,0,0,321,0,0,0,0,0,0,0,320,7.7,10,10,24.1,1010,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1978,10,14,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,0.6,63,99600,0,0,310,0,0,0,0,0,0,0,320,7.2,10,9,24.1,1010,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1978,10,14,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,0.0,73,99600,0,0,276,0,0,0,0,0,0,0,300,4.1,3,3,24.1,77777,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1978,10,14,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,0.0,76,99600,0,0,263,0,0,0,0,0,0,0,310,5.2,0,0,24.1,77777,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1978,10,14,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,0.6,82,99600,0,0,261,0,0,0,0,0,0,0,300,5.2,0,0,24.1,77777,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1978,10,14,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,0.6,85,99700,0,0,268,0,0,0,0,0,0,0,300,3.1,2,2,24.1,77777,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1978,10,14,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,1.1,89,99700,104,1271,268,45,168,29,4500,7900,3800,520,300,4.1,3,2,24.1,77777,9,999999999,110,0.0810,0,88,999.000,999.0,99.0
+1978,10,14,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,2.2,79,99700,346,1374,280,179,443,64,18100,36900,8800,1170,320,6.7,3,2,24.1,77777,9,999999999,120,0.0810,0,88,999.000,999.0,99.0
+1978,10,14,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.8,2.2,68,99700,559,1374,299,224,269,112,24300,26800,13300,2210,340,8.2,7,6,24.1,640,9,999999999,120,0.0810,0,88,999.000,999.0,99.0
+1978,10,14,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,1.1,59,99800,726,1374,303,289,130,219,31500,13400,24400,5570,320,7.2,6,6,24.1,640,9,999999999,120,0.0810,0,88,999.000,999.0,99.0
+1978,10,14,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,-1.7,48,99800,834,1374,300,424,317,228,45700,33800,25200,5620,330,7.7,7,6,24.1,2740,9,999999999,100,0.0810,0,88,999.000,999.0,99.0
+1978,10,14,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,-1.1,46,99700,877,1374,309,493,378,248,53200,40500,27300,6390,340,6.2,8,7,24.1,2740,9,999999999,100,0.0810,0,88,999.000,999.0,99.0
+1978,10,14,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,-1.1,46,99700,851,1374,314,386,138,299,41800,14500,32900,8240,310,6.2,8,8,24.1,2740,9,999999999,100,0.0810,0,88,999.000,999.0,99.0
+1978,10,14,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,-1.7,46,99700,758,1374,299,461,464,202,48200,47100,22200,4530,330,6.7,7,5,24.1,2740,9,999999999,100,0.0810,0,88,999.000,999.0,99.0
+1978,10,14,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,-1.7,44,99700,605,1374,313,266,208,173,29000,20900,19700,4150,310,6.2,8,8,24.1,1220,9,999999999,100,0.0810,0,88,999.000,999.0,99.0
+1978,10,14,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,-1.7,44,99700,402,1374,313,191,266,111,20000,23800,13100,2200,350,6.2,8,8,24.1,1160,9,999999999,100,0.0810,0,88,999.000,999.0,99.0
+1978,10,14,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,-2.2,46,99700,164,1374,303,60,71,51,6400,4300,5900,1070,330,5.7,7,7,24.1,1160,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1978,10,14,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,-2.2,53,99700,4,241,288,2,5,2,0,0,0,0,290,3.1,5,5,24.1,77777,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1978,10,14,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,-2.8,58,99700,0,0,264,0,0,0,0,0,0,0,300,3.1,0,0,24.1,77777,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1978,10,14,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-2.2,70,99700,0,0,257,0,0,0,0,0,0,0,290,2.1,0,0,24.1,77777,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1978,10,14,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-2.8,73,99700,0,0,252,0,0,0,0,0,0,0,270,3.1,0,0,24.1,77777,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1978,10,14,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-2.8,73,99700,0,0,252,0,0,0,0,0,0,0,270,2.6,0,0,24.1,77777,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1978,10,14,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-2.8,76,99700,0,0,255,0,0,0,0,0,0,0,270,1.5,3,1,24.1,77777,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1978,10,14,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-2.2,82,99600,0,0,253,0,0,0,0,0,0,0,180,2.1,3,1,24.1,77777,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1978,10,15,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-2.2,82,99500,0,0,257,0,0,0,0,0,0,0,230,2.1,4,2,24.1,77777,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1978,10,15,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-1.1,82,99500,0,0,274,0,0,0,0,0,0,0,230,2.6,8,7,24.1,3050,9,999999999,100,0.0810,0,88,999.000,999.0,99.0
+1978,10,15,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-1.1,76,99400,0,0,297,0,0,0,0,0,0,0,210,2.6,10,10,24.1,1680,9,999999999,100,0.0810,0,88,999.000,999.0,99.0
+1978,10,15,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,-1.1,70,99300,0,0,302,0,0,0,0,0,0,0,200,2.6,10,10,24.1,1680,9,999999999,100,0.0810,0,88,999.000,999.0,99.0
+1978,10,15,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,0.0,76,99300,0,0,303,0,0,0,0,0,0,0,200,5.2,10,10,16.1,1400,9,999999999,110,0.0810,0,88,999.000,999.0,99.0
+1978,10,15,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,1.1,79,99200,0,0,307,0,0,0,0,0,0,0,190,3.6,10,10,14.5,1010,9,999999999,110,0.0810,0,88,999.000,999.0,99.0
+1978,10,15,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,1.7,82,99200,100,1249,307,17,3,16,1900,0,1900,590,190,5.7,10,10,12.9,700,9,999999999,120,0.0730,0,88,999.000,999.0,99.0
+1978,10,15,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,3.3,83,99100,340,1375,317,82,12,79,9300,500,9100,2880,180,4.6,10,10,14.5,700,9,999999999,129,0.0730,0,88,999.000,999.0,99.0
+1978,10,15,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,2.8,74,99000,553,1375,321,96,7,93,11300,400,11100,4010,190,5.2,10,10,14.5,2740,9,999999999,129,0.0730,0,88,999.000,999.0,99.0
+1978,10,15,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,3.3,77,98900,720,1375,322,134,2,133,15800,100,15800,6000,180,5.2,10,10,11.3,700,9,999999999,129,0.0730,0,88,999.000,999.0,99.0
+1978,10,15,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,4.4,86,98800,828,1375,321,152,2,151,18100,100,18000,7070,170,7.2,10,10,12.9,760,9,999999999,139,0.0730,0,88,999.000,999.0,99.0
+1978,10,15,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,3.9,80,98500,871,1375,322,278,6,275,31900,500,31600,11360,160,6.2,10,10,14.5,1160,9,999999999,129,0.0730,0,88,999.000,999.0,99.0
+1978,10,15,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,4.4,74,98400,845,1375,331,151,3,149,18000,200,17900,7050,170,6.2,10,10,14.5,1010,9,999999999,139,0.0730,0,88,999.000,999.0,99.0
+1978,10,15,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,3.9,66,98300,752,1375,336,226,3,224,25700,300,25600,9050,210,4.6,10,10,14.5,1010,9,999999999,129,0.0730,0,88,999.000,999.0,99.0
+1978,10,15,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,4.4,66,98300,598,1375,339,202,1,201,22500,100,22500,7270,180,3.1,10,10,24.1,1160,9,999999999,139,0.0730,0,88,999.000,999.0,99.0
+1978,10,15,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,5.0,69,98300,395,1375,340,124,1,123,13600,100,13600,4160,230,1.5,10,10,24.1,2290,9,999999999,139,0.0730,0,88,999.000,999.0,99.0
+1978,10,15,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,5.0,74,98400,158,1375,318,39,29,35,4200,2000,4000,860,270,3.1,8,8,24.1,2440,9,999999999,139,0.0730,0,88,999.000,999.0,99.0
+1978,10,15,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,3.9,71,98500,3,218,321,1,1,1,0,0,0,0,290,3.1,9,9,24.1,2440,9,999999999,129,0.0730,0,88,999.000,999.0,99.0
+1978,10,15,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,3.9,77,98600,0,0,325,0,0,0,0,0,0,0,270,4.1,10,10,24.1,1370,9,999999999,129,0.0730,0,88,999.000,999.0,99.0
+1978,10,15,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,4.4,80,98700,0,0,326,0,0,0,0,0,0,0,310,5.2,10,10,19.3,580,9,999999999,139,0.0730,0,88,999.000,999.0,99.0
+1978,10,15,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,3.3,77,98800,0,0,322,0,0,0,0,0,0,0,330,8.8,10,10,24.1,640,9,999999999,129,0.0730,0,88,999.000,999.0,99.0
+1978,10,15,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,2.8,79,98800,0,0,308,0,0,0,0,0,0,0,310,6.2,9,9,24.1,760,9,999999999,129,0.0730,0,88,999.000,999.0,99.0
+1978,10,15,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,3.3,80,98800,0,0,311,0,0,0,0,0,0,0,300,6.7,10,9,24.1,400,9,999999999,129,0.0730,0,88,999.000,999.0,99.0
+1978,10,15,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,3.3,77,98900,0,0,322,0,0,0,0,0,0,0,300,7.7,10,10,24.1,400,9,999999999,129,0.0730,0,88,999.000,999.0,99.0
+1978,10,16,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,3.9,80,98900,0,0,322,0,0,0,0,0,0,0,320,10.3,10,10,24.1,340,9,999999999,129,0.0730,0,88,999.000,999.0,99.0
+1978,10,16,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,3.9,83,99000,0,0,311,0,0,0,0,0,0,0,330,7.7,9,9,24.1,340,9,999999999,139,0.0730,0,88,999.000,999.0,99.0
+1978,10,16,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,3.9,86,99000,0,0,317,0,0,0,0,0,0,0,340,7.2,10,10,24.1,340,9,999999999,129,0.0730,0,88,999.000,999.0,99.0
+1978,10,16,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,4.4,89,99100,0,0,318,0,0,0,0,0,0,0,330,8.8,10,10,11.3,490,9,999999999,139,0.0730,0,88,999.000,999.0,99.0
+1978,10,16,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,4.4,86,99200,0,0,321,0,0,0,0,0,0,0,320,9.3,10,10,24.1,340,9,999999999,139,0.0730,0,88,999.000,999.0,99.0
+1978,10,16,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,4.4,89,99300,0,0,318,0,0,0,0,0,0,0,330,9.3,10,10,11.3,210,9,999999999,139,0.0730,0,88,999.000,999.0,99.0
+1978,10,16,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,4.4,86,99400,96,1227,312,14,7,14,1600,400,1600,370,330,8.8,10,9,12.9,180,9,999999999,139,0.0940,0,88,999.000,999.0,99.0
+1978,10,16,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,5.0,89,99600,335,1376,321,70,9,68,8000,400,7900,2560,20,5.2,10,10,12.9,460,9,999999999,139,0.0940,0,88,999.000,999.0,99.0
+1978,10,16,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,4.4,83,99700,548,1376,323,71,6,69,8600,300,8400,3100,30,6.2,10,10,6.4,240,9,999999999,139,0.0940,0,88,999.000,999.0,99.0
+1978,10,16,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,6.7,86,99900,714,1376,318,357,147,279,38200,15000,30400,7050,20,8.2,9,8,24.1,610,9,999999999,160,0.0940,0,88,999.000,999.0,99.0
+1978,10,16,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,5.6,69,99900,822,1376,326,239,109,173,26700,11500,19800,4660,30,7.7,8,8,24.1,580,9,999999999,150,0.0940,0,88,999.000,999.0,99.0
+1978,10,16,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,4.4,59,100000,864,1376,330,376,157,276,41000,16500,30600,7680,40,8.2,8,8,24.1,910,9,999999999,139,0.0940,0,88,999.000,999.0,99.0
+1978,10,16,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,3.3,57,100000,838,1376,326,387,181,275,42100,19000,30500,7500,20,8.8,8,8,24.1,910,9,999999999,129,0.0940,0,88,999.000,999.0,99.0
+1978,10,16,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,2.2,53,100100,745,1376,316,560,708,171,57100,69400,19400,3600,30,7.7,6,6,24.1,910,9,999999999,120,0.0940,0,88,999.000,999.0,99.0
+1978,10,16,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,2.2,59,100200,591,1376,306,339,433,150,35300,42200,17100,3010,20,5.7,5,5,24.1,77777,9,999999999,120,0.0940,0,88,999.000,999.0,99.0
+1978,10,16,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,1.7,57,100200,388,1376,303,188,196,132,20200,17400,15200,2930,30,6.2,4,4,24.1,77777,9,999999999,120,0.0940,0,88,999.000,999.0,99.0
+1978,10,16,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,1.7,59,100200,151,1376,296,59,201,36,6000,10900,4800,650,20,5.7,2,2,24.1,77777,9,999999999,120,0.0940,0,88,999.000,999.0,99.0
+1978,10,16,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,1.7,73,100300,2,172,273,2,4,2,0,0,0,0,20,3.1,0,0,24.1,77777,9,999999999,120,0.0940,0,88,999.000,999.0,99.0
+1978,10,16,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,1.1,71,100300,0,0,272,0,0,0,0,0,0,0,360,2.1,0,0,24.1,77777,9,999999999,120,0.0940,0,88,999.000,999.0,99.0
+1978,10,16,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,0.6,76,100400,0,0,265,0,0,0,0,0,0,0,320,3.1,0,0,24.1,77777,9,999999999,110,0.0940,0,88,999.000,999.0,99.0
+1978,10,16,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,0.6,85,100400,0,0,259,0,0,0,0,0,0,0,300,2.1,0,0,24.1,77777,9,999999999,110,0.0940,0,88,999.000,999.0,99.0
+1978,10,16,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,0.0,85,100500,0,0,256,0,0,0,0,0,0,0,300,2.1,0,0,24.1,77777,9,999999999,110,0.0940,0,88,999.000,999.0,99.0
+1978,10,16,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,1.1,89,100500,0,0,260,0,0,0,0,0,0,0,300,1.5,0,0,24.1,77777,9,999999999,120,0.0940,0,88,999.000,999.0,99.0
+1978,10,16,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,0.0,89,100500,0,0,255,0,0,0,0,0,0,0,270,1.5,0,0,24.1,77777,9,999999999,110,0.0940,0,88,999.000,999.0,99.0
+1978,10,17,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,0.6,82,100500,0,0,261,0,0,0,0,0,0,0,240,1.5,0,0,24.1,77777,9,999999999,110,0.0940,0,88,999.000,999.0,99.0
+1978,10,17,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-0.6,89,100500,0,0,252,0,0,0,0,0,0,0,210,1.5,0,0,24.1,77777,9,999999999,100,0.0940,0,88,999.000,999.0,99.0
+1978,10,17,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-1.7,89,100500,0,0,247,0,0,0,0,0,0,0,200,2.1,0,0,24.1,77777,9,999999999,100,0.0940,0,88,999.000,999.0,99.0
+1978,10,17,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-0.6,89,100500,0,0,252,0,0,0,0,0,0,0,190,3.6,0,0,24.1,77777,9,999999999,100,0.0940,0,88,999.000,999.0,99.0
+1978,10,17,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.1,85,100600,0,0,251,0,0,0,0,0,0,0,180,2.6,0,0,24.1,77777,9,999999999,100,0.0940,0,88,999.000,999.0,99.0
+1978,10,17,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-1.1,82,100600,0,0,254,0,0,0,0,0,0,0,180,3.1,0,0,19.3,77777,9,999999999,100,0.0940,0,88,999.000,999.0,99.0
+1978,10,17,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-0.6,82,100600,91,1205,256,37,60,31,3900,2900,3700,640,180,3.1,4,0,16.1,77777,9,999999999,100,0.1790,0,88,999.000,999.0,99.0
+1978,10,17,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,2.2,76,100600,330,1377,273,170,392,72,17500,31900,9800,1310,190,3.6,1,0,16.1,77777,9,999999999,120,0.1790,0,88,999.000,999.0,99.0
+1978,10,17,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,2.8,66,100600,542,1377,285,338,580,105,34500,54500,13000,2020,170,3.6,1,0,16.1,77777,9,999999999,129,0.1790,0,88,999.000,999.0,99.0
+1978,10,17,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,2.2,55,100500,708,1377,299,459,596,146,47000,58400,16800,3050,170,5.2,3,1,16.1,77777,9,999999999,120,0.1790,0,88,999.000,999.0,99.0
+1978,10,17,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,2.2,49,100500,816,1377,311,561,576,214,58800,58900,23700,5040,180,5.2,5,2,16.1,77777,9,999999999,120,0.1790,0,88,999.000,999.0,99.0
+1978,10,17,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,1.7,47,100300,858,1377,313,515,456,227,54100,46900,24800,5590,170,6.2,7,3,19.3,77777,9,999999999,120,0.1790,0,88,999.000,999.0,99.0
+1978,10,17,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,2.2,47,100300,831,1377,316,557,541,225,58200,55400,24600,5400,180,5.2,7,3,19.3,77777,9,999999999,120,0.1790,0,88,999.000,999.0,99.0
+1978,10,17,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,2.2,46,100200,738,1377,319,429,409,206,44500,41300,22300,4570,210,6.2,7,3,19.3,77777,9,999999999,120,0.1790,0,88,999.000,999.0,99.0
+1978,10,17,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,1.7,47,100100,585,1377,346,81,4,79,9700,200,9600,3560,170,7.2,10,10,19.3,3660,9,999999999,120,0.1790,0,88,999.000,999.0,99.0
+1978,10,17,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,1.7,44,100000,381,1377,335,70,13,66,8100,600,7900,2630,180,5.7,9,8,24.1,3660,9,999999999,120,0.1790,0,88,999.000,999.0,99.0
+1978,10,17,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,1.7,47,100000,144,1377,325,41,23,39,4500,1500,4400,920,180,4.1,8,7,24.1,2740,9,999999999,120,0.1790,0,88,999.000,999.0,99.0
+1978,10,17,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,2.2,51,99900,1,126,344,0,0,0,0,0,0,0,150,4.1,10,10,24.1,1830,9,999999999,120,0.1790,0,88,999.000,999.0,99.0
+1978,10,17,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,2.2,49,99900,0,0,347,0,0,0,0,0,0,0,160,5.2,10,10,24.1,1830,9,999999999,120,0.1790,0,88,999.000,999.0,99.0
+1978,10,17,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,2.2,51,99800,0,0,344,0,0,0,0,0,0,0,170,6.2,10,10,24.1,1830,9,999999999,120,0.1790,0,88,999.000,999.0,99.0
+1978,10,17,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,2.2,51,99800,0,0,344,0,0,0,0,0,0,0,180,5.2,10,10,24.1,2130,9,999999999,120,0.1790,0,88,999.000,999.0,99.0
+1978,10,17,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,2.2,53,99900,0,0,320,0,0,0,0,0,0,0,210,4.1,7,7,24.1,2440,9,999999999,120,0.1790,0,88,999.000,999.0,99.0
+1978,10,17,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,2.2,59,99900,0,0,313,0,0,0,0,0,0,0,200,4.1,7,7,24.1,2440,9,999999999,120,0.1790,0,88,999.000,999.0,99.0
+1978,10,17,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,2.2,63,99900,0,0,308,0,0,0,0,0,0,0,190,4.1,7,7,24.1,2440,9,999999999,120,0.1790,0,88,999.000,999.0,99.0
+1978,10,18,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,2.2,66,99900,0,0,297,0,0,0,0,0,0,0,210,4.1,8,4,24.1,77777,9,999999999,120,0.1790,0,88,999.000,999.0,99.0
+1978,10,18,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,2.2,63,99800,0,0,297,0,0,0,0,0,0,0,200,5.2,8,3,24.1,77777,9,999999999,120,0.1790,0,88,999.000,999.0,99.0
+1978,10,18,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,2.8,71,99800,0,0,293,0,0,0,0,0,0,0,180,3.6,7,3,24.1,77777,9,999999999,129,0.1790,0,88,999.000,999.0,99.0
+1978,10,18,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,2.8,74,99800,0,0,290,0,0,0,0,0,0,0,180,3.1,7,3,24.1,77777,9,999999999,129,0.1790,0,88,999.000,999.0,99.0
+1978,10,18,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,2.8,76,99800,0,0,282,0,0,0,0,0,0,0,210,2.6,3,1,24.1,77777,9,999999999,129,0.1790,0,88,999.000,999.0,99.0
+1978,10,18,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,2.8,71,99800,0,0,286,0,0,0,0,0,0,0,200,5.7,6,1,24.1,77777,9,999999999,129,0.1790,0,88,999.000,999.0,99.0
+1978,10,18,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,3.3,71,99800,87,1182,303,27,19,25,2900,1100,2800,600,210,4.6,10,6,11.3,3050,9,999999999,129,0.1200,0,88,999.000,999.0,99.0
+1978,10,18,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,3.9,69,99800,325,1377,308,123,88,101,13200,7300,11400,2200,190,4.1,10,6,12.9,3660,9,999999999,139,0.1200,0,88,999.000,999.0,99.0
+1978,10,18,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,3.9,61,99800,537,1377,311,288,371,139,29600,35300,15800,2730,230,5.7,10,4,12.9,77777,9,999999999,129,0.1200,0,88,999.000,999.0,99.0
+1978,10,18,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,4.4,57,99800,702,1377,313,461,586,156,48700,59000,18500,3290,230,5.2,7,2,11.3,77777,9,999999999,139,0.1200,0,88,999.000,999.0,99.0
+1978,10,18,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,5.6,54,99700,810,1377,345,352,175,247,38400,18300,27600,6600,220,3.6,10,8,12.9,3660,9,999999999,150,0.1200,0,88,999.000,999.0,99.0
+1978,10,18,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,5.6,55,99700,852,1377,359,210,11,203,24500,900,24000,9050,230,3.1,10,10,16.1,3660,9,999999999,150,0.1200,0,88,999.000,999.0,99.0
+1978,10,18,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,6.1,62,99700,825,1377,354,235,3,234,27100,300,27000,9850,250,2.6,10,10,14.5,3660,9,999999999,150,0.1200,0,88,999.000,999.0,99.0
+1978,10,18,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,7.2,67,99700,731,1377,355,182,6,178,21000,500,20700,7570,230,2.6,10,10,14.5,3660,9,999999999,170,0.1200,0,88,999.000,999.0,99.0
+1978,10,18,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,7.2,60,99600,578,1377,346,252,100,210,27600,9800,23500,5670,200,3.1,8,8,14.5,3660,9,999999999,170,0.1200,0,88,999.000,999.0,99.0
+1978,10,18,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,7.2,64,99600,374,1377,358,60,0,60,7000,0,7000,2420,240,3.6,10,10,14.5,3050,9,999999999,160,0.1200,0,88,999.000,999.0,99.0
+1978,10,18,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,7.8,75,99700,137,1377,322,47,129,34,5000,6200,4300,620,240,3.1,5,5,14.5,77777,9,999999999,170,0.1200,0,88,999.000,999.0,99.0
+1978,10,18,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,6.7,86,99700,1,103,295,0,1,0,0,0,0,0,240,3.6,1,1,11.3,77777,9,999999999,160,0.1200,0,88,999.000,999.0,99.0
+1978,10,18,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,6.7,86,99700,0,0,289,0,0,0,0,0,0,0,240,3.6,0,0,11.3,77777,9,999999999,160,0.1200,0,88,999.000,999.0,99.0
+1978,10,18,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,6.1,89,99700,0,0,284,0,0,0,0,0,0,0,270,2.6,0,0,11.3,77777,9,999999999,150,0.1200,0,88,999.000,999.0,99.0
+1978,10,18,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,4.4,83,99700,0,0,280,0,0,0,0,0,0,0,320,3.1,0,0,9.7,77777,9,999999999,139,0.1200,0,88,999.000,999.0,99.0
+1978,10,18,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,3.9,93,99700,0,0,271,0,0,0,0,0,0,0,250,2.6,0,0,9.7,77777,9,999999999,139,0.1200,0,88,999.000,999.0,99.0
+1978,10,18,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,3.3,93,99700,0,0,268,0,0,0,0,0,0,0,250,2.1,0,0,9.7,77777,9,999999999,129,0.1200,0,88,999.000,999.0,99.0
+1978,10,18,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,2.8,89,99600,0,0,267,0,0,0,0,0,0,0,240,3.1,0,0,9.7,77777,9,999999999,129,0.1200,0,88,999.000,999.0,99.0
+1978,10,19,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,3.3,93,99600,0,0,268,0,0,0,0,0,0,0,280,3.6,0,0,9.7,77777,9,999999999,129,0.1200,0,88,999.000,999.0,99.0
+1978,10,19,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,2.8,89,99600,0,0,267,0,0,0,0,0,0,0,290,3.6,0,0,12.9,77777,9,999999999,129,0.1200,0,88,999.000,999.0,99.0
+1978,10,19,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,2.2,86,99600,0,0,267,0,0,0,0,0,0,0,270,3.1,0,0,24.1,77777,9,999999999,120,0.1200,0,88,999.000,999.0,99.0
+1978,10,19,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,1.7,86,99600,0,0,264,0,0,0,0,0,0,0,270,3.1,0,0,24.1,77777,9,999999999,120,0.1200,0,88,999.000,999.0,99.0
+1978,10,19,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,1.7,89,99500,0,0,262,0,0,0,0,0,0,0,240,3.6,0,0,24.1,77777,9,999999999,120,0.1200,0,88,999.000,999.0,99.0
+1978,10,19,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,1.1,89,99600,0,0,281,0,0,0,0,0,0,0,250,3.1,7,7,24.1,3660,9,999999999,110,0.1200,0,88,999.000,999.0,99.0
+1978,10,19,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,1.7,86,99600,83,1160,286,24,18,22,2600,1100,2500,540,260,4.1,8,7,16.1,3660,9,999999999,120,0.1280,0,88,999.000,999.0,99.0
+1978,10,19,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,2.2,79,99600,319,1378,294,127,191,82,13400,15500,9800,1570,260,4.6,8,7,16.1,3660,9,999999999,120,0.1280,0,88,999.000,999.0,99.0
+1978,10,19,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,2.8,68,99500,531,1378,295,285,357,144,30100,35000,16600,2970,270,4.1,8,3,16.1,77777,9,999999999,129,0.1280,0,88,999.000,999.0,99.0
+1978,10,19,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,1.7,57,99500,697,1378,301,437,516,172,45800,51800,19500,3650,250,6.2,8,3,19.3,77777,9,999999999,120,0.1280,0,88,999.000,999.0,99.0
+1978,10,19,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,0.6,47,99400,804,1378,307,511,511,208,53600,52200,23000,4830,240,5.2,8,3,24.1,77777,9,999999999,110,0.1280,0,88,999.000,999.0,99.0
+1978,10,19,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,0.6,40,99300,845,1378,319,583,573,225,61000,58800,24800,5460,240,5.2,9,4,24.1,77777,9,999999999,110,0.1280,0,88,999.000,999.0,99.0
+1978,10,19,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,1.7,42,99200,818,1378,323,466,434,204,49100,44400,22600,4790,250,6.2,9,4,24.1,77777,9,999999999,120,0.1280,0,88,999.000,999.0,99.0
+1978,10,19,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,1.7,41,99000,725,1378,325,442,493,179,46400,49700,20200,3880,230,8.8,9,4,24.1,77777,9,999999999,120,0.1280,0,88,999.000,999.0,99.0
+1978,10,19,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,2.2,41,99000,571,1378,329,286,247,182,30100,24600,19900,3950,240,8.2,9,4,24.1,77777,9,999999999,120,0.1280,0,88,999.000,999.0,99.0
+1978,10,19,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,2.2,41,99000,368,1378,329,164,245,97,17300,21100,11600,1890,240,6.2,9,4,24.1,77777,9,999999999,120,0.1280,0,88,999.000,999.0,99.0
+1978,10,19,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,2.8,46,99000,131,1378,324,33,38,30,3700,2100,3500,620,250,4.6,9,4,24.1,77777,9,999999999,129,0.1280,0,88,999.000,999.0,99.0
+1978,10,19,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,2.8,53,99100,0,57,304,0,0,0,0,0,0,0,230,3.6,3,1,24.1,77777,9,999999999,129,0.1280,0,88,999.000,999.0,99.0
+1978,10,19,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,3.3,59,99100,0,0,295,0,0,0,0,0,0,0,230,4.1,2,0,24.1,77777,9,999999999,129,0.1280,0,88,999.000,999.0,99.0
+1978,10,19,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,3.3,59,99100,0,0,304,0,0,0,0,0,0,0,240,4.1,6,2,24.1,77777,9,999999999,129,0.1280,0,88,999.000,999.0,99.0
+1978,10,19,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,3.3,64,99100,0,0,290,0,0,0,0,0,0,0,240,4.1,0,0,24.1,77777,9,999999999,129,0.1280,0,88,999.000,999.0,99.0
+1978,10,19,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,3.3,68,99200,0,0,286,0,0,0,0,0,0,0,250,4.1,1,0,24.1,77777,9,999999999,129,0.1280,0,88,999.000,999.0,99.0
+1978,10,19,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,3.3,77,99200,0,0,279,0,0,0,0,0,0,0,330,2.1,0,0,24.1,77777,9,999999999,129,0.1280,0,88,999.000,999.0,99.0
+1978,10,19,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,2.8,79,99200,0,0,274,0,0,0,0,0,0,0,260,1.5,0,0,24.1,77777,9,999999999,129,0.1280,0,88,999.000,999.0,99.0
+1978,10,20,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,2.8,83,99200,0,0,272,0,0,0,0,0,0,0,280,1.5,0,0,24.1,77777,9,999999999,129,0.1280,0,88,999.000,999.0,99.0
+1978,10,20,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,2.8,86,99200,0,0,270,0,0,0,0,0,0,0,260,1.5,0,0,24.1,77777,9,999999999,129,0.1280,0,88,999.000,999.0,99.0
+1978,10,20,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,2.8,86,99200,0,0,270,0,0,0,0,0,0,0,260,1.5,0,0,24.1,77777,9,999999999,129,0.1280,0,88,999.000,999.0,99.0
+1978,10,20,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,2.2,86,99200,0,0,267,0,0,0,0,0,0,0,270,1.5,0,0,24.1,77777,9,999999999,120,0.1280,0,88,999.000,999.0,99.0
+1978,10,20,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,1.1,86,99200,0,0,262,0,0,0,0,0,0,0,270,2.1,0,0,24.1,77777,9,999999999,110,0.1280,0,88,999.000,999.0,99.0
+1978,10,20,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,0.6,89,99200,0,0,257,0,0,0,0,0,0,0,220,2.6,0,0,24.1,77777,9,999999999,110,0.1280,0,88,999.000,999.0,99.0
+1978,10,20,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,2.2,89,99300,79,1115,265,35,97,25,3400,3800,3100,450,230,2.6,1,0,19.3,77777,9,999999999,120,0.1290,0,88,999.000,999.0,99.0
+1978,10,20,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,7.2,83,99300,314,1379,294,168,462,58,16800,37100,8300,1050,0,0.0,0,0,16.1,77777,9,999999999,160,0.1290,0,88,999.000,999.0,99.0
+1978,10,20,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,7.8,62,99300,526,1379,316,337,650,83,34700,61300,11300,1640,160,3.1,0,0,12.9,77777,9,999999999,170,0.1290,0,88,999.000,999.0,99.0
+1978,10,20,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,10.0,65,99200,691,1379,326,475,732,102,49800,72600,13300,2220,180,4.1,0,0,16.1,77777,9,999999999,200,0.1290,0,88,999.000,999.0,99.0
+1978,10,20,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,7.8,50,99200,798,1379,331,576,787,113,59100,77800,13900,2450,220,4.6,0,0,19.3,77777,9,999999999,170,0.1290,0,88,999.000,999.0,99.0
+1978,10,20,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,8.3,47,99100,839,1379,339,610,797,117,62800,79200,14400,2640,220,3.6,0,0,19.3,77777,9,999999999,179,0.1290,0,88,999.000,999.0,99.0
+1978,10,20,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,9.4,47,99100,812,1379,345,584,786,114,60000,77900,14000,2510,200,5.7,0,0,24.1,77777,9,999999999,189,0.1290,0,88,999.000,999.0,99.0
+1978,10,20,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,8.9,43,99000,718,1379,350,502,752,105,52800,75000,13600,2330,220,4.6,0,0,24.1,77777,9,999999999,179,0.1290,0,88,999.000,999.0,99.0
+1978,10,20,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,7.2,37,99000,564,1379,351,367,673,87,38200,64500,11700,1750,220,4.1,0,0,24.1,77777,9,999999999,170,0.1290,0,88,999.000,999.0,99.0
+1978,10,20,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,7.2,39,99000,361,1379,346,201,513,63,20400,43400,9000,1170,200,4.1,0,0,24.1,77777,9,999999999,160,0.1290,0,88,999.000,999.0,99.0
+1978,10,20,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,6.7,48,98900,125,1379,327,48,172,31,4800,8300,4100,560,190,3.6,0,0,24.1,77777,9,999999999,160,0.1290,0,88,999.000,999.0,99.0
+1978,10,20,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,6.1,54,98900,0,34,317,0,0,0,0,0,0,0,180,3.6,0,0,24.1,77777,9,999999999,160,0.1290,0,88,999.000,999.0,99.0
+1978,10,20,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,6.1,62,98900,0,0,307,0,0,0,0,0,0,0,180,3.1,0,0,24.1,77777,9,999999999,150,0.1290,0,88,999.000,999.0,99.0
+1978,10,20,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,6.7,62,98900,0,0,310,0,0,0,0,0,0,0,180,3.6,0,0,24.1,77777,9,999999999,160,0.1290,0,88,999.000,999.0,99.0
+1978,10,20,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,6.7,62,98800,0,0,310,0,0,0,0,0,0,0,200,3.6,0,0,24.1,77777,9,999999999,160,0.1290,0,88,999.000,999.0,99.0
+1978,10,20,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,6.7,60,98800,0,0,312,0,0,0,0,0,0,0,220,4.6,0,0,24.1,77777,9,999999999,160,0.1290,0,88,999.000,999.0,99.0
+1978,10,20,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,6.1,54,98900,0,0,317,0,0,0,0,0,0,0,220,5.7,0,0,24.1,77777,9,999999999,150,0.1290,0,88,999.000,999.0,99.0
+1978,10,20,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,6.1,56,98800,0,0,314,0,0,0,0,0,0,0,220,3.6,0,0,24.1,77777,9,999999999,150,0.1290,0,88,999.000,999.0,99.0
+1978,10,21,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,6.1,60,98800,0,0,309,0,0,0,0,0,0,0,210,5.2,0,0,24.1,77777,9,999999999,150,0.1290,0,88,999.000,999.0,99.0
+1978,10,21,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,6.1,64,98900,0,0,305,0,0,0,0,0,0,0,200,4.6,0,0,24.1,77777,9,999999999,150,0.1290,0,88,999.000,999.0,99.0
+1978,10,21,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,6.1,64,98800,0,0,305,0,0,0,0,0,0,0,200,5.7,0,0,24.1,77777,9,999999999,150,0.1290,0,88,999.000,999.0,99.0
+1978,10,21,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,5.6,64,98700,0,0,302,0,0,0,0,0,0,0,200,4.6,0,0,24.1,77777,9,999999999,150,0.1290,0,88,999.000,999.0,99.0
+1978,10,21,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,5.6,64,98800,0,0,302,0,0,0,0,0,0,0,210,5.7,0,0,24.1,77777,9,999999999,150,0.1290,0,88,999.000,999.0,99.0
+1978,10,21,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,6.1,69,98800,0,0,306,0,0,0,0,0,0,0,180,4.1,2,1,24.1,77777,9,999999999,150,0.1290,0,88,999.000,999.0,99.0
+1978,10,21,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,6.7,67,98800,75,1092,311,29,40,25,3100,1900,2900,520,190,4.6,4,1,24.1,77777,9,999999999,160,0.1550,0,88,999.000,999.0,99.0
+1978,10,21,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,7.8,60,98900,309,1380,329,148,292,81,15100,23000,9900,1500,190,6.2,6,2,24.1,77777,9,999999999,170,0.1550,0,88,999.000,999.0,99.0
+1978,10,21,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,8.9,56,98900,520,1380,336,300,529,95,30600,49400,11900,1830,210,7.2,3,1,24.1,77777,9,999999999,179,0.1550,0,88,999.000,999.0,99.0
+1978,10,21,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,10.0,53,98900,685,1380,356,456,575,165,47800,57500,19100,3470,200,7.2,7,3,24.1,77777,9,999999999,189,0.1550,0,88,999.000,999.0,99.0
+1978,10,21,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.3,11.1,46,98800,792,1380,373,519,566,189,54800,57800,21500,4310,200,7.2,7,3,24.1,77777,9,999999999,209,0.1550,0,88,999.000,999.0,99.0
+1978,10,21,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,24.4,12.2,47,98800,833,1380,380,541,542,209,57000,55600,23400,4980,210,7.2,7,3,24.1,77777,9,999999999,220,0.1550,0,88,999.000,999.0,99.0
+1978,10,21,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,11.7,43,98700,805,1380,389,491,469,213,51400,47900,23400,4960,190,8.8,7,5,24.1,7620,9,999999999,209,0.1550,0,88,999.000,999.0,99.0
+1978,10,21,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,26.1,11.7,41,98700,712,1380,398,241,69,205,26500,6900,22900,6300,200,6.7,7,6,24.1,7620,9,999999999,220,0.1550,0,88,999.000,999.0,99.0
+1978,10,21,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,25.0,10.6,40,98700,558,1380,391,281,329,146,30000,32600,16700,3020,200,6.2,8,6,24.1,7620,9,999999999,200,0.1550,0,88,999.000,999.0,99.0
+1978,10,21,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,23.9,11.1,45,98700,354,1380,386,142,127,109,15300,11000,12500,2400,200,4.1,8,6,24.1,7010,9,999999999,209,0.1550,0,88,999.000,999.0,99.0
+1978,10,21,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,11.1,51,98700,118,1368,365,32,39,28,3500,2000,3300,580,180,4.1,7,3,24.1,77777,9,999999999,209,0.1550,0,88,999.000,999.0,99.0
+1978,10,21,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,11.1,61,98700,0,0,352,0,0,0,0,0,0,0,180,4.1,7,3,24.1,77777,9,999999999,209,0.1550,0,88,999.000,999.0,99.0
+1978,10,21,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.6,11.7,57,98700,0,0,361,0,0,0,0,0,0,0,170,5.7,7,3,24.1,77777,9,999999999,209,0.1550,0,88,999.000,999.0,99.0
+1978,10,21,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,20.0,11.1,57,98800,0,0,357,0,0,0,0,0,0,0,190,5.7,5,3,24.1,77777,9,999999999,209,0.1550,0,88,999.000,999.0,99.0
+1978,10,21,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,11.1,59,98800,0,0,351,0,0,0,0,0,0,0,190,7.2,3,2,24.1,77777,9,999999999,209,0.1550,0,88,999.000,999.0,99.0
+1978,10,21,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.9,11.1,61,98800,0,0,337,0,0,0,0,0,0,0,200,6.7,0,0,24.1,77777,9,999999999,209,0.1550,0,88,999.000,999.0,99.0
+1978,10,21,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,19.4,11.1,59,98800,0,0,354,0,0,0,0,0,0,0,200,8.2,3,3,24.1,77777,9,999999999,209,0.1550,0,88,999.000,999.0,99.0
+1978,10,21,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,10.6,61,98800,0,0,367,0,0,0,0,0,0,0,210,6.2,10,8,24.1,3050,9,999999999,200,0.1550,0,88,999.000,999.0,99.0
+1978,10,22,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,10.6,61,98800,0,0,385,0,0,0,0,0,0,0,210,8.8,10,10,24.1,3050,9,999999999,200,0.1550,0,88,999.000,999.0,99.0
+1978,10,22,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,11.1,65,98800,0,0,383,0,0,0,0,0,0,0,220,7.2,10,10,24.1,3050,9,999999999,209,0.1550,0,88,999.000,999.0,99.0
+1978,10,22,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,11.1,68,98800,0,0,380,0,0,0,0,0,0,0,220,6.7,10,10,24.1,3050,9,999999999,209,0.1550,0,88,999.000,999.0,99.0
+1978,10,22,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,11.1,68,98800,0,0,380,0,0,0,0,0,0,0,210,6.2,10,10,24.1,3050,9,999999999,209,0.1550,0,88,999.000,999.0,99.0
+1978,10,22,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,11.1,68,98900,0,0,380,0,0,0,0,0,0,0,210,7.2,10,10,24.1,3050,9,999999999,209,0.1550,0,88,999.000,999.0,99.0
+1978,10,22,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,11.1,70,98900,0,0,377,0,0,0,0,0,0,0,200,4.6,10,10,24.1,3050,9,999999999,209,0.1550,0,88,999.000,999.0,99.0
+1978,10,22,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,11.1,72,98900,71,1070,374,18,3,18,2100,0,2100,630,220,4.1,10,10,11.3,3050,9,999999999,209,0.1820,0,88,999.000,999.0,99.0
+1978,10,22,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,11.7,75,98900,303,1381,375,66,4,65,7500,100,7400,2380,200,6.2,10,10,12.9,3050,9,999999999,209,0.1820,0,88,999.000,999.0,99.0
+1978,10,22,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,11.7,68,99000,514,1381,384,103,1,103,12000,100,11900,4210,230,6.7,10,10,14.5,3050,9,999999999,220,0.1820,0,88,999.000,999.0,99.0
+1978,10,22,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,12.2,61,99000,679,1381,385,161,26,148,17700,2600,16500,4690,200,8.2,10,9,14.5,7620,9,999999999,220,0.1820,0,88,999.000,999.0,99.0
+1978,10,22,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,12.8,57,99000,785,1381,395,348,104,288,38100,10600,32100,8760,230,6.2,10,9,14.5,7620,9,999999999,229,0.1820,0,88,999.000,999.0,99.0
+1978,10,22,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.2,12.2,53,99000,826,1381,397,251,60,214,27600,6000,23900,7180,240,6.7,10,9,14.5,7620,9,999999999,220,0.1820,0,88,999.000,999.0,99.0
+1978,10,22,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,22.8,12.2,51,99000,799,1381,400,299,88,248,32900,8900,27700,7910,270,4.1,10,9,14.5,3050,9,999999999,220,0.1820,0,88,999.000,999.0,99.0
+1978,10,22,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,11.7,53,99000,705,1381,405,226,123,163,25100,12700,18600,4090,310,4.1,10,10,16.1,3050,9,999999999,209,0.1820,0,88,999.000,999.0,99.0
+1978,10,22,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,11.7,55,99100,551,1381,402,128,3,126,14600,200,14500,5070,30,8.2,10,10,16.1,3050,9,999999999,209,0.1820,0,88,999.000,999.0,99.0
+1978,10,22,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,8.3,62,99200,348,1381,358,83,41,72,9100,3500,8200,1950,20,6.2,10,9,16.1,3050,9,999999999,179,0.1820,0,88,999.000,999.0,99.0
+1978,10,22,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,8.9,67,99300,112,1346,366,23,1,23,2600,0,2600,800,20,7.2,10,10,14.5,3050,9,999999999,179,0.1820,0,88,999.000,999.0,99.0
+1978,10,22,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,8.3,69,99400,0,0,360,0,0,0,0,0,0,0,10,6.7,10,10,19.3,3050,9,999999999,179,0.1820,0,88,999.000,999.0,99.0
+1978,10,22,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,8.9,75,99500,0,0,357,0,0,0,0,0,0,0,360,3.6,10,10,16.1,1680,9,999999999,179,0.1820,0,88,999.000,999.0,99.0
+1978,10,22,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,9.4,83,99500,0,0,353,0,0,0,0,0,0,0,20,5.2,10,10,16.1,1830,9,999999999,189,0.1820,0,88,999.000,999.0,99.0
+1978,10,22,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,10.0,86,99500,0,0,353,0,0,0,0,0,0,0,10,6.2,10,10,11.3,1830,9,999999999,189,0.1820,0,88,999.000,999.0,99.0
+1978,10,22,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,10.0,86,99500,0,0,353,0,0,0,0,0,0,0,10,6.2,10,10,11.3,460,9,999999999,189,0.1820,0,88,999.000,999.0,99.0
+1978,10,22,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,10.0,90,99600,0,0,351,0,0,0,0,0,0,0,20,6.7,10,10,8.0,340,9,999999999,200,0.1820,0,88,999.000,999.0,99.0
+1978,10,22,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,9.4,90,99600,0,0,347,0,0,0,0,0,0,0,20,4.6,10,10,6.4,310,9,999999999,189,0.1820,0,88,999.000,999.0,99.0
+1978,10,23,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,9.4,90,99700,0,0,347,0,0,0,0,0,0,0,10,5.7,10,10,12.9,310,9,999999999,189,0.1820,0,88,999.000,999.0,99.0
+1978,10,23,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,8.9,93,99800,0,0,341,0,0,0,0,0,0,0,10,6.2,10,10,19.3,760,9,999999999,179,0.1820,0,88,999.000,999.0,99.0
+1978,10,23,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,8.3,89,99800,0,0,341,0,0,0,0,0,0,0,10,7.7,10,10,24.1,760,9,999999999,179,0.1820,0,88,999.000,999.0,99.0
+1978,10,23,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,7.2,86,99900,0,0,336,0,0,0,0,0,0,0,360,8.2,10,10,24.1,760,9,999999999,160,0.1820,0,88,999.000,999.0,99.0
+1978,10,23,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,6.1,83,99900,0,0,333,0,0,0,0,0,0,0,20,7.7,10,10,24.1,760,9,999999999,150,0.1820,0,88,999.000,999.0,99.0
+1978,10,23,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,5.6,83,100000,0,0,329,0,0,0,0,0,0,0,360,6.2,10,10,24.1,760,9,999999999,150,0.1820,0,88,999.000,999.0,99.0
+1978,10,23,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,4.4,77,100100,67,1048,328,20,2,20,2300,0,2300,680,10,8.8,10,10,24.1,700,9,999999999,139,0.0900,0,88,999.000,999.0,99.0
+1978,10,23,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,2.8,74,100200,298,1381,301,120,197,76,12600,15400,9200,1450,360,7.7,7,7,24.1,700,9,999999999,129,0.0900,0,88,999.000,999.0,99.0
+1978,10,23,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,2.8,68,100200,509,1381,300,272,431,109,28500,40600,13500,2070,10,7.7,5,5,24.1,77777,9,999999999,129,0.0900,0,88,999.000,999.0,99.0
+1978,10,23,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,2.8,61,100300,673,1381,307,310,219,201,33700,22400,22700,4970,360,6.2,7,5,24.1,3050,9,999999999,129,0.0900,0,88,999.000,999.0,99.0
+1978,10,23,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,1.7,57,100300,779,1381,312,371,239,234,39700,25200,25400,5610,360,5.7,8,7,24.1,760,9,999999999,120,0.0900,0,88,999.000,999.0,99.0
+1978,10,23,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,2.2,57,100300,820,1381,320,324,205,200,35200,21800,22200,4770,10,7.2,8,8,24.1,760,9,999999999,120,0.0900,0,88,999.000,999.0,99.0
+1978,10,23,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,1.1,54,100300,792,1381,316,420,253,273,45500,26300,30300,7210,30,5.7,8,8,24.1,760,9,999999999,110,0.0900,0,88,999.000,999.0,99.0
+1978,10,23,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,1.7,54,100300,698,1381,311,446,523,177,46600,52500,20000,3770,20,6.7,6,6,24.1,760,9,999999999,120,0.0900,0,88,999.000,999.0,99.0
+1978,10,23,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,1.7,59,100300,544,1381,306,264,275,153,27900,27100,17200,3200,30,7.2,6,6,24.1,760,9,999999999,120,0.0900,0,88,999.000,999.0,99.0
+1978,10,23,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,0.6,56,100300,341,1381,298,178,363,86,18300,29800,10800,1590,30,5.7,4,4,24.1,77777,9,999999999,110,0.0900,0,88,999.000,999.0,99.0
+1978,10,23,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,0.0,60,100300,106,1301,281,44,196,25,4400,9200,3600,440,30,4.6,1,1,24.1,77777,9,999999999,110,0.0900,0,88,999.000,999.0,99.0
+1978,10,23,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,0.0,68,100300,0,0,269,0,0,0,0,0,0,0,40,3.1,0,0,24.1,77777,9,999999999,110,0.0900,0,88,999.000,999.0,99.0
+1978,10,23,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,0.0,70,100300,0,0,267,0,0,0,0,0,0,0,60,3.6,0,0,24.1,77777,9,999999999,110,0.0900,0,88,999.000,999.0,99.0
+1978,10,23,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,0.0,70,100200,0,0,267,0,0,0,0,0,0,0,40,2.6,0,0,24.1,77777,9,999999999,110,0.0900,0,88,999.000,999.0,99.0
+1978,10,23,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-1.1,82,100300,0,0,254,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,100,0.0900,0,88,999.000,999.0,99.0
+1978,10,23,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-0.6,82,100200,0,0,256,0,0,0,0,0,0,0,270,2.6,0,0,24.1,77777,9,999999999,100,0.0900,0,88,999.000,999.0,99.0
+1978,10,23,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-1.1,89,100200,0,0,250,0,0,0,0,0,0,0,240,2.6,0,0,24.1,77777,9,999999999,100,0.0900,0,88,999.000,999.0,99.0
+1978,10,23,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-0.6,89,100100,0,0,257,0,0,0,0,0,0,0,240,2.1,1,1,24.1,77777,9,999999999,100,0.0900,0,88,999.000,999.0,99.0
+1978,10,24,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-1.7,89,100000,0,0,247,0,0,0,0,0,0,0,230,2.1,0,0,24.1,77777,9,999999999,100,0.0900,0,88,999.000,999.0,99.0
+1978,10,24,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-1.1,89,100000,0,0,250,0,0,0,0,0,0,0,210,2.1,0,0,24.1,77777,9,999999999,100,0.0900,0,88,999.000,999.0,99.0
+1978,10,24,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-2.2,89,99900,0,0,244,0,0,0,0,0,0,0,210,2.6,0,0,24.1,77777,9,999999999,89,0.0900,0,88,999.000,999.0,99.0
+1978,10,24,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-1.1,89,99900,0,0,250,0,0,0,0,0,0,0,190,3.1,0,0,24.1,77777,9,999999999,100,0.0900,0,88,999.000,999.0,99.0
+1978,10,24,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.1,85,99800,0,0,251,0,0,0,0,0,0,0,210,3.1,0,0,24.1,77777,9,999999999,100,0.0900,0,88,999.000,999.0,99.0
+1978,10,24,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.1,85,99800,0,0,251,0,0,0,0,0,0,0,270,3.6,0,0,24.1,77777,9,999999999,100,0.0900,0,88,999.000,999.0,99.0
+1978,10,24,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,0.0,85,99700,64,1025,256,34,148,20,3200,6000,2800,350,200,4.1,1,0,11.3,77777,9,999999999,110,0.0750,0,88,999.000,999.0,99.0
+1978,10,24,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,2.2,82,99600,292,1382,269,165,540,46,16700,42600,7600,860,210,6.2,2,0,16.1,77777,9,999999999,120,0.0750,0,88,999.000,999.0,99.0
+1978,10,24,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,2.2,71,99500,503,1382,278,336,724,66,34200,67400,9600,1320,200,8.2,2,0,24.1,77777,9,999999999,120,0.0750,0,88,999.000,999.0,99.0
+1978,10,24,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,2.2,66,99400,667,1382,288,445,726,87,45700,70800,11400,1810,230,9.3,3,1,24.1,77777,9,999999999,120,0.0750,0,88,999.000,999.0,99.0
+1978,10,24,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,2.2,57,99400,773,1382,297,539,770,101,55700,76200,12900,2220,210,8.2,3,1,24.1,77777,9,999999999,120,0.0750,0,88,999.000,999.0,99.0
+1978,10,24,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,2.2,55,99200,814,1382,299,562,750,113,57800,74300,13900,2490,210,8.2,5,1,24.1,77777,9,999999999,120,0.0750,0,88,999.000,999.0,99.0
+1978,10,24,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,2.2,49,99000,786,1382,301,580,827,103,60100,82000,13300,2280,190,8.2,4,0,24.1,77777,9,999999999,120,0.0750,0,88,999.000,999.0,99.0
+1978,10,24,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,1.7,47,98900,692,1382,300,496,821,78,51900,80900,11300,1740,180,9.3,1,0,24.1,77777,9,999999999,120,0.0750,0,88,999.000,999.0,99.0
+1978,10,24,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,1.7,45,98900,538,1382,302,363,760,62,37700,72100,9600,1310,220,10.3,0,0,24.1,77777,9,999999999,120,0.0750,0,88,999.000,999.0,99.0
+1978,10,24,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,1.7,47,98800,335,1382,300,197,608,46,19900,51200,7400,890,210,7.2,0,0,24.1,77777,9,999999999,120,0.0750,0,88,999.000,999.0,99.0
+1978,10,24,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,1.7,53,98700,101,1279,293,48,239,24,4400,12200,3400,420,210,6.2,0,0,24.1,77777,9,999999999,120,0.0750,0,88,999.000,999.0,99.0
+1978,10,24,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,1.7,54,98600,0,0,291,0,0,0,0,0,0,0,200,5.2,0,0,24.1,77777,9,999999999,120,0.0750,0,88,999.000,999.0,99.0
+1978,10,24,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,1.7,54,98500,0,0,291,0,0,0,0,0,0,0,180,6.2,0,0,24.1,77777,9,999999999,120,0.0750,0,88,999.000,999.0,99.0
+1978,10,24,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,1.1,54,98400,0,0,288,0,0,0,0,0,0,0,210,7.2,0,0,24.1,77777,9,999999999,110,0.0750,0,88,999.000,999.0,99.0
+1978,10,24,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,0.6,52,98400,0,0,287,0,0,0,0,0,0,0,200,5.7,0,0,24.1,77777,9,999999999,110,0.0750,0,88,999.000,999.0,99.0
+1978,10,24,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,0.6,52,98300,0,0,287,0,0,0,0,0,0,0,210,7.7,0,0,24.1,77777,9,999999999,110,0.0750,0,88,999.000,999.0,99.0
+1978,10,24,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,1.1,59,98300,0,0,283,0,0,0,0,0,0,0,190,5.7,0,0,24.1,77777,9,999999999,110,0.0750,0,88,999.000,999.0,99.0
+1978,10,24,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,1.1,61,98300,0,0,281,0,0,0,0,0,0,0,190,7.7,0,0,24.1,77777,9,999999999,110,0.0750,0,88,999.000,999.0,99.0
+1978,10,25,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,1.7,61,98200,0,0,312,0,0,0,0,0,0,0,200,7.2,8,8,24.1,3050,9,999999999,120,0.0750,0,88,999.000,999.0,99.0
+1978,10,25,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,1.7,59,98100,0,0,330,0,0,0,0,0,0,0,190,7.7,10,10,24.1,3050,9,999999999,120,0.0750,0,88,999.000,999.0,99.0
+1978,10,25,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,2.2,59,98000,0,0,334,0,0,0,0,0,0,0,200,7.7,10,10,24.1,3050,9,999999999,120,0.0750,0,88,999.000,999.0,99.0
+1978,10,25,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,2.8,59,97900,0,0,337,0,0,0,0,0,0,0,190,9.3,10,10,24.1,3050,9,999999999,129,0.0750,0,88,999.000,999.0,99.0
+1978,10,25,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,3.9,61,97900,0,0,341,0,0,0,0,0,0,0,190,8.2,10,10,24.1,3050,9,999999999,129,0.0750,0,88,999.000,999.0,99.0
+1978,10,25,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,6.1,77,97900,0,0,338,0,0,0,0,0,0,0,190,8.2,10,10,11.3,1400,9,999999999,150,0.0750,0,88,999.000,999.0,99.0
+1978,10,25,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,7.8,89,97900,60,980,337,10,1,10,1200,0,1200,380,200,7.2,10,10,2.4,210,9,999999999,170,0.1220,0,88,999.000,999.0,99.0
+1978,10,25,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,8.3,93,97900,287,1383,338,42,15,38,4500,1200,4300,1060,190,7.2,10,10,3.2,210,9,999999999,170,0.1220,0,88,999.000,999.0,99.0
+1978,10,25,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,8.9,93,97800,497,1383,341,84,3,83,9900,200,9800,3490,190,6.7,10,10,3.2,150,9,999999999,179,0.1220,0,88,999.000,999.0,99.0
+1978,10,25,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,9.4,93,97800,661,1383,345,104,10,100,12500,700,12200,4560,190,9.8,10,10,4.0,150,9,999999999,189,0.1220,0,88,999.000,999.0,99.0
+1978,10,25,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,10.6,93,97800,767,1383,352,134,7,130,16000,500,15700,6030,200,7.2,10,10,4.0,180,9,999999999,200,0.1220,0,88,999.000,999.0,99.0
+1978,10,25,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,11.7,90,97700,808,1383,361,168,8,163,19800,600,19400,7420,200,7.7,10,10,4.0,180,9,999999999,209,0.1220,0,88,999.000,999.0,99.0
+1978,10,25,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,12.8,93,97700,780,1383,365,218,4,216,25100,300,24900,9000,210,5.7,10,10,4.0,180,9,999999999,229,0.1220,0,88,999.000,999.0,99.0
+1978,10,25,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,13.3,90,97700,686,1383,371,246,4,244,27500,400,27300,8920,230,7.7,10,10,4.0,310,9,999999999,229,0.1220,0,88,999.000,999.0,99.0
+1978,10,25,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,13.3,87,97700,532,1383,374,148,1,148,16700,100,16700,5560,190,5.7,10,10,6.4,580,9,999999999,229,0.1220,0,88,999.000,999.0,99.0
+1978,10,25,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,13.3,87,97700,329,1383,374,87,1,87,9700,0,9700,3020,210,5.2,10,10,6.4,460,9,999999999,229,0.1220,0,88,999.000,999.0,99.0
+1978,10,25,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,13.9,87,97700,95,1233,378,25,0,25,2800,0,2800,840,210,7.2,10,10,6.4,580,9,999999999,240,0.1220,0,88,999.000,999.0,99.0
+1978,10,25,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,12.8,87,97900,0,0,371,0,0,0,0,0,0,0,270,3.6,10,10,9.7,1010,9,999999999,229,0.1220,0,88,999.000,999.0,99.0
+1978,10,25,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,12.2,93,97900,0,0,361,0,0,0,0,0,0,0,280,3.6,10,10,8.0,460,9,999999999,220,0.1220,0,88,999.000,999.0,99.0
+1978,10,25,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,11.1,93,97900,0,0,355,0,0,0,0,0,0,0,300,3.6,10,10,6.4,460,9,999999999,200,0.1220,0,88,999.000,999.0,99.0
+1978,10,25,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,10.0,93,98100,0,0,348,0,0,0,0,0,0,0,330,9.3,10,10,9.7,460,9,999999999,189,0.1220,0,88,999.000,999.0,99.0
+1978,10,25,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,7.8,86,98200,0,0,340,0,0,0,0,0,0,0,330,4.1,10,10,12.9,580,9,999999999,170,0.1220,0,88,999.000,999.0,99.0
+1978,10,25,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,7.2,83,98300,0,0,339,0,0,0,0,0,0,0,300,3.6,10,10,12.9,700,9,999999999,160,0.1220,0,88,999.000,999.0,99.0
+1978,10,25,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,5.6,77,98300,0,0,335,0,0,0,0,0,0,0,320,5.7,10,10,24.1,760,9,999999999,150,0.1220,0,88,999.000,999.0,99.0
+1978,10,26,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,3.9,71,98400,0,0,330,0,0,0,0,0,0,0,310,5.2,10,10,24.1,760,9,999999999,129,0.1220,0,88,999.000,999.0,99.0
+1978,10,26,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,3.9,77,98500,0,0,325,0,0,0,0,0,0,0,310,5.2,10,10,24.1,760,9,999999999,129,0.1220,0,88,999.000,999.0,99.0
+1978,10,26,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,2.2,71,98500,0,0,321,0,0,0,0,0,0,0,320,5.7,10,10,24.1,820,9,999999999,120,0.1220,0,88,999.000,999.0,99.0
+1978,10,26,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,2.2,71,98500,0,0,321,0,0,0,0,0,0,0,300,4.1,10,10,24.1,880,9,999999999,120,0.1220,0,88,999.000,999.0,99.0
+1978,10,26,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,1.7,71,98600,0,0,318,0,0,0,0,0,0,0,300,4.1,10,10,24.1,880,9,999999999,120,0.1220,0,88,999.000,999.0,99.0
+1978,10,26,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,1.1,68,98700,0,0,317,0,0,0,0,0,0,0,300,3.1,10,10,24.1,880,9,999999999,110,0.1220,0,88,999.000,999.0,99.0
+1978,10,26,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,0.0,68,98800,56,957,302,13,3,13,1500,0,1500,470,300,3.6,10,9,24.1,880,9,999999999,110,0.1130,0,88,999.000,999.0,99.0
+1978,10,26,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,0.6,68,98900,282,1384,305,70,35,63,7700,2900,7100,1630,290,5.2,10,9,24.1,1010,9,999999999,110,0.1130,0,88,999.000,999.0,99.0
+1978,10,26,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,0.6,63,98900,492,1384,303,186,179,121,19800,17100,13700,2410,300,5.2,8,8,24.1,1010,9,999999999,110,0.1130,0,88,999.000,999.0,99.0
+1978,10,26,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,0.6,54,98900,655,1384,300,401,526,146,42200,52300,17300,2990,290,6.2,4,4,24.1,77777,9,999999999,110,0.1130,0,88,999.000,999.0,99.0
+1978,10,26,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,-0.6,45,98900,761,1384,300,528,719,126,55100,71800,15400,2830,310,6.7,2,2,24.1,77777,9,999999999,100,0.1130,0,88,999.000,999.0,99.0
+1978,10,26,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,-0.6,46,98900,801,1384,298,530,664,139,55200,66500,16500,3210,300,7.7,2,2,24.1,77777,9,999999999,100,0.1130,0,88,999.000,999.0,99.0
+1978,10,26,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,0.0,43,98900,773,1384,311,513,617,163,52700,61000,18500,3550,300,5.7,4,4,24.1,77777,9,999999999,110,0.1130,0,88,999.000,999.0,99.0
+1978,10,26,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,0.0,43,98900,679,1384,311,388,449,164,40700,44900,18600,3430,280,6.7,4,4,24.1,77777,9,999999999,110,0.1130,0,88,999.000,999.0,99.0
+1978,10,26,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,0.0,43,98900,525,1384,311,271,351,135,28000,33200,15400,2640,250,7.2,4,4,24.1,77777,9,999999999,110,0.1130,0,88,999.000,999.0,99.0
+1978,10,26,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,0.0,47,98900,322,1384,311,129,164,90,13500,13300,10400,1760,260,5.2,6,6,24.1,1220,9,999999999,110,0.1130,0,88,999.000,999.0,99.0
+1978,10,26,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,0.6,54,99000,90,1211,305,36,44,32,3800,2100,3700,660,260,3.1,6,6,24.1,1160,9,999999999,110,0.1130,0,88,999.000,999.0,99.0
+1978,10,26,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,1.7,66,99000,0,0,296,0,0,0,0,0,0,0,230,2.6,5,5,24.1,77777,9,999999999,120,0.1130,0,88,999.000,999.0,99.0
+1978,10,26,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,1.7,71,99100,0,0,275,0,0,0,0,0,0,0,220,3.1,0,0,24.1,77777,9,999999999,120,0.1130,0,88,999.000,999.0,99.0
+1978,10,26,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,1.7,71,99100,0,0,281,0,0,0,0,0,0,0,220,3.6,1,1,24.1,77777,9,999999999,120,0.1130,0,88,999.000,999.0,99.0
+1978,10,26,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,1.7,73,99100,0,0,273,0,0,0,0,0,0,0,210,4.1,0,0,24.1,77777,9,999999999,120,0.1130,0,88,999.000,999.0,99.0
+1978,10,26,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,1.7,76,99100,0,0,271,0,0,0,0,0,0,0,220,3.1,0,0,24.1,77777,9,999999999,120,0.1130,0,88,999.000,999.0,99.0
+1978,10,26,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,1.7,73,99100,0,0,278,0,0,0,0,0,0,0,210,4.1,1,1,24.1,77777,9,999999999,120,0.1130,0,88,999.000,999.0,99.0
+1978,10,26,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,1.7,66,99100,0,0,323,0,0,0,0,0,0,0,210,5.7,10,10,24.1,1830,9,999999999,120,0.1130,0,88,999.000,999.0,99.0
+1978,10,27,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,1.7,66,99100,0,0,323,0,0,0,0,0,0,0,200,6.2,10,10,24.1,1830,9,999999999,120,0.1130,0,88,999.000,999.0,99.0
+1978,10,27,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,1.7,68,99000,0,0,283,0,0,0,0,0,0,0,210,6.2,1,1,24.1,77777,9,999999999,120,0.1130,0,88,999.000,999.0,99.0
+1978,10,27,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,1.7,71,99000,0,0,275,0,0,0,0,0,0,0,210,5.7,0,0,24.1,77777,9,999999999,120,0.1130,0,88,999.000,999.0,99.0
+1978,10,27,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,1.7,73,99100,0,0,273,0,0,0,0,0,0,0,230,6.2,0,0,24.1,77777,9,999999999,120,0.1130,0,88,999.000,999.0,99.0
+1978,10,27,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,1.1,73,99100,0,0,270,0,0,0,0,0,0,0,230,5.2,0,0,24.1,77777,9,999999999,110,0.1130,0,88,999.000,999.0,99.0
+1978,10,27,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,1.1,73,99100,0,0,270,0,0,0,0,0,0,0,220,4.1,0,0,24.1,77777,9,999999999,110,0.1130,0,88,999.000,999.0,99.0
+1978,10,27,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,1.1,79,99100,53,935,266,33,178,16,2800,8000,2300,290,220,3.6,0,0,19.3,77777,9,999999999,110,0.0500,0,88,999.000,999.0,99.0
+1978,10,27,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,2.2,74,99100,276,1385,276,162,617,34,16300,49300,6500,700,210,5.2,0,0,24.1,77777,9,999999999,120,0.0500,0,88,999.000,999.0,99.0
+1978,10,27,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,2.8,63,99100,486,1385,287,328,778,48,34000,72200,8500,1120,220,4.1,0,0,24.1,77777,9,999999999,129,0.0500,0,88,999.000,999.0,99.0
+1978,10,27,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,3.9,61,99100,650,1385,295,468,854,59,48500,82700,9500,1410,190,5.2,0,0,24.1,77777,9,999999999,129,0.0500,0,88,999.000,999.0,99.0
+1978,10,27,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,4.4,51,99100,755,1385,310,559,889,66,57900,87400,10100,1610,200,6.2,0,0,24.1,77777,9,999999999,139,0.0500,0,88,999.000,999.0,99.0
+1978,10,27,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,4.4,48,99000,795,1385,315,592,893,71,61300,88100,10500,1720,190,5.2,1,0,24.1,77777,9,999999999,139,0.0500,0,88,999.000,999.0,99.0
+1978,10,27,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,5.0,48,99000,767,1385,318,569,888,69,58900,87400,10400,1660,210,6.2,1,0,24.1,77777,9,999999999,139,0.0500,0,88,999.000,999.0,99.0
+1978,10,27,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,5.0,46,98900,673,1385,320,488,865,60,50600,84100,9600,1440,200,6.2,0,0,24.1,77777,9,999999999,139,0.0500,0,88,999.000,999.0,99.0
+1978,10,27,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,5.0,45,98900,519,1385,323,355,800,50,37000,75100,8700,1170,210,6.2,0,0,24.1,77777,9,999999999,139,0.0500,0,88,999.000,999.0,99.0
+1978,10,27,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,5.0,48,98900,316,1385,318,190,655,36,19500,54700,6900,760,220,7.2,0,0,24.1,77777,9,999999999,139,0.0500,0,88,999.000,999.0,99.0
+1978,10,27,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,3.9,51,99000,85,1188,307,46,273,19,4100,13600,3100,340,230,4.1,0,0,24.1,77777,9,999999999,129,0.0500,0,88,999.000,999.0,99.0
+1978,10,27,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,4.4,62,99000,0,0,298,0,0,0,0,0,0,0,230,3.6,0,0,24.1,77777,9,999999999,139,0.0500,0,88,999.000,999.0,99.0
+1978,10,27,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,4.4,64,99100,0,0,296,0,0,0,0,0,0,0,260,3.6,0,0,24.1,77777,9,999999999,139,0.0500,0,88,999.000,999.0,99.0
+1978,10,27,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,3.9,71,99200,0,0,286,0,0,0,0,0,0,0,270,4.1,0,0,24.1,77777,9,999999999,129,0.0500,0,88,999.000,999.0,99.0
+1978,10,27,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,3.3,74,99300,0,0,281,0,0,0,0,0,0,0,300,3.1,0,0,24.1,77777,9,999999999,129,0.0500,0,88,999.000,999.0,99.0
+1978,10,27,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,1.7,68,99300,0,0,277,0,0,0,0,0,0,0,290,3.1,0,0,24.1,77777,9,999999999,120,0.0500,0,88,999.000,999.0,99.0
+1978,10,27,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,0.6,73,99400,0,0,268,0,0,0,0,0,0,0,310,3.1,0,0,24.1,77777,9,999999999,110,0.0500,0,88,999.000,999.0,99.0
+1978,10,27,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,0.6,76,99500,0,0,265,0,0,0,0,0,0,0,290,3.6,0,0,24.1,77777,9,999999999,110,0.0500,0,88,999.000,999.0,99.0
+1978,10,28,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,0.0,76,99500,0,0,263,0,0,0,0,0,0,0,290,3.1,0,0,24.1,77777,9,999999999,110,0.0500,0,88,999.000,999.0,99.0
+1978,10,28,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-0.6,76,99600,0,0,260,0,0,0,0,0,0,0,310,3.1,0,0,24.1,77777,9,999999999,100,0.0500,0,88,999.000,999.0,99.0
+1978,10,28,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-0.6,79,99600,0,0,258,0,0,0,0,0,0,0,300,3.1,0,0,24.1,77777,9,999999999,100,0.0500,0,88,999.000,999.0,99.0
+1978,10,28,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-0.6,79,99700,0,0,258,0,0,0,0,0,0,0,310,3.1,0,0,24.1,77777,9,999999999,100,0.0500,0,88,999.000,999.0,99.0
+1978,10,28,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,0.0,76,99800,0,0,268,0,0,0,0,0,0,0,330,6.2,1,1,24.1,77777,9,999999999,110,0.0500,0,88,999.000,999.0,99.0
+1978,10,28,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,0.0,79,99900,0,0,266,0,0,0,0,0,0,0,340,4.6,1,1,24.1,77777,9,999999999,110,0.0500,0,88,999.000,999.0,99.0
+1978,10,28,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,0.6,76,99900,50,912,274,30,91,21,2800,2900,2600,370,350,4.6,6,2,24.1,77777,9,999999999,110,0.0500,0,88,999.000,999.0,99.0
+1978,10,28,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,1.7,76,100000,271,1385,287,103,211,60,10600,15700,7500,1080,350,5.2,6,5,24.1,3660,9,999999999,120,0.0500,0,88,999.000,999.0,99.0
+1978,10,28,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,2.8,68,100100,480,1385,292,303,670,65,30700,61700,9300,1270,350,5.7,3,2,24.1,77777,9,999999999,129,0.0500,0,88,999.000,999.0,99.0
+1978,10,28,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,3.3,61,100200,644,1385,298,378,590,98,39300,57800,12400,2060,360,3.6,1,1,24.1,77777,9,999999999,129,0.0500,0,88,999.000,999.0,99.0
+1978,10,28,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,2.2,49,100200,749,1385,306,526,842,63,54600,82700,9700,1570,350,4.6,1,1,24.1,77777,9,999999999,120,0.0500,0,88,999.000,999.0,99.0
+1978,10,28,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,1.1,44,100200,789,1385,315,512,612,158,52800,60800,18100,3520,350,4.6,3,3,24.1,77777,9,999999999,120,0.0500,0,88,999.000,999.0,99.0
+1978,10,28,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,-1.7,36,100200,761,1385,312,483,639,126,50400,63800,15200,2830,20,5.2,3,3,24.1,77777,9,999999999,100,0.0500,0,88,999.000,999.0,99.0
+1978,10,28,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,-0.6,40,100200,667,1385,308,432,660,109,44900,64800,13600,2290,30,5.7,3,2,24.1,77777,9,999999999,100,0.0500,0,88,999.000,999.0,99.0
+1978,10,28,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,0.6,47,100200,513,1385,300,328,703,63,33800,65900,9300,1290,70,5.2,1,1,24.1,77777,9,999999999,110,0.0500,0,88,999.000,999.0,99.0
+1978,10,28,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,2.8,59,100200,310,1385,298,170,559,42,17200,46000,6900,820,40,4.6,1,1,24.1,77777,9,999999999,129,0.0500,0,88,999.000,999.0,99.0
+1978,10,28,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,3.3,68,100200,80,1143,286,43,254,18,3800,12500,2900,330,70,4.6,0,0,24.1,77777,9,999999999,129,0.0500,0,88,999.000,999.0,99.0
+1978,10,28,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,3.3,71,100300,0,0,283,0,0,0,0,0,0,0,50,2.6,0,0,24.1,77777,9,999999999,129,0.0500,0,88,999.000,999.0,99.0
+1978,10,28,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,2.8,71,100300,0,0,281,0,0,0,0,0,0,0,70,4.1,0,0,24.1,77777,9,999999999,129,0.0500,0,88,999.000,999.0,99.0
+1978,10,28,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,2.2,68,100300,0,0,280,0,0,0,0,0,0,0,80,4.1,0,0,24.1,77777,9,999999999,120,0.0500,0,88,999.000,999.0,99.0
+1978,10,28,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,2.2,68,100400,0,0,280,0,0,0,0,0,0,0,90,4.1,0,0,24.1,77777,9,999999999,120,0.0500,0,88,999.000,999.0,99.0
+1978,10,28,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,1.7,68,100400,0,0,277,0,0,0,0,0,0,0,70,3.1,0,0,24.1,77777,9,999999999,120,0.0500,0,88,999.000,999.0,99.0
+1978,10,28,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,1.1,79,100400,0,0,266,0,0,0,0,0,0,0,50,3.1,0,0,24.1,77777,9,999999999,110,0.0500,0,88,999.000,999.0,99.0
+1978,10,28,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,1.7,79,100400,0,0,269,0,0,0,0,0,0,0,40,3.1,0,0,24.1,77777,9,999999999,120,0.0500,0,88,999.000,999.0,99.0
+1978,10,29,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,2.2,79,100400,0,0,288,0,0,0,0,0,0,0,40,3.1,7,5,24.1,7620,9,999999999,120,0.0500,0,88,999.000,999.0,99.0
+1978,10,29,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,2.8,74,100400,0,0,312,0,0,0,0,0,0,0,100,3.1,10,9,24.1,3660,9,999999999,129,0.0500,0,88,999.000,999.0,99.0
+1978,10,29,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,2.8,71,100500,0,0,324,0,0,0,0,0,0,0,100,3.1,10,10,24.1,6100,9,999999999,129,0.0500,0,88,999.000,999.0,99.0
+1978,10,29,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,2.2,76,100500,0,0,285,0,0,0,0,0,0,0,120,3.1,6,3,24.1,77777,9,999999999,120,0.0500,0,88,999.000,999.0,99.0
+1978,10,29,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,2.2,74,100500,0,0,276,0,0,0,0,0,0,0,100,3.6,0,0,24.1,77777,9,999999999,120,0.0500,0,88,999.000,999.0,99.0
+1978,10,29,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,1.7,68,100500,0,0,289,0,0,0,0,0,0,0,90,4.1,4,3,24.1,77777,9,999999999,120,0.0500,0,88,999.000,999.0,99.0
+1978,10,29,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,2.2,74,100600,47,889,298,14,10,14,1600,500,1600,350,120,3.6,7,7,24.1,2740,9,999999999,120,0.1370,0,88,999.000,999.0,99.0
+1978,10,29,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,3.3,71,100700,265,1386,311,80,79,65,8800,6100,7600,1390,120,3.1,8,8,24.1,2740,9,999999999,129,0.1370,0,88,999.000,999.0,99.0
+1978,10,29,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,2.8,66,100600,475,1386,329,85,7,82,9800,400,9700,3390,140,3.6,10,10,11.3,2740,9,999999999,129,0.1370,0,88,999.000,999.0,99.0
+1978,10,29,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,1.1,50,100600,638,1386,328,208,59,180,22800,5800,20100,5320,140,4.6,9,9,9.7,2740,9,999999999,110,0.1370,0,88,999.000,999.0,99.0
+1978,10,29,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,-1.7,38,100500,743,1386,312,491,560,185,51400,56600,20900,4060,150,4.6,5,5,24.1,77777,9,999999999,100,0.1370,0,88,999.000,999.0,99.0
+1978,10,29,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,-0.6,39,100500,783,1386,320,440,421,198,46200,42900,21900,4490,140,5.2,6,6,24.1,2740,9,999999999,110,0.1370,0,88,999.000,999.0,99.0
+1978,10,29,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,-0.6,37,100400,755,1386,315,566,754,149,58300,74500,17600,3230,130,3.1,3,3,24.1,77777,9,999999999,100,0.1370,0,88,999.000,999.0,99.0
+1978,10,29,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,0.0,37,100300,660,1386,311,429,663,107,44500,65000,13400,2240,170,5.7,1,1,24.1,77777,9,999999999,110,0.1370,0,88,999.000,999.0,99.0
+1978,10,29,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,1.1,41,100200,507,1386,306,318,629,83,32700,58600,11200,1620,170,4.6,0,0,24.1,77777,9,999999999,120,0.1370,0,88,999.000,999.0,99.0
+1978,10,29,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,0.0,39,100200,304,1386,303,158,439,59,15900,34700,8300,1060,140,4.6,0,0,24.1,77777,9,999999999,110,0.1370,0,88,999.000,999.0,99.0
+1978,10,29,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,-0.6,45,100200,76,1120,291,32,84,24,3200,3100,3000,430,150,4.1,0,0,24.1,77777,9,999999999,110,0.1370,0,88,999.000,999.0,99.0
+1978,10,29,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,-0.6,50,100200,0,0,284,0,0,0,0,0,0,0,150,3.6,0,0,24.1,77777,9,999999999,100,0.1370,0,88,999.000,999.0,99.0
+1978,10,29,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,-0.6,54,100200,0,0,279,0,0,0,0,0,0,0,140,4.1,0,0,24.1,77777,9,999999999,100,0.1370,0,88,999.000,999.0,99.0
+1978,10,29,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,-0.6,56,100200,0,0,277,0,0,0,0,0,0,0,130,5.7,0,0,24.1,77777,9,999999999,100,0.1370,0,88,999.000,999.0,99.0
+1978,10,29,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,-0.6,54,100200,0,0,279,0,0,0,0,0,0,0,150,4.6,0,0,24.1,77777,9,999999999,100,0.1370,0,88,999.000,999.0,99.0
+1978,10,29,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,-0.6,50,100200,0,0,284,0,0,0,0,0,0,0,150,5.7,0,0,24.1,77777,9,999999999,100,0.1370,0,88,999.000,999.0,99.0
+1978,10,29,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,-0.6,54,100200,0,0,279,0,0,0,0,0,0,0,160,5.2,0,0,24.1,77777,9,999999999,100,0.1370,0,88,999.000,999.0,99.0
+1978,10,29,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,-0.6,58,100200,0,0,275,0,0,0,0,0,0,0,150,4.1,0,0,24.1,77777,9,999999999,100,0.1370,0,88,999.000,999.0,99.0
+1978,10,30,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,-1.1,56,100200,0,0,275,0,0,0,0,0,0,0,180,3.6,0,0,24.1,77777,9,999999999,100,0.1370,0,88,999.000,999.0,99.0
+1978,10,30,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,-1.1,56,100200,0,0,275,0,0,0,0,0,0,0,180,5.2,0,0,24.1,77777,9,999999999,100,0.1370,0,88,999.000,999.0,99.0
+1978,10,30,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,-1.1,56,100200,0,0,275,0,0,0,0,0,0,0,180,5.2,0,0,24.1,77777,9,999999999,100,0.1370,0,88,999.000,999.0,99.0
+1978,10,30,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,-1.7,56,100200,0,0,272,0,0,0,0,0,0,0,170,5.2,0,0,24.1,77777,9,999999999,100,0.1370,0,88,999.000,999.0,99.0
+1978,10,30,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,-1.1,58,100200,0,0,273,0,0,0,0,0,0,0,170,5.2,0,0,24.1,77777,9,999999999,100,0.1370,0,88,999.000,999.0,99.0
+1978,10,30,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,-1.1,63,100200,0,0,268,0,0,0,0,0,0,0,170,4.1,0,0,24.1,77777,9,999999999,100,0.1370,0,88,999.000,999.0,99.0
+1978,10,30,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,-1.1,65,100200,43,844,266,24,79,17,2300,2900,2100,300,180,3.1,0,0,24.1,77777,9,999999999,100,0.0980,0,88,999.000,999.0,99.0
+1978,10,30,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,0.0,54,100300,260,1387,282,137,468,46,13800,35000,7200,830,180,4.1,0,0,24.1,77777,9,999999999,110,0.0980,0,88,999.000,999.0,99.0
+1978,10,30,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,1.7,51,100200,469,1387,296,299,672,66,31000,61900,10000,1300,190,6.7,0,0,24.1,77777,9,999999999,120,0.0980,0,88,999.000,999.0,99.0
+1978,10,30,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,3.3,49,100200,632,1387,306,438,767,82,45000,74200,11100,1690,200,6.7,0,0,24.1,77777,9,999999999,129,0.0980,0,88,999.000,999.0,99.0
+1978,10,30,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,4.4,46,100200,737,1387,317,532,815,92,55200,80400,12300,2010,190,5.7,0,0,24.1,77777,9,999999999,139,0.0980,0,88,999.000,999.0,99.0
+1978,10,30,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,5.6,45,100100,777,1387,326,565,826,95,58800,82000,12700,2140,200,6.7,0,0,24.1,77777,9,999999999,150,0.0980,0,88,999.000,999.0,99.0
+1978,10,30,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,5.6,40,100100,748,1387,333,541,818,92,56200,80900,12400,2040,200,7.7,0,0,24.1,77777,9,999999999,150,0.0980,0,88,999.000,999.0,99.0
+1978,10,30,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,5.6,39,100000,654,1387,336,456,777,84,47100,75500,11300,1750,190,5.2,0,0,24.1,77777,9,999999999,150,0.0980,0,88,999.000,999.0,99.0
+1978,10,30,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,4.4,35,100000,500,1387,337,324,693,69,32900,64300,9600,1340,200,5.7,0,0,24.1,77777,9,999999999,139,0.0980,0,88,999.000,999.0,99.0
+1978,10,30,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,3.3,35,100000,298,1387,331,162,513,49,16500,40600,7800,910,220,3.6,0,0,24.1,77777,9,999999999,129,0.0980,0,88,999.000,999.0,99.0
+1978,10,30,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,3.3,44,100100,71,1098,314,35,130,22,3300,5400,2900,390,210,2.6,0,0,24.1,77777,9,999999999,129,0.0980,0,88,999.000,999.0,99.0
+1978,10,30,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,3.3,49,100100,0,0,306,0,0,0,0,0,0,0,200,3.1,0,0,24.1,77777,9,999999999,129,0.0980,0,88,999.000,999.0,99.0
+1978,10,30,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,3.9,59,100100,0,0,298,0,0,0,0,0,0,0,180,2.6,0,0,24.1,77777,9,999999999,139,0.0980,0,88,999.000,999.0,99.0
+1978,10,30,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,3.9,61,100100,0,0,295,0,0,0,0,0,0,0,180,4.1,0,0,24.1,77777,9,999999999,139,0.0980,0,88,999.000,999.0,99.0
+1978,10,30,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,4.4,64,100100,0,0,296,0,0,0,0,0,0,0,180,3.6,0,0,24.1,77777,9,999999999,139,0.0980,0,88,999.000,999.0,99.0
+1978,10,30,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,5.0,69,100100,0,0,294,0,0,0,0,0,0,0,290,3.1,0,0,24.1,77777,9,999999999,150,0.0980,0,88,999.000,999.0,99.0
+1978,10,30,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,3.9,80,100200,0,0,279,0,0,0,0,0,0,0,230,3.1,0,0,19.3,77777,9,999999999,139,0.0980,0,88,999.000,999.0,99.0
+1978,10,30,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,4.4,77,100200,0,0,284,0,0,0,0,0,0,0,250,2.6,0,0,19.3,77777,9,999999999,139,0.0980,0,88,999.000,999.0,99.0
+1978,10,31,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,3.9,80,100200,0,0,279,0,0,0,0,0,0,0,190,1.5,0,0,24.1,77777,9,999999999,139,0.0980,0,88,999.000,999.0,99.0
+1978,10,31,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,4.4,83,100200,0,0,280,0,0,0,0,0,0,0,180,1.5,0,0,19.3,77777,9,999999999,139,0.0980,0,88,999.000,999.0,99.0
+1978,10,31,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,2.2,86,100200,0,0,267,0,0,0,0,0,0,0,300,1.5,0,0,16.1,77777,9,999999999,120,0.0980,0,88,999.000,999.0,99.0
+1978,10,31,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,2.2,89,100200,0,0,265,0,0,0,0,0,0,0,270,2.1,0,0,14.5,77777,9,999999999,120,0.0980,0,88,999.000,999.0,99.0
+1978,10,31,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,3.9,80,100300,0,0,279,0,0,0,0,0,0,0,350,4.6,0,0,14.5,77777,9,999999999,139,0.0980,0,88,999.000,999.0,99.0
+1978,10,31,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,4.4,80,100300,0,0,295,0,0,0,0,0,0,0,10,4.6,3,3,14.5,77777,9,999999999,139,0.0980,0,88,999.000,999.0,99.0
+1978,10,31,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,6.7,83,100300,41,821,311,22,13,20,2300,700,2200,470,20,6.2,6,6,24.1,2740,9,999999999,160,0.1260,0,88,999.000,999.0,99.0
+1978,10,31,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,6.7,77,100400,254,1388,309,104,249,57,10800,18000,7500,1030,30,7.2,4,3,24.1,77777,9,999999999,160,0.1260,0,88,999.000,999.0,99.0
+1978,10,31,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,6.1,69,100400,463,1388,313,220,375,92,23200,34400,11700,1710,30,7.2,4,3,24.1,77777,9,999999999,160,0.1260,0,88,999.000,999.0,99.0
+1978,10,31,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,6.7,64,100400,626,1388,323,276,259,157,29600,26400,17700,3320,20,7.7,5,4,24.1,77777,9,999999999,160,0.1260,0,88,999.000,999.0,99.0
+1978,10,31,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,6.7,67,100500,731,1388,352,164,13,157,19100,1000,18600,6860,20,8.2,10,10,24.1,460,9,999999999,160,0.1260,0,88,999.000,999.0,99.0
+1978,10,31,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,6.7,69,100400,770,1388,340,254,8,250,28800,700,28400,9810,30,7.2,10,9,24.1,2440,9,999999999,160,0.1260,0,88,999.000,999.0,99.0
+1978,10,31,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,6.7,67,100300,742,1388,330,371,341,186,40100,35800,20900,4200,30,6.7,8,7,24.1,2440,9,999999999,160,0.1260,0,88,999.000,999.0,99.0
+1978,10,31,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,6.1,67,100300,648,1388,315,392,541,136,41700,53700,16500,2750,30,6.7,4,3,24.1,77777,9,999999999,160,0.1260,0,88,999.000,999.0,99.0
+1978,10,31,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,4.4,59,100300,494,1388,316,257,351,129,26500,32700,14800,2500,30,6.7,4,4,24.1,77777,9,999999999,139,0.1260,0,88,999.000,999.0,99.0
+1978,10,31,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,3.9,64,100300,292,1388,306,123,170,86,12800,13100,10000,1690,30,5.7,3,3,24.1,77777,9,999999999,139,0.1260,0,88,999.000,999.0,99.0
+1978,10,31,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,3.3,71,100400,67,1052,296,22,42,18,2300,1500,2200,310,40,5.7,4,3,24.1,77777,9,999999999,129,0.1260,0,88,999.000,999.0,99.0
+1978,10,31,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,3.3,80,100400,0,0,286,0,0,0,0,0,0,0,10,3.6,3,2,24.1,77777,9,999999999,129,0.1260,0,88,999.000,999.0,99.0
+1978,10,31,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,2.2,86,100300,0,0,276,0,0,0,0,0,0,0,330,2.6,2,2,24.1,77777,9,999999999,120,0.1260,0,88,999.000,999.0,99.0
+1978,10,31,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,1.1,89,100300,0,0,260,0,0,0,0,0,0,0,330,3.1,0,0,24.1,77777,9,999999999,120,0.1260,0,88,999.000,999.0,99.0
+1978,10,31,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,1.1,86,100400,0,0,262,0,0,0,0,0,0,0,330,4.1,0,0,24.1,77777,9,999999999,120,0.1260,0,88,999.000,999.0,99.0
+1978,10,31,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.1,2.9,86,100300,0,0,270,0,0,0,0,0,0,0,10,4.0,0,0,24.1,77777,9,999999999,129,0.1260,0,88,999.000,999.0,99.0
+1978,10,31,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.8,4.8,82,100300,0,0,279,0,0,0,0,0,0,0,10,3.8,0,0,24.1,77777,9,999999999,120,0.1260,0,88,999.000,999.0,99.0
+1978,10,31,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.6,6.6,89,100300,0,0,288,0,0,0,0,0,0,0,10,3.7,0,0,24.1,77777,9,999999999,120,0.1260,0,88,999.000,999.0,99.0
+1977,11,1,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.3,8.4,97,99000,0,0,333,0,0,0,0,0,0,0,200,3.5,10,9,6.4,370,9,999999999,259,0.1260,0,88,999.000,999.0,99.0
+1977,11,1,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.1,10.2,93,99000,0,0,353,0,0,0,0,0,0,0,190,3.4,10,10,6.4,430,9,999999999,259,0.1260,0,88,999.000,999.0,99.0
+1977,11,1,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.8,12.1,90,99000,0,0,364,0,0,0,0,0,0,0,190,3.2,10,10,6.4,460,9,999999999,250,0.1260,0,88,999.000,999.0,99.0
+1977,11,1,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,13.9,90,99000,0,0,375,0,0,0,0,0,0,0,170,3.1,10,10,6.4,460,9,999999999,250,0.1260,0,88,999.000,999.0,99.0
+1977,11,1,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,13.9,90,99000,0,0,375,0,0,0,0,0,0,0,170,3.1,10,10,6.4,520,9,999999999,250,0.1260,0,88,999.000,999.0,99.0
+1977,11,1,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,13.9,90,99000,0,0,375,0,0,0,0,0,0,0,170,3.6,10,10,6.4,580,9,999999999,250,0.1260,0,88,999.000,999.0,99.0
+1977,11,1,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,13.3,87,99000,37,798,374,10,0,10,1200,0,1200,370,170,6.2,10,10,3.2,700,9,999999999,240,0.0630,0,88,999.000,999.0,99.0
+1977,11,1,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,13.9,90,99000,248,1388,375,44,1,43,5000,0,5000,1610,170,7.7,10,10,6.4,640,9,999999999,250,0.0630,0,88,999.000,999.0,99.0
+1977,11,1,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,13.9,93,99000,456,1388,372,95,1,95,10900,100,10900,3750,170,7.2,10,10,4.8,640,9,999999999,240,0.0630,0,88,999.000,999.0,99.0
+1977,11,1,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,13.9,90,99000,619,1388,375,126,1,125,14600,100,14600,5310,180,7.7,10,10,4.8,370,9,999999999,250,0.0630,0,88,999.000,999.0,99.0
+1977,11,1,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,13.9,90,99000,723,1388,375,147,0,147,17200,0,17200,6480,140,7.7,10,10,2.4,340,9,999999999,250,0.0630,0,88,999.000,999.0,99.0
+1977,11,1,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,14.4,93,98900,763,1388,376,158,0,157,18400,0,18400,7000,180,7.2,10,10,2.4,180,9,999999999,250,0.0630,0,88,999.000,999.0,99.0
+1977,11,1,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,13.9,93,98900,735,1388,372,150,1,149,17500,100,17500,6600,180,7.2,10,10,3.2,240,9,999999999,240,0.0630,0,88,999.000,999.0,99.0
+1977,11,1,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,13.9,93,98900,641,1388,372,139,1,139,16200,100,16100,5860,150,7.2,10,10,4.8,210,9,999999999,240,0.0630,0,88,999.000,999.0,99.0
+1977,11,1,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,13.9,93,98900,487,1388,372,102,1,102,11800,100,11700,4070,170,5.7,10,10,4.8,270,9,999999999,240,0.0630,0,88,999.000,999.0,99.0
+1977,11,1,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,13.9,96,98900,285,1388,369,53,0,53,6100,0,6100,1990,180,6.2,10,10,4.8,270,9,999999999,240,0.0630,0,88,999.000,999.0,99.0
+1977,11,1,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,13.9,93,98900,62,1030,372,13,0,13,1500,0,1500,480,180,6.7,10,10,4.8,210,9,999999999,240,0.0630,0,88,999.000,999.0,99.0
+1977,11,1,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,13.9,93,99000,0,0,372,0,0,0,0,0,0,0,180,8.2,10,10,8.0,240,9,999999999,240,0.0630,0,88,999.000,999.0,99.0
+1977,11,1,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,13.3,90,99000,0,0,371,0,0,0,0,0,0,0,180,6.2,10,10,9.7,310,9,999999999,240,0.0630,0,88,999.000,999.0,99.0
+1977,11,1,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,13.3,90,99000,0,0,371,0,0,0,0,0,0,0,180,5.2,10,10,8.0,700,9,999999999,240,0.0630,0,88,999.000,999.0,99.0
+1977,11,1,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,12.8,90,99000,0,0,368,0,0,0,0,0,0,0,180,4.1,10,10,9.7,700,9,999999999,229,0.0630,0,88,999.000,999.0,99.0
+1977,11,1,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,13.3,93,99000,0,0,368,0,0,0,0,0,0,0,180,5.2,10,10,6.4,760,9,999999999,240,0.0630,0,88,999.000,999.0,99.0
+1977,11,1,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,13.3,93,99000,0,0,368,0,0,0,0,0,0,0,170,4.6,10,10,6.4,1160,9,999999999,240,0.0630,0,88,999.000,999.0,99.0
+1977,11,1,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,13.9,93,99000,0,0,372,0,0,0,0,0,0,0,180,4.1,10,10,6.4,1680,9,999999999,240,0.0630,0,88,999.000,999.0,99.0
+1977,11,2,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,13.9,93,99100,0,0,372,0,0,0,0,0,0,0,180,3.1,10,10,6.4,1680,9,999999999,240,0.0630,0,88,999.000,999.0,99.0
+1977,11,2,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,13.3,93,99100,0,0,368,0,0,0,0,0,0,0,180,1.5,10,10,6.4,1680,9,999999999,240,0.0630,0,88,999.000,999.0,99.0
+1977,11,2,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,12.8,93,99000,0,0,365,0,0,0,0,0,0,0,150,2.6,10,10,9.7,1680,9,999999999,229,0.0630,0,88,999.000,999.0,99.0
+1977,11,2,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,13.3,96,99100,0,0,366,0,0,0,0,0,0,0,130,2.6,10,10,9.7,1680,9,999999999,240,0.0630,0,88,999.000,999.0,99.0
+1977,11,2,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,12.8,90,99100,0,0,368,0,0,0,0,0,0,0,140,2.6,10,10,9.7,1830,9,999999999,229,0.0630,0,88,999.000,999.0,99.0
+1977,11,2,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,12.8,93,99000,0,0,365,0,0,0,0,0,0,0,140,1.5,10,10,9.7,2130,9,999999999,229,0.0630,0,88,999.000,999.0,99.0
+1977,11,2,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,11.7,90,99000,34,752,343,16,16,14,1700,600,1600,290,150,3.6,8,8,6.4,2130,9,999999999,209,0.0600,0,88,999.000,999.0,99.0
+1977,11,2,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,12.2,84,99000,242,1389,343,96,61,85,10400,4800,9600,1930,160,5.2,8,6,6.4,2440,9,999999999,220,0.0600,0,88,999.000,999.0,99.0
+1977,11,2,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,12.8,78,99000,451,1389,340,266,579,72,27200,52500,10100,1380,170,6.7,4,2,9.7,77777,9,999999999,229,0.0600,0,88,999.000,999.0,99.0
+1977,11,2,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,13.3,73,99100,613,1389,360,333,435,136,34900,42700,16000,2710,180,6.2,9,6,14.5,2740,9,999999999,240,0.0600,0,88,999.000,999.0,99.0
+1977,11,2,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,13.9,70,99100,717,1389,357,461,580,156,48900,58500,18500,3310,200,6.7,9,3,19.3,77777,9,999999999,240,0.0600,0,88,999.000,999.0,99.0
+1977,11,2,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,14.4,68,99000,757,1389,364,473,590,146,48800,58400,16800,3180,220,5.2,8,3,19.3,77777,9,999999999,250,0.0600,0,88,999.000,999.0,99.0
+1977,11,2,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,15.0,66,99000,729,1389,379,419,517,143,44900,52300,17400,3030,170,5.7,8,6,24.1,7620,9,999999999,259,0.0600,0,88,999.000,999.0,99.0
+1977,11,2,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.7,15.0,66,98900,635,1389,390,245,114,192,26600,11500,21300,4650,170,5.2,10,8,19.3,2740,9,999999999,259,0.0600,0,88,999.000,999.0,99.0
+1977,11,2,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,15.0,68,99000,481,1389,387,114,45,98,12500,4200,11100,2830,160,5.7,10,8,24.1,1830,9,999999999,259,0.0600,0,88,999.000,999.0,99.0
+1977,11,2,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,14.4,71,99000,280,1389,388,104,34,97,11300,2800,10800,2260,170,5.2,10,9,19.3,1370,9,999999999,250,0.0600,0,88,999.000,999.0,99.0
+1977,11,2,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,14.4,73,99000,59,984,385,22,6,22,2500,0,2500,710,160,3.6,10,9,19.3,1520,9,999999999,250,0.0600,0,88,999.000,999.0,99.0
+1977,11,2,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,14.4,78,99000,0,0,371,0,0,0,0,0,0,0,160,3.1,8,8,24.1,2440,9,999999999,250,0.0600,0,88,999.000,999.0,99.0
+1977,11,2,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,14.4,78,99000,0,0,379,0,0,0,0,0,0,0,130,3.6,9,9,24.1,2740,9,999999999,250,0.0600,0,88,999.000,999.0,99.0
+1977,11,2,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,13.9,78,99000,0,0,376,0,0,0,0,0,0,0,140,3.1,9,9,24.1,2740,9,999999999,240,0.0600,0,88,999.000,999.0,99.0
+1977,11,2,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,13.9,81,99100,0,0,373,0,0,0,0,0,0,0,130,3.6,9,9,24.1,2740,9,999999999,240,0.0600,0,88,999.000,999.0,99.0
+1977,11,2,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,13.9,81,99100,0,0,373,0,0,0,0,0,0,0,140,3.1,9,9,24.1,2740,9,999999999,240,0.0600,0,88,999.000,999.0,99.0
+1977,11,2,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,12.8,78,99100,0,0,369,0,0,0,0,0,0,0,130,3.1,9,9,19.3,2740,9,999999999,229,0.0600,0,88,999.000,999.0,99.0
+1977,11,2,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,12.8,75,99100,0,0,382,0,0,0,0,0,0,0,130,3.1,10,10,16.1,2440,9,999999999,229,0.0600,0,88,999.000,999.0,99.0
+1977,11,3,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.2,12.8,75,99100,0,0,382,0,0,0,0,0,0,0,150,3.1,10,10,19.3,2440,9,999999999,229,0.0600,0,88,999.000,999.0,99.0
+1977,11,3,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,12.8,81,99100,0,0,376,0,0,0,0,0,0,0,170,3.1,10,10,19.3,2130,9,999999999,229,0.0600,0,88,999.000,999.0,99.0
+1977,11,3,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,13.3,84,99000,0,0,377,0,0,0,0,0,0,0,160,3.1,10,10,16.1,1680,9,999999999,240,0.0600,0,88,999.000,999.0,99.0
+1977,11,3,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,13.3,87,99000,0,0,374,0,0,0,0,0,0,0,150,3.1,10,10,16.1,1400,9,999999999,240,0.0600,0,88,999.000,999.0,99.0
+1977,11,3,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,13.3,87,99100,0,0,374,0,0,0,0,0,0,0,160,3.1,10,10,14.5,1400,9,999999999,240,0.0600,0,88,999.000,999.0,99.0
+1977,11,3,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,13.9,93,99100,0,0,372,0,0,0,0,0,0,0,160,3.6,10,10,14.5,2440,9,999999999,240,0.0600,0,88,999.000,999.0,99.0
+1977,11,3,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,13.9,90,99100,32,730,375,4,2,3,300,100,300,80,170,3.1,10,10,8.0,1680,9,999999999,250,0.0490,0,88,999.000,999.0,99.0
+1977,11,3,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,14.4,90,99200,237,1390,378,49,6,48,5600,100,5500,1720,170,3.1,10,10,8.0,1680,9,999999999,250,0.0490,0,88,999.000,999.0,99.0
+1977,11,3,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,14.4,81,99200,445,1390,387,119,12,115,13400,800,13200,4240,190,3.1,10,10,14.5,2740,9,999999999,250,0.0490,0,88,999.000,999.0,99.0
+1977,11,3,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,15.6,78,99200,607,1390,398,157,5,155,17900,400,17800,6170,190,5.7,10,10,16.1,3050,9,999999999,270,0.0490,0,88,999.000,999.0,99.0
+1977,11,3,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,15.6,76,99200,711,1390,401,213,6,210,24200,500,23900,8330,190,6.2,10,10,19.3,3660,9,999999999,270,0.0490,0,88,999.000,999.0,99.0
+1977,11,3,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,21.1,16.1,73,99200,751,1390,396,310,89,261,33900,9000,29100,7840,230,5.2,10,9,19.3,700,9,999999999,279,0.0490,0,88,999.000,999.0,99.0
+1977,11,3,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,16.1,76,99200,723,1390,405,237,130,169,26300,13500,19300,4270,190,4.6,10,10,19.3,3660,9,999999999,279,0.0490,0,88,999.000,999.0,99.0
+1977,11,3,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.6,16.1,76,99200,629,1390,405,218,13,212,24300,1100,23800,7710,190,3.1,10,10,19.3,3660,9,999999999,279,0.0490,0,88,999.000,999.0,99.0
+1977,11,3,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,16.1,78,99200,476,1390,401,131,1,130,14700,100,14600,4780,200,3.6,10,10,19.3,2740,9,999999999,279,0.0490,0,88,999.000,999.0,99.0
+1977,11,3,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,20.0,16.1,78,99200,274,1390,401,62,3,61,6900,100,6900,2170,210,2.6,10,10,14.5,2440,9,999999999,279,0.0490,0,88,999.000,999.0,99.0
+1977,11,3,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,19.4,15.6,78,99300,55,961,398,15,0,15,1700,0,1700,530,190,2.1,10,10,12.9,2440,9,999999999,270,0.0490,0,88,999.000,999.0,99.0
+1977,11,3,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,18.3,16.1,87,99400,0,0,392,0,0,0,0,0,0,0,290,3.1,10,10,8.0,700,9,999999999,279,0.0490,0,88,999.000,999.0,99.0
+1977,11,3,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,17.2,97,99500,0,0,391,0,0,0,0,0,0,0,20,2.6,10,10,8.0,1160,9,999999999,300,0.0490,0,88,999.000,999.0,99.0
+1977,11,3,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,17.2,97,99500,0,0,391,0,0,0,0,0,0,0,10,2.6,10,10,8.0,1370,9,999999999,300,0.0490,0,88,999.000,999.0,99.0
+1977,11,3,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,17.8,16.1,90,99600,0,0,390,0,0,0,0,0,0,0,360,6.2,10,10,8.0,370,9,999999999,279,0.0490,0,88,999.000,999.0,99.0
+1977,11,3,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.6,13.9,90,99700,0,0,375,0,0,0,0,0,0,0,30,7.2,10,10,11.3,310,9,999999999,250,0.0490,0,88,999.000,999.0,99.0
+1977,11,3,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,15.0,13.3,90,99700,0,0,371,0,0,0,0,0,0,0,10,6.7,10,10,11.3,240,9,999999999,240,0.0490,0,88,999.000,999.0,99.0
+1977,11,3,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,12.8,90,99800,0,0,368,0,0,0,0,0,0,0,20,6.7,10,10,14.5,340,9,999999999,229,0.0490,0,88,999.000,999.0,99.0
+1977,11,4,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,12.2,87,99800,0,0,367,0,0,0,0,0,0,0,20,8.2,10,10,16.1,310,9,999999999,220,0.0490,0,88,999.000,999.0,99.0
+1977,11,4,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,9.4,78,99900,0,0,358,0,0,0,0,0,0,0,30,7.7,10,10,24.1,2130,9,999999999,189,0.0490,0,88,999.000,999.0,99.0
+1977,11,4,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,10.6,86,100000,0,0,357,0,0,0,0,0,0,0,30,6.2,10,10,24.1,370,9,999999999,200,0.0490,0,88,999.000,999.0,99.0
+1977,11,4,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,8.9,80,100000,0,0,352,0,0,0,0,0,0,0,20,6.2,10,10,24.1,2740,9,999999999,179,0.0490,0,88,999.000,999.0,99.0
+1977,11,4,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,7.8,77,100100,0,0,315,0,0,0,0,0,0,0,30,5.2,3,3,24.1,77777,9,999999999,170,0.0490,0,88,999.000,999.0,99.0
+1977,11,4,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,6.7,74,100200,0,0,308,0,0,0,0,0,0,0,20,6.2,2,2,24.1,77777,9,999999999,160,0.0490,0,88,999.000,999.0,99.0
+1977,11,4,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,7.2,80,100200,29,707,306,15,33,12,1500,900,1400,200,30,7.7,2,2,24.1,77777,9,999999999,170,0.1000,0,88,999.000,999.0,99.0
+1977,11,4,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,6.7,69,100300,231,1391,309,115,416,43,11500,29500,6600,770,30,8.8,1,1,24.1,77777,9,999999999,160,0.1000,0,88,999.000,999.0,99.0
+1977,11,4,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,6.1,64,100400,439,1391,315,262,550,84,26600,49000,11000,1550,30,10.8,2,2,24.1,77777,9,999999999,160,0.1000,0,88,999.000,999.0,99.0
+1977,11,4,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,5.6,55,100400,601,1391,321,388,621,113,39600,59500,13800,2240,40,8.2,2,2,24.1,77777,9,999999999,150,0.1000,0,88,999.000,999.0,99.0
+1977,11,4,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,5.6,55,100400,706,1391,321,450,548,166,47200,55000,19200,3520,40,9.3,2,2,24.1,77777,9,999999999,150,0.1000,0,88,999.000,999.0,99.0
+1977,11,4,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,5.6,54,100400,745,1391,320,495,702,112,51900,70200,14100,2510,40,8.8,2,1,24.1,77777,9,999999999,150,0.1000,0,88,999.000,999.0,99.0
+1977,11,4,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,6.1,56,100300,717,1391,320,477,709,105,50000,70600,13500,2310,30,6.7,1,1,24.1,77777,9,999999999,160,0.1000,0,88,999.000,999.0,99.0
+1977,11,4,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,6.1,58,100300,623,1391,312,427,757,82,43900,73000,11000,1670,30,9.8,0,0,24.1,77777,9,999999999,160,0.1000,0,88,999.000,999.0,99.0
+1977,11,4,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,5.6,57,100300,470,1391,309,296,663,67,30700,61000,10000,1310,30,8.8,0,0,24.1,77777,9,999999999,150,0.1000,0,88,999.000,999.0,99.0
+1977,11,4,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,6.1,64,100400,269,1391,305,140,468,47,14200,35500,7300,860,30,8.2,0,0,24.1,77777,9,999999999,160,0.1000,0,88,999.000,999.0,99.0
+1977,11,4,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,6.7,74,100400,52,939,298,28,90,19,2600,3400,2400,340,30,6.7,0,0,24.1,77777,9,999999999,160,0.1000,0,88,999.000,999.0,99.0
+1977,11,4,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,6.7,77,100400,0,0,296,0,0,0,0,0,0,0,30,7.2,0,0,24.1,77777,9,999999999,160,0.1000,0,88,999.000,999.0,99.0
+1977,11,4,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,7.2,83,100400,0,0,294,0,0,0,0,0,0,0,30,7.2,0,0,24.1,77777,9,999999999,170,0.1000,0,88,999.000,999.0,99.0
+1977,11,4,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,6.7,77,100400,0,0,296,0,0,0,0,0,0,0,30,5.7,0,0,24.1,77777,9,999999999,160,0.1000,0,88,999.000,999.0,99.0
+1977,11,4,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,6.1,69,100300,0,0,300,0,0,0,0,0,0,0,40,5.7,0,0,24.1,77777,9,999999999,160,0.1000,0,88,999.000,999.0,99.0
+1977,11,4,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,-0.6,42,100300,0,0,316,0,0,0,0,0,0,0,50,5.7,6,6,24.1,1370,9,999999999,110,0.1000,0,88,999.000,999.0,99.0
+1977,11,4,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,-0.6,40,100300,0,0,327,0,0,0,0,0,0,0,50,6.7,8,8,24.1,1680,9,999999999,100,0.1000,0,88,999.000,999.0,99.0
+1977,11,4,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,0.0,45,100300,0,0,309,0,0,0,0,0,0,0,60,6.2,4,4,24.1,77777,9,999999999,110,0.1000,0,88,999.000,999.0,99.0
+1977,11,5,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,1.1,49,100200,0,0,324,0,0,0,0,0,0,0,60,5.2,8,8,24.1,760,9,999999999,120,0.1000,0,88,999.000,999.0,99.0
+1977,11,5,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,2.8,61,100200,0,0,299,0,0,0,0,0,0,0,50,4.6,2,2,24.1,77777,9,999999999,129,0.1000,0,88,999.000,999.0,99.0
+1977,11,5,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,3.9,66,100200,0,0,303,0,0,0,0,0,0,0,50,5.2,3,3,24.1,77777,9,999999999,139,0.1000,0,88,999.000,999.0,99.0
+1977,11,5,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.6,5.0,69,100200,0,0,340,0,0,0,0,0,0,0,40,6.2,10,10,24.1,670,9,999999999,150,0.1000,0,88,999.000,999.0,99.0
+1977,11,5,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,5.6,69,100100,0,0,343,0,0,0,0,0,0,0,70,5.7,10,10,24.1,580,9,999999999,150,0.1000,0,88,999.000,999.0,99.0
+1977,11,5,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,6.7,74,100100,0,0,344,0,0,0,0,0,0,0,50,6.2,10,10,24.1,520,9,999999999,160,0.1000,0,88,999.000,999.0,99.0
+1977,11,5,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,7.2,80,100100,27,684,342,6,1,6,700,0,700,230,50,5.2,10,10,24.1,520,9,999999999,170,0.1380,0,88,999.000,999.0,99.0
+1977,11,5,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,7.8,80,100100,226,1391,345,35,5,34,4000,100,4000,1290,50,6.2,10,10,24.1,460,9,999999999,170,0.1380,0,88,999.000,999.0,99.0
+1977,11,5,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,8.3,86,100100,434,1391,343,103,6,101,11700,400,11600,3820,40,5.7,10,10,19.3,520,9,999999999,179,0.1380,0,88,999.000,999.0,99.0
+1977,11,5,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,8.3,83,100100,595,1391,346,167,5,165,18900,400,18800,6370,50,6.2,10,10,19.3,490,9,999999999,179,0.1380,0,88,999.000,999.0,99.0
+1977,11,5,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,8.9,80,100000,700,1391,352,218,1,218,24700,100,24700,8430,30,6.7,10,10,19.3,580,9,999999999,179,0.1380,0,88,999.000,999.0,99.0
+1977,11,5,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,8.9,77,99900,739,1391,355,264,4,261,29500,400,29300,9760,40,5.7,10,10,19.3,580,9,999999999,179,0.1380,0,88,999.000,999.0,99.0
+1977,11,5,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,8.9,75,99800,711,1391,357,189,0,189,21700,0,21700,7740,40,7.2,10,10,19.3,580,9,999999999,179,0.1380,0,88,999.000,999.0,99.0
+1977,11,5,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,8.9,77,99700,617,1391,338,177,109,128,19700,11100,14800,3070,30,8.8,8,8,19.3,550,9,999999999,179,0.1380,0,88,999.000,999.0,99.0
+1977,11,5,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,8.9,77,99700,465,1391,345,131,35,119,14300,3300,13300,3270,50,7.2,9,9,19.3,520,9,999999999,179,0.1380,0,88,999.000,999.0,99.0
+1977,11,5,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,8.9,80,99700,264,1391,335,95,70,81,10200,5300,9200,1740,40,7.2,9,8,19.3,2440,9,999999999,179,0.1380,0,88,999.000,999.0,99.0
+1977,11,5,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,8.9,80,99700,49,916,352,13,0,13,1500,0,1500,470,30,5.2,10,10,19.3,1370,9,999999999,179,0.1380,0,88,999.000,999.0,99.0
+1977,11,5,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,9.4,83,99600,0,0,353,0,0,0,0,0,0,0,40,6.7,10,10,24.1,2740,9,999999999,189,0.1380,0,88,999.000,999.0,99.0
+1977,11,5,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,9.4,86,99600,0,0,350,0,0,0,0,0,0,0,40,5.2,10,10,24.1,2740,9,999999999,189,0.1380,0,88,999.000,999.0,99.0
+1977,11,5,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,9.4,83,99600,0,0,343,0,0,0,0,0,0,0,20,5.7,9,9,24.1,2290,9,999999999,189,0.1380,0,88,999.000,999.0,99.0
+1977,11,5,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,10.0,90,99600,0,0,334,0,0,0,0,0,0,0,30,5.2,8,8,24.1,2740,9,999999999,200,0.1380,0,88,999.000,999.0,99.0
+1977,11,5,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,10.0,86,99500,0,0,336,0,0,0,0,0,0,0,20,5.2,8,8,19.3,2740,9,999999999,189,0.1380,0,88,999.000,999.0,99.0
+1977,11,5,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,10.0,86,99500,0,0,353,0,0,0,0,0,0,0,50,4.6,10,10,14.5,2740,9,999999999,189,0.1380,0,88,999.000,999.0,99.0
+1977,11,5,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,10.0,83,99500,0,0,356,0,0,0,0,0,0,0,40,5.2,10,10,14.5,460,9,999999999,189,0.1380,0,88,999.000,999.0,99.0
+1977,11,6,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,10.6,86,99400,0,0,357,0,0,0,0,0,0,0,40,5.7,10,10,11.3,370,9,999999999,200,0.1380,0,88,999.000,999.0,99.0
+1977,11,6,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,10.6,86,99400,0,0,357,0,0,0,0,0,0,0,50,4.1,10,10,11.3,370,9,999999999,200,0.1380,0,88,999.000,999.0,99.0
+1977,11,6,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,11.1,90,99400,0,0,358,0,0,0,0,0,0,0,50,4.1,10,10,11.3,340,9,999999999,209,0.1380,0,88,999.000,999.0,99.0
+1977,11,6,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,11.1,90,99300,0,0,358,0,0,0,0,0,0,0,40,4.6,10,10,8.0,340,9,999999999,209,0.1380,0,88,999.000,999.0,99.0
+1977,11,6,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,11.1,93,99300,0,0,355,0,0,0,0,0,0,0,50,5.2,10,10,8.0,240,9,999999999,209,0.1380,0,88,999.000,999.0,99.0
+1977,11,6,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,10.6,90,99300,0,0,354,0,0,0,0,0,0,0,50,5.2,10,10,8.0,240,9,999999999,200,0.1380,0,88,999.000,999.0,99.0
+1977,11,6,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,10.6,93,99300,24,638,352,7,0,7,0,0,0,0,30,5.7,10,10,8.0,240,9,999999999,200,0.2080,0,88,999.000,999.0,99.0
+1977,11,6,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,10.6,90,99300,221,1392,354,37,1,37,4300,0,4300,1380,30,5.2,10,10,8.0,370,9,999999999,200,0.2080,0,88,999.000,999.0,99.0
+1977,11,6,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,10.6,86,99300,428,1392,357,104,2,104,11800,100,11800,3880,40,6.2,10,10,11.3,370,9,999999999,200,0.2080,0,88,999.000,999.0,99.0
+1977,11,6,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,10.6,86,99300,590,1392,357,142,2,142,16400,100,16300,5700,30,4.6,10,10,11.3,370,9,999999999,200,0.2080,0,88,999.000,999.0,99.0
+1977,11,6,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,11.1,83,99200,694,1392,363,169,2,168,19500,200,19400,7020,50,6.2,10,10,11.3,370,9,999999999,209,0.2080,0,88,999.000,999.0,99.0
+1977,11,6,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,11.7,81,99100,733,1392,369,261,4,259,29300,400,29100,9650,30,6.7,10,10,16.1,370,9,999999999,220,0.2080,0,88,999.000,999.0,99.0
+1977,11,6,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,11.7,84,99000,705,1392,366,205,1,204,23300,100,23200,8120,30,6.2,10,10,11.3,310,9,999999999,209,0.2080,0,88,999.000,999.0,99.0
+1977,11,6,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,11.7,87,99000,612,1392,364,165,1,165,18800,100,18800,6460,30,6.2,10,10,8.0,310,9,999999999,220,0.2080,0,88,999.000,999.0,99.0
+1977,11,6,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,11.7,87,99000,459,1392,364,148,0,147,16300,0,16300,5040,30,7.2,10,10,8.0,270,9,999999999,220,0.2080,0,88,999.000,999.0,99.0
+1977,11,6,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,11.7,90,99000,259,1392,361,40,0,40,4600,0,4600,1540,30,7.7,10,10,8.0,520,9,999999999,209,0.2080,0,88,999.000,999.0,99.0
+1977,11,6,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,11.7,93,99000,46,893,358,11,0,11,1300,0,1300,400,30,5.2,10,10,6.4,210,9,999999999,209,0.2080,0,88,999.000,999.0,99.0
+1977,11,6,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,11.7,93,99000,0,0,358,0,0,0,0,0,0,0,20,6.2,10,10,6.4,180,9,999999999,209,0.2080,0,88,999.000,999.0,99.0
+1977,11,6,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,11.7,93,99000,0,0,358,0,0,0,0,0,0,0,40,5.2,10,10,8.0,180,9,999999999,209,0.2080,0,88,999.000,999.0,99.0
+1977,11,6,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,12.2,96,99000,0,0,359,0,0,0,0,0,0,0,20,4.6,10,10,6.4,180,9,999999999,220,0.2080,0,88,999.000,999.0,99.0
+1977,11,6,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,12.2,96,98900,0,0,359,0,0,0,0,0,0,0,10,5.2,10,10,6.4,150,9,999999999,220,0.2080,0,88,999.000,999.0,99.0
+1977,11,6,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,12.8,96,98900,0,0,362,0,0,0,0,0,0,0,30,4.1,10,10,4.0,210,9,999999999,229,0.2080,0,88,999.000,999.0,99.0
+1977,11,6,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,13.3,96,98900,0,0,366,0,0,0,0,0,0,0,40,3.1,10,10,4.0,90,9,999999999,240,0.2080,0,88,999.000,999.0,99.0
+1977,11,6,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,13.3,96,98900,0,0,366,0,0,0,0,0,0,0,30,4.1,10,10,1.3,60,9,999999999,240,0.2080,0,88,999.000,999.0,99.0
+1977,11,7,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,13.9,100,98800,0,0,366,0,0,0,0,0,0,0,30,2.6,10,10,0.8,60,9,999999999,240,0.2080,0,88,999.000,999.0,99.0
+1977,11,7,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,13.9,100,98800,0,0,366,0,0,0,0,0,0,0,30,3.6,10,10,1.3,60,9,999999999,240,0.2080,0,88,999.000,999.0,99.0
+1977,11,7,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,14.4,13.9,96,98700,0,0,369,0,0,0,0,0,0,0,30,4.1,10,10,1.3,60,9,999999999,240,0.2080,0,88,999.000,999.0,99.0
+1977,11,7,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,13.3,96,98700,0,0,366,0,0,0,0,0,0,0,10,3.6,10,10,1.3,30,9,999999999,229,0.2080,0,88,999.000,999.0,99.0
+1977,11,7,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,12.8,100,98700,0,0,360,0,0,0,0,0,0,0,20,4.1,10,10,0.2,0,9,999999999,229,0.2080,0,88,999.000,999.0,99.0
+1977,11,7,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,12.8,96,98600,0,0,362,0,0,0,0,0,0,0,30,4.1,10,10,0.2,0,9,999999999,229,0.2080,0,88,999.000,999.0,99.0
+1977,11,7,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,12.8,100,98700,22,615,360,11,0,11,0,0,0,0,20,4.6,10,10,0.2,0,9,999999999,229,0.0760,0,88,999.000,999.0,99.0
+1977,11,7,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,12.8,100,98700,215,1393,360,36,0,36,4100,0,4100,1340,30,4.6,10,10,0.2,30,9,999999999,229,0.0760,0,88,999.000,999.0,99.0
+1977,11,7,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,12.8,100,98700,422,1393,360,90,1,90,10300,100,10300,3470,20,3.1,10,10,0.2,0,9,999999999,229,0.0760,0,88,999.000,999.0,99.0
+1977,11,7,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,12.8,100,98700,584,1393,360,129,1,128,14800,100,14800,5250,20,4.1,10,10,0.4,60,9,999999999,229,0.0760,0,88,999.000,999.0,99.0
+1977,11,7,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,13.3,96,98600,688,1393,366,145,1,145,16900,100,16900,6260,20,5.2,10,10,2.4,90,9,999999999,229,0.0760,0,88,999.000,999.0,99.0
+1977,11,7,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,13.3,96,98500,728,1393,366,252,2,251,28300,200,28200,9430,10,4.1,10,10,0.4,60,9,999999999,229,0.0760,0,88,999.000,999.0,99.0
+1977,11,7,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,13.9,100,98400,700,1393,366,258,1,258,28800,100,28800,9290,40,3.6,10,10,0.2,30,9,999999999,240,0.0760,0,88,999.000,999.0,99.0
+1977,11,7,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,13.9,96,98400,606,1393,369,212,0,212,23600,0,23600,7500,20,5.2,10,10,1.3,90,9,999999999,240,0.0760,0,88,999.000,999.0,99.0
+1977,11,7,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,13.3,96,98400,454,1393,366,142,1,141,15700,100,15700,4880,360,3.6,10,10,1.6,90,9,999999999,229,0.0760,0,88,999.000,999.0,99.0
+1977,11,7,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,13.3,96,98400,254,1393,366,71,1,71,7900,0,7900,2320,10,3.1,10,10,0.8,60,9,999999999,229,0.0760,0,88,999.000,999.0,99.0
+1977,11,7,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,13.3,100,98400,43,870,363,17,0,17,1900,0,1900,570,10,3.6,10,10,0.8,60,9,999999999,229,0.0760,0,88,999.000,999.0,99.0
+1977,11,7,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,12.8,96,98400,0,0,362,0,0,0,0,0,0,0,20,4.6,10,10,1.3,90,9,999999999,229,0.0760,0,88,999.000,999.0,99.0
+1977,11,7,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,12.8,96,98500,0,0,362,0,0,0,0,0,0,0,360,3.6,10,10,3.2,90,9,999999999,229,0.0760,0,88,999.000,999.0,99.0
+1977,11,7,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,12.8,96,98500,0,0,362,0,0,0,0,0,0,0,360,2.6,10,10,2.4,120,9,999999999,229,0.0760,0,88,999.000,999.0,99.0
+1977,11,7,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,12.8,96,98500,0,0,362,0,0,0,0,0,0,0,10,4.1,10,10,2.4,60,9,999999999,229,0.0760,0,88,999.000,999.0,99.0
+1977,11,7,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,12.8,96,98500,0,0,362,0,0,0,0,0,0,0,20,3.6,10,10,3.2,60,9,999999999,229,0.0760,0,88,999.000,999.0,99.0
+1977,11,7,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,12.8,96,98500,0,0,362,0,0,0,0,0,0,0,40,1.5,10,10,3.2,90,9,999999999,229,0.0760,0,88,999.000,999.0,99.0
+1977,11,7,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.3,13.3,100,98500,0,0,363,0,0,0,0,0,0,0,340,1.5,10,10,3.2,90,9,999999999,229,0.0760,0,88,999.000,999.0,99.0
+1977,11,8,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,13.3,96,98500,0,0,366,0,0,0,0,0,0,0,300,2.6,10,10,1.3,60,9,999999999,229,0.0760,0,88,999.000,999.0,99.0
+1977,11,8,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,13.3,96,98500,0,0,366,0,0,0,0,0,0,0,0,0.0,10,10,1.3,60,9,999999999,229,0.0760,0,88,999.000,999.0,99.0
+1977,11,8,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,13.3,96,98500,0,0,366,0,0,0,0,0,0,0,350,1.5,10,10,1.3,30,9,999999999,229,0.0760,0,88,999.000,999.0,99.0
+1977,11,8,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,13.3,96,98500,0,0,366,0,0,0,0,0,0,0,0,0.0,10,10,1.3,60,9,999999999,229,0.0760,0,88,999.000,999.0,99.0
+1977,11,8,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,13.9,100,98500,0,0,366,0,0,0,0,0,0,0,30,2.6,10,10,0.6,30,9,999999999,240,0.0760,0,88,999.000,999.0,99.0
+1977,11,8,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,13.9,13.3,96,98600,0,0,366,0,0,0,0,0,0,0,50,1.5,10,10,0.6,90,9,999999999,229,0.0760,0,88,999.000,999.0,99.0
+1977,11,8,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,13.3,96,98700,20,592,366,12,0,12,0,0,0,0,0,0.0,10,10,1.3,270,9,999999999,229,0.0520,0,88,999.000,999.0,99.0
+1977,11,8,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,13.9,96,98700,210,1393,369,71,1,71,7700,0,7700,2090,120,3.1,10,10,2.4,150,9,999999999,240,0.0520,0,88,999.000,999.0,99.0
+1977,11,8,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,13.9,96,98700,417,1393,369,143,1,142,15600,100,15600,4630,130,3.1,10,10,1.6,150,9,999999999,240,0.0520,0,88,999.000,999.0,99.0
+1977,11,8,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,14.4,93,98700,578,1393,376,212,1,211,23400,100,23300,7220,170,2.6,10,10,1.6,180,9,999999999,250,0.0520,0,88,999.000,999.0,99.0
+1977,11,8,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,15.0,93,98700,682,1393,379,237,0,237,26500,0,26500,8700,170,2.6,10,10,1.6,180,9,999999999,259,0.0520,0,88,999.000,999.0,99.0
+1977,11,8,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,15.6,90,98700,722,1393,386,255,1,255,28600,100,28600,9450,160,3.1,10,10,3.2,270,9,999999999,270,0.0520,0,88,999.000,999.0,99.0
+1977,11,8,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,15.0,87,98600,694,1393,385,261,2,260,29000,200,28900,9270,170,4.6,10,10,6.4,370,9,999999999,259,0.0520,0,88,999.000,999.0,99.0
+1977,11,8,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,14.4,90,98600,601,1393,378,201,1,200,22400,100,22300,7210,180,5.2,10,10,6.4,310,9,999999999,250,0.0520,0,88,999.000,999.0,99.0
+1977,11,8,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,14.4,90,98600,449,1393,378,144,1,144,16000,100,16000,4900,160,3.6,10,10,4.8,240,9,999999999,250,0.0520,0,88,999.000,999.0,99.0
+1977,11,8,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,14.4,90,98600,249,1393,378,84,1,83,9100,0,9000,2500,160,3.6,10,10,4.8,310,9,999999999,250,0.0520,0,88,999.000,999.0,99.0
+1977,11,8,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,15.0,90,98600,40,824,382,20,0,20,2200,0,2200,640,150,3.6,10,10,4.8,310,9,999999999,259,0.0520,0,88,999.000,999.0,99.0
+1977,11,8,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,15.0,90,98700,0,0,382,0,0,0,0,0,0,0,170,3.6,10,10,6.4,370,9,999999999,259,0.0520,0,88,999.000,999.0,99.0
+1977,11,8,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,15.6,93,98700,0,0,383,0,0,0,0,0,0,0,160,3.6,10,10,6.4,640,9,999999999,270,0.0520,0,88,999.000,999.0,99.0
+1977,11,8,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,15.6,97,98600,0,0,380,0,0,0,0,0,0,0,130,3.6,10,10,6.4,1160,9,999999999,270,0.0520,0,88,999.000,999.0,99.0
+1977,11,8,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.7,15.6,93,98600,0,0,383,0,0,0,0,0,0,0,140,4.1,10,10,6.4,340,9,999999999,270,0.0520,0,88,999.000,999.0,99.0
+1977,11,8,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,15.0,93,98500,0,0,379,0,0,0,0,0,0,0,140,3.6,10,10,8.0,1160,9,999999999,259,0.0520,0,88,999.000,999.0,99.0
+1977,11,8,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,15.0,93,98500,0,0,379,0,0,0,0,0,0,0,130,4.1,10,10,8.0,1400,9,999999999,259,0.0520,0,88,999.000,999.0,99.0
+1977,11,8,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,15.0,93,98400,0,0,369,0,0,0,0,0,0,0,160,6.2,9,9,8.0,340,9,999999999,259,0.0520,0,88,999.000,999.0,99.0
+1977,11,9,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,15.0,93,98400,0,0,369,0,0,0,0,0,0,0,140,7.2,9,9,8.0,460,9,999999999,259,0.0520,0,88,999.000,999.0,99.0
+1977,11,9,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,14.4,90,98300,0,0,368,0,0,0,0,0,0,0,150,6.2,9,9,8.0,370,9,999999999,250,0.0520,0,88,999.000,999.0,99.0
+1977,11,9,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,14.4,90,98100,0,0,360,0,0,0,0,0,0,0,140,6.7,8,8,9.7,370,9,999999999,250,0.0520,0,88,999.000,999.0,99.0
+1977,11,9,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,13.9,87,98100,0,0,378,0,0,0,0,0,0,0,140,7.7,10,10,11.3,2130,9,999999999,240,0.0520,0,88,999.000,999.0,99.0
+1977,11,9,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,13.9,87,98000,0,0,342,0,0,0,0,0,0,0,150,8.8,7,3,11.3,77777,9,999999999,240,0.0520,0,88,999.000,999.0,99.0
+1977,11,9,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,16.1,13.9,87,98000,0,0,378,0,0,0,0,0,0,0,160,6.2,10,10,11.3,580,9,999999999,240,0.0520,0,88,999.000,999.0,99.0
+1977,11,9,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,14.4,87,97900,18,569,382,11,0,11,0,0,0,0,150,7.7,10,10,6.4,760,9,999999999,250,0.1340,0,88,999.000,999.0,99.0
+1977,11,9,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,14.4,84,97900,205,1394,384,50,0,50,5600,0,5600,1680,180,8.8,10,10,8.0,580,9,999999999,250,0.1340,0,88,999.000,999.0,99.0
+1977,11,9,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.2,15.0,87,97900,411,1394,385,129,0,129,14300,0,14300,4350,170,9.8,10,10,8.0,520,9,999999999,259,0.1340,0,88,999.000,999.0,99.0
+1977,11,9,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,12.2,84,97900,573,1394,370,107,1,107,12500,100,12500,4530,190,8.2,10,10,9.7,1010,9,999999999,220,0.1340,0,88,999.000,999.0,99.0
+1977,11,9,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,12.2,84,97900,677,1394,352,366,350,193,38900,36100,21300,4290,180,6.7,8,8,19.3,1680,9,999999999,220,0.1340,0,88,999.000,999.0,99.0
+1977,11,9,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,12.2,75,97800,716,1394,345,302,250,171,32600,26100,19200,3760,180,7.7,4,4,24.1,77777,9,999999999,220,0.1340,0,88,999.000,999.0,99.0
+1977,11,9,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,17.8,10.0,61,97700,689,1394,348,386,467,151,40800,46800,17600,3140,210,9.8,4,4,24.1,77777,9,999999999,189,0.1340,0,88,999.000,999.0,99.0
+1977,11,9,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,10.0,59,97700,596,1394,350,365,519,139,38200,50600,16500,2760,200,9.3,4,4,24.1,77777,9,999999999,189,0.1340,0,88,999.000,999.0,99.0
+1977,11,9,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,18.3,8.9,54,97700,444,1394,352,228,309,128,24000,28500,14900,2600,190,8.8,5,5,24.1,77777,9,999999999,179,0.1340,0,88,999.000,999.0,99.0
+1977,11,9,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.7,8.3,58,97700,244,1394,343,94,134,70,9800,9300,8200,1350,190,7.7,5,5,24.1,77777,9,999999999,170,0.1340,0,88,999.000,999.0,99.0
+1977,11,9,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,16.1,8.9,63,97600,38,802,361,16,4,15,1700,0,1700,510,220,6.2,9,9,24.1,1830,9,999999999,179,0.1340,0,88,999.000,999.0,99.0
+1977,11,9,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,10.0,86,97800,0,0,353,0,0,0,0,0,0,0,260,9.3,10,10,11.3,430,9,999999999,189,0.1340,0,88,999.000,999.0,99.0
+1977,11,9,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,4.4,83,97900,0,0,323,0,0,0,0,0,0,0,250,9.8,10,10,24.1,460,9,999999999,139,0.1340,0,88,999.000,999.0,99.0
+1977,11,9,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,1.7,73,97900,0,0,315,0,0,0,0,0,0,0,240,8.2,10,10,24.1,1370,9,999999999,120,0.1340,0,88,999.000,999.0,99.0
+1977,11,9,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,-0.6,68,97900,0,0,308,0,0,0,0,0,0,0,240,9.8,10,10,24.1,760,9,999999999,100,0.1340,0,88,999.000,999.0,99.0
+1977,11,9,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,-2.8,62,97900,0,0,276,0,0,0,0,0,0,0,230,10.8,5,5,24.1,77777,9,999999999,89,0.1340,0,88,999.000,999.0,99.0
+1977,11,9,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-2.2,67,97900,0,0,280,0,0,0,0,0,0,0,240,10.8,7,7,24.1,1160,9,999999999,89,0.1340,0,88,999.000,999.0,99.0
+1977,11,9,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-2.8,65,97900,0,0,290,0,0,0,0,0,0,0,240,9.3,9,9,24.1,1160,9,999999999,89,0.1340,0,88,999.000,999.0,99.0
+1977,11,10,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-3.9,60,97900,0,0,297,0,0,0,0,0,0,0,240,7.7,10,10,24.1,1400,9,999999999,89,0.1340,0,88,999.000,999.0,99.0
+1977,11,10,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-4.4,59,98000,0,0,294,0,0,0,0,0,0,0,230,8.8,10,10,24.1,1160,9,999999999,80,0.1340,0,88,999.000,999.0,99.0
+1977,11,10,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-4.4,59,97900,0,0,294,0,0,0,0,0,0,0,230,8.2,10,10,24.1,1400,9,999999999,80,0.1340,0,88,999.000,999.0,99.0
+1977,11,10,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-4.4,62,97900,0,0,291,0,0,0,0,0,0,0,230,11.3,10,10,24.1,1400,9,999999999,80,0.1340,0,88,999.000,999.0,99.0
+1977,11,10,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-5.6,59,97900,0,0,288,0,0,0,0,0,0,0,220,9.3,10,10,24.1,1400,9,999999999,80,0.1340,0,88,999.000,999.0,99.0
+1977,11,10,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-4.4,64,97900,0,0,289,0,0,0,0,0,0,0,210,8.8,10,10,24.1,1400,9,999999999,80,0.1340,0,88,999.000,999.0,99.0
+1977,11,10,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-3.3,70,97900,16,523,290,3,1,3,0,0,0,0,220,9.3,10,10,24.1,700,9,999999999,89,0.0500,0,88,999.000,999.0,99.0
+1977,11,10,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-2.8,73,97900,199,1395,291,69,0,69,7500,0,7500,2000,210,8.2,10,10,24.1,700,9,999999999,89,0.0500,0,88,999.000,999.0,99.0
+1977,11,10,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-2.8,73,97900,406,1395,291,98,11,94,11000,600,10800,3520,230,9.3,10,10,12.9,580,9,999999999,89,0.0500,0,88,999.000,999.0,99.0
+1977,11,10,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-2.2,76,97900,567,1395,292,156,3,155,17700,200,17600,5930,210,8.2,10,10,4.0,340,9,999999999,89,0.0500,0,88,999.000,999.0,99.0
+1977,11,10,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-1.7,79,97900,671,1395,292,178,1,178,20400,100,20300,7180,230,7.2,10,10,24.1,700,9,999999999,100,0.0500,0,88,999.000,999.0,99.0
+1977,11,10,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-2.8,73,97900,711,1395,291,254,0,254,28400,0,28400,9320,250,10.3,10,10,14.5,1160,9,999999999,89,0.0500,0,88,999.000,999.0,99.0
+1977,11,10,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-2.8,73,97900,683,1395,291,258,1,257,28600,100,28600,9090,240,9.3,10,10,14.5,640,9,999999999,89,0.0500,0,88,999.000,999.0,99.0
+1977,11,10,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-2.8,73,98000,590,1395,291,200,3,199,22300,300,22200,7100,240,8.2,10,10,14.5,760,9,999999999,89,0.0500,0,88,999.000,999.0,99.0
+1977,11,10,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-3.3,67,98100,439,1395,293,152,1,151,16600,100,16600,4950,250,7.7,10,10,14.5,1160,9,999999999,89,0.0500,0,88,999.000,999.0,99.0
+1977,11,10,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-3.9,67,98200,239,1395,290,81,1,80,8700,0,8700,2400,260,9.3,10,10,14.5,1010,9,999999999,80,0.0500,0,88,999.000,999.0,99.0
+1977,11,10,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-3.9,67,98300,35,779,290,18,0,18,2000,0,2000,580,270,9.3,10,10,16.1,1010,9,999999999,89,0.0500,0,88,999.000,999.0,99.0
+1977,11,10,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-3.9,67,98400,0,0,290,0,0,0,0,0,0,0,260,8.2,10,10,16.1,1160,9,999999999,89,0.0500,0,88,999.000,999.0,99.0
+1977,11,10,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-4.4,64,98500,0,0,289,0,0,0,0,0,0,0,270,8.2,10,10,19.3,1160,9,999999999,80,0.0500,0,88,999.000,999.0,99.0
+1977,11,10,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-3.9,67,98500,0,0,290,0,0,0,0,0,0,0,280,7.2,10,10,19.3,1010,9,999999999,89,0.0500,0,88,999.000,999.0,99.0
+1977,11,10,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-3.9,67,98500,0,0,290,0,0,0,0,0,0,0,290,5.2,10,10,19.3,1010,9,999999999,89,0.0500,0,88,999.000,999.0,99.0
+1977,11,10,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-3.3,70,98600,0,0,290,0,0,0,0,0,0,0,270,8.8,10,10,16.1,1010,9,999999999,89,0.0500,0,88,999.000,999.0,99.0
+1977,11,10,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-3.9,64,98700,0,0,292,0,0,0,0,0,0,0,280,8.2,10,10,19.3,1160,9,999999999,80,0.0500,0,88,999.000,999.0,99.0
+1977,11,10,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-5.0,57,98800,0,0,293,0,0,0,0,0,0,0,300,6.2,10,10,24.1,1400,9,999999999,80,0.0500,0,88,999.000,999.0,99.0
+1977,11,11,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-4.4,62,98800,0,0,291,0,0,0,0,0,0,0,310,7.7,10,10,19.3,1010,9,999999999,80,0.0500,0,88,999.000,999.0,99.0
+1977,11,11,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-3.9,64,98900,0,0,292,0,0,0,0,0,0,0,280,7.2,10,10,24.1,1010,9,999999999,80,0.0500,0,88,999.000,999.0,99.0
+1977,11,11,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-4.4,64,98900,0,0,289,0,0,0,0,0,0,0,270,6.7,10,10,24.1,1160,9,999999999,80,0.0500,0,88,999.000,999.0,99.0
+1977,11,11,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-4.4,67,99000,0,0,287,0,0,0,0,0,0,0,290,7.7,10,10,24.1,1010,9,999999999,80,0.0500,0,88,999.000,999.0,99.0
+1977,11,11,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-5.0,67,99100,0,0,284,0,0,0,0,0,0,0,300,7.2,10,10,24.1,880,9,999999999,80,0.0500,0,88,999.000,999.0,99.0
+1977,11,11,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-5.0,67,99100,0,0,284,0,0,0,0,0,0,0,300,8.2,10,10,24.1,1370,9,999999999,80,0.0500,0,88,999.000,999.0,99.0
+1977,11,11,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-5.0,72,99200,14,500,279,8,0,8,0,0,0,0,280,7.7,10,10,24.1,1160,9,999999999,80,0.0900,0,88,999.000,999.0,99.0
+1977,11,11,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-5.0,69,99300,194,1395,274,52,0,52,5800,0,5800,1680,270,7.7,9,9,24.1,1160,9,999999999,80,0.0900,0,88,999.000,999.0,99.0
+1977,11,11,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-5.6,64,99400,400,1395,250,194,447,61,19800,39200,8500,1160,280,7.7,1,1,24.1,77777,9,999999999,80,0.0900,0,88,999.000,999.0,99.0
+1977,11,11,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-5.0,59,99400,562,1395,267,390,642,126,39400,60100,15100,2350,300,7.7,5,5,24.1,77777,9,999999999,80,0.0900,0,88,999.000,999.0,99.0
+1977,11,11,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-5.6,57,99500,666,1395,276,260,118,203,28300,12000,22500,4980,300,7.7,8,8,24.1,1070,9,999999999,80,0.0900,0,88,999.000,999.0,99.0
+1977,11,11,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-5.0,53,99500,705,1395,271,420,496,165,44200,49800,18900,3490,300,7.7,4,4,24.1,77777,9,999999999,80,0.0900,0,88,999.000,999.0,99.0
+1977,11,11,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-6.1,52,99600,678,1395,274,305,230,191,32500,23700,20900,4240,290,7.2,7,7,24.1,1220,9,999999999,80,0.0900,0,88,999.000,999.0,99.0
+1977,11,11,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-5.6,53,99600,585,1395,273,360,539,130,37900,52300,15800,2560,310,8.2,6,6,24.1,1220,9,999999999,80,0.0900,0,88,999.000,999.0,99.0
+1977,11,11,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-6.1,52,99700,434,1395,270,214,298,119,22500,27300,14000,2380,300,6.7,6,6,24.1,1370,9,999999999,80,0.0900,0,88,999.000,999.0,99.0
+1977,11,11,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-6.1,52,99800,235,1395,264,97,182,65,10100,12400,8000,1240,310,6.2,3,3,24.1,77777,9,999999999,80,0.0900,0,88,999.000,999.0,99.0
+1977,11,11,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-5.6,59,99800,33,756,250,21,67,14,1800,2200,1700,240,290,3.6,0,0,24.1,77777,9,999999999,80,0.0900,0,88,999.000,999.0,99.0
+1977,11,11,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-5.6,67,99800,0,0,243,0,0,0,0,0,0,0,280,3.1,0,0,24.1,77777,9,999999999,80,0.0900,0,88,999.000,999.0,99.0
+1977,11,11,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-5.6,69,99900,0,0,241,0,0,0,0,0,0,0,260,2.6,0,0,24.1,77777,9,999999999,80,0.0900,0,88,999.000,999.0,99.0
+1977,11,11,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.6,75,99900,0,0,237,0,0,0,0,0,0,0,270,3.6,0,0,24.1,77777,9,999999999,80,0.0900,0,88,999.000,999.0,99.0
+1977,11,11,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-6.1,72,100000,0,0,237,0,0,0,0,0,0,0,300,3.1,0,0,24.1,77777,9,999999999,80,0.0900,0,88,999.000,999.0,99.0
+1977,11,11,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-6.7,66,100000,0,0,239,0,0,0,0,0,0,0,310,3.6,0,0,24.1,77777,9,999999999,69,0.0900,0,88,999.000,999.0,99.0
+1977,11,11,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-7.2,66,100000,0,0,236,0,0,0,0,0,0,0,310,4.1,0,0,24.1,77777,9,999999999,69,0.0900,0,88,999.000,999.0,99.0
+1977,11,11,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-7.2,69,100000,0,0,234,0,0,0,0,0,0,0,320,4.6,0,0,24.1,77777,9,999999999,69,0.0900,0,88,999.000,999.0,99.0
+1977,11,12,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-7.2,72,100000,0,0,232,0,0,0,0,0,0,0,320,5.2,0,0,24.1,77777,9,999999999,69,0.0900,0,88,999.000,999.0,99.0
+1977,11,12,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-7.2,69,100100,0,0,234,0,0,0,0,0,0,0,330,6.2,0,0,24.1,77777,9,999999999,69,0.0900,0,88,999.000,999.0,99.0
+1977,11,12,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-7.2,72,100100,0,0,232,0,0,0,0,0,0,0,320,6.2,0,0,24.1,77777,9,999999999,69,0.0900,0,88,999.000,999.0,99.0
+1977,11,12,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-7.2,75,100200,0,0,230,0,0,0,0,0,0,0,340,6.7,0,0,24.1,77777,9,999999999,69,0.0900,0,88,999.000,999.0,99.0
+1977,11,12,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-7.2,81,100300,0,0,227,0,0,0,0,0,0,0,320,4.6,0,0,24.1,77777,9,999999999,69,0.0900,0,88,999.000,999.0,99.0
+1977,11,12,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-8.3,72,100400,0,0,227,0,0,0,0,0,0,0,350,5.7,0,0,24.1,77777,9,999999999,69,0.0900,0,88,999.000,999.0,99.0
+1977,11,12,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-7.8,78,100500,13,477,231,5,10,4,0,0,0,0,320,6.2,1,1,24.1,77777,9,999999999,69,0.1310,0,88,999.000,999.0,99.0
+1977,11,12,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-8.9,63,100500,189,1396,231,85,295,43,8700,18100,6200,770,350,8.2,0,0,24.1,77777,9,999999999,69,0.1310,0,88,999.000,999.0,99.0
+1977,11,12,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-8.3,58,100600,395,1396,237,231,558,69,23500,48400,9800,1280,350,8.8,0,0,24.1,77777,9,999999999,69,0.1310,0,88,999.000,999.0,99.0
+1977,11,12,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-8.3,50,100700,556,1396,245,367,685,88,37900,65200,11800,1750,340,9.3,0,0,24.1,77777,9,999999999,69,0.1310,0,88,999.000,999.0,99.0
+1977,11,12,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-10.0,42,100700,660,1396,245,461,748,100,48000,73500,13100,2110,340,6.2,0,0,24.1,77777,9,999999999,60,0.1310,0,88,999.000,999.0,99.0
+1977,11,12,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-9.4,41,100700,700,1396,250,500,775,104,52300,76800,13600,2250,350,6.7,0,0,24.1,77777,9,999999999,60,0.1310,0,88,999.000,999.0,99.0
+1977,11,12,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-8.9,44,100700,673,1396,248,471,752,101,49100,74100,13200,2150,320,6.2,0,0,24.1,77777,9,999999999,69,0.1310,0,88,999.000,999.0,99.0
+1977,11,12,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-7.8,46,100700,580,1396,256,373,662,92,38600,63500,12100,1850,330,5.7,1,1,24.1,77777,9,999999999,69,0.1310,0,88,999.000,999.0,99.0
+1977,11,12,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-8.3,46,100700,429,1396,257,224,387,102,23200,34500,12500,1910,330,4.6,2,2,24.1,77777,9,999999999,69,0.1310,0,88,999.000,999.0,99.0
+1977,11,12,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-8.3,46,100700,230,1396,257,101,267,55,10300,18200,7300,1000,350,5.2,2,2,24.1,77777,9,999999999,69,0.1310,0,88,999.000,999.0,99.0
+1977,11,12,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-8.3,54,100700,31,733,249,12,21,10,1200,800,1200,210,350,3.6,2,2,24.1,77777,9,999999999,69,0.1310,0,88,999.000,999.0,99.0
+1977,11,12,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-7.8,59,100700,0,0,244,0,0,0,0,0,0,0,350,3.6,1,1,24.1,77777,9,999999999,69,0.1310,0,88,999.000,999.0,99.0
+1977,11,12,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-7.8,59,100800,0,0,239,0,0,0,0,0,0,0,350,4.1,0,0,24.1,77777,9,999999999,69,0.1310,0,88,999.000,999.0,99.0
+1977,11,12,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-7.8,66,100800,0,0,234,0,0,0,0,0,0,0,350,3.1,0,0,24.1,77777,9,999999999,69,0.1310,0,88,999.000,999.0,99.0
+1977,11,12,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-7.8,66,100800,0,0,234,0,0,0,0,0,0,0,310,2.6,0,0,24.1,77777,9,999999999,69,0.1310,0,88,999.000,999.0,99.0
+1977,11,12,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-7.8,66,100800,0,0,234,0,0,0,0,0,0,0,330,4.1,0,0,24.1,77777,9,999999999,69,0.1310,0,88,999.000,999.0,99.0
+1977,11,12,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-7.8,72,100800,0,0,230,0,0,0,0,0,0,0,320,3.6,0,0,24.1,77777,9,999999999,69,0.1310,0,88,999.000,999.0,99.0
+1977,11,12,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-7.8,75,100800,0,0,228,0,0,0,0,0,0,0,310,2.6,0,0,24.1,77777,9,999999999,69,0.1310,0,88,999.000,999.0,99.0
+1977,11,13,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-7.2,78,100800,0,0,244,0,0,0,0,0,0,0,310,2.6,6,6,24.1,2740,9,999999999,69,0.1310,0,88,999.000,999.0,99.0
+1977,11,13,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-6.7,78,100800,0,0,250,0,0,0,0,0,0,0,310,2.1,7,7,24.1,2740,9,999999999,69,0.1310,0,88,999.000,999.0,99.0
+1977,11,13,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-6.1,78,100800,0,0,256,0,0,0,0,0,0,0,310,3.1,8,8,24.1,2740,9,999999999,80,0.1310,0,88,999.000,999.0,99.0
+1977,11,13,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.6,75,100800,0,0,274,0,0,0,0,0,0,0,300,2.1,10,10,24.1,2740,9,999999999,80,0.1310,0,88,999.000,999.0,99.0
+1977,11,13,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-5.6,78,100800,0,0,264,0,0,0,0,0,0,0,300,1.5,9,9,24.1,2740,9,999999999,80,0.1310,0,88,999.000,999.0,99.0
+1977,11,13,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-5.6,81,100800,0,0,247,0,0,0,0,0,0,0,290,2.6,5,5,24.1,77777,9,999999999,80,0.1310,0,88,999.000,999.0,99.0
+1977,11,13,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-6.1,88,100700,11,454,241,8,11,7,0,0,0,0,160,2.6,8,5,24.1,2740,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1977,11,13,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-5.0,75,100700,184,1397,257,60,53,53,6500,3400,6000,1120,190,2.1,8,6,20.9,3050,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1977,11,13,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-3.9,72,100700,390,1397,267,191,264,115,19900,23100,13400,2310,160,3.6,10,7,19.3,5490,9,999999999,89,0.0620,0,88,999.000,999.0,99.0
+1977,11,13,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-3.3,62,100700,551,1397,283,202,137,147,22100,13500,16700,3440,190,4.1,10,8,16.1,3660,9,999999999,89,0.0620,0,88,999.000,999.0,99.0
+1977,11,13,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-3.9,55,100600,655,1397,293,240,56,214,26400,5600,23800,6160,170,4.6,10,9,24.1,3660,9,999999999,89,0.0620,0,88,999.000,999.0,99.0
+1977,11,13,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-3.3,57,100500,695,1397,283,328,225,215,35700,23000,24200,5350,200,5.7,10,7,24.1,4570,9,999999999,89,0.0620,0,88,999.000,999.0,99.0
+1977,11,13,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-4.4,53,100400,668,1397,282,251,128,189,27400,13100,21200,4640,170,6.2,10,7,24.1,4570,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1977,11,13,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-4.4,53,100300,576,1397,286,215,113,168,23400,11200,18800,3960,180,5.7,9,8,24.1,7620,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1977,11,13,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-4.4,53,100300,425,1397,292,126,67,105,13800,6100,11900,2850,170,5.2,10,9,24.1,2130,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1977,11,13,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-4.4,55,100200,226,1397,299,25,4,24,2900,0,2900,960,170,6.2,10,10,24.1,2130,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1977,11,13,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-3.9,60,100100,29,710,297,8,1,8,1000,0,1000,300,160,6.7,10,10,24.1,2740,9,999999999,89,0.0620,0,88,999.000,999.0,99.0
+1977,11,13,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-3.9,60,100000,0,0,297,0,0,0,0,0,0,0,160,7.2,10,10,24.1,3050,9,999999999,89,0.0620,0,88,999.000,999.0,99.0
+1977,11,13,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-3.3,62,100000,0,0,297,0,0,0,0,0,0,0,170,6.7,10,10,24.1,3050,9,999999999,89,0.0620,0,88,999.000,999.0,99.0
+1977,11,13,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-3.3,65,100000,0,0,295,0,0,0,0,0,0,0,170,5.7,10,10,24.1,3050,9,999999999,89,0.0620,0,88,999.000,999.0,99.0
+1977,11,13,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-3.9,62,100000,0,0,294,0,0,0,0,0,0,0,180,7.2,10,10,24.1,3050,9,999999999,89,0.0620,0,88,999.000,999.0,99.0
+1977,11,13,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-4.4,59,100000,0,0,294,0,0,0,0,0,0,0,180,4.6,10,10,24.1,2130,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1977,11,13,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-2.2,76,99900,0,0,292,0,0,0,0,0,0,0,170,6.7,10,10,9.7,1680,9,999999999,89,0.0620,0,88,999.000,999.0,99.0
+1977,11,13,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-0.6,89,99900,0,0,291,0,0,0,0,0,0,0,160,5.2,10,10,19.3,1680,9,999999999,100,0.0620,0,88,999.000,999.0,99.0
+1977,11,14,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-0.6,89,99800,0,0,291,0,0,0,0,0,0,0,160,5.2,10,10,19.3,1370,9,999999999,100,0.0620,0,88,999.000,999.0,99.0
+1977,11,14,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.1,85,99700,0,0,290,0,0,0,0,0,0,0,170,4.6,10,10,19.3,1370,9,999999999,100,0.0620,0,88,999.000,999.0,99.0
+1977,11,14,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-1.1,82,99700,0,0,293,0,0,0,0,0,0,0,150,4.6,10,10,24.1,1370,9,999999999,100,0.0620,0,88,999.000,999.0,99.0
+1977,11,14,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-1.7,79,99600,0,0,292,0,0,0,0,0,0,0,170,5.2,10,10,24.1,1160,9,999999999,100,0.0620,0,88,999.000,999.0,99.0
+1977,11,14,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-1.7,76,99600,0,0,294,0,0,0,0,0,0,0,170,4.1,10,10,24.1,1160,9,999999999,100,0.0620,0,88,999.000,999.0,99.0
+1977,11,14,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-1.7,76,99500,0,0,294,0,0,0,0,0,0,0,170,4.6,10,10,24.1,1160,9,999999999,100,0.0620,0,88,999.000,999.0,99.0
+1977,11,14,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-2.2,79,99500,10,431,268,3,3,3,0,0,0,0,160,3.6,6,6,24.1,1160,9,999999999,89,0.0810,0,88,999.000,999.0,99.0
+1977,11,14,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-1.7,76,99500,179,1397,255,86,390,34,8600,24600,5400,600,150,3.6,0,0,19.3,77777,9,999999999,100,0.0810,0,88,999.000,999.0,99.0
+1977,11,14,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-1.1,70,99500,384,1397,262,237,651,52,23800,56800,8100,1010,160,5.2,0,0,14.5,77777,9,999999999,100,0.0810,0,88,999.000,999.0,99.0
+1977,11,14,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,-0.6,65,99400,545,1397,269,369,758,66,37900,71800,9800,1360,170,4.6,0,0,14.5,77777,9,999999999,100,0.0810,0,88,999.000,999.0,99.0
+1977,11,14,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,-0.6,58,99400,649,1397,275,458,800,78,47300,77800,11000,1660,180,4.1,1,0,14.5,77777,9,999999999,100,0.0810,0,88,999.000,999.0,99.0
+1977,11,14,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,0.0,54,99200,689,1397,282,496,823,81,51400,80800,11400,1760,190,3.6,1,0,16.1,77777,9,999999999,110,0.0810,0,88,999.000,999.0,99.0
+1977,11,14,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,0.0,48,99100,663,1397,289,470,810,79,48800,79000,11200,1690,160,4.1,1,0,19.3,77777,9,999999999,110,0.0810,0,88,999.000,999.0,99.0
+1977,11,14,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,1.1,50,99000,571,1397,298,366,664,89,37900,63500,11800,1790,180,5.2,6,1,19.3,77777,9,999999999,110,0.0810,0,88,999.000,999.0,99.0
+1977,11,14,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,2.2,53,99000,420,1397,302,222,410,96,23100,36300,12100,1790,190,4.1,6,1,19.3,77777,9,999999999,120,0.0810,0,88,999.000,999.0,99.0
+1977,11,14,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,2.2,61,99000,222,1397,292,105,334,50,10800,22400,7200,900,180,3.6,6,1,19.3,77777,9,999999999,120,0.0810,0,88,999.000,999.0,99.0
+1977,11,14,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,2.2,71,99000,27,687,290,16,29,13,0,0,0,0,160,3.6,7,3,19.3,77777,9,999999999,120,0.0810,0,88,999.000,999.0,99.0
+1977,11,14,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,2.8,76,98900,0,0,291,0,0,0,0,0,0,0,140,3.1,8,4,19.3,77777,9,999999999,129,0.0810,0,88,999.000,999.0,99.0
+1977,11,14,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,3.9,83,98900,0,0,292,0,0,0,0,0,0,0,150,3.6,10,4,19.3,77777,9,999999999,139,0.0810,0,88,999.000,999.0,99.0
+1977,11,14,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,3.9,83,98900,0,0,311,0,0,0,0,0,0,0,150,3.1,10,9,16.1,7620,9,999999999,139,0.0810,0,88,999.000,999.0,99.0
+1977,11,14,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,3.3,83,98800,0,0,286,0,0,0,0,0,0,0,150,3.6,8,3,16.1,77777,9,999999999,129,0.0810,0,88,999.000,999.0,99.0
+1977,11,14,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,5.0,83,98700,0,0,317,0,0,0,0,0,0,0,180,4.1,10,9,14.5,1160,9,999999999,139,0.0810,0,88,999.000,999.0,99.0
+1977,11,14,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,3.9,86,98700,0,0,287,0,0,0,0,0,0,0,150,3.1,8,3,14.5,77777,9,999999999,129,0.0810,0,88,999.000,999.0,99.0
+1977,11,14,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,3.9,86,98600,0,0,287,0,0,0,0,0,0,0,160,3.1,5,3,14.5,77777,9,999999999,129,0.0810,0,88,999.000,999.0,99.0
+1977,11,15,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,5.0,80,98500,0,0,305,0,0,0,0,0,0,0,180,5.7,6,6,19.3,1370,9,999999999,139,0.0810,0,88,999.000,999.0,99.0
+1977,11,15,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.9,5.0,77,98400,0,0,293,0,0,0,0,0,0,0,180,4.6,1,1,24.1,77777,9,999999999,139,0.0810,0,88,999.000,999.0,99.0
+1977,11,15,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,4.4,86,98300,0,0,283,0,0,0,0,0,0,0,160,4.1,1,1,24.1,77777,9,999999999,139,0.0810,0,88,999.000,999.0,99.0
+1977,11,15,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,6.1,77,98200,0,0,329,0,0,0,0,0,0,0,200,5.2,9,9,14.5,1010,9,999999999,150,0.0810,0,88,999.000,999.0,99.0
+1977,11,15,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,6.7,89,98100,0,0,296,0,0,0,0,0,0,0,180,6.2,2,2,19.3,77777,9,999999999,160,0.0810,0,88,999.000,999.0,99.0
+1977,11,15,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,7.2,86,98100,0,0,336,0,0,0,0,0,0,0,190,6.7,10,10,19.3,1010,9,999999999,160,0.0810,0,88,999.000,999.0,99.0
+1977,11,15,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,7.2,83,98000,8,384,314,6,8,5,0,0,0,0,180,6.2,6,6,12.9,2440,9,999999999,160,0.0650,0,88,999.000,999.0,99.0
+1977,11,15,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,7.2,77,98000,173,1398,335,56,52,49,6000,3200,5600,1030,190,7.2,9,9,16.1,1010,9,999999999,160,0.0650,0,88,999.000,999.0,99.0
+1977,11,15,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,7.2,77,98000,379,1398,328,134,121,100,14500,10700,11600,2210,200,9.8,8,8,19.3,2440,9,999999999,160,0.0650,0,88,999.000,999.0,99.0
+1977,11,15,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.3,8.3,72,97900,540,1398,328,260,122,212,28400,11900,23800,5430,210,8.2,5,5,19.3,77777,9,999999999,170,0.0650,0,88,999.000,999.0,99.0
+1977,11,15,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,8.3,62,97900,644,1398,338,291,209,193,31600,21200,21800,4690,230,7.2,5,5,19.3,77777,9,999999999,170,0.0650,0,88,999.000,999.0,99.0
+1977,11,15,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.6,6.1,54,97800,684,1398,331,408,562,128,42000,55000,15000,2650,230,8.8,7,3,24.1,77777,9,999999999,150,0.0650,0,88,999.000,999.0,99.0
+1977,11,15,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,3.3,49,97900,658,1398,337,257,129,195,27900,13100,21700,4770,230,10.3,10,8,24.1,7620,9,999999999,129,0.0650,0,88,999.000,999.0,99.0
+1977,11,15,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,2.2,44,97900,566,1398,355,115,7,112,13300,500,13100,4670,230,7.7,10,10,24.1,7620,9,999999999,120,0.0650,0,88,999.000,999.0,99.0
+1977,11,15,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,2.2,42,97900,416,1398,358,111,5,109,12400,300,12300,3940,220,9.3,10,10,24.1,7620,9,999999999,120,0.0650,0,88,999.000,999.0,99.0
+1977,11,15,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,2.8,46,98000,218,1398,346,43,21,40,4800,1600,4500,1040,230,5.2,10,9,24.1,7620,9,999999999,129,0.0650,0,88,999.000,999.0,99.0
+1977,11,15,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.8,2.2,49,98000,26,687,325,12,10,11,0,0,0,0,230,4.6,8,7,24.1,7620,9,999999999,120,0.0650,0,88,999.000,999.0,99.0
+1977,11,15,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,2.2,51,98000,0,0,328,0,0,0,0,0,0,0,220,4.6,8,8,24.1,7620,9,999999999,120,0.0650,0,88,999.000,999.0,99.0
+1977,11,15,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,3.9,66,98000,0,0,303,0,0,0,0,0,0,0,210,3.6,7,3,24.1,77777,9,999999999,129,0.0650,0,88,999.000,999.0,99.0
+1977,11,15,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,5.6,77,98000,0,0,310,0,0,0,0,0,0,0,180,4.1,7,6,24.1,7620,9,999999999,150,0.0650,0,88,999.000,999.0,99.0
+1977,11,15,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,7.8,80,97900,0,0,345,0,0,0,0,0,0,0,180,4.1,10,10,24.1,3660,9,999999999,170,0.0650,0,88,999.000,999.0,99.0
+1977,11,15,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,10.6,86,97900,0,0,357,0,0,0,0,0,0,0,210,5.7,10,10,16.1,3660,9,999999999,200,0.0650,0,88,999.000,999.0,99.0
+1977,11,15,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.8,11.1,90,97900,0,0,358,0,0,0,0,0,0,0,210,5.2,10,10,14.5,3050,9,999999999,209,0.0650,0,88,999.000,999.0,99.0
+1977,11,15,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,12.2,10.6,90,97900,0,0,344,0,0,0,0,0,0,0,240,6.2,9,9,14.5,3050,9,999999999,200,0.0650,0,88,999.000,999.0,99.0
+1977,11,16,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.1,8.3,83,97900,0,0,336,0,0,0,0,0,0,0,250,5.2,9,9,14.5,7620,9,999999999,170,0.0650,0,88,999.000,999.0,99.0
+1977,11,16,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,8.3,2.2,66,98000,0,0,297,0,0,0,0,0,0,0,270,4.1,4,4,24.1,77777,9,999999999,120,0.0650,0,88,999.000,999.0,99.0
+1977,11,16,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,2.2,71,98000,0,0,312,0,0,0,0,0,0,0,280,4.1,9,9,24.1,2740,9,999999999,120,0.0650,0,88,999.000,999.0,99.0
+1977,11,16,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,2.8,74,98100,0,0,312,0,0,0,0,0,0,0,260,3.1,9,9,24.1,2740,9,999999999,129,0.0650,0,88,999.000,999.0,99.0
+1977,11,16,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,2.2,76,98100,0,0,296,0,0,0,0,0,0,0,280,4.1,7,7,24.1,2740,9,999999999,120,0.0650,0,88,999.000,999.0,99.0
+1977,11,16,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,1.1,82,98100,0,0,273,0,0,0,0,0,0,0,260,2.1,2,2,24.1,77777,9,999999999,110,0.0650,0,88,999.000,999.0,99.0
+1977,11,16,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,0.6,85,98200,7,361,277,4,6,4,0,0,0,0,240,3.1,7,6,24.1,2740,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1977,11,16,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,0.6,82,98200,168,1399,266,77,349,33,7700,21300,5100,580,250,3.1,1,1,19.3,77777,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1977,11,16,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,1.7,71,98200,374,1399,281,200,479,68,20200,40700,9300,1250,250,3.6,1,1,24.1,77777,9,999999999,120,0.0740,0,88,999.000,999.0,99.0
+1977,11,16,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,1.7,59,98300,535,1399,298,330,594,97,33700,55600,12300,1870,260,4.1,3,3,24.1,77777,9,999999999,120,0.0740,0,88,999.000,999.0,99.0
+1977,11,16,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,0.0,50,98200,639,1399,310,264,168,186,28700,17000,20900,4510,240,6.2,10,7,24.1,3960,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1977,11,16,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.0,-0.6,48,98200,679,1399,314,329,183,238,35400,18600,26300,5880,250,5.2,10,8,24.1,4570,9,999999999,100,0.0740,0,88,999.000,999.0,99.0
+1977,11,16,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,-0.6,43,98000,653,1399,306,360,431,155,37700,42700,17700,3180,270,6.7,6,3,24.1,77777,9,999999999,100,0.0740,0,88,999.000,999.0,99.0
+1977,11,16,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,-1.1,41,98000,562,1399,308,350,568,117,35500,53300,14000,2220,260,6.2,7,4,24.1,7620,9,999999999,100,0.0740,0,88,999.000,999.0,99.0
+1977,11,16,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,10.6,-1.1,45,98100,412,1399,332,73,4,72,8500,200,8400,2890,280,7.7,10,10,24.1,3050,9,999999999,100,0.0740,0,88,999.000,999.0,99.0
+1977,11,16,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,0.0,54,98100,214,1399,317,46,11,44,5200,200,5100,1560,230,7.2,10,9,24.1,3050,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1977,11,16,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,-0.6,52,98100,24,664,316,10,3,10,0,0,0,0,240,7.2,9,9,24.1,3050,9,999999999,100,0.0740,0,88,999.000,999.0,99.0
+1977,11,16,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,0.0,58,98100,0,0,312,0,0,0,0,0,0,0,230,4.1,9,9,24.1,3050,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1977,11,16,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,-0.6,56,98100,0,0,300,0,0,0,0,0,0,0,220,6.2,7,7,24.1,3050,9,999999999,100,0.0740,0,88,999.000,999.0,99.0
+1977,11,16,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,0.6,63,98100,0,0,303,0,0,0,0,0,0,0,240,7.7,8,8,24.1,3050,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1977,11,16,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,1.1,65,98100,0,0,319,0,0,0,0,0,0,0,240,5.7,10,10,24.1,1830,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1977,11,16,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,1.7,68,98000,0,0,320,0,0,0,0,0,0,0,240,4.1,10,10,24.1,1830,9,999999999,120,0.0740,0,88,999.000,999.0,99.0
+1977,11,16,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,2.2,74,98000,0,0,318,0,0,0,0,0,0,0,250,4.1,10,10,24.1,1830,9,999999999,120,0.0740,0,88,999.000,999.0,99.0
+1977,11,16,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,2.2,76,97900,0,0,316,0,0,0,0,0,0,0,260,3.6,10,10,24.1,1830,9,999999999,120,0.0740,0,88,999.000,999.0,99.0
+1977,11,17,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,2.2,79,97900,0,0,313,0,0,0,0,0,0,0,220,4.1,10,10,19.3,1680,9,999999999,120,0.0740,0,88,999.000,999.0,99.0
+1977,11,17,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,2.2,82,98000,0,0,311,0,0,0,0,0,0,0,210,5.2,10,10,19.3,1370,9,999999999,120,0.0740,0,88,999.000,999.0,99.0
+1977,11,17,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,1.7,79,97900,0,0,291,0,0,0,0,0,0,0,230,5.2,7,7,24.1,2740,9,999999999,120,0.0740,0,88,999.000,999.0,99.0
+1977,11,17,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,1.1,86,97900,0,0,270,0,0,0,0,0,0,0,240,4.6,2,2,24.1,77777,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1977,11,17,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,1.1,89,98000,0,0,273,0,0,0,0,0,0,0,230,4.6,4,4,24.1,77777,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1977,11,17,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,0.6,92,98000,0,0,260,0,0,0,0,0,0,0,250,5.2,1,1,24.1,77777,9,999999999,110,0.0740,0,88,999.000,999.0,99.0
+1977,11,17,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,0.0,92,98000,6,338,261,5,22,3,0,0,0,0,240,6.2,2,2,11.3,77777,9,999999999,110,0.0600,0,88,999.000,999.0,99.0
+1977,11,17,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,0.0,85,98000,163,1399,282,45,36,41,5000,2500,4700,980,230,7.7,8,8,11.3,240,9,999999999,110,0.0600,0,88,999.000,999.0,99.0
+1977,11,17,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,0.0,79,98000,369,1399,269,215,550,66,21800,46600,9500,1210,220,6.2,2,2,11.3,77777,9,999999999,110,0.0600,0,88,999.000,999.0,99.0
+1977,11,17,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,0.0,70,98100,530,1399,285,244,287,133,26000,28000,15300,2700,260,9.3,6,6,12.9,550,9,999999999,110,0.0600,0,88,999.000,999.0,99.0
+1977,11,17,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,-1.1,56,98000,634,1399,289,380,562,120,38900,54300,14200,2400,250,7.7,4,4,19.3,77777,9,999999999,100,0.0600,0,88,999.000,999.0,99.0
+1977,11,17,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,-2.8,49,98000,674,1399,300,199,51,174,21900,5000,19400,5310,250,10.8,8,8,24.1,2130,9,999999999,89,0.0600,0,88,999.000,999.0,99.0
+1977,11,17,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,-2.2,56,98100,648,1399,296,297,147,228,32000,14800,25100,5550,250,11.3,8,8,24.1,1070,9,999999999,89,0.0600,0,88,999.000,999.0,99.0
+1977,11,17,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,-2.2,58,98100,557,1399,294,180,66,154,19800,6400,17300,4360,250,10.3,8,8,24.1,1070,9,999999999,89,0.0600,0,88,999.000,999.0,99.0
+1977,11,17,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,-2.8,55,98100,408,1399,299,166,205,105,17600,18300,12200,2060,260,8.8,9,9,24.1,1160,9,999999999,89,0.0600,0,88,999.000,999.0,99.0
+1977,11,17,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,-2.8,55,98200,211,1399,299,39,43,33,4400,3000,4000,700,250,6.2,9,9,24.1,1680,9,999999999,89,0.0600,0,88,999.000,999.0,99.0
+1977,11,17,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,-2.8,55,98300,23,641,308,14,1,14,0,0,0,0,270,7.7,10,10,24.1,1680,9,999999999,89,0.0600,0,88,999.000,999.0,99.0
+1977,11,17,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,-2.8,53,98300,0,0,310,0,0,0,0,0,0,0,250,8.2,10,10,24.1,1680,9,999999999,89,0.0600,0,88,999.000,999.0,99.0
+1977,11,17,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,-2.8,55,98300,0,0,308,0,0,0,0,0,0,0,260,8.2,10,10,24.1,1160,9,999999999,89,0.0600,0,88,999.000,999.0,99.0
+1977,11,17,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,-2.8,62,98400,0,0,281,0,0,0,0,0,0,0,260,8.8,7,7,24.1,1680,9,999999999,89,0.0600,0,88,999.000,999.0,99.0
+1977,11,17,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,-3.3,60,98400,0,0,300,0,0,0,0,0,0,0,280,9.3,10,10,24.1,1400,9,999999999,89,0.0600,0,88,999.000,999.0,99.0
+1977,11,17,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.9,-3.3,60,98500,0,0,300,0,0,0,0,0,0,0,270,6.7,10,10,24.1,1400,9,999999999,89,0.0600,0,88,999.000,999.0,99.0
+1977,11,17,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-3.9,60,98500,0,0,297,0,0,0,0,0,0,0,270,7.7,10,10,24.1,1400,9,999999999,89,0.0600,0,88,999.000,999.0,99.0
+1977,11,17,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-3.9,60,98600,0,0,297,0,0,0,0,0,0,0,280,6.2,10,10,24.1,1680,9,999999999,89,0.0600,0,88,999.000,999.0,99.0
+1977,11,18,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-3.3,62,98700,0,0,297,0,0,0,0,0,0,0,260,9.3,10,10,24.1,2130,9,999999999,89,0.0600,0,88,999.000,999.0,99.0
+1977,11,18,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-3.3,62,98700,0,0,297,0,0,0,0,0,0,0,270,7.7,10,10,24.1,1160,9,999999999,89,0.0600,0,88,999.000,999.0,99.0
+1977,11,18,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-3.9,62,98800,0,0,294,0,0,0,0,0,0,0,270,9.3,10,10,24.1,1010,9,999999999,89,0.0600,0,88,999.000,999.0,99.0
+1977,11,18,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-3.9,62,98900,0,0,294,0,0,0,0,0,0,0,280,8.8,10,10,24.1,1010,9,999999999,89,0.0600,0,88,999.000,999.0,99.0
+1977,11,18,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-3.9,64,98900,0,0,292,0,0,0,0,0,0,0,300,7.2,10,10,24.1,880,9,999999999,80,0.0600,0,88,999.000,999.0,99.0
+1977,11,18,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-3.9,64,99000,0,0,292,0,0,0,0,0,0,0,270,7.2,10,10,24.1,880,9,999999999,80,0.0600,0,88,999.000,999.0,99.0
+1977,11,18,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-4.4,62,99100,5,315,291,1,0,1,0,0,0,0,300,5.7,10,10,24.1,1010,9,999999999,80,0.0720,0,88,999.000,999.0,99.0
+1977,11,18,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-4.4,62,99200,158,1400,291,27,8,26,3000,500,2900,670,300,6.7,10,10,24.1,1010,9,999999999,80,0.0720,0,88,999.000,999.0,99.0
+1977,11,18,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-4.4,62,99300,363,1400,291,120,4,119,13200,200,13100,3830,270,7.7,10,10,24.1,1010,9,999999999,80,0.0720,0,88,999.000,999.0,99.0
+1977,11,18,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-5.0,57,99300,524,1400,293,147,7,144,16500,500,16300,5380,290,7.7,10,10,24.1,1010,9,999999999,80,0.0720,0,88,999.000,999.0,99.0
+1977,11,18,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-5.0,53,99300,629,1400,267,429,771,76,44400,74600,10700,1600,290,8.2,3,2,24.1,77777,9,999999999,80,0.0720,0,88,999.000,999.0,99.0
+1977,11,18,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,-5.6,47,99400,670,1400,273,417,608,121,43000,59400,14500,2490,290,7.7,7,3,24.1,77777,9,999999999,80,0.0720,0,88,999.000,999.0,99.0
+1977,11,18,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,-4.4,47,99400,644,1400,279,404,576,135,41300,55400,15700,2670,250,7.7,7,3,24.1,77777,9,999999999,80,0.0720,0,88,999.000,999.0,99.0
+1977,11,18,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,-3.9,51,99400,553,1400,277,360,693,81,37500,66000,11300,1630,280,6.2,3,3,24.1,77777,9,999999999,89,0.0720,0,88,999.000,999.0,99.0
+1977,11,18,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,-4.4,47,99400,404,1400,267,256,696,51,26200,61700,8300,1020,290,7.2,0,0,24.1,77777,9,999999999,80,0.0720,0,88,999.000,999.0,99.0
+1977,11,18,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,-4.4,49,99500,207,1400,265,106,463,35,10700,31400,6000,640,270,5.2,0,0,24.1,77777,9,999999999,80,0.0720,0,88,999.000,999.0,99.0
+1977,11,18,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-4.4,59,99500,21,618,255,16,61,10,0,0,0,0,270,3.1,0,0,24.1,77777,9,999999999,80,0.0720,0,88,999.000,999.0,99.0
+1977,11,18,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-3.9,67,99600,0,0,251,0,0,0,0,0,0,0,230,2.1,0,0,24.1,77777,9,999999999,89,0.0720,0,88,999.000,999.0,99.0
+1977,11,18,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-3.9,67,99600,0,0,256,0,0,0,0,0,0,0,260,3.6,1,1,24.1,77777,9,999999999,89,0.0720,0,88,999.000,999.0,99.0
+1977,11,18,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-3.3,65,99700,0,0,273,0,0,0,0,0,0,0,260,2.1,6,6,24.1,3050,9,999999999,89,0.0720,0,88,999.000,999.0,99.0
+1977,11,18,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-3.3,67,99800,0,0,284,0,0,0,0,0,0,0,240,3.1,9,9,24.1,3050,9,999999999,89,0.0720,0,88,999.000,999.0,99.0
+1977,11,18,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-3.3,67,99800,0,0,278,0,0,0,0,0,0,0,260,2.1,8,8,24.1,3050,9,999999999,89,0.0720,0,88,999.000,999.0,99.0
+1977,11,18,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-2.8,73,99800,0,0,263,0,0,0,0,0,0,0,240,2.6,8,3,24.1,77777,9,999999999,89,0.0720,0,88,999.000,999.0,99.0
+1977,11,18,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-2.8,73,99900,0,0,252,0,0,0,0,0,0,0,250,2.6,0,0,24.1,77777,9,999999999,89,0.0720,0,88,999.000,999.0,99.0
+1977,11,19,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-3.3,82,99900,0,0,260,0,0,0,0,0,0,0,250,1.5,6,6,24.1,3660,9,999999999,89,0.0720,0,88,999.000,999.0,99.0
+1977,11,19,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-3.3,79,100000,0,0,283,0,0,0,0,0,0,0,300,1.5,10,10,24.1,3660,9,999999999,89,0.0720,0,88,999.000,999.0,99.0
+1977,11,19,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-2.8,76,99900,0,0,288,0,0,0,0,0,0,0,360,4.1,10,10,24.1,3660,9,999999999,89,0.0720,0,88,999.000,999.0,99.0
+1977,11,19,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-3.9,75,100000,0,0,269,0,0,0,0,0,0,0,0,0.0,8,8,24.1,3660,9,999999999,89,0.0720,0,88,999.000,999.0,99.0
+1977,11,19,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-3.9,72,100000,0,0,285,0,0,0,0,0,0,0,320,1.5,10,10,24.1,3050,9,999999999,89,0.0720,0,88,999.000,999.0,99.0
+1977,11,19,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-3.9,70,100000,0,0,287,0,0,0,0,0,0,0,20,3.1,10,10,24.1,2440,9,999999999,89,0.0720,0,88,999.000,999.0,99.0
+1977,11,19,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-2.2,76,100000,4,268,292,0,0,0,0,0,0,0,50,3.1,10,10,19.3,2440,9,999999999,89,0.0800,0,88,999.000,999.0,99.0
+1977,11,19,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-1.1,73,100100,154,1400,300,44,2,44,4900,0,4900,1360,300,1.5,10,10,19.3,2440,9,999999999,100,0.0800,0,88,999.000,999.0,99.0
+1977,11,19,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,0.0,70,100100,358,1400,308,87,5,85,9700,200,9700,3080,160,3.6,10,10,14.5,2440,9,999999999,110,0.0800,0,88,999.000,999.0,99.0
+1977,11,19,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,0.6,71,100200,519,1400,312,150,10,146,16800,700,16600,5400,140,3.6,10,10,11.3,3050,9,999999999,110,0.0800,0,88,999.000,999.0,99.0
+1977,11,19,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,0.6,65,100100,624,1400,316,185,8,181,20900,600,20600,6930,120,4.6,10,10,11.3,3050,9,999999999,110,0.0800,0,88,999.000,999.0,99.0
+1977,11,19,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,0.6,63,100000,665,1400,319,184,5,182,21000,400,20800,7230,130,6.2,10,10,11.3,3050,9,999999999,110,0.0800,0,88,999.000,999.0,99.0
+1977,11,19,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.8,-0.6,56,99900,639,1400,320,189,6,186,21300,500,21100,7160,120,6.2,10,10,11.3,3050,9,999999999,100,0.0800,0,88,999.000,999.0,99.0
+1977,11,19,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,0.6,63,99800,549,1400,319,165,1,165,18500,100,18500,6030,110,6.2,10,10,11.3,2440,9,999999999,110,0.0800,0,88,999.000,999.0,99.0
+1977,11,19,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,0.6,63,99700,400,1400,319,116,2,115,12900,100,12800,3990,120,6.2,10,10,11.3,1680,9,999999999,110,0.0800,0,88,999.000,999.0,99.0
+1977,11,19,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,0.0,60,99700,204,1400,318,62,1,62,6800,0,6800,1910,120,6.7,10,10,11.3,1400,9,999999999,110,0.0800,0,88,999.000,999.0,99.0
+1977,11,19,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,1.1,68,99700,20,595,317,7,0,7,0,0,0,0,110,7.7,10,10,11.3,1160,9,999999999,110,0.0800,0,88,999.000,999.0,99.0
+1977,11,19,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,2.8,83,99600,0,0,314,0,0,0,0,0,0,0,120,8.8,10,10,11.3,1010,9,999999999,129,0.0800,0,88,999.000,999.0,99.0
+1977,11,19,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,2.2,79,99600,0,0,313,0,0,0,0,0,0,0,120,8.2,10,10,11.3,1160,9,999999999,120,0.0800,0,88,999.000,999.0,99.0
+1977,11,19,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,2.8,86,99500,0,0,311,0,0,0,0,0,0,0,120,7.7,10,10,11.3,1160,9,999999999,129,0.0800,0,88,999.000,999.0,99.0
+1977,11,19,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,2.8,83,99400,0,0,314,0,0,0,0,0,0,0,130,8.2,10,10,11.3,1160,9,999999999,129,0.0800,0,88,999.000,999.0,99.0
+1977,11,19,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,2.2,76,99400,0,0,316,0,0,0,0,0,0,0,130,8.2,10,10,14.5,1160,9,999999999,120,0.0800,0,88,999.000,999.0,99.0
+1977,11,19,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,1.1,73,99300,0,0,312,0,0,0,0,0,0,0,130,8.2,10,10,19.3,1010,9,999999999,110,0.0800,0,88,999.000,999.0,99.0
+1977,11,19,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,1.7,76,99200,0,0,313,0,0,0,0,0,0,0,130,6.2,10,10,11.3,1010,9,999999999,120,0.0800,0,88,999.000,999.0,99.0
+1977,11,20,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,1.7,73,99100,0,0,315,0,0,0,0,0,0,0,140,6.2,10,10,19.3,1010,9,999999999,120,0.0800,0,88,999.000,999.0,99.0
+1977,11,20,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,2.2,71,98900,0,0,321,0,0,0,0,0,0,0,160,7.2,10,10,24.1,2440,9,999999999,120,0.0800,0,88,999.000,999.0,99.0
+1977,11,20,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,3.3,80,98900,0,0,320,0,0,0,0,0,0,0,170,3.1,10,10,11.3,880,9,999999999,129,0.0800,0,88,999.000,999.0,99.0
+1977,11,20,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,4.4,83,98900,0,0,323,0,0,0,0,0,0,0,170,7.2,10,10,12.9,760,9,999999999,139,0.0800,0,88,999.000,999.0,99.0
+1977,11,20,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.2,5.0,86,98700,0,0,324,0,0,0,0,0,0,0,160,7.7,10,10,11.3,580,9,999999999,139,0.0800,0,88,999.000,999.0,99.0
+1977,11,20,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,5.6,86,98700,0,0,327,0,0,0,0,0,0,0,180,9.3,10,10,19.3,1010,9,999999999,150,0.0800,0,88,999.000,999.0,99.0
+1977,11,20,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,6.7,86,98600,3,245,334,3,0,3,0,0,0,0,170,8.2,10,10,19.3,460,9,999999999,160,0.0630,0,88,999.000,999.0,99.0
+1977,11,20,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,7.2,86,98600,149,1401,336,42,1,42,4600,0,4600,1310,180,8.2,10,10,19.3,430,9,999999999,160,0.0630,0,88,999.000,999.0,99.0
+1977,11,20,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,8.3,83,98500,353,1401,346,119,1,118,13000,100,12900,3740,180,9.3,10,10,19.3,430,9,999999999,170,0.0630,0,88,999.000,999.0,99.0
+1977,11,20,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,9.4,90,98500,514,1401,347,100,1,99,11500,100,11500,4060,180,10.8,10,10,4.8,340,9,999999999,189,0.0630,0,88,999.000,999.0,99.0
+1977,11,20,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,9.4,86,98400,619,1401,350,129,0,129,15000,0,15000,5420,190,8.8,10,10,8.0,430,9,999999999,189,0.0630,0,88,999.000,999.0,99.0
+1977,11,20,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.7,8.9,83,98300,660,1401,350,238,0,238,26500,0,26500,8470,180,12.4,10,10,9.7,370,9,999999999,179,0.0630,0,88,999.000,999.0,99.0
+1977,11,20,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,12.2,10.0,86,98100,635,1401,353,215,2,214,24000,200,23900,7770,190,11.3,10,10,9.7,310,9,999999999,189,0.0630,0,88,999.000,999.0,99.0
+1977,11,20,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,13.9,11.7,87,98100,545,1401,364,180,1,179,19900,100,19900,6300,170,11.3,10,10,9.7,340,9,999999999,209,0.0630,0,88,999.000,999.0,99.0
+1977,11,20,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,14.4,12.2,87,98100,397,1401,367,141,0,141,15400,0,15400,4440,180,10.8,10,10,11.3,370,9,999999999,220,0.0630,0,88,999.000,999.0,99.0
+1977,11,20,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,12.2,84,98100,201,1401,370,57,1,57,6300,0,6300,1800,190,10.3,10,10,12.9,460,9,999999999,220,0.0630,0,88,999.000,999.0,99.0
+1977,11,20,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,15.0,12.2,84,98200,19,595,370,6,0,6,0,0,0,0,200,9.8,10,10,12.9,520,9,999999999,220,0.0630,0,88,999.000,999.0,99.0
+1977,11,20,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,11.7,6.7,72,98500,0,0,347,0,0,0,0,0,0,0,270,9.3,10,10,24.1,1010,9,999999999,160,0.0630,0,88,999.000,999.0,99.0
+1977,11,20,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,10.0,2.8,61,98600,0,0,334,0,0,0,0,0,0,0,260,7.2,10,10,24.1,1400,9,999999999,129,0.0630,0,88,999.000,999.0,99.0
+1977,11,20,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,9.4,2.2,61,98800,0,0,310,0,0,0,0,0,0,0,250,8.2,7,7,24.1,1830,9,999999999,120,0.0630,0,88,999.000,999.0,99.0
+1977,11,20,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,1.7,66,98900,0,0,289,0,0,0,0,0,0,0,240,10.3,2,2,24.1,77777,9,999999999,120,0.0630,0,88,999.000,999.0,99.0
+1977,11,20,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,-3.3,55,99100,0,0,273,0,0,0,0,0,0,0,250,6.7,7,2,24.1,77777,9,999999999,89,0.0630,0,88,999.000,999.0,99.0
+1977,11,20,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-5.6,55,99200,0,0,254,0,0,0,0,0,0,0,250,10.3,0,0,24.1,77777,9,999999999,80,0.0630,0,88,999.000,999.0,99.0
+1977,11,20,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-6.7,54,99300,0,0,248,0,0,0,0,0,0,0,240,8.8,0,0,24.1,77777,9,999999999,69,0.0630,0,88,999.000,999.0,99.0
+1977,11,21,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-7.8,54,99300,0,0,244,0,0,0,0,0,0,0,250,9.3,0,0,24.1,77777,9,999999999,69,0.0630,0,88,999.000,999.0,99.0
+1977,11,21,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-7.8,59,99400,0,0,250,0,0,0,0,0,0,0,240,6.2,3,3,24.1,77777,9,999999999,69,0.0630,0,88,999.000,999.0,99.0
+1977,11,21,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-7.8,61,99500,0,0,245,0,0,0,0,0,0,0,250,9.8,2,2,24.1,77777,9,999999999,69,0.0630,0,88,999.000,999.0,99.0
+1977,11,21,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-8.3,63,99600,0,0,233,0,0,0,0,0,0,0,250,7.7,0,0,24.1,77777,9,999999999,69,0.0630,0,88,999.000,999.0,99.0
+1977,11,21,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-8.3,66,99700,0,0,231,0,0,0,0,0,0,0,280,8.2,0,0,24.1,77777,9,999999999,69,0.0630,0,88,999.000,999.0,99.0
+1977,11,21,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-8.3,72,99700,0,0,227,0,0,0,0,0,0,0,270,7.7,0,0,24.1,77777,9,999999999,69,0.0630,0,88,999.000,999.0,99.0
+1977,11,21,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-8.9,71,99900,3,222,225,2,3,2,0,0,0,0,250,8.8,0,0,24.1,77777,9,999999999,60,0.1190,0,88,999.000,999.0,99.0
+1977,11,21,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-8.9,66,100000,144,1402,229,59,226,35,6000,11800,4800,630,270,9.8,1,0,24.1,77777,9,999999999,69,0.1190,0,88,999.000,999.0,99.0
+1977,11,21,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-8.3,66,100100,348,1402,231,199,504,69,19900,41600,9500,1240,290,8.2,4,0,24.1,77777,9,999999999,69,0.1190,0,88,999.000,999.0,99.0
+1977,11,21,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-8.3,58,100100,509,1402,242,295,495,111,30900,46400,13900,2110,270,6.2,4,1,24.1,77777,9,999999999,69,0.1190,0,88,999.000,999.0,99.0
+1977,11,21,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-8.3,54,100200,614,1402,241,421,725,96,43600,70300,12700,1960,280,9.3,2,0,24.1,77777,9,999999999,69,0.1190,0,88,999.000,999.0,99.0
+1977,11,21,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-8.3,50,100200,656,1402,245,457,757,96,47700,74300,12800,2030,270,7.2,1,0,24.1,77777,9,999999999,69,0.1190,0,88,999.000,999.0,99.0
+1977,11,21,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-8.3,48,100200,631,1402,252,416,701,94,43300,68400,12400,1950,270,7.2,1,1,24.1,77777,9,999999999,69,0.1190,0,88,999.000,999.0,99.0
+1977,11,21,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-8.3,46,100200,541,1402,254,336,603,99,34400,56600,12500,1910,280,6.2,3,1,24.1,77777,9,999999999,69,0.1190,0,88,999.000,999.0,99.0
+1977,11,21,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-8.9,46,100300,393,1402,255,184,263,108,19300,23100,12700,2140,270,6.2,8,2,24.1,77777,9,999999999,69,0.1190,0,88,999.000,999.0,99.0
+1977,11,21,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-8.3,52,100300,198,1402,251,78,177,52,8100,10800,6600,980,270,7.2,7,2,24.1,77777,9,999999999,69,0.1190,0,88,999.000,999.0,99.0
+1977,11,21,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-8.3,56,100500,18,572,249,8,10,7,0,0,0,0,250,5.2,4,3,24.1,77777,9,999999999,69,0.1190,0,88,999.000,999.0,99.0
+1977,11,21,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-8.9,58,100500,0,0,234,0,0,0,0,0,0,0,270,5.2,0,0,24.1,77777,9,999999999,60,0.1190,0,88,999.000,999.0,99.0
+1977,11,21,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-8.9,61,100500,0,0,233,0,0,0,0,0,0,0,280,6.2,0,0,24.1,77777,9,999999999,69,0.1190,0,88,999.000,999.0,99.0
+1977,11,21,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-9.4,61,100500,0,0,230,0,0,0,0,0,0,0,280,4.1,0,0,24.1,77777,9,999999999,60,0.1190,0,88,999.000,999.0,99.0
+1977,11,21,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-10.0,58,100600,0,0,237,0,0,0,0,0,0,0,290,5.7,2,2,24.1,77777,9,999999999,60,0.1190,0,88,999.000,999.0,99.0
+1977,11,21,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-11.1,58,100500,0,0,232,0,0,0,0,0,0,0,310,5.2,6,2,24.1,77777,9,999999999,60,0.1190,0,88,999.000,999.0,99.0
+1977,11,21,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-11.7,55,100500,0,0,259,0,0,0,0,0,0,0,320,6.7,10,10,24.1,3660,9,999999999,60,0.1190,0,88,999.000,999.0,99.0
+1977,11,21,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-11.7,58,100500,0,0,234,0,0,0,0,0,0,0,300,4.1,10,4,24.1,77777,9,999999999,60,0.1190,0,88,999.000,999.0,99.0
+1977,11,22,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-11.7,58,100600,0,0,233,0,0,0,0,0,0,0,320,5.2,10,3,24.1,77777,9,999999999,60,0.1190,0,88,999.000,999.0,99.0
+1977,11,22,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-11.7,58,100600,0,0,233,0,0,0,0,0,0,0,10,2.6,10,3,24.1,77777,9,999999999,60,0.1190,0,88,999.000,999.0,99.0
+1977,11,22,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-11.1,60,100600,0,0,233,0,0,0,0,0,0,0,30,2.6,10,3,24.1,77777,9,999999999,60,0.1190,0,88,999.000,999.0,99.0
+1977,11,22,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-11.7,55,100600,0,0,234,0,0,0,0,0,0,0,50,2.1,10,3,24.1,77777,9,999999999,60,0.1190,0,88,999.000,999.0,99.0
+1977,11,22,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-11.7,55,100600,0,0,234,0,0,0,0,0,0,0,360,3.1,10,3,24.1,77777,9,999999999,60,0.1190,0,88,999.000,999.0,99.0
+1977,11,22,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-11.1,60,100600,0,0,233,0,0,0,0,0,0,0,360,1.5,10,3,24.1,77777,9,999999999,60,0.1190,0,88,999.000,999.0,99.0
+1977,11,22,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.9,-10.6,60,100600,2,199,248,0,0,0,0,0,0,0,10,3.6,10,8,24.1,2740,9,999999999,60,0.1060,0,88,999.000,999.0,99.0
+1977,11,22,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-9.4,63,100600,139,1402,256,29,9,28,3200,600,3100,690,310,2.1,10,9,19.3,2740,9,999999999,60,0.1060,0,88,999.000,999.0,99.0
+1977,11,22,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-7.8,61,100500,344,1402,274,83,31,75,9100,2700,8400,2000,280,2.1,10,10,17.7,2740,9,999999999,69,0.1060,0,88,999.000,999.0,99.0
+1977,11,22,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-6.7,59,100500,505,1402,282,113,1,113,13000,100,12900,4450,130,3.1,10,10,17.7,1220,9,999999999,69,0.1060,0,88,999.000,999.0,99.0
+1977,11,22,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-5.6,62,100400,610,1402,285,165,10,160,18700,800,18400,6290,150,4.6,10,10,16.1,4570,9,999999999,80,0.1060,0,88,999.000,999.0,99.0
+1977,11,22,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-5.0,59,100200,651,1402,291,176,4,174,20000,300,19900,6920,140,4.6,10,10,19.3,3050,9,999999999,80,0.1060,0,88,999.000,999.0,99.0
+1977,11,22,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-5.6,53,100200,627,1402,295,162,9,158,18500,700,18200,6330,140,3.6,10,10,16.1,3050,9,999999999,80,0.1060,0,88,999.000,999.0,99.0
+1977,11,22,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-6.1,48,100100,537,1402,297,148,5,146,16700,400,16600,5500,70,4.6,10,10,19.3,3050,9,999999999,80,0.1060,0,88,999.000,999.0,99.0
+1977,11,22,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-5.6,51,100000,390,1402,289,138,74,117,15100,6600,13200,2980,90,4.1,10,9,19.3,3050,9,999999999,80,0.1060,0,88,999.000,999.0,99.0
+1977,11,22,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-5.0,55,100000,195,1402,281,58,6,57,6300,100,6300,1780,70,6.2,10,8,24.1,3050,9,999999999,80,0.1060,0,88,999.000,999.0,99.0
+1977,11,22,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-4.4,57,99900,17,549,282,9,4,8,0,0,0,0,90,5.2,8,8,24.1,3050,9,999999999,80,0.1060,0,88,999.000,999.0,99.0
+1977,11,22,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-3.9,60,99800,0,0,278,0,0,0,0,0,0,0,100,7.2,7,7,24.1,2440,9,999999999,89,0.1060,0,88,999.000,999.0,99.0
+1977,11,22,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-4.4,62,99800,0,0,252,0,0,0,0,0,0,0,120,6.2,0,0,24.1,77777,9,999999999,80,0.1060,0,88,999.000,999.0,99.0
+1977,11,22,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-5.0,62,99700,0,0,250,0,0,0,0,0,0,0,120,6.7,0,0,24.1,77777,9,999999999,80,0.1060,0,88,999.000,999.0,99.0
+1977,11,22,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-5.0,62,99700,0,0,270,0,0,0,0,0,0,0,110,4.1,7,7,19.3,1830,9,999999999,80,0.1060,0,88,999.000,999.0,99.0
+1977,11,22,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-4.4,59,99600,0,0,286,0,0,0,0,0,0,0,90,6.2,9,9,19.3,1830,9,999999999,80,0.1060,0,88,999.000,999.0,99.0
+1977,11,22,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-3.9,64,99500,0,0,270,0,0,0,0,0,0,0,120,6.7,6,6,19.3,1830,9,999999999,89,0.1060,0,88,999.000,999.0,99.0
+1977,11,22,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-3.3,67,99500,0,0,284,0,0,0,0,0,0,0,130,4.6,9,9,19.3,1830,9,999999999,89,0.1060,0,88,999.000,999.0,99.0
+1977,11,23,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-3.9,64,99400,0,0,292,0,0,0,0,0,0,0,130,4.6,10,10,19.3,1370,9,999999999,89,0.1060,0,88,999.000,999.0,99.0
+1977,11,23,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-3.3,70,99400,0,0,290,0,0,0,0,0,0,0,140,5.2,10,10,16.1,1010,9,999999999,89,0.1060,0,88,999.000,999.0,99.0
+1977,11,23,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-2.8,73,99300,0,0,291,0,0,0,0,0,0,0,120,4.1,10,10,16.1,460,9,999999999,89,0.1060,0,88,999.000,999.0,99.0
+1977,11,23,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-1.7,79,99200,0,0,292,0,0,0,0,0,0,0,130,3.6,10,10,12.9,430,9,999999999,100,0.1060,0,88,999.000,999.0,99.0
+1977,11,23,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,0.0,92,99100,0,0,291,0,0,0,0,0,0,0,160,3.1,10,10,6.4,340,9,999999999,110,0.1060,0,88,999.000,999.0,99.0
+1977,11,23,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,0.6,96,99000,0,0,292,0,0,0,0,0,0,0,140,4.1,10,10,6.4,180,9,999999999,110,0.1060,0,88,999.000,999.0,99.0
+1977,11,23,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,0.6,89,99000,1,175,297,0,0,0,0,0,0,0,160,3.1,10,10,4.0,150,9,999999999,110,0.1250,0,88,999.000,999.0,99.0
+1977,11,23,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,1.1,92,98900,134,1403,297,21,3,20,2300,0,2300,730,140,3.6,10,10,2.4,150,9,999999999,110,0.1250,0,88,999.000,999.0,99.0
+1977,11,23,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,1.1,92,98900,339,1403,297,44,3,44,5300,100,5300,1800,170,4.1,10,10,3.2,150,9,999999999,110,0.1250,0,88,999.000,999.0,99.0
+1977,11,23,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,1.1,92,99000,500,1403,297,89,5,87,10400,300,10300,3620,210,2.1,10,10,3.2,180,9,999999999,110,0.1250,0,88,999.000,999.0,99.0
+1977,11,23,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,1.1,92,98900,605,1403,297,180,7,177,20300,600,20100,6700,230,4.1,10,10,3.2,150,9,999999999,110,0.1250,0,88,999.000,999.0,99.0
+1977,11,23,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,2.2,93,98800,647,1403,303,164,5,162,18800,400,18600,6560,250,5.7,10,10,9.7,240,9,999999999,120,0.1250,0,88,999.000,999.0,99.0
+1977,11,23,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,1.7,89,98800,623,1403,303,204,5,201,22800,400,22600,7380,250,5.7,10,10,11.3,240,9,999999999,120,0.1250,0,88,999.000,999.0,99.0
+1977,11,23,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,0.6,85,98800,534,1403,299,150,3,149,16900,200,16800,5550,250,6.7,10,10,11.3,370,9,999999999,110,0.1250,0,88,999.000,999.0,99.0
+1977,11,23,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,0.6,82,98900,387,1403,301,109,1,109,12200,100,12100,3780,250,5.7,10,10,12.9,430,9,999999999,110,0.1250,0,88,999.000,999.0,99.0
+1977,11,23,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-0.6,82,99000,192,1403,295,55,1,54,6000,0,6000,1710,260,5.7,10,10,12.9,430,9,999999999,100,0.1250,0,88,999.000,999.0,99.0
+1977,11,23,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-0.6,82,99100,16,549,295,10,0,10,0,0,0,0,270,5.7,10,10,12.9,490,9,999999999,100,0.1250,0,88,999.000,999.0,99.0
+1977,11,23,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-0.6,79,99100,0,0,298,0,0,0,0,0,0,0,270,5.2,10,10,12.9,460,9,999999999,100,0.1250,0,88,999.000,999.0,99.0
+1977,11,23,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-1.1,79,99200,0,0,295,0,0,0,0,0,0,0,280,6.2,10,10,11.3,490,9,999999999,100,0.1250,0,88,999.000,999.0,99.0
+1977,11,23,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-1.1,82,99200,0,0,293,0,0,0,0,0,0,0,290,5.7,10,10,11.3,1370,9,999999999,100,0.1250,0,88,999.000,999.0,99.0
+1977,11,23,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-1.1,82,99300,0,0,293,0,0,0,0,0,0,0,290,4.6,10,10,11.3,1220,9,999999999,100,0.1250,0,88,999.000,999.0,99.0
+1977,11,23,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-1.7,85,99300,0,0,280,0,0,0,0,0,0,0,280,3.6,9,9,11.3,2440,9,999999999,100,0.1250,0,88,999.000,999.0,99.0
+1977,11,23,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.7,82,99300,0,0,290,0,0,0,0,0,0,0,290,5.2,10,10,11.3,460,9,999999999,100,0.1250,0,88,999.000,999.0,99.0
+1977,11,23,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-2.2,76,99400,0,0,292,0,0,0,0,0,0,0,300,4.1,10,10,11.3,460,9,999999999,89,0.1250,0,88,999.000,999.0,99.0
+1977,11,24,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-3.3,75,99400,0,0,286,0,0,0,0,0,0,0,290,5.7,10,10,14.5,550,9,999999999,89,0.1250,0,88,999.000,999.0,99.0
+1977,11,24,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-3.9,75,99500,0,0,269,0,0,0,0,0,0,0,290,5.7,8,8,19.3,520,9,999999999,89,0.1250,0,88,999.000,999.0,99.0
+1977,11,24,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-3.9,72,99500,0,0,285,0,0,0,0,0,0,0,300,6.7,10,10,24.1,580,9,999999999,89,0.1250,0,88,999.000,999.0,99.0
+1977,11,24,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-3.9,72,99500,0,0,285,0,0,0,0,0,0,0,300,4.6,10,10,24.1,580,9,999999999,89,0.1250,0,88,999.000,999.0,99.0
+1977,11,24,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-4.4,70,99600,0,0,285,0,0,0,0,0,0,0,300,5.2,10,10,24.1,580,9,999999999,80,0.1250,0,88,999.000,999.0,99.0
+1977,11,24,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-4.4,72,99600,0,0,282,0,0,0,0,0,0,0,300,4.1,10,10,24.1,580,9,999999999,80,0.1250,0,88,999.000,999.0,99.0
+1977,11,24,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-4.4,72,99600,1,129,282,1,0,1,0,0,0,0,280,4.6,10,10,16.1,580,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1977,11,24,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-3.9,72,99600,130,1403,285,33,0,33,3700,0,3700,1060,290,6.2,10,10,16.1,520,9,999999999,89,0.0620,0,88,999.000,999.0,99.0
+1977,11,24,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-3.9,72,99700,334,1403,277,114,40,104,12400,3500,11600,2550,280,5.2,10,9,19.3,520,9,999999999,89,0.0620,0,88,999.000,999.0,99.0
+1977,11,24,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-3.9,67,99700,495,1403,276,193,145,141,21000,13900,16000,3230,280,6.2,10,8,17.7,520,9,999999999,89,0.0620,0,88,999.000,999.0,99.0
+1977,11,24,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-4.4,64,99700,601,1403,261,379,678,82,39600,65800,11300,1700,280,6.2,4,3,17.7,77777,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1977,11,24,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-4.4,64,99700,643,1403,264,376,516,135,39800,51000,16300,2720,260,4.1,5,4,24.1,77777,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1977,11,24,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-4.4,59,99600,619,1403,268,338,446,138,35600,43800,16200,2760,260,5.7,6,4,24.1,7620,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1977,11,24,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-4.4,55,99500,530,1403,264,344,744,57,35900,70400,9200,1230,260,4.6,1,1,24.1,77777,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1977,11,24,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-5.0,55,99500,383,1403,267,225,576,64,23000,49500,9400,1190,290,3.6,3,3,24.1,77777,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1977,11,24,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-5.0,62,99500,189,1403,261,73,169,50,7700,10000,6300,940,290,2.6,6,3,24.1,77777,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1977,11,24,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-5.0,69,99500,15,526,252,12,43,7,0,0,0,0,280,2.6,4,2,24.1,77777,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1977,11,24,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-5.0,72,99400,0,0,250,0,0,0,0,0,0,0,260,2.1,5,2,24.1,77777,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1977,11,24,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-4.4,78,99400,0,0,264,0,0,0,0,0,0,0,190,2.6,9,8,24.1,880,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1977,11,24,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-4.4,78,99300,0,0,270,0,0,0,0,0,0,0,250,1.5,9,9,24.1,880,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1977,11,24,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-4.4,75,99300,0,0,280,0,0,0,0,0,0,0,270,2.1,10,10,24.1,760,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1977,11,24,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-5.0,72,99100,0,0,271,0,0,0,0,0,0,0,120,1.5,9,9,19.3,760,9,999999999,80,0.0620,0,88,999.000,999.0,99.0
+1977,11,24,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-3.9,72,99100,0,0,285,0,0,0,0,0,0,0,160,4.6,10,10,16.1,580,9,999999999,89,0.0620,0,88,999.000,999.0,99.0
+1977,11,24,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-3.3,75,98900,0,0,286,0,0,0,0,0,0,0,160,6.2,10,10,6.4,460,9,999999999,89,0.0620,0,88,999.000,999.0,99.0
+1977,11,25,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-2.8,82,98800,0,0,284,0,0,0,0,0,0,0,160,8.2,10,10,0.8,460,9,999999999,89,0.0620,0,88,999.000,999.0,99.0
+1977,11,25,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-1.7,92,98800,0,0,282,0,0,0,0,0,0,0,270,3.1,10,10,0.8,150,9,999999999,100,0.0620,0,88,999.000,999.0,99.0
+1977,11,25,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-1.7,89,98700,0,0,285,0,0,0,0,0,0,0,270,2.1,10,10,0.8,90,9,999999999,100,0.0620,0,88,999.000,999.0,99.0
+1977,11,25,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-2.2,89,98500,0,0,282,0,0,0,0,0,0,0,350,3.1,10,10,0.8,210,9,999999999,89,0.0620,0,88,999.000,999.0,99.0
+1977,11,25,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-2.8,89,98400,0,0,279,0,0,0,0,0,0,0,320,2.6,10,10,0.8,150,9,999999999,89,0.0620,0,88,999.000,999.0,99.0
+1977,11,25,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-2.8,89,98400,0,0,279,0,0,0,0,0,0,0,310,2.6,10,10,1.6,150,9,999999999,89,0.0620,0,88,999.000,999.0,99.0
+1977,11,25,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-3.3,89,98400,1,105,276,0,0,0,0,0,0,0,280,3.1,10,10,6.4,1010,9,999999999,89,0.1210,0,88,999.000,999.0,99.0
+1977,11,25,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-3.9,89,98300,125,1404,274,27,3,27,3100,0,3100,910,290,4.1,10,10,4.0,180,9,999999999,89,0.1210,0,88,999.000,999.0,99.0
+1977,11,25,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-6.7,85,98400,329,1404,262,115,8,113,12500,400,12400,3490,310,7.2,10,10,4.8,400,9,999999999,69,0.1210,0,88,999.000,999.0,99.0
+1977,11,25,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.6,-8.3,81,98500,491,1404,244,195,216,118,20800,20600,13600,2340,330,9.3,8,8,12.9,580,9,999999999,69,0.1210,0,88,999.000,999.0,99.0
+1977,11,25,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.7,-9.4,81,98600,596,1404,235,216,81,181,23600,7900,20300,5120,320,7.2,7,7,24.1,3050,9,999999999,60,0.1210,0,88,999.000,999.0,99.0
+1977,11,25,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.2,-10.6,77,98600,639,1404,227,342,370,171,36500,37700,19300,3680,320,9.3,5,5,24.1,77777,9,999999999,60,0.1210,0,88,999.000,999.0,99.0
+1977,11,25,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.2,-11.7,71,98600,615,1404,226,312,207,219,33400,20700,24300,5250,310,9.3,7,5,24.1,3660,9,999999999,60,0.1210,0,88,999.000,999.0,99.0
+1977,11,25,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.2,-12.2,68,98700,527,1404,234,149,104,109,16500,10200,12700,2520,320,7.7,8,8,24.1,3660,9,999999999,50,0.1210,0,88,999.000,999.0,99.0
+1977,11,25,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-12.8,68,98800,381,1404,232,179,157,136,19100,13700,15400,3010,310,9.3,8,8,24.1,3660,9,999999999,50,0.1210,0,88,999.000,999.0,99.0
+1977,11,25,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.2,-11.7,71,98800,187,1404,247,35,22,32,3800,1600,3600,830,300,8.2,10,10,4.0,610,9,999999999,60,0.1210,0,88,999.000,999.0,99.0
+1977,11,25,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.3,-12.2,74,99000,14,526,242,5,1,4,0,0,0,0,310,8.2,10,10,11.3,1370,9,999999999,50,0.1210,0,88,999.000,999.0,99.0
+1977,11,25,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-12.8,71,99100,0,0,235,0,0,0,0,0,0,0,310,7.7,9,9,16.1,3050,9,999999999,50,0.1210,0,88,999.000,999.0,99.0
+1977,11,25,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-13.3,71,99100,0,0,239,0,0,0,0,0,0,0,300,8.2,10,10,16.1,3050,9,999999999,50,0.1210,0,88,999.000,999.0,99.0
+1977,11,25,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-9.4,-13.9,70,99200,0,0,217,0,0,0,0,0,0,0,300,5.2,5,5,24.1,77777,9,999999999,50,0.1210,0,88,999.000,999.0,99.0
+1977,11,25,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.6,-15.0,70,99200,0,0,204,0,0,0,0,0,0,0,310,6.2,1,1,24.1,77777,9,999999999,50,0.1210,0,88,999.000,999.0,99.0
+1977,11,25,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.1,-15.6,70,99200,0,0,198,0,0,0,0,0,0,0,300,9.3,0,0,24.1,77777,9,999999999,50,0.1210,0,88,999.000,999.0,99.0
+1977,11,25,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.2,-16.1,73,99200,0,0,195,0,0,0,0,0,0,0,310,9.8,0,0,24.1,77777,9,999999999,40,0.1210,0,88,999.000,999.0,99.0
+1977,11,25,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.8,-17.2,70,99200,0,0,192,0,0,0,0,0,0,0,310,6.2,0,0,24.1,77777,9,999999999,40,0.1210,0,88,999.000,999.0,99.0
+1977,11,26,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.8,-17.8,67,99200,0,0,192,0,0,0,0,0,0,0,300,6.2,0,0,24.1,77777,9,999999999,40,0.1210,0,88,999.000,999.0,99.0
+1977,11,26,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-13.9,-18.3,69,99200,0,0,188,0,0,0,0,0,0,0,300,6.2,0,0,24.1,77777,9,999999999,40,0.1210,0,88,999.000,999.0,99.0
+1977,11,26,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-15.0,-20.0,66,99300,0,0,184,0,0,0,0,0,0,0,300,6.2,0,0,24.1,77777,9,999999999,40,0.1210,0,88,999.000,999.0,99.0
+1977,11,26,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-15.6,-20.0,69,99300,0,0,182,0,0,0,0,0,0,0,300,4.6,0,0,24.1,77777,9,999999999,40,0.1210,0,88,999.000,999.0,99.0
+1977,11,26,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-15.6,-20.0,69,99300,0,0,182,0,0,0,0,0,0,0,300,4.1,0,0,24.1,77777,9,999999999,40,0.1210,0,88,999.000,999.0,99.0
+1977,11,26,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-15.6,-20.0,69,99300,0,0,182,0,0,0,0,0,0,0,290,5.2,0,0,24.1,77777,9,999999999,40,0.1210,0,88,999.000,999.0,99.0
+1977,11,26,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-16.1,-20.6,69,99400,0,82,180,1,1,0,0,0,0,0,290,4.1,0,0,24.1,77777,9,999999999,40,0.1030,0,88,999.000,999.0,99.0
+1977,11,26,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-16.1,-20.6,69,99400,121,1404,180,50,229,29,5100,10800,4100,520,280,3.1,0,0,24.1,77777,9,999999999,40,0.1030,0,88,999.000,999.0,99.0
+1977,11,26,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-14.4,-20.6,60,99300,325,1404,185,190,558,57,19200,45200,8700,1040,270,5.2,0,0,24.1,77777,9,999999999,40,0.1030,0,88,999.000,999.0,99.0
+1977,11,26,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-12.2,-18.9,58,99300,486,1404,192,325,706,75,33500,65100,10900,1460,290,4.6,0,0,24.1,77777,9,999999999,40,0.1030,0,88,999.000,999.0,99.0
+1977,11,26,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.6,-18.9,51,99300,592,1404,197,419,772,87,42300,73300,11300,1650,250,4.6,0,0,24.1,77777,9,999999999,40,0.1030,0,88,999.000,999.0,99.0
+1977,11,26,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.9,-19.4,43,99200,635,1404,202,457,785,95,47600,76600,12800,1970,260,5.2,1,0,24.1,77777,9,999999999,40,0.1030,0,88,999.000,999.0,99.0
+1977,11,26,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-19.4,39,99200,612,1404,209,415,713,99,43000,68900,12900,2010,280,5.7,3,1,24.1,77777,9,999999999,40,0.1030,0,88,999.000,999.0,99.0
+1977,11,26,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.2,-18.3,41,99100,524,1404,215,326,543,119,34000,51300,14800,2290,230,4.1,7,2,24.1,77777,9,999999999,40,0.1030,0,88,999.000,999.0,99.0
+1977,11,26,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-16.7,49,99100,378,1404,218,180,288,100,18800,24900,12100,1960,250,4.6,8,4,24.1,77777,9,999999999,40,0.1030,0,88,999.000,999.0,99.0
+1977,11,26,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.9,-17.2,51,99100,185,1404,218,58,58,50,6300,3700,5800,1050,230,4.1,10,6,24.1,7620,9,999999999,40,0.1030,0,88,999.000,999.0,99.0
+1977,11,26,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.6,-17.2,58,99100,14,503,207,9,6,9,0,0,0,0,240,3.6,8,3,24.1,77777,9,999999999,40,0.1030,0,88,999.000,999.0,99.0
+1977,11,26,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.1,-16.7,64,99100,0,0,204,0,0,0,0,0,0,0,230,3.1,7,2,24.1,77777,9,999999999,40,0.1030,0,88,999.000,999.0,99.0
+1977,11,26,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.2,-16.1,73,99100,0,0,201,0,0,0,0,0,0,0,210,2.1,4,2,24.1,77777,9,999999999,40,0.1030,0,88,999.000,999.0,99.0
+1977,11,26,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.2,-16.1,73,99100,0,0,201,0,0,0,0,0,0,0,170,2.1,5,2,24.1,77777,9,999999999,40,0.1030,0,88,999.000,999.0,99.0
+1977,11,26,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.2,-15.6,76,99100,0,0,209,0,0,0,0,0,0,0,150,2.1,9,6,24.1,3660,9,999999999,50,0.1030,0,88,999.000,999.0,99.0
+1977,11,26,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.6,-15.0,70,99000,0,0,220,0,0,0,0,0,0,0,140,3.1,10,8,24.1,3050,9,999999999,50,0.1030,0,88,999.000,999.0,99.0
+1977,11,26,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-9.4,-15.0,64,99000,0,0,229,0,0,0,0,0,0,0,150,2.1,10,9,19.3,2740,9,999999999,50,0.1030,0,88,999.000,999.0,99.0
+1977,11,26,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-12.8,65,99100,0,0,239,0,0,0,0,0,0,0,150,3.1,10,9,19.3,2740,9,999999999,50,0.1030,0,88,999.000,999.0,99.0
+1977,11,27,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-12.2,68,99000,0,0,246,0,0,0,0,0,0,0,150,3.6,10,10,16.1,2740,9,999999999,50,0.1030,0,88,999.000,999.0,99.0
+1977,11,27,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-11.7,68,98900,0,0,249,0,0,0,0,0,0,0,160,4.1,10,10,16.1,2740,9,999999999,60,0.1030,0,88,999.000,999.0,99.0
+1977,11,27,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-10.0,81,98800,0,0,248,0,0,0,0,0,0,0,150,5.2,10,10,2.4,1520,9,999999999,60,0.1030,0,88,999.000,999.0,99.0
+1977,11,27,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-10.0,81,98700,0,0,248,0,0,0,0,0,0,0,120,5.2,10,10,2.4,910,9,999999999,60,0.1030,0,88,999.000,999.0,99.0
+1977,11,27,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-7.8,92,98600,0,0,252,0,0,0,0,0,0,0,130,5.2,10,10,2.4,460,9,999999999,69,0.1030,0,88,999.000,999.0,99.0
+1977,11,27,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-7.8,92,98600,0,0,252,0,0,0,0,0,0,0,140,5.7,10,10,3.2,460,9,999999999,69,0.1030,0,88,999.000,999.0,99.0
+1977,11,27,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.1,-7.8,88,98500,0,59,255,0,0,0,0,0,0,0,130,5.7,10,10,6.4,610,9,999999999,69,0.2080,0,88,999.000,999.0,99.0
+1977,11,27,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.6,-7.8,85,98500,117,1405,256,33,0,33,3600,0,3600,1020,140,6.7,10,10,4.0,610,9,999999999,69,0.2080,0,88,999.000,999.0,99.0
+1977,11,27,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.0,-7.2,85,98400,320,1405,259,69,4,67,7700,200,7700,2470,150,8.2,10,10,40.2,460,9,999999999,69,0.2080,0,88,999.000,999.0,99.0
+1977,11,27,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-6.7,85,98300,482,1405,262,116,3,115,13200,200,13100,4400,150,6.7,10,10,6.4,460,9,999999999,69,0.2080,0,88,999.000,999.0,99.0
+1977,11,27,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-5.6,85,98200,588,1405,268,191,5,189,21300,400,21200,6840,150,5.2,10,10,3.2,460,9,999999999,80,0.2080,0,88,999.000,999.0,99.0
+1977,11,27,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-5.0,88,98100,631,1405,268,182,3,180,20500,200,20400,6940,140,7.2,10,10,40.2,460,9,999999999,80,0.2080,0,88,999.000,999.0,99.0
+1977,11,27,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-5.0,88,97900,608,1405,268,190,4,188,21300,300,21100,6970,130,5.2,10,10,1.3,310,9,999999999,80,0.2080,0,88,999.000,999.0,99.0
+1977,11,27,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-4.4,92,97900,521,1405,269,144,2,143,16200,100,16100,5330,160,5.7,10,10,1.3,240,9,999999999,80,0.2080,0,88,999.000,999.0,99.0
+1977,11,27,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-5.0,85,97900,375,1405,270,105,1,105,11700,100,11700,3630,150,4.6,10,10,1.3,370,9,999999999,80,0.2080,0,88,999.000,999.0,99.0
+1977,11,27,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-3.9,89,97900,182,1405,274,50,0,50,5500,0,5500,1590,170,3.6,10,10,3.2,310,9,999999999,80,0.2080,0,88,999.000,999.0,99.0
+1977,11,27,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-3.9,92,98000,13,503,271,9,0,9,0,0,0,0,210,3.1,10,10,1.3,240,9,999999999,80,0.2080,0,88,999.000,999.0,99.0
+1977,11,27,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-3.9,92,98000,0,0,271,0,0,0,0,0,0,0,240,4.1,10,10,9.7,460,9,999999999,80,0.2080,0,88,999.000,999.0,99.0
+1977,11,27,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-5.6,85,98200,0,0,268,0,0,0,0,0,0,0,270,5.7,10,10,19.3,460,9,999999999,80,0.2080,0,88,999.000,999.0,99.0
+1977,11,27,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-6.1,85,98300,0,0,265,0,0,0,0,0,0,0,250,6.2,10,10,9.7,460,9,999999999,69,0.2080,0,88,999.000,999.0,99.0
+1977,11,27,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-6.7,85,98400,0,0,262,0,0,0,0,0,0,0,260,5.7,10,10,14.5,460,9,999999999,69,0.2080,0,88,999.000,999.0,99.0
+1977,11,27,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-7.8,88,98500,0,0,232,0,0,0,0,0,0,0,260,5.2,4,4,19.3,77777,9,999999999,69,0.2080,0,88,999.000,999.0,99.0
+1977,11,27,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-8.9,88,98700,0,0,216,0,0,0,0,0,0,0,260,5.2,0,0,19.3,77777,9,999999999,60,0.2080,0,88,999.000,999.0,99.0
+1977,11,27,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-9.4,88,98900,0,0,225,0,0,0,0,0,0,0,250,4.6,4,4,24.1,77777,9,999999999,60,0.2080,0,88,999.000,999.0,99.0
+1977,11,28,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-10.6,84,99000,0,0,218,0,0,0,0,0,0,0,270,4.1,2,2,24.1,77777,9,999999999,60,0.2080,0,88,999.000,999.0,99.0
+1977,11,28,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-10.6,84,99200,0,0,224,0,0,0,0,0,0,0,250,4.1,5,5,24.1,77777,9,999999999,60,0.2080,0,88,999.000,999.0,99.0
+1977,11,28,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-10.6,81,99300,0,0,224,0,0,0,0,0,0,0,250,5.2,4,4,24.1,77777,9,999999999,60,0.2080,0,88,999.000,999.0,99.0
+1977,11,28,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-11.1,77,99300,0,0,219,0,0,0,0,0,0,0,250,5.2,2,2,24.1,77777,9,999999999,60,0.2080,0,88,999.000,999.0,99.0
+1977,11,28,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-12.2,74,99500,0,0,210,0,0,0,0,0,0,0,240,5.2,0,0,19.3,77777,9,999999999,50,0.2080,0,88,999.000,999.0,99.0
+1977,11,28,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.1,-13.3,84,99600,0,0,200,0,0,0,0,0,0,0,250,5.2,0,0,16.1,77777,9,999999999,50,0.2080,0,88,999.000,999.0,99.0
+1977,11,28,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.8,-14.4,87,99800,0,35,194,0,0,0,0,0,0,0,250,5.2,0,0,12.9,77777,9,999999999,50,0.2080,0,88,999.000,999.0,99.0
+1977,11,28,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-12.8,-15.0,84,99900,112,1405,194,46,204,28,4600,9200,3900,500,240,4.6,0,0,12.9,77777,9,999999999,50,0.1050,0,88,999.000,999.0,99.0
+1977,11,28,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-11.7,-13.9,84,100000,316,1405,198,184,541,59,18600,43200,8800,1060,260,3.1,0,0,12.9,77777,9,999999999,50,0.1050,0,88,999.000,999.0,99.0
+1977,11,28,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-9.4,-13.3,74,100100,477,1405,205,319,691,78,32700,63300,11100,1500,260,4.1,0,0,12.9,77777,9,999999999,50,0.1050,0,88,999.000,999.0,99.0
+1977,11,28,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-12.8,68,100100,584,1405,215,392,697,97,40500,66700,12700,1940,300,3.6,2,1,16.1,77777,9,999999999,50,0.1050,0,88,999.000,999.0,99.0
+1977,11,28,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.7,-12.8,62,100100,627,1405,222,386,512,153,40200,50300,17700,3100,240,4.1,5,2,16.1,77777,9,999999999,50,0.1050,0,88,999.000,999.0,99.0
+1977,11,28,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.6,-12.2,60,100100,605,1405,228,350,375,185,36800,37700,20500,4030,260,4.1,6,3,19.3,77777,9,999999999,50,0.1050,0,88,999.000,999.0,99.0
+1977,11,28,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.0,-12.2,57,100200,518,1405,228,337,535,136,34700,50200,16100,2650,290,4.6,7,2,19.3,77777,9,999999999,50,0.1050,0,88,999.000,999.0,99.0
+1977,11,28,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.6,-11.7,62,100300,373,1405,234,149,85,126,16200,7600,14200,3080,210,4.6,10,6,24.1,7620,9,999999999,60,0.1050,0,88,999.000,999.0,99.0
+1977,11,28,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.6,-11.7,62,100400,180,1405,234,69,35,64,7500,2500,7100,1410,240,2.1,10,6,20.9,7620,9,999999999,60,0.1050,0,88,999.000,999.0,99.0
+1977,11,28,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.2,-11.7,71,100400,12,480,228,4,1,4,0,0,0,0,270,2.6,10,6,24.1,7620,9,999999999,60,0.1050,0,88,999.000,999.0,99.0
+1977,11,28,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-11.7,68,100500,0,0,242,0,0,0,0,0,0,0,250,3.1,10,9,24.1,6100,9,999999999,60,0.1050,0,88,999.000,999.0,99.0
+1977,11,28,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-11.7,74,100600,0,0,238,0,0,0,0,0,0,0,250,2.6,10,9,24.1,6100,9,999999999,60,0.1050,0,88,999.000,999.0,99.0
+1977,11,28,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-12.2,77,100600,0,0,228,0,0,0,0,0,0,0,220,2.1,10,8,24.1,4570,9,999999999,50,0.1050,0,88,999.000,999.0,99.0
+1977,11,28,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-11.7,77,100700,0,0,236,0,0,0,0,0,0,0,250,2.6,10,9,24.1,6100,9,999999999,60,0.1050,0,88,999.000,999.0,99.0
+1977,11,28,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-11.7,74,100800,0,0,238,0,0,0,0,0,0,0,240,2.6,10,9,24.1,6100,9,999999999,60,0.1050,0,88,999.000,999.0,99.0
+1977,11,28,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-11.7,77,100900,0,0,236,0,0,0,0,0,0,0,270,2.6,10,9,24.1,6100,9,999999999,60,0.1050,0,88,999.000,999.0,99.0
+1977,11,28,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-11.7,81,100800,0,0,234,0,0,0,0,0,0,0,0,0.0,9,9,24.1,4270,9,999999999,60,0.1050,0,88,999.000,999.0,99.0
+1977,11,29,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.0,-12.2,84,100800,0,0,211,0,0,0,0,0,0,0,300,2.1,2,2,24.1,77777,9,999999999,50,0.1050,0,88,999.000,999.0,99.0
+1977,11,29,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.6,-12.8,84,100700,0,0,202,0,0,0,0,0,0,0,350,3.1,0,0,24.1,77777,9,999999999,50,0.1050,0,88,999.000,999.0,99.0
+1977,11,29,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.7,-12.8,92,100700,0,0,199,0,0,0,0,0,0,0,340,2.6,0,0,24.1,77777,9,999999999,50,0.1050,0,88,999.000,999.0,99.0
+1977,11,29,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.1,-13.3,84,100800,0,0,200,0,0,0,0,0,0,0,10,1.5,0,0,24.1,77777,9,999999999,50,0.1050,0,88,999.000,999.0,99.0
+1977,11,29,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.2,-13.9,88,100800,0,0,205,0,0,0,0,0,0,0,0,0.0,4,3,19.3,77777,9,999999999,50,0.1050,0,88,999.000,999.0,99.0
+1977,11,29,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.2,-13.3,92,100700,0,0,203,0,0,0,0,0,0,0,0,0.0,3,2,19.3,77777,9,999999999,50,0.1050,0,88,999.000,999.0,99.0
+1977,11,29,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.2,-13.3,92,100800,0,12,210,0,0,0,0,0,0,0,270,2.1,8,6,11.3,3660,9,999999999,50,0.1050,0,88,999.000,999.0,99.0
+1977,11,29,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-11.1,-12.2,92,100800,108,1406,208,37,50,33,4000,2400,3800,680,320,2.1,2,2,8.0,77777,9,999999999,50,0.1470,0,88,999.000,999.0,99.0
+1977,11,29,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.2,-10.0,81,100800,311,1406,222,168,387,80,17100,30400,10400,1480,0,0.0,2,2,6.4,77777,9,999999999,60,0.1470,0,88,999.000,999.0,99.0
+1977,11,29,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.9,-8.9,69,100700,473,1406,239,267,325,155,27700,30500,17400,3270,0,0.0,4,4,4.8,77777,9,999999999,69,0.1470,0,88,999.000,999.0,99.0
+1977,11,29,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-6.1,69,100700,580,1406,251,348,406,177,36600,40400,19800,3820,170,4.1,4,4,4.8,77777,9,999999999,80,0.1470,0,88,999.000,999.0,99.0
+1977,11,29,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-5.0,69,100500,624,1406,261,297,226,195,32100,22700,22000,4690,140,5.2,6,6,4.8,7620,9,999999999,80,0.1470,0,88,999.000,999.0,99.0
+1977,11,29,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-5.0,69,100500,602,1406,257,404,468,200,42200,46900,22100,4440,150,4.6,4,4,4.8,77777,9,999999999,80,0.1470,0,88,999.000,999.0,99.0
+1977,11,29,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-4.4,70,100400,515,1406,257,336,512,145,34400,47900,16700,2850,160,4.1,7,3,9.7,77777,9,999999999,80,0.1470,0,88,999.000,999.0,99.0
+1977,11,29,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-5.0,67,100300,371,1406,257,214,344,121,22100,29400,14300,2480,160,3.6,8,3,9.7,77777,9,999999999,80,0.1470,0,88,999.000,999.0,99.0
+1977,11,29,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-6.1,69,100300,179,1406,249,75,111,61,8000,6900,7200,1280,160,3.1,8,3,8.0,77777,9,999999999,80,0.1470,0,88,999.000,999.0,99.0
+1977,11,29,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-6.7,69,100300,12,480,247,5,3,5,0,0,0,0,160,1.5,8,3,8.0,77777,9,999999999,69,0.1470,0,88,999.000,999.0,99.0
+1977,11,29,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-7.2,78,100200,0,0,236,0,0,0,0,0,0,0,160,2.1,5,2,11.3,77777,9,999999999,69,0.1470,0,88,999.000,999.0,99.0
+1977,11,29,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-7.8,88,100200,0,0,228,0,0,0,0,0,0,0,0,0.0,5,2,11.3,77777,9,999999999,69,0.1470,0,88,999.000,999.0,99.0
+1977,11,29,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-8.3,92,100200,0,0,224,0,0,0,0,0,0,0,0,0.0,5,2,11.3,77777,9,999999999,69,0.1470,0,88,999.000,999.0,99.0
+1977,11,29,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-7.8,96,100200,0,0,217,0,0,0,0,0,0,0,190,2.1,0,0,8.0,77777,9,999999999,69,0.1470,0,88,999.000,999.0,99.0
+1977,11,29,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-10.0,84,100100,0,0,213,0,0,0,0,0,0,0,180,2.1,0,0,6.4,77777,9,999999999,60,0.1470,0,88,999.000,999.0,99.0
+1977,11,29,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-7.8,96,100000,0,0,217,0,0,0,0,0,0,0,170,2.6,0,0,6.4,77777,9,999999999,69,0.1470,0,88,999.000,999.0,99.0
+1977,11,29,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-8.3,92,99800,0,0,217,0,0,0,0,0,0,0,0,0.0,0,0,6.4,77777,9,999999999,69,0.1470,0,88,999.000,999.0,99.0
+1977,11,30,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-9.4,92,99800,0,0,212,0,0,0,0,0,0,0,0,0.0,0,0,6.4,77777,9,999999999,60,0.1470,0,88,999.000,999.0,99.0
+1977,11,30,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-10.0,92,99700,0,0,210,0,0,0,0,0,0,0,310,2.1,0,0,3.2,77777,9,999999999,60,0.1470,0,88,999.000,999.0,99.0
+1977,11,30,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-10.0,88,99600,0,0,212,0,0,0,0,0,0,0,320,2.6,2,0,3.2,77777,9,999999999,60,0.1470,0,88,999.000,999.0,99.0
+1977,11,30,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-9.4,92,99600,0,0,219,0,0,0,0,0,0,0,310,1.5,6,2,3.2,77777,9,999999999,60,0.1470,0,88,999.000,999.0,99.0
+1977,11,30,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-8.9,92,99400,0,0,221,0,0,0,0,0,0,0,0,0.0,6,2,3.2,77777,9,999999999,60,0.1470,0,88,999.000,999.0,99.0
+1977,11,30,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-7.8,92,99400,0,0,252,0,0,0,0,0,0,0,0,0.0,10,10,6.4,610,9,999999999,69,0.1470,0,88,999.000,999.0,99.0
+1977,11,30,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-4.4,92,99300,0,0,269,0,0,0,0,0,0,0,320,2.1,10,10,6.4,180,9,999999999,80,0.1470,0,88,999.000,999.0,99.0
+1977,11,30,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-3.9,89,99300,104,1395,274,15,2,15,1800,0,1800,560,340,2.1,10,10,4.8,180,9,999999999,89,0.0970,0,88,999.000,999.0,99.0
+1977,11,30,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-2.2,92,99200,307,1406,280,87,6,85,9600,300,9500,2850,20,2.1,10,10,4.8,90,9,999999999,89,0.0970,0,88,999.000,999.0,99.0
+1977,11,30,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-1.7,85,99100,469,1406,287,130,6,128,14600,400,14500,4660,330,3.1,10,10,4.8,90,9,999999999,100,0.0970,0,88,999.000,999.0,99.0
+1977,11,30,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-0.6,89,99000,576,1406,291,201,6,199,22300,500,22100,6930,30,2.6,10,10,3.2,150,9,999999999,100,0.0970,0,88,999.000,999.0,99.0
+1977,11,30,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,0.0,92,98800,620,1406,291,190,9,186,21400,700,21100,7010,30,2.1,10,10,1.3,120,9,999999999,110,0.0970,0,88,999.000,999.0,99.0
+1977,11,30,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,1.1,96,98700,599,1406,295,198,3,196,22000,300,21900,7070,30,3.1,10,10,0.4,60,9,999999999,110,0.0970,0,88,999.000,999.0,99.0
+1977,11,30,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,1.7,96,98500,513,1406,298,188,1,187,20600,100,20600,6150,50,3.6,10,10,0.2,30,9,999999999,120,0.0970,0,88,999.000,999.0,99.0
+1977,11,30,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,1.7,96,98400,368,1406,298,104,3,103,11500,200,11500,3550,30,3.1,10,10,0.2,30,9,999999999,120,0.0970,0,88,999.000,999.0,99.0
+1977,11,30,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,1.7,100,98400,177,1406,296,47,0,47,5200,0,5200,1510,20,3.1,10,10,0.2,0,9,999999999,120,0.0970,0,88,999.000,999.0,99.0
+1977,11,30,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,1.7,100,98300,11,457,296,8,0,8,0,0,0,0,20,2.6,10,10,0.2,0,9,999999999,120,0.0970,0,88,999.000,999.0,99.0
+1977,11,30,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,1.7,100,98200,0,0,296,0,0,0,0,0,0,0,20,3.1,10,10,0.2,0,9,999999999,120,0.0970,0,88,999.000,999.0,99.0
+1977,11,30,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,2.2,100,98100,0,0,298,0,0,0,0,0,0,0,20,3.1,10,10,0.8,60,9,999999999,120,0.0970,0,88,999.000,999.0,99.0
+1977,11,30,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,2.2,100,97900,0,0,298,0,0,0,0,0,0,0,20,4.1,10,10,0.8,60,9,999999999,120,0.0970,0,88,999.000,999.0,99.0
+1977,11,30,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,2.2,100,97800,0,0,298,0,0,0,0,0,0,0,20,4.1,10,10,0.8,60,9,999999999,120,0.0970,0,88,999.000,999.0,99.0
+1977,11,30,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.5,2.5,100,97500,0,0,300,0,0,0,0,0,0,0,20,4.1,10,10,1.6,60,9,999999999,120,0.0970,0,88,999.000,999.0,99.0
+1977,11,30,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,2.8,96,97400,0,0,302,0,0,0,0,0,0,0,350,4.1,10,10,3.2,120,9,999999999,120,0.0970,0,88,999.000,999.0,99.0
+1977,11,30,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.1,3.1,96,97400,0,0,303,0,0,0,0,0,0,0,300,4.1,10,10,3.2,120,9,999999999,120,0.0970,0,88,999.000,999.0,99.0
+1981,12,1,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.5,3.5,96,97100,0,0,305,0,0,0,0,0,0,0,120,4.1,10,10,6.4,180,9,999999999,110,0.0970,0,88,999.000,999.0,99.0
+1981,12,1,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.8,3.8,100,97000,0,0,307,0,0,0,0,0,0,0,120,4.1,10,10,4.0,120,9,999999999,110,0.0970,0,88,999.000,999.0,99.0
+1981,12,1,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.1,4.1,96,96900,0,0,309,0,0,0,0,0,0,0,120,4.1,10,10,4.0,90,9,999999999,120,0.0970,0,88,999.000,999.0,99.0
+1981,12,1,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,4.4,100,96800,0,0,310,0,0,0,0,0,0,0,140,4.1,10,10,4.0,120,9,999999999,139,0.0970,0,88,999.000,999.0,99.0
+1981,12,1,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,6.1,100,96700,0,0,320,0,0,0,0,0,0,0,160,5.2,10,10,0.8,60,9,999999999,150,0.0970,0,88,999.000,999.0,99.0
+1981,12,1,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,5.6,96,96600,0,0,319,0,0,0,0,0,0,0,140,3.6,10,10,0.4,30,9,999999999,139,0.0970,0,88,999.000,999.0,99.0
+1981,12,1,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,5.0,100,96600,0,0,314,0,0,0,0,0,0,0,150,2.6,10,10,0.4,30,9,999999999,139,0.0970,0,88,999.000,999.0,99.0
+1981,12,1,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,6.7,89,96600,100,1372,331,14,0,14,1600,0,1600,520,190,7.2,10,10,11.3,180,9,999999999,150,0.0820,0,88,999.000,999.0,99.0
+1981,12,1,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,5.0,89,96600,303,1407,321,52,1,52,6000,0,6000,1990,240,4.1,10,10,11.3,980,9,999999999,139,0.0820,0,88,999.000,999.0,99.0
+1981,12,1,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,3.9,83,96600,465,1407,320,97,1,96,11100,100,11000,3790,220,3.6,10,10,11.3,1400,9,999999999,129,0.0820,0,88,999.000,999.0,99.0
+1981,12,1,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,1.1,86,96700,572,1407,302,126,1,126,14500,100,14500,5120,240,6.2,10,10,8.0,430,9,999999999,110,0.0820,0,88,999.000,999.0,99.0
+1981,12,1,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,1.7,89,96600,617,1407,303,124,0,124,14400,0,14400,5240,210,4.6,10,10,9.7,430,9,999999999,120,0.0820,0,88,999.000,999.0,99.0
+1981,12,1,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,1.1,86,96600,596,1407,302,114,0,114,13300,0,13300,4830,200,4.6,10,10,11.3,580,9,999999999,110,0.0820,0,88,999.000,999.0,99.0
+1981,12,1,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,1.7,86,96600,510,1407,305,98,1,98,11400,100,11400,4010,190,5.7,10,10,16.1,520,9,999999999,120,0.0820,0,88,999.000,999.0,99.0
+1981,12,1,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,0.0,76,96600,366,1407,303,63,1,63,7300,0,7300,2480,200,6.2,10,10,19.3,1010,9,999999999,100,0.0820,0,88,999.000,999.0,99.0
+1981,12,1,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,0.6,82,96700,175,1407,301,29,1,29,3300,0,3300,1060,220,5.2,10,10,8.0,340,9,999999999,110,0.0820,0,88,999.000,999.0,99.0
+1981,12,1,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,0.0,82,96700,11,457,299,5,0,5,0,0,0,0,200,5.7,10,10,16.1,340,9,999999999,100,0.0820,0,88,999.000,999.0,99.0
+1981,12,1,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,0.0,89,96700,0,0,294,0,0,0,0,0,0,0,210,6.7,10,10,16.1,340,9,999999999,100,0.0820,0,88,999.000,999.0,99.0
+1981,12,1,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,0.0,85,96800,0,0,296,0,0,0,0,0,0,0,210,6.2,10,10,16.1,310,9,999999999,100,0.0820,0,88,999.000,999.0,99.0
+1981,12,1,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,0.6,89,96800,0,0,297,0,0,0,0,0,0,0,220,6.2,10,10,19.3,310,9,999999999,110,0.0820,0,88,999.000,999.0,99.0
+1981,12,1,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,0.6,89,96900,0,0,297,0,0,0,0,0,0,0,230,7.2,10,10,11.3,210,9,999999999,110,0.0820,0,88,999.000,999.0,99.0
+1981,12,1,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,0.6,85,96900,0,0,299,0,0,0,0,0,0,0,230,4.6,10,10,14.5,340,9,999999999,110,0.0820,0,88,999.000,999.0,99.0
+1981,12,1,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,0.0,85,97000,0,0,296,0,0,0,0,0,0,0,230,8.2,10,10,14.5,340,9,999999999,100,0.0820,0,88,999.000,999.0,99.0
+1981,12,1,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-0.6,85,97100,0,0,293,0,0,0,0,0,0,0,260,7.2,10,10,12.9,370,9,999999999,100,0.0820,0,88,999.000,999.0,99.0
+1981,12,2,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,0.0,89,97200,0,0,294,0,0,0,0,0,0,0,260,9.3,10,10,12.9,340,9,999999999,110,0.0820,0,88,999.000,999.0,99.0
+1981,12,2,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-0.6,89,97200,0,0,291,0,0,0,0,0,0,0,250,7.2,10,10,6.4,240,9,999999999,100,0.0820,0,88,999.000,999.0,99.0
+1981,12,2,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,0.0,92,97300,0,0,291,0,0,0,0,0,0,0,250,6.7,10,10,11.3,370,9,999999999,100,0.0820,0,88,999.000,999.0,99.0
+1981,12,2,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,0.0,92,97400,0,0,291,0,0,0,0,0,0,0,260,7.7,10,10,16.1,370,9,999999999,100,0.0820,0,88,999.000,999.0,99.0
+1981,12,2,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.1,85,97500,0,0,290,0,0,0,0,0,0,0,260,8.2,10,10,16.1,370,9,999999999,100,0.0820,0,88,999.000,999.0,99.0
+1981,12,2,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.7,82,97600,0,0,290,0,0,0,0,0,0,0,260,8.2,10,10,16.1,460,9,999999999,100,0.0820,0,88,999.000,999.0,99.0
+1981,12,2,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-2.8,82,97700,0,0,284,0,0,0,0,0,0,0,260,5.2,10,10,19.3,490,9,999999999,89,0.0820,0,88,999.000,999.0,99.0
+1981,12,2,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-2.8,82,97900,96,1349,284,25,0,25,2800,0,2800,820,230,6.2,10,10,19.3,520,9,999999999,89,0.0830,0,88,999.000,999.0,99.0
+1981,12,2,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-2.8,82,97900,299,1407,284,98,1,98,10700,0,10700,3040,220,5.7,10,10,24.1,490,9,999999999,89,0.0830,0,88,999.000,999.0,99.0
+1981,12,2,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-2.2,82,98000,461,1407,287,158,1,157,17300,100,17300,5200,230,5.7,10,10,24.1,490,9,999999999,89,0.0830,0,88,999.000,999.0,99.0
+1981,12,2,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-4.4,70,98000,569,1407,285,196,0,196,21700,0,21700,6810,240,4.6,10,10,24.1,580,9,999999999,80,0.0830,0,88,999.000,999.0,99.0
+1981,12,2,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-3.3,79,97900,614,1407,283,195,0,195,21800,0,21800,7160,250,6.7,10,10,24.1,520,9,999999999,89,0.0830,0,88,999.000,999.0,99.0
+1981,12,2,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-2.8,82,98000,593,1407,284,206,0,206,22900,0,22900,7210,250,5.2,10,10,19.3,400,9,999999999,89,0.0830,0,88,999.000,999.0,99.0
+1981,12,2,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-2.8,79,98000,508,1407,286,156,1,156,17400,100,17400,5530,230,6.7,10,10,24.1,610,9,999999999,89,0.0830,0,88,999.000,999.0,99.0
+1981,12,2,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-2.8,76,98100,365,1407,288,109,1,109,12100,100,12100,3650,220,4.6,10,10,24.1,700,9,999999999,89,0.0830,0,88,999.000,999.0,99.0
+1981,12,2,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-4.4,75,98200,174,1407,280,44,1,44,4900,0,4900,1440,260,5.7,10,10,24.1,760,9,999999999,80,0.0830,0,88,999.000,999.0,99.0
+1981,12,2,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-5.0,72,98200,11,457,271,3,1,3,0,0,0,0,240,4.1,9,9,19.3,640,9,999999999,80,0.0830,0,88,999.000,999.0,99.0
+1981,12,2,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.0,75,98300,0,0,277,0,0,0,0,0,0,0,230,3.1,10,10,19.3,640,9,999999999,80,0.0830,0,88,999.000,999.0,99.0
+1981,12,2,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.0,75,98300,0,0,277,0,0,0,0,0,0,0,260,3.1,10,10,19.3,700,9,999999999,80,0.0830,0,88,999.000,999.0,99.0
+1981,12,2,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.0,78,98300,0,0,275,0,0,0,0,0,0,0,270,2.6,10,10,19.3,760,9,999999999,80,0.0830,0,88,999.000,999.0,99.0
+1981,12,2,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-5.6,81,98300,0,0,262,0,0,0,0,0,0,0,230,2.6,10,9,11.3,7620,9,999999999,80,0.0830,0,88,999.000,999.0,99.0
+1981,12,2,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-5.6,88,98300,0,0,237,0,0,0,0,0,0,0,230,2.1,6,2,11.3,77777,9,999999999,80,0.0830,0,88,999.000,999.0,99.0
+1981,12,2,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-6.1,88,98300,0,0,235,0,0,0,0,0,0,0,190,2.6,7,2,11.3,77777,9,999999999,69,0.0830,0,88,999.000,999.0,99.0
+1981,12,2,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-7.8,88,98300,0,0,225,0,0,0,0,0,0,0,0,0.0,6,1,12.9,77777,9,999999999,69,0.0830,0,88,999.000,999.0,99.0
+1981,12,3,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-8.9,84,98300,0,0,222,0,0,0,0,0,0,0,250,1.5,3,1,11.3,77777,9,999999999,60,0.0830,0,88,999.000,999.0,99.0
+1981,12,3,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-8.9,88,98300,0,0,216,0,0,0,0,0,0,0,230,2.1,2,0,12.9,77777,9,999999999,60,0.0830,0,88,999.000,999.0,99.0
+1981,12,3,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-8.3,96,98400,0,0,224,0,0,0,0,0,0,0,190,2.1,3,3,11.3,77777,9,999999999,69,0.0830,0,88,999.000,999.0,99.0
+1981,12,3,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-7.8,88,98400,0,0,238,0,0,0,0,0,0,0,0,0.0,8,7,12.9,3660,9,999999999,69,0.0830,0,88,999.000,999.0,99.0
+1981,12,3,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-6.1,92,98400,0,0,260,0,0,0,0,0,0,0,0,0.0,10,10,16.1,3660,9,999999999,69,0.0830,0,88,999.000,999.0,99.0
+1981,12,3,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-6.1,92,98500,0,0,244,0,0,0,0,0,0,0,0,0.0,7,7,14.5,3660,9,999999999,69,0.0830,0,88,999.000,999.0,99.0
+1981,12,3,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-6.7,92,98500,0,0,236,0,0,0,0,0,0,0,160,2.1,7,5,8.0,3660,9,999999999,69,0.0830,0,88,999.000,999.0,99.0
+1981,12,3,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-6.1,88,98500,92,1326,241,35,79,28,3600,3100,3300,510,160,1.5,8,5,8.0,7010,9,999999999,69,0.0610,0,88,999.000,999.0,99.0
+1981,12,3,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-3.9,82,98500,295,1408,251,122,328,51,12900,25300,7600,900,140,2.1,4,3,8.0,77777,9,999999999,89,0.0610,0,88,999.000,999.0,99.0
+1981,12,3,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-2.2,85,98500,458,1408,284,100,8,97,11400,500,11200,3790,190,3.1,10,10,8.0,1400,9,999999999,89,0.0610,0,88,999.000,999.0,99.0
+1981,12,3,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-1.1,85,98500,565,1408,290,127,6,125,14600,400,14500,5050,210,4.1,10,10,11.3,1400,9,999999999,100,0.0610,0,88,999.000,999.0,99.0
+1981,12,3,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-1.1,79,98400,611,1408,295,186,3,185,20900,200,20800,6910,190,3.6,10,10,14.5,1400,9,999999999,100,0.0610,0,88,999.000,999.0,99.0
+1981,12,3,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-0.6,73,98300,590,1408,303,173,2,172,19500,200,19400,6460,190,3.6,10,10,24.1,2740,9,999999999,100,0.0610,0,88,999.000,999.0,99.0
+1981,12,3,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-0.6,70,98300,506,1408,305,147,2,146,16400,100,16400,5300,170,3.1,10,10,24.1,2740,9,999999999,100,0.0610,0,88,999.000,999.0,99.0
+1981,12,3,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-0.6,73,98300,363,1408,303,91,4,90,10200,200,10200,3220,200,2.6,10,10,24.1,2440,9,999999999,100,0.0610,0,88,999.000,999.0,99.0
+1981,12,3,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-0.6,70,98300,173,1408,305,25,0,25,2900,0,2900,930,120,3.6,10,10,16.1,1160,9,999999999,100,0.0610,0,88,999.000,999.0,99.0
+1981,12,3,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-0.6,76,98300,10,458,300,2,0,2,0,0,0,0,180,2.6,10,10,12.9,520,9,999999999,100,0.0610,0,88,999.000,999.0,99.0
+1981,12,3,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,0.6,85,98300,0,0,299,0,0,0,0,0,0,0,140,2.1,10,10,9.7,670,9,999999999,110,0.0610,0,88,999.000,999.0,99.0
+1981,12,3,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,0.6,85,98300,0,0,299,0,0,0,0,0,0,0,90,3.6,10,10,11.3,340,9,999999999,110,0.0610,0,88,999.000,999.0,99.0
+1981,12,3,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,0.6,89,98300,0,0,297,0,0,0,0,0,0,0,50,3.6,10,10,6.4,340,9,999999999,110,0.0610,0,88,999.000,999.0,99.0
+1981,12,3,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,0.6,92,98300,0,0,294,0,0,0,0,0,0,0,40,4.1,10,10,4.0,180,9,999999999,110,0.0610,0,88,999.000,999.0,99.0
+1981,12,3,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,0.6,96,98300,0,0,292,0,0,0,0,0,0,0,20,4.1,10,10,4.0,180,9,999999999,110,0.0610,0,88,999.000,999.0,99.0
+1981,12,3,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,1.1,96,98300,0,0,295,0,0,0,0,0,0,0,340,4.1,10,10,4.0,240,9,999999999,110,0.0610,0,88,999.000,999.0,99.0
+1981,12,3,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,1.1,92,98300,0,0,297,0,0,0,0,0,0,0,340,5.7,10,10,4.0,150,9,999999999,110,0.0610,0,88,999.000,999.0,99.0
+1981,12,4,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,1.1,92,98400,0,0,297,0,0,0,0,0,0,0,340,5.7,10,10,4.0,180,9,999999999,110,0.0610,0,88,999.000,999.0,99.0
+1981,12,4,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,1.1,92,98500,0,0,297,0,0,0,0,0,0,0,330,6.2,10,10,4.0,180,9,999999999,110,0.0610,0,88,999.000,999.0,99.0
+1981,12,4,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,1.1,92,98700,0,0,297,0,0,0,0,0,0,0,320,6.2,10,10,4.0,180,9,999999999,110,0.0610,0,88,999.000,999.0,99.0
+1981,12,4,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,0.6,92,98800,0,0,294,0,0,0,0,0,0,0,330,8.2,10,10,4.0,270,9,999999999,110,0.0610,0,88,999.000,999.0,99.0
+1981,12,4,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,0.6,92,99000,0,0,294,0,0,0,0,0,0,0,330,8.8,10,10,4.0,270,9,999999999,110,0.0610,0,88,999.000,999.0,99.0
+1981,12,4,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.7,82,99100,0,0,290,0,0,0,0,0,0,0,330,7.7,10,10,4.0,490,9,999999999,100,0.0610,0,88,999.000,999.0,99.0
+1981,12,4,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.7,82,99300,0,0,282,0,0,0,0,0,0,0,310,5.2,9,9,14.5,760,9,999999999,100,0.0610,0,88,999.000,999.0,99.0
+1981,12,4,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-2.2,82,99400,89,1303,269,29,22,27,3100,1300,3000,630,320,6.2,7,7,16.1,1400,9,999999999,89,0.1100,0,88,999.000,999.0,99.0
+1981,12,4,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-3.3,85,99600,291,1408,261,98,41,89,10700,3400,10000,2150,310,5.2,7,7,16.1,7620,9,999999999,89,0.1100,0,88,999.000,999.0,99.0
+1981,12,4,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-2.2,79,99600,454,1408,265,181,155,130,19600,14400,14900,2940,310,7.2,5,5,19.3,77777,9,999999999,89,0.1100,0,88,999.000,999.0,99.0
+1981,12,4,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-1.1,73,99700,562,1408,281,268,239,171,28200,23600,18800,3660,320,7.2,7,7,19.3,2130,9,999999999,100,0.1100,0,88,999.000,999.0,99.0
+1981,12,4,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-2.2,67,99700,608,1408,272,338,458,137,35500,44700,16100,2720,300,5.2,4,4,24.1,77777,9,999999999,89,0.1100,0,88,999.000,999.0,99.0
+1981,12,4,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.9,-2.8,62,99700,588,1408,260,394,734,83,41300,70800,11600,1700,300,6.2,0,0,24.1,77777,9,999999999,89,0.1100,0,88,999.000,999.0,99.0
+1981,12,4,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-2.2,67,99800,504,1408,270,302,540,106,30700,49400,12900,1960,280,7.7,3,3,24.1,77777,9,999999999,89,0.1100,0,88,999.000,999.0,99.0
+1981,12,4,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.8,-3.3,65,99800,362,1408,264,191,443,75,20000,37100,10400,1370,300,5.2,2,2,24.1,77777,9,999999999,89,0.1100,0,88,999.000,999.0,99.0
+1981,12,4,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-5.0,62,99900,172,1408,250,74,297,37,7400,18100,5200,640,290,5.2,0,0,24.1,77777,9,999999999,80,0.1100,0,88,999.000,999.0,99.0
+1981,12,4,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-4.4,70,99900,10,434,247,7,13,5,0,0,0,0,270,4.1,0,0,24.1,77777,9,999999999,80,0.1100,0,88,999.000,999.0,99.0
+1981,12,4,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-4.4,72,100000,0,0,244,0,0,0,0,0,0,0,260,4.6,0,0,24.1,77777,9,999999999,80,0.1100,0,88,999.000,999.0,99.0
+1981,12,4,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-4.4,72,100000,0,0,264,0,0,0,0,0,0,0,290,5.2,7,7,14.5,340,9,999999999,80,0.1100,0,88,999.000,999.0,99.0
+1981,12,4,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-4.4,75,100000,0,0,280,0,0,0,0,0,0,0,290,6.2,10,10,14.5,340,9,999999999,80,0.1100,0,88,999.000,999.0,99.0
+1981,12,4,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.0,78,100000,0,0,238,0,0,0,0,0,0,0,270,3.6,0,0,14.5,77777,9,999999999,80,0.1100,0,88,999.000,999.0,99.0
+1981,12,4,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-5.6,81,100000,0,0,238,0,0,0,0,0,0,0,260,3.1,1,1,14.5,77777,9,999999999,80,0.1100,0,88,999.000,999.0,99.0
+1981,12,4,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-5.6,81,100100,0,0,257,0,0,0,0,0,0,0,280,4.1,8,8,14.5,760,9,999999999,80,0.1100,0,88,999.000,999.0,99.0
+1981,12,4,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-5.0,69,100000,0,0,282,0,0,0,0,0,0,0,280,3.6,10,10,14.5,760,9,999999999,80,0.1100,0,88,999.000,999.0,99.0
+1981,12,5,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-5.0,69,100000,0,0,282,0,0,0,0,0,0,0,290,3.6,10,10,14.5,760,9,999999999,80,0.1100,0,88,999.000,999.0,99.0
+1981,12,5,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-5.6,67,100100,0,0,281,0,0,0,0,0,0,0,290,5.2,10,10,14.5,760,9,999999999,80,0.1100,0,88,999.000,999.0,99.0
+1981,12,5,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-5.6,67,100100,0,0,273,0,0,0,0,0,0,0,290,3.1,9,9,14.5,760,9,999999999,80,0.1100,0,88,999.000,999.0,99.0
+1981,12,5,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-6.7,69,100100,0,0,244,0,0,0,0,0,0,0,280,2.6,2,2,14.5,77777,9,999999999,69,0.1100,0,88,999.000,999.0,99.0
+1981,12,5,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-6.7,75,100100,0,0,233,0,0,0,0,0,0,0,270,2.6,0,0,14.5,77777,9,999999999,69,0.1100,0,88,999.000,999.0,99.0
+1981,12,5,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-6.1,85,100200,0,0,229,0,0,0,0,0,0,0,270,3.1,0,0,14.5,77777,9,999999999,80,0.1100,0,88,999.000,999.0,99.0
+1981,12,5,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-6.7,85,100200,0,0,227,0,0,0,0,0,0,0,270,2.6,0,0,9.7,77777,9,999999999,69,0.1100,0,88,999.000,999.0,99.0
+1981,12,5,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-6.7,85,100300,86,1280,227,45,329,17,4100,18100,2800,320,280,3.6,0,0,9.7,77777,9,999999999,69,0.0380,0,88,999.000,999.0,99.0
+1981,12,5,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-6.1,78,100300,287,1409,233,174,676,31,18000,55400,6600,720,270,3.1,0,0,11.3,77777,9,999999999,80,0.0380,0,88,999.000,999.0,99.0
+1981,12,5,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-5.0,72,100400,451,1409,242,304,804,41,31700,73400,8100,1010,280,2.6,0,0,11.3,77777,9,999999999,80,0.0380,0,88,999.000,999.0,99.0
+1981,12,5,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-4.4,67,100300,559,1409,248,398,867,47,41500,82200,8700,1180,260,2.6,0,0,16.1,77777,9,999999999,80,0.0380,0,88,999.000,999.0,99.0
+1981,12,5,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-4.4,62,100200,605,1409,252,437,884,50,45500,84700,9000,1250,280,2.1,0,0,19.3,77777,9,999999999,80,0.0380,0,88,999.000,999.0,99.0
+1981,12,5,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-5.6,57,100200,586,1409,251,421,879,49,43900,83900,8900,1220,240,3.6,0,0,19.3,77777,9,999999999,80,0.0380,0,88,999.000,999.0,99.0
+1981,12,5,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-3.9,60,100100,502,1409,257,347,836,44,36300,77800,8400,1090,270,2.6,0,0,19.3,77777,9,999999999,89,0.0380,0,88,999.000,999.0,99.0
+1981,12,5,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-3.9,64,100100,360,1409,253,226,727,37,23700,63100,7400,870,230,3.1,1,0,16.1,77777,9,999999999,89,0.0380,0,88,999.000,999.0,99.0
+1981,12,5,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-3.9,72,100000,171,1409,247,86,494,24,8600,33100,4600,470,260,2.6,1,0,16.1,77777,9,999999999,89,0.0380,0,88,999.000,999.0,99.0
+1981,12,5,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-5.0,78,100100,10,434,238,12,67,5,0,0,0,0,250,1.5,1,0,16.1,77777,9,999999999,80,0.0380,0,88,999.000,999.0,99.0
+1981,12,5,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-5.0,82,100100,0,0,236,0,0,0,0,0,0,0,0,0.0,0,0,16.1,77777,9,999999999,80,0.0380,0,88,999.000,999.0,99.0
+1981,12,5,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-6.1,85,100100,0,0,229,0,0,0,0,0,0,0,0,0.0,0,0,12.9,77777,9,999999999,80,0.0380,0,88,999.000,999.0,99.0
+1981,12,5,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-5.6,88,100000,0,0,230,0,0,0,0,0,0,0,0,0.0,0,0,11.3,77777,9,999999999,80,0.0380,0,88,999.000,999.0,99.0
+1981,12,5,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-5.6,88,100000,0,0,230,0,0,0,0,0,0,0,140,2.6,0,0,16.1,77777,9,999999999,80,0.0380,0,88,999.000,999.0,99.0
+1981,12,5,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-5.0,85,100000,0,0,234,0,0,0,0,0,0,0,150,2.6,0,0,9.7,77777,9,999999999,80,0.0380,0,88,999.000,999.0,99.0
+1981,12,5,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-5.0,82,100000,0,0,236,0,0,0,0,0,0,0,160,3.1,0,0,11.3,77777,9,999999999,80,0.0380,0,88,999.000,999.0,99.0
+1981,12,5,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-4.4,82,99900,0,0,238,0,0,0,0,0,0,0,160,3.1,2,0,11.3,77777,9,999999999,80,0.0380,0,88,999.000,999.0,99.0
+1981,12,6,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-3.9,85,99800,0,0,239,0,0,0,0,0,0,0,160,3.6,1,0,11.3,77777,9,999999999,89,0.0380,0,88,999.000,999.0,99.0
+1981,12,6,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-4.4,82,99800,0,0,238,0,0,0,0,0,0,0,160,3.6,2,0,11.3,77777,9,999999999,80,0.0380,0,88,999.000,999.0,99.0
+1981,12,6,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-4.4,82,99800,0,0,243,0,0,0,0,0,0,0,150,3.6,3,1,11.3,77777,9,999999999,80,0.0380,0,88,999.000,999.0,99.0
+1981,12,6,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-3.9,85,99800,0,0,243,0,0,0,0,0,0,0,180,4.1,3,1,11.3,77777,9,999999999,89,0.0380,0,88,999.000,999.0,99.0
+1981,12,6,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-3.9,85,99600,0,0,243,0,0,0,0,0,0,0,180,5.2,3,1,11.3,77777,9,999999999,89,0.0380,0,88,999.000,999.0,99.0
+1981,12,6,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-3.9,82,99700,0,0,246,0,0,0,0,0,0,0,180,3.1,3,1,11.3,77777,9,999999999,89,0.0380,0,88,999.000,999.0,99.0
+1981,12,6,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-3.3,79,99600,0,0,265,0,0,0,0,0,0,0,170,3.6,7,7,11.3,7620,9,999999999,89,0.0380,0,88,999.000,999.0,99.0
+1981,12,6,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-2.8,79,99600,82,1256,259,18,18,17,2000,800,2000,350,180,4.6,7,3,19.3,77777,9,999999999,89,0.1470,0,88,999.000,999.0,99.0
+1981,12,6,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-1.7,79,99400,284,1409,264,123,207,80,12800,15600,9600,1560,180,6.2,8,3,24.1,77777,9,999999999,100,0.1470,0,88,999.000,999.0,99.0
+1981,12,6,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,3.3,-1.7,70,99400,447,1409,280,139,84,112,15200,7800,12700,2520,180,6.2,10,7,24.1,7620,9,999999999,100,0.1470,0,88,999.000,999.0,99.0
+1981,12,6,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,4.4,-1.7,65,99300,556,1409,275,319,461,133,33100,44100,15700,2600,180,7.7,7,3,24.1,77777,9,999999999,100,0.1470,0,88,999.000,999.0,99.0
+1981,12,6,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,-1.1,63,99200,603,1409,284,232,197,147,25000,19800,16500,3060,180,6.7,9,5,24.1,6100,9,999999999,100,0.1470,0,88,999.000,999.0,99.0
+1981,12,6,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.2,-1.1,56,99000,584,1409,297,273,170,201,29300,16800,22300,4750,190,7.7,9,7,24.1,6100,9,999999999,100,0.1470,0,88,999.000,999.0,99.0
+1981,12,6,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,-0.6,60,99000,501,1409,306,140,40,126,15400,3800,14100,3520,190,7.7,10,9,24.1,3660,9,999999999,100,0.1470,0,88,999.000,999.0,99.0
+1981,12,6,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.7,-0.6,60,98900,359,1409,306,110,69,92,12000,6000,10500,2390,190,6.2,9,9,24.1,2740,9,999999999,100,0.1470,0,88,999.000,999.0,99.0
+1981,12,6,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,0.0,65,98800,170,1409,285,63,68,54,6700,4100,6200,1130,160,5.7,9,4,24.1,77777,9,999999999,110,0.1470,0,88,999.000,999.0,99.0
+1981,12,6,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,0.6,73,98900,10,434,294,4,0,4,0,0,0,0,190,5.2,10,8,24.1,2740,9,999999999,110,0.1470,0,88,999.000,999.0,99.0
+1981,12,6,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,4.4,0.6,76,98700,0,0,287,0,0,0,0,0,0,0,180,5.2,9,7,24.1,3350,9,999999999,110,0.1470,0,88,999.000,999.0,99.0
+1981,12,6,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,1.1,76,98600,0,0,301,0,0,0,0,0,0,0,180,6.2,10,9,24.1,7620,9,999999999,110,0.1470,0,88,999.000,999.0,99.0
+1981,12,6,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,0.6,73,98500,0,0,294,0,0,0,0,0,0,0,190,5.2,9,8,24.1,2740,9,999999999,110,0.1470,0,88,999.000,999.0,99.0
+1981,12,6,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,0.6,73,98400,0,0,279,0,0,0,0,0,0,0,200,5.7,3,3,24.1,77777,9,999999999,110,0.1470,0,88,999.000,999.0,99.0
+1981,12,6,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,0.6,73,98300,0,0,289,0,0,0,0,0,0,0,180,6.2,7,7,24.1,2740,9,999999999,110,0.1470,0,88,999.000,999.0,99.0
+1981,12,6,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,0.6,73,98300,0,0,309,0,0,0,0,0,0,0,210,5.2,10,10,24.1,2440,9,999999999,110,0.1470,0,88,999.000,999.0,99.0
+1981,12,6,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,0.6,73,98300,0,0,309,0,0,0,0,0,0,0,200,4.6,10,10,24.1,2440,9,999999999,110,0.1470,0,88,999.000,999.0,99.0
+1981,12,7,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,1.1,76,98200,0,0,309,0,0,0,0,0,0,0,190,5.7,10,10,24.1,2440,9,999999999,110,0.1470,0,88,999.000,999.0,99.0
+1981,12,7,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,1.1,76,98200,0,0,309,0,0,0,0,0,0,0,210,5.2,10,10,24.1,2440,9,999999999,110,0.1470,0,88,999.000,999.0,99.0
+1981,12,7,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,1.1,76,98100,0,0,309,0,0,0,0,0,0,0,190,3.6,10,10,11.3,2130,9,999999999,110,0.1470,0,88,999.000,999.0,99.0
+1981,12,7,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,1.7,79,98100,0,0,310,0,0,0,0,0,0,0,210,5.2,10,10,11.3,2130,9,999999999,120,0.1470,0,88,999.000,999.0,99.0
+1981,12,7,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,1.7,79,98100,0,0,310,0,0,0,0,0,0,0,230,3.6,10,10,11.3,2130,9,999999999,120,0.1470,0,88,999.000,999.0,99.0
+1981,12,7,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,1.7,79,98100,0,0,310,0,0,0,0,0,0,0,250,2.6,10,10,11.3,2130,9,999999999,120,0.1470,0,88,999.000,999.0,99.0
+1981,12,7,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,1.7,79,98100,0,0,302,0,0,0,0,0,0,0,230,4.1,9,9,16.1,2440,9,999999999,120,0.1470,0,88,999.000,999.0,99.0
+1981,12,7,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.0,1.7,79,98100,79,1233,302,20,14,19,2200,800,2100,470,230,5.2,9,9,11.3,2440,9,999999999,120,0.0630,0,88,999.000,999.0,99.0
+1981,12,7,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,5.6,2.2,79,98100,280,1409,313,67,2,66,7400,100,7400,2310,240,3.6,10,10,11.3,2440,9,999999999,120,0.0630,0,88,999.000,999.0,99.0
+1981,12,7,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,6.1,2.2,76,98100,444,1409,316,139,8,136,15400,500,15200,4680,240,4.1,10,10,11.3,3960,9,999999999,120,0.0630,0,88,999.000,999.0,99.0
+1981,12,7,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,7.8,2.8,71,97900,553,1409,308,162,59,138,17700,5600,15500,3970,200,6.2,8,8,12.9,3960,9,999999999,129,0.0630,0,88,999.000,999.0,99.0
+1981,12,7,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.9,2.8,66,98000,600,1409,308,358,480,150,37200,46700,17200,3010,230,3.1,7,7,16.1,3960,9,999999999,129,0.0630,0,88,999.000,999.0,99.0
+1981,12,7,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,2.8,63,98100,582,1409,322,193,207,106,21100,20700,12500,2080,270,6.7,9,9,12.9,1830,9,999999999,120,0.0630,0,88,999.000,999.0,99.0
+1981,12,7,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,2.2,61,97800,499,1409,310,209,183,143,22700,17500,16400,3280,210,4.6,7,7,14.5,1520,9,999999999,120,0.0630,0,88,999.000,999.0,99.0
+1981,12,7,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,11.1,3.3,59,98000,358,1409,319,147,226,89,15600,19100,10700,1710,260,5.2,7,7,16.1,2440,9,999999999,129,0.0630,0,88,999.000,999.0,99.0
+1981,12,7,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,9.4,3.9,69,98100,170,1409,308,52,68,43,5600,4200,5100,900,280,5.2,7,6,19.3,3660,9,999999999,129,0.0630,0,88,999.000,999.0,99.0
+1981,12,7,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,8.3,3.9,74,98200,10,435,312,4,6,3,0,0,0,0,270,3.1,8,8,19.3,2440,9,999999999,129,0.0630,0,88,999.000,999.0,99.0
+1981,12,7,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,7.8,2.2,68,98200,0,0,289,0,0,0,0,0,0,0,280,4.1,2,2,24.1,77777,9,999999999,120,0.0630,0,88,999.000,999.0,99.0
+1981,12,7,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.1,1.7,73,98300,0,0,273,0,0,0,0,0,0,0,270,3.6,0,0,24.1,77777,9,999999999,120,0.0630,0,88,999.000,999.0,99.0
+1981,12,7,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,1.1,73,98400,0,0,297,0,0,0,0,0,0,0,290,5.2,8,8,24.1,670,9,999999999,110,0.0630,0,88,999.000,999.0,99.0
+1981,12,7,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,6.7,0.6,65,98500,0,0,316,0,0,0,0,0,0,0,310,6.7,10,10,24.1,760,9,999999999,110,0.0630,0,88,999.000,999.0,99.0
+1981,12,7,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.6,-1.1,63,98600,0,0,310,0,0,0,0,0,0,0,300,6.7,10,10,24.1,670,9,999999999,100,0.0630,0,88,999.000,999.0,99.0
+1981,12,7,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,5.0,-1.7,62,98700,0,0,306,0,0,0,0,0,0,0,310,8.2,10,10,24.1,670,9,999999999,100,0.0630,0,88,999.000,999.0,99.0
+1981,12,7,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-4.4,57,98800,0,0,296,0,0,0,0,0,0,0,330,7.7,10,10,24.1,850,9,999999999,80,0.0630,0,88,999.000,999.0,99.0
+1981,12,8,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,3.3,-4.4,57,98800,0,0,296,0,0,0,0,0,0,0,310,6.7,10,10,24.1,850,9,999999999,80,0.0630,0,88,999.000,999.0,99.0
+1981,12,8,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-4.4,59,98900,0,0,294,0,0,0,0,0,0,0,300,5.2,10,10,24.1,850,9,999999999,80,0.0630,0,88,999.000,999.0,99.0
+1981,12,8,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-3.9,62,98900,0,0,294,0,0,0,0,0,0,0,290,6.7,10,10,24.1,980,9,999999999,89,0.0630,0,88,999.000,999.0,99.0
+1981,12,8,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.8,-4.4,59,99000,0,0,294,0,0,0,0,0,0,0,310,5.2,10,10,24.1,1160,9,999999999,80,0.0630,0,88,999.000,999.0,99.0
+1981,12,8,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-5.0,59,99100,0,0,291,0,0,0,0,0,0,0,320,7.7,10,10,24.1,980,9,999999999,80,0.0630,0,88,999.000,999.0,99.0
+1981,12,8,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,2.2,-5.6,57,99200,0,0,290,0,0,0,0,0,0,0,310,6.7,10,10,24.1,850,9,999999999,80,0.0630,0,88,999.000,999.0,99.0
+1981,12,8,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.7,-5.0,62,99300,0,0,289,0,0,0,0,0,0,0,300,6.2,10,10,24.1,760,9,999999999,80,0.0630,0,88,999.000,999.0,99.0
+1981,12,8,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-5.0,62,99400,77,1210,289,17,6,17,1900,300,1900,420,320,6.2,10,10,24.1,670,9,999999999,80,0.0500,0,88,999.000,999.0,99.0
+1981,12,8,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-5.0,62,99400,277,1410,289,81,1,81,8900,0,8900,2620,320,7.7,10,10,24.1,760,9,999999999,80,0.0500,0,88,999.000,999.0,99.0
+1981,12,8,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-5.6,59,99500,441,1410,288,97,1,96,11000,100,11000,3690,300,6.2,10,10,24.1,760,9,999999999,80,0.0500,0,88,999.000,999.0,99.0
+1981,12,8,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-6.1,57,99500,550,1410,287,185,6,182,20500,500,20300,6380,320,7.2,10,10,24.1,980,9,999999999,80,0.0500,0,88,999.000,999.0,99.0
+1981,12,8,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-6.7,54,99500,598,1410,287,167,9,163,18900,700,18600,6280,340,7.7,10,10,24.1,1220,9,999999999,69,0.0500,0,88,999.000,999.0,99.0
+1981,12,8,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-6.7,54,99500,580,1410,287,187,4,186,20900,300,20800,6690,310,6.2,10,10,24.1,980,9,999999999,69,0.0500,0,88,999.000,999.0,99.0
+1981,12,8,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-7.2,52,99500,498,1410,286,147,4,145,16400,300,16300,5220,340,8.2,10,10,24.1,980,9,999999999,69,0.0500,0,88,999.000,999.0,99.0
+1981,12,8,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-7.2,52,99600,357,1410,286,101,3,100,11200,200,11200,3420,310,5.7,10,10,24.1,980,9,999999999,69,0.0500,0,88,999.000,999.0,99.0
+1981,12,8,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-6.7,61,99700,169,1410,280,47,1,47,5200,0,5200,1480,300,4.6,10,10,24.1,980,9,999999999,69,0.0500,0,88,999.000,999.0,99.0
+1981,12,8,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-6.7,66,99700,10,435,275,6,0,6,0,0,0,0,310,5.2,10,10,19.3,980,9,999999999,69,0.0500,0,88,999.000,999.0,99.0
+1981,12,8,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-4.4,82,99800,0,0,275,0,0,0,0,0,0,0,290,4.6,10,10,19.3,980,9,999999999,80,0.0500,0,88,999.000,999.0,99.0
+1981,12,8,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-5.0,82,99800,0,0,273,0,0,0,0,0,0,0,310,6.2,10,10,19.3,980,9,999999999,80,0.0500,0,88,999.000,999.0,99.0
+1981,12,8,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-3.9,85,99800,0,0,276,0,0,0,0,0,0,0,300,3.6,10,10,19.3,980,9,999999999,89,0.0500,0,88,999.000,999.0,99.0
+1981,12,8,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-5.0,85,99900,0,0,270,0,0,0,0,0,0,0,320,6.2,10,10,24.1,760,9,999999999,80,0.0500,0,88,999.000,999.0,99.0
+1981,12,8,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-5.0,82,99900,0,0,259,0,0,0,0,0,0,0,310,3.6,8,8,24.1,850,9,999999999,80,0.0500,0,88,999.000,999.0,99.0
+1981,12,8,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-5.6,78,99900,0,0,243,0,0,0,0,0,0,0,310,5.2,2,2,24.1,77777,9,999999999,80,0.0500,0,88,999.000,999.0,99.0
+1981,12,8,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-6.1,75,99900,0,0,240,0,0,0,0,0,0,0,310,4.1,1,1,24.1,77777,9,999999999,80,0.0500,0,88,999.000,999.0,99.0
+1981,12,9,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-6.1,78,100000,0,0,241,0,0,0,0,0,0,0,300,4.6,2,2,24.1,77777,9,999999999,80,0.0500,0,88,999.000,999.0,99.0
+1981,12,9,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-6.1,72,100000,0,0,273,0,0,0,0,0,0,0,300,4.6,10,10,24.1,1160,9,999999999,80,0.0500,0,88,999.000,999.0,99.0
+1981,12,9,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-6.7,78,100000,0,0,231,0,0,0,0,0,0,0,310,4.1,0,0,24.1,77777,9,999999999,69,0.0500,0,88,999.000,999.0,99.0
+1981,12,9,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-6.7,85,100100,0,0,227,0,0,0,0,0,0,0,330,4.1,0,0,24.1,77777,9,999999999,69,0.0500,0,88,999.000,999.0,99.0
+1981,12,9,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-7.2,88,100100,0,0,223,0,0,0,0,0,0,0,310,3.6,0,0,24.1,77777,9,999999999,69,0.0500,0,88,999.000,999.0,99.0
+1981,12,9,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-7.8,88,100100,0,0,221,0,0,0,0,0,0,0,310,3.6,0,0,24.1,77777,9,999999999,69,0.0500,0,88,999.000,999.0,99.0
+1981,12,9,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-7.8,88,100100,0,0,221,0,0,0,0,0,0,0,320,3.6,0,0,24.1,77777,9,999999999,69,0.0500,0,88,999.000,999.0,99.0
+1981,12,9,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.6,-7.8,85,100200,74,1187,222,29,90,21,2900,3200,2700,370,300,3.1,0,0,24.1,77777,9,999999999,69,0.1280,0,88,999.000,999.0,99.0
+1981,12,9,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.9,-6.7,81,100200,274,1410,229,139,428,54,14000,32200,7700,960,310,4.1,0,0,24.1,77777,9,999999999,69,0.1280,0,88,999.000,999.0,99.0
+1981,12,9,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-6.1,75,100300,438,1410,243,207,345,97,21500,30900,11900,1810,320,6.2,2,2,24.1,77777,9,999999999,80,0.1280,0,88,999.000,999.0,99.0
+1981,12,9,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-7.2,66,100300,548,1410,252,269,274,160,28300,26900,17800,3380,350,7.2,6,6,24.1,670,9,999999999,69,0.1280,0,88,999.000,999.0,99.0
+1981,12,9,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-8.3,61,100200,596,1410,264,106,31,93,11700,3000,10500,2920,310,5.7,9,9,24.1,980,9,999999999,69,0.1280,0,88,999.000,999.0,99.0
+1981,12,9,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-8.9,58,100200,578,1410,271,162,58,138,17800,5600,15500,4050,330,7.7,10,10,24.1,850,9,999999999,60,0.1280,0,88,999.000,999.0,99.0
+1981,12,9,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-8.3,61,100200,497,1410,271,113,16,108,13000,1000,12700,4260,320,6.7,10,10,24.1,850,9,999999999,69,0.1280,0,88,999.000,999.0,99.0
+1981,12,9,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-8.3,63,100100,357,1410,269,95,2,94,10600,100,10500,3280,320,7.2,10,10,24.1,980,9,999999999,69,0.1280,0,88,999.000,999.0,99.0
+1981,12,9,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-9.4,58,100200,169,1410,255,44,31,40,4800,2100,4500,970,320,7.2,8,8,24.1,980,9,999999999,60,0.1280,0,88,999.000,999.0,99.0
+1981,12,9,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-10.0,58,100200,10,435,265,0,0,0,0,0,0,0,320,6.2,10,10,24.1,980,9,999999999,60,0.1280,0,88,999.000,999.0,99.0
+1981,12,9,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-10.0,63,100200,0,0,233,0,0,0,0,0,0,0,320,5.2,2,2,24.1,77777,9,999999999,60,0.1280,0,88,999.000,999.0,99.0
+1981,12,9,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-10.0,68,100200,0,0,240,0,0,0,0,0,0,0,320,4.1,7,7,24.1,980,9,999999999,60,0.1280,0,88,999.000,999.0,99.0
+1981,12,9,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-10.6,74,100200,0,0,223,0,0,0,0,0,0,0,320,3.1,2,2,24.1,77777,9,999999999,60,0.1280,0,88,999.000,999.0,99.0
+1981,12,9,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-10.6,77,100200,0,0,215,0,0,0,0,0,0,0,320,5.2,0,0,24.1,77777,9,999999999,60,0.1280,0,88,999.000,999.0,99.0
+1981,12,9,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-10.6,77,100200,0,0,224,0,0,0,0,0,0,0,320,5.2,3,3,24.1,77777,9,999999999,60,0.1280,0,88,999.000,999.0,99.0
+1981,12,9,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-10.0,74,100200,0,0,226,0,0,0,0,0,0,0,310,5.2,2,2,24.1,77777,9,999999999,60,0.1280,0,88,999.000,999.0,99.0
+1981,12,9,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-10.6,74,100200,0,0,216,0,0,0,0,0,0,0,320,5.2,0,0,24.1,77777,9,999999999,60,0.1280,0,88,999.000,999.0,99.0
+1981,12,10,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-10.6,77,100200,0,0,215,0,0,0,0,0,0,0,330,5.2,0,0,24.1,77777,9,999999999,60,0.1280,0,88,999.000,999.0,99.0
+1981,12,10,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-10.6,77,100200,0,0,215,0,0,0,0,0,0,0,330,4.1,0,0,24.1,77777,9,999999999,60,0.1280,0,88,999.000,999.0,99.0
+1981,12,10,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-11.1,77,100200,0,0,212,0,0,0,0,0,0,0,300,4.1,0,0,24.1,77777,9,999999999,60,0.1280,0,88,999.000,999.0,99.0
+1981,12,10,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-11.1,77,100100,0,0,212,0,0,0,0,0,0,0,320,4.1,0,0,24.1,77777,9,999999999,60,0.1280,0,88,999.000,999.0,99.0
+1981,12,10,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-11.1,77,100100,0,0,212,0,0,0,0,0,0,0,300,4.1,0,0,24.1,77777,9,999999999,60,0.1280,0,88,999.000,999.0,99.0
+1981,12,10,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-11.1,81,100200,0,0,211,0,0,0,0,0,0,0,310,3.1,0,0,24.1,77777,9,999999999,60,0.1280,0,88,999.000,999.0,99.0
+1981,12,10,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-11.1,81,100100,0,0,211,0,0,0,0,0,0,0,320,3.6,0,0,24.1,77777,9,999999999,60,0.1280,0,88,999.000,999.0,99.0
+1981,12,10,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.3,-11.1,81,100100,71,1164,211,38,243,17,3400,11300,2600,310,310,2.6,0,0,24.1,77777,9,999999999,60,0.0510,0,88,999.000,999.0,99.0
+1981,12,10,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.7,-11.1,71,100100,271,1411,216,159,628,34,16000,49500,6500,690,320,5.2,0,0,24.1,77777,9,999999999,60,0.0510,0,88,999.000,999.0,99.0
+1981,12,10,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.0,-10.6,65,100100,435,1411,226,265,684,49,27400,61900,8200,1030,340,5.2,2,1,24.1,77777,9,999999999,60,0.0510,0,88,999.000,999.0,99.0
+1981,12,10,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-10.0,60,100100,545,1411,232,356,747,62,37000,70800,9500,1310,320,4.6,2,1,24.1,77777,9,999999999,60,0.0510,0,88,999.000,999.0,99.0
+1981,12,10,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-10.0,53,100000,594,1411,238,392,786,56,40800,75000,9100,1300,340,6.7,2,1,24.1,77777,9,999999999,60,0.0510,0,88,999.000,999.0,99.0
+1981,12,10,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-10.0,51,100000,577,1411,240,378,777,56,39400,73900,9100,1280,10,5.2,2,1,24.1,77777,9,999999999,60,0.0510,0,88,999.000,999.0,99.0
+1981,12,10,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-10.0,49,99900,496,1411,245,309,697,61,31900,64600,9100,1240,330,4.6,3,2,24.1,77777,9,999999999,60,0.0510,0,88,999.000,999.0,99.0
+1981,12,10,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-10.0,49,99900,356,1411,251,197,490,72,20000,40600,9700,1290,360,4.6,5,5,24.1,77777,9,999999999,60,0.0510,0,88,999.000,999.0,99.0
+1981,12,10,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-10.0,53,99900,169,1411,246,77,312,39,7700,18800,5400,660,350,4.6,4,4,24.1,77777,9,999999999,60,0.0510,0,88,999.000,999.0,99.0
+1981,12,10,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-10.6,63,99900,10,435,234,9,24,6,0,0,0,0,10,3.1,3,3,24.1,77777,9,999999999,60,0.0510,0,88,999.000,999.0,99.0
+1981,12,10,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-10.6,71,99900,0,0,218,0,0,0,0,0,0,0,10,3.1,1,0,24.1,77777,9,999999999,60,0.0510,0,88,999.000,999.0,99.0
+1981,12,10,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-10.6,74,99900,0,0,216,0,0,0,0,0,0,0,360,2.6,0,0,24.1,77777,9,999999999,60,0.0510,0,88,999.000,999.0,99.0
+1981,12,10,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-10.6,77,99900,0,0,215,0,0,0,0,0,0,0,320,2.6,0,0,24.1,77777,9,999999999,60,0.0510,0,88,999.000,999.0,99.0
+1981,12,10,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-9.4,74,99900,0,0,243,0,0,0,0,0,0,0,290,4.1,9,8,24.1,1830,9,999999999,60,0.0510,0,88,999.000,999.0,99.0
+1981,12,10,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-8.3,78,99800,0,0,258,0,0,0,0,0,0,0,310,4.6,10,10,24.1,850,9,999999999,69,0.0510,0,88,999.000,999.0,99.0
+1981,12,10,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-8.9,74,99800,0,0,251,0,0,0,0,0,0,0,310,3.6,9,9,24.1,760,9,999999999,60,0.0510,0,88,999.000,999.0,99.0
+1981,12,10,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-8.9,74,99800,0,0,258,0,0,0,0,0,0,0,280,3.1,10,10,24.1,670,9,999999999,60,0.0510,0,88,999.000,999.0,99.0
+1981,12,11,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-8.9,74,99800,0,0,251,0,0,0,0,0,0,0,310,3.6,9,9,24.1,760,9,999999999,60,0.0510,0,88,999.000,999.0,99.0
+1981,12,11,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-9.4,78,99800,0,0,234,0,0,0,0,0,0,0,310,3.1,6,6,24.1,760,9,999999999,60,0.0510,0,88,999.000,999.0,99.0
+1981,12,11,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-10.0,81,99800,0,0,219,0,0,0,0,0,0,0,310,2.6,3,1,24.1,77777,9,999999999,60,0.0510,0,88,999.000,999.0,99.0
+1981,12,11,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-10.6,77,99800,0,0,229,0,0,0,0,0,0,0,310,2.1,6,6,24.1,760,9,999999999,60,0.0510,0,88,999.000,999.0,99.0
+1981,12,11,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-11.1,77,99800,0,0,216,0,0,0,0,0,0,0,310,2.1,4,1,24.1,77777,9,999999999,60,0.0510,0,88,999.000,999.0,99.0
+1981,12,11,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-11.1,81,99800,0,0,218,0,0,0,0,0,0,0,310,1.5,10,2,24.1,77777,9,999999999,60,0.0510,0,88,999.000,999.0,99.0
+1981,12,11,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-10.6,77,99900,0,0,236,0,0,0,0,0,0,0,300,3.1,10,8,24.1,7620,9,999999999,60,0.0510,0,88,999.000,999.0,99.0
+1981,12,11,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.2,-10.6,77,99900,69,1141,232,18,36,15,1900,1300,1800,250,310,2.6,8,7,24.1,7620,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,11,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.0,-10.0,68,99900,268,1411,230,130,375,56,13400,27500,8200,1010,360,4.6,7,2,24.1,77777,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,11,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.9,-10.6,60,100000,432,1411,233,249,453,107,25600,40300,13200,2020,360,4.1,7,2,24.1,77777,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,11,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-10.6,55,99900,543,1411,245,265,354,126,27700,33700,14600,2440,330,3.1,7,6,24.1,7620,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,11,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-10.6,51,99900,592,1411,249,173,84,137,19100,8400,15500,3240,320,2.6,7,6,24.1,7620,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,11,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-10.0,47,99800,575,1411,252,288,303,162,30500,30100,18100,3430,30,2.6,4,4,24.1,77777,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,11,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-10.0,47,99800,495,1411,244,319,720,63,32800,66600,9300,1260,20,2.6,1,1,24.1,77777,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,11,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-10.0,47,99700,356,1411,239,214,658,45,21900,56300,7600,900,30,3.1,0,0,24.1,77777,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,11,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-10.0,51,99800,169,1411,236,78,392,30,7900,24100,5000,540,20,2.6,1,0,24.1,77777,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,11,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-8.9,63,99800,10,435,231,10,32,6,0,0,0,0,40,3.1,1,0,24.1,77777,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,11,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-9.4,71,99800,0,0,223,0,0,0,0,0,0,0,30,2.1,0,0,24.1,77777,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,11,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-10.0,77,99900,0,0,217,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,11,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-9.4,84,99900,0,0,216,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,11,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-9.4,84,99900,0,0,216,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,11,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-9.4,81,99900,0,0,217,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,11,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-8.9,88,99900,0,0,216,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,11,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-10.0,88,99800,0,0,212,0,0,0,0,0,0,0,240,2.1,0,0,24.1,77777,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,12,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-10.0,88,99800,0,0,212,0,0,0,0,0,0,0,290,2.6,0,0,24.1,77777,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,12,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-10.0,84,99900,0,0,220,0,0,0,0,0,0,0,0,0.0,2,2,24.1,77777,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,12,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-10.0,84,99900,0,0,217,0,0,0,0,0,0,0,270,1.5,1,1,24.1,77777,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,12,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-10.0,88,99900,0,0,219,0,0,0,0,0,0,0,290,1.5,2,2,24.1,77777,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,12,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-10.0,84,99900,0,0,217,0,0,0,0,0,0,0,260,2.6,1,1,24.1,77777,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,12,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-10.0,88,99900,0,0,216,0,0,0,0,0,0,0,280,2.6,1,1,24.1,77777,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,12,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-10.0,84,100000,0,0,222,0,0,0,0,0,0,0,0,0.0,3,3,19.3,77777,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,12,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.2,-9.4,84,100000,66,1117,220,23,35,20,2500,1500,2400,410,0,0.0,5,1,19.3,77777,9,999999999,60,0.1630,0,88,999.000,999.0,99.0
+1981,12,12,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.0,-8.9,74,100000,265,1411,228,118,276,64,12000,20100,8200,1170,0,0.0,5,1,19.3,77777,9,999999999,60,0.1630,0,88,999.000,999.0,99.0
+1981,12,12,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-6.1,75,100100,430,1411,240,231,448,91,24100,39900,11900,1690,270,2.1,5,1,19.3,77777,9,999999999,80,0.1630,0,88,999.000,999.0,99.0
+1981,12,12,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-5.6,67,100100,541,1411,260,308,420,143,31600,39800,16300,2810,270,3.1,8,6,24.1,3050,9,999999999,80,0.1630,0,88,999.000,999.0,99.0
+1981,12,12,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-5.0,64,100000,590,1411,265,248,262,137,26700,26300,15700,2810,240,2.6,8,6,24.1,3050,9,999999999,80,0.1630,0,88,999.000,999.0,99.0
+1981,12,12,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-5.6,59,100000,574,1411,262,287,324,153,30500,32200,17400,3200,250,3.6,9,4,24.1,77777,9,999999999,80,0.1630,0,88,999.000,999.0,99.0
+1981,12,12,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-2.8,70,100000,494,1411,285,153,14,148,17100,1000,16700,5260,240,3.6,10,9,24.1,3050,9,999999999,89,0.1630,0,88,999.000,999.0,99.0
+1981,12,12,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-5.6,59,99900,356,1411,274,105,81,84,11500,7000,9700,1840,210,3.1,10,8,24.1,3050,9,999999999,80,0.1630,0,88,999.000,999.0,99.0
+1981,12,12,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-5.6,62,99900,169,1411,285,38,0,38,4300,0,4300,1280,210,2.6,10,10,24.1,3050,9,999999999,80,0.1630,0,88,999.000,999.0,99.0
+1981,12,12,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-5.6,64,99900,10,435,283,3,0,3,0,0,0,0,200,1.5,10,10,24.1,3050,9,999999999,80,0.1630,0,88,999.000,999.0,99.0
+1981,12,12,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-5.6,67,99900,0,0,281,0,0,0,0,0,0,0,0,0.0,10,10,24.1,3050,9,999999999,80,0.1630,0,88,999.000,999.0,99.0
+1981,12,12,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-5.0,72,99900,0,0,266,0,0,0,0,0,0,0,180,2.1,8,8,24.1,3050,9,999999999,80,0.1630,0,88,999.000,999.0,99.0
+1981,12,12,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-5.0,72,100000,0,0,279,0,0,0,0,0,0,0,0,0.0,10,10,24.1,1400,9,999999999,80,0.1630,0,88,999.000,999.0,99.0
+1981,12,12,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-4.4,72,100000,0,0,269,0,0,0,0,0,0,0,210,2.1,9,8,24.1,1400,9,999999999,80,0.1630,0,88,999.000,999.0,99.0
+1981,12,12,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-4.4,72,99900,0,0,274,0,0,0,0,0,0,0,180,2.6,9,9,24.1,1400,9,999999999,80,0.1630,0,88,999.000,999.0,99.0
+1981,12,12,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-4.4,72,99900,0,0,282,0,0,0,0,0,0,0,190,4.1,10,10,24.1,1400,9,999999999,80,0.1630,0,88,999.000,999.0,99.0
+1981,12,12,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-4.4,72,99900,0,0,282,0,0,0,0,0,0,0,180,3.6,10,10,24.1,1160,9,999999999,80,0.1630,0,88,999.000,999.0,99.0
+1981,12,13,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-3.9,75,99900,0,0,283,0,0,0,0,0,0,0,200,3.6,10,10,24.1,1370,9,999999999,89,0.1630,0,88,999.000,999.0,99.0
+1981,12,13,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-4.4,72,99900,0,0,282,0,0,0,0,0,0,0,180,2.1,10,10,24.1,1370,9,999999999,80,0.1630,0,88,999.000,999.0,99.0
+1981,12,13,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-3.9,75,99900,0,0,283,0,0,0,0,0,0,0,220,2.6,10,10,24.1,1370,9,999999999,89,0.1630,0,88,999.000,999.0,99.0
+1981,12,13,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-3.3,82,99900,0,0,281,0,0,0,0,0,0,0,200,1.5,10,10,8.0,760,9,999999999,89,0.1630,0,88,999.000,999.0,99.0
+1981,12,13,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-3.3,85,99900,0,0,271,0,0,0,0,0,0,0,190,2.6,9,9,16.1,670,9,999999999,89,0.1630,0,88,999.000,999.0,99.0
+1981,12,13,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-2.8,89,100000,0,0,279,0,0,0,0,0,0,0,200,2.6,10,10,19.3,670,9,999999999,89,0.1630,0,88,999.000,999.0,99.0
+1981,12,13,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-2.8,85,100000,0,0,281,0,0,0,0,0,0,0,200,3.1,10,10,16.1,670,9,999999999,89,0.1630,0,88,999.000,999.0,99.0
+1981,12,13,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-2.8,85,100000,64,1118,281,19,1,19,2100,0,2100,640,180,2.6,10,10,16.1,580,9,999999999,89,0.1010,0,88,999.000,999.0,99.0
+1981,12,13,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-3.3,79,100000,262,1412,283,46,3,46,5300,100,5300,1720,190,2.1,10,10,16.1,580,9,999999999,89,0.1010,0,88,999.000,999.0,99.0
+1981,12,13,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-2.8,82,100000,427,1412,284,105,2,105,11900,100,11900,3880,190,2.1,10,10,16.1,580,9,999999999,89,0.1010,0,88,999.000,999.0,99.0
+1981,12,13,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-2.8,76,99900,539,1412,288,155,4,154,17500,300,17400,5680,220,2.1,10,10,19.3,1160,9,999999999,89,0.1010,0,88,999.000,999.0,99.0
+1981,12,13,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-3.3,70,99900,589,1412,290,170,5,168,19200,400,19000,6340,220,3.1,10,10,19.3,1160,9,999999999,89,0.1010,0,88,999.000,999.0,99.0
+1981,12,13,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-3.3,67,99900,573,1412,293,162,4,160,18200,300,18100,6050,230,2.1,10,10,19.3,1160,9,999999999,89,0.1010,0,88,999.000,999.0,99.0
+1981,12,13,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-2.8,70,99800,494,1412,293,162,2,161,17900,200,17900,5520,230,1.5,10,10,19.3,1400,9,999999999,89,0.1010,0,88,999.000,999.0,99.0
+1981,12,13,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,2.2,-3.3,67,99800,356,1412,293,99,0,99,11000,0,11000,3390,180,1.5,10,10,19.3,1160,9,999999999,89,0.1010,0,88,999.000,999.0,99.0
+1981,12,13,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.7,-3.3,70,99800,170,1412,290,48,1,48,5300,0,5300,1500,0,0.0,10,10,24.1,2740,9,999999999,89,0.1010,0,88,999.000,999.0,99.0
+1981,12,13,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-3.3,79,99800,10,435,283,4,0,4,0,0,0,0,0,0.0,10,10,19.3,2740,9,999999999,89,0.1010,0,88,999.000,999.0,99.0
+1981,12,13,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-3.3,82,99800,0,0,281,0,0,0,0,0,0,0,0,0.0,10,10,19.3,2740,9,999999999,89,0.1010,0,88,999.000,999.0,99.0
+1981,12,13,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-3.9,78,99800,0,0,280,0,0,0,0,0,0,0,0,0.0,10,10,19.3,2740,9,999999999,89,0.1010,0,88,999.000,999.0,99.0
+1981,12,13,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-3.9,78,99800,0,0,280,0,0,0,0,0,0,0,180,1.5,10,10,19.3,2740,9,999999999,89,0.1010,0,88,999.000,999.0,99.0
+1981,12,13,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-3.9,75,99700,0,0,283,0,0,0,0,0,0,0,180,2.1,10,10,24.1,3050,9,999999999,89,0.1010,0,88,999.000,999.0,99.0
+1981,12,13,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-3.3,79,99700,0,0,283,0,0,0,0,0,0,0,190,1.5,10,10,19.3,3050,9,999999999,89,0.1010,0,88,999.000,999.0,99.0
+1981,12,13,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-4.4,78,99700,0,0,278,0,0,0,0,0,0,0,170,1.5,10,10,19.3,1830,9,999999999,80,0.1010,0,88,999.000,999.0,99.0
+1981,12,13,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-4.4,82,99600,0,0,268,0,0,0,0,0,0,0,0,0.0,9,9,24.1,2130,9,999999999,80,0.1010,0,88,999.000,999.0,99.0
+1981,12,14,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-4.4,78,99600,0,0,278,0,0,0,0,0,0,0,200,1.5,10,10,19.3,1160,9,999999999,80,0.1010,0,88,999.000,999.0,99.0
+1981,12,14,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-3.9,82,99600,0,0,278,0,0,0,0,0,0,0,170,1.5,10,10,16.1,760,9,999999999,89,0.1010,0,88,999.000,999.0,99.0
+1981,12,14,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-3.9,82,99600,0,0,278,0,0,0,0,0,0,0,0,0.0,10,10,19.3,1160,9,999999999,89,0.1010,0,88,999.000,999.0,99.0
+1981,12,14,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-3.9,85,99500,0,0,276,0,0,0,0,0,0,0,0,0.0,10,10,19.3,1160,9,999999999,89,0.1010,0,88,999.000,999.0,99.0
+1981,12,14,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-3.3,89,99400,0,0,276,0,0,0,0,0,0,0,0,0.0,10,10,16.1,1160,9,999999999,89,0.1010,0,88,999.000,999.0,99.0
+1981,12,14,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-2.8,92,99500,0,0,277,0,0,0,0,0,0,0,270,2.1,10,10,16.1,1160,9,999999999,89,0.1010,0,88,999.000,999.0,99.0
+1981,12,14,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-2.2,92,99500,0,0,280,0,0,0,0,0,0,0,270,2.1,10,10,8.0,980,9,999999999,89,0.1010,0,88,999.000,999.0,99.0
+1981,12,14,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-2.8,89,99400,62,1094,279,23,0,23,2500,0,2500,730,270,2.1,10,10,8.0,980,9,999999999,89,0.0530,0,88,999.000,999.0,99.0
+1981,12,14,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-2.2,92,99400,259,1412,280,86,1,86,9400,0,9400,2600,270,1.5,10,10,8.0,1400,9,999999999,89,0.0530,0,88,999.000,999.0,99.0
+1981,12,14,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-2.2,85,99400,425,1412,284,157,1,157,17200,100,17100,4880,250,2.6,10,10,8.0,1400,9,999999999,89,0.0530,0,88,999.000,999.0,99.0
+1981,12,14,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-2.2,85,99400,537,1412,284,179,1,179,19900,100,19900,6200,260,3.1,10,10,6.4,980,9,999999999,89,0.0530,0,88,999.000,999.0,99.0
+1981,12,14,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-1.7,89,99300,587,1412,285,207,2,207,23000,200,23000,7160,260,3.1,10,10,8.0,1400,9,999999999,100,0.0530,0,88,999.000,999.0,99.0
+1981,12,14,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-1.7,85,99200,572,1412,287,196,2,196,21800,200,21800,6830,260,4.1,10,10,8.0,460,9,999999999,100,0.0530,0,88,999.000,999.0,99.0
+1981,12,14,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-2.2,82,99200,494,1412,279,224,168,164,24000,15900,18400,3750,290,3.6,9,9,9.7,460,9,999999999,89,0.0530,0,88,999.000,999.0,99.0
+1981,12,14,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-2.8,79,99200,356,1412,286,118,88,95,12800,7600,10900,2080,280,3.6,10,10,12.9,460,9,999999999,89,0.0530,0,88,999.000,999.0,99.0
+1981,12,14,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-2.8,82,99200,170,1412,276,38,27,35,4200,1900,4000,870,290,3.6,9,9,11.3,760,9,999999999,89,0.0530,0,88,999.000,999.0,99.0
+1981,12,14,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-3.3,82,99200,10,459,263,4,7,4,0,0,0,0,270,3.1,7,7,12.9,760,9,999999999,89,0.0530,0,88,999.000,999.0,99.0
+1981,12,14,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-5.6,85,99300,0,0,240,0,0,0,0,0,0,0,260,2.6,2,2,16.1,77777,9,999999999,80,0.0530,0,88,999.000,999.0,99.0
+1981,12,14,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-5.6,88,99300,0,0,230,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,80,0.0530,0,88,999.000,999.0,99.0
+1981,12,14,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-8.3,88,99300,0,0,218,0,0,0,0,0,0,0,270,2.6,0,0,24.1,77777,9,999999999,69,0.0530,0,88,999.000,999.0,99.0
+1981,12,14,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-10.0,88,99300,0,0,212,0,0,0,0,0,0,0,270,3.1,0,0,24.1,77777,9,999999999,60,0.0530,0,88,999.000,999.0,99.0
+1981,12,14,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-10.6,88,99300,0,0,209,0,0,0,0,0,0,0,280,3.1,0,0,24.1,77777,9,999999999,60,0.0530,0,88,999.000,999.0,99.0
+1981,12,14,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-10.0,88,99400,0,0,212,0,0,0,0,0,0,0,300,3.6,0,0,24.1,77777,9,999999999,60,0.0530,0,88,999.000,999.0,99.0
+1981,12,14,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-12.2,74,99400,0,0,210,0,0,0,0,0,0,0,320,5.2,0,0,24.1,77777,9,999999999,50,0.0530,0,88,999.000,999.0,99.0
+1981,12,15,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-9.4,-12.8,77,99400,0,0,206,0,0,0,0,0,0,0,310,2.1,1,0,24.1,77777,9,999999999,50,0.0530,0,88,999.000,999.0,99.0
+1981,12,15,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-9.4,-13.3,74,99400,0,0,205,0,0,0,0,0,0,0,310,4.1,1,0,24.1,77777,9,999999999,50,0.0530,0,88,999.000,999.0,99.0
+1981,12,15,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-9.4,-13.3,74,99400,0,0,205,0,0,0,0,0,0,0,330,3.6,0,0,24.1,77777,9,999999999,50,0.0530,0,88,999.000,999.0,99.0
+1981,12,15,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.6,-13.3,80,99300,0,0,202,0,0,0,0,0,0,0,310,3.1,0,0,24.1,77777,9,999999999,50,0.0530,0,88,999.000,999.0,99.0
+1981,12,15,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.6,-13.9,77,99300,0,0,208,0,0,0,0,0,0,0,320,3.6,6,2,24.1,77777,9,999999999,50,0.0530,0,88,999.000,999.0,99.0
+1981,12,15,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.0,-13.3,77,99300,0,0,208,0,0,0,0,0,0,0,310,3.6,10,1,24.1,77777,9,999999999,50,0.0530,0,88,999.000,999.0,99.0
+1981,12,15,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.0,-13.3,77,99400,0,0,212,0,0,0,0,0,0,0,300,3.1,8,3,19.3,77777,9,999999999,50,0.0530,0,88,999.000,999.0,99.0
+1981,12,15,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.0,-13.3,77,99400,60,1071,224,16,9,15,1700,500,1700,370,310,4.1,9,8,24.1,6100,9,999999999,50,0.0880,0,88,999.000,999.0,99.0
+1981,12,15,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.0,-13.3,77,99400,257,1412,212,116,282,63,11900,20200,8200,1150,310,5.2,8,3,24.1,77777,9,999999999,50,0.0880,0,88,999.000,999.0,99.0
+1981,12,15,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.9,-13.3,71,99400,423,1412,216,214,353,106,22000,31200,12700,2000,300,3.6,8,3,24.1,77777,9,999999999,50,0.0880,0,88,999.000,999.0,99.0
+1981,12,15,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-13.3,65,99400,535,1412,220,284,411,125,29600,38900,14800,2420,300,4.1,8,3,24.1,77777,9,999999999,50,0.0880,0,88,999.000,999.0,99.0
+1981,12,15,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.2,-12.8,65,99300,586,1412,222,361,548,130,38000,53100,15800,2550,310,3.1,8,3,24.1,77777,9,999999999,50,0.0880,0,88,999.000,999.0,99.0
+1981,12,15,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.7,-12.8,62,99200,572,1412,224,336,539,115,34400,50800,13700,2200,310,3.1,8,3,24.1,77777,9,999999999,50,0.0880,0,88,999.000,999.0,99.0
+1981,12,15,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.1,-12.8,60,99100,493,1412,226,267,457,106,28200,42400,13300,2000,340,3.1,7,3,24.1,77777,9,999999999,50,0.0880,0,88,999.000,999.0,99.0
+1981,12,15,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.6,-12.8,57,99200,356,1412,229,187,386,89,19400,32000,11200,1650,290,3.1,5,4,24.1,77777,9,999999999,50,0.0880,0,88,999.000,999.0,99.0
+1981,12,15,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.1,-12.8,60,99200,171,1412,224,72,280,38,7500,16200,5600,680,310,2.1,2,2,24.1,77777,9,999999999,50,0.0880,0,88,999.000,999.0,99.0
+1981,12,15,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-12.8,68,99300,11,459,211,7,20,5,0,0,0,0,290,2.1,0,0,24.1,77777,9,999999999,50,0.0880,0,88,999.000,999.0,99.0
+1981,12,15,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-13.3,68,99300,0,0,209,0,0,0,0,0,0,0,290,2.6,0,0,24.1,77777,9,999999999,50,0.0880,0,88,999.000,999.0,99.0
+1981,12,15,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-12.8,68,99300,0,0,222,0,0,0,0,0,0,0,300,4.1,4,4,24.1,77777,9,999999999,50,0.0880,0,88,999.000,999.0,99.0
+1981,12,15,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-13.3,65,99300,0,0,236,0,0,0,0,0,0,0,300,3.1,10,9,24.1,2130,9,999999999,50,0.0880,0,88,999.000,999.0,99.0
+1981,12,15,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-13.3,65,99300,0,0,236,0,0,0,0,0,0,0,310,3.6,10,9,14.5,2130,9,999999999,50,0.0880,0,88,999.000,999.0,99.0
+1981,12,15,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-13.3,65,99300,0,0,236,0,0,0,0,0,0,0,310,3.1,10,9,14.5,2130,9,999999999,50,0.0880,0,88,999.000,999.0,99.0
+1981,12,15,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-13.3,65,99300,0,0,243,0,0,0,0,0,0,0,300,3.1,10,10,16.1,2130,9,999999999,50,0.0880,0,88,999.000,999.0,99.0
+1981,12,15,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-13.3,65,99300,0,0,243,0,0,0,0,0,0,0,280,3.1,10,10,24.1,1520,9,999999999,50,0.0880,0,88,999.000,999.0,99.0
+1981,12,16,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-13.3,65,99400,0,0,236,0,0,0,0,0,0,0,280,3.6,9,9,24.1,1520,9,999999999,50,0.0880,0,88,999.000,999.0,99.0
+1981,12,16,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-13.3,68,99400,0,0,241,0,0,0,0,0,0,0,290,3.1,10,10,24.1,1830,9,999999999,50,0.0880,0,88,999.000,999.0,99.0
+1981,12,16,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.0,-14.4,70,99500,0,0,207,0,0,0,0,0,0,0,290,3.1,1,1,24.1,77777,9,999999999,50,0.0880,0,88,999.000,999.0,99.0
+1981,12,16,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.1,-14.4,77,99500,0,0,199,0,0,0,0,0,0,0,300,2.6,0,0,24.1,77777,9,999999999,50,0.0880,0,88,999.000,999.0,99.0
+1981,12,16,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.7,-15.0,77,99500,0,0,197,0,0,0,0,0,0,0,280,3.6,0,0,24.1,77777,9,999999999,50,0.0880,0,88,999.000,999.0,99.0
+1981,12,16,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.2,-15.6,76,99600,0,0,195,0,0,0,0,0,0,0,280,2.1,0,0,24.1,77777,9,999999999,50,0.0880,0,88,999.000,999.0,99.0
+1981,12,16,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.8,-15.6,80,99600,0,0,193,0,0,0,0,0,0,0,280,3.1,0,0,19.3,77777,9,999999999,50,0.0880,0,88,999.000,999.0,99.0
+1981,12,16,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-12.8,-15.6,80,99700,58,1048,193,31,178,16,2700,7900,2300,290,280,3.6,1,0,24.1,77777,9,999999999,50,0.0560,0,88,999.000,999.0,99.0
+1981,12,16,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-11.1,-15.6,70,99700,254,1412,202,138,561,33,13800,43200,6000,660,260,4.1,1,1,24.1,77777,9,999999999,50,0.0560,0,88,999.000,999.0,99.0
+1981,12,16,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.9,-15.0,62,99800,421,1412,210,269,716,51,27600,64000,8400,1040,270,3.6,3,1,24.1,77777,9,999999999,50,0.0560,0,88,999.000,999.0,99.0
+1981,12,16,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-13.9,62,99800,534,1412,221,349,632,106,35600,58700,13300,2000,290,3.1,6,4,24.1,7010,9,999999999,50,0.0560,0,88,999.000,999.0,99.0
+1981,12,16,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.2,-13.9,59,99700,585,1412,233,185,95,145,20300,9500,16400,3420,290,4.6,9,8,24.1,3960,9,999999999,50,0.0560,0,88,999.000,999.0,99.0
+1981,12,16,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.7,-13.9,57,99700,571,1412,246,257,128,205,27600,12600,22500,4820,270,5.7,10,10,24.1,3960,9,999999999,50,0.0560,0,88,999.000,999.0,99.0
+1981,12,16,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.7,-13.9,57,99700,493,1412,246,123,6,121,14000,400,13800,4600,280,3.6,10,10,24.1,3660,9,999999999,50,0.0560,0,88,999.000,999.0,99.0
+1981,12,16,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.7,-15.0,52,99700,357,1412,245,105,13,102,11700,700,11500,3450,250,3.1,10,10,24.1,3660,9,999999999,50,0.0560,0,88,999.000,999.0,99.0
+1981,12,16,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.7,-15.0,52,99700,172,1412,245,33,4,32,3700,0,3700,1140,280,2.6,10,10,24.1,1830,9,999999999,50,0.0560,0,88,999.000,999.0,99.0
+1981,12,16,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-15.0,57,99700,11,459,235,2,3,1,0,0,0,0,0,0.0,10,9,24.1,2440,9,999999999,50,0.0560,0,88,999.000,999.0,99.0
+1981,12,16,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-14.4,64,99700,0,0,238,0,0,0,0,0,0,0,310,2.1,10,10,24.1,2440,9,999999999,50,0.0560,0,88,999.000,999.0,99.0
+1981,12,16,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-15.0,59,99600,0,0,239,0,0,0,0,0,0,0,350,3.1,10,10,24.1,1830,9,999999999,50,0.0560,0,88,999.000,999.0,99.0
+1981,12,16,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-13.9,57,99700,0,0,246,0,0,0,0,0,0,0,350,3.1,10,10,24.1,1400,9,999999999,50,0.0560,0,88,999.000,999.0,99.0
+1981,12,16,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-15.0,48,99700,0,0,249,0,0,0,0,0,0,0,10,3.1,10,10,24.1,1160,9,999999999,50,0.0560,0,88,999.000,999.0,99.0
+1981,12,16,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-13.9,55,99700,0,0,249,0,0,0,0,0,0,0,290,2.1,10,10,14.5,340,9,999999999,50,0.0560,0,88,999.000,999.0,99.0
+1981,12,16,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-13.3,62,99700,0,0,245,0,0,0,0,0,0,0,320,1.5,10,10,6.4,270,9,999999999,50,0.0560,0,88,999.000,999.0,99.0
+1981,12,16,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-12.2,71,99600,0,0,244,0,0,0,0,0,0,0,320,3.1,10,10,8.0,310,9,999999999,50,0.0560,0,88,999.000,999.0,99.0
+1981,12,17,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-12.2,71,99500,0,0,244,0,0,0,0,0,0,0,330,4.1,10,10,8.0,460,9,999999999,50,0.0560,0,88,999.000,999.0,99.0
+1981,12,17,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-12.2,71,99500,0,0,244,0,0,0,0,0,0,0,330,4.1,10,10,8.0,460,9,999999999,50,0.0560,0,88,999.000,999.0,99.0
+1981,12,17,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-12.8,68,99500,0,0,243,0,0,0,0,0,0,0,320,4.1,10,10,16.1,610,9,999999999,50,0.0560,0,88,999.000,999.0,99.0
+1981,12,17,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-12.8,68,99400,0,0,243,0,0,0,0,0,0,0,330,5.7,10,10,8.0,1160,9,999999999,50,0.0560,0,88,999.000,999.0,99.0
+1981,12,17,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-12.8,68,99400,0,0,243,0,0,0,0,0,0,0,320,7.2,10,10,2.4,460,9,999999999,50,0.0560,0,88,999.000,999.0,99.0
+1981,12,17,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-12.8,68,99400,0,0,243,0,0,0,0,0,0,0,310,5.2,10,10,4.8,850,9,999999999,50,0.0560,0,88,999.000,999.0,99.0
+1981,12,17,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-12.2,71,99400,0,0,244,0,0,0,0,0,0,0,310,3.6,10,10,8.0,980,9,999999999,50,0.0560,0,88,999.000,999.0,99.0
+1981,12,17,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.2,-12.2,68,99400,56,1048,246,6,14,5,700,500,700,80,330,5.2,10,10,14.5,1160,9,999999999,50,0.0700,0,88,999.000,999.0,99.0
+1981,12,17,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.7,-12.2,65,99500,252,1413,248,46,3,45,5200,100,5200,1670,330,7.7,10,10,4.0,910,9,999999999,50,0.0700,0,88,999.000,999.0,99.0
+1981,12,17,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.7,-11.1,71,99500,419,1413,242,145,50,130,15900,4600,14500,3320,320,7.2,10,9,11.3,1400,9,999999999,60,0.0700,0,88,999.000,999.0,99.0
+1981,12,17,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.6,-10.6,68,99400,532,1413,254,120,12,116,13800,800,13500,4640,320,7.7,10,10,24.1,1400,9,999999999,60,0.0700,0,88,999.000,999.0,99.0
+1981,12,17,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.0,-8.9,74,99400,584,1413,258,129,10,125,14900,700,14600,5130,330,8.8,10,10,3.2,580,9,999999999,60,0.0700,0,88,999.000,999.0,99.0
+1981,12,17,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.6,-8.3,81,99400,571,1413,256,149,4,147,16900,300,16800,5700,340,10.3,10,10,1.6,460,9,999999999,69,0.0700,0,88,999.000,999.0,99.0
+1981,12,17,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.1,-8.9,81,99400,494,1413,253,118,1,117,13300,100,13300,4500,340,10.3,10,10,2.4,1400,9,999999999,60,0.0700,0,88,999.000,999.0,99.0
+1981,12,17,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.1,-10.0,74,99500,357,1413,252,88,4,87,9900,200,9800,3120,330,9.3,10,10,3.2,520,9,999999999,60,0.0700,0,88,999.000,999.0,99.0
+1981,12,17,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.2,-10.6,77,99600,173,1413,241,51,20,48,5500,1400,5300,1130,340,10.3,10,9,4.0,580,9,999999999,60,0.0700,0,88,999.000,999.0,99.0
+1981,12,17,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.2,-11.1,74,99700,11,483,247,6,3,6,0,0,0,0,340,8.8,10,10,8.0,760,9,999999999,60,0.0700,0,88,999.000,999.0,99.0
+1981,12,17,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-12.2,68,99800,0,0,246,0,0,0,0,0,0,0,330,7.2,10,10,9.7,670,9,999999999,50,0.0700,0,88,999.000,999.0,99.0
+1981,12,17,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-12.8,68,99800,0,0,243,0,0,0,0,0,0,0,330,7.2,10,10,11.3,760,9,999999999,50,0.0700,0,88,999.000,999.0,99.0
+1981,12,17,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-13.3,71,99900,0,0,239,0,0,0,0,0,0,0,320,9.3,10,10,14.5,850,9,999999999,50,0.0700,0,88,999.000,999.0,99.0
+1981,12,17,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-9.4,-13.9,70,99900,0,0,225,0,0,0,0,0,0,0,320,6.2,8,8,24.1,850,9,999999999,50,0.0700,0,88,999.000,999.0,99.0
+1981,12,17,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.1,-15.6,70,99900,0,0,215,0,0,0,0,0,0,0,310,6.2,7,7,24.1,850,9,999999999,50,0.0700,0,88,999.000,999.0,99.0
+1981,12,17,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-9.4,-15.0,64,100000,0,0,236,0,0,0,0,0,0,0,300,7.2,10,10,24.1,1160,9,999999999,50,0.0700,0,88,999.000,999.0,99.0
+1981,12,17,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.0,-15.0,67,100000,0,0,233,0,0,0,0,0,0,0,310,5.7,10,10,24.1,1400,9,999999999,50,0.0700,0,88,999.000,999.0,99.0
+1981,12,18,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.6,-15.6,67,100000,0,0,231,0,0,0,0,0,0,0,320,5.7,10,10,24.1,1160,9,999999999,50,0.0700,0,88,999.000,999.0,99.0
+1981,12,18,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.6,-15.6,67,100000,0,0,231,0,0,0,0,0,0,0,320,4.1,10,10,24.1,1400,9,999999999,50,0.0700,0,88,999.000,999.0,99.0
+1981,12,18,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.1,-16.1,67,100000,0,0,218,0,0,0,0,0,0,0,310,4.6,8,8,24.1,1830,9,999999999,50,0.0700,0,88,999.000,999.0,99.0
+1981,12,18,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.2,-16.1,73,100000,0,0,208,0,0,0,0,0,0,0,310,5.2,6,6,24.1,1830,9,999999999,50,0.0700,0,88,999.000,999.0,99.0
+1981,12,18,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.8,-16.7,73,100000,0,0,201,0,0,0,0,0,0,0,310,4.6,3,3,24.1,77777,9,999999999,40,0.0700,0,88,999.000,999.0,99.0
+1981,12,18,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-13.9,-16.7,80,100100,0,0,195,0,0,0,0,0,0,0,310,3.6,2,2,24.1,77777,9,999999999,40,0.0700,0,88,999.000,999.0,99.0
+1981,12,18,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-13.9,-16.7,80,100100,0,0,195,0,0,0,0,0,0,0,300,4.1,2,2,24.1,77777,9,999999999,40,0.0700,0,88,999.000,999.0,99.0
+1981,12,18,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-13.9,-16.7,80,100100,55,1024,193,23,79,17,2300,2900,2100,300,310,2.1,1,1,24.1,77777,9,999999999,40,0.1060,0,88,999.000,999.0,99.0
+1981,12,18,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-12.8,-16.7,73,100200,250,1413,192,132,453,49,13200,32800,7400,870,310,3.1,0,0,24.1,77777,9,999999999,40,0.1060,0,88,999.000,999.0,99.0
+1981,12,18,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-11.1,-15.6,70,100200,417,1413,198,253,611,68,25900,53800,9900,1280,320,3.6,0,0,24.1,77777,9,999999999,50,0.1060,0,88,999.000,999.0,99.0
+1981,12,18,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.3,-14.4,62,100100,531,1413,208,357,722,81,37100,67900,11400,1600,320,6.2,0,0,24.1,77777,9,999999999,50,0.1060,0,88,999.000,999.0,99.0
+1981,12,18,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.2,-13.3,62,100000,583,1413,212,405,759,87,42300,72900,12000,1760,310,5.7,0,0,24.1,77777,9,999999999,50,0.1060,0,88,999.000,999.0,99.0
+1981,12,18,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.1,-13.9,55,100000,571,1413,215,391,747,85,40800,71400,11800,1710,300,6.2,0,0,24.1,77777,9,999999999,50,0.1060,0,88,999.000,999.0,99.0
+1981,12,18,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.6,-13.9,52,100000,494,1413,217,324,700,77,33700,64700,11000,1500,310,5.2,0,0,24.1,77777,9,999999999,50,0.1060,0,88,999.000,999.0,99.0
+1981,12,18,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.6,-13.9,52,100000,358,1413,217,209,578,61,21500,48400,9200,1130,320,6.2,0,0,24.1,77777,9,999999999,50,0.1060,0,88,999.000,999.0,99.0
+1981,12,18,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.7,-15.0,52,100100,174,1413,213,76,298,39,7600,18200,5400,670,280,5.2,1,0,24.1,77777,9,999999999,50,0.1060,0,88,999.000,999.0,99.0
+1981,12,18,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.2,-15.0,54,100100,12,483,211,8,15,6,0,0,0,0,290,5.2,0,0,24.1,77777,9,999999999,50,0.1060,0,88,999.000,999.0,99.0
+1981,12,18,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-15.0,57,100200,0,0,209,0,0,0,0,0,0,0,310,6.2,0,0,24.1,77777,9,999999999,50,0.1060,0,88,999.000,999.0,99.0
+1981,12,18,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-15.0,62,100200,0,0,206,0,0,0,0,0,0,0,290,4.1,0,0,24.1,77777,9,999999999,50,0.1060,0,88,999.000,999.0,99.0
+1981,12,18,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-15.6,59,100200,0,0,205,0,0,0,0,0,0,0,280,3.6,0,0,24.1,77777,9,999999999,50,0.1060,0,88,999.000,999.0,99.0
+1981,12,18,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-10.0,-15.6,64,100200,0,0,202,0,0,0,0,0,0,0,280,4.6,0,0,24.1,77777,9,999999999,50,0.1060,0,88,999.000,999.0,99.0
+1981,12,18,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.2,-16.1,73,100200,0,0,195,0,0,0,0,0,0,0,270,4.1,0,0,24.1,77777,9,999999999,50,0.1060,0,88,999.000,999.0,99.0
+1981,12,18,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.2,-16.1,73,100200,0,0,195,0,0,0,0,0,0,0,300,4.1,0,0,24.1,77777,9,999999999,50,0.1060,0,88,999.000,999.0,99.0
+1981,12,18,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.8,-16.1,76,100200,0,0,193,0,0,0,0,0,0,0,290,4.1,0,0,24.1,77777,9,999999999,40,0.1060,0,88,999.000,999.0,99.0
+1981,12,19,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-13.3,-16.7,76,100200,0,0,191,0,0,0,0,0,0,0,300,4.6,0,0,24.1,77777,9,999999999,40,0.1060,0,88,999.000,999.0,99.0
+1981,12,19,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-14.4,-16.7,83,100200,0,0,188,0,0,0,0,0,0,0,280,3.6,0,0,24.1,77777,9,999999999,40,0.1060,0,88,999.000,999.0,99.0
+1981,12,19,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-15.0,-16.7,87,100200,0,0,186,0,0,0,0,0,0,0,290,4.1,0,0,24.1,77777,9,999999999,40,0.1060,0,88,999.000,999.0,99.0
+1981,12,19,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-15.6,-17.2,87,100200,0,0,184,0,0,0,0,0,0,0,280,4.1,0,0,24.1,77777,9,999999999,40,0.1060,0,88,999.000,999.0,99.0
+1981,12,19,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-15.6,-17.2,87,100200,0,0,184,0,0,0,0,0,0,0,280,4.1,0,0,24.1,77777,9,999999999,40,0.1060,0,88,999.000,999.0,99.0
+1981,12,19,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-16.1,-17.8,87,100300,0,0,182,0,0,0,0,0,0,0,280,3.1,0,0,24.1,77777,9,999999999,40,0.1060,0,88,999.000,999.0,99.0
+1981,12,19,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-16.1,-17.8,87,100300,0,0,182,0,0,0,0,0,0,0,300,4.6,0,0,24.1,77777,9,999999999,40,0.1060,0,88,999.000,999.0,99.0
+1981,12,19,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-16.1,-17.8,87,100300,53,1001,182,32,198,15,2700,8700,2200,270,290,5.2,0,0,24.1,77777,9,999999999,40,0.0490,0,88,999.000,999.0,99.0
+1981,12,19,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-15.0,-17.8,80,100400,248,1413,185,144,614,32,14400,46900,6200,640,280,3.6,0,0,24.1,77777,9,999999999,40,0.0490,0,88,999.000,999.0,99.0
+1981,12,19,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-12.8,-17.2,70,100400,416,1413,192,278,781,43,28900,70000,8200,980,290,4.6,0,0,24.1,77777,9,999999999,40,0.0490,0,88,999.000,999.0,99.0
+1981,12,19,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.0,-18.3,51,100300,530,1413,200,376,853,51,39200,80000,9000,1180,280,4.1,0,0,24.1,77777,9,999999999,40,0.0490,0,88,999.000,999.0,99.0
+1981,12,19,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.9,-15.6,59,100300,583,1413,205,419,872,54,43700,83000,9300,1270,270,5.2,0,0,24.1,77777,9,999999999,50,0.0490,0,88,999.000,999.0,99.0
+1981,12,19,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-14.4,59,100200,571,1413,219,363,625,107,37300,59100,13300,2070,280,6.2,3,3,24.1,77777,9,999999999,50,0.0490,0,88,999.000,999.0,99.0
+1981,12,19,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-14.4,59,100200,494,1413,219,327,698,80,33900,64400,11300,1540,300,4.6,3,3,24.1,77777,9,999999999,50,0.0490,0,88,999.000,999.0,99.0
+1981,12,19,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-14.4,59,100200,359,1413,214,211,636,48,21600,54300,7700,940,290,4.1,1,1,24.1,77777,9,999999999,50,0.0490,0,88,999.000,999.0,99.0
+1981,12,19,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-15.6,54,100200,175,1413,209,87,483,26,8700,32500,4700,500,290,5.2,0,0,24.1,77777,9,999999999,50,0.0490,0,88,999.000,999.0,99.0
+1981,12,19,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.6,-16.7,61,100200,12,483,199,12,60,6,0,0,0,0,280,2.1,0,0,24.1,77777,9,999999999,40,0.0490,0,88,999.000,999.0,99.0
+1981,12,19,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.7,-16.1,70,100200,0,0,196,0,0,0,0,0,0,0,260,1.5,0,0,24.1,77777,9,999999999,50,0.0490,0,88,999.000,999.0,99.0
+1981,12,19,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.8,-16.1,76,100200,0,0,193,0,0,0,0,0,0,0,240,1.5,0,0,24.1,77777,9,999999999,40,0.0490,0,88,999.000,999.0,99.0
+1981,12,19,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-14.4,-17.2,80,100200,0,0,187,0,0,0,0,0,0,0,270,2.1,0,0,24.1,77777,9,999999999,40,0.0490,0,88,999.000,999.0,99.0
+1981,12,19,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-15.0,-17.2,83,100200,0,0,186,0,0,0,0,0,0,0,260,3.6,0,0,24.1,77777,9,999999999,40,0.0490,0,88,999.000,999.0,99.0
+1981,12,19,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-15.6,-18.3,79,100200,0,0,183,0,0,0,0,0,0,0,270,2.1,0,0,24.1,77777,9,999999999,40,0.0490,0,88,999.000,999.0,99.0
+1981,12,19,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-16.1,-18.3,83,100200,0,0,182,0,0,0,0,0,0,0,0,0.0,0,0,24.1,77777,9,999999999,40,0.0490,0,88,999.000,999.0,99.0
+1981,12,19,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-16.7,-18.9,83,100200,0,0,180,0,0,0,0,0,0,0,260,2.6,0,0,24.1,77777,9,999999999,40,0.0490,0,88,999.000,999.0,99.0
+1981,12,20,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-16.7,-18.9,83,100200,0,0,180,0,0,0,0,0,0,0,260,3.1,0,0,24.1,77777,9,999999999,40,0.0490,0,88,999.000,999.0,99.0
+1981,12,20,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.2,-19.4,83,100200,0,0,178,0,0,0,0,0,0,0,240,2.1,0,0,24.1,77777,9,999999999,40,0.0490,0,88,999.000,999.0,99.0
+1981,12,20,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.8,-20.6,79,100200,0,0,175,0,0,0,0,0,0,0,230,2.1,0,0,24.1,77777,9,999999999,40,0.0490,0,88,999.000,999.0,99.0
+1981,12,20,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.2,-20.6,76,100200,0,0,177,0,0,0,0,0,0,0,250,3.1,0,0,24.1,77777,9,999999999,40,0.0490,0,88,999.000,999.0,99.0
+1981,12,20,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.8,-21.1,75,100100,0,0,175,0,0,0,0,0,0,0,250,1.5,0,0,24.1,77777,9,999999999,40,0.0490,0,88,999.000,999.0,99.0
+1981,12,20,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.8,-21.1,75,100100,0,0,175,0,0,0,0,0,0,0,210,2.1,0,0,24.1,77777,9,999999999,40,0.0490,0,88,999.000,999.0,99.0
+1981,12,20,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-18.3,-21.1,79,100100,0,0,174,0,0,0,0,0,0,0,200,2.1,0,0,24.1,77777,9,999999999,40,0.0490,0,88,999.000,999.0,99.0
+1981,12,20,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-17.8,-20.6,79,100000,52,1001,175,29,162,15,2500,7000,2100,270,220,3.1,1,0,14.5,77777,9,999999999,40,0.0580,0,88,999.000,999.0,99.0
+1981,12,20,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-16.7,-18.9,83,100000,246,1413,185,113,325,54,11600,22900,7600,970,220,5.2,3,2,14.5,77777,9,999999999,40,0.0580,0,88,999.000,999.0,99.0
+1981,12,20,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-13.3,-17.8,70,100000,414,1413,196,230,538,69,23600,47300,9700,1300,190,5.2,5,2,14.5,77777,9,999999999,40,0.0580,0,88,999.000,999.0,99.0
+1981,12,20,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.6,-17.8,56,100000,529,1413,205,353,690,90,36300,64500,12100,1740,190,4.6,8,2,19.3,77777,9,999999999,40,0.0580,0,88,999.000,999.0,99.0
+1981,12,20,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.0,-18.3,51,99800,583,1413,208,375,640,107,38500,60800,13300,2090,320,6.2,7,3,24.1,77777,9,999999999,40,0.0580,0,88,999.000,999.0,99.0
+1981,12,20,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-9.4,-18.3,49,99700,571,1413,210,342,530,125,36000,51000,15300,2440,210,8.2,9,3,24.1,77777,9,999999999,40,0.0580,0,88,999.000,999.0,99.0
+1981,12,20,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-9.4,-18.3,49,99600,495,1413,208,321,673,83,33200,62000,11400,1590,200,7.7,8,2,24.1,77777,9,999999999,40,0.0580,0,88,999.000,999.0,99.0
+1981,12,20,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.9,-18.3,47,99500,360,1413,212,193,404,89,20000,33600,11300,1650,180,6.7,9,3,24.1,77777,9,999999999,40,0.0580,0,88,999.000,999.0,99.0
+1981,12,20,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-10.0,-18.9,49,99500,177,1413,208,74,199,49,7600,11700,6100,900,180,7.2,9,3,24.1,77777,9,999999999,40,0.0580,0,88,999.000,999.0,99.0
+1981,12,20,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-11.7,-18.9,55,99300,13,506,200,10,21,8,0,0,0,0,180,7.2,8,2,24.1,77777,9,999999999,40,0.0580,0,88,999.000,999.0,99.0
+1981,12,20,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.2,-18.9,58,99300,0,0,202,0,0,0,0,0,0,0,180,7.2,10,4,24.1,77777,9,999999999,40,0.0580,0,88,999.000,999.0,99.0
+1981,12,20,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.8,-18.9,61,99200,0,0,199,0,0,0,0,0,0,0,170,9.8,10,3,24.1,77777,9,999999999,40,0.0580,0,88,999.000,999.0,99.0
+1981,12,20,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-11.7,-18.3,58,99100,0,0,203,0,0,0,0,0,0,0,170,10.3,10,3,24.1,77777,9,999999999,40,0.0580,0,88,999.000,999.0,99.0
+1981,12,20,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-9.4,-15.6,61,98900,0,0,235,0,0,0,0,0,0,0,180,12.9,10,10,24.1,1400,9,999999999,50,0.0580,0,88,999.000,999.0,99.0
+1981,12,20,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-10.6,74,98800,0,0,250,0,0,0,0,0,0,0,190,10.3,10,10,19.3,700,9,999999999,60,0.0580,0,88,999.000,999.0,99.0
+1981,12,20,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-11.1,65,98700,0,0,253,0,0,0,0,0,0,0,210,10.3,10,10,9.7,700,9,999999999,60,0.0580,0,88,999.000,999.0,99.0
+1981,12,20,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-8.3,81,98600,0,0,256,0,0,0,0,0,0,0,290,10.3,10,10,3.2,460,9,999999999,69,0.0580,0,88,999.000,999.0,99.0
+1981,12,21,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-7.8,85,98400,0,0,256,0,0,0,0,0,0,0,180,9.3,10,10,0.4,240,9,999999999,69,0.0580,0,88,999.000,999.0,99.0
+1981,12,21,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-6.7,88,98300,0,0,260,0,0,0,0,0,0,0,170,9.3,10,10,4.0,370,9,999999999,69,0.0580,0,88,999.000,999.0,99.0
+1981,12,21,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-6.7,85,98300,0,0,262,0,0,0,0,0,0,0,190,9.3,10,10,1.3,240,9,999999999,69,0.0580,0,88,999.000,999.0,99.0
+1981,12,21,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-6.1,88,98300,0,0,263,0,0,0,0,0,0,0,180,7.2,10,10,9.7,240,9,999999999,69,0.0580,0,88,999.000,999.0,99.0
+1981,12,21,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-5.6,88,98200,0,0,265,0,0,0,0,0,0,0,190,6.7,10,10,4.8,240,9,999999999,80,0.0580,0,88,999.000,999.0,99.0
+1981,12,21,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-5.0,85,98100,0,0,270,0,0,0,0,0,0,0,200,6.7,10,10,11.3,310,9,999999999,80,0.0580,0,88,999.000,999.0,99.0
+1981,12,21,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-4.4,85,98100,0,0,273,0,0,0,0,0,0,0,200,7.7,10,10,8.0,370,9,999999999,80,0.0580,0,88,999.000,999.0,99.0
+1981,12,21,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-3.9,82,98200,50,978,278,11,1,11,1300,0,1300,400,200,7.2,10,10,11.3,370,9,999999999,80,0.1130,0,88,999.000,999.0,99.0
+1981,12,21,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-3.3,85,98100,245,1414,279,58,5,57,6500,100,6500,1960,210,7.7,10,10,11.3,370,9,999999999,89,0.1130,0,88,999.000,999.0,99.0
+1981,12,21,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-3.3,82,98200,413,1414,281,117,5,116,13100,300,13000,4060,210,7.7,10,10,11.3,240,9,999999999,89,0.1130,0,88,999.000,999.0,99.0
+1981,12,21,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-2.2,89,98100,528,1414,282,203,8,200,22300,700,22000,6470,220,6.2,10,10,6.4,210,9,999999999,89,0.1130,0,88,999.000,999.0,99.0
+1981,12,21,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-2.2,85,98100,582,1414,284,146,2,145,16600,100,16500,5700,200,6.2,10,10,11.3,240,9,999999999,89,0.1130,0,88,999.000,999.0,99.0
+1981,12,21,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-2.2,85,98000,571,1414,284,173,7,170,19400,500,19200,6270,230,7.7,10,10,11.3,240,9,999999999,89,0.1130,0,88,999.000,999.0,99.0
+1981,12,21,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-1.7,89,97900,496,1414,285,146,3,145,16300,200,16200,5200,220,7.7,10,10,6.4,240,9,999999999,100,0.1130,0,88,999.000,999.0,99.0
+1981,12,21,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-1.7,89,97900,362,1414,285,97,3,97,10900,200,10900,3370,210,4.6,10,10,4.0,180,9,999999999,100,0.1130,0,88,999.000,999.0,99.0
+1981,12,21,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-1.1,89,97900,178,1414,288,45,1,45,5000,0,5000,1470,210,6.2,10,10,2.4,180,9,999999999,100,0.1130,0,88,999.000,999.0,99.0
+1981,12,21,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-1.1,89,98000,13,507,288,6,0,6,0,0,0,0,230,6.2,10,10,2.4,180,9,999999999,100,0.1130,0,88,999.000,999.0,99.0
+1981,12,21,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-1.1,89,97900,0,0,288,0,0,0,0,0,0,0,220,5.2,10,10,6.4,180,9,999999999,100,0.1130,0,88,999.000,999.0,99.0
+1981,12,21,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-0.6,92,97900,0,0,289,0,0,0,0,0,0,0,230,4.1,10,10,3.2,120,9,999999999,100,0.1130,0,88,999.000,999.0,99.0
+1981,12,21,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-0.6,92,97900,0,0,289,0,0,0,0,0,0,0,230,5.2,10,10,3.2,210,9,999999999,100,0.1130,0,88,999.000,999.0,99.0
+1981,12,21,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-0.6,92,97900,0,0,289,0,0,0,0,0,0,0,230,5.7,10,10,4.8,210,9,999999999,100,0.1130,0,88,999.000,999.0,99.0
+1981,12,21,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-0.6,92,98000,0,0,289,0,0,0,0,0,0,0,230,4.1,10,10,6.4,180,9,999999999,100,0.1130,0,88,999.000,999.0,99.0
+1981,12,21,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-1.7,89,98000,0,0,285,0,0,0,0,0,0,0,250,7.2,10,10,11.3,180,9,999999999,100,0.1130,0,88,999.000,999.0,99.0
+1981,12,21,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-1.7,89,98000,0,0,285,0,0,0,0,0,0,0,220,3.1,10,10,11.3,240,9,999999999,100,0.1130,0,88,999.000,999.0,99.0
+1981,12,22,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-1.7,89,98000,0,0,285,0,0,0,0,0,0,0,230,5.2,10,10,11.3,210,9,999999999,100,0.1130,0,88,999.000,999.0,99.0
+1981,12,22,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-1.7,89,98000,0,0,285,0,0,0,0,0,0,0,270,4.1,10,10,11.3,150,9,999999999,100,0.1130,0,88,999.000,999.0,99.0
+1981,12,22,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-1.7,89,98100,0,0,285,0,0,0,0,0,0,0,250,4.1,10,10,11.3,120,9,999999999,100,0.1130,0,88,999.000,999.0,99.0
+1981,12,22,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-1.7,89,98100,0,0,285,0,0,0,0,0,0,0,260,3.6,10,10,6.4,120,9,999999999,100,0.1130,0,88,999.000,999.0,99.0
+1981,12,22,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-1.7,89,98100,0,0,285,0,0,0,0,0,0,0,270,4.1,10,10,9.7,120,9,999999999,100,0.1130,0,88,999.000,999.0,99.0
+1981,12,22,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-1.7,89,98100,0,0,285,0,0,0,0,0,0,0,260,3.6,10,10,11.3,150,9,999999999,100,0.1130,0,88,999.000,999.0,99.0
+1981,12,22,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-2.2,85,98200,0,0,284,0,0,0,0,0,0,0,260,2.1,10,10,11.3,180,9,999999999,89,0.1130,0,88,999.000,999.0,99.0
+1981,12,22,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-2.2,85,98200,49,978,284,22,0,22,2400,0,2400,690,250,1.5,10,10,11.3,180,9,999999999,89,0.1340,0,88,999.000,999.0,99.0
+1981,12,22,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-2.2,89,98300,243,1414,282,39,0,39,4500,0,4500,1470,0,0.0,10,10,6.4,180,9,999999999,89,0.1340,0,88,999.000,999.0,99.0
+1981,12,22,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-2.2,85,98300,412,1414,284,145,1,145,15900,100,15900,4590,230,1.5,10,10,8.0,210,9,999999999,89,0.1340,0,88,999.000,999.0,99.0
+1981,12,22,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-2.2,85,98400,528,1414,284,166,0,166,18500,0,18500,5870,250,3.1,10,10,6.4,240,9,999999999,89,0.1340,0,88,999.000,999.0,99.0
+1981,12,22,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-2.2,85,98300,582,1414,284,193,0,192,21400,0,21400,6820,260,2.1,10,10,8.0,310,9,999999999,89,0.1340,0,88,999.000,999.0,99.0
+1981,12,22,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-2.2,82,98100,572,1414,287,204,0,204,22500,0,22500,6960,300,4.1,10,10,11.3,340,9,999999999,89,0.1340,0,88,999.000,999.0,99.0
+1981,12,22,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-2.8,79,98200,497,1414,286,180,1,179,19700,100,19700,5850,320,3.1,10,10,8.0,370,9,999999999,89,0.1340,0,88,999.000,999.0,99.0
+1981,12,22,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-2.8,79,98100,363,1414,286,117,0,117,12900,0,12900,3770,20,3.6,10,10,8.0,370,9,999999999,89,0.1340,0,88,999.000,999.0,99.0
+1981,12,22,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-2.8,79,98100,180,1414,286,56,0,56,6100,0,6100,1680,30,1.5,10,10,8.0,460,9,999999999,89,0.1340,0,88,999.000,999.0,99.0
+1981,12,22,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-2.8,79,98100,14,530,286,8,0,8,0,0,0,0,30,2.1,10,10,8.0,370,9,999999999,89,0.1340,0,88,999.000,999.0,99.0
+1981,12,22,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-3.3,75,98100,0,0,286,0,0,0,0,0,0,0,20,3.1,10,10,8.0,430,9,999999999,89,0.1340,0,88,999.000,999.0,99.0
+1981,12,22,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-2.8,79,98000,0,0,286,0,0,0,0,0,0,0,350,3.1,10,10,11.3,460,9,999999999,89,0.1340,0,88,999.000,999.0,99.0
+1981,12,22,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-3.3,79,98100,0,0,283,0,0,0,0,0,0,0,330,3.6,10,10,11.3,460,9,999999999,89,0.1340,0,88,999.000,999.0,99.0
+1981,12,22,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-3.3,79,98000,0,0,283,0,0,0,0,0,0,0,330,5.7,10,10,9.7,460,9,999999999,89,0.1340,0,88,999.000,999.0,99.0
+1981,12,22,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-3.3,79,98000,0,0,283,0,0,0,0,0,0,0,320,4.6,10,10,9.7,610,9,999999999,89,0.1340,0,88,999.000,999.0,99.0
+1981,12,22,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-3.3,79,98100,0,0,283,0,0,0,0,0,0,0,300,3.6,10,10,9.7,760,9,999999999,89,0.1340,0,88,999.000,999.0,99.0
+1981,12,22,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-3.3,79,98200,0,0,283,0,0,0,0,0,0,0,280,2.6,10,10,9.7,1220,9,999999999,89,0.1340,0,88,999.000,999.0,99.0
+1981,12,23,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-0.6,-3.9,78,98200,0,0,263,0,0,0,0,0,0,0,300,4.6,7,7,12.9,3660,9,999999999,80,0.1340,0,88,999.000,999.0,99.0
+1981,12,23,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-5.6,72,98300,0,0,256,0,0,0,0,0,0,0,300,4.6,6,6,16.1,3660,9,999999999,80,0.1340,0,88,999.000,999.0,99.0
+1981,12,23,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-6.7,69,98400,0,0,253,0,0,0,0,0,0,0,300,4.1,6,6,19.3,3660,9,999999999,69,0.1340,0,88,999.000,999.0,99.0
+1981,12,23,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-7.8,69,98500,0,0,244,0,0,0,0,0,0,0,300,5.7,4,4,19.3,77777,9,999999999,69,0.1340,0,88,999.000,999.0,99.0
+1981,12,23,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-8.3,75,98500,0,0,236,0,0,0,0,0,0,0,280,5.2,3,3,19.3,77777,9,999999999,69,0.1340,0,88,999.000,999.0,99.0
+1981,12,23,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-9.4,81,98700,0,0,224,0,0,0,0,0,0,0,290,5.2,2,2,19.3,77777,9,999999999,60,0.1340,0,88,999.000,999.0,99.0
+1981,12,23,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-11.1,77,98800,0,0,219,0,0,0,0,0,0,0,280,4.1,6,2,19.3,77777,9,999999999,60,0.1340,0,88,999.000,999.0,99.0
+1981,12,23,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.3,-11.7,77,99000,48,954,219,29,163,15,2400,7000,2100,270,270,3.1,4,3,19.3,77777,9,999999999,60,0.0390,0,88,999.000,999.0,99.0
+1981,12,23,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-12.2,71,99100,242,1414,221,116,357,53,12000,24900,7700,950,290,4.6,4,3,19.3,77777,9,999999999,50,0.0390,0,88,999.000,999.0,99.0
+1981,12,23,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.7,-12.2,65,99200,411,1414,224,244,635,55,24700,56200,8300,1070,260,4.6,4,3,19.3,77777,9,999999999,50,0.0390,0,88,999.000,999.0,99.0
+1981,12,23,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.6,-12.2,60,99300,527,1414,223,344,771,52,35900,72300,8800,1180,280,5.7,1,1,24.1,77777,9,999999999,50,0.0390,0,88,999.000,999.0,99.0
+1981,12,23,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.0,-12.2,57,99300,582,1414,220,421,890,49,44000,84800,8900,1220,270,4.6,0,0,24.1,77777,9,999999999,50,0.0390,0,88,999.000,999.0,99.0
+1981,12,23,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.9,-11.1,58,99200,572,1414,225,405,872,48,42500,82900,8800,1200,240,6.7,0,0,24.1,77777,9,999999999,60,0.0390,0,88,999.000,999.0,99.0
+1981,12,23,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-10.6,55,99200,498,1414,229,343,841,44,36100,78100,8400,1080,230,4.1,0,0,24.1,77777,9,999999999,60,0.0390,0,88,999.000,999.0,99.0
+1981,12,23,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-10.0,56,99200,365,1414,232,230,750,35,24300,65300,7400,860,220,6.2,0,0,24.1,77777,9,999999999,60,0.0390,0,88,999.000,999.0,99.0
+1981,12,23,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-10.0,60,99300,182,1414,228,92,526,24,9700,37700,4800,510,230,5.2,0,0,24.1,77777,9,999999999,60,0.0390,0,88,999.000,999.0,99.0
+1981,12,23,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.0,-10.0,68,99300,15,530,222,15,83,6,0,0,0,0,220,4.6,0,0,24.1,77777,9,999999999,60,0.0390,0,88,999.000,999.0,99.0
+1981,12,23,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-10.0,71,99300,0,0,220,0,0,0,0,0,0,0,210,5.2,0,0,24.1,77777,9,999999999,60,0.0390,0,88,999.000,999.0,99.0
+1981,12,23,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-10.0,74,99400,0,0,219,0,0,0,0,0,0,0,230,5.7,0,0,24.1,77777,9,999999999,60,0.0390,0,88,999.000,999.0,99.0
+1981,12,23,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-10.0,74,99300,0,0,219,0,0,0,0,0,0,0,200,5.2,0,0,24.1,77777,9,999999999,60,0.0390,0,88,999.000,999.0,99.0
+1981,12,23,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-11.1,74,99400,0,0,214,0,0,0,0,0,0,0,220,7.2,0,0,24.1,77777,9,999999999,60,0.0390,0,88,999.000,999.0,99.0
+1981,12,23,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-11.1,74,99400,0,0,214,0,0,0,0,0,0,0,220,6.7,0,0,24.1,77777,9,999999999,60,0.0390,0,88,999.000,999.0,99.0
+1981,12,23,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-11.1,77,99400,0,0,212,0,0,0,0,0,0,0,230,7.2,0,0,24.1,77777,9,999999999,60,0.0390,0,88,999.000,999.0,99.0
+1981,12,23,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-11.7,71,99400,0,0,214,0,0,0,0,0,0,0,230,7.2,0,0,24.1,77777,9,999999999,60,0.0390,0,88,999.000,999.0,99.0
+1981,12,24,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-10.6,77,99300,0,0,215,0,0,0,0,0,0,0,220,6.7,0,0,24.1,77777,9,999999999,60,0.0390,0,88,999.000,999.0,99.0
+1981,12,24,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-10.6,74,99400,0,0,216,0,0,0,0,0,0,0,220,6.2,0,0,24.1,77777,9,999999999,60,0.0390,0,88,999.000,999.0,99.0
+1981,12,24,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-10.0,77,99400,0,0,217,0,0,0,0,0,0,0,210,7.2,0,0,24.1,77777,9,999999999,60,0.0390,0,88,999.000,999.0,99.0
+1981,12,24,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-10.0,77,99400,0,0,217,0,0,0,0,0,0,0,230,7.2,0,0,24.1,77777,9,999999999,60,0.0390,0,88,999.000,999.0,99.0
+1981,12,24,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-10.0,77,99400,0,0,217,0,0,0,0,0,0,0,230,7.2,0,0,24.1,77777,9,999999999,60,0.0390,0,88,999.000,999.0,99.0
+1981,12,24,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-10.0,77,99500,0,0,217,0,0,0,0,0,0,0,230,5.7,0,0,24.1,77777,9,999999999,60,0.0390,0,88,999.000,999.0,99.0
+1981,12,24,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-10.0,81,99600,0,0,215,0,0,0,0,0,0,0,220,4.6,0,0,24.1,77777,9,999999999,60,0.0390,0,88,999.000,999.0,99.0
+1981,12,24,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.2,-10.0,81,99700,47,955,226,18,38,15,1800,1100,1800,260,250,6.7,4,4,24.1,77777,9,999999999,60,0.0810,0,88,999.000,999.0,99.0
+1981,12,24,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.7,-11.1,71,99700,240,1414,216,127,496,40,12900,35700,6800,730,270,6.2,0,0,24.1,77777,9,999999999,60,0.0810,0,88,999.000,999.0,99.0
+1981,12,24,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.6,-12.2,60,99900,410,1414,218,257,676,56,25900,59700,8500,1080,260,5.7,1,0,24.1,77777,9,999999999,50,0.0810,0,88,999.000,999.0,99.0
+1981,12,24,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-12.2,55,99900,527,1414,222,357,774,65,36900,72600,9700,1320,240,7.7,0,0,24.1,77777,9,999999999,50,0.0810,0,88,999.000,999.0,99.0
+1981,12,24,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-12.2,51,99800,583,1414,226,405,805,69,42100,77000,10200,1440,260,7.2,0,0,24.1,77777,9,999999999,50,0.0810,0,88,999.000,999.0,99.0
+1981,12,24,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-11.7,49,99700,573,1414,230,396,798,68,41100,76100,10100,1420,220,4.1,0,0,24.1,77777,9,999999999,60,0.0810,0,88,999.000,999.0,99.0
+1981,12,24,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-11.1,49,99600,499,1414,233,331,754,62,34200,70000,9400,1250,230,4.1,0,0,24.1,77777,9,999999999,60,0.0810,0,88,999.000,999.0,99.0
+1981,12,24,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-10.0,53,99600,366,1414,233,217,639,50,22200,54800,7900,960,220,5.7,0,0,24.1,77777,9,999999999,60,0.0810,0,88,999.000,999.0,99.0
+1981,12,24,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-10.6,55,99600,184,1414,229,84,392,33,8600,25000,5400,590,210,6.2,0,0,24.1,77777,9,999999999,60,0.0810,0,88,999.000,999.0,99.0
+1981,12,24,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-10.0,60,99600,15,554,228,11,34,7,0,0,0,0,290,5.2,0,0,24.1,77777,9,999999999,60,0.0810,0,88,999.000,999.0,99.0
+1981,12,24,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.6,-10.0,71,99600,0,0,220,0,0,0,0,0,0,0,200,5.2,0,0,24.1,77777,9,999999999,60,0.0810,0,88,999.000,999.0,99.0
+1981,12,24,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-10.6,71,99600,0,0,218,0,0,0,0,0,0,0,210,6.7,0,0,24.1,77777,9,999999999,60,0.0810,0,88,999.000,999.0,99.0
+1981,12,24,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-10.6,74,99500,0,0,216,0,0,0,0,0,0,0,210,5.7,0,0,24.1,77777,9,999999999,60,0.0810,0,88,999.000,999.0,99.0
+1981,12,24,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-11.1,71,99500,0,0,216,0,0,0,0,0,0,0,200,6.7,0,0,24.1,77777,9,999999999,60,0.0810,0,88,999.000,999.0,99.0
+1981,12,24,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-12.2,74,99500,0,0,210,0,0,0,0,0,0,0,210,5.2,0,0,24.1,77777,9,999999999,50,0.0810,0,88,999.000,999.0,99.0
+1981,12,24,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-12.8,74,99500,0,0,216,0,0,0,0,0,0,0,230,5.2,3,3,24.1,77777,9,999999999,50,0.0810,0,88,999.000,999.0,99.0
+1981,12,24,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-9.4,-12.2,80,99500,0,0,217,0,0,0,0,0,0,0,210,5.2,4,4,24.1,77777,9,999999999,50,0.0810,0,88,999.000,999.0,99.0
+1981,12,25,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-11.1,84,99500,0,0,216,0,0,0,0,0,0,0,230,6.2,2,2,24.1,77777,9,999999999,60,0.0810,0,88,999.000,999.0,99.0
+1981,12,25,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-10.6,81,99500,0,0,234,0,0,0,0,0,0,0,210,3.1,8,8,24.1,3050,9,999999999,60,0.0810,0,88,999.000,999.0,99.0
+1981,12,25,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-10.0,81,99500,0,0,226,0,0,0,0,0,0,0,230,4.1,4,4,24.1,77777,9,999999999,60,0.0810,0,88,999.000,999.0,99.0
+1981,12,25,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-11.1,81,99500,0,0,211,0,0,0,0,0,0,0,210,4.1,0,0,24.1,77777,9,999999999,60,0.0810,0,88,999.000,999.0,99.0
+1981,12,25,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-9.4,-11.7,84,99400,0,0,207,0,0,0,0,0,0,0,210,1.5,0,0,24.1,77777,9,999999999,60,0.0810,0,88,999.000,999.0,99.0
+1981,12,25,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-9.4,-11.7,84,99400,0,0,207,0,0,0,0,0,0,0,210,2.1,0,0,24.1,77777,9,999999999,60,0.0810,0,88,999.000,999.0,99.0
+1981,12,25,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-9.4,-12.2,80,99400,0,0,206,0,0,0,0,0,0,0,220,3.1,0,0,14.5,77777,9,999999999,50,0.0810,0,88,999.000,999.0,99.0
+1981,12,25,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.9,-11.1,84,99400,46,955,209,24,83,17,2300,2900,2100,300,200,4.1,0,0,9.7,77777,9,999999999,60,0.0990,0,88,999.000,999.0,99.0
+1981,12,25,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.7,-8.9,84,99400,239,1414,227,116,377,50,11600,26700,7000,870,220,3.1,3,3,9.7,77777,9,999999999,60,0.0990,0,88,999.000,999.0,99.0
+1981,12,25,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.9,-7.8,75,99400,409,1414,228,240,620,57,24900,54700,9000,1100,250,2.6,0,0,14.5,77777,9,999999999,69,0.0990,0,88,999.000,999.0,99.0
+1981,12,25,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-7.2,69,99400,527,1414,234,347,728,72,35400,67900,10000,1400,250,5.2,0,0,19.3,77777,9,999999999,69,0.0990,0,88,999.000,999.0,99.0
+1981,12,25,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-6.7,64,99300,583,1414,240,398,768,77,40900,73100,10600,1530,190,4.6,0,0,19.3,77777,9,999999999,69,0.0990,0,88,999.000,999.0,99.0
+1981,12,25,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-6.7,61,99300,574,1414,242,387,757,76,39800,71800,10500,1510,240,4.1,0,0,19.3,77777,9,999999999,69,0.0990,0,88,999.000,999.0,99.0
+1981,12,25,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-6.1,59,99200,501,1414,258,257,328,140,27200,31300,16100,2880,220,3.1,3,3,19.3,77777,9,999999999,80,0.0990,0,88,999.000,999.0,99.0
+1981,12,25,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-6.1,61,99200,368,1414,253,180,432,67,18500,36400,9000,1220,210,1.5,2,2,19.3,77777,9,999999999,80,0.0990,0,88,999.000,999.0,99.0
+1981,12,25,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.0,-6.1,64,99200,186,1414,253,69,164,48,7300,9600,6100,900,190,3.6,3,3,19.3,77777,9,999999999,80,0.0990,0,88,999.000,999.0,99.0
+1981,12,25,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-6.7,72,99200,16,554,242,6,17,5,0,0,0,0,220,1.5,2,2,19.3,77777,9,999999999,69,0.0990,0,88,999.000,999.0,99.0
+1981,12,25,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-7.2,75,99200,0,0,238,0,0,0,0,0,0,0,150,2.6,2,2,24.1,77777,9,999999999,69,0.0990,0,88,999.000,999.0,99.0
+1981,12,25,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-7.2,78,99300,0,0,256,0,0,0,0,0,0,0,180,1.5,9,9,19.3,2740,9,999999999,69,0.0990,0,88,999.000,999.0,99.0
+1981,12,25,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-7.2,81,99300,0,0,262,0,0,0,0,0,0,0,120,2.1,10,10,19.3,3660,9,999999999,69,0.0990,0,88,999.000,999.0,99.0
+1981,12,25,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-7.8,81,99200,0,0,259,0,0,0,0,0,0,0,120,2.6,10,10,24.1,3050,9,999999999,69,0.0990,0,88,999.000,999.0,99.0
+1981,12,25,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-7.2,81,99200,0,0,262,0,0,0,0,0,0,0,160,2.1,10,10,24.1,2740,9,999999999,69,0.0990,0,88,999.000,999.0,99.0
+1981,12,25,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-6.7,81,99200,0,0,264,0,0,0,0,0,0,0,150,2.1,10,10,16.1,1520,9,999999999,69,0.0990,0,88,999.000,999.0,99.0
+1981,12,25,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-6.7,85,99200,0,0,262,0,0,0,0,0,0,0,160,2.1,10,10,16.1,1520,9,999999999,69,0.0990,0,88,999.000,999.0,99.0
+1981,12,26,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-6.7,88,99200,0,0,260,0,0,0,0,0,0,0,0,0.0,10,10,19.3,1520,9,999999999,69,0.0990,0,88,999.000,999.0,99.0
+1981,12,26,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-6.7,78,99100,0,0,266,0,0,0,0,0,0,0,0,0.0,10,10,24.1,1160,9,999999999,69,0.0990,0,88,999.000,999.0,99.0
+1981,12,26,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.3,-6.1,81,99100,0,0,267,0,0,0,0,0,0,0,120,2.1,10,10,24.1,1520,9,999999999,80,0.0990,0,88,999.000,999.0,99.0
+1981,12,26,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-5.6,78,99000,0,0,272,0,0,0,0,0,0,0,150,2.1,10,10,24.1,1520,9,999999999,80,0.0990,0,88,999.000,999.0,99.0
+1981,12,26,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-6.1,72,98900,0,0,266,0,0,0,0,0,0,0,100,2.1,10,9,24.1,3050,9,999999999,80,0.0990,0,88,999.000,999.0,99.0
+1981,12,26,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-8.3,78,98900,0,0,233,0,0,0,0,0,0,0,110,2.1,8,3,24.1,77777,9,999999999,69,0.0990,0,88,999.000,999.0,99.0
+1981,12,26,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-7.2,81,98900,0,0,262,0,0,0,0,0,0,0,110,3.1,10,10,24.1,980,9,999999999,69,0.0990,0,88,999.000,999.0,99.0
+1981,12,26,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-7.2,75,98800,46,931,253,21,16,20,2300,900,2200,470,140,2.1,10,8,24.1,3050,9,999999999,69,0.0400,0,88,999.000,999.0,99.0
+1981,12,26,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-6.7,66,98800,238,1414,275,56,0,56,6300,0,6300,1920,130,3.1,10,10,19.3,2130,9,999999999,69,0.0400,0,88,999.000,999.0,99.0
+1981,12,26,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-6.7,64,98800,409,1414,277,120,6,118,13300,400,13200,4080,120,2.6,10,10,24.1,1680,9,999999999,69,0.0400,0,88,999.000,999.0,99.0
+1981,12,26,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,0.6,-7.2,56,98700,527,1414,282,141,15,136,16000,1100,15600,5160,140,5.2,10,10,24.1,3660,9,999999999,69,0.0400,0,88,999.000,999.0,99.0
+1981,12,26,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-3.3,82,98500,584,1414,281,192,12,187,21400,1000,21000,6730,100,4.1,10,10,14.5,1680,9,999999999,89,0.0400,0,88,999.000,999.0,99.0
+1981,12,26,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-3.9,70,98400,575,1414,287,170,9,167,19200,700,18900,6220,110,5.2,10,10,24.1,1680,9,999999999,89,0.0400,0,88,999.000,999.0,99.0
+1981,12,26,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-4.4,67,98200,503,1414,287,144,3,143,16100,200,16100,5200,110,4.6,10,10,14.5,1680,9,999999999,80,0.0400,0,88,999.000,999.0,99.0
+1981,12,26,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-3.9,70,98200,370,1414,287,110,3,109,12200,200,12100,3670,140,6.2,10,10,12.9,1070,9,999999999,89,0.0400,0,88,999.000,999.0,99.0
+1981,12,26,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-3.3,73,98100,189,1414,280,50,23,47,5500,1600,5300,1140,130,5.2,10,9,11.3,700,9,999999999,89,0.0400,0,88,999.000,999.0,99.0
+1981,12,26,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,1.1,-2.8,76,98100,17,578,288,8,0,8,0,0,0,0,150,5.7,10,10,11.3,700,9,999999999,89,0.0400,0,88,999.000,999.0,99.0
+1981,12,26,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-2.2,79,98000,0,0,289,0,0,0,0,0,0,0,150,5.7,10,10,11.3,610,9,999999999,89,0.0400,0,88,999.000,999.0,99.0
+1981,12,26,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.7,82,98000,0,0,290,0,0,0,0,0,0,0,170,6.7,10,10,16.1,370,9,999999999,100,0.0400,0,88,999.000,999.0,99.0
+1981,12,26,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,1.1,-1.7,82,98000,0,0,290,0,0,0,0,0,0,0,210,4.1,10,10,12.9,340,9,999999999,100,0.0400,0,88,999.000,999.0,99.0
+1981,12,26,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.6,-1.7,85,98000,0,0,287,0,0,0,0,0,0,0,200,5.2,10,10,12.9,340,9,999999999,100,0.0400,0,88,999.000,999.0,99.0
+1981,12,26,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,0.0,-2.8,82,97900,0,0,284,0,0,0,0,0,0,0,220,3.6,10,10,16.1,240,9,999999999,89,0.0400,0,88,999.000,999.0,99.0
+1981,12,26,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.1,-3.9,82,97900,0,0,278,0,0,0,0,0,0,0,240,3.1,10,10,11.3,2740,9,999999999,80,0.0400,0,88,999.000,999.0,99.0
+1981,12,26,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-4.4,82,97800,0,0,249,0,0,0,0,0,0,0,250,3.1,9,3,11.3,77777,9,999999999,80,0.0400,0,88,999.000,999.0,99.0
+1981,12,27,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-3.9,92,97700,0,0,254,0,0,0,0,0,0,0,270,2.1,8,7,8.0,7620,9,999999999,80,0.0400,0,88,999.000,999.0,99.0
+1981,12,27,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-3.3,92,97700,0,0,246,0,0,0,0,0,0,0,130,1.5,7,2,9.7,77777,9,999999999,89,0.0400,0,88,999.000,999.0,99.0
+1981,12,27,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-3.3,96,97700,0,0,246,0,0,0,0,0,0,0,0,0.0,3,3,9.7,77777,9,999999999,89,0.0400,0,88,999.000,999.0,99.0
+1981,12,27,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-4.4,88,97700,0,0,242,0,0,0,0,0,0,0,260,3.6,8,2,9.7,77777,9,999999999,80,0.0400,0,88,999.000,999.0,99.0
+1981,12,27,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.2,-6.1,75,97700,0,0,271,0,0,0,0,0,0,0,270,4.1,10,10,14.5,850,9,999999999,69,0.0400,0,88,999.000,999.0,99.0
+1981,12,27,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-2.8,-5.0,85,97700,0,0,270,0,0,0,0,0,0,0,260,4.6,10,10,9.7,760,9,999999999,80,0.0400,0,88,999.000,999.0,99.0
+1981,12,27,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-1.7,-5.0,78,97900,0,0,275,0,0,0,0,0,0,0,260,5.7,10,10,11.3,310,9,999999999,80,0.0400,0,88,999.000,999.0,99.0
+1981,12,27,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-6.1,72,97900,45,931,273,9,7,8,900,400,900,210,260,6.7,10,10,8.0,760,9,999999999,69,0.0670,0,88,999.000,999.0,99.0
+1981,12,27,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-6.7,66,98000,238,1415,275,42,0,42,4800,0,4800,1550,260,7.2,10,10,8.0,460,9,999999999,69,0.0670,0,88,999.000,999.0,99.0
+1981,12,27,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-6.7,66,98100,409,1415,275,125,8,123,13900,500,13700,4180,260,8.8,10,10,8.0,460,9,999999999,69,0.0670,0,88,999.000,999.0,99.0
+1981,12,27,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-7.2,64,98200,527,1415,275,162,8,159,18100,600,17900,5710,270,8.2,10,10,6.4,520,9,999999999,69,0.0670,0,88,999.000,999.0,99.0
+1981,12,27,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-7.2,61,98200,584,1415,277,158,5,156,17900,400,17700,6010,250,7.7,10,10,9.7,980,9,999999999,69,0.0670,0,88,999.000,999.0,99.0
+1981,12,27,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-7.2,61,98200,577,1415,259,247,84,212,27000,8200,23600,5610,260,8.2,7,7,12.9,670,9,999999999,69,0.0670,0,88,999.000,999.0,99.0
+1981,12,27,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.1,-7.8,61,98300,504,1415,274,142,10,138,15900,700,15700,5090,270,8.2,10,10,12.9,670,9,999999999,69,0.0670,0,88,999.000,999.0,99.0
+1981,12,27,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-0.6,-7.8,59,98300,373,1415,276,74,6,72,8400,300,8400,2760,250,5.2,10,10,14.5,980,9,999999999,69,0.0670,0,88,999.000,999.0,99.0
+1981,12,27,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-1.7,-8.3,61,98400,191,1415,271,43,2,43,4800,0,4800,1460,260,5.7,10,10,14.5,980,9,999999999,69,0.0670,0,88,999.000,999.0,99.0
+1981,12,27,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-8.9,63,98500,18,601,247,8,15,6,0,0,0,0,260,3.1,6,6,14.5,460,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,27,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-8.9,74,98500,0,0,245,0,0,0,0,0,0,0,220,1.5,10,8,12.9,7620,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,27,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-8.9,74,98500,0,0,258,0,0,0,0,0,0,0,220,2.1,10,10,16.1,3660,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,27,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-8.9,74,98700,0,0,258,0,0,0,0,0,0,0,210,3.6,10,10,12.9,4570,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,27,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-4.4,-8.3,75,98700,0,0,261,0,0,0,0,0,0,0,230,4.1,10,10,16.1,3660,9,999999999,69,0.0670,0,88,999.000,999.0,99.0
+1981,12,27,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-3.9,-8.3,72,98700,0,0,263,0,0,0,0,0,0,0,190,3.1,10,10,16.1,3050,9,999999999,69,0.0670,0,88,999.000,999.0,99.0
+1981,12,27,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-8.9,74,98800,0,0,245,0,0,0,0,0,0,0,210,2.6,8,8,16.1,2440,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,27,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-9.4,81,98800,0,0,251,0,0,0,0,0,0,0,230,3.1,10,10,14.5,460,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,28,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.2,-8.9,88,98800,0,0,249,0,0,0,0,0,0,0,230,2.1,10,10,16.1,460,9,999999999,60,0.0670,0,88,999.000,999.0,99.0
+1981,12,28,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.1,-7.8,88,98900,0,0,255,0,0,0,0,0,0,0,240,2.1,10,10,12.9,850,9,999999999,69,0.0670,0,88,999.000,999.0,99.0
+1981,12,28,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-5.6,96,98900,0,0,261,0,0,0,0,0,0,0,200,1.5,10,10,6.4,310,9,999999999,80,0.0670,0,88,999.000,999.0,99.0
+1981,12,28,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-5.0,100,98800,0,0,261,0,0,0,0,0,0,0,170,1.5,10,10,8.0,460,9,999999999,80,0.0670,0,88,999.000,999.0,99.0
+1981,12,28,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-5.6,96,98700,0,0,261,0,0,0,0,0,0,0,190,1.5,10,10,4.8,270,9,999999999,80,0.0670,0,88,999.000,999.0,99.0
+1981,12,28,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-6.1,92,98800,0,0,260,0,0,0,0,0,0,0,270,1.5,10,10,3.2,180,9,999999999,69,0.0670,0,88,999.000,999.0,99.0
+1981,12,28,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-5.0,-6.1,92,98800,0,0,260,0,0,0,0,0,0,0,0,0.0,10,10,3.2,180,9,999999999,69,0.0670,0,88,999.000,999.0,99.0
+1981,12,28,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.0,-5.6,96,98800,44,931,261,9,0,9,1100,0,1100,340,0,0.0,10,10,2.0,180,9,999999999,80,0.1170,0,88,999.000,999.0,99.0
+1981,12,28,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-4.4,-5.6,92,98900,237,1415,263,54,1,54,6100,0,6100,1870,0,0.0,10,10,2.0,180,9,999999999,80,0.1170,0,88,999.000,999.0,99.0
+1981,12,28,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.9,-5.0,92,99000,408,1415,266,86,7,84,9800,400,9700,3230,0,0.0,10,10,2.0,180,9,999999999,80,0.1170,0,88,999.000,999.0,99.0
+1981,12,28,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-3.3,-5.6,85,99000,527,1415,268,181,4,180,20100,300,19900,6140,310,3.1,10,10,2.0,240,9,999999999,80,0.1170,0,88,999.000,999.0,99.0
+1981,12,28,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-5.6,81,98900,585,1415,270,191,5,189,21300,400,21100,6790,330,2.6,10,10,2.4,210,9,999999999,80,0.1170,0,88,999.000,999.0,99.0
+1981,12,28,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-5.6,81,98900,578,1415,262,199,94,160,21800,9100,18100,4560,300,4.6,9,9,4.8,1520,9,999999999,80,0.1170,0,88,999.000,999.0,99.0
+1981,12,28,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.2,-6.7,72,98900,506,1415,258,193,49,175,21100,4700,19400,4540,280,5.2,8,8,16.1,490,9,999999999,69,0.1170,0,88,999.000,999.0,99.0
+1981,12,28,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-2.8,-7.8,69,99000,375,1415,244,171,242,106,18000,20800,12400,2110,330,6.2,5,4,11.3,77777,9,999999999,69,0.1170,0,88,999.000,999.0,99.0
+1981,12,28,16,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-5.0,-8.9,74,99100,194,1415,239,68,77,58,7400,5000,6700,1220,310,5.7,6,6,9.7,520,9,999999999,60,0.1170,0,88,999.000,999.0,99.0
+1981,12,28,17,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-6.1,-9.4,78,99300,19,625,253,5,2,5,0,0,0,0,340,6.7,10,10,11.3,580,9,999999999,60,0.1170,0,88,999.000,999.0,99.0
+1981,12,28,18,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-10.0,77,99400,0,0,250,0,0,0,0,0,0,0,300,4.6,10,10,24.1,640,9,999999999,60,0.1170,0,88,999.000,999.0,99.0
+1981,12,28,19,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-6.7,-10.0,77,99500,0,0,250,0,0,0,0,0,0,0,330,6.2,10,10,19.3,460,9,999999999,60,0.1170,0,88,999.000,999.0,99.0
+1981,12,28,20,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-11.1,77,99600,0,0,245,0,0,0,0,0,0,0,330,5.7,10,10,16.1,460,9,999999999,60,0.1170,0,88,999.000,999.0,99.0
+1981,12,28,21,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-7.8,-10.6,81,99700,0,0,245,0,0,0,0,0,0,0,300,4.1,10,10,16.1,460,9,999999999,60,0.1170,0,88,999.000,999.0,99.0
+1981,12,28,22,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.3,-11.1,81,99700,0,0,243,0,0,0,0,0,0,0,290,3.6,10,10,19.3,460,9,999999999,60,0.1170,0,88,999.000,999.0,99.0
+1981,12,28,23,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-8.9,-11.7,81,99800,0,0,234,0,0,0,0,0,0,0,300,3.1,9,9,24.1,460,9,999999999,60,0.1170,0,88,999.000,999.0,99.0
+1981,12,28,24,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-12.2,-15.6,76,99900,0,0,214,0,0,0,0,0,0,0,280,5.2,8,8,24.1,460,9,999999999,50,0.1170,0,88,999.000,999.0,99.0
+1981,12,29,1,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-13.9,-17.2,76,99900,0,0,199,0,0,0,0,0,0,0,280,2.1,4,4,24.1,77777,9,999999999,40,0.1170,0,88,999.000,999.0,99.0
+1981,12,29,2,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-13.9,-16.1,83,100000,0,0,190,0,0,0,0,0,0,0,270,3.6,0,0,24.1,77777,9,999999999,40,0.1170,0,88,999.000,999.0,99.0
+1981,12,29,3,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-16.1,-18.3,83,100000,0,0,182,0,0,0,0,0,0,0,260,3.1,0,0,24.1,77777,9,999999999,40,0.1170,0,88,999.000,999.0,99.0
+1981,12,29,4,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.8,-20.6,79,100000,0,0,175,0,0,0,0,0,0,0,0,0.0,0,0,19.3,77777,9,999999999,40,0.1170,0,88,999.000,999.0,99.0
+1981,12,29,5,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.2,-18.9,87,100000,0,0,178,0,0,0,0,0,0,0,270,3.1,0,0,14.5,77777,9,999999999,40,0.1170,0,88,999.000,999.0,99.0
+1981,12,29,6,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.2,-19.4,83,100100,0,0,178,0,0,0,0,0,0,0,260,2.6,0,0,16.1,77777,9,999999999,40,0.1170,0,88,999.000,999.0,99.0
+1981,12,29,7,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9*_*9*9*9*9*9,-17.2,-19.4,83,100200,0,0,178,0,0,0,0,0,0,0,220,3.1,0,0,14.5,77777,9,999999999,40,0.1170,0,88,999.000,999.0,99.0
+1981,12,29,8,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-16.7,-18.9,83,100300,44,908,180,28,158,14,2300,6600,1900,250,0,0.0,0,0,9.7,77777,9,999999999,40,0.0520,0,88,999.000,999.0,99.0
+1981,12,29,9,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-14.4,-16.7,83,100300,237,1415,188,136,584,35,13500,43500,6200,660,250,2.1,0,0,8.0,77777,9,999999999,40,0.0520,0,88,999.000,999.0,99.0
+1981,12,29,10,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-11.7,-14.4,80,100400,408,1415,198,267,744,48,27500,66100,8300,990,250,3.1,0,0,9.7,77777,9,999999999,50,0.0520,0,88,999.000,999.0,99.0
+1981,12,29,11,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-8.9,-13.3,71,100400,528,1415,207,373,835,57,38800,78200,9500,1210,240,4.1,0,0,11.3,77777,9,999999999,50,0.0520,0,88,999.000,999.0,99.0
+1981,12,29,12,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-13.3,65,100300,587,1415,210,424,863,62,44200,82100,9900,1320,250,5.2,0,0,14.5,77777,9,999999999,50,0.0520,0,88,999.000,999.0,99.0
+1981,12,29,13,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-13.3,65,100300,580,1415,210,415,857,61,43400,81400,9800,1300,240,4.6,0,0,16.1,77777,9,999999999,50,0.0520,0,88,999.000,999.0,99.0
+1981,12,29,14,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-13.9,62,100200,508,1415,210,352,821,55,36900,76400,9300,1170,220,4.1,0,0,16.1,77777,9,999999999,50,0.0520,0,88,999.000,999.0,99.0
+1981,12,29,15,0,?9?9?9?9E0?9?9?9?9?9?9?9?9?9?9?9?9?9?9?9*9*9*9*9*9,-7.8,-13.9,62,100300,377,1415,210,238,712,47,24600,61900,8000,940,210,5.2,1,0,14.5,77777,9,999999999,50,0.
