[Swift-commit] r7150 - in SwiftApps/tryswift: . css scripts
davidk at ci.uchicago.edu
Fri Oct 11 12:30:57 CDT 2013
Author: davidk
Date: 2013-10-11 12:30:56 -0500 (Fri, 11 Oct 2013)
New Revision: 7150
Added:
SwiftApps/tryswift/scripts/003-foreach.html
SwiftApps/tryswift/scripts/003-foreach.swift
SwiftApps/tryswift/scripts/003-foreach.txt
Removed:
SwiftApps/tryswift/scripts/build_docs.sh
SwiftApps/tryswift/scripts/p1.html
SwiftApps/tryswift/scripts/p1.swift
SwiftApps/tryswift/scripts/p1.txt
SwiftApps/tryswift/scripts/p2.html
SwiftApps/tryswift/scripts/p2.swift
SwiftApps/tryswift/scripts/p2.txt
SwiftApps/tryswift/scripts/part01.png
SwiftApps/tryswift/scripts/part02.png
SwiftApps/tryswift/scripts/part1.txt
SwiftApps/tryswift/scripts/part2.txt
Modified:
SwiftApps/tryswift/css/tryswift.css
SwiftApps/tryswift/index.php
Log:
Some css fixes, new foreach example, some cleanup
Modified: SwiftApps/tryswift/css/tryswift.css
--- SwiftApps/tryswift/css/tryswift.css 2013-10-11 16:16:10 UTC (rev 7149)
+++ SwiftApps/tryswift/css/tryswift.css 2013-10-11 17:30:56 UTC (rev 7150)
@@ -2,13 +2,10 @@
text-align: center;
-#scriptCount {
- text-align: center;
#infoFrame {
width: 100%;
background: white;
+ overflow-y: scroll;
#editor {
@@ -18,12 +15,16 @@
#scriptNav {
position: relative;
- top: 5px;
left: 25%;
right: 25%;
width: 100%;
+#scriptDropdown {
+ position: relative;
+ top: 5px;
.b0b0 {
background: #b0b0b0;
border: 1px solid black;
Modified: SwiftApps/tryswift/index.php
--- SwiftApps/tryswift/index.php 2013-10-11 16:16:10 UTC (rev 7149)
+++ SwiftApps/tryswift/index.php 2013-10-11 17:30:56 UTC (rev 7150)
@@ -90,7 +90,7 @@
function resize() {
$('#editor').height( $(document).height() / 2 );
$('#infoContainer').height( $('#editorContainer').height() );
- $('#infoFrame').height( $('#infoContainer').height() - $('#back').height()-5 );
+ $('#infoFrame').height( $('#infoContainer').height() - $('#scriptDropdown').height()-5 );
$('#swiftOutput').height( $(document).height() * .20 );
$('#fileOutput').height( $(document).height() * .19 );
$('#fileOutput').width( $(document).width() );
Added: SwiftApps/tryswift/scripts/003-foreach.html
--- SwiftApps/tryswift/scripts/003-foreach.html (rev 0)
+++ SwiftApps/tryswift/scripts/003-foreach.html 2013-10-11 17:30:56 UTC (rev 7150)
@@ -0,0 +1,72 @@
+<html>
+<head>
+<link href="formatting.css" rel="stylesheet" media="screen">
+</head>
+<body>
+<h2>Foreach</h2>
+In this example, we first change our application. Instead of using "echo",
+we use an app called simulate. The simulate application serves as a trivial
+proxy for any more complex scientific simulation application. It generates
+and prints a set of one or more random integers
+<pre>
+app (file o) simulate ()
+ simulate stdout=filename(o);
+</pre>
+Swift is a simple scripting language for executing many instances of
+ordinary application programs on distributed parallel resources.
+Swift scripts run many copies of ordinary programs concurrently, using
+statements like this:
+<pre>
+foreach i in [1:10] {
+ string fname=strcat("output/sim_", i, ".out");
+ file f <single_file_mapper; file=fname>;
+ f = simulate();
+</pre>
+<p>
+In this example the foreach loop will iterate over a range of numbers from 0 to 9.
+It will then map an output file and run the simulate app. The important thing to realize
+about this example is that every iteration will run in parallel (up to a user defined
+throttle).
+</p>
+<p>
+Another new feature in this example is the file mapper. In the first hello world example,
+we saw a simplified version of a file mapper with the line:
+</p>
+<pre>
+file out <"out.txt">;
+</pre>
+This is the same as saying
+<pre>
+file out <single_file_mapper; file="output.txt">;
+</pre>
+<p>
+Defining a file mapper in this way allows a file name to be the content of a string
+or the output of another function. The strcat function combines multiple strings into a single
+string.
+</p>
+Execute the script and examine the results. You should see 10 files creates with random numbers.
+<h3>Exercises</h3>
+<ul>
+<li>Create 20 files instead of 10</li>
+<li>Set the output files to be created in a directory called results</li>
+</ul>
+</body>
+</html>
Added: SwiftApps/tryswift/scripts/003-foreach.swift
--- SwiftApps/tryswift/scripts/003-foreach.swift (rev 0)
+++ SwiftApps/tryswift/scripts/003-foreach.swift 2013-10-11 17:30:56 UTC (rev 7150)
@@ -0,0 +1,12 @@
+type file;
+ f = simulate();
Added: SwiftApps/tryswift/scripts/003-foreach.txt
--- SwiftApps/tryswift/scripts/003-foreach.txt (rev 0)
+++ SwiftApps/tryswift/scripts/003-foreach.txt 2013-10-11 17:30:56 UTC (rev 7150)
@@ -0,0 +1 @@
+Foreach
Deleted: SwiftApps/tryswift/scripts/build_docs.sh
--- SwiftApps/tryswift/scripts/build_docs.sh 2013-10-11 16:16:10 UTC (rev 7149)
+++ SwiftApps/tryswift/scripts/build_docs.sh 2013-10-11 17:30:56 UTC (rev 7150)
@@ -1,8 +0,0 @@
-#!/bin/bash
-asciidoc -a icons -a stylesheet=$PWD/asciidoc.css -a max-width=800px -o p1.html part1.txt
-asciidoc -a icons -a stylesheet=$PWD/asciidoc.css -a max-width=800px -o p2.html part2.txt
-asciidoc -a icons -a stylesheet=$PWD/asciidoc.css -a max-width=800px -o p3.html part3.txt
-asciidoc -a icons -a stylesheet=$PWD/asciidoc.css -a max-width=800px -o p4.html part4.txt
-asciidoc -a icons -a stylesheet=$PWD/asciidoc.css -a max-width=800px -o p5.html part5.txt
-asciidoc -a icons -a stylesheet=$PWD/asciidoc.css -a max-width=800px -o p6.html part6.txt
Deleted: SwiftApps/tryswift/scripts/p1.html
--- SwiftApps/tryswift/scripts/p1.html 2013-10-11 16:16:10 UTC (rev 7149)
+++ SwiftApps/tryswift/scripts/p1.html 2013-10-11 17:30:56 UTC (rev 7150)
@@ -1,631 +0,0 @@
-<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN"
- "http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd">
-<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en">
-<head>
-<meta http-equiv="Content-Type" content="application/xhtml+xml; charset=UTF-8" />
-<meta name="generator" content="AsciiDoc 8.6.4" />
-<title>Part 1: Run a single application under Swift</title>
-<style type="text/css">
-/* Sans-serif font. */
-h1, h2, h3, h4, h5, h6,
-div.title, caption.title,
-thead, p.table.header,
-div#toctitle,
-span#author, span#revnumber, span#revdate, span#revremark,
-div#footer {
- font-family: Arial,Helvetica,sans-serif;
-/* Serif font. */
-div.sectionbody {
- font-family: Georgia,"Times New Roman",Times,serif;
-/* Monospace font. */
-tt {
- font-size: inherit;
-body {
- margin: 1em 5% 1em 5%;
-a {
- color: blue;
- text-decoration: underline;
-a:visited {
- color: fuchsia;
-em {
- font-style: italic;
- color: navy;
-strong {
- font-weight: bold;
- color: #083194;
-tt {
- color: navy;
-h1, h2, h3, h4, h5, h6 {
- color: #527bbd;
- margin-top: 1.2em;
- margin-bottom: 0.5em;
- line-height: 1.3;
-h1, h2, h3 {
- border-bottom: 2px solid silver;
-h2 {
- padding-top: 0.5em;
-h3 {
- float: left;
-h3 + * {
- clear: left;
-div.sectionbody {
- margin-left: 0;
-hr {
- border: 1px solid silver;
-p {
- margin-top: 0.5em;
-ul, ol, li > p {
- margin-top: 0;
-ul > li { color: #aaa; }
-ul > li > * { color: black; }
-pre {
- padding: 0;
- margin: 0;
-span#author {
- color: #527bbd;
- font-size: 1.1em;
-span#email {
-span#revnumber, span#revdate, span#revremark {
-div#footer {
- font-size: small;
- border-top: 2px solid silver;
- margin-top: 4.0em;
-div#footer-text {
- float: left;
- padding-bottom: 0.5em;
-div#footer-badges {
- float: right;
-div#preamble {
- margin-top: 1.5em;
- margin-bottom: 1.5em;
-div.tableblock, div.imageblock, div.exampleblock, div.verseblock,
-div.quoteblock, div.literalblock, div.listingblock, div.sidebarblock,
-div.admonitionblock {
- margin-top: 1.0em;
- margin-top: 2.0em;
- margin-bottom: 2.0em;
- margin-right: 10%;
- color: #606060;
-div.content { /* Block element content. */
- padding: 0;
-/* Block element titles. */
-div.title, caption.title {
- color: #527bbd;
- text-align: left;
-div.title + * {
- margin-top: 0;
-td div.title:first-child {
- margin-top: 0.0em;
-div.content div.title:first-child {
-div.content + div.title {
-div.sidebarblock > div.content {
- background: #ffffee;
- border: 1px solid #dddddd;
- border-left: 4px solid #f0f0f0;
- padding: 0.5em;
-div.listingblock > div.content {
- border-left: 5px solid #f0f0f0;
- background: #f8f8f8;
- padding: 0.5em;
-div.quoteblock, div.verseblock {
- padding-left: 1.0em;
- margin-left: 1.0em;
- color: #777777;
-div.quoteblock > div.attribution {
- text-align: right;
-div.verseblock > pre.content {
- font-family: inherit;
-div.verseblock > div.attribution {
- padding-top: 0.75em;
- text-align: left;
-/* DEPRECATED: Pre version 8.2.7 verse style literal block. */
-div.verseblock + div.attribution {
- text-align: left;
-div.admonitionblock .icon {
- vertical-align: top;
- font-size: 1.1em;
- color: #527bbd;
- padding-right: 0.5em;
-div.admonitionblock td.content {
- padding-left: 0.5em;
- border-left: 3px solid #dddddd;
-div.exampleblock > div.content {
-div.imageblock div.content { padding-left: 0; }
-span.image img { border-style: none; }
-a.image:visited { color: white; }
-dl {
- margin-top: 0.8em;
- margin-bottom: 0.8em;
-dt {
- margin-bottom: 0;
- font-style: normal;
- color: navy;
-dd > *:first-child {
- margin-top: 0.1em;
-ul, ol {
- list-style-position: outside;
-ol.arabic {
- list-style-type: decimal;
-ol.loweralpha {
- list-style-type: lower-alpha;
-ol.upperalpha {
- list-style-type: upper-alpha;
-ol.lowerroman {
- list-style-type: lower-roman;
-ol.upperroman {
- list-style-type: upper-roman;
-div.compact ul, div.compact ol,
-div.compact p, div.compact p,
-div.compact div, div.compact div {
- margin-bottom: 0.1em;
-div.tableblock > table {
- border: 3px solid #527bbd;
-thead, p.table.header {
- color: #527bbd;
-tfoot {
-td > div.verse {
- white-space: pre;
-p.table {
- margin-top: 0;
-/* Because the table frame attribute is overriden by CSS in most browsers. */
-div.tableblock > table[frame="void"] {
- border-style: none;
-div.tableblock > table[frame="hsides"] {
- border-left-style: none;
- border-right-style: none;
-div.tableblock > table[frame="vsides"] {
- border-top-style: none;
- border-bottom-style: none;
-div.hdlist {
-div.hdlist tr {
- padding-bottom: 15px;
-dt.hdlist1.strong, td.hdlist1.strong {
-td.hdlist1 {
- padding-right: 0.8em;
- color: navy;
-td.hdlist2 {
-div.hdlist.compact tr {
- margin: 0;
- padding-bottom: 0;
-.comment {
- background: yellow;
-.footnote, .footnoteref {
- font-size: 0.8em;
-span.footnote, span.footnoteref {
- vertical-align: super;
-#footnotes {
- margin: 20px 0 20px 0;
- padding: 7px 0 0 0;
-#footnotes div.footnote {
- margin: 0 0 5px 0;
-#footnotes hr {
- border: none;
- border-top: 1px solid silver;
- height: 1px;
- text-align: left;
- margin-left: 0;
- width: 20%;
- min-width: 100px;
-div.colist td {
- padding-bottom: 0.3em;
-div.colist td img {
- margin-top: 0.3em;
- at media print {
- div#footer-badges { display: none; }
-div#toc {
- margin-bottom: 2.5em;
-div#toctitle {
- color: #527bbd;
- font-size: 1.1em;
-div.toclevel1, div.toclevel2, div.toclevel3, div.toclevel4 {
- margin-top: 0;
- margin-bottom: 0;
-div.toclevel2 {
- margin-left: 2em;
- font-size: 0.9em;
-div.toclevel3 {
- margin-left: 4em;
- font-size: 0.9em;
-div.toclevel4 {
- margin-left: 6em;
- font-size: 0.9em;
-span.aqua { color: aqua; }
-span.black { color: black; }
-span.blue { color: blue; }
-span.fuchsia { color: fuchsia; }
-span.gray { color: gray; }
-span.green { color: green; }
-span.lime { color: lime; }
-span.maroon { color: maroon; }
-span.navy { color: navy; }
-span.olive { color: olive; }
-span.purple { color: purple; }
-span.red { color: red; }
-span.silver { color: silver; }
-span.teal { color: teal; }
-span.white { color: white; }
-span.yellow { color: yellow; }
-span.aqua-background { background: aqua; }
-span.black-background { background: black; }
-span.blue-background { background: blue; }
-span.fuchsia-background { background: fuchsia; }
-span.gray-background { background: gray; }
-span.green-background { background: green; }
-span.lime-background { background: lime; }
-span.maroon-background { background: maroon; }
-span.navy-background { background: navy; }
-span.olive-background { background: olive; }
-span.purple-background { background: purple; }
-span.red-background { background: red; }
-span.silver-background { background: silver; }
-span.teal-background { background: teal; }
-span.white-background { background: white; }
-span.yellow-background { background: yellow; }
-span.big { font-size: 2em; }
-span.small { font-size: 0.6em; }
-a:link { color:navy; }
-a:visited { color:navy; }
-.monospaced, code, pre {
- font-family: "Courier New", Courier, monospace;
- font-size: medium; /* inherit; */
- color: black;
- padding: 0;
- margin: 0;
- padding: 0.5em;
- background: none;
- border: none;
- border-left: none;
- margin-right: none;
-</style>
-<script type="text/javascript">
- // Function that scans the DOM tree for header elements (the DOM2
- // nodeIterator API would be a better technique but not supported by all
- // browsers).
- var iterate = function (el) {
- for (var i = el.firstChild; i != null; i = i.nextSibling) {
- if (i.nodeType == 1 /* Node.ELEMENT_NODE */) {
- var mo = re.exec(i.tagName);
- if (mo && (i.getAttribute("class") || i.getAttribute("className")) != "float") {
- result[result.length] = new TocEntry(i, getText(i), mo[1]-1);
- iterate(i);
- iterate(el);
- return result;
- var toc = document.getElementById("toc");
- var entries = tocEntries(document.getElementById("content"), toclevels);
- for (var i = 0; i < entries.length; ++i) {
- var entry = entries[i];
- if (entry.element.id == "")
- entry.element.id = "_toc_" + i;
- var a = document.createElement("a");
- a.href = "#" + entry.element.id;
- a.appendChild(document.createTextNode(entry.text));
- var div = document.createElement("div");
- div.appendChild(a);
- div.className = "toclevel" + entry.toclevel;
- toc.appendChild(div);
- if (entries.length == 0)
- toc.parentNode.removeChild(toc);
-// Footnotes generator
-/* Based on footnote generation code from:
- * http://www.brandspankingnew.net/archive/2005/07/format_footnote.html
-footnotes: function () {
- var cont = document.getElementById("content");
- var noteholder = document.getElementById("footnotes");
- var spans = cont.getElementsByTagName("span");
- var refs = {};
- var n = 0;
- for (i=0; i<spans.length; i++) {
- if (spans[i].className == "footnote") {
- n++;
- // Use [\s\S] in place of . so multi-line matches work.
- // Because JavaScript has no s (dotall) regex flag.
- note = spans[i].innerHTML.match(/\s*\[([\s\S]*)]\s*/)[1];
- noteholder.innerHTML +=
- "<div class='footnote' id='_footnote_" + n + "'>" +
- "<a href='#_footnoteref_" + n + "' title='Return to text'>" +
- n + "</a>. " + note + "</div>";
- spans[i].innerHTML =
- "[<a id='_footnoteref_" + n + "' href='#_footnote_" + n +
- "' title='View footnote' class='footnote'>" + n + "</a>]";
- var id =spans[i].getAttribute("id");
- if (id != null) refs["#"+id] = n;
- if (n == 0)
- noteholder.parentNode.removeChild(noteholder);
- else {
- // Process footnoterefs.
- if (spans[i].className == "footnoteref") {
- var href = spans[i].getElementsByTagName("a")[0].getAttribute("href");
- href = href.match(/#.*/)[0]; // Because IE return full URL.
- n = refs[href];
- "[<a href='#_footnote_" + n +
-</script>
-</head>
-<body class="article" style="max-width:800px">
-<div id="header">
-<h1>Part 1: Run a single application under Swift</h1>
-</div>
-<div id="content">
-<div id="preamble">
-<div class="sectionbody">
-<div class="paragraph"><p>The first swift script, p1.swift, runs simulate.sh to generate a
-single random number. It writes the number to a file.</p></div>
-<div class="imageblock" style="text-align:center;">
-<div class="content">
-<img src="part01.png" alt="p1 workflow" />
-</div>
-</div>
-<div class="listingblock">
-<div class="title">p1.swift</div>
-<pre><tt>type file;
-app (file o) simulation ()
- simulate stdout=@filename(o);
-file f <"sim.out">;
-f = simulation();</tt></pre>
-</div></div>
-</div>
-</div>
-</div>
-<div id="footnotes"><hr /></div>
-<div id="footer">
-<div id="footer-text">
-Last updated 2013-09-11 13:12:25 CDT
-</div>
-</div>
-</body>
-</html>
Deleted: SwiftApps/tryswift/scripts/p1.swift
--- SwiftApps/tryswift/scripts/p1.swift 2013-10-11 16:16:10 UTC (rev 7149)
+++ SwiftApps/tryswift/scripts/p1.swift 2013-10-11 17:30:56 UTC (rev 7150)
@@ -1,9 +0,0 @@
-type file;
- simulate stdout=filename(o);
-f = simulation();
Deleted: SwiftApps/tryswift/scripts/p1.txt
--- SwiftApps/tryswift/scripts/p1.txt 2013-10-11 16:16:10 UTC (rev 7149)
+++ SwiftApps/tryswift/scripts/p1.txt 2013-10-11 17:30:56 UTC (rev 7150)
@@ -1 +0,0 @@
-p1
Deleted: SwiftApps/tryswift/scripts/p2.html
--- SwiftApps/tryswift/scripts/p2.html 2013-10-11 16:16:10 UTC (rev 7149)
+++ SwiftApps/tryswift/scripts/p2.html 2013-10-11 17:30:56 UTC (rev 7150)
@@ -1,656 +0,0 @@
-<head>
-<title></title>
-div#toctitle,
-div#footer {
-/* Serif font. */
-div.sectionbody {
-tt {
-body {
-a {
- color: blue;
-a:visited {
- color: fuchsia;
-em {
- color: navy;
-strong {
- color: #083194;
-tt {
- color: navy;
- color: #527bbd;
- line-height: 1.3;
-h1, h2, h3 {
-h2 {
-h3 {
- float: left;
-h3 + * {
- clear: left;
-div.sectionbody {
- margin-left: 0;
-hr {
-p {
-ul, ol, li > p {
- margin-top: 0;
-pre {
- padding: 0;
- margin: 0;
-span#author {
- color: #527bbd;
- font-size: 1.1em;
-span#email {
-div#footer {
- font-size: small;
-div#footer-text {
- float: left;
- float: right;
-div#preamble {
- color: #606060;
- padding: 0;
- color: #527bbd;
- text-align: left;
-div.title + * {
- margin-top: 0;
- padding: 0.5em;
- padding: 0.5em;
- color: #777777;
- text-align: left;
- text-align: left;
- font-size: 1.1em;
- color: #527bbd;
-dl {
-dt {
- margin-bottom: 0;
- color: navy;
-ul, ol {
-ol.arabic {
-ol.loweralpha {
-ol.upperalpha {
-ol.lowerroman {
-ol.upperroman {
- color: #527bbd;
-tfoot {
-td > div.verse {
- white-space: pre;
-p.table {
- margin-top: 0;
-div.hdlist {
-div.hdlist tr {
-td.hdlist1 {
- color: navy;
-td.hdlist2 {
- margin: 0;
-.comment {
- font-size: 0.8em;
-#footnotes {
-#footnotes hr {
- border: none;
- height: 1px;
- text-align: left;
- margin-left: 0;
- width: 20%;
- min-width: 100px;
-div.colist td {
- at media print {
-div#toc {
-div#toctitle {
- color: #527bbd;
- font-size: 1.1em;
- margin-top: 0;
- margin-bottom: 0;
-div.toclevel2 {
- margin-left: 2em;
- font-size: 0.9em;
-div.toclevel3 {
- margin-left: 4em;
- font-size: 0.9em;
-div.toclevel4 {
- margin-left: 6em;
- font-size: 0.9em;
- color: black;
- padding: 0;
- margin: 0;
- padding: 0.5em;
- background: none;
- border: none;
-</style>
- // browsers).
- iterate(i);
- iterate(el);
- return result;
- var refs = {};
- var n = 0;
- n++;
- if (n == 0)
- else {
- n = refs[href];
-</script>
-</head>
-<div id="header">
-</div>
-<div id="content">
-<div class="sect2">
-<h3 id="_part_2_running_an_ensemble_of_many_apps_in_parallel_with_a_foreach_loop">Part 2: Running an ensemble of many apps in parallel with a "foreach" loop</h3>
-<div class="paragraph"><p>The <tt>p2.swift</tt> script introduces the <tt>foreach</tt> parallel iteration
-construct to run many concurrent simulations.</p></div>
-<img src="part02.png" alt="part02.png" />
-</div>
-</div>
-<div class="title">p2.swift</div>
-foreach i in [0:9] {
- file f <single_file_mapper; file=@strcat("output/sim_",i,".out")>;
- f = simulation();
-}</tt></pre>
-</div></div>
-<div class="paragraph"><p>The script also shows an
-example of naming the output files of an ensemble run. In this case, the output files will be named
-<tt>output/sim_N.out</tt>.</p></div>
-<div class="paragraph"><p>To run the script and view the output:</p></div>
-<pre><tt>$ cd ../part02
-$ swift p2.swift
-$ ls output
-sim_0.out sim_1.out sim_2.out sim_3.out sim_4.out sim_5.out sim_6.out sim_7.out sim_8.out sim_9.out
-$ more output/*
-output/sim_0.out
- 44
-output/sim_1.out
- 55
-output/sim_9.out
- 82</tt></pre>
-</div></div>
-</div>
-</div>
-<div id="footer">
-Last updated 2013-09-11 13:05:49 CDT
-</div>
-</div>
-</body>
-</html>
Deleted: SwiftApps/tryswift/scripts/p2.swift
--- SwiftApps/tryswift/scripts/p2.swift 2013-10-11 16:16:10 UTC (rev 7149)
+++ SwiftApps/tryswift/scripts/p2.swift 2013-10-11 17:30:56 UTC (rev 7150)
@@ -1,11 +0,0 @@
-type file;
- file f <single_file_mapper; file=strcat("output/sim_",i,".out")>;
- f = simulation();
Deleted: SwiftApps/tryswift/scripts/p2.txt
--- SwiftApps/tryswift/scripts/p2.txt 2013-10-11 16:16:10 UTC (rev 7149)
+++ SwiftApps/tryswift/scripts/p2.txt 2013-10-11 17:30:56 UTC (rev 7150)
@@ -1 +0,0 @@
-p2
Deleted: SwiftApps/tryswift/scripts/part01.png
(Binary files differ)
Deleted: SwiftApps/tryswift/scripts/part02.png
Deleted: SwiftApps/tryswift/scripts/part1.txt
--- SwiftApps/tryswift/scripts/part1.txt 2013-10-11 16:16:10 UTC (rev 7149)
+++ SwiftApps/tryswift/scripts/part1.txt 2013-10-11 17:30:56 UTC (rev 7150)
@@ -1,13 +0,0 @@
-Part 1: Run a single application under Swift
-The first swift script, p1.swift, runs simulate.sh to generate a
-image::part01.png["p1 workflow",align="center"]
-.p1.swift
-sys::[cat ../part01/p1.swift]
Deleted: SwiftApps/tryswift/scripts/part2.txt
--- SwiftApps/tryswift/scripts/part2.txt 2013-10-11 16:16:10 UTC (rev 7149)
+++ SwiftApps/tryswift/scripts/part2.txt 2013-10-11 17:30:56 UTC (rev 7150)
@@ -1,38 +0,0 @@
-Part 2: Running an ensemble of many apps in parallel with a "foreach" loop
-The `p2.swift` script introduces the `foreach` parallel iteration
-image::part02.png[align="center"]
-.p2.swift
-sys::[cat ../part02/p2.swift]
-The script also shows an
-`output/sim_N.out`.
-To run the script and view the output:
-$ cd ../part02
-$ swift p2.swift
-$ ls output
-$ more output/*
-output/sim_0.out
- 44
-output/sim_1.out
- 55
-output/sim_9.out
- 82
More information about the Swift-commit
