[Swift-commit] r7146 - in trunk/tests/sites: . osgconnect
yadunandb at ci.uchicago.edu
Wed Oct 9 10:07:43 CDT 2013
Author: yadunandb
Date: 2013-10-09 10:07:42 -0500 (Wed, 09 Oct 2013)
New Revision: 7146
Added:
trunk/tests/sites/osgconnect/
trunk/tests/sites/osgconnect/osgc_sanity.setup.sh
trunk/tests/sites/osgconnect/osgc_sanity.source.sh
trunk/tests/sites/osgconnect/osgc_sanity.swift
trunk/tests/sites/osgconnect/osgc_sanity.timeout
trunk/tests/sites/osgconnect/sites.template.xml
trunk/tests/sites/osgconnect/swift.properties
trunk/tests/sites/osgconnect/tc.template.data
trunk/tests/sites/osgconnect/title.txt
Log:
Adding sanity tests for OSG Connect
Added: trunk/tests/sites/osgconnect/osgc_sanity.setup.sh
--- trunk/tests/sites/osgconnect/osgc_sanity.setup.sh (rev 0)
+++ trunk/tests/sites/osgconnect/osgc_sanity.setup.sh 2013-10-09 15:07:42 UTC (rev 7146)
@@ -0,0 +1,11 @@
+#!/bin/bash
+USERNAME=$UC3_USERNAME
+if [[ -z $USERNAME ]]
+then
+ echo "Remote username not provided. Skipping sites configs"
+else
+ ls *xml
+ cat sites.xml | sed "s/{env.USER}/$USERNAME/" > tmp && mv tmp sites.xml
+fi
Property changes on: trunk/tests/sites/osgconnect/osgc_sanity.setup.sh
___________________________________________________________________
Added: svn:executable
Added: trunk/tests/sites/osgconnect/osgc_sanity.source.sh
--- trunk/tests/sites/osgconnect/osgc_sanity.source.sh (rev 0)
+++ trunk/tests/sites/osgconnect/osgc_sanity.source.sh 2013-10-09 15:07:42 UTC (rev 7146)
@@ -0,0 +1,6 @@
+#!/bin/bash
+if [ "$HOSTNAME" == "midway001" ]
+then
+ export GLOBUS_HOSTNAME=swift.rcc.uchicago.edu
+ export GLOBUS_TCP_PORT_RANGE=50000,51000
+fi;
Property changes on: trunk/tests/sites/osgconnect/osgc_sanity.source.sh
Added: trunk/tests/sites/osgconnect/osgc_sanity.swift
--- trunk/tests/sites/osgconnect/osgc_sanity.swift (rev 0)
+++ trunk/tests/sites/osgconnect/osgc_sanity.swift 2013-10-09 15:07:42 UTC (rev 7146)
@@ -0,0 +1,11 @@
+type file;
+app (file out, file err) remote_driver ()
+ date stdout=@filename(out) stderr=@filename(err);
+file driver_out <simple_mapper; prefix="sanity", suffix=".out">;
+file driver_err <simple_mapper; prefix="sanity", suffix=".err">;
+(driver_out, driver_err) = remote_driver();
\ No newline at end of file
Added: trunk/tests/sites/osgconnect/osgc_sanity.timeout
--- trunk/tests/sites/osgconnect/osgc_sanity.timeout (rev 0)
+++ trunk/tests/sites/osgconnect/osgc_sanity.timeout 2013-10-09 15:07:42 UTC (rev 7146)
@@ -0,0 +1 @@
+500
Added: trunk/tests/sites/osgconnect/sites.template.xml
--- trunk/tests/sites/osgconnect/sites.template.xml (rev 0)
+++ trunk/tests/sites/osgconnect/sites.template.xml 2013-10-09 15:07:42 UTC (rev 7146)
@@ -0,0 +1,20 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
+ <pool handle="osgc">
+ <execution provider="coaster" url="login01.osgconnect.net" jobmanager="ssh-cl:condor"/>
+ <profile namespace="karajan" key="jobThrottle">10.00</profile>
+ <profile namespace="karajan" key="initialScore">10000</profile>
+ <profile namespace="globus" key="jobsPerNode">1</profile>
+ <profile namespace="globus" key="maxtime">3600</profile>
+ <profile namespace="globus" key="maxWalltime">00:30:00</profile>
+ <profile namespace="globus" key="highOverAllocation">100</profile>
+ <profile namespace="globus" key="lowOverAllocation">100</profile>
+ <profile namespace="globus" key="slots">1</profile>
+ <profile namespace="globus" key="maxNodes">1</profile>
+ <profile namespace="globus" key="nodeGranularity">1</profile>
+ <profile namespace="globus" key="jobType">nonshared</profile>
+ <profile namespace="globus" key="condor.+ProjectName">"Swift"</profile>
+ <workdirectory>.</workdirectory>
+ </pool>
+</config>
Added: trunk/tests/sites/osgconnect/swift.properties
--- trunk/tests/sites/osgconnect/swift.properties (rev 0)
+++ trunk/tests/sites/osgconnect/swift.properties 2013-10-09 15:07:42 UTC (rev 7146)
@@ -0,0 +1,8 @@
+use.provider.staging=true
+use.wrapper.staging=false
+wrapperlog.always.transfer=true
+execution.retries=0
+lazy.errors=false
+provider.staging.pin.swiftfiles=false
+sitedir.keep=true
+tcp.port.range=50000,51000
Added: trunk/tests/sites/osgconnect/tc.template.data
--- trunk/tests/sites/osgconnect/tc.template.data (rev 0)
+++ trunk/tests/sites/osgconnect/tc.template.data 2013-10-09 15:07:42 UTC (rev 7146)
@@ -0,0 +1,6 @@
+local date /bin/date null null null
+beagle date /bin/date null null null
+uc3 date /bin/date null null null
+mcs date /bin/date null null null
+midway date /bin/date null null null
+osgc date /bin/date null null null
Added: trunk/tests/sites/osgconnect/title.txt
--- trunk/tests/sites/osgconnect/title.txt (rev 0)
+++ trunk/tests/sites/osgconnect/title.txt 2013-10-09 15:07:42 UTC (rev 7146)
@@ -0,0 +1 @@
+OSG-Connect remote sanity test
More information about the Swift-commit
